[GRASS-SVN] r70180 - grass/branches/releasebranch_7_2/lib/proj
Sat Dec 31 14:26:38 PST 2016
Author: martinl
Date: 2016-12-31 14:26:38 -0800 (Sat, 31 Dec 2016)
New Revision: 70180
Removed:
   grass/branches/releasebranch_7_2/lib/proj/FL.lla
   grass/branches/releasebranch_7_2/lib/proj/MD.lla
   grass/branches/releasebranch_7_2/lib/proj/TN.lla
   grass/branches/releasebranch_7_2/lib/proj/WI.lla
   grass/branches/releasebranch_7_2/lib/proj/WO.lla
   grass/branches/releasebranch_7_2/lib/proj/alaska.lla
   grass/branches/releasebranch_7_2/lib/proj/conus.lla
   grass/branches/releasebranch_7_2/lib/proj/hawaii.lla
   grass/branches/releasebranch_7_2/lib/proj/ntv1_can.dat
   grass/branches/releasebranch_7_2/lib/proj/nzgd2kgrid0005.gsb
   grass/branches/releasebranch_7_2/lib/proj/prvi.lla
   grass/branches/releasebranch_7_2/lib/proj/stgeorge.lla
   grass/branches/releasebranch_7_2/lib/proj/stlrnc.lla
   grass/branches/releasebranch_7_2/lib/proj/stpaul.lla
   grass/branches/releasebranch_7_2/lib/proj/Makefile
   grass/branches/releasebranch_7_2/lib/proj/README.txt
   grass/branches/releasebranch_7_2/lib/proj/datum.c
libproj: cleanup of local copies of NAD and datum shift files which are used from GDAL; extended documentation in README.txt (trac #2456)
         (merge r69211, r69494 from trunk)
Deleted: grass/branches/releasebranch_7_2/lib/proj/FL.lla
--- grass/branches/releasebranch_7_2/lib/proj/FL.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/FL.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,162 +0,0 @@
-Florida - HP
-  33  33   1   -88.00000      .25000    24.00000      .25000
-0: 7672 -6501 103 -773 125 -788 160 -817 200 -858 246 -914 294 -982 339 -1060
-378 -1141 404 -1217 416 -1277 406 -1312 377 -1308 321 -1253 243 -1136 136 -946
-6 -668 -154 -294 -347 194 -577 813 -837 1548 -1039 2280 -920 2603 -731 2767
--244 2680 366 2537 835 2117 545 1930 194 2344 152 2581 592 2449 1020 2189
-1247 1948
-1: 6754 -7120 8 -708 34 -720 68 -742 113 -778 164 -827 220 -889 276 -960
-327 -1036 372 -1109 404 -1169 422 -1206 423 -1211 404 -1170 367 -1076 311 -915
-234 -680 133 -352 -5 91 -206 694 -519 1526 -940 2565 -720 2708 -761 2904
--190 2656 556 2684 1384 1878 336 1391 -509 2300 -707 2530 249 2025 931 1499
-1153 1093
-2: 5839 -7757 -85 -643 -60 -651 -23 -668 24 -696 79 -738 141 -792 206 -856
-269 -925 328 -992 380 -1048 420 -1085 448 -1093 461 -1060 462 -982 449 -845
-426 -645 391 -367 339 8 246 530 22 1341 -727 2950 -300 2631 -817 2997 -63 2328
-605 3088 2423 1864 -180 932 -1705 2673 -2090 2563 126 1350 1056 604 1092 80
-3: 4931 -8407 -176 -580 -152 -582 -115 -593 -67 -613 -9 -648 57 -692 128 -747
-200 -807 272 -865 339 -914 396 -946 446 -950 484 -919 511 -844 531 -719
-544 -534 557 -282 575 57 603 521 666 1219 935 2462 -596 2881 -290 2556 533 1660
-517 2766 2960 2565 -780 2955 -4000 3000 -3837 1859 682 18 1424 -535 929 -1087
-4: 4040 -9062 -266 -517 -242 -515 -207 -517 -159 -531 -101 -555 -33 -590
-42 -634 122 -683 201 -730 279 -768 350 -790 413 -785 466 -747 508 -664 540 -533
-563 -344 583 -85 600 264 616 739 614 1405 484 2283 -488 2772 -579 2757 -245 2656
--1 3507 917 4006 -862 4197 -2155 2464 -1050 -2791 1050 -1209 1564 -1695
-378 -2234
-5: 3177 -9703 -353 -457 -331 -449 -299 -444 -253 -449 -196 -464 -128 -487
--51 -519 32 -556 117 -590 201 -614 281 -623 350 -604 410 -550 453 -452 480 -305
-487 -97 471 180 425 544 331 1017 146 1614 -231 2286 -935 2790 -1308 3079
--1338 3409 -1044 4066 -165 4364 -98 3520 1098 -1747 317 -3205 1665 -2467
-2276 -2277 -302 -2541
-6: 2355 -10301 -436 -403 -419 -387 -389 -376 -348 -372 -294 -374 -228 -388
--152 -406 -67 -430 20 -449 108 -460 191 -452 264 -416 322 -343 359 -227
-369 -58 345 170 276 464 147 829 -69 1271 -405 1783 -900 2313 -1540 2764
--2049 3120 -2302 3479 -1974 3796 -82 3346 1747 1598 3151 -3091 281 -2706
-2719 -2294 352 -2797 200 -3163
-7: 1590 -10819 -516 -357 -503 -335 -479 -316 -444 -301 -394 -293 -333 -294
--259 -301 -176 -310 -87 -315 3 -311 87 -287 161 -234 215 -144 244 -7 237 183
-182 427 65 727 -132 1080 -432 1471 -848 1880 -1370 2263 -1925 2567 -2361 2769
--2645 2902 -2624 2933 286 1797 3755 -705 3171 -2773 1532 -1897 1118 -915
-636 -2145 -185 -3134
-8: 898 -11213 -591 -325 -585 -296 -567 -267 -540 -243 -498 -224 -442 -213
--372 -206 -291 -202 -202 -194 -111 -176 -24 -139 50 -71 103 35 127 188 109 393
-37 650 -105 952 -335 1281 -668 1611 -1101 1905 -1581 2125 -1957 2219 -1968 2123
--1462 1769 -924 1518 -924 1495 3095 -2090 3298 -1453 2284 -1197 -736 -682
-983 -1073 1002 -3205
-9: 299 -11436 -663 -310 -663 -275 -655 -237 -637 -202 -604 -171 -556 -148
--490 -128 -412 -111 -322 -92 -229 -63 -138 -16 -59 61 -3 177 23 342 6 557
--64 823 -202 1125 -423 1433 -739 1703 -1151 1887 -1604 1941 -1908 1856
--1633 1562 -301 701 169 192 -158 600 1102 -1285 3892 -1075 734 -429 262 -858
-248 -1211 1092 -2529
-10: -192 -11437 -729 -320 -738 -277 -741 -230 -735 -183 -714 -141 -673 -104
--615 -71 -538 -42 -446 -14 -347 23 -249 75 -162 154 -95 273 -60 438 -62 660
--112 932 -217 1238 -388 1541 -637 1773 -980 1854 -1425 1726 -1884 1463
--1835 1296 626 440 839 696 -805 -950 675 -1036 4029 -688 210 -2089 1085 -24
--138 -838 328 -1417
-11: -559 -11168 -788 -361 -808 -309 -826 -252 -835 -194 -827 -137 -798 -85
--745 -38 -668 2 -572 39 -464 79 -354 130 -252 203 -171 313 -117 470 -98 687
--115 961 -170 1281 -261 1604 -388 1849 -570 1874 -871 1503 -1453 663 -2290 -114
-104 1078 789 -131 164 -22 1680 -765 4263 -160 -787 -1958 2609 -1886 -2732 873
--29 -276
-12: -789 -10590 -839 -437 -873 -378 -909 -310 -935 -237 -945 -164 -929 -95
--883 -32 -806 21 -700 67 -578 106 -449 150 -328 208 -226 296 -151 432 -108 627
--92 893 -99 1224 -112 1599 -113 1941 -75 2099 -9 1802 -158 798 -2134 5 -660 884
--909 -1955 809 46 864 -927 1716 -1008 2936 -1094 -50 25 -1001 -540 148 -655
-13: -874 -9674 -878 -556 -930 -488 -988 -408 -1038 -320 -1069 -227 -1070 -135
--1031 -52 -951 18 -832 73 -688 111 -533 142 -384 175 -257 229 -161 323 -97 479
--59 710 -37 1029 -17 1436 20 1898 103 2309 265 2370 583 1459 1923 -901 -2624 -38
--3346 -1930 102 16 663 379 973 -2392 1234 -868 -1191 942 187 -3809 909 1161
-14: -810 -8403 -902 -723 -976 -647 -1061 -554 -1142 -445 -1201 -328 -1222 -209
--1193 -96 -1107 -3 -970 64 -794 104 -601 118 -416 118 -261 126 -143 164
--64 256 -12 422 22 678 42 1036 42 1490 -8 1932 -193 1847 -1030 -947 127 3077
--1734 645 -141 -1585 -1138 971 1611 5264 -608 -9267 85 -497 -917 -1288
-796 1568 1477 278
-15: -600 -6782 -906 -943 -1005 -858 -1124 -751 -1245 -620 -1342 -471 -1391 -314
--1374 -164 -1280 -36 -1115 54 -895 97 -651 95 -418 57 -228 10 -90 -17 -1 1
-61 87 112 247 159 495 175 847 120 1293 38 1673 941 1936 -9941 -936 858 1039
--1295 -2639 3057 -804 2291 1821 1058 -1212 123 688 680 390 -440 1982 611 313
-16: -255 -4835 -881 -1218 -1011 -1128 -1173 -1005 -1344 -848 -1492 -659
--1579 -453 -1580 -249 -1478 -73 -1274 52 -993 110 -676 93 -379 15 -146 -93
-4 -185 92 -229 159 -205 246 -111 382 67 568 396 796 1097 1014 2461 0 2000
--8346 -5148 -6654 4148 2600 -4833 3503 1265 3163 2598 1837 870 -186 126
-143 1015 -128 1314 205 670
-17: 206 -2608 -821 -1550 -983 -1458 -1197 -1322 -1435 -1135 -1652 -897
--1793 -624 -1819 -349 -1707 -105 -1455 72 -1091 157 -670 133 -282 12 -3 -161
-147 -315 206 -394 252 -378 366 -266 611 -48 1003 357 1540 1418 2577 5461
--501 -2255 5516 5948 -18845 -6837 0 -5107 2402 2555 4553 2700 1242 348
--368 554 15 637 -179 1340 -96 1049
-18: 751 -169 -717 -1938 -909 -1851 -1183 -1706 -1510 -1488 -1820 -1188
--2035 -829 -2098 -459 -1978 -127 -1670 124 -1195 255 -625 237 -104 65 226 -193
-346 -405 326 -493 294 -428 384 -196 713 217 1330 869 2070 1935 2277 3529
-24 1272 7103 3967 -2782 -5390 -9810 -3597 -2867 1487 1170 -514 1204 -5
-64 107 122 1081 -289 1400 -334 1205
-19: 1334 2389 -561 -2377 -773 -2304 -1112 -2162 -1555 -1917 -1996 -1538
--2311 -1065 -2419 -573 -2295 -132 -1932 210 -1324 413 -533 419 190 188
-576 -195 619 -483 443 -566 243 -436 202 -76 504 525 1285 1262 2419 1785
-2861 1614 258 744 4600 5835 -1610 -5973 -5784 -751 -2652 -890 -2683 -1865
-1273 57 733 862 74 1430 -445 1184 -488 1116
-20: 1890 4955 -353 -2859 -553 -2813 -955 -2692 -1556 -2435 -2181 -1954
--2620 -1320 -2775 -676 -2644 -120 -2251 317 -1516 619 -396 687 657 403
-1088 -190 986 -572 565 -644 110 -486 -190 -62 -107 705 599 1700 2151 2152
-3558 1268 -1507 -983 42 152 1603 -2650 270 -1361 85 859 -7000 0 1798 903
--428 542 -32 1121 -308 1103 -438 1050
-21: 2332 7397 -106 -3372 -236 -3370 -662 -3295 -1489 -3073 -2389 -2435
--2965 -1560 -3134 -725 -2964 -85 -2606 403 -1849 812 -234 1005 1373 728
-1775 -181 1446 -645 703 -683 -10 -593 -617 -297 -874 462 -590 1868 727 2585
-3088 850 -2719 -882 2463 -2273 1661 -1542 403 -247 -803 -600 -2808 2265
-78 552 -268 754 -152 985 -266 998 -380 958
-22: 2553 9565 128 -3909 183 -3962 -150 -3947 -1331 -3900 -2665 -2973 -3354 -1695
--3442 -625 -3088 7 -2864 391 -2448 853 -86 1168 2369 1054 2538 8 1923 -527
-819 -504 24 -633 -783 -758 -1053 -507 -337 1109 1651 2823 536 -2240 1044 1122
-946 -1948 -80 -814 -1704 2439 -1329 403 -1042 1100 -6 504 -44 770 -102 851
--225 850 -342 820
-23: 2453 11303 233 -4478 625 -4610 730 -4564 -1058 -5090 -3119 -3498 -3769 -1546
--3669 -178 -2723 264 -2620 231 -3334 613 251 553 3000 0 3158 1966 2158 218
-815 55 337 -390 -796 -933 -1254 -1571 -797 456 2435 -455 2771 1386 -827 3268
-0 -3000 -510 -862 -2895 2167 -1703 1713 -892 982 151 593 90 586 -70 637
--225 654 -348 648
-24: 2018 12480 20 -5106 779 -5482 2150 -4984 -657 -6960 -3918 -3730 -3983 -827
--3972 874 -1687 926 -1286 60 -3464 749 -716 2140 8510 -484 -1773 1318 954 978
-1151 -16 1237 -44 -557 -171 -893 -1011 630 -1280 -303 -5857 2962 3371 -2993 5847
-528 -1758 -1163 250 -3620 1297 -22 1275 144 1277 -37 420 -85 425 -185 475
--306 485 -413 474
-25: 1482 13045 -595 -5698 -76 -7030 3555 -5891 -75 -9103 -4913 -2783 -2879 620
--4780 2466 -842 2224 -1877 150 899 5691 -4885 5468 9110 -4286 -849 -657
-27 -1439 790 -1014 1344 195 -172 -280 -633 -726 369 -1130 22 -1009 -22 2187
--1000 0 -51 -252 -87 1011 -3027 403 -787 279 904 2090 38 1229 -150 767 -289 523
--419 392 -521 320
-26: 1355 12925 -894 -5548 -930 -7327 -2531 -19050 1950 -360 -2950 -640
-2000 2000 -4428 2801 -435 3572 -167 2638 386 3423 -965 1454 2797 9 519 847
--1666 -1917 1959 -4827 1000 3000 -886 -211 -1177 -2017 439 -905 749 -2342
--191 5903 406 2279 -2340 -8707 674 987 -4677 5266 -25 -1215 1305 2437 588 1784
--4 996 -354 519 -556 270 -669 146
-27: 1459 11181 -1466 -7182 -2572 -10336 -3104 -11802 1118 -1032 3176 911
--611 4260 -2000 0 -619 3300 -2381 700 -1000 4000 0 -4000 2404 3094 5349 7048
-1689 4151 -991 -3201 131 63 -2168 386 1542 242 -560 -3732 80 -2204 493 3164
-1412 2599 318 -2751 -1207 -4294 -5222 -3431 -2270 3866 520 1894 163 1104
--327 566 -631 218 -792 16 -873 -88
-28: 2203 10314 -830 -6011 -1373 -7303 -4130 -9160 -817 1919 3956 749 -1009 1492
-221 -1684 2270 2426 -2873 3931 -2405 -482 2282 309 2655 2770 3130 5110
-1455 3807 -535 -219 -587 -72 -1198 71 457 -475 -266 -2633 -86 -1848 222 551
-326 205 -885 -2650 -2183 -2117 -1600 -1445 569 2262 -1413 425 -1219 69
--1107 -98 -1098 -227 -1110 -316 -1112 -365
-29: 2716 10001 -644 -4332 -1204 -4602 -2281 -3934 -319 1881 2290 2592
--73 -1368 577 -1976 1226 678 -1193 2021 -1019 265 1543 1065 2171 2483 2097 3629
-1087 2963 -136 972 -554 260 -736 -122 -151 -785 -284 -1841 -246 -1646 -177 -779
--348 -949 -1043 -1950 -1496 -1537 -785 -809 26 629 -1182 -51 -1483 -404
--1478 -541 -1425 -604 -1375 -633 -1328 -640
-30: 3029 9940 -431 -2553 -758 -2281 -989 -1183 36 1426 1195 1655 548 -691
-693 -1266 753 -73 -164 811 -55 576 1094 1158 1573 2020 1451 2592 814 2237
-47 1191 -382 422 -535 -164 -382 -796 -399 -1427 -411 -1516 -453 -1290 -631 -1364
--965 -1632 -1085 -1356 -727 -853 -505 -282 -1099 -484 -1463 -716 -1581 -842
--1583 -891 -1541 -903 -1490 -894
-31: 3263 9862 -143 -949 -274 -581 -241 203 289 1267 831 1191 750 -14 764 -535
-696 -141 363 355 425 565 901 1014 1144 1543 1026 1844 608 1640 101 1035
--260 405 -438 -173 -461 -729 -496 -1199 -542 -1406 -614 -1430 -746 -1484
--908 -1531 -950 -1354 -827 -1061 -822 -811 -1145 -862 -1437 -992 -1593 -1084
--1643 -1128 -1633 -1136 -1596 -1125
-32: 3476 9640 176 430 146 687 231 1079 513 1415 789 1190 837 486 835 38
-769 55 633 269 646 489 808 801 876 1120 747 1278 449 1148 92 765 -203 287
--393 -203 -490 -673 -563 -1065 -630 -1312 -711 -1435 -809 -1506 -904 -1520
--946 -1426 -943 -1278 -1014 -1165 -1223 -1178 -1442 -1248 -1592 -1310
--1667 -1343 -1682 -1351 -1667 -1343
Deleted: grass/branches/releasebranch_7_2/lib/proj/MD.lla
--- grass/branches/releasebranch_7_2/lib/proj/MD.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/MD.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,70 +0,0 @@
-Maryland - HP
-  25  17   1   -80.00000      .25000    37.00000      .25000
-0: 5107 -2502 -700 496 -656 468 -587 418 -481 347 -325 256 -111 152 166 50
-493 -37 854 -96 1221 -118 1568 -125 1953 -143 2433 -195 2464 -281 2529 -395
-1987 -729 447 -916 -3011 -1181 -5559 -406 -6094 541 -5714 1110 -5247 1289
--4993 1254 -4960 1151
-1: 4757 -1695 -644 429 -627 411 -602 368 -555 299 -470 206 -328 96 -125 -15
-126 -105 391 -146 634 -120 762 -58 911 -13 1583 -8 1049 -28 1451 123 1377 -464
-907 -603 -4056 -1955 -6769 -485 -5797 929 -4254 1413 -3251 1295 -2871 993
--2899 724
-2: 4413 -932 -563 355 -566 354 -582 322 -597 258 -579 164 -499 45 -341 -84
--127 -192 93 -234 288 -157 190 -25 -145 65 1065 74 -1087 -40 -877 1058 -994 18
-1208 694 -5540 -3840 -7658 -332 -4130 1732 -1668 1786 -634 1127 -525 501
--856 110
-3: 4055 -240 -456 271 -467 294 -520 279 -598 226 -652 137 -622 9 -469 -140
--216 -285 27 -362 263 -223 177 -13 -96 71 110 26 -1646 -1167 -6731 2306
--6507 1730 -6212 3695 -4277 -7455 -3522 570 519 3029 2116 1873 2259 459
-1672 -383 871 -737
-4: 3649 351 -332 164 -326 230 -409 235 -557 201 -693 131 -718 0 -535 -165
--101 -346 460 -493 33 -283 -1321 62 -1559 1 -5178 295 -5413 -3383 -1930 1443
--2892 564 -10423 1293 -5171 1702 -2535 2461 2932 4061 4566 750 4123 -1116
-2992 -1715 1857 -1727
-5: 3144 806 -212 20 -145 160 -245 172 -468 175 -706 151 -825 16 -677 -154
--182 -358 990 -703 -674 -285 -5937 730 -3063 -730 -2085 -867 -3581 281
--2334 586 -1865 759 -5614 1473 -3452 5821 -3401 5679 1428 2413 4628 -2496
-4177 -3412 2947 -3078 1846 -2521
-6: 2486 1092 -149 -192 58 93 -44 50 -322 127 -644 224 -873 34 -771 -149
--678 -275 1770 -1075 -356 -827 -5051 5 -7881 816 -1030 443 -515 634 -2144 1008
--1825 1030 -2498 1380 -732 4469 -286 5830 843 2970 3527 -3923 2622 -4302
-1634 -3420 962 -2613
-7: 1654 1205 -254 -546 221 60 99 -240 -127 38 -418 455 -728 36 -31 -311
--225 -355 -33 -358 -3518 -30 -4640 -954 -5000 1000 -1818 2806 1675 -346
--1857 1540 -225 -656 -1646 2284 2156 3127 2865 2526 3328 2398 1668 -4480
-57 -3443 -249 -2495 -233 -1941
-8: 774 1247 -684 -1157 78 -16 -159 -920 104 -45 117 1090 -906 205 695 -339
--472 -133 -1852 1212 -5751 619 -1944 -763 0 0 -1000 1000 0 2000 -781 1116
-399 1285 -1441 1545 4580 1012 1900 -687 3393 1019 2580 -6254 -1198 -1689
--1158 -1160 -867 -1068
-9: 286 1527 -1064 -1509 -1784 -1841 -1774 -1770 671 449 1944 1770 -864 986
--654 174 -459 -486 -3471 4225 -753 -3046 -1998 -493 920 1014 -194 1777
-219 1456 -220 1705 -4805 4062 4000 -1000 1438 -738 1687 -1949 4875 -1313
-137 -2862 1175 -2395 -88 -1276 -580 -789
-10: 155 1275 -1109 -3207 -3642 -4791 -2359 752 -671 811 -127 1647 2394 2226
-143 593 -1814 676 -2822 760 3 -1215 2849 -1527 273 2735 -238 2454 -152 3485
-1117 -674 1000 0 -2868 944 -947 22 3163 1227 3618 -1203 2940 -5487 -80 -2667
--428 -1173 -531 -579
-11: 210 2136 -191 -2212 -19 -4924 -671 974 -2112 719 -1798 471 60 914 304 1048
--2565 1609 -3875 184 1862 -2588 7166 1567 -242 2228 -1731 3121 2189 749
--4055 528 -454 -2297 -78 773 -1000 -1000 2289 1712 5097 -691 -167 -5244
-240 -1551 -59 -589 -233 -314
-12: 136 2158 79 -2113 870 -2292 -87 492 -1395 1041 -324 108 1093 15 -372 591
--3302 -1631 1228 1503 2274 -18 348 98 -548 48 3116 847 -2761 -369 -1636 4272
--1692 3024 -2566 -1109 3539 -5665 -2548 3660 4460 -4303 33 -1230 -83 -215
-64 -282 7 -263
-13: 437 2268 560 -1486 885 -1135 371 147 -233 547 243 42 679 -222 -336 -237
--1466 -996 550 564 492 316 -1347 86 -1522 -8 -3178 -134 3508 29 224 1615
--978 2218 111 -3614 1000 -1000 814 1143 -1762 1626 28 -784 -14 -140 274 -574
-170 -385
-14: 853 2381 888 -971 974 -638 715 -41 417 171 481 -79 441 -329 -174 -472
--704 -640 -236 -12 -607 49 -1686 -95 -2002 -238 -1988 -349 1822 -129 995 494
-219 507 526 -1730 552 -212 170 1146 -1495 1850 -678 543 -301 275 -1 -88
-30 -81
-15: 1272 2398 1135 -612 1122 -398 955 -126 740 -45 598 -193 366 -390 -90 -527
--502 -568 -637 -337 -1047 -270 -1628 -342 -1734 -438 -1191 -480 655 -329
-834 -53 575 -59 523 -598 291 234 -200 1168 -1032 1651 -848 1158 -561 799
--319 502 -228 413
-16: 1671 2307 1341 -357 1280 -252 1127 -153 911 -156 671 -279 357 -439
--57 -566 -460 -614 -776 -555 -1133 -534 -1436 -571 -1391 -613 -871 -599
-97 -470 476 -272 475 -136 364 -48 91 536 -331 1193 -799 1568 -849 1461 -725 1247
--579 1047 -498 951
Modified: grass/branches/releasebranch_7_2/lib/proj/Makefile
--- grass/branches/releasebranch_7_2/lib/proj/Makefile	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/Makefile	2016-12-31 22:26:38 UTC (rev 70180)
@@ -12,58 +12,24 @@
 EXTRA_CFLAGS = $(ZLIBINCPATH) $(GDALCFLAGS)
 EXTRA_INC = $(PROJINC)
-NAD_TABLES := $(wildcard *.lla)
-NT_TABLES = ntv1_can.dat nzgd2kgrid0005.gsb
 PROJ_DIR = $(ETC)/proj
-NAD_DIR  = $(ETC)/proj/nad
-NAD_DSTFILES := $(patsubst %.lla,$(NAD_DIR)/%,$(NAD_TABLES))
-NAD_BINFILES := $(patsubst %.lla,$(OBJDIR)/%,$(NAD_TABLES))
-NT_DSTFILES  := $(patsubst %,$(NAD_DIR)/%,$(NT_TABLES))
-NAD_SRCDIR = $(ETC)/proj/nad/src
-NAD_SRCFILES := $(patsubst %.lla,$(NAD_SRCDIR)/%.lla,$(NAD_TABLES))
 PROJ_TABLES := desc.table parms.table units.table
 PROJ_DSTFILES := $(patsubst %,$(PROJ_DIR)/%,$(PROJ_TABLES))
 default: lib $(FTOL_OBJ)
-	$(MAKE) $(NAD_DSTFILES) $(PROJ_DSTFILES) $(NAD_SRCFILES)
+	$(MAKE) $(PROJ_DSTFILES)
 ifdef MINGW
 $(FTOL_OBJ): $(OBJDIR)/ftol.o
 	$(INSTALL) $< $@
 endif
-$(NAD_DSTFILES): $(NAD_DIR)/%: $(OBJDIR)/% | $(NAD_DIR)
-	$(INSTALL_DATA) $< $@
-$(NAD_BINFILES): $(OBJDIR)/%: %.lla
-	$(NAD2BIN) $@ < $<
-$(NT_DSTFILES): $(NAD_DIR)/%: % | $(NAD_DIR)
-$(NAD_SRCFILES): $(NAD_SRCDIR)/%.lla: %.lla | $(NAD_SRCDIR)
 $(PROJ_DSTFILES): $(PROJ_DIR)/%: % | $(PROJ_DIR)
 $(PROJ_DIR):
 	$(MKDIR) $@
-$(NAD_DIR): | $(PROJ_DIR)
-	$(MKDIR) $@
-$(NAD_SRCDIR): | $(PROJ_DIR)
-	$(MKDIR) $@
-# Note for future improvement:
-# To allow for cross-compilation, the above NAD_TABLES files should be
-# created during installation rather than compilation
 #doxygen:
 DOXNAME=proj
Modified: grass/branches/releasebranch_7_2/lib/proj/README.txt
--- grass/branches/releasebranch_7_2/lib/proj/README.txt	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/README.txt	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,4 +1,4 @@
-Update procedure: GRASS GIS relies on GDAL/PROJ.
+Projection string management: GRASS GIS relies on GDAL/PROJ.
 The EPGS DB is transformed into suitable CSV data for GDAL/PROJ
 according to this procedure:
@@ -7,15 +7,47 @@
 The EPSG CSV files are used via GDAL/OGR API from
 gdal-config --datadir
-The datum shift grids are partially included here.
-See https://github.com/OSGeo/proj.4/wiki
-    --> Datum shift grids
+The datum shift grids are also used from GDAL/PROJ (proj-nad package).
 TODO: It is recommended to rely on PROJ4's proj-nad package. For doing so,
       there would be some changes needed to lib/proj/get_proj.c - the call
       to pj_set_finder() should be removed so that PROJ looks in its default
-      locations for the files. Also changes needed to lib/proj/Makefile so
-      it no longer creates the /etc/proj and /etc/proj/nad directories within
-      a GRASS installation nor installs the files there.
+      locations for the files.
+      Function:
+      const char* pszDatumshiftfile = CPLFindFile( "gdal", "datum_shift.csv" );
+# EPSG code queries:
+# printing all available datum shift codes
+ogrinfo /usr/share/gdal/datum_shift.csv -al
+ogrinfo /usr/share/gdal/gcs.csv -al
+# selective printing
+ogrinfo /usr/share/gdal/datum_shift.csv -al -where "SOURCE_CRS_CODE = '4156'" -al
+ogrinfo /usr/share/gdal/gcs.csv -al -where "COORD_REF_SYS_NAME LIKE '%JT%'"
+# print NAD file info
+gdalinfo /usr/share/proj/hawaii
+# query codes
+gdalsrsinfo EPSG:5514
+# transform between projections
+gdaltransform -s_srs EPSG:4326 -t_srs "+proj=longlat +datum=nad27" --debug on
+# Testing: comparing results
+# Testing using GDAL
+PROJ_DEBUG=ON CPL_DEBUG=ON gdaltransform -s_srs EPSG:4326 -t_srs "+proj=longlat +datum=nad27"
+-100 40
+-99.9995941840488 39.9999941029394 0
+# Testing using GRASS GIS
+PROJ_DEBUG=ON CPL_DEBUG=ON m.proj proj_in="+init=epsg:4326" proj_out="+proj=longlat +datum=NAD27" coordinates=-100,40 -d
+-99.99959418|39.99999410|0.00000000
+The resulting values need to be identical (note: m.proj prints with less precision)
Deleted: grass/branches/releasebranch_7_2/lib/proj/TN.lla
--- grass/branches/releasebranch_7_2/lib/proj/TN.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/TN.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,72 +0,0 @@
-Tennessee - HP
-  41  13   1   -91.00000      .25000    34.00000      .25000
-0: 4428 -22007 -1493 4893 -1577 5555 -1600 6225 -1405 5086 -965 1594 -1701 -1996
--2039 -3629 -1741 -3344 -815 -1573 494 700 1259 1802 1435 1879 1325 1617
-1153 1350 1009 1144 885 1001 778 868 707 653 744 389 841 191 927 57 931 -55
-770 -133 351 -128 -257 -37 -607 -22 -737 -63 -743 -99 -678 -91 -560 -30
--416 38 -280 74 -175 66 -102 31 -54 -8 -26 -41 -11 -60 -5 -71 -6 -73 -10 -70
-1: 3780 -18301 -1014 3344 -1198 4442 -1427 6806 -1330 6403 118 1384 -1798 -3653
--2337 -5100 -2065 -4288 -954 -1580 1037 1956 1772 2803 1591 2110 1187 1417
-865 1022 694 810 561 754 431 767 300 564 399 238 602 75 797 25 926 -76 882 -173
-432 -168 -496 49 -785 39 -800 -58 -737 -137 -642 -130 -489 -13 -301 104
--146 160 -46 133 7 73 30 15 39 -23 39 -41 32 -46 25 -45 15 -38
-2: 3069 -14097 -393 1440 -561 2094 -1223 6705 -1961 7926 1706 1136 -2308 -5180
--2320 -5540 -2111 -4420 -1122 -1101 1818 3758 2256 3591 1515 1676 829 738
-424 480 357 358 273 454 155 786 -183 562 41 35 350 -45 609 92 842 -20 992 -165
-588 -224 -866 182 -861 84 -731 -82 -648 -214 -592 -222 -424 11 -164 201
-11 278 89 207 108 101 102 26 89 -10 74 -20 60 -19 46 -10 34 0
-3: 2036 -8580 276 277 983 -599 -510 2225 -1953 5028 -1355 918 -1485 -2621
--646 -2637 -1037 -2105 -236 1836 1439 3031 2063 2724 988 58 257 -375 -160 -55
-89 -77 91 65 124 1042 -806 722 -215 -297 136 -170 329 352 528 121 879 -7
-201 -18 -794 57 -492 2 -427 -117 -460 -287 -591 -403 -424 80 5 335 195 442
-217 266 181 97 144 20 116 3 92 10 73 22 58 35 46 47
-4: 287 -1924 -453 1080 -331 3 2355 -7518 -858 2359 -3610 -2302 575 3050
-1411 1053 432 3839 -252 90 303 163 1142 119 774 -805 -8 -1014 -755 -120
--12 -73 46 -498 607 1411 -1622 1049 -8 -684 10 -208 0 821 -33 109 994 45
--23 190 -839 -183 -74 50 -109 73 -267 -134 -800 -764 -629 316 275 425 405 661
-304 257 190 30 139 10 112 38 91 67 73 85 60 97 52 105
-5: -865 3376 -382 913 -44 -261 1057 -3331 -508 -2245 742 -3452 775 -1825
--559 27 1784 1798 737 1534 -2211 1916 -525 -445 1059 -829 775 -1226 -946 -789
--613 1793 620 -328 564 -481 -1185 836 1279 836 -572 345 -171 501 -881 -280
-962 -334 169 767 678 -1396 -1259 824 78 836 -143 828 -1381 -1522 -1321 1038
-903 11 594 946 264 66 77 -98 79 60 86 143 74 176 64 182 56 178 53 174
-6: -1343 6747 -88 292 232 -825 700 -2723 317 -3600 220 -3850 200 -1389
-784 -730 1893 125 1140 212 -216 618 -3344 1373 -992 -463 1441 -1220 -673 -1585
-592 -975 -498 836 816 1029 -122 1065 805 1213 67 777 -417 -867 -2156 -452
-1484 229 295 930 833 -644 -135 -680 -38 1930 133 3340 -1820 -2259 -3171 2527
-2553 -2627 483 1358 -55 -352 -228 -120 3 358 68 383 61 351 52 310 51 273
-52 247
-7: -1388 8391 183 -350 407 -1309 560 -2735 238 -3997 -42 -4199 71 -1137
-986 -992 1896 -487 1923 -342 237 149 280 -714 -1945 -467 -1380 -467 -1011 -371
--834 -58 -158 -7 1730 2420 237 1669 164 -191 665 -772 723 -1413 -3157 345
-324 726 329 497 1138 1010 -121 -133 -175 -268 -51 4070 2416 8621 -8245 -1489
-5673 -10573 -529 1071 -827 490 -744 521 87 1194 130 721 64 551 45 439 48 362
-56 311
-8: -1226 8668 372 -864 552 -1607 648 -2768 398 -4734 -744 -9695 44 2104
-907 915 2135 -112 1924 -870 990 963 66 -49 -1087 -39 -2185 14 -1731 115
--1028 -154 -294 -680 -1047 2008 2306 1785 1325 -1428 623 -2381 922 -799
--2498 1892 -1328 829 885 93 580 1349 576 1217 12 -1876 -97 104 -616 1461
--931 1274 641 -1811 -915 917 -299 -301 -1130 436 746 2382 319 748 68 663
-38 517 51 417 62 354
-9: -1031 7928 431 -1230 551 -1693 574 -2266 289 -3136 -774 -5420 881 -309
--40 209 2144 -2843 1906 -2731 630 3134 902 1630 -1538 739 -1788 -303 -2169 90
--968 -799 -248 349 -752 651 633 1763 1973 -1677 -241 -2784 761 1326 -1204 715
--841 2315 733 577 2318 604 1564 14 740 -2126 -2785 -760 -1562 2680 -259 -93
--254 487 -1576 -41 795 -1621 -2359 -288 1945 3980 577 -12 -18 710 15 520
-53 425 71 367
-10: -885 6528 377 -1487 428 -1749 404 -1817 238 -1402 -132 -1485 293 583
--1609 -1903 603 -5543 341 6911 -891 -1006 4153 -596 581 -549 -1636 -2262
--1235 290 -986 1249 -792 -297 691 542 87 2083 88 -194 793 190 -515 -726
--295 193 -168 1078 -910 1303 1418 698 1650 -729 -160 -1305 -3097 -1402
-2044 1640 -870 -591 -202 171 -706 -189 817 -396 -1835 172 -131 615 2670 852
--539 476 -59 457 45 400 75 354
-11: -792 4852 259 -1571 258 -1740 205 -1615 161 -93 -68 78 -214 222 -936 -1563
-147 -2586 598 2672 188 1463 1970 688 681 371 -1504 -866 -222 708 -687 -1579
--6 -404 826 -952 -34 2378 -753 786 -287 433 -361 -358 -228 -75 -227 374
--444 519 710 -70 989 -1131 26 -1638 -986 -1436 841 556 -277 83 -228 258
--292 107 130 42 -820 165 -28 216 1382 525 99 410 16 381 51 349 78 321
-12: -729 3220 132 -1351 115 -1285 70 -874 15 145 -134 465 -293 299 -469 -539
-47 -619 440 1495 483 1720 994 1314 412 822 -565 50 -136 69 -190 -1194 167 -806
-416 -572 -146 1121 -691 793 -600 383 -479 -159 -323 -266 -231 -229 -124 -363
-458 -902 717 -1662 439 -2116 168 -1882 116 411 -205 548 -226 540 -208 421
--101 321 -326 275 64 248 641 360 262 339 120 317 96 296 99 278
Deleted: grass/branches/releasebranch_7_2/lib/proj/WI.lla
--- grass/branches/releasebranch_7_2/lib/proj/WI.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/WI.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,121 +0,0 @@
-Wisconsin - HP
-  33  25   1   -94.00000      .25000    42.00000      .25000
-0: 1142 -2439 -9 236 -4 218 3 196 11 171 18 143 24 117 28 93 21 74 -7 64 -62 57
--151 10 -225 -154 -63 -403 -174 -312 -109 -375 719 -221 484 11 -544 454
-778 199 399 -131 482 334 1322 -1332 466 -2511 25 -1372 -3555 -3448 -5228 -413
--4418 992 -3463 1547 -2945 1834 -2806 2036 -2895 2186 -3089 2289
-1: 962 -2138 -21 236 -17 215 -14 188 -10 161 -8 137 -5 116 0 103 -4 101 -29 128
--94 195 -226 268 -450 166 77 -52 -177 185 -345 -67 1266 -30 758 66 -2237 666
-637 96 -1126 -674 -787 1772 867 -1040 -715 -2820 291 1249 -5772 -5028 -5685 625
--2814 1117 -1412 1110 -1050 1180 -1186 1314 -1522 1455 -1903 1573
-2: 789 -1853 -29 240 -26 212 -27 179 -29 147 -35 124 -38 108 -36 97 -39 91
--73 111 -155 193 -302 351 -899 28 -3 1571 93 396 809 1005 933 26 1061 901
--1277 -638 -1717 -289 -3934 -1909 816 1843 -2988 -654 9 -323 -4099 1350
--11582 532 -703 -565 1348 -475 1346 -154 837 167 207 447 -418 678 -972 858
-3: 626 -1593 -31 249 -30 212 -30 169 -40 129 -57 109 -75 103 -74 102 -72 84
--145 61 -357 63 -715 360 -934 1755 -8 140 -147 130 2178 -1107 -475 3922
-1496 1973 -977 -20 -2133 159 -3098 -1078 -853 -668 -1175 -182 -4471 305
--4241 5372 -11726 2321 1303 -2332 2775 -1960 2375 -1259 1651 -726 889 -329
-178 -20 -427 215
-4: 478 -1372 -30 268 -23 218 -22 158 -33 104 -67 88 -106 112 -103 149 -39 161
--71 165 -279 98 -723 336 -906 3204 -74 516 -1855 765 -982 1893 69 2079 3646 -888
--922 -15 -235 719 -2777 -1741 -1142 -103 -1804 86 -2956 1757 -1355 2255
--3134 1816 -3203 103 -128 -984 1112 -1213 1179 -1075 762 -814 214 -536
--302 -290
-5: 348 -1202 -25 299 -11 235 4 147 4 62 -46 46 -130 114 -143 230 57 315 157 508
-223 453 436 -126 -19 2708 -902 1099 -1702 1214 -1251 898 -1389 1090 -605 -59
--6 -31 900 1775 -64 -924 -1836 -851 -1235 -23 -1467 787 -522 1401 -1184 2449
--1736 1127 -501 -242 316 -968 467 -1169 234 -1078 -139 -864 -510 -635
-6: 238 -1102 -22 346 1 271 43 145 83 -10 35 -43 -116 59 -232 271 114 384
-163 885 -209 1025 -1048 -1897 -50 2666 1000 2000 1000 3000 -3204 899 -3657 -801
--255 -263 121 -887 -90 138 67 -175 48 913 15 357 30 1633 408 1889 -765 1792
--85 973 98 -205 19 -979 -185 -1264 -443 -1227 -704 -1042 -930 -825
-7: 156 -1093 -27 409 -4 335 65 174 195 -109 205 -181 40 -99 -123 93 17 377
-516 888 69 909 -2504 1753 -1605 -456 2000 4000 -1616 -315 -2672 -664 -3712 -1021
-1785 209 846 -379 -473 1235 714 -95 983 1023 1307 762 1190 1830 1358 2334
--710 2081 1700 772 669 -488 -327 -1192 -905 -1387 -1204 -1290 -1358 -1081
--1438 -866
-8: 114 -1197 -36 471 -38 418 11 270 246 -190 339 -236 156 -137 -83 56 -170 677
-1969 2103 -321 3927 -6425 -228 238 -2934 -2825 -2596 -1107 1550 811 265
--666 123 -197 833 -16 -175 1144 678 1132 434 2328 1064 1755 1036 3196 1540
-1493 2616 1952 2632 2169 1092 36 -792 -1226 -1434 -1792 -1434 -1980 -1216
--1982 -967 -1912 -760
-9: 130 -1426 -28 508 -64 452 -90 282 -22 -35 144 -52 -13 211 -156 41 -1453 1063
-719 1943 -896 4530 -6271 -1517 -104 -2066 1068 -925 -361 -53 -1982 -944
-1379 -12 -952 965 -1070 -797 2239 624 1667 -203 4486 701 2870 1044 3892 1732
-3191 2514 1811 2523 3311 1338 -956 -1332 -2114 -1570 -2499 -1269 -2540 -935
--2409 -686 -2221 -523
-10: 206 -1747 15 555 -56 549 -244 443 -642 173 -1140 20 -960 1837 53 -952
--296 140 -5773 2701 -4163 -1719 -804 1949 2804 51 2534 -368 -355 -591 1447 -1726
-334 650 -359 97 -3335 800 2697 -1044 1647 -4023 16184 4356 3962 2167 932 5018
--1556 -308 -158 91 1802 -533 -856 -1170 -1910 -1167 -2509 -752 -2635 -438
--2489 -275 -2262 -206
-11: 317 -2136 114 611 127 731 52 866 -353 852 -1022 243 -1368 2721 -5443 12
--3424 100 -3449 1816 -3385 -2127 1752 -602 2884 -927 3992 -127 2172 904
-1956 -66 -514 -1139 -720 -845 -371 -437 -412 836 1652 -861 10857 -5335
-17344 -13635 39679 -18671 -40694 36552 -10007 7834 -814 -887 599 -2128
--621 -1143 -1919 -233 -2275 81 -2196 126 -2005 89
-12: 380 -2585 181 602 339 824 723 1249 1377 1910 -107 1194 -5794 1662 -5583 1775
--1598 -658 -1308 901 -2569 176 3177 -2081 1537 -2218 468 -1548 2980 956
-324 50 -723 -1427 -1159 -1287 2355 505 1492 309 -1213 814 -7803 -4600 5901 -6146
-26567 -18529 -10372 21045 -4757 11552 862 651 1323 -3096 1006 -1396 -1264 193
--1632 412 -1591 355 -1490 258
-13: 338 -3044 56 492 21 635 -43 831 130 1333 3437 5060 -4977 1084 -8092 2428
--529 -1856 2522 114 1587 392 4576 -1342 -83 -1159 -1736 865 4841 -2658
--1515 -1462 -2283 1122 -1734 -5519 1727 1103 -934 814 -787 -239 -8829 -2963
--10693 -3031 12771 2677 4136 3094 3693 2953 3333 -96 1733 -1087 1142 -586
--526 127 -684 291 -760 297 -829 250
-14: 300 -3401 -37 454 -150 702 -367 1139 -720 1828 -1336 1531 -1339 5182
--2773 155 2106 -380 1087 -1387 3721 -1719 2310 32 456 -120 742 -16 1655 -160
--988 50 -1105 1159 -1133 -3569 4 -313 -2867 541 -3983 855 -11104 -3164
-2270 -5082 7686 1598 2136 2220 1634 1412 1577 315 277 -22 829 34 -745 123
-55 59 -61 122 -256 147
-15: 325 -3665 -54 412 -133 738 -305 1282 -833 2233 -3111 4516 2527 7153
-5200 -902 1671 -2632 -1102 -3172 -105 -1837 2154 -742 -1982 1391 625 158
-244 -129 -160 -565 216 686 -334 -1090 -1269 90 -1522 56 -432 -627 2310 -7203
--1769 -1452 -673 2171 -764 2065 -903 1030 -390 -25 -340 -100 59 -6 -353 30
-62 -6 127 24 25 54
-16: 403 -3896 -56 315 -85 689 -102 1244 -72 1989 136 2611 1494 3958 2390 42
-197 178 -481 -1145 1039 -106 -459 -919 435 -20 160 184 -27 -148 -260 -181
-414 -492 35 -190 -1570 -225 406 434 2134 -370 6112 -2074 -1820 -4189 -7219 529
--1826 901 -1739 972 -631 9 -413 -143 -191 -96 -189 -61 38 -59 141 -40 117 -17
-17: 520 -4172 -83 125 -123 511 -146 1010 -38 1486 676 1817 -821 1175 2015 3048
--175 373 -1334 480 3189 -750 172 48 478 -3 933 663 1404 138 -422 273 -506 -1238
--2394 -1351 -204 -1819 566 -693 -594 -1225 6646 2265 -307 -2024 -4556 -563
--2739 109 -1963 354 -1008 48 -564 -92 -304 -111 -165 -102 0 -98 100 -85
-115 -70
-18: 694 -4558 -109 -173 -174 252 -276 870 -421 1650 -542 2308 -90 845 3268 4894
--759 112 -629 -130 575 -159 2441 -41 934 67 977 -577 3696 1106 7694 2089
--12687 -4638 -8040 -3403 2997 -480 512 249 -344 -398 4851 1203 1431 -461
--1711 -421 -1978 -162 -1675 -13 -1007 28 -610 -54 -357 -100 -188 -117 -49 -121
-38 -117 68 -111
-19: 942 -5097 -104 -625 -138 -252 -175 314 -187 1120 -149 2147 -371 2824
--559 4060 9826 3350 -5878 -1630 -1718 -319 3515 -502 1111 1664 -688 -828
-2873 1448 3923 1087 -6691 -2448 -5696 -3595 -80 -2854 -323 -100 165 145
-2528 648 1427 52 -327 -163 -1042 -153 -1121 -98 -840 -51 -572 -76 -368 -109
--217 -129 -102 -140 -30 -144 4 -142
-20: 1238 -5750 -94 -1191 -95 -969 -76 -682 -15 -418 64 -332 -144 -155 -1857 5519
-1958 4101 148 2169 597 1518 3682 2085 2109 2553 -1401 -1172 736 1535 1344 -16
--3061 -1900 -3399 -2921 -1191 -2567 -557 -882 170 -149 1273 224 1011 85
-153 -61 -437 -115 -654 -114 -605 -100 -475 -110 -345 -130 -235 -148 -150 -160
--94 -168 -66 -171
-21: 1548 -6408 -116 -1732 -116 -1605 -112 -1432 -122 -1215 -222 -834 -614 353
--1365 3851 104 4149 556 3567 560 3306 2935 2120 2372 2503 169 597 334 987
-239 -83 -1513 -1348 -1955 -2107 -1167 -1985 -566 -1111 48 -463 640 -104
-639 -44 251 -84 -131 -119 -347 -133 -401 -136 -368 -144 -305 -157 -241 -172
--189 -184 -152 -193 -134 -198
-22: 1852 -6980 -177 -2161 -192 -2040 -224 -1824 -298 -1451 -459 -746 -744 632
--963 2795 -278 3694 368 3792 849 3565 2047 2766 1926 2465 861 1445 455 995
-70 133 -745 -788 -1082 -1380 -828 -1426 -444 -1023 -24 -596 326 -305 391 -184
-224 -157 -3 -160 -173 -168 -258 -172 -278 -179 -267 -189 -242 -200 -219 -211
--203 -220 -196 -226
-23: 2146 -7440 -260 -2464 -291 -2299 -346 -1990 -436 -1469 -568 -623 -711 650
--706 2178 -281 3154 280 3541 832 3481 1481 3025 1518 2570 1027 1852 612 1219
-211 467 -261 -261 -515 -767 -467 -929 -268 -801 -20 -578 184 -389 247 -278
-174 -230 41 -215 -84 -211 -169 -213 -217 -217 -236 -224 -243 -231 -244 -241
--246 -248 -249 -254
-24: 2438 -7814 -354 -2672 -393 -2447 -449 -2055 -522 -1446 -599 -573 -635 553
--537 1758 -211 2673 242 3174 711 3277 1127 3050 1224 2659 1012 2096 719 1487
-404 830 88 214 -113 -248 -153 -490 -82 -532 38 -471 140 -385 176 -320 136 -282
-51 -266 -40 -257 -119 -256 -176 -257 -217 -260 -244 -265 -266 -272 -282 -278
--297 -285
Deleted: grass/branches/releasebranch_7_2/lib/proj/WO.lla
--- grass/branches/releasebranch_7_2/lib/proj/WO.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/WO.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,204 +0,0 @@
-Washington - Oregon - HP
-  37  37   1  -125.00000      .25000    41.00000      .25000
-0: 21787 -14100 -1545 -660 -1593 -125 -1424 653 -1185 1188 -1424 644 -1448 264
--1228 283 -946 601 -741 1113 -627 1500 -442 1503 -369 1374 -528 1151 -665 929
--849 774 -1071 783 -1276 870 -1125 855 -747 746 -425 548 -202 218 56 -54
-244 -107 263 -196 201 -421 103 -535 -18 -665 -170 -591 -279 -297 -313 198
--214 817 169 1323 342 1652 362 1584 338 1433 316 1336
-1: 15553 -7641 -1186 -1309 -1399 -682 -1135 598 -450 1871 -1348 181 -1479 -481
--1141 -377 -745 71 -547 884 -495 1449 -25 1135 209 935 -150 647 -210 411
--414 214 -743 355 -1325 667 -1108 694 -501 630 -175 504 -119 18 187 -372
-429 -176 346 -156 219 -590 94 -603 -49 -928 -283 -861 -421 -522 -461 98
--460 993 390 1621 571 2155 509 1785 436 1460 388 1311
-2: 9304 -960 -697 -1990 -1317 -1536 -1106 271 1079 3748 -1601 -967 -1634 -1456
--1077 -970 -509 -429 -557 853 -716 1712 545 345 1094 290 21 41 364 -46 201 -402
--136 -118 -1625 603 -1175 489 -71 476 200 621 -221 -195 235 -917 645 -143
-347 104 186 -980 77 -462 -57 -1299 -490 -1122 -603 -789 -463 -106 -1053 1254
-869 1834 865 2974 655 1885 536 1412 461 1274
-3: 2957 6169 209 -2374 -1163 -2575 -2003 -1220 3870 7220 -2410 -3715 -1607 -2244
--1090 -1121 94 -606 -1612 1237 -1631 2539 1803 -1923 2554 -797 -549 -686
-1193 -85 1139 -862 1034 -707 -2243 854 -1303 -31 642 147 750 1007 -619 -373
-68 -1652 813 -4 162 663 105 -1902 145 80 7 -1860 -990 -1127 -1070 -1049
-344 -421 -2065 1625 1392 1694 1154 4138 850 1713 685 1383 549 1315
-4: -3925 13709 1975 -1733 324 -2204 -2905 -2053 2052 2327 460 -3287 -588 -1674
--2585 -1319 3966 1261 -9104 2788 -1964 3207 6046 -7829 3305 -2997 -2057 -1196
-2031 905 3494 174 1232 -1806 -1157 1489 -1430 -1783 1007 73 823 948 -31 -838
--889 -147 -24 -778 37 -82 6 -1314 868 -1037 9 -1571 -2057 -275 -3306 -1641
-3047 231 713 724 -3373 2728 2573 2668 1592 2400 964 1873 637 1550
-5: -12666 20545 3843 -419 3000 -696 -4259 -1703 -1092 -3843 4296 -1540
-1277 -2701 -1924 -1118 -1385 1298 -3090 1177 692 1529 3975 -7198 2700 -4986
--1242 -1680 1944 -1574 1840 -317 1526 -736 603 241 -38 -279 1000 0 1222 682
--35 141 -1568 874 -351 -986 -278 -846 -30 -845 91 -766 105 -284 -1381 -131
--1984 -1184 2354 -1520 1476 1283 -253 3118 -1380 2299 1202 1660 764 1738
-520 1519
-6: -24642 24838 3316 261 2035 -356 -1834 -4110 3031 -4739 4516 -2593 2167 -2076
--667 -691 -847 577 -270 -1452 1893 -1660 3175 -4131 2084 -3282 -353 -3054
-93 -1241 1411 -263 1843 -939 511 -546 1538 457 2741 -72 1531 -459 155 -87
--1540 319 114 990 -1037 -395 -266 -409 -438 49 -464 -414 -796 -325 0 803
-188 444 -315 535 -1071 1100 2265 1617 594 1202 301 1232 273 1205
-7: -38069 25452 2538 -239 2531 -1213 817 -5786 3090 -3032 7642 -2607 2258 -1793
-190 1851 2630 -2548 656 -3374 1865 -2186 3609 -2323 1760 -2873 -13 -2193
--337 -1000 1420 -1241 1197 -1364 592 -1689 2771 -1024 4961 1067 3892 115
-999 -1232 -3964 824 88 2914 -1180 362 -703 41 -374 348 -665 -229 -233 -109
-114 467 773 1611 768 990 1215 890 -1248 871 -642 695 -133 768 101 863
-8: -50842 22647 1270 -1512 1247 -2122 8260 -3292 5207 -3327 7780 -3643
-5049 -2313 -406 -589 3614 -2031 2087 -2089 1290 -1086 2433 -1141 1795 -1347
--89 -1520 -109 -927 729 -1033 1640 -1950 -191 -2703 6891 -609 4634 448
-5756 -758 -639 4333 -1965 2038 -401 85 -1892 -481 -955 116 -682 501 -488 -749
--370 88 744 800 1561 1326 303 1403 -1122 310 -1660 1223 -254 529 90 525
-171 645
-9: -60026 17708 2782 -3010 4619 -3693 7578 -2258 7619 -2858 8905 -2177
-6678 -1940 -155 -772 1605 -1166 2376 -682 2932 -358 368 -1232 2956 -1329
--137 -131 430 -448 -1250 -2237 657 -197 3408 1371 5004 287 3376 1322 2834 2953
-573 1943 52 -1850 766 -1455 -544 -1512 401 -396 -1186 -490 284 -1127 -201 1024
-8 1168 733 707 3230 3507 -5021 -1994 -1867 1275 -22 449 200 475 184 572
-10: -66461 12267 3821 -3476 6021 -4007 8619 -3784 8962 -2813 3725 2285
-7195 -1944 3273 -174 4118 -1341 2563 425 2407 -490 2337 887 3197 -5346
--1424 1423 -205 1829 -977 -381 3298 2069 4609 3636 2044 -1086 782 -634
-548 41 2061 -366 2501 -93 774 -1848 620 -1458 592 -1621 -1768 890 2768 -890
--469 2588 537 1792 -1543 -1123 -526 157 -3795 2418 -265 158 22 91 7 480
-30 561
-11: -70595 6783 3854 -3128 6111 -3300 9803 -3554 14590 -3660 -754 1374
-5737 -2536 3847 -3226 4390 8 2064 1206 2652 2658 4365 -431 1098 534 1611 1857
-2641 470 -414 2945 4867 924 4488 2188 -293 -978 -872 -1583 1215 -1735 88 -3265
-2231 1520 1159 100 2117 -171 -1684 -975 -501 889 -169 1201 1679 3064 3892 3526
--2753 -494 -4030 -2238 -1773 50 -656 -32 48 92 -21 389 -97 469
-12: -72112 936 2875 -2593 4004 -2082 5999 -1700 8234 -3561 8895 -2873
-9125 -1260 6243 -1255 821 -636 1458 -155 8143 3887 2315 2292 2948 715 1993 947
-839 -128 3220 1466 7859 3292 6759 1778 -4710 -2415 -3716 -2524 4035 572
--1593 -1854 -387 1085 682 -15 1682 67 -86 6 4 803 1415 2251 12 1079 296 3413
--3336 1338 -2397 -1965 -1523 -912 913 49 -347 271 -340 263 -306 319
-13: -69937 -5749 2234 -2946 2614 -2714 4483 -3452 13195 -9238 8782 760
-6000 3082 6157 2977 615 747 623 -1802 1728 -2279 4485 2343 11977 4969 6586 3390
--1154 2644 1608 -311 7675 3102 15359 -1247 -11875 -4418 -10444 -9781 6256 8078
--2221 2731 9 3089 -856 79 451 -38 700 -1 1742 874 241 1465 -395 1706 -591 1711
--5765 456 -1228 -78 -27 -155 973 1006 282 -184 -148 -67 -335 146
-14: -63499 -12814 2818 -3940 3313 -4184 5284 -4967 9906 -6096 11082 1310
-4661 5020 -549 1524 3453 3095 541 1403 3094 1712 5519 -1726 6038 427 6249 582
-1004 9728 959 712 2453 -728 6226 -579 17726 1955 -47813 14220 16410 -7263
-6825 -6891 2314 455 11 32 957 672 715 91 964 915 2031 653 2028 4644 1382 1400
--11349 -1158 -2484 -324 2502 -602 -545 962 48 196 -200 99 -416 218
-15: -53556 -19083 4048 -4708 4451 -4891 5639 -4536 7573 -2004 7752 3888
-4451 4630 851 1771 -95 1028 -346 1850 -814 3446 4772 -447 1841 -343 8995 3416
-1973 4849 1566 1317 1606 -296 2035 -632 6569 942 -7701 2228 1280 -85 119 517
-988 64 170 -302 693 105 843 160 2336 2384 1705 1089 3379 583 2044 1643 -15903 -166
-490 -34 404 1319 -145 348 369 -114 -300 229 -559 383
-16: -41475 -23536 5455 -4947 5476 -5082 5474 -4763 5070 -2672 4242 10035
-368 3857 1170 1322 220 1786 -794 2101 4294 1856 -3423 529 -2151 2449 14886 2156
--1510 893 2380 1227 1549 701 900 1228 1585 1006 663 1154 621 700 589 259
--1658 527 -319 291 1042 376 1983 -473 4076 3481 1715 -189 1344 -7246 -1411 10298
--3523 -197 -5318 -4348 -2668 3230 -852 991 791 217 -677 620 -742 584
-17: -28742 -25576 6870 -4395 6517 -3829 5647 -1944 3833 2075 -850 4577
--921 3198 -2354 -106 940 2622 -517 2286 55 996 -233 731 1626 -525 3148 4096
-5219 -1117 2051 1936 1587 493 8 2786 1121 1800 2101 1928 53 669 -2673 1984
--16427 9085 -2076 12532 27517 8764 -4554 -29183 1162 491 1659 2562 1316 869
--298 1725 -11388 7066 -8259 -5474 8201 -3897 16 -256 -506 958 -998 178
--687 434
-18: -16811 -25318 8142 -3711 7381 -3101 5452 -1422 2036 1482 -2243 4629
--2106 3637 -2583 -8 -2860 1177 -408 2635 -1717 3153 -1486 3737 4858 -1961
-2471 1129 2972 -189 1522 930 309 39 74 1424 1085 1790 1987 912 1007 -700
--3351 2829 -11348 6148 828 5857 13992 -956 -1465 -6260 714 474 1584 864
-1984 -1215 5038 -1568 -4639 1977 -1973 -744 -3471 1073 -3714 220 -2300 994
--1103 152 -660 513
-19: -6977 -22933 9263 -2946 8382 -2683 5682 -1549 393 1454 -5174 4786
--3881 2536 -2903 822 -2286 955 -1499 -442 -1684 4068 -7316 2932 -1103 3052
-1062 -1496 6206 -3571 8304 1249 -955 485 546 2176 816 214 1089 894 194 890
--636 881 -4221 1701 -167 1634 2286 -271 1718 1408 1423 501 -52 452 1719 -1201
-459 457 -2490 -1751 1838 6070 -4041 -234 -5155 -1404 72 6 -941 886 -475 665
-20: -406 -18627 10038 -1836 9627 -2126 7317 -2636 1088 -2536 -10930 10601
--6455 -503 -2970 -421 -1819 1285 -3817 -277 -12457 5735 -966 -2555 -1126 -148
-6877 -544 10735 -4040 5941 -242 -986 1830 -763 6279 -736 943 1063 -129
--267 32 -1055 1057 -1036 949 -690 533 -59 1212 847 867 170 612 -1165 1685
-1637 -1755 -1294 -982 -1209 -372 -750 923 -2039 1141 -1585 2626 -820 1242
--10 366 110 566
-21: 1966 -12898 9789 34 9929 367 8705 1337 3611 3160 -19465 -1922 -6535 -3078
--3298 -259 -4156 -3872 -3076 -5160 -9099 8803 3180 -4703 1459 1209 8974 1518
-12520 -468 -2370 741 -1312 1499 178 2692 -699 1287 1070 -179 -1049 119
--1427 863 -956 871 -939 -961 1000 888 226 1071 295 528 -1352 382 -1081 -116
--1897 41 639 127 -1084 -712 -878 844 -2952 2582 -347 2477 609 1029 913 511
-22: 45 -7012 7989 1605 7729 1761 5295 1782 -1226 1303 -5404 -714 -8221 2752
--803 -9453 -11306 -4342 -1233 -11 3789 -2553 -14190 -2317 6536 1199 9562 1995
-12609 -177 3103 965 -3090 2904 2801 27 1549 -329 -1514 1456 -3136 37 -115 187
--317 772 -452 -837 94 -30 -241 796 56 249 -1368 -569 -1541 -57 -994 386
-371 495 -377 730 -284 1380 -4278 3696 -546 1432 773 581 1498 144
-23: -4884 -1962 5559 2734 5743 2458 4664 1300 76 -802 -11158 272 7610 -3883
--5436 -3346 -20671 4465 7472 8543 -76 -17457 -3479 421 -8674 -3937 4481 -1051
-10682 2962 15165 -2249 2132 905 6833 1374 -58 275 -2373 517 -695 -475 -1676 -116
--36 71 854 -36 -624 -186 -2138 -92 -384 -524 -2031 564 240 693 -3 -423 1109 1255
--1169 953 -1062 1937 -1563 2685 -867 1061 687 408 2051 -156
-24: -11046 1594 2750 3538 3647 3105 4458 1325 191 -2562 2551 -1691 449 -309
--7045 -1409 -6775 -1656 -1093 1301 -2177 -1163 -3507 -1759 29500 -6082
--18710 -3191 -3246 15487 9665 -13544 4798 -1320 11488 4203 3102 1133 -3915 -1302
--2095 -3624 -1119 -1002 108 -122 685 -82 -1685 -679 -1714 -55 -1384 -413
--1804 -758 1963 1092 357 -6 1346 10 -2670 2101 -766 1140 -39 1659 -597 2037
-1302 770 3204 -398
-25: -16237 3193 -42 3865 1727 3354 7488 567 1769 -3123 1669 -2983 -418 -1243
--3098 -2711 -1165 259 -1742 3440 -2951 382 0 2000 0 2000 9205 -9906 2076 -5315
--1764 -4576 12607 5377 8440 -278 455 985 -1602 -1549 -2810 -1220 -2108 -497
--673 -1128 -880 -755 -844 -164 -45 -791 -313 -895 -2721 -1259 238 1196
-1687 1777 -574 843 -684 937 -2690 218 1321 1893 802 2088 3200 323 5363 -1207
-26: -18107 2782 -2092 3698 -1342 3856 12267 120 -467 -678 2741 -3778 183 -1145
--1215 -1039 -823 -1 899 324 -44 1861 0 1000 375 2218 1625 782 9005 -3530
-1876 -3709 5210 -426 5592 -838 1924 -3352 -1432 -1674 -1963 -1266 -304 -2643
--3141 -1020 -2018 -512 -1068 -1965 -322 -921 -44 -163 -689 -169 -666 1995
-235 1211 1480 297 111 1929 -3528 568 -86 795 1809 1483 6000 -1119 8352 -2725
-27: -15027 798 -177 2510 1012 3787 7493 1218 -774 -1947 1216 -2468 -1174 -223
--742 -71 163 -586 2010 -18 2000 2000 0 2000 807 1254 437 826 4584 -2860
-2921 -1198 2641 -314 5331 -1483 3298 -2594 -1457 -2265 -1076 -1615 -297 -1419
--3157 -1123 -4032 -2209 27 -2043 920 -969 46 -980 -1257 -392 -4734 7912
-4438 -3887 -2893 1162 5360 2169 -1943 -2573 -1507 1810 2403 1821 9566 -3199
-11636 -4570
-28: -10662 -998 292 1038 -5265 4989 12447 987 -3140 -3750 2032 -585 -3574 331
-258 -73 -279 61 2616 -786 2218 65 2604 1664 4423 1513 -2109 -1336 -152 -2651
-3348 971 1615 440 3139 -516 2132 -1643 -192 -1855 -574 -1737 -1410 -1874
--2753 -1818 -3087 1527 -2097 -4769 89 -280 2211 -15 -1306 547 -10824 6553
-8051 -5806 5525 4111 2686 3060 -5071 464 1576 -1936 7370 -2501 12466 -4954
-14097 -5891
-29: -6637 -584 2539 1277 -748 -32 823 -459 -1194 -894 1568 229 -1390 1597
-2432 67 23 -944 -416 -257 0 -3000 -2720 1989 6776 -899 4794 763 9713 2153
--8324 -2071 -1239 65 1307 244 1041 -818 960 -1870 -1308 -1556 -1000 -1000
--2185 -1117 -1024 -1002 -1883 -2075 72 -636 1904 -18 1072 473 -1776 1960
-48 -472 1127 2283 -1057 3613 -3384 752 5575 -2670 13440 -5605 16367 -6914
-16313 -7030
-30: -4765 -453 3502 574 1146 -787 -562 -627 -1207 -172 1208 422 14 957
--431 -176 -2905 -1738 -257 -25 -3612 -1052 -1131 1077 7868 1735 4972 -806
--8162 -661 10660 -1726 -1497 2563 77 -158 1111 -909 2148 -1521 -2887 -115
--1216 -1509 -279 -918 -1694 -1846 1575 -1645 -185 38 656 662 537 2763 -3657 2254
-1537 483 -1371 1915 -887 357 -835 -239 7016 -4174 20824 -9478 20584 -9116
-17859 -7952
-31: -4037 -459 4908 123 3039 -556 1267 -455 368 -12 332 438 -1625 691 -3348 211
--1530 -929 2893 225 -4267 -1277 -11272 3460 15427 -3101 -2386 -9155 2260 5334
-2384 1169 -2646 3752 1233 -1459 2778 1523 532 -355 -2704 -980 -2461 -258
--1168 -465 -4709 -972 6883 2384 -1062 -486 1760 720 4325 -1752 -3096 1310
--2078 1331 -4778 1910 4035 -2336 -2350 1081 4834 -4809 33656 -15590 24122 -11029
-17970 -8348
-32: -3700 -293 6983 -19 5615 -316 4226 -248 3109 54 1736 354 -1661 474
--6979 249 -3154 162 47825 2583 12000 -2000 -72000 10000 13300 -7819 -7300 -28181
--9000 2000 9000 5000 0 17000 -1000 2000 9421 2789 -2291 190 -5130 21 15000 -3000
--16000 -2000 -9321 5195 33995 6522 326 -4717 11000 -11000 7000 -4000 -2863 1397
--35583 11400 -8875 1804 16321 -7601 -15753 6448 -1145 -4686 54898 -24762
-23396 -11131 16559 -8236
-33: -3432 85 9566 -34 8688 -154 7833 -97 7225 97 6862 306 6699 437 6965 484
--214 662 22959 1489 -197 -130 -42569 2278 -10653 -8997 -11106 -18666 -8905 -3700
-1692 5835 524 12894 880 6497 5224 4249 360 1836 -145 520 7013 -1257 -5776 -154
-329 3762 21344 3173 9613 -4220 9929 -8544 3962 -4270 -7800 1308 -25010 6861
--11444 1843 2984 -3349 -6067 434 6685 -7019 35519 -17747 25333 -12871
-18689 -9920
-34: -3189 620 12367 -14 11829 -61 11305 -19 10921 96 10661 226 10272 319
-8870 367 4172 406 7815 377 -6104 -706 -25145 -1826 -17124 -7648 -13786 -11060
--9837 -3779 -3424 3880 -1222 8649 426 7021 2572 5087 1546 3091 1881 1609
-4097 509 880 921 4974 2182 13638 1015 10489 -3045 7678 -5395 1489 -3301
--7621 310 -15807 2978 -10447 845 -2528 -2144 -851 -2964 8916 -7787 23029 -13247
-22196 -12480 18886 -10904
-35: -3007 1251 15149 -1 14752 -25 14266 -9 13699 36 12924 80 11578 84 9000 22
-4740 -147 1549 -561 -7622 -1579 -17312 -3110 -16791 -5847 -14449 -6636
--10904 -2659 -6425 2424 -3361 5852 -1038 6107 873 5148 1555 3793 2440 2572
-3677 1696 3734 1495 6269 1451 9734 273 8592 -1974 5542 -3268 376 -2391
--5845 -546 -10126 595 -8073 -490 -3286 -2533 1008 -4492 8255 -7812 16163 -10996
-18128 -11604 17374 -11160
-36: -2896 1928 17800 -7 17375 -34 16719 -55 15754 -79 14310 -124 12097 -223
-8768 -404 4287 -714 -650 -1239 -7417 -2088 -13466 -3182 -15005 -4315 -14020 -4104
--11506 -1629 -8199 1669 -5191 4173 -2617 5040 -492 4823 1019 4070 2356 3196
-3618 2435 4564 1900 6100 1330 7397 275 6507 -1115 3917 -1971 39 -1793 -4063 -1113
--6539 -852 -5667 -1693 -2533 -3295 1534 -5245 6850 -7679 11997 -9858 14529 -10862
-15142 -11072
Deleted: grass/branches/releasebranch_7_2/lib/proj/alaska.lla
--- grass/branches/releasebranch_7_2/lib/proj/alaska.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/alaska.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,20751 +0,0 @@
-Alaska
- 529 249   1  -194.00000      .12500    46.00000      .12500
-0: 7735165 -6427502 -4788 8872 -4831 8861 -4882 8842 -4939 8828 -5000 8810
--5060 8793 -5127 8772 -5195 8751 -5264 8725 -5345 8704 -5420 8684 -5500 8665
--5571 8642 -5654 8624 -5733 8609 -5815 8592 -5889 8574 -5965 8557 -6037 8546
--6105 8539 -6176 8530 -6242 8523 -6300 8519 -6357 8521 -6412 8523 -6452 8529
--6492 8537 -6532 8543 -6566 8559 -6585 8572 -6609 8593 -6625 8618 -6629 8647
--6637 8675 -6635 8705 -6633 8735 -6629 8766 -6614 8802 -6598 8838 -6574 8883
--6552 8921 -6531 8960 -6509 9002 -6481 9044 -6455 9084 -6424 9124 -6401 9164
--6374 9200 -6354 9238 -6331 9267 -6315 9308 -6300 9340 -6284 9360 -6282 9387
--6278 9410 -6277 9426 -6287 9438 -6307 9450 -6339 9460 -6379 9467 -6417 9465
--6451 9459 -6486 9446 -6524 9437 -6567 9419 -6628 9397 -6690 9373 -6756 9346
--6833 9317 -6908 9283 -6992 9247 -7089 9211 -7181 9169 -7282 9136 -7390 9090
--7498 9048 -7609 9014 -7725 8972 -7849 8929 -7970 8895 -8100 8860 -8232 8828
--8366 8796 -8503 8773 -8641 8749 -8784 8724 -8935 8716 -9079 8703 -9238 8697
--9396 8700 -9561 8707 -9732 8717 -9900 8738 -10076 8761 -10263 8798 -10453 8834
--10656 8885 -10857 8940 -11057 9007 -11274 9076 -11492 9153 -11721 9239
--11955 9336 -12187 9440 -12429 9546 -12675 9664 -12923 9783 -13166 9911
--13421 10044 -13671 10183 -13925 10328 -14179 10476 -14426 10630 -14662 10785
--14893 10941 -15131 11095 -15376 11243 -15616 11406 -15843 11570 -16051 11731
--16259 11884 -16458 12035 -16641 12182 -16820 12324 -16988 12466 -17144 12596
--17291 12725 -17425 12850 -17541 12968 -17651 13080 -17752 13186 -17842 13284
--17918 13375 -17978 13460 -18026 13536 -18067 13602 -18092 13666 -18108 13724
--18121 13774 -18113 13814 -18092 13842 -18067 13874 -18038 13891 -17986 13902
--17932 13909 -17869 13905 -17792 13897 -17714 13881 -17629 13856 -17537 13824
--17435 13788 -17331 13743 -17219 13694 -17105 13644 -16988 13579 -16868 13515
--16751 13441 -16625 13366 -16500 13283 -16376 13196 -16256 13104 -16142 13013
--16026 12916 -15908 12810 -15802 12707 -15693 12603 -15592 12499 -15499 12394
--15412 12286 -15331 12173 -15259 12065 -15188 11960 -15126 11854 -15081 11758
--15032 11660 -14992 11555 -14954 11451 -14927 11353 -14903 11264 -14893 11175
--14881 11092 -14878 11015 -14879 10934 -14884 10862 -14888 10796 -14891 10734
--14906 10674 -14912 10619 -14921 10571 -14931 10523 -14937 10478 -14945 10439
--14946 10401 -14944 10371 -14942 10342 -14929 10310 -14923 10287 -14904 10263
--14873 10241 -14844 10222 -14811 10206 -14766 10193 -14720 10179 -14665 10162
--14608 10149 -14539 10137 -14465 10122 -14387 10109 -14303 10090 -14215 10081
--14124 10067 -14022 10053 -13916 10036 -13815 10023 -13707 10006 -13596 9992
--13483 9972 -13365 9954 -13245 9935 -13125 9912 -13007 9894 -12883 9867
--12764 9848 -12641 9828 -12519 9806 -12399 9787 -12277 9761 -12156 9734
--12040 9714 -11920 9687 -11802 9665 -11685 9642 -11571 9620 -11466 9601
--11359 9570 -11250 9551 -11142 9526 -11039 9498 -10938 9466 -10837 9434
--10744 9404 -10653 9374 -10565 9344 -10481 9314 -10396 9287 -10319 9259
--10248 9233 -10174 9208 -10107 9178 -10045 9153 -9987 9129 -9931 9105
--9879 9084 -9832 9062 -9789 9044 -9752 9022 -9717 9005 -9687 8987 -9656 8973
--9631 8960 -9608 8949 -9588 8940 -9575 8933 -9563 8923 -9550 8916 -9536 8916
--9530 8911 -9524 8909 -9517 8909 -9515 8912 -9510 8914 -9503 8916 -9499 8921
--9495 8929 -9491 8933 -9487 8940 -9482 8949 -9479 8956 -9470 8965 -9462 8973
--9454 8986 -9446 8996 -9437 9004 -9427 9015 -9415 9027 -9404 9038 -9393 9053
--9381 9063 -9367 9079 -9353 9092 -9341 9106 -9329 9120 -9316 9134 -9303 9151
--9288 9179 -9272 9197 -9260 9211 -9247 9223 -9233 9238 -9218 9256 -9203 9271
--9184 9289 -9169 9308 -9154 9328 -9137 9344 -9118 9363 -9094 9379 -9067 9394
--9040 9410 -9014 9426 -8983 9442 -8950 9455 -8910 9468 -8867 9478 -8821 9488
--8771 9497 -8720 9505 -8662 9512 -8601 9518 -8536 9522 -8466 9526 -8389 9527
--8311 9526 -8228 9525 -8146 9526 -8064 9524 -7973 9522 -7878 9516 -7779 9510
--7685 9506 -7593 9500 -7502 9495 -7410 9487 -7311 9480 -7217 9472 -7128 9465
--7046 9456 -6972 9447 -6898 9438 -6825 9432 -6758 9422 -6700 9412 -6650 9403
--6608 9391 -6574 9381 -6548 9370 -6530 9360 -6517 9348 -6511 9336 -6512 9325
--6526 9311 -6550 9296 -6580 9282 -6613 9268 -6643 9256 -6675 9243 -6720 9229
--6775 9216 -6832 9200 -6881 9187 -6919 9180 -6953 9172 -6991 9164 -7035 9155
--7073 9149 -7094 9147 -7099 9149 -7093 9155 -7080 9164 -7061 9173 -7027 9188
--6981 9207 -6914 9227 -6832 9254 -6731 9287 -6617 9323 -6486 9365 -6340 9410
--6191 9452 -6023 9501 -5833 9560 -5622 9620 -5397 9688 -5172 9750 -4957 9809
--4734 9871 -4492 9940 -4229 10015 -3967 10085 -3718 10150 -3492 10208
--3274 10262 -3048 10318 -2816 10374 -2597 10425 -2403 10467 -2239 10496
--2096 10519 -1967 10535 -1850 10547 -1755 10548 -1688 10541 -1645 10522
--1630 10497 -1645 10457 -1692 10405 -1763 10345 -1851 10279 -1943 10211
--2056 10132 -2208 10038 -2402 9932 -2611 9819 -2806 9710 -2980 9606 -3158 9502
--3375 9382 -3618 9253 -3851 9125 -4044 9013 -4184 8917 -4302 8829 -4434 8734
--4568 8639 -4666 8554 -4697 8493 -4652 8459 -4554 8442 -4436 8431 -4285 8430
--4070 8451 -3779 8501 -3400 8579 -2948 8683 -2434 8808 -1855 8954 -1199 9127
--464 9327 341 9553 1226 9805 2206 10090 3273 10407 4415 10747 5610 11107
-6846 11483 8152 11882 9565 12318 11067 12784 12621 13272 14195 13764 15762 14256
-17368 14763 19067 15303 20843 15867 22635 16439 24394 17002 26095 17548
-27794 18095 29555 18661 31351 19241 33118 19815 34808 20362 36394 20878
-37924 21378 39467 21883 40994 22385 42450 22863 43783 23306 44982 23705
-46080 24074 47128 24428 48123 24767 48980 25062 49704 25312 50300 25525
-50765 25701 51091 25838 51278 25932 51330 25983 51241 25987 51002 25948
-50615 25869 50090 25742 49372 25565 48463 25336 47482 25057 46469 24741
-45213 24382 43498 23949 41468 23497 39609 23025 38166 22361 36737 21552
-34555 20950 31220 20594 27204 19998 23556 18754 21138 17138 19976 15919
-19174 15575 17398 15729 13467 15437 6743 13853 -3222 10368 -20000 3000
--21000 4000 -20000 3000 -20000 3000 -20000 3000 -20000 4000 -20000 3000
--21000 3000 -20000 4000 -20000 3000 -21000 4000 -20000 3000 -20000 3000
--20000 4000 -21000 3000 -20000 4000 -20000 3000 -21000 4000 -20000 3000
--20000 3000 -20000 4000 -21000 3000 -20000 3000 -20000 3000
-1: 7771340 -6419781 -4660 8832 -4698 8821 -4740 8799 -4794 8780 -4847 8762
--4901 8743 -4958 8718 -5018 8696 -5077 8669 -5146 8646 -5209 8618 -5275 8597
--5339 8575 -5407 8554 -5473 8536 -5540 8514 -5600 8492 -5662 8481 -5713 8461
--5769 8449 -5828 8437 -5874 8429 -5914 8422 -5961 8422 -5997 8422 -6021 8425
--6048 8428 -6069 8436 -6085 8445 -6092 8458 -6104 8476 -6100 8501 -6097 8524
--6092 8554 -6074 8581 -6062 8609 -6043 8638 -6020 8674 -5993 8714 -5965 8745
--5935 8788 -5905 8826 -5877 8864 -5842 8904 -5814 8945 -5781 8983 -5754 9022
--5727 9055 -5707 9088 -5686 9121 -5672 9153 -5658 9185 -5650 9205 -5654 9230
--5651 9245 -5660 9258 -5677 9272 -5701 9279 -5697 9277 -5737 9282 -5794 9273
--5852 9266 -5910 9253 -5973 9237 -6040 9219 -6122 9189 -6203 9162 -6288 9131
--6384 9098 -6482 9061 -6586 9018 -6701 8977 -6813 8934 -6932 8895 -7063 8845
--7192 8802 -7323 8763 -7464 8714 -7606 8677 -7752 8635 -7901 8600 -8056 8563
--8210 8538 -8367 8512 -8526 8491 -8692 8471 -8864 8456 -9029 8448 -9207 8452
--9387 8457 -9571 8463 -9762 8487 -9950 8507 -10148 8543 -10351 8583 -10559 8633
--10780 8693 -11003 8758 -11223 8831 -11455 8916 -11689 9002 -11936 9107
--12187 9215 -12440 9334 -12694 9458 -12955 9589 -13222 9725 -13478 9868
--13745 10019 -14009 10176 -14273 10337 -14538 10505 -14794 10672 -15039 10848
--15277 11021 -15520 11194 -15769 11357 -16024 11530 -16255 11710 -16468 11884
--16674 12059 -16866 12220 -17047 12385 -17218 12541 -17380 12689 -17531 12835
--17674 12975 -17795 13104 -17908 13232 -18011 13347 -18101 13461 -18180 13565
--18241 13659 -18294 13747 -18332 13826 -18364 13893 -18373 13960 -18385 14017
--18380 14064 -18357 14102 -18329 14133 -18293 14156 -18250 14173 -18192 14182
--18124 14183 -18046 14177 -17959 14163 -17874 14139 -17776 14108 -17677 14070
--17569 14030 -17452 13978 -17331 13927 -17214 13862 -17092 13793 -16963 13718
--16838 13638 -16714 13555 -16585 13465 -16456 13372 -16337 13274 -16220 13174
--16103 13069 -15986 12956 -15884 12846 -15779 12738 -15685 12626 -15594 12513
--15515 12399 -15443 12285 -15381 12172 -15319 12058 -15270 11950 -15230 11849
--15200 11749 -15173 11643 -15146 11533 -15135 11436 -15126 11340 -15130 11255
--15140 11173 -15154 11092 -15168 11013 -15191 10944 -15208 10880 -15232 10819
--15257 10762 -15282 10709 -15313 10662 -15327 10617 -15351 10576 -15368 10540
--15382 10509 -15390 10479 -15397 10451 -15392 10427 -15393 10406 -15377 10386
--15356 10371 -15325 10354 -15293 10341 -15251 10327 -15203 10317 -15147 10303
--15086 10293 -15009 10282 -14929 10267 -14847 10254 -14752 10238 -14657 10228
--14552 10212 -14443 10195 -14325 10181 -14208 10163 -14090 10144 -13966 10126
--13838 10104 -13705 10082 -13572 10056 -13436 10031 -13303 10003 -13166 9974
--13029 9948 -12893 9923 -12757 9895 -12622 9870 -12486 9835 -12353 9803
--12222 9774 -12089 9740 -11962 9711 -11830 9683 -11707 9653 -11590 9625
--11477 9588 -11348 9551 -11235 9515 -11126 9486 -11018 9450 -10914 9412
--10816 9380 -10721 9346 -10626 9313 -10539 9278 -10452 9248 -10370 9216
--10295 9186 -10221 9156 -10151 9125 -10088 9096 -10031 9069 -9974 9043
--9920 9020 -9874 8997 -9832 8977 -9795 8955 -9763 8935 -9733 8921 -9705 8907
--9679 8892 -9660 8882 -9642 8876 -9633 8868 -9623 8859 -9611 8856 -9602 8855
--9598 8855 -9595 8851 -9592 8856 -9592 8859 -9589 8863 -9586 8871 -9586 8879
--9585 8887 -9584 8897 -9584 8907 -9580 8917 -9579 8926 -9574 8941 -9569 8951
--9565 8966 -9557 8980 -9551 8990 -9542 9006 -9532 9021 -9521 9035 -9511 9053
--9499 9067 -9485 9085 -9471 9101 -9458 9118 -9447 9135 -9431 9152 -9412 9169
--9398 9194 -9381 9211 -9362 9231 -9346 9249 -9327 9270 -9307 9287 -9287 9306
--9262 9326 -9239 9346 -9218 9365 -9194 9383 -9168 9402 -9135 9420 -9100 9433
--9068 9450 -9032 9463 -8993 9480 -8950 9492 -8903 9503 -8851 9512 -8799 9519
--8741 9527 -8680 9534 -8616 9538 -8548 9541 -8478 9543 -8400 9544 -8318 9542
--8233 9541 -8146 9534 -8061 9532 -7975 9529 -7881 9523 -7782 9516 -7683 9506
--7587 9499 -7493 9491 -7405 9483 -7311 9473 -7214 9464 -7123 9454 -7032 9445
--6955 9434 -6885 9424 -6813 9414 -6745 9406 -6683 9394 -6628 9384 -6584 9376
--6545 9362 -6518 9352 -6496 9342 -6484 9330 -6477 9319 -6477 9308 -6482 9295
--6500 9283 -6529 9267 -6566 9255 -6603 9242 -6638 9229 -6674 9218 -6721 9205
--6780 9192 -6840 9177 -6893 9163 -6932 9158 -6969 9152 -7006 9142 -7053 9137
--7091 9131 -7114 9128 -7118 9132 -7110 9139 -7097 9148 -7076 9158 -7042 9173
--6991 9191 -6923 9215 -6838 9241 -6736 9274 -6615 9312 -6482 9354 -6333 9399
--6178 9442 -6008 9493 -5815 9550 -5596 9614 -5370 9678 -5140 9743 -4917 9804
--4695 9865 -4448 9935 -4179 10010 -3914 10081 -3663 10146 -3431 10206
--3212 10259 -2983 10316 -2749 10373 -2528 10425 -2332 10467 -2166 10497
--2022 10519 -1895 10536 -1776 10550 -1680 10551 -1615 10544 -1574 10527
--1560 10499 -1576 10460 -1627 10409 -1700 10348 -1789 10284 -1887 10215
--2002 10136 -2158 10041 -2356 9936 -2570 9821 -2772 9712 -2948 9609 -3131 9503
--3354 9384 -3598 9254 -3841 9125 -4040 9010 -4184 8914 -4306 8826 -4443 8729
--4583 8632 -4687 8548 -4725 8483 -4685 8448 -4591 8429 -4475 8416 -4331 8414
--4124 8432 -3835 8480 -3461 8555 -3013 8657 -2505 8779 -1928 8921 -1277 9091
--548 9288 252 9510 1135 9759 2111 10041 3173 10352 4309 10688 5505 11045
-6734 11416 8036 11809 9443 12240 10941 12702 12494 13184 14066 13672 15626 14157
-17225 14658 18920 15190 20692 15750 22481 16316 24238 16874 25934 17413
-27626 17951 29381 18512 31173 19085 32938 19651 34625 20194 36206 20703
-37730 21197 39268 21694 40793 22189 42245 22662 43578 23099 44772 23492
-45863 23854 46907 24204 47880 24534 48730 24823 49453 25069 50048 25277
-50513 25448 50841 25583 51024 25674 51079 25722 50989 25723 50742 25683
-50358 25600 49837 25474 49108 25298 48174 25066 47190 24783 46196 24472
-44957 24115 43218 23671 41139 23226 39241 22771 37776 22101 36329 21283
-34124 20669 30792 20294 26827 19663 23261 18421 20878 16886 19641 15808
-18621 15556 16492 15626 12092 15030 4691 12934 -6082 8878 -20000 3000
--20000 4000 -20000 3000 -21000 3000 -20000 4000 -20000 3000 -20000 3000
--20000 4000 -21000 3000 -20000 4000 -20000 4000 -21000 3000 -20000 4000
--20000 3000 -21000 4000 -20000 3000 -20000 4000 -20000 3000 -21000 4000
--20000 3000 -20000 4000 -20000 3000 -20000 3000 -21000 3000
-2: 7807521 -6412057 -4525 8790 -4562 8780 -4599 8754 -4646 8736 -4688 8707
--4734 8687 -4781 8667 -4835 8639 -4886 8611 -4943 8585 -4992 8552 -5046 8529
--5097 8504 -5152 8482 -5207 8455 -5255 8434 -5305 8411 -5347 8395 -5389 8376
--5427 8356 -5463 8345 -5497 8334 -5525 8321 -5551 8317 -5572 8316 -5583 8317
--5592 8318 -5597 8324 -5596 8334 -5593 8341 -5586 8360 -5570 8380 -5554 8400
--5532 8427 -5502 8453 -5478 8481 -5452 8511 -5418 8541 -5382 8582 -5344 8615
--5305 8653 -5272 8687 -5239 8724 -5197 8765 -5164 8805 -5129 8841 -5100 8876
--5072 8910 -5057 8940 -5038 8970 -5020 9001 -5012 9029 -5007 9052 -5015 9072
--5022 9082 -5045 9092 -5065 9105 -5098 9106 -5081 9098 -5123 9099 -5190 9087
--5262 9076 -5346 9062 -5432 9036 -5519 9016 -5616 8983 -5719 8955 -5823 8917
--5940 8878 -6056 8835 -6182 8792 -6312 8746 -6451 8699 -6593 8651 -6736 8602
--6891 8555 -7046 8511 -7202 8463 -7372 8419 -7537 8374 -7706 8340 -7884 8302
--8058 8274 -8235 8250 -8420 8229 -8605 8212 -8797 8199 -8985 8195 -9179 8202
--9383 8211 -9589 8224 -9796 8250 -10003 8279 -10226 8320 -10444 8369 -10669 8428
--10911 8498 -11154 8574 -11391 8657 -11638 8753 -11895 8855 -12161 8970
--12425 9098 -12691 9226 -12964 9369 -13239 9515 -13521 9667 -13798 9826
--14073 9995 -14350 10167 -14628 10350 -14902 10529 -15167 10724 -15423 10912
--15666 11104 -15911 11294 -16164 11475 -16434 11664 -16672 11852 -16885 12047
--17087 12235 -17276 12415 -17450 12590 -17622 12760 -17778 12918 -17922 13078
--18052 13225 -18170 13365 -18276 13497 -18370 13621 -18451 13739 -18519 13850
--18570 13948 -18613 14037 -18637 14116 -18655 14191 -18659 14256 -18655 14311
--18636 14358 -18604 14393 -18563 14424 -18518 14442 -18461 14456 -18390 14463
--18313 14461 -18222 14448 -18127 14427 -18028 14401 -17920 14362 -17816 14319
--17697 14271 -17571 14215 -17447 14153 -17316 14083 -17189 14008 -17056 13925
--16927 13837 -16794 13741 -16663 13645 -16534 13546 -16414 13445 -16292 13333
--16178 13221 -16066 13104 -15961 12988 -15862 12871 -15773 12751 -15686 12633
--15616 12513 -15554 12395 -15500 12276 -15447 12156 -15409 12045 -15385 11936
--15361 11838 -15352 11731 -15345 11615 -15346 11515 -15352 11421 -15377 11336
--15396 11253 -15432 11172 -15464 11092 -15499 11026 -15538 10961 -15576 10904
--15614 10850 -15660 10797 -15698 10756 -15737 10712 -15773 10675 -15801 10645
--15826 10614 -15847 10589 -15858 10566 -15866 10546 -15870 10528 -15859 10513
--15846 10500 -15820 10487 -15786 10478 -15743 10469 -15691 10457 -15637 10448
--15570 10437 -15490 10429 -15401 10415 -15312 10402 -15208 10388 -15101 10378
--14992 10358 -14865 10343 -14739 10325 -14607 10307 -14474 10283 -14337 10263
--14194 10239 -14046 10210 -13899 10177 -13749 10150 -13597 10118 -13446 10084
--13294 10049 -13145 10019 -12992 9984 -12842 9949 -12695 9910 -12546 9871
--12401 9834 -12257 9792 -12117 9756 -11972 9721 -11841 9685 -11712 9646
--11589 9605 -11451 9553 -11327 9509 -11211 9474 -11097 9433 -10989 9392
--10885 9356 -10782 9316 -10685 9278 -10593 9242 -10501 9207 -10418 9171
--10339 9135 -10264 9103 -10194 9069 -10127 9036 -10071 9007 -10014 8982
--9960 8954 -9913 8929 -9872 8908 -9837 8887 -9806 8866 -9779 8851 -9751 8840
--9724 8824 -9711 8816 -9698 8810 -9688 8801 -9681 8796 -9671 8795 -9665 8794
--9663 8794 -9665 8796 -9666 8804 -9667 8808 -9668 8814 -9670 8825 -9668 8834
--9674 8848 -9677 8859 -9679 8873 -9679 8886 -9678 8899 -9675 8916 -9676 8927
--9672 8945 -9669 8965 -9663 8978 -9656 8997 -9647 9016 -9638 9034 -9628 9052
--9616 9070 -9602 9092 -9586 9112 -9574 9130 -9558 9152 -9542 9170 -9522 9190
--9507 9210 -9484 9232 -9462 9256 -9441 9277 -9419 9300 -9393 9321 -9367 9341
--9336 9362 -9306 9383 -9278 9402 -9247 9423 -9212 9440 -9174 9458 -9132 9471
--9090 9488 -9046 9501 -8999 9516 -8947 9526 -8893 9537 -8834 9544 -8773 9549
--8708 9556 -8639 9559 -8567 9561 -8493 9562 -8416 9562 -8333 9560 -8246 9556
--8155 9549 -8064 9544 -7975 9536 -7887 9531 -7791 9522 -7689 9512 -7587 9501
--7491 9488 -7396 9480 -7309 9471 -7216 9458 -7122 9446 -7030 9435 -6946 9423
--6869 9412 -6801 9399 -6734 9388 -6670 9380 -6612 9366 -6563 9356 -6523 9346
--6491 9333 -6466 9324 -6453 9312 -6443 9302 -6443 9290 -6448 9279 -6458 9267
--6481 9254 -6515 9240 -6555 9229 -6601 9215 -6638 9205 -6676 9193 -6727 9182
--6789 9168 -6852 9155 -6909 9143 -6950 9139 -6985 9131 -7026 9124 -7072 9118
--7111 9113 -7134 9112 -7139 9116 -7128 9124 -7113 9135 -7092 9144 -7055 9159
--7002 9178 -6931 9203 -6844 9230 -6738 9263 -6614 9301 -6476 9344 -6324 9388
--6164 9433 -5991 9485 -5794 9542 -5571 9606 -5339 9670 -5106 9736 -4881 9797
--4651 9859 -4403 9931 -4131 10004 -3860 10077 -3605 10141 -3372 10202
--3150 10256 -2920 10313 -2684 10371 -2460 10424 -2261 10466 -2095 10496
--1953 10518 -1822 10537 -1705 10549 -1610 10552 -1545 10545 -1506 10529
--1492 10501 -1510 10461 -1564 10411 -1639 10351 -1733 10286 -1834 10216
--1950 10139 -2112 10044 -2313 9937 -2531 9825 -2739 9713 -2920 9609 -3106 9503
--3333 9384 -3585 9253 -3829 9125 -4036 9008 -4185 8910 -4311 8821 -4453 8725
--4597 8627 -4709 8539 -4753 8474 -4717 8437 -4625 8417 -4516 8403 -4375 8398
--4173 8414 -3890 8459 -3520 8532 -3078 8632 -2569 8750 -2000 8890 -1352 9057
--628 9249 168 9469 1046 9714 2018 9992 3074 10299 4209 10631 5400 10984
-6626 11349 7922 11738 9325 12164 10819 12620 12365 13096 13934 13579 15490 14058
-17085 14554 18775 15081 20539 15632 22323 16192 24079 16744 25770 17277
-27455 17808 29205 18361 30991 18927 32752 19487 34435 20024 36011 20526
-37530 21012 39060 21503 40581 21990 42030 22457 43362 22887 44547 23275
-45636 23631 46678 23973 47638 24298 48481 24579 49202 24820 49790 25024
-50257 25190 50579 25322 50763 25410 50817 25452 50723 25451 50468 25408
-50088 25324 49572 25196 48828 25019 47876 24785 46880 24498 45898 24193
-44665 23833 42923 23381 40821 22941 38887 22493 37374 21829 35873 21014
-33625 20392 30309 19980 26421 19303 22934 18061 20542 16598 19155 15612
-17838 15368 15328 15293 10544 14446 2873 12155 -7716 8233 -20000 3000
--20000 4000 -20000 3000 -20000 3000 -21000 4000 -20000 3000 -20000 4000
--20000 4000 -21000 3000 -20000 4000 -20000 3000 -20000 4000 -21000 4000
--20000 4000 -20000 3000 -21000 4000 -20000 4000 -20000 3000 -20000 4000
--21000 3000 -20000 4000 -20000 3000 -20000 3000 -20000 3000
-3: 7843716 -6404329 -4388 8748 -4420 8733 -4451 8708 -4490 8684 -4528 8660
--4563 8634 -4601 8607 -4641 8577 -4685 8548 -4728 8519 -4771 8487 -4810 8459
--4848 8429 -4888 8404 -4927 8375 -4964 8350 -4995 8329 -5024 8306 -5055 8284
--5071 8262 -5092 8248 -5112 8231 -5121 8220 -5128 8211 -5134 8208 -5129 8202
--5128 8204 -5111 8211 -5097 8216 -5079 8225 -5056 8239 -5029 8253 -4998 8274
--4962 8298 -4921 8321 -4883 8350 -4848 8378 -4805 8410 -4756 8446 -4712 8479
--4666 8517 -4625 8547 -4590 8582 -4544 8623 -4505 8659 -4468 8699 -4439 8730
--4414 8763 -4394 8792 -4377 8821 -4362 8850 -4361 8874 -4363 8895 -4372 8913
--4394 8922 -4419 8930 -4451 8934 -4491 8937 -4486 8924 -4532 8914 -4606 8906
--4697 8890 -4795 8871 -4898 8841 -5003 8818 -5112 8777 -5240 8748 -5362 8703
--5497 8659 -5640 8608 -5779 8566 -5933 8512 -6092 8465 -6253 8412 -6419 8360
--6597 8306 -6771 8258 -6952 8209 -7142 8162 -7329 8119 -7521 8074 -7718 8039
--7913 8010 -8115 7987 -8317 7967 -8526 7952 -8733 7942 -8949 7938 -9167 7950
--9386 7960 -9609 7985 -9836 8013 -10068 8049 -10297 8096 -10548 8157 -10790 8220
--11046 8298 -11311 8388 -11565 8483 -11831 8590 -12107 8708 -12384 8832
--12669 8973 -12953 9120 -13240 9279 -13531 9440 -13826 9614 -14120 9786
--14408 9969 -14696 10163 -14990 10361 -15269 10562 -15548 10771 -15809 10978
--16061 11194 -16317 11397 -16569 11591 -16844 11801 -17089 12009 -17302 12216
--17500 12418 -17687 12613 -17858 12804 -18026 12984 -18178 13156 -18315 13323
--18438 13481 -18550 13631 -18646 13768 -18729 13902 -18799 14020 -18858 14136
--18901 14240 -18927 14334 -18944 14413 -18952 14491 -18941 14555 -18924 14609
--18892 14656 -18848 14690 -18794 14715 -18736 14733 -18671 14743 -18588 14745
--18498 14740 -18395 14719 -18290 14695 -18180 14662 -18063 14620 -17946 14568
--17824 14517 -17690 14450 -17555 14382 -17413 14301 -17279 14220 -17146 14131
--17007 14035 -16873 13933 -16738 13826 -16604 13722 -16487 13609 -16359 13494
--16248 13373 -16142 13251 -16037 13126 -15944 13002 -15855 12878 -15778 12752
--15711 12627 -15657 12502 -15615 12379 -15578 12254 -15545 12137 -15532 12029
--15528 11925 -15534 11815 -15542 11697 -15561 11598 -15586 11500 -15619 11417
--15660 11330 -15715 11250 -15766 11174 -15816 11107 -15872 11044 -15928 10989
--15981 10938 -16042 10887 -16101 10852 -16153 10809 -16200 10776 -16243 10747
--16282 10725 -16313 10703 -16333 10684 -16351 10667 -16358 10655 -16356 10641
--16347 10633 -16322 10625 -16290 10619 -16246 10610 -16195 10603 -16137 10596
--16060 10587 -15978 10579 -15883 10567 -15783 10556 -15672 10541 -15558 10529
--15432 10512 -15297 10494 -15157 10471 -15012 10452 -14859 10428 -14708 10402
--14551 10373 -14390 10339 -14227 10305 -14061 10268 -13890 10233 -13728 10194
--13558 10154 -13394 10113 -13226 10073 -13060 10029 -12899 9986 -12737 9938
--12577 9893 -12421 9846 -12267 9801 -12114 9758 -11967 9714 -11830 9664
--11702 9617 -11549 9557 -11419 9508 -11292 9460 -11173 9416 -11059 9372
--10949 9330 -10840 9286 -10738 9243 -10642 9201 -10549 9162 -10461 9122
--10378 9082 -10303 9046 -10232 9012 -10166 8974 -10107 8943 -10051 8915
--9997 8885 -9949 8860 -9909 8837 -9877 8816 -9847 8798 -9821 8779 -9794 8769
--9770 8758 -9760 8746 -9749 8740 -9742 8737 -9738 8731 -9729 8733 -9728 8732
--9728 8736 -9733 8741 -9737 8749 -9741 8758 -9747 8765 -9748 8779 -9754 8792
--9762 8807 -9767 8822 -9772 8839 -9775 8855 -9777 8872 -9779 8890 -9779 8906
--9778 8928 -9778 8948 -9773 8967 -9768 8988 -9760 9011 -9752 9033 -9743 9055
--9729 9077 -9717 9099 -9702 9122 -9686 9142 -9669 9167 -9651 9190 -9631 9212
--9609 9233 -9583 9256 -9558 9283 -9534 9306 -9505 9331 -9474 9354 -9443 9377
--9407 9397 -9370 9419 -9334 9439 -9296 9460 -9253 9477 -9208 9495 -9159 9508
--9108 9524 -9056 9535 -9001 9552 -8941 9560 -8878 9567 -8814 9573 -8744 9578
--8671 9581 -8594 9583 -8516 9581 -8436 9580 -8353 9579 -8264 9574 -8172 9564
--8077 9558 -7983 9547 -7889 9540 -7799 9529 -7701 9519 -7597 9506 -7495 9492
--7397 9478 -7305 9465 -7216 9455 -7124 9440 -7034 9427 -6944 9413 -6863 9401
--6788 9387 -6724 9374 -6661 9361 -6602 9351 -6549 9339 -6504 9328 -6470 9316
--6442 9304 -6423 9294 -6414 9284 -6411 9272 -6417 9261 -6425 9249 -6442 9239
--6468 9227 -6508 9216 -6553 9202 -6602 9191 -6643 9181 -6683 9171 -6739 9159
--6804 9146 -6870 9135 -6928 9126 -6970 9118 -7006 9113 -7048 9107 -7094 9103
--7131 9098 -7155 9097 -7160 9103 -7148 9111 -7131 9122 -7106 9132 -7068 9147
--7011 9168 -6939 9190 -6849 9219 -6739 9253 -6611 9292 -6469 9335 -6314 9379
--6149 9425 -5971 9477 -5771 9534 -5545 9597 -5307 9663 -5071 9729 -4842 9791
--4608 9853 -4356 9924 -4081 9998 -3808 10072 -3548 10138 -3313 10196 -3088 10251
--2857 10309 -2618 10368 -2393 10420 -2194 10462 -2026 10494 -1883 10517
--1753 10535 -1637 10547 -1543 10552 -1479 10543 -1439 10529 -1428 10501
--1449 10460 -1504 10412 -1583 10351 -1681 10285 -1783 10217 -1903 10139
--2070 10045 -2273 9938 -2496 9825 -2709 9712 -2894 9609 -3085 9503 -3315 9382
--3572 9251 -3819 9123 -4034 9005 -4189 8907 -4317 8816 -4464 8720 -4612 8620
--4730 8532 -4778 8466 -4746 8426 -4661 8405 -4554 8389 -4418 8383 -4221 8397
--3941 8439 -3577 8510 -3136 8608 -2634 8722 -2068 8860 -1426 9024 -705 9213
-89 9429 960 9670 1928 9946 2981 10246 4111 10575 5298 10923 6520 11284
-7812 11668 9208 12088 10696 12539 12240 13009 13804 13487 15354 13961
-16944 14449 18628 14971 20385 15515 22165 16068 23916 16613 25601 17139
-27281 17664 29024 18210 30804 18768 32559 19320 34238 19851 35806 20346
-37320 20825 38847 21308 40359 21788 41804 22247 43131 22672 44313 23052
-45395 23401 46432 23738 47392 24056 48227 24331 48940 24565 49529 24764
-49992 24926 50308 25051 50486 25136 50541 25175 50441 25169 50174 25122
-49799 25035 49286 24906 48531 24728 47563 24491 46553 24200 45567 23899
-44339 23536 42600 23078 40494 22638 38536 22191 36963 21534 35382 20736
-33085 20114 29787 19656 25968 18935 22535 17700 20117 16285 18561 15340
-16962 15054 14158 14844 9215 13851 1723 11583 -8227 8044 -21000 3000 -20000 4000
--20000 3000 -20000 4000 -20000 3000 -20000 4000 -21000 3000 -20000 4000
--20000 4000 -20000 4000 -21000 3000 -20000 4000 -20000 4000 -21000 4000
--20000 3000 -20000 4000 -21000 4000 -20000 4000 -20000 3000 -20000 4000
-4: 7879924 -6396600 -4243 8704 -4273 8685 -4296 8655 -4327 8637 -4357 8607
--4386 8577 -4413 8547 -4443 8513 -4472 8479 -4505 8451 -4540 8416 -4564 8388
--4591 8352 -4613 8324 -4639 8289 -4659 8262 -4678 8241 -4688 8210 -4701 8191
--4707 8163 -4709 8146 -4711 8125 -4707 8113 -4695 8102 -4682 8096 -4665 8087
--4648 8088 -4613 8088 -4583 8096 -4550 8101 -4511 8113 -4473 8125 -4427 8147
--4381 8165 -4325 8189 -4276 8212 -4228 8243 -4179 8271 -4124 8310 -4065 8342
--4017 8374 -3966 8404 -3926 8442 -3880 8479 -3838 8513 -3798 8552 -3771 8586
--3744 8613 -3723 8642 -3712 8673 -3700 8695 -3703 8719 -3714 8742 -3725 8751
--3757 8761 -3787 8770 -3832 8766 -3883 8766 -3905 8756 -3960 8739 -4046 8726
--4141 8706 -4251 8680 -4370 8650 -4489 8619 -4618 8577 -4764 8538 -4908 8491
--5062 8441 -5224 8387 -5383 8339 -5563 8282 -5737 8226 -5923 8174 -6112 8114
--6308 8056 -6505 8005 -6708 7956 -6922 7906 -7126 7858 -7345 7812 -7559 7777
--7780 7744 -8003 7723 -8227 7705 -8452 7688 -8686 7684 -8922 7681 -9158 7696
--9398 7715 -9640 7738 -9884 7772 -10139 7820 -10387 7871 -10652 7938 -10919 8014
--11190 8102 -11470 8199 -11747 8308 -12035 8426 -12321 8558 -12619 8696
--12917 8850 -13219 9011 -13525 9188 -13835 9367 -14140 9552 -14443 9745
--14752 9949 -15048 10160 -15354 10378 -15649 10599 -15936 10820 -16202 11052
--16467 11283 -16728 11503 -16981 11714 -17260 11943 -17502 12169 -17719 12395
--17921 12610 -18102 12816 -18274 13022 -18434 13216 -18581 13399 -18709 13575
--18828 13744 -18931 13901 -19021 14048 -19089 14184 -19151 14311 -19203 14429
--19226 14536 -19244 14634 -19248 14717 -19242 14793 -19224 14858 -19191 14913
--19146 14958 -19087 14990 -19025 15011 -18954 15028 -18872 15030 -18780 15031
--18683 15020 -18567 14993 -18448 14964 -18329 14926 -18201 14877 -18074 14820
--17943 14758 -17801 14685 -17656 14612 -17507 14524 -17371 14433 -17228 14335
--17084 14233 -16944 14122 -16807 14009 -16673 13896 -16548 13776 -16427 13654
--16312 13525 -16206 13397 -16108 13264 -16015 13132 -15936 12999 -15866 12873
--15804 12740 -15760 12609 -15724 12480 -15703 12352 -15686 12228 -15681 12117
--15695 12011 -15712 11900 -15738 11781 -15777 11676 -15821 11583 -15871 11494
--15931 11411 -16000 11327 -16071 11256 -16141 11189 -16216 11128 -16287 11073
--16360 11028 -16436 10982 -16512 10942 -16581 10909 -16641 10880 -16697 10857
--16748 10839 -16790 10821 -16823 10802 -16850 10793 -16863 10786 -16866 10775
--16862 10769 -16837 10768 -16805 10764 -16760 10756 -16712 10755 -16645 10750
--16564 10741 -16480 10734 -16373 10724 -16265 10710 -16146 10702 -16017 10686
--15881 10668 -15735 10649 -15581 10626 -15419 10601 -15251 10575 -15084 10542
--14913 10508 -14734 10473 -14555 10433 -14371 10391 -14187 10349 -14004 10303
--13824 10258 -13639 10212 -13455 10162 -13276 10112 -13098 10058 -12922 10003
--12751 9952 -12581 9897 -12416 9846 -12248 9794 -12091 9738 -11943 9682
--11803 9626 -11646 9562 -11507 9503 -11374 9449 -11244 9401 -11124 9349
--11007 9303 -10893 9253 -10786 9204 -10687 9157 -10590 9112 -10502 9068
--10417 9025 -10337 8986 -10265 8949 -10199 8911 -10140 8876 -10085 8844
--10031 8816 -9984 8787 -9944 8765 -9913 8744 -9884 8724 -9859 8709 -9836 8696
--9817 8687 -9806 8677 -9798 8670 -9794 8670 -9790 8668 -9788 8668 -9787 8670
--9791 8678 -9800 8686 -9806 8694 -9814 8705 -9824 8720 -9829 8734 -9835 8748
--9846 8767 -9857 8787 -9864 8804 -9874 8824 -9873 8846 -9879 8865 -9881 8888
--9882 8909 -9885 8933 -9882 8957 -9877 8982 -9872 9007 -9864 9031 -9855 9059
--9842 9081 -9829 9107 -9813 9132 -9797 9157 -9777 9184 -9757 9211 -9735 9233
--9708 9260 -9679 9283 -9651 9310 -9620 9336 -9589 9363 -9551 9387 -9513 9412
--9473 9431 -9430 9455 -9386 9476 -9339 9495 -9290 9512 -9238 9530 -9182 9544
--9121 9559 -9061 9570 -8997 9582 -8931 9590 -8861 9596 -8789 9601 -8711 9604
--8631 9603 -8547 9603 -8463 9599 -8376 9595 -8287 9593 -8195 9582 -8099 9573
--7998 9561 -7901 9550 -7804 9539 -7711 9525 -7610 9513 -7508 9496 -7407 9481
--7308 9465 -7216 9449 -7127 9436 -7037 9419 -6951 9404 -6863 9390 -6785 9376
--6715 9361 -6655 9347 -6594 9334 -6539 9323 -6493 9310 -6455 9298 -6423 9287
--6402 9275 -6389 9263 -6384 9253 -6388 9244 -6397 9233 -6411 9222 -6431 9211
--6463 9201 -6508 9191 -6557 9178 -6609 9167 -6654 9159 -6698 9150 -6755 9138
--6824 9127 -6890 9117 -6950 9108 -6994 9100 -7031 9098 -7074 9093 -7117 9088
--7156 9084 -7177 9086 -7181 9091 -7168 9101 -7148 9111 -7121 9120 -7080 9137
--7022 9158 -6944 9182 -6853 9210 -6737 9244 -6607 9283 -6460 9326 -6301 9372
--6132 9418 -5952 9467 -5746 9526 -5516 9591 -5276 9656 -5033 9721 -4800 9784
--4565 9848 -4308 9917 -4030 9991 -3754 10065 -3492 10133 -3254 10191 -3027 10246
--2795 10304 -2555 10362 -2328 10415 -2128 10458 -1960 10489 -1816 10514
--1687 10530 -1571 10544 -1478 10548 -1416 10541 -1377 10525 -1368 10499
--1393 10458 -1448 10410 -1530 10349 -1630 10283 -1739 10215 -1861 10138
--2029 10042 -2239 9936 -2463 9823 -2683 9711 -2872 9607 -3065 9501 -3301 9379
--3562 9249 -3813 9120 -4032 9001 -4192 8903 -4324 8811 -4476 8714 -4631 8614
--4748 8524 -4802 8457 -4776 8416 -4696 8394 -4591 8375 -4460 8368 -4264 8381
--3991 8420 -3629 8489 -3193 8583 -2696 8697 -2134 8831 -1495 8992 -777 9178
-11 9391 879 9628 1844 9898 2891 10197 4015 10520 5199 10863 6416 11219
-7703 11599 9093 12013 10577 12460 12115 12922 13672 13396 15219 13864
-16801 14345 18481 14859 20232 15398 22003 15944 23749 16481 25429 17001
-27102 17518 28838 18057 30611 18608 32358 19153 34034 19675 35594 20163
-37101 20635 38623 21109 40129 21582 41567 22034 42887 22451 44064 22823
-45139 23167 46174 23496 47135 23808 47962 24078 48669 24303 49255 24497
-49708 24653 50021 24773 50198 24852 50247 24887 50139 24877 49867 24826
-49489 24734 48973 24602 48211 24424 47231 24181 46206 23887 45206 23587
-43975 23223 42245 22763 40153 22318 38170 21865 36542 21216 34880 20442
-32530 19819 29229 19324 25465 18577 22072 17351 19612 15962 17899 15021
-16077 14676 13054 14349 7998 13244 579 10909 -9011 7454 -20000 4000 -20000 3000
--21000 4000 -20000 4000 -20000 3000 -20000 4000 -20000 4000 -21000 4000
--20000 3000 -20000 4000 -20000 4000 -21000 4000 -20000 4000 -20000 4000
--21000 4000 -20000 4000 -20000 3000 -20000 4000 -21000 4000 -20000 3000
--20000 4000 -20000 3000 -20000 4000 -21000 3000
-5: 7916150 -6388869 -4094 8656 -4118 8634 -4136 8607 -4158 8582 -4179 8549
--4195 8514 -4215 8483 -4234 8449 -4254 8410 -4276 8380 -4296 8340 -4309 8309
--4320 8273 -4329 8241 -4337 8205 -4343 8171 -4346 8145 -4343 8113 -4336 8088
--4328 8062 -4316 8041 -4300 8015 -4274 8004 -4247 7986 -4221 7976 -4187 7968
--4147 7966 -4104 7964 -4056 7967 -4006 7972 -3957 7983 -3900 7996 -3842 8013
--3781 8031 -3718 8051 -3654 8073 -3601 8101 -3539 8131 -3473 8166 -3412 8202
--3353 8233 -3295 8264 -3250 8295 -3205 8332 -3159 8368 -3119 8404 -3092 8438
--3066 8465 -3047 8492 -3038 8520 -3034 8542 -3038 8564 -3055 8585 -3075 8596
--3116 8601 -3155 8605 -3209 8605 -3276 8597 -3324 8583 -3396 8568 -3487 8550
--3592 8523 -3716 8491 -3843 8462 -3990 8420 -4131 8377 -4292 8335 -4460 8279
--4631 8225 -4812 8167 -5000 8111 -5194 8055 -5395 7993 -5599 7932 -5809 7868
--6032 7810 -6250 7754 -6473 7703 -6711 7646 -6935 7598 -7176 7552 -7412 7513
--7656 7480 -7902 7458 -8148 7439 -8397 7426 -8648 7423 -8903 7425 -9166 7441
--9418 7464 -9682 7489 -9941 7534 -10218 7589 -10485 7644 -10767 7721 -11054 7802
--11345 7898 -11639 8013 -11937 8131 -12236 8261 -12548 8405 -12862 8560
--13175 8724 -13494 8905 -13818 9095 -14140 9293 -14459 9495 -14781 9706
--15104 9930 -15411 10157 -15726 10393 -16037 10635 -16328 10880 -16607 11125
--16877 11373 -17139 11618 -17405 11844 -17677 12094 -17926 12337 -18142 12578
--18342 12807 -18521 13030 -18695 13245 -18848 13452 -18988 13648 -19112 13837
--19223 14015 -19316 14176 -19395 14331 -19455 14477 -19503 14609 -19538 14731
--19559 14839 -19564 14938 -19550 15025 -19530 15098 -19500 15166 -19459 15221
--19396 15262 -19324 15292 -19249 15308 -19163 15323 -19074 15327 -18970 15318
--18858 15300 -18736 15270 -18604 15235 -18468 15191 -18341 15136 -18199 15071
--18056 15001 -17907 14922 -17755 14839 -17600 14748 -17451 14647 -17301 14543
--17158 14429 -17013 14312 -16867 14193 -16734 14071 -16608 13943 -16485 13810
--16370 13675 -16269 13540 -16170 13401 -16087 13263 -16010 13123 -15945 12990
--15892 12852 -15858 12716 -15834 12580 -15826 12447 -15821 12323 -15830 12204
--15859 12094 -15891 11983 -15940 11865 -15993 11758 -16058 11660 -16128 11570
--16203 11487 -16293 11411 -16379 11337 -16471 11273 -16571 11215 -16655 11164
--16752 11116 -16843 11075 -16935 11040 -17016 11011 -17097 10986 -17166 10968
--17227 10955 -17285 10939 -17326 10930 -17362 10922 -17383 10917 -17394 10913
--17389 10915 -17366 10916 -17336 10914 -17293 10911 -17239 10911 -17170 10908
--17085 10901 -16987 10895 -16874 10889 -16756 10873 -16630 10864 -16487 10849
--16337 10830 -16180 10807 -16006 10785 -15833 10755 -15649 10724 -15463 10689
--15275 10648 -15080 10608 -14880 10562 -14685 10517 -14479 10468 -14283 10414
--14084 10364 -13883 10308 -13683 10250 -13487 10194 -13292 10132 -13103 10070
--12921 10009 -12734 9945 -12557 9886 -12378 9825 -12211 9766 -12050 9698
--11902 9631 -11737 9563 -11589 9499 -11447 9437 -11312 9380 -11183 9324
--11060 9273 -10943 9214 -10830 9162 -10725 9111 -10628 9057 -10535 9011
--10450 8966 -10368 8923 -10294 8883 -10230 8842 -10170 8806 -10113 8771
--10061 8742 -10015 8714 -9978 8688 -9946 8669 -9918 8648 -9898 8636 -9876 8623
--9859 8614 -9850 8607 -9843 8600 -9843 8601 -9841 8602 -9844 8604 -9843 8609
--9854 8619 -9864 8630 -9876 8639 -9886 8653 -9896 8674 -9905 8690 -9918 8706
--9930 8728 -9945 8749 -9955 8772 -9964 8793 -9969 8819 -9978 8843 -9982 8870
--9986 8893 -9990 8919 -9987 8947 -9986 8974 -9980 9005 -9972 9031 -9964 9064
--9953 9087 -9939 9114 -9922 9142 -9904 9172 -9882 9203 -9858 9231 -9834 9257
--9804 9286 -9773 9311 -9739 9339 -9704 9366 -9665 9394 -9625 9421 -9579 9443
--9534 9466 -9483 9488 -9433 9511 -9378 9529 -9322 9547 -9262 9564 -9198 9578
--9131 9591 -9063 9602 -8990 9610 -8916 9619 -8839 9623 -8759 9625 -8675 9627
--8588 9622 -8496 9620 -8409 9613 -8314 9608 -8221 9603 -8123 9591 -8024 9575
--7920 9562 -7818 9548 -7722 9535 -7624 9518 -7525 9503 -7421 9484 -7319 9466
--7222 9449 -7132 9430 -7043 9415 -6958 9396 -6872 9380 -6788 9365 -6714 9349
--6649 9333 -6591 9319 -6536 9305 -6487 9293 -6444 9280 -6412 9266 -6387 9258
--6369 9245 -6362 9233 -6363 9225 -6372 9216 -6386 9205 -6406 9196 -6428 9186
--6465 9175 -6517 9167 -6568 9155 -6623 9145 -6671 9139 -6719 9130 -6776 9120
--6847 9109 -6917 9101 -6975 9091 -7021 9087 -7060 9084 -7101 9080 -7144 9076
--7182 9074 -7200 9075 -7203 9081 -7188 9091 -7167 9103 -7136 9111 -7092 9129
--7031 9149 -6949 9173 -6854 9204 -6736 9236 -6601 9276 -6449 9318 -6286 9364
--6114 9412 -5929 9460 -5718 9520 -5485 9583 -5242 9650 -4995 9714 -4759 9777
--4520 9839 -4260 9911 -3979 9984 -3700 10057 -3436 10126 -3194 10185 -2967 10239
--2733 10297 -2493 10356 -2265 10409 -2065 10451 -1895 10482 -1752 10508
--1625 10525 -1508 10538 -1416 10542 -1355 10536 -1320 10520 -1312 10494
--1339 10454 -1398 10406 -1482 10344 -1586 10279 -1696 10211 -1822 10134
--1995 10038 -2208 9932 -2437 9819 -2659 9708 -2851 9604 -3051 9497 -3288 9374
--3554 9246 -3811 9116 -4032 8998 -4196 8897 -4333 8806 -4489 8707 -4647 8607
--4769 8516 -4827 8448 -4804 8407 -4728 8383 -4627 8362 -4499 8354 -4308 8365
--4036 8401 -3679 8468 -3249 8561 -2755 8672 -2195 8804 -1560 8961 -847 9145
--63 9352 801 9587 1761 9853 2805 10148 3924 10466 5102 10805 6314 11156
-7595 11529 8982 11940 10458 12380 11992 12838 13543 13303 15083 13767
-16659 14241 18331 14749 20076 15280 21841 15818 23579 16351 25252 16861
-26919 17373 28648 17903 30411 18446 32151 18982 33819 19497 35376 19978
-36873 20441 38386 20908 39889 21373 41319 21816 42631 22225 43802 22591
-44869 22926 45899 23249 46862 23554 47684 23818 48387 24036 48963 24222
-49412 24372 49715 24486 49886 24559 49936 24589 49817 24575 49538 24517
-49154 24422 48639 24285 47874 24106 46881 23857 45835 23560 44816 23259
-43576 22893 41861 22432 39779 21983 37788 21519 36107 20879 34376 20125
-31970 19499 28661 18985 24925 18231 21558 17016 19056 15641 17225 14688
-15241 14295 12088 13922 7008 12836 -310 10658 -9666 7508 -20000 4000 -20000 3000
--20000 4000 -20000 4000 -20000 4000 -21000 3000 -20000 4000 -20000 4000
--20000 4000 -21000 4000 -20000 4000 -20000 4000 -20000 4000 -21000 4000
--20000 4000 -20000 4000 -21000 4000 -20000 3000 -20000 4000 -20000 4000
--21000 3000 -20000 4000 -20000 3000 -20000 4000
-6: 7952397 -6381141 -3937 8608 -3952 8583 -3970 8555 -3979 8523 -3992 8489
--4001 8450 -4013 8414 -4016 8377 -4025 8341 -4034 8305 -4041 8261 -4039 8229
--4039 8190 -4034 8152 -4024 8116 -4017 8078 -4002 8043 -3983 8010 -3963 7983
--3939 7955 -3909 7930 -3869 7903 -3830 7885 -3788 7862 -3744 7860 -3693 7848
--3635 7840 -3576 7834 -3517 7835 -3449 7840 -3386 7847 -3315 7857 -3243 7875
--3165 7891 -3095 7910 -3023 7933 -2959 7956 -2883 7988 -2810 8022 -2740 8054
--2677 8085 -2618 8118 -2566 8150 -2515 8183 -2475 8220 -2430 8257 -2400 8290
--2383 8316 -2365 8340 -2355 8367 -2361 8392 -2364 8408 -2391 8428 -2426 8437
--2468 8443 -2519 8447 -2587 8441 -2666 8429 -2740 8414 -2825 8400 -2930 8374
--3048 8340 -3182 8309 -3325 8274 -3491 8226 -3654 8181 -3828 8130 -4015 8070
--4211 8008 -4409 7949 -4617 7889 -4834 7829 -5058 7758 -5282 7691 -5524 7625
--5761 7563 -6005 7504 -6253 7446 -6505 7392 -6761 7339 -7018 7291 -7282 7249
--7544 7219 -7813 7189 -8084 7173 -8350 7163 -8618 7160 -8899 7166 -9182 7184
--9455 7213 -9732 7242 -10012 7294 -10306 7352 -10593 7421 -10894 7496
--11195 7592 -11509 7697 -11819 7819 -12135 7954 -12452 8101 -12778 8251
--13110 8420 -13440 8601 -13780 8796 -14114 9001 -14452 9218 -14793 9434
--15127 9667 -15458 9913 -15780 10159 -16111 10413 -16427 10674 -16735 10939
--17023 11204 -17294 11474 -17562 11732 -17834 11979 -18106 12250 -18353 12511
--18569 12766 -18770 13011 -18950 13248 -19120 13477 -19268 13698 -19396 13909
--19519 14106 -19622 14289 -19698 14461 -19774 14626 -19822 14775 -19858 14912
--19877 15036 -19888 15148 -19881 15249 -19854 15337 -19818 15413 -19771 15476
--19716 15531 -19642 15570 -19564 15596 -19472 15612 -19370 15624 -19268 15622
--19157 15608 -19029 15581 -18899 15550 -18755 15507 -18609 15456 -18468 15395
--18317 15324 -18167 15246 -18009 15161 -17849 15068 -17684 14969 -17533 14861
--17372 14750 -17223 14626 -17074 14504 -16920 14374 -16791 14244 -16662 14108
--16535 13968 -16420 13828 -16323 13683 -16229 13535 -16149 13389 -16077 13247
--16018 13105 -15976 12963 -15956 12821 -15942 12681 -15944 12542 -15954 12414
--15977 12293 -16020 12178 -16073 12065 -16141 11944 -16214 11837 -16300 11739
--16382 11649 -16480 11565 -16589 11490 -16700 11421 -16814 11356 -16930 11304
--17035 11254 -17151 11206 -17260 11176 -17369 11141 -17471 11115 -17564 11095
--17653 11084 -17725 11072 -17791 11066 -17848 11056 -17886 11055 -17919 11058
--17935 11058 -17934 11065 -17915 11068 -17881 11069 -17836 11073 -17778 11071
--17705 11072 -17620 11068 -17510 11066 -17390 11057 -17259 11045 -17120 11036
--16969 11017 -16800 10996 -16629 10971 -16443 10948 -16248 10914 -16048 10877
--15848 10837 -15637 10792 -15429 10749 -15210 10694 -14995 10643 -14776 10588
--14556 10527 -14338 10470 -14124 10407 -13906 10340 -13695 10275 -13485 10205
--13276 10134 -13083 10063 -12883 9994 -12695 9923 -12500 9855 -12321 9787
--12153 9714 -11994 9634 -11823 9561 -11664 9490 -11513 9423 -11372 9358
--11236 9295 -11110 9234 -10984 9174 -10870 9115 -10761 9058 -10659 9000
--10565 8951 -10478 8903 -10394 8855 -10320 8812 -10253 8771 -10197 8733
--10140 8695 -10085 8665 -10042 8637 -10005 8610 -9979 8590 -9950 8573
--9932 8560 -9913 8546 -9898 8541 -9889 8534 -9886 8529 -9889 8531 -9893 8532
--9894 8540 -9901 8549 -9911 8559 -9927 8572 -9942 8586 -9955 8605 -9967 8624
--9979 8646 -9996 8665 -10013 8690 -10030 8712 -10042 8740 -10056 8768
--10062 8792 -10073 8821 -10081 8849 -10085 8876 -10092 8910 -10090 8939
--10090 8970 -10085 9001 -10078 9035 -10072 9065 -10060 9095 -10045 9124
--10027 9153 -10007 9188 -9984 9219 -9955 9252 -9927 9279 -9896 9312 -9862 9339
--9824 9367 -9781 9397 -9739 9424 -9692 9451 -9641 9475 -9589 9499 -9534 9520
--9474 9544 -9411 9562 -9348 9580 -9281 9596 -9209 9609 -9135 9622 -9060 9629
--8980 9638 -8897 9643 -8811 9646 -8727 9647 -8636 9646 -8543 9640 -8445 9633
--8350 9625 -8251 9616 -8154 9607 -8052 9595 -7949 9577 -7842 9559 -7738 9544
--7639 9525 -7542 9509 -7441 9490 -7338 9470 -7235 9449 -7140 9427 -7052 9409
--6966 9391 -6884 9372 -6801 9354 -6720 9337 -6651 9320 -6590 9304 -6535 9290
--6486 9274 -6443 9262 -6405 9249 -6377 9237 -6359 9226 -6347 9214 -6344 9206
--6350 9197 -6366 9186 -6384 9180 -6407 9171 -6435 9160 -6476 9153 -6529 9144
--6587 9134 -6645 9125 -6695 9120 -6744 9112 -6805 9103 -6876 9094 -6946 9086
--7007 9079 -7052 9074 -7090 9072 -7131 9070 -7174 9067 -7207 9065 -7226 9067
--7227 9072 -7209 9084 -7185 9094 -7151 9105 -7103 9122 -7038 9144 -6954 9166
--6855 9196 -6732 9232 -6593 9270 -6437 9313 -6269 9357 -6094 9404 -5905 9454
--5690 9514 -5454 9576 -5204 9643 -4956 9708 -4716 9769 -4475 9833 -4211 9902
--3928 9976 -3647 10049 -3380 10118 -3137 10176 -2908 10231 -2673 10290
--2431 10348 -2204 10400 -2003 10444 -1835 10473 -1691 10499 -1564 10517
--1449 10531 -1360 10535 -1299 10527 -1266 10512 -1260 10487 -1290 10447
--1351 10399 -1440 10338 -1545 10273 -1658 10205 -1789 10127 -1963 10033
--2180 9927 -2415 9813 -2638 9703 -2836 9599 -3038 9492 -3280 9371 -3550 9240
--3810 9111 -4034 8991 -4203 8892 -4343 8799 -4503 8701 -4663 8599 -4789 8509
--4851 8439 -4832 8397 -4758 8371 -4663 8350 -4537 8340 -4348 8350 -4078 8385
--3728 8449 -3300 8538 -2809 8648 -2253 8777 -1624 8931 -911 9112 -133 9316
-725 9547 1681 9809 2722 10099 3835 10413 5009 10748 6215 11093 7488 11463
-8874 11867 10341 12301 11868 12753 13414 13213 14947 13668 16516 14138
-18182 14639 19918 15162 21675 15693 23405 16218 25073 16722 26731 17225
-28451 17748 30207 18282 31938 18811 33598 19317 35145 19791 36635 20245
-38143 20704 39636 21160 41058 21595 42364 21996 43525 22354 44589 22682
-45610 22996 46571 23295 47386 23551 48083 23762 48656 23940 49098 24084
-49390 24191 49560 24258 49603 24281 49478 24260 49185 24199 48800 24098
-48280 23957 47515 23772 46510 23522 45450 23220 44401 22916 43152 22546
-41443 22087 39377 21635 37377 21160 35662 20525 33869 19782 31419 19155
-28096 18637 24370 17889 21012 16687 18479 15326 16564 14362 14488 13937
-11288 13550 6285 12528 -727 10526 -9629 7566 -21000 3000 -20000 4000 -20000 4000
--20000 4000 -20000 4000 -20000 4000 -20000 4000 -21000 4000 -20000 4000
--20000 4000 -20000 4000 -21000 4000 -20000 4000 -20000 4000 -21000 4000
--20000 4000 -20000 4000 -20000 4000 -21000 4000 -20000 3000 -20000 4000
-7: 7988672 -6373415 -3774 8555 -3781 8531 -3791 8497 -3793 8462 -3800 8426
--3796 8384 -3796 8347 -3794 8307 -3785 8264 -3782 8224 -3774 8181 -3761 8139
--3746 8101 -3727 8063 -3703 8018 -3677 7981 -3644 7941 -3611 7904 -3575 7870
--3534 7845 -3485 7813 -3431 7785 -3371 7765 -3314 7740 -3251 7732 -3185 7720
--3112 7707 -3033 7703 -2957 7698 -2878 7702 -2802 7705 -2717 7716 -2630 7732
--2540 7748 -2457 7766 -2375 7788 -2298 7810 -2219 7842 -2135 7874 -2059 7903
--1989 7938 -1928 7966 -1871 8000 -1820 8034 -1774 8069 -1731 8106 -1705 8140
--1688 8165 -1673 8190 -1672 8214 -1678 8239 -1691 8255 -1725 8272 -1765 8283
--1817 8284 -1883 8287 -1962 8281 -2054 8265 -2143 8247 -2249 8231 -2370 8201
--2506 8165 -2649 8126 -2816 8084 -2993 8037 -3179 7986 -3370 7927 -3579 7864
--3796 7799 -4015 7733 -4246 7669 -4485 7597 -4732 7528 -4980 7453 -5244 7384
--5500 7317 -5771 7253 -6038 7192 -6313 7138 -6597 7080 -6882 7031 -7163 6987
--7448 6954 -7741 6925 -8026 6908 -8314 6899 -8610 6895 -8908 6908 -9204 6928
--9499 6956 -9801 6997 -10096 7049 -10405 7120 -10711 7191 -11031 7276
--11352 7379 -11675 7496 -12007 7628 -12337 7772 -12679 7935 -13020 8100
--13365 8279 -13720 8473 -14068 8686 -14423 8907 -14775 9140 -15130 9380
--15479 9628 -15817 9893 -16164 10161 -16498 10441 -16828 10715 -17150 11000
--17444 11288 -17722 11575 -17992 11853 -18272 12119 -18543 12410 -18788 12691
--19006 12963 -19205 13224 -19385 13475 -19548 13719 -19691 13952 -19817 14170
--19928 14380 -20021 14576 -20089 14756 -20150 14924 -20185 15079 -20212 15223
--20224 15346 -20218 15465 -20190 15565 -20156 15656 -20107 15731 -20040 15793
--19975 15841 -19889 15881 -19790 15905 -19692 15920 -19577 15925 -19460 15918
--19334 15901 -19198 15871 -19053 15828 -18901 15780 -18744 15724 -18590 15654
--18432 15576 -18274 15493 -18107 15398 -17937 15297 -17764 15189 -17601 15076
--17437 14954 -17282 14826 -17131 14691 -16973 14559 -16836 14416 -16703 14272
--16583 14126 -16468 13977 -16368 13824 -16282 13670 -16203 13517 -16139 13367
--16088 13220 -16056 13073 -16044 12923 -16047 12784 -16057 12637 -16082 12502
--16126 12378 -16182 12261 -16255 12145 -16341 12024 -16436 11914 -16538 11817
--16644 11731 -16765 11645 -16893 11569 -17027 11504 -17161 11444 -17294 11392
--17432 11346 -17562 11305 -17690 11272 -17816 11243 -17939 11226 -18048 11210
--18151 11201 -18241 11193 -18316 11194 -18380 11193 -18432 11193 -18471 11202
--18491 11208 -18494 11220 -18476 11227 -18444 11233 -18396 11240 -18338 11240
--18260 11243 -18163 11245 -18045 11240 -17917 11233 -17774 11225 -17623 11212
--17455 11191 -17276 11170 -17086 11145 -16881 11111 -16669 11076 -16453 11036
--16234 10991 -16006 10941 -15779 10889 -15539 10833 -15302 10770 -15066 10710
--14831 10643 -14593 10577 -14358 10504 -14125 10432 -13897 10355 -13671 10276
--13449 10196 -13236 10117 -13025 10036 -12825 9959 -12618 9883 -12428 9806
--12245 9723 -12076 9634 -11899 9555 -11731 9479 -11573 9404 -11425 9332
--11283 9262 -11149 9194 -11022 9127 -10903 9064 -10791 8999 -10685 8943
--10590 8885 -10500 8833 -10417 8784 -10342 8739 -10274 8695 -10214 8653
--10160 8618 -10109 8584 -10065 8556 -10029 8529 -10004 8510 -9981 8495
--9961 8480 -9945 8469 -9934 8464 -9924 8461 -9926 8456 -9934 8461 -9939 8466
--9945 8473 -9952 8485 -9968 8500 -9986 8515 -10005 8533 -10018 8554 -10036 8578
--10052 8601 -10071 8623 -10091 8652 -10111 8679 -10127 8711 -10144 8739
--10153 8767 -10164 8800 -10175 8832 -10183 8862 -10190 8898 -10192 8931
--10190 8967 -10187 9001 -10180 9035 -10175 9069 -10163 9101 -10146 9134
--10127 9168 -10104 9202 -10081 9238 -10048 9270 -10018 9302 -9983 9336
--9944 9366 -9902 9394 -9856 9425 -9806 9453 -9753 9481 -9697 9506 -9640 9529
--9576 9553 -9511 9575 -9441 9592 -9368 9610 -9294 9626 -9217 9637 -9136 9648
--9051 9655 -8963 9661 -8874 9666 -8782 9666 -8690 9664 -8595 9662 -8494 9653
--8392 9644 -8290 9633 -8187 9621 -8086 9608 -7982 9593 -7874 9574 -7766 9553
--7660 9536 -7559 9514 -7462 9495 -7362 9474 -7258 9452 -7158 9427 -7064 9406
--6976 9384 -6896 9365 -6816 9346 -6737 9325 -6662 9308 -6595 9290 -6539 9274
--6490 9257 -6446 9244 -6406 9231 -6376 9218 -6353 9207 -6341 9196 -6332 9185
--6337 9176 -6347 9169 -6367 9161 -6391 9153 -6418 9146 -6451 9136 -6495 9130
--6552 9124 -6613 9115 -6673 9107 -6723 9102 -6775 9097 -6840 9089 -6913 9080
--6980 9075 -7041 9068 -7088 9064 -7124 9063 -7164 9062 -7205 9059 -7237 9058
--7252 9061 -7251 9068 -7231 9077 -7203 9088 -7166 9100 -7115 9118 -7044 9139
--6957 9162 -6854 9192 -6728 9227 -6584 9266 -6423 9306 -6252 9352 -6071 9399
--5880 9449 -5661 9506 -5420 9570 -5168 9636 -4916 9701 -4672 9762 -4429 9825
--4163 9894 -3877 9966 -3593 10040 -3325 10109 -3081 10167 -2852 10222
--2613 10280 -2372 10338 -2145 10390 -1944 10433 -1777 10465 -1633 10488
--1508 10507 -1395 10521 -1307 10524 -1247 10518 -1215 10503 -1214 10476
--1245 10439 -1311 10389 -1400 10330 -1510 10264 -1625 10196 -1758 10121
--1939 10024 -2157 9920 -2394 9807 -2623 9695 -2824 9592 -3027 9487 -3274 9364
--3548 9233 -3812 9105 -4039 8984 -4210 8886 -4355 8792 -4516 8693 -4682 8592
--4810 8500 -4874 8431 -4858 8387 -4786 8360 -4697 8338 -4572 8327 -4387 8334
--4121 8369 -3772 8431 -3348 8517 -2859 8624 -2310 8751 -1683 8903 -974 9079
--200 9281 655 9508 1606 9766 2641 10052 3749 10362 4918 10691 6119 11033
-7386 11395 8764 11796 10227 12223 11746 12669 13284 13122 14811 13572
-16372 14035 18031 14528 19759 15045 21506 15568 23229 16085 24888 16582
-26538 17076 28250 17592 29997 18118 31717 18639 33367 19135 34908 19600
-36390 20047 37886 20498 39372 20945 40786 21372 42084 21763 43238 22113
-44293 22433 45306 22740 46262 23030 47074 23277 47763 23483 48330 23651
-48760 23789 49049 23887 49214 23948 49252 23964 49119 23938 48819 23871
-48422 23764 47898 23616 47133 23428 46127 23174 45042 22869 43972 22559
-42709 22186 41000 21730 38943 21274 36944 20793 35202 20159 33369 19419
-30879 18795 27543 18276 23818 17536 20454 16360 17902 15018 15937 14050
-13802 13599 10574 13196 5601 12172 -1334 10148 -10043 7149 -20000 4000
--20000 4000 -20000 4000 -20000 4000 -21000 4000 -20000 4000 -20000 4000
--20000 4000 -20000 4000 -21000 4000 -20000 4000 -20000 4000 -20000 4000
--21000 5000 -20000 4000 -20000 4000 -20000 4000 -21000 4000 -20000 4000
--20000 4000 -20000 3000 -20000 4000 -20000 3000 -20000 4000
-8: 8024975 -6365691 -3601 8497 -3607 8473 -3605 8439 -3597 8400 -3597 8358
--3582 8317 -3568 8275 -3554 8231 -3539 8183 -3518 8142 -3497 8094 -3470 8053
--3439 8009 -3409 7962 -3367 7918 -3322 7876 -3282 7835 -3226 7794 -3173 7758
--3110 7727 -3047 7693 -2980 7660 -2899 7638 -2823 7617 -2749 7598 -2662 7585
--2572 7569 -2476 7564 -2382 7561 -2293 7556 -2199 7559 -2104 7570 -2000 7588
--1901 7602 -1807 7614 -1710 7639 -1628 7660 -1539 7687 -1452 7725 -1366 7754
--1293 7784 -1222 7814 -1163 7848 -1115 7882 -1064 7916 -1024 7954 -1000 7985
--982 8017 -975 8040 -979 8061 -991 8084 -1015 8103 -1053 8118 -1106 8128
--1166 8130 -1239 8131 -1336 8119 -1443 8102 -1544 8084 -1665 8061 -1807 8032
--1961 7991 -2125 7945 -2308 7899 -2501 7854 -2709 7795 -2921 7729 -3150 7661
--3383 7591 -3629 7519 -3883 7450 -4143 7372 -4416 7295 -4690 7223 -4972 7146
--5260 7071 -5549 7004 -5841 6940 -6135 6883 -6447 6821 -6751 6770 -7058 6725
--7371 6688 -7680 6664 -7984 6641 -8300 6635 -8614 6633 -8928 6648 -9241 6670
--9559 6704 -9877 6750 -10195 6811 -10514 6880 -10844 6960 -11175 7058
--11515 7164 -11858 7293 -12202 7436 -12554 7591 -12910 7766 -13267 7943
--13633 8136 -14002 8346 -14366 8576 -14742 8813 -15104 9067 -15474 9323
--15836 9593 -16193 9872 -16551 10166 -16898 10466 -17241 10761 -17568 11063
--17869 11370 -18160 11685 -18432 11984 -18712 12266 -18991 12577 -19234 12876
--19449 13166 -19648 13442 -19825 13712 -19983 13966 -20118 14211 -20243 14443
--20341 14663 -20423 14868 -20485 15055 -20525 15231 -20557 15388 -20567 15540
--20563 15667 -20545 15787 -20505 15887 -20452 15978 -20389 16053 -20309 16114
--20233 16158 -20132 16196 -20016 16217 -19901 16229 -19777 16228 -19647 16217
--19510 16196 -19366 16158 -19202 16108 -19042 16056 -18873 15991 -18707 15915
--18543 15831 -18372 15737 -18198 15635 -18015 15525 -17839 15410 -17665 15291
--17500 15160 -17334 15023 -17180 14880 -17024 14740 -16877 14590 -16739 14438
--16619 14282 -16505 14124 -16408 13965 -16327 13803 -16252 13644 -16198 13486
--16151 13332 -16130 13180 -16126 13028 -16141 12878 -16168 12729 -16210 12595
--16272 12461 -16343 12342 -16434 12226 -16545 12103 -16656 11993 -16778 11893
--16912 11809 -17052 11726 -17201 11651 -17362 11587 -17521 11531 -17673 11482
--17829 11440 -17984 11403 -18135 11375 -18279 11350 -18420 11336 -18547 11326
--18667 11324 -18771 11323 -18853 11327 -18936 11332 -18990 11339 -19043 11354
--19064 11365 -19071 11380 -19056 11392 -19023 11405 -18976 11411 -18914 11418
--18825 11421 -18721 11428 -18596 11426 -18455 11415 -18301 11410 -18135 11395
--17954 11375 -17758 11351 -17551 11321 -17325 11285 -17097 11243 -16858 11200
--16625 11148 -16374 11094 -16128 11036 -15869 10970 -15609 10904 -15355 10833
--15100 10759 -14846 10684 -14588 10601 -14339 10523 -14094 10434 -13852 10346
--13612 10255 -13386 10166 -13162 10078 -12943 9994 -12729 9909 -12524 9820
--12329 9728 -12154 9632 -11966 9543 -11789 9461 -11626 9380 -11471 9300
--11322 9224 -11182 9151 -11052 9076 -10928 9007 -10815 8939 -10707 8876
--10608 8816 -10518 8760 -10432 8709 -10358 8660 -10289 8615 -10229 8573
--10177 8533 -10127 8501 -10084 8472 -10048 8447 -10025 8429 -10006 8411
--9987 8398 -9973 8390 -9963 8386 -9960 8385 -9964 8384 -9971 8390 -9983 8396
--9991 8409 -10002 8421 -10018 8439 -10041 8459 -10062 8480 -10082 8505
--10100 8529 -10120 8556 -10142 8584 -10167 8615 -10188 8647 -10209 8679
--10226 8711 -10239 8746 -10251 8779 -10266 8816 -10277 8850 -10286 8888
--10288 8924 -10287 8963 -10284 9000 -10279 9038 -10272 9074 -10261 9109
--10242 9145 -10221 9182 -10197 9218 -10169 9254 -10140 9290 -10104 9323
--10064 9358 -10020 9391 -9973 9420 -9923 9450 -9868 9482 -9809 9510 -9749 9534
--9683 9558 -9614 9582 -9540 9602 -9463 9621 -9385 9638 -9302 9653 -9219 9662
--9130 9671 -9039 9677 -8942 9682 -8847 9684 -8749 9683 -8652 9677 -8550 9673
--8443 9663 -8337 9649 -8229 9636 -8123 9622 -8018 9607 -7912 9589 -7801 9567
--7693 9543 -7584 9522 -7484 9500 -7386 9478 -7285 9454 -7184 9429 -7086 9404
--6996 9380 -6910 9358 -6832 9337 -6754 9316 -6680 9296 -6612 9276 -6550 9259
--6498 9241 -6454 9226 -6414 9211 -6382 9199 -6357 9188 -6340 9177 -6331 9165
--6329 9156 -6337 9148 -6355 9141 -6378 9136 -6408 9127 -6440 9122 -6475 9115
--6521 9110 -6583 9105 -6647 9098 -6708 9092 -6762 9087 -6814 9083 -6880 9077
--6951 9069 -7019 9066 -7082 9059 -7126 9058 -7162 9057 -7201 9056 -7238 9053
--7268 9054 -7281 9056 -7277 9063 -7252 9074 -7222 9085 -7180 9099 -7126 9115
--7051 9136 -6958 9160 -6852 9189 -6723 9224 -6572 9261 -6409 9302 -6233 9348
--6047 9393 -5854 9443 -5632 9500 -5387 9564 -5129 9629 -4876 9694 -4628 9754
--4383 9817 -4114 9885 -3827 9957 -3540 10030 -3271 10098 -3027 10157 -2795 10211
--2558 10268 -2316 10327 -2088 10379 -1889 10421 -1721 10452 -1581 10477
--1454 10495 -1344 10508 -1257 10512 -1202 10505 -1171 10491 -1171 10465
--1205 10427 -1274 10378 -1366 10319 -1478 10254 -1598 10186 -1735 10110
--1917 10016 -2138 9909 -2379 9799 -2612 9687 -2814 9583 -3023 9479 -3272 9356
--3547 9225 -3815 9097 -4047 8978 -4219 8878 -4367 8785 -4532 8685 -4699 8584
--4830 8492 -4896 8421 -4884 8377 -4816 8349 -4727 8327 -4605 8313 -4423 8320
--4161 8353 -3814 8412 -3392 8498 -2909 8601 -2361 8726 -1737 8875 -1035 9048
--264 9247 588 9469 1533 9724 2563 10006 3667 10311 4830 10637 6025 10972
-7286 11330 8656 11725 10114 12145 11624 12586 13156 13033 14675 13476
-16228 13932 17877 14417 19597 14927 21336 15444 23051 15952 24697 16442
-26337 16927 28043 17435 29779 17954 31491 18464 33131 18953 34662 19408
-36133 19848 37622 20290 39098 20728 40503 21145 41792 21529 42937 21869
-43985 22181 44989 22478 45936 22760 46740 22998 47421 23196 47985 23358
-48411 23486 48691 23578 48849 23630 48883 23640 48741 23606 48437 23535
-48029 23420 47498 23267 46734 23073 45720 22815 44628 22509 43531 22191
-42253 21814 40540 21360 38485 20904 36487 20420 34733 19785 32875 19048
-30354 18423 27006 17901 23276 17173 19914 16030 17345 14718 15354 13756
-13194 13297 9963 12898 5024 11931 -1833 10075 -10429 7441 -20000 4000
--20000 4000 -20000 4000 -20000 4000 -20000 4000 -20000 4000 -20000 4000
--21000 4000 -20000 4000 -20000 4000 -20000 5000 -20000 4000 -21000 4000
--20000 4000 -20000 5000 -20000 4000 -21000 4000 -20000 4000 -20000 4000
--20000 4000 -20000 4000 -21000 3000 -20000 4000 -20000 3000
-9: 8061304 -6357968 -3420 8435 -3411 8412 -3411 8376 -3394 8331 -3382 8286
--3363 8244 -3331 8202 -3306 8152 -3277 8102 -3250 8056 -3208 8008 -3168 7959
--3117 7908 -3077 7859 -3014 7814 -2958 7768 -2897 7722 -2829 7682 -2755 7638
--2678 7602 -2597 7566 -2508 7535 -2413 7507 -2319 7485 -2225 7459 -2124 7446
--2017 7429 -1907 7423 -1796 7413 -1691 7407 -1582 7408 -1471 7421 -1359 7436
--1250 7447 -1141 7463 -1037 7486 -943 7503 -844 7531 -751 7570 -659 7602
--583 7629 -507 7661 -447 7695 -396 7723 -346 7762 -311 7801 -279 7834 -272 7863
--270 7887 -281 7911 -299 7934 -332 7951 -377 7965 -441 7978 -515 7978 -601 7975
--709 7961 -828 7942 -944 7921 -1084 7897 -1240 7862 -1420 7820 -1603 7769
--1804 7718 -2011 7673 -2243 7603 -2479 7539 -2726 7460 -2981 7386 -3254 7308
--3533 7235 -3811 7153 -4109 7070 -4410 6990 -4717 6905 -5027 6833 -5339 6760
--5660 6691 -5979 6625 -6308 6566 -6637 6508 -6972 6463 -7306 6427 -7629 6399
--7967 6376 -8294 6372 -8630 6371 -8967 6390 -9296 6411 -9630 6453 -9968 6503
--10305 6567 -10642 6644 -10985 6730 -11331 6834 -11687 6955 -12046 7087
--12408 7240 -12775 7412 -13149 7592 -13524 7788 -13906 7990 -14292 8219
--14673 8464 -15062 8722 -15445 8989 -15826 9271 -16207 9556 -16575 9860
--16947 10172 -17308 10490 -17661 10806 -17992 11133 -18311 11465 -18600 11793
--18884 12114 -19165 12418 -19436 12748 -19688 13070 -19900 13375 -20098 13670
--20273 13952 -20425 14224 -20555 14480 -20669 14724 -20757 14951 -20829 15168
--20881 15361 -20909 15545 -20928 15708 -20923 15860 -20902 15995 -20870 16111
--20817 16217 -20749 16304 -20665 16380 -20578 16439 -20482 16482 -20367 16512
--20240 16531 -20110 16538 -19973 16536 -19831 16519 -19680 16491 -19519 16445
--19352 16391 -19175 16330 -19000 16259 -18822 16175 -18645 16083 -18466 15982
--18282 15873 -18087 15754 -17909 15634 -17725 15502 -17553 15365 -17383 15219
--17221 15072 -17061 14922 -16908 14763 -16771 14600 -16651 14437 -16539 14272
--16443 14101 -16362 13933 -16297 13770 -16243 13604 -16207 13444 -16199 13287
--16203 13126 -16231 12973 -16276 12818 -16333 12683 -16412 12547 -16506 12426
--16612 12306 -16740 12179 -16882 12072 -17029 11971 -17177 11886 -17344 11807
--17515 11733 -17701 11671 -17885 11619 -18066 11571 -18242 11533 -18417 11504
--18590 11478 -18756 11460 -18916 11450 -19063 11448 -19197 11451 -19312 11458
--19412 11464 -19505 11478 -19574 11491 -19628 11512 -19656 11529 -19666 11546
--19656 11565 -19620 11582 -19570 11592 -19504 11603 -19411 11610 -19295 11618
--19163 11617 -19005 11608 -18839 11602 -18655 11586 -18462 11565 -18247 11536
--18023 11505 -17776 11464 -17529 11420 -17274 11369 -17012 11312 -16744 11251
--16475 11185 -16196 11113 -15920 11039 -15641 10959 -15365 10875 -15090 10791
--14817 10699 -14548 10610 -14283 10513 -14025 10414 -13772 10313 -13525 10213
--13289 10118 -13057 10022 -12829 9929 -12612 9830 -12408 9731 -12222 9626
--12025 9530 -11842 9439 -11668 9349 -11509 9263 -11355 9179 -11210 9099
--11073 9021 -10946 8946 -10830 8871 -10724 8807 -10622 8741 -10528 8685
--10441 8627 -10368 8578 -10299 8531 -10239 8486 -10188 8448 -10139 8415
--10098 8385 -10064 8361 -10042 8342 -10025 8327 -10010 8316 -9997 8309
--9988 8304 -9988 8307 -9999 8311 -10006 8317 -10020 8326 -10033 8342 -10046 8359
--10065 8380 -10089 8403 -10118 8428 -10139 8456 -10162 8479 -10184 8512
--10210 8546 -10236 8579 -10264 8614 -10286 8650 -10305 8685 -10320 8725
--10335 8760 -10352 8801 -10366 8839 -10377 8878 -10379 8918 -10380 8959
--10375 9002 -10375 9041 -10366 9079 -10350 9118 -10331 9157 -10312 9194
--10284 9233 -10254 9272 -10223 9309 -10182 9344 -10138 9379 -10091 9413
--10040 9445 -9982 9476 -9923 9507 -9860 9536 -9792 9563 -9721 9585 -9643 9607
--9565 9628 -9480 9648 -9395 9662 -9306 9675 -9214 9684 -9121 9691 -9020 9695
--8917 9698 -8815 9698 -8714 9695 -8611 9688 -8502 9680 -8390 9666 -8279 9651
--8169 9635 -8060 9620 -7952 9602 -7843 9580 -7731 9554 -7619 9531 -7512 9505
--7413 9481 -7313 9456 -7215 9430 -7116 9405 -7021 9376 -6931 9352 -6852 9329
--6778 9307 -6703 9284 -6633 9263 -6572 9243 -6513 9225 -6467 9208 -6427 9193
--6394 9179 -6369 9166 -6348 9157 -6338 9145 -6333 9137 -6335 9127 -6349 9120
--6373 9115 -6401 9110 -6435 9105 -6469 9100 -6509 9096 -6560 9091 -6622 9087
--6689 9083 -6751 9079 -6807 9076 -6860 9072 -6924 9067 -6997 9063 -7065 9057
--7125 9053 -7169 9053 -7205 9054 -7239 9052 -7274 9050 -7301 9051 -7311 9056
--7302 9062 -7276 9074 -7240 9085 -7195 9098 -7135 9114 -7058 9135 -6961 9158
--6849 9188 -6716 9221 -6560 9259 -6393 9299 -6212 9344 -6023 9388 -5826 9439
--5601 9496 -5352 9557 -5092 9622 -4832 9685 -4585 9746 -4336 9808 -4066 9875
--3777 9948 -3489 10019 -3219 10087 -2973 10144 -2742 10198 -2505 10255
--2262 10313 -2034 10366 -1836 10408 -1671 10438 -1531 10462 -1405 10480
--1297 10494 -1213 10497 -1159 10492 -1133 10476 -1134 10452 -1170 10413
--1242 10364 -1337 10305 -1453 10242 -1576 10173 -1715 10097 -1900 10005
--2125 9898 -2369 9787 -2605 9677 -2809 9574 -3021 9468 -3273 9347 -3551 9217
--3821 9087 -4055 8970 -4232 8869 -4380 8777 -4547 8677 -4716 8575 -4851 8484
--4919 8412 -4907 8366 -4845 8339 -4754 8314 -4638 8301 -4457 8306 -4198 8337
--3853 8395 -3436 8477 -2953 8580 -2410 8702 -1789 8847 -1090 9019 -325 9214
-523 9432 1465 9683 2489 9961 3587 10262 4744 10581 5932 10913 7189 11266
-8551 11654 10001 12069 11504 12503 13028 12944 14538 13381 16083 13828
-17722 14308 19435 14810 21159 15320 22866 15819 24505 16300 26134 16779
-27829 17278 29556 17787 31257 18289 32886 18770 34407 19216 35869 19647
-37347 20080 38813 20508 40209 20917 41487 21291 42623 21623 43665 21926
-44658 22213 45595 22485 46393 22715 47066 22905 47623 23059 48043 23178
-48318 23262 48469 23307 48492 23308 48349 23268 48038 23191 47620 23069
-47083 22908 46318 22710 45303 22448 44196 22140 43085 21816 41792 21433
-40073 20980 38017 20525 36020 20042 34254 19408 32381 18675 29842 18045
-26484 17517 22755 16807 19401 15697 16828 14421 14832 13478 12671 13021
-9463 12630 4626 11681 -2012 9812 -10201 7046 -20000 4000 -20000 4000 -20000 4000
--20000 5000 -20000 4000 -21000 4000 -20000 4000 -20000 4000 -20000 5000
--20000 4000 -20000 4000 -21000 4000 -20000 5000 -20000 4000 -20000 4000
--21000 5000 -20000 4000 -20000 4000 -20000 4000 -20000 4000 -21000 4000
-10: 8097672 -6350249 -3231 8372 -3213 8347 -3206 8308 -3178 8257 -3158 8214
--3126 8169 -3087 8123 -3047 8069 -3007 8018 -2960 7965 -2909 7912 -2854 7860
--2788 7807 -2728 7756 -2654 7705 -2579 7653 -2494 7604 -2417 7560 -2322 7517
--2231 7473 -2134 7435 -2021 7403 -1912 7372 -1802 7345 -1685 7318 -1569 7299
--1448 7282 -1323 7273 -1194 7263 -1072 7254 -955 7255 -827 7263 -700 7277
--579 7290 -459 7308 -351 7327 -243 7346 -135 7373 -39 7407 54 7442 145 7472
-216 7505 280 7536 334 7568 379 7608 416 7645 443 7683 448 7713 441 7736
-425 7762 398 7783 356 7800 301 7816 229 7824 139 7825 41 7823 -81 7807 -220 7786
--348 7761 -506 7739 -679 7698 -880 7650 -1079 7600 -1300 7545 -1533 7489
--1783 7419 -2045 7345 -2315 7268 -2589 7185 -2886 7102 -3189 7023 -3494 6938
--3816 6850 -4140 6763 -4472 6670 -4812 6593 -5144 6517 -5491 6443 -5834 6373
--6189 6310 -6544 6250 -6902 6203 -7247 6166 -7613 6136 -7952 6117 -8308 6108
--8666 6111 -9018 6130 -9362 6155 -9721 6198 -10076 6256 -10424 6330 -10775 6404
--11138 6498 -11499 6613 -11868 6742 -12246 6884 -12626 7048 -13007 7227
--13394 7417 -13786 7627 -14185 7848 -14588 8090 -14991 8352 -15391 8628
--15790 8916 -16188 9214 -16580 9522 -16968 9845 -17350 10179 -17721 10519
--18088 10860 -18433 11203 -18755 11557 -19050 11908 -19342 12249 -19625 12573
--19898 12929 -20149 13270 -20362 13591 -20560 13902 -20723 14205 -20870 14486
--20995 14759 -21100 15012 -21183 15250 -21237 15473 -21277 15678 -21292 15864
--21297 16035 -21280 16188 -21243 16325 -21193 16445 -21129 16547 -21040 16635
--20941 16709 -20841 16766 -20729 16806 -20596 16836 -20461 16849 -20313 16849
--20165 16842 -20008 16822 -19846 16786 -19669 16736 -19490 16672 -19304 16604
--19118 16527 -18936 16436 -18742 16338 -18555 16225 -18358 16112 -18160 15982
--17971 15855 -17780 15715 -17600 15569 -17425 15416 -17254 15259 -17092 15100
--16935 14932 -16795 14763 -16670 14592 -16562 14416 -16470 14239 -16394 14065
--16329 13892 -16284 13722 -16255 13553 -16255 13391 -16277 13222 -16319 13068
--16376 12908 -16452 12767 -16552 12632 -16663 12505 -16785 12384 -16942 12259
--17109 12151 -17274 12046 -17446 11962 -17638 11886 -17842 11816 -18051 11756
--18256 11709 -18465 11663 -18666 11628 -18860 11606 -19056 11586 -19249 11574
--19429 11570 -19594 11572 -19745 11583 -19875 11593 -19991 11608 -20091 11630
--20169 11648 -20233 11674 -20269 11701 -20285 11722 -20267 11745 -20234 11766
--20187 11781 -20110 11798 -20011 11809 -19886 11814 -19741 11817 -19575 11809
--19385 11802 -19187 11784 -18979 11761 -18745 11733 -18496 11694 -18235 11650
--17964 11600 -17689 11545 -17406 11480 -17118 11412 -16824 11338 -16520 11258
--16221 11174 -15927 11084 -15628 10995 -15328 10899 -15036 10798 -14750 10698
--14468 10591 -14192 10478 -13920 10369 -13659 10258 -13407 10152 -13163 10049
--12922 9946 -12691 9837 -12478 9727 -12283 9610 -12074 9514 -11885 9411
--11704 9313 -11538 9220 -11379 9129 -11230 9043 -11088 8960 -10957 8878
--10839 8800 -10732 8731 -10627 8663 -10534 8601 -10445 8543 -10368 8491
--10304 8442 -10246 8398 -10195 8357 -10146 8324 -10105 8297 -10076 8273
--10054 8254 -10037 8240 -10027 8230 -10015 8224 -10011 8223 -10014 8229
--10027 8236 -10036 8243 -10053 8256 -10067 8275 -10088 8296 -10106 8320
--10135 8347 -10168 8374 -10193 8405 -10219 8435 -10243 8471 -10273 8506
--10302 8544 -10334 8582 -10357 8621 -10382 8662 -10396 8702 -10415 8743
--10433 8786 -10450 8829 -10461 8872 -10463 8912 -10469 8957 -10464 9000
--10462 9044 -10453 9086 -10436 9128 -10418 9168 -10394 9208 -10366 9248
--10332 9290 -10297 9328 -10254 9363 -10206 9400 -10155 9435 -10098 9467
--10038 9501 -9972 9532 -9902 9562 -9827 9587 -9752 9609 -9668 9631 -9582 9653
--9490 9669 -9398 9682 -9302 9694 -9206 9703 -9105 9708 -8998 9710 -8889 9711
--8780 9706 -8676 9702 -8564 9694 -8452 9682 -8336 9666 -8221 9647 -8106 9631
--7997 9612 -7886 9591 -7775 9567 -7662 9539 -7550 9511 -7446 9484 -7345 9459
--7246 9431 -7151 9403 -7054 9377 -6962 9346 -6879 9320 -6801 9296 -6730 9274
--6662 9251 -6598 9228 -6539 9207 -6489 9190 -6446 9173 -6414 9160 -6386 9146
--6365 9133 -6351 9125 -6347 9115 -6347 9106 -6355 9099 -6372 9094 -6402 9090
--6435 9087 -6473 9084 -6510 9080 -6552 9077 -6607 9075 -6671 9072 -6738 9071
--6803 9068 -6859 9066 -6913 9065 -6976 9061 -7049 9057 -7116 9051 -7174 9051
--7215 9051 -7248 9053 -7280 9053 -7313 9049 -7337 9052 -7343 9056 -7330 9065
--7298 9075 -7260 9086 -7210 9100 -7146 9115 -7062 9135 -6962 9160 -6846 9188
--6706 9220 -6548 9258 -6374 9298 -6190 9340 -5998 9384 -5798 9435 -5568 9491
--5314 9552 -5053 9614 -4791 9677 -4542 9737 -4289 9797 -4019 9865 -3728 9937
--3439 10008 -3168 10073 -2920 10132 -2690 10183 -2453 10241 -2211 10298
--1986 10350 -1788 10391 -1622 10422 -1485 10446 -1362 10464 -1255 10476
--1174 10481 -1123 10474 -1099 10460 -1102 10434 -1142 10397 -1215 10349
--1314 10289 -1434 10226 -1558 10159 -1700 10082 -1890 9991 -2117 9885
--2362 9773 -2600 9664 -2811 9562 -3022 9457 -3278 9336 -3557 9207 -3831 9078
--4066 8960 -4245 8860 -4395 8768 -4564 8667 -4735 8566 -4870 8474 -4942 8402
--4932 8357 -4870 8328 -4783 8302 -4666 8288 -4489 8293 -4231 8321 -3891 8378
--3475 8459 -2996 8559 -2456 8678 -1836 8821 -1144 8990 -380 9180 462 9397
-1397 9644 2419 9916 3511 10213 4661 10528 5844 10855 7092 11201 8446 11585
-9891 11993 11383 12422 12899 12856 14401 13285 15937 13726 17567 14199
-19268 14693 20983 15194 22677 15686 24307 16160 25926 16630 27609 17121
-29326 17620 31015 18115 32632 18585 34143 19022 35594 19445 37062 19868
-38519 20288 39903 20686 41171 21051 42298 21374 43331 21667 44316 21946
-45242 22208 46029 22429 46698 22609 47247 22756 47662 22866 47926 22941
-48072 22977 48092 22972 47943 22924 47623 22839 47201 22712 46653 22544
-45888 22338 44874 22073 43756 21764 42637 21434 41331 21047 39601 20593
-37549 20139 35553 19658 33772 19031 31887 18302 29338 17665 25986 17138
-22269 16441 18921 15362 16357 14125 14361 13208 12211 12772 9038 12410
-4238 11527 -2395 9812 -10692 7344 -20000 4000 -20000 4000 -20000 4000
--20000 4000 -20000 5000 -20000 4000 -20000 4000 -20000 4000 -20000 5000
--21000 4000 -20000 4000 -20000 5000 -20000 4000 -20000 5000 -21000 4000
--20000 4000 -20000 4000 -20000 5000 -20000 4000 -20000 4000 -21000 4000
--20000 4000 -20000 3000 -19000 4000
-11: 8134081 -6342539 -3034 8308 -3011 8279 -2986 8237 -2958 8183 -2921 8139
--2881 8088 -2830 8037 -2777 7982 -2725 7930 -2661 7869 -2599 7812 -2523 7757
--2450 7700 -2366 7646 -2278 7593 -2185 7537 -2083 7482 -1987 7433 -1879 7388
--1769 7343 -1648 7301 -1518 7262 -1394 7229 -1265 7198 -1135 7171 -1002 7148
--863 7132 -724 7117 -573 7106 -442 7098 -307 7092 -170 7104 -27 7114 105 7131
-236 7148 353 7161 469 7182 582 7210 687 7242 787 7280 878 7312 952 7344
-1011 7378 1077 7413 1113 7452 1151 7491 1171 7530 1172 7562 1161 7586 1138 7610
-1101 7633 1049 7652 980 7667 895 7675 800 7676 685 7673 546 7654 392 7634
-243 7610 70 7585 -123 7540 -338 7488 -565 7432 -806 7375 -1062 7311 -1332 7240
--1613 7160 -1911 7080 -2210 6991 -2526 6899 -2862 6819 -3186 6724 -3530 6633
--3884 6537 -4237 6441 -4610 6355 -4970 6276 -5338 6196 -5709 6125 -6086 6059
--6471 5994 -6833 5946 -7232 5906 -7584 5876 -7974 5863 -8346 5847 -8702 5850
--9076 5867 -9456 5901 -9828 5947 -10190 6010 -10558 6086 -10925 6166 -11300 6270
--11679 6387 -12062 6528 -12455 6679 -12849 6855 -13245 7043 -13648 7244
--14057 7467 -14471 7703 -14894 7962 -15306 8236 -15728 8535 -16144 8844
--16556 9159 -16965 9487 -17368 9828 -17760 10187 -18144 10549 -18525 10912
--18877 11276 -19204 11655 -19514 12030 -19805 12388 -20095 12737 -20370 13114
--20617 13471 -20837 13815 -21024 14146 -21185 14460 -21323 14761 -21439 15044
--21536 15309 -21609 15554 -21650 15788 -21674 16000 -21679 16193 -21663 16368
--21635 16522 -21587 16662 -21518 16780 -21432 16884 -21331 16972 -21216 17041
--21100 17098 -20969 17134 -20823 17159 -20675 17169 -20510 17163 -20350 17149
--20177 17123 -20005 17081 -19818 17026 -19625 16955 -19425 16878 -19231 16793
--19040 16699 -18835 16591 -18639 16470 -18432 16347 -18227 16211 -18024 16075
--17826 15926 -17643 15772 -17462 15610 -17283 15446 -17113 15276 -16950 15102
--16813 14924 -16685 14742 -16576 14559 -16484 14378 -16414 14195 -16353 14014
--16318 13835 -16299 13662 -16302 13492 -16344 13318 -16404 13158 -16470 12998
--16567 12850 -16682 12713 -16821 12585 -16955 12459 -17143 12335 -17328 12226
--17519 12127 -17724 12039 -17941 11964 -18169 11897 -18408 11842 -18637 11795
--18875 11757 -19096 11729 -19319 11710 -19537 11696 -19755 11693 -19957 11692
--20139 11703 -20309 11717 -20459 11735 -20585 11759 -20699 11786 -20788 11813
--20856 11846 -20900 11878 -20922 11903 -20904 11932 -20870 11961 -20814 11980
--20732 12001 -20627 12013 -20493 12021 -20333 12025 -20151 12016 -19950 12009
--19733 11993 -19504 11965 -19250 11933 -18978 11891 -18698 11845 -18406 11786
--18108 11725 -17803 11652 -17486 11577 -17171 11494 -16847 11408 -16523 11313
--16205 11213 -15882 11111 -15562 11008 -15250 10897 -14945 10783 -14645 10665
--14347 10546 -14060 10422 -13784 10302 -13519 10183 -13259 10068 -13006 9957
--12761 9840 -12538 9720 -12334 9595 -12116 9486 -11918 9377 -11731 9271
--11559 9169 -11394 9076 -11242 8980 -11095 8891 -10961 8805 -10841 8723
--10730 8651 -10628 8579 -10532 8514 -10440 8452 -10365 8398 -10302 8350
--10244 8305 -10195 8265 -10148 8230 -10108 8202 -10082 8181 -10059 8165
--10047 8153 -10038 8142 -10028 8137 -10028 8141 -10034 8149 -10047 8159
--10063 8170 -10082 8186 -10100 8208 -10120 8233 -10147 8260 -10178 8289
--10210 8321 -10242 8354 -10271 8391 -10299 8430 -10329 8468 -10363 8509
--10397 8550 -10425 8595 -10449 8637 -10469 8682 -10489 8729 -10509 8771
--10528 8818 -10541 8864 -10544 8909 -10549 8957 -10546 9002 -10541 9046
--10534 9092 -10519 9136 -10496 9180 -10470 9222 -10441 9264 -10404 9308
--10364 9347 -10318 9381 -10269 9420 -10211 9457 -10150 9491 -10085 9524
--10012 9554 -9938 9585 -9856 9609 -9775 9633 -9686 9652 -9592 9672 -9494 9687
--9394 9700 -9293 9709 -9191 9716 -9083 9721 -8970 9720 -8856 9718 -8743 9711
--8630 9705 -8517 9695 -8402 9680 -8279 9661 -8162 9639 -8046 9620 -7932 9599
--7822 9575 -7710 9548 -7596 9518 -7487 9488 -7381 9460 -7281 9432 -7187 9401
--7093 9373 -7000 9344 -6913 9313 -6833 9286 -6759 9260 -6692 9237 -6632 9214
--6571 9192 -6520 9172 -6476 9153 -6438 9138 -6411 9124 -6389 9111 -6375 9100
--6368 9093 -6368 9084 -6373 9079 -6388 9072 -6409 9068 -6441 9066 -6479 9065
--6523 9065 -6561 9064 -6606 9061 -6663 9059 -6730 9061 -6797 9060 -6862 9060
--6920 9060 -6974 9058 -7036 9057 -7106 9054 -7172 9052 -7228 9050 -7267 9053
--7294 9054 -7325 9055 -7354 9053 -7373 9056 -7376 9060 -7358 9069 -7324 9080
--7280 9089 -7224 9103 -7155 9118 -7066 9138 -6962 9162 -6841 9189 -6697 9221
--6534 9258 -6355 9297 -6168 9338 -5971 9383 -5767 9431 -5534 9486 -5278 9546
--5013 9607 -4749 9668 -4496 9728 -4245 9787 -3972 9854 -3680 9924 -3391 9995
--3118 10058 -2869 10117 -2640 10169 -2405 10225 -2164 10280 -1938 10331
--1744 10374 -1579 10403 -1444 10427 -1322 10444 -1219 10457 -1140 10462
--1093 10455 -1070 10441 -1076 10415 -1120 10377 -1195 10329 -1297 10273
--1419 10208 -1546 10140 -1692 10066 -1883 9974 -2115 9869 -2361 9759 -2601 9649
--2815 9549 -3029 9444 -3285 9324 -3568 9195 -3842 9066 -4079 8949 -4258 8851
--4412 8757 -4582 8658 -4755 8555 -4891 8465 -4964 8392 -4955 8346 -4893 8317
--4810 8291 -4694 8276 -4519 8279 -4263 8306 -3924 8363 -3512 8440 -3034 8539
--2498 8654 -1882 8796 -1192 8962 -433 9148 404 9362 1335 9605 2351 9873
-3436 10164 4582 10476 5757 10796 6997 11139 8345 11516 9779 11919 11264 12341
-12771 12768 14263 13191 15791 13624 17410 14091 19096 14576 20806 15070
-22485 15553 24104 16019 25712 16481 27382 16963 29089 17453 30765 17939
-32371 18400 33869 18828 35312 19241 36767 19655 38211 20066 39586 20454
-40843 20809 41961 21123 42982 21407 43959 21676 44877 21930 45658 22140
-46312 22310 46859 22448 47265 22550 47524 22617 47663 22644 47677 22629
-47521 22576 47201 22483 46766 22348 46218 22174 45447 21962 44428 21692
-43318 21381 42185 21048 40865 20656 39137 20200 37087 19746 35085 19270
-33296 18653 31401 17928 28856 17294 25513 16765 21813 16077 18478 15029
-15924 13826 13944 12941 11812 12529 8690 12194 3980 11339 -2490 9603 -10575 6970
--20000 4000 -20000 4000 -21000 5000 -20000 4000 -20000 5000 -20000 4000
--20000 5000 -20000 4000 -21000 4000 -20000 5000 -20000 4000 -20000 4000
--20000 5000 -20000 4000 -20000 4000 -20000 4000 -20000 3000 -20000 4000
-12: 8170523 -6334830 -2827 8237 -2798 8206 -2761 8164 -2722 8108 -2677 8055
--2621 8003 -2563 7952 -2494 7891 -2429 7832 -2352 7770 -2274 7709 -2184 7651
--2094 7591 -1993 7534 -1888 7474 -1778 7414 -1658 7357 -1541 7303 -1428 7257
--1288 7202 -1149 7156 -1007 7117 -859 7079 -715 7048 -568 7016 -418 6994
--261 6975 -104 6959 57 6940 197 6936 364 6928 507 6936 657 6948 805 6963
-942 6980 1069 6992 1195 7017 1311 7045 1429 7075 1525 7115 1622 7148 1702 7183
-1761 7218 1821 7254 1859 7294 1893 7338 1904 7376 1901 7407 1887 7436 1857 7463
-1807 7486 1742 7505 1665 7520 1565 7529 1458 7530 1322 7526 1176 7509 1001 7487
-836 7460 641 7431 432 7389 195 7331 -50 7274 -315 7209 -593 7141 -888 7067
--1199 6986 -1510 6893 -1837 6803 -2184 6705 -2537 6614 -2895 6513 -3263 6418
--3642 6321 -4022 6217 -4418 6126 -4811 6037 -5202 5954 -5597 5876 -6005 5809
--6398 5745 -6819 5689 -7191 5650 -7608 5619 -8007 5602 -8382 5591 -8768 5595
--9166 5609 -9553 5647 -9940 5699 -10323 5763 -10712 5838 -11084 5934 -11474 6038
--11868 6164 -12267 6310 -12672 6474 -13083 6659 -13493 6857 -13907 7072
--14331 7306 -14769 7559 -15198 7828 -15633 8126 -16073 8440 -16499 8767
--16930 9101 -17357 9453 -17773 9816 -18182 10199 -18577 10582 -18968 10966
--19332 11357 -19662 11755 -19985 12150 -20284 12536 -20575 12904 -20848 13303
--21094 13682 -21313 14049 -21497 14396 -21651 14722 -21780 15041 -21888 15336
--21976 15614 -22041 15873 -22066 16109 -22080 16328 -22064 16528 -22033 16706
--21989 16863 -21927 17001 -21841 17123 -21737 17225 -21616 17308 -21488 17377
--21350 17431 -21204 17467 -21047 17482 -20882 17489 -20706 17482 -20527 17457
--20343 17426 -20154 17374 -19958 17315 -19759 17237 -19544 17153 -19338 17061
--19133 16957 -18927 16845 -18714 16715 -18498 16577 -18287 16440 -18071 16293
--17871 16138 -17677 15973 -17489 15804 -17304 15629 -17125 15451 -16963 15271
--16819 15082 -16694 14890 -16582 14703 -16489 14510 -16425 14325 -16367 14134
--16338 13946 -16329 13770 -16350 13592 -16401 13414 -16476 13246 -16561 13082
--16675 12933 -16811 12792 -16966 12663 -17127 12534 -17338 12408 -17546 12298
--17773 12203 -18001 12119 -18246 12042 -18505 11981 -18769 11928 -19033 11885
--19290 11852 -19541 11830 -19788 11813 -20035 11809 -20272 11814 -20500 11821
--20704 11835 -20893 11857 -21060 11883 -21200 11915 -21326 11951 -21428 11986
--21505 12022 -21552 12060 -21574 12096 -21563 12127 -21519 12162 -21461 12189
--21374 12212 -21259 12225 -21115 12237 -20941 12239 -20742 12237 -20526 12224
--20290 12209 -20035 12178 -19767 12139 -19470 12097 -19164 12043 -18850 11980
--18529 11914 -18197 11830 -17859 11746 -17519 11654 -17171 11558 -16820 11452
--16474 11345 -16134 11230 -15790 11116 -15456 10991 -15129 10868 -14812 10740
--14495 10608 -14190 10473 -13899 10341 -13618 10211 -13345 10085 -13077 9965
--12825 9839 -12587 9706 -12376 9573 -12149 9453 -11942 9335 -11748 9224
--11570 9115 -11402 9013 -11243 8912 -11093 8816 -10957 8726 -10834 8641
--10722 8562 -10620 8487 -10522 8421 -10431 8359 -10355 8303 -10292 8252
--10238 8207 -10187 8168 -10145 8133 -10103 8106 -10079 8086 -10061 8073
--10051 8060 -10043 8053 -10039 8052 -10037 8057 -10046 8066 -10064 8081
--10084 8097 -10104 8116 -10126 8141 -10148 8169 -10179 8198 -10215 8232
--10249 8270 -10285 8306 -10319 8345 -10347 8388 -10382 8431 -10416 8477
--10455 8521 -10486 8566 -10513 8616 -10535 8662 -10557 8710 -10580 8761
--10600 8808 -10614 8859 -10618 8907 -10623 8957 -10620 9004 -10618 9051
--10608 9098 -10589 9145 -10568 9188 -10541 9234 -10507 9280 -10467 9325
--10426 9365 -10376 9400 -10321 9441 -10261 9477 -10195 9512 -10123 9544
--10046 9576 -9964 9604 -9878 9628 -9789 9652 -9696 9670 -9596 9688 -9492 9703
--9383 9714 -9279 9720 -9169 9726 -9057 9728 -8939 9724 -8818 9721 -8700 9712
--8582 9702 -8467 9689 -8348 9672 -8223 9651 -8104 9628 -7983 9603 -7871 9581
--7759 9554 -7646 9525 -7536 9492 -7426 9460 -7322 9429 -7226 9401 -7132 9369
--7043 9339 -6955 9307 -6871 9276 -6795 9248 -6728 9222 -6666 9197 -6611 9176
--6557 9153 -6512 9135 -6475 9116 -6443 9101 -6421 9086 -6405 9077 -6397 9068
--6397 9061 -6403 9055 -6413 9051 -6432 9045 -6458 9044 -6494 9044 -6537 9046
--6582 9047 -6624 9048 -6672 9047 -6730 9048 -6797 9051 -6867 9053 -6930 9053
--6988 9057 -7042 9056 -7102 9056 -7171 9055 -7233 9055 -7287 9054 -7322 9055
--7347 9059 -7373 9061 -7397 9060 -7413 9061 -7408 9067 -7387 9076 -7350 9086
--7301 9097 -7239 9107 -7164 9124 -7069 9143 -6961 9166 -6834 9193 -6688 9223
--6518 9259 -6336 9296 -6143 9338 -5945 9381 -5734 9428 -5501 9481 -5241 9539
--4972 9600 -4706 9659 -4453 9719 -4201 9776 -3926 9842 -3634 9911 -3344 9980
--3070 10044 -2823 10100 -2593 10152 -2358 10206 -2120 10261 -1896 10312
--1702 10353 -1541 10382 -1407 10405 -1289 10424 -1189 10435 -1113 10440
--1066 10433 -1049 10419 -1056 10393 -1101 10356 -1182 10309 -1286 10252
--1411 10187 -1542 10121 -1688 10047 -1881 9955 -2116 9852 -2366 9742 -2607 9633
--2823 9533 -3038 9429 -3297 9310 -3581 9182 -3856 9054 -4094 8938 -4274 8838
--4429 8745 -4602 8647 -4777 8545 -4911 8455 -4984 8383 -4977 8336 -4918 8305
--4835 8280 -4719 8263 -4545 8266 -4291 8292 -3956 8346 -3544 8423 -3071 8518
--2535 8633 -1925 8772 -1237 8933 -483 9118 350 9328 1277 9566 2285 9830
-3366 10118 4503 10424 5672 10740 6908 11077 8244 11447 9669 11846 11147 12260
-12641 12681 14124 13097 15641 13524 17250 13982 18926 14461 20621 14945
-22290 15421 23897 15879 25493 16332 27151 16804 28843 17287 30508 17762
-32101 18214 33586 18634 35019 19037 36463 19442 37894 19842 39254 20221
-40505 20567 41610 20870 42621 21145 43590 21405 44497 21648 45270 21849
-45918 22011 46457 22138 46853 22231 47107 22289 47244 22306 47249 22284
-47088 22223 46765 22123 46326 21980 45775 21799 44995 21580 43981 21307
-42870 20993 41730 20657 40409 20261 38679 19803 36632 19349 34628 18877
-32832 18268 30936 17557 28393 16927 25063 16399 21382 15726 18070 14696
-15534 13522 13564 12670 11457 12292 8377 12000 3752 11221 -2575 9649 -10448 7322
--20000 4000 -20000 4000 -20000 4000 -20000 5000 -20000 4000 -20000 5000
--20000 4000 -21000 4000 -20000 5000 -20000 4000 -20000 5000 -20000 4000
--20000 5000 -20000 4000 -21000 5000 -20000 4000 -20000 5000 -20000 4000
--20000 4000 -20000 4000 -20000 4000 -20000 5000 -20000 3000 -20000 4000
-13: 8207002 -6327128 -2610 8165 -2574 8131 -2527 8086 -2477 8024 -2419 7971
--2353 7917 -2283 7860 -2205 7797 -2122 7733 -2031 7667 -1934 7601 -1833 7539
--1728 7476 -1603 7417 -1486 7350 -1355 7285 -1219 7225 -1080 7170 -951 7117
--801 7060 -640 7007 -475 6968 -313 6924 -151 6888 11 6858 183 6832 358 6811
-527 6793 700 6777 867 6762 1033 6763 1198 6765 1358 6774 1514 6790 1666 6807
-1802 6821 1933 6845 2050 6873 2177 6909 2283 6945 2381 6982 2457 7019 2519 7055
-2571 7093 2613 7137 2640 7183 2647 7219 2640 7256 2618 7286 2577 7315 2518 7344
-2442 7360 2354 7377 2237 7388 2109 7390 1965 7383 1804 7368 1606 7344 1423 7318
-1219 7285 980 7239 723 7180 458 7119 173 7053 -134 6979 -455 6901 -784 6815
--1129 6717 -1482 6617 -1845 6514 -2226 6416 -2616 6310 -3006 6210 -3417 6105
--3830 5999 -4245 5899 -4665 5807 -5082 5715 -5509 5636 -5927 5561 -6378 5493
--6774 5439 -7218 5396 -7633 5363 -8027 5346 -8453 5335 -8866 5340 -9260 5354
--9662 5398 -10074 5447 -10482 5519 -10874 5599 -11260 5698 -11654 5809
--12061 5940 -12481 6094 -12899 6269 -13325 6462 -13748 6672 -14176 6897
--14613 7142 -15058 7409 -15512 7699 -15967 8015 -16420 8344 -16870 8693
--17317 9043 -17754 9416 -18185 9805 -18607 10209 -19013 10618 -19419 11022
--19795 11438 -20135 11858 -20465 12279 -20771 12685 -21063 13076 -21336 13501
--21583 13903 -21799 14282 -21972 14651 -22126 14997 -22245 15329 -22340 15638
--22418 15931 -22472 16195 -22490 16440 -22482 16665 -22453 16868 -22405 17050
--22345 17208 -22265 17349 -22157 17468 -22035 17569 -21903 17650 -21756 17718
--21597 17765 -21433 17798 -21264 17807 -21079 17810 -20894 17798 -20699 17766
--20507 17728 -20303 17670 -20093 17602 -19881 17519 -19659 17429 -19439 17327
--19222 17214 -19010 17091 -18788 16955 -18559 16812 -18334 16666 -18115 16510
--17907 16347 -17703 16175 -17508 15995 -17317 15810 -17132 15626 -16968 15433
--16820 15239 -16686 15044 -16581 14844 -16488 14644 -16423 14449 -16375 14251
--16347 14055 -16349 13873 -16383 13687 -16448 13505 -16539 13335 -16642 13168
--16775 13011 -16934 12869 -17109 12736 -17294 12608 -17531 12481 -17772 12372
--18024 12276 -18277 12196 -18556 12122 -18844 12060 -19142 12016 -19433 11978
--19716 11949 -19997 11930 -20273 11923 -20547 11926 -20806 11935 -21058 11952
--21286 11973 -21497 12002 -21677 12038 -21839 12077 -21973 12122 -22088 12163
--22177 12207 -22224 12250 -22249 12296 -22234 12334 -22193 12371 -22127 12403
--22032 12430 -21913 12450 -21752 12463 -21563 12466 -21347 12463 -21112 12448
--20859 12429 -20584 12398 -20286 12359 -19968 12308 -19641 12249 -19299 12179
--18949 12103 -18592 12016 -18232 11922 -17862 11818 -17487 11711 -17113 11595
--16742 11475 -16375 11351 -16013 11221 -15654 11088 -15304 10951 -14968 10809
--14635 10669 -14308 10520 -14004 10376 -13706 10234 -13416 10099 -13139 9967
--12874 9831 -12629 9688 -12404 9545 -12171 9416 -11955 9288 -11757 9170
--11574 9052 -11397 8944 -11234 8836 -11084 8737 -10944 8640 -10819 8552
--10708 8472 -10602 8390 -10503 8321 -10414 8260 -10339 8202 -10275 8151
--10223 8104 -10174 8066 -10132 8032 -10094 8009 -10070 7988 -10056 7975
--10047 7967 -10042 7962 -10040 7965 -10042 7971 -10052 7984 -10074 8002
--10097 8023 -10123 8045 -10145 8073 -10170 8104 -10204 8138 -10245 8177
--10283 8216 -10320 8258 -10357 8302 -10390 8347 -10427 8394 -10469 8445
--10504 8492 -10541 8543 -10569 8592 -10594 8645 -10620 8694 -10643 8749
--10666 8800 -10679 8853 -10686 8905 -10690 8957 -10690 9007 -10683 9055
--10672 9106 -10654 9152 -10632 9198 -10604 9248 -10567 9294 -10523 9340
--10479 9381 -10424 9420 -10366 9458 -10302 9494 -10231 9530 -10154 9564
--10070 9594 -9983 9620 -9892 9644 -9798 9666 -9699 9684 -9592 9700 -9480 9714
--9368 9723 -9257 9729 -9143 9730 -9026 9730 -8901 9724 -8778 9717 -8653 9708
--8532 9693 -8414 9679 -8295 9658 -8166 9636 -8043 9609 -7924 9582 -7809 9556
--7699 9528 -7588 9497 -7477 9463 -7371 9426 -7269 9395 -7175 9363 -7087 9333
--7000 9300 -6919 9267 -6839 9235 -6769 9207 -6708 9181 -6651 9157 -6600 9134
--6554 9113 -6519 9095 -6485 9079 -6461 9063 -6444 9050 -6436 9042 -6433 9034
--6440 9029 -6451 9027 -6467 9023 -6488 9021 -6519 9021 -6561 9024 -6606 9028
--6654 9032 -6699 9033 -6748 9037 -6807 9040 -6875 9044 -6942 9047 -7009 9051
--7064 9055 -7119 9058 -7176 9060 -7241 9060 -7301 9058 -7350 9060 -7381 9064
--7404 9066 -7425 9070 -7444 9069 -7454 9072 -7445 9076 -7418 9084 -7375 9095
--7320 9106 -7254 9117 -7174 9131 -7072 9150 -6959 9171 -6828 9198 -6678 9227
--6504 9261 -6315 9298 -6119 9337 -5915 9380 -5703 9424 -5468 9477 -5203 9533
--4932 9592 -4664 9652 -4410 9708 -4157 9765 -3882 9829 -3588 9896 -3299 9965
--3026 10028 -2779 10081 -2551 10134 -2315 10185 -2079 10241 -1859 10290
--1667 10331 -1507 10360 -1375 10382 -1260 10399 -1164 10412 -1089 10416
--1047 10409 -1032 10395 -1043 10369 -1091 10331 -1173 10286 -1283 10229
--1410 10165 -1541 10099 -1692 10025 -1886 9935 -2122 9832 -2375 9724 -2621 9616
--2831 9515 -3054 9411 -3313 9295 -3596 9168 -3870 9040 -4112 8924 -4294 8827
--4450 8734 -4619 8635 -4796 8535 -4931 8444 -5005 8372 -4998 8326 -4940 8294
--4858 8268 -4743 8251 -4570 8253 -4316 8278 -3983 8330 -3573 8406 -3104 8500
--2570 8610 -1963 8747 -1279 8908 -528 9088 300 9294 1220 9528 2224 9789
-3297 10072 4429 10374 5591 10683 6816 11016 8146 11380 9561 11773 11028 12180
-12513 12595 13985 13005 15490 13423 17088 13874 18751 14346 20434 14821
-22091 15290 23684 15738 25269 16183 26913 16646 28591 17120 30244 17586
-31822 18029 33294 18440 34715 18832 36147 19229 37564 19619 38915 19987
-40151 20323 41246 20617 42248 20882 43208 21132 44104 21366 44867 21557
-45508 21709 46040 21827 46432 21911 46683 21957 46809 21967 46808 21936
-46644 21866 46318 21759 45881 21610 45321 21420 44542 21194 43530 20917
-42412 20600 41277 20262 39960 19863 38228 19402 36189 18948 34186 18478
-32396 17881 30484 17181 27951 16560 24636 16046 20984 15379 17697 14362
-15170 13214 13215 12398 11127 12055 8072 11787 3463 11021 -2905 9443 -10939 7095
--20000 4000 -20000 5000 -20000 4000 -19000 4000 -21000 5000 -20000 4000
--20000 5000 -20000 4000 -20000 5000 -20000 4000 -20000 5000 -20000 4000
--20000 5000 -20000 5000 -21000 4000 -20000 5000 -20000 4000 -20000 4000
--20000 5000 -20000 4000 -20000 4000 -20000 4000 -20000 4000 -20000 4000
-14: 8243524 -6319433 -2384 8094 -2342 8050 -2277 8002 -2227 7940 -2150 7882
--2075 7827 -1997 7762 -1902 7699 -1801 7629 -1697 7561 -1582 7490 -1466 7421
--1343 7356 -1205 7292 -1072 7222 -921 7153 -766 7089 -613 7026 -461 6972
--292 6913 -112 6859 69 6809 250 6768 426 6726 612 6691 797 6665 985 6638
-1177 6620 1362 6605 1542 6589 1722 6589 1902 6589 2071 6599 2239 6610 2398 6630
-2551 6646 2680 6668 2812 6699 2936 6733 3050 6775 3144 6812 3226 6852 3288 6890
-3331 6931 3376 6975 3393 7024 3395 7067 3382 7108 3354 7139 3300 7171 3230 7199
-3140 7216 3042 7240 2910 7252 2769 7252 2607 7248 2424 7231 2211 7208 2011 7183
-1782 7145 1526 7097 1252 7037 954 6971 647 6902 320 6826 -24 6743 -387 6646
--748 6546 -1136 6441 -1528 6333 -1929 6226 -2347 6115 -2771 6008 -3205 5895
--3649 5785 -4091 5678 -4541 5578 -4986 5484 -5426 5401 -5889 5318 -6329 5248
--6799 5190 -7241 5145 -7664 5110 -8101 5091 -8546 5078 -8953 5085 -9371 5106
--9802 5149 -10236 5199 -10641 5275 -11039 5367 -11444 5462 -11855 5582
--12274 5717 -12706 5879 -13139 6064 -13572 6264 -13997 6485 -14446 6724
--14896 6977 -15365 7258 -15835 7568 -16303 7900 -16773 8246 -17243 8614
--17706 8989 -18158 9382 -18604 9790 -19039 10220 -19467 10653 -19876 11081
--20263 11524 -20622 11968 -20950 12410 -21266 12838 -21557 13254 -21838 13700
--22074 14126 -22290 14531 -22459 14918 -22606 15281 -22717 15628 -22798 15951
--22865 16252 -22909 16526 -22915 16775 -22888 17009 -22843 17215 -22779 17400
--22698 17559 -22594 17699 -22473 17815 -22333 17917 -22187 17996 -22012 18060
--21843 18103 -21661 18126 -21471 18135 -21272 18132 -21074 18112 -20867 18075
--20659 18029 -20447 17963 -20223 17889 -19998 17800 -19762 17700 -19534 17591
--19313 17469 -19083 17337 -18855 17196 -18618 17046 -18378 16886 -18150 16726
--17932 16553 -17728 16372 -17518 16185 -17322 15991 -17134 15799 -16963 15596
--16808 15396 -16670 15192 -16565 14982 -16474 14775 -16412 14570 -16367 14367
--16350 14165 -16357 13971 -16407 13783 -16485 13595 -16593 13416 -16713 13248
--16864 13090 -17049 12945 -17247 12806 -17459 12679 -17727 12552 -17993 12445
--18272 12349 -18561 12270 -18871 12201 -19188 12144 -19520 12104 -19839 12068
--20155 12046 -20465 12035 -20769 12034 -21071 12043 -21356 12062 -21638 12086
--21884 12115 -22118 12153 -22320 12199 -22494 12246 -22641 12297 -22769 12348
--22865 12399 -22922 12452 -22948 12503 -22929 12548 -22885 12590 -22814 12628
--22712 12658 -22580 12680 -22409 12697 -22204 12702 -21967 12697 -21713 12682
--21434 12664 -21139 12625 -20816 12583 -20478 12529 -20117 12461 -19751 12383
--19371 12300 -18988 12204 -18601 12101 -18200 11987 -17801 11866 -17401 11740
--16999 11607 -16610 11469 -16226 11329 -15845 11184 -15471 11032 -15110 10878
--14763 10723 -14418 10565 -14095 10408 -13785 10254 -13478 10107 -13187 9962
--12911 9816 -12657 9665 -12422 9511 -12179 9371 -11957 9238 -11753 9105
--11566 8985 -11385 8867 -11217 8755 -11063 8651 -10922 8550 -10796 8458
--10681 8371 -10577 8290 -10478 8217 -10388 8154 -10315 8097 -10251 8045
--10200 7998 -10151 7958 -10113 7928 -10077 7906 -10055 7889 -10044 7875
--10036 7870 -10033 7871 -10033 7874 -10038 7883 -10054 7901 -10075 7924
--10104 7947 -10130 7974 -10159 8005 -10187 8039 -10224 8080 -10266 8120
--10308 8164 -10349 8210 -10389 8257 -10428 8308 -10464 8359 -10510 8414
--10549 8465 -10589 8517 -10619 8571 -10646 8628 -10674 8681 -10700 8739
--10721 8793 -10738 8849 -10747 8902 -10750 8957 -10748 9008 -10742 9061
--10731 9110 -10711 9161 -10688 9209 -10657 9260 -10617 9307 -10572 9354
--10521 9399 -10466 9434 -10403 9472 -10333 9509 -10258 9545 -10175 9579
--10087 9608 -9992 9634 -9898 9658 -9799 9677 -9695 9693 -9580 9710 -9463 9718
--9346 9728 -9229 9731 -9110 9731 -8990 9726 -8861 9718 -8731 9708 -8604 9696
--8480 9681 -8360 9664 -8238 9639 -8108 9613 -7984 9584 -7864 9555 -7753 9527
--7643 9496 -7531 9463 -7424 9427 -7321 9388 -7223 9355 -7133 9323 -7048 9290
--6968 9258 -6889 9224 -6819 9191 -6754 9162 -6698 9137 -6648 9113 -6604 9092
--6564 9071 -6536 9053 -6510 9039 -6493 9025 -6482 9014 -6479 9007 -6485 9001
--6496 8999 -6513 8999 -6534 8997 -6559 8997 -6595 9001 -6640 9006 -6687 9012
--6738 9018 -6785 9023 -6836 9029 -6895 9034 -6963 9040 -7030 9045 -7094 9052
--7151 9057 -7200 9062 -7257 9066 -7319 9067 -7374 9068 -7418 9069 -7447 9074
--7464 9079 -7481 9082 -7494 9081 -7499 9084 -7482 9088 -7451 9096 -7402 9107
--7342 9118 -7269 9128 -7182 9141 -7076 9158 -6958 9178 -6823 9205 -6665 9233
--6489 9265 -6295 9300 -6092 9339 -5887 9378 -5672 9423 -5433 9471 -5166 9527
--4894 9585 -4625 9643 -4367 9698 -4114 9752 -3838 9816 -3545 9881 -3256 9949
--2985 10009 -2739 10061 -2511 10113 -2278 10165 -2042 10218 -1827 10266
--1635 10306 -1479 10336 -1350 10356 -1239 10374 -1143 10385 -1072 10390
--1035 10383 -1021 10368 -1035 10343 -1087 10305 -1172 10260 -1284 10204
--1414 10140 -1549 10075 -1700 10002 -1896 9912 -2135 9812 -2389 9703 -2636 9597
--2850 9495 -3070 9395 -3332 9277 -3616 9151 -3889 9026 -4132 8911 -4313 8812
--4471 8723 -4641 8623 -4814 8523 -4951 8434 -5024 8361 -5017 8314 -4960 8284
--4878 8256 -4765 8240 -4592 8240 -4340 8264 -4006 8316 -3601 8388 -3132 8481
--2602 8590 -1997 8724 -1316 8881 -570 9059 253 9260 1168 9492 2166 9748
-3233 10027 4356 10324 5510 10629 6729 10955 8048 11314 9454 11700 10909 12101
-12385 12509 13843 12913 15338 13325 16924 13766 18576 14231 20243 14699
-21886 15158 23467 15598 25037 16035 26670 16490 28331 16954 29970 17410
-31534 17844 32994 18245 34402 18629 35819 19015 37224 19395 38562 19755
-39787 20080 40870 20364 41862 20619 42810 20859 43697 21082 44453 21264
-45085 21406 45609 21515 46000 21588 46242 21625 46363 21626 46358 21586
-46195 21508 45863 21392 45424 21236 44863 21039 44087 20805 43070 20522
-41958 20203 40826 19862 39509 19461 37787 19000 35758 18542 33769 18076
-31971 17487 30058 16797 27528 16197 24241 15696 20617 15032 17352 14028
-14840 12913 12895 12137 10825 11826 7806 11581 3269 10827 -2960 9232 -10783 6894
--20000 5000 -20000 4000 -20000 4000 -20000 5000 -20000 4000 -20000 5000
--20000 4000 -20000 5000 -20000 5000 -20000 4000 -20000 5000 -20000 4000
--20000 5000 -20000 5000 -20000 4000 -21000 5000 -20000 4000 -20000 5000
--20000 4000 -20000 5000 -20000 4000 -20000 4000 -20000 4000 -19000 4000
-15: 8280092 -6311748 -2146 8016 -2098 7971 -2025 7914 -1961 7853 -1875 7791
--1790 7730 -1694 7663 -1589 7597 -1470 7521 -1345 7447 -1219 7374 -1088 7299
--946 7231 -800 7166 -637 7086 -472 7019 -305 6946 -130 6882 45 6818 232 6760
-425 6704 629 6649 830 6599 1024 6561 1222 6519 1425 6486 1629 6465 1838 6444
-2037 6424 2235 6411 2429 6409 2615 6407 2796 6417 2977 6427 3150 6447 3306 6466
-3445 6486 3582 6519 3706 6558 3823 6599 3923 6643 4002 6679 4063 6723 4107 6766
-4144 6817 4153 6868 4152 6915 4129 6955 4091 6991 4025 7027 3948 7059 3843 7082
-3722 7103 3585 7122 3423 7122 3248 7117 3044 7103 2812 7079 2591 7053 2344 7012
-2067 6965 1765 6900 1445 6833 1116 6761 763 6678 394 6591 7 6490 -380 6383
--801 6271 -1223 6159 -1647 6043 -2100 5928 -2549 5811 -3013 5695 -3483 5578
--3957 5459 -4424 5360 -4906 5258 -5384 5169 -5848 5083 -6340 5004 -6821 4942
--7255 4898 -7745 4862 -8201 4837 -8632 4831 -9072 4832 -9522 4858 -9964 4902
--10393 4958 -10812 5034 -11228 5130 -11644 5233 -12072 5354 -12497 5498
--12934 5665 -13376 5857 -13808 6069 -14263 6299 -14728 6548 -15190 6812
--15675 7105 -16155 7430 -16649 7782 -17135 8150 -17615 8534 -18100 8933
--18567 9348 -19028 9777 -19483 10229 -19922 10689 -20344 11147 -20739 11610
--21111 12078 -21448 12545 -21766 12999 -22064 13436 -22342 13905 -22579 14363
--22793 14790 -22959 15195 -23088 15572 -23191 15931 -23267 16268 -23320 16581
--23347 16867 -23341 17123 -23297 17356 -23236 17568 -23150 17752 -23046 17914
--22924 18053 -22790 18171 -22626 18267 -22457 18344 -22270 18400 -22079 18440
--21879 18459 -21672 18462 -21464 18449 -21247 18425 -21023 18384 -20803 18327
--20580 18256 -20349 18173 -20108 18076 -19863 17971 -19627 17852 -19394 17723
--19155 17584 -18916 17433 -18668 17273 -18415 17107 -18180 16935 -17956 16757
--17741 16570 -17525 16373 -17317 16170 -17124 15966 -16946 15759 -16785 15551
--16645 15337 -16536 15119 -16450 14905 -16393 14690 -16352 14482 -16335 14270
--16352 14067 -16415 13873 -16509 13683 -16634 13498 -16775 13325 -16955 13165
--17154 13016 -17379 12876 -17618 12747 -17916 12619 -18213 12514 -18524 12421
--18842 12344 -19187 12281 -19542 12228 -19899 12188 -20260 12160 -20600 12145
--20939 12140 -21282 12146 -21609 12169 -21928 12190 -22230 12223 -22504 12263
--22761 12310 -22982 12363 -23170 12420 -23338 12476 -23470 12544 -23577 12601
--23639 12660 -23666 12719 -23650 12773 -23599 12816 -23517 12861 -23417 12895
--23269 12922 -23082 12940 -22856 12946 -22603 12943 -22324 12927 -22027 12904
--21701 12864 -21355 12815 -20989 12755 -20603 12680 -20205 12594 -19795 12501
--19384 12398 -18965 12284 -18537 12159 -18107 12027 -17677 11886 -17252 11740
--16836 11586 -16428 11435 -16024 11276 -15627 11113 -15247 10947 -14877 10775
--14516 10606 -14173 10434 -13849 10268 -13527 10109 -13221 9954 -12933 9796
--12675 9635 -12428 9468 -12175 9319 -11946 9177 -11739 9040 -11547 8908
--11362 8784 -11192 8666 -11031 8557 -10888 8454 -10762 8357 -10645 8264
--10543 8185 -10445 8108 -10354 8042 -10283 7986 -10218 7932 -10168 7889
--10121 7849 -10085 7822 -10053 7798 -10032 7784 -10022 7774 -10017 7772
--10017 7774 -10019 7783 -10028 7796 -10045 7816 -10071 7843 -10101 7869
--10133 7904 -10163 7937 -10195 7977 -10235 8020 -10280 8065 -10326 8113
--10370 8163 -10414 8213 -10453 8271 -10496 8325 -10545 8382 -10586 8439
--10629 8492 -10661 8553 -10691 8611 -10719 8671 -10748 8730 -10770 8786
--10789 8844 -10798 8898 -10800 8956 -10798 9013 -10793 9066 -10781 9116
--10761 9168 -10735 9221 -10699 9271 -10659 9319 -10611 9367 -10557 9412
--10496 9446 -10428 9485 -10358 9521 -10277 9557 -10187 9589 -10093 9621
--9995 9645 -9895 9666 -9791 9684 -9682 9699 -9562 9711 -9439 9721 -9316 9726
--9194 9728 -9073 9725 -8947 9718 -8815 9708 -8682 9694 -8552 9677 -8426 9662
--8305 9641 -8179 9616 -8051 9583 -7927 9553 -7809 9520 -7696 9492 -7589 9459
--7481 9424 -7376 9385 -7277 9346 -7185 9310 -7099 9277 -7019 9244 -6943 9210
--6872 9175 -6809 9145 -6749 9116 -6701 9089 -6658 9069 -6621 9046 -6590 9028
--6567 9011 -6551 8997 -6540 8986 -6534 8976 -6538 8972 -6551 8970 -6567 8970
--6589 8971 -6615 8974 -6644 8974 -6683 8981 -6731 8989 -6784 8999 -6835 9008
--6884 9016 -6936 9024 -6992 9031 -7062 9040 -7130 9047 -7191 9054 -7244 9063
--7293 9070 -7344 9074 -7401 9079 -7454 9080 -7492 9083 -7517 9089 -7528 9093
--7540 9097 -7549 9097 -7544 9100 -7523 9102 -7485 9112 -7430 9122 -7364 9131
--7285 9142 -7191 9153 -7080 9169 -6956 9189 -6816 9212 -6653 9240 -6473 9270
--6275 9303 -6068 9340 -5859 9378 -5640 9421 -5399 9468 -5131 9522 -4856 9577
--4585 9634 -4326 9686 -4071 9740 -3798 9801 -3505 9865 -3216 9930 -2946 9991
--2702 10040 -2476 10090 -2245 10142 -2012 10193 -1797 10241 -1612 10280
--1457 10308 -1329 10329 -1222 10346 -1129 10356 -1063 10361 -1027 10354
--1018 10339 -1035 10315 -1089 10277 -1178 10231 -1291 10176 -1425 10114
--1562 10049 -1715 9977 -1913 9888 -2153 9788 -2409 9682 -2657 9575 -2872 9476
--3091 9375 -3353 9260 -3640 9133 -3912 9010 -4153 8896 -4334 8798 -4493 8709
--4662 8610 -4834 8512 -4968 8422 -5043 8351 -5036 8303 -4978 8272 -4899 8245
--4783 8228 -4610 8227 -4359 8252 -4028 8301 -3624 8371 -3157 8462 -2628 8570
--2028 8702 -1350 8855 -608 9030 210 9229 1119 9456 2110 9708 3170 9982
-4287 10274 5433 10575 6642 10896 7952 11248 9347 11628 10792 12024 12254 12425
-13704 12820 15185 13227 16757 13661 18394 14117 20050 14576 21679 15028
-23245 15459 24800 15887 26417 16334 28065 16789 29686 17236 31239 17660
-32685 18052 34077 18426 35480 18802 36873 19172 38197 19522 39411 19837
-40483 20112 41461 20357 42404 20586 43276 20799 44024 20971 44650 21103
-45168 21203 45553 21265 45791 21292 45905 21283 45898 21235 45731 21149
-45400 21024 44961 20859 44400 20655 43629 20414 42613 20125 41505 19802
-40374 19458 39059 19056 37354 18593 35346 18136 33361 17670 31559 17084
-29651 16412 27145 15831 23879 15340 20280 14681 17032 13702 14532 12624
-12602 11887 10550 11611 7563 11412 3088 10749 -3019 9345 -10601 7226 -20000 4000
--20000 4000 -20000 5000 -20000 4000 -20000 5000 -20000 4000 -20000 5000
--20000 5000 -20000 4000 -20000 5000 -20000 5000 -20000 4000 -20000 5000
--20000 5000 -20000 4000 -20000 5000 -20000 5000 -20000 4000 -20000 4000
-16: 8316705 -6304071 -1901 7936 -1843 7884 -1766 7827 -1682 7763 -1591 7696
--1491 7630 -1379 7561 -1263 7488 -1123 7410 -989 7331 -841 7250 -699 7175
--544 7100 -369 7030 -196 6950 -7 6876 171 6800 366 6730 565 6664 769 6601
-980 6540 1201 6484 1419 6429 1640 6383 1847 6342 2065 6310 2287 6283 2516 6259
-2731 6240 2941 6227 3149 6220 3340 6219 3538 6231 3726 6242 3909 6257 4076 6277
-4223 6301 4364 6337 4490 6379 4607 6421 4708 6468 4786 6509 4847 6553 4888 6602
-4915 6658 4928 6712 4917 6760 4879 6807 4827 6846 4756 6885 4663 6918 4548 6949
-4409 6977 4257 6996 4079 6995 3883 6994 3654 6980 3410 6960 3164 6928 2898 6892
-2594 6838 2269 6777 1931 6703 1577 6624 1195 6541 801 6450 392 6344 -36 6229
--474 6108 -925 5993 -1388 5871 -1861 5750 -2339 5623 -2841 5499 -3343 5374
--3831 5254 -4339 5143 -4838 5040 -5346 4940 -5843 4849 -6367 4770 -6834 4701
--7346 4655 -7850 4614 -8287 4589 -8752 4584 -9235 4586 -9683 4611 -10121 4658
--10560 4723 -11007 4800 -11445 4893 -11871 5008 -12285 5129 -12723 5282
--13163 5455 -13612 5649 -14069 5874 -14538 6112 -15011 6370 -15494 6646
--15979 6953 -16484 7289 -16987 7658 -17492 8049 -17996 8456 -18496 8872
--18977 9311 -19463 9766 -19928 10243 -20391 10729 -20822 11214 -21230 11696
--21609 12192 -21956 12683 -22280 13164 -22581 13628 -22857 14127 -23095 14602
--23300 15050 -23458 15473 -23585 15869 -23673 16247 -23738 16594 -23782 16920
--23792 17217 -23772 17473 -23705 17715 -23629 17926 -23518 18113 -23395 18274
--23252 18411 -23096 18527 -22912 18618 -22721 18691 -22519 18743 -22311 18774
--22088 18790 -21868 18790 -21644 18769 -21411 18732 -21176 18688 -20943 18624
--20706 18548 -20461 18454 -20213 18352 -19961 18236 -19712 18110 -19466 17977
--19221 17827 -18971 17667 -18710 17496 -18451 17323 -18208 17146 -17970 16960
--17747 16763 -17523 16554 -17310 16347 -17104 16134 -16917 15920 -16754 15703
--16609 15479 -16497 15252 -16414 15030 -16357 14808 -16320 14590 -16314 14373
--16335 14163 -16405 13963 -16521 13766 -16659 13579 -16826 13400 -17027 13235
--17257 13083 -17508 12942 -17773 12813 -18100 12686 -18432 12583 -18774 12492
--19123 12417 -19504 12357 -19898 12308 -20293 12273 -20683 12255 -21058 12243
--21431 12247 -21801 12264 -22161 12289 -22516 12326 -22844 12365 -23144 12414
--23416 12473 -23662 12532 -23874 12600 -24056 12669 -24200 12740 -24311 12809
--24381 12878 -24408 12943 -24391 13002 -24340 13056 -24251 13106 -24137 13142
--23973 13173 -23771 13194 -23525 13201 -23252 13198 -22951 13183 -22629 13154
--22277 13108 -21905 13055 -21509 12987 -21089 12908 -20657 12812 -20221 12711
--19776 12597 -19326 12469 -18868 12334 -18407 12189 -17947 12036 -17500 11872
--17049 11708 -16616 11541 -16193 11366 -15774 11189 -15369 11010 -14976 10824
--14598 10642 -14242 10456 -13895 10277 -13564 10106 -13242 9938 -12944 9770
--12675 9598 -12421 9417 -12159 9259 -11924 9108 -11713 8964 -11513 8827
--11329 8695 -11154 8571 -10989 8458 -10844 8349 -10720 8247 -10602 8154
--10498 8072 -10399 7992 -10311 7927 -10238 7870 -10177 7816 -10130 7773
--10085 7737 -10047 7709 -10020 7688 -10000 7677 -9990 7670 -9992 7672
--9993 7675 -9997 7689 -10009 7707 -10028 7731 -10058 7762 -10092 7793
--10127 7830 -10159 7871 -10193 7914 -10237 7961 -10286 8011 -10334 8061
--10385 8117 -10428 8173 -10473 8233 -10520 8291 -10568 8352 -10616 8413
--10659 8472 -10694 8534 -10725 8595 -10757 8660 -10787 8720 -10812 8778
--10830 8839 -10839 8900 -10842 8956 -10841 9016 -10834 9070 -10821 9122
--10799 9178 -10771 9231 -10736 9281 -10691 9329 -10639 9379 -10582 9421
--10516 9457 -10446 9495 -10372 9533 -10286 9566 -10190 9599 -10092 9628
--9987 9651 -9884 9670 -9774 9686 -9659 9701 -9536 9709 -9407 9718 -9279 9718
--9154 9717 -9030 9714 -8901 9704 -8763 9691 -8629 9674 -8497 9653 -8369 9635
--8249 9612 -8121 9584 -7996 9549 -7871 9515 -7755 9480 -7643 9451 -7540 9416
--7436 9378 -7337 9338 -7240 9297 -7154 9260 -7073 9227 -6998 9193 -6929 9160
--6867 9124 -6810 9093 -6760 9066 -6717 9041 -6680 9018 -6652 8999 -6631 8982
--6614 8967 -6605 8955 -6601 8946 -6603 8939 -6614 8938 -6630 8939 -6654 8941
--6681 8945 -6712 8950 -6745 8954 -6787 8964 -6839 8976 -6892 8989 -6945 9000
--6996 9010 -7047 9022 -7104 9031 -7173 9042 -7238 9054 -7296 9063 -7347 9072
--7391 9082 -7441 9087 -7491 9092 -7539 9097 -7573 9101 -7590 9106 -7597 9112
--7604 9115 -7605 9116 -7593 9118 -7566 9123 -7520 9129 -7461 9140 -7387 9148
--7299 9156 -7202 9168 -7085 9181 -6954 9201 -6809 9223 -6641 9248 -6456 9276
--6255 9308 -6043 9342 -5830 9379 -5610 9419 -5365 9465 -5096 9517 -4819 9570
--4547 9622 -4287 9675 -4032 9726 -3758 9786 -3467 9847 -3179 9911 -2912 9970
--2669 10018 -2445 10066 -2216 10116 -1986 10168 -1775 10213 -1592 10251
--1441 10279 -1316 10299 -1210 10315 -1124 10326 -1060 10329 -1029 10324
--1020 10308 -1042 10284 -1097 10246 -1191 10200 -1306 10147 -1441 10085
--1583 10021 -1735 9949 -1936 9861 -2177 9763 -2433 9658 -2682 9552 -2898 9455
--3117 9354 -3380 9240 -3664 9116 -3938 8993 -4177 8880 -4359 8784 -4516 8693
--4684 8597 -4854 8500 -4986 8410 -5061 8340 -5054 8292 -4995 8261 -4914 8233
--4799 8217 -4627 8214 -4376 8238 -4045 8287 -3643 8356 -3178 8444 -2653 8550
--2053 8679 -1380 8829 -643 9002 169 9198 1075 9421 2056 9669 3112 9939
-4219 10225 5357 10521 6558 10837 7858 11185 9242 11558 10674 11946 12124 12341
-13562 12730 15032 13129 16588 13556 18209 14003 19851 14455 21466 14899
-23017 15321 24559 15741 26159 16179 27790 16624 29397 17062 30932 17478
-32367 17859 33742 18226 35133 18590 36510 18951 37820 19291 39021 19595
-40083 19861 41051 20095 41979 20315 42848 20517 43584 20678 44202 20802
-44712 20889 45094 20943 45327 20960 45441 20940 45429 20884 45259 20789
-44927 20657 44492 20482 43934 20269 43165 20020 42161 19727 41050 19399
-39920 19051 38618 18648 36933 18183 34939 17726 32957 17261 31165 16679
-29276 16021 26792 15460 23548 14973 19968 14335 16736 13381 14256 12341
-12339 11636 10303 11380 7329 11200 2838 10574 -3356 9193 -11036 7000 -19000 4000
--20000 5000 -20000 4000 -20000 5000 -20000 4000 -20000 5000 -20000 5000
--20000 4000 -20000 5000 -20000 5000 -20000 4000 -20000 5000 -20000 5000
-17: 8353359 -6296399 -1650 7849 -1580 7797 -1490 7733 -1399 7671 -1292 7598
--1177 7525 -1055 7454 -923 7375 -773 7294 -622 7212 -455 7125 -295 7047
--122 6966 69 6888 258 6807 461 6727 672 6648 880 6573 1095 6501 1323 6437
-1550 6373 1785 6309 2023 6255 2265 6206 2487 6162 2722 6123 2964 6093 3205 6070
-3435 6050 3662 6035 3877 6028 4080 6027 4295 6036 4498 6049 4680 6066 4858 6083
-5007 6113 5149 6152 5286 6197 5400 6240 5501 6291 5576 6335 5642 6382 5674 6434
-5701 6494 5705 6558 5680 6610 5633 6658 5571 6705 5494 6749 5377 6782 5250 6822
-5095 6853 4925 6870 4728 6878 4516 6878 4266 6862 4001 6844 3730 6821 3438 6778
-3117 6724 2774 6662 2407 6585 2022 6500 1620 6413 1198 6318 762 6204 298 6086
--156 5961 -654 5834 -1133 5707 -1639 5576 -2158 5445 -2682 5315 -3204 5179
--3740 5053 -4264 4934 -4798 4826 -5328 4716 -5873 4624 -6376 4542 -6920 4466
--7452 4415 -7934 4375 -8413 4345 -8922 4341 -9407 4345 -9842 4371 -10301 4420
--10774 4487 -11234 4566 -11668 4666 -12087 4780 -12501 4912 -12950 5065
--13404 5246 -13877 5445 -14345 5678 -14812 5925 -15295 6193 -15784 6477
--16290 6794 -16804 7145 -17334 7534 -17853 7945 -18376 8375 -18896 8811
--19402 9275 -19905 9756 -20385 10260 -20860 10769 -21308 11280 -21729 11787
--22113 12304 -22478 12825 -22805 13331 -23108 13824 -23380 14352 -23613 14843
--23818 15317 -23967 15762 -24085 16181 -24166 16572 -24216 16939 -24248 17268
--24242 17573 -24203 17837 -24120 18073 -24020 18290 -23886 18476 -23742 18637
--23577 18774 -23393 18882 -23193 18971 -22979 19039 -22762 19083 -22531 19111
--22293 19121 -22057 19111 -21815 19084 -21567 19043 -21320 18989 -21074 18918
--20825 18833 -20569 18733 -20311 18624 -20049 18497 -19788 18368 -19538 18222
--19281 18066 -19017 17896 -18749 17717 -18483 17538 -18227 17355 -17981 17158
--17746 16950 -17513 16739 -17293 16520 -17076 16298 -16879 16075 -16710 15851
--16561 15618 -16444 15386 -16364 15152 -16305 14923 -16277 14694 -16274 14472
--16305 14260 -16384 14048 -16517 13846 -16676 13653 -16862 13470 -17088 13305
--17348 13145 -17624 13006 -17918 12875 -18282 12754 -18646 12649 -19020 12563
--19411 12486 -19825 12428 -20255 12390 -20687 12360 -21114 12347 -21528 12346
--21934 12359 -22335 12379 -22731 12413 -23118 12460 -23478 12510 -23798 12570
--24103 12637 -24365 12711 -24597 12789 -24796 12866 -24954 12946 -25073 13025
--25146 13102 -25181 13176 -25159 13243 -25103 13305 -25005 13359 -24876 13403
--24697 13436 -24480 13456 -24215 13466 -23915 13465 -23592 13447 -23242 13412
--22861 13364 -22458 13304 -22029 13227 -21579 13143 -21115 13040 -20644 12927
--20166 12798 -19685 12660 -19193 12510 -18702 12354 -18211 12186 -17731 12008
--17257 11827 -16794 11646 -16342 11455 -15904 11264 -15478 11067 -15063 10869
--14666 10671 -14288 10473 -13932 10281 -13582 10096 -13252 9917 -12940 9736
--12661 9551 -12399 9360 -12133 9193 -11891 9032 -11673 8881 -11469 8736
--11280 8599 -11104 8469 -10936 8349 -10791 8236 -10664 8131 -10548 8038
--10442 7950 -10345 7873 -10258 7806 -10187 7748 -10127 7694 -10080 7655
--10039 7618 -10004 7594 -9976 7574 -9956 7566 -9952 7565 -9957 7568 -9960 7577
--9967 7592 -9980 7616 -10004 7645 -10036 7679 -10072 7717 -10111 7758
--10145 7802 -10185 7851 -10229 7904 -10285 7956 -10334 8012 -10389 8072
--10435 8133 -10481 8197 -10533 8260 -10582 8324 -10638 8387 -10681 8452
--10717 8517 -10750 8582 -10786 8647 -10815 8711 -10844 8773 -10862 8835
--10872 8898 -10874 8958 -10872 9017 -10867 9074 -10851 9132 -10828 9184
--10796 9239 -10761 9289 -10714 9341 -10659 9387 -10595 9429 -10526 9466
--10454 9505 -10374 9541 -10285 9573 -10185 9605 -10079 9631 -9972 9651
--9861 9671 -9749 9684 -9630 9696 -9500 9703 -9369 9708 -9236 9705 -9108 9701
--8980 9696 -8849 9683 -8708 9666 -8572 9647 -8440 9623 -8311 9602 -8191 9577
--8064 9545 -7940 9508 -7817 9470 -7704 9435 -7596 9401 -7496 9366 -7396 9326
--7302 9285 -7212 9244 -7131 9206 -7057 9171 -6989 9138 -6927 9103 -6872 9070
--6824 9038 -6784 9012 -6748 8989 -6719 8967 -6697 8949 -6685 8935 -6677 8921
--6677 8913 -6679 8906 -6688 8903 -6704 8902 -6727 8909 -6757 8913 -6790 8921
--6824 8927 -6860 8937 -6906 8950 -6961 8964 -7014 8981 -7070 8995 -7121 9009
--7172 9021 -7228 9036 -7293 9050 -7358 9062 -7411 9076 -7458 9086 -7499 9097
--7545 9104 -7589 9111 -7630 9117 -7658 9121 -7670 9129 -7672 9133 -7670 9138
--7663 9138 -7644 9140 -7611 9144 -7558 9151 -7492 9160 -7411 9167 -7319 9173
--7212 9184 -7088 9197 -6953 9215 -6801 9234 -6630 9258 -6440 9284 -6234 9313
--6018 9346 -5804 9379 -5579 9418 -5329 9463 -5063 9511 -4784 9562 -4511 9612
--4250 9663 -3995 9711 -3722 9769 -3433 9830 -3147 9890 -2880 9947 -2639 9995
--2418 10041 -2195 10089 -1965 10139 -1757 10185 -1579 10221 -1430 10246
--1311 10266 -1208 10283 -1123 10293 -1066 10297 -1035 10289 -1032 10276
--1055 10250 -1112 10213 -1210 10168 -1329 10115 -1465 10053 -1608 9991
--1764 9920 -1964 9833 -2208 9735 -2463 9632 -2710 9528 -2929 9432 -3150 9332
--3407 9219 -3693 9096 -3965 8975 -4202 8863 -4386 8769 -4539 8679 -4705 8583
--4876 8486 -5007 8397 -5076 8329 -5070 8281 -5010 8249 -4928 8222 -4813 8205
--4641 8203 -4389 8226 -4058 8271 -3660 8341 -3195 8427 -2671 8530 -2075 8656
--1407 8806 -674 8975 133 9167 1031 9386 2008 9630 3056 9896 4156 10179
-5283 10468 6475 10778 7766 11121 9136 11489 10558 11870 11993 12258 13420 12640
-14874 13032 16417 13453 18022 13890 19650 14335 21247 14770 22782 15185
-24310 15596 25894 16025 27509 16462 29099 16890 30618 17297 32035 17669
-33400 18024 34773 18381 36137 18731 37434 19062 38619 19356 39669 19611
-40626 19836 41546 20046 42403 20235 43131 20387 43744 20501 44245 20579
-44621 20622 44854 20629 44966 20599 44950 20534 44778 20430 44447 20289
-44019 20105 43462 19883 42700 19628 41709 19326 40599 18996 39472 18643
-38187 18237 36519 17772 34530 17313 32563 16847 30793 16271 28931 15629
-26468 15074 23237 14610 19672 13979 16463 13065 14015 12063 12129 11370
-10113 11114 7167 10941 2724 10343 -3386 9024 -10987 6947 -20000 4000 -19000 5000
--20000 5000 -20000 4000 -20000 5000 -20000 5000 -20000 5000 -20000 4000
--20000 5000 -20000 5000 -20000 5000 -20000 4000 -20000 5000 -20000 4000
--19000 5000 -20000 4000 -20000 5000 -20000 4000
-18: 8390048 -6288740 -1383 7760 -1305 7707 -1212 7643 -1102 7571 -985 7496
--857 7420 -721 7342 -568 7258 -410 7176 -242 7087 -59 6997 122 6913 309 6826
-519 6741 723 6659 949 6572 1182 6490 1404 6410 1636 6337 1887 6268 2130 6198
-2389 6133 2645 6073 2894 6024 3142 5976 3396 5930 3655 5897 3907 5877 4153 5852
-4393 5840 4619 5830 4838 5829 5061 5836 5272 5852 5463 5868 5645 5890 5805 5920
-5955 5960 6088 6010 6198 6059 6304 6108 6383 6158 6436 6208 6470 6271 6488 6333
-6486 6402 6449 6461 6397 6511 6316 6561 6226 6612 6096 6657 5950 6698 5781 6732
-5594 6756 5374 6767 5136 6767 4878 6757 4582 6739 4291 6718 3979 6673 3639 6622
-3260 6557 2873 6472 2467 6387 2032 6298 1576 6196 1116 6084 633 5954 130 5821
--380 5685 -900 5550 -1441 5412 -1989 5278 -2529 5138 -3102 4992 -3653 4862
--4221 4734 -4769 4618 -5346 4503 -5894 4400 -6456 4317 -7031 4242 -7535 4183
--8052 4136 -8604 4113 -9097 4103 -9561 4105 -10034 4140 -10540 4188 -11015 4256
--11453 4338 -11886 4443 -12309 4560 -12743 4693 -13204 4853 -13669 5037
--14143 5248 -14605 5481 -15083 5737 -15565 6010 -16074 6305 -16602 6635
--17133 7002 -17683 7406 -18217 7838 -18767 8286 -19305 8752 -19830 9237
--20346 9746 -20851 10275 -21344 10812 -21802 11344 -22236 11878 -22632 12420
--23001 12972 -23336 13502 -23646 14023 -23911 14574 -24141 15098 -24341 15599
--24490 16074 -24592 16508 -24665 16907 -24705 17283 -24719 17624 -24697 17929
--24638 18201 -24535 18445 -24407 18657 -24258 18843 -24082 19002 -23894 19134
--23687 19238 -23467 19326 -23239 19385 -22992 19425 -22744 19446 -22488 19448
--22232 19429 -21976 19398 -21713 19351 -21456 19285 -21196 19206 -20937 19115
--20668 19006 -20400 18886 -20126 18760 -19863 18618 -19603 18466 -19337 18298
--19063 18126 -18787 17938 -18508 17750 -18238 17554 -17986 17353 -17739 17137
--17495 16916 -17263 16689 -17040 16460 -16832 16230 -16653 15994 -16499 15755
--16382 15514 -16296 15273 -16241 15033 -16214 14799 -16217 14569 -16254 14347
--16351 14130 -16498 13923 -16677 13725 -16887 13538 -17134 13367 -17424 13207
--17733 13064 -18054 12935 -18454 12818 -18858 12712 -19269 12627 -19697 12557
--20144 12503 -20613 12469 -21087 12447 -21554 12441 -22007 12447 -22446 12471
--22885 12498 -23321 12540 -23735 12595 -24125 12657 -24484 12730 -24807 12810
--25095 12897 -25348 12981 -25559 13066 -25730 13159 -25860 13250 -25939 13339
--25975 13418 -25956 13495 -25888 13563 -25782 13625 -25636 13672 -25446 13709
--25208 13732 -24920 13742 -24597 13740 -24245 13717 -23866 13684 -23454 13631
--23020 13563 -22558 13479 -22066 13385 -21574 13272 -21067 13146 -20553 13007
--20036 12853 -19510 12690 -18988 12519 -18465 12336 -17954 12144 -17451 11948
--16960 11747 -16481 11544 -16016 11333 -15568 11124 -15134 10909 -14717 10694
--14324 10484 -13947 10279 -13588 10078 -13246 9886 -12923 9694 -12631 9497
--12364 9298 -12091 9117 -11841 8947 -11618 8788 -11413 8639 -11219 8494
--11041 8358 -10872 8234 -10725 8117 -10597 8007 -10484 7914 -10377 7823
--10282 7746 -10194 7677 -10123 7621 -10068 7570 -10020 7531 -9984 7496
--9949 7472 -9922 7457 -9907 7455 -9904 7456 -9911 7463 -9919 7475 -9926 7495
--9944 7524 -9969 7558 -10005 7594 -10044 7640 -10084 7685 -10122 7734
--10165 7789 -10214 7845 -10272 7906 -10327 7965 -10381 8028 -10431 8094
--10479 8160 -10535 8229 -10589 8296 -10646 8364 -10694 8433 -10733 8501
--10765 8570 -10802 8636 -10836 8703 -10865 8768 -10885 8831 -10894 8897
--10898 8959 -10894 9021 -10887 9079 -10870 9139 -10847 9191 -10813 9246
--10774 9296 -10725 9347 -10667 9395 -10598 9434 -10528 9473 -10449 9512
--10366 9547 -10272 9577 -10168 9606 -10059 9629 -9946 9648 -9829 9666
--9715 9676 -9592 9687 -9458 9690 -9320 9690 -9188 9687 -9055 9680 -8925 9671
--8792 9655 -8649 9635 -8513 9611 -8379 9586 -8251 9562 -8132 9533 -8008 9499
--7885 9461 -7766 9420 -7656 9382 -7554 9346 -7456 9310 -7363 9268 -7275 9226
--7193 9184 -7117 9145 -7051 9110 -6990 9077 -6937 9043 -6890 9012 -6852 8981
--6820 8954 -6793 8933 -6772 8912 -6759 8899 -6754 8886 -6758 8876 -6765 8871
--6773 8866 -6789 8865 -6812 8868 -6841 8877 -6877 8888 -6915 8898 -6952 8908
--6991 8919 -7041 8938 -7097 8957 -7152 8975 -7208 8995 -7259 9010 -7310 9025
--7364 9044 -7425 9060 -7486 9077 -7536 9090 -7580 9105 -7617 9116 -7656 9126
--7695 9133 -7726 9141 -7750 9146 -7756 9153 -7751 9160 -7741 9163 -7725 9164
--7699 9165 -7657 9170 -7598 9174 -7525 9183 -7437 9190 -7338 9194 -7222 9202
--7093 9214 -6952 9229 -6795 9249 -6618 9269 -6423 9293 -6214 9320 -5996 9350
--5776 9381 -5550 9417 -5299 9460 -5028 9506 -4748 9553 -4478 9603 -4217 9650
--3961 9696 -3689 9751 -3403 9810 -3118 9869 -2854 9924 -2615 9969 -2396 10013
--2176 10062 -1951 10109 -1746 10154 -1571 10188 -1427 10213 -1311 10232
--1211 10248 -1131 10258 -1077 10262 -1051 10254 -1050 10239 -1076 10214
--1138 10179 -1235 10134 -1358 10082 -1497 10019 -1641 9959 -1797 9888
--2000 9804 -2242 9706 -2498 9604 -2746 9502 -2963 9407 -3183 9309 -3442 9197
--3724 9076 -3995 8956 -4232 8845 -4410 8753 -4563 8664 -4729 8569 -4896 8472
--5025 8385 -5093 8315 -5084 8270 -5023 8239 -4941 8211 -4824 8193 -4651 8191
--4399 8212 -4069 8258 -3671 8326 -3208 8409 -2688 8512 -2093 8635 -1427 8782
--700 8947 101 9138 994 9352 1963 9592 3003 9855 4092 10131 5213 10416 6394 10722
-7675 11058 9031 11419 10439 11795 11865 12176 13273 12551 14716 12936
-16243 13349 17835 13780 19440 14216 21025 14643 22542 15049 24055 15453
-25622 15872 27219 16301 28792 16720 30294 17117 31695 17480 33044 17827
-34405 18173 35751 18514 37032 18834 38206 19118 39243 19364 40191 19580
-41098 19778 41947 19958 42667 20099 43273 20204 43766 20271 44135 20303
-44370 20300 44477 20261 44463 20185 44291 20074 43963 19923 43535 19730
-42986 19499 42237 19234 41249 18928 40145 18592 39038 18235 37765 17824
-36103 17358 34126 16899 32188 16430 30453 15863 28610 15225 26152 14697
-22935 14219 19399 13631 16233 12755 13822 11766 11967 11076 9976 10818
-7056 10657 2649 10093 -3427 8852 -11028 6997 -20000 5000 -19000 4000 -20000 5000
--20000 4000 -20000 5000 -20000 5000 -20000 5000 -20000 4000 -19000 5000
--20000 5000 -20000 5000 -20000 5000 -20000 4000 -20000 5000 -20000 5000
--20000 5000 -19000 4000 -20000 4000
-19: 8426771 -6281088 -1109 7670 -1020 7611 -920 7548 -798 7472 -668 7388
--526 7311 -378 7228 -209 7138 -34 7053 151 6955 344 6864 545 6775 754 6682
-978 6593 1211 6503 1455 6416 1695 6328 1943 6241 2194 6166 2455 6091 2725 6022
-3004 5949 3277 5887 3541 5834 3807 5781 4079 5737 4355 5699 4621 5675 4884 5650
-5137 5638 5375 5625 5606 5626 5836 5632 6060 5648 6263 5668 6442 5692 6611 5723
-6760 5764 6901 5818 7016 5871 7116 5929 7193 5976 7242 6038 7269 6103 7281 6171
-7265 6243 7219 6313 7159 6368 7061 6425 6962 6480 6814 6535 6656 6582 6464 6616
-6255 6647 6018 6666 5765 6667 5469 6658 5160 6645 4857 6621 4514 6583 4141 6531
-3749 6460 3333 6376 2895 6287 2429 6193 1947 6090 1456 5969 942 5833 414 5689
--126 5549 -688 5407 -1249 5262 -1817 5118 -2417 4970 -3003 4817 -3596 4679
--4191 4543 -4784 4415 -5373 4295 -5953 4191 -6568 4098 -7118 4017 -7659 3957
--8249 3910 -8786 3880 -9260 3873 -9767 3880 -10293 3908 -10786 3962 -11242 4029
--11677 4118 -12120 4224 -12568 4341 -13024 4485 -13475 4642 -13925 4832
--14381 5050 -14856 5284 -15345 5546 -15849 5830 -16373 6135 -16918 6474
--17472 6852 -18032 7275 -18593 7730 -19159 8199 -19717 8691 -20253 9193
--20796 9735 -21323 10291 -21826 10848 -22301 11409 -22749 11973 -23157 12539
--23537 13118 -23876 13678 -24188 14229 -24455 14812 -24685 15373 -24876 15901
--25017 16383 -25113 16833 -25167 17245 -25194 17631 -25194 17981 -25158 18297
--25078 18575 -24952 18819 -24796 19034 -24625 19214 -24420 19369 -24209 19496
--23977 19599 -23735 19674 -23483 19729 -23213 19767 -22949 19779 -22675 19769
--22397 19749 -22122 19705 -21852 19649 -21582 19577 -21310 19492 -21041 19389
--20762 19275 -20482 19148 -20200 19012 -19931 18865 -19664 18701 -19389 18530
--19105 18349 -18813 18155 -18524 17956 -18248 17751 -17981 17541 -17726 17321
--17472 17091 -17226 16855 -16988 16618 -16775 16380 -16582 16134 -16426 15888
--16303 15640 -16212 15389 -16158 15140 -16134 14901 -16142 14662 -16190 14431
--16298 14208 -16460 13996 -16662 13792 -16895 13599 -17170 13425 -17492 13266
--17826 13121 -18177 12992 -18620 12874 -19066 12772 -19514 12688 -19978 12628
--20465 12579 -20978 12549 -21490 12535 -21998 12537 -22495 12547 -22971 12576
--23454 12619 -23926 12672 -24368 12735 -24792 12813 -25187 12893 -25539 12986
--25850 13082 -26122 13179 -26345 13277 -26536 13381 -26676 13484 -26763 13581
--26797 13673 -26772 13757 -26699 13833 -26581 13900 -26426 13953 -26213 13993
--25954 14019 -25640 14028 -25296 14026 -24914 14004 -24499 13963 -24060 13908
--23589 13833 -23084 13740 -22563 13634 -22031 13508 -21485 13371 -20936 13217
--20379 13052 -19821 12873 -19266 12685 -18708 12488 -18163 12281 -17631 12068
--17109 11846 -16604 11627 -16115 11402 -15642 11173 -15187 10944 -14752 10714
--14341 10487 -13947 10267 -13575 10055 -13223 9849 -12887 9642 -12587 9437
--12310 9224 -12032 9033 -11777 8858 -11551 8686 -11343 8530 -11147 8379
--10963 8240 -10797 8110 -10645 7991 -10519 7878 -10409 7780 -10304 7688
--10206 7611 -10121 7544 -10051 7488 -9999 7441 -9951 7401 -9917 7368 -9884 7349
--9860 7339 -9847 7338 -9846 7346 -9855 7355 -9865 7373 -9880 7398 -9897 7428
--9924 7469 -9962 7512 -10006 7562 -10048 7612 -10088 7668 -10136 7725
--10186 7787 -10250 7854 -10306 7918 -10364 7986 -10417 8056 -10468 8127
--10526 8198 -10585 8269 -10644 8343 -10695 8416 -10735 8485 -10773 8557
--10810 8628 -10846 8696 -10874 8764 -10897 8830 -10904 8895 -10911 8960
--10907 9024 -10897 9083 -10880 9143 -10852 9198 -10819 9251 -10778 9303
--10724 9351 -10663 9398 -10592 9439 -10515 9477 -10435 9515 -10346 9548
--10250 9575 -10141 9602 -10026 9623 -9910 9641 -9790 9654 -9672 9664 -9544 9671
--9408 9672 -9265 9667 -9131 9661 -8996 9652 -8864 9639 -8729 9621 -8590 9595
--8450 9569 -8316 9543 -8191 9513 -8071 9482 -7951 9447 -7832 9405 -7717 9362
--7612 9323 -7514 9285 -7422 9245 -7336 9204 -7257 9161 -7182 9119 -7113 9079
--7055 9044 -7004 9011 -6958 8980 -6924 8948 -6894 8919 -6869 8895 -6852 8874
--6841 8857 -6837 8845 -6842 8835 -6853 8830 -6868 8827 -6885 8826 -6907 8828
--6937 8835 -6972 8849 -7013 8861 -7057 8877 -7096 8891 -7140 8907 -7192 8927
--7248 8951 -7305 8975 -7361 8996 -7410 9015 -7459 9034 -7512 9055 -7570 9074
--7625 9093 -7672 9110 -7712 9127 -7741 9140 -7774 9151 -7808 9161 -7832 9168
--7847 9175 -7845 9182 -7834 9190 -7816 9193 -7792 9194 -7758 9194 -7706 9197
--7641 9201 -7559 9210 -7464 9213 -7357 9218 -7236 9223 -7100 9232 -6951 9248
--6788 9263 -6609 9282 -6410 9303 -6194 9328 -5974 9355 -5749 9383 -5522 9418
--5270 9457 -4996 9500 -4718 9545 -4445 9593 -4185 9636 -3931 9681 -3660 9733
--3375 9790 -3094 9847 -2833 9899 -2597 9941 -2381 9986 -2161 10031 -1945 10078
--1742 10120 -1570 10155 -1431 10179 -1316 10196 -1222 10211 -1148 10221
--1095 10224 -1074 10216 -1076 10202 -1105 10177 -1170 10142 -1271 10099
--1393 10046 -1534 9985 -1679 9926 -1837 9856 -2041 9771 -2283 9676 -2539 9576
--2787 9474 -3001 9381 -3222 9285 -3477 9173 -3758 9055 -4029 8936 -4262 8828
--4437 8736 -4589 8647 -4751 8555 -4916 8458 -5043 8372 -5106 8304 -5096 8258
--5035 8227 -4950 8200 -4833 8181 -4657 8180 -4405 8199 -4076 8245 -3679 8311
--3217 8392 -2699 8494 -2107 8614 -1445 8759 -723 8921 75 9107 959 9319
-1923 9556 2952 9812 4033 10085 5144 10365 6316 10665 7581 10996 8931 11351
-10321 11721 11734 12094 13128 12464 14554 12841 16068 13246 17640 13670
-19231 14099 20795 14516 22296 14916 23792 15310 25343 15722 26922 16141
-28474 16552 29962 16939 31345 17293 32678 17630 34022 17968 35356 18300
-36619 18609 37779 18885 38804 19120 39740 19326 40637 19514 41477 19684
-42189 19816 42788 19910 43275 19967 43641 19989 43871 19976 43981 19925
-43965 19842 43794 19720 43474 19560 43047 19357 42508 19117 41768 18843
-40783 18531 39701 18189 38611 17826 37344 17412 35686 16944 33735 16480
-31832 16013 30133 15444 28296 14836 25842 14280 22654 13842 19164 13284
-16051 12418 13679 11442 11842 10761 9867 10518 6964 10382 2579 9871 -3477 8720
--11072 7005 -20000 5000 -19000 4000 -20000 5000 -20000 5000 -20000 4000
--20000 5000 -19000 5000 -20000 5000 -20000 4000 -20000 5000 -20000 5000
--20000 5000 -20000 5000 -19000 4000 -20000 5000 -20000 5000 -20000 4000
--20000 5000
-20: 8463531 -6273442 -827 7574 -734 7515 -618 7447 -483 7367 -343 7282
--185 7199 -22 7108 162 7017 351 6921 552 6824 762 6726 980 6631 1208 6535
-1446 6438 1704 6346 1964 6251 2226 6160 2496 6071 2760 5992 3044 5912 3332 5837
-3626 5760 3919 5695 4200 5637 4487 5583 4774 5539 5063 5495 5351 5465 5630 5441
-5887 5427 6142 5419 6383 5417 6625 5424 6858 5440 7067 5461 7255 5489 7428 5521
-7576 5567 7722 5622 7843 5680 7935 5744 8007 5799 8055 5864 8072 5934 8073 6005
-8049 6089 7993 6165 7918 6231 7818 6293 7689 6354 7534 6416 7354 6468 7145 6512
-6913 6546 6657 6569 6381 6577 6065 6574 5733 6559 5404 6539 5047 6503 4644 6448
-4226 6380 3776 6294 3306 6200 2820 6105 2314 5991 1780 5867 1242 5721 682 5574
-105 5427 -479 5278 -1072 5124 -1688 4970 -2310 4810 -2927 4649 -3560 4503
--4180 4361 -4816 4223 -5419 4097 -6056 3987 -6659 3886 -7235 3801 -7873 3738
--8449 3689 -8948 3659 -9473 3643 -10044 3654 -10560 3688 -11019 3742 -11467 3817
--11931 3905 -12409 4008 -12869 4138 -13303 4267 -13719 4439 -14160 4629
--14622 4849 -15117 5093 -15622 5364 -16149 5645 -16681 5956 -17236 6309
--17809 6702 -18382 7145 -18963 7618 -19547 8114 -20118 8618 -20685 9157
--21246 9717 -21796 10298 -22317 10893 -22805 11479 -23268 12063 -23693 12658
--24080 13268 -24435 13860 -24743 14443 -25014 15065 -25234 15651 -25420 16192
--25548 16693 -25642 17159 -25680 17596 -25690 17992 -25675 18355 -25619 18679
--25519 18958 -25375 19201 -25189 19411 -24981 19595 -24754 19741 -24521 19861
--24261 19954 -23994 20024 -23718 20071 -23426 20102 -23140 20102 -22847 20094
--22551 20053 -22262 20006 -21980 19945 -21698 19862 -21415 19768 -21133 19662
--20849 19539 -20559 19400 -20271 19263 -19989 19099 -19712 18934 -19437 18753
--19144 18563 -18841 18364 -18542 18160 -18247 17944 -17971 17727 -17707 17499
--17439 17261 -17182 17019 -16929 16771 -16702 16526 -16499 16275 -16336 16019
--16205 15760 -16110 15501 -16058 15246 -16034 14998 -16047 14749 -16110 14511
--16229 14283 -16405 14061 -16627 13855 -16886 13658 -17190 13481 -17536 13320
--17911 13174 -18295 13044 -18777 12926 -19265 12829 -19751 12753 -20262 12696
--20789 12653 -21341 12625 -21901 12618 -22449 12627 -22987 12650 -23513 12689
--24036 12742 -24542 12804 -25025 12882 -25483 12969 -25909 13063 -26291 13164
--26628 13273 -26922 13383 -27162 13497 -27366 13612 -27520 13725 -27611 13835
--27647 13936 -27621 14028 -27535 14112 -27405 14186 -27236 14244 -27007 14291
--26723 14316 -26381 14329 -26005 14327 -25593 14300 -25146 14257 -24673 14193
--24167 14111 -23619 14009 -23060 13887 -22481 13753 -21901 13602 -21315 13435
--20720 13253 -20121 13060 -19531 12853 -18940 12638 -18358 12417 -17792 12184
--17243 11944 -16708 11709 -16197 11465 -15698 11217 -15220 10973 -14767 10726
--14340 10483 -13929 10249 -13541 10023 -13182 9803 -12837 9583 -12525 9366
--12242 9143 -11956 8942 -11696 8755 -11469 8577 -11258 8412 -11059 8255
--10874 8112 -10707 7978 -10558 7856 -10430 7743 -10319 7638 -10217 7546
--10121 7470 -10038 7403 -9967 7351 -9917 7304 -9875 7267 -9840 7240 -9811 7221
--9788 7215 -9776 7219 -9777 7231 -9789 7245 -9803 7270 -9817 7297 -9841 7335
--9868 7379 -9909 7428 -9955 7484 -10000 7539 -10047 7602 -10092 7663 -10149 7732
--10211 7802 -10276 7872 -10337 7945 -10393 8017 -10445 8094 -10507 8172
--10568 8245 -10631 8321 -10685 8396 -10728 8473 -10768 8546 -10806 8619
--10845 8690 -10873 8760 -10896 8828 -10909 8896 -10908 8962 -10908 9026
--10896 9086 -10877 9146 -10849 9202 -10813 9254 -10768 9308 -10713 9355
--10648 9400 -10574 9440 -10492 9477 -10408 9513 -10318 9543 -10214 9569
--10105 9594 -9984 9612 -9862 9628 -9741 9639 -9621 9644 -9488 9648 -9347 9646
--9204 9639 -9066 9629 -8930 9616 -8798 9600 -8663 9577 -8523 9550 -8384 9521
--8253 9488 -8129 9458 -8011 9424 -7896 9386 -7781 9343 -7672 9297 -7571 9257
--7480 9216 -7395 9174 -7317 9134 -7243 9089 -7180 9047 -7121 9007 -7071 8973
--7028 8942 -6993 8911 -6970 8881 -6950 8854 -6936 8832 -6927 8812 -6925 8798
--6932 8790 -6945 8785 -6965 8782 -6989 8784 -7014 8786 -7043 8791 -7079 8802
--7121 8820 -7167 8838 -7213 8859 -7259 8876 -7305 8897 -7357 8919 -7414 8948
--7472 8976 -7528 9002 -7577 9024 -7621 9046 -7673 9069 -7726 9094 -7777 9114
--7817 9134 -7852 9153 -7875 9167 -7902 9181 -7928 9192 -7945 9200 -7950 9209
--7941 9216 -7921 9224 -7894 9226 -7863 9226 -7819 9227 -7759 9228 -7686 9233
--7596 9238 -7494 9241 -7378 9243 -7250 9246 -7108 9254 -6952 9266 -6786 9280
--6600 9296 -6395 9315 -6176 9336 -5951 9362 -5726 9387 -5497 9418 -5242 9455
--4968 9495 -4690 9537 -4417 9581 -4156 9621 -3905 9666 -3636 9715 -3350 9769
--3076 9823 -2816 9872 -2585 9914 -2369 9956 -2155 10000 -1944 10045 -1745 10086
--1578 10119 -1441 10142 -1329 10159 -1242 10172 -1171 10183 -1122 10185
--1104 10178 -1110 10161 -1141 10139 -1210 10104 -1312 10060 -1438 10010
--1578 9950 -1725 9890 -1883 9822 -2087 9738 -2331 9646 -2583 9544 -2831 9448
--3045 9354 -3264 9258 -3519 9150 -3795 9033 -4063 8916 -4293 8809 -4465 8718
--4615 8632 -4775 8540 -4934 8444 -5059 8358 -5121 8293 -5107 8246 -5042 8216
--4956 8189 -4837 8169 -4661 8168 -4408 8188 -4079 8232 -3680 8295 -3223 8376
--2706 8475 -2115 8595 -1460 8736 -740 8895 51 9077 930 9287 1883 9518 2906 9771
-3979 10039 5078 10316 6237 10609 7492 10934 8828 11283 10204 11647 11601 12015
-12983 12376 14391 12747 15888 13145 17444 13561 19014 13982 20559 14392
-22046 14783 23525 15170 25055 15573 26616 15983 28147 16386 29618 16763
-30983 17109 32302 17437 33630 17766 34944 18088 36194 18388 37338 18653
-38352 18881 39276 19076 40164 19255 40994 19416 41697 19538 42287 19622
-42774 19668 43134 19680 43362 19656 43471 19595 43457 19501 43292 19371
-42979 19203 42553 18988 42027 18737 41291 18456 40318 18136 39259 17787
-38189 17421 36918 16999 35279 16525 33364 16061 31502 15587 29810 15039
-27975 14409 25547 13878 22408 13463 18985 12907 15914 12053 13567 11098
-11738 10441 9768 10222 6884 10127 2519 9673 -3514 8599 -11103 6968 -20000 5000
--19000 4000 -20000 5000 -20000 5000 -20000 5000 -19000 4000 -20000 5000
--20000 5000 -20000 5000 -20000 5000 -20000 5000 -20000 4000 -20000 5000
--19000 5000 -20000 5000 -20000 5000 -20000 5000 -20000 5000 -20000 4000
-21: 8500321 -6265803 -540 7476 -432 7415 -313 7343 -161 7261 -10 7170
-166 7081 342 6988 542 6890 747 6789 967 6687 1189 6584 1424 6484 1675 6381
-1931 6282 2201 6184 2485 6081 2770 5988 3054 5898 3340 5809 3642 5727 3945 5648
-4262 5566 4575 5496 4872 5437 5173 5377 5479 5334 5784 5285 6088 5252 6381 5229
-6658 5211 6917 5203 7175 5203 7423 5214 7662 5228 7882 5250 8081 5280 8256 5316
-8405 5362 8547 5423 8670 5488 8757 5557 8825 5618 8874 5688 8886 5763 8867 5846
-8833 5937 8768 6021 8683 6094 8567 6162 8418 6232 8254 6301 8047 6366 7820 6415
-7565 6457 7290 6483 6994 6498 6657 6495 6296 6489 5950 6468 5562 6434 5138 6380
-4684 6308 4211 6228 3720 6128 3198 6031 2656 5910 2094 5777 1528 5626 933 5470
-330 5316 -285 5162 -927 4998 -1565 4835 -2213 4664 -2882 4496 -3535 4333
--4204 4187 -4853 4043 -5506 3907 -6156 3788 -6775 3686 -7448 3593 -8095 3523
--8618 3475 -9162 3442 -9772 3425 -10327 3437 -10795 3471 -11254 3535 -11756 3613
--12259 3693 -12733 3812 -13152 3915 -13533 4084 -13950 4230 -14401 4425
--14900 4664 -15408 4903 -15917 5170 -16449 5460 -16977 5783 -17540 6147
--18130 6551 -18721 7005 -19325 7500 -19923 8011 -20521 8557 -21121 9107
--21699 9701 -22267 10322 -22812 10933 -23322 11539 -23802 12157 -24239 12783
--24641 13424 -25006 14045 -25319 14652 -25576 15308 -25794 15917 -25971 16487
--26096 17013 -26169 17509 -26197 17962 -26193 18378 -26162 18749 -26088 19072
--25964 19348 -25792 19584 -25578 19793 -25344 19975 -25090 20115 -24821 20218
--24537 20308 -24244 20369 -23943 20409 -23631 20424 -23314 20428 -23002 20398
--22692 20362 -22392 20306 -22099 20228 -21803 20140 -21513 20041 -21220 19926
--20925 19788 -20625 19656 -20332 19496 -20046 19336 -19760 19160 -19479 18968
--19177 18771 -18867 18566 -18552 18354 -18246 18137 -17961 17910 -17676 17670
--17398 17424 -17128 17177 -16858 16924 -16619 16667 -16402 16410 -16230 16147
--16088 15877 -15995 15612 -15937 15346 -15913 15089 -15936 14834 -15999 14588
--16134 14352 -16333 14124 -16574 13913 -16856 13715 -17190 13531 -17573 13369
--17978 13223 -18403 13090 -18925 12975 -19452 12884 -19989 12814 -20538 12762
--21111 12720 -21712 12700 -22319 12700 -22909 12720 -23490 12754 -24063 12804
--24626 12867 -25175 12939 -25700 13028 -26198 13127 -26651 13234 -27065 13349
--27428 13471 -27746 13598 -28009 13724 -28230 13849 -28391 13974 -28495 14095
--28524 14208 -28496 14311 -28398 14403 -28258 14486 -28068 14548 -27822 14597
--27514 14631 -27143 14643 -26732 14636 -26289 14607 -25806 14560 -25292 14490
--24747 14397 -24158 14284 -23555 14153 -22935 14006 -22312 13838 -21687 13656
--21051 13458 -20411 13248 -19783 13025 -19152 12792 -18538 12549 -17939 12297
--17360 12042 -16796 11784 -16254 11522 -15734 11258 -15235 10994 -14762 10731
--14315 10470 -13892 10222 -13494 9982 -13117 9750 -12766 9518 -12444 9284
--12157 9049 -11865 8840 -11601 8644 -11370 8458 -11156 8285 -10958 8123
--10774 7976 -10603 7837 -10456 7711 -10329 7596 -10217 7491 -10120 7399
--10023 7322 -9941 7255 -9873 7206 -9827 7163 -9785 7129 -9754 7104 -9726 7091
--9704 7088 -9695 7097 -9700 7114 -9711 7133 -9727 7164 -9745 7197 -9770 7239
--9802 7291 -9844 7346 -9895 7403 -9939 7467 -9989 7534 -10040 7603 -10099 7677
--10161 7752 -10233 7829 -10296 7904 -10355 7980 -10413 8061 -10474 8145
--10542 8223 -10605 8299 -10661 8382 -10710 8459 -10750 8535 -10791 8613
--10832 8686 -10861 8756 -10883 8826 -10897 8896 -10900 8964 -10896 9027
--10884 9090 -10862 9147 -10832 9205 -10794 9256 -10749 9308 -10691 9355
--10621 9403 -10542 9439 -10458 9475 -10370 9504 -10277 9534 -10171 9559
--10055 9580 -9931 9596 -9805 9608 -9681 9617 -9558 9620 -9422 9618 -9281 9613
--9134 9603 -8993 9590 -8860 9572 -8726 9554 -8593 9527 -8452 9496 -8317 9462
--8187 9428 -8065 9394 -7952 9359 -7843 9316 -7733 9272 -7628 9226 -7537 9181
--7450 9139 -7375 9098 -7304 9056 -7242 9011 -7187 8969 -7140 8930 -7099 8897
--7065 8866 -7042 8837 -7028 8810 -7022 8786 -7018 8767 -7020 8749 -7027 8738
--7042 8733 -7065 8732 -7097 8733 -7128 8740 -7159 8745 -7197 8755 -7239 8772
--7288 8793 -7339 8817 -7388 8841 -7438 8865 -7487 8888 -7539 8916 -7595 8948
--7656 8981 -7710 9011 -7756 9037 -7798 9063 -7846 9089 -7894 9116 -7939 9141
--7974 9163 -8000 9182 -8019 9200 -8039 9215 -8055 9227 -8064 9236 -8059 9246
--8043 9254 -8014 9262 -7978 9263 -7937 9263 -7883 9262 -7816 9263 -7734 9266
--7636 9271 -7525 9271 -7402 9271 -7266 9271 -7115 9278 -6956 9287 -6785 9300
--6593 9312 -6383 9327 -6159 9346 -5932 9368 -5706 9392 -5471 9419 -5218 9452
--4943 9490 -4665 9529 -4392 9570 -4133 9608 -3882 9648 -3614 9695 -3335 9747
--3060 9798 -2806 9846 -2576 9886 -2366 9925 -2157 9967 -1947 10011 -1755 10050
--1593 10081 -1459 10104 -1353 10120 -1268 10133 -1200 10143 -1159 10143
--1144 10137 -1151 10121 -1186 10099 -1256 10064 -1362 10021 -1487 9970
--1632 9913 -1778 9854 -1936 9787 -2140 9705 -2382 9612 -2635 9515 -2879 9418
--3095 9325 -3309 9233 -3564 9126 -3834 9010 -4099 8896 -4326 8789 -4494 8700
--4642 8615 -4797 8525 -4953 8430 -5073 8347 -5132 8280 -5116 8235 -5048 8205
--4960 8177 -4837 8159 -4658 8155 -4406 8177 -4077 8218 -3678 8281 -3225 8361
--2708 8457 -2123 8574 -1468 8713 -754 8870 30 9049 905 9254 1850 9482 2863 9730
-3925 9994 5015 10265 6162 10553 7403 10873 8725 11217 10088 11573 11467 11936
-12833 12291 14227 12653 15706 13045 17243 13454 18795 13866 20320 14270
-21789 14652 23249 15031 24760 15427 26299 15828 27812 16221 29263 16591
-30611 16928 31915 17248 33223 17567 34520 17879 35757 18171 36886 18428
-37885 18644 38800 18832 39677 19001 40496 19153 41192 19264 41774 19340
-42258 19375 42615 19377 42841 19341 42949 19272 42940 19167 42779 19027
-42473 18850 42056 18625 41541 18363 40808 18071 39857 17744 38822 17389
-37759 17015 36500 16587 34888 16108 33018 15634 31174 15168 29483 14611
-27658 13985 25276 13480 22212 13054 18849 12503 15810 11675 13465 10741
-11631 10110 9676 9930 6815 9888 2486 9493 -3524 8476 -11102 6891 -20000 5000
--20000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 5000 -20000 5000
--20000 5000 -20000 4000 -20000 5000 -19000 5000 -20000 5000 -20000 5000
-22: 8537140 -6258171 -248 7378 -130 7311 8 7234 167 7150 334 7056 524 6963
-712 6862 930 6758 1153 6655 1388 6547 1631 6437 1882 6336 2149 6226 2426 6122
-2715 6014 3018 5906 3315 5812 3623 5716 3932 5626 4243 5537 4576 5450 4911 5367
-5236 5292 5554 5230 5874 5168 6195 5122 6518 5071 6834 5037 7144 5011 7429 4989
-7709 4982 7974 4985 8229 4995 8477 5012 8706 5036 8912 5067 9085 5108 9244 5158
-9378 5220 9497 5290 9591 5365 9653 5436 9693 5510 9697 5596 9668 5688 9623 5783
-9544 5878 9445 5959 9317 6038 9148 6117 8961 6193 8740 6267 8488 6327 8210 6375
-7919 6408 7601 6427 7244 6434 6850 6428 6482 6416 6063 6380 5615 6326 5138 6256
-4642 6170 4117 6073 3562 5968 2989 5845 2402 5703 1796 5548 1173 5383 537 5219
--120 5056 -790 4888 -1448 4710 -2149 4531 -2845 4352 -3544 4178 -4242 4024
--4918 3869 -5612 3731 -6272 3603 -6972 3488 -7675 3394 -8263 3320 -8838 3264
--9483 3229 -10087 3218 -10575 3231 -11042 3266 -11576 3334 -12124 3406
--12607 3517 -13015 3580 -13383 3765 -13769 3855 -14216 4035 -14705 4258
--15203 4463 -15704 4703 -16197 4985 -16708 5291 -17253 5608 -17829 5971
--18431 6388 -19042 6859 -19675 7368 -20302 7926 -20931 8471 -21558 9068
--22156 9705 -22747 10329 -23321 10967 -23856 11615 -24357 12253 -24803 12909
--25218 13567 -25587 14221 -25900 14863 -26150 15546 -26367 16189 -26531 16802
--26648 17364 -26708 17885 -26724 18351 -26702 18771 -26647 19142 -26557 19460
--26409 19740 -26218 19976 -25971 20174 -25703 20348 -25420 20477 -25116 20575
--24803 20658 -24480 20709 -24156 20733 -23820 20753 -23478 20737 -23149 20708
--22819 20661 -22509 20589 -22199 20507 -21894 20415 -21599 20302 -21297 20172
--20998 20044 -20688 19886 -20386 19732 -20097 19559 -19809 19377 -19517 19179
--19211 18976 -18886 18762 -18556 18545 -18241 18317 -17941 18087 -17645 17840
--17357 17585 -17063 17329 -16778 17071 -16520 16805 -16288 16542 -16105 16270
--15957 15993 -15854 15717 -15795 15445 -15775 15176 -15797 14916 -15868 14659
--16020 14415 -16234 14183 -16497 13965 -16808 13763 -17171 13577 -17592 13410
--18033 13267 -18496 13137 -19060 13023 -19635 12939 -20214 12867 -20809 12816
--21434 12785 -22083 12776 -22736 12783 -23376 12816 -24005 12861 -24626 12918
--25230 12988 -25823 13076 -26393 13174 -26935 13287 -27416 13410 -27865 13540
--28261 13677 -28596 13822 -28885 13957 -29120 14094 -29293 14229 -29407 14363
--29436 14489 -29396 14604 -29292 14710 -29139 14796 -28929 14867 -28662 14920
--28326 14957 -27924 14968 -27474 14957 -26992 14930 -26477 14873 -25920 14795
--25331 14691 -24701 14572 -24049 14427 -23388 14264 -22722 14081 -22046 13883
--21371 13666 -20689 13440 -20016 13198 -19350 12943 -18704 12679 -18068 12410
--17458 12134 -16860 11853 -16295 11575 -15749 11293 -15225 11009 -14735 10727
--14271 10451 -13833 10185 -13424 9928 -13035 9685 -12676 9442 -12343 9195
--12052 8946 -11756 8727 -11490 8523 -11253 8330 -11040 8149 -10844 7982
--10658 7827 -10484 7687 -10339 7557 -10216 7441 -10107 7337 -10007 7243
