[GRASS-SVN] r66431 - grass-addons/grass7/raster/r.stream.variables
Wed Oct 7 14:17:46 PDT 2015
Author: martinl
Date: 2015-10-07 14:17:46 -0700 (Wed, 07 Oct 2015)
New Revision: 66431
Added:
   grass-addons/grass7/raster/r.stream.variables/r.stream.variables.py
Removed:
r.stream.variables: python script must have .py extension
Deleted: grass-addons/grass7/raster/r.stream.variables/r.stream.variables
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-10-07 21:15:44 UTC (rev 66430)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables	2015-10-07 21:17:46 UTC (rev 66431)
@@ -1,391 +0,0 @@
-#!/bin/bash
-# MODULE:       r.stream.watersheds
-# AUTHOR(S):    Giuseppe Amatulli & Sami Domisch
-#               based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
-#				Near-global freshwater-specific environmental variables for
-# 				biodiversity analyses in 1km resolution. Scientific Data"
-# PURPOSE:      Calculation of contiguous stream-specific variables that account
-#				for the upstream environment (based on r.stream.watersheds).
-# COPYRIGHT:    (C) 2001-2012 by the GRASS Development Team
-#               This program is free software under the GNU General Public
-#               License (>=v2). Read the file COPYING that comes with GRASS
-#               for details.
-#%Module
-#% description: Calculation of contiguous stream-specific variables that account for the upstream environment (based on r.stream.watersheds).
-#% keywords: drainage, stream, hydrology
-#%End
-#%option
-#% key: variable
-#% type: string
-#% key_desc: name
-#% description: Name of raster to be converted into a stream-specific variable
-#% required : yes
-#%end
-#%option
-#% key: area
-#% type: string
-#% key_desc: string
-#% multiple: no
-#% options: watershed,stream
-#% description: Area of aggregation: across the sub-watersheds or only across sub-streams
-#% required : yes
-#%end
-#%option
-#% key: folder
-#% type: string
-#% key_desc: name
-#% description: Provide the full folder path (same as for r.stream.watersheds)
-#% required:no
-#% answer: GISDBASE/folder_structure
-#%end
-#%option
-#% key: out_folder
-#% type: string
-#% key_desc: name
-#% description: Provide the full folder path for the output stream-specific variable
-#% required:no
-#% answer: GISDBASE/stream-specific_variables
-#%end
-#%option
-#% key: output
-#% type: string
-#% key_desc: method
-#% multiple: yes
-#% options: cells,min,max,range,mean,stddev,coeff_var,sum
-#% description: Provide the output aggregation method for the stream-specific variable: upstream cells numbers, minimum, maximum, range, mean, standard deviation, coefficient of variation, sum. Output datatype is Int32
-#% required:yes
-#%end
-#%option
-#% key: scale
-#% type: double
-#% key_desc: value
-#% description: Provide a scale factor to multiply or divide the final stream-specific variable (e.g if input raster values are between -1 and 1, use scale=1000 to inicrease the number of decimals - all outputs will be rounded to integers)
-#% answer: 1
-#% required:no
-#%end
-#%option
-#% key: cpu
-#% type: double
-#% description: Number of CPUs used for the parallel computation
-#% answer: 1
-#% required:no
-#%end
-if [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." >&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
-    g.message -e "awk required, please install awk or gawk first"
-    exit 1
-fi
-# setting environment, so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-#test:
-if [ -z "$GIS_OPT_VARIABLE"  ] ; then
-    g.message "Please provide the name of raster to be converted into a stream-specific variable."
-exit 1
-fi
-if [ -z "$GIS_OPT_AREA" ] ; then
-    g.message "Please provide area of aggregation: across the sub-watersheds or only across sub-streams."
-exit 1
-fi
-if [ -z "$GIS_OPT_OUTPUT"  ] ; then
-    g.message "Please provide the output aggregation method for the stream-specific variable: upstream  min, max, range, mean, stddev, coeff_var, sum"
-exit 1
-fi
-#check if drainage and stream file exists
-eval `g.findfile element=cell file="$GIS_OPT_VARIABLE"`
-if [ ! "$file" ] ; then
-    g.message -e "<$GIS_OPT_VARIABLE> does not exist! Aborting."
