[GRASS-SVN] r65266 - in grass-addons/grass7/raster/r.green/r.green.biomassfor: . r.green.biomassfor.co2
Mon May 18 05:52:31 PDT 2015
Author: zarch
Date: 2015-05-18 05:52:31 -0700 (Mon, 18 May 2015)
New Revision: 65266
Added:
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/Makefile
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.html
   grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py
   grass-addons/grass7/raster/r.green/r.green.biomassfor/Makefile
Add biomassfor CO2 module
Modified: grass-addons/grass7/raster/r.green/r.green.biomassfor/Makefile
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/Makefile	2015-05-18 09:16:55 UTC (rev 65265)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/Makefile	2015-05-18 12:52:31 UTC (rev 65266)
@@ -8,6 +8,7 @@
           r.green.biomassfor.technical \
           r.green.biomassfor.legal \
           r.green.biomassfor.impact \
+          r.green.biomassfor.co2
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/Makefile
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/Makefile	2015-05-18 12:52:31 UTC (rev 65266)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../../..
+PGM = r.green.biomassfor.co2
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.html
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.html	2015-05-18 12:52:31 UTC (rev 65266)
@@ -0,0 +1,22 @@
+<h2>DESCRIPTION</h2>
+Compute the co2 emissions of using biomass forestry residuals for energy production.
+<h2>NOTES</h2>
+<h2>EXAMPLE</h2>
+<h2>REFERENCE</h2>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="r.green.html">r.green</a>,
+  <a href="r.green.biomassfor.html">r.green.biomassfor</a>
+</em>
+<h2>AUTHORS</h2>
+Francesco Geri,
+Pietro Zambelli,
+Sandro Sacchelli
+<p><i>Last changed: $Date: 2015-04-20 17:48:56 +0200 (Mon, 20 Apr 2015) $</i></p>
\ No newline at end of file
Added: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py
--- grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py	2015-05-18 12:52:31 UTC (rev 65266)
@@ -0,0 +1,575 @@
+#!/usr/bin/env python
+# -- coding: utf-8 --
+# MODULE:      r.green.biomassfor.co2
+# AUTHOR(S):   Sandro Sacchelli, Francesco Geri
+#              Converted to Python by Francesco Geri, reviewed by Marco Ciolli
+# PURPOSE:     Calculates impacts and multifunctionality values regarding fertility maintenance,
+#              soil water protection, biodiversity, sustainable bioenergy,
+#              avoided CO2 emission, fire risk, recreation
+# COPYRIGHT:   (C) 2013 by the GRASS Development Team
+#              This program is free software under the GNU General Public
+#              License (>=v2). Read the file COPYING that comes with GRASS
+#              for details.
+#%Module
+#% description: Calculates impact and multifunctionality values
+#% keyword: raster
+#% keyword: biomass
+#%End
+#%option G_OPT_V_INPUT
+#% key: forest
+#% type: string
+#% description: Name of vector parcel map
+#% label: Name of vector parcel map
+#% required : yes
+#%end
+#% key: boundaries
+#% type: string
+#% description: Name of vector boundaries map (boolean map)
+#% label: Name of vector boundaries map (boolean map)
+#% required : yes
+#%end
+#%option
+#% key: forest_column_yield
+#% type: string
+#% description: Vector field of yield
+#% required : yes
+#%end
+#%option
+#% key: forest_column_yield_surface
+#% type: string
+#% description: Vector field of stand surface (ha)
+#% required : yes
+#%end
+#%option
+#% key: forest_column_management
+#% type: string
+#% description: Vector field of forest management (1: high forest, 2:coppice)
+#% required : yes
+#%end
+#%option