--9915 7167 -9831 7103 -9768 7056 -9722 7016 -9686 6984 -9655 6961 -9628 6958
--9607 6958 -9605 6972 -9610 6995 -9622 7021 -9640 7055 -9662 7096 -9688 7145
--9721 7201 -9767 7261 -9821 7327 -9868 7396 -9917 7467 -9971 7544 -10035 7623
--10105 7703 -10175 7783 -10242 7865 -10305 7948 -10365 8031 -10429 8119
--10501 8201 -10569 8281 -10627 8364 -10677 8445 -10721 8528 -10762 8604
--10805 8682 -10837 8754 -10859 8825 -10873 8895 -10877 8964 -10870 9030
--10859 9091 -10835 9149 -10804 9207 -10764 9258 -10716 9306 -10654 9353
--10580 9400 -10499 9432 -10412 9467 -10321 9495 -10224 9521 -10115 9545
--9994 9562 -9867 9575 -9737 9583 -9610 9587 -9485 9588 -9350 9583 -9203 9572
--9059 9558 -8915 9542 -8782 9522 -8649 9500 -8515 9468 -8379 9433 -8247 9396
--8119 9358 -8004 9323 -7895 9284 -7789 9240 -7687 9192 -7592 9144 -7506 9098
--7429 9056 -7361 9014 -7302 8973 -7250 8927 -7206 8885 -7168 8847 -7141 8815
--7116 8786 -7103 8758 -7103 8735 -7108 8714 -7116 8698 -7128 8683 -7147 8676
--7172 8676 -7205 8679 -7245 8683 -7287 8694 -7327 8706 -7368 8720 -7418 8742
--7473 8769 -7528 8798 -7582 8827 -7635 8854 -7685 8882 -7738 8916 -7795 8954
--7854 8989 -7905 9023 -7950 9055 -7990 9083 -8033 9114 -8074 9145 -8112 9170
--8142 9195 -8160 9219 -8172 9237 -8183 9253 -8189 9265 -8190 9279 -8177 9286
--8150 9296 -8112 9303 -8068 9305 -8015 9303 -7950 9302 -7876 9301 -7784 9303
--7678 9305 -7560 9305 -7428 9300 -7284 9301 -7126 9304 -6962 9310 -6784 9320
--6587 9329 -6373 9341 -6146 9357 -5915 9375 -5686 9397 -5449 9420 -5196 9451
--4923 9485 -4642 9521 -4372 9559 -4114 9593 -3864 9631 -3599 9675 -3322 9724
--3051 9772 -2800 9818 -2576 9857 -2369 9893 -2164 9932 -1960 9976 -1774 10012
--1613 10043 -1486 10064 -1385 10080 -1303 10091 -1240 10100 -1202 10103
--1191 10094 -1199 10079 -1239 10057 -1311 10022 -1418 9980 -1547 9931
--1691 9874 -1837 9817 -1997 9749 -2200 9670 -2442 9580 -2691 9483 -2933 9387
--3146 9298 -3361 9205 -3608 9101 -3878 8987 -4135 8875 -4359 8770 -4528 8682
--4669 8599 -4818 8509 -4970 8416 -5085 8334 -5141 8268 -5121 8224 -5051 8193
--4962 8166 -4835 8148 -4653 8145 -4398 8165 -4072 8205 -3674 8267 -3220 8345
--2705 8440 -2125 8555 -1472 8690 -764 8846 15 9020 882 9222 1820 9446 2823 9690
-3876 9949 4954 10215 6089 10499 7314 10813 8623 11150 9969 11501 11334 11857
-12683 12205 14061 12562 15521 12946 17038 13348 18569 13753 20076 14148
-21526 14525 22966 14894 24455 15281 25973 15675 27468 16061 28897 16422
-30229 16751 31513 17061 32805 17373 34087 17676 35306 17958 36418 18207
-37406 18414 38309 18593 39174 18752 39986 18895 40673 18997 41253 19062
-41727 19090 42078 19081 42309 19034 42418 18953 42416 18840 42257 18691
-41955 18502 41558 18268 41043 17995 40324 17692 39397 17357 38383 16994
-37322 16612 36087 16176 34517 15688 32683 15210 30844 14741 29150 14174
-27361 13574 25051 13052 22063 12625 18739 12098 15710 11281 13352 10358
-11517 9760 9591 9637 6777 9660 2491 9328 -3487 8353 -11061 6769 -20000 5000
--19000 4000 -20000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 4000
--20000 5000 -19000 5000 -20000 5000 -20000 5000 -20000 5000 -20000 5000
--19000 5000 -20000 5000 -20000 5000 -20000 5000 -20000 5000 -19000 5000
--20000 4000 -20000 5000 -20000 5000 -19000 5000 -20000 5000
-23: 8573983 -6250543 51 7275 181 7207 330 7124 504 7032 688 6939 892 6841
-1096 6734 1319 6624 1567 6514 1814 6404 2079 6289 2357 6183 2631 6067 2927 5956
-3236 5842 3553 5734 3875 5625 4199 5532 4530 5436 4865 5343 5213 5249 5562 5163
-5914 5082 6248 5017 6581 4956 6916 4903 7256 4854 7592 4817 7916 4787 8218 4765
-8500 4759 8774 4760 9048 4769 9304 4789 9540 4819 9743 4852 9917 4892 10087 4947
-10223 5015 10336 5095 10427 5169 10482 5250 10512 5333 10507 5426 10476 5528
-10416 5634 10321 5739 10204 5827 10061 5917 9876 6007 9664 6093 9427 6173
-9155 6248 8855 6305 8540 6345 8195 6372 7817 6384 7396 6384 7002 6368 6555 6343
-6086 6290 5586 6218 5050 6132 4501 6031 3916 5924 3321 5795 2697 5648 2049 5483
-1395 5311 728 5142 33 4967 -658 4787 -1365 4605 -2107 4409 -2835 4220 -3571 4038
--4291 3870 -5013 3708 -5738 3564 -6449 3428 -7198 3304 -7860 3201 -8474 3119
--9167 3063 -9824 3026 -10345 3014 -10832 3031 -11392 3072 -11992 3134
--12500 3244 -12905 3280 -13256 3482 -13632 3498 -14074 3699 -14551 3888
--15029 4035 -15487 4266 -15949 4545 -16428 4819 -16940 5097 -17506 5412
--18098 5783 -18728 6222 -19370 6707 -20026 7261 -20693 7805 -21356 8416
--22002 9039 -22628 9666 -23243 10342 -23850 11025 -24404 11681 -24919 12340
--25380 13017 -25804 13710 -26172 14396 -26478 15088 -26733 15800 -26936 16494
--27106 17150 -27212 17739 -27258 18265 -27248 18737 -27214 19156 -27145 19528
--27041 19847 -26869 20129 -26647 20363 -26363 20555 -26061 20709 -25740 20839
--25400 20931 -25055 21002 -24708 21037 -24353 21065 -23992 21064 -23630 21051
--23279 21005 -22930 20942 -22609 20867 -22288 20779 -21976 20674 -21673 20548
--21364 20424 -21057 20272 -20747 20124 -20439 19952 -20139 19779 -19852 19588
--19555 19382 -19240 19172 -18902 18953 -18562 18723 -18231 18491 -17918 18257
--17613 18004 -17309 17743 -16994 17477 -16688 17212 -16407 16943 -16161 16669
--15963 16390 -15802 16106 -15695 15822 -15632 15538 -15608 15259 -15629 14989
--15712 14726 -15876 14474 -16111 14234 -16400 14013 -16739 13804 -17131 13618
--17591 13448 -18072 13307 -18569 13176 -19185 13068 -19807 12984 -20434 12912
--21078 12872 -21757 12851 -22455 12851 -23156 12872 -23848 12912 -24528 12962
--25190 13026 -25848 13112 -26491 13213 -27105 13326 -27687 13454 -28214 13591
--28691 13740 -29118 13889 -29481 14042 -29788 14192 -30043 14345 -30227 14496
--30347 14644 -30375 14785 -30333 14913 -30215 15023 -30048 15122 -29819 15198
--29527 15258 -29159 15291 -28724 15305 -28235 15294 -27714 15260 -27154 15199
--26557 15111 -25922 15002 -25245 14866 -24544 14709 -23834 14529 -23117 14331
--22400 14114 -21679 13880 -20956 13632 -20237 13368 -19531 13093 -18843 12809
--18176 12517 -17528 12221 -16906 11920 -16311 11622 -15741 11319 -15193 11015
--14685 10716 -14205 10421 -13754 10140 -13332 9867 -12933 9610 -12562 9353
--12227 9093 -11927 8832 -11628 8604 -11360 8389 -11123 8191 -10910 8005
--10711 7828 -10525 7670 -10353 7526 -10211 7394 -10086 7279 -9981 7171
--9882 7080 -9793 7006 -9712 6947 -9653 6899 -9605 6862 -9571 6834 -9543 6818
--9520 6818 -9501 6827 -9500 6845 -9507 6872 -9521 6904 -9543 6946 -9564 6994
--9591 7048 -9629 7111 -9677 7178 -9730 7252 -9783 7326 -9835 7401 -9890 7486
--9957 7570 -10031 7656 -10105 7740 -10177 7828 -10239 7915 -10303 8003
--10373 8092 -10448 8180 -10517 8267 -10580 8349 -10631 8434 -10678 8518
--10721 8598 -10765 8678 -10799 8753 -10824 8823 -10835 8895 -10837 8965
--10834 9031 -10819 9090 -10795 9149 -10764 9207 -10720 9254 -10669 9304
--10606 9349 -10528 9392 -10443 9424 -10352 9455 -10260 9483 -10159 9505
--10045 9524 -9920 9538 -9791 9547 -9659 9553 -9530 9552 -9402 9548 -9267 9540
--9119 9526 -8973 9506 -8830 9485 -8698 9461 -8568 9436 -8435 9401 -8303 9363
--8173 9322 -8050 9280 -7940 9241 -7839 9202 -7739 9154 -7645 9103 -7558 9054
--7482 9008 -7415 8965 -7356 8923 -7307 8881 -7269 8837 -7235 8796 -7211 8758
--7194 8728 -7182 8701 -7181 8676 -7194 8655 -7210 8638 -7231 8625 -7255 8615
--7284 8613 -7318 8616 -7365 8624 -7414 8634 -7465 8650 -7512 8667 -7561 8686
--7617 8713 -7676 8745 -7735 8780 -7796 8815 -7849 8847 -7901 8880 -7955 8920
--8012 8962 -8068 9003 -8115 9041 -8158 9075 -8195 9110 -8233 9143 -8266 9175
--8296 9206 -8321 9232 -8333 9259 -8335 9279 -8334 9296 -8333 9310 -8323 9323
--8299 9332 -8264 9342 -8217 9349 -8161 9351 -8097 9347 -8024 9344 -7939 9343
--7837 9343 -7723 9343 -7596 9341 -7456 9335 -7305 9332 -7140 9330 -6970 9335
--6784 9342 -6584 9348 -6366 9357 -6135 9369 -5902 9384 -5668 9401 -5431 9423
--5178 9449 -4902 9481 -4627 9512 -4356 9546 -4099 9579 -3850 9613 -3589 9655
--3317 9701 -3047 9746 -2804 9789 -2580 9825 -2379 9860 -2179 9897 -1981 9938
--1799 9975 -1644 10003 -1522 10023 -1423 10038 -1347 10048 -1287 10057
--1255 10058 -1246 10051 -1259 10037 -1299 10013 -1373 9979 -1483 9938
--1613 9890 -1758 9834 -1905 9778 -2063 9713 -2266 9634 -2503 9545 -2755 9451
--2993 9356 -3202 9269 -3414 9179 -3658 9075 -3923 8964 -4175 8853 -4392 8750
--4559 8664 -4695 8581 -4844 8494 -4985 8403 -5096 8321 -5147 8256 -5125 8212
--5053 8182 -4956 8156 -4829 8138 -4645 8134 -4388 8153 -4061 8193 -3665 8252
--3212 8330 -2697 8423 -2119 8536 -1471 8670 -769 8820 3 8993 863 9189 1792 9410
-2786 9650 3830 9905 4895 10166 6017 10445 7231 10753 8519 11085 9852 11429
-11198 11779 12530 12121 13892 12471 15332 12848 16830 13243 18338 13641
-19825 14030 21254 14398 22676 14760 24144 15139 25640 15525 27113 15903
-28521 16257 29835 16577 31102 16880 32376 17181 33637 17478 34840 17752
-35938 17991 36913 18191 37803 18359 38659 18511 39458 18642 40140 18736
-40717 18792 41184 18812 41536 18790 41762 18735 41875 18643 41877 18522
-41726 18362 41436 18164 41046 17918 40542 17634 39836 17320 38939 16975
-37934 16605 36884 16213 35683 15768 34162 15270 32344 14787 30503 14305
-28824 13749 27097 13143 24873 12607 21945 12203 18636 11688 15585 10854
-13212 9936 11406 9392 9536 9342 6780 9427 2545 9152 -3396 8240 -10965 6612
--20000 4000 -19000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 5000
--19000 4000 -20000 5000 -20000 5000 -20000 5000 -19000 5000 -20000 5000
--20000 5000 -19000 5000 -20000 5000 -20000 5000 -19000 5000 -20000 5000
-24: 8610845 -6242918 362 7170 496 7099 661 7013 849 6915 1041 6815 1261 6707
-1483 6605 1726 6491 1984 6374 2254 6254 2536 6141 2827 6023 3126 5908 3438 5783
-3761 5672 4102 5553 4441 5444 4779 5340 5134 5238 5489 5142 5860 5044 6229 4954
-6596 4871 6947 4803 7293 4736 7647 4679 8008 4633 8357 4590 8697 4556 9008 4537
-9303 4532 9586 4530 9868 4541 10137 4562 10374 4595 10585 4630 10760 4674
-10925 4735 11070 4808 11182 4892 11269 4977 11314 5063 11339 5152 11326 5255
-11278 5369 11207 5486 11099 5600 10966 5700 10799 5801 10600 5903 10361 6001
-10102 6091 9817 6177 9489 6241 9152 6296 8782 6330 8376 6343 7942 6354
-7505 6343 7046 6320 6545 6271 6012 6197 5449 6108 4877 6009 4266 5895 3634 5763
-2973 5609 2295 5439 1602 5261 905 5080 189 4892 -548 4702 -1313 4510 -2079 4308
--2851 4103 -3613 3907 -4365 3728 -5138 3563 -5899 3399 -6659 3264 -7396 3130
--8061 3016 -8803 2935 -9537 2870 -10113 2825 -10613 2814 -11199 2843 -11845 2882
--12399 2981 -12809 3008 -13161 3223 -13546 3180 -13987 3409 -14457 3543
--14899 3649 -15293 3867 -15702 4134 -16143 4377 -16628 4612 -17168 4896
--17759 5223 -18382 5607 -19032 6049 -19709 6572 -20399 7107 -21092 7720
--21779 8341 -22455 8960 -23112 9657 -23762 10377 -24386 11065 -24954 11734
--25482 12416 -25953 13130 -26384 13862 -26762 14589 -27069 15321 -27322 16079
--27554 16828 -27704 17508 -27771 18100 -27790 18632 -27788 19110 -27743 19540
--27661 19918 -27529 20249 -27327 20522 -27065 20752 -26749 20930 -26403 21083
--26041 21202 -25677 21283 -25303 21336 -24927 21371 -24537 21381 -24147 21376
--23760 21340 -23391 21281 -23030 21217 -22693 21135 -22362 21031 -22044 20918
--21736 20800 -21419 20654 -21108 20506 -20793 20343 -20485 20171 -20184 19987
--19895 19786 -19588 19577 -19268 19355 -18919 19127 -18566 18899 -18220 18665
--17896 18422 -17579 18161 -17246 17893 -16917 17619 -16588 17351 -16286 17079
--16020 16795 -15798 16510 -15627 16215 -15514 15918 -15440 15625 -15414 15337
--15434 15054 -15527 14784 -15703 14523 -15963 14280 -16276 14051 -16641 13845
--17074 13654 -17569 13484 -18091 13338 -18628 13208 -19298 13104 -19965 13020
--20643 12958 -21343 12933 -22073 12920 -22824 12929 -23584 12953 -24329 12999
--25055 13057 -25772 13138 -26479 13237 -27171 13357 -27835 13484 -28461 13627
--29035 13778 -29547 13937 -30001 14105 -30393 14267 -30728 14435 -30997 14606
--31196 14778 -31323 14937 -31352 15096 -31300 15230 -31169 15353 -30982 15457
--30733 15542 -30419 15603 -30013 15642 -29547 15656 -29011 15646 -28446 15601
--27846 15537 -27201 15443 -26519 15321 -25792 15170 -25034 14997 -24274 14802
--23508 14587 -22745 14349 -21972 14094 -21202 13822 -20438 13537 -19694 13242
--18967 12934 -18254 12621 -17577 12302 -16926 11984 -16306 11661 -15708 11338
--15139 11015 -14608 10694 -14113 10381 -13650 10082 -13220 9796 -12805 9523
--12428 9251 -12091 8981 -11781 8706 -11481 8468 -11211 8246 -10976 8041
--10762 7847 -10564 7664 -10378 7503 -10210 7356 -10066 7223 -9943 7106
--9842 6999 -9746 6911 -9659 6837 -9581 6780 -9522 6737 -9479 6704 -9446 6681
--9419 6669 -9397 6674 -9384 6689 -9385 6718 -9393 6748 -9406 6785 -9428 6836
--9453 6891 -9483 6952 -9523 7020 -9575 7097 -9623 7174 -9684 7256 -9738 7339
--9798 7428 -9865 7519 -9941 7609 -10021 7700 -10094 7792 -10163 7883 -10228 7976
--10300 8069 -10379 8160 -10453 8250 -10519 8338 -10572 8424 -10623 8512
--10666 8594 -10712 8672 -10747 8750 -10772 8823 -10785 8895 -10788 8964
--10782 9030 -10767 9091 -10742 9149 -10708 9202 -10665 9250 -10608 9300
--10543 9342 -10463 9381 -10374 9412 -10280 9440 -10182 9464 -10080 9485
--9964 9498 -9836 9509 -9703 9513 -9568 9514 -9439 9510 -9312 9502 -9174 9490
--9025 9469 -8880 9447 -8739 9420 -8606 9392 -8480 9363 -8350 9326 -8223 9283
--8098 9237 -7981 9193 -7877 9152 -7782 9110 -7692 9058 -7607 9008 -7529 8958
--7464 8908 -7409 8865 -7359 8826 -7321 8782 -7296 8739 -7277 8698 -7267 8665
--7260 8636 -7262 8611 -7276 8589 -7300 8571 -7330 8559 -7364 8549 -7401 8545
--7437 8547 -7485 8554 -7543 8568 -7603 8585 -7661 8605 -7716 8628 -7773 8654
--7834 8685 -7899 8725 -7963 8764 -8027 8806 -8082 8843 -8135 8883 -8189 8925
--8243 8974 -8298 9021 -8342 9062 -8382 9103 -8414 9139 -8444 9176 -8472 9212
--8493 9245 -8511 9276 -8513 9304 -8508 9325 -8496 9345 -8486 9359 -8462 9371
--8428 9383 -8383 9392 -8326 9399 -8260 9400 -8186 9396 -8100 9391 -8005 9387
--7894 9386 -7771 9385 -7636 9379 -7489 9371 -7328 9366 -7157 9360 -6979 9362
--6788 9365 -6582 9369 -6361 9375 -6127 9380 -5892 9394 -5655 9407 -5418 9426
--5162 9448 -4889 9475 -4613 9505 -4344 9535 -4090 9564 -3843 9595 -3585 9634
--3316 9676 -3053 9719 -2811 9759 -2595 9793 -2397 9826 -2200 9861 -2009 9899
--1833 9936 -1684 9962 -1564 9980 -1472 9995 -1399 10004 -1344 10013 -1314 10014
--1311 10007 -1327 9991 -1369 9969 -1445 9936 -1556 9895 -1686 9848 -1832 9794
--1979 9738 -2138 9675 -2336 9597 -2572 9511 -2822 9418 -3057 9325 -3262 9239
--3472 9151 -3710 9050 -3970 8941 -4217 8831 -4429 8731 -4589 8645 -4722 8565
--4863 8479 -5001 8388 -5105 8309 -5153 8245 -5127 8201 -5048 8172 -4949 8145
--4818 8128 -4633 8123 -4372 8141 -4045 8182 -3651 8240 -3196 8315 -2687 8406
--2110 8516 -1466 8648 -768 8796 -3 8965 849 9158 1768 9375 2753 9611 3784 9860
-4839 10117 5947 10390 7146 10694 8419 11020 9734 11358 11063 11701 12376 12038
-13721 12382 15139 12751 16617 13140 18103 13530 19568 13913 20975 14272
-22376 14628 23826 15000 25297 15379 26747 15748 28137 16094 29429 16407
-30677 16702 31935 16996 33174 17285 34360 17551 35443 17782 36405 17973
-37284 18133 38128 18276 38921 18397 39593 18482 40161 18531 40628 18540
-40978 18511 41203 18444 41320 18345 41328 18212 41185 18044 40905 17835
-40528 17578 40032 17281 39348 16958 38473 16602 37477 16223 36451 15822
-35291 15365 33809 14857 31993 14362 30154 13876 28517 13325 26874 12693
-24730 12171 21831 11792 18500 11249 15424 10381 13067 9492 11324 9025
-9529 9038 6839 9135 2654 8866 -3260 8030 -10805 6620 -20000 4000 -19000 5000
--20000 5000 -19000 5000 -20000 5000 -19000 5000 -20000 4000 -20000 5000
--19000 5000 -20000 5000 -20000 5000 -20000 5000 -19000 5000 -20000 5000
--20000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 5000 -19000 5000
--20000 5000 -20000 6000 -19000 5000 -20000 5000
-25: 8647713 -6235298 675 7066 821 6987 999 6900 1196 6792 1409 6688 1635 6580
-1873 6471 2136 6355 2413 6228 2697 6104 2997 5983 3303 5863 3619 5742 3953 5613
-4299 5493 4659 5371 5016 5256 5373 5147 5749 5040 6117 4938 6506 4837 6900 4741
-7284 4654 7652 4580 8020 4512 8387 4453 8763 4406 9127 4357 9477 4323 9805 4303
-10113 4295 10405 4300 10699 4309 10967 4332 11214 4363 11430 4405 11611 4452
-11779 4518 11921 4597 12028 4688 12104 4783 12149 4874 12167 4973 12144 5089
-12082 5211 11996 5336 11874 5460 11718 5578 11536 5690 11320 5801 11058 5913
-10778 6020 10464 6118 10117 6195 9750 6255 9361 6298 8925 6323 8469 6337
-8016 6340 7524 6314 6985 6268 6425 6195 5846 6106 5240 6002 4603 5888 3922 5748
-3240 5589 2533 5412 1802 5229 1069 5031 324 4837 -475 4636 -1266 4435 -2071 4219
--2879 4000 -3670 3793 -4479 3603 -5280 3415 -6074 3262 -6865 3093 -7605 2967
--8381 2855 -9193 2748 -9863 2676 -10387 2638 -10990 2636 -11679 2659 -12292 2733
--12726 2755 -13080 2968 -13484 2911 -13964 3137 -14438 3249 -14831 3312
--15159 3516 -15475 3758 -15863 3958 -16330 4159 -16860 4423 -17428 4725
--18040 5050 -18684 5425 -19355 5878 -20066 6378 -20779 6973 -21491 7601
--22193 8223 -22896 8933 -23598 9672 -24270 10389 -24905 11084 -25494 11786
--26033 12513 -26526 13260 -26978 14014 -27362 14772 -27678 15527 -27960 16379
--28123 17160 -28247 17845 -28339 18453 -28387 19001 -28362 19505 -28272 19949
--28166 20339 -28008 20666 -27782 20931 -27482 21145 -27142 21322 -26758 21458
--26358 21560 -25953 21625 -25537 21669 -25123 21688 -24699 21683 -24286 21658
--23879 21609 -23484 21551 -23108 21479 -22753 21382 -22418 21272 -22096 21164
--21783 21028 -21467 20879 -21151 20726 -20833 20553 -20529 20372 -20226 20180
--19933 19970 -19626 19757 -19296 19530 -18935 19300 -18574 19072 -18211 18828
--17874 18578 -17535 18312 -17186 18040 -16834 17763 -16478 17484 -16148 17206
--15858 16918 -15618 16621 -15430 16315 -15300 16011 -15224 15705 -15192 15406
--15211 15116 -15312 14836 -15498 14566 -15780 14322 -16121 14087 -16522 13876
--16989 13686 -17522 13514 -18092 13365 -18666 13236 -19393 13133 -20117 13056
--20845 13011 -21596 12989 -22382 12983 -23194 12996 -24014 13028 -24815 13080
--25595 13153 -26366 13255 -27123 13371 -27866 13503 -28589 13648 -29256 13801
--29879 13964 -30434 14137 -30916 14320 -31335 14502 -31694 14694 -31985 14883
--32205 15069 -32333 15242 -32363 15412 -32303 15557 -32155 15691 -31945 15807
--31680 15896 -31334 15964 -30896 16011 -30381 16022 -29807 16006 -29194 15963
--28549 15890 -27855 15784 -27114 15647 -26333 15483 -25523 15293 -24707 15081
--23893 14846 -23074 14584 -22249 14308 -21436 14014 -20623 13708 -19833 13388
--19058 13060 -18315 12722 -17603 12379 -16920 12036 -16267 11692 -15651 11345
--15059 11005 -14504 10664 -13999 10330 -13519 10015 -13077 9711 -12658 9421
--12271 9139 -11928 8854 -11620 8569 -11315 8321 -11044 8093 -10808 7876
--10598 7677 -10404 7492 -10217 7324 -10049 7176 -9908 7042 -9791 6924
--9688 6820 -9600 6732 -9512 6660 -9436 6607 -9384 6567 -9339 6541 -9310 6524
--9284 6515 -9263 6527 -9254 6547 -9255 6584 -9264 6623 -9281 6671 -9303 6722
--9325 6786 -9362 6857 -9403 6933 -9457 7015 -9507 7098 -9568 7187 -9627 7278
--9686 7370 -9760 7469 -9838 7564 -9919 7660 -9997 7759 -10069 7853 -10140 7951
--10213 8048 -10296 8142 -10376 8236 -10441 8327 -10501 8417 -10552 8503
--10598 8591 -10645 8670 -10682 8747 -10709 8822 -10721 8894 -10724 8963
--10718 9030 -10703 9089 -10676 9144 -10637 9198 -10594 9246 -10537 9292
--10465 9330 -10383 9365 -10291 9396 -10194 9419 -10092 9442 -9987 9459
--9871 9467 -9741 9472 -9602 9473 -9468 9469 -9337 9460 -9208 9449 -9071 9430
--8924 9406 -8778 9378 -8637 9348 -8510 9315 -8386 9281 -8263 9239 -8139 9194
--8021 9145 -7910 9098 -7815 9052 -7727 9008 -7646 8955 -7570 8903 -7507 8851
--7451 8803 -7408 8758 -7371 8718 -7347 8676 -7334 8634 -7330 8596 -7334 8562
--7342 8539 -7356 8517 -7383 8497 -7422 8483 -7467 8475 -7515 8472 -7563 8473
--7612 8478 -7670 8492 -7739 8510 -7810 8535 -7878 8562 -7941 8590 -8004 8621
--8069 8660 -8142 8706 -8210 8753 -8277 8799 -8333 8843 -8386 8888 -8439 8936
--8493 8990 -8544 9041 -8585 9091 -8618 9132 -8645 9174 -8671 9214 -8690 9254
--8703 9291 -8710 9323 -8704 9353 -8691 9378 -8669 9397 -8644 9413 -8611 9426
--8565 9437 -8508 9447 -8440 9453 -8365 9453 -8278 9448 -8182 9443 -8073 9435
--7956 9432 -7825 9428 -7679 9421 -7522 9410 -7355 9401 -7177 9393 -6990 9389
--6795 9391 -6586 9392 -6360 9392 -6121 9396 -5882 9403 -5647 9415 -5408 9428
--5151 9448 -4880 9471 -4605 9497 -4337 9523 -4086 9548 -3841 9577 -3588 9613
--3323 9652 -3065 9691 -2828 9729 -2617 9760 -2423 9790 -2231 9825 -2044 9862
--1874 9894 -1733 9920 -1618 9938 -1529 9949 -1460 9960 -1410 9968 -1384 9968
--1382 9961 -1404 9947 -1448 9924 -1526 9892 -1635 9852 -1768 9805 -1915 9753
--2058 9698 -2218 9636 -2415 9561 -2647 9476 -2892 9384 -3126 9295 -3327 9210
--3530 9124 -3765 9024 -4018 8917 -4261 8810 -4466 8712 -4621 8627 -4747 8549
--4884 8463 -5015 8376 -5112 8296 -5153 8233 -5123 8192 -5042 8161 -4940 8136
--4804 8117 -4613 8114 -4354 8130 -4023 8170 -3630 8226 -3178 8301 -2669 8389
--2094 8498 -1457 8626 -763 8771 -5 8938 839 9128 1750 9339 2723 9571 3742 9816
-4786 10068 5879 10337 7063 10635 8317 10955 9617 11287 10926 11625 12221 11954
-13546 12292 14945 12657 16397 13037 17864 13421 19304 13795 20693 14149
-22069 14499 23497 14862 24945 15234 26371 15597 27739 15935 29013 16241
-30241 16529 31476 16815 32699 17096 33865 17356 34934 17579 35881 17762
-36750 17915 37582 18049 38365 18161 39029 18239 39594 18279 40055 18281
-40405 18242 40633 18166 40755 18058 40763 17914 40635 17737 40364 17518
-39997 17249 39517 16942 38860 16605 37993 16240 37011 15852 36025 15440
-34909 14970 33443 14451 31632 13941 29806 13460 28237 12889 26686 12245
-24596 11758 21691 11373 18326 10766 15247 9878 12942 9060 11294 8683 9592 8712
-6971 8744 2808 8380 -3111 7465 -10575 6082 -19000 5000 -20000 5000 -19000 5000
--20000 5000 -19000 5000 -20000 4000 -20000 5000 -19000 5000 -20000 5000
--20000 5000 -19000 5000 -20000 5000 -20000 6000 -19000 5000 -20000 5000
--20000 5000 -19000 5000 -20000 6000
-26: 8684579 -6227683 996 6958 1150 6880 1336 6782 1553 6671 1779 6560
-2020 6449 2268 6335 2548 6212 2846 6082 3146 5953 3464 5821 3786 5702 4123 5571
-4474 5442 4840 5313 5217 5184 5597 5065 5976 4951 6364 4836 6757 4731 7157 4623
-7572 4525 7980 4435 8364 4355 8745 4282 9133 4224 9523 4173 9902 4119 10269 4086
-10606 4067 10922 4055 11228 4058 11530 4073 11807 4095 12063 4129 12278 4179
-12468 4228 12631 4297 12771 4384 12875 4481 12946 4582 12984 4684 12993 4793
-12964 4918 12886 5052 12785 5194 12640 5328 12473 5456 12266 5583 12032 5707
-11755 5836 11440 5956 11104 6067 10730 6158 10340 6231 9926 6282 9466 6320
-8982 6341 8513 6347 7986 6332 7417 6283 6839 6213 6233 6124 5591 6016 4915 5901
-4210 5756 3497 5588 2752 5404 1990 5211 1218 5004 417 4801 -405 4587 -1227 4375
--2077 4148 -2912 3911 -3761 3699 -4620 3476 -5439 3310 -6264 3094 -7080 2962
--7901 2826 -8777 2674 -9552 2571 -10150 2509 -10759 2476 -11493 2459 -12167 2497
--12650 2522 -13011 2702 -13438 2685 -13977 2880 -14493 3008 -14861 3023
--15092 3209 -15309 3431 -15622 3575 -16067 3740 -16590 3999 -17157 4278
--17735 4562 -18337 4866 -18982 5218 -19674 5650 -20398 6185 -21129 6829
--21858 7462 -22588 8173 -23325 8921 -24059 9647 -24754 10368 -25407 11126
--26029 11876 -26591 12619 -27114 13363 -27590 14127 -27979 14909 -28308 15721
--28511 16680 -28719 17471 -28905 18181 -28995 18827 -28951 19419 -28867 19944
--28793 20405 -28668 20786 -28500 21097 -28250 21352 -27940 21549 -27549 21717
--27108 21826 -26655 21904 -26197 21960 -25742 21984 -25301 21974 -24853 21960
--24414 21918 -23971 21871 -23551 21807 -23157 21718 -22795 21616 -22456 21512
--22132 21386 -21822 21240 -21500 21092 -21185 20924 -20874 20743 -20566 20556
--20269 20358 -19974 20147 -19666 19930 -19325 19703 -18956 19470 -18581 19231
--18209 18980 -17846 18725 -17493 18457 -17123 18180 -16741 17898 -16354 17612
--15994 17325 -15678 17029 -15418 16727 -15212 16413 -15064 16095 -14974 15783
--14936 15474 -14957 15174 -15060 14885 -15262 14613 -15565 14357 -15932 14118
--16370 13902 -16880 13709 -17455 13535 -18067 13384 -18688 13263 -19471 13157
--20255 13098 -21039 13059 -21844 13036 -22688 13037 -23562 13053 -24442 13094
--25305 13167 -26145 13259 -26968 13376 -27778 13508 -28584 13654 -29358 13807
--30075 13973 -30747 14150 -31348 14340 -31866 14543 -32315 14756 -32696 14964
--33010 15167 -33242 15366 -33379 15554 -33410 15733 -33337 15893 -33176 16043
--32945 16166 -32650 16268 -32274 16346 -31803 16393 -31241 16404 -30618 16389
--29957 16337 -29255 16252 -28515 16132 -27718 15982 -26879 15804 -26007 15599
--25134 15362 -24262 15105 -23388 14824 -22512 14527 -21642 14209 -20788 13878
--19946 13534 -19127 13180 -18348 12815 -17599 12450 -16887 12081 -16205 11713
--15559 11347 -14948 10980 -14377 10620 -13851 10269 -13366 9934 -12908 9615
--12483 9309 -12090 9013 -11748 8713 -11437 8421 -11128 8162 -10859 7922
--10624 7700 -10418 7497 -10223 7306 -10042 7133 -9877 6985 -9739 6852
--9625 6733 -9524 6630 -9437 6546 -9354 6477 -9282 6428 -9231 6393 -9190 6370
--9159 6360 -9135 6360 -9120 6375 -9110 6406 -9112 6446 -9121 6495 -9140 6551
--9164 6610 -9190 6681 -9224 6762 -9269 6846 -9323 6934 -9378 7024 -9437 7118
--9498 7219 -9562 7317 -9638 7418 -9718 7520 -9804 7624 -9883 7726 -9960 7826
--10032 7928 -10113 8029 -10198 8128 -10279 8225 -10353 8316 -10415 8408
--10466 8499 -10515 8586 -10564 8669 -10602 8745 -10632 8820 -10644 8893
--10647 8961 -10640 9026 -10624 9086 -10595 9140 -10554 9191 -10510 9239
--10451 9279 -10374 9316 -10291 9348 -10195 9374 -10095 9394 -9988 9413
--9884 9425 -9764 9431 -9632 9430 -9491 9426 -9356 9416 -9224 9404 -9094 9387
--8958 9364 -8812 9334 -8668 9301 -8531 9264 -8406 9228 -8288 9190 -8169 9144
--8052 9095 -7940 9043 -7838 8992 -7752 8943 -7674 8896 -7601 8844 -7539 8789
--7489 8736 -7445 8686 -7413 8643 -7391 8603 -7382 8563 -7384 8522 -7394 8486
--7415 8456 -7436 8434 -7465 8416 -7505 8402 -7561 8393 -7623 8389 -7683 8389
--7744 8397 -7804 8409 -7875 8429 -7954 8454 -8036 8485 -8114 8518 -8185 8552
--8255 8592 -8326 8636 -8403 8689 -8475 8743 -8545 8796 -8602 8846 -8656 8897
--8707 8952 -8758 9009 -8805 9067 -8842 9121 -8872 9168 -8891 9214 -8909 9258
--8921 9301 -8925 9341 -8920 9376 -8905 9408 -8883 9433 -8850 9455 -8813 9472
--8766 9486 -8710 9496 -8641 9505 -8561 9513 -8472 9510 -8376 9504 -8269 9495
--8150 9488 -8019 9481 -7880 9476 -7727 9466 -7559 9451 -7385 9438 -7199 9427
--7008 9422 -6805 9418 -6591 9414 -6361 9413 -6120 9411 -5879 9415 -5643 9421
--5403 9434 -5144 9447 -4876 9467 -4603 9489 -4336 9511 -4089 9533 -3846 9558
--3597 9591 -3336 9627 -3085 9664 -2852 9699 -2648 9727 -2456 9754 -2272 9788
--2089 9821 -1925 9853 -1790 9878 -1679 9894 -1596 9904 -1531 9915 -1485 9922
--1463 9922 -1464 9916 -1488 9901 -1535 9878 -1614 9848 -1725 9808 -1857 9762
--2003 9713 -2147 9658 -2304 9597 -2500 9524 -2726 9441 -2968 9352 -3198 9265
--3394 9181 -3593 9097 -3822 8999 -4068 8893 -4306 8790 -4504 8692 -4653 8610
--4772 8534 -4901 8449 -5026 8362 -5117 8285 -5152 8223 -5118 8181 -5033 8152
--4924 8127 -4784 8107 -4590 8103 -4328 8121 -3996 8158 -3606 8214 -3153 8286
--2647 8373 -2072 8479 -1439 8604 -753 8748 -1 8910 831 9096 1735 9305 2698 9531
-3704 9771 4735 10020 5814 10283 6980 10575 8219 10891 9498 11217 10788 11547
-12065 11872 13369 12204 14746 12561 16175 12936 17617 13312 19036 13680
-20400 14028 21754 14370 23161 14728 24582 15093 25987 15447 27329 15780
-28583 16079 29789 16359 31007 16639 32209 16914 33355 17165 34409 17383
-35344 17559 36199 17703 37019 17832 37792 17937 38449 18009 39007 18041
-39469 18032 39820 17985 40047 17900 40172 17783 40188 17631 40071 17444
-39816 17215 39456 16934 38993 16615 38361 16268 37506 15892 36545 15493
-35598 15070 34526 14587 33068 14052 31259 13536 29474 13049 27987 12448
-26512 11820 24443 11357 21508 10923 18128 10249 15080 9384 12869 8672
-11345 8369 9748 8360 7184 8288 3025 7878 -2910 7110 -10403 6100 -19000 5000
--20000 5000 -19000 5000 -20000 4000 -19000 5000 -20000 5000 -19000 5000
--19000 5000 -20000 5000 -20000 5000 -20000 5000 -19000 6000 -20000 5000
--19000 5000 -20000 5000 -20000 5000 -19000 6000 -20000 5000
-27: 8721441 -6220070 1321 6849 1482 6769 1680 6663 1914 6551 2152 6431
-2403 6317 2671 6196 2965 6070 3282 5932 3597 5799 3937 5661 4278 5534 4629 5399
-4996 5263 5385 5131 5783 4995 6185 4869 6582 4750 6983 4631 7397 4518 7816 4408
-8249 4305 8674 4212 9077 4129 9479 4052 9881 3989 10284 3932 10682 3883
-11060 3846 11411 3821 11741 3812 12058 3811 12367 3829 12648 3858 12910 3890
-13131 3943 13326 4000 13486 4074 13620 4169 13727 4271 13791 4383 13821 4492
-13819 4610 13778 4746 13691 4894 13568 5052 13406 5201 13219 5341 12997 5480
-12730 5618 12439 5767 12098 5906 11735 6030 11335 6133 10917 6223 10473 6287
-10002 6329 9481 6359 8989 6376 8437 6366 7853 6322 7242 6252 6599 6159
-5915 6053 5222 5932 4499 5783 3736 5612 2951 5417 2155 5214 1344 5001 502 4780
--331 4563 -1199 4328 -2094 4089 -2975 3846 -3887 3599 -4767 3411 -5609 3146
--6481 3012 -7357 2831 -8273 2653 -9161 2524 -9862 2429 -10505 2350 -11267 2302
--12026 2284 -12571 2317 -12951 2438 -13402 2486 -13998 2619 -14601 2822
--14985 2774 -15141 2932 -15236 3158 -15461 3248 -15871 3362 -16392 3617
--16942 3894 -17485 4141 -18014 4369 -18587 4619 -19232 4965 -19936 5429
--20671 6037 -21422 6675 -22184 7376 -22959 8136 -23735 8863 -24497 9581
--25231 10398 -25918 11202 -26575 11962 -27186 12673 -27735 13410 -28218 14210
--28632 15059 -28959 15959 -29196 16946 -29427 17770 -29529 18545 -29461 19254
--29439 19884 -29435 20423 -29327 20875 -29219 21235 -29030 21534 -28779 21774
--28378 21954 -27912 22091 -27430 22175 -26915 22235 -26437 22270 -25949 22263
--25468 22244 -24977 22216 -24493 22174 -24032 22121 -23599 22041 -23192 21947
--22825 21846 -22482 21726 -22159 21581 -21845 21437 -21530 21276 -21212 21104
--20901 20918 -20598 20730 -20300 20530 -20013 20318 -19709 20096 -19363 19864
--18985 19621 -18587 19376 -18199 19125 -17820 18864 -17451 18595 -17056 18309
--16641 18019 -16221 17732 -15829 17437 -15482 17136 -15193 16832 -14966 16510
--14799 16186 -14697 15865 -14651 15540 -14665 15233 -14769 14933 -14989 14650
--15311 14384 -15717 14139 -16183 13920 -16736 13722 -17358 13548 -18020 13400
--18697 13280 -19535 13185 -20376 13134 -21218 13095 -22086 13078 -22993 13079
--23929 13107 -24872 13168 -25797 13262 -26694 13372 -27579 13500 -28457 13640
--29313 13797 -30144 13962 -30922 14143 -31640 14341 -32288 14557 -32847 14786
--33327 15016 -33739 15238 -34070 15453 -34318 15662 -34465 15869 -34495 16065
--34406 16246 -34228 16407 -33979 16545 -33654 16661 -33240 16744 -32728 16787
--32125 16802 -31450 16782 -30734 16720 -29974 16625 -29178 16492 -28324 16328
--27416 16137 -26492 15909 -25553 15652 -24617 15372 -23685 15070 -22755 14748
--21829 14404 -20927 14047 -20033 13675 -19170 13293 -18350 12902 -17563 12511
--16817 12116 -16114 11727 -15441 11335 -14807 10946 -14215 10565 -13675 10195
--13181 9842 -12716 9505 -12286 9182 -11888 8870 -11542 8562 -11229 8256
--10920 7988 -10654 7740 -10424 7514 -10221 7301 -10030 7105 -9853 6932
--9687 6784 -9553 6651 -9445 6532 -9350 6432 -9263 6350 -9184 6287 -9117 6242
--9065 6212 -9023 6197 -8997 6190 -8978 6199 -8962 6222 -8954 6260 -8955 6308
--8967 6364 -8985 6430 -9011 6498 -9036 6578 -9073 6667 -9119 6757 -9172 6853
--9231 6952 -9291 7053 -9353 7160 -9419 7264 -9499 7373 -9580 7480 -9670 7587
--9757 7694 -9833 7802 -9912 7908 -9994 8013 -10082 8113 -10170 8214 -10248 8309
--10311 8403 -10367 8494 -10418 8582 -10468 8666 -10509 8743 -10539 8821
--10554 8891 -10555 8958 -10549 9022 -10529 9080 -10499 9134 -10459 9181
--10410 9227 -10350 9266 -10272 9299 -10183 9327 -10084 9348 -9980 9365
--9874 9378 -9767 9386 -9646 9387 -9510 9382 -9368 9371 -9230 9356 -9100 9339
--8971 9317 -8835 9288 -8693 9253 -8551 9214 -8415 9172 -8297 9132 -8182 9090
--8072 9038 -7961 8986 -7857 8930 -7766 8875 -7687 8825 -7622 8777 -7561 8722
--7513 8666 -7475 8612 -7446 8561 -7426 8518 -7420 8480 -7427 8442 -7444 8403
--7472 8370 -7506 8344 -7546 8325 -7590 8310 -7645 8301 -7716 8297 -7795 8299
--7869 8306 -7943 8320 -8018 8337 -8098 8364 -8191 8397 -8281 8435 -8370 8476
--8449 8516 -8526 8563 -8603 8614 -8684 8675 -8760 8735 -8829 8797 -8891 8853
--8943 8910 -8995 8970 -9040 9035 -9082 9097 -9116 9157 -9139 9209 -9152 9258
--9161 9306 -9163 9353 -9158 9398 -9144 9433 -9117 9467 -9083 9495 -9038 9518
--8991 9536 -8931 9549 -8860 9561 -8780 9569 -8689 9575 -8588 9572 -8479 9564
--8359 9553 -8230 9542 -8090 9535 -7939 9527 -7777 9513 -7602 9494 -7418 9479
--7225 9464 -7028 9454 -6821 9447 -6602 9440 -6365 9432 -6124 9429 -5882 9427
--5641 9431 -5402 9437 -5146 9448 -4877 9462 -4605 9482 -4343 9500 -4098 9518
--3858 9539 -3612 9570 -3358 9601 -3113 9636 -2886 9668 -2684 9693 -2500 9719
--2321 9749 -2144 9782 -1986 9812 -1855 9834 -1751 9849 -1672 9859 -1610 9870
--1571 9875 -1551 9876 -1556 9870 -1582 9854 -1630 9833 -1710 9803 -1823 9766
--1953 9720 -2098 9670 -2241 9618 -2397 9560 -2589 9488 -2814 9406 -3049 9320
--3272 9234 -3467 9153 -3659 9071 -3881 8974 -4120 8871 -4349 8769 -4543 8675
--4684 8593 -4797 8518 -4919 8435 -5036 8350 -5118 8275 -5147 8214 -5107 8171
--5018 8143 -4905 8117 -4761 8098 -4562 8095 -4296 8110 -3965 8147 -3574 8202
--3122 8272 -2617 8356 -2047 8461 -1417 8582 -737 8723 6 8883 832 9064 1724 9270
-2676 9491 3669 9728 4686 9970 5751 10229 6901 10518 8119 10825 9380 11146
-10650 11471 11907 11790 13190 12115 14541 12468 15949 12835 17366 13204
-18758 13568 20101 13908 21432 14243 22811 14596 24209 14953 25590 15303
-26911 15627 28138 15921 29326 16195 30522 16469 31704 16737 32831 16983
-33868 17194 34789 17363 35631 17502 36441 17622 37204 17726 37853 17789
-38405 17814 38864 17797 39218 17742 39447 17649 39581 17521 39603 17362
-39493 17166 39248 16926 38905 16636 38463 16305 37851 15946 37011 15560
-36076 15150 35173 14714 34133 14219 32681 13666 30884 13147 29159 12638
-27752 12020 26335 11419 24257 10952 21296 10442 17925 9724 14953 8926
-12878 8333 11478 8060 9988 7948 7483 7724 3315 7271 -2698 6681 -10300 6055
--19000 5000 -19000 4000 -20000 5000 -19000 5000 -20000 5000 -19000 5000
--20000 5000 -19000 5000 -20000 5000 -19000 5000 -20000 5000 -19000 5000
--20000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 5000 -19000 6000
--20000 5000 -19000 5000 -20000 5000 -19000 6000 -20000 5000 -19000 6000
-28: 8758291 -6212455 1642 6737 1822 6652 2030 6545 2266 6429 2531 6302
-2796 6182 3083 6056 3387 5927 3713 5780 4055 5641 4414 5503 4772 5363 5138 5226
-5528 5084 5931 4943 6343 4804 6776 4671 7189 4547 7607 4422 8040 4302 8477 4193
-8930 4084 9373 3985 9796 3896 10215 3817 10629 3749 11049 3691 11460 3640
-11856 3599 12215 3574 12557 3563 12887 3565 13207 3581 13498 3611 13759 3651
-13990 3701 14184 3770 14343 3849 14474 3949 14573 4057 14633 4179 14660 4298
-14644 4428 14590 4577 14487 4739 14347 4913 14168 5072 13959 5229 13721 5385
-13432 5542 13111 5706 12740 5866 12349 6004 11933 6125 11482 6224 11015 6304
-10514 6358 9977 6398 9444 6425 8882 6423 8277 6380 7623 6311 6944 6219
-6242 6110 5524 5986 4762 5834 3949 5659 3130 5456 2308 5235 1461 5014 603 4783
--269 4556 -1193 4304 -2132 4054 -3087 3781 -4020 3562 -4907 3266 -5808 3113
--6747 2886 -7700 2674 -8655 2540 -9490 2410 -10205 2276 -10996 2177 -11839 2114
--12482 2140 -12913 2204 -13365 2290 -14020 2374 -14726 2618 -15181 2575
--15309 2685 -15294 2925 -15407 2990 -15770 3050 -16290 3284 -16814 3561
--17285 3782 -17718 3936 -18178 4106 -18741 4377 -19389 4765 -20113 5291
--20882 5876 -21676 6535 -22489 7283 -23316 8037 -24143 8744 -24947 9598
--25726 10469 -26467 11266 -27170 11976 -27816 12672 -28384 13461 -28885 14345
--29305 15273 -29620 16239 -29905 17165 -29984 18076 -29952 18948 -30060 19711
--30130 20359 -30033 20885 -29970 21318 -29798 21667 -29587 21952 -29202 22180
--28754 22335 -28282 22439 -27744 22504 -27223 22544 -26678 22549 -26126 22534
--25591 22513 -25065 22469 -24564 22422 -24087 22354 -23637 22264 -23218 22162
--22829 22047 -22493 21904 -22165 21762 -21846 21612 -21528 21444 -21224 21274
--20920 21090 -20622 20895 -20336 20696 -20059 20479 -19753 20248 -19402 20004
--19013 19756 -18596 19509 -18195 19256 -17798 18997 -17411 18718 -16989 18428
--16536 18137 -16082 17846 -15651 17551 -15268 17248 -14948 16938 -14691 16615
--14501 16282 -14383 15947 -14325 15610 -14336 15284 -14444 14968 -14674 14671
--15024 14397 -15459 14149 -15968 13927 -16562 13728 -17238 13555 -17949 13409
--18678 13288 -19582 13213 -20482 13161 -21385 13121 -22318 13107 -23295 13121
--24293 13174 -25302 13257 -26290 13364 -27249 13481 -28198 13614 -29138 13766
--30058 13930 -30952 14116 -31794 14320 -32565 14546 -33257 14788 -33857 15035
--34376 15273 -34813 15506 -35172 15738 -35438 15966 -35589 16195 -35614 16413
--35516 16611 -35321 16791 -35045 16947 -34691 17067 -34238 17151 -33680 17202
--33029 17214 -32296 17186 -31524 17114 -30704 17009 -29845 16868 -28927 16689
--27960 16475 -26963 16227 -25960 15951 -24959 15650 -23967 15323 -22973 14968
--21991 14598 -21038 14210 -20092 13809 -19181 13400 -18317 12982 -17492 12563
--16717 12143 -15984 11728 -15292 11313 -14636 10898 -14023 10497 -13469 10107
--12966 9737 -12498 9380 -12061 9039 -11664 8714 -11310 8393 -10998 8076
--10695 7800 -10430 7546 -10205 7312 -10005 7091 -9820 6895 -9647 6719
--9483 6570 -9354 6439 -9249 6322 -9160 6225 -9079 6146 -9001 6087 -8937 6048
--8886 6028 -8849 6017 -8821 6018 -8804 6032 -8793 6066 -8782 6110 -8787 6170
--8797 6232 -8816 6307 -8841 6388 -8869 6477 -8903 6569 -8952 6671 -9007 6774
--9068 6881 -9128 6989 -9192 7102 -9257 7213 -9341 7327 -9427 7444 -9522 7555
--9610 7666 -9691 7780 -9771 7890 -9858 7997 -9950 8103 -10044 8205 -10127 8303
--10193 8396 -10250 8491 -10305 8579 -10359 8664 -10397 8743 -10433 8820
--10447 8889 -10451 8955 -10441 9017 -10421 9074 -10387 9124 -10345 9169
--10298 9215 -10235 9247 -10155 9278 -10062 9300 -9956 9318 -9852 9332
--9746 9338 -9637 9341 -9515 9336 -9374 9325 -9232 9310 -9093 9289 -8965 9267
--8836 9238 -8703 9202 -8563 9163 -8425 9118 -8294 9071 -8181 9025 -8073 8979
--7969 8924 -7866 8866 -7773 8806 -7693 8750 -7625 8696 -7571 8647 -7525 8589
--7489 8532 -7468 8479 -7453 8428 -7451 8386 -7457 8348 -7480 8313 -7517 8278
--7561 8247 -7615 8224 -7670 8209 -7731 8200 -7803 8196 -7890 8198 -7983 8206
--8075 8221 -8162 8239 -8249 8263 -8344 8298 -8445 8339 -8549 8386 -8646 8435
--8734 8482 -8817 8535 -8901 8596 -8985 8662 -9065 8732 -9136 8801 -9195 8864
--9251 8925 -9297 8993 -9340 9065 -9378 9133 -9404 9197 -9420 9255 -9427 9307
--9427 9360 -9419 9412 -9403 9457 -9376 9497 -9342 9532 -9294 9563 -9238 9586
--9175 9604 -9101 9619 -9020 9629 -8925 9636 -8824 9643 -8710 9638 -8587 9627
--8456 9615 -8316 9601 -8164 9591 -8003 9580 -7831 9563 -7649 9542 -7455 9520
--7256 9503 -7052 9489 -6841 9477 -6616 9466 -6377 9456 -6133 9447 -5888 9441
--5648 9440 -5405 9442 -5152 9449 -4885 9460 -4615 9473 -4356 9489 -4115 9503
--3877 9522 -3637 9547 -3388 9576 -3149 9607 -2927 9636 -2731 9661 -2552 9682
--2378 9712 -2209 9741 -2057 9769 -1931 9791 -1833 9804 -1757 9815 -1701 9823
--1664 9829 -1649 9829 -1658 9824 -1685 9809 -1732 9788 -1817 9757 -1928 9723
--2059 9678 -2202 9630 -2342 9578 -2495 9522 -2684 9452 -2906 9371 -3135 9289
--3353 9204 -3540 9125 -3727 9046 -3942 8950 -4174 8849 -4395 8751 -4579 8657
--4713 8578 -4821 8504 -4937 8421 -5043 8339 -5117 8265 -5138 8204 -5091 8163
--5000 8134 -4881 8109 -4732 8090 -4528 8086 -4261 8101 -3928 8136 -3533 8189
--3084 8258 -2583 8340 -2017 8442 -1390 8562 -716 8699 21 8854 837 9033
-1717 9233 2656 9452 3638 9683 4638 9921 5690 10176 6824 10458 8022 10760
-9260 11077 10510 11394 11747 11708 13006 12028 14338 12374 15716 12735
-17108 13100 18477 13455 19793 13790 21100 14120 22454 14464 23827 14818
-25180 15161 26474 15481 27682 15767 28849 16036 30023 16304 31184 16568
-32293 16808 33310 17013 34218 17177 35046 17309 35846 17425 36598 17524
-37241 17580 37788 17597 38245 17575 38598 17512 38834 17410 38970 17277
-39004 17109 38901 16905 38669 16655 38342 16354 37926 16012 37329 15642
-36507 15245 35607 14824 34748 14378 33727 13865 32279 13298 30510 12773
-28858 12234 27530 11613 26136 11035 24034 10535 21069 9945 17744 9215
-14892 8515 12954 8019 11689 7723 10296 7444 7853 7020 3696 6477 -2422 5916
--10322 5336 -19000 5000 -19000 5000 -20000 5000 -19000 5000 -19000 5000
--20000 5000 -19000 5000 -20000 5000 -19000 5000 -20000 5000 -20000 5000
--19000 6000 -20000 5000 -19000 5000 -20000 6000 -19000 5000 -20000 6000
--19000 5000
-29: 8795123 -6204837 1968 6623 2160 6535 2380 6427 2629 6303 2904 6175
-3190 6045 3493 5916 3812 5777 4152 5631 4519 5482 4887 5337 5264 5197 5650 5049
-6055 4904 6485 4754 6917 4611 7359 4471 7794 4341 8234 4212 8686 4087 9138 3970
-9612 3858 10073 3756 10516 3659 10950 3578 11376 3509 11814 3446 12247 3391
-12656 3346 13019 3324 13374 3312 13716 3316 14041 3331 14347 3364 14613 3404
-14840 3459 15044 3532 15200 3619 15325 3727 15419 3844 15476 3971 15497 4101
-15467 4244 15399 4408 15279 4583 15122 4774 14924 4949 14695 5124 14434 5296
-14125 5472 13772 5653 13376 5831 12953 5994 12508 6128 12032 6251 11538 6338
-11016 6403 10453 6458 9902 6492 9312 6500 8668 6461 7982 6395 7287 6305
-6567 6191 5810 6065 4989 5907 4147 5726 3313 5513 2460 5285 1582 5052 697 4812
--239 4564 -1214 4308 -2208 4029 -3204 3769 -4137 3461 -5065 3260 -6057 3000
--7055 2758 -8052 2603 -8991 2452 -9826 2259 -10666 2103 -11585 2001 -12373 2006
--12885 2006 -13342 2087 -14027 2147 -14837 2366 -15420 2409 -15570 2456
--15475 2733 -15485 2812 -15794 2800 -16301 3003 -16792 3293 -17160 3482
--17448 3574 -17758 3686 -18197 3909 -18787 4237 -19474 4649 -20246 5128
--21070 5663 -21923 6363 -22804 7125 -23703 7862 -24585 8727 -25445 9668
--26274 10514 -27065 11255 -27812 11952 -28479 12722 -29067 13602 -29566 14542
--29968 15498 -30280 16481 -30398 17374 -30446 18413 -30721 19355 -30871 20150
--30768 20786 -30719 21300 -30512 21723 -30298 22074 -29968 22351 -29617 22556
--29215 22685 -28687 22773 -28137 22822 -27501 22837 -26877 22826 -26270 22812
--25696 22775 -25172 22726 -24641 22660 -24130 22568 -23639 22463 -23195 22350
--22812 22212 -22461 22069 -22140 21933 -21810 21777 -21535 21612 -21227 21440
--20935 21255 -20652 21054 -20380 20844 -20101 20615 -19797 20372 -19442 20122
--19045 19879 -18629 19635 -18202 19385 -17791 19121 -17366 18834 -16918 18544
--16435 18257 -15939 17963 -15463 17670 -15033 17366 -14670 17051 -14383 16722
--14172 16371 -14038 16018 -13965 15662 -13970 15317 -14072 14982 -14312 14680
--14694 14404 -15161 14149 -15715 13926 -16359 13727 -17085 13558 -17851 13410
--18640 13296 -19606 13229 -20570 13175 -21539 13139 -22540 13143 -23579 13181
--24648 13253 -25733 13349 -26787 13454 -27815 13573 -28826 13719 -29837 13886
--30823 14071 -31775 14280 -32686 14510 -33513 14761 -34254 15019 -34909 15273
--35463 15522 -35923 15774 -36313 16029 -36598 16289 -36758 16538 -36777 16777
--36667 16997 -36450 17194 -36149 17360 -35760 17481 -35264 17572 -34662 17631
--33951 17636 -33163 17602 -32327 17528 -31443 17413 -30519 17259 -29531 17061
--28495 16826 -27426 16559 -26353 16263 -25286 15932 -24223 15570 -23168 15186
--22129 14786 -21115 14368 -20115 13938 -19159 13500 -18253 13053 -17392 12606
--16580 12160 -15821 11715 -15102 11277 -14425 10840 -13801 10414 -13233 10004
--12720 9612 -12250 9238 -11811 8882 -11414 8543 -11056 8210 -10744 7882
--10448 7597 -10186 7335 -9966 7094 -9772 6870 -9596 6671 -9422 6496 -9266 6345
--9140 6215 -9040 6102 -8958 6009 -8880 5933 -8804 5879 -8747 5849 -8695 5833
--8658 5831 -8634 5841 -8618 5863 -8607 5907 -8600 5961 -8602 6029 -8613 6101
--8632 6185 -8655 6276 -8686 6372 -8720 6474 -8770 6585 -8822 6698 -8885 6812
--8947 6927 -9011 7046 -9081 7165 -9166 7286 -9257 7408 -9356 7527 -9444 7643
--9529 7757 -9611 7874 -9703 7987 -9805 8093 -9902 8198 -9988 8298 -10058 8393
--10118 8488 -10176 8576 -10231 8663 -10275 8742 -10307 8819 -10326 8886
--10329 8952 -10318 9010 -10298 9064 -10264 9114 -10217 9157 -10168 9197
--10105 9228 -10022 9252 -9927 9269 -9816 9283 -9707 9293 -9604 9293 -9493 9290
--9367 9279 -9225 9262 -9084 9241 -8945 9213 -8817 9184 -8690 9151 -8561 9110
--8423 9063 -8291 9012 -8166 8959 -8058 8908 -7957 8857 -7862 8800 -7770 8735
--7688 8673 -7619 8613 -7564 8557 -7522 8505 -7491 8447 -7471 8390 -7466 8335
--7469 8287 -7483 8244 -7505 8209 -7545 8176 -7601 8144 -7666 8116 -7737 8099
--7810 8088 -7885 8084 -7977 8085 -8082 8096 -8192 8110 -8298 8131 -8401 8158
--8501 8189 -8608 8231 -8722 8281 -8838 8336 -8943 8393 -9040 8449 -9129 8511
--9218 8578 -9307 8654 -9389 8732 -9461 8809 -9522 8879 -9574 8947 -9618 9021
--9658 9098 -9689 9175 -9709 9242 -9718 9304 -9716 9363 -9708 9420 -9689 9475
--9659 9523 -9620 9565 -9574 9604 -9516 9634 -9447 9659 -9369 9679 -9281 9692
--9187 9702 -9078 9709 -8965 9714 -8838 9708 -8702 9696 -8557 9679 -8405 9663
--8243 9651 -8073 9637 -7892 9617 -7699 9591 -7499 9565 -7290 9543 -7080 9526
--6864 9511 -6636 9494 -6394 9479 -6148 9466 -5900 9455 -5660 9450 -5416 9449
--5163 9450 -4897 9458 -4633 9466 -4378 9478 -4138 9489 -3906 9503 -3670 9525
--3428 9551 -3195 9579 -2977 9605 -2787 9625 -2613 9647 -2445 9673 -2284 9700
--2138 9727 -2018 9748 -1923 9759 -1852 9771 -1801 9778 -1769 9783 -1757 9782
--1768 9777 -1799 9764 -1846 9742 -1929 9713 -2041 9679 -2172 9638 -2313 9590
--2451 9540 -2600 9485 -2785 9416 -3001 9339 -3226 9256 -3437 9176 -3619 9099
--3797 9020 -4007 8927 -4228 8830 -4441 8732 -4617 8641 -4742 8563 -4842 8490
--4949 8410 -5048 8328 -5114 8256 -5125 8195 -5073 8156 -4976 8126 -4851 8101
--4698 8083 -4487 8077 -4219 8091 -3884 8126 -3490 8178 -3040 8244 -2543 8324
--1979 8423 -1358 8541 -691 8674 42 8826 845 9002 1716 9197 2643 9412 3610 9638
-4595 9872 5631 10121 6746 10398 7923 10696 9142 11006 10370 11318 11584 11627
-12821 11941 14127 12280 15481 12636 16842 12996 18186 13344 19479 13674
-20762 13998 22087 14337 23433 14685 24758 15024 26025 15338 27214 15619
-28357 15883 29510 16146 30649 16405 31737 16640 32736 16842 33629 17000
-34444 17127 35233 17237 35977 17329 36610 17381 37155 17394 37608 17365
-37962 17297 38207 17189 38343 17047 38384 16873 38299 16661 38080 16402
-37770 16092 37375 15738 36795 15358 35995 14950 35137 14519 34315 14060
-33307 13528 31867 12952 30148 12413 28568 11845 27298 11232 25903 10662
-23790 10109 20843 9451 17611 8739 14892 8135 13077 7703 11919 7339 10612 6857
-8270 6238 4231 5663 -1779 5319 -9695 5194 -20000 5000 -19000 5000 -19000 5000
--19000 5000 -20000 5000 -19000 5000 -20000 5000 -19000 5000 -19000 5000
--20000 5000 -19000 5000 -20000 6000 -20000 5000 -19000 5000 -19000 6000
--20000 5000 -19000 6000 -20000 6000
-30: 8831924 -6197219 2297 6512 2497 6419 2739 6309 2992 6176 3276 6045
-3581 5910 3903 5776 4239 5628 4599 5474 4978 5323 5362 5174 5756 5025 6157 4874
-6585 4720 7035 4565 7490 4415 7942 4272 8406 4134 8860 4002 9327 3868 9798 3745
-10295 3628 10777 3522 11234 3422 11678 3337 12126 3262 12580 3195 13026 3141
-13451 3096 13829 3068 14190 3058 14542 3064 14876 3080 15191 3112 15466 3154
-15692 3214 15894 3289 16057 3380 16182 3499 16267 3630 16312 3761 16325 3906
-16288 4058 16207 4234 16070 4433 15887 4636 15673 4827 15424 5020 15139 5215
-14802 5408 14418 5609 13999 5811 13548 5993 13068 6149 12562 6289 12048 6391
-11492 6474 10911 6536 10346 6588 9721 6597 9041 6566 8341 6507 7629 6410
-6869 6301 6058 6166 5206 6011 4353 5812 3501 5600 2614 5358 1704 5109 756 4863
--243 4605 -1266 4323 -2294 4043 -3290 3723 -4250 3465 -5273 3202 -6335 2898
--7365 2716 -8381 2546 -9333 2306 -10253 2097 -11252 1958 -12193 1925 -12848 1862
--13345 1880 -14011 1927 -14904 2068 -15643 2232 -15889 2256 -15753 2557
--15680 2713 -15941 2644 -16451 2773 -16916 3077 -17162 3260 -17239 3289
--17345 3356 -17630 3560 -18138 3863 -18801 4154 -19566 4460 -20400 4833
--21286 5388 -22209 6133 -23179 6906 -24142 7779 -25077 8785 -25989 9698
--26867 10487 -27698 11230 -28470 12017 -29146 12886 -29750 13791 -30247 14691
--30644 15617 -30928 16612 -30935 17641 -31338 18787 -31583 19762 -31451 20544
--31345 21176 -31105 21686 -30906 22121 -30675 22478 -30476 22736 -30223 22909
--29744 23023 -29160 23097 -28444 23135 -27736 23131 -27056 23120 -26418 23087
--25831 23030 -25247 22961 -24678 22862 -24104 22754 -23580 22637 -23143 22506
--22732 22367 -22408 22239 -22089 22097 -21827 21940 -21511 21779 -21225 21597
--20956 21401 -20686 21187 -20416 20964 -20147 20724 -19856 20477 -19514 20238
--19118 20001 -18651 19759 -18219 19505 -17769 19233 -17350 18953 -16866 18664
--16335 18374 -15787 18082 -15246 17789 -14773 17480 -14378 17157 -14052 16810
--13816 16439 -13652 16067 -13555 15692 -13547 15331 -13656 14993 -13911 14685
--14311 14404 -14819 14146 -15417 13920 -16117 13724 -16901 13552 -17734 13408
--18570 13301 -19615 13230 -20648 13181 -21681 13170 -22744 13195 -23859 13248
--25011 13328 -26160 13424 -27287 13526 -28384 13658 -29461 13819 -30534 14012
--31600 14224 -32619 14457 -33592 14712 -34489 14971 -35290 15236 -35992 15504
--36585 15774 -37083 16053 -37496 16344 -37799 16629 -37970 16900 -37988 17157
--37861 17395 -37619 17605 -37289 17776 -36862 17911 -36325 18013 -35666 18070
--34900 18075 -34045 18042 -33140 17962 -32193 17838 -31197 17661 -30136 17445
--29020 17191 -27881 16902 -26731 16575 -25589 16209 -24459 15814 -23338 15400
--22238 14969 -21159 14521 -20106 14063 -19102 13591 -18148 13115 -17250 12639
--16402 12163 -15615 11691 -14881 11224 -14180 10766 -13542 10315 -12966 9882
--12444 9470 -11968 9082 -11528 8710 -11137 8357 -10781 8009 -10472 7671
--10178 7378 -9924 7109 -9709 6862 -9523 6635 -9352 6435 -9184 6258 -9035 6108
--8915 5980 -8820 5872 -8741 5782 -8667 5711 -8600 5665 -8540 5640 -8492 5635
--8458 5639 -8435 5661 -8420 5693 -8408 5744 -8403 5809 -8407 5886 -8413 5971
--8434 6065 -8454 6163 -8486 6267 -8521 6381 -8568 6501 -8621 6623 -8682 6744
--8749 6867 -8812 6994 -8886 7119 -8973 7250 -9066 7375 -9169 7501 -9262 7620
--9350 7740 -9433 7861 -9531 7976 -9641 8087 -9741 8192 -9832 8294 -9907 8393
--9970 8487 -10031 8575 -10090 8663 -10137 8742 -10170 8816 -10189 8883
--10192 8947 -10182 9004 -10158 9055 -10124 9102 -10075 9141 -10022 9175
--9958 9203 -9876 9223 -9776 9236 -9662 9244 -9553 9247 -9442 9241 -9330 9233
--9206 9216 -9063 9192 -8921 9163 -8782 9128 -8656 9093 -8534 9055 -8409 9008
--8274 8953 -8147 8896 -8029 8838 -7929 8781 -7837 8725 -7752 8662 -7671 8596
--7599 8529 -7544 8464 -7503 8407 -7476 8354 -7458 8295 -7459 8238 -7470 8181
--7490 8135 -7523 8094 -7562 8060 -7620 8031 -7698 8002 -7784 7980 -7873 7966
--7964 7962 -8057 7962 -8167 7971 -8292 7989 -8419 8011 -8542 8039 -8660 8074
--8771 8113 -8893 8163 -9021 8223 -9146 8286 -9262 8353 -9365 8419 -9461 8487
--9557 8564 -9648 8649 -9733 8735 -9806 8819 -9866 8897 -9918 8973 -9957 9054
--9992 9139 -10016 9219 -10029 9293 -10030 9362 -10021 9425 -10003 9485
--9970 9542 -9928 9594 -9877 9640 -9817 9679 -9747 9712 -9666 9738 -9572 9758
--9470 9770 -9360 9781 -9240 9786 -9112 9790 -8972 9782 -8823 9767 -8665 9749
--8499 9729 -8328 9714 -8148 9697 -7956 9672 -7755 9642 -7545 9614 -7330 9586
--7114 9565 -6894 9546 -6661 9524 -6416 9504 -6167 9486 -5919 9471 -5677 9461
--5434 9455 -5182 9453 -4920 9455 -4657 9460 -4408 9467 -4168 9475 -3943 9486
--3711 9503 -3476 9525 -3248 9550 -3038 9574 -2852 9591 -2685 9611 -2523 9635
--2369 9660 -2231 9685 -2114 9704 -2025 9716 -1958 9725 -1910 9733 -1883 9737
--1876 9738 -1889 9731 -1921 9719 -1970 9698 -2051 9669 -2162 9636 -2293 9596
--2432 9552 -2567 9503 -2710 9448 -2891 9382 -3100 9307 -3322 9227 -3525 9148
--3701 9074 -3871 8996 -4070 8907 -4285 8810 -4487 8715 -4654 8626 -4770 8549
--4861 8478 -4960 8400 -5049 8319 -5106 8247 -5109 8188 -5050 8149 -4945 8119
--4817 8094 -4657 8076 -4442 8069 -4169 8083 -3834 8116 -3442 8167 -2991 8230
--2493 8309 -1936 8404 -1318 8518 -659 8649 66 8799 859 8970 1720 9162 2632 9370
-3585 9593 4557 9822 5574 10066 6669 10338 7827 10630 9023 10935 10230 11242
-11419 11544 12633 11854 13912 12187 15240 12538 16573 12891 17890 13235
-19156 13558 20413 13879 21710 14212 23029 14556 24324 14888 25564 15199
-26731 15476 27851 15733 28983 15995 30096 16249 31164 16481 32144 16678
-33022 16832 33826 16955 34602 17061 35334 17146 35964 17194 36502 17202
-36957 17171 37310 17096 37557 16985 37702 16836 37754 16656 37680 16436
-37471 16170 37188 15850 36818 15487 36253 15095 35478 14677 34661 14235
-33867 13765 32873 13214 31455 12629 29789 12067 28282 11481 27043 10877
-25641 10299 23532 9689 20640 8980 17525 8294 14926 7770 13204 7370 12095 6904
-10848 6217 8613 5397 4714 4752 -1258 4573 -9384 4939 -19000 5000 -19000 5000
--20000 4000 -19000 5000 -19000 5000 -20000 5000 -19000 5000 -19000 5000
--20000 5000 -19000 5000 -19000 5000 -20000 5000 -19000 5000 -20000 6000
--19000 5000 -20000 5000 -19000 5000 -20000 5000 -19000 6000 -20000 5000
--19000 6000 -20000 5000 -19000 6000 -19000 6000
-31: 8868681 -6189590 2628 6396 2835 6303 3088 6188 3360 6055 3659 5915
-3976 5772 4310 5634 4661 5477 5040 5320 5437 5161 5834 5011 6250 4855 6670 4694
-7111 4538 7580 4377 8059 4218 8530 4069 9005 3926 9482 3786 9968 3649 10462 3519
-10974 3395 11469 3287 11947 3183 12411 3095 12877 3015 13340 2943 13805 2887
-14239 2843 14637 2813 15008 2799 15363 2804 15712 2823 16029 2858 16310 2904
-16546 2961 16741 3040 16907 3146 17030 3268 17113 3409 17152 3552 17151 3704
-17101 3871 17006 4064 16852 4279 16649 4497 16414 4710 16144 4920 15832 5134
-15466 5352 15059 5577 14601 5802 14121 6008 13610 6185 13073 6343 12535 6464
-11954 6561 11354 6641 10764 6705 10104 6723 9410 6696 8707 6634 7955 6549
-7148 6434 6296 6305 5441 6131 4575 5941 3681 5699 2742 5452 1788 5204 780 4940
--262 4662 -1311 4367 -2351 4054 -3358 3745 -4406 3472 -5531 3118 -6621 2892
--7667 2687 -8711 2407 -9734 2161 -10811 2001 -11891 1912 -12756 1786 -13351 1690
--13994 1716 -14898 1783 -15790 1999 -16207 2088 -16118 2366 -15964 2662
--16185 2590 -16736 2596 -17227 2902 -17355 3116 -17181 3098 -16995 3101
--17080 3311 -17488 3616 -18138 3827 -18914 3934 -19748 4088 -20633 4446
--21574 5091 -22565 5878 -23598 6737 -24612 7792 -25589 8795 -26531 9657
--27451 10470 -28317 11317 -29109 12223 -29800 13081 -30410 13866 -30914 14669
--31308 15586 -31581 16654 -31938 18001 -32245 19217 -32037 20179 -31838 20950
--31620 21589 -31452 22123 -31392 22560 -31364 22899 -31262 23121 -30853 23272
--30273 23368 -29494 23423 -28724 23437 -27976 23423 -27240 23392 -26570 23323
--25891 23239 -25241 23138 -24600 23018 -24018 22902 -23510 22784 -23011 22652
--22676 22528 -22356 22407 -22105 22253 -21755 22094 -21506 21924 -21227 21727
--20955 21514 -20705 21289 -20458 21056 -20230 20817 -19961 20582 -19607 20356
--19148 20120 -18708 19873 -18221 19615 -17820 19344 -17329 19065 -16816 18775
--16222 18484 -15610 18189 -15034 17891 -14520 17575 -14054 17238 -13696 16870
--13410 16490 -13207 16103 -13096 15717 -13079 15353 -13187 15010 -13446 14692
--13874 14400 -14429 14139 -15083 13911 -15842 13711 -16698 13540 -17584 13401
--18487 13301 -19598 13224 -20694 13196 -21804 13209 -22946 13252 -24144 13311
--25364 13382 -26587 13474 -27784 13587 -28951 13746 -30097 13935 -31242 14155
--32376 14392 -33493 14644 -34532 14902 -35497 15171 -36358 15446 -37107 15734
--37748 16044 -38283 16360 -38733 16679 -39048 16984 -39224 17271 -39237 17548
--39103 17799 -38831 18019 -38467 18204 -38006 18361 -37415 18467 -36700 18528
--35868 18542 -34944 18510 -33968 18417 -32951 18271 -31872 18077 -30735 17842
--29544 17563 -28321 17241 -27089 16877 -25874 16478 -24667 16055 -23476 15612
--22312 15152 -21171 14671 -20063 14178 -19001 13674 -18002 13165 -17064 12658
--16184 12152 -15376 11652 -14617 11154 -13898 10673 -13246 10199 -12658 9743
--12131 9313 -11657 8910 -11221 8523 -10832 8152 -10479 7792 -10179 7442
--9888 7142 -9642 6866 -9437 6616 -9257 6388 -9095 6185 -8936 6006 -8789 5858
--8678 5733 -8588 5631 -8515 5546 -8445 5481 -8383 5443 -8324 5424 -8280 5429
--8247 5446 -8223 5475 -8209 5519 -8197 5580 -8192 5654 -8196 5744 -8204 5840
--8219 5944 -8239 6051 -8270 6166 -8303 6289 -8351 6418 -8403 6550 -8462 6680
--8530 6811 -8596 6946 -8669 7079 -8758 7214 -8856 7345 -8962 7477 -9060 7602
--9152 7725 -9239 7850 -9344 7967 -9456 8081 -9564 8190 -9661 8293 -9739 8393
--9808 8487 -9868 8577 -9932 8663 -9982 8742 -10018 8814 -10039 8880 -10042 8940
--10032 8996 -10006 9043 -9969 9087 -9918 9123 -9863 9151 -9797 9176 -9712 9188
--9610 9198 -9494 9201 -9379 9195 -9267 9185 -9154 9170 -9029 9146 -8888 9113
--8745 9077 -8608 9035 -8482 8995 -8366 8949 -8243 8896 -8116 8833 -7994 8770
--7884 8704 -7790 8645 -7711 8582 -7637 8517 -7567 8444 -7510 8374 -7467 8304
--7441 8246 -7430 8190 -7430 8133 -7448 8074 -7479 8020 -7520 7972 -7568 7934
--7628 7904 -7708 7876 -7805 7853 -7913 7836 -8024 7828 -8134 7829 -8244 7836
--8374 7851 -8516 7876 -8665 7910 -8805 7946 -8936 7987 -9063 8035 -9199 8096
--9338 8164 -9475 8238 -9601 8314 -9712 8388 -9815 8467 -9913 8553 -10009 8646
--10097 8741 -10169 8834 -10230 8920 -10278 9004 -10315 9092 -10344 9183
--10359 9270 -10363 9350 -10359 9424 -10339 9490 -10311 9556 -10266 9618
--10210 9672 -10143 9719 -10072 9761 -9988 9795 -9892 9822 -9785 9842 -9667 9853
--9541 9864 -9408 9869 -9266 9870 -9112 9860 -8950 9843 -8780 9821 -8601 9799
--8417 9780 -8227 9759 -8026 9730 -7815 9698 -7597 9663 -7377 9632 -7154 9606
--6928 9582 -6692 9556 -6442 9531 -6193 9507 -5943 9488 -5699 9473 -5461 9462
--5208 9456 -4949 9454 -4691 9454 -4444 9458 -4210 9461 -3987 9468 -3762 9481
--3532 9501 -3311 9522 -3110 9543 -2929 9557 -2766 9574 -2611 9597 -2464 9621
--2333 9643 -2223 9662 -2138 9674 -2074 9679 -2029 9688 -2007 9693 -2003 9693
--2021 9687 -2053 9674 -2101 9654 -2184 9627 -2293 9596 -2419 9556 -2557 9513
--2691 9467 -2828 9414 -3002 9349 -3205 9278 -3420 9199 -3618 9123 -3784 9050
--3945 8973 -4139 8888 -4340 8792 -4534 8700 -4690 8612 -4798 8538 -4879 8467
--4967 8390 -5046 8312 -5094 8240 -5090 8182 -5020 8142 -4912 8115 -4776 8089
--4608 8068 -4392 8062 -4112 8075 -3778 8107 -3384 8155 -2935 8217 -2440 8293
--1883 8385 -1274 8497 -618 8623 95 8770 881 8939 1729 9124 2627 9329 3564 9546
-4520 9771 5520 10011 6595 10277 7731 10563 8906 10863 10087 11165 11254 11462
-12441 11765 13695 12095 14993 12438 16300 12788 17586 13125 18825 13444
-20055 13759 21324 14090 22613 14428 23878 14757 25094 15062 26233 15336
-27330 15589 28438 15847 29529 16100 30573 16328 31536 16522 32396 16673
-33188 16791 33952 16896 34673 16977 35296 17023 35830 17028 36284 16992
-36642 16915 36893 16797 37046 16645 37107 16458 37043 16233 36854 15960
-36594 15631 36247 15259 35696 14857 34953 14427 34180 13979 33409 13492
-32427 12927 31039 12332 29436 11748 27983 11145 26763 10547 25356 9956
-23271 9290 20467 8545 17479 7883 14964 7410 13271 7018 12140 6460 10907 5593
-8798 4562 5182 3694 -424 3316 -8508 3734 -19000 5000 -19000 5000 -19000 5000
--19000 5000 -20000 5000 -19000 5000 -19000 5000 -20000 5000 -19000 5000
--19000 5000 -20000 5000 -19000 5000 -19000 5000 -20000 5000 -19000 6000
-32: 8905388 -6181952 2955 6283 3173 6186 3437 6068 3727 5926 4040 5785
-4369 5640 4715 5489 5080 5329 5483 5166 5890 5004 6306 4842 6739 4681 7178 4518
-7641 4354 8123 4187 8618 4020 9117 3866 9602 3717 10096 3570 10609 3429
-11120 3293 11646 3166 12162 3050 12654 2942 13138 2852 13619 2764 14100 2689
-14576 2632 15022 2584 15442 2553 15817 2537 16184 2542 16539 2562 16861 2600
-17148 2645 17395 2708 17589 2795 17753 2905 17878 3036 17953 3186 17981 3338
-17971 3502 17919 3681 17797 3893 17629 4122 17404 4361 17145 4596 16845 4821
-16517 5059 16119 5299 15681 5556 15192 5804 14676 6037 14129 6238 13567 6416
-12995 6557 12401 6672 11775 6771 11152 6843 10477 6870 9789 6859 9052 6799
-8262 6707 7408 6604 6554 6451 5687 6302 4784 6075 3824 5837 2832 5585 1837 5317
-797 5036 -256 4743 -1321 4441 -2384 4101 -3463 3805 -4628 3421 -5803 3129
--6894 2902 -7969 2579 -9090 2282 -10247 2118 -11446 1984 -12529 1790 -13309 1565
--13968 1515 -14828 1549 -15813 1736 -16451 1939 -16504 2164 -16342 2560
--16510 2600 -17126 2492 -17722 2736 -17822 3029 -17389 3017 -16835 2937
--16607 3115 -16892 3463 -17553 3657 -18366 3598 -19207 3509 -20054 3622
--20932 4088 -21903 4819 -22945 5644 -24008 6674 -25040 7778 -26027 8739
--27008 9635 -27965 10578 -28868 11557 -29699 12435 -30421 13117 -31048 13725
--31567 14477 -31970 15487 -32261 16723 -32908 18450 -32631 19702 -32293 20657
--32162 21446 -32116 22124 -32234 22672 -32318 23082 -32317 23361 -31959 23533
--31380 23642 -30603 23711 -29833 23725 -29029 23704 -28207 23657 -27396 23578
--26612 23474 -25833 23361 -25130 23234 -24494 23120 -23933 23018 -23363 22908
--22978 22795 -22614 22684 -22325 22546 -21966 22383 -21725 22210 -21463 22020
--21188 21810 -20952 21594 -20742 21368 -20545 21139 -20323 20914 -20030 20695
--19634 20466 -19250 20221 -18743 19962 -18334 19708 -17819 19441 -17329 19161
--16752 18865 -16119 18568 -15474 18271 -14829 17968 -14206 17643 -13710 17300
--13265 16932 -12936 16551 -12736 16154 -12604 15765 -12551 15395 -12650 15031
--12935 14693 -13402 14390 -14006 14122 -14710 13893 -15543 13690 -16442 13521
--17407 13387 -18364 13292 -19555 13226 -20736 13219 -21935 13250 -23139 13296
--24405 13348 -25706 13414 -26993 13514 -28278 13661 -29511 13853 -30742 14074
--31952 14313 -33197 14564 -34381 14821 -35498 15084 -36525 15360 -37454 15663
--38266 15993 -38959 16340 -39530 16690 -40001 17024 -40341 17340 -40533 17644
--40541 17936 -40386 18206 -40085 18445 -39685 18659 -39176 18828 -38540 18944
--37758 19017 -36857 19034 -35862 18994 -34809 18881 -33711 18714 -32553 18500
--31334 18241 -30056 17928 -28744 17570 -27427 17174 -26131 16748 -24851 16300
--23585 15826 -22351 15330 -21145 14814 -19977 14284 -18859 13744 -17814 13201
--16835 12661 -15928 12123 -15092 11591 -14304 11070 -13577 10562 -12908 10065
--12312 9590 -11787 9140 -11316 8719 -10885 8315 -10497 7927 -10152 7555
--9860 7196 -9580 6889 -9342 6611 -9148 6357 -8978 6123 -8823 5920 -8675 5742
--8538 5595 -8426 5478 -8347 5378 -8279 5298 -8212 5242 -8155 5211 -8099 5204
--8057 5220 -8024 5245 -8002 5287 -7990 5341 -7976 5414 -7967 5499 -7973 5603
--7975 5708 -7988 5823 -8009 5941 -8037 6066 -8070 6200 -8116 6340 -8165 6478
--8227 6618 -8290 6759 -8356 6902 -8432 7041 -8522 7182 -8625 7320 -8738 7455
--8838 7586 -8933 7714 -9027 7841 -9136 7963 -9256 8075 -9371 8191 -9471 8294
--9556 8395 -9629 8489 -9693 8579 -9759 8666 -9816 8741 -9852 8811 -9871 8877
--9878 8933 -9866 8987 -9838 9030 -9800 9072 -9746 9099 -9688 9124 -9623 9145
--9532 9153 -9428 9151 -9311 9149 -9191 9141 -9078 9123 -8967 9101 -8838 9067
--8698 9028 -8555 8984 -8420 8935 -8296 8887 -8185 8834 -8067 8773 -7946 8705
--7830 8632 -7730 8561 -7646 8495 -7577 8429 -7515 8358 -7459 8281 -7416 8207
--7391 8134 -7379 8074 -7383 8017 -7404 7959 -7442 7900 -7492 7846 -7553 7801
--7624 7766 -7705 7738 -7801 7714 -7924 7695 -8056 7684 -8186 7683 -8317 7690
--8448 7704 -8597 7727 -8761 7762 -8927 7803 -9085 7849 -9232 7900 -9376 7956
--9524 8026 -9676 8105 -9825 8191 -9959 8277 -10078 8360 -10189 8447 -10292 8544
--10390 8647 -10479 8751 -10551 8854 -10611 8947 -10657 9039 -10690 9134
--10712 9233 -10719 9328 -10715 9411 -10700 9493 -10672 9563 -10630 9632
--10574 9698 -10503 9754 -10425 9805 -10337 9848 -10238 9885 -10129 9911
--10006 9930 -9872 9943 -9729 9951 -9583 9957 -9428 9954 -9260 9943 -9082 9923
--8900 9897 -8708 9873 -8512 9848 -8312 9825 -8102 9793 -7881 9755 -7655 9714
--7428 9680 -7199 9649 -6968 9619 -6727 9589 -6478 9559 -6223 9531 -5975 9506
--5731 9487 -5492 9469 -5242 9460 -4987 9453 -4732 9449 -4489 9448 -4260 9447
--4041 9452 -3822 9461 -3599 9477 -3387 9494 -3189 9511 -3017 9526 -2859 9539
--2708 9558 -2571 9581 -2445 9605 -2342 9620 -2262 9630 -2200 9636 -2162 9644
--2141 9649 -2140 9650 -2162 9644 -2193 9630 -2243 9612 -2324 9587 -2432 9556
--2556 9519 -2689 9477 -2817 9432 -2953 9382 -3120 9318 -3317 9249 -3521 9174
--3711 9099 -3871 9028 -4022 8954 -4207 8870 -4397 8777 -4579 8685 -4724 8601
--4825 8528 -4895 8459 -4973 8383 -5039 8306 -5078 8235 -5062 8177 -4989 8138
--4873 8109 -4727 8084 -4553 8063 -4332 8057 -4052 8067 -3714 8097 -3319 8144
--2872 8204 -2377 8276 -1825 8367 -1220 8475 -572 8598 133 8740 905 8905
-1743 9087 2629 9286 3548 9499 4485 9719 5470 9953 6524 10215 7639 10496
-8785 10789 9944 11086 11084 11378 12250 11677 13475 12001 14743 12339
-16019 12683 17276 13016 18485 13330 19689 13641 20928 13967 22185 14302
-23422 14627 24607 14930 25722 15198 26796 15451 27875 15705 28944 15954
-29966 16182 30909 16374 31752 16523 32532 16639 33284 16741 33991 16825
-34607 16868 35140 16871 35592 16831 35955 16751 36208 16630 36368 16474
-36445 16283 36395 16053 36225 15773 35987 15437 35656 15057 35131 14645
-34425 14207 33687 13750 32934 13248 31969 12672 30625 12065 29082 11458
-27676 10845 26460 10249 25048 9639 23013 8930 20319 8159 17449 7506 14984 7059
-13228 6671 11988 6066 10681 5113 8653 3948 5413 2857 622 2108 -6303 2131
--19000 5000 -19000 5000 -19000 5000 -19000 5000 -19000 5000 -19000 5000
--20000 5000 -19000 5000 -19000 5000 -19000 5000 -20000 5000 -19000 5000
--19000 5000 -20000 5000 -19000 5000 -20000 6000 -19000 5000 -20000 5000
--19000 6000 -19000 5000 -20000 6000 -19000 6000 -19000 6000 -20000 6000
-33: 8942040 -6174299 3281 6173 3508 6068 3781 5942 4089 5799 4419 5657
-4758 5503 5117 5345 5499 5183 5914 5015 6344 4842 6775 4679 7224 4508 7681 4341
-8166 4172 8662 3992 9175 3824 9691 3664 10194 3506 10710 3356 11236 3209
-11769 3070 12319 2933 12849 2811 13358 2702 13855 2604 14354 2514 14850 2434
-15340 2371 15806 2324 16230 2290 16622 2278 17000 2279 17364 2297 17690 2335
-17985 2384 18234 2454 18431 2543 18590 2661 18715 2801 18788 2955 18808 3122
-18787 3298 18721 3488 18588 3719 18397 3965 18151 4227 17864 4481 17544 4730
-17183 4991 16757 5256 16286 5540 15767 5821 15208 6079 14629 6306 14030 6508
-13438 6674 12826 6806 12176 6921 11526 7008 10859 7053 10158 7046 9375 6992
-8544 6905 7681 6783 6821 6656 5917 6462 4935 6254 3918 6017 2909 5732 1893 5445
-844 5163 -217 4869 -1310 4537 -2448 4190 -3648 3815 -4901 3440 -6062 3188
--7151 2842 -8305 2483 -9544 2284 -10833 2137 -12094 1888 -13127 1539 -13902 1382
--14716 1384 -15715 1501 -16568 1764 -16857 1969 -16773 2338 -16913 2559
--17575 2438 -18359 2576 -18584 2964 -17997 3037 -17020 2880 -16349 2967
--16394 3343 -17064 3610 -17977 3481 -18866 3159 -19643 3017 -20397 3250
--21218 3840 -22188 4591 -23242 5498 -24302 6632 -25327 7717 -26332 8706
--27355 9734 -28377 10828 -29356 11806 -30234 12476 -31002 12896 -31661 13403
--32222 14253 -32657 15486 -32981 16953 -33187 18934 -32776 20215 -32769 21226
--32962 22093 -33263 22815 -33407 23355 -33336 23688 -32947 23873 -32357 23968
--31672 24010 -31001 24010 -30232 23957 -29341 23874 -28401 23762 -27468 23631
--26532 23500 -25738 23371 -25045 23259 -24438 23178 -23809 23096 -23344 23009
--22871 22912 -22491 22787 -22103 22624 -21871 22451 -21629 22266 -21356 22064
--21140 21857 -20963 21652 -20789 21440 -20592 21230 -20341 21017 -20048 20791
--19791 20541 -19315 20281 -18905 20024 -18338 19774 -17864 19510 -17319 19227
--16743 18923 -16063 18626 -15312 18330 -14538 18037 -13900 17718 -13268 17383
--12802 17030 -12483 16648 -12223 16248 -12039 15844 -11978 15438 -12088 15045
--12392 14680 -12888 14363 -13519 14087 -14295 13857 -15154 13657 -16157 13492
--17184 13362 -18234 13271 -19500 13237 -20771 13244 -22009 13281 -23305 13315
--24659 13361 -26015 13442 -27427 13572 -28765 13763 -30094 13985 -31384 14228
--32729 14476 -33992 14726 -35270 14984 -36472 15259 -37594 15562 -38596 15910
--39456 16280 -40196 16656 -40815 17021 -41321 17360 -41692 17690 -41892 18016
--41889 18328 -41712 18622 -41378 18897 -40942 19136 -40385 19319 -39692 19452
--38850 19532 -37870 19540 -36797 19480 -35661 19348 -34477 19164 -33235 18926
--31926 18633 -30554 18286 -29154 17899 -27751 17479 -26362 17029 -24999 16547
--23659 16037 -22353 15500 -21080 14945 -19846 14377 -18676 13800 -17577 13220
--16556 12642 -15617 12074 -14758 11517 -13954 10968 -13210 10433 -12531 9915
--11933 9418 -11408 8947 -10940 8504 -10516 8083 -10135 7681 -9804 7298
--9520 6933 -9251 6624 -9025 6340 -8841 6080 -8686 5845 -8539 5638 -8402 5464
--8272 5323 -8167 5207 -8094 5115 -8033 5043 -7971 4995 -7914 4970 -7864 4977
--7821 5004 -7793 5042 -7773 5096 -7755 5161 -7741 5245 -7735 5344 -7733 5461
--7736 5577 -7742 5702 -7761 5832 -7786 5970 -7818 6116 -7863 6262 -7909 6414
--7966 6561 -8032 6709 -8098 6859 -8173 7006 -8267 7154 -8375 7297 -8489 7439
--8598 7572 -8696 7706 -8793 7838 -8910 7959 -9036 8079 -9158 8192 -9265 8297
--9356 8397 -9433 8493 -9504 8582 -9574 8665 -9628 8744 -9669 8810 -9692 8872
--9698 8927 -9687 8976 -9655 9017 -9616 9051 -9560 9075 -9501 9094 -9430 9110
--9340 9111 -9228 9102 -9111 9094 -8988 9081 -8876 9052 -8763 9023 -8636 8984
--8493 8935 -8351 8882 -8218 8824 -8098 8769 -7991 8710 -7878 8640 -7766 8566
--7658 8484 -7567 8406 -7493 8336 -7436 8264 -7387 8187 -7347 8107 -7320 8028
--7311 7953 -7317 7890 -7340 7833 -7379 7772 -7439 7715 -7509 7663 -7594 7620
--7686 7587 -7789 7562 -7909 7544 -8056 7531 -8208 7526 -8363 7530 -8515 7546
--8667 7565 -8836 7598 -9023 7642 -9207 7694 -9385 7750 -9549 7810 -9707 7876
--9868 7956 -10033 8047 -10195 8144 -10338 8240 -10468 8335 -10583 8431
--10690 8537 -10791 8651 -10880 8766 -10953 8878 -11010 8979 -11054 9079
--11082 9182 -11097 9288 -11096 9389 -11081 9482 -11057 9564 -11019 9642
--10963 9714 -10894 9784 -10809 9844 -10714 9896 -10613 9942 -10502 9979
--10376 10005 -10234 10026 -10086 10036 -9927 10044 -9765 10046 -9597 10045
--9412 10029 -9224 10006 -9024 9978 -8821 9949 -8613 9923 -8403 9894 -8183 9857
--7953 9814 -7721 9769 -7484 9729 -7251 9693 -7014 9660 -6770 9624 -6518 9588
--6264 9555 -6013 9526 -5770 9500 -5532 9480 -5284 9465 -5032 9453 -4783 9444
--4543 9439 -4321 9435 -4106 9434 -3891 9442 -3676 9454 -3471 9467 -3281 9482
--3115 9494 -2962 9504 -2821 9522 -2686 9544 -2569 9563 -2472 9579 -2394 9589
--2339 9594 -2303 9601 -2287 9607 -2291 9608 -2309 9602 -2343 9590 -2394 9571
--2473 9548 -2579 9518 -2701 9484 -2829 9443 -2952 9400 -3082 9351 -3245 9290
--3432 9222 -3628 9152 -3807 9077 -3958 9007 -4104 8938 -4275 8854 -4455 8764
--4624 8675 -4757 8592 -4845 8520 -4908 8452 -4975 8378 -5032 8300 -5054 8232
--5030 8174 -4952 8135 -4825 8107 -4674 8080 -4492 8059 -4266 8051 -3981 8060
--3642 8088 -3247 8133 -2803 8191 -2307 8260 -1760 8347 -1158 8452 -520 8572
-176 8711 941 8870 1762 9049 2631 9241 3536 9450 4458 9666 5422 9895 6456 10152
-7545 10426 8669 10715 9800 11006 10916 11292 12053 11587 13250 11906 14487 12240
-15734 12577 16958 12906 18136 13218 19314 13523 20522 13846 21746 14177
-22950 14499 24109 14799 25196 15066 26243 15315 27300 15568 28342 15816
-29339 16043 30265 16234 31090 16382 31853 16497 32594 16599 33291 16687
-33899 16729 34427 16730 34882 16689 35247 16605 35505 16483 35677 16325
-35763 16130 35730 15897 35581 15612 35367 15271 35056 14882 34555 14462
-33888 14017 33179 13554 32448 13037 31504 12451 30211 11833 28727 11205
-27356 10584 26134 9985 24722 9360 22754 8622 20186 7830 17425 7172 14961 6729
-13080 6352 11625 5771 10109 4862 7979 3759 4753 2743 64 2151 -6482 2425
--14915 4084 -17372 4589 -18181 4767 -18491 4845 -18640 4890 -18915 4920
--19426 4942 -18986 4959 -18954 4976 -19072 4993 -19494 5011 -19146 5025
--19162 5040 -19569 5071 -19291 5185 -19635 5731 -19345 5398 -19659 5450
--19283 5907 -19299 5703 -19834 6216 -19533 6513 -19772 7002 -21117 8194
-34: 8978621 -6166634 3604 6062 3844 5951 4123 5819 4445 5675 4789 5525
-5142 5367 5517 5208 5917 5036 6341 4864 6786 4685 7238 4511 7706 4338 8178 4161
-8681 3986 9197 3804 9728 3630 10256 3461 10781 3299 11317 3140 11856 2991
-12417 2841 12979 2702 13527 2573 14051 2460 14566 2354 15076 2263 15594 2178
-16097 2111 16575 2063 17014 2028 17418 2009 17809 2017 18178 2033 18512 2070
-18813 2120 19063 2196 19270 2288 19423 2414 19542 2558 19613 2724 19630 2898
-19599 3090 19518 3298 19369 3542 19153 3808 18883 4094 18570 4366 18226 4643
-17838 4923 17383 5220 16877 5536 16318 5845 15722 6139 15102 6395 14475 6625
-13859 6809 13220 6964 12559 7096 11911 7204 11237 7259 10489 7259 9666 7213
-8821 7125 7966 7012 7070 6860 6089 6678 5039 6475 4003 6196 3005 5896 1988 5620
-928 5335 -175 5011 -1351 4647 -2592 4273 -3899 3855 -5157 3547 -6271 3205
--7409 2781 -8680 2524 -10055 2354 -11442 2070 -12707 1644 -13700 1354
--14548 1309 -15523 1353 -16516 1556 -17129 1766 -17246 2008 -17386 2333
--18057 2357 -19057 2424 -19573 2864 -19030 3135 -17712 2963 -16486 2889
--16101 3234 -16665 3618 -17726 3556 -18744 3093 -19491 2700 -20039 2681
--20605 3086 -21344 3710 -22304 4428 -23375 5417 -24425 6568 -25439 7667
--26480 8772 -27595 9962 -28723 11100 -29792 11891 -30736 12249 -31561 12494
--32277 13085 -32886 14196 -33379 15709 -33740 17399 -33173 19340 -33272 20675
--33819 21841 -34340 22854 -34510 23638 -34252 24129 -33691 24357 -33043 24421
--32514 24404 -32107 24339 -31550 24223 -30707 24073 -29674 23904 -28576 23716
--27470 23546 -26519 23400 -25722 23296 -25060 23232 -24367 23190 -23779 23133
--23180 23059 -22629 22952 -22179 22799 -21906 22623 -21717 22443 -21451 22262
--21257 22076 -21115 21897 -20951 21712 -20754 21520 -20546 21313 -20371 21093
--20243 20835 -19903 20563 -19497 20303 -18931 20052 -18416 19813 -17911 19548
--17388 19262 -16746 18965 -15953 18679 -15066 18402 -14294 18127 -13479 17839
--12876 17526 -12396 17184 -11963 16789 -11643 16364 -11459 15916 -11378 15458
--11464 15031 -11764 14643 -12263 14315 -12975 14036 -13764 13802 -14765 13610
--15834 13449 -16942 13329 -18051 13247 -19443 13245 -20731 13262 -22094 13283
--23467 13314 -24886 13374 -26409 13493 -27829 13667 -29289 13895 -30657 14137
--32091 14382 -33391 14623 -34811 14874 -36170 15140 -37498 15443 -38693 15794
--39741 16185 -40673 16584 -41476 16965 -42156 17330 -42696 17681 -43082 18035
--43292 18388 -43288 18732 -43092 19069 -42727 19374 -42241 19635 -41634 19838
--40879 19982 -39972 20056 -38912 20049 -37748 19966 -36524 19824 -35248 19619
--33912 19351 -32511 19025 -31045 18655 -29546 18248 -28046 17804 -26567 17318
--25113 16792 -23693 16237 -22314 15655 -20969 15060 -19670 14451 -18440 13836
--17289 13221 -16227 12607 -15260 12011 -14375 11425 -13550 10847 -12798 10282
--12118 9744 -11515 9219 -10989 8729 -10528 8262 -10116 7828 -9751 7415
--9430 7025 -9161 6653 -8899 6339 -8689 6051 -8521 5788 -8379 5549 -8244 5343
--8114 5173 -7995 5035 -7898 4928 -7830 4841 -7776 4779 -7719 4739 -7665 4724
--7618 4745 -7581 4780 -7550 4836 -7527 4902 -7510 4977 -7493 5077 -7489 5190
--7481 5315 -7480 5447 -7483 5586 -7497 5727 -7517 5877 -7551 6030 -7588 6192
--7632 6351 -7686 6509 -7752 6664 -7821 6821 -7894 6974 -7989 7131 -8104 7278
--8219 7427 -8334 7564 -8438 7705 -8540 7834 -8661 7959 -8796 8082 -8929 8196
--9044 8304 -9138 8402 -9219 8499 -9298 8587 -9370 8668 -9426 8744 -9470 8809
--9497 8867 -9505 8917 -9493 8965 -9458 9000 -9415 9028 -9359 9051 -9297 9063
--9226 9068 -9131 9064 -9014 9051 -8891 9033 -8768 9013 -8660 8977 -8544 8939
--8417 8892 -8274 8834 -8131 8771 -8001 8705 -7888 8643 -7785 8575 -7679 8497
--7575 8414 -7476 8326 -7394 8240 -7333 8164 -7288 8087 -7254 8005 -7230 7920
--7221 7838 -7231 7761 -7255 7693 -7295 7636 -7358 7576 -7439 7519 -7533 7469
--7642 7428 -7756 7399 -7882 7378 -8028 7363 -8195 7358 -8377 7361 -8555 7372
--8729 7394 -8902 7422 -9092 7464 -9300 7518 -9507 7581 -9705 7648 -9885 7719
--10058 7795 -10232 7886 -10412 7989 -10586 8097 -10739 8206 -10876 8311
--10997 8417 -11108 8534 -11211 8659 -11302 8785 -11375 8905 -11429 9017
--11468 9124 -11492 9235 -11498 9347 -11488 9457 -11464 9556 -11430 9645
--11378 9726 -11313 9804 -11226 9875 -11126 9939 -11016 9993 -10899 10041
--10775 10079 -10632 10107 -10474 10125 -10307 10135 -10133 10141 -9955 10142
--9772 10138 -9575 10121 -9369 10094 -9155 10062 -8940 10029 -8722 9999
--8502 9966 -8270 9924 -8032 9876 -7792 9826 -7547 9781 -7309 9740 -7067 9703
--6821 9660 -6564 9619 -6311 9581 -6061 9546 -5818 9516 -5578 9491 -5337 9471
--5086 9453 -4841 9441 -4609 9431 -4390 9423 -4181 9420 -3973 9422 -3765 9431
--3567 9442 -3383 9453 -3223 9462 -3078 9472 -2943 9487 -2815 9506 -2704 9525
--2613 9539 -2539 9548 -2489 9555 -2457 9559 -2444 9566 -2449 9567 -2469 9561
--2503 9552 -2554 9533 -2631 9512 -2735 9483 -2851 9451 -2975 9412 -3095 9370
--3220 9322 -3372 9265 -3552 9199 -3737 9129 -3906 9059 -4049 8991 -4185 8923
--4343 8841 -4512 8754 -4667 8666 -4789 8585 -4866 8514 -4919 8448 -4972 8375
--5017 8299 -5027 8230 -4997 8172 -4906 8133 -4771 8105 -4613 8078 -4426 8055
--4193 8046 -3903 8054 -3561 8080 -3168 8123 -2724 8177 -2229 8244 -1685 8327
--1092 8429 -461 8544 228 8681 979 8835 1788 9008 2642 9196 3530 9401 4434 9610
-5376 9835 6387 10087 7454 10356 8551 10638 9656 10924 10747 11206 11853 11496
-13023 11809 14226 12138 15441 12473 16632 12796 17784 13103 18928 13406
-20105 13727 21295 14054 22467 14374 23595 14671 24653 14936 25677 15185
-26705 15437 27722 15685 28695 15911 29599 16104 30408 16251 31156 16366
-31884 16468 32572 16560 33169 16604 33695 16604 34150 16562 34519 16480
-34783 16356 34968 16197 35066 16001 35048 15766 34923 15479 34729 15132
-34439 14736 33971 14310 33344 13861 32664 13390 31952 12862 31034 12268
-29797 11637 28373 10994 27021 10364 25781 9762 24387 9125 22492 8373 20058 7566
-17394 6889 14913 6431 12858 6068 11125 5560 9338 4790 7034 3864 3807 3033
--571 2586 -6094 2788 -11951 3641 -15138 4164 -16733 4446 -17561 4606 -18062 4714
--18485 4789 -18847 4847 -18805 4893 -18842 4937 -18973 4984 -19177 5032
--19123 5079 -19168 5135 -19343 5222 -19337 5384 -19486 5680 -19477 5709
--19616 5868 -19573 6179 -19685 6330 -20017 6728 -20161 7196 -20661 7945
--21860 9297
-35: 9015124 -6158951 3922 5950 4171 5837 4463 5699 4795 5552 5151 5394
-5520 5233 5911 5068 6328 4894 6764 4709 7226 4527 7697 4348 8177 4167 8670 3987
-9185 3802 9721 3614 10267 3435 10822 3262 11364 3090 11911 2927 12468 2769
-13048 2616 13629 2471 14194 2336 14738 2220 15265 2108 15795 2009 16324 1922
-16846 1850 17332 1803 17787 1759 18204 1745 18604 1748 18978 1767 19325 1804
-19632 1857 19886 1931 20095 2034 20249 2162 20362 2313 20433 2492 20438 2675
-20401 2876 20306 3102 20139 3362 19899 3654 19603 3958 19268 4259 18894 4556
-18479 4858 17993 5185 17446 5539 16844 5887 16207 6208 15550 6508 14891 6749
-14253 6971 13595 7154 12920 7297 12290 7417 11583 7488 10787 7499 9943 7458
-9106 7377 8231 7258 7268 7104 6212 6937 5130 6691 4132 6397 3152 6123 2117 5840
-1003 5521 -197 5159 -1472 4792 -2806 4381 -4136 3999 -5329 3658 -6432 3195
--7673 2826 -9083 2638 -10575 2346 -12022 1869 -13266 1462 -14264 1346
--15245 1327 -16326 1377 -17244 1520 -17701 1622 -17945 1883 -18583 2132
--19713 2266 -20625 2726 -20420 3235 -18974 3196 -17188 2947 -16166 3135
--16403 3622 -17533 3761 -18778 3310 -19591 2706 -19935 2453 -20102 2644
--20453 3121 -21189 3630 -22235 4290 -23361 5310 -24419 6476 -25437 7670
--26559 8933 -27804 10219 -29068 11247 -30234 11730 -31251 11840 -32131 12120
--32911 12989 -33587 14422 -34139 16145 -34509 17934 -33741 19524 -34452 20969
--35238 22396 -35454 23626 -34926 24489 -34069 24931 -33304 25045 -32965 24975
--32974 24819 -32882 24610 -32287 24354 -31261 24082 -30041 23810 -28757 23563
--27599 23375 -26633 23248 -25829 23188 -25045 23171 -24305 23157 -23554 23107
--22798 23021 -22231 22883 -21893 22713 -21731 22547 -21504 22389 -21328 22239
--21198 22095 -21054 21945 -20866 21780 -20693 21589 -20604 21367 -20604 21108
--20414 20819 -20067 20542 -19575 20295 -19026 20066 -18536 19835 -18036 19568
--17436 19296 -16683 19022 -15785 18761 -14912 18515 -13971 18270 -13199 18016
--12521 17715 -11876 17356 -11380 16930 -11043 16447 -10813 15937 -10670 15432
--10708 14985 -11002 14587 -11596 14252 -12307 13970 -13297 13740 -14319 13555
--15475 13403 -16699 13293 -17897 13225 -19277 13241 -20747 13251 -22162 13268
--23631 13316 -25208 13417 -26700 13586 -28292 13803 -29752 14044 -31266 14282
--32603 14519 -34153 14747 -35623 15010 -37134 15304 -38505 15652 -39764 16048
--40940 16466 -41948 16868 -42821 17246 -43535 17616 -44102 17991 -44528 18380
--44756 18770 -44754 19164 -44535 19544 -44129 19879 -43587 20154 -42932 20374
--42107 20522 -41117 20580 -39967 20560 -38712 20470 -37398 20317 -36028 20088
--34594 19789 -33085 19444 -31518 19053 -29909 18623 -28314 18137 -26739 17602
--25193 17027 -23683 16422 -22224 15797 -20808 15156 -19441 14508 -18146 13853
--16950 13204 -15842 12560 -14850 11928 -13940 11308 -13101 10701 -12340 10109
--11658 9538 -11053 8993 -10540 8480 -10087 8000 -9688 7554 -9335 7133
--9034 6734 -8773 6354 -8532 6034 -8339 5742 -8182 5478 -8056 5239 -7938 5032
--7816 4866 -7707 4735 -7621 4634 -7560 4559 -7510 4504 -7457 4475 -7409 4476
--7365 4503 -7326 4555 -7297 4623 -7273 4705 -7252 4794 -7236 4907 -7226 5035
--7215 5173 -7211 5321 -7208 5470 -7217 5625 -7233 5784 -7259 5953 -7298 6124
--7335 6292 -7387 6460 -7452 6625 -7518 6787 -7596 6951 -7691 7111 -7804 7265
--7928 7418 -8047 7562 -8158 7703 -8265 7836 -8394 7964 -8538 8088 -8680 8204
--8802 8311 -8905 8411 -8989 8506 -9073 8594 -9149 8671 -9213 8744 -9257 8808
--9286 8862 -9296 8909 -9283 8950 -9248 8981 -9197 9004 -9141 9021 -9079 9029
--9006 9025 -8905 9015 -8787 8992 -8655 8970 -8533 8939 -8425 8894 -8310 8847
--8181 8792 -8036 8724 -7899 8652 -7771 8577 -7664 8507 -7567 8432 -7467 8344
--7371 8251 -7281 8155 -7214 8065 -7165 7980 -7133 7897 -7116 7810 -7109 7721
--7119 7635 -7149 7555 -7192 7486 -7254 7427 -7337 7368 -7442 7313 -7563 7263
--7696 7225 -7835 7200 -7983 7184 -8154 7176 -8349 7176 -8557 7187 -8761 7207
--8959 7237 -9153 7274 -9366 7325 -9595 7391 -9825 7464 -10042 7544 -10242 7625
--10426 7713 -10619 7816 -10811 7931 -10997 8052 -11161 8172 -11305 8289
--11431 8406 -11547 8534 -11653 8672 -11744 8807 -11812 8937 -11866 9059
--11904 9174 -11918 9293 -11916 9416 -11897 9530 -11862 9636 -11816 9731
--11754 9817 -11674 9898 -11573 9974 -11454 10039 -11330 10096 -11197 10146
--11056 10186 -10898 10212 -10723 10231 -10537 10240 -10348 10243 -10153 10243
--9955 10236 -9745 10215 -9522 10187 -9295 10150 -9065 10113 -8836 10078
--8606 10041 -8365 9994 -8116 9941 -7869 9886 -7619 9835 -7374 9789 -7128 9746
--6879 9700 -6620 9651 -6366 9607 -6116 9569 -5873 9532 -5634 9503 -5396 9478
--5151 9456 -4912 9438 -4685 9424 -4470 9412 -4266 9404 -4066 9404 -3862 9410
--3675 9418 -3499 9425 -3344 9432 -3204 9440 -3077 9453 -2955 9470 -2850 9489
--2766 9501 -2697 9509 -2651 9515 -2622 9521 -2610 9527 -2619 9529 -2641 9524
--2673 9514 -2723 9498 -2798 9477 -2898 9452 -3010 9420 -3129 9382 -3242 9343
--3362 9298 -3506 9243 -3675 9177 -3851 9112 -4007 9044 -4142 8977 -4267 8911
--4413 8831 -4568 8746 -4710 8661 -4819 8580 -4884 8511 -4926 8446 -4966 8374
--4998 8299 -4997 8230 -4953 8173 -4855 8133 -4712 8105 -4545 8077 -4351 8053
--4110 8043 -3818 8048 -3474 8072 -3080 8113 -2635 8163 -2143 8228 -1604 8307
--1016 8404 -390 8518 283 8648 1024 8797 1818 8967 2657 9150 3530 9348 4415 9554
-5332 9774 6322 10019 7363 10283 8434 10560 9512 10840 10574 11117 11655 11404
-12790 11711 13962 12036 15139 12365 16301 12686 17423 12989 18533 13289
-19677 13607 20831 13933 21971 14250 23067 14547 24095 14811 25094 15058
-26094 15310 27085 15560 28033 15788 28910 15981 29703 16129 30439 16247
-31154 16350 31829 16443 32421 16489 32943 16493 33399 16452 33769 16372
-34046 16250 34236 16092 34353 15896 34348 15661 34244 15372 34080 15022
-33813 14623 33381 14190 32793 13737 32139 13260 31444 12725 30564 12124
-29384 11483 28017 10825 26679 10186 25421 9578 24036 8938 22226 8183 19926 7370
-17359 6664 14855 6174 12621 5815 10617 5390 8559 4788 6099 4067 2966 3414
--959 3041 -5489 3092 -9942 3501 -13101 3884 -15110 4164 -16385 4367 -17225 4521
--17840 4642 -18262 4737 -18456 4814 -18609 4892 -18770 4976 -18933 5059
--19006 5147 -19087 5250 -19206 5382 -19291 5555 -19425 5782 -19546 5966
--19708 6225 -19842 6557 -20055 6872 -20386 7289 -20750 7829 -21355 8606
--22337 9738
-36: 9051538 -6151250 4232 5839 4491 5726 4801 5583 5141 5428 5511 5266
-5893 5099 6298 4927 6727 4750 7178 4562 7657 4369 8146 4186 8644 3998 9151 3814
-9680 3622 10235 3428 10799 3241 11372 3059 11930 2886 12496 2717 13072 2549
-13667 2392 14266 2242 14844 2104 15407 1976 15955 1861 16500 1758 17049 1669
-17579 1593 18079 1538 18546 1493 18975 1482 19383 1479 19770 1498 20130 1534
-20437 1592 20699 1669 20901 1773 21063 1911 21177 2068 21236 2250 21241 2447
-21193 2661 21080 2900 20899 3180 20638 3496 20309 3822 19951 4149 19548 4466
-19105 4799 18587 5162 17993 5549 17345 5932 16671 6312 15963 6592 15273 6936
-14610 7161 13937 7344 13255 7515 12632 7665 11886 7746 11059 7766 10228 7731
-9382 7655 8461 7523 7413 7400 6320 7198 5285 6934 4325 6673 3323 6394 2213 6064
-1000 5711 -290 5354 -1635 4990 -3004 4568 -4268 4188 -5392 3721 -6554 3239
--7953 2967 -9502 2697 -11076 2215 -12545 1718 -13787 1503 -14865 1445
--16001 1323 -17166 1261 -18034 1219 -18554 1305 -19169 1674 -20306 2055
--21558 2572 -21897 3280 -20720 3536 -18575 3211 -16796 3109 -16378 3571
--17351 3990 -18817 3761 -19863 3064 -20095 2538 -19792 2521 -19518 2859
--19798 3204 -20756 3466 -22112 4042 -23412 5058 -24473 6336 -25483 7704
--26690 9114 -28093 10403 -29496 11220 -30750 11431 -31816 11484 -32751 12022
--33600 13241 -34340 14873 -34921 16585 -35248 18269 -35142 19346 -35983 20960
--36191 22736 -35412 24270 -34113 25273 -33141 25700 -32965 25711 -33495 25504
--34058 25211 -33945 24855 -33103 24465 -31832 24072 -30414 23709 -29022 23420
--27840 23230 -26818 23129 -25857 23108 -24918 23105 -24001 23079 -23066 23005
--22336 22884 -21898 22726 -21723 22572 -21546 22445 -21384 22339 -21287 22244
--21149 22141 -20975 22012 -20838 21842 -20827 21626 -20893 21360 -20836 21061
--20555 20764 -20190 20511 -19687 20294 -19216 20082 -18699 19857 -18141 19610
--17444 19356 -16627 19111 -15758 18883 -14752 18663 -13809 18442 -12904 18197
--12013 17882 -11269 17480 -10746 16996 -10339 16451 -10003 15895 -9810 15379
--9838 14922 -10236 14523 -10833 14179 -11771 13901 -12725 13680 -13855 13505
--15168 13364 -16450 13264 -17702 13209 -19199 13215 -20697 13230 -22257 13263
--23836 13354 -25369 13509 -27059 13722 -28631 13948 -30245 14179 -31664 14399
--33306 14620 -34874 14860 -36511 15150 -38015 15489 -39491 15882 -40930 16302
--42190 16716 -43287 17110 -44183 17491 -44952 17887 -45589 18308 -46051 18745
--46295 19187 -46282 19625 -46026 20035 -45581 20389 -44997 20688 -44259 20918
--43356 21059 -42282 21113 -41045 21098 -39698 21009 -38280 20839 -36802 20588
--35261 20269 -33649 19907 -31975 19488 -30260 19006 -28553 18462 -26874 17871
--25226 17243 -23626 16591 -22084 15921 -20589 15238 -19159 14550 -17800 13858
--16549 13170 -15402 12490 -14379 11820 -13447 11162 -12603 10522 -11834 9900
--11149 9305 -10551 8742 -10047 8211 -9613 7721 -9228 7261 -8894 6833 -8612 6423
--8372 6033 -8149 5708 -7972 5410 -7835 5147 -7721 4910 -7619 4706 -7513 4546
--7412 4421 -7337 4329 -7282 4265 -7236 4222 -7193 4203 -7144 4218 -7103 4257
--7067 4327 -7033 4409 -7010 4504 -6985 4611 -6965 4735 -6954 4881 -6937 5034
--6923 5196 -6917 5360 -6919 5525 -6929 5699 -6953 5878 -6988 6060 -7020 6240
--7068 6415 -7128 6590 -7194 6760 -7272 6931 -7370 7098 -7485 7260 -7614 7413
--7740 7563 -7854 7708 -7968 7842 -8104 7974 -8260 8097 -8413 8213 -8544 8322
--8653 8421 -8746 8514 -8833 8601 -8916 8676 -8982 8746 -9033 8806 -9060 8857
--9074 8900 -9060 8935 -9021 8962 -8968 8978 -8907 8989 -8844 8989 -8769 8980
--8666 8960 -8540 8929 -8409 8900 -8282 8860 -8169 8805 -8056 8749 -7927 8684
--7786 8608 -7648 8525 -7527 8441 -7423 8360 -7334 8276 -7243 8181 -7156 8079
--7079 7973 -7023 7876 -6987 7783 -6972 7696 -6970 7604 -6983 7509 -7014 7417
--7061 7337 -7126 7267 -7211 7207 -7318 7148 -7450 7093 -7597 7047 -7756 7012
--7919 6992 -8094 6982 -8289 6977 -8515 6986 -8748 7006 -8980 7034 -9203 7073
--9419 7120 -9656 7183 -9908 7260 -10162 7344 -10399 7436 -10615 7530 -10819 7630
--11023 7745 -11231 7874 -11427 8008 -11601 8141 -11754 8269 -11887 8398
--12006 8538 -12114 8687 -12203 8834 -12272 8975 -12322 9104 -12355 9230
--12363 9357 -12350 9488 -12321 9611 -12275 9723 -12216 9823 -12144 9914
--12050 10000 -11930 10076 -11796 10147 -11654 10206 -11506 10257 -11348 10297
--11175 10325 -10980 10341 -10775 10350 -10569 10350 -10360 10349 -10146 10338
--9920 10316 -9683 10282 -9441 10242 -9198 10199 -8957 10160 -8717 10120
--8464 10067 -8211 10009 -7952 9947 -7698 9892 -7447 9840 -7196 9791 -6943 9740
--6685 9685 -6429 9636 -6179 9591 -5937 9551 -5703 9516 -5464 9486 -5225 9459
--4992 9437 -4769 9419 -4561 9402 -4364 9390 -4168 9387 -3973 9389 -3794 9394
--3625 9400 -3478 9403 -3344 9409 -3222 9420 -3107 9436 -3010 9454 -2931 9467
--2867 9472 -2825 9477 -2797 9484 -2788 9490 -2799 9493 -2822 9489 -2854 9480
--2901 9465 -2973 9446 -3070 9422 -3177 9392 -3292 9358 -3395 9320 -3508 9276
--3645 9222 -3803 9161 -3967 9097 -4114 9031 -4236 8968 -4351 8902 -4482 8825
--4623 8741 -4753 8658 -4847 8579 -4900 8511 -4927 8448 -4954 8375 -4973 8302
--4963 8232 -4903 8177 -4797 8135 -4646 8106 -4470 8077 -4269 8052 -4019 8040
--3725 8044 -3377 8064 -2981 8103 -2541 8150 -2049 8211 -1513 8287 -932 8380
--314 8488 350 8615 1076 8759 1856 8923 2679 9102 3531 9294 4397 9495 5297 9710
-6262 9949 7275 10209 8319 10478 9367 10754 10401 11027 11452 11308 12557 11612
-13691 11931 14834 12256 15964 12574 17050 12873 18129 13173 19236 13487
-20357 13810 21462 14128 22525 14423 23524 14688 24494 14936 25466 15188
-26428 15440 27349 15670 28205 15866 28980 16016 29699 16136 30402 16245
-31065 16336 31649 16388 32168 16396 32626 16360 33001 16283 33287 16164
-33488 16009 33615 15816 33632 15583 33556 15293 33415 14941 33180 14539
-32784 14103 32232 13648 31606 13166 30935 12624 30096 12017 28975 11367
-27660 10699 26335 10049 25061 9435 23681 8795 21949 8049 19780 7237 17311 6503
-14808 5967 12432 5591 10189 5228 7903 4772 5344 4234 2343 3728 -1134 3397
--4903 3331 -8517 3494 -11443 3731 -13602 3963 -15148 4169 -16262 4350
--17065 4503 -17629 4630 -17998 4738 -18270 4848 -18500 4968 -18696 5088
--18842 5216 -18965 5364 -19089 5529 -19225 5715 -19391 5932 -19593 6184
--19825 6515 -20077 6904 -20381 7313 -20767 7773 -21229 8329 -21844 9037
--22654 9918
-37: 9087851 -6143529 4540 5734 4800 5613 5128 5469 5481 5305 5857 5139
-6261 4970 6676 4792 7114 4605 7588 4416 8079 4216 8589 4028 9099 3836 9623 3640
-10164 3445 10740 3244 11322 3050 11904 2861 12482 2683 13066 2509 13659 2335
-14274 2168 14889 2012 15485 1869 16061 1739 16626 1619 17188 1511 17754 1416
-18299 1334 18813 1273 19289 1232 19726 1215 20149 1211 20550 1226 20915 1265
-21232 1320 21496 1402 21705 1514 21862 1655 21973 1818 22028 2009 22030 2214
-21973 2440 21848 2698 21642 2997 21359 3333 21011 3681 20622 4032 20190 4379
-19714 4739 19158 5136 18520 5564 17825 6013 17100 6348 16343 6831 15618 7067
-14921 7333 14244 7589 13559 7791 12918 7937 12138 8031 11320 8056 10520 8040
-9640 7957 8650 7852 7550 7714 6480 7487 5510 7249 4540 6987 3450 6654 2220 6293
-920 5954 -410 5634 -1770 5234 -3070 4796 -4250 4329 -5380 3777 -6690 3380
--8260 3118 -9940 2673 -11550 2116 -13020 1780 -14308 1688 -15546 1465
--16881 1118 -18142 846 -19069 724 -19826 1040 -20866 1701 -22249 2413
--23167 3250 -22616 3852 -20571 3696 -18170 3296 -16854 3502 -17246 4125
--18749 4317 -20126 3736 -20485 2959 -19773 2649 -18672 2835 -18066 3124
--18598 3114 -20241 3030 -22287 3448 -23915 4538 -24881 6100 -25751 7737
--26990 9298 -28536 10550 -30062 11153 -31375 11236 -32472 11460 -33459 12349
--34373 13779 -35165 15318 -35729 16714 -35931 18078 -36780 18682 -36999 20495
--35943 22718 -34134 24677 -32758 25921 -32646 26381 -33729 26310 -35062 26002
--35584 25620 -35011 25174 -33748 24683 -32247 24189 -30720 23758 -29315 23440
--28053 23247 -26830 23139 -25633 23102 -24510 23051 -23433 22969 -22551 22843
--22011 22688 -21750 22543 -21605 22448 -21437 22393 -21368 22350 -21278 22301
--21122 22219 -21010 22078 -21036 21873 -21168 21607 -21179 21299 -20960 20986
--20695 20720 -20345 20510 -19950 20324 -19455 20128 -18868 19909 -18222 19680
--17521 19444 -16757 19215 -15806 18996 -14706 18784 -13598 18564 -12408 18297
--11385 17942 -10605 17491 -9986 16959 -9469 16386 -9084 15827 -8915 15320
--9035 14865 -9417 14459 -10198 14116 -11060 13843 -12117 13633 -13422 13468
--14778 13337 -16115 13244 -17461 13202 -19087 13193 -20741 13223 -22327 13302
--23901 13442 -25615 13644 -27288 13868 -29017 14076 -30590 14277 -32313 14476
--33972 14700 -35638 14977 -37240 15311 -38927 15695 -40609 16107 -42136 16519
--43489 16918 -44611 17316 -45596 17725 -46461 18173 -47143 18649 -47637 19136
--47887 19628 -47849 20101 -47577 20530 -47090 20908 -46413 21225 -45622 21460
--44641 21610 -43487 21685 -42152 21684 -40686 21595 -39153 21406 -37572 21135
--35936 20801 -34213 20401 -32418 19925 -30583 19377 -28754 18767 -26961 18119
--25214 17444 -23523 16750 -21890 16035 -20321 15313 -18815 14578 -17388 13845
--16078 13113 -14896 12389 -13847 11675 -12899 10981 -12046 10310 -11273 9665
--10593 9051 -10011 8471 -9518 7928 -9103 7424 -8744 6953 -8431 6509 -8166 6086
--7955 5687 -7753 5352 -7595 5057 -7479 4795 -7382 4561 -7295 4366 -7203 4212
--7114 4096 -7047 4016 -7000 3961 -6958 3931 -6919 3925 -6877 3951 -6836 4007
--6799 4096 -6764 4192 -6737 4301 -6707 4428 -6687 4567 -6671 4728 -6647 4898
--6626 5072 -6611 5252 -6604 5433 -6611 5618 -6629 5809 -6656 6001 -6686 6192
--6723 6378 -6781 6559 -6846 6739 -6923 6917 -7024 7092 -7145 7257 -7276 7415
--7410 7569 -7527 7715 -7648 7856 -7797 7987 -7963 8110 -8130 8227 -8269 8336
--8389 8433 -8487 8524 -8581 8609 -8669 8683 -8741 8747 -8793 8805 -8825 8853
--8839 8887 -8824 8920 -8782 8939 -8726 8951 -8659 8954 -8593 8949 -8516 8932
--8410 8900 -8279 8865 -8143 8821 -8014 8777 -7895 8711 -7784 8646 -7657 8569
--7518 8483 -7383 8389 -7266 8295 -7167 8204 -7087 8111 -7005 8009 -6927 7894
--6863 7780 -6822 7675 -6798 7576 -6800 7481 -6818 7384 -6849 7284 -6902 7190
--6973 7105 -7059 7035 -7167 6974 -7299 6915 -7457 6862 -7634 6818 -7819 6790
--8011 6773 -8211 6767 -8434 6771 -8687 6787 -8951 6815 -9213 6855 -9460 6902
--9701 6960 -9962 7036 -10239 7124 -10515 7222 -10771 7326 -11009 7432
--11227 7546 -11449 7674 -11670 7818 -11879 7964 -12060 8111 -12224 8252
--12361 8394 -12486 8546 -12592 8707 -12683 8865 -12750 9016 -12795 9157
--12822 9291 -12825 9429 -12801 9566 -12761 9697 -12702 9815 -12631 9921
--12548 10018 -12436 10107 -12301 10189 -12148 10260 -11990 10322 -11827 10373
--11652 10414 -11457 10443 -11244 10458 -11022 10463 -10799 10462 -10573 10460
--10346 10446 -10102 10420 -9850 10382 -9593 10335 -9338 10291 -9086 10246
--8833 10200 -8572 10144 -8309 10078 -8044 10011 -7782 9950 -7525 9893
--7272 9838 -7017 9782 -6756 9721 -6501 9665 -6252 9616 -6011 9570 -5778 9531
--5544 9495 -5310 9463 -5081 9438 -4865 9414 -4663 9392 -4472 9379 -4282 9370
--4096 9370 -3924 9371 -3764 9376 -3623 9376 -3496 9379 -3381 9390 -3272 9404
--3181 9421 -3108 9432 -3049 9439 -3008 9442 -2986 9450 -2978 9456 -2989 9459
--3014 9458 -3044 9450 -3090 9435 -3157 9418 -3250 9396 -3353 9368 -3459 9335
--3557 9300 -3661 9258 -3787 9206 -3935 9148 -4088 9087 -4223 9022 -4332 8961
--4434 8897 -4553 8822 -4677 8740 -4792 8658 -4873 8582 -4910 8516 -4928 8451
--4940 8380 -4942 8307 -4920 8238 -4849 8181 -4729 8141 -4573 8109 -4389 8079
--4178 8053 -3920 8038 -3620 8040 -3272 8058 -2876 8093 -2432 8137 -1945 8195
--1416 8265 -839 8354 -231 8458 425 8580 1135 8720 1901 8878 2708 9050 3542 9238
-4386 9433 5263 9644 6205 9876 7191 10131 8203 10395 9222 10665 10228 10932
-11250 11210 12318 11509 13419 11824 14527 12144 15616 12460 16672 12756
-17716 13053 18787 13366 19871 13688 20939 14005 21969 14300 22938 14565
-23879 14814 24820 15069 25753 15324 26646 15558 27478 15755 28237 15911
-28940 16034 29627 16149 30274 16244 30859 16301 31365 16315 31829 16286
-32213 16212 32506 16100 32716 15948 32865 15761 32902 15530 32854 15242
-32734 14892 32538 14485 32180 14048 31669 13592 31074 13108 30424 12560
-29628 11948 28566 11290 27314 10611 26002 9952 24706 9327 23328 8689 21663 7961
-19619 7158 17263 6404 14782 5815 12313 5402 9889 5065 7438 4711 4819 4311
-1936 3921 -1170 3628 -4398 3497 -7473 3527 -10134 3657 -12296 3833 -13983 4026
--15278 4214 -16248 4387 -16959 4535 -17473 4672 -17857 4814 -18178 4963
--18439 5118 -18649 5283 -18821 5467 -18981 5666 -19154 5867 -19363 6090
--19623 6369 -19924 6738 -20260 7177 -20640 7645 -21079 8144 -21583 8695
--22176 9322 -22865 10017
-38: 9124047 -6135782 4842 5627 5110 5507 5442 5355 5806 5187 6200 5015
-6614 4841 7047 4659 7496 4469 7984 4269 8490 4068 9019 3873 9541 3672 10081 3474
-10637 3271 11228 3065 11827 2860 12425 2666 13021 2483 13623 2303 14228 2122
-14863 1951 15494 1787 16108 1636 16698 1503 17283 1378 17855 1263 18438 1165
-19001 1079 19529 1015 20015 970 20466 947 20899 943 21307 956 21689 991
-22010 1052 22278 1137 22487 1248 22646 1394 22756 1564 22809 1761 22806 1979
-22744 2214 22604 2489 22377 2805 22074 3169 21697 3541 21275 3910 20821 4287
-20308 4679 19708 5113 19021 5600 18270 6006 17490 6622 16687 6856 15899 7261
-15210 7627 14510 7874 13820 8075 13140 8222 12370 8343 11590 8405 10810 8393
-9860 8323 8820 8223 7720 8041 6730 7832 5760 7609 4700 7286 3460 6907 2150 6573
-840 6289 -470 5948 -1770 5479 -3000 4990 -4120 4428 -5370 3917 -6900 3611
--8650 3235 -10370 2659 -11990 2189 -13490 2020 -14890 1792 -16380 1234
--17940 625 -19340 242 -20407 368 -21427 1155 -22733 2182 -24004 3160 -24243 4000
--22808 4218 -20262 3762 -18095 3567 -17541 4151 -18643 4789 -20250 4620
--20977 3748 -20177 3027 -18234 2954 -16303 3232 -15619 3250 -16932 2694
--19977 2098 -23358 2253 -25479 3581 -25946 5781 -26263 7876 -27420 9645
--29108 10858 -30766 11309 -32122 11424 -33248 11924 -34282 13059 -35265 14400
--36082 15472 -36563 16258 -36574 17111 -37813 17426 -36895 19458 -34566 22232
--32498 24791 -32166 26411 -33774 26938 -36116 26783 -37463 26437 -37041 26101
--35593 25683 -33915 25149 -32344 24592 -30882 24115 -29473 23760 -27993 23517
--26491 23344 -25095 23197 -23863 23032 -22865 22848 -22228 22661 -21896 22506
--21697 22424 -21479 22419 -21362 22443 -21317 22453 -21227 22412 -21145 22299
--21205 22105 -21369 21847 -21433 21536 -21255 21215 -21032 20938 -20889 20728
--20664 20561 -20306 20393 -19732 20196 -19065 19980 -18425 19754 -17802 19513
--17000 19270 -15873 19033 -14588 18800 -13152 18557 -11814 18256 -10737 17865
--9877 17393 -9146 16859 -8601 16310 -8255 15778 -8134 15288 -8206 14822
--8630 14406 -9314 14063 -10212 13799 -11453 13603 -12834 13446 -14235 13324
--15737 13240 -17242 13212 -19025 13208 -20670 13267 -22299 13393 -24010 13581
--25777 13787 -27593 13985 -29370 14157 -31178 14329 -32951 14536 -34582 14790
--36234 15117 -38056 15495 -39973 15903 -41746 16307 -43335 16698 -44729 17090
--45997 17512 -47106 17985 -48013 18495 -48737 19026 -49252 19558 -49498 20077
--49493 20565 -49167 21016 -48588 21422 -47908 21759 -47024 22021 -45985 22204
--44716 22314 -43251 22328 -41679 22231 -40060 22022 -38382 21732 -36617 21354
--34751 20887 -32826 20332 -30872 19712 -28924 19048 -27013 18356 -25167 17639
--23369 16901 -21641 16145 -19985 15375 -18397 14591 -16908 13805 -15541 13023
--14324 12249 -13248 11496 -12295 10773 -11431 10077 -10662 9413 -9990 8781
--9424 8185 -8952 7625 -8562 7103 -8231 6615 -7942 6150 -7704 5718 -7519 5316
--7349 4974 -7211 4683 -7116 4429 -7040 4200 -6967 4011 -6889 3865 -6812 3760
--6754 3691 -6715 3650 -6677 3633 -6645 3638 -6599 3681 -6566 3757 -6528 3858
--6492 3974 -6456 4100 -6423 4244 -6398 4401 -6377 4577 -6347 4765 -6314 4954
--6291 5149 -6275 5344 -6277 5543 -6288 5745 -6305 5948 -6329 6150 -6357 6347
--6411 6537 -6471 6724 -6549 6909 -6653 7089 -6780 7260 -6916 7427 -7054 7581
--7179 7729 -7309 7871 -7466 8003 -7650 8128 -7826 8245 -7983 8350 -8108 8448
--8217 8538 -8318 8618 -8412 8691 -8485 8751 -8543 8803 -8577 8846 -8593 8877
--8576 8903 -8529 8918 -8471 8921 -8396 8918 -8327 8903 -8249 8878 -8138 8840
--8002 8792 -7860 8740 -7728 8686 -7607 8613 -7495 8538 -7372 8450 -7233 8350
--7102 8246 -6987 8138 -6897 8038 -6824 7937 -6753 7823 -6683 7700 -6634 7575
--6606 7461 -6601 7357 -6620 7255 -6654 7151 -6709 7047 -6784 6948 -6877 6861
--6989 6789 -7121 6729 -7279 6670 -7467 6618 -7671 6580 -7888 6553 -8105 6543
--8333 6543 -8588 6554 -8872 6579 -9166 6618 -9455 6668 -9729 6725 -9996 6794
--10282 6882 -10585 6983 -10885 7096 -11163 7214 -11419 7332 -11656 7460
--11893 7603 -12129 7762 -12348 7923 -12543 8084 -12711 8238 -12857 8392
--12982 8557 -13091 8730 -13180 8901 -13245 9064 -13286 9215 -13309 9360
--13301 9505 -13269 9651 -13214 9789 -13144 9914 -13061 10026 -12964 10128
--12836 10222 -12683 10306 -12513 10380 -12335 10444 -12155 10496 -11963 10537
--11750 10566 -11520 10580 -11278 10583 -11033 10580 -10795 10574 -10551 10558
--10293 10528 -10024 10484 -9753 10435 -9483 10383 -9219 10336 -8958 10285
--8687 10221 -8415 10151 -8141 10077 -7874 10011 -7611 9948 -7355 9887
--7097 9824 -6837 9758 -6582 9698 -6332 9641 -6095 9591 -5863 9547 -5632 9505
--5404 9469 -5184 9437 -4972 9410 -4776 9386 -4590 9367 -4408 9356 -4231 9352
--4067 9351 -3915 9352 -3781 9351 -3660 9353 -3550 9360 -3452 9374 -3366 9391
--3297 9400 -3242 9407 -3205 9411 -3185 9418 -3180 9425 -3192 9430 -3214 9430
--3245 9421 -3286 9410 -3351 9393 -3438 9373 -3535 9348 -3634 9318 -3727 9284
--3820 9244 -3935 9195 -4073 9139 -4211 9080 -4333 9017 -4428 8959 -4518 8896
--4624 8824 -4732 8743 -4829 8663 -4894 8588 -4918 8522 -4921 8459 -4921 8389
--4907 8314 -4870 8247 -4787 8189 -4658 8147 -4491 8115 -4298 8083 -4074 8056
--3814 8038 -3508 8035 -3157 8052 -2761 8084 -2316 8125 -1833 8176 -1305 8244
--737 8328 -138 8427 506 8544 1206 8678 1954 8830 2743 8997 3558 9179 4379 9368
-5238 9574 6150 9801 7109 10049 8092 10308 9078 10572 10055 10835 11044 11108
-12078 11402 13142 11713 14214 12031 15264 12341 16285 12636 17294 12931
-18332 13242 19374 13565 20404 13880 21399 14176 22336 14442 23246 14693
-24159 14951 25059 15210 25922 15449 26734 15651 27470 15811 28157 15940
-28828 16060 29473 16167 30026 16232 30548 16251 31013 16228 31394 16163
-31700 16055 31937 15911 32095 15730 32152 15504 32124 15219 32056 14869
-31879 14464 31576 14026 31107 13569 30534 13083 29910 12531 29162 11914
-28179 11248 26986 10561 25687 9889 24372 9253 22986 8613 21379 7905 19449 7121
-17205 6357 14772 5721 12263 5255 9731 4911 7169 4609 4506 4300 1737 3997
--1119 3743 -3967 3589 -6674 3554 -9109 3618 -11204 3752 -12947 3926 -14350 4114
--15442 4298 -16277 4464 -16914 4622 -17410 4789 -17818 4967 -18159 5151
--18440 5348 -18669 5566 -18870 5794 -19078 6015 -19329 6245 -19634 6531
--19988 6914 -20387 7376 -20819 7879 -21301 8405 -21823 8949 -22391 9517
--22994 10090
-39: 9160118 -6128007 5132 5525 5410 5400 5746 5244 6126 5075 6536 4893
-6958 4715 7399 4528 7869 4336 8372 4131 8891 3922 9429 3717 9964 3512 10521 3310
-11099 3100 11703 2886 12314 2677 12929 2478 13543 2288 14156 2099 14782 1914
-15436 1737 16083 1566 16712 1410 17314 1271 17917 1140 18505 1021 19103 916
-19684 826 20222 755 20720 709 21186 681 21624 676 22048 685 22440 720 22773 784
-23043 864 23255 982 23417 1131 23527 1308 23579 1512 23567 1737 23498 1983
-23348 2275 23102 2607 22775 2996 22363 3388 21918 3790 21434 4192 20892 4614
-20239 5096 19489 5572 18680 6259 17840 6541 16960 7102 16190 7579 15400 7883
-14710 8137 14080 8366 13330 8566 12610 8740 11880 8825 11060 8812 10080 8742
-8990 8599 7970 8401 6990 8218 5960 7943 4720 7568 3390 7216 2070 6942 830 6654
--390 6218 -1620 5702 -2810 5165 -4030 4601 -5500 4200 -7250 3886 -9080 3349
--10790 2752 -12400 2433 -13970 2234 -15600 1641 -17390 714 -19200 -31
--20710 -201 -21900 480 -23100 1757 -24400 2967 -25253 3913 -24754 4465
--22716 4287 -20167 3864 -18620 4149 -18861 5054 -20310 5500 -21456 4887
--20993 3812 -18653 3234 -15320 3376 -12595 3635 -12138 3215 -14867 1941
--20319 526 -26119 179 -28956 1994 -27771 5643 -26698 8466 -27727 10462
--29712 11604 -31559 11947 -32981 12137 -34145 12828 -35248 13928 -36293 14822
--37108 15142 -37478 15151 -37239 15360 -37939 15563 -35859 17747 -32844 21207
--31595 24643 -33355 26793 -37017 27326 -40040 26980 -40202 26687 -37783 26675
--35206 26472 -33396 25963 -32105 25359 -30870 24847 -29367 24432 -27599 24072
--25827 23737 -24325 23391 -23184 23050 -22469 22745 -22115 22518 -21875 22410
--21565 22442 -21233 22544 -21102 22623 -21055 22630 -21035 22529 -21130 22329
--21348 22055 -21480 21747 -21362 21428 -21161 21146 -21161 20943 -21232 20794
--21136 20646 -20704 20469 -20048 20253 -19385 20019 -18823 19766 -18189 19493
--17196 19208 -15848 18936 -14252 18678 -12641 18414 -11289 18097 -10166 17721
--9212 17281 -8448 16799 -7927 16299 -7563 15793 -7308 15285 -7234 14789
--7536 14350 -8132 14009 -9241 13755 -10593 13570 -12025 13426 -13680 13325
--15418 13261 -17047 13250 -18820 13273 -20528 13373 -22294 13532 -24128 13726
--26013 13905 -27961 14053 -29879 14190 -31769 14364 -33394 14607 -35052 14923
--36931 15300 -39007 15702 -40976 16105 -42777 16484 -44450 16861 -46040 17273
--47467 17754 -48629 18300 -49583 18865 -50339 19430 -50893 19983 -51219 20513
--51144 21014 -50766 21489 -50243 21927 -49431 22305 -48506 22620 -47331 22858
--45942 23002 -44405 23017 -42751 22896 -40993 22663 -39161 22325 -37257 21876
--35276 21325 -33223 20693 -31136 20017 -29067 19315 -27028 18590 -25055 17833
--23154 17052 -21329 16244 -19582 15416 -17915 14574 -16362 13728 -14942 12892
--13684 12078 -12586 11297 -11620 10550 -10761 9831 -9997 9146 -9336 8491
--8789 7870 -8349 7289 -7991 6745 -7686 6233 -7436 5760 -7231 5321 -7068 4922
--6929 4585 -6819 4301 -6748 4050 -6691 3828 -6638 3647 -6572 3504 -6507 3413
--6461 3357 -6427 3332 -6398 3326 -6365 3347 -6327 3408 -6292 3500 -6251 3618
--6209 3755 -6171 3900 -6134 4062 -6101 4238 -6075 4431 -6036 4634 -5993 4843
--5954 5050 -5928 5262 -5922 5476 -5927 5688 -5937 5904 -5948 6116 -5972 6322
--6014 6520 -6075 6717 -6150 6907 -6256 7092 -6388 7269 -6532 7440 -6677 7600
--6808 7751 -6946 7890 -7116 8024 -7315 8150 -7509 8265 -7678 8368 -7812 8465
--7931 8553 -8041 8629 -8142 8700 -8222 8758 -8278 8802 -8319 8840 -8336 8865
--8316 8885 -8265 8895 -8196 8892 -8122 8879 -8050 8857 -7966 8820 -7850 8772
--7709 8718 -7559 8655 -7425 8591 -7303 8509 -7193 8423 -7069 8322 -6931 8211
--6802 8092 -6694 7974 -6610 7863 -6544 7752 -6482 7626 -6428 7493 -6393 7359
--6378 7235 -6392 7123 -6428 7016 -6483 6906 -6562 6795 -6659 6693 -6776 6605
--6914 6531 -7072 6468 -7258 6412 -7475 6364 -7712 6328 -7958 6308 -8206 6301
--8463 6307 -8747 6328 -9066 6363 -9390 6411 -9710 6473 -10011 6541 -10305 6623
--10619 6722 -10945 6840 -11272 6966 -11573 7098 -11848 7233 -12103 7372
--12356 7532 -12604 7706 -12837 7883 -13045 8059 -13219 8226 -13370 8392
--13501 8572 -13609 8759 -13694 8942 -13757 9117 -13794 9279 -13811 9434
--13796 9588 -13752 9741 -13685 9888 -13601 10019 -13504 10139 -13391 10245
--13248 10343 -13077 10431 -12887 10507 -12692 10570 -12492 10625 -12283 10667
--12055 10695 -11802 10707 -11542 10708 -11278 10702 -11023 10693 -10762 10674
--10490 10641 -10205 10592 -9919 10537 -9636 10480 -9361 10428 -9088 10371
--8810 10302 -8528 10225 -8246 10147 -7973 10073 -7706 10005 -7445 9938
--7186 9869 -6927 9797 -6671 9730 -6424 9669 -6187 9612 -5958 9564 -5730 9517
--5512 9476 -5294 9439 -5092 9408 -4900 9380 -4720 9357 -4547 9343 -4378 9337
--4222 9332 -4080 9330 -3952 9329 -3836 9326 -3733 9335 -3644 9347 -3564 9362
--3498 9372 -3450 9379 -3412 9382 -3396 9389 -3393 9398 -3406 9403 -3426 9406
--3455 9398 -3493 9387 -3554 9373 -3635 9356 -3725 9332 -3815 9304 -3902 9272
--3984 9234 -4090 9188 -4212 9135 -4336 9078 -4445 9017 -4528 8961 -4604 8901
--4692 8828 -4784 8751 -4863 8673 -4915 8598 -4922 8533 -4911 8470 -4897 8400
--4866 8326 -4812 8258 -4717 8199 -4578 8158 -4400 8123 -4197 8089 -3966 8059
--3697 8038 -3385 8034 -3030 8047 -2633 8075 -2192 8111 -1711 8158 -1187 8221
--625 8300 -35 8394 597 8506 1283 8635 2017 8781 2785 8942 3580 9116 4381 9300
-5215 9501 6099 9722 7031 9963 7982 10216 8936 10476 9882 10733 10838 11002
-11836 11291 12862 11599 13894 11912 14907 12219 15889 12513 16865 12805
-17864 13116 18868 13438 19857 13754 20817 14051 21718 14319 22597 14572
-23477 14835 24347 15098 25180 15343 25966 15551 26679 15718 27352 15853
-28008 15981 28615 16102 29200 16176 29702 16202 30159 16188 30566 16130
-30890 16032 31122 15897 31300 15723 31381 15503 31404 15224 31354 14877
-31225 14471 30964 14034 30528 13579 29993 13091 29410 12536 28712 11912
-27799 11240 26673 10543 25404 9859 24078 9209 22683 8563 21109 7869 19265 7110
-17129 6346 14771 5675 12272 5157 9691 4779 7063 4489 4386 4231 1692 3984
--989 3767 -3584 3616 -6038 3555 -8292 3586 -10306 3696 -12049 3856 -13507 4045
--14683 4235 -15618 4415 -16351 4591 -16945 4781 -17442 4984 -17863 5190
--18216 5414 -18505 5661 -18753 5919 -18999 6162 -19286 6399 -19626 6684
--20020 7061 -20455 7523 -20929 8039 -21437 8577 -21969 9116 -22518 9646
--23071 10147
-40: 9196055 -6120196 5408 5424 5697 5295 6048 5135 6438 4963 6851 4777
-7289 4594 7748 4403 8224 4205 8739 3992 9280 3779 9822 3567 10373 3358
-10950 3150 11536 2935 12162 2715 12786 2496 13416 2294 14043 2095 14676 1903
-15318 1710 15982 1528 16654 1349 17292 1189 17916 1044 18525 907 19133 784
-19739 668 20337 576 20895 500 21407 449 21885 420 22333 409 22763 417 23170 450
-23515 509 23787 593 24003 715 24170 865 24281 1050 24331 1257 24316 1491
-24238 1752 24078 2051 23818 2409 23458 2801 23017 3251 22540 3657 22028 4082
-21460 4544 20740 5060 19940 5738 19070 6142 18100 6783 17280 7410 16270 7775
-15580 8110 15000 8404 14270 8670 13500 9050 12860 9233 12160 9291 11300 9257
-10260 9160 9220 8976 8220 8803 7220 8594 6010 8260 4640 7907 3290 7628
-2090 7358 980 6975 -180 6463 -1410 5951 -2690 5423 -4100 4938 -5820 4603
--7720 4158 -9530 3487 -11160 2960 -12760 2703 -14490 2247 -16440 1219
--18540 63 -20540 -534 -22120 -181 -23320 1091 -24500 2553 -25580 3588
--25930 4222 -24890 4399 -22725 4113 -20655 4173 -19903 5083 -20703 6135
--21986 6194 -22117 5139 -20055 3970 -15960 3605 -11167 3949 -7673 4138
--7588 3270 -12253 1123 -21372 -1596 -31511 -3085 -35690 -613 -30027 6417
--26105 9986 -27480 12032 -30227 12995 -32387 13137 -33881 13274 -35115 13905
--36329 14648 -37455 14856 -38274 14358 -38531 13640 -38056 13209 -37681 13278
--34783 15339 -31524 19658 -31893 24331 -36415 27164 -42163 27412 -45314 26563
--43017 26450 -37096 27325 -33472 27575 -32222 27079 -31717 26398 -30839 25880
--29199 25399 -27021 24851 -24964 24254 -23440 23629 -22558 23077 -22219 22654
--22088 22434 -21790 22437 -21220 22628 -20672 22832 -20406 22916 -20372 22834
--20533 22585 -20824 22244 -21084 21886 -21103 21563 -20974 21292 -21078 21102
--21451 20983 -21735 20868 -21646 20707 -21107 20486 -20412 20230 -19815 19955
--19279 19655 -18491 19335 -17248 19015 -15659 18730 -13899 18477 -12316 18231
--10991 17962 -9805 17660 -8764 17304 -7960 16892 -7340 16417 -6736 15878
--6171 15293 -5906 14732 -6048 14265 -6827 13915 -8114 13671 -9546 13504
--11259 13392 -13236 13329 -15113 13302 -16766 13321 -18520 13385 -20422 13512
--22358 13683 -24316 13844 -26351 13969 -28366 14076 -30350 14212 -32059 14427
--33705 14737 -35605 15123 -37752 15537 -39834 15937 -41776 16313 -43710 16667
--45639 17057 -47451 17524 -48945 18078 -50154 18677 -51164 19274 -51998 19843
--52672 20392 -52930 20914 -52888 21433 -52586 21952 -51884 22444 -51066 22887
--49971 23269 -48705 23561 -47280 23712 -45623 23710 -43787 23558 -41865 23272
--39900 22858 -37910 22319 -35799 21692 -33608 21012 -31382 20309 -29153 19583
--26975 18825 -24881 18023 -22881 17188 -20959 16315 -19123 15421 -17377 14516
--15745 13614 -14265 12735 -12964 11893 -11847 11087 -10875 10312 -10026 9566
--9272 8846 -8637 8161 -8114 7512 -7709 6905 -7386 6342 -7120 5821 -6908 5342
--6738 4907 -6609 4514 -6500 4194 -6418 3915 -6372 3663 -6338 3446 -6303 3267
--6256 3137 -6206 3055 -6169 3014 -6143 3001 -6115 3012 -6084 3054 -6050 3130
--6017 3240 -5973 3379 -5925 3536 -5881 3701 -5835 3881 -5794 4079 -5766 4289
--5714 4510 -5657 4737 -5604 4961 -5565 5185 -5552 5413 -5548 5642 -5547 5866
--5546 6090 -5561 6304 -5594 6512 -5651 6716 -5726 6913 -5834 7103 -5972 7286
--6123 7459 -6274 7623 -6416 7774 -6559 7917 -6744 8050 -6961 8176 -7174 8289
--7357 8391 -7502 8483 -7632 8571 -7748 8645 -7856 8707 -7944 8764 -8006 8805
--8050 8832 -8067 8855 -8045 8868 -7988 8870 -7912 8859 -7833 8838 -7757 8806
--7668 8762 -7546 8704 -7399 8639 -7243 8564 -7104 8494 -6983 8397 -6872 8298
--6746 8189 -6612 8063 -6485 7930 -6381 7801 -6306 7678 -6247 7555 -6198 7420
--6158 7275 -6137 7129 -6141 6997 -6170 6877 -6225 6762 -6303 6646 -6405 6532
--6528 6424 -6670 6333 -6835 6258 -7020 6196 -7235 6142 -7485 6096 -7754 6065
--8032 6049 -8310 6048 -8598 6063 -8916 6090 -9265 6138 -9626 6197 -9976 6270
--10306 6351 -10628 6445 -10968 6558 -11323 6690 -11675 6833 -11999 6981
--12295 7130 -12569 7286 -12837 7461 -13100 7650 -13347 7843 -13564 8035
--13745 8217 -13905 8398 -14036 8591 -14145 8791 -14229 8988 -14287 9176
--14320 9349 -14331 9513 -14306 9677 -14251 9839 -14169 9993 -14071 10132
--13961 10257 -13832 10369 -13674 10471 -13482 10561 -13274 10640 -13058 10706
--12840 10760 -12614 10803 -12366 10829 -12095 10840 -11814 10838 -11531 10829
--11258 10817 -10981 10795 -10695 10758 -10394 10702 -10093 10642 -9795 10581
--9511 10523 -9225 10460 -8938 10386 -8648 10303 -8360 10218 -8080 10138
--7810 10062 -7547 9992 -7284 9916 -7022 9838 -6771 9764 -6526 9697 -6289 9636
--6064 9581 -5841 9531 -5628 9485 -5418 9442 -5223 9407 -5037 9375 -4864 9350
--4697 9332 -4539 9323 -4391 9316 -4256 9311 -4136 9306 -4027 9305 -3930 9311
--3847 9323 -3774 9337 -3714 9347 -3668 9352 -3634 9358 -3618 9363 -3618 9375
--3628 9382 -3651 9384 -3674 9379 -3710 9369 -3766 9358 -3842 9341 -3922 9322
--4006 9295 -4079 9265 -4154 9229 -4247 9187 -4357 9136 -4465 9081 -4559 9022
--4629 8967 -4688 8909 -4758 8840 -4837 8763 -4896 8686 -4930 8613 -4925 8548
--4895 8484 -4866 8415 -4819 8342 -4749 8272 -4640 8213 -4488 8170 -4299 8134
--4087 8097 -3847 8064 -3570 8040 -3252 8033 -2893 8043 -2497 8066 -2057 8098
--1577 8140 -1057 8197 -505 8271 77 8360 697 8466 1369 8589 2087 8728 2836 8883
-3610 9051 4389 9229 5196 9423 6055 9640 6954 9873 7876 10119 8796 10374
-9708 10627 10631 10892 11591 11177 12580 11479 13572 11789 14544 12093
-15489 12385 16426 12677 17384 12986 18348 13308 19298 13625 20218 13925
-21084 14194 21931 14452 22779 14719 23613 14988 24416 15240 25175 15457
-25867 15630 26521 15772 27164 15911 27789 16046 28316 16130 28818 16167
-29304 16162 29713 16115 30027 16028 30285 15902 30487 15740 30617 15528
-30643 15255 30643 14911 30556 14510 30331 14072 29959 13620 29477 13132
-28923 12574 28266 11942 27432 11262 26386 10556 25167 9859 23838 9191
-22422 8535 20863 7848 19082 7108 17047 6355 14768 5663 12312 5100 9737 4679
-7087 4374 4410 4133 1765 3917 -797 3730 -3230 3590 -5509 3527 -7632 3550
--9563 3651 -11282 3806 -12763 3996 -13988 4195 -14990 4387 -15805 4580
--16479 4791 -17055 5014 -17555 5242 -17978 5485 -18328 5756 -18631 6042
--18918 6307 -19234 6557 -19602 6837 -20022 7196 -20479 7643 -20977 8153
--21502 8687 -22042 9218 -22579 9724 -23103 10183
-41: 9231851 -6112354 5675 5326 5974 5195 6331 5032 6735 4855 7160 4668
-7606 4474 8076 4279 8566 4077 9096 3859 9644 3641 10204 3425 10769 3209
-11357 2995 11962 2773 12590 2546 13238 2325 13880 2114 14528 1910 15174 1708
-15831 1515 16515 1323 17192 1138 17850 974 18492 818 19111 681 19734 552
-20354 428 20970 328 21542 250 22064 193 22557 161 23013 149 23460 151 23877 179
-24234 235 24514 328 24727 444 24900 602 25015 786 25062 997 25049 1240
-24961 1511 24791 1831 24515 2180 24126 2652 23658 3059 23150 3520 22600 3991
-21990 4488 21250 5092 20350 5630 19340 6285 18500 7083 17240 7551 16550 7950
-15860 8359 14990 8748 14340 9128 13770 9562 13180 9690 12440 9711 11520 9660
-10460 9541 9450 9381 8440 9237 7310 8983 5940 8642 4510 8369 3280 8118
-2260 7763 1250 7268 70 6771 -1290 6328 -2760 5850 -4420 5426 -6330 5020
--8220 4367 -9880 3644 -11400 3209 -13060 2875 -15040 2048 -17340 687 -19740 -447
--21820 -630 -23350 310 -24440 1854 -25440 3040 -26200 3568 -26170 3748
--25010 3707 -23250 3819 -22000 4762 -21992 6314 -22934 7330 -23516 6912
--22216 5503 -18374 4363 -12538 4238 -6354 4776 -2028 4979 -2020 3871 -8479 944
--22349 -3647 -40266 -7817 -48406 -5554 -31319 9722 -22638 12642 -26504 14390
--30738 15037 -33134 14743 -34618 14512 -35991 14750 -37422 14927 -38714 14456
--39566 13414 -39735 12333 -39121 11537 -37963 11248 -34723 12510 -30708 17741
--32726 23845 -40596 27592 -48689 26926 -52230 24845 -46263 25098 -33839 28109
--30085 28978 -30844 28225 -31741 27363 -31326 26999 -29381 26502 -26436 25695
--23931 24753 -22406 23802 -21884 23032 -21981 22526 -22043 22375 -21630 22555
--20642 22968 -19595 23260 -19061 23273 -19130 23000 -19532 22506 -19999 21970
--20252 21544 -20315 21270 -20534 21120 -21156 21058 -21895 21005 -22277 20884
--22056 20660 -21414 20361 -20737 20041 -20215 19724 -19628 19395 -18639 19063
--17207 18766 -15496 18535 -13799 18357 -12324 18206 -10938 18058 -9590 17872
--8384 17604 -7388 17219 -6441 16684 -5461 16005 -4642 15274 -4246 14603
--4521 14084 -5588 13721 -6980 13497 -8641 13370 -10699 13322 -12829 13322
--14678 13346 -16357 13398 -18360 13505 -20442 13647 -22509 13796 -24567 13913
--26617 13991 -28632 14091 -30489 14273 -32184 14572 -34098 14970 -36274 15410
--38379 15838 -40377 16214 -42479 16549 -44743 16905 -46978 17334 -48873 17873
--50418 18484 -51719 19104 -52854 19696 -53846 20239 -54473 20763 -54837 21287
--54853 21842 -54369 22418 -53651 22984 -52652 23508 -51508 23957 -50216 24273
--48604 24405 -46739 24362 -44748 24155 -42726 23792 -40695 23289 -38554 22677
--36307 22008 -33957 21316 -31542 20603 -29174 19850 -26886 19047 -24668 18189
--22555 17284 -20535 16340 -18587 15379 -16745 14417 -15041 13476 -13502 12567
--12155 11695 -11021 10857 -10059 10042 -9225 9254 -8499 8496 -7887 7775
--7397 7102 -7028 6480 -6751 5910 -6531 5390 -6359 4914 -6235 4485 -6146 4101
--6063 3798 -6014 3518 -5995 3263 -5984 3044 -5969 2875 -5941 2754 -5908 2686
--5884 2659 -5860 2665 -5834 2693 -5808 2752 -5773 2846 -5738 2980 -5693 3141
--5638 3317 -5586 3505 -5528 3706 -5486 3922 -5444 4155 -5382 4393 -5312 4637
--5239 4878 -5190 5119 -5161 5360 -5149 5603 -5135 5840 -5124 6072 -5123 6296
--5153 6511 -5201 6721 -5275 6928 -5386 7122 -5528 7309 -5686 7485 -5850 7649
--5997 7804 -6151 7949 -6352 8082 -6588 8205 -6818 8316 -7019 8418 -7180 8507
--7316 8590 -7447 8662 -7562 8720 -7656 8769 -7721 8804 -7768 8829 -7789 8844
--7764 8850 -7700 8844 -7615 8825 -7529 8795 -7449 8756 -7356 8701 -7229 8632
--7072 8554 -6910 8472 -6765 8390 -6643 8279 -6530 8169 -6405 8043 -6270 7907
--6149 7762 -6052 7617 -5983 7484 -5935 7349 -5897 7201 -5871 7045 -5866 6888
--5889 6744 -5936 6617 -6011 6496 -6114 6374 -6238 6254 -6390 6144 -6559 6046
--6751 5971 -6964 5910 -7211 5857 -7493 5816 -7797 5788 -8107 5778 -8420 5785
--8740 5805 -9090 5846 -9474 5902 -9870 5974 -10252 6060 -10613 6152 -10963 6261
--11331 6389 -11717 6537 -12093 6696 -12443 6862 -12760 7026 -13053 7198
--13335 7389 -13617 7595 -13876 7805 -14100 8014 -14293 8211 -14455 8406
--14591 8615 -14700 8829 -14782 9039 -14835 9240 -14863 9424 -14867 9599
--14834 9772 -14765 9944 -14668 10105 -14555 10252 -14431 10383 -14286 10500
--14111 10605 -13901 10699 -13671 10780 -13435 10846 -13198 10902 -12954 10945
--12686 10969 -12394 10977 -12093 10973 -11794 10963 -11502 10945 -11209 10921
--10906 10877 -10591 10819 -10273 10751 -9964 10685 -9666 10621 -9370 10553
--9075 10472 -8776 10382 -8480 10291 -8196 10204 -7922 10122 -7655 10046
--7390 9965 -7131 9881 -6880 9800 -6635 9727 -6403 9661 -6182 9601 -5964 9545
--5756 9494 -5553 9448 -5366 9408 -5187 9373 -5019 9344 -4861 9323 -4712 9311
--4573 9301 -4447 9295 -4333 9288 -4232 9285 -4140 9290 -4063 9302 -3998 9314
--3943 9324 -3899 9331 -3868 9335 -3854 9344 -3853 9356 -3864 9364 -3884 9368
--3905 9364 -3938 9356 -3988 9346 -4055 9333 -4127 9315 -4202 9293 -4265 9263
--4328 9231 -4408 9189 -4505 9142 -4598 9088 -4673 9033 -4730 8980 -4774 8922
--4827 8855 -4886 8780 -4927 8705 -4942 8632 -4920 8568 -4877 8504 -4826 8435
--4768 8361 -4678 8290 -4554 8230 -4389 8184 -4190 8147 -3967 8107 -3718 8071
--3433 8045 -3108 8033 -2747 8039 -2350 8057 -1910 8084 -1432 8121 -919 8173
--370 8240 199 8324 807 8424 1465 8540 2165 8673 2896 8821 3646 8983 4402 9155
-5186 9342 6015 9551 6883 9778 7771 10020 8659 10267 9536 10516 10422 10775
-11346 11057 12292 11354 13243 11661 14176 11962 15081 12252 15979 12543
-16896 12852 17816 13176 18725 13493 19603 13794 20436 14069 21250 14331
-22063 14603 22858 14880 23631 15139 24361 15364 25032 15546 25667 15699
-26295 15849 26875 15996 27427 16093 27953 16142 28413 16149 28809 16115
-29159 16041 29443 15930 29672 15779 29799 15576 29873 15311 29912 14973
-29866 14576 29721 14142 29416 13692 28962 13204 28429 12643 27835 12004
-27094 11312 26140 10596 24971 9888 23651 9200 22219 8527 20656 7836 18926 7109
-16959 6367 14767 5667 12369 5070 9821 4609 7188 4277 4528 4029 1924 3825
--561 3656 -2890 3531 -5057 3475 -7080 3503 -8940 3607 -10627 3768 -12104 3963
--13359 4172 -14409 4379 -15278 4591 -16024 4818 -16668 5061 -17237 5306
--17730 5564 -18142 5854 -18498 6162 -18826 6451 -19174 6716 -19568 6994
--19998 7334 -20476 7756 -20979 8243 -21520 8761 -22058 9276 -22588 9763
--23092 10197
-42: 9267489 -6104481 5931 5234 6238 5102 6606 4934 7016 4750 7452 4560
-7912 4362 8389 4162 8893 3953 9435 3729 9991 3509 10568 3288 11145 3067
-11744 2844 12369 2614 13007 2384 13669 2158 14324 1941 14989 1731 15644 1526
-16319 1324 17013 1126 17713 933 18384 759 19033 605 19674 460 20309 324
-20941 194 21570 87 22161 7 22699 -55 23194 -96 23672 -111 24126 -114 24558 -88
-24923 -32 25210 61 25434 178 25609 333 25722 522 25778 739 25759 984 25665 1272
-25483 1573 25190 2027 24770 2393 24280 2913 23720 3411 23190 3882 22520 4401
-21670 4990 20690 5648 19820 6566 18450 7198 17650 7644 16710 8191 15630 8775
-15000 9284 14600 9659 14060 9872 13480 9954 12700 9997 11710 9995 10660 9924
-9640 9843 8560 9714 7260 9448 5780 9173 4450 8949 3420 8628 2560 8151 1550 7636
-200 7252 -1390 6879 -3090 6410 -4950 5921 -6870 5318 -8580 4496 -10010 3814
--11430 3467 -13240 2964 -15580 1785 -18260 277 -20850 -606 -22920 -303
--24250 978 -25140 2297 -25890 2791 -26400 2609 -26290 2338 -25510 2421
--24630 3462 -24390 5635 -24840 7818 -25450 8685 -24884 7815 -21966 6185
--16438 5141 -9191 5210 -1966 5888 3206 6258 3889 5466 -2784 2542 -20521 -3853
--51165 -13397 -73121 -16925 -28021 18918 -13945 15355 -25882 17333 -31520 17696
--33347 16474 -34668 15385 -36425 14939 -38355 14538 -39971 13697 -40896 12699
--40989 12013 -40355 11628 -39225 11179 -36520 10731 -30391 16122 -32314 22138
--44581 27815 -55461 25413 -61614 20799 -51573 21488 -25306 29575 -25242 30592
--30543 28788 -33138 27563 -32998 27889 -30365 27521 -25828 26366 -22585 25047
--21027 23727 -20971 22795 -21637 22255 -22025 22248 -21599 22640 -19950 23430
--17912 23798 -16985 23634 -17339 23082 -18069 22210 -18714 21423 -19057 20974
--19454 20849 -20301 20896 -21457 20976 -22391 20956 -22646 20766 -22202 20428
--21463 20020 -20887 19635 -20486 19306 -19858 19014 -18744 18770 -17254 18608
--15610 18534 -14051 18525 -12524 18555 -10857 18568 -9155 18498 -7604 18267
--6235 17805 -4914 17071 -3726 16140 -2912 15182 -2709 14344 -3401 13740
--4652 13362 -6152 13181 -8082 13140 -10283 13191 -12316 13271 -14137 13359
--15978 13454 -18403 13587 -20609 13729 -22679 13851 -24687 13934 -26648 14010
--28603 14156 -30435 14435 -32429 14843 -34636 15321 -36759 15791 -38699 16202
--40833 16535 -43357 16852 -45997 17226 -48345 17715 -50272 18311 -51941 18947
--53424 19549 -54758 20098 -55748 20596 -56498 21099 -56905 21646 -56769 22257
--56237 22908 -55390 23561 -54337 24164 -53152 24647 -51627 24949 -49810 25039
--47806 24934 -45752 24654 -43670 24205 -41466 23632 -39176 22985 -36740 22313
--34216 21625 -31681 20894 -29195 20097 -26751 19231 -24404 18301 -22160 17319
--19997 16306 -17952 15288 -16023 14289 -14234 13319 -12625 12381 -11261 11468
--10134 10577 -9181 9710 -8359 8876 -7655 8079 -7079 7338 -6636 6659 -6315 6035
--6089 5468 -5922 4952 -5806 4483 -5728 4059 -5679 3677 -5630 3383 -5615 3093
--5624 2838 -5638 2625 -5642 2461 -5632 2353 -5613 2303 -5599 2294 -5582 2318
--5559 2367 -5533 2445 -5496 2562 -5461 2719 -5408 2901 -5350 3102 -5288 3312
--5222 3536 -5170 3774 -5116 4024 -5042 4284 -4952 4545 -4865 4804 -4798 5063
--4756 5318 -4730 5573 -4706 5821 -4678 6066 -4664 6295 -4682 6521 -4726 6737
--4795 6948 -4911 7148 -5058 7338 -5223 7519 -5398 7685 -5553 7841 -5718 7985
--5933 8119 -6196 8241 -6449 8346 -6668 8448 -6845 8534 -6995 8611 -7136 8681
--7262 8734 -7359 8775 -7431 8807 -7481 8825 -7501 8832 -7473 8831 -7402 8818
--7309 8790 -7213 8752 -7126 8702 -7030 8639 -6894 8557 -6729 8468 -6558 8373
--6405 8283 -6279 8156 -6165 8032 -6042 7894 -5910 7743 -5793 7584 -5702 7426
--5641 7279 -5605 7133 -5579 6973 -5568 6803 -5582 6634 -5620 6480 -5689 6344
--5784 6217 -5911 6087 -6063 5960 -6239 5847 -6443 5748 -6661 5671 -6905 5608
--7183 5559 -7498 5521 -7839 5500 -8184 5496 -8532 5507 -8884 5538 -9270 5589
--9690 5658 -10123 5742 -10538 5841 -10930 5948 -11311 6070 -11709 6214
--12124 6379 -12528 6558 -12902 6739 -13241 6920 -13554 7108 -13855 7317
--14151 7541 -14421 7771 -14658 7994 -14858 8208 -15025 8419 -15164 8642
--15272 8872 -15352 9096 -15400 9309 -15423 9506 -15419 9692 -15375 9874
--15293 10055 -15184 10224 -15053 10379 -14912 10515 -14753 10638 -14559 10747
--14329 10844 -14079 10925 -13824 10994 -13566 11051 -13302 11093 -13015 11115
--12700 11121 -12381 11113 -12063 11100 -11753 11079 -11444 11050 -11124 11002
--10793 10937 -10461 10865 -10140 10792 -9829 10722 -9522 10647 -9217 10561
--8911 10464 -8610 10365 -8320 10272 -8042 10186 -7772 10102 -7506 10014
--7248 9924 -6996 9838 -6757 9758 -6529 9687 -6308 9623 -6096 9561 -5896 9505
--5702 9455 -5521 9411 -5349 9372 -5189 9339 -5039 9317 -4898 9300 -4768 9289
--4652 9282 -4543 9272 -4449 9268 -4365 9271 -4294 9284 -4233 9295 -4185 9306
--4143 9313 -4115 9318 -4102 9327 -4101 9341 -4112 9350 -4129 9357 -4146 9354
--4175 9348 -4217 9341 -4276 9330 -4341 9314 -4406 9294 -4458 9267 -4508 9237
--4573 9199 -4656 9153 -4733 9102 -4793 9050 -4829 8998 -4860 8942 -4896 8875
--4933 8804 -4954 8727 -4950 8657 -4912 8592 -4849 8529 -4784 8459 -4708 8383
--4601 8313 -4460 8250 -4282 8202 -4070 8163 -3837 8120 -3579 8081 -3284 8050
--2954 8034 -2590 8035 -2190 8049 -1752 8071 -1277 8102 -767 8147 -227 8209
-334 8286 930 8379 1570 8489 2253 8615 2962 8755 3692 8911 4424 9075 5181 9256
-5982 9458 6817 9680 7668 9913 8523 10156 9365 10398 10214 10653 11100 10931
-12003 11224 12909 11526 13803 11825 14667 12114 15525 12403 16397 12715
-17275 13036 18140 13357 18977 13661 19774 13939 20552 14206 21325 14486
-22087 14770 22824 15038 23527 15274 24172 15466 24791 15628 25401 15792
-25974 15952 26528 16063 27017 16127 27467 16148 27907 16129 28278 16071
-28571 15976 28786 15837 28967 15648 29091 15392 29174 15063 29200 14670
-29117 14241 28843 13795 28430 13308 27963 12744 27440 12096 26788 11391
-25918 10664 24823 9941 23526 9234 22090 8538 20528 7833 18801 7108 16882 6373
-14749 5670 12416 5051 9919 4558 7319 4196 4701 3932 2132 3727 -294 3565
--2558 3451 -4656 3407 -6601 3446 -8408 3563 -10058 3734 -11526 3942 -12789 4165
--13873 4388 -14790 4617 -15583 4865 -16285 5123 -16916 5383 -17470 5656
--17943 5958 -18352 6281 -18724 6592 -19104 6873 -19516 7154 -19965 7478
--20447 7873 -20954 8329 -21497 8819 -22037 9312 -22557 9776 -23050 10192
-43: 9302972 -6096564 6169 5145 6491 5009 6863 4840 7285 4649 7728 4457
-8200 4256 8688 4049 9202 3834 9752 3608 10327 3378 10907 3159 11500 2927
-12113 2700 12747 2465 13401 2230 14081 1999 14743 1775 15423 1558 16091 1349
-16783 1139 17490 936 18197 736 18891 555 19553 399 20202 244 20851 103
-21502 -33 22140 -144 22748 -233 23294 -296 23805 -342 24296 -365 24767 -371
-25210 -351 25575 -295 25876 -204 26109 -85 26287 68 26405 258 26467 474
-26449 732 26360 1000 26150 1401 25840 1711 25410 2251 24840 2781 24390 3225
-23660 3704 22950 4285 22220 4940 21210 5846 19870 6683 18760 7185 17750 7841
-16360 8664 15570 9359 15290 9810 14830 10045 14250 9919 13730 10048 12910 10227
-11870 10338 10810 10387 9750 10396 8550 10266 7120 10028 5650 9823 4500 9571
-3700 9123 2920 8580 1730 8167 100 7918 -1730 7533 -3630 6950 -5510 6272
--7230 5455 -8590 4608 -9760 4084 -11180 3797 -13290 3084 -16070 1647 -19130 165
--21840 -400 -23760 235 -24850 1451 -25500 2103 -26060 1669 -26490 704
--26630 80 -26670 609 -27070 3009 -27900 6837 -28350 9673 -28120 10345
--26160 9077 -21670 7297 -14850 6336 -6885 6455 447 7077 5858 7640 7570 7835
-3590 6740 -11290 1139 -54427 -14084 -119462 -43038 -13991 36346 -2000 15000
--28785 21614 -31644 21191 -31367 17884 -32964 15308 -35955 14080 -38975 13350
--41142 12661 -42119 12409 -42033 13056 -41247 14415 -40308 15920 -39013 16909
--36473 17583 -26524 12443 -46357 26445 -59232 22546 -73296 13829 -63289 13879
--5632 33522 -21555 31857 -33867 27593 -36656 25860 -36106 28406 -32526 28257
--24782 26509 -20745 24925 -19099 23167 -19641 22248 -21192 21693 -22094 21937
--22086 22456 -19502 24035 -15645 24412 -14262 23925 -15403 23076 -16520 21642
--17435 20528 -17940 20144 -18897 20310 -20457 20638 -21949 20850 -22770 20804
--22675 20477 -21918 19967 -21125 19419 -20770 18984 -20691 18727 -20171 18590
--19054 18576 -17578 18691 -16036 18893 -14438 19149 -12518 19401 -10258 19570
--7963 19570 -5913 19287 -4202 18615 -2781 17549 -1802 16249 -1449 14966
--1871 13904 -2948 13180 -4214 12801 -5794 12707 -7804 12800 -9837 12976
--11744 13154 -13723 13302 -15857 13446 -18560 13597 -20741 13745 -22673 13860
--24539 13951 -26465 14084 -28459 14334 -30569 14741 -32902 15250 -35084 15783
--36947 16248 -38955 16612 -41558 16907 -44528 17214 -47308 17626 -49618 18169
--51666 18795 -53575 19414 -55307 19964 -56698 20449 -57782 20909 -58584 21414
--58880 22009 -58679 22697 -58119 23443 -57203 24181 -56116 24836 -54680 25314
--52961 25572 -51045 25602 -49020 25427 -46878 25068 -44572 24556 -42197 23955
--39701 23309 -37121 22650 -34500 21942 -31840 21159 -29152 20294 -26567 19341
--24041 18328 -21610 17273 -19373 16211 -17233 15159 -15187 14134 -13325 13133
--11692 12148 -10314 11170 -9157 10218 -8203 9297 -7409 8424 -6749 7616
--6233 6878 -5839 6206 -5577 5590 -5409 5028 -5301 4514 -5243 4043 -5214 3612
--5215 3225 -5211 2915 -5232 2626 -5264 2378 -5301 2177 -5324 2026 -5335 1937
--5327 1906 -5322 1917 -5309 1964 -5288 2035 -5259 2135 -5222 2277 -5182 2457
--5127 2665 -5061 2889 -4989 3123 -4915 3372 -4850 3632 -4785 3903 -4691 4182
--4585 4464 -4479 4741 -4393 5016 -4340 5286 -4297 5554 -4255 5816 -4207 6066
--4182 6305 -4185 6541 -4223 6766 -4287 6977 -4404 7181 -4557 7374 -4735 7560
--4917 7728 -5084 7885 -5259 8027 -5494 8159 -5786 8280 -6068 8386 -6310 8480
--6502 8564 -6669 8637 -6820 8699 -6956 8749 -7062 8784 -7136 8810 -7188 8821
--7209 8821 -7176 8812 -7094 8790 -6993 8757 -6884 8708 -6791 8648 -6686 8572
--6541 8481 -6367 8378 -6187 8273 -6024 8170 -5892 8029 -5778 7892 -5659 7741
--5529 7573 -5414 7398 -5333 7226 -5279 7066 -5255 6907 -5242 6734 -5247 6549
--5277 6369 -5337 6203 -5427 6057 -5544 5922 -5695 5786 -5876 5655 -6079 5534
--6314 5434 -6563 5355 -6838 5294 -7148 5246 -7502 5213 -7879 5198 -8262 5200
--8643 5220 -9030 5259 -9451 5320 -9912 5402 -10381 5502 -10833 5615 -11261 5735
--11672 5872 -12099 6034 -12542 6218 -12977 6413 -13379 6615 -13739 6812
--14071 7019 -14392 7244 -14703 7488 -14985 7737 -15233 7979 -15439 8208
--15614 8436 -15754 8674 -15863 8920 -15939 9158 -15984 9385 -15998 9594
--15986 9790 -15930 9985 -15836 10173 -15710 10353 -15565 10512 -15407 10655
--15230 10783 -15018 10897 -14767 10994 -14496 11079 -14219 11148 -13943 11206
--13660 11246 -13350 11266 -13017 11271 -12675 11259 -12338 11241 -12010 11218
--11685 11183 -11347 11130 -11002 11060 -10655 10981 -10321 10901 -9997 10825
--9682 10746 -9365 10651 -9054 10548 -8747 10443 -8452 10342 -8169 10248
--7895 10160 -7631 10064 -7375 9970 -7124 9876 -6888 9790 -6662 9715 -6447 9644
--6241 9579 -6046 9518 -5861 9464 -5688 9415 -5524 9373 -5371 9337 -5230 9311
--5097 9292 -4979 9279 -4868 9271 -4768 9259 -4680 9253 -4603 9258 -4538 9267
--4484 9281 -4438 9291 -4403 9299 -4374 9304 -4361 9316 -4361 9330 -4371 9342
--4385 9349 -4400 9350 -4422 9345 -4456 9341 -4506 9333 -4563 9319 -4615 9302
--4657 9278 -4694 9250 -4745 9213 -4809 9171 -4871 9122 -4914 9072 -4934 9022
--4943 8968 -4962 8902 -4979 8832 -4979 8757 -4955 8686 -4898 8622 -4819 8559
--4736 8487 -4638 8412 -4513 8338 -4360 8274 -4165 8224 -3943 8181 -3696 8137
--3427 8091 -3124 8057 -2788 8037 -2420 8033 -2018 8042 -1582 8058 -1108 8082
--604 8121 -72 8175 481 8246 1063 8333 1688 8436 2349 8552 3041 8686 3747 8833
-4451 8991 5184 9167 5955 9361 6755 9575 7571 9801 8391 10037 9197 10275
-10010 10525 10852 10798 11714 11087 12576 11385 13424 11681 14246 11968
-15064 12258 15892 12569 16724 12892 17544 13214 18338 13523 19098 13804
-19838 14076 20574 14365 21297 14657 22000 14935 22667 15181 23292 15385
-23890 15559 24482 15737 25071 15914 25554 16040 26032 16120 26543 16157
-26990 16156 27342 16116 27624 16039 27893 15917 28142 15743 28306 15498
-28437 15178 28516 14793 28465 14371 28256 13928 27935 13443 27539 12878
-27079 12218 26494 11497 25729 10755 24722 10018 23480 9293 22051 8569
-20463 7841 18727 7104 16812 6367 14723 5661 12441 5027 10006 4511 7464 4122
-4892 3841 2365 3628 -19 3467 -2234 3360 -4283 3327 -6180 3382 -7944 3516
--9565 3706 -11013 3931 -12282 4169 -13384 4412 -14333 4660 -15165 4926
--15913 5202 -16594 5477 -17201 5760 -17727 6071 -18191 6404 -18606 6730
--19022 7027 -19452 7314 -19914 7629 -20401 7997 -20909 8421 -21448 8876
--21985 9340 -22499 9779 -22985 10174
-44: 9338271 -6088605 6402 5061 6723 4921 7109 4750 7539 4553 7993 4358
-8470 4156 8965 3940 9496 3725 10054 3492 10637 3258 11227 3029 11836 2797
-12457 2562 13104 2323 13769 2084 14464 1848 15143 1614 15825 1392 16513 1182
-17213 963 17937 752 18655 551 19362 361 20038 196 20698 36 21362 -110 22028 -248
-22680 -368 23299 -462 23859 -527 24380 -583 24883 -609 25369 -622 25825 -604
-26206 -555 26511 -467 26748 -346 26931 -196 27059 -6 27130 213 27120 457
-27010 797 26800 1073 26480 1553 25970 2085 25610 2519 24700 3000 24240 3579
-23740 4212 22620 4988 21370 5929 19980 6559 19060 7260 17380 8307 16240 9267
-15890 9823 15410 10054 14630 10213 14400 9971 14010 10274 13130 10617
-11980 10841 10880 10986 9750 11014 8440 10868 6950 10675 5620 10489 4710 10135
-4060 9593 3190 9099 1700 8858 -230 8664 -2270 8126 -4170 7320 -5840 6441
--7140 5554 -8060 4872 -9010 4594 -10630 4327 -13230 3376 -16560 1750 -19950 354
--22720 25 -24460 718 -25300 1508 -25770 1277 -26250 -112 -26830 -1797
--27510 -2680 -28630 -1604 -30600 2386 -32580 8585 -32240 11999 -30750 12358
--27330 10639 -21500 8707 -13860 7812 -6220 7848 -650 7955 3000 8188 3160 9183
-700 11149 -60 11492 -17750 10082 -163783 -65771 -6797 8754 -17970 29192
--26423 30415 -24494 25149 -23839 17857 -28371 13542 -34424 11947 -39366 11441
--42294 11424 -43218 12359 -42656 14669 -41253 17974 -39754 21336 -38304 23021
--37293 18653 -34487 17053 -42800 21095 -53744 19921 -79158 7506 -87127 1770
-27985 41653 -27873 30267 -43049 23225 -41079 20840 -39504 29030 -36273 28382
--22449 25554 -18769 24309 -16643 21777 -17774 21433 -20619 20700 -21975 21418
--23398 21543 -20074 24982 -12936 25005 -11183 23961 -14361 23147 -15592 20776
--16864 19242 -17259 19087 -18833 19753 -21101 20428 -22620 20735 -22959 20577
--22319 20025 -21150 19286 -20347 18551 -20388 18082 -21113 18033 -20891 18198
--19742 18553 -18169 19095 -16585 19666 -14614 20225 -11919 20709 -8729 20990
--5654 20970 -3113 20559 -1379 19587 -325 18083 -80 16318 -690 14622 -1907 13261
--3136 12400 -4282 12050 -5776 12100 -7539 12368 -9311 12685 -11326 12951
--13689 13159 -16088 13358 -18669 13544 -20645 13721 -22424 13873 -24260 14027
--26316 14271 -28580 14662 -31066 15193 -33432 15780 -35308 16320 -37096 16737
--39531 17035 -42644 17286 -45751 17596 -48394 18044 -50746 18621 -53057 19238
--55273 19812 -57132 20300 -58572 20737 -59732 21187 -60486 21729 -60761 22401
--60648 23191 -60055 24032 -59133 24844 -57830 25513 -56211 25958 -54442 26166
--52530 26137 -50374 25902 -47959 25488 -45432 24947 -42851 24350 -40254 23715
--37589 23028 -34816 22253 -31913 21374 -29065 20401 -26222 19350 -23527 18257
--21054 17152 -18663 16060 -16401 14989 -14309 13931 -12397 12875 -10670 11819
--9215 10775 -8055 9766 -7150 8814 -6413 7938 -5810 7144 -5340 6421 -5007 5758
--4806 5145 -4703 4578 -4665 4049 -4668 3566 -4705 3120 -4754 2726 -4813 2385
--4868 2109 -4925 1883 -4980 1700 -5020 1574 -5046 1507 -5055 1497 -5056 1535
--5045 1602 -5021 1698 -4991 1823 -4954 1991 -4910 2195 -4848 2434 -4772 2680
--4691 2942 -4605 3214 -4527 3499 -4451 3792 -4340 4091 -4208 4393 -4084 4689
--3977 4980 -3905 5267 -3852 5546 -3786 5819 -3716 6078 -3669 6328 -3663 6571
--3688 6800 -3749 7018 -3866 7225 -4028 7422 -4216 7606 -4409 7778 -4586 7934
--4773 8077 -5036 8206 -5361 8324 -5675 8427 -5945 8518 -6157 8596 -6336 8664
--6504 8720 -6647 8766 -6762 8796 -6839 8813 -6893 8819 -6917 8811 -6871 8793
--6780 8762 -6663 8720 -6543 8665 -6441 8592 -6330 8504 -6171 8402 -5987 8288
--5794 8169 -5623 8054 -5486 7900 -5373 7751 -5253 7581 -5127 7397 -5014 7205
--4939 7019 -4896 6844 -4883 6671 -4886 6484 -4906 6283 -4955 6090 -5036 5912
--5149 5758 -5289 5613 -5464 5471 -5673 5332 -5911 5208 -6173 5105 -6455 5024
--6760 4965 -7108 4920 -7501 4890 -7915 4881 -8336 4892 -8752 4919 -9176 4968
--9638 5042 -10136 5137 -10647 5251 -11136 5380 -11599 5516 -12041 5669
--12499 5848 -12975 6052 -13440 6267 -13869 6487 -14254 6702 -14606 6927
--14945 7173 -15272 7437 -15567 7704 -15825 7966 -16041 8211 -16221 8457
--16363 8711 -16470 8972 -16542 9227 -16580 9467 -16589 9689 -16568 9897
--16502 10101 -16391 10300 -16251 10486 -16087 10654 -15912 10803 -15720 10937
--15488 11052 -15214 11153 -14922 11239 -14621 11309 -14326 11366 -14024 11406
--13695 11425 -13340 11424 -12975 11410 -12619 11387 -12274 11360 -11930 11321
--11578 11262 -11215 11185 -10855 11100 -10507 11014 -10172 10931 -9846 10845
--9523 10745 -9203 10634 -8891 10521 -8589 10413 -8304 10314 -8030 10218
--7763 10116 -7508 10015 -7262 9917 -7029 9825 -6806 9742 -6596 9668 -6395 9598
--6209 9531 -6033 9474 -5866 9421 -5712 9377 -5566 9336 -5432 9308 -5312 9287
--5200 9272 -5098 9261 -5008 9249 -4925 9242 -4854 9245 -4797 9257 -4747 9270
--4707 9280 -4674 9288 -4646 9296 -4634 9308 -4634 9324 -4643 9339 -4651 9349
--4664 9350 -4678 9349 -4705 9346 -4746 9341 -4793 9331 -4833 9316 -4861 9295
--4885 9269 -4921 9234 -4968 9195 -5010 9151 -5037 9101 -5037 9053 -5030 8999
--5028 8936 -5021 8865 -5001 8793 -4957 8722 -4880 8658 -4782 8593 -4680 8521
--4560 8444 -4420 8369 -4246 8302 -4040 8250 -3804 8203 -3546 8155 -3264 8105
--2952 8067 -2609 8040 -2238 8032 -1835 8035 -1397 8045 -928 8062 -429 8093
-96 8140 640 8205 1210 8283 1816 8380 2460 8487 3128 8613 3808 8751 4492 8903
-5195 9071 5933 9258 6702 9463 7483 9683 8263 9913 9031 10144 9806 10390
-10606 10657 11424 10943 12240 11235 13042 11530 13823 11815 14598 12105
-15382 12415 16163 12740 16938 13063 17689 13376 18405 13662 19109 13941
-19808 14237 20490 14539 21154 14828 21789 15086 22388 15301 22965 15488
-23536 15684 24065 15879 24551 16024 25095 16120 25593 16176 25995 16195
-26350 16176 26691 16120 27033 16017 27285 15858 27484 15629 27668 15320
-27777 14943 27805 14529 27718 14092 27491 13611 27134 13041 26714 12370
-26226 11630 25580 10869 24680 10115 23500 9369 22073 8620 20462 7861 18694 7100
-16779 6348 14708 5631 12468 4987 10093 4452 7606 4046 5082 3748 2594 3529
-245 3364 -1933 3260 -3950 3241 -5810 3313 -7542 3469 -9125 3682 -10565 3927
--11826 4186 -12940 4450 -13909 4720 -14769 5003 -15554 5297 -16271 5589
--16922 5881 -17496 6197 -18011 6535 -18471 6868 -18920 7178 -19373 7472
--19846 7781 -20340 8129 -20853 8521 -21380 8942 -21910 9371 -22424 9781
--22898 10154
-45: 9373395 -6080604 6615 4981 6941 4842 7337 4663 7773 4467 8241 4265
-8723 4056 9222 3839 9766 3617 10338 3385 10927 3148 11532 2909 12142 2674
-12776 2431 13435 2190 14114 1946 14814 1702 15510 1467 16208 1239 16901 1017
-17613 794 18348 580 19082 372 19799 181 20482 5 21163 -158 21839 -316 22512 -457
-23183 -583 23811 -678 24386 -754 24918 -812 25440 -845 25935 -867 26403 -854
-26795 -805 27103 -723 27348 -604 27550 -453 27680 -268 27770 -57 27760 218
-27650 492 27430 856 27040 1377 26800 1772 25760 2252 25550 2875 25090 3491
-23930 4108 22880 4947 21500 5735 20560 6435 18840 7635 17300 8915 16420 9671
-15830 9925 14940 10037 14110 10322 14700 10520 14480 11022 13370 11391
-12020 11590 10830 11680 9630 11609 8280 11412 6850 11240 5700 11018 5020 10567
-4400 10028 3280 9697 1460 9607 -740 9329 -2820 8535 -4490 7506 -5680 6562
--6370 5845 -6840 5517 -7750 5492 -9800 5147 -13120 3898 -17100 2075 -20860 707
--23640 449 -25190 974 -25870 1181 -26290 130 -26890 -1999 -27810 -4171
--29150 -5201 -31420 -3799 -35090 1534 -38590 11297 -35750 14584 -32860 14356
--28170 12001 -21270 9948 -13060 9364 -6440 9503 -5530 8429 -6080 7372
--14060 7390 -33910 7292 -68640 -2623 56720 34467 -86417 -31082 -38965 -1413
--29729 22917 -23207 30389 -11836 25134 -10875 14256 -21853 9657 -32789 8938
--40068 9356 -43636 10296 -44283 12387 -42965 16026 -40667 20603 -38493 24690
--36897 26090 -36795 23290 -39201 21266 -39324 11709 -52195 26135 -41342 18970
--72112 8457 -19381 27736 -37125 23659 -49847 17253 -42298 12542 -39520 30447
--41156 26387 -19166 22916 -18907 23661 -14030 18902 -15225 20894 -19694 19205
--20516 20824 -24279 19265 -23215 26714 -10611 25097 -8524 23259 -16249 23808
--15794 19651 -17749 17682 -16846 17999 -19202 19429 -22454 20429 -23585 20719
--23043 20345 -21766 19460 -20011 18457 -19167 17443 -19681 16906 -22252 17287
--22331 17853 -20795 18654 -18765 19764 -17023 20699 -14490 21545 -10651 22242
--6242 22541 -2362 22406 563 21882 1790 20637 2068 18652 1256 16391 -556 14203
--2520 12471 -3664 11469 -4517 11200 -5657 11450 -7016 11916 -8768 12356
--11256 12686 -14105 12954 -16608 13224 -18634 13471 -20373 13723 -22137 13959
--24200 14228 -26580 14615 -29202 15143 -31794 15766 -33831 16379 -35461 16867
--37520 17194 -40484 17396 -43743 17597 -46601 17906 -49107 18373 -51682 18952
--54368 19542 -56810 20073 -58713 20527 -60224 20956 -61416 21441 -62242 22063
--62709 22844 -62687 23749 -62135 24686 -61093 25547 -59632 26217 -58006 26636
--56253 26804 -54168 26743 -51675 26473 -48971 26044 -46263 25510 -43612 24912
--40935 24234 -38106 23446 -35030 22531 -31942 21506 -28787 20396 -25825 19249
--23072 18098 -20393 16967 -17911 15855 -15594 14753 -13379 13638 -11296 12503
--9469 11373 -8015 10276 -6908 9246 -6047 8306 -5360 7457 -4799 6685 -4388 5972
--4124 5302 -3999 4671 -3979 4078 -4022 3522 -4104 3021 -4205 2565 -4307 2168
--4428 1808 -4517 1559 -4602 1364 -4677 1216 -4734 1113 -4772 1069 -4798 1085
--4806 1147 -4794 1239 -4769 1358 -4732 1513 -4692 1706 -4643 1936 -4573 2204
--4488 2481 -4397 2767 -4296 3066 -4207 3373 -4112 3691 -3985 4013 -3826 4335
--3677 4650 -3548 4957 -3458 5259 -3385 5552 -3300 5834 -3201 6102 -3131 6364
--3109 6611 -3124 6843 -3179 7068 -3298 7278 -3467 7477 -3666 7664 -3875 7832
--4060 7991 -4268 8133 -4557 8260 -4917 8372 -5272 8473 -5570 8558 -5806 8632
--6004 8696 -6180 8745 -6340 8784 -6458 8808 -6540 8819 -6598 8815 -6616 8802
--6566 8774 -6462 8735 -6325 8684 -6190 8619 -6078 8536 -5958 8438 -5788 8323
--5585 8192 -5380 8065 -5203 7934 -5062 7768 -4946 7603 -4825 7418 -4700 7215
--4593 7006 -4524 6802 -4491 6612 -4488 6425 -4507 6223 -4543 6008 -4615 5797
--4717 5608 -4850 5444 -5017 5291 -5220 5142 -5458 4995 -5727 4866 -6020 4760
--6337 4679 -6675 4619 -7059 4578 -7491 4554 -7947 4551 -8408 4570 -8860 4606
--9322 4665 -9824 4751 -10366 4863 -10917 4991 -11446 5137 -11943 5289
--12421 5458 -12912 5657 -13421 5880 -13917 6116 -14373 6356 -14784 6592
--15158 6834 -15513 7101 -15856 7387 -16168 7675 -16436 7955 -16660 8219
--16845 8481 -16989 8753 -17093 9030 -17160 9302 -17192 9556 -17194 9790
--17166 10010 -17088 10225 -16961 10435 -16803 10628 -16621 10802 -16428 10959
--16220 11097 -15968 11215 -15671 11320 -15356 11405 -15033 11476 -14717 11534
--14394 11572 -14044 11589 -13667 11585 -13283 11565 -12906 11538 -12543 11507
--12184 11463 -11814 11397 -11434 11315 -11061 11221 -10700 11129 -10353 11040
--10016 10947 -9685 10839 -9359 10722 -9042 10601 -8737 10486 -8447 10380
--8170 10278 -7905 10171 -7652 10062 -7409 9957 -7179 9860 -6961 9772 -6756 9693
--6560 9618 -6384 9547 -6216 9485 -6059 9430 -5912 9381 -5774 9337 -5648 9307
--5537 9285 -5437 9267 -5344 9255 -5261 9241 -5183 9235 -5120 9238 -5067 9248
--5027 9262 -4990 9275 -4957 9284 -4932 9291 -4920 9306 -4918 9324 -4926 9340
--4932 9354 -4938 9357 -4945 9359 -4964 9358 -4996 9355 -5028 9349 -5057 9338
--5074 9319 -5083 9294 -5103 9263 -5129 9226 -5150 9184 -5160 9137 -5143 9091
--5115 9039 -5091 8975 -5063 8907 -5019 8834 -4953 8764 -4857 8699 -4742 8635
--4616 8559 -4478 8481 -4314 8405 -4124 8335 -3903 8279 -3656 8229 -3384 8176
--3090 8122 -2765 8078 -2418 8046 -2042 8032 -1638 8028 -1201 8032 -733 8042
--239 8064 277 8104 811 8160 1367 8233 1958 8319 2582 8418 3225 8535 3882 8666
-4542 8809 5214 8968 5922 9149 6653 9346 7399 9557 8140 9780 8869 10007
-9605 10246 10364 10509 11132 10789 11903 11078 12660 11369 13395 11653
-14127 11941 14863 12254 15595 12578 16323 12904 17025 13220 17703 13512
-18364 13798 19023 14102 19664 14414 20287 14716 20890 14985 21459 15214
-22013 15416 22564 15629 23036 15848 23588 16011 24098 16127 24533 16204
-24955 16244 25385 16251 25790 16216 26102 16134 26359 15996 26620 15779
-26852 15486 27053 15122 27213 14716 27219 14286 27026 13807 26700 13235
-26365 12550 25996 11788 25472 11003 24678 10229 23550 9461 22153 8684
-20534 7890 18746 7096 16817 6318 14744 5581 12522 4922 10174 4374 7726 3953
-5243 3648 2798 3423 475 3256 -1676 3157 -3664 3148 -5495 3240 -7190 3422
--8746 3661 -10159 3933 -11416 4217 -12529 4506 -13514 4796 -14399 5101
--15206 5411 -15952 5717 -16640 6021 -17258 6340 -17807 6677 -18313 7013
--18795 7328 -19277 7628 -19766 7934 -20262 8264 -20777 8629 -21300 9018
--21823 9409 -22329 9790 -22799 10139
-46: 9408325 -6072556 6811 4912 7143 4765 7550 4583 7991 4386 8461 4175
-8954 3962 9468 3746 10014 3517 10596 3282 11196 3041 11810 2799 12428 2560
-13072 2311 13735 2065 14432 1816 15138 1566 15847 1330 16556 1096 17260 860
-17979 637 18725 418 19473 205 20197 8 20896 -173 21586 -345 22272 -505
-22966 -656 23647 -784 24281 -890 24873 -972 25415 -1029 25952 -1070 26461 -1101
-26936 -1088 27346 -1052 27668 -973 27920 -855 28120 -705 28280 -532 28370 -318
-28370 -59 28260 221 27990 681 27830 1040 26930 1467 26820 2132 26280 2769
-25120 3264 24290 3860 23380 4699 22270 5464 20690 6648 18770 8240 17130 9329
-16150 9698 15210 9803 14070 10107 13550 10746 15460 11893 15210 12465
-13590 12594 11830 12514 10560 12327 9440 12015 8150 11726 6850 11540 5920 11280
-5350 10823 4600 10412 3170 10304 1020 10284 -1290 9804 -3180 8753 -4370 7642
--4850 6882 -4830 6583 -4910 6712 -5990 6858 -8770 6276 -13070 4594 -17840 2474
--21990 1024 -24770 699 -26190 959 -26820 664 -27370 -891 -28340 -3284
--29850 -5426 -31950 -6184 -35190 -4463 -40750 1301 -45760 14796 -36940 15971
--33760 15267 -28240 12156 -20430 10255 -11110 10800 -4420 12204 -13240 8801
--15400 7084 -27370 9870 -41230 6306 -47077 3381 7095 17436 -45682 -6147
--43389 3509 -36006 20398 -20636 30116 6180 24479 6908 7577 -16342 5389
--32837 6837 -41710 8349 -45267 9942 -45285 12654 -43065 16974 -39725 22201
--36794 26806 -34283 28963 -33102 28362 -34274 23622 -34155 -5866 -48810 30027
--43509 29642 -53507 23667 -38900 26388 -49440 16913 -43413 15637 -54555 14754
--29652 21271 -30433 16999 -34218 22195 -23696 23389 -11580 13434 -12226 21829
--16309 18562 -18632 17804 -13622 18685 -32309 27534 -14512 23150 -8673 21360
--23093 25874 -16623 18510 -20598 16610 -15503 17383 -19821 19703 -25185 20740
--25107 20841 -23175 20161 -21531 18822 -18791 17664 -17850 16187 -18122 15354
--25017 16610 -24568 17496 -21931 18636 -18874 20502 -17430 21602 -14458 22647
--9202 23554 -3303 23749 1160 23353 4506 22934 4495 21644 4134 19276 2470 16589
--354 13899 -3030 11709 -3863 10557 -4173 10412 -4813 10915 -6005 11590
--8219 12091 -11534 12429 -14877 12747 -17267 13118 -18610 13474 -20224 13841
--22238 14196 -24721 14603 -27480 15123 -30238 15750 -32491 16404 -34077 16975
--35710 17355 -38205 17531 -41345 17599 -44295 17719 -46825 18010 -49446 18477
--52451 19055 -55516 19628 -58080 20151 -60041 20627 -61646 21108 -62989 21683
--64098 22423 -64820 23337 -64893 24366 -64327 25401 -63161 26313 -61705 26997
--60107 27422 -58172 27600 -55700 27552 -52868 27296 -50003 26882 -47247 26346
--44531 25685 -41669 24867 -38490 23884 -35201 22756 -31791 21540 -28588 20290
--25519 19062 -22535 17874 -19778 16723 -17170 15582 -14649 14417 -12213 13217
--10031 12005 -8224 10820 -6783 9713 -5682 8711 -4835 7808 -4186 6989 -3700 6223
--3375 5495 -3211 4790 -3183 4121 -3256 3493 -3387 2914 -3550 2397 -3717 1950
--3886 1571 -4050 1224 -4181 1014 -4295 860 -4392 739 -4468 657 -4523 635
--4563 675 -4575 761 -4561 878 -4528 1024 -4485 1201 -4441 1424 -4384 1685
--4305 1981 -4211 2287 -4103 2603 -3989 2927 -3888 3260 -3773 3603 -3624 3948
--3441 4290 -3258 4624 -3106 4949 -2995 5264 -2903 5570 -2789 5863 -2663 6142
--2566 6409 -2527 6661 -2528 6898 -2579 7127 -2697 7340 -2874 7542 -3085 7728
--3311 7898 -3512 8053 -3738 8194 -4055 8318 -4461 8429 -4852 8522 -5187 8604
--5450 8671 -5668 8730 -5860 8773 -6028 8804 -6153 8822 -6238 8825 -6301 8814
--6317 8791 -6262 8755 -6133 8710 -5981 8648 -5826 8571 -5704 8480 -5571 8373
--5388 8241 -5168 8098 -4948 7957 -4760 7815 -4616 7633 -4493 7450 -4372 7249
--4250 7026 -4148 6799 -4085 6577 -4062 6372 -4072 6169 -4105 5951 -4161 5720
--4252 5494 -4377 5292 -4536 5115 -4726 4954 -4958 4796 -5227 4643 -5530 4508
--5857 4400 -6206 4318 -6579 4259 -7002 4220 -7475 4204 -7971 4206 -8476 4234
--8966 4280 -9468 4350 -10012 4451 -10599 4575 -11191 4722 -11761 4884
--12298 5054 -12809 5240 -13335 5460 -13879 5703 -14408 5963 -14891 6223
--15327 6480 -15724 6741 -16099 7030 -16459 7336 -16786 7647 -17062 7947
--17295 8230 -17485 8510 -17632 8801 -17733 9094 -17794 9381 -17820 9652
--17816 9899 -17778 10131 -17685 10357 -17544 10576 -17368 10777 -17167 10961
--16957 11121 -16730 11264 -16458 11388 -16138 11493 -15797 11579 -15452 11650
--15118 11706 -14772 11745 -14401 11759 -14001 11750 -13595 11727 -13201 11694
--12818 11658 -12441 11608 -12055 11538 -11660 11446 -11272 11346 -10898 11248
--10539 11150 -10196 11051 -9853 10937 -9521 10811 -9201 10683 -8891 10561
--8599 10447 -8320 10339 -8056 10226 -7805 10110 -7565 9999 -7341 9897
--7126 9804 -6927 9719 -6740 9640 -6569 9565 -6411 9498 -6264 9439 -6125 9386
--5996 9343 -5878 9308 -5776 9283 -5688 9266 -5603 9252 -5528 9238 -5458 9231
--5399 9233 -5354 9245 -5318 9260 -5285 9273 -5257 9283 -5231 9293 -5219 9308
--5214 9329 -5221 9350 -5222 9364 -5224 9370 -5223 9374 -5233 9376 -5254 9378
--5273 9375 -5288 9366 -5292 9350 -5286 9327 -5288 9299 -5297 9265 -5294 9225
--5284 9181 -5247 9136 -5201 9085 -5152 9023 -5102 8955 -5035 8882 -4943 8813
--4830 8747 -4692 8680 -4545 8605 -4386 8524 -4201 8445 -3993 8372 -3755 8313
--3496 8258 -3210 8200 -2903 8143 -2570 8091 -2212 8053 -1833 8032 -1427 8023
--990 8018 -525 8020 -35 8035 473 8066 995 8114 1537 8178 2113 8256 2715 8345
-3335 8452 3968 8574 4600 8709 5246 8861 5919 9032 6611 9221 7322 9426 8021 9639
-8713 9861 9406 10094 10119 10351 10843 10626 11566 10910 12276 11198 12965 11481
-13650 11769 14337 12081 15019 12406 15695 12735 16352 13055 16985 13352
-17608 13645 18221 13960 18816 14281 19398 14595 19965 14879 20505 15122
-21037 15340 21562 15573 22059 15816 22564 16002 22989 16139 23449 16237
-23966 16303 24429 16336 24784 16326 25062 16269 25401 16149 25740 15953
-26065 15673 26393 15324 26632 14929 26653 14506 26488 14034 26266 13456
-26052 12755 25801 11968 25388 11157 24691 10358 23662 9565 22328 8757
-20727 7929 18927 7092 16950 6278 14837 5512 12593 4833 10235 4270 7806 3840
-5356 3531 2944 3303 652 3140 -1475 3045 -3433 3049 -5231 3164 -6892 3376
--8417 3647 -9801 3950 -11039 4265 -12151 4582 -13143 4896 -14043 5220
--14870 5547 -15637 5865 -16351 6181 -17003 6502 -17595 6836 -18135 7167
--18651 7483 -19157 7784 -19667 8085 -20169 8402 -20684 8744 -21204 9100
--21723 9460 -22221 9808 -22684 10133
-47: 9443050 -6064459 6994 4843 7332 4696 7740 4511 8185 4305 8669 4095
-9165 3883 9690 3655 10243 3425 10833 3186 11439 2942 12060 2697 12686 2451
-13339 2201 14011 1947 14720 1694 15438 1442 16150 1200 16867 957 17588 723
-18316 493 19067 269 19826 51 20559 -155 21268 -342 21967 -517 22668 -682
-23373 -840 24065 -975 24716 -1088 25314 -1175 25874 -1238 26412 -1287
-26943 -1319 27433 -1321 27850 -1288 28190 -1209 28440 -1097 28660 -957
-28840 -789 28940 -577 28950 -352 28810 23 28670 379 28120 698 27880 1320
-27480 2021 26270 2467 25530 2836 25300 3544 24270 4422 22680 5507 20520 7198
-18220 8724 16660 9386 15560 9544 14300 9861 13340 10712 13580 11897 16580 14022
-16120 14418 13500 14033 11120 13404 10030 12729 9240 12053 8150 11627
-7020 11434 6190 11210 5600 10890 4630 10739 2840 10844 480 10809 -1770 10100
--3240 8905 -3720 7933 -3340 7612 -2560 7913 -2340 8514 -3800 8696 -7610 7649
--13220 5305 -18950 2753 -23490 1118 -26280 678 -27600 728 -28240 181 -29150 -1432
--30780 -3512 -33270 -4864 -36500 -4207 -41140 40 -51970 11727 -48370 9997
--32860 12711 -33170 13547 -26870 9832 -18400 8814 -6510 11884 7250 18227
--27430 6431 -23190 5438 -34950 16159 -38780 5943 -37726 2893 -21137 6997
--39392 684 -44834 5020 -40518 16013 -21990 27827 28996 25218 26036 1864
--16751 6161 -35517 8768 -43878 9889 -46643 10972 -45932 13386 -42976 17543
--38829 22639 -35536 27007 -31951 28858 -28636 27797 -27508 22113 -40573 7797
--45589 25431 -42752 31809 -43637 32278 -40210 31904 -56587 15433 -65355 -6152
--46097 12207 -31627 15584 -23294 22906 -18488 29762 -26859 15753 -15672 12895
--16299 17370 -16338 21009 -19069 17828 -9037 17723 -23105 21244 -15344 20053
--20399 23998 -21301 24265 -22164 20583 -22603 19183 -11505 17854 -21059 20528
--30610 21013 -27172 20901 -23309 20027 -22662 18059 -17969 17305 -17542 15072
--13947 13181 -31177 16345 -26869 16952 -22587 18026 -17756 21094 -18464 21642
--15500 22769 -8499 24075 -838 23995 3302 22962 7882 23142 5170 22375 5714 20123
-4031 17121 1593 14147 -2249 11361 -2466 9966 -2203 9936 -2670 10712 -4298 11592
--7446 12033 -11988 12279 -15841 12649 -18024 13150 -18888 13666 -20617 14166
--23077 14648 -26027 15171 -28974 15774 -31396 16428 -32957 17043 -34143 17503
--35928 17703 -38606 17662 -41449 17534 -43954 17536 -46486 17781 -49619 18253
--53250 18845 -56655 19451 -59320 20031 -61385 20599 -63149 21202 -64798 21915
--66254 22794 -67144 23852 -67255 25022 -66585 26170 -65378 27163 -63938 27909
--62167 28405 -59834 28660 -57005 28685 -54046 28494 -51190 28101 -48395 27501
--45480 26669 -42239 25594 -38810 24315 -35243 22918 -31815 21494 -28463 20119
--25181 18830 -22051 17616 -19073 16432 -16204 15222 -13443 13964 -10943 12672
--8775 11401 -6920 10211 -5413 9140 -4282 8185 -3476 7317 -2921 6500 -2550 5705
--2344 4926 -2295 4171 -2364 3462 -2533 2816 -2754 2235 -3003 1735 -3258 1316
--3490 974 -3686 688 -3865 524 -4012 394 -4133 288 -4225 221 -4299 215 -4349 273
--4366 382 -4345 524 -4304 694 -4255 897 -4202 1146 -4131 1441 -4042 1765
--3940 2106 -3819 2449 -3686 2802 -3567 3162 -3439 3531 -3258 3897 -3044 4260
--2835 4613 -2651 4955 -2520 5286 -2404 5605 -2260 5904 -2100 6193 -1977 6466
--1910 6723 -1900 6964 -1945 7196 -2066 7413 -2249 7614 -2473 7800 -2721 7971
--2934 8125 -3177 8263 -3532 8383 -3986 8489 -4427 8577 -4798 8652 -5090 8716
--5333 8766 -5539 8801 -5720 8826 -5854 8838 -5940 8832 -6003 8815 -6021 8782
--5953 8737 -5806 8684 -5626 8613 -5456 8526 -5314 8426 -5170 8306 -4973 8159
--4731 8004 -4497 7847 -4295 7695 -4143 7493 -4015 7294 -3891 7075 -3770 6833
--3678 6585 -3621 6345 -3609 6122 -3632 5904 -3680 5669 -3757 5419 -3868 5180
--4016 4961 -4200 4772 -4420 4602 -4678 4434 -4982 4275 -5314 4135 -5678 4024
--6063 3940 -6472 3883 -6933 3847 -7452 3836 -7991 3849 -8536 3884 -9071 3941
--9611 4023 -10199 4136 -10832 4277 -11470 4444 -12084 4623 -12659 4810
--13204 5016 -13768 5256 -14349 5523 -14909 5804 -15423 6088 -15887 6364
--16304 6648 -16700 6959 -17079 7287 -17417 7621 -17706 7943 -17947 8247
--18142 8542 -18290 8852 -18389 9165 -18444 9469 -18464 9754 -18452 10014
--18403 10259 -18299 10498 -18139 10724 -17941 10936 -17724 11125 -17498 11293
--17250 11439 -16956 11567 -16613 11674 -16248 11761 -15882 11830 -15522 11886
--15157 11924 -14765 11934 -14343 11922 -13913 11893 -13499 11855 -13098 11812
--12704 11759 -12302 11680 -11891 11582 -11489 11475 -11102 11368 -10734 11264
--10378 11157 -10032 11035 -9692 10903 -9363 10766 -9052 10637 -8759 10516
--8478 10402 -8215 10281 -7967 10160 -7733 10043 -7511 9934 -7304 9836
--7109 9746 -6929 9663 -6768 9584 -6619 9513 -6481 9451 -6351 9395 -6231 9348
--6121 9312 -6032 9285 -5952 9267 -5878 9253 -5808 9239 -5745 9229 -5694 9233
--5655 9246 -5624 9262 -5596 9277 -5568 9288 -5543 9298 -5531 9317 -5525 9341
--5526 9364 -5527 9381 -5520 9390 -5511 9396 -5512 9403 -5520 9407 -5527 9407
--5527 9401 -5516 9389 -5494 9370 -5479 9343 -5465 9311 -5444 9275 -5410 9232
--5351 9188 -5285 9139 -5214 9078 -5137 9010 -5045 8939 -4933 8867 -4795 8801
--4636 8733 -4467 8657 -4285 8572 -4079 8491 -3851 8414 -3598 8351 -3323 8292
--3025 8228 -2703 8164 -2360 8107 -1994 8063 -1611 8034 -1200 8016 -764 8005
--301 7999 182 8003 683 8026 1194 8066 1720 8119 2280 8189 2863 8269 3459 8364
-4063 8477 4670 8604 5286 8747 5925 8909 6581 9088 7248 9284 7911 9491 8559 9705
-9213 9933 9881 10184 10553 10452 11228 10732 11891 11017 12532 11297 13168 11585
-13805 11897 14436 12224 15062 12554 15665 12878 16257 13181 16834 13483
-17402 13806 17949 14139 18489 14466 19015 14765 19527 15022 20034 15258
-20534 15514 21038 15784 21438 15993 21886 16152 22439 16273 22968 16366
-23351 16428 23652 16448 24020 16416 24466 16318 24885 16144 25314 15880
-25702 15547 25927 15167 25973 14754 25940 14283 25877 13703 25787 12986
-25631 12174 25325 11333 24777 10500 23895 9680 22656 8839 21075 7969 19215 7088
-17159 6231 14953 5430 12637 4721 10257 4139 7835 3699 5405 3387 3024 3165
-767 3005 -1332 2921 -3252 2942 -5021 3084 -6645 3331 -8128 3642 -9482 3983
--10701 4334 -11796 4682 -12790 5023 -13698 5365 -14542 5704 -15327 6038
--16058 6361 -16743 6684 -17364 7014 -17939 7339 -18487 7648 -19014 7943
--19543 8238 -20059 8542 -20574 8863 -21097 9192 -21611 9520 -22100 9839
--22557 10137
-48: 9477574 -6056314 7161 4783 7498 4633 7906 4442 8368 4234 8855 4024
-9354 3807 9891 3577 10447 3339 11042 3101 11657 2848 12287 2601 12923 2354
-13581 2099 14260 1839 14975 1582 15700 1329 16426 1077 17147 835 17874 594
-18611 363 19371 131 20136 -93 20891 -305 21603 -496 22314 -677 23018 -849
-23736 -1010 24437 -1157 25100 -1273 25713 -1363 26282 -1432 26832 -1490
-27370 -1524 27880 -1539 28320 -1514 28650 -1436 28930 -1329 29150 -1198
-29350 -1036 29470 -848 29490 -592 29380 -217 29110 31 28760 495 28660 1215
-27490 1711 26620 1946 26830 2429 26380 3355 24620 4417 22310 5923 19760 7713
-17590 8847 16210 9214 15080 9524 13700 10459 13070 12148 14200 13990 17760 16531
-17250 16467 12740 15408 9480 14064 9290 12762 9260 11580 8460 10982 7340 10868
-6460 10847 5680 10838 4390 11020 2340 11318 -120 11207 -2090 10321 -3010 9149
--2650 8522 -1320 8815 200 9802 700 10831 -1220 10923 -6330 9186 -13720 5864
--20590 2734 -25460 894 -28170 385 -29350 374 -30080 -153 -31380 -1470
--33890 -2898 -37690 -3202 -42650 -1169 -48400 4172 -53400 12775 -46180 15936
--39180 15875 -30400 7146 -22580 4569 -14680 5727 -120 11584 47390 32181
--72140 -7731 -33440 7521 -35730 24129 -33470 1926 -34730 -446 -32861 1256
--40882 -309 -44599 102 -39331 1595 -18277 2102 41192 14645 21822 29001
--19432 20439 -36470 16198 -44056 13919 -46539 13187 -45698 14483 -42662 17799
--38399 22170 -35734 25834 -32650 27105 -30318 25932 -30920 22107 -38275 17407
--41354 25094 -40699 30620 -41319 31608 -43788 27778 -54379 14612 -58774 1531
--45692 9209 -32915 14791 -23491 21552 -19231 24909 -23338 17648 -21244 14965
--23558 16276 -27409 17401 -32621 14248 -24008 10037 63797 1084 -30393 42666
--22367 18748 -21491 23638 -30458 42685 -14638 19759 -19559 17683 -23495 18855
--38880 19988 -28484 20576 -23466 19811 -26714 17023 -18195 17978 -21770 14905
--5294 10451 -41790 16939 -26077 15782 -22304 16405 -14708 21313 -21762 19536
--18598 20861 -9501 23186 -128 22618 1369 20066 9186 21298 493 21754 7362 22578
-4668 17716 9998 16088 2147 12246 2429 10169 2424 10037 1107 11033 -1750 12154
--6046 12318 -12472 12333 -16992 12801 -18990 13473 -19740 14161 -21775 14777
--24757 15342 -28057 15917 -30822 16522 -32401 17121 -32963 17621 -33791 17913
--35596 17876 -38020 17534 -40359 17115 -42803 16950 -45985 17157 -50106 17657
--54502 18318 -58256 19019 -61069 19732 -63256 20468 -65180 21252 -67093 22123
--68734 23136 -69639 24338 -69626 25667 -68798 26966 -67517 28093 -65899 28980
--63748 29629 -61053 30042 -58146 30210 -55298 30112 -52478 29707 -49503 28951
--46205 27822 -42676 26370 -39034 24725 -35467 23028 -31911 21410 -28342 19935
--24785 18605 -21369 17356 -18065 16103 -14967 14784 -12196 13417 -9720 12045
--7423 10752 -5408 9594 -3826 8574 -2731 7652 -2048 6781 -1632 5920 -1395 5062
--1305 4225 -1354 3437 -1525 2719 -1803 2091 -2132 1548 -2481 1092 -2823 722
--3129 431 -3368 243 -3589 105 -3765 -21 -3902 -129 -4010 -191 -4098 -188
--4160 -113 -4174 16 -4144 179 -4092 372 -4032 599 -3969 879 -3889 1206
--3789 1562 -3674 1934 -3538 2310 -3390 2692 -3255 3079 -3101 3474 -2894 3864
--2652 4248 -2406 4621 -2190 4979 -2029 5325 -1890 5654 -1716 5962 -1517 6257
--1359 6537 -1268 6796 -1237 7043 -1275 7274 -1397 7495 -1590 7695 -1831 7882
--2094 8053 -2327 8205 -2590 8338 -2986 8454 -3492 8552 -3995 8637 -4409 8705
--4738 8763 -5004 8806 -5229 8833 -5423 8850 -5564 8854 -5651 8840 -5712 8815
--5730 8775 -5645 8722 -5475 8659 -5267 8579 -5072 8482 -4914 8373 -4752 8237
--4536 8082 -4276 7909 -4020 7739 -3804 7572 -3642 7352 -3506 7136 -3381 6898
--3264 6635 -3180 6366 -3132 6106 -3129 5865 -3164 5630 -3231 5376 -3329 5109
--3464 4850 -3634 4616 -3844 4415 -4092 4234 -4381 4059 -4714 3890 -5083 3745
--5483 3632 -5904 3548 -6350 3489 -6856 3458 -7416 3454 -8002 3475 -8590 3520
--9168 3590 -9751 3681 -10384 3810 -11064 3969 -11752 4154 -12410 4353
--13023 4560 -13609 4784 -14211 5047 -14829 5336 -15422 5640 -15969 5950
--16458 6249 -16900 6554 -17319 6888 -17711 7241 -18067 7598 -18365 7941
--18614 8265 -18817 8583 -18965 8909 -19062 9241 -19109 9563 -19121 9862
--19101 10138 -19041 10396 -18925 10644 -18745 10883 -18529 11102 -18291 11298
--18045 11472 -17779 11624 -17461 11754 -17096 11862 -16706 11950 -16317 12018
--15934 12072 -15548 12108 -15133 12115 -14688 12098 -14238 12064 -13802 12020
--13381 11972 -12971 11912 -12555 11827 -12126 11721 -11711 11605 -11311 11490
--10932 11380 -10567 11266 -10214 11135 -9866 10993 -9535 10851 -9221 10714
--8926 10586 -8644 10465 -8381 10338 -8137 10210 -7910 10088 -7692 9972
--7491 9870 -7301 9774 -7130 9688 -6978 9604 -6840 9530 -6711 9464 -6591 9406
--6477 9355 -6380 9319 -6300 9290 -6231 9272 -6165 9256 -6104 9241 -6048 9233
--6002 9237 -5972 9251 -5944 9269 -5921 9284 -5894 9298 -5871 9310 -5854 9333
--5850 9357 -5847 9384 -5839 9405 -5827 9417 -5809 9426 -5801 9435 -5796 9443
--5788 9449 -5776 9445 -5746 9435 -5708 9419 -5674 9396 -5639 9367 -5596 9332
--5540 9291 -5459 9249 -5367 9200 -5273 9141 -5171 9075 -5050 9001 -4918 8931
--4754 8863 -4575 8793 -4381 8713 -4174 8628 -3949 8541 -3700 8462 -3428 8393
--3137 8330 -2827 8260 -2491 8189 -2136 8125 -1763 8073 -1371 8038 -959 8013
--523 7992 -62 7975 415 7971 909 7984 1406 8014 1919 8059 2462 8118 3023 8187
-3595 8272 4173 8374 4751 8492 5336 8626 5943 8779 6557 8948 7185 9135 7805 9333
-8414 9540 9025 9762 9645 10006 10269 10268 10891 10544 11505 10823 12096 11102
-12684 11390 13269 11702 13848 12028 14417 12361 14973 12688 15517 12999
-16050 13307 16568 13641 17067 13986 17560 14325 18045 14639 18526 14913
-19008 15170 19474 15446 19912 15745 20311 15978 20849 16160 21404 16308
-21825 16431 22150 16524 22541 16576 23040 16572 23540 16503 24022 16344
-24480 16108 24843 15794 25090 15422 25302 15023 25468 14564 25538 13984
-25539 13249 25487 12406 25364 11520 25023 10662 24299 9803 23123 8925
-21507 8016 19555 7089 17368 6180 15049 5328 12658 4579 10241 3971 7813 3522
-5403 3215 3043 3000 824 2849 -1245 2780 -3129 2824 -4860 3000 -6443 3289
--7885 3647 -9190 4034 -10385 4427 -11469 4810 -12455 5178 -13372 5538
--14220 5891 -15017 6234 -15767 6566 -16470 6891 -17118 7216 -17724 7529
--18302 7827 -18854 8114 -19396 8398 -19925 8687 -20451 8985 -20973 9291
--21482 9590 -21967 9882 -22425 10153
-49: 9511890 -6048111 7302 4724 7648 4573 8060 4382 8527 4174 9021 3957
-9528 3739 10064 3503 10627 3267 11225 3019 11848 2766 12486 2513 13127 2262
-13792 2007 14484 1747 15197 1483 15926 1224 16667 968 17394 719 18125 480
-18872 242 19641 7 20412 -225 21170 -443 21894 -634 22615 -820 23323 -998
-24060 -1169 24764 -1318 25441 -1441 26056 -1539 26644 -1611 27190 -1676
-27760 -1718 28270 -1739 28720 -1719 29070 -1650 29350 -1549 29600 -1425
-29810 -1273 29950 -1103 29980 -804 29880 -520 29530 -236 29530 379 28820 967
-27720 1196 27860 1469 28070 2296 26530 3434 24000 4679 21490 6311 19180 7824
-17430 8624 16310 9027 14920 9840 13360 11665 12710 14315 14500 16796 18860 19018
-19470 18214 10910 16581 6340 14546 8900 12513 10070 10547 9250 9746 7790 9907
-6550 10341 5440 10805 3880 11361 1640 11795 -720 11590 -2340 10606 -2600 9584
--1400 9413 780 10359 3060 11997 3910 13421 1690 13421 -4780 10900 -14790 6093
--22840 2323 -27820 391 -30260 -64 -31210 9 -31930 -306 -33560 -1190 -36690 -1974
--41510 -1601 -47710 762 -54460 5263 -59670 10784 -56970 14583 -30680 24446
--21030 4934 -15700 2418 -8690 5161 2730 11384 14480 19297 -42380 2557
--36690 8137 -35060 15236 -33750 5079 -35420 1205 -37490 472 -41544 -807
--41788 -1841 -33651 -2012 -13273 578 18037 12439 9457 25388 -16107 23968
--32538 20266 -41139 17030 -44550 15216 -44440 15471 -42026 17774 -38345 21206
--36719 24094 -34663 25013 -33344 24281 -33881 22491 -36906 21529 -38524 25236
--38855 28559 -40148 28706 -43559 24597 -49524 15954 -51066 8683 -43446 10778
--33623 14906 -25364 19526 -21436 21561 -22932 18800 -24447 16791 -27428 16106
--29661 14892 -27343 11461 -9773 7543 32280 6353 -8394 25222 -16627 16861
--26350 22937 -79345 76922 54916 25006 -22066 13170 -31706 15306 -35355 18732
--28036 20965 -30503 17692 -29195 17545 -24971 18539 -27515 16448 -20779 13736
--26744 13925 -21796 12831 -20202 17249 -14061 18172 -29348 13614 -21591 16004
--11635 19917 -6161 18603 -4311 15224 -379 14157 -13931 12974 15422 36856
--11651 12356 43839 23955 15146 16319 12410 11640 9624 10755 6145 11784
-1302 13430 -3572 12998 -13259 12676 -18514 13423 -20272 14273 -21140 15065
--23563 15702 -27053 16264 -30540 16802 -32765 17317 -33025 17774 -32191 18095
--32593 18196 -34139 17894 -36007 17162 -38040 16299 -41258 15952 -45945 16170
--51512 16776 -56816 17573 -60981 18417 -63960 19312 -66151 20282 -67948 21287
--69820 22287 -71410 23384 -72149 24699 -71811 26219 -70713 27730 -69167 29064
--67161 30168 -64634 31046 -61875 31699 -59195 32077 -56527 32091 -53612 31625
--50293 30603 -46676 29057 -43007 27139 -39390 25084 -35762 23104 -31971 21333
--28012 19803 -24109 18445 -20310 17142 -16819 15777 -13757 14325 -11017 12836
--8351 11405 -5806 10116 -3671 8986 -2123 7986 -1165 7044 -619 6116 -324 5183
--191 4265 -203 3405 -368 2636 -672 1971 -1082 1412 -1535 944 -2003 547
--2434 226 -2811 -24 -3124 -119 -3381 -257 -3569 -403 -3707 -526 -3820 -592
--3918 -580 -3985 -489 -3996 -343 -3958 -156 -3894 60 -3820 314 -3742 622
--3653 980 -3540 1373 -3413 1778 -3263 2188 -3104 2601 -2948 3017 -2771 3435
--2537 3849 -2258 4255 -1978 4646 -1726 5023 -1534 5382 -1367 5720 -1161 6037
--911 6337 -712 6619 -595 6885 -542 7131 -568 7365 -689 7585 -894 7787 -1149 7973
--1432 8142 -1688 8294 -1971 8420 -2415 8530 -2990 8623 -3560 8700 -4032 8761
--4399 8811 -4695 8847 -4941 8869 -5143 8876 -5284 8872 -5373 8850 -5435 8819
--5448 8768 -5341 8708 -5141 8636 -4902 8547 -4679 8440 -4500 8322 -4319 8173
--4077 8003 -3794 7817 -3519 7630 -3285 7450 -3105 7211 -2965 6978 -2841 6720
--2728 6435 -2651 6142 -2615 5860 -2624 5602 -2673 5349 -2758 5073 -2874 4786
--3032 4507 -3231 4258 -3467 4043 -3741 3852 -4063 3665 -4428 3489 -4833 3340
--5270 3222 -5728 3136 -6212 3080 -6761 3054 -7367 3055 -7998 3087 -8634 3142
--9258 3222 -9884 3328 -10565 3472 -11295 3649 -12034 3854 -12735 4075
--13394 4301 -14021 4545 -14661 4830 -15317 5146 -15947 5475 -16527 5809
--17045 6131 -17513 6460 -17950 6818 -18362 7196 -18730 7577 -19041 7943
--19298 8290 -19504 8626 -19656 8973 -19747 9323 -19789 9663 -19792 9980
--19763 10271 -19694 10541 -19561 10800 -19361 11049 -19125 11276 -18867 11480
--18602 11660 -18315 11816 -17973 11949 -17585 12057 -17169 12146 -16756 12212
--16351 12266 -15942 12299 -15505 12302 -15038 12279 -14564 12239 -14107 12188
--13669 12135 -13241 12068 -12811 11976 -12365 11863 -11936 11737 -11522 11615
--11132 11496 -10763 11375 -10399 11237 -10046 11087 -9712 10935 -9395 10790
--9099 10658 -8816 10529 -8556 10396 -8315 10260 -8095 10131 -7881 10012
--7687 9904 -7503 9803 -7342 9714 -7199 9625 -7073 9547 -6953 9479 -6841 9418
--6739 9366 -6651 9327 -6582 9299 -6525 9278 -6467 9262 -6415 9248 -6365 9240
--6326 9245 -6301 9260 -6281 9280 -6259 9298 -6235 9313 -6210 9327 -6194 9352
--6187 9382 -6179 9411 -6165 9435 -6146 9450 -6120 9463 -6097 9475 -6083 9488
--6060 9497 -6031 9497 -5983 9491 -5930 9477 -5874 9456 -5816 9431 -5751 9398
--5673 9360 -5566 9318 -5452 9271 -5334 9212 -5201 9146 -5055 9073 -4894 9001
--4709 8933 -4507 8860 -4289 8778 -4057 8689 -3807 8598 -3536 8515 -3247 8441
--2941 8371 -2613 8297 -2265 8217 -1897 8147 -1516 8086 -1116 8043 -704 8010
--265 7979 191 7952 665 7938 1151 7940 1635 7960 2135 7995 2657 8044 3199 8101
-3744 8175 4297 8266 4845 8374 5398 8497 5968 8641 6548 8801 7131 8977 7710 9166
-8276 9366 8839 9581 9413 9818 9989 10074 10559 10343 11119 10619 11662 10894
-12199 11183 12730 11493 13255 11819 13770 12155 14273 12484 14769 12802
-15257 13119 15724 13461 16172 13818 16617 14170 17059 14501 17503 14792
-17959 15066 18392 15367 18748 15692 19227 15951 19772 16159 20203 16335
-20562 16492 20986 16620 21517 16707 22052 16742 22530 16683 23018 16577
-23462 16346 23868 16043 24309 15710 24757 15338 25063 14881 25207 14287
-25296 13534 25438 12649 25562 11749 25428 10831 24816 9941 23633 9035
-21942 8073 19870 7077 17559 6104 15137 5198 12683 4405 10220 3769 7774 3311
-5368 3006 3027 2802 823 2667 -1220 2619 -3071 2691 -4757 2909 -6290 3249
--7680 3663 -8944 4105 -10097 4547 -11165 4968 -12138 5367 -13053 5746
--13904 6110 -14710 6462 -15472 6798 -16185 7126 -16857 7443 -17491 7743
--18090 8027 -18669 8299 -19231 8568 -19771 8839 -20306 9117 -20833 9397
--21339 9670 -21827 9934 -22278 10182
-50: 9545996 -6039855 7420 4670 7783 4522 8197 4324 8660 4121 9163 3902
-9670 3676 10216 3441 10786 3200 11385 2949 12016 2693 12650 2436 13305 2181
-13977 1926 14670 1662 15386 1395 16124 1127 16867 873 17598 620 18341 378
-19095 135 19869 -106 20650 -338 21408 -561 22143 -763 22866 -950 23588 -1134
-24324 -1306 25042 -1463 25725 -1593 26350 -1693 26940 -1775 27510 -1843
-28070 -1894 28610 -1919 29070 -1906 29430 -1843 29710 -1748 29980 -1631
-30200 -1499 30380 -1321 30420 -1033 30260 -812 30090 -398 29920 215 28910 550
-28620 694 29150 1287 28230 2462 25650 3645 23170 4819 21330 6203 19640 7403
-18120 8212 16640 8981 14640 10468 12370 13181 11010 16578 13180 19514
-19470 21165 24850 19277 7370 17826 1500 15628 10630 12372 12360 8848 10470 7915
-8050 8774 6230 9997 4780 11051 3010 11927 760 12407 -1390 12083 -2580 11055
--2260 10224 -400 10459 2480 11924 5380 14062 6740 15860 4740 15993 -2650 12941
--16740 5780 -25530 1621 -30160 -138 -32110 -412 -32760 -187 -33390 -243
--35070 -719 -38380 -1023 -43370 -328 -49430 1918 -55120 5603 -57570 9933
--51910 13869 -33400 17626 -21830 7984 -14990 4592 -8950 5927 -3050 9630
--3370 12338 -27120 6887 -31560 8262 -32430 10443 -33270 6474 -35720 3616
--38620 2101 -40840 663 -39213 -536 -31135 -478 -16223 2765 -445 11252
--3180 20133 -17180 22156 -29709 20689 -37832 18231 -41838 16355 -42633 16054
--41166 17518 -38408 20081 -37618 22309 -36464 23069 -35760 22833 -35821 22309
--36622 22626 -37142 24716 -37540 26497 -38809 26134 -41505 22929 -44790 17573
--45228 13305 -40648 13359 -33531 15635 -26792 18502 -23147 20055 -23568 19352
--25742 18069 -28163 16598 -28175 14371 -22586 11176 -8250 8592 9229 9538
--5278 18011 -16420 20287 -28575 31205 -43014 55916 16412 32851 -11440 19703
--25103 17286 -29696 18545 -28276 19697 -29473 18530 -28349 18776 -26266 19266
--30006 15405 -26585 14027 -25829 13767 -23976 14112 -23802 17058 -20483 17790
--26787 11408 -9802 9647 -2951 10215 -9986 16612 -9619 15010 -7749 14152
--9527 16349 5232 27468 3278 18782 30841 21629 23241 17361 19238 13141
-15687 11388 10965 12100 3714 15025 -175 13972 -15193 13728 -20302 14961
--21562 15748 -22603 16395 -25473 16895 -29469 17345 -33083 17761 -34627 18112
--33230 18342 -30128 18417 -30208 18389 -31374 17846 -32589 16657 -34677 15111
--39861 14664 -46988 15043 -54387 15861 -60679 16859 -65314 17816 -68364 18863
--70249 20108 -71216 21359 -72620 22399 -74076 23432 -74553 24798 -73685 26563
--72089 28365 -70032 29965 -67582 31332 -64914 32494 -62404 33448 -60074 34101
--57483 34262 -54320 33696 -50688 32312 -46972 30250 -43404 27814 -39846 25355
--35987 23144 -31740 21296 -27347 19771 -23026 18414 -19075 17042 -15644 15542
--12632 13932 -9676 12317 -6687 10821 -3992 9507 -1885 8356 -452 7303 412 6281
-882 5265 1102 4271 1129 3351 966 2548 627 1881 157 1333 -399 880 -993 490
--1579 145 -2103 -156 -2556 -400 -2962 -447 -3245 -625 -3428 -804 -3557 -942
--3663 -1006 -3764 -977 -3831 -866 -3838 -695 -3787 -486 -3705 -243 -3618 43
--3527 377 -3421 770 -3296 1198 -3162 1639 -3003 2084 -2823 2529 -2651 2976
--2455 3419 -2185 3855 -1870 4282 -1552 4693 -1261 5086 -1037 5457 -842 5805
--587 6129 -286 6433 -36 6715 117 6984 191 7233 177 7466 57 7685 -152 7888
--427 8075 -736 8241 -1012 8385 -1320 8509 -1823 8613 -2484 8699 -3129 8767
--3665 8819 -4081 8862 -4411 8891 -4676 8905 -4885 8905 -5023 8891 -5111 8863
--5173 8821 -5177 8764 -5044 8697 -4809 8617 -4532 8518 -4275 8401 -4071 8270
--3866 8112 -3599 7926 -3285 7726 -2986 7525 -2735 7332 -2541 7073 -2394 6821
--2268 6543 -2161 6233 -2092 5914 -2068 5610 -2090 5330 -2153 5058 -2255 4762
--2395 4451 -2577 4153 -2803 3886 -3065 3656 -3370 3452 -3721 3257 -4120 3071
--4562 2916 -5036 2795 -5533 2708 -6057 2653 -6648 2633 -7299 2640 -7983 2682
--8666 2749 -9335 2841 -10010 2961 -10738 3122 -11524 3321 -12312 3543
--13067 3786 -13770 4032 -14434 4301 -15118 4608 -15814 4951 -16485 5306
--17097 5664 -17645 6012 -18139 6365 -18597 6747 -19028 7154 -19409 7559
--19730 7950 -19997 8319 -20208 8676 -20361 9041 -20447 9414 -20481 9771
--20476 10106 -20435 10411 -20358 10695 -20208 10964 -19988 11224 -19730 11460
--19451 11671 -19164 11856 -18857 12017 -18492 12152 -18077 12261 -17637 12348
--17197 12413 -16770 12465 -16340 12496 -15878 12495 -15389 12464 -14894 12419
--14416 12361 -13958 12301 -13514 12227 -13065 12128 -12609 12005 -12162 11872
--11737 11740 -11338 11614 -10956 11485 -10589 11338 -10231 11180 -9892 11021
--9574 10870 -9275 10727 -8997 10593 -8738 10452 -8501 10311 -8286 10176
--8082 10051 -7892 9939 -7715 9834 -7563 9738 -7431 9647 -7316 9567 -7208 9496
--7106 9432 -7012 9378 -6935 9339 -6879 9309 -6832 9286 -6784 9272 -6739 9258
--6696 9250 -6665 9257 -6645 9274 -6630 9296 -6613 9316 -6590 9333 -6566 9351
--6547 9378 -6537 9412 -6523 9445 -6505 9473 -6477 9491 -6442 9507 -6408 9524
--6378 9540 -6341 9553 -6293 9558 -6228 9554 -6157 9544 -6080 9526 -5999 9503
--5910 9473 -5804 9437 -5676 9398 -5539 9350 -5390 9293 -5232 9225 -5057 9154
--4867 9080 -4657 9010 -4432 8935 -4188 8850 -3930 8756 -3655 8662 -3362 8573
--3055 8495 -2734 8419 -2387 8337 -2022 8250 -1644 8171 -1251 8101 -845 8050
--432 8007 7 7966 463 7930 932 7904 1405 7895 1883 7904 2368 7929 2870 7964
-3388 8010 3912 8073 4435 8153 4953 8249 5472 8363 6009 8496 6546 8644 7088 8809
-7625 8991 8144 9181 8663 9389 9188 9620 9710 9868 10231 10130 10737 10402
-11231 10675 11713 10961 12192 11270 12661 11596 13119 11932 13570 12267
-14017 12588 14456 12914 14871 13267 15266 13632 15660 14000 16057 14345
-16465 14653 16885 14949 17289 15273 17620 15620 18110 15907 18531 16144
-18888 16353 19344 16546 19916 16715 20469 16848 20908 16886 21340 16923
-21841 16774 22372 16593 22998 16356 23712 16035 24301 15656 24627 15207
-24813 14625 25086 13847 25514 12965 25886 11971 25890 11038 25311 10116
-24101 9136 22352 8099 20197 7043 17807 6012 15304 5048 12764 4202 10230 3528
-7740 3054 5304 2754 2956 2568 754 2455 -1267 2433 -3090 2542 -4723 2811
--6202 3213 -7530 3692 -8738 4199 -9846 4696 -10874 5165 -11831 5596 -12735 5994
--13585 6368 -14397 6725 -15160 7065 -15896 7390 -16576 7697 -17238 7983
--17860 8249 -18465 8502 -19041 8752 -19600 9004 -20140 9257 -20673 9512
--21185 9760 -21669 9997 -22121 10221
-51: 9579875 -6031543 7529 4626 7891 4474 8306 4285 8779 4069 9277 3850
-9797 3621 10340 3384 10914 3142 11522 2891 12152 2629 12797 2370 13453 2114
-14123 1853 14824 1589 15546 1317 16286 1048 17029 786 17768 536 18515 290
-19276 42 20051 -204 20839 -440 21603 -663 22340 -870 23066 -1065 23799 -1254
-24540 -1428 25263 -1586 25950 -1723 26590 -1831 27170 -1915 27760 -1989
-28340 -2047 28880 -2082 29350 -2069 29710 -2012 30020 -1925 30290 -1812
-30530 -1706 30730 -1509 30790 -1273 30590 -1025 30570 -520 30040 -53 29360 90
-29730 406 29580 1413 27390 2707 24740 3620 23430 4373 22790 5352 21390 6549
-19080 7874 16300 9224 13190 11225 9900 14454 7450 17876 9460 20668 16890 22140
-33910 18720 1600 19937 -1030 20664 17600 12239 15690 5910 11230 5574 7500 7986
-5140 10314 3530 11902 1800 12911 -280 13286 -2120 12782 -2950 11700 -2220 10983
-10 11441 3220 13135 6420 15463 8140 17457 6800 17950 140 15336 -19610 4949
--27570 1287 -31450 -109 -33060 -286 -33580 -3 -34130 96 -35670 -89 -38720 -107
--43220 668 -48400 2594 -52560 5522 -53130 8833 -47390 11684 -35180 12898
--25010 8833 -18090 6477 -13120 6780 -10070 8468 -11920 9444 -21940 7847
--26860 8079 -29350 8652 -31730 7219 -34830 5666 -37890 4402 -39470 3170
--37650 2221 -31342 2443 -21512 5067 -12920 10616 -13252 16516 -20529 19332
--28931 19429 -35496 18101 -39412 16684 -40806 16241 -40230 17142 -38417 19011
--38025 20735 -37485 21415 -37172 21504 -36962 21603 -36796 22293 -36654 23665
--36747 24658 -37536 24229 -39213 22054 -40989 18786 -41052 16120 -38149 15535
--32988 16566 -27541 18287 -24211 19571 -24078 19751 -25895 19048 -27555 17528
--26537 15169 -21068 12408 -11530 10624 -3625 11675 -8779 16583 -16594 21754
--23992 30775 -25553 40981 -3976 32412 -11290 23712 -20018 19974 -24742 19300
--26151 19347 -27279 18857 -27192 18744 -26911 18278 -28522 15948 -27297 14738
--26091 14428 -24927 14826 -23901 15924 -21020 15230 -18577 11014 -6540 8552
--738 8833 -11024 13842 -11310 14471 -9400 14932 -6884 17348 1713 22044
-7775 19946 21624 19707 22844 16844 21510 13432 19199 11096 15398 10408
-7074 13268 -3482 15513 -16318 18253 -20629 18023 -21840 17783 -23322 17933
--26798 18175 -31362 18465 -35187 18724 -36326 18860 -33330 18792 -26141 18515
--26865 18508 -27644 17846 -28070 16267 -30225 13619 -39083 13471 -49602 14274
--58951 15390 -66129 16623 -71175 17469 -74059 18473 -75408 19999 -74204 21557
--74929 22450 -76652 23150 -77024 24437 -75278 26586 -72898 28753 -70166 30621
--67417 32218 -64819 33668 -62676 34960 -60639 35971 -57971 36366 -54551 35707
--50831 33889 -47303 31234 -43923 28256 -40277 25444 -35983 23107 -31189 21303
--26342 19885 -21850 18585 -17973 17158 -14630 15509 -11382 13713 -8038 11938
--4857 10320 -2175 8904 -138 7640 1280 6458 2152 5317 2597 4228 2698 3245
-2520 2422 2120 1778 1574 1287 921 896 209 546 -517 207 -1223 -136 -1842 -466
--2375 -750 -2867 -845 -3170 -1087 -3342 -1295 -3456 -1422 -3550 -1465
--3641 -1402 -3707 -1257 -3704 -1050 -3636 -811 -3533 -536 -3432 -222 -3323 151
--3198 576 -3063 1039 -2920 1520 -2751 2001 -2558 2479 -2366 2953 -2146 3424
--1844 3884 -1489 4331 -1126 4763 -794 5166 -535 5554 -304 5911 2 6238 361 6542
-669 6828 865 7098 966 7344 964 7578 843 7795 633 7999 335 8182 -1 8347 -302 8488
--641 8605 -1210 8701 -1967 8778 -2707 8837 -3315 8881 -3778 8917 -4148 8935
--4433 8942 -4649 8934 -4792 8913 -4868 8877 -4924 8825 -4919 8762 -4762 8687
--4477 8600 -4159 8492 -3865 8367 -3629 8222 -3395 8052 -3099 7854 -2753 7637
--2425 7424 -2154 7216 -1947 6938 -1790 6667 -1663 6366 -1561 6029 -1503 5684
--1488 5355 -1525 5052 -1603 4759 -1723 4441 -1888 4107 -2095 3785 -2347 3500
--2639 3253 -2973 3036 -3356 2831 -3791 2639 -4266 2475 -4780 2349 -5315 2263
--5883 2208 -6516 2192 -7220 2210 -7948 2260 -8685 2342 -9401 2445 -10124 2580
--10904 2760 -11746 2977 -12590 3223 -13398 3488 -14146 3756 -14856 4047
--15582 4381 -16321 4750 -17031 5132 -17678 5518 -18257 5892 -18777 6269
--19259 6679 -19704 7112 -20103 7545 -20438 7960 -20708 8352 -20928 8732
--21079 9118 -21161 9511 -21188 9887 -21172 10240 -21121 10559 -21029 10857
--20864 11140 -20627 11408 -20342 11653 -20040 11869 -19734 12062 -19406 12227
--19018 12362 -18575 12472 -18107 12558 -17642 12622 -17191 12671 -16738 12698
--16255 12691 -15742 12657 -15226 12602 -14725 12537 -14250 12470 -13787 12391
--13323 12282 -12850 12151 -12392 12008 -11956 11866 -11543 11733 -11157 11595
--10777 11441 -10419 11274 -10079 11107 -9760 10947 -9459 10798 -9181 10656
--8926 10509 -8694 10362 -8487 10221 -8288 10091 -8106 9974 -7935 9865
--7794 9764 -7676 9669 -7571 9587 -7474 9514 -7382 9448 -7299 9393 -7234 9351
--7188 9322 -7151 9300 -7117 9284 -7079 9272 -7041 9264 -7018 9274 -7005 9293
--6994 9315 -6982 9340 -6959 9359 -6935 9380 -6915 9411 -6901 9448 -6882 9486
--6858 9518 -6820 9541 -6774 9559 -6731 9581 -6685 9601 -6630 9618 -6565 9627
--6482 9628 -6389 9619 -6292 9605 -6187 9585 -6070 9558 -5937 9524 -5786 9486
--5623 9439 -5449 9381 -5258 9316 -5055 9242 -4836 9168 -4599 9095 -4350 9019
--4081 8928 -3793 8832 -3494 8733 -3178 8638 -2851 8554 -2509 8471 -2147 8382
--1767 8287 -1374 8198 -970 8120 -561 8058 -141 8006 297 7955 750 7906 1215 7869
-1683 7847 2146 7846 2617 7858 3101 7882 3594 7915 4094 7966 4589 8033 5076 8117
-5564 8221 6060 8342 6558 8479 7056 8634 7547 8803 8025 8986 8496 9187 8969 9409
-9440 9648 9905 9904 10359 10171 10802 10440 11231 10724 11654 11032 12066 11357
-12468 11692 12865 12031 13258 12356 13648 12691 14008 13052 14349 13429
-14689 13807 15038 14171 15406 14494 15794 14812 16157 15161 16505 15532
-16887 15849 17184 16117 17615 16359 18220 16592 18815 16814 19225 16950
-19548 17126 20017 17043 20657 17044 21438 16918 22347 16645 23187 16330
-23734 16001 24024 15600 24360 15010 24940 14244 25655 13236 26198 12254
-26277 11268 25748 10250 24577 9205 22856 8131 20688 7019 18233 5909 15607 4862
-12924 3948 10264 3234 7678 2747 5181 2463 2796 2300 586 2216 -1411 2226
--3200 2382 -4773 2710 -6184 3182 -7433 3740 -8572 4320 -9617 4885 -10597 5405
--11522 5870 -12407 6287 -13250 6669 -14065 7028 -14839 7366 -15586 7687
--16290 7980 -16964 8248 -17614 8494 -18238 8726 -18833 8953 -19406 9182
--19959 9410 -20496 9638 -21012 9861 -21501 10071 -21953 10271
-52: 9613525 -6023173 7619 4591 7977 4436 8399 4242 8869 4027 9377 3808
-9892 3575 10440 3338 11018 3094 11629 2840 12260 2576 12908 2317 13569 2054
-14241 1795 14944 1526 15672 1251 16412 981 17156 715 17898 463 18650 214
-19409 -38 20193 -284 20976 -525 21747 -750 22489 -962 23222 -1160 23959 -1351
-24700 -1529 25430 -1693 26120 -1833 26750 -1945 27350 -2030 27950 -2114
-28530 -2179 29090 -2216 29550 -2210 29930 -2157 30250 -2072 30520 -1977
-30790 -1875 31010 -1682 31040 -1487 30930 -1170 30840 -662 30170 -383
-30060 -264 30420 360 29190 1635 26470 2724 24950 3043 25540 3113 26050 3778
-24000 5539 19260 8038 14270 9936 9820 11835 6590 15140 3340 17399 5520 18303
-11230 17374 16150 14949 3360 21796 31900 45954 21190 4140 14880 803 9680 3672
-5500 8667 3160 11976 1780 13653 360 14414 -1370 14457 -2900 13696 -3460 12499
--2590 11770 -340 12195 2730 13764 5610 15836 6820 17446 4640 17411 -2830 14365
--16910 7355 -25720 3176 -30450 1205 -32590 618 -33410 671 -34060 754 -35430 702
--37990 805 -41730 1508 -45890 3045 -48900 5260 -48790 7682 -44190 9624
--35960 10223 -28080 8655 -22220 7404 -18260 7353 -16250 7992 -17110 8322
--21210 7848 -24480 7869 -27080 8102 -29940 7775 -33260 7197 -36300 6512
--37860 5719 -36720 5113 -32500 5301 -26340 7034 -21219 10472 -20620 14359
--24214 16965 -29446 17830 -34257 17397 -37626 16558 -39255 16199 -39323 16766
--38314 18120 -37951 19480 -37742 20091 -37707 20331 -37479 20659 -37021 21398
--36587 22408 -36350 23067 -36575 22794 -37361 21457 -38200 19490 -38107 17760
--36167 17037 -32333 17379 -27878 18410 -24818 19498 -24277 20064 -25504 19811
--26597 18584 -25468 16508 -21242 14181 -15166 12755 -10964 13444 -12686 16680
--16928 21368 -20453 27506 -19632 32265 -11889 29346 -13384 24555 -17872 21402
--21507 19981 -23653 19338 -25030 18789 -25589 18344 -25881 17631 -26515 16275
--26090 15365 -25349 15026 -24424 15084 -22832 15138 -19504 14040 -14642 11441
--6861 9635 -3346 9854 -7765 12461 -8854 13843 -7673 15032 -4835 17001
-962 19298 7514 19055 15922 18295 19446 16230 19935 13736 18316 11924 14166 11610
-6152 13658 -4134 16229 -13956 18625 -18641 19076 -20654 18967 -22869 19081
--27022 19262 -32092 19477 -36154 19609 -37364 19532 -34019 19152 -20242 18322
--23709 18483 -23433 17760 -22393 16171 -24253 12097 -39772 13326 -54146 14754
--64836 16061 -72288 17610 -77606 17692 -79957 18113 -81517 19923 -75474 22011
--76178 22438 -79513 22374 -80267 23378 -76796 26261 -73467 28770 -69957 30788
--67192 32472 -64648 34150 -62714 35755 -60923 37243 -58089 38106 -54548 37426
--51019 35109 -47812 31778 -44576 28253 -40657 25186 -35819 22884 -30482 21311
--25350 20162 -20920 19043 -17160 17615 -13600 15806 -9895 13765 -6252 11734
--3033 9886 -365 8253 1765 6782 3302 5424 4218 4174 4526 3085 4350 2217
-3857 1597 3189 1190 2435 912 1607 667 744 378 -111 19 -934 -385 -1660 -796
--2263 -1167 -2821 -1414 -3143 -1718 -3309 -1922 -3402 -2010 -3479 -1991
--3564 -1875 -3622 -1676 -3598 -1420 -3510 -1136 -3383 -824 -3260 -473
--3131 -65 -2985 397 -2840 901 -2686 1417 -2514 1940 -2310 2447 -2094 2955
--1847 3454 -1512 3935 -1112 4403 -702 4852 -326 5276 -29 5671 241 6033
-605 6365 1035 6670 1407 6956 1651 7222 1783 7468 1798 7699 1677 7916 1456 8117
-1140 8296 773 8460 446 8595 65 8707 -575 8795 -1440 8862 -2285 8911 -2977 8947
--3504 8971 -3911 8983 -4216 8982 -4441 8966 -4581 8936 -4651 8891 -4698 8832
--4679 8761 -4493 8681 -4158 8583 -3787 8472 -3445 8332 -3173 8180 -2908 7999
--2577 7782 -2195 7554 -1840 7328 -1541 7104 -1319 6808 -1150 6516 -1020 6188
--924 5824 -879 5452 -877 5094 -924 4769 -1020 4453 -1160 4109 -1349 3751
--1583 3406 -1866 3098 -2184 2836 -2549 2605 -2967 2388 -3435 2186 -3948 2016
--4501 1887 -5074 1798 -5686 1745 -6368 1735 -7117 1762 -7901 1823 -8688 1916
--9456 2036 -10227 2185 -11062 2383 -11962 2623 -12867 2891 -13725 3180
--14522 3472 -15280 3786 -16050 4146 -16836 4543 -17588 4956 -18270 5369
--18880 5769 -19428 6173 -19933 6612 -20399 7072 -20811 7533 -21157 7975
--21439 8392 -21659 8791 -21811 9203 -21890 9615 -21906 10012 -21880 10381
--21816 10718 -21714 11029 -21531 11323 -21270 11602 -20963 11854 -20640 12078
--20310 12276 -19958 12445 -19548 12583 -19077 12692 -18581 12774 -18089 12836
--17616 12884 -17141 12907 -16635 12895 -16096 12852 -15555 12791 -15037 12718
--14543 12642 -14061 12556 -13582 12439 -13094 12298 -12622 12144 -12175 11995
--11754 11853 -11357 11706 -10974 11543 -10611 11369 -10268 11192 -9948 11025
--9650 10870 -9370 10719 -9120 10567 -8895 10413 -8692 10266 -8503 10131
--8329 10009 -8167 9895 -8038 9791 -7929 9695 -7837 9608 -7754 9533 -7672 9465
--7596 9408 -7546 9366 -7512 9337 -7487 9316 -7462 9300 -7432 9289 -7404 9284
--7384 9294 -7380 9316 -7374 9342 -7364 9369 -7343 9391 -7318 9416 -7296 9450
--7279 9493 -7256 9534 -7223 9570 -7177 9596 -7118 9621 -7063 9646 -7002 9672
--6929 9693 -6845 9705 -6744 9710 -6631 9704 -6508 9694 -6378 9677 -6234 9653
--6075 9621 -5897 9583 -5708 9538 -5502 9481 -5283 9414 -5050 9340 -4801 9265
--4537 9189 -4259 9110 -3964 9017 -3650 8914 -3322 8810 -2982 8710 -2632 8619
--2272 8529 -1895 8431 -1496 8328 -1087 8229 -673 8142 -258 8068 166 8007
-606 7943 1057 7883 1517 7832 1976 7799 2430 7784 2883 7784 3350 7795 3819 7816
-4291 7851 4760 7907 5213 7980 5670 8070 6127 8180 6583 8304 7037 8448 7480 8606
-7915 8779 8337 8971 8761 9185 9178 9415 9588 9664 9988 9924 10375 10189
-10752 10471 11117 10776 11473 11099 11818 11433 12156 11773 12494 12106
-12833 12445 13138 12817 13422 13202 13702 13594 13999 13972 14329 14315
-14680 14651 14998 15030 15334 15431 15567 15779 15870 16077 16440 16354
-17080 16638 17520 16864 17746 17165 18097 17157 18761 17357 19654 17331
-20702 17134 21722 16920 22457 16706 22877 16438 23258 16028 23899 15442
-24807 14553 25727 13579 26386 12529 26599 11436 26259 10382 25272 9329
-23667 8191 21488 6976 18877 5758 16020 4618 13102 3641 10249 2893 7518 2411
-4933 2142 2505 2008 301 1958 -1669 2005 -3406 2213 -4911 2606 -6228 3162
