[GRASS-SVN] r69985 - in grass/trunk/gui/wxpython: . location_wizard
Sat Dec 3 12:48:29 PST 2016
Author: martinl
Date: 2016-12-03 12:48:29 -0800 (Sat, 03 Dec 2016)
New Revision: 69985
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/location_wizard/base.py
   grass/trunk/gui/wxpython/location_wizard/dialogs.py
   grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI/location wizard simplification: decrease number of dialogs shown by default
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2016-12-03 17:41:29 UTC (rev 69984)
+++ grass/trunk/gui/wxpython/gis_set.py	2016-12-03 20:48:29 UTC (rev 69985)
@@ -546,46 +546,31 @@
                 dlg.CenterOnScreen()
                 if dlg.ShowModal() == wx.ID_YES:
                     self.ImportFile(gWizard.georeffile)
-                else:
-                    self.SetDefaultRegion(location=gWizard.location)
                 dlg.Destroy()
-            else:
+            if gWizard.default_region:
+                defineRegion = RegionDef(self, location=gWizard.location)
+                defineRegion.CenterOnScreen()
+                defineRegion.ShowModal()
+                defineRegion.Destroy()
-            dlg = TextEntryDialog(
-                parent=self,
-                message=_("Do you want to create new mapset?"),
-                caption=_("Create new mapset"),
-                defaultValue=self._getDefaultMapsetName(),
-                validator=GenericValidator(
-                    grass.legal_name,
-                    self._nameValidationFailed),
-                style=wx.OK | wx.CANCEL | wx.HELP)
-            help = dlg.FindWindowById(wx.ID_HELP)
-            help.Bind(wx.EVT_BUTTON, self.OnHelp)
-            if dlg.ShowModal() == wx.ID_OK:
-                mapsetName = dlg.GetValue()
-                self.CreateNewMapset(mapsetName)
+            if gWizard.user_mapset:
+                dlg = TextEntryDialog(
+                    parent=self,
+                    message=_("New mapset:"),
+                    caption=_("Create new mapset"),
+                    defaultValue=self._getDefaultMapsetName(),
+                    validator=GenericValidator(
+                        grass.legal_name,
+                        self._nameValidationFailed
+                    style=wx.OK | wx.CANCEL | wx.HELP
+                help = dlg.FindWindowById(wx.ID_HELP)
+                help.Bind(wx.EVT_BUTTON, self.OnHelp)
+                if dlg.ShowModal() == wx.ID_OK:
+                    mapsetName = dlg.GetValue()
+                    self.CreateNewMapset(mapsetName)
-    def SetDefaultRegion(self, location):
-        """Asks to set default region."""
-        caption = _("Location <%s> created") % location
-        message = _("Do you want to set the default "
-                    "region extents and resolution now?")
-        dlg = wx.MessageDialog(
-            parent=self, message="%(caption)s.\n\n%(extent)s" %
-            ({'caption': caption, 'extent': message}),
-            caption=caption, style=wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
-        dlg.CenterOnScreen()
-        if dlg.ShowModal() == wx.ID_YES:
-            dlg.Destroy()
-            defineRegion = RegionDef(self, location=location)
-            defineRegion.CenterOnScreen()
-            defineRegion.ShowModal()
-            defineRegion.Destroy()
-        else:
-            dlg.Destroy()
     def ImportFile(self, filePath):
         """Tries to import file as vector or raster.