-    exit 1
-fi
-export GISDBASE=$(g.gisenv get=GISDBASE  separator=space)
-export LOCATION_NAME=$(g.gisenv get=LOCATION_NAME  separator=space)
-export GIS_OPT_AREA
-export GIS_OPT_VARIABLE
-export GIS_OPT_OUTPUT
-export GIS_OPT_SCALE
-if [ ${GIS_OPT_FOLDER} = "GISDBASE/folder_structure" ] ; then
-       export GIS_OPT_FOLDER=$GISDBASE"/folder_structure"
-else
-       export GIS_OPT_FOLDER=$GIS_OPT_FOLDER
-fi
-if [ ${GIS_OPT_OUT_FOLDER} = "GISDBASE/stream-specific_variables" ] ; then
-      export GIS_OPT_OUT_FOLDER=$GISDBASE"/stream-specific_variables"
-else
-      export GIS_OPT_OUT_FOLDER=$GIS_OPT_OUT_FOLDER
-fi
-mkdir  $GIS_OPT_OUT_FOLDER  2> /dev/null
-# what to do in case of user break:
-exitprocedure()
-echo ""
-g.message -e 'Process aborted by user. All intermediate files have been deleted!'
-# reset in the permanent mapset
-g.gisenv set="MAPSET=PERMANENT"
-g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
-g.gisenv set="GISDBASE=$GISDBASE"
-# delete intermediate files
-rm -fr  $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}*
-find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.txt' -delete
-find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.tif' -delete
-rm -fr  $GIS_OPT_FOLDER/blockfile/stat_*.txt
-exit 1
-# shell check for user break (signal list: trap -l)
-trap "exitprocedure" 2 3 9 15 19
-echo ""
-echo "##########################################################################"
-echo "Stream-specific variable calculation based on the sub-watersheds and sub-streams"
-echo ""
-echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
-echo "Near-global freshwater-specific environmental variables for"
-echo "biodiversity analyses in 1km resolution. Scientific Data"
-echo ""
-export GISRC_def=$GISRC
-echo Using  $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) blocks in  $GIS_OPT_FOLDER/blockfile/
-for file in  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/blockfile*_sub_${GIS_OPT_AREA}.tar.gz    ; do
-    export DIRNAME=$(dirname   $file )
-    filename=$(basename $file )
-    cd $DIRNAME
-    tar -xf $file
-    cd $GISDBASE
-    export BLKID=$(echo $filename |  awk -v GIS_OPT_AREA=${GIS_OPT_AREA} '{ gsub("0000", "") ; gsub("blockfile","") ; gsub("_sub_","") ; gsub("GIS_OPT_AREA","") ; gsub(".tar.gz","") ;  print  }')
-    export dir4d=${BLKID: -4:1} ; if [ -z $dir4d  ] ; then  dir4d=0 ; fi
-    export dir3d=${BLKID: -3:1} ; if [ -z $dir3d  ] ; then  dir3d=0 ; fi
-    export dir2d=${BLKID: -2:1} ; if [ -z $dir2d  ] ; then  dir2d=0 ; fi
-    export dir1d=${BLKID: -1:1} ; if [ -z $dir1d  ] ; then  dir1d=0 ; fi
-echo  "Start the stream-specific variable aggregation for block $file"
-ls  $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif | awk '{ if (NR>0) { print $1 ,  NR} }'   | xargs  -n 2 -P $GIS_OPT_CPU  bash -c  $'
-file=$1
-filename=$(basename $file .tif )
-if [  $GIS_OPT_AREA =  "watershed"  ] ; then ID=${filename:15:99}; fi
-if [  $GIS_OPT_AREA =  "stream"  ] ; then ID=${filename:12:99}; fi
-NR=$2
-if [ $( expr  $( expr $NR + 1 ) / 100)  -eq  $( expr $NR / 100 + 1 ) ] ; then
-echo  -en  "\r$(expr $NR / 100 + 1 )% done"
-fi
-# replicate the start-GISRC in a uniq GISRC
-cp   $GISRC_def    $HOME/.grass7/rc$ID
-export GISRC=$HOME/.grass7/rc$ID
-g.mapset  -c   mapset=sub_${GIS_OPT_AREA}ID$ID   location=$LOCATION_NAME  dbase=$GISDBASE   --quiet
-rm -f    $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}ID$ID/.gislock
-export GISBASE=$( grep  gisbase   $(which grass70) | awk \'{ if(NR==2) { gsub ("\\"","" ) ; print $3 }  }\' )
-export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
-export LD_LIBRARY_PATH="$GISBASE/lib"
-export GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH"
-export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
-export MANPATH=$MANPATH:$GISBASE/man
-# echo  Load $DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif
-r.in.gdal input=$DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif       output=sub_${GIS_OPT_AREA}ID${ID}   --q
-g.region   rast=sub_${GIS_OPT_AREA}ID${ID}@sub_${GIS_OPT_AREA}ID${ID}  zoom=sub_${GIS_OPT_AREA}ID${ID}@sub_${GIS_OPT_AREA}ID${ID} --q
-r.mapcalc "sub_$GIS_OPT_VARIABLE = if ( sub_${GIS_OPT_AREA}ID${ID} == 1 , $GIS_OPT_VARIABLE at PERMANENT  , null())"    --o --q
