[GRASS-SVN] r70005 - grass-addons/grass7/raster/r.denoise
Mon Dec 5 11:53:12 PST 2016
Author: guano
Date: 2016-12-05 11:53:12 -0800 (Mon, 05 Dec 2016)
New Revision: 70005
Added:
   grass-addons/grass7/raster/r.denoise/r.denoise.py
r.denoise - python version
Added: grass-addons/grass7/raster/r.denoise/r.denoise.py
--- grass-addons/grass7/raster/r.denoise/r.denoise.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.denoise/r.denoise.py	2016-12-05 19:53:12 UTC (rev 70005)
@@ -0,0 +1,240 @@
+#!/usr/bin/env python
+# MODULE:       r.denoise.py
+# AUTHOR(S):    John A Stevenson
+#               Converted to Python by Carlos H. Grohmann
+# PURPOSE:      Run Sun's denoising algorithm from within GRASS
+# COPYRIGHT:    (C) 2009 GRASS Development Team/John A Stevenson
+# NOTES:    Requires Sun's denoising algorithm executable (mdenoise).
+#       Instructions for installation of mdenoise are given on the
+#       html manual page (g.manual r.denoise).
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+# MINOR FIXES:     Alexander Muriy (amuriy AT gmail DOT com), 01.2012
+#%Module
+#%  description: r.denoise - denoise topographic data
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Raster input map
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,cell,raster
+#% description: Denoised raster output map
+#% required : yes
+#%end
+#%option
+#% key: iterations
+#% type: integer
+#% description: Number of normal-updating iterations
+#% answer: 5
+#% options: 1-50
+#% required : no
+#%end
+#%option
+#% key: threshold
+#% type: double
+#% description: Edge-sharpness threshold
+#% answer: 0.93
+#% options: 0-1
+#% required : no
+#%end
+#%option
+#% key: epsg
+#% type: integer
+#% description: EPSG projection code (required if current location is not projected)
+#%end
+import sys
+import os
+import atexit
+import subprocess
+from itertools import izip
+import grass.script as grass
+# from grass.exceptions import CalledModuleError
+# pyproj
+try:
+    import pyproj
+except ImportError:
+    grass.fatal(_("pyproj not found, install it first: pip install pyproj (https://jswhit.github.io/pyproj)"))
+# PID for temporary files
+unique = str(os.getpid())
+# # what to do in case of user break:
+def cleanup():
+    # delete any TMP files:
+    grass.message(_("Removing temporary files..."))
+    tmp_rmaps = [fname for fname in os.listdir('.') if fname.endswith('%s.xyz' % unique)]
+    try:
+        for fname in tmp_rmaps:
+            os.remove(fname)
+    except OSError:
+        pass
+    # grass.run_command('g.remove', quiet=True, flags='f', type='raster', name=tmp_rmaps)
+# test if requirements are present
+def check_requirements():
+        # mdenoise
+        if not grass.find_program('mdenoise'):
+            grass.fatal(_("mdenoise required. Follow instructions in html manual page to install it (g.manual r.denoise)."))
+# Test for projected location
+def check_proj(epsg):
+    # check if location is in longlat
+    if grass.parse_command('g.proj', flags='j')['+proj'] == 'longlat':
+        # if not projected, check if EPSG code was supplied for reprojection
+        if epsg:
+            # With EPSG code, check that it corresponds to a projected locality. # WGS84 LatLong: 4326
+            out_proj = pyproj.Proj(init='epsg:'+str(epsg))
+            if out_proj.is_latlong() == False:
+                reproject = True
+            else:
+                grass.fatal(_("EPSG code is not suitable. A projected coordinate system is required."))
+        else:
+            grass.fatal(_("During processing r.denoise needs to convert the input map to a projected coordinate system; please specify a suitable EPSG code."))
+    else:
+        grass.message(_("Projected coordinate system. No reprojection needed."))
+        reproject = False
+    return reproject
+# reproject data
+def do_proj(xyz_in, xyz_out, in_proj, out_proj):
+    # grass.message(_("Projecting..."))