+#% key: forest_column_treatment
+#% type: string
+#% description: Vector field of forest treatment (1: final felling, 2:thinning)
+#% required : yes
+#%end
+#% key: forest_roads
+#% type: string
+#% description: Vector map of forest roads
+#% label: Vector map of forest roads
+#% required : yes
+#%end
+#%option
+#% key: forest_column_roughness
+#% type: string
+#% description: Vector field of roughness
+#% required : no
+#% guisection: Opt files
+#%end
+#% key: rivers
+#% type: string
+#% description: Vector map of rivers
+#% label: Vector map of rivers
+#% required : no
+#%end
+#% key: lakes
+#% type: string
+#% description: Vector map of lakes
+#% label: Vector map of lakes
+#% required : no
+#%end
+#%option
+#% key: energy_tops_hf
+#% type: double
+#% description: Energy for tops and branches in high forest in MWh/m³
+#% answer: 0.49
+#% guisection: Energy
+#%end
+#%option
+#% key: energy_cormometric_vol_hf
+#% type: double
+#% description: Energy for tops and branches for high forest in MWh/m³
+#% answer: 1.97
+#%end
+#%option
+#% key: energy_tops_cop
+#% type: double
+#% description: Energy for tops and branches for Coppices in MWh/m³
+#% answer: 0.55
+#%end
+#%option G_OPT_R_INPUT
+#% key: energy_map
+#% description: Bioenergy map in MWh/m³
+#% required : yes
+#%end
+#% key: dhp
+#% type: string
+#% description: Name of vector district heating points
+#% label: Name of vector district heating points
+#% required : yes
+#%end
+#%option
+#% key: output_basename_co2map
+#% type: string
+#% gisprompt: new
+#% description: Name for output CO2 emissions map
+#% key_desc : name
+#% guisection: CO2 Emission
+#%end
+#%option
+#% key: output_basename_aco2map
+#% type: string
+#% gisprompt: new
+#% description: Name for output avoided CO2 emissions map
+#% key_desc : name
+#%end
+#%option
+#% key: output_basename_nco2map
+#% type: string
+#% gisprompt: new
+#% description: Name for output net CO2 emissions map
+#% key_desc : name
+#%end
+#% key: dtm
+#% type: string
+#% description: Name of Digital terrain model map
+#% required : no
+#% guisection : CO2 Emission
+#%end
+#%option
+#% type: string
+#% required : no
+#%end
+#% key: soilp2_map
+#% type: string
+#% description: Soil production map
+#% required : no
+#%end
+#% key: tree_diam
+#% type: string
+#% description: Average tree diameter map
+#% required : no
+#%end
+#% key: tree_vol
+#% type: string
+#% description: Average tree volume map
+#% required : no
+#%end
+#% key: main_roads
+#% type: string
+#% description: Vector map of main roads
+#% label: Vector map of main roads
+#% required : no
+#%end
+#%option
+#% key: slp_min_cc
+#% type: double
+#% description: Percent slope lower limit with Cable Crane
+#% answer: 30.
+#% required : no
+#%end
+#%option
+#% key: slp_max_cc
+#% type: double
+#% description: Percent slope higher limit with Cable Crane
+#% answer: 100.
+#% required : no
+#%end
+#%option
+#% key: dist_max_cc
+#% type: double
+#% description: Maximum distance with Cable Crane
+#% answer: 800.
+#% required : no
+#%end
+#%option
+#% key: slp_max_fw
+#% type: double
+#% description: Percent slope higher limit with Forwarder
+#% answer: 30.
+#% required : no
+#%end
+#%option
+#% key: dist_max_fw
+#% type: double
+#% description: Maximum distance with Forwarder
+#% answer: 600.
+#% required : no
+#%end
+#%option
+#% key: slp_max_cop
+#% type: double
+#% description: Percent slope higher limit with other techniques for Coppices
+#% answer: 30.
+#% required : no
+#%end
+#%option
+#% key: dist_max_cop
+#% type: double
+#% description: Maximum distance with other techniques for Coppices
+#% answer: 600.