-echo $ID"|"$( r.univar -t --q  map=sub_$GIS_OPT_VARIABLE  |  awk  \'{ if (NR==2 ) print}\'   ) >   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt
-FULL=$(awk -F "|"  \'{if (NF==13) {print 1 } else {print 0} }\'   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt)
-if [ $FULL -eq 0 ] ; then
-rm   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt
-else
-rm -f $DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif
-fi
-rm -r $HOME/.grass7/rc$ID    $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}ID$ID
-' _
-echo -en  "\r100% done"
-echo ""
-echo "Check for missing files due to RAM overload"
-if ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  1> /dev/null 2>&1 ; then
-echo $(ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  | wc -l ) files had RAM issues
-ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  | awk '{ if (NR>0) { print $1 ,  NR} }'   | xargs  -n 2 -P 1 bash -c  $'
-file=$1
-echo Fix missing file $file using only 1 CPU
-NR=$2
-if [ ! -f  $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt ] ; then
-fi
-if [ $FULL -eq 0 ] ; then rm   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt ; fi
-fi
-' _
-else
-echo 0 files had RAM issues
-fi
-cat $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID*.txt >  $DIRNAME/stat_${GIS_OPT_VARIABLE}.txt
-rm -f  $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID*.txt
-done
-echo "Aggregating the final table to reclassify the raster ID"
-echo "ID|non_null_cells|null_cells|min|max|range|mean|mean_of_abs|stddev|variance|coeff_var|sum|sum_abs" >  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
-cat  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt  >>  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
-rm -f  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt
-echo Reclass the grid_id for the following output  ${GIS_OPT_OUTPUT//","/" "}
-echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P $GIS_OPT_CPU bash -c $'
-if [ $1 = "cells" ]     ; then col=2 ; fi
-if [ $1 = "min" ]       ; then col=4 ; fi
-if [ $1 = "max" ]       ; then col=5 ; fi
-if [ $1 = "range" ]     ; then col=6 ; fi
-if [ $1 = "mean" ]      ; then col=7 ; fi
-if [ $1 = "stddev" ]    ; then col=9 ; fi
-if [ $1 = "coeff_var" ] ; then col=11 ; fi
-if [ $1 = "sum" ]       ; then col=12 ; fi
-awk -F "|" -v col=$col -v scale=$GIS_OPT_SCALE  \' { if (NR>1 ) {gsub("-nan","0",$col); gsub("inf","0",$col);  print $1" = "int($col * scale) }}\' $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt  > $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_$1.txt
-' _
-echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P 1 bash -c $'
-echo  Create stream-specific variable:  $GIS_OPT_VARIABLE $1
-r.reclass input=grid_ID  output=${GIS_OPT_VARIABLE}_$1  rules=$GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt   --overwrite   --q
-# rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
-r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
-if test -f "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif"; then echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!";fi
-#echo "$GIS_OPT_OUT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
-' _
-exit
-echo "The full stream variable calculation has been done!"
-echo "To list the stream-specific output variables: ls $GIS_OPT_OUT_FOLDER/*.tif"
Copied: grass-addons/grass7/raster/r.stream.variables/r.stream.variables.py (from rev 66429, grass-addons/grass7/raster/r.stream.variables/r.stream.variables)
--- grass-addons/grass7/raster/r.stream.variables/r.stream.variables.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.stream.variables/r.stream.variables.py	2015-10-07 21:17:46 UTC (rev 66431)
@@ -0,0 +1,391 @@
+#!/bin/bash
+# MODULE:       r.stream.watersheds
+# AUTHOR(S):    Giuseppe Amatulli & Sami Domisch
+#               based on "Domisch, S., Amatulli, G., Jetz, W. (in review)
+#				Near-global freshwater-specific environmental variables for
+# 				biodiversity analyses in 1km resolution. Scientific Data"
+# PURPOSE:      Calculation of contiguous stream-specific variables that account
+#				for the upstream environment (based on r.stream.watersheds).
