[GRASS-SVN] r65323 - in grass/trunk: include/defs lib/raster
Tue May 26 04:52:15 PDT 2015
Author: glynn
Date: 2015-05-26 04:52:14 -0700 (Tue, 26 May 2015)
New Revision: 65323
   grass/trunk/include/defs/raster.h
   grass/trunk/lib/raster/close.c
   grass/trunk/lib/raster/open.c
Fix bugs in r65272 (compressed nulls)
Add Rast__open_null_write, Rast__close_null
Modified: grass/trunk/include/defs/raster.h
--- grass/trunk/include/defs/raster.h	2015-05-26 11:51:00 UTC (rev 65322)
+++ grass/trunk/include/defs/raster.h	2015-05-26 11:52:14 UTC (rev 65323)
@@ -100,6 +100,7 @@
 void Rast_close(int);
 void Rast_unopen(int);
 void Rast__unopen_all(void);
+void Rast__close_null(int);
 /* color_compat.c */
 void Rast_make_ryg_colors(struct Colors *, CELL, CELL);
@@ -454,6 +455,7 @@
 int Rast_open_new(const char *, RASTER_MAP_TYPE);
 int Rast_open_new_uncompressed(const char *, RASTER_MAP_TYPE);
 void Rast_set_quant_rules(int, struct Quant *);
+int Rast__open_null_write(const char *);
 /* put_cellhd.c */
 void Rast_put_cellhd(const char *, struct Cell_head *);
@@ -463,7 +465,6 @@
 void Rast_put_c_row(int, const CELL *);
 void Rast_put_f_row(int, const FCELL *);
 void Rast_put_d_row(int, const DCELL *);
-int Rast__open_null_write(int);
 void Rast__write_null_bits(int, const unsigned char *, int, int, int);
 /* put_title.c */
Modified: grass/trunk/lib/raster/close.c
--- grass/trunk/lib/raster/close.c	2015-05-26 11:51:00 UTC (rev 65322)
+++ grass/trunk/lib/raster/close.c	2015-05-26 11:52:14 UTC (rev 65323)
@@ -344,10 +344,6 @@
     if (fcb->gdal)
 	return close_new_gdal(fd, ok);
-    if (fcb->null_fd >= 0)
-	close(fcb->null_fd);
-    fcb->null_fd = -1;
     if (ok) {
 	switch (fcb->open_mode) {
 	case OPEN_NEW_COMPRESSED:
@@ -433,6 +429,10 @@
     close(fcb->data_fd);
     fcb->open_mode = -1;
+    if (fcb->null_fd >= 0)
+	close(fcb->null_fd);
+    fcb->null_fd = -1;
     if (fcb->data != NULL)
 	G_free(fcb->data);
@@ -479,6 +479,47 @@
     return stat;
+void Rast__close_null(int fd)
+    struct fileinfo *fcb = &R__.fileinfo[fd];
+    char path[GPATH_MAX];
+    if (fcb->null_row_ptr) {			/* compressed nulls */
+	fcb->null_row_ptr[fcb->cellhd.rows] = lseek(fcb->null_fd, 0L, SEEK_CUR);
+	Rast__write_null_row_ptrs(fd, fcb->null_fd);
+	G_free(fcb->null_row_ptr);
+    /* create path : full null file name */
+    G__make_mapset_element_misc("cell_misc", fcb->name);
+    G_file_name_misc(path, "cell_misc", NULL_FILE, fcb->name, G_mapset());
+    remove(path);
+    G_file_name_misc(path, "cell_misc", NULL2_FILE, fcb->name, G_mapset());
+    remove(path);
+		     fcb->null_row_ptr ? NULL2_FILE : NULL_FILE,
+		     fcb->name, G_mapset());
+    if (rename(fcb->null_temp_name, path))
+	G_warning(_("Unable to rename null file '%s' to '%s': %s"),
+		  fcb->null_temp_name, path, strerror(errno));
+    remove(fcb->null_temp_name);
+    G_free(fcb->null_temp_name);
+    G_free(fcb->name);
+    G_free(fcb->mapset);
+    G_free(fcb->null_bits);
+    fcb->open_mode = -1;
 /* returns 0 on success, 1 on failure */
 static void write_fp_format(int fd)
Modified: grass/trunk/lib/raster/open.c
--- grass/trunk/lib/raster/open.c	2015-05-26 11:51:00 UTC (rev 65322)
+++ grass/trunk/lib/raster/open.c	2015-05-26 11:52:14 UTC (rev 65323)
@@ -332,27 +332,21 @@
     fcb->null_row_ptr = NULL;
     if (!gdal) {
-	if (!G_find_file2_misc("cell_misc", NULL_FILE, r_name, r_mapset)) {
-	    /* G_warning("unable to find [%s]",path); */
-	    fcb->null_file_exists = 0;
-	else {
-	    /* First, check for compressed null file */
-	    fcb->null_fd = G_open_old_misc("cell_misc", NULL_FILE, r_name, r_mapset);
-	    if (fcb->null_fd < 0) {
-		fcb->null_fd = G_open_old_misc("cell_misc", NULL2_FILE, r_name, r_mapset);
-		if (fcb->null_fd >= 0) {
-		    fcb->null_row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
-		    if (Rast__read_null_row_ptrs(fd, fcb->null_fd) < 0) {
-			G_free(fcb->null_row_ptr);
-			fcb->null_row_ptr = NULL;
+	/* First, check for compressed null file */
+	fcb->null_fd = G_open_old_misc("cell_misc", NULL_FILE, r_name, r_mapset);
+	if (fcb->null_fd < 0) {
+	    fcb->null_fd = G_open_old_misc("cell_misc", NULL2_FILE, r_name, r_mapset);
+	    if (fcb->null_fd >= 0) {
+		fcb->null_row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
+		if (Rast__read_null_row_ptrs(fd, fcb->null_fd) < 0) {
+		    fcb->null_row_ptr = NULL;
-	    fcb->null_file_exists = fcb->null_fd >= 0;
+	fcb->null_file_exists = fcb->null_fd >= 0;
     return fd;
@@ -716,6 +710,60 @@
     return fd;
+int Rast__open_null_write(const char *name)
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    struct fileinfo *fcb;
+    int fd;
+    char *tempname;
+    char *map;
+    char *mapset;
+    Rast__init();
+    if (!G_find_raster2(name, G_mapset()))
+	G_fatal_error(_("Raster map <%s> does not exist in the current mapset (%s)"),
+		      name, G_mapset());
+    if (G_unqualified_name(name, G_mapset(), xname, xmapset) < 0)
+	G_fatal_error(_("Raster map <%s> is not in the current mapset (%s)"),
+    map = G_store(xname);
+    mapset = G_store(xmapset);
+    fd = new_fileinfo();
+    fcb = &R__.fileinfo[fd];
+    G_zero(fcb, sizeof(*fcb));
+    fcb->name = map;
+    fcb->mapset = mapset;
+    Rast_get_cellhd(map, mapset, &fcb->cellhd);
+    /* open a null tempfile name */
+    tempname = G_tempfile();
+    fcb->null_fd = creat(tempname, 0666);
+	G_free(tempname);
+	G_fatal_error(_("No temp files available: %s"), strerror(errno));
+    fcb->null_temp_name = tempname;
+    if (R__.compress_nulls) {
+	G_zero(fcb->row_ptr, (fcb->cellhd.rows + 1) * sizeof(off_t));
+    /* allocate null bitstream buffer for writing */
+    fcb->null_bits = Rast__allocate_null_bits(fcb->cellhd.cols);
+    return fd;
    \brief Set raster map floating-point data format.
