[GRASS-SVN] r66444 - grass-addons/grass7/vector/v.habitat.dem
Fri Oct 9 05:11:13 PDT 2015
Author: hellik
Date: 2015-10-09 05:11:13 -0700 (Fri, 09 Oct 2015)
New Revision: 66444
   grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
v.habitat.dem: add calculation percent geomorphon of area
Modified: grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py
--- grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py	2015-10-09 09:59:38 UTC (rev 66443)
+++ grass-addons/grass7/vector/v.habitat.dem/v.habitat.dem.py	2015-10-09 12:11:13 UTC (rev 66444)
@@ -438,8 +438,107 @@
                                      other_table = t_habitat_geomorphons_pivot,
                                      other_column = 'field_1')
     grass.message( "Geomorphon information joint to habitat attribute table." )
+    grass.message( "..." )
+    grass.message( "Calculating percent geomorphon of habitat area ..." )
+    # add column for percent geomorphon
+    grass.run_command("v.db.addcolumn", map = v_habitat,
+                                     layer = 1,
+                                     columns = "%s_perc_flat double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_summit double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_ridge double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_shoulder double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_spur double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_slope double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_hollow double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_footslope double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_valley double precision" % prefix )
+                                     layer = 1,
+                                     columns = "%s_perc_depression double precision" % prefix )
+    # calculate percent geomorphon
+    grass.run_command("v.db.update", map = v_habitat,
+                                     layer = 1,
+                                     column = "%s_perc_flat" % prefix,
+                                     query_column="cast(flat AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_summit" % prefix,
+                                     query_column="cast(summit AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_ridge" % prefix,
+                                     query_column="cast(ridge AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_shoulder" % prefix,
+                                     query_column="cast(shoulder AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_spur" % prefix,
+                                     query_column="cast(spur AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_slope" % prefix,
+                                     query_column="cast(slope AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_hollow" % prefix,
+                                     query_column="cast(hollow AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_footslope" % prefix,
+                                     query_column="cast(footslope AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_valley" % prefix,
+                                     query_column="cast(valley AS real) / cast( SubTotal AS real) * 100.0")
+                                     layer = 1,
+                                     column = "%s_perc_depression" % prefix,
+                                     query_column="cast(depression AS real) / cast( SubTotal AS real) * 100.0")
+    grass.message( " " )
+    grass.message( "Calculating of percent geomorphon of habitat area done." )
     grass.message( "----" )
     # Give information where output files are
     grass.message( "Geomorphon information:" )
     grass.message( habgeocsv )
