[GRASS-SVN] r66211 - grass-addons/grass7/raster/r.mcda.promethee
Mon Sep 14 06:15:22 PDT 2015
Author: gianluca
Date: 2015-09-14 06:15:21 -0700 (Mon, 14 Sep 2015)
New Revision: 66211
   grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
   grass-addons/grass7/raster/r.mcda.promethee/main.c
   grass-addons/grass7/raster/r.mcda.promethee/promethee.c
negative and positive flow output
Modified: grass-addons/grass7/raster/r.mcda.promethee/local_proto.h
--- grass-addons/grass7/raster/r.mcda.promethee/local_proto.h	2015-09-14 13:01:36 UTC (rev 66210)
+++ grass-addons/grass7/raster/r.mcda.promethee/local_proto.h	2015-09-14 13:15:21 UTC (rev 66211)
@@ -20,5 +20,4 @@
 void build_flow_matrix(int nrows, int ncols, int ncriteria,
                             double *weight_vect, double ***decision_vol,
-                            double **positive_flow_vol, double **negative_flow_vol,
-                            double **net_flow_vol);
+                            double **positive_flow_vol, double **negative_flow_vol);
Modified: grass-addons/grass7/raster/r.mcda.promethee/main.c
--- grass-addons/grass7/raster/r.mcda.promethee/main.c	2015-09-14 13:01:36 UTC (rev 66210)
+++ grass-addons/grass7/raster/r.mcda.promethee/main.c	2015-09-14 13:15:21 UTC (rev 66211)
@@ -30,22 +30,22 @@
 int main(int argc, char *argv[])
     struct Cell_head cellhd;    /* it stores region information,  and header information of rasters */
-    char *result_positive_flow, *result_negative_flow, *result_net_flow;     /* outputs raster name */
+    char *result_positive_flow, *result_negative_flow;     /* outputs raster name */
     /*char *mapset;      mapset name */
-    unsigned char *outrast_positive_flow, *outrast_negative_flow, *outrast_net_flow;  /* output buffer */
+    unsigned char *outrast_positive_flow, *outrast_negative_flow;  /* output buffer */
     int i,j, ncriteria=0;   /* index and  files number*/
     int nrows, ncols;
     int row1, col1;
-    int outfd_positive_flow, outfd_negative_flow, outfd_net_flow;      /* output file descriptor */
+    int outfd_positive_flow, outfd_negative_flow;      /* output file descriptor */
     /*RASTER_MAP_TYPE data_type;     type of the map (CELL/DCELL/...) */
-    double *weight_vect, ***decision_vol, **positive_flow_vol, **negative_flow_vol, **net_flow_vol;/* vector and matrix */
+    double *weight_vect, ***decision_vol, **positive_flow_vol, **negative_flow_vol;/* vector and matrix */
     struct History history; /* holds meta-data (title, comments,..) */
     struct GModule *module; /* GRASS module for parsing arguments */
-    struct Option *criteria, *weight, *positiveflow, *negativeflow, *netflow;   /* options */
+    struct Option *criteria, *weight, *positiveflow, *negativeflow;   /* options */
     struct input *attributes; /*storage  alla input criteria GRID files and output concordance and discordance GRID files*/
@@ -90,14 +90,6 @@
     negativeflow->answer ="negativeflow";
     negativeflow->description = "negative flow output map";
-    netflow = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
-    netflow->key = "netflow";
-    netflow->type = TYPE_STRING;
-    netflow->required = YES;
-    netflow->gisprompt = "new,cell,raster";
-    netflow->answer ="netflow";
-    netflow->description = "net flow output map";
     /* options and flags parser */
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
@@ -145,7 +137,6 @@
     result_positive_flow=positiveflow->answer; /* store output name in variables*/
     result_negative_flow=negativeflow->answer;
-    result_net_flow=netflow->answer;
     if (G_legal_filename(result_positive_flow) < 0) /* check for legal database file names */
@@ -154,8 +145,6 @@
     if (G_legal_filename(result_negative_flow) < 0) /* check for legal database file names */
         G_fatal_error(_("<%s> is an illegal file name"), result_negative_flow);
-    if (G_legal_filename(result_net_flow) < 0) /* check for legal database file names */
-        G_fatal_error(_("<%s> is an illegal file name"), result_net_flow);
     /*values = G_malloc(ncriteria * sizeof(DCELL));*/
@@ -166,8 +155,6 @@
     decision_vol=G_malloc(nrows * sizeof(double*));
     positive_flow_vol=G_calloc(nrows, sizeof(double*)); /*Allocates aligned block of memory and initializes the allocated memory to zero.*/
