[GRASS-SVN] r65233 - grass/branches/releasebranch_7_0/raster/r.compress
Wed May 13 04:38:09 PDT 2015
Author: neteler
Date: 2015-05-13 04:38:09 -0700 (Wed, 13 May 2015)
New Revision: 65233
   grass/branches/releasebranch_7_0/raster/r.compress/main.c
   grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html
r.compress: print flag added; examples added; mention GRASS_ZLIB_LEVEL (trunk, r65115 + r65118)
Modified: grass/branches/releasebranch_7_0/raster/r.compress/main.c
--- grass/branches/releasebranch_7_0/raster/r.compress/main.c	2015-05-13 08:06:40 UTC (rev 65232)
+++ grass/branches/releasebranch_7_0/raster/r.compress/main.c	2015-05-13 11:38:09 UTC (rev 65233)
@@ -8,7 +8,7 @@
  * PURPOSE:      Compress and decompress raster map files.
- * COPYRIGHT:    (C) 2003 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2003-2015 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -20,6 +20,7 @@
  * compress_cell converts straight grid_cell files into compressed grid_cell
  * files.  Compressed files have the following format:
+ * RLE:
  *  - Array of addresses pointing to the internal start of each row
  *    First byte of each row is the nuber of bytes per cell for that row
  *    Remainder of the row is a series of byte groups that describe the data:
@@ -45,6 +46,7 @@
 static off_t newsize, oldsize;
 static int process(char *, int);
+static int pprint(char *, int);
 static int doit(char *, int, RASTER_MAP_TYPE);
 int main(int argc, char *argv[])
@@ -54,13 +56,14 @@
     char *name;
     struct GModule *module;
     struct Option *map;
-    struct Flag *uncompress;
+    struct Flag *uncompress, *pflag;
     G_gisinit(argv[0]);
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("map management"));
+    G_add_keyword(_("compression"));
     module->description = _("Compresses and decompresses raster maps.");
     map = G_define_option();
@@ -75,9 +78,19 @@
     uncompress->key = 'u';
     uncompress->description = _("Uncompress the map");
+    pflag = G_define_flag();
+    pflag->key = 'p';
+    pflag->description = _("Print compression information and data type of input map(s)");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    if(pflag->answer) {
+        for (n = 0; (name = map->answers[n]); n++)
+            pprint(name, pflag->answer);
+        exit(EXIT_SUCCESS);
     stat = 0;
 	if (process(name, uncompress->answer))
@@ -95,26 +108,26 @@
     int colr_ok;
     int hist_ok;
     int cats_ok;
-    int quant_ok;
+    int quant_ok=0;
     off_t diff;
     RASTER_MAP_TYPE map_type;
     char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
     if (G_find_raster(name, G_mapset()) == NULL) {
-	G_warning(_("[%s] not found"), name);
+	G_warning(_("Raster map <%s> not found"), name);
 	return 1;
     if (Rast_is_reclass(name, G_mapset(), rname, rmapset) > 0) {
 	G_warning(uncompress
-		  _("[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress")
+		  _("<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress")
-		  _("[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"),
+		  _("<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"),
 		  name, rname, rmapset);
 	return 1;
     if (G_find_file2_misc("cell_misc", "gdal", name, G_mapset())) {
-	G_warning(_("[%s] is a GDAL-linked map - can't (un)compress"), name);
+	G_warning(_("<%s> is a GDAL-linked map - can't (un)compress"), name);
 	return 1;
@@ -180,15 +193,15 @@
     /* check if already compressed/decompressed */
     if (uncompress && cellhd.compressed == 0) {
-	G_warning(_("[%s] already uncompressed"), name);
+	G_warning(_("<%s> already uncompressed"), name);
 	return 1;
     else if (!uncompress && cellhd.compressed > 0) {
-	G_warning(_("[%s] already compressed"), name);
+	G_warning(_("<%s> already compressed"), name);
 	return 1;
-    G_message(_("\n%sCOMPRESS [%s]"), uncompress ? "UN" : "", name);
+    G_message(_("\n%sCOMPRESS <%s>"), uncompress ? "UN" : "", name);
     Rast_set_window(&cellhd);
@@ -231,3 +244,59 @@
     Rast_close(old);
     return 0;
+static int pprint(char *name, int printstyle)
+    struct Cell_head cellhd;
+    char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+    int done;
+    RASTER_MAP_TYPE map_type;
+    if (G_find_raster(name, G_mapset()) == NULL) {
+        return 1;
+    if (G_find_file2_misc("cell_misc", "gdal", name, G_mapset())) {
