[GRASS-SVN] r66093 - grass/trunk/lib/python/pygrass/vector
Thu Sep 3 15:06:20 PDT 2015
Author: huhabla
Date: 2015-09-03 15:06:20 -0700 (Thu, 03 Sep 2015)
New Revision: 66093
   grass/trunk/lib/python/pygrass/vector/__init__.py
pygrass vector: Added areas_to_wkb_list()  and tests
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2015-09-03 21:16:30 UTC (rev 66092)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2015-09-03 22:06:20 UTC (rev 66093)
@@ -662,7 +662,7 @@
             >>> test_vect = VectorTopo(test_vector_name)
             >>> test_vect.open('r')
-            >>> bbox = Bbox(north=20, south=-1, east=203, west=-1)
+            >>> bbox = Bbox(north=20, south=-1, east=20, west=-1)
             >>> result = test_vect.features_to_wkb_list(bbox=bbox,
             ...                                         feature_type="point")
             >>> len(result)
@@ -727,7 +727,7 @@
         bboxlist = self.find_by_bbox.geos(bbox, type=feature_type,
                                           bboxlist_only = True)
-        if bboxlist is not None:
+        if bboxlist is not None and len(bboxlist) > 0:
             l = []
             line_p = libvect.line_pnts()
@@ -754,7 +754,95 @@
             return l
         return None
+    @must_be_open
+    def areas_to_wkb_list(self, bbox=None, field=1):
+        """Return all features of type point, line, boundary or centroid
+           as a list of Well Known Binary representations (WKB)
+           (id, cat, wkb) triplets located in a specific
+           bounding box.
+           :param bbox: The boundingbox to search for features,
+                       if bbox=None the boundingbox of the whole
+                       vector map layer is used
+           :type bbox: grass.pygrass.vector.basic.Bbox
+           :param field: The centroid category field
+           :type field: integer
+           :return: A list of triplets, or None if nothing was found
+           The well known binary are stored in byte arrays.
+            Examples:
+            >>> from grass.pygrass.vector import VectorTopo
+            >>> from grass.pygrass.vector.basic import Bbox
+            >>> test_vect = VectorTopo(test_vector_name)
+            >>> test_vect.open('r')
+            >>> result = test_vect.areas_to_wkb_list(bbox=bbox)
+            >>> len(result)
+            4
+            >>> for entry in result:
+            ...     a_id, cat, wkb = entry
+            ...     print(a_id, cat, len(wkb))
+            (1, 3, 225)
+            (2, 3, 141)
+            (3, 3, 93)
+            (4, 3, 141)
+            >>> result = test_vect.areas_to_wkb_list()
+            >>> len(result)
+            4
+            (1, 3, 225)
+            (2, 3, 141)
+            (3, 3, 93)
+            (4, 3, 141)
+            >>> test_vect.close()
+        if bbox is None:
+            bbox = self.bbox()
+        bboxlist = self.find_by_bbox.areas(bbox, bboxlist_only = True)
+            l = []
+            line_c = libvect.line_cats()
+            size = ctypes.c_size_t()
+            cat = ctypes.c_int()
+            for a_id in bboxlist.ids:
+                barray = libvect.Vect_read_area_to_wkb(self.c_mapinfo,
+                                                       a_id,
+                                                       ctypes.byref(size))
+                if not barray:
+                    raise GrassError(_("Unable to read area with id %i"%(a_id)))
+                pcat = None
+                c_ok = libvect.Vect_get_area_cats(self.c_mapinfo, a_id,
+                                                  ctypes.byref(line_c))
+                if c_ok == 0: # Centroid found
+                    ok = libvect.Vect_cat_get(ctypes.byref(line_c), field,
+                                              ctypes.byref(cat))
+                    if ok > 0:
+                        pcat = cat.value
+                l.append((a_id, pcat, ctypes.string_at(barray, size.value)))
+            return l
+        return None
 if __name__ == "__main__":
     import doctest
     from grass.pygrass import utils