+# COPYRIGHT:    (C) 2001-2012 by the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#% description: Calculation of contiguous stream-specific variables that account for the upstream environment (based on r.stream.watersheds).
+#% keywords: drainage, stream, hydrology
+#%End
+#%option
+#% key: variable
+#% type: string
+#% key_desc: name
+#% description: Name of raster to be converted into a stream-specific variable
+#% required : yes
+#%end
+#%option
+#% key: area
+#% type: string
+#% key_desc: string
+#% multiple: no
+#% options: watershed,stream
+#% description: Area of aggregation: across the sub-watersheds or only across sub-streams
+#% required : yes
+#%end
+#%option
+#% key: folder
+#% type: string
+#% key_desc: name
+#% description: Provide the full folder path (same as for r.stream.watersheds)
+#% required:no
+#% answer: GISDBASE/folder_structure
+#%end
+#%option
+#% key: out_folder
+#% type: string
+#% key_desc: name
+#% description: Provide the full folder path for the output stream-specific variable
+#% required:no
+#% answer: GISDBASE/stream-specific_variables
+#%end
+#%option
+#% key: output
+#% type: string
+#% key_desc: method
+#% multiple: yes
+#% options: cells,min,max,range,mean,stddev,coeff_var,sum
+#% description: Provide the output aggregation method for the stream-specific variable: upstream cells numbers, minimum, maximum, range, mean, standard deviation, coefficient of variation, sum. Output datatype is Int32
+#% required:yes
+#%end
+#%option
+#% key: scale
+#% type: double
+#% key_desc: value
+#% description: Provide a scale factor to multiply or divide the final stream-specific variable (e.g if input raster values are between -1 and 1, use scale=1000 to inicrease the number of decimals - all outputs will be rounded to integers)
+#% answer: 1
+#% required:no
+#%end
+#%option
+#% key: cpu
+#% type: double
+#% description: Number of CPUs used for the parallel computation
+#% answer: 1
+#% required:no
+#%end
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." >&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+#### check if we have awk
+if [ ! -x "`which awk`" ] ; then
+    g.message -e "awk required, please install awk or gawk first"
+    exit 1
+fi
+# setting environment, so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+#test:
+if [ -z "$GIS_OPT_VARIABLE"  ] ; then
+    g.message "Please provide the name of raster to be converted into a stream-specific variable."
+exit 1
+fi
+if [ -z "$GIS_OPT_AREA" ] ; then
+    g.message "Please provide area of aggregation: across the sub-watersheds or only across sub-streams."
+exit 1
+fi
+if [ -z "$GIS_OPT_OUTPUT"  ] ; then
+    g.message "Please provide the output aggregation method for the stream-specific variable: upstream  min, max, range, mean, stddev, coeff_var, sum"
+exit 1
+fi
+#check if drainage and stream file exists
+eval `g.findfile element=cell file="$GIS_OPT_VARIABLE"`
+if [ ! "$file" ] ; then
+    g.message -e "<$GIS_OPT_VARIABLE> does not exist! Aborting."
+    exit 1
+fi
+export GISDBASE=$(g.gisenv get=GISDBASE  separator=space)
+export LOCATION_NAME=$(g.gisenv get=LOCATION_NAME  separator=space)
+export GIS_OPT_AREA
+export GIS_OPT_VARIABLE
+export GIS_OPT_OUTPUT
+export GIS_OPT_SCALE
+if [ ${GIS_OPT_FOLDER} = "GISDBASE/folder_structure" ] ; then
+       export GIS_OPT_FOLDER=$GISDBASE"/folder_structure"
+else
+       export GIS_OPT_FOLDER=$GIS_OPT_FOLDER
+fi
+if [ ${GIS_OPT_OUT_FOLDER} = "GISDBASE/stream-specific_variables" ] ; then
+      export GIS_OPT_OUT_FOLDER=$GISDBASE"/stream-specific_variables"
+else
+      export GIS_OPT_OUT_FOLDER=$GIS_OPT_OUT_FOLDER
+fi
+mkdir  $GIS_OPT_OUT_FOLDER  2> /dev/null
+# what to do in case of user break:
+exitprocedure()
+echo ""
+g.message -e 'Process aborted by user. All intermediate files have been deleted!'