--7384 3808 -8430 4476 -9393 5115 -10312 5693 -11197 6196 -12061 6630 -12896 7018
--13710 7375 -14499 7708 -15259 8016 -15983 8295 -16678 8541 -17348 8764
--17993 8971 -18606 9173 -19193 9375 -19757 9577 -20303 9777 -20827 9971
--21320 10158 -21772 10333
-53: 9646946 -6014749 7685 4565 8040 4406 8473 4206 8940 3993 9448 3775
-9963 3541 10517 3304 11097 3050 11703 2798 12341 2531 12989 2271 13652 2009
-14328 1748 15029 1476 15760 1202 16498 924 17247 659 17991 403 18738 153
-19505 -102 20288 -351 21070 -594 21840 -819 22589 -1035 23323 -1232 24060 -1428
-24800 -1610 25540 -1778 26230 -1920 26860 -2035 27470 -2131 28070 -2214
-28660 -2284 29220 -2326 29690 -2322 30070 -2277 30390 -2192 30690 -2118
-30960 -2008 31210 -1840 31220 -1654 31210 -1272 30920 -834 30410 -688
-30690 -476 30600 430 28570 1747 26250 2363 26590 1881 29280 1185 30630 1726
-26890 4576 17800 9223 10200 11318 4890 11912 4450 15760 -250 16366 3320 16095
-7730 15416 11640 16394 15790 22253 32740 30220 27240 9272 14200 6244 7890 6400
-2920 12535 850 15366 -40 16196 -1010 16236 -2370 15771 -3620 14707 -4050 13369
--3280 12518 -1330 12722 1270 13917 3540 15513 4130 16635 1580 16326 -5110 13767
--15140 9136 -23260 5348 -28450 3037 -31230 1997 -32530 1710 -33380 1662
--34590 1626 -36660 1744 -39620 2303 -42900 3450 -45210 5064 -45080 6799
--41780 8177 -36170 8705 -30420 8241 -25930 7740 -22910 7681 -21240 7885
--21090 7945 -22390 7748 -24020 7746 -25970 7974 -28550 8167 -31610 8219
--34500 8090 -36220 7784 -35940 7507 -33550 7647 -29840 8662 -26670 10696
--25771 13223 -27397 15329 -30479 16459 -33786 16611 -36451 16269 -38037 16080
--38499 16471 -38076 17455 -37580 18570 -37501 19108 -37646 19375 -37517 19731
--37100 20390 -36619 21183 -36180 21708 -35968 21639 -36071 20915 -36259 19767
--36036 18626 -34668 17945 -31748 17935 -28054 18554 -25208 19473 -24303 20215
--24947 20315 -25639 19496 -24764 17850 -21799 15928 -17895 14665 -15280 14913
--15604 16977 -17514 20346 -18912 24274 -18032 26915 -15036 26131 -15150 23743
--17305 21584 -19747 20160 -21707 19243 -23108 18536 -23861 17924 -24213 17228
--24429 16369 -24237 15732 -23832 15392 -23108 15218 -21411 14879 -18045 13894
--13197 12295 -7683 11115 -4783 11133 -5619 12391 -5975 13599 -5122 14837
--2940 16354 1040 17723 6233 17923 11953 17317 15473 15901 16570 14247
-15339 13108 11362 13110 4351 14557 -4225 16594 -11825 18418 -16273 19211
--18835 19439 -21536 19768 -26108 20069 -31329 20316 -35136 20369 -35587 20085
--31360 19411 -22280 18463 -20272 17846 -17746 16712 -12411 14372 -19162 13266
--44253 16193 -60490 17621 -70497 18641 -76869 21062 -82717 18819 -83266 17525
--89380 19601 -72604 22747 -76440 22249 -83791 21027 -85578 21455 -78335 25903
--74580 28193 -69873 30155 -67755 31676 -64823 33442 -62720 35192 -61429 37333
--58276 39202 -54723 38641 -51500 35688 -48611 31557 -45395 27498 -41182 24322
--35814 22299 -29962 21220 -24682 20599 -20401 19874 -16553 18542 -12504 16532
--8311 14123 -4457 11690 -1138 9468 1718 7511 4086 5780 5739 4250 6523 2950
-6483 1947 5908 1287 5078 937 4175 793 3237 701 2256 539 1245 230 246 -219
--711 -741 -1557 -1270 -2237 -1732 -2805 -2206 -3162 -2543 -3326 -2698
--3398 -2701 -3456 -2599 -3522 -2401 -3566 -2126 -3522 -1811 -3404 -1472
--3252 -1113 -3101 -718 -2948 -272 -2782 235 -2620 778 -2469 1340 -2292 1896
--2072 2445 -1840 2983 -1565 3505 -1193 4013 -745 4501 -285 4970 143 5406
-481 5810 793 6179 1217 6510 1731 6818 2177 7095 2474 7357 2643 7602 2679 7830
-2559 8041 2326 8241 1988 8419 1587 8579 1232 8713 810 8813 81 8895 -906 8951
--1875 8990 -2653 9014 -3250 9030 -3707 9033 -4042 9023 -4269 8997 -4401 8960
--4460 8906 -4501 8840 -4466 8762 -4238 8673 -3847 8574 -3414 8451 -3018 8307
--2705 8143 -2403 7945 -2035 7723 -1613 7476 -1216 7237 -894 7002 -653 6680
--470 6365 -335 6014 -251 5619 -216 5216 -230 4831 -292 4480 -403 4139 -563 3769
--778 3384 -1041 3013 -1353 2683 -1702 2403 -2099 2157 -2551 1927 -3055 1716
--3605 1539 -4193 1407 -4812 1313 -5466 1264 -6196 1259 -6997 1295 -7834 1370
--8674 1476 -9495 1609 -10315 1775 -11208 1995 -12172 2255 -13137 2549
--14053 2862 -14901 3178 -15705 3518 -16523 3905 -17356 4331 -18151 4775
--18874 5218 -19516 5645 -20090 6078 -20619 6543 -21107 7035 -21534 7525
--21890 7995 -22181 8435 -22408 8860 -22557 9293 -22629 9727 -22638 10145
--22600 10531 -22524 10885 -22406 11210 -22206 11518 -21923 11805 -21593 12066
--21244 12295 -20891 12499 -20517 12673 -20081 12812 -19580 12920 -19058 12999
--18540 13059 -18042 13102 -17544 13121 -17013 13103 -16450 13053 -15888 12983
--15347 12902 -14835 12819 -14338 12724 -13841 12596 -13339 12446 -12853 12285
--12394 12124 -11965 11973 -11560 11818 -11174 11646 -10804 11461 -10462 11279
--10141 11102 -9840 10939 -9568 10784 -9320 10623 -9103 10464 -8906 10311
--8727 10171 -8560 10043 -8409 9927 -8288 9819 -8194 9719 -8115 9631 -8044 9554
--7972 9483 -7908 9426 -7872 9384 -7850 9354 -7838 9334 -7822 9321 -7799 9310
--7780 9306 -7768 9318 -7769 9345 -7771 9374 -7761 9404 -7742 9429 -7716 9457
--7691 9497 -7670 9543 -7643 9590 -7601 9631 -7545 9662 -7477 9689 -7406 9720
--7327 9751 -7239 9777 -7134 9794 -7013 9801 -6879 9800 -6732 9793 -6575 9779
--6401 9759 -6214 9727 -6011 9692 -5793 9647 -5559 9590 -5305 9523 -5040 9449
--4760 9370 -4469 9293 -4163 9210 -3839 9112 -3494 9006 -3139 8894 -2774 8789
--2403 8690 -2022 8593 -1625 8486 -1210 8373 -785 8264 -359 8165 64 8082
-491 8008 932 7933 1384 7859 1839 7794 2289 7748 2732 7720 3170 7708 3615 7704
-4064 7711 4508 7731 4945 7774 5369 7834 5792 7912 6208 8008 6623 8121 7031 8250
-7428 8398 7814 8561 8189 8743 8562 8947 8925 9169 9280 9408 9621 9661 9954 9922
-10277 10200 10586 10502 10882 10820 11166 11154 11447 11496 11731 11831
-12014 12179 12259 12557 12482 12952 12706 13355 12950 13748 13233 14109
-13540 14469 13811 14872 14071 15319 14233 15695 14647 16020 15275 16340
-15784 16633 15996 17019 16193 17130 16765 17477 17697 17568 18794 17471
-19910 17397 20787 17323 21323 17153 21766 16850 22446 16428 23460 15773
-24599 14930 25648 13922 26510 12757 27058 11650 27107 10612 26419 9481
-24900 8210 22569 6864 19642 5548 16415 4344 13173 3313 10075 2544 7188 2048
-4515 1796 2076 1694 -112 1674 -2037 1766 -3699 2023 -5114 2502 -6313 3151
--7354 3897 -8286 4668 -9154 5394 -10006 6040 -10844 6582 -11685 7034 -12515 7423
--13338 7774 -14138 8096 -14910 8387 -15655 8644 -16370 8865 -17063 9060
--17726 9239 -18363 9411 -18961 9585 -19539 9757 -20096 9929 -20629 10095
--21125 10254 -21583 10406
-54: 9680140 -6006264 7729 4542 8085 4384 8518 4181 8993 3970 9496 3746
-10014 3514 10567 3273 11142 3020 11755 2764 12391 2501 13045 2237 13701 1973
-14377 1712 15079 1437 15810 1161 16551 887 17298 618 18047 361 18790 104
-19552 -148 20334 -404 21116 -642 21890 -873 22630 -1089 23370 -1290 24110 -1486
-24850 -1671 25590 -1843 26270 -1985 26920 -2102 27520 -2201 28110 -2289
-28720 -2364 29280 -2408 29750 -2411 30140 -2367 30460 -2287 30770 -2221
-31070 -2110 31310 -1976 31340 -1770 31360 -1350 30920 -1011 30690 -927
-31110 -579 30480 497 28160 1672 26760 1753 28920 520 33390 -863 35470 -510
-30030 3446 14540 11796 5850 13335 -360 10967 5970 16849 -2690 14780 3720 13984
-6350 13920 7820 17327 20670 19567 32370 19267 30610 9178 10540 13536 6530 9242
-610 17894 -880 18967 -1310 18502 -1960 17780 -3030 16887 -4120 15622 -4610 14192
--4110 13196 -2660 13097 -690 13843 960 14924 1130 15659 -1290 15337 -6760 13465
--14300 10284 -21280 7137 -26410 4813 -29580 3483 -31330 2917 -32400 2703
--33510 2622 -35130 2703 -37430 3109 -40010 3920 -41910 5057 -42000 6293
--39830 7318 -36000 7848 -31950 7883 -28690 7822 -26490 7869 -25100 7945
--24390 7900 -24320 7746 -24770 7728 -25870 7973 -27800 8398 -30320 8808
--32870 9092 -34660 9201 -35120 9232 -34070 9393 -32050 9967 -30080 11131
--29221 12735 -29834 14334 -31561 15470 -33724 15948 -35711 15972 -37108 15971
--37757 16284 -37729 17007 -37104 17964 -37049 18431 -37241 18665 -37234 18961
--36965 19495 -36571 20117 -36080 20572 -35610 20668 -35241 20358 -34948 19738
--34578 18999 -33530 18409 -31272 18232 -28197 18584 -25544 19344 -24321 20146
--24444 20510 -24803 20092 -24182 18904 -22184 17375 -19608 16222 -17802 16102
--17535 17263 -18173 19396 -18553 21823 -17874 23466 -16522 23461 -16362 22366
--17383 21031 -18925 19878 -20450 18953 -21648 18192 -22319 17528 -22531 16913
--22487 16317 -22278 15856 -22015 15557 -21461 15315 -19943 14932 -16909 14208
--12673 13220 -8311 12448 -5445 12321 -4454 12876 -3869 13691 -2950 14685
--1354 15815 1358 16765 5087 17070 9061 16724 11847 15852 12886 14851 11849 14237
-8359 14402 2503 15444 -4419 16920 -10433 18284 -14380 19133 -17083 19590
--19839 20165 -24480 20664 -29642 21012 -33269 21052 -33617 20634 -29954 19751
--23267 18595 -17954 17472 -12279 16214 -6799 14892 -12217 15374 -52127 21203
--65059 23143 -72156 23943 -75896 29018 -84153 21039 -78440 16405 -99029 18466
--63583 22734 -78998 21214 -91104 19576 -93716 19402 -79466 26619 -77894 25864
--69981 28385 -70598 29522 -66229 31089 -63098 32425 -63322 35387 -59071 39522
--55402 39157 -52430 35233 -49713 30128 -46511 25583 -42217 22523 -36417 21118
--29884 20895 -24359 21145 -20241 21159 -16166 20036 -11509 17729 -6740 14747
--2515 11717 1123 9004 4318 6675 6885 4699 8438 3052 8825 1771 8302 909
-7348 482 6265 393 5182 457 4076 471 2932 293 1745 -118 557 -701 -559 -1354
--1539 -1975 -2303 -2486 -2866 -3180 -3254 -3503 -3400 -3560 -3435 -3460
--3463 -3256 -3506 -2968 -3531 -2609 -3460 -2219 -3307 -1814 -3124 -1401
--2948 -960 -2772 -466 -2580 85 -2411 678 -2264 1279 -2085 1880 -1855 2469
--1603 3037 -1301 3589 -890 4117 -395 4631 122 5112 600 5562 981 5977 1342 6344
-1837 6680 2443 6977 2975 7251 3336 7504 3543 7741 3604 7964 3487 8174 3243 8372
-2885 8550 2446 8708 2059 8835 1595 8930 771 8998 -365 9048 -1479 9070 -2366 9083
--3043 9087 -3556 9082 -3920 9061 -4148 9033 -4261 8982 -4306 8922 -4334 8849
--4274 8764 -3998 8672 -3541 8563 -3037 8436 -2580 8289 -2219 8108 -1875 7907
--1464 7669 -996 7408 -558 7155 -209 6908 59 6556 257 6221 394 5842 464 5416
-485 4982 453 4564 375 4186 247 3819 64 3422 -178 3005 -469 2608 -810 2253
--1191 1955 -1622 1692 -2108 1450 -2646 1226 -3231 1043 -3860 904 -4522 812
--5221 763 -5998 764 -6854 810 -7744 900 -8640 1020 -9515 1169 -10389 1352
--11341 1591 -12371 1877 -13400 2196 -14376 2534 -15278 2876 -16135 3242
--17001 3657 -17880 4116 -18723 4590 -19486 5064 -20164 5520 -20766 5981
--21320 6477 -21827 7000 -22268 7521 -22638 8019 -22937 8486 -23170 8934
--23316 9390 -23381 9848 -23380 10287 -23331 10692 -23241 11062 -23107 11401
--22889 11721 -22583 12019 -22227 12287 -21853 12523 -21476 12732 -21077 12910
--20614 13048 -20088 13155 -19536 13233 -18990 13288 -18468 13326 -17945 13342
--17389 13316 -16803 13258 -16221 13179 -15654 13088 -15124 12998 -14613 12894
--14099 12756 -13582 12596 -13085 12423 -12613 12254 -12176 12092 -11762 11929
--11372 11748 -11001 11555 -10657 11362 -10336 11179 -10039 11009 -9766 10845
--9524 10680 -9315 10512 -9129 10356 -8959 10210 -8800 10078 -8659 9959
--8546 9847 -8467 9744 -8404 9654 -8345 9574 -8286 9504 -8235 9446 -8208 9403
--8200 9374 -8203 9356 -8195 9344 -8184 9333 -8171 9333 -8165 9348 -8173 9377
--8180 9410 -8174 9444 -8158 9473 -8129 9506 -8102 9549 -8075 9600 -8044 9654
--7993 9699 -7927 9736 -7848 9768 -7760 9802 -7665 9839 -7558 9871 -7434 9893
--7290 9903 -7135 9906 -6962 9902 -6776 9892 -6577 9874 -6356 9845 -6127 9811
--5878 9766 -5613 9711 -5326 9643 -5027 9566 -4715 9486 -4397 9407 -4061 9319
--3705 9217 -3331 9105 -2944 8988 -2554 8874 -2158 8768 -1759 8663 -1341 8547
--907 8423 -466 8301 -28 8192 403 8098 836 8011 1279 7923 1729 7835 2181 7756
-2624 7696 3053 7654 3476 7627 3902 7609 4326 7601 4744 7607 5151 7635 5541 7680
-5930 7746 6307 7829 6678 7925 7039 8044 7387 8180 7725 8331 8053 8502 8374 8696
-8681 8908 8978 9138 9264 9383 9541 9639 9809 9912 10057 10209 10294 10524
-10518 10855 10739 11196 10971 11535 11193 11890 11380 12274 11538 12676
-11702 13090 11891 13498 12125 13877 12388 14259 12606 14689 12733 15182
-12942 15584 13458 15943 14008 16275 14283 16691 14379 16952 14772 17365
-15630 17638 16712 17621 17803 17705 18737 17819 19378 17731 19877 17474
-20615 17159 21720 16768 23006 16185 24256 15389 25494 14257 26785 13070
-27925 11986 28492 10846 28053 9550 26439 8141 23732 6719 20313 5355 16624 4082
-13029 2998 9688 2155 6667 1644 3946 1408 1517 1328 -626 1351 -2486 1480
--4051 1823 -5348 2386 -6411 3144 -7315 4015 -8121 4904 -8889 5737 -9663 6459
--10458 7046 -11278 7514 -12104 7898 -12938 8234 -13747 8537 -14537 8805
--15305 9032 -16043 9221 -16759 9383 -17444 9529 -18097 9670 -18716 9810
--19304 9953 -19872 10094 -20412 10230 -20920 10362 -21378 10490
-55: 9713109 -5997714 7751 4522 8112 4367 8540 4167 9018 3950 9518 3725
-10039 3493 10594 3255 11168 3000 11776 2746 12415 2478 13061 2214 13721 1951
-14394 1685 15096 1411 15825 1136 16565 857 17310 590 18058 333 18795 75
-19560 -178 20337 -438 21118 -679 21890 -906 22630 -1125 23360 -1327 24100 -1523
-24850 -1711 25570 -1888 26260 -2028 26900 -2146 27510 -2245 28100 -2337
-28690 -2416 29270 -2462 29740 -2472 30130 -2424 30450 -2355 30760 -2286
-31080 -2181 31320 -2073 31400 -1837 31350 -1416 30890 -1158 30910 -1087
-31270 -628 30290 512 28030 1512 27370 1250 30500 -372 35750 -2107 38510 -2174
-33580 1423 10660 15041 6000 14000 -700 13378 2990 15589 5400 11609 3110 11041
-10630 11610 -6180 21453 18480 19067 27080 16690 24810 12668 12540 14426
-6200 13920 1250 18224 -760 19477 -1490 19167 -2210 18427 -3260 17500 -4350 16264
--5000 14864 -4900 13791 -4030 13417 -2730 13727 -1630 14358 -1700 14798
--3790 14548 -8120 13252 -14010 10998 -19930 8457 -24730 6307 -28040 4867
--30090 4109 -31370 3767 -32430 3629 -33720 3657 -35460 3925 -37500 4473
--39130 5251 -39470 6125 -38140 6904 -35560 7416 -32750 7664 -30500 7831
--28970 7987 -27900 8067 -27040 8010 -26380 7861 -26100 7809 -26500 8027
--27680 8510 -29540 9091 -31610 9628 -33320 10033 -34220 10329 -34090 10585
--33180 10957 -32070 11628 -31420 12636 -31548 13809 -32458 14824 -33818 15451
--35244 15726 -36398 15881 -37087 16183 -37294 16738 -36651 17579 -36553 17994
--36727 18182 -36766 18399 -36633 18788 -36367 19264 -35926 19658 -35359 19847
--34703 19802 -34067 19520 -33521 19060 -32652 18579 -30882 18324 -28334 18490
--25889 19089 -24435 19865 -24092 20400 -24138 20322 -23653 19564 -22292 18404
--20538 17393 -19205 17031 -18710 17546 -18743 18750 -18656 20181 -18110 21217
--17374 21438 -17174 20977 -17647 20188 -18594 19333 -19698 18521 -20608 17792
--21092 17158 -21098 16616 -20821 16165 -20483 15818 -20209 15571 -19768 15355
--18502 15063 -15945 14603 -12382 14012 -8704 13507 -5819 13314 -3962 13505
--2654 13976 -1521 14671 -225 15493 1674 16210 4251 16549 6952 16437 8892 15978
-9579 15457 8619 15198 5639 15445 792 16225 -4814 17293 -9705 18328 -13154 19114
--15752 19682 -18222 20452 -22671 21138 -27667 21618 -31329 21710 -32186 21262
--29687 20298 -24607 19069 -18980 17938 -13746 17236 -11686 17573 -19937 20264
--44747 26340 -57944 31792 -63778 37316 -66220 42238 -76627 24101 -70409 16464
--74202 17744 -73943 13664 -95108 17493 -100004 19967 -95506 24086 -84354 29795
--86474 15787 -68800 25999 -78189 26828 -71078 26570 -64237 26298 -68500 30026
--60476 39312 -56809 38636 -53798 33085 -50998 26924 -47935 22106 -44208 19499
--38079 19143 -30116 20149 -23960 21619 -20453 22962 -16272 22152 -10846 19331
--5035 15471 -75 11662 3978 8437 7377 5798 9891 3670 11090 1994 10990 752
-10064 -8 8860 -288 7605 -224 6347 -70 5027 -69 3638 -357 2203 -911 787 -1616
--514 -2320 -1626 -2925 -2475 -3383 -3058 -4190 -3452 -4428 -3547 -4376
--3511 -4186 -3488 -3897 -3502 -3533 -3498 -3098 -3396 -2630 -3209 -2158
--2997 -1687 -2799 -1191 -2592 -648 -2382 -45 -2204 593 -2066 1247 -1895 1893
--1659 2518 -1390 3125 -1060 3703 -611 4258 -68 4784 501 5283 1038 5750
-1467 6167 1876 6536 2451 6863 3164 7155 3793 7418 4229 7658 4485 7886 4565 8106
-4459 8314 4215 8509 3841 8688 3364 8845 2938 8967 2430 9051 1488 9111 174 9141
--1110 9152 -2131 9152 -2902 9144 -3481 9127 -3872 9104 -4085 9063 -4174 9005
--4186 8938 -4195 8857 -4106 8771 -3775 8671 -3237 8559 -2651 8433 -2127 8269
--1710 8087 -1316 7875 -857 7621 -337 7352 143 7086 525 6818 818 6444 1033 6088
-1169 5680 1225 5220 1224 4749 1169 4298 1075 3888 926 3493 722 3066 450 2617
-130 2189 -239 1810 -654 1489 -1116 1211 -1637 951 -2209 719 -2827 527 -3496 383
--4199 290 -4945 243 -5772 250 -6681 309 -7629 412 -8582 550 -9511 714 -10443 915
--11456 1174 -12554 1487 -13657 1832 -14696 2196 -15656 2567 -16564 2959
--17481 3404 -18413 3895 -19305 4402 -20107 4906 -20823 5394 -21455 5885
--22034 6413 -22561 6967 -23018 7521 -23398 8048 -23704 8542 -23943 9017
--24088 9496 -24143 9978 -24133 10439 -24068 10863 -23965 11248 -23817 11604
--23577 11937 -23247 12242 -22865 12519 -22463 12761 -22061 12973 -21637 13155
--21149 13295 -20592 13398 -20011 13472 -19440 13522 -18890 13559 -18343 13567
--17764 13534 -17154 13466 -16546 13376 -15958 13278 -15410 13178 -14882 13064
--14352 12917 -13824 12745 -13311 12563 -12830 12382 -12387 12211 -11965 12038
--11568 11848 -11197 11646 -10853 11445 -10532 11253 -10238 11076 -9969 10906
--9731 10734 -9533 10561 -9355 10398 -9194 10249 -9047 10112 -8916 9989
--8815 9874 -8750 9770 -8700 9677 -8657 9596 -8614 9525 -8572 9466 -8556 9424
--8562 9397 -8579 9380 -8585 9369 -8582 9360 -8576 9363 -8580 9381 -8592 9413
--8606 9451 -8604 9491 -8587 9523 -8557 9560 -8528 9608 -8498 9665 -8458 9725
--8400 9775 -8321 9817 -8231 9854 -8127 9895 -8016 9937 -7889 9974 -7742 10001
--7579 10015 -7398 10023 -7200 10021 -6986 10016 -6755 10000 -6503 9975
--6245 9941 -5967 9898 -5666 9841 -5347 9772 -5012 9697 -4668 9613 -4316 9529
--3952 9439 -3566 9331 -3157 9213 -2740 9089 -2321 8968 -1903 8854 -1482 8739
--1041 8614 -588 8478 -130 8345 323 8222 763 8116 1201 8017 1644 7914 2098 7811
-2544 7717 2976 7643 3396 7585 3805 7544 4210 7511 4609 7485 4999 7477 5375 7489
-5733 7520 6084 7571 6424 7640 6748 7723 7061 7828 7362 7950 7650 8090 7927 8251
-8195 8432 8447 8633 8686 8855 8915 9090 9134 9340 9346 9608 9537 9900 9713 10209
-9876 10537 10037 10877 10215 11219 10377 11578 10503 11968 10598 12376
-10699 12798 10829 13220 11014 13616 11230 14020 11390 14476 11385 14999
-11687 15432 12222 15812 12576 16224 12656 16593 12840 17034 13533 17504
-14546 17581 15537 17809 16396 18120 17075 18135 17652 17908 18441 17676
-19662 17515 21104 17250 22465 16785 23798 15874 25441 14665 27441 13494
-29332 12292 30364 10954 29962 9524 27983 8089 24714 6657 20731 5209 16591 3838
-12662 2600 9119 1690 6004 1151 3270 922 876 894 -1213 959 -2984 1176 -4436 1590
--5593 2261 -6506 3160 -7262 4174 -7930 5205 -8584 6159 -9282 6971 -10037 7607
--10835 8084 -11661 8454 -12501 8765 -13326 9036 -14136 9270 -14927 9460
--15693 9612 -16431 9734 -17141 9844 -17814 9947 -18451 10053 -19052 10161
--19633 10271 -20187 10377 -20698 10481 -21161 10583
-56: 9745844 -5989107 7756 4515 8117 4355 8543 4158 9017 3942 9519 3713
-10041 3483 10590 3244 11165 2992 11772 2733 12405 2467 13051 2202 13711 1938
-14382 1670 15076 1397 15801 1122 16544 848 17281 578 18028 316 18761 60
-19526 -194 20290 -454 21070 -696 21840 -923 22570 -1140 23310 -1342 24030 -1540
-24780 -1733 25500 -1903 26190 -2046 26820 -2166 27420 -2267 28020 -2359
-28600 -2440 29170 -2486 29650 -2492 30030 -2450 30360 -2387 30660 -2316
-30990 -2222 31220 -2123 31360 -1854 31220 -1455 30790 -1248 30970 -1169
-31250 -648 30110 480 27990 1393 27480 1134 30240 -255 34340 -1471 35360 -770
-29200 3356 14640 11616 8330 13182 5130 13285 8330 13491 11590 12095 2370 17010
-2130 12071 -2110 17498 11260 17687 18710 16345 18210 14768 11700 15386
-6200 15985 2120 18031 0 18949 -1080 18851 -1980 18356 -3130 17636 -4320 16597
--5210 15358 -5530 14286 -5250 13723 -4550 13685 -3960 13941 -4200 14149
--5930 13943 -9370 13050 -14090 11415 -19080 9388 -23460 7475 -26740 6055
--28980 5203 -30440 4773 -31490 4587 -32520 4567 -33870 4732 -35470 5082
--36880 5594 -37400 6207 -36650 6802 -34950 7261 -33020 7578 -31490 7847
--30490 8080 -29760 8213 -29010 8192 -28220 8060 -27610 7983 -27500 8142
--28060 8586 -29260 9200 -30790 9849 -32280 10443 -33350 10935 -33760 11316
--33580 11651 -33090 12087 -32680 12734 -32653 13578 -33111 14435 -33937 15101
--34924 15521 -35835 15804 -36485 16125 -36798 16581 -36257 17334 -36115 17715
--36212 17873 -36230 18019 -36171 18284 -36000 18628 -35657 18944 -35097 19169
--34307 19274 -33449 19205 -32738 18948 -31939 18576 -30528 18290 -28434 18315
--26236 18750 -24651 19437 -23938 20040 -23683 20222 -23208 19823 -22207 19015
--20949 18180 -19923 17716 -19380 17819 -19130 18395 -18836 19167 -18370 19778
--17878 19992 -17692 19801 -17898 19325 -18464 18705 -19215 18032 -19868 17383
--20147 16806 -19966 16327 -19480 15960 -18952 15681 -18572 15481 -18163 15318
--17127 15144 -15014 14902 -12056 14584 -8906 14274 -6115 14083 -3905 14100
--2169 14334 -813 14782 387 15371 1824 15935 3632 16291 5410 16358 6611 16198
-6876 16006 5892 15991 3322 16293 -712 16916 -5354 17726 -9472 18531 -12523 19233
--14928 19837 -16977 20722 -21036 21554 -25785 22178 -29618 22381 -31243 22012
--30141 21100 -26715 19939 -22291 19019 -18665 18948 -18639 20494 -25777 24445
--40296 30814 -50903 37552 -56687 43303 -59994 44779 -64764 33686 -62828 23454
--64708 13408 -72777 17155 -101293 16831 -102883 18946 -94818 24066 -83744 28430
--77275 25142 -67949 31181 -87896 30288 -88580 16113 -66983 15795 -76898 19384
--61795 39281 -59622 35795 -55350 28084 -51928 21516 -49198 16982 -47526 15205
--41357 16351 -30024 18786 -22522 21481 -21432 25366 -17342 24821 -10633 21101
--2775 15959 3171 11301 7301 7750 10473 5005 12718 2881 13591 1251 13191 -31
-12074 -887 10722 -1232 9268 -1201 7703 -1108 6007 -1236 4248 -1691 2504 -2372
-862 -3078 -620 -3652 -1848 -4038 -2768 -4266 -3436 -4980 -3797 -5073 -3789 -4944
--3646 -4724 -3542 -4424 -3505 -4029 -3462 -3548 -3323 -3018 -3102 -2485
--2867 -1959 -2638 -1411 -2405 -813 -2177 -158 -1996 534 -1875 1243 -1721 1931
--1484 2602 -1205 3246 -849 3856 -361 4427 222 4970 848 5490 1444 5962 1927 6384
-2389 6747 3055 7069 3888 7347 4635 7592 5158 7820 5467 8039 5577 8252 5492 8458
-5253 8653 4859 8835 4341 8988 3883 9104 3317 9181 2233 9222 707 9237 -783 9235
--1959 9221 -2841 9197 -3492 9175 -3904 9142 -4095 9094 -4144 9030 -4113 8952
--4086 8869 -3964 8776 -3569 8676 -2941 8568 -2261 8426 -1657 8262 -1175 8075
--727 7848 -208 7589 367 7306 891 7024 1309 6742 1630 6351 1860 5968 1994 5530
-2034 5029 2000 4519 1924 4031 1804 3588 1636 3163 1406 2703 1110 2218 758 1757
-359 1351 -88 1007 -583 710 -1138 436 -1737 191 -2391 -10 -3099 -156 -3842 -253
--4633 -299 -5510 -281 -6477 -211 -7483 -92 -8496 63 -9484 243 -10474 466
--11551 748 -12724 1085 -13901 1457 -15011 1850 -16033 2247 -16995 2668
--17968 3146 -18951 3668 -19893 4209 -20740 4749 -21490 5267 -22157 5789
--22763 6349 -23309 6938 -23780 7525 -24172 8085 -24484 8604 -24728 9106
--24871 9613 -24916 10117 -24891 10601 -24811 11044 -24698 11447 -24532 11818
--24268 12160 -23912 12479 -23504 12762 -23075 13008 -22647 13226 -22196 13409
--21681 13549 -21093 13650 -20481 13718 -19883 13765 -19308 13794 -18736 13796
--18131 13757 -17498 13677 -16866 13577 -16260 13468 -15691 13358 -15146 13235
--14600 13077 -14058 12894 -13534 12700 -13043 12509 -12593 12329 -12164 12146
--11766 11946 -11392 11735 -11047 11525 -10729 11326 -10437 11141 -10172 10963
--9942 10786 -9751 10608 -9584 10439 -9436 10284 -9300 10146 -9178 10018
--9091 9901 -9042 9794 -9008 9700 -8979 9618 -8948 9546 -8921 9488 -8918 9447
--8937 9421 -8969 9405 -8988 9398 -8994 9391 -8996 9396 -9007 9418 -9029 9454
--9047 9497 -9049 9541 -9033 9579 -9002 9620 -8969 9674 -8936 9738 -8887 9803
--8821 9858 -8733 9907 -8626 9949 -8507 9997 -8379 10045 -8230 10087 -8064 10119
--7877 10139 -7671 10148 -7445 10153 -7202 10151 -6937 10138 -6657 10116
--6367 10082 -6056 10041 -5724 9983 -5365 9913 -4995 9837 -4617 9751 -4230 9663
--3837 9568 -3417 9455 -2976 9332 -2525 9200 -2077 9070 -1633 8947 -1190 8823
--728 8686 -250 8538 225 8394 691 8257 1142 8137 1586 8025 2036 7906 2485 7789
-2927 7678 3353 7587 3761 7514 4155 7459 4540 7407 4914 7367 5273 7341 5619 7337
-5947 7353 6259 7389 6556 7442 6833 7512 7098 7601 7351 7711 7588 7838 7816 7986
-8026 8157 8223 8347 8405 8556 8574 8784 8740 9027 8892 9288 9022 9573 9141 9876
-9247 10199 9347 10536 9464 10881 9572 11243 9635 11636 9667 12049 9703 12478
-9773 12910 9908 13322 10070 13747 10171 14229 10080 14762 10451 15221
-10873 15656 10988 16066 11001 16534 11449 17094 12357 17377 13258 17683
-13946 18164 14534 18334 15145 18159 15992 18014 17315 18062 18969 18106
-20482 17960 21759 17403 23305 16336 25628 15135 28548 13868 31158 12446
-32434 10979 31793 9592 29273 8209 25410 6679 20924 5060 16399 3441 12192 2064
-8473 1076 5281 514 2527 348 152 385 -1873 552 -3533 829 -4851 1343 -5861 2162
--6609 3215 -7198 4393 -7714 5586 -8251 6685 -8865 7596 -9568 8275 -10346 8752
--11168 9095 -12019 9364 -12868 9594 -13701 9783 -14521 9930 -15315 10035
--16081 10116 -16817 10182 -17511 10245 -18166 10312 -18791 10384 -19383 10459
--19946 10536 -20463 10611 -20933 10687
-57: 9778350 -5980442 7742 4516 8096 4353 8521 4157 8997 3941 9495 3711
-10013 3480 10561 3244 11137 2995 11739 2733 12366 2463 13010 2200 13663 1936
-14332 1669 15026 1395 15743 1123 16488 849 17214 580 17957 320 18680 58
-19440 -195 20200 -447 20980 -693 21740 -925 22460 -1136 23190 -1341 23920 -1534
-24650 -1728 25360 -1896 26050 -2041 26670 -2159 27270 -2263 27860 -2354
-28440 -2430 28990 -2477 29470 -2482 29850 -2442 30170 -2380 30470 -2300
-30790 -2221 31020 -2122 31180 -1829 30960 -1448 30590 -1265 30840 -1171
-31050 -648 29960 422 27950 1341 27180 1321 28820 490 31230 -40 30940 1082
-25640 4515 16620 9478 11070 11785 9090 12635 10470 13098 10780 13591 4870 16191
-2200 14497 1340 16405 7680 16944 12510 16457 12890 15866 9570 16132 5710 16718
-2570 17718 630 18240 -560 18215 -1600 17933 -2830 17465 -4150 16693 -5260 15672
--5960 14690 -6200 14027 -6070 13747 -5920 13714 -6310 13715 -7770 13507
--10540 12856 -14370 11643 -18620 10022 -22540 8368 -25710 7035 -28030 6161
--29620 5678 -30720 5459 -31610 5407 -32640 5495 -33910 5709 -35100 6030
--35710 6451 -35380 6897 -34260 7287 -32930 7602 -31890 7902 -31270 8175
--30840 8357 -30340 8396 -29670 8312 -28980 8227 -28610 8326 -28730 8697
--29360 9258 -30410 9917 -31570 10594 -32590 11202 -33270 11698 -33530 12087
--33460 12445 -33320 12901 -33290 13518 -33520 14219 -34018 14857 -34684 15346
--35373 15714 -35940 16068 -36272 16476 -35908 17153 -35750 17516 -35751 17666
--35703 17772 -35634 17938 -35511 18177 -35261 18413 -34772 18624 -33960 18797
--32977 18863 -32127 18746 -31326 18478 -30169 18198 -28464 18120 -26540 18387
--24926 18942 -23961 19536 -23432 19870 -22883 19753 -22056 19250 -21079 18620
--20251 18157 -19716 18041 -19345 18233 -18958 18579 -18528 18879 -18153 19000
--17963 18890 -18032 18570 -18350 18105 -18842 17560 -19285 16997 -19396 16483
--19067 16061 -18423 15736 -17706 15499 -17178 15328 -16724 15216 -15832 15135
--14081 15052 -11625 14924 -8938 14772 -6372 14637 -4097 14594 -2188 14691
--687 14969 520 15390 1736 15850 3076 16215 4231 16402 4856 16457 4747 16493
-3672 16643 1411 16994 -2004 17538 -5956 18193 -9572 18859 -12340 19487
--14553 20093 -16213 21009 -19786 21938 -24203 22714 -28152 23086 -30543 22874
--30808 22097 -29042 21057 -26237 20322 -24176 20642 -24931 22789 -30159 27235
--39050 33640 -46884 40534 -52009 46161 -55120 48156 -57899 44547 -59404 41052
--64550 36518 -76850 1337 -94540 5425 -97109 13912 -90084 22645 -80010 29591
--72285 33033 -69013 37350 -82879 35860 -110512 27478 -81484 7320 -58584 6031
--72826 35861 -66133 26338 -55443 19040 -50965 14596 -48835 11158 -52422 10213
--47334 13167 -28557 16635 -18146 19183 -24602 28658 -19769 27593 -10897 22502
-773 15652 7347 10385 10489 7065 12924 4517 15154 2551 16178 1038 15874 -544
-14704 -1897 13111 -2638 11216 -2853 9051 -2942 6748 -3272 4529 -3918 2500 -4644
-681 -5132 -917 -5262 -2234 -5123 -3211 -4888 -4015 -5224 -4304 -5135 -4144 -5018
--3850 -4903 -3632 -4711 -3523 -4373 -3423 -3900 -3240 -3347 -2982 -2775
--2714 -2202 -2464 -1606 -2206 -958 -1953 -248 -1779 506 -1690 1262 -1565 2004
--1339 2726 -1055 3403 -679 4039 -154 4627 478 5196 1157 5727 1819 6203
-2357 6623 2879 6983 3648 7293 4626 7546 5510 7776 6129 7990 6507 8200 6658 8404
-6594 8607 6363 8806 5948 8985 5387 9136 4887 9245 4256 9310 3005 9336 1230 9337
--504 9317 -1852 9286 -2864 9253 -3598 9222 -4024 9180 -4183 9125 -4179 9052
--4098 8967 -4029 8880 -3864 8786 -3388 8693 -2656 8574 -1869 8431 -1171 8269
--611 8068 -104 7834 479 7568 1116 7271 1693 6976 2148 6688 2493 6270 2743 5861
-2877 5387 2889 4846 2821 4292 2716 3764 2573 3288 2382 2828 2125 2332 1799 1808
-1419 1314 988 875 510 508 -19 191 -607 -99 -1235 -357 -1920 -566 -2665 -717
--3451 -817 -4287 -859 -5216 -835 -6238 -749 -7304 -614 -8379 -441 -9429 -240
--10480 1 -11627 307 -12880 671 -14134 1073 -15318 1493 -16404 1919 -17426 2370
--18455 2880 -19495 3438 -20488 4014 -21382 4588 -22170 5138 -22871 5692
--23505 6288 -24071 6914 -24554 7534 -24957 8125 -25278 8676 -25525 9204
--25663 9738 -25700 10266 -25659 10772 -25563 11237 -25434 11658 -25250 12043
--24964 12397 -24579 12724 -24142 13015 -23687 13267 -23231 13488 -22755 13675
--22208 13813 -21590 13909 -20948 13972 -20319 14011 -19718 14035 -19123 14031
--18494 13982 -17834 13892 -17179 13781 -16554 13660 -15965 13541 -15403 13406
--14843 13237 -14288 13041 -13754 12836 -13252 12634 -12793 12444 -12359 12251
--11959 12042 -11585 11822 -11239 11602 -10924 11396 -10635 11203 -10374 11019
--10155 10835 -9973 10653 -9819 10479 -9680 10320 -9557 10176 -9446 10045
--9375 9926 -9343 9818 -9325 9723 -9310 9641 -9293 9569 -9281 9510 -9292 9470
--9328 9446 -9372 9432 -9402 9429 -9420 9425 -9432 9432 -9451 9459 -9481 9500
--9503 9548 -9510 9596 -9493 9641 -9463 9686 -9428 9747 -9387 9817 -9332 9888
--9259 9953 -9155 10005 -9037 10054 -8902 10107 -8754 10161 -8587 10211
--8394 10248 -8184 10272 -7953 10288 -7702 10295 -7424 10297 -7126 10288
--6814 10268 -6490 10237 -6150 10194 -5781 10137 -5386 10068 -4977 9988
--4559 9900 -4142 9808 -3715 9709 -3260 9590 -2784 9459 -2301 9319 -1820 9181
--1351 9049 -881 8914 -397 8766 103 8605 598 8446 1081 8297 1540 8161 1993 8035
-2446 7902 2895 7766 3335 7639 3755 7529 4149 7442 4528 7369 4893 7302 5242 7242
-5572 7200 5883 7178 6177 7179 6453 7199 6707 7237 6937 7292 7153 7365 7353 7460
-7541 7575 7717 7710 7875 7868 8012 8046 8136 8245 8247 8462 8357 8696 8449 8950
-8521 9228 8583 9522 8630 9839 8673 10173 8730 10516 8778 10882 8778 11275
-8747 11689 8721 12123 8725 12565 8805 12990 8914 13434 8947 13939 8856 14474
-9206 14976 9379 15415 9271 15916 9408 16428 10154 16976 11053 17329 11603 17926
-11954 18311 12448 18230 13315 18169 14712 18423 16564 18754 18355 18863
-19641 18600 20819 17836 22815 16762 26078 15552 29954 14102 33116 12552
-34390 11189 33334 9943 30281 8459 25959 6664 21117 4684 16275 2838 11800 1343
-7871 293 4517 -206 1680 -281 -700 -122 -2656 111 -4198 474 -5362 1132 -6190 2102
--6755 3320 -7150 4685 -7490 6071 -7885 7327 -8396 8335 -9035 9051 -9782 9517
--10611 9818 -11476 10034 -12354 10209 -13224 10345 -14080 10441 -14910 10497
--15714 10526 -16472 10546 -17193 10563 -17870 10587 -18510 10621 -19120 10660
--19694 10705 -20221 10752 -20692 10802
-58: 9810626 -5971714 7704 4517 8054 4358 8475 4167 8950 3948 9448 3720
-9965 3488 10505 3252 11078 3003 11676 2742 12301 2475 12936 2213 13588 1942
-14249 1680 14942 1410 15651 1135 16385 864 17107 595 17840 336 18570 78
-19310 -175 20060 -432 20840 -671 21580 -902 22310 -1115 23020 -1317 23740 -1508
-24460 -1697 25170 -1867 25840 -2013 26460 -2128 27040 -2229 27630 -2317
-28190 -2385 28730 -2439 29200 -2438 29580 -2395 29870 -2333 30180 -2246
-30480 -2174 30700 -2062 30860 -1763 30590 -1389 30260 -1204 30490 -1094
-30670 -606 29740 372 27910 1311 26790 1607 27220 1366 28100 1403 27090 2620
-22940 5242 16940 8521 12550 10749 10820 12031 11010 12937 10300 13982
-6760 15559 4110 15550 3530 16391 6260 16805 8830 16675 9220 16453 7440 16570
-4860 16932 2550 17407 930 17634 -220 17596 -1310 17434 -2560 17159 -3940 16639
--5220 15852 -6230 14997 -6890 14320 -7240 13890 -7480 13651 -8030 13480
--9330 13223 -11630 12694 -14800 11761 -18390 10457 -21910 9050 -24880 7832
--27210 6983 -28920 6477 -30070 6232 -30910 6156 -31750 6195 -32720 6312
--33730 6503 -34360 6786 -34280 7115 -33580 7429 -32650 7713 -31910 7999
--31540 8275 -31370 8500 -31100 8604 -30640 8578 -30070 8516 -29620 8577
--29490 8859 -29740 9345 -30340 9956 -31160 10622 -32040 11276 -32760 11856
--33240 12314 -33470 12681 -33540 13061 -33580 13534 -33727 14106 -34034 14684
--34470 15190 -34984 15604 -35439 15988 -35746 16375 -35573 16981 -35427 17339
--35342 17504 -35216 17593 -35089 17708 -34964 17862 -34757 18024 -34357 18198
--33595 18384 -32576 18519 -31627 18507 -30785 18337 -29789 18087 -28401 17941
--26752 18060 -25208 18461 -24097 18979 -23353 19371 -22695 19450 -21929 19193
--21096 18761 -20378 18370 -19854 18166 -19428 18152 -18995 18238 -18577 18325
--18245 18330 -18048 18213 -18021 17959 -18172 17590 -18482 17138 -18749 16652
--18737 16203 -18317 15825 -17567 15529 -16714 15308 -16032 15157 -15489 15071
--14654 15051 -13159 15067 -11099 15076 -8821 15051 -6544 15000 -4402 14965
--2494 15010 -963 15184 263 15496 1381 15886 2461 16248 3235 16519 3463 16718
-3049 16911 1886 17182 -165 17584 -3120 18100 -6590 18678 -9848 19264 -12427 19838
--14523 20443 -15936 21310 -19009 22302 -22994 23226 -26917 23808 -29888 23803
--31291 23189 -30991 22247 -29741 21584 -28964 22004 -30075 24268 -33907 28686
--39847 34806 -45665 41367 -49906 46749 -52617 49264 -55136 47982 -58858 43911
--66231 34281 -77532 11371 -88465 8611 -90349 14875 -84930 23859 -77179 32460
--72000 39341 -73455 45160 -88783 47512 -130790 42405 -98530 4117 -65648 7008
--51053 21346 -58784 8161 -46163 9278 -44987 10332 -45391 7615 -58033 6215
--57235 10804 -25637 13508 -7841 10844 -33704 33788 -22527 28747 -11442 22553
-6739 13877 12087 8898 12355 6898 13892 4675 17319 2873 19389 1643 19545 -763
-18165 -3277 15950 -4805 13157 -5395 10004 -5694 6887 -6248 4207 -7118
-2018 -7802 171 -7759 -1443 -6990 -2794 -5904 -3782 -4930 -4744 -4578 -4934 -4320
--4608 -4372 -4135 -4553 -3770 -4629 -3552 -4473 -3375 -4098 -3137 -3579
--2836 -3001 -2536 -2403 -2268 -1766 -1979 -1070 -1703 -303 -1548 503 -1510 1312
--1430 2119 -1226 2886 -946 3595 -554 4251 5 4870 685 5457 1427 5989 2158 6470
-2757 6889 3344 7244 4235 7528 5380 7758 6417 7974 7155 8169 7615 8363 7813 8559
-7767 8759 7552 8961 7119 9138 6506 9285 5961 9387 5253 9441 3814 9454 1750 9438
--262 9401 -1823 9351 -2981 9310 -3806 9268 -4253 9216 -4368 9154 -4297 9073
--4150 8984 -4032 8893 -3812 8804 -3243 8705 -2390 8582 -1477 8452 -668 8279
--26 8071 556 7839 1208 7558 1913 7248 2547 6955 3043 6655 3417 6198 3688 5763
-3821 5256 3800 4672 3694 4069 3553 3499 3384 2985 3167 2491 2881 1954 2528 1390
-2114 855 1653 386 1140 -9 576 -347 -42 -655 -699 -926 -1415 -1144 -2195 -1300
--3023 -1401 -3904 -1443 -4886 -1408 -5965 -1308 -7094 -1152 -8232 -962
--9343 -741 -10461 -479 -11680 -147 -13016 245 -14356 675 -15616 1127 -16772 1582
--17851 2065 -18943 2609 -20043 3202 -21092 3815 -22031 4425 -22862 5009
--23598 5597 -24258 6229 -24843 6892 -25341 7549 -25755 8174 -26084 8754
--26334 9311 -26468 9870 -26492 10427 -26434 10955 -26324 11441 -26175 11879
--25973 12280 -25665 12648 -25249 12981 -24781 13279 -24297 13537 -23814 13761
--23307 13949 -22732 14086 -22082 14177 -21410 14233 -20752 14266 -20119 14282
--19503 14270 -18848 14212 -18164 14111 -17486 13986 -16840 13854 -16230 13722
--15653 13577 -15079 13396 -14511 13188 -13964 12970 -13455 12757 -12990 12556
--12550 12354 -12146 12135 -11775 11906 -11429 11677 -11118 11462 -10832 11263
--10578 11072 -10367 10882 -10198 10694 -10055 10516 -9930 10353 -9816 10205
--9721 10072 -9667 9950 -9649 9841 -9649 9746 -9651 9663 -9650 9591 -9653 9533
--9676 9495 -9730 9474 -9789 9462 -9834 9461 -9862 9462 -9881 9472 -9910 9503
--9949 9550 -9976 9604 -9983 9657 -9972 9707 -9940 9759 -9899 9827 -9855 9904
--9794 9982 -9708 10053 -9595 10113 -9463 10168 -9311 10227 -9142 10289
--8954 10345 -8737 10387 -8503 10418 -8246 10437 -7964 10449 -7655 10456
--7323 10450 -6977 10433 -6619 10403 -6244 10361 -5840 10304 -5405 10233
--4954 10152 -4501 10061 -4049 9964 -3585 9861 -3095 9736 -2583 9597 -2064 9448
--1553 9302 -1052 9158 -559 9014 -49 8852 472 8678 991 8504 1489 8339 1964 8191
-2420 8048 2879 7898 3330 7744 3767 7600 4180 7472 4560 7367 4926 7276 5269 7192
-5590 7114 5893 7053 6171 7013 6431 6998 6669 7001 6879 7024 7059 7061 7225 7118
-7373 7199 7513 7300 7633 7422 7738 7566 7815 7731 7884 7917 7936 8124 7987 8348
-8024 8593 8037 8861 8041 9147 8030 9455 8015 9783 8011 10123 8001 10489
-7936 10882 7841 11294 7750 11728 7691 12178 7713 12615 7760 13076 7721 13601
-7715 14164 7894 14659 7724 15199 7508 15642 7943 16310 8878 16788 9498 17399
-9597 18031 9751 18147 10452 18132 11856 18530 13862 19147 15980 19488
-17493 19373 18347 18889 19559 18096 22296 17154 26665 15901 31447 14336
-34972 12906 36084 11780 34648 10478 31249 8636 26700 6352 21632 4042 16505 2068
-11658 501 7333 -511 3648 -920 609 -885 -1822 -646 -3699 -343 -5088 160
--6052 957 -6659 2070 -6983 3481 -7137 5068 -7253 6659 -7464 8073 -7840 9182
--8402 9938 -9117 10382 -9950 10629 -10851 10779 -11776 10888 -12704 10960
--13603 10996 -14482 10994 -15320 10967 -16116 10933 -16865 10901 -17564 10878
--18221 10871 -18847 10874 -19431 10886 -19967 10904 -20448 10926
-59: 9842675 -5962933 7640 4531 7994 4374 8413 4179 8878 3965 9376 3738
-9889 3504 10427 3269 10989 3018 11588 2765 12201 2499 12834 2231 13482 1966
-14133 1704 14821 1437 15520 1159 16250 889 16960 626 17690 368 18410 115
-19130 -143 19890 -395 20640 -634 21380 -861 22100 -1073 22800 -1269 23510 -1460
-24210 -1646 24900 -1818 25570 -1957 26180 -2070 26750 -2165 27310 -2251
-27870 -2317 28400 -2362 28840 -2361 29210 -2314 29490 -2244 29790 -2152
-30040 -2076 30280 -1956 30400 -1647 30110 -1278 29780 -1066 29930 -931
-30080 -499 29370 363 27810 1292 26460 1851 25940 2101 25640 2553 24200 3766
-20870 5807 16470 8201 12910 10163 11230 11582 10850 12715 10080 13875
-7940 15146 5700 15861 4870 16510 5720 16861 6800 16866 6880 16765 5720 16797
-3960 16968 2230 17163 890 17207 -150 17122 -1210 17001 -2430 16847 -3810 16512
--5180 15927 -6390 15216 -7380 14574 -8080 14079 -8670 13709 -9400 13402
--10640 13073 -12600 12592 -15260 11834 -18360 10768 -21450 9573 -24220 8490
--26490 7683 -28270 7179 -29490 6917 -30350 6817 -31060 6821 -31840 6872
--32680 6976 -33280 7154 -33370 7397 -32940 7644 -32280 7885 -31750 8134
--31510 8398 -31480 8641 -31420 8796 -31190 8836 -30810 8820 -30430 8866
--30190 9086 -30200 9486 -30490 10020 -31020 10631 -31680 11272 -32330 11882
--32890 12399 -33280 12809 -33490 13173 -33630 13572 -33773 14048 -33973 14559
--34273 15044 -34641 15478 -34993 15874 -35238 16255 -35213 16791 -35103 17150
--34961 17339 -34769 17440 -34565 17533 -34396 17635 -34201 17742 -33862 17868
--33195 18035 -32200 18194 -31199 18256 -30308 18170 -29396 17972 -28249 17796
--26846 17795 -25431 18042 -24268 18447 -23392 18827 -22632 19010 -21851 18930
--21085 18669 -20420 18380 -19900 18173 -19435 18066 -18973 18010 -18542 17962
--18206 17867 -17994 17717 -17893 17480 -17918 17165 -18070 16780 -18199 16360
--18103 15963 -17637 15626 -16845 15350 -15914 15142 -15111 14993 -14452 14917
--13618 14926 -12288 14997 -10533 15095 -8586 15169 -6614 15205 -4706 15221
--2934 15263 -1472 15396 -266 15649 797 15986 1724 16346 2281 16673 2265 16968
-1640 17271 419 17633 -1478 18079 -4117 18602 -7219 19152 -10195 19702
--12665 20251 -14733 20855 -16070 21615 -18692 22646 -22192 23721 -25931 24514
--29212 24723 -31419 24267 -32295 23388 -32343 22695 -32609 23011 -34060 25075
--37190 29129 -41695 34692 -46305 40648 -49840 45524 -52184 47878 -54716 46797
--59377 42030 -67269 32646 -76858 19262 -84184 15359 -85330 19212 -81425 26855
--76447 35244 -74906 42510 -80657 47467 -96709 47527 -118967 38131 -103413 12933
--76267 4610 -49769 7008 -55499 8856 -33992 13790 -28632 16923 -51296 11192
--55090 7409 -62156 11874 -32814 6532 7246 -8046 -51934 40297 -19139 23195
--10860 19899 15114 10853 15488 7857 10921 8604 12458 5797 19872 3754 23939 3592
-24598 -688 22369 -5364 18907 -7945 14694 -8802 10143 -9171 6018 -9956
-2986 -11232 939 -11930 -679 -10951 -2163 -8632 -3471 -6043 -4447 -4031
--5538 -2740 -5609 -2390 -5098 -2838 -4445 -3548 -3915 -4088 -3576 -4268
--3304 -4099 -2995 -3682 -2653 -3143 -2320 -2544 -2035 -1879 -1723 -1139
--1431 -320 -1307 533 -1334 1407 -1319 2269 -1150 3078 -878 3820 -480 4507
-117 5151 842 5741 1650 6278 2452 6765 3110 7185 3776 7522 4806 7777 6142 7992
-7362 8183 8239 8351 8785 8525 9035 8712 9020 8908 8823 9108 8374 9287 7706 9436
-7113 9533 6325 9577 4666 9578 2262 9541 -77 9483 -1880 9422 -3209 9364
--4142 9308 -4612 9251 -4669 9178 -4507 9093 -4278 8998 -4095 8913 -3810 8820
--3134 8715 -2135 8606 -1079 8474 -150 8296 593 8093 1255 7852 1989 7562
-2764 7252 3459 6952 4001 6636 4409 6143 4703 5683 4827 5140 4772 4509 4617 3854
-4439 3236 4234 2683 3992 2151 3677 1570 3291 962 2844 384 2350 -119 1802 -544
-1203 -906 556 -1231 -131 -1516 -872 -1743 -1686 -1905 -2554 -2008 -3483 -2047
--4516 -2003 -5656 -1887 -6846 -1711 -8052 -1500 -9227 -1258 -10407 -972
--11705 -616 -13134 -195 -14563 268 -15905 751 -17131 1238 -18278 1753
--19431 2331 -20594 2963 -21701 3613 -22690 4260 -23565 4879 -24336 5503
--25023 6172 -25627 6874 -26142 7569 -26566 8230 -26901 8840 -27153 9427
--27282 10014 -27295 10597 -27218 11149 -27088 11656 -26920 12114 -26700 12530
--26367 12910 -25922 13252 -25419 13555 -24903 13818 -24390 14045 -23857 14233
--23251 14368 -22567 14453 -21863 14502 -21176 14526 -20517 14535 -19872 14514
--19192 14445 -18484 14331 -17783 14194 -17114 14047 -16489 13905 -15894 13747
--15305 13555 -14724 13332 -14168 13102 -13651 12878 -13178 12666 -12736 12453
--12328 12225 -11959 11984 -11616 11749 -11310 11525 -11028 11319 -10782 11122
--10580 10925 -10422 10731 -10293 10550 -10182 10383 -10083 10233 -9999 10096
--9962 9974 -9962 9863 -9982 9767 -10003 9685 -10017 9613 -10032 9557 -10073 9521
--10144 9501 -10220 9495 -10279 9495 -10317 9501 -10347 9516 -10384 9552
--10429 9603 -10466 9664 -10475 9724 -10466 9780 -10433 9838 -10389 9914
--10339 9997 -10272 10085 -10173 10162 -10049 10229 -9904 10290 -9734 10357
--9546 10427 -9332 10490 -9093 10539 -8833 10574 -8549 10598 -8236 10616
--7894 10626 -7528 10626 -7144 10610 -6753 10583 -6342 10541 -5897 10483
--5425 10412 -4933 10327 -4441 10235 -3952 10133 -3450 10024 -2923 9893
--2370 9745 -1816 9588 -1272 9431 -741 9277 -222 9121 318 8946 864 8757
-1402 8567 1919 8388 2407 8224 2869 8064 3335 7896 3788 7723 4225 7561 4630 7414
-5000 7289 5347 7183 5670 7078 5964 6980 6236 6901 6482 6843 6706 6809 6907 6797
-7071 6799 7204 6821 7315 6863 7412 6927 7500 7013 7568 7121 7615 7251 7637 7402
-7647 7574 7642 7769 7632 7983 7614 8218 7570 8474 7516 8749 7449 9047 7377 9366
-7313 9703 7240 10066 7114 10455 6957 10861 6799 11295 6675 11747 6631 12195
-6617 12670 6499 13214 6595 13798 6455 14375 5943 14844 5855 15423 6659 16082
-7551 16623 7667 17425 7363 17892 7574 17935 8756 18328 10817 19172 13249 19802
-15185 19791 16035 19400 16395 18889 17881 18361 21649 17625 27258 16337
-32890 14825 36665 13653 37636 12566 36008 10878 32559 8438 28010 5715
-22819 3302 17329 1326 11864 -205 6805 -1178 2492 -1568 -903 -1507 -3416 -1230
--5173 -790 -6339 -146 -7022 767 -7321 2055 -7316 3696 -7146 5525 -6966 7327
--6939 8919 -7147 10150 -7613 10952 -8309 11372 -9167 11551 -10131 11619
--11129 11642 -12132 11633 -13100 11593 -14030 11521 -14915 11431 -15747 11338
--16530 11253 -17256 11184 -17928 11132 -18572 11098 -19162 11076 -19707 11064
--20196 11057
-60: 9874503 -5954094 7562 4553 7908 4397 8327 4200 8791 3988 9279 3761
-9786 3529 10321 3293 10878 3047 11465 2795 12080 2532 12703 2264 13341 1998
-13986 1740 14670 1475 15360 1200 16070 932 16780 668 17500 414 18200 162
-18920 -93 19670 -341 20410 -578 21130 -802 21840 -1008 22520 -1204 23210 -1393
-23910 -1578 24590 -1741 25240 -1878 25830 -1984 26380 -2078 26940 -2158
-27470 -2217 27980 -2256 28420 -2251 28750 -2198 29010 -2119 29290 -2021
-29520 -1935 29730 -1799 29820 -1492 29530 -1116 29190 -866 29190 -687
-29280 -304 28770 429 27530 1311 26120 2029 25020 2625 23950 3370 22210 4575
-19350 6266 15800 8169 12750 9884 11020 11282 10400 12470 9770 13613 8460 14770
-6610 15807 5580 16496 5470 16871 5650 16955 5390 16910 4460 16892 3120 16949
-1750 16999 610 16949 -330 16805 -1320 16690 -2480 16578 -3820 16355 -5190 15929
--6520 15357 -7700 14782 -8690 14270 -9540 13835 -10470 13436 -11690 13034
--13430 12561 -15740 11902 -18400 11011 -21130 9991 -23660 9043 -25850 8290
--27620 7793 -28940 7519 -29840 7397 -30510 7373 -31160 7383 -31850 7428
--32410 7532 -32600 7706 -32370 7900 -31910 8098 -31500 8306 -31330 8543
--31360 8779 -31440 8969 -31400 9069 -31210 9106 -30950 9169 -30740 9350
--30650 9683 -30740 10138 -31040 10673 -31490 11264 -32020 11858 -32560 12397
--33000 12850 -33320 13228 -33520 13603 -33680 14015 -33848 14462 -34067 14914
--34332 15334 -34592 15737 -34768 16111 -34815 16578 -34740 16935 -34576 17152
--34345 17280 -34083 17375 -33843 17454 -33627 17524 -33328 17611 -32746 17739
--31829 17897 -30827 18000 -29893 17984 -29007 17850 -28014 17672 -26824 17596
--25564 17709 -24420 17990 -23478 18308 -22646 18524 -21830 18548 -21086 18415
--20434 18227 -19898 18056 -19412 17927 -18918 17810 -18455 17682 -18095 17523
--17847 17339 -17676 17102 -17598 16810 -17620 16476 -17628 16114 -17462 15764
--16977 15462 -16193 15207 -15234 15007 -14360 14859 -13607 14780 -12738 14794
--11512 14891 -9977 15036 -8297 15182 -6603 15297 -4950 15376 -3394 15452
--2063 15586 -956 15813 42 16118 869 16480 1309 16839 1156 17201 411 17580
--847 18008 -2644 18500 -5023 19043 -7814 19597 -10578 20137 -12989 20682
--15075 21294 -16502 21925 -18782 22978 -21801 24180 -25229 25153 -28573 25553
--31261 25242 -32962 24419 -34006 23670 -35114 23795 -36956 25484 -39899 28965
--43797 33803 -47839 39001 -50978 43215 -53061 45149 -55485 43979 -60216 39516
--67687 32162 -75791 24129 -81301 21197 -82222 23809 -79609 29902 -76747 37064
--77370 43265 -84295 46686 -97539 45095 -110164 36170 -104955 20375 -89353 10566
--68411 4110 -53268 2409 -27835 14884 -7036 22246 -26978 14934 -61009 12758
--61779 13258 -42725 7824 -27117 5282 -22836 7259 -6776 9831 6535 10672
-7894 13165 13522 11187 4924 14166 8650 7413 24437 4251 30359 7996 31199 -580
-26878 -8663 21593 -12011 15544 -12592 9152 -12705 3723 -13763 607 -16087
--720 -17312 -1733 -14818 -2942 -9952 -4185 -5141 -5130 -1833 -6159 512
--6115 750 -5496 -363 -4708 -1859 -4042 -3075 -3575 -3752 -3199 -3891 -2820 -3642
--2432 -3184 -2078 -2605 -1781 -1931 -1448 -1155 -1142 -302 -1062 611 -1175 1550
--1233 2457 -1107 3304 -856 4083 -446 4804 179 5455 946 6047 1814 6597 2695 7091
-3419 7506 4160 7816 5356 8051 6902 8245 8325 8395 9354 8526 9998 8678 10298 8856
-10322 9045 10162 9241 9705 9431 8983 9586 8339 9685 7469 9721 5552 9707
-2753 9647 34 9570 -2048 9488 -3571 9410 -4630 9343 -5107 9275 -5082 9197
--4802 9108 -4467 9015 -4206 8927 -3842 8830 -3038 8736 -1879 8641 -665 8501
-397 8325 1249 8128 2005 7878 2822 7589 3679 7279 4437 6965 5028 6627 5475 6120
-5790 5634 5903 5050 5801 4362 5589 3649 5362 2979 5123 2381 4847 1806 4500 1182
-4081 524 3603 -99 3076 -641 2495 -1096 1862 -1485 1184 -1829 476 -2129
--288 -2365 -1133 -2532 -2040 -2636 -3016 -2674 -4104 -2619 -5303 -2483
--6557 -2287 -7828 -2052 -9072 -1788 -10321 -1480 -11699 -1094 -13225 -644
--14755 -150 -16183 366 -17486 885 -18701 1433 -19923 2049 -21152 2720
--22316 3407 -23359 4093 -24279 4749 -25085 5409 -25799 6116 -26427 6859
--26956 7596 -27387 8293 -27728 8936 -27982 9552 -28105 10170 -28101 10779
--28008 11357 -27855 11884 -27669 12361 -27427 12793 -27069 13184 -26590 13534
--26054 13843 -25503 14110 -24961 14340 -24398 14528 -23762 14659 -23045 14736
--22306 14778 -21587 14791 -20901 14792 -20230 14764 -19525 14680 -18792 14553
--18066 14401 -17379 14241 -16736 14085 -16123 13916 -15521 13710 -14927 13474
--14362 13230 -13836 12994 -13358 12771 -12911 12548 -12505 12310 -12135 12059
--11799 11815 -11497 11583 -11222 11370 -10983 11167 -10789 10965 -10648 10766
--10532 10579 -10435 10410 -10350 10256 -10284 10120 -10259 9994 -10282 9884
--10322 9787 -10362 9705 -10393 9636 -10421 9581 -10481 9547 -10571 9529
--10662 9528 -10737 9532 -10787 9542 -10828 9562 -10872 9604 -10927 9662
--10971 9728 -10986 9796 -10976 9857 -10942 9924 -10896 10006 -10841 10099
--10765 10194 -10656 10280 -10521 10353 -10360 10422 -10172 10497 -9962 10575
--9725 10645 -9462 10702 -9176 10743 -8862 10772 -8518 10793 -8142 10811
--7739 10813 -7321 10801 -6892 10775 -6442 10734 -5960 10675 -5445 10603
--4914 10517 -4377 10420 -3847 10317 -3314 10199 -2742 10060 -2152 9905
--1556 9739 -974 9571 -418 9406 132 9236 697 9048 1273 8844 1835 8637 2370 8441
-2870 8259 3347 8084 3813 7897 4272 7705 4705 7521 5104 7355 5466 7211 5796 7085
-6096 6960 6367 6844 6604 6743 6817 6666 7004 6614 7167 6583 7286 6568 7367 6573
-7425 6597 7470 6645 7500 6715 7520 6809 7511 6923 7473 7060 7422 7220 7361 7400
-7294 7602 7216 7826 7116 8069 7010 8332 6888 8617 6755 8928 6638 9258 6503 9616
-6316 9999 6093 10396 5875 10824 5680 11278 5576 11731 5495 12220 5295 12779
-5410 13425 4858 13989 4204 14468 4487 15188 5562 15715 6103 16471 5592 17333
-5033 17615 5559 17864 7403 18738 10068 19712 12560 19948 13832 19519 13707 19095
-13624 18953 15670 18940 20775 18380 27782 17014 34285 15579 38321 14480
-39289 13076 37738 10766 34521 7805 30188 5008 24953 2787 18955 989 12473 -508
-6135 -1656 802 -2250 -3123 -2280 -5703 -1908 -7233 -1299 -8044 -542 -8322 515
--8180 2034 -7727 3940 -7119 6024 -6561 8072 -6239 9892 -6255 11286 -6628 12143
--7324 12530 -8248 12620 -9310 12574 -10417 12479 -11513 12359 -12572 12219
--13568 12064 -14506 11906 -15383 11753 -16195 11613 -16947 11493 -17636 11400
--18288 11327 -18891 11273 -19442 11230 -19940 11197
-61: 9906136 -5945208 7446 4592 7798 4427 8218 4232 8674 4019 9158 3793
-9666 3563 10192 3329 10736 3084 11318 2834 11928 2572 12540 2309 13170 2045
-13820 1785 14470 1525 15160 1256 15870 988 16560 726 17270 470 17960 223
-18670 -22 19390 -268 20120 -503 20840 -726 21540 -932 22200 -1123 22880 -1303
-23540 -1481 24210 -1640 24850 -1775 25430 -1883 25970 -1967 26480 -2033
-27000 -2088 27490 -2119 27900 -2111 28230 -2057 28480 -1969 28700 -1854
-28890 -1738 29060 -1577 29100 -1303 28890 -966 28560 -651 28400 -361 28260 40
-27800 656 26830 1421 25560 2204 24350 2937 23020 3802 21020 5030 18300 6597
-15270 8258 12660 9792 10850 11102 9840 12250 8930 13379 8470 14408 6980 15486
-5950 16222 5380 16696 4960 16924 4390 16968 3510 16939 2390 16920 1250 16891
-190 16813 -780 16684 -1740 16549 -2800 16404 -4010 16188 -5290 15849 -6610 15406
--7860 14929 -9030 14446 -10120 13980 -11250 13527 -12570 13076 -14120 12611
--16060 12032 -18400 11251 -20900 10352 -23260 9504 -25300 8823 -27010 8326
--28340 8015 -29300 7871 -30010 7838 -30630 7838 -31240 7859 -31750 7917
--32030 8021 -31940 8162 -31590 8329 -31280 8515 -31120 8719 -31140 8932
--31230 9122 -31270 9257 -31230 9348 -31130 9456 -31030 9643 -30970 9924
--31020 10298 -31210 10769 -31520 11308 -31920 11857 -32340 12367 -32710 12815
--33000 13209 -33260 13589 -33470 13988 -33674 14399 -33866 14810 -34049 15202
--34298 15557 -34332 15950 -34352 16343 -34316 16675 -34176 16916 -33949 17086
--33674 17213 -33393 17300 -33100 17359 -32741 17424 -32177 17515 -31411 17635
--30548 17729 -29627 17744 -28683 17674 -27696 17562 -26630 17498 -25545 17537
--24516 17681 -23574 17877 -22699 18035 -21869 18085 -21120 18032 -20444 17920
--19862 17795 -19340 17676 -18851 17551 -18394 17406 -18002 17236 -17656 17054
--17364 16842 -17197 16562 -17140 16230 -17049 15890 -16789 15581 -16300 15316
--15587 15102 -14694 14925 -13771 14787 -12886 14708 -11946 14712 -10860 14787
--9610 14919 -8132 15082 -6544 15253 -5019 15406 -3666 15558 -2561 15743
--1677 15989 -853 16288 -163 16639 169 17013 -28 17412 -702 17834 -1824 18297
--3562 18825 -5867 19399 -8450 19985 -10996 20564 -13431 21183 -15463 21725
--17003 22448 -19194 23442 -21939 24549 -25049 25473 -28196 25929 -30986 25803
--33162 25259 -34903 24757 -36646 24939 -38874 26339 -41824 29116 -45379 32951
--48961 37056 -51944 40378 -54376 41896 -57227 40964 -61734 37560 -67957 32450
--74299 27518 -78636 25564 -79914 27310 -78903 31788 -77818 37320 -79289 42101
--85149 44390 -94718 42551 -102936 35662 -101934 25111 -92344 16173 -76811 9797
--60640 8335 -41395 12167 -6712 19279 -19607 16426 -43898 14173 -48763 12110
--38685 6887 -25599 1223 -15286 -3730 -36912 10127 14661 21353 12090 5377
-20366 -5097 2190 19422 7370 7049 31944 2851 37972 16541 39414 -1785 31065 -13664
-23881 -16198 15547 -15647 6624 -15244 -527 -16697 -3021 -21651 -2644 -24965
--2733 -19695 -3457 -10514 -4963 -1916 -5798 1979 -6306 4038 -6351 3856
--5598 2221 -4590 188 -3688 -1508 -3025 -2564 -2547 -2991 -2144 -2950 -1768 -2647
--1405 -2223 -1087 -1744 -848 -1177 -806 -443 -1090 515 -1565 1640 -1909 2781
--1942 3790 -1701 4616 -1257 5285 -622 5845 181 6338 1142 6820 2239 7300
-3405 7776 4764 8214 6469 8586 8389 8863 10163 9017 11486 9054 12277 9029
-12558 8998 12420 8997 11963 9048 11209 9166 10226 9343 9147 9538 7762 9694
-5643 9784 2906 9805 143 9783 -2203 9723 -4033 9623 -5339 9494 -6047 9361
--6191 9237 -5956 9145 -5485 9063 -4863 8991 -4005 8902 -2751 8805 -1206 8688
-401 8531 1846 8343 3023 8138 3965 7913 4732 7667 5324 7393 1644 6948 6133 6648
-7923 6180 7161 5602 6793 4956 6629 4228 6476 3467 6284 2752 6028 2092 5699 1441
-5296 762 4816 62 4276 -599 3697 -1171 3094 -1657 2455 -2073 1787 -2438
-1086 -2750 327 -3004 -511 -3188 -1439 -3298 -2459 -3326 -3599 -3260 -4847 -3104
--6165 -2883 -7524 -2620 -8884 -2322 -10284 -1981 -11770 -1571 -13350 -1099
--14933 -582 -16439 -38 -17844 526 -19171 1124 -20466 1771 -21737 2467
--22936 3183 -24029 3905 -24995 4617 -25844 5334 -26587 6079 -27240 6851
--27783 7615 -28226 8346 -28563 9035 -28804 9697 -28916 10347 -28912 10978
--28806 11572 -28642 12121 -28419 12620 -28131 13068 -27743 13472 -27254 13833
--26708 14146 -26127 14415 -25530 14643 -24903 14825 -24221 14955 -23575 15051
--22737 15057 -21924 15063 -21245 15050 -20561 14999 -19837 14906 -19096 14772
--18355 14612 -17648 14441 -16977 14263 -16339 14073 -15722 13852 -15120 13610
--14548 13361 -14016 13112 -13530 12872 -13085 12633 -12671 12383 -12304 12128
--11972 11879 -11676 11641 -11414 11417 -11184 11204 -11006 10997 -10868 10794
--10765 10606 -10683 10436 -10617 10278 -10574 10139 -10571 10013 -10609 9902
--10662 9806 -10719 9726 -10773 9657 -10831 9607 -10910 9574 -11011 9559
--11110 9559 -11201 9569 -11269 9585 -11330 9615 -11383 9662 -11441 9724
--11485 9793 -11507 9867 -11503 9942 -11473 10020 -11426 10110 -11362 10208
--11271 10306 -11154 10400 -11007 10486 -10824 10568 -10629 10651 -10404 10735
--10145 10811 -9854 10875 -9539 10923 -9186 10958 -8791 10981 -8399 11007
--7938 11010 -7499 11002 -7037 10982 -6544 10941 -6024 10883 -5475 10810
--4905 10723 -4327 10623 -3742 10510 -3155 10384 -2550 10240 -1929 10078
--1298 9904 -676 9725 -76 9545 509 9355 1100 9153 1700 8937 2283 8720 2839 8508
-3360 8303 3853 8099 4327 7889 4778 7685 5201 7491 5605 7307 5965 7134 6281 6974
-6553 6828 6784 6701 6996 6591 7184 6497 7338 6418 7434 6354 7492 6311 7534 6301
-7575 6324 7608 6371 7593 6431 7503 6500 7355 6580 7199 6687 7089 6832 7031 7013
-7003 7217 6964 7433 6857 7659 6669 7898 6422 8163 6141 8460 5869 8786 5617 9141
-5380 9515 5159 9911 4960 10334 4782 10788 4628 11264 4491 11697 4121 12300
-4288 13120 3426 13662 2529 14102 2521 14602 3367 15064 4187 15715 4482 16500
-4614 17173 5128 18005 6161 19214 7474 20359 8608 20891 9167 20818 9370 20533
-10392 20203 13702 19640 19850 18441 27666 16622 34884 14828 39779 13380
-41866 11902 41485 9990 39164 7740 35168 5565 29494 3619 22159 1708 13551 -304
-4874 -2115 -1996 -2974 -6280 -2700 -8288 -1627 -8816 -246 -8681 1076 -8372 2315
--7978 3683 -7387 5357 -6642 7240 -6030 9030 -5809 10440 -6030 11353 -6603 11823
--7408 12000 -8341 12051 -9328 12079 -10336 12121 -11331 12161 -12315 12176
--13265 12152 -14180 12088 -15047 11996 -15865 11884 -16629 11769 -17334 11662
--17993 11566 -18602 11482 -19156 11413 -19665 11356
-62: 9937556 -5936268 7314 4635 7668 4470 8082 4271 8537 4057 9020 3834
-9521 3603 10036 3371 10576 3132 11140 2883 11740 2625 12360 2361 12980 2100
-13600 1844 14250 1588 14930 1323 15620 1058 16310 796 17010 541 17680 299
-18380 62 19070 -179 19800 -410 20510 -634 21190 -837 21830 -1025 22480 -1194
-23130 -1363 23790 -1520 24400 -1652 24980 -1759 25490 -1832 25970 -1885
-26460 -1932 26930 -1957 27330 -1946 27650 -1890 27860 -1786 28020 -1651
-28190 -1514 28320 -1338 28340 -1084 28150 -759 27800 -393 27490 -19 27200 406
-26740 956 25900 1648 24760 2432 23650 3192 22260 4091 20200 5328 17570 6827
-14890 8354 12530 9754 10690 10962 9410 12040 8620 13092 7930 14119 6980 15087
-6020 15836 5220 16403 4500 16753 3690 16881 2790 16879 1780 16843 730 16796
--310 16723 -1300 16612 -2250 16469 -3240 16290 -4330 16066 -5530 15770
--6790 15415 -8050 15015 -9310 14572 -10560 14106 -11830 13629 -13210 13157
--14640 12710 -16320 12189 -18420 11486 -20720 10672 -22900 9907 -24810 9286
--26430 8798 -27730 8469 -28720 8310 -29480 8263 -30110 8252 -30660 8258
--31200 8279 -31550 8333 -31520 8437 -31280 8574 -31030 8736 -30890 8910
--30890 9100 -30970 9283 -31050 9433 -31090 9563 -31120 9709 -31130 9909
--31130 10157 -31210 10476 -31360 10894 -31580 11382 -31870 11877 -32180 12351
--32450 12776 -32690 13169 -32980 13554 -33220 13945 -33447 14337 -33626 14715
--33763 15076 -33862 15421 -33930 15759 -33987 16106 -33925 16420 -33782 16672
--33559 16874 -33276 17033 -32960 17132 -32610 17192 -32197 17244 -31650 17312
--30994 17397 -30245 17474 -29361 17507 -28388 17484 -27398 17429 -26411 17388
--25452 17384 -24523 17433 -23623 17527 -22739 17614 -21901 17655 -21142 17631
--20443 17561 -19820 17470 -19267 17369 -18776 17252 -18311 17115 -17880 16953
--17442 16788 -17044 16603 -16796 16335 -16655 16007 -16477 15684 -16152 15408
--15657 15185 -15002 15009 -14162 14859 -13223 14738 -12271 14659 -11307 14655
--10346 14709 -9305 14821 -7987 14988 -6492 15194 -5086 15403 -3912 15620
--3035 15861 -2376 16138 -1744 16449 -1191 16803 -957 17189 -1188 17610
--1776 18061 -2778 18548 -4443 19102 -6671 19710 -9104 20332 -11486 20952
--13734 21566 -15875 22201 -17645 22920 -19760 23850 -22284 24854 -25122 25717
--28055 26221 -30819 26285 -33242 26018 -35395 25774 -37556 26013 -40078 27123
--43111 29227 -46531 32108 -49933 35211 -52936 37759 -55658 38986 -58735 38414
--62903 36093 -68084 32723 -73137 29627 -76757 28340 -78388 29480 -78459 32646
--78293 36730 -79620 40322 -83811 42007 -90509 40641 -96428 35835 -96926 28624
--90497 21540 -77944 16170 -61982 13990 -43429 14562 -23246 15632 -24462 14735
--34582 13446 -37499 11337 -32372 7214 -25298 1999 -22092 -2524 -21881 3455
--273 5967 536 3168 7197 -2986 22357 5453 32769 8621 20345 8310 45475 21512
-48341 -7461 33697 -18398 26676 -17225 15826 -15514 3520 -14970 -6950 -16419
--7992 -27310 -3943 -37127 -2982 -25992 -3690 -9701 -4803 2136 -6001 7860
--7536 8650 -6860 7200 -5483 4690 -4023 2106 -2828 93 -2011 -1135 -1511 -1679
--1163 -1754 -848 -1607 -499 -1426 -175 -1280 -49 -1063 -351 -548 -1213 416
--2354 1777 -3172 3212 -3386 4404 -3112 5266 -2609 5869 -1946 6314 -1107 6697
-6 7111 1457 7607 3243 8178 5400 8763 7880 9269 10457 9598 12756 9692 14446 9560
-15365 9292 15511 9010 15019 8794 14061 8711 12786 8804 11311 9061 9678 9404
-7782 9724 5442 9951 2718 10064 -82 10077 -2656 9995 -4823 9821 -6451 9601
--7439 9394 -7769 9248 -7527 9164 -6822 9105 -5707 9045 -4206 8964 -2318 8858
--179 8723 1961 8554 3864 8364 5366 8178 6401 7996 6973 7802 7100 7551 6813 7199
-6207 6703 5497 6108 6258 5526 6799 4855 7100 4090 7208 3300 7144 2544 6917 1811
-6558 1078 6097 328 5556 -417 4963 -1100 4354 -1702 3743 -2222 3117 -2676
-2480 -3073 1804 -3411 1065 -3683 231 -3879 -718 -3981 -1790 -3990 -2989 -3903
--4307 -3725 -5714 -3486 -7182 -3200 -8679 -2874 -10219 -2498 -11821 -2061
--13468 -1568 -15114 -1024 -16703 -446 -18201 159 -19640 802 -21006 1487
--22328 2211 -23569 2957 -24706 3719 -25716 4482 -26610 5256 -27390 6044
--28062 6848 -28618 7642 -29069 8410 -29405 9144 -29631 9851 -29732 10535
--29718 11191 -29610 11804 -29423 12373 -29166 12890 -28837 13358 -28419 13774
--27916 14145 -27349 14463 -26736 14732 -26085 14956 -25397 15133 -24659 15258
--23878 15338 -23086 15366 -22378 15350 -21637 15310 -20900 15239 -20151 15131
--19387 14989 -18634 14820 -17908 14636 -17209 14437 -16548 14226 -15911 13990
--15298 13741 -14722 13482 -14186 13224 -13694 12967 -13248 12710 -12826 12452
--12463 12191 -12137 11935 -11846 11692 -11594 11458 -11385 11236 -11216 11023
--11088 10818 -10994 10628 -10927 10457 -10888 10296 -10872 10154 -10885 10029
--10936 9918 -11011 9823 -11079 9744 -11161 9678 -11247 9632 -11350 9603
--11461 9588 -11575 9591 -11678 9606 -11767 9631 -11843 9670 -11909 9723
--11971 9789 -12017 9862 -12047 9944 -12045 10031 -12023 10120 -11973 10219
--11899 10323 -11798 10427 -11666 10530 -11507 10628 -11315 10722 -11099 10816
--10859 10906 -10584 10989 -10269 11059 -9919 11114 -9519 11157 -9073 11186
--8596 11204 -8169 11221 -7694 11220 -7191 11202 -6660 11164 -6103 11105
--5515 11033 -4899 10943 -4273 10838 -3638 10719 -3000 10584 -2359 10432
--1695 10263 -1027 10081 -364 9890 278 9692 903 9488 1521 9268 2148 9039
-2755 8809 3330 8579 3870 8349 4387 8119 4861 7889 5310 7671 5731 7461 6138 7253
-6499 7051 6789 6861 7028 6698 7228 6558 7418 6435 7584 6317 7691 6208 7724 6114
-7723 6050 7728 6032 7759 6051 7765 6092 7679 6133 7468 6168 7180 6218 6934 6301
-6791 6441 6769 6624 6793 6827 6771 7031 6620 7232 6323 7446 5915 7691 5471 7977
-5065 8298 4732 8644 4485 9010 4302 9396 4149 9812 3981 10266 3772 10754
-3481 11279 3098 11837 3037 12628 1803 13198 625 13559 436 13853 1336 14183
-2689 14736 3830 15586 4493 16690 4676 18112 4472 19777 4059 21304 3639 22286
-3444 22626 3889 22450 5868 21768 10456 20390 18104 18116 27583 15274 36103 12802
-42087 11122 45325 9983 46157 8967 44833 7884 41304 6734 35268 5378 26456 3458
-15174 722 3190 -2235 -5444 -3407 -9667 -2495 -10422 -269 -9324 2241 -7949 4217
--7189 5409 -6965 6231 -6583 7376 -5895 8896 -5409 10233 -5595 10881 -6374 10886
--7421 10601 -8456 10352 -9378 10307 -10189 10484 -10948 10811 -11685 11185
--12449 11527 -13232 11786 -14036 11944 -14831 12013 -15607 12005 -16348 11951
--17051 11868 -17710 11775 -18318 11681 -18872 11593 -19382 11517
-63: 9968766 -5927271 7163 4684 7519 4513 7930 4319 8382 4107 8860 3880
-9350 3652 9860 3423 10380 3188 10950 2942 11540 2686 12130 2423 12760 2166
-13370 1914 14000 1663 14660 1402 15340 1140 16020 879 16710 626 17370 388
-18040 160 18730 -75 19430 -305 20130 -525 20800 -726 21420 -904 22040 -1068
-22670 -1228 23310 -1383 23920 -1508 24470 -1614 24950 -1677 25410 -1718
-25860 -1755 26320 -1773 26690 -1759 27000 -1698 27180 -1577 27300 -1426
-27430 -1270 27520 -1086 27520 -834 27320 -508 26960 -109 26540 315 26150 768
-25640 1294 24840 1954 23810 2716 22790 3461 21470 4346 19470 5557 17000 6986
-14560 8415 12410 9715 10570 10832 9170 11839 8270 12835 7580 13807 6800 14699
-5890 15440 4980 16051 4080 16473 3180 16672 2230 16718 1240 16706 240 16677
--800 16627 -1810 16540 -2760 16400 -3730 16206 -4750 15975 -5880 15706
--7080 15402 -8330 15054 -9620 14647 -10920 14199 -12270 13720 -13670 13244
--15020 12825 -16530 12349 -18440 11706 -20560 10962 -22580 10271 -24330 9701
--25860 9234 -27130 8902 -28110 8730 -28890 8663 -29530 8636 -30100 8621
--30660 8615 -31040 8637 -31100 8711 -30940 8825 -30740 8962 -30650 9110
--30660 9279 -30720 9452 -30830 9606 -30920 9755 -31010 9929 -31090 10136
--31160 10365 -31250 10653 -31400 11032 -31590 11472 -31800 11921 -32040 12354
--32240 12753 -32440 13133 -32690 13509 -32960 13892 -33189 14269 -33352 14623
--33458 14957 -33513 15272 -33550 15593 -33572 15901 -33515 16194 -33381 16441
--33160 16656 -32876 16828 -32538 16939 -32153 17006 -31712 17055 -31178 17110
--30585 17176 -29911 17238 -29068 17274 -28109 17279 -27136 17258 -26200 17233
--25322 17212 -24469 17211 -23607 17239 -22735 17273 -21901 17286 -21139 17264
--20421 17208 -19769 17134 -19196 17044 -18683 16933 -18199 16804 -17731 16653
--17226 16508 -16748 16342 -16421 16094 -16199 15784 -15943 15485 -15557 15239
--15056 15053 -14429 14913 -13627 14789 -12699 14686 -11743 14622 -10797 14618
--9932 14664 -9039 14769 -7858 14939 -6481 15159 -5201 15405 -4184 15664
--3494 15947 -3020 16254 -2554 16588 -2146 16955 -2014 17359 -2290 17803
--2843 18272 -3773 18778 -5359 19352 -7478 19986 -9773 20640 -12020 21287
--14184 21923 -16305 22565 -18186 23294 -20311 24176 -22707 25111 -25337 25944
--28099 26518 -30811 26752 -33331 26718 -35707 26660 -38109 26913 -40809 27752
--43932 29274 -47340 31366 -50708 33669 -53781 35626 -56639 36673 -59749 36446
--63581 34985 -68018 32819 -72242 30816 -75430 29906 -77286 30590 -77954 32764
--78083 35736 -78823 38470 -81423 39897 -85996 39201 -90404 36105 -91314 31167
--86596 25745 -76065 21184 -61556 18556 -45626 17393 -36003 13169 -31147 12752
--31584 12391 -30495 11164 -26049 8654 -20225 5435 -16018 1635 -20138 -11667
--9315 -14117 -4113 -18285 5346 -21007 37588 8013 12392 11973 44923 8193
-39513 11883 47239 3586 38481 -7983 33004 -8996 17102 -10248 844 -11506
--16294 -9935 -13970 -32097 -2840 -59477 -2360 -33126 -4244 -5778 -5976 9427
--7357 14505 -7956 13018 -6772 9989 -4809 6498 -2872 3458 -1422 1369 -577 270
--210 -129 -55 -155 117 -112 430 -211 815 -487 944 -742 356 -579 -1281 331
--3495 1966 -4966 3759 -5270 5105 -4779 5964 -4162 6510 -3494 6859 -2651 7162
--1387 7553 474 8094 2979 8761 6057 9438 9517 9979 12997 10244 16011 10170
-18141 9807 19134 9300 18993 8823 17938 8491 16288 8397 14333 8574 12217 8992
-10006 9516 7636 10000 5047 10334 2240 10467 -659 10411 -3500 10189 -6044 9865
--8030 9536 -9266 9291 -9676 9162 -9301 9114 -8224 9086 -6524 9038 -4306 8966
--1683 8862 1123 8734 3828 8579 6150 8417 7861 8274 8841 8142 9057 7983
-8564 7735 7483 7336 6008 6755 5587 6155 6166 5508 6957 4781 7576 3986 7921 3170
-7994 2357 7823 1535 7455 710 6954 -107 6375 -887 5762 -1596 5149 -2238
-4558 -2808 3967 -3317 3365 -3755 2717 -4122 1989 -4402 1134 -4584 147 -4667
--997 -4648 -2280 -4541 -3692 -4356 -5210 -4109 -6801 -3804 -8433 -3447
--10112 -3035 -11826 -2570 -13558 -2049 -15278 -1477 -16949 -865 -18547 -213
--20078 471 -21528 1197 -22915 1951 -24206 2735 -25388 3536 -26444 4348
--27385 5176 -28196 6008 -28893 6850 -29464 7681 -29914 8490 -30255 9266
--30467 10015 -30555 10733 -30529 11417 -30406 12054 -30197 12640 -29909 13177
--29543 13663 -29096 14093 -28568 14469 -27973 14792 -27324 15061 -26625 15278
--25877 15450 -25084 15575 -24256 15649 -23430 15665 -22718 15635 -21978 15573
--21217 15481 -20445 15358 -19669 15204 -18895 15024 -18154 14822 -17425 14606
--16740 14375 -16090 14127 -15465 13864 -14879 13595 -14340 13324 -13839 13053
--13390 12783 -12979 12513 -12612 12246 -12291 11984 -12005 11734 -11769 11491
--11573 11261 -11417 11045 -11303 10838 -11221 10645 -11169 10471 -11157 10310
--11167 10167 -11203 10040 -11270 9930 -11360 9837 -11452 9760 -11559 9696
--11671 9656 -11796 9628 -11922 9618 -12052 9625 -12172 9646 -12274 9678
--12370 9725 -12448 9784 -12518 9856 -12571 9937 -12603 10028 -12609 10123
--12587 10224 -12537 10332 -12453 10444 -12341 10557 -12198 10670 -12024 10778
--11821 10883 -11592 10989 -11336 11088 -11043 11178 -10699 11257 -10307 11317
--9865 11368 -9359 11399 -8823 11419 -8388 11445 -7894 11451 -7361 11436
--6789 11400 -6190 11345 -5553 11271 -4892 11177 -4216 11067 -3538 10942
--2852 10800 -2160 10639 -1451 10461 -738 10268 -40 10066 640 9852 1304 9631
-1965 9395 2619 9150 3245 8901 3839 8653 4402 8401 4940 8147 5427 7899 5876 7660
-6299 7426 6701 7192 7054 6964 7320 6755 7526 6574 7702 6412 7881 6264 8015 6119
-8071 5985 8038 5875 7984 5801 7956 5770 7956 5775 7904 5793 7726 5804 7410 5812
-7038 5841 6748 5921 6610 6061 6608 6240 6636 6431 6559 6609 6296 6784 5853 6977
-5305 7208 4754 7486 4294 7799 3964 8131 3755 8479 3624 8849 3491 9249 3292 9690
-2987 10175 2557 10695 2032 11243 1506 12131 -25 12650 -1272 12889 -1358 13017
--176 13235 1663 13769 3320 14772 4127 16274 3772 18212 2371 20354 447 22307
--1320 23704 -2340 24366 -2114 24257 151 23251 5674 21047 15394 17422 28039 12964
-38451 9618 45244 7971 49052 7610 50620 7845 50151 8178 47281 8315 41332 7900
-31532 6314 17438 2813 687 -2187 -9614 -3647 -12941 -1645 -11526 2207 -8129 6146
--5300 8736 -4546 9406 -5386 9018 -5652 9434 -4949 10839 -4516 11931 -5397 11609
--7166 10286 -8998 8872 -10400 7977 -11297 7766 -11832 8124 -12205 8822
--12554 9639 -12973 10414 -13493 11051 -14098 11518 -14758 11816 -15444 11972
--16137 12022 -16810 12000 -17451 11937 -18042 11851 -18597 11760 -19104 11673
-64: 9999768 -5918219 7002 4738 7350 4565 7760 4373 8210 4159 8670 3936
-9160 3708 9650 3484 10180 3254 10720 3011 11310 2753 11890 2499 12500 2241
-13110 1997 13710 1751 14370 1491 15030 1230 15700 973 16370 726 17020 493
-17680 272 18340 41 19030 -186 19710 -400 20360 -599 20960 -766 21570 -922
-22170 -1078 22790 -1225 23370 -1351 23920 -1447 24360 -1500 24800 -1534
-25220 -1560 25650 -1573 26010 -1550 26290 -1481 26440 -1350 26530 -1186
-26630 -1017 26680 -818 26650 -563 26450 -235 26060 181 25600 633 25100 1115
-24550 1644 23750 2291 22770 3030 21830 3751 20590 4601 18730 5755 16440 7106
-14230 8446 12250 9659 10480 10702 9030 11649 8040 12595 7280 13522 6510 14354
-5610 15067 4660 15687 3690 16145 2720 16390 1760 16486 790 16517 -220 16521
--1250 16504 -2270 16443 -3240 16320 -4200 16127 -5210 15897 -6290 15646
--7450 15371 -8670 15062 -9940 14682 -11250 14257 -12620 13788 -14010 13329
--15290 12931 -16700 12491 -18470 11906 -20400 11228 -22260 10602 -23880 10079
--25310 9636 -26520 9315 -27480 9130 -28280 9038 -28940 8992 -29500 8957
--30090 8925 -30510 8925 -30640 8976 -30550 9073 -30450 9187 -30400 9316
--30430 9466 -30510 9624 -30630 9775 -30730 9935 -30840 10118 -30950 10331
--31070 10550 -31180 10818 -31340 11166 -31510 11569 -31700 11980 -31880 12376
--32050 12747 -32210 13103 -32430 13466 -32690 13835 -32903 14196 -33055 14534
--33133 14844 -33163 15139 -33179 15436 -33173 15725 -33109 15993 -32970 16228
--32758 16438 -32472 16611 -32125 16731 -31727 16804 -31270 16855 -30744 16907
--30188 16962 -29560 17013 -28762 17048 -27838 17060 -26895 17053 -26004 17040
--25174 17015 -24367 16992 -23538 16987 -22687 16987 -21865 16972 -21100 16939
--20378 16883 -19704 16810 -19113 16721 -18572 16612 -18063 16484 -17560 16340
--17010 16210 -16480 16065 -16086 15838 -15783 15555 -15453 15285 -15015 15069
--14497 14913 -13884 14803 -13111 14706 -12217 14627 -11287 14581 -10379 14588
--9597 14642 -8810 14751 -7754 14924 -6514 15154 -5366 15415 -4487 15702
--3937 16010 -3603 16341 -3282 16701 -3007 17093 -2988 17518 -3325 17981
--3880 18468 -4786 18991 -6292 19581 -8290 20233 -10451 20902 -12579 21568
--14664 22219 -16743 22873 -18720 23585 -20859 24429 -23166 25326 -25660 26163
--28284 26808 -30940 27189 -33496 27336 -35958 27415 -38472 27659 -41254 28264
--44428 29322 -47847 30809 -51229 32505 -54352 34029 -57244 34956 -60272 34998
--63811 34157 -67723 32781 -71391 31423 -74312 30694 -76303 31021 -77280 32455
--77435 34589 -77536 36704 -78822 38021 -81754 37917 -84954 36070 -85856 32627
--82305 28285 -73864 23969 -62238 20410 -50130 17426 -41436 13741 -34981 12411
--30926 11824 -27027 10741 -22325 8342 -17473 4081 -14186 -3164 -14336 -15962
--8776 -23878 -2684 -29527 5627 -28442 6367 742 -37363 7109 116403 9812
-43350 10022 48601 5361 42471 -2989 40455 1351 14630 -2947 -470 -7668 -27275 4430
--18180 -33029 2333 -102813 -2683 -35797 -6405 4084 -8257 18933 -9308 20404
--8500 16035 -6442 11406 -3617 7081 -1106 3843 524 2042 1222 1485 1234 1566
-975 1783 878 1807 1146 1430 1709 670 2140 -181 1536 -566 -1059 152 -5071 2167
--7369 4478 -7471 5888 -6336 6648 -5562 7163 -4968 7452 -4264 7713 -2939 8125
--678 8738 2594 9479 6718 10161 11346 10598 15966 10644 19907 10289 22560 9657
-23557 8975 22909 8441 21025 8184 18470 8261 15700 8665 12911 9310 10121 10036
-7305 10658 4466 11020 1563 11028 -1496 10715 -4701 10199 -7717 9652 -10094 9222
--11502 8990 -11845 8929 -11154 8937 -9553 8950 -7177 8929 -4194 8887 -832 8825
-2625 8740 5831 8634 8439 8525 10198 8429 10944 8336 10649 8189 9432 7923
-7514 7471 5187 6823 5274 6225 6198 5537 7290 4765 8185 3942 8734 3081 8929 2183
-8808 1260 8447 349 7935 -525 7351 -1343 6747 -2104 6167 -2808 5621 -3442
-5079 -4005 4510 -4484 3873 -4864 3125 -5130 2226 -5290 1161 -5347 -83 -5316
--1481 -5206 -3010 -5021 -4653 -4764 -6375 -4432 -8133 -4039 -9938 -3594
--11764 -3095 -13593 -2541 -15399 -1935 -17159 -1283 -18863 -588 -20484 140
--22024 901 -23481 1692 -24836 2511 -26076 3357 -27180 4217 -28165 5096
--29012 5975 -29731 6860 -30315 7732 -30773 8581 -31108 9403 -31308 10189
--31386 10944 -31346 11657 -31203 12319 -30964 12926 -30644 13479 -30246 13982
--29769 14426 -29205 14810 -28583 15134 -27892 15399 -27143 15612 -26340 15780
--25496 15899 -24618 15964 -23745 15971 -23039 15919 -22288 15839 -21512 15726
--20722 15587 -19926 15419 -19139 15219 -18369 15003 -17627 14769 -16919 14518
--16246 14255 -15617 13980 -15019 13700 -14471 13415 -13969 13129 -13523 12847
--13111 12567 -12746 12292 -12432 12022 -12161 11766 -11931 11517 -11748 11282
--11606 11059 -11507 10851 -11441 10657 -11418 10478 -11423 10319 -11457 10174
--11518 10046 -11605 9939 -11715 9846 -11831 9773 -11969 9714 -12104 9676
--12247 9653 -12392 9648 -12539 9659 -12679 9686 -12802 9726 -12909 9780
--13002 9847 -13080 9924 -13143 10017 -13176 10115 -13192 10221 -13170 10331
--13119 10450 -13024 10572 -12899 10694 -12746 10816 -12560 10936 -12346 11054
--12107 11170 -11832 11280 -11517 11379 -11145 11465 -10716 11535 -10221 11590
--9664 11625 -9067 11646 -8615 11683 -8101 11696 -7540 11686 -6929 11653
--6281 11600 -5591 11521 -4885 11427 -4166 11313 -3443 11182 -2698 11030
--1955 10859 -1199 10671 -439 10469 293 10254 1012 10025 1719 9785 2424 9532
-3113 9269 3753 9001 4368 8732 4962 8460 5515 8184 6023 7915 6477 7648 6903 7385
-7297 7128 7625 6881 7871 6655 8054 6452 8222 6257 8381 6077 8478 5909 8472 5761
-8378 5643 8275 5558 8207 5508 8154 5481 8020 5465 7748 5447 7358 5441 6957 5471
-6675 5556 6552 5694 6526 5858 6467 6018 6245 6166 5823 6315 5239 6495 4609 6720
-4055 6991 3642 7291 3393 7604 3262 7925 3160 8263 2996 8638 2687 9054 2223 9516
-1616 10023 921 10562 -250 11516 -1853 11985 -2855 12127 -2605 12159 -1121 12341
-945 12933 2693 14130 3311 15967 2383 18303 89 20817 -2845 23091 -5538 24756
--7320 25609 -7755 25548 -6054 24372 -463 21563 11504 16474 29684 9525
-41991 5250 48494 4072 51760 4977 53386 6743 53582 8556 51675 10015 46508 10777
-36780 10079 20690 6244 -3633 -2609 -14648 -3910 -15763 -168 -11163 5784
--4673 11474 -76 14665 -108 14068 -3794 11162 -5129 10798 -3687 13077 -2697 14776
--4683 13263 -8107 10009 -11144 7013 -13045 5262 -13884 4834 -14046 5391
--13926 6500 -13788 7802 -13786 9048 -13969 10101 -14323 10909 -14801 11470
--15368 11819 -15984 12001 -16606 12066 -17213 12052 -17786 11991 -18322 11910
--18822 11819
-65: 10030570 -5909114 6820 4794 7170 4622 7570 4433 8010 4218 8460 4001
-8950 3775 9440 3555 9930 3327 10480 3086 11050 2834 11630 2582 12220 2329
-12810 2089 13410 1847 14040 1590 14690 1337 15350 1079 16000 835 16640 613
-17260 396 17930 171 18580 -48 19250 -262 19890 -452 20470 -618 21040 -764
-21630 -911 22230 -1053 22790 -1172 23300 -1265 23740 -1309 24140 -1331
-24540 -1348 24940 -1354 25280 -1321 25520 -1247 25660 -1108 25720 -934
-25780 -752 25810 -540 25750 -279 25530 52 25140 470 24650 937 24090 1441
-23500 1980 22680 2626 21720 3348 20810 4044 19660 4854 17940 5940 15860 7208
-13830 8461 12020 9596 10340 10577 8920 11473 7850 12374 7000 13262 6170 14054
-5270 14736 4290 15340 3290 15808 2300 16082 1330 16222 370 16294 -630 16332
--1650 16349 -2690 16318 -3680 16212 -4650 16033 -5650 15814 -6710 15576
--7840 15329 -9010 15044 -10270 14688 -11550 14284 -12900 13837 -14270 13401
--15500 13024 -16830 12616 -18460 12080 -20250 11466 -21960 10897 -23450 10420
--24780 10009 -25920 9697 -26870 9503 -27660 9390 -28340 9318 -28910 9263
--29500 9215 -29960 9198 -30140 9232 -30140 9309 -30110 9410 -30120 9521
--30190 9654 -30310 9797 -30410 9943 -30520 10105 -30650 10292 -30770 10503
--30890 10717 -31030 10969 -31180 11291 -31360 11663 -31550 12043 -31700 12406
--31840 12750 -31990 13082 -32180 13426 -32410 13780 -32601 14125 -32736 14445
--32798 14738 -32807 15017 -32806 15292 -32785 15563 -32710 15811 -32564 16032
--32353 16228 -32067 16397 -31721 16517 -31319 16594 -30855 16653 -30340 16702
--29804 16752 -29203 16798 -28446 16826 -27568 16835 -26666 16832 -25813 16822
--25015 16798 -24240 16767 -23434 16747 -22605 16724 -21793 16690 -21030 16647
--20306 16581 -19624 16507 -19011 16410 -18446 16299 -17904 16168 -17372 16031
--16793 15910 -16231 15779 -15782 15576 -15408 15325 -15009 15084 -14527 14896
--13989 14769 -13385 14680 -12639 14609 -11780 14552 -10892 14526 -10035 14556
--9320 14625 -8621 14743 -7680 14925 -6580 15159 -5568 15433 -4808 15734
--4372 16058 -4141 16410 -3941 16793 -3790 17208 -3878 17661 -4278 18143
--4872 18646 -5774 19182 -7211 19783 -9089 20447 -11126 21128 -13154 21805
--15164 22465 -17193 23128 -19260 23823 -21403 24635 -23648 25506 -26046 26349
--28579 27065 -31178 27567 -33735 27857 -36216 28044 -38745 28287 -41537 28713
--44699 29431 -48108 30466 -51484 31707 -54615 32910 -57482 33746 -60386 33970
--63660 33546 -67176 32683 -70442 31711 -73170 31053 -75231 31087 -76392 31954
--76537 33440 -76162 35064 -76433 36274 -78038 36569 -80166 35547 -80836 33063
--78086 29387 -71466 25142 -62375 21006 -52725 17315 -44400 14085 -37240 12345
--31207 11367 -25769 10048 -20615 7297 -15831 2199 -12151 -5892 -10147 -16654
--7022 -25047 -3775 -29446 -705 -25998 -1423 -9532 -1073 -1326 76910 2364
-60867 3002 58048 8305 47538 3525 36658 10970 -6797 3899 -4748 4770 -19070 6271
--5965 -25868 -475 -166665 -9748 -20129 -10871 18134 -10941 26165 -11350 21822
--9348 15769 -6167 10679 -1964 6034 1279 2994 2992 1926 3321 2445 2660 3362
-1706 3993 1157 4069 1332 3459 2214 2220 3425 681 3511 -530 -49 -302 -7390 2322
--10570 5527 -9864 6699 -7217 7169 -6453 7752 -6104 8003 -5819 8245 -4639 8729
--2040 9448 2035 10239 7306 10843 13308 11031 19340 10706 24476 9959 27790 9049
-28686 8298 27213 7928 24100 7993 20361 8453 16719 9204 13314 10124 10010 11047
-6767 11768 3723 12047 816 11731 -2382 10917 -6127 9934 -9841 9107 -12683 8615
--14163 8457 -14222 8500 -13007 8594 -10723 8671 -7585 8717 -3838 8758
-226 8785 4237 8782 7793 8740 10522 8681 12129 8621 12463 8542 11546 8390
-9559 8098 6834 7618 3811 6945 4779 6355 6306 5639 7812 4838 9004 3968 9751 3022
-10051 2014 9971 993 9620 6 9114 -929 8539 -1814 7977 -2654 7449 -3434 6955 -4132
-6462 -4735 5917 -5230 5264 -5600 4464 -5851 3480 -6001 2297 -6055 931 -6032
--597 -5930 -2263 -5734 -4033 -5447 -5876 -5076 -7761 -4643 -9683 -4160
--11618 -3624 -13548 -3034 -15452 -2389 -17318 -1693 -19125 -960 -20848 -195
--22498 602 -24032 1429 -25461 2290 -26766 3180 -27926 4088 -28951 5016
--29835 5948 -30579 6876 -31181 7792 -31639 8683 -31971 9550 -32162 10378
--32222 11167 -32159 11912 -31991 12601 -31723 13230 -31379 13800 -30937 14317
--30429 14772 -29839 15163 -29177 15488 -28437 15751 -27641 15958 -26786 16118
--25887 16232 -24960 16287 -24046 16278 -23331 16206 -22570 16106 -21779 15974
--20975 15814 -20161 15626 -19352 15412 -18564 15177 -17801 14923 -17072 14655
--16384 14376 -15739 14087 -15140 13791 -14585 13495 -14083 13196 -13634 12901
--13222 12612 -12871 12328 -12561 12051 -12295 11786 -12079 11534 -11910 11294
--11789 11069 -11702 10857 -11663 10660 -11655 10482 -11687 10320 -11747 10175
--11831 10049 -11940 9942 -12075 9853 -12216 9781 -12381 9729 -12542 9693
--12706 9677 -12872 9676 -13040 9692 -13197 9725 -13340 9774 -13462 9835
--13570 9910 -13665 9998 -13730 10097 -13774 10204 -13788 10322 -13769 10444
--13717 10574 -13618 10705 -13480 10837 -13314 10971 -13114 11102 -12889 11233
--12636 11360 -12348 11481 -12012 11592 -11609 11687 -11141 11764 -10597 11824
--9984 11864 -9327 11889 -8858 11935 -8322 11956 -7727 11950 -7072 11924
--6372 11867 -5637 11790 -4889 11692 -4120 11574 -3343 11437 -2542 11275
--1743 11093 -939 10898 -143 10684 635 10454 1397 10208 2158 9952 2904 9679
-3617 9398 4284 9109 4923 8820 5548 8525 6124 8227 6647 7931 7111 7636 7531 7344
-7915 7066 8221 6804 8451 6558 8629 6321 8787 6093 8915 5881 8957 5696 8885 5542
-8744 5415 8600 5312 8482 5229 8353 5165 8124 5112 7768 5078 7339 5074 6955 5117
-6703 5208 6567 5334 6449 5462 6217 5581 5794 5697 5199 5831 4529 6008 3922 6236
-3468 6497 3199 6778 3070 7060 3002 7345 2871 7647 2587 7981 2099 8360 1420 8792
-606 9281 -244 9822 -1996 10791 -3362 11212 -3858 11303 -3214 11325 -1620 11560
-299 12282 1727 13677 1937 15757 584 18330 -2092 21029 -5334 23416 -8284 25123
--10412 25959 -11551 25872 -11143 24730 -7080 21843 5715 15671 33543 4660
-45971 -193 50045 -227 51457 2480 52633 5884 53489 8914 52903 11255 48894 12893
-40063 13399 24699 10812 -10417 -4018 -19352 -3673 -17358 2133 -9203 10233
-1123 17973 8300 22079 6689 19357 -3598 11072 -5993 10273 -1610 15826 1625 20202
--2458 16849 -8684 10625 -13461 5502 -15964 2730 -16697 2060 -16417 2800
--15755 4290 -15111 6028 -14674 7702 -14512 9135 -14607 10258 -14901 11072
--15341 11612 -15862 11931 -16426 12089 -16986 12136 -17532 12110 -18049 12045
--18535 11960
-66: 10061180 -5899960 6630 4855 6960 4687 7370 4496 7790 4289 8250 4069
-8710 3849 9180 3632 9690 3409 10200 3174 10770 2922 11340 2675 11920 2426
-12480 2188 13080 1951 13690 1702 14320 1452 14970 1200 15600 960 16220 744
-16830 530 17470 316 18110 99 18760 -108 19370 -294 19930 -451 20480 -593
-21060 -731 21620 -864 22160 -980 22660 -1062 23070 -1103 23440 -1113 23810 -1123
-24190 -1118 24510 -1080 24720 -996 24830 -851 24880 -668 24900 -476 24900 -255
-24810 14 24580 351 24190 763 23690 1232 23120 1746 22470 2297 21640 2947
-20690 3651 19810 4325 18710 5099 17120 6118 15220 7301 13370 8472 11700 9536
-10120 10459 8750 11312 7650 12170 6720 13022 5830 13783 4890 14436 3900 15019
-2890 15480 1900 15774 930 15949 -30 16051 -1010 16120 -2040 16168 -3070 16161
--4070 16076 -5040 15919 -6060 15714 -7100 15493 -8210 15267 -9360 15006
--10570 14672 -11820 14292 -13140 13870 -14460 13455 -15650 13102 -16930 12724
--18440 12235 -20080 11676 -21650 11156 -23040 10722 -24290 10342 -25360 10047
--26270 9845 -27080 9713 -27740 9619 -28320 9548 -28920 9487 -29390 9456
--29630 9478 -29700 9540 -29740 9625 -29810 9722 -29910 9838 -30060 9970
--30180 10111 -30290 10267 -30420 10454 -30540 10660 -30680 10866 -30810 11106
--30980 11406 -31150 11751 -31340 12105 -31490 12440 -31620 12757 -31740 13068
--31920 13393 -32110 13727 -32292 14055 -32401 14360 -32453 14636 -32452 14900
--32431 15155 -32399 15411 -32315 15645 -32164 15848 -31951 16032 -31671 16190
--31323 16306 -30922 16387 -30463 16448 -29953 16498 -29431 16548 -28848 16587
--28131 16609 -27298 16612 -26439 16606 -25617 16593 -24846 16569 -24095 16535
--23308 16507 -22492 16468 -21692 16423 -20937 16367 -20212 16296 -19522 16217
--18894 16115 -18298 15997 -17730 15865 -17173 15731 -16574 15618 -15989 15498
--15491 15318 -15063 15096 -14609 14885 -14086 14723 -13538 14618 -12936 14553
--12216 14502 -11396 14463 -10557 14463 -9749 14509 -9093 14599 -8468 14733
--7640 14923 -6673 15168 -5792 15448 -5143 15760 -4799 16098 -4653 16465
--4556 16867 -4515 17307 -4693 17781 -5157 18284 -5798 18804 -6707 19350
--8090 19961 -9866 20628 -11799 21319 -13738 22004 -15679 22669 -17660 23338
--19792 24027 -21933 24804 -24141 25648 -26463 26494 -28931 27260 -31489 27858
--34025 28266 -36491 28554 -38988 28810 -41731 29131 -44830 29611 -48178 30318
--51513 31223 -54611 32175 -57415 32923 -60181 33256 -63208 33106 -66390 32570
--69331 31842 -71883 31207 -73954 31002 -75246 31421 -75441 32372 -74810 33557
--74379 34596 -74920 35082 -76051 34557 -76320 32678 -74013 29458 -68737 25332
--61494 20998 -53495 17099 -45805 14014 -38568 12072 -31821 10813 -25692 9293
--20111 6401 -14904 1288 -10438 -6184 -7430 -14961 -5415 -22205 -4068 -25802
--2175 -23509 2008 -14855 15995 -7789 55758 -2642 64213 1872 67688 8579
-60601 11032 7119 9206 -17640 8680 -8982 9627 -8677 -12688 -5807 -46453
--4560 -103869 -9676 -32048 -11115 9827 -10750 20875 -13216 15283 -10769 11842
--6226 8255 270 3543 4332 963 5917 957 5614 3219 3897 5239 1891 6306 703 6448
-689 5696 1821 4133 4284 2030 6462 -244 2792 -1130 -11138 2319 -14539 7128
--12293 7280 -6527 7213 -6626 8172 -6591 8342 -7281 8585 -6553 9222 -3685 10111
-1212 10964 7704 11427 15260 11246 23050 10403 29791 9148 34005 7957 34673 7287
-31870 7357 26877 8045 21574 9093 17145 10261 13406 11442 9730 12533 6040 13323
-2831 13436 242 12561 -2894 10950 -7566 9315 -12465 8186 -15913 7696 -17300 7677
--16793 7870 -14797 8089 -11680 8278 -7729 8458 -3245 8644 1421 8794 5837 8881
-9567 8888 12213 8853 13476 8797 13256 8716 11642 8564 8914 8282 5531 7819
-2045 7171 4249 6591 6579 5858 8613 5007 10147 4045 11093 2973 11485 1851
-11428 739 11067 -328 10540 -1349 9976 -2335 9448 -3265 8969 -4112 8523 -4852
-8059 -5470 7510 -5958 6812 -6326 5933 -6583 4836 -6754 3520 -6836 2013 -6828
-344 -6710 -1447 -6474 -3336 -6134 -5289 -5716 -7293 -5243 -9316 -4717
--11362 -4143 -13406 -3515 -15427 -2832 -17414 -2102 -19335 -1338 -21185 -536
--22940 297 -24580 1163 -26088 2066 -27461 3002 -28684 3958 -29753 4939
--30670 5919 -31437 6897 -32055 7858 -32519 8796 -32841 9708 -33021 10579
--33064 11407 -32978 12181 -32779 12898 -32474 13551 -32091 14140 -31622 14669
--31077 15136 -30451 15530 -29745 15856 -28966 16113 -28118 16315 -27208 16466
--26258 16571 -25284 16615 -24321 16589 -23597 16495 -22825 16374 -22021 16220
--21198 16039 -20367 15831 -19535 15596 -18728 15343 -17944 15068 -17197 14783
--16493 14487 -15844 14182 -15236 13872 -14680 13564 -14177 13252 -13720 12944
--13320 12646 -12974 12352 -12669 12070 -12415 11799 -12214 11541 -12061 11297
--11957 11068 -11896 10854 -11874 10656 -11891 10477 -11946 10313 -12027 10171
--12141 10046 -12278 9942 -12435 9854 -12606 9787 -12796 9738 -12979 9710
--13170 9695 -13362 9702 -13548 9725 -13731 9765 -13895 9821 -14033 9889
--14155 9974 -14260 10073 -14334 10180 -14385 10298 -14405 10426 -14392 10562
--14332 10701 -14228 10843 -14083 10986 -13902 11130 -13690 11277 -13450 11420
--13186 11560 -12883 11692 -12526 11814 -12092 11921 -11585 12006 -10995 12072
--10324 12118 -9605 12147 -9118 12202 -8554 12231 -7921 12233 -7221 12206
--6472 12151 -5694 12074 -4897 11973 -4077 11851 -3237 11704 -2378 11536
--1530 11347 -682 11139 158 10914 985 10666 1805 10405 2613 10128 3398 9840
-4131 9537 4835 9229 5510 8915 6166 8595 6763 8271 7300 7948 7766 7626 8187 7310
-8555 7011 8857 6728 9078 6454 9253 6181 9387 5920 9471 5686 9444 5490 9315 5325
-9138 5181 8961 5046 8786 4927 8562 4827 8231 4754 7803 4720 7374 4728 7019 4781
-6781 4865 6578 4958 6298 5040 5843 5116 5213 5210 4501 5345 3839 5530 3355 5761
-3087 6009 3004 6259 2981 6503 2901 6745 2652 7003 2165 7292 1432 7630 516 8028
--482 8506 -1438 9064 -3406 9973 -4237 10341 -4139 10437 -3250 10536 -1906 10916
--569 11818 203 13389 -57 15604 -1532 18229 -3944 20880 -6644 23119 -8928 24582
--10501 25077 -11511 24663 -11997 23532 -10704 21095 -1914 15351 39670 -1498
-46943 -5723 46577 -4044 45660 866 46720 5708 48668 9265 50053 11448 46592 12639
-35497 12382 17264 8881 -8253 355 -18697 -187 -16916 5378 -6773 14495 7794 24415
-19722 30706 17358 25974 -8090 5609 -9674 6008 2371 19505 11667 31034 2616 23693
--8268 12804 -15279 5047 -18399 1194 -18993 235 -18312 1036 -17203 2730
--16147 4730 -15369 6676 -14939 8369 -14822 9725 -14966 10731 -15290 11427
--15729 11865 -16237 12107 -16755 12211 -17272 12223 -17769 12177 -18241 12102
-67: 10091620 -5890760 6420 4920 6750 4757 7140 4567 7560 4362 8000 4146
-8450 3931 8920 3718 9410 3498 9920 3267 10460 3019 11020 2776 11590 2532
-12140 2298 12720 2065 13310 1824 13930 1575 14560 1335 15180 1097 15770 883
-16360 678 16990 470 17600 256 18230 60 18820 -120 19370 -273 19890 -407
-20440 -538 20980 -662 21500 -771 21970 -846 22360 -881 22700 -884 23060 -883
-23400 -869 23690 -825 23890 -731 23980 -581 23990 -392 23990 -192 23960 43
-23840 316 23600 655 23210 1063 22720 1528 22120 2044 21470 2600 20630 3244
-19700 3935 18820 4589 17770 5333 16310 6289 14550 7389 12840 8482 11300 9482
-9830 10353 8500 11160 7400 11979 6430 12796 5480 13527 4520 14156 3500 14714
-2500 15166 1520 15473 540 15670 -410 15800 -1390 15893 -2400 15963 -3430 15982
--4420 15914 -5420 15779 -6420 15597 -7460 15394 -8550 15187 -9660 14950
--10850 14638 -12060 14281 -13330 13889 -14610 13499 -15760 13165 -16970 12814
--18390 12368 -19900 11862 -21360 11385 -22650 10985 -23810 10639 -24830 10357
--25730 10154 -26500 10009 -27160 9899 -27760 9815 -28340 9745 -28830 9702
--29110 9712 -29230 9764 -29330 9832 -29450 9918 -29600 10021 -29770 10141
--29900 10275 -30030 10426 -30150 10607 -30290 10805 -30420 11005 -30570 11231
--30730 11510 -30910 11828 -31080 12158 -31250 12472 -31360 12768 -31470 13058
--31640 13363 -31810 13681 -31967 13988 -32061 14278 -32100 14538 -32090 14785
--32058 15026 -32016 15268 -31923 15485 -31767 15676 -31554 15848 -31278 15993
--30935 16105 -30537 16187 -30086 16248 -29579 16297 -29066 16344 -28505 16378
--27819 16395 -27027 16393 -26206 16380 -25415 16362 -24667 16334 -23934 16301
--23164 16262 -22359 16216 -21572 16158 -20819 16093 -20095 16018 -19403 15935
--18757 15830 -18138 15709 -17546 15578 -16961 15445 -16350 15336 -15748 15227
--15213 15068 -14738 14872 -14241 14688 -13692 14548 -13135 14467 -12541 14421
--11841 14388 -11063 14370 -10269 14387 -9518 14453 -8917 14561 -8353 14712
--7626 14917 -6784 15169 -6028 15459 -5485 15781 -5220 16131 -5152 16510
--5141 16929 -5192 17390 -5450 17882 -5972 18403 -6658 18937 -7581 19493
--8918 20112 -10615 20786 -12463 21479 -14331 22170 -16210 22838 -18145 23509
--20299 24189 -22433 24937 -24604 25748 -26884 26588 -29309 27386 -31817 28052
--34337 28560 -36777 28938 -39227 29234 -41882 29505 -44872 29837 -48114 30317
--51369 30975 -54391 31726 -57107 32374 -59737 32753 -62540 32776 -65419 32462
--68068 31892 -70424 31268 -72441 30882 -73810 30944 -74116 31440 -73430 32198
--72583 32990 -72316 33485 -72578 33213 -72323 31723 -70158 28866 -65760 24944
--59767 20656 -52977 16741 -46074 13659 -39174 11567 -32403 10135 -26126 8568
--20299 5842 -14611 1263 -9410 -5052 -5744 -12086 -3996 -18102 -3310 -21529
--1318 -21087 5087 -16887 19912 -11732 43724 -6380 56071 -609 58833 5588
-47038 8861 11203 7984 -8867 6103 -8722 467 -7050 -19105 -5724 -43293 -6154 -62279
--9109 -28397 -9317 3547 -4418 9219 -19220 10485 -13127 8806 -6457 6410
-3488 568 8016 -1661 9035 -901 7957 4045 4759 7081 1291 8276 -561 8395 -781 7641
--18 6108 3418 4145 9370 1300 8575 -1400 -16608 1974 -17723 8667 -14461 6892
--3788 6611 -6325 8232 -5806 8173 -8730 8529 -8774 9503 -5655 10664 63 11638
-7708 11940 16925 11304 26925 9779 35907 7861 41504 6333 41839 5922 36854 6783
-28844 8461 21394 10282 16635 11829 13317 13141 9553 14332 5180 15227 1735 15234
-252 13574 -2178 10740 -8712 8249 -15852 6851 -20087 6484 -21015 6701 -19516 7105
--16460 7498 -12382 7873 -7621 8250 -2485 8608 2632 8880 7287 9018 10998 9030
-13364 8979 14131 8912 13259 8848 10942 8735 7593 8518 3788 8131 196 7548
-3868 6974 7173 6201 9859 5250 11797 4138 12951 2921 13408 1689 13313 486
-12867 -681 12250 -1817 11635 -2910 11080 -3919 10609 -4808 10180 -5558
-9712 -6176 9141 -6673 8388 -7070 7409 -7378 6193 -7595 4751 -7700 3120 -7673
-1333 -7502 -562 -7202 -2548 -6799 -4590 -6333 -6694 -5818 -8820 -5256
--10983 -4645 -13152 -3988 -15317 -3279 -17444 -2522 -19511 -1723 -21502 -887
--23371 -17 -25128 889 -26730 1835 -28173 2815 -29462 3823 -30575 4854
--31523 5888 -32316 6918 -32943 7931 -33408 8919 -33722 9878 -33882 10792
--33903 11661 -33785 12470 -33558 13214 -33219 13890 -32795 14498 -32291 15040
--31702 15517 -31037 15916 -30294 16237 -29473 16488 -28569 16682 -27609 16824
--26604 16916 -25580 16948 -24571 16901 -23836 16785 -23055 16640 -22232 16465
--21387 16260 -20533 16028 -19682 15773 -18850 15498 -18057 15206 -17298 14901
--16577 14586 -15920 14266 -15309 13941 -14749 13618 -14244 13295 -13794 12975
--13396 12666 -13051 12366 -12758 12077 -12521 11801 -12335 11537 -12197 11289
--12115 11057 -12073 10842 -12078 10643 -12118 10463 -12197 10301 -12309 10159
--12447 10038 -12609 9936 -12796 9851 -12997 9789 -13211 9744 -13423 9720
--13640 9712 -13860 9724 -14073 9756 -14276 9803 -14463 9866 -14617 9945
--14754 10038 -14865 10147 -14960 10265 -15018 10395 -15039 10534 -15031 10682
--14968 10830 -14860 10986 -14705 11142 -14511 11298 -14286 11458 -14035 11614
--13756 11767 -13438 11915 -13056 12049 -12598 12164 -12052 12260 -11411 12333
--10682 12387 -9904 12421 -9396 12486 -8798 12523 -8121 12529 -7379 12505
--6587 12451 -5764 12375 -4909 12271 -4030 12142 -3126 11989 -2225 11813
--1321 11617 -425 11398 466 11156 1356 10892 2229 10614 3084 10319 3896 10011
-4667 9690 5409 9357 6130 9016 6813 8669 7428 8320 7974 7970 8444 7623 8870 7285
-9240 6959 9532 6647 9755 6339 9917 6032 10021 5748 10038 5498 9947 5287
-9771 5102 9567 4927 9360 4758 9119 4606 8789 4486 8356 4409 7877 4383 7450 4402
-7111 4450 6839 4506 6515 4550 6028 4585 5355 4632 4564 4725 3837 4874 3294 5076
-3014 5303 2961 5527 3025 5737 3025 5933 2839 6131 2364 6344 1610 6590 614 6888
--504 7264 -1612 7738 -2585 8322 -4176 9077 -4289 9384 -3713 9539 -2941 9802
--2300 10400 -1965 11518 -2071 13234 -2713 15465 -3895 17952 -5368 20315
--6681 22149 -7355 23092 -7196 22871 -6357 21523 -4947 19792 -1847 16688
-7259 9981 29347 -2302 35429 -8236 34391 -6211 32686 1052 35209 6720 38965 9892
-44747 10851 43375 11089 29625 10519 10390 7605 -9339 2766 -19374 2015
--18322 6686 -7971 15603 10512 27313 30977 38275 35805 36569 -23699 -10779
--16304 -3452 9788 24034 32819 51959 11503 35017 -6033 17528 -15380 6981
--19103 1989 -19743 453 -18961 899 -17715 2384 -16516 4297 -15607 6246
--15056 8001 -14840 9446 -14902 10552 -15156 11339 -15546 11854 -16010 12158
--16498 12306 -16988 12347 -17466 12320 -17929 12252
-68: 10121900 -5881520 6190 4991 6520 4831 6900 4643 7300 4444 7740 4230
-8180 4020 8640 3810 9110 3593 9610 3367 10140 3125 10680 2884 11240 2647
-11780 2417 12330 2190 12910 1954 13510 1711 14130 1474 14720 1245 15300 1037
-15870 835 16470 632 17070 428 17670 235 18240 63 18770 -81 19270 -207 19790 -331
-20320 -451 20800 -550 21250 -620 21620 -644 21930 -639 22270 -635 22580 -609
-22840 -555 23020 -457 23080 -302 23080 -108 23070 103 22990 343 22860 627
-22590 969 22210 1365 21720 1825 21130 2338 20460 2893 19640 3527 18720 4200
-17870 4838 16850 5548 15480 6451 13870 7474 12290 8497 10830 9432 9470 10254
-8200 11017 7110 11799 6100 12577 5130 13285 4150 13885 3120 14422 2120 14863
-1140 15177 170 15393 -780 15545 -1750 15656 -2760 15743 -3770 15783 -4770 15736
--5750 15618 -6750 15462 -7790 15278 -8840 15098 -9950 14878 -11090 14590
--12260 14255 -13490 13892 -14710 13531 -15830 13218 -16980 12891 -18310 12481
--19720 12019 -21060 11589 -22280 11214 -23360 10897 -24340 10632 -25190 10431
--25950 10278 -26620 10159 -27200 10066 -27780 9986 -28280 9936 -28580 9939
--28750 9977 -28900 10032 -29050 10107 -29240 10202 -29430 10307 -29590 10433
--29720 10582 -29860 10751 -30000 10941 -30140 11130 -30300 11344 -30450 11605
--30630 11902 -30800 12207 -30960 12501 -31080 12777 -31190 13049 -31340 13336
--31490 13635 -31630 13926 -31715 14200 -31738 14443 -31725 14676 -31689 14904
--31632 15131 -31536 15332 -31376 15513 -31161 15672 -30886 15808 -30551 15914
--30163 15992 -29717 16053 -29222 16100 -28718 16142 -28172 16173 -27509 16184
--26756 16176 -25967 16156 -25206 16132 -24478 16102 -23756 16064 -23003 16017
--22212 15961 -21431 15897 -20683 15823 -19959 15745 -19268 15661 -18608 15553
--17968 15432 -17349 15300 -16745 15172 -16121 15068 -15509 14968 -14946 14825
--14432 14654 -13899 14492 -13336 14376 -12775 14313 -12190 14285 -11516 14270
--10776 14270 -10028 14306 -9332 14389 -8779 14514 -8277 14680 -7639 14898
--6913 15162 -6267 15463 -5825 15796 -5638 16155 -5637 16546 -5699 16980
--5831 17457 -6161 17965 -6729 18501 -7457 19045 -8394 19610 -9705 20237
--11335 20917 -13108 21612 -14923 22306 -16752 22976 -18642 23645 -20762 24312
--22884 25031 -25038 25814 -27283 26637 -29665 27441 -32154 28150 -34637 28735
--37050 29197 -39445 29547 -42006 29817 -44865 30069 -47963 30402 -51097 30877
--54019 31457 -56627 32004 -59120 32382 -61719 32507 -64327 32337 -66702 31883
--68831 31278 -70715 30769 -72100 30552 -72526 30657 -71929 31012 -70898 31493
--70084 31860 -69638 31667 -68844 30425 -66616 27881 -62722 24235 -57543 20132
--51661 16281 -45537 13156 -39174 10927 -32747 9378 -26663 7858 -20834 5460
--14858 1642 -9116 -3434 -4878 -8996 -2895 -14013 -2233 -17493 -263 -18602
-5947 -17158 18200 -13942 34086 -9416 44447 -3992 46240 1335 36543 4413
-15334 4069 16 925 -4508 -6519 -4856 -20615 -4752 -35185 -6310 -40992 -9292 -23728
--10157 -1793 -8167 8491 -16344 9240 -12512 7350 -3235 4807 6746 -992 11746 -3249
-11681 -3951 10127 5280 4999 8323 -309 8931 -2356 8882 -2062 8235 -2744 7038
--441 6385 7419 6026 8510 6125 -12732 1892 -15306 1525 -13408 5550 -7196 8316
--3636 5887 -2125 7139 -10700 8122 -11271 9682 -7761 11147 -1332 12325
-7024 12488 17748 11355 30521 8961 42781 6109 50748 4064 50746 4066 42233 6215
-29078 9377 18441 12148 14708 13822 13583 14925 10195 16059 4359 17244
-13 17583 1457 14946 1645 10148 -9324 6600 -20854 5108 -25775 5088 -25380 5684
--22249 6369 -17869 6997 -12820 7593 -7340 8177 -1703 8685 3710 9019 8421 9139
-11936 9103 13875 9017 14039 8961 12492 8961 9551 8961 5781 8876 1884 8608
--1352 8090 3910 7503 8343 6630 11823 5507 14242 4213 15612 2859 16047 1516
-15780 210 15085 -1079 14218 -2335 13387 -3513 12698 -4566 12148 -5468
-11681 -6222 11191 -6860 10586 -7411 9775 -7883 8726 -8259 7427 -8510 5907 -8599
-4200 -8506 2349 -8255 401 -7880 -1645 -7428 -3749 -6920 -5935 -6369 -8175 -5776
--10470 -5147 -12794 -4472 -15125 -3742 -17429 -2958 -19667 -2123 -21815 -1252
--23825 -342 -25695 603 -27398 1590 -28923 2615 -30269 3678 -31424 4759
--32403 5853 -33212 6939 -33842 8010 -34306 9055 -34608 10059 -34747 11023
--34734 11933 -34590 12779 -34316 13551 -33945 14250 -33480 14876 -32936 15432
--32307 15914 -31602 16316 -30816 16635 -29942 16877 -28994 17059 -27980 17192
--26926 17267 -25854 17282 -24795 17215 -24046 17075 -23243 16902 -22405 16703
--21540 16473 -20661 16220 -19785 15941 -18942 15645 -18129 15331 -17362 15007
--16640 14674 -15970 14336 -15357 13997 -14790 13657 -14290 13322 -13839 12992
--13443 12675 -13109 12366 -12830 12071 -12605 11789 -12439 11521 -12322 11270
--12258 11035 -12239 10818 -12265 10620 -12336 10441 -12440 10281 -12584 10141
--12744 10023 -12941 9923 -13153 9844 -13385 9785 -13627 9744 -13877 9726
--14118 9725 -14368 9745 -14605 9784 -14834 9839 -15044 9910 -15216 9999
--15365 10103 -15493 10220 -15597 10352 -15663 10494 -15696 10645 -15689 10804
--15629 10964 -15511 11134 -15351 11301 -15143 11473 -14906 11644 -14643 11817
--14347 11984 -14010 12147 -13609 12293 -13125 12419 -12539 12527 -11849 12609
--11062 12670 -10222 12709 -9688 12788 -9054 12830 -8336 12841 -7551 12819
--6721 12769 -5839 12692 -4927 12585 -3983 12450 -3025 12292 -2072 12111
--1118 11904 -163 11669 791 11412 1742 11133 2668 10838 3560 10525 4409 10197
-5221 9851 6011 9491 6781 9125 7485 8750 8111 8375 8666 8003 9154 7629 9592 7262
-9971 6905 10259 6559 10475 6213 10612 5881 10671 5580 10624 5316 10472 5083
-10265 4863 10045 4650 9795 4450 9478 4282 9039 4160 8507 4088 7977 4066
-7538 4078 7185 4100 6827 4111 6340 4106 5646 4108 4805 4152 3967 4265 3322 4441
-2981 4654 2933 4864 3055 5049 3160 5209 3057 5357 2641 5511 1878 5686 839 5898
--368 6169 -1594 6528 -2693 7007 -3571 7623 -4146 8111 -3503 8352 -2781 8614
--2622 9110 -3168 9992 -4165 11356 -5221 13189 -6050 15332 -6467 17500
--6390 19340 -5712 20543 -4265 20830 -1818 19754 1645 16959 5679 15025
-9744 12397 14201 6767 21069 -2808 21267 -10581 18383 -7982 14380 3297
-20203 8819 24120 10780 39280 9327 43767 8619 24936 8980 4479 7149 -12686 3449
--22583 1567 -23184 4481 -16729 10741 849 20583 27797 34838 63944 52761
--53816 -40934 -16192 -12727 19057 24839 68409 85092 25156 53076 612 27962
--11296 14159 -16338 7101 -17854 3915 -17682 3081 -16865 3657 -15943 4979
--15203 6581 -14745 8152 -14570 9518 -14643 10605 -14893 11403 -15271 11944
--15722 12273 -16194 12445 -16672 12503 -17140 12485 -17589 12421
-69: 10152020 -5872244 5950 5068 6280 4911 6640 4728 7040 4531 7460 4321
-7890 4113 8330 3909 8800 3696 9280 3473 9800 3238 10320 3002 10860 2766
-11390 2546 11920 2324 12500 2088 13080 1857 13660 1624 14240 1403 14800 1198
-15360 1002 15930 807 16510 610 17090 422 17630 257 18140 120 18620 1 19120 -116
-19620 -227 20080 -321 20500 -382 20850 -395 21140 -390 21450 -375 21730 -341
-21970 -279 22120 -171 22170 -17 22150 184 22110 402 22020 646 21860 938
-21580 1280 21190 1671 20720 2121 20120 2625 19460 3173 18650 3797 17770 4450
-16930 5069 15950 5750 14670 6602 13180 7555 11700 8509 10340 9390 9050 10162
-7850 10887 6770 11631 5760 12369 4760 13046 3770 13628 2760 14144 1750 14571
-770 14890 -190 15120 -1140 15287 -2110 15415 -3110 15518 -4100 15573 -5090 15548
--6070 15449 -7060 15311 -8080 15151 -9120 14993 -10180 14794 -11300 14532
--12430 14221 -13620 13882 -14780 13546 -15870 13259 -16960 12957 -18210 12579
--19520 12155 -20770 11761 -21910 11416 -22940 11122 -23870 10876 -24680 10679
--25420 10521 -26080 10397 -26660 10296 -27240 10213 -27720 10160 -28050 10153
--28270 10178 -28440 10226 -28640 10290 -28850 10370 -29060 10467 -29230 10585
--29390 10726 -29530 10888 -29690 11070 -29830 11246 -29990 11446 -30160 11691
--30330 11969 -30500 12253 -30650 12529 -30780 12786 -30870 13041 -31020 13310
--31160 13593 -31289 13866 -31362 14123 -31377 14353 -31353 14572 -31315 14787
--31254 14998 -31151 15188 -30990 15357 -30774 15505 -30503 15632 -30174 15732
--29791 15804 -29356 15861 -28876 15908 -28378 15943 -27845 15969 -27206 15976
--26482 15962 -25727 15937 -24989 15907 -24278 15871 -23569 15827 -22829 15777
--22049 15710 -21276 15636 -20531 15559 -19811 15477 -19119 15394 -18450 15283
--17789 15161 -17152 15030 -16527 14907 -15892 14811 -15274 14720 -14691 14592
--14142 14437 -13584 14301 -13014 14204 -12455 14156 -11878 14146 -11229 14149
--10530 14166 -9827 14218 -9182 14317 -8676 14457 -8229 14639 -7672 14870
--7049 15144 -6511 15457 -6158 15800 -6044 16168 -6104 16569 -6230 17019
--6440 17507 -6831 18029 -7436 18576 -8199 19130 -9153 19703 -10444 20335
--12020 21019 -13733 21717 -15499 22411 -17286 23083 -19136 23746 -21193 24402
--23302 25105 -25436 25853 -27649 26648 -29988 27438 -32452 28167 -34914 28800
--37294 29331 -39629 29744 -42094 30041 -44816 30267 -47757 30509 -50737 30852
--53534 31291 -56027 31736 -58392 32078 -60803 32246 -63160 32174 -65283 31807
--67164 31237 -68856 30656 -70167 30233 -70674 30022 -70233 30004 -69194 30152
--68070 30296 -67111 30062 -65840 28965 -63463 26698 -59816 23370 -55145 19525
--49938 15790 -44480 12622 -38690 10252 -32755 8597 -27066 7131 -21466 5078
--15474 2006 -9449 -1945 -4716 -6281 -2246 -10471 -1311 -13955 432 -16121
-5471 -16505 14732 -15003 25761 -11749 33551 -7317 35235 -2941 29202 -331
-16742 -609 5678 -3931 132 -10566 -1592 -20013 -2559 -28213 -5110 -29738
--8539 -20195 -7699 -3911 -15337 12212 -18014 12416 -12492 6172 -525 -3279
-13127 7587 16502 -331 12979 -8938 11479 6259 4248 7019 -3012 6702 -4194 6479
--895 5872 -1875 4829 62 2797 2426 7788 4420 5752 -8110 5683 -12870 3566
--11006 5698 -5679 7533 -5854 7914 1193 8775 -15153 8514 -12978 10228 -9269 11606
--2663 13102 5183 13185 16711 11637 32941 8170 50068 3941 62348 894 62393 1416
-48321 5613 25984 11016 9893 14932 10807 16059 15577 16264 13219 17027
-4044 18788 -3714 20835 4646 17068 12851 8810 -9898 4216 -29726 3106 -33727 3822
--30142 4947 -24613 5938 -18867 6779 -13034 7560 -7052 8286 -1096 8845
-4449 9142 9067 9176 12262 9065 13684 8967 13211 8987 11040 9135 7637 9324
-3729 9417 168 9267 -2184 8769 4727 8113 10458 7057 14900 5723 17901 4256
-19450 2770 19699 1320 18991 -103 17734 -1516 16319 -2866 15026 -4093 14009 -5157
-13258 -6067 12689 -6853 12166 -7565 11550 -8213 10738 -8774 9697 -9197
-8405 -9431 6893 -9448 5210 -9265 3385 -8938 1445 -8516 -594 -8031 -2740 -7492
--4999 -6919 -7362 -6311 -9824 -5670 -12341 -4978 -14882 -4223 -17395 -3405
--19834 -2535 -22161 -1625 -24328 -679 -26316 303 -28119 1329 -29717 2403
--31111 3516 -32308 4660 -33312 5816 -34121 6967 -34758 8099 -35209 9201
--35486 10261 -35603 11273 -35558 12227 -35373 13109 -35064 13911 -34644 14633
--34140 15276 -33551 15842 -32886 16328 -32135 16732 -31300 17045 -30381 17278
--29384 17446 -28317 17564 -27212 17625 -26089 17619 -24989 17528 -24224 17362
--23399 17163 -22535 16933 -21639 16682 -20745 16400 -19857 16098 -18994 15778
--18170 15444 -17395 15100 -16667 14746 -15992 14390 -15371 14035 -14807 13681
--14305 13334 -13859 12995 -13466 12666 -13146 12352 -12882 12050 -12673 11761
--12522 11490 -12427 11237 -12382 11002 -12390 10784 -12443 10587 -12540 10409
--12670 10253 -12842 10117 -13039 10000 -13265 9905 -13508 9830 -13775 9773
--14049 9739 -14330 9729 -14607 9733 -14882 9763 -15155 9809 -15403 9872
--15633 9955 -15827 10052 -15995 10168 -16136 10294 -16248 10437 -16328 10593
--16373 10756 -16367 10928 -16310 11103 -16190 11285 -16018 11466 -15800 11653
--15548 11839 -15273 12027 -14958 12210 -14601 12385 -14184 12548 -13673 12686
--13049 12806 -12304 12898 -11465 12967 -10566 13015 -9996 13104 -9327 13152
--8572 13170 -7744 13152 -6860 13104 -5924 13026 -4945 12916 -3944 12778
--2934 12615 -1929 12425 -912 12204 108 11957 1133 11684 2139 11390 3111 11080
-4035 10745 4932 10391 5800 10023 6648 9639 7454 9241 8175 8841 8816 8442
-9381 8042 9905 7638 10367 7238 10745 6846 11029 6461 11226 6087 11335 5736
-11341 5417 11233 5132 11044 4865 10808 4606 10566 4357 10268 4139 9850 3969
-9297 3851 8678 3783 8093 3750 7620 3736 7205 3713 6728 3680 6063 3639 5200 3637
-4286 3706 3509 3853 3038 4056 2923 4265 3064 4441 3243 4571 3247 4674 2908 4776
-2172 4896 1104 5047 -158 5240 -1457 5493 -2635 5842 -3581 6326 -4258 6960
--3330 7084 -2093 7251 -1694 7662 -2682 8449 -4823 9674 -7344 11322 -9312 13268
--10024 15266 -9200 16964 -7055 18023 -4126 18299 -804 17881 3354 16365
-9026 11437 15500 10544 20008 9958 17640 6891 13127 -1164 9320 -12003 5434 -9362
--6110 7139 7248 10339 974 11343 34645 5855 52610 4466 21280 8304 414 7936
--14759 3877 -25279 -564 -27482 707 -30440 1798 -23432 2261 -25044 -4204
-20498 14851 -13756 -19789 26423 4518 13444 3371 76864 85681 68954 107572
-20705 54742 337 30933 -8892 18160 -12901 11107 -14347 7654 -14609 6513
--14406 6745 -14135 7670 -13977 8834 -13988 9965 -14167 10920 -14483 11651
--14890 12160 -15357 12478 -15835 12645 -16310 12703 -16777 12686 -17219 12617
-70: 10181990 -5862933 5700 5152 6010 4995 6380 4816 6750 4622 7170 4422
-7580 4213 8020 4014 8460 3805 8940 3587 9430 3357 9960 3125 10460 2896
-10980 2678 11500 2465 12050 2235 12620 2008 13180 1781 13750 1565 14280 1371
-14810 1180 15370 990 15920 801 16490 619 17010 462 17480 330 17950 218
-18430 107 18890 4 19340 -82 19730 -133 20040 -143 20340 -130 20610 -108
-20860 -68 21080 3 21210 114 21240 275 21210 476 21140 698 21040 948 20840 1246
-20570 1588 20190 1971 19700 2410 19120 2906 18470 3448 17680 4053 16820 4685
-16000 5284 15070 5937 13870 6737 12480 7632 11110 8524 9830 9349 8590 10082
-7460 10765 6390 11472 5380 12175 4390 12821 3390 13383 2380 13877 1380 14294
-410 14612 -540 14856 -1500 15038 -2460 15178 -3430 15293 -4420 15360 -5400 15354
--6370 15273 -7340 15158 -8350 15014 -9360 14878 -10400 14703 -11470 14462
--12590 14174 -13710 13860 -14820 13554 -15870 13287 -16930 13007 -18090 12660
--19310 12273 -20480 11908 -21560 11592 -22530 11319 -23400 11090 -24190 10900
--24920 10741 -25550 10613 -26130 10507 -26700 10423 -27180 10367 -27530 10352
--27780 10368 -27980 10406 -28200 10462 -28440 10530 -28660 10617 -28860 10728
--29030 10862 -29180 11017 -29350 11188 -29500 11354 -29670 11541 -29840 11773
--30000 12030 -30180 12295 -30330 12554 -30450 12794 -30550 13032 -30680 13286
--30820 13553 -30932 13809 -31001 14050 -31013 14268 -30984 14472 -30939 14674
--30875 14872 -30771 15049 -30607 15207 -30391 15346 -30126 15464 -29802 15555
--29428 15624 -29001 15675 -28534 15717 -28046 15750 -27527 15769 -26907 15771
--26210 15753 -25481 15723 -24760 15684 -24070 15643 -23374 15595 -22646 15538
--21879 15465 -21109 15383 -20370 15299 -19655 15216 -18957 15130 -18282 15020
--17609 14899 -16953 14770 -16311 14652 -15670 14561 -15043 14477 -14446 14363
--13875 14227 -13299 14108 -12719 14030 -12165 14000 -11602 14004 -10979 14023
--10313 14057 -9655 14123 -9062 14237 -8602 14391 -8209 14587 -7723 14830
--7193 15114 -6747 15437 -6484 15790 -6433 16170 -6547 16581 -6739 17039
--7013 17540 -7456 18073 -8101 18629 -8890 19190 -9861 19769 -11132 20406
--12664 21092 -14328 21792 -16047 22487 -17794 23155 -19608 23816 -21620 24476
--23702 25160 -25804 25877 -27980 26633 -30281 27394 -32703 28117 -35133 28776
--37479 29353 -39766 29823 -42138 30162 -44726 30394 -47510 30592 -50320 30843
--52974 31168 -55346 31507 -57580 31794 -59817 31969 -61956 31949 -63852 31652
--65495 31124 -66946 30513 -68105 29958 -68626 29505 -68325 29171 -67373 28992
--66130 28867 -64865 28510 -63236 27481 -60702 25451 -57170 22448 -52819 18904
--48084 15330 -43151 12140 -37873 9635 -32437 7855 -27213 6389 -22008 4597
--16267 2141 -10226 -883 -5134 -4217 -2094 -7665 -713 -10997 830 -13760
-4630 -15345 11316 -15241 19020 -13293 24764 -10009 26641 -6573 23556 -4471
-16206 -4731 8508 -7572 3700 -12580 1759 -18434 257 -22308 -3018 -21065
--7601 -12890 -11346 413 -17988 13702 -19567 17827 -11731 14824 7329 5725
-15788 1927 20125 1768 11952 -8417 7292 -5654 1932 -737 -4830 1062 -6116 -55
-419 -1840 9175 3719 43560 -24110 -13402 20980 -19282 9481 -12942 12210
--14054 7870 -9778 8915 -2695 10157 -6599 5848 -11990 12106 -12797 9476
--8711 11030 -9015 11694 -3732 13840 1363 13954 12211 12460 32712 7758
-56600 1577 76921 -3586 78276 -2567 56196 4952 17195 13752 -10090 19172
-4698 18188 22210 16381 21057 16240 5709 18428 -12413 25604 10702 20562
-40779 5871 -14304 1258 -47293 1441 -43910 3328 -34094 4958 -25912 6100
--19346 6996 -13248 7812 -7069 8525 -951 9005 4626 9169 9076 9083 11896 8925
-12782 8893 11713 9082 9037 9461 5397 9888 1705 10160 -1039 10081 -1899 9512
-6714 8686 13994 7403 19640 5868 23326 4257 24949 2665 24702 1105 23100 -444
-20771 -1953 18337 -3359 16211 -4603 14605 -5679 13510 -6630 12796 -7498
-12257 -8325 11715 -9081 11031 -9701 10132 -10112 8997 -10272 7648 -10194
-6114 -9941 4435 -9581 2603 -9145 621 -8647 -1529 -8093 -3867 -7504 -6384 -6883
--9050 -6222 -11821 -5499 -14620 -4706 -17386 -3848 -20060 -2941 -22579 -1997
--24909 -1021 -27018 -4 -28913 1062 -30567 2185 -32006 3352 -33228 4562
--34239 5787 -35053 7004 -35675 8201 -36109 9365 -36361 10481 -36442 11545
--36360 12541 -36136 13460 -35777 14293 -35319 15035 -34772 15693 -34136 16269
--33423 16760 -32627 17163 -31745 17470 -30781 17689 -29728 17842 -28615 17940
--27454 17983 -26287 17957 -25144 17840 -24360 17646 -23508 17417 -22614 17160
--21701 16878 -20785 16572 -19882 16243 -19011 15898 -18185 15540 -17396 15174
--16665 14802 -15982 14427 -15353 14052 -14784 13685 -14286 13328 -13848 12978
--13473 12642 -13158 12319 -12910 12012 -12718 11719 -12588 11444 -12508 11190
--12488 10954 -12518 10739 -12601 10545 -12725 10370 -12887 10216 -13092 10082
--13321 9970 -13585 9878 -13865 9808 -14164 9758 -14476 9729 -14792 9725
--15106 9740 -15410 9775 -15707 9832 -15979 9903 -16233 9996 -16451 10105
--16636 10228 -16796 10368 -16920 10524 -17016 10691 -17070 10868 -17072 11053
--17015 11244 -16888 11439 -16706 11637 -16477 11838 -16212 12040 -15918 12243
--15593 12444 -15223 12634 -14780 12812 -14237 12965 -13581 13097 -12787 13201
--11892 13279 -10934 13337 -10328 13433 -9624 13491 -8829 13515 -7951 13504
--7013 13458 -6010 13377 -4970 13265 -3921 13126 -2859 12957 -1785 12754
--698 12522 395 12260 1481 11976 2534 11668 3547 11335 4522 10978 5473 10599
-6402 10206 7309 9796 8148 9370 8880 8946 9544 8517 10149 8084 10705 7645
-11183 7209 11563 6782 11826 6365 12002 5965 12082 5596 12047 5256 11894 4939
-11668 4632 11408 4331 11125 4059 10751 3836 10220 3672 9555 3553 8855 3474
-8218 3414 7685 3358 7175 3293 6547 3226 5726 3181 4768 3204 3872 3314 3241 3503
-2983 3718 3056 3902 3270 4020 3358 4085 3112 4130 2433 4195 1365 4301 54 4446
--1293 4633 -2507 4877 -3464 5213 -4124 5681 -4520 6301 -1911 5997 -422 6090
--875 6680 -3449 7806 -7459 9429 -11565 11420 -14302 13546 -14561 15440
--11983 16620 -7237 16610 -1967 15296 2152 13528 5839 12697 11987 5721
-20031 7732 26643 9919 15496 10200 -4992 1740 7970 -2878 5513 -1105 -21876 2237
-6393 6746 -37398 10700 25709 -581 70489 -3177 18630 9683 2676 10642 -9924 6041
--21825 -2048 -22270 994 -32252 284 -15008 5267 -25708 318 -4590 -4388
-15407 -5521 32709 -3088 9515 -7471 23846 20659 68271 116114 41140 90495
-14235 53543 589 32553 -6358 20234 -9802 13480 -11436 10281 -12195 9216
--12573 9314 -12846 9950 -13141 10741 -13500 11485 -13933 12083 -14408 12511
--14912 12780 -15418 12918 -15905 12958 -16372 12927 -16816 12847
-71: 10211830 -5853588 5430 5239 5740 5085 6090 4912 6460 4719 6850 4520
-7270 4320 7680 4125 8110 3921 8580 3706 9060 3484 9560 3257 10050 3032
-10560 2820 11050 2611 11590 2390 12140 2165 12680 1948 13220 1736 13740 1547
-14260 1367 14780 1182 15320 997 15860 826 16360 674 16810 547 17260 443
-17710 338 18150 243 18570 166 18940 121 19240 113 19500 137 19750 164 19990 209
-20170 287 20290 402 20290 567 20260 769 20170 993 20050 1248 19850 1546
-19560 1886 19180 2264 18700 2693 18130 3177 17490 3709 16710 4296 15900 4906
-15090 5486 14200 6109 13070 6864 11780 7705 10500 8537 9280 9315 8130 10007
-7040 10654 5970 11324 4990 11995 3990 12611 3000 13152 2000 13626 1010 14031
-50 14350 -890 14600 -1850 14793 -2790 14947 -3750 15071 -4730 15151 -5690 15156
--6640 15096 -7610 14998 -8590 14876 -9580 14755 -10590 14603 -11630 14384
--12700 14120 -13780 13830 -14850 13546 -15850 13300 -16870 13041 -17960 12728
--19100 12373 -20200 12036 -21200 11745 -22120 11491 -22960 11277 -23720 11095
--24420 10938 -25040 10806 -25620 10699 -26160 10615 -26660 10557 -27010 10536
--27280 10543 -27520 10573 -27760 10620 -28010 10681 -28250 10760 -28460 10862
--28650 10990 -28810 11137 -28990 11295 -29150 11455 -29320 11632 -29490 11844
--29670 12088 -29840 12334 -29990 12577 -30110 12802 -30210 13021 -30340 13263
--30460 13515 -30571 13756 -30636 13981 -30642 14184 -30612 14377 -30562 14567
--30500 14750 -30392 14917 -30229 15064 -30016 15192 -29752 15302 -29436 15385
--29071 15449 -28653 15495 -28193 15533 -27721 15559 -27211 15575 -26611 15570
--25936 15547 -25232 15510 -24533 15466 -23855 15421 -23172 15369 -22454 15303
--21697 15225 -20935 15136 -20202 15046 -19490 14961 -18794 14873 -18108 14765
--17423 14642 -16751 14518 -16101 14403 -15455 14318 -14823 14241 -14217 14139
--13626 14021 -13035 13918 -12453 13855 -11904 13840 -11360 13858 -10760 13891
--10126 13942 -9510 14023 -8966 14148 -8551 14317 -8203 14524 -7789 14778
--7342 15073 -6981 15403 -6794 15769 -6805 16156 -6971 16576 -7218 17041
--7551 17556 -8039 18097 -8722 18660 -9534 19227 -10520 19811 -11773 20448
--13264 21137 -14884 21840 -16564 22531 -18270 23197 -20050 23852 -22048 24532
--24081 25201 -26148 25886 -28281 26602 -30534 27325 -32905 28024 -35293 28680
--37598 29283 -39837 29795 -42126 30174 -44592 30431 -47215 30618 -49863 30813
--52361 31043 -54603 31287 -56708 31506 -58782 31655 -60733 31656 -62432 31409
--63853 30923 -65066 30314 -66024 29685 -66465 29066 -66255 28487 -65413 28014
--64181 27615 -62773 27088 -60924 26064 -58291 24221 -54823 21536 -50681 18311
--46285 14929 -41748 11760 -36885 9147 -31868 7223 -27086 5683 -22345 4028
--17050 2003 -11238 -323 -5978 -2852 -2403 -5618 -492 -8637 1043 -11610
-3914 -13915 8654 -14850 13989 -14044 18199 -11843 20162 -9273 18930 -7632
-14589 -7822 9371 -9971 5851 -13377 4368 -16603 2788 -17608 -987 -14539
--6716 -6674 -12820 4647 -18914 15967 -20832 22689 -13963 23846 15273 12820
-14087 -6608 22471 5415 7947 -10165 4325 -14880 2424 -4569 -5752 -1777
--8089 -6282 1640 -20133 -4960 43822 32691 -13076 18774 -6579 -19865 -11652
--5318 8272 -13733 15773 -6818 14297 26567 7747 45199 10755 -86338 12842
--23836 11340 -4871 9894 -8316 11148 -7017 13702 -5463 14287 2865 14063
-28182 8202 59128 -115 94589 -9801 99611 -8624 68293 4392 744 17999 -53382 25932
--1253 19290 38481 14359 34260 13145 12612 13091 -27610 32330 23065 24900
-98930 664 -36800 -495 -79864 1497 -52155 4510 -34472 6128 -25594 6975
--19744 7616 -14068 8239 -7883 8768 -1604 9052 4047 9047 8360 8875 10830 8757
-11223 8891 9658 9342 6637 10006 3023 10671 -82 11070 -1501 10967 -212 10225
-10280 9128 19509 7626 26714 5951 31208 4250 32695 2577 31439 903 28223 -754
-24066 -2342 19938 -3789 16478 -5057 13972 -6175 12409 -7207 11547 -8199
-11097 -9147 10792 -9974 10425 -10590 9881 -10929 9110 -10996 8120 -10857
-6916 -10595 5516 -10255 3902 -9835 2047 -9327 -87 -8757 -2523 -8144 -5237 -7489
--8179 -6780 -11266 -6005 -14393 -5163 -17457 -4262 -20392 -3321 -23117 -2351
--25605 -1346 -27828 -299 -29789 806 -31494 1974 -32952 3202 -34181 4475
--35193 5766 -35992 7055 -36587 8319 -36997 9546 -37215 10717 -37256 11833
--37133 12874 -36862 13830 -36463 14690 -35958 15452 -35365 16126 -34678 16713
--33918 17208 -33077 17607 -32142 17903 -31128 18109 -30025 18245 -28860 18323
--27655 18344 -26435 18293 -25260 18150 -24444 17922 -23566 17664 -22641 17376
--21714 17065 -20782 16731 -19878 16373 -18996 16002 -18158 15618 -17361 15228
--16620 14833 -15929 14440 -15301 14051 -14735 13670 -14240 13298 -13806 12942
--13450 12596 -13146 12268 -12914 11954 -12741 11658 -12624 11385 -12565 11129
--12569 10897 -12630 10686 -12736 10492 -12894 10320 -13089 10168 -13332 10038
--13603 9930 -13896 9844 -14219 9780 -14560 9736 -14907 9715 -15259 9717
--15605 9743 -15944 9784 -16263 9848 -16566 9932 -16847 10033 -17086 10152
--17295 10288 -17470 10440 -17618 10608 -17726 10789 -17788 10981 -17798 11180
--17736 11387 -17608 11597 -17416 11810 -17175 12027 -16894 12248 -16589 12467
--16251 12684 -15864 12892 -15401 13084 -14832 13255 -14136 13401 -13295 13516
--12344 13607 -11325 13674 -10684 13779 -9946 13847 -9108 13880 -8175 13873
--7170 13828 -6104 13748 -5012 13635 -3909 13492 -2792 13314 -1640 13102
--476 12857 687 12584 1817 12289 2919 11962 3981 11604 5018 11224 6039 10823
-7035 10404 7988 9965 8850 9513 9614 9059 10310 8595 10962 8125 11556 7650
-12044 7181 12407 6722 12648 6276 12805 5851 12868 5455 12802 5087 12616 4732
-12351 4381 12056 4050 11703 3767 11230 3545 10585 3380 9813 3249 9041 3141
-8341 3044 7735 2949 7103 2857 6325 2783 5387 2762 4406 2830 3597 2991 3148 3207
-3077 3409 3236 3543 3375 3590 3223 3583 2619 3583 1575 3631 235 3740 -1165 3900
--2398 4093 -3315 4324 -3888 4628 -4159 5043 -4262 5599 -199 4847 1078 4872
--665 5660 -5119 7156 -11075 9230 -16704 11657 -20051 14115 -19600 16138
--14751 17071 -6526 16017 1713 12080 5098 5578 3500 1130 7262 8086 12045 9272
-25075 12397 12939 17264 -14141 11661 3702 -1718 13665 7354 4462 -1628
--6899 8322 -59079 4381 -19583 -3989 47343 -17734 54679 15684 21444 13207
-5396 10952 -2124 2483 -16383 5735 -12653 2640 1982 7245 -33316 6845 -24814 -28932
--1962 -28354 31695 -598 22749 6486 16441 30425 40531 86301 34200 86682
-18465 64030 6611 42155 -961 27274 -5515 18511 -8196 13899 -9789 11833
--10802 11214 -11529 11336 -12135 11764 -12706 12253 -13271 12678 -13845 12989
--14405 13181 -14944 13267 -15452 13271 -15930 13214 -16388 13114
-72: 10241540 -5844211 5150 5329 5450 5180 5790 5009 6150 4822 6530 4626
-6930 4431 7340 4241 7750 4043 8200 3832 8660 3615 9150 3394 9640 3176 10110 2968
-10590 2763 11110 2551 11640 2332 12160 2120 12690 1915 13180 1731 13680 1559
-14180 1381 14700 1201 15210 1038 15690 893 16130 773 16540 675 16970 578
-17390 487 17790 420 18140 380 18410 376 18650 403 18890 439 19090 492 19260 573
-19350 693 19360 859 19290 1060 19210 1285 19060 1544 18850 1843 18550 2177
-18190 2547 17710 2968 17150 3439 16510 3958 15770 4526 14980 5113 14200 5673
-13340 6272 12280 6984 11080 7769 9870 8553 8730 9282 7620 9937 6580 10555
-5560 11188 4560 11827 3580 12417 2600 12933 1610 13390 640 13783 -310 14100
--1240 14353 -2170 14559 -3120 14718 -4070 14854 -5020 14944 -5960 14959
--6900 14916 -7850 14835 -8820 14732 -9770 14630 -10750 14495 -11760 14299
--12790 14056 -13830 13790 -14860 13530 -15810 13299 -16790 13066 -17810 12776
--18890 12454 -19910 12145 -20860 11877 -21730 11641 -22530 11441 -23260 11267
--23940 11110 -24540 10979 -25110 10872 -25650 10789 -26130 10730 -26500 10704
--26790 10704 -27050 10726 -27310 10769 -27570 10821 -27830 10894 -28050 10989
--28240 11110 -28430 11246 -28600 11398 -28780 11550 -28960 11711 -29130 11913
--29310 12138 -29480 12371 -29640 12597 -29750 12806 -29860 13014 -29980 13239
--30110 13477 -30200 13703 -30267 13916 -30267 14107 -30236 14286 -30189 14462
--30127 14635 -30015 14791 -29852 14926 -29645 15046 -29386 15145 -29076 15221
--28717 15281 -28310 15321 -27864 15353 -27400 15373 -26899 15384 -26314 15374
--25664 15343 -24982 15302 -24300 15253 -23634 15203 -22966 15147 -22257 15074
--21508 14989 -20755 14894 -20022 14800 -19315 14713 -18625 14625 -17932 14516
--17236 14395 -16556 14271 -15891 14162 -15246 14080 -14613 14011 -13998 13920
--13393 13818 -12796 13728 -12209 13681 -11672 13678 -11144 13710 -10567 13756
--9968 13820 -9395 13914 -8893 14054 -8520 14234 -8218 14451 -7863 14715
--7497 15020 -7212 15360 -7092 15732 -7159 16128 -7373 16554 -7672 17030
--8056 17552 -8589 18103 -9297 18673 -10132 19242 -11128 19827 -12368 20469
--13823 21154 -15407 21859 -17047 22548 -18720 23209 -20460 23859 -22447 24558
--24448 25223 -26467 25880 -28547 26558 -30741 27239 -33054 27901 -35391 28538
--37650 29143 -39833 29674 -42058 30091 -44404 30376 -46883 30570 -49364 30733
--51707 30897 -53820 31056 -55786 31200 -57704 31308 -59492 31299 -61027 31078
--62263 30628 -63267 30037 -63995 29379 -64302 28663 -64098 27913 -63344 27202
--62185 26551 -60743 25836 -58808 24771 -56149 23063 -52745 20667 -48775 17757
--44637 14602 -40402 11502 -35851 8824 -31168 6752 -26743 5086 -22444 3450
--17675 1670 -12281 -184 -7079 -2102 -3113 -4263 -660 -6850 1070 -9737
-3419 -12372 6829 -13998 10491 -14095 13530 -12821 15361 -11001 15133 -9755
-12528 -9863 9032 -11363 6731 -13502 5921 -14958 4633 -14233 949 -10244
--4943 -2880 -11336 6586 -16351 15559 -17018 20833 -10817 19865 5020 9488
-7163 -5483 8579 -7210 8743 -5688 11020 -3872 9558 5095 -3173 5071 -3999 3290
-35099 -43062 3741 3642 13930 2235 -19031 1891 -2211 8507 14212 21852 -23170 2963
--5882 12389 74369 3690 -75424 10645 29155 -10539 -49304 24494 -21357 18548
--8601 11544 -7584 13872 -12206 14235 -7386 15802 18838 9747 49325 1481
-114045 -17602 123803 -17162 86323 4935 -19548 23196 -140361 36735 5332 16648
-71068 9273 38188 10227 18604 491 -21573 37857 80842 16348 145840 4191
--101408 4442 -117294 4776 -45651 7710 -29583 8233 -25227 8261 -21766 8358
--16613 8595 -10059 8836 -3269 8906 2650 8782 6936 8626 9142 8664 9143 9067
-7204 9830 4003 10775 642 11620 -1538 12051 -1149 11819 2925 10819 15762 9403
-27579 7761 36877 6050 42360 4331 43403 2592 40328 813 34421 -974 27358 -2668
-20647 -4187 15262 -5516 11557 -6720 9434 -7872 8519 -8991 8362 -10019
-8548 -10843 8780 -11384 8866 -11630 8711 -11648 8307 -11531 7636 -11330
-6674 -11042 5385 -10635 3722 -10109 1615 -9493 -944 -8817 -3929 -8087
--7233 -7301 -10726 -6457 -14255 -5562 -17675 -4620 -20890 -3654 -23826 -2662
--26452 -1634 -28756 -560 -30763 577 -32492 1788 -33952 3067 -35167 4400
--36153 5758 -36922 7118 -37487 8446 -37859 9734 -38039 10966 -38035 12132
--37871 13221 -37554 14213 -37108 15103 -36556 15888 -35913 16576 -35174 17171
--34365 17670 -33468 18064 -32484 18349 -31416 18538 -30264 18652 -29053 18708
--27801 18703 -26538 18627 -25319 18452 -24469 18192 -23567 17903 -22622 17583
--21681 17238 -20745 16872 -19832 16485 -18943 16083 -18091 15673 -17282 15257
--16530 14840 -15835 14430 -15207 14023 -14649 13630 -14165 13249 -13742 12881
--13396 12529 -13108 12197 -12890 11879 -12729 11583 -12634 11310 -12601 11057
--12626 10826 -12717 10618 -12854 10427 -13046 10259 -13284 10110 -13560 9984
--13871 9881 -14209 9802 -14572 9744 -14953 9709 -15339 9697 -15727 9707
--16109 9738 -16476 9790 -16826 9862 -17165 9955 -17468 10066 -17737 10196
--17974 10344 -18171 10509 -18336 10690 -18457 10885 -18525 11093 -18535 11309
--18478 11530 -18345 11756 -18146 11988 -17893 12222 -17604 12458 -17285 12697
--16933 12932 -16533 13157 -16049 13367 -15454 13555 -14717 13716 -13832 13847
--12818 13949 -11740 14026 -11070 14143 -10288 14222 -9399 14262 -8407 14258
--7338 14216 -6217 14137 -5077 14025 -3914 13876 -2724 13690 -1492 13468
--257 13216 961 12934 2137 12619 3290 12270 4424 11888 5538 11485 6632 11063
-7691 10617 8681 10149 9571 9666 10372 9176 11122 8676 11825 8167 12446 7657
-12929 7159 13268 6672 13499 6196 13650 5739 13710 5309 13621 4902 13403 4505
-13093 4119 12729 3771 12286 3482 11705 3258 10950 3081 10084 2922 9237 2777
-8479 2646 7774 2528 7011 2434 6100 2382 5083 2403 4128 2522 3441 2719 3148 2939
-3171 3104 3288 3167 3213 3137 2711 3072 1719 3046 371 3101 -1084 3241 -2362 3429
--3251 3629 -3671 3835 -3718 4067 -3566 4375 -3435 4797 1470 3630 2052 3592
--1286 4576 -7663 6453 -15424 9018 -22395 11979 -26295 14977 -25145 17570
--17720 19112 -4623 18448 9235 13508 12575 2289 1991 -8330 -9553 9587 -20738 7289
--20927 16128 51419 36861 -4110 973 14640 -6129 13568 -8360 20540 -1247
--18135 19387 -54460 4322 -33656 5950 99914 -14782 26963 10824 4618 2516
--2198 6371 6807 7216 1787 2835 48410 20715 3185 -875 -69114 1196 -16117 -25868
--9997 -43109 25260 14394 16573 18982 12321 36280 22302 66941 22491 74809
-15514 63670 8135 43811 1993 29955 -2487 21485 -5560 16678 -7655 14204
--9119 13135 -10211 12849 -11091 12943 -11860 13171 -12557 13404 -13227 13576
--13846 13668 -14429 13685 -14966 13640 -15460 13545 -15924 13417
-73: 10271140 -5834809 4860 5423 5150 5279 5470 5111 5830 4929 6200 4737
-6580 4548 6980 4362 7370 4168 7810 3964 8260 3751 8730 3536 9190 3325 9650 3122
-10120 2924 10620 2717 11120 2505 11630 2298 12140 2100 12600 1925 13080 1757
-13570 1584 14060 1414 14550 1256 15010 1117 15420 1005 15810 913 16220 822
-16620 739 16990 676 17320 643 17570 647 17790 675 18000 717 18200 776 18340 860
-18410 983 18410 1153 18330 1350 18220 1578 18080 1838 17860 2132 17550 2463
-17190 2824 16730 3230 16180 3693 15560 4198 14830 4745 14080 5310 13320 5846
-12490 6421 11500 7093 10370 7832 9250 8568 8150 9255 7100 9874 6110 10461
-5100 11063 4120 11670 3160 12233 2190 12729 1230 13170 260 13547 -660 13860
--1590 14120 -2500 14328 -3430 14497 -4360 14638 -5300 14737 -6220 14763
--7150 14735 -8080 14670 -9010 14585 -9950 14498 -10890 14381 -11870 14205
--12860 13984 -13860 13740 -14840 13501 -15760 13292 -16680 13078 -17670 12814
--18660 12518 -19630 12236 -20520 11986 -21350 11769 -22120 11583 -22810 11414
--23470 11263 -24050 11135 -24620 11028 -25140 10946 -25610 10885 -26000 10856
--26300 10852 -26570 10872 -26850 10906 -27130 10952 -27390 11018 -27620 11108
--27830 11221 -28020 11349 -28210 11492 -28390 11633 -28570 11788 -28760 11975
--28940 12185 -29110 12402 -29270 12615 -29390 12811 -29490 13005 -29620 13216
--29730 13440 -29830 13653 -29890 13853 -29892 14033 -29863 14199 -29815 14363
--29752 14525 -29642 14668 -29484 14795 -29279 14905 -29023 14995 -28719 15064
--28369 15117 -27976 15153 -27539 15178 -27084 15192 -26593 15197 -26021 15182
--25389 15143 -24730 15098 -24064 15043 -23411 14990 -22752 14928 -22052 14851
--21313 14758 -20565 14660 -19839 14561 -19134 14471 -18449 14383 -17750 14275
--17050 14153 -16359 14031 -15690 13926 -15041 13850 -14413 13788 -13789 13706
--13175 13616 -12575 13542 -11997 13508 -11464 13514 -10954 13559 -10401 13617
--9837 13692 -9303 13801 -8841 13953 -8509 14142 -8246 14371 -7953 14643
--7653 14956 -7442 15304 -7383 15686 -7496 16088 -7749 16521 -8097 17002
--8530 17532 -9103 18089 -9836 18666 -10690 19237 -11693 19824 -12918 20464
--14348 21151 -15894 21852 -17504 22539 -19141 23194 -20846 23837 -22807 24549
--24776 25213 -26746 25852 -28766 26499 -30911 27141 -33156 27763 -35444 28368
--37642 28955 -39761 29489 -41920 29926 -44169 30239 -46500 30446 -48832 30595
--51023 30714 -53003 30803 -54833 30879 -56606 30931 -58235 30895 -59627 30675
--60723 30250 -61543 29681 -62069 29017 -62211 28259 -61946 27406 -61236 26523
--60145 25662 -58737 24764 -56804 23626 -54194 22011 -50879 19853 -47080 17245
--43164 14335 -39178 11361 -34880 8668 -30438 6478 -26261 4664 -22323 2963
--18075 1270 -13223 -317 -8268 -1817 -4105 -3469 -1201 -5578 855 -8178
-3024 -10846 5624 -12852 8165 -13595 10325 -13058 11890 -11868 12089 -10959
-10460 -11002 8081 -12003 6682 -13261 6485 -13648 5726 -12052 2672 -7861
--2527 -1308 -8187 6377 -12244 13147 -12602 16621 -9606 14796 -1736 7182
-1760 -2097 4059 -4764 6782 -1883 9089 2662 7312 9143 -9 10895 -327 8025
-15597 -13353 33369 -44079 -11862 4712 -3952 9469 -1566 7774 -447 13664
--8169 7845 -7382 8818 -7104 3930 108954 -33722 63369 -13705 -146473 59447
--34277 24380 -8319 15048 -9257 13958 -22785 17509 12790 8253 1246 12289
-9302 11873 131116 -23600 138230 -25448 88185 9996 -22954 24902 -271970 49625
-54658 4959 127307 -332 -22066 10729 -120621 15443 204516 18788 25332 6233
-78046 12644 -42338 6676 -55220 8682 -35573 10066 -30902 9880 -30761 9241
--28152 8779 -21947 8599 -13793 8585 -5796 8547 651 8454 5000 8450 7029 8746
-6740 9465 4533 10531 1264 11696 -1704 12621 -2734 12977 -183 12533 7251 11250
-23292 9569 38685 7933 50898 6324 57718 4675 57878 2895 51813 947 41665 -1063
-30229 -2963 19861 -4630 11917 -6090 6773 -7425 4147 -8704 3409 -9905 3858 -10925
-4887 -11663 6055 -12094 7091 -12285 7851 -12341 8274 -12332 8332 -12233
-7969 -11993 7119 -11563 5702 -10968 3625 -10252 887 -9458 -2460 -8616
--6244 -7737 -10265 -6825 -14283 -5883 -18105 -4916 -21609 -3927 -24742 -2921
--27468 -1880 -29822 -784 -31838 379 -33548 1621 -34983 2944 -36156 4332
--37107 5756 -37838 7177 -38363 8574 -38692 9928 -38828 11222 -38782 12443
--38570 13578 -38199 14615 -37707 15538 -37105 16346 -36404 17047 -35614 17649
--34749 18148 -33800 18534 -32761 18805 -31643 18973 -30449 19063 -29182 19093
--27889 19063 -26585 18956 -25324 18746 -24436 18453 -23511 18129 -22560 17773
--21609 17393 -20664 16991 -19738 16572 -18840 16139 -17972 15699 -17150 15258
--16397 14822 -15700 14393 -15083 13972 -14528 13567 -14057 13174 -13647 12798
--13314 12441 -13035 12103 -12832 11786 -12691 11492 -12613 11221 -12608 10971
--12661 10742 -12779 10537 -12955 10349 -13187 10184 -13464 10041 -13782 9921
--14136 9825 -14516 9754 -14923 9704 -15341 9676 -15766 9672 -16194 9690
--16608 9728 -17010 9788 -17400 9870 -17769 9974 -18103 10093 -18409 10236
--18669 10396 -18888 10575 -19069 10769 -19196 10980 -19282 11204 -19291 11437
--19237 11675 -19099 11918 -18898 12167 -18638 12418 -18340 12674 -18012 12932
--17649 13186 -17230 13430 -16723 13660 -16103 13865 -15325 14042 -14388 14190
--13327 14306 -12183 14396 -11477 14525 -10651 14613 -9700 14660 -8651 14661
--7528 14622 -6360 14548 -5167 14434 -3931 14280 -2655 14086 -1352 13859
--55 13599 1207 13303 2443 12964 3668 12591 4891 12189 6088 11766 7249 11320
-8358 10845 9377 10343 10305 9826 11167 9300 11978 8762 12731 8217 13361 7676
-13835 7149 14160 6630 14394 6117 14558 5619 14617 5148 14510 4697 14246 4265
-13868 3854 13421 3496 12875 3202 12178 2967 11322 2759 10377 2565 9467 2388
-8633 2238 7814 2121 6915 2051 5883 2036 4818 2102 3907 2259 3322 2470 3114 2666
-3115 2773 3061 2763 2667 2666 1779 2567 462 2545 -1036 2639 -2390 2827
--3303 3053 -3614 3256 -3381 3407 -2825 3521 -2275 3648 -2057 3851 2841 2336
-2277 2230 -2739 3382 -10809 5624 -19972 8690 -27959 12224 -32439 15877
--31121 19372 -21769 22474 -2820 24607 21747 23455 27269 12373 2556 382
--16822 -3058 -35976 -13071 -22816 31855 22606 27657 -12498 -12151 51409 -6998
--14256 -14175 36474 -7601 851 6151 -24960 -1958 -5341 -8078 67363 -4185
--1522 43419 -2495 -4287 6030 5238 -293 6898 10071 6655 17356 12914 5576 8699
--18852 12220 21643 8404 24186 2540 -21664 -20689 -10356 3107 -258 28626
-9112 52559 12367 63296 10401 59733 7107 39966 2849 29642 -891 22997 -3818 18785
--6041 16308 -7728 14999 -9041 14406 -10113 14206 -11032 14188 -11840 14224
--12588 14246 -13262 14227 -13886 14162 -14449 14057 -14962 13917 -15440 13753
-74: 10300630 -5825384 4560 5523 4840 5382 5150 5216 5490 5039 5860 4854
-6220 4669 6600 4486 6990 4299 7410 4101 7840 3894 8290 3681 8750 3477 9180 3281
-9630 3088 10110 2888 10590 2685 11090 2483 11560 2291 12020 2122 12470 1963
-12930 1793 13410 1630 13880 1479 14310 1349 14700 1242 15080 1156 15450 1071
-15830 993 16180 938 16490 910 16720 919 16920 951 17120 998 17280 1061
-17420 1149 17470 1275 17440 1442 17370 1643 17250 1869 17100 2124 16870 2415
-16560 2743 16200 3096 15750 3486 15220 3935 14610 4425 13920 4955 13190 5495
-12460 6013 11660 6558 10720 7195 9670 7891 8600 8584 7570 9233 6570 9816
-5600 10375 4630 10947 3670 11522 2730 12061 1780 12539 840 12960 -110 13326
--1010 13632 -1930 13892 -2830 14104 -3730 14279 -4650 14427 -5560 14529
--6470 14568 -7380 14556 -8280 14503 -9190 14434 -10100 14362 -11020 14261
--11960 14105 -12910 13906 -13870 13682 -14810 13467 -15690 13274 -16570 13078
--17500 12837 -18440 12567 -19350 12309 -20190 12077 -20980 11878 -21710 11703
--22380 11542 -23010 11398 -23590 11272 -24120 11167 -24640 11086 -25110 11028
--25500 10997 -25810 10988 -26100 11003 -26380 11032 -26670 11075 -26940 11133
--27180 11216 -27400 11323 -27600 11446 -27800 11580 -27990 11710 -28180 11855
--28360 12030 -28560 12228 -28720 12431 -28890 12631 -29020 12813 -29120 12999
--29240 13195 -29360 13402 -29456 13606 -29510 13792 -29518 13962 -29487 14115
--29443 14270 -29378 14417 -29271 14551 -29118 14670 -28917 14769 -28666 14852
--28369 14914 -28028 14959 -27644 14988 -27219 15007 -26773 15017 -26292 15016
--25734 14991 -25118 14950 -24475 14897 -23824 14840 -23184 14778 -22532 14714
--21842 14633 -21112 14533 -20371 14431 -19647 14328 -18949 14236 -18263 14147
--17568 14040 -16863 13918 -16163 13801 -15491 13698 -14844 13625 -14219 13569
--13592 13496 -12976 13417 -12374 13357 -11800 13335 -11280 13351 -10787 13406
--10265 13474 -9727 13563 -9236 13683 -8810 13844 -8513 14043 -8292 14283
--8052 14561 -7813 14884 -7665 15240 -7661 15628 -7818 16036 -8110 16475
--8496 16963 -8973 17497 -9580 18059 -10339 18637 -11208 19214 -12215 19800
--13432 20439 -14837 21126 -16353 21824 -17934 22505 -19540 23154 -21207 23790
--23123 24505 -25049 25165 -26982 25797 -28953 26422 -31042 27031 -33226 27616
--35439 28184 -37580 28742 -39637 29260 -41720 29702 -43870 30032 -46080 30254
--48267 30402 -50318 30489 -52163 30530 -53866 30540 -55482 30536 -56966 30458
--58236 30227 -59218 29809 -59905 29251 -60254 28595 -60234 27830 -59875 26931
--59152 25941 -58109 24921 -56744 23864 -54870 22641 -52354 21074 -49172 19106
--45547 16765 -41845 14109 -38086 11303 -34015 8657 -29761 6394 -25740 4456
--22051 2646 -18251 937 -13958 -553 -9400 -1812 -5250 -3088 -2046 -4735
-353 -6942 2562 -9431 4757 -11566 6613 -12716 8159 -12733 9417 -12050 9748 -11425
-8659 -11435 6950 -12089 6092 -12797 6314 -12621 6110 -10741 3967 -6814
--99 -1224 -4684 4921 -7999 10016 -8604 12401 -8615 10861 -4822 6036 -1508 843
-1394 -730 4325 1624 6321 5649 5772 9614 3347 9876 5159 4250 14603 -11673
-23034 -29169 1277 -4703 -3898 8145 -4780 8395 -4713 9565 -5497 10454 -4595 8095
-6449 -1239 67616 -18046 20365 1954 -92924 42003 -10594 13361 -3057 15951
--10403 15915 13552 7081 145961 -25529 -108539 34698 -59250 27165 115140 -7139
-157273 -14841 -101780 22967 -27570 19494 -119057 20859 62037 -1646 221494 -8047
-22742 9323 -56052 12021 49708 16587 -6012 11061 8774 13269 4025 12709
--13752 13149 -25246 12742 -37225 11277 -42447 9727 -39019 8636 -29529 8075
--18171 7972 -8328 8060 -1390 8196 2913 8461 4786 9052 4294 10055 1859 11345
--1488 12621 -4090 13520 -3969 13719 891 13041 12075 11532 32645 9766 53023 8345
-69440 7027 78291 5560 77123 3707 66357 1429 49764 -1013 32067 -3294 16816 -5251
-5767 -6922 -862 -8417 -3734 -9785 -3898 -10970 -2399 -11876 -101 -12461
-2388 -12795 4703 -13014 6646 -13201 8129 -13345 9095 -13339 9483 -13084
-9175 -12561 8056 -11815 6005 -10934 3014 -9985 -822 -9023 -5258 -8064
--9944 -7110 -14553 -6148 -18821 -5167 -22615 -4169 -25894 -3149 -28668 -2094
--31011 -992 -32984 187 -34633 1456 -36014 2815 -37139 4254 -38039 5736
--38723 7230 -39205 8703 -39488 10126 -39583 11489 -39484 12774 -39224 13967
--38804 15049 -38255 16002 -37597 16829 -36837 17545 -35991 18150 -35069 18644
--34063 19017 -32970 19270 -31806 19415 -30562 19478 -29253 19481 -27913 19419
--26574 19275 -25276 19029 -24350 18701 -23408 18338 -22450 17942 -21489 17523
--20535 17085 -19590 16628 -18670 16163 -17793 15696 -16968 15233 -16214 14775
--15530 14329 -14924 13895 -14380 13477 -13919 13074 -13521 12691 -13196 12331
--12930 11991 -12737 11676 -12617 11383 -12568 11115 -12587 10868 -12672 10642
--12823 10440 -13043 10257 -13310 10097 -13629 9964 -13992 9851 -14385 9762
--14815 9699 -15265 9658 -15721 9638 -16187 9639 -16649 9664 -17105 9711
--17553 9779 -17981 9870 -18387 9985 -18759 10117 -19096 10272 -19377 10443
--19616 10637 -19810 10845 -19955 11075 -20047 11312 -20065 11561 -20015 11820
--19881 12080 -19679 12347 -19410 12619 -19107 12893 -18766 13172 -18394 13445
--17954 13712 -17428 13961 -16777 14185 -15957 14382 -14977 14545 -13856 14677
--12652 14780 -11906 14923 -11026 15022 -10022 15074 -8921 15082 -7754 15050
--6534 14979 -5270 14864 -3957 14704 -2594 14507 -1230 14276 115 14002
-1435 13686 2748 13324 4070 12931 5386 12514 6655 12068 7873 11594 9016 11082
-10080 10546 11062 9997 11998 9434 12879 8860 13671 8279 14301 7709 14764 7148
-15090 6588 15348 6027 15537 5484 15600 4967 15455 4481 15127 4017 14667 3593
-14125 3226 13473 2919 12672 2657 11731 2413 10717 2184 9738 1987 8798 1842
-7847 1750 6805 1714 5663 1738 4557 1837 3677 2007 3137 2204 2915 2359 2784 2403
-2460 2332 1714 2199 498 2101 -1001 2119 -2447 2277 -3456 2531 -3768 2798
--3322 2987 -2315 3054 -1147 2993 -294 2859 -191 2748 3794 959 1738 752
--4856 2011 -14140 4580 -23978 8129 -32321 12190 -37198 16370 -36537 20520
--27534 24938 -4775 30435 38093 36822 50345 23600 3328 13040 -13306 1721
--47001 -22765 -37891 28975 -16678 1084 -26145 -44075 37390 7029 20077 59
-60165 -16997 18143 -7287 -10274 -1152 -4541 7487 5492 10746 1452 10869
-18740 4932 9166 9670 2827 633 11682 8101 6845 8114 3940 13720 1548 8653
-7738 7726 8259 5522 -4460 1301 -5785 10663 -1645 27454 3614 43857 6479 52522
-6463 50829 4924 39392 2313 30720 -444 24771 -2921 20820 -4997 18314 -6699 16810
--8091 15963 -9262 15505 -10269 15255 -11153 15100 -11959 14969 -12678 14836
--13331 14684 -13915 14511 -14444 14321 -14937 14117
-75: 10330020 -5815939 4260 5625 4520 5488 4820 5326 5150 5154 5500 4973
-5860 4793 6210 4614 6600 4435 6990 4241 7410 4040 7850 3832 8280 3634 8690 3445
-9140 3258 9590 3063 10050 2868 10530 2671 10990 2487 11410 2323 11850 2171
-12300 2011 12740 1852 13190 1707 13600 1583 13980 1484 14320 1400 14680 1321
-15040 1253 15360 1201 15650 1180 15860 1193 16050 1229 16230 1278 16370 1347
-16480 1436 16530 1566 16490 1732 16410 1931 16280 2154 16110 2406 15890 2695
-15590 3015 15220 3357 14790 3737 14270 4171 13680 4643 13020 5153 12310 5672
-11610 6168 10850 6689 9960 7293 8950 7946 7950 8600 6980 9213 6020 9763
-5090 10296 4150 10841 3220 11387 2290 11898 1360 12355 450 12763 -480 13116
--1360 13416 -2260 13674 -3150 13889 -4030 14068 -4930 14217 -5810 14326
--6710 14376 -7580 14375 -8480 14339 -9360 14283 -10240 14224 -11120 14138
--12030 14002 -12940 13819 -13870 13619 -14760 13423 -15610 13249 -16450 13069
--17320 12850 -18220 12602 -19060 12364 -19870 12150 -20620 11967 -21320 11806
--21960 11653 -22560 11513 -23130 11391 -23650 11293 -24150 11212 -24610 11158
--25000 11122 -25330 11115 -25620 11123 -25910 11149 -26200 11185 -26490 11239
--26730 11317 -26960 11417 -27180 11532 -27380 11660 -27570 11781 -27780 11917
--27960 12081 -28160 12265 -28340 12457 -28500 12644 -28630 12816 -28740 12988
--28860 13174 -28980 13369 -29077 13560 -29134 13734 -29141 13892 -29114 14037
--29072 14178 -29011 14316 -28905 14440 -28753 14548 -28558 14637 -28316 14714
--28027 14769 -27691 14806 -27316 14830 -26902 14842 -26466 14846 -25993 14838
--25452 14808 -24848 14760 -24218 14703 -23582 14636 -22953 14575 -22312 14504
--21628 14418 -20902 14315 -20176 14208 -19453 14101 -18759 14009 -18077 13918
--17383 13811 -16673 13690 -15970 13575 -15297 13476 -14654 13406 -14033 13355
--13409 13293 -12789 13222 -12191 13173 -11622 13160 -11118 13187 -10642 13251
--10148 13329 -9641 13430 -9178 13559 -8796 13730 -8533 13938 -8347 14185
--8157 14473 -7972 14803 -7881 15166 -7931 15558 -8125 15974 -8451 16417
--8873 16909 -9386 17447 -10027 18014 -10804 18593 -11688 19171 -12699 19758
--13907 20396 -15294 21080 -16782 21773 -18337 22450 -19909 23093 -21544 23720
--23401 24425 -25290 25085 -27180 25712 -29109 26324 -31138 26910 -33254 27461
--35396 27995 -37471 28517 -39464 29009 -41469 29438 -43528 29774 -45620 30008
--47673 30159 -49592 30228 -51311 30232 -52887 30190 -54359 30132 -55702 30013
--56846 29753 -57738 29327 -58324 28772 -58544 28122 -58392 27364 -57922 26460
--57149 25420 -56125 24298 -54801 23116 -52994 21806 -50597 20258 -47564 18430
--44128 16315 -40638 13899 -37100 11293 -33260 8750 -29174 6477 -25261 4451
--21716 2545 -18246 762 -14456 -747 -10362 -1920 -6408 -2955 -3088 -4224
--430 -6005 1939 -8188 3987 -10263 5494 -11627 6654 -12029 7660 -11737
-8013 -11343 7237 -11346 5921 -11775 5314 -12159 5704 -11750 5933 -9931
-4698 -6508 1845 -1882 -1615 3012 -4286 6960 -5135 8846 -7136 7928 -5591 5224
--3041 2626 -270 2080 2445 3837 4450 6526 5204 8370 5545 7062 8119 1040
-13555 -9916 16568 -18721 7144 -9157 -3943 8476 -5967 10563 -3425 8937
--2236 9679 -5887 9219 4077 3357 28974 -3999 3988 7000 -38446 22686 -7472 12495
-399 12083 -26963 14622 284 6158 69220 -3803 -59938 23718 -43338 24868
-12792 13911 243 14254 36070 -1711 10062 12593 -22512 2027 -7796 367 152569 -6547
-178594 -1705 -74452 12650 5990 11138 34262 7835 20926 12100 20929 17366
-6510 17362 -23784 15356 -52215 12186 -60467 9538 -52827 7822 -37099 6948
--20940 7080 -9194 7613 -2722 8182 1023 8744 2723 9546 2109 10711 -573 12098
--4161 13374 -6695 14161 -5734 14176 1214 13319 16207 11729 42995 10169
-70195 9249 92843 8478 105214 7308 102445 5294 84442 2400 58270 -822 31952 -3782
-10632 -6222 -3786 -8192 -11604 -9828 -14200 -11189 -13201 -12227 -10114 -12907
--6088 -13307 -1902 -13596 1977 -13923 5314 -14299 8019 -14581 10041 -14590
-11297 -14216 11630 -13486 10870 -12509 8842 -11419 5502 -10324 997 -9286
--4297 -8310 -9855 -7367 -15168 -6418 -19911 -5440 -23952 -4436 -27287 -3402
--30025 -2340 -32282 -1228 -34150 -35 -35712 1255 -37016 2652 -38081 4142
--38928 5698 -39573 7279 -40010 8835 -40250 10346 -40297 11789 -40152 13147
--39836 14398 -39358 15520 -38748 16503 -38029 17351 -37206 18072 -36302 18673
--35318 19159 -34254 19517 -33116 19749 -31901 19866 -30608 19897 -29257 19865
--27872 19766 -26500 19584 -25171 19298 -24214 18931 -23261 18524 -22289 18084
--21315 17624 -20338 17144 -19377 16654 -18439 16157 -17557 15663 -16739 15176
--15996 14701 -15328 14238 -14730 13791 -14204 13360 -13749 12947 -13353 12560
--13035 12197 -12786 11858 -12612 11544 -12510 11255 -12492 10991 -12542 10746
--12662 10526 -12852 10329 -13107 10151 -13416 10002 -13776 9874 -14182 9773
--14625 9693 -15091 9638 -15585 9603 -16089 9589 -16593 9599 -17103 9629
--17608 9685 -18101 9763 -18577 9864 -19022 9989 -19433 10135 -19785 10302
--20097 10487 -20351 10693 -20562 10921 -20722 11163 -20826 11419 -20862 11685
--20819 11961 -20695 12241 -20490 12528 -20214 12820 -19904 13116 -19552 13415
--19159 13712 -18709 13999 -18158 14269 -17479 14516 -16618 14732 -15589 14913
--14415 15062 -13144 15179 -12353 15336 -11427 15444 -10377 15507 -9232 15525
--8013 15502 -6735 15433 -5388 15313 -3987 15151 -2555 14955 -1138 14714
-258 14422 1658 14083 3076 13704 4504 13296 5899 12861 7222 12392 8479 11881
-9664 11332 10789 10762 11857 10181 12871 9584 13819 8971 14629 8355 15261 7750
-15719 7146 16080 6534 16383 5920 16601 5330 16646 4776 16444 4261 16028 3777
-15476 3338 14847 2954 14107 2624 13226 2323 12201 2039 11107 1789 10029 1593
-8959 1472 7852 1415 6656 1413 5405 1460 4254 1569 3357 1728 2792 1895 2458 2002
-2113 2002 1480 1903 430 1774 -986 1719 -2474 1809 -3634 2052 -4077 2381
--3610 2683 -2294 2849 -478 2800 1277 2517 2314 2052 2090 1524 4381 -492
-567 -882 -7460 384 -17332 3232 -26756 7275 -34236 11809 -38433 16259 -37958 20378
--31368 24463 -13161 29884 49849 44894 61829 13139 5970 18628 -603 19297
--18317 13663 -46008 2494 -56217 -22951 -44804 -37334 8386 -4927 38751 -1341
-82990 -21119 16453 -8132 -23002 5447 -6083 7044 6751 2313 11250 2300 16358 28377
-6653 10449 2758 -2623 10235 7290 10298 13145 3036 6720 3479 5385 -1456 2847
-149 6691 -3333 11470 -904 18172 80 28781 2046 39229 3538 45086 3786 44331
-2970 37977 1341 31508 -633 26396 -2608 22711 -4419 20188 -6000 18530 -7376 17466
--8557 16783 -9596 16326 -10520 15993 -11352 15719 -12100 15471 -12773 15231
--13378 14991 -13921 14746 -14421 14499
-76: 10359340 -5806477 3940 5730 4190 5598 4490 5440 4790 5270 5140 5096
-5480 4919 5830 4746 6180 4575 6570 4383 6970 4188 7390 3988 7810 3797 8210 3614
-8620 3431 9060 3242 9510 3050 9960 2864 10400 2689 10810 2531 11210 2381
-11650 2228 12070 2076 12500 1938 12890 1822 13240 1728 13560 1649 13910 1575
-14230 1513 14540 1467 14810 1451 15010 1465 15170 1506 15330 1557 15470 1629
-15550 1723 15590 1853 15550 2017 15450 2214 15320 2434 15140 2683 14920 2965
-14610 3281 14270 3609 13840 3979 13340 4397 12770 4854 12120 5342 11450 5840
-10780 6316 10050 6814 9190 7383 8260 8001 7310 8615 6370 9194 5460 9719
-4570 10224 3660 10741 2760 11260 1850 11750 950 12185 40 12576 -830 12917
--1720 13212 -2580 13468 -3460 13683 -4330 13861 -5200 14016 -6050 14130
--6940 14186 -7780 14196 -8650 14173 -9520 14133 -10360 14087 -11220 14016
--12090 13893 -12960 13730 -13850 13551 -14700 13373 -15510 13216 -16320 13051
--17150 12851 -17980 12627 -18800 12404 -19550 12208 -20260 12041 -20930 11892
--21560 11749 -22130 11613 -22670 11496 -23190 11402 -23670 11325 -24120 11271
--24510 11238 -24840 11226 -25140 11230 -25450 11256 -25730 11286 -26030 11336
--26290 11409 -26510 11503 -26740 11611 -26960 11731 -27150 11845 -27370 11971
--27560 12127 -27750 12300 -27940 12479 -28110 12656 -28230 12818 -28360 12977
--28480 13152 -28600 13337 -28699 13515 -28755 13677 -28764 13825 -28742 13958
--28701 14091 -28645 14220 -28542 14334 -28394 14430 -28201 14513 -27970 14581
--27689 14627 -27361 14659 -26991 14676 -26590 14682 -26162 14679 -25700 14666
--25167 14631 -24582 14576 -23963 14511 -23336 14441 -22719 14374 -22089 14301
--21416 14210 -20693 14103 -19974 13989 -19258 13881 -18569 13787 -17891 13696
--17197 13588 -16486 13469 -15783 13356 -15110 13259 -14468 13194 -13853 13146
--13236 13091 -12616 13029 -12021 12989 -11463 12986 -10972 13023 -10517 13095
--10042 13182 -9571 13291 -9136 13430 -8793 13612 -8562 13827 -8409 14082
--8262 14375 -8132 14712 -8093 15081 -8184 15479 -8419 15901 -8773 16345
--9228 16841 -9776 17386 -10441 17954 -11235 18535 -12132 19111 -13146 19698
--14347 20333 -15714 21014 -17182 21704 -18706 22376 -20248 23009 -21847 23628
--23663 24321 -25506 24975 -27350 25602 -29230 26204 -31206 26771 -33253 27301
--35329 27802 -37323 28287 -39257 28746 -41171 29156 -43143 29485 -45124 29722
--47057 29874 -48853 29936 -50456 29911 -51907 29833 -53251 29727 -54456 29568
--55477 29279 -56274 28832 -56785 28265 -56919 27616 -56670 26868 -56099 25980
--55264 24933 -54230 23757 -52927 22491 -51192 21111 -48910 19564 -46041 17830
--42792 15893 -39498 13698 -36182 11297 -32584 8895 -28690 6670 -24870 4621
--21394 2654 -18125 791 -14741 -798 -11105 -2001 -7460 -2930 -4195 -3924
--1390 -5319 1114 -7146 3179 -9038 4560 -10459 5527 -11107 6370 -11102
-6745 -10894 6198 -10897 5131 -11171 4590 -11371 4948 -10913 5401 -9325
-4881 -6480 3103 -2739 676 1163 -1362 4324 -2262 6004 -5208 5609 -4986 4335
--3292 3307 -1000 3445 1377 4769 3408 6364 4897 6900 6339 5010 8655 120
-11490 -6642 11941 -10610 6489 -5384 -1011 5215 -3848 9071 -3283 9375 -3250 9963
--6054 9954 -3776 8877 9847 2948 -1884 8540 -14742 13419 -7046 10329 -6588 10190
--8770 12084 -14765 9237 11130 11647 -18767 15488 -28358 17046 -9062 12991
-3738 7343 44524 -5684 3567 12585 2677 4160 37675 -1568 166034 -16568 15672 4902
--180807 30916 87026 6208 137176 341 44891 9472 37839 22941 22864 20692
--30177 17372 -78580 12131 -82632 8548 -65572 6447 -40456 5208 -18556 6096
--6098 7453 -2982 8605 -667 9315 1056 10102 545 11240 -2459 12586 -6670 13772
--9730 14430 -8647 14302 -329 13379 17979 11914 52629 10930 88747 10860
-120687 10937 139701 10270 135874 8027 106515 4048 66194 -545 28558 -4623
-383 -7765 -17057 -10076 -25289 -11773 -26756 -12972 -23871 -13694 -18633 -14053
--12465 -14262 -6320 -14569 -705 -15064 4133 -15625 8133 -15965 11273 -15854
-13477 -15213 14553 -14154 14238 -12883 12250 -11598 8467 -10437 3056 -9433
--3419 -8546 -10108 -7692 -16258 -6798 -21470 -5841 -25645 -4822 -28910 -3769
--31485 -2688 -33555 -1554 -35272 -342 -36715 982 -37937 2429 -38952 4001
--39766 5652 -40377 7331 -40778 8997 -40982 10610 -40976 12145 -40784 13572
--40407 14874 -39868 16036 -39191 17050 -38399 17907 -37515 18627 -36542 19224
--35497 19696 -34381 20035 -33190 20239 -31924 20321 -30585 20313 -29193 20242
--27772 20104 -26361 19882 -24998 19550 -24029 19135 -23063 18679 -22076 18196
--21074 17691 -20071 17172 -19090 16645 -18147 16120 -17278 15599 -16477 15092
--15747 14596 -15096 14118 -14506 13653 -13987 13213 -13534 12792 -13147 12402
--12835 12038 -12601 11701 -12448 11390 -12378 11105 -12390 10844 -12474 10605
--12631 10390 -12858 10202 -13144 10037 -13493 9896 -13893 9779 -14345 9686
--14834 9615 -15352 9566 -15886 9537 -16437 9531 -16997 9546 -17562 9586
--18118 9650 -18665 9738 -19182 9852 -19667 9987 -20108 10147 -20486 10328
--20816 10525 -21098 10747 -21330 10990 -21504 11248 -21631 11522 -21688 11804
--21658 12100 -21534 12401 -21326 12708 -21046 13023 -20726 13341 -20362 13663
--19953 13983 -19487 14292 -18917 14587 -18205 14853 -17305 15090 -16226 15293
--14999 15460 -13666 15593 -12835 15763 -11865 15884 -10778 15962 -9584 15993
--8308 15976 -6948 15904 -5511 15784 -4034 15626 -2546 15423 -1073 15168
-396 14857 1900 14503 3429 14111 4945 13689 6397 13232 7760 12731 9059 12181
-10311 11598 11525 10997 12686 10384 13789 9747 14781 9094 15609 8437 16242 7789
-16726 7134 17140 6465 17506 5797 17740 5167 17740 4588 17452 4051 16943 3548
-16309 3086 15614 2671 14816 2302 13857 1960 12741 1646 11538 1390 10313 1213
-9080 1124 7796 1102 6444 1119 5081 1171 3854 1266 2895 1398 2226 1533 1710 1612
-1110 1600 202 1518 -1044 1440 -2484 1468 -3750 1655 -4415 1991 -4140 2390
--2807 2723 -599 2856 2002 2687 4292 2169 5448 1327 4742 289 4831 -1962
--1006 -2694 -10510 -1596 -20502 1492 -28218 6153 -33231 11195 -34710 15846
--30546 19767 -18666 23630 5869 28192 44438 31129 15341 1232 12801 31406
-19756 32294 -10662 26591 -32123 -2039 -87179 -37094 -72414 -36290 -14600 -6664
-25768 3840 80400 -28169 34240 8231 -4102 5088 3042 1298 -2802 -3990 -3019 -4307
-6761 12073 8319 13921 13639 10146 14091 12664 11632 13960 6635 9187 4804 6204
-1330 4583 -4700 8229 -3843 15020 -1200 22344 38 30128 1075 36911 1824 40622
-1965 40217 1448 36436 356 31783 -1074 27594 -2624 24277 -4150 21823 -5562 20076
--6844 18851 -7992 17986 -9014 17354 -9942 16866 -10781 16463 -11540 16109
--12228 15786 -12837 15480 -13396 15183 -13899 14893
-77: 10388590 -5797003 3620 5839 3850 5707 4140 5555 4440 5391 4760 5221
-5100 5050 5420 4883 5770 4714 6140 4530 6530 4342 6930 4148 7320 3961 7710 3784
-8110 3610 8530 3424 8950 3239 9380 3060 9800 2889 10200 2736 10580 2598
-10990 2449 11400 2304 11790 2172 12170 2061 12500 1974 12810 1899 13120 1831
-13440 1773 13710 1732 13960 1720 14150 1739 14310 1781 14440 1835 14560 1909
-14630 2005 14660 2134 14600 2298 14510 2490 14370 2710 14190 2952 13960 3229
-13660 3538 13320 3856 12910 4212 12420 4613 11870 5054 11250 5525 10600 6000
-9970 6456 9250 6931 8450 7473 7570 8051 6650 8632 5770 9180 4910 9677 4040 10158
-3170 10651 2290 11143 1410 11608 530 12026 -340 12400 -1210 12730 -2060 13019
--2910 13273 -3760 13484 -4610 13665 -5460 13824 -6300 13939 -7150 14003
--7970 14024 -8830 14012 -9650 13982 -10470 13951 -11300 13890 -12130 13785
--12980 13639 -13820 13476 -14630 13315 -15420 13175 -16180 13027 -16960 12846
--17760 12636 -18530 12435 -19240 12254 -19920 12099 -20550 11961 -21150 11827
--21700 11700 -22240 11589 -22730 11497 -23200 11424 -23640 11371 -24030 11339
--24360 11327 -24670 11329 -24980 11350 -25270 11377 -25570 11422 -25830 11493
--26070 11580 -26310 11682 -26520 11794 -26730 11901 -26950 12023 -27140 12168
--27350 12332 -27540 12498 -27710 12665 -27850 12816 -27960 12965 -28100 13131
--28220 13304 -28314 13471 -28374 13623 -28391 13759 -28372 13884 -28333 14008
--28276 14127 -28182 14230 -28038 14319 -27852 14393 -27626 14451 -27353 14492
--27036 14518 -26674 14527 -26279 14527 -25864 14518 -25406 14498 -24887 14459
--24314 14396 -23710 14326 -23092 14252 -22485 14180 -21866 14102 -21201 14007
--20486 13895 -19768 13779 -19061 13667 -18380 13571 -17707 13479 -17010 13372
--16304 13254 -15600 13140 -14925 13050 -14291 12986 -13683 12942 -13070 12892
--12456 12841 -11865 12807 -11319 12813 -10841 12857 -10404 12937 -9955 13032
--9509 13150 -9110 13298 -8796 13487 -8600 13710 -8476 13971 -8366 14269
--8289 14613 -8296 14988 -8426 15390 -8695 15815 -9077 16264 -9562 16761
--10136 17310 -10830 17879 -11640 18460 -12544 19038 -13558 19620 -14751 20255
--16101 20932 -17545 21615 -19044 22281 -20556 22908 -22118 23520 -23912 24198
--25707 24841 -27499 25465 -29327 26062 -31240 26615 -33225 27129 -35229 27603
--37158 28055 -39011 28483 -40850 28866 -42727 29178 -44603 29410 -46423 29561
--48100 29616 -49598 29575 -50940 29470 -52162 29328 -53237 29130 -54137 28814
--54840 28344 -55289 27759 -55360 27097 -55045 26358 -54401 25491 -53509 24459
--52453 23273 -51156 21968 -49477 20538 -47302 18983 -44587 17312 -41518 15506
--38411 13498 -35301 11296 -31946 9051 -28272 6920 -24568 4907 -21131 2934
--17973 1024 -14868 -662 -11621 -1961 -8332 -2892 -5245 -3729 -2429 -4817
-158 -6296 2286 -7942 3677 -9315 4587 -10091 5354 -10287 5780 -10217 5456 -10221
-4601 -10386 4058 -10471 4270 -10039 4741 -8726 4674 -6443 3708 -3470 2152 -366
-720 2219 -45 3782 -3109 3697 -3633 3303 -2679 3192 -973 3749 989 4829 2878 5791
-4554 5767 6181 4044 7927 608 9283 -3308 8790 -5002 5306 -1937 624 3988
--2098 7576 -2917 8974 -3591 9729 -4812 9876 -3717 9224 -2139 7578 -7293 10676
--4896 9721 -4202 8631 -5467 9094 -7988 10464 -14944 12383 -12653 10776
-442 13056 -13966 12536 -6080 9734 5753 5083 16334 1307 3010 9237 803 7399
-7864 5217 14238 1488 24984 1833 -58191 16881 83720 5054 226792 -6876 15687 6326
-42131 30595 33381 20646 -44898 18577 -117918 10726 -99283 7053 -69257 5165
--33706 2766 -6959 5374 3498 7851 -3589 9675 -2961 10091 -33 10487 63 11411
--3435 12618 -8865 13699 -13338 14276 -13256 14104 -4862 13258 15456 12119
-58706 12082 105444 13191 150908 14536 182876 14830 181077 12470 132651 6553
-71529 -362 20158 -6118 -14567 -10131 -33731 -12721 -41007 -14292 -40272 -15095
--34764 -15329 -26923 -15289 -18374 -15335 -10184 -15721 -2858 -16418
-3413 -17104 8630 -17375 12860 -16961 16046 -15874 17978 -14365 18240 -12777
-16375 -11386 12071 -10321 5444 -9538 -2680 -8878 -10884 -8204 -18007 -7407
--23583 -6473 -27701 -5433 -30688 -4338 -32928 -3207 -34719 -2032 -36229 -770
--37564 615 -38724 2155 -39727 3836 -40538 5608 -41139 7416 -41519 9208
--41692 10932 -41640 12546 -41385 14040 -40945 15397 -40333 16600 -39583 17630
--38717 18493 -37760 19211 -36724 19800 -35613 20254 -34442 20562 -33200 20731
--31878 20774 -30493 20725 -29061 20611 -27601 20432 -26153 20166 -24760 19783
--23794 19307 -22805 18801 -21786 18272 -20756 17726 -19730 17167 -18745 16607
--17816 16051 -16962 15508 -16186 14974 -15472 14458 -14826 13960 -14246 13481
--13724 13029 -13266 12605 -12893 12212 -12595 11849 -12380 11515 -12260 11209
--12221 10930 -12263 10674 -12376 10444 -12568 10239 -12827 10062 -13145 9911
--13532 9782 -13981 9674 -14474 9589 -15013 9524 -15581 9482 -16171 9460
--16782 9460 -17403 9484 -18026 9532 -18643 9608 -19241 9707 -19794 9834
--20315 9981 -20785 10153 -21191 10345 -21549 10559 -21850 10795 -22113 11054
--22320 11328 -22471 11619 -22545 11920 -22518 12235 -22404 12557 -22190 12887
--21902 13224 -21565 13567 -21192 13914 -20769 14258 -20291 14591 -19698 14909
--18956 15200 -18022 15459 -16898 15684 -15611 15871 -14218 16022 -13360 16206
--12352 16346 -11220 16440 -9970 16482 -8621 16466 -7170 16395 -5649 16279
--4108 16121 -2566 15911 -1027 15640 543 15315 2160 14950 3790 14549 5364 14109
-6849 13623 8254 13083 9621 12497 10978 11883 12298 11253 13562 10603 14737 9920
-15764 9221 16599 8520 17249 7823 17792 7109 18285 6383 18712 5672 18939 5015
-18865 4415 18474 3858 17881 3323 17197 2819 16464 2359 15616 1944 14577 1566
-13341 1239 11977 991 10561 844 9126 789 7658 788 6147 806 4667 843 3340 911
-2266 1016 1435 1135 691 1220 -152 1243 -1241 1230 -2533 1252 -3807 1388
--4662 1681 -4694 2101 -3652 2555 -1490 2905 1527 3013 4825 2757 7619 2044
-8942 848 7813 -742 5571 -3304 -2608 -4641 -14225 -4009 -24572 -764 -29204 4834
--30623 10430 -29354 15106 -22001 17940 -9443 19969 9328 21333 26629 19648
-14517 7435 23198 25257 18011 21011 3037 29053 -49807 -4353 -108462 -37293
--93160 -37002 -6639 -3910 38681 -1136 60384 -20979 28460 29888 -368 8231
--2610 3488 1582 -1182 -2196 4705 2513 492 -2311 -934 22172 12961 16321 14967
-12336 14843 9485 12315 8548 9545 5273 6996 -8557 8165 -3751 18200 -1741 25575
--644 31506 110 35934 578 38133 658 37716 288 35174 -487 31747 -1553 28357
--2780 25451 -4048 23142 -5285 21382 -6450 20062 -7525 19068 -8507 18299
--9417 17685 -10246 17172 -11006 16728 -11694 16330 -12308 15964 -12864 15618
--13377 15286
-78: 10417770 -5787519 3290 5947 3520 5821 3780 5674 4080 5514 4380 5350
-4710 5181 5010 5021 5350 4859 5700 4680 6080 4496 6460 4310 6830 4129 7210 3958
-7590 3788 7980 3610 8390 3431 8810 3259 9200 3092 9570 2949 9940 2812 10330 2672
-10720 2535 11090 2407 11440 2300 11760 2219 12040 2149 12350 2090 12630 2033
-12900 1998 13120 1989 13300 2011 13430 2053 13560 2111 13650 2185 13730 2283
-13720 2415 13680 2574 13570 2760 13440 2976 13250 3215 13010 3487 12720 3785
-12400 4095 11990 4434 11520 4825 10990 5246 10390 5699 9770 6155 9150 6589
-8490 7042 7710 7556 6880 8101 6010 8651 5170 9166 4350 9641 3510 10098
-2680 10565 1820 11036 960 11477 110 11877 -730 12237 -1580 12553 -2400 12837
--3230 13086 -4070 13298 -4880 13479 -5720 13637 -6530 13757 -7340 13824
--8160 13854 -8980 13853 -9780 13835 -10570 13816 -11370 13767 -12170 13673
--12980 13545 -13780 13398 -14570 13253 -15300 13126 -16040 12994 -16780 12829
--17540 12639 -18250 12454 -18930 12288 -19580 12145 -20180 12016 -20760 11892
--21300 11773 -21800 11665 -22280 11578 -22740 11511 -23180 11460 -23550 11429
--23880 11413 -24210 11416 -24510 11434 -24820 11459 -25110 11500 -25370 11567
--25630 11650 -25860 11747 -26090 11851 -26310 11953 -26530 12067 -26730 12204
--26940 12358 -27130 12515 -27310 12669 -27450 12814 -27580 12955 -27700 13110
--27840 13272 -27933 13426 -27997 13571 -28015 13697 -28003 13814 -27967 13926
--27913 14036 -27824 14131 -27686 14212 -27508 14278 -27286 14328 -27021 14360
--26711 14379 -26361 14385 -25974 14377 -25565 14361 -25119 14335 -24610 14290
--24047 14223 -23457 14147 -22851 14068 -22252 13991 -21641 13910 -20984 13810
--20277 13694 -19564 13572 -18866 13460 -18186 13362 -17522 13268 -16831 13162
--16121 13045 -15421 12932 -14752 12844 -14122 12783 -13519 12742 -12914 12699
--12305 12652 -11723 12630 -11187 12641 -10726 12690 -10305 12776 -9878 12881
--9461 13007 -9090 13163 -8809 13357 -8641 13587 -8547 13854 -8475 14157
--8440 14506 -8490 14886 -8659 15292 -8955 15718 -9367 16172 -9875 16671
--10476 17220 -11189 17792 -12016 18373 -12927 18947 -13938 19529 -15124 20161
--16453 20833 -17877 21511 -19350 22170 -20834 22791 -22361 23393 -24133 24056
--25885 24695 -27625 25305 -29400 25896 -31251 26441 -33173 26939 -35104 27397
--36970 27823 -38748 28220 -40506 28574 -42285 28864 -44069 29084 -45782 29231
--47349 29280 -48743 29229 -49991 29101 -51097 28932 -52052 28707 -52842 28364
--53452 27878 -53831 27269 -53856 26590 -53504 25847 -52807 24998 -51877 23999
--50797 22831 -49501 21515 -47863 20067 -45783 18509 -43208 16875 -40307 15169
--37362 13306 -34438 11281 -31319 9197 -27882 7181 -24330 5250 -20946 3327
--17844 1418 -14910 -338 -11961 -1753 -8995 -2762 -6146 -3548 -3426 -4425
--838 -5606 1332 -6989 2794 -8247 3724 -9068 4485 -9395 4994 -9428 4897 -9431
-4272 -9508 3755 -9505 3787 -9116 4148 -8053 4286 -6262 3851 -3933 2952 -1478
-2050 646 1517 2095 -1141 2131 -1987 2228 -1586 2625 -442 3420 1062 4404
-2654 5109 4168 5003 5578 3758 6777 1571 7368 -622 6641 -1314 4294 515 1251 3916
--1039 6658 -2331 8234 -3235 9064 -3933 9250 -3675 8801 -3362 7972 -4360 8441
--3741 9069 -5049 10143 -4575 9250 -6021 9394 -8828 10758 -12632 10858
--3434 11060 -5195 10080 -304 8299 6155 5053 -6220 5970 -951 8869 -1833 8242
--3575 7321 -17543 7706 -3053 8086 -17677 14102 28908 9481 296596 -7841
-28272 6225 25700 22875 -18231 14115 -61138 20439 -155223 8533 -81065 6388
--52654 5749 -12018 -919 15365 5641 22264 8862 -10451 11614 -7242 10782
-23 10376 1263 11034 -3145 12098 -10536 13120 -17475 13744 -19733 13660
--13029 12992 7012 12298 57361 13423 114529 15954 178001 19121 234461 21350
-245655 19526 161250 9969 70632 -751 5088 -8693 -33759 -13522 -52177 -16113
--56763 -17230 -52830 -17373 -44216 -16971 -33616 -16520 -22762 -16473
--12715 -17015 -3951 -17918 3448 -18648 9618 -18680 14766 -17757 18933 -16022
-21849 -13944 22926 -12062 21400 -10727 16584 -10002 8357 -9669 -2215 -9406
--12487 -8999 -20655 -8332 -26357 -7420 -30062 -6336 -32464 -5161 -34173 -3946
--35590 -2685 -36895 -1329 -38157 170 -39338 1837 -40383 3661 -41237 5584
--41869 7539 -42248 9460 -42393 11277 -42292 12976 -41972 14546 -41458 15954
--40766 17184 -39931 18228 -38987 19101 -37953 19817 -36851 20389 -35677 20814
--34443 21092 -33142 21219 -31769 21223 -30336 21131 -28855 20971 -27353 20744
--25866 20426 -24453 19989 -23486 19452 -22468 18893 -21417 18318 -20357 17728
--19330 17132 -18356 16537 -17456 15952 -16626 15378 -15867 14817 -15162 14279
--14521 13759 -13929 13266 -13407 12807 -12954 12379 -12587 11986 -12316 11625
--12130 11297 -12042 11000 -12034 10726 -12101 10481 -12246 10264 -12462 10076
--12750 9913 -13111 9772 -13532 9656 -14025 9557 -14568 9480 -15163 9420
--15795 9384 -16449 9369 -17127 9379 -17819 9413 -18505 9473 -19169 9559
--19813 9673 -20413 9809 -20963 9969 -21462 10153 -21903 10356 -22297 10586
--22631 10837 -22927 11108 -23167 11400 -23338 11710 -23422 12031 -23408 12365
--23291 12710 -23067 13063 -22772 13424 -22423 13793 -22041 14164 -21611 14534
--21116 14895 -20509 15236 -19742 15554 -18773 15838 -17599 16085 -16261 16294
--14809 16469 -13925 16671 -12883 16831 -11697 16939 -10376 16987 -8941 16973
--7406 16905 -5815 16796 -4217 16638 -2618 16417 -987 16136 695 15801 2416 15432
-4121 15018 5735 14550 7242 14026 8714 13449 10196 12833 11678 12191 13123 11529
-14476 10832 15700 10098 16745 9348 17599 8603 18306 7853 18929 7082 19510 6304
-19983 5560 20177 4883 20011 4264 19519 3668 18869 3079 18170 2515 17429 2002
-16529 1544 15383 1147 13970 822 12389 597 10742 479 9090 447 7433 452 5775 457
-4169 467 2718 508 1484 604 440 736 -535 872 -1565 984 -2717 1090 -3887 1246
--4806 1507 -5111 1894 -4478 2365 -2741 2833 69 3180 3669 3284 7509 3018
-10804 2241 12520 831 11383 -1241 7287 -4206 -3492 -6500 -18837 -6829 -31429 -3693
--30876 3547 -27683 9631 -25216 14475 -15211 15549 -5387 15533 6972 14604
-16967 13243 20242 13643 23052 16016 28770 9541 1420 12423 -72078 5333
--117472 -32004 -111279 -38530 23263 14840 51034 15256 42248 4947 8705 7592
--3312 11675 -1317 16263 5575 -4343 -2822 -14210 1438 498 -4250 6392 22963 2258
-10971 9748 10838 12480 10241 13031 9700 10783 9386 10151 -5454 11114 -4311 22385
--2797 28624 -1649 32863 -862 35613 -413 36735 -313 36152 -566 34199 -1140 31538
--1961 28767 -2949 26247 -4007 24126 -5089 22416 -6135 21063 -7130 19992
--8059 19131 -8931 18422 -9742 17824 -10493 17306 -11174 16847 -11783 16429
--12341 16040 -12855 15671
-79: 10446900 -5778027 2950 6058 3180 5935 3430 5793 3700 5641 4000 5480
-4310 5317 4600 5162 4920 5006 5270 4831 5620 4653 5970 4473 6350 4298 6700 4135
-7060 3971 7440 3799 7820 3623 8220 3458 8590 3302 8950 3161 9300 3029 9670 2896
-10030 2764 10390 2645 10710 2543 11010 2463 11290 2402 11560 2343 11830 2295
-12080 2264 12290 2258 12440 2279 12570 2326 12680 2383 12760 2459 12820 2559
-12810 2689 12750 2844 12650 3025 12510 3237 12320 3471 12090 3736 11810 4024
-11470 4324 11100 4653 10630 5026 10120 5434 9560 5866 8960 6300 8360 6715
-7720 7150 6980 7633 6200 8151 5380 8669 4570 9159 3780 9607 2990 10043
-2170 10486 1350 10934 520 11356 -310 11741 -1120 12084 -1940 12390 -2740 12662
--3560 12910 -4360 13121 -5160 13298 -5960 13459 -6750 13578 -7540 13652
--8330 13689 -9120 13698 -9900 13690 -10660 13679 -11430 13641 -12190 13562
--12970 13447 -13750 13316 -14470 13187 -15200 13076 -15890 12954 -16590 12803
--17310 12631 -17990 12463 -18630 12308 -19250 12179 -19830 12059 -20370 11945
--20900 11831 -21370 11729 -21850 11647 -22290 11585 -22710 11537 -23080 11506
--23430 11491 -23740 11492 -24050 11506 -24360 11534 -24650 11570 -24920 11633
--25180 11711 -25420 11805 -25660 11902 -25880 11999 -26100 12107 -26320 12233
--26520 12381 -26730 12529 -26910 12676 -27050 12809 -27190 12941 -27320 13088
--27440 13240 -27556 13386 -27618 13520 -27640 13636 -27635 13744 -27607 13848
--27554 13950 -27469 14037 -27337 14108 -27166 14166 -26954 14209 -26694 14236
--26394 14245 -26047 14245 -25670 14232 -25272 14210 -24834 14178 -24336 14127
--23783 14054 -23205 13975 -22611 13889 -22019 13807 -21418 13723 -20765 13619
--20068 13497 -19362 13374 -18667 13258 -17997 13158 -17334 13063 -16651 12959
--15944 12841 -15245 12732 -14581 12642 -13960 12584 -13367 12547 -12765 12509
--12166 12470 -11591 12451 -11071 12470 -10622 12526 -10217 12618 -9816 12728
--9425 12859 -9083 13024 -8827 13223 -8688 13460 -8624 13729 -8584 14042
--8589 14393 -8675 14775 -8883 15185 -9203 15615 -9635 16068 -10170 16571
--10794 17121 -11527 17692 -12367 18273 -13278 18843 -14290 19425 -15463 20052
--16781 20718 -18182 21391 -19631 22044 -21083 22658 -22576 23251 -24319 23902
--26036 24529 -27726 25128 -29448 25713 -31240 26248 -33097 26735 -34966 27181
--36755 27585 -38467 27958 -40145 28281 -41834 28551 -43522 28755 -45131 28890
--46602 28936 -47906 28875 -49056 28734 -50066 28540 -50915 28294 -51600 27936
--52114 27435 -52422 26811 -52409 26107 -52031 25354 -51310 24521 -50355 23549
--49254 22415 -47958 21119 -46364 19679 -44358 18128 -41915 16526 -39162 14881
--36358 13136 -33589 11258 -30687 9322 -27485 7427 -24119 5601 -20823 3770
--17764 1919 -14926 139 -12176 -1375 -9470 -2498 -6863 -3313 -4305 -4075
--1795 -5025 386 -6168 1920 -7280 2909 -8091 3692 -8495 4290 -8602 4428 -8607
-4063 -8613 3631 -8532 3531 -8165 3737 -7309 3900 -5909 3751 -4101 3291 -2173
-2803 -441 2508 862 515 911 -377 1245 -340 1890 337 2803 1398 3767 2615 4434
-3807 4473 4874 3745 5645 2474 5840 1299 5133 1043 3484 2171 1391 4211 -449 6156
--1757 7525 -2675 8306 -3250 8539 -3323 8303 -3267 7890 -3438 7960 -3418 8461
--4113 8969 -4239 8324 -6021 10234 -5719 9554 -6791 9745 -4381 9558 -3209 8903
--1180 9265 -1059 6699 -5999 7549 -4086 8274 -3890 7641 -5994 7049 -17986 10113
--2208 10958 21880 13001 84662 10119 180268 2700 -207091 5760 -156949 12185
-5645 1725 30379 18000 -67428 12275 21819 9081 -14506 10559 20376 -6333
-38564 8150 54280 9350 -37903 14631 -12554 10718 2970 9445 4540 10138 -1563 11088
--11497 12096 -21818 12981 -27507 13104 -24267 12628 -7474 12336 44952 14532
-107959 18510 189979 24035 287443 29803 345682 30906 185276 13746 58676 -2701
--16066 -12783 -53987 -17837 -68683 -19868 -69283 -20145 -61792 -19425
--50198 -18361 -37195 -17597 -24504 -17599 -13127 -18392 -3482 -19506
-4483 -20196 11104 -19825 16832 -18164 21883 -15555 25976 -12763 28240 -10637
-27493 -9572 22429 -9501 12195 -9896 -2315 -10172 -15453 -10101 -24545 -9587
--29829 -8684 -32556 -7520 -33967 -6232 -34929 -4886 -35930 -3490 -37104 -1991
--38410 -340 -39727 1489 -40915 3474 -41885 5566 -42589 7667 -42986 9693
--43103 11621 -42953 13420 -42558 15053 -41952 16505 -41167 17768 -40251 18833
--39220 19712 -38107 20419 -36929 20968 -35689 21369 -34386 21615 -33022 21706
--31590 21665 -30104 21523 -28570 21312 -27026 21032 -25505 20659 -24063 20171
--23091 19571 -22038 18961 -20960 18336 -19894 17703 -18878 17065 -17940 16433
--17075 15811 -16267 15204 -15514 14612 -14810 14047 -14152 13507 -13552 13002
--13031 12536 -12591 12111 -12251 11721 -12009 11366 -11859 11047 -11796 10758
--11809 10498 -11903 10268 -12064 10071 -12306 9897 -12624 9750 -13023 9624
--13491 9516 -14031 9426 -14637 9355 -15298 9302 -15997 9274 -16730 9270
--17484 9290 -18239 9336 -18986 9410 -19698 9509 -20382 9632 -21022 9779
--21611 9951 -22152 10144 -22632 10360 -23067 10604 -23445 10868 -23774 11155
--24035 11464 -24225 11792 -24319 12132 -24307 12489 -24183 12858 -23956 13234
--23653 13622 -23299 14017 -22913 14415 -22480 14810 -21975 15198 -21356 15570
--20563 15913 -19561 16225 -18342 16497 -16945 16734 -15434 16931 -14530 17157
--13445 17336 -12192 17455 -10790 17505 -9273 17496 -7669 17440 -6026 17339
--4367 17177 -2695 16948 -962 16659 834 16324 2638 15945 4386 15507 6026 15005
-7599 14442 9183 13833 10809 13193 12435 12523 13984 11818 15399 11067
-16653 10278 17720 9483 18623 8692 19415 7891 20146 7066 20816 6241 21299 5471
-21438 4771 21180 4114 20617 3456 19946 2790 19268 2155 18527 1591 17557 1110
-16243 714 14593 406 12742 207 10843 109 8977 84 7151 81 5361 64 3625 51
-2020 83 575 192 -707 379 -1898 613 -3041 863 -4121 1136 -4995 1451 -5408 1835
--5093 2282 -3856 2741 -1627 3150 1499 3443 5291 3558 9373 3396 13128 2781
-15623 1467 15373 -789 10819 -4136 -2100 -7680 -23691 -9600 -44195 -7314
--34604 2662 -24880 8519 -23256 14084 -9442 13232 -4973 12691 -257 10271
-4733 5411 19455 1847 37491 7966 18345 6197 -101616 70296 3377 -11082 -65657 -32050
--79231 -23460 19750 13152 34049 14916 11187 5876 -15931 338 -14828 30677
-7553 27045 20260 -15889 -11869 -50514 5853 -3789 -1533 4006 4618 5930
-14650 6044 14512 7991 13753 11029 14027 8288 5485 17467 -2937 20266 -4118 26441
--3366 30884 -2370 33763 -1587 35370 -1112 35767 -973 35020 -1141 33366
--1583 31197 -2242 28890 -3059 26709 -3967 24792 -4911 23176 -5856 21841
--6769 20741 -7643 19828 -8477 19059 -9261 18401 -9993 17829 -10663 17322
--11269 16863 -11821 16438 -12339 16038
-80: 10475990 -5768529 2610 6168 2820 6053 3070 5916 3330 5766 3620 5614
-3900 5455 4190 5306 4500 5151 4810 4985 5160 4811 5500 4638 5840 4470 6190 4313
-6530 4152 6890 3990 7250 3820 7630 3658 7980 3511 8330 3375 8650 3249 9000 3121
-9350 2995 9680 2883 9990 2784 10270 2710 10520 2652 10790 2597 11030 2555
-11260 2528 11450 2525 11600 2549 11710 2594 11810 2652 11870 2729 11930 2830
-11910 2957 11840 3110 11740 3286 11590 3492 11410 3721 11180 3980 10900 4257
-10580 4545 10210 4862 9770 5223 9270 5613 8740 6023 8160 6438 7590 6835
-6960 7250 6280 7711 5520 8197 4740 8690 3980 9153 3220 9579 2460 9993 1670 10413
-880 10842 70 11245 -720 11612 -1510 11940 -2300 12234 -3070 12501 -3870 12743
--4660 12950 -5430 13127 -6190 13285 -6970 13407 -7730 13485 -8490 13529
--9260 13547 -10010 13545 -10740 13544 -11470 13517 -12220 13450 -12950 13349
--13690 13232 -14390 13116 -15070 13016 -15740 12907 -16420 12770 -17080 12616
--17720 12461 -18340 12319 -18930 12199 -19470 12092 -20000 11985 -20510 11877
--20960 11781 -21420 11707 -21840 11645 -22260 11602 -22630 11572 -22970 11559
--23290 11559 -23590 11573 -23900 11597 -24200 11633 -24470 11691 -24720 11766
--24990 11853 -25220 11948 -25450 12039 -25680 12140 -25900 12263 -26110 12398
--26320 12542 -26500 12679 -26660 12804 -26790 12928 -26930 13063 -27060 13207
--27173 13345 -27245 13472 -27271 13578 -27268 13677 -27248 13773 -27199 13867
--27120 13945 -26996 14011 -26830 14058 -26621 14094 -26373 14114 -26079 14119
--25739 14110 -25371 14091 -24981 14064 -24556 14027 -24063 13968 -23522 13891
--22953 13805 -22369 13716 -21786 13629 -21191 13541 -20550 13433 -19857 13308
--19159 13181 -18470 13062 -17807 12962 -17152 12867 -16472 12761 -15768 12642
--15075 12535 -14418 12447 -13802 12392 -13219 12357 -12628 12322 -12037 12290
--11473 12276 -10963 12299 -10528 12364 -10145 12459 -9766 12573 -9397 12711
--9084 12883 -8858 13087 -8740 13328 -8700 13602 -8696 13919 -8735 14273
--8858 14659 -9092 15072 -9442 15502 -9891 15957 -10445 16462 -11091 17010
--11842 17581 -12691 18161 -13602 18728 -14614 19308 -15778 19930 -17080 20591
--18463 21258 -19885 21904 -21310 22510 -22772 23095 -24476 23738 -26148 24351
--27797 24940 -29468 25509 -31213 26037 -33009 26518 -34798 26952 -36525 27344
--38173 27692 -39776 27993 -41384 28238 -42969 28427 -44487 28548 -45869 28586
--47079 28517 -48146 28367 -49070 28158 -49828 27894 -50413 27528 -50838 27020
--51074 26384 -51022 25659 -50624 24895 -49894 24064 -48925 23120 -47819 22023
--46530 20767 -44966 19355 -43030 17828 -40709 16254 -38093 14660 -35410 12999
--32766 11243 -30041 9429 -27064 7648 -23904 5928 -20729 4217 -17728 2463
--14952 716 -12327 -859 -9800 -2091 -7398 -2982 -5027 -3710 -2643 -4507
--497 -5450 1092 -6414 2143 -7178 2961 -7626 3634 -7789 3980 -7801 3885 -7750
-3607 -7604 3465 -7241 3532 -6526 3640 -5420 3596 -4021 3392 -2516 3177 -1118
-3076 19 1775 43 1005 456 838 1185 1171 2130 1837 3091 2675 3807 3524 4045
-4249 3759 4698 3118 4682 2542 4055 2503 2842 3236 1322 4526 -132 5882 -1296 6960
--2165 7641 -2710 7916 -2940 7863 -3021 7699 -3118 7727 -3260 7994 -3700 8250
--4114 8255 -4980 9153 -4830 8888 -4643 8937 -4315 8717 -6141 8645 -712 10608
--6952 7102 -5031 7516 -5064 7748 -4677 7612 -4198 7242 -12358 9454 616 10378
-24478 11960 53661 10327 40661 6674 -152248 6270 -141310 7238 -29114 4258
-18010 11973 -3833 11681 32564 10093 25313 8862 39106 1988 20260 8143 101564 5321
--99402 18508 -8196 8954 9881 7987 8194 9281 322 9812 -11612 10706 -25774 12232
--35041 12648 -36064 12237 -25025 12110 21677 14958 79856 20054 167652 27886
-311470 38778 505204 50143 188074 15186 37106 -7714 -35090 -18161 -67304 -22172
--77302 -23044 -74414 -22285 -64309 -20754 -50752 -19217 -36281 -18382
--22622 -18637 -10749 -19801 -1038 -21158 6675 -21757 12997 -20857 18729 -18257
-24445 -14490 29938 -10758 33903 -8445 34662 -7866 30181 -8837 17954 -10259
--3713 -11126 -20747 -11415 -30071 -11055 -33858 -10143 -34773 -8885 -34731 -7452
--34815 -5945 -35467 -4378 -36687 -2720 -38246 -902 -39882 1091 -41354 3248
--42519 5495 -43327 7719 -43758 9885 -43850 11937 -43631 13821 -43151 15521
--42445 17028 -41558 18333 -40544 19419 -39423 20299 -38222 20995 -36962 21534
--35645 21916 -34269 22132 -32837 22182 -31337 22088 -29785 21893 -28201 21627
--26614 21293 -25065 20868 -23594 20324 -22589 19666 -21506 19003 -20418 18330
--19375 17646 -18401 16962 -17504 16284 -16666 15617 -15869 14972 -15110 14346
--14382 13754 -13715 13198 -13116 12684 -12606 12218 -12197 11796 -11891 11415
--11681 11070 -11559 10766 -11517 10489 -11549 10249 -11652 10040 -11829 9860
--12097 9706 -12444 9574 -12885 9459 -13411 9362 -14012 9280 -14687 9215
--15424 9174 -16204 9157 -17016 9167 -17844 9200 -18663 9258 -19457 9345
--20220 9454 -20947 9586 -21628 9742 -22263 9923 -22854 10126 -23397 10354
--23869 10609 -24290 10888 -24637 11192 -24920 11518 -25115 11864 -25214 12227
--25205 12606 -25081 12998 -24853 13400 -24551 13814 -24201 14236 -23815 14662
--23376 15086 -22877 15505 -22240 15904 -21425 16279 -20387 16620 -19127 16923
--17667 17186 -16091 17407 -15163 17663 -14019 17856 -12694 17980 -11221 18039
--9633 18044 -7981 18003 -6288 17908 -4569 17743 -2799 17506 -958 17216
-931 16878 2797 16480 4572 16008 6266 15468 7950 14876 9693 14245 11484 13581
-13237 12877 14846 12119 16292 11308 17576 10471 18690 9634 19683 8801
-20598 7945 21450 7065 22182 6199 22653 5397 22720 4661 22383 3938 21802 3189
-21160 2433 20521 1734 19757 1140 18670 662 17125 284 15183 1 13035 -182
-10882 -275 8828 -309 6859 -331 4951 -365 3081 -385 1270 -340 -423 -182
--1971 98 -3354 472 -4535 906 -5411 1380 -5838 1877 -5620 2373 -4660 2826
--2938 3178 -542 3403 2400 3533 5810 3618 9618 3662 13579 3501 17133 2762
-18937 937 16443 -2411 4008 -7129 -25022 -10793 -64397 -9418 -45160 1013
--26681 6752 -14890 10267 -6782 10777 -1798 14929 -18938 18129 -1521 12034
-22362 -20643 14661 -13661 -46143 51054 -51436 34002 22523 2112 -10268 -18614
--70869 -11890 25948 15400 -7280 2259 -7614 2320 -16867 9920 -36522 41214
-23409 39483 53048 -10913 -17146 -54311 -6507 -27024 -425 -11050 7149 -4738
-9993 516 15010 -414 19571 1799 8012 20202 2285 25058 -2176 26824 -3504 29726
--3254 32287 -2536 34016 -1877 34846 -1456 34806 -1317 33976 -1445 32529
--1816 30711 -2372 28765 -3077 26883 -3875 25172 -4718 23679 -5579 22399
--6419 21311 -7244 20383 -8038 19585 -8795 18892 -9508 18284 -10158 17745
--10757 17257 -11308 16804 -11823 16380
-81: 10505050 -5759031 2270 6281 2470 6172 2690 6038 2960 5895 3230 5748
-3500 5592 3770 5449 4060 5300 4370 5142 4680 4973 5030 4804 5350 4641 5660 4491
-6000 4336 6330 4180 6690 4019 7040 3861 7380 3718 7700 3589 8010 3469 8330 3348
-8660 3224 8980 3119 9260 3026 9530 2956 9770 2900 10010 2850 10240 2814
-10450 2790 10630 2789 10760 2816 10850 2860 10950 2917 11000 2995 11040 3097
-11020 3219 10950 3368 10850 3543 10690 3741 10510 3964 10290 4213 10010 4485
-9700 4761 9340 5065 8920 5409 8450 5784 7930 6176 7380 6571 6830 6951 6230 7345
-5570 7782 4860 8243 4120 8711 3390 9152 2650 9554 1930 9948 1180 10349
-410 10756 -370 11143 -1130 11490 -1890 11806 -2660 12089 -3410 12350 -4180 12582
--4930 12788 -5690 12963 -6440 13117 -7170 13243 -7910 13324 -8650 13374
--9380 13397 -10110 13406 -10820 13411 -11510 13394 -12230 13337 -12930 13248
--13620 13146 -14310 13043 -14940 12952 -15590 12856 -16230 12733 -16860 12589
--17470 12451 -18050 12321 -18610 12212 -19130 12111 -19640 12014 -20110 11913
--20570 11826 -21000 11753 -21420 11698 -21810 11653 -22180 11630 -22520 11617
--22830 11618 -23150 11630 -23440 11652 -23750 11690 -24020 11742 -24280 11812
--24550 11898 -24790 11987 -25030 12074 -25250 12168 -25470 12284 -25700 12417
--25920 12551 -26100 12678 -26250 12796 -26410 12915 -26540 13040 -26680 13175
--26795 13306 -26874 13424 -26904 13523 -26903 13613 -26891 13701 -26851 13784
--26776 13857 -26656 13916 -26497 13956 -26299 13983 -26054 13997 -25766 13996
--25437 13980 -25077 13956 -24695 13922 -24274 13879 -23795 13816 -23263 13733
--22701 13641 -22129 13549 -21554 13457 -20965 13364 -20333 13252 -19649 13125
--18957 12993 -18273 12873 -17617 12773 -16972 12676 -16297 12568 -15600 12451
--14909 12344 -14259 12257 -13649 12204 -13080 12171 -12498 12142 -11917 12112
--11362 12104 -10866 12134 -10449 12199 -10082 12299 -9725 12419 -9379 12563
--9093 12739 -8893 12949 -8796 13192 -8780 13471 -8808 13791 -8877 14147
--9034 14537 -9297 14953 -9663 15383 -10132 15839 -10704 16342 -11371 16892
--12135 17463 -12986 18038 -13903 18604 -14917 19180 -16069 19797 -17354 20452
--18720 21114 -20120 21753 -21517 22349 -22949 22928 -24602 23561 -26237 24163
--27846 24738 -29478 25294 -31158 25816 -32901 26286 -34623 26712 -36286 27091
--37869 27424 -39403 27706 -40930 27933 -42425 28103 -43850 28210 -45152 28236
--46275 28163 -47264 28003 -48109 27779 -48784 27507 -49285 27135 -49636 26632
--49798 25991 -49703 25256 -49286 24473 -48546 23642 -47579 22718 -46479 21659
--45201 20446 -43666 19078 -41801 17590 -39581 16056 -37090 14504 -34529 12911
--31990 11243 -29395 9535 -26613 7848 -23654 6227 -20635 4634 -17716 3003
--14993 1336 -12449 -245 -10045 -1564 -7796 -2546 -5583 -3295 -3348 -4007
--1273 -4803 339 -5631 1450 -6336 2299 -6802 3032 -7007 3537 -7036 3689 -6951
-3606 -6757 3506 -6384 3501 -5756 3537 -4861 3505 -3767 3418 -2593 3359 -1471
-3377 -504 2658 -497 2071 -92 1831 625 1927 1538 2285 2479 2795 3240 3331 3655
-3766 3688 3972 3470 3836 3265 3283 3355 2339 3881 1186 4748 23 5704 -984 6532
--1774 7107 -2329 7408 -2653 7482 -2847 7470 -3013 7518 -3229 7671 -3577 7843
--3966 7992 -4422 8378 -4472 8373 -4488 8410 -4813 8423 -5647 8690 -3940 9448
--6580 7913 -5844 7644 -5585 7558 -5330 7398 -5513 7678 -9614 7928 -1641 7991
-12079 10883 22016 10131 -6557 8065 -90489 6914 -91346 6609 -32224 6153
-4978 9369 7338 10243 24392 9597 27657 8168 29705 5469 17234 7369 47497 8568
--41552 13708 -7606 9562 7409 8605 6121 9426 891 8340 -10244 8834 -28664 11875
--39921 12529 -44076 11895 -38915 11565 -3223 14543 40545 20309 106509 29474
-234691 43688 654303 82553 201562 4953 39707 -15213 -31412 -22113 -62595 -24309
--72046 -24198 -68814 -22805 -58424 -20914 -44614 -19341 -30045 -18791
--16514 -19541 -5133 -21209 3676 -22866 10137 -23400 15131 -21959 19977 -18303
-25907 -13050 33049 -7956 39234 -5552 42423 -5566 40210 -8027 28349 -10812
--8483 -12040 -29921 -12666 -37341 -12451 -37847 -11542 -35973 -10204
--34112 -8644 -33352 -6981 -33916 -5276 -35521 -3477 -37651 -1537 -39850 601
--41752 2902 -43199 5273 -44135 7668 -44597 9994 -44646 12170 -44341 14154
--43756 15940 -42940 17514 -41946 18860 -40816 19965 -39595 20854 -38298 21558
--36944 22090 -35541 22449 -34082 22628 -32563 22632 -30999 22485 -29379 22234
--27738 21915 -26107 21528 -24535 21046 -23045 20439 -21976 19733 -20876 19019
--19810 18287 -18816 17547 -17897 16807 -17040 16075 -16218 15359 -15406 14671
--14624 14011 -13881 13395 -13209 12826 -12628 12312 -12151 11851 -11785 11440
--11517 11070 -11341 10743 -11232 10453 -11201 10199 -11231 9981 -11344 9796
--11540 9635 -11827 9500 -12216 9382 -12713 9279 -13304 9193 -13978 9120
--14734 9070 -15554 9042 -16416 9042 -17300 9065 -18194 9113 -19068 9182
--19915 9275 -20728 9394 -21503 9531 -22242 9695 -22938 9882 -23588 10096
--24183 10336 -24692 10603 -25145 10896 -25508 11217 -25796 11559 -25996 11927
--26103 12312 -26097 12713 -25981 13129 -25770 13557 -25474 13999 -25133 14450
--24754 14905 -24322 15361 -23814 15811 -23165 16244 -22328 16650 -21257 17024
--19941 17360 -18428 17650 -16790 17899 -15802 18179 -14601 18383 -13215 18518
--11682 18597 -10047 18622 -8351 18598 -6610 18504 -4814 18331 -2941 18094
--993 17803 975 17455 2881 17027 4702 16518 6497 15949 8348 15340 10271 14692
-12202 13999 14026 13249 15665 12432 17130 11567 18453 10686 19672 9812
-20805 8930 21861 8016 22824 7077 23598 6166 24031 5321 24035 4520 23661 3704
-23109 2850 22537 2012 21936 1272 21117 680 19829 230 17997 -121 15728 -392
-13283 -580 10897 -689 8697 -743 6624 -781 4604 -818 2562 -823 499 -736
--1507 -500 -3355 -97 -4922 453 -6071 1109 -6635 1820 -6471 2520 -5525 3123
--3885 3526 -1812 3647 377 3500 2509 3244 4745 3140 7469 3387 10982 3911
-15320 4262 19756 3749 21857 1383 14845 -4137 -19033 -9929 -98143 -11989
--51957 933 -26307 3827 28 4551 26001 2776 -2783 16286 -15939 17529 -16971 33593
-5418 -6743 -22233 17920 -11644 13817 -25957 19959 -7319 -3376 -11435 -9927
--27092 -11399 -24853 6389 -11489 -1651 -18617 -2283 -43731 7640 -42539 26843
-61961 -5234 32380 7829 -7473 -8046 529 -17438 6311 -12057 10397 -7988
-11750 -4464 14132 -2724 14853 2932 7447 16876 2186 24107 -1157 27608 -2500 30167
--2608 32088 -2204 33301 -1752 33791 -1444 33600 -1361 32816 -1500 31579
--1847 30058 -2352 28423 -2992 26809 -3716 25304 -4487 23950 -5276 22756
--6067 21710 -6846 20797 -7606 19996 -8337 19290 -9027 18667 -9665 18109
--10252 17602 -10798 17131 -11314 16689
-82: 10534090 -5749534 1920 6396 2110 6289 2340 6160 2570 6026 2840 5882
-3090 5734 3360 5592 3620 5448 3920 5297 4220 5137 4540 4970 4850 4815 5150 4668
-5470 4522 5780 4370 6120 4217 6450 4067 6770 3925 7070 3801 7370 3688 7670 3570
-7980 3456 8280 3354 8550 3266 8800 3199 9010 3151 9240 3103 9460 3067 9650 3048
-9810 3050 9930 3075 10020 3120 10090 3179 10150 3260 10160 3355 10140 3478
-10080 3622 9970 3789 9810 3984 9640 4201 9410 4440 9140 4702 8840 4970
-8500 5261 8090 5592 7630 5946 7140 6322 6610 6699 6090 7063 5510 7438 4890 7852
-4210 8292 3500 8730 2800 9152 2110 9534 1400 9907 690 10290 -50 10676 -810 11046
--1540 11378 -2280 11683 -3000 11953 -3750 12204 -4470 12431 -5220 12635
--5950 12806 -6660 12959 -7370 13084 -8080 13171 -8800 13224 -9510 13254
--10190 13270 -10890 13280 -11550 13272 -12230 13222 -12910 13149 -13560 13057
--14210 12967 -14820 12887 -15440 12800 -16040 12689 -16640 12559 -17220 12432
--17760 12315 -18300 12217 -18800 12123 -19290 12032 -19730 11939 -20180 11858
--20590 11790 -21000 11741 -21390 11700 -21740 11677 -22070 11665 -22390 11667
--22700 11681 -23000 11699 -23300 11734 -23580 11788 -23850 11856 -24100 11935
--24370 12021 -24600 12102 -24820 12192 -25070 12303 -25290 12429 -25510 12556
--25700 12678 -25860 12788 -26010 12899 -26160 13018 -26300 13144 -26422 13267
--26506 13375 -26538 13470 -26546 13551 -26539 13631 -26507 13707 -26435 13771
--26321 13824 -26170 13857 -25976 13878 -25738 13884 -25461 13876 -25139 13855
--24787 13825 -24407 13784 -24000 13737 -23530 13669 -23008 13580 -22453 13483
--21886 13386 -21323 13291 -20744 13194 -20116 13080 -19444 12947 -18755 12813
--18078 12690 -17431 12588 -16790 12490 -16126 12381 -15434 12266 -14751 12157
--14103 12074 -13508 12021 -12944 11991 -12374 11964 -11806 11937 -11260 11935
--10778 11969 -10376 12038 -10028 12140 -9690 12265 -9368 12414 -9108 12594
--8933 12807 -8857 13057 -8862 13336 -8914 13659 -9016 14018 -9202 14410
--9491 14828 -9875 15258 -10360 15713 -10952 16218 -11632 16766 -12408 17335
--13264 17908 -14187 18472 -15194 19041 -16336 19654 -17608 20305 -18955 20960
--20335 21592 -21701 22181 -23104 22750 -24715 23375 -26314 23963 -27883 24529
--29467 25072 -31097 25581 -32776 26044 -34439 26461 -36043 26833 -37561 27149
--39027 27420 -40476 27631 -41889 27784 -43236 27876 -44449 27894 -45504 27816
--46410 27645 -47183 27416 -47786 27129 -48213 26758 -48497 26263 -48601 25626
--48460 24889 -48018 24099 -47276 23262 -46317 22351 -45223 21322 -43964 20155
--42460 18842 -40655 17408 -38527 15916 -36159 14406 -33709 12868 -31258 11279
--28767 9652 -26144 8043 -23368 6500 -20505 5011 -17703 3507 -15048 1952
--12564 410 -10236 -947 -8084 -2014 -6006 -2815 -3908 -3496 -1920 -4193
--304 -4912 842 -5556 1727 -6022 2491 -6265 3109 -6318 3461 -6223 3574 -6000
-3579 -5617 3580 -5045 3570 -4298 3522 -3416 3469 -2488 3475 -1589 3555 -778
-3231 -764 2837 -397 2592 252 2549 1090 2689 1978 2945 2747 3220 3271 3422 3521
-3455 3582 3238 3618 2731 3803 1961 4229 1037 4858 81 5555 -795 6195 -1528 6677
--2092 6985 -2486 7141 -2779 7226 -3028 7307 -3297 7422 -3621 7549 -3968 7686
--4301 7875 -4502 7951 -4735 8027 -5157 8145 -5651 8402 -5459 8669 -6445 8109
--6301 7832 -6038 7737 -5767 7727 -6131 7789 -10818 6941 -5305 5846 41 8858
-8683 9104 -10172 8228 -44507 7362 -47098 7171 -16600 7193 2369 8444 -3648 9285
-8129 9060 15898 8047 19845 6850 8209 8059 15622 9536 -12317 10758 -4003 9917
-3532 12225 2435 7716 2053 5982 -5483 6298 -29964 12429 -39324 12784 -43983 11595
--42439 10647 -14109 13392 28178 20150 103267 32035 235198 45838 431127 58138
-228130 16060 81139 -7283 695 -17600 -38198 -21502 -52576 -22197 -52506 -21261
--44222 -19782 -31894 -18727 -18498 -18831 -6123 -20279 3886 -22546 10890 -24580
-15050 -25180 17445 -23403 20041 -18826 25291 -11814 34428 -4485 43145 -2447
-49129 -2677 50823 -7075 51003 -11688 -22706 -12318 -44614 -13350 -45242 -13306
--40357 -12469 -35053 -11164 -31368 -9574 -30089 -7845 -31072 -6087 -33585 -4272
--36717 -2286 -39755 -70 -42237 2326 -44000 4880 -45058 7466 -45523 9971
--45500 12303 -45088 14430 -44374 16327 -43432 17977 -42313 19364 -41064 20502
--39720 21407 -38322 22112 -36864 22627 -35352 22956 -33802 23091 -32195 23044
--30550 22847 -28861 22545 -27175 22170 -25505 21726 -23908 21180 -22410 20505
--21263 19763 -20173 18989 -19157 18194 -18229 17387 -17358 16583 -16521 15792
--15687 15024 -14855 14290 -14048 13602 -13305 12970 -12655 12397 -12117 11891
--11693 11440 -11374 11045 -11139 10693 -10978 10386 -10875 10119 -10829 9889
--10857 9697 -10979 9533 -11192 9394 -11515 9277 -11960 9174 -12518 9086
--13182 9013 -13937 8958 -14777 8925 -15674 8916 -16616 8933 -17573 8969
--18519 9028 -19445 9106 -20349 9201 -21221 9322 -22063 9464 -22871 9636
--23641 9828 -24347 10052 -24980 10303 -25525 10583 -25986 10892 -26361 11228
--26654 11591 -26865 11978 -26983 12384 -26996 12809 -26903 13251 -26710 13706
--26434 14175 -26108 14655 -25736 15144 -25306 15633 -24793 16117 -24131 16586
--23265 17028 -22153 17436 -20793 17805 -19215 18128 -17519 18404 -16454 18699