     negative_flow_vol=G_calloc(nrows, sizeof(double*));
-    net_flow_vol=G_calloc(nrows, sizeof(double*));
-    //negative_flow_vol=G_calloc(nrows, sizeof(double*));
     for (i=0; i<nrows; ++i)
@@ -175,7 +162,7 @@
         decision_vol[i]=G_malloc(ncols * sizeof(double*));
         positive_flow_vol[i]=G_calloc(ncols, sizeof(double*));/*Allocates aligned block of memory and initializes the allocated memory to zero.*/
         negative_flow_vol[i]=G_calloc(ncols, sizeof(double*));
-        negative_flow_vol[i]=G_calloc(ncols, sizeof(double*));
         for (j=0; j<ncols; ++j)
             decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage ****/
@@ -185,13 +172,11 @@
     /* Allocate output buffer, use  DCELL_TYPE */
     outrast_positive_flow = Rast_allocate_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
     outrast_negative_flow = Rast_allocate_buf(DCELL_TYPE);
-    outrast_net_flow = Rast_allocate_buf(DCELL_TYPE);
     /* controlling, if we can write the raster */
     outfd_positive_flow = Rast_open_new(result_positive_flow, DCELL_TYPE);
     outfd_negative_flow = Rast_open_new(result_negative_flow, DCELL_TYPE);
-    outfd_net_flow = Rast_open_new(result_net_flow, DCELL_TYPE);
     /*build a three dimensional matrix for storage all critera maps*/
     G_message("Load data");
@@ -212,7 +197,7 @@
     G_message("run algorithm");
-    build_flow_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol,positive_flow_vol,negative_flow_vol,net_flow_vol); /*scan all DCELL, make a pairwise comparatione, buil positive flow matrix*/
+    build_flow_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol,positive_flow_vol,negative_flow_vol); /*scan all DCELL, make a pairwise comparatione, buil positive flow matrix*/
     G_message("buil mcda maps");
     for (row1 = 0; row1 < nrows; row1++)
@@ -222,11 +207,9 @@
             ((DCELL *) outrast_positive_flow)[col1] = (DCELL)positive_flow_vol[row1][col1];/*write positive flow map*/
             ((DCELL *) outrast_negative_flow)[col1] = (DCELL)negative_flow_vol[row1][col1];/*write negative flow map*/
-            //((DCELL *) outrast_net_flow)[col1] = (DCELL)net_flow_vol[row1][col1];/*write negative flow map*/;
         Rast_put_row(outfd_positive_flow, outrast_positive_flow,  DCELL_TYPE);
         Rast_put_row(outfd_negative_flow, outrast_negative_flow,  DCELL_TYPE);
-        //Rast_put_row(outfd_net_flow, outrast_net_flow,  DCELL_TYPE);
@@ -238,19 +221,18 @@
     G_free(outrast_positive_flow);
     G_free(outrast_negative_flow);
-    G_free(outrast_net_flow);
     G_free(decision_vol);
     G_free(positive_flow_vol);
     G_free(negative_flow_vol);
-    G_free(net_flow_vol);
     /* closing raster maps */
     for (i = 0; i<ncriteria; i++)
         Rast_close(attributes[i].infd);
     Rast_close(outfd_positive_flow);
     Rast_close(outfd_negative_flow);
-    Rast_close(outfd_net_flow);
     /* add command line incantation to history positive file */
     Rast_short_history(result_positive_flow, "raster", &history);
@@ -262,10 +244,6 @@
     Rast_command_history(&history);
     Rast_write_history(result_negative_flow, &history);
-        /* add command line incantation to history net file */
-    Rast_short_history(result_net_flow, "raster", &history);
-    Rast_command_history(&history);
-    Rast_write_history(result_net_flow, &history);
     exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.mcda.promethee/promethee.c
--- grass-addons/grass7/raster/r.mcda.promethee/promethee.c	2015-09-14 13:01:36 UTC (rev 66210)
+++ grass-addons/grass7/raster/r.mcda.promethee/promethee.c	2015-09-14 13:15:21 UTC (rev 66211)
@@ -9,8 +9,7 @@
@@ -51,8 +50,7 @@
     int row1, col1, row2, col2;
     int i;
@@ -92,13 +90,11 @@
 	for(row1 = 0; row1 < nrows; row1++)
-			G_message("--");
 			for (col1 = 0; col1 < ncols; col1++)
 					//G_percent(col1, (ncols), 2);
 					positive_flow_vol[row1][col1]=positive_flow_vol[row1][col1]/ncriteria;
 					negative_flow_vol[row1][col1]=negative_flow_vol[row1][col1]/ncriteria;
-					//net_flow_vol[row1][col1]=0; //positive_flow_vol[row1][col1]-negative_flow_vol[row1][col1];
 					//G_message("%f-%f=%f",positive_flow_vol[row1][col1],negative_flow_vol[row1][col1],net_flow_vol[row1][col1]);
