[GRASS-SVN] r66742 - grass/trunk/scripts/v.rast.stats/testsuite
Wed Nov 4 04:59:21 PST 2015
Author: neteler
Date: 2015-11-04 04:59:20 -0800 (Wed, 04 Nov 2015)
New Revision: 66742
   grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
test_v_rast_stats.py: fix indentation. TODO: understand pass in tearDown()
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2015-11-04 12:51:20 UTC (rev 66741)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2015-11-04 12:59:20 UTC (rev 66742)
@@ -19,7 +19,7 @@
         cls.del_temp_region()
     def tearDown(self):
-    	pass
+        pass
         self.runModule("g.remove", flags='f', type="raster", name="map_a")
         self.runModule("g.remove", flags='f', type="raster", name="map_b")
         self.runModule("g.remove", flags='f', type="raster", name="zone_map")
@@ -46,9 +46,9 @@
                           method=["minimum","maximum","sum"], flags="c",
                           column_prefix="a")
         v_db_select = SimpleModule("v.db.select", map="zone_map")
-	self.runModule(v_db_select)
-	self.assertLooksLike(univar_string, v_db_select.outputs.stdout)
+        self.runModule(v_db_select)
+        self.assertLooksLike(univar_string, v_db_select.outputs.stdout)
 class TestRastStatsFails(TestCase):