--15202 18920 -13774 19077 -12208 19185 -10536 19236 -8792 19219 -6979 19119
--5091 18943 -3111 18706 -1074 18414 954 18045 2916 17584 4823 17048 6768 16464
-8805 15844 10890 15178 12912 14445 14747 13639 16389 12763 17895 11849
-19324 10931 20699 10016 22004 9074 23205 8091 24253 7088 25036 6122 25425 5216
-25397 4327 25047 3401 24575 2449 24088 1552 23500 810 22556 253 21018 -162
-18848 -498 16241 -784 13525 -1006 10962 -1151 8653 -1230 6499 -1271 4346 -1287
-2080 -1252 -308 -1099 -2707 -765 -4909 -221 -6678 530 -7756 1437 -7927 2423
--7071 3369 -5259 4102 -2844 4428 -465 4191 1193 3414 1819 2408 1908 1748
-2546 1968 4553 3151 8624 4781 14661 6342 21112 6864 22185 1983 -17788 -2305
--99512 -8366 -60188 -1911 -37624 -1505 -14200 -3154 64954 -3130 17885 24409
-9892 12222 -15366 22874 -6736 6144 -25649 15645 -39897 5968 -23502 13013
--17387 4142 -17324 -208 -35702 -6313 -18446 623 -28117 1502 -19780 -7385
--29594 -5145 -5478 14025 28461 16883 18495 4810 -12283 -7857 7974 -3849
-14012 -5796 14589 -7000 13180 -6397 12281 -4002 10663 2161 6109 12286
-2212 19972 -313 24885 -1483 28144 -1749 30307 -1581 31595 -1327 32142
--1161 32055 -1165 31453 -1352 30467 -1704 29236 -2201 27888 -2802 26527
--3482 25226 -4206 24023 -4950 22932 -5699 21954 -6441 21077 -7173 20296
--7880 19597 -8551 18972 -9176 18410 -9754 17895 -10297 17415 -10810 16961
-83: 10563120 -5740041 1570 6512 1760 6407 1960 6286 2210 6152 2430 6015
-2690 5876 2930 5738 3200 5598 3460 5450 3760 5299 4060 5138 4350 4988 4640 4846
-4930 4707 5240 4563 5550 4414 5860 4268 6170 4133 6450 4011 6730 3906 7020 3794
-7300 3686 7580 3587 7850 3505 8060 3444 8270 3396 8480 3352 8680 3316 8870 3301
-9010 3305 9110 3332 9200 3377 9250 3435 9310 3514 9310 3611 9280 3730 9210 3869
-9100 4032 8950 4219 8780 4431 8560 4662 8300 4913 8010 5170 7670 5450 7270 5765
-6840 6106 6360 6462 5870 6824 5360 7172 4820 7526 4210 7922 3560 8338 2890 8752
-2230 9151 1570 9519 890 9872 200 10235 -520 10603 -1240 10954 -1940 11273
--2650 11564 -3350 11828 -4070 12069 -4780 12291 -5490 12488 -6190 12656
--6880 12810 -7570 12932 -8260 13021 -8940 13081 -9620 13117 -10280 13137
--10940 13153 -11590 13150 -12230 13112 -12870 13048 -13500 12967 -14120 12889
--14700 12819 -15280 12741 -15860 12642 -16420 12524 -16970 12408 -17490 12300
--17990 12211 -18480 12127 -18940 12045 -19370 11958 -19790 11880 -20200 11819
--20590 11773 -20970 11738 -21310 11716 -21640 11705 -21960 11707 -22260 11722
--22570 11742 -22850 11772 -23150 11828 -23410 11892 -23680 11968 -23940 12047
--24180 12127 -24410 12213 -24650 12316 -24880 12436 -25100 12558 -25310 12676
--25470 12777 -25630 12883 -25780 12994 -25930 13113 -26047 13229 -26137 13330
--26183 13416 -26196 13490 -26188 13564 -26162 13634 -26098 13689 -25992 13734
--25846 13762 -25656 13775 -25429 13777 -25157 13761 -24843 13734 -24501 13698
--24128 13653 -23730 13601 -23265 13525 -22753 13433 -22206 13331 -21651 13228
--21094 13130 -20523 13031 -19903 12910 -19235 12777 -18556 12640 -17885 12514
--17247 12408 -16616 12310 -15957 12203 -15273 12085 -14596 11977 -13954 11895
--13370 11843 -12819 11814 -12259 11790 -11696 11768 -11167 11768 -10701 11805
--10313 11879 -9978 11984 -9660 12111 -9362 12265 -9126 12448 -8973 12665
--8919 12917 -8947 13200 -9021 13524 -9151 13886 -9365 14279 -9674 14697
--10075 15127 -10582 15583 -11179 16086 -11877 16633 -12663 17201 -13527 17771
--14448 18332 -15449 18896 -16587 19504 -17842 20150 -19172 20797 -20527 21422
--21869 22005 -23243 22565 -24822 23179 -26375 23758 -27908 24314 -29445 24841
--31027 25340 -32646 25793 -34250 26204 -35794 26565 -37253 26875 -38653 27131
--40031 27333 -41370 27471 -42635 27552 -43772 27561 -44757 27473 -45594 27301
--46297 27062 -46831 26769 -47206 26397 -47422 25912 -47472 25289 -47300 24556
--46829 23764 -46084 22926 -45128 22020 -44046 21019 -42813 19896 -41342 18641
--39587 17261 -37547 15821 -35285 14359 -32940 12875 -30580 11354 -28174 9794
--25670 8245 -23046 6757 -20337 5352 -17660 3965 -15094 2531 -12666 1072
--10396 -286 -8305 -1412 -6320 -2272 -4338 -2958 -2439 -3599 -842 -4234
-344 -4822 1251 -5280 2036 -5553 2716 -5640 3213 -5562 3498 -5333 3641 -4948
-3694 -4416 3687 -3765 3626 -3035 3581 -2286 3601 -1556 3697 -871 3604 -823
-3359 -497 3144 67 3029 800 3026 1597 3094 2328 3183 2901 3207 3287 3111 3530
-2832 3729 2350 3990 1685 4373 894 4863 76 5394 -710 5899 -1406 6313 -1976 6616
--2434 6824 -2810 6971 -3128 7088 -3446 7201 -3774 7307 -4106 7407 -4429 7515
--4715 7595 -5043 7685 -5462 7822 -5882 8028 -6125 8176 -6622 8010 -6746 7871
--6792 7829 -7037 7855 -7900 7793 -9193 6993 -877 3705 -4476 7160 29 7936
--4860 7965 -14386 7489 -18559 7860 1415 7826 7291 8067 -21785 8876 -6278 8903
--38 8278 4981 7598 2364 8129 4502 9751 -1347 8696 -1991 8838 -2081 10258
-1109 10494 4026 6170 -2077 6300 -25746 12928 -30174 12666 -34605 11250
--37314 9220 -16752 10846 18933 17127 88618 30986 185370 40384 271176 41349
-193515 19589 98577 1003 30759 -10145 -8317 -15748 -25990 -17917 -29407 -18163
--24065 -17698 -14085 -17584 -2588 -18572 8063 -20784 16191 -23649 20817 -26111
-21840 -27002 20310 -25371 18739 -20532 21362 -12001 33179 -606 44738 -841
-52354 418 51394 -5618 104617 -13084 -62091 -10554 -62586 -12785 -49759 -12916
--39218 -12383 -30980 -11416 -25950 -10025 -24792 -8371 -26933 -6762 -31052 -5124
--35676 -3238 -39818 -1037 -42958 1498 -45012 4252 -46133 7077 -46534 9819
--46392 12385 -45849 14708 -44994 16746 -43905 18477 -42643 19912 -41260 21071
--39786 21977 -38258 22656 -36677 23133 -35053 23418 -33403 23511 -31702 23418
--29977 23171 -28230 22812 -26492 22377 -24797 21868 -23181 21256 -21688 20510
--20480 19737 -19417 18896 -18469 18027 -17601 17146 -16765 16275 -15915 15421
--15054 14602 -14200 13831 -13393 13123 -12682 12485 -12089 11919 -11618 11428
--11255 10993 -10973 10616 -10756 10287 -10586 10003 -10460 9760 -10400 9559
--10426 9392 -10557 9253 -10799 9137 -11181 9037 -11683 8953 -12313 8886
--13052 8833 -13887 8801 -14803 8792 -15772 8803 -16782 8834 -17800 8879
--18799 8942 -19791 9021 -20766 9117 -21712 9237 -22634 9382 -23523 9558
--24359 9760 -25112 9992 -25776 10257 -26336 10551 -26799 10875 -27183 11228
--27493 11612 -27729 12017 -27872 12444 -27919 12893 -27857 13360 -27694 13843
--27437 14340 -27120 14854 -26755 15377 -26326 15902 -25798 16423 -25120 16930
--24227 17409 -23079 17855 -21666 18258 -20033 18614 -18277 18922 -17145 19229
--15856 19472 -14401 19666 -12804 19805 -11094 19874 -9287 19856 -7388 19749
--5387 19573 -3304 19344 -1188 19044 895 18650 2931 18163 4969 17612 7090 17027
-9295 16397 11491 15698 13526 14911 15346 14043 17005 13115 18614 12160
-20219 11203 21805 10231 23293 9218 24616 8156 25705 7084 26471 6053 26842 5067
-26830 4077 26562 3046 26215 2021 25810 1107 25179 394 24049 -118 22205 -511
-19681 -867 16759 -1207 13825 -1494 11140 -1688 8757 -1782 6520 -1804 4188 -1773
-1612 -1671 -1207 -1440 -4088 -1004 -6726 -315 -8743 641 -9773 1820 -9530 3129
--7897 4391 -5054 5343 -1638 5645 1237 4984 2252 3293 689 1017 -2489 -830
--4836 -1174 -5351 249 -2461 2357 3931 5164 12790 10578 26251 6409 -22214 4601
--76743 7794 -53576 3339 -37794 -2421 -22630 -1918 -21425 -11114 95478 2274
-77684 23988 -27833 13609 -29370 7521 -32249 9201 -33278 8046 -24715 11500
--23233 12800 -16206 6499 -25444 2558 -22613 -1462 -35298 -4444 -23894 3399
--20019 12743 -13429 16419 17845 16234 14754 1163 -14549 -17800 12293 -4383
-20573 -3323 17596 -6628 12747 -8078 9338 -6106 6801 -473 3936 7650 1548 15084
--8 20741 -759 24766 -954 27485 -879 29168 -754 30023 -709 30214 -806 29896
--1051 29204 -1435 28267 -1934 27195 -2530 26078 -3183 24977 -3881 23930
--4594 22956 -5311 22058 -6027 21237 -6737 20491 -7420 19815 -8082 19203
--8691 18646 -9262 18133 -9801 17653 -10310 17194
-84: 10592150 -5730556 1220 6630 1400 6527 1610 6408 1810 6282 2050 6148
-2280 6016 2510 5884 2760 5748 3020 5608 3290 5457 3580 5305 3860 5162 4120 5023
-4400 4893 4690 4752 4990 4608 5280 4471 5570 4340 5840 4225 6090 4121 6360 4016
-6640 3913 6900 3817 7140 3742 7340 3682 7540 3639 7730 3598 7920 3563 8080 3551
-8220 3557 8320 3583 8380 3629 8440 3688 8470 3763 8470 3859 8440 3975 8370 4111
-8260 4268 8110 4448 7940 4653 7720 4876 7480 5118 7180 5363 6860 5632 6490 5934
-6070 6258 5610 6598 5130 6946 4650 7274 4130 7616 3550 7987 2940 8381 2300 8777
-1660 9154 1020 9503 380 9840 -270 10187 -970 10535 -1660 10872 -2350 11176
--3020 11456 -3700 11710 -4380 11943 -5080 12157 -5750 12348 -6430 12515
--7100 12666 -7760 12787 -8420 12879 -9080 12942 -9730 12983 -10370 13008
--10990 13029 -11610 13034 -12230 13002 -12840 12946 -13430 12877 -14020 12810
--14580 12749 -15130 12680 -15680 12590 -16210 12484 -16720 12376 -17220 12281
--17700 12199 -18160 12123 -18610 12048 -19020 11966 -19410 11897 -19810 11841
--20190 11798 -20550 11766 -20900 11746 -21220 11739 -21530 11740 -21840 11754
--22140 11776 -22420 11808 -22720 11859 -22980 11921 -23260 11995 -23520 12071
--23760 12146 -24000 12231 -24240 12327 -24480 12440 -24700 12558 -24920 12670
--25090 12767 -25240 12864 -25410 12970 -25560 13082 -25678 13189 -25776 13286
--25829 13364 -25845 13434 -25842 13498 -25821 13560 -25768 13611 -25665 13648
--25525 13669 -25343 13678 -25124 13671 -24855 13652 -24553 13618 -24218 13575
--23856 13527 -23460 13468 -23004 13388 -22501 13292 -21963 13183 -21415 13078
--20867 12974 -20306 12872 -19690 12748 -19029 12612 -18361 12472 -17697 12344
--17064 12235 -16445 12137 -15793 12028 -15112 11910 -14445 11803 -13813 11722
--13240 11670 -12695 11643 -12150 11620 -11601 11601 -11082 11605 -10625 11644
--10254 11721 -9938 11830 -9637 11960 -9363 12115 -9148 12302 -9016 12523
--8984 12777 -9028 13061 -9126 13385 -9282 13751 -9518 14144 -9852 14562
--10271 14993 -10788 15446 -11398 15950 -12105 16494 -12903 17060 -13773 17628
--14691 18184 -15689 18744 -16814 19348 -18062 19987 -19369 20629 -20704 21246
--22022 21820 -23365 22375 -24916 22977 -26429 23547 -27923 24093 -29413 24609
--30946 25094 -32511 25539 -34061 25942 -35541 26296 -36945 26597 -38289 26843
--39596 27032 -40864 27165 -42059 27237 -43123 27234 -44045 27147 -44811 26966
--45455 26725 -45927 26424 -46250 26054 -46413 25577 -46418 24972 -46204 24253
--45723 23466 -44970 22631 -44017 21734 -42953 20754 -41736 19669 -40299 18464
--38595 17146 -36627 15761 -34466 14351 -32221 12924 -29949 11461 -27618 9966
--25203 8464 -22700 7024 -20133 5675 -17577 4379 -15109 3061 -12747 1702
--10528 379 -8475 -765 -6552 -1678 -4663 -2391 -2847 -3007 -1278 -3584
--62 -4123 883 -4569 1680 -4868 2390 -4994 2970 -4947 3388 -4736 3660 -4367
-3799 -3871 3837 -3288 3789 -2666 3744 -2043 3763 -1436 3845 -854 3859 -741
-3717 -446 3538 29 3391 646 3296 1326 3241 1988 3193 2566 3094 3028 2899 3391
-2572 3700 2098 4014 1483 4370 772 4774 31 5198 -702 5611 -1375 5977 -1967 6279
--2475 6521 -2910 6713 -3291 6866 -3649 6992 -3994 7086 -4330 7158 -4661 7224
--4984 7283 -5340 7357 -5739 7485 -6139 7658 -6479 7787 -6856 7769 -7096 7710
--7297 7660 -7559 7553 -7829 7200 -7263 6244 -3427 4614 -4517 6000 -3174 6796
--2442 7772 -4129 7619 -5740 8096 268 8162 280 8051 -14868 8502 -790 8908
--8760 8578 -3155 7956 -1541 8121 -80 8491 -1065 7453 -2243 6941 -2774 7740
-2529 13840 10057 4001 3276 7777 -29482 17250 -16663 12653 -20069 11612
--27923 8013 -14876 8317 2601 11520 58928 28174 122463 33061 167448 30937
-144181 19168 94615 6382 48861 -3322 17391 -9507 626 -12909 -4419 -14482
--1361 -15250 6439 -16211 16070 -18065 25062 -20916 31418 -24233 33705 -27073
-31361 -28445 25075 -27523 17269 -23641 13166 -15571 26969 2411 45311 -4591
-56083 399 11319 -855 204059 -13936 -142164 -4700 -65893 -10284 -44838 -10139
--33868 -10683 -24003 -10721 -18014 -9883 -17625 -8419 -21805 -7259 -28327 -6108
--34921 -4519 -40345 -2336 -44091 347 -46290 3358 -47324 6506 -47572 9610
--47275 12516 -46581 15097 -45572 17298 -44325 19112 -42908 20569 -41365 21708
--39741 22566 -38068 23185 -36354 23604 -34612 23838 -32847 23886 -31063 23744
--29256 23438 -27454 23016 -25686 22516 -23972 21942 -22357 21264 -20872 20455
--19650 19630 -18636 18714 -17753 17763 -16920 16807 -16075 15868 -15196 14956
--14309 14098 -13455 13302 -12697 12585 -12058 11952 -11553 11402 -11160 10927
--10845 10512 -10579 10155 -10347 9849 -10138 9589 -9984 9376 -9911 9202
--9938 9064 -10097 8952 -10390 8862 -10828 8788 -11400 8729 -12098 8688
--12904 8665 -13806 8660 -14792 8675 -15820 8702 -16883 8741 -17961 8788
--19040 8847 -20104 8921 -21168 9016 -22209 9135 -23223 9284 -24190 9464
--25077 9677 -25862 9921 -26542 10199 -27108 10508 -27584 10846 -27988 11216
--28330 11618 -28603 12043 -28798 12493 -28881 12963 -28857 13456 -28714 13966
--28472 14497 -28160 15044 -27793 15603 -27363 16167 -26822 16728 -26123 17272
--25204 17793 -24018 18278 -22567 18718 -20880 19110 -19067 19449 -17901 19774
--16594 20056 -15116 20286 -13476 20449 -11705 20523 -9810 20498 -7798 20392
--5687 20228 -3518 20005 -1332 19695 816 19279 2953 18777 5147 18227 7435 17643
-9752 16989 11980 16239 13981 15389 15799 14462 17541 13488 19340 12494
-21193 11487 23008 10446 24654 9349 26047 8205 27133 7060 27887 5957 28285 4882
-28362 3794 28239 2680 28028 1619 27668 721 26939 51 25566 -436 23380 -851
-20524 -1277 17339 -1713 14249 -2087 11491 -2325 9048 -2412 6689 -2383
-4090 -2278 1098 -2094 -2264 -1782 -5736 -1258 -8899 -444 -11256 698 -12335 2152
--11750 3826 -9337 5514 -5311 6860 -479 7344 3492 6367 4222 3573 -151 -599
--8125 -4512 -13744 -6179 -17345 -4971 -15123 -4433 -5903 -5572 12156 2476
-14595 -1269 -20227 41285 -46082 43744 -45514 3760 -37855 -8226 -28095 -4029
--55151 4299 64715 4575 149252 3972 -939 -2904 -23453 3916 -45299 13597
--37843 16747 -28521 11084 -28498 8919 -17435 1240 -15374 6842 -18279 3969
--37433 -1657 -33745 -186 -27509 8723 -13932 8655 2743 12791 -6633 1641
--9247 -4781 37368 13199 33050 4207 19380 -6055 9765 -10365 4850 -9119
-2553 -3951 1167 3260 268 10420 -225 16421 -390 21000 -339 24261 -227 26410
--148 27661 -187 28209 -353 28218 -655 27838 -1075 27192 -1592 26387 -2189 25503
--2835 24595 -3515 23706 -4211 22852 -4911 22045 -5605 21291 -6291 20592
--6962 19950 -7610 19362 -8213 18821 -8780 18317 -9309 17842 -9817 17386
-85: 10621180 -5721078 880 6746 1040 6646 1230 6535 1440 6409 1660 6283
-1870 6153 2100 6027 2320 5900 2570 5762 2830 5619 3100 5472 3370 5334 3610 5203
-3880 5074 4150 4938 4420 4804 4710 4670 4970 4547 5220 4440 5470 4337 5720 4236
-5980 4135 6220 4047 6440 3974 6630 3919 6820 3877 6990 3841 7160 3809 7320 3797
-7450 3802 7520 3832 7580 3875 7630 3935 7660 4008 7660 4100 7620 4215 7540 4346
-7430 4497 7290 4672 7120 4868 6900 5083 6670 5314 6390 5551 6070 5807 5720 6096
-5310 6407 4880 6731 4420 7061 3950 7373 3460 7700 2910 8052 2320 8425 1710 8802
-1110 9159 490 9489 -110 9813 -750 10144 -1420 10474 -2080 10796 -2730 11086
--3390 11353 -4040 11600 -4700 11824 -5360 12033 -6020 12217 -6670 12380
--7310 12529 -7940 12649 -8580 12741 -9210 12809 -9830 12853 -10450 12883
--11040 12909 -11630 12918 -12220 12896 -12800 12846 -13370 12788 -13920 12728
--14460 12675 -14970 12614 -15510 12536 -15990 12438 -16490 12343 -16960 12253
--17420 12183 -17850 12113 -18280 12041 -18670 11969 -19050 11904 -19430 11854
--19810 11815 -20150 11787 -20490 11768 -20800 11764 -21120 11768 -21420 11781
--21710 11804 -22010 11834 -22290 11884 -22570 11945 -22840 12017 -23110 12090
--23350 12161 -23590 12242 -23840 12336 -24080 12445 -24310 12554 -24520 12661
--24710 12755 -24870 12845 -25030 12945 -25190 13052 -25321 13152 -25420 13240
--25476 13313 -25495 13378 -25507 13436 -25487 13492 -25437 13533 -25344 13564
--25212 13581 -25035 13585 -24821 13571 -24561 13545 -24266 13506 -23938 13458
--23584 13404 -23193 13340 -22748 13256 -22252 13156 -21724 13042 -21181 12931
--20641 12824 -20089 12719 -19479 12593 -18828 12452 -18165 12310 -17510 12179
--16888 12070 -16277 11969 -15630 11860 -14960 11742 -14297 11634 -13678 11553
--13113 11503 -12581 11477 -12043 11453 -11510 11439 -11003 11444 -10563 11488
--10200 11566 -9904 11676 -9621 11809 -9368 11968 -9175 12157 -9065 12380
--9047 12634 -9110 12920 -9230 13247 -9410 13612 -9672 14007 -10021 14425
--10456 14854 -10983 15306 -11604 15808 -12323 16350 -13127 16913 -14002 17479
--14919 18031 -15910 18586 -17027 19186 -18259 19817 -19551 20452 -20864 21063
--22158 21632 -23477 22178 -24996 22774 -26469 23331 -27922 23870 -29373 24373
--30860 24849 -32375 25286 -33873 25678 -35295 26023 -36639 26317 -37930 26556
--39178 26740 -40381 26866 -41503 26925 -42501 26921 -43363 26828 -44074 26647
--44664 26401 -45076 26100 -45346 25728 -45467 25261 -45430 24674 -45188 23971
--44687 23201 -43929 22375 -42989 21491 -41930 20527 -40737 19473 -39331 18313
--37673 17057 -35765 15731 -33698 14376 -31542 12998 -29353 11597 -27097 10161
--24762 8713 -22350 7307 -19897 5994 -17450 4763 -15074 3541 -12791 2283
--10627 1032 -8605 -111 -6725 -1055 -4905 -1797 -3152 -2410 -1620 -2957
--377 -3457 599 -3886 1412 -4203 2146 -4366 2770 -4360 3276 -4187 3641 -3852
-3875 -3398 3979 -2874 3966 -2330 3942 -1796 3954 -1280 4017 -771 4060 -583
-3974 -302 3824 91 3664 586 3521 1146 3385 1728 3238 2286 3056 2787 2785 3219
-2413 3591 1931 3930 1341 4264 669 4608 -40 4962 -748 5319 -1415 5656 -2035 5962
--2576 6230 -3060 6457 -3484 6642 -3873 6781 -4235 6873 -4576 6928 -4916 6961
--5246 6993 -5599 7050 -5972 7160 -6348 7308 -6695 7423 -7026 7452 -7294 7422
--7494 7340 -7614 7139 -7487 6698 -6665 5960 -4872 5235 -4637 5767 -3761 6462
--2726 7232 -1998 7392 -3226 8226 -4006 8367 -645 7949 -6720 8437 -4252 8858
--8763 8698 -3081 8038 -2753 8204 -2154 8008 -1545 6954 -1254 6413 145 7161
-5300 9552 13023 6610 1302 9611 -43069 22376 -932 9738 -14690 12450 -10405 8590
--2646 11164 -12549 11599 21747 18888 63436 22910 94252 22286 99404 17176
-81903 9349 56928 1794 35904 -4193 23056 -8377 18514 -11080 20605 -12963
-27063 -14829 35494 -17287 43529 -20458 48902 -23928 49658 -26977 44630 -28800
-34078 -28646 20271 -25861 7419 -19769 -1984 -9993 52036 -9011 82136 -28947
--18347 22742 49933 253 -23121 -3155 -52881 -2436 -39985 -2712 -30699 -7184
--16598 -9278 -8410 -9303 -9106 -7783 -16245 -7562 -26073 -7389 -34958 -6216
--41654 -4035 -45746 -1144 -47780 2206 -48511 5821 -48518 9452 -48054 12828
--47209 15731 -46052 18096 -44646 19954 -43047 21375 -41325 22428 -39531 23177
--37699 23701 -35844 24045 -33977 24223 -32110 24213 -30242 24007 -28377 23635
--26533 23145 -24741 22579 -23026 21940 -21421 21204 -19967 20338 -18786 19426
--17842 18420 -16996 17388 -16151 16361 -15273 15362 -14362 14408 -13473 13521
--12668 12714 -12010 12003 -11486 11382 -11088 10848 -10753 10389 -10455 9993
--10163 9654 -9881 9369 -9623 9137 -9435 8956 -9357 8815 -9413 8710 -9618 8632
--9975 8575 -10470 8536 -11101 8512 -11857 8506 -12714 8516 -13667 8538
--14704 8570 -15783 8605 -16911 8642 -18063 8684 -19232 8734 -20399 8803
--21570 8892 -22722 9013 -23826 9170 -24851 9359 -25779 9584 -26581 9841
--27266 10133 -27846 10454 -28353 10810 -28794 11194 -29191 11610 -29519 12055
--29766 12526 -29894 13018 -29892 13536 -29757 14077 -29523 14641 -29208 15223
--28831 15822 -28392 16426 -27844 17028 -27133 17614 -26194 18176 -24983 18701
--23495 19184 -21764 19612 -19890 19987 -18747 20347 -17432 20671 -15912 20931
--14196 21104 -12330 21172 -10325 21147 -8199 21055 -5988 20913 -3747 20696
--1514 20374 717 19943 2974 19440 5322 18898 7729 18298 10091 17602 12286 16785
-14261 15870 16126 14895 18057 13882 20139 12843 22278 11774 24298 10652
-26036 9469 27434 8244 28505 7029 29276 5848 29760 4689 30014 3518 30087 2354
-30003 1286 29638 413 28745 -237 27080 -748 24563 -1247 21419 -1797 18048 -2358
-14868 -2817 12058 -3079 9534 -3121 6961 -3007 3995 -2802 461 -2533 -3558 -2156
--7715 -1575 -11500 -686 -14326 593 -15616 2288 -14900 4338 -11911 6561
--6674 8561 78 9649 6312 8820 8097 5063 548 -1584 -15475 -8571 -22979 -12388
--30511 -10571 -29154 -12625 -19937 -23370 -7290 -15972 8913 189 -2707 82301
--13277 70784 -38080 10904 -37116 -7930 -27186 3622 -6271 9010 79631 3071
-39699 -15931 35401 3905 -23180 -9924 -43608 14930 -32190 20154 -28509 13232
--28357 2868 -45222 -37497 12901 -10920 -29242 33886 -31499 14180 -21459 7972
--13437 1661 -15110 6327 -11026 6595 -29033 1518 -16906 5042 80755 44731
-40616 10910 14185 -7955 2736 -13762 -1193 -12370 -1959 -7189 -1697 -345
--1194 6584 -684 12659 -238 17524 121 21155 348 23686 431 25303 355 26191
-137 26521 -213 26438 -662 26069 -1203 25510 -1803 24841 -2452 24120 -3121 23381
--3809 22647 -4496 21936 -5176 21254 -5849 20611 -6503 20011 -7142 19454
--7741 18936 -8299 18449 -8829 17985 -9337 17536
-86: 10650210 -5711613 540 6862 690 6770 860 6658 1070 6539 1260 6416 1470 6292
-1670 6170 1900 6048 2130 5918 2370 5778 2630 5638 2870 5505 3110 5382 3350 5255
-3610 5126 3870 4996 4140 4869 4380 4752 4620 4645 4850 4553 5080 4454 5320 4359
-5550 4274 5760 4203 5930 4151 6110 4112 6260 4078 6420 4051 6570 4038 6680 4048
-6750 4074 6800 4119 6840 4175 6860 4246 6850 4338 6820 4448 6740 4573 6620 4719
-6490 4889 6310 5078 6110 5284 5880 5504 5610 5733 5320 5976 4960 6252 4580 6550
-4150 6858 3730 7172 3270 7471 2810 7780 2280 8115 1720 8471 1140 8827 560 9165
--30 9482 -600 9786 -1220 10105 -1860 10419 -2490 10725 -3120 11005 -3750 11259
--4370 11494 -5010 11712 -5640 11914 -6270 12095 -6900 12253 -7520 12400
--8120 12519 -8730 12610 -9340 12678 -9930 12728 -10520 12762 -11090 12789
--11650 12803 -12210 12790 -12760 12749 -13300 12698 -13820 12643 -14330 12601
--14840 12548 -15320 12478 -15790 12391 -16260 12303 -16700 12222 -17140 12157
--17550 12096 -17960 12029 -18330 11963 -18710 11907 -19060 11860 -19430 11824
--19760 11799 -20100 11787 -20400 11782 -20710 11788 -21010 11803 -21300 11825
--21590 11856 -21870 11901 -22160 11964 -22430 12033 -22700 12106 -22950 12173
--23190 12249 -23440 12341 -23680 12447 -23930 12549 -24140 12651 -24330 12740
--24490 12825 -24670 12921 -24820 13020 -24965 13115 -25068 13198 -25132 13265
--25154 13322 -25174 13375 -25159 13425 -25115 13460 -25028 13484 -24900 13495
--24730 13494 -24525 13475 -24271 13442 -23983 13399 -23661 13347 -23314 13285
--22933 13217 -22496 13129 -22003 13024 -21484 12905 -20952 12789 -20420 12681
--19871 12572 -19275 12441 -18627 12300 -17972 12154 -17328 12021 -16713 11910
--16109 11807 -15474 11698 -14805 11578 -14159 11472 -13545 11390 -12991 11341
--12471 11314 -11947 11294 -11424 11279 -10933 11289 -10505 11334 -10159 11415
--9874 11525 -9611 11659 -9377 11821 -9207 12012 -9115 12237 -9113 12492
--9194 12778 -9334 13107 -9536 13472 -9815 13867 -10183 14283 -10635 14713
--11165 15164 -11805 15662 -12530 16201 -13337 16763 -14216 17323 -15132 17872
--16115 18425 -17223 19016 -18444 19642 -19717 20272 -21011 20874 -22283 21437
--23573 21975 -25058 22567 -26496 23118 -27917 23644 -29327 24140 -30772 24606
--32239 25031 -33683 25414 -35054 25751 -36348 26039 -37581 26272 -38770 26450
--39914 26568 -40978 26629 -41916 26615 -42717 26519 -43380 26345 -43904 26094
--44279 25794 -44502 25423 -44583 24963 -44512 24392 -44241 23713 -43726 22964
--42968 22152 -42029 21279 -40978 20336 -39811 19312 -38434 18193 -36820 16994
--34968 15724 -32970 14419 -30898 13093 -28788 11753 -26608 10382 -24340 8985
--22006 7609 -19641 6320 -17283 5133 -14998 3981 -12789 2821 -10680 1642
--8696 532 -6841 -424 -5075 -1191 -3383 -1815 -1873 -2345 -616 -2819 394 -3231
-1230 -3553 1978 -3750 2627 -3792 3182 -3667 3616 -3381 3924 -2975 4095 -2509
-4138 -2031 4139 -1565 4158 -1112 4208 -659 4240 -396 4178 -120 4048 200
-3884 585 3711 1038 3522 1546 3313 2076 3063 2586 2741 3044 2327 3437 1826 3771
-1233 4079 572 4382 -128 4696 -826 5026 -1513 5355 -2145 5668 -2714 5953
--3225 6206 -3680 6413 -4089 6566 -4460 6658 -4804 6698 -5137 6708 -5457 6717
--5803 6760 -6142 6855 -6485 6978 -6815 7074 -7115 7107 -7358 7085 -7509 6993
--7510 6773 -7231 6381 -6518 5896 -5445 5575 -4761 5834 -3892 6329 -2932 6880
--2341 7253 -3067 7822 -3944 8019 -2948 7942 -3531 8417 -3872 8634 -4508 8116
--4721 8702 -5001 8941 -4167 8435 -1979 6977 -597 6359 1398 6868 4679 8191
-6124 8592 -4918 11744 -26131 17077 -11834 10468 -3014 7728 -10042 13288
--1939 19253 -12620 11680 -1922 11065 18512 14210 39151 15084 64592 15328
-68168 10909 58203 5204 46948 -326 39235 -4931 36712 -8437 39156 -11119
-45328 -13511 53557 -16134 61802 -19174 67574 -22438 68243 -25492 61727 -27736
-47586 -28453 28125 -26844 8871 -22261 -2248 -15264 14301 -10977 29416 -14428
-9853 1887 26962 -5646 9891 -10267 -66693 14285 -37197 8243 -33810 -4491
--9632 -8103 2432 -8857 150 -5870 -10900 -7768 -25127 -9250 -36191 -8456
--43937 -6098 -47856 -2916 -49227 860 -49417 5096 -49161 9456 -48592 13432
--47660 16698 -46380 19205 -44796 21038 -42994 22339 -41076 23228 -39089 23819
--37091 24223 -35097 24477 -33117 24575 -31159 24487 -29221 24205 -27315 23754
--25455 23195 -23659 22563 -21959 21869 -20380 21084 -18959 20164 -17899 19117
--17012 18011 -16167 16902 -15282 15817 -14348 14773 -13431 13792 -12600 12888
--11913 12084 -11391 11380 -11008 10772 -10689 10249 -10380 9801 -10047 9418
--9686 9097 -9328 8836 -9019 8638 -8820 8493 -8765 8393 -8872 8332 -9143 8297
--9556 8286 -10103 8292 -10768 8312 -11558 8346 -12443 8386 -13436 8427
--14508 8467 -15653 8498 -16862 8525 -18111 8553 -19395 8596 -20695 8657
--21993 8750 -23247 8878 -24425 9045 -25495 9246 -26445 9485 -27263 9757
--27964 10061 -28578 10395 -29130 10761 -29639 11161 -30102 11591 -30491 12052
--30778 12539 -30936 13056 -30937 13601 -30800 14174 -30555 14771 -30232 15392
--29849 16029 -29411 16675 -28859 17320 -28151 17949 -27204 18556 -25979 19126
--24459 19651 -22685 20122 -20762 20536 -19684 20950 -18340 21310 -16744 21586
--14929 21757 -12944 21825 -10819 21814 -8591 21755 -6315 21636 -4026 21423
--1738 21089 574 20649 2955 20153 5419 19605 7890 18973 10239 18210 12395 17325
-14391 16359 16415 15345 18636 14297 21055 13207 23462 12064 25618 10858
-27363 9594 28716 8296 29778 7008 30637 5757 31311 4523 31812 3294 32103 2099
-32115 1028 31686 155 30571 -531 28602 -1138 25785 -1781 22427 -2492 18956 -3182
-15729 -3698 12870 -3936 10185 -3892 7284 -3660 3818 -3343 -374 -2994 -5140 -2582
--10053 -1998 -14531 -1104 -17928 219 -19658 2057 -19209 4415 -16133 7195
--10104 10094 -1248 12398 8867 12707 14986 8871 5545 -475 -27686 -11246
--30895 -18229 -42386 -13468 -39751 -21838 6541 -18648 19327 -19637 -51916 -1071
--13649 112876 -6721 74919 -17913 5849 -28630 -8903 -36907 10029 -12783 9826
-18834 -5958 -17748 916 38865 17827 29681 -23257 -12239 -3947 -2093 14799
--16649 6380 -8500 -7100 7217 -45386 -47462 1650 -44678 40683 -12691 6557
--15743 7622 -12148 3849 -11921 5445 -11902 5625 -26309 5879 -2068 17036
-106789 72673 17779 2936 -1321 -13469 -6178 -16492 -6631 -14079 -5422 -8887
--3771 -2468 -2235 4038 -988 9897 -77 14753 537 18521 869 21272 977 23144
-887 24303 630 24901 249 25076 -227 24948 -788 24609 -1398 24136 -2049 23582
--2713 22983 -3395 22367 -4072 21750 -4743 21143 -5405 20560 -6052 20006
--6683 19486 -7276 18995 -7828 18531 -8355 18083 -8862 17646
-87: 10679270 -5702159 200 6979 330 6889 500 6780 690 6669 870 6548 1070 6430
-1260 6314 1470 6196 1690 6071 1920 5936 2150 5806 2390 5673 2610 5555 2840 5436
-3070 5312 3330 5188 3570 5066 3800 4952 4020 4852 4230 4763 4460 4671 4680 4579
-4880 4497 5090 4429 5250 4379 5400 4343 5550 4312 5700 4289 5830 4278 5920 4285
-6000 4313 6030 4355 6070 4409 6080 4478 6070 4569 6040 4676 5940 4797 5840 4937
-5700 5096 5540 5281 5330 5477 5120 5690 4850 5908 4570 6139 4230 6403 3860 6686
-3460 6982 3050 7278 2620 7566 2160 7858 1670 8180 1130 8515 580 8849 30 9175
--540 9476 -1090 9768 -1670 10067 -2290 10369 -2890 10661 -3500 10926 -4110 11173
--4700 11396 -5300 11606 -5920 11803 -6530 11980 -7120 12133 -7720 12276
--8300 12394 -8870 12486 -9460 12553 -10030 12604 -10590 12644 -11130 12676
--11660 12694 -12200 12685 -12720 12651 -13230 12609 -13730 12561 -14210 12524
--14690 12482 -15140 12415 -15600 12338 -16030 12258 -16450 12186 -16870 12130
--17260 12073 -17650 12013 -18010 11952 -18360 11902 -18710 11860 -19060 11827
--19390 11806 -19700 11799 -20010 11794 -20310 11800 -20610 11819 -20900 11839
--21180 11871 -21480 11917 -21750 11977 -22030 12045 -22290 12116 -22550 12181
--22800 12254 -23050 12344 -23300 12445 -23540 12542 -23770 12639 -23960 12723
--24120 12807 -24300 12895 -24470 12990 -24608 13078 -24723 13155 -24792 13217
--24820 13268 -24841 13315 -24839 13361 -24797 13390 -24714 13407 -24596 13414
--24431 13407 -24231 13382 -23985 13344 -23706 13296 -23390 13237 -23046 13172
--22673 13100 -22245 13007 -21763 12895 -21246 12775 -20724 12654 -20199 12543
--19660 12430 -19071 12296 -18430 12151 -17783 12005 -17146 11870 -16539 11754
--15947 11652 -15318 11542 -14661 11422 -14023 11314 -13419 11233 -12874 11184
--12368 11158 -11853 11137 -11343 11126 -10867 11137 -10456 11184 -10123 11264
--9852 11377 -9608 11512 -9391 11677 -9238 11868 -9165 12095 -9185 12351
--9279 12637 -9437 12965 -9657 13331 -9957 13725 -10341 14141 -10804 14569
--11343 15018 -11991 15514 -12727 16051 -13538 16607 -14416 17166 -15332 17709
--16310 18257 -17405 18843 -18612 19464 -19873 20086 -21146 20683 -22396 21237
--23661 21770 -25108 22359 -26520 22901 -27903 23418 -29282 23904 -30680 24362
--32098 24776 -33496 25154 -34826 25483 -36065 25764 -37244 25990 -38385 26164
--39467 26281 -40474 26337 -41366 26320 -42114 26225 -42727 26051 -43198 25805
--43527 25507 -43714 25139 -43760 24682 -43656 24130 -43364 23478 -42835 22747
--42071 21954 -41149 21102 -40106 20181 -38950 19181 -37603 18103 -36031 16952
--34227 15733 -32288 14480 -30288 13207 -28253 11925 -26145 10614 -23939 9270
--21666 7928 -19372 6665 -17090 5498 -14878 4404 -12741 3312 -10682 2210
--8739 1141 -6913 198 -5177 -587 -3540 -1224 -2053 -1751 -790 -2203 253 -2600
-1118 -2924 1883 -3149 2551 -3235 3130 -3162 3603 -2931 3963 -2586 4190 -2179
-4287 -1759 4324 -1349 4356 -947 4401 -540 4417 -214 4363 57 4242 319 4071 616
-3874 989 3650 1438 3402 1934 3101 2427 2734 2873 2285 3248 1757 3558 1148 3839
-478 4121 -228 4424 -938 4750 -1631 5081 -2278 5402 -2870 5698 -3387 5961
--3853 6178 -4261 6334 -4632 6425 -4965 6457 -5291 6455 -5600 6453 -5924 6488
--6243 6568 -6555 6668 -6860 6739 -7130 6770 -7339 6759 -7440 6675 -7377 6482
--7071 6190 -6475 5901 -5658 5772 -4881 5938 -4041 6266 -3233 6651 -2763 7014
--2993 7428 -3337 7681 -2951 7817 -2783 8086 -2761 8114 -1199 7650 -6177 9543
--7079 9833 -6220 9340 -2572 7229 -1248 6555 378 6914 2106 7982 1331 9447
--5197 12291 -12989 15509 -7507 14478 -11139 10504 -6560 11725 -3334 16116
--11815 12160 -13841 6728 -12552 9499 -4045 9730 38314 14376 53994 11231
-52558 7040 50086 2068 47994 -2682 48472 -6666 52302 -9762 59073 -12198
-68095 -14459 77932 -16891 85939 -19590 88520 -22459 82107 -25162 64893 -27057
-39020 -27164 12592 -24483 -4720 -18894 -24614 -10154 -4476 -7684 75259 -18343
-99055 16878 -71681 -21605 -115255 17201 -35195 9722 -48292 -8086 -3419 -7203
-12883 -9271 9192 -958 -6110 -8528 -26345 -12299 -38363 -11183 -47104 -8245
--50010 -4780 -50076 -614 -49569 4354 -49238 9649 -48785 14362 -47885 18022
--46491 20626 -44712 22351 -42691 23438 -40536 24103 -38352 24514 -36185 24777
--34067 24911 -31996 24901 -29975 24713 -27995 24336 -26074 23804 -24218 23174
--22437 22485 -20766 21745 -19228 20913 -17854 19929 -16957 18709 -16115 17501
--15229 16329 -14286 15202 -13330 14128 -12463 13126 -11762 12217 -11250 11411
--10892 10712 -10624 10107 -10336 9584 -9985 9137 -9563 8764 -9096 8463
--8669 8235 -8334 8079 -8159 7985 -8163 7941 -8343 7935 -8673 7959 -9135 8005
--9699 8066 -10373 8132 -11159 8202 -12061 8264 -13076 8314 -14201 8347
--15430 8364 -16746 8376 -18132 8393 -19568 8429 -21016 8494 -22434 8596
--23780 8736 -25016 8918 -26112 9134 -27077 9387 -27920 9668 -28662 9984
--29332 10327 -29963 10703 -30547 11112 -31073 11555 -31507 12031 -31812 12535
--31968 13075 -31959 13648 -31804 14251 -31545 14884 -31215 15544 -30841 16223
--30413 16912 -29884 17600 -29190 18277 -28251 18930 -27012 19547 -25471 20120
--23664 20638 -21689 21099 -20674 21573 -19270 21959 -17563 22240 -15632 22412
--13531 22495 -11313 22521 -9022 22501 -6706 22404 -4394 22184 -2050 21835
-349 21393 2839 20896 5378 20329 7866 19640 10186 18806 12337 17863 14458 16865
-16758 15829 19345 14742 22090 13591 24687 12372 26866 11087 28541 9748
-29837 8381 30952 7027 32004 5707 32977 4412 33782 3137 34288 1910 34347 807
-33784 -127 32407 -926 30146 -1697 27107 -2527 23632 -3400 20125 -4181
-16884 -4700 13916 -4858 10956 -4683 7583 -4311 3470 -3882 -1481 -3480
--7043 -3073 -12704 -2545 -17853 -1733 -21869 -486 -24245 1322 -24519 3778
--22215 6925 -16625 10692 -6766 14697 7983 17607 24438 15886 22488 4249
--52874 -9073 -40748 -16848 -44884 -3173 -16820 -18472 1976 -11895 -2373 -167
--38369 31947 -23598 90355 -1512 24851 -9036 -3883 -17652 -6945 -53342 14291
--16703 12077 16933 -16805 -5830 2754 47217 -691 -9472 -11976 -34962 -10596
-37589 19344 -8093 3597 -15326 -2940 -19044 -8330 -20279 -4889 -15291 15278
--16931 3027 -17266 4274 -14324 4436 -12335 6086 -11107 8274 -10466 13075
-13760 25687 60896 46797 22133 12184 1372 -6289 -6006 -12368 -7284 -11860
--6126 -8017 -4233 -2676 -2367 3005 -834 8314 284 12872 1014 16538 1402 19322
-1516 21315 1399 22641 1117 23432 709 23809 207 23875 -367 23722 -986 23417
--1638 23011 -2303 22541 -2980 22032 -3650 21504 -4312 20973 -4965 20449
--5612 19945 -6229 19464 -6819 19006 -7371 18567 -7892 18139 -8396 17716
-88: 10708360 -5692723 -150 7094 -10 7008 140 6904 310 6794 490 6681 670 6568
-860 6457 1040 6342 1250 6221 1470 6095 1690 5967 1910 5842 2120 5728 2330 5617
-2550 5496 2790 5374 3010 5258 3230 5153 3430 5056 3640 4971 3830 4879 4050 4797
-4240 4715 4420 4655 4580 4604 4710 4570 4850 4542 4990 4519 5100 4510 5200 4518
-5250 4544 5290 4584 5320 4641 5320 4709 5310 4793 5260 4896 5180 5013 5070 5144
-4940 5302 4780 5475 4580 5668 4370 5869 4120 6076 3840 6298 3520 6548 3170 6818
-2790 7100 2380 7384 1980 7658 1540 7935 1070 8239 560 8560 40 8875 -500 9184
--1030 9473 -1570 9750 -2120 10037 -2710 10323 -3290 10600 -3870 10855
--4450 11090 -5020 11307 -5600 11509 -6190 11697 -6770 11870 -7350 12020
--7900 12159 -8470 12273 -9020 12366 -9580 12436 -10120 12488 -10650 12529
--11170 12566 -11690 12587 -12180 12582 -12680 12556 -13160 12520 -13640 12478
--14090 12447 -14530 12411 -14980 12354 -15410 12283 -15810 12211 -16200 12146
--16610 12096 -16980 12046 -17350 11991 -17690 11937 -18030 11893 -18370 11853
--18700 11826 -19020 11808 -19330 11802 -19630 11801 -19930 11811 -20210 11827
--20510 11850 -20790 11881 -21070 11927 -21360 11988 -21630 12051 -21910 12121
--22160 12186 -22410 12258 -22670 12343 -22920 12440 -23170 12535 -23400 12626
--23590 12706 -23760 12784 -23950 12868 -24110 12960 -24267 13043 -24379 13112
--24453 13170 -24494 13216 -24515 13259 -24520 13298 -24484 13322 -24408 13334
--24294 13334 -24135 13320 -23941 13293 -23705 13251 -23431 13197 -23123 13133
--22785 13065 -22419 12987 -21996 12888 -21523 12773 -21014 12649 -20496 12525
--19983 12411 -19451 12292 -18867 12158 -18237 12009 -17598 11859 -16966 11723
--16373 11608 -15787 11502 -15167 11390 -14521 11273 -13888 11162 -13298 11082
--12765 11032 -12268 11007 -11766 10988 -11268 10977 -10806 10991 -10411 11035
--10093 11117 -9836 11231 -9606 11370 -9409 11533 -9274 11728 -9218 11954
--9254 12211 -9366 12497 -9540 12823 -9777 13190 -10094 13584 -10494 13997
--10965 14423 -11516 14871 -12169 15365 -12912 15897 -13730 16451 -14607 17004
--15523 17545 -16492 18086 -17579 18669 -18771 19283 -20016 19898 -21274 20487
--22501 21037 -23740 21563 -25161 22144 -26536 22682 -27890 23190 -29234 23668
--30591 24116 -31965 24526 -33315 24895 -34597 25218 -35797 25492 -36928 25713
--38016 25885 -39054 26000 -40001 26051 -40835 26037 -41547 25943 -42119 25771
--42543 25533 -42830 25237 -42978 24871 -42995 24426 -42861 23891 -42547 23257
--42010 22548 -41256 21780 -40333 20955 -39298 20058 -38157 19082 -36838 18037
--35299 16927 -33545 15760 -31652 14558 -29717 13337 -27740 12108 -25698 10848
--23554 9559 -21338 8266 -19097 7021 -16874 5875 -14723 4809 -12643 3768
--10639 2729 -8734 1718 -6932 793 -5227 2 -3624 -642 -2166 -1165 -905 -1611
-161 -2000 1062 -2325 1849 -2569 2536 -2685 3126 -2666 3619 -2495 4011 -2209
-4279 -1862 4426 -1501 4489 -1144 4540 -791 4590 -422 4596 -52 4537 206
-4413 423 4235 664 4023 984 3777 1393 3492 1849 3148 2300 2746 2696 2263 3026
-1703 3308 1066 3576 379 3861 -344 4174 -1067 4511 -1768 4845 -2421 5164
--3006 5457 -3526 5716 -3977 5925 -4366 6079 -4718 6166 -5035 6199 -5349 6197
--5646 6198 -5954 6233 -6261 6302 -6557 6376 -6846 6427 -7093 6458 -7276 6463
--7352 6401 -7265 6257 -6970 6063 -6450 5912 -5760 5882 -4999 5997 -4194 6203
--3460 6461 -2967 6768 -2829 7112 -2775 7402 -2482 7631 -2187 7856 -2034 7997
--1968 8164 -5004 9269 -6357 9521 -6289 9421 -5000 8392 -3792 7262 -2283 7286
--951 7946 -1942 9260 -5499 11353 -8859 13461 -7747 13825 -8699 12632 -5639 13093
--4536 14498 -8450 12367 -10870 9224 -16142 8393 -7598 9776 -4960 9774
-30650 8851 35814 7549 44718 3318 48755 -1366 52881 -5601 58819 -8808 66545 -10781
-76925 -12167 89651 -13566 102067 -15364 109157 -17790 104977 -20842 84833 -24098
-48754 -26492 9333 -26694 -2786 -25915 -55218 -15308 -23362 -27157 69661 -69265
-98257 -9394 83529 7705 -194596 85734 -122739 -882 -41866 -7133 -8511 -565
-13994 -10622 17917 9665 -403 -12751 -30100 -17103 -39233 -13625 -50824 -9718
--51357 -6433 -49386 -2223 -48346 3446 -48569 9971 -48631 15588 -47887 19653
--46376 22266 -44342 23792 -42038 24616 -39635 25047 -37253 25271 -34947 25370
--32729 25353 -30601 25203 -28548 24891 -26567 24417 -24658 23804 -22822 23107
--21080 22367 -19458 21579 -17966 20689 -16644 19626 -15927 18222 -15099 16928
--14159 15710 -13173 14553 -12263 13453 -11523 12431 -11022 11505 -10720 10687
--10513 9971 -10291 9353 -9967 8818 -9500 8369 -8938 8005 -8376 7734 -7907 7557
--7598 7461 -7496 7438 -7588 7468 -7845 7535 -8216 7631 -8680 7741 -9224 7857
--9869 7967 -10628 8063 -11527 8132 -12585 8177 -13789 8195 -15136 8195
--16604 8192 -18167 8203 -19772 8244 -21372 8323 -22902 8442 -24317 8602
--25589 8798 -26711 9029 -27704 9289 -28595 9577 -29401 9898 -30158 10247
--30865 10630 -31514 11046 -32085 11498 -32529 11986 -32823 12511 -32948 13073
--32913 13671 -32740 14307 -32471 14975 -32161 15676 -31816 16397 -31424 17130
--30936 17867 -30271 18592 -29352 19297 -28113 19966 -26546 20591 -24696 21164
--22672 21671 -21661 22201 -20157 22605 -18335 22892 -16302 23080 -14125 23203
--11856 23281 -9545 23298 -7221 23204 -4884 22967 -2489 22602 2 22158 2579 21652
-5173 21044 7655 20291 9980 19397 12219 18424 14568 17414 17230 16362 20185 15232
-23183 14014 25842 12720 27938 11359 29490 9949 30775 8513 32056 7093 33440 5710
-34809 4360 35951 3029 36639 1739 36674 543 35916 -529 34269 -1514 31766 -2493
-28598 -3511 25105 -4500 21632 -5304 18357 -5752 15186 -5770 11795 -5436
-7782 -4921 2870 -4406 -2931 -3985 -9266 -3627 -15582 -3205 -21247 -2550
--25746 -1497 -28748 78 -30051 2299 -29418 5297 -26185 9270 -18780 14479
--3641 20894 26012 25184 65810 11346 -78895 -3579 -48768 -9809 -29197 -4386
--8093 -8089 -5711 1301 -14479 13040 -22877 33908 -7839 44080 -11214 4631
--17992 -2133 -17785 -2246 -28299 3773 -3400 82 -9096 1693 -2968 2603 20274 -5636
--17631 -10312 -85523 -27072 74572 24666 13387 6603 -7297 592 -8155 5525
--14783 -2806 -13502 4417 -22755 5815 -20512 5708 -16104 6082 -12136 7752
--8122 10778 -1606 16089 14972 24284 33619 30236 19297 14231 5107 504 -2362 -6211
--4785 -7413 -4521 -5227 -3155 -1282 -1550 3305 -131 7824 930 11862 1618 15230
-1972 17883 2049 19864 1904 21255 1592 22158 1155 22671 637 22885 45 22877
--582 22710 -1235 22430 -1899 22072 -2570 21661 -3233 21216 -3891 20755
--4536 20290 -5176 19837 -5795 19396 -6374 18972 -6923 18561 -7447 18155
--7945 17751
-89: 10737490 -5683303 -490 7208 -360 7123 -220 7027 -50 6920 100 6812
-290 6703 450 6598 630 6486 820 6371 1020 6250 1230 6129 1440 6008 1630 5899
-1830 5793 2040 5676 2250 5560 2470 5450 2670 5348 2850 5257 3050 5173 3240 5087
-3420 5006 3600 4932 3780 4872 3910 4826 4050 4795 4160 4765 4300 4745 4400 4735
-4470 4747 4540 4771 4550 4810 4590 4864 4590 4930 4560 5010 4520 5110 4440 5222
-4320 5351 4200 5498 4040 5664 3850 5852 3640 6043 3410 6240 3140 6451 2830 6691
-2490 6945 2130 7214 1740 7485 1360 7745 940 8012 490 8298 0 8602 -500 8905
--1000 9196 -1520 9471 -2020 9736 -2570 10007 -3120 10281 -3680 10546 -4230 10790
--4790 11013 -5330 11221 -5890 11417 -6450 11600 -7010 11766 -7560 11914
--8100 12047 -8630 12160 -9160 12251 -9690 12323 -10210 12376 -10710 12420
--11210 12458 -11700 12482 -12170 12482 -12640 12463 -13090 12432 -13550 12397
--13970 12370 -14400 12340 -14810 12290 -15220 12228 -15600 12162 -15970 12103
--16350 12057 -16710 12015 -17050 11966 -17390 11918 -17710 11876 -18040 11844
--18350 11819 -18660 11807 -18970 11801 -19260 11802 -19550 11814 -19840 11833
--20120 11854 -20400 11887 -20690 11934 -20970 11993 -21260 12054 -21520 12125
--21780 12188 -22030 12257 -22290 12339 -22550 12431 -22810 12525 -23030 12613
--23230 12687 -23410 12763 -23600 12842 -23770 12927 -23928 13008 -24045 13070
--24121 13124 -24170 13165 -24198 13204 -24205 13237 -24177 13256 -24106 13264
--23995 13258 -23844 13237 -23656 13207 -23429 13162 -23160 13102 -22856 13033
--22527 12959 -22169 12878 -21751 12775 -21285 12657 -20786 12529 -20274 12402
--19769 12282 -19245 12164 -18669 12024 -18047 11872 -17414 11721 -16793 11583
--16206 11465 -15628 11360 -15022 11244 -14386 11127 -13760 11018 -13182 10936
--12658 10888 -12176 10860 -11682 10842 -11197 10833 -10751 10848 -10369 10892
--10066 10976 -9825 11090 -9609 11228 -9429 11393 -9315 11589 -9276 11816
--9323 12072 -9450 12357 -9641 12684 -9897 13049 -10228 13441 -10641 13855
--11124 14279 -11681 14723 -12340 15213 -13090 15743 -13915 16293 -14792 16842
--15701 17378 -16664 17915 -17744 18492 -18926 19101 -20154 19708 -21391 20291
--22601 20835 -23815 21356 -25206 21924 -26555 22457 -27877 22959 -29185 23431
--30510 23873 -31833 24277 -33144 24640 -34381 24957 -35543 25226 -36632 25443
--37672 25613 -38659 25723 -39557 25777 -40350 25762 -41012 25669 -41546 25506
--41934 25274 -42185 24982 -42299 24626 -42284 24192 -42128 23669 -41797 23054
--41253 22368 -40503 21631 -39582 20832 -38556 19955 -37432 19010 -36136 17995
--34627 16927 -32913 15806 -31065 14653 -29175 13478 -27254 12288 -25266 11080
--23181 9851 -21018 8606 -18822 7389 -16647 6259 -14536 5199 -12504 4200
--10547 3216 -8679 2256 -6901 1356 -5224 578 -3647 -67 -2216 -602 -955 -1052
-120 -1434 1051 -1759 1860 -2007 2571 -2152 3172 -2176 3677 -2062 4082 -1836
-4376 -1551 4557 -1247 4645 -941 4716 -633 4763 -301 4775 77 4696 318 4569 507
-4382 721 4158 1015 3882 1390 3575 1796 3199 2177 2758 2510 2244 2789 1650 3047
-985 3324 271 3630 -476 3971 -1206 4316 -1916 4646 -2560 4949 -3128 5219
--3618 5451 -4031 5647 -4378 5793 -4694 5882 -4992 5925 -5285 5938 -5583 5954
--5886 5995 -6195 6052 -6500 6105 -6781 6145 -7023 6182 -7200 6199 -7265 6164
--7179 6070 -6906 5964 -6445 5905 -5824 5918 -5095 5992 -4321 6109 -3598 6291
--3018 6556 -2644 6881 -2360 7197 -2054 7481 -1832 7760 -1851 8065 -2350 8499
--4072 9223 -5236 9471 -5952 8828 -6874 8740 -6552 8226 -5415 7902 -4026 7906
--4944 8539 -6987 9751 -8877 11175 -8304 12370 -6541 13647 -4323 14366
--3922 14387 -5949 12692 -8163 10370 -10437 8966 -6137 8905 -2930 8406
-1981 8024 9056 8866 33199 4282 41801 -408 49892 -4920 58552 -8187 66525 -9182
-77875 -9275 94329 -9385 113513 -9964 128411 -11496 129818 -14326 108329 -18440
-55582 -22806 -23312 -24320 -29155 -33313 -50811 -2405 -33655 -8840 72745 -58326
-90173 -16333 50750 21716 -114969 49619 -148983 -25893 -63658 -15505 -1685 -6351
--17078 -17 43442 14454 10636 -26437 -33302 -20671 -32693 -13300 -55737 -9364
--50375 -7679 -45999 -4127 -45226 2011 -47320 10328 -48372 16989 -47782 21358
--46019 23878 -43613 25173 -40964 25778 -38300 26022 -35741 26063 -33336 25978
--31077 25781 -28937 25473 -26906 25041 -24956 24474 -23079 23782 -21290 23019
--19601 22217 -18026 21367 -16599 20393 -15337 19233 -14763 17689 -13911 16347
--12935 15101 -11977 13909 -11198 12765 -10681 11703 -10424 10735 -10318 9876
--10200 9124 -9947 8471 -9486 7915 -8851 7465 -8158 7127 -7532 6909 -7083 6805
--6869 6797 -6882 6868 -7077 6991 -7387 7146 -7755 7320 -8162 7496 -8629 7660
--9207 7802 -9929 7908 -10842 7976 -11968 8001 -13301 8002 -14819 7988
--16485 7984 -18251 8003 -20034 8063 -21773 8163 -23393 8305 -24857 8484
--26162 8692 -27318 8929 -28359 9190 -29324 9479 -30223 9797 -31060 10149
--31834 10534 -32516 10956 -33083 11416 -33499 11915 -33748 12460 -33835 13042
--33773 13667 -33596 14337 -33355 15041 -33085 15782 -32805 16546 -32478 17328
--32046 18114 -31420 18893 -30522 19656 -29282 20383 -27688 21067 -25792 21695
--23709 22257 -22590 22821 -20972 23240 -19060 23550 -16979 23784 -14782 23964
--12516 24093 -10219 24127 -7900 24016 -5528 23752 -3061 23375 -474 22928
-2189 22404 4819 21750 7328 20938 9715 20013 12138 19039 14806 18035 17841 16963
-21102 15781 24211 14488 26799 13117 28724 11682 30178 10196 31558 8689
-33160 7202 35014 5756 36856 4337 38338 2920 39144 1508 39076 144 38081 -1137
-36182 -2351 33527 -3538 30350 -4691 26942 -5714 23534 -6446 20184 -6743
-16680 -6582 12668 -6083 7806 -5460 1932 -4908 -4773 -4515 -11831 -4241
--18606 -3948 -24475 -3465 -29045 -2660 -32252 -1442 -34294 252 -35392 2485
--35473 5340 -34156 9127 -30598 15747 -18500 29970 57082 18890 -27364 7263
--16140 -6973 -35801 -10229 -15269 3858 2989 17624 -9453 24095 -14833 31403
--134 16123 -9485 -2186 -16181 -1703 -19005 -3218 -19888 -2085 454 -737
-5045 4523 -9370 -212 -1264 -7734 -15898 -5193 -22517 -6891 11902 2992
-13760 3607 -17467 5304 -12980 4574 -10519 324 -18564 4534 -20930 6427
--18383 6903 -14308 7528 -9995 9110 -5066 11903 1859 15984 12125 20421
-20174 21488 15049 13512 6942 4691 1234 -840 -1392 -2657 -1847 -1672 -1165 1015
--78 4504 984 8152 1812 11561 2346 14508 2590 16915 2591 18779 2391 20146
-2045 21088 1580 21680 1040 21992 445 22092 -190 22033 -842 21856 -1507 21593
--2172 21267 -2831 20898 -3480 20502 -4120 20094 -4759 19688 -5371 19289
--5948 18900 -6493 18517 -7010 18136 -7514 17752
-90: 10766650 -5673900 -820 7318 -700 7237 -580 7147 -410 7044 -270 6943
--100 6839 50 6735 220 6630 400 6518 580 6402 780 6286 970 6174 1160 6070
-1340 5966 1530 5852 1740 5743 1920 5638 2120 5539 2290 5454 2470 5372 2640 5293
-2820 5212 2990 5145 3140 5086 3260 5043 3390 5012 3500 4985 3620 4963 3710 4958
-3780 4968 3820 4992 3860 5031 3860 5082 3880 5145 3840 5223 3790 5318 3710 5424
-3610 5548 3470 5690 3330 5849 3150 6027 2940 6210 2710 6396 2450 6600 2160 6827
-1850 7068 1490 7327 1120 7585 750 7830 360 8084 -80 8358 -540 8647 -1020 8933
--1510 9208 -1980 9471 -2480 9724 -2980 9982 -3530 10243 -4050 10497 -4590 10731
--5120 10941 -5640 11141 -6170 11330 -6710 11509 -7240 11669 -7780 11811
--8280 11942 -8790 12053 -9300 12143 -9800 12214 -10290 12269 -10770 12313
--11250 12353 -11710 12381 -12160 12385 -12590 12371 -13030 12345 -13450 12317
--13870 12296 -14260 12268 -14650 12224 -15030 12168 -15390 12112 -15750 12058
--16100 12019 -16440 11980 -16780 11938 -17090 11894 -17400 11855 -17710 11828
--18020 11809 -18320 11799 -18620 11796 -18890 11800 -19190 11812 -19470 11832
--19750 11858 -20030 11889 -20310 11935 -20600 11994 -20880 12056 -21150 12125
--21410 12184 -21650 12253 -21930 12332 -22190 12422 -22450 12513 -22670 12596
--22880 12670 -23070 12739 -23250 12815 -23430 12897 -23600 12971 -23714 13030
--23798 13080 -23852 13116 -23883 13149 -23896 13178 -23874 13192 -23808 13197
--23706 13184 -23558 13160 -23376 13124 -23154 13073 -22895 13009 -22593 12937
--22272 12859 -21921 12774 -21509 12669 -21051 12544 -20560 12414 -20056 12284
--19556 12159 -19042 12039 -18476 11897 -17859 11743 -17236 11588 -16624 11447
--16044 11330 -15476 11223 -14878 11106 -14251 10987 -13638 10878 -13069 10797
--12557 10747 -12085 10719 -11609 10703 -11133 10693 -10699 10708 -10332 10756
--10044 10839 -9816 10951 -9616 11091 -9455 11256 -9355 11452 -9335 11680
--9394 11935 -9535 12220 -9742 12547 -10015 12907 -10358 13300 -10785 13711
--11279 14134 -11841 14576 -12506 15062 -13261 15588 -14090 16134 -14966 16680
--15873 17210 -16832 17742 -17901 18315 -19070 18916 -20284 19518 -21503 20095
--22694 20631 -23885 21148 -25249 21703 -26575 22233 -27865 22727 -29135 23194
--30427 23630 -31714 24031 -32983 24388 -34182 24699 -35303 24965 -36350 25181
--37350 25345 -38286 25457 -39148 25512 -39894 25495 -40519 25409 -41012 25251
--41374 25027 -41587 24744 -41669 24400 -41634 23977 -41455 23461 -41114 22870
--40559 22213 -39809 21500 -38893 20722 -37881 19877 -36767 18960 -35492 17977
--34011 16947 -32335 15875 -30525 14761 -28675 13617 -26799 12469 -24855 11313
--22816 10140 -20699 8941 -18546 7761 -16403 6631 -14334 5592 -12329 4620
--10411 3679 -8572 2756 -6819 1896 -5165 1134 -3617 478 -2206 -72 -955 -525
-138 -901 1083 -1219 1916 -1471 2645 -1639 3261 -1698 3775 -1630 4180 -1464
-4488 -1234 4696 -988 4802 -734 4879 -470 4933 -173 4938 177 4845 399 4710 574
-4510 786 4267 1071 3977 1409 3636 1747 3236 2047 2765 2310 2212 2550 1584 2809
-893 3111 152 3454 -615 3818 -1360 4165 -2067 4469 -2692 4734 -3223 4963
--3656 5163 -3997 5335 -4283 5479 -4541 5580 -4806 5645 -5090 5686 -5398 5727
--5721 5776 -6053 5820 -6379 5857 -6679 5892 -6938 5935 -7119 5965 -7192 5952
--7121 5905 -6875 5866 -6455 5864 -5871 5891 -5170 5926 -4411 5990 -3672 6139
--3013 6394 -2498 6721 -2088 7056 -1783 7373 -1657 7708 -1846 8113 -2494 8638
--3733 9240 -4932 9558 -6000 9319 -6648 8253 -6997 8567 -7603 8604 -8237 8144
--8400 7877 -9291 8166 -11016 8919 -9930 10415 -4959 14309 -2695 15317
--2407 14642 -3469 12943 -4559 10966 -4765 9470 -2225 8764 -928 8433 -6036 8986
--1193 8993 14661 5454 26614 845 40499 -4243 53138 -8050 58501 -7321 68911 -5931
-88959 -4839 117219 -4006 143517 -4025 155184 -5458 139917 -8818 79706 -14028
--64613 -9814 -26647 -29807 -37291 -13143 -19330 -12665 39623 -27192 55046 -1613
-29516 31127 -39691 38345 -118929 -51402 -80864 -50157 -43722 -38036 -17461 -13673
-419 -6340 -3011 -13236 -1231 -4434 -18274 -9001 -64629 -7582 -44365 -8770
--39464 -6312 -40423 -448 -46478 10607 -48522 18110 -47672 22577 -45352 25008
--42418 26230 -39377 26779 -36470 26927 -33794 26814 -31361 26536 -29125 26161
--27043 25720 -25079 25188 -23192 24530 -21376 23751 -19646 22899 -18008 22013
--16493 21065 -15129 19990 -13940 18742 -13405 17171 -12527 15823 -11568 14543
--10737 13288 -10196 12065 -9971 10917 -9965 9868 -9996 8935 -9871 8120
--9478 7421 -8821 6848 -8021 6417 -7235 6134 -6625 6000 -6286 6005 -6225 6114
--6382 6301 -6653 6533 -6959 6779 -7245 7030 -7527 7260 -7869 7460 -8353 7619
--9051 7723 -10016 7778 -11264 7790 -12784 7778 -14525 7768 -16433 7777
--18411 7823 -20367 7909 -22219 8037 -23908 8200 -25413 8389 -26757 8597
--27968 8829 -29088 9083 -30141 9361 -31123 9673 -32026 10022 -32821 10407
--33483 10835 -33998 11303 -34354 11816 -34551 12375 -34600 12981 -34539 13632
--34397 14333 -34221 15076 -34038 15856 -33847 16667 -33599 17501 -33238 18341
--32655 19181 -31768 20004 -30512 20798 -28883 21546 -26935 22234 -24793 22854
--23451 23426 -21728 23874 -19797 24233 -17733 24533 -15577 24775 -13344 24934
--11074 24959 -8741 24813 -6303 24524 -3736 24145 -1037 23700 1719 23157
-4403 22461 6972 21618 9493 20693 12166 19742 15177 18745 18529 17639 21956 16386
-25027 15011 27423 13553 29166 12036 30616 10472 32261 8890 34352 7331
-36798 5812 39155 4296 40934 2741 41777 1140 41538 -454 40283 -1988 38195 -3428
-35502 -4766 32451 -5959 29236 -6906 25927 -7469 22423 -7556 18417 -7202
-13559 -6578 7612 -5914 592 -5403 -7098 -5104 -14811 -4939 -21791 -4746
--27423 -4371 -31405 -3717 -33957 -2772 -35685 -1537 -37121 -39 -37904 1348
--36286 680 -28690 -6386 -6544 -11642 16620 76573 -28764 39054 -17935 -67
--30831 -2078 4882 4357 3210 14811 -11176 19907 -6646 19936 -6140 10471
--8430 474 -14245 -472 -19833 -5808 -19482 -7078 -9468 -4807 -642 1215
--2622 1408 10851 2298 -28064 -8940 -10976 -5906 -5921 -3349 -7189 5135
--20309 8127 -17470 6235 -12879 3774 -12788 5505 -12848 6996 -11636 7727
--9360 8453 -6261 9782 -2171 11917 3226 14619 9496 16878 13583 16670 11881 12387
-7645 7034 3892 3109 1693 1436 934 1790 1083 3562 1654 6123 2295 8967 2813 11738
-3135 14224 3229 16324 3129 18006 2863 19286 2470 20210 1974 20829 1424 21201
-817 21373 181 21395 -471 21301 -1132 21115 -1792 20862 -2442 20560 -3089 20223
--3725 19867 -4357 19508 -4965 19149 -5537 18793 -6077 18441 -6597 18085
--7098 17724
-91: 10795860 -5664515 -1150 7425 -1040 7352 -920 7264 -780 7168 -630 7071
--490 6969 -340 6871 -180 6771 -20 6664 150 6555 340 6444 510 6335 690 6233
-860 6136 1030 6028 1220 5923 1410 5822 1570 5730 1740 5645 1900 5569 2060 5493
-2230 5416 2380 5350 2520 5295 2640 5256 2750 5225 2850 5201 2950 5179 3050 5174
-3090 5182 3140 5208 3170 5245 3170 5294 3170 5352 3140 5431 3090 5520 3010 5621
-2900 5738 2780 5876 2630 6028 2460 6197 2270 6371 2040 6549 1790 6744 1510 6959
-1200 7189 880 7435 520 7679 160 7915 -210 8155 -620 8416 -1070 8688 -1530 8963
--1990 9223 -2440 9472 -2910 9715 -3410 9961 -3910 10210 -4430 10451 -4940 10674
--5440 10877 -5930 11069 -6440 11249 -6960 11422 -7480 11577 -7980 11715
--8460 11841 -8950 11951 -9420 12038 -9910 12110 -10380 12168 -10830 12211
--11280 12254 -11720 12282 -12140 12290 -12560 12280 -12960 12258 -13370 12238
--13750 12223 -14130 12197 -14500 12158 -14850 12107 -15190 12058 -15530 12012
--15860 11976 -16180 11942 -16510 11905 -16810 11865 -17100 11834 -17400 11808
--17690 11794 -17990 11787 -18270 11787 -18550 11791 -18830 11806 -19110 11828
--19390 11855 -19670 11886 -19940 11934 -20230 11992 -20520 12055 -20790 12120
--21040 12180 -21300 12246 -21570 12324 -21840 12409 -22090 12499 -22330 12579
--22530 12650 -22730 12715 -22910 12789 -23100 12865 -23270 12936 -23395 12991
--23481 13037 -23540 13066 -23576 13097 -23593 13120 -23576 13132 -23517 13129
--23417 13115 -23277 13086 -23100 13044 -22885 12988 -22626 12920 -22337 12846
--22023 12764 -21678 12674 -21272 12566 -20823 12437 -20336 12302 -19841 12170
--19347 12044 -18839 11918 -18284 11776 -17676 11619 -17062 11461 -16453 11319
--15887 11198 -15330 11093 -14739 10974 -14121 10852 -13519 10745 -12961 10663
--12460 10612 -12001 10585 -11534 10567 -11075 10559 -10653 10574 -10301 10622
--10026 10704 -9813 10818 -9630 10957 -9481 11122 -9399 11320 -9391 11545
--9468 11800 -9624 12085 -9841 12409 -10130 12770 -10488 13160 -10926 13570
--11424 13986 -11998 14428 -12667 14910 -13428 15434 -14257 15975 -15133 16515
--16038 17042 -16990 17569 -18051 18135 -19206 18732 -20406 19327 -21611 19898
--22780 20428 -23954 20937 -25286 21488 -26589 22006 -27854 22497 -29092 22962
--30349 23391 -31601 23787 -32836 24139 -33991 24447 -35078 24709 -36086 24920
--37049 25086 -37946 25199 -38765 25252 -39468 25242 -40064 25159 -40522 25007
--40858 24791 -41042 24524 -41099 24190 -41037 23772 -40845 23276 -40484 22709
--39927 22076 -39179 21379 -38268 20628 -37267 19815 -36160 18931 -34907 17985
--33450 16990 -31802 15951 -30032 14870 -28211 13767 -26370 12659 -24465 11549
--22471 10418 -20384 9266 -18260 8114 -16152 7005 -14099 5990 -12124 5035
--10234 4114 -8424 3231 -6689 2407 -5056 1649 -3534 982 -2140 428 -892 -21
-202 -394 1155 -706 2008 -968 2751 -1148 3386 -1234 3904 -1204 4312 -1091
-4628 -918 4835 -721 4969 -516 5047 -290 5097 -38 5083 263 4986 459 4828 639
-4615 862 4355 1136 4048 1423 3676 1683 3251 1901 2750 2107 2171 2333 1508 2617
-785 2961 13 3338 -769 3708 -1526 4030 -2221 4288 -2816 4498 -3284 4670
--3629 4837 -3877 4996 -4066 5149 -4246 5277 -4470 5378 -4747 5459 -5088 5522
--5461 5576 -5842 5609 -6213 5634 -6554 5667 -6845 5713 -7047 5750 -7137 5755
--7089 5746 -6867 5756 -6469 5785 -5916 5808 -5236 5817 -4478 5864 -3716 6014
--3004 6282 -2404 6617 -1946 6954 -1652 7278 -1609 7634 -1904 8078 -2595 8619
--3650 9171 -4787 9505 -5823 9444 -6578 9008 -7277 9212 -8424 9198 -11591 8681
--11070 7801 -11173 7256 -14342 7280 -12858 7837 -3436 15019 -1470 15464
--1245 14244 -1646 12622 -1758 11012 -932 9699 1043 8868 1531 8653 -5671 9611
--5926 9988 2536 6705 10406 2785 29075 -3033 47128 -8874 42518 -4844 48684 -2345
-70640 -844 109943 1309 150037 3140 172982 4289 167473 4904 117605 3453
--33011 -16863 -33905 -28327 -40036 -17380 -19883 -14398 11887 -11898
-15877 3305 884 22306 -14821 8403 -56660 -40310 -55712 -52948 -51834 -43958
--39183 -23801 -23401 -13247 -27863 -13532 -18564 -8920 -26713 -7700 -40591 -10229
--35620 -8200 -33486 -6842 -36012 -4109 -47852 9962 -49312 17556 -47353 22263
--44146 25062 -40599 26647 -37183 27419 -34116 27607 -31428 27395 -29063 26973
--26943 26484 -24984 25958 -23130 25339 -21326 24572 -19588 23674 -17914 22702
--16329 21696 -14871 20634 -13573 19475 -12454 18169 -11841 16730 -10946 15402
--10090 14050 -9507 12672 -9291 11312 -9388 10025 -9588 8852 -9663 7814
--9418 6921 -8816 6181 -7955 5615 -7030 5238 -6251 5051 -5766 5047 -5625 5195
--5757 5450 -6038 5766 -6325 6107 -6528 6440 -6636 6750 -6722 7021 -6901 7242
--7293 7402 -8001 7504 -9075 7550 -10522 7560 -12290 7562 -14306 7573 -16470 7618
--18659 7697 -20761 7815 -22710 7964 -24453 8132 -26006 8312 -27401 8505
--28690 8715 -29902 8948 -31040 9212 -32077 9513 -32986 9858 -33746 10244
--34336 10677 -34764 11156 -35050 11683 -35204 12256 -35259 12883 -35245 13562
--35191 14291 -35120 15072 -35055 15896 -34970 16755 -34814 17646 -34512 18549
--33960 19451 -33072 20345 -31790 21209 -30110 22025 -28108 22779 -25901 23458
--24284 24031 -22511 24524 -20632 24953 -18647 25324 -16553 25611 -14357 25771
--12078 25761 -9683 25582 -7139 25281 -4432 24919 -1603 24487 1248 23931
-4006 23214 6669 22366 9364 21468 12303 20545 15603 19538 19146 18373 22578 17028
-25474 15551 27627 13999 29259 12392 30874 10744 32979 9086 35733 7454
-38843 5840 41700 4187 43700 2438 44487 594 44016 -1270 42530 -3046 40350 -4657
-37766 -6046 34994 -7159 32085 -7917 28905 -8231 25166 -8083 20481 -7570
-14510 -6898 7190 -6307 -1208 -5951 -10014 -5827 -18354 -5788 -25319 -5631
--30238 -5206 -32895 -4469 -33733 -3481 -33892 -2227 -34533 -291 -34949 3505
--32508 10060 -26262 14680 -2901 35709 28976 25533 -36656 19635 -18771 9256
--21512 -3838 -670 4145 -7798 10762 -29125 14126 -9919 13919 -6202 8231
--6939 3585 -14020 2065 -22648 -8688 -22411 -10895 -15681 -8443 -6952 3693
--6703 5255 -10788 -4174 681 -11627 -1027 -27198 -31169 9169 -25453 15325
--26406 13586 -20511 8266 -13391 5621 -4651 6770 -3219 7804 -3644 8394
--3473 8970 -2113 9924 464 11369 4059 13031 7891 14184 10311 13814 9958 11454
-7906 8331 5672 5813 4086 4592 3306 4725 3147 5922 3321 7792 3592 9969 3811 12173
-3911 14217 3845 15996 3638 17467 3302 18627 2859 19494 2343 20106 1774 20502
-1163 20721 527 20800 -127 20767 -782 20646 -1435 20455 -2079 20209 -2718 19926
--3349 19619 -3975 19301 -4575 18980 -5149 18660 -5688 18336 -6196 18006
--6694 17667
-92: 10825120 -5655150 -1480 7533 -1370 7465 -1270 7380 -1130 7289 -990 7194
--860 7099 -730 7005 -590 6910 -430 6808 -260 6703 -100 6597 70 6494 220 6394
-380 6302 550 6202 720 6101 890 6005 1050 5913 1200 5836 1340 5762 1500 5690
-1650 5617 1780 5552 1920 5499 2030 5462 2120 5433 2210 5408 2320 5391 2390 5385
-2440 5392 2470 5414 2500 5455 2490 5497 2490 5558 2460 5630 2400 5718 2330 5811
-2230 5925 2100 6056 1960 6199 1800 6359 1600 6527 1390 6699 1150 6883 880 7086
-600 7306 270 7539 -60 7772 -410 7995 -760 8225 -1160 8472 -1580 8731 -2020 8990
--2460 9240 -2890 9477 -3330 9707 -3810 9944 -4300 10181 -4790 10410 -5270 10622
--5750 10818 -6240 11001 -6710 11174 -7200 11340 -7700 11490 -8170 11626
--8640 11746 -9100 11852 -9560 11938 -10010 12012 -10450 12069 -10890 12114
--11320 12158 -11720 12187 -12130 12197 -12520 12192 -12900 12176 -13280 12158
--13640 12146 -14010 12127 -14340 12092 -14680 12046 -14990 12003 -15320 11962
--15630 11931 -15940 11902 -16240 11869 -16540 11834 -16810 11806 -17090 11786
--17380 11775 -17670 11771 -17940 11772 -18220 11781 -18480 11796 -18760 11820
--19040 11847 -19310 11882 -19600 11930 -19870 11986 -20170 12048 -20430 12112
--20690 12174 -20950 12238 -21220 12312 -21490 12396 -21740 12482 -21990 12561
--22200 12629 -22390 12692 -22590 12762 -22780 12834 -22950 12902 -23075 12952
--23169 12992 -23230 13022 -23274 13045 -23295 13064 -23284 13072 -23229 13064
--23135 13046 -23002 13016 -22828 12968 -22617 12907 -22369 12836 -22083 12757
--21777 12672 -21436 12579 -21040 12467 -20594 12334 -20118 12198 -19629 12061
--19141 11932 -18642 11804 -18093 11658 -17498 11501 -16888 11341 -16289 11197
--15733 11075 -15185 10965 -14605 10849 -13996 10726 -13403 10616 -12858 10533
--12370 10483 -11919 10457 -11469 10436 -11020 10429 -10612 10446 -10273 10492
--10013 10575 -9812 10688 -9645 10828 -9514 10992 -9444 11188 -9452 11415
--9544 11667 -9711 11951 -9941 12274 -10244 12633 -10614 13021 -11063 13428
--11569 13843 -12149 14280 -12823 14758 -13586 15279 -14417 15816 -15294 16351
--16197 16872 -17140 17396 -18194 17956 -19337 18546 -20524 19135 -21710 19700
--22863 20224 -24017 20728 -25332 21275 -26598 21786 -27832 22271 -29059 22730
--30274 23155 -31499 23544 -32696 23893 -33822 24199 -34866 24459 -35842 24668
--36768 24833 -37631 24946 -38415 25002 -39082 24997 -39643 24920 -40077 24773
--40375 24572 -40543 24312 -40579 23989 -40497 23588 -40290 23114 -39920 22564
--39356 21945 -38602 21272 -37709 20554 -36711 19775 -35616 18921 -34374 18006
--32941 17036 -31325 16031 -29579 14989 -27785 13927 -25976 12864 -24101 11782
--22122 10687 -20066 9574 -17985 8453 -15882 7386 -13849 6385 -11893 5433
--10018 4532 -8221 3680 -6518 2869 -4905 2112 -3395 1455 -2019 915 -784 464
-299 91 1275 -228 2136 -490 2892 -682 3541 -787 4063 -796 4477 -725 4784 -599
-5010 -447 5140 -281 5207 -99 5256 113 5228 344 5108 523 4929 712 4697 944
-4413 1194 4088 1417 3693 1593 3244 1744 2716 1919 2112 2160 1417 2486 661 2872
--130 3267 -939 3616 -1702 3883 -2381 4071 -2940 4208 -3326 4331 -3557 4473
--3665 4641 -3715 4824 -3792 5003 -3971 5151 -4263 5270 -4662 5356 -5115 5402
--5578 5420 -6023 5434 -6418 5466 -6750 5511 -6990 5547 -7103 5566 -7078 5587
--6879 5630 -6501 5672 -5958 5688 -5294 5690 -4536 5745 -3763 5919 -3020 6209
--2382 6546 -1898 6868 -1633 7171 -1657 7515 -2021 7959 -2754 8491 -3760 9032
--4862 9426 -5873 9596 -6740 9627 -7628 9891 -8959 10100 -11221 10089 -12266 9700
--12606 7574 -18330 7833 -12457 7603 -5397 12617 -2448 13052 -1414 12246
--1073 11350 -551 10486 580 9636 1931 8887 1609 8738 -1991 9340 -2500 9635
--1689 8495 -3523 5962 17957 185 44250 -10511 18291 -762 18712 1028 38089 1205
-90269 4404 146078 7285 176010 8914 171569 8794 125145 4517 33284 -10054
-2744 -26151 -35355 -13074 -15656 -16700 3373 -8384 -11161 -4395 -11097 4417
--15631 301 -11506 -22248 -21538 -44517 -55686 -39784 -67540 -23983 -52820 -16242
--48025 -13831 -32288 -16052 -25967 -16980 -24541 -3619 -23032 -8191 -29878 -6
--38422 -4741 -49776 755 -49179 12099 -46098 19193 -42110 23545 -38028 26178
--34350 27520 -31270 27913 -28715 27719 -26548 27273 -24633 26756 -22857 26176
--21135 25448 -19436 24534 -17757 23479 -16132 22363 -14592 21228 -13178 20081
--11937 18884 -10890 17569 -10084 16396 -9201 15066 -8560 13576 -8327 11999
--8497 10432 -8891 8958 -9219 7629 -9219 6474 -8777 5510 -7941 4759 -6925 4243
--5982 3970 -5351 3935 -5109 4103 -5225 4426 -5544 4836 -5870 5282 -6055 5718
--6032 6120 -5866 6472 -5692 6764 -5697 6994 -6032 7159 -6809 7266 -8076 7327
--9786 7365 -11865 7403 -14181 7461 -16597 7550 -18979 7664 -21208 7801
--23231 7949 -25028 8095 -26641 8241 -28114 8395 -29488 8569 -30785 8772
--31971 9015 -33006 9309 -33859 9650 -34519 10041 -35005 10484 -35339 10971
--35567 11511 -35728 12102 -35848 12747 -35948 13450 -36023 14212 -36097 15028
--36162 15898 -36188 16811 -36108 17761 -35845 18731 -35299 19707 -34393 20675
--33072 21614 -31342 22503 -29281 23326 -27013 24066 -25179 24649 -23432 25206
--21664 25712 -19769 26138 -17713 26437 -15496 26569 -13137 26521 -10619 26324
--7919 26046 -5051 25723 -2086 25315 848 24757 3677 24035 6438 23207 9302 22343
-12454 21431 15922 20382 19509 19121 22790 17658 25429 16068 27390 14412
-29063 12716 31050 10990 33816 9262 37354 7547 41149 5814 44437 3982 46541 1994
-47178 -123 46464 -2245 44802 -4210 42667 -5891 40383 -7208 38066 -8121
-35596 -8598 32593 -8628 28563 -8265 23004 -7666 15634 -7067 6599 -6693
--3505 -6642 -13647 -6806 -22670 -6928 -29501 -6728 -33394 -6049 -34103 -4911
--32182 -3524 -29518 -2068 -28865 -137 -28936 4818 -23303 18262 -22585 14917
-7755 32268 -12539 15665 -28355 15895 -15431 3395 -10916 4831 -6851 6549
--622 13561 -37895 10152 -17228 9500 -11743 9789 -9185 5742 -18539 2183
--25749 -7658 -26176 -9552 -21625 -6544 -14852 345 -9146 742 -6898 2261
--10787 -3636 -42639 -40982 -13819 14491 -18288 17954 -25580 14989 -20313 7396
--14244 5451 3021 7799 3754 8539 2047 8868 959 9194 1107 9773 2460 10654
-4665 11633 7046 12257 8655 12017 8860 10766 7999 9048 6789 7592 5756 6866
-5103 7000 4803 7878 4725 9274 4725 10946 4701 12684 4605 14343 4401 15827
-4092 17088 3691 18112 3211 18904 2672 19486 2089 19884 1478 20129 839 20247
-191 20260 -458 20190 -1104 20048 -1741 19853 -2374 19616 -2997 19353 -3615 19075
--4212 18791 -4781 18501 -5312 18207 -5818 17902 -6314 17586
-93: 10854430 -5645809 -1800 7641 -1710 7575 -1590 7494 -1480 7409 -1350 7316
--1230 7227 -1110 7138 -970 7045 -830 6949 -680 6849 -520 6746 -370 6648
--230 6556 -90 6465 70 6371 240 6277 380 6183 540 6094 670 6022 810 5950
-940 5880 1080 5812 1210 5749 1320 5700 1430 5663 1520 5636 1600 5612 1680 5597
-1760 5589 1800 5597 1830 5618 1840 5653 1850 5699 1830 5755 1790 5824 1740 5907
-1670 5996 1570 6105 1450 6229 1310 6366 1150 6517 960 6678 760 6843 540 7015
-280 7210 -10 7419 -310 7642 -620 7862 -960 8073 -1290 8291 -1680 8528 -2070 8774
--2500 9019 -2910 9259 -3330 9484 -3750 9702 -4210 9928 -4670 10154 -5130 10372
--5600 10575 -6060 10764 -6510 10938 -6980 11105 -7440 11263 -7910 11409
--8370 11540 -8810 11655 -9250 11760 -9680 11845 -10110 11916 -10530 11975
--10950 12020 -11340 12064 -11730 12095 -12120 12109 -12480 12108 -12850 12094
--13190 12078 -13540 12070 -13880 12056 -14200 12025 -14500 11987 -14810 11945
--15120 11909 -15410 11884 -15700 11861 -15990 11830 -16270 11800 -16530 11776
--16800 11759 -17070 11754 -17360 11751 -17620 11756 -17890 11767 -18160 11785
--18430 11807 -18690 11836 -18970 11872 -19250 11924 -19530 11976 -19810 12040
--20100 12105 -20350 12164 -20610 12224 -20870 12300 -21150 12382 -21410 12464
--21660 12543 -21870 12607 -22060 12667 -22260 12733 -22470 12803 -22630 12867
--22772 12914 -22865 12951 -22930 12976 -22977 12995 -23005 13010 -22994 13013
--22948 13002 -22858 12982 -22732 12946 -22562 12895 -22354 12832 -22115 12756
--21834 12672 -21532 12584 -21199 12487 -20812 12372 -20372 12239 -19900 12096
--19419 11956 -18942 11825 -18448 11695 -17906 11547 -17319 11388 -16716 11227
--16129 11080 -15582 10957 -15044 10846 -14474 10728 -13876 10604 -13292 10494
--12760 10410 -12281 10359 -11845 10333 -11406 10312 -10970 10306 -10578 10320
--10252 10369 -10004 10450 -9815 10563 -9663 10703 -9548 10867 -9493 11061
--9515 11287 -9620 11538 -9797 11820 -10042 12141 -10359 12498 -10740 12883
--11196 13287 -11710 13701 -12296 14134 -12973 14610 -13740 15123 -14573 15656
--15453 16187 -16348 16704 -17283 17222 -18331 17777 -19463 18360 -20636 18943
--21809 19502 -22944 20022 -24078 20518 -25371 21062 -26614 21571 -27821 22049
--29023 22500 -30210 22920 -31407 23304 -32567 23652 -33662 23955 -34670 24214
--35623 24421 -36516 24585 -37338 24702 -38090 24762 -38728 24762 -39262 24687
--39667 24551 -39944 24364 -40091 24111 -40107 23799 -40006 23421 -39789 22965
--39405 22429 -38836 21826 -38093 21181 -37202 20498 -36212 19750 -35124 18923
--33907 18031 -32480 17091 -30889 16115 -29171 15124 -27403 14106 -25601 13069
--23744 12010 -21811 10948 -19772 9863 -17681 8794 -15609 7758 -13578 6759
--11634 5815 -9756 4930 -8001 4086 -6304 3277 -4705 2549 -3216 1920 -1852 1385
--634 932 457 547 1434 221 2304 -43 3065 -244 3724 -367 4239 -404 4656 -370
-4988 -281 5178 -164 5304 -34 5398 110 5437 278 5352 440 5210 603 5006 799
-4755 1024 4447 1229 4100 1380 3692 1486 3217 1594 2662 1769 2039 2044 1326 2413
-538 2826 -285 3207 -1114 3503 -1888 3686 -2562 3786 -3073 3853 -3372 3936
--3457 4083 -3373 4293 -3238 4543 -3176 4789 -3299 4996 -3636 5144 -4143 5230
--4719 5258 -5292 5255 -5825 5256 -6287 5278 -6669 5320 -6948 5351 -7095 5383
--7092 5427 -6904 5492 -6545 5542 -6013 5554 -5351 5564 -4599 5647 -3823 5852
--3077 6159 -2428 6485 -1948 6772 -1705 7035 -1779 7345 -2222 7762 -3026 8277
--4086 8815 -5225 9278 -6271 9635 -7154 9952 -7954 10374 -8850 10830 -9949 11213
--11092 11343 -14984 10753 -28816 10366 -10627 5924 -4544 10757 -2574 9465
--1731 9204 -1226 9471 -521 9649 748 9408 2214 8515 2133 8178 700 8404 171 8551
-2033 8273 3592 7480 10529 5904 21093 -2229 -5895 2133 -9984 2464 -4454 1
-58213 4623 135553 8169 170655 9299 169715 7708 137398 1928 83090 -9325
-41731 -18564 -21000 -2116 3557 -23781 22739 -11244 -42539 -8488 -14168 -5045
--4759 1140 1238 -5433 4416 -38745 -61157 -32789 -93939 -15592 -59259 -16203
--40206 -14574 -33414 -17415 -35675 -14488 -28623 -4322 -20330 4043 -34136 5330
--41291 -16384 -55956 -15325 -48391 4735 -44179 14322 -39430 20773 -34801 24923
--30979 27083 -28061 27830 -25817 27804 -23986 27453 -22359 26961 -20786 26306
--19202 25425 -17583 24330 -15949 23109 -14339 21861 -12812 20644 -11427 19478
--10233 18302 -9271 16998 -8182 16116 -7368 14715 -7043 12998 -7241 11155
--7804 9333 -8423 7645 -8768 6154 -8605 4898 -7928 3904 -6913 3196 -5856 2791
--5063 2687 -4714 2850 -4804 3226 -5187 3734 -5615 4296 -5854 4851 -5787 5359
--5404 5804 -4865 6178 -4402 6481 -4248 6729 -4589 6915 -5532 7059 -7065 7169
--9111 7269 -11527 7373 -14142 7487 -16790 7618 -19331 7748 -21665 7872
--23756 7979 -25624 8069 -27317 8152 -28881 8246 -30340 8369 -31680 8539
--32852 8765 -33816 9056 -34549 9400 -35067 9802 -35435 10256 -35711 10755
--35946 11307 -36180 11910 -36430 12572 -36689 13297 -36935 14088 -37166 14943
--37353 15860 -37460 16833 -37428 17846 -37179 18890 -36621 19945 -35679 20992
--34314 22009 -32539 22977 -30430 23870 -28114 24672 -26236 25297 -24604 25926
--22937 26495 -21074 26944 -18972 27225 -16638 27318 -14120 27245 -11418 27070
--8532 26851 -5508 26586 -2444 26209 534 25655 3390 24936 6212 24132 9183 23287
-12446 22350 15951 21217 19416 19828 22460 18230 24857 16518 26747 14766
-28670 12993 31252 11207 34840 9418 39211 7615 43640 5736 47230 3690 49320 1438
-49734 -942 48781 -3271 47055 -5332 45133 -6963 43357 -8086 41713 -8705
-39857 -8857 37142 -8617 32812 -8108 26226 -7530 17141 -7139 5955 -7146
--6279 -7582 -18081 -8197 -27954 -8552 -34669 -8260 -37497 -7140 -36045 -5251
--30621 -2981 -23696 -873 -22366 439 -25263 2060 -8375 21896 -14865 16887
--16398 29518 -28652 16573 -26638 9045 -18823 6909 -12948 7373 -7971 9111
--18528 9430 -26353 8985 -17950 9738 -3933 5790 -7910 4358 -20418 335 -28283 -5316
--29487 -6227 -27139 -3414 -25959 892 -25494 2602 14178 -4671 -15206 -4860
--25465 -7722 -25340 8962 -16259 7026 -18156 8428 -21264 6040 -15139 6133
--2719 7823 1818 8683 2553 9008 2402 9194 2592 9495 3485 9981 4933 10541
-6533 10916 7737 10845 8187 10266 7976 9431 7419 8719 6809 8418 6325 8646
-5999 9369 5785 10461 5605 11769 5420 13152 5176 14499 4862 15728 4478 16801
-4025 17693 3512 18405 2953 18946 2366 19333 1753 19588 1118 19730 477 19779
--169 19748 -804 19649 -1429 19494 -2055 19299 -2671 19075 -3281 18833
--3868 18582 -4432 18325 -4961 18056 -5462 17778 -5956 17483
-94: 10883790 -5636490 -2100 7746 -2030 7683 -1930 7606 -1820 7525 -1700 7436
--1590 7353 -1470 7265 -1360 7181 -1220 7089 -1080 6992 -940 6891 -800 6801
--670 6712 -540 6625 -390 6538 -250 6445 -100 6355 30 6273 160 6201 280 6133
-400 6065 530 6003 650 5942 760 5894 840 5858 930 5835 1010 5812 1080 5795
-1140 5789 1180 5795 1200 5815 1210 5849 1210 5892 1190 5946 1160 6009 1110 6091
-1030 6176 930 6279 820 6398 680 6528 530 6670 340 6823 150 6981 -60 7146
--310 7329 -580 7529 -870 7739 -1170 7948 -1480 8154 -1820 8358 -2170 8581
--2560 8816 -2950 9050 -3350 9277 -3760 9491 -4150 9700 -4590 9914 -5030 10130
--5470 10338 -5920 10532 -6360 10712 -6790 10881 -7230 11040 -7670 11192
--8120 11333 -8550 11458 -8980 11572 -9390 11673 -9800 11755 -10210 11825
--10610 11883 -11000 11931 -11370 11974 -11740 12007 -12110 12023 -12450 12023
--12780 12013 -13110 12002 -13440 11996 -13760 11986 -14060 11959 -14340 11924
--14640 11889 -14910 11857 -15200 11836 -15480 11814 -15750 11791 -16000 11765
--16260 11744 -16520 11731 -16790 11727 -17050 11728 -17310 11736 -17580 11749
--17840 11769 -18100 11795 -18370 11825 -18640 11861 -18910 11912 -19200 11965
--19480 12028 -19760 12094 -20020 12152 -20270 12211 -20540 12284 -20820 12367
--21090 12448 -21330 12522 -21550 12583 -21750 12642 -21950 12705 -22150 12772
--22330 12831 -22460 12878 -22566 12909 -22635 12930 -22692 12948 -22717 12958
--22714 12956 -22668 12943 -22586 12919 -22465 12879 -22304 12825 -22098 12758
--21864 12680 -21588 12592 -21292 12499 -20964 12399 -20585 12282 -20151 12145
--19686 12001 -19213 11857 -18741 11724 -18260 11591 -17723 11444 -17143 11279
--16553 11117 -15974 10968 -15435 10845 -14906 10733 -14343 10612 -13760 10489
--13188 10378 -12664 10293 -12200 10241 -11773 10214 -11347 10196 -10924 10188
--10549 10200 -10234 10249 -9997 10330 -9823 10443 -9685 10582 -9585 10745
--9544 10939 -9584 11164 -9697 11412 -9886 11691 -10142 12012 -10471 12366
--10866 12749 -11328 13150 -11851 13560 -12439 13990 -13118 14461 -13891 14970
--14727 15498 -15603 16026 -16496 16535 -17425 17049 -18463 17598 -19588 18177
--20746 18752 -21905 19305 -23023 19820 -24143 20311 -25411 20851 -26635 21353
--27811 21827 -28994 22272 -30157 22687 -31320 23067 -32454 23414 -33513 23717
--34500 23972 -35419 24181 -36282 24345 -37073 24464 -37794 24530 -38410 24531
--38908 24466 -39296 24342 -39550 24159 -39682 23918 -39682 23626 -39568 23267
--39337 22821 -38943 22300 -38377 21724 -37639 21115 -36752 20457 -35758 19729
--34708 18924 -33469 18062 -32088 17150 -30497 16223 -28799 15275 -27034 14291
--25261 13272 -23451 12241 -21507 11194 -19453 10152 -17399 9122 -15319 8099
--13301 7107 -11331 6176 -9501 5295 -7723 4448 -6050 3668 -4472 2981 -2995 2373
--1638 1833 -423 1365 661 972 1636 644 2495 376 3273 166 3905 27 4449 -33
-4872 -23 5154 35 5369 124 5531 223 5600 332 5604 463 5473 559 5296 709 5068 900
-4790 1092 4462 1236 4092 1318 3669 1374 3177 1469 2608 1667 1960 1983 1236 2384
-425 2788 -422 3121 -1281 3329 -2082 3411 -2761 3415 -3244 3419 -3454 3491
--3364 3687 -3044 3988 -2642 4341 -2386 4678 -2456 4940 -2889 5094 -3565 5155
--4316 5144 -5022 5106 -5655 5088 -6177 5099 -6613 5131 -6934 5162 -7117 5205
--7126 5272 -6948 5353 -6596 5410 -6070 5429 -5419 5457 -4679 5570 -3917 5806
--3187 6115 -2557 6413 -2082 6652 -1858 6855 -1974 7116 -2506 7490 -3433 7973
--4641 8496 -5927 8995 -7075 9461 -8024 9939 -8823 10498 -9566 11132 -10383 11833
--11942 12675 -18536 14007 -50545 16704 -1284 3680 4750 7289 -93 4734 -1268 6106
--1429 7758 -1044 8955 327 9421 2709 7792 2938 7216 2923 7214 1797 7079
-5225 7123 3571 7476 3369 10730 1869 8730 -12306 10020 -22596 3165 -27369 -815
--2336 697 116708 6562 153965 7648 158853 5788 142894 887 113613 -6415
-79610 -10977 30925 -6288 7287 -14638 -2928 -10748 -27894 -9918 -10033 -10083
--1533 -2144 -13942 -6921 -16236 -20642 -25948 -27624 -103907 756 -39484 -16102
--20668 -13012 -30882 -19292 -50674 -12548 -40846 -9973 -27825 -1180 -33983 -4574
--53859 -7610 -46541 -12915 -45319 -2790 -42566 7962 -36618 17298 -31131 23316
--27266 26343 -24742 27497 -22999 27716 -21610 27508 -20301 27025 -18921 26245
--17442 25187 -15854 23928 -14204 22586 -12562 21268 -11016 20047 -9632 18924
--8484 17791 -7598 16472 -6213 15739 -5547 14160 -5623 12150 -6277 10006
--7184 7921 -7935 6033 -8191 4415 -7816 3112 -6943 2155 -5862 1563 -4948 1339
--4480 1462 -4531 1864 -4983 2456 -5560 3141 -5948 3830 -5924 4461 -5422 5008
--4549 5468 -3586 5858 -2837 6187 -2587 6475 -3035 6727 -4225 6952 -6102 7158
--8522 7350 -11273 7533 -14150 7698 -16986 7841 -19648 7947 -22066 8007
--24243 8029 -26203 8023 -28003 8014 -29664 8034 -31176 8103 -32506 8244
--33596 8465 -34415 8760 -34982 9120 -35359 9539 -35641 10004 -35912 10514
--36235 11073 -36620 11688 -37053 12360 -37511 13103 -37930 13919 -38289 14816
--38568 15784 -38716 16817 -38693 17901 -38428 19024 -37850 20161 -36880 21292
--35486 22393 -33680 23438 -31537 24408 -29198 25275 -27523 25977 -26047 26675
--24413 27277 -22462 27715 -20181 27962 -17628 28029 -14885 27971 -11968 27861
--8918 27729 -5800 27531 -2711 27176 231 26617 3043 25897 5847 25100 8828 24240
-12075 23237 15481 21979 18742 20443 21537 18707 23788 16888 25807 15063
-28199 13245 31564 11425 36045 9586 41214 7685 46147 5638 49892 3358 51840 847
-51984 -1758 50844 -4216 49184 -6263 47667 -7727 46629 -8564 45908 -8839
-44915 -8685 42689 -8248 38168 -7703 30477 -7266 19346 -7191 5484 -7718
--9440 -8848 -23328 -10133 -34240 -10858 -40890 -10487 -42872 -8892 -39800 -6055
--31065 -2502 -17704 1509 -17273 6265 -34802 14762 13093 -19560 -13328 24124
--35503 40950 -44499 19181 -38718 10367 -36123 8504 -24452 10063 -13671 9205
-2138 4410 -2592 5756 -3647 6420 -894 5067 -8388 4676 -24295 -576 -31459 -3975
--30245 -3295 -24328 -817 -18219 -234 -9660 -2847 -9635 3130 -15114 4904
--19352 3876 -27258 1172 -10866 3753 -16262 2833 -23267 6148 -18257 7182
--8892 8215 -2726 8819 279 9041 1666 9106 2588 9213 3603 9444 4821 9754
-6071 10011 7098 10072 7685 9904 7837 9616 7670 9401 7376 9423 7057 9765
-6765 10421 6490 11327 6226 12389 5932 13511 5601 14616 5216 15644 4777 16554
-4287 17332 3755 17967 3188 18463 2601 18833 1989 19089 1360 19247 726 19321
-89 19320 -533 19257 -1145 19137 -1765 18979 -2374 18788 -2972 18580 -3551 18360
--4109 18130 -4632 17889 -5128 17634 -5618 17362
-95: 10913220 -5627193 -2410 7849 -2340 7788 -2250 7715 -2150 7638 -2050 7554
--1950 7475 -1830 7392 -1720 7310 -1600 7224 -1480 7133 -1340 7037 -1230 6947
--1090 6864 -980 6784 -840 6697 -720 6608 -580 6525 -450 6446 -340 6378
--230 6312 -120 6245 -10 6187 110 6129 200 6082 280 6051 360 6025 430 6004
-490 5990 540 5983 590 5988 600 6008 590 6038 600 6080 580 6130 540 6191
-490 6265 410 6350 320 6448 210 6560 80 6684 -80 6821 -240 6962 -440 7113
--640 7273 -870 7445 -1130 7635 -1420 7835 -1690 8033 -2000 8228 -2320 8423
--2650 8635 -3020 8859 -3400 9081 -3780 9295 -4170 9501 -4540 9697 -4960 9903
--5370 10110 -5810 10308 -6230 10495 -6640 10666 -7060 10825 -7480 10979
--7900 11125 -8320 11261 -8730 11383 -9140 11492 -9530 11589 -9920 11671
--10300 11739 -10680 11795 -11050 11843 -11410 11889 -11750 11922 -12090 11939
--12420 11941 -12730 11933 -13030 11928 -13340 11923 -13640 11915 -13930 11895
--14190 11863 -14470 11834 -14720 11805 -14990 11785 -15260 11768 -15510 11751
--15760 11726 -16000 11712 -16250 11699 -16510 11697 -16760 11702 -17020 11714
--17270 11729 -17530 11751 -17800 11780 -18050 11810 -18310 11849 -18600 11896
--18870 11953 -19160 12015 -19430 12079 -19690 12138 -19960 12197 -20220 12269
--20500 12349 -20770 12428 -21020 12500 -21240 12561 -21440 12617 -21640 12676
--21840 12741 -22030 12796 -22170 12840 -22275 12869 -22345 12887 -22403 12901
--22440 12908 -22437 12903 -22396 12885 -22319 12856 -22204 12815 -22047 12758
--21844 12688 -21614 12605 -21349 12515 -21056 12418 -20735 12317 -20360 12195
--19932 12057 -19478 11908 -19009 11763 -18548 11628 -18072 11494 -17545 11343
--16969 11177 -16389 11013 -15823 10863 -15293 10738 -14771 10624 -14222 10504
--13649 10380 -13088 10267 -12571 10183 -12120 10130 -11707 10103 -11292 10082
--10885 10074 -10519 10085 -10220 10136 -9998 10216 -9836 10327 -9710 10466
--9623 10629 -9602 10822 -9650 11044 -9774 11291 -9973 11567 -10247 11885
--10582 12237 -10990 12618 -11458 13016 -11989 13422 -12581 13847 -13264 14315
--14041 14818 -14875 15343 -15751 15864 -16641 16370 -17564 16879 -18595 17421
--19709 17993 -20855 18563 -21997 19110 -23103 19620 -24209 20107 -25457 20639
--26657 21135 -27816 21604 -28965 22045 -30109 22458 -31244 22835 -32346 23179
--33384 23479 -34347 23733 -35232 23948 -36069 24111 -36836 24233 -37528 24302
--38121 24307 -38592 24256 -38959 24138 -39197 23962 -39310 23736 -39305 23465
--39173 23116 -38927 22683 -38540 22186 -37969 21644 -37232 21059 -36349 20417
--35393 19708 -34297 18934 -33132 18102 -31712 17235 -30147 16346 -28450 15430
--26733 14465 -24992 13474 -23141 12463 -21197 11441 -19185 10438 -17108 9424
--15042 8407 -12982 7430 -11061 6509 -9171 5628 -7415 4798 -5759 4065 -4187 3406
--2723 2793 -1378 2240 -179 1764 898 1368 1840 1038 2733 768 3460 550 4155 397
-4676 321 5061 311 5379 352 5617 415 5741 485 5771 568 5774 666 5617 713
-5390 840 5119 1002 4814 1145 4471 1223 4073 1248 3636 1276 3133 1384 2558 1612
-1901 1957 1162 2360 348 2726 -528 2976 -1419 3074 -2260 3041 -2978 2954
--3465 2912 -3612 3011 -3351 3300 -2728 3753 -1960 4265 -1416 4710 -1437 5002
--2063 5131 -3004 5128 -3980 5050 -4832 4962 -5535 4918 -6103 4914 -6579 4940
--6950 4980 -7165 5040 -7193 5132 -7016 5228 -6655 5295 -6133 5327 -5491 5376
--4777 5514 -4052 5762 -3372 6061 -2777 6315 -2316 6490 -2092 6624 -2229 6820
--2846 7141 -3950 7579 -5411 8062 -6950 8547 -8274 9048 -9378 9593 -10421 10201
--11647 10846 -13500 11445 -16984 11872 -24088 11912 -33889 11086 -3713 8263
-2965 7296 841 5425 -844 5787 -1478 7206 -1621 8494 -328 9975 3780 6847
-3513 6366 5613 6475 3972 6130 5304 6420 2397 7171 -8627 13564 -14219 13462
--24245 11912 -32919 6210 -32636 2141 -4791 1981 71104 4826 113922 5696
-131310 4401 134160 1222 130004 -3678 118192 -7204 78730 -6561 -400 -6514
--30994 -4774 -22664 -4884 6500 -5736 2630 -12484 -31077 -13936 -25708 -15652
--24374 -9858 -33329 10661 -28033 -12419 -18453 -13186 -46970 -24792 -51599 -4237
--35541 -5753 -46023 -6726 -37345 -7460 -40851 -15755 -43856 -14289 -46342 -9196
--43766 2330 -33894 14893 -27021 22267 -23461 25670 -21686 27033 -20626 27459
--19709 27366 -18673 26843 -17418 25932 -15946 24739 -14299 23395 -12560 22018
--10828 20709 -9214 19533 -7805 18463 -6685 17337 -5883 15938 -4276 15060
--3855 13195 -4374 10873 -5463 8444 -6626 6139 -7392 4114 -7501 2443 -6938 1179
--5969 345 -5005 -51 -4424 -29 -4423 357 -4936 1008 -5697 1805 -6320 2636
--6469 3408 -5964 4076 -4853 4633 -3400 5102 -1992 5520 -1019 5912 -785 6294
--1447 6670 -2988 7033 -5253 7372 -8033 7673 -11065 7924 -14130 8104 -17083 8206
--19827 8223 -22328 8168 -24616 8053 -26711 7919 -28645 7803 -30401 7744
--31930 7772 -33183 7899 -34118 8130 -34746 8445 -35138 8831 -35402 9269
--35666 9746 -36017 10261 -36507 10820 -37098 11435 -37751 12112 -38388 12870
--38947 13710 -39392 14646 -39697 15667 -39851 16763 -39807 17924 -39520 19129
--38928 20353 -37951 21571 -36560 22760 -34763 23888 -32617 24934 -30264 25868
--29032 26679 -27688 27430 -25954 28036 -23751 28442 -21163 28659 -18322 28735
--15328 28741 -12245 28736 -9112 28699 -6004 28551 -3011 28193 -210 27609
-2461 26865 5152 26046 8042 25136 11176 24028 14399 22627 17440 20944 20066 19093
-22339 17204 24697 15348 27760 13527 32000 11702 37353 9824 43190 7814
-48445 5578 52167 3057 53861 308 53728 -2465 52472 -4963 51019 -6897 50109 -8104
-50037 -8602 50507 -8545 50693 -8161 49317 -7671 44907 -7248 36190 -7055
-22708 -7321 5491 -8392 -12866 -10409 -29313 -12654 -41334 -13930 -47575 -13508
--48755 -11705 -45218 -8201 -35751 -4387 -13888 -2188 -18081 -6919 -33558 -11188
--27746 -19008 19773 47622 -37669 50964 -57089 29769 -69687 16118 -10213 7167
-1746 7796 -827 6404 8504 9609 -9073 3999 -4741 1415 -2382 5736 -9452 5412
--30481 -1853 -35021 -3668 -29909 -401 -19950 3321 -14686 2695 -9980 -1915
--16509 1206 -14954 5575 -14790 3664 -15160 2984 -7335 8021 -20543 1229
--24893 6013 -20260 7598 -12737 8447 -6483 8884 -2373 9018 136 9003 1806 8990
-3158 9067 4412 9232 5574 9426 6542 9575 7217 9647 7572 9690 7661 9791 7577 10036
-7398 10475 7162 11109 6892 11903 6597 12801 6255 13738 5874 14665 5449 15536
-4985 16318 4480 16999 3941 17566 3375 18021 2782 18372 2184 18625 1563 18792
-942 18884 316 18908 -296 18872 -895 18784 -1501 18656 -2106 18497 -2692 18318
--3263 18127 -3812 17923 -4330 17708 -4819 17475 -5302 17225
-96: 10942720 -5617921 -2710 7950 -2650 7890 -2570 7821 -2480 7750 -2380 7670
--2280 7594 -2190 7516 -2090 7437 -1970 7353 -1860 7269 -1740 7179 -1630 7092
--1510 7013 -1410 6936 -1280 6853 -1170 6768 -1040 6689 -930 6613 -830 6548
--720 6489 -630 6424 -520 6364 -420 6312 -330 6268 -260 6234 -200 6211 -140 6192
--80 6176 -30 6171 10 6175 10 6194 10 6222 10 6260 -20 6309 -50 6368 -100 6437
--190 6516 -270 6611 -380 6716 -510 6836 -650 6963 -820 7101 -990 7241 -1200 7392
--1420 7559 -1660 7738 -1940 7927 -2200 8116 -2500 8301 -2790 8487 -3120 8688
--3470 8900 -3840 9112 -4190 9316 -4560 9511 -4920 9698 -5320 9894 -5710 10093
--6130 10279 -6530 10459 -6920 10623 -7320 10774 -7710 10923 -8120 11064
--8520 11194 -8910 11311 -9290 11417 -9670 11510 -10030 11590 -10400 11657
--10760 11713 -11090 11762 -11440 11806 -11760 11841 -12080 11857 -12380 11859
--12670 11857 -12970 11854 -13240 11852 -13530 11848 -13800 11830 -14050 11801
--14290 11775 -14550 11752 -14790 11737 -15050 11722 -15290 11706 -15520 11688
--15750 11675 -16000 11667 -16230 11668 -16480 11674 -16740 11689 -16980 11706
--17240 11730 -17490 11762 -17750 11792 -18000 11832 -18280 11881 -18560 11939
--18850 11999 -19110 12063 -19380 12123 -19650 12182 -19910 12253 -20190 12329
--20460 12406 -20720 12478 -20930 12537 -21140 12590 -21350 12649 -21540 12709
--21740 12760 -21880 12804 -21990 12830 -22060 12847 -22122 12856 -22164 12858
--22166 12851 -22129 12830 -22057 12797 -21946 12752 -21792 12694 -21597 12619
--21370 12534 -21111 12440 -20824 12343 -20510 12238 -20139 12112 -19718 11972
--19272 11821 -18810 11673 -18356 11538 -17887 11401 -17371 11247 -16802 11079
--16230 10915 -15674 10765 -15152 10637 -14642 10523 -14103 10401 -13539 10274
--12992 10164 -12487 10079 -12044 10024 -11645 9996 -11244 9976 -10847 9965
--10496 9979 -10209 10027 -9999 10106 -9851 10216 -9738 10354 -9667 10515
--9656 10710 -9718 10929 -9854 11175 -10066 11448 -10346 11762 -10696 12111
--11113 12490 -11592 12883 -12124 13286 -12718 13707 -13408 14172 -14187 14671
--15024 15189 -15895 15705 -16781 16206 -17702 16710 -18725 17246 -19827 17811
--20962 18375 -22093 18917 -23183 19422 -24273 19905 -25501 20426 -26685 20920
--27824 21382 -28948 21820 -30063 22230 -31179 22605 -32257 22946 -33266 23247
--34202 23502 -35069 23714 -35883 23881 -36620 24005 -37286 24080 -37858 24095
--38312 24049 -38657 23938 -38880 23775 -38980 23568 -38962 23308 -38827 22966
--38575 22552 -38180 22089 -37612 21578 -36863 21005 -36024 20374 -35014 19693
--34022 18955 -32774 18166 -31405 17338 -29839 16476 -28189 15570 -26475 14632
--24682 13665 -22866 12683 -20959 11698 -18944 10710 -16840 9693 -14720 8687
--12707 7731 -10694 6817 -8827 5952 -7073 5165 -5409 4458 -3853 3789 -2418 3160
--1109 2601 82 2130 1120 1740 2126 1410 2928 1132 3764 909 4396 747 4902 660
-5325 640 5654 664 5836 706 5916 756 5972 817 5990 889 5764 895 5476 989
-5171 1105 4835 1184 4469 1202 4061 1190 3604 1211 3098 1336 2518 1589 1866 1939
-1134 2313 322 2609 -562 2759 -1484 2739 -2386 2589 -3180 2414 -3735 2343
--3892 2499 -3502 2936 -2529 3613 -1239 4350 -253 4920 -246 5210 -1238 5249
--2588 5128 -3829 4952 -4787 4805 -5496 4727 -6060 4717 -6563 4745 -6985 4805
--7248 4893 -7291 5012 -7098 5130 -6721 5210 -6195 5254 -5564 5318 -4892 5465
--4231 5709 -3642 5984 -3121 6186 -2685 6283 -2420 6335 -2530 6451 -3217 6712
--4511 7106 -6327 7528 -8223 7947 -9692 8436 -10876 8994 -12122 9599 -13761 10212
--16173 10672 -19746 10746 -24047 10097 -24063 8576 -470 9115 197 7265
--150 6198 -938 6109 -1167 6966 -1554 6958 513 8928 3884 7279 3070 6370
-4435 6431 1377 5962 1942 7568 -4378 8743 -14116 13202 -22665 14204 -31781 12534
--37986 8472 -34469 5073 -11264 4005 34184 4736 69726 4919 91816 4086 107582 2943
-126329 -862 149063 -4943 137003 -6001 -31458 1169 -72598 2382 -30155 -528
-9944 -3681 13153 -8014 -7660 -7411 -10057 -6160 29265 -23235 -15699 -5171
--21047 -5537 -27685 -13324 -39355 -22055 -47304 3617 -10266 -8423 -50264 -11412
--48475 -7003 -33171 -10122 -42067 -13377 -49136 -15441 -47889 -2069 -29515 15039
--22221 22132 -20067 24953 -19488 26275 -19144 26897 -18588 26926 -17676 26393
--16385 25428 -14780 24213 -12954 22887 -11029 21536 -9129 20251 -7398 19092
--5937 18016 -4831 16824 -4125 15288 -2473 13924 -2397 11700 -3368 9083
--4820 6436 -6125 4003 -6832 1936 -6776 321 -6099 -805 -5210 -1428 -4568 -1565
--4491 -1258 -5049 -604 -5989 276 -6911 1238 -7360 2164 -7020 2974 -5822 3649
--3975 4210 -1904 4708 -108 5196 968 5715 1040 6262 37 6829 -1927 7379 -4586 7871
--7653 8270 -10843 8540 -13973 8671 -16939 8657 -19720 8517 -22327 8284
--24782 7998 -27075 7721 -29178 7502 -31026 7383 -32533 7395 -33658 7535
--34394 7794 -34814 8147 -35054 8561 -35267 9019 -35588 9499 -36104 10009
--36812 10556 -37635 11158 -38484 11832 -39259 12596 -39888 13461 -40341 14434
--40624 15507 -40740 16672 -40678 17911 -40393 19200 -39824 20516 -38895 21827
--37553 23105 -35805 24323 -33693 25446 -31351 26452 -30660 27381 -29337 28165
--27336 28753 -24745 29130 -21775 29348 -18633 29480 -15457 29594 -12318 29706
--9245 29749 -6294 29611 -3534 29210 -986 28568 1459 27777 3964 26909 6698 25917
-9667 24694 12710 23157 15589 21359 18189 19439 20680 17534 23562 15702
-27407 13921 32506 12118 38613 10199 44895 8062 50254 5620 53769 2858 55132 -103
-54725 -2991 53451 -5460 52346 -7206 52193 -8107 53267 -8255 55186 -7921
-56931 -7454 56943 -7132 53250 -7064 43886 -7215 27833 -7667 6337 -9015
--16420 -12057 -35968 -15643 -49017 -17612 -53426 -16790 -52555 -15430
--47825 -11390 -39798 -6164 -15628 -3499 -37840 -15005 -32052 554 -27947 13567
-1550 40884 -14045 39885 -18477 24695 -11553 13164 -38313 8060 -16967 7959
--5055 3434 -1937 4651 -12932 172 -11618 3878 -7492 6483 -22491 5298 -29040 -540
--34539 -3232 -27087 3023 -15034 6842 -12846 2702 -6102 -15722 -23181 12457
--18081 10088 -13815 6161 -11610 5020 -9976 6529 -17537 3894 -21049 5911
--18690 7444 -13510 8352 -8289 8801 -4167 8936 -1222 8905 887 8841 2518 8837
-3879 8924 5045 9082 6013 9275 6738 9482 7218 9711 7457 9999 7520 10385
-7448 10891 7283 11519 7046 12243 6753 13030 6405 13841 6012 14638 5578 15390
-5105 16075 4597 16678 4065 17189 3504 17609 2924 17939 2333 18188 1729 18360
-1121 18467 511 18510 -92 18497 -679 18436 -1272 18334 -1865 18203 -2440 18052
--3002 17884 -3538 17707 -4052 17514 -4536 17304 -5011 17075
-97: 10972280 -5608673 -3010 8049 -2940 7991 -2880 7925 -2800 7859 -2710 7782
--2610 7709 -2530 7635 -2440 7562 -2340 7482 -2230 7400 -2130 7317 -2020 7231
--1920 7159 -1820 7085 -1720 7005 -1600 6925 -1500 6850 -1390 6776 -1290 6716
--1210 6656 -1110 6597 -1020 6541 -930 6488 -860 6446 -790 6416 -730 6392
--680 6371 -630 6356 -580 6354 -560 6355 -550 6374 -560 6399 -560 6437 -590 6481
--620 6539 -680 6604 -750 6678 -850 6766 -950 6869 -1070 6979 -1200 7102
--1370 7233 -1540 7366 -1740 7509 -1940 7668 -2180 7836 -2430 8018 -2700 8198
--2970 8370 -3260 8550 -3570 8741 -3900 8940 -4250 9143 -4600 9339 -4940 9522
--5290 9701 -5660 9887 -6050 10077 -6430 10256 -6820 10426 -7190 10584
--7570 10730 -7940 10869 -8330 11005 -8710 11132 -9090 11242 -9440 11345
--9790 11437 -10150 11515 -10490 11580 -10830 11634 -11140 11682 -11460 11727
--11780 11759 -12060 11778 -12350 11783 -12630 11781 -12890 11781 -13160 11783
--13430 11781 -13670 11765 -13910 11742 -14130 11717 -14370 11699 -14610 11686
--14840 11674 -15080 11661 -15290 11648 -15510 11637 -15750 11633 -15970 11636
--16220 11645 -16460 11662 -16710 11682 -16950 11707 -17200 11740 -17450 11774
--17710 11812 -17980 11863 -18260 11923 -18540 11984 -18820 12045 -19070 12105
--19340 12165 -19610 12234 -19890 12309 -20170 12386 -20410 12454 -20640 12512
--20840 12563 -21060 12622 -21260 12676 -21450 12728 -21600 12766 -21710 12792
--21783 12804 -21851 12810 -21894 12812 -21898 12802 -21868 12776 -21801 12740
--21690 12694 -21541 12631 -21354 12553 -21131 12466 -20876 12369 -20597 12271
--20287 12163 -19924 12035 -19506 11889 -19070 11739 -18614 11589 -18168 11450
--17708 11313 -17197 11157 -16638 10987 -16076 10823 -15527 10671 -15015 10542
--14518 10426 -13990 10304 -13435 10176 -12897 10065 -12406 9981 -11974 9925
--11584 9894 -11199 9874 -10818 9863 -10474 9878 -10202 9924 -10003 10002
--9870 10112 -9769 10245 -9713 10407 -9714 10599 -9788 10819 -9938 11062
--10159 11332 -10448 11644 -10806 11990 -11232 12364 -11722 12755 -12257 13153
--12860 13570 -13548 14030 -14329 14525 -15168 15036 -16039 15547 -16922 16045
--17835 16542 -18848 17073 -19943 17631 -21066 18190 -22189 18725 -23264 19225
--24338 19703 -25546 20219 -26712 20706 -27833 21165 -28938 21598 -30035 22006
--31115 22376 -32175 22716 -33163 23017 -34075 23274 -34920 23484 -35713 23656
--36431 23783 -37075 23860 -37620 23884 -38059 23848 -38386 23745 -38600 23598
--38687 23404 -38662 23151 -38523 22824 -38268 22439 -37868 22006 -37294 21509
--36574 20943 -35683 20336 -34794 19694 -33683 18998 -32512 18247 -31153 17439
--29614 16587 -27941 15699 -26191 14787 -24451 13857 -22677 12912 -20770 11956
--18693 10959 -16546 9939 -14444 8956 -12336 8016 -10323 7115 -8461 6285
--6681 5531 -5032 4806 -3505 4107 -2115 3468 -819 2923 333 2472 1468 2090
-2340 1759 3309 1474 4043 1245 4647 1080 5206 989 5625 961 5882 972 6013 1000
-6144 1036 6248 1078 6230 1120 5865 1101 5549 1153 5226 1210 4874 1224 4485 1192
-4056 1158 3584 1182 3073 1317 2502 1571 1873 1902 1162 2224 376 2438 -490 2481
--1428 2342 -2386 2082 -3286 1828 -4000 1734 -4304 1959 -3912 2587 -2610 3573
--597 4640 1109 5347 1115 5560 -583 5415 -2528 5115 -4005 4816 -4948 4605
--5543 4507 -6008 4497 -6517 4544 -7039 4639 -7372 4767 -7417 4919 -7196 5063
--6782 5163 -6251 5212 -5639 5273 -5001 5407 -4430 5635 -4003 5881 -3633 6028
--3242 6041 -2888 5986 -2883 6000 -3614 6194 -5063 6580 -7315 6940 -9662 7242
--11025 7723 -12002 8268 -13199 8851 -14843 9485 -17010 10005 -19566 10293
--21158 10395 -17724 10437 -6197 9380 545 4885 555 5221 189 6708 -719 6789
--1585 6401 -688 5922 3121 6164 -1290 5433 -1113 5537 -1895 6177 -1556 8664
--6947 10769 -16082 13446 -25852 14194 -34968 12792 -40481 9919 -37843 7314
--22681 6067 3398 5876 27175 5520 44635 4765 60405 6220 87009 2979 144163 -2117
-224125 -7274 -87335 9010 -112381 8582 -15504 1820 35155 -2076 42211 -4584
-32942 -4859 36133 -6182 52368 -14474 -15733 -13603 -35116 -21263 -20944 -17329
--2709 -289 -26918 1202 -24744 -18739 -40572 -24708 -58411 4009 -16998 362
--40816 -9327 -48508 -20674 -53970 -4201 -20708 18072 -17949 21337 -18503 23138
--18992 24794 -18995 25917 -18467 26242 -17398 25833 -15853 24948 -13946 23817
--11809 22537 -9587 21169 -7448 19817 -5542 18576 -4000 17402 -2916 16093
--2319 14422 -873 12326 -1236 9694 -2653 6833 -4371 4058 -5721 1605 -6320 -381
--6140 -1832 -5492 -2728 -4875 -3079 -4742 -2925 -5286 -2342 -6391 -1451
--7638 -399 -8500 670 -8495 1640 -7405 2461 -5337 3137 -2692 3729 -51 4309
-1989 4945 2978 5670 2701 6462 1228 7278 -1198 8040 -4183 8673 -7379 9112
--10527 9326 -13516 9310 -16365 9093 -19141 8727 -21904 8277 -24621 7812
--27218 7408 -29557 7116 -31510 6980 -32981 7013 -33944 7200 -34462 7509
--34690 7908 -34826 8350 -35056 8812 -35510 9284 -36234 9766 -37171 10286
--38194 10861 -39169 11520 -39997 12282 -40605 13168 -41000 14177 -41221 15304
--41303 16537 -41252 17856 -41030 19237 -40554 20646 -39743 22055 -38522 23430
--36858 24737 -34813 25946 -32493 27023 -32231 28058 -30753 28859 -28327 29428
--25277 29801 -21939 30066 -18598 30298 -15391 30541 -12369 30753 -9535 30829
--6899 30648 -4494 30160 -2270 29432 -94 28576 2210 27646 4785 26574 7617 25249
-10544 23618 13392 21762 16129 19837 19010 17977 22525 16222 27143 14515
-32984 12742 39600 10772 46059 8483 51266 5813 54429 2802 55402 -356 54766 -3329
-53552 -5731 52887 -7263 53573 -7841 55868 -7654 59373 -7127 63040 -6767
-65152 -6945 63186 -7631 54109 -8332 35515 -8572 8345 -9231 -20045 -13319
--43208 -18818 -57634 -21574 -57285 -18424 -52353 -19256 -42784 -17410
--29046 -21365 -17318 -40855 -88553 36390 -69375 54976 3298 21966 -1965 30133
--643 22909 -2177 12205 -5514 8112 -23758 7875 -8614 5808 -882 -1828 -8869 2624
--21919 -1200 -15896 3954 -18640 6818 -30076 6297 -21812 1805 -31679 -2975
--14850 10848 -23706 4701 -26097 9982 -18623 5567 -13730 -1882 -12819 2047
--11044 3552 -9934 4395 -10388 5374 -14385 5021 -16732 6120 -15684 7319
--12382 8177 -8450 8654 -4884 8829 -2024 8826 191 8762 1935 8731 3358 8778
-4536 8914 5499 9125 6260 9395 6798 9718 7131 10108 7291 10569 7302 11112
-7203 11730 7012 12407 6743 13119 6415 13840 6035 14543 5608 15209 5141 15819
-4646 16360 4127 16828 3582 17217 3024 17531 2443 17773 1853 17950 1262 18067
-665 18125 82 18133 -495 18093 -1072 18016 -1652 17908 -2217 17781 -2771 17638
--3293 17482 -3796 17311 -4275 17122 -4745 16912
-98: 11001900 -5599447 -3290 8144 -3240 8089 -3170 8029 -3110 7962 -3030 7891
--2940 7821 -2860 7752 -2790 7684 -2690 7610 -2600 7529 -2500 7448 -2400 7369
--2320 7298 -2220 7229 -2130 7154 -2030 7078 -1940 7004 -1830 6937 -1760 6878
--1670 6820 -1580 6766 -1510 6709 -1420 6660 -1360 6620 -1290 6590 -1260 6566
--1200 6547 -1160 6533 -1120 6528 -1090 6533 -1100 6546 -1100 6571 -1120 6607
--1140 6649 -1170 6703 -1230 6766 -1310 6833 -1390 6916 -1500 7015 -1610 7119
--1740 7238 -1900 7358 -2060 7487 -2250 7621 -2450 7773 -2670 7935 -2930 8104
--3160 8275 -3430 8441 -3710 8610 -4000 8791 -4320 8982 -4650 9175 -4990 9360
--5300 9536 -5640 9707 -6000 9883 -6370 10064 -6730 10233 -7100 10397 -7460 10546
--7810 10688 -8170 10820 -8530 10950 -8900 11074 -9250 11180 -9590 11279
--9920 11366 -10260 11441 -10570 11507 -10890 11558 -11200 11607 -11490 11650
--11780 11683 -12050 11703 -12320 11709 -12570 11709 -12840 11710 -13070 11712
--13330 11714 -13550 11702 -13770 11680 -13990 11662 -14200 11645 -14420 11634
--14660 11626 -14860 11617 -15080 11607 -15280 11599 -15510 11596 -15730 11603
--15960 11614 -16200 11633 -16430 11655 -16680 11684 -16920 11717 -17170 11751
--17430 11790 -17690 11844 -17960 11904 -18250 11965 -18530 12026 -18780 12086
--19040 12145 -19320 12214 -19600 12289 -19870 12364 -20130 12431 -20350 12485
--20560 12538 -20770 12592 -20980 12647 -21170 12694 -21320 12730 -21440 12752
--21519 12765 -21583 12767 -21628 12766 -21640 12752 -21615 12725 -21545 12686
--21441 12637 -21298 12571 -21115 12490 -20894 12402 -20645 12301 -20372 12201
--20068 12093 -19711 11961 -19302 11812 -18870 11661 -18422 11508 -17983 11369
--17532 11228 -17027 11071 -16479 10902 -15923 10734 -15386 10582 -14881 10454
--14397 10336 -13881 10211 -13333 10086 -12805 9971 -12327 9886 -11907 9832
--11532 9799 -11157 9778 -10787 9767 -10460 9782 -10200 9826 -10013 9903
--9890 10012 -9805 10145 -9760 10304 -9774 10494 -9862 10710 -10020 10952
--10252 11221 -10548 11528 -10920 11872 -11353 12241 -11848 12629 -12391 13024
--12997 13436 -13689 13891 -14469 14381 -15310 14886 -16179 15392 -17057 15884
--17967 16377 -18970 16901 -20057 17454 -21171 18005 -22279 18535 -23342 19029
--24402 19504 -25590 20013 -26739 20496 -27850 20950 -28933 21380 -30006 21783
--31067 22152 -32102 22488 -33075 22788 -33964 23047 -34787 23261 -35561 23435
--36259 23563 -36886 23648 -37413 23677 -37839 23647 -38146 23557 -38350 23427
--38428 23243 -38406 22993 -38262 22693 -37999 22339 -37591 21921 -37039 21429
--36286 20887 -35492 20317 -34495 19713 -33469 19057 -32308 18321 -30961 17521
--29387 16680 -27698 15817 -26001 14945 -24322 14062 -22527 13152 -20546 12195
--18433 11192 -16296 10185 -14119 9219 -11962 8288 -9962 7416 -8044 6613
--6268 5843 -4648 5076 -3173 4357 -1772 3736 -495 3224 755 2792 1718 2413
-2792 2082 3613 1797 4285 1568 5003 1406 5517 1314 5853 1278 6065 1278 6262 1297
-6458 1326 6512 1345 6394 1355 5965 1323 5657 1330 5329 1323 4950 1278 4529 1210
-4075 1159 3581 1178 3057 1306 2508 1541 1912 1829 1257 2093 534 2228 -270 2177
--1171 1935 -2148 1574 -3160 1243 -4112 1115 -4749 1391 -4649 2220 -3218 3610
--276 5185 2674 6023 2574 6013 -477 5552 -3133 5015 -4626 4596 -5325 4341
--5610 4255 -5863 4268 -6366 4332 -7096 4495 -7548 4663 -7585 4844 -7291 5022
--6817 5145 -6295 5195 -5692 5233 -5076 5316 -4603 5515 -4431 5762 -4363 5871
--4091 5783 -3580 5598 -3331 5468 -4162 5552 -5600 6003 -8342 6364 -11258 6503
--11839 7090 -12180 7588 -13167 8050 -14570 8717 -16124 9268 -17944 9583
--19995 9902 -21814 10404 -19716 9852 13684 4951 2096 6840 2122 6852 -249 6183
--2171 4807 -2502 4145 -1890 4335 -4598 4545 -5728 4725 -5643 5892 -2583 9958
--6921 12240 -15776 13779 -26004 14016 -35452 12818 -41690 10781 -41955 8980
--34567 8096 -21502 7915 -9108 7793 -1108 7724 2647 8541 6497 7545 28800 5416
-189768 -2276 -2657 7626 -80219 9450 46188 443 75285 -1629 68723 -2839
-56965 -3918 54593 -6615 53107 -12800 20039 -17326 5818 -20114 16845 -14370
--11943 6676 -20502 -1061 -35515 -33877 -35527 -20035 -42394 1371 -41263 10060
--46182 -13407 -22886 -4800 -47582 563 -16095 13478 -20442 15003 -20749 19160
--20653 22680 -20226 24866 -19281 25702 -17768 25534 -15751 24788 -13367 23700
--10789 22338 -8185 20780 -5732 19200 -3606 17758 -1956 16440 -895 15044
--436 13332 497 10417 -416 7365 -2237 4304 -4137 1486 -5461 -881 -5949 -2680
--5740 -3878 -5288 -4488 -5133 -4549 -5639 -4132 -6836 -3333 -8390 -2285
--9727 -1139 -10229 -28 -9478 961 -7417 1795 -4362 2518 -939 3208 2122 3959
-4166 4839 4800 5858 3954 6967 1873 8061 -1003 9022 -4171 9732 -7234 10117
--10009 10155 -12555 9880 -15098 9373 -17842 8732 -20858 8064 -24018 7454
--27088 6977 -29782 6681 -31898 6589 -33339 6694 -34140 6959 -34449 7336
--34514 7774 -34595 8230 -34891 8675 -35508 9105 -36434 9541 -37552 10007
--38688 10540 -39684 11171 -40452 11927 -40956 12829 -41242 13870 -41403 15052
--41498 16354 -41533 17756 -41473 19230 -41195 20740 -40588 22252 -39540 23729
--38000 25135 -36027 26431 -33726 27586 -33557 28692 -31694 29501 -28761 30071
--25283 30482 -21717 30838 -18374 31197 -15358 31555 -12666 31825 -10243 31871
--8041 31587 -6042 30979 -4144 30152 -2202 29238 -43 28260 2453 27141 5240 25765
-8173 24105 11134 22261 14154 20395 17526 18633 21672 16990 26939 15372
-33266 13625 40082 11573 46410 9100 51233 6170 53908 2893 54477 -474 53659 -3540
-52576 -5894 52376 -7228 53858 -7496 57260 -6990 62267 -6326 68013 -6267
-72923 -7391 74151 -9568 67205 -11497 46807 -11056 11429 -8403 -23737 -13417
--50059 -21723 -68606 -26063 -58217 -13520 -50434 -16821 -45694 -10092
--33337 4122 -13202 -7506 -66391 28684 -52330 15951 -16358 28556 -35079 28940
--3111 10774 -1065 1966 -8617 7486 -19752 1896 -3409 1267 15553 -287 -16190 2685
--23020 1016 -19076 3016 -30303 8850 -17752 5232 -22406 7874 -28800 2413
--15089 6878 -29084 5572 -37102 10630 -15706 4679 -13505 -310 -11517 871
--9712 2506 -8953 3780 -9616 4790 -11754 5329 -13136 6250 -12618 7237 -10515 8018
--7676 8507 -4805 8730 -2285 8775 -192 8741 1514 8716 2921 8752 4079 8876
-5031 9086 5787 9377 6356 9739 6738 10168 6957 10660 7030 11213 6985 11815
-6841 12453 6610 13109 6317 13763 5957 14399 5553 14999 5109 15552 4635 16046
-4133 16478 3613 16843 3073 17142 2511 17379 1938 17559 1366 17682 787 17755
-222 17777 -339 17758 -904 17700 -1468 17615 -2022 17509 -2562 17388 -3077 17252
--3567 17102 -4037 16931 -4507 16740
-99: 11031590 -5590246 -3570 8235 -3520 8188 -3470 8127 -3400 8065 -3340 7997
--3260 7930 -3190 7866 -3110 7801 -3040 7731 -2950 7654 -2860 7578 -2780 7503
--2700 7435 -2610 7369 -2530 7299 -2450 7225 -2350 7154 -2270 7091 -2190 7036
--2120 6981 -2050 6928 -1980 6872 -1900 6826 -1830 6789 -1790 6757 -1750 6737
--1710 6717 -1670 6703 -1640 6699 -1610 6702 -1620 6714 -1640 6739 -1640 6771
--1670 6811 -1710 6859 -1760 6919 -1840 6985 -1920 7063 -2010 7155 -2130 7256
--2260 7366 -2410 7482 -2560 7603 -2750 7731 -2930 7873 -3160 8028 -3390 8190
--3620 8353 -3870 8508 -4140 8669 -4420 8842 -4710 9023 -5040 9205 -5360 9381
--5660 9549 -5980 9715 -6330 9881 -6670 10052 -7020 10215 -7370 10371 -7710 10513
--8050 10646 -8390 10777 -8730 10900 -9080 11016 -9400 11122 -9740 11214
--10040 11301 -10360 11373 -10660 11438 -10960 11487 -11240 11532 -11520 11575
--11780 11610 -12050 11630 -12290 11638 -12530 11640 -12760 11641 -13000 11646
--13230 11647 -13440 11639 -13640 11621 -13840 11605 -14050 11591 -14250 11583
--14470 11577 -14670 11572 -14860 11565 -15070 11560 -15280 11559 -15490 11570
--15720 11581 -15950 11603 -16170 11626 -16410 11659 -16660 11692 -16890 11726
--17150 11768 -17410 11822 -17690 11882 -17970 11945 -18240 12009 -18500 12064
--18760 12124 -19030 12192 -19320 12268 -19590 12341 -19850 12407 -20070 12461
--20280 12509 -20500 12564 -20710 12615 -20900 12662 -21050 12695 -21170 12713
--21260 12725 -21315 12727 -21369 12720 -21384 12704 -21363 12675 -21298 12635
--21200 12581 -21057 12516 -20879 12430 -20664 12340 -20419 12238 -20151 12135
--19853 12023 -19504 11890 -19100 11740 -18670 11586 -18235 11434 -17805 11291
--17355 11150 -16862 10992 -16321 10820 -15776 10650 -15247 10499 -14753 10369
--14278 10249 -13771 10127 -13235 9999 -12723 9885 -12254 9798 -11845 9742
--11483 9710 -11116 9688 -10762 9678 -10448 9690 -10199 9734 -10025 9810
--9918 9916 -9842 10049 -9813 10205 -9837 10393 -9936 10608 -10107 10847
--10344 11113 -10650 11418 -11032 11757 -11470 12123 -11977 12507 -12522 12897
--13131 13305 -13829 13754 -14609 14239 -15447 14740 -16316 15239 -17191 15726
--18096 16213 -19091 16732 -20169 17278 -21274 17823 -22368 18346 -23422 18835
--24467 19305 -25640 19813 -26773 20288 -27864 20738 -28926 21162 -29986 21562
--31029 21929 -32040 22266 -32996 22560 -33866 22822 -34671 23037 -35427 23215
--36106 23347 -36713 23439 -37236 23472 -37642 23451 -37937 23375 -38128 23256
--38213 23077 -38182 22846 -38032 22573 -37765 22240 -37369 21826 -36804 21346
--36108 20841 -35256 20315 -34304 19750 -33313 19106 -32151 18373 -30763 17581
--29196 16763 -27554 15943 -25925 15124 -24208 14279 -22323 13388 -20317 12422
--18229 11420 -16054 10433 -13789 9471 -11637 8554 -9554 7702 -7611 6888
--5842 6066 -4262 5267 -2738 4563 -1352 3989 -6 3507 1050 3088 2205 2714
-3103 2386 3821 2109 4666 1888 5304 1733 5739 1635 6040 1592 6342 1580 6621 1595
-6742 1616 6662 1619 6485 1597 6168 1558 5864 1514 5507 1451 5091 1359 4617 1261
-4111 1188 3588 1185 3053 1283 2524 1481 1973 1727 1401 1937 791 2015 112 1892
--658 1575 -1549 1137 -2575 736 -3727 555 -4878 823 -5537 1781 -4623 3636
--807 6079 4286 6955 3737 6451 -1678 5494 -4697 4729 -5640 4259 -5785 4013
--5579 3999 -5463 4062 -5983 4113 -7174 4383 -7795 4572 -7785 4764 -7365 4982
--6783 5148 -6334 5192 -5726 5189 -5078 5162 -4618 5327 -4855 5641 -5327 5747
--5330 5543 -4609 5221 -3935 4915 -5337 4697 -6488 5253 -9611 5806 -12897 5876
--11176 6943 -10705 7227 -11856 7241 -13098 7970 -13496 8430 -13331 8288
--13041 8018 -14578 8642 -19481 11157 3357 6108 -8193 9652 -281 7229 1301 5922
--2716 3572 -4410 3050 -5624 3191 -7389 4500 -8997 4460 -9378 5036 -1347 11134
--5797 12691 -14543 13461 -24695 13408 -34337 12476 -41637 11141 -44885 10130
--43352 9814 -38356 9911 -33030 9925 -29317 9771 -25966 9675 -15983 8764
-18363 6918 99122 3697 37768 7431 10256 6349 23547 2491 69437 1040 63259 -326
-53084 -2007 52011 -4900 51205 -10301 41924 -15539 41542 -18366 45044 -15517
-23310 -7257 -17385 -6117 -57767 -15795 -21991 -20600 -27980 -10030 -65777 -1881
--48424 1725 9406 14230 -32229 3029 -23307 8837 -23182 11767 -23142 17157
--22859 21872 -22091 24815 -20649 25994 -18534 25932 -15880 25134 -12897 23834
--9788 22109 -6732 20123 -3912 18166 -1525 16478 251 15069 1282 13718 1559 12125
-1646 8462 102 4992 -2104 1754 -4121 -1043 -5390 -3242 -5812 -4780 -5702 -5681
--5612 -6005 -6055 -5830 -7261 -5247 -9048 -4358 -10866 -3274 -12000 -2122
--11820 -1006 -10048 15 -6836 931 -2767 1799 1305 2704 4525 3743 6239 4967
-6176 6357 4485 7814 1661 9178 -1616 10271 -4727 10947 -7251 11133 -9163 10846
--10829 10190 -12802 9323 -15502 8404 -18969 7572 -22875 6906 -26693 6461
--29951 6260 -32340 6291 -33795 6519 -34436 6888 -34543 7332 -34463 7790
--34511 8223 -34875 8613 -35625 8967 -36692 9320 -37885 9709 -39000 10184
--39887 10780 -40480 11524 -40814 12433 -40990 13511 -41143 14743 -41349 16118
--41603 17604 -41832 19176 -41872 20792 -41547 22415 -40713 24005 -39313 25512
--37396 26905 -35086 28138 -34477 29277 -32027 30097 -28595 30699 -24856 31194
--21313 31670 -18237 32151 -15661 32585 -13489 32844 -11588 32791 -9864 32363
--8225 31622 -6556 30719 -4709 29776 -2546 28804 12 27700 2884 26347 5960 24737
-9152 22970 12539 21211 16393 19570 21048 18043 26713 16508 33194 14764
-39850 12602 45730 9897 49968 6667 52073 3087 52249 -524 51303 -3743 50389 -6121
-50613 -7329 52715 -7325 56897 -6488 62935 -5652 70376 -5967 78368 -8511
-84402 -13407 82665 -18484 63144 -18067 13826 -5700 -27661 -11538 -51632 -23018
--83224 -33971 -52619 904 -31723 -1353 -71666 -12601 -63524 -2971 -42186 1263
--36867 15433 1465 19348 -10843 19747 -32958 14572 -11545 11776 -4561 6973
--21946 16617 -16369 843 -11092 3416 1283 751 -10832 1535 -15702 399 -17748 2709
--27411 12452 -18827 9742 -27552 10933 -20557 1483 -15103 2423 -19873 2147
--20586 3010 -31040 9024 -24263 4036 -14742 2929 -10215 3158 -8668 3853
--8796 4667 -9803 5423 -10468 6296 -10071 7171 -8637 7892 -6562 8386 -4314 8652
--2187 8752 -326 8765 1259 8764 2579 8808 3687 8926 4602 9130 5338 9418
-5912 9783 6314 10216 6564 10708 6682 11250 6681 11826 6582 12427 6390 13037
-6129 13639 5806 14223 5433 14771 5016 15280 4569 15738 4093 16141 3597 16484
-3079 16772 2539 17004 1989 17184 1433 17314 875 17396 330 17434 -216 17429
--770 17391 -1309 17324 -1855 17238 -2383 17135 -2889 17019 -3365 16887
--3831 16734 -4288 16562
-100: 11061350 -5581068 -3840 8324 -3800 8279 -3750 8223 -3690 8163 -3640 8101
--3560 8039 -3510 7977 -3440 7914 -3360 7847 -3290 7775 -3220 7704 -3140 7634
--3070 7568 -2990 7505 -2920 7438 -2840 7368 -2760 7300 -2690 7240 -2610 7189
--2560 7137 -2490 7081 -2420 7033 -2360 6987 -2310 6951 -2270 6923 -2220 6900
--2190 6881 -2160 6868 -2130 6862 -2120 6864 -2130 6878 -2140 6899 -2150 6929
--2190 6966 -2210 7012 -2270 7069 -2350 7131 -2420 7204 -2520 7290 -2630 7386
--2760 7491 -2890 7603 -3050 7715 -3210 7837 -3410 7971 -3610 8120 -3830 8272
--4070 8425 -4290 8573 -4550 8727 -4820 8892 -5110 9064 -5410 9237 -5710 9403
--6010 9564 -6310 9721 -6630 9880 -6960 10042 -7300 10200 -7630 10346 -7960 10483
--8270 10610 -8600 10736 -8930 10854 -9250 10964 -9570 11065 -9860 11155
--10170 11238 -10460 11310 -10740 11368 -11020 11419 -11290 11464 -11550 11504
--11790 11539 -12040 11560 -12270 11569 -12480 11572 -12710 11574 -12920 11581
--13130 11585 -13330 11579 -13530 11562 -13700 11547 -13890 11537 -14090 11533
--14290 11529 -14490 11526 -14660 11521 -14860 11520 -15060 11522 -15270 11535
--15480 11548 -15700 11572 -15930 11598 -16160 11630 -16400 11666 -16630 11703
--16890 11745 -17140 11799 -17420 11858 -17700 11925 -17970 11985 -18230 12044
--18480 12103 -18760 12170 -19040 12244 -19320 12318 -19580 12382 -19800 12434
--20010 12481 -20230 12534 -20440 12585 -20630 12629 -20800 12660 -20910 12678
--21000 12684 -21062 12686 -21117 12677 -21137 12658 -21112 12628 -21057 12584
--20959 12529 -20822 12462 -20646 12374 -20438 12279 -20198 12178 -19935 12070
--19641 11957 -19297 11825 -18902 11672 -18479 11516 -18050 11364 -17626 11217
--17184 11075 -16699 10916 -16166 10743 -15633 10574 -15114 10421 -14629 10290
--14159 10169 -13666 10045 -13144 9918 -12643 9805 -12182 9717 -11787 9660
--11436 9624 -11084 9605 -10740 9593 -10440 9604 -10205 9648 -10043 9722
--9943 9827 -9882 9957 -9866 10112 -9901 10297 -10014 10510 -10194 10747
--10437 11010 -10754 11310 -11142 11647 -11594 12009 -12102 12390 -12654 12774
--13266 13177 -13966 13621 -14749 14100 -15582 14596 -16451 15089 -17320 15571
--18225 16052 -19211 16564 -20282 17104 -21375 17643 -22457 18160 -23502 18643
--24535 19108 -25692 19609 -26806 20081 -27879 20529 -28930 20948 -29973 21342
--30996 21707 -31989 22043 -32926 22337 -33780 22598 -34570 22816 -35305 22996
--35977 23133 -36565 23229 -37074 23269 -37469 23255 -37762 23198 -37940 23082
--38021 22915 -37983 22705 -37837 22456 -37573 22131 -37174 21723 -36633 21270
--35942 20810 -35069 20328 -34197 19778 -33187 19127 -31993 18400 -30609 17632
--29106 16857 -27522 16097 -25837 15324 -24021 14503 -22133 13608 -20180 12636
--18092 11647 -15819 10669 -13513 9711 -11269 8799 -9120 7936 -7152 7070
--5395 6205 -3734 5412 -2225 4761 -803 4233 339 3773 1520 3363 2501 2999
-3273 2684 4181 2420 4980 2212 5523 2053 5940 1943 6360 1887 6745 1875 6939 1890
-6883 1910 6747 1903 6648 1858 6506 1805 6187 1713 5772 1601 5289 1468 4745 1335
-4169 1228 3591 1186 3033 1239 2514 1397 2027 1607 1564 1786 1107 1832 631 1675
-112 1319 -499 845 -1284 408 -2362 183 -3864 380 -5669 1293 -6585 3458 -3032 7476
-5019 8026 2318 6582 -5085 4910 -6852 4183 -6399 3846 -5981 3659 -5308 3820
--4688 3992 -5188 3851 -7352 4346 -8099 4459 -7971 4624 -7406 4905 -6609 5150
--6407 5177 -5774 5145 -5009 4919 -4254 5020 -5114 5555 -6440 5684 -6900 5306
--6059 4953 -4654 4665 -7949 3688 -9629 3575 -12842 4694 -12509 6135 -6646 8228
--6845 7563 -9705 6315 -11497 7406 -10610 7809 -7751 6791 -1516 4639 8315 1562
-14295 147 -40579 18392 -36059 17195 -5507 7761 237 5359 -2679 4699 -5288 3747
--7504 3138 -8064 5939 -8297 5847 -7361 6815 -4101 8592 -6894 10710 -13901 11896
--22878 12140 -32078 11667 -40013 11024 -45382 10758 -47457 10978 -46696 11285
--44378 11192 -40915 10600 -34298 9702 -19006 8417 12404 6849 54817 5451
-47197 6543 41336 6223 45215 5093 36491 4746 32240 3193 27460 1338 35955 -747
-42725 -6037 48930 -11614 64924 -15914 70194 -15556 52497 -11350 8439 -5161
--39502 -6753 -44043 -9444 -36748 -7449 -45470 -4198 -34055 -6011 -4241 2942
--18669 1845 -21288 6148 -23309 11332 -24559 17763 -24853 23224 -24070 26488
--22212 27597 -19417 27213 -16007 25913 -12331 23982 -8662 21578 -5138 18991
--1909 16619 780 14759 2702 13412 3679 12291 3704 10990 2661 6722 389 2850
--2195 -544 -4311 -3283 -5540 -5266 -5977 -6514 -6090 -7127 -6491 -7237
--7607 -6962 -9494 -6395 -11733 -5600 -13557 -4636 -14166 -3561 -13000 -2431
--9949 -1288 -5467 -141 -444 1040 4056 2317 7063 3767 7997 5421 6807 7220
-3938 9012 217 10576 -3394 11681 -6101 12161 -7519 11962 -7862 11178 -7990 10018
--9007 8753 -11699 7614 -16004 6743 -21158 6185 -26181 5930 -30289 5948
--33108 6186 -34615 6583 -35094 7061 -34981 7546 -34730 7982 -34698 8338
--35080 8616 -35874 8845 -36946 9079 -38061 9371 -39002 9775 -39646 10331
--39979 11060 -40119 11980 -40237 13089 -40485 14372 -40958 15816 -41603 17391
--42277 19068 -42742 20800 -42763 22544 -42163 24253 -40875 25872 -38954 27363
--36566 28681 -34946 29817 -31774 30661 -27972 31333 -24248 31940 -21046 32539
--18527 33111 -16605 33557 -15070 33729 -13713 33522 -12370 32931 -10938 32082
--9279 31151 -7297 30251 -4901 29363 -2111 28358 987 27118 4294 25626 7770 23981
-11505 22334 15722 20792 20656 19348 26379 17868 32626 16109 38748 13810
-43912 10830 47398 7250 48901 3320 48728 -595 47711 -4059 46970 -6601 47528 -7824
-50022 -7625 54513 -6403 60673 -5212 68560 -5688 78769 -9828 90278 -18845
-97207 -30948 86253 -36826 8124 -1766 -32314 -8729 -36484 -17697 -88316 -38513
--68216 -11977 -54678 -2913 -74356 -4944 -76122 216 -57172 6683 -10401 12707
-10885 14604 21055 13469 21138 11445 11181 11449 -25546 17604 -43956 25655
--43012 19212 -14987 2750 -8115 -874 -5898 124 -13446 2181 -11319 4006
--22677 8225 -25046 11810 -24636 10380 -18820 4681 -15444 3398 -17457 3360
--21711 4992 -27298 6375 -27226 3099 -14706 3679 -10397 3648 -8736 4039
--8363 4709 -8584 5479 -8688 6314 -8211 7121 -7091 7802 -5501 8297 -3715 8601
--1943 8753 -324 8817 1103 8852 2315 8914 3349 9034 4207 9229 4913 9505
-5473 9854 5875 10269 6147 10742 6290 11258 6329 11803 6259 12367 6113 12933
-5884 13492 5600 14030 5258 14539 4873 15010 4455 15438 4008 15816 3540 16142
-3042 16420 2531 16646 1998 16826 1467 16961 934 17052 406 17100 -126 17111
--658 17087 -1185 17037 -1718 16968 -2231 16883 -2722 16784 -3192 16668
--3646 16533 -4096 16377
-101: 11091180 -5571913 -4100 8411 -4070 8367 -4030 8313 -3970 8261 -3920 8202
--3870 8142 -3800 8084 -3760 8023 -3690 7960 -3620 7893 -3550 7825 -3490 7759
--3420 7699 -3360 7635 -3290 7572 -3220 7508 -3150 7441 -3090 7384 -3030 7333
--2970 7286 -2920 7234 -2860 7187 -2800 7144 -2760 7107 -2720 7080 -2690 7059
--2650 7041 -2630 7027 -2610 7020 -2600 7022 -2610 7034 -2630 7053 -2640 7084
--2670 7114 -2710 7158 -2760 7214 -2830 7273 -2900 7342 -3010 7420 -3110 7511
--3230 7610 -3360 7716 -3510 7825 -3670 7939 -3860 8068 -4050 8207 -4250 8354
--4490 8495 -4700 8638 -4950 8784 -5200 8939 -5470 9104 -5770 9268 -6050 9428
--6340 9579 -6630 9728 -6930 9881 -7250 10033 -7570 10186 -7880 10326 -8190 10455
--8490 10577 -8810 10698 -9110 10809 -9420 10917 -9710 11011 -10000 11100
--10290 11180 -10550 11247 -10820 11304 -11090 11356 -11330 11397 -11570 11437
--11810 11470 -12040 11493 -12240 11502 -12440 11507 -12650 11509 -12850 11518
--13040 11524 -13230 11519 -13410 11504 -13570 11492 -13750 11484 -13940 11482
--14120 11482 -14300 11479 -14480 11477 -14660 11480 -14850 11483 -15050 11497
--15260 11516 -15470 11540 -15690 11568 -15920 11602 -16150 11638 -16390 11679
--16630 11722 -16890 11775 -17160 11836 -17440 11901 -17700 11963 -17970 12021
--18220 12081 -18490 12148 -18780 12219 -19060 12293 -19310 12356 -19540 12409
--19750 12453 -19970 12505 -20180 12554 -20380 12596 -20540 12626 -20650 12640
--20750 12646 -20820 12646 -20867 12636 -20892 12614 -20870 12581 -20817 12535
--20723 12479 -20593 12409 -20421 12320 -20218 12222 -19978 12119 -19721 12010
--19435 11896 -19096 11760 -18704 11608 -18291 11450 -17866 11297 -17451 11147
--17018 11005 -16540 10845 -16018 10674 -15491 10501 -14981 10348 -14507 10216
--14050 10095 -13566 9970 -13057 9843 -12563 9730 -12120 9639 -11733 9583
--11393 9548 -11051 9526 -10722 9515 -10437 9523 -10213 9566 -10064 9642
--9975 9742 -9925 9871 -9916 10024 -9968 10207 -10093 10418 -10280 10650
--10536 10911 -10861 11209 -11253 11541 -11712 11901 -12229 12275 -12783 12655
--13401 13053 -14103 13490 -14885 13966 -15721 14455 -16582 14943 -17451 15417
--18349 15893 -19332 16401 -20393 16932 -21475 17464 -22546 17975 -23581 18454
--24605 18912 -25744 19407 -26849 19876 -27903 20316 -28936 20734 -29956 21125
--30972 21487 -31947 21820 -32866 22117 -33703 22373 -34480 22595 -35200 22778
--35861 22920 -36438 23019 -36932 23064 -37316 23064 -37607 23014 -37776 22907
--37856 22756 -37822 22569 -37676 22335 -37414 22009 -37015 21618 -36499 21207
--35776 20794 -34981 20336 -34104 19775 -33068 19122 -31882 18415 -30563 17696
--29103 16984 -27461 16277 -25667 15531 -23863 14712 -22075 13802 -20161 12837
--17986 11861 -15612 10889 -13225 9928 -10866 9003 -8652 8090 -6665 7166
--4798 6294 -3144 5553 -1644 4963 -421 4469 744 4024 1807 3626 2639 3279
-3576 2981 4554 2729 5224 2517 5752 2346 6332 2219 6835 2154 7094 2149 7080 2182
-6975 2220 6976 2218 7012 2163 6889 2066 6546 1924 6093 1768 5541 1598 4903 1421
-4231 1268 3566 1170 2960 1176 2449 1300 2015 1494 1670 1666 1400 1707 1189 1548
-1029 1200 912 747 772 354 442 188 -442 406 -2549 1161 -6241 2991 -6456 9346
-1336 8533 -14658 5958 -6427 3077 -6777 3608 -5418 3606 -5491 3369 -4886 3841
--3716 4305 -3960 3484 -7693 4421 -8196 4243 -7964 4339 -7503 4725 -6268 5091
--6560 5081 -5867 5122 -5066 4663 -3166 4506 -5120 5578 -7396 5638 -7905 4765
--7501 4783 -6632 5733 -11582 2257 -20793 26 -30541 -1632 7686 13122 4907 12148
--1615 8678 -8276 4873 -11265 7103 -9937 7791 -7565 6664 -2011 4752 5063 2378
-1023 3525 -25440 11989 -26458 11708 -9657 9310 -2429 6107 -4122 7090 -5560 6021
--7594 5468 -8663 5462 -6885 5343 -5914 6088 -5207 7250 -7594 8868 -13022 10069
--20417 10569 -28617 10542 -36595 10519 -43165 10900 -47061 11524 -47991 11881
--46301 11529 -41847 10460 -33090 8984 -17168 7383 7363 5962 33376 5191
-40228 5852 40055 6839 36174 7805 23062 8296 12526 7547 -798 5549 16741 5347
-27967 -728 40769 -6269 79480 -12791 88001 -13554 69653 -10790 31293 -6700
--10297 -6071 -44143 -4088 -47018 -4227 -30654 -8466 -23437 -8736 -9350 -6465
--14133 -2462 -18679 3901 -22650 11778 -25521 20246 -26673 26757 -26031 30062
--23747 30521 -20164 29155 -15865 26760 -11452 23789 -7261 20538 -3312 17364
-331 14696 3378 12826 5476 11730 6373 11008 6047 10113 3664 5386 563 1156
--2434 -2371 -4674 -5027 -5919 -6777 -6456 -7742 -6881 -8131 -7837 -8176
--9647 -8022 -12131 -7739 -14629 -7296 -16193 -6630 -15976 -5687 -13520 -4464
--8985 -3002 -3168 -1376 2716 359 7339 2196 9666 4167 9274 6284 6408 8471
-1942 10529 -2884 12169 -6758 13112 -8660 13185 -8215 12385 -5989 10912
--3570 9129 -3057 7468 -5903 6246 -11749 5562 -18975 5349 -25852 5484 -31202 5862
--34594 6389 -36163 6974 -36412 7539 -35987 8009 -35462 8349 -35249 8551
--35521 8648 -36206 8698 -37110 8781 -37978 8958 -38590 9288 -38871 9805
--38900 10529 -38877 11459 -39026 12596 -39542 13929 -40477 15440 -41714 17108
--42999 18897 -43998 20756 -44403 22635 -44001 24472 -42733 26213 -40706 27806
--38136 29211 -35032 30327 -31124 31214 -27198 31981 -23830 32709 -21301 33408
--19585 34013 -18443 34392 -17538 34411 -16594 34019 -15430 33279 -13913 32377
--11952 31501 -9509 30742 -6621 30036 -3421 29227 -16 28179 3521 26854
-7223 25332 11187 23747 15555 22216 20451 20775 25855 19314 31477 17558
-36733 15132 40949 11830 43604 7841 44523 3528 44058 -733 43006 -4559 42415 -7462
-43208 -8924 45955 -8680 50439 -7031 55701 -5203 61853 -5261 71805 -10431
-87012 -23868 101228 -46291 113554 -76240 -29595 -13337 -23596 -11598
--38842 -22086 -68332 -29917 -60681 -10313 -57014 142 -65885 2209 -72624 4375
--62418 10533 23930 14252 37774 10186 34415 11526 35015 12360 35628 12903
--37991 24125 -53749 35026 -50242 30143 -34430 12985 -27036 2197 -4352 2683
--31961 34086 -31057 -8139 -7684 -2206 -12955 5276 -16163 7555 -15160 6312
--14406 5974 -16127 6769 -19440 8170 -22142 4620 -23898 1717 -16669 2574
--12018 3323 -9617 4017 -8533 4761 -8056 5546 -7665 6348 -7017 7106 -6003 7751
--4678 8245 -3201 8577 -1706 8775 -296 8886 977 8960 2083 9046 3035 9173
-3837 9362 4509 9620 5039 9948 5438 10337 5719 10778 5879 11260 5940 11769
-5906 12293 5790 12819 5596 13337 5350 13836 5042 14310 4689 14750 4303 15150
-3886 15506 3437 15819 2973 16084 2483 16306 1976 16486 1472 16623 957 16721
-448 16779 -64 16800 -575 16790 -1090 16756 -1606 16701 -2107 16632 -2585 16547
--3044 16448 -3484 16328 -3925 16187
-102: 11121090 -5562779 -4360 8493 -4330 8451 -4290 8406 -4250 8353 -4200 8298
--4150 8241 -4110 8187 -4050 8129 -4000 8068 -3940 8009 -3880 7945 -3820 7877
--3770 7821 -3710 7764 -3650 7701 -3590 7642 -3530 7579 -3470 7522 -3430 7474
--3370 7430 -3330 7382 -3270 7336 -3230 7293 -3190 7259 -3160 7232 -3130 7212
--3100 7194 -3080 7180 -3070 7172 -3070 7176 -3070 7184 -3090 7203 -3110 7231
--3140 7259 -3170 7300 -3230 7351 -3300 7407 -3370 7475 -3470 7547 -3560 7634
--3680 7725 -3820 7826 -3950 7929 -4110 8039 -4280 8160 -4470 8291 -4670 8430
--4880 8566 -5100 8701 -5330 8840 -5570 8987 -5830 9144 -6110 9298 -6380 9451
--6650 9597 -6930 9736 -7220 9882 -7520 10028 -7830 10173 -8130 10309 -8410 10430
--8710 10545 -8990 10661 -9290 10770 -9580 10872 -9860 10963 -10130 11047
--10400 11124 -10650 11188 -10890 11244 -11150 11294 -11380 11333 -11600 11372
--11820 11407 -12030 11428 -12220 11438 -12400 11443 -12600 11448 -12780 11458
--12960 11462 -13140 11460 -13290 11448 -13450 11437 -13620 11431 -13780 11432
--13960 11435 -14130 11433 -14300 11436 -14470 11439 -14660 11444 -14840 11459
--15050 11482 -15250 11506 -15460 11537 -15690 11572 -15920 11612 -16150 11651
--16380 11697 -16650 11751 -16910 11812 -17190 11876 -17450 11941 -17720 11999
--17960 12056 -18240 12122 -18520 12195 -18800 12268 -19060 12330 -19290 12382
--19500 12426 -19710 12478 -19930 12523 -20130 12563 -20290 12592 -20410 12605
--20500 12609 -20570 12605 -20630 12596 -20653 12571 -20631 12535 -20585 12489
--20494 12431 -20366 12356 -20198 12268 -19998 12169 -19764 12063 -19512 11953
--19230 11837 -18898 11701 -18513 11548 -18104 11387 -17689 11232 -17279 11085
--16853 10938 -16386 10779 -15871 10606 -15354 10435 -14854 10280 -14390 10147
--13944 10026 -13466 9901 -12971 9773 -12492 9659 -12057 9569 -11682 9512
--11356 9477 -11024 9453 -10710 9441 -10432 9450 -10227 9490 -10086 9564
--10009 9664 -9969 9790 -9973 9942 -10039 10123 -10171 10330 -10369 10559
--10634 10817 -10967 11112 -11370 11440 -11832 11794 -12355 12164 -12913 12540
--13533 12934 -14237 13364 -15021 13833 -15856 14318 -16713 14799 -17579 15268
--18473 15737 -19450 16237 -20502 16763 -21573 17288 -22635 17793 -23663 18265
--24675 18718 -25799 19208 -26888 19671 -27927 20105 -28945 20520 -29952 20908
--30954 21267 -31912 21598 -32808 21893 -33643 22152 -34396 22375 -35107 22559
--35754 22705 -36331 22805 -36806 22861 -37184 22872 -37464 22828 -37636 22730
--37716 22599 -37682 22432 -37545 22202 -37282 21878 -36896 21519 -36365 21158
--35679 20777 -34924 20313 -34016 19741 -32981 19104 -31862 18442 -30594 17790
--29079 17143 -27323 16468 -25535 15720 -23868 14885 -22178 13966 -20200 13020
--17883 12062 -15408 11088 -12907 10112 -10445 9143 -8170 8168 -6054 7217
--4176 6380 -2548 5710 -1240 5172 -77 4703 1036 4271 1930 3883 2921 3551
-4040 3260 4884 3004 5487 2774 6225 2579 6898 2439 7218 2384 7236 2412 7161 2488
-7233 2564 7439 2581 7487 2525 7220 2350 6900 2149 6457 1948 5836 1735 5085 1509
-4275 1293 3479 1139 2797 1107 2260 1211 1876 1404 1643 1586 1547 1645 1600 1507
-1828 1198 2298 823 3101 568 4298 653 5867 1303 7469 2749 7948 5233 4149 8519
--15835 5790 -62668 -1042 -12037 3954 -1499 4981 -2611 3932 -4323 3291
--4852 4093 -3579 5331 -4291 3489 -6469 4083 -7227 3812 -7377 3905 -8018 4414
--6640 4684 -6088 4901 -5987 4706 -5858 5183 -1120 3636 -5715 5897 -7975 5417
--4361 2679 -2506 3856 -7037 7011 -10474 6429 -13225 5044 -13200 5729 -9083 6811
--2573 9854 -3521 8783 -9876 4311 -11226 5704 -11351 6927 -11088 6824 -8424 6420
--3085 4702 -10093 6499 -10528 7053 -12806 7733 -7727 7649 -4110 7174 -4148 6268
--5047 6287 -8030 5783 -7711 6095 -4435 4797 -4781 5222 -5494 6074 -7543 7272
--11498 8354 -17113 9010 -23841 9289 -31413 9748 -38742 10677 -43352 11548
--44491 11803 -42326 11144 -37006 9704 -27915 7919 -14039 6184 3841 4830
-20880 4178 28720 4976 28507 7372 22034 10404 11182 11658 -7 11496 -10556 10901
--6359 10859 9648 3765 17518 156 90172 -9106 97696 -9902 78139 -8529 43738 -6392
-6271 -4930 -24622 -3645 -35524 -13077 -32858 -8277 -25722 -7872 -10471 -14355
--12885 -6694 -16708 1873 -21969 12743 -26546 24495 -28528 32475 -27957 35345
--25164 34296 -20564 31162 -15140 27118 -9979 22938 -5458 18966 -1234 15460
-2825 12731 6338 11030 8667 10316 9430 10090 8623 9610 4772 4556 746 49
--2750 -3580 -5188 -6136 -6510 -7646 -7185 -8355 -7959 -8628 -9475 -8812
--11925 -9095 -14904 -9461 -17492 -9704 -18574 -9544 -17266 -8752 -13265 -7247
--7052 -5141 187 -2659 6822 -47 11248 2543 12377 5088 9984 7629 4774 10109
--1838 12299 -8079 13845 -12201 14420 -12875 13852 -9661 12205 -3478 9825
-3033 7292 6018 5268 2581 4205 -6081 4054 -16682 4506 -26288 5267 -33280 6141
--37294 7006 -38804 7765 -38650 8351 -37719 8722 -36746 8862 -36171 8814
--36143 8647 -36536 8468 -37102 8366 -37547 8429 -37693 8694 -37540 9191
--37250 9916 -37130 10865 -37463 12028 -38450 13402 -40085 14978 -42140 16741
--44211 18652 -45837 20654 -46617 22681 -46314 24662 -44919 26533 -42612 28232
--39712 29722 -34906 30821 -30407 31772 -26676 32643 -24012 33477 -22441 34229
--21681 34796 -21303 35032 -20865 34850 -20073 34262 -18749 33419 -16777 32548
--14118 31835 -10845 31325 -7191 30908 -3447 30383 221 29587 3845 28450
-7591 27006 11579 25358 15842 23667 20353 22079 25061 20605 29741 18960
-33863 16510 36992 12827 38820 8354 39231 3664 38554 -909 37444 -5173 36909 -8680
-37778 -10688 40801 -10646 45719 -8567 49825 -5989 51893 -5058 58748 -10417
-76695 -27665 89062 -58162 90260 -73268 8091 -43333 -15974 -34721 -36469 -36481
--52328 -31299 -36387 -788 -40371 7928 -38819 9157 -36238 4133 -10759 -278
--13565 28633 29895 8539 40462 8091 39427 18069 3521 13765 -26900 28681
--44066 48739 -43909 43144 -39950 21012 -48465 1723 -3449 -44 -38225 24890
--35742 5098 -17022 1962 -12565 4912 -12428 7107 -12359 7603 -12811 7884
--14490 8310 -16943 8165 -18946 5391 -19742 3138 -16281 3047 -12818 3571
--10404 4238 -8919 4959 -7965 5705 -7195 6449 -6359 7148 -5345 7753 -4157 8233
--2867 8579 -1556 8812 -312 8964 826 9076 1839 9186 2720 9324 3474 9509
-4101 9753 4613 10057 5004 10416 5285 10822 5459 11268 5534 11736 5526 12221
-5443 12708 5282 13186 5065 13650 4790 14091 4468 14501 4115 14878 3724 15215
-3307 15512 2869 15768 2408 15983 1926 16162 1441 16300 952 16404 459 16468
--30 16500 -528 16502 -1022 16479 -1519 16438 -2008 16383 -2470 16312 -2917 16227
--3351 16121 -3775 15995
-103: 11151060 -5553670 -4610 8573 -4580 8534 -4550 8494 -4500 8442 -4480 8389
--4430 8337 -4390 8286 -4340 8233 -4300 8176 -4240 8117 -4200 8057 -4150 7994
--4090 7941 -4060 7887 -3990 7829 -3950 7770 -3900 7712 -3840 7657 -3800 7611
--3760 7568 -3720 7523 -3670 7477 -3640 7440 -3610 7404 -3570 7379 -3560 7361
--3530 7342 -3520 7328 -3500 7318 -3510 7321 -3510 7331 -3540 7347 -3560 7370
--3590 7399 -3620 7439 -3670 7484 -3750 7537 -3820 7600 -3910 7672 -4000 7750
--4120 7838 -4240 7932 -4380 8029 -4520 8134 -4700 8248 -4860 8374 -5070 8504
--5260 8634 -5480 8762 -5680 8895 -5930 9036 -6170 9181 -6440 9331 -6690 9474
--6960 9613 -7220 9745 -7500 9885 -7780 10025 -8080 10163 -8360 10290 -8640 10410
--8900 10518 -9180 10629 -9460 10729 -9740 10830 -10000 10917 -10260 10999
--10500 11070 -10740 11133 -10980 11187 -11200 11235 -11410 11273 -11640 11311
--11830 11346 -12030 11365 -12200 11376 -12370 11382 -12540 11388 -12720 11397
--12880 11404 -13040 11403 -13190 11394 -13330 11384 -13490 11379 -13650 11382
--13810 11386 -13960 11390 -14130 11392 -14290 11397 -14470 11406 -14640 11423
--14850 11445 -15040 11472 -15250 11506 -15470 11542 -15690 11581 -15920 11624
--16150 11671 -16410 11726 -16680 11787 -16950 11852 -17210 11917 -17470 11975
--17720 12030 -17990 12098 -18280 12172 -18560 12242 -18810 12305 -19040 12354
--19250 12399 -19470 12446 -19690 12495 -19880 12531 -20040 12556 -20170 12571
--20260 12574 -20340 12567 -20390 12553 -20420 12530 -20399 12491 -20358 12444
--20270 12385 -20143 12307 -19980 12218 -19783 12117 -19553 12010 -19306 11899
--19030 11783 -18702 11643 -18324 11490 -17923 11329 -17514 11171 -17111 11025
--16693 10878 -16234 10717 -15731 10544 -15218 10372 -14728 10217 -14278 10083
--13839 9963 -13375 9836 -12888 9708 -12418 9593 -11999 9506 -11637 9447
--11320 9410 -11002 9386 -10699 9373 -10436 9381 -10239 9421 -10113 9492
--10044 9591 -10019 9714 -10034 9866 -10109 10042 -10252 10247 -10461 10474
--10731 10727 -11071 11019 -11486 11343 -11953 11692 -12480 12057 -13044 12430
--13663 12817 -14370 13242 -15153 13705 -15988 14182 -16843 14658 -17706 15121
--18597 15584 -19564 16077 -20608 16596 -21672 17114 -22726 17612 -23740 18078
--24742 18527 -25856 19009 -26924 19465 -27960 19899 -28955 20306 -29952 20691
--30932 21048 -31885 21374 -32760 21669 -33580 21931 -34328 22152 -35022 22341
--35661 22486 -36228 22592 -36699 22658 -37065 22675 -37341 22637 -37517 22550
--37594 22442 -37564 22287 -37434 22053 -37170 21747 -36798 21429 -36255 21111
--35629 20738 -34870 20255 -33953 19691 -32974 19093 -31913 18499 -30612 17917
--28985 17314 -27211 16632 -25581 15860 -24077 15013 -22356 14111 -20226 13193
--17774 12251 -15203 11267 -12586 10253 -10040 9230 -7633 8206 -5446 7264
--3592 6492 -2115 5890 -900 5394 239 4938 1222 4512 2249 4126 3460 3787
-4510 3483 5204 3202 6014 2941 6874 2727 7321 2602 7353 2591 7295 2686 7413 2834
-7739 2959 7968 3005 7785 2947 7485 2654 7311 2386 6903 2134 6205 1872 5286 1585
-4272 1309 3298 1106 2485 1043 1899 1142 1547 1344 1398 1544 1425 1625 1648 1517
-2133 1250 3011 956 4507 837 6965 1151 10881 2170 16775 4133 23944 7004
-25366 9443 -7284 5981 -122774 -8514 -25849 2228 -2084 5688 -3445 4057
--4604 2951 -5064 4259 -4680 4714 -4905 3835 -5297 3871 -6271 4688 -5918 3766
--7874 4469 -7969 3813 -5615 4840 -6104 3991 -8579 6900 41 1854 -11264 6675
--11446 4860 11913 -4715 1405 5656 -7384 10281 -8977 11350 -9571 8226 -10216 5283
--12652 6277 -9508 7294 -5642 8558 -8655 6132 -9049 5839 -10938 6478 -11616 6642
--10177 6673 -8224 6080 -10199 6544 -13001 4680 -6530 7084 -6205 5983 -4907 6295
--4554 6096 -5019 5952 -5965 5880 -4805 6007 -2997 5366 -4979 5120 -5929 5293
--7087 6019 -9447 6949 -13117 7727 -17814 8062 -24654 8802 -33147 10276
--37889 11245 -38339 11286 -35184 10320 -29379 8678 -21269 6884 -10446 5269
-1557 4059 12404 3043 17896 3624 15838 7449 8097 13145 2135 14392 -4718 13691
--11121 12632 -11032 12003 -2302 9185 14232 3802 73474 579 87632 -2763
-73692 -4933 45206 -6381 13598 -8118 -12043 -11283 -25289 -17264 -37849 -3452
--33901 -3131 -8629 -23889 -10277 -9480 -12794 -401 -20639 13691 -27858 30861
--30428 40401 -29762 41726 -26402 37949 -20417 32359 -13430 26372 -7540 21230
--3181 17064 1009 13697 5500 11166 9706 9696 12364 9389 12901 9664 11429 9532
-6072 4304 1017 -381 -3119 -4093 -5858 -6551 -7277 -7804 -8057 -8267 -9114 -8530
--11119 -9105 -14151 -10222 -17567 -11724 -20173 -13095 -20645 -13695
--18062 -13017 -12293 -10925 -4169 -7670 4662 -3789 12057 110 16043 3624
-15400 6695 10219 9500 1827 12096 -7624 14242 -15714 15510 -20195 15504
--19341 14048 -12413 11297 -472 7761 12577 4293 19745 1936 14633 1427 811 2309
--15089 3829 -28408 5455 -37258 6922 -41717 8123 -42838 8990 -41932 9499
--40202 9643 -38523 9461 -37363 9049 -36837 8532 -36764 8066 -36820 7771
--36719 7731 -36310 7967 -35666 8476 -35083 9228 -34948 10199 -35639 11379
--37334 12778 -39938 14410 -43074 16269 -46128 18315 -48454 20482 -49542 22679
--49167 24823 -47412 26828 -44587 28639 -41153 30212 -34782 31312 -29985 32338
--26792 33311 -25148 34217 -24726 34964 -24944 35417 -25159 35451 -24867 35029
--23822 34261 -21936 33374 -19115 32633 -15340 32199 -10841 32057 -6137 32024
--1828 31848 1874 31339 5237 30386 8703 28936 12485 27026 16405 24880 20219 22879
-23924 21349 27514 20120 30329 17972 32326 13748 33459 8659 33528 3690
-32699 -972 31400 -5634 30714 -9986 31179 -12858 34372 -13328 41406 -10603
-46203 -7557 42832 -5849 44982 -11539 72618 -34598 80907 -58519 72873 -69859
-29388 -60061 296 -53535 -22526 -50813 -35704 -40100 2729 14521 -24394 16492
--15245 19311 -13992 16542 -6646 12989 2773 4074 24777 -8672 15790 3528
-19961 13785 -13371 21421 -17054 38216 -35635 68981 -28583 56612 -12966 21580
--12666 -24477 -68161 12393 -56373 19097 -39352 10956 -22364 7396 -14000 7756
--11175 8774 -10685 9242 -11394 9363 -12958 9222 -14872 8421 -16383 6466
--16790 4770 -15104 4220 -12818 4348 -10799 4786 -9250 5360 -8068 5995
--7065 6645 -6082 7263 -5036 7812 -3904 8265 -2723 8611 -1543 8864 -416 9045
-626 9188 1565 9323 2385 9473 3092 9658 3691 9890 4183 10172 4563 10501
-4845 10875 5029 11281 5122 11712 5133 12157 5072 12605 4945 13046 4756 13476
-4510 13886 4221 14270 3897 14623 3536 14941 3147 15224 2735 15469 2298 15679
-1847 15853 1382 15993 916 16099 442 16170 -27 16210 -504 16221 -977 16209
--1459 16180 -1931 16137 -2383 16079 -2818 16006 -3236 15913 -3653 15801
-104: 11181090 -5544583 -4840 8650 -4820 8616 -4800 8575 -4760 8529 -4730 8478
--4700 8430 -4660 8383 -4630 8331 -4580 8280 -4550 8223 -4500 8164 -4460 8107
--4420 8057 -4370 8005 -4340 7950 -4280 7895 -4250 7839 -4200 7790 -4160 7743
--4130 7701 -4090 7657 -4060 7616 -4040 7581 -4000 7544 -3970 7521 -3970 7502
--3940 7484 -3930 7469 -3930 7460 -3930 7463 -3940 7471 -3960 7485 -3990 7507
--4020 7534 -4050 7570 -4100 7613 -4170 7663 -4250 7720 -4330 7791 -4420 7862
--4540 7946 -4650 8035 -4770 8126 -4930 8225 -5080 8333 -5250 8453 -5450 8578
--5630 8700 -5830 8822 -6040 8947 -6260 9080 -6500 9220 -6750 9363 -7000 9500
--7250 9629 -7500 9755 -7760 9889 -8040 10024 -8310 10154 -8590 10277 -8840 10389
--9100 10493 -9360 10598 -9630 10696 -9890 10788 -10140 10874 -10370 10952
--10610 11021 -10830 11081 -11040 11134 -11260 11178 -11460 11214 -11660 11256
--11840 11286 -12030 11305 -12180 11316 -12340 11323 -12500 11329 -12650 11338
--12820 11349 -12950 11346 -13090 11338 -13220 11334 -13360 11330 -13510 11333
--13670 11339 -13820 11345 -13960 11349 -14120 11356 -14290 11367 -14460 11387
--14650 11409 -14840 11439 -15050 11473 -15250 11509 -15480 11552 -15700 11595
--15930 11645 -16190 11698 -16440 11760 -16720 11829 -16980 11893 -17240 11949
--17480 12006 -17760 12075 -18040 12146 -18320 12214 -18570 12278 -18810 12327
--19010 12371 -19230 12417 -19450 12463 -19640 12501 -19820 12522 -19930 12537
--20030 12538 -20100 12531 -20160 12513 -20190 12489 -20175 12449 -20133 12401
--20047 12338 -19925 12263 -19764 12170 -19572 12067 -19348 11958 -19104 11848
--18834 11730 -18512 11590 -18141 11435 -17743 11274 -17343 11115 -16946 10969
--16537 10821 -16085 10660 -15591 10485 -15090 10315 -14610 10158 -14165 10025
--13736 9903 -13284 9778 -12811 9648 -12353 9535 -11944 9445 -11593 9386
--11287 9349 -10982 9325 -10693 9310 -10445 9317 -10255 9357 -10140 9426
--10082 9523 -10068 9644 -10099 9793 -10182 9968 -10337 10169 -10553 10393
--10829 10643 -11179 10931 -11597 11249 -12075 11594 -12604 11956 -13173 12321
--13793 12704 -14501 13125 -15283 13580 -16116 14049 -16972 14519 -17831 14977
--18715 15434 -19677 15919 -20713 16432 -21770 16941 -22814 17433 -23815 17893
--24809 18336 -25906 18812 -26964 19263 -27986 19690 -28969 20095 -29954 20472
--30921 20829 -31855 21151 -32719 21445 -33522 21707 -34261 21930 -34944 22119
--35577 22267 -36135 22376 -36599 22449 -36962 22473 -37228 22439 -37411 22372
--37491 22279 -37466 22127 -37332 21894 -37086 21619 -36702 21344 -36197 21051
--35594 20663 -34827 20177 -33943 19642 -33029 19102 -31970 18589 -30580 18061
--28905 17449 -27271 16738 -25849 15947 -24380 15109 -22510 14251 -20209 13372
--17676 12438 -15034 11430 -12331 10366 -9648 9281 -7102 8238 -4877 7338
--3112 6638 -1705 6089 -523 5619 574 5172 1632 4738 2875 4326 4083 3943
-4911 3595 5685 3277 6671 2999 7325 2804 7420 2735 7369 2811 7515 3007 7915 3238
-8306 3417 8291 3483 7697 3401 7825 2972 7888 2630 7512 2323 6671 2002 5503 1656
-4192 1323 2954 1080 1971 1002 1329 1096 989 1309 883 1521 964 1615 1212 1528
-1692 1291 2537 1033 3937 949 6206 1273 9874 2231 15887 4014 25794 6717
-39996 9975 37084 10433 -195715 -17691 -16547 3077 -1988 5476 -4054 5709
--5309 3457 -5938 3725 -5981 3982 -5734 3983 -5085 4440 -4494 6512 -4625 2908
--7363 5267 -7862 3756 -5448 3053 -6459 3024 -12197 9040 -6525 3920 -30298 5370
--37023 6480 41359 -9234 18299 5119 308 9684 -4624 14922 -6827 10489 -9793 5184
--11079 5485 -8934 6372 -8402 7482 -8830 6646 -6072 5821 -10047 6162 -11307 6383
--11018 6428 -10362 6137 -10820 5869 -11201 4857 -7640 5560 -6945 5118
--5169 5781 -5027 5895 -4982 5568 -4687 5820 -2611 6116 -1208 6059 -6038 5409
--6431 4856 -6372 5180 -7165 5986 -9087 7008 -10975 6979 -16541 7691 -27791 9937
--32029 10817 -31186 10565 -26675 9339 -20663 7665 -14507 6191 -6719 5008
--296 4441 5753 2480 9274 1830 4932 7054 -5098 16395 -4507 16188 -6776 14306
--10521 12314 -10776 11791 -6857 12724 18710 12503 60076 9500 73606 4318
-62229 -1162 37632 -5902 10225 -9992 -12989 -13721 -29165 -15647 -40984 -8491
--35416 -8314 -26031 -21258 10265 -14503 -2730 -4428 -18549 13525 -30068 40430
--31937 50158 -31093 47764 -27511 39812 -19552 31759 -10151 23956 -3602 18676
--490 15244 3156 12605 8163 10427 13534 9006 16651 9005 16762 9765 14359 9922
-7556 4748 1352 -49 -3628 -3912 -6754 -6296 -8196 -7242 -8900 -7398 -10050 -7696
--12418 -8914 -16010 -11352 -19934 -14630 -22667 -17739 -22584 -19434
--18660 -18803 -10907 -15650 -541 -10514 10254 -4469 18694 1249 22186 5793
-19219 9144 10302 11886 -2307 14350 -15437 16294 -25926 17128 -31048 16347
--28619 13774 -17305 9660 2411 4675 25819 -36 40779 -2819 31147 -2115 7966 534
--15748 3569 -33487 6239 -43917 8315 -48202 9774 -48310 10637 -46158 10928
--43247 10702 -40576 10057 -38614 9155 -37426 8198 -36745 7401 -36207 6920
--35489 6822 -34472 7090 -33317 7664 -32450 8475 -32390 9471 -33595 10646
--36253 12045 -40136 13710 -44658 15663 -48925 17864 -52033 20226 -53325 22627
--52609 24953 -50147 27103 -46488 29021 -42264 30671 -34814 31804 -30108 32910
--27797 33968 -27414 34907 -28235 35592 -29330 35875 -29824 35652 -29190 34968
--27384 34030 -24554 33163 -20570 32651 -15320 32613 -9166 32949 -3100 33374
-1672 33571 4878 33348 7307 32577 10025 31051 13442 28612 16950 25560 19811 22641
-22286 20878 25071 20737 26461 19793 27352 14495 28162 8522 28140 3524
-27228 -664 25360 -5467 24325 -10851 23221 -14729 24956 -16090 36587 -11095
-46357 -7426 39941 -7381 41943 -15755 63503 -36074 72932 -56910 66867 -67663
-43842 -65745 23537 -59555 11506 -49807 14654 -29697 36937 8631 -24039 20120
--27984 16410 -14778 20410 2420 12011 8535 -12506 34841 -45861 -8862 -2570
-8902 37128 1676 37803 -62468 69636 -52036 73258 -32646 62412 -19570 34815
--69699 -42893 -26256 -2492 -27018 6758 -26084 9694 -18222 10418 -12148 10969
--9636 11227 -9464 11054 -10471 10611 -11989 9942 -13542 8894 -14668 7411
--14933 6107 -14030 5439 -12518 5308 -10913 5514 -9472 5906 -8232 6395
--7119 6924 -6051 7447 -4977 7927 -3876 8338 -2753 8670 -1657 8929 -607 9130
-362 9295 1244 9449 2019 9612 2691 9798 3266 10022 3739 10284 4118 10589
-4398 10930 4591 11301 4698 11695 4730 12102 4690 12512 4589 12920 4428 13317
-4211 13697 3950 14055 3653 14385 3322 14686 2959 14953 2573 15188 2166 15391
-1739 15562 1298 15701 850 15807 400 15884 -48 15929 -504 15949 -960 15946
--1423 15928 -1883 15895 -2318 15848 -2741 15786 -3144 15706 -3548 15606
-105: 11211200 -5535518 -5070 8726 -5060 8693 -5030 8655 -5010 8611 -4980 8566
--4960 8520 -4930 8474 -4900 8427 -4860 8377 -4830 8323 -4790 8271 -4760 8216
--4720 8168 -4690 8119 -4660 8067 -4610 8014 -4580 7961 -4550 7916 -4510 7872
--4490 7829 -4450 7789 -4430 7750 -4400 7714 -4370 7679 -4370 7657 -4350 7638
--4340 7619 -4330 7607 -4330 7598 -4340 7598 -4340 7604 -4370 7619 -4390 7640
--4430 7663 -4470 7695 -4510 7736 -4570 7784 -4650 7838 -4740 7902 -4830 7971
--4920 8049 -5040 8135 -5170 8222 -5300 8312 -5460 8416 -5620 8530 -5800 8648
--5980 8764 -6180 8881 -6370 8998 -6580 9124 -6820 9257 -7050 9394 -7300 9525
--7520 9647 -7760 9768 -8020 9894 -8280 10025 -8540 10146 -8800 10263 -9050 10371
--9290 10472 -9530 10568 -9780 10664 -10040 10753 -10270 10834 -10490 10908
--10700 10973 -10920 11032 -11120 11082 -11310 11125 -11510 11161 -11680 11198
--11850 11228 -12020 11249 -12170 11259 -12310 11266 -12460 11273 -12590 11282
--12750 11293 -12870 11291 -13000 11287 -13110 11282 -13240 11282 -13390 11285
--13530 11292 -13670 11300 -13810 11307 -13960 11314 -14110 11328 -14290 11351
--14470 11374 -14650 11405 -14850 11439 -15060 11478 -15280 11523 -15490 11566
--15720 11617 -15960 11670 -16230 11735 -16490 11802 -16760 11867 -17020 11923
--17260 11983 -17530 12049 -17810 12120 -18090 12188 -18340 12250 -18570 12299
--18790 12342 -19000 12389 -19210 12432 -19420 12468 -19580 12491 -19710 12503
--19800 12502 -19870 12493 -19940 12476 -19960 12451 -19960 12409 -19913 12358
--19831 12294 -19711 12219 -19555 12124 -19364 12021 -19146 11910 -18905 11797
--18641 11680 -18328 11541 -17958 11383 -17570 11222 -17173 11064 -16786 10916
--16383 10767 -15940 10607 -15454 10431 -14968 10261 -14491 10104 -14057 9971
--13638 9849 -13196 9724 -12737 9595 -12290 9480 -11894 9391 -11553 9331
--11257 9294 -10970 9267 -10687 9254 -10451 9259 -10277 9298 -10170 9365
--10124 9459 -10124 9580 -10160 9726 -10259 9897 -10421 10097 -10643 10318
--10931 10563 -11287 10845 -11711 11162 -12194 11502 -12726 11856 -13302 12216
--13923 12595 -14628 13010 -15413 13458 -16244 13921 -17099 14385 -17952 14833
--18829 15286 -19787 15765 -20816 16268 -21865 16771 -22899 17255 -23890 17709
--24872 18148 -25959 18616 -27001 19062 -28011 19483 -28986 19881 -29959 20254
--30909 20607 -31824 20931 -32678 21223 -33472 21479 -34197 21704 -34876 21894
--35496 22044 -36055 22157 -36502 22237 -36862 22260 -37131 22239 -37315 22192
--37395 22104 -37372 21951 -37252 21733 -37014 21492 -36631 21256 -36164 20962
--35564 20560 -34812 20089 -33990 19601 -33112 19142 -31998 18695 -30529 18173
--28956 17519 -27553 16776 -26250 15991 -24650 15199 -22576 14405 -20181 13575
--17650 12643 -14981 11595 -12149 10465 -9275 9321 -6576 8279 -4341 7437
--2559 6800 -1206 6293 45 5840 1129 5395 2359 4928 3634 4444 4588 3967 5267 3554
-6193 3222 7057 2977 7335 2857 7318 2898 7515 3093 8004 3397 8528 3704 8700 3920
-8251 3976 7323 3849 8368 3294 8728 2880 8318 2511 7234 2130 5696 1727 3976 1347
-2393 1075 1199 983 501 1074 199 1279 143 1489 196 1589 322 1517 559 1293
-936 1026 1502 876 2121 992 2419 1442 1268 2093 -4115 2461 -18474 1667 -34484 326
--22502 4185 2702 4984 -6322 5536 -5487 5667 -6569 4142 -6969 3514 -7429 3277
--7684 3305 -5620 4460 -6232 9222 -4361 4205 -4231 3980 -6235 4937 -3389 2960
--3980 3772 -16398 6921 -13835 5161 -8996 -4046 -1423 -6648 -1058 11376
-11418 6224 -1875 4971 -2918 14180 -5498 11679 -8284 7608 -9189 6678 -7633 7065
--6551 6068 -6995 5971 -5360 5901 -8584 6356 -10264 6168 -10866 6073 -10823 5862
--10678 5530 -10052 5000 -8148 4986 -7379 4720 -6789 4814 -6826 4788 -4983 5756
--5085 5831 -2896 6072 -2222 6319 -5387 6170 -6135 4965 -5609 5087 -4984 5494
--6252 7111 -4871 6242 -7949 6530 -23656 9795 -25961 10235 -24032 9804
--18051 8459 -11984 6885 -9112 6063 -3003 5386 -2837 6948 -1161 3625 1942 698
--5754 9209 -12253 16668 -10315 16088 -12612 13984 -23375 12614 -13494 13401
-3088 15706 32465 18717 62545 17582 66443 10719 49727 2138 24542 -5200
--369 -10735 -20355 -15023 -34045 -18433 -41271 -21184 -36681 -29107 -21536 -32354
-13767 13348 -5506 187 -21086 12538 -34307 55444 -31086 59102 -31182 50136
--28884 37251 -17913 28720 -4543 19624 2580 15686 2294 14175 4824 12741
-10450 10847 17971 8877 21516 9041 20760 10388 17116 10913 9069 6085 1620 1135
--4491 -3139 -8052 -5536 -9253 -6018 -9488 -5642 -10390 -5884 -12962 -7950
--17191 -12270 -21928 -18184 -25194 -23910 -24862 -27193 -19660 -26504
--9729 -21622 3365 -13573 16840 -4278 27093 3977 30431 9534 24644 12548
-10814 14657 -7301 16743 -25028 18426 -38426 18766 -44512 17063 -40870 13166
--25298 7455 3602 715 42810 -5755 74206 -9507 52260 -6304 12652 -874 -21231 4051
--42965 7773 -53699 10340 -56604 11914 -54829 12616 -50855 12540 -46403 11795
--42511 10544 -39607 9025 -37662 7537 -36346 6373 -35216 5744 -33889 5671
--32256 6058 -30560 6772 -29388 7693 -29424 8712 -31274 9838 -35139 11174
--40665 12834 -46973 14880 -52777 17269 -56779 19876 -58109 22528 -56660 25061
--53018 27362 -48100 29378 -42800 31093 -34986 32286 -30813 33473 -29660 34595
--30708 35534 -32819 36124 -34637 36200 -34976 35687 -33345 34703 -30167 33587
--26132 32784 -20946 32589 -14038 33057 -5737 33968 2173 34900 7170 35416
-8870 35416 9200 34885 10475 33326 13653 30078 17066 25492 18757 20728
-19631 17985 23122 20141 22737 22898 22499 14804 23905 7560 24171 2989
-23228 274 19724 -4198 18885 -10657 14682 -15007 9600 -18670 26517 -6201
-35972 6592 38106 -5503 50079 -25368 64832 -43459 71464 -58570 67546 -66531
-54791 -65779 42030 -58586 34487 -45221 33934 -23910 32045 3392 -4961 18103
--17803 21464 -12393 22956 98 13136 11066 -9843 24395 -31493 -18967 7184
--12322 33043 -23947 45299 -71896 67963 -49095 48123 -38384 37151 -37946 6770
-30035 -28730 -35263 968 -33885 6511 -23109 11040 -13345 13723 -8457 14367
--7626 13741 -8780 12613 -10475 11438 -12065 10323 -13308 9185 -14024 8006
--14085 7012 -13425 6407 -12286 6184 -10961 6244 -9650 6489 -8424 6846
--7273 7256 -6163 7681 -5079 8084 -3999 8448 -2919 8753 -1876 9007 -875 9215
-42 9395 874 9563 1619 9736 2265 9924 2824 10141 3287 10389 3659 10671 3948 10984
-4146 11324 4266 11683 4317 12055 4294 12431 4216 12806 4084 13172 3894 13523
-3660 13856 3392 14165 3081 14447 2747 14700 2389 14924 2008 15120 1606 15285
-1187 15423 762 15530 335 15608 -90 15659 -528 15686 -967 15691 -1416 15681
--1857 15658 -2274 15620 -2682 15569 -3074 15500 -3465 15411
-106: 11241380 -5526472 -5300 8799 -5290 8767 -5260 8732 -5240 8691 -5230 8649
--5200 8604 -5180 8565 -5160 8518 -5140 8469 -5100 8422 -5070 8370 -5040 8322
--5020 8273 -4990 8229 -4960 8181 -4930 8129 -4900 8079 -4870 8036 -4850 7992
--4820 7954 -4810 7916 -4770 7877 -4760 7842 -4740 7811 -4730 7787 -4730 7768
--4710 7751 -4710 7738 -4720 7730 -4710 7728 -4730 7732 -4760 7748 -4780 7765
--4820 7788 -4860 7818 -4900 7853 -4970 7899 -5030 7949 -5120 8011 -5210 8078
--5300 8150 -5420 8230 -5530 8311 -5670 8400 -5810 8498 -5980 8604 -6130 8715
--6320 8826 -6500 8935 -6690 9047 -6900 9168 -7110 9298 -7350 9423 -7560 9549
--7800 9665 -8010 9780 -8260 9900 -8510 10026 -8760 10142 -9010 10252 -9240 10354
--9460 10451 -9700 10543 -9940 10634 -10170 10720 -10400 10796 -10600 10867
--10800 10929 -11000 10984 -11180 11032 -11380 11074 -11540 11109 -11710 11145
--11870 11174 -12020 11195 -12150 11205 -12290 11212 -12410 11218 -12540 11230
--12680 11238 -12800 11238 -12900 11236 -13020 11232 -13130 11232 -13270 11238
--13410 11249 -13530 11255 -13670 11264 -13800 11275 -13960 11290 -14110 11313
--14290 11339 -14480 11371 -14660 11406 -14870 11448 -15080 11491 -15300 11535
--15510 11589 -15760 11645 -16020 11709 -16280 11775 -16550 11840 -16800 11898
--17040 11956 -17310 12023 -17590 12092 -17870 12162 -18120 12223 -18350 12271
--18570 12314 -18770 12359 -18990 12403 -19200 12438 -19350 12457 -19480 12469
--19580 12466 -19660 12457 -19720 12440 -19740 12412 -19740 12369 -19700 12318
--19621 12253 -19501 12175 -19348 12080 -19162 11977 -18948 11864 -18713 11751
--18453 11633 -18142 11494 -17781 11335 -17397 11174 -17009 11014 -16628 10866
--16236 10719 -15798 10556 -15323 10383 -14842 10211 -14377 10056 -13954 9921
--13546 9801 -13114 9674 -12663 9547 -12232 9429 -11844 9343 -11520 9281
--11233 9242 -10956 9217 -10687 9201 -10460 9208 -10298 9243 -10206 9310
--10168 9401 -10177 9522 -10227 9663 -10336 9832 -10507 10029 -10738 10246
--11030 10489 -11392 10767 -11826 11077 -12313 11413 -12850 11760 -13429 12117
--14048 12489 -14756 12899 -15544 13340 -16368 13796 -17220 14252 -18071 14694
--18944 15140 -19896 15612 -20917 16108 -21955 16602 -22979 17079 -23962 17527
--24933 17959 -26007 18422 -27043 18859 -28041 19276 -28997 19668 -29960 20038
--30898 20385 -31798 20707 -32643 20996 -33427 21252 -34136 21476 -34805 21665
--35421 21816 -35967 21936 -36416 22015 -36772 22041 -37042 22037 -37217 22004
--37308 21915 -37292 21765 -37188 21564 -36943 21365 -36588 21148 -36138 20842
--35545 20439 -34828 19993 -34082 19576 -33188 19204 -31996 18781 -30556 18215
--29196 17514 -27990 16763 -26615 16019 -24796 15310 -22583 14607 -20237 13828
--17792 12886 -15067 11772 -12035 10550 -8858 9352 -6001 8320 -3619 7532
--1872 6947 -383 6479 799 6045 2000 5589 3251 5062 4250 4447 4862 3819 5496 3359
-6344 3075 6821 2948 6953 2979 7263 3158 7958 3474 8722 3858 9100 4206 8820 4417
-7990 4432 6983 4243 9139 3609 9784 3136 9257 2709 7823 2265 5808 1814 3566 1395
-1519 1095 106 984 -581 1055 -760 1231 -731 1423 -725 1530 -820 1480 -963 1280
--1148 1002 -1483 775 -2276 702 -4128 799 -8045 906 -14976 722 -22146 195
--6822 1622 -7093 9022 -3593 4943 -6474 5545 -5825 5175 -6076 4003 -6640 3243
--7354 2901 -7561 3073 -6481 4119 -5865 6113 -4083 5951 -4191 5739 -7456 5859
--3513 3338 -3198 3480 -12882 5678 -11341 4250 -6571 -876 -2730 -1931 -4620 8214
-3578 5916 -206 5511 -2012 10098 -4552 9922 -7015 7916 -7383 7099 -4098 7633
--6303 5177 -5531 6291 -3833 7135 -6983 5817 -8809 5574 -10136 5645 -10479 5596
--10121 5409 -9140 5164 -7838 4957 -7295 4656 -7428 4491 -7104 4562 -5845 5206
--5758 5472 -5240 5463 -3854 5817 -6155 5488 -7136 6808 -7324 6907 -2702 5358
--4014 6855 -4329 6748 -8693 7597 -13147 8001 -17148 8896 -17846 9176 -10975 8053
--4975 6695 -7514 6759 646 5611 -6206 11407 -9542 6955 -7183 1813 -10472 7710
--14223 17231 -10162 14382 -22055 12151 -32663 13914 -10023 15564 11560 17037
-47498 24481 78117 26634 65953 16612 36590 4327 7338 -4831 -15627 -10427
--30798 -13830 -39324 -16945 -42674 -22724 -40479 -36052 -31415 -48938
-9825 44692 -8804 -2257 -20661 6719 -32935 71958 -21879 56172 -30135 42423
--31432 27403 -15153 23993 3764 14432 11264 13694 4838 14758 6109 14436
-11871 12577 23285 8843 26571 9245 24086 11571 19057 12764 10318 8576 1657 3268
--6107 -2077 -10046 -4612 -10420 -4260 -9510 -2855 -9688 -2735 -12306 -5723
--17385 -12537 -23562 -22240 -28209 -31911 -28262 -37512 -22016 -36609
--9723 -29109 6703 -16760 23993 -2665 37591 9206 41934 15542 32889 16843
-12535 17431 -12749 19061 -35898 20718 -52287 20670 -59291 17920 -54938 12470
--36501 4972 495 -3713 60661 -12580 130198 -19154 74148 -10554 8792 -1205
--34769 5561 -57510 10037 -65973 12845 -65884 14359 -61359 14761 -55144 14193
--48966 12807 -43783 10826 -39921 8571 -37267 6451 -35418 4890 -33819 4179
--32002 4268 -29775 4891 -27468 5843 -25870 6947 -25915 7974 -28456 8961
--33745 10129 -41338 11721 -49997 13856 -57854 16489 -62961 19426 -64105 22399
--61341 25174 -55836 27621 -49128 29710 -42457 31465 -35047 32732 -31788 33993
--31994 35168 -34599 36101 -38061 36596 -40517 36468 -40265 35645 -36746 34299
--31326 32938 -26170 32212 -20306 32409 -11908 33472 -859 35055 9925 36529
-14765 37157 13182 37156 9424 37058 8195 35854 11860 31570 16309 24791
-16483 16777 14214 10583 23785 16320 19754 29571 17851 13842 22321 5579
-23583 2147 22056 1658 14169 -2391 15697 -8871 9631 -11376 -8107 -22450
-20975 -4017 25676 27337 30365 -2822 56704 -34838 68795 -49852 72707 -59895
-69719 -64681 61723 -62961 52825 -54854 45681 -40532 39763 -20515 29192 1785
-5711 18127 -8812 27078 -11936 30924 -9004 26258 -5313 12929 -2732 -969
--13305 2989 -11211 15214 -23567 28589 -87375 62079 -24213 6802 -8324 5671
--6060 1824 5646 -3825 -26375 -6707 -30560 1371 -13948 12366 -3682 17628
--2579 17763 -5742 15689 -9426 13329 -12145 11419 -13752 10018 -14494 8951
--14607 8083 -14229 7415 -13427 6999 -12333 6826 -11100 6851 -9852 7020
--8644 7282 -7490 7599 -6370 7936 -5283 8271 -4215 8581 -3170 8855 -2166 9095
--1206 9302 -331 9488 477 9665 1190 9845 1819 10034 2365 10244 2823 10481
-3194 10744 3487 11034 3690 11345 3827 11674 3894 12014 3887 12358 3835 12702
-3725 13038 3562 13364 3356 13672 3108 13960 2823 14225 2513 14464 2184 14677
-1830 14863 1450 15023 1058 15158 651 15265 250 15345 -158 15399 -573 15432
--999 15443 -1428 15441 -1850 15426 -2253 15397 -2647 15354 -3023 15295
--3409 15216
-107: 11271620 -5517447 -5520 8870 -5500 8837 -5480 8805 -5470 8768 -5460 8727
--5440 8686 -5420 8650 -5410 8607 -5390 8561 -5370 8514 -5330 8465 -5320 8421
--5300 8377 -5280 8333 -5250 8288 -5230 8240 -5210 8194 -5180 8150 -5170 8110
--5150 8074 -5140 8036 -5110 8000 -5100 7964 -5080 7936 -5080 7914 -5080 7895
--5080 7876 -5070 7864 -5070 7855 -5090 7852 -5100 7860 -5130 7869 -5150 7886
--5190 7906 -5230 7936 -5280 7968 -5330 8009 -5400 8058 -5490 8114 -5570 8177
--5660 8247 -5770 8322 -5880 8400 -6020 8482 -6150 8576 -6310 8676 -6460 8780
--6640 8887 -6810 8990 -6990 9095 -7180 9212 -7410 9334 -7610 9456 -7840 9573
--8050 9683 -8260 9793 -8490 9907 -8730 10024 -8970 10138 -9200 10245 -9430 10338
--9630 10431 -9860 10522 -10090 10607 -10300 10689 -10520 10760 -10710 10827
--10890 10887 -11080 10941 -11250 10986 -11420 11025 -11580 11060 -11740 11095
--11880 11122 -12020 11142 -12150 11153 -12260 11160 -12370 11166 -12490 11177
--12620 11186 -12730 11188 -12820 11185 -12920 11184 -13040 11186 -13150 11192
--13290 11204 -13400 11213 -13530 11222 -13660 11235 -13800 11253 -13960 11275
--14120 11303 -14310 11337 -14480 11374 -14690 11417 -14900 11461 -15100 11507
--15330 11558 -15560 11618 -15820 11682 -16080 11748 -16350 11811 -16590 11873
--16840 11930 -17100 11997 -17380 12066 -17650 12135 -17910 12196 -18140 12245
--18340 12285 -18560 12329 -18780 12371 -18970 12407 -19140 12425 -19270 12436
--19360 12432 -19440 12423 -19500 12403 -19540 12373 -19520 12330 -19490 12279
--19410 12212 -19298 12133 -19146 12038 -18964 11936 -18752 11821 -18524 11708
--18267 11588 -17961 11449 -17605 11290 -17231 11127 -16846 10968 -16475 10821
--16091 10675 -15663 10512 -15195 10337 -14720 10165 -14267 10011 -13855 9877
--13457 9756 -13036 9629 -12594 9502 -12174 9386 -11799 9298 -11489 9236
--11213 9199 -10944 9170 -10689 9154 -10475 9161 -10324 9195 -10241 9259
--10213 9349 -10235 9465 -10296 9608 -10413 9772 -10594 9967 -10834 10180
--11132 10418 -11499 10692 -11937 10997 -12433 11327 -12973 11671 -13550 12022
--14174 12388 -14885 12790 -15668 13226 -16492 13674 -17339 14122 -18189 14558
--19056 14997 -20002 15460 -21013 15949 -22043 16436 -23058 16904 -24032 17347
--24993 17771 -26057 18227 -27079 18657 -28067 19067 -29005 19457 -29960 19821
--30879 20164 -31777 20480 -32609 20767 -33373 21020 -34079 21242 -34746 21433
--35344 21587 -35883 21707 -36333 21787 -36683 21819 -36950 21826 -37130 21801
--37224 21713 -37222 21566 -37120 21394 -36893 21230 -36553 21014 -36114 20694
--35538 20299 -34887 19901 -34173 19569 -33233 19250 -32002 18801 -30718 18179
--29593 17451 -28429 16720 -26839 16055 -24802 15471 -22633 14893 -20507 14167
--18161 13187 -15316 11955 -11880 10604 -8355 9337 -5181 8316 -2714 7574
--791 7040 640 6614 1824 6209 3012 5755 3978 5142 4642 4339 4903 3484 5258 3037
-5697 2927 5937 3029 6426 3272 7511 3579 8753 3956 9540 4360 9509 4688 8763 4845
-7786 4794 7055 4542 10091 3916 10913 3415 10171 2930 8322 2429 5748 1932
-2903 1476 220 1123 -1380 994 -1864 1021 -1775 1136 -1566 1304 -1591 1436
--1955 1441 -2488 1294 -3118 1039 -3943 786 -5214 647 -7138 695 -9726 937
--11999 1437 -11133 2472 -8626 3924 -7673 5875 -6542 5182 -6947 5559 -4875 4669
--4683 3463 -5537 2919 -6704 2684 -7246 3014 -7062 4058 -6358 5399 -5370 6243
--5729 6530 -6990 4858 -5656 3639 -4022 3669 -8272 4807 -7817 4749 -7669 3638
--6544 1522 -6052 6664 2332 4123 1522 4924 -496 7410 -3149 7914 -5830 6989
--6869 6247 -455 7822 -3438 6451 -7372 5330 -3669 7115 -5091 6093 -7032 5255
--9290 5426 -9852 5475 -9431 5420 -8252 5430 -7071 5191 -6666 4831 -7870 4464
--7271 4479 -5942 4915 -5614 5467 -4088 5317 -7992 5441 -7361 5100 -7501 6557
--6405 6676 -3424 5931 -3722 7223 -4447 7418 -6968 7806 -9252 7942 -11921 8450
--16201 9415 -8795 8722 -7018 8690 -8248 8120 -3413 7741 -3292 8927 -8981 7574
--10496 5723 -13380 10374 -14418 16981 -1460 11465 -21803 11012 -34326 17840
-9261 20711 -3 12794 52405 28240 108209 38685 67051 21282 18983 4131 -14410 -5587
--33968 -9390 -41923 -9386 -42866 -6863 -41090 -1496 -39636 10003 -45113 32714
--89856 14788 24799 -7068 14663 -29472 -16511 32664 -3835 17912 -38455 16664
--32762 15066 -7082 17466 11184 15768 16362 16192 11561 17121 9309 16937
-12097 15175 29036 8257 30070 9530 24874 13425 19092 15710 10993 12405
-1553 6489 -9050 -1353 -13071 -4060 -11545 -2124 -8527 1146 -7457 2187
--10011 -1592 -16297 -11436 -24915 -26426 -32404 -42116 -33831 -51045
--26898 -49634 -12160 -38374 8103 -20071 30597 955 50208 18304 58359 24926
-45606 21451 16227 19318 -18507 21047 -47447 23512 -65872 23378 -72612 19349
--67091 11941 -47410 2418 -7319 -8138 70158 -19458 224128 -33333 79638 -12867
--12834 354 -57291 7921 -74883 12566 -78060 15406 -73793 16787 -66210 16835
--57809 15724 -50071 13641 -43769 10852 -39123 7756 -35955 4888 -33792 2876
--32010 2192 -29959 2640 -27176 3630 -24109 4915 -21808 6352 -21600 7345
--24732 8026 -31619 8852 -41774 10270 -53578 12502 -64339 15475 -70974 18880
--71621 22289 -66639 25341 -58320 27908 -49167 30020 -40864 31764 -34474 33094
--32373 34426 -34019 35657 -38255 36605 -43266 37055 -46558 36788 -45463 35674
--38796 33859 -29500 32066 -23978 31422 -18992 32075 -9978 33798 4479 36136
-20602 38258 24713 38503 16799 37830 5843 38571 165 38915 6225 33302 14289 24077
-12297 11963 543 -3643 33253 3537 18348 42284 11899 10493 25956 4153 32181 3779
-22747 1239 9682 -6886 9256 -1989 5844 -3511 2231 -4754 19317 8008 15845 2979
-13304 -4536 53543 -32750 67191 -48017 71203 -56854 69549 -60385 64181 -58157
-57161 -49976 49655 -36128 40921 -17779 28336 2196 10656 19497 -3934 32234
--12860 40238 -18138 42009 -22119 36377 -23151 21456 -9707 -4701 331 -6169
-15897 -11642 -81127 40494 -31198 -1685 -5871 -10857 7704 6422 603 -1238
--20388 -5583 -26064 321 5878 18780 12288 23820 3878 20835 -6175 16178
--13050 12439 -16486 10056 -17548 8711 -17303 7979 -16431 7560 -15301 7310
--14045 7189 -12726 7184 -11409 7273 -10127 7437 -8904 7659 -7738 7916
--6622 8189 -5541 8465 -4492 8728 -3471 8971 -2497 9190 -1575 9391 -729 9576
-50 9756 743 9938 1360 10127 1896 10333 2350 10559 2722 10806 3019 11076
-3234 11362 3381 11663 3462 11975 3478 12291 3442 12605 3353 12916 3219 13216
-3031 13502 2808 13770 2548 14017 2269 14242 1961 14444 1630 14621 1274 14776
-906 14906 528 15012 143 15093 -248 15149 -643 15186 -1050 15204 -1458 15207
--1864 15200 -2251 15177 -2633 15144 -2994 15093 -3362 15024
-108: 11301920 -5508438 -5720 8932 -5710 8905 -5700 8876 -5690 8840 -5680 8804
--5670 8765 -5650 8730 -5650 8690 -5630 8648 -5620 8603 -5590 8559 -5580 8519
--5570 8475 -5550 8432 -5530 8391 -5520 8346 -5500 8302 -5480 8260 -5480 8225
--5460 8188 -5450 8153 -5430 8115 -5420 8083 -5420 8057 -5410 8034 -5420 8016
--5420 7999 -5410 7984 -5420 7974 -5430 7974 -5450 7978 -5480 7986 -5510 8001
--5540 8021 -5590 8047 -5620 8079 -5690 8117 -5760 8163 -5830 8213 -5910 8272
--6010 8339 -6110 8411 -6210 8485 -6340 8561 -6480 8650 -6630 8745 -6770 8847
--6940 8944 -7100 9045 -7280 9143 -7470 9253 -7670 9369 -7880 9486 -8090 9597
--8290 9702 -8490 9807 -8720 9914 -8940 10027 -9170 10135 -9390 10236 -9590 10325
--9810 10414 -10010 10501 -10230 10582 -10430 10659 -10630 10728 -10810 10791
--10990 10848 -11150 10899 -11310 10942 -11470 10982 -11620 11015 -11760 11046
--11910 11072 -12020 11090 -12130 11102 -12240 11109 -12340 11114 -12450 11128
--12560 11137 -12650 11139 -12750 11136 -12830 11138 -12940 11142 -13050 11147
--13170 11160 -13280 11169 -13400 11183 -13530 11195 -13660 11214 -13800 11239
--13970 11269 -14140 11303 -14320 11341 -14520 11385 -14730 11431 -14920 11478
--15140 11529 -15380 11590 -15630 11653 -15890 11721 -16150 11786 -16390 11845
--16640 11904 -16890 11972 -17190 12039 -17440 12108 -17710 12167 -17930 12216
--18130 12257 -18360 12300 -18560 12340 -18770 12376 -18920 12395 -19060 12404
--19150 12399 -19230 12387 -19290 12367 -19330 12336 -19320 12293 -19280 12239
--19200 12174 -19100 12093 -18950 11999 -18767 11894 -18560 11782 -18337 11666
--18087 11545 -17784 11406 -17434 11247 -17065 11086 -16690 10927 -16325 10778
--15947 10633 -15528 10470 -15069 10295 -14607 10125 -14161 9971 -13759 9836
--13368 9715 -12961 9589 -12531 9463 -12122 9347 -11758 9258 -11457 9196
--11195 9159 -10939 9131 -10691 9113 -10493 9117 -10354 9151 -10279 9214
--10263 9302 -10294 9415 -10366 9556 -10491 9718 -10680 9908 -10929 10120
--11233 10351 -11608 10621 -12049 10922 -12551 11247 -13095 11585 -13672 11931
--14301 12290 -15009 12686 -15789 13115 -16615 13556 -17455 13995 -18301 14425
--19168 14857 -20104 15311 -21106 15792 -22127 16272 -23134 16732 -24098 17166
--25051 17584 -26104 18033 -27109 18454 -28084 18859 -29022 19242 -29953 19603
--30865 19941 -31746 20251 -32565 20533 -33327 20786 -34022 21009 -34676 21194
--35271 21349 -35801 21471 -36243 21554 -36594 21591 -36861 21606 -37044 21585
--37144 21495 -37154 21357 -37051 21216 -36838 21071 -36517 20851 -36086 20525
--35550 20147 -34961 19813 -34248 19555 -33244 19245 -32063 18746 -31004 18076
--30032 17345 -28729 16665 -26873 16125 -24775 15722 -22877 15295 -21066 14613
--18837 13545 -15652 12127 -11707 10581 -7597 9214 -4114 8199 -1422 7516
-510 7042 1853 6650 2937 6298 3810 5878 4610 5215 4814 4194 4514 2930 4289 2672
-4228 2914 4592 3348 6012 3839 8085 4183 9770 4502 10335 4837 9779 5086
-8703 5147 7882 5007 7761 4740 11137 4231 11935 3758 10886 3205 8562 2634
-5389 2101 1984 1587 -1628 1118 -3274 999 -3226 962 -2665 971 -2133 1118
--2180 1313 -2912 1422 -3807 1383 -4653 1180 -5589 936 -6753 788 -8089 874
--9341 1261 -9757 2035 -8540 3275 -7492 4623 -7799 5336 -8371 5213 -8130 5982
--3524 4280 -3320 2681 -4506 2739 -6268 2578 -7020 2961 -7688 4080 -6995 4906
--6199 5594 -6473 5791 -6912 4773 -6322 3950 -5658 3840 -7286 4313 -6917 4615
--7390 3966 -6374 4395 -3801 6094 1152 5067 2028 5359 968 6507 -926 6966
--2780 6649 -3336 6268 -1260 6675 -4165 6637 -7039 5692 -5913 6368 -5021 5823
--5858 4556 -8784 5287 -9016 5448 -8727 5488 -7600 5718 -6485 5439 -5795 5106
--8754 4552 -7625 4544 -6153 4890 -7627 5987 -6197 5573 -7575 5337 -6334 4712
--5827 5452 -5208 6160 -3802 6314 -3747 7263 -4565 7707 -6308 8057 -8169 8313
--10111 8691 -11197 8910 -8077 8709 -7195 8841 -7628 8736 -6651 9358 -5636 8624
--9929 8295 -10686 7077 -12948 10024 -14523 12970 -11383 12733 -6828 20144
-21380 25146 92381 42918 -106530 -7721 24092 21231 166396 57297 59161 22041
--7790 44 -39547 -7748 -53125 -8600 -50970 -5290 -42114 735 -34117 9279
--30750 20263 -34262 28043 -41069 8281 20499 -10539 -18519 -32096 -14884 3025
--21383 13671 -62417 9218 -38123 8194 5262 15828 20508 18741 21680 19690
-16880 19383 13899 17616 16349 14345 25896 9731 27311 10578 20302 15853
-16062 19318 10982 17248 2152 11108 -14041 -2023 -17117 -4366 -12056 389
--5948 6559 -3377 9148 -5865 4989 -13680 -8020 -25977 -29978 -38692 -55100
--42713 -68447 -35346 -65721 -18280 -49407 5580 -23722 34082 6768 63670 33224
-82218 39737 64837 24387 22260 18583 -25287 22623 -59178 27748 -77051 27898
--80743 21948 -71237 11757 -48012 -360 -4868 -13066 82860 -26793 320543 -48314
-30004 -9454 -50189 2773 -79113 9480 -87364 14213 -84951 17356 -77211 18816
--67468 18600 -57643 17000 -48927 14244 -41946 10646 -36840 6656 -33439 2904
--31301 297 -29773 -223 -27955 905 -24640 2319 -20561 3950 -17110 6108
--16085 6968 -19551 7044 -28092 7240 -41307 8340 -57353 10687 -72452 14164
--81409 18271 -81147 22294 -72478 25653 -59942 28270 -47652 30304 -37650 31954
--32597 33302 -31673 34704 -34629 36010 -40421 37015 -47305 37522 -52215 37280
--50752 35990 -39281 33563 -22130 30907 -18575 30450 -17557 31667 -9714 34032
-8033 37087 35147 40303 37216 39206 18138 36098 -3793 38299 -17942 43228
--5495 34760 10178 23447 4540 10735 -33759 -20045 65287 -26081 22207 37461
--1823 19974 32485 6150 46348 7642 27746 9567 6633 -3528 3892 -1129 4647 913
-6858 2542 14861 6113 15401 -423 19984 -9322 44638 -27771 59353 -41718
-65544 -50379 66037 -53887 62751 -51996 57081 -44573 49711 -31992 40324 -15438
-28082 2884 13329 20217 -578 34638 -11847 44972 -20533 49544 -25762 44480
--19547 12645 -15558 1374 -12013 -7235 -15838 -2471 -29736 3386 -16029 -9614
--265 -11737 10505 -562 6214 -3492 -13990 -3779 -22953 755 43815 33585
-30776 31147 4565 21228 -13247 13518 -21761 9083 -24233 7010 -23556 6307
--21573 6273 -19275 6495 -17089 6773 -15135 7038 -13404 7279 -11873 7506
--10479 7727 -9199 7954 -8012 8186 -6890 8421 -5819 8654 -4789 8878 -3793 9091
--2854 9291 -1957 9479 -1138 9661 -390 9838 293 10019 899 10206 1425 10407
-1872 10622 2248 10857 2547 11107 2772 11373 2931 11650 3025 11937 3061 12226
-3045 12517 2975 12801 2863 13078 2696 13342 2493 13593 2262 13823 2008 14033
-1723 14224 1413 14393 1081 14541 740 14666 382 14771 16 14852 -352 14910
--734 14949 -1117 14972 -1510 14980 -1898 14979 -2271 14963 -2633 14937
--2981 14893 -3335 14834
-109: 11332280 -5499450 -5910 8994 -5910 8972 -5910 8943 -5900 8911 -5890 8875
--5890 8838 -5880 8808 -5870 8770 -5870 8732 -5860 8689 -5840 8649 -5830 8610
--5820 8569 -5810 8530 -5800 8487 -5790 8446 -5780 8408 -5770 8366 -5760 8332
--5750 8298 -5750 8263 -5740 8229 -5740 8196 -5730 8172 -5730 8150 -5740 8132
--5740 8115 -5740 8100 -5750 8090 -5760 8088 -5790 8091 -5820 8099 -5840 8114
--5870 8130 -5920 8154 -5960 8186 -6020 8219 -6090 8262 -6160 8310 -6250 8366
--6320 8429 -6430 8495 -6540 8565 -6650 8638 -6790 8721 -6920 8812 -7070 8907
--7230 9003 -7390 9096 -7550 9190 -7730 9294 -7930 9403 -8130 9514 -8330 9622
--8520 9722 -8710 9821 -8930 9926 -9150 10028 -9350 10133 -9570 10227 -9770 10315
--9960 10400 -10160 10481 -10350 10558 -10560 10631 -10740 10698 -10900 10757
--11080 10812 -11220 10860 -11380 10901 -11520 10939 -11660 10969 -11790 11002
--11910 11026 -12020 11042 -12130 11053 -12210 11060 -12310 11068 -12410 11079
--12510 11090 -12590 11091 -12680 11090 -12750 11092 -12850 11097 -12950 11103
--13060 11116 -13170 11129 -13280 11141 -13390 11156 -13520 11177 -13670 11203
--13820 11235 -13990 11269 -14160 11309 -14360 11354 -14560 11399 -14750 11448
--14970 11502 -15190 11559 -15450 11626 -15710 11693 -15970 11759 -16200 11819
--16450 11878 -16700 11943 -16990 12014 -17250 12080 -17500 12140 -17730 12186
--17940 12229 -18150 12273 -18360 12310 -18560 12345 -18730 12364 -18850 12371
--18940 12365 -19030 12353 -19090 12335 -19120 12299 -19110 12256 -19080 12202
--19010 12136 -18900 12055 -18750 11961 -18579 11853 -18374 11742 -18153 11627
--17909 11507 -17611 11365 -17267 11209 -16902 11045 -16537 10889 -16178 10740
--15807 10594 -15396 10431 -14949 10258 -14493 10088 -14059 9934 -13667 9800
--13286 9678 -12887 9554 -12470 9427 -12074 9314 -11721 9222 -11430 9162
--11177 9123 -10932 9095 -10703 9077 -10512 9079 -10385 9113 -10320 9173
--10311 9260 -10356 9371 -10438 9508 -10571 9669 -10769 9856 -11022 10061
--11334 10290 -11717 10556 -12162 10851 -12668 11171 -13214 11504 -13794 11843
--14423 12196 -15133 12585 -15909 13007 -16731 13441 -17572 13873 -18412 14294
--19272 14718 -20203 15166 -21195 15638 -22207 16108 -23205 16562 -24160 16988
--25103 17399 -26144 17837 -27141 18252 -28101 18650 -29026 19027 -29942 19382
--30843 19713 -31707 20021 -32525 20297 -33277 20550 -33960 20769 -34604 20951
--35194 21106 -35711 21230 -36150 21307 -36503 21356 -36770 21377 -36952 21354
--37061 21259 -37076 21139 -36981 21025 -36775 20887 -36470 20658 -36056 20331
--35567 19983 -35026 19721 -34277 19508 -33233 19171 -32191 18622 -31347 17923
--30384 17203 -28829 16609 -26769 16259 -24843 16084 -23387 15821 -22027 15167
--19794 13959 -16197 12267 -11452 10419 -6559 8900 -2666 7909 90 7311 1958 6912
-3161 6540 3757 6251 4447 5941 4924 5311 4816 4178 3859 2068 2673 2451 2116 3219
-3012 4008 5632 4775 8887 4924 10902 5009 11075 5204 9968 5355 8738 5289
-8369 5034 9057 4837 12239 4622 12714 4253 11123 3584 8282 2895 4438 2333
-1018 1741 -4118 971 -5448 999 -4310 892 -3240 695 -2250 862 -2317 1183
--3631 1456 -4873 1570 -5681 1436 -6471 1198 -7381 1027 -8126 1124 -8667 1516
--8721 2240 -7913 3368 -6247 4865 -6231 5346 -7700 5770 -7842 5739 -4802 4263
--3637 1638 -4390 3146 -6533 2769 -6708 2954 -8280 4258 -7122 4309 -6118 4734
--6722 5126 -6946 4705 -6580 4196 -6196 4149 -6720 4555 -7127 4543 -7162 4380
--5492 4787 -1673 6149 1375 5936 2544 6042 2256 6533 1121 6823 -320 6711
--1773 6234 -3814 5299 -4985 6801 -8235 5541 -7778 5874 -5721 5834 -6146 4208
--6856 4841 -7066 5413 -7462 6008 -8005 5434 -7397 5351 -7010 5158 -8116 4879
--7486 4937 -6981 5388 -7860 6147 -6110 5444 -6648 5393 -4248 4136 -4001 4755
--3873 5650 -3525 6349 -3766 7203 -4686 7809 -6158 8250 -7758 8624 -9067 9006
--7729 8466 -6829 8371 -6725 8702 -7127 9045 -8318 9759 -7849 9064 -9119 8149
--10361 7678 -9628 9559 -8487 10382 418 12685 69070 32700 336398 116853
--54717 6528 -375027 -68770 -11601 9610 272630 90457 26334 15757 -37828 -5965
--59172 -8482 -69168 -7168 -54124 -2332 -33489 3766 -18940 9579 -12395 13330
--11888 10730 -12952 -3528 -7120 -13847 -29888 -21070 -15773 15889 -21606 8963
--78339 4671 -39064 2309 20458 16397 24390 21179 21484 21958 16374 20331
-13144 17027 14280 12779 19379 9017 21155 9444 10678 16822 10200 21295
-9894 21099 4619 17072 -20865 -4682 -20547 -4879 -10562 3782 -1252 13401
-2109 17612 -494 13683 -9557 -1493 -26377 -31362 -48257 -71960 -55661 -89859
--47438 -83608 -28326 -60952 -3093 -28194 29155 13176 72646 55959 117813 64355
-92555 20073 29945 12695 -35358 24718 -70158 35503 -83223 35793 -81129 26381
--64614 12146 -34346 -2956 14478 -17401 92765 -30255 189934 -38397 46028 -17034
--38691 -2701 -74915 6822 -84870 13732 -82118 18236 -73797 20273 -63898 19894
--53937 17951 -45128 14625 -38074 10322 -32899 5519 -29519 791 -27725 -2748
--26965 -3035 -26311 -671 -22360 969 -16940 2572 -11764 6662 -8934 7038
--12374 5996 -22355 5142 -38933 5743 -60561 8247 -82385 12472 -95142 17664
--93466 22602 -78539 26246 -59802 28764 -43807 30553 -32491 31973 -28833 33255
--28840 34745 -32638 36157 -39458 37242 -48351 37923 -56321 37976 -56867 36871
--39678 33786 -4085 29249 -9230 29566 -16323 31585 -11170 34465 5708 37565
-54561 43072 50377 39271 14034 30033 -19445 34072 -50258 50765 -23244 33344
-1842 18126 -31187 9276 -75180 1316 106698 2616 56805 -14983 -23266 -1291
-35062 -13353 50460 -6655 38411 29964 7447 4159 6637 5101 8933 6201 11762 6183
-16068 5071 18911 -1057 25428 -10020 40251 -23044 52183 -34631 58778 -42669
-60663 -46361 58911 -45221 54443 -39061 47797 -28202 39020 -13660 28073 2830
-15543 19111 3092 33143 -7945 42978 -16638 46156 -21363 39010 -19571 17895
--18297 5447 -17461 -3018 -18549 -4400 -17439 -6800 -9217 -12353 997 -12580
-8612 -6941 9228 -4091 -957 4814 15468 15381 103075 56866 30230 30430 -13528 13550
--31508 5864 -36186 3025 -34756 2550 -30925 3148 -26581 4125 -22565 5123
--19183 5984 -16441 6669 -14224 7190 -12407 7591 -10860 7907 -9504 8170
--8281 8405 -7157 8622 -6095 8828 -5084 9024 -4117 9212 -3204 9394 -2340 9568
--1548 9741 -820 9914 -153 10090 437 10274 956 10467 1399 10674 1776 10895
-2076 11129 2308 11377 2480 11634 2588 11897 2643 12164 2642 12430 2593 12693
-2495 12948 2352 13194 2178 13424 1964 13641 1734 13837 1466 14016 1181 14177
-878 14318 556 14440 218 14540 -130 14621 -474 14680 -837 14721 -1204 14748
--1582 14760 -1946 14764 -2305 14754 -2653 14734 -2987 14697 -3328 14646
-110: 11362710 -5490479 -6110 9055 -6100 9034 -6110 9008 -6100 8975 -6090 8943
--6100 8912 -6100 8882 -6090 8847 -6090 8811 -6080 8773 -6080 8732 -6060 8697
--6070 8660 -6060 8623 -6060 8583 -6050 8542 -6040 8505 -6040 8468 -6040 8435
--6030 8402 -6030 8368 -6040 8337 -6030 8307 -6030 8281 -6040 8259 -6040 8242
--6040 8226 -6060 8212 -6060 8203 -6080 8198 -6100 8199 -6140 8207 -6160 8221
--6190 8234 -6240 8259 -6280 8285 -6330 8320 -6410 8357 -6470 8403 -6550 8455
--6640 8514 -6730 8578 -6840 8643 -6950 8712 -7080 8790 -7200 8875 -7360 8966
--7500 9059 -7650 9145 -7820 9235 -7980 9335 -8180 9438 -8360 9542 -8560 9646
--8740 9741 -8920 9837 -9130 9934 -9340 10034 -9540 10129 -9740 10222 -9920 10306
--10110 10387 -10300 10464 -10480 10536 -10670 10605 -10840 10669 -11010 10726
--11150 10778 -11300 10824 -11450 10863 -11570 10898 -11690 10926 -11810 10958
--11920 10981 -12030 10998 -12110 11007 -12200 11014 -12280 11022 -12370 11033
--12470 11042 -12530 11047 -12610 11046 -12680 11046 -12760 11053 -12860 11061
--12960 11074 -13060 11089 -13160 11101 -13270 11120 -13400 11142 -13530 11166
--13680 11198 -13850 11235 -14010 11278 -14210 11321 -14390 11369 -14600 11418
--14800 11472 -15030 11530 -15270 11600 -15540 11668 -15790 11730 -16020 11793
--16260 11850 -16530 11916 -16790 11987 -17060 12053 -17320 12111 -17530 12158
--17740 12200 -17960 12243 -18170 12282 -18360 12314 -18520 12332 -18660 12338
--18740 12333 -18830 12320 -18890 12298 -18920 12265 -18910 12222 -18880 12166
--18820 12101 -18700 12019 -18570 11922 -18390 11816 -18190 11703 -17975 11590
--17733 11468 -17441 11328 -17105 11174 -16745 11009 -16385 10852 -16034 10705
--15671 10557 -15266 10397 -14830 10225 -14384 10054 -13963 9900 -13573 9769
--13208 9647 -12819 9523 -12414 9395 -12025 9283 -11688 9193 -11404 9132
--11164 9092 -10931 9063 -10715 9044 -10535 9047 -10418 9080 -10362 9138
--10367 9222 -10418 9331 -10505 9466 -10654 9624 -10858 9807 -11119 10008
--11436 10234 -11822 10494 -12274 10786 -12782 11099 -13334 11426 -13914 11759
--14541 12106 -15253 12490 -16029 12902 -16847 13327 -17683 13755 -18517 14167
--19371 14582 -20299 15023 -21280 15485 -22282 15948 -23271 16392 -24216 16812
--25151 17214 -26176 17642 -27160 18052 -28111 18440 -29026 18810 -29930 19160
--30818 19484 -31671 19786 -32476 20061 -33219 20306 -33891 20522 -34525 20704
--35108 20858 -35619 20977 -36056 21056 -36397 21109 -36669 21133 -36852 21105
--36960 21013 -36994 20909 -36903 20813 -36696 20678 -36402 20437 -36006 20112
--35575 19805 -35054 19605 -34247 19405 -33224 19028 -32357 18443 -31657 17728
--30566 17028 -28728 16565 -26627 16457 -25057 16537 -24262 16438 -23352 15812
--21160 14453 -17017 12383 -11224 10040 -5071 8324 -925 7397 1649 6934
-3442 6633 4242 6220 4251 5990 4596 5857 4907 5272 4997 4483 3243 861 728 2917
--173 4077 1137 4981 5128 6135 9866 5617 12124 5284 11806 5369 10138 5509
-8793 5312 9031 4814 10671 4810 13422 5238 13140 5097 10432 4151 7023 3221
-1994 2614 364 1980 -6911 441 -7201 1029 -4355 841 -3515 271 -1925 570 -1931 1100
--4238 1538 -5739 1874 -6155 1785 -6629 1533 -7437 1279 -7632 1398 -7845 1727
--8247 2186 -9016 2764 -9039 3768 -102 6624 -5943 6495 -8985 6331 -6142 2140
--4671 782 -5745 4212 -6609 3949 -6684 3513 -7273 4238 -6071 3510 -5074 3921
--6733 4736 -6828 4668 -6461 4390 -6018 4606 -6332 4877 -7095 4588 -6266 4680
--4030 5119 -935 6048 1562 6361 2908 6567 3120 6814 2420 6970 969 6989 -1371 6736
--7300 4467 -8816 5204 -7159 5385 -9094 5251 -8191 4662 -4847 5375 -4664 5059
--5010 5111 -6924 5954 -7922 5693 -8003 5438 -7710 5236 -7607 5053 -6448 5051
--5900 5301 -6046 5592 -5264 5244 -4975 5001 -3615 4417 -3172 4769 -3093 5544
--3153 6368 -3645 7205 -4648 7873 -5886 8335 -6896 8641 -7222 9012 -6591 8654
--6521 8507 -6813 8435 -7841 8966 -8719 10327 -8778 9725 -8195 8571 -8079 8259
--7469 9093 -7623 8944 1564 11743 41787 24751 98832 48870 -137321 -6617
--127790 -9809 112842 38944 152726 64482 58114 29156 -27523 -445 -56535 -1247
--81963 -3373 -47523 1026 -13804 5309 3807 6783 9467 4018 9390 -4026 6877 -13480
--16326 -5973 -29028 2137 -18924 15445 -17032 12717 -33070 7718 -30225 4894
--10777 7867 5047 18883 10778 21062 8236 18987 5153 14847 4557 10068 6024 6517
-6263 6889 2613 12436 3768 17964 4475 18801 -872 14716 -16527 827 -17612 -1812
--5466 8822 4765 20783 6446 24991 3478 21577 -5083 7199 -24892 -27800 -62580 -94749
--71943 -113216 -60843 -98401 -39531 -68204 -18519 -33311 6969 13880 60180 84739
-173065 107729 128684 -4446 36645 925 -52467 30903 -75518 50380 -79386 48742
--73147 32638 -51039 12907 -19199 -4577 21099 -19372 69250 -29841 100001 -32519
-32140 -21084 -30447 -8608 -63653 2695 -73359 12271 -71359 18572 -63974 21469
--55878 20615 -46895 18579 -38855 14795 -32379 9974 -27485 4738 -24159 -635
--22664 -5562 -23161 -6296 -25571 -1634 -20291 -473 -13375 -631 -6131 9220
-277 7665 -3067 4808 -13827 2376 -33316 2296 -61583 4997 -94094 10261 -113166 17139
--109861 23559 -83895 27306 -56383 29442 -36737 30752 -25384 31729 -23151 32812
--23537 34477 -27335 36031 -33588 37114 -43486 37986 -55568 38617 -63557 38461
--46280 35329 33632 26563 996 29630 -14864 32789 -5714 36485 -2615 37404
-71454 45333 51646 38384 -2082 19513 -34124 23695 -91318 63378 -33018 27070
-25065 8986 -6075 4055 -35708 6359 48192 -3792 34862 -9107 -18793 -8618
--20164 -40906 -14244 -78299 57748 61261 38283 41345 25433 23236 20450 14073
-19506 9139 20885 5055 23456 -902 28961 -8808 38242 -18624 46897 -27972
-52597 -35066 54885 -38801 54069 -38469 50650 -33754 45023 -24828 37466 -12484
-28213 1871 17803 16386 7205 29009 -2611 37594 -10662 39896 -15797 34003
--17395 20653 -18101 9349 -18168 889 -17349 -3909 -13562 -7934 -6499 -11084
-1985 -10572 9925 -6064 18971 1597 52077 24404 246810 114776 16543 18720
--47980 -2657 -57772 -5284 -56869 -5086 -51775 -3818 -44836 -1953 -37604 118
--31013 2097 -25468 3813 -21055 5194 -17627 6251 -14975 7030 -12900 7597
--11202 8014 -9770 8328 -8524 8580 -7394 8793 -6348 8985 -5360 9162 -4424 9329
--3539 9495 -2709 9657 -1941 9819 -1237 9984 -586 10154 -17 10332 495 10517
-935 10715 1310 10923 1613 11144 1848 11374 2034 11612 2152 11856 2222 12102
-2236 12347 2200 12589 2128 12825 2006 13052 1852 13267 1659 13468 1447 13652
-1202 13820 944 13972 662 14107 354 14223 38 14320 -289 14400 -614 14459
--956 14502 -1306 14531 -1665 14548 -2014 14555 -2353 14551 -2686 14535
--3012 14505 -3342 14461
-111: 11393190 -5481521 -6290 9111 -6280 9091 -6300 9069 -6290 9039 -6300 9008
--6290 8982 -6300 8951 -6310 8921 -6300 8886 -6300 8851 -6300 8815 -6290 8779
--6300 8746 -6300 8711 -6300 8673 -6300 8636 -6290 8598 -6300 8564 -6300 8533
--6300 8504 -6310 8470 -6300 8440 -6320 8411 -6310 8384 -6320 8365 -6330 8348
--6340 8331 -6350 8318 -6360 8311 -6380 8304 -6410 8305 -6430 8311 -6460 8322
--6500 8337 -6530 8357 -6580 8381 -6640 8413 -6700 8448 -6770 8491 -6850 8541
--6930 8597 -7020 8656 -7120 8719 -7230 8782 -7360 8857 -7480 8938 -7610 9024
--7770 9112 -7900 9193 -8060 9280 -8230 9373 -8410 9472 -8590 9572 -8770 9669
--8950 9760 -9120 9851 -9320 9944 -9520 10038 -9710 10130 -9900 10219 -10080 10297
--10250 10374 -10430 10445 -10610 10517 -10780 10582 -10940 10643 -11090 10698
--11240 10747 -11370 10789 -11490 10826 -11620 10859 -11730 10887 -11840 10917
--11940 10938 -12020 10954 -12110 10963 -12180 10971 -12260 10977 -12330 10989
--12420 10997 -12480 11003 -12550 11002 -12610 11004 -12680 11010 -12770 11019
--12860 11035 -12960 11050 -13060 11061 -13160 11083 -13280 11106 -13400 11133
--13550 11164 -13710 11201 -13880 11246 -14060 11290 -14250 11339 -14440 11389
--14640 11442 -14870 11502 -15110 11571 -15370 11641 -15620 11705 -15850 11765
--16090 11824 -16350 11886 -16610 11959 -16880 12026 -17130 12083 -17350 12129
--17550 12172 -17770 12214 -17970 12253 -18180 12280 -18330 12301 -18460 12306
--18550 12303 -18630 12287 -18690 12264 -18730 12231 -18720 12187 -18690 12131
--18630 12066 -18510 11983 -18380 11889 -18210 11780 -18010 11667 -17797 11553
--17563 11432 -17275 11294 -16945 11139 -16594 10976 -16234 10818 -15892 10671
--15538 10525 -15144 10366 -14712 10195 -14278 10025 -13869 9872 -13488 9739
--13132 9619 -12752 9495 -12361 9370 -11981 9257 -11655 9167 -11384 9105
--11155 9066 -10933 9037 -10727 9017 -10560 9019 -10453 9050 -10407 9107
--10420 9189 -10480 9297 -10580 9429 -10732 9583 -10948 9762 -11215 9960
--11539 10184 -11928 10437 -12386 10723 -12894 11031 -13450 11353 -14031 11680
--14660 12019 -15370 12396 -16145 12801 -16959 13220 -17787 13636 -18620 14043
--19468 14450 -20386 14882 -21363 15335 -22353 15789 -23329 16225 -24269 16636
--25195 17030 -26205 17450 -27173 17850 -28111 18232 -29025 18591 -29905 18935
--30784 19252 -31627 19550 -32420 19820 -33151 20058 -33815 20271 -34438 20450
--35010 20602 -35522 20717 -35945 20793 -36288 20851 -36557 20877 -36740 20841
--36851 20755 -36885 20660 -36801 20581 -36603 20439 -36310 20187 -35932 19872
--35549 19611 -35025 19448 -34163 19238 -33203 18830 -32511 18220 -31863 17483
--30570 16822 -28499 16532 -26487 16677 -25458 16989 -25381 17056 -25020 16516
--22998 15080 -18357 12572 -11221 9379 -2870 7449 1056 6681 2977 6365 4595 6165
-4995 5670 4266 5503 4229 5544 4403 4429 4829 3618 3579 1506 -556 5133 -1809 5511
--867 5901 4046 7824 11052 5768 13469 5062 12598 5292 10217 5687 8468 5414
-9373 4216 12293 4493 14933 6361 13200 6656 7831 5070 4107 3708 -3951 2829
--2441 2165 -5398 -572 -6519 973 -2371 780 -4272 -248 -1867 414 -1470 1199
--4890 1576 -6274 2236 -5837 2145 -5958 1918 -7178 1472 -6619 1765 -6395 2140
--6374 2586 -6906 3223 -5500 5028 -4015 5251 -5493 4119 -10291 4867 -9009 3184
--7749 2620 -5107 4090 -6245 3936 -5700 3054 -5420 3858 -4895 3917 -5553 3868
--6168 4222 -6202 4564 -5877 4507 -6007 4857 -6736 5064 -6539 4868 -5233 4996
--2712 5274 -394 6121 1685 6674 3069 6951 3505 7037 2805 6919 537 6585 -3833 6011
--6496 5219 -7717 5218 -7754 5488 -10933 5584 -8794 5131 -5986 5261 -4261 4700
--3253 4270 -6521 5829 -7403 5610 -7870 5275 -7747 5118 -7154 4944 -4642 4805
--3906 4877 -4023 4985 -3938 4876 -3776 4764 -3183 4642 -2847 4977 -2736 5647
--2854 6452 -3404 7284 -4459 8001 -5572 8499 -6383 8787 -5361 8899 -5664 8854
--6339 8976 -6884 8975 -7730 9138 -9566 10287 -10059 10033 -7461 8593 -6930 8422
--7269 8759 -7450 8497 -10562 7851 -8065 8352 -13470 7888 -26548 16956
-29333 23553 153457 47086 46423 43481 -1762 23576 -53508 2226 -58185 9492
--109328 -738 -24606 5733 19884 8353 30801 6277 27466 -234 18098 -10725
-6964 -18096 -566 -1178 -20367 15488 -18696 20423 -17419 15846 -22590 9347
--27141 4268 -23111 4210 9893 16693 4785 17924 -2776 15381 -7464 10896
--9718 5627 -10615 1353 -10473 680 -8335 5211 -2715 12273 1914 16665 802 16470
--10253 5452 -12501 -1577 -1116 13011 6458 25166 3324 25315 201 20934 -5121 10271
--20965 -18502 -81272 -123203 -86336 -129329 -69501 -98901 -43237 -58938
--34512 -32990 -39961 -2553 -18655 98216 255586 174192 167901 -61768 34496 -5755
--75770 47181 -55953 76236 -54212 66861 -56595 38358 -31686 12379 -4042 -5251
-19523 -19576 40985 -28415 46778 -29315 8713 -22913 -33635 -13468 -56178 -1359
--58944 11263 -56386 19035 -49319 23125 -45265 20296 -37420 19041 -30837 14651
--25667 9308 -21448 4362 -17794 109 -15127 -4338 -17765 -10829 -26275 -2054
--17445 -1899 -9881 -9456 -1503 17013 11976 8163 7185 3393 -2850 -1120
--23344 -1989 -57368 813 -106489 7258 -135431 16678 -132634 25800 -86207 28979
--47592 30337 -25894 30912 -17139 31133 -16467 31753 -16466 33881 -19490 35647
--22111 36432 -29498 37263 -42099 38330 -61000 39886 -68987 39102 91259 23078
--2813 32406 -12863 36050 33451 43694 55609 45645 -1553 31425 -4244 27561
--27762 20173 -50763 25299 -73498 42141 -38107 24168 953 8511 -2552 2907
-1986 17880 1040 4316 -6166 1500 -22406 -2638 -10574 -7471 -14961 -62615
-32481 5184 38605 20513 33531 17705 28776 12541 26321 8155 25991 4035 27477 -1003
-31234 -7332 37090 -14786 43036 -22175 47416 -28200 49494 -31789 49135 -32148
-46545 -28832 42008 -21846 35854 -11750 28390 337 20014 12820 11321 23807
-2935 31325 -4427 33629 -10040 29844 -13602 21248 -15816 12165 -16602 4408
--15344 -1205 -11009 -5131 -3461 -6801 7101 -4772 21623 2039 45378 15528
-92615 41678 169116 81049 37918 28841 -37847 737 -61730 -7815 -63980 -8782
--58152 -7063 -49736 -4460 -41162 -1719 -33519 802 -27185 2939 -22202 4646
--18375 5950 -15461 6909 -13217 7599 -11434 8096 -9961 8455 -8704 8726
--7586 8942 -6562 9125 -5601 9289 -4704 9443 -3850 9593 -3054 9743 -2314 9895
--1629 10052 -1007 10213 -446 10382 50 10560 483 10747 855 10944 1158 11150
-1398 11365 1591 11587 1722 11812 1798 12039 1833 12266 1814 12490 1757 12707
-1654 12918 1519 13117 1348 13304 1150 13477 934 13635 692 13777 430 13906
-143 14016 -151 14111 -456 14188 -769 14247 -1090 14291 -1420 14323 -1763 14342
--2096 14352 -2421 14353 -2737 14341 -3050 14318 -3362 14279
-112: 11423730 -5472580 -6470 9165 -6460 9147 -6470 9126 -6480 9100 -6480 9072
--6490 9047 -6500 9018 -6500 8988 -6500 8960 -6510 8925 -6510 8894 -6510 8858
--6530 8827 -6520 8794 -6530 8759 -6530 8724 -6540 8689 -6540 8657 -6550 8626
--6560 8598 -6560 8568 -6570 8538 -6580 8510 -6580 8484 -6590 8465 -6600 8450
--6620 8434 -6630 8419 -6640 8411 -6660 8406 -6690 8405 -6720 8410 -6750 8422
--6780 8434 -6820 8451 -6860 8473 -6930 8501 -6980 8537 -7050 8577 -7130 8622
--7200 8676 -7300 8732 -7390 8789 -7500 8851 -7610 8922 -7740 9001 -7860 9081
--8010 9161 -8150 9238 -8300 9323 -8450 9412 -8630 9506 -8800 9599 -8970 9692
--9150 9778 -9320 9866 -9500 9954 -9690 10044 -9870 10133 -10060 10214
--10220 10289 -10390 10362 -10560 10432 -10720 10499 -10880 10560 -11040 10617
--11180 10670 -11310 10719 -11430 10756 -11550 10794 -11660 10822 -11770 10850
--11860 10876 -11960 10900 -12030 10912 -12100 10920 -12160 10928 -12230 10935
--12310 10945 -12370 10955 -12440 10960 -12490 10961 -12540 10963 -12610 10970
--12690 10979 -12770 10997 -12870 11010 -12960 11026 -13050 11046 -13160 11069
--13290 11100 -13430 11130 -13580 11168 -13740 11211 -13920 11262 -14120 11310
--14290 11361 -14500 11413 -14720 11475 -14950 11541 -15220 11611 -15450 11679
--15690 11737 -15920 11795 -16180 11862 -16440 11930 -16710 11998 -16950 12055
--17170 12100 -17360 12145 -17590 12184 -17790 12223 -17980 12249 -18150 12270
--18260 12276 -18370 12270 -18450 12254 -18500 12231 -18540 12200 -18530 12152
--18500 12096 -18440 12032 -18330 11949 -18200 11855 -18020 11746 -17840 11633
--17620 11519 -17400 11399 -17109 11259 -16790 11106 -16444 10946 -16091 10789
--15754 10640 -15409 10495 -15026 10338 -14600 10168 -14176 10000 -13772 9847
--13406 9713 -13060 9595 -12691 9471 -12308 9347 -11942 9236 -11625 9145
--11366 9085 -11146 9044 -10938 9014 -10745 8995 -10585 8996 -10489 9025
--10455 9081 -10478 9162 -10544 9265 -10653 9395 -10813 9547 -11038 9723
--11309 9917 -11641 10136 -12036 10385 -12493 10665 -13005 10969 -13564 11281
--14149 11604 -14775 11938 -15483 12306 -16255 12704 -17063 13114 -17894 13523
--18716 13922 -19560 14320 -20471 14744 -21437 15187 -22418 15632 -23385 16058
--24315 16461 -25228 16847 -26226 17257 -27184 17650 -28108 18023 -29008 18375
--29879 18708 -30741 19019 -31574 19310 -32354 19575 -33078 19807 -33730 20012
--34340 20192 -34908 20339 -35411 20447 -35833 20523 -36165 20582 -36426 20606
--36606 20564 -36723 20479 -36755 20399 -36675 20319 -36477 20171 -36181 19913
--35836 19608 -35489 19388 -34928 19243 -34030 19015 -33159 18592 -32610 17951
--31929 17189 -30413 16593 -28194 16476 -26366 16818 -25933 17294 -26541 17521
--26906 17182 -25261 15884 -20373 13059 -12033 8383 584 6492 3193 5874
-3562 5607 5012 5004 4315 5155 4834 5265 3812 5293 3546 4584 4217 5002 3355 4683
-792 5094 -730 6504 -1777 6710 1266 8270 12150 4596 14499 4305 13300 5067
-10076 6167 7126 6170 8843 2950 13820 3358 17328 8497 13426 9372 1487 6722
--2988 5142 -7665 2912 -647 3245 -2991 -2003 -2964 -1966 -1109 179 -6584 462
--4724 615 -4234 1887 -3959 1108 -5100 2363 -4464 2343 -4462 2358 -6766 1569
--5328 2242 -5133 2672 -4585 3103 -6342 4033 -6092 3623 -5272 3755 -6087 3558
--8974 3973 -8867 4243 -8259 3921 -4525 4198 -7519 2346 -4926 2992 -4233 3983
--4373 4248 -5399 4215 -5511 3851 -5378 4359 -5436 4920 -5932 5319 -7404 5391
