[GRASS-SVN] r66380 - grass/trunk/raster/r.in.lidar
Tue Sep 29 19:31:39 PDT 2015
Author: wenzeslaus
Date: 2015-09-29 19:31:39 -0700 (Tue, 29 Sep 2015)
New Revision: 66380
   grass/trunk/raster/r.in.lidar/main.c
r.in.lidar: more gui sections
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c	2015-09-30 01:07:13 UTC (rev 66379)
+++ grass/trunk/raster/r.in.lidar/main.c	2015-09-30 02:31:39 UTC (rev 66380)
@@ -205,6 +205,7 @@
     base_raster_opt->required = NO;
     base_raster_opt->label = _("Subtract raster values from the z coordinates");
     base_raster_opt->description = _("The scale for z is applied beforehand, the filter afterwards");
+    base_raster_opt->guisection = _("Transform");
     zrange_opt = G_define_option();
     zrange_opt->key = "zrange";
@@ -212,6 +213,7 @@
     zrange_opt->required = NO;
     zrange_opt->key_desc = "min,max";
     zrange_opt->description = _("Filter range for z data (min,max)");
+    zrange_opt->guisection = _("Selection");
     zscale_opt = G_define_option();
     zscale_opt->key = "zscale";
@@ -219,6 +221,7 @@
     zscale_opt->required = NO;
     zscale_opt->answer = "1.0";
     zscale_opt->description = _("Scale to apply to z data");
+    zscale_opt->guisection = _("Transform");
     percent_opt = G_define_option();
     percent_opt->key = "percent";
@@ -243,6 +246,7 @@
     trim_opt->type = TYPE_DOUBLE;
     trim_opt->required = NO;
     trim_opt->options = "0-50";
+    trim_opt->label = _("Discard given percentage of the smallest and largest values");
     trim_opt->description =
 	_("Discard <trim> percent of the smallest and <trim> percent of the largest observations");
     trim_opt->guisection = _("Statistic");
@@ -261,6 +265,7 @@
     filter_opt->label = _("Only import points of selected return type");
     filter_opt->description = _("If not specified, all points are imported");
     filter_opt->options = "first,last,mid";
+    filter_opt->guisection = _("Selection");
     class_opt = G_define_option();
     class_opt->key = "class_filter";
@@ -270,6 +275,7 @@
     class_opt->label = _("Only import points of selected class(es)");
     class_opt->description = _("Input is comma separated integers. "
                                "If not specified, all points are imported.");
+    class_opt->guisection = _("Selection");
     print_flag = G_define_flag();
     print_flag->key = 'p';
