[GRASS-SVN] r66533 - grass/trunk/raster/r.mapcalc
Mon Oct 19 13:45:53 PDT 2015
Author: neteler
Date: 2015-10-19 13:45:53 -0700 (Mon, 19 Oct 2015)
New Revision: 66533
   grass/trunk/raster/r.mapcalc/r.mapcalc.html
   grass/trunk/raster/r.mapcalc/r3.mapcalc.html
r3.mapcalc manual: partial sync to r.mapcalc manual; HTML cosmetics
Modified: grass/trunk/raster/r.mapcalc/r.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r.mapcalc.html	2015-10-19 20:25:47 UTC (rev 66532)
+++ grass/trunk/raster/r.mapcalc/r.mapcalc.html	2015-10-19 20:45:53 UTC (rev 66533)
@@ -279,13 +279,11 @@
 The functions currently supported are listed in the table below.
 The type of the result is indicated in the last column.
-<em>F</em>
-means that the functions always results in a floating point value,
-<em>I</em>
-means that the function gives an integer result, and
-<em>*</em>
-indicates that the result is float if any of the arguments to the function
-are floating point values and integer if all arguments are integer.
+<em>F</em> means that the functions always results in a floating point value,
+<em>I</em> means that the function gives an integer result, and
+<em>*</em> indicates that the result is float if any of the arguments to the
+function are floating point values and integer if all arguments are integer.
 <p><div class="code"><pre>
 function                description                                     type
@@ -331,6 +329,7 @@
 tan(x)                  tangent of x (x is in degrees)                  F
 xor(x,y)                exclusive-or (XOR) of x and y                   I
 </pre></div>
 Internal variables:
  row()                  current row of moving window
@@ -682,8 +681,7 @@
 <h2>KNOWN ISSUES</h2>
 Continuation lines must end with a <tt>\</tt> and have <em>no</em> trailing
-white space (blanks or tabs).
-If the user does leave white space at the end of
+white space (blanks or tabs). If the user does leave white space at the end of
 continuation lines, the error messages produced by <em>r.mapcalc</em> will
 be meaningless and the equation will not work as the user intended.
 This is particularly important for the <tt>eval()</tt> function.
@@ -701,7 +699,7 @@
 <h2>SEE ALSO</h2>
-<p><em>
+<em>
 <a href="g.region.html">g.region</a>,
 <a href="r.bitpattern.html">r.bitpattern</a>,
 <a href="r.blend.html">r.blend</a>,
Modified: grass/trunk/raster/r.mapcalc/r3.mapcalc.html
--- grass/trunk/raster/r.mapcalc/r3.mapcalc.html	2015-10-19 20:25:47 UTC (rev 66532)
+++ grass/trunk/raster/r.mapcalc/r3.mapcalc.html	2015-10-19 20:45:53 UTC (rev 66533)
@@ -4,8 +4,9 @@
 involving existing raster map layers, integer or floating point constants,
 and functions.
-<h3>PROGRAM USE</h3>
+<h3>Program use</h3>
 <em>r3.mapcalc</em> expression have the form:
 <p><b>result =</b><em> expression</em>
 <p>where <em>result</em> is the name of a raster map layer
@@ -38,7 +39,8 @@
 Sorry, <foo> is not a valid parameter
 </pre></div>
-If no options are given, it manufactures "input=-" (which reads from
+<!-- sync to r.mapcalc? -->
+If no options are given, it manufactures "file=-" (which reads from
 stdin), so you can continue to use e.g.:
@@ -50,15 +52,15 @@
 foo = 1
 EOF
 </pre></div>
-But unless you need compatibility with previous versions, use input=
+But unless you need compatibility with previous versions, use file=
 explicitly, e.g.:
-r3.mapcalc input=file
+r3.mapcalc file=file
 </pre></div>
 or:
-r3.mapcalc input=- <<EOF
+r3.mapcalc file=- <<EOF
 foo = 1
 EOF
 </pre></div>
@@ -71,7 +73,8 @@
 should be enclosed within single quotes.  See NOTES, below.
-<h3>OPERATORS AND ORDER OF PRECEDENCE</h3>
+<h3>Operators and order of precedence</h3>
 The following operators are supported:
      Operator   Meaning                    Type        Precedence
@@ -112,7 +115,9 @@
 The logical operators give a 1 result if the comparison is true, 0 otherwise.
 <p><p>
-<h3>3D GRID NAMES</h3>
+<h3>3D Grid names</h3>
 Anything in the expression which is not a number, operator, or function name
 is taken to be a 3D grid name.
