[GRASS-SVN] r66120 - grass/trunk/lib/python/temporal
Sat Sep 5 19:44:34 PDT 2015
Author: huhabla
Date: 2015-09-05 19:44:34 -0700 (Sat, 05 Sep 2015)
New Revision: 66120
   grass/trunk/lib/python/temporal/c_libraries_interface.py
temporal framework: Added new function to C-library RPC Server that are based on PyGRASS to receive full raster and vector map layer info
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-09-06 02:43:23 UTC (rev 66119)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py	2015-09-06 02:44:34 UTC (rev 66120)
@@ -26,6 +26,8 @@
 import grass.lib.raster3d as libraster3d
 import grass.lib.temporal as libtgis
 from grass.pygrass.rpc.base import RPCServerBase
+from grass.pygrass.raster import RasterRow
+from grass.pygrass.vector import VectorTopo
@@ -46,7 +48,8 @@
     G_MAPSET = 11
     G_LOCATION = 12
     G_GISDBASE = 13
-    G_FATAL_ERROR = 14
+    READ_MAP_FULL_INFO = 14
+    G_FATAL_ERROR = 49
     TYPE_RASTER = 0
     TYPE_RASTER3D = 1
@@ -54,7 +57,95 @@
+def _read_map_full_info(lock, conn, data):
+    """Read full map specific metadata from the spatial database using
+       PyGRASS functions.
+       :param lock: A multiprocessing.Lock instance
+       :param conn: A multiprocessing.Pipe instance used to send True or False
+       :param data: The list of data entries [function_id, maptype, name, mapset]
+    info = None
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+        if maptype == RPCDefs.TYPE_RASTER:
+            info = _read_raster_full_info(name, mapset)
+        elif maptype == RPCDefs.TYPE_VECTOR:
+            info = _read_vector_full_info(name, mapset)
+    except:
+        raise
+    finally:
+        conn.send(info)
+def _read_raster_full_info(name, mapset):
+    """Read raster info, history and cats using PyGRASS RasterRow
+       and return a dictionary. Colors should be supported in the
+       future.
+    info = {}
+    r = RasterRow(name=name, mapset=mapset)
+    if r.exist() is True:
+        r.open("r")
+        for item in r.info:
+            info[item[0]] = item[1]
+        for item in r.hist:
+        info["full_name"] = r.name_mapset()
+        info["mtype"] = r.mtype
+        if r.cats:
+            info["cats_title"] = r.cats_title
+            info["cats"] = list(r.cats)
+        r.close()
+    return(info)
+def _read_vector_full_info(name, mapset):
+    """Read vector info using PyGRASS VectorTopo
+    info = {}
+    v = VectorTopo(name=name, mapset=mapset)
+    if v.exist() is True:
+        v.open("r")
+        # Bounding box
+        for item in v.bbox().items():
+        info["name"] = v.name
+        info["mapset"] = v.mapset
+        info["comment"] = v.comment
+        info["full_name"] = v.full_name
+        info["is_3d"] = v.is_3D()
+        info["map_date"] = v.map_date
+        info["maptype"] = v.maptype
+        info["organization"] = v.organization
+        info["person"] = v.person
+        info["proj"] = v.proj
+        info["proj_name"] = v.proj_name
+        info["title"] = v.title
+        info["thresh"] = v.thresh
+        info["zone"] = v.zone
+        vtypes = ['areas', 'dblinks', 'faces', 'holes', 'islands',
+                  'kernels', 'lines', 'nodes', 'points', 'updated_lines',
+                  'updated_nodes', 'volumes']
+        for vtype in vtypes:
+            info[vtype] = v.number_of(vtype)
+        info.update(v.num_primitives())
+        if v.table is not None:
+            info["columns"] = v.table.columns
+    return(info)
 def _fatal_error(lock, conn, data):
     """Calls G_fatal_error()"""
     libgis.G_fatal_error("Fatal Error in C library server")
@@ -127,18 +218,23 @@
        :returns: Name of the database or None if no temporal database present
-    mapset = data[1]
-    if not mapset:
-        mapset = libgis.G_mapset()
-    dbstring = libtgis.tgis_get_mapset_database_name(mapset)
+    dbstring = None
+    try:
+        mapset = data[1]
+        if not mapset:
+            mapset = libgis.G_mapset()
+        dbstring = libtgis.tgis_get_mapset_database_name(mapset)
-    if dbstring:
-        # We substitute GRASS variables if they are located in the database string
-        # This behavior is in conjunction with db.connect
-        dbstring = dbstring.replace("$GISDBASE", libgis.G_gisdbase())
-        dbstring = dbstring.replace("$LOCATION_NAME", libgis.G_location())
-        dbstring = dbstring.replace("$MAPSET", mapset)