+#% required : no
+#%end
+#%flag
+#% key: r
+#% description: Remove all operational maps
+#%end
+import grass.script as grass
+from grass.script.core import run_command, parser,overwrite, read_command
+from grass.pygrass.messages import get_msgr
+import numpy as np
+from grass.pygrass.raster import RasterRow
+import pdb
+ow = overwrite()
+def yield_pix_process(opts, flgs,yield_,yield_surface):
+    YPIX = ''
+    expr_surf='analysis_surface='+opts['energy_map']+'>0'
+    run_command('r.mapcalc', overwrite=ow,expression=expr_surf)
+    run_command("r.mapcalc", overwrite=ow,
+        expression='yield_pix1 = ('+yield_+'/'+yield_surface+')*((ewres()*nsres())/10000)')
+    run_command("r.null", map="yield_pix1", null=0)
+    run_command("r.mapcalc", overwrite=ow,expression="yield_pix=yield_pix1")
+def avoided_CO2_emission(opts, flgs):
+    forest=opts['forest']
+    boundaries=opts['boundaries']
+    yield_=opts['forest_column_yield']
+    management=opts['forest_column_management']
+    treatment=opts['forest_column_treatment']
+    yield_surface=opts['forest_column_yield_surface']
+    roughness=opts['forest_column_roughness']
+    forest_roads=opts['forest_roads']
+    main_roads=opts['main_roads']
+    tree_diam=opts['tree_diam']
+    tree_vol=opts['tree_vol']
+    soil_prod=opts['soilp2_map']
+    rivers=opts['rivers']
+    lakes=opts['lakes']
+    dhp=opts['dhp']
+    vector_forest=opts['forest']
+    ######## start import and convert ########
+    run_command("g.region",vect=boundaries)
+    run_command("v.to.rast", input=forest,output="yield", use="attr", attrcolumn=yield_,overwrite=True)
+    run_command("v.to.rast", input=forest,output="yield_surface", use="attr", attrcolumn=yield_surface,overwrite=True)
+    run_command("v.to.rast", input=forest,output="treatment", use="attr", attrcolumn=treatment,overwrite=True)
+    run_command("v.to.rast", input=forest,output="management", use="attr", attrcolumn=management,overwrite=True)
+    run_command("v.to.rast", input=forest_roads,output="forest_roads", use="val", overwrite=True)
+    run_command("v.to.rast", input=main_roads,output="main_roads", use="val", overwrite=True)
+    run_command("r.null", map='yield',null=0)
+    run_command("r.null", map='yield_surface',null=0)
+    run_command("r.null", map='treatment',null=0)
+    run_command("r.null", map='management',null=0)
+    ######## end import and convert ########
+    ######## temp patch to link map and fields ######
+    management="management"
+    treatment="treatment"
+    yield_surface="yield_surface"
+    yield_="yield"
+    forest_roads="forest_roads"
+    main_roads="main_roads"
+    ######## end temp patch to link map and fields ######
+    if roughness=='':
+        run_command("r.mapcalc",overwrite=ow,expression='roughness=0')
+        roughness='roughness'
+    else:
+        run_command("v.to.rast", input=forest,output="roughness", use="attr", attrcolumn=roughness,overwrite=True)
+        run_command("r.null", map='roughness',null=0)
+    if tree_diam=='':
+        run_command("r.mapcalc",overwrite=ow,expression='tree_diam=99999')
+        tree_diam='tree_diam'
+    if tree_vol=='':
+        run_command("r.mapcalc",overwrite=ow,expression='tree_vol=9.999')
+        tree_vol='tree_vol'
+    if soil_prod=='':
+        run_command("r.mapcalc",overwrite=ow,expression='soil_map=99999')
+        soil_prod='soil_map'
+    #process the yield_pix map
+    yield_pix_process(opts, flgs,yield_,yield_surface)
+    #control and process the slope map
+    run_command("r.slope.aspect", overwrite=ow,elevation=opts['dtm'], slope="slope__", format="percent")
