[GRASS-SVN] r66277 - in grass/trunk: lib/python/temporal locale/po
Tue Sep 22 04:30:32 PDT 2015
Author: neteler
Date: 2015-09-22 04:30:32 -0700 (Tue, 22 Sep 2015)
New Revision: 66277
   grass/trunk/lib/python/temporal/open_stds.py
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fi.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_ml.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ro.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
temporal: fix msg typo
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/lib/python/temporal/open_stds.py	2015-09-22 11:30:32 UTC (rev 66277)
@@ -63,7 +63,7 @@
     if not sp.is_in_db(dbif):
         dbif.close()
-        msgr.fatal(_("Space time %(sp)s dataset <%(name)s> no found") %
+        msgr.fatal(_("Space time %(sp)s dataset <%(name)s> not found") %
                    {'sp': sp.get_new_map_instance(None).get_type(),
                     'name': name})
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ar.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3699,7 +3699,7 @@
 #: ../lib/python/temporal/open_stds.py:66
 #, fuzzy, python-format
-msgid "Space time %(sp)s dataset <%(name)s> no found"
+msgid "Space time %(sp)s dataset <%(name)s> not found"
 msgstr "غير موجود'%s' الفيكتور"
 #: ../lib/python/temporal/open_stds.py:105
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_cs.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3751,7 +3751,7 @@
 msgstr "Rastrová mapa <%s> nebyla nalezena"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_de.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3745,7 +3745,7 @@
 msgstr "Rasterkarte <%s> wurde nicht gefunden."
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_el.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3741,7 +3741,7 @@
 msgstr "Ο χάρτης raster  <%s> δεν βρέθηκε"
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_es.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3886,7 +3886,7 @@
 msgstr "No se ha encontrado el mapa raster <%s>."
Modified: grass/trunk/locale/po/grasslibs_fi.po
--- grass/trunk/locale/po/grasslibs_fi.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_fi.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3562,7 +3562,7 @@
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_fr.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3778,7 +3778,7 @@
 msgstr "La carte vecteur <%s> n'a pas été trouvée"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_it.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3755,7 +3755,7 @@
 msgstr "Raster <%s> non trovato"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ja.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3744,7 +3744,7 @@
 msgstr "ラスターマップ <%s> が見つかりません"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ko.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3658,7 +3658,7 @@
 msgstr "'%s' 디버그파일을 열 수 없습니다"
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_lv.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3687,7 +3687,7 @@
 msgstr "Ieejas vektors '%s' nav atrasts"
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ml.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3625,7 +3625,7 @@
 msgstr "റാസ്റ്റെർ മാപ്പ് <%s> കണ്മാനില്ല"
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_pl.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3716,7 +3716,7 @@
 msgstr "Mapa rastrowa <%s> nie została znaleziona"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_pt.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3737,7 +3737,7 @@
 msgstr "Vetor de entrada '%s' não encontrado"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3722,7 +3722,7 @@
Modified: grass/trunk/locale/po/grasslibs_ro.po
--- grass/trunk/locale/po/grasslibs_ro.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ro.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3628,7 +3628,7 @@
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_ru.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3753,7 +3753,7 @@
 msgstr "Растровый слой <%s> не найден"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_sl.po	2015-09-22 11:30:32 UTC (rev 66277)
 msgstr "Vneseni vektor '%s' ni bil najden"
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_th.po	2015-09-22 11:30:32 UTC (rev 66277)
 msgstr "ไม่พบแผนที่เชิงภาพ <%s> "
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_tr.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3670,7 +3670,7 @@
 msgstr "<%s> raster haritası bulunamadı"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_vi.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3743,7 +3743,7 @@
 msgstr "Không tìm thấy bản đồ raster <%s>"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2015-09-22 11:29:02 UTC (rev 66276)
+++ grass/trunk/locale/po/grasslibs_zh.po	2015-09-22 11:30:32 UTC (rev 66277)
@@ -3739,7 +3739,7 @@
 msgstr "输入矢量'%s'未找到"
