[GRASS-SVN] r66714 - in grass/trunk/raster/r.in.gdal: . testsuite testsuite/data
Mon Nov 2 04:11:17 PST 2015
Author: huhabla
Date: 2015-11-02 04:11:17 -0800 (Mon, 02 Nov 2015)
New Revision: 66714
Added:
   grass/trunk/raster/r.in.gdal/testsuite/
   grass/trunk/raster/r.in.gdal/testsuite/data/
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation.asc
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation.nc
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation.prj
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tif
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tiff
   grass/trunk/raster/r.in.gdal/testsuite/data/elevation3d.nc
   grass/trunk/raster/r.in.gdal/testsuite/data/generate_data.sh
   grass/trunk/raster/r.in.gdal/testsuite/test_r_in_gdal.py
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/raster/r.in.gdal/r.in.gdal.html
raster modules: Added number of band digits (option num_digits) and map names output file
(map_names_file option) to provide better support for raster time series from stacked raster layers like netCDF.
Added several tests and test-data based on the NC location.
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2015-11-02 11:11:47 UTC (rev 66713)
+++ grass/trunk/raster/r.in.gdal/main.c	2015-11-02 12:11:17 UTC (rev 66714)
@@ -68,12 +68,15 @@
     int projcomp_error = 0;
     int overwrite;
     int offset = 0;
+    char *suffix;
+    int num_digits = 0;
     struct GModule *module;
     struct
 	struct Option *input, *output, *target, *title, *outloc, *band,
-	              *memory, *offset, *rat;
+	              *memory, *offset, *num_digits, *map_names_file,
+	              *rat;
     } parm;
     struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c, *flag_p,
         *flag_j;
@@ -137,7 +140,21 @@
     parm.offset->answer = "0";
     parm.offset->description = _("The offset will be added to the band number while output raster map name creation");
     parm.offset->guisection = _("Metadata");
+    parm.num_digits = G_define_option();
+    parm.num_digits->key = "num_digits";
+    parm.num_digits->type = TYPE_INTEGER;
+    parm.num_digits->required = NO;
+    parm.num_digits->answer = "0";
+    parm.num_digits->description = _("Number of digits for the generated band number with leading 0's. If 0 the length will adjust to the band number.");
+    parm.num_digits->guisection = _("Metadata");
+    parm.map_names_file = G_define_standard_option(G_OPT_F_OUTPUT);
+    parm.map_names_file->key = "map_names_file";
+    parm.map_names_file->required = NO;
+    parm.map_names_file->description = _("Name of the output file that contains the imported map names");
+    parm.map_names_file->guisection = _("Metadata");
     parm.outloc = G_define_option();
     parm.outloc->key = "location";
     parm.outloc->type = TYPE_STRING;
@@ -212,8 +229,10 @@
     input = parm.input->answer;
     output = parm.output->answer;
     offset = atoi(parm.offset->answer);
+    num_digits = atoi(parm.num_digits->answer);
     if ((title = parm.title->answer))
 	G_strip(title);
@@ -233,6 +252,18 @@
     if (flag_l->answer && G_projection() != PROJECTION_LL)
 	G_fatal_error(_("The '-l' flag only works in Lat/Lon locations"));
+    if(num_digits < 0)
+        G_fatal_error(_("The number of digits for band numbering must be equal or greater than 0"));
+    /* Allocate the suffix string */
+    if(num_digits > 0) {
+        suffix = G_calloc( num_digits + 1, sizeof(char));
+    } else {
+        /* Band number length should not exceed 64 digits */
+        suffix = G_calloc(65, sizeof(char));
     /*      Fire up the engines.                                            */
@@ -593,7 +624,15 @@
 	char szBandName[512];
 	int nBand = 0;
 	char colornamebuf[512], colornamebuf2[512];
+	FILE *map_names_file = NULL;
+	if(parm.map_names_file->answer) {
+	    map_names_file = fopen(parm.map_names_file->answer, "w");
+	    if(map_names_file == NULL) {
+	        G_fatal_error(_("Unable to open the map names output text file"));
 	I_init_group_ref(&ref);
 	colornamebuf2[0] = '\0';
@@ -611,6 +650,13 @@
 		nBand++;
+            /* Generate the suffix */
+                G_snprintf(suffix, num_digits + 1, "%0*d", num_digits, nBand + offset);
+            } else {
+                G_snprintf(suffix, 65, "%d", nBand + offset);
 	    G_debug(3, "Import raster band %d", nBand);
 	    hBand = GDALGetRasterBand(hDS, nBand);
 	    if (!hBand)
@@ -623,21 +669,21 @@
 		/* check: two channels with identical name ? */
 		if (strcmp(colornamebuf, colornamebuf2) == 0)
-		    sprintf(colornamebuf, "%d", nBand + offset);
+		    sprintf(colornamebuf, "%s", suffix);
 		else
 		    strcpy(colornamebuf2, colornamebuf);
 		/* avoid bad color names; in case of 'Gray' often all channels are named 'Gray' */
 		if (strcmp(colornamebuf, "Undefined") == 0 ||
 		    strcmp(colornamebuf, "Gray") == 0)
-		    sprintf(szBandName, "%s.%d", output, nBand + offset);
+		    sprintf(szBandName, "%s.%s", output, suffix);
 		else {
 		    G_tolcase(colornamebuf);
 		    sprintf(szBandName, "%s.%s", output, colornamebuf);
 	    else
             if (!parm.outloc->answer) {	/* Check if the map exists */
               if (G_find_raster2(szBandName, G_mapset())) {
@@ -651,10 +697,16 @@
 	    ImportBand(hBand, szBandName, &ref);
+	    if(map_names_file)
+	        fprintf(map_names_file, "%s\n", szBandName);
 	    if (title)
 		Rast_put_cell_title(szBandName, title);
+	    fclose(map_names_file);
 	I_put_group_ref(output, &ref);
 	I_free_group_ref(&ref);
Modified: grass/trunk/raster/r.in.gdal/r.in.gdal.html
--- grass/trunk/raster/r.in.gdal/r.in.gdal.html	2015-11-02 11:11:47 UTC (rev 66713)
+++ grass/trunk/raster/r.in.gdal/r.in.gdal.html	2015-11-02 12:11:17 UTC (rev 66714)
@@ -233,40 +233,45 @@
 <h3>ECAD Data</h3>
 The <a href="http://eca.knmi.nl/">European Climate Assessment and Dataset (ECAD) project</a>
-provides climate data for europe ranging from 1950 - 2010. To import the different
+provides climate data for Europe ranging from 1950 - 2010 or later. To import the different
 chunks of data provided by the project as netCDF files, the offset parameter can be used to get
 daily numbered raster maps from 1. Jan. 1950 on. Make sure you are in a LatLong location.
+<p>
+Use the <em>num_digits</em> option to allow chronological numbering of the imported raster map layers,
+so that <em>g.list</em> list's them in the correct import order. Use <em>num_digits=5</em>
+to have a 5 digit suffix with leading zeros (00001 - 99999).
+</p>
 <div class="code"><pre>
 # Import precipitation data
-r.in.gdal -o input=rr_0.25deg_reg_1950-1964_v4.0.nc output=precipitation offset=0
-r.in.gdal -o input=rr_0.25deg_reg_1965-1979_v4.0.nc output=precipitation offset=5479
-r.in.gdal -o input=rr_0.25deg_reg_1980-1994_v4.0.nc output=precipitation offset=10957
-r.in.gdal -o input=rr_0.25deg_reg_1995-2010_v4.0.nc output=precipitation offset=16436
+r.in.gdal -o input=rr_0.25deg_reg_1950-1964_v4.0.nc output=precipitation num_digits=5 offset=0
+r.in.gdal -o input=rr_0.25deg_reg_1965-1979_v4.0.nc output=precipitation num_digits=5 offset=5479
+r.in.gdal -o input=rr_0.25deg_reg_1980-1994_v4.0.nc output=precipitation num_digits=5 offset=10957
+r.in.gdal -o input=rr_0.25deg_reg_1995-2010_v4.0.nc output=precipitation num_digits=5 offset=16436
 # Import air pressure data
-r.in.gdal -o input=pp_0.25deg_reg_1950-1964_v4.0.nc output=air_pressure offset=0
-r.in.gdal -o input=pp_0.25deg_reg_1965-1979_v4.0.nc output=air_pressure offset=5479
-r.in.gdal -o input=pp_0.25deg_reg_1980-1994_v4.0.nc output=air_pressure offset=10957
-r.in.gdal -o input=pp_0.25deg_reg_1995-2010_v4.0.nc output=air_pressure offset=16436
+r.in.gdal -o input=pp_0.25deg_reg_1950-1964_v4.0.nc output=air_pressure num_digits=5 offset=0
+r.in.gdal -o input=pp_0.25deg_reg_1965-1979_v4.0.nc output=air_pressure num_digits=5 offset=5479
+r.in.gdal -o input=pp_0.25deg_reg_1980-1994_v4.0.nc output=air_pressure num_digits=5 offset=10957
+r.in.gdal -o input=pp_0.25deg_reg_1995-2010_v4.0.nc output=air_pressure num_digits=5 offset=16436
 # Import min temperature data
-r.in.gdal -o input=tn_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_min offset=0
-r.in.gdal -o input=tn_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_min offset=5479
-r.in.gdal -o input=tn_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_min offset=10957
-r.in.gdal -o input=tn_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_min offset=16436
+r.in.gdal -o input=tn_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_min num_digits=5 offset=0
+r.in.gdal -o input=tn_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_min num_digits=5 offset=5479
+r.in.gdal -o input=tn_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_min num_digits=5 offset=10957
+r.in.gdal -o input=tn_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_min num_digits=5 offset=16436
 # Import max temperature data
-r.in.gdal -o input=tx_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_max offset=0
-r.in.gdal -o input=tx_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_max offset=5479
-r.in.gdal -o input=tx_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_max offset=10957
-r.in.gdal -o input=tx_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_max offset=16436
+r.in.gdal -o input=tx_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_max num_digits=5 offset=0
+r.in.gdal -o input=tx_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_max num_digits=5 offset=5479
+r.in.gdal -o input=tx_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_max num_digits=5 offset=10957
+r.in.gdal -o input=tx_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_max num_digits=5 offset=16436
 # Import mean temperature data
-r.in.gdal -o input=tg_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_mean offset=0
-r.in.gdal -o input=tg_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_mean offset=5479
-r.in.gdal -o input=tg_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_mean offset=10957
-r.in.gdal -o input=tg_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_mean offset=16436
+r.in.gdal -o input=tg_0.25deg_reg_1950-1964_v4.0.nc output=temperatur_mean num_digits=5 offset=0
+r.in.gdal -o input=tg_0.25deg_reg_1965-1979_v4.0.nc output=temperatur_mean num_digits=5 offset=5479
+r.in.gdal -o input=tg_0.25deg_reg_1980-1994_v4.0.nc output=temperatur_mean num_digits=5 offset=10957
+r.in.gdal -o input=tg_0.25deg_reg_1995-2010_v4.0.nc output=temperatur_mean num_digits=5 offset=16436
 </pre></div>
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.asc
--- grass/trunk/raster/r.in.gdal/testsuite/data/elevation.asc	                        (rev 0)
+++ grass/trunk/raster/r.in.gdal/testsuite/data/elevation.asc	2015-11-02 12:11:17 UTC (rev 66714)
@@ -0,0 +1,140 @@
+ncols        150
+nrows        135
+xllcorner    630000.000000000000
+yllcorner    215000.000000000000
+cellsize     100.000000000000
+ 147.0630950927734375 152.12115478515625 147.2090301513671875 149.65704345703125 153.3755645751953125 148.8382568359375 142.92120361328125 137.28582763671875 131.2375335693359375 135.0667724609375 135.067169189453125 134.82135009765625 138.7494049072265625 129.339385986328125 127.7231597900390625 115.90633392333984375 127.56354522705078125 125.89801025390625 116.35941314697265625 113.82979583740234375 124.5316162109375 126.8661041259765625 124.2809295654296875 128.773712158203125 133.4118194580078125 137.837005615234375 139.28656005859375 140.6150970458984375 135.343231201171875 128.500762939453125 127.37060546875 119.70105743408203125 119.3015594482421875 127.2521820068359375 128.194244384765625 119.832366943359375 106.79439544677734375 109.45601654052734375 120.16432952880859375 118.76798248291015625 124.11301422119140625 123.33393096923828125 117.5319366455078125 113.59697723388671875 113.36993408203125 105.30654144287109375 107.28885650634765625 109.23299407958984375 109.7545394
 8974609375 113.39490509033203125 113.3239593505859375 112.55747222900390625 114.97637939453125 123.600250244140625 127.41924285888671875 130.048431396484375 127.94661712646484375 125.52149200439453125 130.856658935546875 134.1063079833984375 140.3046112060546875 145.119232177734375 146.4401702880859375 143.6253204345703125 132.537322998046875 130.2416534423828125 123.69161224365234375 119.80559539794921875 121.44713592529296875 118.2919464111328125 107.2722625732421875 110.53791046142578125 109.9663238525390625 98.112579345703125 113.620269775390625 122.74054718017578125 119.688629150390625 111.731781005859375 124.81524658203125 130.053375244140625 134.4781494140625 131.7899017333984375 130.4069976806640625 124.803314208984375 117.4057769775390625 111.37706756591796875 102.38402557373046875 104.89791107177734375 106.197357177734375 106.7447967529296875 95.8866729736328125 93.0522308349609375 106.21762847900390625 110.05739593505859375 110.67018890380859375 112.6681976318359375 104.3
 4329986572265625 101.30873870849609375 97.84938812255859375 83.26679229736328125 87.63956451416015625 91.57776641845703125 92.918426513671875 104.0501861572265625 107.91741180419921875 108.80377197265625 113.43962860107421875 119.15274810791015625 118.87059783935546875 114.55390167236328125 110.691802978515625 105.1898345947265625 102.11480712890625 99.87047576904296875 99.81594085693359375 94.94239044189453125 90.17211151123046875 84.374176025390625 81.61074066162109375 80.644500732421875 87.0795745849609375 91.97032928466796875 89.11646270751953125 94.9373321533203125 94.47211456298828125 93.8458099365234375 89.40924072265625 86.59696197509765625 81.58402252197265625 79.3111114501953125 80.51703643798828125 86.2068023681640625 86.38266754150390625 84.5159149169921875 80.02588653564453125 73.94976043701171875 76.57281494140625 75.497802734375 75.03617095947265625 71.50623321533203125 71.18262481689453125 67.79132843017578125 65.61725616455078125 65.5240478515625 62.0011024475097656
 25 63.028888702392578125 60.446041107177734375 58.106021881103515625 59.43198394775390625 58.0997467041015625
+ 139.369110107421875 146.6329345703125 149.074127197265625 148.1779327392578125 152.795440673828125 148.0280609130859375 139.7231597900390625 133.63165283203125 137.468353271484375 141.60107421875 136.475830078125 142.383544921875 142.94219970703125 140.2969970703125 127.43737030029296875 125.662750244140625 130.5152435302734375 126.6941986083984375 123.83542633056640625 113.99900054931640625 115.06160736083984375 118.69449615478515625 120.4935150146484375 123.323577880859375 129.9435882568359375 133.2914886474609375 138.03350830078125 142.0122222900390625 136.07366943359375 130.4931488037109375 133.7778167724609375 120.59066009521484375 128.248992919921875 126.204437255859375 126.9675750732421875 121.3265380859375 106.68035888671875 112.29991912841796875 120.388275146484375 122.58621978759765625 126.1321563720703125 129.169342041015625 121.4636993408203125 104.81328582763671875 114.6881561279296875 117.81927490234375 111.26456451416015625 121.63330078125 122.111907958984375 125.206
 13861083984375 126.8651580810546875 127.9424896240234375 118.88240814208984375 122.3585968017578125 123.423248291015625 129.0344696044921875 133.149322509765625 135.193756103515625 134.148956298828125 134.2367095947265625 142.68212890625 143.9658660888671875 147.2552337646484375 145.1698455810546875 139.5727996826171875 135.0703277587890625 130.08624267578125 127.9488067626953125 126.967315673828125 119.6435394287109375 110.93662261962890625 103.7127532958984375 112.31634521484375 102.5748443603515625 106.3715972900390625 118.62984466552734375 122.01187896728515625 123.45072174072265625 118.11722564697265625 125.80570220947265625 133.952789306640625 125.20946502685546875 125.22589874267578125 121.024078369140625 112.501556396484375 106.95789337158203125 108.5532989501953125 114.5069122314453125 110.5792999267578125 103.69458770751953125 93.94379425048828125 94.80356597900390625 101.21497344970703125 109.1531982421875 115.74002838134765625 111.98248291015625 106.6247100830078125 99.9
 9361419677734375 97.221282958984375 83.65607452392578125 94.3115997314453125 96.6214599609375 102.22194671630859375 105.18079376220703125 107.2328948974609375 110.4209747314453125 118.847991943359375 121.52201080322265625 120.0618896484375 116.91424560546875 112.5440673828125 106.01018524169921875 102.67165374755859375 95.26287841796875 97.16381072998046875 97.45102691650390625 94.11257171630859375 87.2729949951171875 86.86525726318359375 86.90009307861328125 88.023834228515625 93.92140960693359375 95.03759765625 97.7988128662109375 97.07118988037109375 93.98595428466796875 93.3791656494140625 87.10912322998046875 81.82108306884765625 82.5820465087890625 81.35767364501953125 85.021270751953125 83.4852142333984375 87.46832275390625 82.0218048095703125 79.24779510498046875 76.34833526611328125 77.35459136962890625 75.48372650146484375 71.31089019775390625 70.90891265869140625 70.722564697265625 68.75160980224609375 63.876529693603515625 62.81777191162109375 60.703369140625 60.67475891
 11328125 58.445117950439453125 58.224887847900390625 56.136493682861328125
+ 133.7091827392578125 137.4987030029296875 145.8946075439453125 150.9004974365234375 152.7673187255859375 148.5075531005859375 140.171142578125 140.9747161865234375 142.5267486572265625 145.008941650390625 140.4365997314453125 144.612548828125 146.81500244140625 140.987579345703125 129.2682952880859375 132.7298583984375 132.6204833984375 130.3763580322265625 123.3799591064453125 115.53179931640625 123.45423126220703125 120.117584228515625 120.64618682861328125 129.747772216796875 131.79376220703125 131.60809326171875 137.070465087890625 142.9826202392578125 141.4319305419921875 136.8502197265625 136.554962158203125 121.07761383056640625 126.68999481201171875 121.8423004150390625 121.17653656005859375 117.7196044921875 106.090484619140625 108.99028778076171875 118.05629730224609375 119.700531005859375 127.19287109375 125.962432861328125 113.52841949462890625 104.24912261962890625 107.31111907958984375 112.70055389404296875 120.019073486328125 120.8834228515625 125.961456298828125 121
 .96500396728515625 130.5788421630859375 131.9444580078125 127.3573455810546875 120.60353851318359375 126.110321044921875 128.5214385986328125 130.32122802734375 136.422882080078125 142.726715087890625 137.6275177001953125 142.4093170166015625 147.761566162109375 146.6278076171875 138.67938232421875 133.5899200439453125 130.31243896484375 127.90352630615234375 123.724090576171875 123.0005340576171875 116.08359527587890625 105.86614227294921875 102.9943389892578125 116.4925079345703125 112.1541748046875 120.34032440185546875 112.239288330078125 118.80345916748046875 126.6989593505859375 128.286865234375 133.049407958984375 132.6152801513671875 128.961578369140625 124.14374542236328125 114.0610504150390625 115.6576995849609375 116.1227264404296875 118.052398681640625 119.75214385986328125 115.13564300537109375 107.620147705078125 94.23056793212890625 97.35369110107421875 107.5441741943359375 113.9366455078125 113.3800201416015625 106.3342437744140625 100.6667633056640625 90.79457092285
 15625 88.04584503173828125 87.92757415771484375 94.94966888427734375 103.68431854248046875 101.4556732177734375 108.73227691650390625 116.2928466796875 117.700958251953125 117.42156219482421875 120.717193603515625 116.0183258056640625 114.04721832275390625 112.238555908203125 109.42354583740234375 104.37164306640625 99.36480712890625 94.1761627197265625 89.88111114501953125 87.68704986572265625 85.9812469482421875 87.083984375 91.617156982421875 93.959747314453125 97.85272979736328125 98.4934844970703125 98.903717041015625 96.3869476318359375 93.21015167236328125 89.6341552734375 89.39717864990234375 84.7627410888671875 87.08055877685546875 84.23670196533203125 81.4802093505859375 80.17263031005859375 85.8988189697265625 84.927398681640625 80.3305511474609375 76.76692962646484375 75.67620086669921875 73.3672943115234375 72.2982025146484375 70.47034454345703125 64.08531951904296875 65.49219512939453125 64.90728759765625 62.990024566650390625 61.416835784912109375 60.55318450927734375
  57.612476348876953125 57.29129791259765625 58.63105010986328125
+ 135.737945556640625 137.934295654296875 145.576690673828125 151.6974639892578125 151.155303955078125 143.010101318359375 139.734405517578125 145.28936767578125 145.04302978515625 142.888336181640625 143.123138427734375 143.7969818115234375 144.9995269775390625 139.5050201416015625 130.9752197265625 134.6947784423828125 129.6082763671875 123.69264984130859375 116.620697021484375 120.43180084228515625 129.955810546875 128.7548065185546875 126.3118896484375 128.113250732421875 135.2704925537109375 139.086151123046875 139.87506103515625 139.932830810546875 136.193878173828125 133.8372039794921875 131.618011474609375 121.594329833984375 122.95013427734375 115.0747528076171875 111.135498046875 107.28745269775390625 114.6934051513671875 122.53336334228515625 125.47109222412109375 125.68224334716796875 125.9552001953125 128.0567169189453125 118.50647735595703125 105.45874786376953125 116.05658721923828125 114.6296539306640625 117.93297576904296875 120.9758148193359375 124.44815826416015625
  125.8614501953125 134.4842376708984375 135.6967315673828125 126.7408599853515625 121.7750396728515625 131.740478515625 128.7557220458984375 132.3029632568359375 139.364288330078125 144.315460205078125 145.30120849609375 146.2233428955078125 148.987274169921875 145.616973876953125 139.474029541015625 128.134857177734375 123.993865966796875 116.5010223388671875 113.96179962158203125 110.48981475830078125 107.01111602783203125 108.1793365478515625 116.03326416015625 119.62279510498046875 115.13413238525390625 129.46343994140625 117.38236236572265625 121.47829437255859375 130.9502105712890625 134.25811767578125 138.0882568359375 136.8563079833984375 133.0239715576171875 128.1735076904296875 122.0340118408203125 122.705322265625 120.390716552734375 119.40120697021484375 114.60809326171875 112.81360626220703125 107.09711456298828125 94.91803741455078125 100.365081787109375 107.34906005859375 115.9082794189453125 115.33142852783203125 102.4051361083984375 100.8874053955078125 102.24669647
 216796875 87.12503814697265625 94.7435760498046875 98.118133544921875 107.05812835693359375 112.05963134765625 109.10984039306640625 116.8393096923828125 123.58484649658203125 123.12992095947265625 120.26049041748046875 115.07012939453125 108.4511566162109375 107.84302520751953125 108.46616363525390625 105.3317108154296875 102.54302215576171875 97.06027984619140625 94.03829193115234375 89.97440338134765625 94.015716552734375 94.59258270263671875 95.49007415771484375 98.15234375 97.72031402587890625 95.06085205078125 93.86402130126953125 92.868743896484375 93.540374755859375 87.6901702880859375 84.2690887451171875 86.4663543701171875 87.2433013916015625 85.10327911376953125 80.44774627685546875 76.84979248046875 79.5842132568359375 80.3055572509765625 77.6847991943359375 74.89249420166015625 72.51253509521484375 72.49431610107421875 65.552490234375 62.911678314208984375 64.83447265625 63.81871795654296875 61.89096832275390625 61.46663665771484375 63.21900177001953125 63.8626213073730
 46875 57.256862640380859375 57.026447296142578125 58.86327362060546875
+ 141.1980438232421875 142.17279052734375 146.8488922119140625 145.9217681884765625 146.158233642578125 146.7086334228515625 143.875946044921875 143.0060272216796875 139.094635009765625 139.5990142822265625 139.9721221923828125 138.29132080078125 142.5258331298828125 139.371917724609375 135.5819549560546875 133.6104583740234375 127.4442901611328125 119.23975372314453125 121.6800689697265625 126.98398590087890625 133.0224761962890625 134.935699462890625 130.53228759765625 125.47202301025390625 133.0961151123046875 140.36834716796875 143.0216064453125 132.723052978515625 129.050750732421875 128.3583526611328125 126.517181396484375 125.5191192626953125 126.97151947021484375 125.8962554931640625 120.237579345703125 107.92205810546875 117.19896697998046875 124.12456512451171875 129.439056396484375 128.156463623046875 116.52021026611328125 119.6851043701171875 115.9182281494140625 106.25466156005859375 112.53495025634765625 123.89138031005859375 118.8887786865234375 121.515472412109375 125
 .0907135009765625 127.4061431884765625 128.56488037109375 129.77801513671875 131.615203857421875 126.385955810546875 127.626007080078125 133.4459228515625 134.549346923828125 139.1992034912109375 144.0880584716796875 146.899444580078125 148.5489501953125 145.2030792236328125 146.1272125244140625 141.444580078125 138.576263427734375 135.1002044677734375 129.1866607666015625 126.83562469482421875 121.51865386962890625 105.86522674560546875 118.636383056640625 126.63611602783203125 123.0199127197265625 123.23636627197265625 130.7941131591796875 120.66266632080078125 117.8262939453125 123.4028167724609375 133.1378326416015625 137.66485595703125 134.001129150390625 131.24981689453125 126.71979522705078125 123.04114532470703125 120.4075469970703125 119.73732757568359375 111.160247802734375 114.6643829345703125 109.24648284912109375 100.014984130859375 95.86048126220703125 105.19409942626953125 114.3167724609375 118.46102142333984375 114.3863983154296875 106.99192047119140625 105.579109191
 89453125 101.57772064208984375 90.99030303955078125 97.92348480224609375 105.335205078125 107.124420166015625 115.07630157470703125 113.70291900634765625 118.242584228515625 121.5383148193359375 124.04193115234375 121.2149200439453125 119.26049041748046875 112.6859588623046875 103.64595794677734375 106.14292144775390625 103.70995330810546875 102.09299468994140625 100.406585693359375 96.13899993896484375 95.4234161376953125 99.1256256103515625 99.69795989990234375 100.20430755615234375 99.933929443359375 94.78865814208984375 91.1438446044921875 89.465789794921875 91.284637451171875 90.2055816650390625 87.08229827880859375 81.282806396484375 82.3089752197265625 83.54647064208984375 81.35323333740234375 81.82009124755859375 74.93572998046875 76.02762603759765625 76.21369171142578125 74.856414794921875 73.6097869873046875 71.63436126708984375 66.5827789306640625 63.67144775390625 61.848819732666015625 62.11019134521484375 63.0923309326171875 67.61850738525390625 63.919307708740234375 63
 .545291900634765625 65.69214630126953125 57.158130645751953125 57.15252685546875 57.91318511962890625
+ 139.421295166015625 146.4323577880859375 143.000091552734375 137.578125 141.131317138671875 146.304718017578125 149.024627685546875 139.64837646484375 135.953094482421875 133.3410491943359375 132.4214324951171875 133.0732269287109375 134.2940521240234375 137.630950927734375 134.701141357421875 132.2540283203125 124.64757537841796875 118.0184173583984375 128.0242767333984375 127.60546112060546875 139.05615234375 139.1453857421875 137.4026947021484375 136.688140869140625 130.9003143310546875 137.407440185546875 143.5855712890625 141.337371826171875 133.702484130859375 125.938934326171875 124.08669281005859375 120.58899688720703125 124.24506378173828125 125.32099151611328125 115.65467071533203125 108.87397003173828125 115.43827056884765625 122.52599334716796875 130.6141815185546875 129.1114044189453125 125.10833740234375 117.04821014404296875 110.89447784423828125 110.3506317138671875 112.81336212158203125 118.1087493896484375 119.40810394287109375 125.69133758544921875 127.9953765869
 140625 129.955596923828125 134.2674407958984375 138.6222381591796875 132.294891357421875 130.7775726318359375 136.3063201904296875 137.3157806396484375 139.4423980712890625 140.9637908935546875 142.6595306396484375 143.9837493896484375 147.80718994140625 144.7305755615234375 137.8412322998046875 134.326202392578125 136.256500244140625 134.05120849609375 131.2401123046875 124.5858154296875 117.14141845703125 110.1756439208984375 121.99444580078125 122.452484130859375 126.5565948486328125 126.8861541748046875 128.052093505859375 121.0460662841796875 128.26708984375 131.2569580078125 135.846832275390625 132.5491790771484375 129.5359649658203125 126.4781494140625 120.926116943359375 120.32123565673828125 118.3289794921875 120.91916656494140625 114.3598480224609375 107.076690673828125 108.37184906005859375 99.34311676025390625 100.48136138916015625 109.36846923828125 114.7621002197265625 118.90802764892578125 117.77126312255859375 113.22936248779296875 109.8384552001953125 103.8353576660
 15625 88.72151947021484375 99.25308990478515625 107.33063507080078125 114.1364593505859375 115.40478515625 115.90154266357421875 118.8337554931640625 123.87378692626953125 121.97565460205078125 117.7552337646484375 116.58155059814453125 113.49593353271484375 102.5764617919921875 99.24898529052734375 99.7467803955078125 100.929534912109375 96.9856719970703125 97.8637237548828125 98.24405670166015625 98.15013885498046875 100.2722015380859375 101.50743865966796875 98.37175750732421875 94.79042816162109375 86.03911590576171875 85.48177337646484375 88.03789520263671875 84.9872894287109375 84.6730804443359375 82.03012847900390625 77.94281768798828125 79.5185699462890625 78.5646514892578125 76.1422882080078125 74.86556243896484375 73.14112091064453125 68.4846343994140625 72.57625579833984375 70.61474609375 69.43718719482421875 67.00533294677734375 63.148162841796875 62.50128173828125 62.971088409423828125 69.4601898193359375 70.84273529052734375 68.471710205078125 66.87976837158203125 69.5
 920867919921875 60.87454986572265625 57.85589599609375 56.469654083251953125
+ 139.5461273193359375 140.4133758544921875 135.700592041015625 133.812744140625 135.8598785400390625 141.0911865234375 147.7211151123046875 142.687744140625 142.588134765625 138.02740478515625 131.35858154296875 127.88724517822265625 126.85865020751953125 129.521270751953125 130.431243896484375 127.94980621337890625 120.876678466796875 123.04190826416015625 132.9070892333984375 138.267425537109375 138.9341278076171875 141.490692138671875 140.47027587890625 136.1331634521484375 134.990325927734375 139.016326904296875 143.6570587158203125 140.04156494140625 136.5765838623046875 135.2798309326171875 122.84798431396484375 122.228485107421875 116.8753814697265625 115.34584808349609375 110.9964599609375 113.7207183837890625 121.6022796630859375 127.17049407958984375 133.693511962890625 127.6866302490234375 124.738616943359375 123.1152191162109375 120.83329010009765625 108.26235198974609375 112.72782135009765625 121.44537353515625 125.69789886474609375 131.66357421875 129.5828704833984375
 130.4046630859375 133.14715576171875 136.354827880859375 130.94317626953125 130.371337890625 126.6645355224609375 129.44195556640625 132.922637939453125 139.011138916015625 142.455596923828125 145.5953521728515625 149.2052154541015625 142.34930419921875 139.815521240234375 136.7332611083984375 132.2336578369140625 128.4544219970703125 125.013092041015625 122.163665771484375 119.43553924560546875 123.44086456298828125 121.6558837890625 122.6158905029296875 123.708526611328125 124.656036376953125 126.8018646240234375 129.9899139404296875 128.585784912109375 137.1960601806640625 136.86376953125 128.700958251953125 124.1122589111328125 120.01082611083984375 115.85056304931640625 113.20574188232421875 113.0704345703125 113.94589996337890625 111.4267120361328125 107.9058074951171875 101.9232177734375 96.3724365234375 101.56531524658203125 109.6321868896484375 111.88409423828125 118.38462066650390625 121.304443359375 115.47348785400390625 111.8264617919921875 106.63843536376953125 90.86695
 86181640625 96.2694091796875 104.43076324462890625 110.78562164306640625 117.31158447265625 121.81101226806640625 119.943115234375 121.2491302490234375 117.49090576171875 117.08930206298828125 113.40680694580078125 111.0255279541015625 107.1001129150390625 102.36185455322265625 94.60285186767578125 94.91155242919921875 94.63211822509765625 95.7228851318359375 95.0455780029296875 95.657257080078125 98.1092681884765625 97.793426513671875 92.92839813232421875 91.77765655517578125 88.66957855224609375 82.0297088623046875 85.25708770751953125 81.21038818359375 80.59793853759765625 77.7289581298828125 76.573699951171875 75.84228515625 75.1736907958984375 72.2223663330078125 70.00569915771484375 65.6920623779296875 64.81644439697265625 73.46993255615234375 68.57627105712890625 66.3668212890625 63.554515838623046875 62.3201904296875 63.462493896484375 69.3040618896484375 72.39720916748046875 73.0672454833984375 78.88465118408203125 69.35488128662109375 70.34885406494140625 62.85898971557617
 1875 60.3300323486328125 60.172214508056640625
+ 133.6780242919921875 130.8223114013671875 133.0596160888671875 139.1998291015625 143.852752685546875 145.9181365966796875 147.3009185791015625 145.277496337890625 146.381256103515625 144.8831939697265625 141.5192718505859375 138.9593048095703125 134.775726318359375 124.992462158203125 125.67513275146484375 121.2436370849609375 120.91756439208984375 125.6083221435546875 132.216766357421875 135.6631011962890625 142.466278076171875 144.7189788818359375 139.81451416015625 140.569976806640625 141.7913665771484375 144.0281219482421875 139.0801544189453125 135.8144989013671875 133.98663330078125 132.4947357177734375 122.825439453125 130.5964813232421875 125.02716064453125 112.38779449462890625 115.4821319580078125 118.48247528076171875 124.344879150390625 127.769134521484375 134.7066802978515625 126.89568328857421875 124.707427978515625 124.3605804443359375 124.459442138671875 110.917449951171875 111.0428466796875 123.7240447998046875 129.2177276611328125 132.1363067626953125 129.32379150
 390625 131.3293304443359375 134.2198333740234375 135.97509765625 136.230712890625 135.249725341796875 130.0499725341796875 129.557220458984375 135.746734619140625 138.50390625 142.52593994140625 147.41973876953125 150.55902099609375 150.051239013671875 143.7942657470703125 138.58807373046875 135.853240966796875 134.6668853759765625 132.4223175048828125 124.6741790771484375 114.22383880615234375 118.55036163330078125 129.9885711669921875 128.0773162841796875 132.85662841796875 130.7108917236328125 128.6394500732421875 132.73297119140625 135.3772430419921875 138.91290283203125 137.56610107421875 135.590728759765625 134.3205718994140625 125.970245361328125 121.24486541748046875 117.2465057373046875 112.9617919921875 110.23030853271484375 104.4991912841796875 105.3055877685546875 99.0306854248046875 109.03908538818359375 103.35016632080078125 107.95101165771484375 115.67431640625 121.11846923828125 120.3217315673828125 112.68099212646484375 106.92363739013671875 100.909210205078125 94.8
 892364501953125 104.5265045166015625 109.2411651611328125 111.14264678955078125 117.86136627197265625 123.25379180908203125 122.832183837890625 115.998504638671875 114.61895751953125 112.9309844970703125 113.17881011962890625 107.12230682373046875 104.571380615234375 101.72185516357421875 101.7886810302734375 97.5828399658203125 88.74253082275390625 92.460052490234375 92.5766143798828125 94.40309906005859375 98.030303955078125 97.17406463623046875 91.030731201171875 88.73317718505859375 91.6719818115234375 85.699127197265625 79.27692413330078125 81.742401123046875 78.1047821044921875 76.517852783203125 75.9962921142578125 71.61981201171875 70.10638427734375 68.90642547607421875 68.6545867919921875 72.4340667724609375 64.78939056396484375 67.16686248779296875 65.522796630859375 63.3468780517578125 63.194705963134765625 64.38814544677734375 66.4452972412109375 72.001373291015625 77.87407684326171875 85.21358489990234375 84.32849884033203125 71.95909881591796875 73.8706207275390625 69.
 78769683837890625 72.2470855712890625 60.148876190185546875
+ 123.3807830810546875 129.0315399169921875 135.38818359375 139.077484130859375 143.0005950927734375 147.476165771484375 144.8210296630859375 143.5684967041015625 145.2019805908203125 141.8232269287109375 138.9693603515625 133.531219482421875 126.7306976318359375 123.1263885498046875 122.028778076171875 121.83061981201171875 128.1142578125 131.4333038330078125 133.0813751220703125 134.5289154052734375 141.5283966064453125 145.7993927001953125 143.6972198486328125 146.32696533203125 147.27630615234375 145.9366912841796875 139.9581756591796875 132.0839080810546875 128.6482696533203125 128.267242431640625 123.45299530029296875 126.5001373291015625 119.17352294921875 113.57646942138671875 124.8601531982421875 125.622955322265625 130.662689208984375 132.9767913818359375 135.7197113037109375 127.04756927490234375 125.82073974609375 125.04871368408203125 119.85312652587890625 111.227935791015625 110.730010986328125 122.88782501220703125 125.44678497314453125 127.0638885498046875 126.7133941
 650390625 129.4528045654296875 129.792510986328125 136.2444610595703125 138.2958831787109375 137.6734619140625 137.39642333984375 132.618377685546875 133.451873779296875 134.27294921875 138.0198822021484375 146.310943603515625 149.9778289794921875 149.023040771484375 145.2354278564453125 142.1718902587890625 135.262298583984375 126.91774749755859375 127.6923980712890625 120.43210601806640625 120.318878173828125 127.52439117431640625 129.1208953857421875 136.860565185546875 135.079315185546875 134.7110748291015625 136.50762939453125 136.1814727783203125 139.6244354248046875 142.03204345703125 139.20306396484375 136.6837158203125 133.4280853271484375 126.7288970947265625 123.8006439208984375 119.87042999267578125 120.67070770263671875 122.368194580078125 114.773651123046875 107.5207061767578125 104.0154266357421875 114.331695556640625 105.03857421875 114.01827239990234375 114.08527374267578125 120.74892425537109375 114.38946533203125 110.61182403564453125 111.98270416259765625 103.984
 55810546875 95.888916015625 104.01406097412109375 114.34775543212890625 118.0075836181640625 120.2605438232421875 125.38225555419921875 123.4834747314453125 119.50479888916015625 113.6790313720703125 107.618438720703125 110.7426605224609375 106.45433807373046875 102.4776458740234375 97.6409759521484375 99.08673095703125 98.683685302734375 95.61407470703125 87.90676116943359375 89.924102783203125 92.8483734130859375 95.8159637451171875 95.14331817626953125 92.13903045654296875 83.95599365234375 88.5150604248046875 85.780548095703125 77.64481353759765625 78.03145599365234375 76.8164215087890625 73.6689910888671875 70.86846160888671875 70.05049896240234375 69.29514312744140625 69.88265228271484375 73.4163665771484375 69.95598602294921875 71.12436676025390625 70.614288330078125 66.11270904541015625 63.364429473876953125 65.684539794921875 72.26021575927734375 71.799346923828125 73.8674468994140625 81.51163482666015625 87.42778778076171875 83.911376953125 72.15879058837890625 77.64397430
 419921875 76.1002349853515625 68.74250030517578125 59.012187957763671875
+ 134.9927825927734375 132.4256134033203125 130.2545928955078125 136.8470916748046875 143.9631195068359375 145.177215576171875 147.86273193359375 144.8113250732421875 145.7834930419921875 137.548248291015625 131.05267333984375 126.7592315673828125 129.4942169189453125 133.89300537109375 128.5748291015625 122.44854736328125 126.7511138916015625 132.1304168701171875 137.1300506591796875 141.2825775146484375 145.4812774658203125 148.2704925537109375 144.019287109375 141.9427490234375 143.647247314453125 140.8651275634765625 138.8712005615234375 137.598358154296875 132.3270416259765625 127.76911163330078125 122.3185577392578125 118.94835662841796875 114.4099273681640625 121.637359619140625 130.27154541015625 132.3679351806640625 135.201690673828125 142.141876220703125 138.2823028564453125 134.871063232421875 132.203338623046875 129.114532470703125 125.6522674560546875 114.52507781982421875 120.06158447265625 123.72840118408203125 122.99897003173828125 128.392333984375 129.396438598632812
 5 117.01226806640625 128.755584716796875 132.30743408203125 135.688385009765625 138.5387115478515625 141.616455078125 136.9596099853515625 139.706695556640625 142.2173004150390625 138.252655029296875 144.283050537109375 148.01556396484375 151.5827484130859375 145.773529052734375 141.17437744140625 137.9162445068359375 131.8501129150390625 126.281890869140625 116.7690582275390625 125.48085784912109375 135.984039306640625 129.353179931640625 130.7033233642578125 139.928466796875 135.93328857421875 138.6698455810546875 142.0002593994140625 141.0207061767578125 142.20819091796875 135.8042144775390625 130.9785919189453125 128.3721160888671875 125.724395751953125 127.1157073974609375 123.88304901123046875 121.09082794189453125 118.88454437255859375 110.9295654296875 103.9259490966796875 111.65894317626953125 115.47397613525390625 110.3257293701171875 117.70455169677734375 121.35637664794921875 122.274139404296875 115.12804412841796875 110.37005615234375 105.156890869140625 95.769615173339
 84375 98.29027557373046875 110.41419219970703125 115.81488037109375 117.96004486083984375 121.97515106201171875 126.04962921142578125 120.0755462646484375 113.691314697265625 112.03619384765625 107.6531524658203125 104.433807373046875 108.47657012939453125 105.42913818359375 96.45526885986328125 92.97045135498046875 98.203521728515625 93.02398681640625 86.22512054443359375 88.4628753662109375 91.73357391357421875 90.73992919921875 90.97246551513671875 90.42670440673828125 82.7951507568359375 86.16622161865234375 81.63068389892578125 78.42041015625 74.061248779296875 72.84990692138671875 71.3089752197265625 67.6060638427734375 69.722564697265625 70.28133392333984375 77.126190185546875 76.84642791748046875 74.9549407958984375 66.714202880859375 66.08094024658203125 65.20526885986328125 68.3672027587890625 70.210418701171875 75.63411712646484375 82.2353668212890625 72.83731842041015625 76.1327667236328125 82.50118255615234375 79.1515350341796875 74.2209014892578125 77.3332672119140625
 72.3896331787109375 65.143157958984375 62.2171478271484375
+ 140.076202392578125 142.359039306640625 141.1747589111328125 139.49969482421875 137.445648193359375 145.3968658447265625 149.348114013671875 146.165283203125 142.0843963623046875 136.8837127685546875 129.5036163330078125 134.902984619140625 139.992218017578125 136.2177734375 126.20070648193359375 128.8696746826171875 130.91522216796875 126.63188934326171875 134.21954345703125 141.4659423828125 145.53765869140625 146.700164794921875 143.7661285400390625 137.957672119140625 132.273468017578125 133.8212432861328125 132.0070037841796875 132.8845977783203125 129.513153076171875 124.17063140869140625 116.9277496337890625 115.58203125 119.594329833984375 127.5289306640625 132.086761474609375 136.7503814697265625 138.2176055908203125 142.4090423583984375 137.160400390625 133.278350830078125 128.415374755859375 122.1305389404296875 118.64183807373046875 112.55944061279296875 120.89896392822265625 124.82964324951171875 128.8895416259765625 130.926971435546875 129.844573974609375 128.94990539
 55078125 129.64404296875 132.4306182861328125 137.2047271728515625 140.001251220703125 140.1653289794921875 141.1006622314453125 145.2896270751953125 147.1561737060546875 148.1356353759765625 149.1424713134765625 148.866455078125 151.7530517578125 143.707763671875 143.438720703125 138.1951904296875 132.4097137451171875 128.776123046875 126.6552886962890625 127.069305419921875 132.678985595703125 138.7578582763671875 134.6778564453125 137.97979736328125 140.9930877685546875 141.6160736083984375 142.207183837890625 143.82598876953125 140.9339141845703125 137.920806884765625 135.738494873046875 127.4450225830078125 120.7170562744140625 121.3989715576171875 120.86651611328125 116.35150909423828125 109.23882293701171875 105.00357818603515625 113.44692230224609375 118.490020751953125 116.26792144775390625 113.7048187255859375 120.31352996826171875 126.48712158203125 123.7093963623046875 119.2075042724609375 114.36174774169921875 106.72037506103515625 96.0950927734375 99.58936309814453125
 105.72528839111328125 111.3651275634765625 114.4167633056640625 119.55403900146484375 118.6974639892578125 115.54315185546875 113.6904754638671875 105.82024383544921875 106.64986419677734375 99.4619598388671875 101.89994049072265625 103.1165008544921875 97.654388427734375 90.85388946533203125 97.243499755859375 92.565582275390625 86.88121795654296875 84.90943145751953125 87.7885284423828125 83.5971221923828125 88.082916259765625 88.80036163330078125 80.8997955322265625 78.92140960693359375 75.03021240234375 73.38201141357421875 72.51595306396484375 68.61054229736328125 72.07846832275390625 72.2762298583984375 79.238037109375 77.11238861083984375 82.54965972900390625 81.17108917236328125 84.77152252197265625 69.8958587646484375 67.2054443359375 63.731372833251953125 71.16884613037109375 73.2807464599609375 76.28780364990234375 81.477783203125 81.7018585205078125 82.61409759521484375 84.91309356689453125 81.61057281494140625 78.64113616943359375 77.55594635009765625 68.673538208007812
 5 64.63816070556640625 70.92841339111328125
+ 138.7584075927734375 140.6340789794921875 144.5179443359375 148.58197021484375 143.44061279296875 141.750579833984375 149.8781585693359375 146.3974456787109375 138.864532470703125 137.398651123046875 130.4633026123046875 138.9102020263671875 144.107177734375 136.235015869140625 127.89502716064453125 130.9814300537109375 135.1947784423828125 132.8258514404296875 128.5294189453125 133.4830780029296875 135.2445526123046875 138.8182220458984375 144.454437255859375 143.5221099853515625 132.36578369140625 126.15285491943359375 125.99761199951171875 124.9058380126953125 121.42726898193359375 124.33698272705078125 118.32759857177734375 117.45928955078125 127.46260833740234375 134.6215362548828125 140.5225067138671875 137.6094970703125 140.2173919677734375 143.3284454345703125 136.781219482421875 133.860565185546875 133.428863525390625 126.546783447265625 118.3901519775390625 112.3379364013671875 115.85382843017578125 122.13509368896484375 127.74552154541015625 132.4824981689453125 134.8276
 67236328125 135.9179229736328125 136.149169921875 136.28314208984375 138.65338134765625 142.1256103515625 143.289886474609375 143.8555450439453125 145.9322967529296875 148.1970672607421875 150.0684814453125 151.5660552978515625 152.886138916015625 153.032562255859375 144.7492828369140625 143.5993804931640625 139.5736541748046875 135.99090576171875 126.76076507568359375 130.466064453125 134.3912811279296875 141.2716217041015625 140.711029052734375 140.8588104248046875 141.5889129638671875 138.846588134765625 139.69329833984375 141.1503143310546875 143.1899871826171875 141.836151123046875 141.2030487060546875 135.3109588623046875 128.1977081298828125 123.285858154296875 117.74217987060546875 113.5337982177734375 109.47583770751953125 115.4111785888671875 110.01723480224609375 118.69936370849609375 120.33139801025390625 122.25002288818359375 116.7166900634765625 118.1838836669921875 125.0156707763671875 122.91464996337890625 113.9502105712890625 108.6357879638671875 103.399208068847656
 25 97.97260284423828125 103.74908447265625 113.2780609130859375 115.391387939453125 117.01215362548828125 119.65515899658203125 120.8006134033203125 111.40154266357421875 106.1176300048828125 103.72344970703125 98.3126220703125 94.50836944580078125 95.10919952392578125 92.27225494384765625 91.20009613037109375 87.93679046630859375 91.0704498291015625 88.78151702880859375 85.68563079833984375 83.03624725341796875 82.87468719482421875 81.48090362548828125 88.22840118408203125 85.939483642578125 80.05403900146484375 75.96993255615234375 73.66690826416015625 71.75927734375 72.83400726318359375 73.63245391845703125 81.2760009765625 84.27991485595703125 82.11782073974609375 81.3890838623046875 86.6731719970703125 83.70249176025390625 76.44439697265625 71.37334442138671875 67.20952606201171875 67.83342742919921875 73.10703277587890625 78.73024749755859375 78.07556915283203125 82.90833282470703125 87.2011871337890625 89.2305755615234375 86.818817138671875 79.5162200927734375 79.511154174804
 6875 71.92684173583984375 69.1607818603515625 73.1593017578125 79.2204132080078125
+ 138.658172607421875 143.150634765625 145.3385467529296875 150.112213134765625 150.1318511962890625 151.849945068359375 150.6754913330078125 145.6955413818359375 148.4995269775390625 142.7800445556640625 133.705322265625 143.959136962890625 146.0471954345703125 139.4148712158203125 126.616973876953125 133.150970458984375 137.3023223876953125 141.4937286376953125 131.323760986328125 134.7677459716796875 144.332672119140625 148.283050537109375 146.606414794921875 136.8291473388671875 136.632537841796875 135.103271484375 132.0009002685546875 126.05892181396484375 119.6800079345703125 125.48032379150390625 130.6110076904296875 121.8597412109375 124.5477752685546875 134.236724853515625 141.4757080078125 142.52716064453125 142.68841552734375 142.0106658935546875 137.6125030517578125 134.394989013671875 133.447021484375 126.09638214111328125 119.053070068359375 111.29042816162109375 119.9304046630859375 134.992156982421875 130.8423614501953125 130.812835693359375 130.754241943359375 131.68
 11981201171875 133.5768280029296875 135.4695587158203125 137.1255340576171875 140.106170654296875 141.772857666015625 142.921112060546875 144.2542572021484375 146.2019500732421875 148.3958282470703125 151.9649658203125 154.6661529541015625 153.4642486572265625 144.7003631591796875 143.28765869140625 137.3925018310546875 135.101715087890625 126.7759552001953125 135.9681549072265625 139.264373779296875 144.4471588134765625 145.6282806396484375 144.131622314453125 142.919708251953125 137.0227508544921875 137.746307373046875 139.4328765869140625 141.1882781982421875 142.021575927734375 137.5374298095703125 134.65362548828125 126.05278778076171875 122.3408355712890625 115.86373138427734375 118.6931915283203125 123.83246612548828125 116.54935455322265625 111.9213104248046875 120.45706939697265625 122.2311553955078125 125.7892913818359375 122.84526824951171875 122.77816009521484375 120.680206298828125 115.07961273193359375 116.82158660888671875 111.0220794677734375 99.12279510498046875 108
 .1194000244140625 111.6046905517578125 112.00899505615234375 119.6273651123046875 122.01099395751953125 118.77812957763671875 123.8712615966796875 118.504364013671875 114.25328826904296875 115.7152099609375 108.99530792236328125 97.96512603759765625 97.97451019287109375 94.0462799072265625 90.01839447021484375 86.05315399169921875 83.6984100341796875 82.89388275146484375 83.24768829345703125 78.3681182861328125 79.08284759521484375 80.35219573974609375 84.3311614990234375 78.5401153564453125 76.52721405029296875 75.4364471435546875 70.21144866943359375 82.58867645263671875 83.5035858154296875 74.975189208984375 80.40140533447265625 86.68346405029296875 85.72417449951171875 85.48509979248046875 87.0650787353515625 84.608489990234375 79.54120635986328125 75.59038543701171875 69.49555206298828125 68.48821258544921875 75.6281280517578125 81.95662689208984375 80.1139068603515625 80.68500518798828125 88.9241180419921875 90.6804656982421875 84.20627593994140625 84.86248016357421875 81.5447
 1588134765625 75.70574951171875 69.84906768798828125 78.15069580078125 82.48259735107421875
+ 136.6953277587890625 138.1971893310546875 145.8376617431640625 149.7340850830078125 148.1543121337890625 149.648956298828125 151.1035919189453125 149.3681793212890625 143.437774658203125 142.195281982421875 134.27130126953125 145.708526611328125 146.0153961181640625 135.2770538330078125 126.4555206298828125 135.3006744384765625 142.2508087158203125 145.783203125 142.024505615234375 138.3377838134765625 146.3483123779296875 151.6541900634765625 141.872344970703125 138.7046356201171875 144.2716217041015625 138.6037139892578125 134.9339599609375 123.71865081787109375 124.7230224609375 134.51373291015625 134.0409698486328125 134.2061767578125 122.01810455322265625 128.0724639892578125 134.5187835693359375 141.56829833984375 145.33172607421875 139.7490386962890625 131.3601837158203125 127.44266510009765625 127.5049896240234375 123.517364501953125 120.22003936767578125 114.39615631103515625 123.18286895751953125 125.95180511474609375 126.22847747802734375 128.084228515625 127.97737121582
 03125 128.0703582763671875 129.76983642578125 134.3690948486328125 133.01641845703125 133.199249267578125 136.74053955078125 141.2131500244140625 141.9087066650390625 146.0075531005859375 148.88214111328125 151.7725372314453125 154.6439971923828125 150.8283843994140625 144.14141845703125 142.22113037109375 139.1137847900390625 132.7908782958984375 129.148406982421875 136.88470458984375 142.206878662109375 145.045135498046875 144.3624420166015625 143.704681396484375 145.173187255859375 137.5843658447265625 135.5810089111328125 139.1543121337890625 138.294158935546875 141.0040740966796875 132.2854766845703125 127.425048828125 126.471099853515625 120.03050994873046875 121.86283111572265625 125.071502685546875 128.5366363525390625 118.08776092529296875 114.36014556884765625 118.881317138671875 126.31313323974609375 127.11649322509765625 127.77571868896484375 127.2363128662109375 124.66390228271484375 111.64310455322265625 107.10953521728515625 105.52787017822265625 104.2496490478515625
 114.09827423095703125 119.91173553466796875 117.51902008056640625 118.4357757568359375 119.6908111572265625 124.4010162353515625 124.5590972900390625 120.65438079833984375 119.13764190673828125 115.886810302734375 111.0484619140625 109.5443267822265625 105.8681793212890625 94.63915252685546875 95.58371734619140625 99.8217315673828125 93.15924835205078125 89.00858306884765625 92.08620452880859375 91.4612884521484375 85.00568389892578125 78.19240570068359375 79.54621124267578125 76.72003936767578125 76.62265777587890625 78.2144927978515625 85.15593719482421875 88.29732513427734375 88.65000152587890625 78.2827606201171875 84.91034698486328125 87.30941009521484375 83.92401123046875 87.24853515625 84.3123016357421875 82.22440338134765625 79.50324249267578125 72.625335693359375 69.57472991943359375 74.759002685546875 78.0376739501953125 77.97245025634765625 84.18195343017578125 83.73545074462890625 86.73334503173828125 87.52942657470703125 86.3600311279296875 83.47515869140625 79.90930938
 720703125 76.83641815185546875 70.3056182861328125 75.03646087646484375 80.3958740234375
+ 129.4226837158203125 133.5117645263671875 140.0296173095703125 143.4622650146484375 142.4554443359375 147.5742645263671875 150.667755126953125 147.91424560546875 143.2381134033203125 138.3577728271484375 138.1897735595703125 144.0892181396484375 140.369384765625 137.0963592529296875 136.884857177734375 137.3574676513671875 139.802703857421875 145.375091552734375 142.22906494140625 136.39013671875 145.3533172607421875 149.656097412109375 145.70904541015625 142.938323974609375 146.1348114013671875 136.943206787109375 128.5742950439453125 122.1273040771484375 125.8143157958984375 138.3800048828125 139.223602294921875 137.0851287841796875 125.78980255126953125 128.79681396484375 135.5364837646484375 143.36865234375 146.48370361328125 137.0076904296875 131.9434051513671875 130.7244415283203125 127.59900665283203125 125.2366943359375 121.15218353271484375 115.69384002685546875 117.99402618408203125 121.80370330810546875 125.3712615966796875 126.0731353759765625 126.12225341796875 132.821
 258544921875 133.248870849609375 138.1210479736328125 137.161956787109375 136.9585113525390625 142.4634857177734375 140.380462646484375 141.47637939453125 142.0287933349609375 148.815460205078125 150.411773681640625 153.6726837158203125 151.9937286376953125 146.517181396484375 141.623992919921875 138.568603515625 133.475799560546875 135.8765716552734375 137.5351104736328125 141.20648193359375 142.494659423828125 140.3120574951171875 140.882049560546875 141.9075927734375 138.3140869140625 134.1084136962890625 136.826080322265625 136.4192962646484375 140.54412841796875 137.25897216796875 128.725067138671875 128.5849151611328125 123.40505218505859375 129.6923980712890625 131.581024169921875 127.9168243408203125 120.94927978515625 116.17301177978515625 122.7147369384765625 127.57049560546875 127.18257904052734375 129.6347808837890625 125.01047515869140625 122.358856201171875 117.30651092529296875 114.2989349365234375 107.8326568603515625 105.7631988525390625 115.6229705810546875 119.489
 31121826171875 121.59320831298828125 124.9577484130859375 126.19474029541015625 124.94976806640625 126.3244171142578125 121.7577667236328125 116.8359222412109375 111.960418701171875 106.6943206787109375 105.6331939697265625 102.01131439208984375 94.371246337890625 99.01840972900390625 105.09313201904296875 97.63228607177734375 100.4333343505859375 98.171844482421875 91.23136138916015625 83.42372894287109375 82.1235504150390625 79.677642822265625 73.15341949462890625 79.14699554443359375 86.44661712646484375 90.64536285400390625 95.18006134033203125 92.91423797607421875 83.2506866455078125 88.1375732421875 90.13913726806640625 86.8641204833984375 84.6355438232421875 81.41193389892578125 79.14600372314453125 74.52974700927734375 73.65270233154296875 72.2200164794921875 78.1850738525390625 84.2450103759765625 80.63164520263671875 81.274810791015625 87.031982421875 87.203643798828125 87.79409027099609375 86.665557861328125 79.32513427734375 76.73285675048828125 70.4631500244140625 75.88
 85040283203125 77.4590911865234375 79.828826904296875
+ 139.2057037353515625 135.9355621337890625 136.2894744873046875 138.3431396484375 139.5531158447265625 145.5137481689453125 150.027618408203125 143.668670654296875 142.121337890625 141.2480316162109375 143.0847930908203125 141.9848480224609375 143.7325286865234375 141.85260009765625 130.091094970703125 138.9800872802734375 145.2055511474609375 148.018035888671875 149.156402587890625 146.80389404296875 144.9857635498046875 149.230560302734375 148.3544769287109375 147.2167816162109375 141.8423309326171875 134.2164764404296875 123.7486419677734375 129.33160400390625 126.8772735595703125 138.645050048828125 141.0457611083984375 141.1671295166015625 136.651123046875 127.886383056640625 138.98974609375 144.5724945068359375 141.8782806396484375 137.01324462890625 139.03045654296875 134.7195892333984375 131.890655517578125 127.009063720703125 119.6456756591796875 117.24857330322265625 128.1983489990234375 128.9447021484375 132.1792144775390625 132.4615325927734375 131.1389617919921875 132.8
 63189697265625 139.12896728515625 141.371490478515625 141.6844482421875 134.305389404296875 142.9899749755859375 146.4266815185546875 143.590484619140625 142.675201416015625 148.4417877197265625 149.6105499267578125 151.606414794921875 149.788665771484375 147.3925628662109375 145.059051513671875 144.9850311279296875 142.5238037109375 141.6240234375 141.636444091796875 140.9266815185546875 139.8127899169921875 138.402740478515625 137.164825439453125 136.82977294921875 134.947662353515625 134.2517852783203125 133.7499237060546875 135.4415130615234375 139.774993896484375 137.197906494140625 131.1107177734375 134.479156494140625 125.66989898681640625 132.734710693359375 133.45404052734375 127.477783203125 119.4599456787109375 117.18143463134765625 124.43048095703125 128.7355499267578125 129.664764404296875 129.824127197265625 122.3847808837890625 119.13549041748046875 115.57476806640625 111.27288055419921875 103.8796844482421875 108.3502349853515625 112.680328369140625 117.1105422973632
 8125 124.59650421142578125 123.7894287109375 128.30987548828125 128.1085205078125 126.75086212158203125 122.01789093017578125 120.46230316162109375 118.0204010009765625 110.63268280029296875 103.67324066162109375 97.89923858642578125 101.6526031494140625 105.444854736328125 104.250030517578125 102.1197967529296875 101.49695587158203125 98.04024505615234375 93.22884368896484375 87.9706878662109375 87.99623870849609375 77.76963043212890625 77.6209869384765625 87.4409332275390625 87.61595916748046875 91.5126190185546875 95.86496734619140625 92.55258941650390625 82.93190765380859375 88.26239013671875 91.54521942138671875 89.24100494384765625 85.9256591796875 80.78908538818359375 79.42040252685546875 81.7383575439453125 72.34238433837890625 70.9746246337890625 76.12651824951171875 82.1333770751953125 85.72650909423828125 87.94085693359375 86.17205047607421875 88.3479766845703125 87.989410400390625 84.80625152587890625 80.4064483642578125 77.24605560302734375 81.83428955078125 82.73450469
 970703125 82.2916717529296875 82.1475372314453125
+ 144.0026397705078125 147.6641387939453125 147.0720672607421875 147.0747222900390625 146.9569549560546875 148.4623565673828125 151.0540618896484375 148.1483154296875 147.8220672607421875 147.8322601318359375 144.6734619140625 147.9318389892578125 149.687591552734375 142.4987945556640625 132.10748291015625 143.0980377197265625 149.379058837890625 152.8295135498046875 153.8564453125 148.789581298828125 149.15155029296875 149.753509521484375 148.8880462646484375 147.524169921875 139.922393798828125 130.8655548095703125 128.8824310302734375 127.8128814697265625 131.424957275390625 134.6972198486328125 142.1883544921875 143.3994903564453125 141.064208984375 130.202423095703125 139.6068572998046875 144.9176483154296875 140.114013671875 133.25927734375 128.769775390625 127.21730804443359375 123.01116943359375 124.8640289306640625 122.53569793701171875 119.0186920166015625 129.3349151611328125 133.078826904296875 133.32525634765625 134.1067352294921875 137.9690704345703125 131.8847961425781
 25 135.9771881103515625 141.9664764404296875 144.3196868896484375 141.310882568359375 143.028594970703125 146.827789306640625 149.325714111328125 150.77947998046875 151.3245697021484375 151.474395751953125 151.0140380859375 146.988037109375 146.0687103271484375 144.691741943359375 143.6484527587890625 141.6129913330078125 140.337738037109375 141.471099853515625 144.2382354736328125 142.3254852294921875 141.642822265625 145.9584197998046875 138.8091278076171875 137.50628662109375 135.6721954345703125 133.87713623046875 135.303375244140625 138.15252685546875 138.565704345703125 135.6226654052734375 134.710968017578125 128.7858734130859375 134.0422821044921875 130.2734222412109375 124.02923583984375 120.3665924072265625 125.29003143310546875 122.14849853515625 126.60498046875 132.4401702880859375 131.38189697265625 127.935699462890625 124.37853240966796875 121.73461151123046875 110.992218017578125 108.7640533447265625 117.29505157470703125 122.433990478515625 125.42603302001953125 126.