+    run_command("r.slope.aspect", overwrite=ow,elevation=opts['dtm'], slope="slope_deg__")
+    run_command("r.param.scale", overwrite=ow,
+                input=opts['dtm'], output="morphometric_features",
+                size=3, method="feature")
+    #process the preparatory maps
+            expression='pix_cross = ((ewres()+nsres())/2)/ cos(slope_deg__)')
+    run_command("r.null", map="morphometric_features", null=0)
+    exprmap='frict_surf_extr = pix_cross + if(yield_pix1<=0, 99999) + if(morphometric_features==6, 99999)'
+    if rivers!='':
+        run_command("v.to.rast", input=rivers,output="rivers", use="val", overwrite=True)
+        run_command("r.null", map="rivers", null=0)
+        rivers="rivers"
+        exprmap+='+ if('+rivers+'>=1, 99999)'
+    if lakes!='':
+        run_command("v.to.rast", input=lakes,output="lakes", use="val", overwrite=True)
+        run_command("r.null", map="lakes", null=0)
+        lakes="lakes"
+        exprmap+='+ if('+lakes+'>=1, 99999)'
+    run_command("r.mapcalc",overwrite=ow,expression=exprmap)
+    run_command("r.cost", overwrite=ow,
+            input="frict_surf_extr", output="extr_dist",
+            stop_points=vector_forest, start_rast=forest_roads,
+            max_cost=1500)
+    CCEXTR = 'cable_crane_extraction = if('+yield_+'>0 && slope__>'+opts['slp_min_cc']+' && slope__<='+opts['slp_max_cc']+' && extr_dist<'+opts['dist_max_cc']+', 1)'
+    FWEXTR = 'forwarder_extraction = if('+yield_+'>0 && slope__<='+opts['slp_max_fw']+' && '+management+'==1 && ('+roughness+'==0 || '+roughness+'==1 || '+roughness+'==99999) && extr_dist<'+opts['dist_max_fw']+', 1)'
+    OEXTR = 'other_extraction = if('+yield_+'>0 && slope__<='+opts['slp_max_cop']+' && '+management+'==2 && ('+roughness+'==0 || '+roughness+'==1 || '+roughness+'==99999) && extr_dist<'+opts['dist_max_cop']+', 1)'
+    run_command("r.mapcalc", overwrite=ow,expression=CCEXTR)
+    run_command("r.mapcalc", overwrite=ow,expression=FWEXTR)
+    run_command("r.mapcalc", overwrite=ow,expression=OEXTR)
+    run_command("r.mapcalc",overwrite=ow,expression="slope___=if(slope__<=100,slope__,100)")
+    # Calculate productivity
+    #view the paper appendix for the formulas
+                expression='fell_productHFtr1 = if('+management+' ==1 && ('+treatment+' ==1 || '+treatment+' ==99999) && '+tree_diam+' <99999,(cable_crane_extraction*(42-(2.6*'+tree_diam+'))/(-20))*1.65*(1-(slope___/100)), if('+management+' ==1 && ('+treatment+' ==1 || '+treatment+' ==99999) && '+tree_diam+' == 99999,(cable_crane_extraction*(42-(2.6*35))/(-20))*1.65*(1-(slope___/100))))')
+    run_command("r.null", map="fell_productHFtr1", null=0)
+                expression='fell_productHFtr2 = if('+management+' ==1 && '+treatment+' ==2 && '+tree_diam+' <99999,(cable_crane_extraction*(42-(2.6*'+tree_diam+'))/(-20))*1.65*(1-((1000-(90*slope___)/(-80))/100)), if('+management+' ==1 && '+treatment+' ==2 && '+tree_diam+' == 99999,(cable_crane_extraction*(42-(2.6*35))/(-20))*1.65*(1-((1000-(90*slope___)/(-80))/100))))')
+    run_command("r.null", map="fell_productHFtr2", null=0)
+                expression='fell_proc_productC = if('+management+' ==2 && '+soil_prod+' <99999,((0.3-(1.1*'+soil_prod+'))/(-4))*(1-(slope___/100)), if('+management+' ==2 && '+soil_prod+' == 99999,((0.3-(1.1*3))/(-4))*(1-(slope___/100))))')
+    run_command("r.null", map="fell_proc_productC", null=0)
+    ###### check fell_proc_productC ######
+    #9999: default value, if is present take into the process the average value (in case of fertility is 33)
