[GRASS-SVN] r70000 - grass/branches/releasebranch_7_0/lib/python/temporal
Sun Dec 4 14:51:50 PST 2016
Author: martinl
Date: 2016-12-04 14:51:50 -0800 (Sun, 04 Dec 2016)
New Revision: 70000
   grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
libtemporal: simplify percent() calls in dataset_mapcalculator() (merge r69998 from trunk)
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py	2016-12-04 22:49:16 UTC (rev 69999)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py	2016-12-04 22:51:50 UTC (rev 70000)
@@ -196,8 +196,7 @@
         for i in range(num):
             count += 1
-            if count % 10 == 0:
-                msgr.percent(count, num, 1)
+            msgr.percent(count, num, 10)
             # Create the r.mapcalc statement for the current time step
             map_name = "{base}_{suffix}".format(base=base,
@@ -294,8 +293,7 @@
         for new_map in map_list:
             count += 1
             # Read the map data
             new_map.load()
@@ -315,8 +313,6 @@
         # Update the spatio-temporal extent and the metadata table entries
         new_sp.update_from_registered_maps(dbif)
-        msgr.percent(1, 1, 1)
         # Remove empty maps
         if len(empty_maps) > 0:
             names = ""