Modified: grass/trunk/gui/wxpython/location_wizard/base.py
--- grass/trunk/gui/wxpython/location_wizard/base.py	2016-12-03 17:41:29 UTC (rev 69984)
+++ grass/trunk/gui/wxpython/location_wizard/base.py	2016-12-03 20:48:29 UTC (rev 69985)
@@ -36,9 +36,8 @@
             label.SetToolTipString(tooltip)
         return label
-    def MakeTextCtrl(
-            self, text='', size=(100, -1),
-            style=0, parent=None, tooltip=None):
+    def MakeTextCtrl(self, text='', size=(100, -1),
+                     style=0, parent=None, tooltip=None):
         """Generic text control"""
         if not parent:
             parent = self
@@ -48,9 +47,8 @@
             textCtrl.SetToolTipString(tooltip)
         return textCtrl
-    def MakeButton(
-            self, text, id=wx.ID_ANY, size=(-1, -1),
-            parent=None, tooltip=None):
+    def MakeButton(self, text, id=wx.ID_ANY, size=(-1, -1),
+                   parent=None, tooltip=None):
         """Generic button"""
         if not parent:
             parent = self
@@ -59,3 +57,14 @@
         if tooltip:
             button.SetToolTipString(tooltip)
         return button
+    def MakeCheckBox(self, text, id=wx.ID_ANY, size=(-1, -1),
+        """Generic checkbox"""
+        if not parent:
+            parent = self
+        chbox = wx.CheckBox(parent=parent, id=id, label=text,
+                             size=size)
+        if tooltip:
+            chbox.SetToolTipString(tooltip)
+        return chbox
Modified: grass/trunk/gui/wxpython/location_wizard/dialogs.py
--- grass/trunk/gui/wxpython/location_wizard/dialogs.py	2016-12-03 17:41:29 UTC (rev 69984)
+++ grass/trunk/gui/wxpython/location_wizard/dialogs.py	2016-12-03 20:48:29 UTC (rev 69985)
@@ -506,11 +506,20 @@
     def __UpdateInfo(self):
         """Update number of rows/cols/cells"""
-        self.rows = int((self.north - self.south) / self.nsres)
-        self.cols = int((self.east - self.west) / self.ewres)
+        try:
+            rows = int((self.north - self.south) / self.nsres)
+            cols = int((self.east - self.west) / self.ewres)
+        except ZeroDivisionError:
+            return
+        self.rows = rows
+        self.cols = cols
         self.cells = self.rows * self.cols
-        self.depth = int((self.top - self.bottom) / self.tbres)
+        try:
+            depth = int((self.top - self.bottom) / self.tbres)
+            return
+        self.depth = depth
         self.cells3 = self.rows * self.cols * self.depth
         # 2D
@@ -524,7 +533,7 @@
     def OnSetButton(self, event=None):
         """Set default region"""
         ret = RunCommand('g.region',
-                         flags='sgpa',
+                         flags='sa',
                          n=self.north,
                          s=self.south,
                          e=self.east,
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-12-03 17:41:29 UTC (rev 69984)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py	2016-12-03 20:48:29 UTC (rev 69985)
@@ -22,7 +22,7 @@
  - wizard::LocationWizard
  - wizard::WizardWithHelpButton
-(C) 2007-2013 by the GRASS Development Team
+(C) 2007-2016 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -122,6 +122,20 @@
                 self._nameValidationFailed))
         self.tlocTitle = self.MakeTextCtrl(size=(400, -1))
+        # checkbox
+        self.tlocRegion = self.MakeCheckBox(_("Set default region extent and resolution"),
+                                            tooltip=_("This option allows setting default "
+                                                      "computation region immediately after "
+                                                      "new location is created. Default "
+                                                      "computation region can be defined later "
+                                                      "using g.region based on imported data."))
+        self.tlocUserMapset = self.MakeCheckBox(_("Create user mapset"),
+                                                tooltip=_("This option allows creating user "
+                                                          "mapset immediately after new location "
+                                                          "is created. Note that GRASS always creates "
+                                                          "PERMANENT mapset."))
         # layout
         self.sizer.Add(item=self.MakeLabel(_("GIS Data Directory:")),
                        flag=wx.ALIGN_RIGHT |
@@ -146,9 +160,8 @@
                 tooltip=_("Name of location directory in GIS Data Directory")),
             flag=wx.ALIGN_RIGHT | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
             border=5,
-            pos=(
-                2,
-                1))
+            pos=(2, 1)
         self.sizer.Add(item=self.tlocation,
                        flag=wx.ALIGN_LEFT |
@@ -164,14 +177,23 @@
                     "you can leave this field blank.")),
             flag=wx.ALIGN_RIGHT | wx.ALIGN_TOP | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
             border=5,
-            pos=(
-                3,
-                1))
+            pos=(3, 1)
         self.sizer.Add(item=self.tlocTitle,
                        wx.ALL, border=5,
                        pos=(3, 2), span=(1, 2))
+        self.sizer.Add(item=self.tlocRegion,
+                       flag=wx.ALIGN_LEFT |
+                       wx.ALIGN_CENTER_VERTICAL |
+                       wx.ALL, border=5,
+                       pos=(4, 2), span=(1, 2))
+        self.sizer.Add(item=self.tlocUserMapset,
+                       wx.ALL, border=5,
+                       pos=(5, 2), span=(1, 2))
         self.sizer.AddGrowableCol(3)
         # bindings
@@ -2233,6 +2255,10 @@
         # file from which new location is created
         self.georeffile = None
+        # additional settings
+        self.default_region = False
+        self.user_mapset = False
         # define wizard pages
@@ -2330,6 +2356,8 @@
                 self.location = self.startpage.location
                 self.grassdatabase = self.startpage.grassdatabase
                 self.georeffile = self.filepage.georeffile
+                self.default_region = self.startpage.tlocRegion.IsChecked()
+                self.user_mapset = self.startpage.tlocUserMapset.IsChecked()
                 # FIXME here was code for setting default region, what for is this if:
                 # if self.altdb == False:
