[GRASS-SVN] r66144 - grass/trunk/locale/po
Mon Sep 7 13:46:47 PDT 2015
Author: neteler
Date: 2015-09-07 13:46:47 -0700 (Mon, 07 Sep 2015)
New Revision: 66144
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
keywords cosmetics: completing r66133
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_ar.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13628,7 +13628,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:122
 #: ../vector/v.lrs/v.lrs.label/main.c:103
 #, fuzzy
-msgid "Linear Reference System"
+msgid "linear reference system"
 msgstr "اسم ملف الأصناف المرجعية"
 #: ../vector/v.lrs/v.lrs.segment/main.c:75
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_cs.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13690,7 +13690,7 @@
 #, fuzzy
 msgstr "Lineární referenční systém"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_de.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13676,9 +13676,8 @@
 #: ../vector/v.lrs/v.lrs.where/main.c:58
-#, fuzzy
-msgstr "Erzeuge Linearesreferenzsystem"
+msgstr "Lineares Referenzsystem"
 msgid ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_el.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13072,7 +13072,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_es.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13757,7 +13757,7 @@
 #, fuzzy
 msgstr "Crear Sistema de Referencia Lineal (LRS)"
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_fi.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -12584,7 +12584,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_fr.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -14344,7 +14344,7 @@
 #, fuzzy
 msgstr "Nom de fichier des classes de référence"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_it.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13504,7 +13504,7 @@
 #, fuzzy
 msgstr "Crea sistema di riferimento lineare"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_ja.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13510,7 +13510,7 @@
 #, fuzzy
 msgstr "線型参照系を作成"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_ko.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13147,7 +13147,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_lv.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13663,7 +13663,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_pl.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13532,7 +13532,7 @@
 #, fuzzy
 msgstr "Utwórz Linear Reference System"
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_pt.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13909,7 +13909,7 @@
 #, fuzzy
 msgstr "Nome do arquivo para as classes de referência"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2015-09-07 20:46:47 UTC (rev 66144)
 #, fuzzy
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_ro.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -12748,7 +12748,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_ru.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13721,7 +13721,7 @@
 #, fuzzy
 msgstr "Создать линейную систему координат"
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_sl.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13686,7 +13686,7 @@
 #, fuzzy
 msgstr "Ime datoteke z referenènimi razredi"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_th.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13635,7 +13635,7 @@
 #, fuzzy
 msgstr "สร้าง ระบบการอ้างอิงตำแหน่งเชิงเส้น"
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_tr.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13409,7 +13409,7 @@
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_vi.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13712,7 +13712,7 @@
 #, fuzzy
 msgstr "Tạo Hệ tham chiếu Tuyến tính"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2015-09-07 20:11:46 UTC (rev 66143)
+++ grass/trunk/locale/po/grassmods_zh.po	2015-09-07 20:46:47 UTC (rev 66144)
@@ -13645,7 +13645,7 @@
 #, fuzzy
 msgstr "基准分类的文件名称"