 2447357177734375 129.567169189453125 129.1023712158203125 128.9652099609375 124.79482269287109375 121.2159271240234375 117.71466064453125 119.2208709716796875 114.71006011962890625 106.607696533203125 100.0653228759765625 105.78389739990234375 108.6761932373046875 104.03614044189453125 99.228057861328125 96.1175689697265625 95.9909820556640625 94.2252197265625 93.06980133056640625 80.69673919677734375 80.1394805908203125 80.76883697509765625 88.4625244140625 89.37584686279296875 91.75237274169921875 96.24982452392578125 95.6191558837890625 88.065093994140625 93.46750640869140625 92.21216583251953125 88.55252838134765625 83.20413970947265625 84.126434326171875 87.7532958984375 80.83386993408203125 70.48311614990234375 73.37158203125 77.89035797119140625 77.39453887939453125 78.671539306640625 84.935699462890625 87.807586669921875 89.08233642578125 86.2435302734375 82.76070404052734375 78.89141082763671875 83.94768524169921875 83.3993072509765625 84.56284332275390625 83.13459777832031
 25 82.95104217529296875
+ 137.2118377685546875 143.8779144287109375 147.826385498046875 149.1351470947265625 148.1861419677734375 151.009613037109375 152.50152587890625 150.4476776123046875 152.3717041015625 151.8279571533203125 145.6611480712890625 144.2235565185546875 151.41046142578125 143.842987060546875 139.0353546142578125 137.286346435546875 146.53948974609375 148.43426513671875 149.652069091796875 155.083740234375 153.2807159423828125 151.888031005859375 150.4818115234375 145.1556549072265625 138.41510009765625 134.371337890625 131.8509368896484375 129.3428955078125 138.935394287109375 142.163299560546875 144.923980712890625 145.298614501953125 149.8531494140625 147.6315765380859375 144.0794525146484375 145.697906494140625 138.1264801025390625 136.64727783203125 137.4516754150390625 134.8821868896484375 130.69769287109375 132.8419647216796875 122.38116455078125 122.7632904052734375 121.36147308349609375 124.542449951171875 127.08611297607421875 130.331390380859375 136.450897216796875 139.47514343261
 71875 140.1496124267578125 140.197906494140625 145.0789642333984375 143.5373687744140625 142.0458221435546875 148.873626708984375 150.1767730712890625 152.2626800537109375 152.1587982177734375 150.8902435302734375 148.5329742431640625 145.7747344970703125 145.44073486328125 140.51312255859375 136.1981201171875 135.137725830078125 135.681488037109375 138.8280792236328125 143.6010894775390625 143.53857421875 142.145416259765625 143.031768798828125 142.4917755126953125 141.62603759765625 135.0869140625 134.636016845703125 132.1393280029296875 134.2813568115234375 136.59686279296875 138.2436370849609375 135.607574462890625 133.6566162109375 136.1746673583984375 133.5278778076171875 127.5095367431640625 127.0009002685546875 128.4594573974609375 127.50247955322265625 128.5972747802734375 131.9871826171875 129.172393798828125 127.10488128662109375 124.5357666015625 119.64839935302734375 112.80609893798828125 111.61542510986328125 117.76006317138671875 124.1362152099609375 130.0623779296875
  131.4205474853515625 130.95452880859375 126.99964141845703125 123.3433685302734375 122.09555816650390625 120.24736785888671875 115.24617767333984375 114.231781005859375 113.7183990478515625 105.74727630615234375 105.5361175537109375 108.5489044189453125 109.21099853515625 104.144317626953125 97.98291778564453125 93.11724090576171875 90.66240692138671875 89.05660247802734375 90.1151580810546875 78.91613006591796875 80.58664703369140625 83.243865966796875 89.50445556640625 91.29608154296875 93.87288665771484375 97.38234710693359375 98.5518341064453125 86.7660369873046875 95.51279449462890625 93.8911895751953125 87.83953857421875 88.3669586181640625 89.39116668701171875 86.2976226806640625 79.54668426513671875 72.345977783203125 74.7912139892578125 78.7663421630859375 83.52813720703125 85.74143218994140625 84.63141632080078125 88.670166015625 90.85938262939453125 85.31882476806640625 77.9589080810546875 86.1188201904296875 89.44342041015625 86.0504608154296875 85.5343780517578125 84.7
 8961944580078125 81.63840484619140625
+ 142.6156768798828125 143.3248443603515625 142.9074859619140625 145.021240234375 147.4858551025390625 152.3035736083984375 152.524505615234375 149.6174468994140625 152.135955810546875 152.384063720703125 151.340728759765625 145.8332366943359375 151.36260986328125 144.466552734375 144.6443939208984375 144.677459716796875 148.408966064453125 144.84112548828125 150.40643310546875 153.6478271484375 151.534271240234375 148.005859375 147.7304840087890625 146.109893798828125 141.50750732421875 139.7498931884765625 130.9991607666015625 133.8689422607421875 141.985107421875 148.5682373046875 147.613525390625 146.5694427490234375 147.3306427001953125 143.05352783203125 140.51263427734375 147.2901153564453125 148.569366455078125 143.8097686767578125 138.0503387451171875 132.7302093505859375 132.3056793212890625 129.1699676513671875 120.26955413818359375 121.61560821533203125 130.50537109375 133.41632080078125 133.6732940673828125 135.921875 134.9025421142578125 135.9830780029296875 138.3925170
 8984375 143.1691436767578125 146.8358001708984375 147.9750823974609375 143.7554779052734375 142.90350341796875 149.3437042236328125 151.7553558349609375 150.9141845703125 147.8434600830078125 144.1825103759765625 144.4963531494140625 142.8692779541015625 141.663726806640625 138.5919342041015625 135.986236572265625 130.9813385009765625 137.608795166015625 141.970794677734375 140.3073883056640625 140.85888671875 139.9018402099609375 143.550201416015625 142.9046783447265625 138.8010406494140625 135.377105712890625 130.7093505859375 129.8683319091796875 132.342010498046875 134.9944305419921875 133.6934051513671875 136.452423095703125 137.3015899658203125 134.516387939453125 132.2938995361328125 131.083251953125 132.144622802734375 130.8294525146484375 131.5482635498046875 129.837738037109375 124.67813873291015625 120.86684417724609375 117.6281585693359375 112.56563568115234375 113.00547027587890625 114.25970458984375 119.93343353271484375 124.95198822021484375 132.186431884765625 130.93
 08319091796875 126.31752777099609375 123.33943939208984375 119.21649169921875 117.68457794189453125 115.4420623779296875 116.8942108154296875 111.0203094482421875 113.35693359375 111.64121246337890625 109.7137603759765625 110.67278289794921875 108.869293212890625 102.54569244384765625 96.62441253662109375 87.42160797119140625 88.79912567138671875 82.562164306640625 83.09951019287109375 79.55319976806640625 81.4365234375 90.58303070068359375 92.19512176513671875 92.4103851318359375 94.3348388671875 97.94580078125 97.5527496337890625 91.53394317626953125 97.4516754150390625 94.32213592529296875 93.51267242431640625 93.24599456787109375 90.7262725830078125 84.22562408447265625 78.149444580078125 73.06833648681640625 76.18891143798828125 79.29790496826171875 84.2214202880859375 89.90993499755859375 93.03302764892578125 92.99633026123046875 93.339813232421875 87.1752471923828125 85.43841552734375 91.766998291015625 90.74768829345703125 91.585693359375 90.4203948974609375 86.0652847290039
 0625 81.4996490478515625
+ 146.4464874267578125 149.9470672607421875 149.851318359375 150.45892333984375 150.943389892578125 151.356353759765625 149.333160400390625 146.9367218017578125 148.457763671875 150.440765380859375 152.1422882080078125 151.2055511474609375 150.43304443359375 148.4557952880859375 150.0448455810546875 151.7680511474609375 149.8102569580078125 150.1890106201171875 150.921112060546875 152.8441619873046875 149.384033203125 145.890655517578125 146.08148193359375 147.6517791748046875 134.8669891357421875 135.2328643798828125 136.8368377685546875 138.4762115478515625 144.0627288818359375 147.321929931640625 146.773223876953125 149.3310394287109375 149.647186279296875 146.5193023681640625 147.88592529296875 148.489837646484375 150.1601104736328125 146.326873779296875 142.6964569091796875 137.1950836181640625 133.26751708984375 127.5147705078125 129.2167816162109375 129.2018280029296875 124.6569671630859375 133.03155517578125 135.8521881103515625 141.7315216064453125 142.1797027587890625 138.3
 371429443359375 141.7712554931640625 142.046630859375 144.2699432373046875 148.2280426025390625 149.1777496337890625 147.677032470703125 150.1235809326171875 150.80908203125 150.5265045166015625 146.931549072265625 141.5344696044921875 142.1965179443359375 141.05718994140625 139.5373992919921875 137.159637451171875 134.991424560546875 129.3285675048828125 134.805206298828125 138.5222930908203125 136.5889892578125 135.84686279296875 139.8498382568359375 141.624908447265625 141.478851318359375 140.8928985595703125 138.66119384765625 133.6629486083984375 127.78705596923828125 129.524078369140625 132.0141754150390625 129.9134979248046875 134.687469482421875 133.8615264892578125 136.2329559326171875 135.3750762939453125 133.2574462890625 130.0352783203125 129.7661590576171875 127.85321807861328125 131.147735595703125 131.008636474609375 121.95063018798828125 119.64382171630859375 122.5826263427734375 123.546875 116.84752655029296875 123.283721923828125 130.034423828125 133.02857971191406
 25 131.514068603515625 127.50159454345703125 124.034423828125 118.691314697265625 115.32575225830078125 112.10935211181640625 108.18183135986328125 108.6175994873046875 110.87506866455078125 110.65993499755859375 110.31209564208984375 108.01116180419921875 107.0708770751953125 100.818511962890625 93.391448974609375 97.71360015869140625 95.67089080810546875 93.48914337158203125 87.87542724609375 79.56751251220703125 81.20171356201171875 91.40842437744140625 92.3191680908203125 93.89846038818359375 95.0917205810546875 97.95873260498046875 98.799774169921875 94.61434173583984375 96.2674713134765625 94.72188568115234375 93.22995758056640625 88.82018280029296875 85.0704193115234375 80.77004241943359375 77.35650634765625 74.67425537109375 79.5927886962890625 81.1701507568359375 83.6454620361328125 90.03885650634765625 95.17946624755859375 95.30681610107421875 92.16138458251953125 85.1600494384765625 89.17597198486328125 89.985443115234375 91.678497314453125 96.2580413818359375 92.24963378
 90625 84.83124542236328125 89.09757232666015625
+ 149.229400634765625 149.5843505859375 151.0136566162109375 153.308837890625 151.8264007568359375 151.3973541259765625 148.2374420166015625 142.748443603515625 143.9563446044921875 146.1430206298828125 151.615692138671875 148.2039031982421875 150.601898193359375 146.01495361328125 148.2628173828125 152.1550445556640625 153.037445068359375 154.307403564453125 154.044464111328125 153.849609375 148.9234466552734375 147.418792724609375 148.2555389404296875 148.39056396484375 139.2454833984375 134.7747344970703125 133.9500885009765625 137.1006317138671875 139.842315673828125 141.7949981689453125 145.6624603271484375 149.9212188720703125 151.0054931640625 148.029327392578125 147.4601898193359375 150.577911376953125 148.28948974609375 142.779571533203125 137.8549957275390625 134.6971282958984375 128.818634033203125 124.0211181640625 135.532958984375 136.5197601318359375 126.61986541748046875 126.72168731689453125 135.132476806640625 139.5518341064453125 142.762359619140625 144.902740478515
 625 142.197723388671875 147.002166748046875 147.1272125244140625 147.1848907470703125 148.1134033203125 149.5693817138671875 150.7902679443359375 149.7006072998046875 143.813201904296875 144.623138427734375 142.7343902587890625 134.888885498046875 132.962554931640625 136.961181640625 135.88031005859375 131.5811614990234375 129.8871002197265625 132.5775146484375 133.785980224609375 134.966033935546875 135.0559539794921875 134.3023223876953125 137.28826904296875 139.5103607177734375 139.348876953125 139.434051513671875 137.6784515380859375 131.642364501953125 125.78165435791015625 127.2181854248046875 133.07904052734375 131.183837890625 131.377777099609375 131.6487579345703125 133.86737060546875 130.1246795654296875 125.8180084228515625 126.62239837646484375 123.4416351318359375 128.8374176025390625 127.4980010986328125 122.98802947998046875 126.3163299560546875 129.41943359375 121.40052032470703125 121.62353515625 126.73431396484375 131.5346221923828125 130.53753662109375 129.4212646
 484375 127.57794189453125 122.89728546142578125 118.39395904541015625 115.94298553466796875 113.33642578125 108.92264556884765625 105.87696075439453125 107.50412750244140625 109.65453338623046875 107.28476715087890625 109.33542633056640625 104.71253204345703125 101.8662567138671875 101.107330322265625 98.34474945068359375 96.94391632080078125 97.54033660888671875 88.63445281982421875 80.07353973388671875 83.02675628662109375 92.74924468994140625 92.12652587890625 91.67102813720703125 93.2795257568359375 95.2399444580078125 97.58721923828125 99.63910675048828125 97.8743438720703125 94.99102020263671875 89.638397216796875 87.0122833251953125 82.88526153564453125 81.29804229736328125 80.55908966064453125 75.1915283203125 81.00382232666015625 85.53090667724609375 85.54772186279296875 89.18532562255859375 92.604248046875 94.23740386962890625 89.0671844482421875 88.23705291748046875 91.8621673583984375 92.7722625732421875 92.16320037841796875 94.103668212890625 91.7852020263671875 88.6037
 750244140625 92.56501007080078125
+ 145.6008758544921875 146.5866546630859375 148.9673309326171875 150.96087646484375 147.15350341796875 149.929718017578125 148.4118804931640625 145.0728607177734375 141.4710540771484375 143.09857177734375 148.1376800537109375 144.818450927734375 145.95452880859375 143.4318389892578125 145.4749603271484375 153.556976318359375 147.44342041015625 149.3437042236328125 149.281494140625 152.1805419921875 153.038726806640625 150.0785675048828125 148.87255859375 148.77813720703125 140.577606201171875 135.3278350830078125 142.822784423828125 141.0691680908203125 145.6762542724609375 143.8663177490234375 142.3907928466796875 145.3458251953125 147.474639892578125 149.2042999267578125 149.7534637451171875 148.09368896484375 148.6617584228515625 144.2643890380859375 140.6408233642578125 136.21929931640625 134.3837432861328125 128.43377685546875 138.4248199462890625 139.343170166015625 134.2464447021484375 131.6341094970703125 130.4987335205078125 134.6602783203125 138.210235595703125 143.48867797
 8515625 145.9006500244140625 147.077117919921875 146.06121826171875 147.048736572265625 146.1068572998046875 146.8822174072265625 148.5109100341796875 149.8684234619140625 147.8014984130859375 139.5916290283203125 135.492767333984375 134.6662139892578125 132.85205078125 132.5767059326171875 134.5308380126953125 130.798980712890625 122.43569183349609375 133.5830535888671875 135.0522918701171875 132.16278076171875 128.53363037109375 133.754364013671875 138.7662200927734375 138.3980712890625 136.1428680419921875 136.783111572265625 136.2006988525390625 134.0172271728515625 126.94199371337890625 124.09271240234375 131.1005859375 127.013671875 127.775390625 128.149261474609375 128.2314910888671875 130.75640869140625 125.60352325439453125 122.333831787109375 122.996734619140625 128.7707061767578125 129.870452880859375 127.7395477294921875 131.0160675048828125 129.197967529296875 123.8484954833984375 125.1736602783203125 131.772064208984375 131.31268310546875 128.093414306640625 127.495117
 1875 127.69313812255859375 123.25656890869140625 115.95861053466796875 113.34883880615234375 112.08043670654296875 104.363128662109375 102.53022003173828125 104.54172515869140625 106.08625030517578125 107.32726287841796875 107.4563446044921875 103.16835784912109375 102.535736083984375 103.418212890625 99.93280792236328125 93.7564544677734375 92.48014068603515625 90.0927276611328125 80.16367340087890625 87.25696563720703125 94.3211669921875 94.27239990234375 97.45351409912109375 98.263275146484375 96.5602874755859375 97.20999908447265625 99.67327117919921875 100.24068450927734375 97.31258392333984375 93.58324432373046875 90.065093994140625 87.300811767578125 83.41786956787109375 75.11656951904296875 82.18531036376953125 83.66625213623046875 84.10767364501953125 89.6501312255859375 91.16670989990234375 94.9162445068359375 92.67317962646484375 88.8604278564453125 91.826446533203125 89.6133575439453125 93.85718536376953125 96.40291595458984375 96.9600830078125 93.27471923828125 92.75932
 31201171875 89.9083709716796875
+ 144.610107421875 143.3088836669921875 146.5263214111328125 145.3155975341796875 143.4387969970703125 146.086029052734375 144.4864654541015625 143.167572021484375 139.3314056396484375 139.8380126953125 147.4680633544921875 146.2111663818359375 141.477813720703125 143.4721832275390625 142.04925537109375 146.6082000732421875 139.6665496826171875 145.5769500732421875 144.5732269287109375 147.6779937744140625 152.2714080810546875 146.7595062255859375 143.7660369873046875 142.5469970703125 138.1917572021484375 146.905029296875 147.326568603515625 145.379638671875 147.828399658203125 149.3961639404296875 148.0395660400390625 145.265472412109375 144.9121856689453125 149.503936767578125 147.48480224609375 144.9326934814453125 146.7828369140625 141.6833343505859375 140.6705780029296875 134.068817138671875 130.3836517333984375 135.8453521728515625 136.1622772216796875 137.0139923095703125 136.23504638671875 136.5682373046875 137.6053009033203125 136.77508544921875 142.29644775390625 144.36437
 98828125 146.8178863525390625 140.23333740234375 144.563568115234375 145.1579437255859375 142.4873199462890625 145.530731201171875 147.7719268798828125 147.6620941162109375 145.39337158203125 141.5518035888671875 137.4343109130859375 130.4857940673828125 126.25141143798828125 128.463470458984375 129.4034881591796875 126.7427978515625 123.6900177001953125 132.0020904541015625 135.08782958984375 131.3196258544921875 128.030364990234375 134.0066375732421875 138.8361968994140625 137.653106689453125 136.93743896484375 137.176300048828125 133.112579345703125 130.9683837890625 128.3400115966796875 128.12677001953125 123.45208740234375 123.27532196044921875 124.63536834716796875 124.20475006103515625 128.5627288818359375 129.2088165283203125 125.75409698486328125 120.13582611083984375 122.84420013427734375 125.44971466064453125 127.2360992431640625 127.94283294677734375 127.38173675537109375 125.93135833740234375 126.3151702880859375 129.33538818359375 130.0974578857421875 126.7560806274414
 0625 124.41146087646484375 127.36629486083984375 128.407379150390625 122.104248046875 117.01287078857421875 115.03879547119140625 113.023468017578125 109.26425933837890625 102.60030364990234375 99.3546905517578125 102.81137847900390625 105.16985321044921875 105.1099395751953125 101.427337646484375 99.777313232421875 99.978851318359375 99.12697601318359375 94.60101318359375 91.05669403076171875 84.53081512451171875 84.28546142578125 89.0100250244140625 94.9022979736328125 97.71375274658203125 99.8010711669921875 102.46262359619140625 100.68509674072265625 100.38201141357421875 101.4403228759765625 99.8276214599609375 93.8940887451171875 86.3115234375 82.9208831787109375 81.3459625244140625 77.2177276611328125 77.98522186279296875 83.04187774658203125 87.82745361328125 86.60259246826171875 87.18048095703125 91.698089599609375 96.144073486328125 92.6370697021484375 90.4256439208984375 93.58432769775390625 92.30936431884765625 96.10552215576171875 94.37946319580078125 93.807830810546875
  92.6600494384765625 89.8938140869140625 87.16307830810546875
+ 146.478515625 146.0313873291015625 139.70928955078125 139.153839111328125 138.721038818359375 137.6107177734375 138.5416107177734375 137.6981353759765625 135.7020263671875 137.1555328369140625 139.4978179931640625 142.367828369140625 139.2270050048828125 142.012176513671875 136.329986572265625 136.0659027099609375 142.74407958984375 149.071502685546875 150.068878173828125 149.6579132080078125 150.1019134521484375 145.9448699951171875 143.166351318359375 140.8715667724609375 146.3363037109375 145.252288818359375 143.482269287109375 143.2044219970703125 148.326934814453125 149.908447265625 148.9502410888671875 146.9203338623046875 147.534637451171875 147.3848419189453125 142.767333984375 141.75140380859375 143.287017822265625 142.336273193359375 137.298187255859375 133.78302001953125 136.0888519287109375 141.6286468505859375 141.324737548828125 141.745819091796875 135.2781524658203125 137.0050811767578125 141.8111724853515625 139.4113311767578125 141.4915008544921875 145.025695800781
 25 143.9031829833984375 141.5574798583984375 140.747650146484375 142.53570556640625 146.5296478271484375 149.089324951171875 150.47308349609375 148.7530059814453125 138.8527679443359375 136.483917236328125 135.7513275146484375 132.1259765625 125.33592987060546875 129.213531494140625 128.457427978515625 122.0664215087890625 126.7458953857421875 131.3404693603515625 134.8970184326171875 128.6494293212890625 130.2341766357421875 131.8354339599609375 134.024627685546875 138.6201934814453125 135.771697998046875 132.3748779296875 132.5294647216796875 132.3921051025390625 132.6346282958984375 128.3987274169921875 131.2091064453125 124.18555450439453125 118.03520965576171875 122.1263275146484375 123.30637359619140625 125.65254974365234375 126.00887298583984375 120.64305877685546875 118.8336029052734375 121.52582550048828125 123.4949188232421875 123.72594451904296875 124.07460784912109375 124.7119293212890625 123.70355987548828125 126.96417999267578125 127.4049530029296875 122.09072875976562
 5 120.18695831298828125 126.00934600830078125 129.077301025390625 125.19747161865234375 123.037872314453125 119.5501251220703125 117.70166778564453125 112.39947509765625 107.19759368896484375 97.923431396484375 96.94756317138671875 98.134857177734375 98.9112701416015625 95.84523773193359375 98.64654541015625 97.67044830322265625 94.2129669189453125 93.13686370849609375 86.8509674072265625 83.51874542236328125 85.08084869384765625 89.3694610595703125 90.1255035400390625 93.19818115234375 97.26821136474609375 99.99855804443359375 103.27754974365234375 103.36319732666015625 103.3079986572265625 98.46485137939453125 91.92144775390625 91.9203948974609375 91.9312286376953125 89.76705169677734375 84.792572021484375 79.29927825927734375 80.98891448974609375 84.895843505859375 89.7715606689453125 91.123809814453125 94.60784912109375 97.34464263916015625 94.641357421875 94.48758697509765625 96.04135894775390625 95.5796966552734375 95.90533447265625 92.6342620849609375 89.7751617431640625 86.3
 73748779296875 84.623504638671875 85.37682342529296875
+ 148.358123779296875 143.8025054931640625 138.5731964111328125 139.7958221435546875 137.3817901611328125 140.8617095947265625 134.361572265625 133.665283203125 133.665771484375 133.9311981201171875 133.2723541259765625 134.4519805908203125 135.928009033203125 136.934967041015625 132.52862548828125 140.266815185546875 145.611846923828125 151.79052734375 149.5266876220703125 143.7358551025390625 146.3134765625 149.832244873046875 144.5246734619140625 140.200164794921875 146.030975341796875 144.132293701171875 143.2431640625 142.158660888671875 147.1864013671875 147.3621063232421875 143.4559173583984375 143.025604248046875 141.45855712890625 142.4178466796875 140.1138763427734375 140.995941162109375 144.4176788330078125 144.6868438720703125 139.0599212646484375 137.6880645751953125 141.5387115478515625 144.819610595703125 142.7408905029296875 140.214508056640625 135.4355010986328125 138.54718017578125 144.1426239013671875 143.20318603515625 144.253326416015625 145.5137939453125 142.969
 78759765625 140.465911865234375 138.7937469482421875 144.72125244140625 146.7086334228515625 149.7988433837890625 150.074554443359375 147.24566650390625 140.8621368408203125 139.5101318359375 134.6382904052734375 132.9437408447265625 126.82830810546875 118.319183349609375 124.47954559326171875 121.7619476318359375 123.943328857421875 126.31867218017578125 131.5678253173828125 123.7381439208984375 129.5572052001953125 131.7647857666015625 135.011016845703125 136.294219970703125 133.255523681640625 129.33233642578125 128.281982421875 129.984405517578125 133.387420654296875 132.8572845458984375 136.180694580078125 131.142791748046875 120.496002197265625 116.6342926025390625 119.34577178955078125 120.0684661865234375 120.93207550048828125 118.32555389404296875 120.876861572265625 118.99367523193359375 119.08509063720703125 122.301239013671875 119.74481201171875 119.99976348876953125 122.9109649658203125 128.7014312744140625 126.56003570556640625 118.9732818603515625 120.67535400390625 1
 23.30234527587890625 126.73897552490234375 125.296844482421875 121.69724273681640625 121.0289764404296875 120.81998443603515625 112.7148895263671875 105.75188446044921875 98.30881500244140625 94.260528564453125 92.60698699951171875 91.4538421630859375 90.80712127685546875 90.33081817626953125 88.5993194580078125 87.65911865234375 85.93994903564453125 84.4154815673828125 83.658294677734375 88.67893218994140625 96.0816802978515625 95.57422637939453125 94.479736328125 100.8140716552734375 102.0640106201171875 105.41922760009765625 105.82256317138671875 103.2043304443359375 98.64734649658203125 96.51590728759765625 98.85443115234375 96.33011627197265625 91.34700775146484375 83.7391815185546875 86.66736602783203125 87.442596435546875 84.38468170166015625 88.13134002685546875 91.94272613525390625 95.710540771484375 100.70366668701171875 95.42551422119140625 96.91771697998046875 98.6335906982421875 98.10770416259765625 96.47869110107421875 93.8918914794921875 91.24289703369140625 87.977828
 9794921875 83.2551727294921875 81.15801239013671875
+ 143.39373779296875 138.4779052734375 140.41851806640625 143.7269744873046875 143.28118896484375 147.3324127197265625 144.314483642578125 140.9261627197265625 144.352447509765625 137.88165283203125 131.3669586181640625 131.7437744140625 131.69720458984375 132.8094482421875 131.650299072265625 140.4344329833984375 143.7306365966796875 148.1287994384765625 143.9407501220703125 140.2152099609375 148.3995513916015625 150.547027587890625 147.70111083984375 141.0160369873046875 140.1279144287109375 141.6170501708984375 138.21588134765625 145.2366943359375 146.6217498779296875 144.5160980224609375 142.1438446044921875 140.939605712890625 138.8278045654296875 135.6573944091796875 138.125946044921875 144.088836669921875 146.736175537109375 146.473236083984375 144.4302978515625 143.4034576416015625 144.5533905029296875 144.769012451171875 141.831512451171875 141.0368499755859375 141.836181640625 142.4392242431640625 144.832733154296875 147.1826324462890625 145.473175048828125 145.806976318359
 375 142.199432373046875 138.3694915771484375 139.9136810302734375 143.712738037109375 147.0950469970703125 150.0513916015625 149.19818115234375 144.575164794921875 140.4927825927734375 140.223297119140625 140.5179290771484375 136.8453826904296875 128.183258056640625 118.9582366943359375 118.12470245361328125 118.42116546630859375 118.359619140625 121.53350067138671875 124.46728515625 118.7457427978515625 126.3165435791015625 131.7802734375 136.786865234375 128.713287353515625 128.22735595703125 125.14670562744140625 125.4153594970703125 125.5112762451171875 132.6055908203125 135.1021728515625 133.859771728515625 131.466156005859375 126.07523345947265625 122.98770904541015625 115.96451568603515625 116.08478546142578125 118.41765594482421875 118.733551025390625 114.13610076904296875 112.9788360595703125 118.967987060546875 119.966766357421875 116.76044464111328125 118.10825347900390625 119.9990692138671875 125.48798370361328125 123.0799102783203125 114.7249908447265625 115.27828216552
 734375 121.6034698486328125 122.824859619140625 120.44686126708984375 120.90712738037109375 118.06395721435546875 118.81842041015625 113.561553955078125 106.9149932861328125 103.5574493408203125 103.6437225341796875 100.729156494140625 95.63449859619140625 98.58379364013671875 91.97042083740234375 89.93265533447265625 88.28823089599609375 86.89258575439453125 85.24897003173828125 85.93607330322265625 90.3556365966796875 90.79976654052734375 96.654205322265625 98.23627471923828125 102.923065185546875 102.5146942138671875 102.85788726806640625 105.94720458984375 106.1945037841796875 103.75173187255859375 101.87038421630859375 104.40209197998046875 97.20024871826171875 90.14791107177734375 80.3336181640625 83.85590362548828125 89.13080596923828125 88.02977752685546875 86.7806243896484375 90.66423797607421875 97.4388580322265625 101.19954681396484375 97.30004119873046875 103.493927001953125 102.99837493896484375 101.00501251220703125 98.40518951416015625 96.632293701171875 92.0129699707
 03125 88.24382781982421875 88.668670654296875 84.34575653076171875
+ 140.3860015869140625 143.34564208984375 143.2276763916015625 146.9696044921875 149.668670654296875 149.9356536865234375 145.820220947265625 142.5973358154296875 143.699981689453125 139.1071624755859375 141.5953216552734375 135.5308990478515625 129.8209991455078125 129.6488189697265625 129.853515625 134.7656097412109375 139.6417236328125 142.156646728515625 140.0003662109375 138.328887939453125 147.182464599609375 146.5926361083984375 141.5390167236328125 146.077301025390625 144.2914886474609375 136.15936279296875 144.1596221923828125 149.881683349609375 150.193084716796875 148.1094512939453125 145.6979522705078125 147.214508056640625 146.6486968994140625 139.6149749755859375 134.050933837890625 141.4573211669921875 144.2509613037109375 142.2768707275390625 139.950775146484375 139.78924560546875 143.548736572265625 147.3505401611328125 146.9756317138671875 145.0967864990234375 143.0360870361328125 141.7176361083984375 146.2340545654296875 146.5020751953125 145.32110595703125 147.615
 570068359375 140.940093994140625 137.0431365966796875 137.76104736328125 142.382843017578125 146.845184326171875 150.2643890380859375 148.002227783203125 144.578826904296875 139.4874267578125 133.50396728515625 136.102630615234375 135.6733551025390625 133.0200042724609375 125.40514373779296875 121.68236541748046875 116.8679046630859375 116.943878173828125 119.94632720947265625 116.58916473388671875 124.7794952392578125 131.738800048828125 134.650543212890625 134.7331085205078125 129.150146484375 127.60460662841796875 125.20532989501953125 119.9186248779296875 126.93579864501953125 128.6558990478515625 134.1108245849609375 135.582427978515625 130.826751708984375 127.29178619384765625 127.35700225830078125 121.2110137939453125 114.282928466796875 113.5383148193359375 114.58702850341796875 114.41584014892578125 112.168731689453125 111.91132354736328125 115.60370635986328125 115.71659088134765625 115.81293487548828125 119.88663482666015625 122.8080902099609375 118.881805419921875 115.45
 966339111328125 116.8402557373046875 123.76267242431640625 122.49571990966796875 116.5072479248046875 118.1688079833984375 118.91466522216796875 113.78635406494140625 111.4410552978515625 110.94972991943359375 107.092041015625 100.3006591796875 101.03420257568359375 103.39229583740234375 105.1556243896484375 100.75696563720703125 95.06961822509765625 91.05069732666015625 90.6920928955078125 90.37139892578125 91.34171295166015625 90.880584716796875 92.9011077880859375 96.4052581787109375 98.68103790283203125 103.9140472412109375 104.77460479736328125 106.03850555419921875 107.08672332763671875 106.92205810546875 104.1838531494140625 100.57342529296875 99.13509368896484375 95.14675140380859375 85.05783843994140625 87.86293792724609375 91.4076690673828125 87.82466888427734375 91.35991668701171875 91.644012451171875 94.90924835205078125 100.80040740966796875 102.67166900634765625 100.022796630859375 102.4976348876953125 104.4107666015625 102.5508270263671875 101.36779022216796875 98.138
 0767822265625 95.221588134765625 93.5179443359375 90.40738677978515625 82.260040283203125
+ 141.078216552734375 145.12255859375 148.300994873046875 149.9993743896484375 153.992523193359375 153.02825927734375 146.9098052978515625 147.2720794677734375 144.4818878173828125 142.26153564453125 149.3726043701171875 143.80938720703125 136.640472412109375 129.65887451171875 129.03277587890625 129.6991729736328125 133.888153076171875 137.2769775390625 133.84100341796875 139.0386199951171875 143.8101043701171875 143.5134735107421875 139.216796875 144.15399169921875 145.8907623291015625 135.3589630126953125 141.8992156982421875 149.217254638671875 149.680511474609375 151.0074615478515625 150.9937286376953125 150.3150177001953125 147.172821044921875 141.0464935302734375 135.947601318359375 134.1389312744140625 141.602142333984375 137.650726318359375 135.326141357421875 136.3443603515625 144.17254638671875 144.9423675537109375 145.1660919189453125 141.011016845703125 139.612396240234375 140.4163818359375 143.4867706298828125 143.565338134765625 138.91351318359375 138.1403656005859375
 140.3939056396484375 133.7218780517578125 138.12469482421875 140.414703369140625 144.0788116455078125 148.683837890625 144.890350341796875 135.313690185546875 134.1555023193359375 131.9530487060546875 127.73200225830078125 129.525543212890625 130.104644775390625 129.7600860595703125 124.13300323486328125 117.30297088623046875 112.33038330078125 120.2118682861328125 115.8889312744140625 123.71910858154296875 130.870147705078125 129.8176727294921875 130.6573486328125 132.27923583984375 125.15027618408203125 119.66835784912109375 119.22859954833984375 123.5521087646484375 126.072296142578125 130.6278533935546875 134.06903076171875 134.460906982421875 130.1658782958984375 125.03380584716796875 122.2999267578125 118.9519805908203125 113.8092193603515625 109.2593231201171875 111.93321990966796875 110.905029296875 111.00408935546875 111.86185455322265625 114.58106231689453125 114.15441131591796875 114.033447265625 115.46599578857421875 116.4004669189453125 111.057342529296875 116.475135803
 22265625 121.91066741943359375 122.34375762939453125 116.4483642578125 112.44416046142578125 118.76717376708984375 114.70703125 110.871612548828125 107.7594451904296875 104.08554840087890625 106.6923828125 108.99889373779296875 110.651947021484375 108.1009368896484375 102.8957977294921875 97.737548828125 98.51406097412109375 92.6098785400390625 97.60253143310546875 97.63372039794921875 95.23258209228515625 95.9942779541015625 95.711151123046875 97.9339447021484375 104.49599456787109375 104.15869903564453125 106.797637939453125 107.43487548828125 104.2975616455078125 100.07375335693359375 97.125457763671875 93.22518157958984375 87.91400146484375 84.5838775634765625 89.84357452392578125 94.9656982421875 93.47127532958984375 92.70038604736328125 94.348236083984375 101.19744110107421875 104.52645111083984375 103.90061187744140625 103.01092529296875 103.56874847412109375 104.691680908203125 102.1755828857421875 100.8657379150390625 97.66064453125 96.701324462890625 94.68349456787109375 8
 7.89044952392578125 87.51418304443359375
+ 143.100616455078125 145.6425628662109375 149.9514617919921875 154.1868133544921875 155.3574066162109375 153.145477294921875 146.9533538818359375 148.162841796875 147.238616943359375 145.3052520751953125 150.871917724609375 150.2068634033203125 145.5019989013671875 142.405120849609375 137.1011810302734375 127.8035125732421875 127.89827728271484375 129.21368408203125 129.9725494384765625 136.49713134765625 140.646270751953125 138.4807281494140625 137.5640716552734375 142.37762451171875 142.351409912109375 134.1923675537109375 139.641937255859375 145.1004791259765625 142.268951416015625 148.5708770751953125 150.22918701171875 149.3886566162109375 143.060028076171875 138.900909423828125 136.586822509765625 130.541229248046875 131.96954345703125 135.070831298828125 131.16217041015625 139.4318695068359375 140.371429443359375 142.8387298583984375 139.448974609375 139.596221923828125 143.1823883056640625 144.6544342041015625 145.0296173095703125 141.8431243896484375 138.1470184326171875 13
 5.448486328125 137.3194427490234375 131.9580230712890625 134.0965118408203125 137.4271087646484375 142.309844970703125 147.50701904296875 146.422027587890625 137.6481170654296875 131.4376220703125 127.72335052490234375 124.19525909423828125 122.76204681396484375 123.8143768310546875 122.858489990234375 122.871002197265625 115.56298828125 116.1264190673828125 113.62053680419921875 116.14459991455078125 121.5535888671875 126.6961212158203125 122.8125 128.7210540771484375 127.51000213623046875 124.2095947265625 115.4228363037109375 119.7691497802734375 122.7124786376953125 121.77400970458984375 129.7628173828125 131.721527099609375 129.442169189453125 128.7174072265625 126.30281829833984375 124.47042083740234375 123.5628509521484375 122.30764007568359375 114.31536102294921875 110.71839141845703125 105.70862579345703125 107.98937225341796875 105.89899444580078125 109.3705291748046875 109.548126220703125 112.568359375 111.36553955078125 110.63845062255859375 113.189727783203125 120.02274
 322509765625 115.4477996826171875 119.37868499755859375 115.204071044921875 109.05596160888671875 114.99027252197265625 116.4188995361328125 111.56891632080078125 109.7969818115234375 108.64675140380859375 111.77480316162109375 114.431610107421875 113.95551300048828125 108.1797637939453125 101.053741455078125 103.26328277587890625 102.7457275390625 97.57166290283203125 101.50608062744140625 104.2559661865234375 99.002227783203125 103.25695037841796875 98.67800140380859375 98.9008941650390625 100.554962158203125 104.56097412109375 107.32129669189453125 107.3408660888671875 100.89150238037109375 94.88942718505859375 93.08914947509765625 92.77027130126953125 90.5930023193359375 87.97638702392578125 88.778778076171875 94.14789581298828125 97.6804351806640625 95.8072357177734375 99.51395416259765625 103.80529022216796875 107.7751312255859375 105.4381866455078125 106.06810760498046875 103.37708282470703125 99.309295654296875 95.478271484375 98.1453704833984375 96.907318115234375 95.061424
 25537109375 93.0831298828125 87.9720611572265625 87.0950164794921875
+ 143.7816925048828125 148.1285247802734375 151.3486175537109375 154.4197540283203125 156.221710205078125 153.8486480712890625 147.3661956787109375 146.147613525390625 151.484649658203125 152.0695037841796875 152.9053192138671875 151.1960296630859375 149.8976898193359375 142.989044189453125 140.3633575439453125 133.15789794921875 126.725189208984375 127.26966094970703125 128.395782470703125 132.97076416015625 136.357696533203125 132.93792724609375 135.490142822265625 134.9169921875 140.7415771484375 131.2783660888671875 137.192626953125 135.406463623046875 139.225006103515625 145.6966705322265625 150.243316650390625 151.110504150390625 147.76373291015625 144.8510284423828125 143.6389617919921875 136.9431610107421875 127.67871856689453125 128.7306365966796875 131.576507568359375 134.21783447265625 138.9483795166015625 135.9782867431640625 140.0059661865234375 145.4114532470703125 146.1351470947265625 141.821868896484375 145.7898406982421875 145.871795654296875 139.2920989990234375 136
 .9586334228515625 131.56591796875 130.8667755126953125 139.10540771484375 143.3262786865234375 145.986541748046875 143.9623870849609375 145.2947845458984375 137.9423675537109375 137.8807220458984375 135.5966339111328125 128.4949798583984375 128.1593475341796875 118.91530609130859375 117.05368804931640625 113.13091278076171875 116.7719268798828125 118.34220123291015625 116.6427154541015625 122.94315338134765625 126.95915985107421875 123.3349761962890625 120.4125518798828125 128.987548828125 127.49432373046875 117.25910186767578125 111.417144775390625 119.75196075439453125 118.24394989013671875 126.56604766845703125 130.1524810791015625 131.98785400390625 131.5508880615234375 127.03263092041015625 122.69515228271484375 120.17159271240234375 123.301910400390625 122.137786865234375 117.0392608642578125 117.17601776123046875 111.02735137939453125 109.258026123046875 105.15847015380859375 105.27156829833984375 107.05892181396484375 107.9569549560546875 106.62899017333984375 107.5730438232
 421875 112.21802520751953125 118.3801727294921875 111.36656951904296875 115.65659332275390625 108.4417724609375 108.32155609130859375 115.28899383544921875 113.971282958984375 111.2699737548828125 108.136474609375 109.92447662353515625 113.6125030517578125 117.2676849365234375 116.3469390869140625 109.754730224609375 106.51651763916015625 108.5163421630859375 104.49560546875 98.19730377197265625 101.3094329833984375 105.44451904296875 104.03572845458984375 104.3737030029296875 103.59912109375 101.881439208984375 104.2628326416015625 103.7646636962890625 106.5341033935546875 106.12479400634765625 101.99028778076171875 98.07511138916015625 96.97765350341796875 100.2455291748046875 98.06482696533203125 92.6085662841796875 90.17978668212890625 94.41429901123046875 98.03130340576171875 98.5397491455078125 102.18103790283203125 107.36869049072265625 108.1828460693359375 106.652679443359375 106.63874053955078125 105.740631103515625 101.94147491455078125 95.26868438720703125 92.663139343261
 71875 92.75811004638671875 94.55416107177734375 94.5358428955078125 93.10691070556640625 93.88559722900390625
+ 146.454193115234375 147.321380615234375 149.1821746826171875 149.6888275146484375 153.4170379638671875 153.44647216796875 147.766265869140625 146.03375244140625 151.1726531982421875 152.6468353271484375 151.219940185546875 148.7503509521484375 149.9815826416015625 146.1823272705078125 145.0864410400390625 142.4794769287109375 134.8667144775390625 125.8789520263671875 125.26758575439453125 129.743560791015625 128.1856231689453125 134.0999298095703125 133.802276611328125 134.462615966796875 134.2962646484375 128.8463897705078125 131.83160400390625 135.4510498046875 143.2422332763671875 149.219268798828125 150.4742584228515625 148.65802001953125 144.99853515625 142.776702880859375 144.3566131591796875 140.742279052734375 139.548797607421875 125.289642333984375 131.112518310546875 131.0983428955078125 129.277618408203125 133.455596923828125 137.4694366455078125 141.840423583984375 144.9727783203125 138.8550262451171875 139.2248382568359375 144.18389892578125 142.2168121337890625 137.25
 03814697265625 134.199005126953125 129.7374267578125 139.5796356201171875 141.339935302734375 144.0247650146484375 141.063446044921875 142.558197021484375 143.5787200927734375 141.0207061767578125 134.5648956298828125 136.8648681640625 133.8953094482421875 127.48552703857421875 123.69525909423828125 122.83521270751953125 122.2890625 106.61865997314453125 110.91509246826171875 117.45743560791015625 123.02703857421875 112.6751251220703125 123.31292724609375 128.207733154296875 123.28896331787109375 118.41252899169921875 108.58048248291015625 114.32921600341796875 117.07776641845703125 125.58856201171875 126.20964813232421875 128.5404510498046875 130.6545562744140625 124.7150726318359375 117.78791046142578125 116.88967132568359375 120.69441986083984375 122.24524688720703125 122.91121673583984375 123.63564300537109375 117.51331329345703125 115.29470062255859375 108.67299652099609375 108.053466796875 99.62822723388671875 101.69849395751953125 101.38592529296875 106.64757537841796875 110.