+    # open files
+    f_in = open(xyz_in, 'r')
+    f_out = open(xyz_out, 'w')
+    #read input coordinates file
+    for line in f_in.readlines():
+        xyz = line.split()
+        # do the projection
+        x, y = pyproj.transform(in_proj, out_proj, xyz[0], xyz[1])
+        # write output to file
+        f_out.write('%.6f %.6f %s\n' % (x,y, xyz[2]))
+    # close files
+    f_in.close()
+    f_out.close()
+def main():
+    global unique
+    # user keys
+    in_raster = options['input'] # in_raster = 'srtm_1sec_amazonia'
+    out_raster = options['output'] # out_raster = 'teste_dnoise'
+    iterations = options['iterations']
+    threshold = options['threshold']
+    epsg = options['epsg']
+    # check if input file exists
+    if not grass.find_file(in_raster)['file']:
+        grass.fatal(_("Raster map <%s> not found") % in_raster)
+    # check if current location is in a projected coordinate system
+    reproject = check_proj(epsg)
+    # define projections
+    loc_proj = grass.read_command('g.proj', flags='jf')
+    loc_proj = pyproj.Proj(loc_proj.strip())
+    epsg_proj = pyproj.Proj(init='epsg:'+ str(epsg))
+    # name the files
+    tmp_xyz = 'tmp_xyz_%s.xyz' % unique
+    tmp_xyz_orig = 'tmp_xyz_%s.xyz' % unique
+    tmp_xyz_proj = 'tmp_xyz_proj_%s.xyz' % unique
+    tmp_out_dnoise = 'tmp_xyz_dnoise_%s.xyz' % unique
+    # tmp_out_dnoise_proj = 'tmp_xyz_dnoise_proj_%s.xyz' % unique
+    tmp_xyz_merge = 'tmp_xyz_merge_%s.xyz' % unique
+    # list for cleanup
+    tmp_rmaps = [tmp_xyz, tmp_xyz_orig, tmp_xyz_proj, tmp_out_dnoise, tmp_xyz_merge]
+    # Export the map to xyz points.
+    grass.message(_("Exporting points..."))
+    grass.run_command('r.stats', flags='1g', input=in_raster, output=tmp_xyz, overwrite=True)
+    # Reproject if necessary
+    if reproject:
+        do_proj(xyz_in=tmp_xyz, xyz_out=tmp_xyz_proj, in_proj=loc_proj, out_proj=epsg_proj)
+        tmp_xyz = tmp_xyz_proj
+    # Denoise.  The -z flag preserves the xy positions of the points.
+    grass.message(_("Denoising..."))
+    cmd = ['mdenoise'] + ['-i'] + [tmp_xyz] + ['-t'] + [str(threshold)] + ['-n'] + [str(iterations)] + ['-z'] + ['-o'] + [tmp_out_dnoise]
+    grass.call(cmd)
+    # If reprojected, it is necessary to return to original coordinate system.
+    #### actually, there's no need for this, since we will use only the Z coordinates from the denoised data ####
+    # if reproject:
+    #     do_proj(xyz_in=tmp_out_dnoise, xyz_out=tmp_out_dnoise_proj, in_proj=epsg_proj, out_proj=loc_proj)
+    #     tmp_out_dnoise = tmp_out_dnoise_proj
+    # As only the z coordinates have changed in denoising, to prevent rounding
+    # errors, the new z coordinates are combined with the original xy coordinates.
+    f_merged = open(tmp_xyz_merge, 'w') # new, merged
+    with open(tmp_out_dnoise) as f_dnoise, open(tmp_xyz_orig) as f_orig:
+        for line_dnoise, line_orig in izip(f_dnoise, f_orig):
+            xyz_dnoise = line_dnoise.split()  # denoised
+            xyz_orig = line_orig.split()  # original
+            f_merged.write('%s %s %s\n' % (xyz_orig[0], xyz_orig[1], xyz_dnoise[2]))
+    # close files
+    f_merged.close()
+    # Reload data
+    grass.message(_("Reloading data..."))
+    grass.run_command('r.in.xyz', flags='i', input=tmp_xyz_merge, output=out_raster, method='min', x=1, y=2, z=3, separator='space', overwrite=True)
+    # Edit metadata to record denoising parameters
+    grass.run_command('r.support', map=out_raster, title="A denoised version of <%s>" % in_raster)
+    grass.run_command('r.support', map=out_raster, history="Generated by: r.denoise %s iterations=%s threshold=%s" % (in_raster, str(threshold), str(iterations)))
+    # clean tmp files
+    try:
+            os.remove(fname)
+    except OSError:
+        pass
+#run the module
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    atexit.register(cleanup)
+    check_requirements()
+    main()