+    #r.mapcalc --o 'fell_proc_productC = if(management at PERMANENT ==2 && soil_prod at PERMANENT <99999,((0.3-(1.1*soil_prod at PERMANENT))/(-4))*(1-(slope at PERMANENT/100)), if(management at PERMANENT ==2 && soil_prod at PERMANENT == 99999,((0.3-(1.1*3))/(-4))*(1-((1000-(90*slope at PERMANENT)/(-80))/100))))'
+    #import ipdb; ipdb.set_trace()
+                expression='proc_productHFtr1 = if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'==99999, cable_crane_extraction*0.363*35^1.116, if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_diam+'<99999, cable_crane_extraction*0.363*'+tree_diam+'^1.116))')
+    run_command("r.null", map="proc_productHFtr1", null=0)
+                expression='fell_proc_productHFtr1 = if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_vol+'<9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/'+tree_vol+')-0.1846*1)), if('+management+' == 1 && ('+treatment+' == 1 || '+treatment+' ==99999) && '+tree_vol+'==9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/0.7)-0.1846*1))))')
+    run_command("r.null", map="fell_proc_productHFtr1", null=0)
+                expression='fell_proc_productHFtr2 = if('+management+' == 1 && '+treatment+' == 2 && '+tree_vol+'<9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/'+tree_vol+')-0.1846*1))*0.8, if('+management+' == 1 && '+treatment+' == 2 && '+tree_vol+'==9.999, forwarder_extraction*60/(1.5*(2.71^(0.1480-0.3894*2+0.0002*(slope___^2)-0.2674*2.5))+(1.0667+(0.3094/0.7)-0.1846*1))*0.8))')
+    run_command("r.null", map="fell_proc_productHFtr2", null=0)
+                expression='chipp_prodHF = if('+management+' ==1 && ('+treatment+' == 1 ||  '+treatment+' == 99999), yield_pix/34, if('+management+' ==1 && '+treatment+' == 2, yield_pix/20.1))')
+    run_command("r.null", map="chipp_prodHF", null=0)
+                expression='chipp_prodC = if('+management+' ==2, yield_pix/45.9)')
+    run_command("r.null", map="chipp_prodC", null=0)
+                expression='chipp_prod = chipp_prodHF + chipp_prodC')
+    run_command("r.null", map="chipp_prod", null=0)
+                expression='extr_product_cableHF = if('+management+' ==1, cable_crane_extraction*149.33*(extr_dist^-1.3438)* extr_dist/8*0.75)')
+    run_command("r.null", map="extr_product_cableHF", null=0)
+                expression='extr_product_cableC = if('+management+' ==2, cable_crane_extraction*149.33*(extr_dist^-1.3438)* extr_dist/8*0.75)')
+    run_command("r.null", map="extr_product_cableC", null=0)
+                expression='extr_product_forw = forwarder_extraction*36.293*(extr_dist^-1.1791)* extr_dist/8*0.6')
+    run_command("r.null", map="extr_product_forw", null=0)
+                expression='extr_product_other = other_extraction*36.293*(extr_dist^-1.1791)* extr_dist/8*0.6')
+    run_command("r.null", map="extr_product_other", null=0)
+    #cost of the transport distance
+    #this is becouse the wood must be sell to the collection point
+    #instead the residual must be brung to the heating points
+                expression='tot_roads = '+forest_roads+' ||| '+main_roads)
+    run_command("r.null", map="tot_roads", null=0)
+                expression='tot_roads_neg = if(tot_roads==1,0,1)')
+    run_command("r.null", map="tot_roads_neg", null=1)
+                expression='frict_surf_tr1 =  frict_surf_extr*tot_roads_neg')
+                expression='frict_surf_tr = frict_surf_tr1+(tot_roads*((ewres()+nsres())/2))')
+    #run_command("r.null", map=dhp, null=0)
+    try:
+        run_command("r.cost", overwrite=ow, input="frict_surf_tr",