 83272552490234375 114.30826568603515625 106.8067779541015625 112.32865142822265625 107.52010345458984375 108.23989105224609375 115.650299072265625 111.9615631103515625 103.89673614501953125 104.261138916015625 110.74593353271484375 114.64812469482421875 116.01204681396484375 114.2585906982421875 111.51993560791015625 111.20537567138671875 110.66422271728515625 106.86046600341796875 100.29273223876953125 102.541351318359375 106.4903564453125 108.998870849609375 107.788177490234375 106.825592041015625 105.51892852783203125 106.505615234375 105.9224090576171875 106.32952117919921875 106.26386260986328125 103.4358978271484375 102.70095062255859375 99.62892913818359375 98.726715087890625 95.66532135009765625 90.7127685546875 96.37233734130859375 90.97032928466796875 97.3330841064453125 100.853057861328125 104.17400360107421875 108.37863922119140625 106.7477264404296875 104.035797119140625 104.05120849609375 102.17273712158203125 102.77869415283203125 98.79314422607421875 94.2169952392578
 125 89.45081329345703125 89.27046966552734375 92.2602386474609375 95.92673492431640625 98.5523681640625
+ 147.0452423095703125 146.196136474609375 147.0951690673828125 149.65814208984375 151.1097259521484375 153.781494140625 151.0351409912109375 144.4349212646484375 147.4030303955078125 150.69378662109375 151.36328125 145.5135345458984375 145.647491455078125 149.1414642333984375 147.0780181884765625 144.80694580078125 139.9447479248046875 138.2981414794921875 124.92035675048828125 125.3000640869140625 129.401123046875 135.793853759765625 138.1757354736328125 131.692901611328125 134.0440826416015625 128.4655303955078125 136.1389007568359375 140.87310791015625 145.4632568359375 147.958648681640625 143.6890869140625 138.246490478515625 137.269012451171875 138.6510162353515625 143.83673095703125 137.12066650390625 136.1490325927734375 128.679351806640625 126.64199066162109375 129.858551025390625 136.798583984375 138.067840576171875 139.3184814453125 138.9663238525390625 141.786529541015625 136.5045928955078125 135.432952880859375 139.6609344482421875 140.8456268310546875 139.1534423828125
 133.9972381591796875 129.832794189453125 136.8690338134765625 137.66973876953125 141.9442291259765625 137.695281982421875 141.6592559814453125 143.12579345703125 141.4363861083984375 139.601104736328125 138.83294677734375 131.965789794921875 129.949676513671875 129.466888427734375 125.14990997314453125 124.986968994140625 109.61126708984375 104.769134521484375 113.78759765625 115.99002838134765625 114.11855316162109375 122.061187744140625 126.81388092041015625 116.59369659423828125 112.0944976806640625 107.45223236083984375 107.74924468994140625 113.25841522216796875 119.57256317138671875 124.9436187744140625 129.523223876953125 127.40164947509765625 123.99462127685546875 118.46369171142578125 112.7298736572265625 115.22946929931640625 113.469268798828125 120.67160797119140625 123.9049835205078125 124.31855010986328125 123.21572113037109375 118.07306671142578125 112.45772552490234375 113.30031585693359375 101.8584136962890625 101.04052734375 101.16185760498046875 105.398887634277343
 75 106.20557403564453125 99.9610137939453125 106.35672760009765625 101.96581268310546875 107.87714385986328125 114.81798553466796875 108.50983428955078125 106.08221435546875 104.7326507568359375 110.71218109130859375 112.77556610107421875 115.8193511962890625 113.80097198486328125 113.06777191162109375 110.390380859375 107.87123870849609375 106.901641845703125 106.0594329833984375 104.91176605224609375 107.2810516357421875 109.10970306396484375 109.80279541015625 107.27978515625 107.66863250732421875 109.31421661376953125 107.31018829345703125 105.12801361083984375 107.58397674560546875 105.77123260498046875 103.5153045654296875 101.69147491455078125 96.70659637451171875 97.74326324462890625 94.72460174560546875 99.49404144287109375 98.45761871337890625 97.32647705078125 100.71697998046875 105.0241241455078125 108.619476318359375 104.96219635009765625 98.3207550048828125 97.97607421875 97.20207977294921875 99.48030853271484375 98.668243408203125 94.0413970947265625 88.26261138916015
 625 89.41179656982421875 92.581390380859375 96.5020294189453125 98.52605438232421875
+ 149.8548583984375 147.2035369873046875 146.210357666015625 150.1793212890625 154.985382080078125 155.417724609375 151.5817718505859375 144.3494110107421875 143.4996337890625 146.74969482421875 147.8526458740234375 148.511260986328125 146.013427734375 143.604705810546875 144.742462158203125 141.98931884765625 139.8372650146484375 132.30694580078125 127.4012908935546875 123.9876708984375 127.7198638916015625 136.263671875 136.876068115234375 129.399658203125 127.6154632568359375 131.5218963623046875 134.5574798583984375 140.3681182861328125 142.0406951904296875 141.7951507568359375 141.042205810546875 141.147918701171875 135.55419921875 137.0866546630859375 140.7459716796875 136.0819854736328125 129.249267578125 125.67415618896484375 125.59996795654296875 130.328460693359375 134.4853515625 136.625579833984375 141.1771240234375 139.219573974609375 137.2688140869140625 131.53375244140625 134.7685546875 139.51422119140625 139.863922119140625 132.6977081298828125 129.5576629638671875 127
 .955780029296875 132.5114898681640625 137.0962677001953125 137.92633056640625 133.7947998046875 139.78143310546875 139.89727783203125 139.2746429443359375 137.445220947265625 135.7610931396484375 134.9054718017578125 133.8990478515625 127.3390960693359375 123.07080841064453125 122.18209075927734375 115.3932037353515625 105.2664794921875 104.52028656005859375 104.456024169921875 116.51253509521484375 119.0431060791015625 121.34374237060546875 121.24771881103515625 109.9731903076171875 104.58527374267578125 111.676849365234375 121.35882568359375 125.417083740234375 122.9469146728515625 122.4175567626953125 125.32861328125 121.7424163818359375 118.3516998291015625 111.95208740234375 111.798309326171875 113.99684906005859375 117.7797088623046875 117.99127960205078125 121.654388427734375 120.519989013671875 122.27993011474609375 118.0675811767578125 118.88277435302734375 111.9532928466796875 101.4583282470703125 96.92765045166015625 95.656097412109375 94.31362152099609375 97.135414123535
 15625 98.17511749267578125 101.00878143310546875 107.0187530517578125 113.179718017578125 108.074066162109375 97.02510833740234375 104.79754638671875 108.11191558837890625 108.982635498046875 111.57065582275390625 108.0817413330078125 107.268402099609375 109.5139312744140625 106.40796661376953125 106.4053955078125 104.48181915283203125 103.08762359619140625 104.86887359619140625 107.4058380126953125 106.22022247314453125 107.35294342041015625 107.33295440673828125 108.92237091064453125 104.78794097900390625 103.26766204833984375 104.3950042724609375 103.80277252197265625 104.42282867431640625 100.93144989013671875 99.85382080078125 102.2681121826171875 98.65979766845703125 99.20905303955078125 100.15727996826171875 101.40897369384765625 102.40320587158203125 105.26485443115234375 108.26644134521484375 105.0537261962890625 100.06146240234375 95.61865234375 95.27681732177734375 95.86145782470703125 95.87461090087890625 91.99272918701171875 87.6458282470703125 89.09052276611328125 93.1
 3831329345703125 97.01312255859375 100.2993316650390625
+ 149.42547607421875 149.24737548828125 147.5106353759765625 147.214691162109375 149.7722625732421875 154.1632843017578125 149.0718536376953125 144.354522705078125 140.940826416015625 146.758758544921875 143.965667724609375 145.31365966796875 146.13232421875 138.6285552978515625 145.0863494873046875 144.360809326171875 141.89300537109375 141.75408935546875 137.6600341796875 130.2151641845703125 134.5472564697265625 132.500335693359375 132.692901611328125 128.0147552490234375 124.4826812744140625 128.5931549072265625 133.53533935546875 140.6356353759765625 140.3004150390625 140.6263580322265625 140.076629638671875 137.9046630859375 134.6772613525390625 133.835296630859375 140.1333160400390625 140.0470123291015625 133.57757568359375 124.66584014892578125 122.69765472412109375 130.8521881103515625 134.9865875244140625 137.7052764892578125 138.48944091796875 137.01702880859375 131.8278045654296875 129.9637908935546875 131.13037109375 137.4169158935546875 141.510955810546875 137.412124633
 7890625 132.162261962890625 126.00652313232421875 131.841522216796875 134.9795989990234375 131.0697784423828125 136.587493896484375 137.962738037109375 136.352294921875 138.3295440673828125 136.2079925537109375 131.7761688232421875 129.2697296142578125 127.78778076171875 129.0671539306640625 127.6107025146484375 119.81418609619140625 113.74155426025390625 117.748260498046875 108.3528594970703125 100.61106109619140625 108.3884429931640625 109.4223785400390625 120.05718231201171875 119.61084747314453125 110.03106689453125 101.50464630126953125 113.6255645751953125 122.43790435791015625 124.0784149169921875 118.1233673095703125 119.03775787353515625 123.79196929931640625 121.79743194580078125 116.1924285888671875 115.0799102783203125 107.72646331787109375 112.56764984130859375 113.044708251953125 113.629638671875 114.02593231201171875 115.26351165771484375 120.70264434814453125 125.5655517578125 118.98583984375 112.56449127197265625 108.39598846435546875 106.3408660888671875 102.949279
 78515625 99.860198974609375 93.7647705078125 95.5136566162109375 96.62441253662109375 103.91245269775390625 106.63282012939453125 107.8795928955078125 104.04853057861328125 98.603118896484375 102.05922698974609375 102.85558319091796875 105.9667816162109375 102.56462860107421875 104.59545135498046875 109.50325775146484375 104.621734619140625 98.62105560302734375 99.2200164794921875 100.2015838623046875 101.462005615234375 104.36963653564453125 102.46504974365234375 105.208221435546875 105.125396728515625 106.47274017333984375 104.1240997314453125 101.48387908935546875 102.32054901123046875 103.14006805419921875 103.41852569580078125 101.20278167724609375 103.01830291748046875 104.310028076171875 102.55809783935546875 103.16998291015625 102.901092529296875 104.7241363525390625 105.59857177734375 106.5628204345703125 106.3184814453125 105.62712860107421875 103.21405792236328125 96.87535858154296875 89.72272491455078125 91.00469207763671875 90.219512939453125 89.7390899658203125 86.1470
 03173828125 90.28202056884765625 94.18096160888671875 98.17638397216796875 101.4969940185546875
+ 147.4726104736328125 150.81866455078125 150.0279541015625 146.7676239013671875 149.9260711669921875 152.4222412109375 146.529998779296875 142.9050445556640625 139.693267822265625 145.2451019287109375 144.0098876953125 141.89239501953125 145.20404052734375 138.2698211669921875 139.5865936279296875 139.7916717529296875 137.5120697021484375 134.13397216796875 133.5379791259765625 122.93548583984375 123.906646728515625 124.61463165283203125 129.74951171875 126.89791107177734375 125.07440185546875 128.671142578125 134.416748046875 138.6920166015625 137.4837646484375 138.4824981689453125 137.841766357421875 133.603118896484375 131.3860626220703125 133.1727447509765625 138.9372711181640625 135.9159088134765625 130.43096923828125 125.0119171142578125 120.74234771728515625 126.40093231201171875 133.25982666015625 135.3569793701171875 132.958251953125 130.896331787109375 127.51589202880859375 130.2947540283203125 136.343597412109375 140.5296173095703125 140.0687255859375 139.4466400146484375
  134.7523345947265625 124.4537353515625 125.91228485107421875 132.1544342041015625 131.604766845703125 136.873016357421875 137.024993896484375 131.634246826171875 134.167449951171875 137.42596435546875 129.79803466796875 126.6430206298828125 130.363616943359375 129.3555450439453125 132.2753448486328125 123.812408447265625 123.18325042724609375 125.8988037109375 118.9091949462890625 103.80687713623046875 99.718475341796875 110.906341552734375 117.6788787841796875 116.2830352783203125 109.38489532470703125 102.84662628173828125 113.71944427490234375 122.561798095703125 119.1354217529296875 111.79550933837890625 120.5297393798828125 123.593505859375 119.7193756103515625 112.99477386474609375 108.694488525390625 106.23862457275390625 107.6383056640625 106.19130706787109375 109.8936767578125 113.8415069580078125 118.82808685302734375 124.811614990234375 127.93091583251953125 122.89483642578125 119.11705780029296875 117.87276458740234375 111.667236328125 103.02208709716796875 105.17559051
 513671875 103.5562591552734375 94.7361602783203125 94.576080322265625 96.8792877197265625 102.6527252197265625 103.36435699462890625 100.87218475341796875 97.057830810546875 102.066314697265625 99.54238128662109375 100.7601470947265625 100.0037994384765625 102.8182525634765625 107.71649169921875 98.966094970703125 95.76988983154296875 96.2746734619140625 97.758453369140625 99.90496826171875 100.45653533935546875 102.885772705078125 101.71811676025390625 104.71533966064453125 104.2882537841796875 102.46692657470703125 99.758209228515625 99.23972320556640625 98.6001434326171875 99.40143585205078125 97.812255859375 99.9113922119140625 102.44478607177734375 103.04248809814453125 100.4282379150390625 100.02191925048828125 101.81589508056640625 103.47797393798828125 105.27422332763671875 105.19831085205078125 102.871063232421875 100.986236572265625 100.10466766357421875 94.8952484130859375 87.36919403076171875 85.39020538330078125 86.32752227783203125 83.6981964111328125 89.08621978759765
 625 93.8232574462890625 98.43288421630859375 99.68018341064453125
+ 149.8500518798828125 150.50823974609375 153.6005706787109375 148.7681121826171875 149.8945159912109375 149.7730712890625 148.2449798583984375 151.08538818359375 139.3945465087890625 142.212677001953125 140.2597198486328125 137.99658203125 136.4167633056640625 133.7644500732421875 133.981170654296875 132.6351318359375 131.6019134521484375 130.7250823974609375 124.14319610595703125 122.6008148193359375 121.924163818359375 122.82752227783203125 123.69445037841796875 124.944793701171875 124.38756561279296875 128.2178955078125 132.710968017578125 134.0395965576171875 133.034332275390625 135.28240966796875 138.73028564453125 130.3025665283203125 127.02947998046875 131.2309722900390625 135.3560791015625 136.573272705078125 133.1805572509765625 126.37351226806640625 119.07811737060546875 126.66902923583984375 130.828765869140625 127.29912567138671875 132.8472747802734375 128.4203948974609375 122.55071258544921875 127.422332763671875 136.5879364013671875 142.52301025390625 139.8766021728515
 625 134.9407196044921875 132.1181793212890625 126.4663848876953125 122.92510223388671875 129.3105926513671875 130.227630615234375 131.1698455810546875 133.2903594970703125 130.033905029296875 130.0469818115234375 125.18727874755859375 132.816192626953125 124.46703338623046875 129.4304656982421875 131.930267333984375 132.972747802734375 127.8425445556640625 122.4573516845703125 115.5531463623046875 112.9672698974609375 105.35021209716796875 97.9329681396484375 97.32349395751953125 107.52378082275390625 114.28981781005859375 105.815826416015625 100.2124176025390625 112.53357696533203125 120.5594482421875 113.1890869140625 112.395050048828125 115.42708587646484375 120.96437835693359375 115.80030059814453125 115.79085540771484375 105.98696136474609375 102.60994720458984375 103.24920654296875 105.864227294921875 111.41595458984375 115.19557952880859375 117.8177337646484375 123.00002288818359375 128.2994842529296875 123.93691253662109375 123.116668701171875 114.89469146728515625 109.49423
 2177734375 110.44669342041015625 110.4327850341796875 105.90476226806640625 98.954132080078125 92.1207122802734375 94.90033721923828125 102.94293975830078125 98.3788909912109375 93.27217864990234375 95.39752960205078125 99.38033294677734375 95.96195220947265625 95.369354248046875 100.2290802001953125 100.209625244140625 102.48448944091796875 97.08261871337890625 96.28845977783203125 95.345123291015625 94.45790863037109375 95.8162384033203125 97.47930908203125 101.63153839111328125 99.38248443603515625 102.69309234619140625 102.7600860595703125 101.70407867431640625 98.730133056640625 99.0113677978515625 96.1895904541015625 93.62322998046875 94.45941925048828125 95.9624176025390625 100.4158477783203125 101.02158355712890625 97.28170013427734375 96.331298828125 97.9965362548828125 100.245513916015625 101.3425750732421875 104.1324310302734375 101.1413116455078125 97.9450225830078125 96.51096343994140625 97.2750701904296875 92.51848602294921875 85.34806060791015625 80.4516143798828125 8
 3.62749481201171875 87.64295196533203125 92.821624755859375 94.95538330078125 94.31626129150390625
+ 152.512359619140625 153.1404571533203125 152.8338470458984375 149.0073089599609375 148.699066162109375 147.8865814208984375 147.523773193359375 147.490325927734375 140.3529205322265625 135.1087493896484375 136.4930572509765625 135.414398193359375 133.61297607421875 133.68194580078125 130.709320068359375 128.3641815185546875 131.3696746826171875 128.60626220703125 133.1479644775390625 134.2789764404296875 124.04567718505859375 121.24761962890625 121.2339019775390625 120.90381622314453125 120.29239654541015625 122.60788726806640625 129.22760009765625 130.228057861328125 130.646759033203125 133.2678680419921875 136.889190673828125 133.720550537109375 124.37713623046875 129.6805877685546875 135.4752655029296875 134.2825164794921875 135.304473876953125 132.1833648681640625 119.70379638671875 119.26546478271484375 122.78643035888671875 129.2765655517578125 132.6677703857421875 128.581573486328125 124.4348907470703125 131.063446044921875 136.8395843505859375 140.7786712646484375 135.56848
 14453125 137.477630615234375 131.9243011474609375 129.1021575927734375 122.57049560546875 122.78289031982421875 125.7935028076171875 127.5803070068359375 128.554962158203125 124.5841827392578125 127.27362823486328125 128.898040771484375 125.62639617919921875 120.95934295654296875 123.25829315185546875 127.98596954345703125 132.45751953125 129.881805419921875 128.65283203125 121.98822021484375 116.780487060546875 111.44420623779296875 100.45676422119140625 96.05218505859375 107.01239013671875 110.7132110595703125 103.5073394775390625 101.46331787109375 107.6825408935546875 117.486846923828125 109.15261077880859375 108.21312713623046875 115.15523529052734375 119.58121490478515625 116.0425567626953125 112.25585174560546875 110.31182861328125 103.14937591552734375 101.2092132568359375 107.21533203125 109.86540985107421875 112.23596954345703125 116.94461822509765625 126.54308319091796875 127.01184844970703125 124.69886016845703125 119.2286529541015625 115.92302703857421875 116.5617904663
 0859375 114.59349822998046875 117.49846649169921875 110.4702911376953125 101.48021697998046875 96.65172576904296875 91.65125274658203125 97.55347442626953125 99.3380889892578125 90.3345184326171875 88.77838134765625 90.57462310791015625 93.94710540771484375 95.2645416259765625 102.825408935546875 106.72663116455078125 101.30106353759765625 93.6549072265625 91.9476776123046875 94.76589202880859375 95.46793365478515625 97.75174713134765625 100.9187469482421875 99.4442596435546875 96.4494781494140625 101.09188079833984375 102.032318115234375 99.9072418212890625 97.43857574462890625 98.90512847900390625 95.80236053466796875 91.41253662109375 91.21771240234375 95.8326263427734375 99.7288818359375 101.01171875 96.61804962158203125 94.736541748046875 96.7877655029296875 99.3395843505859375 99.86124420166015625 102.99742889404296875 100.0395660400390625 96.64791107177734375 94.9504547119140625 96.06923675537109375 93.44091796875 90.86702728271484375 83.15914154052734375 81.0517578125 87.506
 5765380859375 91.16985321044921875 91.42157745361328125 90.593505859375
+ 146.7382659912109375 149.9534912109375 150.4296417236328125 144.54364013671875 147.79669189453125 145.54168701171875 145.4381256103515625 145.20587158203125 141.906768798828125 138.11883544921875 136.431365966796875 136.1527557373046875 139.3703460693359375 138.290802001953125 142.5928955078125 138.970001220703125 137.838134765625 139.11859130859375 138.4427032470703125 134.8520965576171875 130.5473785400390625 133.1809844970703125 125.79126739501953125 120.8803558349609375 118.7614593505859375 121.92548370361328125 122.3161773681640625 126.356842041015625 131.454833984375 129.728271484375 133.0653228759765625 135.0872802734375 125.01313018798828125 127.809661865234375 130.69281005859375 128.062164306640625 134.6056671142578125 134.9049530029296875 127.24457550048828125 117.4402618408203125 123.31568145751953125 129.928314208984375 128.8482208251953125 122.42067718505859375 124.72303009033203125 128.2185211181640625 134.8922119140625 138.62518310546875 132.10467529296875 133.511001
 5869140625 137.3394927978515625 135.3453369140625 129.29864501953125 122.208404541015625 122.3736114501953125 119.10634613037109375 124.156707763671875 121.410888671875 128.73223876953125 128.6800384521484375 122.538299560546875 117.78530120849609375 121.28279876708984375 128.55419921875 133.103790283203125 131.0232391357421875 125.82982635498046875 116.78142547607421875 113.44165802001953125 104.2406768798828125 101.4212493896484375 95.776458740234375 97.8900299072265625 110.545562744140625 104.446624755859375 96.77901458740234375 109.0745086669921875 111.58353424072265625 101.41104888916015625 111.9782562255859375 117.119293212890625 117.3945465087890625 112.88404083251953125 108.3248138427734375 105.4822235107421875 99.5509796142578125 99.981781005859375 103.76976776123046875 110.31711578369140625 112.56524658203125 119.946746826171875 128.3956756591796875 128.06744384765625 125.48651885986328125 121.8391571044921875 122.35410308837890625 122.234832763671875 119.90476226806640625
  117.52617645263671875 113.6990814208984375 106.81200408935546875 106.0995941162109375 95.67177581787109375 87.33103179931640625 94.410003662109375 90.67794036865234375 86.4998626708984375 87.555389404296875 93.00681304931640625 98.61829376220703125 103.12646484375 103.616790771484375 98.4637451171875 92.472503662109375 87.2544708251953125 90.9237823486328125 95.19751739501953125 97.17130279541015625 101.23607635498046875 94.45856475830078125 94.68904876708984375 100.0616912841796875 100.1093292236328125 97.88311767578125 96.123046875 97.3002471923828125 96.15171051025390625 89.63582611083984375 91.19225311279296875 95.8523712158203125 97.95082855224609375 99.57068634033203125 96.31585693359375 93.10085296630859375 96.87647247314453125 96.79746246337890625 100.01373291015625 101.95105743408203125 101.9151153564453125 96.55854034423828125 91.5319061279296875 93.3556060791015625 89.890411376953125 89.46169281005859375 84.4067840576171875 77.27614593505859375 85.35828399658203125 83.58
 94622802734375 86.36902618408203125 87.3904266357421875
+ 143.67413330078125 146.799285888671875 144.2581024169921875 141.445709228515625 147.4324493408203125 147.4847259521484375 145.8419952392578125 148.1535186767578125 145.15460205078125 144.0810089111328125 145.301422119140625 145.166534423828125 144.133697509765625 143.68475341796875 142.5915679931640625 142.253936767578125 141.594940185546875 144.609130859375 142.03607177734375 132.9160308837890625 132.4170379638671875 137.8823394775390625 138.2690277099609375 134.2705535888671875 130.1295623779296875 119.2420196533203125 126.28092193603515625 121.1641082763671875 127.87305450439453125 127.65613555908203125 130.518218994140625 129.851318359375 121.42858123779296875 125.68112945556640625 125.57102203369140625 125.91574859619140625 130.9644775390625 132.398681640625 129.62054443359375 117.768157958984375 118.2215118408203125 125.451171875 126.82106781005859375 118.2793121337890625 124.60596466064453125 127.49480438232421875 132.420013427734375 136.8133697509765625 127.4144134521484375
  129.63232421875 134.99371337890625 132.533599853515625 133.4262542724609375 128.7490081787109375 126.84482574462890625 121.4786224365234375 115.14971923828125 118.545989990234375 123.2467498779296875 125.6887664794921875 122.69704437255859375 115.85433197021484375 122.0594024658203125 126.66524505615234375 130.256744384765625 128.997039794921875 129.5380706787109375 121.4806671142578125 111.46755218505859375 116.6488494873046875 110.20288848876953125 98.0869293212890625 92.84188079833984375 104.30023956298828125 103.95580291748046875 96.7349700927734375 103.36118316650390625 104.199310302734375 102.96057891845703125 108.15830230712890625 115.51123809814453125 111.102935791015625 109.59934234619140625 110.1640777587890625 107.4489593505859375 98.529052734375 97.90769195556640625 108.0326995849609375 111.86281585693359375 117.24840545654296875 121.23535919189453125 125.82741546630859375 125.01222991943359375 122.49106597900390625 119.78730010986328125 118.94934844970703125 122.901741
 02783203125 118.8937225341796875 112.799713134765625 108.32566070556640625 107.99112701416015625 104.3564910888671875 96.60446929931640625 95.036163330078125 92.83193206787109375 85.4990081787109375 86.72320556640625 87.1205596923828125 91.5633392333984375 96.8755950927734375 99.58917236328125 100.4528961181640625 95.37230682373046875 87.3238525390625 87.47931671142578125 93.701904296875 95.126556396484375 95.53621673583984375 94.77561187744140625 91.49884033203125 96.152374267578125 99.34374237060546875 101.95320892333984375 97.074127197265625 94.68276214599609375 94.39580535888671875 94.0792999267578125 92.25260162353515625 89.58734130859375 93.70030975341796875 94.15933990478515625 95.62155914306640625 95.8498077392578125 92.59967041015625 96.73413848876953125 92.3418121337890625 97.81075286865234375 99.38488006591796875 102.10054779052734375 97.88248443603515625 93.42137908935546875 88.1137542724609375 86.9639434814453125 88.65341949462890625 84.875946044921875 78.60225677490234
 375 79.9255523681640625 78.51139068603515625 86.59114837646484375 90.028167724609375
+ 141.07421875 143.24566650390625 138.2341461181640625 145.8363800048828125 147.618133544921875 150.5208282470703125 147.0788726806640625 147.5430908203125 145.7558746337890625 145.43695068359375 146.607086181640625 146.4202117919921875 145.5345001220703125 143.8119354248046875 143.952117919921875 144.491729736328125 143.5471038818359375 146.915374755859375 139.6185150146484375 136.1346282958984375 133.81549072265625 135.3961181640625 137.3094940185546875 133.0479888916015625 129.8514251708984375 118.64105987548828125 118.65077972412109375 123.351959228515625 120.63626861572265625 123.16524505615234375 124.38191986083984375 122.08188629150390625 117.3436126708984375 117.50843048095703125 119.6676483154296875 122.367401123046875 127.21010589599609375 129.9232330322265625 131.07464599609375 122.57411956787109375 115.8399810791015625 120.838775634765625 123.83028411865234375 116.01983642578125 123.4034881591796875 125.448486328125 132.2856903076171875 134.0048370361328125 125.4007568359
 375 126.82990264892578125 130.1443634033203125 126.760711669921875 128.98516845703125 136.0263214111328125 135.2052154541015625 130.219329833984375 118.67536163330078125 114.046783447265625 112.84152984619140625 120.35866546630859375 122.7005157470703125 113.03704833984375 117.14670562744140625 120.95672607421875 125.2919464111328125 124.60556793212890625 128.1035614013671875 124.71062469482421875 117.22585296630859375 121.97199249267578125 112.27732086181640625 103.71996307373046875 92.853302001953125 97.4512481689453125 99.15277862548828125 94.292877197265625 100.7532196044921875 98.802032470703125 105.9338836669921875 109.77613067626953125 110.857086181640625 106.8251495361328125 107.0450592041015625 110.82498931884765625 106.56789398193359375 97.14746856689453125 102.9033966064453125 105.61966705322265625 110.5585784912109375 117.4264984130859375 122.0338287353515625 122.6523284912109375 122.09404754638671875 118.2481689453125 113.5781097412109375 115.80136871337890625 120.32041
 93115234375 120.8823089599609375 115.24517059326171875 108.27852630615234375 106.57056427001953125 102.8169708251953125 98.51364898681640625 95.2896270751953125 93.9519805908203125 91.10443115234375 92.9086151123046875 83.30548095703125 89.91939544677734375 92.81562042236328125 93.7273406982421875 96.44115447998046875 89.74646759033203125 83.28267669677734375 90.26085662841796875 95.417266845703125 98.00311279296875 93.74248504638671875 88.81731414794921875 91.03186798095703125 97.0599365234375 100.356689453125 99.5474090576171875 96.28829193115234375 93.55701446533203125 92.4826202392578125 89.75276947021484375 92.836700439453125 84.21627044677734375 90.22503662109375 92.7626953125 93.33057403564453125 94.30462646484375 91.1715240478515625 94.44594573974609375 91.03787994384765625 92.1551513671875 97.11717987060546875 101.3743896484375 96.58754730224609375 96.44437408447265625 91.31111907958984375 84.82108306884765625 86.02808380126953125 86.5427093505859375 77.490814208984375 76.4
 022979736328125 88.161895751953125 90.0782318115234375 92.74566650390625
+ 136.388397216796875 137.420623779296875 139.4173736572265625 144.00836181640625 143.436279296875 146.5018768310546875 149.8101806640625 149.5762786865234375 148.87432861328125 146.886810302734375 145.835296630859375 146.3538970947265625 146.307159423828125 144.690216064453125 143.8394927978515625 143.4831695556640625 145.6604766845703125 146.066375732421875 141.8505096435546875 141.137908935546875 134.103179931640625 129.1242828369140625 129.1933441162109375 125.4534912109375 120.30919647216796875 119.18247222900390625 117.68711090087890625 117.71979522705078125 121.79155731201171875 119.64806365966796875 116.87438201904296875 115.5894012451171875 115.00634765625 113.83409881591796875 115.06897735595703125 118.5523529052734375 122.8864593505859375 125.45774078369140625 127.72203826904296875 124.82178497314453125 112.33676910400390625 119.9953155517578125 119.234130859375 116.36486053466796875 122.238983154296875 123.4510955810546875 128.1599578857421875 128.8838348388671875 122.164
 17694091796875 125.56940460205078125 127.03040313720703125 125.6060638427734375 128.893890380859375 135.395050048828125 135.020782470703125 126.20426177978515625 125.61971282958984375 118.97412109375 111.37371063232421875 111.90130615234375 119.61809539794921875 115.82317352294921875 114.57415008544921875 118.46279144287109375 119.75669097900390625 118.78887176513671875 127.45461273193359375 127.74936676025390625 125.58309173583984375 121.851898193359375 114.599151611328125 109.66605377197265625 95.44528961181640625 94.07715606689453125 95.84551239013671875 91.22968292236328125 90.71486663818359375 98.80248260498046875 108.1070098876953125 109.8578338623046875 105.26805877685546875 100.88471221923828125 104.92060089111328125 109.81139373779296875 103.283477783203125 92.301116943359375 98.5634613037109375 103.70616912841796875 103.774658203125 111.076568603515625 114.95163726806640625 120.22674560546875 115.26171875 117.03752899169921875 111.50191497802734375 112.31995391845703125 11
 8.9379119873046875 120.99327850341796875 117.09133148193359375 115.3008880615234375 108.14804840087890625 105.5670013427734375 102.504180908203125 97.5192413330078125 95.2090911865234375 97.104644775390625 90.99802398681640625 81.101898193359375 81.0676727294921875 86.77811431884765625 87.67922210693359375 91.972503662109375 89.7076568603515625 82.64501190185546875 87.5751800537109375 90.34560394287109375 90.71242523193359375 87.564483642578125 87.59442138671875 93.18829345703125 94.4805755615234375 100.6747894287109375 98.50019073486328125 95.49411773681640625 91.62328338623046875 93.39144134521484375 89.20354461669921875 90.06655120849609375 86.4197845458984375 86.1779632568359375 88.8936309814453125 89.8542327880859375 88.6876068115234375 92.88280487060546875 92.59654998779296875 88.6041107177734375 91.58998870849609375 98.89096832275390625 100.99242401123046875 94.3993682861328125 95.5099334716796875 91.52429962158203125 86.77764892578125 80.971435546875 83.85803985595703125 73.
 5236053466796875 79.3243408203125 86.2100982666015625 82.520355224609375 90.57587432861328125
+ 134.31622314453125 135.3301849365234375 138.3215484619140625 142.590057373046875 137.85986328125 142.4929351806640625 149.6547698974609375 149.91790771484375 148.64501953125 147.8347930908203125 145.0321807861328125 144.5107879638671875 146.6013031005859375 145.625244140625 143.903656005859375 142.8988800048828125 146.3412322998046875 145.7271270751953125 138.5863800048828125 139.64892578125 129.8818817138671875 130.2429962158203125 126.1637725830078125 124.755035400390625 126.36969757080078125 127.07831573486328125 134.9735107421875 116.4309844970703125 116.450439453125 116.63155364990234375 120.1916351318359375 115.661895751953125 118.6323394775390625 125.90441131591796875 113.5849151611328125 117.5232696533203125 120.5249176025390625 120.68703460693359375 123.391693115234375 124.3757781982421875 112.02928924560546875 116.94516754150390625 114.576751708984375 115.0833892822265625 116.40789031982421875 119.782806396484375 125.51282501220703125 123.56226348876953125 121.19992828369
 140625 123.38864898681640625 119.1989898681640625 123.32822418212890625 131.2737579345703125 138.0233001708984375 132.932586669921875 128.4143524169921875 132.084136962890625 124.19647979736328125 116.24910736083984375 108.3230133056640625 111.0030059814453125 115.59765625 108.51275634765625 116.24239349365234375 114.5559234619140625 118.0338592529296875 126.17678070068359375 122.11956787109375 123.95066070556640625 122.422698974609375 118.552093505859375 111.62946319580078125 103.38846588134765625 96.041595458984375 93.062286376953125 90.48960113525390625 93.02272796630859375 100.123291015625 100.65830230712890625 99.95038604736328125 100.06093597412109375 98.0762481689453125 103.64778900146484375 108.48906707763671875 100.06320953369140625 90.4582672119140625 97.56243133544921875 101.86687469482421875 100.52082061767578125 106.23500823974609375 117.259063720703125 116.31951904296875 111.8887481689453125 112.3004913330078125 107.54657745361328125 111.56683349609375 116.041458129882
 8125 120.80661773681640625 119.254241943359375 112.73493194580078125 110.0855560302734375 108.510650634765625 103.07028961181640625 98.26373291015625 93.652679443359375 101.87772369384765625 99.4625244140625 92.6484832763671875 84.23355865478515625 82.39189910888671875 83.3891754150390625 85.26578521728515625 86.38315582275390625 82.149505615234375 83.28099822998046875 86.01044464111328125 86.102203369140625 82.914794921875 87.29355621337890625 90.3748016357421875 97.8948211669921875 99.3407440185546875 97.64214324951171875 93.900634765625 92.46929931640625 89.38840484619140625 89.05759429931640625 89.27860260009765625 88.2446441650390625 82.39608001708984375 84.58771514892578125 85.317718505859375 92.21750640869140625 92.94100189208984375 92.87139129638671875 86.312164306640625 94.37328338623046875 101.53806304931640625 98.64194488525390625 95.11312103271484375 89.72533416748046875 85.09976959228515625 86.97208404541015625 79.92185211181640625 80.8608856201171875 74.416984558105468
 75 75.25380706787109375 78.25208282470703125 83.690032958984375 91.816192626953125
+ 131.0258941650390625 133.4357452392578125 136.6060333251953125 139.8017578125 138.2632904052734375 143.4972076416015625 146.4831695556640625 149.7229461669921875 145.93743896484375 147.5133819580078125 144.0481109619140625 143.126922607421875 144.11566162109375 144.1336669921875 143.007354736328125 147.46722412109375 146.33575439453125 143.98651123046875 137.5222320556640625 130.8992156982421875 132.4263763427734375 134.69439697265625 131.56060791015625 124.1989593505859375 135.1838226318359375 137.56573486328125 137.8533935546875 134.1126556396484375 117.74593353271484375 125.7724609375 125.98047637939453125 122.01819610595703125 122.81744384765625 130.29241943359375 115.60455322265625 113.2895355224609375 117.065887451171875 116.71921539306640625 119.196319580078125 119.18651580810546875 109.24102783203125 111.7777862548828125 112.92377471923828125 109.8209381103515625 110.5159912109375 115.450469970703125 120.6901397705078125 115.92728424072265625 117.5481109619140625 118.507759
 09423828125 116.547332763671875 126.5615997314453125 130.8912506103515625 138.1109161376953125 137.0887298583984375 133.82135009765625 135.595672607421875 126.8592376708984375 122.6578216552734375 113.2152099609375 106.7128753662109375 108.1183013916015625 106.47101593017578125 111.4881134033203125 111.02770233154296875 119.31874847412109375 122.823577880859375 119.481231689453125 120.85387420654296875 123.966522216796875 118.62483978271484375 110.5928802490234375 105.050537109375 99.0990447998046875 94.86141204833984375 89.62884521484375 90.24456787109375 92.96353912353515625 92.82570648193359375 91.23369598388671875 90.890869140625 99.376220703125 100.8095245361328125 104.606292724609375 99.2751617431640625 89.81073760986328125 95.5650177001953125 102.13253021240234375 108.0723876953125 115.4988250732421875 117.60686492919921875 112.45937347412109375 105.71450042724609375 105.37516021728515625 102.76844024658203125 111.37079620361328125 113.46152496337890625 118.13846588134765625
 118.595306396484375 111.79534149169921875 106.979736328125 104.0338592529296875 101.7543487548828125 96.5070953369140625 100.5847625732421875 104.6021728515625 105.1027374267578125 99.207550048828125 94.3556671142578125 81.4755096435546875 81.96099090576171875 80.37967681884765625 79.671142578125 78.41143035888671875 79.4776458740234375 82.00774383544921875 81.7985687255859375 81.972503662109375 87.0493316650390625 90.31497955322265625 96.92081451416015625 94.44155120849609375 96.193939208984375 91.8704681396484375 91.9540252685546875 91.79601287841796875 83.79436492919921875 86.98400115966796875 88.9477996826171875 79.7881317138671875 84.86957550048828125 91.42887115478515625 94.81601715087890625 90.51940155029296875 87.71158599853515625 85.87171173095703125 95.1773681640625 97.79421234130859375 96.746063232421875 93.53240203857421875 85.93023681640625 84.28000640869140625 81.49333953857421875 78.1491851806640625 78.955230712890625 77.38764190673828125 71.0692291259765625 82.228775
 0244140625 87.1021575927734375 89.83121490478515625
+ 133.132080078125 129.2080841064453125 135.6617889404296875 135.582122802734375 136.7506866455078125 140.50689697265625 142.2636871337890625 141.889312744140625 146.1226043701171875 146.481689453125 142.8524322509765625 140.6006927490234375 142.066864013671875 142.326416015625 143.7673797607421875 144.683685302734375 140.1280059814453125 136.2891998291015625 132.861572265625 135.6340789794921875 138.3406982421875 137.034698486328125 135.43463134765625 127.06873321533203125 136.9693145751953125 143.85870361328125 141.4167022705078125 139.1448822021484375 121.29833221435546875 131.2830047607421875 135.7261199951171875 128.5645599365234375 125.47662353515625 127.186248779296875 120.3327178955078125 112.1714324951171875 114.04889678955078125 115.44415283203125 116.92315673828125 117.31049346923828125 112.9980316162109375 108.4982452392578125 107.57830047607421875 107.11206817626953125 106.8152008056640625 109.3665924072265625 114.76248931884765625 110.968902587890625 112.474044799804687
 5 110.13890838623046875 119.68555450439453125 127.88367462158203125 132.455474853515625 136.949737548828125 136.8120269775390625 133.5503997802734375 132.4751129150390625 131.586517333984375 128.2457275390625 116.26329803466796875 110.89090728759765625 106.00142669677734375 104.31729888916015625 104.33901214599609375 111.08074188232421875 113.61609649658203125 119.6382904052734375 114.5318603515625 114.44017791748046875 121.96035003662109375 115.5151519775390625 111.878173828125 108.3887786865234375 103.50018310546875 97.538482666015625 89.52051544189453125 86.699493408203125 86.5683135986328125 86.973785400390625 88.43160247802734375 90.3545379638671875 96.216888427734375 99.41571044921875 100.6390380859375 98.0865020751953125 87.940887451171875 99.9102325439453125 102.6240692138671875 102.11666107177734375 111.9704742431640625 110.5630645751953125 110.79264068603515625 103.83306121826171875 98.08612060546875 107.05512237548828125 107.762359619140625 113.25319671630859375 117.59402
 4658203125 115.6976318359375 110.9115142822265625 107.47974395751953125 102.72600555419921875 99.5330047607421875 97.343505859375 99.5009307861328125 104.4109649658203125 108.5498504638671875 106.4954833984375 101.87677764892578125 94.55225372314453125 79.6994781494140625 78.1519317626953125 77.53851318359375 75.62981414794921875 82.87169647216796875 83.85955810546875 83.96370697021484375 79.76082611083984375 94.44705963134765625 94.57782745361328125 92.95766448974609375 90.03089141845703125 90.5610504150390625 88.13986968994140625 89.1559906005859375 94.08200836181640625 88.2304534912109375 82.9257354736328125 84.67891693115234375 78.83574676513671875 84.45849609375 91.61136627197265625 94.81317138671875 88.16899871826171875 80.7214508056640625 87.09935760498046875 96.74204254150390625 93.775482177734375 94.449615478515625 94.5978851318359375 89.07514190673828125 83.37639617919921875 78.161865234375 77.43059539794921875 78.5063323974609375 78.69557952880859375 69.36725616455078125
 78.0279998779296875 80.51558685302734375 86.53441619873046875
+ 137.162078857421875 129.2805328369140625 131.2506866455078125 130.3432159423828125 136.6608123779296875 132.7736663818359375 135.8661346435546875 139.765655517578125 145.969268798828125 145.8376617431640625 142.0244140625 140.7583160400390625 139.29193115234375 142.3719024658203125 141.0747833251953125 138.3817291259765625 137.864501953125 137.3391571044921875 139.908538818359375 142.0657196044921875 145.730072021484375 140.06243896484375 140.0825653076171875 135.27410888671875 134.6638031005859375 145.0080108642578125 146.6207275390625 138.1480560302734375 123.6238250732421875 131.9221343994140625 137.9597320556640625 137.8502197265625 126.91786956787109375 129.550537109375 122.3600921630859375 111.6556549072265625 111.9400177001953125 112.722869873046875 110.6422882080078125 110.1134490966796875 109.4452362060546875 113.81069183349609375 110.05735015869140625 109.15755462646484375 108.50009918212890625 110.05908203125 106.737518310546875 105.3137054443359375 106.3267669677734375
 112.8331146240234375 123.23779296875 129.0586395263671875 128.88543701171875 135.23443603515625 131.7657623291015625 128.88275146484375 128.37835693359375 132.3526153564453125 127.96030426025390625 122.36823272705078125 118.516448974609375 119.97270965576171875 115.80651092529296875 101.21370697021484375 104.2765045166015625 113.96726226806640625 115.75659942626953125 107.9337615966796875 114.35272979736328125 119.1898193359375 112.12659454345703125 105.49434661865234375 104.7634735107421875 102.35201263427734375 97.81295013427734375 87.9021453857421875 86.37323760986328125 85.7045745849609375 85.57064056396484375 85.5296783447265625 88.9625091552734375 92.59746551513671875 95.94910430908203125 96.02579498291015625 92.81317901611328125 86.8290557861328125 99.8225555419921875 102.22196197509765625 108.53094482421875 109.09914398193359375 102.3478240966796875 109.60077667236328125 103.44000244140625 100.41197967529296875 105.57830047607421875 113.506195068359375 115.61399078369140625
 113.0583038330078125 109.9961395263671875 107.90038299560546875 106.39202117919921875 105.143585205078125 99.75653076171875 94.49349212646484375 100.5665435791015625 104.12139129638671875 108.6114501953125 111.76787567138671875 104.77013397216796875 99.6048431396484375 95.25881195068359375 89.3998565673828125 89.55985260009765625 81.94634246826171875 76.6747589111328125 77.2918701171875 80.4440765380859375 84.55883026123046875 85.7120819091796875 81.3369903564453125 80.07863616943359375 82.1343536376953125 85.03127288818359375 85.2579498291015625 89.600799560546875 92.2988128662109375 91.37306976318359375 86.5304412841796875 82.5352935791015625 78.41735076904296875 83.41681671142578125 89.2548370361328125 90.6373748779296875 84.510040283203125 79.79338836669921875 88.38459014892578125 92.61692047119140625 90.53838348388671875 92.859283447265625 93.8135986328125 85.75482940673828125 83.4338226318359375 80.90000152587890625 75.7730865478515625 78.168212890625 85.59679412841796875 74.8
 34869384765625 73.12456512451171875 76.4854736328125 81.14595794677734375
+ 137.0872039794921875 130.377197265625 125.88219451904296875 132.8903961181640625 129.30950927734375 137.8672943115234375 143.227935791015625 148.5181884765625 146.9207916259765625 141.5014801025390625 141.4124908447265625 136.0098876953125 138.702239990234375 142.8248138427734375 145.4481964111328125 142.0312957763671875 142.304840087890625 141.588897705078125 143.907989501953125 143.874908447265625 147.369232177734375 139.199005126953125 144.0262451171875 140.8574066162109375 135.3710479736328125 143.4106903076171875 148.7475433349609375 141.17724609375 135.0669097900390625 136.8657379150390625 140.7231597900390625 142.2365264892578125 141.074615478515625 131.542236328125 132.4134521484375 130.734832763671875 122.30847930908203125 110.96724700927734375 110.54259490966796875 116.704193115234375 114.0701904296875 112.07068634033203125 117.13228607177734375 111.955718994140625 112.279693603515625 114.9452667236328125 113.9564666748046875 105.224517822265625 105.6836090087890625 113.2
 431640625 123.21059417724609375 125.766448974609375 127.76102447509765625 132.7597198486328125 131.8804779052734375 126.65404510498046875 126.8045501708984375 132.1228790283203125 126.38378143310546875 126.33089447021484375 125.5932769775390625 123.5162200927734375 119.82512664794921875 105.10424041748046875 99.0692596435546875 105.736572265625 109.17462158203125 106.4142913818359375 114.7445220947265625 116.5612030029296875 108.92345428466796875 101.44591522216796875 99.32561492919921875 97.1683349609375 92.8321380615234375 88.0100250244140625 86.55157470703125 95.39710235595703125 85.77184295654296875 85.00492095947265625 85.14994049072265625 87.52251434326171875 91.87255859375 91.4041595458984375 88.18265533447265625 90.990814208984375 96.416748046875 96.91083526611328125 101.76438140869140625 102.35465240478515625 98.84654998779296875 107.717437744140625 99.29373931884765625 98.411834716796875 104.1942138671875 108.67435455322265625 112.30025482177734375 108.8321990966796875 103
 .20270538330078125 105.092742919921875 104.0862274169921875 101.522430419921875 98.155426025390625 91.2144622802734375 98.4484100341796875 102.33209228515625 107.8144378662109375 109.91646575927734375 107.590087890625 104.760040283203125 97.50559234619140625 95.7218475341796875 90.9982757568359375 82.5318450927734375 78.5624542236328125 75.24544525146484375 80.28304290771484375 82.059112548828125 83.5146331787109375 84.7177276611328125 81.8528289794921875 84.89031982421875 86.91973876953125 86.6875 89.339813232421875 91.31084442138671875 93.45957183837890625 91.516693115234375 87.8477935791015625 83.55170440673828125 80.45603179931640625 85.547088623046875 86.4951934814453125 80.742584228515625 79.89505767822265625 86.9553985595703125 85.302520751953125 87.53934478759765625 91.41998291015625 87.60037994384765625 82.34069061279296875 78.66674041748046875 79.64813995361328125 74.2840118408203125 76.80826568603515625 87.44075775146484375 74.83980560302734375 68.27591705322265625 73.031
 2652587890625 82.735565185546875
+ 139.22705078125 138.784423828125 125.5641326904296875 127.11800384521484375 129.18280029296875 133.2437286376953125 142.8574676513671875 147.099639892578125 145.1548004150390625 140.529052734375 135.442779541015625 135.8952484130859375 135.469451904296875 138.2853851318359375 145.278961181640625 146.0285186767578125 145.2875823974609375 144.6165924072265625 144.57208251953125 146.052215576171875 147.7910003662109375 144.53009033203125 149.175872802734375 141.7142791748046875 135.2539520263671875 139.7817535400390625 147.339752197265625 138.268035888671875 138.8168182373046875 140.2718048095703125 143.5508270263671875 143.71844482421875 142.32196044921875 133.6580963134765625 135.0333404541015625 131.8479766845703125 124.55709075927734375 122.496124267578125 119.68892669677734375 119.12900543212890625 119.91080474853515625 117.78707122802734375 113.92852783203125 111.88641357421875 120.706268310546875 119.2947845458984375 113.0537109375 104.97539520263671875 106.35625457763671875 11
 1.78591156005859375 121.69116973876953125 117.39333343505859375 125.55486297607421875 130.00225830078125 130.872802734375 125.03354644775390625 121.1108245849609375 125.89203643798828125 122.53301239013671875 120.6107635498046875 120.6238250732421875 123.02228546142578125 118.939666748046875 110.74437713623046875 106.70116424560546875 97.589691162109375 100.3264312744140625 107.4388427734375 108.42879486083984375 111.6095123291015625 107.5654296875 98.751953125 96.82337188720703125 91.96509552001953125 87.08499908447265625 86.98117828369140625 90.8181610107421875 99.08594512939453125 84.85832977294921875 84.85190582275390625 84.9310760498046875 85.25550079345703125 85.686767578125 86.61328887939453125 86.3983001708984375 85.55826568603515625 82.058197021484375 92.534393310546875 98.21999359130859375 96.05580902099609375 99.48523712158203125 105.138641357421875 90.5313568115234375 100.22611236572265625 105.8163299560546875 109.4384918212890625 109.7078094482421875 109.351448059082031
 25 97.1650238037109375 100.91336822509765625 102.018951416015625 98.12393951416015625 92.32796478271484375 89.17879486083984375 94.41268157958984375 102.17783355712890625 106.676727294921875 106.92200469970703125 104.61971282958984375 104.182830810546875 102.92443084716796875 101.21909332275390625 93.5725860595703125 86.74575042724609375 77.53968048095703125 81.97149658203125 75.2872772216796875 73.37554168701171875 80.59052276611328125 80.226287841796875 77.1038665771484375 78.17259979248046875 90.56580352783203125 89.47801971435546875 86.67119598388671875 88.699066162109375 89.95603179931640625 93.216705322265625 91.305023193359375 83.38384246826171875 75.40952301025390625 81.229461669921875 83.75432586669921875 82.08559417724609375 75.21775054931640625 80.9908447265625 80.85091400146484375 84.58933258056640625 89.17308807373046875 89.0760650634765625 83.56500244140625 76.82089996337890625 75.16463470458984375 75.9418487548828125 74.2476959228515625 80.19799041748046875 80.5163116
 455078125 70.8915557861328125 70.361785888671875 75.06134033203125
+ 142.238525390625 137.6444244384765625 124.85475921630859375 128.8133392333984375 136.1479644775390625 139.33258056640625 141.586669921875 144.34161376953125 140.4786224365234375 139.171722412109375 133.3716583251953125 132.8542327880859375 135.0098724365234375 141.8283233642578125 146.2578125 148.44329833984375 148.7773284912109375 148.5148468017578125 149.235626220703125 146.7382659912109375 148.597320556640625 147.5360870361328125 149.283721923828125 140.373138427734375 140.032745361328125 142.126800537109375 149.2006378173828125 144.8852081298828125 141.04644775390625 144.179046630859375 142.615264892578125 142.701416015625 142.3512725830078125 133.5878753662109375 132.6584014892578125 128.5103912353515625 124.3025665283203125 124.78522491455078125 130.4755401611328125 127.95977020263671875 123.5210723876953125 117.74539947509765625 113.09572601318359375 118.82564544677734375 126.4048309326171875 124.6568450927734375 108.34671783447265625 104.34719085693359375 105.24745941162109
 375 110.31372833251953125 112.84970855712890625 120.30052947998046875 126.0205841064453125 122.5790252685546875 127.38838958740234375 123.8896026611328125 118.2281036376953125 123.4508819580078125 117.753021240234375 117.103546142578125 113.98895263671875 122.1610870361328125 117.44075775146484375 111.6346435546875 107.89714813232421875 108.56079864501953125 97.69658660888671875 102.07587432861328125 105.23459625244140625 102.53272247314453125 98.94625091552734375 96.0948638916015625 92.55013275146484375 87.79740142822265625 87.66498565673828125 89.9729461669921875 100.24376678466796875 98.96935272216796875 84.59250640869140625 84.3228759765625 84.4241180419921875 84.54695892333984375 84.32568359375 84.88983917236328125 82.50371551513671875 81.566650390625 81.36791229248046875 82.66675567626953125 87.94217681884765625 90.93076324462890625 92.8943634033203125 100.7171783447265625 88.46048736572265625 95.54447174072265625 101.991607666015625 99.86679840087890625 108.37500762939453125
 105.6172637939453125 94.8168487548828125 98.35164642333984375 100.2150421142578125 96.62408447265625 89.587677001953125 89.02300262451171875 94.07513427734375 100.09204864501953125 102.17470550537109375 106.0005950927734375 104.637237548828125 103.64379119873046875 102.05371856689453125 104.565673828125 96.92462158203125 91.27446746826171875 88.9557037353515625 74.02640533447265625 72.7442779541015625 72.76445770263671875 73.77909088134765625 74.1516876220703125 77.62624359130859375 82.40546417236328125 88.7011566162109375 88.2383575439453125 84.31029510498046875 85.69927978515625 86.27845001220703125 89.76425933837890625 91.24201202392578125 84.99271392822265625 75.5634307861328125 76.82805633544921875 81.1226348876953125 77.9629974365234375 75.1558990478515625 76.1484222412109375 78.5201263427734375 85.63318634033203125 88.4374237060546875 86.6032257080078125 84.84946441650390625 76.2755584716796875 70.77725982666015625 71.3832855224609375 68.79474639892578125 72.9108123779296875
 73.52640533447265625 70.61811065673828125 66.40460968017578125 71.7963714599609375
+ 137.1536712646484375 133.212738037109375 123.55434417724609375 127.3555145263671875 135.690216064453125 134.500396728515625 139.686065673828125 139.5676727294921875 135.5297393798828125 137.4039154052734375 133.98077392578125 129.639923095703125 135.9020233154296875 142.41314697265625 140.13629150390625 145.68280029296875 152.6353607177734375 151.122711181640625 149.74102783203125 150.376861572265625 150.0189361572265625 150.74066162109375 149.5147247314453125 147.158843994140625 145.6341705322265625 145.139556884765625 150.2473297119140625 148.2984161376953125 144.287506103515625 142.951812744140625 142.2455902099609375 142.471099853515625 137.0411376953125 134.699249267578125 135.5396728515625 139.1498565673828125 134.2724456787109375 130.8573760986328125 128.794769287109375 125.3258819580078125 120.47513580322265625 124.43096160888671875 128.481903076171875 126.20967864990234375 125.58504486083984375 118.06856536865234375 109.29679107666015625 104.55095672607421875 104.557838439
 94140625 107.942047119140625 116.81197357177734375 122.9178466796875 121.59848785400390625 122.44976806640625 123.02445220947265625 115.91062164306640625 115.2583160400390625 121.55666351318359375 121.6553192138671875 111.0186767578125 110.88784027099609375 121.29457855224609375 114.96680450439453125 117.42914581298828125 120.90219879150390625 116.56461334228515625 103.998870849609375 96.07788848876953125 99.6113739013671875 100.54428863525390625 93.60820770263671875 90.42296600341796875 88.95943450927734375 87.82778167724609375 100.1689453125 94.1895751953125 100.6478424072265625 109.29448699951171875 100.1297607421875 91.1947021484375 84.06915283203125 84.2472686767578125 82.15381622314453125 81.95947265625 81.75337982177734375 81.283782958984375 81.3552398681640625 80.59886932373046875 87.0050811767578125 82.8074951171875 89.97077178955078125 98.625701904296875 90.40010833740234375 91.8418731689453125 95.6291046142578125 101.98081207275390625 106.52288818359375 98.875625610351562
 5 93.252777099609375 91.38141632080078125 93.971221923828125 93.319000244140625 89.63214874267578125 87.81600189208984375 92.48534393310546875 95.44376373291015625 101.1092529296875 106.4019012451171875 104.8718109130859375 100.79769134521484375 100.32753753662109375 99.40361785888671875 100.55155181884765625 96.37316131591796875 92.2849273681640625 85.07292938232421875 76.86966705322265625 75.439483642578125 74.73844146728515625 72.90192413330078125 78.9641571044921875 83.00641632080078125 86.09195709228515625 82.42450714111328125 82.03582763671875 83.17230987548828125 84.6077423095703125 86.798492431640625 88.742218017578125 84.24626922607421875 80.6951141357421875 73.3666534423828125 76.34368133544921875 74.33383941650390625 72.67195892333984375 74.04254150390625 82.352508544921875 84.9193878173828125 87.3181915283203125 85.44712066650390625 81.67620086669921875 78.3333587646484375 75.03021240234375 71.27066802978515625 66.7289276123046875 69.7530975341796875 69.63805389404296875
  68.4830169677734375 63.981121063232421875 69.80097198486328125
+ 130.5011138916015625 130.0653533935546875 126.909881591796875 123.31378173828125 131.9155731201171875 131.5290069580078125 135.468902587890625 131.4384765625 129.501434326171875 137.4304962158203125 130.1631011962890625 129.7274932861328125 136.5179901123046875 136.31658935546875 140.6055908203125 148.0834197998046875 148.192108154296875 147.011444091796875 142.2003326416015625 148.3683624267578125 149.92022705078125 149.2904205322265625 150.7860260009765625 149.5284271240234375 147.926055908203125 148.15985107421875 149.489898681640625 149.6197967529296875 144.3294677734375 142.9581451416015625 141.982421875 140.8839569091796875 137.6663818359375 135.7745361328125 138.0507354736328125 140.99298095703125 138.5477447509765625 131.6421051025390625 124.24149322509765625 118.57928466796875 118.50018310546875 127.54590606689453125 133.8233184814453125 132.8351287841796875 123.430816650390625 116.9590606689453125 103.96136474609375 104.37300872802734375 104.7819671630859375 105.064674377
 44140625 114.86296844482421875 119.23822784423828125 114.92169952392578125 120.45923614501953125 120.5494384765625 111.1964111328125 115.9915313720703125 120.77988433837890625 117.56821441650390625 112.74857330322265625 108.36968994140625 119.68416595458984375 114.34363555908203125 110.93857574462890625 118.6086578369140625 119.371185302734375 108.88719940185546875 94.029998779296875 92.615203857421875 92.2144927978515625 88.6862335205078125 89.2278289794921875 89.813690185546875 88.07147979736328125 99.010589599609375 105.00040435791015625 100.63558197021484375 110.7874298095703125 106.379425048828125 96.30332183837890625 87.69435882568359375 83.92377471923828125 82.1020355224609375 82.2788848876953125 82.45526123046875 81.8521881103515625 82.97560882568359375 90.61226654052734375 80.19840240478515625 80.92110443115234375 88.90032196044921875 92.3099365234375 86.569122314453125 91.4644622802734375 93.263336181640625 95.77710723876953125 96.29921722412109375 94.27320098876953125 87.