-    conn.send(dbstring)
+        if dbstring:
+            # We substitute GRASS variables if they are located in the database string
+            # This behavior is in conjunction with db.connect
+            dbstring = dbstring.replace("$GISDBASE", libgis.G_gisdbase())
+            dbstring = dbstring.replace("$LOCATION_NAME", libgis.G_location())
+            dbstring = dbstring.replace("$MAPSET", mapset)
+    except:
+        raise
+    finally:
+        conn.send(dbstring)
@@ -195,21 +291,25 @@
                     mapset, layer]
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
-    layer = data[4]
     check = False
-    if maptype == RPCDefs.TYPE_RASTER:
-        if libgis.G_has_raster_timestamp(name, mapset) == 1:
-            check = True
-    elif maptype == RPCDefs.TYPE_VECTOR:
-        if libgis.G_has_vector_timestamp(name, layer, mapset) == 1:
-            check = True
-    elif maptype == RPCDefs.TYPE_RASTER3D:
-        if libgis.G_has_raster3d_timestamp(name, mapset) == 1:
-            check = True
-    conn.send(check)
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+        layer = data[4]
+            if libgis.G_has_raster_timestamp(name, mapset) == 1:
+                check = True
+            if libgis.G_has_vector_timestamp(name, layer, mapset) == 1:
+                check = True
+        elif maptype == RPCDefs.TYPE_RASTER3D:
+            if libgis.G_has_raster3d_timestamp(name, mapset) == 1:
+                check = True
+    except:
+        raise
+    finally:
+        conn.send(check)
@@ -239,21 +339,26 @@
                     mapset, layer]
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
-    layer = data[4]
     check = False
-    ts = libgis.TimeStamp()
-        check = libgis.G_read_raster_timestamp(name, mapset, byref(ts))
-        check = libgis.G_read_vector_timestamp(name, layer, mapset, byref(ts))
-        check = libgis.G_read_raster3d_timestamp(name, mapset, byref(ts))
+    dates = None
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+        layer = data[4]
+        ts = libgis.TimeStamp()
+            check = libgis.G_read_raster_timestamp(name, mapset, byref(ts))
+            check = libgis.G_read_vector_timestamp(name, layer, mapset, byref(ts))
+            check = libgis.G_read_raster3d_timestamp(name, mapset, byref(ts))
-    dates = _convert_timestamp_from_grass(ts)
-    conn.send((check, dates))
+        dates = _convert_timestamp_from_grass(ts)
+    except:
+        raise
+    finally:
+        conn.send((check, dates))
@@ -273,28 +378,31 @@
                     mapset, layer, timestring]
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
-    layer = data[4]
-    timestring = data[5]
     check = -3
-    check = libgis.G_scan_timestamp(byref(ts), timestring)
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+        layer = data[4]
+        timestring = data[5]
+        check = libgis.G_scan_timestamp(byref(ts), timestring)
-    if check != 1:
-        logging.error("Unable to convert the timestamp: " + timestring)
-        return -2
+        if check != 1:
+            logging.error("Unable to convert the timestamp: " + timestring)
+            return -2
-        check = libgis.G_write_raster_timestamp(name, byref(ts))
-        check = libgis.G_write_vector_timestamp(name, layer, byref(ts))
-        check = libgis.G_write_raster3d_timestamp(name, byref(ts))
+            check = libgis.G_write_raster_timestamp(name, byref(ts))
+            check = libgis.G_write_vector_timestamp(name, layer, byref(ts))
+            check = libgis.G_write_raster3d_timestamp(name, byref(ts))
+    except:
+        raise
+    finally:
+        conn.send(check)
-    conn.send(check)
@@ -314,20 +422,23 @@
                     mapset, layer]
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
-    layer = data[4]
     check = False
-        check = libgis.G_remove_raster_timestamp(name, mapset)
-        check = libgis.G_remove_vector_timestamp(name, layer, mapset)
-        check = libgis.G_remove_raster3d_timestamp(name, mapset)
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+        layer = data[4]
+            check = libgis.G_remove_raster_timestamp(name, mapset)
+            check = libgis.G_remove_vector_timestamp(name, layer, mapset)
+            check = libgis.G_remove_raster3d_timestamp(name, mapset)
+    except:
+        raise
+    finally:
+        conn.send(check)
