[GRASS-SVN] r66298 - grass/trunk/scripts/r.import
Tue Sep 22 19:46:04 PDT 2015
Author: annakrat
Date: 2015-09-22 19:46:04 -0700 (Tue, 22 Sep 2015)
New Revision: 66298
   grass/trunk/scripts/r.import/r.import.py
r.import: fix import in latlon location
Modified: grass/trunk/scripts/r.import/r.import.py
--- grass/trunk/scripts/r.import/r.import.py	2015-09-22 22:24:10 UTC (rev 66297)
+++ grass/trunk/scripts/r.import/r.import.py	2015-09-23 02:46:04 UTC (rev 66298)
@@ -254,13 +254,23 @@
                                                 memory=memory, quiet=True)
             except CalledModuleError:
                 grass.fatal(_("Unable to get reprojected map extent"))
+            try:
+                srcregion = grass.parse_key_val(tgtextents, val_type=float, vsep=' ')
+                n = srcregion['n']
+                s = srcregion['s']
+                e = srcregion['e']
+                w = srcregion['w']
+            except ValueError:  # import into latlong, expect 53:39:06.894826N
+                srcregion = grass.parse_key_val(tgtextents, vsep=' ')
+                n = grass.float_or_dms(srcregion['n'][:-1]) * \
+                    (-1 if srcregion['n'][-1] == 'S' else 1)
+                s = grass.float_or_dms(srcregion['s'][:-1]) * \
+                    (-1 if srcregion['s'][-1] == 'S' else 1)
+                e = grass.float_or_dms(srcregion['e'][:-1]) * \
+                    (-1 if srcregion['e'][-1] == 'W' else 1)
+                w = grass.float_or_dms(srcregion['w'][:-1]) * \
+                    (-1 if srcregion['w'][-1] == 'W' else 1)
-            srcregion = grass.parse_key_val(tgtextents, val_type=float, vsep=' ')
-            n = srcregion['n']
-            s = srcregion['s']
-            e = srcregion['e']
-            w = srcregion['w']
             grass.run_command('g.region', n=n, s=s, e=e, w=w)
         # v.in.region in tgt
