[GRASS-SVN] r66773 - grass/trunk/lib/db/stubs
Mon Nov 9 04:06:44 PST 2015
Author: glynn
Date: 2015-11-09 04:06:44 -0800 (Mon, 09 Nov 2015)
New Revision: 66773
   grass/trunk/lib/db/stubs/add_col.c
   grass/trunk/lib/db/stubs/bindupdate.c
   grass/trunk/lib/db/stubs/close_cursor.c
   grass/trunk/lib/db/stubs/closedb.c
   grass/trunk/lib/db/stubs/create_index.c
   grass/trunk/lib/db/stubs/create_table.c
   grass/trunk/lib/db/stubs/createdb.c
   grass/trunk/lib/db/stubs/delete.c
   grass/trunk/lib/db/stubs/deletedb.c
   grass/trunk/lib/db/stubs/desc_table.c
   grass/trunk/lib/db/stubs/drop_col.c
   grass/trunk/lib/db/stubs/drop_index.c
   grass/trunk/lib/db/stubs/drop_table.c
   grass/trunk/lib/db/stubs/execute.c
   grass/trunk/lib/db/stubs/fetch.c
   grass/trunk/lib/db/stubs/finddb.c
   grass/trunk/lib/db/stubs/finish.c
   grass/trunk/lib/db/stubs/init.c
   grass/trunk/lib/db/stubs/insert.c
   grass/trunk/lib/db/stubs/list_index.c
   grass/trunk/lib/db/stubs/list_tables.c
   grass/trunk/lib/db/stubs/listdb.c
   grass/trunk/lib/db/stubs/open_insert.c
   grass/trunk/lib/db/stubs/open_select.c
   grass/trunk/lib/db/stubs/open_update.c
   grass/trunk/lib/db/stubs/opendb.c
   grass/trunk/lib/db/stubs/priv.c
   grass/trunk/lib/db/stubs/rows.c
   grass/trunk/lib/db/stubs/transaction.c
   grass/trunk/lib/db/stubs/update.c
Include dbstubs.h, fix prototypes for open_select_cursor and describe_table
Modified: grass/trunk/lib/db/stubs/add_col.c
--- grass/trunk/lib/db/stubs/add_col.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/add_col.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 #include <grass/dbmi.h>
+#include <grass/dbstubs.h>
    This function calls db_procedure_not_implemented().
Modified: grass/trunk/lib/db/stubs/bindupdate.c
--- grass/trunk/lib/db/stubs/bindupdate.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/bindupdate.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
    \fn int db__driver_bind_update (cursor)
Modified: grass/trunk/lib/db/stubs/close_cursor.c
--- grass/trunk/lib/db/stubs/close_cursor.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/close_cursor.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
Modified: grass/trunk/lib/db/stubs/closedb.c
--- grass/trunk/lib/db/stubs/closedb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/closedb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_close_database(void)
Modified: grass/trunk/lib/db/stubs/create_index.c
--- grass/trunk/lib/db/stubs/create_index.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/create_index.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_create_index(dbIndex * index)
Modified: grass/trunk/lib/db/stubs/create_table.c
--- grass/trunk/lib/db/stubs/create_table.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/create_table.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_create_table(dbTable * table)
Modified: grass/trunk/lib/db/stubs/createdb.c
--- grass/trunk/lib/db/stubs/createdb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/createdb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_create_database(dbHandle * handle)
Modified: grass/trunk/lib/db/stubs/delete.c
--- grass/trunk/lib/db/stubs/delete.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/delete.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_delete(dbCursor * cursor)
Modified: grass/trunk/lib/db/stubs/deletedb.c
--- grass/trunk/lib/db/stubs/deletedb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/deletedb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_delete_database(dbHandle * handle)
Modified: grass/trunk/lib/db/stubs/desc_table.c
--- grass/trunk/lib/db/stubs/desc_table.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/desc_table.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,6 +1,7 @@
-int db__driver_describe_table(dbString * name, dbTable * table)
+int db__driver_describe_table(dbString * name, dbTable ** table)
     db_procedure_not_implemented("db_describe_table");
     return DB_FAILED;
Modified: grass/trunk/lib/db/stubs/drop_col.c
--- grass/trunk/lib/db/stubs/drop_col.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/drop_col.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_drop_column(dbString * tableName, dbString * columnName)
Modified: grass/trunk/lib/db/stubs/drop_index.c
--- grass/trunk/lib/db/stubs/drop_index.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/drop_index.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_drop_index(dbString * name)
Modified: grass/trunk/lib/db/stubs/drop_table.c
