[GRASS-SVN] r66687 - grass/trunk/gui/wxpython/xml
Sat Oct 31 06:37:23 PDT 2015
Author: neteler
Date: 2015-10-31 06:37:23 -0700 (Sat, 31 Oct 2015)
New Revision: 66687
   grass/trunk/gui/wxpython/xml/wxgui_items.xml
wxgui_items.xml: update of a few of several outdated module descriptions. Really a job for tools/update_menudata.py (also outdated)
Modified: grass/trunk/gui/wxpython/xml/wxgui_items.xml
--- grass/trunk/gui/wxpython/xml/wxgui_items.xml	2015-10-31 12:05:48 UTC (rev 66686)
+++ grass/trunk/gui/wxpython/xml/wxgui_items.xml	2015-10-31 13:37:23 UTC (rev 66687)
@@ -199,14 +199,14 @@
     <label>Common formats import</label>
     <handler>OnImportGdalLayers</handler>
     <related-module>r.in.gdal</related-module>
-    <description>Import raster data into a GRASS map layer using GDAL.</description>
+    <description>Imports raster data into a GRASS raster map using GDAL library.</description>
     <keywords>raster,import</keywords>
   </wxgui-item>
   <wxgui-item name="CommonImportFormats">
     <label>Common import formats</label>
     <handler>OnImportOgrLayers</handler>
     <related-module>v.in.ogr</related-module>
-    <description>Converts vector layers into a GRASS vector map using OGR.</description>
+    <description>Imports vector data into a GRASS vector map using OGR library.</description>
     <keywords>vector,import</keywords>
   </wxgui-item>
   <wxgui-item name="DXFImport">