+# reset in the permanent mapset
+g.gisenv set="MAPSET=PERMANENT"
+g.gisenv set="LOCATION_NAME=$LOCATION_NAME"
+g.gisenv set="GISDBASE=$GISDBASE"
+# delete intermediate files
+rm -fr  $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}*
+find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.txt' -delete
+find    $GIS_OPT_FOLDER/ -maxdepth 1 -name  '*.tif' -delete
+rm -fr  $GIS_OPT_FOLDER/blockfile/stat_*.txt
+exit 1
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 9 15 19
+echo ""
+echo "##########################################################################"
+echo "Stream-specific variable calculation based on the sub-watersheds and sub-streams"
+echo ""
+echo "Citation: Domisch, S., Amatulli, G., Jetz, W. (in review)"
+echo "Near-global freshwater-specific environmental variables for"
+echo "biodiversity analyses in 1km resolution. Scientific Data"
+echo ""
+export GISRC_def=$GISRC
+echo Using  $( ls $GIS_OPT_FOLDER/blockfile/blockfile* | wc -l ) blocks in  $GIS_OPT_FOLDER/blockfile/
+for file in  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/blockfile*_sub_${GIS_OPT_AREA}.tar.gz    ; do
+    export DIRNAME=$(dirname   $file )
+    filename=$(basename $file )
+    cd $DIRNAME
+    tar -xf $file
+    cd $GISDBASE
+    export BLKID=$(echo $filename |  awk -v GIS_OPT_AREA=${GIS_OPT_AREA} '{ gsub("0000", "") ; gsub("blockfile","") ; gsub("_sub_","") ; gsub("GIS_OPT_AREA","") ; gsub(".tar.gz","") ;  print  }')
+    export dir4d=${BLKID: -4:1} ; if [ -z $dir4d  ] ; then  dir4d=0 ; fi
+    export dir3d=${BLKID: -3:1} ; if [ -z $dir3d  ] ; then  dir3d=0 ; fi
+    export dir2d=${BLKID: -2:1} ; if [ -z $dir2d  ] ; then  dir2d=0 ; fi
+    export dir1d=${BLKID: -1:1} ; if [ -z $dir1d  ] ; then  dir1d=0 ; fi
+echo  "Start the stream-specific variable aggregation for block $file"
+ls  $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif | awk '{ if (NR>0) { print $1 ,  NR} }'   | xargs  -n 2 -P $GIS_OPT_CPU  bash -c  $'
+file=$1
+filename=$(basename $file .tif )
+if [  $GIS_OPT_AREA =  "watershed"  ] ; then ID=${filename:15:99}; fi
+if [  $GIS_OPT_AREA =  "stream"  ] ; then ID=${filename:12:99}; fi
+NR=$2
+if [ $( expr  $( expr $NR + 1 ) / 100)  -eq  $( expr $NR / 100 + 1 ) ] ; then
+echo  -en  "\r$(expr $NR / 100 + 1 )% done"
+fi
+# replicate the start-GISRC in a uniq GISRC
+cp   $GISRC_def    $HOME/.grass7/rc$ID
+export GISRC=$HOME/.grass7/rc$ID
+g.mapset  -c   mapset=sub_${GIS_OPT_AREA}ID$ID   location=$LOCATION_NAME  dbase=$GISDBASE   --quiet
+rm -f    $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}ID$ID/.gislock
+export GISBASE=$( grep  gisbase   $(which grass70) | awk \'{ if(NR==2) { gsub ("\\"","" ) ; print $3 }  }\' )
+export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
+export LD_LIBRARY_PATH="$GISBASE/lib"
+export GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH"
+export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
+export MANPATH=$MANPATH:$GISBASE/man
+# echo  Load $DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif
+r.in.gdal input=$DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif       output=sub_${GIS_OPT_AREA}ID${ID}   --q
+g.region   rast=sub_${GIS_OPT_AREA}ID${ID}@sub_${GIS_OPT_AREA}ID${ID}  zoom=sub_${GIS_OPT_AREA}ID${ID}@sub_${GIS_OPT_AREA}ID${ID} --q
+r.mapcalc "sub_$GIS_OPT_VARIABLE = if ( sub_${GIS_OPT_AREA}ID${ID} == 1 , $GIS_OPT_VARIABLE at PERMANENT  , null())"    --o --q
