[GRASS-SVN] r66574 - in grass/trunk/temporal: t.rast.univar t.vect.univar
Thu Oct 22 03:37:48 PDT 2015
Author: huhabla
Date: 2015-10-22 03:37:47 -0700 (Thu, 22 Oct 2015)
New Revision: 66574
   grass/trunk/temporal/t.rast.univar/t.rast.univar.py
   grass/trunk/temporal/t.vect.univar/t.vect.univar.py
temporal modules: Added file based output to t.vect.univar
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.py
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.py	2015-10-22 10:14:37 UTC (rev 66573)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.py	2015-10-22 10:37:47 UTC (rev 66574)
@@ -25,12 +25,10 @@
 #%option G_OPT_STRDS_INPUT
 #%end
 #%option G_OPT_F_OUTPUT
 #% required: no
 #%end
 #%option G_OPT_T_WHERE
 #% guisection: Selection
 #%end
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py	2015-10-22 10:14:37 UTC (rev 66573)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py	2015-10-22 10:37:47 UTC (rev 66574)
@@ -25,6 +25,10 @@
 #%option G_OPT_STVDS_INPUT
 #%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#%end
 #%option G_OPT_V_FIELD
 #%end
@@ -72,6 +76,7 @@
     # Get the options
     input = options["input"]
+    output = options["output"]
     twhere = options["twhere"]
     layer = options["layer"]
     type = options["type"]
@@ -84,8 +89,13 @@
     # Make sure the temporal database exists
     tgis.init()
+    if not output:
+        output = None
+    if output == "-":
+        output = None
     tgis.print_vector_dataset_univar_statistics(
-        input, twhere, layer, type, column, where, extended, header, separator)
+        input, output, twhere, layer, type, column, where, extended, header, separator)
 if __name__ == "__main__":
     options, flags = grass.parser()
