[GRASS-SVN] r66663 - grass/trunk/lib/python/pygrass/vector
Thu Oct 29 09:44:10 PDT 2015
Author: zarch
Date: 2015-10-29 09:44:10 -0700 (Thu, 29 Oct 2015)
New Revision: 66663
   grass/trunk/lib/python/pygrass/vector/abstract.py
pygrass: Create a link/table also when open a vector map in rw mode
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py	2015-10-29 15:52:52 UTC (rev 66662)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py	2015-10-29 16:44:10 UTC (rev 66663)
@@ -352,19 +352,20 @@
         if mode == 'w':
             openvect = libvect.Vect_open_new(self.c_mapinfo, self.name, with_z)
             self.dblinks = DBlinks(self.c_mapinfo)
-            if tab_cols:
-                # create a link
-                link = Link(layer,
-                            link_name if link_name else self.name,
-                            tab_name if tab_name else self.name,
-                            link_key, link_db, link_driver)
-                # add the new link
-                self.dblinks.add(link)
-                # create the table
-                table = link.table()
-                table.create(tab_cols)
-                table.conn.commit()
+        if mode in ('w', 'rw') and tab_cols:
+            # create a link
+            link = Link(layer,
+                        link_name if link_name else self.name,
+                        tab_name if tab_name else self.name,
+                        link_key, link_db, link_driver)
+            # add the new link
+            self.dblinks.add(link)
+            # create the table
+            table = link.table()
+            table.create(tab_cols)
+            table.conn.commit()
         # check the C function result.
         if openvect == -1:
             str_err = "Not able to open the map, C function return %d."
