[GRASS-SVN] r66345 - grass/trunk/vector/v.in.lidar
Sat Sep 26 18:59:51 PDT 2015
Author: wenzeslaus
Date: 2015-09-26 18:59:51 -0700 (Sat, 26 Sep 2015)
New Revision: 66345
   grass/trunk/vector/v.in.lidar/main.c
v.in.lidar: count imported points explicitly
This avoids limits imposed by header reading functions in libLAS.
Assuming that the libLAS reading functions will actually still work.
Ignoring the issue for messages before processing, percentage and info.
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c	2015-09-27 01:30:37 UTC (rev 66344)
+++ grass/trunk/vector/v.in.lidar/main.c	2015-09-27 01:59:51 UTC (rev 66345)
@@ -152,10 +152,14 @@
     int cat_max_reached = FALSE;
 #ifdef HAVE_LONG_LONG_INT
-    unsigned long long n_features, feature_count, n_outside,
+    unsigned long long n_features; /* what libLAS reports as point count */
+    unsigned long long points_imported; /* counter how much we have imported */
+    unsigned long long feature_count, n_outside,
         n_filtered, n_class_filtered, not_valid;
 #else
-    unsigned long n_features, feature_count, n_outside,
+    unsigned long n_features;
+    unsigned long points_imported;
+    unsigned long feature_count, n_outside,
 #endif
@@ -619,7 +623,12 @@
 	G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
     Vect_hist_command(&Map);
+    /* libLAS uses uint32_t according to the source code
+     * or unsigned int according to the online doc,
+     * so just storing in long doesn't help.
+     * Thus, we use this just for the messages and percents.
     n_features = LASHeader_GetPointRecordsCount(LAS_header);
     las_point_format = LASHeader_GetDataFormatId(LAS_header);
@@ -744,6 +753,7 @@
     /* Import feature */
+    points_imported = 0;
     cat = 1;
     not_valid = 0;
     feature_count = 0;
@@ -974,6 +984,7 @@
             break;
 	cat++;
+        points_imported++;
     G_percent(n_features, n_features, 1);	/* finish it */
@@ -991,15 +1002,12 @@
 	Vect_build(&Map);
     Vect_close(&Map);
-    /* compute how much we have imported */
-#ifdef HAVE_LONG_LONG_INT
-    unsigned long long points_imported;
-#else
-    unsigned long points_imported;
-#endif
-    /* valid only when not having count limit */
-    points_imported = n_features - not_valid - n_outside - n_filtered
-        - n_class_filtered - offset_n_counter - n_count_filtered;
+    /* can be easily determined only when not having count limit */
+    if (!limit_n && points_imported != n_features - not_valid - n_outside
+            - n_filtered - n_class_filtered - offset_n_counter - n_count_filtered)
+        G_warning(_("The underlying libLAS library is at its limits."
+                    " Previously reported counts might have been distorted."
+                    " However, the import itself should be unaffected."));
     if (limit_n)