 8691253662109375 89.80271148681640625 91.72403717041015625 90.73917388916015625 87.3205413818359375 86.76058197021484375 92.57904052734375 93.710418701171875 96.9929351806640625 98.4324493408203125 101.30507659912109375 97.8958282470703125 97.3148651123046875 98.6123504638671875 96.2531280517578125 97.49723052978515625 93.00909423828125 91.291229248046875 83.25618743896484375 82.74883270263671875 74.2321929931640625 71.98029327392578125 75.82492828369140625 79.06465911865234375 81.709808349609375 80.30089569091796875 81.35778045654296875 80.57547760009765625 80.94097900390625 82.15503692626953125 87.2536468505859375 86.8167877197265625 83.680572509765625 77.20362091064453125 81.43410491943359375 76.56235504150390625 71.5882110595703125 74.749847412109375 80.77016448974609375 85.39678955078125 85.80698394775390625 84.865142822265625 78.20384979248046875 72.21553802490234375 69.9775543212890625 66.3137664794921875 67.759429931640625 68.5811920166015625 67.292144775390625 63.5179595947
 265625 63.76251983642578125 67.021331787109375
+ 140.2483673095703125 137.23431396484375 127.99819183349609375 121.887542724609375 128.9037628173828125 133.1471710205078125 130.6681365966796875 128.7241973876953125 129.2733612060546875 133.8663787841796875 130.212432861328125 128.885528564453125 131.992401123046875 132.455780029296875 140.9739990234375 143.2407379150390625 141.655731201171875 139.8488922119140625 146.040130615234375 150.3853759765625 149.4295806884765625 146.353240966796875 147.79345703125 150.6153411865234375 151.9878387451171875 149.5449371337890625 149.4158172607421875 148.33551025390625 145.745941162109375 146.4856719970703125 144.538848876953125 133.2946319580078125 131.0279998779296875 131.2573089599609375 131.1287841796875 140.241058349609375 140.661651611328125 125.0937347412109375 128.75390625 124.71428680419921875 121.084228515625 129.4734039306640625 134.8873748779296875 137.5120391845703125 125.43321990966796875 119.2546234130859375 106.946685791015625 104.0310211181640625 104.91266632080078125 104.90
 48309326171875 105.71685028076171875 112.86801910400390625 113.78591156005859375 119.1561126708984375 114.61916351318359375 106.5029449462890625 116.61701202392578125 115.87017822265625 111.19829559326171875 107.6179656982421875 102.6349029541015625 111.19342803955078125 102.21442413330078125 103.89389801025390625 106.5663604736328125 109.66542816162109375 110.2033538818359375 94.3280792236328125 91.92281341552734375 89.57337188720703125 88.63600921630859375 90.13507843017578125 102.48487091064453125 107.485992431640625 101.7075042724609375 103.7922821044921875 113.4029998779296875 112.70444488525390625 104.3491668701171875 98.56179046630859375 90.67095184326171875 84.5671234130859375 83.779571533203125 82.67627716064453125 82.3025970458984375 81.652801513671875 94.53696441650390625 94.92718505859375 80.20894622802734375 78.4471588134765625 82.907928466796875 79.5186004638671875 79.9985198974609375 82.125823974609375 80.03841400146484375 87.72791290283203125 81.73505401611328125 81.
 05724334716796875 88.7746734619140625 95.20351409912109375 89.47934722900390625 88.4425506591796875 86.733154296875 86.283966064453125 88.67812347412109375 89.53507232666015625 91.618408203125 95.97507476806640625 97.868621826171875 96.8460693359375 91.45909881591796875 93.8325958251953125 94.3075714111328125 97.08953094482421875 91.63278961181640625 91.285491943359375 85.49541473388671875 85.90869140625 74.76641082763671875 71.43225860595703125 72.7368927001953125 75.330810546875 77.11573028564453125 79.820892333984375 81.11278533935546875 78.60543060302734375 80.00067901611328125 80.87487030029296875 84.349853515625 86.10445404052734375 83.3458404541015625 84.77863311767578125 83.7625274658203125 78.67162322998046875 70.11165618896484375 74.1831512451171875 79.19173431396484375 85.19293975830078125 80.91497802734375 80.82416534423828125 77.39116668701171875 68.200042724609375 64.30640411376953125 64.611572265625 68.01883697509765625 64.99422454833984375 64.09282684326171875 64.147
 95684814453125 62.929141998291015625 63.14569091796875
+ 144.082550048828125 134.3506317138671875 133.3423919677734375 120.74398040771484375 124.84462738037109375 127.15887451171875 125.0593719482421875 128.1636962890625 134.0034332275390625 134.73004150390625 128.854217529296875 126.92111968994140625 133.5211029052734375 137.32135009765625 137.290435791015625 136.0577239990234375 137.06439208984375 138.5523223876953125 146.3978729248046875 147.7234039306640625 146.7308349609375 145.066192626953125 143.1044921875 148.0672607421875 149.5284423828125 151.9681854248046875 152.002960205078125 148.5016021728515625 147.367095947265625 135.9524078369140625 137.0122833251953125 135.520843505859375 132.9734344482421875 128.3255462646484375 132.3256683349609375 129.952545166015625 140.6343231201171875 136.8907623291015625 134.3997802734375 129.4257049560546875 124.245941162109375 131.8074188232421875 137.5970458984375 134.1038970947265625 131.4008026123046875 126.4442291259765625 117.01717376708984375 103.91062164306640625 103.8121795654296875 103
 .726348876953125 103.6477813720703125 104.67841339111328125 108.41797637939453125 110.587310791015625 110.1953887939453125 105.037261962890625 112.3120574951171875 110.56359100341796875 102.504486083984375 102.444061279296875 102.35140228271484375 102.2625579833984375 102.23552703857421875 102.91278076171875 99.3824005126953125 100.82558441162109375 99.85839080810546875 94.739013671875 91.70522308349609375 90.40069580078125 90.79653167724609375 102.34641265869140625 110.61704254150390625 116.50489044189453125 110.31346893310546875 102.57979583740234375 113.3179779052734375 108.80319976806640625 104.40656280517578125 97.17530059814453125 92.1478118896484375 93.96106719970703125 83.81130218505859375 98.27246856689453125 82.22513580322265625 93.68094635009765625 91.7964935302734375 86.08362579345703125 81.90478515625 78.83795928955078125 79.41985321044921875 78.9853668212890625 78.84235382080078125 80.7317352294921875 78.07480621337890625 78.780609130859375 82.610382080078125 78.716178
 89404296875 89.77715301513671875 92.4888153076171875 89.21065521240234375 86.46883392333984375 85.319091796875 83.9248809814453125 86.07088470458984375 88.7670745849609375 87.629119873046875 92.20822906494140625 93.2147369384765625 92.15001678466796875 88.27098846435546875 89.48165130615234375 92.03902435302734375 94.23801422119140625 91.5355377197265625 86.513031005859375 83.6242523193359375 78.7845001220703125 73.65875244140625 70.75289154052734375 71.93515777587890625 75.57262420654296875 77.613677978515625 80.2729339599609375 79.68831634521484375 76.9275360107421875 77.2360076904296875 79.7876739501953125 80.3989105224609375 82.307586669921875 82.6246795654296875 83.4958953857421875 80.601593017578125 71.6270599365234375 69.37697601318359375 73.46399688720703125 79.4500732421875 78.64238739013671875 77.93936920166015625 79.26837158203125 73.85849761962890625 64.2608489990234375 63.906620025634765625 64.1739654541015625 66.396942138671875 63.849971771240234375 63.9645614624023437
 5 63.16577911376953125 62.9701690673828125 63.130710601806640625
+ 144.6318206787109375 141.5373687744140625 133.313720703125 128.937164306640625 120.0092010498046875 124.19998931884765625 127.0645751953125 130.805877685546875 131.104217529296875 133.6890106201171875 127.40734100341796875 127.30142974853515625 134.7174530029296875 134.735198974609375 129.977203369140625 130.8543853759765625 132.434478759765625 142.313323974609375 145.3399200439453125 138.56951904296875 144.9349212646484375 148.1447296142578125 140.624481201171875 142.1993560791015625 147.6736602783203125 148.1738739013671875 144.96624755859375 146.9730377197265625 142.0664215087890625 139.7693023681640625 138.8508758544921875 138.496429443359375 136.847930908203125 136.2711334228515625 136.0146026611328125 134.751861572265625 140.923614501953125 138.47784423828125 136.5911407470703125 130.545074462890625 127.69759368896484375 134.14434814453125 138.208404541015625 130.2210845947265625 124.46326446533203125 118.8459930419921875 110.09218597412109375 110.04093170166015625 103.762840
 27099609375 103.66332244873046875 103.5634765625 103.45025634765625 105.1763458251953125 103.209747314453125 103.08425140380859375 102.96738433837890625 104.23038482666015625 102.6601104736328125 102.59108734130859375 102.519744873046875 102.32987213134765625 102.19873809814453125 102.18927764892578125 94.548614501953125 93.573944091796875 94.56113433837890625 95.34763336181640625 93.5087127685546875 91.3650970458984375 90.73404693603515625 96.607635498046875 104.93206787109375 106.2367095947265625 108.698974609375 115.56451416015625 105.48394775390625 114.8111724853515625 104.44004058837890625 102.2495574951171875 99.15737152099609375 104.0494232177734375 98.97115325927734375 106.457489013671875 104.4584197998046875 95.90708160400390625 95.74582672119140625 85.8378448486328125 87.59101104736328125 81.56644439697265625 79.7436370849609375 79.15546417236328125 78.9676666259765625 78.335845947265625 76.9313201904296875 78.079681396484375 78.09659576416015625 77.46236419677734375 81.98
 250579833984375 85.2266082763671875 90.0021209716796875 85.24853515625 84.37187957763671875 81.06939697265625 82.30307769775390625 84.77056121826171875 84.10831451416015625 82.7160491943359375 84.90445709228515625 85.4398040771484375 85.441497802734375 83.78314971923828125 89.94892120361328125 92.43735504150390625 91.54863739013671875 94.5922088623046875 92.801605224609375 88.69864654541015625 80.82016754150390625 77.2691497802734375 70.259307861328125 69.9718780517578125 72.88964080810546875 75.764373779296875 79.4603271484375 79.5970306396484375 79.22254180908203125 76.96006011962890625 79.7454681396484375 76.7353057861328125 77.98967742919921875 79.83464813232421875 79.059661865234375 77.72637939453125 70.7657012939453125 69.6269378662109375 72.84127044677734375 76.03147125244140625 75.62218475341796875 75.77689361572265625 76.46695709228515625 68.4582061767578125 64.217803955078125 64.18245697021484375 63.87313079833984375 65.66173553466796875 67.45064544677734375 67.94110107421
 875 63.323421478271484375 62.855289459228515625 63.32988739013671875
+ 144.4709930419921875 139.9132843017578125 131.9453582763671875 128.9992828369140625 119.9594268798828125 120.0596160888671875 127.317535400390625 126.29537200927734375 130.7899627685546875 133.5662384033203125 125.86753082275390625 126.72613525390625 130.182769775390625 127.2545928955078125 130.894012451171875 135.8419342041015625 141.1100006103515625 141.87554931640625 142.4949188232421875 137.8859405517578125 143.3615264892578125 143.2767181396484375 137.8639373779296875 137.9552154541015625 141.014068603515625 141.9144287109375 146.86956787109375 150.0224761962890625 145.928741455078125 142.9980010986328125 141.1806182861328125 139.0941925048828125 138.34222412109375 138.22259521484375 137.0944671630859375 136.834197998046875 132.8016204833984375 138.5180816650390625 136.1832427978515625 131.626617431640625 129.7599029541015625 135.542572021484375 134.3915863037109375 127.97841644287109375 120.47887420654296875 124.689605712890625 120.29232025146484375 120.90041351318359375 107.
 6555023193359375 103.86994171142578125 103.53922271728515625 103.40779876708984375 103.11932373046875 103.206298828125 103.08698272705078125 102.9836578369140625 102.8723602294921875 102.7508392333984375 102.65790557861328125 110.8454132080078125 115.19725799560546875 102.07489776611328125 106.83654022216796875 101.4923095703125 97.114105224609375 95.7874603271484375 91.71646881103515625 91.83685302734375 91.06097412109375 91.44384002685546875 96.840118408203125 106.0550537109375 111.95455169677734375 119.44034576416015625 117.2920989990234375 113.77062225341796875 116.65836334228515625 109.98276519775390625 110.39327239990234375 108.45208740234375 105.33466339111328125 101.440582275390625 109.2042083740234375 99.550506591796875 94.81156158447265625 90.075103759765625 86.14072418212890625 97.73609161376953125 91.6160736083984375 82.37706756591796875 80.63272857666015625 78.7735595703125 80.9316558837890625 80.41211700439453125 79.00396728515625 77.64501953125 77.08365631103515625 76
 .86830902099609375 79.5694122314453125 84.6940765380859375 83.02722930908203125 80.164886474609375 79.589019775390625 78.389617919921875 83.8310394287109375 81.37127685546875 78.39163970947265625 77.817840576171875 79.39373779296875 79.7673492431640625 85.56566619873046875 92.1899261474609375 91.7733917236328125 90.7840576171875 92.28960418701171875 89.892120361328125 89.72338104248046875 87.24344635009765625 79.309600830078125 69.7452850341796875 69.359405517578125 70.51879119873046875 74.4246826171875 78.541748046875 78.49988555908203125 74.34548187255859375 75.95053863525390625 77.3635101318359375 75.57159423828125 74.36370849609375 76.66500091552734375 73.62884521484375 71.21875762939453125 69.4553375244140625 69.04392242431640625 70.82982635498046875 70.68231201171875 72.79946136474609375 71.52630615234375 72.49730682373046875 68.30652618408203125 64.66150665283203125 66.66290283203125 66.80246734619140625 67.335693359375 69.36864471435546875 68.40976715087890625 66.48326873779
 296875 66.03728485107421875 65.9909515380859375
+ 143.6918182373046875 142.6682586669921875 139.3832855224609375 137.6778717041015625 129.275665283203125 118.54053497314453125 121.88451385498046875 126.016082763671875 132.005462646484375 129.0300445556640625 121.8312225341796875 123.7677154541015625 124.5759124755859375 129.0514678955078125 136.5513458251953125 141.909515380859375 144.0971527099609375 138.5260162353515625 137.6914215087890625 134.2551727294921875 140.365570068359375 135.1271514892578125 136.9583587646484375 138.2694244384765625 139.212860107421875 141.2931671142578125 144.8264923095703125 150.24017333984375 146.3537139892578125 143.085113525390625 142.061279296875 141.2089996337890625 139.4156036376953125 138.4505462646484375 138.643218994140625 139.001678466796875 140.02349853515625 138.924163818359375 139.5906829833984375 132.684478759765625 130.9718017578125 137.289459228515625 134.007659912109375 126.85961151123046875 130.9407501220703125 132.0441741943359375 125.981353759765625 119.43280792236328125 105.67108
 154296875 114.1239776611328125 118.4676361083984375 103.36353302001953125 117.51685333251953125 103.3975067138671875 103.05799102783203125 102.984283447265625 102.89373016357421875 102.750152587890625 102.6470794677734375 112.6043243408203125 114.83193206787109375 102.37744903564453125 113.186309814453125 109.01085662841796875 101.53438568115234375 101.4239044189453125 97.811553955078125 92.90750885009765625 92.20986175537109375 94.585540771484375 97.79238128662109375 106.64391326904296875 112.7656402587890625 119.21038818359375 123.501434326171875 120.95771026611328125 117.23159027099609375 112.798828125 113.3313751220703125 111.46012115478515625 109.646728515625 107.51114654541015625 110.35686492919921875 106.2349395751953125 97.98052978515625 86.0165557861328125 90.63198089599609375 102.63629150390625 97.809112548828125 81.0826568603515625 78.80216217041015625 79.03565216064453125 79.70751190185546875 78.765411376953125 84.851898193359375 76.72491455078125 76.84185028076171875 75
 .9875335693359375 76.62326812744140625 76.6153106689453125 77.68961334228515625 77.83975982666015625 77.89942169189453125 77.3825836181640625 75.62807464599609375 74.3377227783203125 74.35742950439453125 74.88311767578125 75.75994873046875 76.96840667724609375 78.08646392822265625 86.55704498291015625 89.50482940673828125 89.009918212890625 89.07598114013671875 84.18325042724609375 85.99394989013671875 87.07830810546875 86.3176422119140625 79.22205352783203125 69.2074432373046875 70.22438812255859375 72.752410888671875 76.60135650634765625 76.915679931640625 74.9540557861328125 83.44786834716796875 75.86826324462890625 72.285247802734375 71.209869384765625 73.5570526123046875 71.3325653076171875 66.5116119384765625 66.40509796142578125 67.3014678955078125 66.80152130126953125 65.21697998046875 67.28957366943359375 70.9705963134765625 68.6618499755859375 69.69113922119140625 64.33025360107421875 66.10791015625 67.632293701171875 68.63436126708984375 73.63965606689453125 77.4608230590
 8203125 68.48187255859375 66.1977386474609375 65.93347930908203125
+ 139.9224395751953125 137.5917205810546875 135.912841796875 134.0670928955078125 130.51580810546875 117.67121124267578125 120.51700592041015625 125.71007537841796875 130.5230865478515625 128.42547607421875 120.1285858154296875 127.75780487060546875 131.548004150390625 133.8554840087890625 136.8188629150390625 141.486602783203125 142.48724365234375 139.3353424072265625 131.3099517822265625 134.4240875244140625 132.6273651123046875 134.3537750244140625 134.9155426025390625 143.546630859375 149.0580902099609375 149.881866455078125 150.3597564697265625 151.81207275390625 148.9564971923828125 146.0776214599609375 143.815673828125 141.785308837890625 141.0613250732421875 140.7566070556640625 140.770843505859375 140.970184326171875 141.403564453125 142.3759307861328125 136.9274444580078125 136.894439697265625 134.1121826171875 139.153594970703125 134.8871002197265625 132.8471832275390625 135.836212158203125 132.69537353515625 125.58832550048828125 112.18326568603515625 117.460845947265625
 123.5934295654296875 119.4428253173828125 109.98563385009765625 119.15558624267578125 110.53717803955078125 103.05413818359375 102.98389434814453125 102.93221282958984375 102.8498077392578125 107.0135955810546875 120.528533935546875 109.57338714599609375 112.82079315185546875 114.84859466552734375 112.32541656494140625 107.89441680908203125 109.10741424560546875 96.8492431640625 99.896453857421875 96.65692901611328125 100.0353546142578125 107.7105255126953125 105.446319580078125 106.88898468017578125 113.3467254638671875 119.99982452392578125 122.39078521728515625 120.7165985107421875 117.8912353515625 111.71157073974609375 110.02178955078125 105.1950531005859375 109.5887603759765625 110.29122161865234375 103.06048583984375 97.37055206298828125 86.81104278564453125 94.27664947509765625 101.77684783935546875 100.4111480712890625 96.21405792236328125 81.0666656494140625 82.98249053955078125 88.92528533935546875 89.8609466552734375 90.4089202880859375 78.190399169921875 76.600242614746
 09375 76.16020965576171875 75.9138946533203125 75.807830810546875 77.89006805419921875 76.6899566650390625 76.79177093505859375 77.11389923095703125 74.57306671142578125 73.71292877197265625 74.46966552734375 74.19330596923828125 74.3248748779296875 74.4114990234375 75.38934326171875 85.43450164794921875 88.44905853271484375 87.126068115234375 86.1599273681640625 79.64871978759765625 82.755126953125 81.2811126708984375 84.60198211669921875 82.85231781005859375 80.065826416015625 70.81159210205078125 72.94496917724609375 76.38877105712890625 74.61779022216796875 73.23724365234375 81.89051055908203125 73.4813079833984375 71.24523162841796875 68.5285491943359375 67.9242401123046875 67.24178314208984375 66.4150238037109375 65.86820220947265625 66.39437103271484375 66.14476776123046875 65.156982421875 65.75510406494140625 67.1348419189453125 65.13393402099609375 68.5970001220703125 64.0344696044921875 65.350067138671875 66.9915618896484375 74.9521636962890625 77.593292236328125 76.657386
 77978515625 73.1277923583984375 69.68535614013671875 67.143035888671875
+ 133.6662750244140625 130.970947265625 128.0332489013671875 125.45342254638671875 127.69402313232421875 118.0000762939453125 116.5520477294921875 122.93448638916015625 128.8055267333984375 128.202850341796875 118.89884185791015625 128.844970703125 134.6186065673828125 136.858489990234375 136.8803253173828125 138.2613983154296875 139.485687255859375 136.7071990966796875 132.818511962890625 129.83489990234375 131.222808837890625 132.021636962890625 139.875732421875 142.9745025634765625 145.5772705078125 148.0979766845703125 143.680450439453125 150.1683502197265625 149.82049560546875 149.1415557861328125 146.0268402099609375 143.9169769287109375 142.8061065673828125 140.6341400146484375 142.1400299072265625 141.9723358154296875 141.965118408203125 145.693206787109375 142.736358642578125 135.748199462890625 133.687713623046875 138.8695068359375 139.25732421875 134.949554443359375 130.2388763427734375 124.49019622802734375 120.56215667724609375 111.78237152099609375 122.22437286376953125
  122.5190277099609375 108.56937408447265625 115.94728851318359375 123.8405609130859375 118.33245086669921875 113.9845733642578125 102.84108734130859375 102.93221282958984375 102.93865966796875 108.80983734130859375 124.30835723876953125 111.71954345703125 117.54419708251953125 123.2872467041015625 120.829803466796875 118.38433074951171875 110.96923065185546875 97.0226593017578125 106.75136566162109375 98.468048095703125 100.10271453857421875 110.02008056640625 117.0790863037109375 119.560089111328125 119.1059112548828125 119.80500030517578125 124.1161956787109375 119.94785308837890625 116.0874176025390625 113.46385955810546875 111.49251556396484375 106.25433349609375 103.477752685546875 107.8620452880859375 99.98900604248046875 94.75649261474609375 87.68062591552734375 94.9334564208984375 103.6326751708984375 107.51959228515625 103.32568359375 86.27201080322265625 90.346649169921875 99.18448638916015625 97.10962677001953125 88.55401611328125 81.1007843017578125 78.132904052734375 83
 .49674224853515625 84.7092742919921875 83.63323211669921875 74.7749481201171875 74.9603424072265625 75.26769256591796875 75.1597900390625 74.47800445556640625 85.82080078125 82.0073394775390625 74.029571533203125 73.62042236328125 73.0095062255859375 81.70484161376953125 86.30106353759765625 86.287567138671875 85.331329345703125 84.580108642578125 78.88651275634765625 80.35512542724609375 75.24628448486328125 79.9622802734375 80.18004608154296875 80.18543243408203125 71.15058135986328125 71.31011199951171875 74.6146697998046875 74.95049285888671875 70.488067626953125 72.22661590576171875 67.17034149169921875 66.95767974853515625 67.87762451171875 66.77721405029296875 66.41623687744140625 66.37490081787109375 65.95440673828125 65.98486328125 65.9688873291015625 65.6919403076171875 65.4444580078125 65.38315582275390625 65.41619873046875 66.52848052978515625 64.74497222900390625 76.253753662109375 77.2688751220703125 72.647125244140625 75.73000335693359375 78.05197906494140625 73.44055
 938720703125 71.44770050048828125 70.443389892578125
+ 140.4013214111328125 135.8564300537109375 133.842742919921875 130.0566253662109375 121.77561187744140625 116.36871337890625 117.77923583984375 123.8314666748046875 129.8030853271484375 129.6723175048828125 117.98908233642578125 123.5682830810546875 131.4443359375 134.910247802734375 133.20196533203125 134.3142242431640625 133.6341552734375 129.8984527587890625 128.9085540771484375 123.77742767333984375 128.04180908203125 132.019866943359375 138.3221435546875 145.3799591064453125 148.4738616943359375 143.8447418212890625 140.8812408447265625 145.9473724365234375 146.9212188720703125 147.349609375 145.8780059814453125 143.5431060791015625 142.6146240234375 142.6635284423828125 142.6355133056640625 142.4971923828125 143.0121002197265625 145.6489105224609375 145.600128173828125 142.5212249755859375 140.433990478515625 134.2941131591796875 132.023651123046875 130.9864959716796875 130.103546142578125 129.37249755859375 126.8217926025390625 118.86766815185546875 130.1485595703125 118.4164
 8101806640625 120.8327178955078125 120.46450042724609375 128.266754150390625 123.3427276611328125 118.8134918212890625 112.70879364013671875 102.93221282958984375 111.90442657470703125 119.19086456298828125 124.295440673828125 115.77417755126953125 116.8093414306640625 125.83708953857421875 120.7064666748046875 114.9553680419921875 105.210235595703125 103.0919342041015625 111.74192047119140625 99.30811309814453125 103.65283966064453125 105.18193817138671875 108.0851593017578125 116.91178131103515625 123.06966400146484375 124.9131317138671875 121.847900390625 115.777984619140625 113.09922027587890625 108.06050872802734375 104.10678863525390625 99.9825439453125 97.7142791748046875 100.04296112060546875 101.590972900390625 92.1615142822265625 92.87140655517578125 102.639068603515625 102.96131134033203125 109.74141693115234375 103.35516357421875 96.19680023193359375 99.72472381591796875 100.7196807861328125 93.639739990234375 82.824005126953125 86.93625640869140625 84.87686920166015625
 83.58791351318359375 81.97879791259765625 80.98255157470703125 80.4141845703125 78.70311737060546875 75.265106201171875 75.008514404296875 74.85472869873046875 83.72130584716796875 84.20362091064453125 73.5666046142578125 73.7593536376953125 73.194091796875 82.37514495849609375 84.062408447265625 84.59534454345703125 84.05496978759765625 86.75136566162109375 77.111724853515625 75.02422332763671875 71.32634735107421875 78.15357208251953125 77.48157501220703125 72.767669677734375 71.85987091064453125 69.089630126953125 74.2175750732421875 73.52703857421875 72.98738861083984375 72.917999267578125 67.2051239013671875 67.2488555908203125 68.4557037353515625 67.37543487548828125 66.6417236328125 66.45745849609375 66.71920013427734375 66.1508636474609375 66.207763671875 67.97756195068359375 65.005462646484375 65.03459930419921875 65.1414031982421875 65.02800750732421875 68.52101898193359375 75.9598388671875 74.32543182373046875 73.17998504638671875 71.914398193359375 80.39070892333984375 7
 3.29451751708984375 72.15190887451171875 70.33545684814453125
+ 140.5352325439453125 136.130828857421875 133.3301544189453125 130.5733184814453125 127.99831390380859375 122.3558349609375 115.61562347412109375 120.56719970703125 128.3167266845703125 129.1197052001953125 117.270416259765625 120.37105560302734375 126.2329864501953125 129.7483367919921875 132.4878997802734375 131.1613922119140625 126.762969970703125 126.47026824951171875 121.51456451416015625 125.632659912109375 132.6495208740234375 138.498291015625 143.143890380859375 148.127197265625 148.4568634033203125 142.323577880859375 137.893585205078125 143.517333984375 146.2839202880859375 146.5470123291015625 144.090087890625 142.876068115234375 142.88311767578125 145.7962188720703125 150.6988983154296875 140.1304931640625 145.393218994140625 145.73443603515625 141.172821044921875 141.536285400390625 143.9519195556640625 137.071258544921875 129.315582275390625 132.7686767578125 129.457061767578125 120.7757568359375 118.9596405029296875 127.926177978515625 125.89110565185546875 124.819206
 23779296875 124.63036346435546875 128.629058837890625 127.53122711181640625 117.7996673583984375 108.8812408447265625 113.45269775390625 102.8066253662109375 118.31925201416015625 121.96688079833984375 120.4838714599609375 122.53553009033203125 127.676361083984375 125.793701171875 125.59632110595703125 115.28928375244140625 107.22258758544921875 110.35100555419921875 113.8128662109375 104.2755584716796875 107.3144683837890625 111.8322296142578125 121.29400634765625 118.53591156005859375 120.242156982421875 127.53577423095703125 123.82654571533203125 119.008270263671875 114.93601226806640625 110.15090179443359375 108.1790924072265625 101.87657928466796875 100.42901611328125 98.49506378173828125 92.885406494140625 89.319549560546875 99.3323211669921875 105.21652984619140625 110.32518768310546875 110.08577728271484375 104.2266387939453125 102.65419769287109375 94.21947479248046875 90.75589752197265625 89.34087371826171875 87.3963470458984375 87.5193328857421875 87.31708526611328125 88.
 40545654296875 92.94316864013671875 86.9895172119140625 81.6069183349609375 77.6436767578125 77.44605255126953125 78.15946197509765625 78.30368804931640625 86.577880859375 81.77465057373046875 73.1107940673828125 73.00914764404296875 73.4517059326171875 76.4270477294921875 80.5836944580078125 77.63567352294921875 81.9396209716796875 81.4286346435546875 77.317352294921875 74.937255859375 70.3160247802734375 73.78549957275390625 74.8469390869140625 71.88291168212890625 73.7549896240234375 68.6512603759765625 68.27121734619140625 71.689697265625 79.733978271484375 66.69882965087890625 67.0350799560546875 68.576995849609375 68.613006591796875 68.0797882080078125 67.06678009033203125 66.95501708984375 69.0281829833984375 69.44055938720703125 71.36513519287109375 65.56354522705078125 65.34163665771484375 65.1249237060546875 65.056243896484375 70.7720184326171875 74.29819488525390625 81.617401123046875 79.7370758056640625 76.11826324462890625 77.06880950927734375 80.4528656005859375 82.053
 1005859375 77.041778564453125 73.69690704345703125
+ 138.4471435546875 135.8393402099609375 125.9966888427734375 124.12638092041015625 118.75670623779296875 115.34813690185546875 114.52130126953125 120.15252685546875 122.14081573486328125 129.748199462890625 116.76006317138671875 119.46343231201171875 126.98638916015625 132.5956878662109375 131.18658447265625 125.1077880859375 123.65149688720703125 120.9191436767578125 122.873687744140625 132.1357574462890625 131.1900634765625 136.3782196044921875 143.286102294921875 146.1417083740234375 142.536468505859375 138.9726409912109375 138.820037841796875 139.8635406494140625 141.65228271484375 142.9418792724609375 142.412994384765625 142.144134521484375 142.716583251953125 142.656890869140625 139.5814666748046875 138.1422271728515625 142.5973052978515625 139.6352996826171875 140.3904876708984375 142.642913818359375 145.4857635498046875 139.8343658447265625 130.6965789794921875 123.8123779296875 121.02652740478515625 128.04595947265625 122.75327301025390625 135.463409423828125 129.8057250976
 5625 120.005828857421875 133.13177490234375 122.579254150390625 122.12044525146484375 120.03078460693359375 122.7317352294921875 119.1885833740234375 105.1508331298828125 125.30454254150390625 130.35113525390625 124.9161376953125 130.61163330078125 133.1998443603515625 130.85760498046875 125.36963653564453125 116.91513824462890625 104.7568206787109375 113.990142822265625 119.397613525390625 105.165618896484375 111.48418426513671875 118.66351318359375 122.766357421875 125.12693023681640625 125.8534393310546875 126.86008453369140625 124.08699798583984375 117.905059814453125 112.31537628173828125 108.21895599365234375 108.1586151123046875 107.37390899658203125 110.920928955078125 104.93903350830078125 98.3801116943359375 90.60253143310546875 99.556610107421875 107.11634063720703125 101.8361663818359375 97.00848388671875 95.6624755859375 94.18306732177734375 102.59848785400390625 98.63433837890625 91.20355224609375 94.8224334716796875 98.93085479736328125 96.1956024169921875 87.26268005
 37109375 95.12812042236328125 84.60717010498046875 80.83657073974609375 79.51198577880859375 79.296783447265625 80.60066986083984375 85.15453338623046875 78.3278961181640625 77.093536376953125 73.29834747314453125 75.5988006591796875 75.5046844482421875 73.70250701904296875 76.4262847900390625 77.20777130126953125 79.1161651611328125 77.33966064453125 76.33026885986328125 74.10172271728515625 70.65088653564453125 82.33159637451171875 77.0386962890625 71.11092376708984375 73.6548614501953125 73.57207489013671875 67.448272705078125 78.81572723388671875 77.0687255859375 68.3444061279296875 77.48955535888671875 74.83144378662109375 69.1254425048828125 68.83937835693359375 68.1787261962890625 69.20490264892578125 69.8765869140625 73.73102569580078125 82.4551239013671875 82.26947784423828125 67.06494903564453125 65.91486358642578125 73.41666412353515625 71.69472503662109375 83.8690643310546875 85.04650115966796875 83.4522705078125 82.70914459228515625 82.214080810546875 80.071762084960937
 5 79.99367523193359375 75.16606903076171875 70.3374481201171875
+ 137.39288330078125 138.4335479736328125 132.7012786865234375 128.9994354248046875 128.0439453125 122.097808837890625 116.347808837890625 119.75392913818359375 127.42940521240234375 128.643951416015625 115.6584625244140625 117.66779327392578125 126.926116943359375 123.22479248046875 124.47388458251953125 120.3208160400390625 118.973236083984375 123.41641998291015625 128.69097900390625 127.612274169921875 138.50054931640625 137.3070526123046875 143.238494873046875 143.38385009765625 134.6116790771484375 132.947296142578125 137.122100830078125 139.481689453125 140.94073486328125 143.105712890625 142.3812103271484375 139.9177703857421875 139.3189849853515625 139.6624603271484375 138.0825653076171875 139.2457427978515625 141.083526611328125 139.173370361328125 139.218048095703125 143.9090118408203125 144.672637939453125 140.316070556640625 130.0824127197265625 131.1413116455078125 130.6450042724609375 132.110076904296875 125.7597198486328125 137.0660552978515625 130.696563720703125 122.
 7279205322265625 137.5375823974609375 136.646697998046875 128.7945098876953125 121.9178619384765625 123.4874114990234375 110.7248077392578125 113.76107025146484375 114.3537750244140625 122.30638885498046875 130.149658203125 131.125518798828125 132.77886962890625 123.60108184814453125 117.59717559814453125 111.95912933349609375 110.7686004638671875 117.1187286376953125 119.4844970703125 104.08292388916015625 110.00682830810546875 118.96134185791015625 126.94321441650390625 129.7412567138671875 124.0919647216796875 120.994293212890625 119.094451904296875 119.25017547607421875 117.84099578857421875 116.56824493408203125 113.42795562744140625 112.63494110107421875 111.8077239990234375 105.839508056640625 97.81978607177734375 103.38014984130859375 102.016754150390625 100.54460906982421875 108.1075592041015625 114.46380615234375 115.92678070068359375 108.72164154052734375 107.08219146728515625 102.60744476318359375 91.72580718994140625 96.7649078369140625 102.68264007568359375 94.11273193
 359375 96.56673431396484375 91.59976959228515625 85.21138763427734375 85.8271636962890625 90.591033935546875 90.33411407470703125 89.89475250244140625 92.32470703125 91.46953582763671875 87.18955230712890625 76.87142181396484375 78.22565460205078125 73.39533233642578125 72.77243804931640625 72.83443450927734375 76.99947357177734375 76.36377716064453125 76.72542572021484375 74.668426513671875 71.6302490234375 70.40789794921875 79.92447662353515625 73.14882659912109375 71.81649017333984375 81.38251495361328125 81.04276275634765625 78.5971832275390625 72.96901702880859375 77.30767822265625 81.67272186279296875 76.6208648681640625 76.2290802001953125 71.07538604736328125 71.20249176025390625 69.1614532470703125 69.38269805908203125 71.3488922119140625 77.7674713134765625 83.01737213134765625 81.1295166015625 67.261322021484375 74.320098876953125 75.4357147216796875 86.63934326171875 76.7989959716796875 82.8818206787109375 86.10921478271484375 84.3756103515625 83.3316497802734375 81.9581
 451416015625 80.37139129638671875 75.80159759521484375 69.99419403076171875
+ 137.43621826171875 140.4673614501953125 138.7571868896484375 134.3459320068359375 128.8752288818359375 124.50154876708984375 112.9344024658203125 118.190032958984375 126.7027740478515625 126.63054656982421875 116.872314453125 118.8446044921875 122.25864410400390625 124.24495697021484375 119.9729156494140625 116.85398101806640625 126.8017120361328125 130.722625732421875 137.3390350341796875 137.9708251953125 138.9445343017578125 143.67266845703125 141.433929443359375 137.783416748046875 129.982879638671875 140.30963134765625 140.862640380859375 141.1456146240234375 142.238555908203125 144.4158935546875 144.1160430908203125 140.3431243896484375 138.574249267578125 137.4374847412109375 139.428863525390625 138.4129638671875 139.2497100830078125 138.2334136962890625 141.7524871826171875 143.1978302001953125 141.5374755859375 138.471923828125 136.362823486328125 137.7835693359375 135.7720947265625 136.763641357421875 135.2340850830078125 137.23883056640625 131.902984619140625 128.4715270
 99609375 138.3415985107421875 136.809295654296875 131.9954376220703125 126.03304290771484375 114.88283538818359375 124.53438568115234375 127.71962738037109375 125.66419219970703125 119.62184906005859375 131.458831787109375 136.801544189453125 133.5355224609375 128.6767578125 123.05815887451171875 118.7213287353515625 117.7543792724609375 117.3040771484375 118.50170135498046875 104.767974853515625 115.6611480712890625 121.3655853271484375 127.23361968994140625 126.0498504638671875 119.17478179931640625 115.29730987548828125 112.33831787109375 112.406768798828125 115.98236846923828125 117.62151336669921875 113.3589324951171875 109.69853973388671875 108.5356903076171875 105.6168975830078125 93.29681396484375 99.4739990234375 100.422149658203125 105.772979736328125 111.9467926025390625 118.32308197021484375 116.9253997802734375 108.342254638671875 101.957733154296875 99.96912384033203125 95.0073089599609375 96.73891448974609375 104.09587860107421875 100.73377227783203125 99.109245300292
 96875 97.90477752685546875 88.52154541015625 93.7783966064453125 92.19776153564453125 91.7379302978515625 89.7616424560546875 89.4443206787109375 89.4364166259765625 86.99958038330078125 78.86100006103515625 74.37870025634765625 79.57110595703125 79.4416046142578125 75.74346160888671875 76.1879730224609375 74.28496551513671875 72.48752593994140625 70.12944793701171875 71.167144775390625 79.5495452880859375 80.25566864013671875 74.0682373046875 72.58759307861328125 73.272918701171875 71.65312957763671875 76.28845977783203125 80.50255584716796875 70.3564300537109375 80.29816436767578125 81.8547515869140625 78.2660064697265625 73.8566436767578125 71.92635345458984375 70.108428955078125 70.83977508544921875 78.1645965576171875 86.16983795166015625 87.27809906005859375 80.81290435791015625 74.93563079833984375 69.1552276611328125 80.99851226806640625 89.9120941162109375 82.8736114501953125 88.65354156494140625 89.1832275390625 84.22887420654296875 83.9907684326171875 83.92223358154296875
  80.3648223876953125 72.828155517578125 68.94451904296875
+ 136.812591552734375 137.4344635009765625 134.427520751953125 135.8284912109375 130.587921142578125 124.47064208984375 112.06970977783203125 115.136077880859375 121.07228851318359375 124.63153076171875 119.4707183837890625 115.9036712646484375 118.8616180419921875 118.008941650390625 115.7239990234375 125.18087005615234375 127.0298309326171875 132.4425048828125 140.757293701171875 142.8883514404296875 144.047454833984375 143.4516448974609375 138.429779052734375 131.7594757080078125 130.1526031494140625 140.25958251953125 141.387847900390625 142.827423095703125 144.1349945068359375 145.9556884765625 144.636322021484375 141.4207611083984375 140.0140380859375 139.18505859375 138.9463653564453125 140.575164794921875 133.280059814453125 135.83087158203125 137.5972137451171875 140.524444580078125 142.989288330078125 141.347900390625 139.3405303955078125 135.3579864501953125 140.3862762451171875 140.3960418701171875 140.232757568359375 139.2681884765625 133.80401611328125 133.3305206298828
 125 141.51654052734375 135.32086181640625 128.8729095458984375 129.685302734375 125.74603271484375 119.8587799072265625 129.5751800537109375 128.13482666015625 124.66936492919921875 134.152069091796875 139.7557220458984375 140.521820068359375 136.515106201171875 128.1826171875 124.11431121826171875 120.85428619384765625 120.1949310302734375 116.93353271484375 117.9902496337890625 114.6023712158203125 123.58998870849609375 131.1674652099609375 128.5767364501953125 120.4471435546875 114.9428863525390625 112.186614990234375 116.182830810546875 114.73947906494140625 112.55029296875 109.9599609375 108.155029296875 104.37004852294921875 97.09914398193359375 99.59075164794921875 105.59622955322265625 108.52988433837890625 107.92771148681640625 117.26721954345703125 122.492828369140625 113.2352294921875 107.4925689697265625 111.9866790771484375 105.70665740966796875 95.99303436279296875 103.39028167724609375 106.59624481201171875 99.480316162109375 103.20980072021484375 97.1779937744140625
 94.08759307861328125 99.08425140380859375 98.560272216796875 91.3778533935546875 88.17848968505859375 87.6051025390625 80.0125732421875 78.510589599609375 76.89258575439453125 76.8060302734375 82.1827239990234375 72.263671875 82.90814208984375 82.39159393310546875 81.75431060791015625 81.375823974609375 81.63086700439453125 79.25916290283203125 71.66951751708984375 72.18495941162109375 74.2022705078125 73.323577880859375 72.574188232421875 72.47431182861328125 72.083709716796875 76.4169464111328125 77.56665802001953125 80.0778961181640625 86.49506378173828125 86.5569305419921875 85.42139434814453125 83.79288482666015625 82.009429931640625 79.69544219970703125 77.8634796142578125 77.160797119140625 76.65819549560546875 78.67905426025390625 76.37264251708984375 71.600982666015625 76.88417816162109375 84.6609649658203125 88.23255157470703125 90.60733795166015625 88.66790008544921875 83.9405975341796875 85.713470458984375 84.3121337890625 77.29180908203125 71.52678680419921875 68.350730
 89599609375
+ 135.6642913818359375 129.670257568359375 128.9738616943359375 132.56060791015625 130.6150054931640625 126.1596221923828125 112.389251708984375 112.88712310791015625 117.36688995361328125 122.12563323974609375 126.21517181396484375 111.93201446533203125 112.78978729248046875 115.8617706298828125 120.65843963623046875 128.0344696044921875 135.9444122314453125 135.2452850341796875 135.7529144287109375 139.076629638671875 144.42242431640625 143.2642364501953125 140.803070068359375 131.077545166015625 131.7223663330078125 140.0414886474609375 142.8104095458984375 144.2589111328125 145.32745361328125 146.1284942626953125 147.1759185791015625 144.6024322509765625 142.0302276611328125 140.16497802734375 139.8738555908203125 141.0781097412109375 140.12872314453125 136.7218780517578125 133.857574462890625 133.873291015625 137.31842041015625 139.7490692138671875 138.5696563720703125 136.9581756591796875 139.7462921142578125 140.3288421630859375 141.4688873291015625 142.1287078857421875 137.64
 8956298828125 129.95721435546875 139.688812255859375 139.426055908203125 135.9181365966796875 135.005279541015625 118.100830078125 131.5296173095703125 132.7588043212890625 124.73203277587890625 125.01345062255859375 132.03228759765625 133.5695037841796875 133.4647674560546875 133.8985443115234375 131.86871337890625 129.5069122314453125 128.0882110595703125 122.70679473876953125 124.65319061279296875 124.11168670654296875 125.114654541015625 125.35572052001953125 124.144500732421875 122.94781494140625 121.238311767578125 119.92658233642578125 120.4790191650390625 114.65618896484375 111.214630126953125 102.071685791015625 104.09497833251953125 102.648651123046875 98.47574615478515625 95.1729888916015625 107.75069427490234375 108.308746337890625 111.44422149658203125 109.70537567138671875 116.5191497802734375 122.157745361328125 114.7559051513671875 115.52494049072265625 109.23423004150390625 100.67003631591796875 106.59789276123046875 102.84668731689453125 108.2631988525390625 102.70
 989990234375 99.37686920166015625 98.706634521484375 101.01647186279296875 99.778289794921875 95.4688873291015625 92.0876922607421875 87.81142425537109375 88.25467681884765625 87.64227294921875 87.62355804443359375 84.9653778076171875 80.1401519775390625 76.51853179931640625 72.1786956787109375 71.47735595703125 75.35648345947265625 73.59636688232421875 72.28325653076171875 78.6325225830078125 72.89566802978515625 73.2250823974609375 72.12329864501953125 76.04384613037109375 77.8530120849609375 72.78787994384765625 72.84471893310546875 71.8955535888671875 71.27986907958984375 79.6673736572265625 82.8444976806640625 80.90528106689453125 81.4484405517578125 80.86761474609375 81.1175537109375 78.88454437255859375 74.14800262451171875 82.6078338623046875 86.58939361572265625 85.8782806396484375 84.77236175537109375 77.71511077880859375 76.629791259765625 79.1748199462890625 78.25342559814453125 84.100494384765625 88.93816375732421875 85.012603759765625 81.2759246826171875 80.50947570800
 78125 80.32854461669921875 74.98007965087890625 69.51502227783203125 77.13238525390625
+ 134.4747161865234375 132.398681640625 123.99745941162109375 122.6306915283203125 123.2240753173828125 124.5695037841796875 113.701202392578125 115.59673309326171875 117.47223663330078125 120.9713134765625 123.13848876953125 111.35974884033203125 114.644744873046875 121.5380401611328125 125.6194000244140625 131.8370361328125 132.693450927734375 127.5439605712890625 130.1828460693359375 133.712005615234375 140.9945831298828125 138.2637176513671875 137.8300933837890625 130.717071533203125 131.8316192626953125 139.53680419921875 142.723114013671875 142.743621826171875 145.217132568359375 145.6884765625 147.3109588623046875 144.7258453369140625 144.4932403564453125 146.1989288330078125 144.376434326171875 143.657684326171875 141.60906982421875 139.0611724853515625 134.5564117431640625 132.3931732177734375 132.67694091796875 134.2982177734375 135.0676116943359375 137.237823486328125 140.8851470947265625 142.8547515869140625 140.248016357421875 140.893402099609375 140.9986572265625 135.56
 46514892578125 138.4706268310546875 140.7576141357421875 138.7473907470703125 128.6588134765625 131.4534454345703125 140.4427490234375 134.8341064453125 130.048187255859375 135.34051513671875 141.99237060546875 143.1483306884765625 138.949798583984375 135.9706573486328125 132.5797882080078125 130.8321075439453125 131.5582275390625 128.8341827392578125 127.71784210205078125 126.36480712890625 126.824798583984375 123.90665435791015625 129.2649383544921875 132.432464599609375 129.3844757080078125 125.30490875244140625 122.94272613525390625 118.852020263671875 115.12685394287109375 105.0460357666015625 104.5680084228515625 98.2850189208984375 102.422149658203125 105.8924713134765625 114.6099700927734375 117.5434417724609375 115.958343505859375 120.78394317626953125 117.03350067138671875 123.391265869140625 117.21616363525390625 112.97954559326171875 105.6649627685546875 106.74721527099609375 109.84734344482421875 108.32068634033203125 107.964141845703125 105.96878814697265625 104.184814
 453125 99.08649444580078125 96.416259765625 94.0641326904296875 92.00518798828125 89.29108428955078125 89.84680938720703125 85.1704559326171875 92.0536651611328125 98.3042449951171875 88.86865997314453125 80.91693115234375 76.96190643310546875 74.121826171875 72.78429412841796875 72.44817352294921875 73.42752838134765625 71.76221466064453125 74.10793304443359375 73.7342529296875 76.934783935546875 78.72185516357421875 79.13848876953125 80.1992034912109375 80.58391571044921875 75.2365264892578125 72.95738983154296875 68.364959716796875 80.68404388427734375 77.5949249267578125 82.73065948486328125 82.930267333984375 83.07128143310546875 83.01937103271484375 79.73821258544921875 75.78145599365234375 82.43918609619140625 88.17916107177734375 89.2724151611328125 82.64138031005859375 78.0097808837890625 84.15869140625 86.91068267822265625 81.3401336669921875 90.30635833740234375 88.9540557861328125 86.01134490966796875 83.3141937255859375 78.89263916015625 75.3286895751953125 72.313064575
 1953125 72.5489349365234375 81.81690216064453125
+ 132.1120452880859375 134.7157745361328125 130.618408203125 122.37825775146484375 116.29592132568359375 120.99951934814453125 117.2734222412109375 110.09671783447265625 113.5811614990234375 118.38067626953125 120.767913818359375 110.07482147216796875 116.47502899169921875 124.002899169921875 128.07720947265625 127.08655548095703125 122.7725982666015625 126.06330108642578125 128.883087158203125 135.1742401123046875 140.2155914306640625 137.7320556640625 133.7209625244140625 127.91939544677734375 130.79052734375 137.982391357421875 135.381805419921875 136.6862945556640625 138.9438934326171875 138.42681884765625 145.1067962646484375 143.529052734375 146.5245819091796875 147.926849365234375 147.07403564453125 145.712158203125 141.9774322509765625 140.6290435791015625 141.128326416015625 140.2403106689453125 133.721405029296875 130.0178070068359375 131.5919342041015625 137.9964141845703125 140.768218994140625 140.0087432861328125 137.66094970703125 140.76446533203125 141.930908203125 138
 .6763153076171875 137.0155487060546875 140.420379638671875 132.7437286376953125 132.00262451171875 141.4297943115234375 143.014923095703125 140.03692626953125 136.416717529296875 139.521575927734375 142.8446197509765625 141.8568878173828125 137.736968994140625 135.2461700439453125 130.051239013671875 129.625762939453125 128.9149017333984375 126.52431488037109375 127.04563140869140625 128.367828369140625 128.525482177734375 131.3966064453125 127.87981414794921875 129.9422760009765625 127.08089447021484375 125.72859954833984375 121.739990234375 115.77179718017578125 112.02489471435546875 110.90648651123046875 105.5084686279296875 104.39837646484375 108.6337890625 105.41817474365234375 114.6323089599609375 118.52913665771484375 122.1522369384765625 126.43509674072265625 122.79474639892578125 123.59520721435546875 120.39255523681640625 111.46723175048828125 114.69342041015625 113.41829681396484375 113.42002105712890625 112.10828399658203125 109.5498809814453125 107.6414031982421875 103.
 09795379638671875 103.46414947509765625 99.95691680908203125 99.45029449462890625 96.8866424560546875 93.21761322021484375 86.38397216796875 88.79445648193359375 93.03693389892578125 100.24947357177734375 94.2393646240234375 86.560028076171875 80.00412750244140625 75.850677490234375 74.2736358642578125 73.78668975830078125 74.0857086181640625 76.05850982666015625 74.74663543701171875 74.46917724609375 78.62284088134765625 84.257537841796875 86.53850555419921875 84.72426605224609375 79.039215087890625 76.78952789306640625 73.01464080810546875 71.74031829833984375 74.61008453369140625 79.9605712890625 86.34454345703125 85.635711669921875 85.92073822021484375 87.3520355224609375 82.51242828369140625 78.56964874267578125 82.6186065673828125 86.69519805908203125 89.83435821533203125 84.88668060302734375 80.35527801513671875 81.80959320068359375 89.2715301513671875 87.1180267333984375 91.1127166748046875 86.11211395263671875 85.247222900390625 80.785980224609375 79.66179656982421875 73.32
 865142822265625 70.6523284912109375 74.04510498046875 76.07433319091796875
+ 129.6407318115234375 133.055908203125 127.11722564697265625 123.13824462890625 125.7418060302734375 122.33498382568359375 113.56006622314453125 110.36226654052734375 111.54888153076171875 114.4781036376953125 115.79567718505859375 108.96750640869140625 119.72353363037109375 122.89685821533203125 122.6382598876953125 119.013916015625 125.2107696533203125 127.717437744140625 134.5111083984375 137.8326416015625 137.9626007080078125 133.98590087890625 131.392974853515625 123.10009002685546875 127.9810943603515625 131.709503173828125 130.0290374755859375 133.548828125 132.45166015625 142.4361419677734375 143.8242034912109375 145.7880859375 147.394012451171875 147.8358154296875 146.8359832763671875 145.145965576171875 144.0059356689453125 142.919525146484375 141.5408935546875 139.8175506591796875 136.3771514892578125 129.8790740966796875 129.2933197021484375 137.0667724609375 136.7772979736328125 133.62078857421875 136.74591064453125 140.991455078125 142.416229248046875 138.3154907226562
 5 137.8735809326171875 140.5901336669921875 139.717437744140625 142.8784942626953125 144.26715087890625 141.1689910888671875 137.5304412841796875 136.215301513671875 136.646728515625 140.27874755859375 140.6771087646484375 138.8076019287109375 136.3549041748046875 134.04522705078125 134.3051605224609375 132.456817626953125 123.51430511474609375 129.96484375 131.7270355224609375 134.7247161865234375 134.609130859375 131.68731689453125 125.67943572998046875 121.548797607421875 119.953338623046875 121.14228057861328125 121.16767120361328125 117.46025848388671875 110.04245758056640625 101.80225372314453125 111.20279693603515625 115.93106842041015625 109.2841339111328125 109.01914215087890625 113.68314361572265625 120.5952911376953125 125.50670623779296875 127.91262054443359375 124.75435638427734375 115.93805694580078125 120.3927001953125 121.2619171142578125 120.19741058349609375 116.3539276123046875 113.24353790283203125 108.99332427978515625 107.02480316162109375 106.29494476318359375
  104.7713623046875 103.39447021484375 101.0193634033203125 95.65990447998046875 88.226531982421875 86.7121124267578125 91.941680908203125 95.4694976806640625 101.25200653076171875 97.8792266845703125 92.788055419921875 87.9098052978515625 84.393402099609375 79.53810882568359375 76.5220794677734375 76.00046539306640625 80.3301849365234375 85.40937042236328125 85.76027679443359375 83.89073944091796875 88.09839630126953125 90.151031494140625 87.36397552490234375 76.97106170654296875 75.69123077392578125 70.360992431640625 82.4468994140625 76.3426055908203125 84.43206787109375 87.76445770263671875 87.7267608642578125 85.7613067626953125 84.22670745849609375 78.1114044189453125 82.4881439208984375 90.7005615234375 89.36443328857421875 90.21376800537109375 84.43154144287109375 83.71323394775390625 86.71405792236328125 86.1944427490234375 92.48827362060546875 90.16954803466796875 84.074462890625 80.3854522705078125 79.5671234130859375 73.38482666015625 73.63341522216796875 74.1254501342773
 4375 81.4648895263671875 79.729217529296875
+ 132.295196533203125 135.0467376708984375 127.0996856689453125 132.1926727294921875 128.0685577392578125 118.5821075439453125 117.383575439453125 110.395416259765625 109.01621246337890625 112.17646026611328125 108.8506927490234375 113.31066131591796875 116.48639678955078125 114.67925262451171875 118.9358062744140625 123.4665679931640625 130.730224609375 135.16339111328125 135.7212371826171875 137.5746612548828125 132.1930084228515625 130.0169677734375 125.61969757080078125 123.052581787109375 124.39537811279296875 126.18526458740234375 127.5786590576171875 128.60516357421875 136.396759033203125 139.781768798828125 140.816070556640625 143.8160247802734375 145.7560272216796875 146.0839385986328125 145.459197998046875 142.9980010986328125 141.091888427734375 138.17803955078125 135.548553466796875 132.875823974609375 131.881744384765625 133.6686859130859375 129.466796875 132.423126220703125 130.9897918701171875 134.569305419921875 139.529296875 142.2918853759765625 138.97100830078125 13
 6.5833587646484375 137.021575927734375 142.4040985107421875 144.5121917724609375 145.5480499267578125 144.5785369873046875 142.4658355712890625 136.0835113525390625 134.6931610107421875 134.8658905029296875 135.77764892578125 135.95751953125 136.900634765625 135.3895263671875 134.3007965087890625 134.0952606201171875 134.02947998046875 129.2004547119140625 132.9930877685546875 136.4589080810546875 134.20648193359375 133.1291046142578125 132.18487548828125 129.517913818359375 122.578338623046875 116.71663665771484375 114.17999267578125 114.5154266357421875 115.85240936279296875 108.819549560546875 106.39540863037109375 115.45404815673828125 121.4368133544921875 119.28693389892578125 108.74498748779296875 118.15607452392578125 121.75867462158203125 127.48989105224609375 128.3195343017578125 121.5535736083984375 120.60631561279296875 125.969146728515625 124.7691802978515625 119.5703887939453125 112.73274993896484375 109.73232269287109375 103.04799652099609375 101.135650634765625 101.72
 873687744140625 104.08807373046875 99.5369873046875 96.88849639892578125 87.95229339599609375 89.65015411376953125 94.08974456787109375 95.53237152099609375 99.25128936767578125 100.48148345947265625 97.475830078125 92.4362640380859375 88.47083282470703125 84.502410888671875 80.089935302734375 78.52274322509765625 78.6685638427734375 81.044189453125 87.374114990234375 91.915252685546875 92.749267578125 92.06327056884765625 93.2605438232421875 86.40499114990234375 76.86229705810546875 72.66596221923828125 71.62371063232421875 81.33313751220703125 76.8850860595703125 85.6421966552734375 91.30977630615234375 88.76224517822265625 88.2825775146484375 84.54105377197265625 77.774017333984375 82.56036376953125 89.7950286865234375 94.41173553466796875 91.280670166015625 83.334625244140625 90.941436767578125 87.75690460205078125 90.60485076904296875 93.67400360107421875 87.7253570556640625 85.4927215576171875 79.3242340087890625 76.4846343994140625 79.8318939208984375 77.35559844970703125 71.