--6263 5010 -4461 5220 -1823 5291 -156 6361 1695 7020 3074 7305 3668 7277
-3209 6930 1114 6361 -4437 5941 -7735 5588 -7934 5644 -8458 5921 -9949 6109
--9343 5899 -7750 5576 -5659 4809 -3066 4080 -4005 4588 -5238 4660 -6395 4605
--7097 4620 -6867 4529 -2381 4270 -2010 4299 -2505 4414 -2955 4498 -3178 4602
--3095 4761 -2940 5145 -2769 5755 -2692 6519 -3041 7369 -4089 8167 -4723 8670
--5155 8915 -4437 8542 -5191 9135 -6406 9643 -6588 9649 -6984 9240 -8819 10042
--12532 10058 -7082 8245 -8044 9056 -6524 8437 -6169 8713 -9309 8407 -18240 5331
--12163 9412 11267 15384 61515 28350 104429 41287 36189 37766 -19968 24457
--74555 9161 -115460 3277 -134476 -2647 42304 13663 65927 13564 53381 9189
-38224 2658 21384 -6985 9728 -9391 2199 3549 -15037 8457 -15842 19990 -18631 15547
--15889 9984 -16443 4664 -10668 4403 4243 11229 -10969 11767 -18846 9931
--22319 5839 -24938 77 -28008 -5899 -28478 -8647 -20721 -4165 -7819 5784
-4886 17068 14510 26467 3882 12957 10804 -4514 -8977 19236 -13316 17466
--15349 11018 -16440 1678 -22045 -15065 -39587 -48815 -76167 -110149 -84590 -114568
--66796 -71466 -24187 -12580 -30746 -1959 -92782 -13454 -230566 17584
-282303 116653 239226 -6498 -26258 11431 -51551 63039 39522 113100 7200 86063
--39272 36415 -6615 8533 13651 -3299 15410 -17255 16136 -25880 16042 -25257
--13153 -22677 -45668 -17985 -55456 -5586 -42269 12049 -40787 19199 -30193 26751
--35674 16926 -26256 20350 -22041 13957 -19329 7027 -16758 2103 -13125 1168
--6553 6804 -8821 -6845 -23826 -8428 -11399 -2140 -6407 -27946 -167 34186
-25487 5682 14891 2299 8200 -4722 -10370 -6457 -44378 -4191 -114443 2890
--156092 15691 -165952 30467 -80668 31154 -32608 31484 -12543 31180 -9855 30201
--10178 29703 -9825 33050 -12420 35107 -8107 35186 -8543 35663 -9191 36110
--12186 37452 -28121 36736 4528 35105 -11656 35778 -7798 38329 23123 37397
-30170 37696 -9047 29240 -25217 24937 -40982 22004 -54332 24839 -60015 30092
--39855 22064 -16050 13274 -9517 11248 -7467 18554 -16044 14068 -18656 5762
--23443 -1893 -17496 -7491 -1928 -19314 23367 -17560 33337 -1889 34045 4645
-32008 5497 30152 4116 29422 1688 30100 -1760 32399 -6301 36050 -11742
-39995 -17391 43135 -22317 44751 -25596 44547 -26449 42582 -24354 39034 -19162
-34231 -11202 28443 -1323 21935 9158 15007 18610 8002 25354 1348 28045
--4475 26189 -9101 20734 -12401 13930 -13913 7444 -12886 2322 -8522 -911
--393 -1476 11918 1653 29511 9370 54505 22448 87056 40417 105625 54448
-39079 30015 -19562 7976 -48591 -3096 -57089 -6677 -55008 -6405 -48475 -4447
--40774 -1941 -33497 538 -27298 2717 -22331 4497 -18490 5880 -15544 6910
--13281 7657 -11499 8194 -10038 8577 -8801 8861 -7713 9078 -6727 9254 -5804 9409
--4942 9550 -4128 9689 -3365 9827 -2655 9968 -2003 10115 -1403 10268 -857 10428
--374 10596 45 10773 412 10958 718 11151 965 11352 1157 11558 1295 11767
-1385 11977 1431 12187 1426 12392 1387 12595 1300 12790 1182 12975 1029 13148
-854 13310 658 13459 435 13592 183 13714 -73 13820 -352 13910 -634 13985
--934 14044 -1238 14089 -1548 14121 -1870 14142 -2194 14156 -2501 14160
--2803 14154 -3099 14134 -3399 14101
-113: 11454310 -5463651 -6620 9217 -6630 9199 -6650 9179 -6650 9156 -6660 9133
--6680 9108 -6680 9082 -6680 9054 -6700 9026 -6700 8997 -6710 8967 -6730 8934
--6730 8905 -6740 8876 -6750 8841 -6760 8807 -6770 8776 -6770 8744 -6780 8715
--6800 8690 -6810 8658 -6810 8633 -6830 8604 -6830 8579 -6850 8561 -6860 8547
--6880 8532 -6890 8517 -6910 8506 -6930 8502 -6960 8501 -6990 8507 -7020 8514
--7050 8526 -7090 8543 -7130 8560 -7190 8588 -7250 8622 -7320 8660 -7390 8700
--7460 8750 -7560 8804 -7640 8858 -7750 8917 -7860 8985 -7980 9058 -8100 9133
--8240 9209 -8380 9285 -8520 9365 -8670 9448 -8830 9539 -9010 9628 -9170 9716
--9330 9796 -9500 9879 -9670 9965 -9850 10051 -10030 10133 -10200 10212
--10370 10284 -10510 10354 -10680 10418 -10840 10481 -10980 10541 -11130 10594
--11260 10646 -11380 10690 -11500 10726 -11600 10759 -11700 10790 -11800 10813
--11880 10840 -11970 10860 -12040 10874 -12100 10881 -12150 10887 -12210 10893
--12270 10905 -12340 10914 -12390 10920 -12430 10921 -12490 10922 -12540 10930
--12610 10943 -12700 10958 -12770 10974 -12870 10988 -12950 11011 -13060 11036
--13180 11063 -13310 11099 -13450 11136 -13630 11182 -13790 11230 -13980 11280
--14160 11332 -14350 11385 -14580 11446 -14810 11514 -15060 11583 -15310 11650
--15530 11709 -15760 11768 -16010 11835 -16280 11904 -16540 11969 -16780 12026
--16990 12073 -17200 12114 -17400 12155 -17620 12192 -17800 12222 -17960 12239
--18080 12243 -18180 12237 -18270 12224 -18320 12200 -18350 12165 -18350 12120
--18320 12064 -18250 11997 -18160 11915 -18010 11822 -17850 11715 -17660 11601
--17460 11487 -17230 11366 -16950 11229 -16638 11074 -16298 10917 -15952 10760
--15621 10613 -15283 10470 -14905 10312 -14495 10144 -14075 9978 -13684 9825
--13328 9693 -12988 9574 -12631 9451 -12261 9329 -11906 9217 -11600 9130
--11350 9067 -11140 9026 -10944 8996 -10759 8976 -10615 8977 -10527 9005
--10505 9060 -10536 9138 -10610 9239 -10728 9366 -10896 9516 -11126 9688
--11404 9879 -11741 10092 -12141 10338 -12601 10611 -13115 10908 -13674 11217
--14263 11532 -14889 11859 -15593 12221 -16359 12610 -17167 13012 -17991 13412
--18810 13803 -19648 14193 -20548 14607 -21504 15042 -22479 15477 -23434 15894
--24354 16287 -25255 16665 -26239 17067 -27189 17449 -28099 17812 -28983 18158
--29847 18481 -30692 18785 -31517 19069 -32276 19325 -32987 19552 -33642 19751
--34237 19926 -34784 20065 -35286 20170 -35703 20246 -36028 20303 -36277 20321
--36461 20270 -36571 20189 -36597 20120 -36530 20038 -36325 19881 -36021 19613
--35701 19322 -35377 19128 -34773 18984 -33858 18747 -33077 18315 -32612 17637
--31866 16858 -30158 16334 -27848 16340 -26235 16765 -26241 17288 -27497 17625
--28619 17530 -27562 16599 -22975 14056 -14032 7240 4557 6767 5483 4902
-3908 5574 5239 5560 3584 3892 4501 4171 3155 5251 3040 5045 3137 5365 3090 5184
-3215 5385 1937 5987 -72 7198 2028 7566 9597 5209 13669 4215 13875 4821
-10189 6985 4180 8944 7186 692 15593 301 20847 12508 16173 12398 -3021 5420
--4922 7768 -7970 6249 -3665 4855 -2561 -4620 -7365 -5224 -5666 338 -5812 1567
--4423 1001 -3969 1430 -4070 1277 -4890 1664 -4481 2604 -4689 2528 -2959 2450
--5093 2582 -5510 3135 -4984 3227 -5980 3256 -5529 3410 -5168 3036 -5134 3592
--6648 4224 -6981 4851 -5838 5053 -3635 4847 -8522 1397 -6775 1649 -4197 3798
--3842 4163 -4776 4058 -5797 3828 -5181 4366 -5489 5509 -6220 6080 -7049 5560
--7106 4904 -4781 5573 -1260 5026 2 6748 1781 7364 2957 7636 3495 7591 3175 7133
-1343 6421 -2930 5916 -8480 5992 -7141 6068 -7818 6633 -9100 6513 -9598 6598
--9449 6126 -7731 5100 -1863 3561 -1214 3365 -2540 3509 -4081 3690 -4935 3849
--4604 3818 -2262 3694 -1706 3741 -2126 3928 -2770 4177 -3292 4456 -3562 4766
--3584 5176 -3348 5729 -2906 6453 -2695 7351 -3951 8335 -3666 8754 -3757 8753
--3354 8183 -4865 9392 -5406 9747 -5993 9945 -5867 8491 -7893 9099 -10123 9380
--8192 8841 -8310 9276 -7580 9172 -4445 8060 -6570 7766 -9024 7148 1252 11126
-25874 18066 58038 28952 71974 37614 34873 36929 -11588 28881 -66149 16124
--136727 -387 -197086 -10648 144882 24801 80364 15983 46016 11559 33155 8970
-12619 -3704 4984 -7691 1597 -1083 -7588 5814 -8116 23965 -30628 12431
--11586 10751 -8699 4735 -2000 3148 5442 7835 -28533 6057 -32665 5132 -33335 1586
--36070 -4669 -43453 -13558 -48428 -20441 -33435 -15042 -11228 -1509 9927 17405
-43387 49821 16776 25618 -900 9695 -6178 6321 -33903 -5037 -37269 -13216
--34938 -24427 -38349 -42618 -50983 -69183 -70849 -100463 -79059 -95675
--63749 -30082 31527 80480 21198 75362 -45542 36395 -128071 7279 -42062 -50125
--12483 -55942 -41887 5651 -4169 65313 235958 169947 93955 97667 -53811 9481
-22508 7083 31343 7889 7682 -9309 -9070 -21403 5481 -16220 -28128 -18609
--64926 -23604 -63751 -12045 -16124 17538 -32082 14352 -2336 36717 -35003 3935
--11612 27262 -13389 12749 -14894 1303 -15804 -8028 -15192 -13140 574 12971
-14142 5852 -1681 5202 -13825 -4889 -4946 -8864 6452 18980 22720 9253 20877 2312
-14223 -5133 -2907 -9294 -35705 -9401 -92030 -3614 -151118 11734 -211723 38705
--64806 33466 -19672 33301 -2757 31947 -6420 29238 -539 26252 -10902 32186
--8302 33826 -2109 34017 1499 34539 2679 35778 -1265 38226 -13529 40002
--13567 33213 -16578 32905 -12125 31967 3152 32270 4281 32291 -16456 28619
--32161 25779 -44124 24205 -51682 24942 -51771 25793 -39897 21865 -25540 17405
--18495 16308 -17197 18393 -21690 15469 -23240 8638 -22752 1533 -15581 -4243
--808 -10732 16341 -14949 26670 -8931 30664 -3453 31339 -808 30931 -262
-30641 -1058 31062 -2924 32473 -5793 34760 -9500 37342 -13606 39500 -17453
-40639 -20296 40451 -21429 38923 -20305 36207 -16655 32575 -10606 28242 -2744
-23349 5902 17984 13991 12247 20133 6341 23238 616 22901 -4519 19673 -8540 14875
--10728 9841 -10254 5676 -6337 3228 1532 3309 13643 6624 30068 13510 49898 23501
-68359 34094 67737 39240 31214 27151 -8461 12392 -34026 2402 -45117 -2345
--46555 -3474 -42887 -2589 -37191 -798 -31237 1234 -25884 3147 -21449 4778
--17933 6080 -15188 7073 -13059 7804 -11372 8335 -9983 8717 -8806 8997
--7769 9208 -6830 9378 -5961 9521 -5143 9653 -4372 9780 -3642 9908 -2968 10039
--2343 10176 -1767 10320 -1247 10470 -779 10628 -366 10794 -13 10967 290 11149
-540 11335 737 11526 877 11721 981 11915 1034 12108 1044 12300 1012 12486
-945 12667 845 12838 712 13001 554 13152 375 13290 165 13417 -62 13531 -299 13632
--557 13718 -826 13791 -1105 13849 -1396 13893 -1686 13927 -1994 13951
--2301 13966 -2593 13972 -2880 13970 -3159 13955 -3449 13928
-114: 11484950 -5454737 -6790 9267 -6790 9249 -6800 9231 -6820 9211 -6840 9189
--6840 9165 -6850 9142 -6870 9117 -6880 9090 -6890 9065 -6910 9036 -6920 9006
--6930 8979 -6940 8949 -6960 8921 -6970 8888 -6990 8857 -6990 8827 -7010 8801
--7030 8775 -7030 8747 -7040 8721 -7070 8694 -7070 8671 -7090 8652 -7110 8639
--7130 8625 -7140 8610 -7160 8599 -7180 8595 -7210 8594 -7240 8597 -7280 8602
--7300 8613 -7340 8629 -7390 8645 -7450 8672 -7500 8701 -7570 8737 -7630 8778
--7710 8824 -7800 8874 -7890 8923 -7980 8981 -8090 9044 -8200 9112 -8330 9183
--8460 9258 -8600 9330 -8730 9404 -8870 9484 -9030 9569 -9200 9656 -9360 9739
--9510 9815 -9670 9895 -9830 9975 -10000 10057 -10180 10135 -10340 10211
--10490 10279 -10640 10344 -10800 10406 -10940 10466 -11070 10523 -11210 10575
--11340 10622 -11450 10663 -11560 10699 -11640 10728 -11750 10757 -11830 10778
--11910 10806 -11980 10824 -12050 10837 -12090 10843 -12140 10849 -12190 10855
--12250 10865 -12300 10874 -12350 10879 -12390 10884 -12420 10884 -12480 10892
--12550 10905 -12610 10922 -12700 10938 -12780 10954 -12850 10976 -12960 11003
--13080 11028 -13200 11067 -13350 11104 -13500 11153 -13680 11200 -13850 11251
--14030 11301 -14230 11357 -14430 11418 -14680 11487 -14920 11556 -15150 11622
--15390 11681 -15600 11741 -15860 11809 -16120 11876 -16380 11941 -16620 11997
--16820 12045 -17030 12085 -17240 12126 -17440 12160 -17630 12193 -17780 12210
--17900 12211 -18000 12204 -18090 12194 -18140 12167 -18170 12133 -18170 12088
--18130 12032 -18080 11965 -17980 11885 -17850 11788 -17670 11682 -17500 11571
--17290 11456 -17060 11337 -16800 11200 -16490 11046 -16151 10890 -15816 10734
--15492 10588 -15159 10445 -14791 10290 -14390 10123 -13979 9958 -13598 9807
--13252 9676 -12922 9556 -12574 9436 -12214 9313 -11872 9204 -11577 9115
--11338 9054 -11137 9013 -10950 8981 -10778 8963 -10648 8963 -10568 8989
--10554 9043 -10596 9118 -10677 9218 -10804 9342 -10980 9488 -11212 9658
--11500 9844 -11841 10053 -12243 10294 -12708 10562 -13225 10853 -13784 11156
--14371 11463 -14997 11785 -15698 12139 -16463 12520 -17266 12913 -18083 13306
--18897 13687 -19730 14067 -20618 14474 -21569 14899 -22534 15323 -23476 15731
--24384 16116 -25274 16484 -26251 16877 -27183 17249 -28084 17604 -28946 17938
--29803 18256 -30637 18552 -31444 18824 -32195 19072 -32890 19292 -33535 19486
--34119 19653 -34658 19787 -35149 19885 -35551 19960 -35870 20013 -36118 20021
--36296 19966 -36403 19887 -36420 19819 -36348 19738 -36144 19567 -35832 19289
--35532 19013 -35208 18833 -34568 18682 -33654 18441 -32941 18000 -32524 17289
--31700 16503 -29855 16037 -27506 16076 -26004 16448 -26200 16883 -27888 17194
--29486 17110 -29417 16079 -26727 13410 -18929 8736 7184 6149 9583 4762
-2325 5951 2821 5207 4488 5066 4370 4936 3887 4965 3304 4961 2818 5480 3943 5022
-4725 5442 4396 5202 1185 7129 1833 7284 7732 5369 13261 3588 15783 3404
-12750 6306 -383 15570 5589 -1300 20306 -5032 19627 20057 11834 14479 -881 7506
--6278 6546 -7167 5612 -5959 3112 -6066 -2527 -9211 -3625 -9713 -560 -5049 2699
--3578 897 -3656 1167 -3390 1891 -4286 1710 -5145 2078 -5393 1756 -2027 2433
--4301 3571 -4771 3847 -6378 3968 -6790 3945 -4130 2449 -4061 2562 -4116 3246
--4860 4265 -5732 5052 -5021 5189 -4376 4488 -6586 2467 -6166 2100 -4137 3171
--2972 3733 -3682 3863 -5822 3868 -6182 4103 -6090 5796 -6826 6185 -6356 6464
--8898 4357 -6579 5958 -2800 5198 2260 6987 2506 7382 2723 7783 3014 7917
-3039 7437 2163 6521 -548 5894 -6247 6393 -5404 6604 -7394 7137 -8037 6801
--8677 6971 -9806 6576 -10186 5482 483 2826 985 2435 -575 2606 -2168 2899
--3003 3090 -2988 3112 -2138 3114 -1982 3254 -2494 3542 -3289 3910 -4066 4283
--4640 4638 -4912 5014 -4791 5490 -4079 6152 -2810 7107 -4385 8566 -2968 9262
--1622 8430 -1658 7992 -3344 8174 -2978 8596 -3788 8900 -4860 8324 -6606 8582
--7912 8865 -7380 8846 -6895 9061 -5698 8995 -3361 8388 -2690 8313 -267 9226
-10226 13370 28885 20414 48502 29395 55001 36386 38535 38011 15226 34839
--7218 27580 -36000 8403 -107183 -1218 89625 19022 -35165 4226 -9120 9089
-18363 19334 -8411 -4230 -3877 -10225 6295 -4223 15779 6648 17592 19235
--95085 360 -8872 16122 -7128 7168 -6527 915 -7259 4898 -25024 4572 -31321 3485
--34021 -148 -37669 -6067 -53320 -18832 -73312 -34495 -44156 -25010 -11040 -8344
-1941 5773 94513 94837 17939 27750 -5463 9661 -22721 -4231 -64439 -27074
--53635 -32784 -43970 -43507 -45166 -60224 -52557 -74302 -60986 -86783
--68529 -81724 -78288 -2219 119854 205977 82993 146294 17399 67079 -55005 902
--337413 -224192 -234075 -115324 -59696 6629 -41591 32752 516263 248055
-174340 82855 -134250 -99178 48488 67320 21920 30189 -1414 11054 -44628 -16427
-26189 2799 -29640 -6872 -88611 -31350 -88845 -25719 41104 37347 -55609 -13677
-49158 63684 -60000 -33923 16643 54937 -7154 11427 -13605 -6107 -19282 -26457
--31986 -65858 -24569 -64538 37046 67758 25082 54752 8728 28871 7640 16022
-13770 19151 22154 12387 22713 4269 17388 -3952 4196 -10229 -18680 -13302
--51134 -11381 -89739 -59 -198013 41801 -107408 41611 -40102 37424 -10467 33040
--9519 28124 -8552 25570 -6374 29595 -4298 30933 347 31329 3833 31890 4133 32988
--723 34456 -10587 34640 -17161 30666 -20447 29153 -18674 28455 -12836 29176
--13557 30083 -24073 29379 -34749 28166 -42868 27059 -47083 26468 -45898 25540
--38728 22936 -30023 20186 -24578 18838 -22980 18293 -24198 15365 -24037 9967
--21231 3913 -13869 -1650 -2013 -6966 10808 -10815 20323 -9526 25800 -6712
-28392 -4553 29433 -3477 29927 -3351 30509 -4075 31545 -5624 33083 -7917
-34814 -10702 36289 -13536 37046 -15859 36825 -17071 35603 -16646 33534 -14238
-30845 -9807 27705 -3703 24149 3316 20114 10194 15520 15790 10416 19178
-5015 19943 -228 18341 -4660 15188 -7445 11522 -7699 8351 -4684 6561 2034 6870
-12405 9723 25691 15054 39738 21914 49779 27955 44504 30301 22649 23845
--3160 14415 -22699 6666 -33311 2041 -36647 170 -35375 154 -31815 1161
--27523 2591 -23377 4073 -19775 5411 -16818 6519 -14456 7391 -12574 8045
--11060 8530 -9801 8883 -8713 9142 -7751 9340 -6883 9497 -6067 9631 -5297 9752
--4576 9868 -3887 9985 -3249 10108 -2655 10234 -2105 10368 -1609 10509
--1161 10656 -761 10812 -415 10973 -117 11143 130 11315 327 11494 474 11673
-586 11853 641 12032 665 12209 645 12382 594 12549 508 12709 395 12860 252 13000
-84 13130 -105 13249 -310 13357 -534 13452 -771 13535 -1024 13605 -1287 13662
--1558 13705 -1835 13740 -2128 13765 -2417 13782 -2694 13791 -2969 13792
--3237 13780 -3511 13758
-115: 11515640 -5445835 -6940 9312 -6940 9298 -6960 9282 -6980 9262 -7000 9242
--7010 9218 -7020 9200 -7040 9176 -7050 9153 -7070 9125 -7090 9102 -7110 9075
--7120 9048 -7140 9023 -7150 8993 -7180 8964 -7180 8936 -7200 8905 -7220 8883
--7240 8858 -7260 8830 -7260 8806 -7280 8781 -7300 8758 -7320 8740 -7340 8726
--7360 8710 -7380 8698 -7390 8688 -7430 8684 -7450 8680 -7470 8681 -7520 8689
--7540 8697 -7580 8711 -7630 8727 -7690 8753 -7740 8778 -7800 8811 -7870 8852
--7940 8892 -8020 8942 -8120 8986 -8200 9040 -8310 9101 -8420 9166 -8540 9234
--8680 9304 -8790 9372 -8930 9442 -9060 9520 -9220 9600 -9380 9681 -9530 9762
--9680 9835 -9830 9909 -9990 9985 -10150 10064 -10310 10138 -10470 10211
--10620 10275 -10760 10336 -10890 10393 -11040 10455 -11170 10507 -11290 10555
--11410 10600 -11520 10638 -11600 10671 -11700 10702 -11790 10725 -11850 10747
--11940 10772 -12000 10792 -12050 10802 -12100 10805 -12120 10813 -12180 10819
--12220 10827 -12270 10835 -12310 10843 -12340 10844 -12370 10847 -12420 10856
--12490 10869 -12550 10886 -12610 10904 -12690 10922 -12780 10942 -12870 10970
--12980 10996 -13100 11034 -13240 11074 -13400 11122 -13560 11172 -13730 11222
--13910 11273 -14100 11330 -14310 11389 -14540 11457 -14790 11529 -15010 11594
--15240 11655 -15470 11714 -15710 11781 -15970 11847 -16220 11913 -16460 11969
--16670 12016 -16870 12056 -17070 12096 -17260 12132 -17460 12161 -17620 12178
--17730 12181 -17820 12176 -17910 12162 -17960 12135 -18000 12101 -17990 12057
--17960 12000 -17910 11936 -17810 11853 -17670 11757 -17510 11652 -17330 11540
--17130 11428 -16910 11309 -16650 11171 -16330 11022 -16020 10864 -15680 10710
--15362 10565 -15041 10424 -14681 10270 -14287 10105 -13889 9941 -13516 9792
--13177 9660 -12858 9544 -12522 9423 -12170 9303 -11841 9192 -11557 9106
--11330 9043 -11136 9004 -10959 8972 -10800 8953 -10678 8954 -10612 8977
--10604 9030 -10656 9102 -10746 9201 -10877 9323 -11064 9465 -11302 9631
--11593 9814 -11938 10018 -12344 10255 -12812 10516 -13331 10802 -13892 11097
--14478 11400 -15104 11714 -15799 12061 -16563 12433 -17360 12818 -18173 13202
--18979 13575 -19802 13946 -20687 14343 -21625 14758 -22578 15173 -23511 15571
--24411 15944 -25285 16305 -26248 16687 -27175 17049 -28056 17396 -28906 17722
--29748 18030 -30574 18315 -31361 18576 -32104 18820 -32784 19030 -33412 19215
--33983 19376 -34522 19502 -34997 19592 -35391 19665 -35699 19714 -35938 19712
--36106 19653 -36211 19574 -36224 19505 -36143 19415 -35939 19229 -35613 18947
--35324 18685 -35001 18501 -34326 18338 -33411 18103 -32753 17651 -32353 16918
--31470 16144 -29566 15696 -27198 15678 -25644 15891 -25754 16169 -27292 16396
--28615 16264 -28443 15184 -25228 12725 -16431 9235 57 6670 4925 5550 2248 5987
-1933 5894 2814 5959 3202 5819 4144 4939 3181 5094 2805 5640 4772 5139 4533 5707
-3880 5236 1908 6439 2405 6596 6571 5157 12948 2611 18011 874 19946 -746
--3320 17671 7745 9485 50345 -61 -4924 23004 1347 11663 -2798 9813 -5249 2769
--6999 3063 -7391 2233 -7809 -304 -8784 -1207 -8198 25 -7493 2028 -5581 1589
--4890 1494 -3242 2874 -4477 1656 -4940 2230 -5494 1548 -3923 2134 -4866 3913
--5529 3978 -4502 3900 -5265 3607 -4247 2805 -4169 2972 -4052 3553 -3723 3785
--5020 5288 -4515 5167 -4181 4459 -4999 3460 -5513 2652 -3653 2973 -1405 3581
--1938 3954 -6542 4427 -7280 4701 -6273 5256 -6580 6675 -5381 6681 -10247 3869
--7967 5199 -5205 4778 5431 7612 1825 6856 1504 7587 1823 8185 2523 7729
-3217 6458 3789 5310 -2965 6294 -3337 7020 -6635 7496 -6056 7122 -5101 7244
--5408 6603 -7267 5019 -1918 3110 -139 2420 -534 2328 -1431 2502 -1940 2569
--2143 2592 -2121 2682 -2465 2911 -3254 3266 -4272 3671 -5294 4040 -6160 4347
--6786 4641 -7167 5016 -7294 5594 -6807 6492 -1447 7964 -415 8603 184 8031
--126 5942 -84 8130 -552 8323 -1333 8318 -3490 7943 -5133 8035 -5852 8260
--5510 8386 -4645 8574 -3249 8664 -1363 8618 568 9087 4449 10949 12945 15398
-25536 22171 37551 29781 42044 35579 35730 37570 24264 35427 10376 28747
--11296 15953 -42401 8451 11453 12254 -42365 4958 -21086 7697 31419 37169
--34045 -9910 -14643 -14301 -1966 -8805 -860 -1468 -26735 -3519 -91200 -17032
-26353 39237 12962 23690 -7190 3105 -16265 3528 -21285 4117 -24914 3533
--28926 -470 -27578 -2382 -51362 -17253 -110710 -51993 -44519 -26389 9791 -15
--52397 -43782 172044 166398 -30322 -12928 -3535 16880 -83118 -34040 -60778 -28147
--39715 -31660 -32291 -45325 -39838 -65538 -47413 -62916 -46717 -50430
--50344 -41923 -31741 20419 147945 276765 67583 144156 -30016 8803 -153063 -117307
--331443 -256729 -134314 -43385 -35511 44369 -54554 17489 420274 173421
-301795 97439 -80032 -14515 -46835 30173 -145555 -82588 74662 88019 -97948 -18228
-83655 30574 -7204 17105 -92282 -34001 -140318 -52551 154157 90033 -157465 -99368
-123063 90498 -104834 -81680 72669 116735 -11295 13598 -16130 -6394 -22640 -31518
--26064 -58280 -13384 -42802 23771 38482 27327 52950 19878 41337 16856 29474
-18601 23486 21845 15848 21679 7401 16988 -1097 6309 -8265 -11989 -12235
--39659 -9935 -79481 2798 -137649 29596 -100994 37636 -40935 36261 -11371 32850
--14343 26217 -14101 24343 -10121 25740 -5745 26669 -1110 27114 1812 27528
-1263 28060 -3718 28433 -12059 27855 -19626 25783 -24371 24807 -25596 25147
--24409 27032 -25024 29845 -29690 31514 -35447 31636 -40095 30652 -42259 29123
--41054 27123 -36697 24546 -31391 22035 -27510 20084 -25678 18194 -25074 15053
--23557 10492 -19857 5358 -13107 396 -3687 -4102 6351 -7376 14754 -8028
-20676 -7184 24383 -6070 26543 -5235 27834 -4831 28790 -4921 29806 -5571
-31013 -6805 32284 -8515 33341 -10445 33842 -12207 33589 -13333 32587 -13347
-30997 -11871 29028 -8745 26804 -4120 24311 1490 21375 7278 17806 12319
-13510 15811 8627 17316 3555 16885 -1035 15027 -4287 12517 -5328 10211
--3478 8900 1566 9181 9542 11326 19388 15104 28913 19598 34566 23115 29370 24620
-15671 21038 -951 15100 -14873 9518 -23655 5626 -27502 3594 -27771 3026
--25951 3399 -23217 4255 -20314 5275 -17634 6266 -15347 7124 -13451 7822
--11894 8363 -10605 8771 -9502 9074 -8538 9301 -7673 9476 -6879 9616 -6128 9737
--5416 9846 -4740 9953 -4099 10061 -3497 10172 -2940 10290 -2418 10414
--1943 10545 -1515 10681 -1134 10827 -796 10976 -505 11134 -267 11295 -64 11459
-83 11626 196 11792 264 11957 291 12122 286 12281 249 12436 174 12585 76 12724
--54 12856 -207 12977 -378 13088 -564 13191 -772 13281 -994 13360 -1227 13427
--1472 13481 -1728 13526 -1993 13559 -2271 13586 -2541 13604 -2809 13616
--3066 13618 -3322 13611 -3583 13591
-116: 11546380 -5436944 -7080 9355 -7090 9342 -7110 9327 -7130 9309 -7150 9295
--7170 9274 -7190 9254 -7200 9232 -7220 9210 -7240 9185 -7260 9162 -7290 9142
--7290 9114 -7320 9090 -7340 9062 -7370 9038 -7380 9009 -7390 8981 -7420 8957
--7440 8936 -7460 8910 -7470 8888 -7500 8862 -7510 8842 -7530 8824 -7560 8810
--7580 8794 -7600 8780 -7620 8773 -7640 8766 -7680 8762 -7700 8764 -7740 8772
--7770 8776 -7810 8791 -7860 8805 -7900 8827 -7960 8854 -8030 8883 -8090 8919
--8160 8959 -8230 9003 -8340 9047 -8410 9098 -8510 9157 -8630 9219 -8740 9282
--8860 9349 -8990 9413 -9110 9480 -9250 9553 -9400 9629 -9540 9707 -9690 9783
--9840 9855 -9980 9923 -10130 9997 -10300 10070 -10440 10143 -10600 10210
--10730 10271 -10860 10331 -11000 10386 -11130 10441 -11260 10490 -11370 10536
--11470 10578 -11580 10616 -11660 10648 -11750 10675 -11820 10696 -11890 10717
--11950 10741 -12020 10758 -12060 10768 -12090 10772 -12120 10779 -12160 10783
--12200 10791 -12250 10801 -12270 10806 -12300 10808 -12320 10813 -12370 10821
--12420 10835 -12480 10851 -12550 10868 -12610 10889 -12700 10910 -12780 10937
--12890 10968 -13010 11003 -13150 11044 -13290 11092 -13450 11142 -13630 11194
--13800 11245 -13980 11301 -14190 11361 -14420 11431 -14650 11502 -14880 11566
--15110 11627 -15320 11686 -15570 11753 -15830 11821 -16080 11885 -16310 11940
--16510 11989 -16710 12026 -16910 12066 -17100 12103 -17300 12130 -17450 12148
--17560 12151 -17650 12145 -17740 12130 -17790 12105 -17820 12069 -17830 12026
--17790 11969 -17740 11904 -17630 11823 -17510 11728 -17350 11623 -17160 11512
--16980 11401 -16750 11282 -16500 11147 -16200 10997 -15870 10841 -15550 10688
--15240 10544 -14930 10405 -14571 10252 -14189 10089 -13801 9927 -13435 9778
--13106 9651 -12799 9534 -12470 9413 -12131 9294 -11812 9185 -11537 9100
--11320 9039 -11140 8997 -10973 8968 -10824 8947 -10709 8946 -10657 8971
--10658 9019 -10715 9092 -10813 9188 -10955 9307 -11145 9447 -11392 9609
--11687 9787 -12030 9988 -12444 10218 -12915 10475 -13436 10754 -13995 11044
--14582 11340 -15206 11647 -15899 11985 -16655 12351 -17452 12726 -18257 13101
--19054 13466 -19871 13829 -20747 14215 -21676 14621 -22619 15024 -23539 15413
--24425 15777 -25292 16127 -26239 16498 -27149 16851 -28019 17187 -28857 17505
--29685 17802 -30495 18078 -31270 18332 -32001 18563 -32664 18764 -33280 18942
--33844 19096 -34363 19213 -34831 19296 -35213 19362 -35513 19404 -35740 19393
--35906 19329 -35993 19246 -36008 19177 -35923 19077 -35707 18878 -35368 18591
--35095 18334 -34757 18136 -34053 17966 -33150 17735 -32515 17274 -32107 16537
--31213 15782 -29319 15323 -26973 15181 -25237 15190 -25042 15299 -25979 15444
--26718 15277 -26228 14232 -22822 12067 -15344 9311 -5152 7172 -244 6265
-148 6402 459 6517 1150 6444 2080 6005 3379 5237 3714 5114 3687 5401 4102 5465
-3455 5896 2658 5928 1861 6379 2281 6306 4609 5428 10458 3059 13003 4541
-14520 2567 8116 6464 12258 6370 32450 7124 6786 15914 5952 11039 -87 9870
--4616 6170 -7252 5164 -8307 4215 -8682 2680 -8783 1657 -8164 1530 -7447 1990
--6047 2591 -5248 2578 -5108 1821 -5395 1575 -5406 2685 -5347 2279 -4864 2526
--5368 3672 -5896 3409 -2892 3491 -4558 3327 -4520 3133 -4669 3670 -4789 4804
--3763 4280 -4334 4800 -3917 4803 -3687 4393 -3848 4331 -5748 3018 -3658 3015
-400 3804 558 4120 -8347 4916 -8825 4862 -6614 4071 -7223 5551 -6614 3854
--7380 5601 -5351 6328 -580 6432 5613 7636 -3035 4971 -886 6817 -191 8253
-957 7759 2213 6417 5742 4913 1806 5155 -410 7081 -3495 7909 -2782 7602
-260 7098 1036 6777 -4946 4843 -2693 3615 -1135 2994 -1109 2604 -1404 2542
--1533 2405 -1797 2394 -2238 2523 -3045 2777 -4192 3099 -5487 3422 -6734 3685
--7793 3875 -8557 4059 -8948 4343 -8752 4841 -7262 5634 -3037 6706 -451 7400
-1086 7351 1797 6784 1950 6869 1326 7451 1568 7717 -2258 7212 -3626 7219
--3730 7438 -3187 7609 -2036 7798 -629 8030 682 8447 2348 9555 5326 12216
-10646 17052 17906 23511 24635 30035 27518 34700 25057 36241 18811 34298
-9339 28826 -4944 20528 -19847 14642 -11134 13413 -28027 10998 -16274 13305
-2899 13352 -15689 2374 -16907 -8623 -8858 -6547 -7566 2214 -24058 312
--39968 -484 10046 21642 -6285 8515 -16175 769 -25723 4786 -18452 4539
--18627 3830 -26450 -3381 -10812 3446 -28280 -4349 -163863 -72911 -22163 -9114
-99100 69993 -117453 -83322 106203 100784 -159770 -117588 -10068 28886
--43882 3030 -6176 6508 -3345 -8632 -5143 -26207 -26423 -64919 -41704 -54718
--34342 -7715 -37725 -4468 -51702 -7440 76275 169915 104597 213104 -33568 10262
--144383 -129085 -221489 -209339 -88281 -51787 -62130 27663 -13312 32356
-238996 113642 210715 88232 7957 35743 -43077 32643 -63627 3343 -5029 3725
--116807 -61227 -46135 250 93479 48335 23953 15462 -56638 -28201 -4324 53334
--9924 -27453 34824 10325 -3315 7787 -19841 33784 -31027 5796 -26611 -8534
--24693 -24343 -17952 -40786 -5554 -24626 15083 19419 22401 38593 21185 38086
-19404 31572 19284 25242 19625 18316 18164 10815 13629 2850 4761 -4611
--10084 -9545 -33394 -7901 -64943 2502 -95862 19828 -82347 30531 -25783 32024
--7419 33519 -15216 22105 -19061 21657 -14767 21699 -9160 22011 -4423 22202
--1944 22298 -2971 22235 -7877 21788 -15306 20884 -22808 19865 -28580 19882
--32025 21483 -33067 24882 -32174 30779 -32733 34891 -34712 35982 -36798 34759
--37757 32282 -36870 29274 -34282 26128 -31057 23213 -28352 20625 -26527 17986
--25058 14693 -22809 10641 -18935 6254 -13013 2014 -5428 -1748 2666 -4587
-9978 -5991 15807 -6314 20049 -6127 22961 -5794 24908 -5493 26301 -5349
-27479 -5483 28621 -5990 29704 -6880 30549 -8043 30916 -9251 30669 -10168
-29836 -10397 28588 -9566 27130 -7437 25578 -4015 23884 394 21831 5197
-19150 9658 15657 13084 11403 15029 6707 15414 2187 14528 -1362 12940 -3127 11331
--2488 10358 769 10506 6338 11958 13186 14483 19511 17369 22941 19513 19098 20741
-10437 18782 -206 15092 -9749 11251 -16449 8241 -20044 6388 -21105 5581
--20494 5529 -18996 5934 -17177 6544 -15366 7201 -13728 7805 -12309 8315
--11098 8725 -10050 9042 -9128 9283 -8305 9468 -7543 9615 -6830 9736 -6151 9840
--5492 9938 -4872 10033 -4278 10132 -3719 10235 -3196 10342 -2705 10457
--2249 10577 -1848 10705 -1483 10838 -1157 10978 -875 11123 -642 11272
--442 11425 -291 11578 -181 11732 -108 11885 -68 12036 -66 12185 -95 12327
--155 12466 -243 12596 -358 12717 -495 12831 -650 12935 -823 13032 -1013 13117
--1220 13192 -1436 13256 -1659 13310 -1908 13352 -2160 13386 -2415 13413
--2678 13432 -2930 13446 -3172 13450 -3416 13445 -3664 13431
-117: 11577150 -5428060 -7210 9396 -7230 9383 -7250 9371 -7280 9357 -7300 9339
--7310 9322 -7340 9305 -7360 9285 -7380 9265 -7390 9245 -7430 9220 -7450 9201
--7470 9177 -7490 9154 -7520 9130 -7540 9104 -7560 9077 -7580 9055 -7610 9030
--7630 9009 -7650 8986 -7670 8964 -7700 8940 -7710 8921 -7740 8903 -7760 8890
--7790 8875 -7800 8861 -7820 8851 -7860 8845 -7880 8842 -7920 8841 -7950 8849
--7990 8854 -8020 8865 -8060 8878 -8120 8900 -8160 8924 -8240 8951 -8300 8985
--8360 9020 -8440 9066 -8530 9106 -8610 9154 -8710 9210 -8820 9269 -8930 9329
--9050 9389 -9160 9452 -9290 9517 -9420 9587 -9560 9657 -9700 9733 -9850 9805
--9980 9873 -10130 9937 -10270 10008 -10420 10078 -10570 10149 -10710 10211
--10840 10269 -10970 10324 -11090 10378 -11220 10431 -11340 10475 -11440 10517
--11540 10559 -11630 10596 -11720 10624 -11790 10648 -11860 10672 -11910 10691
--11980 10708 -12030 10726 -12070 10737 -12090 10741 -12120 10746 -12140 10749
--12180 10757 -12220 10767 -12240 10772 -12260 10774 -12280 10778 -12310 10787
--12370 10802 -12420 10818 -12490 10836 -12540 10855 -12620 10879 -12710 10906
--12800 10938 -12930 10974 -13050 11016 -13200 11062 -13350 11114 -13520 11165
--13690 11218 -13880 11273 -14070 11334 -14300 11402 -14530 11474 -14760 11542
--14980 11599 -15190 11658 -15440 11725 -15680 11794 -15940 11857 -16160 11912
--16370 11958 -16550 11998 -16760 12037 -16950 12072 -17140 12100 -17280 12119
--17400 12121 -17490 12114 -17570 12099 -17620 12074 -17660 12039 -17660 11996
--17620 11939 -17570 11874 -17480 11793 -17340 11699 -17190 11595 -17010 11484
--16810 11375 -16610 11257 -16360 11122 -16050 10975 -15740 10820 -15430 10668
--15120 10527 -14810 10388 -14470 10237 -14090 10075 -13715 9915 -13359 9768
--13039 9642 -12741 9526 -12424 9407 -12095 9289 -11785 9182 -11523 9099
--11312 9036 -11146 8995 -10988 8965 -10848 8945 -10744 8943 -10699 8969
--10712 9013 -10776 9085 -10881 9180 -11031 9295 -11227 9431 -11480 9590
--11777 9765 -12125 9961 -12541 10186 -13015 10438 -13538 10711 -14096 10995
--14680 11284 -15304 11583 -15995 11914 -16746 12272 -17536 12638 -18335 13004
--19127 13360 -19933 13715 -20800 14090 -21720 14486 -22648 14879 -23560 15258
--24433 15612 -25290 15952 -26219 16309 -27115 16654 -27971 16980 -28803 17288
--29611 17574 -30407 17841 -31169 18084 -31878 18305 -32536 18497 -33137 18668
--33691 18811 -34192 18921 -34648 18996 -35021 19053 -35312 19088 -35525 19070
--35684 18993 -35764 18911 -35774 18833 -35685 18724 -35447 18513 -35118 18232
--34846 17961 -34480 17742 -33766 17569 -32871 17344 -32234 16874 -31807 16152
--30933 15428 -29152 14932 -26829 14636 -24945 14449 -24297 14412 -24477 14478
--24692 14271 -23920 13281 -20751 11385 -15047 9144 -8462 7465 -4366 6807
--2526 6894 -1305 6976 -268 6682 1017 5995 2608 5221 3582 4947 3635 5200
-3199 5690 2397 6325 2045 6598 2355 6451 3356 5556 5328 3893 8965 1660 13807 2397
-10078 4332 10007 5939 12396 6134 15945 7291 9834 10431 16213 7928 3384 11188
--4117 10404 -7515 9111 -8762 7781 -9005 6321 -8742 4928 -8008 3559 -7037 2301
--5849 3511 -5462 3140 -6539 1462 -6104 2278 -5883 3070 -5030 2486 -5070 2409
--5703 3195 -5015 3506 -4402 2550 -4034 3394 -5470 3297 -3573 3603 -4226 6145
--4871 5179 -4667 4784 -3943 4801 -4181 4535 -4340 4513 -5470 3724 -4498 3370
-536 4514 -728 4474 -6451 4394 -7539 3618 -5363 2441 -7042 4482 -6529 4128
--5665 5526 -3780 6919 980 6944 3221 7266 -2958 4558 -1789 5333 -1861 7711
--987 5890 2569 5721 7307 5369 4871 3504 2944 7090 102 7864 81 7396 2698 7794
-3623 7673 530 5480 -120 4776 -370 4266 -1370 3362 -1480 2979 -1291 2659
--1588 2611 -2379 2726 -3632 2890 -5184 3019 -6792 3122 -8237 3190 -9379 3230
--10106 3307 -10328 3516 -9839 3934 -8272 4565 -5421 5296 -2737 5888 1449 6977
-2545 7312 2392 6335 2709 6385 5230 7182 -1563 6209 -1806 6210 -1245 6506
--748 6655 694 6723 2103 6949 2298 7761 2683 9545 3460 13038 4860 18406
-7157 24670 9471 30313 10284 33969 8756 34925 5209 33088 -114 28761 -7094 22993
--12908 18360 -11331 16111 -12897 14655 -3218 14189 8468 11041 3088 9211
--3311 308 -20840 -1709 -15282 9622 -16023 6878 -17841 6434 -13701 -1127
--8330 -5725 -20261 -2153 -27412 8016 -21064 4392 -18617 -323 -22300 -7407
--22746 -8609 -43664 -14973 -88234 -31130 -12060 6214 46773 42354 -25419 -9501
-42641 50051 -138438 -97216 -31214 5242 -36262 -625 -15053 -8473 -6462 7432
-16819 19809 -2120 -34162 -30889 -105882 -66784 -10117 -41656 -962 -67337 -4406
--20215 45997 53072 141705 39715 138591 -80542 -58403 -166799 -195680
--70159 -49804 -62488 4718 -5189 39868 133482 91306 122236 68284 21921 42339
--49687 11190 -100045 -43016 46031 40121 -91304 -42887 3521 6603 -10939 14541
--25447 5510 -28226 -22237 -97274 22804 13722 2029 83305 26000 68551 36319
-22190 31470 -5546 12683 -14611 -1830 -15827 -13630 -10789 -21133 -1425 -11114
-10396 11706 16641 26171 17666 29347 17026 27236 16399 23662 15226 19159
-12798 13939 8559 7238 1917 -378 -7847 -7687 -24547 -7999 -45412 -940 -60633 10388
--51621 19998 -20336 27729 -6785 39342 -22221 19025 -22397 17555 -17328 17744
--11652 17697 -7560 17478 -5609 17218 -6942 16721 -12006 15608 -18896 14414
--26124 14047 -32397 14925 -37579 17628 -40424 21679 -36149 32699 -33168 39422
--32630 40823 -33283 38794 -33797 35161 -33402 31086 -32016 27180 -30106 23697
--28217 20590 -26527 17543 -24725 14219 -22201 10552 -18468 6785 -13352 3225
--7122 110 -453 -2346 5898 -3980 11396 -4913 15809 -5374 19151 -5534 21585 -5499
-23367 -5370 24790 -5277 26017 -5341 27074 -5650 27859 -6202 28197 -6900
-27999 -7535 27308 -7801 26298 -7367 25186 -5957 24095 -3474 22974 -71
-21596 3852 19663 7717 16933 10942 13359 13091 9183 14005 4920 13825 1272 12943
--1052 11876 -1493 11154 155 11163 3619 12056 8067 13664 12177 15501 14392 16875
-11999 17949 6608 16955 -141 14723 -6518 12177 -11400 9984 -14424 8459
--15776 7622 -15904 7339 -15289 7430 -14308 7726 -13212 8102 -12140 8480
--11159 8816 -10266 9097 -9457 9321 -8715 9498 -8029 9639 -7375 9754 -6745 9853
--6138 9940 -5545 10025 -4977 10111 -4429 10199 -3910 10292 -3422 10391
--2963 10496 -2538 10607 -2156 10725 -1806 10848 -1494 10977 -1229 11111
--999 11249 -804 11389 -657 11531 -546 11673 -463 11815 -419 11954 -412 12091
--432 12224 -479 12351 -556 12472 -660 12586 -777 12692 -923 12789 -1083 12879
--1259 12961 -1448 13031 -1645 13093 -1858 13144 -2092 13186 -2327 13219
--2570 13247 -2817 13267 -3056 13281 -3286 13288 -3518 13285 -3754 13274
-118: 11607970 -5419183 -7350 9432 -7360 9422 -7390 9412 -7410 9400 -7440 9384
--7450 9367 -7480 9353 -7500 9334 -7530 9317 -7550 9299 -7580 9277 -7610 9255
--7630 9237 -7660 9216 -7670 9193 -7710 9167 -7740 9144 -7760 9121 -7780 9100
--7810 9081 -7840 9057 -7860 9036 -7870 9015 -7910 8994 -7920 8979 -7960 8965
--7980 8949 -8000 8938 -8020 8926 -8040 8921 -8090 8918 -8120 8917 -8150 8921
--8190 8926 -8220 8938 -8250 8949 -8310 8969 -8370 8989 -8430 9018 -8490 9047
--8560 9081 -8620 9122 -8720 9164 -8800 9208 -8890 9260 -9000 9316 -9100 9373
--9220 9432 -9330 9491 -9450 9551 -9590 9618 -9710 9686 -9850 9757 -9990 9825
--10130 9893 -10260 9952 -10400 10018 -10540 10086 -10690 10154 -10820 10213
--10940 10267 -11070 10320 -11180 10369 -11300 10420 -11410 10462 -11520 10503
--11590 10543 -11700 10575 -11760 10601 -11830 10626 -11890 10646 -11940 10663
--12000 10680 -12040 10697 -12080 10705 -12090 10711 -12120 10715 -12130 10718
--12160 10726 -12190 10734 -12210 10739 -12230 10741 -12240 10747 -12270 10753
--12320 10769 -12360 10788 -12430 10803 -12480 10824 -12550 10849 -12630 10877
--12730 10907 -12850 10945 -12960 10988 -13110 11035 -13260 11085 -13430 11138
--13590 11191 -13770 11245 -13970 11308 -14180 11374 -14420 11446 -14640 11515
--14850 11572 -15070 11632 -15310 11697 -15550 11766 -15790 11830 -16030 11882
--16220 11931 -16410 11970 -16610 12007 -16810 12041 -16980 12069 -17120 12088
--17240 12092 -17330 12083 -17410 12068 -17460 12044 -17500 12010 -17490 11966
--17460 11909 -17410 11845 -17310 11765 -17190 11671 -17030 11566 -16850 11459
--16670 11349 -16460 11232 -16210 11100 -15920 10955 -15620 10800 -15300 10650
--15000 10511 -14710 10375 -14360 10223 -14000 10064 -13630 9905 -13287 9762
--12972 9635 -12690 9520 -12380 9405 -12060 9287 -11762 9182 -11509 9099
--11311 9037 -11150 8997 -11006 8965 -10874 8946 -10783 8945 -10743 8968
--10763 9013 -10838 9082 -10949 9174 -11103 9288 -11310 9420 -11566 9576
--11869 9747 -12218 9937 -12637 10158 -13112 10405 -13638 10672 -14191 10950
--14777 11231 -15396 11525 -16084 11846 -16831 12195 -17612 12553 -18405 12911
--19195 13258 -19992 13603 -20849 13969 -21755 14354 -22671 14738 -23571 15105
--24432 15450 -25278 15778 -26191 16126 -27073 16459 -27914 16773 -28737 17070
--29532 17348 -30307 17603 -31056 17837 -31751 18045 -32391 18230 -32983 18392
--33521 18526 -34018 18625 -34452 18690 -34811 18743 -35096 18766 -35297 18736
--35446 18658 -35513 18566 -35525 18481 -35430 18359 -35175 18144 -34849 17859
--34575 17572 -34192 17335 -33477 17155 -32580 16924 -31923 16458 -31455 15769
--30646 15080 -29011 14533 -26803 14093 -24848 13748 -23699 13591 -23231 13565
--23016 13298 -21962 12340 -19157 10675 -14993 8844 -10634 7581 -7315 7173
--4765 7271 -2779 7230 -1382 6696 -62 5775 1447 4899 2548 4562 2719 4930
-2245 5846 1780 6956 2171 7545 3570 6997 5365 5387 7261 3466 9283 1809 10622 1731
-7930 2714 9689 6213 9013 5454 7746 4863 11418 4731 24309 5531 2090 14131
--4798 14049 -7524 12677 -8539 11291 -8701 9949 -8379 8500 -7666 6490 -6627 3418
--5379 3387 -5093 2458 -7646 1935 -5900 3388 -5964 3944 -4169 2362 -4380 1955
--5614 3101 -5189 3172 -4334 2582 -4849 3076 -7719 3046 -2203 2132 -4699 6557
--4644 6962 -3937 5129 -4769 5301 -5178 4825 -4364 5195 -4611 4864 -3731 4461
--976 4546 -2214 4261 -6050 3833 -7210 2904 -3733 1416 -5008 2749 -5512 3653
--3538 4626 -2759 6958 -750 7100 -816 7192 -2674 5090 -86 3702 -640 6353
--2170 4052 1959 4159 7452 4579 7875 937 3294 6336 3714 8600 3220 7383 4713 8333
-6309 8217 5203 7346 3068 6819 1395 6393 -1709 4422 -1356 3737 -759 3359
--1205 3290 -2395 3341 -4128 3272 -6188 2990 -8147 2734 -9756 2557 -10894 2456
--11504 2471 -11533 2662 -10892 3069 -9483 3665 -7417 4367 -5044 5117 -1556 6069
-1763 6300 2624 6212 2077 5563 3714 6118 1457 5658 1677 5341 1824 5733 1339 5698
-3349 5418 5169 5397 3380 6601 2165 9010 237 13380 -2983 19578 -5661 25874
--7415 30829 -8943 33631 -10730 34044 -12566 32207 -13880 28534 -13957 23974
--11724 20179 -6537 18364 -275 18148 10787 18692 22237 17814 25401 15482
-18686 7288 -32560 -463 -15819 18956 -9621 5041 -15942 6522 -18225 2458
-1024 -25913 -21815 -6183 -32265 13095 -22344 664 -17706 -5567 -21327 -14865
--32195 -21522 -49694 -22274 -39722 -10 -4676 15516 10979 20585 -10681 -5515
--10236 -8567 -64938 -34314 49114 86407 -50668 -23966 -23747 -50584 -12117 10935
-9040 71165 -10622 17043 -66098 -164602 -63779 -14659 -52412 -6872 -68455 -2471
--52364 -8656 -28400 21270 122660 290895 -5923 31217 -108196 -155422 -117551 -119206
--19043 -2568 9083 67396 38723 52024 44220 23298 20990 42732 -2750 27024
--22687 -32921 -175763 -61827 -65227 -1298 121840 97089 27946 43962 -26742 -19326
--68845 -78654 -111085 -11302 -30921 -1739 42806 21326 94218 48001 56398 38507
-21087 21457 2540 7355 -3949 -1195 -3366 -5315 1801 -1026 7873 9419 11536 17702
-12316 19866 12069 20261 11632 19963 9606 18406 6583 16531 2884 11534 -1452 4416
--4056 -7479 -14313 -9503 -27201 -4785 -35141 2670 -30682 9175 -17535 15346
--13795 36459 -21568 25420 -21162 19631 -16452 16776 -11897 14907 -9693 13717
--8291 13120 -9671 12599 -15504 10851 -21871 9224 -28550 9578 -34702 10942
--41477 14765 -48293 15643 -36875 36184 -30963 44758 -29421 45180 -29870 41697
--30658 36786 -30923 31759 -30420 27213 -29348 23312 -27978 19916 -26411 16739
--24491 13526 -21906 10230 -18419 7001 -13966 4038 -8746 1480 -3135 -610
-2407 -2220 7494 -3409 11865 -4256 15408 -4793 18160 -5045 20257 -5058
-21921 -4927 23293 -4772 24431 -4705 25258 -4804 25643 -5066 25531 -5389
-24972 -5570 24136 -5330 23247 -4401 22442 -2625 21703 -34 20815 3114 19489 6392
-17436 9318 14553 11498 10989 12723 7133 13032 3565 12672 897 12029 -365 11506
--23 11421 1747 11910 4363 12886 6895 14042 8329 14954 7081 15872 3833 15454
--387 14168 -4587 12551 -8043 11034 -10446 9865 -11808 9118 -12329 8743
--12281 8646 -11885 8726 -11329 8893 -10709 9090 -10083 9280 -9469 9449
--8870 9590 -8296 9706 -7737 9805 -7183 9888 -6638 9965 -6100 10036 -5574 10108
--5057 10183 -4555 10261 -4079 10346 -3623 10436 -3198 10532 -2805 10634
--2436 10741 -2108 10855 -1819 10974 -1558 11098 -1337 11224 -1149 11354
--1006 11485 -892 11615 -811 11746 -765 11875 -745 12001 -763 12124 -795 12243
--863 12354 -957 12459 -1062 12558 -1195 12651 -1339 12734 -1501 12811
--1679 12878 -1859 12936 -2060 12986 -2278 13026 -2498 13060 -2728 13086
--2957 13107 -3193 13123 -3410 13131 -3624 13130 -3850 13122
-119: 11638830 -5410314 -7470 9467 -7490 9458 -7510 9450 -7550 9438 -7570 9426
--7590 9412 -7610 9397 -7640 9382 -7670 9367 -7690 9348 -7730 9330 -7760 9310
--7790 9292 -7800 9271 -7840 9253 -7860 9228 -7900 9206 -7930 9185 -7950 9166
--7970 9149 -8010 9126 -8030 9105 -8060 9083 -8080 9065 -8100 9048 -8130 9036
--8160 9021 -8190 9009 -8200 9000 -8240 8993 -8270 8988 -8300 8990 -8340 8991
--8370 8996 -8410 9003 -8440 9016 -8500 9033 -8550 9054 -8600 9079 -8680 9107
--8730 9142 -8810 9178 -8890 9219 -8970 9259 -9070 9307 -9160 9362 -9270 9416
--9380 9472 -9490 9525 -9610 9586 -9730 9648 -9860 9714 -9990 9783 -10130 9846
--10250 9908 -10390 9967 -10520 10028 -10660 10094 -10790 10159 -10920 10214
--11050 10266 -11150 10318 -11270 10364 -11380 10408 -11480 10450 -11580 10489
--11660 10526 -11740 10557 -11810 10581 -11870 10604 -11920 10623 -11970 10637
--12020 10654 -12050 10669 -12090 10676 -12090 10682 -12110 10685 -12120 10688
--12140 10695 -12170 10703 -12190 10708 -12190 10711 -12210 10717 -12230 10723
--12270 10738 -12320 10756 -12360 10773 -12420 10794 -12490 10819 -12570 10848
--12660 10880 -12770 10917 -12880 10960 -13030 11007 -13170 11058 -13340 11111
--13490 11162 -13680 11219 -13870 11281 -14080 11348 -14300 11420 -14530 11485
--14740 11547 -14950 11606 -15180 11668 -15420 11739 -15670 11802 -15890 11856
--16090 11901 -16270 11939 -16460 11978 -16660 12013 -16830 12040 -16980 12057
--17080 12061 -17170 12053 -17260 12037 -17300 12015 -17340 11980 -17330 11935
--17300 11879 -17250 11817 -17160 11736 -17030 11643 -16880 11542 -16700 11433
--16520 11324 -16320 11210 -16080 11080 -15780 10932 -15490 10783 -15180 10635
--14890 10497 -14600 10362 -14270 10212 -13910 10054 -13550 9899 -13210 9757
--12920 9632 -12630 9518 -12337 9404 -12032 9289 -11741 9185 -11498 9101
--11309 9041 -11158 9001 -11023 8970 -10901 8951 -10820 8949 -10792 8973
--10817 9015 -10899 9084 -11016 9172 -11178 9282 -11389 9413 -11651 9566
--11958 9731 -12311 9919 -12730 10134 -13207 10376 -13731 10636 -14287 10908
--14867 11183 -15485 11469 -16169 11783 -16912 12123 -17685 12473 -18469 12821
--19253 13159 -20042 13495 -20887 13852 -21782 14226 -22688 14599 -23574 14955
--24424 15288 -25257 15608 -26154 15946 -27017 16265 -27856 16567 -28658 16857
--29440 17121 -30202 17367 -30929 17590 -31617 17788 -32238 17964 -32813 18116
--33345 18240 -33824 18327 -34245 18384 -34592 18428 -34862 18441 -35059 18402
--35200 18317 -35252 18216 -35250 18120 -35157 17989 -34900 17773 -34564 17479
--34280 17175 -33892 16921 -33185 16727 -32299 16481 -31592 16028 -31079 15388
--30326 14733 -28867 14140 -26866 13587 -24896 13125 -23358 12869 -22446 12738
--21832 12382 -20475 11439 -18028 9966 -15048 8486 -12079 7578 -9229 7373
--6245 7462 -3799 7260 -2379 6485 -1440 5343 -313 4322 755 3927 1355 4428
-1465 5834 1605 7775 2656 9091 5151 8254 7829 5802 9575 3851 10160 2846
-9232 2955 6707 3935 8185 4818 6636 4102 4941 3723 9316 3478 14767 5861
-3919 11859 -2656 13896 -5810 13991 -7157 13428 -7601 12632 -7557 11607
--7178 9812 -6498 4447 -5472 4900 -5779 4088 -5960 2307 -4437 2402 -4784 3952
--4050 2441 -2578 1594 -6985 3045 -5631 2838 -3542 2183 -5361 2985 -6387 3369
--4524 3251 -4115 5683 -4345 5883 -3723 5301 -5423 5833 -5432 5326 -4235 6201
--3757 5926 -3127 5317 -681 4417 -2066 3719 -5571 3143 -7430 2351 -302 -248
--3560 1703 -7161 4471 133 2786 -2331 7670 -2855 7640 -5430 8675 -5824 7528
--1246 5564 7366 3575 4900 1062 2384 -19 9962 2652 5650 710 135 3062 5272 7479
-4415 7493 4441 7569 7739 9196 8369 8969 5228 8591 3607 9031 -2967 5452
--547 4822 524 4550 -500 4411 -2221 4368 -4508 3944 -7212 2960 -9568 2239
--11300 1831 -12367 1646 -12805 1669 -12646 1914 -11877 2382 -10568 3018
--8975 3720 -7435 4384 -5073 4872 709 5428 1768 5773 -417 5094 1994 5750
-2262 5266 4104 4265 3599 5316 2144 4791 5680 3966 8704 3507 3967 5171 1629 7997
--2507 13001 -11691 20707 -19526 27310 -24955 31682 -28747 33732 -31315 33638
--32170 31633 -30093 28059 -23740 23695 -13309 20053 -2572 19043 8223 20734
-20875 24188 32666 26501 35726 24515 23311 15090 -5277 10582 -4004 16313
-5819 -14358 -7955 -1388 -10449 1000 -2304 -6380 -16268 10694 -45467 3574
--20796 -11541 -13046 -8407 -14717 -18628 -30939 -27877 -59485 -30964
--13438 27879 -4606 32290 -8958 -2769 -10534 -12300 -14769 -22130 13230 67162
--5951 12926 -23894 -5440 1495 -78251 -11123 -1948 -16124 17475 -45545 28617
--86767 -69958 -56691 -15252 -51965 -4885 -55759 -3040 -58420 -7460 -34023 25521
-63900 171720 43112 81019 14231 -15282 -61312 -33763 -13056 4398 -26907 -12160
--48459 -18369 -22197 -41053 1927 40656 -4640 11723 -104490 -50824 -76458 -11493
--73940 6 9334 40665 95040 60751 18052 4622 -48380 -39623 -62480 -16408
--19442 -4457 29705 16530 68500 38774 49320 33953 25607 22989 10537 12198
-4516 9111 2186 6683 4628 6461 6421 9058 7336 12691 6619 10986 6289 12882
-6977 15689 4167 15951 879 18276 -1856 14131 -5468 10001 439 -8341 -5887 -9730
--13976 -5625 -18744 492 -17774 6876 -14769 14040 -18806 24659 -22078 22844
--19091 19841 -13317 16271 -9907 12980 -11584 10883 -10098 10282 -10388 10832
--18434 8458 -23687 6179 -28692 8466 -34715 9270 -41955 15715 -57387 5494
--33125 42008 -26855 48691 -25983 46845 -27191 41898 -28763 36114 -29779 30607
--29941 25845 -29353 21882 -28220 18527 -26656 15488 -24633 12548 -22026 9657
--18743 6922 -14791 4479 -10296 2397 -5463 659 -584 -799 4089 -2028 8303 -3047
-11900 -3823 14829 -4310 17151 -4504 19011 -4444 20548 -4223 21808 -3955
-22733 -3745 23232 -3660 23237 -3684 22803 -3703 22106 -3511 21353 -2870
-20712 -1594 20198 357 19643 2845 18774 5569 17305 8147 15085 10233 12157 11607
-8804 12234 5485 12256 2701 11941 893 11591 269 11463 769 11691 2007 12247
-3375 12958 4215 13570 3726 14303 1842 14215 -772 13537 -3513 12567 -5936 11572
--7791 10731 -9023 10122 -9711 9747 -9983 9559 -9979 9506 -9787 9533 -9494 9599
--9142 9679 -8746 9760 -8328 9832 -7895 9897 -7442 9958 -6988 10014 -6516 10070
--6048 10126 -5582 10185 -5114 10249 -4660 10319 -4226 10394 -3806 10477
--3412 10563 -3043 10657 -2698 10756 -2394 10860 -2119 10969 -1868 11083
--1660 11199 -1482 11318 -1333 11438 -1227 11559 -1147 11680 -1097 11798
--1071 11915 -1076 12028 -1106 12138 -1164 12241 -1244 12339 -1345 12432
--1464 12517 -1594 12596 -1750 12668 -1906 12731 -2078 12788 -2264 12834
--2462 12873 -2673 12906 -2894 12933 -3108 12954 -3327 12970 -3535 12979
--3739 12980 -3948 12975
-120: 11669720 -5401454 -7590 9502 -7610 9493 -7640 9484 -7660 9474 -7690 9467
--7720 9452 -7740 9438 -7770 9428 -7810 9411 -7830 9397 -7860 9380 -7900 9361
--7920 9344 -7950 9325 -7990 9309 -8010 9287 -8050 9264 -8090 9245 -8100 9227
--8130 9212 -8170 9190 -8190 9170 -8220 9149 -8250 9130 -8270 9115 -8300 9103
--8330 9092 -8360 9076 -8380 9068 -8410 9060 -8440 9055 -8480 9057 -8510 9059
--8540 9064 -8580 9067 -8620 9079 -8670 9096 -8720 9113 -8780 9138 -8840 9167
--8910 9197 -8970 9230 -9050 9269 -9130 9309 -9230 9355 -9320 9405 -9430 9457
--9530 9511 -9640 9563 -9750 9617 -9870 9676 -10000 9742 -10120 9804 -10260 9867
--10370 9925 -10510 9982 -10620 10040 -10770 10103 -10890 10162 -11020 10216
--11130 10265 -11240 10315 -11350 10358 -11460 10400 -11550 10441 -11640 10474
--11710 10512 -11800 10539 -11850 10562 -11900 10583 -11950 10599 -11990 10615
--12040 10629 -12070 10645 -12090 10650 -12090 10651 -12110 10655 -12110 10659
--12140 10668 -12140 10674 -12160 10678 -12170 10684 -12170 10687 -12200 10693
--12230 10709 -12270 10725 -12310 10745 -12370 10765 -12420 10790 -12510 10819
--12600 10853 -12700 10892 -12810 10933 -12950 10978 -13090 11031 -13250 11085
--13410 11136 -13580 11191 -13780 11256 -13970 11322 -14210 11393 -14420 11459
--14630 11521 -14830 11578 -15060 11641 -15310 11712 -15540 11774 -15760 11827
--15960 11873 -16140 11909 -16320 11950 -16510 11984 -16690 12010 -16820 12027
--16940 12029 -17030 12021 -17100 12008 -17150 11986 -17180 11949 -17180 11905
--17150 11851 -17090 11788 -17000 11709 -16880 11617 -16730 11515 -16560 11409
--16380 11302 -16170 11188 -15950 11059 -15650 10914 -15360 10765 -15070 10621
--14780 10485 -14500 10351 -14170 10203 -13830 10048 -13470 9893 -13150 9754
--12850 9631 -12590 9520 -12290 9406 -12000 9291 -11728 9191 -11490 9108
--11309 9049 -11169 9007 -11043 8979 -10930 8959 -10856 8957 -10838 8979
--10875 9021 -10956 9088 -11085 9174 -11251 9282 -11471 9410 -11737 9558
--12044 9721 -12401 9903 -12821 10114 -13299 10351 -13822 10605 -14377 10870
--14954 11138 -15569 11417 -16247 11723 -16986 12055 -17753 12397 -18530 12735
--19302 13064 -20082 13390 -20920 13737 -21806 14102 -22695 14463 -23570 14809
--24407 15131 -25225 15440 -26107 15766 -26962 16075 -27783 16370 -28574 16644
--29334 16897 -30085 17133 -30801 17347 -31464 17534 -32076 17697 -32637 17840
--33153 17955 -33618 18031 -34025 18079 -34357 18111 -34622 18116 -34811 18068
--34935 17974 -34978 17864 -34964 17756 -34874 17614 -34611 17397 -34265 17099
--33973 16780 -33581 16509 -32896 16289 -32022 16021 -31264 15587 -30686 15009
--29958 14385 -28703 13756 -26940 13131 -25020 12596 -23284 12254 -22099 12009
--21087 11550 -19470 10607 -17352 9306 -15194 8121 -12996 7495 -10321 7426
--7102 7465 -4609 7089 -3564 6101 -3254 4761 -2622 3572 -1444 3026 -17 3509
-1164 5347 1775 8567 2808 11532 6614 10278 10394 6218 11754 4354 10835 4073
-7882 4592 2778 6279 9052 4164 1925 3972 3773 2849 5900 3058 7815 5650 3385 9888
--842 12580 -3544 13770 -5046 14039 -5844 13726 -6226 12859 -6309 11113
--6137 8055 -5843 7557 -6848 6875 -5092 2548 -4127 2086 -4403 3150 -4051 2907
--2628 1838 -4986 2428 -4568 2369 -900 1136 -6002 3034 -6204 4072 -6534 3845
--4580 5155 -3938 5749 -4138 6166 -4074 5972 -3815 5093 -3530 6249 -2116 5975
--2011 5928 1821 4063 436 2890 -1979 1783 -2366 327 859 -1423 -1842 396
--6601 4627 -2669 5903 -1471 8407 -5166 10677 -10251 9551 -9050 9938 -566 7921
-21726 2167 16070 -290 8951 -1371 6496 -766 371 -1222 -3060 864 -843 4476
--469 6114 972 7050 6906 8869 8054 8925 6131 8684 4605 9994 -3802 7771 2313 6582
-2710 6216 205 5772 -1958 5725 -4741 4951 -8341 2843 -11098 1670 -12868 1126
--13796 943 -14037 1037 -13684 1394 -12796 1977 -11350 2701 -9596 3481
--8075 4251 -4937 4667 -2219 4924 -536 5121 -2983 4664 -2493 6193 1335 4362
-3540 2635 -1906 5846 4613 3402 8434 2150 8813 2157 6694 3618 1177 7139
--1689 11058 -20880 22119 -33540 29054 -41617 32703 -47223 34030 -50875 33483
--51690 31209 -47526 27331 -35539 22321 -15683 17671 -356 17199 12120 20715
-25632 27944 39727 34444 45047 34515 31897 17404 21619 8343 19483 -1879
-21732 -21079 -4165 2478 -6260 3150 -4586 214 -19558 9741 -29943 9103 -17117 516
--7720 -1130 320 -12282 -5128 -12475 -41622 -11051 -29250 8865 -30754 10934
--12518 5574 -12361 -698 -21255 -27979 30368 42838 -4592 14341 -10233 -5422
-2087 -67611 -13439 -5205 -17910 11796 -44486 17292 -73681 -20025 -71027 -7617
--79672 -922 -71979 -5306 -56705 -10035 -52456 2049 4902 79127 28516 77133
-54737 43453 6712 66 -234 -43264 -29581 -82177 -44710 4902 -41158 15400
--12675 56754 -12597 9019 -60845 -24554 15277 36542 -88129 -18181 -28614 10123
-73651 30932 1674 9628 -42905 -8729 -20393 -2545 2421 -6803 17856 8516
-45509 31044 26828 24895 16166 18943 9691 11018 8991 16116 5067 15310 7143 11599
-5380 8769 4204 11116 1560 3599 944 7321 4172 12762 60 11495 -2824 18460
--2434 10373 -4392 8009 -1914 -326 -3638 -3879 -7458 -1997 -9991 2499 -10610 8098
--11875 13570 -23172 16241 -23371 18159 -16872 19314 -8536 15951 -5348 11705
--15495 8887 -12096 8239 -8641 11945 -21142 9323 -25501 6118 -21016 14819
--35659 13013 -43582 14168 -47225 15464 -32454 36015 -24929 43743 -23877 42787
--25926 38100 -28496 32516 -30268 27324 -30875 22952 -30447 19399 -29267 16441
--27524 13801 -25297 11286 -22594 8851 -19410 6587 -15779 4598 -11781 2926
--7512 1514 -3148 270 1141 -869 5148 -1912 8699 -2793 11699 -3439 14155 -3794
-16170 -3855 17857 -3669 19247 -3323 20298 -2932 20939 -2595 21084 -2359
-20787 -2189 20199 -1947 19538 -1446 18977 -505 18583 966 18229 2910 17687 5136
-16692 7351 15053 9269 12742 10675 9950 11492 6997 11783 4287 11721 2195 11529
-938 11406 531 11481 767 11769 1256 12187 1587 12590 1492 13125 436 13205
--1187 12905 -2988 12372 -4686 11761 -6112 11192 -7174 10732 -7899 10402
--8329 10190 -8544 10070 -8590 10013 -8517 9996 -8350 10000 -8128 10016
--7843 10038 -7524 10064 -7168 10094 -6792 10127 -6395 10165 -5990 10207
--5570 10255 -5159 10310 -4747 10371 -4356 10438 -3970 10512 -3602 10592
--3259 10676 -2946 10767 -2659 10861 -2397 10963 -2163 11066 -1964 11173
--1791 11283 -1653 11393 -1547 11503 -1465 11615 -1414 11724 -1385 11832
--1385 11936 -1410 12038 -1458 12133 -1522 12225 -1620 12310 -1728 12390
--1847 12465 -1987 12532 -2138 12592 -2297 12644 -2469 12689 -2650 12728
--2851 12759 -3060 12785 -3264 12807 -3467 12822 -3661 12834 -3859 12836
--4058 12832
-121: 11700640 -5392598 -7700 9531 -7730 9527 -7750 9517 -7770 9510 -7810 9502
--7840 9491 -7860 9479 -7900 9467 -7930 9455 -7960 9441 -7990 9425 -8030 9408
--8050 9393 -8090 9377 -8120 9361 -8160 9340 -8190 9323 -8230 9301 -8250 9286
--8290 9269 -8310 9252 -8350 9230 -8370 9211 -8400 9193 -8430 9180 -8460 9167
--8490 9154 -8520 9141 -8540 9132 -8570 9125 -8600 9120 -8640 9121 -8680 9121
--8700 9126 -8740 9130 -8780 9140 -8830 9156 -8890 9172 -8930 9194 -9000 9222
--9060 9251 -9130 9281 -9210 9318 -9280 9355 -9380 9399 -9460 9447 -9580 9496
--9670 9547 -9780 9597 -9880 9650 -10000 9705 -10120 9767 -10250 9827 -10380 9885
--10480 9943 -10620 9995 -10730 10052 -10860 10111 -10990 10165 -11110 10219
--11220 10267 -11320 10311 -11420 10351 -11520 10394 -11610 10430 -11700 10464
--11770 10497 -11840 10523 -11890 10544 -11940 10563 -11970 10578 -12020 10594
--12050 10606 -12090 10620 -12090 10626 -12110 10624 -12100 10629 -12100 10630
--12120 10640 -12140 10648 -12130 10650 -12140 10653 -12140 10659 -12160 10667
--12190 10681 -12230 10698 -12280 10717 -12310 10737 -12380 10763 -12450 10793
--12530 10826 -12630 10863 -12750 10905 -12880 10954 -13020 11004 -13170 11060
--13320 11111 -13500 11166 -13680 11230 -13890 11297 -14100 11366 -14330 11432
--14520 11492 -14730 11551 -14950 11616 -15190 11682 -15420 11746 -15640 11802
--15830 11845 -16000 11881 -16190 11919 -16380 11954 -16550 11981 -16680 11995
--16790 11998 -16880 11993 -16950 11976 -17000 11956 -17030 11919 -17030 11876
--17000 11822 -16940 11761 -16850 11683 -16730 11590 -16590 11491 -16410 11386
--16240 11278 -16040 11168 -15810 11039 -15540 10897 -15240 10750 -14950 10609
--14670 10473 -14400 10341 -14080 10197 -13740 10042 -13410 9891 -13080 9752
--12800 9633 -12530 9523 -12260 9410 -11980 9298 -11700 9199 -11490 9118
--11311 9058 -11180 9019 -11062 8989 -10960 8971 -10898 8967 -10885 8989
--10928 9031 -11018 9094 -11153 9179 -11327 9285 -11548 9411 -11818 9555
--12130 9714 -12487 9892 -12908 10097 -13386 10329 -13911 10577 -14467 10836
--15037 11097 -15647 11369 -16319 11667 -17054 11991 -17815 12324 -18586 12654
--19343 12972 -20120 13291 -20945 13626 -21816 13980 -22697 14331 -23556 14667
--24382 14978 -25183 15277 -26061 15591 -26897 15890 -27697 16173 -28473 16435
--29227 16680 -29955 16904 -30654 17108 -31307 17282 -31905 17435 -32448 17567
--32948 17671 -33399 17737 -33793 17776 -34117 17796 -34366 17791 -34549 17736
--34660 17634 -34688 17511 -34670 17391 -34577 17246 -34311 17021 -33959 16719
--33647 16392 -33256 16101 -32608 15849 -31758 15558 -30954 15150 -30287 14624
--29570 14029 -28472 13381 -26950 12727 -25156 12153 -23406 11744 -22047 11388
--20687 10823 -18911 9877 -17076 8724 -15405 7784 -13551 7364 -10874 7361
--7678 7318 -5509 6784 -5066 5641 -5445 4165 -5267 2809 -3782 1979 -1078 2059
-1788 3816 2477 8622 1583 15215 7506 12855 12822 5953 12990 4623 9864 4877
-5111 4950 4833 6243 10072 6000 -2421 4840 -686 4046 1757 3751 3483 5647
-2466 8684 553 11247 -1215 12872 -2611 13621 -3683 13647 -4531 13009 -5219 11775
--5820 10334 -6486 10180 -7168 9682 -3665 1719 -3467 1863 -4183 3567 -4351 4431
--640 1612 -2960 2243 -5058 2788 83 428 -6584 2431 -10373 4118 -3758 5056
--3891 5815 -4910 6738 -3994 7040 -4121 6497 -2282 5104 -722 3184 1217 3197
-3635 7328 2743 4141 2652 2749 1395 1282 2029 -754 4078 -2990 904 -1280
--9763 6465 -6556 9441 -3553 9826 -5999 10699 -7674 10660 -3685 11941 15645 8325
-29389 3723 19502 554 10861 -1374 2340 -2889 -7179 -3762 -8380 -1330 -6886 2313
--6321 4978 -4872 6168 5431 8614 6023 8543 4665 8758 1970 9290 -1338 9154
-4152 6871 3650 7650 -73 6846 -1722 7127 -4708 6291 -9687 2590 -12753 1238
--14396 674 -15080 524 -15138 706 -14702 1182 -13876 1901 -12416 2720 -10288 3552
--9116 4496 -4380 4769 -5590 4649 -4465 4892 -4583 5124 -2131 5265 6828 3785
--1198 3264 -13478 6157 5242 1155 10325 -305 7292 1765 10879 2020 5292 5688
--5183 9661 -33551 24954 -46318 30639 -55062 33210 -61900 33962 -66831 33154
--68645 30710 -64497 26497 -48946 20434 -15917 13007 893 12731 11263 16655
-23439 27273 41499 37577 53021 44506 37698 17586 43299 10604 33764 -5287
-26966 -13994 10071 -2546 2585 897 -2645 738 -12877 4358 -13040 15276 -8151 9349
--2338 3423 2518 -3577 461 -1128 -10459 8358 -23908 -4658 -53354 -11726
--19939 1367 -10636 8014 8109 -14953 48313 28105 12818 13471 -9909 -8329
--33695 -34308 -15408 -8753 -12987 9556 -29343 14033 -55633 -2959 -63040 -2921
--79972 181 -95704 -2036 -98956 -7724 -73476 -10933 -63794 -1095 -28803 48467
-72703 55519 64214 12993 35635 -32011 246 -50793 -19722 -753 -20104 24514
--2246 41035 -4611 17210 -112239 11556 -5760 5914 -12000 0 -9000 12000
-138528 25450 -89416 -5788 -16111 12128 -14722 12666 6386 -11408 -8906 -1883
-17505 19407 15855 23177 6332 8507 6675 10360 9438 15661 8890 19759 7571 14240
-4770 9402 1720 8240 -971 5722 -802 8141 1308 10787 -1874 10304 -3618 11806
--4979 9209 -6027 9975 -4647 6957 -4220 2518 -5825 3161 -7027 5844 -9556 9740
--14835 11777 -20965 12478 -22188 14930 -14714 19981 -4040 16365 2341 12085
--23125 8753 -15826 6024 -10578 12779 -15009 14206 -21020 12817 -23486 16806
--33063 17354 -38219 19020 -36387 23088 -25932 33374 -20083 37877 -21277 36006
--25657 31394 -29870 26488 -32469 22234 -33295 18814 -32720 16096 -31206 13841
--29074 11805 -26506 9825 -23595 7882 -20379 6065 -16904 4476 -13212 3152
--9335 2033 -5365 1020 -1404 38 2383 -927 5831 -1814 8821 -2536 11349 -3010
-13466 -3195 15269 -3091 16781 -2755 17959 -2283 18743 -1784 19040 -1348
-18888 -994 18413 -654 17825 -193 17308 547 16953 1673 16702 3191 16375 4985
-15734 6855 14575 8565 12834 9926 10594 10839 8075 11309 5582 11443 3423 11391
-1812 11308 814 11309 341 11437 173 11662 65 11913 81 12260 -529 12405 -1565 12327
--2784 12076 -4005 11733 -5103 11374 -6008 11049 -6698 10785 -7188 10586
--7516 10444 -7693 10347 -7751 10283 -7720 10240 -7606 10217 -7428 10204
--7191 10203 -6916 10210 -6610 10225 -6276 10248 -5922 10279 -5556 10318
--5193 10364 -4823 10417 -4464 10477 -4115 10542 -3779 10615 -3462 10692
--3175 10774 -2902 10863 -2655 10953 -2438 11048 -2251 11147 -2090 11247
--1952 11347 -1847 11450 -1768 11551 -1718 11654 -1687 11751 -1687 11849
--1699 11941 -1743 12031 -1800 12115 -1885 12195 -1990 12270 -2100 12339
--2223 12402 -2364 12458 -2512 12508 -2673 12551 -2843 12588 -3033 12618
--3222 12644 -3418 12666 -3610 12681 -3794 12693 -3981 12697 -4172 12696
-122: 11731590 -5383748 -7810 9559 -7830 9557 -7860 9549 -7880 9542 -7920 9536
--7950 9527 -7980 9515 -8010 9507 -8050 9494 -8080 9482 -8120 9469 -8140 9453
--8180 9440 -8220 9427 -8250 9408 -8290 9392 -8320 9373 -8370 9356 -8390 9340
--8420 9326 -8460 9307 -8480 9288 -8520 9270 -8550 9252 -8570 9240 -8610 9227
--8640 9215 -8670 9203 -8690 9192 -8720 9186 -8750 9181 -8790 9180 -8830 9181
--8860 9186 -8890 9189 -8930 9199 -8980 9212 -9040 9228 -9080 9248 -9150 9273
--9200 9301 -9280 9333 -9340 9363 -9430 9401 -9520 9440 -9600 9487 -9710 9533
--9800 9583 -9910 9631 -10000 9680 -10120 9732 -10240 9790 -10360 9849
--10490 9905 -10590 9959 -10720 10010 -10830 10063 -10960 10118 -11080 10170
--11190 10222 -11300 10267 -11400 10308 -11480 10348 -11580 10387 -11670 10420
--11750 10455 -11820 10483 -11880 10509 -11930 10527 -11970 10546 -12010 10558
--12030 10572 -12070 10585 -12100 10595 -12100 10601 -12100 10602 -12110 10604
--12090 10605 -12110 10613 -12120 10620 -12120 10624 -12110 10627 -12120 10632
--12130 10640 -12150 10655 -12190 10671 -12230 10690 -12280 10710 -12320 10738
--12400 10767 -12470 10799 -12580 10837 -12690 10880 -12810 10928 -12950 10979
--13090 11034 -13250 11085 -13410 11142 -13610 11203 -13800 11272 -14010 11341
--14230 11406 -14430 11465 -14620 11526 -14840 11589 -15080 11655 -15310 11717
--15520 11771 -15700 11818 -15890 11853 -16060 11890 -16250 11924 -16410 11952
--16540 11965 -16650 11967 -16740 11962 -16800 11947 -16860 11922 -16880 11892
--16880 11849 -16850 11793 -16800 11732 -16710 11654 -16580 11566 -16440 11467
--16280 11365 -16100 11257 -15910 11146 -15680 11022 -15410 10881 -15130 10737
--14840 10598 -14580 10465 -14300 10332 -13990 10190 -13660 10039 -13330 9890
--13020 9754 -12750 9636 -12490 9528 -12220 9417 -11950 9306 -11700 9208
--11480 9130 -11310 9073 -11190 9033 -11090 9001 -10988 8983 -10938 8982
--10935 9003 -10982 9042 -11081 9106 -11217 9189 -11401 9292 -11624 9413
--11898 9555 -12215 9712 -12573 9883 -12993 10085 -13472 10311 -13995 10553
--14545 10804 -15117 11061 -15725 11325 -16390 11616 -17113 11931 -17868 12256
--18630 12573 -19386 12884 -20151 13194 -20963 13522 -21822 13864 -22689 14203
--23529 14528 -24349 14830 -25136 15117 -25995 15422 -26816 15706 -27602 15980
--28368 16231 -29107 16465 -29823 16680 -30496 16868 -31128 17034 -31717 17177
--32244 17296 -32735 17388 -33170 17448 -33550 17477 -33858 17487 -34101 17464
--34282 17401 -34373 17299 -34397 17172 -34361 17035 -34246 16865 -34009 16634
--33673 16340 -33324 16025 -32883 15721 -32262 15432 -31509 15112 -30721 14701
--29992 14201 -29194 13631 -28164 13006 -26765 12365 -25093 11797 -23532 11336
--22106 10850 -20606 10161 -18871 9242 -17072 8304 -15383 7616 -13482 7300
--11227 7187 -9013 6920 -7550 6254 -7301 5124 -7642 3773 -7448 2447 -5693 1323
--1649 497 4018 744 4868 6225 -2482 20494 7734 13246 14940 6603 12300 5734
-4253 4858 -1451 3681 1741 7130 6959 8263 2205 7246 327 5923 575 4992 1706 6043
-2430 8165 2168 10315 1208 11909 -59 12754 -1369 12825 -2611 12212 -3731 11130
--4726 9974 -5478 9270 -5456 8054 -3408 4194 -2769 3643 -2540 4490 -1455 4875
-1267 3225 1015 2631 -521 2304 -1394 1600 -7999 3506 -11476 5919 -5357 5337
--6047 6899 -7702 8228 -3797 7795 -5287 7391 -1766 5579 754 -804 1543 -1756
-5626 5751 5562 5646 5558 4248 3730 2855 4587 575 7730 -3539 5995 -3284
--15057 9411 -6463 11460 -3802 10399 -5962 10200 -5036 11338 1683 12318
-33649 7791 40772 5390 15459 2118 9968 -45 -785 -3579 -16162 -6198 -11649 -2590
--9002 1786 -7960 5457 -5906 6537 -377 7486 1299 7470 1012 7426 -209 7365
--702 7120 2003 7180 -94 9154 525 7868 -994 7802 -4691 6751 -11058 3339
--14345 1590 -15670 724 -16053 470 -15953 699 -15515 1302 -15236 2224 -14664 3120
--13439 3954 -11066 4676 -4743 4599 -4792 4632 -4193 4965 -1344 4515 13640 1829
-36862 -1986 -31884 8955 -30056 8320 -7465 2979 3924 320 6665 561 8126 1613
--2657 7632 -14919 13203 -35450 23272 -49500 28813 -59534 31457 -67291 32369
--73223 31756 -76874 29605 -76403 25940 -65204 20113 -12114 7786 -418 7968
-4547 8882 14972 21152 31393 26408 38617 31239 51847 35784 67041 26489
-42183 -194 32726 -5733 20933 -1279 12153 1501 5500 3099 -453 6819 -831 13194
-599 10429 1118 3721 -1507 -4654 -8834 -9929 -15964 -10416 20336 18375
-8419 13935 -83248 -13940 -7183 9391 -4800 3771 84936 19876 20888 10093
--14278 -2755 -41875 -22333 -18387 -6549 -420 12257 -3946 17078 -36791 -688
--35152 -2701 -55184 950 -80773 -387 -126436 -9047 -126598 -10530 -121837 -2104
--101128 18917 85458 26008 91461 6206 58266 -17491 22440 -23007 255 2673
--6469 22637 -5496 30256 -19523 20259 -65570 13386 -17221 3956 5889 1071
-25169 5118 73227 9275 -33259 675 -20531 9482 -19534 11594 -31976 14534
--2445 12488 663 15521 8308 14275 964 6286 1991 6682 5768 9546 6812 12573
-5305 10241 2938 6882 -1161 6390 -4142 8814 -2827 11453 445 11563 -3750 10298
--5605 9888 -6032 9427 -6160 9958 -5219 9209 -6298 7867 -6833 8019 -5949 8822
--9229 11897 -16313 10913 -15652 10518 -17362 14467 -16222 16842 -7693 16647
--573 18078 -13292 14532 -12283 11685 -9946 13902 -13223 15623 -19737 16479
--25621 19121 -31824 21400 -33479 24446 -27312 28868 -15191 33861 -10580 33719
--16253 28077 -24724 22364 -31596 18379 -35614 15819 -37006 14040 -36442 12592
--34605 11230 -31999 9838 -28943 8374 -25632 6889 -22156 5476 -18570 4221
--14904 3155 -11160 2239 -7384 1394 -3651 559 -71 -277 3240 -1071 6187 -1745
-8745 -2216 10940 -2433 12817 -2377 14393 -2084 15627 -1631 16485 -1113
-16907 -614 16933 -169 16663 253 16261 746 15886 1422 15611 2372 15412 3616
-15158 5083 14668 6639 13766 8110 12394 9346 10577 10254 8459 10815 6262 11083
-4223 11159 2519 11153 1238 11158 367 11222 789 11657 -681 11462 -173 11980
--603 12076 -1667 11936 -2811 11736 -3842 11520 -4725 11296 -5471 11079
--6077 10889 -6546 10731 -6905 10608 -7142 10511 -7250 10439 -7256 10382
--7195 10342 -7077 10315 -6919 10299 -6719 10295 -6463 10301 -6165 10317
--5843 10341 -5521 10373 -5213 10411 -4895 10457 -4568 10511 -4249 10570
--3932 10636 -3644 10707 -3377 10779 -3132 10859 -2907 10942 -2703 11030
--2525 11121 -2366 11213 -2241 11303 -2138 11396 -2063 11489 -2011 11584
--1984 11675 -1976 11765 -1984 11849 -2015 11931 -2074 12009 -2151 12083
--2244 12154 -2350 12217 -2460 12277 -2587 12329 -2726 12376 -2880 12417
--3046 12452 -3216 12481 -3389 12508 -3568 12529 -3751 12544 -3930 12554
--4114 12560 -4297 12560
-123: 11762570 -5374899 -7900 9585 -7940 9583 -7960 9576 -7990 9574 -8020 9567
--8060 9559 -8090 9550 -8120 9544 -8160 9532 -8190 9520 -8230 9509 -8260 9496
--8310 9483 -8340 9471 -8370 9456 -8400 9439 -8450 9423 -8490 9406 -8530 9392
--8550 9378 -8580 9360 -8630 9342 -8650 9324 -8680 9308 -8710 9297 -8750 9285
--8770 9271 -8810 9261 -8820 9250 -8870 9243 -8890 9240 -8930 9237 -8970 9239
--9000 9241 -9030 9246 -9070 9254 -9120 9265 -9180 9280 -9220 9299 -9280 9324
--9350 9348 -9410 9378 -9480 9408 -9560 9444 -9640 9481 -9730 9526 -9830 9569
--9930 9617 -10020 9662 -10120 9708 -10240 9759 -10350 9816 -10470 9869
--10580 9924 -10700 9976 -10810 10022 -10920 10075 -11040 10125 -11170 10175
--11270 10224 -11360 10266 -11470 10309 -11550 10346 -11640 10381 -11730 10412
--11790 10444 -11870 10471 -11920 10495 -11960 10513 -12000 10528 -12030 10542
--12060 10551 -12090 10564 -12100 10573 -12110 10579 -12100 10579 -12110 10579
--12090 10583 -12100 10588 -12110 10595 -12090 10598 -12100 10601 -12090 10606
--12100 10616 -12130 10628 -12150 10646 -12190 10663 -12230 10687 -12290 10712
--12350 10741 -12420 10774 -12520 10811 -12630 10855 -12750 10902 -12890 10954
--13020 11009 -13180 11062 -13340 11118 -13520 11178 -13720 11246 -13920 11316
--14150 11379 -14340 11441 -14520 11499 -14740 11560 -14970 11630 -15200 11689
--15400 11742 -15590 11787 -15760 11825 -15940 11859 -16120 11896 -16280 11921
--16410 11935 -16510 11939 -16600 11931 -16670 11916 -16710 11893 -16740 11863
--16730 11819 -16710 11768 -16650 11704 -16570 11627 -16450 11541 -16300 11446
--16140 11341 -15970 11239 -15780 11126 -15560 11003 -15290 10866 -15010 10725
--14740 10588 -14480 10456 -14200 10325 -13910 10187 -13580 10036 -13270 9891
--12960 9759 -12690 9641 -12450 9534 -12190 9426 -11930 9317 -11680 9220
--11480 9144 -11320 9089 -11210 9049 -11100 9018 -11020 9000 -10980 8998
--10986 9018 -11039 9058 -11142 9120 -11283 9200 -11472 9301 -11698 9421
--11978 9558 -12292 9711 -12658 9880 -13075 10078 -13557 10297 -14073 10533
--14621 10777 -15193 11025 -15795 11285 -16454 11569 -17169 11877 -17915 12190
--18672 12499 -19419 12800 -20173 13100 -20972 13421 -21820 13753 -22672 14080
--23501 14393 -24304 14684 -25085 14963 -25912 15254 -26723 15531 -27496 15790
--28250 16033 -28973 16254 -29675 16456 -30329 16636 -30944 16790 -31515 16922
--32037 17030 -32509 17111 -32925 17160 -33291 17183 -33594 17179 -33828 17144
--33991 17074 -34087 16967 -34101 16836 -34046 16681 -33920 16494 -33689 16253
--33364 15970 -32991 15661 -32515 15344 -31944 15034 -31231 14690 -30466 14267
--29709 13783 -28865 13243 -27864 12638 -26504 12023 -25021 11474 -23601 10986
--22178 10415 -20690 9642 -18983 8747 -17170 7963 -15336 7462 -13486 7209
--11756 6977 -10284 6552 -9375 5809 -9278 4802 -9553 3677 -9462 2618 -7978 1621
--3249 194 7477 -2751 11547 -624 -8411 28301 12128 11366 10400 8086 4511 5770
--14071 2661 -11726 1369 10324 11665 10806 11629 6771 9155 3107 7466 1122 6362
-1224 6648 3314 8090 4126 9739 3635 11038 2403 11714 940 11634 -506 10854
--1848 9553 -3046 8077 -3900 6965 -3884 6312 -2531 5949 -1868 5643 -894 5921
-1311 6264 4404 4992 5975 3396 4717 2293 -88 2217 -8694 3728 -11049 4383
--8126 9415 -7949 9229 -8683 10390 -2837 6881 -5591 8062 -5277 7590 617 -3451
-860 -3539 1718 824 2361 2552 6076 6540 5885 7010 4156 5501 6614 276 3799 1790
--6425 8016 -1064 8237 -217 8084 -4918 8401 838 9119 10756 9271 35678 7930
-48935 7603 -1725 3523 9823 2540 926 -2272 -22975 -7449 -7306 -1596 -5585 3544
--6644 6753 -6061 6512 -4876 6172 -3486 5970 -3090 5764 -3242 5316 -3018 4971
--1465 6919 -1828 8763 -949 8056 -1625 8121 -4962 7571 -13430 3715 -15834 2170
--16396 1241 -16461 900 -16308 1097 -15588 1695 -16086 2756 -16538 3578
--16384 4283 -14134 4952 -3787 4302 -4800 4363 -5694 4829 -6189 5384 -4668 4792
-19979 452 -14757 6824 -24967 7749 -9301 3503 -1117 1430 1618 1488 414 3563
--8164 8816 -19525 14673 -34258 21422 -46729 25952 -56394 28677 -63696 29997
--68869 29738 -71433 27919 -68981 24596 -55403 19087 -22506 10613 -7406 7722
-137 7970 9040 14450 20479 19387 29111 24145 40448 27788 48894 21881 45768 12716
-38230 6694 28468 5334 20359 5306 14935 6351 11660 8985 10968 11907 10149 9790
-6465 3328 -1399 -5229 -8945 -11015 -10984 -9642 2350 5424 -11230 3844
--12568 5221 58280 20397 -77642 -3432 -6864 13557 31135 11526 2093 1183
--15392 -13077 -2539 -755 21034 18027 32002 23454 -21281 -5394 -1217 -1747
--25098 4510 -44428 4107 -139734 -9830 -145161 -5685 -126315 -371 -79595 5810
-32103 6078 61244 -2972 45240 -9430 20894 -6758 4528 9025 -2583 21801 -8129 23205
--19027 17373 -36253 9968 -13830 2116 10602 -2341 32240 -3904 46722 -3202
--8336 2772 -16285 4820 -7508 -363 -39707 16360 -8415 5243 -31091 26320
--14502 16613 -1105 29532 -892 12137 2779 6148 3718 6642 1141 5961 616 3745
--4917 4883 -8884 12028 -6623 14633 -2115 12432 -925 10210 -6631 9499 -5826 10026
--2907 11262 -4731 10259 -8601 10872 -7704 9620 -4468 10524 -9947 11583
--11483 9784 -6535 9522 -10345 19478 -16375 19572 -10751 21004 -6412 22545
--9449 20411 -7785 17039 -6676 15563 -11279 16582 -19763 18483 -27855 21023
--32316 24488 -32025 28506 -21468 33204 -796 35856 3674 31060 -10493 18765
--24757 11714 -34516 9538 -39793 9498 -41585 9823 -40933 9809 -38718 9326
--35590 8464 -31996 7368 -28205 6180 -24360 5027 -20535 3991 -16743 3099
--12998 2323 -9309 1609 -5711 905 -2285 200 900 -476 3788 -1060 6344 -1482
-8573 -1690 10493 -1660 12098 -1415 13373 -1009 14289 -519 14829 -15 15022 470
-14959 951 14758 1482 14533 2140 14348 2990 14187 4047 13966 5274 13551 6572
-12818 7827 11697 8921 10212 9781 8446 10374 6552 10728 4707 10903 3048 10973
-1673 11013 595 11064 -225 11142 -867 11240 1004 12136 92 12033 -1397 11734
--2716 11489 -3733 11310 -4529 11154 -5179 11006 -5712 10872 -6144 10757
--6506 10660 -6759 10582 -6876 10516 -6904 10462 -6868 10419 -6787 10388
--6688 10367 -6548 10358 -6327 10361 -6056 10373 -5770 10393 -5491 10421
--5226 10451 -4957 10492 -4660 10539 -4365 10594 -4075 10654 -3810 10717
--3570 10783 -3346 10852 -3142 10930 -2952 11012 -2783 11094 -2633 11179
--2513 11260 -2415 11342 -2346 11429 -2296 11516 -2265 11602 -2257 11683
--2259 11761 -2288 11834 -2336 11907 -2409 11976 -2497 12042 -2593 12101
--2692 12156 -2807 12206 -2940 12249 -3086 12287 -3241 12321 -3399 12350
--3558 12376 -3723 12396 -3898 12411 -4074 12421 -4249 12427 -4425 12429
-124: 11793580 -5366055 -8000 9610 -8020 9607 -8070 9607 -8090 9600 -8120 9595
--8150 9588 -8190 9584 -8230 9577 -8270 9567 -8290 9557 -8340 9545 -8380 9535
--8410 9525 -8450 9513 -8490 9498 -8520 9485 -8560 9468 -8610 9454 -8640 9440
--8680 9428 -8710 9411 -8740 9392 -8780 9377 -8810 9361 -8840 9350 -8870 9339
--8900 9326 -8940 9313 -8960 9306 -8990 9299 -9020 9293 -9060 9293 -9100 9291
--9130 9295 -9160 9299 -9200 9306 -9260 9315 -9300 9331 -9360 9347 -9410 9371
--9470 9395 -9540 9422 -9600 9451 -9680 9485 -9760 9518 -9850 9563 -9940 9604
--10040 9649 -10130 9691 -10240 9735 -10340 9786 -10450 9838 -10560 9891
--10690 9940 -10780 9992 -10900 10036 -11010 10086 -11120 10133 -11250 10181
--11330 10225 -11440 10269 -11530 10307 -11610 10343 -11700 10376 -11770 10406
--11840 10432 -11900 10460 -11960 10484 -12000 10498 -12030 10513 -12050 10523
--12080 10534 -12100 10547 -12110 10551 -12120 10558 -12110 10557 -12100 10556
--12080 10562 -12090 10564 -12100 10570 -12090 10574 -12070 10578 -12070 10582
--12070 10591 -12100 10602 -12130 10620 -12160 10640 -12190 10664 -12240 10689
--12310 10717 -12380 10750 -12470 10787 -12570 10830 -12700 10878 -12820 10930
--12970 10984 -13110 11038 -13270 11091 -13440 11153 -13640 11222 -13850 11291
--14060 11353 -14250 11415 -14430 11472 -14640 11535 -14870 11601 -15090 11662
--15300 11713 -15480 11759 -15640 11797 -15820 11830 -16000 11866 -16150 11891
--16280 11905 -16380 11909 -16460 11903 -16530 11886 -16570 11863 -16600 11833
--16600 11788 -16570 11740 -16510 11678 -16430 11603 -16300 11517 -16170 11422
--16010 11321 -15840 11218 -15660 11110 -15440 10986 -15170 10850 -14910 10713
--14630 10578 -14380 10449 -14120 10321 -13820 10182 -13510 10036 -13200 9894
--12910 9763 -12640 9648 -12410 9544 -12160 9437 -11900 9329 -11680 9236
--11470 9159 -11330 9107 -11220 9068 -11130 9036 -11060 9020 -11020 9017
--11030 9037 -11100 9076 -11200 9135 -11345 9215 -11541 9315 -11774 9432
--12055 9565 -12371 9714 -12734 9879 -13158 10072 -13632 10289 -14149 10515
--14698 10755 -15265 10995 -15857 11248 -16510 11527 -17220 11823 -17957 12129
--18704 12431 -19445 12721 -20186 13012 -20975 13324 -21807 13645 -22650 13962
--23467 14264 -24249 14544 -25017 14812 -25829 15093 -26621 15360 -27381 15605
--28119 15836 -28828 16047 -29510 16238 -30155 16408 -30753 16552 -31307 16673
--31811 16770 -32272 16837 -32676 16879 -33031 16893 -33314 16876 -33541 16831
--33700 16754 -33780 16642 -33794 16503 -33725 16335 -33588 16133 -33367 15892
--33046 15608 -32644 15297 -32185 14975 -31614 14652 -30934 14290 -30193 13858
--29414 13391 -28580 12872 -27543 12292 -26294 11695 -24936 11172 -23578 10689
--22247 10074 -20840 9255 -19173 8375 -17273 7706 -15382 7323 -13686 7081
--12287 6788 -11200 6274 -10609 5547 -10484 4680 -10550 3836 -10484 3199
--9883 2943 -7365 3103 7017 -223 14498 -2115 6726 10709 1392 17495 1145 10801
--4722 6986 -18368 5024 -2714 5076 8019 10644 8700 11606 8122 9243 3990 8039
-573 7146 -81 7019 4628 8194 6089 9375 5676 10255 4422 10675 2993 10421
-1601 9463 273 7818 -1045 5805 -2270 4357 -2710 4456 -1276 7733 -1326 7304
--220 7207 2911 8414 7075 7101 10705 4467 9975 2756 2193 3438 -10417 6379
--11333 6889 -8785 8550 -7464 8790 -6264 9074 821 2950 -6137 6394 -6280 5586
--3604 439 -2788 -1338 -4099 -461 -3749 743 4191 5857 4611 8056 4260 8524
-4299 6042 4109 5926 1756 5609 4266 7510 5163 5883 -5641 6237 5759 6853
-6828 5633 18982 5580 32474 6975 -7960 4126 7787 2871 944 1693 6017 575
-3263 1060 3597 11565 -4476 3020 -4568 4822 -8021 4586 -6784 4756 -6415 4867
--6150 4492 -5527 4102 -5038 5130 -3412 8198 -4230 6659 -5664 6989 -8487 7457
--14577 4436 -15899 3291 -16001 2316 -16155 1728 -16458 1898 -14278 2127
--15746 3398 -16582 3920 -16389 4184 -12971 4694 -7457 4418 -7495 4391
--7925 4546 -9933 5989 -10164 6338 -1202 4445 -13991 6453 -20055 6760 -13108 4619
--7240 3199 -4897 3428 -6226 5643 -11892 10022 -20191 14990 -30398 19652
--39988 23201 -47685 25953 -53112 27636 -56413 27780 -57374 26487 -54290 23938
--43879 19643 -25293 13582 -12438 9447 -4294 8245 3014 11032 10704 14660
-17141 17803 22247 18113 22783 13514 38037 21392 35464 15973 29123 11639
-24092 9445 22322 9181 22192 10418 22399 11614 20809 9720 14576 4025 1241 -4445
--6591 -9525 -8232 -8666 -3597 -1884 -4537 -58 5459 4538 23024 27029 -43329 -4524
--9579 1095 -12389 12688 -7482 4195 -12296 -11395 -440 4812 21259 15024
-38296 4361 60171 3143 -27092 17018 -12644 9697 -37280 3772 -88586 -6531
--111269 5916 -95330 5897 -52973 1016 859 -5721 24807 -12085 14207 -6474
-1601 847 -3819 14599 -4687 23493 -10421 17385 -13059 13475 -23630 6197
--10865 477 7795 -4262 26893 -9401 42712 -12836 -8252 7718 -29285 10438
--19716 4247 -36541 12820 -24706 12335 -23317 14203 -17799 11707 1605 27468
-529 15472 828 7141 1283 5163 -6092 5784 -1631 3775 -9760 8160 -11538 14605
--7180 10217 1343 9596 -1044 9194 -12369 11000 -6213 13077 -2378 14011
--2653 13195 -4027 12508 -2468 10948 642 10134 664 9156 1936 7271 872 8303
--18698 23383 -16814 25175 -12701 25893 -10396 27370 -9149 25919 -3548 21346
--1698 16487 -8228 17472 -19705 20118 -30747 22083 -33477 26193 -34627 30007
--22362 35336 17531 38321 22720 29732 -7245 6390 -27283 125 -38811 1847
--44637 5191 -46482 7684 -45583 8823 -42933 8854 -39278 8177 -35153 7144
--30883 6002 -26655 4907 -22553 3940 -18596 3120 -14790 2422 -11125 1792
--7614 1192 -4297 599 -1209 33 1611 -459 4140 -821 6369 -1006 8303 -989
-9928 -784 11233 -426 12209 23 12849 512 13192 1010 13305 1523 13275 2078
-13194 2729 13093 3512 12973 4438 12778 5482 12424 6582 11806 7655 10885 8619
-9665 9413 8199 10007 6587 10409 4958 10654 3412 10790 2046 10870 895 10932
--58 10995 -837 11062 1200 11972 387 11886 -1158 11567 -2538 11318 -3562 11159
--4320 11036 -4926 10925 -5416 10826 -5825 10741 -6186 10671 -6443 10609
--6567 10556 -6606 10508 -6584 10469 -6534 10439 -6484 10417 -6385 10408
--6199 10409 -5958 10419 -5705 10438 -5460 10459 -5238 10487 -5006 10520
--4743 10563 -4467 10614 -4208 10667 -3964 10725 -3748 10783 -3550 10845
--3364 10915 -3184 10991 -3026 11067 -2888 11144 -2775 11217 -2679 11291
--2613 11369 -2566 11452 -2539 11530 -2524 11605 -2525 11675 -2548 11742
--2592 11809 -2659 11874 -2739 11934 -2830 11990 -2920 12040 -3028 12087
--3152 12127 -3286 12164 -3433 12196 -3583 12224 -3728 12249 -3880 12269
--4045 12283 -4216 12293 -4385 12299 -4551 12303
-125: 11824620 -5357214 -8090 9636 -8120 9631 -8160 9629 -8180 9627 -8220 9623
--8240 9617 -8290 9611 -8320 9609 -8360 9597 -8400 9591 -8440 9581 -8480 9573
--8510 9562 -8560 9553 -8600 9538 -8630 9525 -8680 9511 -8710 9500 -8750 9487
--8790 9472 -8830 9459 -8860 9441 -8890 9425 -8920 9411 -8960 9401 -8990 9389
--9030 9377 -9050 9365 -9080 9356 -9120 9349 -9150 9346 -9180 9346 -9220 9343
--9250 9344 -9290 9348 -9310 9356 -9380 9365 -9420 9378 -9470 9392 -9530 9415
--9590 9438 -9650 9465 -9720 9493 -9790 9521 -9870 9556 -9960 9597 -10050 9638
--10150 9678 -10230 9721 -10330 9763 -10440 9810 -10550 9860 -10660 9911
--10770 9957 -10870 10007 -10980 10050 -11090 10095 -11200 10140 -11300 10188
--11410 10231 -11500 10267 -11580 10306 -11670 10341 -11750 10370 -11820 10401
--11880 10426 -11930 10450 -11990 10470 -12030 10487 -12060 10496 -12080 10506
--12090 10518 -12120 10529 -12120 10533 -12120 10536 -12120 10538 -12090 10535
--12090 10539 -12080 10543 -12090 10547 -12070 10552 -12060 10553 -12050 10558
--12050 10567 -12070 10582 -12100 10599 -12130 10616 -12160 10638 -12200 10665
--12270 10696 -12330 10727 -12430 10764 -12520 10806 -12650 10855 -12770 10907
--12910 10961 -13040 11013 -13210 11068 -13370 11128 -13580 11197 -13770 11266
--13970 11328 -14160 11388 -14350 11446 -14550 11508 -14770 11574 -14990 11634
--15190 11686 -15370 11731 -15530 11767 -15710 11801 -15870 11836 -16030 11861
--16160 11874 -16250 11879 -16340 11872 -16390 11858 -16440 11834 -16460 11804
--16460 11761 -16430 11713 -16380 11651 -16290 11577 -16180 11492 -16040 11401
--15880 11298 -15710 11199 -15540 11093 -15320 10970 -15060 10838 -14800 10702
--14530 10567 -14290 10443 -14030 10317 -13750 10182 -13430 10037 -13140 9897
--12850 9769 -12600 9657 -12380 9554 -12130 9449 -11880 9344 -11660 9254
--11480 9177 -11340 9125 -11230 9089 -11160 9059 -11090 9041 -11060 9039
--11080 9058 -11150 9097 -11260 9155 -11410 9232 -11610 9330 -11850 9445
--12128 9575 -12448 9721 -12812 9883 -13230 10070 -13704 10280 -14222 10503
--14769 10737 -15329 10970 -15916 11216 -16564 11486 -17267 11776 -17995 12073
--18732 12365 -19458 12648 -20192 12928 -20967 13231 -21787 13542 -22618 13850
--23420 14140 -24189 14409 -24942 14667 -25742 14938 -26510 15191 -27258 15427
--27975 15644 -28672 15847 -29340 16027 -29965 16184 -30552 16319 -31089 16428
--31574 16515 -32027 16573 -32420 16604 -32757 16608 -33028 16582 -33253 16528
--33388 16442 -33469 16324 -33472 16176 -33399 15997 -33260 15788 -33035 15542
--32702 15259 -32317 14940 -31856 14615 -31283 14287 -30641 13911 -29893 13484
--29135 13023 -28279 12531 -27279 11960 -26118 11387 -24773 10900 -23504 10435
--22323 9810 -21012 8970 -19343 8132 -17405 7532 -15572 7196 -13985 6970
--12679 6633 -11769 6114 -11229 5444 -10808 4751 -10251 4132 -9170 3522
--6958 2838 -3066 2300 -935 6554 6817 3003 5931 6848 1459 10080 -12286 10755
-5361 8379 -8410 7395 -406 7509 3747 9693 5188 9929 5550 9000 2746 8415
--845 7898 -3087 7125 5963 8342 7065 9039 6612 9462 5511 9751 4481 9485
-3472 8573 2457 6772 1199 4248 -534 2621 -2088 2641 206 10480 -1858 7915
--1136 7445 2555 10830 7426 9452 13376 5696 12700 3692 -721 6071 -8592 7488
--9017 7425 -6195 6173 -3589 5295 705 3584 1139 2173 -10243 7524 -6973 5118
--6055 4214 -4218 1827 -7819 1042 -6578 1418 -1111 3420 1025 6925 1527 8897
-727 7623 5049 4143 2846 6977 10776 8622 4087 3907 2696 3931 14064 9125
--1861 3443 6650 1818 35299 6058 -191 1671 -9944 6152 4361 8260 16177 7517
-9407 1110 3705 7516 -333 4630 911 7273 -9777 4896 -7006 4991 -8345 5348
--8493 5024 -7394 4369 -8834 4257 -3910 9590 -10456 3339 -11018 4462 -12957 6586
--15831 4728 -15121 4679 -14816 3573 -15337 2609 -17927 3165 -11287 2362
--14405 4142 -15235 4234 -15560 4271 -13187 4311 -11135 4677 -10019 4627
--10919 4436 -14462 6496 -16441 7153 -15003 6612 -19536 6946 -21461 6821
--17531 5843 -13082 5110 -10602 5474 -10611 7502 -13216 11046 -17989 14845
--24305 18115 -30564 20999 -35331 23743 -38074 25665 -39238 26205 -39266 25522
--37518 23759 -32238 20439 -22840 15573 -14034 11229 -7306 9179 -2119 10166
-2805 12904 7942 15654 13087 16427 12112 15324 5970 16006 18873 16008 20419 13752
-21193 11618 26078 10619 30306 11019 32151 11596 30848 10233 24296 5872
-3860 -2954 -3726 -6955 -5971 -6452 -4512 -2163 -2580 2433 3276 9376 5305 18195
--18344 -622 -13911 -4273 -1700 -2571 20645 -7124 -66316 496 -6808 37791
-409 8836 22164 -12634 48431 13812 2792 16097 -6047 10333 -15676 -1900
--31182 -10972 -66204 19751 -53629 13006 -20079 929 -14358 -10385 925 -19086
--20877 -8002 -24116 24 -15858 17021 -9166 25939 -16123 10639 -3972 12232
--20236 4438 -9660 2039 -1804 -113 2268 -3912 30354 -9625 10521 1962 -28944 8479
--25931 7782 -25270 10030 -26318 12148 -21898 13821 -7680 14611 -8517 12587
--6899 9800 -5054 5324 1524 4854 -18694 10000 -8243 7922 -1635 5162 -4354 8463
--13580 6877 -7121 7441 -17232 6282 -1200 18685 683 19422 1141 18254 865 16319
-1210 14217 3761 11828 7876 9883 11765 8399 15764 7818 15093 10931 -8521 23807
--28807 24418 -18481 25996 -13715 29319 -9901 29778 1633 24415 2288 16892
--4739 19271 -17675 22477 -34226 22676 -31855 26846 -37769 27531 -34097 32519
-35803 38533 41983 27506 -10765 -10290 -31407 -9018 -42970 -1266 -49027 5292
--50891 9093 -49751 10489 -46694 10295 -42572 9248 -37983 7869 -33309 6470
--28749 5212 -24411 4156 -20312 3303 -16438 2610 -12787 2019 -9340 1484
--6104 974 -3105 497 -357 83 2129 -224 4339 -384 6262 -373 7894 -197 9230 117
-10257 527 10990 993 11454 1488 11707 2012 11822 2577 11854 3214 11826 3945
-11756 4772 11596 5680 11294 6626 10783 7552 10020 8404 9023 9131 7807 9709
-6448 10133 5024 10424 3631 10610 2338 10729 1178 10812 169 10875 -677 10931
-1111 11693 397 11651 -1036 11394 -2345 11188 -3336 11058 -4068 10958 -4657 10868
--5125 10790 -5524 10723 -5880 10671 -6144 10623 -6280 10580 -6335 10538
--6332 10504 -6309 10478 -6294 10458 -6225 10448 -6075 10449 -5866 10458
--5644 10473 -5435 10492 -5245 10515 -5046 10544 -4817 10583 -4566 10628
--4330 10677 -4107 10728 -3918 10780 -3739 10836 -3568 10900 -3400 10968
--3256 11039 -3127 11108 -3021 11174 -2931 11241 -2870 11313 -2826 11387
--2797 11461 -2786 11528 -2781 11593 -2798 11655 -2841 11715 -2904 11776
--2974 11831 -3059 11883 -3143 11930 -3242 11974 -3356 12011 -3485 12046
--3621 12076 -3765 12103 -3901 12127 -4036 12147 -4193 12161 -4357 12171
--4519 12177 -4676 12182
-126: 11855680 -5348371 -8180 9656 -8210 9654 -8240 9651 -8270 9650 -8310 9647
--8340 9644 -8370 9641 -8410 9635 -8460 9628 -8490 9622 -8530 9615 -8570 9605
--8620 9598 -8660 9590 -8690 9577 -8730 9563 -8770 9552 -8820 9541 -8860 9529
--8900 9515 -8930 9503 -8960 9486 -9000 9471 -9040 9459 -9070 9448 -9100 9438
--9130 9425 -9170 9413 -9200 9404 -9230 9396 -9260 9395 -9300 9395 -9330 9390
--9360 9391 -9390 9396 -9440 9402 -9480 9410 -9530 9423 -9590 9438 -9630 9456
--9700 9479 -9750 9504 -9830 9531 -9890 9559 -9980 9592 -10060 9629 -10150 9670
--10240 9708 -10330 9749 -10420 9788 -10530 9834 -10640 9881 -10740 9930
--10860 9976 -10950 10018 -11050 10061 -11160 10107 -11270 10150 -11370 10194
--11460 10234 -11560 10270 -11640 10306 -11710 10336 -11800 10366 -11860 10395
--11920 10419 -11970 10439 -12020 10459 -12060 10475 -12080 10484 -12100 10493
--12110 10500 -12130 10511 -12130 10517 -12130 10518 -12110 10517 -12100 10515
--12080 10517 -12080 10521 -12070 10529 -12070 10530 -12040 10533 -12030 10534
--12030 10544 -12050 10561 -12070 10577 -12100 10595 -12140 10614 -12160 10642
--12230 10672 -12300 10707 -12390 10742 -12480 10784 -12600 10834 -12720 10885
--12850 10937 -12990 10989 -13140 11044 -13310 11105 -13510 11173 -13700 11240
--13900 11304 -14070 11363 -14270 11419 -14460 11481 -14680 11546 -14890 11607
--15090 11659 -15260 11699 -15430 11740 -15590 11773 -15760 11804 -15910 11832
--16040 11843 -16130 11850 -16210 11842 -16260 11828 -16310 11807 -16330 11775
--16330 11733 -16290 11684 -16250 11625 -16160 11552 -16050 11468 -15910 11377
--15760 11279 -15590 11179 -15420 11077 -15210 10956 -14950 10825 -14690 10691
--14440 10559 -14190 10438 -13950 10315 -13670 10181 -13370 10038 -13070 9903
--12800 9776 -12560 9667 -12340 9567 -12110 9463 -11870 9362 -11650 9271
--11480 9199 -11350 9147 -11250 9110 -11190 9082 -11120 9065 -11100 9063
--11130 9083 -11200 9119 -11320 9178 -11470 9253 -11680 9348 -11920 9462
--12200 9588 -12520 9730 -12887 9889 -13303 10072 -13775 10275 -14292 10494
--14830 10722 -15392 10948 -15970 11188 -16611 11450 -17304 11732 -18025 12022
--18755 12306 -19467 12578 -20189 12850 -20953 13143 -21759 13444 -22576 13741
--23367 14023 -24118 14281 -24859 14526 -25638 14787 -26395 15029 -27122 15253
--27830 15462 -28506 15652 -29157 15821 -29766 15968 -30337 16092 -30861 16192
--31340 16268 -31773 16315 -32155 16336 -32472 16333 -32747 16294 -32939 16236
--33081 16139 -33142 16012 -33139 15857 -33078 15671 -32918 15457 -32692 15208
--32375 14918 -31987 14598 -31509 14272 -30979 13936 -30325 13561 -29593 13129
--28841 12691 -27999 12207 -27062 11654 -25886 11105 -24579 10654 -23460 10212
--22386 9598 -21110 8790 -19466 7995 -17623 7428 -15850 7117 -14253 6881
--12992 6536 -12143 6051 -11471 5521 -10704 5109 -9655 4850 -8019 4764
--5616 4992 -3079 6024 -3778 8578 -817 6109 773 6818 1382 6568 -4729 8506
--620 8078 2380 6277 5442 7590 858 9172 1912 8185 3774 8422 2309 8783 415 9193
--2633 7452 2388 7769 4725 8429 5750 8524 5296 9053 5203 8949 4816 8491
-4458 7003 3694 4257 2006 4313 -414 5927 -136 10029 -3931 5803 -2793 7851
-32 10746 4593 11022 12503 6889 9817 5470 -200 6299 -6408 6712 -7587 4388
--3894 5665 -2357 5507 -1575 4604 -4991 5239 -4606 4624 -4056 4655 -3276 4157
--1055 3165 -10291 2809 -8292 3639 -3151 5203 -3588 3326 -1199 5220 -3352 7151
--5195 6149 -8130 5784 17649 6168 15515 5267 17307 6681 23517 10863 -10440 7040
-22209 -2811 9859 2193 655 6399 -6385 6074 -4719 7313 6840 7013 22318 2988
-10807 3990 1203 2301 2538 7047 -5135 8680 -2121 7202 -9600 6832 -10761 6379
--7513 6248 -15200 6544 -9507 8285 -14497 5823 -11892 2089 -16459 4211
--17706 3151 -14262 5609 -13896 4401 -13902 2890 -23086 5196 -9389 3303
--10486 3741 -12907 3935 -15605 4279 -14740 4379 -12322 3952 -10739 4084
--13871 4777 -21459 7175 -24399 7930 -25412 7855 -27005 7764 -26431 7625
--22662 7220 -18103 6853 -14585 7293 -12555 9019 -12226 11764 -13737 14519
--16687 16874 -19636 19334 -21172 21998 -21032 24049 -20215 24976 -19945 24821
--20671 23551 -21240 20655 -18581 16496 -13221 12578 -8184 10450 -5743 10630
--3917 13019 -666 15818 6367 16729 -2264 15367 -21613 11061 5158 14536
-6572 13796 11567 12137 26580 10823 35593 10814 38177 11122 35639 10042
-27155 6496 11533 455 1675 -3121 -3343 -3186 -5006 -37 -4928 5020 -3305 11556
--3687 15807 -9373 -544 -27428 -4710 -21862 -2945 -15085 -10192 -27156 -2516
-6318 16249 -15548 963 -3785 -12220 43161 35052 18600 11380 -1174 14358
--4037 -243 -6609 2614 -18248 11223 -15259 11306 18352 5621 -29938 -3394
--2617 3098 -51097 -33677 -43462 -11464 -12990 15533 -25052 11184 -25100 13056
-1356 15266 -9524 8917 1431 7215 -4266 7115 -35556 5966 15734 -7239 2969 798
--13186 6009 -16683 8682 -4958 5958 -26046 9271 -27736 10102 -5162 5885
--15637 4317 -15189 12196 -16403 4370 8126 5427 -12981 11646 -8390 9253
--5682 7790 -4296 5224 -16918 9928 -5937 7122 -13986 10636 -1208 19770
-2277 21478 2741 20546 2903 18417 4370 15544 7762 12404 12533 9928 17561 8787
-21764 9769 21552 14211 10057 22008 -11426 19429 -31360 20840 -9819 23040
--3117 29291 13401 22166 -12249 25878 -3620 24340 -6079 23512 -35532 27220
--29148 27231 -26390 21401 -26327 20005 9178 30342 25704 -2984 -3281 -11217
--28139 -5450 -43815 4412 -51755 11457 -54153 14621 -52920 14914 -49546 13581
--45059 11565 -40131 9446 -35179 7522 -30405 5915 -25924 4643 -21745 3666
--17847 2915 -14235 2317 -10853 1810 -7700 1353 -4791 941 -2113 587 312 324
-2482 187 4386 195 6016 347 7371 627 8442 1002 9247 1440 9808 1921 10175 2441
-10397 3002 10528 3619 10565 4303 10545 5053 10424 5855 10179 6682 9757 7490
-9141 8248 8325 8914 7323 9465 6180 9896 4952 10215 3720 10436 2525 10590
-1401 10693 395 10768 -484 10823 835 11367 206 11371 -1030 11209 -2192 11074
--3102 10983 -3802 10906 -4373 10830 -4835 10766 -5229 10711 -5586 10670
--5856 10633 -6007 10597 -6081 10561 -6100 10532 -6103 10508 -6112 10490
--6075 10483 -5954 10482 -5778 10489 -5592 10502 -5412 10518 -5248 10538
--5082 10564 -4881 10598 -4657 10638 -4441 10682 -4242 10729 -4072 10774
--3915 10825 -3759 10882 -3605 10945 -3474 11009 -3355 11072 -3254 11131
--3172 11192 -3115 11258 -3069 11326 -3045 11392 -3034 11455 -3028 11514
--3045 11570 -3083 11626 -3138 11682 -3204 11733 -3283 11781 -3360 11825
--3450 11865 -3558 11901 -3680 11933 -3805 11961 -3942 11988 -4068 12010
--4198 12030 -4343 12044 -4495 12053 -4650 12061 -4800 12066
-127: 11886760 -5339529 -8260 9675 -8290 9672 -8330 9672 -8350 9672 -8390 9671
--8420 9670 -8460 9665 -8500 9662 -8540 9657 -8590 9651 -8610 9645 -8660 9636
--8710 9629 -8750 9623 -8780 9613 -8830 9601 -8870 9589 -8910 9579 -8960 9567
--8990 9557 -9040 9542 -9060 9529 -9090 9515 -9140 9503 -9180 9492 -9200 9483
--9230 9470 -9270 9459 -9300 9450 -9340 9444 -9370 9440 -9400 9438 -9430 9436
--9470 9437 -9490 9440 -9550 9445 -9580 9454 -9630 9465 -9690 9478 -9740 9499
--9800 9518 -9840 9542 -9920 9567 -10000 9595 -10070 9625 -10150 9661 -10240 9701
--10330 9735 -10420 9774 -10510 9814 -10610 9855 -10710 9902 -10830 9947
--10920 9994 -11030 10031 -11120 10072 -11220 10117 -11330 10160 -11440 10199
--11520 10236 -11600 10274 -11700 10306 -11760 10335 -11830 10362 -11900 10389
--11950 10409 -12010 10432 -12050 10450 -12080 10462 -12100 10473 -12110 10479
--12130 10487 -12140 10494 -12140 10499 -12140 10501 -12120 10500 -12090 10495
--12080 10497 -12070 10500 -12070 10511 -12050 10510 -12030 10510 -12020 10515
--12020 10526 -12030 10537 -12050 10557 -12070 10574 -12110 10595 -12140 10621
--12190 10650 -12270 10686 -12340 10721 -12440 10762 -12550 10813 -12680 10861
--12800 10914 -12940 10967 -13080 11021 -13260 11082 -13440 11149 -13630 11215
--13830 11280 -14000 11336 -14180 11394 -14380 11454 -14590 11518 -14810 11580
--14990 11631 -15160 11672 -15310 11709 -15490 11743 -15650 11776 -15790 11801
--15920 11812 -16010 11819 -16090 11813 -16140 11801 -16180 11778 -16210 11745
--16190 11705 -16170 11659 -16120 11598 -16030 11527 -15920 11445 -15790 11352
--15630 11259 -15480 11162 -15300 11060 -15100 10941 -14850 10813 -14590 10681
--14350 10553 -14100 10433 -13870 10312 -13590 10182 -13310 10043 -13010 9908
--12750 9786 -12520 9678 -12310 9580 -12090 9479 -11850 9381 -11650 9292
--11480 9221 -11360 9170 -11270 9135 -11210 9107 -11160 9090 -11140 9090
--11180 9110 -11250 9145 -11370 9203 -11540 9276 -11750 9368 -11980 9481
--12270 9605 -12590 9744 -12960 9896 -13370 10077 -13847 10274 -14355 10489
--14892 10710 -15444 10931 -16021 11163 -16651 11418 -17339 11693 -18049 11974
--18766 12252 -19469 12513 -20182 12777 -20933 13059 -21724 13353 -22526 13638
--23304 13909 -24040 14157 -24763 14394 -25527 14642 -26273 14872 -26981 15088
--27669 15286 -28332 15465 -28966 15620 -29562 15760 -30115 15872 -30625 15966
--31097 16029 -31508 16067 -31878 16076 -32186 16065 -32441 16020 -32638 15950
--32753 15847 -32814 15711 -32815 15547 -32725 15359 -32585 15139 -32348 14886
--32042 14594 -31639 14270 -31190 13943 -30666 13612 -30012 13224 -29287 12805
--28540 12381 -27760 11910 -26814 11373 -25618 10849 -24449 10421 -23425 10015
--22359 9440 -21107 8687 -19589 7923 -17888 7396 -16128 7089 -14529 6827
--13332 6491 -12433 6075 -11562 5737 -10563 5595 -9301 5709 -7639 6124
--5745 6852 -4326 7895 -4349 8690 -3105 6860 -3716 6174 -164 6831 -1475 7105
-1006 6994 5312 5417 8063 5985 178 11145 873 6802 4088 8017 1898 8935 2431 10864
--3255 7068 561 7171 2616 8103 4743 7631 4084 8858 5353 8632 5293 8910 5647 8053
-5368 4504 3812 6846 -1447 8126 -2531 9499 -2172 5164 -4230 7148 -1019 9656
-4013 11018 8400 9043 6026 6902 -1379 5747 -4586 7305 -4849 2214 -4798 4811
--4068 5947 -6054 4963 -3187 5999 -3719 4953 -3481 5540 -4184 3899 -2152 3253
--7918 3105 -8711 4223 -6343 4972 -3914 2431 -2619 3011 -1167 4079 -4919 5214
--3853 4364 4323 6951 10161 6048 11162 5270 7987 4133 -300 5525 23186 4528
-21568 7534 17335 10457 12466 10130 9510 9082 8958 6387 10565 2949 4104 1777
--299 731 1221 2592 2647 9443 -6672 9706 -13341 6108 -14229 5362 -5384 4615
--11261 7799 -17404 12650 -26009 13816 -14812 3374 -15355 2410 -16691 2907
--15672 4360 -15815 4222 -14034 2876 -17755 4414 -11685 4250 -10857 3822
--13425 3994 -15902 3732 -15244 3734 -12346 3530 -11033 3639 -22662 6323
--28114 7734 -31561 8479 -33778 8705 -34579 8745 -32674 8788 -27899 8589
--21892 8348 -16581 8739 -12366 10115 -9452 12113 -8254 14041 -8446 15797
--8496 17927 -7123 20425 -4442 22572 -1874 23878 -1327 24177 -4807 23102
--12424 20102 -15438 16518 -11526 13440 -6634 11691 -7263 11140 -8869 13406
--9574 16357 4678 16622 -11319 13560 -20636 11901 -15390 12576 -15492 12906
--6173 12054 25903 10394 38260 10108 40372 10342 37169 9769 28689 7399
-16056 3462 5319 475 -2004 -191 -6425 1612 -9140 4962 -10829 8325 -12759 8331
--12206 1442 -23259 -2969 -26424 -1311 -22082 -4940 -18066 -1822 -3783 3987
--9338 -3919 3123 -10979 32542 2163 31028 -9803 14750 28158 11053 -19121
--18378 14859 -31549 -347 -2244 17150 4877 32787 -31435 -16810 -19347 -861
--27463 -7540 -51707 6673 92194 48550 -68715 -8804 -46141 -1865 11674 14116
--14668 8282 16229 9002 20652 9109 -43343 7186 -25300 1012 -24983 6658
--5935 5502 -15057 11643 20280 1348 -29846 6894 -30183 4750 -23067 2960
--21301 6058 -28015 9100 -28722 4800 26637 6761 -14680 18117 -9984 14771
--4406 10318 -2784 7284 -7447 8758 -3519 8386 -4985 11536 299 17351 2384 20226
-2291 20770 2312 19454 4395 16310 8266 12408 12994 9499 17398 8618 20128 10224
-18679 14210 9816 18787 -6154 18855 -19653 19749 -9941 21907 1143 25368
-10448 22477 -291 27422 196 28332 -4196 28216 -19263 29359 -18967 26887
--19655 19292 -28624 17094 -4104 17383 23902 -46686 452 -27902 -27226 -1666
--45301 14626 -54043 21663 -56377 22877 -54832 21040 -51137 17930 -46409 14574
--41322 11498 -36266 8916 -31442 6872 -26943 5316 -22784 4166 -18949 3319
--15400 2683 -12117 2175 -9071 1748 -6260 1377 -3668 1066 -1313 838 808 717
-2679 724 4297 859 5663 1109 6765 1449 7621 1859 8262 2320 8714 2824 9020 3371
-9223 3962 9326 4603 9347 5288 9271 6005 9084 6737 8754 7454 8252 8130 7592 8742
-6777 9264 5819 9690 4771 10023 3689 10270 2602 10449 1551 10574 573 10664
--309 10725 491 11061 -76 11097 -1106 11025 -2094 10961 -2905 10915 -3557 10860
--4105 10800 -4563 10747 -4953 10702 -5306 10669 -5585 10640 -5752 10610
--5844 10578 -5885 10552 -5913 10531 -5943 10517 -5932 10510 -5841 10508
--5700 10515 -5543 10524 -5387 10538 -5252 10556 -5113 10579 -4936 10608
--4741 10645 -4544 10684 -4370 10725 -4214 10767 -4079 10812 -3940 10863
--3796 10920 -3675 10978 -3569 11035 -3473 11089 -3404 11145 -3349 11204
--3307 11265 -3282 11327 -3268 11384 -3268 11438 -3281 11489 -3316 11540
--3366 11592 -3430 11639 -3501 11684 -3571 11724 -3656 11762 -3755 11794
--3870 11826 -3990 11852 -4111 11877 -4234 11899 -4359 11917 -4492 11931
--4633 11942 -4781 11949 -4926 11955
-128: 11917860 -5330687 -8340 9692 -8360 9691 -8400 9691 -8440 9692 -8470 9691
--8500 9690 -8540 9690 -8580 9686 -8620 9683 -8670 9677 -8690 9674 -8750 9666
--8790 9660 -8840 9653 -8870 9647 -8910 9634 -8960 9624 -9010 9613 -9040 9604
--9080 9593 -9130 9581 -9160 9569 -9180 9558 -9240 9543 -9260 9533 -9300 9523
--9330 9516 -9360 9502 -9400 9493 -9430 9488 -9470 9482 -9490 9480 -9530 9480
--9560 9478 -9600 9482 -9630 9487 -9680 9494 -9730 9504 -9780 9519 -9830 9537
--9890 9556 -9940 9579 -10010 9600 -10080 9629 -10160 9657 -10240 9691
--10320 9730 -10410 9764 -10500 9797 -10590 9836 -10680 9879 -10790 9921
--10900 9965 -10990 10008 -11090 10044 -11180 10086 -11290 10126 -11380 10166
--11490 10205 -11580 10242 -11650 10275 -11740 10307 -11800 10335 -11870 10360
--11940 10382 -11980 10400 -12040 10424 -12070 10441 -12100 10452 -12120 10460
--12130 10466 -12140 10472 -12150 10482 -12150 10483 -12140 10484 -12120 10482
--12100 10480 -12080 10479 -12070 10483 -12060 10489 -12040 10490 -12020 10491
--12000 10496 -12000 10506 -12020 10517 -12030 10537 -12050 10555 -12080 10575
--12110 10602 -12170 10630 -12230 10665 -12320 10700 -12400 10743 -12510 10789
--12630 10841 -12750 10892 -12900 10944 -13030 10999 -13200 11057 -13380 11125
--13570 11193 -13750 11255 -13930 11312 -14100 11367 -14310 11429 -14500 11493
--14720 11552 -14900 11602 -15070 11644 -15210 11679 -15380 11715 -15540 11744
--15690 11770 -15800 11784 -15900 11789 -15960 11782 -16020 11771 -16060 11747
--16080 11719 -16070 11678 -16050 11630 -15990 11574 -15910 11503 -15790 11421
--15670 11330 -15510 11237 -15370 11144 -15190 11044 -14990 10928 -14750 10801
--14490 10673 -14250 10546 -14020 10429 -13790 10311 -13530 10182 -13250 10048
--12960 9916 -12700 9796 -12480 9691 -12270 9594 -12070 9498 -11840 9400
--11650 9314 -11480 9246 -11370 9195 -11300 9160 -11230 9135 -11190 9118
--11190 9119 -11220 9139 -11310 9172 -11430 9228 -11590 9304 -11810 9392
--12050 9502 -12340 9625 -12660 9759 -13030 9909 -13440 10083 -13900 10278
--14420 10487 -14945 10702 -15494 10916 -16062 11142 -16688 11392 -17366 11658
--18066 11931 -18770 12201 -19466 12454 -20167 12709 -20904 12981 -21684 13264
--22466 13541 -23232 13802 -23953 14040 -24663 14267 -25410 14505 -26138 14725
--26830 14930 -27501 15115 -28151 15285 -28768 15429 -29350 15559 -29884 15664
--30383 15743 -30841 15798 -31233 15828 -31595 15829 -31891 15806 -32138 15754
--32319 15675 -32424 15566 -32485 15421 -32460 15252 -32397 15056 -32248 14833
--32011 14582 -31681 14285 -31299 13959 -30876 13637 -30349 13295 -29705 12915
--28971 12509 -28260 12087 -27512 11638 -26526 11119 -25421 10608 -24357 10215
--23306 9839 -22224 9316 -21063 8603 -19726 7918 -18126 7431 -16393 7099
--14888 6822 -13709 6489 -12664 6163 -11622 5969 -10508 6039 -9230 6439
--7756 7145 -6398 8034 -5677 8847 -5785 8899 -6215 6716 -6281 4530 -901 6410
-1273 7502 2083 7355 4120 5671 6220 6286 3361 8514 3649 7145 4730 7716 -1561 8780
--1328 9769 1190 7251 3714 7173 3616 7964 4285 7635 2117 9673 5411 8141
-4491 8976 5660 7010 4199 6562 4260 10532 -3809 8887 -3708 8332 -2948 6194
--4358 6245 2374 8671 1604 11088 6208 10840 4365 7313 -3734 549 -3148 9136
--3941 6986 -5160 3274 -5252 4442 -5741 5215 -3853 6430 -3982 5358 -4841 7221
--5134 4988 -4654 974 -7706 1835 -9217 3927 -8176 5533 -1884 1729 -293 2039
-2 2607 -6926 5882 -7963 4786 -3331 5595 4794 5047 2930 3087 -7023 -3458
--858 4700 30072 11729 37888 14379 38566 15893 35704 15032 28768 12099
-11861 6253 -3703 2325 -8452 1062 -6775 945 -1928 1592 9857 3956 -11162 7357
--15056 2562 -11096 912 -2519 1561 -4299 6682 -18965 16490 -42836 25979
--16912 5466 -17166 4713 -17980 5125 -16618 3949 -15448 2626 -16242 3540
--16510 3951 -13701 4231 -13062 4278 -14927 4646 -18196 3605 -18197 3959
--16692 4227 -17345 4689 -24981 6372 -31217 7687 -36383 8711 -40155 9351
--41410 9773 -38977 10023 -32660 9871 -23983 9505 -16621 9772 -10659 10754
--5652 12026 -2383 13307 -598 14651 1350 16462 4640 18748 8980 20986 13045 22684
-14595 23488 9396 22577 -8071 18822 -15706 15830 -10602 13750 -3190 12730
--6244 10855 -8137 12947 -12553 15404 -3558 15675 -8964 13863 -15409 12835
--19588 12889 -29776 13071 -25465 12657 26588 10007 35487 9371 36611 9615
-34938 9663 27811 8456 16761 5870 5676 3339 -2796 2150 -8634 2636 -13060 4116
--15921 5368 -17822 4650 -16606 1975 -22547 231 -23116 906 -21277 -387
--17146 609 -9983 1419 -6546 -4478 7235 -13118 27789 -15229 38151 -22878
-36750 -14507 -12097 1951 -13136 45268 -32749 14260 -7100 9540 -14818 13913
--15402 4715 -7814 4611 -9551 -4216 -18357 12549 44083 26501 -52280 -1887
-35946 13394 -11477 6396 -42007 2113 -9200 7126 18079 9093 -23481 9447
--30455 2946 -34534 10070 4357 2273 -16831 12457 -10882 9616 -29240 8600
--19600 1468 -23658 4425 -28419 8820 -32963 11056 -36351 10401 -15684 9400
--1247 22907 224 16882 3219 10703 3608 7783 1825 7846 3145 8056 3396 10025
-3966 14153 2774 17854 402 20183 -1135 20319 1480 16805 5820 11592 10206 8056
-13387 7355 14462 9430 12255 13352 5836 17218 -3458 18953 -11927 18516
--9531 18372 2483 17249 14000 26255 10435 30874 6321 31423 462 30733 -6950 29418
--7165 23048 -9017 1177 -27384 -18532 -15666 60340 40409 -112084 -847 -36479
--32663 10493 -49487 28886 -56345 33177 -57349 31266 -55102 26937 -51121 22023
--46356 17407 -41345 13465 -36417 10295 -31742 7857 -27387 6041 -23369 4722
--19676 3776 -16260 3089 -13114 2568 -10196 2154 -7500 1809 -5012 1529
--2744 1325 -688 1219 1144 1222 2735 1342 4099 1565 5218 1877 6118 2256
-6814 2691 7333 3172 7703 3695 7962 4257 8118 4856 8179 5486 8149 6134 8019 6789
-7766 7431 7370 8040 6840 8601 6176 9094 5382 9510 4502 9846 3552 10109
-2576 10306 1614 10453 682 10557 -178 10631 165 10809 -375 10861 -1223 10857
--2048 10851 -2755 10843 -3355 10812 -3883 10768 -4323 10724 -4708 10689
--5053 10663 -5338 10642 -5520 10618 -5629 10589 -5694 10566 -5740 10548
--5792 10536 -5800 10530 -5737 10529 -5624 10533 -5491 10542 -5367 10553
--5259 10569 -5144 10589 -4986 10615 -4815 10647 -4646 10682 -4489 10720
--4353 10756 -4230 10797 -4103 10843 -3982 10894 -3865 10946 -3769 10999
--3689 11047 -3621 11097 -3572 11152 -3533 11207 -3509 11263 -3496 11315
--3499 11365 -3509 11411 -3540 11458 -3585 11506 -3645 11549 -3713 11591
--3777 11628 -3855 11662 -3950 11694 -4057 11722 -4168 11748 -4283 11770
--4397 11792 -4516 11810 -4640 11823 -4775 11834 -4910 11841 -5049 11848
-129: 11948980 -5321843 -8410 9707 -8440 9708 -8470 9707 -8510 9709 -8540 9712
--8580 9711 -8610 9711 -8660 9707 -8700 9706 -8740 9703 -8780 9698 -8820 9695
--8870 9689 -8920 9681 -8950 9676 -9000 9665 -9040 9656 -9090 9647 -9130 9639
--9160 9629 -9210 9618 -9250 9606 -9270 9594 -9320 9582 -9350 9571 -9390 9563
--9420 9555 -9450 9544 -9490 9531 -9510 9530 -9550 9522 -9590 9521 -9620 9520
--9640 9519 -9690 9522 -9720 9525 -9770 9533 -9810 9541 -9860 9556 -9920 9573
--9970 9591 -10030 9614 -10100 9633 -10160 9660 -10230 9688 -10320 9720
--10400 9758 -10490 9789 -10570 9822 -10660 9859 -10750 9897 -10860 9940
--10950 9982 -11050 10022 -11150 10058 -11240 10097 -11350 10135 -11430 10173
--11540 10211 -11630 10247 -11700 10276 -11770 10307 -11830 10334 -11920 10356
--11960 10378 -12020 10396 -12060 10418 -12090 10431 -12130 10442 -12130 10449
--12140 10453 -12160 10460 -12160 10467 -12160 10470 -12140 10468 -12130 10466
--12090 10465 -12080 10461 -12060 10464 -12060 10471 -12030 10474 -12010 10474
--11990 10477 -11990 10487 -11990 10499 -12020 10517 -12030 10535 -12060 10557
--12100 10582 -12140 10612 -12200 10645 -12280 10681 -12370 10721 -12470 10768
--12590 10821 -12720 10871 -12840 10922 -12980 10975 -13150 11037 -13330 11100
--13500 11170 -13690 11232 -13870 11287 -14030 11342 -14220 11403 -14430 11466
--14630 11522 -14810 11574 -14980 11617 -15120 11652 -15280 11685 -15430 11715
--15580 11740 -15690 11754 -15790 11758 -15840 11753 -15910 11740 -15940 11719
--15960 11689 -15950 11651 -15920 11604 -15860 11548 -15790 11478 -15680 11397
--15550 11309 -15400 11218 -15250 11125 -15080 11026 -14890 10917 -14650 10791
--14400 10664 -14170 10540 -13930 10426 -13720 10312 -13460 10183 -13180 10053
--12910 9923 -12660 9809 -12440 9705 -12250 9611 -12050 9516 -11830 9420
--11640 9337 -11490 9271 -11380 9222 -11320 9187 -11260 9164 -11230 9149
--11230 9149 -11270 9170 -11350 9203 -11490 9257 -11660 9331 -11860 9420
--12120 9527 -12400 9645 -12730 9777 -13090 9923 -13500 10094 -13960 10285
--14470 10489 -15000 10697 -15540 10907 -16099 11125 -16718 11370 -17389 11628
--18078 11891 -18770 12153 -19456 12399 -20141 12645 -20870 12909 -21633 13183
--22402 13449 -23152 13702 -23858 13930 -24555 14144 -25285 14378 -25989 14585
--26673 14778 -27328 14953 -27962 15110 -28562 15249 -29122 15368 -29649 15463
--30136 15530 -30568 15577 -30956 15597 -31307 15592 -31593 15558 -31825 15500
--31991 15415 -32103 15296 -32136 15144 -32129 14968 -32052 14766 -31895 14547
--31662 14284 -31333 13996 -30978 13667 -30547 13336 -30020 13008 -29384 12635
--28679 12217 -28000 11824 -27227 11393 -26268 10877 -25289 10398 -24205 10022
--23090 9677 -22058 9179 -21050 8560 -19836 7965 -18295 7496 -16686 7149
--15277 6850 -14024 6532 -12844 6255 -11705 6151 -10571 6362 -9364 6909
--8128 7705 -7203 8569 -6901 9191 -7041 9080 -7128 7565 -6690 3923 -3003 4751
-2489 7427 3025 6663 1743 6818 3123 6709 4187 6895 4598 6940 3472 7305 -1271 7669
--2738 7545 5049 8538 5633 8469 6616 8620 5062 8547 3697 9535 4459 8637
-2110 10875 1365 6697 -349 9511 -4577 11427 -600 8002 -4043 7535 -5706 5726
--5835 4708 -1246 5823 9171 12538 10262 13554 7425 11412 -4121 -295 -4790 4168
--4909 5127 -5503 3727 -5743 4117 -5755 4897 -4885 5764 -4827 5768 -5374 6344
--5795 4567 -6198 1675 -7817 1388 -8607 2825 -7103 4887 -2721 4450 -861 4895
--1456 5647 -6700 4758 -11214 3492 -8286 3949 5734 3798 3593 2325 -6145 197
--3385 3676 20106 11921 44119 17844 52554 20170 52703 19204 45353 15358
-12996 5704 -18581 1261 -21051 650 -14883 1924 -14052 762 6689 -74 -3533 3355
--11239 -3444 -5884 -4748 5959 -4208 12908 -153 -60 10296 -44453 28303
--38188 21236 -30305 16677 -24264 12718 -19210 6416 -16686 3218 -16501 2734
--16410 2855 -15257 3568 -15479 3833 -17800 4478 -21560 4750 -22867 5325
--22154 5546 -22351 5651 -26710 6402 -32751 7530 -39232 8787 -44595 9849
--47001 10702 -44796 11244 -36743 11050 -23678 10253 -14891 10369 -8414 10998
--1736 11444 3040 12219 5696 13298 8262 14820 11876 16873 16399 19101 21077 21125
-24184 22524 20319 22182 -11793 16978 -16651 14731 -11869 13260 -5683 12413
--4527 11702 -3987 12972 -3708 14666 1476 15023 730 14151 -4604 13545 -13089 13401
--17699 13321 -9006 12817 -1243 11169 15957 9311 23808 9305 28763 9946
-23997 9579 13908 7832 2441 5579 -5893 4048 -11228 3550 -15963 3559 -18099 3792
--18949 3362 -18259 2189 -19718 3162 -22645 3232 -20259 3096 -17893 4115
--14274 4652 -9765 483 3656 -11335 15705 -15304 22627 -17001 21447 -11241
--3042 7913 -18398 36324 -35562 31164 -24835 23133 2898 -3057 15101 -12298
-21558 -15982 6641 -8529 -18954 2082 -13919 14377 -15839 9395 11285 6928
--7654 9998 -21814 8268 -14446 11592 34468 15413 -12799 17854 -22290 -1367
--48052 14429 32266 -9529 -31345 14636 -37607 15312 -39611 12500 -7143 -1169
--21790 7199 -24686 13661 -28225 15560 -38981 17803 -27937 20068 -13132 24150
--641 13104 7787 7726 8567 6855 7932 7372 9662 7119 11267 7132 8083 10621
-2969 15344 -2884 19740 -7946 22241 -3241 17499 2287 9674 6371 5410 8170 5169
-7913 8250 5659 13079 1741 17187 -435 20351 -5995 16207 -6780 11671 160 10830
-19728 31582 17085 33226 10174 31426 2956 29526 -2351 27386 -2072 23087
--461 15622 -13942 9807 1372 5927 56449 -198826 -19312 -11154 -44454 30690
--53936 40754 -56648 40495 -55822 36114 -53030 30308 -49134 24440 -44705 19178
--40109 14788 -35587 11304 -31269 8642 -27228 6671 -23476 5244 -20008 4228
--16801 3502 -13833 2970 -11076 2560 -8516 2235 -6157 1975 -3982 1792 -2001 1695
--229 1697 1329 1802 2675 2002 3808 2284 4731 2632 5466 3040 6030 3492 6453 3986
-6760 4516 6954 5075 7058 5655 7069 6245 6988 6836 6797 7416 6498 7970 6079 8485
-5539 8947 4890 9349 4146 9683 3326 9953 2465 10165 1585 10327 716 10447
--102 10536 -121 10614 -642 10673 -1350 10712 -2039 10748 -2654 10768 -3205 10757
--3702 10729 -4128 10695 -4503 10670 -4845 10652 -5122 10638 -5315 10618
--5443 10594 -5521 10572 -5588 10559 -5657 10548 -5686 10544 -5642 10543
--5557 10546 -5449 10553 -5352 10564 -5265 10576 -5171 10594 -5038 10618
--4886 10646 -4741 10677 -4601 10711 -4487 10743 -4376 10780 -4262 10822
--4151 10866 -4045 10915 -3964 10962 -3886 11005 -3830 11051 -3786 11100
--3746 11151 -3729 11201 -3714 11249 -3719 11293 -3728 11337 -3758 11379
--3802 11423 -3850 11464 -3916 11501 -3980 11535 -4049 11568 -4141 11597
--4238 11623 -4346 11648 -4451 11669 -4557 11689 -4668 11707 -4789 11719
--4912 11730 -5044 11739 -5171 11745
-130: 11980120 -5313001 -8480 9722 -8510 9721 -8540 9724 -8580 9727 -8610 9730
--8650 9730 -8680 9731 -8730 9728 -8770 9726 -8820 9725 -8850 9723 -8890 9719
--8950 9714 -8990 9711 -9030 9702 -9070 9693 -9120 9687 -9170 9678 -9200 9671
--9250 9663 -9280 9650 -9320 9640 -9360 9629 -9400 9618 -9430 9608 -9470 9601
--9500 9590 -9540 9582 -9560 9571 -9600 9565 -9630 9560 -9660 9560 -9700 9559
--9740 9558 -9760 9559 -9810 9562 -9840 9567 -9890 9579 -9940 9592 -10000 9607
--10050 9625 -10100 9643 -10180 9665 -10230 9690 -10310 9716 -10390 9748
--10470 9782 -10560 9816 -10630 9845 -10720 9880 -10810 9915 -10920 9959
--11020 9998 -11110 10036 -11200 10073 -11300 10107 -11390 10143 -11480 10181
--11580 10217 -11670 10249 -11730 10280 -11810 10306 -11880 10332 -11940 10354
--11990 10376 -12040 10391 -12080 10410 -12120 10424 -12140 10432 -12150 10438
--12160 10443 -12160 10447 -12170 10453 -12170 10456 -12150 10455 -12120 10452
--12100 10450 -12080 10446 -12060 10447 -12040 10454 -12030 10456 -12010 10459
--11980 10460 -11980 10469 -11980 10481 -11990 10498 -12020 10517 -12040 10540
--12070 10563 -12120 10594 -12180 10625 -12250 10662 -12350 10701 -12430 10749
--12550 10800 -12680 10851 -12800 10902 -12940 10953 -13100 11015 -13270 11078
--13450 11143 -13630 11209 -13790 11262 -13970 11318 -14150 11377 -14350 11438
--14550 11495 -14730 11548 -14880 11589 -15030 11623 -15180 11655 -15340 11687
--15470 11709 -15590 11724 -15670 11728 -15730 11723 -15800 11712 -15820 11690
--15840 11659 -15830 11621 -15800 11578 -15750 11522 -15680 11454 -15550 11375
--15440 11287 -15290 11199 -15140 11107 -14980 11011 -14780 10904 -14560 10781
--14310 10655 -14080 10535 -13860 10424 -13640 10311 -13400 10185 -13120 10058
--12860 9934 -12620 9821 -12410 9721 -12220 9627 -12020 9535 -11820 9443
--11650 9362 -11500 9297 -11400 9250 -11330 9217 -11290 9196 -11260 9179
--11270 9182 -11320 9202 -11400 9235 -11550 9289 -11710 9360 -11930 9449
--12170 9554 -12470 9669 -12790 9798 -13150 9942 -13560 10107 -14020 10294
--14520 10494 -15040 10697 -15580 10900 -16130 11113 -16740 11351 -17403 11602
--18083 11858 -18765 12112 -19439 12349 -20112 12588 -20824 12843 -21576 13105
--22330 13363 -23063 13608 -23758 13825 -24438 14032 -25148 14252 -25838 14454
--26506 14636 -27147 14798 -27764 14946 -28349 15076 -28890 15185 -29405 15269
--29870 15333 -30292 15367 -30682 15377 -31011 15364 -31282 15322 -31502 15257
--31672 15164 -31756 15037 -31804 14880 -31788 14698 -31700 14496 -31543 14265
--31309 14018 -31007 13712 -30642 13387 -30204 13070 -29685 12738 -29083 12345
--28421 11964 -27713 11588 -26918 11154 -26075 10667 -25122 10206 -23969 9843
--22877 9497 -21968 9068 -21050 8548 -19848 8020 -18401 7560 -16953 7218
--15573 6913 -14237 6597 -13007 6338 -11880 6289 -10771 6554 -9650 7107
--8607 7855 -7925 8578 -7718 8981 -7640 8667 -7255 7330 -6205 5236 -3473 5481
-118 6939 -326 5827 1534 6530 2789 6333 3563 6122 5144 6849 4277 7193 1960 7522
-1702 7230 4287 7509 6020 8162 5913 9313 5121 10238 4073 11890 2779 13263
--2368 12248 -10924 7753 -326 8636 -154 8669 -844 7867 -4531 5589 -5471 8138
--5136 3323 258 3244 7176 9196 8524 11441 5559 9557 -1567 3234 -4103 3568
--5020 4236 -5685 3964 -6044 4088 -6048 4545 -5606 5213 -5438 5652 -5682 5835
--6085 4589 -6686 2439 -7685 1188 -8089 1675 -6698 5138 -3617 7091 -2296 7310
--2990 6728 -6251 5175 -8810 3778 -5757 3422 5957 3718 5827 2614 -7559 2266
--7037 3863 8150 12499 45659 20692 55035 23196 52995 21149 39754 15308
-11224 6568 -17068 612 -24766 -1237 -16407 -390 -11033 -1448 -2384 -1790
--6148 -164 -10656 -4082 -5385 -7002 10269 -8568 30117 -7575 29240 150
--52157 34225 -49730 33320 -37180 27832 -27214 21425 -19454 9218 -16431 4389
--15867 2552 -16081 2425 -16537 2335 -17082 2715 -20188 4225 -26358 6028
--29049 7072 -27820 6952 -25514 6159 -27210 6211 -32683 7256 -39961 8690
--46638 10102 -50513 11422 -49497 12350 -40451 12232 -19723 10395 -11920 10545
--7280 11051 1271 10365 7049 10888 9179 11949 10856 13200 13106 14878 15998 16882
-19098 18932 20374 20421 14140 20049 -5082 16879 -11728 14582 -10152 13042
--5663 12347 -1606 12260 2669 13255 7302 14429 13154 14707 15481 14293
-10976 13892 -3951 13774 -8798 13594 -6697 13276 -6444 12530 6224 9336
-11329 9438 22249 10659 17687 10785 8085 9530 -4348 7395 -11222 5827 -13910 4792
--17409 3430 -17927 3231 -18256 3190 -18029 3717 -18229 3776 -21420 5221
--17546 5216 -17255 6929 -16488 9297 -16420 9507 -3210 -6973 -898 -6351
--201 -2545 6160 -2302 7080 5301 -17830 25917 -40420 37544 -42452 39791
-23902 -18757 36293 -26466 45966 -37207 12879 -13264 -21 -9369 -31061 21251
--17876 14811 -2207 7016 -5007 2255 -4044 7622 3088 6690 3348 43443 -14285 36200
--15539 -1987 -22499 -4884 5898 -10799 -24337 3618 -37539 8363 -38962 5184
--24488 -2984 -8158 19431 -16011 21714 -26885 19239 -27796 21865 -26236 26743
--22030 26866 -4442 7205 8219 5066 7934 7392 8206 8937 12885 7287 19182 3248
-10843 7257 1701 13313 -7421 19682 -19681 26529 -7342 18255 706 6216 4047 1799
-3941 2632 2662 7648 1150 14991 -1524 19339 4073 25082 -946 15080 -1817 9497
-5315 12983 18351 26779 16467 27612 9160 25617 1097 23505 -4752 20561 -4517 14929
-4424 6514 2814 13220 18735 11062 33598 -138349 -21104 -39648 -42786 13753
--49490 33059 -50965 36989 -50170 34527 -48044 29685 -45033 24337 -41489 19362
--37689 15123 -33846 11711 -30090 9073 -26509 7099 -23134 5658 -19981 4626
--17033 3891 -14282 3358 -11712 2958 -9322 2647 -7094 2407 -5034 2238 -3145 2149
--1440 2151 71 2242 1393 2420 2519 2674 3457 2994 4219 3368 4816 3790 5280 4253
-5614 4747 5847 5268 5988 5802 6035 6344 5995 6880 5861 7407 5638 7914 5310 8387
-4884 8821 4347 9205 3733 9532 3026 9804 2263 10025 1474 10199 679 10334
--94 10435 -361 10467 -867 10529 -1467 10592 -2058 10652 -2598 10693 -3098 10699
--3569 10682 -3978 10660 -4341 10643 -4672 10635 -4947 10626 -5140 10610
--5282 10592 -5382 10573 -5462 10561 -5540 10555 -5583 10551 -5560 10551
--5503 10553 -5421 10559 -5340 10568 -5272 10580 -5199 10596 -5090 10617
--4958 10641 -4829 10669 -4711 10699 -4608 10728 -4517 10761 -4414 10798
--4313 10839 -4222 10882 -4145 10925 -4078 10964 -4027 11005 -3988 11049
--3953 11096 -3936 11141 -3924 11185 -3926 11225 -3939 11264 -3968 11304
--4008 11344 -4055 11381 -4113 11415 -4175 11447 -4236 11477 -4326 11504
--4415 11529 -4517 11552 -4617 11572 -4715 11591 -4819 11607 -4933 11621
--5048 11630 -5174 11640 -5294 11646
-131: 12011280 -5304157 -8550 9733 -8580 9737 -8600 9739 -8650 9744 -8680 9747
--8710 9745 -8750 9746 -8800 9748 -8840 9746 -8870 9749 -8930 9743 -8970 9741
--9010 9738 -9060 9734 -9090 9727 -9150 9723 -9190 9716 -9240 9707 -9280 9700
--9310 9692 -9350 9682 -9400 9673 -9430 9660 -9470 9652 -9510 9642 -9540 9634
--9580 9625 -9610 9617 -9640 9606 -9670 9602 -9710 9596 -9740 9596 -9780 9594
--9800 9593 -9840 9596 -9880 9597 -9910 9601 -9970 9611 -10010 9625 -10070 9640
--10120 9655 -10180 9675 -10230 9695 -10310 9716 -10380 9745 -10450 9774
--10530 9805 -10620 9840 -10690 9867 -10780 9899 -10880 9936 -10970 9975
--11070 10012 -11160 10052 -11260 10085 -11340 10117 -11430 10152 -11520 10188
--11630 10221 -11700 10253 -11770 10282 -11840 10309 -11910 10330 -11960 10352
--12020 10371 -12070 10389 -12100 10401 -12130 10416 -12160 10425 -12160 10429
--12180 10431 -12170 10437 -12180 10439 -12170 10444 -12150 10444 -12130 10438
--12090 10436 -12080 10431 -12050 10433 -12040 10438 -12030 10438 -12000 10443
--11970 10444 -11970 10453 -11970 10465 -11980 10481 -12000 10501 -12020 10521
--12060 10547 -12090 10575 -12160 10605 -12230 10645 -12320 10684 -12400 10729
--12520 10781 -12640 10831 -12760 10880 -12900 10934 -13050 10992 -13220 11055
--13400 11120 -13570 11185 -13730 11239 -13900 11292 -14090 11351 -14280 11413
--14470 11469 -14640 11520 -14800 11559 -14940 11593 -15090 11627 -15240 11657
--15360 11680 -15490 11694 -15560 11698 -15630 11693 -15680 11683 -15720 11660
--15720 11631 -15710 11593 -15690 11550 -15640 11495 -15550 11430 -15450 11353
--15320 11267 -15180 11180 -15040 11090 -14880 10996 -14680 10889 -14470 10771
--14230 10648 -13990 10529 -13790 10422 -13570 10311 -13330 10191 -13070 10065
--12820 9944 -12580 9833 -12370 9735 -12200 9646 -12000 9555 -11820 9466
--11640 9387 -11510 9325 -11410 9280 -11360 9249 -11320 9226 -11290 9214
--11310 9215 -11360 9236 -11460 9270 -11600 9323 -11770 9392 -11980 9479
--12240 9582 -12520 9697 -12850 9821 -13200 9962 -13620 10125 -14070 10306
--14570 10501 -15080 10701 -15610 10898 -16160 11106 -16760 11334 -17410 11579
--18077 11830 -18754 12075 -19412 12305 -20075 12537 -20774 12783 -21511 13035
--22247 13284 -22970 13519 -23649 13729 -24311 13926 -25007 14136 -25675 14328
--26333 14501 -26959 14654 -27556 14794 -28128 14911 -28653 15007 -29149 15089
--29603 15142 -30017 15170 -30392 15168 -30703 15147 -30965 15099 -31188 15028
--31334 14926 -31418 14793 -31470 14628 -31425 14444 -31346 14229 -31196 14016
--30970 13747 -30673 13451 -30284 13136 -29858 12812 -29378 12465 -28817 12105
--28139 11733 -27380 11345 -26652 10931 -25893 10482 -24890 10036 -23734 9663
--22767 9342 -21933 8979 -20959 8529 -19742 8031 -18431 7621 -17113 7308
--15729 7003 -14406 6680 -13247 6437 -12179 6408 -11110 6629 -10035 7100
--9040 7724 -8352 8299 -8000 8540 -7680 8190 -7154 7202 -6376 6014 -5076 5780
--3666 5969 -3231 5338 1482 5946 3733 6433 4897 6665 5166 6489 5243 6973
-4205 7621 3612 6335 4731 7075 5529 7872 5427 9114 4781 10537 3754 12372
-2124 13640 -853 13275 -3834 11409 -7618 5544 -4176 6386 -2692 7057 -4392 -116
--5616 5295 -4815 5735 -911 6247 3509 8971 4909 10052 3116 8526 -837 5247
--3383 4428 -4832 4455 -5798 4278 -6329 4156 -6367 4357 -6027 4986 -5729 5753
--5697 6201 -5875 5598 -6316 3909 -7043 1868 -7620 713 -6824 5784 -4366 8932
--3636 8606 -3339 7135 -4882 5531 -5314 4364 -2198 4001 3846 4019 3140 3009
--4642 1022 -1209 4774 8544 15633 32579 23502 44888 25852 44936 22900 31389 15397
-8496 6488 -17012 -1244 -27524 -4099 -13015 -1782 -7108 -3105 -8117 -1719
--11924 -1485 -17154 -2811 -15698 -6147 -2967 -7916 21633 -5778 18586 4520
--20846 26596 -29495 32674 -25632 30567 -19933 24068 -15457 13736 -13976 6717
--14255 3095 -15256 2510 -17187 1343 -16974 1352 -20834 3782 -32380 7356
--36539 8831 -33551 8051 -26135 5746 -25373 5504 -30486 6731 -38152 8402
--45414 10023 -50186 11609 -50811 12967 -43667 13422 -11048 9689 -9498 10434
--9283 11227 2228 8891 7894 10067 8403 11235 8608 11957 8688 13043 9244 14639
-10780 16612 12283 18418 7689 18398 -2367 16496 -7175 14471 -7279 12978
--4080 12366 1743 12626 9371 13610 17235 14482 24929 14639 30262 14369
-28932 13951 4462 13917 1467 13464 2218 12869 -113 12518 598 10939 3866 10839
-10591 11457 6571 11842 -204 11018 -13563 8860 -17945 7661 -19495 6674
--12416 3629 -14793 3722 -16736 4290 -17466 5010 -17303 4074 -17958 4990
--15771 5311 -12557 6983 -12415 8626 -16919 10933 -12781 3849 -16873 6372
--22864 14285 -7047 4806 23106 -3381 -10346 10760 -27375 21271 -27242 21744
-3316 5928 15895 -3257 34957 -27453 11917 -8943 -3919 3397 -8161 5744 -3952 7051
--654 9106 -2799 9527 246 2410 439 12190 -6863 42158 -17277 45330 -4770 -17028
--8494 -20350 -4880 -15321 -19780 -3281 -29598 4309 -29782 6028 -20456 4709
--7088 18614 -11071 22132 -27829 14571 -13698 17938 -16533 23898 -14089 16465
--10738 12865 -5822 10962 -2062 12545 946 13970 10250 10459 29277 -2296
-9070 5531 -3601 13144 -12677 19800 -38111 33538 -6310 15024 6107 2613
-5059 -1425 1512 574 -328 8125 1974 21604 1995 28558 3486 28134 -1499 9261
--1099 4360 7417 11918 20068 24946 14259 19522 6162 16946 -2399 15278 -9749 12125
--11921 4592 7144 -15051 2706 370 6372 6985 27280 -60997 -24068 -21132
--31426 5691 -35895 21514 -39139 27920 -40675 28379 -40601 25781 -39276 21983
--37092 18038 -34388 14470 -31413 11484 -28362 9107 -25343 7285 -22424 5931
--19636 4945 -16989 4236 -14491 3719 -12137 3336 -9923 3043 -7846 2820
--5911 2665 -4123 2583 -2499 2582 -1043 2663 244 2821 1351 3049 2296 3338
-3067 3681 3691 4071 4178 4500 4541 4960 4799 5442 4970 5935 5047 6433 5043 6923
-4963 7405 4802 7868 4550 8307 4207 8712 3776 9076 3265 9394 2658 9664 1995 9888
-1290 10071 562 10217 -142 10332 -564 10351 -1055 10417 -1584 10492 -2092 10566
--2574 10619 -3034 10636 -3479 10632 -3868 10619 -4217 10611 -4539 10610
--4804 10607 -5000 10598 -5152 10581 -5267 10568 -5356 10559 -5446 10553
--5497 10553 -5496 10553 -5461 10554 -5399 10560 -5335 10568 -5292 10579
--5228 10593 -5137 10612 -5030 10633 -4917 10658 -4815 10685 -4727 10711
--4647 10740 -4558 10774 -4467 10810 -4387 10849 -4318 10887 -4261 10923
--4217 10960 -4180 11000 -4151 11041 -4136 11083 -4126 11123 -4127 11159
--4142 11195 -4167 11231 -4204 11268 -4252 11301 -4305 11333 -4363 11363
--4424 11390 -4504 11415 -4588 11439 -4681 11460 -4776 11478 -4871 11497
--4969 11513 -5074 11525 -5184 11536 -5302 11544 -5416 11551
-132: 12042450 -5295311 -8620 9745 -8630 9748 -8670 9753 -8700 9758 -8750 9762
--8770 9762 -8820 9764 -8860 9764 -8900 9765 -8950 9765 -8980 9764 -9030 9763
--9090 9759 -9110 9756 -9160 9751 -9220 9748 -9260 9740 -9300 9734 -9340 9727
--9380 9720 -9420 9712 -9470 9702 -9500 9691 -9540 9683 -9580 9674 -9600 9666
--9640 9658 -9680 9649 -9720 9641 -9740 9634 -9770 9630 -9810 9629 -9850 9627
--9870 9626 -9910 9627 -9940 9630 -9980 9636 -10040 9644 -10080 9655 -10120 9670
--10190 9686 -10240 9703 -10300 9723 -10360 9744 -10440 9770 -10510 9797
--10590 9827 -10670 9860 -10760 9888 -10830 9922 -10930 9954 -11030 9991
--11110 10026 -11210 10064 -11300 10097 -11390 10128 -11460 10161 -11570 10195
--11650 10225 -11740 10257 -11800 10286 -11870 10308 -11930 10329 -11990 10351
--12040 10369 -12090 10381 -12110 10395 -12150 10410 -12170 10417 -12180 10420
--12180 10423 -12180 10425 -12180 10429 -12180 10431 -12160 10432 -12130 10426
--12090 10422 -12070 10418 -12060 10419 -12040 10423 -12020 10426 -11990 10428
--11970 10429 -11960 10437 -11950 10450 -11980 10465 -11980 10483 -12010 10504
--12030 10531 -12080 10559 -12140 10589 -12210 10625 -12290 10666 -12380 10710
--12490 10761 -12600 10812 -12730 10861 -12860 10913 -13000 10972 -13180 11033
--13340 11098 -13520 11160 -13680 11215 -13840 11266 -14010 11327 -14210 11387
--14400 11442 -14560 11492 -14720 11531 -14850 11565 -15000 11598 -15140 11628
--15270 11650 -15390 11663 -15460 11669 -15520 11662 -15580 11652 -15600 11631
--15610 11603 -15610 11564 -15570 11522 -15520 11473 -15450 11404 -15340 11331
--15220 11247 -15070 11160 -14930 11074 -14780 10981 -14600 10876 -14370 10760
--14150 10641 -13920 10526 -13710 10419 -13500 10312 -13270 10194 -13020 10075
--12770 9954 -12540 9846 -12350 9749 -12170 9664 -11990 9576 -11810 9491
--11650 9414 -11510 9353 -11430 9310 -11380 9281 -11350 9260 -11330 9248
--11340 9251 -11410 9271 -11500 9306 -11650 9357 -11830 9428 -12040 9513
--12290 9612 -12580 9726 -12900 9849 -13260 9985 -13670 10143 -14120 10323
--14600 10513 -15120 10706 -15640 10900 -16180 11102 -16770 11323 -17410 11561
--18080 11806 -18730 12043 -19377 12266 -20032 12489 -20717 12728 -21437 12972
--22164 13213 -22866 13438 -23530 13640 -24177 13826 -24862 14028 -25510 14209
--26148 14375 -26760 14521 -27344 14648 -27899 14757 -28408 14846 -28884 14916
--29333 14962 -29738 14981 -30086 14972 -30391 14943 -30653 14887 -30863 14812
--30989 14701 -31083 14562 -31116 14395 -31067 14199 -30994 13995 -30855 13756
--30629 13502 -30310 13216 -29926 12883 -29548 12559 -29105 12236 -28518 11881
--27798 11495 -27075 11118 -26447 10745 -25669 10312 -24628 9868 -23598 9511
--22724 9217 -21826 8880 -20730 8451 -19553 8025 -18403 7692 -17156 7415
--15832 7110 -14640 6792 -13593 6567 -12556 6501 -11468 6628 -10342 6975
--9261 7478 -8402 7912 -7860 8063 -7477 7781 -7177 7111 -6933 6337 -6496 5840
--5672 5438 -4205 4905 -411 5059 3576 6149 5265 6324 5958 6750 5581 6786
-4991 7691 4979 6445 4850 6720 4825 7213 4741 8163 3999 9511 2902 11373
-1083 11835 -1314 10874 -3751 8882 -6455 5563 -4765 3654 -2973 1172 -3191 -1727
--5849 7954 -5347 10484 -2785 10341 110 10432 1439 9927 756 8331 -1334 6299
--3341 5349 -4934 5008 -6095 4635 -6700 4297 -6676 4389 -6259 5154 -5769 6376
--5396 7477 -5165 7772 -5146 6993 -5438 5481 -5961 4101 -6371 4847 -6520 6308
--5820 7587 -2474 6509 -4345 4954 -2916 4484 24 4477 3223 4723 2473 4277
--3951 -690 4503 4728 4302 19585 18939 26611 32841 28884 38526 25997 27669 16890
-6509 5700 -17087 -4210 -25925 -7492 -15578 -721 -7605 -4056 -11931 -806
--16528 -1432 -25068 -27 -30140 -4232 -25574 -5537 9228 -2656 8648 6957
-2933 21561 -4143 29117 -6835 29580 -7227 24569 -7810 15836 -9786 7797
--12014 2802 -14334 2484 -16395 1558 -14373 576 -19843 2480 -39209 8453
--43915 10103 -39102 8604 -22688 3845 -20912 4179 -26570 6244 -34188 8113
--40706 9505 -44066 10857 -42346 12108 -32383 12280 -11811 10376 -12229 10536
--9942 9984 -1238 7930 -917 12420 2073 11775 2628 11258 733 11569 -1020 12622
--519 14410 4289 16981 1854 17199 -2967 15792 -4204 14095 -5044 12766 -3295 12235
-3736 12757 14399 13964 23770 14658 31360 14758 35921 14525 34076 14074
-21491 13736 17486 13173 16294 12566 11041 12294 -2507 12088 -2941 12018
-1831 11900 -7292 12555 -11792 11873 -16294 10409 -16308 9328 -14374 7966
--10852 5404 -14095 5126 -16073 5255 -16998 5196 -16197 5145 -15712 5331
--12149 4938 -9121 5851 -8105 7077 -14920 10477 -13631 7836 -17495 7855
--24257 15216 -10625 7935 6975 897 -4952 4417 -13961 9504 -18826 15437
--4963 10287 583 7053 9214 -2576 -2771 9211 -14013 23507 15362 -8483 13191 -1818
-5798 10273 -3412 19396 833 -7157 -2239 5191 -6720 23853 -10664 23546 -5528 -7026
--7025 -15383 -9509 -12418 -17464 -3362 -22700 4568 -20814 9568 -13937 7478
--6 17445 4420 21816 -16935 4632 -15085 9282 -22828 18187 -13441 15516
--11324 15933 -9849 15263 -8764 17057 -8361 19341 -128 17294 42910 -9651
--2194 8753 -17159 18084 -30327 27162 -43702 35142 11461 5309 16959 -1996
-6186 -3339 -899 -397 -3387 7647 4204 28200 4576 35761 3411 33450 -5269 -1069
--4808 -3827 4771 7546 26418 29063 12367 11712 4357 9660 -3134 8636 -8965 5810
--10080 -464 -3138 -9004 -9594 519 -45573 10589 -20779 -1118 17176 -21763
-323 -5412 -14860 9471 -24453 17771 -29848 20728 -32377 20387 -32952 18377
--32228 15752 -30677 13117 -28625 10769 -26312 8814 -23894 7261 -21448 6072
--19055 5183 -16733 4531 -14502 4051 -12371 3692 -10342 3419 -8425 3213
--6625 3071 -4952 2996 -3412 2993 -2021 3064 -782 3204 306 3409 1236 3669
-2009 3980 2646 4338 3147 4732 3538 5157 3815 5603 4007 6059 4112 6515 4142 6967
-4101 7408 3989 7835 3800 8241 3533 8619 3183 8963 2753 9269 2246 9533 1666 9757
-1042 9946 390 10099 -255 10227 -751 10255 -1221 10328 -1692 10406 -2145 10487
--2580 10546 -3009 10574 -3427 10577 -3799 10574 -4132 10573 -4436 10579
--4694 10582 -4895 10578 -5050 10567 -5172 10556 -5271 10549 -5370 10548
--5436 10548 -5446 10549 -5427 10551 -5384 10556 -5342 10564 -5312 10573
--5263 10586 -5190 10604 -5096 10622 -5000 10645 -4916 10668 -4842 10692
--4772 10717 -4698 10748 -4614 10781 -4542 10815 -4483 10850 -4436 10882
--4399 10915 -4364 10952 -4340 10989 -4324 11026 -4319 11063 -4320 11095
--4335 11129 -4360 11161 -4396 11194 -4439 11226 -4490 11254 -4545 11282
--4603 11307 -4678 11330 -4759 11352 -4841 11372 -4932 11389 -5021 11407
--5113 11422 -5212 11435 -5321 11444 -5428 11453 -5533 11460
-133: 12073630 -5286462 -8660 9756 -8700 9759 -8720 9764 -8770 9769 -8810 9774
--8830 9778 -8870 9780 -8920 9779 -8960 9779 -9010 9783 -9050 9782 -9090 9783
--9140 9779 -9180 9777 -9220 9774 -9280 9769 -9320 9764 -9360 9758 -9400 9752
--9440 9747 -9490 9739 -9520 9729 -9570 9720 -9600 9710 -9640 9703 -9680 9697
--9700 9689 -9740 9680 -9770 9672 -9800 9665 -9840 9662 -9870 9659 -9910 9659
--9940 9658 -9960 9658 -10010 9660 -10050 9668 -10090 9674 -10130 9686
--10190 9697 -10240 9712 -10300 9730 -10360 9750 -10420 9769 -10490 9795
--10560 9820 -10650 9850 -10720 9880 -10810 9908 -10880 9938 -10980 9971
--11070 10007 -11150 10042 -11260 10076 -11340 10106 -11420 10139 -11500 10170
--11590 10202 -11690 10231 -11770 10260 -11830 10287 -11890 10307 -11960 10330
--12010 10349 -12050 10365 -12100 10378 -12140 10392 -12160 10402 -12180 10410
--12190 10412 -12190 10414 -12190 10416 -12190 10419 -12180 10420 -12150 10419
--12130 10414 -12090 10409 -12080 10406 -12060 10405 -12040 10409 -12010 10413
--11980 10414 -11960 10416 -11950 10423 -11950 10434 -11960 10450 -11980 10468
--11990 10489 -12020 10515 -12070 10544 -12120 10572 -12180 10607 -12270 10649
--12360 10694 -12450 10743 -12580 10791 -12690 10841 -12820 10892 -12970 10950
--13130 11014 -13300 11077 -13470 11135 -13620 11190 -13780 11243 -13950 11301
--14150 11361 -14320 11416 -14490 11464 -14640 11504 -14770 11536 -14910 11569
--15050 11599 -15180 11621 -15280 11633 -15360 11637 -15420 11632 -15470 11622
--15500 11602 -15510 11573 -15490 11538 -15470 11496 -15410 11446 -15340 11381
--15230 11308 -15110 11226 -14980 11141 -14830 11057 -14690 10967 -14500 10864
--14290 10749 -14060 10634 -13840 10521 -13640 10418 -13440 10313 -13220 10201
--12970 10081 -12730 9965 -12500 9860 -12320 9767 -12160 9683 -11980 9596
--11800 9516 -11640 9442 -11530 9383 -11440 9340 -11410 9314 -11370 9296
--11360 9282 -11390 9289 -11450 9308 -11550 9344 -11700 9394 -11870 9462
--12100 9548 -12340 9646 -12640 9757 -12950 9878 -13310 10010 -13710 10167
--14160 10341 -14650 10527 -15150 10716 -15660 10905 -16200 11102 -16780 11317
--17410 11548 -18050 11784 -18710 12016 -19340 12231 -19980 12449 -20650 12679
--21360 12915 -22070 13147 -22754 13362 -23405 13556 -24040 13737 -24703 13930
--25338 14101 -25959 14257 -26555 14393 -27124 14514 -27661 14613 -28160 14696
--28621 14757 -29049 14792 -29442 14804 -29782 14788 -30081 14751 -30335 14690
--30513 14606 -30657 14492 -30739 14344 -30753 14174 -30719 13978 -30647 13759
--30507 13527 -30269 13280 -29944 12973 -29610 12649 -29259 12343 -28786 12017
--28160 11649 -27477 11267 -26861 10933 -26247 10573 -25385 10140 -24405 9722
--23525 9386 -22637 9089 -21579 8743 -20424 8365 -19383 8040 -18356 7775
--17176 7514 -15982 7215 -14946 6927 -13935 6703 -12839 6572 -11665 6594
--10436 6845 -9219 7222 -8224 7543 -7637 7644 -7429 7460 -7482 7014 -7598 6420
--7421 5821 -6512 5233 -4543 4768 -1187 4839 2314 5506 4328 5899 5565 6341
-5809 6985 5146 6908 5162 6950 4724 6743 3940 6452 4027 6876 2820 7746 1729 10244
--397 9499 -2676 7467 -4413 5618 -5405 5915 -4250 2580 -2300 -2422 -977 -5141
--6150 13306 -5520 14846 -4139 13104 -2314 11458 -1166 9900 -1177 8209
--2301 6713 -3897 5881 -5490 5419 -6702 4913 -7231 4491 -7043 4638 -6420 5676
--5668 7413 -4904 9239 -4163 10448 -3574 10697 -3380 9907 -3851 7747 -5534 3324
--9021 2253 -10172 6034 -3707 4733 -2207 4598 -648 4475 1468 4398 2998 4380
-1736 4045 -1592 3480 1028 8751 -4621 19452 4013 27100 20594 31057 39209 31220
-47314 25680 -9964 -118 -19103 -6682 -19550 -7156 -17747 -856 -13407 -1227
--14743 -899 -18765 -260 -24910 1123 -33018 -3921 -30475 -3990 -14554 -326
--10168 7758 16239 18908 13092 26145 8487 27986 4731 24206 107 16107 -5705 7570
--9479 2591 -11303 1523 -12938 1889 -17014 579 -23577 1862 -37739 7663
--45082 9498 -43080 8299 -14312 -48 -16420 3266 -23373 6632 -30026 8215
--34818 8778 -36351 9765 -33669 11165 -25321 11708 -13808 11164 -12180 11252
--14676 11609 -10113 11389 -5477 10728 -2272 10533 -2433 10281 -6929 10459
--10731 11084 -11947 12349 -1364 16150 -4013 16113 -6209 14672 -1721 13433
--3997 12342 -5176 11753 2782 12551 17272 14246 26548 14839 32592 14855
-36021 14519 35829 14003 31482 13528 29372 12919 28343 12330 23176 12192
--7180 12766 -6902 12448 -2347 12016 -19899 13236 -18852 12675 -14912 11968
--9355 11484 -4719 10438 -4306 8169 -13293 5776 -15225 5950 -16128 5436
--14853 5134 -13621 5203 -11757 4911 -9358 5538 -8080 6604 -9745 8544 -8594 8481
--13789 7494 -19153 10845 -10768 7698 -3674 5034 -6852 3879 -10936 6162
--10444 9215 -4517 6712 -10598 12254 -4245 8179 -5834 11298 -4738 20479
-14777 2031 17825 -698 10593 4442 -4221 10039 -5004 2672 -7290 5814 -6056 11342
--7018 9476 -6720 519 -9030 -5922 -12775 -6131 -17299 -144 -20426 4505
--19122 6950 -9627 10354 3742 13612 12103 13289 5720 5764 -11049 11089
--20035 15840 -15303 15496 -11800 15722 -9479 15357 -8693 16762 -9727 16752
--1908 11909 14256 7174 -5743 13389 -16515 18568 -24280 23708 -23917 24481
-5258 9610 14769 2455 568 227 -3200 3116 -3102 11031 1423 24362 2281 29565
-174 23510 -5760 1758 -8218 -6210 -5102 -2298 27575 26752 16669 16629 5649 10217
--1907 7140 -6925 4947 -9509 1659 -12048 -254 -16951 8269 -43162 10276
--28117 6325 1869 -7314 1863 -3654 -7043 4557 -15682 11009 -21859 14406
--25579 15307 -27350 14642 -27707 13191 -27096 11479 -25838 9810 -24191 8333
--22324 7103 -20336 6120 -18324 5361 -16321 4787 -14358 4355 -12449 4027
--10613 3776 -8854 3587 -7196 3456 -5637 3389 -4191 3383 -2871 3445 -1688 3569
--641 3752 274 3985 1041 4267 1682 4591 2196 4953 2595 5344 2893 5755 3103 6174
-3233 6596 3288 7012 3279 7418 3207 7812 3066 8188 2862 8541 2576 8865 2220 9158
-1792 9414 1295 9635 744 9825 164 9985 -424 10120 -927 10174 -1376 10250
--1807 10330 -2221 10411 -2615 10476 -3016 10508 -3406 10521 -3763 10525
--4077 10532 -4367 10543 -4620 10553 -4814 10552 -4975 10546 -5101 10539
--5209 10535 -5312 10536 -5387 10539 -5412 10540 -5405 10544 -5379 10547
--5351 10555 -5333 10565 -5302 10576 -5243 10591 -5163 10609 -5083 10628
--5013 10650 -4949 10670 -4896 10694 -4829 10721 -4754 10751 -4695 10782
--4643 10812 -4602 10841 -4567 10871 -4541 10904 -4522 10938 -4507 10972
--4504 11004 -4506 11035 -4519 11064 -4544 11094 -4580 11124 -4620 11152
--4671 11180 -4720 11204 -4776 11227 -4844 11249 -4920 11269 -5003 11288
--5084 11305 -5168 11321 -5253 11335 -5348 11347 -5453 11357 -5552 11365
--5652 11373
-134: 12104840 -5277610 -8730 9763 -8750 9771 -8780 9774 -8820 9781 -8860 9786
--8900 9788 -8930 9793 -8970 9794 -9010 9793 -9060 9799 -9100 9798 -9160 9800
--9190 9799 -9240 9797 -9280 9792 -9330 9790 -9380 9787 -9410 9780 -9460 9775
--9500 9772 -9550 9762 -9580 9753 -9620 9747 -9660 9737 -9700 9730 -9730 9726
--9760 9717 -9800 9707 -9820 9701 -9860 9695 -9900 9692 -9930 9690 -9960 9689
--9990 9685 -10020 9686 -10070 9691 -10100 9696 -10150 9704 -10190 9713
--10240 9725 -10290 9737 -10350 9755 -10410 9774 -10470 9795 -10540 9816
--10620 9843 -10690 9870 -10770 9901 -10850 9926 -10920 9956 -11020 9988
--11110 10020 -11190 10056 -11300 10087 -11370 10117 -11450 10148 -11530 10177
--11630 10209 -11710 10235 -11790 10262 -11860 10288 -11920 10312 -11970 10328
--12030 10347 -12070 10363 -12110 10375 -12150 10387 -12180 10397 -12190 10402
--12200 10405 -12190 10406 -12190 10409 -12200 10408 -12180 10412 -12160 10407
--12130 10403 -12100 10395 -12060 10394 -12060 10394 -12030 10395 -12020 10401
--11980 10399 -11950 10403 -11940 10409 -11950 10423 -11950 10436 -11970 10452
--11970 10474 -12010 10499 -12050 10528 -12100 10558 -12160 10590 -12250 10632
--12340 10676 -12440 10726 -12550 10775 -12660 10820 -12770 10872 -12930 10931
--13090 10993 -13260 11055 -13430 11113 -13570 11165 -13720 11220 -13890 11277
--14080 11335 -14260 11390 -14410 11435 -14570 11476 -14690 11508 -14830 11542
--14960 11567 -15090 11590 -15180 11604 -15270 11609 -15310 11603 -15370 11592
--15400 11572 -15400 11545 -15390 11509 -15360 11469 -15310 11419 -15230 11357
--15140 11286 -15000 11205 -14880 11122 -14740 11040 -14590 10953 -14410 10851
--14200 10741 -13990 10627 -13770 10518 -13570 10416 -13380 10315 -13160 10205
--12930 10090 -12680 9975 -12480 9874 -12290 9784 -12140 9703 -11960 9621
--11800 9539 -11650 9470 -11540 9413 -11460 9374 -11420 9348 -11410 9330
--11400 9320 -11420 9326 -11490 9348 -11600 9381 -11740 9432 -11930 9500
--12140 9584 -12400 9682 -12690 9791 -13000 9908 -13350 10039 -13750 10192
--14200 10361 -14680 10546 -15180 10730 -15680 10912 -16210 11104 -16780 11314
--17400 11539 -18030 11770 -18680 11993 -19290 12202 -19920 12412 -20590 12635
--21273 12864 -21966 13087 -22637 13295 -23275 13480 -23892 13654 -24540 13838
--25159 14005 -25767 14150 -26343 14277 -26895 14387 -27411 14481 -27906 14556
--28349 14609 -28764 14636 -29144 14640 -29475 14616 -29768 14573 -29995 14503
--30174 14415 -30316 14294 -30384 14147 -30398 13965 -30379 13769 -30300 13540
--30137 13321 -29898 13052 -29624 12753 -29319 12449 -28922 12135 -28403 11795
--27822 11426 -27259 11085 -26694 10766 -25970 10386 -25068 9978 -24224 9598
--23427 9265 -22430 8947 -21266 8619 -20202 8328 -19316 8072 -18350 7829
--17221 7569 -16148 7299 -15158 7056 -14081 6826 -12864 6637 -11618 6606
--10340 6776 -9111 7039 -8170 7245 -7722 7317 -7752 7199 -7973 6869 -8075 6372
--7710 5788 -6554 5205 -4446 4793 -1499 4772 1467 5118 3482 5450 4629 5805
-5756 6917 4110 6898 2942 8444 3879 6080 3038 5794 3661 6121 1024 5863 392 10190
--2191 7610 -4461 4696 -5316 2610 -5139 8129 -4414 4562 -3455 432 -1422 -726
--2999 9301 -3081 12951 -4156 12043 -3434 10557 -2687 9024 -2459 7614 -3279 6518
--4774 5905 -6407 5524 -7610 5077 -7997 4745 -7541 5068 -6600 6395 -5538 8538
--4410 10849 -3203 12670 -2134 13660 -1536 13582 -1713 11509 -3607 1607
--9780 -2510 -12120 4687 -6512 4427 -2295 4867 -179 4545 1782 4217 2974 4217
-1768 4742 -4967 6287 -3652 11140 -20551 18668 -16458 25559 -1881 29504
-19718 29519 36993 23396 12380 6978 -260 -538 -6412 -1741 -10652 1094 -13325 1411
--14840 -1164 -18206 -394 -20581 1216 -28340 -1893 -28516 -1944 -21770 1386
--12712 8053 6178 17147 12374 24040 13868 26743 11815 23634 5497 14834
--4233 5016 -7927 2206 -7186 1556 -8559 3710 -19440 701 -23120 687 -30306 5559
--35585 5675 -31532 2680 -16499 -1266 -20669 5733 -24288 8856 -27357 8934
--29661 7783 -29472 8326 -27410 10551 -21517 11633 -14257 11710 -11750 11779
--21197 12846 -16950 12556 -8899 11061 -4596 10278 -4504 10047 -11082 10225
--13943 10874 -13932 12091 -9384 14224 -11268 14370 -11852 13011 1763 12610
--3976 11951 -9873 11025 -1920 11938 17229 14354 24588 14706 28293 14595
-30407 14138 31967 13679 32364 13367 31083 12839 27101 12464 17503 12561
--2302 12969 -8007 12775 -9280 12470 -17236 12914 -15335 13032 -7913 13405
-1687 13862 8765 13450 8384 11485 -10021 7038 -14302 5677 -15396 5029 -13573 4504
--12437 4965 -12976 5073 -11029 5647 -8953 5856 -7798 6248 -7476 6572 -6803 7566
--10632 7781 -6787 6734 -7553 9780 -9330 4507 -12148 5435 -7728 8726 -10639 7208
--9024 7698 -5788 8137 -7262 7560 5290 16961 15371 7416 18593 1141 14155 334
--8199 8486 -10269 5777 -10686 6976 -8634 5950 -6651 2171 -7446 7242 -11152 2518
--15408 -552 -17469 4524 -19422 6270 -18971 7074 -13645 7974 1193 8656
-17451 7621 36485 7498 -12123 14361 -17010 16166 -12686 15225 -9082 14844
--5828 13491 -4634 15449 -10693 15848 -7564 12840 -3861 14220 -10611 15250
--11478 15700 -13618 17407 -11773 16730 -3181 13279 3673 8396 -635 5798
--2610 7149 -2424 12286 -419 19465 73 22037 -864 16946 -2497 5331 -499 272
-6884 4614 7554 13056 7243 12445 1320 9223 -2232 7121 -4849 7200 -6261 6139
--12363 5397 -18178 11109 -36275 11015 -29563 8520 -12111 1442 -6221 731
--8433 3964 -13275 7688 -17869 10279 -21231 11461 -23239 11528 -24080 10899
--24033 9925 -23338 8851 -22201 7819 -20791 6902 -19200 6130 -17527 5510
--15810 5020 -14098 4640 -12407 4345 -10754 4116 -9156 3943 -7640 3823
--6201 3758 -4853 3752 -3610 3807 -2485 3915 -1484 4078 -598 4286 157 4541
-792 4833 1308 5164 1721 5522 2029 5900 2258 6286 2402 6675 2480 7059 2501 7433
-2458 7799 2357 8147 2199 8477 1971 8783 1678 9060 1313 9308 885 9523 407 9712
--114 9875 -634 10016 -1109 10098 -1531 10180 -1935 10257 -2313 10339 -2678 10405
--3053 10443 -3417 10462 -3753 10474 -4055 10487 -4331 10504 -4569 10519
--4763 10523 -4919 10521 -5051 10517 -5167 10517 -5273 10520 -5353 10524
--5390 10528 -5394 10531 -5383 10536 -5368 10543 -5361 10551 -5340 10563
--5296 10577 -5234 10592 -5166 10611 -5103 10628 -5058 10648 -5009 10669
--4954 10694 -4891 10719 -4841 10748 -4795 10774 -4759 10802 -4732 10828
--4710 10857 -4693 10888 -4685 10919 -4680 10948 -4684 10975 -4699 11002
--4719 11030 -4757 11056 -4796 11083 -4845 11107 -4886 11130 -4942 11152
--5008 11171 -5079 11190 -5156 11208 -5236 11223 -5313 11239 -5390 11252
--5481 11263 -5576 11274 -5675 11281 -5767 11290
-135: 12136050 -5268756 -8780 9771 -8800 9778 -8840 9785 -8870 9792 -8910 9796
--8950 9798 -8980 9804 -9020 9808 -9070 9807 -9110 9812 -9150 9814 -9210 9815
--9240 9815 -9300 9814 -9330 9811 -9380 9809 -9430 9806 -9470 9801 -9510 9797
--9550 9794 -9600 9784 -9640 9778 -9680 9771 -9710 9762 -9750 9755 -9780 9751
--9810 9743 -9850 9735 -9880 9728 -9910 9722 -9950 9720 -9980 9716 -10010 9716
--10050 9712 -10070 9714 -10110 9718 -10160 9722 -10190 9731 -10240 9739
--10290 9751 -10340 9763 -10400 9781 -10460 9796 -10510 9815 -10580 9839
--10660 9864 -10740 9890 -10810 9919 -10890 9944 -10960 9972 -11060 10004
--11140 10035 -11230 10066 -11320 10100 -11400 10126 -11490 10156 -11560 10186
--11650 10213 -11730 10241 -11810 10267 -11880 10290 -11940 10313 -11990 10327
--12040 10344 -12080 10360 -12130 10373 -12160 10383 -12180 10391 -12200 10397
--12210 10399 -12200 10399 -12190 10399 -12190 10398 -12190 10403 -12160 10398
--12130 10393 -12100 10384 -12070 10382 -12060 10380 -12030 10384 -12000 10387
--11980 10387 -11950 10391 -11930 10397 -11940 10409 -11950 10424 -11960 10440
--11970 10461 -11990 10484 -12040 10511 -12080 10544 -12140 10576 -12240 10617
--12320 10660 -12410 10706 -12530 10757 -12630 10803 -12750 10855 -12890 10910
--13050 10971 -13210 11033 -13380 11092 -13520 11145 -13670 11194 -13840 11251
--14020 11310 -14180 11363 -14350 11407 -14490 11448 -14610 11480 -14750 11512
--14880 11539 -15000 11560 -15090 11574 -15180 11580 -15220 11573 -15270 11561
--15290 11545 -15300 11516 -15290 11482 -15260 11442 -15200 11392 -15140 11333
--15030 11263 -14910 11184 -14780 11102 -14640 11024 -14500 10937 -14330 10840
--14130 10731 -13910 10622 -13700 10514 -13500 10414 -13320 10317 -13110 10210
--12880 10098 -12650 9987 -12440 9887 -12280 9803 -12110 9724 -11960 9643
--11800 9567 -11650 9498 -11550 9445 -11480 9406 -11440 9382 -11430 9365
--11430 9359 -11470 9366 -11530 9386 -11640 9422 -11790 9472 -11970 9539
--12200 9622 -12440 9718 -12740 9828 -13040 9940 -13400 10070 -13790 10219
--14240 10387 -14700 10564 -15200 10746 -15690 10924 -16220 11109 -16770 11316
--17390 11534 -18010 11758 -18630 11977 -19250 12179 -19860 12381 -20500 12597
--21180 12817 -21860 13036 -22516 13235 -23136 13412 -23737 13577 -24369 13756
--24975 13915 -25565 14051 -26118 14171 -26659 14275 -27167 14359 -27643 14424
--28074 14471 -28478 14493 -28833 14487 -29161 14461 -29443 14408 -29658 14333
--29849 14233 -29963 14118 -30024 13957 -30062 13780 -30024 13565 -29923 13356
--29765 13112 -29576 12837 -29323 12568 -28971 12254 -28518 11922 -28058 11587
--27595 11246 -27105 10929 -26452 10576 -25585 10196 -24755 9837 -24073 9481
--23270 9149 -22175 8834 -21044 8559 -20157 8313 -19349 8061 -18349 7812
--17219 7575 -16160 7367 -15098 7168 -13899 6942 -12634 6751 -11444 6702
--10309 6798 -9263 6929 -8522 7032 -8245 7059 -8278 6957 -8285 6691 -7999 6291
--7273 5813 -5988 5327 -4045 4966 -1543 4897 1016 5153 3072 5584 4567 6151
-5714 6931 5088 7067 161 7239 -731 6676 -416 6211 3106 7620 -1807 6765 -1870 8998
--4160 5768 -6179 4950 -5678 4979 -4834 6721 -4437 4649 -5427 3049 -1441 755
--529 5848 251 10118 -3777 9116 -3286 8401 -3188 7433 -2950 6587 -4014 5838
--5735 5446 -7515 5356 -8756 5206 -9062 5095 -8197 5607 -6794 7107 -5459 9406
--4103 11784 -2626 13656 -1353 14595 -846 14029 -1495 11038 -3802 4367
--7897 1316 -9170 4246 -5333 2967 -6060 4465 -2036 4278 381 3842 1374 3860
--504 4662 -10507 6915 -17393 11637 -31239 17732 -35016 23132 -27679 26222
--5413 26222 36645 22448 34388 13133 21736 6875 9975 4657 394 4572 -7638 3036
--14690 725 -16615 582 -12300 3268 -22178 -181 -23421 -103 -22456 2518
--15741 7471 -5093 15832 4512 22203 12797 25730 13996 23004 6895 11525
--8097 -3109 -7765 5973 -3082 4241 -1093 6877 -20544 1273 -16907 388 -20984 3445
--26052 2885 -22505 -1378 -14645 -4360 -26818 9182 -25340 10909 -24555 9305
--25581 5746 -23473 6205 -23691 10485 -20501 11886 -17156 12176 -16685 12233
--21030 12827 -19000 12981 -9181 11366 -5759 10592 -6012 10363 -10186 10531
--12408 11098 -12132 11879 -9962 12852 -9842 12988 -8835 11868 -2681 11678
--5633 12068 -8718 11185 -6097 11707 3935 12795 14766 13574 17966 13731
-18603 13283 21877 13095 26588 13228 25976 12927 20044 12650 9927 12759
--2444 13062 -8901 12916 -11118 12649 -13062 12728 -9162 13274 653 14532
-13887 15895 22036 15864 18778 13625 1776 9286 -8742 5892 -12513 4616 -13685 3618
--12455 3420 -14356 7152 -12468 6699 -9236 5602 -3760 4950 1342 6411 -8281 6697
--9461 6543 -7926 6893 -1681 16566 -9260 4453 -11279 1843 1011 9255 -9403 4870
--12457 3181 -8048 6550 -7697 6374 12343 12195 12274 8047 12212 3658 7120 2545
--5879 5305 -9797 4825 -11389 9699 -11394 7702 -10147 5852 -3182 5887 -12206 7146
--16247 4059 -17026 5659 -18452 6923 -19283 7367 -19337 6607 -13609 4625
--1197 4660 38117 11349 13243 15773 573 16544 -2514 15337 -2377 14121 -1307 13006
--1805 13632 -6197 14029 -8327 13611 -10550 14736 -9456 12318 -12160 13740
--8056 12683 -6466 11025 -12429 16501 -4287 12809 -1875 9851 -1518 9613
--1750 11895 -1283 15211 -1497 16482 -1440 13202 -1440 7118 506 3980 3951 5759
-3358 9399 2737 10048 -4701 8368 -3547 7201 -3738 10586 -2924 10967 -6836 9020
--13551 7995 -30465 14130 -29467 10731 -20251 6313 -14205 4434 -12935 4972
--14469 6541 -16899 8047 -19125 8999 -20694 9329 -21512 9170 -21664 8698
--21271 8067 -20471 7391 -19394 6741 -18120 6155 -16728 5657 -15261 5247
--13769 4915 -12274 4651 -10802 4441 -9359 4281 -7972 4169 -6649 4108 -5407 4100
--4249 4147 -3189 4242 -2234 4385 -1386 4573 -650 4800 -27 5066 493 5366
-905 5692 1225 6039 1459 6395 1623 6752 1719 7108 1758 7455 1748 7793 1677 8117
-1550 8428 1371 8714 1136 8977 820 9213 452 9423 36 9608 -419 9772 -888 9917
--1305 10024 -1698 10109 -2075 10187 -2428 10267 -2768 10335 -3113 10378
--3454 10403 -3773 10422 -4058 10440 -4319 10463 -4543 10482 -4732 10490
--4894 10492 -5023 10492 -5140 10494 -5252 10501 -5331 10506 -5378 10512
--5395 10515 -5397 10520 -5391 10528 -5396 10536 -5385 10547 -5354 10560
--5300 10573 -5246 10590 -5196 10607 -5161 10624 -5120 10643 -5077 10665
--5024 10688 -4979 10713 -4939 10737 -4915 10762 -4888 10785 -4870 10812
--4855 10840 -4850 10867 -4852 10893 -4859 10919 -4870 10942 -4891 10967
--4925 10992 -4964 11016 -5008 11039 -5050 11059 -5104 11078 -5167 11098
--5233 11114 -5303 11131 -5377 11146 -5455 11160 -5530 11172 -5610 11184
--5701 11193 -5790 11202 -5881 11209
-136: 12167280 -5259901 -8820 9780 -8860 9787 -8890 9792 -8920 9801 -8960 9804
--9000 9811 -9030 9814 -9070 9819 -9120 9821 -9160 9823 -9200 9826 -9250 9830
--9300 9830 -9340 9831 -9380 9829 -9430 9827 -9480 9821 -9510 9820 -9560 9816
--9610 9813 -9650 9806 -9680 9800 -9720 9794 -9770 9785 -9800 9779 -9830 9773
--9860 9768 -9900 9759 -9920 9754 -9960 9749 -9990 9745 -10030 9741 -10060 9739
--10090 9738 -10120 9741 -10160 9742 -10200 9749 -10240 9754 -10280 9763
--10330 9777 -10390 9788 -10440 9803 -10490 9818 -10560 9838 -10620 9859
--10690 9882 -10780 9908 -10850 9937 -10920 9961 -11000 9987 -11090 10017
--11170 10048 -11260 10079 -11350 10110 -11430 10136 -11510 10165 -11590 10191
--11670 10220 -11750 10245 -11830 10271 -11890 10294 -11960 10312 -12000 10328
--12050 10344 -12100 10357 -12130 10369 -12170 10377 -12190 10387 -12210 10391
--12210 10394 -12200 10392 -12200 10390 -12190 10390 -12190 10393 -12160 10389
--12130 10383 -12100 10376 -12070 10372 -12050 10371 -12030 10374 -12000 10374
--11970 10374 -11950 10379 -11930 10384 -11930 10397 -11940 10410 -11950 10429
--11970 10447 -11980 10471 -12020 10498 -12070 10529 -12140 10562 -12210 10602
--12300 10644 -12390 10690 -12500 10741 -12610 10787 -12720 10834 -12870 10890
--13010 10951 -13170 11011 -13330 11070 -13480 11121 -13620 11172 -13780 11227
--13960 11284 -14120 11336 -14280 11380 -14420 11419 -14540 11453 -14670 11482
--14800 11511 -14910 11531 -15010 11544 -15080 11548 -15120 11544 -15180 11533
--15190 11516 -15200 11488 -15190 11454 -15160 11415 -15110 11367 -15030 11308
--14930 11238 -14820 11163 -14690 11084 -14550 11007 -14420 10923 -14240 10828
--14050 10721 -13840 10616 -13630 10510 -13450 10414 -13260 10318 -13060 10216
--12830 10105 -12620 9999 -12420 9903 -12250 9820 -12100 9743 -11940 9667
--11800 9594 -11660 9528 -11560 9476 -11500 9440 -11460 9417 -11460 9404
--11460 9397 -11510 9404 -11570 9427 -11680 9462 -11840 9514 -12010 9580
--12240 9662 -12490 9757 -12780 9864 -13090 9976 -13440 10101 -13830 10251
--14260 10414 -14730 10585 -15210 10765 -15710 10939 -16210 11119 -16760 11321
--17360 11534 -17980 11751 -18590 11964 -19190 12160 -19790 12356 -20420 12566
--21080 12779 -21750 12989 -22380 13182 -22993 13351 -23577 13510 -24189 13682
--24785 13830 -25354 13964 -25893 14075 -26422 14171 -26909 14248 -27367 14305
--27798 14345 -28183 14362 -28526 14351 -28845 14315 -29101 14257 -29333 14174
--29509 14075 -29602 13946 -29678 13791 -29716 13599 -29650 13394 -29543 13172
--29437 12911 -29276 12669 -28971 12388 -28562 12054 -28156 11725 -27814 11415
--27436 11098 -26867 10746 -26049 10369 -25174 10037 -24547 9718 -23964 9379
--23087 9055 -21961 8764 -20981 8508 -20234 8253 -19362 7983 -18230 7748
--17029 7572 -15901 7440 -14740 7281 -13509 7084 -12372 6929 -11430 6869
--10602 6870 -9821 6880 -9244 6879 -8899 6850 -8550 6741 -7985 6548 -7184 6287
--6251 5956 -5147 5567 -3671 5236 -1737 5149 393 5425 2249 6007 3519 6774
-4023 7490 3034 7545 -71 6764 -3688 7319 -3258 5778 -1746 8019 -5980 6963
--6146 8010 -4061 5200 -6272 6605 -4302 7631 -3306 5889 -2570 3054 -6152 2845
--2935 1943 -735 3129 1563 8192 -2159 6640 -1021 6554 -2947 5852 -2612 5617
--4562 4933 -6615 4606 -8540 5067 -9946 5438 -10572 5558 -9057 6142 -6916 7604
--5444 9828 -4149 11882 -2604 13445 -1144 14245 -782 13577 -1701 11023
--3764 6990 -6342 4727 -7476 4941 -6949 3936 -6362 5261 -2700 4112 -1436 3532
--371 3699 -52 4433 -16961 5800 -26226 10516 -38821 15978 -47773 20221
--48143 22587 -31669 22930 46524 22515 48940 17238 35288 12711 20651 10402
-8328 8913 -2511 5282 -12406 3889 -10898 4348 -8786 3209 -15195 1875 -18115 2259
--18980 3784 -17921 6016 -15596 14452 -6017 19196 8880 23850 11098 21957
--1445 5571 -9877 -375 -8869 1497 -2472 5698 -2913 8061 -4365 6109 -8220 1867
--14527 2225 -19806 6083 -20343 1207 -18827 217 -23565 3669 -19889 8063
--19100 8002 -23512 2780 -17341 3814 -20916 11226 -19200 11732 -18851 11844
--18913 11587 -18792 11750 -16445 12626 -10734 12058 -7146 11300 -6026 10920
--8230 10882 -9373 11358 -8799 11638 -7264 11871 -6724 12303 -7186 10967
--7209 11512 -7008 11550 -7221 11306 -7660 11542 -8431 11322 5879 12409
-5845 12848 2566 12186 7196 12238 18229 13339 17964 13025 10592 12665 1089 12659
--5639 13072 -10594 13050 -11002 12876 -9715 12614 -4727 13182 6846 15051
-26557 17600 38122 18169 34771 15983 15736 11279 -7443 6162 -11759 5416
--14612 4128 -12620 4309 -14819 7263 -13258 6801 -10762 5472 -1770 4556
-1251 5862 -3684 7128 -4172 8764 -2008 12842 2139 18858 -8801 -370 -4434 645
-6138 7536 -8262 1632 -4968 2931 -13814 2782 -6135 4619 9258 7476 2486 6427
-4916 5102 1788 5469 -6909 6130 -12873 7292 -5339 9475 -9510 7967 -7979 6610
--4096 6637 -20709 12995 -11861 4873 -14085 5796 -16939 7117 -19470 7499
--21519 7582 -20784 3678 -7024 5563 25214 13014 22054 16583 12945 16504
-7044 14875 4478 13213 3837 11928 2998 11565 -4 11714 -4452 12253 -11193 13512
--14672 12900 -9958 12167 -10074 11091 -11373 10727 -16088 14240 -5674 12564
--1371 10795 -12 10051 -1502 10527 -1860 11683 -2877 12776 -1951 10808
--2283 7605 -1750 5435 -742 5788 -54 8811 632 9819 -13779 8781 -5553 8238
--566 11980 2499 15946 -911 15303 -6880 15601 -24633 4855 -27329 8459 -23718 8494
--19557 7108 -17250 6381 -16821 6547 -17484 7135 -18479 7705 -19344 8034
--19853 8083 -19955 7896 -19662 7553 -19046 7123 -18181 6667 -17137 6226
--15965 5825 -14706 5478 -13405 5187 -12084 4948 -10773 4752 -9475 4603
--8217 4495 -7009 4436 -5868 4426 -4796 4464 -3803 4548 -2900 4676 -2097 4842
--1388 5046 -778 5287 -268 5558 146 5857 471 6173 713 6500 891 6830 1000 7159
-1060 7481 1068 7795 1021 8097 926 8388 785 8658 591 8906 326 9132 9 9334
--352 9515 -754 9677 -1170 9824 -1521 9948 -1879 10038 -2230 10117 -2566 10197
--2878 10266 -3199 10313 -3519 10344 -3815 10369 -4085 10393 -4332 10420
--4543 10443 -4726 10455 -4885 10461 -5015 10463 -5127 10470 -5246 10477
--5331 10486 -5380 10492 -5405 10497 -5419 10502 -5422 10509 -5434 10518
--5435 10528 -5412 10541 -5370 10553 -5331 10568 -5288 10583 -5262 10598
--5230 10616 -5195 10636 -5148 10656 -5113 10679 -5081 10701 -5058 10721
--5042 10744 -5023 10768 -5012 10792 -5009 10817 -5016 10841 -5024 10863
--5035 10885 -5057 10907 -5089 10931 -5123 10951 -5168 10972 -5209 10992
--5258 11009 -5317 11026 -5383 11043 -5447 11057 -5517 11072 -5590 11084
--5662 11097 -5735 11108 -5824 11116 -5907 11125 -5991 11133
-137: 12198530 -5251040 -8870 9786 -8910 9794 -8940 9800 -8970 9807 -9010 9814
--9040 9820 -9080 9824 -9120 9828 -9160 9832 -9210 9836 -9240 9838 -9300 9841
--9340 9845 -9390 9843 -9420 9843 -9480 9842 -9520 9840 -9570 9838 -9610 9833
--9650 9832 -9690 9826 -9720 9821 -9770 9812 -9810 9807 -9840 9801 -9880 9795
--9910 9792 -9930 9782 -9970 9777 -10000 9771 -10040 9767 -10060 9765 -10110 9765
--10130 9763 -10160 9766 -10200 9765 -10240 9770 -10280 9776 -10320 9787
--10370 9799 -10430 9809 -10470 9824 -10540 9840 -10580 9857 -10670 9879
--10730 9901 -10800 9926 -10880 9953 -10960 9978 -11020 10002 -11120 10030
--11200 10060 -11290 10091 -11370 10119 -11460 10145 -11530 10172 -11610 10198
--11690 10226 -11770 10252 -11840 10273 -11910 10294 -11960 10311 -12010 10331
--12070 10343 -12090 10355 -12150 10365 -12180 10373 -12190 10382 -12210 10388
--12220 10386 -12210 10385 -12190 10384 -12190 10383 -12190 10384 -12160 10381
--12130 10372 -12090 10366 -12060 10364 -12050 10362 -12030 10365 -12010 10362
--11970 10364 -11940 10367 -11920 10372 -11930 10386 -11930 10399 -11940 10416
--11960 10434 -11980 10459 -12020 10487 -12050 10513 -12130 10548 -12200 10589
--12280 10629 -12370 10675 -12480 10723 -12580 10770 -12700 10817 -12830 10872
--12980 10929 -13140 10991 -13290 11048 -13420 11100 -13580 11147 -13730 11202
--13900 11259 -14060 11310 -14220 11353 -14350 11392 -14470 11422 -14590 11456
--14720 11483 -14830 11500 -14920 11514 -14990 11517 -15040 11515 -15070 11504
--15100 11488 -15110 11458 -15100 11425 -15060 11388 -15010 11343 -14940 11284
--14840 11215 -14720 11141 -14600 11065 -14470 10989 -14330 10910 -14170 10815
--13970 10711 -13760 10609 -13570 10507 -13390 10414 -13210 10322 -13010 10220
--12800 10113 -12580 10010 -12390 9918 -12230 9839 -12080 9764 -11940 9692
--11800 9620 -11660 9557 -11570 9507 -11520 9474 -11490 9454 -11480 9441
--11500 9436 -11540 9446 -11610 9468 -11720 9504 -11880 9555 -12060 9622
--12280 9703 -12540 9797 -12810 9903 -13140 10013 -13470 10137 -13860 10281
--14290 10442 -14740 10613 -15230 10786 -15700 10956 -16210 11133 -16750 11329
--17340 11538 -17940 11750 -18540 11955 -19120 12147 -19710 12338 -20340 12539
--20970 12747 -21620 12950 -22250 13136 -22840 13299 -23411 13451 -24005 13615
--24582 13755 -25132 13881 -25667 13990 -26169 14076 -26653 14147 -27095 14200
--27514 14233 -27881 14244 -28214 14227 -28511 14182 -28776 14119 -29006 14034
--29146 13928 -29249 13795 -29330 13635 -29345 13440 -29274 13238 -29212 12986
--29131 12753 -28919 12513 -28561 12198 -28192 11867 -27913 11573 -27629 11272
--27172 10925 -26450 10537 -25600 10199 -24931 9923 -24494 9618 -23876 9284
--22879 8961 -21804 8672 -20998 8411 -20253 8144 -19206 7889 -17906 7712
--16632 7615 -15447 7538 -14282 7410 -13197 7256 -12359 7132 -11769 7037
--11234 6949 -10609 6860 -9937 6785 -9150 6706 -8110 6618 -6913 6530 -5830 6417
--5100 6202 -4532 5847 -3722 5497 -2369 5395 -662 5727 892 6475 1778 7507
-1637 8631 97 9604 -2723 10015 -3979 6332 -4679 6699 -4769 4899 -11422 4638
--12849 7609 -10237 2498 280 8333 -127 8961 -1525 5062 -1833 3241 -3605 3033
--3132 2437 -1865 -854 2806 5837 -3559 6738 3078 6224 -3116 4756 -1948 5353
--5668 4136 -7203 3427 -8839 4833 -10528 5939 -13006 6051 -10309 6487 -6772 7668
--5473 9781 -4683 11172 -3237 12241 -1296 13266 -1023 13004 -2031 11307
--3688 8954 -5167 7558 -5431 7557 -4650 7530 -5938 5686 -6569 3130 -4511 3517
--2278 4629 4786 6804 -20536 1863 -27686 7612 -38648 13477 -47354 17108
--44200 19458 -21432 21059 27057 21241 38303 18689 31475 15836 19065 14119
-6145 12666 -9239 5829 -1680 8066 101 9600 -1778 4472 -10287 4705 -13638 5510
--15519 6679 -20640 6375 -21226 11437 -15874 13306 5464 19238 6052 17782
--1917 8100 -6592 4518 -10762 2590 -6534 4181 -355 10975 -776 9519 -7065 3558
--13182 2789 -15160 4719 -18170 4424 -19758 4595 -21131 -2502 -13021 4365
--12999 4075 -27702 5112 -14744 7258 -13002 9152 -14158 9643 -17932 9826
--19137 9939 -15705 9882 -14071 12341 -11635 12507 -8413 11752 -5379 11155
--5744 10743 -6291 11415 -6289 11494 -5647 10843 -7216 11408 -7062 10692
--7534 11899 -6584 11511 -6704 10931 -6892 11043 -8008 11242 -2421 11619
--4450 12560 -12435 11253 -8294 11408 10290 13783 8736 12950 -61 12441
--9349 12163 -8872 13100 -13334 13244 -10617 13348 -7803 12350 -4241 12351
-5925 14488 37811 19001 55216 20440 54214 18787 31967 13774 -12595 5375
--11751 6831 -17159 4780 -11004 4729 -15383 7789 -13014 6377 -14071 5149
--683 3910 -181 5678 -2480 7212 -851 7861 -762 10672 -437 11442 -5684 1839
--4133 1354 -2712 3721 201 3899 -1900 3181 -7212 4141 -5587 5189 660 5702
-3532 4327 7040 5439 5933 8165 -6838 8669 -11679 9632 -8192 10282 -9200 9212
--9823 8000 -11120 8389 -7449 9354 -10748 6914 -13443 7426 -16314 7917
--19908 6906 -23805 7926 -21902 6532 -13671 7829 20602 16234 23755 17798
-17682 15961 11706 13648 8357 11846 7504 10396 7640 9295 6201 9145 1056 10210
--11261 12895 -18310 13889 -8514 11397 -13582 10521 -13659 9701 -16424 11680
--9012 10989 -2021 10163 976 9368 -2540 9114 -3431 9652 -3613 9495 -1164 8796
--3448 7657 -4459 6014 -5720 5046 -5033 8989 -9596 9951 -17603 9201 -2455 7152
-2705 10656 7699 17571 2674 14838 -5669 8196 -12447 9066 -22202 14560 -24248 13242
--22472 10166 -20289 8035 -18938 7163 -18459 7075 -18493 7287 -18687 7500
--18809 7585 -18735 7518 -18429 7321 -17892 7034 -17154 6699 -16266 6351
--15254 6018 -14166 5718 -13029 5455 -11857 5233 -10685 5050 -9521 4905
--8388 4802 -7293 4742 -6248 4729 -5262 4760 -4341 4833 -3492 4945 -2736 5095
--2059 5278 -1470 5496 -972 5741 -564 6013 -237 6303 15 6603 198 6908 322 7211
-394 7511 418 7803 397 8086 327 8357 218 8613 52 8848 -166 9062 -440 9256
--752 9432 -1106 9592 -1470 9738 -1755 9871 -2082 9966 -2411 10046 -2718 10128
--3009 10200 -3307 10250 -3604 10287 -3880 10316 -4134 10344 -4365 10376
--4566 10403 -4741 10419 -4897 10426 -5026 10434 -5137 10442 -5254 10452
--5340 10462 -5394 10470 -5430 10475 -5448 10481 -5461 10489 -5481 10498
--5489 10508 -5472 10519 -5444 10531 -5412 10544 -5382 10559 -5361 10572
--5338 10587 -5308 10606 -5270 10624 -5240 10644 -5216 10664 -5197 10683
--5187 10703 -5172 10724 -5163 10746 -5166 10768 -5170 10790 -5178 10810
--5195 10830 -5219 10850 -5244 10871 -5280 10890 -5322 10909 -5358 10926
--5409 10943 -5462 10958 -5525 10974 -5588 10987 -5655 11001 -5719 11013
--5790 11024 -5860 11035 -5940 11043 -6018 11052 -6098 11060
-138: 12229790 -5242177 -8920 9794 -8950 9798 -8980 9805 -9020 9815 -9060 9822
--9090 9829 -9120 9833 -9160 9837 -9210 9841 -9250 9845 -9290 9850 -9340 9854
--9380 9855 -9430 9855 -9470 9857 -9520 9855 -9560 9855 -9610 9855 -9650 9851
--9690 9848 -9730 9845 -9770 9838 -9810 9831 -9840 9826 -9890 9821 -9910 9816
--9960 9811 -9970 9804 -10010 9798 -10040 9793 -10070 9790 -10110 9788
--10140 9785 -10170 9786 -10200 9787 -10240 9789 -10280 9790 -10310 9800
--10350 9809 -10410 9818 -10460 9830 -10500 9844 -10570 9859 -10620 9876
--10690 9897 -10770 9919 -10840 9943 -10900 9968 -10980 9992 -11060 10015
--11140 10045 -11220 10070 -11310 10102 -11400 10130 -11460 10152 -11550 10180
--11630 10204 -11710 10230 -11780 10257 -11850 10275 -11920 10296 -11970 10314
--12020 10329 -12070 10342 -12110 10354 -12160 10362 -12170 10370 -12200 10378
--12210 10381 -12210 10382 -12210 10379 -12200 10375 -12190 10377 -12190 10377
--12160 10371 -12120 10365 -12090 10360 -12070 10352 -12040 10353 -12030 10355
--12000 10354 -11970 10354 -11930 10357 -11930 10364 -11920 10374 -11930 10387
--11930 10405 -11950 10424 -11980 10446 -12000 10473 -12060 10501 -12100 10535
--12190 10573 -12260 10616 -12360 10660 -12450 10707 -12570 10753 -12670 10800
--12810 10854 -12950 10911 -13100 10970 -13250 11026 -13380 11077 -13530 11126
--13680 11178 -13840 11232 -14010 11283 -14150 11327 -14290 11366 -14400 11395
--14520 11426 -14640 11453 -14740 11469 -14840 11485 -14900 11488 -14960 11484
--14990 11475 -15000 11458 -15020 11432 -15000 11396 -14970 11361 -14920 11316
--14840 11260 -14750 11193 -14640 11121 -14510 11046 -14380 10972 -14260 10894
--14080 10804 -13900 10702 -13700 10601 -13510 10502 -13330 10414 -13160 10323
--12970 10225 -12750 10123 -12550 10023 -12370 9933 -12200 9857 -12080 9786
--11930 9715 -11790 9646 -11680 9587 -11580 9539 -11540 9509 -11510 9489
--11510 9479 -11530 9476 -11570 9488 -11640 9510 -11770 9548 -11920 9596
--12100 9665 -12320 9745 -12580 9839 -12850 9942 -13170 10053 -13510 10174
--13880 10316 -14310 10472 -14760 10641 -15230 10811 -15710 10976 -16190 11149
--16730 11342 -17310 11546 -17890 11753 -18490 11951 -19050 12138 -19630 12324
--20240 12519 -20860 12722 -21500 12917 -22100 13097 -22680 13254 -23240 13400
--23810 13554 -24375 13690 -24912 13811 -25424 13911 -25921 13993 -26388 14057
--26822 14105 -27216 14136 -27574 14138 -27895 14114 -28184 14065 -28458 13995
--28649 13910 -28781 13794 -28908 13664 -28975 13492 -28960 13308 -28939 13074
--28909 12840 -28774 12622 -28493 12339 -28183 12017 -27941 11731 -27722 11447
--27343 11108 -26731 10720 -25976 10362 -25326 10096 -24939 9831 -24526 9506
--23697 9150 -22583 8815 -21649 8539 -20957 8302 -20104 8061 -18858 7862
--17453 7752 -16192 7711 -15048 7643 -14027 7530 -13205 7407 -12701 7288
--12361 7158 -11912 7013 -11160 6882 -10058 6773 -8594 6690 -6893 6658
--5372 6669 -4511 6653 -4413 6456 -4597 6058 -4404 5654 -3474 5543 -1999 5911
--598 6742 117 7853 -193 9001 -1573 9825 -4100 9541 -5177 7178 -5805 6431
--6817 5107 -10670 4902 -12191 5847 -10112 4162 -3708 6835 -1898 7326 -1227 5234
--82 3878 436 3374 527 2650 -1164 1344 -6078 4189 -6482 4413 9593 5551 -1012 4082
--4698 6201 -9407 4031 -6511 1902 -6692 4781 -8229 6802 -18108 6187 -12542 6421
--6231 7129 -5362 9335 -5732 9731 -4603 10112 -1515 12061 -1631 12432 -2761 11451
--4199 10017 -5209 9193 -5290 9199 -5126 8850 -6065 7105 -6589 5157 -5345 4930
--5293 5891 19156 10996 -16040 965 -28923 2141 -34068 10195 -41718 13383
--35374 15897 -12728 19071 15171 19666 22244 18361 18940 16157 8684 14255
--5621 12193 -15629 8068 13252 12136 13186 11457 3351 10720 -10482 9869
--11394 8662 -12962 8050 -16814 8490 -17964 12296 -13636 10244 -5095 12949
--2037 15890 -3693 11747 -6110 7733 -10707 4396 -8651 6050 -3485 10882
--1965 11144 -8873 2437 -11898 1702 -13501 3187 -16117 4352 -16247 4262
--16475 397 -12943 2339 -7603 361 -32034 9613 -12337 9382 -6266 6945 -8082 7418
--15576 7880 -18484 8897 -12283 8769 -13713 12073 -12458 12148 -10814 11394
--8823 10574 1197 9735 -2637 10341 -6883 12414 -6831 11513 -7288 11138
--7049 10948 -6820 11767 -5940 11474 -5338 9481 -5201 9331 -9311 12310
--6416 12659 -4505 12497 -5417 12076 -10362 12458 -10201 12952 -3888 12250
--10111 12183 -20238 11385 -8251 13223 -16582 13136 -10560 14118 -7130 11815
--7052 10834 -6763 12506 42917 19874 65459 21729 69846 21207 54197 17841
--14888 5554 -18745 5620 -18108 5315 -12181 6283 -12383 6009 -11874 4592
--8919 4555 -7296 4578 -6561 6606 -6789 7763 1461 4264 -1422 6338 -1892 6262
--4537 2290 -2317 3242 -3661 4150 -1566 3872 -3365 1800 -5346 4200 -5846 8092
--3192 6923 6084 1973 11211 4977 15474 11888 -6341 11956 -10082 12577 -8199 11909
--7093 10122 -6570 8433 -6237 7782 -4951 7718 -18017 9049 -11286 8049 -15664 9285
--22201 6516 -20431 9580 -17005 10571 -7563 12931 12571 17764 18521 18071
-15109 14123 10498 11442 7763 10197 7683 9018 9519 7176 9370 6891 4113 8372
--19709 13899 -20160 14381 1055 9506 -16342 10672 -14411 9693 -13134 7969
--10156 8624 -3412 8989 -511 7972 -2100 7853 -4506 8651 -5562 6925 1648 7438
--3826 8165 -5052 7329 -7667 5868 -8078 7274 -13345 8652 -14925 7568 -5939 5631
-600 6763 11836 17032 9978 15932 663 14444 -5642 -2020 -22887 23278 -25922 18686
--24315 12781 -22006 9449 -20208 8012 -19115 7557 -18545 7506 -18265 7556
--18060 7568 -17810 7494 -17436 7333 -16926 7099 -16270 6820 -15483 6523
--14602 6230 -13645 5958 -12643 5714 -11605 5504 -10559 5328 -9521 5187
--8499 5086 -7506 5026 -6558 5008 -5655 5032 -4810 5097 -4022 5195 -3312 5330
--2671 5495 -2113 5692 -1631 5916 -1227 6162 -900 6427 -642 6703 -454 6985
--324 7265 -239 7543 -202 7817 -200 8081 -250 8336 -332 8577 -468 8799 -654 9004
--885 9189 -1161 9359 -1465 9516 -1789 9661 -2008 9796 -2302 9894 -2607 9978
--2893 10061 -3160 10135 -3437 10189 -3708 10231 -3966 10264 -4202 10296
--4420 10331 -4609 10361 -4774 10380 -4925 10392 -5052 10402 -5168 10412
--5274 10424 -5363 10437 -5422 10445 -5463 10452 -5488 10458 -5509 10465
--5535 10476 -5545 10485 -5535 10497 -5518 10507 -5495 10519 -5475 10532
--5456 10545 -5443 10559 -5422 10575 -5391 10592 -5363 10610 -5345 10627
--5333 10645 -5323 10662 -5314 10681 -5312 10702 -5316 10721 -5318 10740
--5326 10759 -5344 10776 -5370 10795 -5396 10814 -5431 10831 -5468 10849
--5504 10864 -5554 10879 -5604 10894 -5660 10908 -5725 10920 -5789 10933
--5842 10945 -5912 10955 -5980 10965 -6054 10974 -6129 10982 -6203 10989
-139: 12261050 -5233312 -8960 9798 -8990 9805 -9030 9810 -9060 9821 -9100 9827
--9120 9836 -9170 9841 -9200 9846 -9250 9848 -9290 9855 -9340 9860 -9380 9864
--9420 9867 -9470 9867 -9510 9868 -9560 9869 -9590 9869 -9640 9868 -9700 9866
--9720 9864 -9770 9860 -9810 9856 -9840 9848 -9880 9843 -9930 9841 -9950 9834
--9990 9829 -10010 9825 -10040 9818 -10080 9812 -10100 9812 -10140 9809
--10170 9805 -10210 9806 -10240 9806 -10270 9809 -10310 9812 -10350 9820
--10390 9831 -10440 9838 -10480 9849 -10540 9862 -10590 9880 -10650 9892
--10720 9913 -10790 9934 -10860 9960 -10930 9983 -11000 10004 -11080 10027
--11160 10056 -11250 10082 -11330 10112 -11410 10139 -11480 10161 -11560 10187
--11640 10211 -11730 10235 -11790 10259 -11860 10279 -11930 10297 -11970 10315
--12030 10329 -12080 10342 -12110 10350 -12150 10360 -12180 10369 -12200 10372
--12210 10377 -12210 10378 -12210 10372 -12200 10370 -12200 10371 -12180 10368
--12150 10364 -12130 10357 -12080 10352 -12060 10346 -12040 10344 -12030 10346
--12000 10345 -11960 10346 -11940 10346 -11920 10355 -11920 10365 -11920 10375
--11930 10394 -11950 10415 -11960 10434 -12000 10462 -12050 10489 -12100 10521
--12160 10559 -12250 10603 -12350 10645 -12440 10692 -12540 10738 -12650 10784
--12780 10834 -12920 10892 -13070 10950 -13210 11006 -13340 11057 -13480 11102
--13630 11152 -13800 11208 -13950 11257 -14090 11301 -14220 11337 -14340 11368
--14450 11397 -14560 11424 -14660 11441 -14760 11454 -14820 11459 -14870 11454
--14900 11444 -14920 11429 -14930 11403 -14910 11370 -14880 11333 -14830 11290
--14760 11235 -14660 11171 -14550 11100 -14420 11027 -14310 10956 -14170 10879
--14010 10791 -13830 10693 -13630 10595 -13450 10500 -13280 10412 -13110 10325
--12920 10229 -12730 10132 -12510 10035 -12340 9948 -12190 9873 -12060 9809
--11930 9738 -11800 9674 -11680 9615 -11600 9574 -11550 9544 -11540 9525
--11530 9516 -11560 9517 -11600 9529 -11690 9553 -11800 9590 -11960 9641
--12140 9707 -12360 9788 -12610 9882 -12890 9984 -13200 10093 -13540 10212
--13910 10352 -14320 10506 -14770 10672 -15240 10837 -15690 10999 -16180 11170
--16710 11358 -17270 11557 -17850 11759 -18420 11952 -18980 12135 -19540 12314
--20130 12504 -20750 12700 -21360 12892 -21950 13066 -22520 13216 -23060 13356
--23620 13502 -24150 13636 -24691 13747 -25185 13845 -25662 13922 -26122 13981
--26536 14024 -26912 14046 -27262 14044 -27576 14016 -27866 13962 -28111 13891
--28280 13793 -28430 13685 -28565 13543 -28599 13373 -28604 13175 -28629 12937
--28566 12731 -28349 12473 -28096 12165 -27918 11892 -27748 11633 -27429 11296
--26881 10907 -26243 10546 -25695 10269 -25359 10021 -25068 9703 -24408 9329
--23288 8955 -22182 8652 -21454 8448 -20840 8262 -19844 8060 -18471 7905
--17098 7835 -15933 7791 -14934 7703 -14118 7589 -13545 7487 -13194 7373
--12833 7236 -12169 7100 -11006 6980 -9322 6891 -7292 6841 -5329 6853 -4071 6918
--3921 6886 -4665 6614 -5491 6132 -5602 5694 -4718 5600 -3199 5992 -1744 6805
--987 7843 -1228 8829 -2342 9389 -4684 8863 -5567 7512 -5790 6690 -6446 5845
--8703 5427 -10628 5314 -10560 4711 -7751 5678 -4959 6002 -1623 5206 2320 4521
-5574 4111 6704 3510 3801 2754 -4405 3052 -14228 2298 -18801 2779 2216 6228
-564 9124 -14358 7412 -743 1017 1860 4089 4453 7706 -31782 4829 -17059 5909
--6811 6681 -3725 7724 -6695 7857 -6304 7179 -1765 11022 -3341 11804 -4244 11187
--5467 10153 -6305 9748 -6069 10248 -5930 10004 -6247 8799 -5982 7664 -3654 7905
-3430 10034 30202 14197 -21629 -2118 -25833 -9 -25246 6155 -35047 9134
--27466 11861 -5699 17266 10057 17730 7923 17027 7419 15091 1586 13644
--9242 13554 -9434 12395 9273 14107 14045 14066 5008 14113 -15730 13929
--8472 10279 -8681 8070 -11167 8643 -12022 13038 -8750 10904 -13564 9098
--8978 16640 -7560 13638 -5943 8288 -14065 5607 -13033 6530 -9452 9092
--7234 8916 -9179 3702 -9655 2134 -10625 2483 -13953 4237 -11422 4715 -12666 1561
--15199 -1231 -10628 3513 -20135 8237 -11323 8608 -5402 7335 -4945 7247
--8036 7449 -9528 8108 -16380 10044 -15486 12398 -12327 11464 -9898 10662
--6357 9771 -341 8895 -6043 11637 -8409 12271 -7743 11043 -7475 10261 -6964 10475
--6404 11605 -5810 12085 -5481 8626 -6035 9501 -8249 12061 -7267 13191
--3885 12458 -4546 12669 -8214 12922 -9058 13620 -5395 13996 -11422 12578
--16530 12501 -9422 12287 -9862 11945 -16794 14014 -10293 11532 -9002 10350
--12554 11546 17487 17500 52377 19360 59119 19292 43275 16179 2720 9072
--9699 7217 -10500 7096 -6329 7806 -4221 7435 -10917 3540 -10387 4634 -9398 3777
--11482 7689 -16733 10915 7278 -1708 -1461 2170 -698 4251 -3808 4059 -5266 4095
--1375 3760 -3364 2345 -6026 1493 -4444 6259 -4933 10363 -2496 5628 2483 -573
-6322 2256 16230 15576 3248 18232 -3584 16755 -4413 13904 -2997 10625 -2360 8167
--3383 7129 -6885 7534 -17520 9160 -9200 7041 -14256 10034 -21065 8521
--17108 11185 -11531 13632 -2982 16535 8648 19636 13090 18756 8903 10797
-5317 8433 3370 8806 3893 8665 7502 5586 6007 5923 -2217 8281 -19322 12359
--26546 14328 3472 6294 -4847 10023 -4787 6505 -8531 8292 -8980 8592 -8566 8809
--3291 6463 -2669 6635 -5948 9017 -11205 4812 2784 7488 -27 7820 -3745 6852
--7139 8194 -8667 7066 -11819 7189 -11741 6713 -6069 6030 1202 6294 11761 5820
-20325 -11287 27774 -41090 -23088 58194 -33807 52050 -28431 23727 -24683 13805
--22136 10347 -20317 9038 -19067 8491 -18256 8225 -17728 8057 -17336 7902
--16970 7726 -16553 7515 -16055 7267 -15463 6997 -14762 6717 -13982 6442
--13140 6186 -12252 5954 -11333 5753 -10406 5582 -9478 5445 -8560 5346
--7671 5284 -6814 5263 -5990 5282 -5219 5339 -4492 5426 -3834 5547 -3234 5697
--2705 5876 -2239 6079 -1851 6305 -1529 6547 -1270 6800 -1077 7060 -933 7320
--842 7579 -787 7833 -774 8082 -805 8322 -868 8548 -974 8760 -1127 8955
--1328 9132 -1567 9296 -1832 9449 -2117 9591 -2281 9727 -2540 9827 -2821 9913
--3083 9997 -3328 10073 -3583 10130 -3834 10174 -4073 10213 -4290 10248
--4491 10287 -4672 10318 -4828 10341 -4968 10355 -5094 10368 -5207 10380
--5311 10395 -5397 10409 -5459 10418 -5507 10426 -5535 10433 -5562 10442
--5591 10451 -5609 10461 -5605 10472 -5594 10482 -5576 10493 -5565 10505
--5555 10517 -5548 10530 -5531 10544 -5505 10559 -5486 10576 -5469 10591
--5462 10606 -5457 10623 -5453 10640 -5451 10658 -5454 10675 -5463 10692
--5471 10710 -5489 10725 -5514 10742 -5541 10759 -5570 10775 -5610 10790
--5649 10805 -5693 10819 -5741 10832 -5794 10845 -5854 10857 -5911 10868
--5969 10880 -6028 10889 -6095 10899 -6165 10907 -6238 10915 -6306 10923
-140: 12292340 -5224445 -9010 9803 -9030 9809 -9070 9815 -9100 9826 -9130 9834
--9170 9841 -9210 9848 -9240 9852 -9290 9856 -9330 9865 -9370 9867 -9420 9872
--9460 9877 -9500 9877 -9550 9880 -9600 9881 -9630 9881 -9680 9881 -9720 9880
--9760 9878 -9810 9874 -9840 9870 -9880 9865 -9910 9861 -9960 9856 -9980 9851
--10020 9848 -10050 9841 -10070 9837 -10100 9832 -10140 9828 -10170 9829
--10210 9826 -10230 9826 -10270 9824 -10300 9828 -10330 9832 -10380 9840
--10420 9846 -10470 9856 -10520 9868 -10560 9881 -10610 9896 -10680 9910
--10750 9927 -10810 9951 -10880 9974 -10950 9995 -11020 10018 -11100 10039
--11180 10067 -11260 10094 -11340 10121 -11430 10147 -11490 10171 -11580 10191
--11650 10215 -11730 10240 -11810 10263 -11860 10282 -11930 10299 -11980 10316
--12040 10328 -12080 10340 -12120 10350 -12140 10358 -12180 10364 -12200 10371
--12200 10372 -12220 10371 -12200 10369 -12200 10365 -12190 10364 -12180 10362
--12160 10356 -12110 10350 -12090 10345 -12060 10339 -12030 10337 -12030 10337
--11990 10337 -11960 10336 -11940 10339 -11910 10345 -11920 10356 -11920 10366
--11930 10385 -11940 10404 -11960 10423 -11990 10451 -12030 10478 -12100 10507
--12150 10549 -12240 10588 -12330 10631 -12430 10677 -12520 10722 -12630 10765
--12750 10817 -12890 10875 -13030 10931 -13180 10987 -13310 11035 -13430 11079
--13590 11129 -13740 11183 -13900 11231 -14040 11276 -14150 11311 -14270 11339
--14390 11366 -14490 11396 -14590 11412 -14680 11424 -14730 11428 -14780 11425
--14820 11414 -14840 11400 -14840 11375 -14830 11343 -14790 11306 -14740 11264
--14670 11211 -14570 11148 -14470 11080 -14350 11008 -14220 10939 -14100 10864
--13940 10777 -13760 10684 -13570 10591 -13400 10495 -13220 10410 -13060 10327
--12890 10236 -12680 10140 -12490 10047 -12320 9963 -12180 9891 -12050 9829
--11920 9763 -11800 9700 -11690 9646 -11610 9605 -11570 9578 -11550 9563
--11570 9554 -11590 9557 -11630 9571 -11720 9597 -11850 9634 -11990 9685
--12180 9752 -12390 9832 -12650 9924 -12920 10028 -13230 10134 -13560 10251
--13920 10390 -14340 10542 -14780 10703 -15230 10867 -15690 11025 -16160 11193
--16670 11377 -17230 11571 -17790 11767 -18350 11958 -18910 12134 -19450 12310
--20020 12496 -20620 12685 -21220 12871 -21800 13040 -22350 13186 -22870 13320
--23430 13463 -23940 13587 -24450 13697 -24941 13788 -25399 13861 -25841 13916
--26245 13953 -26610 13970 -26948 13964 -27256 13931 -27536 13874 -27753 13796
--27918 13700 -28097 13586 -28202 13439 -28230 13272 -28275 13051 -28291 12842
--28148 12615 -27930 12316 -27811 12044 -27723 11818 -27457 11505 -26966 11103
--26396 10738 -25967 10461 -25724 10211 -25516 9889 -24989 9489 -23933 9099
--22678 8784 -21792 8593 -21355 8467 -20779 8293 -19664 8079 -18258 7924
--16983 7856 -15944 7789 -15116 7686 -14447 7588 -13933 7510 -13456 7425
--12763 7332 -11644 7257 -9996 7199 -7940 7145 -5810 7110 -4220 7136 -3771 7148
--4572 7008 -5994 6620 -6975 6097 -6816 5707 -5509 5682 -3651 6085 -2019 6821
--1220 7709 -1444 8496 -2445 8877 -4344 8383 -4902 7661 -4757 7093 -5160 6435
--7229 5737 -10140 5096 -11969 4661 -11043 5028 -7528 5377 -1756 5348 5128 5223
-11140 5021 13942 4601 11065 4064 93 3363 -22159 779 -58330 -3140 -33791 17628
-40881 -1361 -30816 24988 11507 9551 24084 -6130 50059 7340 -71833 -505
--23475 4348 -9445 5190 -3578 4965 -6685 8466 -3472 5803 -6452 9630 -8149 10581
--6343 10312 -7157 9397 -8150 9266 -7116 10955 -6747 10881 -6630 9872 -5956 8926
--4371 8510 -2600 7933 2053 6959 -1269 4681 -9356 3974 -13140 6556 -19916 7680
--15442 10658 -3823 14467 1467 15280 975 14776 1255 13418 -942 12563 -12297 15354
--8390 15465 4182 16250 9779 16785 -1157 18717 -9956 16620 -4685 8177 -4607 6738
--7815 9738 -6287 13616 1361 13752 -20508 11526 -12850 12743 -15264 13164
--10796 6857 -15534 4936 -17284 5886 -16059 7216 -13743 6617 -9409 5768
--7014 3560 -5592 2555 -9915 5577 -8214 5842 -8383 3970 -15223 -1049 -13083 1986
--14193 5339 -9383 6814 -4793 7372 -3304 7771 -4686 8062 -7429 8670 -12887 10215
--12907 12749 -11274 10777 -9226 10245 -6675 10237 -4772 9656 -7727 11646
--9611 11756 -8103 9218 -7747 8202 -6994 8978 -6311 10432 -5947 11134 -5903 10011
--6237 10646 -6773 12154 -5897 13013 -3905 13079 -4011 13546 -5897 13046
--6674 14116 -5921 14926 -8500 14692 -10115 15130 -11518 14382 -11426 11381
--15933 9471 -10636 11667 -8749 12972 -16883 10734 -948 13251 30824 14784
-38521 15968 28949 14151 9834 10576 -265 8815 -1771 8685 -502 8888 -423 7958
--5228 5622 -7190 5400 -8382 5094 -9845 7236 -35919 19638 12002 -6829 10024 -6402
-3169 5475 -875 6620 -3069 5772 -3046 4118 -6565 2228 -10863 2023 -5051 12018
--4677 11976 -849 4068 1159 -5301 3485 -6075 14229 23676 6558 23275 61 19008
--1158 14588 1610 9949 1842 6970 -1253 5790 -6838 6450 -22052 8997 -10644 9738
--11928 8433 -14929 8787 -10311 12438 -5885 15094 -144 17666 6548 20167
-9293 19895 1778 5973 -629 5572 -2003 8174 -1787 9788 5059 4396 3345 5723
--2284 7434 -6150 7669 -6676 7552 -10081 10311 -9852 11508 -4054 8051 -8583 8421
--12456 9559 -13663 9479 -6163 5178 -5901 6479 -5482 7337 -5543 6042 1595 7572
-1370 8200 -2400 7572 -6244 8390 -7270 5935 -9630 6265 -9399 6772 -6025 7821
--1461 10247 4028 13792 10172 14912 32017 5775 -19240 4540 -30744 26872
--22886 13329 -21501 12058 -20395 11430 -19229 10688 -18218 9974 -17444 9364
--16876 8863 -16438 8452 -16050 8099 -15646 7781 -15187 7477 -14663 7186
--14059 6902 -13375 6634 -12639 6387 -11860 6165 -11049 5972 -10226 5808
--9404 5676 -8590 5578 -7794 5517 -7018 5495 -6279 5509 -5574 5558 -4913 5638
--4308 5747 -3751 5884 -3251 6047 -2814 6232 -2437 6439 -2124 6662 -1868 6894
--1668 7135 -1515 7375 -1421 7616 -1355 7855 -1324 8088 -1337 8313 -1380 8527
--1464 8728 -1593 8913 -1764 9084 -1972 9242 -2197 9390 -2446 9530 -2571 9664
--2796 9765 -3052 9852 -3289 9936 -3512 10013 -3745 10073 -3978 10121 -4197 10162
--4396 10201 -4580 10241 -4749 10276 -4896 10301 -5030 10318 -5149 10332
--5260 10347 -5359 10364 -5447 10379 -5507 10391 -5556 10398 -5591 10407
--5620 10415 -5650 10426 -5676 10436 -5678 10446 -5672 10455 -5659 10466
--5655 10477 -5652 10488 -5652 10500 -5636 10514 -5614 10527 -5605 10541
--5593 10556 -5586 10569 -5587 10584 -5582 10599 -5585 10615 -5590 10631
--5598 10647 -5612 10661 -5627 10677 -5651 10691 -5680 10706 -5710 10721
--5748 10735 -5784 10748 -5823 10761 -5872 10774 -5923 10785 -5979 10796
--6033 10806 -6087 10818 -6144 10826 -6209 10836 -6273 10844 -6341 10851
--6406 10859
-141: 12323640 -5215573 -9050 9805 -9070 9813 -9110 9819 -9140 9831 -9170 9837
--9210 9847 -9240 9852 -9280 9859 -9320 9864 -9360 9871 -9420 9875 -9450 9880
--9490 9885 -9540 9887 -9580 9890 -9630 9891 -9670 9893 -9710 9893 -9760 9891
--9800 9890 -9830 9889 -9870 9883 -9910 9880 -9950 9875 -9980 9870 -10020 9867
--10040 9865 -10080 9857 -10100 9853 -10140 9850 -10160 9847 -10200 9846
--10230 9845 -10270 9844 -10290 9842 -10320 9846 -10360 9850 -10410 9856
--10440 9865 -10490 9874 -10540 9885 -10590 9896 -10640 9910 -10690 9925
--10770 9942 -10830 9966 -10900 9987 -10970 10010 -11040 10031 -11110 10050
--11190 10074 -11280 10104 -11360 10130 -11430 10156 -11510 10178 -11580 10198
--11660 10220 -11740 10244 -11810 10265 -11870 10285 -11940 10301 -11980 10316
--12030 10328 -12080 10339 -12120 10346 -12150 10357 -12170 10362 -12200 10369
--12200 10368 -12200 10367 -12200 10363 -12200 10362 -12180 10357 -12180 10354
--12150 10351 -12120 10344 -12090 10339 -12050 10332 -12040 10330 -12010 10329
--11990 10329 -11950 10329 -11940 10332 -11920 10335 -11910 10347 -11920 10358
--11930 10375 -11930 10394 -11960 10414 -11990 10441 -12030 10468 -12070 10497
--12150 10535 -12230 10574 -12320 10616 -12410 10663 -12510 10705 -12600 10750
--12730 10801 -12860 10857 -13000 10912 -13150 10967 -13270 11013 -13390 11057
--13540 11108 -13690 11159 -13850 11206 -13980 11249 -14100 11284 -14200 11313
--14320 11337 -14430 11365 -14520 11381 -14600 11395 -14650 11400 -14710 11397
--14730 11385 -14750 11369 -14750 11346 -14750 11315 -14700 11278 -14660 11239
--14590 11187 -14490 11125 -14390 11059 -14270 10989 -14140 10922 -14030 10850
--13870 10765 -13700 10675 -13510 10583 -13340 10492 -13180 10408 -13010 10329
--12850 10240 -12650 10149 -12460 10059 -12300 9978 -12160 9910 -12040 9848
--11920 9787 -11810 9728 -11690 9675 -11620 9637 -11590 9612 -11580 9600
--11590 9595 -11620 9597 -11660 9612 -11760 9640 -11880 9678 -12020 9729
--12210 9797 -12430 9878 -12680 9968 -12960 10071 -13250 10176 -13580 10292
--13940 10430 -14350 10578 -14770 10736 -15230 10899 -15670 11054 -16140 11219
--16640 11397 -17180 11590 -17730 11780 -18280 11967 -18820 12140 -19350 12309
--19910 12492 -20490 12677 -21080 12856 -21640 13020 -22170 13162 -22680 13290
--23220 13431 -23730 13550 -24210 13656 -24680 13741 -25140 13811 -25562 13862
--25940 13896 -26306 13907 -26641 13897 -26933 13859 -27188 13800 -27385 13717
--27583 13622 -27759 13501 -27823 13357 -27878 13170 -27936 12961 -27892 12760
--27715 12483 -27610 12200 -27604 11991 -27446 11725 -27009 11321 -26470 10939
--26109 10669 -25988 10424 -25875 10086 -25446 9651 -24482 9243 -23178 8943
--22120 8766 -21693 8671 -21542 8519 -20920 8250 -19670 7972 -18229 7823
--17035 7776 -16108 7725 -15380 7641 -14720 7580 -14018 7549 -13133 7521
--11907 7506 -10321 7514 -8452 7503 -6542 7460 -5006 7409 -4387 7363 -5010 7253
--6577 6968 -8119 6515 -8488 6067 -7296 5839 -5066 5936 -2684 6344 -960 6959
--355 7646 -869 8217 -2058 8448 -3352 8094 -3661 7758 -3481 7364 -4239 6656
--7037 5687 -11116 4837 -14132 4495 -13750 4825 -9249 5386 -1387 5811 7895 5968
-15847 5812 19507 5550 16307 5694 4226 6465 -22952 6510 -105579 -1770 -152623 57520
-60580 -10180 38978 2206 44884 1173 50616 -4645 47696 658 -46464 -580 -34878 2047
--20263 3516 -11124 4399 -7248 6452 -2426 6340 -10180 11655 -12479 8507
--6196 9089 -8090 8140 -10405 7864 -8132 11381 -7714 10970 -7262 9885 -5959 9075
--3595 8621 -4767 6750 -3515 5798 -3504 5444 -3015 5671 -3829 6987 -7371 8203
--6294 10499 -1867 12955 -5723 13295 -5429 13231 -5034 12783 -6639 12878
--11475 15023 -8682 16343 -1167 17548 2914 18811 -1293 20414 -4190 18547
-2734 3233 721 4502 -6527 9901 -6992 12812 7882 11600 -5357 11690 -12424 14050
--26603 16499 -16227 5709 -20943 4987 -23716 6375 -22823 7445 -19133 7292
--13095 6751 -7533 5143 -3362 3772 -5190 5165 -5821 5436 -7470 3843 -10978 969
--10571 1634 -9870 3336 -6934 5087 -3456 7224 -1870 8371 -2634 8828 -5204 9370
--8944 10711 -10312 12350 -10099 8735 -9136 9467 -7804 10997 -7834 9953
--8790 12415 -9351 13129 -9922 5582 -8809 5561 -7273 7603 -6405 9622 -6234 10966
--6273 11189 -6122 11659 -5447 12311 -4573 12647 -3395 13110 -3208 14321
--4223 12987 -4951 14710 -5452 15501 -7269 15113 -9379 14403 -12138 12757
--13646 10077 -14397 9403 -9209 13596 -7263 17579 -12479 10825 -7272 11272
-7994 10921 16469 13233 13048 12106 9550 10658 4279 9409 4908 9769 4275 10041
-4197 8850 382 7585 -1748 7097 -3011 6690 -6775 6637 -21330 13036 1975 114
-7537 -1597 4890 4964 1870 7592 -297 7491 -2119 5919 -5587 5524 -10465 7568
--12723 13441 -9667 13960 1865 5980 2866 -2148 5152 1091 8908 15567 3435 16705
--1019 15388 -908 12930 6153 7766 5501 5183 -1691 4276 -9613 5185 -13484 9153
--14121 9866 -11316 8344 -11121 8260 -3430 13240 -2035 14525 97 15246 2800 15268
-3117 13252 -857 7988 -3103 6260 -4040 7783 -3185 7618 -271 8358 256 8454
--3315 8592 1348 5653 -1197 5831 -6269 8172 -8113 9743 -6826 8846 -11961 11001
--16968 11174 -18060 9833 -13311 6902 -9461 6459 -3513 6264 -607 6611 3049 8032
-3342 8756 -175 6891 -3347 6840 -6912 6482 -8524 6543 -7880 6907 -5836 8204
--4437 10365 -4053 12028 -6978 8931 -35199 -5806 33173 13539 -3584 14603
--16371 21016 -18380 18083 -18185 15482 -17465 13516 -16706 11970 -16079 10747
--15607 9796 -15239 9063 -14925 8497 -14612 8046 -14247 7671 -13827 7344
--13325 7052 -12754 6787 -12129 6550 -11457 6339 -10751 6157 -10036 6001
--9310 5876 -8587 5783 -7880 5724 -7188 5703 -6526 5713 -5892 5758 -5299 5830
--4741 5930 -4228 6057 -3766 6205 -3349 6377 -2993 6566 -2685 6771 -2439 6986
--2235 7208 -2079 7431 -1972 7656 -1902 7878 -1849 8097 -1851 8310 -1878 8513
--1942 8702 -2047 8879 -2190 9043 -2365 9195 -2568 9338 -2778 9476 -2875 9607
--3070 9707 -3295 9795 -3507 9880 -3714 9957 -3921 10019 -4134 10069 -4333 10113
--4518 10155 -4687 10196 -4839 10234 -4978 10260 -5105 10280 -5220 10297
--5322 10314 -5419 10332 -5505 10348 -5565 10361 -5615 10370 -5653 10379
--5683 10388 -5716 10399 -5746 10409 -5754 10420 -5751 10428 -5746 10438
--5744 10449 -5749 10459 -5746 10470 -5741 10482 -5726 10495 -5717 10507
--5710 10521 -5708 10532 -5711 10546 -5713 10560 -5710 10574 -5719 10588
--5731 10603 -5743 10615 -5763 10629 -5783 10642 -5813 10656 -5845 10670
--5878 10682 -5911 10694 -5951 10706 -5999 10717 -6047 10728 -6097 10738
--6151 10748 -6202 10758 -6256 10767 -6318 10776 -6379 10783 -6440 10791
--6504 10798
-142: 12354950 -5206700 -9080 9808 -9120 9818 -9140 9824 -9180 9833 -9210 9842
--9240 9849 -9280 9858 -9310 9864 -9350 9869 -9400 9876 -9450 9881 -9490 9888
--9520 9892 -9570 9897 -9610 9898 -9660 9900 -9700 9903 -9750 9903 -9790 9902
--9820 9903 -9870 9901 -9890 9896 -9940 9890 -9970 9889 -10010 9887 -10050 9882
--10080 9878 -10100 9871 -10130 9870 -10160 9867 -10190 9862 -10220 9862
--10260 9862 -10280 9861 -10320 9860 -10340 9860 -10390 9867 -10430 9873
--10470 9881 -10510 9890 -10550 9901 -10610 9911 -10660 9924 -10720 9940
--10780 9958 -10850 9978 -10910 10000 -10990 10021 -11050 10042 -11120 10059
--11200 10085 -11290 10113 -11370 10138 -11440 10163 -11520 10183 -11590 10206
--11660 10226 -11740 10247 -11820 10268 -11880 10287 -11930 10302 -11970 10315
--12040 10329 -12080 10339 -12110 10346 -12140 10354 -12180 10361 -12190 10364
--12200 10363 -12200 10361 -12190 10360 -12190 10357 -12180 10353 -12170 10351
--12150 10346 -12120 10338 -12080 10330 -12050 10325 -12040 10322 -12010 10324
--11980 10322 -11950 10323 -11930 10323 -11920 10328 -11910 10338 -11920 10351
--11920 10367 -11930 10383 -11960 10405 -11980 10431 -12030 10458 -12070 10488
