[GRASS-SVN] r66102 - in grass-addons/grass7/raster: . r.mcda.promethee
Fri Sep 4 14:43:40 PDT 2015
Author: gianluca
Date: 2015-09-04 14:43:40 -0700 (Fri, 04 Sep 2015)
New Revision: 66102
Added:
   grass-addons/grass7/raster/r.mcda.promethee/
   grass-addons/grass7/raster/r.mcda.promethee/Makefile
   grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
   grass-addons/grass7/raster/r.mcda.promethee/main.c
   grass-addons/grass7/raster/r.mcda.promethee/promethee.c
   grass-addons/grass7/raster/r.mcda.promethee/r.mcda.promethee.html
firsth implementation of mcda promethee module
Added: grass-addons/grass7/raster/r.mcda.promethee/Makefile
--- grass-addons/grass7/raster/r.mcda.promethee/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.promethee/Makefile	2015-09-04 21:43:40 UTC (rev 66102)
@@ -0,0 +1,9 @@
+MODULE_TOPDIR = ../..
+PGM = r.mcda.promethee
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
--- grass-addons/grass7/raster/r.mcda.promethee/local_proto.h	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.promethee/local_proto.h	2015-09-04 21:43:40 UTC (rev 66102)
@@ -0,0 +1,24 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+#include <grass/config.h>
+struct input
+    char *name, *mapset;	/* input raster name  and mapset name */
+    int infd;
+    void *inrast;		/* input buffer */
+void build_weight_vect(int ncriteria, struct Option *weight,
+						double *weight_vect);
+void build_flow_matrix(int nrows, int ncols, int ncriteria,
+                            double *weight_vect, double ***decision_vol,
+                            double ***positive_flow_vol, double ***negative_flow_vol);
Added: grass-addons/grass7/raster/r.mcda.promethee/main.c
--- grass-addons/grass7/raster/r.mcda.promethee/main.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.promethee/main.c	2015-09-04 21:43:40 UTC (rev 66102)
@@ -0,0 +1,260 @@
+ * MODULE:   r.mcda.promethee
+ * AUTHORS:  Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
+ * PURPOSE:      Make a multicriteria decision analysis based on PROMETHEE algorithm,
+ *               with concordance and discordance indexes maps
+ * COPYRIGHT:    (C) GRASS Development Team (2015)
+ *              This program is free software under the GNU General Public
+ *              License (>=v2). Read the file COPYING that comes with GRASS
+ *              for details.
+#include <stdio.h>
+#include "local_proto.h"
+ * main function
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;    /* it stores region information,  and header information of rasters */
+    char *result_positive_flow, *result_negative_flow, *result_netflow;     /* outputs raster name */
+    /*char *mapset;      mapset name */
+    unsigned char *outrast_positive_flow, *outrast_negative_flow, *outrast_netflow;  /* output buffer */
+    int i,j, ncriteria=0;   /* index and  files number*/
+    int nrows, ncols;
+    int row1, col1;
+    int outfd_positive_flow, outfd_negative_flow, outfd_netflow;      /* output file descriptor */
+    /*RASTER_MAP_TYPE data_type;     type of the map (CELL/DCELL/...) */
+    double *weight_vect, ***decision_vol, ***positive_flow_vol, ***negative_flow_vol;/* vector and matrix */
+    struct History history; /* holds meta-data (title, comments,..) */
+    struct GModule *module; /* GRASS module for parsing arguments */
+    struct Option *criteria, *weight, *positiveflow, *negativeflow, *netflow;   /* options */
+    struct input *attributes; /*storage  alla input criteria GRID files and output concordance and discordance GRID files*/
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);     /* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    G_add_keyword(_("raster,MCDA"));
+    module->description = _("Multicirtieria decision analysis based on PROMETHEE method");
+    /* Define the different options as defined in gis.h */
+    criteria  = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+    criteria->key        = "criteria";
+    criteria->type       = TYPE_STRING;
+    criteria->required   = YES;
+    criteria->multiple   = YES;
+    criteria->gisprompt  = "old,cell,raster" ;
+    criteria->description = "Input geographics criteria in information system";
+    weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+    weight->key        = "weight";
+    weight->type       = TYPE_DOUBLE;
+    weight->required   = YES;
+    weight->multiple   = YES;
+    weight->description = _("Criteria weight(s) (w1,w2,..,wn)");
+    positiveflow = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+    positiveflow->key = "positiveflow";
+    positiveflow->type = TYPE_STRING;
+    positiveflow->required = YES;
+    positiveflow->gisprompt = "new,cell,raster";
+    positiveflow->answer ="positiveflow";
+    positiveflow->description = "positive flow output map";
+    negativeflow = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+    negativeflow->key = "negativeflow";
+    negativeflow->type = TYPE_STRING;
+    negativeflow->required = YES;
+    negativeflow->gisprompt = "new,cell,raster";