+echo $ID"|"$( r.univar -t --q  map=sub_$GIS_OPT_VARIABLE  |  awk  \'{ if (NR==2 ) print}\'   ) >   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt
+FULL=$(awk -F "|"  \'{if (NF==13) {print 1 } else {print 0} }\'   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt)
+if [ $FULL -eq 0 ] ; then
+rm   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt
+else
+rm -f $DIRNAME/sub_${GIS_OPT_AREA}ID${ID}.tif
+fi
+rm -r $HOME/.grass7/rc$ID    $GISDBASE/$LOCATION_NAME/sub_${GIS_OPT_AREA}ID$ID
+' _
+echo -en  "\r100% done"
+echo ""
+echo "Check for missing files due to RAM overload"
+if ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  1> /dev/null 2>&1 ; then
+echo $(ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  | wc -l ) files had RAM issues
+ls $DIRNAME/sub_${GIS_OPT_AREA}ID*.tif  | awk '{ if (NR>0) { print $1 ,  NR} }'   | xargs  -n 2 -P 1 bash -c  $'
+file=$1
+echo Fix missing file $file using only 1 CPU
+NR=$2
+if [ ! -f  $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt ] ; then
+fi
+if [ $FULL -eq 0 ] ; then rm   $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID$ID.txt ; fi
+fi
+' _
+else
+echo 0 files had RAM issues
+fi
+cat $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID*.txt >  $DIRNAME/stat_${GIS_OPT_VARIABLE}.txt
+rm -f  $DIRNAME/stat_${GIS_OPT_VARIABLE}_ID*.txt
+done
+echo "Aggregating the final table to reclassify the raster ID"
+echo "ID|non_null_cells|null_cells|min|max|range|mean|mean_of_abs|stddev|variance|coeff_var|sum|sum_abs" >  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
+cat  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt  >>  $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt
+rm -f  $GIS_OPT_FOLDER/*digit4/*digit3/*digit2/*digit1/stat_${GIS_OPT_VARIABLE}.txt
+echo Reclass the grid_id for the following output  ${GIS_OPT_OUTPUT//","/" "}
+echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P $GIS_OPT_CPU bash -c $'
+if [ $1 = "cells" ]     ; then col=2 ; fi
+if [ $1 = "min" ]       ; then col=4 ; fi
+if [ $1 = "max" ]       ; then col=5 ; fi
+if [ $1 = "range" ]     ; then col=6 ; fi
+if [ $1 = "mean" ]      ; then col=7 ; fi
+if [ $1 = "stddev" ]    ; then col=9 ; fi
+if [ $1 = "coeff_var" ] ; then col=11 ; fi
+if [ $1 = "sum" ]       ; then col=12 ; fi
+awk -F "|" -v col=$col -v scale=$GIS_OPT_SCALE  \' { if (NR>1 ) {gsub("-nan","0",$col); gsub("inf","0",$col);  print $1" = "int($col * scale) }}\' $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}.txt  > $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_$1.txt
+' _
+echo ${GIS_OPT_OUTPUT//","/" "} |  xargs -n 1 -P 1 bash -c $'
+echo  Create stream-specific variable:  $GIS_OPT_VARIABLE $1
+r.reclass input=grid_ID  output=${GIS_OPT_VARIABLE}_$1  rules=$GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt   --overwrite   --q
+# rm -f $GIS_OPT_FOLDER/blockfile/stat_${GIS_OPT_VARIABLE}_${1}.txt
+r.out.gdal -c  input=${GIS_OPT_VARIABLE}_${1}  nodata=-9999  output=$GIS_OPT_OUT_FOLDER/${GIS_OPT_VARIABLE}_${1}.tif  type=Int32  -c  createopt="COMPRESS=LZW,ZLEVEL=9"  --o --q  2> /dev/null
+if test -f "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif"; then echo "$GIS_OPT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!";fi
+#echo "$GIS_OPT_OUT_FOLDER/blockfile/${GIS_OPT_VARIABLE}_${1}.tif has been created!"
+' _
+exit
+echo "The full stream variable calculation has been done!"
+echo "To list the stream-specific output variables: ls $GIS_OPT_OUT_FOLDER/*.tif"