 Examples:
@@ -131,7 +136,7 @@
 x = "a-b"
 </pre></div>
-<p>would be interpreted as: x equals the 3D grid named <em>a-b</em>
+<p>would be interpreted as:  x equals the 3D grid named <em>a-b</em>
 <p>Also
 x = 3107
@@ -156,12 +161,13 @@
 result = x at PERMANENT / y at SOILS
 </pre></div>
-<p>The mapset specified does not have to be in the mapset search path. (This
-method of overriding the mapset search path is common to all GRASS commands,
-not just <em>r3.mapcalc</em>.)
+<p>The mapset specified does not have to be in the mapset search path.
+(This method of overriding the mapset search path is common to all
+GRASS commands, not just <em>r3.mapcalc</em>.)
 <p>
-<h3>THE NEIGHBORHOOD MODIFIER</h3>
+<h3>The neighborhood modifier</h3>
 3D grids are data base files stored in voxel format, i.e., three-dimensional
 matrices of float/double values. In <em>r3.mapcalc</em>, 3D grids may be
 followed by a <em>neighborhood</em> modifier that specifies a relative offset
@@ -176,18 +182,16 @@
 permits the development of neighborhood-type filters within a single 3D
 grid or across multiple 3D grids.
-<p>
-<h3>FUNCTIONS</h3>
+<h3>Functions</h3>
-<em>F</em>
-<em>I</em>
-<em>*</em>
@@ -233,6 +237,7 @@
 </pre></div>
 Internal variables:
@@ -249,7 +254,8 @@
 Note, that the row(), col() and depth() indexing starts with 1.
-<h3>FLOATING POINT VALUES IN THE EXPRESSION</h3>
+<h3>Floating point values in the expression</h3>
 Floating point numbers are allowed in the expression. A floating point
 number is a number which contains a decimal point:
@@ -274,6 +280,7 @@
 <h3>NULL support</h3>
 <ul>
 <li>Division by zero should result in NULL.
 <li>Modulus by zero should result in NULL.
@@ -381,7 +388,9 @@
 Extra care must be taken if the expression is given on the command line.
 Some characters have special meaning to the UNIX shell.
 These include, among others:
-<p>* ( ) > & |
+<div class="code"><pre>
+</pre></div>
 <p>It is advisable to put single quotes around the expression; e.g.:
 'result = volume * 2'
@@ -541,25 +550,36 @@
-Continuation lines must end with a \ and have NO trailing white space
-(blanks or tabs).  If the user does leave white space at the end of
+Continuation lines must end with a <tt>\</tt> and have <em>no</em> trailing
 continuation lines, the error messages produced by <em>r3.mapcalc</em> will
-This is important for the eval() function.
+This is particularly important for the <tt>eval()</tt> function.
 <p><!-- STILL TRUE ??-->
-Currently, there is no comment mechanism in <em>r3.mapcalc</em>. Perhaps
-adding a capability that would cause the entire line to be ignored when
-the user inserted a # at the start of a line as if it were not present,
-would do the trick.
+Currently, there is no comment mechanism in <em>r3.mapcalc</em>.
+Perhaps adding a capability that would cause the entire line to be
+ignored when the user inserted a # at the start of a line
+as if it were not present, would do the trick.
 <p>The function should require the user to type "end" or "exit" instead
 of simply a blank line. This would make separation of multiple scripts
 separable by white space.
-<p>r3.mapcalc does not print a warning in case of operations on NULL cells.
-It is left to the user to utilize the isnull() function.
+<p><em>r3.mapcalc</em> does not print a warning in case of operations on
+NULL cells. It is left to the user to utilize the <tt>isnull()</tt> function.
 <h2>SEE ALSO</h2>
-<b><a href="http://grass.osgeo.org/uploads/grass/history_docs/mapcalc-algebra.pdf">r3.mapcalc: An Algebra for GIS and Image
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r3.colors.html">r3.colors</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
+<h2>REFERENCES</h2>
+<b><a href="http://grass.osgeo.org/uploads/grass/history_docs/mapcalc-algebra.pdf">r.mapcalc: An Algebra for GIS and Image
 Processing</a></b>, by Michael Shapiro and Jim Westervelt, U.S. Army
 Construction Engineering Research Laboratory (March/1991).
 <p>
@@ -572,13 +592,12 @@
 Brovelli, M. (ed.)(2001): The Geomatics Workbook N. 2. Politecnico di Milano,
 Italy (ISSN 1591-092X) (<a href="http://geomatica.como.polimi.it/workbooks/n2/articoli/mn2.pdf">PDF</a>)
-<p><em><a href="r.mapcalc.html">r.mapcalc</a></em>
 <h2>AUTHORS</h2>
 Tomas Paudits & Jaro Hofierka, funded by GeoModel s.r.o., Slovakia
 <br><a href="mailto:tpaudits at mailbox.sk">tpaudits at mailbox.sk</a>,
 <a href="MAILTO:hofierka at geomodel.sk">hofierka at geomodel.sk</a>
+<p>Glynn Clements
 <p>
 <i>Last changed: $Date$</i>