+    negativeflow->answer ="negativeflow";
+    negativeflow->description = "negative flow output map";
+    netflow = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+    netflow->key = "netflow";
+    netflow->type = TYPE_STRING;
+    netflow->required = YES;
+    netflow->gisprompt = "new,cell,raster";
+    netflow->answer ="netflow";
+    netflow->description = "net flow output map";
+    /* options and flags parser */
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    G_message("Start: %s",G_date()); /*write calculation start time*/
+    /* number of file (=criteria) */
+    while (criteria->answers[ncriteria]!=NULL)
+        ncriteria++;
+    /* process the input maps:  stores options and flags to variables */
+    /* CRITERIA grid */
+    attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files*/
+    weight_vect=G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight*/
+    build_weight_vect(ncriteria,weight,weight_vect); /*calcolate weight vector*/
+    for (i = 0; i < ncriteria; i++)
+        struct input *p = &attributes[i];
+        p->name = criteria->answers[i];
+        p->mapset = (char *) G_find_raster2(p->name,""); /*  Looks for the raster map "name" in the database. */
+        if (p->mapset==NULL) /* returns NULL if the map was not found in any mapset,   mapset name otherwise */
+            G_fatal_error(_("Raster file <%s> not found"), p->name);
+ /* determine the inputmap type (CELL/FCELL/DCELL) */
+ /*     data_type = Rast_map_type(p->name, p->mapset);*/
+        if ((p->infd =  Rast_open_old(p->name, p->mapset))<0) /* Rast_open_cell_old - returns file destriptor (>0) */
+            G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),p->name, p->mapset);
+        Rast_get_cellhd(p->name,p->mapset,&cellhd);/* controlling, if we can open input raster */
+        G_debug(3, "number of rows %d", cellhd.rows);
+        p->inrast = Rast_allocate_buf(DCELL_TYPE); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+    result_positive_flow=positiveflow->answer; /* store output name in variables*/
+    result_negative_flow=negativeflow->answer;
+    result_netflow=netflow->answer;
+    if (G_legal_filename(result_positive_flow) < 0) /* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_positive_flow);
+    if (G_legal_filename(result_negative_flow) < 0) /* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_negative_flow);
+    if (G_legal_filename(result_netflow) < 0) /* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_netflow);
+    /*values = G_malloc(ncriteria * sizeof(DCELL));*/
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    /*memory allocation for-three dimensional matrix*/
+    decision_vol=G_malloc(nrows * sizeof(double*));
+    positive_flow_vol=G_malloc(nrows * sizeof(double*));
+    negative_flow_vol=G_malloc(nrows * sizeof(double*));
+    for (i=0; i<nrows; ++i)
+        decision_vol[i]=G_malloc(ncols * sizeof(double*));
+        positive_flow_vol[i]=G_malloc(nrows * sizeof(double*));
+        negative_flow_vol[i]=G_malloc(nrows * sizeof(double*));
+        for (j=0; j<ncols; ++j)
+            decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage ****/
+            positive_flow_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double));
+            negative_flow_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double));
+    /* Allocate output buffer, use  DCELL_TYPE */
+    outrast_positive_flow = Rast_allocate_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_negative_flow = Rast_allocate_buf(DCELL_TYPE);
+    /* controlling, if we can write the raster */
+    outrast_positive_flow = Rast_open_new(result_positive_flow, DCELL_TYPE);
+    outrast_negative_flow = Rast_open_new(result_negative_flow, DCELL_TYPE);
+    outrast_netflow = Rast_open_new(result_netflow, DCELL_TYPE);
+    /*build a three dimensional matrix for storage all critera maps*/
+    for (i=0;i<ncriteria;i++)
+        for (row1 = 0; row1 < nrows;row1++)
+            Rast_get_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
+            /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
+            for (col1 = 0; col1 < ncols; col1++)
+                /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array*/
+                DCELL v1 = ((DCELL *)attributes[i].inrast)[col1];
+                decision_vol[row1][col1][i]=(double)(v1);
+                G_message("row: %d",row1);
+    build_flow_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol,positive_flow_vol, negative_flow_vol); /*scan all DCELL, make a pairwise comparatione, buil positive flow matrix*/
+    for (row1 = 0; row1 < nrows; row1++)
+            ((DCELL *) outrast_positive_flow)[col1] = (DCELL)positive_flow_vol[row1][col1][ncriteria];/*write positive flow map*/
+            ((DCELL *) outrast_negative_flow)[col1] = (DCELL)negative_flow_vol[row1][col1][ncriteria];/*write negative flow map*/
+        Rast_put_row(outfd_positive_flow, outrast_positive_flow,  DCELL_TYPE);
