[GRASS-SVN] r66350 - in grass/branches/releasebranch_7_0/temporal: t.rast.aggregate t.rast.aggregate.ds
Sun Sep 27 05:55:22 PDT 2015
Author: neteler
Date: 2015-09-27 05:55:22 -0700 (Sun, 27 Sep 2015)
New Revision: 66350
   grass/branches/releasebranch_7_0/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
   grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.py
temporal: fix typo in msg; sync white space to trunk
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.py	2015-09-27 12:51:49 UTC (rev 66349)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.aggregate/t.rast.aggregate.py	2015-09-27 12:55:22 UTC (rev 66350)
@@ -89,7 +89,7 @@
 #%flag
 #% key: s
-#% description: Use start time - truncated accoring to granularity - as suffix. This flag overrides the offset option.
+#% description: Use start time - truncated according to granularity - as suffix (overrides offset option)
 #%end
 import grass.script as gcore
@@ -111,11 +111,11 @@
     offset = options["offset"]
     nprocs = options["nprocs"]
     time_suffix = flags["s"]
     topo_list = sampling.split(",")
     tgis.init()
     dbif = tgis.SQLDatabaseInterfaceConnection()
     dbif.connect()
@@ -129,7 +129,7 @@
     # We will create the strds later, but need to check here
     tgis.check_new_stds(output, "strds",   dbif,  gcore.overwrite())
     start_time = map_list[0].temporal_extent.get_start_time()
     if sp.is_time_absolute():
@@ -164,13 +164,13 @@
             end = start_time + int(gran)
             granule.set_relative_time(start, end,  sp.get_relative_time_unit())
         start_time = end
         granularity_list.append(granule)
-    output_list = tgis.aggregate_by_topology(granularity_list=granularity_list,  granularity=gran,
-        map_list=map_list,
+    output_list = tgis.aggregate_by_topology(granularity_list=granularity_list,  granularity=gran,
+        map_list=map_list,
        topo_list=topo_list,  basename=base, time_suffix=time_suffix,
-        offset=offset,  method=method,  nprocs=nprocs,  spatial=None,
+        offset=offset,  method=method,  nprocs=nprocs,  spatial=None,
        overwrite=gcore.overwrite())
     if output_list:
@@ -178,12 +178,12 @@
         output_strds = tgis.open_new_stds(output, "strds", temporal_type,
        title, description, semantic_type,
-        if register_null:
-            register_null=False
-        else:
+        if register_null:
+            register_null=False
+        else:
             register_null=True
-        tgis.register_map_object_list("rast", output_list,  output_strds, register_null,
+        tgis.register_map_object_list("rast", output_list,  output_strds, register_null,
                                                        sp.get_relative_time_unit(),  dbif)
         # Update the raster metadata table entries with aggregation type
Modified: grass/branches/releasebranch_7_0/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/branches/releasebranch_7_0/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2015-09-27 12:51:49 UTC (rev 66349)
+++ grass/branches/releasebranch_7_0/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2015-09-27 12:55:22 UTC (rev 66350)
@@ -90,7 +90,7 @@
 #%flag
 #% key: s
 #%end