--12130 10522 -12220 10562 -12300 10603 -12400 10649 -12490 10689 -12590 10735
--12700 10785 -12840 10838 -12970 10895 -13120 10946 -13230 10991 -13360 11036
--13490 11086 -13650 11136 -13790 11182 -13930 11223 -14040 11255 -14140 11285
--14260 11310 -14360 11335 -14450 11354 -14520 11365 -14580 11370 -14630 11367
--14650 11358 -14670 11340 -14670 11316 -14660 11286 -14620 11252 -14580 11213
--14510 11163 -14410 11102 -14300 11038 -14200 10970 -14080 10905 -13950 10835
--13810 10753 -13640 10665 -13450 10576 -13290 10488 -13120 10407 -12980 10331
--12800 10245 -12620 10155 -12440 10070 -12290 9993 -12140 9927 -12030 9869
--11920 9811 -11810 9755 -11700 9704 -11640 9670 -11600 9648 -11600 9635
--11620 9633 -11640 9637 -11700 9654 -11780 9684 -11910 9722 -12060 9776
--12250 9840 -12460 9923 -12710 10014 -12980 10115 -13270 10219 -13600 10335
--13950 10471 -14350 10616 -14780 10772 -15210 10932 -15650 11086 -16110 11246
--16600 11421 -17130 11610 -17660 11798 -18210 11980 -18720 12148 -19250 12315
--19790 12492 -20360 12673 -20930 12848 -21470 13006 -22000 13145 -22490 13271
--23000 13407 -23500 13521 -23970 13622 -24440 13705 -24870 13771 -25270 13816
--25640 13849 -26002 13858 -26319 13843 -26596 13801 -26829 13738 -27044 13657
--27260 13556 -27392 13433 -27440 13286 -27521 13092 -27564 12899 -27464 12662
--27361 12373 -27387 12155 -27349 11937 -27019 11570 -26499 11157 -26149 10884
--26112 10662 -26106 10321 -25774 9842 -24918 9394 -23656 9113 -22513 8974
--22013 8883 -22116 8727 -22066 8403 -21196 7979 -19693 7687 -18173 7635
--17026 7695 -16189 7703 -15476 7658 -14671 7637 -13568 7663 -12094 7710
--10334 7774 -8530 7823 -6974 7807 -5944 7717 -5687 7590 -6366 7435 -7885 7182
--9636 6808 -10530 6404 -9377 6178 -6241 6234 -2614 6497 282 6880 1776 7318
-1697 7745 354 8046 -1483 8086 -2390 7885 -2607 7748 -2805 7362 -4507 6477
--8475 5339 -13482 4522 -16830 4427 -15995 5020 -10184 5895 -546 6579 10256 6686
-18705 6161 20957 5585 13672 5864 -5891 7378 -41853 9482 -97940 12465 -108081 35226
-8725 4605 38968 418 50294 -1186 50847 -3246 34305 -1504 -16934 -869 -27399 1006
--23825 2782 -18151 4453 -14781 6693 -16241 9036 -22755 12286 18043 6089
--2990 8187 -7702 7592 -11168 8082 -10724 9453 -9296 9267 -8338 8559 -6881 8030
--2510 8076 -3711 6812 -3465 5976 -5574 5710 -3666 5949 1275 7135 -1290 8391
--4064 10195 -5063 11799 -7981 12272 -8731 12573 -9108 12626 -10283 12586
--12104 14208 -10216 15864 -5160 16962 -478 17478 777 16949 2525 13055
-7448 4209 4273 6779 1878 9206 2185 9781 10740 9254 7357 9856 -1189 12472
--30136 16587 -32981 11379 -34096 9239 -33640 9123 -30780 9245 -25324 8832
--17531 7990 -9001 6612 -632 4359 -2623 5146 -4296 5457 -6245 4041 -6544 2441
--5814 2000 -5316 2189 -4135 3389 -1374 7262 -164 8787 -770 9003 -2922 8903
--5871 9167 -8086 9439 -9370 7980 -9751 8408 -9538 9846 -9527 11137 -9855 12408
--10159 11337 -10457 6418 -9369 5587 -7196 7991 -6379 9869 -6549 11567
--6678 12082 -6148 12204 -4248 12186 -3743 11665 -2993 11471 -2622 12037
--3086 15635 -3656 16411 -4508 16097 -6341 14664 -9037 12964 -12734 10587
--15677 7920 -15100 7864 -6761 13638 -4546 18983 -7263 15645 -7435 14446
--5783 11704 473 9922 -2182 9787 7394 10230 3367 8978 8127 10021 5095 11165
-8838 9144 4485 8821 2905 8658 1535 7966 -2038 7842 -8873 8673 75 4107 4630 3490
-4312 6771 3095 9191 2087 9530 283 7392 -1890 8342 -8044 11209 -21919 13758
--19355 16307 7120 8842 3325 645 5333 6801 5889 10378 -518 8425 -3326 10154
--3363 11340 11221 5314 9500 4258 -2034 3941 -9457 5299 -13605 8905 -10314 9537
--9345 8710 -5868 8542 -675 12114 -2132 12270 -2064 11654 -1238 9960 -1760 7359
--2997 9927 -4273 7408 -5035 9574 -4720 8697 -3053 8615 557 9220 14 8338
-426 6622 -2150 5853 -4653 6848 -5448 7788 -7041 8172 -14864 13753 -21780 12447
--23065 10253 -18840 7900 -12673 6448 -681 5243 2689 6690 4520 8241 4523 8623
-2684 7186 227 6078 -6388 7302 -7408 7007 -6098 6523 -4399 7373 -5582 8625
--7261 8963 559 6434 27592 -1658 -35770 11658 -15860 14878 -15746 20525
--16098 20458 -15793 18343 -15205 15917 -14619 13748 -14163 11982 -13857 10614
--13664 9584 -13516 8820 -13370 8246 -13170 7805 -12901 7448 -12538 7149
--12103 6893 -11599 6667 -11040 6473 -10444 6304 -9826 6161 -9201 6046
--8567 5960 -7941 5908 -7338 5887 -6750 5897 -6183 5937 -5647 6007 -5143 6098
--4672 6215 -4244 6353 -3856 6510 -3519 6686 -3225 6876 -2984 7075 -2781 7279
--2625 7488 -2507 7697 -2422 7905 -2366 8111 -2347 8311 -2362 8503 -2406 8683
--2488 8851 -2603 9008 -2757 9155 -2931 9294 -3114 9428 -3187 9554 -3356 9654
--3555 9742 -3741 9827 -3922 9904 -4109 9967 -4300 10020 -4482 10066 -4651 10110
--4804 10153 -4944 10192 -5075 10221 -5192 10243 -5299 10261 -5396 10279
--5490 10300 -5573 10317 -5633 10331 -5681 10341 -5718 10350 -5754 10361
--5792 10371 -5818 10382 -5829 10392 -5834 10401 -5833 10410 -5837 10420
--5841 10429 -5844 10441 -5842 10451 -5834 10462 -5826 10475 -5823 10485
--5827 10497 -5831 10509 -5836 10521 -5836 10534 -5843 10547 -5854 10559
--5869 10572 -5894 10583 -5914 10596 -5942 10608 -5973 10620 -6003 10631
--6035 10643 -6075 10653 -6118 10663 -6163 10674 -6214 10683 -6264 10692
--6312 10702 -6364 10710 -6420 10718 -6479 10726 -6539 10733 -6597 10740
-143: 12386290 -5197824 -9130 9811 -9150 9820 -9190 9826 -9210 9838 -9240 9844
--9280 9853 -9310 9863 -9340 9868 -9390 9872 -9430 9882 -9480 9888 -9520 9894
--9560 9899 -9600 9903 -9640 9906 -9690 9909 -9730 9911 -9770 9914 -9810 9912
--9860 9912 -9880 9911 -9930 9908 -9960 9903 -10000 9901 -10040 9899 -10070 9896
--10100 9889 -10130 9888 -10150 9884 -10180 9881 -10210 9880 -10250 9876
--10280 9877 -10300 9875 -10340 9874 -10370 9878 -10400 9882 -10450 9888
--10500 9897 -10530 9905 -10560 9914 -10630 9926 -10670 9937 -10740 9955
--10800 9971 -10860 9990 -10920 10013 -11000 10031 -11060 10051 -11130 10070
--11210 10095 -11300 10120 -11370 10145 -11460 10168 -11520 10189 -11590 10212
--11660 10230 -11750 10251 -11810 10272 -11880 10289 -11940 10303 -11970 10316
--12030 10329 -12080 10339 -12110 10344 -12140 10351 -12160 10357 -12190 10363
--12190 10360 -12190 10356 -12200 10356 -12180 10351 -12170 10349 -12160 10347
--12140 10341 -12120 10332 -12080 10324 -12050 10317 -12020 10317 -12010 10317
--11980 10317 -11950 10315 -11930 10316 -11910 10321 -11910 10332 -11910 10344
--11920 10358 -11930 10376 -11950 10397 -11990 10422 -12010 10447 -12070 10477
--12130 10511 -12210 10550 -12290 10591 -12380 10634 -12470 10677 -12570 10720
--12690 10768 -12810 10821 -12950 10876 -13080 10925 -13200 10971 -13320 11016
--13450 11063 -13600 11112 -13750 11157 -13870 11198 -13980 11228 -14090 11257
--14190 11283 -14300 11306 -14380 11324 -14450 11336 -14510 11341 -14550 11337
--14580 11329 -14590 11313 -14590 11288 -14570 11258 -14540 11227 -14500 11187
--14430 11138 -14340 11079 -14230 11017 -14120 10951 -14010 10887 -13890 10820
--13740 10740 -13580 10656 -13400 10568 -13240 10483 -13070 10406 -12940 10331
--12770 10250 -12590 10164 -12420 10081 -12260 10006 -12130 9946 -12030 9889
--11910 9834 -11810 9780 -11720 9735 -11650 9703 -11620 9681 -11620 9672
--11640 9670 -11670 9677 -11720 9695 -11820 9727 -11940 9768 -12090 9820
--12270 9887 -12500 9967 -12730 10060 -13000 10160 -13300 10264 -13610 10378
--13960 10512 -14350 10656 -14770 10810 -15200 10967 -15630 11119 -16070 11276
--16550 11448 -17070 11632 -17600 11818 -18120 11998 -18630 12161 -19140 12325
--19670 12497 -20220 12674 -20780 12846 -21300 13000 -21810 13137 -22290 13256
--22790 13389 -23260 13499 -23740 13598 -24170 13678 -24590 13739 -24980 13782
--25350 13813 -25690 13821 -25987 13800 -26251 13758 -26482 13693 -26720 13610
--26913 13502 -26996 13383 -27065 13224 -27163 13046 -27160 12843 -27084 12569
--27104 12324 -27155 12137 -26954 11827 -26486 11408 -26112 11105 -26089 10913
--26212 10601 -25993 10093 -25225 9577 -24065 9282 -22951 9190 -22406 9114
--22594 8917 -22962 8530 -22633 7978 -21255 7512 -19406 7390 -17820 7567
--16773 7769 -16059 7809 -15316 7763 -14226 7768 -12579 7852 -10478 7972
--8335 8083 -6734 8107 -6154 7999 -6760 7786 -8313 7553 -10241 7301 -12038 6988
--13175 6630 -12820 6383 -9242 6524 -2982 6985 2420 7425 5553 7724 6251 7916
-4823 8003 1932 7949 -1211 7715 -2333 7589 -2376 7546 -3229 7070 -6347 5995
--11626 4811 -17062 4227 -19876 4525 -17832 5516 -10426 6768 779 7650 12427 7454
-20425 6085 20473 4626 9421 4689 -13356 6917 -45721 10668 -77597 15491
--73963 22554 -14418 10303 22186 3863 39407 706 41069 -1124 26466 -1038
--2929 -410 -18629 1077 -23086 2870 -20788 4614 -15183 6637 -12526 9432
--9180 11017 4783 9236 -6751 7776 -6577 6943 -11557 8267 -12074 7869 -9145 7414
--8087 7044 -8257 6725 -1917 7698 -3760 6926 -4413 6291 -4521 5925 -1775 5901
-1842 6537 -432 7734 -6726 9463 -9738 10791 -10231 11276 -10465 12148 -11161 12691
--12168 11476 -13386 13167 -12549 14998 -8574 15461 -1931 14903 2346 13125
-5624 9385 9064 4685 10160 7767 10926 8129 9307 6682 15388 6803 16688 7508
-15029 10083 -38373 18905 -45819 16226 -44963 13449 -42185 12095 -37805 11315
--31164 10330 -21425 8709 -8754 6452 2267 5694 -3517 6232 -4658 6612 -4751 5033
--928 4247 749 3369 193 2140 -1315 1493 1104 7634 1523 8715 863 8375 -906 7556
--3489 6947 -6310 6839 -9007 6870 -10582 7116 -11011 8502 -10561 12256
--10520 12832 -10523 10772 -10725 7122 -9847 6252 -6784 9546 -6291 10491
--6874 12357 -7068 12531 -6531 12240 -3108 12001 -3990 10940 -3304 10916
--2561 12234 -2438 15176 -2592 16386 -3077 16030 -4669 13940 -7253 12038
--11921 9269 -17083 6249 -17811 5868 -3206 15270 -863 18500 -2582 17106
--6213 15533 -12899 14271 -1255 10138 -6797 10959 1659 9761 199 9190 2443 7589
--3803 12119 14022 7549 7417 8827 7735 9586 2875 8129 644 8837 -1627 8025
-1649 6785 3228 7392 2574 9006 2493 10813 3146 11464 2052 7140 3192 9231
-170 12139 -28295 8821 -31879 9288 7631 10747 2818 6066 788 7593 3745 9797
-1568 8457 -65 7268 -586 9413 8440 7109 10118 6211 -4748 5271 -9113 6302
--10678 7392 -8066 9683 -9672 9160 -1850 5201 3125 14339 -3797 11375 -4789 9997
--4180 8320 -4858 6726 -5402 9235 -5096 8189 -5254 9297 -5360 8760 -5372 7664
-2061 9474 1539 7905 -2793 7487 -7169 5652 -6975 6371 -5016 7898 -7269 10017
--13366 13228 -25249 11070 -26288 9385 -19735 7687 -10186 5163 -538 4645
-3126 7277 4517 8965 4508 9266 3516 8233 1266 6451 -3215 6984 -4828 7131
--3295 5693 -1396 6707 -5819 7508 -14204 7211 -3517 6380 11011 20561 -24869 -62
--19284 11106 -15749 19407 -14219 21224 -13276 19751 -12533 17284 -11991 14844
--11683 12776 -11598 11148 -11654 9920 -11769 9017 -11881 8357 -11915 7866
--11859 7492 -11683 7195 -11407 6951 -11043 6744 -10613 6567 -10129 6417
--9614 6290 -9082 6188 -8539 6113 -7997 6067 -7470 6050 -6952 6062 -6453 6102
--5974 6166 -5518 6252 -5090 6361 -4697 6490 -4342 6637 -4023 6800 -3739 6975
--3506 7160 -3310 7350 -3149 7544 -3022 7740 -2930 7935 -2865 8128 -2832 8317
--2831 8498 -2858 8670 -2922 8829 -3011 8980 -3142 9120 -3289 9255 -3448 9386
--3507 9506 -3653 9605 -3822 9692 -3982 9778 -4143 9856 -4307 9919 -4478 9973
--4641 10022 -4792 10067 -4934 10111 -5058 10152 -5181 10182 -5290 10205
--5392 10226 -5486 10246 -5570 10267 -5646 10285 -5708 10301 -5755 10311
--5792 10322 -5831 10332 -5869 10343 -5892 10354 -5910 10364 -5917 10373
--5922 10382 -5926 10391 -5937 10400 -5942 10411 -5942 10420 -5939 10431
--5935 10441 -5933 10451 -5939 10462 -5944 10473 -5952 10484 -5957 10495
--5964 10507 -5977 10518 -5994 10529 -6016 10539 -6037 10551 -6064 10562
--6095 10573 -6125 10583 -6155 10593 -6192 10603 -6232 10613 -6278 10621
--6327 10631 -6372 10639 -6418 10648 -6468 10656 -6518 10664 -6575 10671
--6634 10677 -6689 10685
-144: 12417630 -5188945 -9150 9813 -9200 9820 -9210 9829 -9250 9840 -9280 9848
--9310 9857 -9350 9865 -9380 9872 -9410 9877 -9460 9888 -9510 9892 -9550 9900
--9590 9904 -9620 9909 -9680 9912 -9710 9917 -9760 9919 -9790 9921 -9840 9921
--9880 9922 -9910 9919 -9950 9918 -9990 9916 -10020 9912 -10060 9912 -10090 9906
--10120 9904 -10160 9901 -10170 9897 -10200 9894 -10240 9893 -10260 9891
--10300 9890 -10320 9889 -10360 9889 -10380 9892 -10430 9896 -10460 9903
--10510 9910 -10550 9917 -10590 9928 -10630 9941 -10690 9951 -10750 9966
--10810 9985 -10870 10000 -10940 10023 -11010 10041 -11070 10062 -11140 10081
--11210 10103 -11300 10127 -11380 10151 -11460 10175 -11520 10193 -11600 10216
--11660 10234 -11740 10256 -11810 10275 -11880 10288 -11930 10305 -11980 10316
--12020 10328 -12070 10339 -12100 10343 -12140 10349 -12160 10355 -12170 10358
--12190 10358 -12190 10354 -12180 10351 -12170 10347 -12170 10346 -12160 10342
--12140 10336 -12100 10324 -12080 10319 -12040 10313 -12020 10313 -12010 10309
--11970 10310 -11950 10310 -11930 10311 -11910 10317 -11900 10323 -11910 10336
--11920 10349 -11930 10369 -11940 10389 -11980 10412 -12010 10440 -12070 10467
--12120 10502 -12200 10536 -12280 10581 -12370 10621 -12460 10663 -12550 10704
--12660 10753 -12790 10803 -12930 10856 -13040 10909 -13170 10950 -13280 10996
--13410 11039 -13560 11088 -13700 11133 -13820 11173 -13930 11202 -14030 11230
--14140 11255 -14230 11279 -14310 11295 -14380 11307 -14440 11313 -14480 11309
--14500 11298 -14510 11283 -14520 11260 -14500 11231 -14460 11200 -14420 11162
--14350 11113 -14270 11057 -14160 10995 -14050 10933 -13930 10869 -13830 10805
--13680 10728 -13520 10645 -13350 10560 -13190 10479 -13030 10404 -12900 10333
--12740 10253 -12560 10171 -12400 10091 -12240 10020 -12120 9963 -12020 9910
--11920 9857 -11810 9806 -11720 9765 -11670 9733 -11640 9715 -11640 9708
--11660 9709 -11690 9717 -11750 9736 -11850 9770 -11970 9811 -12120 9867
--12300 9933 -12520 10013 -12760 10104 -13020 10205 -13310 10308 -13620 10422
--13960 10554 -14350 10698 -14760 10850 -15180 11003 -15600 11153 -16040 11309
--16500 11478 -17010 11658 -17520 11840 -18040 12016 -18530 12179 -19020 12339
--19550 12508 -20080 12680 -20620 12849 -21130 13000 -21610 13132 -22090 13250
--22570 13375 -23030 13487 -23490 13581 -23900 13658 -24310 13719 -24690 13760
--25050 13788 -25370 13791 -25650 13773 -25908 13728 -26152 13662 -26388 13576
--26528 13467 -26595 13345 -26705 13188 -26795 13019 -26770 12785 -26776 12517
--26867 12322 -26808 12083 -26432 11692 -26010 11341 -25949 11159 -26147 10915
--26117 10414 -25466 9825 -24376 9467 -23341 9388 -22838 9347 -23052 9112
--23637 8641 -23749 7998 -22712 7389 -20705 7141 -18598 7374 -17131 7799
--16346 8035 -15832 7993 -15028 7881 -13540 7892 -11253 8053 -8543 8259
--6219 8380 -5228 8302 -6235 7989 -9155 7579 -12884 7259 -15668 7017 -16731 6796
--16360 6559 -15021 6446 -8476 7070 2981 8121 10274 8705 12931 8828 12093 8698
-8655 8360 3456 7875 -1891 7236 -4137 7049 -2989 7154 -4656 6601 -9671 5343
--16374 4204 -21632 4005 -23084 4737 -19342 6120 -10141 7828 2629 9073
-14762 8541 22086 5830 20244 2771 6767 2296 -15958 5313 -42201 10186 -60816 14730
--55078 17215 -21863 11995 8278 6970 26289 3523 30465 1354 21167 537 2532 741
--13281 1952 -22484 3661 -22364 4799 -12069 5753 -7828 9540 -4743 11003
--11506 7518 -7379 8539 -6943 8075 -9520 8292 -10018 7780 -5490 6506 -3443 6717
--2238 7289 -8703 6305 -8205 6551 -6917 6476 -4835 6059 -1018 5520 2464 5353
--230 6255 -12434 8180 -15600 9391 -11630 9329 -10652 10877 -11674 12943
--12612 9378 -14490 12898 -15253 15176 -12640 14285 -2228 12601 3398 10417
-7105 7780 12014 5146 8991 6505 12500 5378 14940 5335 18468 6234 16697 7649
-4894 12648 -29037 17682 -43071 17044 -46258 15106 -44983 13694 -41472 12724
--35716 11645 -26097 9446 -9966 5409 8816 6714 -8207 7368 -11424 7747 2287 7561
-8031 7178 9135 6333 7242 4719 2309 2310 1973 5385 2221 6974 1929 6894 684 5867
--1513 4959 -4638 5002 -8809 6596 -11245 6384 -12010 6902 -10780 13871
--10555 13561 -9936 11052 -10229 8169 -9360 8528 -7592 9884 -7061 10720
--7088 11824 -6742 12108 -5637 11964 -3812 11486 -6399 10066 -4439 10501
--3008 12017 -2442 14041 -2027 15298 -1453 15693 -2019 13486 -2890 12593
--7793 10019 -14907 7194 -15624 7171 -6235 12965 -725 16319 1449 16284
-591 14795 -11232 15374 -4743 11020 -8572 13013 -2803 9593 -1612 7775 -5950 8148
--20884 13107 18502 4402 16835 6376 4064 9543 1498 8584 2155 9845 2402 9197
-3702 8853 2158 10396 -325 10274 -448 10478 142 9887 2391 7675 3699 8961
-4877 10513 -5506 7949 -3851 6909 -19160 9625 -13664 7321 -10538 7226 958 10685
-2369 8546 2745 6596 -2047 10309 2512 9027 3171 7572 -639 8253 -7207 8467
--15196 6798 3878 13530 -2778 -1721 -7508 8121 5032 16158 -2894 12731 -6205 10556
--5408 8829 -7399 5718 -6957 8456 -5762 8920 -4468 9901 -3262 9989 -4924 8297
--1252 8573 -835 7893 -6614 6529 -16310 3520 -13944 5150 -8104 7606 -5165 10693
--8003 13046 -27936 8552 -26757 8106 -16725 7775 -5339 3935 1404 3828 3189 8298
-3910 9789 3858 9912 3807 9150 2807 5819 -128 6466 -2106 7966 639 5545 202 8258
--5707 9677 -26656 9239 -11076 3345 -14804 10555 -15361 6115 -13384 17751
--12299 22169 -11346 22054 -10313 20062 -9387 17560 -8797 15149 -8620 13068
--8781 11383 -9183 10082 -9659 9110 -10122 8400 -10476 7880 -10696 7496
--10746 7205 -10673 6974 -10475 6788 -10181 6633 -9818 6502 -9411 6393
--8970 6307 -8513 6244 -8050 6207 -7596 6195 -7149 6212 -6707 6250 -6283 6311
--5879 6395 -5493 6497 -5132 6619 -4802 6755 -4503 6908 -4236 7071 -4012 7243
--3820 7420 -3655 7602 -3528 7783 -3426 7967 -3352 8149 -3305 8327 -3286 8498
--3302 8661 -3345 8813 -3418 8956 -3522 9091 -3638 9223 -3780 9348 -3832 9464
--3954 9561 -4095 9649 -4230 9733 -4366 9810 -4513 9874 -4666 9930 -4809 9979
--4947 10026 -5072 10071 -5184 10112 -5297 10144 -5397 10169 -5494 10191
--5581 10213 -5659 10234 -5729 10254 -5789 10270 -5836 10281 -5875 10293
--5908 10303 -5950 10315 -5973 10326 -5994 10336 -6003 10345 -6011 10353
--6017 10362 -6028 10371 -6041 10380 -6038 10390 -6042 10400 -6040 10408
--6042 10419 -6047 10427 -6057 10437 -6065 10448 -6070 10458 -6082 10468
--6096 10478 -6114 10488 -6131 10498 -6155 10507 -6179 10518 -6211 10528
--6243 10537 -6271 10546 -6305 10555 -6343 10564 -6387 10572 -6433 10581
--6475 10589 -6520 10597 -6568 10604 -6617 10612 -6669 10619 -6725 10625
--6774 10633
-145: 12448990 -5180067 -9190 9816 -9220 9822 -9250 9833 -9280 9842 -9310 9849
--9340 9859 -9380 9867 -9410 9874 -9450 9882 -9490 9891 -9540 9899 -9580 9904
--9610 9908 -9650 9914 -9700 9919 -9740 9922 -9790 9926 -9820 9930 -9860 9928
--9900 9931 -9930 9929 -9970 9928 -10010 9925 -10050 9922 -10080 9922 -10100 9917
--10150 9915 -10170 9911 -10190 9908 -10230 9908 -10250 9906 -10290 9904
--10310 9903 -10340 9903 -10370 9902 -10400 9904 -10440 9909 -10480 9917
--10520 9923 -10560 9930 -10600 9940 -10650 9953 -10710 9963 -10750 9978
--10820 9994 -10880 10012 -10950 10035 -11010 10051 -11080 10070 -11150 10089
--11220 10112 -11300 10134 -11380 10157 -11460 10180 -11530 10200 -11590 10219
--11660 10236 -11730 10258 -11810 10275 -11870 10291 -11930 10306 -11970 10317
--12020 10328 -12060 10336 -12100 10344 -12130 10348 -12140 10351 -12170 10357
--12180 10356 -12180 10350 -12180 10348 -12160 10342 -12160 10340 -12150 10336
--12130 10333 -12100 10320 -12070 10314 -12030 10308 -12020 10307 -12000 10304
--11980 10306 -11940 10304 -11930 10306 -11910 10311 -11900 10317 -11910 10328
--11910 10343 -11920 10361 -11950 10382 -11970 10404 -12010 10430 -12050 10459
--12120 10492 -12190 10526 -12270 10568 -12360 10608 -12440 10652 -12530 10687
--12650 10737 -12770 10787 -12900 10840 -13010 10889 -13140 10931 -13250 10975
--13370 11018 -13510 11066 -13660 11107 -13770 11147 -13880 11176 -13980 11203
--14070 11228 -14170 11251 -14250 11268 -14310 11277 -14370 11284 -14410 11279
--14430 11270 -14440 11255 -14440 11232 -14420 11204 -14390 11172 -14350 11137
--14270 11089 -14200 11034 -14090 10974 -13980 10913 -13870 10852 -13760 10790
--13620 10714 -13460 10635 -13310 10553 -13140 10474 -12990 10402 -12860 10334
--12710 10256 -12530 10178 -12380 10103 -12230 10034 -12110 9979 -12020 9929
--11910 9880 -11820 9831 -11730 9792 -11680 9765 -11650 9748 -11660 9744
--11680 9746 -11720 9757 -11780 9779 -11880 9812 -11990 9855 -12150 9910
--12330 9979 -12540 10059 -12770 10150 -13050 10250 -13320 10354 -13620 10467
--13970 10597 -14340 10739 -14750 10889 -15150 11042 -15570 11190 -16000 11342
--16440 11510 -16950 11687 -17440 11864 -17950 12038 -18430 12198 -18910 12356
--19410 12523 -19930 12691 -20460 12856 -20950 13005 -21430 13134 -21870 13249
--22350 13371 -22790 13481 -23240 13572 -23630 13650 -24030 13706 -24400 13746
--24740 13772 -25040 13776 -25320 13757 -25570 13713 -25835 13647 -26024 13553
--26119 13450 -26215 13325 -26353 13176 -26423 12997 -26428 12744 -26498 12516
--26545 12321 -26317 11995 -25901 11613 -25714 11396 -25934 11221 -26086 10798
--25652 10163 -24652 9691 -23644 9578 -23200 9574 -23477 9330 -24152 8772
--24521 8047 -23830 7366 -21903 7024 -19443 7222 -17436 7799 -16411 8278
--16106 8324 -15821 8063 -14869 7849 -12858 7908 -9849 8209 -6547 8544
--4144 8678 -3951 8420 -6898 7769 -12715 7062 -19025 6758 -21977 6705 -20845 6791
--17689 6748 -18065 6375 -9121 7580 12487 9667 20654 10258 21368 10028
-18285 9561 12612 8737 4628 7826 -4118 6558 -9246 6104 -3134 6776 -6164 6209
--13976 4665 -22552 3522 -26831 3855 -26117 4960 -20629 6491 -9696 8699
-4888 10838 17223 10352 24224 5795 21430 83 5843 -1204 -16006 3185 -37540 9550
--49446 13902 -44291 15200 -23195 12553 96 8923 16564 5813 22511 3579 17752 2355
-5105 2219 -9939 3346 -23228 5274 -25996 5134 -9051 3413 -9776 9616 -10468 10605
--12196 7960 -8499 8232 -6588 8233 -6816 7940 -6497 7202 -4057 6368 -2869 6549
--3700 7066 -8622 6907 -9954 7149 -9256 7094 -6811 6449 -2279 5211 2812 3877
-2033 4221 -19506 6023 -20995 6658 -10163 5695 -8991 6190 -11113 11473
--12028 7789 -14754 16369 -17091 18232 -18059 13979 -1566 10814 3063 8289
-4541 6819 9903 5112 8375 5406 11217 4233 16740 5811 17617 6449 12468 8535
--1675 13564 -23250 16320 -36340 16020 -41382 14782 -41950 13707 -40360 13062
--37217 12528 -31090 10752 -16808 3247 11060 8066 -1690 8925 -17835 9202
-11085 10109 14976 9901 15274 9373 13522 8075 4279 2512 2729 4228 2808 5740
-2735 5741 1904 4888 169 4153 -2717 4414 -8456 8434 -11053 7852 -11423 8547
--10640 12205 -10159 12555 -8329 11154 -9144 9405 -9858 9089 -8840 9465
--8324 10114 -7752 10922 -6932 11212 -5967 11181 -6020 10474 -7972 9479
--5113 10063 -3744 11287 -3341 12156 -2834 12869 -1443 13829 1404 14735
-4209 15447 -785 12598 -14000 8038 -16420 7177 -9266 11424 -2446 15135
-1163 16512 646 16553 -5169 16742 -4299 14053 -5254 10439 -1331 6242 2605 4005
-2157 3887 -22292 9258 186 7903 4953 10174 1918 9309 1504 7830 4036 10033
-4824 9724 4216 9808 -422 12344 -2319 11548 -2524 9811 -1883 7450 -500 8012
-114 8656 7315 10344 2144 8402 -2527 7120 -13960 7742 -12054 7217 -12170 8894
--6258 10067 -2689 8510 -138 7379 -1677 10167 1567 10282 2943 9458 1156 8299
--3983 8504 -5127 8211 2321 11359 -1787 4712 -4261 9423 752 12941 -6119 12454
--9281 11437 -5437 11221 -10371 4897 -9661 6155 -6704 8621 -3737 10750
--426 11913 -7894 8033 -5495 7753 -2255 8188 -7973 6679 -28118 873 -26449 1747
--13146 5718 -6036 9154 -8703 10522 -20650 8302 -20452 7647 -6886 7952
--245 5840 3052 5604 4140 7860 3825 9393 3612 9335 3758 8070 5150 4457 3288 4936
-940 7232 -139 9293 -3284 14712 -11171 17481 -24013 17059 -23878 15286
--36798 32633 -10461 -28439 -7942 16406 -9400 21105 -8850 20215 -7301 18538
--5840 16685 -5014 14806 -4915 13034 -5400 11477 -6234 10193 -7192 9193
--8114 8444 -8869 7897 -9427 7499 -9764 7206 -9917 6987 -9907 6816 -9762 6680
--9526 6569 -9222 6479 -8873 6408 -8508 6358 -8118 6331 -7730 6327 -7342 6347
--6958 6386 -6585 6448 -6227 6527 -5883 6625 -5550 6739 -5248 6868 -4971 7011
--4719 7163 -4502 7324 -4311 7490 -4148 7659 -4021 7830 -3911 8001 -3827 8174
--3765 8340 -3739 8503 -3736 8657 -3759 8802 -3815 8938 -3893 9067 -3997 9194
--4108 9317 -4155 9428 -4254 9524 -4367 9609 -4483 9693 -4599 9768 -4724 9833
--4860 9889 -4989 9939 -5110 9987 -5219 10032 -5321 10074 -5421 10107 -5512 10134
--5605 10157 -5683 10179 -5753 10202 -5822 10222 -5878 10239 -5922 10251
--5960 10263 -5992 10275 -6034 10286 -6058 10298 -6079 10308 -6090 10316
--6102 10324 -6107 10334 -6120 10341 -6136 10351 -6139 10360 -6138 10368
--6143 10377 -6148 10385 -6156 10394 -6161 10404 -6174 10412 -6183 10421
--6196 10431 -6207 10440 -6227 10448 -6244 10458 -6269 10466 -6293 10476
--6321 10484 -6353 10493 -6380 10502 -6413 10510 -6450 10517 -6492 10526
--6536 10533 -6575 10541 -6618 10548 -6666 10555 -6710 10563 -6759 10569
--6809 10576 -6858 10583
-146: 12480370 -5171186 -9230 9815 -9250 9825 -9280 9835 -9310 9843 -9340 9852
--9370 9860 -9410 9870 -9440 9877 -9480 9885 -9520 9894 -9560 9903 -9600 9908
--9650 9912 -9680 9920 -9720 9924 -9760 9928 -9810 9931 -9840 9935 -9880 9937
--9920 9938 -9960 9936 -9990 9935 -10030 9933 -10070 9931 -10100 9931 -10120 9929
--10160 9925 -10190 9923 -10210 9920 -10240 9916 -10270 9917 -10310 9917
--10320 9916 -10360 9915 -10380 9914 -10410 9916 -10460 9922 -10490 9927
--10530 9936 -10570 9940 -10620 9952 -10660 9964 -10710 9974 -10760 9991
--10830 10004 -10890 10022 -10950 10043 -11020 10060 -11090 10080 -11140 10097
--11230 10118 -11300 10140 -11380 10164 -11460 10186 -11530 10201 -11590 10223
--11660 10241 -11720 10260 -11800 10277 -11870 10293 -11920 10307 -11960 10318
--12010 10325 -12050 10334 -12090 10344 -12120 10346 -12140 10351 -12160 10353
--12170 10351 -12170 10348 -12160 10342 -12160 10341 -12160 10335 -12130 10335
--12120 10329 -12100 10316 -12060 10308 -12030 10304 -12020 10302 -12000 10299
--11960 10300 -11940 10300 -11930 10301 -11900 10304 -11900 10312 -11910 10325
--11910 10336 -11910 10354 -11950 10373 -11960 10396 -12010 10421 -12050 10451
--12110 10483 -12190 10514 -12250 10558 -12350 10598 -12430 10637 -12520 10676
--12630 10722 -12740 10770 -12870 10822 -12990 10870 -13110 10912 -13220 10953
--13330 10999 -13470 11043 -13610 11083 -13730 11119 -13830 11153 -13920 11176
--14010 11201 -14110 11222 -14190 11240 -14250 11251 -14300 11254 -14340 11250
--14360 11241 -14370 11226 -14370 11203 -14340 11176 -14320 11148 -14270 11112
--14210 11063 -14120 11011 -14020 10953 -13920 10894 -13810 10834 -13700 10774
--13560 10702 -13410 10624 -13260 10546 -13100 10469 -12950 10400 -12830 10335
--12670 10259 -12510 10185 -12350 10113 -12220 10048 -12110 9994 -12010 9947
--11910 9901 -11820 9857 -11740 9821 -11690 9794 -11670 9782 -11680 9779
--11700 9785 -11740 9796 -11810 9819 -11900 9856 -12020 9898 -12180 9954
--12350 10023 -12560 10106 -12790 10195 -13060 10296 -13330 10398 -13630 10512
--13960 10640 -14340 10781 -14720 10931 -15130 11080 -15530 11227 -15950 11377
--16390 11542 -16880 11716 -17360 11893 -17850 12063 -18330 12220 -18790 12376
--19270 12540 -19780 12706 -20290 12868 -20770 13013 -21230 13140 -21680 13256
--22110 13376 -22550 13484 -22980 13571 -23370 13647 -23750 13702 -24100 13745
--24430 13766 -24700 13770 -24990 13755 -25250 13708 -25490 13641 -25630 13549
--25713 13452 -25858 13324 -26017 13180 -26065 12981 -26102 12740 -26178 12543
--26098 12296 -25765 11927 -25476 11644 -25590 11502 -25892 11197 -25747 10589
--24923 9995 -23911 9772 -23430 9792 -23752 9593 -24526 8980 -25044 8156
--24570 7437 -22833 7072 -20260 7230 -17856 7841 -16483 8487 -16246 8681
--16502 8326 -16343 7800 -15065 7554 -12372 7775 -8591 8322 -4681 8877
--2119 9075 -2541 8605 -7340 7445 -16448 6219 -26027 6160 -28158 6510 -22979 7221
--13412 7588 -24186 5570 -16862 7477 28608 11833 31877 11876 28278 10986
-22850 10369 15926 9008 5692 7999 -7379 5687 -21273 4446 1395 6950 -6354 6304
--18288 4070 -30098 2597 -32022 3867 -28046 5194 -21733 6114 -9857 8552
-7407 12547 18847 13156 26432 6487 24866 -3220 5521 -5542 -15532 1636 -34066 10311
--41798 14123 -37146 14619 -21986 12684 -3504 9782 10927 7194 17688 5298
-16197 4121 7864 3842 -5367 5038 -22064 8159 -23086 5100 -13907 1338 -18327 10856
--18025 9922 -12931 6641 -8157 7378 -5231 7816 -4365 7428 -4031 6729 -3286 6318
--3388 6636 -5184 7261 -8927 7639 -11344 7969 -12013 7963 -10721 7302 -6951 5697
--1075 3158 -1196 3835 -16211 1616 -17065 -2204 -8094 6297 -6989 -6481
--8434 -13588 -13607 27289 -14228 28564 -14442 24200 -17502 13880 -6311 9093
-867 5787 4552 3913 416 8028 3064 7179 9090 5406 14168 5574 14083 6157 7959 7800
--6004 13592 -20100 14675 -29272 14258 -33272 13288 -34152 12348 -33600 11856
--31733 11778 -25416 10295 -11981 6762 6866 8798 7992 10112 -13382 11025
-158 11064 8921 10882 13171 10116 13340 8335 8392 5021 5083 5566 4078 5978
-3576 5683 2663 5345 978 5837 -1874 7460 -6439 9659 -9847 8176 -9658 9028
--8847 10898 -7867 11339 -6976 10822 -8234 9861 -10398 9027 -11330 8416
--10160 9146 -8693 10167 -7234 10652 -5772 10245 -6504 9707 -8496 9098
--7847 9152 -5684 10302 -5388 10006 -5122 9928 -3798 11346 2429 15561 12235 19719
-10716 18579 -19082 4831 -19517 5444 -10662 10986 -3108 15267 768 17261
-947 17999 -1569 18324 -2175 16567 -3278 7624 -1301 3334 796 1950 -1360 2727
--12200 6136 -4662 7835 -4539 14783 67 9198 2407 7390 4361 8800 4515 9805
-2729 10986 -1011 12770 -3042 12468 -3420 10516 -2677 7670 -1527 7332 -195 7923
-3101 8850 251 8079 -4640 7152 -9144 6798 -3144 6476 -10616 10521 -10966 9811
--8235 8084 -2612 6504 -1538 10545 3797 10955 5780 10806 3795 7491 -3556 8898
--1350 9710 2950 10583 -449 9116 -3418 11218 -956 10295 -10687 11648 -11195 12534
--8072 12694 -16578 1421 -12897 4379 -7460 8922 -2555 12334 -30 13542 -16826 5900
--11403 6560 -2262 8762 -4273 8456 -42886 -2640 -38627 -1438 -12898 4623
--2714 8109 -4955 9095 -13381 8065 -14635 7505 5844 9386 3847 7721 3849 6950
-4755 7442 4359 8216 4198 7565 3675 6706 7783 1997 5579 3765 2187 7798 -2369 13502
--7926 23433 -16487 26803 -25265 23170 -33095 6936 -71945 -50405 18638 67134
--8344 20092 -10860 14695 -8064 14938 -4506 15414 -1821 15218 -524 14356
--523 13098 -1433 11729 -2849 10461 -4422 9406 -5903 8585 -7147 7979 -8106 7543
--8775 7233 -9174 7010 -9368 6847 -9384 6723 -9271 6629 -9072 6554 -8814 6499
--8526 6462 -8210 6444 -7879 6448 -7542 6471 -7217 6514 -6889 6575 -6574 6653
--6259 6746 -5958 6853 -5684 6976 -5425 7110 -5188 7254 -4980 7404 -4796 7559
--4632 7717 -4501 7877 -4388 8039 -4292 8201 -4220 8359 -4178 8512 -4157 8657
--4169 8795 -4207 8925 -4262 9049 -4346 9171 -4439 9290 -4472 9399 -4554 9491
--4646 9576 -4738 9656 -4834 9730 -4943 9795 -5062 9851 -5174 9901 -5280 9950
--5376 9995 -5463 10038 -5555 10071 -5638 10098 -5719 10124 -5791 10146
--5858 10170 -5919 10191 -5968 10209 -6013 10221 -6051 10233 -6083 10246
--6117 10258 -6150 10269 -6165 10280 -6180 10287 -6191 10296 -6200 10305
--6213 10313 -6227 10321 -6234 10330 -6238 10337 -6241 10346 -6251 10354
--6260 10361 -6265 10370 -6279 10378 -6289 10387 -6303 10394 -6314 10403
--6335 10411 -6354 10419 -6380 10427 -6399 10435 -6426 10444 -6461 10451
--6486 10458 -6514 10467 -6553 10473 -6594 10481 -6634 10489 -6672 10495
--6713 10502 -6756 10509 -6800 10516 -6843 10522 -6893 10529 -6940 10535
-147: 12511760 -5162305 -9260 9819 -9270 9826 -9320 9835 -9340 9843 -9370 9852
--9410 9862 -9430 9873 -9460 9879 -9510 9888 -9550 9898 -9580 9905 -9630 9911
--9670 9917 -9700 9923 -9750 9930 -9780 9933 -9830 9937 -9870 9938 -9900 9942
--9940 9943 -9970 9945 -10010 9942 -10060 9941 -10080 9941 -10110 9939
--10140 9935 -10180 9935 -10200 9934 -10230 9930 -10250 9928 -10290 9925
--10320 9927 -10340 9928 -10370 9925 -10390 9928 -10430 9927 -10460 9931
--10510 9939 -10540 9946 -10580 9951 -10620 9963 -10670 9974 -10720 9985
--10770 10000 -10840 10012 -10890 10033 -10950 10051 -11020 10069 -11090 10088
--11150 10103 -11230 10125 -11300 10147 -11380 10172 -11450 10188 -11530 10205
--11590 10227 -11650 10243 -11720 10263 -11800 10279 -11860 10293 -11900 10307
--11960 10317 -12000 10326 -12040 10334 -12070 10341 -12110 10346 -12140 10349
--12150 10350 -12150 10347 -12160 10345 -12160 10340 -12150 10335 -12130 10334
--12130 10330 -12110 10324 -12090 10313 -12050 10304 -12030 10300 -12010 10298
--12000 10296 -11960 10296 -11940 10294 -11920 10296 -11900 10299 -11900 10308
--11900 10319 -11910 10329 -11910 10348 -11940 10367 -11970 10389 -12000 10413
--12050 10443 -12100 10472 -12170 10506 -12260 10546 -12330 10587 -12410 10624
--12510 10662 -12610 10708 -12720 10754 -12840 10805 -12970 10851 -13080 10894
--13190 10934 -13300 10977 -13430 11019 -13570 11060 -13680 11097 -13770 11125
--13860 11151 -13970 11173 -14040 11195 -14130 11213 -14190 11222 -14240 11226
--14270 11221 -14290 11213 -14300 11198 -14300 11175 -14270 11150 -14250 11120
--14200 11086 -14140 11040 -14050 10988 -13960 10932 -13850 10873 -13750 10818
--13640 10758 -13510 10689 -13360 10614 -13210 10537 -13060 10463 -12920 10398
--12790 10335 -12640 10263 -12490 10192 -12330 10121 -12210 10060 -12090 10010
--12010 9965 -11910 9922 -11820 9882 -11760 9849 -11700 9823 -11680 9814
--11700 9814 -11720 9821 -11770 9834 -11830 9861 -11920 9897 -12050 9942
--12190 9998 -12380 10068 -12570 10151 -12810 10241 -13070 10341 -13340 10443
--13630 10556 -13960 10683 -14320 10824 -14700 10972 -15100 11119 -15500 11265
--15900 11414 -16330 11576 -16800 11747 -17280 11922 -17750 12089 -18210 12246
--18670 12398 -19130 12560 -19630 12724 -20120 12883 -20590 13028 -21030 13151
--21460 13265 -21890 13387 -22320 13493 -22710 13580 -23090 13650 -23470 13707
--23800 13750 -24100 13774 -24390 13777 -24660 13759 -24920 13716 -25110 13650
--25230 13565 -25340 13465 -25529 13344 -25677 13197 -25702 12984 -25745 12770
--25764 12571 -25572 12268 -25261 11929 -25222 11753 -25540 11566 -25682 11075
--25160 10408 -24195 10013 -23571 9992 -23813 9894 -24689 9312 -25373 8390
--25085 7587 -23484 7231 -20944 7405 -18367 8003 -16737 8682 -16494 8964
--17198 8586 -17864 7784 -17517 7116 -15620 7020 -12123 7555 -7624 8463
--3197 9345 -323 9733 -823 9137 -6697 7281 -19025 4954 -32559 5694 -31905 6534
--22331 8296 5365 10327 -36598 2754 -44455 5581 60702 15334 37503 12977
-28789 11058 22661 11063 17391 8823 7562 8977 -6390 4991 -49440 1352 20304 8773
--5721 7299 -20374 3667 -39160 1008 -35916 4443 -26556 5869 -22295 4490
--11894 5972 10469 12796 16732 15727 26157 7912 31947 -5192 3463 -9255
--15597 2969 -31449 13317 -35151 14779 -31012 14137 -19484 12251 -4031 9566
-8275 7666 14853 6630 15259 6073 10203 6036 -187 7314 -24192 14517 -22508 9053
--18861 5204 -21537 4221 -20919 3673 -15520 3479 -7637 6413 -3593 7399
--2400 7060 -2462 6499 -2838 6370 -3896 6794 -6207 7422 -9704 7943 -12857 8367
--14832 8562 -15133 8291 -12778 7373 -3838 4520 185 5561 -16042 4716 -8016 5193
--10306 2856 -8472 -7873 -10560 -10943 -12491 13965 -13292 21959 -14322 20424
--14695 13630 -8675 8813 -3603 5909 -1726 5187 -3954 7731 -1503 7907 7220 6080
-11171 5868 9544 6520 2635 7983 -8468 10868 -17961 11895 -22466 12067 -23650 11204
--23555 10112 -23418 9811 -23672 10920 -18431 10208 -8658 8580 1212 9561
-5439 11294 -4759 12513 -5484 11240 2552 11005 9535 10329 12643 8677 11346 6512
-7084 7265 5483 6635 4349 6047 3084 6366 1484 8300 -668 11322 -4035 12746
--9001 7479 -7482 8840 -6667 10008 -5255 10232 -4922 10414 -7191 9923 -11538 8606
--14354 6953 -11583 8314 -9182 9739 -7233 10557 -4582 9644 -5973 9457 -9433 9197
--10184 8805 -8705 9115 -7806 8638 -7810 7527 -8903 7788 -2551 13756 11602 19409
-6602 16356 -12299 7390 -15931 6666 -6828 13139 -918 16650 1543 17790 1371 17865
--295 17321 -1552 14915 -2543 8811 -2309 3662 -1799 2227 -3479 3271 -7783 6394
--6538 10348 -6414 15632 1921 6007 3856 6166 4674 7970 3894 9771 1376 11617
--1817 13314 -3567 13620 -3882 11958 -2741 7632 -1882 6602 -1275 7136 -760 7869
--3479 7817 -8167 7494 -10850 7477 2444 7527 -2890 9935 -11208 8728 -12378 7686
--7398 4043 3828 11256 8955 9960 11182 10167 5727 8442 -7560 9283 -1319 10623
-3829 10191 -1071 10235 -6533 10745 -8578 9907 -14250 9861 -15766 9330
--15398 7482 -17832 2671 -13203 6543 -9137 10419 -7749 12101 -10545 11061
--20244 6333 -16525 6002 -5867 7899 -11316 6716 -37107 35 -40315 -925 -2178 6351
-5172 8455 2246 8896 -3917 8569 -2799 8702 8160 9996 61 8356 2242 7368 5073 6766
-6179 6173 7530 3508 6886 2672 6408 2239 4823 5099 2588 10434 -3376 19061
--14371 31418 -23245 36120 -28578 32141 -29139 20176 -11842 8794 -41565 6823
--23341 7147 -15661 6843 -7865 9823 -1153 12915 3158 14572 4901 14711 4631 13834
-3068 12497 875 11104 -1455 9878 -3603 8904 -5409 8180 -6816 7664 -7831 7307
--8500 7063 -8898 6894 -9063 6776 -9079 6690 -8982 6628 -8807 6585 -8587 6559
--8331 6551 -8053 6562 -7768 6590 -7484 6635 -7201 6696 -6917 6772 -6635 6862
--6371 6964 -6111 7081 -5869 7206 -5652 7342 -5450 7483 -5263 7629 -5109 7777
--4970 7927 -4850 8079 -4750 8231 -4667 8380 -4607 8525 -4578 8663 -4571 8793
--4597 8916 -4631 9036 -4689 9153 -4760 9267 -4788 9375 -4856 9464 -4926 9545
--4997 9624 -5072 9696 -5167 9760 -5269 9816 -5362 9866 -5456 9914 -5536 9961
--5613 10003 -5696 10036 -5772 10066 -5839 10090 -5906 10115 -5967 10139
--6019 10160 -6064 10178 -6110 10192 -6149 10204 -6175 10217 -6204 10229
--6239 10242 -6256 10251 -6270 10260 -6280 10267 -6292 10276 -6307 10285
--6319 10292 -6329 10301 -6332 10307 -6341 10316 -6349 10322 -6357 10330
--6365 10337 -6382 10346 -6395 10352 -6406 10360 -6417 10367 -6439 10375
--6458 10382 -6483 10390 -6503 10396 -6528 10404 -6560 10411 -6585 10419
--6616 10425 -6652 10432 -6689 10438 -6728 10446 -6764 10452 -6803 10458
--6843 10465 -6883 10472 -6931 10477 -6976 10484 -7019 10491
-148: 12543170 -5153421 -9280 9819 -9320 9827 -9340 9835 -9360 9843 -9410 9855
--9430 9865 -9460 9872 -9490 9881 -9540 9889 -9570 9900 -9610 9908 -9650 9915
--9690 9921 -9720 9926 -9770 9932 -9810 9938 -9850 9942 -9880 9941 -9930 9947
--9960 9949 -9990 9950 -10030 9949 -10070 9948 -10100 9948 -10120 9946
--10160 9947 -10190 9944 -10210 9942 -10240 9938 -10270 9936 -10300 9935
--10330 9937 -10350 9937 -10390 9936 -10400 9937 -10440 9939 -10470 9941
--10520 9950 -10550 9954 -10580 9963 -10630 9972 -10680 9984 -10720 9995
--10780 10006 -10840 10023 -10900 10042 -10960 10058 -11020 10078 -11090 10094
--11150 10110 -11220 10131 -11300 10153 -11380 10177 -11450 10193 -11520 10210
--11580 10229 -11650 10245 -11710 10265 -11790 10280 -11850 10294 -11890 10305
--11940 10318 -11990 10325 -12030 10333 -12070 10340 -12090 10343 -12120 10348
--12140 10346 -12150 10346 -12140 10342 -12150 10337 -12130 10331 -12130 10331
--12120 10326 -12110 10319 -12070 10310 -12050 10302 -12020 10296 -12000 10295
--11990 10294 -11960 10289 -11930 10290 -11920 10290 -11900 10295 -11900 10303
--11900 10315 -11900 10325 -11920 10342 -11930 10362 -11970 10381 -11990 10406
--12040 10432 -12100 10463 -12170 10498 -12240 10537 -12320 10576 -12400 10610
--12490 10650 -12590 10693 -12710 10740 -12820 10788 -12940 10834 -13050 10875
--13160 10912 -13270 10957 -13390 10997 -13530 11037 -13630 11073 -13720 11100
--13810 11125 -13900 11147 -14000 11168 -14070 11186 -14120 11196 -14180 11193
--14200 11195 -14230 11185 -14230 11170 -14230 11148 -14210 11123 -14170 11094
--14140 11058 -14070 11017 -13990 10966 -13890 10910 -13790 10853 -13690 10800
--13590 10743 -13460 10676 -13310 10603 -13160 10529 -13020 10457 -12880 10395
--12760 10334 -12620 10267 -12460 10197 -12320 10131 -12190 10072 -12090 10025
--12000 9982 -11910 9943 -11830 9906 -11760 9873 -11710 9854 -11710 9845
--11710 9847 -11740 9857 -11790 9873 -11850 9901 -11950 9937 -12060 9984
--12220 10043 -12390 10112 -12600 10193 -12820 10286 -13070 10387 -13350 10488
--13630 10599 -13950 10727 -14300 10867 -14680 11012 -15070 11161 -15450 11303
--15840 11452 -16270 11611 -16730 11781 -17190 11952 -17650 12116 -18090 12273
--18540 12423 -19000 12584 -19470 12744 -19940 12903 -20400 13045 -20840 13167
--21240 13279 -21660 13401 -22070 13506 -22460 13594 -22820 13663 -23180 13721
--23490 13762 -23780 13789 -24060 13795 -24340 13777 -24570 13737 -24730 13669
--24830 13594 -25000 13494 -25220 13380 -25310 13223 -25305 13012 -25332 12823
--25279 12598 -25052 12269 -24897 12010 -25102 11871 -25435 11551 -25286 10932
--24510 10361 -23726 10196 -23704 10183 -24545 9760 -25464 8818 -25464 7862
--24055 7429 -21536 7636 -18887 8264 -17143 8915 -16949 9163 -18091 8721
--19570 7705 -20191 6651 -19130 6143 -16263 6437 -11961 7400 -7020 8700
--2492 9961 445 10721 264 10330 -5631 7875 -20891 3029 -34117 5860 -25083 6768
--19673 9750 48522 18025 -55315 -3945 -103469 160 117022 20797 19760 12184
-17985 9526 14247 11689 14115 7430 8015 11272 16193 6023 -100548 -3319
-58705 12923 -11240 8953 -11837 4008 -48930 -1622 -36993 6174 -17417 8123
--20666 2035 -16360 370 14600 8808 4970 9408 15675 4528 43257 6796 -3253 -6863
--18364 13539 -23174 13547 -25376 12766 -24124 12309 -16486 11047 -2638 8266
-7083 7362 12436 7822 12913 8574 8096 9984 -2964 13009 -20300 17698 -17268 10074
--18864 8079 -22626 -1883 -22021 -1850 -17179 -143 -5766 6098 -1785 7246
--908 6920 -1522 6411 -2634 6331 -4296 6641 -6938 7064 -10476 7466 -13999 7868
--16558 8076 -17438 7785 -15654 6947 -8875 5816 7868 6939 -31047 5684 -7187 4916
--7227 7388 -6686 3566 -12438 -7345 -10793 5161 -11986 13341 -14737 14477
--13726 11263 -9916 8171 -6994 6323 -6347 6104 -7717 7763 -6574 8711 6286 6406
-8329 6441 5225 6741 -2027 7457 -11443 8525 -17622 9357 -16588 10331 -14022 9183
--12553 7795 -12357 7484 -16130 10399 -11842 9890 -4240 8345 2357 7936
--4377 12886 -7684 12847 -7257 11675 -513 11269 7807 10790 12637 9584 12818 7968
-9800 7331 7143 6375 4885 5918 2906 6908 1246 9886 202 14505 -690 18001
--7571 6979 -6589 8173 -5460 9517 -2979 9375 -2600 10233 -6312 9753 -14149 7261
--16214 6494 -11306 8330 -8529 9613 -5936 10313 -3697 10050 -5239 9906
--11717 9947 -12616 8703 -10933 8882 -9121 9263 -7986 9309 -10184 6387
--4643 10557 3302 14285 477 12674 -9701 7811 -13455 6930 -720 16254 2049 17786
-2248 17317 1115 16376 -667 15263 -2228 13279 -3278 9738 -3843 5178 -3830 3689
--4203 4325 -4807 6319 -3527 8317 -1781 9141 807 10135 3552 8381 4810 8563
-3675 9929 350 11856 -2979 13588 -4175 14500 -4414 13858 -2478 6979 -2018 6229
--2377 6980 -2843 7676 -4905 7893 -7781 7768 -7678 7876 -562 7841 -1414 8083
--6276 9264 -4569 8355 2311 7015 -2386 8349 5945 8527 11535 8694 9598 8230
--9989 9478 -6784 10230 -2465 10151 -3225 9946 -12018 10178 -15375 9423
--18823 8100 -20457 5860 -20747 2907 -19780 1681 -11646 10066 -9932 12600
--12670 11617 -18940 8734 -26369 5090 -22747 4654 -1994 8128 -6762 7799
--23608 4455 -25745 3521 -4254 6544 5331 8140 5116 8709 -1474 8886 -1315 9196
-2270 10341 1167 9102 3702 7520 6873 5923 8749 4292 11861 -1127 9571 -679
-2858 3462 1716 7893 3207 13303 -1958 22623 -20985 39998 -29417 44830 -30700 39709
--29184 26312 -30249 8668 -30611 758 -31093 -5149 -20257 -1631 -6643 6254
-3875 12715 9703 16038 11475 16685 10478 15705 7918 14020 4727 12237 1514 10668
--1377 9426 -3786 8514 -5655 7872 -7010 7440 -7944 7153 -8530 6965 -8851 6842
--8977 6760 -8964 6706 -8870 6672 -8698 6656 -8494 6656 -8266 6673 -8021 6704
--7778 6753 -7525 6813 -7275 6887 -7017 6975 -6778 7073 -6535 7183 -6313 7301
--6108 7430 -5907 7562 -5729 7699 -5573 7838 -5430 7979 -5300 8122 -5191 8264
--5110 8406 -5032 8542 -4990 8672 -4974 8796 -4977 8913 -4996 9026 -5031 9139
--5077 9250 -5109 9354 -5157 9440 -5207 9519 -5257 9595 -5315 9665 -5391 9728
--5478 9783 -5556 9835 -5637 9881 -5702 9928 -5768 9970 -5839 10005 -5906 10033
--5965 10059 -6026 10084 -6082 10109 -6128 10130 -6165 10149 -6209 10162
--6242 10176 -6271 10189 -6301 10201 -6325 10214 -6347 10223 -6358 10232
--6371 10240 -6386 10248 -6397 10257 -6412 10264 -6421 10272 -6428 10278
--6435 10286 -6442 10292 -6455 10299 -6466 10306 -6481 10314 -6492 10319
--6506 10327 -6519 10334 -6540 10339 -6558 10347 -6580 10354 -6602 10360
--6625 10366 -6655 10373 -6681 10380 -6712 10386 -6747 10392 -6781 10398
--6818 10405 -6852 10411 -6893 10417 -6925 10423 -6967 10430 -7009 10435
--7054 10442 -7095 10447
-149: 12574600 -5144537 -9320 9819 -9340 9827 -9370 9835 -9390 9845 -9430 9855
--9460 9867 -9480 9872 -9520 9884 -9560 9890 -9600 9901 -9630 9909 -9680 9918
--9700 9924 -9740 9930 -9790 9935 -9840 9940 -9870 9944 -9900 9947 -9950 9952
--9970 9954 -10010 9955 -10050 9954 -10080 9955 -10120 9955 -10130 9954
--10180 9952 -10200 9953 -10230 9950 -10250 9946 -10280 9945 -10310 9943
--10340 9944 -10360 9946 -10390 9945 -10420 9947 -10450 9949 -10480 9953
--10520 9958 -10560 9965 -10590 9972 -10630 9981 -10690 9992 -10730 10004
--10780 10015 -10840 10031 -10900 10049 -10970 10065 -11020 10085 -11090 10100
--11150 10117 -11220 10137 -11290 10157 -11380 10179 -11440 10198 -11510 10215
--11570 10233 -11640 10246 -11710 10265 -11770 10283 -11840 10293 -11880 10306
--11940 10315 -11980 10325 -12020 10333 -12040 10338 -12080 10340 -12100 10345
--12130 10347 -12130 10344 -12140 10337 -12130 10334 -12120 10330 -12120 10326
--12110 10323 -12100 10316 -12060 10307 -12040 10300 -12010 10292 -12000 10291
--11980 10289 -11950 10286 -11940 10286 -11910 10285 -11890 10291 -11900 10298
--11900 10308 -11900 10322 -11920 10338 -11930 10356 -11960 10376 -11990 10399
--12040 10423 -12090 10455 -12160 10490 -12230 10527 -12310 10564 -12390 10599
--12470 10638 -12580 10680 -12680 10724 -12810 10772 -12910 10818 -13020 10855
--13120 10893 -13240 10935 -13360 10976 -13480 11015 -13590 11049 -13670 11075
--13770 11100 -13850 11122 -13930 11143 -14010 11156 -14070 11167 -14110 11168
--14140 11167 -14160 11156 -14170 11142 -14170 11121 -14140 11096 -14110 11066
--14070 11034 -14000 10993 -13920 10943 -13840 10889 -13730 10834 -13630 10782
--13530 10726 -13420 10662 -13260 10592 -13120 10521 -12970 10451 -12850 10393
--12730 10335 -12590 10269 -12450 10201 -12300 10139 -12180 10084 -12080 10040
--12000 9999 -11910 9963 -11830 9926 -11770 9900 -11730 9882 -11720 9875
--11720 9879 -11760 9891 -11810 9911 -11870 9939 -11970 9977 -12090 10027
--12230 10085 -12410 10155 -12610 10239 -12830 10330 -13080 10429 -13350 10533
--13620 10644 -13940 10770 -14290 10909 -14650 11054 -15030 11200 -15400 11341
--15790 11489 -16200 11648 -16650 11815 -17100 11984 -17540 12147 -17980 12301
--18400 12450 -18850 12609 -19320 12769 -19770 12924 -20210 13064 -20630 13187
--21030 13298 -21430 13421 -21820 13522 -22190 13609 -22550 13683 -22880 13744
--23180 13785 -23470 13812 -23750 13820 -24010 13806 -24210 13764 -24320 13706
--24470 13634 -24690 13538 -24880 13427 -24900 13259 -24880 13068 -24873 12893
--24791 12627 -24628 12320 -24677 12134 -25024 11955 -25214 11495 -24766 10858
--23964 10472 -23581 10432 -24138 10230 -25193 9442 -25651 8358 -24646 7684
--22251 7804 -19471 8482 -17574 9169 -17449 9351 -19093 8746 -21553 7460
--23305 6025 -23122 5138 -20630 5213 -16426 6130 -11460 7511 -6680 9021
--2993 10507 -1081 11702 -1881 12037 -9024 10190 -40450 1322 -8109 6785
-13915 7422 18672 11571 40293 30662 -66840 -11328 -46897 -5207 28280 16000
--3536 10938 -1215 8848 -2831 8813 -2286 7935 -9235 8675 46295 11371 -5682 6698
--57432 4726 8754 11199 30893 7177 -46373 -685 -41512 5789 970 12336 -11880 2012
--6483 1017 1898 2468 -21906 170 -23064 -3554 41975 17258 10495 10594 -10883 17984
--10069 8283 -13823 8298 -16845 9486 -13766 9591 -750 6370 5564 6649 9726 8823
-10402 10361 6973 11995 -798 14006 -11958 14954 -19008 11045 -20296 7406
--21816 744 -19769 -623 -14071 991 -5520 5027 -1054 6717 -22 6795 -1124 6181
--2755 5891 -4758 5912 -7532 6020 -11045 6196 -14559 6429 -17068 6445 -17792 5930
--16041 5063 -11202 4412 -5626 4650 -21595 4513 -13070 5906 -10190 9546
--7534 7240 -12661 4743 -7288 6172 -11290 9878 -17847 10576 -14102 8735
--10181 7277 -8393 6441 -7871 6142 -7736 7231 -6608 8533 1124 7986 3595 7830
-1043 7071 -5639 7191 -14611 7042 -19248 7434 -12306 9589 -5949 7645 -4393 6545
--5565 6876 -8243 8879 -6573 9187 -3147 8626 -1588 8732 -6029 10339 -9208 10770
--8716 10686 -2204 10929 8539 11162 14401 10175 14740 8391 11709 6786 8016 5572
-4583 5387 1697 6485 -763 8859 -2049 12613 -1068 17105 -3976 12347 -3924 11432
--4360 10038 -1683 9983 -387 10865 -7347 9354 -13462 7768 -14824 7471 -11795 8607
--8673 9741 -5498 10460 -2904 10486 -3815 10296 -16531 11008 -12439 8279
--11897 8657 -10298 9298 -8955 9236 -8757 7814 -5283 9343 -1367 11220 -2295 10977
--6055 9286 -7081 9980 -1066 14749 1103 15886 889 15043 -537 13742 -2425 12609
--4020 11601 -4893 10433 -5637 7160 -5599 5715 -4648 5870 -2650 7193 -306 8524
-1755 9285 1443 8492 4262 8042 6180 8322 4801 9541 -105 11490 -4359 12790
--4608 13253 -4611 12889 -3023 8971 -2281 7626 -3540 8015 -3606 8257 -4677 8418
--6872 8045 -6821 8574 -3337 8765 -2522 8022 -3722 8591 -2186 8256 1252 7599
-1039 7749 5367 7754 8239 7807 5194 7889 -6083 8733 -7722 9213 -7019 9300
--9008 9504 -15243 10346 -19270 9672 -21888 7751 -22844 4582 -22599 566
--21138 -1142 -7687 14416 -9208 13805 -14358 10227 -21773 6213 -29543 2783
--29288 2206 10450 9427 545 10005 -15804 8355 -19753 7252 -6667 7353 2349 8141
-4430 8712 -5913 9267 -6114 9818 -2632 10585 1633 9531 5519 7403 8799 4595
-11364 1249 14575 -3274 11569 -2385 -5682 7249 -5043 12818 4121 16967 4178 23010
--27030 47773 -32534 49789 -28618 43559 -21571 28637 -34685 1439 -38636 -4735
--47559 -24296 -24726 -9298 -2189 6815 12017 16650 18284 20572 19050 20651
-16639 18786 12717 16254 8355 13783 4197 11703 558 10100 -2417 8944 -4710 8146
--6390 7617 -7565 7275 -8314 7060 -8764 6924 -8996 6841 -9047 6791 -9007 6764
--8880 6755 -8717 6762 -8525 6783 -8311 6819 -8097 6867 -7865 6929 -7643 7002
--7413 7086 -7187 7180 -6958 7283 -6755 7397 -6550 7518 -6365 7641 -6185 7771
--6026 7900 -5883 8033 -5744 8168 -5631 8301 -5537 8434 -5458 8563 -5395 8686
--5364 8803 -5354 8914 -5351 9022 -5369 9129 -5400 9237 -5424 9335 -5457 9420
--5488 9496 -5518 9569 -5557 9638 -5621 9699 -5684 9755 -5754 9804 -5818 9852
--5873 9898 -5927 9939 -5987 9973 -6045 10004 -6095 10029 -6151 10055 -6198 10079
--6240 10102 -6275 10119 -6310 10135 -6338 10148 -6367 10161 -6397 10174
--6415 10186 -6438 10197 -6449 10205 -6463 10213 -6476 10221 -6488 10228
--6504 10237 -6513 10244 -6520 10250 -6528 10256 -6537 10264 -6550 10269
--6563 10276 -6576 10282 -6587 10289 -6599 10294 -6618 10301 -6637 10307
--6651 10313 -6673 10319 -6696 10324 -6723 10331 -6746 10337 -6771 10343
--6806 10349 -6838 10354 -6867 10361 -6902 10366 -6937 10372 -6973 10378
--7009 10383 -7047 10390 -7087 10395 -7126 10402 -7164 10407
-150: 12606060 -5135655 -9350 9820 -9370 9826 -9400 9836 -9420 9847 -9460 9855
--9480 9868 -9510 9873 -9550 9883 -9580 9891 -9620 9902 -9650 9913 -9700 9920
--9730 9926 -9760 9931 -9810 9939 -9850 9942 -9890 9948 -9930 9951 -9950 9956
--10000 9957 -10020 9960 -10070 9961 -10100 9961 -10130 9958 -10150 9960
--10180 9958 -10220 9959 -10240 9960 -10260 9953 -10300 9951 -10310 9952
--10350 9953 -10370 9954 -10400 9954 -10420 9955 -10460 9957 -10490 9961
--10530 9968 -10570 9975 -10590 9980 -10640 9988 -10680 10000 -10740 10011
--10780 10025 -10840 10038 -10900 10054 -10970 10072 -11020 10092 -11090 10106
--11150 10122 -11220 10142 -11290 10161 -11360 10183 -11440 10201 -11500 10219
--11560 10234 -11630 10249 -11700 10268 -11760 10282 -11830 10293 -11870 10307
--11920 10315 -11970 10325 -12000 10330 -12030 10336 -12060 10338 -12100 10343
--12110 10346 -12120 10340 -12120 10336 -12110 10330 -12110 10325 -12110 10325
--12100 10319 -12080 10314 -12060 10304 -12020 10296 -12000 10290 -12000 10287
--11980 10285 -11950 10283 -11920 10283 -11920 10283 -11880 10287 -11900 10293
--11880 10303 -11910 10317 -11910 10333 -11930 10351 -11950 10370 -11990 10392
--12040 10417 -12090 10448 -12150 10481 -12220 10518 -12300 10552 -12370 10588
--12470 10625 -12550 10666 -12670 10712 -12780 10759 -12890 10798 -12990 10838
--13090 10874 -13200 10914 -13330 10954 -13440 10994 -13550 11026 -13630 11051
--13710 11073 -13800 11100 -13880 11116 -13960 11127 -14010 11139 -14040 11142
--14090 11138 -14090 11128 -14110 11114 -14100 11094 -14070 11068 -14050 11041
--14000 11009 -13940 10969 -13870 10920 -13770 10868 -13670 10815 -13580 10764
--13480 10711 -13360 10648 -13220 10580 -13080 10512 -12940 10446 -12810 10389
--12700 10333 -12570 10272 -12430 10206 -12290 10148 -12170 10094 -12070 10053
--11990 10017 -11920 9982 -11840 9947 -11770 9925 -11740 9909 -11730 9903
--11740 9912 -11780 9924 -11830 9946 -11890 9977 -11990 10018 -12100 10066
--12250 10126 -12420 10199 -12630 10281 -12840 10373 -13080 10473 -13340 10576
--13620 10687 -13920 10812 -14270 10951 -14620 11096 -14980 11240 -15360 11381
--15730 11525 -16130 11683 -16560 11851 -17010 12017 -17440 12179 -17850 12330
--18280 12479 -18700 12636 -19150 12794 -19600 12948 -20020 13087 -20420 13210
--20810 13323 -21200 13441 -21570 13543 -21930 13631 -22280 13710 -22590 13768
--22860 13813 -23160 13843 -23430 13853 -23670 13840 -23830 13804 -23940 13753
--24140 13683 -24380 13596 -24490 13481 -24460 13316 -24420 13151 -24410 12967
--24360 12677 -24328 12419 -24558 12268 -24910 12004 -24855 11459 -24218 10904
--23562 10691 -23646 10625 -24550 10139 -25431 9113 -25133 8146 -23193 7927
--20374 8511 -18100 9297 -17739 9551 -19705 8839 -23264 7205 -26720 5218
--28061 3770 -26100 3616 -21246 4777 -15323 6505 -9940 8098 -6041 9347
--4328 10600 -5010 11798 -7765 12214 -12613 10304 -23289 5683 -3321 7314
-16186 8754 18187 12298 7314 17035 -51228 -3435 -15646 3543 3904 9276 -7275 8636
--9041 8212 -4338 8223 -4591 8524 -2599 9523 22432 10710 3269 6778 -31994 3684
--7369 7368 1129 4315 -9646 8405 -18090 9644 -1177 11483 1428 7814 8618 8159
-12680 9793 -37905 -6822 -27100 -1961 13266 13620 2419 10664 -6471 13205
--6700 8415 -7877 7003 -8091 6962 -4683 6597 -6449 7157 794 6626 6042 9832
-7460 11056 5585 12160 1219 13000 -6066 11885 -21894 10782 -18717 7979
--19087 4032 -15559 2548 -9541 3360 -3278 5592 621 7160 1277 7213 -965 5719
--3256 4957 -5404 4705 -8047 4576 -11351 4479 -14653 4323 -16898 3875 -17506 2991
--16393 2138 -13988 1815 -12384 1544 -17218 1570 -14542 4179 -12650 11950
--8682 16522 -8239 12438 -7164 9263 -17061 10243 -26379 9361 -14465 7193
--9167 6903 -8650 6843 -8159 5723 -6586 6468 -6949 8630 -1827 9220 312 9327
--1467 7462 -6754 7774 -15251 6881 -17809 7395 -12975 8404 -751 5793 585 5551
--1261 6403 -3500 7897 -3124 8427 -2296 8413 -2855 8585 -6379 7895 -9782 8439
--10445 9108 -4376 10091 11758 11391 17529 10306 16486 8022 12271 5833
-7567 4713 3263 5162 -18 6181 -3474 7230 -6077 9006 -2131 16902 -3262 15057
--2397 14735 -5332 10743 -1524 10628 4784 12003 -9189 10143 -12238 8945
--12881 9025 -11601 9476 -9322 10228 -6519 10870 -4318 10983 -4896 10608
--10811 9980 -11807 8282 -13330 8972 -10964 9599 -8886 9607 -7474 8901
--4945 9047 -2766 10058 -2676 10817 -2715 10549 -3153 11604 -1716 13277
--1025 13386 -1559 12259 -3058 10822 -4980 9751 -6469 9687 -6730 11360
--7511 9397 -7601 7825 -5723 7437 -1347 8443 1439 9019 2758 8954 3238 8090
-6113 7585 9242 7732 8011 8698 357 10980 -4960 11423 -6441 11320 -6104 12562
--4020 10240 -1772 8579 -5264 9301 -3651 8898 -3582 9263 -5703 7877 -7083 9328
--5399 9665 -4037 8668 -3720 8499 -2733 8237 -696 7716 2952 7654 4687 7350
-5019 7250 2030 7349 -4878 8017 -7659 8228 -9455 8402 -12944 8995 -17988 11237
--21517 10890 -22991 9428 -21754 7205 -17321 4824 -10631 4504 -11006 10187
--10344 9362 -12474 6449 -15509 3509 -16654 1595 -11029 2380 5880 7479
--6251 10406 -20461 10439 -24900 9511 -12509 8399 -5334 8843 -2911 9215
--8501 9389 -10605 10089 -7093 11438 1972 10391 6159 7991 8069 4610 9483 755
-13400 -3669 14151 -3820 -20430 13744 -15549 20090 2376 26064 2774 31118
--17155 40792 -26517 42823 -22937 39272 -9043 26863 -15624 9540 -90039 -55015
--63990 -37371 -20088 -4938 9938 16601 24405 26211 28466 28128 26734 26097
-22244 22528 16767 18760 11257 15432 6268 12772 1998 10790 -1437 9387 -4089 8433
--6035 7809 -7395 7413 -8286 7169 -8832 7019 -9131 6934 -9236 6885 -9229 6862
--9142 6858 -9003 6870 -8837 6897 -8648 6934 -8445 6984 -8235 7044 -8029 7116
--7815 7197 -7603 7286 -7395 7386 -7188 7492 -6994 7606 -6812 7722 -6634 7843
--6472 7965 -6326 8089 -6181 8216 -6064 8341 -5961 8467 -5876 8588 -5797 8704
--5749 8814 -5721 8919 -5701 9022 -5703 9124 -5713 9227 -5739 9321 -5754 9403
--5765 9476 -5776 9547 -5802 9614 -5848 9674 -5898 9729 -5952 9777 -6000 9825
--6047 9869 -6093 9911 -6137 9945 -6184 9974 -6232 10001 -6277 10027 -6316 10051
--6354 10074 -6385 10092 -6415 10107 -6440 10121 -6466 10134 -6491 10147
--6510 10160 -6529 10170 -6541 10178 -6552 10186 -6569 10195 -6576 10202
--6593 10209 -6602 10217 -6612 10222 -6621 10229 -6631 10235 -6639 10240
--6654 10247 -6667 10253 -6678 10258 -6692 10264 -6711 10269 -6729 10275
--6743 10281 -6765 10286 -6786 10291 -6813 10297 -6836 10303 -6860 10308
--6891 10313 -6921 10319 -6952 10324 -6988 10330 -7018 10335 -7050 10341
--7085 10346 -7122 10352 -7158 10357 -7198 10363 -7234 10369
-151: 12637530 -5126772 -9370 9820 -9400 9826 -9430 9836 -9450 9847 -9480 9856
--9510 9867 -9530 9874 -9570 9885 -9610 9891 -9640 9902 -9680 9914 -9710 9921
--9760 9928 -9780 9933 -9830 9941 -9860 9946 -9910 9951 -9940 9954 -9970 9959
--10020 9961 -10040 9963 -10080 9967 -10110 9965 -10140 9964 -10170 9964
--10190 9965 -10220 9966 -10250 9963 -10280 9961 -10310 9959 -10330 9959
--10350 9960 -10380 9961 -10410 9961 -10430 9964 -10460 9964 -10500 9969
--10530 9977 -10570 9981 -10600 9987 -10640 9998 -10690 10009 -10740 10019
--10780 10030 -10840 10044 -10890 10061 -10970 10077 -11020 10097 -11080 10112
--11150 10125 -11210 10147 -11280 10167 -11360 10185 -11430 10204 -11500 10221
--11550 10237 -11620 10250 -11680 10268 -11750 10284 -11810 10296 -11860 10305
--11910 10315 -11940 10323 -11990 10329 -12030 10333 -12050 10336 -12080 10342
--12090 10342 -12100 10337 -12110 10334 -12100 10328 -12100 10324 -12090 10320
--12090 10317 -12060 10311 -12060 10300 -12020 10293 -11990 10288 -11980 10283
--11970 10283 -11940 10280 -11920 10281 -11910 10278 -11880 10283 -11890 10289
--11890 10301 -11900 10314 -11910 10326 -11920 10347 -11950 10364 -11990 10387
--12030 10411 -12080 10439 -12140 10473 -12220 10509 -12290 10543 -12360 10577
--12450 10613 -12540 10653 -12650 10698 -12760 10743 -12860 10783 -12960 10819
--13060 10856 -13170 10893 -13290 10933 -13410 10972 -13500 11004 -13590 11029
--13670 11050 -13750 11072 -13830 11089 -13900 11103 -13950 11112 -13990 11112
--14020 11111 -14030 11102 -14050 11086 -14030 11066 -14020 11042 -13980 11015
--13940 10985 -13880 10944 -13810 10899 -13710 10847 -13620 10795 -13530 10746
--13430 10695 -13310 10634 -13180 10568 -13040 10503 -12900 10440 -12790 10384
--12660 10332 -12550 10273 -12410 10212 -12270 10154 -12160 10104 -12060 10066
--11990 10032 -11920 10000 -11840 9971 -11790 9948 -11750 9934 -11740 9933
--11760 9942 -11790 9957 -11840 9980 -11910 10014 -12010 10056 -12120 10105
--12270 10167 -12430 10240 -12630 10323 -12850 10416 -13080 10515 -13340 10619
--13600 10729 -13910 10853 -14240 10992 -14590 11135 -14940 11281 -15300 11420
--15670 11562 -16060 11719 -16480 11885 -16910 12051 -17330 12211 -17730 12360
--18140 12509 -18550 12664 -18990 12820 -19420 12974 -19830 13112 -20220 13236
--20590 13348 -20960 13465 -21320 13569 -21670 13657 -22000 13738 -22290 13799
--22560 13847 -22850 13879 -23110 13892 -23320 13880 -23450 13854 -23590 13809
--23820 13742 -24040 13663 -24070 13548 -23980 13396 -23960 13251 -24000 13046
--24020 12761 -24130 12552 -24460 12397 -24673 12052 -24359 11495 -23652 11069
--23246 10949 -23702 10746 -24706 10010 -25161 8927 -24133 8234 -21677 8415
--19070 9157 -17978 9614 -19544 9065 -23690 7308 -29026 4718 -33134 2281
--33434 1252 -28627 2426 -20159 5287 -12086 7977 -6636 9405 -4152 9660
--4946 10224 -8688 11389 -13107 12483 -10775 11156 -11264 8703 -1321 8884
-8078 8257 10321 10808 2455 12013 -22492 4974 -19946 6363 -9249 3450 -6469 6255
--5031 7880 -2957 8532 -3726 9106 -4315 10120 2315 10534 4347 6331 -11387 4871
--6284 6463 -3172 6410 -2941 9442 -11781 9616 -6150 9856 2539 9485 4629 8405
-230 6798 -19788 828 -17219 2909 -708 10024 -1574 10441 -4746 10846 -5393 8492
--5883 6987 -5655 6541 -4319 6690 -5656 7488 98 6894 3500 8718 4017 10022
-1445 10931 -3786 11265 -10822 10434 -17949 9700 -8819 8809 -13253 6629
--9182 5426 -3344 5691 488 6872 3552 8566 3632 8508 -1045 4885 -4128 3771
--6144 3558 -8325 3407 -11262 2968 -14423 2056 -16376 794 -16908 -572 -16493 -1073
--15793 -113 -14589 -659 -13847 -2250 -9153 -3563 -1354 -1537 14452 24367
-8300 28662 -52231 19817 -49491 13142 -28887 10169 -12823 7998 -6920 7715
--8949 8140 -9456 5280 -7758 6004 -4542 8468 -1266 9288 -547 9304 -2715 8513
--7152 8374 -12340 7586 -13282 7124 -8959 6926 -1069 5696 1204 5559 262 6267
--1130 7230 -1211 7609 -928 7499 -1654 7315 -4325 6833 -7977 7200 -10799 7919
--8011 9023 16983 11862 19458 10003 16023 7190 10472 4679 5472 4026 965 5902
--1081 7512 -4367 8341 -7720 9488 -7285 12950 -8060 12134 -6690 13248 -5881 13419
--6667 11484 2194 13374 -2003 11339 -6414 10091 -9390 10901 -10897 10416
--10138 10687 -7870 11177 -5460 11428 -3785 10894 -4304 9233 -9438 7525
--15056 9244 -10309 9867 -7881 10106 -6398 9712 -3966 8871 -2285 9536 -1461 10836
--879 11823 -1264 12644 -2846 12170 -3266 11496 -3983 10254 -5473 8767
--7409 7524 -8889 7641 -8021 12822 -9130 11464 -9912 9523 -7929 8446 -86 9818
-2312 9586 2398 8862 2868 7953 6470 7368 12636 7442 12764 7813 725 11093
--5448 10282 -7971 8879 -8243 12912 -7092 11103 1154 7059 -7887 9760 -3427 8470
--4297 10481 -877 6947 -6430 10424 -7605 11379 -5320 9168 -4417 8738 -3790 8670
--2074 8349 2304 7336 2306 7035 1480 7001 -350 6879 -5539 7656 -7224 7551
--10148 8090 -15210 9580 -19808 11473 -22712 11982 -23352 11700 -20851 11038
--14274 9913 -5490 7825 -4917 8700 -6624 4597 -7301 2435 -5950 1170 -1198 648
-6517 1812 9193 5687 -17128 10627 -29481 10839 -30800 7965 -25143 12181
--15288 10870 -8986 10056 -11352 9147 -15147 9705 -12040 13079 2735 11893
-4706 9701 3118 6789 157 4077 -610 1546 1040 1926 -19691 13200 -18792 22355
-11399 33347 9697 34772 -6168 29446 -17772 28766 -10966 25075 8444 23721
--16381 4859 -167730 -115425 -69009 -35897 -219 14485 29863 34511 38592 38829
-37518 36258 32389 31185 25865 25701 19185 20752 12930 16697 7424 13585
-2785 11318 -942 9736 -3827 8672 -5958 7981 -7453 7545 -8446 7280 -9061 7122
--9397 7034 -9541 6987 -9551 6967 -9482 6968 -9354 6983 -9204 7013 -9022 7052
--8832 7102 -8638 7163 -8433 7231 -8234 7308 -8029 7395 -7832 7487 -7628 7589
--7438 7694 -7251 7805 -7080 7918 -6912 8032 -6762 8148 -6616 8266 -6488 8385
--6377 8502 -6280 8617 -6197 8725 -6127 8830 -6080 8928 -6051 9026 -6028 9123
--6025 9221 -6043 9312 -6043 9389 -6037 9461 -6038 9529 -6046 9594 -6071 9651
--6110 9705 -6149 9754 -6189 9799 -6223 9843 -6253 9884 -6293 9918 -6333 9947
--6372 9974 -6404 10000 -6439 10024 -6468 10047 -6495 10065 -6524 10081
--6544 10095 -6563 10108 -6588 10121 -6603 10134 -6622 10144 -6634 10152
--6644 10160 -6655 10168 -6670 10176 -6679 10184 -6691 10190 -6698 10195
--6710 10202 -6720 10207 -6728 10213 -6740 10219 -6757 10224 -6769 10229
--6783 10234 -6798 10240 -6815 10244 -6832 10250 -6853 10255 -6872 10259
--6898 10265 -6920 10270 -6945 10275 -6976 10280 -7000 10285 -7033 10290
--7065 10295 -7096 10300 -7126 10305 -7160 10311 -7191 10316 -7228 10322
--7267 10327 -7297 10333
-152: 12669030 -5117890 -9410 9818 -9420 9826 -9460 9837 -9480 9847 -9500 9858
--9530 9866 -9560 9874 -9590 9885 -9630 9893 -9670 9903 -9690 9913 -9740 9921
--9770 9930 -9810 9935 -9840 9942 -9880 9948 -9930 9955 -9950 9956 -9990 9962
--10030 9964 -10060 9968 -10090 9968 -10120 9969 -10160 9970 -10170 9970
--10200 9971 -10240 9970 -10260 9968 -10290 9968 -10310 9964 -10340 9964
--10360 9967 -10390 9967 -10410 9969 -10440 9972 -10470 9971 -10500 9976
--10540 9983 -10570 9987 -10600 9995 -10650 10005 -10690 10018 -10730 10025
--10780 10035 -10840 10051 -10900 10066 -10960 10084 -11010 10100 -11080 10116
--11140 10132 -11210 10152 -11270 10169 -11350 10188 -11420 10206 -11480 10223
--11550 10240 -11600 10251 -11680 10267 -11740 10284 -11790 10297 -11850 10306
--11890 10313 -11930 10322 -11970 10329 -12010 10332 -12030 10336 -12070 10338
--12070 10339 -12090 10334 -12090 10332 -12090 10326 -12080 10321 -12080 10317
--12080 10315 -12050 10305 -12030 10298 -12010 10290 -11990 10285 -11970 10280
--11960 10279 -11940 10279 -11910 10279 -11900 10275 -11880 10281 -11890 10286
--11880 10298 -11900 10307 -11900 10323 -11930 10341 -11950 10360 -11980 10382
--12020 10404 -12070 10433 -12140 10466 -12210 10500 -12280 10533 -12350 10566
--12430 10602 -12530 10641 -12630 10684 -12740 10727 -12840 10766 -12930 10804
--13030 10838 -13140 10874 -13250 10912 -13370 10950 -13460 10981 -13550 11006
--13620 11026 -13710 11046 -13770 11065 -13850 11077 -13890 11084 -13940 11086
--13960 11083 -13970 11074 -13990 11060 -13970 11039 -13950 11015 -13930 10990
--13880 10960 -13820 10919 -13750 10877 -13650 10827 -13580 10776 -13470 10728
--13380 10680 -13260 10619 -13140 10558 -13000 10493 -12880 10433 -12750 10381
--12640 10328 -12520 10274 -12390 10215 -12260 10162 -12150 10113 -12050 10078
--11990 10047 -11930 10018 -11840 9991 -11790 9969 -11760 9960 -11760 9961
--11770 9971 -11810 9989 -11860 10015 -11920 10049 -12020 10092 -12140 10144
--12280 10206 -12450 10280 -12640 10364 -12840 10456 -13080 10557 -13330 10660
--13590 10770 -13890 10895 -14210 11033 -14550 11173 -14900 11318 -15250 11458
--15600 11600 -15990 11756 -16390 11918 -16810 12083 -17210 12243 -17610 12391
--18010 12538 -18400 12693 -18830 12848 -19240 13002 -19630 13139 -20020 13261
--20360 13374 -20730 13493 -21070 13597 -21410 13686 -21720 13769 -21990 13832
--22270 13885 -22540 13920 -22790 13935 -22950 13929 -23090 13913 -23250 13870
--23510 13812 -23660 13740 -23600 13628 -23520 13496 -23540 13361 -23640 13140
--23770 12878 -23980 12709 -24260 12530 -24260 12134 -23721 11627 -23023 11321
--22885 11209 -23581 10834 -24509 9944 -24543 8941 -23072 8520 -20613 8870
--18731 9400 -19081 9219 -22487 7795 -28516 5142 -35433 1813 -40173 -916
--39282 -1357 -30590 1651 -16534 7098 -5957 10880 -1277 11629 -680 9834
--3720 9344 -10243 10523 -18963 13273 -7215 11787 -4601 9407 -1247 9150
--3563 7236 1064 9022 2977 9268 -13276 5757 -18455 4521 -12288 5270 -944 8422
-2387 9460 1413 9378 -647 9149 -5686 9636 -4662 9485 -1281 7401 -4690 6702
--3401 7557 -5710 7726 -4365 9137 -7563 9282 -7339 9017 -3759 8235 -4421 6438
--9094 4437 -4886 7405 -7295 6873 -3149 9139 -2818 9856 -3969 9770 -4877 8397
--5774 7154 -5648 6693 -3644 7158 -6067 8428 554 6541 1313 7652 828 8702
--2808 9515 -9443 9876 -15908 9230 -20062 8595 -1833 9711 -3081 8158 -832 7102
-4432 7190 3916 7431 6518 10096 6868 10723 -1447 3704 -4995 3186 -6555 3343
--7956 3350 -10519 2464 -14040 278 -15717 -2069 -16011 -4065 -16076 -3974
--17148 455 -15638 686 -11844 -547 -3669 -539 10455 4622 29962 21306 25964 27161
--114838 21473 -72996 12043 -21834 10015 -6759 8157 -5278 8304 -7604 7945
--9066 6069 -8265 6042 -1639 8766 381 9192 -181 9231 -2680 9021 -6145 8648
--8969 7648 -8799 6746 -5478 6404 -961 5985 781 5916 424 6267 -74 6743 418 6885
-1411 6693 1801 6518 797 6517 -1404 7078 -3730 7870 -2927 8651 12855 12033
-13141 8744 10434 6036 5430 3595 1947 3529 -2337 7428 -1472 9722 -4401 10285
--9612 10209 -10700 11545 -10370 11792 -8301 11749 -7409 12352 -9241 11650
--6146 12205 1025 10787 -2693 9917 -6922 12610 -11046 10730 -11275 10674
--8907 11062 -6161 11780 -1802 11660 4280 9307 -8009 7185 -15711 8179 -7389 9401
--6612 10345 -6153 10496 -3293 8517 -1925 9260 -868 10972 -92 12560 -229 13453
--4462 11403 -4854 10855 -5473 9885 -6882 8632 -8521 7580 -9256 8597 -9188 11963
--9983 12112 -11338 10705 -11006 8704 1603 10904 1703 9544 -3 8678 -648 8076
-2876 7696 13688 8566 13318 8955 3743 10253 -3128 10272 -7105 9031 -7846 9408
--6651 8035 -7794 7155 -3214 6654 -2893 6909 -4013 15503 3862 3676 -7085 11666
--9739 13249 -5573 8859 -4830 9011 -4868 9175 -4418 9210 1528 7094 -2004 7172
--3575 7576 -3581 7104 -5787 7181 -5759 6787 -9385 7758 -16387 10081 -20525 11743
--22694 12569 -22864 13106 -20204 13754 -12348 13899 170 9063 1438 9560
--2898 939 -3128 275 530 605 8812 816 18899 1484 19065 4164 -30298 11980
--37710 12052 -35046 4654 -35250 17823 -19360 12500 -10513 9641 -10739 8244
--16616 8028 -10666 14805 -1755 13671 -144 11809 -3255 9744 -9507 8741
--14937 8058 -2991 6014 -17797 13272 -23161 21338 28792 37149 16637 34152
-2002 15432 -11574 17987 5297 16257 7801 20867 -21235 816 -273724 -198571
--34054 -3895 33733 42669 48184 50383 46427 46908 40211 40282 33062 33230
-25975 26803 19254 21402 13066 17119 7583 13883 2904 11540 -919 9907 -3906 8812
--6133 8101 -7716 7655 -8771 7384 -9429 7227 -9791 7139 -9950 7096 -9969 7079
--9900 7084 -9774 7103 -9621 7134 -9445 7174 -9261 7224 -9064 7282 -8864 7348
--8667 7422 -8465 7504 -8270 7592 -8071 7686 -7881 7786 -7695 7889 -7517 7994
--7347 8101 -7193 8210 -7039 8320 -6907 8431 -6782 8540 -6676 8649 -6584 8750
--6503 8848 -6438 8942 -6388 9034 -6352 9126 -6331 9219 -6341 9307 -6327 9381
--6306 9449 -6292 9514 -6283 9576 -6296 9632 -6324 9684 -6351 9732 -6379 9776
--6398 9819 -6414 9860 -6449 9892 -6481 9922 -6508 9949 -6537 9974 -6563 9999
--6583 10021 -6608 10039 -6632 10055 -6651 10069 -6665 10083 -6685 10096
--6698 10109 -6714 10118 -6726 10127 -6732 10135 -6744 10143 -6758 10150
--6767 10158 -6776 10164 -6788 10170 -6795 10175 -6803 10181 -6816 10186
--6828 10192 -6841 10196 -6853 10202 -6869 10206 -6884 10210 -6898 10216
--6916 10220 -6938 10225 -6956 10230 -6980 10234 -7000 10238 -7026 10244
--7054 10248 -7081 10253 -7108 10257 -7138 10263 -7169 10267 -7197 10272
--7231 10278 -7261 10282 -7294 10288 -7331 10293 -7361 10298
-153: 12700540 -5109012 -9430 9819 -9450 9828 -9480 9835 -9500 9847 -9530 9858
--9560 9865 -9580 9875 -9610 9883 -9650 9894 -9690 9905 -9720 9915 -9750 9922
--9790 9930 -9820 9937 -9860 9944 -9900 9948 -9940 9955 -9980 9959 -10010 9965
--10040 9967 -10070 9969 -10100 9971 -10130 9975 -10160 9975 -10190 9974
--10220 9975 -10250 9976 -10260 9972 -10290 9971 -10320 9970 -10350 9971
--10370 9973 -10400 9974 -10420 9974 -10450 9975 -10470 9978 -10500 9983
--10540 9989 -10570 9995 -10600 10003 -10650 10012 -10690 10022 -10730 10031
--10790 10041 -10840 10058 -10890 10071 -10950 10088 -11020 10106 -11080 10119
--11130 10137 -11200 10153 -11260 10174 -11340 10191 -11410 10208 -11460 10224
--11540 10241 -11600 10253 -11660 10269 -11720 10284 -11780 10295 -11830 10305
--11880 10313 -11920 10319 -11950 10328 -11990 10332 -12010 10334 -12050 10334
--12060 10336 -12070 10333 -12070 10329 -12080 10324 -12060 10318 -12070 10315
--12070 10311 -12040 10305 -12010 10295 -12000 10286 -11980 10282 -11960 10278
--11950 10276 -11930 10277 -11910 10275 -11890 10274 -11880 10278 -11870 10283
--11880 10294 -11900 10306 -11900 10319 -11920 10335 -11950 10355 -11980 10377
--12020 10398 -12060 10427 -12130 10457 -12210 10492 -12270 10524 -12340 10557
--12410 10591 -12510 10628 -12610 10671 -12720 10713 -12810 10750 -12910 10788
--13010 10820 -13100 10856 -13220 10892 -13330 10928 -13420 10958 -13500 10984
--13570 11002 -13670 11021 -13720 11039 -13790 11051 -13840 11059 -13890 11059
--13900 11056 -13920 11047 -13920 11033 -13910 11014 -13900 10990 -13860 10964
--13830 10933 -13760 10898 -13690 10853 -13610 10806 -13520 10757 -13420 10711
--13330 10663 -13220 10606 -13100 10545 -12970 10483 -12840 10428 -12720 10376
--12620 10326 -12500 10273 -12370 10218 -12240 10167 -12140 10123 -12050 10090
--11990 10060 -11920 10034 -11860 10008 -11790 9992 -11780 9986 -11770 9988
--11780 10000 -11820 10019 -11870 10047 -11940 10082 -12030 10129 -12150 10180
--12290 10243 -12460 10319 -12640 10404 -12850 10497 -13080 10596 -13320 10699
--13570 10811 -13870 10936 -14180 11070 -14510 11212 -14850 11355 -15190 11494
--15540 11636 -15910 11790 -16300 11952 -16700 12115 -17100 12275 -17490 12422
--17870 12566 -18250 12721 -18660 12876 -19060 13028 -19450 13167 -19800 13289
--20150 13402 -20490 13520 -20830 13627 -21150 13720 -21430 13801 -21700 13869
--21980 13925 -22230 13964 -22450 13983 -22610 13984 -22730 13975 -22940 13941
--23160 13891 -23240 13825 -23140 13719 -23070 13614 -23160 13480 -23350 13253
--23550 13025 -23780 12884 -23920 12680 -23640 12278 -22900 11849 -22280 11632
--22356 11473 -23208 10949 -24045 10000 -23860 9125 -22323 8852 -20261 9102
--19304 9154 -20856 8269 -25492 6194 -32707 3117 -41043 -687 -46980 -3866
--45783 -4104 -32718 884 -9331 10472 3545 15193 5231 14578 2896 9728 -1310 8266
--6863 9144 -18956 14808 -9871 11523 -417 7777 -5008 10472 -14613 4925
--8772 6605 -1938 3828 -2187 10131 -17008 3688 -14255 7732 5923 11749 8415 11307
-3138 10098 1801 8629 -8468 8740 -6987 8209 -5084 7860 -5291 8072 -4614 8634
--5155 8751 -3908 9027 -4695 8858 -8222 8379 -7147 7527 -7007 6477 -7081 6277
--2801 8601 -4968 7292 -3414 8428 -2692 9181 -3054 9103 -4224 8149 -6101 7063
--6424 6439 1397 6439 -4110 8132 -3224 7645 -3132 7793 -1564 7940 -4690 8555
--11966 9364 -13375 8768 -12734 8358 -6315 9448 -2062 7930 2094 7012 11754 7479
-4134 5980 6707 10163 6413 10263 1231 5926 -4333 5063 -6037 4700 -6526 4891
--8791 3632 -13942 -367 -15125 -3574 -15032 -6183 -15135 -6290 -18831 3657
--17572 4302 -14186 3913 -8469 5075 -1258 9737 896 18677 -25195 23108 -94420 19476
--23445 8569 -6910 7384 -1936 6767 -4735 8558 -6438 7988 -7164 6824 -5871 6765
--1624 8186 509 8657 -92 8899 -2272 8831 -4686 8222 -5983 7185 -5183 6558
--2784 6561 -327 6497 547 6321 407 6280 696 6411 2139 6440 4319 6335 6315 6373
-7490 6792 7891 7813 8052 9095 7799 10429 1412 10107 160 5847 392 4673 -731 4140
--1984 5198 -3454 8271 -3067 10566 -4695 11481 -11761 10327 -12462 10996
--11377 11812 -8036 10190 -6244 11221 -9332 10824 -7950 11069 -3043 10434
--4108 9814 -7127 11221 -12537 10758 -12502 10382 -8542 10148 -6245 11492
--785 12358 18146 9803 -4500 6444 -11359 7054 -9067 9023 -7962 10260 -6867 10263
--4711 9080 -3091 9449 -1881 11040 -1682 12271 -1860 12563 -4299 12475
--4333 12032 -5552 11067 -7358 9875 -8996 8074 -8517 9394 -8314 11840 -8149 13069
--7749 13401 -6277 12262 -3880 7682 -3176 7345 -4158 8198 -5514 8761 -3946 8401
-14160 9765 12512 9506 3404 9084 -2692 9669 -5908 9984 -7474 7909 -6691 8401
--5624 8584 -1619 341 -191 2019 -8000 17077 -1351 7682 -2315 8939 -6654 10979
--6665 9820 -5061 9839 -4420 8939 -4164 8787 -2314 8032 -9187 8044 -9614 9149
--5222 7327 -4964 6604 -6039 6666 -9414 7918 -16346 10194 -19501 11668
--20615 12111 -20076 12451 -17582 12911 -7023 12411 -327 9504 1597 8862
--157 3783 -2385 2849 -61 3270 7511 3344 14770 3222 8425 5510 -21968 10689
--34430 12581 -36493 11985 -33547 17580 -13562 8815 -6128 8331 -5418 9049
--15623 9130 -10752 13392 -4273 12719 -3293 12658 -5283 11348 -9041 11853
--10834 12098 -7313 10148 -3996 16977 8164 26736 9040 22796 3495 16049
-1483 10822 -6335 15539 3478 18755 1434 15310 -41850 -7264 -246294 -152211
--12879 -1958 34353 35997 39597 43255 36084 41108 31476 36065 26875 30392
-22079 25012 17027 20338 11890 16526 6977 13581 2551 11411 -1199 9878 -4204 8840
--6484 8162 -8121 7735 -9230 7478 -9911 7329 -10287 7249 -10446 7211 -10466 7199
--10387 7207 -10254 7228 -10099 7260 -9910 7301 -9717 7349 -9525 7406 -9318 7468
--9113 7539 -8915 7615 -8718 7698 -8514 7786 -8324 7878 -8137 7975 -7954 8073
--7780 8172 -7613 8274 -7454 8376 -7314 8480 -7177 8582 -7067 8684 -6959 8779
--6870 8870 -6786 8958 -6726 9046 -6674 9132 -6630 9221 -6630 9306 -6605 9375
--6569 9441 -6537 9502 -6519 9562 -6521 9615 -6537 9666 -6555 9713 -6561 9756
--6571 9797 -6582 9836 -6606 9870 -6630 9898 -6647 9925 -6668 9950 -6684 9974
--6703 9997 -6720 10014 -6740 10031 -6753 10044 -6767 10059 -6784 10071
--6794 10084 -6805 10094 -6814 10103 -6825 10110 -6831 10119 -6841 10125
--6854 10133 -6865 10140 -6871 10144 -6877 10150 -6888 10156 -6901 10160
--6912 10165 -6922 10171 -6935 10174 -6950 10179 -6965 10184 -6980 10187
--6998 10193 -7018 10196 -7037 10201 -7056 10205 -7076 10209 -7105 10214
--7130 10218 -7154 10223 -7180 10226 -7211 10232 -7239 10236 -7266 10241
--7297 10245 -7326 10251 -7358 10256 -7393 10261 -7422 10266
-154: 12732080 -5100133 -9460 9819 -9480 9827 -9500 9834 -9520 9848 -9550 9857
--9590 9866 -9600 9875 -9640 9885 -9660 9894 -9710 9903 -9740 9914 -9780 9924
--9800 9930 -9840 9939 -9880 9945 -9910 9950 -9960 9956 -9990 9960 -10020 9966
--10060 9970 -10080 9972 -10100 9974 -10140 9977 -10180 9978 -10210 9978
--10230 9977 -10250 9980 -10270 9977 -10300 9977 -10330 9974 -10350 9976
--10380 9977 -10400 9979 -10430 9982 -10450 9981 -10470 9983 -10500 9989
--10540 9995 -10580 10002 -10600 10008 -10650 10018 -10700 10029 -10730 10036
--10780 10047 -10840 10062 -10890 10075 -10950 10094 -11010 10110 -11070 10123
--11130 10139 -11190 10157 -11250 10175 -11330 10195 -11390 10209 -11460 10223
--11520 10242 -11580 10256 -11650 10271 -11710 10283 -11770 10294 -11810 10303
--11860 10313 -11900 10319 -11940 10326 -11970 10329 -12000 10331 -12020 10332
--12040 10334 -12060 10333 -12050 10325 -12060 10321 -12050 10315 -12060 10313
--12040 10309 -12030 10300 -12010 10294 -11980 10284 -11970 10281 -11950 10274
--11940 10274 -11920 10273 -11900 10271 -11890 10274 -11870 10277 -11870 10281
--11880 10290 -11890 10302 -11900 10316 -11910 10331 -11940 10350 -11980 10372
--12020 10393 -12060 10419 -12120 10450 -12180 10485 -12270 10517 -12330 10547
--12400 10579 -12490 10616 -12600 10659 -12690 10698 -12790 10736 -12890 10771
--12970 10803 -13080 10838 -13190 10874 -13280 10908 -13380 10936 -13460 10960
--13530 10978 -13620 10996 -13670 11016 -13750 11024 -13790 11033 -13830 11034
--13840 11030 -13870 11019 -13860 11006 -13850 10989 -13840 10964 -13800 10939
--13770 10910 -13710 10873 -13640 10831 -13550 10784 -13470 10738 -13380 10693
--13290 10648 -13180 10592 -13050 10533 -12930 10474 -12810 10421 -12700 10370
--12590 10323 -12480 10274 -12350 10221 -12230 10171 -12130 10131 -12050 10100
--11990 10073 -11920 10048 -11860 10027 -11800 10015 -11780 10008 -11790 10013
--11790 10028 -11840 10047 -11880 10077 -11950 10116 -12050 10162 -12160 10216
--12300 10280 -12460 10355 -12640 10441 -12850 10535 -13070 10634 -13310 10737
--13560 10850 -13830 10975 -14150 11109 -14470 11248 -14810 11390 -15130 11529
--15460 11670 -15830 11823 -16220 11984 -16590 12147 -16990 12305 -17360 12453
--17730 12594 -18100 12748 -18490 12903 -18880 13054 -19250 13195 -19600 13315
--19930 13428 -20260 13550 -20580 13658 -20890 13753 -21160 13837 -21410 13908
--21690 13966 -21920 14010 -22110 14033 -22260 14046 -22390 14041 -22620 14016
--22810 13977 -22810 13916 -22680 13826 -22660 13742 -22830 13607 -23090 13386
--23310 13199 -23470 13074 -23380 12860 -22800 12491 -21920 12153 -21350 11985
--21610 11753 -22600 11128 -23494 10192 -23368 9425 -22075 9171 -20598 9142
--20373 8641 -22496 7172 -27264 4892 -34378 2224 -43838 -1710 -51823 -5720
--52823 -6982 -37011 -911 3013 15790 16187 19872 11039 15452 1487 10779
--4473 8689 -11361 9840 -16567 11499 -9674 12075 -2487 7769 -11866 10699
-12509 5197 -5202 5597 -4970 6355 -7593 12735 -21040 4514 -15458 6992 -128 10159
-5709 10703 -4837 10201 -4563 8644 -3093 5906 -2276 5992 -6516 7537 -7041 8839
--6141 9480 -5443 9300 -3645 8850 -4174 8427 -6641 7874 -7134 7202 -6916 6699
--5910 6931 -3494 8079 -3517 7908 -2495 8293 -1538 8810 -1370 8700 -2418 7890
--5554 6886 -10026 6193 9264 5193 -5211 8220 -6658 8441 -8137 8229 -1873 7498
--3104 7918 -14003 9785 -7769 8287 -4775 7350 -10236 9162 -3280 6732 -2044 5283
-14449 5610 6198 5099 5025 11781 4072 10956 1091 7965 -3034 6485 -5376 6001
--4554 7298 -6159 6433 -14593 454 -14351 -2257 -14689 -3998 -15802 -2797
--18337 3392 -18833 6121 -18239 7641 -17213 9437 -16693 12008 -18843 15351
--35828 17595 -38292 12853 -8676 7537 -11358 7615 -6432 7093 -5548 7629
--5620 7341 -5466 6799 -4154 6840 -1547 7602 146 8061 -348 8306 -1971 8099
--3398 7383 -3635 6710 -2459 6720 -655 7127 609 7154 815 6732 730 6363 1527 6273
-3727 6295 6873 6331 10096 6520 12743 7133 14651 8019 15579 8668 12842 8678
--7460 8185 -9221 5944 -7393 5193 -5889 5504 -5301 6835 -5255 8954 -5971 10414
--9393 10507 -8838 11194 -11206 9965 -10861 9666 -8556 10712 -5880 10937
--6994 10626 -9032 10588 -6095 10153 -6363 8888 -6977 10082 -14778 10600
--13267 9992 -4541 8209 -2891 9423 2169 8674 16266 12347 3410 7983 -5286 6738
--9147 9524 -9452 10663 -8310 10266 -6530 9245 -4849 9408 -3436 11282 -5418 12144
--10035 11853 1627 13172 -1778 13371 -5263 12332 -7941 11481 -9743 7981
--6589 10117 -6401 11798 -5892 13110 -4217 14622 -1770 15277 -7905 4048
--6416 6310 -5786 9036 -5302 11320 -803 12304 2214 7314 5664 8565 -1467 7064
--4385 8111 -5757 9030 -6545 8218 -6139 8099 -4692 7127 -1685 4341 -3739 7404
--9070 16031 -4046 7393 5342 2678 -3361 8775 -6903 11693 -4553 8494 -4028 7548
--6062 8071 -8534 8406 -11751 7827 -14113 11811 -4802 7486 -4665 6304 -7436 6653
--10665 7757 -14676 10725 -16593 11621 -16269 10838 -14065 10523 -11387 10774
--6457 10636 -4191 8537 -578 9608 1039 6146 -6056 6653 -6969 7657 -75 7338
-8155 5103 2052 6250 -15857 9592 -26660 12248 -29372 13802 -22499 13044
--11077 9159 -5355 9397 -6094 10902 -9514 9673 -7023 12981 -3030 10570
--4749 13073 -4802 11235 -6361 13246 -5851 14609 -12439 9128 -2422 13510
-14829 18570 3524 13359 -5687 12261 -6842 14832 -1113 20934 5794 23892
-1165 18450 -22630 8850 -74606 -33903 -52851 -33574 -15962 -449 -242 17230
-7882 24049 13149 25289 15834 23769 15894 21037 13790 18006 10303 15194
-6215 12845 2142 11027 -1511 9703 -4540 8785 -6887 8179 -8592 7795 -9748 7564
--10463 7432 -10861 7362 -11011 7333 -11026 7326 -10933 7338 -10786 7360
--10613 7393 -10416 7431 -10213 7479 -10001 7533 -9792 7592 -9583 7658
--9374 7729 -9167 7806 -8967 7887 -8767 7974 -8574 8062 -8387 8154 -8199 8246
--8030 8340 -7861 8436 -7711 8531 -7572 8627 -7442 8721 -7329 8810 -7223 8896
--7129 8979 -7053 9060 -6989 9142 -6922 9226 -6916 9306 -6877 9373 -6826 9435
--6782 9494 -6754 9550 -6741 9602 -6745 9650 -6749 9696 -6743 9737 -6747 9778
--6751 9816 -6762 9847 -6772 9877 -6787 9903 -6798 9927 -6811 9951 -6820 9974
--6834 9991 -6846 10007 -6858 10021 -6867 10035 -6880 10048 -6891 10061
--6898 10070 -6904 10079 -6914 10087 -6918 10094 -6924 10102 -6938 10110
--6945 10115 -6953 10120 -6958 10126 -6971 10131 -6980 10135 -6993 10141
--7002 10145 -7015 10149 -7027 10153 -7044 10157 -7059 10162 -7077 10165
--7093 10170 -7112 10173 -7132 10178 -7152 10181 -7177 10185 -7201 10190
--7225 10194 -7250 10198 -7278 10202 -7307 10206 -7332 10212 -7359 10215
--7389 10221 -7419 10226 -7449 10230 -7482 10236
-155: 12763650 -5091259 -9490 9817 -9500 9829 -9530 9836 -9550 9846 -9570 9856
--9600 9868 -9630 9876 -9660 9885 -9700 9893 -9720 9904 -9750 9915 -9800 9923
--9830 9929 -9850 9939 -9890 9946 -9930 9951 -9970 9958 -10010 9962 -10030 9967
--10070 9972 -10100 9974 -10120 9976 -10150 9979 -10180 9981 -10210 9980
--10230 9983 -10260 9983 -10290 9980 -10310 9980 -10340 9979 -10350 9980
--10390 9982 -10400 9986 -10430 9986 -10450 9985 -10480 9989 -10510 9992
--10540 10001 -10570 10008 -10610 10015 -10650 10022 -10700 10033 -10730 10043
--10780 10053 -10830 10066 -10880 10080 -10950 10096 -11010 10113 -11060 10128
--11120 10142 -11180 10160 -11250 10177 -11320 10197 -11380 10212 -11450 10225
--11500 10241 -11570 10256 -11630 10271 -11690 10282 -11750 10292 -11800 10304
--11830 10312 -11880 10318 -11930 10324 -11950 10326 -11990 10328 -12000 10330
--12020 10332 -12040 10328 -12040 10324 -12030 10318 -12040 10314 -12040 10309
--12030 10306 -12010 10299 -12000 10292 -11970 10283 -11960 10277 -11940 10274
--11930 10272 -11920 10268 -11890 10270 -11880 10270 -11860 10276 -11870 10281
--11870 10287 -11890 10300 -11890 10311 -11910 10327 -11940 10346 -11970 10366
--12000 10389 -12060 10414 -12110 10443 -12180 10476 -12250 10507 -12320 10539
--12390 10570 -12480 10604 -12580 10647 -12680 10686 -12760 10720 -12850 10756
--12960 10786 -13040 10820 -13140 10855 -13260 10887 -13340 10914 -13420 10938
--13480 10955 -13570 10973 -13640 10991 -13690 11000 -13740 11006 -13770 11008
--13790 11003 -13810 10994 -13810 10981 -13790 10961 -13790 10939 -13750 10914
--13710 10887 -13660 10850 -13580 10809 -13510 10763 -13420 10719 -13330 10675
--13240 10631 -13140 10578 -13020 10521 -12900 10466 -12770 10412 -12670 10365
--12570 10321 -12450 10272 -12340 10223 -12220 10175 -12130 10138 -12040 10110
--11980 10084 -11920 10063 -11860 10045 -11820 10033 -11790 10030 -11790 10038
--11810 10053 -11840 10076 -11900 10106 -11960 10146 -12060 10196 -12180 10249
--12300 10314 -12460 10390 -12650 10477 -12840 10571 -13060 10671 -13300 10774
--13530 10886 -13810 11010 -14120 11144 -14430 11284 -14750 11424 -15070 11563
--15390 11703 -15750 11856 -16120 12015 -16500 12177 -16870 12332 -17230 12480
--17590 12622 -17950 12775 -18320 12930 -18700 13078 -19060 13219 -19400 13342
--19710 13456 -20020 13580 -20350 13689 -20620 13786 -20880 13871 -21130 13947
--21400 14008 -21620 14055 -21780 14087 -21890 14108 -22080 14111 -22290 14094
--22440 14067 -22380 14010 -22240 13942 -22290 13873 -22520 13739 -22820 13540
--23020 13388 -23030 13279 -22670 13076 -21820 12768 -20800 12516 -20240 12363
--20620 12064 -21820 11397 -23040 10501 -23200 9828 -22329 9539 -21366 9247
--21455 8304 -23331 6443 -26918 4308 -31766 3376 -41501 -37 -50994 -4897
--57018 -8536 -44924 -4340 20198 23382 27381 24031 11344 13176 -6071 9790
--10701 8416 -15592 10473 -13038 8439 2230 4329 -1000 8294 -9200 9441 5347 5965
-1768 9433 -6859 7985 -18124 13952 -22825 9047 -18091 8012 -8777 8870 -4519 9308
--8675 9282 -8412 8484 2945 2687 2566 3457 -5321 7520 -7413 9034 -6521 9791
--5955 9243 -3077 8341 -3559 7947 -5285 7498 -6224 7024 -6277 6757 -5493 6986
--4070 7684 -3126 8148 -1589 8241 -181 8726 633 8560 868 7764 -70 6830 -9134 6548
-199 6011 -6376 6866 -6097 8077 -10760 8076 -2983 7907 2236 7521 -15347 11126
--1152 6924 1975 6325 -6196 6102 659 7250 -1006 5914 10937 5440 15202 5866
--16156 11398 -3158 10236 -567 8390 -2754 7102 -6489 6259 -4312 8949 -6868 7781
--12242 4167 -10973 1669 -13442 -292 -15522 705 -17380 4444 -18942 7669
--20573 10240 -22724 12060 -25162 12077 -19927 11038 -22830 12194 -17423 9451
--12860 7721 -12651 8147 -8376 7050 -5852 6623 -4849 6371 -4261 6234 -3204 6446
--1547 7028 -471 7452 -914 7576 -1989 7216 -2587 6653 -2009 6582 -468 7241
-1121 7929 1831 7913 1632 7267 1430 6632 2282 6282 4722 6251 8241 6368 11860 6689
-14699 7234 16129 7651 15166 7567 8913 6913 -8709 5946 -11394 6052 -10424 6052
--8353 6865 -7313 8012 -6031 9543 -5829 10610 -9408 10360 -9599 10894 -11822 8750
--11218 8968 -9041 9967 -5070 10200 -6092 9766 -10505 10181 -9279 9387
--6820 8022 -7064 9772 -12562 10812 -12780 10915 1565 8300 3939 8926 7451 9508
-12647 10856 4647 6329 -2333 4955 -9723 10428 -10533 11161 -9329 10232
--7741 9030 -5995 8986 -2545 11910 -2916 12806 -8322 12046 -2624 12410
--5665 13532 -8143 11584 -11455 10435 -10645 9062 -2406 12224 -4747 11454
--5489 10821 -5418 9819 -6742 5830 -1458 11767 -4743 11011 -6082 11171
--8484 12248 -6311 11306 -3848 7926 -406 8549 -3140 7607 -4779 7776 -4687 8939
--4886 8456 -4893 7770 -1792 7206 -2683 7584 -6187 9253 -8842 12250 -5596 7751
-2041 5336 -1247 7988 -3917 10011 -3673 8741 -4145 7894 -6337 7605 -10123 5944
--11414 5708 -14461 14288 -7427 8865 -6669 6955 -10029 7295 -11782 7258
--12989 11677 -13203 11719 -11323 8927 -8497 8531 -7177 9279 -6818 10543
--9715 8968 -3027 9095 5750 5119 -12804 9553 -17046 11889 -8735 11594 4347 6175
--1225 6461 -12639 8273 -18219 10186 -18699 11437 -13535 11623 -7750 9316
--3582 10240 -5884 12776 -6073 8181 -3094 10568 -1879 10240 -9130 13071
--3158 11541 -7507 12286 -7955 11248 -13994 11354 -6022 11604 20127 15285
--5761 11033 -13299 10595 -10316 15686 6902 28623 13416 36419 8827 41653
--4010 42501 -5206 -31379 -27220 -25045 -42547 -15097 -37312 -2305 -20868 8211
--4745 14449 6080 16895 11167 16848 11810 15514 9673 13743 6119 12026 2179 10587
--1545 9489 -4709 8709 -7203 8186 -9024 7853 -10271 7653 -11041 7542 -11458 7484
--11625 7462 -11626 7462 -11525 7475 -11360 7499 -11159 7530 -10955 7569
--10727 7613 -10505 7663 -10284 7719 -10059 7780 -9844 7845 -9629 7917
--9416 7991 -9208 8071 -9011 8152 -8807 8237 -8614 8322 -8438 8409 -8262 8496
--8103 8586 -7951 8674 -7810 8762 -7691 8844 -7565 8925 -7462 9001 -7370 9078
--7287 9155 -7211 9234 -7196 9309 -7144 9373 -7085 9431 -7021 9488 -6983 9541
--6957 9591 -6946 9637 -6939 9681 -6927 9722 -6925 9760 -6913 9797 -6910 9828
--6918 9857 -6925 9882 -6930 9906 -6933 9930 -6937 9951 -6949 9970 -6954 9985
--6962 9999 -6967 10012 -6972 10026 -6981 10037 -6991 10048 -6997 10057
--6998 10064 -7002 10072 -7011 10079 -7020 10086 -7025 10092 -7034 10097
--7040 10103 -7051 10107 -7055 10112 -7070 10116 -7078 10121 -7091 10125
--7103 10128 -7119 10133 -7134 10136 -7148 10140 -7169 10144 -7182 10148
--7208 10151 -7224 10155 -7246 10158 -7268 10163 -7292 10167 -7319 10170
--7341 10175 -7372 10179 -7395 10183 -7420 10187 -7448 10193 -7477 10197
--7505 10202 -7532 10207
-156: 12795240 -5082387 -9510 9819 -9530 9828 -9550 9836 -9570 9846 -9600 9857
--9630 9867 -9650 9876 -9680 9884 -9710 9893 -9740 9904 -9770 9915 -9820 9923
--9840 9930 -9880 9937 -9910 9946 -9940 9951 -9980 9960 -10020 9964 -10040 9969
--10080 9973 -10110 9977 -10140 9977 -10160 9980 -10190 9983 -10220 9983
--10240 9985 -10260 9986 -10300 9984 -10320 9981 -10340 9984 -10360 9985
--10390 9988 -10410 9988 -10430 9990 -10460 9991 -10480 9995 -10510 9998
--10540 10004 -10580 10012 -10610 10019 -10650 10027 -10690 10039 -10730 10048
--10780 10056 -10820 10071 -10880 10085 -10940 10099 -11000 10115 -11060 10130
--11110 10145 -11170 10161 -11240 10179 -11310 10200 -11370 10213 -11430 10227
--11490 10241 -11560 10256 -11610 10270 -11670 10281 -11730 10293 -11790 10303
--11810 10311 -11860 10315 -11910 10322 -11940 10323 -11960 10326 -11990 10329
--12000 10328 -12020 10326 -12020 10321 -12020 10318 -12020 10309 -12020 10306
--12020 10304 -11990 10299 -11990 10289 -11960 10280 -11940 10275 -11930 10272
--11920 10272 -11910 10268 -11880 10267 -11870 10267 -11860 10272 -11860 10279
--11870 10287 -11880 10296 -11890 10309 -11900 10323 -11930 10342 -11970 10362
--12000 10384 -12040 10408 -12100 10438 -12180 10467 -12240 10499 -12300 10529
--12390 10559 -12460 10595 -12560 10633 -12650 10673 -12760 10707 -12820 10742
--12920 10768 -13010 10802 -13120 10837 -13220 10868 -13300 10893 -13370 10915
--13450 10934 -13520 10950 -13590 10966 -13650 10976 -13680 10980 -13720 10981
--13740 10978 -13750 10968 -13750 10956 -13750 10936 -13720 10913 -13710 10891
--13660 10863 -13600 10828 -13530 10787 -13460 10742 -13370 10699 -13290 10658
--13200 10614 -13100 10563 -12980 10509 -12860 10457 -12750 10404 -12640 10359
--12540 10318 -12440 10270 -12330 10224 -12210 10179 -12110 10146 -12040 10118
--11980 10096 -11920 10075 -11860 10062 -11830 10050 -11800 10052 -11800 10059
--11820 10079 -11850 10102 -11910 10134 -11970 10175 -12070 10225 -12180 10281
--12310 10347 -12470 10425 -12640 10510 -12830 10604 -13060 10707 -13270 10810
--13520 10921 -13780 11045 -14070 11177 -14390 11317 -14690 11456 -15010 11594
--15330 11735 -15670 11885 -16020 12045 -16390 12203 -16750 12359 -17110 12505
--17440 12650 -17800 12800 -18160 12952 -18520 13102 -18870 13242 -19190 13367
--19500 13482 -19800 13608 -20090 13720 -20370 13816 -20610 13904 -20860 13982
--21100 14051 -21310 14102 -21450 14139 -21570 14167 -21750 14178 -21970 14172
--22070 14155 -21940 14108 -21850 14059 -21930 14004 -22220 13876 -22530 13704
--22650 13583 -22490 13493 -21870 13321 -20790 13086 -19640 12902 -19030 12751
--19440 12419 -20890 11741 -22790 10900 -23420 10336 -22950 10093 -22260 9758
--22220 8733 -23147 6706 -24719 4402 -24529 6728 -33592 4592 -39575 404
--46243 -3567 -29814 2500 12239 19937 22929 22492 660 4846 -19676 7641
--21038 7823 -14254 8373 -9068 6386 -530 4278 -1541 6237 -4723 6743 937 5497
-487 7214 -13024 14843 -19668 15704 -21519 10701 -19446 8003 -14556 7382
--10510 7095 -8754 6433 -5723 5437 2124 5407 -78 8632 -1347 2354 -6541 6605
--4901 8898 -4981 8151 -3871 7817 -3704 7633 -4711 7306 -5604 6955 -5858 6747
--5482 6813 -4728 7179 -3936 7738 -847 8702 464 9062 801 8673 -7 7841 -2120 7174
--5500 6810 -2332 6704 -9684 5489 -7433 7582 -11408 8289 -6828 9838 -2037 9765
--12138 12130 4553 6270 -16706 13941 26145 -4520 14873 5859 -7207 5626
--5283 6011 -5574 7242 -1442 8967 975 8854 1189 8002 -849 7323 -5964 7973
--5870 9076 -7061 8391 -8983 7190 -9088 5811 -12805 3252 -14844 3816 -15537 6030
--17279 8837 -19367 11447 -21063 12810 -21978 9433 -21208 9813 -19400 10563
--15322 9357 -14423 8137 -12846 7695 -7799 6009 -4860 5280 -3843 5248 -3468 5489
--2898 5916 -1884 6538 -1375 6914 -1801 6944 -2453 6566 -2393 6333 -1143 6877
-897 7999 2743 8829 3400 8782 2941 8059 2340 7125 2611 6206 4717 5967 8108 6229
-11498 6728 13745 7061 13997 6748 11336 5958 4119 4883 -9256 4280 -9739 6422
--10407 6529 -8695 7664 -9008 8365 -6900 9427 -6131 9883 -7698 9774 -10093 9677
--11166 8703 -10517 9180 -8442 10542 -5013 9173 -7301 9252 -9918 9037 -9699 8671
--3575 7178 -4071 8759 -6980 10344 -6328 11092 1553 10133 5178 10082 8427 10813
-10353 11219 1601 5090 -3642 5351 -8628 9208 -9986 10542 -8947 9776 -7685 8995
--6196 9490 -3984 11504 -3689 12787 -5231 12650 -4221 12766 -9499 11635
--10785 10368 -15171 9557 -13584 8614 3922 15090 -4572 10959 -5064 9610
--3238 9879 -3473 5426 -1792 9560 -8089 11535 -7240 11500 -13005 12557
--11377 10168 -8136 7507 -3166 9563 -4408 8517 -5100 7820 -2707 9601 -1900 8760
--1651 7723 -941 7248 -3891 9693 -8398 9162 -9246 10897 -7093 8873 -2015 6915
--1910 7834 -2552 9098 -2853 8937 -4285 8250 -7137 7358 -10112 6600 -10693 6791
--11743 11157 -8904 9606 -9674 8455 -11586 8665 -11684 7914 -11326 10811
--9559 11347 -4106 5871 -9204 8481 -9054 10310 -9489 10050 -12167 9729
--5079 8809 18137 547 -21015 11210 -23362 13560 -7718 11961 -2380 9299
--6435 7844 -14038 7481 -12125 8201 -10187 8882 -5699 11317 -3484 8655
--136 8830 -4374 13140 -4417 10359 -3629 9935 -3905 11498 -7686 12353 -6902 11389
--9346 11173 -9776 10734 -11664 11504 -6613 11727 5312 12202 -5660 10480
--13558 9445 -11908 13146 18471 32346 22156 36449 15435 33895 -970 22142
--8663 -134 18297 8083 -61877 -14847 -63800 -10641 -36820 380 -11549 8796
-4409 13137 11828 14433 13275 14000 11186 12819 7373 11485 3052 10295 -1057 9357
--4561 8680 -7324 8222 -9346 7931 -10734 7758 -11592 7664 -12058 7618 -12252 7602
--12253 7605 -12137 7621 -11958 7644 -11736 7675 -11504 7710 -11263 7752
--11027 7799 -10786 7848 -10542 7904 -10316 7965 -10089 8029 -9872 8098
--9646 8170 -9438 8244 -9226 8322 -9021 8399 -8836 8479 -8652 8560 -8483 8642
--8324 8724 -8171 8805 -8033 8881 -7900 8956 -7781 9026 -7676 9098 -7580 9171
--7494 9245 -7470 9314 -7402 9375 -7331 9431 -7256 9484 -7205 9535 -7171 9582
--7144 9627 -7128 9668 -7106 9708 -7091 9745 -7073 9780 -7063 9811 -7062 9838
--7062 9863 -7059 9887 -7055 9909 -7055 9931 -7058 9948 -7060 9964 -7063 9978
--7068 9991 -7070 10004 -7072 10017 -7079 10026 -7083 10034 -7086 10043
--7087 10050 -7091 10057 -7100 10064 -7106 10070 -7109 10075 -7119 10080
--7124 10084 -7132 10089 -7144 10094 -7151 10098 -7164 10101 -7177 10105
--7189 10109 -7207 10112 -7220 10117 -7236 10119 -7254 10123 -7275 10126
--7293 10130 -7312 10134 -7337 10137 -7357 10141 -7382 10145 -7403 10148
--7429 10153 -7453 10156 -7479 10162 -7506 10165 -7532 10170 -7559 10175
--7583 10180
-157: 12826860 -5073516 -9540 9819 -9550 9827 -9580 9836 -9590 9845 -9630 9857
--9640 9867 -9670 9877 -9700 9882 -9730 9893 -9770 9904 -9790 9914 -9830 9923
--9860 9931 -9890 9936 -9930 9946 -9950 9952 -10000 9962 -10020 9962 -10060 9971
--10100 9974 -10120 9978 -10140 9978 -10180 9983 -10190 9984 -10230 9986
--10250 9987 -10280 9989 -10290 9987 -10330 9985 -10340 9986 -10370 9989
--10400 9991 -10410 9993 -10430 9992 -10460 9996 -10480 9999 -10510 10004
--10550 10009 -10580 10016 -10610 10023 -10640 10032 -10690 10041 -10730 10052
--10780 10061 -10820 10074 -10880 10089 -10920 10102 -11000 10117 -11040 10133
--11110 10147 -11160 10163 -11230 10181 -11300 10200 -11350 10214 -11420 10227
--11480 10242 -11540 10256 -11590 10270 -11660 10281 -11710 10291 -11770 10300
--11800 10310 -11840 10314 -11890 10319 -11920 10320 -11940 10323 -11970 10326
--11980 10328 -12010 10324 -12000 10318 -12000 10314 -12000 10308 -12000 10303
--12000 10302 -11980 10297 -11970 10288 -11950 10279 -11930 10273 -11920 10270
--11910 10269 -11890 10268 -11870 10266 -11860 10265 -11860 10269 -11860 10277
--11860 10285 -11870 10293 -11880 10307 -11900 10321 -11930 10339 -11950 10355
--12000 10378 -12040 10404 -12100 10432 -12160 10460 -12240 10492 -12280 10520
--12360 10550 -12450 10585 -12540 10620 -12640 10659 -12720 10694 -12800 10727
--12900 10751 -12980 10785 -13080 10819 -13190 10848 -13260 10873 -13340 10895
--13410 10912 -13470 10927 -13540 10941 -13600 10952 -13630 10957 -13670 10956
--13690 10952 -13700 10943 -13700 10931 -13690 10909 -13680 10889 -13650 10866
--13600 10841 -13550 10805 -13490 10765 -13400 10722 -13330 10680 -13250 10639
--13160 10598 -13060 10549 -12950 10498 -12830 10446 -12710 10395 -12620 10355
--12520 10313 -12430 10269 -12300 10223 -12200 10184 -12110 10152 -12040 10124
--11970 10107 -11920 10088 -11870 10076 -11820 10067 -11810 10071 -11810 10081
--11830 10101 -11860 10129 -11920 10159 -11990 10203 -12070 10253 -12190 10310
--12310 10379 -12460 10456 -12640 10544 -12830 10637 -13040 10739 -13260 10843
--13490 10954 -13750 11077 -14030 11209 -14340 11347 -14640 11487 -14950 11623
--15250 11764 -15580 11914 -15930 12072 -16280 12228 -16640 12382 -16970 12530
--17310 12673 -17650 12823 -17990 12975 -18350 13123 -18670 13262 -18990 13388
--19280 13506 -19580 13634 -19860 13744 -20110 13842 -20350 13934 -20580 14016
--20820 14090 -21000 14144 -21130 14187 -21260 14221 -21440 14243 -21640 14247
--21680 14236 -21560 14203 -21460 14171 -21590 14129 -21910 14011 -22200 13867
--22240 13772 -21930 13706 -21100 13578 -19870 13409 -18600 13273 -17880 13127
--18160 12790 -19770 12154 -22860 11323 -23930 10910 -23700 10866 -23090 10841
--22610 10387 -22080 9117 -20770 6625 -17735 9094 -26452 8912 -23706 6391
--36641 140 -21920 5463 4227 15783 11404 18187 -19288 1553 -22104 6072
--21471 8098 -13587 5759 -8728 5065 -4152 4659 -4136 5496 -6114 5686 -5877 6666
--7507 10022 -12387 15222 -15848 15465 -16913 9018 -18951 6435 -17582 5779
--12875 5256 -5671 4355 -59 4575 3758 6175 632 6966 -4186 2525 -8684 4105
--3731 7209 -4634 7567 -5151 7482 -4223 7517 -4865 7262 -5579 6998 -5786 6814
--5587 6723 -4964 6893 -4371 7803 -1726 8670 27 9273 48 8616 -2063 7452
--5595 6554 -6480 7297 -7083 7491 -431 6436 -4784 6330 -9209 7459 -5681 9783
--3959 10296 -6136 11239 2955 8768 7725 8943 24714 7612 -2228 1056 -13785 3127
--10813 5753 -7946 7488 -1000 7793 1515 7908 1431 7825 -746 7977 -4514 8709
--5975 9101 -6679 8294 -7107 8665 -8256 7500 -10309 7567 -13408 6900 -12726 7394
--14883 9195 -17209 10805 -17763 10728 -17248 8813 -21914 10714 -19048 11386
--15875 10423 -16313 8717 -13715 7903 -5482 4598 -3054 3908 -2973 4350
--3248 4965 -3280 5535 -2712 6235 -2577 6615 -2967 6631 -3430 6297 -2919 6417
--1083 7425 1687 8783 4369 9629 5331 9715 4569 9109 3257 7804 2122 5666
-3528 5188 6684 5861 9675 6729 11207 6827 10444 5532 7219 4494 1080 4023
--6814 4324 -8682 5732 -9187 6200 -9062 7230 -11547 7760 -7801 8808 -6517 8720
--6094 8850 -9714 8497 -9395 8003 -8807 8409 -6699 9991 -4500 9682 -7565 9413
--6723 7458 -5307 7168 -1650 7058 -1102 8394 -2401 10264 -2508 11777 841 11782
-2800 10731 5273 10514 5825 9804 901 6829 -3483 7049 -7291 9377 -8956 10408
--7621 9142 -7253 8884 -7107 10208 -6653 12395 -5957 11941 -6387 12016
--7033 11517 -10344 12417 -10832 10517 -12047 10447 -11027 9309 -2300 12091
--4451 10801 -4987 9824 -2822 9388 2834 5851 440 8006 -17591 12334 -10846 12234
--11403 12157 -10982 9514 -7322 8089 -5680 8889 -6533 9072 -6262 9173 -1541 8947
-174 8600 -176 8205 -1922 8324 -3943 10037 -10147 7238 -8788 10776 -7152 9836
--6732 6995 -4080 7647 -2483 8818 -2144 9244 -3983 8653 -7126 7367 -9162 7207
--9952 7772 -10170 9662 -8648 9449 -11520 8762 -12218 8774 -11537 8639
--9854 9919 -7070 10248 -4775 7861 -8266 9030 -10630 12516 -11778 9771
--11138 8612 -467 7488 4119 3147 -14379 8551 -14414 12236 -8700 11891 -6094 10520
--9998 8886 -19374 6914 -8411 7370 -5790 8023 -2852 9425 -527 8953 2094 9858
-1222 12425 -1293 11599 -6099 10463 -2841 11665 -7150 11463 -9860 10298
--11899 9893 -9611 10910 -9488 12534 -7286 12730 -3233 12251 -2541 12664
--5308 11926 -248 15606 18072 26196 24036 28346 19729 21853 -15064 7114
--109612 -14651 81257 42847 -98662 -13688 -66954 -7036 -25198 4007 1531 11017
-15073 14155 19747 14760 18960 14021 15192 12749 10113 11421 4842 10270
-11 9379 -4042 8742 -7205 8314 -9522 8047 -11099 7890 -12088 7805 -12627 7766
--12862 7755 -12875 7759 -12762 7774 -12565 7798 -12328 7824 -12071 7858
--11809 7895 -11551 7937 -11289 7981 -11032 8032 -10791 8086 -10551 8143
--10314 8206 -10081 8271 -9854 8338 -9643 8408 -9421 8479 -9223 8551 -9035 8625
--8847 8700 -8674 8775 -8519 8850 -8366 8921 -8228 8989 -8085 9054 -7974 9121
--7864 9189 -7763 9257 -7736 9324 -7657 9380 -7569 9432 -7484 9482 -7424 9531
--7377 9576 -7336 9619 -7312 9658 -7281 9695 -7254 9732 -7231 9765 -7213 9794
--7204 9821 -7193 9846 -7187 9868 -7178 9891 -7169 9911 -7169 9929 -7165 9944
--7164 9958 -7166 9971 -7165 9983 -7163 9996 -7162 10005 -7167 10014 -7172 10022
--7171 10028 -7170 10036 -7182 10044 -7181 10048 -7183 10054 -7194 10058
--7200 10063 -7207 10068 -7215 10071 -7222 10076 -7232 10079 -7244 10083
--7258 10086 -7275 10090 -7286 10093 -7304 10096 -7323 10100 -7339 10103
--7360 10106 -7374 10110 -7399 10113 -7418 10117 -7441 10120 -7464 10124
--7486 10128 -7509 10132 -7537 10136 -7559 10140 -7580 10145 -7610 10150
--7632 10154
-158: 12858490 -5064651 -9550 9821 -9580 9828 -9590 9836 -9630 9845 -9640 9855
--9670 9866 -9690 9876 -9720 9885 -9750 9892 -9780 9903 -9810 9913 -9840 9923
--9880 9931 -9910 9935 -9930 9947 -9970 9953 -10020 9959 -10040 9965 -10070 9970
--10100 9975 -10130 9978 -10160 9981 -10180 9985 -10210 9984 -10230 9987
--10260 9988 -10290 9991 -10300 9990 -10320 9989 -10350 9990 -10380 9992
--10400 9994 -10420 9995 -10430 9997 -10460 9999 -10480 10003 -10520 10007
--10550 10015 -10580 10019 -10610 10025 -10630 10037 -10690 10044 -10730 10056
--10770 10065 -10820 10077 -10880 10091 -10920 10106 -10980 10121 -11040 10134
--11090 10149 -11150 10164 -11220 10182 -11290 10199 -11340 10216 -11410 10228
--11460 10241 -11520 10256 -11580 10270 -11640 10279 -11690 10290 -11740 10298
--11790 10308 -11830 10312 -11860 10316 -11900 10319 -11920 10322 -11950 10323
--11970 10324 -11980 10322 -11990 10316 -11970 10311 -11980 10305 -11980 10302
--11990 10299 -11970 10295 -11960 10284 -11930 10278 -11910 10273 -11910 10268
--11900 10269 -11880 10266 -11860 10266 -11860 10264 -11850 10267 -11850 10273
--11850 10282 -11860 10290 -11880 10305 -11900 10318 -11920 10337 -11950 10352
--11990 10374 -12030 10397 -12090 10425 -12150 10454 -12220 10485 -12280 10513
--12340 10540 -12430 10575 -12520 10609 -12620 10645 -12690 10680 -12780 10712
--12870 10738 -12960 10768 -13050 10801 -13150 10829 -13230 10853 -13300 10875
--13360 10892 -13440 10903 -13490 10917 -13550 10927 -13590 10932 -13620 10932
--13630 10927 -13650 10918 -13650 10906 -13640 10886 -13630 10865 -13590 10842
--13560 10817 -13490 10783 -13440 10743 -13360 10703 -13280 10661 -13210 10622
--13120 10581 -13030 10535 -12910 10484 -12800 10435 -12690 10388 -12590 10348
--12500 10308 -12410 10267 -12290 10224 -12190 10188 -12100 10155 -12030 10132
--11970 10116 -11930 10100 -11860 10090 -11830 10084 -11820 10088 -11810 10100
--11840 10121 -11870 10152 -11920 10185 -12000 10229 -12080 10280 -12190 10340
--12320 10408 -12460 10485 -12630 10573 -12820 10669 -13030 10770 -13230 10872
--13470 10984 -13720 11108 -13990 11239 -14290 11376 -14580 11516 -14880 11649
--15180 11791 -15490 11939 -15840 12094 -16180 12252 -16520 12406 -16840 12551
--17160 12695 -17500 12842 -17830 12994 -18170 13143 -18490 13280 -18780 13407
--19070 13527 -19350 13650 -19630 13762 -19860 13864 -20090 13959 -20310 14048
--20540 14121 -20710 14181 -20830 14230 -20950 14270 -21130 14297 -21310 14314
--21320 14309 -21170 14287 -21110 14273 -21260 14239 -21590 14140 -21850 14017
--21830 13945 -21400 13900 -20490 13817 -19210 13700 -17940 13592 -17110 13440
--17130 13123 -18450 12588 -23270 11680 -24330 11460 -24200 11658 -23750 12056
--23360 12401 -23080 12594 -22280 12288 -17100 8417 -21650 9052 -15848 7171
--22555 4562 -17817 6694 -5497 10985 -6049 11607 -19374 3675 -18389 6950
--17777 7614 -12530 6198 -9802 5468 -7133 5590 -7034 5921 -9653 5031 -12692 7352
--15049 11892 -10197 14496 -10485 15119 -9985 5614 -18141 4884 -19838 4987
--14364 4374 -458 2460 6976 3606 8534 6809 2480 6572 -6305 1505 -9149 2762
--6691 5796 -6972 6951 -7964 7059 -5429 7398 -6043 7156 -6262 7053 -5940 7001
--5905 6768 -5713 6533 -5761 7975 -2543 8795 -173 9281 191 8346 -2538 6804
--8116 5137 -3860 7404 -2377 7694 2275 7616 -3657 5772 -5726 7175 -6393 9337
--4570 9329 -3545 9459 5114 5743 13331 2633 7264 11748 -7193 6373 -14749 5148
--8265 7024 -6249 8119 -1449 7492 364 7478 742 7795 -917 8511 -3752 9468
--5635 9923 -5480 8916 -5570 9157 -6570 9315 -7149 8979 -11421 8482 -11055 8080
--13690 9306 -17254 10256 -18161 9177 -17037 8574 -17701 11279 -16768 12324
--16102 11003 -15031 9154 -14256 9141 -1307 3075 -1962 3219 -3329 4272
--3974 5064 -4502 5455 -4074 6174 -3906 6670 -4212 6729 -4882 6304 -4170 6651
--1873 7926 1788 9314 6067 10002 7513 10410 6116 10166 4070 8763 450 4267
-1269 3894 4592 5391 7294 6894 8322 6922 6889 3989 3987 3120 -452 3695 -5503 4739
--7337 5487 -7809 5290 -9087 6459 -11188 7575 -9672 7839 -9137 7045 -9058 8286
--4683 7194 -5295 7005 -6826 7476 -6605 9088 -5583 10007 -4083 9320 -1260 5522
--681 6434 930 7258 1619 8422 519 10330 -1788 12729 -857 13343 -1117 10811
-1713 9933 3083 8966 891 8003 -2080 8437 -5288 10082 -7943 10941 -5784 8413
--6995 8713 -8499 10531 -9756 12704 -10244 13344 -10839 13617 -11305 13387
--8619 11133 -8329 10023 -7784 10137 -9707 7901 -5457 9410 -5228 9806 -5899 9578
--5330 10261 7575 5969 6123 7202 -30464 13868 -7595 11950 -6327 12393 -6577 9518
--6820 7413 -7434 8004 -8839 9215 -9268 10478 -1062 8527 630 8816 -659 8843
--6133 8352 -7924 9407 -7553 8575 -6873 9769 -7565 8900 -10241 6593 -5567 7616
--2723 8737 -1553 9480 -3979 8597 -5770 8219 -7573 8219 -9122 8537 -10147 9184
--9209 9002 -11110 8690 -11757 8798 -10830 8917 -8588 9630 -5493 10740
--5367 10480 -8666 11959 -12617 14311 -16268 10002 -15156 8884 2369 4196
-3629 2973 -5150 6773 -8174 10473 -9377 10874 -6548 10847 -6980 9964 -19754 6649
--12497 6637 -7073 7290 -3155 8298 342 9015 4840 10628 9052 12977 6778 13188
--3272 11281 -5952 11423 -9606 10695 -12800 8327 -14693 5717 -8059 14135
--7362 15230 -6133 15344 -3531 15171 -763 14844 1423 13467 8168 15836 20127 21473
-27900 23252 41368 19431 -59536 -12156 -420324 -95708 27335 38029 11128 25104
-20938 21590 29938 20767 34759 20115 35393 18906 32565 17186 27316 15249
-20746 13384 13820 11776 7258 10500 1506 9558 -3222 8902 -6876 8473 -9540 8208
--11365 8051 -12512 7970 -13154 7932 -13445 7921 -13484 7924 -13373 7937
--13170 7957 -12915 7980 -12640 8010 -12355 8042 -12078 8077 -11796 8118
--11519 8161 -11258 8209 -11005 8260 -10756 8315 -10507 8373 -10269 8433
--10041 8496 -9813 8560 -9596 8624 -9398 8691 -9203 8760 -9015 8829 -8848 8896
--8688 8962 -8536 9024 -8385 9085 -8262 9145 -8139 9209 -8020 9273 -7984 9334
--7898 9388 -7799 9436 -7708 9484 -7635 9529 -7571 9571 -7530 9612 -7488 9650
--7453 9685 -7414 9720 -7384 9751 -7357 9780 -7342 9806 -7326 9829 -7312 9852
--7298 9873 -7283 9893 -7276 9910 -7270 9925 -7262 9939 -7261 9951 -7258 9964
--7251 9976 -7252 9986 -7244 9993 -7253 10002 -7252 10008 -7250 10016 -7262 10023
--7255 10028 -7259 10034 -7260 10037 -7271 10043 -7278 10046 -7285 10051
--7292 10055 -7299 10058 -7313 10061 -7324 10065 -7337 10068 -7349 10071
--7368 10075 -7385 10078 -7405 10080 -7420 10084 -7435 10087 -7454 10091
--7475 10094 -7499 10097 -7519 10101 -7544 10104 -7562 10109 -7588 10113
--7609 10116 -7629 10122 -7658 10125 -7681 10131
-159: 12890170 -5055788 -9590 9819 -9600 9829 -9620 9836 -9640 9845 -9660 9857
--9690 9865 -9710 9875 -9740 9883 -9770 9893 -9800 9903 -9830 9913 -9860 9922
--9890 9930 -9920 9937 -9950 9945 -9990 9953 -10030 9959 -10050 9965 -10080 9970
--10110 9974 -10140 9979 -10170 9981 -10190 9986 -10220 9987 -10240 9988
--10270 9990 -10290 9992 -10310 9993 -10330 9991 -10360 9992 -10380 9996
--10400 9996 -10420 9998 -10440 10000 -10460 10005 -10480 10006 -10520 10010
--10550 10017 -10580 10022 -10610 10030 -10640 10040 -10680 10048 -10720 10057
--10760 10069 -10820 10080 -10870 10093 -10920 10110 -10970 10122 -11030 10135
--11080 10152 -11140 10165 -11210 10181 -11270 10200 -11330 10216 -11390 10227
--11440 10242 -11500 10257 -11580 10268 -11620 10277 -11680 10288 -11720 10297
--11760 10305 -11810 10310 -11840 10316 -11880 10317 -11910 10318 -11930 10321
--11940 10321 -11960 10318 -11970 10312 -11960 10310 -11950 10304 -11970 10300
--11970 10297 -11960 10292 -11930 10283 -11910 10276 -11910 10272 -11890 10267
--11890 10266 -11870 10265 -11860 10263 -11850 10264 -11840 10267 -11830 10269
--11850 10281 -11860 10289 -11880 10302 -11880 10316 -11910 10332 -11950 10350
--11990 10370 -12020 10391 -12080 10419 -12140 10449 -12200 10477 -12270 10503
--12340 10531 -12410 10567 -12490 10598 -12600 10633 -12680 10667 -12750 10697
--12840 10723 -12920 10753 -13020 10784 -13120 10809 -13200 10835 -13260 10854
--13320 10870 -13390 10883 -13450 10895 -13510 10903 -13540 10907 -13570 10908
--13590 10904 -13590 10893 -13600 10880 -13590 10863 -13570 10840 -13550 10821
--13500 10794 -13450 10760 -13390 10722 -13310 10682 -13240 10642 -13160 10603
--13090 10565 -12990 10521 -12880 10473 -12770 10425 -12660 10379 -12570 10341
--12490 10303 -12380 10264 -12280 10225 -12180 10188 -12090 10159 -12020 10139
--11980 10126 -11920 10110 -11870 10102 -11830 10099 -11820 10105 -11820 10117
--11850 10141 -11880 10172 -11930 10210 -12000 10253 -12080 10305 -12200 10366
--12310 10435 -12460 10513 -12630 10601 -12810 10697 -13000 10798 -13220 10901
--13440 11014 -13680 11135 -13960 11266 -14230 11403 -14530 11539 -14810 11674
--15100 11814 -15400 11963 -15740 12114 -16070 12274 -16400 12425 -16720 12568
--17020 12712 -17350 12859 -17670 13011 -17990 13158 -18300 13295 -18590 13422
--18860 13542 -19130 13662 -19390 13777 -19620 13880 -19830 13979 -20070 14069
--20270 14147 -20420 14211 -20530 14263 -20650 14309 -20830 14344 -20990 14365
--20970 14371 -20830 14358 -20770 14358 -20940 14333 -21250 14246 -21480 14146
--21440 14090 -20980 14065 -20090 14015 -18920 13930 -17770 13822 -17120 13633
--17330 13289 -18850 12760 -22060 12129 -23540 11962 -23860 12224 -23690 12743
--23280 13293 -22590 13591 -21020 12987 -17680 10457 -17680 9838 -15070 8718
--17750 7667 -20400 7715 -17232 9376 -10382 8345 -14594 5618 -14649 6758
--15104 7029 -10212 6635 -10676 5974 -8703 6493 -8189 6871 -11351 3633
--16447 6727 -22325 12648 -6018 10661 -4757 9399 -3972 7892 -18895 6620
--21565 5911 -16639 4835 5950 409 13601 2185 14141 8528 3599 7720 -10302 -1191
--10460 2093 -8249 5950 -8199 7121 -8645 7031 -9823 6744 -9116 6621 -7474 6930
--5299 7268 -5489 7075 -10001 6316 -7384 7637 -2659 8449 366 9412 1961 7994
-610 6491 -7471 4645 -5242 6281 -2264 6124 2780 5153 -2175 8888 -1397 8537
--7519 10235 -6497 9729 -3499 8375 2154 5621 7338 3093 2655 7728 -4274 6945
--8252 6556 -6241 7625 -4585 8672 -3778 7480 -2172 7270 -186 7723 -970 8784
--3066 9979 -5380 10916 -4570 9185 -3891 8944 -3885 8802 -5160 9146 -9419 10256
--10183 9705 -13058 9899 -19056 10254 -20026 8975 -16332 7649 -13354 11284
--13659 11858 -13836 11131 -10378 8124 -8051 7851 -1989 4320 -5726 4763
--6278 5550 -5659 5975 -6470 5566 -5751 6287 -5046 7064 -5109 7241 -6668 6290
--5843 6644 -3352 8050 848 9357 7797 9444 9426 10249 6351 10377 4647 10077
--2258 2043 -1285 2751 2898 5152 5039 7167 5762 7726 3987 2250 1736 2184
--1091 4030 -5083 5694 -5782 5651 -5405 4019 -7671 5778 -10732 7761 -9606 7201
--9161 4594 -7512 7428 -4338 7157 -3093 6329 -7240 6372 -6675 7735 -2705 7552
--629 8534 2016 6112 1660 7982 2194 8433 3217 8601 2136 9835 -4738 13275
--5120 13702 -3378 11635 287 9819 3068 8395 2554 8421 1143 8749 -1096 9957
--4838 10449 -6171 9267 -8129 9551 -10541 11267 -13361 13521 -14492 14500
--14447 14429 -13253 13435 -9952 11205 -8329 8803 -7349 8083 -5755 7531
--4397 7809 -4013 7964 -4498 8020 -6254 8941 -5112 11517 -8189 12449 -5453 9050
--1335 9417 -2267 11539 -3552 11052 -6481 7076 -7941 7507 -8907 8522 -10028 10126
--5319 10268 -2165 10493 -1821 10735 -11157 9864 -11672 8087 -4548 8877
--4496 9139 -6821 8174 -14764 5155 -6340 7378 -3939 8079 -2127 9097 -2594 9246
--3116 9634 -5250 9485 -7692 9277 -9600 9128 -10433 8739 -11604 8448 -11673 8837
--9083 9326 -5956 10112 -4308 10971 -5300 11419 -8762 12424 -13278 13332
--17123 11632 -15844 10409 228 2373 3312 2340 -668 5867 -4975 9887 -12847 9494
--8609 10401 -7313 9922 -14957 7465 -11278 6934 -6994 7087 -3648 7672 -160 8661
-6078 10685 17710 13893 16984 15132 -1482 11700 -7398 12287 -10722 12120
--12876 10078 -13371 6892 -9388 11777 -7343 14922 -5437 16888 -2598 17969
-1111 17380 5456 13317 13078 14534 23693 18486 33153 21643 29773 21487
--91434 -7682 -557941 -129558 -33924 8932 30704 27158 75839 36829 69826 32529
-60324 27499 51863 23241 43549 19671 34892 16677 26059 14228 17529 12307
-9775 10866 3135 9839 -2266 9140 -6425 8687 -9456 8407 -11533 8245 -12873 8158
--13631 8115 -13985 8100 -14066 8099 -13969 8109 -13759 8123 -13492 8142
--13200 8165 -12893 8193 -12595 8221 -12294 8255 -12003 8293 -11716 8333
--11451 8377 -11181 8426 -10919 8475 -10670 8530 -10427 8584 -10186 8641
--9959 8699 -9746 8760 -9544 8820 -9348 8884 -9165 8944 -8994 9004 -8825 9061
--8674 9116 -8530 9172 -8402 9231 -8272 9290 -8230 9348 -8127 9397 -8020 9442
--7922 9487 -7832 9528 -7762 9569 -7714 9607 -7659 9642 -7616 9677 -7573 9710
--7534 9739 -7497 9767 -7479 9792 -7452 9814 -7433 9836 -7414 9857 -7397 9876
--7379 9893 -7368 9907 -7361 9921 -7355 9933 -7347 9946 -7343 9956 -7334 9967
--7326 9975 -7329 9982 -7330 9989 -7327 9997 -7334 10003 -7326 10009 -7331 10014
--7332 10018 -7339 10022 -7346 10027 -7353 10031 -7356 10035 -7363 10038
--7377 10041 -7390 10044 -7394 10047 -7414 10051 -7429 10054 -7449 10057
--7462 10060 -7475 10062 -7489 10066 -7511 10069 -7530 10073 -7553 10076
--7575 10079 -7594 10082 -7613 10087 -7636 10090 -7658 10095 -7679 10099
--7704 10103 -7724 10108
-160: 12921870 -5046929 -9610 9820 -9630 9827 -9640 9837 -9660 9845 -9690 9856
--9700 9864 -9730 9875 -9760 9883 -9790 9892 -9820 9902 -9850 9913 -9880 9922
--9900 9930 -9940 9936 -9960 9944 -10010 9953 -10030 9959 -10070 9965 -10090 9970
--10120 9973 -10150 9981 -10170 9981 -10200 9985 -10230 9989 -10260 9991
--10270 9991 -10290 9994 -10320 9993 -10340 9994 -10360 9995 -10380 9998
--10410 10000 -10420 10001 -10450 10002 -10460 10007 -10490 10008 -10510 10014
--10550 10018 -10570 10028 -10610 10034 -10650 10042 -10670 10050 -10720 10060
--10760 10070 -10810 10083 -10860 10097 -10910 10110 -10970 10125 -11020 10138
--11070 10152 -11130 10166 -11190 10182 -11260 10198 -11320 10215 -11380 10228
--11420 10242 -11490 10255 -11550 10266 -11610 10276 -11660 10286 -11700 10295
--11740 10304 -11780 10308 -11830 10314 -11860 10314 -11880 10315 -11910 10319
--11920 10317 -11940 10316 -11950 10311 -11940 10307 -11950 10302 -11950 10299
--11940 10293 -11940 10289 -11920 10280 -11900 10275 -11890 10270 -11880 10269
--11870 10264 -11870 10263 -11840 10263 -11840 10261 -11830 10265 -11830 10268
--11850 10278 -11850 10288 -11860 10300 -11880 10314 -11910 10330 -11940 10347
--11970 10364 -12020 10386 -12070 10415 -12130 10442 -12190 10469 -12250 10495
--12320 10523 -12390 10556 -12480 10590 -12580 10622 -12650 10654 -12730 10684
--12810 10709 -12900 10738 -12980 10766 -13080 10792 -13170 10814 -13230 10834
--13280 10850 -13350 10862 -13400 10873 -13460 10881 -13490 10884 -13530 10885
--13540 10879 -13550 10867 -13540 10856 -13540 10840 -13520 10818 -13500 10796
--13450 10771 -13410 10738 -13340 10701 -13270 10663 -13200 10623 -13120 10587
--13050 10548 -12950 10506 -12850 10461 -12740 10414 -12640 10370 -12550 10333
--12460 10299 -12370 10262 -12260 10223 -12170 10188 -12090 10162 -12010 10145
--11980 10133 -11920 10121 -11870 10113 -11840 10114 -11820 10120 -11820 10134
--11860 10159 -11890 10191 -11930 10230 -12010 10278 -12080 10329 -12200 10390
--12310 10458 -12450 10538 -12620 10628 -12790 10723 -13000 10823 -13190 10927
--13410 11039 -13650 11160 -13910 11290 -14190 11427 -14460 11561 -14740 11695
--15020 11834 -15320 11982 -15640 12135 -15970 12288 -16280 12440 -16580 12583
--16890 12726 -17190 12872 -17510 13022 -17830 13169 -18120 13304 -18380 13432
--18650 13553 -18920 13671 -19170 13785 -19370 13891 -19590 13993 -19810 14086
--20010 14163 -20140 14229 -20240 14288 -20370 14336 -20540 14377 -20680 14406
--20650 14415 -20510 14410 -20450 14419 -20620 14404 -20910 14332 -21120 14246
--21070 14201 -20660 14184 -19880 14156 -18900 14091 -17970 13973 -17490 13753
--17770 13380 -19070 12888 -21120 12422 -22480 12267 -23060 12459 -23060 12895
--22630 13356 -21670 13517 -19980 12969 -17700 11568 -16630 10712 -15800 9872
--17570 9141 -20070 8762 -19490 8899 -16090 8063 -14353 6906 -14991 7127
--13093 6511 -8792 6543 -9253 6229 -8544 6291 -7524 5505 -8244 4361 -11604 5651
--19649 12363 -11070 10339 -7476 8772 -5679 7560 -14089 6850 -16617 6059
--11678 4332 4198 828 14621 807 17292 10631 -2617 5528 -13774 -1548 -10163 3609
--7968 7853 -9230 7703 -9032 6856 -14276 5780 -11705 5698 -8040 6493 -1319 7258
-5933 6814 -24543 6570 -11499 7266 -2638 7195 349 9767 2500 6801 1933 3126
--5847 7009 -6749 7585 -7110 7287 -3138 7236 2584 8005 3356 9618 -4042 8337
--5886 9621 -3427 7790 -1201 6357 3068 2558 1426 5119 1374 6152 -2691 6814
--5028 7724 -3506 9442 -6838 7051 -4968 7045 -421 7568 -685 8748 -1256 9424
--2060 9666 -7919 11703 -4370 9960 -3578 9444 -4529 9748 -7011 10510 -8344 10460
--11071 10504 -20915 11377 -21132 10441 -12780 8472 -10457 8180 -10741 8799
--8576 7770 -9933 8637 -5229 8836 -1719 5086 -11711 6680 -9930 7017 -6999 7137
--8220 5486 -7083 6475 -5758 7578 -5269 8058 -8441 5949 -6954 6105 -4546 7539
--1388 8866 8888 7515 9679 8701 2648 7693 1240 7494 -967 4030 -1867 4099
-2734 5502 2806 6231 2331 6805 3345 3211 292 3116 -1011 5335 -5541 6866
--3246 4442 -2441 3847 -4674 5410 -10198 8443 -7492 6408 -8439 5330 -7309 7015
--4270 7119 1041 5016 -14514 6998 -9850 8950 -389 7623 5577 6316 6707 4910
-2205 10037 714 9866 2334 8728 3380 8446 -9790 13770 -8559 13626 -4419 11695
-682 9638 4995 8111 6729 7709 6181 7984 4429 9458 -2647 10384 -6960 10241
--9513 10590 -12225 12029 -17067 14368 -18105 15077 -17218 14424 -15176 12772
--11581 10458 -6756 8178 -5093 7185 -4274 6836 -3696 6738 -3165 6727 -3237 7192
--9041 9648 -7540 11650 -5435 11511 616 8536 3711 7722 -20 10397 -950 9550
--6559 10189 -8049 9049 -8229 8458 -11838 10038 -9853 11565 -7228 11487
--6052 11752 -8433 13020 -8094 8044 -4961 8346 -5015 8595 -7612 7769 -11845 5986
--8818 6232 -7794 6148 -7231 6513 2713 11892 782 11614 -2899 10694 -6420 9917
--9318 9277 -11645 8649 -13940 8130 -14573 8130 -3475 10177 -2195 10565
--2616 10873 -4461 11070 -7817 11298 -11959 11286 -15382 10373 -15183 9197
--5258 4573 331 3702 -1835 5982 -8374 9706 -14543 9363 -9508 10342 -8866 9551
--7511 8647 -5792 7764 -4076 7233 -2568 7206 -753 7828 3744 9539 23001 13542
-19036 14800 4631 13561 -5037 14487 -9385 14638 -11207 13294 -11826 6811
--9680 9938 -7637 13897 -5423 17219 -2285 19643 1881 20002 6182 11583 12662 12834
-18807 15170 20830 15831 16307 18481 -40489 2304 -378719 -79530 -159154 -22452
--39528 9625 30469 26541 53257 29678 57279 27610 54095 24134 47459 20585
-38951 17427 29631 14811 20394 12761 11909 11235 4601 10151 -1350 9414
--5955 8935 -9333 8639 -11663 8464 -13180 8365 -14055 8315 -14494 8291
--14612 8284 -14530 8288 -14325 8296 -14053 8308 -13745 8325 -13419 8345
--13097 8368 -12782 8394 -12470 8425 -12164 8458 -11874 8496 -11593 8535
--11317 8580 -11056 8625 -10796 8674 -10543 8723 -10304 8774 -10077 8827
--9869 8883 -9657 8938 -9466 8994 -9285 9047 -9110 9099 -8944 9149 -8791 9200
--8649 9254 -8509 9309 -8461 9363 -8354 9407 -8234 9451 -8120 9490 -8029 9530
--7945 9568 -7885 9603 -7825 9638 -7775 9670 -7722 9700 -7676 9729 -7638 9755
--7607 9779 -7576 9801 -7551 9822 -7528 9842 -7500 9860 -7483 9876 -7469 9891
--7457 9903 -7443 9916 -7435 9928 -7424 9940 -7414 9948 -7406 9956 -7404 9965
--7406 9971 -7403 9978 -7404 9985 -7395 9990 -7399 9995 -7403 9999 -7404 10004
--7407 10008 -7414 10012 -7421 10015 -7424 10019 -7443 10022 -7449 10025
--7454 10028 -7473 10031 -7487 10034 -7503 10037 -7519 10040 -7527 10043
--7545 10046 -7562 10049 -7582 10052 -7605 10056 -7624 10058 -7641 10062
--7664 10066 -7686 10070 -7703 10074 -7724 10077 -7745 10083 -7766 10086
-161: 12953590 -5038076 -9630 9821 -9650 9827 -9660 9838 -9690 9846 -9700 9854
--9730 9863 -9750 9875 -9780 9882 -9800 9892 -9830 9902 -9870 9911 -9890 9923
--9920 9929 -9960 9935 -9980 9944 -10020 9951 -10050 9959 -10070 9966 -10100 9970
--10130 9973 -10160 9981 -10190 9982 -10200 9984 -10240 9989 -10260 9992
--10280 9995 -10310 9994 -10320 9995 -10340 9997 -10360 9998 -10390 9999
--10410 10000 -10420 10004 -10450 10006 -10470 10007 -10490 10013 -10520 10016
--10550 10022 -10560 10028 -10610 10037 -10640 10044 -10680 10053 -10710 10062
--10750 10075 -10810 10085 -10850 10097 -10910 10112 -10960 10126 -11020 10140
--11050 10153 -11120 10167 -11180 10182 -11250 10198 -11300 10214 -11360 10228
--11420 10240 -11460 10252 -11530 10265 -11600 10275 -11640 10286 -11680 10293
--11720 10302 -11760 10306 -11810 10309 -11830 10314 -11860 10313 -11890 10315
--11910 10314 -11910 10314 -11920 10307 -11940 10304 -11930 10300 -11920 10296
--11930 10292 -11930 10287 -11900 10279 -11880 10273 -11870 10266 -11870 10267
--11860 10264 -11850 10262 -11840 10262 -11820 10260 -11830 10263 -11820 10268
--11840 10277 -11840 10284 -11860 10297 -11870 10312 -11890 10328 -11940 10343
--11960 10359 -12010 10385 -12070 10409 -12120 10436 -12170 10462 -12240 10488
--12310 10515 -12370 10547 -12460 10581 -12550 10612 -12630 10641 -12710 10669
--12780 10695 -12870 10723 -12960 10750 -13040 10773 -13120 10797 -13200 10814
--13240 10830 -13310 10841 -13360 10851 -13410 10860 -13450 10860 -13470 10861
--13500 10855 -13500 10845 -13500 10834 -13490 10817 -13470 10794 -13450 10774
--13410 10748 -13360 10716 -13300 10681 -13220 10642 -13160 10604 -13080 10569
--13010 10534 -12920 10493 -12820 10448 -12710 10401 -12610 10361 -12530 10325
--12440 10295 -12350 10257 -12250 10221 -12160 10190 -12080 10166 -12010 10149
--11970 10140 -11920 10128 -11870 10124 -11840 10125 -11830 10134 -11830 10151
--11860 10177 -11890 10209 -11940 10249 -12010 10296 -12090 10350 -12190 10413
--12310 10482 -12450 10561 -12600 10651 -12780 10746 -12970 10846 -13180 10950
--13380 11061 -13610 11181 -13860 11312 -14130 11446 -14400 11581 -14680 11715
--14940 11850 -15240 11998 -15540 12149 -15860 12303 -16160 12450 -16460 12593
--16750 12735 -17040 12880 -17350 13029 -17650 13173 -17940 13309 -18200 13437
--18450 13556 -18710 13679 -18940 13790 -19140 13897 -19350 13996 -19560 14091
--19740 14172 -19880 14239 -19960 14300 -20100 14352 -20260 14396 -20380 14428
--20350 14443 -20220 14444 -20160 14456 -20300 14448 -20560 14389 -20760 14312
--20730 14269 -20400 14258 -19790 14241 -19010 14186 -18300 14061 -17920 13820
--18170 13439 -19090 12985 -20420 12578 -21520 12385 -22130 12455 -22220 12733
--21780 13018 -20770 13073 -19280 12701 -17620 11927 -16610 11241 -16380 10598
--17520 9998 -19070 9485 -19080 9089 -17310 8398 -15500 7692 -14690 7434
--12740 6994 -10200 6867 -9874 6642 -9191 6838 -7254 5345 -5955 6434 -9531 8248
--13532 9151 -10836 7973 -7113 6885 -8790 8350 -11479 7216 -12311 6822
--10032 5901 1497 4107 15510 4606 19117 9780 -12556 3276 -17382 -242 -10994 1010
--7781 8825 -12654 7145 -12720 5991 -13951 4608 -11342 4748 -9347 5806
--2283 6683 6878 11002 -21388 4871 -11341 4798 -516 3771 243 10014 1086 8830
-1504 3351 -4120 5624 -8002 7231 -10672 8134 -9212 8540 6498 4546 6316 6082
-1783 9596 -3839 11556 -1165 6626 975 5019 -2211 4256 1135 5457 12856 6167
--4831 7053 -10894 8074 -4970 8009 -8693 6932 -5062 7274 -937 7948 -1750 9371
--1808 9881 -2730 10261 -5741 11269 -4538 10494 -3912 10068 -4535 10270
--6239 10811 -8186 11113 -11434 11428 -17015 11932 -16881 11398 -11575 9696
--10129 5555 -12861 7551 -11687 7478 -6118 5870 -4575 10556 -6127 5789
--11726 6272 -10879 6800 -10039 6522 -5256 6254 -6978 7025 -6733 7530 -6900 7724
--7875 6343 -5622 5289 -2827 6106 -327 7031 3331 5457 3714 6522 386 6638
--60 6703 1610 5991 -706 6060 1709 5511 1132 4163 2042 5608 1347 5275 -2815 6001
--2486 6882 -7138 7763 -2500 4962 1765 3027 2052 3406 -6787 8165 -7473 7984
--10280 7235 -8264 8167 -2148 7550 2293 5534 -29738 9260 -12735 11734 5244 8090
-14793 5500 12621 5476 1236 9168 -5051 10303 -4893 9641 -2870 8777 -7851 11174
--6863 11544 -2758 10482 2944 8896 8805 7508 12670 6915 13454 7159 9657 8486
--2985 10697 -8905 11230 -11012 11486 -12694 12222 -20222 14997 -19835 14945
--17948 13662 -15606 11723 -12283 9477 -4251 7550 -3347 6778 -4164 6571
--4491 6325 -4796 6376 -5405 7225 -7695 9117 -4496 10628 -1125 10435 2865 8800
-4247 8237 1587 9517 -988 9868 -3294 10713 -7970 10451 -10748 10453 -9677 9240
--10846 10467 -10335 10626 -7551 10041 -4014 13462 -5389 10402 -5167 9612
--5469 9358 -7417 8584 -9485 7205 -8193 6405 -7023 6401 -5022 7609 693 10961
-134 11291 -2762 10740 -6000 10092 -8745 9455 -10920 8910 -12268 8520 -11193 8572
--4659 9692 -2605 10097 -2624 10249 -3990 10138 -6667 9648 -10146 8986
--13549 8359 -17786 9266 -10001 6842 -1585 6052 -3689 8360 -8249 9931 -12497 9627
--11941 9416 -11354 8605 -1045 9420 -198 8345 3 7311 1014 6807 3501 7127
-8812 8663 18336 11736 14490 14037 4595 14485 -3505 14885 -7783 14457 -9342 12635
--9601 9251 -8903 10368 -7712 13239 -6021 16141 -3172 17975 865 17651 5578 13946
-11131 15082 15095 16347 15602 15265 16819 16006 -34990 8730 -217395 -46217
--173980 -25507 -97481 -2453 -28768 13878 14542 21459 37025 23304 45503 22207
-45107 19900 39487 17329 31224 14971 22138 13023 13406 11528 5716 10442
--631 9695 -5576 9200 -9237 8889 -11789 8699 -13461 8589 -14451 8527 -14961 8494
--15123 8478 -15064 8472 -14864 8473 -14582 8478 -14266 8488 -13926 8499
--13582 8515 -13243 8535 -12915 8557 -12593 8583 -12286 8614 -11985 8646
--11701 8682 -11419 8722 -11143 8762 -10880 8804 -10636 8849 -10390 8896
--10172 8945 -9950 8994 -9751 9043 -9558 9091 -9379 9137 -9201 9183 -9034 9230
--8884 9278 -8735 9329 -8683 9378 -8564 9420 -8436 9459 -8314 9496 -8210 9533
--8121 9568 -8050 9601 -7983 9634 -7929 9664 -7868 9693 -7812 9720 -7769 9745
--7731 9768 -7695 9788 -7663 9809 -7637 9827 -7606 9846 -7582 9861 -7563 9875
--7547 9887 -7532 9900 -7519 9911 -7505 9923 -7494 9931 -7481 9939 -7477 9947
--7480 9954 -7472 9960 -7467 9968 -7465 9972 -7467 9977 -7465 9981 -7468 9986
--7470 9990 -7473 9994 -7483 9998 -7489 10000 -7496 10004 -7505 10006 -7512 10010
--7530 10013 -7542 10016 -7556 10018 -7569 10021 -7581 10024 -7597 10027
--7614 10030 -7631 10033 -7653 10037 -7670 10039 -7685 10043 -7708 10046
--7729 10050 -7749 10054 -7766 10059 -7787 10062 -7805 10067
-162: 12985350 -5029228 -9650 9821 -9670 9827 -9690 9838 -9710 9845 -9720 9856
--9750 9864 -9770 9873 -9790 9882 -9820 9891 -9850 9901 -9880 9910 -9920 9921
--9940 9930 -9970 9935 -9990 9943 -10030 9951 -10060 9958 -10090 9965 -10110 9970
--10140 9975 -10170 9980 -10190 9983 -10220 9986 -10240 9988 -10270 9993
--10290 9995 -10310 9996 -10330 9995 -10340 9999 -10370 9999 -10390 10000
--10410 10003 -10430 10005 -10450 10008 -10470 10011 -10490 10015 -10520 10018
--10550 10025 -10570 10029 -10610 10039 -10630 10047 -10680 10056 -10710 10065
--10750 10075 -10790 10088 -10850 10099 -10910 10113 -10950 10126 -11000 10139
--11040 10155 -11110 10169 -11170 10183 -11230 10198 -11290 10212 -11350 10227
--11400 10239 -11450 10249 -11520 10264 -11570 10273 -11620 10283 -11660 10291
--11700 10298 -11740 10304 -11790 10308 -11810 10309 -11840 10313 -11860 10311
--11880 10313 -11900 10310 -11910 10305 -11910 10303 -11900 10296 -11910 10294
--11910 10289 -11910 10286 -11880 10277 -11870 10271 -11850 10266 -11850 10265
--11860 10263 -11840 10262 -11820 10259 -11810 10258 -11820 10261 -11820 10269
--11830 10274 -11840 10282 -11840 10296 -11870 10308 -11880 10324 -11930 10340
--11950 10359 -12000 10380 -12050 10404 -12110 10431 -12170 10456 -12220 10482
--12290 10507 -12360 10537 -12440 10569 -12530 10603 -12610 10631 -12680 10655
--12760 10681 -12840 10707 -12920 10733 -13010 10758 -13090 10779 -13150 10794
--13210 10810 -13270 10822 -13320 10830 -13350 10837 -13410 10838 -13430 10838
--13440 10833 -13460 10824 -13450 10811 -13440 10793 -13430 10772 -13400 10750
--13370 10726 -13310 10695 -13260 10661 -13190 10623 -13110 10586 -13040 10552
--12980 10518 -12880 10478 -12790 10435 -12690 10391 -12580 10351 -12500 10318
--12430 10287 -12330 10253 -12240 10220 -12150 10190 -12070 10168 -12010 10153
--11960 10144 -11920 10138 -11870 10132 -11840 10135 -11830 10147 -11840 10166
--11860 10191 -11900 10226 -11940 10266 -12010 10314 -12090 10370 -12190 10433
--12310 10502 -12430 10583 -12600 10671 -12760 10766 -12950 10868 -13140 10970
--13350 11081 -13570 11201 -13820 11329 -14080 11463 -14340 11599 -14600 11729
--14870 11864 -15150 12010 -15450 12160 -15750 12312 -16040 12458 -16330 12599
--16610 12738 -16910 12884 -17190 13030 -17480 13173 -17760 13309 -18020 13435
--18250 13553 -18500 13678 -18710 13791 -18920 13894 -19110 13994 -19320 14089
--19500 14169 -19620 14239 -19700 14299 -19830 14353 -19980 14401 -20100 14435
--20070 14450 -19950 14455 -19880 14470 -20000 14468 -20220 14414 -20400 14345
--20400 14298 -20180 14284 -19720 14271 -19140 14221 -18600 14096 -18320 13846
--18440 13479 -19030 13050 -19890 12651 -20710 12396 -21270 12347 -21370 12443
--20930 12551 -20020 12534 -18800 12303 -17540 11872 -16730 11411 -16540 10943
--17160 10455 -17980 9947 -18050 9426 -17140 8829 -15820 8281 -14650 7957
--13060 7733 -11500 7733 -10910 7958 -10340 8508 -9090 8216 -5840 4478
--10110 8860 -10000 7613 -7531 7489 -7142 7134 -7710 8240 -9021 6711 -9339 7635
--12517 7801 -5917 6511 7713 5395 7598 8196 -9310 5350 -14819 3339 -9510 1449
--9901 5803 -11971 5834 -13117 5190 -12507 3144 -10612 5698 -7272 5347
--1897 5752 1211 7468 -10310 4644 -7219 3975 -1036 4239 835 7547 1513 7385
-985 4807 -2897 5361 -6885 6466 -8993 7186 -6599 6883 2514 4242 4549 3715
-6360 9882 -1490 11941 -6543 7844 5535 4572 -4531 6189 6469 6990 58806 7047
--46119 6252 -29488 8371 -9635 6782 -6469 6763 -2986 8148 -1041 9062 -1564 9953
--2087 10325 -2952 10538 -4393 10830 -4322 10521 -4172 10370 -4705 10613
--6079 11091 -8081 11508 -10827 11852 -13836 12036 -13925 11472 -11504 9701
--10596 6268 -12134 6556 -11773 6723 -8410 6417 -5847 8518 -7464 6630 -11183 6427
--8736 7108 -9379 6533 -6082 6114 -8723 7269 -7571 6976 -8100 7155 -8556 5844
--4191 4220 -1890 4485 -2305 5495 577 4264 -434 6424 16 7686 1238 6225 -1892 7992
--1853 6621 -346 4553 261 2532 2577 5104 2599 4292 -14658 12996 -8946 10585
--6016 8362 -1136 5441 4728 2510 9637 593 -4262 8228 -2226 6884 -15979 10951
--14272 11423 -11206 11132 -12321 10483 -24347 11749 -8613 10976 17693 5743
-29663 3107 22231 4337 -2614 8495 -14128 10895 -14044 10688 -7150 7802
--6705 8555 -4271 9132 -599 8947 5159 8037 12512 6926 17819 6365 19524 6497
-15542 7530 -5652 11513 -11328 12155 -13254 12347 -14978 12844 -18333 14035
--17073 13430 -15080 12126 -12318 10302 -7938 7938 -5289 7418 -3977 6886
--5276 6804 -5521 6288 -6290 6242 -6623 7201 -7224 8475 -236 9839 2399 9785
-4031 8957 4285 8632 2635 9228 545 9823 -1707 10537 -5446 10720 -8438 10567
--9587 9817 -11649 10347 -11929 10856 -5312 9869 -2399 11787 -5315 10650
--5673 10768 -5338 10716 -6759 10132 -7907 8759 -6197 7105 -5026 7251 -3362 8620
--683 10516 -1691 10309 -3707 10170 -6134 9990 -7931 9587 -9231 9325 -9684 9108
--8688 8870 -5561 9296 -4395 9455 -3870 9630 -4306 9519 -6316 8505 -9365 7494
--11445 6456 -22971 10753 -13115 8782 -1292 8743 -1739 9858 -5388 10449
--8823 9791 -9452 9133 -7707 8624 -1267 8799 1106 8041 2208 6988 3996 6257
-7294 6240 11948 7278 15305 9726 8346 13330 1270 14384 -4106 14230 -7017 13292
--7657 11731 -7014 10246 -7665 10794 -7565 12596 -7051 14689 -4813 15715
--971 15398 4030 14859 9820 18408 13490 19983 13431 16963 2440 -6034 -32750 -22306
--94931 11950 -158448 -7182 -135885 -5082 -76395 5364 -21159 13969 15877 18380
-34992 19430 40895 18524 38493 16766 31641 14848 23007 13126 14272 11738
-6387 10698 -203 9964 -5387 9469 -9246 9147 -11967 8945 -13755 8823 -14839 8748
--15400 8704 -15603 8677 -15564 8661 -15365 8654 -15083 8650 -14753 8651
--14403 8655 -14044 8662 -13679 8674 -13338 8689 -12999 8708 -12668 8730
--12359 8756 -12052 8784 -11758 8816 -11474 8851 -11200 8885 -10943 8924
--10687 8964 -10452 9006 -10233 9049 -10017 9093 -9818 9135 -9628 9177
--9441 9217 -9260 9259 -9095 9303 -8949 9349 -8889 9395 -8764 9432 -8631 9469
--8493 9503 -8385 9537 -8288 9569 -8211 9601 -8138 9631 -8071 9660 -8003 9687
--7944 9712 -7892 9735 -7847 9758 -7807 9777 -7772 9797 -7739 9814 -7710 9832
--7679 9847 -7651 9860 -7632 9873 -7616 9884 -7602 9896 -7584 9906 -7570 9915
--7556 9923 -7550 9930 -7549 9938 -7538 9943 -7530 9951 -7530 9955 -7529 9960
--7527 9965 -7528 9968 -7530 9973 -7534 9977 -7541 9980 -7544 9984 -7552 9986
--7559 9989 -7568 9993 -7580 9995 -7590 9998 -7607 10001 -7623 10004 -7634 10006
--7645 10009 -7659 10012 -7678 10015 -7699 10019 -7712 10021 -7734 10024
--7750 10029 -7767 10032 -7788 10035 -7810 10040 -7825 10044 -7844 10048
-163: 13017130 -5020386 -9670 9822 -9690 9828 -9700 9838 -9730 9845 -9750 9855
--9770 9866 -9790 9872 -9810 9881 -9830 9891 -9870 9900 -9900 9908 -9930 9921
--9950 9927 -9990 9937 -10010 9942 -10040 9951 -10070 9959 -10100 9964
--10130 9969 -10150 9974 -10170 9980 -10200 9983 -10220 9986 -10250 9990
--10280 9993 -10300 9994 -10320 9997 -10330 9998 -10350 9999 -10370 10001
--10400 10002 -10410 10004 -10430 10007 -10450 10009 -10470 10015 -10500 10015
--10520 10020 -10540 10028 -10580 10032 -10600 10039 -10640 10049 -10670 10058
--10700 10068 -10750 10076 -10790 10088 -10850 10101 -10890 10113 -10940 10128
--10990 10140 -11040 10155 -11100 10167 -11150 10184 -11220 10199 -11280 10212
--11330 10224 -11380 10238 -11440 10248 -11500 10260 -11550 10272 -11600 10280
--11640 10289 -11680 10296 -11720 10301 -11760 10305 -11790 10307 -11820 10309
--11840 10309 -11860 10311 -11880 10307 -11880 10303 -11890 10300 -11890 10295
--11890 10292 -11890 10286 -11880 10280 -11870 10277 -11850 10271 -11840 10264
--11840 10263 -11840 10262 -11830 10260 -11810 10259 -11800 10256 -11820 10260
--11800 10268 -11820 10271 -11830 10282 -11830 10292 -11860 10307 -11880 10321
--11920 10337 -11940 10355 -11990 10377 -12040 10400 -12100 10426 -12150 10451
--12210 10476 -12270 10500 -12350 10529 -12420 10559 -12510 10590 -12580 10618
--12660 10645 -12730 10666 -12810 10692 -12900 10719 -12970 10741 -13050 10762
--13120 10775 -13160 10790 -13230 10803 -13280 10810 -13310 10814 -13360 10817
--13390 10817 -13400 10811 -13400 10802 -13400 10788 -13410 10770 -13380 10749
--13350 10729 -13320 10705 -13270 10675 -13220 10641 -13150 10604 -13070 10568
--13010 10535 -12930 10503 -12860 10462 -12750 10423 -12660 10380 -12560 10341
--12480 10310 -12400 10280 -12330 10250 -12230 10218 -12130 10189 -12060 10168
--12000 10156 -11960 10149 -11910 10143 -11880 10140 -11840 10146 -11830 10158
--11840 10179 -11870 10205 -11900 10240 -11940 10281 -12010 10332 -12090 10387
--12190 10451 -12300 10520 -12430 10602 -12580 10689 -12750 10784 -12920 10886
--13120 10988 -13310 11098 -13530 11217 -13780 11343 -14020 11478 -14280 11613
--14530 11741 -14790 11875 -15060 12018 -15350 12166 -15640 12318 -15930 12463
--16200 12599 -16480 12739 -16760 12882 -17040 13028 -17320 13170 -17580 13303
--17830 13427 -18060 13545 -18290 13669 -18500 13781 -18700 13884 -18890 13983
--19080 14074 -19260 14156 -19370 14229 -19450 14287 -19570 14341 -19710 14389
--19830 14425 -19810 14439 -19700 14445 -19630 14460 -19710 14460 -19890 14413
--20050 14345 -20090 14292 -19930 14267 -19640 14250 -19220 14202 -18820 14080
--18600 13838 -18620 13496 -18930 13084 -19470 12682 -20090 12379 -20530 12217
--20580 12145 -20170 12104 -19430 12032 -18470 11869 -17480 11610 -16730 11308
--16450 10989 -16640 10617 -16980 10178 -16980 9684 -16460 9174 -15580 8739
--14570 8474 -13420 8358 -12340 8408 -11660 8675 -10900 8921 -9550 8351
--7590 6516 -8550 8179 -7830 8046 -7160 8158 -6780 8671 -8620 8989 -9330 7176
--10117 8313 -11493 7742 -8872 6933 -4016 4929 -2417 8291 -7251 6467 -7426 4148
--10285 3978 -11538 5210 -12154 5200 -11915 5082 -12015 4767 -10658 5365
--5292 3323 -689 3209 775 4083 -3259 3520 -2742 3516 8 4215 1712 5874 2531 6107
-1945 5231 -1016 5352 -4790 5943 -6421 6539 -4367 6940 598 7298 2753 8604
-3914 3746 -9036 12343 -23064 8198 11466 2749 5951 6700 9327 7385 16650 6157
--40071 5367 -10681 8433 -3675 7482 -3661 7221 -912 9536 -1002 10185 -1743 10512
--2409 10539 -3069 10486 -3984 10456 -4408 10356 -4454 10470 -4764 10807
--5810 11243 -7547 11601 -9688 11792 -11558 11730 -11930 11230 -10902 10033
--9750 6630 -10977 6588 -12031 6915 -11097 6954 -5797 7572 -6212 6902 -8539 6615
--9781 8182 -13529 7167 -12411 6785 -5647 6987 -5788 6256 -7326 5886 -9316 4341
--6591 3684 -4850 3395 -4636 6750 303 3624 -3888 8871 -3329 9091 -997 7354
--1967 7377 -2335 6390 -2253 5077 -3013 4611 -4407 6799 -8678 8709 -17035 12953
--6919 9643 -3710 7943 -2980 6954 -2160 6003 523 4978 5325 4599 1963 5332
--8755 9534 -14215 12402 -18097 13903 -21976 14245 -23589 14001 -5022 10723
-36056 1451 48632 -1034 35424 1700 -9937 7925 -23064 11445 -21315 11766
--8183 5776 -7204 6838 -2607 7489 -196 8069 4910 7750 14338 6815 19640 6501
-19453 7005 12919 8377 -1660 10908 -9066 11766 -12439 12082 -14414 12455
--15458 12684 -11814 11203 -10621 10320 -8707 9164 -3217 6274 -6919 7907
--5561 7757 -4612 6883 -4292 6341 -4762 6370 -6077 7170 -7964 7932 3366 9426
-3180 9295 3320 8841 3486 8670 2951 8985 1974 9502 503 10125 -2030 10530
--4949 10323 -7643 9713 -10461 9707 -12109 10031 -5937 10190 -4393 10792
--5311 10769 -5128 11849 -4661 12074 -5952 11758 -7140 10373 -4387 7592
--3908 8077 -3164 9412 -1316 10722 -3229 9286 -4252 9635 -6267 10022 -6950 9687
--7427 9786 -7283 9819 -7088 8976 -5852 9174 -6716 8955 -5777 9427 -5377 9991
--7696 8690 -12396 8578 -14454 7886 -19895 10070 -6634 8659 246 9349 202 10719
--2332 11154 -5132 9779 -5967 8913 -4649 8537 -1341 8335 871 7697 2408 6617
-4785 5779 8513 5514 12750 5973 14209 7625 2047 12966 -2411 13642 -5259 12859
--6824 11605 -6585 10496 -3976 10217 -6337 10759 -7027 11824 -8354 13574
--6775 13924 -3118 13352 1837 13549 8096 20006 10766 20528 9984 17912 4913 11499
-3919 12764 -27043 4326 -183616 -21356 -175347 -14145 -107069 -1092 -39947 9309
-5983 15236 30465 17484 39212 17434 38144 16244 31817 14682 23325 13172
-14551 11902 6556 10926 -161 10220 -5470 9731 -9434 9405 -12242 9195 -14105 9060
--15232 8973 -15833 8917 -16058 8879 -16026 8853 -15840 8835 -15549 8823
--15208 8814 -14841 8809 -14469 8809 -14088 8812 -13730 8819 -13373 8831
--13030 8844 -12706 8863 -12380 8885 -12071 8909 -11778 8937 -11495 8965
--11225 8997 -10965 9031 -10714 9066 -10488 9105 -10270 9141 -10052 9180
--9857 9215 -9662 9252 -9478 9289 -9301 9328 -9137 9371 -9083 9410 -8954 9447
--8805 9478 -8663 9511 -8548 9542 -8444 9572 -8358 9601 -8282 9629 -8204 9657
--8135 9681 -8069 9706 -8009 9727 -7963 9748 -7918 9767 -7876 9786 -7834 9802
--7804 9819 -7770 9834 -7741 9846 -7716 9859 -7693 9870 -7677 9881 -7660 9890
--7644 9900 -7631 9908 -7622 9914 -7609 9922 -7604 9928 -7594 9934 -7592 9939
--7590 9944 -7584 9949 -7582 9952 -7588 9957 -7590 9960 -7598 9964 -7600 9967
--7606 9970 -7611 9973 -7620 9976 -7629 9979 -7639 9981 -7654 9984 -7669 9987
--7682 9990 -7692 9992 -7705 9996 -7725 9998 -7738 10001 -7759 10004 -7772 10008
--7792 10011 -7806 10015 -7827 10018 -7845 10023 -7860 10026 -7879 10031
-164: 13048950 -5011549 -9700 9822 -9710 9829 -9720 9837 -9750 9846 -9770 9855
--9790 9866 -9800 9872 -9830 9881 -9850 9889 -9890 9900 -9910 9908 -9950 9919
--9970 9927 -9990 9937 -10030 9943 -10050 9950 -10080 9957 -10110 9965
--10150 9968 -10150 9973 -10180 9978 -10210 9982 -10240 9988 -10260 9990
--10280 9992 -10300 9995 -10330 9997 -10340 10000 -10350 9999 -10370 10001
--10400 10005 -10420 10006 -10430 10009 -10450 10012 -10480 10014 -10490 10017
--10520 10023 -10540 10028 -10580 10035 -10610 10041 -10630 10051 -10670 10060
--10700 10068 -10740 10077 -10790 10089 -10840 10101 -10880 10114 -10940 10130
--10980 10141 -11030 10154 -11080 10167 -11150 10184 -11200 10198 -11260 10210
--11320 10223 -11370 10235 -11420 10247 -11480 10259 -11520 10269 -11580 10278
--11620 10288 -11670 10293 -11700 10297 -11740 10301 -11770 10304 -11800 10306
--11820 10307 -11830 10308 -11860 10306 -11860 10301 -11860 10296 -11870 10293
--11870 10290 -11880 10281 -11860 10280 -11860 10276 -11830 10268 -11830 10263
--11820 10262 -11830 10261 -11810 10258 -11800 10257 -11790 10256 -11800 10260
--11800 10266 -11810 10269 -11810 10281 -11830 10289 -11850 10305 -11870 10322
--11910 10334 -11930 10351 -11990 10374 -12030 10395 -12080 10423 -12130 10443
--12200 10468 -12260 10493 -12330 10522 -12400 10550 -12490 10579 -12560 10606
--12630 10632 -12700 10654 -12780 10677 -12870 10703 -12940 10725 -13020 10745
--13070 10760 -13130 10770 -13180 10783 -13240 10791 -13280 10795 -13310 10795
--13340 10796 -13350 10789 -13360 10779 -13360 10765 -13350 10748 -13340 10728
--13310 10708 -13270 10685 -13240 10654 -13170 10620 -13100 10587 -13040 10550
--12970 10520 -12900 10487 -12830 10447 -12720 10409 -12630 10370 -12540 10331
--12460 10303 -12380 10274 -12310 10244 -12210 10215 -12130 10187 -12050 10170
--12000 10157 -11950 10152 -11920 10148 -11870 10147 -11840 10152 -11830 10168
--11840 10189 -11870 10219 -11900 10254 -11940 10295 -12010 10346 -12090 10404
--12180 10466 -12290 10536 -12420 10618 -12570 10706 -12730 10801 -12900 10900
--13090 11002 -13280 11113 -13490 11231 -13720 11356 -13970 11488 -14210 11622
--14460 11750 -14710 11884 -14970 12023 -15260 12170 -15530 12317 -15820 12464
--16080 12597 -16340 12735 -16610 12877 -16890 13021 -17150 13160 -17410 13291
--17650 13415 -17870 13531 -18090 13651 -18300 13763 -18480 13863 -18680 13962
--18850 14053 -19030 14133 -19120 14204 -19220 14263 -19310 14316 -19450 14364
--19570 14398 -19570 14412 -19470 14415 -19400 14428 -19430 14427 -19580 14384
--19720 14316 -19760 14254 -19690 14215 -19490 14186 -19220 14135 -18950 14017
--18750 13800 -18700 13477 -18840 13084 -19180 12699 -19600 12363 -19890 12100
--19870 11900 -19560 11755 -19000 11625 -18230 11457 -17390 11251 -16670 11043
--16220 10832 -16130 10566 -16150 10219 -16040 9800 -15660 9380 -15100 9036
--14410 8822 -13630 8715 -12850 8743 -12160 8918 -11300 8942 -10030 8457
--8620 7696 -8220 8221 -7620 8408 -7350 8658 -7520 9063 -8710 9147 -9450 8450
--10160 8899 -10840 8956 -10330 8816 -11400 5675 -11117 7626 -9274 6889
--4352 5079 -8189 5144 -12151 5516 -12177 5482 -10722 4644 -12786 5642
--10657 5496 -2476 559 1849 574 3001 1755 1339 2454 642 3087 1331 3906 2558 4933
-3873 5409 4011 5365 1650 5504 -2906 5760 -4579 6231 -3000 7174 -840 9314
--4693 13375 -5119 789 -41656 19882 -28300 6661 29160 168 23742 3604 11677 6704
-2163 5537 -20642 5876 -9172 7739 -3690 8009 -3612 8356 -3064 9789 -3137 10548
--2999 10676 -3189 10398 -3401 10184 -4243 10059 -5148 10114 -4929 10524
--4570 10931 -5130 11267 -6551 11443 -8250 11359 -9590 10938 -10115 10135
--9697 9063 -7429 8058 -9010 7822 -11541 7997 -14325 7643 -4272 7734 -5498 7795
--8432 7758 -10712 8122 -15784 7732 -18851 7570 180 7588 -1374 6737 -10843 4390
--13799 3020 -10562 4958 -9602 6016 -9127 8488 -1106 4638 -4824 7641 -6605 9114
--2115 7046 -1917 6592 -2810 6257 -3699 5853 -6203 6592 -10409 9010 -16616 11655
--21230 13167 -967 6814 -1516 7105 -6009 8537 -10918 9894 -11387 10071
-14571 1992 6547 3647 -750 7967 -11104 12206 -21060 14916 -26296 15634
--24046 14947 -6761 11473 56047 -4051 60416 -5137 36471 -964 -10089 7063
--21469 10033 -13602 8767 -13823 7153 -12243 8129 -2380 7361 -3018 8442
-129 8431 14585 7113 19130 6958 16888 7776 9953 9136 146 10532 -5936 10646
--9345 10735 -11207 11012 -12144 11124 -5081 8535 -6652 8543 -6587 8035
--4561 6979 -5789 8067 -4786 8506 -2430 6929 -1432 6617 -509 6879 795 7835
-2483 8666 -5677 8334 -2886 8510 -231 8465 1508 8454 2514 8660 3058 9050
-3011 9617 1789 10343 -913 9979 -4258 9056 -6424 8643 -8128 8934 -11341 10058
--10037 10662 -7544 11082 -4382 11999 -2247 12510 -4575 12239 -4524 10700
--6052 8868 -5516 9156 -5689 9628 -3206 10096 -2011 9558 -2342 9838 -5755 10558
--5960 9755 -6147 10154 -5391 10609 -6149 8907 -5277 9484 -9130 8698 -7553 9531
--6449 11708 -11064 9938 -11191 9596 -10603 8494 -11355 9468 -4743 8100
-1136 9284 1118 11467 -21 12361 -2388 9385 -3048 8619 -2347 8567 -1267 8234
-122 7802 926 6515 3072 5718 6349 5610 9230 6144 8819 7792 1679 11000 -2509 11753
--4788 10834 -6236 9542 -6711 8864 -2497 10068 -4201 10453 -5609 10918
--9682 13100 -8311 13071 -4548 12747 787 13768 5867 17334 8286 17788 8432 16309
-8464 18946 10524 15874 -9370 -2023 -234413 -19396 -200157 -12736 -105773 161
--30691 9938 14210 15277 35633 17239 41830 17155 39166 16058 31971 14627
-23067 13233 14129 12052 6096 11132 -620 10457 -5913 9981 -9865 9657 -12672 9441
--14525 9295 -15664 9198 -16275 9130 -16495 9081 -16464 9043 -16274 9015
--15976 8993 -15623 8974 -15246 8962 -14851 8952 -14465 8948 -14086 8946
--13714 8950 -13356 8957 -13017 8967 -12682 8983 -12363 9000 -12055 9021
--11762 9043 -11482 9068 -11211 9095 -10963 9126 -10721 9158 -10495 9191
--10272 9222 -10068 9254 -9868 9286 -9674 9318 -9486 9354 -9316 9391 -9257 9428
--9125 9460 -8966 9490 -8823 9519 -8698 9547 -8591 9575 -8499 9603 -8413 9628
--8331 9654 -8259 9677 -8186 9699 -8123 9721 -8069 9739 -8021 9758 -7974 9775
--7927 9792 -7893 9807 -7855 9821 -7823 9834 -7797 9845 -7771 9856 -7753 9866
--7731 9877 -7713 9885 -7698 9893 -7687 9900 -7671 9906 -7668 9913 -7656 9919
--7648 9924 -7649 9928 -7641 9933 -7640 9937 -7645 9941 -7645 9946 -7646 9948
--7650 9952 -7658 9954 -7658 9957 -7667 9960 -7679 9964 -7684 9966 -7702 9968
--7713 9971 -7725 9974 -7737 9977 -7747 9979 -7766 9983 -7782 9985 -7799 9989
--7810 9991 -7829 9995 -7843 9999 -7862 10002 -7880 10006 -7896 10011 -7911 10014
-165: 13080800 -5002718 -9720 9822 -9730 9828 -9740 9840 -9760 9846 -9800 9855
--9810 9864 -9820 9873 -9850 9881 -9870 9889 -9900 9900 -9930 9908 -9960 9917
--9990 9925 -10000 9935 -10040 9944 -10070 9949 -10090 9956 -10120 9964
--10150 9970 -10170 9972 -10190 9976 -10220 9983 -10250 9987 -10260 9990
--10290 9992 -10310 9996 -10330 9998 -10350 10000 -10360 9999 -10370 10001
--10400 10006 -10420 10008 -10440 10010 -10450 10014 -10480 10015 -10490 10018
--10520 10025 -10540 10031 -10580 10036 -10600 10044 -10640 10050 -10670 10061
--10690 10069 -10740 10079 -10780 10090 -10830 10102 -10880 10115 -10930 10128
--10970 10142 -11020 10154 -11070 10167 -11130 10183 -11190 10196 -11250 10209
--11300 10223 -11350 10233 -11410 10246 -11460 10256 -11510 10266 -11550 10274
--11600 10286 -11650 10291 -11680 10295 -11720 10298 -11740 10302 -11780 10302
--11790 10305 -11830 10303 -11830 10303 -11840 10299 -11840 10295 -11860 10289
--11850 10287 -11860 10282 -11840 10278 -11840 10272 -11820 10264 -11810 10263
--11810 10259 -11800 10260 -11800 10257 -11780 10256 -11790 10258 -11780 10257
--11790 10263 -11800 10271 -11800 10279 -11820 10289 -11840 10302 -11860 10319
--11900 10333 -11930 10347 -11970 10370 -12020 10391 -12070 10416 -12110 10440
--12180 10462 -12250 10485 -12310 10513 -12380 10541 -12470 10569 -12540 10596
--12600 10620 -12680 10641 -12750 10663 -12840 10688 -12910 10709 -12970 10729
--13040 10744 -13090 10753 -13150 10763 -13190 10772 -13240 10774 -13270 10776
--13300 10774 -13300 10768 -13320 10757 -13310 10743 -13300 10726 -13300 10707
--13260 10687 -13240 10664 -13180 10635 -13130 10603 -13070 10568 -13000 10535
--12940 10502 -12870 10471 -12780 10434 -12700 10395 -12610 10357 -12510 10322
--12440 10295 -12360 10268 -12290 10238 -12200 10211 -12120 10187 -12050 10169
--11980 10158 -11950 10154 -11920 10151 -11870 10154 -11840 10161 -11830 10175
--11850 10197 -11860 10227 -11900 10267 -11950 10308 -12000 10360 -12080 10417
--12180 10481 -12280 10549 -12410 10632 -12550 10720 -12710 10814 -12880 10913
--13050 11015 -13240 11124 -13450 11241 -13670 11366 -13910 11496 -14150 11627
--14390 11756 -14630 11887 -14890 12025 -15150 12169 -15440 12315 -15700 12458
--15950 12592 -16210 12727 -16470 12867 -16730 13008 -17000 13145 -17240 13274
--17470 13396 -17690 13511 -17900 13624 -18080 13734 -18280 13835 -18470 13933
--18630 14024 -18800 14101 -18900 14168 -18970 14227 -19060 14279 -19210 14324
--19320 14357 -19330 14367 -19260 14368 -19180 14376 -19190 14372 -19290 14332
--19390 14262 -19450 14189 -19420 14132 -19300 14089 -19140 14029 -18970 13917
--18810 13717 -18710 13419 -18740 13060 -18950 12694 -19200 12337 -19330 12007
--19300 11734 -19100 11520 -18680 11315 -18050 11086 -17270 10875 -16540 10713
--16010 10571 -15730 10388 -15530 10117 -15280 9772 -14980 9429 -14630 9140
--14210 8938 -13700 8808 -13110 8800 -12430 8891 -11550 8831 -10410 8515
--9240 8215 -8500 8409 -7990 8602 -7880 8834 -8120 9129 -8770 9238 -9350 9037
--9970 9129 -10730 9138 -11430 8851 -12660 7445 -12350 7852 -9980 7419
--7020 6493 -9040 6235 -14457 5962 -13100 6187 -9836 4499 -12240 3721 -10153 4069
-290 -462 4378 -130 5644 1224 4459 2290 2532 3043 1658 3729 2502 4523 4879 5292
-6536 5759 5196 6064 -2006 5991 -3553 6282 -964 7355 3919 9751 -1270 22779
--28856 11479 -51880 17927 1201 -5274 23140 -3070 22134 1791 6583 6391
--2059 6569 -10889 6918 -7136 7945 -4305 8555 -5993 9073 -6836 9928 -6547 10737
--4603 10644 -4342 9950 -3729 9761 -4835 9650 -6834 9811 -5696 10665 -3950 11040
--3970 11202 -5265 11173 -6684 10865 -7479 10171 -7836 9111 -8518 8130
--3719 9274 -6246 9009 -7536 9214 -12297 8032 -6982 8332 -7649 9070 -8933 8790
--9862 8326 -12204 8038 -16412 8091 -4924 8456 -2574 8119 -18187 3996 -17902 3229
--14166 4905 -11692 6152 -9197 7686 -4992 7067 -7583 7577 -11801 10138
--2409 6296 -2651 6312 -3901 6550 -4071 6237 -6950 7414 -10877 9596 -14300 11381
--12759 9625 -5934 7415 -4427 7828 -7701 9376 -11656 10629 -8536 9882 8038 5395
-1154 5426 8265 7570 -6689 11647 -22575 14503 -24387 14158 -11739 11436
-12339 6323 51216 -2992 55100 -4660 27598 -1784 -15952 7241 -14994 8295
--10575 7549 -9580 7321 -9305 9158 -4971 8330 -8602 9678 -9664 9773 13941 7405
-15685 7389 11929 8394 5858 9732 -539 10432 -3112 8970 -4908 8537 -4531 8242
--4500 8163 -2238 7395 -6821 8295 -6893 7803 -5816 7354 -4867 8091 -2835 8631
--937 7814 318 7471 1421 7646 2092 8355 1322 8766 -4307 8470 -4231 8365
--2357 8279 -323 8260 1643 8382 3636 8654 5257 9114 5426 10418 2546 9692
--2576 8095 -3793 7426 -4260 7652 -17597 9865 -15282 10370 -9956 10767
--3187 11560 4665 12409 9359 12661 -15171 10701 -12904 9813 -8456 9819
--9405 9611 -4233 9705 913 9550 2895 9838 -2935 10663 -6812 10499 -6244 10120
--5446 9579 -4860 10307 -5678 9425 -7345 9976 -7746 9471 -5732 12040 -7876 10586
--9287 10039 -8003 10737 -6033 10351 -3700 6814 3306 8554 854 11781 1593 14182
--735 8369 -789 8636 -239 9126 -1403 8405 -409 8693 -1609 6705 -125 6084
-2731 6378 5016 6881 4929 8107 1305 9942 -1578 10332 -2849 9023 -3623 7770
--3906 7495 -4784 9847 -5522 10409 -6736 10848 -9044 11959 -8414 12013
--5341 11828 395 13022 4528 15009 6591 15524 7662 14744 12633 13991 42172 7116
--42529 8435 -392747 -30920 -191400 -7963 -55463 7516 10183 14958 38404 17863
-47526 18320 46479 17505 40078 16139 31204 14659 21700 13304 12688 12181
-4799 11311 -1705 10670 -6804 10212 -10603 9894 -13289 9676 -15065 9524
--16146 9417 -16722 9339 -16926 9278 -16875 9230 -16671 9190 -16360 9159
--16001 9131 -15602 9110 -15200 9091 -14797 9078 -14405 9070 -14017 9065
--13646 9065 -13294 9069 -12946 9076 -12622 9088 -12303 9101 -12000 9118
--11716 9137 -11439 9159 -11176 9183 -10936 9210 -10700 9238 -10471 9264
--10258 9291 -10053 9319 -9853 9347 -9660 9379 -9482 9412 -9414 9445 -9276 9474
--9117 9502 -8970 9527 -8834 9553 -8721 9579 -8628 9604 -8540 9628 -8454 9652
--8368 9673 -8295 9694 -8228 9714 -8167 9732 -8120 9749 -8066 9766 -8017 9781
--7976 9796 -7939 9810 -7902 9821 -7871 9832 -7845 9843 -7822 9854 -7801 9863
--7779 9871 -7760 9879 -7750 9885 -7734 9892 -7723 9898 -7714 9905 -7706 9910
--7698 9914 -7695 9918 -7697 9922 -7695 9927 -7699 9930 -7698 9934 -7696 9937
--7702 9939 -7708 9943 -7712 9945 -7722 9949 -7734 9951 -7745 9954 -7752 9956
--7765 9959 -7778 9962 -7790 9965 -7803 9968 -7818 9970 -7839 9974 -7847 9976
--7866 9980 -7877 9984 -7896 9987 -7913 9991 -7926 9995 -7946 9999
-166: 13112680 -4993895 -9740 9822 -9740 9830 -9770 9839 -9790 9848 -9810 9856
--9830 9864 -9840 9873 -9860 9880 -9890 9890 -9920 9899 -9940 9908 -9970 9915
--10000 9924 -10020 9934 -10050 9943 -10080 9949 -10110 9956 -10130 9961
--10160 9969 -10180 9971 -10210 9976 -10220 9981 -10250 9988 -10280 9991
--10290 9993 -10320 9996 -10340 9999 -10350 10000 -10360 10000 -10380 10004
--10400 10005 -10430 10009 -10430 10010 -10460 10014 -10480 10016 -10490 10020
--10530 10027 -10540 10032 -10580 10037 -10600 10047 -10620 10051 -10670 10062
--10700 10070 -10740 10080 -10770 10091 -10820 10103 -10870 10114 -10920 10126
--10960 10141 -11010 10155 -11060 10167 -11120 10181 -11180 10196 -11230 10209
--11290 10220 -11330 10231 -11400 10244 -11430 10253 -11490 10264 -11540 10273
--11580 10283 -11630 10285 -11660 10292 -11690 10294 -11730 10300 -11750 10300
--11780 10300 -11800 10301 -11810 10300 -11820 10297 -11830 10292 -11820 10287
--11830 10284 -11840 10281 -11820 10276 -11820 10270 -11810 10265 -11790 10258
--11800 10258 -11790 10255 -11790 10258 -11770 10256 -11780 10257 -11760 10255
--11780 10264 -11790 10269 -11790 10277 -11800 10289 -11830 10301 -11850 10315
--11890 10330 -11910 10346 -11960 10364 -12020 10387 -12050 10412 -12110 10435
--12160 10453 -12220 10479 -12290 10506 -12370 10532 -12440 10561 -12520 10586
--12580 10607 -12650 10629 -12730 10651 -12800 10672 -12880 10695 -12930 10714
--13000 10727 -13060 10736 -13100 10744 -13160 10751 -13190 10757 -13240 10757
--13250 10753 -13260 10748 -13270 10736 -13270 10723 -13260 10705 -13250 10685
--13210 10666 -13190 10643 -13150 10616 -13090 10585 -13030 10551 -12960 10516
--12900 10487 -12840 10456 -12760 10420 -12670 10382 -12580 10346 -12490 10312
--12420 10286 -12340 10260 -12270 10234 -12180 10207 -12110 10185 -12040 10169
--11990 10158 -11940 10155 -11910 10155 -11870 10157 -11850 10166 -11820 10181
--11840 10206 -11870 10237 -11900 10275 -11950 10320 -12000 10371 -12080 10428
--12160 10493 -12270 10562 -12400 10642 -12530 10730 -12690 10825 -12850 10923
--13020 11026 -13210 11131 -13390 11248 -13630 11373 -13850 11500 -14090 11630
--14320 11757 -14550 11886 -14800 12023 -15060 12165 -15320 12308 -15590 12448
--15830 12583 -16080 12714 -16330 12851 -16590 12989 -16830 13125 -17080 13252
--17300 13369 -17500 13483 -17700 13593 -17900 13698 -18080 13802 -18250 13896
--18420 13984 -18570 14058 -18670 14124 -18750 14180 -18830 14229 -18960 14271
--19070 14300 -19110 14309 -19040 14306 -18980 14307 -18970 14299 -19030 14257
--19100 14185 -19140 14105 -19140 14029 -19080 13965 -19000 13893 -18890 13782
--18760 13594 -18660 13320 -18660 13003 -18760 12656 -18830 12287 -18870 11936
--18870 11635 -18760 11362 -18410 11067 -17840 10774 -17120 10545 -16430 10397
--15890 10283 -15490 10138 -15130 9905 -14780 9613 -14500 9316 -14280 9048
--14020 8844 -13660 8704 -13130 8677 -12430 8721 -11570 8656 -10570 8482
--9610 8391 -8890 8495 -8460 8624 -8350 8802 -8460 9042 -8730 9189 -9060 9128
--9570 9061 -10340 9006 -11270 8860 -12140 8373 -11910 8289 -10450 7822
--9610 7027 -11010 6185 -13730 5317 -13030 4617 -10890 3261 -10480 2506
--7321 2547 57 1255 5024 1641 7620 2633 6620 3323 2900 3607 300 3860 540 4481
-4530 5740 8070 6621 9460 7250 -2290 6623 -2970 7031 -900 9485 6260 11939
-21320 27003 -28230 4492 -31310 2829 -140 -2687 910 3302 6260 5539 1710 7457
--2700 7532 -6310 7794 -4920 8463 -3694 9131 -8543 9558 -10553 9867 -10326 11056
--5145 10691 -5904 9252 -3534 9478 -5128 9366 -9953 9354 -6653 11029 -2636 11077
--2470 11023 -4161 10898 -5471 10572 -5159 9924 -3600 9059 -5210 8580 -3184 9231
--7019 9454 -7787 9120 -8190 7876 -6351 8751 -9632 10810 -10025 9989 -9701 8441
--11972 7882 -15511 7996 -12418 8233 -12374 7873 -18978 5810 -16952 4417
--14357 5350 -11841 5434 -8554 6309 -5795 6860 -5682 7099 -11698 9879 -7361 8090
--6348 7629 -6470 7634 -3553 6201 -6143 7273 -8586 8738 -10009 9486 -8641 8392
--5851 7555 -4851 8378 -7051 9540 -11774 10605 -11097 10008 -3691 8018
-3189 7933 32806 6594 -2773 10891 -32373 14334 -23504 11994 1149 7475 25694 2758
-48679 -1791 48247 -1226 10123 905 -24608 5127 -5930 8008 -7881 7329 -5777 8663
--6015 9108 -3417 8634 -5111 8658 -9130 9338 1207 8361 4645 7840 3545 8647
-362 9970 -3461 10604 -773 7142 -1476 6534 1336 5646 654 5957 1082 6520
--8819 9167 -6550 7844 -5928 7404 -4167 8103 -1419 8948 -431 8554 522 8378
-1307 8525 1147 9007 -317 9132 -3519 8827 -4355 8510 -3586 8275 -2069 8179
-125 8281 3215 8646 6707 9327 8145 10148 4707 9409 -5948 6917 -7609 6770
--8697 7431 -15344 8764 -15261 9264 -11783 9599 -6345 10298 533 11417 4824 12165
--8051 11359 -11376 10649 -10501 10282 -9206 9939 -3570 9768 4220 9654
-9830 9928 -1647 11449 -3504 11472 -3125 11118 -2818 10809 -2882 11120
--3867 10699 -5169 10650 -5990 10109 -5849 10435 -7037 9412 -6685 10598
--5988 10338 -4595 8941 -2148 6384 8068 7596 -1813 9984 1259 12636 1302 9736
-1338 10271 2161 10391 -2153 8169 466 10618 -4219 7098 -3227 6909 -562 7846
-1546 7923 2525 8576 718 9883 -1070 10104 -963 7968 -1613 6893 -1620 6337
--6846 9943 -6488 9923 -7069 10326 -8259 11047 -7844 11043 -6136 10359
-388 11745 3260 13191 4318 13745 3216 12877 -2490 10480 -22098 7608 -431557 -32301
--316554 -26152 2463 13168 58726 20330 65353 21253 62030 20614 55577 19343
-47251 17775 37773 16142 27917 14620 18426 13313 9824 12257 2470 11448
--3533 10848 -8201 10417 -11675 10112 -14115 9895 -15728 9741 -16694 9626
--17184 9538 -17345 9467 -17262 9409 -17030 9360 -16700 9318 -16320 9282
--15917 9251 -15502 9224 -15086 9204 -14675 9187 -14281 9175 -13901 9169
--13537 9165 -13180 9165 -12847 9171 -12520 9179 -12208 9189 -11917 9203
--11636 9219 -11367 9238 -11123 9260 -10882 9282 -10650 9304 -10430 9328
--10214 9350 -10014 9376 -9813 9402 -9626 9433 -9561 9462 -9418 9489 -9253 9512
--9104 9536 -8959 9559 -8839 9583 -8746 9606 -8654 9628 -8562 9650 -8473 9670
--8396 9690 -8325 9708 -8263 9724 -8204 9742 -8153 9756 -8103 9772 -8055 9786
--8012 9798 -7977 9809 -7947 9821 -7915 9831 -7886 9840 -7864 9850 -7842 9859
--7821 9865 -7809 9872 -7788 9878 -7781 9885 -7767 9891 -7759 9895 -7746 9901
--7748 9904 -7750 9908 -7740 9913 -7747 9916 -7748 9920 -7742 9923 -7746 9926
--7755 9928 -7755 9932 -7765 9935 -7774 9937 -7787 9940 -7794 9942 -7803 9945
--7813 9948 -7829 9951 -7845 9954 -7856 9956 -7870 9960 -7880 9962 -7900 9966
--7913 9970 -7929 9973 -7943 9976 -7957 9981 -7973 9985
-167: 13144590 -4985079 -9750 9824 -9770 9831 -9790 9839 -9800 9847 -9830 9857
--9850 9866 -9860 9872 -9880 9880 -9910 9888 -9930 9899 -9960 9908 -9980 9913
--10010 9925 -10040 9933 -10060 9941 -10090 9948 -10120 9954 -10140 9963
--10170 9968 -10200 9970 -10210 9977 -10240 9981 -10250 9987 -10280 9990
--10300 9995 -10330 9995 -10340 9999 -10360 10000 -10370 10002 -10390 10003
--10400 10006 -10420 10009 -10440 10013 -10470 10013 -10480 10018 -10490 10021
--10520 10026 -10560 10034 -10570 10038 -10590 10048 -10630 10053 -10660 10063
--10700 10070 -10730 10081 -10770 10091 -10820 10103 -10860 10115 -10910 10127
--10950 10141 -11000 10153 -11050 10166 -11110 10180 -11160 10195 -11220 10206
--11270 10218 -11320 10230 -11380 10240 -11420 10252 -11470 10262 -11520 10269
--11570 10279 -11600 10283 -11640 10289 -11670 10291 -11700 10296 -11730 10296
--11750 10298 -11780 10296 -11790 10299 -11800 10295 -11800 10288 -11810 10284
--11810 10283 -11820 10278 -11800 10275 -11800 10267 -11790 10263 -11780 10257
--11780 10257 -11790 10253 -11770 10256 -11760 10253 -11760 10256 -11750 10256
--11760 10262 -11780 10268 -11780 10276 -11800 10287 -11820 10301 -11840 10313
--11870 10327 -11900 10343 -11950 10360 -12000 10384 -12040 10406 -12090 10431
--12160 10449 -12200 10472 -12270 10498 -12340 10524 -12420 10552 -12490 10574
--12570 10597 -12610 10616 -12710 10639 -12770 10660 -12840 10681 -12910 10696
--12960 10710 -13020 10719 -13060 10728 -13110 10734 -13150 10737 -13200 10739
--13200 10733 -13230 10727 -13220 10716 -13220 10702 -13220 10684 -13200 10666
--13180 10647 -13150 10623 -13100 10598 -13050 10566 -12990 10533 -12930 10500
--12860 10470 -12810 10442 -12720 10405 -12640 10370 -12560 10335 -12480 10301
--12390 10277 -12330 10254 -12250 10228 -12170 10202 -12100 10181 -12030 10166
--11980 10159 -11940 10157 -11900 10156 -11870 10161 -11840 10170 -11830 10187
--11840 10213 -11860 10245 -11900 10283 -11940 10328 -12000 10379 -12070 10438
--12160 10502 -12260 10572 -12370 10651 -12520 10739 -12670 10833 -12820 10930
--12990 11031 -13160 11138 -13350 11252 -13580 11375 -13790 11503 -14030 11629
--14240 11754 -14470 11880 -14710 12017 -14970 12157 -15220 12296 -15470 12434
--15720 12568 -15950 12696 -16190 12829 -16440 12966 -16690 13099 -16910 13222
--17120 13338 -17330 13448 -17520 13557 -17710 13661 -17870 13759 -18040 13850
--18210 13936 -18350 14007 -18460 14070 -18530 14122 -18600 14168 -18720 14205
--18830 14231 -18880 14238 -18840 14229 -18780 14222 -18760 14207 -18800 14165
--18820 14091 -18870 14003 -18860 13913 -18840 13825 -18800 13736 -18740 13618
--18640 13434 -18580 13189 -18550 12904 -18540 12571 -18520 12213 -18520 11872
--18550 11561 -18460 11230 -18130 10862 -17600 10532 -16970 10293 -16370 10128
--15880 9999 -15420 9838 -14940 9607 -14530 9341 -14250 9058 -14050 8807
--13850 8616 -13460 8492 -12890 8469 -12140 8497 -11340 8455 -10530 8380
--9770 8380 -9200 8448 -8820 8515 -8620 8645 -8530 8859 -8530 9015 -8670 8982
--9030 8871 -9700 8816 -10530 8796 -11170 8632 -11130 8373 -10440 7784
--10930 6786 -11970 5468 -13140 4083 -12600 2861 -10950 1747 -9190 1373
--5840 2144 -430 3568 4750 4456 9510 5218 8790 5272 2180 4706 -2370 4304
--3820 4580 2330 6763 5070 7852 6970 8961 3880 7010 2420 6787 2820 9750
-7270 11698 11090 15591 -11130 3903 -13580 -1735 -9010 6257 -4820 7993
--560 8534 -830 8833 -2190 8062 -4290 8267 -3980 8848 -4030 9608 -7040 10221
--11490 9306 -13620 11473 -3070 10939 -8640 8559 -2870 9783 -4420 9524
--14163 8752 -7047 11549 -691 10669 -1356 10599 -4104 10602 -5764 10482
--4539 10061 786 9340 -4695 9086 -4879 9475 -5586 9362 -7544 8771 -6365 6746
--7449 8254 -8756 12681 -10282 12014 -8944 8555 -12076 7632 -17892 7749
--19243 7740 -20114 7468 -22176 6257 -13717 6373 -14426 6191 -11659 5450
--7943 5330 -6657 6932 -4207 6964 -8600 8515 -8447 8479 -8204 8239 -7219 7841
--4344 6832 -5629 7295 -5415 7844 -5736 8125 -5167 7687 -4322 7423 -3274 8712
--3284 9180 -8827 10421 -8742 9975 -3931 8817 6852 9703 78568 3151 -11067 10141
--75362 17020 -16263 9861 11721 4541 30940 1220 45888 -541 50210 3385 4054 5123
--10512 8098 -23865 5378 -16472 6686 -8908 8473 -6784 8439 -825 8195 160 6517
--12533 8513 -6015 8868 -4702 7383 -3707 7969 -3256 8945 -6485 8730 1077 7761
-1073 5926 750 4394 -1164 5319 -584 7451 -5153 9620 -619 7415 -2668 7778
--3431 8397 -2781 8790 -1981 8781 -740 9113 40 9427 -433 9800 -1779 9700
--3706 9256 -4629 8727 -4711 8323 -4145 8117 -2602 8154 794 8526 6211 9331
-9050 10018 6375 9547 -13226 5466 -11474 6802 -10589 7660 -12505 8077 -13258 8069
--12913 8041 -11326 8506 -6864 10061 3276 11808 -2303 11767 -8629 11179
--11319 10660 -9973 10342 -5234 10158 2888 10223 11397 10791 8128 11917
-5338 12330 3371 12343 1745 12298 348 12388 -1106 12116 -2553 11633 -3909 10629
--5014 9596 -5887 8716 -5520 9101 -4579 8877 -2957 7879 -330 6574 4033 6954
--38 8224 139 9365 91 8350 2645 10710 1768 9280 -1586 7254 1645 11430 -2923 9523
--4201 8524 -2198 10086 -1028 9156 1085 9148 -43 10415 -1480 11054 92 7871
--3120 8528 -6128 9546 -2332 6587 -3930 7673 -5720 9194 -6960 10377 -5728 10625
--5155 9012 -1954 9992 424 11733 1125 12843 -82 12763 -5142 11153 -34798 5671
--714389 -56483 -44412 448 65642 16770 71181 20580 62934 20895 54583 20072
-46569 18761 38261 17254 29608 15743 20939 14366 12730 13195 5342 12252
--961 11528 -6108 10986 -10097 10591 -13068 10304 -15140 10096 -16498 9940
--17293 9821 -17661 9725 -17740 9645 -17614 9579 -17345 9519 -16991 9469
--16595 9424 -16179 9384 -15750 9350 -15320 9321 -14905 9298 -14504 9279
--14113 9265 -13740 9256 -13378 9250 -13031 9248 -12703 9252 -12387 9256
--12089 9265 -11804 9276 -11536 9290 -11281 9306 -11039 9325 -10804 9343
--10575 9361 -10361 9381 -10151 9402 -9948 9425 -9759 9453 -9689 9479 -9547 9502
--9371 9523 -9222 9545 -9075 9565 -8953 9587 -8850 9607 -8755 9629 -8659 9649
--8572 9667 -8483 9685 -8414 9702 -8347 9719 -8287 9733 -8234 9749 -8179 9762
--8128 9776 -8085 9788 -8048 9798 -8014 9810 -7983 9819 -7948 9829 -7923 9837
--7898 9846 -7881 9852 -7858 9860 -7844 9865 -7833 9872 -7818 9877 -7807 9883
--7801 9887 -7796 9891 -7797 9895 -7786 9900 -7785 9903 -7792 9906 -7788 9910
--7787 9912 -7795 9916 -7802 9918 -7808 9922 -7812 9924 -7823 9927 -7832 9929
--7843 9932 -7851 9935 -7863 9938 -7880 9940 -7888 9944 -7901 9946 -7917 9949
--7929 9953 -7945 9956 -7958 9960 -7971 9963 -7988 9967 -8003 9972
-168: 13176530 -4976270 -9770 9826 -9790 9832 -9800 9839 -9830 9848 -9840 9858
--9860 9865 -9880 9871 -9910 9880 -9920 9889 -9940 9896 -9970 9909 -10000 9914
--10030 9925 -10050 9932 -10070 9939 -10100 9948 -10130 9953 -10150 9961
--10190 9967 -10200 9971 -10220 9977 -10250 9982 -10260 9985 -10290 9988
--10310 9994 -10330 9996 -10350 10000 -10360 10000 -10380 10003 -10380 10003
--10420 10006 -10420 10010 -10450 10012 -10460 10016 -10490 10019 -10490 10022
--10530 10027 -10540 10035 -10580 10039 -10590 10047 -10630 10054 -10660 10062
--10690 10071 -10730 10083 -10770 10091 -10810 10103 -10850 10116 -10900 10127
--10940 10140 -10990 10152 -11040 10165 -11100 10179 -11150 10192 -11210 10204
--11260 10217 -11300 10229 -11350 10238 -11410 10248 -11450 10260 -11510 10266
--11540 10274 -11570 10281 -11620 10286 -11660 10288 -11680 10291 -11710 10294
--11720 10294 -11760 10294 -11760 10295 -11780 10290 -11790 10286 -11790 10282
--11790 10279 -11800 10276 -11790 10273 -11770 10266 -11780 10259 -11760 10256
--11770 10257 -11760 10254 -11760 10252 -11750 10253 -11740 10253 -11740 10255
--11760 10262 -11760 10268 -11770 10275 -11780 10285 -11810 10300 -11840 10309
--11860 10325 -11880 10339 -11940 10357 -11980 10381 -12030 10400 -12070 10426
--12140 10445 -12200 10466 -12250 10490 -12320 10517 -12390 10543 -12470 10566
--12530 10585 -12590 10604 -12670 10628 -12740 10645 -12810 10667 -12880 10681
--12930 10694 -12980 10703 -13020 10710 -13070 10718 -13110 10717 -13150 10719
--13170 10716 -13170 10708 -13180 10697 -13190 10682 -13170 10665 -13160 10646
--13140 10628 -13100 10603 -13070 10580 -13000 10549 -12960 10516 -12890 10483
--12830 10454 -12770 10426 -12700 10393 -12610 10359 -12540 10323 -12450 10291
--12380 10268 -12300 10247 -12240 10221 -12160 10197 -12080 10176 -12020 10164
--11970 10158 -11930 10156 -11900 10158 -11860 10163 -11840 10174 -11840 10192
--11830 10218 -11860 10251 -11890 10290 -11940 10334 -12000 10386 -12060 10446
--12150 10509 -12240 10579 -12360 10657 -12500 10745 -12640 10838 -12790 10936
--12960 11034 -13120 11139 -13310 11253 -13530 11375 -13730 11500 -13960 11626
--14170 11748 -14400 11873 -14620 12005 -14870 12144 -15120 12281 -15350 12418
--15600 12546 -15820 12673 -16060 12804 -16290 12937 -16540 13067 -16750 13188
--16960 13299 -17150 13408 -17340 13515 -17520 13616 -17690 13711 -17840 13796
--17990 13878 -18140 13947 -18230 14007 -18320 14056 -18390 14095 -18490 14129
--18590 14151 -18650 14153 -18640 14141 -18590 14126 -18560 14101 -18580 14055
--18590 13982 -18600 13889 -18600 13784 -18580 13676 -18580 13569 -18530 13436
--18480 13250 -18450 13029 -18410 12758 -18310 12441 -18240 12112 -18260 11795
--18280 11468 -18160 11087 -17820 10694 -17340 10365 -16850 10109 -16390 9899
--15960 9710 -15450 9496 -14920 9248 -14460 8986 -14150 8719 -13920 8497
--13600 8343 -13110 8254 -12420 8244 -11660 8262 -10940 8242 -10330 8225
--9810 8260 -9380 8296 -9000 8319 -8680 8418 -8410 8614 -8220 8766 -8210 8752
--8470 8647 -9010 8586 -9670 8562 -10170 8399 -10240 7993 -9960 7285 -11070 6102
--11920 4551 -12410 2953 -11850 1598 -10360 638 -8270 499 -5400 2078 -1520 6534
-2620 7419 11270 8142 11490 7583 1300 6133 -3620 5253 -8880 4634 1510 8404
-2500 9624 2710 10348 7830 7133 6110 7173 4230 8110 4370 9023 2710 9443
--5870 7115 -9450 4503 -5870 6770 -2240 8033 -580 9144 -840 9544 -1430 8023
--2800 8273 -3110 8975 -3270 9947 -3430 11517 -8320 8819 -10850 10051 -5050 9918
--8000 11361 -7280 10115 -7300 10060 -7750 11041 -5740 9129 -2590 9286
--2320 9990 -5620 10302 -7660 10531 -7570 10426 1830 9620 -2460 9582 -4640 9984
--1760 9163 -4380 7870 -8650 6647 -10268 7520 -7818 15154 -10334 12425
--9553 9282 -12004 7852 -21616 8092 -23268 7658 -22197 7776 -25369 5950
--11075 8373 -19529 7179 -13837 5790 -7993 4275 -8636 6877 447 5160 -5808 6861
--7264 8188 -9393 8424 -9061 8165 -5947 7546 -2800 6880 -64 7044 -836 7399
--2311 7743 -3635 8058 -3051 8723 -406 9010 2377 9368 7644 9078 26368 7199
-58343 4909 98646 579 -29420 8141 -91624 16166 -56441 14199 -3317 5471
-18816 3156 30311 2929 28937 5169 2928 6273 -11429 7184 -18464 7323 -15988 7632
--11596 8179 -8103 8335 -713 8631 -1915 4657 -9180 6409 -4549 9159 -9660 5954
--6832 6906 -1978 9090 -5331 8915 -2728 7199 -1405 5405 -5007 3026 -3438 4439
-2541 8033 2894 9487 3535 8497 -1316 9144 -3872 9140 -5083 8691 -4544 8673
--2522 9758 -1541 10328 -2011 10617 -3119 10297 -4372 9659 -5050 8882 -5766 8322
--6458 8005 -6570 7885 -4416 8037 2899 8854 4404 9118 -726 8207 -13155 5975
--8706 8670 -8521 8679 -8023 7909 -9126 7214 -11568 6731 -14378 6701 -14643 8580
-6060 11613 1124 11750 -8175 11217 -13782 10722 -12123 10636 -9111 10520
--937 10739 15739 11555 17922 12546 14477 13169 10051 13468 6259 13633
-3520 13724 1594 13512 32 12789 -1777 11170 -4091 8790 -5215 7478 -4879 7391
--3675 7433 -1941 7125 33 6549 1655 6393 492 6890 268 7680 434 8123 1969 9305
-2537 8048 1605 7277 1784 9191 -2243 8800 -5297 8582 -1923 10877 -3188 10835
--2006 10446 -715 10447 -349 10108 892 9347 -2693 9603 -3747 9274 -4516 7838
--4011 7558 -5044 8841 -6528 9947 -3563 10008 -4608 8691 -4666 8763 -3215 10689
--4103 12084 -8960 12177 -16956 10592 -24890 5858 -44752 3887 -223388 -13497
--119075 -472 -40131 9669 -633 14720 16002 16547 20957 16662 19965 15958
-15972 14944 10613 13897 4914 12954 -524 12172 -5307 11555 -9276 11086
--12393 10734 -14705 10471 -16311 10274 -17342 10121 -17910 9999 -18132 9897
--18112 9810 -17919 9735 -17607 9667 -17231 9608 -16816 9555 -16384 9507
--15947 9467 -15505 9430 -15082 9401 -14673 9375 -14281 9354 -13901 9339
--13534 9328 -13182 9322 -12852 9318 -12538 9319 -12225 9322 -11941 9329
--11669 9338 -11414 9350 -11169 9364 -10937 9378 -10702 9393 -10484 9409
--10265 9427 -10064 9447 -9871 9471 -9805 9495 -9657 9515 -9483 9533 -9319 9553
--9179 9570 -9052 9591 -8942 9610 -8842 9629 -8752 9647 -8658 9664 -8566 9682
--8494 9697 -8426 9712 -8366 9727 -8308 9740 -8247 9754 -8195 9766 -8153 9778
--8112 9789 -8074 9798 -8041 9808 -8010 9818 -7976 9826 -7954 9833 -7932 9841
--7912 9847 -7898 9853 -7880 9859 -7864 9865 -7854 9870 -7853 9875 -7841 9878
--7837 9883 -7832 9887 -7829 9890 -7830 9894 -7829 9898 -7828 9900 -7834 9903
--7839 9906 -7845 9909 -7849 9911 -7858 9915 -7871 9917 -7878 9919 -7890 9923
--7897 9925 -7909 9929 -7920 9931 -7932 9934 -7950 9937 -7956 9940 -7971 9944
--7982 9947 -8002 9951 -8015 9955 -8031 9958
-169: 13208510 -4967472 -9790 9829 -9810 9835 -9830 9840 -9840 9848 -9860 9858
--9880 9865 -9890 9871 -9930 9879 -9930 9890 -9960 9897 -9990 9907 -10010 9914
--10040 9924 -10060 9931 -10080 9938 -10110 9948 -10140 9953 -10170 9960
--10200 9966 -10210 9972 -10230 9976 -10250 9981 -10280 9984 -10290 9989
--10320 9992 -10340 9996 -10350 10000 -10370 10001 -10380 10003 -10390 10004
--10420 10006 -10430 10010 -10450 10014 -10460 10016 -10480 10019 -10510 10022
--10520 10030 -10550 10036 -10570 10040 -10590 10046 -10630 10054 -10660 10063
--10690 10071 -10720 10081 -10770 10092 -10800 10104 -10850 10115 -10890 10128
--10930 10139 -10980 10151 -11030 10163 -11090 10177 -11140 10191 -11190 10202
--11250 10215 -11290 10226 -11330 10236 -11390 10247 -11430 10256 -11480 10265
--11530 10270 -11560 10276 -11600 10282 -11620 10285 -11660 10288 -11690 10289
--11710 10292 -11730 10291 -11740 10290 -11760 10287 -11760 10284 -11770 10280
--11780 10276 -11770 10273 -11770 10271 -11750 10262 -11760 10258 -11750 10254
--11750 10255 -11750 10253 -11750 10253 -11720 10252 -11730 10252 -11740 10255
--11740 10258 -11750 10267 -11760 10276 -11770 10284 -11790 10296 -11830 10308
--11850 10322 -11870 10337 -11930 10356 -11970 10376 -12010 10395 -12060 10420
--12120 10440 -12180 10460 -12230 10484 -12290 10508 -12380 10533 -12440 10557
--12510 10576 -12560 10595 -12640 10614 -12710 10633 -12780 10652 -12840 10668
--12890 10679 -12950 10687 -12980 10694 -13030 10700 -13070 10700 -13100 10700
--13130 10698 -13140 10688 -13140 10677 -13140 10665 -13130 10646 -13110 10626
--13100 10609 -13060 10586 -13020 10561 -12980 10532 -12910 10500 -12860 10468
--12800 10438 -12740 10411 -12670 10379 -12580 10346 -12510 10312 -12430 10283
--12350 10258 -12290 10239 -12230 10213 -12140 10192 -12060 10173 -12010 10160
--11970 10155 -11920 10157 -11900 10158 -11850 10164 -11840 10177 -11830 10196
--11830 10221 -11860 10255 -11890 10296 -11930 10339 -11980 10392 -12060 10450
--12140 10514 -12230 10583 -12340 10663 -12480 10749 -12610 10841 -12770 10937
--12920 11035 -13080 11139 -13270 11252 -13470 11370 -13680 11495 -13890 11618
--14100 11739 -14310 11861 -14540 11990 -14770 12127 -15020 12264 -15250 12396
--15470 12522 -15700 12645 -15920 12775 -16150 12902 -16380 13030 -16600 13147
--16790 13257 -16980 13360 -17160 13467 -17340 13564 -17490 13654 -17650 13737
--17790 13814 -17920 13880 -18030 13936 -18110 13980 -18190 14012 -18250 14042
--18360 14061 -18420 14059 -18440 14042 -18390 14019 -18370 13984 -18370 13932
--18370 13859 -18370 13762 -18350 13644 -18340 13522 -18320 13399 -18310 13245
--18280 13056 -18290 12843 -18210 12577 -18070 12279 -18020 11983 -18030 11681
--18020 11328 -17830 10929 -17480 10559 -17110 10245 -16790 9957 -16460 9675
--16060 9401 -15520 9129 -14960 8866 -14470 8612 -14110 8375 -13770 8197
--13310 8087 -12650 8029 -11860 8018 -11100 8018 -10520 8006 -10110 8018
--9800 8057 -9460 8068 -9040 8069 -8560 8155 -8140 8341 -7830 8494 -7740 8505
--7930 8412 -8360 8300 -8870 8149 -9240 7831 -9300 7276 -9090 6506 -10260 5331
--10940 3852 -11240 2412 -10760 1300 -9380 627 -7220 479 -5070 1877 -2530 10416
--3140 9229 10120 10126 9720 9206 3500 7619 3420 7701 -5900 6250 -2170 7991
-30 9130 1910 9574 5270 8592 5260 8462 2650 7310 1260 7920 -1440 8548 -6360 8742
--8900 8438 -930 6322 930 7538 1410 8707 1030 9022 -1310 8476 -2150 8523
--2620 9062 -3190 9834 -4010 10542 -4500 10171 -6100 10596 -4330 11139
--5420 12130 -9640 8861 -8560 9005 -490 11251 -4570 8850 -4320 8884 -2880 9930
--6790 10141 -6760 10636 -4820 10747 -2880 10242 -3970 10194 -3710 10831
--620 10405 -2080 8388 -12210 8660 -11420 10391 -9370 14483 -14490 10373
--11350 9344 -10480 8227 -24950 9322 -22162 8279 -11369 10083 -9128 8841
--32210 5791 -33967 6500 -18221 7387 -11954 6319 -10783 2913 4454 -362
-759 5179 -2215 7893 -11211 8445 -11842 8301 -9107 7574 2912 6904 8253 6601
-6734 6864 -2559 8476 -5226 8850 -5110 8995 452 8975 9777 8855 23071 7877
-43079 5686 64325 3101 65928 1161 -9580 4996 -56913 9560 -56704 13541 -22203 8703
--1799 7218 9682 6818 9400 7265 -3821 6992 -14295 6203 -11486 9134 -12247 8138
--12050 7349 -11185 6731 -739 7098 -1343 4415 -5374 4213 -8120 8839 -10408 6509
--9066 5995 -386 10052 -1859 9634 -6679 6143 -3028 5372 -12359 1248 -6333 3445
-9601 10043 10438 10477 8052 9277 -1177 10754 -4303 9915 -7387 8386 -7113 8139
--3832 10313 -2856 11060 -3265 11271 -4258 10737 -5160 9959 -5154 8875
--6230 8236 -7993 7892 -10205 7631 -11420 7324 -384 8491 -2 8773 -3710 8457
--9833 8013 -9113 9406 -7677 9321 -2368 7761 -2596 6880 -5744 6525 -9348 6630
--9779 7489 716 10118 -1427 10722 -10635 10586 -18921 10369 -14388 10697
--13425 10580 -7047 10904 22290 12063 25143 13114 20220 13844 13835 14278
-8474 14562 5013 14709 3139 14599 2039 13901 282 11845 -3752 7523 -5147 5852
--4651 5801 -3144 6328 -1263 6739 198 6619 372 5827 620 5729 683 6527 482 7750
-1090 8663 3655 6643 4361 6459 3836 7491 -128 7702 -3251 8425 -5233 10676
--9012 11816 -6514 11333 -802 10520 4085 9512 -440 9450 -2157 9553 -91 8828
--4068 8903 -4192 8405 -4298 8840 -5538 9890 -2420 10837 -5055 8954 -7415 7789
--5911 9647 -6177 11164 -11255 11222 -12040 10273 15115 8253 5663 10339
--55343 2755 -145157 -2483 -96722 4456 -50274 10206 -21855 13314 -7176 14488
--1018 14541 214 14050 -1231 13361 -3963 12668 -7100 12055 -10133 11554
--12761 11157 -14880 10852 -16463 10616 -17540 10430 -18200 10282 -18521 10158
--18569 10051 -18429 9959 -18168 9875 -17817 9801 -17406 9734 -16965 9673
--16527 9620 -16083 9571 -15638 9530 -15207 9493 -14796 9462 -14403 9436
--14018 9414 -13644 9399 -13293 9388 -12965 9380 -12645 9375 -12336 9375
--12048 9376 -11776 9382 -11519 9390 -11273 9399 -11037 9411 -10807 9422
--10580 9435 -10367 9450 -10160 9468 -9966 9487 -9898 9508 -9748 9526 -9575 9543
--9410 9560 -9261 9576 -9138 9594 -9027 9612 -8923 9629 -8833 9646 -8734 9662
--8643 9677 -8570 9692 -8496 9707 -8432 9720 -8375 9733 -8309 9745 -8260 9758
--8212 9768 -8172 9779 -8128 9788 -8096 9798 -8062 9806 -8031 9815 -8006 9822
--7983 9829 -7958 9836 -7946 9841 -7926 9848 -7914 9853 -7900 9858 -7895 9862
--7882 9867 -7878 9871 -7874 9875 -7868 9878 -7867 9883 -7865 9885 -7868 9888
--7869 9891 -7875 9894 -7881 9898 -7885 9900 -7893 9903 -7904 9905 -7910 9908
--7922 9911 -7930 9914 -7939 9916 -7955 9920 -7959 9922 -7977 9926 -7983 9929
--7998 9932 -8008 9936 -8025 9939 -8040 9943 -8057 9946
-170: 13240520 -4958678 -9810 9828 -9830 9836 -9840 9841 -9860 9850 -9880 9855
--9890 9866 -9920 9872 -9940 9882 -9950 9890 -9980 9897 -9990 9905 -10040 9914
--10040 9925 -10070 9929 -10100 9938 -10130 9946 -10150 9952 -10180 9961
--10200 9964 -10220 9973 -10240 9976 -10260 9979 -10280 9985 -10300 9986
--10330 9992 -10340 9995 -10360 10001 -10370 10002 -10390 10003 -10400 10005
--10420 10006 -10440 10010 -10450 10015 -10460 10017 -10490 10020 -10500 10021
--10530 10029 -10550 10035 -10570 10041 -10600 10046 -10620 10056 -10660 10063
--10690 10071 -10710 10084 -10760 10092 -10800 10103 -10840 10113 -10880 10126
--10930 10139 -10970 10151 -11020 10162 -11070 10174 -11130 10189 -11180 10201
--11220 10213 -11280 10223 -11320 10232 -11370 10245 -11420 10254 -11450 10261
--11510 10267 -11540 10274 -11580 10280 -11600 10281 -11650 10283 -11660 10285
--11690 10288 -11710 10288 -11710 10287 -11740 10285 -11740 10280 -11750 10276
--11750 10273 -11750 10271 -11750 10266 -11740 10262 -11740 10258 -11730 10254
--11740 10252 -11730 10252 -11730 10251 -11720 10250 -11720 10251 -11720 10254
--11720 10258 -11750 10265 -11750 10274 -11750 10283 -11780 10294 -11810 10306
--11840 10320 -11870 10335 -11900 10353 -11950 10372 -12000 10394 -12050 10414
--12100 10433 -12160 10454 -12210 10477 -12280 10501 -12350 10524 -12430 10549
--12470 10567 -12540 10582 -12600 10604 -12680 10621 -12750 10639 -12810 10653
--12860 10663 -12900 10672 -12940 10678 -12990 10683 -13040 10684 -13060 10683
--13080 10679 -13100 10670 -13100 10660 -13100 10646 -13080 10627 -13080 10607
--13050 10590 -13020 10569 -12980 10543 -12940 10514 -12880 10484 -12830 10453
--12760 10424 -12710 10398 -12640 10366 -12560 10332 -12480 10300 -12400 10273
--12340 10250 -12270 10230 -12200 10207 -12130 10186 -12060 10168 -12000 10157
--11950 10152 -11920 10156 -11880 10158 -11860 10166 -11830 10178 -11820 10197
--11830 10225 -11850 10258 -11890 10297 -11920 10344 -11980 10397 -12050 10453
--12120 10516 -12220 10586 -12320 10666 -12460 10748 -12590 10841 -12730 10938
--12880 11035 -13040 11137 -13220 11247 -13420 11363 -13620 11485 -13830 11607
--14030 11727 -14230 11845 -14440 11973 -14690 12107 -14910 12241 -15140 12370
--15360 12492 -15570 12615 -15790 12739 -16010 12865 -16230 12987 -16440 13103
--16630 13209 -16820 13307 -16990 13412 -17150 13505 -17310 13590 -17440 13671
--17590 13743 -17730 13804 -17830 13856 -17910 13896 -17960 13924 -18040 13947
--18130 13961 -18190 13956 -18220 13936 -18190 13901 -18180 13861 -18180 13799
--18160 13723 -18140 13625 -18120 13498 -18100 13368 -18070 13223 -18050 13052
--18080 12861 -18080 12640 -17970 12375 -17860 12100 -17820 11827 -17820 11517
--17730 11142 -17470 10766 -17160 10441 -16930 10130 -16750 9791 -16530 9427
--16110 9078 -15540 8777 -14950 8516 -14480 8282 -14070 8080 -13600 7942
--13000 7857 -12200 7801 -11360 7761 -10680 7732 -10230 7718 -10000 7742
--9820 7780 -9480 7785 -8930 7791 -8290 7893 -7710 8078 -7340 8240 -7230 8281
--7380 8192 -7720 7986 -8150 7638 -8390 7116 -8310 6448 -7900 5708 -8640 4755
--9140 3611 -9530 2655 -9430 2199 -8270 2420 -5550 3153 -3790 4799 110 11954
--6140 8552 -3030 8250 -2160 8058 2920 8285 14870 11009 2370 8385 -700 8076
--270 8416 1150 8674 2170 9093 2430 8813 1040 8060 -540 8198 -2790 8669
--5370 9096 -5680 8988 -1040 7851 1190 8196 1820 8746 1400 8839 -170 8584
--1150 8625 -1860 9084 -2520 9756 -3080 10322 -3250 10520 -3850 10813 -3560 11105
--4390 11070 -6470 9327 -4920 9129 -410 9990 -2270 9124 -5140 9363 -5490 9918
--6910 10186 -6050 10887 -4690 11164 -4510 11306 -6480 11499 -5110 12081
--1290 12896 -470 9438 -17930 9601 -11570 11297 -9690 12673 -21360 10595
--16200 11599 -17920 10922 -17330 9949 -18020 10658 -6460 7395 -7962 6959
--32854 4477 -41065 6278 -14367 9211 -10168 8289 -9094 -2570 -2662 -4254
-1079 5008 -2429 7756 -9127 8506 -11692 8447 -13464 7742 9790 6885 15293 6568
-13107 6921 -3687 8805 -7155 9360 -8732 9254 -2315 9206 15763 8378 30403 7159
-45743 5138 55265 2926 45010 1898 1570 3772 -32720 6976 -40687 9770 -25053 8652
--15580 10233 -5317 9928 -3338 9799 -8255 9432 -12330 8528 -11257 7190
--10348 6474 -10114 6020 -11170 5526 -5384 5781 -4162 5016 -6438 5295 -9675 6385
--9007 5551 -8521 5187 99 9599 -346 9679 -15763 3157 -4737 4910 -13658 2167
--8104 3282 21826 14806 13662 12124 6454 10352 1711 10748 -2467 9922 -8124 7883
--7414 8079 -4965 9863 -3871 11100 -4002 11527 -4935 10842 -5871 10126
--4702 8661 -5900 8092 -7620 7854 -9788 7717 -13272 7031 -7744 7973 -5700 8696
--5141 9141 -7472 9551 -8520 10348 -7661 10202 4242 7629 4311 6979 1421 6990
--2342 7355 -5621 7055 -2182 8703 -2041 9495 -6448 9617 -22868 10468 -19545 10085
--12847 10139 -1784 10809 16985 12049 23382 13413 19368 14177 12732 14569
-6899 14839 3662 14928 2510 14847 2666 14378 2255 12616 -4256 5649 -5369 4365
--4578 4638 -2810 5684 -626 6799 861 7201 -853 5195 992 4414 1489 5191 402 7029
--1010 8955 3742 5238 5378 6079 5894 7063 874 6986 -1807 8030 -8643 11390
--17816 12224 -13065 11790 -4121 10831 1941 9577 1287 8791 1007 8257 2832 7885
-3445 8753 5403 10335 -7141 6625 -4124 10399 -942 12843 -4495 10566 -5544 9538
--10596 6363 -4771 9510 -10615 9420 -16554 8073 -8450 6505 10004 10183
--24708 7428 -68331 5220 -76624 6833 -60544 9825 -41611 12113 -27340 13288
--18545 13594 -14048 13385 -12433 12939 -12546 12432 -13541 11956 -14886 11551
--16202 11217 -17330 10952 -18172 10739 -18718 10566 -19006 10420 -19060 10296
--18939 10186 -18683 10088 -18349 9999 -17945 9918 -17514 9844 -17052 9778
--16602 9717 -16152 9664 -15710 9617 -15277 9575 -14867 9538 -14472 9508
--14086 9482 -13717 9462 -13370 9446 -13034 9434 -12715 9426 -12414 9421
--12121 9420 -11852 9421 -11592 9425 -11351 9432 -11115 9439 -10887 9449
--10657 9458 -10449 9471 -10233 9485 -10040 9503 -9974 9520 -9820 9536
--9650 9551 -9487 9566 -9336 9580 -9210 9597 -9099 9613 -8995 9629 -8900 9645
--8800 9659 -8712 9674 -8634 9687 -8562 9701 -8493 9713 -8433 9726 -8369 9738
--8314 9749 -8265 9759 -8224 9769 -8183 9779 -8148 9788 -8110 9796 -8082 9804
--8052 9811 -8026 9818 -8004 9824 -7991 9831 -7968 9836 -7957 9842 -7942 9846
--7935 9851 -7925 9856 -7915 9859 -7914 9864 -7905 9867 -7901 9871 -7903 9874
--7903 9877 -7904 9880 -7910 9883 -7908 9886 -7919 9889 -7927 9892 -7933 9895
--7942 9897 -7951 9900 -7961 9903 -7964 9906 -7986 9908 -7985 9912 -8005 9915
--8009 9918 -8022 9921 -8036 9925 -8049 9928 -8064 9932 -8076 9936
-171: 13272560 -4949894 -9830 9828 -9840 9838 -9860 9842 -9880 9851 -9900 9857
--9910 9865 -9930 9873 -9960 9882 -9960 9890 -9990 9895 -10020 9906 -10040 9914
--10060 9924 -10090 9930 -10110 9938 -10130 9944 -10160 9952 -10190 9960
--10210 9965 -10230 9970 -10250 9976 -10270 9980 -10290 9985 -10310 9984
--10330 9991 -10350 9996 -10360 9999 -10380 10001 -10390 10004 -10410 10005
--10420 10007 -10440 10011 -10460 10015 -10460 10017 -10490 10020 -10510 10023
--10530 10028 -10540 10034 -10580 10044 -10600 10048 -10620 10056 -10650 10062
--10690 10071 -10710 10084 -10750 10091 -10800 10101 -10830 10113 -10880 10126
--10920 10137 -10960 10150 -11010 10162 -11060 10175 -11110 10187 -11170 10196
--11210 10209 -11260 10220 -11310 10231 -11350 10242 -11400 10250 -11430 10258
--11490 10266 -11520 10270 -11570 10275 -11580 10278 -11620 10280 -11630 10281
--11670 10283 -11690 10285 -11700 10285 -11710 10280 -11720 10276 -11720 10272
--11740 10271 -11730 10269 -11730 10265 -11730 10260 -11710 10256 -11720 10253
--11720 10249 -11720 10250 -11710 10249 -11710 10248 -11700 10251 -11700 10253
--11720 10259 -11720 10262 -11740 10273 -11750 10282 -11770 10293 -11790 10303
--11820 10318 -11860 10333 -11890 10349 -11930 10369 -11990 10392 -12040 10410
--12080 10428 -12130 10448 -12190 10468 -12260 10494 -12330 10518 -12400 10539
--12450 10557 -12510 10573 -12580 10591 -12650 10610 -12710 10626 -12770 10639
--12830 10649 -12870 10658 -12900 10662 -12950 10667 -13000 10667 -13020 10665
--13030 10661 -13050 10654 -13060 10643 -13060 10625 -13050 10610 -13030 10590
--13010 10572 -12990 10552 -12940 10526 -12900 10498 -12840 10467 -12790 10437
--12730 10410 -12680 10385 -12610 10352 -12530 10320 -12460 10290 -12380 10263
--12320 10241 -12250 10222 -12190 10200 -12110 10180 -12050 10164 -11990 10152
--11940 10149 -11910 10152 -11880 10158 -11850 10165 -11820 10179 -11820 10200
--11820 10226 -11850 10259 -11880 10299 -11910 10345 -11970 10399 -12030 10455
--12120 10517 -12200 10587 -12310 10664 -12430 10748 -12550 10840 -12700 10935
--12850 11031 -13000 11131 -13170 11240 -13370 11355 -13560 11473 -13760 11592
--13960 11710 -14150 11827 -14360 11954 -14580 12082 -14820 12214 -15030 12341
--15250 12460 -15440 12579 -15660 12700 -15870 12822 -16090 12941 -16290 13054
--16460 13156 -16650 13251 -16820 13349 -16970 13439 -17130 13521 -17250 13598
--17400 13665 -17520 13722 -17640 13768 -17700 13805 -17770 13830 -17820 13847
--17900 13853 -17970 13844 -17990 13820 -17990 13780 -17980 13727 -17970 13660
--17960 13579 -17920 13479 -17910 13349 -17860 13211 -17820 13047 -17820 12866
--17850 12666 -17820 12429 -17710 12170 -17650 11914 -17630 11642 -17590 11310
--17400 10937 -17120 10603 -16890 10313 -16800 9984 -16730 9580 -16500 9153
--16040 8773 -15420 8480 -14850 8244 -14430 8030 -14020 7843 -13500 7703
--12780 7603 -11930 7513 -11090 7427 -10500 7367 -10180 7355 -10070 7394
--9900 7448 -9440 7474 -8680 7526 -7800 7665 -7100 7868 -6670 8050 -6560 8133
--6700 8044 -7030 7730 -7430 7172 -7610 6458 -7330 5740 -6430 5145 -6340 4538
--6590 3860 -7320 3502 -8050 3748 -7810 5071 -3470 6803 -2720 7064 -2060 10056
--9950 7745 -23550 4055 -44920 -856 21220 13371 41990 17899 12020 10719
-3840 8894 1280 8409 670 8468 440 8906 430 8944 -140 8760 -1220 8808 -2790 9032
--4120 9313 -3830 9365 -1320 9025 570 9084 1430 9130 1360 8883 510 8559
--350 8559 -1110 9013 -1820 9688 -2380 10218 -2660 10478 -2970 10642 -2900 10653
--3020 10288 -3600 9439 -2020 9158 400 9413 -550 9185 -6560 9948 -7320 10215
--7340 10454 -6390 10971 -5620 11444 -7090 12221 -8360 13044 -8180 14329
--7480 15198 -7340 9529 -17160 10265 -6880 12632 -10230 13204 -20990 10811
--12450 13005 -16160 10475 -16490 8967 -16660 9316 -12520 7113 -14880 5880
--15270 3713 -29014 6161 -16442 8507 -8955 6545 -13147 -563 -8228 -1708
--4232 3443 -5146 6543 -8335 7889 -9470 8149 -6905 7779 7030 7218 12620 7022
-9941 7418 -972 8559 -6332 9180 -7248 9304 -469 9172 14559 8416 28917 7179
-40448 5317 44030 3502 33000 2679 6240 3672 -18360 5801 -29820 8023 -27550 9025
--15000 10300 -10530 10914 -9839 11257 -11430 11362 -11791 10591 -11817 4821
--9168 4728 -7833 4880 -12983 4321 -9111 5100 -8054 5200 -11504 5593 -10023 4932
--9060 3582 -6609 3920 1168 9178 -5402 7441 -18128 3114 2916 8931 -7730 5531
--5409 6206 30645 16728 8955 10443 3565 9875 -141 9952 -5071 8788 -5077 7766
--5378 8062 -4398 9523 -3809 10826 -3803 11247 -4391 10726 -5111 9861 -5348 8670
--6253 7994 -7401 7615 -9484 7216 -13462 7360 -11368 8022 -9484 8896 -4443 9829
--3974 10554 -4389 10868 -2677 10286 4395 8543 6678 7697 6106 7546 2995 7747
--4625 7699 -5094 8603 -5559 9238 -9349 9559 -18055 9831 -17950 8669 -8029 9319
-4761 10520 15227 11845 19526 13625 14117 14109 7611 14186 1623 14329 -601 14086
--913 13618 328 12694 1647 10514 -2870 6054 -4540 4469 -4209 4370 -2780 5447
--423 6948 2402 8495 -2694 4602 2111 3196 3058 3481 1409 4754 -2992 7397
--1294 6646 1271 8051 5433 8701 -1081 7201 -1459 7476 -16293 12475 -22039 12711
--17141 11935 -5595 11033 1070 9318 2076 7603 2028 6107 2982 4942 4391 4590
-5463 5624 77 8749 3313 13389 2624 14963 -4379 13163 -1651 13027 -10088 5183
-397 8209 -1630 8676 -13364 7439 -17388 8760 13171 6603 -11562 7595 -42879 8336
--59542 9523 -58402 11108 -49106 12401 -38791 13110 -30486 13279 -24838 13092
--21473 12727 -19763 12310 -19108 11913 -19052 11566 -19248 11277 -19502 11039