 65972900390625 79.38175201416015625 82.501312255859375
+ 126.098846435546875 129.830291748046875 135.5699005126953125 134.17608642578125 128.7869873046875 129.6141510009765625 126.73431396484375 117.19155120849609375 107.3729400634765625 108.5641937255859375 108.65187835693359375 114.7010040283203125 113.31356048583984375 121.03592681884765625 126.61493682861328125 123.55982208251953125 129.9496307373046875 136.108978271484375 138.3020477294921875 133.7476959228515625 131.3597564697265625 128.3137969970703125 122.64238739013671875 129.3862762451171875 134.143646240234375 134.3936920166015625 130.204742431640625 132.71343994140625 132.2214508056640625 134.2533416748046875 137.8268890380859375 141.9580230712890625 142.5887603759765625 143.7910614013671875 143.13372802734375 140.2312469482421875 138.485321044921875 138.1879730224609375 137.94561767578125 137.46185302734375 138.842742919921875 137.0940093994140625 129.46905517578125 129.6959075927734375 128.219879150390625 134.022674560546875 140.5358123779296875 140.641754150390625 134.9016
 11328125 135.1564178466796875 139.5000762939453125 143.058563232421875 144.5963287353515625 144.6045379638671875 143.2770843505859375 142.2433929443359375 138.6824493408203125 135.9264068603515625 135.1439056396484375 134.8974609375 137.9002227783203125 132.3672027587890625 129.933349609375 129.014617919921875 128.9682464599609375 131.4063568115234375 135.7363128662109375 134.548828125 133.7891998291015625 131.652374267578125 129.04034423828125 131.6698455810546875 131.0107421875 128.086883544921875 120.22515869140625 119.71781158447265625 116.927276611328125 110.2865142822265625 106.63922119140625 111.9944915771484375 120.4900970458984375 125.0980682373046875 126.4646453857421875 118.61920166015625 115.2497711181640625 123.32550811767578125 129.4936065673828125 128.6023712158203125 127.427947998046875 126.69830322265625 126.22843170166015625 122.25443267822265625 119.94884490966796875 115.39636993408203125 111.97948455810546875 108.96816253662109375 102.966278076171875 94.332191467
 28515625 96.6957244873046875 92.54325103759765625 89.64252471923828125 92.86301422119140625 96.23632049560546875 99.34389495849609375 103.83592987060546875 101.294647216796875 98.54415130615234375 90.0249786376953125 86.4251708984375 80.2348175048828125 79.47417449951171875 76.20862579345703125 79.896392822265625 81.2514801025390625 83.42279052734375 86.44327545166015625 90.26857757568359375 96.32997894287109375 95.00226593017578125 90.03011322021484375 85.241729736328125 78.1250152587890625 72.8972015380859375 76.86249542236328125 78.13165283203125 84.769256591796875 90.6470947265625 92.8841094970703125 91.47353363037109375 92.19744873046875 86.9636077880859375 81.14764404296875 79.24431610107421875 81.76352691650390625 89.53363037109375 92.1948089599609375 86.386993408203125 91.6310577392578125 93.41124725341796875 94.7314605712890625 94.3376617431640625 91.7038116455078125 84.00514984130859375 81.6724395751953125 74.6673583984375 83.6972503662109375 82.42095184326171875 78.784400
 93994140625 75.95850372314453125 81.63837432861328125
+ 132.28973388671875 133.623626708984375 131.9107818603515625 134.536285400390625 134.49346923828125 134.60186767578125 128.0091552734375 123.2059783935546875 106.89180755615234375 106.7613677978515625 107.01605224609375 109.3484649658203125 117.45926666259765625 124.496063232421875 130.632171630859375 131.9472503662109375 130.8498382568359375 136.256195068359375 137.1728668212890625 134.14849853515625 124.72425079345703125 123.78022003173828125 122.51911163330078125 131.425048828125 135.295135498046875 137.1529998779296875 133.083282470703125 136.8562469482421875 141.60498046875 143.4642333984375 142.107696533203125 144.33489990234375 146.6950836181640625 145.1583404541015625 143.3003997802734375 142.62042236328125 142.8771209716796875 144.1624908447265625 143.0596771240234375 141.4741668701171875 142.02117919921875 138.8523101806640625 132.7523956298828125 127.69834136962890625 125.5735626220703125 131.633209228515625 137.38250732421875 137.242950439453125 134.1272735595703125 135.
 6865386962890625 139.4435272216796875 142.37982177734375 143.576324462890625 142.74298095703125 142.31121826171875 140.1366119384765625 141.579254150390625 141.073699951171875 136.702239990234375 135.8229827880859375 139.8748321533203125 138.977508544921875 136.1795501708984375 134.562530517578125 127.68767547607421875 126.0412750244140625 130.75177001953125 129.81292724609375 133.3786163330078125 130.7017822265625 128.3810882568359375 129.23858642578125 129.828125 127.4312744140625 125.19191741943359375 125.70963287353515625 122.43187713623046875 115.0245361328125 109.2757110595703125 117.76627349853515625 123.69190216064453125 130.1189117431640625 131.9493408203125 123.6646270751953125 115.93227386474609375 121.41535186767578125 128.3305816650390625 131.0850372314453125 128.607086181640625 125.46881103515625 125.01004791259765625 117.49615478515625 113.6275787353515625 111.13568115234375 107.44518280029296875 103.2079315185546875 95.71604156494140625 96.12830352783203125 95.140502
 9296875 96.28771209716796875 97.52713775634765625 97.07952117919921875 99.3522491455078125 101.56630706787109375 107.07819366455078125 101.299560546875 96.40581512451171875 94.2279815673828125 89.70281982421875 82.42071533203125 80.41312408447265625 90.61363983154296875 77.66800689697265625 82.99040985107421875 84.57302093505859375 88.0430908203125 94.8236083984375 96.61113739013671875 91.29878997802734375 86.76482391357421875 80.763031005859375 76.51491546630859375 72.26984405517578125 78.675506591796875 78.64055633544921875 88.40090179443359375 92.1984710693359375 94.09239959716796875 93.77164459228515625 92.92827606201171875 86.7476806640625 77.79692840576171875 88.21329498291015625 90.05957794189453125 92.05859375 85.79496002197265625 93.12511444091796875 94.33875274658203125 95.19275665283203125 92.6849365234375 92.23792266845703125 87.98415374755859375 84.94757080078125 80.0313262939453125 76.6942901611328125 84.26558685302734375 86.47621917724609375 82.2817230224609375 74.086
 7462158203125 80.5070037841796875
+ 130.0936737060546875 127.03249359130859375 130.0998992919921875 132.99090576171875 134.2086944580078125 132.7196044921875 123.9351959228515625 117.94452667236328125 115.14129638671875 105.7564239501953125 108.06974029541015625 114.01546478271484375 114.883636474609375 122.64234161376953125 127.38385772705078125 131.9467620849609375 134.487640380859375 137.431884765625 134.6024017333984375 134.0993499755859375 126.77203369140625 121.4040985107421875 123.38327789306640625 127.903411865234375 132.9863128662109375 137.3919677734375 135.629852294921875 138.155914306640625 144.811614990234375 144.4330291748046875 142.6976776123046875 142.219451904296875 146.4102935791015625 147.323150634765625 146.6107025146484375 145.281494140625 146.001068115234375 145.3191986083984375 143.9158477783203125 140.784393310546875 140.795379638671875 138.23968505859375 137.00048828125 130.8568115234375 124.35404205322265625 129.235992431640625 127.3567657470703125 130.90899658203125 135.03857421875 137.5775
 604248046875 137.9915771484375 140.9487457275390625 141.941497802734375 140.9798736572265625 137.1118927001953125 135.801910400390625 138.321807861328125 141.4693450927734375 139.7344970703125 136.5500335693359375 136.0382080078125 136.45697021484375 137.2412872314453125 137.2631072998046875 133.4117279052734375 125.11591339111328125 123.548919677734375 127.22637939453125 129.463287353515625 127.5974273681640625 122.198486328125 129.6922149658203125 126.2065277099609375 123.4338836669921875 123.531005859375 125.48813629150390625 120.79170989990234375 118.43495941162109375 118.55179595947265625 113.96917724609375 119.84539031982421875 126.57378387451171875 131.8481903076171875 122.8073272705078125 121.3740234375 124.52142333984375 126.64019012451171875 129.8396453857421875 126.8390960693359375 121.2902069091796875 121.5780029296875 116.62957763671875 109.4282379150390625 104.027130126953125 102.49560546875 97.8436431884765625 101.73644256591796875 103.95189666748046875 103.7540435791
 015625 105.25438690185546875 104.59040069580078125 100.22585296630859375 101.85962677001953125 104.7215118408203125 109.01959991455078125 104.2534942626953125 96.0243072509765625 90.90496826171875 84.78157806396484375 81.75763702392578125 89.338836669921875 91.4316253662109375 81.25566864013671875 82.57279205322265625 88.42266082763671875 88.98822784423828125 95.372589111328125 96.1673431396484375 93.308990478515625 89.60398101806640625 81.583648681640625 75.0535888671875 75.7872467041015625 79.93271636962890625 82.16101837158203125 84.0978240966796875 90.23973846435546875 93.7695159912109375 94.50327301025390625 92.65645599365234375 87.30495452880859375 79.49475860595703125 86.39969635009765625 90.2516632080078125 93.39885711669921875 89.61702728271484375 93.48076629638671875 93.5173187255859375 90.7939910888671875 90.911712646484375 89.17964935302734375 86.41237640380859375 81.57080841064453125 78.4988555908203125 79.94408416748046875 87.0723876953125 87.236968994140625 81.5020217
 8955078125 81.1371917724609375 75.53481292724609375
+ 121.7080078125 123.4837799072265625 127.95078277587890625 132.344818115234375 130.1439361572265625 129.7321319580078125 128.6598968505859375 123.60796356201171875 115.00276947021484375 109.30773162841796875 109.511383056640625 112.56170654296875 117.2813262939453125 125.4180450439453125 129.35406494140625 132.152008056640625 131.8250274658203125 131.789398193359375 132.928192138671875 130.4698333740234375 126.39333343505859375 117.6726531982421875 123.81511688232421875 133.03399658203125 138.8694610595703125 138.8769073486328125 138.979827880859375 140.32989501953125 141.177825927734375 141.89276123046875 141.60626220703125 142.2390899658203125 144.2059326171875 146.5007171630859375 146.12493896484375 142.7309112548828125 142.433349609375 143.0124359130859375 142.1853790283203125 136.86041259765625 134.4392242431640625 132.1623382568359375 133.5870208740234375 126.5716552734375 123.54508209228515625 124.24913787841796875 130.1074981689453125 135.22454833984375 136.197479248046875 1
 36.5372161865234375 132.12255859375 138.9672088623046875 138.653228759765625 139.753021240234375 135.9736175537109375 136.0342864990234375 135.1728363037109375 139.4393310546875 139.9451446533203125 138.682708740234375 136.7220306396484375 133.5994873046875 135.18353271484375 136.2827606201171875 132.79718017578125 128.084716796875 121.80258941650390625 120.0771484375 120.322174072265625 122.36237335205078125 123.5074462890625 127.7533416748046875 125.30303955078125 120.8240509033203125 120.59563446044921875 123.89481353759765625 122.742645263671875 122.53472137451171875 120.8858795166015625 118.711456298828125 124.12139892578125 128.665130615234375 129.020172119140625 123.0844879150390625 128.2589874267578125 130.7475128173828125 129.7150726318359375 126.915618896484375 126.1215972900390625 122.805877685546875 115.69891357421875 115.4007110595703125 111.05736541748046875 106.94297027587890625 99.88834381103515625 108.12358856201171875 103.32616424560546875 109.68441009521484375 109
 .43274688720703125 112.93355560302734375 108.9840087890625 105.52089691162109375 105.62603759765625 106.236053466796875 108.83160400390625 103.09033966064453125 95.4256591796875 84.62627410888671875 85.258331298828125 91.8023681640625 93.31351470947265625 87.2956085205078125 81.97760772705078125 83.649200439453125 87.56754302978515625 93.628326416015625 95.89205169677734375 92.8507080078125 89.3161163330078125 85.5136260986328125 80.75836181640625 76.32665252685546875 76.33535003662109375 82.95545196533203125 84.95340728759765625 83.85520172119140625 89.4722900390625 97.02773284912109375 97.78084564208984375 94.6128692626953125 92.315643310546875 82.05889129638671875 86.30956268310546875 92.862579345703125 98.88007354736328125 95.46024322509765625 97.12774658203125 91.1088409423828125 86.61455535888671875 86.26929473876953125 84.8457794189453125 83.2320404052734375 78.60248565673828125 84.657196044921875 84.37534332275390625 92.25292205810546875 89.40958404541015625 78.0920944213867
 1875 86.2939453125 78.68694305419921875
+ 117.98122406005859375 123.0048828125 127.85198974609375 128.3892822265625 128.9704437255859375 123.5386810302734375 129.609649658203125 123.08666229248046875 116.58679962158203125 105.42218780517578125 107.7723388671875 111.42650604248046875 116.67208099365234375 122.34839630126953125 122.171173095703125 121.3558807373046875 124.05893707275390625 132.0251312255859375 129.7551727294921875 128.2777252197265625 123.05157470703125 116.2853240966796875 122.28884124755859375 130.0123443603515625 140.072906494140625 140.9537506103515625 139.887908935546875 139.2469482421875 138.3435821533203125 138.805206298828125 137.998016357421875 138.263885498046875 140.775360107421875 141.36065673828125 142.338714599609375 141.8943939208984375 138.4399871826171875 141.0150604248046875 142.2393951416015625 143.0330963134765625 139.9552154541015625 133.014129638671875 132.495086669921875 132.9636077880859375 125.06826019287109375 123.92455291748046875 131.657318115234375 133.700469970703125 134.1219024
 658203125 133.0033416748046875 131.67156982421875 137.047576904296875 137.4634552001953125 138.8701019287109375 140.2943572998046875 140.9187774658203125 136.07318115234375 138.16192626953125 138.877716064453125 137.5247802734375 134.8063812255859375 134.821624755859375 131.574951171875 134.337493896484375 129.67529296875 131.8797607421875 130.4579620361328125 127.24530792236328125 117.98967742919921875 114.8071136474609375 117.79518890380859375 124.47844696044921875 121.214996337890625 117.3525848388671875 119.5843353271484375 125.91434478759765625 123.73248291015625 125.12420654296875 127.862152099609375 122.214385986328125 125.4244384765625 130.7428131103515625 131.845855712890625 129.165130615234375 130.48321533203125 129.861236572265625 127.82801055908203125 125.6112518310546875 122.36981201171875 121.192474365234375 118.9405364990234375 114.6311187744140625 103.15424346923828125 109.7397003173828125 107.746185302734375 111.7866668701171875 105.07035064697265625 113.88289642333
 984375 117.14237213134765625 115.00934600830078125 109.54926300048828125 105.46393585205078125 101.0593414306640625 100.15631103515625 100.92414093017578125 100.2238006591796875 94.20908355712890625 85.24549102783203125 86.2108154296875 92.3957366943359375 99.031005859375 95.88385009765625 83.95146942138671875 86.19416046142578125 93.09765625 94.25394439697265625 95.79824066162109375 89.17650604248046875 84.138763427734375 80.5783538818359375 78.96256256103515625 79.46233367919921875 80.41059112548828125 84.06824493408203125 87.1389923095703125 90.4180450439453125 91.83724212646484375 97.59683990478515625 100.3709259033203125 97.77530670166015625 96.48986053466796875 88.24941253662109375 86.8013763427734375 94.54416656494140625 102.4959869384765625 100.3734588623046875 97.95977783203125 92.9665679931640625 87.6764678955078125 89.76071929931640625 80.44683837890625 79.2428436279296875 84.6239471435546875 90.23429107666015625 85.86312103271484375 92.78826141357421875 86.04771423339843
 75 86.139373779296875 88.50272369384765625 77.939453125
+ 116.8243560791015625 121.23270416259765625 126.7196044921875 122.01318359375 121.38185882568359375 120.02417755126953125 124.316986083984375 123.185272216796875 117.8061676025390625 106.02457427978515625 107.14521026611328125 106.745513916015625 110.09241485595703125 111.65813446044921875 117.20249176025390625 120.168243408203125 124.426544189453125 131.96417236328125 122.50934600830078125 123.10706329345703125 120.51865386962890625 116.72185516357421875 123.7750396728515625 130.597991943359375 137.4004364013671875 139.81524658203125 142.575286865234375 137.4384307861328125 136.2917938232421875 138.380157470703125 135.15435791015625 137.847076416015625 139.2737579345703125 140.3659515380859375 140.9561920166015625 137.963134765625 136.8568572998046875 141.247650146484375 139.5428619384765625 139.2550201416015625 141.67462158203125 141.6302947998046875 138.6556549072265625 135.1167449951171875 129.604461669921875 120.7837982177734375 125.274810791015625 130.0117034912109375 130.8733
 062744140625 127.722442626953125 134.4408721923828125 134.3481292724609375 132.8608245849609375 135.7544403076171875 139.7837066650390625 139.182952880859375 132.3537750244140625 137.88568115234375 136.7059326171875 133.1006622314453125 132.150421142578125 132.528839111328125 132.31072998046875 131.4388580322265625 133.0019683837890625 133.9163665771484375 132.6001739501953125 127.424530029296875 123.07541656494140625 116.63365936279296875 111.62723541259765625 114.82717132568359375 119.6565093994140625 113.939239501953125 121.3432464599609375 122.888275146484375 120.47946929931640625 124.65936279296875 125.9913330078125 127.839874267578125 127.5325775146484375 130.337310791015625 133.5024871826171875 133.372283935546875 131.42962646484375 129.3038482666015625 126.2481231689453125 123.36928558349609375 121.38088226318359375 118.36681365966796875 111.8172760009765625 107.7864990234375 113.9478912353515625 114.7732391357421875 114.24741363525390625 109.159332275390625 108.745948791503
 90625 114.8784942626953125 113.86931610107421875 110.76804351806640625 105.3648834228515625 98.5478973388671875 92.97740936279296875 92.87152862548828125 94.34712982177734375 92.6318511962890625 84.656890869140625 88.449371337890625 93.40128326416015625 93.16924285888671875 98.633880615234375 92.23238372802734375 84.01384735107421875 89.2433013916015625 94.77498626708984375 94.7842559814453125 94.61202239990234375 92.54863739013671875 89.837890625 85.1134796142578125 80.64321136474609375 76.09508514404296875 83.089752197265625 93.00777435302734375 88.83530426025390625 94.648162841796875 98.84522247314453125 100.904998779296875 103.530120849609375 100.80831146240234375 97.49369049072265625 91.0058135986328125 85.849884033203125 90.78553009033203125 97.84789276123046875 100.33652496337890625 99.6783599853515625 95.45890045166015625 92.39276885986328125 88.03208160400390625 86.07171630859375 91.81595611572265625 88.830810546875 83.65708160400390625 90.52306365966796875 90.9827575683593
 75 89.95447540283203125 90.767547607421875 89.04624176025390625 80.14031219482421875
+ 118.64798736572265625 123.09571075439453125 125.99176788330078125 118.75962066650390625 117.37595367431640625 115.34552001953125 117.44134521484375 118.24716949462890625 112.4441375732421875 103.67948150634765625 108.38745880126953125 112.13951873779296875 118.89351654052734375 122.27099609375 125.84825897216796875 128.310028076171875 130.84356689453125 128.943511962890625 130.0499420166015625 123.1808319091796875 113.92038726806640625 117.143310546875 124.6316986083984375 131.1769561767578125 137.5052032470703125 135.6047515869140625 134.545257568359375 129.946258544921875 134.4321136474609375 138.5644073486328125 133.1576690673828125 133.1655426025390625 131.3311767578125 136.95452880859375 140.0815887451171875 135.1110992431640625 137.6446075439453125 141.9724578857421875 137.5151519775390625 136.0069122314453125 136.5478668212890625 139.1294708251953125 136.8280487060546875 130.1353302001953125 129.7508392333984375 120.09844207763671875 122.15764617919921875 126.710914611816406
 25 124.4757080078125 131.2721710205078125 133.7664337158203125 131.31549072265625 130.029754638671875 135.39581298828125 136.9986724853515625 132.4302215576171875 133.5318603515625 137.6476287841796875 133.78155517578125 131.444854736328125 130.2309722900390625 130.0394439697265625 131.4466400146484375 130.487335205078125 135.185943603515625 136.4171905517578125 133.0336456298828125 130.5895233154296875 126.7877044677734375 121.29827117919921875 113.63199615478515625 110.75508880615234375 112.93474578857421875 112.74910736083984375 119.54453277587890625 119.97043609619140625 117.49527740478515625 121.1246795654296875 120.6044769287109375 127.52709197998046875 131.7754974365234375 132.008148193359375 132.8524169921875 133.940643310546875 132.3956451416015625 125.30364227294921875 126.93442535400390625 124.15540313720703125 122.008331298828125 119.54517364501953125 116.82939910888671875 116.06070709228515625 116.98299407958984375 117.6019287109375 117.2491455078125 115.125617980957031
 25 115.808380126953125 115.10831451416015625 109.56069183349609375 104.67095184326171875 104.16847991943359375 102.25998687744140625 100.207244873046875 95.61414337158203125 88.40384674072265625 95.29795074462890625 86.5111846923828125 93.57045745849609375 96.91481781005859375 103.55257415771484375 100.38535308837890625 92.48613739013671875 84.13519287109375 92.20006561279296875 94.7811431884765625 95.63549041748046875 96.275909423828125 94.66201019287109375 93.97548675537109375 88.62937164306640625 83.56981658935546875 75.34998321533203125 82.3379669189453125 87.66655731201171875 92.11579132080078125 98.1824493408203125 103.25855255126953125 107.29840850830078125 107.0530853271484375 102.8998260498046875 98.5587310791015625 92.62563323974609375 87.74053955078125 90.68087005615234375 92.0771331787109375 97.8872833251953125 98.9520263671875 92.82016754150390625 88.65967559814453125 82.95647430419921875 88.361358642578125 96.96575164794921875 90.990570068359375 87.79933929443359375 93
 .6226654052734375 91.15167999267578125 92.83124542236328125 94.0959320068359375 89.75945281982421875 83.22573089599609375
+ 116.61849212646484375 121.41487884521484375 122.20450592041015625 122.71314239501953125 120.370025634765625 112.9321441650390625 110.3443603515625 115.1115875244140625 111.966278076171875 103.50254058837890625 106.98955535888671875 114.8834991455078125 122.4476165771484375 121.61576080322265625 123.42545318603515625 130.5285797119140625 132.283538818359375 127.0641937255859375 127.4285125732421875 123.782501220703125 112.92919921875 118.33884429931640625 123.028228759765625 129.3193817138671875 135.4033355712890625 134.9024505615234375 129.41241455078125 132.80255126953125 137.44171142578125 136.0321502685546875 131.67193603515625 130.1825408935546875 133.1243133544921875 140.082000732421875 140.097259521484375 133.6142120361328125 135.6016998291015625 138.6377716064453125 135.9788665771484375 136.4423828125 138.6870880126953125 136.0465545654296875 135.9257659912109375 134.887847900390625 129.9129180908203125 124.4405975341796875 119.149627685546875 123.24065399169921875 128.88311
 767578125 131.630035400390625 130.620391845703125 127.8113861083984375 131.7272491455078125 133.5220489501953125 131.3561553955078125 131.9920501708984375 137.0950164794921875 136.44561767578125 129.1610565185546875 125.4279632568359375 129.47332763671875 124.9763336181640625 124.28818511962890625 128.557220458984375 132.979034423828125 135.1455841064453125 132.0247955322265625 125.726348876953125 122.0178680419921875 123.71645355224609375 117.99896240234375 112.47005462646484375 107.96408843994140625 110.91184234619140625 117.0041046142578125 115.331634521484375 115.44892120361328125 117.04711151123046875 122.48487091064453125 129.4427642822265625 130.8850860595703125 128.7641754150390625 129.2642364501953125 131.20159912109375 132.3109130859375 126.21954345703125 119.21338653564453125 116.4147491455078125 119.56684112548828125 119.8177947998046875 118.5560760498046875 114.26297760009765625 112.9570159912109375 114.0660858154296875 115.68264007568359375 115.5308990478515625 115.064
 5599365234375 114.497589111328125 110.861663818359375 107.29369354248046875 105.16156768798828125 100.0748748779296875 98.07273101806640625 91.78791046142578125 92.34796905517578125 95.6948089599609375 89.077606201171875 97.7259368896484375 102.07862091064453125 103.99803924560546875 97.7070465087890625 87.83834075927734375 88.48882293701171875 95.20261383056640625 97.461822509765625 96.55272674560546875 96.425628662109375 96.07756805419921875 92.47380828857421875 89.2449798583984375 84.26956939697265625 76.78954315185546875 89.48220062255859375 90.07552337646484375 96.0883331298828125 99.22967529296875 105.79499053955078125 106.0754852294921875 104.83876800537109375 104.27082061767578125 100.8344268798828125 95.1995086669921875 89.432373046875 102.52851104736328125 100.8099212646484375 101.09523773193359375 100.9202117919921875 97.7959747314453125 91.64630126953125 83.40604400634765625 89.29973602294921875 94.31194305419921875 94.21074676513671875 89.36850738525390625 94.8307723999
 0234375 94.575103759765625 95.5899658203125 95.60254669189453125 91.10758209228515625 87.623931884765625
+ 112.67670440673828125 115.70191192626953125 126.3607025146484375 128.474639892578125 128.2648468017578125 121.70111083984375 116.96495819091796875 107.1300048828125 106.65180206298828125 102.12499237060546875 106.02677154541015625 108.36536407470703125 113.78290557861328125 120.7123260498046875 129.19183349609375 132.6297454833984375 132.533111572265625 122.85538482666015625 123.0667877197265625 116.48075103759765625 112.0604095458984375 122.76416778564453125 128.4766082763671875 131.57867431640625 134.47735595703125 132.4000396728515625 126.49642181396484375 129.1291046142578125 136.4861602783203125 132.1097259521484375 127.22197723388671875 129.2480926513671875 136.88995361328125 140.0107879638671875 138.5111083984375 134.4224395751953125 129.0651092529296875 134.753692626953125 131.3737945556640625 132.303253173828125 138.207366943359375 131.864593505859375 129.400848388671875 127.9939727783203125 126.1067352294921875 122.847869873046875 117.79030609130859375 120.124671936035156
 25 126.8653106689453125 127.39919281005859375 127.3836669921875 126.9168548583984375 132.5126800537109375 128.3962860107421875 127.2038116455078125 134.9366455078125 136.9125518798828125 133.469451904296875 127.57068634033203125 122.53272247314453125 122.30869293212890625 122.003936767578125 129.9253997802734375 133.68206787109375 135.784393310546875 132.8917388916015625 132.2929534912109375 130.245330810546875 127.9066925048828125 127.1077423095703125 124.71759033203125 118.795867919921875 112.36623382568359375 107.33609771728515625 109.82549285888671875 114.67937469482421875 113.0484466552734375 120.9030914306640625 124.92354583740234375 128.2501678466796875 127.4113616943359375 125.14525604248046875 125.02132415771484375 129.25189208984375 132.318359375 127.81392669677734375 119.78136444091796875 116.8052825927734375 116.5280914306640625 116.70607757568359375 117.2489013671875 117.13299560546875 113.1054229736328125 110.2509307861328125 113.6493072509765625 114.904815673828125 11
 0.13674163818359375 110.259307861328125 106.5577392578125 101.26651763916015625 97.3837127685546875 94.8939666748046875 94.50421905517578125 97.24861907958984375 102.81581878662109375 105.05239105224609375 96.3464508056640625 99.550201416015625 104.2630615234375 100.0449066162109375 90.34832000732421875 90.5572052001953125 98.7072296142578125 96.75490570068359375 100.2938079833984375 99.59911346435546875 98.8712310791015625 94.9710693359375 92.5810546875 86.892822265625 82.4100189208984375 76.4705963134765625 83.91129302978515625 90.6519775390625 95.70804595947265625 103.2651824951171875 104.7449188232421875 102.61536407470703125 100.445587158203125 102.889404296875 102.849639892578125 97.18896484375 89.6513214111328125 96.92125701904296875 102.2027435302734375 101.84999847412109375 97.19879150390625 95.137725830078125 90.53885650634765625 82.97283935546875 86.19766998291015625 91.28924560546875 94.62413787841796875 95.75022125244140625 97.144317626953125 98.04746246337890625 99.455
 10101318359375 94.22442626953125 91.70818328857421875 93.26290130615234375
+ 108.979827880859375 117.9922943115234375 123.79380035400390625 124.6200103759765625 130.4305419921875 126.739776611328125 120.08766937255859375 107.94751739501953125 103.6443939208984375 102.08454132080078125 108.38910675048828125 120.086883544921875 121.29607391357421875 120.89066314697265625 128.387664794921875 129.501983642578125 131.1485748291015625 126.51959228515625 120.349151611328125 112.58187103271484375 114.431793212890625 121.9650115966796875 127.98077392578125 129.8729248046875 132.190582275390625 128.3917083740234375 124.5129852294921875 132.87371826171875 137.15167236328125 133.8428802490234375 123.8889312744140625 126.2441864013671875 130.812957763671875 134.1615142822265625 136.3491363525390625 134.8203125 126.04498291015625 129.466461181640625 126.67632293701171875 134.1454315185546875 137.525909423828125 137.138153076171875 131.4085235595703125 127.16210174560546875 124.54238128662109375 125.4024810791015625 116.98845672607421875 116.96380615234375 123.43707275390
 625 123.675048828125 129.0904693603515625 132.038543701171875 129.5218353271484375 124.7544708251953125 130.342681884765625 136.55242919921875 135.9721221923828125 126.1940460205078125 125.62070465087890625 120.3954620361328125 119.89247894287109375 128.3380126953125 132.620391845703125 135.71337890625 134.3184814453125 131.518463134765625 129.0810394287109375 131.022552490234375 131.0540313720703125 126.60742950439453125 122.92758941650390625 117.85228729248046875 111.05157470703125 105.47296905517578125 110.43074798583984375 108.8743133544921875 117.51964569091796875 121.1193084716796875 123.7806243896484375 124.49767303466796875 123.64499664306640625 120.44659423828125 123.99298095703125 128.0696258544921875 131.518341064453125 127.46340179443359375 122.98079681396484375 124.4899139404296875 118.50038909912109375 111.7208709716796875 108.7825469970703125 112.23777008056640625 113.73168182373046875 109.90178680419921875 112.86168670654296875 114.67359161376953125 111.5240631103515
 625 105.34302520751953125 102.74668121337890625 101.73921966552734375 100.30008697509765625 99.7911529541015625 102.9254302978515625 100.65084075927734375 107.2283782958984375 108.13934326171875 99.96773529052734375 96.5806884765625 101.39255523681640625 97.1024322509765625 93.7391357421875 97.5069732666015625 97.8137054443359375 98.97064208984375 102.34976959228515625 100.0788116455078125 97.1194915771484375 88.12967681884765625 90.035614013671875 86.246551513671875 79.7563323974609375 76.76624298095703125 83.07763671875 91.38164520263671875 94.5233154296875 103.15595245361328125 98.26396942138671875 98.978607177734375 96.9046478271484375 99.39111328125 102.04128265380859375 99.07305145263671875 94.39276885986328125 100.61832427978515625 103.02532958984375 100.50725555419921875 94.1707611083984375 90.81153106689453125 86.4361724853515625 85.15183258056640625 91.99698638916015625 90.25359344482421875 92.940826416015625 94.72336578369140625 99.6381072998046875 101.9299774169921875 99
 .75286102294921875 96.24481964111328125 94.0235748291015625 92.71096038818359375
+ 109.12482452392578125 117.85773468017578125 119.2764892578125 124.7189178466796875 128.1548004150390625 122.64278411865234375 116.2888031005859375 107.799591064453125 102.08142852783203125 104.06644439697265625 108.54346466064453125 117.4570770263671875 123.27332305908203125 122.5699005126953125 122.79871368408203125 127.30054473876953125 129.639556884765625 126.3067474365234375 121.989532470703125 109.79723358154296875 113.922637939453125 121.080047607421875 123.9748992919921875 127.6647796630859375 129.3024139404296875 122.0901947021484375 128.9664764404296875 133.426116943359375 135.65557861328125 131.3360137939453125 122.1132354736328125 127.14328765869140625 132.68780517578125 135.4813385009765625 134.1601715087890625 130.1288604736328125 127.40819549560546875 123.30126953125 128.526580810546875 133.2421722412109375 138.19830322265625 137.264404296875 134.7089996337890625 134.0394744873046875 132.3591766357421875 131.3752593994140625 126.7266998291015625 115.80567169189453125
 118.01351165771484375 121.74727630615234375 126.6305999755859375 128.37237548828125 122.35587310791015625 128.0948333740234375 134.4891510009765625 134.725341796875 133.70245361328125 129.179290771484375 126.56484222412109375 119.7436676025390625 117.90874481201171875 127.02730560302734375 131.658721923828125 130.13818359375 132.7310791015625 129.83489990234375 125.98780059814453125 128.558197021484375 130.0330657958984375 122.88477325439453125 116.37054443359375 115.7792510986328125 115.20175933837890625 105.74617767333984375 106.93767547607421875 112.09659576416015625 117.54346466064453125 118.07743072509765625 119.37457275390625 119.788330078125 119.14842987060546875 117.6574859619140625 120.99347686767578125 127.0406341552734375 130.0587158203125 127.82767486572265625 128.5039520263671875 128.3029937744140625 124.11423492431640625 119.45806121826171875 112.5754241943359375 105.8504638671875 106.4052886962890625 106.886077880859375 114.0292510986328125 110.05281829833984375 112.5
 32196044921875 113.791290283203125 112.77666473388671875 109.3448486328125 107.3782806396484375 103.77370452880859375 108.31203460693359375 106.64032745361328125 108.05982208251953125 109.16683197021484375 106.91896820068359375 103.143890380859375 104.72666168212890625 106.144256591796875 101.6358795166015625 97.15590667724609375 97.60668182373046875 100.87158966064453125 101.936309814453125 98.24700927734375 95.05727386474609375 90.6443939208984375 87.3161468505859375 82.4381103515625 78.03214263916015625 81.26214599609375 80.52687835693359375 84.522216796875 94.03566741943359375 97.13875579833984375 91.76214599609375 94.66059112548828125 94.28453826904296875 99.52938079833984375 100.09735107421875 101.72412872314453125 100.255950927734375 102.0910186767578125 101.8394012451171875 100.42737579345703125 96.70543670654296875 91.748626708984375 87.06551361083984375 95.44245147705078125 91.2390594482421875 93.08934783935546875 96.05654144287109375 96.8489227294921875 99.948287963867187
 5 101.19422149658203125 98.31131744384765625 93.38164520263671875 91.42465972900390625 87.05063629150390625
+ 107.7533721923828125 111.65068817138671875 113.63956451416015625 122.54160308837890625 124.35585784912109375 117.21715545654296875 114.62979888916015625 104.99652099609375 102.04828643798828125 103.94351959228515625 117.7122955322265625 116.968231201171875 115.4264678955078125 115.62790679931640625 119.362091064453125 125.7764434814453125 125.7841796875 123.79419708251953125 118.75508880615234375 114.71201324462890625 111.440948486328125 117.7713775634765625 122.67531585693359375 128.240814208984375 126.280853271484375 124.08003997802734375 129.5722808837890625 134.3403167724609375 134.2461700439453125 129.41558837890625 121.44103240966796875 128.817840576171875 131.857574462890625 133.5238800048828125 136.3012542724609375 132.364288330078125 125.45117950439453125 120.15921783447265625 127.129852294921875 133.5484161376953125 135.6749420166015625 137.0698699951171875 131.7051849365234375 134.7286376953125 135.7093505859375 131.380889892578125 122.98162841796875 118.8875579833984375
  116.89508819580078125 120.8051300048828125 123.0302886962890625 120.63500213623046875 126.5072784423828125 130.627349853515625 131.382904052734375 130.12860107421875 129.7722320556640625 129.8165740966796875 129.1624603271484375 122.46491241455078125 117.05974578857421875 124.237548828125 125.27056121826171875 126.972686767578125 131.9347991943359375 129.254669189453125 123.3687286376953125 124.86124420166015625 128.0872955322265625 128.8338470458984375 123.35163116455078125 116.6045684814453125 111.73906707763671875 104.36394500732421875 104.1447601318359375 111.95023345947265625 111.1829376220703125 111.74651336669921875 112.67282867431640625 112.223480224609375 115.3880615234375 119.72296905517578125 125.0403594970703125 129.5141754150390625 129.5398101806640625 123.19327545166015625 125.56769561767578125 127.67127227783203125 124.323638916015625 120.41814422607421875 116.9160919189453125 113.57137298583984375 102.7986907958984375 109.7086181640625 112.51540374755859375 106.9746
 1700439453125 111.80789947509765625 114.5637359619140625 115.97177886962890625 113.411529541015625 108.23699188232421875 102.88291168212890625 110.612579345703125 109.85327911376953125 109.291351318359375 109.15628814697265625 109.31351470947265625 110.40007781982421875 107.2091522216796875 110.3694610595703125 103.0258941650390625 99.95993804931640625 100.61244964599609375 103.2911834716796875 101.3035736083984375 94.2068634033203125 93.683624267578125 87.6978607177734375 83.722808837890625 82.1602020263671875 82.960845947265625 83.38961029052734375 78.323944091796875 85.00994110107421875 88.4720458984375 89.224853515625 88.187835693359375 88.62737274169921875 89.2933502197265625 93.515289306640625 96.31655120849609375 101.2776336669921875 103.2821044921875 97.76432037353515625 94.9511260986328125 95.547210693359375 93.601531982421875 90.21643829345703125 89.58712005615234375 95.47344970703125 97.0918731689453125 95.787811279296875 95.9584503173828125 100.71933746337890625 101.7266
 387939453125 101.9340667724609375 100.967926025390625 97.1710968017578125 92.84357452392578125 90.506805419921875
+ 107.81307220458984375 114.8634490966796875 118.35631561279296875 125.20477294921875 115.05770111083984375 110.15178680419921875 104.61840057373046875 102.0178070068359375 102.0178070068359375 102.245635986328125 107.6595611572265625 111.08040618896484375 115.0298004150390625 120.0572509765625 120.9146728515625 127.00643157958984375 121.4854736328125 122.62890625 115.90087127685546875 108.07540130615234375 115.2243499755859375 124.075531005859375 128.444854736328125 126.59859466552734375 122.84383392333984375 119.70917510986328125 129.8962554931640625 132.85491943359375 132.43896484375 127.85936737060546875 119.08705902099609375 125.7241973876953125 131.726837158203125 132.73272705078125 135.282012939453125 129.8436126708984375 123.86263275146484375 118.65643310546875 126.1967315673828125 131.79962158203125 134.1387786865234375 136.8538055419921875 130.7123260498046875 132.2295074462890625 135.1729278564453125 132.1837310791015625 133.7996673583984375 119.65425872802734375 114.30924
 224853515625 117.7631988525390625 121.36092376708984375 119.9305877685546875 126.25859832763671875 126.120086669921875 126.68349456787109375 124.55065155029296875 127.889617919921875 128.0829620361328125 129.7009429931640625 124.8924560546875 117.626739501953125 119.609130859375 120.94362640380859375 128.2212677001953125 129.7179718017578125 125.782470703125 121.04027557373046875 121.92608642578125 125.954254150390625 127.030059814453125 123.33028411865234375 121.022674560546875 115.51631927490234375 103.60832977294921875 103.84874725341796875 104.024017333984375 105.601531982421875 109.09571075439453125 117.73581695556640625 119.7778472900390625 119.541015625 124.08742523193359375 129.4562225341796875 131.1428985595703125 127.66910552978515625 122.81090545654296875 120.95775604248046875 124.58786773681640625 121.71484375 115.53731536865234375 110.474700927734375 112.449188232421875 103.0435791015625 105.23883819580078125 108.97669219970703125 106.213958740234375 110.814826965332031
 25 111.490478515625 111.9340667724609375 112.93802642822265625 112.27043914794921875 111.01611328125 110.60611724853515625 110.11772918701171875 109.46514892578125 109.377716064453125 109.30493927001953125 109.40313720703125 110.02846527099609375 110.08058929443359375 101.83864593505859375 101.4153594970703125 102.84328460693359375 104.38396453857421875 99.3054351806640625 92.25455474853515625 88.07201385498046875 91.78017425537109375 87.9793701171875 82.5166473388671875 86.7332763671875 87.26824188232421875 81.363677978515625 79.6103973388671875 81.172119140625 83.4048919677734375 84.8563385009765625 94.329345703125 96.27008819580078125 97.949127197265625 97.25318145751953125 101.28208160400390625 102.177947998046875 94.952117919921875 93.70684814453125 91.68310546875 89.92278289794921875 88.5020599365234375 93.4508056640625 95.95111846923828125 98.38873291015625 98.16899871826171875 98.94673919677734375 101.74030303955078125 101.11362457275390625 102.79474639892578125 102.03634643
 5546875 98.41175079345703125 95.02388763427734375 92.48314666748046875
+ 108.6503448486328125 116.05881500244140625 122.16213226318359375 126.19905853271484375 123.48857879638671875 120.5373687744140625 114.3941802978515625 101.99407958984375 102.0224456787109375 108.74913787841796875 115.6740264892578125 120.31343841552734375 121.325775146484375 126.1343231201171875 124.40029144287109375 125.693450927734375 118.615966796875 112.72734832763671875 111.46974945068359375 111.31084442138671875 121.05989837646484375 125.698516845703125 125.6165618896484375 121.50841522216796875 115.99758148193359375 120.26396942138671875 131.3333892822265625 126.8597869873046875 127.73844146728515625 123.8306121826171875 118.215667724609375 126.88869476318359375 126.59072113037109375 128.6204071044921875 134.80181884765625 129.34698486328125 121.946044921875 116.98394775390625 120.73952484130859375 126.07427215576171875 131.927734375 127.982513427734375 125.05693817138671875 128.7960968017578125 134.444000244140625 138.191375732421875 132.5880279541015625 127.320304870605468
 75 113.041259765625 115.4400482177734375 114.824676513671875 121.80088043212890625 122.9644927978515625 121.51648712158203125 124.77498626708984375 122.84340667724609375 127.5795745849609375 126.17139434814453125 129.466888427734375 125.3649139404296875 117.53043365478515625 117.33065032958984375 121.9716949462890625 125.373779296875 126.006805419921875 127.3588104248046875 122.44158172607421875 120.2424468994140625 122.98455047607421875 123.36370086669921875 117.94260406494140625 118.50371551513671875 115.20092010498046875 105.3371429443359375 100.56116485595703125 107.08654022216796875 113.04314422607421875 112.20056915283203125 122.9686431884765625 124.18735504150390625 126.22072601318359375 124.36704254150390625 130.001617431640625 129.77984619140625 125.30849456787109375 121.229644775390625 117.4025115966796875 119.458343505859375 116.0784454345703125 116.11266326904296875 111.11162567138671875 105.46620941162109375 103.53682708740234375 101.719451904296875 101.2824554443359375
  106.63707733154296875 110.4399871826171875 111.035430908203125 105.90484619140625 108.44611358642578125 112.201934814453125 107.9550018310546875 107.7219085693359375 106.16468048095703125 106.2921905517578125 104.39125823974609375 108.27259063720703125 109.7502288818359375 110.25667572021484375 110.4441680908203125 104.8824462890625 102.06360626220703125 103.60724639892578125 102.9349822998046875 96.62908172607421875 93.82704925537109375 94.05565643310546875 94.2488861083984375 87.45270538330078125 83.86273956298828125 87.9847564697265625 91.55518341064453125 90.05849456787109375 79.96277618408203125 86.00592041015625 91.4803466796875 92.13584136962890625 92.6922149658203125 98.66461944580078125 102.71369171142578125 104.29273223876953125 100.5899200439453125 102.45068359375 101.20468902587890625 99.28932952880859375 98.532470703125 93.062255859375 91.86232757568359375 90.71120452880859375 99.078216552734375 102.47333526611328125 102.55776214599609375 101.62945556640625 100.4558792
 1142578125 99.1388092041015625 101.08689117431640625 99.52902984619140625 96.39160919189453125 94.26335906982421875 95.197601318359375
+ 106.5276336669921875 113.10210418701171875 117.8045654296875 121.44821929931640625 125.52007293701171875 121.03887176513671875 104.89208984375 101.95684051513671875 102.119476318359375 110.44024658203125 115.6872711181640625 118.47800445556640625 120.63427734375 126.1632537841796875 127.88518524169921875 126.97664642333984375 121.66733551025390625 116.9298553466796875 105.5870819091796875 114.46048736572265625 122.9150390625 121.0921173095703125 116.26979827880859375 113.51161956787109375 117.67244720458984375 124.62116241455078125 132.173309326171875 128.4075927734375 121.76435089111328125 115.540435791015625 116.726806640625 123.51058197021484375 129.117645263671875 132.2218170166015625 132.777801513671875 131.5747528076171875 125.65595245361328125 115.563385009765625 121.23380279541015625 128.4814605712890625 132.0079193115234375 126.17575836181640625 125.70497894287109375 133.412261962890625 135.4387969970703125 138.072601318359375 135.4857940673828125 131.1139068603515625 115.
 24709320068359375 111.77178192138671875 112.44174957275390625 119.062835693359375 119.4708251953125 121.88818359375 121.46988677978515625 121.9495391845703125 125.80449676513671875 125.96192169189453125 127.483306884765625 127.60015869140625 125.4068145751953125 117.071807861328125 117.19396209716796875 120.71053314208984375 124.44123077392578125 126.66131591796875 120.9777679443359375 116.41803741455078125 122.78668975830078125 120.0156097412109375 117.25885009765625 108.86724090576171875 110.6759490966796875 106.9315185546875 99.290313720703125 107.89502716064453125 115.56360626220703125 120.9784698486328125 120.9369354248046875 123.59412384033203125 125.883636474609375 127.43698883056640625 128.1163482666015625 127.20343017578125 122.33605194091796875 120.640045166015625 116.09780120849609375 113.33844757080078125 114.08563995361328125 115.41075897216796875 110.8786773681640625 107.5283203125 101.5353851318359375 99.8125152587890625 106.21639251708984375 108.4434967041015625 109.
 392547607421875 108.5203094482421875 105.5854339599609375 104.9762115478515625 109.14389801025390625 105.50738525390625 104.3857574462890625 104.08672332763671875 104.397735595703125 102.8428497314453125 106.92279052734375 109.2313232421875 110.4552154541015625 111.02060699462890625 109.37216949462890625 105.355194091796875 104.5151824951171875 103.45391082763671875 98.03050994873046875 97.82819366455078125 98.36336517333984375 94.10088348388671875 86.4140167236328125 86.06334686279296875 92.8225250244140625 94.11376190185546875 97.16251373291015625 83.9329376220703125 84.646240234375 91.3264007568359375 94.85713958740234375 99.0396575927734375 99.56697845458984375 104.0413970947265625 105.7913665771484375 104.578094482421875 104.1982574462890625 102.5494384765625 100.02597808837890625 96.25641632080078125 91.54088592529296875 96.7335662841796875 94.0562896728515625 95.0953216552734375 101.9544525146484375 100.410369873046875 97.95188140869140625 99.15960693359375 94.239128112792968
 75 99.1668243408203125 98.19066619873046875 92.353790283203125 88.67596435546875 96.26746368408203125
+ 103.6797027587890625 107.0944366455078125 110.86713409423828125 117.48871612548828125 123.7025299072265625 120.5233612060546875 104.814971923828125 101.93194580078125 103.00812530517578125 108.097686767578125 112.7468109130859375 120.169281005859375 122.04946136474609375 123.1888885498046875 122.4648284912109375 124.13481903076171875 114.5165863037109375 109.93511199951171875 104.6376190185546875 116.37204742431640625 119.42856597900390625 115.43987274169921875 109.7510528564453125 117.0175933837890625 123.96672821044921875 129.1206207275390625 133.1202392578125 128.1323089599609375 126.9053802490234375 115.3901519775390625 117.45821380615234375 123.03383636474609375 130.0009765625 128.4337158203125 128.904144287109375 127.04268646240234375 123.8739013671875 118.32062530517578125 118.14557647705078125 124.76232147216796875 129.7552032470703125 121.90392303466796875 125.19950103759765625 130.5902862548828125 133.1071929931640625 135.865478515625 125.99149322509765625 120.74310302734
 375 121.9334259033203125 111.34215545654296875 110.56586456298828125 112.92450714111328125 115.08538055419921875 118.947601318359375 116.16645050048828125 122.53589630126953125 120.53252410888671875 123.66887664794921875 126.13175201416015625 128.380889892578125 122.79814910888671875 116.1696929931640625 112.4655303955078125 117.306793212890625 123.09940338134765625 124.08724212646484375 117.36454010009765625 114.4004974365234375 121.05382537841796875 113.9677886962890625 110.6636962890625 106.8821258544921875 106.228118896484375 103.71338653564453125 101.33829498291015625 108.898773193359375 112.228118896484375 122.08113861083984375 124.05739593505859375 121.96913909912109375 122.4517059326171875 124.09680938720703125 123.97977447509765625 124.51003265380859375 119.84394073486328125 117.631011962890625 118.9571533203125 112.554840087890625 109.78375244140625 111.32662200927734375 111.5529937744140625 109.42070770263671875 104.84513092041015625 97.20986175537109375 103.8150634765625
  104.29825592041015625 105.94939422607421875 103.567230224609375 104.35312652587890625 102.66680145263671875 105.2273406982421875 102.3602447509765625 100.79239654541015625 99.24082183837890625 99.324981689453125 104.296234130859375 107.87837982177734375 109.108245849609375 110.31096649169921875 110.788818359375 109.8143768310546875 106.68888092041015625 106.00103759765625 101.63651275634765625 100.96962738037109375 101.8755035400390625 98.9824981689453125 93.39791107177734375 88.385589599609375 87.82036590576171875 93.82054901123046875 98.9006500244140625 99.57207489013671875 89.94991302490234375 82.02271270751953125 86.85308837890625 94.57022857666015625 93.18509674072265625 96.89954376220703125 101.48322296142578125 102.22501373291015625 105.45473480224609375 104.5230865478515625 100.6849822998046875 94.9396209716796875 93.62540435791015625 96.6219329833984375 100.6309814453125 100.4235687255859375 102.48383331298828125 103.18408966064453125 100.3326568603515625 94.29895782470703
 125 96.67462921142578125 92.6558837890625 97.368377685546875 96.5261383056640625 95.399444580078125 82.62584686279296875 90.9868927001953125
+ 102.66478729248046875 112.268280029296875 115.81304168701171875 122.6732330322265625 121.303741455078125 110.64995574951171875 101.86639404296875 101.922454833984375 101.90270233154296875 106.37117767333984375 111.3043670654296875 113.5153350830078125 114.343353271484375 116.2827606201171875 121.72801971435546875 119.07993316650390625 113.99988555908203125 104.16486358642578125 109.20897674560546875 115.967529296875 110.7865753173828125 108.128173828125 112.77768707275390625 116.08243560791015625 120.44367218017578125 125.08502197265625 131.0141448974609375 124.228179931640625 125.5422515869140625 114.49326324462890625 113.9524078369140625 124.8783111572265625 125.2672576904296875 124.5302886962890625 130.8524017333984375 132.1047210693359375 127.21807861328125 118.869293212890625 113.3229217529296875 123.50907135009765625 125.83901214599609375 117.33673858642578125 126.70478057861328125 130.7677001953125 134.5257415771484375 137.6071014404296875 134.14215087890625 134.022994995117
 1875 132.4283905029296875 125.41849517822265625 113.03668975830078125 109.964263916015625 111.2902984619140625 112.2949371337890625 117.86983489990234375 119.57086181640625 117.89594268798828125 123.05158233642578125 124.25951385498046875 125.0507049560546875 123.87851715087890625 115.02091217041015625 112.00814056396484375 117.8923797607421875 123.2009124755859375 122.51477813720703125 116.30162811279296875 113.051544189453125 119.133392333984375 118.9060821533203125 116.11652374267578125 111.960601806640625 101.70076751708984375 99.9453887939453125 99.53330230712890625 109.984619140625 113.2022705078125 120.57094573974609375 121.4390869140625 116.3251495361328125 119.5446624755859375 120.15654754638671875 119.88240814208984375 124.23673248291015625 116.997161865234375 111.5815582275390625 109.35626220703125 107.79090118408203125 106.8944244384765625 109.0424346923828125 108.4461822509765625 105.840240478515625 105.32599639892578125 95.83115386962890625 96.45977783203125 102.607475
 28076171875 103.14827728271484375 101.97597503662109375 101.2543182373046875 98.75241851806640625 100.25888824462890625 97.6485137939453125 97.6656951904296875 101.4574737548828125 104.3076019287109375 106.27577972412109375 106.81894683837890625 110.230133056640625 110.81615447998046875 110.66989898681640625 110.20436859130859375 108.50457763671875 105.9814910888671875 102.21913909912109375 103.5094451904296875 102.95023345947265625 100.18463134765625 94.2397613525390625 92.1692657470703125 92.37088775634765625 92.2765655517578125 101.48717498779296875 100.64064788818359375 94.15378570556640625 81.306640625 89.268035888671875 92.51731109619140625 98.7589263916015625 99.94387054443359375 103.3944091796875 104.4460906982421875 106.2341156005859375 104.10345458984375 98.3679046630859375 97.42774200439453125 100.39827728271484375 95.0842437744140625 102.27106475830078125 105.358612060546875 102.1758270263671875 99.3219451904296875 97.36054229736328125 95.8903961181640625 93.646888732910
 15625 91.09960174560546875 93.4965667724609375 91.57605743408203125 95.57222747802734375 90.784454345703125 83.9376373291015625
+ 101.983428955078125 111.91909027099609375 116.5142364501953125 124.78466796875 125.8249359130859375 113.0055999755859375 102.535888671875 101.89588165283203125 101.89588165283203125 104.4175872802734375 111.242340087890625 117.49211883544921875 119.54508209228515625 123.92125701904296875 125.6191558837890625 124.41440582275390625 115.58333587646484375 103.22728729248046875 106.8532257080078125 109.41144561767578125 108.20682525634765625 115.01305389404296875 121.50299835205078125 126.07965850830078125 130.049224853515625 130.8863372802734375 130.919891357421875 119.2559967041015625 119.03891754150390625 113.7634735107421875 115.08165740966796875 121.54718017578125 120.89687347412109375 126.16597747802734375 128.610565185546875 125.42235565185546875 118.3499603271484375 114.30014801025390625 112.2270965576171875 120.228363037109375 119.88472747802734375 116.6945037841796875 123.42603302001953125 128.0245361328125 128.1777191162109375 135.1121826171875 138.299957275390625 130.8012390
 13671875 124.2053070068359375 119.2878875732421875 114.62918853759765625 109.96715545654296875 108.60521697998046875 109.30023193359375 110.63232421875 116.317657470703125 118.38474273681640625 118.8688812255859375 122.96683502197265625 120.6147613525390625 119.7415771484375 111.40103912353515625 109.1456756591796875 117.112548828125 119.89234161376953125 120.8236541748046875 115.16962432861328125 111.14997100830078125 115.15093994140625 119.6743011474609375 120.724884033203125 114.02172088623046875 106.35076141357421875 100.88410186767578125 98.53818511962890625 106.895599365234375 113.79547882080078125 117.6243133544921875 113.42357635498046875 114.51983642578125 114.7812957763671875 114.750579833984375 122.34393310546875 125.4074249267578125 119.859771728515625 118.3623504638671875 113.076385498046875 108.12505340576171875 101.80467987060546875 104.14934539794921875 104.98914337158203125 104.85411834716796875 101.36779022216796875 98.11383056640625 93.77689361572265625 97.9884109
 4970703125 100.8971405029296875 98.6547393798828125 99.6115570068359375 97.7203521728515625 97.77105712890625 94.99394989013671875 99.012115478515625 104.52359771728515625 104.99201202392578125 105.57579803466796875 109.506072998046875 111.08599090576171875 110.297821044921875 109.3158111572265625 110.28728485107421875 110.33315277099609375 107.68904876708984375 104.271697998046875 106.18087005615234375 105.68149566650390625 101.1888580322265625 95.744415283203125 86.2730255126953125 93.0599822998046875 96.32318878173828125 97.07151031494140625 101.19942474365234375 95.21953582763671875 90.29114532470703125 84.9855499267578125 90.2255401611328125 98.034271240234375 100.97132110595703125 103.9443511962890625 102.4055938720703125 105.25946807861328125 104.42173004150390625 99.6959991455078125 100.59255218505859375 103.355316162109375 101.63687896728515625 103.817779541015625 106.0120849609375 99.65090179443359375 94.7757415771484375 91.032806396484375 90.56565093994140625 92.191131591
 796875 90.978057861328125 90.58647918701171875 91.04111480712890625 94.35227203369140625 95.1380157470703125 86.18173980712890625
+ 102.11679840087890625 109.23017120361328125 119.13315582275390625 124.29302215576171875 125.62351226806640625 120.702178955078125 107.967193603515625 101.8653411865234375 101.8633270263671875 106.34686279296875 111.59506988525390625 118.0806121826171875 122.6536865234375 125.02437591552734375 125.01087188720703125 122.75185394287109375 117.472869873046875 109.715301513671875 101.6972503662109375 104.32505035400390625 112.41403961181640625 119.37393951416015625 122.79438018798828125 124.7514801025390625 129.8723602294921875 132.261138916015625 130.2093353271484375 125.730194091796875 119.2368621826171875 112.47051239013671875 111.2760467529296875 114.28885650634765625 118.1387481689453125 123.7032928466796875 127.35768890380859375 130.5417938232421875 124.5178985595703125 117.87578582763671875 109.61077117919921875 118.04868316650390625 112.6407470703125 115.384796142578125 119.01755523681640625 125.56592559814453125 127.2639312744140625 133.792205810546875 137.9820098876953125 136.