-    conn.send(check)
@@ -342,22 +453,25 @@
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
     check = False
-        mapset = libgis.G_find_raster(name, mapset)
-        mapset = libgis.G_find_vector(name, mapset)
-        mapset = libgis.G_find_raster3d(name, mapset)
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+            mapset = libgis.G_find_raster(name, mapset)
+            mapset = libgis.G_find_vector(name, mapset)
+            mapset = libgis.G_find_raster3d(name, mapset)
-    if mapset:
-        check = True
+        if mapset:
+            check = True
+    except:
+        raise
+    finally:
+        conn.send(check)
-    conn.send(check)
@@ -369,18 +483,22 @@
-    maptype = data[1]
-    name = data[2]
-    mapset = data[3]
-        kvp = _read_raster_info(name, mapset)
-        kvp = _read_vector_info(name, mapset)
-        kvp = _read_raster3d_info(name, mapset)
+    kvp = None
+    try:
+        maptype = data[1]
+        name = data[2]
+        mapset = data[3]
+            kvp = _read_raster_info(name, mapset)
+            kvp = _read_vector_info(name, mapset)
+            kvp = _read_raster3d_info(name, mapset)
+    except:
+        raise
+    finally:
+        conn.send(kvp)
-    conn.send(kvp)
@@ -765,7 +883,7 @@
     libgis.G_add_error_handler(cerror_handler, None)
     # Crerate the function array
-    functions = [0]*15
+    functions = [0]*50
     functions[RPCDefs.STOP] = _stop
     functions[RPCDefs.HAS_TIMESTAMP] = _has_timestamp
     functions[RPCDefs.WRITE_TIMESTAMP] = _write_timestamp
@@ -779,6 +897,7 @@
     functions[RPCDefs.G_MAPSET] = _get_mapset
     functions[RPCDefs.G_LOCATION] = _get_location
     functions[RPCDefs.G_GISDBASE] = _get_gisdbase
+    functions[RPCDefs.READ_MAP_FULL_INFO] = _read_map_full_info
     functions[RPCDefs.G_FATAL_ERROR] = _fatal_error
     libgis.G_gisinit("c_library_server")
@@ -843,6 +962,10 @@
            True
            >>> ciface.read_raster_info("test", tgis.get_current_mapset())
            {'rows': 12, 'north': 80.0, 'min': 1, 'datatype': 'CELL', 'max': 1, 'ewres': 10.0, 'cols': 8, 'west': 0.0, 'east': 120.0, 'nsres': 10.0, 'south': 0.0}
+           >>> ciface.read_raster_full_info("test", tgis.get_current_mapset()) # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
+           {u'tbres': 1.0, ... 'title': 'test', u'south': 0.0}
            >>> check = ciface.has_raster_timestamp("test", tgis.get_current_mapset())
            >>> print check
            True
@@ -890,8 +1013,23 @@
            >>> print check
            True
            >>> kvp = ciface.read_vector_info("test", tgis.get_current_mapset())
+           >>> kvp['points']
+           10
+           >>> kvp = ciface.read_vector_full_info("test", tgis.get_current_mapset())
            >>> print kvp['points']
            10
+           >>> kvp['point']
+           10
+           >>> kvp['area']
+           0
+           >>> kvp['lines']
+           10
+           >>> kvp['line']
+           0
+           >>> 'columns' in kvp
+           False
            >>> check = ciface.has_vector_timestamp("test", tgis.get_current_mapset(), None)
            >>> print check
            True
@@ -979,7 +1117,23 @@
         self.client_conn.send([RPCDefs.READ_MAP_INFO, RPCDefs.TYPE_RASTER,
                                name, mapset, None])
         return self.safe_receive("read_raster_info")
+    def read_raster_full_info(self, name, mapset):
+           future.
+           :param name: The name of the map
+           :param mapset: The mapset of the map
+           :returns: The key value pairs of the map specific metadata,
+                     or None in case of an error
+        self.check_server()
+        self.client_conn.send([RPCDefs.READ_MAP_FULL_INFO,
+                               RPCDefs.TYPE_RASTER,
+                               name, mapset, None])
+        return self.safe_receive("read_raster_full_info")
     def has_raster_timestamp(self, name, mapset):
         """Check if a file based raster timetamp exists
@@ -1168,6 +1322,21 @@
         return self.safe_receive("read_vector_info")
+    def read_vector_full_info(self, name, mapset):
+                               RPCDefs.TYPE_VECTOR,
+        return self.safe_receive("read_vector_full_info")
     def has_vector_timestamp(self, name, mapset, layer=None):
         """Check if a file based vector timetamp exists
