[GRASS-SVN] r66281 - in grass/branches/releasebranch_7_0: imagery/i.cluster temporal/t.create temporal/t.info temporal/t.list
Tue Sep 22 05:05:03 PDT 2015
Author: neteler
Date: 2015-09-22 05:05:02 -0700 (Tue, 22 Sep 2015)
New Revision: 66281
   grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html
   grass/branches/releasebranch_7_0/temporal/t.create/t.create.html
   grass/branches/releasebranch_7_0/temporal/t.info/t.info.html
   grass/branches/releasebranch_7_0/temporal/t.list/t.list.html
manual: minor tweaks
Modified: grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html
--- grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html	2015-09-22 12:04:47 UTC (rev 66280)
+++ grass/branches/releasebranch_7_0/imagery/i.cluster/i.cluster.html	2015-09-22 12:05:02 UTC (rev 66281)
@@ -269,7 +269,7 @@
 # generate signature file and report
 i.cluster group=lsat7_2002 subgroup=lsat7_2002 \
   signaturefile=sig_cluster_lsat2002 \
-  classes=10 report=rep_clust_lsat2002.txt
+  classes=10 reportfile=rep_clust_lsat2002.txt
 </pre></div>
 To complete the unsupervised classification, <em>i.maxlik</em> is subsequently used.
Modified: grass/branches/releasebranch_7_0/temporal/t.create/t.create.html
--- grass/branches/releasebranch_7_0/temporal/t.create/t.create.html	2015-09-22 12:04:47 UTC (rev 66280)
+++ grass/branches/releasebranch_7_0/temporal/t.create/t.create.html	2015-09-22 12:05:02 UTC (rev 66281)
@@ -44,6 +44,7 @@
 <em>
 <a href="t.register.html">t.register</a>,
+<a href="t.remove.html">t.remove</a>,
 <a href="t.info.html">t.info</a>
 </em>
Modified: grass/branches/releasebranch_7_0/temporal/t.info/t.info.html
--- grass/branches/releasebranch_7_0/temporal/t.info/t.info.html	2015-09-22 12:04:47 UTC (rev 66280)
+++ grass/branches/releasebranch_7_0/temporal/t.info/t.info.html	2015-09-22 12:05:02 UTC (rev 66281)
@@ -141,6 +141,7 @@
 <em>
 <a href="t.create.html">t.create</a>,
+<a href="t.list.html">t.list</a>,
 <a href="r.info.html">r.info</a>,
 <a href="r3.info.html">r3.info</a>,
Modified: grass/branches/releasebranch_7_0/temporal/t.list/t.list.html
--- grass/branches/releasebranch_7_0/temporal/t.list/t.list.html	2015-09-22 12:04:47 UTC (rev 66280)
+++ grass/branches/releasebranch_7_0/temporal/t.list/t.list.html	2015-09-22 12:05:02 UTC (rev 66281)
@@ -23,7 +23,7 @@
 <h2>EXAMPLES</h2>
-In order to obtain the list of raster space time dataset
+Obtain the list of raster space time dataset(s):
 <div class="code"><pre>
 t.list strds
@@ -32,11 +32,12 @@
 tempmean_monthly at climate_2000_2012
 </pre></div>
-Tha user can obtain also the list of raster contained into temporal
-datasets
+The user can obtain also the list of raster maps contained in a temporal
+datasets (this may be the content of several space time datasets if enabled
+through <a href="g.mapsets.html">g.mapsets</a>):
-t.list rast
+t.list raster
 Time stamped raster maps with absolute time available in mapset <climate_2000_2012>:
 2009_01_tempmean at climate_2000_2012
 2009_02_tempmean at climate_2000_2012