--19676 10843 -19744 10678 -19675 10536 -19488 10411 -19202 10298 -18846 10195
--18437 10102 -17995 10016 -17538 9938 -17074 9866 -16607 9800 -16151 9743
--15722 9691 -15289 9644 -14877 9604 -14487 9570 -14111 9540 -13745 9515
--13398 9498 -13062 9481 -12757 9469 -12457 9461 -12165 9457 -11896 9455
--11641 9456 -11400 9460 -11164 9465 -10939 9471 -10716 9479 -10502 9488
--10294 9501 -10094 9515 -10028 9531 -9877 9544 -9712 9558 -9549 9571 -9397 9585
--9269 9598 -9162 9614 -9054 9629 -8956 9643 -8859 9656 -8771 9670 -8689 9682
--8614 9695 -8549 9707 -8484 9719 -8424 9730 -8363 9741 -8313 9751 -8275 9760
--8232 9769 -8193 9778 -8155 9786 -8123 9794 -8095 9800 -8069 9808 -8043 9813
--8031 9820 -8007 9826 -7998 9830 -7982 9836 -7968 9841 -7961 9844 -7954 9849
--7946 9852 -7942 9857 -7936 9860 -7936 9863 -7937 9867 -7937 9869 -7941 9873
--7939 9876 -7950 9878 -7956 9882 -7965 9884 -7971 9887 -7976 9890 -7986 9892
--7994 9896 -8011 9899 -8011 9901 -8030 9905 -8037 9908 -8045 9911 -8056 9914
--8073 9918 -8087 9922 -8095 9926
-172: 13304640 -4941118 -9860 9830 -9850 9836 -9880 9846 -9900 9851 -9910 9858
--9930 9866 -9950 9873 -9960 9882 -9980 9889 -10010 9898 -10040 9905 -10050 9914
--10080 9924 -10100 9931 -10120 9936 -10140 9946 -10170 9950 -10200 9959
--10220 9963 -10230 9970 -10260 9975 -10280 9979 -10300 9984 -10310 9985
--10340 9991 -10360 9996 -10370 9997 -10380 10001 -10400 10004 -10410 10004
--10420 10008 -10450 10010 -10460 10014 -10470 10017 -10490 10022 -10510 10022
--10520 10030 -10560 10035 -10570 10042 -10600 10049 -10620 10057 -10660 10063
--10670 10070 -10710 10082 -10750 10091 -10790 10102 -10830 10113 -10870 10123
--10910 10136 -10950 10151 -11000 10161 -11050 10173 -11100 10184 -11150 10194
--11210 10207 -11240 10216 -11290 10229 -11330 10238 -11380 10246 -11430 10255
--11460 10262 -11500 10268 -11540 10271 -11570 10275 -11590 10277 -11620 10277
--11640 10278 -11670 10282 -11680 10281 -11690 10275 -11700 10273 -11700 10271
--11710 10268 -11720 10267 -11710 10262 -11710 10257 -11700 10254 -11700 10251
--11700 10248 -11700 10248 -11700 10248 -11690 10248 -11680 10249 -11690 10252
--11710 10257 -11710 10263 -11730 10270 -11730 10280 -11760 10291 -11780 10303
--11810 10315 -11830 10329 -11880 10347 -11920 10367 -11970 10387 -12020 10406
--12060 10423 -12120 10443 -12170 10462 -12240 10487 -12310 10509 -12370 10530
--12420 10546 -12480 10565 -12550 10581 -12620 10598 -12680 10614 -12740 10626
--12790 10635 -12840 10643 -12870 10648 -12900 10651 -12950 10651 -12980 10648
--13000 10646 -13010 10636 -13020 10624 -13010 10609 -13000 10593 -13000 10573
--12970 10554 -12940 10534 -12910 10511 -12860 10482 -12810 10452 -12750 10422
--12700 10396 -12650 10371 -12580 10340 -12500 10308 -12430 10278 -12360 10253
--12300 10232 -12230 10214 -12170 10194 -12110 10172 -12030 10159 -11980 10149
--11930 10145 -11900 10149 -11870 10156 -11850 10165 -11810 10178 -11820 10199
--11820 10226 -11840 10260 -11870 10299 -11900 10345 -11960 10399 -12020 10455
--12100 10517 -12190 10585 -12280 10662 -12400 10745 -12530 10838 -12670 10928
--12810 11024 -12960 11123 -13120 11230 -13320 11342 -13500 11458 -13690 11576
--13880 11691 -14070 11806 -14280 11928 -14490 12056 -14710 12184 -14930 12307
--15130 12424 -15320 12538 -15530 12657 -15740 12774 -15940 12892 -16140 13000
--16300 13099 -16480 13189 -16650 13282 -16800 13368 -16940 13446 -17080 13518
--17210 13583 -17320 13635 -17430 13678 -17500 13709 -17570 13727 -17620 13739
--17680 13741 -17730 13727 -17770 13699 -17780 13653 -17780 13590 -17760 13514
--17750 13430 -17710 13324 -17690 13198 -17630 13049 -17580 12876 -17590 12686
--17600 12472 -17530 12222 -17450 11969 -17430 11724 -17420 11439 -17310 11086
--17070 10730 -16800 10440 -16680 10157 -16680 9785 -16660 9328 -16350 8878
--15780 8524 -15150 8272 -14680 8058 -14370 7835 -14040 7608 -13530 7412
--12790 7254 -11930 7111 -11130 6986 -10600 6916 -10390 6923 -10310 6999
--10040 7093 -9320 7188 -8210 7320 -7030 7513 -6150 7752 -5710 7972 -5630 8121
--5790 8067 -6180 7664 -6630 6910 -6880 6020 -6520 5321 -4780 5046 -3500 4798
--3410 4576 -4560 4707 -6320 5138 -9270 7180 -3290 9135 -1080 9007 -1740 9804
--9400 7704 -30800 2251 -105120 -14071 43180 18664 52710 20725 27100 14543
-11590 10715 4230 8912 910 8412 -650 8808 -830 9047 -580 9345 -1040 9442
--2210 9457 -3100 9599 -2910 9779 -1530 9853 -120 9889 790 9634 1090 9002
-720 8436 80 8321 -650 8837 -1390 9632 -2020 10137 -2480 10272 -2880 10310
--2830 10216 -2180 9899 -1790 9072 -420 9033 340 9412 -1650 9508 -5920 10050
--7540 10328 -7730 10590 -7270 11019 -7190 11544 -8350 12316 -9440 13278
--9800 14368 -9700 14631 -9680 12334 -11620 13112 -5890 15597 -5410 17710
--8700 17803 -19770 7231 -19890 6623 -18490 6874 -17240 7266 -15200 6351
--14950 5398 -14290 4569 -19540 5867 -15140 6892 -11190 5375 -12270 1761
--10000 955 -7560 3461 -7225 5870 -7917 7279 -7183 7808 -3427 7781 4483 7549
-8427 7485 6464 7779 -165 8433 -4896 8931 -5409 9129 359 9057 11819 8549
-23780 7453 32420 5867 33860 4376 25230 3629 7970 4059 -9350 5472 -19920 7249
--21720 8654 -16560 9866 -14330 10696 -14480 11115 -15730 10708 -16049 8945
--10725 5566 -9474 4977 -9454 4352 -11887 3833 -9377 4942 -10268 4657 -11336 4556
--12220 4773 -8502 4228 -1166 5058 6052 8951 851 7763 -3557 7238 -542 9822
--9015 6361 -5593 6546 12643 11601 7959 10617 4834 10612 1477 10208 -4478 8085
--4895 7329 -4287 7930 -3410 9355 -3064 10608 -3073 10925 -3416 10430 -4222 9514
--6085 8452 -7146 7857 -7620 7591 -10097 6947 -11234 7303 -10048 8028 -8840 9074
--4332 10420 -486 11460 -688 11437 -127 10631 3370 9342 6032 8454 7447 8127
-6776 8379 -6245 8590 -6951 9229 -7992 9357 -10999 9350 -14554 9335 -16387 6807
--1084 8953 15379 10831 26191 11887 7855 13814 5713 13466 1209 12969 -5847 13164
--6187 12396 -6091 11501 -3928 10378 1885 8614 -2451 5752 -4056 4280 -3741 4979
--3561 5298 -2553 5849 1523 7972 56 5997 2546 4206 3692 3109 2107 2707 -7710 6689
--8896 7201 -10150 10724 -6228 11526 2005 9785 -1055 9638 -14457 11728
--22625 11845 -19848 11204 -3542 11090 1748 8711 1304 6214 10 3983 -398 1986
-1153 181 4516 -17 4876 9591 13623 16373 7548 16121 -16852 10163 -21675 6228
-13025 13808 18346 12658 11077 10325 -18207 6540 -127975 274 109090 9153
-15383 9078 -28387 10794 -48541 12046 -53518 12930 -50173 13453 -43711 13611
--37112 13469 -31684 13138 -27710 12726 -25029 12309 -23329 11930 -22283 11606
--21637 11335 -21203 11112 -20847 10925 -20505 10766 -20158 10624 -19760 10499
--19339 10384 -18892 10280 -18420 10183 -17952 10093 -17477 10011 -17006 9935
--16541 9868 -16096 9806 -15663 9750 -15242 9700 -14834 9658 -14450 9620
--14086 9588 -13726 9560 -13383 9539 -13060 9520 -12750 9506 -12459 9495
--12176 9487 -11918 9484 -11664 9482 -11416 9484 -11191 9486 -10966 9490
--10749 9496 -10535 9503 -10330 9513 -10134 9527 -10068 9539 -9927 9552
--9757 9563 -9593 9575 -9446 9587 -9319 9601 -9208 9613 -9101 9628 -9004 9640
--8905 9653 -8820 9665 -8738 9678 -8662 9689 -8592 9701 -8528 9712 -8468 9722
--8409 9733 -8360 9742 -8314 9751 -8274 9760 -8236 9769 -8198 9776 -8164 9784
--8133 9791 -8108 9797 -8083 9803 -8066 9810 -8047 9815 -8032 9820 -8015 9826
--8000 9829 -7993 9835 -7986 9838 -7979 9842 -7974 9847 -7971 9850 -7966 9853
--7968 9856 -7967 9860 -7969 9862 -7971 9866 -7976 9869 -7985 9872 -7991 9874
--7997 9877 -8006 9880 -8012 9884 -8016 9886 -8031 9889 -8038 9892 -8052 9895
--8059 9898 -8071 9902 -8079 9905 -8096 9908 -8108 9913 -8116 9916
-173: 13336750 -4932351 -9870 9832 -9880 9837 -9900 9845 -9910 9853 -9930 9860
--9940 9867 -9960 9874 -9980 9881 -10010 9890 -10020 9898 -10040 9906 -10070 9914
--10090 9924 -10110 9930 -10130 9936 -10160 9945 -10180 9949 -10200 9959
--10230 9962 -10250 9969 -10270 9975 -10280 9978 -10300 9983 -10320 9987
--10350 9989 -10370 9995 -10380 9998 -10380 10001 -10410 10002 -10410 10004
--10430 10008 -10450 10011 -10460 10012 -10480 10017 -10490 10021 -10510 10024
--10520 10030 -10560 10037 -10570 10042 -10600 10048 -10630 10057 -10650 10064
--10670 10071 -10710 10082 -10740 10089 -10790 10101 -10820 10111 -10870 10124
--10900 10135 -10940 10148 -10990 10159 -11040 10171 -11090 10182 -11140 10194
--11190 10203 -11220 10213 -11270 10224 -11330 10235 -11360 10244 -11400 10253
--11450 10259 -11480 10264 -11520 10267 -11540 10271 -11580 10273 -11590 10274
--11620 10276 -11650 10277 -11660 10277 -11670 10270 -11680 10271 -11680 10268
--11690 10265 -11690 10264 -11700 10261 -11690 10254 -11680 10250 -11680 10248
--11690 10248 -11680 10246 -11680 10244 -11680 10248 -11670 10250 -11670 10250
--11690 10257 -11700 10260 -11710 10270 -11720 10279 -11750 10289 -11770 10301
--11790 10311 -11820 10329 -11870 10345 -11910 10364 -11940 10382 -12000 10402
--12050 10418 -12100 10437 -12150 10458 -12220 10480 -12280 10499 -12340 10522
--12400 10538 -12450 10555 -12520 10570 -12580 10588 -12650 10602 -12710 10613
--12760 10623 -12800 10629 -12830 10633 -12870 10635 -12910 10634 -12940 10633
--12950 10630 -12970 10618 -12980 10609 -12970 10592 -12960 10576 -12960 10558
--12930 10537 -12900 10518 -12870 10494 -12820 10466 -12780 10437 -12720 10408
--12660 10382 -12620 10357 -12550 10328 -12480 10297 -12410 10268 -12330 10243
--12280 10221 -12210 10206 -12160 10186 -12080 10168 -12020 10153 -11970 10142
--11920 10143 -11900 10146 -11860 10153 -11830 10163 -11820 10177 -11800 10197
--11820 10224 -11830 10259 -11860 10300 -11900 10344 -11940 10396 -12010 10452
--12080 10516 -12170 10582 -12270 10658 -12370 10741 -12500 10831 -12630 10921
--12780 11016 -12910 11111 -13080 11215 -13260 11328 -13440 11441 -13620 11556
--13810 11667 -13990 11780 -14190 11901 -14400 12027 -14620 12150 -14810 12270
--15020 12383 -15200 12495 -15400 12608 -15600 12725 -15800 12838 -15990 12942
--16150 13036 -16320 13124 -16480 13211 -16630 13293 -16760 13367 -16900 13436
--17010 13495 -17130 13544 -17230 13580 -17310 13607 -17370 13620 -17410 13626
--17470 13625 -17510 13606 -17540 13573 -17560 13522 -17550 13453 -17550 13369
--17530 13275 -17500 13166 -17470 13040 -17400 12884 -17350 12708 -17340 12511
--17330 12284 -17250 12027 -17190 11781 -17190 11537 -17160 11226 -17010 10865
--16740 10539 -16520 10271 -16500 9963 -16560 9546 -16470 9063 -16040 8641
--15380 8351 -14780 8148 -14470 7926 -14370 7633 -14220 7298 -13820 6993
--13090 6757 -12200 6581 -11390 6459 -10890 6413 -10740 6471 -10640 6608
--10200 6786 -9100 6985 -7440 7210 -5860 7470 -4770 7757 -4360 8038 -4440 8293
--4610 8365 -5010 7936 -5670 6987 -6060 5901 -6210 5220 -3070 5644 -470 5707
--160 5922 -1430 6415 -2000 6286 -7440 9351 -4220 10108 -4270 9587 -3000 9981
--8300 8057 -22430 3993 -44660 -1317 8260 10712 24020 14673 17710 12908
-9360 10449 3630 8701 200 8004 -2050 8792 -1760 8985 -200 9869 -140 10020
--1440 9781 -2390 9810 -2450 10078 -1740 10405 -780 10577 140 10217 720 9117
-610 8210 150 7872 -510 8560 -1240 9720 -1920 10180 -2520 9987 -3280 9880
--3730 9659 -2990 9296 160 8800 680 8827 300 9549 -2820 9678 -6170 10157
--7860 10379 -8210 10586 -8040 10897 -8180 11261 -9040 11808 -9940 12649
--10340 13675 -10160 14268 -9530 14132 -8650 15259 -5480 17183 -4940 18318
--8260 16655 -16450 9539 -18820 7072 -18530 6559 -17400 6525 -15980 6024
--14850 5468 -14090 5228 -15300 5807 -13590 6116 -11680 5140 -11450 3361
--10270 2905 -8890 4185 -8180 5807 -7610 6985 -5910 7617 -2370 7833 2530 7839
-5150 7868 3880 8069 -350 8423 -3980 8697 -4410 8855 -60 8905 8420 8608
-17670 7748 24230 6555 25240 5369 19360 4634 8110 4711 -3940 5607 -12640 6890
--16330 8105 -16100 9178 -16180 10012 -17080 10311 -18020 9676 -17580 8131
--14180 6115 -12310 5135 -11146 4406 -10498 4041 -9124 4468 -11617 3743
--14013 3981 -11671 4868 -6992 5041 4513 5893 9911 8288 8347 8856 7298 9355
--5980 9244 -8974 7743 -10197 5340 -580 7983 4873 10226 6152 11398 4770 11230
--4001 7602 -4016 7213 -2735 8110 -1867 9532 -1900 10624 -2350 10707 -2514 10092
--2943 9098 -7074 7955 -8372 7545 -7171 7821 -10716 6549 -8227 7240 -6105 7879
--7794 8933 -3611 10908 4656 12674 1626 12177 -465 11151 601 10063 2217 9151
-2568 8472 1163 8427 -289 10391 -2997 10470 -7546 9284 -13115 7973 -17486 6949
--15486 6412 4645 10537 18164 12784 23157 13378 13840 13091 8034 11922
-357 10810 -12509 11601 -10336 10173 -11445 9047 -10444 8035 820 7291 -1073 5654
--2876 4683 -3447 5457 -4129 5619 -3905 5757 -1605 6638 -501 7088 1295 6132
-1286 5141 -1885 4345 -9108 3886 -12648 5176 -19718 13070 -17277 14564
-8171 12187 2294 11629 -11568 11652 -22262 11057 -23677 10119 1290 11326
-1226 7609 -2400 4933 -5168 2878 -7404 1380 -6423 4 -931 -236 9027 4260
-27092 17050 19537 17277 -22359 9472 -18894 7697 11016 12160 22318 12574
-13717 10905 -17508 7614 -64813 7256 73811 -5607 6632 8152 -25402 12509
--41617 14147 -47784 14699 -47599 14704 -44093 14399 -39458 13927 -34963 13389
--31175 12863 -28218 12388 -26022 11986 -24416 11655 -23230 11385 -22323 11163
--21593 10980 -20964 10822 -20395 10682 -19847 10557 -19322 10442 -18810 10337
--18300 10237 -17807 10147 -17329 10063 -16857 9987 -16396 9915 -15963 9852
--15543 9794 -15133 9744 -14736 9698 -14363 9658 -14007 9625 -13664 9595
--13329 9571 -13019 9551 -12712 9534 -12428 9522 -12149 9512 -11900 9506
--11653 9503 -11412 9502 -11194 9503 -10972 9505 -10762 9510 -10544 9515
--10351 9524 -10154 9534 -10099 9547 -9957 9557 -9785 9568 -9622 9578 -9485 9588
--9354 9600 -9242 9613 -9141 9625 -9041 9638 -8940 9649 -8858 9661 -8778 9672
--8699 9683 -8635 9694 -8565 9705 -8506 9715 -8450 9724 -8396 9734 -8349 9743
--8311 9751 -8275 9759 -8232 9767 -8199 9774 -8167 9781 -8144 9787 -8118 9794
--8100 9799 -8083 9806 -8059 9810 -8045 9816 -8036 9819 -8024 9825 -8017 9828
--8009 9833 -8003 9836 -8000 9840 -7995 9844 -7997 9847 -7996 9850 -7995 9853
--8000 9856 -8004 9860 -8006 9862 -8011 9865 -8025 9869 -8033 9871 -8036 9874
--8041 9877 -8053 9880 -8063 9883 -8073 9886 -8080 9890 -8090 9892 -8099 9896
--8118 9900 -8124 9903 -8134 9907
-174: 13368890 -4923595 -9890 9834 -9890 9840 -9920 9847 -9930 9854 -9940 9861
--9960 9868 -9980 9874 -9990 9881 -10020 9890 -10030 9898 -10060 9908 -10080 9916
--10100 9921 -10130 9931 -10140 9936 -10170 9942 -10190 9949 -10210 9958
--10240 9964 -10260 9968 -10270 9974 -10300 9976 -10310 9984 -10330 9985
--10350 9989 -10370 9995 -10390 9999 -10380 10000 -10410 10002 -10420 10003
--10440 10006 -10450 10011 -10460 10013 -10490 10016 -10490 10021 -10510 10025
--10530 10031 -10560 10037 -10570 10042 -10590 10047 -10630 10056 -10650 10066
--10670 10071 -10710 10080 -10740 10090 -10780 10101 -10820 10111 -10850 10123
--10900 10133 -10940 10144 -10970 10158 -11040 10169 -11080 10180 -11120 10191
--11170 10202 -11220 10211 -11250 10217 -11300 10233 -11350 10241 -11380 10251
--11430 10254 -11470 10260 -11490 10263 -11530 10268 -11550 10269 -11580 10271
--11600 10272 -11620 10272 -11640 10272 -11650 10269 -11650 10267 -11670 10266
--11670 10261 -11670 10261 -11680 10258 -11670 10252 -11660 10246 -11670 10247
--11660 10246 -11670 10245 -11660 10243 -11660 10247 -11660 10247 -11660 10251
--11670 10254 -11680 10260 -11700 10268 -11720 10278 -11730 10286 -11750 10300
--11780 10311 -11810 10327 -11850 10341 -11890 10359 -11930 10380 -11980 10397
--12030 10414 -12080 10432 -12130 10450 -12200 10473 -12250 10493 -12320 10513
--12370 10531 -12430 10545 -12480 10561 -12560 10577 -12610 10589 -12670 10602
--12720 10609 -12770 10616 -12790 10620 -12840 10621 -12860 10620 -12910 10616
--12910 10612 -12930 10603 -12930 10593 -12930 10577 -12930 10560 -12910 10543
--12890 10523 -12870 10501 -12830 10478 -12780 10450 -12740 10422 -12680 10395
--12640 10369 -12590 10343 -12520 10315 -12450 10287 -12390 10258 -12310 10233
--12250 10212 -12200 10196 -12140 10180 -12070 10162 -12000 10145 -11960 10138
--11910 10139 -11890 10143 -11850 10149 -11820 10159 -11800 10174 -11810 10196
--11810 10222 -11820 10256 -11850 10298 -11880 10342 -11940 10393 -11990 10448
--12070 10511 -12150 10578 -12240 10652 -12350 10734 -12470 10822 -12600 10912
--12730 11005 -12880 11097 -13030 11200 -13190 11309 -13380 11421 -13560 11532
--13730 11642 -13920 11754 -14100 11869 -14310 11993 -14510 12113 -14720 12231
--14890 12340 -15090 12446 -15270 12558 -15470 12670 -15660 12780 -15840 12880
--16000 12970 -16150 13053 -16320 13139 -16450 13217 -16600 13283 -16710 13349
--16830 13402 -16930 13447 -17040 13480 -17110 13503 -17170 13512 -17210 13511
--17250 13502 -17290 13481 -17310 13443 -17340 13388 -17330 13314 -17320 13223
--17300 13122 -17280 13009 -17240 12879 -17170 12718 -17120 12543 -17090 12343
--17050 12102 -16960 11847 -16910 11607 -16930 11351 -16880 11020 -16660 10668
--16420 10365 -16260 10095 -16320 9750 -16380 9292 -16160 8819 -15590 8465
--14860 8254 -14380 8077 -14310 7791 -14530 7355 -14660 6848 -14400 6405
--13670 6114 -12640 5965 -11670 5918 -11120 5941 -10990 6068 -10940 6295
--10360 6591 -8750 6929 -6310 7227 -4200 7550 -2860 7903 -2660 8218 -3160 8625
--3150 9021 -3510 8664 -4410 7487 -4620 6145 -6790 5242 -1020 7236 1990 7528
-870 8554 -580 8537 -710 7962 -1930 9020 -2560 10334 -6590 9558 -4940 9661
--3910 9093 -3440 8119 3630 8568 -13480 5293 -3690 8715 2140 9823 2180 9243
-460 8146 -1290 7280 -3800 8996 -2410 8445 990 10229 1400 10389 -850 9759
--1970 9762 -2220 10097 -1960 10648 -1420 11141 -500 10997 400 9193 250 7946
--60 7166 -670 8204 -1310 10267 -1950 10567 -2370 9625 -3330 9464 -4500 9155
--4530 8803 1980 8424 470 8164 -340 9081 -4540 10143 -7450 10433 -8750 10395
--8850 10442 -8500 10612 -8570 10710 -9260 10912 -10050 11588 -10350 12830
--9980 13992 -8910 14960 -7340 16303 -5440 17627 -5400 17850 -8280 15848
--13500 11449 -16410 8734 -17120 7528 -16590 6981 -15560 6343 -14400 5925
--13520 5833 -13350 6035 -12360 6020 -11300 5374 -10740 4480 -9960 4291
--9100 5025 -8390 6076 -7410 6998 -5520 7628 -2480 7975 960 8112 2870 8192
-2110 8320 -770 8433 -3590 8492 -4180 8613 -1210 8748 4860 8578 11800 8047
-16890 7232 18040 6306 14420 5568 7140 5448 -1170 5906 -8070 6723 -12450 7656
--14780 8564 -16620 9264 -18340 9382 -19540 8799 -19530 7669 -17880 6344
--15990 5338 -13480 4524 -10220 4012 -8340 4117 -11026 3753 -15445 4422
--9402 4035 -3489 4766 4238 5988 8027 7783 7971 8841 5792 9257 -2871 8767
--7308 7303 -9872 5519 -7375 6260 2074 9817 4756 11276 4067 10987 -208 8890
--451 8302 362 9009 612 10180 -404 10921 -2255 10610 -2862 9735 -1182 8654
--7587 7260 -9538 6835 -7439 7872 -11064 6663 -4775 7528 543 7438 -7998 8038
--3287 11018 13129 14652 1242 12912 -3388 11696 -2875 10915 -1397 10235
--1836 9319 -4564 8269 6475 12769 2829 11908 -4887 9042 -13367 6535 -20402 4902
--19831 5165 8767 12767 16968 14932 19603 14899 19359 12353 13102 10532
-1514 8940 -10450 8780 -13748 7977 -14365 6917 -10381 5707 -7149 7067 -3849 5727
--3134 4817 -3462 6269 -5193 6213 -6490 5889 -5615 5640 -2783 7939 -708 7632
--1568 7373 -5546 6989 -11700 2903 -15003 5594 -13649 11582 -8520 14728
-4170 14568 272 13738 -9782 12187 -16750 11409 -15839 11325 -5965 9535
--7255 5100 -10233 3845 -12311 2966 -16177 3033 -15381 3047 -6258 3063
-16604 3156 24244 10727 10806 12953 -15231 9964 -12030 8729 14183 9783
-26207 10061 18046 8530 -9549 1158 -54779 -5410 53996 7106 6996 10245 -18749 13842
--33275 15577 -40441 16018 -42521 15751 -41408 15144 -38686 14414 -35430 13688
--32276 13037 -29525 12486 -27256 12042 -25449 11687 -24001 11408 -22843 11184
--21889 10998 -21084 10843 -20379 10705 -19736 10581 -19142 10468 -18589 10364
--18063 10266 -17562 10175 -17087 10092 -16627 10015 -16183 9945 -15759 9880
--15360 9823 -14959 9771 -14585 9724 -14226 9685 -13880 9650 -13554 9619
--13238 9594 -12939 9573 -12640 9555 -12360 9540 -12096 9530 -11852 9523
--11609 9518 -11386 9516 -11169 9516 -10953 9516 -10749 9519 -10545 9524
--10347 9531 -10158 9540 -10107 9552 -9974 9561 -9800 9569 -9638 9579 -9500 9589
--9379 9599 -9268 9611 -9164 9622 -9071 9634 -8972 9645 -8887 9656 -8805 9666
--8731 9677 -8664 9687 -8599 9698 -8536 9707 -8484 9717 -8426 9725 -8384 9734
--8345 9742 -8305 9750 -8261 9758 -8229 9765 -8198 9772 -8176 9778 -8152 9784
--8131 9790 -8111 9795 -8088 9801 -8074 9806 -8066 9810 -8055 9815 -8043 9819
--8040 9823 -8028 9827 -8024 9831 -8022 9835 -8022 9837 -8022 9841 -8021 9845
--8024 9847 -8031 9851 -8030 9853 -8034 9857 -8048 9859 -8051 9863 -8059 9866
--8066 9868 -8073 9872 -8084 9875 -8095 9877 -8102 9881 -8108 9885 -8120 9887
--8136 9892 -8138 9895 -8153 9898
-175: 13401070 -4914848 -9900 9836 -9910 9842 -9940 9850 -9940 9855 -9960 9862
--9980 9869 -9990 9874 -10010 9881 -10030 9890 -10050 9899 -10070 9910
--10090 9916 -10110 9921 -10140 9928 -10160 9936 -10180 9943 -10200 9950
--10220 9958 -10250 9962 -10270 9967 -10280 9974 -10300 9979 -10320 9981
--10340 9986 -10360 9988 -10370 9994 -10390 9998 -10400 9999 -10420 10000
--10420 10004 -10440 10006 -10460 10010 -10460 10013 -10490 10016 -10490 10022
--10520 10025 -10530 10031 -10550 10036 -10580 10044 -10600 10047 -10620 10055
--10650 10065 -10670 10071 -10710 10079 -10740 10090 -10760 10100 -10810 10111
--10850 10120 -10890 10132 -10930 10142 -10970 10156 -11030 10168 -11070 10177
--11110 10190 -11150 10198 -11200 10208 -11250 10216 -11270 10229 -11330 10237
--11370 10245 -11410 10251 -11450 10256 -11470 10260 -11510 10264 -11530 10265
--11560 10267 -11580 10268 -11600 10267 -11610 10269 -11630 10265 -11640 10265
--11640 10260 -11660 10261 -11650 10258 -11650 10254 -11650 10250 -11650 10246
--11650 10244 -11650 10243 -11650 10243 -11640 10243 -11650 10245 -11640 10246
--11650 10249 -11660 10253 -11670 10259 -11680 10267 -11700 10275 -11720 10285
--11740 10299 -11760 10310 -11790 10324 -11840 10338 -11870 10357 -11920 10374
--11950 10393 -12010 10410 -12060 10425 -12110 10446 -12180 10467 -12230 10487
--12290 10505 -12350 10521 -12390 10536 -12460 10552 -12520 10567 -12590 10577
--12630 10589 -12690 10598 -12720 10602 -12760 10608 -12800 10607 -12830 10605
--12860 10602 -12870 10595 -12890 10588 -12900 10578 -12880 10562 -12890 10544
--12870 10527 -12850 10508 -12830 10487 -12790 10464 -12750 10435 -12710 10408
--12650 10380 -12600 10357 -12550 10331 -12500 10303 -12420 10276 -12360 10248
--12290 10223 -12230 10204 -12180 10187 -12120 10172 -12060 10154 -11990 10141
--11950 10133 -11900 10132 -11870 10138 -11840 10146 -11820 10155 -11790 10171
--11790 10193 -11800 10220 -11820 10252 -11830 10294 -11880 10337 -11920 10389
--11980 10445 -12050 10504 -12130 10571 -12210 10645 -12320 10727 -12440 10811
--12570 10899 -12690 10989 -12830 11081 -12980 11183 -13140 11290 -13320 11397
--13490 11509 -13670 11614 -13830 11723 -14020 11835 -14220 11955 -14410 12073
--14600 12188 -14790 12293 -14960 12396 -15150 12505 -15340 12612 -15520 12718
--15690 12816 -15850 12900 -16000 12978 -16150 13063 -16290 13136 -16420 13198
--16530 13259 -16640 13307 -16750 13349 -16830 13377 -16910 13393 -16980 13399
--17000 13394 -17050 13380 -17070 13353 -17090 13312 -17110 13254 -17100 13175
--17090 13079 -17080 12971 -17030 12853 -17000 12717 -16920 12557 -16880 12383
--16830 12180 -16760 11930 -16660 11681 -16630 11446 -16640 11173 -16540 10836
--16310 10499 -16080 10212 -16000 9921 -16110 9533 -16100 9058 -15750 8625
--15030 8355 -14300 8213 -14000 8017 -14260 7605 -14880 6963 -15350 6241
--15260 5664 -14440 5374 -13050 5364 -11640 5496 -10920 5605 -10860 5795
--11000 6117 -10490 6559 -8400 7074 -4680 7375 -2060 7749 -440 8194 -740 8430
--2320 8936 -1570 10047 -1650 9891 -3310 8366 -1140 6876 -7660 5045 3970 9895
-2150 10248 -600 10398 -2180 10463 -1110 8864 1140 7713 -3240 10037 -7000 8510
--6440 8972 -3190 9386 -1100 9706 6180 9477 -4390 6182 -5060 7377 -2810 8742
--2020 8984 -2310 8622 -3070 7818 -3890 8718 -1080 7830 1580 9268 3100 10181
--940 9203 -1760 9469 -1900 9772 -2130 10434 -2030 11379 -920 12123 200 9221
--470 7909 -570 6330 -1110 7799 -1560 11773 -2200 11465 -1910 9118 -1970 9072
--3050 8743 -2630 8606 420 8477 -2210 7771 -3420 8020 -7880 10372 -9510 10421
--10020 10098 -9470 10057 -8460 10272 -8300 10093 -9040 9813 -9980 10232
--10220 12014 -9760 13692 -8500 15175 -6790 16590 -5390 17523 -5580 17321
--7810 15579 -11330 12691 -13950 10372 -15100 8945 -15050 8046 -14310 7117
--13400 6647 -12670 6478 -12160 6428 -11440 6233 -10690 5781 -10090 5341
--9470 5321 -8880 5785 -8290 6496 -7370 7224 -5680 7806 -3140 8182 -440 8362
-1190 8456 830 8501 -1200 8440 -3490 8397 -4330 8515 -2560 8626 1620 8579
-6740 8323 10800 7783 12100 7020 10060 6357 5390 6092 -330 6229 -5710 6755
--10110 7468 -13560 8158 -16460 8603 -18870 8608 -20660 8146 -21560 7351
--21280 6414 -19920 5535 -16690 4672 -10880 3855 -8870 3587 -10150 5650
--13750 3615 -6110 2607 -1650 4104 2350 5469 3450 7120 3900 8358 3360 8728
--330 8297 -3480 7299 -5510 6387 -5890 6556 -5916 7805 594 10513 2661 10917
-1991 10035 3230 9598 4130 10214 4040 11092 1750 11402 -2990 10601 -7370 9223
--5444 7882 807 7425 -2599 6863 -9627 8763 -13717 7028 -8466 6987 9300 6194
--9234 5874 3503 9885 18578 17888 -5317 13129 -7519 12182 -4952 12018 -1602 12082
-666 12067 -1118 10593 6700 13180 6380 12587 -1070 8448 -9488 5751 -16450 4630
--15144 6092 195 11463 7774 14708 12202 15573 23126 11110 18818 9551 3718 7033
--8686 6667 -16449 6792 -19835 6632 -15247 5702 -9572 6037 -3728 5435 -1312 5184
--3664 6257 -6490 6678 -10072 7075 -11825 7312 -4566 5482 -2307 6878 -3692 7327
--7898 6679 -13238 4592 -14949 6314 -5480 11571 491 15134 4561 16295 -2291 15511
--10250 11741 -13477 10478 -10874 11808 -12413 6773 -12816 4697 -15156 3866
--19157 4647 -24186 5809 -23582 6850 -14157 7213 25072 843 19943 5948 283 9393
--17995 9389 -12878 8479 21719 6778 31221 6356 19087 5333 -3122 2607 -15939 2051
-6103 -506 936 9376 -13151 14092 -25070 16137 -32674 16677 -36314 16363
--37032 15630 -35948 14756 -33931 13902 -31599 13156 -29320 12541 -27270 12055
--25516 11679 -24035 11388 -22797 11160 -21758 10976 -20875 10822 -20102 10689
--19428 10569 -18805 10461 -18238 10359 -17715 10265 -17219 10178 -16758 10097
--16316 10021 -15900 9954 -15491 9890 -15109 9834 -14732 9783 -14378 9738
--14037 9698 -13715 9663 -13400 9633 -13103 9607 -12816 9585 -12530 9567
--12262 9553 -12013 9541 -11776 9533 -11541 9528 -11330 9524 -11124 9524
--10910 9523 -10715 9525 -10519 9529 -10334 9535 -10153 9543 -10096 9553
--9962 9562 -9802 9570 -9643 9578 -9508 9587 -9388 9597 -9281 9608 -9179 9619
--9088 9629 -8993 9640 -8904 9650 -8827 9661 -8757 9670 -8688 9681 -8627 9690
--8564 9700 -8506 9708 -8456 9717 -8409 9726 -8372 9733 -8331 9742 -8291 9748
--8255 9756 -8225 9763 -8203 9769 -8178 9774 -8158 9781 -8136 9786 -8120 9792
--8103 9797 -8090 9801 -8082 9805 -8065 9810 -8061 9815 -8056 9818 -8051 9822
--8045 9826 -8048 9828 -8044 9833 -8045 9836 -8046 9839 -8055 9842 -8054 9845
--8058 9849 -8067 9851 -8072 9855 -8079 9857 -8090 9861 -8092 9864 -8101 9866
--8112 9870 -8121 9873 -8126 9877 -8136 9880 -8153 9883 -8156 9887 -8167 9891
-176: 13433280 -4906108 -9920 9838 -9940 9842 -9940 9853 -9950 9856 -9980 9863
--9990 9870 -10010 9875 -10020 9885 -10040 9890 -10060 9898 -10090 9909
--10110 9916 -10120 9922 -10150 9928 -10160 9936 -10200 9943 -10210 9949
--10230 9957 -10260 9963 -10280 9968 -10290 9972 -10310 9975 -10330 9982
--10340 9986 -10370 9988 -10380 9994 -10390 9997 -10410 9997 -10420 10000
--10430 10003 -10440 10008 -10460 10010 -10470 10012 -10490 10018 -10500 10021
--10520 10025 -10520 10032 -10560 10035 -10570 10042 -10610 10048 -10620 10057
--10650 10062 -10670 10070 -10700 10079 -10740 10089 -10760 10100 -10810 10110
--10840 10119 -10890 10129 -10910 10142 -10960 10153 -11020 10165 -11060 10176
--11100 10186 -11140 10194 -11190 10205 -11220 10214 -11260 10225 -11310 10233
--11360 10242 -11390 10248 -11420 10253 -11460 10254 -11490 10260 -11510 10260
--11550 10265 -11560 10264 -11570 10263 -11590 10264 -11610 10263 -11620 10261
--11620 10257 -11630 10255 -11630 10256 -11640 10252 -11630 10248 -11630 10244
--11630 10242 -11630 10241 -11640 10241 -11630 10243 -11620 10243 -11630 10244
--11640 10248 -11640 10252 -11650 10257 -11670 10265 -11690 10273 -11700 10285
--11730 10297 -11750 10308 -11770 10322 -11820 10335 -11860 10353 -11900 10371
--11940 10389 -11980 10404 -12040 10421 -12090 10441 -12150 10461 -12210 10480
--12270 10498 -12320 10513 -12370 10527 -12430 10542 -12480 10555 -12560 10567
--12600 10578 -12640 10586 -12690 10591 -12720 10593 -12760 10594 -12790 10591
--12820 10588 -12840 10581 -12850 10574 -12840 10561 -12860 10549 -12840 10529
--12830 10512 -12810 10495 -12790 10473 -12760 10449 -12720 10421 -12660 10394
--12620 10366 -12570 10343 -12520 10320 -12470 10293 -12400 10264 -12330 10237
--12270 10214 -12210 10195 -12160 10181 -12100 10162 -12040 10147 -11980 10135
--11930 10128 -11900 10127 -11860 10132 -11830 10142 -11810 10149 -11780 10169
--11780 10189 -11790 10217 -11810 10248 -11820 10288 -11860 10331 -11910 10384
--11960 10439 -12030 10497 -12110 10562 -12190 10636 -12290 10715 -12410 10799
--12530 10885 -12650 10974 -12780 11064 -12940 11162 -13090 11266 -13260 11373
--13420 11482 -13590 11584 -13750 11688 -13940 11800 -14120 11915 -14310 12031
--14500 12142 -14670 12243 -14850 12344 -15020 12448 -15210 12552 -15380 12652
--15550 12745 -15710 12829 -15850 12903 -15980 12983 -16130 13051 -16240 13111
--16350 13165 -16470 13211 -16550 13248 -16640 13272 -16710 13283 -16770 13285
--16800 13276 -16840 13256 -16850 13225 -16870 13180 -16880 13119 -16860 13037
--16850 12938 -16830 12825 -16810 12700 -16730 12560 -16670 12403 -16620 12230
--16560 12021 -16450 11772 -16360 11531 -16330 11293 -16310 11012 -16180 10677
--15920 10359 -15730 10080 -15720 9762 -15820 9344 -15740 8869 -15240 8492
--14400 8307 -13720 8204 -13670 7947 -14310 7356 -15380 6471 -16240 5525
--16300 4836 -15280 4622 -13210 4897 -10920 5389 -9890 5520 -9950 5717
--10530 6107 -10480 6661 -8230 7473 -2360 7636 210 8049 2310 8707 1330 8569
--3040 8774 -20 11365 490 11466 -4080 9081 1990 7919 1600 7347 5820 10620
--970 10881 -3010 11867 -3810 12186 -2800 10509 -430 6621 -3280 7014 -6830 7282
--7650 8221 -2460 8822 -1340 9482 560 9812 1830 7034 -1260 8105 -2400 9376
--3040 9610 -3210 9623 -3120 7838 -2680 8053 -590 7865 1450 8629 4550 9778
--960 9041 -1150 9459 -850 9264 -2410 9613 -2650 10565 390 12668 -940 10054
--1680 8104 -1670 6724 -1810 7627 -1810 14419 -2960 11935 -3240 9686 1320 7898
--2200 8186 -2570 8655 -1010 9425 -7260 7968 -7800 7923 -9720 9537 -10610 9585
--10950 9230 -9750 9357 -7530 10110 -7190 9724 -8370 8718 -9950 8467 -10210 11329
--9860 13294 -8540 14932 -6550 16403 -5190 17173 -5280 16877 -6920 15512
--9430 13516 -11580 11691 -12800 10295 -13050 9198 -12520 8063 -12030 7443
--11620 7078 -11250 6816 -10760 6542 -10190 6262 -9620 6089 -9070 6140
--8620 6457 -8220 6983 -7550 7576 -6210 8081 -4120 8409 -1830 8568 -280 8645
--220 8626 -1590 8523 -3470 8512 -4530 8585 -3720 8638 -950 8655 2820 8521
-6030 8094 7310 7494 6200 6930 3160 6581 -850 6619 -5070 7031 -9140 7535
--12890 7909 -16200 8106 -19040 8035 -21350 7649 -23060 7062 -23820 6411
--23160 5769 -20090 5246 -10600 4627 -7920 4862 -7940 5532 -10950 751 -6450 699
--2520 3751 -240 4687 -2710 6383 -1570 7939 820 8149 930 7987 -400 7544
--1200 7221 -2650 7145 -14390 5736 -2030 10395 1560 11093 3120 10775 5410 10732
-7600 11345 8560 12024 6390 12009 -720 10800 -10560 8754 -8400 6675 670 8611
--13870 6749 2590 10636 -13480 7826 -25444 5447 4343 4566 -3825 4366 9393 10326
-13053 15154 -300 13816 -4749 13103 -3675 13079 -493 13386 2733 13658 4934 13497
-10520 14731 12120 14156 4630 7933 -2750 5624 -11550 4593 -12650 5896 -5971 9442
--262 12373 7443 13330 19490 11480 22730 10244 5390 5659 -5860 5672 -17810 6807
--27290 7793 -21276 6417 -11471 5866 -1502 5152 3460 4942 -3111 6109 -6244 6512
--11570 7162 -14798 6456 -10648 5122 -5293 7017 -5395 7242 -8613 6688 -13258 5870
--14948 7134 -825 11108 6229 15136 7431 16985 -5813 16881 -13242 9585 -14765 6467
--10779 8684 -11591 9977 -13435 7408 -16559 5628 -21243 5735 -27238 7478
--22520 7877 -6525 6503 20384 2478 10730 5381 -10990 8111 -25621 8717 -22089 7927
-32282 3654 34172 3833 14238 4946 -8530 3993 3870 3008 -16169 -1240 -4421 8482
--10732 13049 -19416 15620 -26274 16578 -30432 16456 -32204 15762 -32276 14857
--31277 13955 -29746 13159 -28037 12509 -26360 12000 -24818 11610 -23455 11314
--22278 11087 -21253 10907 -20371 10758 -19606 10633 -18935 10519 -18322 10418
--17765 10323 -17265 10236 -16785 10153 -16353 10078 -15931 10006 -15541 9942
--15163 9883 -14799 9828 -14458 9780 -14124 9736 -13799 9699 -13501 9664
--13210 9635 -12927 9611 -12653 9588 -12388 9572 -12135 9556 -11900 9545
--11672 9537 -11450 9532 -11246 9528 -11052 9526 -10849 9526 -10662 9527
--10478 9531 -10295 9535 -10120 9544 -10074 9552 -9944 9560 -9786 9568
--9632 9575 -9506 9584 -9390 9594 -9283 9603 -9180 9615 -9096 9624 -9003 9634
--8915 9644 -8841 9654 -8776 9664 -8707 9673 -8645 9683 -8582 9692 -8525 9700
--8477 9709 -8436 9717 -8391 9725 -8354 9733 -8316 9740 -8280 9747 -8248 9753
--8226 9760 -8201 9766 -8182 9772 -8160 9777 -8144 9783 -8131 9788 -8114 9792
--8101 9797 -8091 9801 -8079 9806 -8080 9810 -8074 9813 -8068 9817 -8072 9821
--8070 9824 -8064 9828 -8064 9831 -8072 9835 -8080 9837 -8077 9841 -8089 9843
--8089 9847 -8097 9850 -8111 9853 -8113 9857 -8119 9859 -8126 9862 -8139 9866
--8140 9869 -8156 9873 -8166 9876 -8169 9880 -8184 9883
-177: 13465520 -4897378 -9940 9841 -9940 9844 -9960 9853 -9980 9857 -9980 9865
--10010 9871 -10020 9878 -10040 9885 -10050 9892 -10080 9899 -10090 9908
--10120 9915 -10140 9924 -10160 9926 -10180 9936 -10200 9943 -10220 9951
--10250 9955 -10260 9961 -10290 9968 -10300 9971 -10320 9976 -10330 9981
--10350 9985 -10370 9989 -10390 9993 -10400 9995 -10410 9997 -10430 10000
--10430 10003 -10450 10007 -10470 10010 -10470 10013 -10490 10016 -10500 10021
--10520 10026 -10530 10031 -10560 10037 -10570 10042 -10610 10048 -10620 10056
--10650 10062 -10670 10071 -10700 10077 -10730 10087 -10760 10098 -10800 10108
--10840 10117 -10880 10130 -10910 10139 -10950 10150 -11000 10163 -11050 10174
--11090 10183 -11130 10192 -11170 10202 -11210 10212 -11250 10221 -11290 10229
--11340 10236 -11370 10244 -11400 10250 -11440 10250 -11480 10255 -11490 10258
--11520 10259 -11540 10260 -11560 10261 -11570 10259 -11590 10260 -11590 10258
--11600 10253 -11610 10252 -11610 10253 -11620 10249 -11610 10245 -11620 10243
--11610 10240 -11620 10238 -11610 10240 -11620 10241 -11610 10241 -11610 10243
--11620 10246 -11630 10250 -11640 10255 -11650 10265 -11670 10273 -11690 10283
--11710 10295 -11740 10306 -11760 10319 -11800 10332 -11830 10351 -11890 10368
--11930 10384 -11960 10399 -12020 10417 -12060 10435 -12120 10454 -12190 10473
--12240 10490 -12300 10505 -12340 10520 -12400 10533 -12460 10545 -12520 10558
--12570 10567 -12610 10574 -12650 10578 -12680 10581 -12710 10581 -12760 10578
--12780 10574 -12800 10567 -12800 10560 -12810 10547 -12810 10533 -12800 10515
--12800 10498 -12770 10480 -12750 10460 -12720 10435 -12680 10408 -12630 10382
--12590 10354 -12540 10332 -12490 10307 -12440 10281 -12370 10253 -12310 10229
--12240 10203 -12200 10186 -12140 10172 -12080 10157 -12030 10140 -11960 10129
--11920 10121 -11880 10122 -11850 10127 -11820 10136 -11800 10146 -11770 10162
--11770 10185 -11780 10212 -11790 10244 -11820 10281 -11840 10325 -11900 10376
--11940 10432 -12010 10489 -12090 10553 -12160 10625 -12260 10703 -12380 10784
--12490 10870 -12620 10954 -12730 11042 -12880 11142 -13040 11242 -13190 11347
--13360 11451 -13510 11551 -13680 11654 -13850 11761 -14030 11873 -14220 11986
--14390 12093 -14570 12191 -14730 12288 -14900 12388 -15070 12488 -15250 12585
--15410 12676 -15560 12753 -15690 12824 -15820 12900 -15960 12966 -16070 13021
--16180 13070 -16280 13113 -16370 13143 -16440 13165 -16510 13173 -16570 13171
--16600 13158 -16630 13132 -16640 13097 -16650 13049 -16630 12985 -16620 12901
--16610 12801 -16590 12684 -16540 12556 -16470 12410 -16400 12256 -16350 12083
--16270 11870 -16130 11628 -16040 11397 -16010 11158 -15960 10866 -15770 10545
--15510 10249 -15360 9972 -15380 9634 -15470 9195 -15280 8737 -14650 8422
--13750 8305 -13140 8219 -13320 7870 -14380 7090 -15870 5966 -17120 4814
--17380 4025 -16120 3927 -13080 4668 -9070 5877 -7780 5771 -7900 5907 -8990 6298
--9730 6720 -8270 8079 1060 8081 1610 8459 4420 9508 3440 8816 -6150 7592
-1460 12573 1590 12846 2020 8871 4210 8219 3460 8409 3280 10417 -970 11867
--3420 13125 -4760 13677 -4800 12378 -1030 4531 -2840 4555 -5660 6235 -6290 7562
--3680 8042 -2270 7850 -850 7331 980 10254 -490 10223 -1870 10523 -2690 10462
--2790 10041 -2340 8814 -1310 8412 740 8308 3320 8862 5480 9673 -2030 9034
--1330 9431 2790 9107 -5240 8544 -4700 9190 2540 14039 -2500 10549 -2890 9048
--2330 8748 -1840 10480 -1540 14315 -2390 9764 -1650 8568 610 7723 -5910 8404
--6740 8723 -6070 10346 -9090 9233 -9350 8389 -9880 8624 -10430 8517 -11390 8078
--9450 8504 -5390 10446 -5140 10010 -7150 8183 -10180 6130 -10510 10745
--10620 12439 -9200 14090 -6460 15867 -4740 16707 -4530 16472 -5640 15444
--7480 14023 -9210 12599 -10340 11303 -10790 10085 -10500 8892 -10510 8082
--10560 7504 -10540 7122 -10350 6905 -9970 6813 -9490 6797 -8990 6855 -8620 7087
--8370 7512 -7990 7991 -7030 8389 -5370 8625 -3340 8737 -1720 8794 -1190 8786
--1950 8790 -3430 8836 -4590 8836 -4420 8805 -2650 8768 90 8563 2550 8202
-3590 7742 2860 7282 710 7016 -2290 7137 -5730 7483 -9340 7681 -12900 7742
--16120 7757 -18980 7597 -21530 7227 -23640 6771 -24700 6303 -23840 5867
--20090 5588 -13010 5207 -9160 4742 -8100 3429 -8830 -215 -6830 -812 -4030 4235
--1390 3762 -9230 5823 -7050 7918 -2040 7625 300 7717 -880 7486 -1320 7409
--3980 7425 -10030 7356 -4840 9869 -920 10833 2210 10995 5870 11335 10010 12096
-13650 12757 14500 12635 9050 11305 -2250 8893 -12930 7236 -3970 8334 -20620 5121
--250 10127 -9920 8243 -23980 5516 -13220 4783 -6670 4588 3770 9007 6650 12636
-1060 13283 -2300 13360 -2010 13628 780 14133 4710 14665 8870 14968 13960 15258
-16670 14030 13940 10026 7140 7257 -7780 4799 -11310 5129 -9450 7327 -8410 9728
--860 10705 12210 10161 22030 9293 15820 6718 4220 6323 -13770 7576 -34000 9447
--32410 8728 -14988 6741 1235 5077 12533 4036 -2290 5823 -4970 5952 -13767 7664
--18260 6301 -14368 5672 -8798 6594 -6624 6992 -7736 6876 -11126 6695 -14757 7519
--5638 9956 4762 14290 10429 15218 -10546 15125 -13289 10534 -15470 4920
--8262 11022 -9213 11548 -12191 9189 -16016 6860 -20486 6058 -29697 8691
--22653 8438 -5267 6670 15765 4183 15246 4725 -11628 7195 -18242 6971 -9538 5343
-19524 2619 21215 3447 -7223 8779 -35126 18767 49293 15333 -29276 -16773
--16838 -1810 -13754 8960 -17410 14083 -22126 15946 -25701 16145 -27704 15570
--28387 14707 -28101 13817 -27227 13025 -26074 12373 -24814 11865 -23578 11476
--22422 11185 -21382 10964 -20455 10792 -19637 10654 -18919 10537 -18284 10435
--17708 10343 -17192 10257 -16715 10177 -16278 10104 -15878 10034 -15484 9970
--15118 9910 -14774 9856 -14440 9806 -14130 9761 -13823 9721 -13525 9686
--13246 9654 -12979 9627 -12714 9603 -12460 9584 -12212 9567 -11977 9553
--11753 9542 -11537 9535 -11340 9529 -11143 9527 -10957 9524 -10768 9524
--10589 9526 -10419 9528 -10244 9534 -10075 9540 -10034 9548 -9909 9556
--9760 9564 -9613 9571 -9487 9580 -9377 9588 -9275 9599 -9176 9608 -9091 9619
--9006 9627 -8919 9638 -8850 9647 -8781 9656 -8715 9666 -8656 9675 -8600 9683
--8541 9693 -8495 9700 -8451 9709 -8410 9716 -8371 9724 -8336 9732 -8298 9738
--8270 9745 -8248 9751 -8224 9757 -8198 9763 -8178 9769 -8167 9774 -8149 9779
--8137 9784 -8124 9788 -8112 9793 -8098 9797 -8101 9802 -8094 9805 -8091 9810
--8090 9812 -8091 9817 -8089 9820 -8085 9823 -8087 9827 -8095 9830 -8098 9833
--8107 9837 -8110 9839 -8114 9843 -8125 9846 -8131 9850 -8137 9852 -8142 9855
--8151 9859 -8161 9863 -8167 9865 -8181 9870 -8182 9872 -8196 9877
-178: 13497800 -4888659 -9960 9843 -9960 9848 -9970 9854 -9990 9859 -10010 9867
--10020 9873 -10040 9879 -10040 9884 -10070 9893 -10090 9901 -10100 9908
--10130 9915 -10150 9923 -10170 9928 -10190 9936 -10220 9943 -10230 9950
--10250 9956 -10280 9960 -10290 9967 -10310 9971 -10320 9976 -10340 9980
--10360 9983 -10370 9989 -10400 9991 -10410 9995 -10410 9996 -10430 10001
--10450 10004 -10450 10006 -10470 10011 -10480 10014 -10490 10016 -10500 10019
--10520 10025 -10540 10032 -10560 10036 -10570 10042 -10610 10047 -10620 10056
--10650 10061 -10660 10070 -10700 10078 -10730 10086 -10760 10094 -10800 10107
--10830 10117 -10870 10128 -10900 10137 -10950 10149 -10990 10160 -11030 10170
--11090 10180 -11110 10190 -11160 10200 -11200 10209 -11240 10216 -11270 10225
--11320 10232 -11350 10239 -11390 10246 -11420 10247 -11450 10253 -11470 10255
--11500 10253 -11520 10257 -11540 10256 -11550 10255 -11560 10255 -11580 10253
--11580 10251 -11590 10251 -11600 10250 -11590 10246 -11600 10243 -11590 10240
--11600 10237 -11600 10236 -11600 10239 -11610 10237 -11590 10241 -11600 10242
--11600 10243 -11610 10248 -11630 10255 -11630 10262 -11660 10272 -11670 10281
--11700 10294 -11710 10303 -11750 10315 -11790 10330 -11820 10348 -11860 10366
--11910 10380 -11950 10396 -11990 10412 -12040 10428 -12100 10448 -12150 10466
--12220 10483 -12270 10498 -12320 10511 -12370 10524 -12430 10537 -12480 10548
--12530 10557 -12570 10562 -12620 10566 -12650 10569 -12670 10568 -12720 10566
--12740 10561 -12760 10555 -12760 10546 -12770 10534 -12770 10520 -12770 10501
--12750 10484 -12730 10465 -12710 10447 -12690 10423 -12640 10394 -12600 10369
--12550 10342 -12510 10320 -12460 10297 -12410 10270 -12350 10242 -12280 10218
--12230 10195 -12170 10178 -12120 10164 -12070 10149 -12000 10135 -11950 10122
--11900 10115 -11870 10116 -11830 10121 -11820 10130 -11780 10140 -11770 10156
--11760 10180 -11770 10206 -11770 10238 -11810 10275 -11830 10318 -11870 10368
--11930 10422 -11990 10480 -12060 10543 -12140 10612 -12240 10688 -12340 10768
--12450 10852 -12580 10936 -12690 11020 -12830 11116 -12970 11217 -13140 11318
--13280 11419 -13440 11517 -13610 11617 -13760 11721 -13950 11829 -14110 11939
--14290 12042 -14460 12136 -14620 12231 -14780 12326 -14940 12423 -15110 12516
--15270 12601 -15410 12677 -15540 12744 -15660 12815 -15800 12877 -15900 12930
--16010 12975 -16090 13012 -16190 13037 -16250 13056 -16310 13061 -16360 13057
--16410 13038 -16420 13012 -16420 12971 -16410 12920 -16400 12855 -16390 12769
--16350 12668 -16340 12548 -16260 12418 -16200 12271 -16120 12119 -16070 11946
--15950 11730 -15800 11499 -15710 11277 -15660 11035 -15570 10745 -15350 10441
--15080 10164 -14930 9891 -14980 9542 -15040 9095 -14760 8665 -14010 8409
--13060 8345 -12530 8257 -12910 7824 -14270 6891 -16110 5588 -17680 4273
--18200 3388 -16920 3351 -12920 4622 -5680 7396 -4860 6344 -4770 6581 -5780 6889
--6420 6494 -4750 7597 2540 9823 2320 9503 1790 9187 660 10342 -1320 7663
-1980 10426 2920 11077 4290 9187 5230 8830 2250 8702 910 10001 -1100 12222
--2700 13133 -3910 12835 -4430 10680 -2650 5579 -3060 4594 -5080 6896 -5470 8065
--4280 8352 -3100 8096 -1890 8130 -810 9904 -1270 10379 -1940 11045 -2250 11011
--2080 10487 -1530 9568 -580 8941 900 8699 2610 8967 3330 9424 -70 9360
--160 9596 990 9613 -2760 9753 -2640 10811 -750 11414 -2500 10455 -2760 9873
--2240 9995 -1710 11087 -1600 12322 -2180 10154 -2410 9175 -3050 8840 -7410 9305
--9460 9814 -10170 10620 -11140 9871 -9610 8317 -9270 7841 -9340 7747 -11260 7277
--7050 8584 -3080 10488 -2550 10982 -5040 9680 -10050 5611 -11920 7846
--12330 10142 -10750 12403 -6260 15168 -4070 16211 -3450 16018 -4070 15236
--5380 14195 -6770 13052 -7820 11831 -8470 10532 -8540 9363 -9090 8387
--9680 7682 -10100 7348 -10300 7331 -10190 7442 -9820 7504 -9350 7548 -9010 7729
--8870 8071 -8710 8438 -8110 8710 -6810 8849 -4980 8920 -3170 8990 -2140 9095
--2260 9249 -3330 9322 -4430 9230 -4610 9065 -3500 8813 -1570 8490 180 8149
-830 7820 110 7537 -1740 7491 -4330 7732 -7330 7884 -10480 7749 -13550 7589
--16310 7490 -18840 7263 -21300 6905 -23440 6544 -24490 6222 -23480 6011
--19910 5922 -14500 5555 -10500 4491 -8640 2276 -8400 -726 -7980 -1532
--7400 1194 -2980 3949 -8420 6344 -9060 7513 -7030 7855 -3670 7050 -5580 6929
--3360 7377 -4990 8098 -8050 8824 -6490 10166 -3760 10777 -420 10938 3930 11458
-9560 12370 16040 13050 21070 12854 18190 11361 -12030 7782 -20920 5828
--20160 4437 -26870 1145 -21490 1650 2700 13547 -7150 10648 -7550 8036
--3940 7218 1150 9275 2710 11531 300 12592 -1930 13097 -1950 13604 630 14305
-5200 15079 10250 15502 15470 15400 19570 14222 21040 11799 17700 9398
--6590 4989 -8710 4526 -8530 5651 -16270 7753 -9990 8468 5310 8510 25920 8965
-28280 7722 18480 7131 -4470 8342 -44500 12067 -44960 11425 -17920 7767
-920 5274 21380 2651 9430 3795 -8140 5728 -24380 8804 -19823 7087 -15776 6192
--10121 6466 -6832 6965 -6715 7249 -9715 7452 -20502 8090 -16367 9924 -8077 12578
--451 13178 -165 11802 1319 8660 -9044 11516 -6588 13072 -7533 12385 -11494 10162
--17181 7912 -23304 7111 -29071 8298 -24142 8454 -8451 7255 12788 5581
-16241 5220 2914 5822 -2354 5047 1809 3157 10864 1112 6416 1580 -47479 7398
--126061 21572 172465 -11889 -60912 -1857 -16796 6285 -13422 11575 -16095 14508
--19335 15662 -21989 15699 -23738 15141 -24624 14340 -24775 13510 -24415 12763
--23737 12144 -22888 11656 -21983 11286 -21078 11008 -20224 10798 -19436 10640
--18730 10513 -18088 10409 -17515 10319 -16999 10237 -16525 10163 -16094 10094
--15699 10029 -15328 9969 -14980 9912 -14648 9860 -14337 9812 -14035 9768
--13760 9728 -13481 9692 -13212 9660 -12952 9633 -12708 9608 -12469 9587
--12241 9569 -12009 9554 -11793 9543 -11582 9533 -11383 9525 -11200 9522
--11018 9520 -10843 9518 -10672 9518 -10501 9520 -10338 9522 -10174 9528
--10020 9535 -9978 9543 -9858 9550 -9718 9557 -9578 9565 -9463 9574 -9349 9581
--9259 9592 -9163 9602 -9079 9611 -8998 9621 -8919 9630 -8850 9639 -8781 9648
--8721 9658 -8660 9667 -8610 9675 -8548 9684 -8507 9692 -8465 9701 -8422 9707
--8386 9716 -8348 9722 -8312 9730 -8289 9736 -8261 9743 -8245 9748 -8220 9755
--8197 9760 -8179 9765 -8165 9771 -8152 9776 -8146 9780 -8133 9785 -8120 9789
--8119 9794 -8113 9798 -8108 9801 -8109 9805 -8102 9809 -8107 9813 -8108 9816
--8106 9820 -8111 9823 -8119 9826 -8122 9829 -8129 9833 -8129 9836 -8138 9840
--8146 9842 -8151 9846 -8159 9849 -8165 9852 -8178 9856 -8181 9859 -8192 9863
--8195 9866 -8211 9870
-179: 13530110 -4879950 -9970 9846 -9990 9850 -9980 9855 -10000 9862 -10020 9870
--10040 9872 -10050 9881 -10060 9887 -10080 9894 -10100 9902 -10110 9908
--10140 9915 -10160 9922 -10180 9928 -10200 9937 -10220 9941 -10250 9951
--10260 9956 -10290 9961 -10300 9966 -10320 9970 -10330 9976 -10350 9978
--10360 9984 -10380 9987 -10400 9991 -10410 9995 -10420 9996 -10440 10000
--10450 10004 -10450 10006 -10480 10010 -10480 10014 -10500 10017 -10510 10020
--10520 10024 -10540 10029 -10560 10037 -10580 10042 -10600 10047 -10620 10054
--10640 10062 -10670 10068 -10700 10078 -10730 10084 -10750 10094 -10790 10106
--10830 10115 -10870 10125 -10890 10135 -10940 10146 -10980 10158 -11030 10167
--11070 10180 -11100 10187 -11140 10195 -11190 10205 -11230 10214 -11250 10220
--11300 10229 -11340 10234 -11370 10242 -11400 10243 -11430 10248 -11450 10251
--11480 10249 -11500 10252 -11520 10255 -11530 10251 -11540 10253 -11560 10248
--11560 10250 -11580 10247 -11570 10247 -11580 10242 -11570 10240 -11580 10237
--11580 10236 -11590 10234 -11580 10237 -11590 10235 -11580 10237 -11580 10240
--11590 10241 -11590 10248 -11610 10254 -11630 10261 -11640 10268 -11660 10280
--11670 10291 -11700 10301 -11730 10313 -11770 10328 -11800 10346 -11840 10361
--11890 10377 -11930 10393 -11970 10406 -12020 10423 -12070 10441 -12140 10461
--12190 10477 -12240 10491 -12290 10501 -12330 10515 -12400 10528 -12450 10539
--12500 10546 -12540 10553 -12570 10554 -12610 10558 -12650 10555 -12680 10553
--12700 10549 -12710 10543 -12730 10534 -12730 10521 -12730 10506 -12730 10489
--12710 10470 -12690 10452 -12680 10433 -12640 10410 -12610 10383 -12560 10357
--12520 10333 -12480 10307 -12430 10285 -12390 10261 -12320 10231 -12260 10209
--12200 10187 -12140 10170 -12100 10156 -12050 10140 -11990 10129 -11930 10115
--11890 10109 -11850 10109 -11820 10116 -11810 10122 -11770 10136 -11760 10150
--11740 10173 -11760 10198 -11760 10231 -11790 10270 -11820 10311 -11860 10359
--11910 10412 -11970 10468 -12030 10530 -12120 10599 -12200 10672 -12310 10752
--12420 10832 -12520 10914 -12650 10997 -12780 11091 -12920 11187 -13070 11287
--13220 11386 -13360 11480 -13530 11578 -13680 11678 -13850 11784 -14020 11888
--14190 11989 -14350 12081 -14500 12171 -14660 12262 -14820 12356 -14980 12446
--15130 12527 -15260 12597 -15390 12661 -15510 12731 -15630 12788 -15730 12835
--15840 12877 -15910 12911 -16000 12933 -16060 12946 -16120 12950 -16160 12943
--16190 12922 -16200 12892 -16210 12848 -16190 12793 -16170 12726 -16140 12642
--16100 12537 -16070 12421 -16000 12288 -15910 12140 -15830 11993 -15750 11818
--15620 11608 -15480 11386 -15360 11172 -15280 10929 -15150 10645 -14910 10361
--14620 10105 -14480 9839 -14520 9487 -14530 9046 -14180 8645 -13340 8441
--12340 8422 -11850 8333 -12330 7857 -13820 6852 -15800 5478 -17520 4119
--18170 3201 -17130 3107 -13220 4475 -890 10167 -2520 6985 -2160 8675 -1460 8130
--2950 9142 -550 7398 110 8492 3420 9128 -220 8443 10 8896 800 7809 2710 9140
-2880 9731 4560 8766 5180 9056 700 8836 -660 9252 -910 12228 -1360 12370
--2400 11469 -4360 9617 -3580 6306 -2880 5037 -4800 8730 -4660 9213 -4300 9242
--3600 8868 -2800 8850 -2280 9503 -2430 9703 -2340 11086 -1940 11135 -1440 10691
--980 9949 -490 9284 160 8931 1050 9039 1780 9422 640 9674 340 9961 250 10177
--1430 10451 -1830 10928 -1560 10959 -2140 10654 -2150 10486 -1750 10600
--1450 11047 -1660 11370 -2520 10599 -3720 10173 -5590 10126 -8800 10415
--11110 10759 -12460 11029 -13000 10328 -9310 7761 -9500 6943 -10270 6705
--9960 6910 -3010 8762 370 10507 350 11697 -2430 11940 -10380 4635 -12770 6416
--13670 8632 -12770 10762 -5790 14759 -3650 15684 -2380 15352 -2390 14759
--3230 14007 -4360 13051 -5410 11868 -6300 10503 -6870 9362 -7970 8280
--9090 7593 -10050 7486 -10700 7821 -10910 8151 -10670 8266 -10200 8285
--9830 8407 -9700 8653 -9690 8904 -9360 9060 -8360 9127 -6640 9189 -4600 9324
--2980 9574 -2520 9841 -3160 9905 -4110 9693 -4410 9285 -3720 8771 -2450 8316
--1340 8003 -1090 7845 -2000 7813 -3970 7989 -6700 8210 -9610 8062 -12350 7659
--14740 7407 -16760 7293 -18710 7079 -20790 6763 -22680 6490 -23530 6275
--22540 6251 -19450 6298 -15070 5894 -11300 4431 -9030 1762 -8050 -1131
--7400 -2312 -6490 -895 -5870 2980 -8200 5440 -10500 8098 -10380 8204 -10060 6760
--13880 6152 -6370 7282 -7040 8878 -8880 9948 -8790 10736 -7290 10899 -4700 10665
--860 11189 4660 12163 11780 12725 17620 12225 11490 10276 -10290 7368
--22560 5142 -25610 3274 -22510 1453 -17770 2904 -3520 10067 -3000 10609
--1580 9482 280 8975 1120 9968 820 11236 -1140 12053 -3370 12564 -4180 13115
--1920 13962 3640 15062 8900 15534 13580 15245 17280 14145 18740 12329
-15160 10089 2090 6895 -760 5382 -570 5009 -21240 6945 -14370 6959 690 7111
-33800 9518 38410 8809 30960 7862 10440 8253 -56180 14705 -43520 12334
--20080 8631 -1510 5649 36060 587 16510 2570 -23660 7545 -40840 10057 -19060 6863
--15656 5990 -9548 6223 -6714 7055 -8116 7679 -14124 7982 -24458 8401 -27036 9727
--23392 11655 -13195 12552 7315 11570 12421 11301 5610 13478 979 13442
--3561 12429 -9877 10469 -17933 8178 -25013 7380 -29283 8138 -27053 8827
--13933 8231 15043 6761 21276 5869 15576 5409 11603 4244 11754 2319 11236 543
--7593 866 -91402 7345 -353837 34162 298829 -37371 34943 1697 -7721 10215
--14276 13009 -15851 14404 -17273 14980 -18804 14924 -20127 14455 -21033 13784
--21465 13068 -21504 12406 -21240 11847 -20767 11400 -20184 11056 -19545 10798
--18902 10604 -18279 10459 -17691 10345 -17153 10254 -16656 10177 -16208 10107
--15790 10045 -15412 9988 -15060 9934 -14735 9883 -14422 9836 -14133 9792
--13858 9752 -13600 9714 -13346 9681 -13105 9650 -12861 9624 -12627 9599
--12410 9579 -12191 9561 -11983 9547 -11783 9534 -11588 9524 -11388 9516
--11212 9512 -11039 9508 -10875 9508 -10715 9507 -10556 9508 -10394 9510
--10241 9513 -10095 9519 -9946 9527 -9909 9534 -9797 9542 -9667 9550 -9533 9557
--9424 9566 -9315 9574 -9228 9583 -9142 9594 -9059 9603 -8982 9613 -8909 9621
--8843 9631 -8776 9640 -8716 9649 -8664 9658 -8609 9667 -8555 9675 -8510 9684
--8475 9691 -8426 9699 -8394 9707 -8361 9714 -8325 9721 -8299 9728 -8277 9734
--8261 9740 -8232 9746 -8215 9752 -8194 9757 -8181 9763 -8169 9767 -8160 9773
--8150 9777 -8137 9781 -8136 9786 -8128 9790 -8123 9795 -8127 9798 -8120 9801
--8124 9806 -8121 9809 -8123 9813 -8127 9816 -8135 9820 -8137 9822 -8145 9827
--8146 9830 -8150 9833 -8159 9836 -8167 9839 -8173 9843 -8180 9846 -8191 9850
--8196 9853 -8205 9856 -8207 9861 -8223 9863
-180: 13562450 -4871247 -9990 9848 -9990 9850 -10010 9858 -10010 9864
--10030 9868 -10040 9875 -10070 9884 -10080 9887 -10080 9895 -10110 9904
--10130 9909 -10150 9915 -10170 9923 -10200 9928 -10210 9938 -10230 9942
--10250 9948 -10270 9955 -10300 9962 -10300 9966 -10330 9970 -10340 9975
--10360 9977 -10370 9983 -10390 9987 -10400 9991 -10420 9993 -10420 9996
--10450 10001 -10440 10003 -10470 10005 -10480 10011 -10490 10014 -10500 10016
--10510 10019 -10530 10023 -10540 10030 -10560 10035 -10580 10042 -10600 10047
--10630 10054 -10640 10061 -10660 10068 -10700 10075 -10720 10084 -10760 10094
--10790 10104 -10820 10115 -10860 10125 -10890 10132 -10930 10143 -10970 10155
--11010 10164 -11060 10176 -11090 10185 -11140 10192 -11160 10201 -11210 10210
--11250 10217 -11280 10226 -11320 10230 -11350 10236 -11380 10241 -11420 10242
--11430 10247 -11460 10246 -11480 10247 -11500 10250 -11500 10249 -11530 10250
--11540 10246 -11550 10246 -11550 10244 -11550 10242 -11560 10239 -11560 10236
--11560 10236 -11560 10233 -11570 10233 -11570 10233 -11570 10233 -11560 10235
--11580 10236 -11570 10242 -11570 10245 -11590 10254 -11620 10258 -11620 10267
--11640 10277 -11660 10289 -11680 10299 -11720 10312 -11750 10326 -11790 10342
--11820 10357 -11870 10372 -11900 10390 -11950 10402 -12000 10418 -12050 10435
--12110 10455 -12160 10470 -12210 10483 -12260 10494 -12310 10507 -12360 10519
--12420 10529 -12460 10536 -12510 10543 -12540 10545 -12570 10546 -12610 10544
--12640 10541 -12660 10536 -12680 10531 -12680 10522 -12690 10509 -12700 10494
--12680 10476 -12670 10456 -12660 10441 -12630 10420 -12610 10397 -12570 10373
--12530 10345 -12490 10320 -12450 10297 -12400 10274 -12350 10251 -12300 10224
--12230 10200 -12180 10179 -12130 10162 -12080 10147 -12030 10133 -11970 10120
--11910 10109 -11870 10103 -11840 10103 -11810 10110 -11790 10116 -11760 10129
--11740 10143 -11740 10166 -11740 10192 -11750 10224 -11770 10262 -11810 10302
--11840 10349 -11890 10401 -11950 10456 -12010 10516 -12080 10583 -12180 10656
--12270 10733 -12370 10811 -12490 10891 -12600 10973 -12730 11063 -12860 11158
--13010 11255 -13150 11349 -13300 11443 -13440 11536 -13600 11633 -13760 11736
--13930 11838 -14080 11933 -14250 12023 -14380 12110 -14540 12198 -14700 12287
--14840 12374 -14990 12449 -15120 12518 -15240 12579 -15360 12644 -15460 12696
--15570 12742 -15660 12778 -15740 12807 -15810 12828 -15880 12839 -15920 12841
--15950 12830 -15980 12808 -15990 12774 -15980 12727 -15970 12670 -15940 12602
--15890 12517 -15860 12416 -15800 12299 -15710 12165 -15620 12021 -15530 11876
--15430 11702 -15290 11500 -15130 11288 -14990 11080 -14880 10840 -14730 10567
--14450 10306 -14140 10069 -13980 9813 -14010 9467 -13980 9041 -13550 8672
--12650 8510 -11620 8523 -11090 8455 -11540 7990 -12960 7016 -14800 5720
--16260 4500 -16490 3826 -14730 4120 -10110 5835 -2120 9144 -440 8692 550 9347
-950 8893 -3020 9889 -2450 8368 -440 8262 3510 8413 1320 8257 880 8359 1570 7883
-3330 8256 1580 9298 4260 8738 5650 8730 -1400 9130 -1470 9474 -10 10624
-260 10683 -650 10052 -5090 9548 -4590 7723 -3290 7208 -2850 9093 -2610 9526
--3670 9744 -3580 9317 -3190 9327 -3160 9627 -3470 9381 -2880 10161 -1560 10611
--810 10507 -550 9987 -650 9396 -920 8995 -750 9091 560 9578 310 10027 240 10386
--20 10679 -890 10904 -1370 11053 -1430 11002 -1560 10939 -1450 10946 -1180 10986
--1130 11068 -1640 11110 -2850 10962 -4610 10972 -6850 11096 -9380 11220
--11200 11233 -12040 11023 -11880 10026 -10050 7978 -10190 6735 -11120 6188
--10350 6383 1230 8667 2830 9428 1160 9236 -2710 8061 -8500 9904 -11110 9237
--12420 9645 -11800 10947 -8050 13499 -5050 14584 -1740 14206 -870 13978
--1240 13525 -2190 12700 -3320 11515 -4490 10096 -5640 8927 -7310 7789
--8910 7212 -10360 7489 -11580 8389 -12100 8991 -11940 9132 -11440 9080
--11000 9095 -10800 9226 -10760 9380 -10620 9457 -9870 9496 -8240 9585
--5910 9803 -3630 10167 -2670 10493 -3040 10515 -3800 10133 -4000 9388
--3640 8622 -2970 8064 -2390 7835 -2380 7935 -3390 8132 -5760 8393 -9270 8438
--12410 7968 -14720 7408 -16270 7201 -17390 7188 -18570 7092 -20040 6890
--21400 6661 -21910 6447 -21090 6525 -18650 6659 -15130 6193 -11830 4467
--9550 1642 -8290 -1060 -7520 -2167 -6840 -1077 -6640 1651 -7880 3954 -12180 8968
--13060 8621 -14690 6021 -15370 4492 -13830 7182 -11770 9429 -11950 10467
--12000 11106 -11420 11076 -9880 10057 -7540 10569 -3360 11560 3670 11976
-13680 11368 6740 9297 -9460 7085 -21650 5314 -25810 3951 -13560 3000 -14050 4091
--8300 7785 -4260 9256 2150 9526 4300 9599 1590 10485 -80 11195 -2450 11625
--5770 11909 -8530 12304 -7235 13174 481 14872 5384 15318 8840 14849 11490 13792
-12720 12444 11000 11010 3930 9024 -800 7583 -3300 6663 -6290 5866 -930 6219
-11760 7513 31550 9611 35360 10038 24830 9944 -860 10764 -41580 13518 -17940 9944
--1900 6708 17060 3325 38730 -152 17660 1826 -51820 10594 -71660 12872
--21080 6085 -11082 4984 -6495 5683 -5355 7231 -8541 8141 -16852 8240 -28998 7981
--36015 8884 -36663 10870 -27716 12782 14717 12088 21204 13888 16315 15553
-7344 13250 762 12373 -7170 10790 -17886 7740 -24831 7080 -27359 8386 -26033 9956
--18236 9916 19246 7981 23499 6826 21057 6137 17940 5018 14159 3326 7427 2102
--13386 2624 -70237 6625 -199821 15137 111566 -16409 17452 -1064 -7578 6183
--12367 10052 -13279 12238 -14122 13343 -15285 13686 -16504 13529 -17513 13094
--18215 12548 -18594 12003 -18688 11520 -18561 11122 -18287 10810 -17907 10572
--17478 10394 -17027 10261 -16574 10160 -16143 10080 -15738 10015 -15362 9958
--15008 9908 -14685 9862 -14379 9820 -14101 9780 -13832 9744 -13580 9708
--13348 9677 -13123 9647 -12906 9621 -12693 9596 -12482 9575 -12275 9557
--12084 9540 -11891 9527 -11709 9515 -11527 9506 -11355 9499 -11179 9494
--11018 9491 -10863 9489 -10713 9490 -10566 9492 -10422 9494 -10274 9496
--10130 9501 -9998 9507 -9861 9515 -9832 9525 -9726 9532 -9598 9540 -9477 9547
--9375 9556 -9275 9564 -9190 9575 -9109 9584 -9034 9594 -8960 9603 -8888 9613
--8831 9621 -8764 9631 -8712 9641 -8655 9649 -8607 9658 -8555 9666 -8507 9675
--8477 9682 -8432 9691 -8397 9698 -8368 9705 -8333 9713 -8310 9719 -8287 9725
--8270 9732 -8243 9738 -8231 9744 -8210 9749 -8191 9755 -8184 9759 -8171 9765
--8166 9770 -8154 9774 -8154 9778 -8140 9783 -8135 9787 -8139 9791 -8139 9795
--8136 9799 -8137 9803 -8137 9806 -8142 9810 -8148 9813 -8154 9816 -8161 9820
--8155 9824 -8163 9827 -8172 9830 -8179 9834 -8189 9836 -8194 9841 -8203 9844
--8207 9847 -8214 9851 -8223 9854 -8235 9858
-181: 13594830 -4862556 -10000 9851 -10010 9853 -10020 9859 -10030 9867
--10040 9870 -10060 9876 -10070 9883 -10090 9889 -10110 9897 -10110 9904
--10140 9909 -10170 9916 -10180 9924 -10210 9930 -10220 9937 -10240 9941
--10260 9949 -10280 9956 -10300 9959 -10320 9966 -10320 9971 -10350 9974
--10370 9977 -10370 9983 -10400 9987 -10410 9989 -10430 9990 -10430 9995
--10440 10001 -10460 10005 -10470 10006 -10480 10011 -10490 10012 -10500 10017
--10520 10019 -10530 10024 -10550 10029 -10560 10034 -10580 10040 -10600 10049
--10630 10052 -10640 10060 -10670 10067 -10690 10074 -10720 10083 -10750 10092
--10790 10104 -10820 10115 -10850 10122 -10890 10129 -10920 10141 -10960 10153
--11000 10163 -11040 10171 -11090 10182 -11120 10190 -11150 10197 -11200 10207
--11230 10213 -11260 10221 -11310 10226 -11330 10233 -11360 10237 -11400 10239
--11420 10241 -11440 10242 -11460 10244 -11470 10246 -11490 10245 -11520 10245
--11510 10242 -11530 10244 -11530 10239 -11540 10238 -11540 10236 -11540 10234
--11540 10232 -11540 10232 -11550 10229 -11550 10231 -11550 10230 -11560 10233
--11550 10234 -11560 10241 -11550 10244 -11580 10252 -11600 10257 -11610 10266
--11630 10274 -11640 10286 -11670 10299 -11690 10309 -11730 10323 -11780 10339
--11800 10353 -11850 10369 -11880 10384 -11930 10398 -11970 10414 -12030 10431
--12080 10448 -12130 10462 -12180 10476 -12240 10486 -12280 10500 -12340 10510
--12370 10520 -12430 10527 -12470 10532 -12500 10535 -12540 10535 -12570 10533
--12600 10531 -12620 10525 -12640 10520 -12650 10510 -12660 10497 -12640 10482
--12650 10464 -12630 10444 -12620 10428 -12600 10407 -12570 10387 -12530 10362
--12500 10333 -12450 10310 -12420 10287 -12370 10266 -12330 10241 -12270 10214
--12210 10191 -12150 10169 -12110 10154 -12060 10141 -12010 10127 -11950 10111
--11900 10103 -11850 10098 -11820 10097 -11800 10102 -11770 10111 -11750 10121
--11730 10137 -11730 10160 -11720 10183 -11740 10215 -11760 10253 -11780 10292
--11830 10338 -11870 10390 -11920 10442 -11980 10502 -12060 10566 -12140 10638
--12240 10714 -12340 10788 -12440 10867 -12550 10947 -12680 11034 -12810 11127
--12940 11220 -13090 11312 -13220 11403 -13370 11493 -13510 11587 -13670 11687
--13830 11785 -13990 11877 -14140 11963 -14270 12048 -14420 12133 -14570 12218
--14720 12298 -14850 12372 -14980 12437 -15090 12496 -15200 12556 -15300 12605
--15410 12645 -15490 12681 -15570 12707 -15620 12724 -15690 12733 -15730 12731
--15750 12719 -15770 12695 -15770 12657 -15760 12611 -15730 12551 -15710 12483
--15650 12397 -15600 12301 -15530 12184 -15430 12049 -15310 11911 -15230 11769
--15110 11601 -14940 11404 -14770 11204 -14610 11000 -14490 10769 -14300 10514
--13980 10269 -13640 10049 -13450 9809 -13450 9482 -13390 9077 -12930 8735
--11980 8598 -10900 8640 -10280 8607 -10580 8210 -11750 7352 -13290 6222
--14340 5217 -14110 4779 -12010 5246 -7790 6746 -2360 8843 410 9668 1460 10528
-680 10819 -1180 8804 -2910 8170 1260 8289 1750 7851 830 8405 420 8663 -520 8302
-300 8518 1250 8724 2920 8408 2980 8695 1030 8928 110 9302 2130 9152 1170 9266
--1030 9374 -4210 9520 -4440 8710 -2930 8730 -450 9989 390 10617 -2900 8973
--2940 9021 -2810 9440 -3360 9976 -4260 8788 -3250 9217 -700 10036 10 10198
--90 9850 -670 9363 -1750 8889 -1830 9151 -1280 9782 -950 10444 -300 10806
--270 11142 -760 11340 -1090 11315 -980 11150 -890 11184 -790 11326 -720 11375
--850 11285 -1470 11137 -2840 11170 -4820 11399 -7040 11618 -9020 11603
--10110 11314 -10200 10981 -9830 10059 -9050 8313 -9010 7090 -8890 6588
--6720 6862 -140 8100 1490 8640 -70 8659 -3630 8783 -7910 10586 -9000 10416
--10800 10439 -11080 10759 -9850 12319 -6550 13430 -910 12918 410 13254
-360 13005 -470 12195 -1790 10953 -3210 9496 -4920 8251 -7190 7036 -9160 6532
--10930 7267 -12820 9140 -13570 10030 -13420 10076 -12870 9849 -12320 9698
--11940 9728 -11720 9853 -11630 9898 -11170 9945 -9690 10072 -7090 10353
--3950 10773 -2650 11114 -3030 11093 -3800 10510 -3660 9342 -3660 8364
--3660 7798 -3490 7680 -3360 8161 -4080 8482 -6850 8621 -12080 8412 -15580 7642
--17280 7030 -17870 6951 -17990 7144 -18220 7341 -18920 7325 -19630 7051
--19590 6639 -19270 6729 -17750 6896 -15160 6315 -12490 4444 -10560 1765
--9440 -453 -8760 -1139 -8310 68 -8310 2542 -9490 5091 -12830 7736 -14230 8388
--18540 6033 -18710 5006 -16960 4295 -14620 8381 -15040 9545 -14980 10679
--15080 11127 -14610 8993 -13930 9735 -11390 10664 -5580 10920 13570 10640
-3540 8414 -9220 6949 -17590 5935 -18190 5231 -10560 4913 -15990 5062 -12940 6936
--8270 8247 4020 9266 7320 9555 1130 10785 -260 11134 -2720 11254 -7600 11309
--13780 11463 -14947 12074 -3410 14704 130 14874 2271 14193 4046 13157
-5594 12227 7426 11961 3230 10808 -2210 9670 -4680 8675 9610 5237 14160 6220
-21800 8564 30810 10681 30750 11539 19830 11589 60 11498 -19060 11197 -7570 8209
-7630 5072 25780 1915 42050 -945 29910 -528 -75160 12685 -78800 12304 -37940 6752
--16393 4698 -6742 5233 -4263 7653 -7327 8593 -16501 8157 -31984 6430 -39615 6844
--38435 8892 -25562 11463 3659 13346 16645 16278 18212 18280 8042 12590
-3659 13025 -3500 12277 -18173 6749 -22704 6583 -19668 9190 -12069 12080
--2623 12606 4960 9375 12498 8227 17399 7942 17138 7206 9163 5556 -2760 4701
--25635 5007 -65455 6222 -91417 5428 11858 -3985 308 -4056 -2978 676 -5945 5840
--7956 9318 -9671 11327 -11294 12282 -12789 12540 -14051 12385 -15028 12026
--15716 11602 -16136 11197 -16322 10845 -16341 10562 -16210 10343 -15993 10178
--15718 10055 -15402 9964 -15085 9894 -14774 9840 -14477 9794 -14189 9756
--13919 9722 -13665 9690 -13438 9663 -13216 9636 -13007 9611 -12808 9589
--12619 9568 -12434 9549 -12257 9531 -12080 9517 -11897 9504 -11735 9492
--11575 9484 -11412 9477 -11249 9471 -11103 9467 -10952 9465 -10808 9465
--10666 9466 -10539 9468 -10403 9471 -10272 9476 -10140 9479 -10010 9485
--9890 9492 -9761 9501 -9742 9511 -9642 9520 -9521 9527 -9413 9536 -9317 9545
--9222 9553 -9143 9564 -9070 9574 -9001 9584 -8930 9593 -8866 9603 -8806 9612
--8750 9622 -8698 9630 -8645 9640 -8598 9649 -8551 9657 -8504 9666 -8473 9674
--8434 9681 -8402 9690 -8368 9696 -8340 9704 -8316 9711 -8294 9717 -8279 9724
--8253 9729 -8232 9736 -8221 9742 -8206 9747 -8192 9752 -8188 9757 -8175 9762
--8166 9767 -8165 9771 -8155 9776 -8152 9781 -8153 9784 -8149 9788 -8150 9792
--8152 9796 -8153 9800 -8156 9804 -8159 9807 -8165 9811 -8173 9814 -8173 9818
--8173 9821 -8182 9824 -8186 9828 -8203 9832 -8206 9834 -8213 9839 -8222 9842
--8228 9845 -8235 9849 -8243 9853
-182: 13627250 -4853873 -10020 9852 -10030 9856 -10030 9862 -10040 9868
--10060 9873 -10070 9877 -10080 9884 -10110 9891 -10110 9898 -10130 9904
--10150 9911 -10180 9916 -10200 9924 -10210 9931 -10230 9936 -10250 9941
--10260 9949 -10290 9955 -10310 9960 -10320 9964 -10340 9970 -10360 9974
--10360 9977 -10390 9983 -10400 9986 -10420 9989 -10430 9992 -10440 9996
--10450 9998 -10460 10002 -10470 10009 -10480 10010 -10500 10012 -10510 10017
--10520 10019 -10530 10024 -10550 10029 -10570 10033 -10590 10040 -10600 10046
--10620 10053 -10650 10059 -10670 10066 -10680 10074 -10720 10083 -10750 10091
--10780 10102 -10810 10110 -10850 10120 -10880 10129 -10910 10138 -10960 10152
--10990 10159 -11030 10168 -11080 10180 -11110 10187 -11140 10196 -11180 10202
--11210 10209 -11250 10214 -11290 10224 -11320 10229 -11340 10233 -11380 10234
--11400 10236 -11420 10239 -11440 10240 -11450 10243 -11480 10241 -11500 10240
--11490 10239 -11510 10239 -11510 10236 -11520 10235 -11520 10232 -11530 10232
--11520 10229 -11520 10227 -11530 10227 -11530 10228 -11550 10229 -11530 10231
--11540 10233 -11530 10239 -11550 10241 -11560 10249 -11580 10256 -11600 10264
--11610 10274 -11630 10285 -11650 10295 -11680 10305 -11720 10320 -11740 10335
--11790 10351 -11830 10364 -11860 10380 -11900 10394 -11950 10410 -12000 10426
--12060 10442 -12110 10456 -12150 10468 -12210 10480 -12240 10492 -12300 10502
--12350 10510 -12390 10519 -12440 10521 -12470 10526 -12490 10525 -12530 10523
--12570 10521 -12580 10514 -12590 10508 -12620 10499 -12610 10484 -12610 10471
--12610 10453 -12590 10434 -12590 10415 -12560 10398 -12530 10375 -12500 10350
--12460 10323 -12420 10300 -12390 10278 -12340 10256 -12300 10232 -12240 10205
--12190 10183 -12130 10162 -12080 10146 -12040 10132 -11990 10119 -11940 10106
--11880 10097 -11830 10091 -11810 10091 -11780 10095 -11760 10105 -11740 10115
--11720 10130 -11700 10151 -11720 10175 -11720 10206 -11740 10242 -11770 10281
--11800 10328 -11850 10377 -11900 10429 -11960 10485 -12020 10549 -12110 10620
--12200 10692 -12300 10766 -12400 10840 -12510 10920 -12620 11004 -12750 11093
--12890 11184 -13010 11275 -13150 11362 -13290 11449 -13440 11540 -13580 11636
--13740 11731 -13880 11821 -14040 11903 -14160 11982 -14300 12065 -14450 12146
--14590 12225 -14710 12295 -14840 12355 -14940 12410 -15050 12470 -15150 12514
--15230 12550 -15330 12583 -15390 12608 -15450 12623 -15510 12629 -15520 12621
--15550 12607 -15560 12585 -15560 12546 -15540 12497 -15500 12438 -15470 12369
--15400 12285 -15340 12189 -15260 12076 -15150 11944 -15030 11811 -14920 11672
--14790 11507 -14590 11320 -14390 11129 -14240 10936 -14080 10718 -13870 10476
--13510 10245 -13130 10043 -12910 9827 -12870 9527 -12790 9145 -12320 8819
--11340 8697 -10210 8758 -9470 8774 -9550 8474 -10400 7774 -11550 6846
--12230 6041 -11740 5742 -9630 6182 -6010 7347 -1750 8827 1360 9857 3050 10574
-2910 10633 780 9467 -740 8033 -1620 8210 -870 8251 -440 9400 -480 9458
--3830 8495 -2800 8847 490 8375 1870 7895 1060 8717 3810 8606 1110 9292
-4830 7969 1530 8271 -1540 8968 -3920 9955 -4200 9174 -2980 9311 1250 10248
-1310 10378 -100 9335 -960 9117 -1620 9325 -3240 9972 -3960 8677 -3070 8632
-1030 9771 890 9927 100 9664 -560 9254 -2680 8520 -3170 8964 -2230 10270
--2420 11007 -820 11135 -490 11571 -890 11848 -1030 11705 -380 11213 -210 11284
--340 11634 -490 11850 -670 11703 -1050 11186 -2390 11137 -4340 11438 -6460 11747
--8040 11639 -8390 10990 -7570 11025 -7120 10571 -6910 8766 -6940 7772
--6390 7445 -4410 7618 -1210 8146 -740 8477 -1970 8783 -4770 9498 -8880 11169
--7190 10891 -10520 10929 -11340 9776 -10490 10574 -4500 10944 -1780 13131
-810 13297 1330 12694 650 11695 -1050 10337 -2570 8943 -4630 7673 -7770 6304
--9860 5672 -11400 6678 -14250 10302 -14980 11212 -14620 10901 -14100 10399
--13510 10079 -12890 10077 -12200 10312 -12130 10337 -12100 10398 -10890 10553
--8260 10855 -3680 11261 -2410 11581 -3290 11563 -4520 10877 -3510 9141
--4200 8108 -5190 7654 -5410 7469 -4670 8672 -4370 8882 -6890 8613 -15330 8213
--18750 7137 -19490 6510 -19090 6584 -18180 7101 -17330 7838 -17240 8047
--17380 7651 -16520 6683 -17450 6799 -17270 6961 -15590 6204 -13610 4291
--12260 2038 -11530 643 -11060 568 -10830 1863 -10900 4045 -11610 6149
--15070 6128 -16500 6835 -18490 8009 -19270 7583 -16090 3453 -17650 5025
--18340 6680 -16730 8683 -16110 9397 -18310 9046 -17600 9365 -13730 9661
--5210 9725 8160 9772 -4080 7412 -11710 7087 -16120 6864 -15090 6624 -10900 6475
--13480 6589 -12990 7400 -9650 8369 -1540 9225 3480 9668 2230 10443 1460 10799
--1020 10917 -7020 11008 -17120 11289 -18900 12004 -12176 13516 -7884 13798
--5197 13265 -3252 12352 -1328 11601 5922 12655 3955 11594 897 10102 1844 8451
-14916 6640 20743 7585 26630 10615 30250 12540 27580 13158 17650 12717
-3270 11417 -7630 9251 -3890 6557 5460 4282 15510 2705 18710 2190 350 3595
--49380 7096 -58940 7615 -33590 4465 -15904 3513 -5909 4218 -2918 8005
--5165 8509 -13438 7590 -34175 3676 -40492 4010 -37994 6379 -26216 9738
--6920 13038 5790 15898 10023 16900 6877 14519 5125 15298 912 15821 -20784 5460
--20767 6859 -11671 10959 1911 15096 13411 16540 -9871 10654 691 10149
-12796 10665 16537 10494 3156 8058 -8512 7237 -24532 6615 -43766 4296 -47160 -2037
--11745 -6433 -29841 -552 -5101 571 -2203 4171 -3575 7495 -5609 9827 -7549 11156
--9262 11713 -10722 11770 -11921 11558 -12872 11230 -13581 10887 -14060 10576
--14347 10317 -14464 10113 -14454 9958 -14360 9844 -14187 9760 -13991 9700
--13773 9654 -13556 9619 -13343 9592 -13130 9569 -12936 9550 -12747 9532
--12575 9517 -12407 9502 -12249 9490 -12091 9477 -11947 9467 -11800 9457
--11655 9449 -11507 9443 -11364 9437 -11234 9433 -11095 9431 -10961 9430
--10839 9429 -10705 9431 -10578 9433 -10466 9437 -10347 9442 -10227 9447
--10106 9453 -9991 9459 -9881 9465 -9772 9474 -9657 9484 -9636 9495 -9548 9505
--9435 9514 -9338 9522 -9249 9532 -9167 9542 -9090 9552 -9022 9563 -8962 9572
--8893 9583 -8835 9592 -8776 9602 -8731 9611 -8678 9621 -8630 9631 -8581 9639
--8543 9648 -8498 9656 -8470 9665 -8430 9673 -8396 9680 -8372 9688 -8346 9695
--8320 9703 -8301 9709 -8282 9715 -8259 9722 -8237 9728 -8227 9734 -8210 9739
--8204 9745 -8200 9749 -8188 9755 -8178 9760 -8176 9765 -8165 9769 -8164 9774
--8163 9777 -8160 9782 -8164 9786 -8165 9790 -8165 9794 -8165 9798 -8171 9801
--8178 9805 -8183 9809 -8182 9812 -8187 9815 -8195 9820 -8199 9822 -8213 9826
--8215 9830 -8221 9833 -8232 9837 -8242 9840 -8247 9844 -8250 9847
-183: 13659690 -4845201 -10030 9855 -10040 9858 -10050 9864 -10050 9869
--10070 9874 -10080 9880 -10100 9886 -10120 9891 -10120 9899 -10150 9905
--10160 9912 -10180 9919 -10210 9924 -10220 9931 -10240 9936 -10260 9941
--10280 9948 -10290 9955 -10310 9961 -10330 9964 -10350 9969 -10360 9973
--10370 9978 -10400 9980 -10410 9985 -10420 9991 -10440 9994 -10440 9994
--10450 9997 -10470 10003 -10480 10008 -10480 10010 -10500 10011 -10510 10017
--10530 10020 -10530 10024 -10560 10028 -10570 10033 -10590 10039 -10600 10045
--10630 10052 -10640 10059 -10670 10065 -10680 10074 -10720 10081 -10750 10091
--10770 10099 -10810 10109 -10840 10118 -10870 10126 -10910 10138 -10950 10149
--10990 10154 -11020 10166 -11060 10176 -11100 10184 -11120 10193 -11170 10198
--11200 10205 -11240 10210 -11270 10219 -11300 10226 -11330 10227 -11350 10230
--11390 10233 -11400 10236 -11430 10236 -11430 10237 -11460 10237 -11470 10237
--11480 10235 -11490 10235 -11490 10233 -11500 10231 -11510 10229 -11500 10228
--11500 10227 -11510 10224 -11520 10224 -11510 10226 -11520 10226 -11520 10230
--11520 10232 -11530 10236 -11530 10240 -11540 10247 -11570 10253 -11580 10262
--11590 10273 -11610 10283 -11640 10292 -11660 10303 -11700 10316 -11730 10332
--11770 10347 -11800 10361 -11840 10375 -11880 10389 -11930 10406 -11970 10420
--12040 10437 -12080 10450 -12130 10462 -12170 10474 -12210 10483 -12260 10494
--12320 10503 -12360 10509 -12400 10512 -12430 10515 -12460 10515 -12500 10515
--12520 10509 -12540 10505 -12560 10497 -12570 10488 -12580 10474 -12570 10458
--12570 10443 -12560 10424 -12540 10406 -12530 10387 -12500 10365 -12460 10339
--12430 10314 -12390 10291 -12350 10268 -12310 10246 -12270 10222 -12210 10197
--12160 10175 -12110 10155 -12060 10139 -12020 10123 -11970 10113 -11910 10099
--11870 10091 -11820 10084 -11800 10085 -11760 10089 -11740 10098 -11720 10108
--11700 10124 -11700 10142 -11700 10166 -11710 10196 -11720 10232 -11750 10272
--11780 10315 -11830 10362 -11870 10414 -11940 10469 -11990 10532 -12070 10599
--12170 10669 -12260 10743 -12350 10815 -12460 10892 -12580 10972 -12690 11059
--12830 11147 -12950 11235 -13080 11320 -13210 11403 -13350 11492 -13490 11585
--13640 11674 -13800 11763 -13920 11840 -14050 11919 -14190 11997 -14320 12074
--14460 12149 -14580 12215 -14700 12276 -14800 12326 -14900 12381 -14990 12422
--15080 12458 -15160 12488 -15230 12509 -15270 12519 -15310 12523 -15330 12516
--15360 12502 -15350 12476 -15350 12437 -15320 12388 -15280 12330 -15230 12260
--15160 12176 -15080 12081 -14990 11975 -14870 11852 -14730 11720 -14610 11579
--14450 11421 -14250 11247 -14050 11071 -13850 10887 -13650 10680 -13410 10456
--13060 10241 -12700 10040 -12420 9836 -12230 9581 -12010 9273 -11540 8997
--10730 8851 -9800 8828 -9090 8801 -8840 8600 -9030 8162 -9400 7583 -9490 7073
--8900 6870 -7340 7105 -4920 7773 -2020 8663 1060 9449 4080 10075 5950 10365
-2110 10438 -830 8248 -3480 7860 -1110 8587 860 11090 -1420 9675 -6680 7655
--1450 8437 -1240 8098 920 7936 2100 8476 4990 8554 2320 8945 4110 8153
--80 8109 -1960 8773 -3460 10886 -3130 9252 -3280 9462 3270 10451 1080 10233
-1870 9517 500 9440 -760 9722 -1970 9944 -2370 8175 -570 8438 1890 9458
-730 9625 -540 9408 -690 8882 -2220 8422 -3560 8814 -2100 10824 -4490 11361
--1050 11164 -830 11990 -1270 12437 -1250 12170 530 10924 440 11166 -270 11729
--740 12468 -780 12450 -400 11060 -1460 10866 -3270 11157 -5340 11596 -6830 11504
--6640 9985 -4750 11152 -4340 11607 -4570 9294 -5080 8797 -4640 8696 -3190 8711
--1790 8698 -3170 8757 -3820 9056 -4830 9594 -8920 11369 -8040 11645 -13980 11955
--17250 8743 -9630 9052 -4120 9249 2760 13141 2900 13032 2150 12104 1280 11135
--1360 9724 -2590 8639 -4480 7697 -9420 6152 -11320 5232 -11310 5699 -15360 11936
--15520 12036 -14840 11167 -14650 10506 -14200 10109 -13500 10181 -11850 10807
--11810 10661 -12350 10755 -11380 10958 -9500 11148 -2880 11471 -2270 11695
--3670 11734 -6420 11257 -3560 8892 -5890 8215 -8270 7969 -9130 6957 -7610 9865
--5580 9288 -5780 8253 -18930 7915 -20730 6465 -20340 5816 -19170 6090
--17430 6940 -15550 8640 -14560 8931 -14470 8246 -12500 6391 -16490 6808
--18000 6868 -16880 5854 -15440 4003 -14740 2506 -14500 2411 -14140 2770
--14160 3594 -14650 4915 -15090 6044 -15820 6281 -15570 6949 -17690 7329
--17810 6919 -15790 5331 -20770 3829 -21280 4868 -17840 6484 -14410 7746
--19930 8757 -18590 8657 -14970 7901 -7640 7073 1480 7044 -3900 7973 -12070 8107
--16150 8277 -13780 8322 -9130 8104 -11310 8213 -12780 8333 -12930 9062
--8810 9701 -1190 9770 920 10229 2220 10533 580 10670 -5180 10857 -21420 11248
--23150 11814 -18424 12567 -14101 12828 -10734 12597 -7365 12102 -3736 11848
-1750 12257 3389 11469 4515 9937 8143 8237 15950 7359 20223 8747 25750 13009
-28240 14499 25820 14552 17320 13389 4750 10811 -5610 6510 -6760 4222 -3430 3346
--800 3737 -4860 5569 -19890 7685 -27410 -456 -34640 521 -24026 1234 -12194 3181
--4346 6251 -2483 9465 -6366 9405 -15998 6665 -31065 2166 -38058 373 -36770 1797
--28038 6217 -15021 12012 -4985 15926 -528 16457 -686 14608 -1647 14441
--5272 14939 -16472 10412 -18063 6367 -8811 14011 5391 19712 9267 19214
--3973 14680 -201 12783 12164 13077 21093 13807 597 10505 -7420 9732 -17810 8007
--28295 2884 -29462 -7524 -21751 -9256 -26594 -1136 -12624 980 -1711 3703
-3170 6837 2730 9255 -579 10663 -4571 11265 -8034 11359 -10564 11183 -12198 10892
--13124 10580 -13561 10291 -13686 10050 -13634 9858 -13474 9713 -13279 9608
--13061 9534 -12861 9484 -12669 9450 -12500 9427 -12345 9412 -12207 9402
--12072 9395 -11951 9390 -11843 9386 -11740 9383 -11627 9379 -11523 9377
--11423 9376 -11313 9374 -11203 9373 -11090 9374 -10983 9375 -10872 9376
--10767 9379 -10662 9382 -10549 9387 -10445 9391 -10340 9397 -10240 9404
--10141 9411 -10035 9419 -9936 9427 -9837 9435 -9734 9443 -9661 9452 -9543 9465
--9514 9478 -9445 9488 -9348 9498 -9259 9507 -9175 9518 -9102 9528 -9033 9539
--8973 9550 -8914 9561 -8853 9571 -8796 9581 -8744 9591 -8704 9601 -8653 9610
--8607 9621 -8566 9629 -8529 9638 -8489 9647 -8460 9656 -8424 9663 -8395 9672
--8366 9679 -8345 9687 -8322 9694 -8301 9701 -8281 9707 -8262 9714 -8245 9720
--8231 9727 -8220 9731 -8212 9738 -8207 9743 -8198 9748 -8187 9753 -8180 9757
--8176 9763 -8177 9767 -8173 9772 -8173 9775 -8172 9780 -8175 9784 -8176 9789
--8180 9791 -8181 9796 -8186 9800 -8188 9803 -8195 9807 -8199 9810 -8209 9814
--8211 9818 -8218 9821 -8225 9824 -8232 9829 -8243 9831 -8250 9836 -8256 9839
--8259 9842
-184: 13692160 -4836538 -10040 9857 -10050 9861 -10060 9867 -10070 9871
--10080 9874 -10090 9883 -10110 9888 -10130 9892 -10140 9901 -10160 9905
--10170 9912 -10190 9919 -10220 9925 -10230 9932 -10250 9936 -10260 9941
--10290 9948 -10300 9955 -10320 9959 -10340 9966 -10350 9970 -10370 9972
--10380 9977 -10400 9978 -10410 9986 -10430 9991 -10440 9993 -10450 9994
--10460 9998 -10470 10005 -10480 10005 -10490 10011 -10510 10013 -10510 10014
--10530 10019 -10540 10023 -10550 10027 -10580 10035 -10590 10038 -10610 10045
--10620 10051 -10650 10060 -10660 10063 -10680 10073 -10720 10081 -10740 10089
--10770 10097 -10800 10106 -10840 10117 -10870 10124 -10900 10135 -10940 10145
--10980 10154 -11020 10162 -11050 10172 -11080 10180 -11110 10189 -11160 10195
--11180 10201 -11220 10208 -11260 10215 -11290 10219 -11310 10223 -11340 10228
--11360 10229 -11380 10229 -11410 10234 -11420 10231 -11440 10234 -11450 10234
--11460 10231 -11470 10230 -11470 10229 -11490 10227 -11490 10226 -11480 10225
--11490 10223 -11490 10223 -11490 10223 -11500 10223 -11510 10223 -11500 10227
--11510 10231 -11510 10234 -11510 10238 -11530 10244 -11550 10252 -11560 10261
--11580 10270 -11590 10280 -11620 10289 -11650 10300 -11680 10313 -11710 10329
--11750 10343 -11780 10357 -11820 10373 -11860 10384 -11900 10401 -11950 10415
--12010 10431 -12050 10444 -12100 10456 -12140 10467 -12180 10475 -12240 10487
--12280 10494 -12330 10501 -12360 10504 -12390 10505 -12430 10506 -12460 10506
--12480 10499 -12500 10494 -12530 10488 -12520 10478 -12540 10463 -12540 10448
--12530 10432 -12520 10414 -12510 10396 -12480 10377 -12470 10355 -12430 10330
--12400 10306 -12360 10282 -12320 10259 -12270 10236 -12240 10212 -12180 10189
--12140 10168 -12080 10147 -12050 10131 -11990 10119 -11950 10105 -11900 10093
--11850 10084 -11800 10078 -11780 10079 -11750 10083 -11720 10091 -11700 10100
--11680 10117 -11690 10134 -11680 10157 -11690 10187 -11710 10222 -11730 10259
--11760 10301 -11800 10348 -11860 10398 -11900 10452 -11970 10514 -12040 10578
--12130 10646 -12210 10718 -12310 10788 -12410 10861 -12530 10941 -12630 11024
--12770 11111 -12880 11195 -13000 11275 -13140 11358 -13270 11442 -13400 11532
--13560 11620 -13690 11703 -13820 11778 -13940 11853 -14070 11928 -14210 12003
--14330 12074 -14450 12138 -14560 12192 -14660 12242 -14760 12291 -14840 12332
--14920 12368 -15000 12392 -15050 12411 -15100 12419 -15130 12420 -15140 12414
--15160 12398 -15150 12370 -15140 12333 -15100 12283 -15050 12225 -15000 12155
--14920 12075 -14830 11981 -14720 11880 -14590 11765 -14440 11636 -14290 11496
--14130 11345 -13920 11183 -13700 11020 -13470 10848 -13230 10655 -12960 10447
--12630 10242 -12260 10048 -11930 9862 -11610 9652 -11290 9402 -10830 9161
--10170 8990 -9400 8905 -8720 8847 -8200 8727 -7840 8503 -7570 8205 -7220 7927
--6620 7784 -5560 7840 -4220 8125 -2520 8564 -210 9051 2450 9565 3980 9956
-2200 9991 -70 8821 -1710 8382 -580 8955 490 10242 -1020 9558 -3490 8410
--1440 8489 -760 8357 780 8308 2190 8549 3730 8694 3090 8908 3630 8444 1280 8408
-70 8887 -190 9882 560 10188 1900 10272 1060 10461 -2480 9968 2520 9416
-460 9509 -480 9610 -1390 10364 -1570 7173 2030 8649 4300 9894 670 9654
--1250 9408 310 8806 -50 8797 -260 9397 -2780 10369 -6520 9913 -2330 11284
--1440 12504 -1540 12849 -1750 12508 1540 10276 550 10613 -710 11953 -1240 12947
--960 13401 540 10818 -460 10583 -1930 10719 -3980 11325 -5550 11663 -4620 7550
--3180 11627 -2230 12011 -2490 10817 -4140 10367 -4100 10249 -3030 10128
--2180 9573 -6260 9395 -6600 9836 -7030 10015 -9070 11149 -9240 11958 -13490 11391
--16670 8452 -13230 7035 -4910 9257 8230 14691 2850 12130 880 10831 990 10500
--3320 9009 -3370 8666 -3830 8644 -12230 7317 -14320 6905 -12510 7426 -13130 10918
--13670 10956 -13180 10364 -13920 10144 -13790 9891 -13720 10115 -10820 11436
--11120 10782 -12170 10925 -9710 11084 -7350 11170 -5350 11414 -3760 11320
--3340 11012 -6560 10295 -6210 10248 -9720 9259 -12830 9439 -14650 5906
--13100 12221 -11500 9318 -11970 7601 -14500 7127 -17590 5357 -18630 5137
--18050 5718 -16060 6729 -12820 9718 -10290 9291 -9170 7767 -10110 6317
--18620 7449 -20700 7311 -18630 5780 -17380 3597 -17510 2591 -18100 4509
--17430 5100 -17370 5119 -18620 5578 -18830 5954 -17120 6372 -13460 7269
--17510 6363 -18740 5766 -18290 6058 -20180 4489 -22820 4377 -18560 5217
--12580 7392 -13810 7825 -13560 7444 -12470 5804 -9680 4387 3420 5262 -3640 7005
--13890 8518 -18120 9486 -10850 9765 -7600 9731 -10350 9840 -13480 9307
--17700 10041 -17460 10556 -6120 9929 -3810 10302 90 10507 -1930 10543
--9350 10799 -21120 11224 -24410 11645 -20770 11917 -17591 12184 -14694 12247
--10118 11997 -6056 11941 -1774 12002 1812 11310 6125 9845 11140 8132 15606 8050
-15870 10709 20280 13950 24460 15235 24330 14899 17170 13157 3370 9731
--9420 3031 -12920 1600 -12750 1587 -12780 2418 -15880 3919 -21720 4351
--22344 -771 -22856 -1783 -16691 -257 -8500 3917 -2369 9595 -1978 12972
--7441 11870 -17363 7080 -29026 691 -35775 -3789 -35803 -3944 -29752 1862
--20582 11978 -13575 17801 -10828 17192 -11058 13141 -11069 11676 -10731 15382
--15599 14709 -15793 14030 -7320 16261 3956 19832 5992 20385 -3447 16364
--4815 13136 5695 12937 19572 14773 13840 14017 5019 12753 -6039 10214
--15818 4210 -17376 -13224 -20076 -17066 -23490 4902 -15784 977 3806 3087
-14476 6719 13709 9203 6896 10408 -968 10816 -7357 10821 -11576 10642 -13870 10396
--14772 10140 -14813 9904 -14404 9703 -13819 9543 -13211 9423 -12670 9337
--12217 9281 -11880 9246 -11617 9228 -11443 9220 -11312 9219 -11220 9224
--11159 9229 -11107 9238 -11062 9245 -11022 9254 -10968 9261 -10920 9269
--10869 9276 -10806 9283 -10730 9291 -10656 9298 -10578 9306 -10499 9313
--10421 9322 -10345 9329 -10255 9338 -10174 9348 -10093 9356 -10006 9367
--9918 9378 -9838 9387 -9753 9398 -9664 9408 -9576 9419 -9491 9431 -9411 9444
--9432 9456 -9354 9469 -9262 9480 -9170 9490 -9096 9502 -9031 9514 -8970 9525
--8915 9536 -8864 9548 -8808 9558 -8752 9569 -8711 9580 -8670 9589 -8624 9600
--8580 9610 -8546 9619 -8512 9629 -8479 9637 -8443 9646 -8418 9655 -8390 9662
--8360 9671 -8338 9678 -8318 9686 -8301 9692 -8280 9700 -8264 9706 -8252 9712
--8236 9719 -8224 9724 -8216 9731 -8211 9735 -8205 9741 -8194 9747 -8189 9751
--8187 9756 -8185 9761 -8185 9765 -8182 9770 -8179 9774 -8179 9779 -8187 9782
--8192 9787 -8191 9790 -8196 9794 -8196 9798 -8204 9802 -8211 9805 -8220 9809
--8220 9813 -8224 9816 -8234 9820 -8242 9824 -8252 9827 -8259 9831 -8265 9834
--8267 9838
-185: 13724670 -4827887 -10050 9860 -10070 9862 -10070 9869 -10080 9875
--10090 9878 -10110 9884 -10120 9890 -10140 9895 -10150 9901 -10170 9907
--10180 9913 -10210 9919 -10220 9927 -10240 9930 -10260 9936 -10270 9943
--10290 9949 -10310 9953 -10330 9959 -10340 9965 -10360 9970 -10370 9973
--10400 9977 -10400 9979 -10420 9985 -10430 9990 -10440 9991 -10460 9995
--10460 10000 -10470 10003 -10490 10004 -10500 10010 -10510 10013 -10520 10015
--10530 10019 -10540 10022 -10560 10029 -10570 10032 -10590 10038 -10620 10043
--10620 10052 -10640 10059 -10670 10064 -10680 10071 -10720 10079 -10730 10087
--10770 10097 -10800 10105 -10830 10114 -10860 10122 -10900 10131 -10940 10143
--10970 10152 -11000 10160 -11040 10168 -11070 10175 -11100 10186 -11150 10191
--11170 10198 -11210 10205 -11240 10210 -11270 10215 -11300 10219 -11320 10224
--11340 10224 -11360 10225 -11390 10227 -11400 10229 -11430 10230 -11430 10228
--11440 10228 -11450 10226 -11460 10225 -11460 10225 -11480 10222 -11460 10221
--11470 10221 -11470 10220 -11480 10219 -11490 10220 -11480 10223 -11490 10224
--11490 10228 -11490 10232 -11510 10236 -11510 10242 -11530 10250 -11540 10258
--11560 10269 -11580 10276 -11610 10287 -11620 10298 -11660 10310 -11700 10326
--11730 10340 -11760 10354 -11800 10369 -11830 10380 -11880 10395 -11930 10410
--11970 10427 -12030 10438 -12070 10449 -12110 10460 -12150 10468 -12200 10479
--12250 10487 -12290 10492 -12330 10495 -12360 10498 -12390 10496 -12420 10495
--12440 10491 -12470 10485 -12480 10477 -12500 10468 -12490 10453 -12510 10440
--12480 10422 -12490 10403 -12470 10386 -12450 10369 -12430 10346 -12390 10320
--12370 10297 -12330 10272 -12290 10251 -12250 10229 -12200 10205 -12150 10182
--12120 10159 -12050 10141 -12020 10124 -11980 10113 -11920 10098 -11880 10086
--11830 10077 -11790 10072 -11760 10073 -11730 10076 -11710 10085 -11680 10093
--11680 10108 -11660 10127 -11670 10148 -11670 10177 -11690 10211 -11700 10246
--11750 10287 -11780 10334 -11830 10383 -11880 10435 -11930 10493 -12010 10556
--12090 10624 -12180 10693 -12270 10759 -12350 10831 -12470 10907 -12580 10990
--12700 11072 -12820 11154 -12930 11232 -13060 11310 -13190 11393 -13320 11479
--13460 11563 -13590 11643 -13720 11716 -13840 11787 -13950 11859 -14090 11933
--14210 11998 -14320 12059 -14430 12111 -14520 12158 -14600 12202 -14700 12243
--14760 12276 -14840 12300 -14880 12315 -14930 12320 -14950 12320 -14950 12314
--14970 12296 -14960 12269 -14930 12232 -14880 12182 -14830 12125 -14760 12056
--14680 11978 -14580 11889 -14460 11791 -14310 11683 -14160 11559 -14000 11422
--13800 11278 -13600 11127 -13350 10977 -13100 10818 -12830 10636 -12540 10443
--12200 10248 -11830 10067 -11440 9900 -11060 9726 -10660 9517 -10210 9301
--9630 9124 -8960 9008 -8290 8931 -7640 8860 -6960 8762 -6310 8636 -5670 8508
--5040 8420 -4280 8387 -3540 8467 -2670 8637 -1240 8889 680 9247 2000 9601
-1720 9690 630 9159 -220 8825 190 9074 680 9625 20 9408 -980 8910 -420 8813
-160 8732 1140 8701 2220 8803 3160 8948 3460 9086 3600 8793 2710 8842 2360 9127
-2650 9736 3340 10289 4110 10462 3700 10235 2850 9588 -1620 9649 -1960 9538
-260 7652 -3800 8379 -3080 8051 4260 10508 8650 11371 1730 9893 -220 9868
-860 8945 360 9371 -380 10002 -1070 11476 -3020 6879 -2580 10650 -1160 12564
--140 12093 620 11117 -220 10038 -990 11184 -1780 11863 -1390 12435 430 13300
-330 11802 -270 11054 -730 10388 -2610 10559 -3760 11655 -4990 9039 -2750 11376
--610 11629 -760 11355 -4320 11475 -4680 11544 -4480 11508 -4520 10187
--7120 10351 -7930 11218 -8160 10327 -9720 10958 -8560 12441 -11390 11857
--14090 9578 -10020 9541 -5130 9665 6370 12656 -4020 8422 -4280 8372 -2330 9727
--4080 8623 -5260 8828 -5790 9918 -11540 9700 -16080 9330 -11440 8145 -10440 9465
--10490 10475 -10700 9678 -11350 9879 -11270 9915 -12310 10574 -11580 11724
--12450 10620 -12260 10794 -8030 11170 -5610 10992 -8620 11251 -6550 10737
--5000 10025 -5670 9455 -7050 12127 -13640 10493 -16250 10262 -18060 9596
--18490 12378 -17020 6898 -18070 5688 -10570 5782 -13830 4974 -16770 5197
--17190 6377 -15570 7817 -10670 10122 -7040 9071 -5390 7089 -7280 5485
--23140 8489 -24180 8162 -19490 6035 -19040 2930 -20240 1788 -22320 7462
--20680 7423 -18770 6253 -21620 6101 -22790 5693 -20690 5933 -12600 7542
--15260 6821 -19800 6123 -21070 6365 -21730 5300 -21000 4100 -15710 3639
--5460 6791 -3880 7292 -3470 6178 -2750 3770 -910 2022 2870 2725 -5290 5699
--18160 8835 -24200 10702 -8480 11008 -5600 10741 -7220 10372 -16770 10789
--21250 11118 -21020 11023 -15600 10599 -13670 10853 -4300 10803 -6170 10471
--13680 10799 -22570 11320 -25780 11666 -20070 11426 -19150 11822 -18550 12247
--12330 11922 -8827 11927 -5808 11936 -1637 11459 5013 10219 10679 8000
-13040 8191 6930 12146 11800 14347 19430 14908 22880 13862 16980 11018
--2820 5562 -14530 1769 -18600 561 -19280 14 -19270 -72 -19960 828 -20791 2123
--19582 -538 -17836 -2278 -13345 -955 -6758 4861 -189 14292 -664 18446
--7428 16173 -17572 9248 -27776 241 -34188 -7690 -35061 -10755 -30517 -3773
--22907 14799 -18532 23375 -18764 20151 -21369 10497 -20815 5555 -12799 17858
--16378 18320 -19396 14895 -10837 16195 8053 23418 7743 22986 -7582 16069
--16627 10305 -6287 9816 23659 14999 29624 16218 19939 14140 6522 10394
--4149 4412 -8702 -4919 -11769 -6495 -24926 -572 -16097 -8172 21017 1036
-33690 7051 26313 9297 12013 9834 -1273 9849 -10708 9761 -16133 9664 -18448 9561
--18729 9450 -17860 9338 -16490 9232 -15028 9141 -13697 9072 -12594 9024
--11737 8997 -11133 8987 -10730 8989 -10467 8999 -10322 9015 -10262 9035
--10239 9055 -10247 9076 -10265 9098 -10278 9117 -10288 9136 -10299 9153
--10300 9171 -10279 9187 -10247 9202 -10207 9217 -10164 9231 -10116 9245
--10068 9259 -10014 9273 -9949 9286 -9893 9299 -9835 9313 -9763 9326 -9689 9340
--9632 9354 -9564 9366 -9482 9379 -9413 9391 -9348 9406 -9282 9420 -9317 9435
--9252 9449 -9167 9460 -9078 9473 -9009 9485 -8956 9497 -8899 9510 -8851 9522
--8805 9533 -8755 9546 -8711 9556 -8672 9567 -8629 9578 -8590 9589 -8554 9599
--8521 9608 -8490 9619 -8460 9627 -8431 9637 -8404 9645 -8381 9653 -8355 9662
--8333 9669 -8310 9678 -8296 9684 -8283 9691 -8264 9699 -8254 9704 -8238 9712
--8229 9717 -8219 9723 -8211 9729 -8209 9734 -8202 9740 -8199 9745 -8193 9750
--8193 9755 -8191 9759 -8189 9764 -8186 9768 -8191 9773 -8195 9777 -8198 9781
--8200 9786 -8203 9789 -8209 9793 -8213 9796 -8220 9801 -8227 9804 -8229 9808
--8233 9812 -8244 9815 -8251 9819 -8259 9823 -8266 9826 -8273 9830 -8275 9834
-186: 13757210 -4819244 -10070 9861 -10070 9866 -10090 9872 -10090 9875
--10110 9880 -10120 9886 -10130 9893 -10140 9896 -10170 9903 -10180 9907
--10190 9914 -10210 9920 -10230 9927 -10250 9932 -10260 9937 -10290 9945
--10300 9949 -10310 9952 -10340 9959 -10350 9965 -10360 9971 -10380 9973
--10400 9975 -10410 9980 -10420 9984 -10440 9990 -10450 9992 -10460 9995
--10460 9998 -10480 10002 -10490 10004 -10510 10008 -10520 10013 -10520 10017
--10530 10018 -10540 10022 -10560 10027 -10580 10032 -10590 10039 -10610 10043
--10630 10050 -10640 10057 -10670 10065 -10690 10070 -10700 10077 -10740 10086
--10760 10094 -10800 10104 -10830 10114 -10860 10120 -10880 10129 -10930 10138
--10960 10149 -11000 10157 -11020 10165 -11060 10173 -11090 10181 -11140 10187
--11160 10195 -11190 10202 -11230 10205 -11250 10212 -11280 10215 -11310 10219
--11320 10220 -11350 10220 -11370 10222 -11390 10225 -11400 10226 -11410 10225
--11420 10221 -11430 10224 -11450 10221 -11450 10220 -11450 10221 -11450 10219
--11450 10216 -11450 10217 -11470 10217 -11470 10217 -11470 10220 -11470 10223
--11470 10226 -11480 10228 -11490 10234 -11500 10239 -11510 10248 -11520 10255
--11550 10266 -11560 10275 -11580 10284 -11610 10295 -11640 10308 -11680 10322
--11700 10337 -11750 10351 -11780 10364 -11810 10376 -11850 10390 -11900 10406
--11950 10421 -12000 10432 -12040 10443 -12080 10453 -12120 10462 -12170 10472
--12220 10479 -12260 10484 -12290 10487 -12330 10489 -12350 10487 -12380 10486
--12410 10482 -12420 10477 -12450 10468 -12450 10457 -12460 10445 -12460 10429
--12460 10412 -12440 10394 -12430 10377 -12420 10360 -12400 10338 -12360 10313
--12330 10286 -12290 10264 -12270 10242 -12220 10223 -12180 10199 -12120 10175
--12080 10153 -12040 10134 -11990 10118 -11950 10106 -11910 10092 -11850 10080
--11820 10070 -11770 10066 -11750 10066 -11710 10070 -11690 10077 -11670 10086
--11660 10100 -11640 10118 -11650 10141 -11660 10167 -11660 10198 -11690 10233
--11720 10275 -11760 10320 -11800 10366 -11850 10416 -11900 10472 -11980 10536
--12050 10600 -12130 10665 -12230 10730 -12300 10801 -12410 10874 -12530 10954
--12640 11033 -12750 11113 -12870 11186 -12980 11264 -13100 11344 -13240 11424
--13370 11506 -13500 11583 -13620 11654 -13720 11721 -13850 11791 -13970 11859
--14090 11923 -14200 11981 -14280 12030 -14380 12074 -14460 12116 -14550 12155
--14610 12185 -14680 12207 -14720 12222 -14750 12225 -14770 12223 -14780 12214
--14780 12198 -14760 12171 -14720 12135 -14670 12085 -14610 12030 -14540 11963
--14440 11887 -14330 11800 -14200 11709 -14050 11605 -13880 11489 -13700 11357
--13500 11220 -13270 11078 -13020 10940 -12740 10793 -12440 10625 -12140 10443
--11800 10263 -11410 10093 -10990 9947 -10550 9796 -10120 9618 -9640 9427
--9090 9260 -8480 9134 -7840 9049 -7150 8992 -6340 8953 -5510 8913 -4740 8871
--4040 8831 -3350 8787 -2810 8795 -2330 8850 -1510 8963 -260 9175 850 9445
-1300 9589 1040 9376 690 9139 830 9172 1080 9376 920 9333 600 9163 750 9097
-1160 9056 1830 9034 2550 9078 3210 9196 3750 9328 3880 9196 3840 9270 4150 9415
-4610 9854 4920 10406 4950 10622 4190 10321 2480 9785 -1130 9575 -420 9169
-14750 7646 -15860 5575 -9480 8380 4520 12489 9520 11776 7770 9984 4890 8116
-2360 12131 1130 10594 450 9142 1070 9527 70 6423 -1940 11862 -200 12858
-970 11159 1390 9277 150 9302 -1800 11340 -2680 11579 -1680 11869 2300 13255
-70 12136 -30 11455 -160 11059 -3090 10512 -5040 13947 -5060 10301 -2180 10388
-640 9979 -720 10962 -3400 11657 -4420 11954 -5220 11883 -6040 11127 -7830 11272
--8620 13136 -7690 10632 -9420 11252 -9970 12230 -11540 11992 -15700 9096
--10770 9841 -7660 10421 840 9924 -4070 7571 -5890 7168 -2700 9699 -4820 9177
--7480 9284 -6780 11690 -12340 12081 -16550 11546 -7690 7860 -7510 8111
--7480 9729 -8530 9684 -9130 10063 -8070 9979 -11910 10550 -12790 11319
--13570 11593 -12940 11611 -10210 11450 -8530 11101 -9370 10955 -8040 10519
--6660 10054 -6700 9948 -8450 11126 -12900 10595 -15880 10428 -17980 10254
--18960 10374 -18390 7121 -17530 5503 -13390 4988 -14710 4858 -17410 5639
--17710 7582 -17270 8834 -10690 11160 -7290 8886 -7300 7307 -11630 5783
--21960 7948 -24740 8675 -18070 6848 -22020 2048 -22700 830 -26250 11972
--22980 8892 -18570 6525 -20230 6470 -24210 5540 -24710 5458 -10060 8516
--15700 7318 -21020 6241 -22830 7201 -22670 6780 -19770 5814 -5400 2390
-3470 4502 6390 5568 7610 4292 8650 1527 9340 -375 7610 452 -3250 4593 -19990 9668
--26050 12251 -17080 12457 -11680 11868 -10960 11295 -15970 11222 -22050 11715
--22310 11152 -19770 10721 -18920 11159 -13750 11392 -12360 10371 -17960 10899
--24230 11496 -27490 11876 -16660 10912 -19760 11646 -24050 12698 -14520 11907
--12690 11901 -11200 11876 -7600 11748 1290 11306 5110 8340 2710 9211 -2280 12047
-1550 13689 13030 13627 20430 11866 18250 8502 -11390 976 -19700 1482 -22000 1164
--21960 -638 -20969 -2600 -19950 -2424 -18473 2287 -17266 720 -16065 -1995
--13483 -1959 -7911 4428 2514 20497 1418 25288 -6704 21822 -17217 13409
--26740 2363 -32774 -9301 -34041 -17857 -30004 -12928 -21034 22451 -18472 33757
--22014 26853 -29199 7787 -31200 -8460 -6757 25387 -16057 21039 -26992 11086
--20123 10628 19832 27776 15273 25871 -14298 13084 -35178 3954 -27921 2873
-33934 14965 44416 17022 28992 13230 11993 8857 -689 4324 -8417 -184 -13304 -2610
--18927 -2932 3483 -9498 63337 5964 61053 9520 35256 8888 9374 8008 -9278 7687
--20283 7777 -25318 8024 -26354 8270 -25045 8452 -22603 8561 -19804 8618
--17138 8643 -14847 8656 -13010 8667 -11628 8684 -10655 8705 -10019 8735
--9626 8766 -9431 8802 -9354 8838 -9357 8874 -9409 8910 -9470 8943 -9543 8976
--9612 9005 -9674 9033 -9725 9060 -9745 9085 -9756 9109 -9754 9131 -9742 9152
--9728 9173 -9707 9193 -9673 9212 -9644 9229 -9604 9248 -9566 9265 -9513 9283
--9465 9300 -9416 9317 -9361 9332 -9306 9347 -9251 9362 -9193 9378 -9144 9395
--9201 9412 -9145 9427 -9062 9440 -8981 9454 -8919 9466 -8872 9481 -8822 9493
--8785 9506 -8743 9519 -8700 9531 -8664 9543 -8625 9555 -8592 9566 -8554 9577
--8520 9587 -8495 9598 -8465 9608 -8438 9617 -8414 9627 -8389 9635 -8365 9645
--8347 9652 -8324 9661 -8302 9669 -8291 9676 -8279 9683 -8266 9691 -8250 9697
--8240 9704 -8234 9710 -8222 9717 -8213 9722 -8209 9727 -8207 9734 -8202 9738
--8199 9744 -8202 9749 -8197 9753 -8196 9759 -8197 9762 -8198 9768 -8200 9772
--8202 9776 -8212 9780 -8213 9784 -8216 9788 -8222 9792 -8228 9796 -8233 9800
--8235 9804 -8246 9807 -8252 9811 -8260 9814 -8265 9819 -8269 9822 -8280 9825
--8282 9829
-187: 13789780 -4810612 -10080 9865 -10080 9867 -10100 9875 -10100 9877
--10120 9882 -10140 9889 -10140 9893 -10160 9898 -10160 9905 -10200 9909
--10200 9915 -10220 9921 -10240 9927 -10250 9933 -10270 9940 -10290 9943
--10310 9948 -10330 9954 -10340 9959 -10360 9965 -10370 9971 -10390 9973
--10400 9976 -10410 9980 -10430 9982 -10440 9989 -10460 9995 -10460 9994
--10460 9997 -10480 10001 -10500 10005 -10520 10008 -10520 10012 -10520 10015
--10540 10019 -10540 10023 -10560 10026 -10580 10031 -10600 10038 -10610 10042
--10620 10049 -10650 10057 -10660 10063 -10690 10069 -10710 10076 -10730 10085
--10770 10092 -10790 10101 -10830 10113 -10850 10119 -10880 10126 -10910 10135
--10960 10145 -10980 10154 -11010 10163 -11060 10170 -11080 10178 -11120 10183
--11150 10192 -11180 10199 -11210 10201 -11240 10205 -11260 10212 -11290 10213
--11310 10217 -11330 10216 -11350 10219 -11370 10220 -11390 10221 -11390 10221
--11410 10218 -11410 10219 -11420 10217 -11430 10218 -11440 10218 -11430 10215
--11440 10213 -11430 10213 -11450 10214 -11450 10216 -11460 10218 -11450 10220
--11460 10223 -11460 10226 -11470 10231 -11490 10237 -11500 10244 -11500 10253
--11530 10263 -11540 10272 -11570 10282 -11590 10290 -11620 10306 -11660 10319
--11680 10333 -11720 10348 -11760 10360 -11790 10372 -11830 10385 -11870 10401
--11930 10415 -11970 10428 -12010 10438 -12050 10446 -12100 10455 -12130 10464
--12180 10471 -12230 10477 -12260 10479 -12290 10481 -12320 10479 -12340 10478
--12360 10473 -12400 10467 -12410 10460 -12410 10448 -12420 10436 -12420 10418
--12420 10403 -12400 10387 -12390 10369 -12390 10351 -12360 10329 -12330 10305
--12300 10279 -12260 10255 -12230 10236 -12190 10215 -12150 10192 -12110 10170
--12050 10147 -12010 10128 -11970 10112 -11930 10100 -11880 10086 -11840 10074
--11790 10065 -11760 10059 -11730 10059 -11700 10064 -11670 10071 -11650 10078
--11630 10092 -11640 10109 -11620 10132 -11640 10156 -11650 10187 -11670 10222
--11690 10262 -11740 10303 -11770 10349 -11820 10396 -11870 10452 -11940 10514
--12010 10574 -12090 10640 -12180 10702 -12260 10769 -12360 10840 -12470 10916
--12580 10993 -12680 11071 -12800 11143 -12900 11216 -13030 11293 -13160 11371
--13280 11448 -13400 11523 -13510 11591 -13630 11655 -13740 11722 -13850 11788
--13970 11847 -14070 11904 -14150 11950 -14240 11992 -14320 12030 -14400 12068
--14460 12096 -14520 12117 -14560 12129 -14580 12130 -14590 12129 -14600 12119
--14600 12102 -14560 12076 -14520 12038 -14470 11994 -14400 11939 -14310 11873
--14210 11800 -14090 11720 -13950 11630 -13780 11534 -13610 11423 -13420 11299
--13200 11170 -12960 11037 -12690 10908 -12390 10773 -12080 10618 -11760 10452
--11400 10284 -11000 10129 -10570 9995 -10100 9865 -9620 9711 -9120 9547
--8580 9396 -7970 9277 -7380 9190 -6690 9134 -5890 9111 -4990 9104 -4160 9105
--3420 9099 -2730 9071 -2170 9077 -1730 9111 -1220 9166 -420 9274 450 9455
-1140 9604 1310 9550 1250 9389 1300 9322 1490 9364 1580 9360 1570 9324 1720 9315
-2090 9313 2620 9309 3180 9337 3670 9435 4190 9569 4280 9593 4740 9657 5380 9733
-5810 10094 5810 10621 5450 10845 4660 10588 3350 10098 1390 9562 870 8565
-1730 6737 -10490 6775 -8130 13141 8890 13009 12330 12719 10660 11022 7690 9787
-4780 11164 2990 10172 2310 8943 2470 8614 1720 7905 650 10415 1360 10749
-2160 9076 2280 7565 960 7565 -2100 11540 -2730 11792 -1290 11736 1120 11930
-380 11498 380 11864 1420 13505 -4560 13429 -7270 17075 -6890 17700 -1150 -226
-1810 5860 310 9894 -2670 11624 -3780 12056 -5220 12091 -6140 11651 -7240 11692
--8180 12570 -9000 11721 -11380 11542 -14010 11140 -17090 10036 -19080 8704
--11610 10692 -4410 10850 -2500 9703 -2890 8715 -3710 8540 -2940 9686 -4410 9841
--6460 10340 -7920 12071 -11240 12590 -12800 11652 -8350 9159 -7080 8568
--7000 9202 -7920 9262 -8560 9334 -4960 11170 -13210 10792 -14050 11089
--15160 12664 -14850 12455 -13140 11794 -11520 11208 -10790 10942 -9280 10613
--7800 10187 -7340 9895 -8300 10034 -10960 9848 -13610 9777 -15900 9548
--17240 8940 -17460 7046 -16800 5504 -15300 4828 -16280 5201 -18190 6601
--18880 8897 -18300 10906 -15730 10397 -10940 7358 -11500 7602 -15470 5396
--21000 7924 -22130 9924 -19530 9839 -30060 4693 -31770 7069 -22290 9958
--21860 6144 -15810 5610 -13880 7249 -19150 6827 -18220 8125 -15300 7559
--21710 6873 -23900 5890 -22870 7450 -20760 7280 -17520 6262 5090 2116
-12060 3247 14790 4022 16650 2570 18330 -197 18910 -2037 15560 -1185 2400 3489
--24220 11524 -31980 14329 -25900 13698 -19160 12682 -15770 12052 -17300 11753
--21090 11668 -22130 10767 -20710 10187 -23100 10869 -20010 11272 -17370 10759
--20290 11287 -20970 11406 -19350 11206 -19370 11214 -20280 11548 -26830 13065
--22350 12682 -18990 12081 -16810 11484 -14300 11139 -1390 11201 -4140 10131
--10450 10669 -16490 12171 -14190 12936 3150 11972 10480 8587 8440 3176
--9680 -877 -18460 5083 -21030 4447 -20653 536 -18588 -3878 -17009 -5500
--14689 5155 -14742 3169 -15248 -596 -15088 -2556 -11991 1500 5769 27565
-2708 30893 -6660 26842 -17079 19089 -25631 8813 -30686 -4226 -31832 -19955
--28315 -27907 -14894 33966 -13159 44749 -17668 38211 -28768 12589 -42936 -34826
-12326 41811 -14881 17774 -34058 1606 -35496 -1708 39073 32160 25008 26575
--21627 6114 -49651 -3486 -57044 -6440 45076 14189 46512 14841 21987 8544
-5349 4745 -6634 1996 -15213 317 -4115 2428 -9044 7052 69176 -4338 131072 14619
-77435 8690 24874 4475 -9668 3268 -28837 3675 -37414 4664 -39300 5694 -37290 6548
--33310 7176 -28616 7605 -23999 7884 -19879 8065 -16470 8186 -13792 8273
--11806 8345 -10400 8408 -9485 8468 -8934 8526 -8642 8582 -8530 8636 -8537 8688
--8608 8739 -8714 8786 -8832 8830 -8951 8870 -9058 8910 -9150 8946 -9218 8979
--9263 9012 -9301 9041 -9325 9071 -9339 9097 -9342 9123 -9333 9147 -9334 9171
--9316 9193 -9290 9216 -9261 9236 -9231 9257 -9197 9277 -9161 9297 -9127 9313
--9083 9331 -9039 9349 -8996 9367 -9079 9388 -9031 9403 -8952 9419 -8880 9432
--8824 9448 -8786 9462 -8748 9476 -8708 9490 -8676 9504 -8642 9516 -8613 9529
--8578 9542 -8546 9553 -8516 9565 -8489 9576 -8464 9586 -8437 9597 -8412 9607
--8397 9617 -8370 9626 -8348 9635 -8332 9644 -8313 9652 -8298 9660 -8283 9668
--8275 9676 -8262 9682 -8249 9690 -8239 9697 -8228 9703 -8226 9709 -8217 9716
--8216 9721 -8208 9727 -8205 9732 -8202 9738 -8206 9743 -8203 9748 -8201 9753
--8207 9757 -8206 9762 -8205 9767 -8210 9771 -8220 9775 -8219 9780 -8225 9783
--8225 9788 -8233 9791 -8241 9796 -8243 9799 -8255 9803 -8263 9807 -8263 9810
--8273 9814 -8277 9818 -8287 9822 -8288 9825
-188: 13822380 -4801991 -10080 9867 -10110 9871 -10100 9878 -10120 9881
--10130 9886 -10140 9890 -10150 9894 -10170 9899 -10180 9907 -10200 9909
--10220 9917 -10220 9923 -10250 9928 -10260 9932 -10280 9940 -10300 9943
--10310 9950 -10340 9953 -10350 9960 -10360 9964 -10380 9971 -10390 9973
--10410 9976 -10420 9980 -10430 9983 -10440 9988 -10460 9995 -10470 9995
--10470 9998 -10490 9999 -10500 10004 -10510 10009 -10530 10012 -10530 10012
--10540 10020 -10540 10023 -10570 10026 -10580 10029 -10590 10036 -10610 10043
--10630 10049 -10640 10056 -10670 10060 -10680 10068 -10710 10075 -10740 10084
--10760 10090 -10790 10099 -10820 10110 -10850 10119 -10880 10125 -10900 10133
--10940 10141 -10980 10151 -11010 10159 -11040 10168 -11060 10174 -11110 10181
--11140 10188 -11170 10194 -11200 10197 -11220 10202 -11240 10207 -11270 10209
--11300 10212 -11320 10213 -11330 10214 -11360 10216 -11360 10216 -11380 10215
--11390 10215 -11390 10216 -11400 10215 -11410 10214 -11420 10214 -11420 10211
--11420 10210 -11420 10210 -11430 10211 -11440 10214 -11430 10215 -11450 10217
--11440 10220 -11450 10224 -11450 10228 -11470 10234 -11480 10243 -11490 10249
--11520 10261 -11520 10269 -11550 10278 -11570 10289 -11600 10302 -11630 10315
--11660 10330 -11700 10343 -11740 10356 -11770 10368 -11810 10381 -11850 10395
--11900 10410 -11940 10422 -11980 10432 -12020 10441 -12060 10448 -12110 10457
--12150 10464 -12190 10469 -12220 10471 -12250 10473 -12290 10473 -12300 10470
--12330 10465 -12350 10458 -12370 10451 -12380 10440 -12380 10426 -12390 10409
--12380 10395 -12360 10380 -12360 10360 -12350 10344 -12330 10320 -12290 10297
--12260 10272 -12240 10249 -12190 10229 -12170 10208 -12120 10187 -12080 10163
--12030 10141 -11990 10122 -11930 10107 -11910 10094 -11860 10080 -11820 10070
--11780 10059 -11730 10054 -11710 10052 -11690 10058 -11660 10063 -11630 10070
--11610 10084 -11610 10101 -11610 10122 -11620 10146 -11630 10177 -11650 10209
--11670 10249 -11700 10287 -11740 10329 -11790 10378 -11840 10432 -11910 10489
--11970 10550 -12060 10613 -12120 10674 -12220 10737 -12300 10805 -12410 10879
--12520 10953 -12620 11029 -12720 11099 -12840 11167 -12950 11243 -13070 11318
--13190 11391 -13310 11462 -13410 11527 -13520 11590 -13640 11653 -13740 11716
--13850 11775 -13940 11826 -14030 11870 -14100 11909 -14180 11948 -14260 11981
--14310 12010 -14360 12026 -14400 12038 -14420 12039 -14420 12035 -14420 12026
--14410 12010 -14380 11983 -14330 11947 -14260 11905 -14200 11852 -14090 11789
--13980 11718 -13860 11642 -13700 11558 -13520 11468 -13350 11363 -13140 11247
--12910 11124 -12650 11001 -12370 10882 -12070 10759 -11730 10617 -11400 10465
--11020 10312 -10610 10169 -10160 10049 -9690 9933 -9170 9800 -8660 9660
--8080 9531 -7490 9424 -6910 9342 -6260 9287 -5480 9263 -4610 9264 -3770 9280
--3030 9291 -2320 9280 -1690 9299 -1180 9346 -710 9393 -150 9448 510 9555
-1190 9682 1570 9699 1670 9601 1730 9513 1900 9487 2080 9481 2260 9488 2500 9513
-2890 9540 3420 9561 3900 9596 4350 9679 4800 9817 4850 9951 5500 10010
-6230 10068 6590 10384 6470 10881 6150 11143 5910 11073 5820 10866 5810 10662
-5980 10283 5290 9387 150 8309 -15010 10979 5840 16454 10270 14715 9600 12071
-7980 10503 6080 10210 4800 9306 4460 8425 4370 8104 3770 8088 3110 9017
-3120 8820 3330 7649 2880 7070 1130 7491 -1370 9796 -1880 10671 -640 10539
-510 10229 -250 9982 -500 11008 4500 15053 -5940 12610 -7800 13718 -6010 12285
--2160 1520 2480 9999 860 11724 -2100 12247 -4080 12381 -5400 12237 -6020 11727
--6770 11631 -8100 12153 -10120 12010 -13380 11349 -17690 9850 -23390 7638
--29200 5460 -27700 5443 6610 15662 5250 13750 1420 11517 -910 10621 -1830 10661
--3230 10693 -5010 11068 -7400 12276 -9580 12580 -10270 11698 -8430 10069
--7330 9433 -7110 9693 -7590 9946 -8250 10116 -9100 11031 -12670 10637
--14880 11574 -16730 12919 -17150 12693 -16010 11795 -14080 11035 -12520 11039
--10480 10771 -8490 10167 -7320 9486 -7110 9018 -8510 8773 -10720 8660
--13150 8386 -14760 7793 -15920 6626 -16150 5348 -16280 4785 -17720 5340
--19480 6637 -20600 8291 -20450 9347 -19080 8788 -16280 7051 -16780 7126
--19550 6907 -22620 8811 -23330 10329 -22980 9902 -27920 7416 -28800 8544
--23150 9299 -20410 7676 -15870 7497 -13440 8524 -14580 9040 -13900 9974
--19360 8414 -22240 8121 -23870 6050 -18880 7662 -15610 7484 -5030 4645
-8160 2678 14840 3165 18480 3351 21380 1854 23830 -535 24830 -2086 22150 -1526
-10470 2175 -31990 14379 -38620 16195 -31640 13790 -24310 12585 -18860 12245
--18430 11850 -21780 11672 -23740 10673 -23280 10287 -24110 9966 -23660 11152
--21120 11153 -20450 11506 -18970 11596 -16730 11344 -15870 11050 -16320 11015
--30220 13802 -27270 13247 -22140 12070 -16850 10831 -11340 10010 -10720 11380
--16410 11416 -23010 11743 -30710 12430 -33710 12804 -6780 11608 -2440 7351
-30 -201 -11700 -3267 -18340 11727 -19038 8786 -17569 3412 -13095 -1170
--11207 -1756 -10929 3799 -12253 4303 -13527 2826 -13141 2454 -9204 7366
-96 22558 -1488 28185 -9219 27729 -17937 24341 -24432 19483 -27062 12404
--26259 -466 -21086 -20535 -11571 14190 -7035 37239 -5567 48381 -6137 45610
--23253 -24573 10183 22405 -24248 -9400 -20697 -5033 -768 8280 3587 7836
-14355 15602 -28421 -5258 -23700 -1954 1075 5808 -35757 -7479 4814 4052
--7321 -585 -10779 -811 -19691 -1742 -39694 -2970 45214 28456 96523 70085
-258022 -1330 117196 -9808 22400 -9837 -27110 -7763 -50760 -4858 -59846 -1845
--60496 838 -56384 3000 -49855 4623 -42435 5775 -35111 6566 -28482 7094
--22839 7447 -18273 7687 -14740 7860 -12134 7993 -10302 8102 -9093 8195
--8359 8280 -7953 8359 -7788 8433 -7786 8500 -7869 8566 -8004 8626 -8155 8682
--8312 8734 -8460 8784 -8592 8828 -8697 8872 -8782 8912 -8856 8950 -8910 8985
--8949 9019 -8985 9051 -9001 9081 -9019 9109 -9022 9137 -9020 9163 -9009 9188
--8997 9212 -8981 9237 -8960 9257 -8939 9279 -8915 9298 -8880 9318 -8855 9338
--8945 9361 -8910 9379 -8837 9395 -8776 9411 -8729 9427 -8694 9443 -8666 9459
--8633 9473 -8606 9487 -8582 9502 -8558 9515 -8527 9527 -8502 9541 -8473 9552
--8455 9564 -8429 9575 -8409 9586 -8389 9597 -8372 9606 -8351 9617 -8331 9625
--8318 9635 -8301 9643 -8286 9652 -8277 9660 -8264 9668 -8256 9675 -8246 9682
--8238 9690 -8226 9696 -8227 9702 -8215 9709 -8217 9715 -8211 9721 -8211 9726
--8206 9732 -8207 9737 -8208 9743 -8207 9747 -8212 9752 -8212 9757 -8214 9762
--8216 9766 -8226 9771 -8225 9775 -8227 9778 -8235 9784 -8242 9787 -8247 9791
--8246 9795 -8263 9799 -8267 9803 -8271 9806 -8281 9810 -8287 9814 -8290 9818
--8296 9821
-189: 13855010 -4793377 -10090 9872 -10110 9872 -10120 9879 -10130 9884
--10140 9888 -10150 9892 -10160 9895 -10180 9901 -10190 9907 -10210 9912
--10220 9919 -10240 9924 -10260 9928 -10270 9933 -10280 9940 -10310 9946
--10320 9949 -10340 9954 -10360 9961 -10360 9963 -10390 9971 -10400 9972
--10410 9975 -10430 9981 -10430 9983 -10450 9989 -10460 9993 -10470 9995
--10480 9997 -10500 9999 -10500 10005 -10510 10007 -10530 10012 -10540 10014
--10540 10019 -10550 10022 -10560 10026 -10580 10029 -10590 10034 -10620 10043
--10620 10049 -10650 10054 -10670 10059 -10690 10066 -10700 10074 -10740 10081
--10750 10091 -10790 10097 -10810 10109 -10840 10116 -10870 10124 -10910 10130
--10930 10139 -10970 10149 -11000 10155 -11030 10164 -11050 10170 -11100 10177
--11130 10184 -11150 10190 -11180 10194 -11210 10198 -11230 10203 -11260 10205
--11270 10207 -11310 10210 -11320 10209 -11330 10212 -11350 10212 -11360 10211
--11370 10211 -11380 10212 -11380 10211 -11400 10211 -11400 10208 -11400 10209
--11410 10206 -11400 10207 -11410 10208 -11420 10211 -11420 10212 -11430 10214
--11430 10219 -11420 10221 -11440 10224 -11460 10233 -11460 10240 -11480 10247
--11500 10256 -11500 10266 -11540 10277 -11550 10285 -11580 10299 -11610 10312
--11640 10326 -11680 10340 -11710 10350 -11750 10362 -11780 10378 -11830 10391
--11870 10404 -11910 10416 -11950 10426 -12000 10436 -12030 10442 -12070 10451
--12120 10456 -12150 10461 -12190 10464 -12220 10467 -12240 10465 -12270 10461
--12290 10457 -12320 10449 -12330 10443 -12340 10431 -12340 10418 -12350 10403
--12340 10387 -12330 10370 -12330 10354 -12310 10335 -12290 10314 -12260 10290
--12230 10265 -12200 10243 -12160 10222 -12140 10203 -12100 10181 -12050 10158
--12010 10134 -11960 10117 -11920 10101 -11880 10089 -11840 10075 -11790 10064
--11760 10054 -11710 10049 -11700 10047 -11670 10051 -11640 10056 -11610 10064
--11600 10075 -11580 10093 -11600 10113 -11600 10136 -11600 10165 -11620 10195
--11650 10235 -11680 10271 -11710 10314 -11760 10358 -11810 10411 -11870 10466
--11940 10524 -12010 10586 -12080 10644 -12160 10705 -12250 10771 -12360 10841
--12450 10915 -12560 10986 -12650 11053 -12760 11119 -12880 11193 -12990 11264
--13090 11334 -13210 11403 -13320 11464 -13420 11524 -13530 11585 -13630 11646
--13730 11700 -13830 11751 -13910 11793 -13970 11828 -14040 11864 -14110 11896
--14170 11922 -14210 11940 -14240 11949 -14250 11950 -14250 11945 -14250 11936
--14240 11919 -14190 11894 -14150 11860 -14060 11819 -13990 11767 -13880 11709
--13760 11642 -13630 11568 -13470 11490 -13290 11405 -13080 11308 -12870 11200
--12630 11084 -12370 10971 -12070 10861 -11750 10748 -11400 10620 -11060 10482
--10660 10341 -10230 10212 -9790 10105 -9310 10001 -8770 9885 -8230 9766
--7640 9657 -7050 9568 -6460 9494 -5840 9442 -5100 9419 -4270 9417 -3460 9435
--2720 9453 -2040 9451 -1360 9476 -780 9535 -250 9595 230 9632 770 9697
-1390 9790 1850 9835 2040 9788 2170 9714 2340 9673 2580 9663 2840 9684 3160 9725
-3600 9770 4130 9812 4640 9865 5070 9946 5520 10086 5570 10273 6230 10350
-6930 10411 7230 10692 7140 11139 7120 11483 7660 11695 9010 11943 10880 12500
-11920 13603 9000 15356 -1510 16947 1060 9050 1160 13858 5000 13744 5280 11362
-6200 10003 6090 9314 6250 8413 6810 7690 6860 7419 6250 7540 5440 7900
-4790 7541 4390 6928 3410 6713 1450 7125 -430 8413 -590 9120 290 8974 440 8508
--810 8246 -1720 9094 -810 11222 -1590 13578 -4920 11947 -3110 12324 -760 7173
-1040 10267 -460 11834 -2760 12235 -4680 12343 -5810 12085 -6170 11562
--6760 11440 -8190 11817 -10430 11855 -13530 11147 -17630 9450 -23110 7282
--27920 6159 -22460 7516 -3850 13466 290 13607 -170 12347 -810 12020 -1230 11757
--2160 11531 -3650 11587 -6170 12406 -7860 12488 -8520 11684 -8040 10634
--7590 10358 -7610 10792 -8190 11322 -9690 11640 -14170 11181 -17500 10862
--10650 10931 -16970 12870 -19330 12561 -18870 11446 -16160 10359 -14460 11149
--11730 10850 -9000 9993 -7310 8967 -5590 8097 -6190 7601 -8110 7355 -10900 7170
--12170 6724 -14690 6146 -15570 5126 -16540 4620 -18860 5192 -20600 5944
--22250 6966 -22440 7315 -22350 7284 -20120 6162 -21130 6902 -23260 7731
--25340 9633 -25350 10860 -23440 9809 -23750 7895 -24710 9181 -22270 9740
--20080 9720 -16720 9865 -14310 10233 -14610 10498 -16600 10506 -14080 10637
--17980 9640 -19670 7629 -9860 8662 -6610 7039 370 4579 8360 3392 13960 3620
-18050 3577 21550 2429 24020 825 23800 107 18020 1416 2700 5519 -24660 12689
--36220 15299 -31020 11721 -26220 11552 -19740 11982 -18900 11189 -25510 10757
--25050 11680 -25230 11527 -25860 10250 -24690 10335 -22400 11103 -20490 11806
--18460 12132 -16690 12064 -16350 11859 -18400 11947 -25980 13170 -26010 12860
--22460 11817 -17490 10577 -12430 9761 -11480 10369 -22810 11620 -26870 12110
--32360 12570 -38390 13463 -26230 12724 -21460 10045 -7460 2604 -17650 3494
--24790 11492 -18760 8078 -16183 4591 -6706 1110 -5447 1433 -7706 4739
--10741 6625 -12801 7240 -12370 7436 -8894 9716 -4337 16858 -6039 22162
--12613 24852 -19467 26151 -23656 27510 -23009 28769 -20809 23739 -15436 -25488
--9152 -4193 -5263 18483 -4196 28211 -5772 21090 -7570 10171 -186 13897
--15483 -4450 -13688 -5339 -3952 933 -10890 -390 -7647 1900 -22349 -3688
--21580 -972 -15939 1378 -32906 -3504 -17563 -1221 -10657 -1587 -14931 -2214
--29099 -3900 -64338 -19213 74875 23366 965210 162850 2200 -1995 -98370 -26297
--104430 -24118 -103110 -17870 -99440 -11770 -92750 -6608 -83497 -2505
--72756 609 -61572 2880 -50792 4483 -40998 5586 -32521 6335 -25509 6844
--19911 7198 -15617 7451 -12466 7642 -10252 7796 -8769 7924 -7857 8036
--7344 8137 -7135 8229 -7105 8314 -7190 8392 -7342 8466 -7526 8534 -7710 8597
--7894 8656 -8056 8711 -8197 8764 -8317 8810 -8418 8857 -8503 8898 -8570 8939
--8631 8977 -8673 9012 -8713 9046 -8732 9079 -8748 9108 -8763 9138 -8762 9167
--8765 9193 -8759 9219 -8755 9241 -8737 9264 -8720 9286 -8708 9308 -8808 9333
--8789 9353 -8718 9371 -8669 9388 -8632 9407 -8603 9423 -8581 9440 -8557 9455
--8539 9471 -8514 9486 -8495 9500 -8478 9514 -8456 9527 -8432 9539 -8415 9552
--8395 9564 -8380 9575 -8359 9586 -8349 9596 -8330 9607 -8312 9616 -8300 9626
--8288 9634 -8273 9644 -8263 9652 -8258 9659 -8253 9668 -8238 9675 -8232 9682
--8227 9689 -8225 9696 -8215 9702 -8217 9709 -8211 9715 -8215 9720 -8209 9726
--8207 9732 -8213 9737 -8212 9742 -8215 9747 -8220 9752 -8221 9757 -8222 9762
--8229 9766 -8231 9770 -8235 9774 -8243 9779 -8244 9783 -8254 9787 -8251 9791
--8270 9795 -8274 9799 -8279 9803 -8282 9806 -8294 9810 -8297 9814 -8303 9818
-190: 13887670 -4784772 -10100 9873 -10120 9878 -10140 9880 -10140 9886
--10140 9890 -10160 9892 -10180 9897 -10180 9903 -10200 9909 -10210 9913
--10230 9921 -10250 9924 -10270 9929 -10270 9935 -10300 9940 -10310 9946
--10330 9951 -10340 9955 -10360 9960 -10380 9964 -10390 9970 -10410 9973
--10420 9976 -10420 9981 -10440 9983 -10460 9987 -10460 9993 -10470 9994
--10490 9997 -10500 10000 -10510 10004 -10520 10006 -10530 10012 -10530 10015
--10550 10018 -10550 10020 -10570 10026 -10580 10029 -10590 10034 -10620 10042
--10620 10047 -10650 10052 -10670 10058 -10680 10065 -10710 10075 -10730 10082
--10750 10087 -10790 10096 -10800 10107 -10840 10114 -10870 10122 -10890 10127
--10930 10137 -10960 10147 -10990 10151 -11020 10160 -11050 10167 -11080 10172
--11110 10180 -11140 10187 -11170 10191 -11200 10194 -11210 10198 -11250 10201
--11260 10203 -11280 10205 -11300 10205 -11320 10207 -11330 10208 -11350 10209
--11350 10207 -11360 10208 -11370 10206 -11380 10208 -11380 10204 -11390 10204
--11390 10204 -11390 10205 -11390 10204 -11400 10207 -11410 10209 -11410 10213
--11410 10215 -11410 10218 -11430 10222 -11440 10230 -11450 10237 -11450 10245
--11480 10253 -11500 10262 -11510 10273 -11530 10284 -11560 10296 -11590 10307
--11630 10323 -11650 10336 -11690 10345 -11720 10358 -11760 10373 -11810 10386
--11840 10399 -11890 10411 -11910 10420 -11970 10429 -12000 10437 -12050 10444
--12080 10449 -12110 10455 -12150 10458 -12180 10459 -12220 10456 -12230 10454
--12260 10449 -12280 10441 -12290 10434 -12300 10424 -12310 10411 -12300 10397
--12300 10380 -12300 10362 -12290 10345 -12270 10328 -12260 10308 -12240 10283
--12190 10259 -12170 10237 -12130 10216 -12110 10197 -12070 10176 -12020 10151
--11990 10130 -11920 10114 -11910 10094 -11850 10084 -11830 10072 -11770 10059
--11730 10048 -11700 10044 -11670 10042 -11650 10045 -11620 10049 -11600 10057
--11580 10068 -11570 10084 -11570 10104 -11580 10125 -11580 10154 -11600 10183
--11620 10219 -11660 10255 -11680 10296 -11720 10340 -11780 10389 -11830 10444
--11900 10500 -11970 10559 -12040 10613 -12110 10672 -12210 10738 -12290 10804
--12380 10875 -12500 10942 -12590 11007 -12680 11074 -12800 11142 -12900 11210
--13020 11279 -13120 11343 -13220 11403 -13320 11459 -13420 11518 -13520 11575
--13610 11628 -13720 11675 -13780 11716 -13840 11750 -13910 11782 -13970 11812
--14030 11838 -14060 11854 -14090 11862 -14090 11863 -14090 11859 -14080 11849
--14070 11832 -14020 11807 -13950 11775 -13880 11738 -13780 11688 -13680 11631
--13560 11569 -13410 11497 -13240 11427 -13050 11348 -12840 11256 -12620 11156
--12370 11048 -12090 10943 -11780 10844 -11460 10740 -11100 10624 -10740 10498
--10330 10373 -9890 10257 -9440 10159 -8950 10068 -8410 9966 -7860 9865
--7250 9775 -6650 9698 -6060 9638 -5450 9592 -4740 9571 -3950 9570 -3160 9588
--2460 9606 -1780 9609 -1120 9634 -490 9694 90 9764 580 9805 1080 9850 1650 9919
-2120 9970 2410 9957 2580 9909 2810 9876 3090 9873 3390 9905 3770 9954 4240 10009
-4790 10072 5300 10143 5790 10235 6250 10381 6390 10583 7010 10693 7620 10769
-7860 11004 7880 11389 8170 11812 9380 12248 12060 12796 16070 13717 20330 15194
-22500 16845 16760 17154 -28140 14116 12480 18762 3040 13728 -520 10057
-3450 9239 4930 8788 7210 7766 9290 7003 9720 6632 8950 6821 7660 7093 6200 6822
-5240 6527 3890 6416 1960 6558 650 7200 700 7617 960 7531 170 7128 -1330 7097
--1540 8232 380 10474 1240 13152 -2250 13086 -3350 11049 -610 8915 -800 10399
--2560 11828 -3780 11914 -5310 11990 -6480 11723 -6630 11411 -7030 11270
--8280 11472 -10070 11514 -12190 11254 -14770 9906 -19130 7980 -25280 7971
--17050 9306 -12210 12207 -7830 12191 -5200 11499 -2790 12658 -1520 12526
--1590 12091 -2680 11869 -4790 12408 -6220 12258 -7100 11542 -7490 11008
--7800 11184 -8310 11852 -9220 12479 -10970 12658 -14040 11957 -16280 10692
--13790 11865 -18800 12328 -22240 12247 -22590 11291 -18100 9250 -16670 11179
--13320 10588 -9840 9614 -8480 8434 -4310 7294 -4890 6447 -6650 6136 -10650 6254
--9490 5730 -14460 5988 -14730 5002 -15730 4285 -19530 5097 -20540 4952
--23220 5853 -22880 5424 -25280 6549 -21030 4586 -23320 6565 -25140 7493
--27560 10126 -27350 11940 -22080 9790 -18510 6473 -21490 10004 -20500 10342
--19950 11590 -16910 12004 -13500 11863 -11600 12061 -12640 11638 -12460 12553
--12720 12190 -10590 10914 -7220 8350 -3410 6400 1530 4646 6640 4068 10960 4402
-14840 4532 18460 3929 20900 3073 20070 2993 13060 4552 -2130 7822 -18420 10418
--30710 12172 -31040 11000 -27070 11615 -21410 11747 -17760 10478 -28590 10287
--28130 11454 -27120 12393 -26980 10027 -24820 10666 -22600 11651 -20560 12464
--18740 12917 -17520 12978 -17680 12826 -19220 12635 -22640 12827 -23610 12397
--22390 11606 -19680 10505 -16560 9478 -15520 9578 -19620 11182 -22000 12031
--24930 12538 -40200 13421 -32180 12798 -24080 10859 -22150 8619 -29590 9915
--36520 13704 -18310 5933 -19470 5495 -1770 2730 -2890 4460 -7370 7172
--11520 9637 -14272 11605 -14028 11071 -10571 8883 -7134 10489 -9048 14761
--15661 18918 -21052 22112 -23882 24734 -18744 25001 -16382 16282 -12835 -9960
--8562 -1902 -6020 10428 -5978 16255 -7027 13988 -7181 11899 -7509 8635
--14480 -1272 -15402 -4586 -13352 -2969 -18790 -3702 -22776 -3967 -23961 -1245
--24176 969 -29213 -848 -24385 2398 -16142 619 -10808 -919 -5458 -2184
-7924 -2790 51712 -2145 241123 37023 625680 99561 143410 23686 -61270 -11732
--120910 -20308 -130960 -18492 -124830 -13674 -112870 -8629 -98720 -4287
--84024 -870 -69797 1680 -56727 3513 -45195 4801 -35408 5693 -27390 6314
--21054 6750 -16203 7069 -12641 7310 -10135 7502 -8443 7662 -7392 7798
--6799 7919 -6533 8030 -6490 8129 -6575 8223 -6738 8307 -6939 8387 -7151 8461
--7360 8529 -7551 8594 -7719 8653 -7869 8710 -8000 8762 -8112 8811 -8205 8858
--8288 8902 -8352 8943 -8407 8981 -8452 9019 -8486 9054 -8511 9086 -8531 9119
--8550 9150 -8562 9178 -8566 9203 -8565 9229 -8567 9253 -8562 9277 -8665 9304
--8659 9326 -8602 9346 -8560 9366 -8532 9384 -8512 9404 -8495 9420 -8479 9438
--8465 9454 -8450 9469 -8436 9485 -8423 9500 -8405 9513 -8393 9527 -8372 9539
--8358 9552 -8347 9564 -8336 9575 -8320 9586 -8308 9597 -8294 9607 -8279 9616
--8273 9626 -8262 9635 -8256 9644 -8247 9652 -8239 9659 -8233 9668 -8229 9675
--8223 9683 -8219 9689 -8219 9696 -8216 9702 -8212 9709 -8211 9715 -8213 9720
--8213 9726 -8213 9732 -8213 9737 -8221 9742 -8225 9747 -8225 9752 -8227 9757
--8232 9762 -8237 9766 -8246 9770 -8245 9775 -8249 9779 -8259 9783 -8262 9787
--8275 9791 -8279 9795 -8282 9799 -8289 9802 -8296 9807 -8302 9810 -8308 9814
-191: 13920360 -4776176 -10120 9876 -10130 9879 -10140 9884 -10150 9887
--10150 9892 -10170 9896 -10190 9900 -10190 9903 -10200 9908 -10220 9916
--10240 9920 -10260 9927 -10270 9930 -10290 9935 -10300 9939 -10310 9948
--10340 9952 -10350 9957 -10370 9960 -10380 9964 -10400 9971 -10400 9973
--10430 9976 -10430 9981 -10450 9981 -10460 9988 -10470 9990 -10470 9995
--10490 9999 -10510 9998 -10510 10004 -10520 10008 -10530 10011 -10540 10013
--10550 10016 -10560 10022 -10570 10025 -10580 10028 -10600 10035 -10610 10039
--10620 10046 -10650 10052 -10670 10059 -10680 10065 -10700 10072 -10740 10078
--10750 10087 -10780 10096 -10800 10105 -10830 10112 -10860 10117 -10890 10126
--10920 10134 -10960 10145 -10980 10148 -11010 10156 -11030 10163 -11080 10170
--11100 10175 -11120 10183 -11160 10188 -11180 10192 -11200 10194 -11220 10196
--11250 10198 -11270 10201 -11290 10200 -11300 10203 -11310 10205 -11330 10204
--11330 10202 -11350 10204 -11350 10204 -11360 10202 -11370 10201 -11370 10202
--11380 10201 -11370 10202 -11380 10201 -11380 10203 -11400 10207 -11390 10208
--11390 10212 -11400 10216 -11410 10220 -11420 10227 -11430 10233 -11440 10241
--11460 10250 -11490 10260 -11490 10270 -11520 10281 -11540 10292 -11570 10304
--11600 10318 -11630 10333 -11660 10341 -11710 10354 -11740 10368 -11770 10379
--11820 10394 -11860 10406 -11880 10414 -11930 10424 -11980 10430 -12010 10438
--12050 10444 -12080 10449 -12120 10449 -12140 10452 -12180 10450 -12200 10445
--12220 10441 -12240 10433 -12260 10427 -12260 10418 -12270 10405 -12270 10388
--12260 10374 -12260 10355 -12250 10338 -12240 10321 -12230 10302 -12190 10277
--12170 10252 -12130 10231 -12110 10213 -12070 10192 -12040 10169 -12000 10147
--11950 10126 -11910 10108 -11880 10091 -11840 10078 -11800 10068 -11760 10055
--11710 10044 -11670 10038 -11650 10038 -11630 10038 -11610 10042 -11570 10050
--11570 10061 -11550 10077 -11550 10093 -11550 10116 -11560 10142 -11580 10171
--11600 10203 -11620 10239 -11650 10282 -11690 10320 -11750 10368 -11800 10421
--11860 10475 -11920 10530 -12000 10584 -12060 10641 -12150 10703 -12240 10768
--12320 10836 -12430 10900 -12520 10963 -12620 11025 -12720 11091 -12820 11157
--12930 11225 -13030 11284 -13130 11341 -13220 11396 -13310 11452 -13410 11505
--13510 11556 -13590 11601 -13650 11639 -13720 11672 -13780 11704 -13840 11732
--13890 11754 -13930 11771 -13930 11778 -13940 11779 -13940 11774 -13920 11765
--13890 11748 -13850 11725 -13770 11695 -13700 11657 -13590 11612 -13490 11558
--13350 11498 -13210 11432 -13020 11367 -12830 11293 -12610 11209 -12380 11115
--12120 11016 -11830 10918 -11530 10828 -11180 10735 -10820 10628 -10450 10515
--10020 10403 -9580 10299 -9130 10213 -8630 10132 -8080 10043 -7520 9956
--6910 9881 -6300 9819 -5720 9768 -5100 9732 -4410 9718 -3650 9717 -2880 9737
--2200 9757 -1540 9764 -890 9787 -270 9842 340 9914 870 9962 1360 10003
-1920 10060 2400 10112 2750 10117 2980 10094 3250 10080 3590 10088 3930 10133
-4340 10193 4830 10258 5390 10335 5940 10425 6450 10536 6950 10690 7260 10901
-7820 11053 8340 11151 8580 11332 8660 11651 9060 12117 10540 12659 13760 13292
-18650 14240 23890 15677 26350 17267 20710 18133 1560 18004 16750 19549
--6710 16728 -10760 9199 -600 9399 1610 9191 7340 7559 11890 6623 12560 5927
-11470 6219 9760 6688 7150 6434 5810 6316 4410 6362 2670 5951 1700 6076
-1510 6347 780 6430 -1130 6312 -2860 6691 -1800 7903 3600 9102 10000 9424
-1750 12047 -9880 14176 -1610 10389 -2690 11056 -4300 12353 -4310 11629
--5560 11691 -7070 11429 -6980 11522 -7210 11221 -8440 11151 -9770 11163
--11190 11738 -12280 10855 -15240 8492 -26870 9790 -8070 10776 -17670 12118
--14060 10939 -10410 9722 -4810 12889 -1990 12597 -1460 12100 -2190 11829
--3550 12190 -4770 11877 -5930 11366 -6970 11266 -7960 11765 -8880 12533
--9900 13159 -11270 13413 -13050 13101 -14790 10387 -15870 11751 -19040 12002
--25010 12370 -28110 12673 -22660 10620 -17250 8693 -15770 9282 -12070 8991
--12350 7875 -3350 6632 -6030 5578 -7720 5465 -14990 6252 -6010 4899 -15600 6406
--12630 5057 -13130 3798 -19570 5629 -17870 3870 -22990 5682 -19670 3502
--28020 7564 -18290 2583 -21960 6053 -22940 5735 -27430 9844 -29040 13442
--20400 10237 -13090 3616 -20850 12285 -17990 10202 -19500 12881 -15820 13174
--11450 12515 -7660 13376 -9830 12707 -10580 13587 -9430 13928 -5200 13187
--5400 9306 -2880 6894 560 5331 3800 5073 6750 5595 9900 5987 13410 5787
-16330 5343 16700 5432 12030 6545 30 8425 -19060 9749 -30220 10564 -32550 10312
--28650 11326 -24800 10739 -23730 9887 -25690 9674 -27790 10027 -29230 10717
--24690 12559 -23330 12453 -22150 12772 -20630 13282 -19160 13664 -18190 13723
--18890 13629 -19120 12986 -19890 12701 -21360 12059 -22480 11705 -22630 10749
--21350 9031 -18980 8262 -17010 11157 -20230 12076 -24850 12505 -32230 12939
--28600 12711 -23260 11875 -24080 10811 -30900 11003 -34920 11326 -22310 7538
--21680 7382 -10620 6555 -9110 8631 -11770 9755 -14470 11304 -16930 14182
--17210 13141 -13850 6478 -8830 4755 -10270 8454 -18101 12580 -21050 15169
--25221 17020 -14660 16954 -14922 10370 -13113 -2448 -9654 5928 -8088 9635
--9717 10822 -11166 8985 -10870 9031 -13877 5271 -17915 357 -19558 -2633
--19710 -1659 -22417 -686 -26590 2681 -24905 1240 -26403 756 -29118 -209
--24981 -224 -14994 -675 -3071 -1466 15222 -1577 49638 634 118538 8660
-251343 33519 380620 57209 168700 26722 -2480 656 -87540 -11143 -118890 -13498
--123490 -11428 -115740 -7895 -102650 -4310 -87770 -1240 -72916 1174 -59133 2980
--46954 4289 -36615 5224 -28148 5892 -21446 6374 -16317 6733 -12537 7009
--9868 7230 -8060 7414 -6919 7572 -6283 7711 -5987 7836 -5926 7951 -6011 8056
--6184 8153 -6404 8243 -6634 8326 -6864 8404 -7082 8477 -7272 8546 -7446 8608
--7598 8669 -7738 8724 -7851 8777 -7962 8826 -8040 8873 -8110 8917 -8174 8958
--8229 8997 -8270 9035 -8304 9071 -8341 9105 -8364 9136 -8387 9165 -8397 9193
--8409 9219 -8419 9246 -8522 9275 -8525 9299 -8483 9321 -8448 9341 -8433 9363
--8418 9383 -8410 9401 -8403 9419 -8396 9436 -8384 9453 -8375 9470 -8365 9485
--8354 9500 -8346 9513 -8332 9527 -8326 9540 -8312 9552 -8303 9565 -8297 9576
--8281 9586 -8270 9597 -8263 9608 -8258 9617 -8250 9626 -8245 9636 -8237 9644
--8230 9652 -8223 9661 -8222 9668 -8222 9675 -8218 9683 -8215 9690 -8212 9696
--8212 9703 -8208 9709 -8215 9715 -8215 9721 -8217 9726 -8218 9732 -8222 9737
--8228 9742 -8231 9748 -8228 9752 -8239 9757 -8245 9762 -8249 9766 -8251 9770
--8255 9775 -8264 9780 -8271 9783 -8277 9787 -8281 9791 -8290 9796 -8294 9799
--8300 9803 -8309 9806 -8312 9811
-192: 13953080 -4767589 -10130 9878 -10140 9881 -10150 9887 -10150 9888
--10170 9894 -10180 9900 -10190 9901 -10200 9904 -10220 9911 -10230 9917
--10240 9922 -10270 9927 -10270 9932 -10290 9935 -10310 9940 -10320 9949
--10340 9952 -10360 9957 -10370 9961 -10400 9965 -10400 9970 -10410 9973
--10430 9976 -10440 9980 -10450 9983 -10460 9988 -10470 9990 -10480 9994
--10490 9998 -10510 9999 -10510 10004 -10530 10008 -10540 10010 -10530 10012
--10550 10017 -10570 10020 -10570 10025 -10590 10028 -10600 10034 -10610 10039
--10630 10045 -10640 10052 -10660 10057 -10690 10064 -10700 10070 -10730 10078
--10750 10085 -10780 10094 -10800 10101 -10820 10109 -10850 10116 -10890 10125
--10910 10133 -10950 10141 -10970 10146 -11000 10152 -11030 10160 -11060 10164
--11090 10173 -11110 10179 -11140 10183 -11170 10189 -11190 10189 -11210 10192
--11230 10195 -11250 10196 -11280 10198 -11280 10198 -11300 10199 -11310 10199
--11320 10201 -11330 10200 -11330 10198 -11350 10199 -11350 10198 -11360 10198
--11350 10197 -11360 10198 -11370 10199 -11360 10201 -11380 10202 -11370 10205
--11380 10210 -11380 10213 -11390 10217 -11410 10223 -11420 10230 -11420 10238
--11450 10247 -11460 10257 -11480 10268 -11500 10277 -11520 10288 -11550 10301
--11580 10315 -11610 10327 -11640 10339 -11680 10348 -11710 10363 -11760 10376
--11790 10388 -11820 10400 -11860 10409 -11900 10416 -11950 10424 -11980 10433
--12010 10438 -12050 10442 -12080 10443 -12110 10444 -12140 10443 -12160 10438
--12190 10433 -12210 10427 -12210 10421 -12230 10410 -12230 10397 -12230 10382
--12230 10367 -12220 10350 -12220 10332 -12200 10314 -12190 10295 -12160 10271
--12140 10246 -12100 10227 -12080 10208 -12050 10188 -12010 10165 -11960 10143
--11930 10121 -11890 10103 -11850 10088 -11820 10074 -11780 10062 -11730 10051
--11690 10041 -11650 10034 -11630 10032 -11610 10032 -11590 10036 -11560 10044
--11540 10054 -11540 10069 -11530 10084 -11530 10105 -11530 10131 -11550 10157
--11570 10190 -11600 10225 -11620 10263 -11670 10302 -11710 10347 -11760 10397
--11820 10450 -11880 10503 -11950 10556 -12010 10610 -12100 10669 -12180 10731
--12270 10797 -12360 10858 -12460 10918 -12540 10978 -12640 11041 -12740 11106
--12840 11168 -12950 11227 -13040 11280 -13120 11333 -13210 11386 -13300 11438
--13390 11485 -13480 11529 -13540 11564 -13590 11598 -13650 11626 -13710 11654
--13760 11673 -13780 11689 -13790 11696 -13800 11695 -13780 11693 -13760 11683
--13740 11667 -13680 11645 -13610 11617 -13510 11583 -13420 11539 -13290 11488
--13170 11432 -13010 11370 -12820 11310 -12620 11242 -12390 11164 -12150 11077
--11890 10985 -11600 10897 -11280 10815 -10930 10729 -10560 10633 -10170 10532
--9760 10433 -9290 10340 -8840 10263 -8340 10193 -7800 10116 -7220 10042
--6610 9978 -6000 9928 -5420 9887 -4800 9861 -4120 9854 -3380 9857 -2630 9878
--1950 9901 -1310 9915 -690 9938 -60 9986 540 10056 1110 10107 1620 10153
-2160 10207 2660 10259 3050 10276 3360 10274 3670 10276 4050 10302 4440 10360
-4880 10433 5400 10510 5960 10602 6540 10709 7070 10837 7620 11004 8080 11230
-8640 11424 9110 11552 9370 11689 9460 11949 9780 12417 11060 12970 14080 13551
-18900 14357 24220 15617 27460 17186 25710 18626 19630 19698 22480 20448
-10220 17972 -16290 7808 -11250 11113 -5440 10230 6710 7490 14750 6755
-14660 5333 13160 5826 11890 6913 7210 6257 6280 6272 5320 6971 3620 5550
-2560 5228 1760 5474 -300 5900 -3660 6312 -6470 7366 -6020 8991 360 9785
-11690 8032 15560 6925 -11440 14519 -3110 11888 -3140 11538 -1260 11829
--5260 12606 -5000 11892 -5630 11268 -6990 12133 -7040 11350 -8640 11161
--9980 11633 -12110 11881 -15280 11376 -22470 8388 -27960 10576 4100 13154
--14390 11834 -14040 11084 -14600 10685 -4680 10418 -2290 11181 -1830 11448
--2270 11514 -2760 11792 -3750 11493 -5110 11220 -6640 11384 -8060 11966
--9180 12613 -10030 12930 -10900 12771 -12270 12071 -13920 11083 -9320 12621
--18770 11269 -25930 11362 -29070 11663 -26530 10790 -23280 9699 -22940 9726
--22930 9247 -15320 6993 -4210 5868 -10190 5896 -17520 6605 -23170 7467
--7500 5768 -12100 5702 -6880 5151 -12100 4506 -15180 6071 -13560 3978
--18590 5724 -14090 3283 -22030 7428 -24090 7594 -9030 968 -14320 3313
--21610 7971 -24940 11301 -21460 10427 -18390 8554 -21700 13094 -14990 9599
--15900 12351 -10990 11163 -8710 11549 -6570 12279 -9570 13776 -9830 14146
--7580 14483 -5090 14820 -5060 11328 -3980 8697 -1420 6826 440 6621 1860 7222
-3730 7731 6870 7636 10410 7290 12670 7341 11670 7943 4140 8944 -21560 9686
--30750 10224 -33130 10405 -30880 10678 -26910 9591 -25520 9672 -25150 8830
--26130 9457 -27690 11389 -24260 12915 -22720 12914 -22190 13205 -20890 13609
--19430 13968 -17960 13899 -20210 14232 -18630 12848 -16660 12708 -18830 11722
--22050 12444 -25420 11753 -26260 8683 -22960 5616 -13550 12386 -20210 12276
--25480 12278 -27290 12341 -24660 12285 -21660 12178 -27690 10968 -29390 10280
--30430 9948 -25440 8375 -22290 8770 -16950 9057 -16060 12265 -17160 10655
--16520 8994 -15420 9185 -17790 9607 -21280 6556 -11860 6428 -11380 7938
--20170 9094 -15090 9031 -19120 9302 -18242 11986 -19426 9829 -16162 4327
--12267 8548 -10308 8448 -14230 7769 -15807 4931 -14539 7711 -19742 3606
--21420 3185 -19294 3773 -25943 2276 -27031 274 -29151 2412 -28687 2064
--28952 1224 -28377 125 -22784 -783 -11231 -1487 5796 -1867 31572 -992
-71930 2618 132802 10921 209443 25215 247220 34559 145400 22135 28450 6477
--50820 -3492 -91580 -7393 -106090 -7395 -105340 -5524 -96560 -3072 -84185 -710
--70758 1289 -57777 2864 -46054 4056 -35964 4940 -27623 5593 -20980 6081
--15867 6453 -12079 6747 -9394 6986 -7572 7187 -6418 7361 -5773 7514 -5469 7653
--5410 7779 -5499 7896 -5684 8004 -5913 8102 -6152 8196 -6409 8282 -6644 8363
--6860 8438 -7050 8510 -7221 8575 -7380 8638 -7518 8696 -7644 8752 -7743 8803
--7829 8852 -7909 8898 -7975 8941 -8038 8983 -8083 9022 -8138 9060 -8175 9094
--8208 9127 -8234 9155 -8254 9185 -8274 9215 -8382 9245 -8394 9272 -8365 9295
--8341 9318 -8332 9340 -8328 9361 -8323 9381 -8326 9401 -8323 9419 -8319 9436
--8313 9454 -8309 9470 -8304 9486 -8296 9500 -8292 9514 -8287 9528 -8277 9541
--8272 9554 -8270 9565 -8257 9577 -8247 9587 -8245 9598 -8242 9609 -8235 9618
--8232 9627 -8225 9637 -8219 9644 -8217 9654 -8216 9661 -8215 9669 -8215 9676
--8213 9683 -8210 9690 -8213 9697 -8206 9704 -8216 9709 -8213 9716 -8220 9721
--8224 9727 -8227 9732 -8232 9738 -8233 9743 -8231 9748 -8242 9752 -8245 9758
--8253 9762 -8256 9766 -8266 9771 -8266 9776 -8275 9779 -8283 9784 -8286 9788
--8296 9791 -8299 9796 -8305 9799 -8312 9804 -8317 9807
-193: 13985830 -4759011 -10150 9882 -10150 9882 -10150 9887 -10160 9890
--10180 9897 -10180 9901 -10200 9904 -10210 9908 -10220 9912 -10250 9919
--10250 9921 -10270 9928 -10280 9934 -10300 9936 -10310 9943 -10330 9948
--10340 9950 -10370 9958 -10380 9963 -10390 9967 -10410 9971 -10410 9973
--10440 9976 -10450 9978 -10450 9984 -10460 9988 -10480 9988 -10490 9994
--10490 9997 -10510 10000 -10520 10005 -10530 10007 -10530 10009 -10540 10011
--10550 10017 -10570 10020 -10570 10023 -10590 10028 -10610 10033 -10610 10040
--10630 10044 -10640 10050 -10660 10056 -10690 10063 -10700 10069 -10730 10077
--10750 10084 -10770 10091 -10800 10099 -10820 10106 -10840 10115 -10880 10123
--10910 10131 -10930 10137 -10960 10144 -10990 10151 -11020 10156 -11060 10160
--11070 10169 -11100 10174 -11130 10180 -11150 10184 -11170 10186 -11200 10188
--11230 10191 -11230 10192 -11260 10194 -11270 10194 -11290 10195 -11290 10195
--11300 10196 -11310 10195 -11320 10195 -11330 10196 -11340 10195 -11340 10194
--11330 10193 -11350 10194 -11350 10195 -11350 10198 -11360 10199 -11360 10203
--11360 10206 -11370 10210 -11380 10215 -11380 10220 -11400 10226 -11420 10235
--11420 10244 -11440 10254 -11460 10263 -11480 10273 -11510 10286 -11530 10298
--11560 10310 -11590 10324 -11620 10333 -11650 10344 -11690 10358 -11730 10371
--11760 10384 -11800 10394 -11830 10402 -11870 10410 -11910 10419 -11950 10427
--11980 10432 -12020 10435 -12050 10437 -12070 10437 -12100 10436 -12130 10432
--12150 10426 -12170 10421 -12180 10413 -12190 10404 -12190 10391 -12200 10377
--12190 10360 -12190 10342 -12180 10327 -12170 10308 -12150 10289 -12120 10266
--12110 10242 -12080 10222 -12040 10204 -12020 10183 -11990 10160 -11940 10139
--11900 10118 -11860 10098 -11820 10085 -11790 10071 -11760 10058 -11720 10047
--11670 10037 -11630 10029 -11610 10029 -11590 10028 -11570 10030 -11540 10037
--11520 10046 -11510 10061 -11510 10075 -11510 10096 -11510 10118 -11530 10145
--11540 10177 -11570 10210 -11600 10244 -11630 10284 -11680 10327 -11720 10374
--11770 10424 -11840 10477 -11900 10527 -11970 10579 -12040 10636 -12130 10695
--12210 10757 -12300 10817 -12390 10874 -12460 10931 -12570 10992 -12660 11053
--12760 11113 -12860 11171 -12940 11221 -13020 11271 -13120 11321 -13200 11372
--13290 11416 -13360 11457 -13420 11492 -13470 11522 -13530 11550 -13580 11577
--13630 11596 -13640 11610 -13660 11615 -13640 11617 -13630 11614 -13620 11604
--13580 11589 -13520 11568 -13450 11542 -13350 11509 -13240 11470 -13110 11421
--12980 11369 -12820 11312 -12630 11255 -12420 11194 -12200 11122 -11940 11041
--11670 10959 -11380 10877 -11050 10803 -10700 10726 -10320 10639 -9940 10550
--9490 10460 -9040 10379 -8580 10311 -8080 10250 -7540 10185 -6960 10123
--6350 10069 -5750 10029 -5160 9995 -4540 9978 -3870 9978 -3150 9987 -2420 10008
--1740 10036 -1100 10056 -490 10081 120 10127 730 10191 1300 10247 1840 10296
-2380 10355 2910 10409 3330 10437 3690 10450 4060 10470 4480 10512 4920 10583
-5390 10671 5930 10764 6520 10868 7090 10992 7670 11137 8250 11315 8830 11547
-9390 11786 9900 11953 10210 12064 10310 12286 10420 12733 11250 13251
-13630 13732 17830 14336 22870 15313 26840 16673 27840 18180 25910 19406
-23390 19605 12230 17200 -6010 11694 -8610 11368 -2500 7472 7100 7683 17190 7649
-14490 5054 12910 5618 14290 8064 6240 6506 7540 6273 7190 8868 5040 5691
-3350 5019 1960 5225 -1480 6160 -6350 7080 -10890 8828 -13670 11233 -10890 13136
-1430 10296 9850 7235 -750 9830 570 10070 3510 10865 5570 11468 2820 12023
-550 11721 -1910 11360 -4440 11682 -6280 11450 -8470 11277 -10540 11185
--12930 10731 -16060 9650 -20200 7837 -19990 8822 -3310 12955 -9370 13637
--13060 12621 -13610 11711 -8040 10948 -4960 11039 -3520 11222 -3080 11330
--2710 11459 -3360 11223 -4800 11093 -6560 11331 -8150 11814 -9150 12211
--9390 12263 -8960 11926 -8220 11208 -7770 11521 -6550 11472 -19470 10547
--26200 10338 -29120 10736 -28340 10765 -26410 10332 -25420 9668 -24100 8400
--18950 6721 -14340 6177 -19200 6713 -26850 7671 -32300 8459 -27080 7883
--9280 4956 100 4939 -6780 3738 -4260 5459 -4660 3899 -7930 4219 -6400 4211
--9580 7027 -14600 6672 -9790 3268 -12410 4313 -18440 7549 -22590 10128
--22190 10500 -20360 10191 -19420 11514 -14640 10247 -12830 11520 -10350 12123
--9630 12016 -7810 12563 -8440 13289 -8930 13510 -6260 13565 -5620 15106
--8770 13803 -7040 11787 -4070 8846 -3090 8647 -3330 9193 -3350 9658 -920 9385
-2780 8902 5800 8930 6300 9008 800 9439 -16190 9895 -26800 10315 -31640 10603
--32280 10664 -29240 8769 -24780 9693 -24970 8097 -27230 9835 -23170 11813
--21960 12924 -21570 12242 -22620 12756 -21060 13092 -19740 13615 -15530 12912
--22130 14701 -18250 11818 -12160 12855 -16240 11242 -18970 14486 -26420 13655
--29460 9170 -28930 1104 -8260 15965 -22930 12190 -28430 12031 -26530 11762
--25190 11319 -24100 11629 -28190 11058 -24940 9991 -32490 10945 -32850 5085
--25070 9677 -21510 10673 -20400 11936 -20160 10683 -19130 8954 -18250 8225
--19440 8006 -20420 6767 -15380 6566 -13800 6913 -15950 6985 -12670 6673
--13020 7088 -18150 9245 -22330 8271 -14580 8527 -19010 7714 -12152 5990
--18322 6007 -12464 7192 -21385 6607 -24523 4311 -26555 3501 -25135 4171
--27541 3298 -30201 1985 -31799 2524 -31734 2380 -30832 1635 -27933 490
--20712 -728 -7845 -1692 11323 -1979 38505 -814 75410 2731 120568 9212
-162477 17502 170550 21908 114770 16800 38630 8208 -24210 1304 -63890 -2378
--83130 -3357 -87980 -2689 -83970 -1269 -75176 330 -64349 1811 -53199 3054
--42769 4046 -33584 4815 -25873 5407 -19673 5868 -14856 6231 -11267 6526
--8708 6773 -6966 6982 -5875 7168 -5252 7331 -4973 7481 -4926 7617 -5033 7744
--5232 7860 -5464 7968 -5725 8069 -5991 8164 -6239 8252 -6479 8335 -6682 8412
--6878 8485 -7047 8553 -7206 8617 -7337 8677 -7460 8734 -7561 8788 -7656 8838
--7738 8885 -7813 8931 -7869 8974 -7942 9014 -7987 9053 -8030 9087 -8076 9119
--8109 9151 -8134 9182 -8246 9217 -8263 9244 -8248 9269 -8234 9293 -8235 9318
--8238 9340 -8239 9361 -8244 9381 -8250 9401 -8251 9420 -8253 9438 -8257 9456
--8253 9471 -8251 9487 -8247 9501 -8246 9516 -8242 9529 -8243 9543 -8236 9555
--8231 9567 -8226 9578 -8226 9589 -8224 9599 -8222 9610 -8219 9620 -8217 9628
--8208 9637 -8203 9646 -8211 9655 -8210 9662 -8211 9670 -8209 9677 -8208 9684
--8211 9691 -8211 9698 -8213 9704 -8215 9710 -8220 9716 -8225 9722 -8230 9728
--8233 9733 -8236 9739 -8241 9743 -8242 9748 -8247 9754 -8253 9758 -8261 9763
--8270 9767 -8268 9771 -8283 9776 -8289 9780 -8294 9784 -8299 9789 -8301 9792
--8312 9796 -8316 9800 -8321 9803
-194: 14018610 -4750443 -10160 9886 -10160 9884 -10160 9890 -10180 9893
--10180 9898 -10190 9903 -10200 9906 -10220 9911 -10230 9913 -10260 9918
--10260 9923 -10270 9930 -10290 9933 -10300 9938 -10320 9945 -10330 9949
--10350 9951 -10370 9958 -10390 9962 -10400 9966 -10400 9972 -10420 9972
--10440 9978 -10450 9979 -10460 9983 -10470 9986 -10490 9989 -10490 9994
--10490 9997 -10510 9999 -10520 10005 -10530 10006 -10540 10008 -10540 10013
--10560 10017 -10560 10018 -10580 10023 -10590 10026 -10600 10033 -10620 10038
--10630 10044 -10640 10050 -10670 10056 -10680 10062 -10700 10068 -10730 10076
--10740 10082 -10770 10089 -10800 10096 -10810 10104 -10840 10113 -10870 10121
--10900 10128 -10920 10135 -10960 10141 -10980 10147 -11010 10154 -11040 10158
--11060 10164 -11100 10170 -11110 10177 -11140 10179 -11160 10182 -11180 10185
--11210 10186 -11220 10187 -11240 10191 -11260 10191 -11270 10192 -11280 10192
--11290 10190 -11290 10190 -11300 10192 -11310 10193 -11330 10191 -11320 10190
--11320 10191 -11340 10189 -11330 10190 -11340 10195 -11340 10196 -11340 10199
--11350 10203 -11350 10207 -11360 10211 -11380 10217 -11380 10224 -11400 10234
--11400 10240 -11420 10250 -11440 10259 -11470 10269 -11490 10282 -11510 10294
--11540 10307 -11560 10319 -11600 10329 -11630 10340 -11660 10353 -11700 10365
--11740 10379 -11770 10388 -11800 10397 -11840 10405 -11880 10413 -11920 10419
--11960 10426 -11980 10430 -12010 10432 -12040 10430 -12070 10429 -12090 10425
--12110 10421 -12140 10414 -12140 10406 -12150 10396 -12160 10385 -12160 10371
--12160 10354 -12150 10336 -12140 10321 -12130 10304 -12120 10283 -12090 10262
--12080 10238 -12040 10217 -12020 10198 -11990 10179 -11960 10159 -11920 10137
--11870 10114 -11830 10094 -11800 10081 -11770 10068 -11730 10056 -11690 10043
--11650 10032 -11620 10028 -11590 10023 -11570 10023 -11540 10026 -11520 10030
--11500 10039 -11500 10052 -11480 10067 -11490 10086 -11490 10107 -11500 10133
--11520 10164 -11540 10194 -11570 10227 -11590 10266 -11640 10307 -11690 10352
--11740 10400 -11790 10450 -11860 10497 -11910 10548 -11990 10603 -12070 10661
--12160 10718 -12240 10775 -12310 10831 -12400 10886 -12490 10943 -12580 11000
--12680 11059 -12770 11116 -12850 11162 -12920 11210 -13020 11260 -13110 11304
--13180 11349 -13260 11387 -13300 11420 -13350 11450 -13410 11477 -13460 11501
--13490 11519 -13520 11531 -13510 11538 -13510 11540 -13490 11537 -13470 11529
--13430 11514 -13370 11493 -13290 11469 -13190 11439 -13070 11404 -12950 11357
--12800 11308 -12650 11257 -12440 11205 -12230 11148 -12000 11082 -11750 11010
--11480 10932 -11170 10860 -10830 10793 -10490 10724 -10110 10646 -9710 10567
--9270 10486 -8820 10416 -8350 10358 -7850 10304 -7300 10250 -6730 10197
--6130 10154 -5520 10121 -4950 10097 -4330 10086 -3660 10090 -2950 10104
--2250 10129 -1570 10157 -930 10185 -320 10216 280 10261 890 10322 1470 10379
-2030 10433 2590 10499 3140 10558 3590 10597 3990 10623 4420 10660 4880 10718
-5350 10802 5860 10904 6430 11011 7030 11130 7630 11268 8240 11429 8820 11613
-9470 11836 10070 12116 10630 12322 11080 12433 11220 12637 11150 13058
-11460 13540 13040 13935 16330 14348 20780 14996 24910 15977 27170 17194
-26690 18209 23270 18230 14730 16406 3830 12952 620 10357 4910 6239 13820 3486
-8810 5855 11340 8504 10680 5367 13230 8112 8890 9809 11560 6146 9670 10236
-7560 8246 4460 6070 3020 5938 -1620 7443 -7280 8200 -12380 10006 -18890 12505
--22420 17006 -6750 11903 3420 8160 1000 7677 1810 8465 10200 10328 14580 11113
-12050 11483 7290 11381 2510 11182 -1530 11330 -4900 11312 -8000 11007
--10520 10455 -12410 9585 -13920 8426 -14630 7412 -12200 8164 -6850 12563
--10790 13329 -14460 13226 -14470 12537 -11040 11764 -7910 11429 -5670 11349
--4290 11332 -3310 11282 -3650 11056 -4960 10963 -6730 11135 -8240 11395
--8990 11495 -8640 11434 -7100 11495 -4600 11766 -4090 10057 -5520 10326
--16490 9020 -24080 9348 -27540 10108 -27850 10545 -26650 10169 -25380 8926
--24020 7333 -21890 6315 -21340 6490 -25520 7346 -31580 8123 -36130 8423
--34750 7517 -25210 5039 -7580 3152 -1210 4627 7800 6650 6620 4025 2680 3614
-4010 4552 5350 7986 -7810 6488 -11030 5541 -12160 5974 -17210 8125 -21880 10023
--22490 10634 -20390 10483 -17750 10567 -13650 10073 -11090 11077 -10630 14032
--12630 12640 -8650 13207 -6000 12978 -4550 13242 -5240 14061 -8640 13165
--15860 14778 -10970 14177 -7630 10729 -6510 11054 -8200 11323 -10710 11767
--8680 11107 -5110 10235 -2600 10463 -600 9671 -390 9963 -12200 10160 -22440 10392
--28380 10380 -30670 9990 -32150 8569 -24390 9761 -25350 8436 -25290 11968
--21550 11258 -21110 12748 -20280 10593 -23450 11700 -20090 11445 -21280 12703
--11030 10177 -20660 13623 -19020 10864 -8130 11092 -19270 12670 -5740 20048
--24930 12553 -21960 9010 -29310 6898 -23050 12997 -23990 12668 -29550 12497
--29310 12281 -31030 10214 -28580 10340 -32210 10300 -30710 9720 -33880 9412
--33920 6881 -29160 8974 -25820 10242 -24060 10928 -22980 10270 -21830 9105
--20950 8270 -20850 7726 -20240 6985 -17270 6589 -15280 6399 -14620 6151
--12900 5961 -13450 6390 -17210 7582 -19930 7740 -17410 8084 -18850 7200
--16340 5984 -18360 5940 -17192 6622 -22659 6068 -26089 4765 -27931 4048
--27748 4046 -28148 3485 -31826 2730 -33592 2739 -33628 2589 -31995 1968
--27835 892 -19695 -397 -6502 -1494 12359 -1876 37277 -914 67520 1893 99147 6481
-122437 11563 121820 14240 88170 12378 38700 8013 -7630 3781 -41300 1009
--60860 -163 -68760 -152 -68480 535 -63149 1503 -55231 2502 -46387 3407
--37719 4174 -29866 4801 -23147 5308 -17660 5720 -13364 6060 -10138 6344
--7827 6589 -6261 6802 -5274 6992 -4729 7164 -4499 7321 -4481 7465 -4611 7600
--4820 7724 -5064 7841 -5339 7948 -5616 8050 -5879 8145 -6124 8235 -6348 8318
--6550 8396 -6738 8470 -6911 8540 -7058 8605 -7190 8667 -7307 8724 -7414 8779
--7507 8830 -7601 8879 -7674 8926 -7744 8970 -7811 9011 -7865 9048 -7919 9083
--7965 9116 -7998 9151 -8121 9187 -8141 9216 -8131 9243 -8127 9269 -8136 9294
--8147 9319 -8158 9341 -8169 9362 -8178 9384 -8185 9403 -8194 9422 -8200 9440
--8204 9458 -8202 9473 -8203 9488 -8204 9504 -8209 9518 -8211 9532 -8209 9545
--8205 9556 -8202 9569 -8207 9580 -8205 9591 -8206 9601 -8205 9612 -8203 9620
--8198 9630 -8198 9639 -8203 9648 -8204 9655 -8205 9664 -8206 9671 -8204 9678
--8207 9686 -8214 9692 -8211 9699 -8217 9705 -8220 9711 -8229 9717 -8229 9723
--8236 9729 -8236 9734 -8243 9739 -8247 9744 -8252 9750 -8258 9754 -8260 9759
--8273 9763 -8278 9768 -8287 9772 -8292 9777 -8296 9781 -8306 9784 -8306 9789
--8314 9793 -8321 9797 -8327 9800
-195: 14051410 -4741882 -10160 9888 -10170 9889 -10180 9891 -10180 9896
--10190 9898 -10190 9903 -10220 9910 -10230 9913 -10240 9914 -10250 9920
--10270 9924 -10280 9930 -10290 9935 -10310 9939 -10330 9944 -10330 9950
--10360 9952 -10380 9958 -10380 9963 -10400 9965 -10410 9970 -10430 9973
--10440 9980 -10450 9977 -10470 9984 -10470 9987 -10490 9991 -10500 9994
--10500 9996 -10510 10000 -10520 10003 -10530 10006 -10540 10009 -10540 10012
--10560 10015 -10570 10018 -10580 10023 -10590 10026 -10610 10031 -10620 10039
--10620 10043 -10650 10049 -10660 10055 -10680 10061 -10700 10066 -10730 10073
--10740 10080 -10770 10090 -10790 10094 -10800 10102 -10830 10110 -10870 10118
--10900 10125 -10910 10132 -10950 10139 -10970 10144 -11000 10152 -11020 10156
--11060 10161 -11080 10165 -11100 10173 -11130 10174 -11150 10180 -11170 10180
--11190 10181 -11210 10185 -11220 10186 -11240 10188 -11260 10187 -11260 10187
--11270 10187 -11280 10187 -11290 10188 -11300 10188 -11310 10187 -11300 10187
--11320 10187 -11310 10186 -11310 10186 -11330 10191 -11330 10194 -11330 10195
--11330 10199 -11340 10203 -11340 10209 -11360 10213 -11370 10222 -11370 10230
--11380 10237 -11410 10247 -11430 10255 -11440 10267 -11470 10276 -11490 10290
--11520 10303 -11550 10314 -11580 10325 -11600 10336 -11640 10348 -11660 10360
--11710 10374 -11750 10383 -11770 10393 -11810 10399 -11850 10405 -11890 10413
--11930 10419 -11950 10424 -11970 10426 -12010 10425 -12030 10421 -12060 10420
--12080 10413 -12100 10407 -12100 10401 -12120 10390 -12120 10381 -12120 10364
--12130 10348 -12110 10331 -12110 10315 -12100 10300 -12080 10279 -12060 10258
--12040 10234 -12010 10213 -11990 10192 -11960 10176 -11930 10157 -11890 10133
--11840 10112 -11820 10092 -11770 10078 -11740 10064 -11710 10054 -11670 10039
--11630 10030 -11600 10023 -11580 10019 -11540 10018 -11520 10021 -11500 10025
--11490 10034 -11470 10045 -11460 10057 -11470 10075 -11460 10097 -11480 10122
--11490 10151 -11510 10180 -11540 10210 -11560 10247 -11600 10287 -11650 10330
--11700 10376 -11760 10422 -11800 10471 -11870 10517 -11940 10570 -12010 10625
--12090 10680 -12180 10735 -12250 10790 -12330 10840 -12410 10894 -12500 10951
--12600 11007 -12690 11059 -12750 11105 -12840 11151 -12920 11197 -13000 11239
--13080 11282 -13150 11319 -13200 11351 -13240 11379 -13290 11405 -13340 11427
--13360 11444 -13390 11457 -13390 11463 -13370 11465 -13360 11463 -13320 11454
--13290 11441 -13220 11422 -13140 11399 -13030 11372 -12920 11339 -12790 11297
--12640 11251 -12480 11203 -12270 11157 -12060 11105 -11820 11044 -11570 10979
--11280 10909 -10980 10842 -10650 10783 -10300 10722 -9910 10654 -9500 10582
--9070 10512 -8620 10450 -8140 10400 -7650 10356 -7100 10309 -6530 10268
--5950 10231 -5330 10207 -4760 10190 -4150 10184 -3490 10194 -2800 10212
--2110 10238 -1430 10270 -800 10303 -180 10340 420 10387 1030 10446 1620 10505
-2200 10564 2770 10635 3330 10703 3830 10750 4270 10792 4740 10844 5220 10914
-5750 11011 6290 11124 6870 11244 7500 11378 8130 11527 8740 11700 9360 11888
-10000 12092 10650 12404 11300 12645 11900 12766 12150 12961 12020 13361
-11940 13820 12740 14174 15050 14462 18630 14819 22440 15375 25080 16155
-25440 16834 22920 16797 17310 15527 10950 13118 8390 10296 10140 6822
-13390 4314 10710 4666 11380 5073 11590 3064 11360 8162 10930 12739 12350 10192
-11340 10170 9210 8049 6450 6054 4730 8291 -580 9902 -5560 9266 -7410 10204
--13020 9894 -19790 16636 13710 2964 -19610 17334 -15020 12856 -6630 9592
-12260 11246 21510 11212 18390 11156 11510 11078 5100 11021 450 11187 -3710 11086
--7530 10454 -10380 9735 -11490 8944 -11570 8139 -10590 7865 -8490 8795
--8270 10774 -11060 11940 -16440 13124 -15960 12897 -13220 12271 -10300 11766
--7570 11519 -5490 11401 -4300 11182 -4380 10939 -5450 10845 -6970 10878
--8220 10800 -8730 10457 -8270 9988 -6830 9725 -4340 9847 820 10188 -170 9418
--15460 9149 -21450 9271 -24700 9898 -25800 10154 -25360 9417 -24290 7719
--23350 6138 -22740 5759 -23500 6617 -26610 7706 -30580 8225 -33990 8323
--34080 7355 -28900 5246 -19750 3200 -14630 2819 2500 4466 17980 7479 13360 5615
-11710 5095 20000 10768 -7470 6360 -14160 7352 -12170 7173 -15700 8814
--20380 10281 -21520 10883 -18940 10604 -16380 10311 -12730 9762 -10200 9982
--10760 16520 -16980 12237 -9340 14119 -4820 12691 -2020 12787 -7320 14448
--3830 11843 -19770 14418 -14380 14165 -13570 13126 -9220 14031 -11580 13008
--16480 13860 -13150 12984 -9820 11409 -11970 12161 -10590 9673 1100 10771
--11010 10502 -19970 10662 -24590 10524 -24040 10709 -28160 10192 -28120 9491
--26610 7865 -29170 10382 -23750 11166 -22660 11807 -19440 10194 -21990 10427
--14840 8033 -20040 9825 -35610 13195 -15960 16480 -11260 9083 -9990 6463
--37890 10748 -2470 19939 -12000 15530 -17420 11829 -24630 10378 -25590 12266
--26810 12530 -30120 12338 -31460 11772 -32900 10385 -32570 9962 -34230 9731
--34240 9281 -35280 8746 -34730 7789 -31860 8592 -29090 9468 -27070 9952
--25570 9728 -24270 9100 -23150 8468 -22250 7902 -20910 7290 -18650 6785
--16600 6377 -15220 6037 -14170 5889 -14680 6167 -16900 6808 -18700 7143
--18510 7294 -19040 6768 -18490 6080 -19350 5926 -20080 6072 -23380 5659
--26209 4858 -27883 4231 -28168 3890 -27906 3409 -32211 2886 -34274 2803
--34432 2696 -32548 2225 -27980 1297 -19802 79 -7302 -1049 9766 -1583 30974 -1022
-54607 918 76691 4021 90496 7329 88231 9313 67060 8992 34740 7048 1830 4741
--24600 2954 -41990 1987 -50760 1752 -52813 2015 -50232 2546 -44950 3173
--38415 3793 -31653 4356 -25319 4845 -19774 5263 -15177 5619 -11535 5927
--8790 6194 -6813 6432 -5475 6643 -4648 6835 -4206 7012 -4042 7174 -4074 7325
--4226 7466 -4448 7597 -4710 7719 -4997 7834 -5282 7942 -5552 8043 -5804 8138
--6044 8228 -6256 8311 -6448 8390 -6634 8465 -6801 8535 -6939 8600 -7070 8663
--7183 8722 -7295 8776 -7397 8828 -7481 8879 -7566 8926 -7642 8970 -7709 9009
--7767 9047 -7826 9083 -7867 9119 -7998 9157 -8020 9188 -8025 9217 -8025 9245
--8040 9272 -8057 9297 -8075 9321 -8094 9344 -8110 9365 -8122 9386 -8134 9407
--8148 9425 -8155 9443 -8155 9460 -8161 9476 -8166 9492 -8172 9506 -8178 9521
--8179 9534 -8178 9547 -8179 9559 -8184 9571 -8186 9583 -8190 9593 -8191 9603
--8190 9614 -8187 9622 -8196 9632 -8193 9641 -8196 9649 -8199 9657 -8200 9665
--8202 9673 -8206 9680 -8210 9687 -8214 9693 -8216 9700 -8217 9707 -8228 9712
--8232 9718 -8238 9725 -8239 9729 -8246 9735 -8250 9741 -8256 9745 -8264 9750
--8266 9755 -8276 9760 -8284 9765 -8288 9768 -8296 9773 -8301 9778 -8308 9781
--8310 9786 -8321 9789 -8329 9794 -8330 9797
-196: 14084240 -4733329 -10160 9888 -10180 9892 -10190 9895 -10190 9897
--10200 9900 -10200 9907 -10230 9910 -10230 9913 -10240 9915 -10270 9924
--10270 9925 -10290 9930 -10300 9937 -10310 9941 -10330 9943 -10340 9951
--10370 9952 -10370 9959 -10390 9964 -10400 9964 -10420 9970 -10430 9974
--10450 9979 -10450 9978 -10470 9985 -10480 9988 -10490 9990 -10500 9992
--10500 9996 -10520 10000 -10520 10002 -10530 10005 -10540 10008 -10550 10013
--10560 10015 -10570 10019 -10580 10021 -10590 10027 -10610 10031 -10620 10037
--10630 10043 -10650 10048 -10660 10054 -10680 10059 -10700 10065 -10720 10073
--10740 10079 -10760 10087 -10780 10094 -10800 10100 -10830 10106 -10860 10115
--10890 10123 -10910 10130 -10940 10135 -10960 10142 -10990 10146 -11020 10154
--11040 10159 -11060 10164 -11100 10168 -11110 10169 -11140 10175 -11160 10176
--11170 10178 -11200 10181 -11210 10183 -11220 10183 -11240 10182 -11250 10184
--11260 10184 -11260 10183 -11280 10183 -11270 10184 -11300 10184 -11290 10183
--11300 10183 -11300 10183 -11300 10183 -11310 10186 -11310 10190 -11320 10192
--11310 10196 -11320 10200 -11330 10206 -11340 10211 -11350 10217 -11360 10226
--11370 10235 -11390 10243 -11410 10251 -11420 10263 -11450 10272 -11470 10286
--11500 10298 -11530 10310 -11560 10320 -11580 10332 -11610 10343 -11640 10356
--11680 10368 -11710 10379 -11760 10385 -11780 10394 -11820 10400 -11860 10407
--11890 10413 -11920 10417 -11940 10420 -11970 10419 -12000 10416 -12030 10412
--12040 10407 -12060 10401 -12070 10395 -12080 10385 -12080 10374 -12090 10359
--12080 10343 -12090 10326 -12070 10312 -12070 10294 -12050 10275 -12020 10253
--12010 10231 -11980 10209 -11960 10190 -11930 10172 -11900 10154 -11860 10130
--11830 10109 -11780 10091 -11750 10077 -11710 10061 -11690 10051 -11650 10037
--11610 10026 -11580 10020 -11550 10017 -11520 10013 -11500 10016 -11490 10020
--11460 10028 -11450 10037 -11440 10049 -11440 10067 -11440 10087 -11450 10111
--11460 10136 -11490 10165 -11500 10196 -11530 10230 -11570 10267 -11610 10308
--11660 10351 -11710 10398 -11760 10443 -11830 10487 -11880 10537 -11960 10590
--12030 10644 -12120 10697 -12180 10745 -12260 10797 -12340 10847 -12430 10901
--12510 10956 -12600 11004 -12670 11048 -12750 11093 -12820 11136 -12900 11177
--12980 11217 -13040 11254 -13100 11283 -13130 11308 -13170 11336 -13220 11355
--13250 11372 -13260 11382 -13270 11391 -13240 11394 -13230 11390 -13190 11383
--13140 11369 -13080 11353 -13000 11333 -12890 11308 -12770 11276 -12640 11238
--12490 11198 -12320 11152 -12110 11109 -11900 11063 -11660 11008 -11400 10948
--11120 10886 -10800 10826 -10480 10774 -10120 10719 -9740 10659 -9320 10597
--8890 10536 -8440 10481 -7970 10439 -7470 10402 -6940 10366 -6360 10330
--5770 10303 -5180 10286 -4610 10276 -4000 10275 -3350 10289 -2680 10310
--1980 10340 -1330 10375 -700 10411 -70 10453 540 10504 1140 10564 1750 10623
-2330 10687 2930 10764 3490 10837 4030 10897 4510 10950 5010 11015 5540 11098
-6080 11204 6660 11324 7270 11456 7910 11601 8560 11760 9190 11940 9820 12127
-10470 12322 11130 12649 11870 12913 12610 13045 13050 13231 12990 13603
-12700 14047 12930 14403 14310 14648 16940 14813 20100 15015 22660 15356
-23580 15652 22300 15531 19030 14659 15370 13006 13450 10763 13530 8107
-14120 5910 12880 5019 12590 4621 12250 4550 11860 7979 12150 11179 13000 10772
-12350 9845 10190 8080 7220 7249 4420 9109 680 10852 -1800 11033 -1210 10930
-3180 8644 29890 -3146 191530 -67054 -185670 85565 -64610 35081 -9790 11679
-1590 12077 21490 11055 17910 10768 10350 10899 3860 11068 820 11352 -3140 10938
--7570 9634 -11020 9066 -11130 8782 -10400 8382 -8910 8352 -6980 8692 -9430 9910
--13360 11088 -16660 12582 -16040 12781 -14000 12354 -11840 11774 -9000 11522
--6450 11412 -5340 11072 -5260 10852 -5990 10784 -7040 10658 -7790 10212
--7930 9409 -7440 8498 -6240 7863 -3920 7985 -460 10667 -2420 9761 -8910 8434
--15520 9106 -20210 9742 -22980 9633 -23630 8485 -22890 6455 -22020 4948
--21400 5081 -21540 6635 -23300 8005 -24810 8135 -27590 8631 -28960 8045
--26380 6471 -21890 4909 -15750 4418 -4360 5646 8150 7540 10240 7096 10110 7156
-10090 9407 -6750 7780 -16540 7952 -19460 8121 -11040 8573 -10350 9724
--17070 10802 -15350 10754 -15220 10877 -13040 11029 -13570 10805 -13350 12563
--12140 12890 -11750 14101 -8030 13388 -5740 13307 -7660 13830 -7990 12879
--15650 13901 -14340 13998 -12160 13668 -8660 13855 -14690 14394 -13800 14424
--7660 15641 -2940 14510 -24010 12018 -31210 9537 3770 12397 -15990 10722
--21220 11052 -23570 10650 -16310 11754 -24320 11888 -29200 9715 -30090 9738
--31480 10137 -36460 11643 -37010 13841 -34820 14060 -1360 2186 1990 1738
--7140 7516 -58160 38307 -20810 7345 -13280 3044 -15420 4043 -26530 8968
--11390 15156 -12140 14789 -16590 12961 -22260 11934 -25530 12238 -27930 12272
--30610 11991 -32460 11387 -33880 10459 -34550 9874 -35580 9466 -35970 9019
--36260 8533 -35520 8085 -33560 8349 -31330 8831 -29370 9183 -27740 9202
--26310 8952 -24980 8578 -23650 8133 -22030 7613 -20020 7092 -18090 6621
--16610 6247 -15760 6065 -15990 6162 -17240 6462 -18460 6677 -18980 6710
--19460 6409 -19630 6012 -20320 5809 -21460 5697 -23660 5331 -25810 4744
--27222 4174 -27590 3707 -27128 3239 -31660 2773 -33955 2706 -34307 2685
--32555 2385 -28209 1663 -20673 608 -9569 -462 5053 -1119 22387 -956 40569 228
-56393 2247 65489 4481 63837 6073 50530 6477 29510 5871 6740 4821 -12990 3849
--27190 3219 -35474 2978 -38624 3053 -37932 3331 -34760 3711 -30255 4124
--25287 4527 -20455 4902 -16121 5241 -12467 5546 -9544 5821 -7327 6069
--5729 6297 -4662 6504 -4023 6695 -3706 6874 -3611 7041 -3698 7196 -3882 7341
--4126 7478 -4401 7606 -4694 7726 -4983 7840 -5258 7947 -5520 8047 -5764 8141
--5988 8230 -6193 8313 -6384 8393 -6558 8467 -6710 8537 -6845 8604 -6973 8665
--7096 8724 -7204 8779 -7307 8832 -7397 8883 -7481 8929 -7561 8972 -7623 9012
--7693 9049 -7746 9088 -7874 9128 -7905 9161 -7913 9191 -7928 9221 -7950 9249
--7972 9277 -7997 9301 -8020 9325 -8044 9347 -8060 9370 -8078 9391 -8093 9410
--8103 9429 -8112 9447 -8121 9463 -8128 9480 -8137 9495 -8145 9511 -8151 9524
--8156 9537 -8156 9549 -8158 9562 -8173 9574 -8172 9585 -8172 9596 -8179 9606
--8178 9615 -8185 9625 -8186 9634 -8188 9643 -8193 9651 -8199 9659 -8200 9667
--8201 9674 -8207 9682 -8212 9688 -8217 9696 -8221 9701 -8223 9708 -8231 9714
--8240 9719 -8246 9726 -8250 9731 -8251 9736 -8263 9741 -8267 9747 -8269 9751
--8282 9757 -8285 9761 -8293 9765 -8298 9769 -8308 9774 -8312 9779 -8316 9782
--8324 9786 -8331 9791 -8334 9794
-197: 14117100 -4724787 -10180 9891 -10180 9895 -10200 9897 -10200 9899
--10200 9905 -10220 9909 -10220 9911 -10240 9913 -10250 9917 -10270 9923
--10280 9928 -10290 9932 -10310 9938 -10320 9942 -10330 9945 -10350 9949
--10360 9954 -10380 9959 -10400 9963 -10400 9965 -10430 9969 -10430 9975
--10450 9977 -10450 9980 -10480 9985 -10480 9989 -10490 9989 -10510 9995
--10510 9994 -10510 9998 -10520 10003 -10540 10005 -10540 10008 -10550 10012
--10560 10015 -10570 10019 -10590 10022 -10590 10025 -10610 10031 -10620 10036
--10630 10041 -10640 10047 -10660 10054 -10680 10058 -10700 10065 -10720 10070
--10740 10078 -10750 10085 -10780 10093 -10800 10098 -10820 10104 -10860 10112
--10880 10120 -10900 10125 -10930 10133 -10960 10139 -10980 10144 -11000 10151
--11030 10155 -11060 10160 -11080 10165 -11110 10168 -11120 10169 -11140 10172
--11160 10174 -11180 10177 -11200 10179 -11210 10180 -11220 10179 -11230 10179
--11250 10180 -11250 10180 -11260 10177 -11270 10181 -11280 10181 -11270 10179
--11280 10178 -11280 10181 -11290 10179 -11300 10183 -11290 10186 -11300 10189
--11300 10192 -11300 10197 -11320 10201 -11330 10208 -11330 10214 -11340 10222
--11360 10232 -11370 10239 -11390 10247 -11400 10259 -11430 10268 -11450 10283
--11480 10294 -11510 10304 -11530 10316 -11560 10328 -11580 10338 -11630 10351
--11650 10364 -11690 10372 -11720 10381 -11760 10386 -11780 10396 -11830 10401
--11860 10406 -11880 10411 -11920 10413 -11930 10413 -11960 10410 -11990 10405
--12010 10403 -12030 10395 -12030 10389 -12050 10379 -12050 10367 -12050 10356
--12050 10339 -12050 10320 -12040 10308 -12030 10289 -12020 10272 -11990 10250
--11970 10227 -11950 10206 -11930 10188 -11910 10169 -11860 10149 -11850 10129
--11790 10108 -11760 10088 -11730 10075 -11680 10061 -11670 10047 -11620 10035
--11590 10024 -11560 10017 -11530 10012 -11500 10010 -11480 10013 -11460 10016
--11450 10021 -11430 10031 -11420 10042 -11410 10058 -11420 10077 -11420 10101
--11440 10122 -11440 10151 -11480 10181 -11500 10213 -11530 10247 -11570 10288
--11620 10328 -11660 10373 -11720 10415 -11770 10458 -11840 10505 -11900 10555
--11980 10608 -12050 10659 -12120 10705 -12190 10753 -12270 10800 -12350 10853
--12440 10906 -12510 10951 -12590 10993 -12660 11036 -12730 11077 -12800 11116
--12880 11155 -12940 11190 -12990 11216 -13030 11241 -13060 11265 -13100 11286
--13140 11301 -13140 11313 -13140 11320 -13120 11323 -13100 11320 -13070 11313
--13000 11303 -12950 11286 -12870 11268 -12760 11247 -12620 11215 -12500 11183
--12340 11144 -12180 11102 -11970 11064 -11750 11022 -11510 10973 -11260 10919
--10960 10864 -10650 10809 -10320 10763 -9970 10717 -9590 10662 -9160 10610
--8740 10556 -8290 10510 -7810 10474 -7330 10445 -6780 10416 -6230 10388
--5640 10368 -5050 10357 -4470 10353 -3880 10360 -3250 10376 -2570 10401
--1900 10434 -1250 10471 -610 10512 10 10558 620 10611 1240 10673 1840 10736
-2440 10803 3040 10883 3640 10963 4190 11031 4710 11096 5240 11172 5800 11265
-6380 11376 6960 11504 7600 11643 8260 11794 8920 11962 9570 12147 10210 12327
-10880 12529 11530 12852 12320 13122 13170 13262 13810 13435 13930 13767
-13660 14185 13550 14558 14210 14820 15940 14909 18320 14889 20530 14874
-21720 14812 21410 14537 19770 13890 17760 12793 16390 11247 15770 9354
-15430 7524 14650 6249 13980 5624 13190 5940 12740 7846 13110 9797 13710 10145
-13070 9332 10780 8022 7550 7838 4570 9492 2500 11172 2860 11316 7250 9689
-18070 5085 42150 -4913 74160 -16245 -111180 60245 -7220 17140 -3520 13507
-1140 12592 9940 10726 8520 10494 3460 11085 -1710 11376 220 11918 -3100 11132
--8230 8430 -13290 8456 -11530 9058 -10740 8931 -9850 8961 -7320 8260 -9240 8626
--16310 11050 -16630 12328 -14800 12522 -13400 12168 -12940 11355 -9990 11284
--7100 11309 -6140 10922 -6070 10785 -6400 10795 -6770 10539 -6790 9790
--6270 8704 -5690 7595 -5120 6863 -4060 6956 1560 8721 -6320 9350 -5390 8540
--11080 9479 -16220 9789 -20740 9184 -22560 7899 -21600 5559 -20340 3896
--18850 4317 -17250 6849 -18360 8718 -16260 7512 -19310 9270 -22440 9224
--20680 8121 -20150 7071 -14950 6525 -12690 7365 -3770 8019 1080 8019 1500 8105
--100 8636 -9290 8144 -16440 7929 -19220 7831 -16520 8205 -9930 10646 -10270 9203
--11720 11048 -13900 11097 -11650 12120 -14240 12121 -12590 11595 -15330 11976
--14330 13156 -11570 13412 -9610 13581 -9830 13791 -10700 13552 -13850 13878
--13710 13970 -12210 13928 -10690 14145 -12620 14686 -10890 15075 -6650 15782
--5360 15077 -14940 13307 -16240 11979 -17060 11864 -24310 10765 -24910 10921
--23630 11040 -19930 11735 -24050 11802 -28720 10739 -31610 10627 -34380 10900
--38110 11908 -37350 12851 -29670 11387 -7820 4677 -3060 4764 -13560 11791
--39570 25877 -26450 11289 -19370 5205 -19080 5008 -21840 8215 -16270 12068
--15510 13134 -18130 12739 -22160 12244 -25570 12126 -28380 11970 -30880 11637
--32820 11100 -34320 10417 -35360 9846 -36240 9375 -36710 8930 -36760 8500
--36070 8177 -34590 8185 -32790 8393 -31020 8622 -29410 8744 -27930 8720
--26490 8562 -25000 8273 -23310 7864 -21460 7396 -19680 6936 -18240 6552
--17400 6313 -17350 6255 -17980 6324 -18800 6379 -19430 6330 -19930 6118
--20340 5848 -20980 5631 -22040 5413 -23620 5055 -25230 4554 -26350 4015
--26666 3512 -26144 3047 -30476 2564 -32857 2511 -33445 2573 -32059 2443
--28318 1948 -21848 1114 -12463 173 -415 -532 13443 -665 27459 -61 39248 1186
-46006 2698 45533 3975 37524 4663 24134 4750 8804 4463 -5330 4073 -16265 3771
--23327 3637 -26724 3669 -27157 3830 -25514 4073 -22636 4356 -19206 4651
--15726 4943 -12518 5221 -9765 5484 -7556 5731 -5861 5962 -4657 6179 -3870 6382
--3422 6571 -3232 6751 -3228 6919 -3369 7078 -3580 7227 -3839 7368 -4135 7501
--4433 7626 -4725 7745 -5004 7855 -5269 7961 -5519 8060 -5748 8153 -5955 8241
--6157 8324 -6337 8402 -6498 8476 -6643 8546 -6783 8612 -6911 8673 -7027 8732
--7141 8787 -7237 8841 -7331 8890 -7417 8935 -7493 8977 -7562 9017 -7626 9058
--7760 9099 -7798 9134 -7809 9166 -7834 9198 -7862 9227 -7893 9255 -7922 9282
--7949 9306 -7978 9330 -8000 9353 -8021 9376 -8042 9396 -8055 9415 -8066 9434
--8080 9451 -8092 9468 -8104 9484 -8117 9499 -8124 9514 -8130 9528 -8136 9540
--8138 9553 -8151 9566 -8156 9577 -8159 9588 -8167 9598 -8167 9609 -8173 9618
--8174 9627 -8183 9637 -8188 9645 -8194 9653 -8201 9661 -8200 9669 -8206 9676
--8208 9684 -8214 9690 -8222 9697 -8227 9703 -8231 9709 -8238 9716 -8248 9721
--8254 9727 -8255 9732 -8266 9738 -8270 9743 -8278 9747 -8283 9753 -8288 9757
--8297 9762 -8300 9767 -8312 9770 -8318 9775 -8320 9780 -8327 9783 -8336 9787
--8341 9791
-198: 14149980 -4716252 -10190 9894 -10190 9898 -10200 9899 -10210 9902
--10210 9906 -10220 9909 -10230 9913 -10250 9917 -10250 9918 -10270 9925
--10290 9929 -10300 9933 -10310 9938 -10320 9944 -10340 9945 -10350 9951
--10370 9954 -10380 9958 -10400 9964 -10410 9966 -10420 9969 -10440 9975
--10450 9977 -10470 9979 -10470 9985 -10490 9989 -10490 9991 -10510 9992
--10510 9993 -10510 9999 -10530 10003 -10540 10005 -10550 10007 -10550 10012
--10560 10015 -10570 10018 -10580 10023 -10600 10023 -10610 10031 -10620 10036
--10620 10041 -10650 10046 -10660 10052 -10670 10058 -10700 10064 -10720 10067
--10730 10077 -10760 10085 -10770 10090 -10800 10095 -10820 10102 -10840 10111
--10880 10116 -10890 10122 -10930 10130 -10940 10138 -10970 10141 -11000 10148
--11020 10151 -11050 10158 -11070 10160 -11090 10163 -11110 10166 -11130 10168
--11150 10170 -11170 10174 -11180 10174 -11190 10175 -11210 10177 -11220 10177
--11230 10174 -11230 10175 -11250 10176 -11250 10176 -11270 10176 -11260 10175
--11260 10176 -11270 10177 -11270 10177 -11280 10179 -11280 10181 -11280 10185
--11280 10189 -11300 10193 -11290 10199 -11310 10203 -11320 10210 -11330 10219
--11340 10229 -11350 10235 -11370 10244 -11390 10253 -11410 10264 -11430 10278
--11460 10289 -11480 10302 -11510 10311 -11540 10323 -11560 10334 -11600 10347
--11630 10358 -11660 10365 -11700 10375 -11720 10382 -11760 10389 -11790 10395
--11830 10400 -11850 10406 -11880 10407 -11900 10406 -11930 10404 -11950 10400
--11970 10396 -12000 10391 -12000 10383 -12010 10374 -12010 10363 -12020 10349
--12020 10333 -12000 10318 -12020 10304 -12000 10286 -11980 10267 -11960 10247
--11940 10224 -11920 10204 -11900 10184 -11880 10166 -11840 10148 -11810 10128
--11770 10105 -11730 10087 -11700 10073 -11670 10059 -11640 10046 -11610 10034
--11560 10021 -11540 10014 -11510 10010 -11480 10008 -11460 10008 -11430 10012
--11420 10016 -11410 10024 -11400 10035 -11390 10050 -11390 10068 -11400 10090
--11400 10111 -11420 10137 -11450 10166 -11470 10196 -11500 10230 -11530 10266
--11570 10308 -11620 10346 -11670 10389 -11730 10429 -11790 10475 -11840 10521
--11920 10573 -11990 10620 -12050 10666 -12120 10712 -12200 10756 -12280 10805
--12360 10855 -12440 10899 -12500 10940 -12570 10981 -12640 11020 -12710 11057
--12780 11093 -12850 11126 -12880 11153 -12920 11176 -12950 11197 -13000 11217
--13020 11234 -13030 11245 -13020 11252 -13000 11254 -12980 11253 -12940 11246
--12890 11236 -12820 11221 -12740 11206 -12630 11186 -12500 11159 -12360 11128
--12220 11092 -12040 11055 -11840 11020 -11620 10984 -11380 10938 -11110 10891
--10830 10841 -10510 10793 -10190 10752 -9830 10712 -9450 10666 -9040 10620
--8600 10573 -8160 10535 -7680 10506 -7200 10483 -6670 10461 -6110 10439
--5530 10427 -4960 10422 -4370 10424 -3790 10435 -3160 10456 -2500 10484
--1830 10521 -1200 10560 -560 10606 70 10655 690 10710 1300 10774 1920 10840
-2510 10911 3140 10994 3740 11079 4320 11154 4870 11229 5430 11314 6020 11415
-6610 11533 7220 11661 7870 11805 8540 11963 9210 12135 9890 12320 10530 12493
-11240 12701 11860 13014 12620 13278 13550 13422 14350 13574 14740 13857
-14640 14224 14420 14600 14630 14900 15610 14999 17250 14889 18960 14653
-20170 14312 20430 13853 19790 13267 18820 12515 17910 11526 17180 10262
-16620 8861 16020 7623 15210 6931 14180 7029 13600 7912 13900 9061 14360 9527
-13690 8906 11320 7916 8010 8021 5230 9570 4260 11121 6140 11154 11550 9244
-20630 5611 31180 1752 27610 4822 -36580 32651 2440 17584 13080 13107 6730 12246
-2640 12266 970 11172 -3030 11940 -9230 11642 150 12613 -3780 12011 -8970 7029
--17360 8175 -11940 9558 -11930 9222 -12840 9700 -9250 7374 -12140 9253
--21260 10422 -11960 12028 -11410 12021 -11160 11940 -14480 10427 -10620 10877
--7330 11119 -6540 10720 -6900 10659 -6720 10830 -6250 10501 -5360 9570
--3680 8477 -2570 7405 -1710 6671 230 6477 3480 6972 -7930 9213 -9640 7770
--10330 9545 -13240 9680 -19800 8734 -22840 8238 -20370 5458 -18920 3249
--16880 3732 -13040 7947 -16250 10558 -7570 5346 -11830 9709 -17150 9868
--13860 9196 -18850 8822 -12190 8167 -20400 9083 -11980 8558 -6650 8584
--7920 8530 -7620 8163 -12300 8244 -15260 7927 -16010 7605 -17080 7068
--13370 10364 -13190 9546 -13440 9519 -14310 10299 -11480 12724 -13250 12507
--13920 11922 -15900 12076 -15720 12830 -14140 13359 -12660 13723 -12240 13947
--12620 13950 -13790 14036 -13770 14054 -12870 14072 -11890 14268 -11650 14670
--9950 15067 -7560 15393 -7530 14938 -12140 13807 -15550 12709 -20150 12129
--24800 11326 -25490 11152 -24300 11247 -22880 11599 -25060 11663 -28550 11272
--31680 11177 -34360 11328 -36140 11726 -34140 11756 -26800 10337 -14620 7434
--10990 8029 -17470 12579 -29120 17914 -26470 12264 -22760 7920 -21590 6966
--21580 8484 -19400 10692 -18890 11859 -20460 12093 -23240 11977 -26130 11836
--28780 11628 -31080 11303 -32940 10851 -34430 10320 -35550 9814 -36390 9357
--36880 8935 -36890 8543 -36310 8234 -35160 8101 -33680 8124 -32120 8240
--30620 8372 -29160 8457 -27730 8440 -26220 8289 -24580 7998 -22880 7616
--21230 7203 -19890 6829 -18990 6545 -18700 6373 -18940 6284 -19460 6208
--19980 6085 -20440 5889 -20870 5660 -21410 5435 -22260 5178 -23420 4820
--24630 4356 -25490 3840 -25710 3335 -25158 2880 -28957 2353 -31234 2286
--32019 2397 -31101 2408 -28158 2130 -22912 1537 -15306 776 -5648 106 5290 -202
-16183 7 25323 711 30872 1704 31542 2687 27193 3418 19030 3816 9085 3946
--627 3933 -8629 3890 -14225 3887 -17351 3952 -18326 4084 -17692 4266 -16022 4482
--13813 4715 -11453 4953 -9218 5191 -7279 5424 -5699 5651 -4503 5867 -3665 6076
--3145 6273 -2884 6460 -2813 6640 -2897 6810 -3083 6971 -3324 7124 -3607 7268
--3902 7404 -4208 7533 -4503 7656 -4786 7771 -5053 7880 -5304 7984 -5535 8081
--5747 8172 -5952 8259 -6137 8341 -6306 8418 -6465 8492 -6606 8560 -6742 8624
--6867 8686 -6984 8745 -7086 8800 -7186 8853 -7284 8899 -7368 8943 -7451 8986
--7519 9027 -7648 9072 -7691 9108 -7713 9142 -7745 9174 -7782 9206 -7816 9235
--7847 9263 -7884 9288 -7913 9313 -7941 9337 -7968 9360 -7989 9382 -8009 9402
--8024 9420 -8039 9439 -8058 9456 -8072 9474 -8088 9489 -8097 9504 -8108 9517
--8114 9532 -8120 9544 -8133 9558 -8143 9569 -8143 9580 -8152 9591 -8157 9602
--8161 9611 -8165 9621 -8179 9631 -8185 9639 -8185 9647 -8195 9656 -8199 9663
--8205 9671 -8209 9679 -8213 9685 -8218 9692 -8228 9699 -8234 9705 -8245 9711
--8250 9717 -8255 9723 -8258 9729 -8267 9733 -8275 9739 -8278 9744 -8288 9750
--8288 9754 -8304 9758 -8309 9763 -8313 9768 -8320 9771 -8325 9776 -8332 9781
--8338 9784 -8348 9788
-199: 14182890 -4707727 -10200 9897 -10200 9900 -10200 9902 -10210 9905
--10220 9908 -10240 9910 -10230 9916 -10250 9919 -10260 9921 -10270 9926
--10300 9929 -10300 9935 -10320 9939 -10320 9943 -10340 9948 -10360 9953
--10370 9954 -10390 9958 -10410 9964 -10410 9966 -10430 9967 -10440 9974
--10450 9978 -10470 9980 -10470 9984 -10490 9989 -10500 9989 -10500 9993
--10510 9994 -10520 9998 -10530 10003 -10540 10006 -10550 10007 -10550 10012
--10570 10015 -10570 10018 -10580 10021 -10600 10024 -10600 10030 -10620 10034
--10640 10040 -10640 10046 -10660 10053 -10670 10056 -10700 10060 -10710 10067
--10730 10077 -10750 10082 -10780 10087 -10790 10093 -10810 10100 -10840 10108
--10870 10114 -10890 10120 -10920 10129 -10940 10133 -10960 10138 -10980 10145
--11010 10149 -11040 10154 -11060 10157 -11080 10159 -11100 10162 -11120 10163
--11130 10168 -11160 10170 -11160 10170 -11180 10172 -11200 10174 -11200 10172
--11210 10171 -11230 10171 -11230 10172 -11240 10172 -11250 10172 -11240 10172
--11250 10172 -11250 10174 -11260 10173 -11260 10175 -11260 10177 -11270 10182
--11270 10184 -11280 10190 -11280 10195 -11290 10200 -11310 10208 -11310 10214
--11320 10224 -11340 10232 -11350 10239 -11360 10250 -11400 10260 -11410 10274
--11440 10284 -11460 10298 -11490 10306 -11510 10319 -11540 10330 -11570 10340
--11600 10351 -11640 10361 -11670 10369 -11690 10376 -11740 10383 -11760 10389
--11790 10396 -11820 10399 -11850 10400 -11870 10399 -11890 10399 -11910 10396
--11940 10391 -11970 10385 -11960 10377 -11980 10369 -11980 10358 -11980 10344
--11980 10329 -11970 10315 -11990 10299 -11960 10283 -11950 10264 -11920 10244
--11920 10221 -11890 10202 -11870 10182 -11850 10166 -11810 10144 -11780 10125
--11750 10105 -11710 10086 -11670 10071 -11650 10058 -11610 10045 -11580 10032
--11550 10020 -11510 10012 -11490 10008 -11460 10005 -11430 10005 -11420 10007
--11410 10011 -11380 10018 -11370 10028 -11370 10044 -11370 10059 -11360 10080
--11380 10100 -11390 10124 -11410 10152 -11440 10179 -11460 10211 -11500 10247
--11530 10285 -11580 10323 -11620 10363 -11670 10402 -11740 10445 -11790 10489
--11870 10537 -11920 10584 -11990 10628 -12050 10669 -12130 10713 -12210 10761
--12290 10805 -12360 10847 -12420 10888 -12480 10927 -12550 10962 -12610 11000
--12690 11033 -12750 11066 -12780 11090 -12820 11113 -12850 11134 -12890 11151
--12920 11169 -12920 11178 -12900 11185 -12890 11188 -12860 11188 -12830 11182
--12770 11170 -12700 11160 -12620 11145 -12500 11127 -12390 11104 -12240 11075
--12100 11043 -11910 11008 -11720 10980 -11490 10945 -11260 10907 -10990 10861
--10710 10818 -10390 10778 -10070 10740 -9710 10707 -9340 10668 -8920 10627
--8500 10588 -8040 10557 -7580 10534 -7100 10516 -6570 10501 -6030 10487
--5460 10479 -4870 10480 -4300 10487 -3730 10503 -3100 10527 -2450 10561
--1800 10599 -1160 10642 -520 10690 90 10743 730 10802 1340 10868 1960 10937
-2570 11011 3200 11097 3830 11185 4400 11268 5000 11351 5580 11443 6180 11551
-6790 11670 7430 11801 8080 11948 8770 12108 9460 12283 10130 12465 10800 12631
-11500 12835 12130 13129 12820 13384 13760 13532 14670 13665 15300 13890
-15460 14188 15330 14533 15330 14853 15810 14999 16810 14898 18030 14575
-19060 14066 19530 13451 19440 12827 19110 12230 18570 11587 17940 10788
-17470 9799 17010 8767 16170 8100 15030 7921 14340 8176 14530 8838 14920 9238
-14240 8737 11950 7926 8750 8085 6170 9480 5570 10913 7630 11054 12140 9639
-17890 7516 21590 6670 15740 10530 -4270 20420 8710 16350 15750 13557 12710 12820
-9240 13023 7310 12914 -5110 12591 -6530 11501 -6020 11553 -8060 11937
--9600 9851 -15750 9003 -15130 8182 -13000 8202 -13100 10062 -14160 9673
--15090 11252 -18310 8982 -12400 10185 -10930 10818 -8080 12076 -17050 9154
--10470 10564 -7230 10888 -6620 10381 -8130 10302 -7230 10823 -5850 10485
--4280 9416 -750 8657 310 7786 -190 7189 -800 7200 -1750 7850 -7820 7253
--9450 8402 -5800 7140 -8260 8804 -19250 8026 -24680 10328 -18000 6557
--18130 3630 -17380 4784 -14070 11786 -19140 11761 -7120 3142 -8130 7037
--9790 7994 -11840 8826 -16800 9472 -17150 9890 -13850 9971 -10480 8427
--8500 8870 -15440 8883 -11450 7742 -14790 8675 -14070 8548 -11730 9227
--16790 9315 -15250 8819 -16230 8827 -9040 11122 -21770 7506 -15350 10330
--14850 11429 -15500 11723 -16680 12105 -16830 12734 -15970 13329 -14920 13796
--14310 14094 -14230 14195 -14540 14210 -14430 14170 -13800 14155 -12930 14265
--11990 14512 -10540 14776 -9230 14908 -9610 14587 -12470 13826 -16190 12930
--19910 12436 -23370 11789 -24570 11446 -24350 11388 -24170 11526 -25690 11595
--28240 11492 -30820 11443 -32820 11465 -33430 11492 -31260 11213 -25880 10307
--19120 9230 -16670 9895 -19800 12335 -25070 14333 -25440 12142 -24110 9637
--23240 8659 -22750 9176 -21830 10311 -21700 11153 -22770 11513 -24740 11564
--27030 11473 -29290 11281 -31310 10994 -33010 10624 -34390 10197 -35450 9767
--36260 9357 -36730 8973 -36760 8614 -36310 8303 -35400 8087 -34170 7988
--32810 8000 -31430 8090 -30070 8200 -28700 8256 -27250 8200 -25730 8012
--24180 7719 -22680 7372 -21410 7023 -20480 6716 -20010 6473 -19970 6282
--20250 6110 -20640 5924 -21000 5712 -21330 5485 -21750 5251 -22340 4977
--23200 4625 -24080 4185 -24740 3692 -24860 3201 -24310 2757 -27300 2196
--29320 2088 -30225 2204 -29758 2307 -27618 2208 -23598 1843 -17650 1285
--10091 717 -1521 344 7028 313 14334 655 19193 1267 20750 1980 18918 2629
-14346 3120 8254 3444 1908 3644 -3636 3775 -7805 3888 -10390 4012 -11521 4158
--11482 4328 -10630 4518 -9330 4722 -7848 4933 -6405 5148 -5130 5362 -4096 5574
--3328 5782 -2808 5983 -2525 6176 -2425 6363 -2469 6542 -2623 6712 -2848 6875
--3117 7030 -3414 7177 -3719 7316 -4022 7448 -4314 7575 -4601 7693 -4869 7806
--5118 7912 -5349 8013 -5573 8108 -5774 8198 -5958 8284 -6131 8364 -6298 8440
--6447 8511 -6588 8578 -6719 8643 -6845 8703 -6946 8762 -7055 8816 -7159 8866
--7253 8910 -7341 8955 -7420 9000 -7543 9045 -7599 9083 -7624 9118 -7661 9152
--7704 9185 -7745 9215 -7777 9244 -7819 9270 -7855 9296 -7885 9322 -7915 9345
--7943 9368 -7965 9389 -7985 9407 -8002 9427 -8022 9445 -8043 9463 -8056 9478
--8069 9494 -8084 9509 -8092 9522 -8103 9536 -8116 9550 -8127 9561 -8129 9573
--8141 9584 -8149 9594 -8151 9605 -8156 9615 -8173 9624 -8176 9634 -8184 9641
--8190 9650 -8198 9659 -8204 9666 -8209 9673 -8214 9681 -8219 9687 -8225 9695
--8237 9700 -8243 9707 -8252 9714 -8258 9719 -8263 9724 -8267 9730 -8274 9735
--8286 9741 -8290 9746 -8293 9750 -8307 9755 -8313 9760 -8317 9765 -8322 9768
--8333 9773 -8340 9777 -8342 9781 -8349 9785
-200: 14215820 -4699209 -10210 9901 -10200 9901 -10210 9904 -10220 9906
--10230 9913 -10230 9911 -10250 9916 -10250 9920 -10270 9924 -10280 9928
--10290 9930 -10300 9937 -10330 9941 -10330 9944 -10340 9948 -10360 9953
--10380 9954 -10390 9961 -10400 9963 -10420 9967 -10440 9967 -10440 9973
--10450 9978 -10470 9979 -10480 9986 -10490 9986 -10490 9989 -10510 9994
--10520 9996 -10520 9997 -10530 10003 -10540 10006 -10550 10007 -10550 10011
--10570 10013 -10570 10016 -10590 10022 -10590 10024 -10610 10030 -10620 10033
--10640 10038 -10640 10044 -10650 10053 -10670 10055 -10690 10059 -10720 10067
--10730 10075 -10740 10079 -10770 10087 -10790 10092 -10810 10098 -10830 10105
--10860 10111 -10890 10119 -10910 10127 -10930 10128 -10950 10134 -10980 10142
--11000 10146 -11020 10151 -11050 10153 -11070 10156 -11090 10159 -11110 10161
--11120 10164 -11140 10164 -11150 10167 -11170 10168 -11180 10169 -11190 10168
--11200 10168 -11210 10168 -11220 10168 -11220 10168 -11230 10169 -11230 10168
--11240 10168 -11230 10169 -11240 10170 -11250 10172 -11250 10175 -11250 10177
--11260 10180 -11260 10186 -11270 10191 -11270 10197 -11290 10205 -11290 10210
--11310 10219 -11320 10229 -11330 10236 -11350 10245 -11370 10257 -11390 10268
--11420 10280 -11440 10293 -11470 10302 -11490 10314 -11510 10323 -11550 10334
--11580 10347 -11610 10355 -11640 10363 -11670 10370 -11700 10377 -11730 10384
--11760 10390 -11790 10393 -11820 10395 -11830 10394 -11860 10393 -11880 10391
--11910 10386 -11920 10379 -11940 10371 -11940 10364 -11940 10353 -11940 10339
--11960 10326 -11940 10310 -11950 10296 -11930 10280 -11920 10262 -11900 10240
--11870 10220 -11860 10199 -11840 10182 -11820 10164 -11790 10142 -11750 10123
--11720 10105 -11690 10085 -11650 10069 -11620 10058 -11590 10044 -11550 10030
--11530 10019 -11490 10010 -11470 10006 -11440 10003 -11420 10002 -11390 10004
--11380 10006 -11360 10013 -11350 10024 -11340 10035 -11350 10050 -11340 10071
--11340 10089 -11370 10113 -11370 10136 -11410 10165 -11420 10193 -11460 10227
--11490 10264 -11540 10301 -11570 10337 -11630 10375 -11680 10416 -11730 10459
--11820 10502 -11860 10548 -11930 10589 -11980 10629 -12060 10671 -12140 10716
--12210 10758 -12280 10799 -12340 10836 -12400 10875 -12460 10909 -12530 10941
--12590 10975 -12650 11006 -12690 11029 -12730 11052 -12750 11072 -12780 11089
--12810 11103 -12810 11115 -12800 11121 -12780 11124 -12750 11124 -12720 11119
--12650 11110 -12600 11099 -12500 11087 -12390 11071 -12270 11050 -12130 11024
--11990 10995 -11800 10964 -11610 10938 -11390 10909 -11140 10873 -10880 10836
--10600 10795 -10290 10761 -9960 10729 -9610 10700 -9240 10668 -8830 10633
--8410 10600 -7950 10576 -7510 10557 -7020 10547 -6500 10535 -5960 10529
--5400 10525 -4820 10533 -4260 10543 -3680 10564 -3070 10592 -2440 10628
--1780 10669 -1150 10716 -520 10767 110 10822 730 10885 1350 10954 1980 11025
-2610 11104 3230 11191 3870 11282 4470 11371 5070 11462 5690 11560 6300 11671
-6940 11793 7580 11924 8240 12073 8950 12234 9640 12408 10330 12586 10990 12743
-11720 12930 12310 13202 12970 13448 13830 13599 14780 13723 15590 13894
-16020 14111 16100 14393 16080 14695 16290 14883 16830 14839 17630 14527
-18390 13965 18860 13264 19010 12574 19010 12002 18730 11529 18270 11022
-17960 10359 17650 9577 16880 9007 15700 8656 14930 8560 15000 8931 15330 9251
-14740 8843 12660 8129 9720 8205 7280 9355 6600 10656 8050 11016 11120 10247
-14430 9179 15840 9237 12880 11678 7240 15499 12070 14780 15960 13573 15090 13136
-12370 13221 8370 13160 -220 12705 -3890 11907 -6090 11653 -8300 11595
--10320 10487 -13800 9412 -14480 8571 -13670 8702 -13770 9912 -14720 10359
--15200 10889 -15460 9762 -12100 10146 -9730 10888 -7740 11778 -10330 10941
--10290 9927 -9190 10140 -6350 9935 -10110 9608 -8260 10668 -5860 10370
--4910 8934 2310 9010 2560 8234 -300 7501 -3670 7096 -5640 6749 -8800 6223
--5900 7672 -4480 7311 -5820 8231 -15170 8528 -27330 14447 -12410 8601
--18290 4932 -17030 6901 -12490 10501 -19080 6359 -12320 4544 -9740 5939
--9560 7092 -11350 8234 -14450 9189 -15210 9779 -12900 9761 -11210 8984
--11360 8982 -14970 8858 -14070 8377 -14890 8831 -14060 9076 -13110 9560
--15590 9585 -15850 9100 -16010 9162 -13920 9936 -19670 8420 -17800 9607
--16940 10711 -17100 11413 -17680 12011 -17820 12655 -17340 13278 -16580 13803
--15960 14163 -15640 14327 -15570 14338 -15380 14272 -14890 14210 -14100 14226
--13100 14332 -11960 14455 -11190 14476 -11640 14225 -13670 13681 -16750 12984
--19340 12619 -21970 12078 -23360 11674 -23880 11502 -24360 11514 -25660 11570
--27580 11569 -29530 11542 -30900 11483 -31000 11353 -29220 11053 -25660 10565
--21750 10246 -20100 10790 -21400 12045 -23870 12844 -24790 11944 -24640 10594
--24330 9839 -24060 9887 -23770 10379 -23910 10862 -24760 11133 -26220 11205
--28020 11137 -29880 10969 -31600 10723 -33090 10416 -34310 10068 -35270 9704
--35980 9350 -36430 9010 -36490 8686 -36150 8382 -35410 8124 -34390 7945
--33190 7870 -31950 7895 -30700 7979 -29420 8050 -28090 8045 -26710 7931
--25300 7715 -23950 7432 -22760 7120 -21810 6814 -21210 6534 -21010 6283
--21100 6048 -21330 5815 -21570 5576 -21790 5337 -22040 5092 -22430 4813
--23020 4470 -23650 4053 -24130 3586 -24160 3117 -23610 2691 -25680 2118
--27310 1955 -28223 2038 -28126 2176 -26707 2203 -23777 2027 -19289 1668
--13477 1237 -6821 884 -75 737 5901 851 10251 1196 12412 1679 12259 2196
-10139 2663 6748 3046 2899 3342 -701 3574 -3590 3768 -5555 3947 -6596 4122
--6851 4303 -6522 4493 -5843 4689 -5005 4889 -4158 5093 -3404 5297 -2802 5503
--2377 5704 -2128 5901 -2030 6091 -2064 6277 -2209 6454 -2417 6626 -2676 6789
--2960 6946 -3269 7095 -3572 7237 -3875 7372 -4164 7500 -4447 7622 -4712 7738
--4961 7847 -5196 7951 -5412 8048 -5619 8142 -5807 8229 -5981 8313 -6146 8392
--6307 8465 -6446 8535 -6583 8601 -6712 8665 -6831 8726 -6940 8781 -7043 8833
--7146 8880 -7235 8926 -7324 8972 -7455 9019 -7512 9059 -7543 9096 -7583 9130
--7628 9164 -7675 9197 -7716 9225 -7758 9253 -7796 9281 -7833 9306 -7868 9331
--7896 9354 -7923 9375 -7949 9396 -7968 9415 -7991 9433 -8013 9452 -8024 9469
--8044 9485 -8060 9499 -8072 9514 -8085 9528 -8099 9541 -8107 9554 -8118 9565
--8127 9577 -8139 9588 -8144 9598 -8153 9609 -8165 9618 -8171 9628 -8179 9636
--8186 9645 -8196 9653 -8203 9661 -8210 9669 -8214 9676 -8220 9683 -8225 9689
--8239 9697 -8243 9703 -8251 9709 -8260 9715 -8266 9721 -8274 9726 -8278 9732
--8288 9737 -8292 9742 -8296 9747 -8310 9752 -8314 9757 -8323 9761 -8327 9766
--8337 9770 -8342 9774 -8347 9778 -8351 9782
-201: 14248770 -4690700 -10200 9903 -10210 9904 -10220 9906 -10230 9909
--10230 9914 -10240 9916 -10250 9918 -10260 9919 -10270 9927 -10280 9927
--10300 9934 -10310 9938 -10320 9942 -10340 9945 -10350 9949 -10370 9953
--10380 9956 -10390 9960 -10410 9964 -10420 9966 -10430 9968 -10450 9973
--10460 9978 -10470 9981 -10480 9984 -10480 9987 -10500 9989 -10500 9995
--10520 9994 -10530 9997 -10530 10000 -10540 10007 -10550 10007 -10560 10010
--10560 10011 -10570 10018 -10590 10020 -10600 10023 -10610 10030 -10620 10033
--10630 10038 -10650 10042 -10650 10050 -10670 10054 -10690 10060 -10710 10066
--10730 10072 -10740 10078 -10760 10085 -10790 10090 -10800 10096 -10830 10103
--10850 10109 -10880 10116 -10900 10124 -10920 10127 -10950 10133 -10960 10136
--10990 10142 -11010 10146 -11040 10150 -11070 10154 -11070 10156 -11090 10158
--11120 10160 -11120 10162 -11140 10163 -11160 10164 -11160 10165 -11180 10165
--11190 10165 -11190 10163 -11210 10164 -11210 10165 -11220 10165 -11210 10164
--11220 10164 -11220 10165 -11220 10166 -11230 10169 -11240 10171 -11240 10173
--11240 10177 -11250 10182 -11250 10186 -11260 10193 -11270 10201 -11280 10207
--11290 10216 -11300 10224 -11310 10232 -11330 10242 -11350 10252 -11380 10264
--11390 10276 -11430 10286 -11440 10300 -11460 10307 -11500 10318 -11520 10330