--- grass/trunk/lib/db/stubs/drop_table.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/drop_table.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_drop_table(dbString * name)
Modified: grass/trunk/lib/db/stubs/execute.c
--- grass/trunk/lib/db/stubs/execute.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/execute.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_execute_immediate(dbString * SQLstatement)
Modified: grass/trunk/lib/db/stubs/fetch.c
--- grass/trunk/lib/db/stubs/fetch.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/fetch.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_fetch(dbCursor * cursor, int position, int *more)
Modified: grass/trunk/lib/db/stubs/finddb.c
--- grass/trunk/lib/db/stubs/finddb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/finddb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_find_database(dbHandle * handle, int *found)
Modified: grass/trunk/lib/db/stubs/finish.c
--- grass/trunk/lib/db/stubs/finish.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/finish.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_finish(void)
Modified: grass/trunk/lib/db/stubs/init.c
--- grass/trunk/lib/db/stubs/init.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/init.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_init(int argc, char *argv[])
Modified: grass/trunk/lib/db/stubs/insert.c
--- grass/trunk/lib/db/stubs/insert.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/insert.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_insert(dbCursor * cursor)
Modified: grass/trunk/lib/db/stubs/list_index.c
--- grass/trunk/lib/db/stubs/list_index.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/list_index.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int
 db__driver_list_indexes(dbString * tableName, dbIndex ** indexes, int *count)
Modified: grass/trunk/lib/db/stubs/list_tables.c
--- grass/trunk/lib/db/stubs/list_tables.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/list_tables.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_list_tables(dbString ** names, int *count, int system)
Modified: grass/trunk/lib/db/stubs/listdb.c
--- grass/trunk/lib/db/stubs/listdb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/listdb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int
 db__driver_list_databases(dbString * path, int npaths, dbHandle ** handles,
Modified: grass/trunk/lib/db/stubs/open_insert.c
--- grass/trunk/lib/db/stubs/open_insert.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/open_insert.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_open_insert_cursor(dbCursor * cursor)
Modified: grass/trunk/lib/db/stubs/open_select.c
--- grass/trunk/lib/db/stubs/open_select.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/open_select.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,7 +1,8 @@
 int
-db__driver_open_select_cursor(dbString * select, dbCursor * cursor, int *mode)
+db__driver_open_select_cursor(dbString * select, dbCursor * cursor, int mode)
     db_procedure_not_implemented("db_open_select_cursor");
     return DB_FAILED;
Modified: grass/trunk/lib/db/stubs/open_update.c
--- grass/trunk/lib/db/stubs/open_update.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/open_update.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int
 db__driver_open_update_cursor(dbString * name, dbString * select,
Modified: grass/trunk/lib/db/stubs/opendb.c
--- grass/trunk/lib/db/stubs/opendb.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/opendb.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_open_database(dbHandle * handle)
Modified: grass/trunk/lib/db/stubs/priv.c
--- grass/trunk/lib/db/stubs/priv.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/priv.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_grant_on_table(dbString * tableName, int priv, int to)
Modified: grass/trunk/lib/db/stubs/rows.c
--- grass/trunk/lib/db/stubs/rows.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/rows.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_get_num_rows(dbCursor * cursor)
Modified: grass/trunk/lib/db/stubs/transaction.c
--- grass/trunk/lib/db/stubs/transaction.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/transaction.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 /* Implemented only in some drivers */
 int db__driver_begin_transaction(void)
Modified: grass/trunk/lib/db/stubs/update.c
--- grass/trunk/lib/db/stubs/update.c	2015-11-09 11:47:38 UTC (rev 66772)
+++ grass/trunk/lib/db/stubs/update.c	2015-11-09 12:06:44 UTC (rev 66773)
@@ -1,4 +1,5 @@
 int db__driver_update(dbCursor * cursor)