 5472259521484375 128.962066650390625 130.2459564208984375 127.04021453857421875 122.6151580810546875 109.3260955810546875 107.8022918701171875 107.86249542236328125 109.948516845703125 117.894287109375 115.762115478515625 119.08335113525390625 117.35372161865234375 114.9900970458984375 112.19122314453125 105.994354248046875 111.03838348388671875 117.791534423828125 117.5780029296875 114.0701904296875 109.367340087890625 114.47235107421875 116.90447235107421875 117.8774566650390625 110.4706573486328125 105.395294189453125 98.04582977294921875 96.90552520751953125 107.39891815185546875 109.63326263427734375 109.00324249267578125 109.07569122314453125 109.1668853759765625 115.74010467529296875 119.87751007080078125 123.3083038330078125 125.11176300048828125 122.080322265625 118.51299285888671875 114.3668670654296875 113.941192626953125 104.317047119140625 102.396697998046875 97.89591217041015625 96.18520355224609375 98.00310516357421875 97.80762481689453125 93.43019866943359375 96.8919
 7540283203125 98.05239105224609375 95.7110748291015625 99.6013641357421875 99.385894775390625 96.69080352783203125 92.9600982666015625 98.5392303466796875 101.70709228515625 101.23007965087890625 103.69055938720703125 108.4645538330078125 107.1687164306640625 104.4354705810546875 106.02765655517578125 109.50548553466796875 110.28197479248046875 107.97835540771484375 106.9194488525390625 105.60986328125 105.2559661865234375 101.198883056640625 96.06116485595703125 95.59002685546875 95.64212799072265625 97.8431243896484375 99.99616241455078125 103.10312652587890625 97.56122589111328125 88.84833526611328125 88.85163116455078125 93.00318145751953125 92.58447265625 98.23134613037109375 98.76668548583984375 107.1340484619140625 105.358856201171875 104.4911956787109375 102.79177093505859375 105.25438690185546875 106.46013641357421875 102.36138916015625 104.71572113037109375 107.390777587890625 104.6704254150390625 99.08477020263671875 93.85773468017578125 89.18780517578125 86.8407287597656
 25 84.17746734619140625 86.79463958740234375 85.21570587158203125 90.631134033203125 92.6138458251953125 85.49494171142578125
+ 105.6492462158203125 115.53569793701171875 119.6066741943359375 122.53681182861328125 120.27553558349609375 120.25637054443359375 116.25379180908203125 101.83492279052734375 101.83483123779296875 101.97942352294921875 109.85219573974609375 117.08889007568359375 120.39864349365234375 123.130645751953125 121.9128570556640625 119.496063232421875 119.819091796875 116.29970550537109375 102.30931854248046875 107.7853851318359375 114.27394866943359375 116.924285888671875 116.686920166015625 125.14116668701171875 129.38720703125 130.8294830322265625 124.0952911376953125 122.10434722900390625 120.1580810546875 112.58934783935546875 109.31674957275390625 114.706451416015625 123.05684661865234375 127.9852752685546875 129.433746337890625 129.0604248046875 123.48429107666015625 117.70623016357421875 108.24072265625 111.30838775634765625 117.507904052734375 123.76523590087890625 127.31201934814453125 129.1327667236328125 134.3199462890625 134.5743255615234375 133.2447967529296875 136.37712097167
 96875 133.9193115234375 136.462982177734375 135.474212646484375 123.58892822265625 123.89495849609375 113.99510955810546875 106.38636016845703125 108.71358489990234375 108.5933837890625 109.98346710205078125 109.190338134765625 113.32195281982421875 111.3481597900390625 106.512176513671875 105.10352325439453125 109.9535064697265625 112.7267608642578125 114.86266326904296875 110.48189544677734375 109.02986907958984375 114.35296630859375 120.5122528076171875 116.52465057373046875 109.77429962158203125 109.209014892578125 106.3878936767578125 97.49973297119140625 100.6529388427734375 100.14284515380859375 105.270660400390625 110.69896697998046875 114.69878387451171875 116.35616302490234375 118.297271728515625 121.3615570068359375 124.31829071044921875 122.28491973876953125 121.11083221435546875 118.0894012451171875 114.95819854736328125 111.03629302978515625 108.03287506103515625 101.8348541259765625 101.8761138916015625 97.45885467529296875 94.52698516845703125 92.20684051513671875 93
 .23111724853515625 96.27059173583984375 93.5146636962890625 97.9866485595703125 98.28746795654296875 95.81163787841796875 93.20461273193359375 95.17870330810546875 98.14466094970703125 102.5460052490234375 104.54961395263671875 107.5476531982421875 102.93009185791015625 101.57000732421875 106.37009429931640625 110.5951080322265625 107.69449615478515625 105.97772216796875 105.03460693359375 105.0628509521484375 104.68985748291015625 97.451751708984375 91.587615966796875 95.3779754638671875 94.33835601806640625 97.963958740234375 97.8578338623046875 96.01216888427734375 93.5246734619140625 90.59981536865234375 91.95392608642578125 96.36496734619140625 99.59098052978515625 97.60073089599609375 93.99652099609375 97.97332000732421875 101.59600067138671875 105.1387939453125 107.4709014892578125 108.03177642822265625 108.88469696044921875 103.70208740234375 107.06417083740234375 105.9948883056640625 103.5963592529296875 101.86943817138671875 97.17934417724609375 91.886138916015625 93.49382
 781982421875 87.355072021484375 85.19919586181640625 80.89400482177734375 79.8146209716796875 86.7082977294921875 81.83245849609375
+ 106.34334564208984375 114.30757904052734375 116.10546112060546875 117.9226531982421875 115.27126312255859375 115.16249847412109375 113.01151275634765625 101.80443572998046875 101.80443572998046875 101.85050201416015625 108.90943145751953125 114.99724578857421875 120.1730804443359375 122.93473052978515625 119.408477783203125 117.51563262939453125 117.07216644287109375 116.67718505859375 103.693084716796875 103.90924072265625 106.2334747314453125 108.663848876953125 119.75966644287109375 124.99362945556640625 126.95987701416015625 128.3228302001953125 125.0467071533203125 119.8102264404296875 114.0957794189453125 108.98613739013671875 108.1847686767578125 115.008209228515625 117.73394775390625 122.6132049560546875 125.94593048095703125 121.3879241943359375 119.839202880859375 114.06813812255859375 108.15198516845703125 113.89385986328125 118.97953033447265625 119.68609619140625 121.21665191650390625 124.7459869384765625 131.1403350830078125 136.502716064453125 130.982025146484375 133
 .4014892578125 134.4582366943359375 137.4234771728515625 137.0823822021484375 135.276397705078125 131.5540008544921875 126.2982025146484375 106.88608551025390625 105.23268890380859375 104.87579345703125 104.84827423095703125 103.965118408203125 107.16129302978515625 106.850494384765625 104.59218597412109375 102.36792755126953125 106.9676055908203125 105.858245849609375 107.347869873046875 106.20346832275390625 111.2381744384765625 118.0927734375 119.19083404541015625 117.28614044189453125 112.6647796630859375 114.33777618408203125 107.67058563232421875 95.39151763916015625 97.8528594970703125 105.7086181640625 109.04399871826171875 112.94817352294921875 110.38887786865234375 113.59052276611328125 116.44014739990234375 122.24341583251953125 122.56768798828125 121.536102294921875 119.43367767333984375 118.2200927734375 112.17348480224609375 107.92795562744140625 105.3704376220703125 108.71970367431640625 108.082611083984375 104.8347320556640625 100.87215423583984375 98.884483337402343
 75 89.92537689208984375 90.02425384521484375 93.4937744140625 92.99938201904296875 97.0739898681640625 94.86910247802734375 91.80938720703125 96.33689117431640625 100.6123199462890625 100.1786956787109375 103.03460693359375 104.07466888427734375 99.10784149169921875 100.24727630615234375 106.069305419921875 109.7333831787109375 108.233428955078125 104.5865478515625 100.46429443359375 103.30289459228515625 98.13904571533203125 92.31082916259765625 95.18804168701171875 97.4616241455078125 95.4344635009765625 99.4328460693359375 99.4149932861328125 96.6599884033203125 93.08526611328125 96.6070709228515625 93.856719970703125 96.8195648193359375 93.7666473388671875 99.9106597900390625 97.57990264892578125 100.14212799072265625 102.93614959716796875 104.19870758056640625 104.2065582275390625 113.0218353271484375 111.092193603515625 109.49871063232421875 107.05487823486328125 102.17376708984375 98.87624359130859375 95.97499847412109375 93.62688446044921875 95.643310546875 89.7606201171875
 89.72806549072265625 86.58760833740234375 90.6513671875 89.68775177001953125 78.75154876708984375 77.3968963623046875
+ 108.428924560546875 112.8332366943359375 113.2501220703125 113.885772705078125 110.95215606689453125 110.06158447265625 107.200592041015625 102.584014892578125 101.77223968505859375 101.773956298828125 108.72592926025390625 114.47226715087890625 119.4448089599609375 121.413665771484375 120.51006317138671875 114.20824432373046875 112.34686279296875 114.20220184326171875 99.02361297607421875 105.7442474365234375 114.51845550537109375 119.59236907958984375 120.93042755126953125 120.2899627685546875 122.34488677978515625 127.13422393798828125 121.8990478515625 118.94925689697265625 115.81145477294921875 105.30236053466796875 111.4557037353515625 117.96752166748046875 122.63935089111328125 125.18495941162109375 124.77484130859375 123.9309234619140625 116.22982025146484375 110.3262481689453125 106.8518524169921875 109.20134735107421875 113.00142669677734375 116.8047637939453125 122.6880035400390625 130.32421875 134.73138427734375 136.1357421875 133.7450714111328125 129.709808349609375 13
 1.566558837890625 133.1357421875 135.418670654296875 136.281097412109375 135.7766265869140625 128.1276092529296875 118.89885711669921875 106.5501556396484375 116.225555419921875 105.0538330078125 102.6578369140625 101.46726226806640625 101.10414886474609375 100.731475830078125 100.6324462890625 102.1681671142578125 104.523284912109375 106.43306732177734375 105.0225982666015625 111.60675811767578125 117.0930938720703125 116.31801605224609375 114.15345001220703125 115.61389923095703125 114.25008392333984375 104.63306427001953125 94.3497314453125 98.839080810546875 103.689697265625 109.14147186279296875 109.2079315185546875 109.659759521484375 113.02135467529296875 116.49248504638671875 121.46829986572265625 119.5835418701171875 120.2417144775390625 120.12107086181640625 116.2288665771484375 114.39469146728515625 113.25799560546875 107.220672607421875 111.96150970458984375 106.178192138671875 106.55567169189453125 103.4225616455078125 98.83972930908203125 89.8712158203125 88.3755569458
 0078125 88.9393768310546875 92.71208953857421875 93.34763336181640625 90.46150970458984375 92.9625244140625 98.417938232421875 98.981048583984375 95.900177001953125 99.4013824462890625 99.38498687744140625 99.16730499267578125 102.72510528564453125 106.30129241943359375 108.70569610595703125 109.57263946533203125 103.98448944091796875 100.9302215576171875 93.7865142822265625 94.74027252197265625 93.20355987548828125 100.27744293212890625 100.4013824462890625 98.24285125732421875 101.2012481689453125 101.01517486572265625 97.6782989501953125 98.884490966796875 99.30480194091796875 91.19634246826171875 98.97328948974609375 97.61469268798828125 99.31166839599609375 102.67588043212890625 104.37201690673828125 107.41579437255859375 104.944366455078125 110.20415496826171875 111.55175018310546875 109.31055450439453125 107.7696380615234375 106.726898193359375 104.38047027587890625 102.04636383056640625 101.59833526611328125 98.51505279541015625 93.77384185791015625 92.464263916015625 93.425
 81939697265625 88.55899810791015625 93.77205657958984375 90.0169830322265625 82.2722625732421875 80.0836181640625
+ 105.99932861328125 110.58469390869140625 107.533050537109375 109.4827117919921875 108.75981903076171875 108.68658447265625 106.238861083984375 104.6750946044921875 101.7900390625 101.78290557861328125 103.58563995361328125 111.7682647705078125 114.27523040771484375 115.8413238525390625 115.27005767822265625 108.66165924072265625 108.69342803955078125 109.8182220458984375 97.834716796875 106.5946502685546875 113.61948394775390625 117.73113250732421875 116.6786651611328125 116.48154449462890625 122.3002166748046875 124.99710845947265625 121.70578765869140625 118.4005584716796875 111.7770233154296875 105.03409576416015625 112.16979217529296875 113.814361572265625 115.80339813232421875 121.3677825927734375 128.107940673828125 124.45697784423828125 120.63489532470703125 114.6819000244140625 105.09217071533203125 114.274871826171875 120.37259674072265625 124.69683074951171875 127.6085052490234375 129.1102294921875 132.5732269287109375 129.858001708984375 133.2724151611328125 130.94371032
 71484375 125.27439117431640625 131.127593994140625 132.72100830078125 133.7634735107421875 133.166351318359375 120.86765289306640625 120.60198974609375 119.58014678955078125 117.008514404296875 116.328369140625 107.01703643798828125 102.14615631103515625 107.32154083251953125 101.68766021728515625 98.4205780029296875 100.3729248046875 101.79547882080078125 102.80706024169921875 107.03780364990234375 110.9857940673828125 113.26988983154296875 113.21630859375 110.86492156982421875 114.99961090087890625 114.06781005859375 102.0877685546875 94.5516815185546875 94.42819976806640625 102.38834381103515625 106.7088165283203125 100.79123687744140625 106.83791351318359375 112.53464508056640625 118.21161651611328125 118.62621307373046875 117.30181121826171875 118.2145843505859375 120.93228912353515625 117.544036865234375 113.56952667236328125 111.71968841552734375 113.43297576904296875 110.6979522705078125 105.42501068115234375 101.510101318359375 97.32035064697265625 97.82903289794921875 92.3
 392333984375 91.55611419677734375 88.116455078125 90.14435577392578125 91.44666290283203125 88.38687896728515625 94.28289031982421875 94.930938720703125 92.4050445556640625 92.24840545654296875 92.5885772705078125 95.26601409912109375 100.2008056640625 103.33293914794921875 106.82971954345703125 108.10437774658203125 109.0570526123046875 107.05072021484375 105.26183319091796875 96.6232757568359375 102.79090118408203125 94.1080474853515625 104.21973419189453125 105.75836181640625 103.15172576904296875 102.13311767578125 102.6604766845703125 96.56671142578125 101.10132598876953125 100.8741302490234375 95.94667816162109375 98.26113128662109375 98.33617401123046875 100.79225921630859375 103.84265899658203125 107.27289581298828125 111.24277496337890625 103.99806976318359375 111.8634033203125 109.96783447265625 106.66767120361328125 104.5396575927734375 105.5619964599609375 102.82816314697265625 99.6248321533203125 98.9096221923828125 98.47118377685546875 97.0970611572265625 95.3075790405
 2734375 92.86009979248046875 93.3805084228515625 87.05008697509765625 84.20015716552734375 78.144683837890625 86.3051300048828125
+ 100.4468994140625 99.7443695068359375 102.37100982666015625 104.1125335693359375 102.47925567626953125 103.43689727783203125 106.63278961181640625 99.7772369384765625 99.75022125244140625 99.76982879638671875 105.180206298828125 110.906402587890625 110.46620941162109375 110.1348876953125 107.54878997802734375 105.5117034912109375 106.300537109375 102.46518707275390625 97.56600189208984375 103.07042694091796875 109.20922088623046875 111.01880645751953125 111.8428497314453125 118.7249755859375 120.40995025634765625 122.06600189208984375 119.92728424072265625 111.844482421875 105.90688323974609375 105.34305572509765625 111.1676788330078125 114.6236419677734375 119.9166412353515625 125.01897430419921875 125.43383026123046875 118.1432647705078125 115.7863922119140625 112.23016357421875 104.1368865966796875 111.97274017333984375 118.6071624755859375 124.31456756591796875 124.49308013916015625 129.0522613525390625 129.537200927734375 126.9795684814453125 129.247711181640625 121.8101654052
 734375 126.34418487548828125 132.4730682373046875 135.011199951171875 131.212982177734375 130.6726226806640625 130.076873779296875 125.62164306640625 123.41841888427734375 125.3726959228515625 121.00617218017578125 106.58577728271484375 111.03884124755859375 116.06626129150390625 113.48757171630859375 98.6545257568359375 98.0831298828125 100.12432861328125 100.3325653076171875 106.33731842041015625 109.29953765869140625 108.37578582763671875 107.4636383056640625 109.72582244873046875 111.1654815673828125 111.48921966552734375 109.8329620361328125 96.64435577392578125 93.1700897216796875 94.15003204345703125 96.73040008544921875 106.1398773193359375 108.49774169921875 108.76361846923828125 114.000030517578125 114.56348419189453125 113.54840850830078125 118.5256805419921875 119.507232666015625 117.8170013427734375 111.90103912353515625 113.56642913818359375 115.25180816650390625 110.45117950439453125 107.9129791259765625 103.974517822265625 99.92781829833984375 94.3202056884765625 99.
 60123443603515625 97.16312408447265625 87.21593475341796875 88.11785125732421875 87.78116607666015625 87.85532379150390625 88.84442901611328125 88.927490234375 93.52654266357421875 93.8436279296875 98.10492706298828125 94.461639404296875 96.9950103759765625 100.03807830810546875 101.64188385009765625 104.625762939453125 107.87010955810546875 107.3070220947265625 105.06163787841796875 100.7982330322265625 106.23095703125 97.2930908203125 105.49500274658203125 105.97785186767578125 103.8785247802734375 103.5785369873046875 105.205841064453125 99.75511932373046875 104.67810821533203125 103.42813873291015625 97.769500732421875 97.14769744873046875 98.01247406005859375 100.21407318115234375 103.714202880859375 109.0374298095703125 111.2397308349609375 110.66977691650390625 107.30802154541015625 105.9290313720703125 105.9974212646484375 100.30097198486328125 103.38709259033203125 100.389373779296875 98.55944061279296875 94.34747314453125 95.08127593994140625 95.1537017822265625 90.8993530
 2734375 91.85301971435546875 92.49758148193359375 83.80092620849609375 82.1820068359375 85.85870361328125 88.17572021484375
+ 95.83142852783203125 96.41802215576171875 97.11409759521484375 98.377044677734375 99.23792266845703125 100.45145416259765625 100.9786834716796875 103.53655242919921875 99.30220794677734375 99.45989227294921875 104.26523590087890625 107.3625030517578125 105.98925018310546875 104.018951416015625 107.6670989990234375 104.9168701171875 102.87541961669921875 102.75293731689453125 96.27727508544921875 98.84777069091796875 103.90984344482421875 112.50116729736328125 116.5254669189453125 116.701141357421875 115.89412689208984375 120.5052337646484375 118.35518646240234375 111.69753265380859375 103.357574462890625 109.95433807373046875 116.401031494140625 118.04541778564453125 119.7823486328125 120.44345855712890625 122.408203125 117.622406005859375 110.22936248779296875 110.4020233154296875 103.372894287109375 113.880645751953125 120.89344024658203125 122.83187103271484375 120.56291961669921875 126.26027679443359375 122.835235595703125 119.5230255126953125 118.52207183837890625 123.28217315
 673828125 131.54083251953125 131.4333648681640625 135.955108642578125 131.4443359375 129.1263885498046875 125.62105560302734375 126.93045806884765625 128.99530029296875 124.9854278564453125 115.1098480224609375 109.5757293701171875 118.38016510009765625 121.22701263427734375 116.958160400390625 114.19689178466796875 97.789947509765625 98.5482635498046875 98.94432830810546875 103.7773590087890625 105.6103668212890625 106.600555419921875 105.7625885009765625 108.53891754150390625 106.87580108642578125 109.1400299072265625 108.57120513916015625 99.85239410400390625 94.84369659423828125 92.64697265625 102.83045196533203125 104.2201385498046875 102.71539306640625 109.4671478271484375 110.46630859375 113.241241455078125 111.5162506103515625 113.93752288818359375 115.73435211181640625 115.28475189208984375 112.75690460205078125 108.490020751953125 113.4905548095703125 111.0248260498046875 104.246826171875 101.5789794921875 98.3408660888671875 98.78884124755859375 98.4730682373046875 95.954
 24652099609375 91.05620574951171875 86.06977081298828125 86.67987823486328125 86.4659271240234375 95.83858489990234375 98.3850860595703125 97.1656036376953125 98.545654296875 100.85813140869140625 101.58617401123046875 103.134002685546875 103.40264129638671875 104.291839599609375 104.7898101806640625 109.0035858154296875 109.96346282958984375 109.421417236328125 106.85131072998046875 108.5520782470703125 102.25048065185546875 107.3462982177734375 108.32794952392578125 107.31188201904296875 108.45122528076171875 108.02561187744140625 104.11292266845703125 107.15334320068359375 98.398895263671875 97.8078155517578125 102.99608612060546875 95.94915771484375 102.4265289306640625 104.3139495849609375 107.52027130126953125 114.247344970703125 108.38149261474609375 105.4960174560546875 102.9452667236328125 99.26412200927734375 97.44979095458984375 99.43750762939453125 96.82242584228515625 98.23069000244140625 92.63238525390625 92.3469390869140625 94.27066802978515625 88.984130859375 88.3954
 2388916015625 86.3336029052734375 82.998016357421875 93.9124603271484375 90.2276458740234375 96.30123138427734375
+ 95.830078125 95.75226593017578125 95.37371063232421875 96.36122894287109375 96.83536529541015625 98.26573944091796875 98.2171783447265625 99.52927398681640625 95.10182952880859375 95.98036956787109375 100.3425140380859375 104.10614013671875 104.42391204833984375 101.42719268798828125 103.14910125732421875 103.99745941162109375 100.7295684814453125 100.6796417236328125 96.21083831787109375 99.86714935302734375 107.76436614990234375 111.50372314453125 113.89675140380859375 114.63330078125 111.34259796142578125 116.6162261962890625 117.9114837646484375 113.011505126953125 100.9786529541015625 108.9989166259765625 112.55066680908203125 110.7121124267578125 114.46134185791015625 119.77154541015625 119.39943695068359375 115.74903106689453125 110.70944976806640625 104.1261749267578125 104.6975860595703125 113.6298980712890625 119.8667449951171875 121.01940155029296875 113.33094024658203125 115.08766937255859375 117.80023956298828125 120.6345672607421875 129.250274658203125 129.18830871582
 03125 128.0207977294921875 136.5941925048828125 137.2877197265625 131.8481903076171875 132.4077606201171875 127.28731536865234375 119.93121337890625 121.9385833740234375 115.16899871826171875 111.6049346923828125 113.61186981201171875 121.4812774658203125 123.94077301025390625 116.2859954833984375 103.9084625244140625 97.662811279296875 97.5462646484375 96.986328125 99.6260528564453125 104.76593017578125 103.01770782470703125 105.4769134521484375 105.793609619140625 104.547027587890625 106.98925018310546875 106.048583984375 103.89421844482421875 98.25726318359375 91.9742584228515625 94.50586700439453125 99.16339874267578125 107.9697265625 113.6392059326171875 115.1128692626953125 113.60504150390625 109.5821075439453125 109.7165985107421875 110.0082550048828125 113.1062469482421875 109.9214630126953125 107.1692047119140625 110.1606597900390625 109.55463409423828125 106.597747802734375 105.37297821044921875 102.41651153564453125 98.67618560791015625 93.54563140869140625 92.51689147949
 21875 90.4435882568359375 87.50101470947265625 88.63616180419921875 94.39452362060546875 96.07233428955078125 97.3263397216796875 99.05892181396484375 100.51088714599609375 102.17826080322265625 102.705413818359375 103.96811676025390625 104.5101165771484375 105.48822021484375 107.17437744140625 110.192718505859375 109.1431884765625 108.99765777587890625 109.035186767578125 109.11034393310546875 108.439910888671875 109.14722442626953125 108.968475341796875 107.68732452392578125 108.12505340576171875 107.77309417724609375 108.88080596923828125 109.3742218017578125 104.62164306640625 106.4896392822265625 105.16728973388671875 100.26446533203125 108.165008544921875 111.50205230712890625 110.02918243408203125 112.48778533935546875 111.46051788330078125 108.3842620849609375 103.40467071533203125 102.47888946533203125 98.5354156494140625 93.80147552490234375 93.58315277099609375 92.88217926025390625 91.49581146240234375 90.2537841796875 93.472564697265625 91.31826019287109375 85.4831542968
 75 82.81800079345703125 91.36559295654296875 93.0457611083984375 91.76383209228515625 96.2117156982421875
+ 95.49999237060546875 95.785491943359375 95.59201812744140625 95.11251068115234375 94.69126129150390625 95.032867431640625 97.25428009033203125 97.5050811767578125 95.72426605224609375 95.0631866455078125 98.52449798583984375 102.4396209716796875 98.0775146484375 100.37636566162109375 100.966217041015625 102.34857177734375 99.1947174072265625 102.336883544921875 94.87862396240234375 100.5173187255859375 106.57495880126953125 108.376739501953125 109.74608612060546875 110.5877838134765625 108.6633758544921875 113.26983642578125 114.244140625 109.358154296875 99.77660369873046875 105.27683258056640625 109.0508270263671875 115.53583526611328125 120.682403564453125 120.66136932373046875 119.9247283935546875 117.6887969970703125 110.81780242919921875 101.918121337890625 105.47711181640625 110.97601318359375 120.49996185302734375 116.19720458984375 108.51116180419921875 115.4783935546875 120.65169525146484375 127.40175628662109375 135.42095947265625 137.5352020263671875 136.661392211914062
 5 137.1705169677734375 134.1864471435546875 129.1752777099609375 132.775238037109375 132.3816070556640625 130.181671142578125 119.7561187744140625 122.35550689697265625 119.75705718994140625 122.1350860595703125 123.52337646484375 117.7877960205078125 113.11346435546875 114.73299407958984375 116.1444091796875 97.4842376708984375 95.76284027099609375 97.29813385009765625 101.30402374267578125 100.13404083251953125 102.50853729248046875 102.455810546875 100.82354736328125 102.43264007568359375 104.57645416259765625 100.6999053955078125 98.07141876220703125 91.30088043212890625 92.2895965576171875 102.9100341796875 108.3858489990234375 108.99385833740234375 110.052703857421875 112.3412628173828125 108.5338134765625 104.6074066162109375 109.78119659423828125 110.24492645263671875 106.55194091796875 108.6573944091796875 107.47216796875 106.19354248046875 102.03191375732421875 100.9271697998046875 96.14968109130859375 93.52629852294921875 91.53633880615234375 91.03021240234375 86.76222229
 00390625 85.07277679443359375 85.32238006591796875 91.998626708984375 93.61449432373046875 96.08221435546875 98.026824951171875 100.29650115966796875 102.67748260498046875 102.6490631103515625 103.28749847412109375 103.2696533203125 105.50896453857421875 108.7286376953125 108.363189697265625 106.99834442138671875 106.63358306884765625 107.84693145751953125 107.35256195068359375 107.613525390625 107.5189666748046875 105.6938934326171875 105.018218994140625 105.12532806396484375 108.16036224365234375 108.5853118896484375 109.9662628173828125 108.72359466552734375 107.96199798583984375 109.533935546875 100.24614715576171875 108.64250946044921875 113.63214111328125 113.90402984619140625 114.97412872314453125 110.890411376953125 109.03545379638671875 103.07775115966796875 100.5089874267578125 99.98883819580078125 97.4232177734375 95.04845428466796875 91.904815673828125 89.5659942626953125 86.9866485595703125 87.721588134765625 87.17665863037109375 83.50748443603515625 92.3868789672851562
 5 96.6740875244140625 97.9066162109375 92.83953857421875 96.195220947265625
+ 96.20619964599609375 96.35231781005859375 95.099517822265625 94.2712860107421875 94.73212432861328125 94.38292694091796875 95.0439453125 94.06488800048828125 96.1473541259765625 95.1239166259765625 95.63431549072265625 96.18480682373046875 95.23685455322265625 96.03469085693359375 95.7398223876953125 95.90320587158203125 97.0801544189453125 100.6519927978515625 94.06987762451171875 101.519287109375 104.4047088623046875 102.5739593505859375 106.93212890625 106.89839935302734375 106.89630126953125 111.5076446533203125 111.3175506591796875 106.9614105224609375 99.2124176025390625 110.6364593505859375 116.4141387939453125 117.2422943115234375 118.17784881591796875 114.18670654296875 117.260345458984375 115.52101898193359375 109.37870025634765625 101.9049835205078125 105.81517791748046875 115.17201995849609375 115.95433807373046875 106.5948486328125 114.7979583740234375 117.2263336181640625 122.2629547119140625 129.544219970703125 132.5989837646484375 135.688934326171875 136.89817810058
 59375 134.88671875 131.1908111572265625 125.17536163330078125 129.55718994140625 129.923248291015625 128.2474365234375 126.89453887939453125 124.83344268798828125 122.57555389404296875 127.6821441650390625 124.585906982421875 119.9598236083984375 121.7444000244140625 120.25850677490234375 116.46321868896484375 113.93717193603515625 96.03614044189453125 95.92578887939453125 97.54593658447265625 98.77962493896484375 99.68747711181640625 100.29155731201171875 100.03107452392578125 100.5723114013671875 101.22985076904296875 98.23270416259765625 95.77661895751953125 90.65682220458984375 90.726287841796875 97.37311553955078125 101.142822265625 105.52205657958984375 109.39591217041015625 105.891571044921875 107.22882843017578125 103.371368408203125 109.84912872314453125 107.540618896484375 105.5837860107421875 105.0387725830078125 106.71685028076171875 103.70025634765625 103.1662445068359375 101.35587310791015625 99.343292236328125 97.8880157470703125 97.7845611572265625 93.869277954101562
 5 84.54107666015625 84.453826904296875 88.333587646484375 89.6495361328125 92.98770904541015625 92.6511383056640625 97.9669342041015625 98.6553802490234375 100.15721893310546875 101.00904083251953125 103.23850250244140625 103.34221649169921875 105.5104217529296875 109.25037384033203125 107.45275115966796875 107.7186126708984375 107.63959503173828125 107.73839569091796875 106.9145050048828125 106.00537872314453125 105.28528594970703125 104.08672332763671875 103.879180908203125 104.8019866943359375 105.83026885986328125 106.4488983154296875 109.49251556396484375 108.52008819580078125 109.02529144287109375 109.39361572265625 103.8998260498046875 110.02074432373046875 110.57505035400390625 110.4466094970703125 111.18981170654296875 109.932769775390625 106.7906646728515625 103.85335540771484375 101.68444061279296875 98.37305450439453125 94.35736083984375 92.026763916015625 93.36237335205078125 91.09587860107421875 87.41106414794921875 84.589080810546875 83.78102874755859375 90.7726745605
 46875 98.46741485595703125 102.18183135986328125 103.9028778076171875 100.32810211181640625 98.260345458984375
+ 114.8211822509765625 100.961273193359375 103.7197418212890625 94.86704254150390625 94.41963958740234375 94.368865966796875 93.2117919921875 95.117889404296875 94.320037841796875 94.05471038818359375 94.12625885009765625 94.569915771484375 94.73639678955078125 94.8470001220703125 94.52669525146484375 94.0880889892578125 94.426544189453125 93.3774261474609375 93.3438873291015625 99.87920379638671875 99.61824798583984375 100.110595703125 102.462921142578125 100.9293365478515625 103.26964569091796875 107.88262176513671875 108.39005279541015625 104.7783660888671875 99.43619537353515625 108.82708740234375 115.1868438720703125 111.46793365478515625 110.69823455810546875 113.08795928955078125 117.424163818359375 111.434661865234375 104.05222320556640625 100.37552642822265625 106.19254302978515625 105.57521820068359375 102.56098175048828125 109.87334442138671875 115.6196441650390625 124.80126190185546875 129.138519287109375 131.6895294189453125 127.43587493896484375 126.8704833984375 129.63
 17901611328125 133.801055908203125 127.2358551025390625 120.93476104736328125 126.21189117431640625 130.172332763671875 132.6988983154296875 128.9150848388671875 129.248992919921875 127.8603057861328125 130.33563232421875 129.5557098388671875 128.6833648681640625 123.4181976318359375 114.19134521484375 105.52211761474609375 101.54998779296875 96.15378570556640625 95.10305023193359375 95.59832763671875 96.49468231201171875 98.03282928466796875 99.23748016357421875 96.84685516357421875 96.25363922119140625 98.7737579345703125 95.67960357666015625 94.0960845947265625 90.45084381103515625 89.66046905517578125 90.37975311279296875 98.78981781005859375 104.225921630859375 108.037200927734375 100.09029388427734375 100.7318267822265625 105.90450286865234375 109.80556488037109375 104.57077789306640625 105.10675048828125 100.007476806640625 108.0489959716796875 104.2507476806640625 98.704620361328125 102.0936279296875 102.41670989990234375 100.6879119873046875 100.95977783203125 94.1899032592
 7734375 83.70257568359375 84.1185150146484375 90.62355804443359375 90.9594879150390625 92.26367950439453125 90.6570281982421875 94.1977386474609375 94.84690093994140625 94.50746917724609375 103.32877349853515625 103.3133544921875 102.9028472900390625 106.10302734375 108.16823577880859375 105.37306976318359375 105.381072998046875 104.9722442626953125 104.30379486083984375 103.58782958984375 103.6726531982421875 104.07328033447265625 102.85295867919921875 102.164581298828125 104.6170196533203125 104.0546875 103.84421539306640625 107.64199066162109375 106.3109588623046875 108.0106201171875 107.99703216552734375 105.00323486328125 110.32729339599609375 111.26987457275390625 110.32330322265625 109.388946533203125 108.60556793212890625 106.11766815185546875 101.00429534912109375 97.5750274658203125 96.15442657470703125 97.4810333251953125 97.69332122802734375 93.3384857177734375 91.9287567138671875 93.7541961669921875 90.2438812255859375 85.2388458251953125 88.668487548828125 97.278465270
 99609375 105.378631591796875 103.13227081298828125 101.66025543212890625 99.1523590087890625
+ 124.7664947509765625 110.75148773193359375 112.9425048828125 98.4692840576171875 94.31780242919921875 94.058624267578125 94.00513458251953125 93.35333251953125 92.1309967041015625 93.2491302490234375 94.4787139892578125 94.07756805419921875 94.01540374755859375 94.3256988525390625 93.74495697021484375 93.8000030517578125 92.5989990234375 93.3736724853515625 93.1732330322265625 98.4709930419921875 97.25115966796875 97.70014190673828125 97.93721771240234375 98.36241912841796875 103.43898773193359375 104.72564697265625 106.79398345947265625 105.29510498046875 97.300140380859375 107.89789581298828125 112.324859619140625 107.78972625732421875 109.71428680419921875 114.2133026123046875 114.09929656982421875 110.7687835693359375 97.999267578125 97.9252166748046875 97.58648681640625 102.36119842529296875 109.7979888916015625 113.87166595458984375 120.12656402587890625 125.36821746826171875 125.8055877685546875 126.0644683837890625 131.0757293701171875 127.84427642822265625 124.392173767089
 84375 129.6594085693359375 122.4977874755859375 118.57756805419921875 127.25412750244140625 130.2246551513671875 129.99822998046875 130.371917724609375 127.13347625732421875 125.249053955078125 127.002716064453125 128.588165283203125 128.21783447265625 124.072265625 121.9767303466796875 120.0240478515625 111.84447479248046875 98.9820709228515625 95.18536376953125 94.10005950927734375 94.63503265380859375 95.8265228271484375 95.566558837890625 94.49120330810546875 94.1455230712890625 92.41925811767578125 90.8372955322265625 90.086181640625 89.6801605224609375 89.221527099609375 89.656280517578125 95.613922119140625 103.3808746337890625 105.40991973876953125 95.45732879638671875 101.98619842529296875 105.31439208984375 100.09621429443359375 100.942108154296875 102.83782958984375 99.10479736328125 107.3936614990234375 104.2930755615234375 100.02172088623046875 94.96856689453125 99.97277069091796875 101.7220611572265625 98.7447052001953125 91.36905670166015625 84.1970977783203125 83.614
 1815185546875 85.37408447265625 86.88533782958984375 89.030853271484375 91.86199951171875 93.62017059326171875 95.80239105224609375 99.49713134765625 102.78925323486328125 102.95752716064453125 104.879913330078125 107.02605438232421875 107.04084014892578125 103.39461517333984375 100.98889923095703125 102.23506927490234375 101.6511383056640625 101.771331787109375 103.25197601318359375 101.52477264404296875 97.63775634765625 102.50653076171875 103.34592437744140625 102.6695404052734375 102.69500732421875 104.993316650390625 104.541351318359375 105.32513427734375 105.97557830810546875 108.4726104736328125 110.623809814453125 111.8480224609375 109.41806793212890625 106.29746246337890625 107.12355804443359375 104.475494384765625 101.89221954345703125 99.91600799560546875 101.3109283447265625 100.403778076171875 96.55007171630859375 96.376220703125 98.8300628662109375 93.56589508056640625 88.24980926513671875 88.99596405029296875 95.3415985107421875 98.76050567626953125 104.60694122314453
 125 96.65476226806640625 95.19419097900390625 95.2476806640625
+ 130.082855224609375 127.66306304931640625 122.49729156494140625 122.991485595703125 118.61545562744140625 104.01709747314453125 92.6204986572265625 95.63718414306640625 93.2946624755859375 93.8089141845703125 93.375335693359375 92.1683502197265625 92.954071044921875 93.20484161376953125 94.963836669921875 93.9905548095703125 92.8085174560546875 92.18611907958984375 91.8643951416015625 91.3643646240234375 91.9477691650390625 94.1595001220703125 93.5845489501953125 96.98032379150390625 98.1102752685546875 98.724456787109375 101.2481689453125 100.50476837158203125 97.812469482421875 102.83608245849609375 103.2007293701171875 103.17725372314453125 109.2082672119140625 109.392486572265625 111.24710845947265625 103.28643035888671875 96.3279876708984375 95.2033843994140625 106.048736572265625 105.99925994873046875 114.03969573974609375 119.4613494873046875 122.1552886962890625 119.43959808349609375 125.06829833984375 127.8477325439453125 128.5160675048828125 126.0601654052734375 120.96579
 742431640625 126.27594757080078125 124.71315765380859375 117.0300445556640625 126.06768035888671875 127.127227783203125 126.30693817138671875 127.53679656982421875 124.0742950439453125 121.90007781982421875 121.97911834716796875 125.802703857421875 128.5161285400390625 120.59917449951171875 111.88925933837890625 111.22509765625 101.24777984619140625 111.12290191650390625 110.88013458251953125 94.09609222412109375 93.79286956787109375 93.5862579345703125 93.193450927734375 92.36767578125 91.6161041259765625 90.72658538818359375 92.11824798583984375 96.4833221435546875 97.96776580810546875 88.49279022216796875 90.09612274169921875 97.5227813720703125 105.21503448486328125 106.7734375 97.7989044189453125 91.308441162109375 96.8388671875 92.51494598388671875 97.4943695068359375 91.6084136962890625 103.683197021484375 108.844390869140625 100.294464111328125 96.748016357421875 97.67255401611328125 95.26700592041015625 99.54337310791015625 98.94777679443359375 93.2129058837890625 84.823028
 564453125 83.5954742431640625 88.8483123779296875 95.24933624267578125 94.63063812255859375 97.01552581787109375 97.2131500244140625 95.72580718994140625 101.294921875 103.15975189208984375 102.67673492431640625 105.58306884765625 106.0485076904296875 107.91361236572265625 104.00091552734375 99.2417755126953125 101.35384368896484375 101.54825592041015625 100.39501190185546875 103.251190185546875 97.88661956787109375 98.1698150634765625 101.76331329345703125 100.88843536376953125 98.89910125732421875 98.88092803955078125 103.04782867431640625 103.2288818359375 104.4966888427734375 104.19415283203125 106.86206817626953125 110.78685760498046875 110.57306671142578125 110.05413818359375 107.708648681640625 106.95078277587890625 105.90853118896484375 104.57633209228515625 103.06684112548828125 104.6049041748046875 102.9532012939453125 98.4795074462890625 100.52663421630859375 98.14402008056640625 95.25555419921875 89.1184844970703125 97.71764373779296875 95.6537017822265625 101.7960357666
 015625 100.44396209716796875 97.32936859130859375 90.5338592529296875 87.47229766845703125
+ 130.053924560546875 134.5759429931640625 128.3421783447265625 118.8011932373046875 110.31671905517578125 102.30980682373046875 114.0401458740234375 118.1610260009765625 109.62512969970703125 94.1640167236328125 93.93939971923828125 91.319854736328125 92.07155609130859375 93.31491851806640625 95.90345001220703125 92.39910888671875 92.11231231689453125 91.90535736083984375 92.0383758544921875 90.6940765380859375 91.53079986572265625 91.06385040283203125 95.57920074462890625 94.48152923583984375 95.37648773193359375 96.67943572998046875 99.56505584716796875 95.068389892578125 96.99338531494140625 100.38100433349609375 101.5683746337890625 100.4669036865234375 101.37540435791015625 105.89572906494140625 110.1144256591796875 98.097686767578125 93.085968017578125 105.0150299072265625 109.7056121826171875 115.1661376953125 113.556427001953125 120.4129486083984375 118.6309356689453125 117.677459716796875 123.631683349609375 129.1776885986328125 128.5185394287109375 121.25830841064453125 11
 4.30519866943359375 120.55603790283203125 115.85260009765625 118.20587158203125 124.3513946533203125 124.3017120361328125 123.644195556640625 121.69781494140625 121.44191741943359375 119.52518463134765625 121.07543182373046875 125.815582275390625 127.04579925537109375 126.4453887939453125 122.122222900390625 114.97954559326171875 119.39604949951171875 109.6528167724609375 116.2277069091796875 106.86191558837890625 93.0871124267578125 92.68360137939453125 92.17828369140625 91.9631195068359375 91.32270050048828125 91.7303924560546875 104.48272705078125 102.9417877197265625 88.45575714111328125 88.41961669921875 89.6347808837890625 93.97824859619140625 101.887786865234375 97.99237060546875 99.07216644287109375 89.76428985595703125 93.35346221923828125 89.2124786376953125 95.44533538818359375 92.58588409423828125 105.8625335693359375 105.5555877685546875 94.95867919921875 94.98914337158203125 97.57411956787109375 92.9482574462890625 98.3906707763671875 101.8327789306640625 97.0710296630
 859375 85.31771087646484375 83.06392669677734375 88.129119873046875 96.06998443603515625 98.93720245361328125 95.7555999755859375 99.67743682861328125 101.33466339111328125 102.59365081787109375 106.1072845458984375 107.32802581787109375 104.9876861572265625 105.62941741943359375 105.25794219970703125 102.88385009765625 100.91008758544921875 97.1002349853515625 97.4616241455078125 97.8101654052734375 102.167724609375 99.951416015625 95.3840789794921875 100.15399169921875 96.262054443359375 99.2285919189453125 101.207733154296875 103.34519195556640625 104.3519439697265625 105.347259521484375 106.87442779541015625 108.4416046142578125 108.15520477294921875 109.79314422607421875 107.44347381591796875 105.21624755859375 105.15033721923828125 105.7960357666015625 107.974578857421875 105.5942840576171875 108.11347198486328125 103.78719329833984375 100.84062957763671875 101.71726226806640625 98.10132598876953125 91.8264923095703125 90.99045562744140625 100.08065032958984375 101.36346435546
 875 102.93991851806640625 95.10599517822265625 90.49085235595703125 86.154022216796875 86.78340911865234375
+ 127.427825927734375 133.705047607421875 127.261016845703125 119.062652587890625 103.68093109130859375 114.373291015625 109.90723419189453125 122.05023956298828125 112.49225616455078125 95.31560516357421875 94.1725311279296875 94.0188140869140625 92.0081634521484375 92.78934478759765625 92.934173583984375 92.65465545654296875 92.73059844970703125 91.10010528564453125 90.938262939453125 90.8342742919921875 90.6107025146484375 91.1977386474609375 91.3816070556640625 92.4686737060546875 93.90111541748046875 94.14374542236328125 94.94510650634765625 93.27739715576171875 97.73883819580078125 97.85882568359375 99.2326812744140625 97.02381134033203125 100.08820343017578125 100.73149871826171875 102.422088623046875 92.4627227783203125 97.47623443603515625 107.03049468994140625 113.59958648681640625 117.54871368408203125 119.5569915771484375 118.55065155029296875 112.7465057373046875 117.82567596435546875 120.66945648193359375 126.7866668701171875 128.545257568359375 124.165496826171875 112.
 46636199951171875 115.942657470703125 111.1068115234375 116.04631805419921875 122.70766448974609375 127.2754058837890625 125.41268157958984375 125.74254608154296875 124.33049774169921875 118.64003753662109375 118.0789794921875 121.86163330078125 120.6567230224609375 124.45477294921875 125.5495452880859375 123.93288421630859375 115.8366241455078125 115.6704254150390625 118.85280609130859375 109.7718963623046875 100.44297027587890625 96.4149627685546875 100.52387237548828125 98.87171173095703125 104.40708160400390625 105.6472625732421875 110.8680419921875 101.503082275390625 90.57961273193359375 88.3625946044921875 88.3321533203125 88.26982879638671875 95.05342864990234375 87.82682037353515625 91.52337646484375 87.58312225341796875 86.98260498046875 88.12442779541015625 92.1850433349609375 89.95001220703125 102.34259033203125 101.0273284912109375 95.39069366455078125 92.92340087890625 93.25429534912109375 93.07965850830078125 98.763153076171875 99.61084747314453125 98.82794189453125 8
 1.89485931396484375 83.0523834228515625 88.71338653564453125 96.0048828125 102.7819366455078125 101.5538482666015625 101.2074127197265625 102.56137847900390625 102.6414794921875 105.11086273193359375 106.11235809326171875 104.37210845947265625 104.05672454833984375 102.602386474609375 100.1717529296875 101.95494842529296875 95.78945159912109375 93.9623870849609375 97.0813446044921875 100.32373809814453125 98.58513641357421875 92.69527435302734375 92.4466552734375 95.22373199462890625 97.9969635009765625 101.944976806640625 102.3699798583984375 103.5005950927734375 104.63373565673828125 108.40015411376953125 111.00385284423828125 108.7460174560546875 106.56772613525390625 106.8127288818359375 104.74560546875 104.29279327392578125 106.08309173583984375 107.9064788818359375 109.371856689453125 109.6924591064453125 108.2640380859375 105.418243408203125 100.79265594482421875 96.49951934814453125 99.02083587646484375 94.44890594482421875 100.94213104248046875 105.0989532470703125 99.59590
 911865234375 92.7052154541015625 96.36435699462890625 91.1296539306640625 96.32433319091796875
+ 132.8655548095703125 130.9565887451171875 118.54593658447265625 110.874359130859375 116.2519073486328125 111.4656219482421875 121.05921173095703125 119.64870452880859375 110.35756683349609375 97.12010955810546875 98.4033355712890625 98.54842376708984375 110.67926788330078125 120.529266357421875 100.82309722900390625 94.52368927001953125 92.432769775390625 92.32635498046875 91.67084503173828125 92.1326751708984375 91.9688720703125 91.60781097412109375 91.36891937255859375 90.5010986328125 91.4672698974609375 91.76364898681640625 90.4067230224609375 94.63214874267578125 94.346527099609375 97.22711944580078125 97.577789306640625 94.787017822265625 98.298065185546875 98.30084228515625 99.077301025390625 91.75640869140625 95.446746826171875 100.75112152099609375 108.05628204345703125 116.2218017578125 116.704833984375 112.1117706298828125 109.27712249755859375 117.835052490234375 124.6706085205078125 126.18514251708984375 126.72019195556640625 116.84246826171875 114.82141876220703125 10
 8.58518218994140625 113.21921539306640625 119.345703125 122.2587890625 126.9759063720703125 129.5230560302734375 130.1171112060546875 126.44719696044921875 119.57236480712890625 115.25677490234375 120.4842681884765625 123.2493896484375 121.9941558837890625 124.9776153564453125 121.9901885986328125 119.2082672119140625 121.4818572998046875 115.61283111572265625 104.5428009033203125 112.49082183837890625 118.19474029541015625 117.30985260009765625 109.491973876953125 112.9587249755859375 111.4694671630859375 112.994476318359375 104.70635223388671875 94.62146759033203125 88.331878662109375 88.301544189453125 88.22148895263671875 85.3480224609375 84.5348968505859375 85.09439849853515625 83.8356475830078125 83.6542205810546875 85.4893341064453125 86.2142791748046875 89.52484893798828125 100.42486572265625 100.22771453857421875 94.01848602294921875 87.85707855224609375 90.7429656982421875 89.01943206787109375 94.14678192138671875 94.83514404296875 91.97210693359375 81.65601348876953125 82
 .93363189697265625 89.6674652099609375 96.41934967041015625 102.84588623046875 104.51213836669921875 103.09066009521484375 101.27434539794921875 100.47936248779296875 103.19748687744140625 103.65167999267578125 102.04749298095703125 100.243621826171875 98.95391845703125 98.86270904541015625 100.142181396484375 98.52550506591796875 91.80030059814453125 94.16654205322265625 98.48244476318359375 96.51674652099609375 89.46723175048828125 96.36113739013671875 97.4814910888671875 94.69657135009765625 100.366119384765625 102.0336761474609375 104.1193084716796875 106.70635986328125 106.59467315673828125 110.5159912109375 108.94567108154296875 103.98267364501953125 106.96089935302734375 103.417633056640625 104.01458740234375 106.73000335693359375 107.3454742431640625 109.53073883056640625 112.50030517578125 112.072479248046875 108.75226593017578125 101.210296630859375 101.78025054931640625 97.03801727294921875 98.12412261962890625 103.93524169921875 103.13869476318359375 101.2179183959960937
 5 97.1472320556640625 98.72490692138671875 92.55251312255859375 99.9801483154296875
+ 136.3496856689453125 129.178955078125 127.26792144775390625 127.5651702880859375 125.37686920166015625 113.463531494140625 119.7427215576171875 107.1798095703125 99.95391845703125 100.2819976806640625 112.3659515380859375 119.25054931640625 117.77275848388671875 123.27259063720703125 116.35211944580078125 123.99761962890625 106.94719696044921875 100.4630584716796875 94.739166259765625 93.64659881591796875 92.69141387939453125 91.4253997802734375 90.9349822998046875 90.7165069580078125 90.99715423583984375 90.61492919921875 89.5315399169921875 90.30962371826171875 91.0969085693359375 91.1051483154296875 96.08039093017578125 92.51847076416015625 96.575531005859375 96.9632720947265625 97.535797119140625 91.35327911376953125 98.255126953125 107.7979736328125 113.1955413818359375 112.3515625 110.297088623046875 103.95953369140625 110.3168487548828125 113.61128997802734375 118.822265625 123.66887664794921875 125.75539398193359375 118.03014373779296875 108.53629302978515625 105.8808517456
 0546875 110.74289703369140625 117.84320068359375 124.18556976318359375 126.001007080078125 128.8933258056640625 129.6100311279296875 125.11376953125 118.9368133544921875 114.92507171630859375 117.62792205810546875 119.70447540283203125 120.39638519287109375 122.335693359375 119.47536468505859375 116.64394378662109375 119.2482147216796875 114.99356842041015625 108.30458831787109375 116.1483154296875 116.208953857421875 113.85230255126953125 114.6163787841796875 113.797943115234375 109.5576171875 108.57816314697265625 108.52892303466796875 99.3387451171875 91.20298004150390625 89.70294952392578125 89.7263946533203125 89.27440643310546875 89.4431915283203125 91.62789154052734375 84.461639404296875 83.64902496337890625 83.16230010986328125 82.4839324951171875 84.2695465087890625 95.13663482666015625 92.1156463623046875 94.08301544189453125 85.41004180908203125 87.12708282470703125 85.78981781005859375 86.7337188720703125 87.6429290771484375 81.77288055419921875 80.9842987060546875 83.93
 1732177734375 90.00164794921875 95.8447265625 99.6930084228515625 102.149932861328125 99.7584381103515625 99.36016082763671875 99.2017822265625 101.76753997802734375 102.67200469970703125 100.505340576171875 99.856353759765625 98.50405120849609375 97.23758697509765625 98.85631561279296875 97.0367889404296875 91.0244598388671875 94.2008209228515625 97.05434417724609375 92.90876007080078125 89.46659088134765625 91.889617919921875 94.304168701171875 99.0948333740234375 101.2583465576171875 103.85037994384765625 105.036895751953125 107.223602294921875 109.64977264404296875 110.67897796630859375 106.04901885986328125 102.164703369140625 104.646820068359375 101.77303314208984375 103.93219757080078125 106.942535400390625 107.953155517578125 109.99318695068359375 111.31119537353515625 107.57763671875 105.07505035400390625 103.209320068359375 103.3329925537109375 95.9652557373046875 100.85822296142578125 105.66883087158203125 105.9900360107421875 101.200897216796875 99.76267242431640625 101.
