[GRASS-SVN] r66204 - in grass/trunk/gui/wxpython: core tplot
Sun Sep 13 19:49:57 PDT 2015
Author: annakrat
Date: 2015-09-13 19:49:57 -0700 (Sun, 13 Sep 2015)
New Revision: 66204
   grass/trunk/gui/wxpython/core/toolboxes.py
   grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
workaround some compilation problems on Mac (see #2142, #1819)
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py	2015-09-13 22:14:56 UTC (rev 66203)
+++ grass/trunk/gui/wxpython/core/toolboxes.py	2015-09-14 02:49:57 UTC (rev 66204)
@@ -62,14 +62,20 @@
         # (these files are always check for existence here)
         return ""
-userToolboxesFile = os.path.join(GetSettingsPath(), 'toolboxes', 'toolboxes.xml')
-userMainMenuFile = os.path.join(GetSettingsPath(), 'toolboxes', 'main_menu.xml')
-if not os.path.exists(userToolboxesFile):
-    userToolboxesFile = None
-if not os.path.exists(userMainMenuFile):
-    userMainMenuFile = None
+def _getUserToolboxesFile():
+    userToolboxesFile = os.path.join(GetSettingsPath(), 'toolboxes', 'toolboxes.xml')
+    if not os.path.exists(userToolboxesFile):
+        userToolboxesFile = None
+    return userToolboxesFile
+def _getUserMainMenuFile():
+    userMainMenuFile = os.path.join(GetSettingsPath(), 'toolboxes', 'main_menu.xml')
+    if not os.path.exists(userMainMenuFile):
+        userMainMenuFile = None
+    return userMainMenuFile
 def _(string):
     """Get translated version of a string"""
     # is attribute initialized to actual value?
@@ -156,27 +162,27 @@
         if os.path.exists(menudataFile):
             # remove menu file when there is no main_menu and toolboxes
-            if not userToolboxesFile and not userRootFile:
+            if not _getUserToolboxesFile() and not userRootFile:
                 os.remove(menudataFile)
                 _debug(2, "toolboxes.getMenudataFile: no user defined files, menudata deleted")
                 return fallback
-            if bool(userToolboxesFile) != bool(userRootFile):
+            if bool(_getUserToolboxesFile()) != bool(userRootFile):
                 # always generate new because we don't know if there has been any change
                 generateNew = True
                 _debug(2, "toolboxes.getMenudataFile: only one of the user defined files")
             else:
                 # if newer files -> generate new
                 menudataTime = os.path.getmtime(menudataFile)
-                if userToolboxesFile:
-                    if os.path.getmtime(userToolboxesFile) > menudataTime:
+                if _getUserToolboxesFile():
+                    if os.path.getmtime(_getUserToolboxesFile()) > menudataTime:
                         _debug(2, "toolboxes.getMenudataFile: user toolboxes is newer than menudata")
                         generateNew = True
                 if userRootFile:
                     if os.path.getmtime(userRootFile) > menudataTime:
                         _debug(2, "toolboxes.getMenudataFile: user root file is newer than menudata")
                         generateNew = True
-        elif userToolboxesFile or userRootFile:
+        elif _getUserToolboxesFile() or userRootFile:
             _debug(2, "toolboxes.getMenudataFile: no menudata")
             generateNew = True
         else:
@@ -256,8 +262,8 @@
     toolboxes = etree.parse(toolboxesFile)
-    if userDefined and userToolboxesFile:
-        userToolboxes = etree.parse(userToolboxesFile)
+    if userDefined and _getUserToolboxesFile():
+        userToolboxes = etree.parse(_getUserToolboxesFile())
     else:
         userToolboxes = None
@@ -604,9 +610,11 @@
                 hasErrors = True
     if hasErrors:
-        sys.stderr.write(_("WARNING: Some addons failed when loading. "
-                           "Please consider to update your addons by running 'g.extension.all -f'.\n"))
+        # not translatable until toolboxes compilation on Mac is fixed
+        # translating causes importing globalvar, where sys.exit is called
+        sys.stderr.write("WARNING: Some addons failed when loading. "
+                         "Please consider to update your addons by running 'g.extension.all -f'.\n")
 def _escapeXML(text):
     """Helper function for correct escaping characters for XML.
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py	2015-09-13 22:14:56 UTC (rev 66203)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py	2015-09-14 02:49:57 UTC (rev 66204)
@@ -72,7 +72,6 @@
 #%end
 import grass.script as gscript
-from core.giface import StandaloneGrassInterface
 def main():
@@ -80,6 +79,7 @@
     import wx
     from core.utils import _
+    from core.giface import StandaloneGrassInterface
     try:
         from tplot.frame import TplotFrame
     except ImportError as e:
