[GRASS-SVN] r66836 - grass-addons/tools/addons
Sun Nov 15 05:17:01 PST 2015
Author: neteler
Date: 2015-11-15 05:17:01 -0800 (Sun, 15 Nov 2015)
New Revision: 66836
   grass-addons/tools/addons/README.txt
   grass-addons/tools/addons/grass-addons-index.sh
addons: hints added
Modified: grass-addons/tools/addons/README.txt
--- grass-addons/tools/addons/README.txt	2015-11-15 13:06:17 UTC (rev 66835)
+++ grass-addons/tools/addons/README.txt	2015-11-15 13:17:01 UTC (rev 66836)
@@ -4,25 +4,27 @@
 WORKFLOW
-On building server (currently geo102.fsv.cvut.cz) are runing two
-scripts (see crontab.build):
+On building server (currently geo102.fsv.cvut.cz) two scripts are
+running (see file crontab.build):
-1) grass-addons.sh to recompile GRASS Addons locally
+1) grass-addons.sh to recompile GRASS Addons on it;
 2) grass-addons-build.sh to create addons packages, the script
-provides tarballs with created addons manual pages and logs for
-publishing.
+   provides tarballs with created addons manual pages and logs for
+   publication on the publishing server.
-On publishing server (grass.osgeo.org) is running one script (see
-crontab.publish):
+   On publishing server (grass.osgeo.org) one script is running (see
+   file crontab.publish):
 3) grass-addons-publish.sh downloads provided tarballs (2) from
-building server and creates index.html page on publishing server.
+   building server and creates index.html page on publishing server at
+   https://grass.osgeo.org/grass70/manuals/addons/index.html
 SCRIPTS OVERVIEW
 * build-xml.py - support Python script called by compile-xml.sh
-* compile.sh - support script to compile GRASS Addons modules called by compile-xml.sh
+* compile.sh   - support script to compile GRASS Addons modules called by compile-xml.sh
 * compile-xml.sh - creates XML file for each addons module (used by g.extension)
 * grass-addons-index.sh - creates ovewview index page, called by grass-addons-publish.sh
 * grass-addons-build.sh - called on Building server (2)
Modified: grass-addons/tools/addons/grass-addons-index.sh
--- grass-addons/tools/addons/grass-addons-index.sh	2015-11-15 13:06:17 UTC (rev 66835)
+++ grass-addons/tools/addons/grass-addons-index.sh	2015-11-15 13:17:01 UTC (rev 66836)
@@ -84,6 +84,7 @@
 <h2>GRASS GIS ${major} Addons Manual pages</h2>
 <!-- Generated from: /home/martinl/src/grass-addons/tools/addons/ -->
+<!--       See also: https://svn.osgeo.org/grass/grass-addons/tools/addons/README.txt -->
 <table><tr><td>
 <script type=\"text/javascript\" src=\"https://www.openhub.net/p/grass_gis_addons/widgets/project_factoids_stats?format=js\"></script>