+        Rast_put_row(outfd_negative_flow, outrast_negative_flow,  DCELL_TYPE);
+    G_message("End: %s",G_date());
+    /* memory cleanup */
+    for (i = 0; i<ncriteria; i++)
+        G_free(attributes[i].inrast);
+    G_free(outrast_positive_flow);
+    G_free(outrast_negative_flow);
+    G_free(decision_vol);
+    G_free(positive_flow_vol);
+    G_free(negative_flow_vol);
+    /* closing raster maps */
+        Rast_close(attributes[i].infd);
+    Rast_close(outfd_positive_flow);
+    Rast_close(outfd_negative_flow);
+    /* add command line incantation to history concordance file */
+    Rast_short_history(result_positive_flow, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(result_positive_flow, &history);
+    /* add command line incantation to history discordance file */
+    Rast_short_history(result_negative_flow, "raster", &history);
+    Rast_write_history(result_negative_flow, &history);
+    exit(EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.mcda.promethee/promethee.c
--- grass-addons/grass7/raster/r.mcda.promethee/promethee.c	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.promethee/promethee.c	2015-09-04 21:43:40 UTC (rev 66102)
@@ -0,0 +1,102 @@
+ * global function declaration
+ * function definitions
+void build_weight_vect(int ncriteria,struct Option *weight,
+    int i, nweight = 0;
+    double weight_sum = 0;
+    while (weight->answers[nweight] != NULL)
+        nweight++;
+    if (nweight != ncriteria)
+        G_fatal_error(_("criteria number  and weight number are different"));
+    for (i = 0; i < nweight; i++)
+        weight_vect[i] = (atof(weight->answers[i]));	/*transfer  weight value  in double  array */
+        weight_sum = weight_sum + weight_vect[i];	/*calculate sum weight */
+        weight_vect[i] = weight_vect[i] / weight_sum;	/*normalize vector weight */
+    int row1, col1, row2, col2;
+    int i;
+	double threshold;
+/* make pairwise comparation and build positive flow matrix */
+		G_percent(i, (nrows*ncriteria), 2);
+				for (row2 = 0; row2 < nrows; row2++)
+					for (col2 = 0; col2 < ncols; col2++)
+						threshold = (decision_vol[row1][col1][i] - decision_vol[row2][col2][i]);
+						if (threshold>0)
+							positive_flow_vol[row1][col1][i]=threshold*weight_vect[i];
+							negative_flow_vol[row1][col1][i]=0;
+						else
+							positive_flow_vol[row1][col1][i]=0;
+							negative_flow_vol[row1][col1][i]=threshold*weight_vect[i];
+    /*storage preference value in decision_vol */
+        G_percent(row1, nrows, 2);
+			for ( i=0; i<ncriteria;i++)
+            /*fill matrix with performance  for each DCELL */
+            positive_flow_vol[row1][col1][ncriteria] = positive_flow_vol[row1][col1][ncriteria]+positive_flow_vol[row1][col1][i];
+            negative_flow_vol[row1][col1][ncriteria] = negative_flow_vol[row1][col1][ncriteria]+negative_flow_vol[row1][col1][i];
Added: grass-addons/grass7/raster/r.mcda.promethee/r.mcda.promethee.html
--- grass-addons/grass7/raster/r.mcda.promethee/r.mcda.promethee.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.promethee/r.mcda.promethee.html	2015-09-04 21:43:40 UTC (rev 66102)
@@ -0,0 +1,47 @@
+<h2>DESCRIPTION</h2>
+<em>r.mcda.electre</em> is the implementation of the ELECTRE multicriteria
+algorithm in GRASS GIS environment. It is one of the available tools in the
+r.mcda suite. It requires as an input the list of raster representing the
+criteria to be assessed in the multicriteria evaluation and the vector of
+weights to be assigned. Every single cell of the GRASS region is considered
+as one of the possible alternatives to evaluate and it is described with
+the value assumed for the same cell by the raster used as criteria. There
+are two output files. One represents the spatial distribution of the
+concordance index, the other one of the discordance index. The optimal
+solution is the one presenting the maximum concordance value and the minimum
+discordance value at the same time.
+<h2>NOTES</h2>
+The module does not standardize the raster-criteria. Therefore, they must
+be prepared before by using, for example, r.mapcalc. The weights vector
+is always normalized so that the sum of the weights is 1.
+<h2>CITE AS</h2>
+<p>Massei, G., Rocchi, L., Paolotti, L., Greco, S., & Boggia,
+Decision Support Systems for environmental management:
+A case study on wastewater from agriculture, Journal of Environmental Management,
+Volume 146, 15 December 2014, Pages 491-504, ISSN 0301-4797</p>
+<h2>REFERENCE</h2>
+<p>Roy, B. (1971) Problem and methods with multiple objective functions
+ Mathematical programming 1, 239-266.</P>
+<p>Roy, B. (1990): The outranking approach and the foundations of Electre
+ methods , Document du LAMSADE, Paris.</P>
+<p>Janssen R. (1994) - Multiobjective decision support for environmental
+ management, Kluwer Academic Publishers.</P>
+<p>GRASS Development Team (2015)</P>
+<h2>SEE ALSO</h2>
+<em>r.mcda.fuzzy, r.mcda.regime, r.mcda.roughet, r.mapcalc</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2012-12-04 19:08:17 +0100 (mar, 04 dic 2012) $</i>
