[GRASS-SVN] r70133 - in grass-addons/grass7/raster3d: . r3.to.group
Mon Dec 26 14:38:58 PST 2016
Author: wenzeslaus
Date: 2016-12-26 14:38:58 -0800 (Mon, 26 Dec 2016)
New Revision: 70133
Added:
   grass-addons/grass7/raster3d/r3.to.group/
   grass-addons/grass7/raster3d/r3.to.group/Makefile
   grass-addons/grass7/raster3d/r3.to.group/r3.to.group.html
   grass-addons/grass7/raster3d/r3.to.group/r3.to.group.py
   grass-addons/grass7/raster3d/Makefile
r3.to.group: script convert 3D raster to list of 2D rasters registered in an imagery group
Modified: grass-addons/grass7/raster3d/Makefile
--- grass-addons/grass7/raster3d/Makefile	2016-12-26 22:22:38 UTC (rev 70132)
+++ grass-addons/grass7/raster3d/Makefile	2016-12-26 22:38:58 UTC (rev 70133)
@@ -5,6 +5,7 @@
 	r3.forestfrag \
 	r3.profile \
 	r3.scatterplot \
+	r3.to.group \
 	r3.what
 include $(MODULE_TOPDIR)/include/Make/Dir.make
Added: grass-addons/grass7/raster3d/r3.to.group/Makefile
--- grass-addons/grass7/raster3d/r3.to.group/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.to.group/Makefile	2016-12-26 22:38:58 UTC (rev 70133)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r3.to.group
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/raster3d/r3.to.group/r3.to.group.html
--- grass-addons/grass7/raster3d/r3.to.group/r3.to.group.html	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.to.group/r3.to.group.html	2016-12-26 22:38:58 UTC (rev 70133)
@@ -0,0 +1,32 @@
+<h2>DESCRIPTION</h2>
+<em>r3.to.rast</em>
+<h2>NOTES</h2>
+If group already exists and the user does not want to add to it,
+the group needs to be removed first.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+g.region
+r3.to.rast
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.to.rast.html">r3.to.rast</a>
+</em>
+<h2>AUTHORS</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a><br>
+<p>
+<i>Last changed: $Date: 2015-09-02 07:01:34 -0400 (Wed, 02 Sep 2015) $</i>
Added: grass-addons/grass7/raster3d/r3.to.group/r3.to.group.py
--- grass-addons/grass7/raster3d/r3.to.group/r3.to.group.py	                        (rev 0)
+++ grass-addons/grass7/raster3d/r3.to.group/r3.to.group.py	2016-12-26 22:38:58 UTC (rev 70133)
@@ -0,0 +1,133 @@
+#!/usr/bin/env python
+# MODULE:        r3.to.group
+# AUTHOR(S):     Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE:       Create an imagery group from 3D raster
+# COPYRIGHT:     (C) 2016 by Vaclav Petras, and the GRASS Development Team
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
+#%module
+#% description: Convert a 3D raster map to imagery group
+#% keyword: raster3d
+#% keyword: conversion
+#% keyword: raster
+#% keyword: imagery
+#% keyword: voxel
+#% keyword: map management
+#%end
+#%option G_OPT_R3_INPUT
+#%end
+#%option G_OPT_I_GROUP
+#%end
+#%option G_OPT_I_SUBGROUP
+#% required: no
+#%end
+#%option G_OPT_R_BASENAME_OUTPUT
+#% key: basename
+#% required: no
+#%end
+#%option G_OPT_R_TYPE
+#% required: no
+#%end
+#%option
+#% key: multiply
+#% type: double
+#% required: no
+#% label: Value to multiply the raster values with
+#% description: Coefficient a in the equation y = ax + b
+#%end
+#%option
+#% key: add
+#% type: double
+#% required: no
+#% label: Value to add to the raster values
+#% description: Coefficient b in the equation y = ax + b
+#%end
+#%flag
+#% key: a
+#% description: Add to group or subgroup if it already exists
+#%end
+import grass.script as gs
+from grass.exceptions import CalledModuleError
+def remove(maps):
+    """Remove raster maps"""
+    if maps:
+        gs.run_command('g.remove', flags='f', quiet=True,
+                       type='rast', name=maps)
+def list_in_current_mapset(pattern):
+    maps = gs.list_pairs(type='rast', mapset=".", pattern=pattern, flag='e')
+    maps = [name for name, mapset in maps]
+    return maps
+def main():
+    options, flags = gs.parser()
+    input_ = options['input']
+    group = options['group']
+    subgroup = options['subgroup']
+    basename = options['basename']
+    add_to_group = flags['a']
+    # options to be passed to r3.to.rast
+    additional_options = {}
+    for option in ['type', 'multiply', 'add']:
+        if options[option]:
+            additional_options[option] = options[option]
+    if not subgroup:
+        subgroup = group
+    if not basename:
+        basename = group
+    basename_sep = "_"
+    pattern = "%s%s[0-9]+" % (basename, basename_sep)
+    overwrite = gs.overwrite()
+    group_exists = gs.find_file(group, element='group')['file']
+    subgroup_exists = gs.find_file(group, element='subgroup')['file']
+    if group_exists and subgroup_exists:
+        if not add_to_group:  # and not overwrite:
+            gs.fatal(_("Group <%s> and subgroup <%s> exist, use"
+                       " different name or -a flag") % (group, subgroup))
+        # if overwrite:  # not implemented
+            # TODO: remove group?
+    # when just group exists, i.group should create new subgroup
+    rasters = list_in_current_mapset(pattern)
+    if not overwrite and rasters:
+        if len(rasters) > 3:
+            formatted = "%s,..." % ", ".join(rasters[:3])
+        else:
+            formatted = ", ".join(rasters)
+        gs.fatal(_("There are rasters with basename <%s> (%s), use"
+                   " different name or overwrite") % (basename, formatted))
+    rasters = []
+    try:
+        gs.run_command('r3.to.rast', input=input_, output=basename,
+                       **additional_options)
+        # it's clear we created just the ones in the current mapset
+        # and we need to make the command line as short as possible
+        gs.run_command('i.group', input=rasters,
+                       group=group, subgroup=subgroup)
+    except CalledModuleError as error:
+        remove(rasters)
+        gs.fatal(_("Module %s failed. Check the above error messages.") %
+                 error.cmd)
+if __name__ == "__main__":
+    main()
Property changes on: grass-addons/grass7/raster3d/r3.to.group/r3.to.group.py
___________________________________________________________________
Added: svn:executable