+                    output="tot_dist", stop_points=opts['forest'], start_points=dhp,
+                    max_cost=100000)
+                    expression='transp_dist = tot_dist -  extr_dist')
+    except:
+                    expression='transp_dist = extr_dist')
+                expression='transport_prod = if(('+treatment+' == 1 ||  '+treatment+' == 99999), ((transp_dist/1000/30)*(yield_pix*1/32)*2), if('+management+' ==1 && '+treatment+' == 2, ((transp_dist/1000/30)*(yield_pix*2.7/32)*2)))')
+    # Avoided carbon dioxide emission
+                expression='fell_HFtr1_em = yield_pix/fell_productHFtr1*4.725')
+                expression='fell_HFtr2_em = yield_pix/fell_productHFtr2*4.725')
+                expression='fell_proc_C_em = yield_pix/fell_proc_productC*2.363')
+                expression='proc_HFtr1_em =  yield_pix/proc_productHFtr1*37.729')
+                expression='fell_proc_HFtr1_em = yield_pix/fell_proc_productHFtr1*36.899')
+                expression='fell_proc_HFtr2_em = yield_pix/fell_proc_productHFtr2*36.899')
+                expression='chipp_em = chipp_prod*130.599')
+                expression='extr_cableHF_em = yield_pix/extr_product_cableHF*20.730')
+                expression='extr_cableC_em = yield_pix/extr_product_cableC*12.956')
+                expression='extr_forw_em = yield_pix/extr_product_forw*25.394')
+                expression='extr_other_em = yield_pix/extr_product_other*15.548')
+                expression='transport_em =  transport_prod*24.041')
+    run_command("r.null", map='fell_HFtr1_em', null=0)
+    run_command("r.null", map='fell_HFtr2_em', null=0)
+    run_command("r.null", map='fell_proc_C_em', null=0)
+    run_command("r.null", map='proc_HFtr1_em', null=0)
+    run_command("r.null", map='fell_proc_HFtr1_em', null=0)
+    run_command("r.null", map='fell_proc_HFtr2_em', null=0)
+    run_command("r.null", map='chipp_em', null=0)
+    run_command("r.null", map='extr_cableHF_em', null=0)
+    run_command("r.null", map='extr_cableC_em', null=0)
+    run_command("r.null", map='extr_forw_em', null=0)
+    run_command("r.null", map='extr_other_em', null=0)
+    run_command("r.null", map='transport_em', null=0)
+    run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_co2map']+' = (analysis_surface*(fell_HFtr1_em  + fell_HFtr2_em + fell_proc_C_em + proc_HFtr1_em + fell_proc_HFtr1_em + fell_proc_HFtr2_em + chipp_em + extr_cableHF_em + extr_cableC_em + extr_forw_em + extr_other_em + transport_em))/1000')
+    run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_aco2map']+' = '+opts['energy_map']+'*320')
+    #run_command("r.mapcalc", overwrite=ow, expression=opts['output_netco2_map']+' = analysis_surface*'+('+opts['output_aco2_map']+' - '+opts['output_co2_map']+')/1000')
+    run_command("r.mapcalc", overwrite=ow, expression=opts['output_basename_nco2map']+' = analysis_surface*('+opts['output_basename_aco2map']+' - '+opts['output_basename_co2map']+')/1000')
+    mapco2=opts['output_basename_co2map']
+    with RasterRow(mapco2) as pT:
+        T = np.array(pT)
+    mapaco2=opts['output_basename_nco2map']
+    with RasterRow(mapaco2) as pT1:
+        A = np.array(pT1)
+    print ("Total emission (Tons): %.2f" % np.nansum(T))
+    print ("Total avoided emission (Tons): %.2f" % np.nansum(A))
+def main(opts, flgs):
+    avoided_CO2_emission(opts, flgs)
+if __name__ == "__main__":
+    main(*parser())
Property changes on: grass-addons/grass7/raster/r.green/r.green.biomassfor/r.green.biomassfor.co2/r.green.biomassfor.co2.py
___________________________________________________________________
Added: svn:executable