+        G_message(_("<%s> is a GDAL-linked map"), name);
+        return 1;
+    Rast_get_cellhd(name, G_mapset(), &cellhd);
+    map_type = Rast_map_type(name, G_mapset());
+    done = 0;
+    if (Rast_is_reclass(name, G_mapset(), rname, rmapset) > 0) {
+        G_message(_("<%s> is a reclass file of map <%s> in mapset <%s>"),
+                  name, rname, rmapset);
+        done = 1;
+        done = 1;
+    /* Integer (CELL) compression:
+     *    cellhd.compressed == 0: uncompressed
+     *    cellhd.compressed == 1: RLE compressed
+     *    cellhd.compressed == 2: DEFLATE compressed
+    if (!done && cellhd.compressed == 0) {
+        G_message(_("<%s> is uncompressed (level %i: %s). Data type: <%s>"), name, cellhd.compressed,
+                    "NONE",
+                     (map_type == CELL_TYPE ? "CELL" :
+                       (map_type == DCELL_TYPE ? "DCELL" :
+                         (map_type == FCELL_TYPE ? "FCELL" : "??"))));
+    else if (!done && cellhd.compressed > 0) {
+        G_message(_("<%s> is compressed (level %i: %s). Data type: <%s>"), name, cellhd.compressed,
+                    cellhd.compressed == 1 ? "RLE" : "DEFLATE",
+    return 0;
Modified: grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html
--- grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html	2015-05-13 08:06:40 UTC (rev 65232)
+++ grass/branches/releasebranch_7_0/raster/r.compress/r.compress.html	2015-05-13 11:38:09 UTC (rev 65233)
@@ -1,7 +1,8 @@
 <h2>DESCRIPTION</h2>
 <em>r.compress</em> can be used to compress and decompress
-raster map layers.
+raster map layers. Additionally, it prints information about the
+map compression and data type of the input raster map(s).
 <p>
 During compression, this program reformats raster maps using a run-length-encoding
@@ -51,10 +52,11 @@
 <p>
 Integer (CELL) raster maps are by default ZLIB compressed or may remain
 uncompressed. If the environment variable <tt>GRASS_INT_ZLIB</tt>
-exists and has the value 0, newly generated compressed integer (CELL type) raster maps will
-be compressed using RLE compression instead of ZLIB. In the internal
-cellhd file, the value for "compressed" is 1 for RLE and 2 for ZLIB.
+exists and has the value 0, newly generated compressed integer (CELL type)
+raster maps will be compressed using RLE compression instead of ZLIB.
 <p>
+In the internal cellhd file, the value for "compressed" is 1 for RLE and 2 for ZLIB.
+<p>
 Obviously, decompression is controlled by the raster map's compression,
 not the environment variable.
@@ -150,9 +152,62 @@
 only be larger by the size of the address array and the
 single byte preceding each row.
+<p>
+Since GRASS GIS 7.0.0, the default compression method for
+ Integer (CELL) maps is deflate and not any more the RLE compression.
+<h4>DEFLATE compression level</h4>
+If the environment variable <tt>GRASS_ZLIB_LEVEL</tt> exists and
+its value can be parsed as an integer, it determines the compression
+level used when newly generated raster maps are compressed using zlib
+compression. This applies to all raster map types (CELL, FCELL, DCELL).
+<p>
+If the variable does not exist, or the value cannot be parsed as an
+integer, zlib's default compression level will be used.
+<h2>EXAMPLES</h2>
+Printing of current compression state:
+<div class="code"><pre>
+r.compress compressed_no -p
+  <compressed_no> (level 0: NONE). Data type: <CELL>
+</pre></div>
+<p>
+Applying RLE compression to a copy of the uncompressed map:
+# compression of map using RLE compression
+g.copy raster=compressed_no,compressed_RLE
+export GRASS_INT_ZLIB=0 # RLE
+r.compress compressed_RLE
+r.compress compressed_RLE -p
+  <compressed_RLE> is compressed (level 1: RLE). Data type: <CELL>
+unset GRASS_INT_ZLIB
+</pre></div>
+<p>
+Applying DEFLATE (ZLIB) compression to a copy of the uncompressed map:
+# compression of map using DEFLATE compression
+g.copy raster=compressed_no,compressed_DEFLATE
+export GRASS_INT_ZLIB=1 # deflate
+r.compress compressed_DEFLATE
+r.compress compressed_DEFLATE -p
+  <compressed_DEFLATE> is compressed (level 2: DEFLATE). Data type: <CELL>
+</pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="r.support.html">r.support</a></em>
+<em>
+<a href="r.info.html">r.info</a>,
+<a href="r.support.html">r.support</a>
+</em>
 <h2>AUTHORS</h2>
