[GRASS-SVN] r66454 - grass/trunk/scripts/v.import
Fri Oct 9 11:15:14 PDT 2015
Author: annakrat
Date: 2015-10-09 11:15:14 -0700 (Fri, 09 Oct 2015)
New Revision: 66454
   grass/trunk/scripts/v.import/v.import.py
v.import: pep8 cleanup, fix copy and paste bug in error message
Modified: grass/trunk/scripts/v.import/v.import.py
--- grass/trunk/scripts/v.import/v.import.py	2015-10-09 18:04:07 UTC (rev 66453)
+++ grass/trunk/scripts/v.import/v.import.py	2015-10-09 18:15:14 UTC (rev 66454)
@@ -22,7 +22,7 @@
 #% keyword: import
 #% keyword: projection
 #%end
-#%option
+#%option
 #% key: input
 #% type: string
 #% required: yes
@@ -72,28 +72,28 @@
 import sys
 import os
-import shutil
 import atexit
-import math
 import grass.script as grass
 from grass.exceptions import CalledModuleError
+# initialize global vars
+TMPLOC = None
+SRCGISRC = None
+GISDBASE = None
 def cleanup():
     # remove temp location
-    if tmploc:
-        grass.try_rmdir(os.path.join(gisdbase, tmploc))
-    if srcgisrc:
-        grass.try_remove(srcgisrc)
+    if TMPLOC:
+        grass.try_rmdir(os.path.join(GISDBASE, TMPLOC))
+    if SRCGISRC:
+        grass.try_remove(SRCGISRC)
 def main():
-    global tmploc, srcgisrc, gisdbase
+    global TMPLOC, SRCGISRC, GISDBASE
-    # initialize global vars
-    tmploc = None
-    srcgisrc = None
-    gisdbase = None
     # list formats and exit
     if flags['f']:
         grass.run_command('v.in.ogr', flags='f')
@@ -103,35 +103,35 @@
     if flags['l']:
         grass.run_command('v.in.ogr', flags='l', input=options['input'])
         return 0
     OGRdatasource = options['input']
     output = options['output']
     layers = options['layer']
     vflags = None
     if options['extent'] == 'region':
         vflags = 'r'
     vopts = {}
     if options['encoding']:
         vopts['encoding'] = options['encoding']
     grassenv = grass.gisenv()
     tgtloc = grassenv['LOCATION_NAME']
     tgtmapset = grassenv['MAPSET']
-    gisdbase = grassenv['GISDBASE']
+    GISDBASE = grassenv['GISDBASE']
     tgtgisrc = os.environ['GISRC']
-    srcgisrc = grass.tempfile()
-    tmploc = 'temp_import_location_' + str(os.getpid())
+    SRCGISRC = grass.tempfile()
-    f = open(srcgisrc, 'w')
+    TMPLOC = 'temp_import_location_' + str(os.getpid())
+    f = open(SRCGISRC, 'w')
     f.write('MAPSET: PERMANENT\n')
-    f.write('GISDBASE: %s\n' % gisdbase)
-    f.write('LOCATION_NAME: %s\n' % tmploc);
+    f.write('GISDBASE: %s\n' % GISDBASE)
+    f.write('LOCATION_NAME: %s\n' % TMPLOC)
     f.write('GUI: text\n')
     f.close()
-    tgtsrs = grass.read_command('g.proj', flags = 'j', quiet = True)
+    tgtsrs = grass.read_command('g.proj', flags='j', quiet=True)
     # create temp location from input without import
     grass.verbose(_("Creating temporary location for <%s>...") % OGRdatasource)
@@ -140,13 +140,13 @@
     if output:
         vopts['output'] = output
     try:
-        grass.run_command('v.in.ogr', input = OGRdatasource,
-                          location = tmploc, flags = 'i', quiet = True, **vopts)
+        grass.run_command('v.in.ogr', input=OGRdatasource,
+                          location=TMPLOC, flags='i', quiet=True, **vopts)
     except CalledModuleError:
         grass.fatal(_("Unable to create location from OGR datasource <%s>") % OGRdatasource)
     # switch to temp location
-    os.environ['GISRC'] = str(srcgisrc)
+    os.environ['GISRC'] = str(SRCGISRC)
     # switch to target location
     os.environ['GISRC'] = str(tgtgisrc)
@@ -155,58 +155,57 @@
     if grass.run_command('v.in.ogr', input=OGRdatasource, flags='j',
                          errors='status', quiet=True) == 0:
         try:
-                              flags = vflags, **vopts)
-            grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
+                              flags=vflags, **vopts)
+            grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
             return 0
-        except CalledModuleError as e:
+        except CalledModuleError:
             grass.fatal(_("Unable to import <%s>") % OGRdatasource)
     # make sure target is not xy
-    if grass.parse_command('g.proj', flags = 'g')['name'] == 'xy_location_unprojected':
+    if grass.parse_command('g.proj', flags='g')['name'] == 'xy_location_unprojected':
         grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
     # make sure input is not xy
-        grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
+        grass.fatal(_("Coordinate reference system not available for input <%s>") % OGRdatasource)
         # v.in.region in tgt
         vreg = 'vreg_' + str(os.getpid())
-        grass.run_command('v.in.region', output = vreg, quiet = True)
+        grass.run_command('v.in.region', output=vreg, quiet=True)
         # reproject to src
         try:
-            grass.run_command('v.proj', input = vreg, output = vreg,
-                              location = tgtloc, mapset = tgtmapset, quiet = True)
+            grass.run_command('v.proj', input=vreg, output=vreg,
+                              location=tgtloc, mapset=tgtmapset, quiet=True)
             grass.fatal(_("Unable to reproject to source location"))
         # set region from region vector
-        grass.run_command('g.region', res = '1')
-        grass.run_command('g.region', vector = vreg)
+        grass.run_command('g.region', res='1')
+        grass.run_command('g.region', vector=vreg)
     # import into temp location
     grass.message(_("Importing <%s> ...") % OGRdatasource)
     try:
         grass.fatal(_("Unable to import OGR datasource <%s>") % OGRdatasource)
     # if output is not define check source mapset
     if not output:
         output = grass.list_grouped('vector')['PERMANENT'][0]
@@ -214,20 +213,20 @@
     if not grass.overwrite() and \
        grass.find_file(output, element='vector', mapset='.')['mapset']:
         grass.fatal(_("option <%s>: <%s> exists.") % ('output', output))
-        grass.run_command('g.remove', type = 'vector', name = vreg,
-                          flags = 'f', quiet = True)
+        grass.run_command('g.remove', type='vector', name=vreg,
+                          flags='f', quiet=True)
     # v.proj
     grass.message(_("Reprojecting <%s>...") % output)
     try:
-        grass.run_command('v.proj', location = tmploc,
-                          mapset = 'PERMANENT', input = output,
-                          quiet = True)
+        grass.run_command('v.proj', location=TMPLOC,
+                          mapset='PERMANENT', input=output,
+                          quiet=True)
         grass.fatal(_("Unable to to reproject vector <%s>") % output)
     return 0
 if __name__ == "__main__":