 36907958984375 99.3516693115234375 100.6993408203125
+ 135.0903472900390625 132.8905792236328125 134.312774658203125 130.4919281005859375 125.07225799560546875 122.21276092529296875 109.380828857421875 105.2165069580078125 113.8462371826171875 106.3072052001953125 112.44394683837890625 119.82448577880859375 128.5341949462890625 130.275360107421875 130.849334716796875 125.887298583984375 119.1988525390625 112.563201904296875 99.41729736328125 95.206298828125 93.35619354248046875 91.90765380859375 91.28668975830078125 90.89144134521484375 89.44071197509765625 89.6508636474609375 89.51747894287109375 88.575286865234375 89.85799407958984375 89.2286224365234375 90.13788604736328125 89.96237945556640625 94.15770721435546875 96.8056488037109375 98.66558074951171875 90.77046966552734375 97.79461669921875 107.78957366943359375 111.201873779296875 105.72321319580078125 101.93587493896484375 111.6173095703125 118.76837921142578125 121.09604644775390625 124.21671295166015625 121.462646484375 120.166534423828125 111.5256500244140625 107.13377380371
 09375 105.53498077392578125 112.31145477294921875 120.18111419677734375 125.65142822265625 127.4280242919921875 125.960540771484375 127.0417633056640625 121.57440948486328125 118.395782470703125 116.412506103515625 113.3998565673828125 114.860626220703125 117.67679595947265625 119.757293701171875 115.75839996337890625 114.23867034912109375 117.9951934814453125 115.40285491943359375 115.57492828369140625 116.4134368896484375 115.3685150146484375 113.9644775390625 109.17369842529296875 110.97068023681640625 109.77386474609375 102.4516143798828125 106.6872711181640625 105.81394195556640625 101.64003753662109375 91.7311248779296875 90.2745361328125 98.9761962890625 97.3341522216796875 97.06038665771484375 86.3271636962890625 83.40361785888671875 82.58099365234375 82.445343017578125 81.8442535400390625 81.667144775390625 81.2427825927734375 86.44210052490234375 83.2352447509765625 82.885223388671875 81.66857147216796875 82.05893707275390625 83.7191162109375 80.3598785400390625 80.6908721
 923828125 84.2049407958984375 92.0030517578125 94.50720977783203125 94.94765472412109375 100.95595550537109375 92.47503662109375 93.98700714111328125 94.7248992919921875 97.74056243896484375 102.01815032958984375 100.51667022705078125 97.249786376953125 95.98313140869140625 96.58234405517578125 96.9715576171875 96.88983154296875 93.5378875732421875 92.06623077392578125 95.2830657958984375 90.88713836669921875 91.20990753173828125 95.146484375 95.8269805908203125 97.19631195068359375 101.73165130615234375 102.47020721435546875 106.0379638671875 106.64484405517578125 110.24131011962890625 110.59566497802734375 107.551025390625 102.013519287109375 102.07448577880859375 101.05889129638671875 102.43486785888671875 104.6039886474609375 106.7076568603515625 108.67745208740234375 112.25899505615234375 111.2259521484375 108.2985992431640625 107.43035888671875 99.77496337890625 104.45793914794921875 100.970550537109375 109.29045867919921875 108.12631988525390625 101.72040557861328125 102.8101
 2725830078125 105.67095184326171875 102.5147552490234375 101.36838531494140625
+ 135.4486846923828125 138.5984344482421875 131.2178802490234375 122.59809112548828125 119.07112884521484375 114.97231292724609375 118.18675994873046875 120.9064483642578125 124.0373382568359375 120.4480438232421875 105.21114349365234375 122.40833282470703125 128.9736175537109375 133.20013427734375 119.2871246337890625 107.78839874267578125 104.93846893310546875 101.877593994140625 99.127593994140625 99.00395965576171875 94.95526123046875 93.417022705078125 93.06539154052734375 92.81050872802734375 90.17304229736328125 90.0088348388671875 89.9626922607421875 90.34247589111328125 89.70600128173828125 89.611480712890625 89.16648101806640625 88.81885528564453125 88.3026885986328125 98.24092864990234375 92.58824920654296875 91.86058807373046875 99.1136474609375 104.83344268798828125 103.8636474609375 99.3103790283203125 109.77198028564453125 116.135162353515625 117.8056488037109375 118.8944091796875 123.646728515625 118.0977935791015625 116.08321380615234375 117.01529693603515625 101.513
 98468017578125 105.3643798828125 111.5581817626953125 115.91941070556640625 121.76996612548828125 123.648651123046875 122.0842742919921875 126.4596099853515625 125.29161834716796875 123.31014251708984375 123.35010528564453125 117.4750823974609375 112.5423583984375 112.5079803466796875 117.32265472412109375 115.7144927978515625 112.012176513671875 114.86586761474609375 112.85445404052734375 112.5664520263671875 112.43004608154296875 111.191680908203125 109.029327392578125 107.4952545166015625 107.06513214111328125 105.99654388427734375 102.80568695068359375 102.305145263671875 99.0978546142578125 95.2332611083984375 89.22440338134765625 100.21521759033203125 104.65735626220703125 102.2925262451171875 94.98509979248046875 94.196044921875 86.94048309326171875 83.05059051513671875 84.5103607177734375 82.50884246826171875 84.8835296630859375 84.3421783447265625 82.33019256591796875 80.7572021484375 80.70172882080078125 80.4143524169921875 81.44516754150390625 81.9962615966796875 80.75781
 25 80.2198486328125 85.46308135986328125 90.07611083984375 89.64678955078125 88.530029296875 89.49131011962890625 93.45590972900390625 96.60169219970703125 99.88518524169921875 100.1557464599609375 102.38153076171875 99.686248779296875 96.5036163330078125 94.67133331298828125 96.77437591552734375 96.06894683837890625 95.35400390625 95.28491973876953125 89.00399017333984375 92.26563262939453125 88.71633148193359375 91.62905120849609375 95.4044036865234375 97.4900054931640625 98.1037139892578125 102.64353179931640625 102.776611328125 105.6219329833984375 107.00777435302734375 109.91277313232421875 104.85280609130859375 105.35854339599609375 101.67830657958984375 100.32314300537109375 100.783355712890625 99.97576904296875 101.9019927978515625 104.49875640869140625 105.9956512451171875 109.9149627685546875 112.8450927734375 111.5264739990234375 103.44506072998046875 101.31644439697265625 108.32154083251953125 104.11542510986328125 107.1828765869140625 108.46709442138671875 100.819168090
 8203125 106.03792572021484375 107.99957275390625 107.72882080078125 106.42595672607421875
+ 142.2846527099609375 143.1173248291015625 137.873382568359375 135.4098358154296875 127.7597808837890625 127.07933807373046875 117.64176177978515625 128.8155059814453125 127.47894287109375 115.9442901611328125 117.9736785888671875 116.4744110107421875 122.4976043701171875 132.619171142578125 128.1742095947265625 122.2711639404296875 115.59618377685546875 105.37705230712890625 117.41008758544921875 114.0988311767578125 96.8059234619140625 104.7799224853515625 111.01491546630859375 106.571502685546875 119.98900604248046875 98.2680816650390625 90.41309356689453125 90.11357879638671875 89.87671661376953125 89.85445404052734375 89.25647735595703125 88.82479095458984375 88.94808197021484375 87.03037261962890625 88.4269256591796875 88.5976715087890625 92.81522369384765625 100.25543212890625 95.6606903076171875 106.5782470703125 111.780303955078125 111.60710906982421875 114.86881256103515625 119.11222076416015625 121.5713958740234375 116.63813018798828125 110.82108306884765625 110.637878417
 96875 100.82171630859375 107.27736663818359375 114.88596343994140625 121.02037811279296875 122.546722412109375 116.48003387451171875 118.93512725830078125 124.32740020751953125 127.47371673583984375 127.006195068359375 124.949737548828125 120.03423309326171875 118.392425537109375 109.861785888671875 110.40236663818359375 110.96923065185546875 109.929840087890625 113.34688568115234375 111.60381317138671875 107.120819091796875 105.24249267578125 104.5522003173828125 101.379974365234375 99.4579315185546875 98.232757568359375 96.8157806396484375 94.5307159423828125 93.90245819091796875 92.40508270263671875 90.73484039306640625 94.84842681884765625 103.6830291748046875 108.986236572265625 104.3925933837890625 94.45282745361328125 97.58925628662109375 91.44732666015625 85.764068603515625 87.86377716064453125 83.9872894287109375 86.253143310546875 89.96547698974609375 93.25943756103515625 87.88579559326171875 80.860443115234375 80.60866546630859375 80.3397369384765625 79.99237823486328125
 81.6295013427734375 79.73499298095703125 83.38824462890625 85.1255035400390625 85.521881103515625 89.80028533935546875 93.14557647705078125 97.33426666259765625 100.11859130859375 102.3364715576171875 102.245819091796875 102.55455780029296875 99.13384246826171875 95.98675537109375 91.73191070556640625 94.77423858642578125 93.29540252685546875 94.255950927734375 92.562896728515625 88.10982513427734375 88.6675872802734375 86.43238067626953125 89.99723052978515625 92.78276824951171875 94.0035400390625 97.86383056640625 101.039215087890625 102.11687469482421875 103.70365142822265625 106.03852081298828125 109.35355377197265625 106.35715484619140625 101.70203399658203125 100.14727020263671875 98.88677215576171875 99.69598388671875 101.406463623046875 103.07552337646484375 103.99929046630859375 105.5798187255859375 109.00249481201171875 112.54465484619140625 108.42212677001953125 109.2200469970703125 107.85771942138671875 110.337493896484375 112.2210845947265625 106.0339202880859375 106.41
 5069580078125 104.17641448974609375 108.14665985107421875 110.6934661865234375 111.47571563720703125 103.0794219970703125
+ 141.7007598876953125 139.113739013671875 140.18450927734375 138.6341705322265625 134.0517578125 126.49054718017578125 123.93308258056640625 131.8383941650390625 123.95528411865234375 128.7540740966796875 127.16454315185546875 119.5765228271484375 124.2299041748046875 133.441680908203125 133.915802001953125 129.2591552734375 110.40618133544921875 119.783905029296875 119.66004180908203125 108.61602020263671875 98.47615814208984375 106.95369720458984375 118.15787506103515625 117.3522796630859375 116.2868804931640625 114.67955780029296875 94.478240966796875 90.88970184326171875 90.19547271728515625 89.281585693359375 89.4654998779296875 88.88057708740234375 88.5482635498046875 88.191650390625 87.6979522705078125 88.17935943603515625 88.43711090087890625 91.5224151611328125 101.90975189208984375 107.7694091796875 108.1788330078125 110.32532501220703125 112.49468994140625 116.37519073486328125 119.854461669921875 120.1860198974609375 117.5753326416015625 103.91204833984375 99.37656402587
 890625 108.811279296875 114.9903564453125 122.04129791259765625 118.81128692626953125 117.4645843505859375 122.332305908203125 126.4269256591796875 127.69799041748046875 127.90760040283203125 127.524688720703125 124.06000518798828125 118.50548553466796875 112.023406982421875 109.14398193359375 107.672637939453125 107.32952880859375 104.833160400390625 104.87128448486328125 103.16164398193359375 102.14394378662109375 101.515472412109375 101.6392974853515625 101.32649993896484375 105.0272979736328125 105.5940093994140625 105.05239105224609375 97.1887054443359375 94.67884063720703125 102.28705596923828125 96.5896453857421875 106.34075164794921875 110.1245880126953125 103.38268280029296875 98.2515869140625 101.55513763427734375 95.7590179443359375 87.61528778076171875 93.81473541259765625 86.32541656494140625 88.87831878662109375 95.51825714111328125 94.274017333984375 94.127349853515625 82.195556640625 80.58774566650390625 80.342376708984375 79.849822998046875 80.0010833740234375 79.48
 162841796875 81.760009765625 86.253448486328125 95.300048828125 98.90608978271484375 94.60347747802734375 97.12847137451171875 100.21839141845703125 102.0950927734375 101.457427978515625 101.63321685791015625 99.19850921630859375 93.26049041748046875 91.28802490234375 92.6516876220703125 90.90093231201171875 90.858245849609375 89.2901611328125 86.62248992919921875 86.4825897216796875 90.4452667236328125 89.61717987060546875 95.819488525390625 98.06977081298828125 100.3414459228515625 103.35231781005859375 103.32201385498046875 103.939117431640625 106.21764373779296875 107.6092529296875 105.20749664306640625 101.83087921142578125 101.07598114013671875 97.91613006591796875 101.2906951904296875 102.92858123779296875 104.84906768798828125 106.2722930908203125 107.72969818115234375 107.40509796142578125 111.33718109130859375 112.89859771728515625 112.4765777587890625 110.11978912353515625 110.90134429931640625 113.95751953125 109.95135498046875 110.23394775390625 112.4307098388671875 110
 .4742279052734375 112.2808380126953125 111.91402435302734375 106.18279266357421875
+ 138.292572021484375 135.7084197998046875 138.60162353515625 134.8694610595703125 134.8898773193359375 132.0336456298828125 128.2016448974609375 135.2054443359375 135.6006927490234375 130.3778533935546875 124.47873687744140625 120.9388580322265625 128.9225616455078125 133.19183349609375 120.44561767578125 112.84929656982421875 120.7156219482421875 125.93665313720703125 117.461944580078125 102.22670745849609375 108.73688507080078125 113.5483551025390625 120.3365478515625 122.9998931884765625 118.73455810546875 109.33625030517578125 103.29151153564453125 92.8039398193359375 90.7230377197265625 89.6697845458984375 88.88680267333984375 88.98166656494140625 88.5976715087890625 88.21816253662109375 87.67580413818359375 87.72556304931640625 88.2582550048828125 99.83356475830078125 101.54291534423828125 105.97467041015625 105.0899658203125 104.45088958740234375 113.0219573974609375 116.49742889404296875 115.45264434814453125 114.3362579345703125 112.6074676513671875 104.576934814453125 98.3
 56292724609375 107.2668304443359375 115.55255126953125 120.8734893798828125 114.8524169921875 113.41869354248046875 118.90508270263671875 123.669342041015625 123.28646087646484375 124.30687713623046875 127.1010284423828125 124.5671844482421875 118.65322113037109375 112.877410888671875 113.6816864013671875 112.13150787353515625 110.56781005859375 107.63842010498046875 105.347747802734375 108.84522247314453125 108.62310791015625 109.7663421630859375 108.00970458984375 112.899383544921875 112.6498565673828125 114.3798065185546875 108.42243194580078125 98.176177978515625 100.61734771728515625 106.94422149658203125 107.4166717529296875 105.31192779541015625 110.414337158203125 100.76625823974609375 104.7129364013671875 98.96656036376953125 93.41759490966796875 94.66704559326171875 94.65526580810546875 87.92236328125 94.85536956787109375 99.5477447509765625 97.1460418701171875 95.2781219482421875 89.9332733154296875 83.5739288330078125 80.38065338134765625 79.55803680419921875 79.89304351
 806640625 79.4602203369140625 79.79274749755859375 85.7176513671875 93.113677978515625 95.37801361083984375 98.4607391357421875 100.17826080322265625 100.3632354736328125 101.33975982666015625 99.9949188232421875 96.44605255126953125 96.980255126953125 91.83831787109375 91.55884552001953125 92.3696441650390625 93.75272369384765625 87.27972412109375 86.01995086669921875 85.51975250244140625 89.87195587158203125 94.5866851806640625 96.21132659912109375 94.0704345703125 99.48575592041015625 99.36273193359375 102.253692626953125 103.2062530517578125 106.95691680908203125 109.217742919921875 106.9904632568359375 100.129425048828125 100.5869140625 96.7824249267578125 98.8764495849609375 103.43717193603515625 105.89579010009765625 106.72049713134765625 109.06735992431640625 110.50911712646484375 110.64861297607421875 112.2313232421875 114.45401763916015625 114.64189910888671875 114.60434722900390625 114.850341796875 114.80921173095703125 113.2523040771484375 112.07785797119140625 113.13709
 259033203125 114.04914093017578125 115.192169189453125 112.563812255859375 106.63272857666015625
+ 135.08184814453125 133.700469970703125 138.0734405517578125 134.356781005859375 131.5060577392578125 132.33624267578125 128.152099609375 132.9718475341796875 135.484039306640625 136.0474090576171875 127.71910858154296875 133.4351959228515625 133.96173095703125 127.28572845458984375 119.2523345947265625 122.010955810546875 128.8910675048828125 113.7027587890625 111.0125579833984375 112.9824981689453125 120.8594207763671875 107.13330841064453125 120.18996429443359375 115.02227783203125 107.10272216796875 114.1601715087890625 108.32643890380859375 105.9604644775390625 102.5505828857421875 93.24950408935546875 89.56772613525390625 88.64170074462890625 88.18912506103515625 88.13288116455078125 87.68634033203125 87.64336395263671875 87.613189697265625 98.4611358642578125 99.1816864013671875 104.93474578857421875 101.3441009521484375 106.56192779541015625 107.90105438232421875 111.67942047119140625 112.94132232666015625 110.6447601318359375 102.3902740478515625 98.2874298095703125 101.316
 44439697265625 108.7598419189453125 115.4775238037109375 114.75408935546875 108.63658905029296875 111.87215423583984375 118.55493927001953125 120.63004302978515625 115.44550323486328125 121.160552978515625 125.4160003662109375 121.5996856689453125 117.41529083251953125 117.150360107421875 116.01308441162109375 118.954620361328125 116.44173431396484375 110.52938079833984375 115.47896575927734375 113.18875885009765625 109.90004730224609375 116.56737518310546875 114.740966796875 116.89990997314453125 120.578857421875 112.643157958984375 102.997314453125 102.8737640380859375 107.37238311767578125 109.9461669921875 115.25342559814453125 111.32532501220703125 105.0814971923828125 106.825408935546875 102.24139404296875 101.5296173095703125 96.1743316650390625 97.89780426025390625 88.6991424560546875 93.28076934814453125 96.77758026123046875 100.84320068359375 92.9997406005859375 90.7833404541015625 88.15531158447265625 100.1130523681640625 106.068878173828125 102.05926513671875 98.82518768
 310546875 79.09674835205078125 78.67189788818359375 81.637298583984375 90.56458282470703125 97.1319427490234375 100.27921295166015625 100.55103302001953125 97.5697479248046875 100.2127685546875 98.1700897216796875 94.473419189453125 94.17736053466796875 90.21144866943359375 89.5159149169921875 90.02811431884765625 90.21530914306640625 85.1803436279296875 85.0244293212890625 87.89190673828125 88.47774505615234375 93.88066864013671875 97.4800262451171875 97.6157379150390625 100.8185577392578125 104.12418365478515625 104.8778533935546875 104.5231475830078125 105.70941162109375 106.5918121337890625 106.17819976806640625 103.76172637939453125 95.3739013671875 95.82250213623046875 98.36621856689453125 102.84942626953125 107.078521728515625 108.11128997802734375 110.72447967529296875 110.7608642578125 111.45232391357421875 113.30554962158203125 114.90616607666015625 115.84943389892578125 115.4228973388671875 115.19427490234375 113.860626220703125 112.56745147705078125 110.02187347412109375
  110.2593841552734375 111.91291046142578125 113.79511260986328125 112.9904937744140625 103.38181304931640625
+ 129.1093292236328125 133.54052734375 137.3831024169921875 135.9885101318359375 131.89752197265625 129.91510009765625 129.21240234375 130.3203125 132.1102294921875 136.9936370849609375 136.798797607421875 137.4790496826171875 131.3461761474609375 121.45069122314453125 126.33789825439453125 125.22722625732421875 129.3465728759765625 126.43381500244140625 127.77138519287109375 116.62674713134765625 124.94484710693359375 111.323089599609375 122.26926422119140625 117.47858428955078125 123.65639495849609375 114.577423095703125 112.889404296875 114.816131591796875 105.24318695068359375 107.1947174072265625 95.03524017333984375 89.2555084228515625 88.18035125732421875 88.10816192626953125 87.46974945068359375 87.6423797607421875 87.52593231201171875 89.038421630859375 98.0599822998046875 103.4528961181640625 97.78676605224609375 100.24727630615234375 103.08470916748046875 108.56485748291015625 112.20803070068359375 112.68087005615234375 106.63775634765625 96.06165313720703125 105.426055908
 203125 113.20372772216796875 116.0500335693359375 108.1387176513671875 104.751434326171875 113.49210357666015625 118.97235107421875 114.4886322021484375 116.78025054931640625 119.2559814453125 123.748138427734375 122.65860748291015625 122.37270355224609375 120.2276763916015625 120.02059173583984375 118.52346038818359375 114.9818572998046875 113.48322296142578125 118.562347412109375 118.2044219970703125 114.45328521728515625 118.8383026123046875 123.47918701171875 123.1818695068359375 118.37952423095703125 111.997955322265625 106.02790069580078125 109.2598114013671875 111.33957672119140625 110.1213531494140625 116.93865203857421875 111.418212890625 108.09490203857421875 112.5996551513671875 106.7268218994140625 107.38320159912109375 103.61602020263671875 92.73514556884765625 96.1043701171875 95.962158203125 101.131805419921875 100.91443634033203125 99.97601318359375 92.45645904541015625 92.0870361328125 91.57048797607421875 104.09027862548828125 101.9946746826171875 78.63593292236328
 125 78.3402862548828125 78.63634490966796875 82.091705322265625 89.63889312744140625 93.34528350830078125 95.20429229736328125 93.9405059814453125 96.0631561279296875 99.02980804443359375 96.62287139892578125 91.06536865234375 92.11865234375 88.50446319580078125 88.17316436767578125 89.47612762451171875 86.5569610595703125 83.8082275390625 85.77036285400390625 92.97801971435546875 95.82982635498046875 93.59102630615234375 95.961395263671875 100.40999603271484375 102.27337646484375 103.5743408203125 102.0793304443359375 103.3228607177734375 104.46167755126953125 107.30623626708984375 106.8125762939453125 101.360931396484375 93.631500244140625 96.85436248779296875 99.68134307861328125 101.949493408203125 104.66289520263671875 109.5940093994140625 110.43315887451171875 111.66080474853515625 113.6691741943359375 112.00262451171875 113.18730926513671875 115.49724578857421875 112.75689697265625 112.8285369873046875 111.62750244140625 110.49033355712890625 109.2752227783203125 109.32498931
 884765625 110.5943450927734375 112.22452545166015625 112.39813995361328125 108.0803070068359375
+ 126.747650146484375 129.697662353515625 133.9808807373046875 132.3709869384765625 132.000640869140625 125.51090240478515625 125.1482391357421875 127.0964202880859375 130.1639251708984375 135.3621673583984375 134.02191162109375 134.1331024169921875 127.01030731201171875 132.783782958984375 136.737701416015625 135.0514678955078125 128.5502777099609375 133.1349334716796875 133.8657073974609375 123.17804718017578125 128.0096893310546875 116.4965362548828125 127.0688018798828125 127.00376129150390625 129.70465087890625 123.02519989013671875 115.04467010498046875 118.2685394287109375 113.901824951171875 114.96686553955078125 110.2017822265625 98.51697540283203125 91.22266387939453125 88.57649993896484375 87.68163299560546875 87.1688995361328125 87.37685394287109375 87.40775299072265625 93.13423919677734375 97.19947052001953125 92.8929443359375 101.35883331298828125 105.4007568359375 107.17121124267578125 108.68041229248046875 109.59473419189453125 100.43672943115234375 95.513359069824218
 75 103.60552215576171875 112.0088958740234375 113.42053985595703125 103.2738037109375 107.83644866943359375 115.91979217529296875 115.475341796875 107.81342315673828125 113.92667388916015625 119.72956085205078125 123.45963287353515625 120.1380615234375 120.33406829833984375 117.62899017333984375 117.7352752685546875 117.87229156494140625 116.97906494140625 117.43408203125 117.43755340576171875 117.5868682861328125 118.4645843505859375 120.1193695068359375 122.97165679931640625 122.21750640869140625 117.0321044921875 109.94586181640625 111.60079193115234375 115.97296142578125 117.610931396484375 114.81639862060546875 116.1235809326171875 114.87915802001953125 113.55759429931640625 114.78279876708984375 113.28472137451171875 110.26853179931640625 100.93044281005859375 97.0051422119140625 94.9168853759765625 100.62625885009765625 102.2486419677734375 102.62836456298828125 96.967742919921875 93.3932037353515625 96.81438446044921875 95.40340423583984375 100.97591400146484375 98.231269836
 42578125 78.06851959228515625 78.40549468994140625 78.7773284912109375 84.2218475341796875 87.54345703125 89.80998992919921875 91.44029998779296875 95.12237548828125 96.10767364501953125 96.25457763671875 96.00218963623046875 94.20041656494140625 89.443023681640625 88.8209075927734375 86.207183837890625 85.7113189697265625 84.62020111083984375 85.43288421630859375 87.1796722412109375 91.5787353515625 95.921905517578125 97.01493072509765625 98.9770965576171875 102.25980377197265625 100.69036865234375 101.77135467529296875 102.085113525390625 99.646881103515625 101.96833038330078125 103.10794830322265625 103.41442108154296875 97.8631744384765625 93.86913299560546875 98.23416900634765625 102.7589569091796875 104.45070648193359375 107.766510009765625 109.87125396728515625 110.5370330810546875 111.08335113525390625 109.8932037353515625 109.85846710205078125 111.3072967529296875 110.883514404296875 106.84638214111328125 108.05068206787109375 106.5222320556640625 106.74932098388671875 105.
 99153900146484375 108.92089080810546875 112.07059478759765625 112.47943115234375 113.5931854248046875 110.82555389404296875
+ 123.9901580810546875 124.8658599853515625 130.621185302734375 127.427581787109375 128.3437347412109375 128.856536865234375 123.84780120849609375 127.51166534423828125 131.3812103271484375 134.9035186767578125 132.398590087890625 130.866729736328125 129.93017578125 134.386993408203125 137.236328125 138.0766143798828125 134.7462921142578125 133.2103118896484375 133.1620025634765625 134.092071533203125 128.098114013671875 125.3753509521484375 129.958892822265625 128.8845977783203125 129.0994720458984375 121.9970703125 113.79132080078125 107.6588134765625 108.86937713623046875 109.7555999755859375 105.27306365966796875 94.46218109130859375 92.44972991943359375 89.71085357666015625 87.615020751953125 87.34058380126953125 86.8134002685546875 87.0620880126953125 87.800079345703125 92.493804931640625 94.365264892578125 95.87995147705078125 103.0788116455078125 102.8525390625 104.13695526123046875 106.2290496826171875 95.1520233154296875 95.80190277099609375 102.97661590576171875 109.267143
 24951171875 112.3816070556640625 100.9543609619140625 110.07761383056640625 112.93840789794921875 106.48073577880859375 109.13220977783203125 115.67162322998046875 122.4405364990234375 122.7161407470703125 117.76807403564453125 115.680633544921875 117.64154052734375 112.12066650390625 114.26511383056640625 113.79044342041015625 115.76845550537109375 113.2592010498046875 112.7450408935546875 113.94366455078125 120.24564361572265625 124.03589630126953125 121.62822723388671875 118.18051910400390625 114.41014862060546875 117.75402069091796875 119.97890472412109375 123.00533294677734375 121.26071929931640625 118.35883331298828125 119.52870941162109375 117.66382598876953125 116.75302886962890625 112.57254791259765625 108.12996673583984375 96.2359466552734375 103.26995849609375 97.64678192138671875 103.2179412841796875 103.9537506103515625 104.26738739013671875 97.8885955810546875 100.32682037353515625 99.06561279296875 96.74463653564453125 94.71019744873046875 91.95343780517578125 86.1205
 596923828125 78.0048370361328125 78.5448455810546875 84.76773834228515625 87.02771759033203125 91.8706817626953125 94.1687774658203125 94.3562164306640625 94.90326690673828125 93.952117919921875 94.25482940673828125 92.9124298095703125 86.6956024169921875 88.951263427734375 82.6037750244140625 82.10988616943359375 87.29865264892578125 91.1795196533203125 93.50460052490234375 92.641845703125 89.19124603271484375 95.31395721435546875 96.92911529541015625 100.8377685546875 99.405059814453125 101.3451995849609375 103.9625091552734375 100.29781341552734375 97.2392730712890625 100.33843994140625 97.95586395263671875 91.99114990234375 94.12343597412109375 98.4430999755859375 102.404510498046875 106.03504180908203125 106.73412322998046875 107.59574127197265625 107.29079437255859375 107.64252471923828125 108.38384246826171875 108.65558624267578125 109.31487274169921875 109.96826171875 106.857818603515625 104.61060333251953125 104.2344970703125 104.46575164794921875 109.130218505859375 111.28
 2958984375 113.3019866943359375 114.6689453125 113.79244232177734375 111.845947265625
+ 121.19516754150390625 124.815093994140625 124.1371002197265625 124.603851318359375 128.7196197509765625 127.37702178955078125 121.49185943603515625 125.50119781494140625 131.7843170166015625 132.78399658203125 131.6146697998046875 126.7636871337890625 129.808746337890625 133.6927947998046875 136.026641845703125 137.161529541015625 134.792236328125 130.1536712646484375 128.2659454345703125 130.8152313232421875 132.133087158203125 130.6614227294921875 131.0341796875 126.07752227783203125 128.0651092529296875 115.63086700439453125 118.70722198486328125 117.06459808349609375 111.64621734619140625 98.764862060546875 96.03939056396484375 100.36406707763671875 100.78566741943359375 90.4054107666015625 88.08733367919921875 87.0972900390625 87.14476776123046875 86.6371002197265625 86.87718963623046875 87.78753662109375 92.32781982421875 94.208221435546875 99.353607177734375 100.8225250244140625 101.8084716796875 102.628265380859375 92.91547393798828125 95.59244537353515625 104.2004547119140
 625 112.150970458984375 108.34148406982421875 98.57695770263671875 108.2445220947265625 104.48282623291015625 103.99291229248046875 112.50995635986328125 117.3108367919921875 124.0119781494140625 121.8151397705078125 117.83417510986328125 113.26113128662109375 114.91587066650390625 113.70619964599609375 108.10926055908203125 110.19199371337890625 111.55014801025390625 111.15241241455078125 109.9873809814453125 116.986541748046875 122.03290557861328125 125.98046875 123.96973419189453125 120.527801513671875 118.531707763671875 119.81911468505859375 122.434661865234375 124.7594146728515625 125.0114898681640625 121.63568115234375 119.28948974609375 112.70870208740234375 113.38397979736328125 109.2755889892578125 102.5657501220703125 100.6471099853515625 107.9665679931640625 104.7878875732421875 105.5533294677734375 105.5356597900390625 104.50565338134765625 101.86065673828125 99.1224365234375 95.743499755859375 91.11933135986328125 92.61672210693359375 89.332183837890625 78.370544433593
 75 77.8508148193359375 77.9308929443359375 81.61993408203125 86.28159332275390625 89.39180755615234375 90.32056427001953125 91.6166534423828125 92.85758209228515625 88.23111724853515625 92.47949981689453125 93.70821380615234375 87.13097381591796875 86.71642303466796875 80.458831787109375 82.7992401123046875 84.27466583251953125 89.7359771728515625 91.98728179931640625 93.99147796630859375 96.91089630126953125 96.72800445556640625 98.72020721435546875 98.5042572021484375 100.34100341796875 104.74170684814453125 104.755218505859375 104.9402618408203125 98.994873046875 94.8505706787109375 95.3396453857421875 92.23256683349609375 95.2152557373046875 97.6544036865234375 100.97063446044921875 103.2763824462890625 104.4225006103515625 104.74774932861328125 106.8154296875 106.05628204345703125 106.6934661865234375 108.18123626708984375 107.875 108.09362030029296875 104.31038665771484375 102.9682159423828125 104.44152069091796875 104.55612945556640625 108.3708648681640625 112.111221313476562
 5 113.822357177734375 112.6851654052734375 112.85361480712890625 114.5100250244140625
+ 119.907867431640625 119.30477142333984375 122.455810546875 126.24451446533203125 127.86762237548828125 122.20783233642578125 121.27455902099609375 128.519317626953125 131.2655792236328125 130.768463134765625 130.204254150390625 128.0130157470703125 125.29979705810546875 130.467193603515625 133.555694580078125 135.748291015625 132.9239959716796875 130.2368316650390625 126.5995635986328125 126.58824920654296875 130.434478759765625 131.843597412109375 128.249969482421875 124.6730499267578125 128.2857666015625 124.42613983154296875 122.069915771484375 114.84456634521484375 102.13018798828125 105.60709381103515625 112.81992340087890625 102.67948150634765625 106.754638671875 97.27471923828125 90.6403656005859375 86.96103668212890625 86.80974578857421875 86.564727783203125 86.7683563232421875 86.801544189453125 88.17803955078125 92.6218719482421875 94.566192626953125 96.13939666748046875 99.1755218505859375 98.35665130615234375 90.20135498046875 100.800537109375 107.41817474365234375 110.
 86843109130859375 102.43041229248046875 95.95197296142578125 101.40196990966796875 101.01271820068359375 108.38690185546875 114.60955047607421875 120.59332275390625 123.69663238525390625 118.542205810546875 117.289154052734375 114.76458740234375 110.5431976318359375 106.786285400390625 103.66584014892578125 104.678192138671875 106.39305877685546875 104.0128631591796875 113.06292724609375 118.15038299560546875 122.92487335205078125 123.96410369873046875 119.66196441650390625 119.8671722412109375 114.4176025390625 117.16904449462890625 120.3395538330078125 120.83586883544921875 123.42179107666015625 121.17488861083984375 116.77735137939453125 110.88741302490234375 108.15612030029296875 103.5449676513671875 105.44580078125 103.36456298828125 110.58167266845703125 107.92133331298828125 107.50994873046875 103.8936614990234375 99.98874664306640625 97.50319671630859375 96.53607177734375 94.69547271728515625 88.114410400390625 87.1797332763671875 83.0932464599609375 79.88222503662109375 80.
 63641357421875 77.47586822509765625 77.6192626953125 83.067169189453125 84.7733306884765625 87.693115234375 90.4288482666015625 90.96645355224609375 85.44388580322265625 90.94721221923828125 89.88547515869140625 84.0971221923828125 81.148345947265625 81.15967559814453125 86.27353668212890625 88.81595611572265625 86.30377197265625 87.498870849609375 88.200958251953125 94.50862884521484375 97.8106842041015625 96.7527008056640625 101.16414642333984375 103.3460540771484375 108.36191558837890625 109.0646209716796875 106.860260009765625 102.2002105712890625 95.05306243896484375 92.53824615478515625 90.9103546142578125 92.88763427734375 96.45191192626953125 99.22259521484375 101.29228973388671875 102.19769287109375 105.61211395263671875 105.34944915771484375 103.8219451904296875 104.8800811767578125 104.798126220703125 105.668212890625 106.343170166015625 104.77249908447265625 101.820587158203125 100.81267547607421875 102.67193603515625 105.77797698974609375 107.69042205810546875 112.56175
 23193359375 108.0129547119140625 110.065582275390625 110.364654541015625
+ 117.11313629150390625 114.64786529541015625 116.67401885986328125 120.44527435302734375 124.1228485107421875 119.2142486572265625 122.7993927001953125 127.43331146240234375 128.630645751953125 127.4747467041015625 126.3480377197265625 125.87067413330078125 123.02435302734375 128.4407196044921875 130.2665252685546875 132.328369140625 128.6322174072265625 125.98571014404296875 128.0974578857421875 123.16025543212890625 126.82045745849609375 129.20623779296875 128.6621551513671875 123.5558013916015625 127.0825347900390625 125.95035552978515625 116.3299102783203125 114.97782135009765625 109.779296875 107.92809295654296875 115.97187042236328125 105.860504150390625 112.50006866455078125 104.7676239013671875 96.89411163330078125 87.9576416015625 86.59033203125 86.3794097900390625 86.58650970458984375 86.5854644775390625 86.57419586181640625 89.502410888671875 90.33658599853515625 94.9160003662109375 96.133087158203125 90.39295196533203125 92.77591705322265625 98.9449005126953125 104.01814
 27001953125 107.7449951171875 98.33901214599609375 94.29924774169921875 100.8480072021484375 106.8023529052734375 112.54376983642578125 116.44122314453125 114.7703094482421875 119.65595245361328125 112.55669403076171875 114.69867706298828125 114.82315826416015625 115.681854248046875 114.850372314453125 109.93741607666015625 101.8082427978515625 101.12461090087890625 105.51683807373046875 108.597564697265625 114.01850128173828125 118.67961883544921875 120.62845611572265625 111.75586700439453125 115.108062744140625 110.93691253662109375 112.7660980224609375 113.650390625 115.8117523193359375 122.51212310791015625 121.7022857666015625 117.6354827880859375 116.2777252197265625 115.33567047119140625 110.77501678466796875 111.43598175048828125 109.11101531982421875 111.9934844970703125 109.304412841796875 102.8688507080078125 96.62114715576171875 99.31676483154296875 93.4902191162109375 88.7343902587890625 88.8590240478515625 84.40570068359375 84.295166015625 85.1153717041015625 85.107902
 52685546875 80.7554168701171875 82.4347381591796875 77.57300567626953125 80.42743682861328125 85.504241943359375 89.8367462158203125 90.7320404052734375 89.37163543701171875 82.215362548828125 84.3607635498046875 81.0802001953125 79.7529449462890625 80.4599151611328125 83.3225860595703125 84.7111663818359375 89.4844512939453125 89.51399993896484375 93.77144622802734375 92.68051910400390625 94.57762908935546875 95.07952880859375 98.255523681640625 98.683868408203125 105.0485992431640625 109.67668914794921875 108.27367401123046875 103.11151885986328125 98.8542633056640625 95.4100341796875 91.9135894775390625 92.1378326416015625 95.37853240966796875 100.60472869873046875 101.99839019775390625 105.59209442138671875 107.58547210693359375 104.8815765380859375 106.52063751220703125 102.72634124755859375 101.3531494140625 102.427734375 100.445648193359375 103.2787628173828125 100.74137115478515625 98.456939697265625 99.96477508544921875 106.1392822265625 108.8857269287109375 110.42747497558
 59375 106.69156646728515625 105.8122406005859375 106.18137359619140625 108.9282989501953125
+ 113.90717315673828125 114.32897186279296875 113.59139251708984375 115.82413482666015625 120.08042144775390625 116.45772552490234375 123.382781982421875 124.26682281494140625 125.19435882568359375 124.722686767578125 119.64311981201171875 122.169647216796875 121.06292724609375 125.4200439453125 127.4530487060546875 128.0616302490234375 126.959197998046875 123.2416229248046875 126.24725341796875 120.92108917236328125 121.54962158203125 123.98065948486328125 123.0251007080078125 121.6104888916015625 124.77590179443359375 126.89360809326171875 118.0448150634765625 123.300506591796875 114.44327545166015625 116.8257598876953125 119.58507537841796875 111.33893585205078125 116.64656829833984375 108.47489166259765625 106.2184600830078125 89.181304931640625 86.52248382568359375 86.0715789794921875 86.45082855224609375 86.691314697265625 86.34392547607421875 86.83179473876953125 87.66827392578125 92.1341094970703125 90.74066925048828125 87.72791290283203125 93.9821624755859375 98.963401794433
 59375 104.0648956298828125 105.4513702392578125 93.782318115234375 98.55141448974609375 101.7188720703125 106.85669708251953125 112.8665313720703125 111.4453887939453125 109.1361541748046875 112.748504638671875 108.74945068359375 111.026397705078125 114.4451904296875 120.61974334716796875 115.86376953125 109.37642669677734375 104.52901458740234375 98.4813232421875 102.71782684326171875 106.821746826171875 109.61669158935546875 116.58242034912109375 118.742523193359375 112.1331329345703125 107.61154937744140625 108.7379150390625 108.818206787109375 115.37320709228515625 120.0908203125 122.20938873291015625 122.5242156982421875 119.14464569091796875 117.22678375244140625 115.70192718505859375 114.16539764404296875 114.3254852294921875 114.286773681640625 113.7056427001953125 108.24088287353515625 106.50677490234375 109.2646636962890625 105.72325897216796875 99.83530426025390625 96.38243865966796875 86.4860382080078125 90.0312652587890625 88.297454833984375 90.853973388671875 86.841377
 25830078125 85.845550537109375 87.43622589111328125 78.4433135986328125 85.76691436767578125 87.084869384765625 91.62615966796875 89.2749176025390625 86.1602935791015625 80.2626190185546875 79.44197845458984375 79.58567047119140625 84.43082427978515625 86.6988372802734375 89.59925079345703125 90.26903533935546875 86.83684539794921875 91.75833892822265625 92.13961029052734375 97.6521453857421875 97.94709014892578125 100.93019866943359375 103.77977752685546875 103.216583251953125 105.88915252685546875 109.12892913818359375 102.65496826171875 101.13541412353515625 96.893646240234375 95.161163330078125 93.5549163818359375 91.52312469482421875 96.24222564697265625 100.20417022705078125 106.105560302734375 106.2759552001953125 104.82486724853515625 102.50212860107421875 103.0222015380859375 101.6044464111328125 100.94732666015625 99.08220672607421875 97.07241058349609375 100.130462646484375 97.90345001220703125 100.13440704345703125 104.86704254150390625 106.95966339111328125 109.75262451
 171875 110.07845306396484375 109.89841461181640625 106.73974609375 103.66015625 104.95855712890625
+ 125.58208465576171875 121.5009613037109375 111.7002716064453125 113.73860931396484375 117.0418701171875 114.64380645751953125 119.7098236083984375 118.9643707275390625 121.00576019287109375 117.6677093505859375 117.5770416259765625 121.27596282958984375 118.297271728515625 124.0821380615234375 125.8860321044921875 126.20842742919921875 125.246917724609375 121.45714569091796875 124.06827545166015625 117.83425140380859375 121.67014312744140625 123.6045684814453125 118.86734771728515625 118.90529632568359375 121.652679443359375 122.79869842529296875 125.25222015380859375 125.94121551513671875 120.70162200927734375 123.4891815185546875 123.31171417236328125 121.42409515380859375 117.62252044677734375 110.06699371337890625 104.26746368408203125 97.30475616455078125 89.22296142578125 86.3482666015625 86.3387908935546875 86.391998291015625 86.2809600830078125 86.44564056396484375 86.2016143798828125 87.39075469970703125 88.28443145751953125 87.2432098388671875 95.913421630859375 99.122459
 41162109375 101.5805511474609375 99.91607666015625 90.67726898193359375 100.0192108154296875 106.371917724609375 109.58342742919921875 112.10103607177734375 105.19649505615234375 109.3654327392578125 106.99143218994140625 103.59686279296875 109.40976715087890625 117.68976593017578125 118.43267822265625 114.40973663330078125 109.491943359375 108.1133880615234375 101.27034759521484375 102.660797119140625 105.90386962890625 111.88932037353515625 114.826812744140625 116.29437255859375 110.56282806396484375 104.0076141357421875 105.14455413818359375 112.11004638671875 120.3033447265625 122.86676788330078125 120.65169525146484375 118.1463470458984375 118.416900634765625 116.2086944580078125 111.7165374755859375 109.0901031494140625 110.25588226318359375 112.93019866943359375 113.75897979736328125 114.26190948486328125 111.82463836669921875 108.8551177978515625 102.22382354736328125 98.63776397705078125 89.25542449951171875 95.68836212158203125 94.1272125244140625 95.13520050048828125 92.4
 847869873046875 87.899200439453125 89.3151397705078125 86.79021453857421875 85.60961151123046875 86.09482574462890625 87.55808258056640625 88.82033538818359375 85.9150543212890625 79.54126739501953125 80.0992584228515625 83.86757659912109375 81.63480377197265625 87.2987518310546875 90.0978240966796875 88.79860687255859375 93.7178802490234375 94.94384002685546875 91.8036346435546875 95.25677490234375 96.9559783935546875 101.80675506591796875 106.98549652099609375 104.6944427490234375 109.54370880126953125 109.75213623046875 106.25217437744140625 99.66542816162109375 97.33588409423828125 96.47335052490234375 92.02371978759765625 90.71417236328125 92.46840667724609375 98.5043792724609375 102.57151031494140625 104.197235107421875 104.75177001953125 101.91973114013671875 103.76902008056640625 103.90766143798828125 99.04431915283203125 97.20641326904296875 97.30617523193359375 95.5354156494140625 94.670501708984375 96.91309356689453125 99.3273773193359375 102.5731658935546875 107.64838409
 423828125 111.1384429931640625 109.19692230224609375 107.86359405517578125 106.59874725341796875 99.52933502197265625 101.67775726318359375
+ 129.86334228515625 124.85401153564453125 111.96384429931640625 112.10657501220703125 113.8038787841796875 113.566650390625 116.31093597412109375 117.915679931640625 118.88426971435546875 116.46596527099609375 116.28365325927734375 116.1857452392578125 118.157745361328125 123.4911041259765625 121.921356201171875 123.0009613037109375 122.87652587890625 122.29657745361328125 121.72015380859375 116.74022674560546875 118.00522613525390625 122.7902374267578125 118.96912384033203125 118.38610076904296875 117.392822265625 120.5253143310546875 123.5882568359375 125.52263641357421875 121.8139190673828125 123.16086578369140625 123.4220733642578125 125.24510955810546875 118.0852813720703125 102.5476226806640625 104.8845977783203125 107.75970458984375 94.7393035888671875 89.8356475830078125 86.3679046630859375 86.2285919189453125 86.25214385986328125 86.20043182373046875 86.3505096435546875 86.305694580078125 86.5162506103515625 86.6244659423828125 89.76776885986328125 96.41107940673828125 97.9
 2984771728515625 90.649017333984375 95.29496002197265625 103.898529052734375 105.22198486328125 104.8045196533203125 110.0581207275390625 104.04264068603515625 102.04236602783203125 99.33281707763671875 112.70093536376953125 112.99495697021484375 116.95577239990234375 113.0619659423828125 113.057586669921875 111.47641754150390625 107.29366302490234375 99.91133880615234375 97.0590362548828125 100.803253173828125 108.57952880859375 109.2270355224609375 114.42713165283203125 109.848968505859375 101.0115966796875 104.3533935546875 114.02973175048828125 120.7112274169921875 120.7040557861328125 120.89874267578125 115.01729583740234375 112.263153076171875 115.393646240234375 112.5412445068359375 108.656219482421875 105.89820098876953125 109.12711334228515625 112.7177276611328125 111.30107879638671875 112.796966552734375 106.228759765625 98.14542388916015625 94.72521209716796875 94.23024749755859375 98.6558837890625 93.8634490966796875 99.40254974365234375 93.1170196533203125 91.4742965698
 2421875 95.29543304443359375 88.4811553955078125 85.54821014404296875 76.7096710205078125 79.5621795654296875 86.11405181884765625 84.3383026123046875 78.346923828125 80.6927947998046875 90.30417633056640625 87.24858856201171875 86.61426544189453125 91.091888427734375 92.30046844482421875 95.4863128662109375 97.28565216064453125 95.35976409912109375 95.62210845947265625 98.130218505859375 101.1950225830078125 105.62105560302734375 107.8617401123046875 109.4788360595703125 108.1533660888671875 104.2260894775390625 101.98423004150390625 101.58893585205078125 102.302734375 93.86505889892578125 88.75673675537109375 92.65814971923828125 96.5591583251953125 98.9333343505859375 101.16501617431640625 97.04296875 100.8883056640625 102.590850830078125 102.92855072021484375 96.51430511474609375 95.5590362548828125 94.4285430908203125 96.6287689208984375 98.1445465087890625 98.5897369384765625 100.2381134033203125 101.962249755859375 105.33756256103515625 108.26146697998046875 108.4508209228515
 625 106.270233154296875 105.92086029052734375 99.43096923828125 101.41860198974609375
+ 130.9158782958984375 122.389312744140625 125.48952484130859375 110.8942413330078125 111.15216827392578125 112.98644256591796875 113.70012664794921875 117.2760162353515625 116.60050201416015625 115.25710296630859375 114.2274322509765625 113.6458892822265625 120.28382110595703125 122.0091094970703125 116.0455474853515625 119.43529510498046875 118.73302459716796875 121.85646820068359375 122.14553070068359375 119.4975738525390625 114.1049652099609375 116.69140625 115.58150482177734375 119.5444793701171875 116.34165191650390625 118.60173797607421875 119.07086181640625 122.561737060546875 119.47768402099609375 118.1266937255859375 122.93072509765625 124.92580413818359375 114.347259521484375 114.81885528564453125 106.781982421875 101.89530181884765625 93.39019775390625 96.55190277099609375 86.34452056884765625 86.22896575927734375 86.19849395751953125 86.19849395751953125 86.49658203125 86.258209228515625 86.32761383056640625 86.352874755859375 86.34699249267578125 93.33110809326171875 94
 .81288909912109375 90.2055206298828125 98.5360565185546875 102.32657623291015625 100.46369171142578125 102.56114959716796875 103.86006927490234375 100.33486175537109375 95.3731689453125 106.34555816650390625 112.8971405029296875 110.34528350830078125 114.34418487548828125 109.31725311279296875 107.91698455810546875 110.80438995361328125 107.9552154541015625 106.84130096435546875 98.7041015625 95.96671295166015625 100.974884033203125 109.65688323974609375 111.5507659912109375 106.078338623046875 97.7997589111328125 106.17945098876953125 113.568695068359375 114.4877777099609375 115.92144775390625 120.375213623046875 116.07270050048828125 108.26373291015625 109.55419158935546875 107.64148712158203125 105.25713348388671875 104.2420196533203125 110.319488525390625 112.992706298828125 109.367401123046875 109.8877716064453125 106.93962860107421875 101.876434326171875 104.6980438232421875 97.62802886962890625 100.50406646728515625 97.8512420654296875 101.03626251220703125 94.6248779296875 9
 5.24267578125 98.31169891357421875 93.519622802734375 93.19989013671875 81.1346435546875 76.1918182373046875 80.8023681640625 78.71312713623046875 78.102813720703125 82.78548431396484375 89.986572265625 91.08272552490234375 88.74013519287109375 88.87984466552734375 93.42046356201171875 96.6371917724609375 99.00811004638671875 100.68731689453125 98.7809295654296875 99.95902252197265625 101.14022064208984375 103.11865234375 107.3155364990234375 104.815582275390625 102.1835479736328125 104.79254913330078125 105.78537750244140625 104.8112335205078125 99.84780120849609375 93.04711151123046875 87.78755950927734375 93.53374481201171875 99.22314453125 99.04073333740234375 94.73940277099609375 99.14675140380859375 98.67596435546875 100.89548492431640625 98.254547119140625 96.22631072998046875 92.80303955078125 99.05910491943359375 101.97898101806640625 103.320037841796875 100.9553680419921875 103.7777252197265625 105.84682464599609375 106.97467041015625 109.96871185302734375 108.383918762207
 03125 104.92337799072265625 101.3035125732421875 98.56768798828125 98.25759124755859375
+ 132.519744873046875 131.54656982421875 128.7081451416015625 120.54825592041015625 110.22840118408203125 110.853759765625 111.34694671630859375 112.180267333984375 113.52492523193359375 116.60628509521484375 111.13196563720703125 112.615509033203125 117.5226593017578125 119.59712982177734375 113.712615966796875 116.1976776123046875 116.6925811767578125 119.44278717041015625 118.32802581787109375 118.76755523681640625 114.010284423828125 111.7158966064453125 113.20784759521484375 118.118377685546875 114.65079498291015625 117.70896148681640625 117.097900390625 118.89443206787109375 114.51746368408203125 119.23095703125 123.7701873779296875 124.7888641357421875 121.7795257568359375 110.94066619873046875 112.62923431396484375 103.7914886474609375 101.30571746826171875 99.20365142822265625 91.4854583740234375 86.19207000732421875 86.19849395751953125 86.19849395751953125 86.19849395751953125 86.19844818115234375 86.20558929443359375 86.27362823486328125 86.33898162841796875 86.6579666137
 6953125 87.64862060546875 90.129058837890625 94.3721923828125 92.0908050537109375 94.56894683837890625 93.87737274169921875 97.8104248046875 92.67925262451171875 99.96268463134765625 111.7040557861328125 110.590545654296875 103.94378662109375 108.72771453857421875 106.80248260498046875 104.49991607666015625 109.00699615478515625 111.8696441650390625 108.16156768798828125 98.14322662353515625 94.8719024658203125 102.78464508056640625 106.96142578125 107.5066070556640625 99.39792633056640625 96.0880279541015625 106.27986907958984375 106.86325836181640625 108.05376434326171875 112.1011199951171875 118.64662933349609375 117.65396881103515625 112.2743988037109375 106.000579833984375 101.4584503173828125 101.759033203125 103.22019195556640625 109.326416015625 109.481201171875 105.734527587890625 105.93871307373046875 109.942413330078125 107.5216522216796875 106.38861083984375 102.58354949951171875 102.19094085693359375 101.57071685791015625 101.67273712158203125 97.74288177490234375 99.40
 05279541015625 96.88578033447265625 97.51082611083984375 93.1781463623046875 86.4113922119140625 78.5865631103515625 76.4343414306640625 77.2006988525390625 77.30614471435546875 78.95526885986328125 85.44081878662109375 89.4370574951171875 92.4437408447265625 90.73496246337890625 92.2383270263671875 94.695404052734375 96.78838348388671875 99.35292816162109375 103.50513458251953125 103.69829559326171875 107.08343505859375 109.4804534912109375 105.3877716064453125 100.4784393310546875 99.36774444580078125 102.92227935791015625 103.2819061279296875 102.553131103515625 98.17772674560546875 91.39810943603515625 87.978271484375 94.255706787109375 93.372711181640625 92.9190826416015625 99.973876953125 101.982513427734375 98.88510894775390625 95.21479034423828125 93.643798828125 92.40306854248046875 94.57134246826171875 99.51830291748046875 103.11733245849609375 104.44305419921875 103.24676513671875 105.12640380859375 104.0381317138671875 103.64659881591796875 108.66442108154296875 106.4119
 56787109375 105.23007965087890625 104.00804901123046875 100.7810516357421875 94.78192138671875
+ 135.4275054931640625 137.8513031005859375 131.5162506103515625 128.8143463134765625 118.3727874755859375 109.47875213623046875 109.0540008544921875 108.6451873779296875 109.628509521484375 109.09365081787109375 108.701385498046875 111.276153564453125 111.82935333251953125 113.41704559326171875 112.1881103515625 113.3990478515625 114.87784576416015625 115.94086456298828125 112.46402740478515625 115.16851806640625 114.99256134033203125 111.3877716064453125 113.41741943359375 116.6651153564453125 112.4203948974609375 111.9714508056640625 116.2573394775390625 115.24190521240234375 112.77643585205078125 120.223297119140625 122.04198455810546875 119.58055877685546875 118.69956207275390625 119.000701904296875 118.4913330078125 113.37227630615234375 109.66699981689453125 106.33840179443359375 104.98148345947265625 93.961273193359375 86.19849395751953125 86.19849395751953125 86.19849395751953125 86.16918182373046875 86.13883209228515625 86.10416412353515625 86.09378814697265625 86.209381103
 515625 86.604705810546875 88.110137939453125 85.8049774169921875 85.8022003173828125 87.3005523681640625 90.42391204833984375 94.05867767333984375 93.166900634765625 101.54331207275390625 109.53594970703125 105.658050537109375 101.0153045654296875 105.91046142578125 103.91979217529296875 105.518463134765625 106.30255889892578125 107.5947418212890625 106.48188018798828125 100.10492706298828125 93.95476531982421875 95.11930084228515625 100.46204376220703125 102.86891937255859375 92.13251495361328125 98.121551513671875 101.31023406982421875 109.03398895263671875 113.13037872314453125 116.71484375 119.32352447509765625 114.6188201904296875 113.51895904541015625 111.3494415283203125 105.5752716064453125 97.48211669921875 103.16905975341796875 106.76120758056640625 107.78900146484375 99.03296661376953125 106.0640411376953125 110.36602020263671875 108.94252777099609375 106.73793792724609375 107.54956817626953125 104.774627685546875 105.03205108642578125 100.8576507568359375 98.961555480957
 03125 99.36435699462890625 96.26416015625 94.95163726806640625 91.35651397705078125 88.23041534423828125 80.290771484375 75.95821380615234375 76.282684326171875 76.55670928955078125 81.4424591064453125 87.627655029296875 90.20391845703125 92.0674896240234375 94.0228424072265625 90.9830780029296875 92.3283233642578125 95.809234619140625 99.9039154052734375 105.324798583984375 109.013092041015625 109.3007659912109375 105.86399078369140625 101.95195770263671875 97.04561614990234375 94.32807159423828125 97.5325927734375 98.928314208984375 98.88475799560546875 94.7691497802734375 86.95034027099609375 88.2065582275390625 90.11660003662109375 94.95371246337890625 98.9031524658203125 102.35208892822265625 103.08702850341796875 98.44110870361328125 93.9000701904296875 90.21317291259765625 94.0113525390625 97.746429443359375 96.7900543212890625 102.466156005859375 104.40586090087890625 103.6304473876953125 101.962738037109375 102.52252197265625 100.37776947021484375 103.85239410400390625 103.
