[GRASS-SVN] r66540 - grass/trunk/lib/python/pygrass/rpc
Mon Oct 19 15:13:30 PDT 2015
Author: huhabla
Date: 2015-10-19 15:13:30 -0700 (Mon, 19 Oct 2015)
New Revision: 66540
   grass/trunk/lib/python/pygrass/rpc/__init__.py
   grass/trunk/lib/python/pygrass/rpc/base.py
pygrass rpc: Better error handling in rpc server
Modified: grass/trunk/lib/python/pygrass/rpc/__init__.py
--- grass/trunk/lib/python/pygrass/rpc/__init__.py	2015-10-19 21:26:46 UTC (rev 66539)
+++ grass/trunk/lib/python/pygrass/rpc/__init__.py	2015-10-19 22:13:30 UTC (rev 66540)
@@ -198,11 +198,11 @@
     def error_handler(data):
         """This function will be called in case of a fatal error in libgis"""
-        #sys.stderr.write("Error handler was called\n")
+        # sys.stderr.write("Error handler was called\n")
         # We send an exeption that will be handled in
         # the parent process, then close the pipe
         # and release any possible lock
-        conn.send(FatalError())
+        conn.send(FatalError("G_fatal_error() was called in the server process"))
         conn.close()
         lock.release()
@@ -278,8 +278,20 @@
             >>> len(ret)
             12
+            >>> extent = {"north":100, "south":10, "east":30, "west":10,
+            ...           "rows":2, "cols":2}
+            >>> ret = provider.get_raster_image_as_np(name=test_raster_name,
+            ...                                       extent=extent)
             >>> provider.stop()
+            >>> extent = {"rows":3, "cols":1}
+            >>> len(ret)
+            12
         self.check_server()
Modified: grass/trunk/lib/python/pygrass/rpc/base.py
--- grass/trunk/lib/python/pygrass/rpc/base.py	2015-10-19 21:26:46 UTC (rev 66539)
+++ grass/trunk/lib/python/pygrass/rpc/base.py	2015-10-19 22:13:30 UTC (rev 66540)
@@ -115,8 +115,8 @@
         """Check every 200 micro seconds if the server process is alive"""
         while True:
             time.sleep(0.2)
-            #sys.stderr.write("Check server process\n")
-            self._check_restart_server()
+            # sys.stderr.write("Check server process\n")
+            self._check_restart_server(caller="Server check thread")
             self.threadLock.acquire()
             if self.stopThread == True:
                 #sys.stderr.write("Stop thread\n")
@@ -137,7 +137,7 @@
     def check_server(self):
-    def _check_restart_server(self):
+    def _check_restart_server(self, caller="main thread"):
         """Restart the server if it was terminated
@@ -148,22 +148,22 @@
         self.server_conn.close()
         self.start_server()
-        logging.warning("Needed to restart the libgis server")
+        logging.warning("Needed to restart the libgis server, caller: %s"%(caller))
         self.threadLock.release()
     def safe_receive(self, message):
-        """Receive the data and throw an FatalError exception in case the server
+        """Receive the data and throw a FatalError exception in case the server
            process was killed and the pipe was closed by the checker thread"""
         try:
             ret = self.client_conn.recv()
             if isinstance(ret,  FatalError):
-               raise FatalError()
+               raise ret
             return ret
-        except (EOFError,  IOError,  FatalError):
+        except (EOFError,  IOError,  FatalError), e:
             # The pipe was closed by the checker thread because
             # the server process was killed
-            raise FatalError(message)
+            raise FatalError(message + "\n  " + str(e))
     def stop(self):
         """Stop the check thread, the libgis server and close the pipe