 63330078125 104.7938385009765625 105.40216064453125 102.72309112548828125 97.354248046875
+ 137.083465576171875 134.6613616943359375 127.70966339111328125 119.7054901123046875 117.85860443115234375 109.99111175537109375 108.82796478271484375 108.23867034912109375 106.78859710693359375 107.13555908203125 106.967926025390625 106.98674774169921875 107.89719390869140625 111.19541168212890625 110.83708953857421875 111.25200653076171875 112.2169952392578125 112.51930999755859375 110.231719970703125 113.2361907958984375 112.49317169189453125 109.7885894775390625 108.68183135986328125 114.53722381591796875 113.139892578125 109.5272674560546875 113.695037841796875 111.05271148681640625 113.75104522705078125 117.5085296630859375 118.93589019775390625 115.24806976318359375 117.963165283203125 117.33447265625 117.0911102294921875 117.55966949462890625 115.6058807373046875 112.7303924560546875 104.37850189208984375 107.81793975830078125 90.1088409423828125 86.19849395751953125 86.19849395751953125 86.19849395751953125 86.19849395751953125 86.07508087158203125 91.1451263427734375 85.87
 57171630859375 85.921295166015625 86.9450531005859375 86.1913909912109375 85.80224609375 85.80224609375 85.80161285400390625 86.61402130126953125 92.06548309326171875 100.08524322509765625 104.16530609130859375 100.78278350830078125 97.77983856201171875 102.161895751953125 99.1512603759765625 104.44121551513671875 103.55544281005859375 103.534698486328125 99.38333892822265625 98.95662689208984375 91.723114013671875 91.77623748779296875 100.73895263671875 98.60558319091796875 89.70410919189453125 94.13527679443359375 100.12282562255859375 108.6447601318359375 112.1648406982421875 116.8457489013671875 112.3853607177734375 107.72806549072265625 111.58282470703125 111.44687652587890625 106.48766326904296875 99.50368499755859375 98.2274932861328125 101.23717498779296875 104.7796783447265625 93.1161041259765625 104.39421844482421875 107.4441070556640625 110.71582794189453125 108.201019287109375 105.95069122314453125 106.51680755615234375 104.2725372314453125 95.9726409912109375 94.3921585
 0830078125 91.08127593994140625 92.0244293212890625 90.18505859375 90.87358856201171875 89.7359161376953125 86.86524200439453125 76.119873046875 76.2833709716796875 83.039886474609375 89.2252349853515625 91.9108123779296875 94.41391754150390625 93.523956298828125 90.68080902099609375 89.12789154052734375 91.72884368896484375 96.8856048583984375 102.66744232177734375 104.5912322998046875 105.8475189208984375 107.19922637939453125 105.01280975341796875 100.17537689208984375 97.20633697509765625 93.84305572509765625 91.4984283447265625 94.9720611572265625 94.69133758544921875 89.4918060302734375 85.62481689453125 91.41495513916015625 96.14852142333984375 99.41693115234375 101.396331787109375 101.6976165771484375 100.06912994384765625 96.54863739013671875 90.69274139404296875 92.062530517578125 100.345916748046875 102.0976409912109375 98.69940948486328125 103.29497528076171875 103.761962890625 99.04329681396484375 98.40262603759765625 100.34337615966796875 99.3404388427734375 99.8189392
 08984375 102.7637786865234375 104.03719329833984375 105.03682708740234375 102.119842529296875 98.20648193359375
+ 138.904327392578125 138.935302734375 127.96826171875 115.95351409912109375 116.210174560546875 117.9048309326171875 111.57218170166015625 123.59746551513671875 121.11022186279296875 108.63411712646484375 106.40859222412109375 106.31861114501953125 106.1583099365234375 107.98523712158203125 109.720458984375 110.14806365966796875 110.79217529296875 110.60503387451171875 109.0517425537109375 109.64232635498046875 111.0879974365234375 111.45777130126953125 106.60890960693359375 108.95876312255859375 108.80217742919921875 107.8371429443359375 107.3489990234375 107.75727081298828125 109.8196258544921875 113.08994293212890625 115.02065277099609375 111.91071319580078125 114.82437896728515625 112.7250518798828125 116.3721923828125 115.84075164794921875 115.23523712158203125 116.2290802001953125 110.77800750732421875 111.31568145751953125 106.40096282958984375 89.12944793701171875 86.19280242919921875 86.2015533447265625 86.17728424072265625 85.98513031005859375 85.913726806640625 85.7199859
 619140625 85.8632049560546875 85.8377685546875 85.83111572265625 85.80224609375 85.80224609375 85.80489349365234375 85.77881622314453125 90.1223602294921875 95.66413116455078125 94.08904266357421875 95.20133209228515625 94.59278106689453125 99.86669158935546875 95.948455810546875 98.7233734130859375 99.5871734619140625 104.49877166748046875 101.80274200439453125 101.3260650634765625 95.6376953125 88.04726409912109375 96.77020263671875 94.61629486083984375 88.19474029541015625 96.11444854736328125 104.16957855224609375 112.968231201171875 115.672119140625 116.61516571044921875 108.2812347412109375 101.965118408203125 106.621734619140625 111.17775726318359375 107.88594818115234375 103.2939453125 91.2622528076171875 99.91049957275390625 102.85570526123046875 92.14182281494140625 98.0503997802734375 104.96904754638671875 105.28072357177734375 108.31003570556640625 102.866119384765625 105.39771270751953125 101.81170654296875 101.12664031982421875 93.08759307861328125 88.2587738037109375
 87.95839691162109375 82.90547943115234375 84.06243133544921875 83.5275421142578125 82.04268646240234375 78.5857086181640625 75.92242431640625 84.17803192138671875 89.4681396484375 91.4568023681640625 90.79976654052734375 91.6016998291015625 87.8433837890625 87.55560302734375 93.4465789794921875 99.1421356201171875 96.144134521484375 95.7820587158203125 102.23863983154296875 106.3253936767578125 108.1232147216796875 107.0214385986328125 103.90729522705078125 96.92364501953125 91.55425262451171875 89.42479705810546875 91.3979949951171875 85.30637359619140625 87.4537506103515625 89.81714630126953125 93.79198455810546875 97.44316864013671875 100.55957794189453125 99.44062042236328125 96.662353515625 95.0670318603515625 88.8508758544921875 94.3773193359375 101.4656829833984375 101.19718170166015625 102.407867431640625 104.40660858154296875 103.36631011962890625 98.8018341064453125 95.74127960205078125 95.87111663818359375 95.19033050537109375 99.91365814208984375 104.0582733154296875 102
 .5705108642578125 106.25009918212890625 101.980987548828125 96.79866790771484375
+ 136.0551910400390625 129.0155792236328125 121.04308319091796875 128.0679473876953125 120.9245147705078125 125.34328460693359375 114.3264312744140625 129.17449951171875 123.8509063720703125 115.959259033203125 124.88286590576171875 117.97985076904296875 105.92295074462890625 105.220611572265625 106.70733642578125 106.6483154296875 108.652435302734375 108.16620635986328125 107.72351837158203125 107.54540252685546875 109.2845611572265625 109.04067230224609375 105.186492919921875 106.1974945068359375 107.46440887451171875 105.8673248291015625 105.2281646728515625 105.70287322998046875 106.95429229736328125 108.1015777587890625 110.164581298828125 110.67754364013671875 110.7419281005859375 112.87774658203125 116.619140625 112.29296112060546875 112.215179443359375 115.6609344482421875 116.31272125244140625 116.37591552734375 104.67784881591796875 102.322052001953125 108.51097869873046875 102.30054473876953125 89.54244232177734375 87.46158599853515625 98.17486572265625 93.2679443359375 87
 .4357147216796875 85.83272552490234375 85.81214141845703125 85.80224609375 85.771759033203125 85.771759033203125 85.74135589599609375 85.71080780029296875 85.6868133544921875 89.1633148193359375 89.77872467041015625 97.8396759033203125 96.25089263916015625 93.43799591064453125 95.49895477294921875 95.92415618896484375 101.61765289306640625 108.3233489990234375 108.9876708984375 101.1597747802734375 91.5997772216796875 90.6263275146484375 91.916015625 90.78911590576171875 100.5014495849609375 102.77196502685546875 110.229156494140625 109.91797637939453125 109.33896636962890625 102.44190216064453125 97.822418212890625 99.86775970458984375 108.8921661376953125 102.75914764404296875 103.55744171142578125 89.0707244873046875 94.89926910400390625 97.78754425048828125 89.87094879150390625 99.45697784423828125 104.59909820556640625 105.0133209228515625 104.80640411376953125 98.09462738037109375 103.10321807861328125 106.17635345458984375 104.24025726318359375 95.32415771484375 94.2495803833
 0078125 93.70087432861328125 85.3031158447265625 86.32030487060546875 86.41710662841796875 81.1072540283203125 80.85944366455078125 75.167724609375 79.8180694580078125 86.2992401123046875 88.82888031005859375 87.83637237548828125 86.430328369140625 84.70082855224609375 88.024444580078125 91.26049041748046875 90.99715423583984375 92.04904937744140625 96.30496978759765625 102.3460540771484375 105.20369720458984375 107.940093994140625 103.65810394287109375 101.66657257080078125 96.346405029296875 98.286407470703125 87.3717193603515625 86.7210845947265625 84.77951812744140625 88.6331329345703125 92.81703948974609375 98.2349090576171875 98.133941650390625 100.5597686767578125 97.10945892333984375 94.79327392578125 90.98211669921875 88.76757049560546875 91.36389923095703125 95.96770477294921875 98.77671051025390625 103.04405975341796875 104.2978515625 100.20211029052734375 98.60990142822265625 93.73236083984375 93.0346527099609375 96.6017913818359375 102.406219482421875 104.35411071777343
 75 100.11717987060546875 100.94321441650390625 100.42748260498046875 94.21710968017578125
+ 137.1124114990234375 130.2045440673828125 134.0711212158203125 125.452392578125 127.893707275390625 131.119537353515625 118.66658782958984375 129.9435577392578125 121.0579376220703125 119.94029998779296875 129.0186004638671875 119.145355224609375 117.21829986572265625 108.37624359130859375 104.58353424072265625 104.67620086669921875 105.02779388427734375 104.84456634521484375 105.5430145263671875 104.7290802001953125 106.8326568603515625 105.865814208984375 104.75302886962890625 103.86209869384765625 104.61614990234375 104.106353759765625 103.4726715087890625 104.47389984130859375 106.6863250732421875 104.91766357421875 106.0662994384765625 104.29788970947265625 105.3793487548828125 109.94855499267578125 112.82857513427734375 110.30373382568359375 110.35214996337890625 111.53606414794921875 112.1354827880859375 117.09302520751953125 115.98448944091796875 102.50311279296875 111.6484375 111.03270721435546875 99.8873443603515625 109.46537017822265625 106.19440460205078125 102.75571441
 650390625 98.31722259521484375 100.101531982421875 85.8018951416015625 85.78760528564453125 85.771759033203125 85.7403717041015625 85.74263763427734375 85.71080780029296875 85.71080780029296875 85.67632293701171875 89.8973236083984375 94.2541656494140625 93.0631256103515625 91.19956207275390625 92.097198486328125 97.51071929931640625 105.45074462890625 104.52744293212890625 112.57472991943359375 108.23303985595703125 99.04510498046875 87.26941680908203125 86.6066131591796875 88.43091583251953125 96.82212066650390625 102.8978271484375 105.0459747314453125 104.72034454345703125 102.7613525390625 94.7795867919921875 96.40029144287109375 98.65543365478515625 108.7165985107421875 106.62802886962890625 98.923583984375 95.88861846923828125 84.692840576171875 91.6729583740234375 95.787933349609375 103.97608184814453125 101.51263427734375 101.0280609130859375 99.2083282470703125 96.239959716796875 102.46410369873046875 108.100921630859375 106.97223663330078125 103.1211090087890625 99.4079132
 080078125 93.3304443359375 88.94574737548828125 93.03851318359375 91.98487091064453125 84.7660369873046875 85.60265350341796875 75.58106231689453125 80.8272705078125 86.73694610595703125 87.0735931396484375 83.92845916748046875 81.9277801513671875 83.8121185302734375 85.2055816650390625 86.68895721435546875 92.65096282958984375 98.302978515625 101.52970123291015625 104.6228790283203125 103.02472686767578125 105.70027923583984375 104.6230621337890625 98.60977935791015625 95.2950439453125 93.99787139892578125 90.5944976806640625 83.695068359375 85.6898956298828125 91.99005126953125 96.1999969482421875 99.59984588623046875 100.58063507080078125 99.41268157958984375 92.671051025390625 93.56394195556640625 89.40421295166015625 90.5767669677734375 96.3740081787109375 98.12644195556640625 100.5565185546875 103.4857330322265625 102.29061126708984375 98.8562469482421875 93.99448394775390625 92.4628143310546875 93.71820068359375 98.3273468017578125 101.8326568603515625 102.61338043212890625 9
 8.60280609130859375 99.95592498779296875 98.658905029296875 93.8147430419921875
+ 140.775787353515625 142.2751617431640625 139.2060699462890625 134.1814727783203125 134.92333984375 134.2548828125 120.071380615234375 132.1829071044921875 132.9547882080078125 126.31000518798828125 132.5486297607421875 125.450958251953125 123.55938720703125 125.7476806640625 110.0767669677734375 103.96714019775390625 103.51190948486328125 103.13817596435546875 103.071624755859375 102.33776092529296875 102.8082427978515625 103.4810028076171875 103.91571044921875 101.5659942626953125 101.82741546630859375 102.91064453125 101.28366851806640625 103.10866546630859375 102.499114990234375 102.31705474853515625 103.83776092529296875 101.140472412109375 103.86035919189453125 105.29553985595703125 108.76145172119140625 107.62523651123046875 107.11367034912109375 107.270416259765625 111.18218231201171875 115.6388702392578125 114.70594024658203125 113.1372833251953125 114.38584136962890625 112.8724822998046875 112.4409332275390625 106.4064483642578125 108.67092132568359375 108.6495819091796875
  108.3364410400390625 105.68932342529296875 96.7673492431640625 85.79987335205078125 85.7723541259765625 85.7412872314453125 85.70948028564453125 85.71080780029296875 85.68032073974609375 85.68032073974609375 85.7394256591796875 88.589508056640625 90.2872314453125 88.9495086669921875 89.97350311279296875 93.76447296142578125 100.38698577880859375 103.1417083740234375 110.56789398193359375 108.4680328369140625 103.15116119384765625 93.36151885986328125 87.42193603515625 90.4598541259765625 97.1740570068359375 101.1710052490234375 99.5040435791015625 97.14730072021484375 86.94405364990234375 84.62346649169921875 91.114288330078125 98.3404541015625 106.3575286865234375 101.1027984619140625 89.567657470703125 100.7654876708984375 82.36434173583984375 85.7275238037109375 93.3305206298828125 101.71735382080078125 97.8571319580078125 97.551544189453125 93.11869049072265625 96.7238311767578125 103.8339996337890625 108.83435821533203125 112.23618316650390625 104.644195556640625 98.1266860961
 9140625 90.9160308837890625 93.64192962646484375 95.689697265625 93.3509979248046875 90.569366455078125 79.10199737548828125 75.75316619873046875 76.5791778564453125 83.5574188232421875 85.62493896484375 80.8922119140625 81.5487060546875 85.35986328125 90.9875946044921875 96.0274505615234375 97.38739776611328125 101.2800140380859375 100.561859130859375 103.05680084228515625 99.55975341796875 102.89385223388671875 103.21288299560546875 101.30889129638671875 94.67046356201171875 89.89403533935546875 85.778564453125 83.631805419921875 87.9860382080078125 88.9510345458984375 95.326141357421875 99.84566497802734375 99.6546630859375 99.50066375732421875 96.1464691162109375 90.14703369140625 88.52834320068359375 91.27098846435546875 98.9046630859375 99.702117919921875 98.77350616455078125 100.1831512451171875 97.3406982421875 96.64171600341796875 94.65716552734375 89.37689971923828125 92.52152252197265625 96.55860137939453125 99.18573760986328125 99.4411468505859375 96.3165740966796875 96.
 52669525146484375 95.20096588134765625 92.19559478759765625
+ 144.1992340087890625 144.1640472412109375 140.77789306640625 132.2435302734375 132.345703125 127.22296905517578125 125.87320709228515625 131.7558441162109375 131.5599822998046875 128.7175445556640625 131.4659423828125 126.84764862060546875 126.11846923828125 125.71488189697265625 122.281829833984375 120.60507965087890625 120.32421112060546875 102.596710205078125 101.76038360595703125 101.02490997314453125 100.2274932861328125 100.45124053955078125 100.20529937744140625 100.476776123046875 99.44390869140625 100.64189910888671875 99.850860595703125 99.2149200439453125 99.76052093505859375 99.5898895263671875 100.66719818115234375 98.5286865234375 99.79880523681640625 101.52582550048828125 104.1071319580078125 105.016021728515625 103.106903076171875 103.64310455322265625 108.2270965576171875 112.67755889892578125 111.6025543212890625 109.14315032958984375 111.2313995361328125 109.8854217529296875 110.771026611328125 104.85468292236328125 104.96376800537109375 107.22452545166015625 106
 .28849029541015625 104.3123321533203125 102.42998504638671875 86.13114166259765625 85.7412872314453125 85.7412872314453125 85.708526611328125 85.71080780029296875 85.68032073974609375 85.68032073974609375 85.64984130859375 86.90838623046875 87.60225677490234375 85.5607147216796875 88.13311004638671875 90.2245635986328125 93.19031524658203125 100.157684326171875 103.8988037109375 101.9852142333984375 102.69829559326171875 95.94171142578125 82.32386016845703125 81.54561614990234375 91.53542327880859375 94.42295074462890625 92.22198486328125 87.8228302001953125 81.18572998046875 81.1355743408203125 83.67401885986328125 89.890655517578125 99.68912506103515625 95.496490478515625 94.11916351318359375 95.73325347900390625 91.22686767578125 84.69878387451171875 96.77150726318359375 99.45842742919921875 96.73604583740234375 88.3433074951171875 91.12288665771484375 97.27020263671875 104.0762939453125 108.22308349609375 108.83153533935546875 105.36486053466796875 101.2214508056640625 94.744476
 318359375 98.30179595947265625 94.54250335693359375 91.584716796875 86.811065673828125 76.15473175048828125 75.59804534912109375 76.1022491455078125 82.22644805908203125 83.68576812744140625 77.9497833251953125 82.544158935546875 89.6186370849609375 94.53823089599609375 101.4641571044921875 103.5804290771484375 99.9015655517578125 99.830535888671875 98.6332855224609375 98.192169189453125 100.31845855712890625 102.33295440673828125 98.03334808349609375 96.4517974853515625 96.03374481201171875 89.2408905029296875 84.13427734375 90.4478302001953125 96.168792724609375 97.666412353515625 99.6635894775390625 96.62003326416015625 98.21556854248046875 95.7356719970703125 89.43021392822265625 88.43749237060546875 93.2044525146484375 99.6317138671875 99.1567535400390625 93.28639984130859375 95.15422821044921875 97.1203765869140625 95.47838592529296875 93.428924560546875 88.32434844970703125 90.638702392578125 95.138275146484375 96.92302703857421875 99.58966827392578125 97.092681884765625 94.9
 853363037109375 94.79273223876953125 88.56003570556640625
+ 140.9576568603515625 140.9232177734375 141.47900390625 137.4042510986328125 139.0755462646484375 139.429595947265625 133.3107452392578125 131.7722930908203125 126.32305145263671875 125.99939727783203125 120.22011566162109375 117.895111083984375 116.7205963134765625 114.52776336669921875 115.60236358642578125 111.90219879150390625 108.0675811767578125 105.75199127197265625 103.822113037109375 104.99285125732421875 102.71282958984375 101.67315673828125 100.5455169677734375 99.98487091064453125 99.14826202392578125 98.55792999267578125 98.1659698486328125 97.63629913330078125 96.8544464111328125 96.75121307373046875 96.40702056884765625 96.40973663330078125 95.9303131103515625 99.49784088134765625 100.7824249267578125 102.56548309326171875 100.69020843505859375 101.19690704345703125 103.77606201171875 104.83310699462890625 107.41841888427734375 107.818450927734375 105.20738983154296875 108.3487396240234375 106.88668060302734375 104.85260009765625 98.53729248046875 101.0625152587890625
  101.56783294677734375 99.4036102294921875 98.7498626708984375 96.27001190185546875 85.76560211181640625 85.74147796630859375 85.7412872314453125 85.71080780029296875 85.68032073974609375 85.64984130859375 85.6492156982421875 85.62474822998046875 85.58882904052734375 85.5274200439453125 86.097442626953125 87.258087158203125 89.18447113037109375 92.941680908203125 95.11231231689453125 95.08022308349609375 95.66300201416015625 95.5406646728515625 81.6728973388671875 81.70412445068359375 81.32837677001953125 83.51371002197265625 83.60646820068359375 80.2384490966796875 78.67098236083984375 78.40576934814453125 78.4988250732421875 78.17340850830078125 86.6931610107421875 79.58322906494140625 79.68737030029296875 82.1746368408203125 79.4907379150390625 79.9914093017578125 88.18785858154296875 97.44185638427734375 95.8137969970703125 86.88653564453125 91.706878662109375 96.70377349853515625 101.66767120361328125 103.3813629150390625 106.4757537841796875 102.32861328125 104.539009094238281
 25 101.6865997314453125 99.50707244873046875 94.6906280517578125 88.5525970458984375 82.50443267822265625 80.199951171875 75.1103363037109375 75.41921234130859375 76.69893646240234375 78.43100738525390625 77.98040771484375 82.631622314453125 87.0289154052734375 92.7471923828125 94.973236083984375 96.4368743896484375 93.63013458251953125 91.65389251708984375 97.0394134521484375 100.7262420654296875 101.1898956298828125 101.14789581298828125 98.63260650634765625 95.8987884521484375 91.6507568359375 87.0809783935546875 84.122955322265625 91.7363433837890625 96.4183349609375 100.57373046875 99.64496612548828125 94.21367645263671875 92.32328033447265625 93.41835784912109375 87.3078155517578125 88.44020843505859375 98.07901763916015625 99.1165924072265625 98.22295379638671875 90.51395416259765625 93.81732177734375 93.4218597412109375 91.92325592041015625 92.748321533203125 87.80265045166015625 92.93888092041015625 95.6179962158203125 98.29521942138671875 101.3893890380859375 99.2780227661
 1328125 95.37554931640625 89.738494873046875 87.731292724609375
+ 137.026580810546875 135.5069122314453125 136.110198974609375 138.8521728515625 141.011383056640625 141.717010498046875 137.6267547607421875 130.704986572265625 129.097198486328125 128.942901611328125 128.101409912109375 127.8238067626953125 127.339080810546875 127.6819305419921875 120.0684051513671875 127.27463531494140625 120.37653350830078125 120.607391357421875 107.25165557861328125 116.0498809814453125 111.54998779296875 104.24134063720703125 102.2566375732421875 102.5301055908203125 111.47536468505859375 105.3060760498046875 99.06587982177734375 100.4687347412109375 103.9506072998046875 96.3029632568359375 96.043365478515625 95.3133392333984375 95.123748779296875 95.94617462158203125 97.8642730712890625 96.520843505859375 99.9500579833984375 99.49764251708984375 100.09814453125 99.3551025390625 101.94451904296875 104.306365966796875 100.4032745361328125 104.8835906982421875 102.90462493896484375 100.2828216552734375 98.3549041748046875 98.3633575439453125 96.51116180419921875
 93.342681884765625 93.9972076416015625 92.1410369873046875 89.6566162109375 85.71701812744140625 85.76163482666015625 85.7412872314453125 85.70953369140625 85.64984130859375 85.61936187744140625 85.588897705078125 85.55829620361328125 85.5303497314453125 85.39710235595703125 85.00384521484375 84.712005615234375 84.32776641845703125 84.09014129638671875 83.57216644287109375 89.275909423828125 82.356201171875 82.10381317138671875 81.91008758544921875 81.7129058837890625 80.5328369140625 79.37985992431640625 78.44846343994140625 78.822784423828125 78.71155548095703125 78.96610260009765625 78.03162384033203125 78.6405792236328125 78.09574127197265625 77.05181884765625 77.98816680908203125 77.98926544189453125 78.48089599609375 78.338287353515625 87.24198150634765625 85.78417205810546875 88.33582305908203125 91.47231292724609375 96.54349517822265625 100.03878021240234375 105.628173828125 107.09175872802734375 102.17829132080078125 96.6338348388671875 96.90331268310546875 94.9669113159179
 6875 90.42014312744140625 88.34842681884765625 86.46897125244140625 86.141632080078125 84.92142486572265625 74.664093017578125 75.2109375 75.1360015869140625 78.4378662109375 81.49335479736328125 86.346160888671875 89.75005340576171875 94.03264617919921875 91.82683563232421875 86.61934661865234375 90.89665985107421875 98.3406829833984375 101.63103485107421875 96.88030242919921875 96.58092498779296875 96.51747894287109375 90.68239593505859375 89.86379241943359375 84.0193328857421875 86.17090606689453125 91.399993896484375 96.4113006591796875 99.552093505859375 97.6982879638671875 97.62316131591796875 91.60831451416015625 87.07550811767578125 85.30507659912109375 87.8668060302734375 92.1679229736328125 97.07338714599609375 98.72269439697265625 94.18038177490234375 86.98638916015625 90.33661651611328125 87.764801025390625 86.16017913818359375 88.43206787109375 94.4063568115234375 97.09554290771484375 100.23332977294921875 100.92314910888671875 99.257110595703125 95.942169189453125 92.2
 0352935791015625 86.7970123291015625
+ 134.6531219482421875 129.3896331787109375 133.4991912841796875 138.04510498046875 138.2426910400390625 138.540740966796875 136.86614990234375 131.2526397705078125 135.547454833984375 136.6641998291015625 132.7601165771484375 130.589263916015625 132.9482879638671875 131.305999755859375 129.4203033447265625 133.770660400390625 128.749847412109375 119.08617401123046875 120.677215576171875 114.3908843994140625 119.58191680908203125 106.85541534423828125 117.31812286376953125 114.4953155517578125 126.0807952880859375 117.21984100341796875 123.478973388671875 116.5780792236328125 120.98424530029296875 119.507965087890625 116.9334869384765625 95.43042755126953125 94.659576416015625 93.92279052734375 93.96912384033203125 93.0968780517578125 97.07283782958984375 98.1616668701171875 97.9619598388671875 94.8135528564453125 97.7935791015625 100.5016326904296875 99.777557373046875 99.59995269775390625 95.5673065185546875 94.9435577392578125 91.8654022216796875 90.0014801025390625 88.73982238769
 53125 88.62445068359375 88.1195831298828125 86.34366607666015625 85.865142822265625 85.80236053466796875 85.78656005859375 85.770294189453125 85.71268463134765625 85.6588897705078125 85.605560302734375 85.5888214111328125 85.55654144287109375 85.50064849853515625 85.36215972900390625 84.91649627685546875 84.70143890380859375 84.30947113037109375 84.0705413818359375 83.47686004638671875 83.0145111083984375 82.7948455810546875 82.3768310546875 82.19542694091796875 81.9172210693359375 79.5736236572265625 78.44425201416015625 78.906982421875 78.607666015625 79.5537567138671875 79.414581298828125 78.2111968994140625 77.90131378173828125 77.94844818115234375 77.6499176025390625 77.44159698486328125 77.64697265625 77.4718170166015625 77.205810546875 78.11522674560546875 84.23561859130859375 88.7400054931640625 93.43630218505859375 99.990478515625 104.54233551025390625 106.39015960693359375 102.1125946044921875 101.8895721435546875 96.969024658203125 89.95569610595703125 89.7881851196289062
 5 86.00018310546875 84.55516815185546875 80.0002593994140625 79.05869293212890625 76.15505218505859375 74.61698150634765625 74.60878753662109375 74.803375244140625 77.5937042236328125 80.0970458984375 83.673828125 89.631866455078125 94.15386962890625 86.5770111083984375 87.9810943603515625 96.1491546630859375 95.3334808349609375 99.88895416259765625 98.08110809326171875 91.8286285400390625 90.4677886962890625 86.72086334228515625 85.27001190185546875 80.59560394287109375 84.9599456787109375 90.979095458984375 95.25016021728515625 98.5821533203125 93.8611602783203125 95.626068115234375 93.50492095947265625 86.02393341064453125 87.8827972412109375 93.90142822265625 96.08921051025390625 98.66132354736328125 98.977569580078125 94.83422088623046875 88.12451934814453125 86.78688812255859375 85.1003265380859375 86.2065277099609375 89.19681549072265625 93.7513427734375 98.21445465087890625 99.17035675048828125 97.5420989990234375 95.34217071533203125 89.454010009765625 88.55843353271484375
 86.470733642578125
+ 128.5970001220703125 123.386444091796875 128.3559722900390625 131.6408233642578125 133.7724761962890625 138.0798797607421875 139.017181396484375 136.4813232421875 137.1886138916015625 142.058685302734375 135.603118896484375 132.7125701904296875 136.9993438720703125 134.647674560546875 128.263397216796875 135.3497314453125 127.12064361572265625 118.8497314453125 125.926910400390625 126.4792938232421875 123.295135498046875 110.66751861572265625 120.37255096435546875 125.57366943359375 123.62433624267578125 119.1879119873046875 119.0009918212890625 117.406158447265625 116.4389801025390625 112.67432403564453125 113.11872100830078125 108.83563232421875 94.7796478271484375 94.38646697998046875 93.43129730224609375 92.98291778564453125 92.260955810546875 92.35523223876953125 92.6213531494140625 92.0512542724609375 92.57906341552734375 91.78558349609375 93.54860687255859375 93.122314453125 89.08837890625 88.65529632568359375 87.294464111328125 86.37644195556640625 85.98728179931640625 85.9
 544677734375 85.92421722412109375 85.8936920166015625 85.8632049560546875 85.83272552490234375 85.80529022216796875 93.27813720703125 85.74539947509765625 85.65289306640625 85.59112548828125 85.55840301513671875 85.527923583984375 85.49674224853515625 85.31206512451171875 84.97818756103515625 84.6467132568359375 84.30968475341796875 84.010467529296875 83.54863739013671875 83.1927490234375 82.92035675048828125 82.65047454833984375 82.4457855224609375 82.53143310546875 82.5578155517578125 82.62249755859375 80.8909759521484375 80.4390869140625 79.68183135986328125 78.67691802978515625 78.10367584228515625 77.76688385009765625 77.618072509765625 76.3809356689453125 77.026397705078125 77.2332000732421875 77.27628326416015625 78.02911376953125 86.47797393798828125 84.15685272216796875 92.036346435546875 94.1306915283203125 102.02138519287109375 106.6686553955078125 102.12896728515625 96.59008026123046875 98.371917724609375 95.3050537109375 92.3369598388671875 86.86734771728515625 83.96538
 543701171875 84.84502410888671875 88.1047515869140625 86.564300537109375 84.4510345458984375 74.18195343017578125 74.189605712890625 74.50063323974609375 75.61408233642578125 81.316131591796875 86.71257781982421875 90.2929229736328125 89.024383544921875 82.3664703369140625 92.3411407470703125 98.789581298828125 99.70763397216796875 100.612152099609375 101.00313568115234375 96.50035858154296875 90.5175018310546875 92.932037353515625 85.6905517578125 80.815826416015625 83.71260833740234375 89.03078460693359375 93.3674774169921875 97.63623809814453125 91.19301605224609375 88.3681640625 88.93766021728515625 84.6712188720703125 86.10355377197265625 93.41564178466796875 96.9537353515625 96.773895263671875 95.34526824951171875 90.721923828125 87.9705047607421875 83.0096893310546875 83.00926971435546875 88.82566070556640625 94.35129547119140625 95.96648406982421875 97.307861328125 98.533966064453125 94.99668121337890625 94.783447265625 96.5638275146484375 85.3759613037109375 85.280212402343
 75
+ 120.82723236083984375 126.482330322265625 131.3605194091796875 134.7197113037109375 138.593994140625 141.036590576171875 141.2475128173828125 140.739044189453125 140.6124420166015625 141.84393310546875 138.6820526123046875 137.065155029296875 138.5654144287109375 136.952972412109375 136.204742431640625 136.879730224609375 128.197052001953125 128.56793212890625 128.249908447265625 132.109405517578125 122.9207000732421875 110.61820220947265625 123.985076904296875 126.3574981689453125 116.99825286865234375 112.3280181884765625 109.30455780029296875 107.73513031005859375 104.57958984375 104.0589141845703125 100.201934814453125 98.783111572265625 97.2971343994140625 98.33295440673828125 94.1252288818359375 92.90471649169921875 92.09105682373046875 91.70650482177734375 91.30340576171875 91.23089599609375 90.90894317626953125 90.08636474609375 89.8813934326171875 88.16820526123046875 87.8294219970703125 87.10359954833984375 87.46445465087890625 86.58989715576171875 97.3609161376953125 88.
 24016571044921875 93.1092529296875 88.01678466796875 85.90118408203125 91.40633392333984375 104.1060638427734375 101.095672607421875 85.65789031982421875 85.56124114990234375 85.55840301513671875 85.61858367919921875 85.59293365478515625 85.5765533447265625 85.31061553955078125 84.9724578857421875 84.61437225341796875 84.2847137451171875 83.97623443603515625 83.6715087890625 83.34290313720703125 83.06882476806640625 82.79241180419921875 82.5902862548828125 90.79346466064453125 90.2682342529296875 86.87244415283203125 86.09686279296875 83.94568634033203125 82.2044219970703125 79.89888763427734375 78.48983001708984375 77.96166229248046875 77.6678924560546875 77.2148284912109375 76.62352752685546875 76.93907928466796875 77.16413116455078125 80.0074310302734375 80.1897430419921875 85.448516845703125 92.44066619873046875 95.0066986083984375 102.01459503173828125 102.257537841796875 100.154083251953125 92.39728546142578125 95.1801910400390625 93.03717803955078125 93.27997589111328125 91.7
 285919189453125 95.40676116943359375 92.8963775634765625 98.03124237060546875 94.46974945068359375 84.75125885009765625 74.79195404052734375 73.88674163818359375 74.28592681884765625 74.04734039306640625 78.47418975830078125 85.55706024169921875 85.33182525634765625 80.10468292236328125 87.39716339111328125 94.69077301025390625 93.632354736328125 99.9463348388671875 101.3838348388671875 103.2760467529296875 100.68312835693359375 97.29412841796875 94.18442535400390625 87.842254638671875 82.143951416015625 85.17507171630859375 93.21074676513671875 94.9665985107421875 95.13402557373046875 95.79650115966796875 91.4149017333984375 86.6952056884765625 81.845855712890625 90.72180938720703125 96.06160736083984375 95.94290924072265625 94.4007568359375 94.98882293701171875 89.05028533935546875 84.94805908203125 81.367462158203125 85.675872802734375 89.87189483642578125 95.725433349609375 97.00800323486328125 96.387603759765625 96.4911346435546875 99.50894927978515625 99.05892181396484375 92.4
 9224090576171875 84.7965850830078125 88.140899658203125
+ 121.1121826171875 129.046417236328125 131.914306640625 134.081878662109375 136.263671875 139.7578887939453125 137.2089080810546875 136.430816650390625 139.3782806396484375 139.1170654296875 135.8148345947265625 133.0280609130859375 134.236297607421875 139.849609375 138.617645263671875 130.45074462890625 126.76595306396484375 131.56329345703125 130.9305419921875 133.2145538330078125 125.1385040283203125 113.27347564697265625 125.85848236083984375 122.26827239990234375 116.78871917724609375 122.75077056884765625 118.51174163818359375 119.31279754638671875 112.9987030029296875 106.47646331787109375 104.79888916015625 110.1621856689453125 106.1528167724609375 101.9574127197265625 109.23610687255859375 95.486358642578125 92.77400970458984375 93.25312042236328125 91.02300262451171875 90.92449951171875 90.51313018798828125 90.08769989013671875 89.625885009765625 88.5135498046875 88.2010040283203125 94.693328857421875 98.462158203125 101.66546630859375 106.625701904296875 99.81585693359375
  103.92519378662109375 110.47908782958984375 106.387298583984375 106.6993255615234375 104.54305267333984375 103.01617431640625 100.115875244140625 85.55840301513671875 85.5557861328125 85.6969757080078125 85.71196746826171875 85.67800140380859375 85.3135528564453125 84.9493560791015625 84.62079620361328125 84.26763916015625 83.9760894775390625 83.7283935546875 83.4616241455078125 83.1616973876953125 82.95632171630859375 82.6732330322265625 93.45679473876953125 93.84792327880859375 89.17718505859375 87.0867767333984375 84.8946075439453125 83.25643157958984375 80.12481689453125 79.23976898193359375 79.12221527099609375 77.45217132568359375 77.3791656494140625 77.16349029541015625 76.8831787109375 76.89931488037109375 77.91172027587890625 80.72354888916015625 85.95806884765625 90.72692108154296875 92.09822845458984375 91.527923583984375 97.42180633544921875 97.87116241455078125 89.59586334228515625 90.09039306640625 89.0568695068359375 92.84243011474609375 95.9130096435546875 100.24893
 1884765625 102.1776580810546875 99.2701263427734375 87.35874176025390625 87.44852447509765625 73.97733306884765625 74.139984130859375 73.76770782470703125 74.09551239013671875 74.22168731689453125 81.4190521240234375 78.877197265625 84.8092041015625 90.32117462158203125 87.95963287353515625 95.37281036376953125 99.674041748046875 101.436309814453125 96.73896026611328125 95.6587982177734375 95.06683349609375 93.9814605712890625 89.89145660400390625 83.31771087646484375 83.37313079833984375 90.77288055419921875 95.07073211669921875 93.252960205078125 94.47040557861328125 90.05864715576171875 88.28696441650390625 81.205841064453125 88.32126617431640625 91.293243408203125 94.632568359375 91.6421051025390625 93.4737396240234375 89.19305419921875 82.4364013671875 82.7187957763671875 83.95633697509765625 87.26245880126953125 89.042633056640625 94.48874664306640625 97.3452606201171875 97.7651214599609375 97.5760345458984375 95.905364990234375 92.9802398681640625 83.9603729248046875 86.68135
 07080078125
+ 126.81766510009765625 127.80682373046875 129.9361114501953125 134.3807525634765625 136.4519500732421875 136.017364501953125 132.688568115234375 134.0315704345703125 140.3663330078125 138.4269866943359375 132.68994140625 135.3219146728515625 132.7650604248046875 137.6019744873046875 139.65234375 138.83154296875 133.2760467529296875 137.51904296875 136.703948974609375 136.6067657470703125 130.1389923095703125 116.23822021484375 123.8232574462890625 118.72121429443359375 122.98603057861328125 128.4220733642578125 123.73171234130859375 114.94461822509765625 107.2300567626953125 119.52408599853515625 109.68265533447265625 117.09305572509765625 110.8402862548828125 105.79145050048828125 114.88694000244140625 117.01197052001953125 108.50750732421875 98.5393524169921875 108.9296875 92.76149749755859375 89.91794586181640625 89.8755035400390625 89.83399200439453125 89.2290496826171875 88.27044677734375 91.62640380859375 96.16680145263671875 107.4608154296875 114.18906402587890625 108.1828536
 9873046875 110.52136993408203125 108.77519989013671875 106.25960540771484375 104.1487884521484375 101.94928741455078125 100.0018310546875 97.57386016845703125 97.3891754150390625 87.71987152099609375 85.80146026611328125 85.85175323486328125 85.78377532958984375 85.34001922607421875 84.9798431396484375 84.71347808837890625 84.2826690673828125 84.0366973876953125 83.7774505615234375 83.5452423095703125 88.50189208984375 83.04573822021484375 88.9448394775390625 101.123199462890625 99.5606842041015625 91.49395751953125 88.01691436767578125 85.68682098388671875 81.35811614990234375 83.79962921142578125 84.61908721923828125 78.288116455078125 77.6555633544921875 77.253662109375 76.75049591064453125 77.12335205078125 76.73502349853515625 77.55680084228515625 78.512481689453125 79.36209869384765625 81.47431182861328125 88.303680419921875 87.2976531982421875 88.86594390869140625 90.79291534423828125 89.07459259033203125 85.97461700439453125 91.35153961181640625 95.1817169189453125 99.762626
 64794921875 104.69715118408203125 105.96804046630859375 99.64788818359375 97.407745361328125 89.30379486083984375 73.7198486328125 73.459075927734375 73.5398101806640625 73.5162811279296875 74.34529876708984375 75.81507110595703125 79.8671722412109375 83.0012969970703125 84.62203216552734375 89.84934234619140625 96.3526763916015625 102.70200347900390625 101.21851348876953125 99.43558502197265625 94.87940216064453125 90.58606719970703125 87.7998199462890625 86.82189178466796875 80.31795501708984375 80.65203094482421875 83.48557281494140625 86.41974639892578125 90.20691680908203125 92.4498443603515625 88.2305450439453125 85.96514892578125 80.19953155517578125 89.5096588134765625 92.54570770263671875 92.5359649658203125 86.397491455078125 88.957305908203125 86.17748260498046875 79.56072998046875 86.09358978271484375 87.7154693603515625 87.18502044677734375 93.60532379150390625 96.41532135009765625 98.36408233642578125 94.33841705322265625 90.65940093994140625 91.1042327880859375 89.906
 280517578125 83.25853729248046875 86.2197418212890625
+ 127.53765869140625 131.9288787841796875 133.655670166015625 133.8411865234375 130.9111785888671875 126.9639129638671875 132.0006103515625 133.1673126220703125 137.008026123046875 140.646697998046875 137.7298736572265625 132.3323822021484375 131.7333831787109375 136.7805023193359375 139.9254608154296875 141.5179443359375 135.16748046875 132.959381103515625 129.874542236328125 127.59461212158203125 118.7603607177734375 124.40563201904296875 123.68076324462890625 125.11180877685546875 126.661834716796875 124.551971435546875 115.1686248779296875 111.41582489013671875 117.2414703369140625 122.562103271484375 116.91893768310546875 120.57488250732421875 112.277435302734375 111.92806243896484375 115.650177001953125 120.11408233642578125 110.67414093017578125 104.90758514404296875 113.14623260498046875 98.16741180419921875 108.7287139892578125 101.5643768310546875 100.15538787841796875 103.8960723876953125 99.52767181396484375 97.0216522216796875 107.08905792236328125 105.8254241943359375 1
 14.12578582763671875 112.8378143310546875 109.83785247802734375 105.4649200439453125 102.9773712158203125 100.7553253173828125 97.05548095703125 95.34272003173828125 92.91687774658203125 91.16143798828125 88.6697845458984375 86.25841522216796875 86.04305267333984375 85.8094635009765625 85.70609283447265625 85.173187255859375 99.42353057861328125 84.59333038330078125 84.06847381591796875 83.833465576171875 89.889556884765625 100.26728057861328125 96.76450347900390625 87.947113037109375 102.43767547607421875 103.1921539306640625 97.5411834716796875 90.982757568359375 85.61791229248046875 81.76920318603515625 87.47359466552734375 89.71124267578125 83.488616943359375 79.17205047607421875 77.15502166748046875 76.5013885498046875 76.5777130126953125 77.88735198974609375 76.85042572021484375 77.93072509765625 78.15938568115234375 78.23699951171875 80.189239501953125 82.1058502197265625 82.138916015625 83.49095916748046875 83.390472412109375 86.84024810791015625 93.3971099853515625 96.79272
 4609375 100.0316162109375 104.06818389892578125 103.90560150146484375 99.785003662109375 91.43054962158203125 93.09735107421875 87.32144927978515625 76.25099945068359375 73.490081787109375 73.66944122314453125 73.891143798828125 76.35056304931640625 78.9320068359375 81.64288330078125 88.70337677001953125 94.5649871826171875 99.280181884765625 95.21985626220703125 96.2175445556640625 98.023406982421875 98.42919921875 93.860565185546875 90.14861297607421875 81.67049407958984375 78.521484375 80.1485137939453125 87.3802642822265625 90.85907745361328125 93.743927001953125 96.23740386962890625 90.13677978515625 85.62933349609375 82.0198974609375 88.6494140625 89.716949462890625 92.52159881591796875 88.82463836669921875 82.08599090576171875 83.97316741943359375 81.56992340087890625 86.6014556884765625 91.27803802490234375 92.0763397216796875 92.5041656494140625 96.9310302734375 98.602020263671875 98.92514801025390625 96.9400482177734375 93.69702911376953125 88.2595367431640625 83.331634521
 484375 83.7658233642578125
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.nc
(Binary files differ)
Property changes on: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.nc
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.prj
--- grass/trunk/raster/r.in.gdal/testsuite/data/elevation.prj	                        (rev 0)
+++ grass/trunk/raster/r.in.gdal/testsuite/data/elevation.prj	2015-11-02 12:11:17 UTC (rev 66714)
@@ -0,0 +1 @@
+PROJCS["Lambert_Conformal_Conic",GEOGCS["GCS_grs80",DATUM["D_North_American_1983",SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["standard_parallel_1",36.16666666666666],PARAMETER["standard_parallel_2",34.33333333333334],PARAMETER["latitude_of_origin",33.75],PARAMETER["central_meridian",-79],PARAMETER["false_easting",609601.22],PARAMETER["false_northing",0],UNIT["Meter",1]]
\ No newline at end of file
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tif
Property changes on: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tif
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tiff
Property changes on: grass/trunk/raster/r.in.gdal/testsuite/data/elevation.tiff
Added: grass/trunk/raster/r.in.gdal/testsuite/data/elevation3d.nc
Property changes on: grass/trunk/raster/r.in.gdal/testsuite/data/elevation3d.nc
Added: grass/trunk/raster/r.in.gdal/testsuite/data/generate_data.sh
--- grass/trunk/raster/r.in.gdal/testsuite/data/generate_data.sh	                        (rev 0)
+++ grass/trunk/raster/r.in.gdal/testsuite/data/generate_data.sh	2015-11-02 12:11:17 UTC (rev 66714)
@@ -0,0 +1,20 @@
+#!/bin/bash
+# This script requires the graass7 North Caroline location
+export GRASS_OVERWRITE=1
+# 2D output
+g.region rast=elevation -p
+g.region res=100 -p
+r.out.gdal in=elevation out=elevation.tif format=GTiff
+r.out.gdal in=elevation out=elevation.tiff format=GTiff
+r.out.gdal in=elevation out=elevation.asc format=AAIGrid
+r.out.gdal in=elevation out=elevation.nc format=netCDF
+# 3D output
+g.region b=0 t=5 res3=100 tbres=1 -p3
+r.to.rast3 input=elevation output=elevation3d
+r3.out.netcdf input=elevation3d out=elevation3d.nc
Added: grass/trunk/raster/r.in.gdal/testsuite/test_r_in_gdal.py
--- grass/trunk/raster/r.in.gdal/testsuite/test_r_in_gdal.py	                        (rev 0)
+++ grass/trunk/raster/r.in.gdal/testsuite/test_r_in_gdal.py	2015-11-02 12:11:17 UTC (rev 66714)
@@ -0,0 +1,291 @@
+"""Test of r.in.gdal
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+class TestGdalImport(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Use temporary region settings"""
+        cls.use_temp_region()
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        cls.del_temp_region()
+    def tearDown(self):
+        self.runModule("g.remove", type="raster", flags="f",
+                       pattern="test_gdal_import_map*")
+    def test_1(self):
+        self.assertModule("r.in.gdal", "Import GTiff Format",
+                          input="data/elevation.tif",
+                          output="test_gdal_import_map")
+        self.runModule("g.region", raster="test_gdal_import_map")
+        # Output of r.univar
+        univar_string="""n=20250
+                         null_cells=0
+                         cells=20250
+                         min=56.1364936828613
+                         max=156.221710205078
+                         range=100.085216522217
+                         mean=110.358078733845
+                         mean_of_abs=110.358078733845
+                         stddev=20.3247267738233
+                         variance=413.09451843057
+                         coeff_var=18.4170719597623
+                         sum=2234751.09436035"""
+        self.assertRasterFitsUnivar(raster="test_gdal_import_map",  reference=univar_string,
+                                    precision=3)
+    def test_2(self):
+                          input="data/elevation.tiff",
+                         null_cells=0
+                         cells=20250
+                                    precision=3)
+    def test_3(self):
+        self.assertModule("r.in.gdal", "Import AAIGrid Format",
+                          input="data/elevation.asc",
+                         null_cells=0
+                         cells=20250
+                                    precision=3)
+    def test_4(self):
+        self.assertModule("r.in.gdal", "Import netCDF Format",
+                          input="data/elevation.nc",
+                         null_cells=0
+                         cells=20250
+                                    precision=3)
+    def test_netCDF_3d_1(self):
+                          input="data/elevation3d.nc",
+                          num_digits="3",
+                          flags="o",
+        # Output of r.info
+        info_string="""north=228500
+                       south=215000
+                       east=644640
+                       west=629640
+                       nsres=100
+                       ewres=100
+                       rows=135
+                       cols=150
+                       cells=20250
+                       datatype=FCELL
+                       ncats=0"""
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.001",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.002",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.003",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.004",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.005",  reference=info_string,
+                                    precision=3)
+    def test_netCDF_3d_2(self):
+                          num_digits=0,
+                          offset=100,
+                          flags="o",
+                       south=215000
+                       east=644640
+                       west=629640
+                       nsres=100
+                       ewres=100
+                       rows=135
+                       cols=150
+                       cells=20250
+                       datatype=FCELL
+                       ncats=0"""
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.101",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.102",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.103",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.104",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.105",  reference=info_string,
+                                    precision=3)
+    def test_netCDF_3d_3(self):
+                          num_digits=5,
+                          offset=100,
+                          flags="o",
+                       south=215000
+                       east=644640
+                       west=629640
+                       nsres=100
+                       ewres=100
+                       rows=135
+                       cols=150
+                       cells=20250
+                       datatype=FCELL
+                       ncats=0"""
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.00101",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.00102",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.00103",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.00104",  reference=info_string,
+                                    precision=3)
+        self.assertRasterFitsInfo(raster="test_gdal_import_map.00105",  reference=info_string,
+                                    precision=3)
+    def test_netCDF_3d_4(self):
+                          num_digits="3",
+                          flags="o",
+                          band=2,
+                       south=215000
+                       east=644640
+                       west=629640
+                       nsres=100
+                       ewres=100
+                       rows=135
+                       cols=150
+                       cells=20250
+                       datatype=FCELL
+                       ncats=0"""
+        self.assertRasterFitsInfo(raster="test_gdal_import_map",  reference=info_string,
+                                    precision=3)
+    def test_netCDF_3d_5(self):
+        """Test the output map names file option"""
+                          num_digits=10,
+                          offset=100,
+                          flags="o",
+                          map_names_file="map_names_file.txt",
+        map_list="""test_gdal_import_map.0000000101
+test_gdal_import_map.0000000102
+test_gdal_import_map.0000000103
+test_gdal_import_map.0000000104
+test_gdal_import_map.0000000105
+        text_from_file = open("map_names_file.txt", "r").read()
+        self.assertLooksLike(map_list, text_from_file)
+class TestGdalImportFails(TestCase):
+    def test_error_handling_1(self):
+        # Wrong number of digits
+        self.assertModuleFail("r.in.gdal",
+                              num_digits="-1",
+    def test_error_handling_2(self):
+        # No location specified
+                              flags="c",
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