--11550 10339 -11590 10350 -11610 10356 -11640 10365 -11670 10372 -11700 10378
--11740 10384 -11750 10387 -11780 10390 -11810 10389 -11820 10389 -11850 10384
--11880 10380 -11880 10374 -11900 10366 -11910 10359 -11910 10349 -11910 10335
--11920 10322 -11920 10305 -11910 10293 -11900 10278 -11880 10259 -11870 10238
--11850 10218 -11830 10198 -11810 10180 -11790 10162 -11760 10143 -11730 10120
--11690 10103 -11660 10086 -11630 10069 -11600 10058 -11560 10043 -11530 10029
--11510 10016 -11460 10010 -11450 10006 -11420 10002 -11400 9998 -11370 10000
--11350 10003 -11340 10008 -11320 10018 -11320 10029 -11320 10042 -11320 10061
--11320 10079 -11330 10101 -11340 10123 -11360 10148 -11390 10177 -11420 10210
--11460 10243 -11490 10280 -11530 10314 -11580 10348 -11620 10387 -11690 10428
--11750 10471 -11810 10512 -11860 10551 -11920 10590 -11990 10632 -12060 10672
--12140 10712 -12200 10752 -12270 10788 -12320 10823 -12380 10854 -12440 10887
--12500 10919 -12560 10947 -12600 10971 -12620 10993 -12660 11011 -12680 11028
--12700 11040 -12720 11053 -12700 11059 -12670 11061 -12650 11063 -12600 11059
--12560 11051 -12490 11040 -12390 11030 -12290 11017 -12170 10998 -12020 10975
--11880 10948 -11710 10922 -11500 10897 -11290 10872 -11040 10843 -10790 10809
--10500 10774 -10200 10743 -9870 10716 -9530 10693 -9150 10665 -8760 10636
--8340 10610 -7900 10590 -7430 10578 -6970 10572 -6450 10567 -5920 10563
--5360 10567 -4800 10577 -4240 10595 -3670 10618 -3060 10648 -2440 10688
--1790 10732 -1170 10781 -530 10835 80 10894 710 10959 1350 11030 1980 11106
-2600 11186 3240 11276 3880 11369 4500 11463 5120 11559 5750 11662 6380 11778
-7030 11899 7680 12030 8360 12179 9060 12339 9770 12512 10460 12683 11130 12832
-11870 12997 12470 13248 13060 13477 13820 13632 14750 13751 15640 13884
-16290 14029 16610 14227 16700 14477 16820 14672 17110 14688 17570 14440
-18090 13914 18440 13206 18660 12478 18810 11884 18650 11449 18330 11094
-18170 10648 18020 10091 17340 9653 16210 9245 15380 8977 15310 9172 15580 9439
-15140 9140 13410 8509 10800 8445 8520 9292 7590 10414 8230 10960 9950 10725
-11710 10282 12410 10496 11460 11819 10360 13488 12770 13637 15110 13282
-15140 13113 13190 13140 9410 13051 3570 12682 -760 12143 -4070 11786 -6890 11444
--9360 10642 -11830 9741 -12940 9129 -13060 9223 -13360 9928 -13900 10427
--14010 10677 -13400 10309 -11220 10483 -9030 11005 -7320 11521 -7240 11316
--6580 10887 -4700 11202 -3440 11268 -9140 9412 -11680 9247 -6000 9938
--9050 7636 5180 9296 3440 8308 -1400 7635 -7230 7200 -8830 6454 -12600 6179
--3490 10465 740 8627 610 7602 -13560 11002 -21080 8464 -11900 12659 -25820 8091
--17080 6576 -16400 6025 -18070 4647 -14680 4459 -11940 5434 -10880 6556
--11540 7675 -13030 8630 -13520 9249 -12610 9396 -12020 9146 -12640 9064
--14450 8952 -14680 8797 -14920 9020 -14510 9285 -14300 9584 -15430 9620
--16040 9417 -16390 9433 -16390 9617 -18720 9185 -18560 9731 -18200 10537
--18240 11260 -18530 11920 -18630 12568 -18340 13193 -17780 13740 -17210 14144
--16820 14358 -16600 14399 -16400 14337 -16000 14251 -15370 14198 -14520 14196
--13660 14206 -13180 14150 -13530 13935 -14970 13524 -17300 12988 -19090 12696
--21070 12237 -22430 11830 -23240 11597 -24040 11538 -25200 11569 -26700 11593
--28160 11570 -29110 11476 -29090 11307 -27820 11065 -25550 10820 -23230 10784
--22080 11185 -22530 11858 -23750 12229 -24590 11842 -24930 11121 -25070 10592
--25130 10454 -25250 10595 -25570 10800 -26330 10932 -27490 10954 -28940 10875
--30460 10717 -31920 10499 -33190 10236 -34240 9942 -35070 9634 -35690 9327
--36080 9030 -36150 8742 -35890 8456 -35300 8186 -34430 7963 -33370 7821
--32250 7777 -31110 7808 -29930 7858 -28730 7865 -27490 7792 -26230 7632
--25010 7404 -23890 7132 -22960 6842 -22300 6551 -21960 6272 -21920 6001
--22030 5735 -22140 5474 -22240 5219 -22340 4965 -22550 4684 -22910 4354
--23340 3961 -23660 3525 -23610 3084 -23060 2677 -24190 2124 -25360 1907
--26170 1928 -26315 2055 -25484 2148 -23452 2110 -20177 1920 -15798 1635
--10669 1354 -5323 1177 -404 1170 3511 1338 5999 1644 6908 2024 6405 2417
-4882 2783 2826 3102 715 3378 -1122 3616 -2475 3834 -3306 4037 -3643 4236
--3603 4434 -3324 4632 -2921 4832 -2504 5033 -2125 5235 -1842 5436 -1680 5634
--1627 5829 -1678 6017 -1819 6201 -2025 6379 -2277 6550 -2562 6714 -2856 6872
--3167 7023 -3473 7166 -3764 7303 -4047 7434 -4323 7557 -4589 7676 -4830 7788
--5066 7893 -5279 7994 -5485 8090 -5676 8180 -5858 8265 -6019 8347 -6174 8422
--6325 8495 -6462 8563 -6599 8629 -6710 8690 -6835 8749 -6945 8802 -7049 8851
--7148 8898 -7234 8946 -7372 8995 -7431 9036 -7466 9074 -7507 9110 -7563 9144
--7610 9178 -7657 9208 -7702 9237 -7742 9264 -7785 9292 -7821 9317 -7856 9341
--7881 9363 -7915 9383 -7936 9404 -7960 9423 -7981 9441 -8002 9460 -8019 9475
--8037 9490 -8056 9505 -8065 9520 -8081 9534 -8092 9546 -8105 9558 -8117 9570
--8128 9582 -8138 9592 -8151 9602 -8157 9613 -8166 9622 -8175 9631 -8181 9639
--8191 9648 -8200 9656 -8209 9664 -8214 9672 -8219 9678 -8230 9686 -8240 9692
--8244 9699 -8253 9705 -8263 9711 -8267 9717 -8276 9723 -8283 9728 -8291 9734
--8297 9739 -8303 9744 -8308 9749 -8320 9753 -8327 9758 -8330 9763 -8341 9766
--8343 9772 -8353 9775 -8358 9779
-202: 14281760 -4682197 -10220 9904 -10210 9907 -10230 9909 -10230 9911
--10240 9915 -10240 9918 -10250 9921 -10270 9922 -10280 9926 -10280 9930
--10310 9935 -10310 9938 -10320 9942 -10340 9946 -10360 9950 -10370 9954
--10390 9957 -10400 9960 -10400 9963 -10430 9967 -10430 9970 -10450 9973
--10460 9978 -10470 9979 -10480 9986 -10490 9987 -10490 9990 -10510 9993
--10520 9994 -10520 9998 -10540 9999 -10540 10005 -10550 10006 -10560 10010
--10570 10013 -10570 10015 -10580 10019 -10600 10024 -10610 10028 -10620 10032
--10640 10038 -10640 10042 -10650 10048 -10670 10053 -10690 10058 -10700 10065
--10720 10069 -10740 10079 -10760 10084 -10780 10088 -10800 10094 -10820 10101
--10850 10107 -10870 10113 -10890 10121 -10920 10124 -10930 10131 -10970 10134
--10970 10136 -11010 10142 -11030 10148 -11050 10151 -11060 10153 -11080 10154
--11100 10156 -11110 10160 -11130 10160 -11150 10160 -11150 10160 -11160 10161
--11180 10161 -11180 10160 -11190 10161 -11200 10161 -11200 10161 -11200 10159
--11200 10160 -11210 10162 -11200 10163 -11220 10166 -11220 10166 -11230 10170
--11230 10174 -11230 10178 -11230 10182 -11250 10190 -11250 10196 -11260 10203
--11270 10212 -11290 10220 -11290 10228 -11320 10238 -11330 10247 -11350 10259
--11380 10271 -11400 10283 -11420 10294 -11450 10302 -11460 10313 -11500 10324
--11530 10334 -11560 10344 -11580 10351 -11620 10358 -11640 10366 -11670 10372
--11700 10378 -11730 10381 -11750 10384 -11770 10385 -11790 10382 -11820 10380
--11840 10375 -11850 10370 -11860 10361 -11880 10354 -11880 10344 -11880 10331
--11880 10319 -11890 10302 -11880 10290 -11870 10273 -11850 10257 -11840 10237
--11810 10215 -11810 10198 -11780 10180 -11750 10161 -11740 10143 -11700 10119
--11660 10102 -11640 10085 -11600 10068 -11580 10057 -11550 10043 -11500 10029
--11480 10017 -11450 10010 -11420 10003 -11400 10000 -11380 9996 -11340 9998
--11330 10000 -11310 10004 -11310 10012 -11290 10023 -11290 10035 -11290 10053
--11290 10069 -11300 10088 -11320 10110 -11320 10135 -11350 10162 -11390 10192
--11420 10225 -11440 10257 -11480 10290 -11530 10323 -11580 10360 -11630 10399
--11690 10439 -11750 10479 -11810 10515 -11850 10552 -11920 10592 -12000 10630
--12060 10668 -12120 10706 -12190 10741 -12240 10771 -12300 10804 -12350 10834
--12420 10865 -12470 10891 -12510 10914 -12540 10936 -12560 10953 -12580 10968
--12600 10979 -12620 10992 -12600 10999 -12580 11002 -12540 11004 -12510 11000
--12450 10993 -12390 10985 -12300 10974 -12190 10965 -12070 10946 -11940 10926
--11780 10904 -11610 10879 -11420 10859 -11190 10836 -10950 10811 -10710 10782
--10420 10752 -10120 10725 -9810 10702 -9450 10683 -9100 10661 -8700 10638
--8280 10617 -7850 10602 -7400 10595 -6930 10592 -6420 10593 -5900 10595
--5360 10600 -4790 10617 -4240 10638 -3670 10664 -3080 10700 -2460 10739
--1830 10787 -1200 10838 -590 10895 40 10957 670 11023 1310 11098 1940 11176
-2570 11259 3220 11350 3870 11444 4490 11542 5130 11642 5760 11751 6420 11867
-7080 11989 7730 12116 8410 12266 9130 12424 9830 12593 10540 12757 11200 12899
-11960 13048 12570 13273 13140 13483 13800 13634 14640 13755 15520 13865
-16310 13956 16810 14075 17090 14252 17240 14419 17430 14466 17710 14289
-18030 13848 18230 13197 18440 12486 18610 11870 18510 11423 18260 11118
-18190 10787 18170 10397 17620 10087 16590 9701 15720 9368 15510 9450 15690 9689
-15410 9515 14050 8990 11890 8803 9810 9342 8660 10241 8610 10874 9290 11003
-10030 10931 10330 11146 10160 11850 10350 12665 11950 12954 13610 12942
-14040 12929 12870 12954 10070 12869 5930 12590 1890 12201 -1710 11834
--4870 11400 -7590 10728 -9790 10012 -11100 9560 -11710 9598 -12170 10015
--12520 10407 -12470 10613 -11790 10568 -10270 10707 -8500 11030 -6810 11332
--5590 11386 -4150 11422 -2470 11754 -1860 11857 -4010 10815 -2680 9487
--4390 9540 -11220 7365 -570 7962 390 7023 -2170 7810 -7690 8165 -12170 8284
--16510 8402 -23470 9220 19910 5290 20550 4840 -16790 11129 -22240 10236
--19030 11586 -23760 9145 -19930 7088 -18530 5714 -18010 4838 -15790 4835
--13500 5503 -12180 6396 -12000 7329 -12460 8157 -12690 8755 -12470 9046
--12460 9088 -13100 9086 -14190 9045 -14700 9017 -14950 9147 -14910 9350
--15030 9551 -15650 9631 -16270 9618 -16800 9671 -17360 9758 -18480 9728
--18770 10075 -18750 10645 -18840 11266 -19070 11880 -19190 12493 -19030 13086
--18620 13626 -18140 14049 -17730 14302 -17500 14385 -17310 14354 -17020 14273
--16570 14186 -15950 14116 -15330 14046 -15000 13936 -15240 13733 -16210 13403
--17880 12986 -19220 12723 -20710 12325 -21880 11941 -22740 11684 -23580 11583
--24610 11586 -25810 11607 -26920 11580 -27630 11481 -27640 11318 -26840 11132
--25450 11005 -24010 11055 -23230 11341 -23320 11738 -23970 11952 -24650 11790
--25160 11401 -25590 11041 -25920 10849 -26300 10811 -26770 10837 -27500 10845
--28490 10802 -29680 10694 -30970 10530 -32220 10325 -33280 10087 -34180 9831
--34890 9561 -35420 9291 -35720 9030 -35810 8775 -35600 8514 -35100 8253
--34340 8011 -33420 7825 -32390 7722 -31350 7694 -30280 7701 -29190 7693
--28090 7632 -26960 7506 -25870 7317 -24830 7083 -23910 6815 -23230 6533
--22820 6244 -22660 5958 -22660 5673 -22690 5398 -22670 5131 -22650 4868
--22690 4590 -22880 4273 -23120 3906 -23310 3503 -23180 3092 -22630 2710
--22890 2204 -23570 1944 -24200 1894 -24480 1974 -24050 2081 -22711 2126
--20394 2064 -17152 1910 -13237 1721 -9026 1570 -4956 1514 -1474 1582 1111 1764
-2641 2029 3153 2337 2865 2651 2071 2954 1047 3232 45 3487 -771 3724 -1338 3945
--1643 4158 -1721 4367 -1671 4571 -1541 4774 -1394 4976 -1273 5177 -1211 5377
--1231 5573 -1312 5766 -1464 5955 -1683 6136 -1933 6314 -2208 6484 -2506 6650
--2803 6808 -3102 6959 -3408 7104 -3693 7243 -3965 7374 -4235 7501 -4489 7620
--4728 7734 -4959 7842 -5173 7945 -5374 8041 -5563 8135 -5741 8222 -5909 8305
--6071 8383 -6217 8457 -6355 8528 -6493 8595 -6612 8658 -6736 8719 -6854 8772
--6963 8824 -7066 8872 -7160 8921 -7295 8972 -7355 9015 -7396 9052 -7444 9090
--7497 9127 -7551 9160 -7602 9191 -7651 9221 -7695 9250 -7738 9277 -7782 9304
--7814 9328 -7845 9351 -7881 9372 -7905 9392 -7932 9413 -7956 9432 -7974 9450
--7997 9466 -8016 9482 -8036 9497 -8050 9511 -8065 9526 -8080 9539 -8097 9552
--8106 9563 -8118 9575 -8129 9586 -8144 9597 -8152 9607 -8162 9616 -8172 9626
--8180 9634 -8186 9643 -8194 9651 -8209 9660 -8218 9667 -8220 9674 -8230 9681
--8241 9688 -8248 9695 -8254 9702 -8264 9707 -8275 9713 -8279 9720 -8286 9724
--8296 9731 -8299 9735 -8304 9741 -8316 9745 -8321 9751 -8332 9755 -8332 9759
--8344 9764 -8347 9768 -8357 9772 -8362 9776
-203: 14314760 -4673701 -10220 9906 -10220 9908 -10230 9910 -10230 9915
--10250 9916 -10250 9920 -10260 9922 -10260 9924 -10290 9928 -10290 9933
--10310 9935 -10310 9938 -10330 9944 -10340 9947 -10360 9949 -10370 9955
--10390 9958 -10400 9961 -10420 9963 -10420 9968 -10430 9972 -10450 9972
--10460 9977 -10470 9980 -10490 9984 -10490 9987 -10500 9990 -10510 9992
--10510 9995 -10530 9998 -10530 10000 -10550 10004 -10550 10006 -10560 10009
--10560 10012 -10580 10016 -10580 10018 -10600 10022 -10610 10028 -10620 10031
--10630 10037 -10650 10042 -10650 10046 -10660 10052 -10690 10057 -10700 10063
--10720 10071 -10740 10075 -10750 10081 -10780 10086 -10790 10091 -10820 10100
--10840 10105 -10860 10112 -10880 10118 -10910 10122 -10930 10128 -10950 10131
--10970 10134 -10990 10139 -11020 10144 -11040 10148 -11060 10150 -11070 10149
--11080 10153 -11100 10156 -11120 10157 -11130 10157 -11140 10156 -11150 10156
--11160 10157 -11170 10157 -11170 10157 -11190 10157 -11180 10157 -11190 10156
--11190 10157 -11190 10157 -11190 10161 -11200 10160 -11210 10163 -11210 10167
--11210 10170 -11220 10174 -11220 10180 -11230 10185 -11240 10192 -11250 10198
--11250 10208 -11260 10217 -11280 10224 -11300 10234 -11310 10241 -11340 10254
--11350 10267 -11380 10278 -11400 10287 -11420 10297 -11440 10308 -11480 10319
--11510 10328 -11530 10339 -11560 10345 -11580 10352 -11620 10360 -11640 10367
--11670 10373 -11700 10376 -11720 10378 -11740 10377 -11760 10377 -11780 10375
--11800 10370 -11820 10366 -11830 10357 -11840 10350 -11850 10339 -11850 10327
--11850 10315 -11860 10299 -11840 10286 -11840 10271 -11820 10255 -11810 10235
--11790 10214 -11770 10197 -11750 10178 -11730 10160 -11710 10142 -11670 10121
--11640 10102 -11610 10084 -11580 10069 -11550 10056 -11520 10044 -11490 10030
--11460 10017 -11420 10008 -11400 10003 -11380 9999 -11350 9995 -11320 9995
--11310 9999 -11290 10001 -11280 10006 -11270 10016 -11260 10028 -11260 10044
--11260 10062 -11280 10079 -11280 10097 -11290 10121 -11320 10146 -11340 10175
--11380 10205 -11400 10238 -11440 10268 -11470 10298 -11540 10333 -11570 10371
--11640 10410 -11680 10447 -11750 10480 -11790 10515 -11860 10553 -11920 10590
--11990 10626 -12050 10661 -12110 10694 -12160 10723 -12220 10753 -12280 10785
--12330 10813 -12380 10836 -12420 10860 -12440 10879 -12480 10897 -12490 10911
--12510 10922 -12520 10932 -12510 10941 -12480 10944 -12460 10946 -12410 10943
--12360 10938 -12300 10930 -12200 10922 -12100 10913 -11980 10897 -11850 10879
--11700 10858 -11530 10839 -11330 10821 -11110 10802 -10880 10778 -10640 10755
--10360 10729 -10060 10705 -9740 10687 -9410 10672 -9040 10655 -8660 10636
--8250 10621 -7810 10611 -7380 10608 -6910 10609 -6420 10613 -5900 10620
--5360 10632 -4820 10650 -4270 10674 -3700 10704 -3110 10742 -2500 10785
--1890 10833 -1270 10889 -640 10946 -30 11011 600 11080 1250 11155 1870 11235
-2510 11321 3160 11413 3820 11508 4450 11609 5090 11712 5750 11822 6410 11941
-7060 12059 7730 12187 8430 12332 9130 12488 9840 12653 10550 12811 11220 12943
-11990 13085 12620 13282 13190 13472 13770 13615 14510 13734 15330 13834
-16140 13890 16790 13950 17210 14054 17470 14170 17650 14216 17860 14091
-18060 13739 18170 13185 18330 12536 18460 11934 18360 11467 18140 11163
-18120 10873 18160 10586 17760 10375 16870 10048 15980 9707 15620 9711
-15700 9928 15520 9876 14530 9488 12840 9235 11050 9512 9810 10172 9280 10790
-9240 11126 9290 11282 9210 11508 9130 11914 9490 12355 10600 12595 11890 12675
-12510 12723 11980 12757 10120 12689 7160 12472 3730 12163 280 11820 -2920 11388
--5680 10812 -7820 10229 -9230 9870 -10080 9862 -10660 10114 -10980 10406
--10950 10596 -10420 10662 -9380 10782 -8000 10967 -6430 11132 -4780 11254
--3000 11474 -1380 11827 -630 12089 -1320 11487 -1730 10450 -5570 9318
--15830 4192 -4730 6968 2750 4124 -1550 9907 -7210 10054 -12120 9593 -15220 9019
--13570 8147 10390 5734 11940 5742 -8920 9130 -17710 9866 -19560 10324
--21620 9093 -20350 7573 -19120 6365 -18010 5666 -16260 5574 -14420 5947
--13120 6551 -12510 7233 -12410 7890 -12440 8425 -12450 8782 -12680 8972
--13280 9065 -14060 9097 -14630 9122 -14980 9215 -15200 9361 -15470 9516
--15940 9636 -16500 9740 -17090 9867 -17720 10001 -18410 10128 -18780 10412
--18940 10843 -19090 11352 -19330 11888 -19490 12435 -19440 12977 -19170 13484
--18790 13903 -18430 14178 -18200 14303 -18040 14314 -17870 14260 -17580 14174
--17200 14072 -16790 13954 -16580 13808 -16710 13605 -17350 13324 -18490 12990
--19620 12739 -20740 12389 -21700 12035 -22450 11772 -23210 11646 -24090 11620
--25030 11626 -25910 11596 -26490 11503 -26590 11357 -26140 11209 -25310 11130
--24440 11184 -23900 11385 -23890 11641 -24260 11793 -24810 11738 -25370 11526
--25940 11280 -26470 11090 -27010 10972 -27600 10895 -28310 10818 -29200 10716
--30230 10577 -31350 10400 -32430 10196 -33360 9973 -34120 9737 -34720 9493
--35150 9250 -35400 9014 -35460 8786 -35290 8552 -34860 8308 -34200 8067
--33370 7860 -32430 7712 -31480 7630 -30500 7589 -29510 7551 -28510 7482
--27520 7367 -26520 7204 -25580 6998 -24690 6755 -24000 6487 -23540 6205
--23300 5915 -23220 5626 -23170 5342 -23070 5068 -22930 4802 -22860 4527
--22890 4224 -22980 3883 -23040 3512 -22850 3133 -22290 2777 -21820 2339
--22010 2054 -22420 1936 -22700 1953 -22520 2038 -21700 2115 -20090 2134
--17727 2083 -14768 1984 -11456 1884 -8119 1830 -5067 1852 -2556 1959 -726 2139
-385 2370 873 2629 913 2894 664 3155 286 3406 -91 3644 -389 3874 -592 4093
--694 4308 -740 4518 -755 4724 -770 4927 -799 5128 -881 5328 -1006 5524
--1169 5715 -1391 5901 -1646 6083 -1916 6260 -2209 6430 -2501 6595 -2792 6753
--3086 6905 -3374 7051 -3648 7189 -3918 7323 -4177 7450 -4422 7572 -4649 7686
--4878 7796 -5084 7900 -5285 8000 -5470 8093 -5650 8183 -5815 8268 -5978 8347
--6127 8422 -6262 8495 -6399 8564 -6528 8629 -6650 8690 -6775 8746 -6889 8798
--6996 8847 -7091 8899 -7219 8950 -7288 8993 -7335 9034 -7381 9071 -7440 9109
--7499 9144 -7552 9175 -7602 9206 -7651 9236 -7698 9263 -7742 9291 -7782 9316
--7809 9339 -7847 9361 -7879 9383 -7907 9402 -7933 9423 -7953 9440 -7972 9458
--7999 9473 -8015 9489 -8038 9504 -8053 9519 -8070 9532 -8082 9545 -8096 9557
--8112 9569 -8122 9580 -8135 9590 -8148 9602 -8160 9611 -8168 9620 -8178 9629
--8184 9639 -8196 9646 -8205 9655 -8217 9663 -8223 9670 -8232 9677 -8243 9684
--8249 9691 -8257 9698 -8265 9704 -8276 9709 -8285 9716 -8291 9721 -8298 9727
--8301 9732 -8310 9738 -8319 9742 -8323 9748 -8336 9751 -8343 9757 -8345 9761
--8352 9765 -8360 9769 -8364 9773
-204: 14347790 -4665212 -10220 9909 -10230 9908 -10230 9912 -10240 9917
--10250 9917 -10260 9922 -10260 9924 -10270 9927 -10290 9929 -10300 9934
--10310 9935 -10320 9940 -10330 9944 -10350 9948 -10360 9952 -10370 9955
--10390 9959 -10400 9960 -10420 9966 -10420 9967 -10440 9970 -10450 9974
--10460 9978 -10470 9980 -10480 9983 -10500 9987 -10500 9989 -10510 9991
--10510 9995 -10530 9997 -10540 9999 -10550 10005 -10540 10006 -10560 10008
--10570 10011 -10570 10015 -10590 10020 -10590 10021 -10610 10026 -10620 10030
--10630 10037 -10640 10041 -10660 10044 -10660 10051 -10690 10056 -10700 10063
--10710 10068 -10730 10075 -10760 10079 -10770 10083 -10790 10091 -10810 10098
--10830 10103 -10860 10109 -10870 10116 -10900 10120 -10920 10122 -10940 10129
--10960 10133 -10990 10136 -11010 10141 -11020 10144 -11040 10146 -11060 10147
--11070 10149 -11090 10152 -11110 10153 -11110 10153 -11130 10153 -11140 10153
--11140 10154 -11160 10153 -11160 10152 -11170 10152 -11170 10155 -11180 10152
--11170 10153 -11180 10154 -11180 10156 -11190 10158 -11190 10160 -11190 10164
--11200 10165 -11200 10171 -11210 10174 -11210 10181 -11230 10189 -11230 10195
--11240 10203 -11240 10213 -11260 10220 -11290 10227 -11290 10238 -11310 10249
--11340 10261 -11360 10272 -11370 10282 -11400 10293 -11420 10302 -11450 10313
--11490 10323 -11510 10333 -11530 10340 -11550 10348 -11590 10353 -11620 10360
--11640 10368 -11660 10371 -11690 10371 -11710 10373 -11730 10371 -11750 10368
--11770 10365 -11790 10361 -11800 10353 -11810 10345 -11810 10337 -11820 10324
--11820 10311 -11810 10295 -11810 10283 -11820 10269 -11790 10252 -11780 10233
--11760 10214 -11740 10195 -11710 10178 -11710 10160 -11680 10142 -11650 10122
--11610 10102 -11590 10084 -11550 10070 -11540 10057 -11490 10044 -11470 10030
--11430 10018 -11400 10009 -11370 10002 -11360 9999 -11320 9993 -11310 9993
--11280 9996 -11270 9998 -11250 10003 -11240 10013 -11240 10022 -11230 10035
--11240 10052 -11240 10069 -11250 10086 -11260 10107 -11280 10132 -11300 10158
--11330 10188 -11370 10217 -11390 10248 -11430 10274 -11470 10308 -11530 10344
--11580 10381 -11630 10416 -11680 10446 -11740 10481 -11790 10517 -11850 10549
--11920 10584 -11980 10619 -12030 10648 -12080 10678 -12140 10706 -12200 10735
--12250 10762 -12300 10786 -12330 10805 -12360 10826 -12380 10840 -12410 10856
--12420 10867 -12440 10877 -12410 10884 -12400 10888 -12360 10890 -12320 10888
--12280 10884 -12210 10877 -12120 10870 -12020 10864 -11890 10849 -11780 10832
--11620 10815 -11450 10798 -11260 10784 -11050 10768 -10820 10747 -10570 10726
--10310 10705 -10010 10685 -9700 10671 -9360 10661 -9010 10646 -8630 10632
--8230 10621 -7810 10617 -7370 10617 -6920 10622 -6420 10630 -5920 10640
--5390 10656 -4850 10677 -4320 10705 -3750 10738 -3170 10779 -2570 10823
--1970 10873 -1340 10929 -730 10991 -110 11056 510 11127 1150 11204 1780 11286
-2430 11372 3070 11465 3730 11562 4370 11662 5020 11767 5690 11881 6350 11998
-7010 12115 7690 12240 8380 12381 9080 12534 9800 12691 10510 12845 11180 12967
-11940 13104 12620 13278 13180 13448 13750 13575 14370 13691 15110 13783
-15890 13827 16580 13847 17120 13893 17480 13957 17730 13977 17930 13876
-18080 13595 18140 13141 18260 12583 18350 12027 18240 11566 18010 11250
-17980 10964 18060 10726 17800 10577 17050 10320 16180 9999 15690 9941
-15640 10124 15500 10175 14810 9932 13540 9684 12100 9775 10920 10213 10160 10748
-9680 11164 9280 11450 8860 11706 8580 11991 8680 12259 9380 12425 10330 12501
-10970 12556 10840 12590 9680 12536 7570 12353 4770 12089 1690 11777 -1340 11384
--3990 10889 -6080 10405 -7500 10100 -8470 10060 -9100 10213 -9480 10427
--9530 10587 -9210 10678 -8550 10772 -7530 10861 -6180 10916 -4510 11002
--2700 11237 -1130 11572 -390 11951 -990 11511 -2540 10405 -6270 8594 -11040 5511
--5810 5941 -1050 5500 -2890 8772 -6940 9786 -10540 9677 -11820 9013 -8390 7917
-2630 6518 3700 6498 -6290 8070 -13670 8942 -17240 9263 -19170 8719 -19190 7833
--18540 7025 -17560 6512 -16230 6365 -14820 6527 -13670 6883 -12950 7334
--12620 7817 -12490 8261 -12560 8621 -12850 8875 -13380 9033 -14030 9118
--14590 9173 -15040 9250 -15400 9361 -15750 9492 -16180 9638 -16690 9811
--17270 10007 -17850 10206 -18390 10409 -18730 10675 -18950 11031 -19160 11454
--19400 11917 -19600 12394 -19640 12876 -19510 13337 -19230 13731 -18930 14010
--18710 14165 -18590 14219 -18500 14203 -18370 14138 -18180 14035 -17970 13897
--17860 13731 -17930 13526 -18340 13276 -19130 12997 -20120 12760 -21020 12451
--21750 12127 -22380 11868 -23010 11721 -23700 11670 -24460 11657 -25150 11623
--25650 11538 -25830 11410 -25640 11283 -25180 11214 -24670 11245 -24320 11378
--24290 11552 -24530 11669 -25000 11665 -25550 11548 -26190 11378 -26830 11210
--27450 11064 -28120 10936 -28830 10808 -29660 10667 -30590 10502 -31590 10313
--32540 10106 -33360 9888 -34030 9665 -34530 9436 -34890 9209 -35100 8990
--35120 8781 -34980 8570 -34600 8347 -34010 8118 -33260 7903 -32410 7730
--31520 7607 -30610 7522 -29720 7447 -28810 7358 -27910 7241 -27020 7090
--26140 6902 -25310 6680 -24620 6429 -24120 6158 -23840 5876 -23700 5589
--23560 5305 -23400 5030 -23180 4762 -23000 4492 -22920 4202 -22890 3886
--22850 3546 -22570 3198 -22000 2869 -20970 2505 -20740 2216 -20900 2046
--21080 2000 -21030 2039 -20520 2113 -19440 2171 -17730 2187 -15500 2162
--12920 2119 -10200 2091 -7570 2104 -5241 2174 -3340 2300 -1924 2476 -982 2682
--420 2909 -159 3142 -81 3377 -112 3607 -182 3834 -253 4054 -319 4269 -374 4481
--448 4687 -540 4892 -653 5092 -794 5291 -971 5485 -1186 5676 -1432 5861
--1698 6040 -1972 6216 -2265 6386 -2540 6551 -2825 6708 -3106 6859 -3374 7006
--3638 7145 -3900 7279 -4143 7406 -4381 7529 -4601 7645 -4814 7756 -5020 7861
--5212 7961 -5399 8057 -5577 8148 -5740 8234 -5898 8315 -6046 8391 -6184 8465
--6326 8535 -6448 8602 -6583 8665 -6707 8721 -6826 8774 -6934 8825 -7033 8877
--7153 8929 -7224 8975 -7276 9015 -7327 9054 -7389 9093 -7452 9127 -7504 9161
--7561 9192 -7612 9222 -7659 9251 -7706 9279 -7752 9304 -7782 9329 -7815 9350
--7852 9372 -7884 9393 -7911 9414 -7931 9432 -7958 9449 -7982 9465 -8001 9482
--8024 9496 -8045 9512 -8055 9526 -8073 9538 -8087 9551 -8105 9562 -8116 9574
--8129 9586 -8141 9596 -8155 9605 -8165 9616 -8177 9624 -8187 9634 -8194 9642
--8206 9650 -8216 9658 -8223 9666 -8233 9673 -8244 9681 -8253 9687 -8261 9694
--8267 9700 -8280 9706 -8285 9712 -8297 9718 -8298 9724 -8306 9729 -8313 9734
--8326 9739 -8325 9744 -8343 9749 -8349 9754 -8351 9758 -8356 9762 -8364 9766
--8367 9770
-205: 14380840 -4656729 -10220 9910 -10230 9910 -10240 9914 -10250 9918
--10250 9918 -10270 9924 -10270 9925 -10270 9929 -10290 9930 -10300 9935
--10320 9939 -10330 9941 -10330 9944 -10340 9947 -10370 9952 -10370 9956
--10390 9960 -10410 9963 -10410 9965 -10430 9966 -10430 9970 -10460 9976
--10460 9978 -10470 9982 -10480 9984 -10490 9985 -10510 9987 -10510 9993
--10520 9994 -10520 9996 -10540 9998 -10540 10003 -10560 10006 -10550 10008
--10570 10010 -10580 10016 -10580 10019 -10600 10021 -10610 10025 -10610 10030
--10630 10036 -10640 10040 -10650 10044 -10670 10048 -10680 10056 -10690 10061
--10710 10067 -10730 10072 -10760 10079 -10770 10082 -10780 10087 -10810 10097
--10820 10101 -10850 10107 -10870 10113 -10890 10116 -10910 10120 -10930 10126
--10950 10131 -10980 10135 -11000 10136 -11010 10141 -11030 10143 -11050 10145
--11060 10146 -11070 10146 -11090 10148 -11100 10151 -11120 10150 -11130 10150
--11130 10148 -11140 10150 -11150 10149 -11150 10149 -11160 10151 -11160 10148
--11170 10150 -11160 10150 -11160 10152 -11180 10154 -11170 10157 -11180 10159
--11180 10163 -11190 10166 -11190 10171 -11210 10177 -11210 10185 -11210 10191
--11220 10199 -11230 10208 -11250 10213 -11270 10223 -11270 10234 -11290 10244
--11320 10256 -11330 10267 -11350 10278 -11380 10287 -11400 10295 -11430 10307
--11460 10318 -11480 10328 -11510 10334 -11530 10342 -11560 10349 -11580 10354
--11620 10362 -11630 10364 -11660 10365 -11680 10367 -11700 10367 -11720 10363
--11740 10360 -11750 10355 -11770 10349 -11770 10341 -11780 10333 -11790 10321
--11790 10307 -11780 10293 -11780 10281 -11780 10266 -11770 10248 -11740 10233
--11730 10212 -11710 10194 -11700 10178 -11670 10161 -11650 10142 -11630 10121
--11590 10103 -11560 10086 -11530 10071 -11510 10057 -11470 10044 -11440 10031
--11410 10021 -11380 10009 -11350 10003 -11330 9997 -11300 9993 -11280 9992
--11260 9992 -11250 9997 -11220 10000 -11220 10008 -11210 10015 -11210 10028
--11200 10045 -11210 10058 -11220 10076 -11220 10095 -11240 10120 -11270 10144
--11300 10169 -11320 10198 -11340 10227 -11380 10253 -11430 10284 -11470 10318
--11530 10352 -11570 10385 -11620 10416 -11670 10447 -11730 10480 -11780 10512
--11850 10545 -11920 10578 -11950 10604 -12010 10634 -12060 10660 -12120 10687
--12170 10712 -12220 10735 -12240 10755 -12280 10773 -12290 10787 -12330 10802
--12340 10814 -12350 10823 -12330 10829 -12310 10835 -12270 10835 -12250 10835
--12200 10832 -12130 10826 -12040 10821 -11930 10814 -11830 10802 -11690 10788
--11550 10773 -11390 10759 -11210 10746 -10990 10734 -10760 10715 -10520 10698
--10270 10680 -9970 10665 -9670 10654 -9340 10646 -8990 10636 -8620 10626
--8220 10620 -7810 10618 -7380 10621 -6940 10632 -6450 10642 -5960 10657
--5440 10675 -4910 10700 -4370 10730 -3820 10765 -3250 10808 -2660 10855
--2060 10907 -1450 10964 -830 11026 -230 11095 400 11165 1040 11245 1670 11327
-2310 11414 2960 11507 3610 11604 4260 11705 4910 11811 5580 11924 6260 12041
-6920 12157 7600 12277 8290 12415 8990 12562 9710 12713 10410 12858 11070 12973
-11830 13103 12530 13262 13130 13411 13670 13523 14250 13627 14900 13714
-15610 13752 16290 13754 16870 13764 17310 13783 17630 13773 17870 13673
-18030 13437 18070 13065 18170 12602 18260 12117 18120 11686 17890 11371
-17810 11080 17900 10855 17740 10736 17130 10541 16320 10258 15770 10151
-15540 10285 15400 10396 14900 10288 13970 10094 12870 10083 11860 10346
-11040 10766 10370 11178 9730 11517 9060 11798 8510 12041 8290 12235 8560 12346
-9150 12394 9670 12432 9690 12459 8990 12413 7440 12251 5200 12013 2550 11727
--190 11379 -2650 10957 -4610 10549 -6010 10283 -7000 10219 -7690 10309
--8100 10460 -8240 10584 -8110 10664 -7740 10732 -7070 10755 -5990 10720
--4510 10731 -2860 10895 -1430 11165 -780 11573 -1400 11242 -2980 10233
--5560 8604 -7630 6684 -5650 6254 -3520 6388 -4390 8052 -6870 9056 -9070 9233
--9440 8787 -6860 7941 -1950 7072 -1450 6939 -6280 7609 -11320 8208 -14740 8489
--16730 8322 -17410 7905 -17280 7466 -16700 7148 -15810 7020 -14810 7072
--13920 7260 -13260 7539 -12870 7874 -12710 8225 -12740 8550 -13020 8819
--13500 9009 -14060 9129 -14620 9204 -15110 9276 -15540 9369 -15950 9485
--16370 9641 -16840 9849 -17380 10092 -17920 10342 -18360 10587 -18700 10853
--18910 11170 -19130 11538 -19370 11941 -19600 12362 -19720 12785 -19690 13194
--19510 13554 -19280 13821 -19080 13990 -18970 14077 -18950 14101 -18940 14067
--18890 13981 -18840 13847 -18830 13674 -18900 13470 -19170 13241 -19730 13001
--20630 12788 -21350 12515 -21950 12219 -22440 11967 -22940 11806 -23480 11730
--24070 11698 -24620 11659 -25060 11580 -25290 11468 -25270 11352 -25070 11276
--24800 11277 -24610 11354 -24590 11469 -24780 11556 -25180 11572 -25710 11506
--26350 11385 -27030 11241 -27720 11093 -28410 10947 -29130 10795 -29910 10632
--30770 10452 -31670 10254 -32540 10044 -33280 9828 -33890 9612 -34320 9392
--34620 9175 -34770 8966 -34780 8767 -34650 8573 -34320 8369 -33800 8156
--33110 7946 -32320 7761 -31500 7611 -30670 7491 -29830 7382 -29000 7270
--28180 7141 -27370 6990 -26550 6813 -25790 6605 -25100 6371 -24590 6114
--24260 5842 -24060 5563 -23880 5284 -23650 5013 -23380 4746 -23120 4482
--22950 4205 -22830 3910 -22670 3599 -22340 3282 -21740 2978 -20350 2684
--19760 2407 -19650 2207 -19710 2107 -19660 2097 -19340 2144 -18570 2208
--17350 2259 -15680 2284 -13660 2291 -11470 2295 -9230 2320 -7160 2378
--5310 2478 -3800 2615 -2630 2784 -1780 2976 -1200 3181 -810 3395 -590 3612
--460 3828 -420 4043 -400 4256 -440 4463 -500 4670 -610 4871 -750 5071 -910 5267
--1100 5460 -1320 5648 -1560 5831 -1830 6010 -2090 6184 -2360 6352 -2631 6515
--2895 6672 -3155 6823 -3409 6969 -3656 7108 -3904 7242 -4131 7370 -4363 7493
--4571 7610 -4777 7721 -4981 7827 -5162 7929 -5346 8025 -5516 8117 -5676 8204
--5835 8285 -5980 8364 -6122 8438 -6265 8510 -6388 8577 -6529 8641 -6650 8699
--6769 8752 -6877 8805 -6983 8857 -7097 8911 -7167 8957 -7222 8998 -7285 9038
--7346 9077 -7410 9114 -7463 9146 -7521 9179 -7575 9209 -7629 9239 -7676 9268
--7719 9293 -7754 9318 -7792 9340 -7828 9363 -7859 9384 -7890 9405 -7914 9423
--7944 9442 -7970 9457 -7983 9474 -8012 9490 -8030 9505 -8049 9519 -8066 9532
--8083 9545 -8095 9557 -8110 9568 -8124 9580 -8141 9591 -8153 9600 -8162 9611
--8171 9620 -8184 9628 -8198 9638 -8209 9646 -8212 9654 -8228 9662 -8232 9669
--8245 9677 -8256 9683 -8265 9690 -8272 9697 -8283 9703 -8287 9708 -8301 9715
--8300 9720 -8314 9726 -8315 9731 -8331 9736 -8335 9741 -8343 9746 -8353 9751
--8355 9755 -8362 9759 -8367 9763 -8371 9768
-206: 14413920 -4648255 -10230 9912 -10240 9912 -10240 9915 -10250 9920
--10260 9921 -10270 9924 -10270 9927 -10280 9930 -10290 9933 -10310 9936
--10320 9940 -10330 9943 -10340 9945 -10340 9950 -10370 9951 -10380 9956
--10390 9960 -10400 9961 -10420 9966 -10420 9967 -10440 9970 -10450 9975
--10460 9980 -10480 9981 -10480 9983 -10490 9986 -10510 9989 -10510 9992
--10520 9994 -10530 9995 -10530 9998 -10550 10002 -10550 10006 -10560 10007
--10570 10010 -10570 10014 -10590 10017 -10590 10022 -10600 10025 -10620 10030
--10620 10033 -10640 10039 -10650 10044 -10670 10049 -10680 10053 -10690 10059
--10710 10066 -10720 10071 -10750 10077 -10760 10082 -10790 10086 -10800 10093
--10820 10098 -10840 10105 -10860 10109 -10880 10115 -10900 10119 -10920 10122
--10950 10128 -10960 10132 -10990 10134 -11000 10138 -11020 10140 -11030 10142
--11050 10142 -11070 10142 -11070 10144 -11090 10148 -11110 10147 -11110 10145
--11120 10146 -11120 10146 -11140 10147 -11150 10145 -11140 10146 -11150 10146
--11140 10147 -11150 10146 -11160 10146 -11160 10152 -11160 10154 -11170 10155
--11160 10158 -11180 10163 -11170 10167 -11190 10174 -11190 10179 -11200 10186
--11200 10196 -11220 10202 -11240 10210 -11240 10218 -11260 10228 -11280 10239
--11280 10251 -11310 10262 -11340 10271 -11350 10281 -11380 10290 -11400 10302
--11440 10313 -11460 10321 -11480 10329 -11510 10336 -11520 10343 -11560 10352
--11590 10353 -11610 10357 -11630 10360 -11650 10362 -11660 10361 -11690 10357
--11710 10355 -11730 10349 -11730 10345 -11740 10338 -11740 10329 -11760 10318
--11760 10304 -11750 10291 -11760 10278 -11740 10264 -11730 10248 -11720 10230
--11700 10212 -11690 10194 -11670 10178 -11640 10161 -11620 10141 -11600 10122
--11570 10104 -11530 10087 -11510 10072 -11480 10058 -11450 10046 -11420 10032
--11380 10021 -11360 10011 -11330 10002 -11310 9998 -11270 9994 -11260 9991
--11240 9991 -11220 9994 -11200 9996 -11200 10004 -11180 10010 -11180 10022
--11170 10037 -11170 10050 -11190 10067 -11190 10085 -11210 10107 -11220 10130
--11250 10154 -11280 10179 -11310 10205 -11330 10232 -11380 10262 -11420 10293
--11470 10325 -11510 10356 -11560 10386 -11620 10412 -11660 10446 -11720 10477
--11780 10508 -11850 10537 -11880 10563 -11930 10590 -11980 10616 -12050 10640
--12090 10664 -12140 10688 -12170 10705 -12190 10721 -12210 10737 -12240 10751
--12260 10761 -12270 10771 -12250 10776 -12230 10783 -12200 10783 -12170 10784
--12110 10782 -12050 10777 -11970 10771 -11870 10768 -11750 10757 -11630 10744
--11500 10732 -11330 10720 -11150 10709 -10940 10699 -10720 10685 -10490 10669
--10230 10655 -9950 10643 -9650 10635 -9320 10632 -8990 10623 -8620 10618
--8230 10615 -7830 10617 -7400 10624 -6970 10637 -6500 10650 -6010 10668
--5500 10690 -4980 10716 -4450 10749 -3910 10788 -3350 10830 -2760 10880
--2170 10934 -1570 10993 -970 11055 -360 11124 270 11197 900 11276 1530 11361
-2170 11447 2820 11539 3460 11636 4110 11738 4780 11843 5450 11957 6130 12073
-6790 12183 7460 12301 8150 12433 8860 12574 9570 12719 10270 12855 10920 12964
-11640 13085 12350 13231 13000 13361 13560 13461 14100 13552 14690 13630
-15320 13664 15960 13660 16550 13650 17030 13642 17380 13606 17680 13499
-17860 13286 17940 12973 18030 12592 18120 12180 18000 11801 17750 11501
-17620 11215 17680 10990 17590 10878 17140 10727 16430 10491 15810 10354
-15460 10428 15230 10558 14850 10552 14170 10432 13340 10388 12530 10534
-11780 10841 11080 11202 10360 11538 9560 11823 8820 12053 8310 12216 8200 12297
-8420 12318 8700 12337 8730 12355 8230 12313 7050 12167 5250 11946 2990 11685
-590 11375 -1630 11016 -3450 10668 -4760 10433 -5730 10354 -6440 10399
--6870 10499 -7100 10583 -7110 10643 -6960 10687 -6550 10671 -5770 10577
--4600 10507 -3190 10575 -1950 10751 -1410 11104 -1900 10885 -3100 10101
--4680 8851 -5740 7517 -5230 6880 -4590 6915 -5270 7735 -6800 8465 -8120 8741
--8220 8529 -6740 7980 -4580 7408 -4460 7207 -6950 7440 -10160 7770 -12850 7988
--14660 7999 -15600 7866 -15830 7691 -15630 7544 -15130 7476 -14530 7495
--13920 7597 -13440 7768 -13110 7994 -12950 8264 -12980 8543 -13200 8797
--13630 8999 -14150 9140 -14680 9231 -15180 9307 -15660 9391 -16100 9497
--16510 9652 -16970 9872 -17450 10138 -17940 10417 -18360 10685 -18680 10955
--18880 11252 -19080 11586 -19310 11949 -19550 12324 -19730 12700 -19760 13062
--19680 13382 -19510 13630 -19340 13799 -19250 13905 -19250 13958 -19300 13959
--19380 13899 -19450 13781 -19530 13615 -19620 13420 -19830 13208 -20230 12996
--21060 12810 -21670 12572 -22160 12305 -22560 12064 -22970 11893 -23380 11795
--23820 11745 -24280 11697 -24640 11624 -24910 11523 -25010 11415 -24990 11330
--24870 11301 -24790 11330 -24820 11396 -24990 11455 -25350 11471 -25840 11428
--26460 11336 -27150 11214 -27850 11076 -28550 10926 -29250 10769 -30000 10599
--30790 10412 -31630 10212 -32420 10000 -33110 9788 -33670 9574 -34060 9362
--34310 9151 -34430 8946 -34430 8753 -34310 8567 -34000 8379 -33550 8181
--32920 7982 -32190 7795 -31430 7630 -30650 7486 -29880 7352 -29100 7215
--28350 7071 -27600 6915 -26860 6741 -26130 6543 -25470 6321 -24940 6078
--24580 5818 -24330 5550 -24110 5279 -23830 5014 -23510 4753 -23200 4494
--22960 4229 -22750 3955 -22520 3667 -22130 3378 -21520 3099 -19900 2861
--19060 2609 -18710 2398 -18590 2263 -18500 2209 -18220 2221 -17670 2270
--16750 2329 -15480 2381 -13920 2421 -12140 2456 -10280 2498 -8460 2561
--6770 2649 -5280 2767 -4050 2910 -3050 3076 -2290 3257 -1720 3450 -1330 3650
--1050 3855 -880 4060 -790 4265 -780 4469 -820 4669 -890 4869 -1010 5064
--1170 5258 -1350 5447 -1550 5633 -1780 5813 -2000 5990 -2260 6162 -2510 6327
--2740 6490 -3010 6645 -3230 6796 -3470 6940 -3700 7079 -3930 7213 -4150 7340
--4360 7463 -4560 7581 -4751 7692 -4963 7799 -5133 7900 -5307 7998 -5474 8090
--5636 8178 -5783 8260 -5931 8339 -6077 8415 -6211 8487 -6339 8556 -6482 8620
--6606 8678 -6721 8733 -6833 8786 -6939 8840 -7052 8894 -7122 8940 -7180 8983
--7239 9024 -7308 9062 -7374 9100 -7432 9134 -7484 9166 -7548 9198 -7601 9227
--7647 9257 -7692 9283 -7728 9308 -7771 9331 -7803 9354 -7842 9375 -7869 9397
--7901 9415 -7926 9434 -7956 9451 -7974 9467 -8000 9483 -8023 9498 -8038 9513
--8060 9526 -8077 9539 -8089 9551 -8107 9563 -8124 9575 -8136 9585 -8151 9596
--8158 9606 -8169 9615 -8181 9625 -8200 9633 -8209 9642 -8218 9650 -8228 9658
--8235 9665 -8247 9672 -8260 9680 -8264 9687 -8274 9693 -8288 9699 -8291 9705
--8302 9712 -8307 9717 -8320 9723 -8323 9728 -8332 9733 -8341 9738 -8347 9742
--8354 9748 -8359 9752 -8365 9756 -8373 9761 -8375 9765
-207: 14447010 -4639788 -10230 9915 -10240 9913 -10250 9917 -10260 9921
--10260 9923 -10270 9927 -10280 9927 -10280 9930 -10290 9935 -10310 9939
--10320 9941 -10330 9944 -10340 9948 -10360 9949 -10360 9951 -10380 9956
--10390 9959 -10410 9962 -10410 9967 -10430 9968 -10440 9971 -10450 9975
--10460 9980 -10470 9979 -10490 9982 -10500 9988 -10500 9989 -10510 9990
--10520 9993 -10530 9996 -10530 9997 -10550 10001 -10550 10005 -10560 10009
--10570 10009 -10570 10014 -10590 10017 -10590 10021 -10600 10025 -10610 10028
--10630 10033 -10640 10037 -10640 10044 -10670 10047 -10670 10052 -10690 10059
--10710 10064 -10720 10069 -10740 10075 -10750 10081 -10780 10084 -10800 10091
--10820 10096 -10830 10104 -10850 10107 -10880 10112 -10900 10115 -10910 10120
--10930 10126 -10960 10129 -10970 10131 -11000 10136 -11010 10136 -11020 10138
--11030 10138 -11050 10140 -11060 10140 -11080 10144 -11100 10144 -11090 10143
--11110 10142 -11110 10143 -11120 10142 -11140 10142 -11130 10142 -11130 10143
--11140 10143 -11140 10143 -11140 10144 -11140 10146 -11150 10150 -11150 10151
--11150 10155 -11160 10158 -11160 10165 -11170 10169 -11180 10175 -11180 10182
--11190 10190 -11200 10197 -11220 10206 -11230 10214 -11240 10223 -11250 10233
--11280 10246 -11290 10257 -11310 10265 -11340 10275 -11350 10285 -11380 10297
--11410 10306 -11430 10316 -11460 10323 -11480 10330 -11500 10338 -11530 10344
--11550 10348 -11580 10352 -11610 10354 -11610 10356 -11630 10354 -11660 10353
--11690 10350 -11690 10345 -11700 10339 -11710 10334 -11710 10325 -11720 10314
--11730 10303 -11720 10288 -11730 10276 -11720 10261 -11700 10248 -11690 10230
--11680 10210 -11650 10193 -11640 10178 -11620 10162 -11600 10142 -11570 10124
--11540 10104 -11500 10089 -11490 10072 -11460 10062 -11430 10047 -11390 10033
--11370 10021 -11330 10012 -11300 10004 -11290 9999 -11250 9994 -11230 9991
--11220 9989 -11180 9992 -11190 9994 -11170 9999 -11160 10006 -11140 10017
--11150 10030 -11140 10043 -11150 10058 -11160 10074 -11170 10095 -11180 10117
--11210 10138 -11240 10163 -11260 10187 -11290 10211 -11330 10239 -11370 10270
--11420 10299 -11460 10329 -11500 10355 -11550 10381 -11600 10413 -11660 10442
--11710 10472 -11770 10497 -11820 10524 -11850 10550 -11920 10573 -11960 10595
--12020 10620 -12070 10640 -12080 10657 -12110 10673 -12140 10688 -12160 10701
--12180 10712 -12180 10719 -12180 10725 -12150 10732 -12130 10734 -12090 10735
--12050 10732 -11980 10728 -11900 10725 -11800 10723 -11690 10712 -11580 10702
--11440 10691 -11280 10681 -11100 10673 -10900 10665 -10690 10653 -10460 10641
--10210 10630 -9930 10620 -9640 10616 -9330 10615 -8990 10609 -8640 10607
--8260 10609 -7850 10613 -7440 10622 -7020 10638 -6560 10655 -6070 10675
--5580 10699 -5070 10728 -4550 10764 -4020 10803 -3450 10848 -2880 10898
--2310 10954 -1710 11014 -1110 11078 -520 11146 110 11222 740 11299 1360 11385
-2010 11471 2650 11563 3300 11659 3940 11761 4610 11865 5280 11978 5960 12090
-6620 12198 7280 12312 7980 12437 8680 12573 9380 12712 10080 12840 10730 12940
-11410 13053 12120 13186 12780 13304 13380 13392 13910 13468 14470 13534
-15030 13567 15610 13560 16190 13541 16670 13519 17050 13469 17380 13354
-17610 13155 17690 12880 17810 12561 17920 12216 17840 11891 17580 11624
-17420 11354 17430 11128 17380 11011 17050 10892 16460 10700 15830 10553
-15400 10572 15080 10687 14710 10739 14190 10691 13560 10655 12910 10738
-12270 10954 11640 11248 10950 11546 10150 11815 9320 12032 8610 12179
-8200 12246 8070 12253 8110 12256 8010 12265 7550 12225 6600 12095 5100 11894
-3200 11650 1100 11374 -890 11065 -2510 10766 -3750 10558 -4670 10467 -5350 10483
--5820 10537 -6080 10583 -6190 10619 -6190 10644 -5990 10609 -5490 10486
--4630 10361 -3500 10335 -2480 10411 -2040 10648 -2350 10522 -3130 9975
--4090 9073 -4730 8090 -4820 7444 -4910 7294 -5600 7643 -6660 8103 -7530 8368
--7670 8311 -7000 7993 -6130 7611 -6200 7397 -7620 7420 -9660 7563 -11610 7702
--13100 7775 -14060 7786 -14480 7769 -14540 7748 -14370 7748 -14080 7780
--13770 7853 -13470 7966 -13270 8128 -13160 8333 -13200 8570 -13410 8802
--13790 9000 -14250 9151 -14760 9258 -15270 9343 -15740 9427 -16200 9526
--16620 9674 -17050 9891 -17510 10162 -17960 10450 -18360 10729 -18660 10999
--18870 11285 -19060 11597 -19250 11932 -19480 12276 -19680 12614 -19790 12938
--19770 13222 -19660 13446 -19530 13606 -19450 13717 -19450 13791 -19540 13819
--19670 13788 -19850 13692 -19990 13543 -20130 13361 -20320 13168 -20630 12976
--21360 12818 -21900 12613 -22320 12376 -22690 12149 -23010 11973 -23350 11859
--23690 11791 -24050 11734 -24370 11664 -24630 11572 -24810 11470 -24900 11378
--24910 11323 -24920 11315 -24990 11340 -25160 11369 -25490 11372 -25940 11338
--26530 11260 -27200 11154 -27880 11027 -28570 10884 -29250 10729 -29960 10561
--30710 10375 -31480 10176 -32200 9968 -32850 9759 -33380 9550 -33730 9343
--33960 9137 -34060 8935 -34040 8743 -33930 8562 -33670 8382 -33250 8197
--32690 8008 -32030 7826 -31300 7656 -30590 7497 -29860 7345 -29140 7190
--28440 7032 -27750 6868 -27050 6691 -26360 6499 -25730 6286 -25200 6055
--24800 5806 -24520 5550 -24250 5290 -23940 5032 -23580 4779 -23240 4527
--22930 4274 -22660 4015 -22370 3750 -21950 3484 -21290 3229 -19620 3030
--18610 2807 -18040 2603 -17760 2451 -17550 2366 -17260 2343 -16800 2368
--16080 2418 -15100 2477 -13840 2535 -12420 2590 -10880 2649 -9310 2721
--7810 2809 -6420 2917 -5210 3045 -4180 3193 -3330 3355 -2680 3531 -2160 3716
--1800 3906 -1530 4102 -1370 4297 -1290 4493 -1280 4688 -1310 4881 -1400 5073
--1520 5262 -1670 5448 -1840 5629 -2040 5807 -2240 5981 -2460 6149 -2680 6314
--2900 6473 -3120 6628 -3330 6776 -3550 6919 -3770 7058 -3990 7190 -4180 7318
--4380 7439 -4570 7557 -4760 7669 -4950 7775 -5120 7878 -5290 7974 -5450 8068
--5600 8156 -5756 8239 -5899 8318 -6038 8394 -6171 8467 -6307 8537 -6444 8601
--6567 8661 -6688 8715 -6797 8770 -6903 8823 -7016 8880 -7086 8926 -7141 8968
--7205 9010 -7276 9050 -7339 9088 -7402 9122 -7460 9155 -7518 9186 -7576 9217
--7623 9247 -7666 9274 -7710 9298 -7750 9323 -7788 9345 -7823 9367 -7854 9389
--7886 9408 -7912 9426 -7944 9444 -7964 9460 -7992 9477 -8015 9492 -8032 9507
--8052 9520 -8072 9534 -8084 9545 -8104 9558 -8121 9570 -8136 9581 -8146 9591
--8158 9601 -8171 9611 -8183 9620 -8195 9629 -8207 9638 -8222 9646 -8230 9654
--8239 9661 -8252 9669 -8262 9676 -8268 9683 -8276 9690 -8291 9696 -8298 9702
--8304 9708 -8312 9714 -8323 9720 -8331 9725 -8336 9730 -8343 9735 -8348 9739
--8363 9745 -8364 9749 -8369 9754 -8377 9757 -8384 9762
-208: 14480130 -4631326 -10240 9916 -10250 9916 -10250 9919 -10260 9922
--10260 9925 -10280 9927 -10280 9929 -10280 9930 -10300 9936 -10310 9940
--10320 9944 -10330 9945 -10350 9948 -10350 9949 -10370 9952 -10380 9956
--10390 9961 -10410 9964 -10410 9963 -10430 9969 -10440 9974 -10450 9976
--10470 9978 -10470 9979 -10480 9982 -10500 9986 -10500 9989 -10520 9990
--10510 9993 -10530 9995 -10540 9997 -10540 10001 -10550 10006 -10560 10008
--10570 10009 -10570 10013 -10590 10018 -10590 10019 -10600 10024 -10610 10028
--10620 10033 -10640 10036 -10640 10041 -10660 10045 -10670 10052 -10690 10056
--10700 10064 -10720 10069 -10730 10072 -10760 10079 -10770 10082 -10800 10090
--10810 10094 -10820 10100 -10850 10105 -10870 10111 -10880 10113 -10910 10118
--10920 10122 -10950 10127 -10960 10127 -10990 10131 -10990 10134 -11020 10136
--11020 10136 -11040 10136 -11050 10137 -11060 10139 -11080 10140 -11080 10141
--11100 10140 -11100 10138 -11110 10138 -11110 10139 -11120 10139 -11120 10139
--11130 10140 -11120 10140 -11130 10140 -11130 10143 -11140 10144 -11130 10147
--11140 10152 -11140 10156 -11150 10159 -11150 10164 -11160 10171 -11170 10177
--11180 10186 -11180 10194 -11200 10201 -11210 10209 -11230 10218 -11230 10228
--11270 10240 -11270 10251 -11290 10260 -11310 10270 -11330 10279 -11360 10289
--11380 10301 -11400 10311 -11440 10318 -11450 10324 -11480 10330 -11500 10337
--11520 10344 -11560 10347 -11570 10348 -11580 10349 -11610 10350 -11630 10348
--11650 10344 -11660 10340 -11670 10335 -11680 10330 -11680 10321 -11700 10311
--11690 10300 -11690 10285 -11700 10274 -11690 10260 -11670 10247 -11670 10228
--11640 10211 -11630 10193 -11610 10177 -11600 10162 -11570 10144 -11540 10126
--11520 10105 -11480 10089 -11460 10076 -11440 10063 -11400 10048 -11370 10035
--11340 10023 -11310 10013 -11280 10005 -11260 10001 -11240 9994 -11200 9991
--11190 9989 -11170 9989 -11150 9992 -11150 9997 -11120 10003 -11120 10013
--11110 10024 -11120 10035 -11110 10049 -11120 10065 -11140 10083 -11150 10104
--11170 10124 -11200 10147 -11210 10170 -11250 10192 -11280 10219 -11320 10246
--11360 10273 -11410 10303 -11440 10327 -11490 10353 -11540 10381 -11590 10408
--11650 10436 -11700 10461 -11750 10485 -11790 10509 -11840 10533 -11890 10554
--11940 10576 -11990 10594 -12010 10612 -12040 10627 -12060 10641 -12080 10652
--12110 10662 -12110 10671 -12090 10678 -12090 10682 -12050 10686 -12020 10686
--11980 10684 -11920 10682 -11840 10681 -11740 10676 -11640 10669 -11530 10663
--11390 10651 -11230 10642 -11070 10637 -10870 10631 -10660 10622 -10440 10612
--10200 10603 -9920 10597 -9650 10594 -9330 10596 -9020 10595 -8650 10596
--8290 10598 -7900 10606 -7500 10619 -7080 10635 -6630 10655 -6160 10678
--5670 10704 -5170 10735 -4660 10771 -4140 10814 -3580 10860 -3020 10912
--2460 10967 -1860 11028 -1290 11094 -680 11162 -70 11237 560 11316 1180 11400
-1820 11487 2450 11579 3100 11671 3750 11773 4400 11877 5090 11987 5750 12097
-6410 12202 7080 12311 7760 12432 8450 12560 9170 12693 9840 12813 10480 12907
-11160 13009 11830 13128 12510 13237 13120 13319 13660 13382 14210 13436
-14740 13461 15270 13453 15800 13431 16270 13403 16670 13349 17010 13234
-17260 13046 17370 12796 17520 12524 17640 12230 17600 11955 17390 11724
-17190 11482 17140 11263 17100 11137 16880 11036 16400 10885 15830 10746
-15340 10722 14940 10805 14550 10877 14100 10880 13580 10870 13060 10925
-12530 11083 11980 11311 11370 11560 10640 11795 9810 11993 9020 12127
-8400 12187 8030 12186 7810 12179 7550 12179 7050 12144 6200 12028 4910 11848
-3260 11625 1450 11374 -300 11105 -1780 10845 -2900 10656 -3770 10563 -4440 10552
--4920 10572 -5200 10583 -5360 10592 -5430 10599 -5400 10557 -5120 10432
--4540 10277 -3720 10184 -2910 10171 -2560 10268 -2730 10188 -3220 9829
--3780 9200 -4220 8464 -4520 7875 -4900 7602 -5580 7677 -6450 7924 -7140 8131
--7410 8155 -7240 7990 -7000 7740 -7230 7545 -8140 7477 -9470 7507 -10860 7575
--12040 7646 -12880 7712 -13370 7775 -13590 7830 -13620 7885 -13600 7947
--13500 8021 -13400 8116 -13340 8241 -13320 8407 -13390 8608 -13590 8816
--13930 9007 -14360 9163 -14840 9282 -15340 9379 -15830 9468 -16260 9567
--16690 9707 -17100 9913 -17540 10177 -17960 10460 -18350 10739 -18640 11006
--18870 11281 -19030 11577 -19210 11892 -19420 12210 -19620 12522 -19770 12817
--19810 13073 -19760 13273 -19670 13420 -19590 13530 -19600 13612 -19680 13658
--19850 13650 -20080 13580 -20270 13453 -20460 13291 -20640 13113 -20910 12943
--21530 12806 -22020 12630 -22420 12423 -22760 12216 -23050 12040 -23320 11914
--23610 11831 -23890 11766 -24180 11696 -24430 11611 -24660 11513 -24810 11420
--24900 11347 -24990 11310 -25100 11299 -25290 11301 -25590 11287 -26020 11248
--26570 11177 -27190 11079 -27850 10962 -28510 10827 -29160 10680 -29830 10517
--30530 10337 -31240 10145 -31910 9942 -32520 9737 -33000 9535 -33360 9333
--33550 9131 -33640 8933 -33620 8741 -33530 8561 -33280 8385 -32920 8207
--32420 8029 -31800 7853 -31150 7682 -30460 7518 -29790 7354 -29130 7187
--28450 7018 -27820 6845 -27160 6666 -26500 6476 -25900 6269 -25360 6047
--24960 5809 -24630 5564 -24320 5315 -23980 5067 -23610 4821 -23210 4579
--22870 4335 -22570 4092 -22220 3845 -21750 3601 -21090 3365 -19460 3190
--18340 2996 -17640 2809 -17170 2656 -16840 2553 -16490 2503 -16030 2503
--15440 2536 -14620 2589 -13610 2650 -12440 2715 -11160 2786 -9840 2866
--8520 2956 -7280 3062 -6130 3182 -5140 3317 -4270 3467 -3590 3628 -3010 3799
--2580 3978 -2250 4162 -2020 4347 -1890 4535 -1820 4723 -1810 4909 -1850 5096
--1930 5279 -2050 5460 -2180 5638 -2330 5811 -2500 5982 -2690 6148 -2880 6309
--3070 6466 -3260 6618 -3460 6765 -3660 6906 -3850 7043 -4050 7175 -4230 7301
--4420 7423 -4600 7539 -4790 7651 -4950 7757 -5120 7858 -5290 7957 -5440 8049
--5590 8138 -5740 8221 -5870 8300 -6020 8377 -6150 8450 -6280 8521 -6410 8585
--6540 8645 -6659 8701 -6768 8754 -6873 8810 -6989 8866 -7057 8913 -7115 8956
--7174 8998 -7249 9038 -7314 9076 -7376 9111 -7438 9145 -7498 9176 -7552 9208
--7603 9238 -7649 9264 -7690 9291 -7736 9314 -7774 9337 -7809 9360 -7842 9381
--7873 9402 -7904 9419 -7929 9437 -7956 9454 -7982 9471 -8009 9486 -8027 9502
--8046 9514 -8068 9528 -8084 9541 -8099 9553 -8119 9565 -8134 9576 -8148 9587
--8156 9596 -8172 9607 -8182 9616 -8194 9625 -8213 9634 -8220 9642 -8235 9650
--8245 9658 -8256 9665 -8262 9673 -8272 9679 -8280 9686 -8297 9693 -8301 9699
--8305 9705 -8317 9711 -8328 9716 -8334 9722 -8343 9727 -8348 9732 -8353 9737
--8364 9742 -8371 9746 -8375 9751 -8381 9755 -8388 9759
-209: 14513260 -4622872 -10240 9919 -10250 9918 -10250 9920 -10260 9924
--10270 9926 -10280 9927 -10280 9931 -10290 9932 -10300 9938 -10310 9940
--10320 9943 -10340 9947 -10340 9950 -10360 9950 -10370 9952 -10380 9957
--10400 9960 -10400 9964 -10420 9964 -10430 9970 -10440 9975 -10450 9977
--10460 9976 -10470 9982 -10490 9982 -10500 9985 -10500 9986 -10510 9991
--10510 9991 -10530 9994 -10540 9997 -10540 10003 -10550 10004 -10560 10006
--10570 10010 -10570 10014 -10590 10016 -10580 10019 -10600 10024 -10610 10027
--10620 10031 -10630 10036 -10640 10040 -10660 10044 -10670 10050 -10690 10055
--10700 10062 -10710 10068 -10730 10070 -10750 10076 -10770 10081 -10790 10089
--10800 10092 -10820 10098 -10840 10102 -10860 10108 -10880 10112 -10900 10115
--10920 10120 -10930 10124 -10950 10125 -10980 10127 -10980 10130 -11000 10133
--11010 10134 -11030 10133 -11040 10135 -11050 10135 -11070 10136 -11070 10136
--11090 10137 -11080 10134 -11090 10135 -11100 10136 -11110 10136 -11110 10136
--11100 10136 -11120 10136 -11120 10137 -11110 10139 -11120 10141 -11130 10143
--11120 10149 -11130 10151 -11130 10155 -11140 10160 -11140 10166 -11160 10174
--11160 10181 -11170 10190 -11180 10196 -11190 10202 -11210 10214 -11210 10224
--11250 10234 -11250 10245 -11270 10255 -11290 10265 -11310 10273 -11340 10282
--11350 10295 -11380 10305 -11410 10311 -11430 10318 -11450 10324 -11480 10332
--11490 10338 -11520 10341 -11540 10343 -11570 10343 -11580 10344 -11600 10343
--11610 10339 -11630 10336 -11640 10331 -11650 10324 -11660 10318 -11660 10307
--11660 10296 -11670 10284 -11660 10272 -11660 10258 -11650 10244 -11640 10228
--11610 10211 -11600 10194 -11590 10178 -11560 10162 -11550 10145 -11520 10128
--11480 10106 -11470 10092 -11440 10078 -11410 10065 -11380 10050 -11340 10036
--11320 10026 -11290 10014 -11260 10008 -11230 10000 -11210 9997 -11190 9991
--11160 9988 -11140 9989 -11130 9990 -11110 9994 -11100 10000 -11090 10009
--11090 10019 -11080 10029 -11080 10041 -11090 10057 -11100 10072 -11120 10092
--11130 10110 -11150 10132 -11170 10154 -11200 10174 -11230 10198 -11270 10224
--11310 10251 -11350 10277 -11390 10301 -11430 10324 -11480 10350 -11530 10377
--11590 10403 -11630 10427 -11680 10448 -11720 10470 -11770 10493 -11820 10515
--11870 10534 -11910 10552 -11940 10568 -11960 10581 -11990 10594 -12010 10606
--12030 10617 -12040 10624 -12030 10629 -12010 10636 -11990 10638 -11950 10639
--11920 10638 -11850 10638 -11790 10637 -11690 10632 -11590 10627 -11480 10622
--11350 10613 -11200 10604 -11030 10602 -10850 10597 -10640 10590 -10430 10582
--10190 10577 -9930 10572 -9660 10573 -9350 10575 -9040 10579 -8690 10581
--8340 10585 -7960 10596 -7560 10611 -7150 10631 -6720 10652 -6250 10676
--5770 10705 -5290 10736 -4790 10776 -4270 10819 -3730 10866 -3180 10919
--2610 10975 -2050 11037 -1460 11101 -870 11170 -270 11246 350 11324 980 11408
-1600 11496 2240 11584 2870 11676 3520 11775 4180 11879 4850 11986 5520 12094
-6170 12195 6830 12300 7510 12414 8200 12539 8900 12663 9570 12777 10200 12865
-10850 12955 11520 13065 12180 13164 12800 13237 13370 13293 13890 13337
-14410 13356 14910 13343 15420 13318 15860 13290 16250 13237 16580 13129
-16850 12953 16990 12728 17150 12485 17290 12233 17300 11998 17140 11799
-16940 11591 16830 11388 16790 11252 16620 11160 16250 11043 15760 10922
-15270 10876 14810 10923 14390 10989 13950 11020 13500 11033 13040 11084
-12580 11202 12100 11382 11590 11584 10960 11778 10190 11947 9380 12068
-8660 12121 8140 12118 7720 12103 7300 12097 6730 12063 5910 11964 4750 11803
-3300 11600 1700 11374 160 11134 -1160 10907 -2190 10734 -3000 10638 -3660 10606
--4140 10600 -4450 10580 -4630 10562 -4740 10551 -4790 10505 -4690 10390
--4340 10231 -3780 10101 -3210 10021 -2940 9985 -3040 9907 -3330 9670 -3690 9236
--3990 8690 -4330 8184 -4790 7860 -5450 7777 -6200 7872 -6830 8004 -7220 8056
--7360 7979 -7470 7825 -7800 7667 -8490 7570 -9430 7537 -10440 7552 -11350 7600
--12050 7671 -12540 7761 -12820 7852 -12990 7942 -13120 8029 -13200 8120
--13260 8213 -13340 8327 -13400 8470 -13520 8645 -13740 8833 -14050 9012
--14460 9170 -14910 9301 -15380 9408 -15870 9509 -16310 9611 -16710 9745
--17120 9940 -17530 10188 -17940 10461 -18320 10729 -18620 10991 -18840 11254
--19010 11535 -19180 11831 -19360 12130 -19560 12421 -19720 12694 -19820 12929
--19800 13111 -19760 13246 -19700 13348 -19690 13431 -19780 13487 -19960 13498
--20180 13449 -20430 13345 -20640 13204 -20840 13046 -21080 12894 -21590 12773
--22040 12623 -22420 12444 -22770 12257 -23050 12088 -23290 11957 -23530 11862
--23770 11789 -24020 11717 -24270 11638 -24510 11545 -24700 11452 -24860 11370
--25000 11310 -25170 11274 -25350 11249 -25650 11218 -26060 11170 -26560 11097
--27150 11004 -27770 10892 -28400 10765 -29000 10624 -29640 10470 -30280 10299
--30930 10114 -31560 9919 -32120 9720 -32580 9524 -32910 9329 -33100 9133
--33180 8938 -33170 8748 -33060 8566 -32870 8392 -32540 8219 -32100 8046
--31540 7876 -30930 7709 -30310 7542 -29660 7374 -29040 7201 -28420 7023
--27820 6844 -27190 6663 -26570 6472 -25980 6270 -25460 6055 -25030 5828
--24690 5592 -24340 5355 -23970 5116 -23560 4880 -23160 4646 -22780 4413
--22440 4182 -22060 3952 -21570 3726 -20890 3507 -19370 3346 -18240 3174
--17420 3009 -16820 2865 -16340 2757 -15910 2691 -15430 2670 -14860 2683
--14160 2724 -13300 2779 -12330 2845 -11250 2919 -10130 3003 -8990 3097
--7890 3202 -6860 3317 -5920 3446 -5090 3585 -4400 3735 -3810 3896 -3340 4063
--2960 4236 -2700 4413 -2510 4592 -2390 4771 -2340 4951 -2330 5130 -2360 5309
--2440 5484 -2540 5657 -2650 5826 -2770 5993 -2940 6155 -3090 6313 -3260 6468
--3420 6616 -3600 6761 -3780 6901 -3950 7036 -4130 7166 -4300 7291 -4480 7412
--4650 7527 -4810 7638 -4980 7743 -5150 7845 -5290 7942 -5450 8036 -5590 8123
--5730 8207 -5870 8286 -6000 8363 -6130 8436 -6270 8507 -6400 8572 -6520 8631
--6640 8688 -6740 8742 -6850 8798 -6968 8853 -7038 8902 -7092 8945 -7157 8987
--7227 9028 -7292 9066 -7358 9102 -7423 9135 -7478 9168 -7533 9199 -7587 9229
--7634 9257 -7675 9282 -7723 9307 -7761 9330 -7797 9353 -7833 9375 -7864 9394
--7894 9414 -7921 9431 -7952 9448 -7977 9465 -8002 9481 -8021 9496 -8043 9509
--8065 9523 -8081 9536 -8097 9548 -8119 9561 -8133 9571 -8150 9583 -8160 9592
--8170 9602 -8184 9612 -8198 9621 -8214 9631 -8222 9638 -8234 9646 -8249 9654
--8259 9662 -8267 9670 -8278 9676 -8284 9683 -8300 9689 -8304 9696 -8314 9702
--8323 9707 -8331 9714 -8337 9719 -8349 9724 -8351 9729 -8358 9734 -8370 9739
--8373 9743 -8381 9748 -8387 9753 -8394 9756
-210: 14546420 -4614423 -10240 9919 -10250 9921 -10260 9924 -10270 9924
--10270 9926 -10280 9929 -10290 9931 -10290 9934 -10300 9939 -10310 9939
--10330 9946 -10340 9946 -10340 9951 -10350 9951 -10380 9955 -10370 9957
--10400 9961 -10410 9963 -10420 9966 -10430 9971 -10440 9973 -10450 9977
--10460 9977 -10470 9982 -10490 9983 -10490 9983 -10500 9987 -10520 9989
--10510 9990 -10520 9994 -10540 10000 -10540 10001 -10550 10001 -10560 10008
--10570 10008 -10570 10012 -10580 10016 -10590 10019 -10600 10023 -10610 10027
--10610 10030 -10630 10033 -10650 10040 -10650 10045 -10660 10048 -10680 10054
--10690 10061 -10720 10065 -10730 10068 -10750 10075 -10760 10079 -10770 10088
--10800 10090 -10820 10095 -10830 10101 -10850 10105 -10870 10110 -10890 10113
--10910 10117 -10930 10120 -10940 10123 -10960 10125 -10970 10127 -10990 10129
--11010 10130 -11010 10131 -11030 10133 -11040 10132 -11050 10132 -11070 10133
--11070 10133 -11070 10130 -11070 10134 -11090 10131 -11090 10133 -11100 10132
--11090 10131 -11110 10132 -11100 10135 -11100 10136 -11110 10136 -11110 10140
--11110 10144 -11120 10147 -11110 10151 -11130 10157 -11130 10161 -11130 10170
--11150 10177 -11150 10185 -11160 10190 -11180 10198 -11190 10209 -11200 10219
--11220 10228 -11240 10240 -11250 10249 -11270 10258 -11290 10267 -11310 10278
--11340 10288 -11350 10297 -11380 10306 -11410 10313 -11420 10318 -11450 10326
--11470 10331 -11490 10335 -11510 10337 -11540 10338 -11550 10340 -11570 10337
--11580 10334 -11600 10330 -11610 10328 -11620 10322 -11620 10313 -11640 10302
--11640 10293 -11640 10281 -11630 10270 -11630 10258 -11620 10242 -11610 10227
--11590 10210 -11570 10195 -11550 10179 -11540 10161 -11520 10147 -11500 10129
--11460 10109 -11440 10094 -11420 10080 -11390 10066 -11350 10053 -11320 10039
--11290 10028 -11260 10016 -11250 10010 -11210 10003 -11190 9997 -11160 9992
--11130 9988 -11130 9990 -11100 9990 -11070 9992 -11080 9996 -11060 10004
--11060 10015 -11050 10023 -11050 10035 -11050 10048 -11070 10064 -11080 10082
--11090 10098 -11110 10118 -11120 10137 -11160 10157 -11180 10178 -11230 10202
--11250 10230 -11300 10254 -11340 10276 -11370 10296 -11410 10322 -11470 10346
--11530 10372 -11570 10394 -11610 10414 -11650 10434 -11700 10454 -11750 10476
--11800 10494 -11840 10510 -11870 10526 -11890 10538 -11920 10551 -11940 10561
--11960 10571 -11970 10578 -11960 10584 -11940 10592 -11930 10593 -11890 10593
--11860 10594 -11790 10593 -11730 10592 -11640 10591 -11550 10587 -11440 10582
--11320 10574 -11170 10569 -11010 10566 -10830 10563 -10630 10559 -10430 10553
--10190 10548 -9950 10547 -9680 10550 -9380 10554 -9060 10559 -8750 10565
--8390 10572 -8030 10582 -7630 10601 -7240 10623 -6800 10645 -6360 10671
--5890 10700 -5420 10735 -4930 10774 -4420 10819 -3890 10868 -3350 10920
--2790 10977 -2230 11040 -1670 11102 -1080 11172 -480 11247 130 11326 750 11409
-1370 11495 2000 11582 2620 11671 3270 11770 3930 11871 4590 11976 5250 12081
-5900 12179 6550 12279 7220 12389 7910 12506 8590 12624 9270 12730 9880 12815
-10530 12897 11170 12995 11810 13085 12430 13151 13000 13202 13550 13239
-14030 13250 14540 13234 15010 13207 15420 13178 15800 13128 16140 13031
-16400 12873 16570 12667 16720 12451 16880 12230 16940 12025 16830 11853
-16640 11676 16500 11496 16430 11357 16310 11269 16020 11173 15620 11075
-15140 11022 14690 11043 14230 11092 13800 11129 13360 11155 12930 11206
-12480 11305 12060 11449 11630 11611 11070 11767 10390 11906 9620 12010
-8900 12054 8270 12050 7730 12030 7200 12019 6560 11985 5720 11898 4650 11756
-3350 11573 1930 11369 550 11154 -640 10951 -1570 10793 -2350 10692 -2980 10648
--3470 10618 -3800 10576 -4000 10532 -4150 10501 -4220 10448 -4210 10343
--4050 10197 -3730 10053 -3350 9934 -3180 9799 -3260 9695 -3460 9516 -3700 9213
--3950 8809 -4250 8397 -4680 8073 -5290 7908 -5950 7895 -6560 7957 -7030 8000
--7370 7973 -7670 7880 -8090 7764 -8700 7668 -9430 7610 -10200 7592 -10920 7613
--11500 7672 -11940 7759 -12250 7858 -12500 7961 -12700 8067 -12910 8170
--13090 8271 -13260 8384 -13420 8518 -13600 8675 -13830 8846 -14140 9015
--14530 9171 -14950 9310 -15420 9430 -15870 9541 -16310 9649 -16710 9782
--17110 9967 -17500 10199 -17880 10456 -18250 10713 -18570 10961 -18800 11214
--18970 11478 -19130 11758 -19290 12038 -19480 12311 -19660 12566 -19780 12786
--19810 12956 -19810 13080 -19770 13175 -19770 13255 -19840 13314 -20010 13337
--20230 13307 -20480 13224 -20710 13104 -20930 12967 -21170 12833 -21560 12720
--21980 12591 -22360 12438 -22700 12274 -22980 12116 -23220 11984 -23440 11882
--23650 11801 -23880 11727 -24110 11650 -24350 11564 -24570 11472 -24780 11387
--24960 11313 -25160 11258 -25370 11212 -25670 11164 -26050 11104 -26510 11028
--27060 10935 -27650 10826 -28230 10703 -28800 10569 -29390 10422 -29980 10260
--30590 10085 -31150 9897 -31690 9706 -32100 9517 -32410 9329 -32600 9139
--32680 8949 -32680 8762 -32580 8579 -32410 8406 -32130 8234 -31720 8065
--31220 7899 -30680 7734 -30090 7570 -29500 7400 -28900 7224 -28320 7044
--27750 6861 -27160 6677 -26570 6487 -26000 6289 -25490 6080 -25050 5860
--24680 5635 -24310 5407 -23910 5178 -23490 4952 -23060 4728 -22670 4506
--22290 4285 -21890 4070 -21380 3858 -20690 3657 -19340 3498 -18230 3346
--17350 3202 -16630 3072 -16050 2966 -15510 2894 -14980 2859 -14400 2856
--13750 2881 -13000 2927 -12160 2986 -11250 3060 -10280 3142 -9290 3237
--8320 3339 -7410 3452 -6540 3575 -5770 3708 -5100 3850 -4520 4000 -4040 4159
--3640 4322 -3340 4490 -3110 4659 -2960 4832 -2850 5004 -2810 5177 -2800 5348
--2840 5519 -2890 5686 -2970 5851 -3070 6013 -3190 6171 -3310 6326 -3460 6477
--3600 6624 -3750 6765 -3910 6902 -4060 7035 -4230 7163 -4390 7287 -4540 7407
--4710 7520 -4860 7630 -5030 7736 -5170 7835 -5320 7933 -5470 8025 -5600 8113
--5740 8196 -5870 8275 -6000 8351 -6130 8426 -6270 8496 -6390 8561 -6500 8621
--6630 8677 -6740 8732 -6830 8787 -6950 8843 -7020 8892 -7080 8935 -7140 8978
--7220 9019 -7274 9057 -7343 9094 -7407 9127 -7465 9159 -7521 9192 -7574 9221
--7623 9250 -7667 9275 -7711 9300 -7750 9324 -7789 9346 -7825 9368 -7862 9389
--7887 9408 -7913 9425 -7943 9443 -7976 9460 -7996 9475 -8015 9491 -8045 9505
--8064 9518 -8079 9531 -8095 9544 -8121 9556 -8133 9568 -8148 9578 -8163 9588
--8172 9598 -8190 9608 -8202 9618 -8217 9626 -8224 9635 -8236 9643 -8252 9651
--8261 9658 -8275 9666 -8285 9673 -8290 9679 -8299 9687 -8310 9692 -8319 9699
--8328 9705 -8335 9710 -8340 9716 -8353 9721 -8355 9727 -8368 9731 -8372 9736
--8380 9740 -8387 9746 -8391 9749 -8397 9754
-211: 14579600 -4605982 -10240 9920 -10260 9923 -10260 9927 -10270 9926
--10270 9928 -10280 9930 -10290 9931 -10300 9936 -10310 9939 -10310 9941
--10330 9945 -10340 9948 -10340 9951 -10360 9952 -10370 9956 -10380 9957
--10400 9962 -10410 9965 -10410 9965 -10430 9970 -10440 9974 -10450 9976
--10470 9978 -10470 9982 -10480 9982 -10490 9984 -10500 9986 -10510 9988
--10520 9992 -10520 9995 -10530 9998 -10540 9998 -10560 10001 -10560 10007
--10560 10008 -10570 10012 -10580 10015 -10580 10017 -10610 10022 -10600 10027
--10610 10028 -10630 10034 -10640 10038 -10650 10043 -10660 10050 -10670 10054
--10700 10058 -10710 10062 -10720 10068 -10740 10074 -10760 10076 -10770 10085
--10800 10088 -10810 10094 -10820 10099 -10850 10102 -10850 10106 -10880 10112
--10900 10115 -10920 10117 -10940 10120 -10950 10123 -10960 10124 -10980 10126
--10990 10127 -11000 10128 -11020 10129 -11030 10129 -11040 10130 -11050 10129
--11050 10129 -11060 10129 -11070 10129 -11070 10128 -11080 10129 -11080 10130
--11080 10126 -11090 10130 -11090 10131 -11090 10132 -11100 10133 -11090 10137
--11100 10140 -11100 10142 -11100 10147 -11110 10153 -11120 10158 -11120 10165
--11130 10171 -11130 10179 -11150 10186 -11160 10194 -11170 10202 -11190 10213
--11200 10225 -11210 10235 -11240 10242 -11250 10251 -11270 10263 -11290 10272
--11310 10281 -11340 10291 -11360 10298 -11370 10308 -11400 10314 -11420 10318
--11440 10325 -11470 10329 -11490 10332 -11500 10332 -11520 10333 -11550 10331
--11550 10331 -11570 10327 -11580 10322 -11590 10318 -11600 10310 -11600 10299
--11610 10290 -11610 10278 -11600 10267 -11600 10257 -11600 10242 -11570 10225
--11560 10211 -11540 10195 -11530 10178 -11520 10164 -11490 10147 -11480 10130
--11430 10113 -11420 10096 -11390 10082 -11370 10070 -11330 10056 -11300 10041
--11270 10029 -11230 10019 -11220 10014 -11190 10004 -11160 9998 -11140 9994
--11110 9989 -11100 9989 -11070 9988 -11060 9990 -11040 9995 -11040 10002
--11020 10010 -11020 10019 -11010 10028 -11030 10039 -11030 10056 -11040 10071
--11060 10088 -11070 10105 -11080 10123 -11110 10140 -11140 10160 -11170 10183
--11200 10210 -11250 10231 -11280 10251 -11310 10272 -11360 10294 -11410 10318
--11460 10340 -11510 10362 -11540 10382 -11600 10399 -11630 10419 -11690 10437
--11720 10454 -11770 10472 -11790 10484 -11830 10498 -11840 10510 -11880 10518
--11890 10527 -11910 10534 -11900 10542 -11870 10546 -11860 10550 -11840 10551
--11800 10551 -11750 10550 -11680 10551 -11600 10550 -11510 10546 -11400 10542
--11290 10537 -11150 10532 -10980 10531 -10830 10530 -10630 10527 -10420 10524
--10210 10521 -9970 10520 -9700 10526 -9420 10532 -9110 10538 -8790 10546
--8460 10555 -8100 10569 -7720 10588 -7330 10611 -6920 10634 -6470 10662
--6020 10694 -5560 10728 -5070 10770 -4590 10814 -4060 10864 -3540 10916
--2980 10974 -2440 11035 -1870 11099 -1300 11168 -710 11241 -110 11321
-500 11403 1120 11488 1730 11573 2350 11659 2990 11755 3650 11855 4300 11958
-4970 12059 5600 12152 6240 12249 6910 12355 7580 12465 8260 12577 8910 12677
-9540 12755 10170 12833 10800 12919 11420 13001 12020 13063 12580 13109
-13140 13141 13630 13146 14110 13128 14580 13099 14970 13068 15320 13022
-15680 12937 15930 12796 16110 12611 16260 12421 16420 12224 16510 12043
-16460 11892 16310 11741 16150 11583 16050 11451 15940 11361 15720 11280
-15380 11201 14980 11156 14530 11158 14070 11189 13630 11220 13200 11248
-12770 11299 12330 11386 11910 11504 11520 11637 11020 11760 10430 11872
-9730 11957 9010 11992 8380 11984 7760 11962 7160 11944 6460 11909 5630 11831
-4610 11705 3430 11543 2150 11359 890 11163 -180 10981 -1030 10833 -1780 10731
--2380 10675 -2900 10629 -3250 10570 -3460 10506 -3610 10451 -3710 10388
--3770 10290 -3730 10158 -3570 10017 -3370 9881 -3290 9690 -3400 9552 -3570 9389
--3780 9158 -3990 8861 -4240 8533 -4630 8242 -5160 8044 -5750 7962 -6330 7964
--6840 7982 -7270 7971 -7720 7916 -8190 7837 -8770 7757 -9410 7696 -10060 7661
--10640 7666 -11150 7706 -11540 7779 -11840 7871 -12130 7975 -12380 8085
--12640 8196 -12910 8305 -13150 8419 -13380 8550 -13610 8698 -13870 8855
--14190 9014 -14560 9168 -14980 9310 -15410 9441 -15850 9562 -16280 9675
--16680 9812 -17060 9989 -17430 10208 -17790 10448 -18160 10690 -18480 10927
--18720 11166 -18910 11414 -19060 11676 -19220 11938 -19390 12195 -19560 12433
--19710 12641 -19780 12803 -19820 12921 -19800 13010 -19810 13086 -19880 13145
--20020 13175 -20230 13158 -20480 13092 -20710 12993 -20940 12877 -21170 12759
--21490 12654 -21850 12542 -22220 12410 -22560 12266 -22870 12122 -23100 11995
--23320 11889 -23510 11803 -23730 11726 -23940 11650 -24180 11567 -24410 11480
--24660 11394 -24870 11315 -25090 11245 -25330 11184 -25620 11122 -25990 11053
--26430 10970 -26920 10875 -27490 10766 -28020 10648 -28550 10517 -29100 10377
--29650 10223 -30200 10056 -30730 9877 -31200 9695 -31590 9512 -31880 9330
--32070 9149 -32150 8964 -32150 8781 -32070 8600 -31910 8426 -31670 8255
--31300 8087 -30870 7924 -30350 7762 -29840 7599 -29270 7431 -28720 7256
--28170 7075 -27630 6891 -27070 6706 -26500 6518 -25970 6322 -25450 6119
--25020 5907 -24630 5691 -24230 5471 -23820 5253 -23370 5037 -22940 4822
--22520 4609 -22130 4401 -21710 4198 -21190 4000 -20500 3811 -19330 3654
--18270 3515 -17360 3387 -16580 3273 -15890 3175 -15270 3103 -14680 3061
--14080 3046 -13450 3058 -12740 3092 -11990 3143 -11190 3209 -10340 3289
--9480 3380 -8640 3480 -7810 3589 -7040 3707 -6320 3834 -5690 3968 -5140 4113
--4650 4261 -4260 4417 -3920 4576 -3680 4737 -3480 4902 -3350 5067 -3270 5234
--3230 5398 -3220 5562 -3240 5725 -3290 5885 -3360 6041 -3450 6196 -3550 6347
--3660 6494 -3790 6636 -3900 6776 -4060 6911 -4180 7041 -4340 7167 -4480 7289
--4640 7406 -4770 7519 -4930 7628 -5080 7731 -5220 7831 -5350 7927 -5500 8019
--5630 8106 -5750 8188 -5890 8268 -6010 8344 -6140 8417 -6270 8487 -6380 8553
--6510 8613 -6620 8668 -6730 8724 -6830 8778 -6950 8835 -7010 8884 -7070 8927
--7140 8970 -7200 9011 -7260 9050 -7340 9086 -7400 9120 -7460 9153 -7509 9184
--7563 9215 -7615 9243 -7662 9269 -7701 9294 -7746 9318 -7780 9340 -7819 9363
--7856 9383 -7886 9403 -7910 9420 -7941 9438 -7970 9454 -7996 9471 -8016 9486
--8043 9500 -8057 9514 -8082 9527 -8097 9539 -8121 9552 -8136 9564 -8149 9574
--8161 9584 -8179 9595 -8191 9604 -8206 9614 -8219 9623 -8231 9631 -8242 9640
--8253 9647 -8266 9655 -8277 9663 -8289 9669 -8297 9677 -8306 9683 -8315 9689
--8323 9696 -8334 9702 -8339 9707 -8345 9713 -8358 9719 -8361 9723 -8371 9729
--8380 9733 -8388 9738 -8390 9742 -8396 9747 -8400 9750
-212: 14612810 -4597546 -10260 9922 -10260 9923 -10260 9928 -10270 9929
--10270 9930 -10290 9931 -10290 9933 -10300 9937 -10310 9940 -10320 9943
--10330 9944 -10330 9949 -10350 9952 -10360 9954 -10370 9955 -10380 9958
--10400 9962 -10410 9965 -10410 9966 -10440 9970 -10430 9972 -10450 9975
--10470 9979 -10470 9982 -10480 9982 -10490 9985 -10500 9986 -10500 9987
--10520 9992 -10520 9995 -10530 9996 -10540 9998 -10550 10003 -10560 10003
--10560 10007 -10570 10011 -10570 10015 -10590 10016 -10600 10022 -10600 10028
--10620 10027 -10620 10033 -10640 10037 -10640 10043 -10660 10047 -10670 10054
--10690 10055 -10700 10063 -10730 10065 -10730 10072 -10760 10074 -10760 10083
--10790 10088 -10800 10092 -10820 10096 -10840 10099 -10850 10105 -10870 10108
--10880 10110 -10910 10116 -10930 10117 -10940 10120 -10950 10122 -10970 10123
--10980 10125 -11000 10125 -11000 10125 -11020 10128 -11030 10126 -11030 10125
--11040 10126 -11050 10127 -11060 10125 -11060 10125 -11060 10126 -11070 10125
--11070 10123 -11070 10125 -11070 10128 -11080 10129 -11090 10129 -11080 10133
--11080 10138 -11090 10139 -11090 10142 -11090 10148 -11100 10155 -11110 10159
--11110 10166 -11120 10174 -11130 10182 -11140 10189 -11160 10196 -11160 10208
--11190 10220 -11190 10228 -11220 10236 -11230 10246 -11250 10258 -11260 10265
--11300 10275 -11310 10283 -11340 10294 -11340 10300 -11380 10308 -11400 10313
--11420 10318 -11440 10322 -11460 10327 -11470 10326 -11490 10327 -11520 10328
--11530 10325 -11540 10323 -11560 10318 -11550 10313 -11570 10306 -11570 10297
--11580 10286 -11580 10277 -11570 10265 -11580 10254 -11560 10242 -11550 10226
--11530 10209 -11530 10193 -11500 10181 -11490 10164 -11460 10148 -11450 10133
--11420 10115 -11390 10099 -11370 10085 -11340 10071 -11310 10058 -11270 10046
--11250 10033 -11220 10021 -11190 10015 -11170 10007 -11130 10001 -11110 9995
--11090 9991 -11070 9988 -11050 9987 -11030 9990 -11020 9993 -11000 10001
--10990 10006 -11000 10014 -10980 10023 -10990 10032 -10990 10045 -11010 10063
--11010 10076 -11030 10094 -11040 10109 -11070 10126 -11090 10145 -11120 10166
--11160 10190 -11190 10209 -11220 10229 -11260 10248 -11310 10267 -11350 10290
--11400 10310 -11440 10332 -11490 10350 -11520 10367 -11570 10383 -11610 10401
--11670 10418 -11690 10434 -11730 10446 -11760 10458 -11780 10469 -11810 10478
--11830 10484 -11840 10493 -11830 10500 -11820 10504 -11800 10508 -11780 10508
--11750 10510 -11700 10509 -11640 10511 -11560 10510 -11480 10507 -11370 10504
--11260 10500 -11120 10496 -10990 10497 -10810 10497 -10630 10495 -10440 10494
--10220 10492 -9990 10494 -9730 10501 -9460 10508 -9170 10517 -8870 10526
--8520 10536 -8180 10552 -7820 10573 -7430 10597 -7030 10622 -6610 10649
--6160 10683 -5710 10720 -5230 10759 -4760 10805 -4250 10855 -3730 10908
--3190 10964 -2650 11027 -2100 11090 -1540 11157 -950 11232 -360 11308
-240 11390 850 11474 1440 11556 2070 11641 2700 11734 3340 11832 3990 11930
-4650 12029 5270 12120 5910 12210 6560 12312 7230 12417 7890 12522 8540 12615
-9160 12689 9780 12763 10400 12842 11000 12914 11580 12972 12140 13012
-12680 13041 13180 13044 13650 13025 14100 12995 14510 12963 14840 12921
-15170 12844 15440 12721 15630 12558 15780 12388 15930 12217 16040 12054
-16030 11918 15920 11789 15770 11654 15650 11531 15540 11440 15360 11367
-15090 11305 14720 11266 14330 11261 13880 11279 13450 11302 13020 11325
-12580 11369 12150 11447 11730 11547 11320 11654 10870 11755 10330 11841
-9700 11908 9030 11935 8390 11923 7780 11900 7120 11875 6400 11838 5580 11765
-4600 11653 3520 11508 2360 11341 1210 11165 240 10998 -580 10859 -1260 10756
--1860 10690 -2380 10632 -2780 10561 -3010 10484 -3160 10408 -3280 10329
--3370 10232 -3410 10113 -3370 9978 -3310 9840 -3300 9635 -3460 9465 -3640 9296
--3860 9103 -4050 8871 -4290 8615 -4630 8366 -5090 8169 -5610 8049 -6150 8005
--6640 7992 -7150 7979 -7650 7944 -8180 7890 -8750 7830 -9340 7776 -9930 7742
--10450 7734 -10910 7762 -11270 7820 -11580 7901 -11840 7996 -12140 8102
--12410 8213 -12730 8325 -13030 8442 -13310 8571 -13580 8713 -13860 8861
--14200 9012 -14550 9160 -14970 9305 -15380 9441 -15800 9569 -16220 9692
--16620 9830 -16970 10003 -17340 10210 -17680 10436 -18030 10664 -18350 10888
--18610 11112 -18800 11346 -18970 11590 -19120 11836 -19290 12074 -19450 12298
--19600 12494 -19710 12649 -19770 12764 -19800 12852 -19800 12923 -19880 12981
--20020 13013 -20190 13007 -20430 12957 -20660 12874 -20870 12777 -21120 12677
--21380 12577 -21690 12476 -22050 12364 -22380 12239 -22690 12110 -22940 11989
--23150 11883 -23350 11795 -23550 11715 -23750 11638 -23990 11559 -24220 11475
--24490 11391 -24730 11310 -24970 11232 -25230 11161 -25520 11088 -25870 11010
--26290 10923 -26760 10825 -27260 10716 -27770 10598 -28280 10472 -28770 10336
--29280 10189 -29790 10030 -30260 9860 -30700 9685 -31060 9509 -31330 9334
--31510 9159 -31590 8982 -31600 8803 -31530 8626 -31390 8453 -31170 8282
--30850 8115 -30460 7953 -30000 7793 -29510 7632 -29010 7466 -28480 7293
--27970 7114 -27450 6931 -26920 6748 -26390 6561 -25870 6370 -25370 6171
--24940 5966 -24530 5758 -24130 5548 -23680 5338 -23240 5132 -22770 4926
--22360 4724 -21950 4526 -21530 4334 -20990 4149 -20310 3971 -19310 3815
--18330 3685 -17430 3570 -16590 3468 -15850 3381 -15160 3312 -14500 3266
--13880 3246 -13230 3249 -12560 3271 -11860 3314 -11130 3372 -10370 3444
--9620 3530 -8860 3626 -8130 3730 -7420 3843 -6770 3963 -6190 4093 -5650 4229
--5180 4371 -4780 4518 -4460 4670 -4180 4824 -3980 4980 -3810 5139 -3700 5298
--3630 5457 -3590 5615 -3580 5772 -3610 5926 -3640 6078 -3700 6227 -3790 6375
--3870 6518 -3980 6658 -4070 6793 -4200 6925 -4330 7053 -4460 7176 -4590 7297
--4720 7411 -4860 7523 -5010 7630 -5140 7732 -5270 7830 -5410 7926 -5540 8016
--5660 8103 -5790 8184 -5910 8263 -6030 8339 -6160 8412 -6270 8482 -6400 8547
--6520 8606 -6630 8662 -6720 8717 -6840 8772 -6940 8829 -7020 8877 -7070 8921
--7120 8964 -7200 9005 -7270 9043 -7330 9080 -7390 9113 -7450 9147 -7510 9179
--7560 9209 -7610 9237 -7660 9264 -7695 9288 -7737 9312 -7777 9335 -7817 9358
--7853 9378 -7884 9398 -7914 9415 -7938 9433 -7968 9450 -7991 9467 -8020 9481
--8042 9496 -8058 9510 -8081 9523 -8099 9535 -8121 9548 -8138 9560 -8155 9570
--8162 9581 -8185 9591 -8194 9601 -8208 9610 -8223 9619 -8235 9628 -8249 9636
--8258 9644 -8273 9652 -8280 9660 -8294 9666 -8300 9674 -8310 9680 -8320 9686
--8327 9693 -8339 9699 -8344 9705 -8351 9710 -8364 9715 -8371 9721 -8376 9725
--8384 9731 -8394 9735 -8397 9740 -8400 9744 -8409 9748
-213: 14646030 -4589116 -10260 9923 -10260 9926 -10270 9927 -10270 9931
--10270 9931 -10290 9933 -10300 9937 -10300 9936 -10310 9941 -10320 9943
--10330 9945 -10340 9949 -10350 9952 -10360 9954 -10370 9957 -10380 9958
--10400 9964 -10400 9965 -10420 9968 -10440 9970 -10430 9970 -10450 9976
--10460 9979 -10470 9980 -10480 9983 -10490 9985 -10490 9986 -10500 9987
--10520 9991 -10520 9992 -10530 9998 -10540 9999 -10550 10001 -10560 10002
--10560 10005 -10560 10011 -10580 10015 -10580 10015 -10600 10019 -10600 10027
--10610 10028 -10620 10032 -10640 10037 -10640 10042 -10650 10046 -10670 10051
--10690 10056 -10700 10060 -10710 10064 -10730 10070 -10750 10073 -10760 10081
--10780 10086 -10790 10088 -10810 10095 -10830 10098 -10850 10102 -10860 10105
--10880 10109 -10900 10113 -10910 10114 -10930 10117 -10940 10120 -10960 10120
--10970 10121 -10990 10124 -11000 10122 -11000 10124 -11010 10123 -11030 10124
--11030 10122 -11030 10122 -11040 10122 -11050 10122 -11060 10122 -11050 10121
--11050 10122 -11060 10123 -11060 10123 -11070 10124 -11070 10125 -11070 10129
--11070 10134 -11070 10136 -11070 10139 -11090 10143 -11090 10149 -11090 10155
--11090 10162 -11100 10170 -11120 10175 -11130 10184 -11130 10192 -11150 10204
--11160 10213 -11180 10221 -11190 10231 -11210 10241 -11230 10251 -11240 10260
--11280 10268 -11290 10277 -11310 10286 -11330 10295 -11350 10301 -11370 10307
--11400 10312 -11410 10316 -11430 10320 -11460 10323 -11460 10321 -11490 10322
--11500 10320 -11520 10318 -11520 10314 -11530 10309 -11540 10302 -11540 10295
--11550 10285 -11550 10274 -11550 10264 -11540 10251 -11530 10239 -11530 10227
--11510 10208 -11500 10194 -11470 10180 -11460 10167 -11450 10149 -11420 10134
--11390 10117 -11360 10103 -11350 10088 -11320 10073 -11280 10061 -11250 10048
--11230 10037 -11190 10024 -11170 10018 -11150 10009 -11110 10004 -11090 9997
--11060 9992 -11040 9990 -11020 9987 -11010 9990 -10990 9992 -10980 9998
--10950 10004 -10970 10009 -10950 10017 -10950 10026 -10970 10039 -10960 10052
--10970 10068 -10990 10083 -11000 10096 -11020 10113 -11050 10129 -11070 10150
--11110 10170 -11140 10190 -11170 10208 -11200 10224 -11260 10242 -11290 10263
--11340 10283 -11380 10302 -11430 10320 -11460 10335 -11500 10352 -11550 10366
--11600 10384 -11630 10396 -11660 10410 -11700 10420 -11710 10430 -11740 10439
--11770 10446 -11780 10453 -11780 10458 -11760 10465 -11750 10467 -11720 10468
--11700 10470 -11660 10469 -11600 10471 -11520 10471 -11440 10470 -11350 10467
--11240 10463 -11110 10461 -10980 10462 -10810 10464 -10640 10464 -10450 10463
--10240 10464 -10020 10467 -9780 10475 -9510 10484 -9230 10494 -8930 10504
--8600 10516 -8270 10534 -7920 10554 -7540 10579 -7160 10606 -6740 10636
--6310 10668 -5870 10706 -5410 10747 -4940 10792 -4440 10841 -3940 10895
--3400 10952 -2880 11013 -2340 11076 -1780 11142 -1210 11215 -630 11290
--40 11372 560 11454 1150 11533 1760 11616 2380 11707 3020 11801 3670 11897
-4310 11992 4920 12079 5540 12166 6190 12262 6850 12361 7510 12461 8130 12548
-8740 12618 9360 12687 9980 12762 10550 12825 11120 12877 11660 12916 12200 12940
-12690 12942 13160 12924 13610 12895 14000 12863 14340 12822 14650 12754
-14920 12646 15120 12503 15280 12355 15410 12204 15530 12060 15550 11936
-15490 11823 15360 11709 15250 11595 15110 11510 14960 11439 14720 11386
-14410 11356 14060 11349 13650 11360 13240 11372 12820 11389 12380 11426
-11950 11490 11510 11576 11100 11665 10660 11746 10160 11814 9560 11862
-8940 11881 8330 11868 7730 11841 7070 11813 6350 11770 5530 11703 4630 11600
-3600 11468 2550 11319 1490 11159 590 11005 -160 10874 -810 10771 -1400 10695
--1930 10628 -2350 10551 -2620 10461 -2800 10374 -2920 10279 -3040 10175
--3120 10061 -3160 9936 -3200 9801 -3260 9609 -3450 9419 -3680 9238 -3900 9056
--4110 8865 -4370 8660 -4660 8454 -5070 8273 -5510 8139 -6020 8064 -6510 8025
--7010 7999 -7540 7969 -8080 7931 -8670 7888 -9250 7846 -9790 7816 -10290 7806
--10710 7829 -11080 7875 -11370 7943 -11660 8027 -11940 8125 -12240 8232
--12560 8342 -12900 8459 -13220 8585 -13500 8723 -13840 8864 -14150 9008
--14520 9152 -14920 9294 -15320 9433 -15730 9567 -16140 9696 -16500 9838
--16870 10006 -17220 10204 -17550 10418 -17880 10632 -18190 10843 -18450 11056
--18680 11275 -18840 11502 -19000 11731 -19150 11953 -19320 12162 -19460 12347
--19590 12496 -19680 12608 -19740 12696 -19760 12765 -19850 12821 -19980 12856
--20140 12856 -20350 12819 -20560 12750 -20770 12670 -21010 12586 -21220 12493
--21520 12402 -21850 12304 -22170 12195 -22470 12080 -22730 11970 -22940 11866
--23150 11777 -23340 11694 -23550 11618 -23770 11540 -24010 11459 -24270 11378
--24550 11296 -24790 11216 -25070 11138 -25370 11059 -25700 10975 -26100 10882
--26540 10783 -27000 10674 -27480 10556 -27960 10433 -28420 10301 -28880 10159
--29350 10006 -29780 9846 -30170 9677 -30510 9509 -30760 9340 -30930 9171
--31010 9000 -31030 8828 -30960 8656 -30850 8484 -30640 8315 -30370 8148
--30010 7988 -29600 7828 -29160 7670 -28680 7506 -28210 7335 -27720 7159
--27230 6980 -26730 6799 -26220 6616 -25710 6428 -25250 6235 -24800 6036
--24400 5835 -23980 5634 -23530 5434 -23070 5236 -22600 5040 -22170 4847
--21760 4659 -21330 4478 -20790 4303 -20120 4136 -19270 3984 -18380 3859
--17490 3753 -16670 3659 -15860 3581 -15130 3517 -14440 3474 -13760 3450
--13110 3446 -12450 3461 -11790 3495 -11090 3544 -10410 3610 -9720 3688
--9030 3778 -8380 3877 -7730 3983 -7140 4099 -6590 4221 -6090 4351 -5640 4486
--5240 4626 -4920 4770 -4640 4917 -4420 5066 -4240 5219 -4100 5370 -4010 5523
--3940 5675 -3900 5825 -3910 5975 -3920 6122 -3960 6267 -4020 6410 -4090 6548
--4170 6685 -4250 6817 -4360 6945 -4470 7070 -4590 7192 -4700 7309 -4820 7422
--4960 7531 -5090 7636 -5210 7737 -5340 7835 -5470 7927 -5590 8018 -5710 8103
--5830 8184 -5950 8262 -6060 8336 -6180 8410 -6300 8478 -6420 8544 -6530 8602
--6630 8658 -6740 8713 -6840 8767 -6950 8824 -7020 8873 -7080 8916 -7130 8958
--7200 9000 -7260 9038 -7330 9075 -7390 9108 -7460 9142 -7500 9174 -7560 9204
--7610 9232 -7660 9259 -7690 9283 -7740 9308 -7780 9331 -7810 9353 -7850 9373
--7888 9393 -7914 9411 -7940 9429 -7969 9446 -7994 9462 -8016 9478 -8044 9492
--8065 9506 -8082 9519 -8100 9531 -8120 9545 -8142 9556 -8159 9566 -8168 9578
--8186 9587 -8201 9598 -8214 9607 -8225 9616 -8240 9624 -8255 9633 -8264 9641
--8278 9649 -8285 9656 -8294 9664 -8305 9670 -8315 9677 -8325 9684 -8330 9690
--8343 9696 -8355 9702 -8360 9707 -8369 9713 -8375 9718 -8383 9723 -8389 9727
--8402 9733 -8401 9737 -8407 9741 -8412 9745
-214: 14679270 -4580690 -10260 9924 -10270 9928 -10260 9928 -10280 9932
--10280 9931 -10290 9936 -10300 9938 -10300 9937 -10310 9939 -10320 9944
--10330 9948 -10340 9948 -10360 9954 -10350 9955 -10370 9956 -10380 9960
--10400 9964 -10410 9966 -10420 9967 -10420 9970 -10450 9972 -10450 9974
--10450 9978 -10470 9980 -10470 9981 -10490 9985 -10490 9987 -10510 9987
--10510 9990 -10510 9993 -10530 9997 -10550 9997 -10540 10000 -10550 10003
--10560 10005 -10570 10010 -10570 10012 -10580 10016 -10590 10019 -10610 10025
--10610 10027 -10610 10032 -10630 10037 -10640 10041 -10660 10044 -10660 10049
--10680 10054 -10700 10059 -10710 10064 -10720 10066 -10750 10073 -10750 10079
--10770 10082 -10790 10087 -10800 10094 -10820 10096 -10840 10100 -10850 10103
--10880 10107 -10890 10109 -10900 10113 -10920 10114 -10930 10116 -10950 10118
--10960 10119 -10970 10120 -10990 10119 -10990 10122 -11000 10120 -11020 10119
--11010 10120 -11020 10118 -11030 10118 -11040 10119 -11040 10119 -11050 10119
--11040 10118 -11040 10119 -11050 10119 -11050 10120 -11060 10124 -11050 10126
--11050 10128 -11060 10132 -11060 10135 -11080 10140 -11070 10144 -11070 10150
--11080 10157 -11090 10165 -11100 10170 -11110 10179 -11110 10188 -11130 10198
--11150 10206 -11160 10216 -11170 10226 -11190 10234 -11210 10245 -11230 10254
--11250 10263 -11270 10270 -11280 10280 -11310 10289 -11330 10294 -11340 10300
--11370 10307 -11390 10310 -11410 10314 -11430 10315 -11440 10316 -11460 10316
--11470 10316 -11490 10313 -11500 10310 -11500 10305 -11510 10300 -11510 10290
--11520 10282 -11520 10272 -11520 10264 -11520 10250 -11510 10238 -11500 10225
--11480 10209 -11470 10195 -11450 10179 -11440 10168 -11420 10151 -11390 10135
--11360 10120 -11350 10105 -11320 10091 -11290 10076 -11260 10065 -11230 10051
--11200 10039 -11170 10029 -11150 10020 -11120 10014 -11100 10005 -11060 9998
--11040 9994 -11010 9992 -11000 9989 -10980 9990 -10960 9992 -10940 9994
--10940 10000 -10920 10006 -10920 10013 -10930 10021 -10930 10034 -10930 10045
--10930 10058 -10940 10072 -10950 10086 -10990 10098 -11000 10117 -11030 10133
--11060 10153 -11080 10170 -11120 10187 -11150 10202 -11200 10220 -11240 10238
--11280 10257 -11320 10273 -11360 10292 -11410 10307 -11430 10320 -11490 10334
--11530 10351 -11570 10361 -11600 10374 -11630 10384 -11660 10392 -11680 10402
--11700 10409 -11730 10415 -11710 10419 -11720 10425 -11690 10429 -11670 10428
--11650 10431 -11620 10431 -11560 10433 -11490 10434 -11410 10432 -11330 10430
--11220 10427 -11110 10428 -10980 10429 -10810 10431 -10650 10433 -10470 10433
--10260 10435 -10060 10438 -9820 10449 -9560 10458 -9300 10470 -9000 10480
--8690 10495 -8370 10512 -8030 10535 -7660 10560 -7290 10587 -6880 10618
--6470 10651 -6030 10689 -5590 10730 -5130 10775 -4650 10825 -4150 10878
--3630 10935 -3120 10994 -2590 11058 -2040 11123 -1480 11192 -910 11269
--330 11347 260 11428 840 11505 1440 11586 2050 11673 2690 11765 3310 11858
-3940 11949 4550 12032 5160 12115 5800 12206 6440 12301 7090 12395 7720 12476
-8300 12543 8920 12607 9510 12676 10080 12734 10630 12782 11170 12818 11680 12841
-12180 12841 12640 12823 13080 12797 13480 12766 13790 12727 14110 12668
-14390 12571 14590 12447 14760 12317 14880 12185 14990 12060 15040 11947
-15020 11847 14920 11746 14810 11649 14670 11567 14510 11499 14320 11451
-14050 11425 13730 11421 13370 11427 12980 11432 12580 11444 12170 11471
-11730 11522 11280 11594 10860 11668 10420 11733 9930 11785 9380 11820
-8790 11830 8200 11815 7610 11787 6980 11753 6270 11710 5490 11644 4640 11547
-3680 11428 2710 11292 1740 11146 900 11006 190 10879 -430 10776 -1010 10693
--1520 10619 -1970 10535 -2280 10442 -2490 10344 -2630 10237 -2770 10127
--2880 10010 -2980 9891 -3070 9762 -3180 9590 -3420 9399 -3650 9208 -3930 9028
--4160 8855 -4430 8685 -4720 8514 -5070 8355 -5480 8223 -5940 8131 -6410 8070
--6890 8031 -7420 7999 -7970 7968 -8540 7935 -9110 7904 -9640 7882 -10120 7874
--10550 7893 -10900 7934 -11220 7994 -11500 8067 -11790 8154 -12100 8255
--12430 8360 -12760 8473 -13100 8597 -13430 8731 -13750 8866 -14100 9003
--14470 9141 -14830 9281 -15240 9422 -15630 9557 -16020 9691 -16380 9833
--16740 9999 -17080 10189 -17390 10392 -17700 10595 -18010 10794 -18270 10995
--18510 11201 -18680 11414 -18840 11626 -19000 11831 -19150 12027 -19320 12200
--19430 12343 -19550 12455 -19630 12540 -19680 12611 -19780 12666 -19890 12701
--20060 12708 -20230 12680 -20440 12625 -20640 12557 -20860 12488 -21060 12404
--21320 12321 -21630 12234 -21920 12139 -22220 12038 -22470 11936 -22710 11839
--22920 11749 -23100 11667 -23320 11590 -23520 11513 -23770 11434 -24040 11355
--24310 11275 -24570 11195 -24850 11113 -25150 11030 -25480 10943 -25860 10848
--26280 10746 -26720 10638 -27140 10522 -27590 10399 -28040 10270 -28460 10134
--28880 9987 -29290 9834 -29640 9673 -29940 9510 -30180 9348 -30330 9184
--30410 9021 -30440 8854 -30390 8687 -30280 8519 -30090 8352 -29850 8188
--29540 8027 -29160 7870 -28770 7711 -28330 7551 -27880 7383 -27430 7211
--26960 7035 -26490 6858 -26010 6679 -25530 6496 -25060 6308 -24630 6116
--24220 5922 -23800 5729 -23360 5537 -22870 5348 -22420 5161 -21970 4977
--21560 4800 -21110 4628 -20580 4463 -19930 4305 -19200 4159 -18390 4039
--17560 3937 -16720 3849 -15920 3777 -15160 3719 -14430 3678 -13750 3654
--13060 3647 -12410 3656 -11750 3683 -11110 3726 -10450 3783 -9820 3854
--9190 3937 -8580 4029 -7990 4130 -7440 4239 -6930 4354 -6460 4478 -6030 4606
--5660 4739 -5330 4876 -5040 5016 -4820 5159 -4620 5304 -4470 5450 -4360 5595
--4270 5742 -4220 5887 -4190 6030 -4200 6172 -4200 6313 -4250 6450 -4310 6586
--4360 6717 -4440 6847 -4520 6971 -4620 7093 -4730 7212 -4820 7326 -4940 7438
--5070 7544 -5170 7647 -5300 7746 -5410 7842 -5540 7934 -5650 8022 -5770 8107
--5880 8186 -5990 8263 -6100 8338 -6220 8409 -6330 8478 -6440 8542 -6550 8601
--6650 8656 -6760 8710 -6840 8765 -6970 8821 -7040 8869 -7080 8913 -7140 8955
--7210 8995 -7270 9035 -7330 9070 -7390 9105 -7460 9137 -7510 9170 -7560 9200
--7610 9228 -7660 9255 -7700 9279 -7740 9303 -7780 9327 -7810 9349 -7850 9370
--7890 9389 -7920 9407 -7940 9425 -7970 9442 -7997 9459 -8020 9474 -8047 9488
--8069 9502 -8088 9516 -8105 9528 -8125 9541 -8141 9552 -8161 9564 -8176 9574
--8189 9584 -8208 9594 -8218 9604 -8231 9613 -8245 9622 -8256 9629 -8270 9638
--8280 9646 -8292 9653 -8301 9661 -8314 9668 -8322 9674 -8327 9680 -8335 9688
--8350 9693 -8357 9699 -8371 9704 -8374 9710 -8381 9716 -8388 9720 -8396 9725
--8404 9730 -8408 9734 -8413 9739 -8420 9742
-215: 14712530 -4572269 -10270 9924 -10260 9931 -10270 9928 -10280 9931
--10280 9935 -10290 9936 -10300 9937 -10310 9940 -10310 9941 -10320 9945
--10330 9948 -10340 9950 -10350 9954 -10360 9954 -10370 9958 -10390 9960
--10390 9963 -10410 9967 -10420 9967 -10430 9969 -10440 9972 -10440 9975
--10460 9977 -10450 9980 -10480 9980 -10490 9984 -10490 9987 -10500 9987
--10510 9989 -10520 9993 -10530 9995 -10530 9997 -10550 9999 -10550 10004
--10550 10005 -10570 10009 -10570 10011 -10580 10016 -10590 10018 -10600 10024
--10610 10026 -10610 10032 -10620 10036 -10650 10037 -10650 10043 -10660 10047
--10670 10053 -10700 10059 -10700 10061 -10720 10066 -10740 10071 -10740 10077
--10770 10081 -10780 10086 -10790 10091 -10820 10093 -10820 10097 -10850 10103
--10860 10103 -10880 10108 -10900 10112 -10910 10111 -10920 10112 -10930 10115
--10960 10115 -10960 10117 -10970 10118 -10980 10118 -10990 10119 -11000 10115
--11010 10116 -11000 10115 -11020 10116 -11030 10116 -11030 10115 -11030 10116
--11030 10115 -11030 10114 -11040 10114 -11040 10118 -11030 10121 -11040 10122
--11050 10125 -11040 10128 -11050 10131 -11050 10134 -11060 10140 -11060 10146
--11060 10153 -11080 10160 -11080 10165 -11100 10174 -11100 10184 -11110 10191
--11130 10200 -11140 10211 -11150 10220 -11170 10227 -11190 10239 -11210 10249
--11230 10255 -11240 10266 -11260 10273 -11290 10282 -11310 10287 -11320 10294
--11340 10300 -11370 10305 -11380 10308 -11400 10309 -11420 10310 -11430 10311
--11450 10311 -11460 10308 -11470 10306 -11470 10301 -11480 10296 -11490 10289
--11490 10280 -11490 10269 -11490 10261 -11490 10249 -11490 10237 -11470 10223
--11460 10209 -11440 10196 -11430 10181 -11410 10168 -11390 10153 -11370 10137
--11340 10122 -11320 10108 -11290 10092 -11270 10079 -11240 10068 -11210 10056
--11170 10044 -11150 10032 -11120 10023 -11100 10016 -11070 10008 -11050 10001
--11010 9996 -10980 9994 -10970 9990 -10960 9989 -10940 9992 -10910 9994
--10910 9997 -10890 10004 -10900 10010 -10890 10017 -10890 10028 -10890 10037
--10890 10050 -10910 10062 -10910 10074 -10940 10087 -10960 10103 -10980 10119
--11010 10136 -11040 10151 -11060 10168 -11100 10183 -11140 10198 -11180 10216
--11230 10232 -11260 10248 -11310 10264 -11340 10278 -11370 10291 -11420 10304
--11470 10317 -11520 10330 -11540 10339 -11570 10350 -11590 10357 -11620 10366
--11650 10373 -11660 10378 -11670 10383 -11650 10387 -11650 10390 -11630 10392
--11610 10393 -11580 10394 -11520 10397 -11450 10397 -11390 10396 -11310 10394
--11210 10393 -11100 10393 -10980 10396 -10830 10399 -10650 10401 -10490 10403
--10300 10406 -10100 10410 -9870 10421 -9620 10431 -9360 10444 -9090 10456
--8780 10471 -8470 10490 -8140 10513 -7790 10539 -7420 10567 -7040 10596
--6630 10631 -6200 10670 -5780 10710 -5330 10755 -4860 10805 -4370 10857
--3870 10913 -3360 10973 -2840 11034 -2320 11099 -1760 11168 -1200 11240
--630 11318 -60 11396 530 11472 1090 11550 1710 11635 2320 11724 2940 11813
-3570 11901 4160 11979 4760 12060 5390 12146 6020 12237 6650 12324 7260 12401
-7850 12464 8440 12524 9040 12587 9580 12642 10120 12686 10660 12718 11160 12739
-11630 12742 12100 12725 12520 12700 12920 12673 13240 12635 13540 12582
-13830 12499 14040 12389 14210 12275 14340 12161 14440 12052 14510 11952
-14500 11860 14450 11772 14340 11688 14210 11611 14070 11548 13870 11503
-13650 11480 13350 11476 13030 11479 12670 11481 12310 11488 11910 11506
-11480 11546 11040 11603 10610 11664 10170 11716 9680 11754 9170 11779
-8590 11783 8020 11764 7460 11733 6850 11699 6180 11653 5420 11588 4620 11498
-3740 11387 2840 11262 1940 11128 1160 10998 480 10878 -110 10774 -660 10686
--1170 10604 -1640 10517 -1980 10421 -2220 10317 -2400 10205 -2550 10086
--2690 9967 -2820 9847 -2940 9724 -3110 9574 -3360 9390 -3620 9198 -3920 9017
--4190 8852 -4480 8700 -4760 8556 -5100 8416 -5480 8296 -5900 8198 -6340 8124
--6810 8073 -7320 8035 -7840 8004 -8400 7977 -8960 7955 -9480 7937 -9950 7935
--10370 7953 -10740 7991 -11070 8044 -11370 8111 -11670 8190 -11990 8280
--12300 8380 -12630 8489 -12980 8608 -13330 8735 -13660 8867 -14010 8998
--14380 9132 -14730 9268 -15130 9406 -15520 9543 -15880 9677 -16230 9821
--16580 9982 -16910 10165 -17220 10359 -17520 10551 -17810 10741 -18070 10930
--18300 11123 -18490 11323 -18670 11521 -18810 11713 -18970 11893 -19130 12057
--19260 12193 -19380 12300 -19480 12387 -19550 12458 -19660 12513 -19780 12551
--19930 12562 -20090 12541 -20290 12497 -20470 12442 -20680 12385 -20870 12311
--21120 12236 -21380 12159 -21660 12073 -21950 11984 -22210 11892 -22440 11801
--22640 11715 -22840 11633 -23050 11556 -23260 11479 -23520 11403 -23760 11325
--24040 11247 -24290 11167 -24570 11086 -24900 11000 -25210 10912 -25590 10816
--25980 10714 -26370 10606 -26800 10491 -27200 10372 -27610 10245 -28010 10112
--28400 9972 -28760 9825 -29090 9671 -29360 9514 -29580 9358 -29730 9200
--29810 9041 -29830 8881 -29800 8720 -29700 8556 -29540 8394 -29310 8231
--29030 8072 -28700 7915 -28330 7760 -27940 7600 -27520 7436 -27100 7268
--26660 7097 -26210 6924 -25760 6749 -25290 6571 -24850 6390 -24420 6203
--24010 6018 -23590 5831 -23150 5648 -22670 5467 -22200 5288 -21750 5114
--21340 4946 -20910 4782 -20370 4627 -19730 4478 -19090 4339 -18370 4223
--17580 4124 -16770 4040 -15980 3972 -15210 3918 -14470 3879 -13770 3856
--13090 3848 -12420 3854 -11770 3875 -11150 3911 -10530 3963 -9920 4026
--9330 4102 -8770 4188 -8220 4281 -7710 4384 -7220 4493 -6780 4609 -6380 4731
--6000 4857 -5700 4988 -5410 5121 -5180 5257 -4970 5395 -4810 5535 -4690 5674
--4580 5814 -4510 5954 -4480 6092 -4450 6229 -4450 6364 -4480 6497 -4530 6628
--4560 6756 -4620 6881 -4690 7002 -4780 7122 -4860 7236 -4960 7349 -5060 7456
--5170 7562 -5280 7662 -5390 7759 -5510 7853 -5600 7944 -5730 8030 -5830 8113
--5930 8192 -6050 8268 -6150 8341 -6260 8412 -6360 8480 -6470 8543 -6580 8601
--6680 8656 -6770 8709 -6870 8764 -6990 8820 -7050 8867 -7100 8911 -7150 8952
--7220 8993 -7270 9032 -7350 9068 -7400 9101 -7460 9135 -7510 9166 -7570 9197
--7620 9225 -7660 9251 -7700 9276 -7750 9300 -7780 9324 -7820 9345 -7860 9367
--7890 9385 -7920 9404 -7950 9422 -7970 9438 -8000 9455 -8030 9471 -8050 9485
--8070 9499 -8095 9512 -8110 9525 -8131 9538 -8148 9549 -8165 9561 -8182 9570
--8194 9582 -8209 9591 -8224 9601 -8239 9609 -8252 9619 -8261 9627 -8275 9635
--8287 9643 -8301 9650 -8308 9658 -8317 9665 -8326 9671 -8333 9678 -8345 9684
--8356 9691 -8363 9696 -8374 9702 -8381 9707 -8389 9713 -8395 9718 -8400 9722
--8407 9727 -8413 9732 -8418 9736 -8427 9740
-216: 14745800 -4563856 -10260 9927 -10270 9931 -10270 9930 -10280 9933
--10280 9935 -10300 9937 -10290 9937 -10310 9942 -10320 9942 -10310 9946
--10340 9949 -10350 9950 -10340 9952 -10360 9955 -10370 9959 -10390 9962
--10390 9964 -10410 9966 -10410 9967 -10430 9968 -10430 9971 -10450 9976
--10450 9976 -10470 9978 -10470 9982 -10490 9983 -10480 9986 -10500 9988
--10510 9990 -10520 9992 -10530 9996 -10530 9994 -10540 9999 -10550 10003
--10550 10004 -10560 10008 -10580 10012 -10570 10014 -10590 10018 -10590 10023
--10610 10026 -10610 10029 -10620 10033 -10630 10036 -10650 10043 -10660 10047
--10680 10053 -10680 10055 -10700 10060 -10710 10066 -10730 10070 -10750 10075
--10760 10079 -10770 10084 -10790 10088 -10800 10091 -10820 10096 -10840 10099
--10850 10103 -10870 10105 -10890 10108 -10900 10110 -10900 10110 -10930 10111
--10940 10112 -10960 10114 -10950 10115 -10970 10116 -10980 10114 -10990 10113
--10990 10114 -11000 10113 -11010 10112 -11000 10113 -11020 10112 -11020 10111
--11020 10112 -11020 10111 -11030 10111 -11020 10115 -11020 10117 -11030 10119
--11030 10121 -11030 10124 -11030 10126 -11040 10130 -11040 10137 -11050 10141
--11060 10148 -11060 10155 -11060 10161 -11080 10169 -11080 10176 -11100 10185
--11110 10195 -11130 10206 -11130 10214 -11150 10221 -11170 10232 -11190 10243
--11210 10249 -11220 10260 -11240 10267 -11260 10274 -11270 10282 -11300 10287
--11330 10295 -11340 10299 -11360 10301 -11370 10303 -11390 10304 -11410 10307
--11420 10306 -11440 10303 -11440 10301 -11450 10298 -11450 10292 -11450 10285
--11470 10277 -11460 10267 -11470 10258 -11460 10249 -11460 10236 -11440 10221
--11440 10210 -11410 10197 -11410 10181 -11380 10170 -11360 10155 -11350 10141
--11320 10123 -11300 10109 -11270 10096 -11240 10082 -11220 10071 -11180 10059
--11160 10047 -11120 10036 -11110 10026 -11070 10020 -11050 10012 -11010 10004
--10990 9999 -10960 9995 -10950 9990 -10930 9991 -10920 9992 -10880 9994
--10870 9997 -10860 10002 -10860 10006 -10870 10013 -10850 10022 -10850 10031
--10860 10042 -10870 10053 -10880 10064 -10890 10076 -10910 10090 -10940 10106
--10960 10121 -10990 10134 -11010 10149 -11050 10165 -11090 10178 -11110 10194
--11180 10211 -11200 10223 -11250 10238 -11270 10250 -11320 10263 -11370 10275
--11420 10286 -11440 10299 -11480 10307 -11510 10316 -11540 10324 -11560 10332
--11590 10338 -11610 10344 -11610 10347 -11610 10352 -11590 10353 -11590 10356
--11570 10357 -11540 10358 -11490 10361 -11430 10361 -11370 10361 -11290 10360
--11200 10358 -11100 10360 -10970 10363 -10840 10368 -10680 10369 -10510 10373
--10340 10376 -10130 10382 -9920 10393 -9690 10404 -9450 10417 -9160 10431
--8890 10446 -8570 10465 -8260 10489 -7920 10516 -7560 10544 -7190 10574
--6800 10609 -6380 10646 -5970 10689 -5530 10732 -5080 10781 -4600 10833
--4110 10888 -3620 10946 -3110 11008 -2590 11070 -2060 11138 -1500 11209
--950 11284 -370 11360 180 11434 750 11509 1350 11591 1950 11678 2560 11764
-3170 11847 3760 11924 4340 11999 4960 12083 5580 12168 6190 12250 6800 12323
-7370 12383 7950 12439 8530 12495 9070 12548 9600 12589 10110 12619 10610 12639
-11080 12642 11540 12627 11940 12605 12340 12580 12660 12547 12960 12498
-13240 12426 13480 12331 13640 12229 13780 12133 13880 12037 13950 11948
-13970 11865 13920 11787 13850 11714 13740 11646 13600 11587 13420 11542
-13200 11521 12950 11517 12640 11517 12330 11519 11980 11520 11610 11532
-11200 11562 10770 11607 10340 11655 9910 11695 9430 11722 8930 11740 8360 11735
-7820 11714 7280 11682 6690 11646 6050 11599 5340 11535 4580 11450 3770 11347
-2930 11230 2100 11105 1370 10985 720 10871 150 10767 -370 10673 -880 10587
--1350 10495 -1710 10399 -2000 10292 -2200 10177 -2370 10054 -2540 9932
--2690 9811 -2840 9688 -3050 9557 -3300 9385 -3580 9199 -3890 9020 -4200 8858
--4490 8717 -4800 8587 -5130 8465 -5510 8354 -5880 8259 -6310 8181 -6750 8121
--7230 8078 -7740 8043 -8270 8018 -8800 8001 -9310 7988 -9780 7987 -10200 8007
--10570 8043 -10920 8093 -11240 8153 -11560 8226 -11860 8309 -12200 8402
--12520 8504 -12860 8619 -13210 8740 -13550 8865 -13900 8993 -14270 9123
--14620 9254 -14990 9390 -15380 9525 -15730 9658 -16070 9800 -16400 9958
--16730 10134 -17030 10318 -17310 10503 -17600 10682 -17850 10861 -18080 11043
--18280 11231 -18450 11416 -18620 11596 -18760 11763 -18920 11915 -19060 12045
--19190 12150 -19290 12235 -19380 12307 -19490 12363 -19630 12402 -19770 12418
--19930 12404 -20110 12369 -20270 12324 -20470 12277 -20670 12216 -20890 12149
--21130 12077 -21380 12002 -21660 11921 -21910 11839 -22140 11754 -22350 11673
--22550 11593 -22750 11518 -22970 11441 -23230 11365 -23470 11290 -23730 11214
--23990 11135 -24290 11054 -24580 10970 -24910 10880 -25260 10784 -25630 10685
--26010 10577 -26400 10465 -26780 10347 -27160 10224 -27530 10095 -27900 9960
--28230 9819 -28520 9671 -28770 9521 -28980 9370 -29110 9217 -29200 9064
--29220 8909 -29190 8754 -29120 8595 -28960 8437 -28760 8278 -28510 8121
--28200 7966 -27880 7812 -27510 7656 -27130 7495 -26730 7330 -26320 7164
--25900 6995 -25470 6826 -25020 6653 -24590 6477 -24180 6299 -23780 6119
--23360 5940 -22910 5765 -22440 5592 -21970 5421 -21530 5255 -21120 5095
--20670 4941 -20160 4794 -19530 4653 -18960 4523 -18290 4410 -17560 4313
--16800 4233 -16020 4166 -15260 4116 -14540 4079 -13820 4056 -13130 4047
--12480 4051 -11850 4069 -11220 4100 -10620 4145 -10040 4203 -9480 4272
--8950 4350 -8430 4438 -7940 4533 -7490 4636 -7070 4746 -6680 4861 -6330 4980
--6010 5104 -5750 5230 -5510 5360 -5300 5492 -5120 5624 -4990 5759 -4880 5893
--4800 6026 -4730 6158 -4710 6291 -4690 6421 -4710 6549 -4730 6676 -4760 6799
--4810 6921 -4880 7038 -4930 7154 -5010 7266 -5100 7375 -5190 7480 -5290 7583
--5390 7681 -5480 7776 -5600 7867 -5700 7957 -5800 8042 -5900 8123 -6000 8200
--6100 8275 -6200 8347 -6310 8417 -6410 8484 -6500 8546 -6610 8604 -6710 8658
--6800 8710 -6900 8765 -7010 8819 -7070 8867 -7120 8910 -7180 8952 -7230 8992
--7290 9030 -7360 9066 -7410 9099 -7470 9133 -7520 9164 -7570 9194 -7630 9223
--7670 9248 -7710 9274 -7760 9297 -7780 9321 -7830 9342 -7860 9364 -7890 9383
--7930 9400 -7950 9419 -7990 9436 -8010 9452 -8030 9468 -8060 9482 -8070 9496
--8100 9509 -8120 9522 -8130 9535 -8160 9546 -8164 9557 -8189 9568 -8202 9579
--8214 9588 -8230 9598 -8247 9607 -8258 9616 -8267 9624 -8283 9632 -8295 9640
--8306 9648 -8313 9655 -8324 9662 -8332 9668 -8346 9676 -8350 9681 -8361 9688
--8369 9694 -8378 9699 -8388 9705 -8396 9710 -8401 9715 -8404 9720 -8411 9724
--8418 9729 -8430 9734 -8432 9737
-217: 14779090 -4555447 -10260 9931 -10260 9929 -10280 9931 -10280 9934
--10280 9936 -10300 9938 -10300 9939 -10300 9943 -10320 9944 -10320 9945
--10340 9949 -10340 9952 -10350 9953 -10360 9955 -10370 9959 -10390 9961
--10390 9964 -10400 9966 -10420 9967 -10420 9968 -10430 9971 -10440 9974
--10460 9977 -10460 9979 -10470 9981 -10480 9984 -10490 9986 -10500 9987
--10500 9989 -10520 9992 -10520 9993 -10540 9994 -10540 10000 -10540 10001
--10550 10005 -10560 10007 -10570 10010 -10580 10013 -10580 10018 -10590 10021
--10610 10025 -10610 10027 -10610 10031 -10630 10037 -10640 10041 -10660 10046
--10670 10052 -10680 10054 -10690 10059 -10710 10064 -10720 10069 -10740 10072
--10750 10078 -10770 10083 -10780 10086 -10800 10090 -10810 10093 -10830 10096
--10840 10102 -10860 10102 -10880 10105 -10890 10106 -10900 10108 -10910 10109
--10930 10110 -10940 10109 -10950 10113 -10960 10114 -10970 10111 -10970 10111
--10980 10112 -10990 10109 -10990 10109 -11000 10110 -11000 10108 -11010 10108
--11010 10109 -11000 10107 -11010 10109 -11020 10111 -11010 10113 -11010 10114
--11020 10118 -11020 10118 -11010 10124 -11030 10127 -11030 10132 -11030 10137
--11040 10143 -11040 10150 -11050 10157 -11060 10163 -11070 10169 -11090 10180
--11090 10191 -11100 10199 -11120 10208 -11140 10217 -11150 10226 -11160 10234
--11190 10244 -11200 10254 -11230 10261 -11230 10267 -11250 10275 -11280 10281
--11300 10288 -11310 10292 -11340 10295 -11350 10298 -11360 10298 -11380 10302
--11400 10301 -11400 10299 -11420 10297 -11420 10292 -11430 10290 -11420 10281
--11440 10274 -11440 10264 -11440 10256 -11440 10247 -11430 10234 -11420 10222
--11400 10210 -11390 10198 -11390 10183 -11350 10170 -11350 10157 -11320 10143
--11290 10126 -11270 10112 -11250 10098 -11220 10087 -11200 10074 -11160 10061
--11140 10051 -11100 10039 -11080 10030 -11050 10023 -11010 10015 -10990 10008
--10970 10002 -10940 9996 -10920 9993 -10910 9993 -10890 9992 -10850 9994
--10850 9995 -10830 10001 -10830 10005 -10820 10010 -10830 10016 -10810 10025
--10820 10036 -10830 10045 -10840 10055 -10860 10067 -10860 10078 -10890 10094
--10920 10105 -10940 10120 -10960 10133 -11000 10145 -11040 10159 -11060 10175
--11110 10187 -11160 10200 -11180 10213 -11220 10225 -11260 10236 -11310 10248
--11360 10258 -11390 10269 -11410 10277 -11450 10286 -11480 10291 -11510 10299
--11530 10305 -11560 10309 -11560 10314 -11560 10318 -11550 10318 -11550 10322
--11530 10321 -11510 10323 -11450 10326 -11410 10328 -11340 10326 -11280 10327
--11200 10325 -11090 10327 -10980 10332 -10850 10335 -10700 10338 -10550 10343
--10370 10347 -10180 10352 -9980 10365 -9760 10376 -9510 10390 -9260 10404
--8980 10420 -8690 10440 -8380 10463 -8050 10491 -7710 10519 -7350 10550
--6970 10584 -6570 10622 -6160 10662 -5740 10707 -5300 10755 -4830 10805
--4360 10860 -3880 10917 -3390 10977 -2880 11038 -2350 11104 -1820 11173
--1260 11246 -720 11321 -160 11391 390 11465 970 11543 1570 11627 2170 11709
-2760 11790 3340 11863 3910 11936 4510 12015 5120 12096 5730 12173 6310 12243
-6880 12299 7450 12352 8000 12405 8540 12453 9070 12491 9550 12520 10050 12539
-10510 12543 10950 12531 11360 12511 11730 12489 12070 12459 12360 12417
-12640 12354 12880 12271 13070 12182 13200 12098 13310 12015 13370 11937
-13400 11862 13400 11793 13330 11728 13240 11669 13100 11613 12940 11574
-12740 11550 12510 11545 12240 11544 11940 11544 11610 11543 11260 11550
-10890 11571 10470 11605 10060 11641 9640 11670 9170 11691 8670 11698 8140 11690
-7590 11666 7070 11632 6500 11595 5900 11546 5230 11484 4520 11404 3760 11305
-2990 11197 2220 11081 1530 10966 910 10858 370 10754 -150 10660 -630 10567
--1100 10472 -1490 10374 -1790 10268 -2030 10153 -2240 10029 -2420 9903
--2590 9781 -2770 9660 -3000 9537 -3250 9380 -3550 9205 -3860 9033 -4180 8875
--4500 8737 -4820 8615 -5160 8505 -5520 8403 -5900 8313 -6280 8235 -6710 8172
--7170 8125 -7650 8087 -8150 8061 -8660 8044 -9150 8034 -9600 8036 -10040 8054
--10410 8090 -10770 8137 -11110 8194 -11420 8260 -11750 8338 -12080 8424
--12410 8521 -12750 8629 -13080 8745 -13430 8864 -13780 8986 -14140 9111
--14490 9241 -14850 9373 -15210 9504 -15570 9636 -15890 9774 -16210 9928
--16530 10097 -16820 10273 -17100 10448 -17370 10619 -17610 10788 -17840 10961
--18040 11137 -18240 11310 -18390 11480 -18540 11636 -18690 11779 -18840 11900
--18960 12003 -19070 12087 -19170 12157 -19310 12215 -19430 12256 -19590 12275
--19730 12268 -19900 12241 -20050 12205 -20230 12167 -20440 12118 -20640 12057
--20870 11993 -21100 11925 -21360 11853 -21580 11777 -21830 11701 -22030 11625
--22230 11548 -22440 11474 -22670 11399 -22890 11325 -23150 11251 -23410 11176
--23670 11099 -23940 11020 -24240 10937 -24570 10847 -24900 10754 -25250 10655
--25610 10550 -25980 10442 -26330 10326 -26680 10207 -27030 10081 -27370 9950
--27670 9815 -27950 9674 -28190 9530 -28370 9384 -28500 9236 -28570 9088
--28610 8939 -28580 8788 -28510 8636 -28380 8482 -28190 8327 -27960 8172
--27700 8022 -27400 7869 -27060 7716 -26700 7558 -26340 7397 -25960 7236
--25560 7072 -25140 6908 -24720 6740 -24310 6571 -23900 6399 -23510 6226
--23110 6056 -22660 5886 -22180 5721 -21730 5558 -21290 5400 -20880 5249
--20430 5102 -19940 4964 -19330 4829 -18800 4708 -18180 4599 -17490 4506
--16780 4426 -16040 4362 -15310 4312 -14590 4277 -13890 4254 -13210 4245
--12560 4248 -11940 4262 -11320 4289 -10740 4330 -10170 4383 -9640 4445
--9130 4517 -8630 4598 -8170 4686 -7730 4783 -7330 4886 -6960 4994 -6620 5108
--6310 5224 -6040 5344 -5820 5467 -5590 5593 -5430 5719 -5270 5848 -5160 5975
--5070 6104 -5000 6230 -4950 6357 -4940 6483 -4930 6606 -4930 6728 -4960 6847
--5000 6964 -5050 7079 -5100 7191 -5170 7299 -5230 7406 -5320 7508 -5410 7607
--5510 7704 -5600 7796 -5690 7886 -5790 7972 -5890 8056 -5970 8136 -6080 8212
--6170 8284 -6260 8356 -6360 8424 -6450 8490 -6550 8552 -6650 8608 -6740 8662
--6840 8713 -6920 8767 -7040 8821 -7100 8868 -7150 8911 -7190 8952 -7260 8992
--7310 9029 -7370 9066 -7420 9098 -7480 9132 -7540 9162 -7590 9193 -7630 9221
--7690 9247 -7720 9271 -7760 9295 -7800 9318 -7830 9341 -7870 9361 -7900 9380
--7940 9399 -7960 9416 -7990 9433 -8010 9450 -8040 9465 -8070 9479 -8080 9493
--8110 9507 -8120 9519 -8140 9532 -8160 9544 -8180 9554 -8190 9566 -8210 9575
--8220 9586 -8240 9595 -8252 9604 -8263 9613 -8273 9622 -8293 9629 -8302 9638
--8312 9645 -8319 9652 -8333 9660 -8337 9666 -8354 9672 -8356 9679 -8369 9685
--8378 9691 -8386 9697 -8394 9702 -8403 9708 -8405 9712 -8414 9717 -8417 9723
--8426 9726 -8432 9731 -8436 9735
-218: 14812410 -4547043 -10260 9931 -10270 9930 -10280 9933 -10280 9936
--10290 9936 -10290 9938 -10300 9942 -10310 9944 -10320 9943 -10320 9947
--10340 9949 -10340 9952 -10350 9953 -10360 9956 -10370 9958 -10380 9962
--10390 9963 -10400 9966 -10420 9968 -10420 9968 -10430 9972 -10440 9974
--10450 9978 -10460 9978 -10470 9981 -10480 9982 -10490 9985 -10490 9987
--10500 9988 -10520 9991 -10520 9992 -10530 9995 -10540 9999 -10540 10001
--10550 10004 -10560 10008 -10560 10007 -10580 10013 -10580 10017 -10590 10019
--10600 10023 -10600 10027 -10620 10030 -10620 10036 -10640 10040 -10650 10044
--10670 10050 -10670 10054 -10690 10059 -10700 10062 -10710 10066 -10730 10071
--10750 10076 -10760 10081 -10770 10084 -10800 10087 -10800 10092 -10820 10094
--10840 10098 -10850 10100 -10860 10102 -10880 10105 -10890 10105 -10910 10107
--10910 10106 -10920 10108 -10940 10111 -10950 10109 -10960 10111 -10960 10107
--10970 10108 -10980 10107 -10980 10107 -10980 10105 -10990 10106 -11000 10106
--10990 10106 -11000 10103 -11000 10105 -11000 10108 -11000 10109 -11000 10109
--11000 10115 -11000 10115 -11010 10118 -11010 10124 -11020 10128 -11010 10132
--11020 10139 -11030 10146 -11040 10150 -11040 10158 -11060 10165 -11070 10175
--11080 10184 -11080 10193 -11100 10202 -11120 10211 -11130 10219 -11150 10229
--11160 10238 -11180 10248 -11210 10254 -11210 10261 -11240 10267 -11250 10276
--11270 10281 -11290 10286 -11310 10288 -11330 10293 -11330 10294 -11360 10295
--11370 10296 -11380 10294 -11390 10294 -11390 10288 -11400 10284 -11400 10278
--11410 10270 -11420 10262 -11410 10254 -11410 10243 -11400 10234 -11400 10224
--11370 10209 -11370 10198 -11360 10185 -11330 10172 -11320 10158 -11300 10144
--11280 10129 -11240 10114 -11230 10103 -11190 10090 -11170 10077 -11150 10065
--11110 10053 -11080 10044 -11060 10033 -11010 10027 -11000 10017 -10970 10012
--10950 10005 -10920 9999 -10890 9996 -10880 9993 -10860 9993 -10830 9994
--10820 9995 -10800 9999 -10800 10004 -10790 10008 -10780 10013 -10790 10020
--10780 10030 -10790 10038 -10800 10047 -10810 10058 -10830 10068 -10840 10081
--10870 10093 -10900 10104 -10920 10120 -10940 10127 -10980 10141 -11020 10155
--11050 10166 -11100 10179 -11130 10189 -11170 10202 -11200 10210 -11250 10222
--11300 10231 -11330 10241 -11360 10248 -11390 10256 -11430 10262 -11440 10267
--11490 10273 -11500 10276 -11510 10281 -11510 10285 -11510 10287 -11510 10289
--11490 10287 -11480 10290 -11430 10292 -11390 10294 -11320 10294 -11260 10293
--11190 10293 -11100 10295 -10990 10300 -10860 10304 -10730 10308 -10580 10312
--10410 10317 -10230 10325 -10040 10335 -9830 10349 -9590 10361 -9350 10378
--9080 10393 -8810 10413 -8500 10437 -8190 10464 -7860 10492 -7510 10524
--7140 10556 -6760 10595 -6360 10634 -5950 10679 -5530 10726 -5070 10776
--4620 10828 -4140 10885 -3660 10943 -3170 11003 -2660 11066 -2140 11134
--1600 11205 -1060 11276 -520 11346 30 11415 600 11492 1170 11572 1760 11652
-2340 11729 2900 11799 3470 11869 4050 11943 4650 12020 5240 12094 5820 12159
-6370 12214 6930 12266 7470 12312 8000 12358 8510 12395 8990 12423 9480 12440
-9930 12444 10340 12435 10760 12417 11130 12400 11460 12375 11760 12336
-12020 12282 12270 12210 12460 12132 12610 12059 12710 11986 12790 11919
-12830 11852 12830 11792 12790 11732 12720 11681 12590 11631 12440 11593
-12270 11571 12050 11564 11790 11561 11520 11558 11210 11555 10890 11558
-10540 11573 10160 11597 9750 11624 9330 11645 8900 11656 8400 11658 7880 11645
-7360 11618 6850 11584 6300 11544 5730 11496 5110 11434 4430 11357 3730 11265
-3000 11162 2290 11054 1650 10944 1060 10839 520 10740 30 10642 -440 10547
--900 10450 -1280 10350 -1620 10244 -1880 10129 -2120 10006 -2330 9881
--2520 9759 -2720 9638 -2960 9518 -3220 9374 -3520 9212 -3840 9049 -4170 8897
--4500 8762 -4830 8646 -5180 8540 -5520 8446 -5900 8361 -6280 8286 -6690 8222
--7110 8173 -7580 8133 -8050 8106 -8530 8088 -9010 8078 -9450 8080 -9870 8098
--10250 8132 -10620 8178 -10960 8230 -11290 8293 -11630 8365 -11970 8447
--12290 8537 -12630 8639 -12960 8748 -13290 8862 -13640 8979 -14000 9100
--14340 9225 -14700 9354 -15040 9482 -15390 9611 -15690 9745 -16010 9894
--16330 10056 -16590 10222 -16870 10391 -17140 10552 -17370 10713 -17580 10876
--17800 11042 -17970 11205 -18140 11364 -18310 11512 -18450 11646 -18590 11761
--18720 11858 -18830 11942 -18950 12011 -19070 12069 -19220 12112 -19360 12135
--19510 12134 -19660 12113 -19800 12085 -19980 12056 -20190 12015 -20370 11963
--20580 11906 -20810 11844 -21020 11779 -21270 11711 -21490 11641 -21690 11571
--21900 11499 -22100 11427 -22340 11354 -22550 11281 -22800 11209 -23060 11135
--23310 11061 -23580 10983 -23880 10901 -24190 10815 -24500 10723 -24840 10626
--25190 10525 -25530 10419 -25860 10307 -26190 10191 -26510 10070 -26820 9944
--27110 9813 -27370 9679 -27580 9540 -27750 9399 -27880 9257 -27950 9114
--27980 8970 -27970 8824 -27900 8677 -27780 8528 -27630 8378 -27410 8227
--27170 8080 -26900 7930 -26580 7780 -26260 7625 -25920 7470 -25560 7311
--25190 7154 -24800 6994 -24390 6833 -23990 6669 -23610 6504 -23220 6338
--22830 6174 -22370 6013 -21930 5855 -21470 5698 -21050 5548 -20630 5404
--20200 5266 -19700 5134 -19120 5007 -18610 4893 -18030 4789 -17400 4698
--16720 4621 -16020 4558 -15330 4509 -14630 4473 -13960 4452 -13300 4442
--12650 4442 -12040 4455 -11440 4479 -10870 4515 -10320 4562 -9810 4620
--9300 4686 -8830 4761 -8380 4843 -7960 4933 -7580 5029 -7210 5132 -6890 5238
--6590 5348 -6330 5462 -6090 5578 -5880 5698 -5700 5818 -5550 5941 -5420 6062
--5330 6185 -5250 6306 -5200 6428 -5170 6548 -5150 6668 -5150 6784 -5160 6900
--5180 7012 -5230 7124 -5270 7231 -5320 7337 -5380 7439 -5470 7539 -5530 7636
--5620 7729 -5710 7820 -5800 7907 -5890 7991 -5980 8073 -6060 8151 -6150 8226
--6240 8297 -6330 8366 -6420 8434 -6500 8499 -6600 8559 -6690 8614 -6790 8667
--6870 8718 -6960 8771 -7080 8825 -7130 8870 -7170 8913 -7220 8954 -7280 8993
--7330 9030 -7390 9066 -7440 9099 -7500 9130 -7560 9163 -7600 9192 -7650 9219
--7690 9246 -7730 9270 -7780 9294 -7800 9316 -7850 9339 -7880 9359 -7910 9378
--7940 9397 -7970 9414 -8000 9431 -8030 9447 -8050 9463 -8070 9477 -8090 9491
--8110 9504 -8130 9517 -8150 9529 -8180 9541 -8180 9553 -8190 9562 -8220 9573
--8230 9583 -8250 9593 -8250 9602 -8280 9610 -8280 9619 -8299 9627 -8311 9635
--8320 9643 -8325 9650 -8340 9656 -8348 9664 -8356 9670 -8364 9676 -8375 9683
--8384 9688 -8394 9694 -8403 9700 -8406 9705 -8412 9710 -8421 9715 -8427 9719
--8429 9724 -8439 9729 -8446 9732
-219: 14845740 -4538642 -10270 9931 -10270 9931 -10270 9935 -10280 9935
--10290 9936 -10300 9940 -10300 9943 -10310 9945 -10310 9944 -10330 9947
--10330 9950 -10340 9953 -10350 9953 -10360 9955 -10370 9957 -10380 9962
--10390 9964 -10400 9967 -10420 9968 -10420 9968 -10420 9972 -10440 9975
--10450 9977 -10460 9977 -10470 9980 -10480 9983 -10480 9984 -10490 9985
--10500 9988 -10520 9989 -10510 9993 -10520 9994 -10540 9997 -10550 10002
--10550 10003 -10550 10006 -10560 10007 -10570 10012 -10580 10015 -10590 10018
--10590 10022 -10600 10028 -10610 10031 -10630 10032 -10630 10039 -10650 10042
--10660 10050 -10660 10053 -10690 10056 -10690 10062 -10710 10064 -10720 10069
--10740 10074 -10750 10079 -10770 10082 -10790 10085 -10790 10091 -10810 10093
--10830 10094 -10850 10097 -10850 10101 -10870 10102 -10880 10103 -10890 10104
--10910 10104 -10910 10106 -10930 10108 -10940 10106 -10940 10108 -10950 10104
--10960 10105 -10960 10105 -10970 10103 -10980 10103 -10970 10103 -10980 10103
--10980 10102 -10990 10101 -10980 10102 -10990 10104 -10990 10105 -10990 10106
--10980 10110 -11000 10112 -10990 10114 -11000 10119 -11000 10124 -11000 10128
--11010 10135 -11010 10140 -11020 10145 -11040 10152 -11040 10160 -11050 10170
--11050 10178 -11080 10188 -11080 10197 -11100 10204 -11120 10212 -11130 10223
--11140 10233 -11160 10241 -11180 10247 -11190 10255 -11220 10261 -11230 10268
--11250 10274 -11260 10280 -11290 10282 -11300 10287 -11310 10289 -11330 10290
--11350 10291 -11350 10290 -11360 10288 -11370 10284 -11370 10280 -11380 10275
--11390 10267 -11390 10259 -11380 10251 -11380 10243 -11380 10233 -11370 10223
--11350 10209 -11340 10199 -11330 10185 -11320 10174 -11290 10161 -11280 10144
--11250 10130 -11230 10118 -11200 10105 -11170 10095 -11140 10081 -11130 10067
--11090 10058 -11050 10047 -11030 10038 -11000 10029 -10980 10021 -10950 10015
--10910 10007 -10900 10003 -10870 9999 -10850 9995 -10830 9994 -10810 9994
--10790 9996 -10770 9998 -10760 10003 -10760 10006 -10750 10009 -10750 10015
--10760 10025 -10750 10033 -10760 10040 -10780 10049 -10780 10059 -10800 10070
--10820 10080 -10850 10092 -10870 10103 -10890 10113 -10930 10124 -10970 10137
--11000 10147 -11050 10158 -11080 10167 -11110 10180 -11150 10186 -11190 10198
--11240 10205 -11270 10214 -11310 10221 -11330 10228 -11370 10233 -11390 10238
--11430 10243 -11460 10245 -11460 10250 -11460 10253 -11480 10255 -11470 10256
--11460 10256 -11440 10257 -11400 10260 -11370 10262 -11310 10262 -11240 10262
--11190 10262 -11100 10264 -11000 10268 -10880 10274 -10760 10277 -10610 10282
--10450 10287 -10280 10297 -10110 10307 -9890 10319 -9670 10333 -9440 10349
--9190 10366 -8930 10386 -8630 10410 -8330 10436 -8010 10464 -7670 10495
--7310 10528 -6950 10566 -6560 10605 -6170 10649 -5760 10694 -5310 10743
--4870 10794 -4420 10850 -3940 10906 -3480 10964 -2960 11026 -2460 11093
--1940 11160 -1400 11230 -890 11296 -340 11364 200 11437 770 11514 1350 11591
-1900 11664 2470 11733 3010 11799 3580 11870 4170 11943 4750 12012 5310 12074
-5840 12126 6400 12177 6930 12223 7450 12263 7940 12298 8420 12325 8900 12342
-9320 12348 9750 12341 10140 12326 10510 12310 10840 12289 11140 12257
-11400 12209 11640 12148 11850 12080 11990 12016 12120 11952 12190 11893
-12240 11836 12250 11782 12230 11730 12170 11682 12070 11639 11930 11603
-11770 11582 11560 11575 11340 11569 11070 11564 10790 11559 10500 11558
-10150 11569 9790 11583 9420 11604 9020 11616 8600 11622 8110 11616 7630 11600
-7110 11572 6610 11536 6100 11495 5540 11447 4950 11386 4320 11311 3670 11223
-2980 11126 2330 11024 1720 10920 1160 10819 650 10720 170 10623 -300 10526
--720 10427 -1130 10327 -1480 10221 -1750 10107 -2030 9987 -2260 9862 -2460 9741
--2690 9621 -2930 9502 -3220 9367 -3500 9218 -3830 9067 -4150 8922 -4490 8791
--4840 8676 -5180 8577 -5520 8485 -5910 8405 -6270 8332 -6670 8270 -7080 8219
--7520 8180 -7980 8151 -8420 8132 -8870 8123 -9310 8124 -9720 8140 -10100 8171
--10470 8213 -10810 8264 -11160 8323 -11500 8390 -11830 8468 -12170 8552
--12500 8648 -12830 8751 -13160 8860 -13500 8971 -13840 9088 -14190 9209
--14510 9333 -14870 9458 -15190 9584 -15500 9714 -15800 9856 -16090 10010
--16370 10171 -16630 10329 -16890 10483 -17120 10636 -17330 10790 -17520 10947
--17710 11101 -17890 11249 -18040 11390 -18180 11516 -18330 11625 -18460 11719
--18580 11799 -18690 11869 -18820 11926 -18970 11971 -19110 11996 -19260 12000
--19390 11987 -19550 11967 -19710 11943 -19900 11911 -20090 11866 -20280 11816
--20490 11760 -20700 11702 -20930 11640 -21140 11577 -21340 11511 -21540 11444
--21750 11376 -21970 11307 -22200 11235 -22440 11165 -22680 11093 -22940 11020
--23190 10945 -23490 10865 -23790 10781 -24090 10692 -24400 10597 -24730 10500
--25060 10397 -25360 10290 -25680 10177 -25980 10061 -26270 9939 -26530 9813
--26770 9685 -26970 9552 -27130 9416 -27250 9279 -27330 9142 -27350 9002
--27350 8862 -27280 8719 -27190 8575 -27050 8430 -26850 8284 -26630 8139
--26380 7994 -26100 7847 -25790 7697 -25480 7545 -25140 7392 -24810 7238
--24430 7085 -24030 6928 -23660 6772 -23280 6613 -22910 6453 -22520 6297
--22090 6143 -21640 5990 -21210 5842 -20790 5699 -20370 5561 -19950 5431
--19480 5305 -18900 5184 -18400 5077 -17870 4978 -17260 4891 -16630 4816
--15980 4753 -15310 4705 -14670 4671 -14010 4647 -13370 4637 -12740 4636
--12150 4647 -11560 4667 -11010 4700 -10480 4743 -9970 4796 -9480 4856
--9030 4925 -8590 5002 -8180 5085 -7810 5176 -7460 5271 -7150 5371 -6850 5475
--6590 5583 -6350 5693 -6150 5806 -5970 5921 -5810 6036 -5680 6154 -5580 6270
--5500 6386 -5430 6502 -5390 6618 -5370 6732 -5360 6845 -5350 6956 -5380 7064
--5400 7171 -5440 7276 -5480 7377 -5540 7477 -5600 7574 -5670 7667 -5740 7758
--5830 7846 -5910 7931 -5990 8013 -6070 8093 -6150 8169 -6230 8242 -6320 8311
--6400 8380 -6480 8445 -6560 8509 -6660 8568 -6740 8623 -6830 8674 -6910 8725
--7010 8776 -7110 8829 -7170 8875 -7210 8916 -7250 8956 -7300 8996 -7350 9032
--7420 9067 -7460 9100 -7520 9131 -7570 9163 -7620 9192 -7660 9219 -7710 9245
--7750 9269 -7780 9293 -7830 9316 -7860 9337 -7890 9358 -7920 9377 -7960 9394
--7970 9413 -8010 9429 -8040 9445 -8060 9461 -8080 9475 -8100 9489 -8120 9502
--8140 9515 -8160 9527 -8180 9539 -8190 9550 -8210 9560 -8220 9571 -8240 9580
--8250 9591 -8270 9599 -8280 9608 -8290 9616 -8310 9625 -8320 9633 -8320 9640
--8340 9647 -8344 9655 -8353 9661 -8364 9667 -8375 9674 -8382 9680 -8393 9686
--8400 9692 -8408 9697 -8415 9703 -8419 9707 -8427 9712 -8435 9717 -8437 9722
--8444 9726 -8452 9730
-220: 14879080 -4530246 -10260 9931 -10270 9934 -10280 9933 -10280 9937
--10290 9938 -10290 9939 -10300 9943 -10310 9945 -10320 9947 -10320 9947
--10340 9949 -10340 9952 -10350 9955 -10360 9956 -10370 9958 -10370 9961
--10390 9963 -10400 9967 -10420 9967 -10420 9969 -10420 9972 -10440 9974
--10450 9977 -10460 9977 -10460 9979 -10470 9982 -10490 9984 -10480 9985
--10500 9988 -10510 9989 -10510 9993 -10530 9993 -10530 9998 -10540 10000
--10540 10001 -10550 10006 -10560 10006 -10570 10010 -10580 10014 -10580 10017
--10590 10023 -10600 10025 -10610 10030 -10620 10033 -10630 10038 -10640 10041
--10650 10047 -10660 10051 -10680 10055 -10690 10060 -10700 10062 -10720 10067
--10730 10072 -10740 10077 -10770 10080 -10780 10085 -10780 10088 -10810 10090
--10820 10092 -10830 10096 -10840 10098 -10860 10101 -10870 10101 -10890 10100
--10890 10103 -10900 10104 -10920 10103 -10930 10104 -10930 10105 -10930 10103
--10950 10102 -10960 10101 -10950 10100 -10960 10101 -10970 10101 -10970 10099
--10970 10098 -10960 10098 -10980 10099 -10970 10099 -10980 10102 -10970 10104
--10980 10106 -10980 10108 -10980 10109 -10980 10115 -10990 10120 -10990 10123
--10990 10130 -11000 10135 -11010 10141 -11020 10147 -11020 10157 -11030 10164
--11040 10173 -11070 10182 -11070 10189 -11080 10198 -11090 10206 -11110 10217
--11130 10226 -11130 10235 -11160 10241 -11180 10249 -11190 10254 -11210 10261
--11230 10267 -11240 10274 -11260 10276 -11270 10281 -11290 10282 -11310 10286
--11310 10286 -11330 10283 -11340 10283 -11350 10281 -11340 10276 -11360 10270
--11350 10265 -11360 10256 -11370 10250 -11360 10243 -11340 10231 -11340 10221
--11330 10210 -11320 10198 -11300 10186 -11300 10175 -11270 10162 -11250 10146
--11230 10134 -11210 10120 -11180 10110 -11140 10096 -11130 10085 -11090 10072
--11060 10061 -11040 10050 -11010 10041 -10980 10034 -10950 10025 -10920 10017
--10900 10012 -10870 10005 -10850 10001 -10820 9998 -10800 9997 -10790 9995
--10760 9997 -10740 9997 -10740 10002 -10720 10003 -10720 10008 -10720 10012
--10710 10019 -10720 10027 -10720 10034 -10740 10042 -10750 10050 -10750 10059
--10780 10070 -10800 10079 -10830 10090 -10850 10098 -10870 10108 -10920 10120
--10950 10129 -10990 10139 -11030 10148 -11060 10158 -11100 10165 -11130 10173
--11180 10182 -11220 10190 -11250 10195 -11280 10200 -11320 10206 -11340 10210
--11380 10214 -11400 10216 -11420 10220 -11420 10223 -11430 10225 -11430 10225
--11420 10226 -11410 10227 -11380 10228 -11340 10230 -11300 10232 -11240 10231
--11190 10231 -11100 10234 -11010 10239 -10900 10242 -10780 10248 -10650 10253
--10490 10258 -10340 10267 -10160 10278 -9970 10290 -9760 10305 -9530 10321
--9300 10336 -9030 10358 -8760 10382 -8470 10407 -8170 10436 -7830 10464
--7490 10499 -7140 10535 -6770 10574 -6390 10615 -5980 10661 -5560 10709
--5140 10759 -4680 10812 -4230 10867 -3770 10923 -3280 10984 -2780 11048
--2280 11113 -1760 11180 -1250 11245 -730 11310 -180 11381 360 11454 920 11527
-1470 11598 2010 11663 2560 11727 3110 11795 3680 11863 4240 11930 4790 11988
-5320 12038 5850 12087 6380 12131 6880 12168 7360 12202 7840 12227 8300 12245
-8720 12252 9140 12248 9520 12236 9890 12223 10200 12204 10520 12177 10770 12137
-11000 12083 11210 12026 11370 11969 11510 11914 11580 11862 11640 11813
-11660 11765 11660 11719 11600 11677 11530 11637 11400 11605 11250 11586
-11070 11576 10860 11569 10610 11562 10350 11556 10070 11551 9750 11557
-9410 11567 9050 11580 8680 11585 8270 11585 7830 11576 7340 11556 6860 11525
-6360 11489 5870 11447 5340 11398 4790 11338 4190 11266 3570 11183 2950 11090
-2340 10992 1740 10893 1220 10796 730 10698 260 10603 -180 10504 -620 10404
--1000 10304 -1350 10200 -1660 10086 -1940 9968 -2200 9847 -2430 9725 -2660 9610
--2940 9490 -3210 9361 -3510 9222 -3820 9083 -4140 8947 -4490 8822 -4820 8710
--5180 8612 -5530 8523 -5900 8445 -6270 8375 -6640 8315 -7050 8265 -7480 8226
--7900 8196 -8330 8176 -8760 8166 -9190 8167 -9570 8179 -9960 8209 -10320 8247
--10670 8295 -11030 8349 -11370 8414 -11700 8486 -12040 8566 -12360 8657
--12690 8754 -13010 8857 -13360 8963 -13680 9074 -14010 9191 -14340 9312
--14680 9433 -14990 9554 -15280 9680 -15570 9817 -15860 9963 -16130 10116
--16380 10266 -16640 10413 -16860 10558 -17060 10703 -17250 10852 -17440 10997
--17600 11136 -17770 11270 -17910 11389 -18060 11493 -18180 11584 -18300 11661
--18420 11730 -18550 11786 -18690 11832 -18830 11861 -18990 11869 -19130 11862
--19250 11848 -19410 11830 -19600 11805 -19780 11769 -19970 11723 -20170 11675
--20360 11621 -20580 11566 -20780 11508 -20970 11448 -21170 11386 -21380 11321
--21590 11256 -21830 11188 -22060 11119 -22290 11049 -22540 10979 -22800 10906
--23070 10828 -23360 10746 -23640 10661 -23950 10569 -24260 10475 -24570 10376
--24860 10273 -25150 10165 -25430 10052 -25700 9936 -25950 9815 -26180 9692
--26350 9565 -26510 9434 -26620 9303 -26690 9170 -26730 9035 -26710 8900
--26670 8763 -26600 8623 -26450 8483 -26290 8341 -26090 8201 -25850 8060
--25590 7917 -25310 7771 -25030 7624 -24710 7475 -24400 7327 -24030 7178
--23660 7028 -23300 6877 -22940 6724 -22580 6572 -22190 6422 -21790 6275
--21360 6129 -20920 5987 -20510 5850 -20120 5720 -19700 5595 -19240 5476
--18670 5363 -18200 5259 -17670 5165 -17100 5082 -16520 5010 -15900 4949
--15280 4901 -14670 4866 -14040 4843 -13430 4830 -12830 4829 -12250 4836
--11680 4856 -11150 4884 -10630 4923 -10140 4971 -9660 5027 -9220 5091
--8800 5161 -8400 5239 -8030 5324 -7690 5412 -7390 5507 -7100 5605 -6840 5706
--6600 5810 -6410 5917 -6220 6027 -6070 6136 -5930 6247 -5820 6358 -5740 6469
--5660 6581 -5610 6691 -5590 6800 -5560 6908 -5550 7015 -5560 7120 -5580 7222
--5610 7323 -5640 7422 -5690 7517 -5740 7611 -5810 7702 -5880 7789 -5950 7875
--6020 7958 -6090 8037 -6170 8115 -6240 8190 -6320 8260 -6400 8328 -6470 8394
--6550 8459 -6620 8522 -6720 8579 -6790 8632 -6890 8683 -6960 8733 -7050 8783
--7150 8835 -7210 8880 -7240 8921 -7280 8960 -7340 8999 -7380 9035 -7440 9069
--7490 9102 -7540 9133 -7590 9164 -7640 9192 -7680 9220 -7730 9245 -7760 9270
--7810 9292 -7840 9315 -7870 9337 -7900 9357 -7940 9375 -7960 9394 -7990 9411
--8030 9428 -8040 9444 -8070 9459 -8090 9473 -8110 9487 -8130 9500 -8150 9513
--8170 9525 -8180 9537 -8210 9548 -8220 9558 -8230 9569 -8250 9578 -8260 9588
--8280 9597 -8290 9606 -8300 9614 -8310 9622 -8330 9631 -8330 9637 -8340 9645
--8350 9653 -8370 9658 -8370 9666 -8380 9671 -8394 9678 -8401 9683 -8406 9690
--8412 9695 -8421 9700 -8426 9704 -8434 9710 -8444 9715 -8444 9720 -8452 9723
--8457 9727
-221: 14912450 -4521856 -10270 9931 -10270 9934 -10280 9935 -10280 9938
--10290 9939 -10290 9941 -10300 9943 -10310 9945 -10310 9947 -10330 9947
--10340 9950 -10340 9953 -10350 9953 -10350 9957 -10370 9959 -10380 9961
--10390 9963 -10400 9966 -10410 9968 -10410 9970 -10430 9972 -10440 9972
--10440 9976 -10460 9977 -10460 9979 -10470 9981 -10480 9983 -10480 9986
--10500 9987 -10500 9989 -10510 9992 -10530 9994 -10530 9996 -10530 9998
--10540 10000 -10550 10004 -10560 10006 -10560 10011 -10580 10012 -10580 10017
--10580 10022 -10590 10024 -10610 10028 -10610 10032 -10630 10037 -10630 10040
--10650 10045 -10660 10050 -10670 10054 -10680 10057 -10700 10062 -10710 10066
--10720 10070 -10750 10075 -10750 10081 -10770 10082 -10780 10083 -10800 10088
--10810 10092 -10820 10093 -10830 10096 -10850 10099 -10860 10097 -10870 10098
--10880 10100 -10900 10101 -10910 10101 -10910 10103 -10920 10101 -10930 10100
--10930 10099 -10940 10097 -10950 10098 -10950 10100 -10950 10097 -10960 10097
--10950 10094 -10960 10095 -10960 10095 -10960 10097 -10960 10098 -10970 10101
--10960 10102 -10970 10103 -10970 10106 -10960 10110 -10980 10114 -10970 10121
--10990 10126 -10980 10130 -10990 10136 -11000 10142 -11010 10151 -11020 10160
--11030 10167 -11040 10176 -11050 10184 -11070 10192 -11070 10199 -11100 10210
--11100 10220 -11120 10229 -11140 10234 -11150 10242 -11170 10248 -11200 10255
--11200 10260 -11230 10267 -11230 10271 -11250 10275 -11260 10276 -11280 10281
--11290 10281 -11300 10278 -11320 10279 -11320 10275 -11320 10272 -11330 10266
--11330 10262 -11340 10254 -11330 10248 -11340 10239 -11320 10230 -11310 10222
--11310 10209 -11290 10198 -11280 10188 -11270 10175 -11260 10161 -11220 10150
--11210 10136 -11180 10124 -11150 10112 -11130 10099 -11100 10089 -11070 10077
--11040 10063 -11010 10055 -11000 10044 -10960 10037 -10920 10027 -10900 10022
--10880 10016 -10840 10008 -10810 10004 -10810 10000 -10780 9999 -10760 9997
--10730 9998 -10720 9998 -10690 10000 -10700 10003 -10690 10005 -10680 10009
--10680 10017 -10680 10022 -10690 10028 -10700 10034 -10700 10042 -10720 10051
--10730 10058 -10760 10068 -10780 10077 -10800 10086 -10830 10094 -10870 10105
--10900 10112 -10940 10120 -10970 10130 -11010 10137 -11040 10145 -11090 10152
--11120 10160 -11170 10164 -11190 10170 -11230 10176 -11260 10181 -11300 10182
--11330 10186 -11350 10189 -11370 10193 -11380 10194 -11390 10195 -11390 10196
--11390 10196 -11380 10198 -11360 10199 -11320 10200 -11280 10203 -11240 10200
--11180 10202 -11100 10205 -11020 10208 -10920 10214 -10800 10218 -10680 10224
--10550 10229 -10390 10237 -10220 10250 -10040 10261 -9840 10277 -9630 10291
--9400 10308 -9150 10329 -8900 10352 -8610 10378 -8310 10405 -7990 10435
--7680 10468 -7320 10503 -6980 10540 -6600 10581 -6220 10627 -5810 10672
--5390 10722 -4950 10772 -4520 10826 -4070 10881 -3600 10939 -3110 11002
--2620 11065 -2120 11128 -1620 11191 -1110 11254 -580 11322 -50 11392 490 11462
-1030 11529 1560 11593 2090 11654 2630 11717 3180 11784 3740 11845 4270 11903
-4770 11949 5310 11996 5810 12036 6310 12075 6780 12105 7230 12131 7690 12148
-8110 12158 8520 12156 8900 12146 9260 12135 9580 12120 9870 12097 10130 12064
-10360 12018 10570 11969 10740 11919 10880 11872 10970 11827 11030 11784
-11070 11742 11060 11701 11030 11664 10960 11628 10860 11599 10720 11580
-10560 11571 10370 11562 10130 11554 9900 11545 9630 11539 9320 11541 9000 11545
-8680 11552 8310 11551 7930 11548 7510 11535 7050 11511 6570 11480 6100 11442
-5640 11399 5130 11351 4590 11291 4040 11222 3480 11142 2870 11053 2310 10959
-1760 10866 1250 10770 770 10675 320 10580 -110 10481 -540 10382 -920 10283
--1260 10178 -1590 10067 -1880 9951 -2150 9833 -2410 9713 -2640 9600 -2940 9482
--3230 9357 -3530 9228 -3820 9097 -4150 8971 -4470 8852 -4820 8744 -5170 8647
--5530 8560 -5890 8484 -6250 8416 -6640 8357 -7020 8309 -7430 8270 -7830 8241
--8260 8220 -8670 8208 -9060 8207 -9460 8219 -9820 8244 -10190 8280 -10530 8324
--10890 8375 -11230 8434 -11570 8502 -11890 8580 -12230 8665 -12530 8756
--12870 8853 -13190 8954 -13520 9060 -13840 9174 -14160 9288 -14470 9406
--14780 9523 -15060 9645 -15350 9775 -15620 9915 -15880 10059 -16130 10202
--16370 10342 -16590 10480 -16780 10617 -16970 10757 -17150 10894 -17320 11026
--17490 11151 -17620 11266 -17760 11365 -17900 11451 -18010 11528 -18140 11594
--18260 11651 -18410 11697 -18540 11728 -18690 11740 -18820 11739 -18960 11729
--19090 11718 -19280 11699 -19460 11668 -19630 11631 -19830 11587 -20010 11539
--20220 11489 -20410 11437 -20590 11382 -20790 11324 -20990 11264 -21210 11202
--21430 11138 -21660 11072 -21900 11005 -22130 10936 -22370 10866 -22640 10790
--22910 10712 -23190 10629 -23480 10542 -23770 10450 -24060 10356 -24340 10256
--24620 10154 -24870 10045 -25130 9933 -25350 9818 -25570 9700 -25740 9578
--25890 9454 -25980 9327 -26070 9199 -26090 9069 -26100 8940 -26060 8806
--25980 8673 -25860 8536 -25720 8400 -25530 8264 -25320 8127 -25080 7990
--24820 7847 -24560 7705 -24270 7561 -23960 7418 -23620 7274 -23270 7130
--22920 6984 -22580 6838 -22240 6693 -21870 6549 -21460 6407 -21060 6269
--20630 6133 -20230 6003 -19850 5879 -19450 5760 -18990 5647 -18450 5539
--17980 5440 -17460 5351 -16940 5272 -16370 5201 -15800 5143 -15230 5096
--14650 5060 -14050 5037 -13470 5023 -12900 5019 -12340 5025 -11790 5042
--11280 5067 -10780 5102 -10290 5147 -9840 5197 -9410 5256 -9000 5321 -8610 5394
--8240 5473 -7930 5556 -7610 5644 -7340 5735 -7080 5832 -6850 5929 -6650 6031
--6470 6134 -6310 6238 -6170 6344 -6060 6449 -5960 6555 -5890 6661 -5830 6767
--5790 6872 -5760 6975 -5750 7077 -5750 7177 -5760 7277 -5780 7373 -5800 7468
--5840 7561 -5890 7651 -5950 7739 -6010 7824 -6070 7906 -6130 7986 -6200 8065
--6270 8139 -6340 8212 -6410 8280 -6480 8347 -6550 8412 -6620 8474 -6700 8535
--6780 8592 -6850 8644 -6950 8694 -7010 8741 -7090 8792 -7200 8842 -7240 8887
--7280 8926 -7320 8966 -7370 9003 -7410 9039 -7470 9072 -7520 9105 -7570 9135
--7610 9166 -7660 9194 -7700 9221 -7750 9246 -7780 9270 -7820 9292 -7860 9315
--7880 9337 -7920 9356 -7960 9375 -7980 9393 -8000 9410 -8030 9427 -8060 9443
--8080 9457 -8100 9472 -8120 9486 -8150 9498 -8160 9512 -8180 9523 -8190 9535
--8210 9546 -8240 9556 -8240 9567 -8260 9576 -8270 9586 -8290 9595 -8290 9604
--8310 9612 -8320 9620 -8340 9628 -8340 9636 -8350 9643 -8360 9649 -8370 9657
--8380 9663 -8400 9669 -8390 9676 -8410 9681 -8410 9687 -8420 9692 -8430 9698
--8435 9703 -8443 9707 -8449 9712 -8453 9717 -8457 9721 -8463 9725
-222: 14945820 -4513470 -10260 9932 -10270 9935 -10280 9936 -10280 9938
--10290 9939 -10290 9942 -10300 9944 -10310 9944 -10320 9947 -10320 9948
--10340 9952 -10340 9951 -10350 9955 -10350 9957 -10370 9959 -10380 9962
--10380 9963 -10400 9964 -10410 9968 -10410 9969 -10420 9972 -10440 9972
--10440 9975 -10450 9977 -10460 9980 -10470 9981 -10480 9982 -10480 9986
--10490 9986 -10500 9989 -10510 9989 -10520 9994 -10530 9996 -10530 9998
--10540 9998 -10540 10004 -10550 10005 -10570 10009 -10570 10012 -10570 10016
--10590 10019 -10590 10024 -10590 10028 -10610 10030 -10630 10035 -10630 10039
--10640 10043 -10650 10048 -10670 10054 -10680 10056 -10680 10061 -10700 10065
--10730 10068 -10730 10073 -10750 10079 -10760 10079 -10770 10082 -10790 10086
--10800 10091 -10810 10090 -10830 10094 -10840 10094 -10850 10096 -10860 10096
--10870 10097 -10880 10098 -10900 10099 -10900 10100 -10910 10099 -10920 10097
--10920 10096 -10930 10095 -10930 10096 -10930 10096 -10950 10094 -10940 10094
--10950 10092 -10940 10091 -10950 10092 -10940 10094 -10950 10096 -10960 10096
--10950 10098 -10950 10099 -10950 10103 -10960 10106 -10970 10110 -10960 10116
--10960 10121 -10980 10126 -10970 10130 -10990 10138 -10990 10147 -11010 10155
--11010 10161 -11020 10170 -11040 10179 -11040 10185 -11060 10193 -11080 10204
--11090 10213 -11100 10222 -11120 10228 -11140 10236 -11150 10242 -11160 10247
--11190 10255 -11190 10260 -11210 10265 -11230 10269 -11240 10271 -11250 10274
--11270 10274 -11280 10274 -11290 10274 -11300 10272 -11300 10266 -11300 10262
--11310 10259 -11310 10253 -11310 10244 -11310 10237 -11290 10230 -11290 10220
--11290 10210 -11270 10197 -11250 10188 -11240 10176 -11240 10163 -11200 10151
--11180 10138 -11160 10128 -11130 10113 -11100 10103 -11080 10092 -11040 10082
--11020 10069 -11000 10056 -10970 10048 -10940 10041 -10910 10031 -10880 10025
--10850 10019 -10810 10012 -10790 10008 -10780 10003 -10750 10000 -10730 10000
--10700 9998 -10700 9999 -10680 10001 -10660 10003 -10660 10003 -10640 10006
--10650 10014 -10640 10017 -10650 10023 -10660 10026 -10670 10035 -10680 10042
--10690 10051 -10720 10058 -10730 10065 -10750 10073 -10790 10081 -10810 10090
--10860 10096 -10890 10105 -10920 10111 -10950 10119 -11000 10127 -11030 10132
--11070 10138 -11110 10141 -11150 10147 -11170 10152 -11210 10156 -11250 10158
--11280 10160 -11300 10163 -11330 10165 -11340 10168 -11350 10167 -11350 10168
--11360 10169 -11350 10168 -11330 10171 -11310 10172 -11260 10173 -11230 10173
--11180 10174 -11110 10175 -11030 10179 -10930 10184 -10830 10190 -10720 10195
--10590 10201 -10440 10209 -10280 10221 -10110 10233 -9930 10247 -9720 10262
--9500 10280 -9270 10299 -9030 10322 -8750 10347 -8460 10374 -8160 10404
--7850 10435 -7520 10470 -7180 10506 -6820 10547 -6450 10590 -6050 10635
--5650 10683 -5220 10732 -4810 10783 -4370 10836 -3920 10893 -3440 10953
--2970 11014 -2470 11076 -1990 11136 -1490 11196 -990 11261 -460 11328
-60 11396 590 11459 1100 11521 1620 11579 2150 11639 2680 11703 3220 11762
-3740 11817 4240 11860 4740 11903 5250 11943 5730 11980 6190 12010 6630 12037
-7080 12053 7500 12062 7890 12063 8270 12057 8620 12049 8950 12038 9230 12017
-9490 11990 9710 11952 9930 11909 10090 11867 10250 11826 10340 11788 10420 11749
-10460 11714 10460 11677 10460 11644 10380 11612 10300 11585 10180 11569
-10030 11557 9860 11549 9650 11538 9420 11530 9180 11520 8880 11520 8590 11520
-8270 11520 7930 11518 7570 11508 7170 11492 6730 11467 6280 11435 5840 11396
-5380 11352 4900 11304 4400 11245 3880 11178 3340 11100 2780 11016 2250 10927
-1730 10836 1240 10744 790 10650 340 10556 -70 10458 -490 10361 -860 10262
--1210 10158 -1530 10048 -1840 9936 -2130 9820 -2390 9703 -2650 9592 -2950 9478
--3240 9357 -3550 9234 -3830 9111 -4160 8992 -4490 8881 -4820 8776 -5170 8683
--5520 8597 -5870 8522 -6240 8455 -6620 8398 -7000 8351 -7380 8312 -7770 8283
--8190 8262 -8580 8249 -8970 8247 -9330 8256 -9700 8279 -10070 8312 -10390 8351
--10760 8399 -11100 8454 -11430 8518 -11740 8591 -12070 8671 -12400 8758
--12710 8849 -13020 8944 -13350 9047 -13650 9154 -13960 9266 -14270 9377
--14560 9491 -14840 9607 -15120 9732 -15370 9865 -15630 10002 -15870 10138
--16100 10270 -16310 10402 -16500 10531 -16680 10664 -16860 10793 -17030 10918
--17190 11036 -17330 11145 -17460 11240 -17600 11324 -17710 11397 -17840 11463
--17960 11519 -18110 11566 -18240 11598 -18370 11614 -18510 11617 -18630 11612
--18780 11608 -18940 11592 -19110 11568 -19300 11536 -19460 11498 -19650 11456
--19850 11411 -20030 11363 -20210 11313 -20400 11260 -20590 11205 -20810 11147
--21030 11086 -21250 11022 -21470 10960 -21700 10893 -21940 10825 -22190 10752
--22460 10678 -22720 10597 -23000 10514 -23270 10427 -23540 10335 -23810 10241
--24070 10142 -24310 10039 -24550 9932 -24760 9821 -24960 9708 -25120 9592
--25260 9474 -25360 9351 -25430 9229 -25480 9105 -25470 8979 -25440 8851
--25370 8723 -25280 8591 -25130 8459 -24970 8328 -24790 8196 -24560 8061
--24330 7926 -24070 7787 -23800 7649 -23510 7511 -23200 7372 -22870 7233
--22540 7094 -22220 6954 -21870 6814 -21520 6677 -21140 6542 -20730 6409
--20330 6280 -19950 6156 -19570 6036 -19190 5925 -18740 5817 -18230 5713
--17750 5620 -17260 5535 -16750 5458 -16230 5391 -15690 5335 -15140 5288
--14600 5253 -14050 5228 -13490 5214 -12960 5209 -12410 5212 -11900 5226
--11390 5249 -10910 5280 -10440 5320 -10010 5367 -9590 5421 -9190 5482
--8810 5549 -8460 5621 -8130 5700 -7830 5782 -7570 5869 -7320 5957 -7090 6051
--6880 6146 -6700 6243 -6540 6343 -6410 6442 -6290 6543 -6180 6643 -6110 6744
--6040 6845 -6000 6945 -5960 7044 -5940 7142 -5940 7239 -5920 7332 -5950 7427
--5970 7517 -6000 7606 -6040 7694 -6090 7778 -6140 7861 -6180 7940 -6260 8017
--6310 8094 -6370 8166 -6440 8236 -6510 8302 -6570 8368 -6620 8430 -6700 8492
--6770 8551 -6840 8606 -6930 8657 -7000 8705 -7070 8752 -7140 8801 -7240 8851
--7290 8894 -7310 8934 -7360 8971 -7400 9009 -7460 9043 -7500 9077 -7540 9108
--7600 9139 -7640 9168 -7690 9196 -7720 9223 -7770 9247 -7800 9271 -7840 9294
--7870 9315 -7910 9337 -7940 9357 -7960 9375 -8000 9392 -8020 9410 -8040 9426
--8070 9442 -8100 9456 -8110 9471 -8140 9484 -8150 9498 -8170 9510 -8190 9521
--8210 9534 -8220 9544 -8240 9555 -8250 9565 -8270 9574 -8290 9584 -8290 9593
--8310 9602 -8320 9610 -8330 9618 -8340 9626 -8350 9633 -8360 9641 -8370 9648
--8380 9654 -8390 9661 -8400 9667 -8400 9674 -8420 9679 -8420 9684 -8430 9690
--8430 9696 -8450 9700 -8450 9705 -8450 9710 -8461 9715 -8465 9718 -8472 9723
-223: 14979230 -4505088 -10270 9934 -10270 9935 -10280 9936 -10290 9938
--10280 9941 -10300 9941 -10300 9945 -10310 9945 -10320 9947 -10320 9948
--10330 9952 -10340 9952 -10350 9954 -10360 9957 -10360 9957 -10370 9963
--10390 9964 -10390 9966 -10410 9967 -10410 9969 -10420 9969 -10430 9972
--10440 9976 -10450 9977 -10460 9980 -10460 9980 -10470 9983 -10480 9983
--10500 9985 -10490 9987 -10510 9990 -10520 9993 -10520 9995 -10530 9998
--10530 9998 -10540 10003 -10550 10005 -10560 10007 -10570 10011 -10570 10016
--10580 10018 -10580 10024 -10600 10025 -10600 10029 -10620 10033 -10630 10037
--10640 10043 -10650 10047 -10660 10052 -10670 10054 -10680 10060 -10690 10063
--10720 10068 -10720 10070 -10740 10074 -10760 10079 -10760 10081 -10780 10084
--10790 10087 -10810 10090 -10810 10091 -10830 10092 -10840 10092 -10850 10095
--10870 10095 -10870 10096 -10880 10095 -10890 10097 -10900 10096 -10900 10095
--10910 10092 -10920 10094 -10920 10095 -10920 10092 -10930 10091 -10940 10091
--10930 10090 -10920 10089 -10940 10088 -10940 10091 -10930 10092 -10940 10092
--10940 10094 -10940 10096 -10950 10099 -10940 10102 -10950 10107 -10940 10112
--10960 10117 -10960 10119 -10960 10126 -10970 10134 -10980 10142 -10990 10149
--11000 10156 -11000 10165 -11020 10173 -11030 10178 -11040 10187 -11060 10198
--11070 10206 -11090 10213 -11100 10222 -11120 10231 -11130 10235 -11140 10242
--11160 10248 -11180 10254 -11190 10259 -11200 10263 -11220 10266 -11230 10267
--11240 10269 -11260 10268 -11260 10269 -11270 10268 -11280 10262 -11280 10260
--11290 10253 -11290 10250 -11280 10243 -11290 10235 -11270 10227 -11260 10218
--11260 10210 -11250 10199 -11230 10186 -11210 10177 -11210 10165 -11180 10153
--11160 10141 -11130 10129 -11110 10117 -11080 10106 -11050 10095 -11030 10085
--11000 10073 -10970 10061 -10950 10050 -10910 10045 -10900 10036 -10850 10028
--10820 10022 -10790 10016 -10780 10010 -10750 10006 -10720 10004 -10700 10001
--10680 10001 -10680 10001 -10640 10001 -10640 10001 -10630 10002 -10610 10005
--10610 10010 -10610 10013 -10610 10019 -10620 10021 -10630 10028 -10640 10035
--10650 10042 -10670 10048 -10690 10055 -10720 10062 -10740 10069 -10770 10076
--10810 10083 -10840 10089 -10860 10095 -10900 10102 -10950 10108 -10970 10112
--11020 10118 -11060 10121 -11100 10125 -11120 10129 -11160 10133 -11190 10136
--11240 10136 -11260 10138 -11290 10139 -11290 10141 -11320 10141 -11320 10141
--11330 10142 -11320 10142 -11310 10143 -11280 10145 -11250 10145 -11220 10146
--11170 10146 -11120 10148 -11030 10151 -10960 10157 -10860 10161 -10750 10166
--10630 10173 -10500 10181 -10340 10192 -10180 10204 -10010 10218 -9810 10234
--9600 10250 -9390 10270 -9140 10292 -8880 10316 -8620 10342 -8340 10372
--8020 10402 -7710 10437 -7380 10471 -7040 10510 -6680 10552 -6290 10596
--5910 10642 -5500 10691 -5090 10739 -4670 10791 -4240 10845 -3770 10903
--3310 10962 -2830 11021 -2360 11078 -1880 11137 -1390 11200 -890 11263
--360 11327 140 11390 650 11447 1150 11502 1650 11562 2190 11621 2700 11677
-3220 11729 3690 11773 4190 11812 4680 11852 5140 11886 5600 11917 6040 11940
-6470 11961 6870 11968 7270 11972 7630 11969 7980 11964 8310 11953 8590 11940
-8840 11915 9070 11885 9280 11847 9450 11812 9610 11778 9710 11743 9800 11712
-9840 11679 9870 11648 9850 11618 9800 11589 9740 11566 9620 11549 9500 11539
-9330 11530 9160 11518 8940 11508 8710 11497 8430 11494 8160 11490 7850 11487
-7540 11481 7180 11469 6810 11448 6400 11422 5990 11389 5550 11351 5110 11306
-4660 11257 4200 11201 3690 11134 3190 11059 2670 10979 2160 10893 1670 10805
-1210 10717 770 10625 340 10530 -70 10435 -470 10340 -840 10242 -1180 10139
--1510 10031 -1810 9921 -2120 9809 -2390 9695 -2650 9585 -2960 9476 -3260 9360
--3570 9242 -3870 9124 -4180 9013 -4490 8907 -4830 8808 -5170 8717 -5520 8633
--5870 8559 -6230 8494 -6590 8438 -6970 8391 -7340 8352 -7730 8324 -8110 8302
--8490 8288 -8880 8285 -9230 8293 -9590 8312 -9940 8343 -10280 8377 -10630 8421
--10960 8473 -11280 8532 -11600 8602 -11920 8677 -12230 8759 -12550 8845
--12850 8935 -13170 9031 -13470 9135 -13760 9241 -14050 9349 -14350 9457
--14610 9569 -14870 9688 -15130 9815 -15370 9944 -15600 10074 -15830 10199
--16020 10323 -16220 10448 -16390 10571 -16570 10694 -16740 10813 -16880 10925
--17020 11027 -17160 11119 -17290 11200 -17410 11271 -17530 11336 -17650 11391
--17790 11437 -17920 11472 -18050 11491 -18180 11497 -18300 11498 -18450 11496
--18590 11488 -18760 11468 -18930 11440 -19110 11408 -19270 11372 -19460 11331
--19650 11289 -19820 11243 -20000 11194 -20190 11143 -20400 11089 -20610 11032
--20820 10973 -21040 10912 -21260 10850 -21500 10783 -21740 10715 -21980 10643
--22240 10566 -22500 10487 -22760 10403 -23020 10316 -23280 10225 -23510 10132
--23750 10033 -23960 9930 -24180 9826 -24340 9717 -24500 9606 -24640 9493
--24740 9376 -24810 9259 -24840 9140 -24850 9019 -24820 8897 -24770 8772
--24680 8646 -24560 8520 -24400 8392 -24240 8265 -24040 8135 -23820 8004
--23590 7872 -23330 7738 -23050 7604 -22770 7472 -22460 7338 -22130 7204
--21840 7070 -21500 6936 -21180 6806 -20790 6676 -20410 6550 -20030 6427
--19650 6307 -19290 6194 -18920 6088 -18500 5985 -18000 5887 -17520 5797
--17050 5715 -16560 5643 -16070 5578 -15560 5523 -15060 5478 -14540 5443
--14010 5418 -13500 5403 -12990 5396 -12470 5397 -11980 5409 -11490 5428
--11030 5457 -10590 5493 -10160 5535 -9750 5585 -9380 5641 -9000 5703 -8650 5771
--8340 5844 -8050 5921 -7790 6001 -7540 6086 -7310 6172 -7110 6263 -6920 6354
--6770 6448 -6630 6543 -6500 6637 -6410 6734 -6320 6830 -6250 6925 -6200 7021
--6160 7115 -6120 7209 -6120 7301 -6110 7391 -6120 7481 -6130 7569 -6150 7654
--6190 7739 -6230 7819 -6270 7899 -6310 7976 -6370 8051 -6420 8124 -6490 8195
--6540 8262 -6600 8327 -6650 8389 -6720 8451 -6770 8511 -6840 8568 -6920 8621
--6980 8672 -7070 8718 -7130 8764 -7190 8812 -7290 8861 -7330 8902 -7360 8942
--7400 8978 -7440 9015 -7490 9049 -7530 9082 -7590 9113 -7620 9142 -7660 9171
--7720 9200 -7750 9225 -7790 9249 -7820 9273 -7870 9295 -7890 9317 -7930 9337
--7950 9357 -7990 9375 -8010 9393 -8030 9409 -8060 9426 -8090 9441 -8110 9457
--8120 9470 -8150 9483 -8170 9496 -8180 9509 -8200 9521 -8220 9532 -8230 9542
--8250 9554 -8270 9563 -8280 9573 -8300 9582 -8300 9591 -8320 9600 -8330 9608
--8330 9616 -8360 9624 -8360 9632 -8370 9639 -8370 9646 -8390 9652 -8400 9658
--8410 9665 -8410 9671 -8430 9677 -8430 9683 -8430 9687 -8440 9694 -8450 9698
--8460 9703 -8460 9707 -8470 9713 -8470 9716 -8480 9721
-224: 15012640 -4496711 -10270 9935 -10270 9936 -10280 9937 -10280 9939
--10290 9941 -10300 9941 -10300 9944 -10310 9946 -10310 9948 -10320 9949
--10330 9951 -10340 9952 -10360 9955 -10350 9956 -10370 9959 -10370 9960
--10380 9963 -10390 9966 -10400 9968 -10410 9968 -10410 9970 -10430 9973
--10440 9976 -10450 9977 -10450 9978 -10460 9979 -10470 9983 -10480 9983
--10490 9984 -10490 9987 -10500 9989 -10520 9991 -10520 9994 -10520 9997
--10540 9998 -10530 10000 -10550 10006 -10550 10007 -10570 10010 -10570 10015
--10570 10017 -10580 10022 -10600 10023 -10600 10029 -10610 10031 -10620 10037
--10630 10042 -10650 10045 -10650 10050 -10660 10054 -10680 10057 -10690 10061
--10710 10066 -10720 10068 -10730 10073 -10740 10076 -10760 10080 -10760 10081
--10790 10085 -10790 10087 -10810 10089 -10820 10090 -10830 10091 -10840 10092
--10860 10093 -10870 10093 -10860 10093 -10870 10094 -10890 10094 -10890 10092
--10900 10091 -10910 10091 -10910 10092 -10910 10090 -10910 10087 -10920 10087
--10920 10088 -10920 10088 -10920 10086 -10930 10087 -10920 10089 -10930 10088
--10920 10089 -10930 10093 -10940 10096 -10930 10098 -10930 10103 -10940 10107
--10940 10111 -10940 10116 -10950 10123 -10960 10129 -10960 10136 -10970 10144
--10990 10151 -10990 10158 -11000 10166 -11010 10173 -11030 10181 -11040 10191
--11050 10199 -11070 10209 -11080 10215 -11100 10223 -11110 10229 -11120 10236
--11140 10241 -11160 10248 -11160 10253 -11180 10257 -11200 10259 -11200 10262
--11230 10263 -11230 10264 -11240 10263 -11250 10262 -11250 10260 -11260 10256
--11260 10249 -11260 10247 -11270 10240 -11260 10234 -11250 10224 -11240 10218
--11230 10208 -11220 10198 -11210 10188 -11190 10177 -11170 10167 -11160 10154
--11140 10143 -11110 10130 -11080 10120 -11060 10109 -11040 10098 -11010 10087
--10970 10078 -10950 10066 -10930 10055 -10890 10047 -10870 10040 -10830 10034
--10810 10025 -10770 10019 -10750 10014 -10720 10010 -10700 10006 -10670 10003
--10660 10001 -10650 10001 -10610 10002 -10610 10001 -10600 10003 -10580 10004
--10580 10006 -10580 10010 -10570 10014 -10580 10018 -10600 10023 -10600 10029
--10610 10034 -10630 10039 -10650 10045 -10670 10051 -10700 10059 -10720 10064
--10760 10069 -10790 10075 -10820 10080 -10850 10086 -10900 10089 -10920 10094
--10960 10100 -11010 10102 -11050 10106 -11070 10108 -11110 10110 -11150 10113
--11190 10114 -11220 10115 -11240 10115 -11260 10117 -11280 10117 -11290 10115
--11290 10117 -11300 10116 -11280 10117 -11260 10118 -11230 10118 -11220 10119
--11170 10119 -11120 10121 -11050 10126 -10970 10129 -10880 10133 -10780 10139
--10670 10145 -10550 10153 -10400 10164 -10260 10175 -10090 10190 -9900 10205
--9710 10221 -9490 10240 -9260 10261 -9030 10285 -8760 10311 -8500 10338
--8200 10368 -7900 10403 -7580 10436 -7250 10474 -6910 10513 -6530 10556
--6170 10600 -5770 10648 -5370 10694 -4970 10744 -4550 10796 -4110 10851
--3650 10909 -3190 10966 -2730 11020 -2270 11076 -1790 11136 -1300 11197
--790 11259 -300 11319 180 11372 670 11427 1170 11482 1690 11538 2190 11594
-2680 11642 3150 11685 3640 11723 4120 11761 4560 11795 5010 11824 5440 11847
-5860 11868 6260 11878 6640 11882 7000 11881 7340 11879 7660 11872 7930 11860
-8190 11841 8430 11815 8640 11784 8810 11755 8960 11725 9090 11696 9170 11669
-9220 11640 9260 11615 9250 11587 9210 11561 9160 11540 9070 11525 8950 11514
-8800 11506 8640 11493 8450 11481 8230 11471 7970 11463 7710 11457 7440 11452
-7120 11442 6800 11427 6440 11405 6060 11377 5660 11344 5250 11304 4830 11261
-4410 11212 3980 11156 3490 11091 3020 11018 2530 10941 2050 10859 1580 10774
-1150 10689 720 10598 320 10506 -90 10412 -480 10317 -840 10222 -1170 10122
--1500 10016 -1830 9908 -2120 9798 -2400 9689 -2670 9581 -2980 9476 -3290 9364
--3590 9250 -3900 9138 -4200 9033 -4510 8931 -4840 8838 -5180 8749 -5520 8668
--5860 8596 -6230 8531 -6570 8476 -6930 8430 -7310 8392 -7670 8362 -8050 8341
--8410 8326 -8790 8321 -9140 8327 -9490 8345 -9820 8371 -10170 8403 -10500 8443
--10820 8491 -11140 8547 -11450 8611 -11770 8682 -12070 8760 -12390 8840
--12680 8925 -12980 9017 -13270 9114 -13560 9217 -13840 9320 -14120 9424
--14380 9530 -14640 9643 -14880 9764 -15100 9887 -15330 10010 -15550 10129
--15740 10246 -15930 10364 -16100 10481 -16260 10598 -16440 10710 -16570 10816
--16710 10913 -16850 11001 -16980 11080 -17090 11149 -17220 11212 -17330 11268
--17460 11313 -17600 11349 -17710 11371 -17850 11380 -17960 11385 -18100 11388
--18240 11382 -18390 11367 -18560 11346 -18730 11319 -18910 11286 -19070 11251
--19250 11213 -19420 11171 -19590 11128 -19790 11080 -19970 11029 -20180 10978
--20390 10922 -20610 10864 -20810 10805 -21040 10742 -21280 10677 -21490 10608
--21750 10535 -22000 10459 -22250 10380 -22500 10297 -22730 10210 -22950 10121
--23190 10027 -23380 9930 -23580 9830 -23730 9726 -23890 9621 -24020 9512
--24110 9402 -24180 9289 -24230 9174 -24230 9060 -24210 8942 -24160 8822
--24090 8701 -23980 8580 -23840 8457 -23690 8334 -23510 8210 -23310 8083
--23080 7956 -22850 7828 -22600 7699 -22330 7571 -22030 7443 -21740 7315
--21440 7186 -21130 7059 -20810 6934 -20460 6811 -20080 6690 -19710 6572
--19350 6458 -19010 6351 -18650 6249 -18240 6151 -17760 6058 -17300 5972
--16840 5894 -16370 5823 -15910 5762 -15430 5709 -14950 5664 -14470 5631
--13980 5605 -13470 5589 -13000 5580 -12520 5580 -12050 5589 -11570 5606
--11140 5631 -10710 5664 -10300 5702 -9910 5748 -9540 5799 -9190 5857 -8840 5920
--8540 5987 -8250 6060 -7990 6134 -7750 6214 -7530 6295 -7320 6380 -7130 6466
--6980 6555 -6850 6644 -6720 6734 -6620 6825 -6530 6917 -6450 7007 -6400 7098
--6350 7188 -6310 7278 -6300 7365 -6280 7453 -6290 7538 -6290 7622 -6310 7704
--6330 7784 -6360 7864 -6400 7939 -6450 8014 -6480 8086 -6540 8156 -6590 8224
--6650 8290 -6690 8353 -6740 8414 -6800 8472 -6860 8531 -6930 8586 -6980 8639
--7060 8687 -7120 8733 -7190 8777 -7250 8824 -7340 8871 -7380 8913 -7400 8950
--7440 8987 -7490 9022 -7520 9055 -7570 9088 -7610 9117 -7660 9148 -7700 9175
--7740 9203 -7780 9228 -7810 9252 -7850 9275 -7890 9297 -7910 9318 -7950 9339
--7970 9358 -8010 9376 -8030 9393 -8050 9409 -8080 9426 -8100 9441 -8120 9456
--8140 9470 -8160 9482 -8180 9496 -8200 9508 -8220 9519 -8230 9531 -8240 9542
--8260 9551 -8280 9562 -8290 9572 -8300 9580 -8320 9590 -8330 9598 -8340 9607
--8350 9614 -8360 9622 -8370 9630 -8380 9637 -8380 9644 -8400 9650 -8410 9657
--8420 9662 -8420 9670 -8430 9674 -8430 9680 -8450 9686 -8450 9691 -8460 9696
--8460 9701 -8470 9705 -8480 9710 -8480 9714 -8480 9719
-225: 15046070 -4488340 -10270 9935 -10270 9937 -10280 9938 -10280 9939
--10290 9943 -10310 9943 -10300 9944 -10310 9946 -10310 9949 -10320 9950
--10330 9950 -10340 9952 -10340 9954 -10360 9956 -10360 9958 -10370 9961
--10380 9964 -10390 9965 -10390 9967 -10410 9969 -10410 9969 -10430 9974
--10440 9975 -10440 9978 -10450 9975 -10460 9980 -10460 9981 -10480 9983
--10490 9983 -10480 9986 -10510 9990 -10500 9990 -10520 9993 -10520 9997
--10530 9997 -10540 10000 -10540 10004 -10540 10006 -10570 10009 -10560 10014
--10570 10017 -10580 10020 -10590 10021 -10600 10027 -10600 10032 -10610 10035
--10630 10040 -10640 10043 -10650 10048 -10660 10054 -10670 10056 -10680 10058
--10700 10064 -10710 10068 -10730 10070 -10730 10074 -10750 10077 -10760 10079
--10780 10082 -10780 10084 -10800 10088 -10800 10088 -10820 10090 -10840 10090
--10840 10089 -10860 10092 -10860 10091 -10860 10090 -10870 10091 -10890 10090
--10880 10089 -10900 10087 -10890 10089 -10900 10089 -10900 10085 -10910 10084
--10900 10084 -10910 10085 -10920 10084 -10910 10084 -10910 10085 -10910 10086
--10920 10088 -10910 10089 -10920 10092 -10920 10094 -10930 10097 -10920 10103
--10930 10106 -10920 10113 -10940 10117 -10950 10125 -10940 10130 -10960 10138
--10970 10146 -10970 10152 -10990 10159 -10990 10168 -11020 10176 -11020 10184
--11040 10193 -11040 10203 -11070 10210 -11070 10214 -11090 10222 -11110 10230
--11120 10236 -11130 10241 -11150 10246 -11160 10252 -11170 10253 -11190 10256
--11190 10258 -11210 10258 -11220 10258 -11220 10257 -11230 10255 -11230 10252
--11240 10246 -11240 10244 -11240 10237 -11230 10232 -11230 10224 -11220 10216
--11210 10205 -11190 10198 -11190 10190 -11160 10177 -11160 10167 -11130 10156
--11110 10145 -11090 10133 -11060 10122 -11040 10112 -11020 10101 -10990 10090
--10950 10081 -10930 10069 -10910 10061 -10870 10050 -10840 10045 -10810 10037
--10780 10029 -10750 10023 -10720 10019 -10710 10012 -10670 10009 -10660 10004
--10630 10002 -10610 10004 -10590 10001 -10580 10002 -10570 10003 -10550 10001
--10550 10006 -10550 10007 -10540 10012 -10540 10015 -10560 10017 -10560 10021
--10580 10028 -10590 10033 -10610 10036 -10620 10043 -10650 10046 -10680 10054
--10710 10057 -10750 10061 -10770 10067 -10810 10071 -10840 10073 -10870 10077
--10920 10082 -10960 10084 -10990 10086 -11030 10089 -11070 10091 -11110 10091
--11130 10091 -11180 10094 -11200 10093 -11220 10093 -11230 10094 -11260 10092
--11260 10091 -11270 10092 -11250 10092 -11250 10093 -11220 10093 -11200 10093
--11170 10093 -11120 10095 -11060 10100 -10990 10103 -10910 10107 -10810 10111
--10710 10118 -10600 10126 -10460 10136 -10320 10148 -10170 10162 -9990 10176
--9800 10191 -9600 10210 -9390 10231 -9160 10254 -8910 10279 -8650 10305
--8380 10335 -8080 10367 -7780 10399 -7470 10437 -7130 10474 -6770 10515
--6420 10558 -6030 10604 -5660 10649 -5270 10696 -4850 10746 -4430 10800
--3990 10854 -3550 10909 -3100 10960 -2660 11016 -2180 11073 -1720 11130
--1220 11190 -750 11247 -270 11299 190 11349 690 11404 1180 11456 1680 11510
-2150 11556 2610 11597 3100 11636 3550 11672 4000 11704 4420 11732 4840 11757
-5240 11776 5650 11788 6010 11793 6370 11794 6700 11794 7010 11791 7290 11781
-7540 11766 7780 11745 7990 11721 8160 11695 8330 11670 8450 11646 8540 11623
-8600 11598 8650 11575 8650 11552 8630 11529 8570 11509 8500 11495 8400 11486
-8270 11476 8120 11464 7940 11451 7740 11439 7510 11429 7250 11423 6990 11413
-6720 11402 6400 11384 6060 11362 5700 11331 5330 11298 4950 11259 4550 11216
-4130 11167 3730 11112 3280 11048 2830 10979 2370 10902 1920 10824 1470 10743
-1060 10658 650 10573 260 10481 -130 10389 -510 10295 -860 10202 -1190 10105
--1530 10003 -1840 9896 -2140 9788 -2420 9682 -2700 9579 -3010 9478 -3320 9369
--3620 9260 -3930 9152 -4230 9052 -4540 8954 -4870 8865 -5180 8780 -5530 8701
--5860 8631 -6220 8568 -6550 8513 -6910 8467 -7260 8430 -7620 8400 -7990 8377
--8340 8362 -8700 8357 -9050 8361 -9390 8375 -9720 8398 -10050 8429 -10370 8465
--10700 8508 -11000 8559 -11300 8620 -11620 8688 -11910 8759 -12210 8835
--12510 8916 -12790 9002 -13080 9094 -13360 9192 -13620 9291 -13890 9390
--14150 9491 -14390 9600 -14620 9712 -14850 9831 -15050 9946 -15270 10060
--15460 10171 -15630 10282 -15810 10394 -15960 10503 -16120 10610 -16270 10711
--16390 10803 -16540 10887 -16660 10964 -16780 11031 -16890 11093 -17010 11147
--17130 11194 -17250 11229 -17380 11253 -17500 11267 -17620 11274 -17740 11280
--17880 11278 -18030 11269 -18190 11251 -18350 11229 -18520 11201 -18680 11171
--18850 11136 -19010 11099 -19180 11059 -19370 11017 -19540 10970 -19750 10921
--19950 10869 -20160 10816 -20360 10759 -20580 10701 -20800 10639 -21020 10573
--21250 10504 -21500 10432 -21730 10356 -21960 10278 -22180 10196 -22400 10110
--22620 10022 -22790 9929 -22980 9834 -23140 9735 -23290 9635 -23400 9532
--23490 9427 -23560 9319 -23600 9209 -23620 9100 -23600 8987 -23570 8873
--23500 8756 -23400 8639 -23280 8521 -23140 8404 -22980 8284 -22790 8163
--22580 8040 -22370 7917 -22130 7794 -21880 7671 -21610 7549 -21320 7425
--21060 7303 -20750 7181 -20430 7061 -20120 6944 -19740 6829 -19400 6716
--19040 6608 -18720 6505 -18370 6408 -17980 6316 -17530 6226 -17080 6144
--16630 6069 -16180 6002 -15740 5942 -15300 5890 -14840 5848 -14380 5814
--13920 5789 -13450 5771 -12990 5762 -12540 5761 -12100 5766 -11660 5781
--11230 5804 -10810 5832 -10430 5868 -10060 5909 -9680 5956 -9350 6009
--9030 6068 -8720 6130 -8440 6198 -8190 6267 -7950 6341 -7720 6418 -7530 6498
--7350 6579 -7190 6662 -7040 6746 -6930 6832 -6820 6918 -6720 7004 -6660 7090
--6590 7177 -6540 7263 -6500 7348 -6460 7431 -6460 7515 -6450 7597 -6450 7676
--6460 7756 -6480 7833 -6500 7908 -6530 7982 -6570 8053 -6610 8122 -6660 8190
--6690 8256 -6750 8320 -6780 8379 -6850 8439 -6890 8496 -6940 8552 -7000 8607
--7070 8656 -7120 8704 -7190 8748 -7250 8792 -7300 8837 -7390 8883 -7420 8923
--7460 8960 -7480 8996 -7520 9030 -7570 9063 -7610 9094 -7650 9123 -7690 9153
--7740 9180 -7770 9207 -7800 9232 -7840 9255 -7880 9278 -7910 9299 -7940 9320
--7960 9341 -8000 9359 -8020 9377 -8050 9394 -8070 9410 -8090 9426 -8120 9441
--8140 9456 -8150 9469 -8170 9482 -8200 9495 -8220 9507 -8230 9519 -8240 9530
--8260 9541 -8270 9550 -8290 9561 -8300 9570 -8310 9580 -8330 9588 -8340 9597
--8350 9604 -8360 9613 -8370 9620 -8380 9628 -8390 9635 -8400 9642 -8400 9649
--8420 9654 -8430 9661 -8430 9667 -8440 9673 -8440 9679 -8450 9683 -8460 9689
--8470 9694 -8470 9698 -8480 9704 -8480 9708 -8490 9712 -8490 9716
-226: 15079520 -4479971 -10270 9935 -10280 9936 -10280 9939 -10280 9941
--10290 9942 -10300 9945 -10310 9945 -10300 9945 -10310 9950 -10330 9950
--10330 9951 -10330 9953 -10350 9952 -10350 9957 -10360 9958 -10370 9960
--10380 9963 -10380 9965 -10390 9966 -10400 9969 -10420 9971 -10420 9971
--10440 9975 -10440 9977 -10440 9976 -10460 9979 -10470 9980 -10460 9982
--10480 9984 -10490 9985 -10500 9987 -10500 9991 -10510 9993 -10520 9997
--10530 9996 -10530 10000 -10530 10001 -10550 10006 -10550 10007 -10570 10012
--10570 10016 -10570 10019 -10580 10021 -10590 10027 -10600 10031 -10610 10034
--10620 10038 -10630 10042 -10640 10047 -10660 10050 -10670 10053 -10680 10058
--10690 10063 -10700 10064 -10720 10068 -10720 10072 -10750 10075 -10750 10077
--10760 10081 -10770 10082 -10790 10085 -10800 10085 -10820 10087 -10810 10089
--10840 10089 -10840 10088 -10850 10089 -10850 10089 -10870 10087 -10870 10088
--10870 10086 -10880 10085 -10880 10086 -10890 10085 -10890 10084 -10890 10082
--10900 10080 -10900 10082 -10890 10081 -10900 10081 -10900 10083 -10910 10083
--10900 10085 -10900 10085 -10910 10088 -10910 10090 -10910 10094 -10910 10097
--10920 10103 -10910 10108 -10920 10113 -10930 10119 -10940 10125 -10940 10132
--10950 10141 -10960 10146 -10980 10154 -10980 10162 -10990 10170 -11000 10178
--11020 10187 -11030 10196 -11050 10203 -11050 10208 -11070 10216 -11090 10223
--11100 10229 -11110 10235 -11130 10240 -11140 10245 -11140 10249 -11170 10250
--11180 10252 -11190 10252 -11190 10252 -11190 10252 -11210 10251 -11210 10249
--11220 10244 -11210 10239 -11220 10235 -11200 10229 -11200 10222 -11200 10214
--11180 10205 -11180 10196 -11150 10190 -11150 10179 -11130 10167 -11110 10158
--11080 10147 -11070 10135 -11050 10123 -11020 10116 -10990 10104 -10970 10092
--10930 10083 -10910 10073 -10890 10065 -10840 10056 -10820 10048 -10790 10042
--10760 10032 -10720 10028 -10700 10021 -10690 10015 -10650 10011 -10630 10008
--10600 10005 -10590 10003 -10570 10003 -10550 10002 -10540 10003 -10520 10002
--10530 10003 -10510 10006 -10510 10010 -10510 10011 -10530 10013 -10520 10017
--10530 10021 -10550 10026 -10580 10028 -10590 10034 -10600 10038 -10640 10042
--10670 10046 -10690 10049 -10720 10052 -10760 10058 -10790 10059 -10840 10062
--10870 10065 -10910 10066 -10940 10070 -10990 10071 -11010 10072 -11060 10071
--11100 10071 -11120 10072 -11160 10072 -11180 10072 -11200 10071 -11220 10070
--11230 10068 -11240 10068 -11230 10068 -11220 10070 -11210 10069 -11190 10069
--11160 10068 -11120 10069 -11080 10075 -11000 10078 -10920 10081 -10850 10085
--10750 10091 -10640 10100 -10530 10110 -10380 10121 -10240 10133 -10070 10147
--9900 10164 -9710 10180 -9510 10200 -9280 10222 -9060 10247 -8810 10272
--8540 10301 -8270 10331 -7970 10365 -7670 10398 -7350 10434 -7010 10474
--6660 10517 -6310 10559 -5930 10603 -5560 10648 -5160 10697 -4750 10747
--4330 10799 -3890 10852 -3470 10902 -3040 10954 -2590 11009 -2110 11064
--1650 11121 -1180 11175 -730 11225 -280 11273 200 11325 690 11376 1160 11427
-1630 11471 2080 11510 2540 11549 3000 11583 3420 11613 3840 11644 4240 11666
-4640 11685 5030 11699 5390 11706 5730 11709 6070 11710 6370 11710 6640 11703
-6890 11691 7130 11674 7350 11655 7530 11634 7680 11613 7810 11593 7910 11573
-7980 11553 8030 11532 8050 11513 8040 11492 8000 11474 7920 11461 7850 11452
-7720 11442 7590 11431 7430 11418 7250 11404 7020 11394 6800 11385 6540 11372
-6290 11360 5990 11340 5690 11317 5330 11288 4980 11252 4620 11213 4260 11170
-3860 11123 3470 11067 3050 11006 2620 10939 2190 10865 1770 10790 1340 10710
-950 10630 560 10545 190 10455 -190 10366 -570 10275 -910 10183 -1230 10088
--1560 9988 -1880 9887 -2180 9780 -2470 9677 -2720 9577 -3050 9479 -3350 9375
--3670 9270 -3970 9166 -4260 9070 -4570 8977 -4890 8890 -5200 8809 -5530 8733
--5870 8664 -6200 8603 -6550 8550 -6880 8503 -7230 8466 -7570 8436 -7930 8414
--8280 8397 -8610 8391 -8970 8392 -9290 8405 -9620 8424 -9930 8453 -10260 8485
--10560 8524 -10870 8573 -11160 8628 -11460 8692 -11750 8759 -12050 8830
--12320 8906 -12610 8988 -12880 9075 -13150 9168 -13420 9262 -13660 9357
--13910 9453 -14140 9555 -14370 9663 -14580 9774 -14780 9884 -14980 9991
--15180 10097 -15350 10203 -15500 10308 -15660 10413 -15820 10513 -15940 10608
--16080 10698 -16220 10777 -16340 10851 -16450 10918 -16570 10977 -16680 11031
--16790 11077 -16920 11113 -17030 11140 -17160 11155 -17250 11166 -17380 11175
--17520 11177 -17670 11170 -17810 11157 -17960 11139 -18130 11117 -18290 11090
--18440 11060 -18600 11027 -18770 10990 -18940 10952 -19120 10909 -19310 10865
--19510 10816 -19700 10767 -19910 10714 -20110 10659 -20320 10600 -20540 10538
--20760 10473 -20980 10405 -21200 10334 -21430 10259 -21640 10181 -21840 10100
--22030 10015 -22230 9929 -22390 9838 -22540 9744 -22680 9650 -22800 9551
--22870 9451 -22950 9348 -22990 9244 -23010 9140 -23000 9031 -22980 8922
--22910 8811 -22830 8699 -22720 8585 -22580 8473 -22450 8358 -22280 8241
--22080 8124 -21890 8007 -21660 7888 -21430 7771 -21170 7653 -20910 7535
--20650 7419 -20360 7302 -20070 7188 -19760 7075 -19410 6966 -19070 6859
--18740 6755 -18420 6658 -18090 6565 -17720 6477 -17290 6392 -16850 6312
--16440 6241 -16000 6176 -15570 6119 -15150 6068 -14720 6028 -14290 5994
--13850 5969 -13420 5951 -12980 5940 -12540 5937 -12140 5942 -11710 5953
--11310 5973 -10920 5999 -10530 6030 -10180 6068 -9820 6112 -9510 6160
--9190 6214 -8890 6272 -8620 6335 -8370 6400 -8140 6468 -7920 6541 -7730 6615
--7540 6691 -7390 6770 -7240 6849 -7120 6930 -7020 7011 -6920 7093 -6840 7175
--6770 7257 -6730 7338 -6670 7419 -6650 7499 -6610 7578 -6620 7656 -6600 7733
--6620 7809 -6620 7882 -6640 7955 -6660 8025 -6700 8093 -6730 8161 -6760 8225
--6800 8289 -6840 8350 -6900 8409 -6930 8465 -6980 8520 -7030 8575 -7080 8627
--7140 8677 -7190 8721 -7260 8765 -7310 8807 -7360 8850 -7440 8896 -7480 8935
--7510 8971 -7520 9005 -7570 9039 -7610 9071 -7650 9101 -7690 9130 -7720 9159
--7770 9185 -7800 9212 -7840 9236 -7870 9259 -7900 9281 -7930 9302 -7960 9323
--7990 9342 -8020 9361 -8040 9379 -8070 9395 -8090 9411 -8110 9426 -8140 9442
--8150 9456 -8170 9470 -8190 9482 -8220 9494 -8220 9507 -8240 9518 -8260 9529
--8270 9540 -8290 9550 -8300 9559 -8310 9569 -8330 9578 -8340 9587 -8350 9596
--8360 9603 -8370 9611 -8380 9619 -8390 9626 -8400 9634 -8410 9640 -8410 9646
--8430 9653 -8430 9659 -8440 9665 -8450 9671 -8450 9677 -8470 9681 -8460 9687
--8470 9692 -8480 9696 -8490 9702 -8490 9705 -8500 9710 -8500 9714
-227: 15112980 -4471607 -10280 9936 -10280 9938 -10270 9940 -10290 9939
--10290 9943 -10300 9946 -10300 9945 -10300 9946 -10310 9948 -10330 9951
--10320 9951 -10340 9952 -10340 9953 -10350 9957 -10350 9960 -10370 9960
--10380 9960 -10390 9964 -10390 9966 -10400 9969 -10410 9970 -10420 9971
--10430 9974 -10430 9977 -10450 9976 -10450 9978 -10460 9979 -10470 9981
--10470 9984 -10490 9984 -10490 9987 -10500 9989 -10510 9994 -10510 9995
--10530 9996 -10520 9998 -10540 10001 -10540 10005 -10550 10006 -10550 10012
--10570 10014 -10570 10018 -10570 10022 -10590 10025 -10600 10029 -10600 10032
--10610 10037 -10630 10042 -10630 10044 -10650 10047 -10670 10052 -10670 10058
--10680 10059 -10700 10064 -10710 10066 -10720 10071 -10730 10072 -10740 10076
--10760 10078 -10760 10079 -10780 10083 -10790 10083 -10800 10084 -10810 10088
--10820 10085 -10830 10087 -10840 10087 -10850 10087 -10850 10086 -10850 10084
--10860 10084 -10870 10083 -10870 10082 -10880 10082 -10880 10081 -10880 10080
--10880 10077 -10890 10079 -10880 10079 -10890 10078 -10890 10080 -10890 10080
--10900 10082 -10890 10081 -10890 10084 -10900 10086 -10900 10092 -10890 10094
--10900 10097 -10910 10102 -10910 10109 -10910 10115 -10930 10120 -10930 10127
--10930 10134 -10950 10142 -10960 10148 -10960 10156 -10970 10163 -10990 10173
--11000 10181 -11010 10189 -11030 10195 -11040 10202 -11050 10209 -11060 10217
--11080 10224 -11100 10229 -11110 10235 -11110 10238 -11130 10242 -11150 10244
--11150 10246 -11160 10248 -11170 10248 -11180 10246 -11180 10246 -11190 10245
--11180 10241 -11190 10236 -11190 10232 -11180 10226 -11190 10218 -11170 10213
--11160 10203 -11150 10196 -11140 10190 -11120 10179 -11110 10169 -11080 10157
--11070 10149 -11040 10137 -11020 10127 -11000 10117 -10970 10107 -10950 10097
--10920 10085 -10890 10077 -10860 10068 -10820 10060 -10800 10052 -10760 10045
--10740 10037 -10710 10030 -10670 10024 -10660 10018 -10640 10014 -10600 10011
--10580 10007 -10560 10007 -10550 10003 -10530 10004 -10500 10002 -10500 10002
--10490 10001 -10480 10005 -10490 10007 -10480 10007 -10490 10010 -10490 10014
--10500 10016 -10510 10020 -10530 10022 -10550 10025 -10570 10029 -10590 10031
--10620 10035 -10660 10038 -10680 10043 -10700 10043 -10740 10046 -10790 10049
--10830 10049 -10860 10051 -10910 10053 -10920 10055 -10970 10053 -11020 10053
--11050 10052 -11090 10052 -11110 10053 -11130 10051 -11160 10050 -11180 10049
--11210 10047 -11200 10046 -11210 10046 -11200 10046 -11190 10046 -11180 10046
--11170 10045 -11110 10045 -11080 10050 -11010 10054 -10950 10056 -10870 10060
--10780 10066 -10700 10073 -10570 10084 -10450 10094 -10310 10106 -10160 10119
--9990 10135 -9810 10151 -9630 10170 -9400 10192 -9190 10215 -8960 10240
--8700 10267 -8450 10296 -8170 10328 -7860 10360 -7570 10395 -7240 10433
--6910 10474 -6560 10515 -6200 10557 -5850 10600 -5460 10647 -5060 10695
--4660 10744 -4250 10796 -3820 10843 -3410 10892 -2980 10945 -2520 10998
--2060 11053 -1630 11104 -1170 11151 -740 11197 -280 11248 200 11297 660 11343
-1110 11387 1540 11426 2000 11461 2420 11494 2850 11525 3250 11553 3660 11577
-4040 11598 4410 11610 4770 11620 5110 11624 5430 11628 5730 11629 6000 11625
-6260 11618 6490 11603 6710 11588 6880 11570 7050 11554 7180 11538 7280 11520
-7360 11504 7420 11487 7430 11470 7450 11451 7420 11436 7350 11424 7280 11414
-7180 11405 7060 11393 6910 11380 6750 11368 6540 11356 6330 11343 6100 11332
-5840 11317 5580 11295 5290 11272 4960 11241 4630 11207 4290 11167 3940 11125
-3570 11078 3200 11025 2820 10964 2400 10899 1990 10829 1600 10754 1200 10678
-820 10600 440 10518 80 10431 -280 10343 -630 10254 -980 10164 -1290 10071
--1610 9976 -1930 9875 -2240 9774 -2510 9672 -2770 9577 -3090 9481 -3410 9380
--3710 9281 -4000 9181 -4300 9087 -4610 8999 -4910 8915 -5230 8836 -5550 8763
--5870 8697 -6210 8637 -6530 8584 -6860 8538 -7200 8501 -7520 8472 -7870 8448
--8210 8430 -8540 8423 -8880 8424 -9210 8432 -9510 8451 -9830 8475 -10130 8504
--10440 8541 -10730 8585 -11020 8637 -11300 8695 -11600 8759 -11880 8826
--12150 8896 -12420 8974 -12680 9056 -12940 9144 -13200 9234 -13440 9323
--13670 9415 -13890 9512 -14110 9614 -14320 9720 -14510 9823 -14710 9924
--14890 10026 -15050 10125 -15210 10225 -15360 10324 -15500 10420 -15630 10510
--15780 10595 -15890 10672 -16010 10743 -16130 10807 -16240 10866 -16350 10919
--16460 10965 -16570 11000 -16680 11030 -16800 11047 -16910 11060 -17020 11073
--17150 11076 -17290 11074 -17430 11064 -17580 11052 -17740 11032 -17890 11009
--18030 10984 -18200 10954 -18340 10923 -18510 10887 -18690 10848 -18880 10808
--19060 10764 -19240 10717 -19450 10667 -19640 10616 -19850 10562 -20040 10504
--20260 10442 -20470 10378 -20680 10310 -20890 10240 -21090 10166 -21280 10090
--21470 10010 -21660 9927 -21800 9842 -21960 9754 -22080 9663 -22190 9570
--22280 9475 -22340 9377 -22380 9278 -22410 9178 -22410 9075 -22390 8971
--22330 8865 -22260 8757 -22170 8650 -22040 8541 -21910 8431 -21760 8319
--21580 8208 -21400 8094 -21200 7982 -20980 7869 -20740 7757 -20490 7645
--20230 7532 -19980 7422 -19690 7313 -19390 7205 -19070 7102 -18750 6999
--18440 6900 -18130 6807 -17800 6719 -17460 6636 -17050 6553 -16630 6478
--16230 6410 -15810 6347 -15420 6291 -15000 6243 -14600 6203 -14190 6170
--13780 6145 -13370 6127 -12950 6115 -12550 6110 -12150 6113 -11760 6123
--11370 6140 -10990 6162 -10630 6191 -10290 6225 -9950 6264 -9640 6309
--9330 6359 -9050 6412 -8800 6471 -8540 6531 -8320 6595 -8110 6663 -7910 6732
--7730 6804 -7580 6877 -7430 6952 -7300 7028 -7200 7105 -7110 7182 -7020 7260
--6960 7337 -6900 7415 -6850 7491 -6810 7567 -6780 7643 -6770 7717 -6760 7791
--6760 7862 -6760 7933 -6770 8002 -6800 8070 -6820 8135 -6850 8199 -6870 8263
--6910 8323 -6950 8381 -6990 8438 -7030 8493 -7070 8546 -7110 8599 -7170 8649
--7210 8696 -7270 8741 -7320 8782 -7370 8823 -7420 8865 -7500 8910 -7530 8947
--7550 8983 -7580 9015 -7620 9049 -7650 9079 -7690 9109 -7730 9138 -7760 9165
--7800 9191 -7830 9217 -7870 9241 -7900 9263 -7930 9285 -7950 9305 -7990 9326
--8020 9345 -8030 9363 -8070 9380 -8090 9397 -8110 9412 -8130 9428 -8150 9442
--8170 9457 -8190 9469 -8210 9483 -8220 9494 -8250 9506 -8250 9518 -8280 9529
--8280 9539 -8310 9549 -8310 9559 -8320 9568 -8340 9577 -8350 9586 -8360 9594
--8370 9602 -8380 9609 -8390 9618 -8410 9624 -8410 9632 -8420 9639 -8420 9645
--8430 9651 -8450 9657 -8440 9664 -8460 9668 -8460 9675 -8470 9680 -8480 9684
--8480 9690 -8490 9695 -8490 9699 -8500 9704 -8510 9708 -8510 9711
-228: 15146450 -4463246 -10270 9937 -10280 9939 -10280 9939 -10290 9941
--10290 9942 -10290 9946 -10300 9945 -10310 9947 -10310 9947 -10320 9951
--10320 9952 -10340 9953 -10330 9952 -10350 9958 -10350 9960 -10370 9959
--10380 9962 -10390 9963 -10380 9964 -10400 9967 -10410 9971 -10420 9969
--10420 9974 -10440 9975 -10440 9977 -10450 9978 -10450 9980 -10460 9980
--10480 9983 -10480 9983 -10480 9986 -10500 9989 -10500 9992 -10510 9993
--10520 9996 -10520 9998 -10540 10000 -10540 10005 -10540 10006 -10550 10009
--10550 10013 -10570 10018 -10580 10019 -10580 10023 -10590 10028 -10600 10033
--10610 10035 -10620 10040 -10630 10042 -10640 10046 -10650 10050 -10670 10054
--10680 10058 -10690 10062 -10700 10066 -10710 10068 -10730 10070 -10730 10075
--10740 10075 -10760 10078 -10770 10080 -10770 10081 -10790 10083 -10810 10083
--10800 10085 -10820 10084 -10840 10084 -10830 10084 -10840 10084 -10840 10082
--10850 10081 -10860 10081 -10860 10080 -10860 10078 -10870 10079 -10870 10078
--10870 10076 -10870 10075 -10870 10076 -10880 10076 -10880 10077 -10880 10077
--10880 10078 -10880 10079 -10890 10081 -10880 10082 -10890 10087 -10880 10090
--10890 10094 -10890 10099 -10900 10103 -10900 10111 -10910 10115 -10910 10121
--10930 10129 -10930 10137 -10940 10143 -10940 10149 -10970 10156 -10960 10167
--10990 10174 -10990 10183 -11010 10190 -11020 10195 -11030 10203 -11050 10211
--11060 10217 -11070 10223 -11090 10227 -11100 10232 -11110 10235 -11120 10239
--11130 10241 -11140 10242 -11150 10244 -11150 10242 -11160 10241 -11160 10240
--11160 10238 -11170 10234 -11160 10228 -11170 10222 -11160 10217 -11140 10209
--11140 10203 -11130 10194 -11110 10189 -11100 10179 -11080 10169 -11070 10159
--11040 10149 -11030 10140 -11000 10128 -10970 10121 -10950 10109 -10930 10099
--10900 10091 -10850 10079 -10850 10073 -10810 10063 -10770 10056 -10740 10047
--10710 10040 -10690 10034 -10660 10027 -10640 10021 -10610 10018 -10580 10013
--10550 10010 -10540 10009 -10520 10003 -10500 10005 -10490 10003 -10470 10002
--10460 10002 -10450 10003 -10460 10004 -10450 10005 -10450 10007 -10460 10009
--10470 10012 -10470 10015 -10500 10016 -10510 10017 -10520 10021 -10550 10023
--10580 10027 -10610 10029 -10640 10030 -10660 10032 -10700 10034 -10730 10035
--10790 10036 -10820 10037 -10860 10038 -10880 10038 -10930 10036 -10970 10036
--11010 10035 -11040 10034 -11070 10034 -11090 10032 -11120 10030 -11140 10028
--11170 10027 -11180 10026 -11180 10025 -11180 10024 -11180 10025 -11160 10023
--11150 10023 -11120 10023 -11070 10026 -11030 10029 -10960 10033 -10900 10037
--10820 10041 -10740 10047 -10620 10058 -10510 10068 -10380 10079 -10230 10093
--10080 10106 -9910 10122 -9730 10141 -9530 10161 -9320 10184 -9100 10208
--8870 10233 -8610 10261 -8350 10292 -8070 10322 -7770 10356 -7460 10393
--7150 10431 -6810 10470 -6470 10512 -6130 10551 -5750 10597 -5380 10644
--4980 10691 -4590 10738 -4180 10785 -3770 10832 -3350 10881 -2920 10933
--2490 10984 -2050 11033 -1620 11078 -1190 11124 -750 11170 -290 11218
-160 11262 590 11304 1020 11342 1450 11375 1860 11407 2280 11437 2680 11466
-3070 11488 3450 11510 3800 11525 4160 11534 4480 11542 4810 11545 5090 11549
-5370 11548 5630 11542 5860 11532 6070 11520 6250 11507 6410 11493 6550 11481
-6650 11467 6750 11453 6800 11438 6840 11423 6840 11407 6830 11394 6790 11383
-6720 11373 6630 11364 6520 11353 6390 11340 6240 11328 6060 11315 5860 11302
-5640 11288 5410 11272 5160 11250 4880 11226 4580 11195 4260 11161 3950 11122
-3620 11080 3280 11034 2910 10981 2550 10923 2180 10860 1790 10792 1410 10719
-1040 10646 660 10570 310 10491 -30 10406 -380 10320 -720 10234 -1070 10146
--1360 10056 -1680 9962 -2000 9865 -2300 9767 -2560 9670 -2850 9576 -3140 9483
--3460 9387 -3750 9291 -4050 9195 -4350 9105 -4640 9020 -4950 8940 -5260 8863
--5570 8792 -5880 8727 -6210 8669 -6520 8617 -6840 8572 -7170 8536 -7490 8505
--7820 8480 -8140 8464 -8480 8454 -8790 8453 -9120 8460 -9410 8475 -9720 8497
--10020 8523 -10320 8556 -10600 8597 -10870 8645 -11160 8700 -11440 8759
--11720 8821 -11970 8888 -12230 8960 -12490 9037 -12730 9121 -12970 9206
--13220 9291 -13430 9378 -13650 9469 -13860 9566 -14060 9666 -14240 9765
--14430 9860 -14600 9956 -14760 10050 -14910 10145 -15060 10238 -15190 10329
--15330 10416 -15450 10497 -15580 10570 -15690 10639 -15800 10701 -15910 10759
--16010 10810 -16120 10856 -16220 10893 -16340 10922 -16440 10942 -16550 10959
--16670 10971 -16780 10979 -16920 10980 -17060 10974 -17190 10964 -17340 10948
--17490 10930 -17630 10908 -17780 10883 -17920 10854 -18090 10822 -18260 10788
--18430 10751 -18610 10710 -18790 10667 -18990 10622 -19170 10573 -19360 10523
--19570 10469 -19750 10411 -19960 10350 -20160 10288 -20360 10221 -20540 10151
--20730 10080 -20910 10004 -21080 9926 -21240 9846 -21360 9762 -21500 9677
--21590 9588 -21690 9497 -21740 9406 -21790 9311 -21820 9216 -21820 9118
--21800 9019 -21770 8917 -21700 8815 -21610 8712 -21500 8608 -21390 8504
--21240 8396 -21090 8290 -20910 8181 -20730 8075 -20530 7966 -20300 7859
--20060 7753 -19830 7645 -19590 7539 -19310 7436 -19030 7334 -18730 7234
--18420 7136 -18130 7043 -17840 6954 -17520 6869 -17190 6791 -16800 6712
--16420 6640 -16020 6573 -15640 6514 -15250 6460 -14860 6414 -14470 6374
--14100 6342 -13690 6317 -13310 6298 -12920 6286 -12530 6280 -12160 6281
--11780 6289 -11420 6303 -11060 6323 -10710 6348 -10380 6379 -10070 6415
--9760 6456 -9470 6501 -9200 6551 -8940 6605 -8710 6661 -8480 6721 -8280 6783
--8090 6849 -7910 6916 -7760 6984 -7600 7055 -7490 7126 -7380 7199 -7280 7271
--7200 7345 -7120 7418 -7070 7491 -7020 7565 -6970 7636 -6940 7708 -6920 7779
--6920 7848 -6900 7917 -6900 7985 -6910 8051 -6930 8115 -6930 8178 -6970 8240
--6990 8299 -7010 8358 -7060 8415 -7090 8468 -7120 8521 -7160 8573 -7200 8623
--7240 8673 -7300 8717 -7330 8761 -7390 8800 -7430 8840 -7480 8881 -7560 8924
--7580 8961 -7610 8994 -7640 9027 -7660 9058 -7690 9089 -7740 9118 -7760 9145
--7800 9172 -7830 9198 -7870 9222 -7900 9246 -7930 9268 -7950 9289 -7990 9309
--8010 9329 -8040 9348 -8070 9366 -8090 9382 -8100 9399 -8140 9414 -8150 9429
--8170 9443 -8190 9458 -8200 9470 -8230 9482 -8240 9495 -8260 9506 -8270 9518
--8290 9528 -8300 9539 -8320 9549 -8320 9558 -8340 9567 -8340 9576 -8370 9585
--8370 9593 -8390 9600 -8390 9609 -8400 9616 -8410 9623 -8420 9630 -8430 9637
--8430 9644 -8440 9649 -8460 9656 -8450 9662 -8470 9667 -8470 9672 -8480 9678
--8480 9683 -8500 9688 -8490 9693 -8510 9697 -8500 9702 -8510 9706 -8520 9709
-229: 15179940 -4454889 -10270 9937 -10280 9940 -10280 9939 -10290 9941
--10280 9943 -10300 9944 -10300 9946 -10300 9947 -10310 9948 -10310 9950
--10330 9950 -10330 9955 -10340 9955 -10340 9958 -10360 9958 -10370 9958
--10370 9962 -10380 9963 -10390 9964 -10400 9967 -10410 9969 -10410 9970
--10420 9972 -10430 9974 -10440 9977 -10440 9978 -10450 9978 -10460 9981
--10470 9980 -10480 9984 -10480 9985 -10490 9989 -10500 9991 -10510 9992
--10510 9995 -10520 9998 -10530 10000 -10530 10003 -10540 10005 -10550 10009
--10550 10012 -10560 10016 -10570 10018 -10580 10022 -10580 10026 -10600 10032
--10600 10034 -10620 10038 -10620 10041 -10640 10044 -10640 10048 -10660 10051
--10670 10057 -10680 10060 -10700 10064 -10700 10067 -10720 10068 -10720 10071
--10740 10074 -10740 10076 -10760 10077 -10770 10080 -10780 10080 -10790 10082
--10800 10082 -10810 10082 -10810 10082 -10830 10082 -10830 10081 -10830 10081
--10840 10078 -10840 10078 -10850 10079 -10850 10076 -10860 10075 -10860 10075
--10850 10073 -10870 10072 -10860 10074 -10860 10075 -10870 10073 -10870 10073
--10870 10075 -10870 10076 -10870 10078 -10880 10079 -10870 10082 -10870 10086
--10870 10092 -10880 10095 -10890 10098 -10890 10105 -10890 10111 -10900 10117
--10910 10124 -10920 10131 -10930 10136 -10930 10143 -10940 10152 -10960 10160
--10960 10168 -10980 10177 -10990 10184 -11000 10189 -11010 10195 -11030 10205
--11050 10210 -11050 10215 -11060 10221 -11080 10226 -11090 10230 -11100 10233
--11110 10235 -11110 10236 -11130 10238 -11130 10238 -11130 10237 -11140 10237
--11140 10234 -11140 10230 -11140 10223 -11140 10220 -11140 10215 -11120 10207
--11120 10201 -11100 10193 -11100 10187 -11070 10180 -11060 10168 -11050 10160
--11020 10151 -11000 10140 -10980 10131 -10950 10123 -10930 10111 -10900 10102
--10870 10093 -10840 10084 -10830 10075 -10780 10067 -10750 10059 -10730 10052
--10690 10043 -10670 10038 -10640 10030 -10620 10026 -10590 10020 -10550 10016
--10540 10012 -10510 10010 -10500 10006 -10470 10006 -10470 10003 -10450 10003
--10430 10000 -10420 10003 -10430 10004 -10420 10003 -10420 10003 -10430 10006
--10430 10008 -10440 10011 -10470 10010 -10470 10011 -10480 10014 -10510 10015
--10540 10019 -10560 10019 -10590 10020 -10620 10021 -10660 10023 -10690 10023
--10740 10024 -10770 10023 -10810 10023 -10840 10024 -10890 10021 -10920 10021
--10970 10018 -11000 10017 -11020 10017 -11050 10014 -11090 10012 -11100 10009
--11140 10009 -11140 10005 -11160 10005 -11160 10005 -11150 10003 -11150 10003
--11150 10001 -11110 10001 -11080 10004 -11030 10006 -10980 10010 -10920 10013
--10850 10018 -10770 10023 -10670 10033 -10560 10043 -10450 10052 -10300 10067
--10160 10079 -10010 10094 -9840 10111 -9640 10131 -9460 10153 -9230 10176
--9020 10200 -8770 10226 -8530 10256 -8260 10285 -7980 10316 -7680 10353
--7370 10390 -7060 10427 -6730 10464 -6400 10505 -6040 10547 -5680 10591
--5300 10637 -4910 10682 -4530 10727 -4140 10772 -3730 10819 -3310 10868
--2900 10916 -2470 10963 -2050 11007 -1650 11050 -1200 11095 -770 11139
--340 11183 80 11222 500 11258 910 11289 1330 11323 1720 11352 2110 11380
-2490 11403 2860 11424 3210 11439 3540 11450 3880 11459 4190 11466 4480 11469
-4740 11470 5000 11468 5230 11461 5430 11452 5620 11443 5780 11431 5930 11421
-6030 11411 6130 11399 6190 11387 6230 11374 6250 11361 6250 11348 6210 11339
-6160 11329 6090 11321 5990 11311 5870 11297 5720 11285 5570 11272 5380 11258
-5180 11244 4970 11227 4730 11204 4470 11178 4200 11150 3900 11115 3600 11077
-3280 11034 2970 10990 2630 10939 2290 10882 1930 10821 1560 10755 1210 10685
-860 10615 490 10541 170 10463 -170 10380 -500 10298 -840 10213 -1150 10129
--1460 10042 -1770 9950 -2070 9855 -2370 9761 -2640 9667 -2910 9575 -3220 9488
--3510 9393 -3810 9301 -4100 9210 -4390 9123 -4680 9040 -4990 8964 -5280 8888
--5600 8820 -5900 8756 -6210 8700 -6520 8649 -6830 8605 -7140 8568 -7460 8537
--7770 8513 -8090 8495 -8410 8484 -8710 8482 -9030 8487 -9320 8499 -9620 8517
--9900 8541 -10190 8572 -10480 8609 -10740 8653 -11010 8704 -11280 8759
--11550 8817 -11800 8879 -12040 8947 -12300 9021 -12530 9098 -12760 9180
--12980 9259 -13200 9341 -13410 9429 -13610 9519 -13790 9614 -13980 9707
--14160 9798 -14310 9888 -14480 9977 -14610 10069 -14760 10156 -14890 10242
--15010 10325 -15140 10402 -15260 10472 -15370 10539 -15470 10600 -15580 10655
--15670 10706 -15780 10751 -15880 10789 -15990 10818 -16100 10841 -16190 10858
--16300 10875 -16420 10884 -16550 10887 -16670 10885 -16810 10878 -16950 10867
--17090 10851 -17220 10833 -17370 10811 -17510 10787 -17660 10758 -17830 10727
--17990 10694 -18160 10657 -18350 10618 -18520 10575 -18700 10531 -18890 10484
--19070 10433 -19260 10380 -19450 10323 -19650 10264 -19830 10202 -20010 10137
--20190 10069 -20350 9998 -20510 9925 -20660 9848 -20780 9770 -20920 9690
--21000 9605 -21110 9520 -21160 9432 -21200 9344 -21240 9253 -21240 9160
--21240 9065 -21190 8969 -21150 8872 -21060 8773 -20980 8674 -20860 8574
--20730 8473 -20600 8370 -20430 8268 -20260 8164 -20070 8062 -19870 7960
--19640 7858 -19430 7755 -19190 7656 -18940 7556 -18670 7459 -18380 7364
--18100 7271 -17810 7182 -17540 7098 -17240 7017 -16930 6941 -16560 6867
--16190 6798 -15820 6734 -15450 6676 -15090 6625 -14710 6579 -14350 6542
--13990 6509 -13610 6485 -13240 6466 -12870 6452 -12510 6446 -12150 6445
--11800 6451 -11450 6463 -11110 6480 -10780 6502 -10470 6531 -10170 6562
--9870 6600 -9590 6642 -9330 6688 -9090 6737 -8860 6789 -8630 6845 -8450 6903
--8250 6964 -8080 7027 -7930 7091 -7770 7157 -7660 7224 -7550 7292 -7440 7361
--7360 7430 -7300 7499 -7230 7568 -7180 7637 -7130 7706 -7090 7774 -7070 7841
--7060 7907 -7040 7973 -7040 8037 -7040 8100 -7050 8161 -7060 8222 -7080 8281
--7100 8338 -7130 8394 -7150 8448 -7190 8500 -7220 8550 -7240 8600 -7280 8649
--7330 8696 -7370 8740 -7410 8781 -7450 8819 -7510 8858 -7540 8897 -7610 8939
--7650 8975 -7660 9007 -7680 9038 -7710 9069 -7740 9099 -7780 9127 -7800 9154
--7840 9179 -7870 9205 -7900 9229 -7930 9252 -7960 9273 -7980 9293 -8020 9313
--8040 9333 -8060 9351 -8090 9369 -8110 9385 -8140 9400 -8150 9416 -8170 9431
--8190 9445 -8210 9458 -8220 9471 -8250 9483 -8250 9495 -8280 9507 -8290 9517
--8300 9529 -8320 9538 -8330 9548 -8330 9557 -8360 9567 -8360 9576 -8380 9584
--8380 9592 -8390 9599 -8410 9608 -8410 9614 -8420 9622 -8430 9629 -8440 9636
--8450 9641 -8450 9649 -8460 9654 -8470 9660 -8470 9665 -8480 9671 -8490 9676
--8490 9682 -8500 9686 -8510 9691 -8510 9695 -8510 9700 -8520 9703 -8530 9708
-230: 15213440 -4446535 -10270 9939 -10280 9937 -10280 9940 -10280 9942
--10280 9944 -10300 9943 -10300 9944 -10300 9949 -10310 9948 -10310 9949
--10330 9950 -10320 9954 -10340 9955 -10340 9958 -10360 9958 -10360 9961
--10370 9961 -10390 9963 -10380 9964 -10400 9967 -10400 9966 -10410 9969
--10410 9973 -10420 9973 -10440 9976 -10450 9977 -10450 9977 -10450 9981
--10470 9982 -10470 9983 -10480 9985 -10490 9987 -10490 9988 -10500 9991
--10510 9995 -10520 9997 -10520 10000 -10530 10001 -10540 10004 -10540 10008
--10550 10010 -10550 10015 -10560 10017 -10580 10022 -10580 10025 -10590 10030
--10600 10033 -10610 10035 -10620 10039 -10620 10043 -10640 10047 -10650 10050
--10670 10053 -10670 10058 -10690 10063 -10690 10065 -10710 10066 -10720 10068
--10730 10072 -10730 10075 -10750 10076 -10760 10077 -10770 10076 -10780 10080
--10790 10081 -10800 10080 -10800 10079 -10800 10079 -10830 10080 -10820 10078
--10830 10078 -10830 10075 -10840 10075 -10840 10075 -10840 10073 -10840 10071
--10860 10072 -10850 10071 -10850 10071 -10850 10071 -10850 10071 -10860 10071
--10860 10071 -10860 10072 -10860 10075 -10860 10076 -10860 10077 -10860 10083
--10870 10086 -10860 10092 -10870 10095 -10880 10100 -10880 10105 -10880 10113
--10900 10118 -10900 10126 -10920 10131 -10920 10137 -10930 10146 -10940 10155
--10950 10162 -10960 10171 -10970 10177 -10980 10184 -11000 10188 -11000 10197
--11030 10204 -11030 10210 -11040 10214 -11060 10219 -11070 10224 -11080 10227
--11080 10230 -11100 10230 -11100 10232 -11110 10233 -11110 10233 -11110 10233
--11120 10229 -11120 10225 -11110 10222 -11120 10216 -11120 10213 -11100 10205
--11090 10198 -11070 10191 -11080 10186 -11050 10179 -11040 10170 -11020 10160
--11000 10152 -10990 10142 -10950 10131 -10940 10125 -10900 10114 -10880 10103
--10860 10096 -10820 10088 -10790 10079 -10770 10070 -10730 10062 -10710 10057
--10670 10046 -10650 10040 -10620 10034 -10600 10028 -10560 10023 -10540 10019
--10510 10015 -10500 10012 -10470 10009 -10460 10006 -10440 10005 -10420 10003
--10400 10000 -10400 10003 -10390 10002 -10400 10002 -10390 10001 -10390 10003
--10400 10005 -10410 10006 -10430 10005 -10430 10007 -10450 10008 -10480 10008
--10490 10010 -10520 10011 -10550 10012 -10580 10011 -10620 10013 -10650 10012
--10680 10011 -10730 10012 -10760 10010 -10810 10010 -10830 10007 -10880 10006
--10930 10003 -10950 10001 -10990 10000 -11010 9998 -11040 9996 -11070 9992
--11100 9990 -11120 9987 -11130 9986 -11130 9986 -11130 9984 -11140 9982
--11120 9981 -11110 9981 -11080 9983 -11040 9984 -10990 9988 -10940 9991
--10880 9994 -10800 10002 -10710 10008 -10610 10018 -10510 10027 -10370 10040
--10250 10053 -10090 10066 -9940 10084 -9760 10101 -9570 10122 -9380 10145
--9150 10167 -8940 10192 -8690 10220 -8450 10248 -8170 10278 -7900 10313
--7590 10348 -7300 10383 -6980 10420 -6660 10457 -6330 10498 -5970 10540
--5610 10583 -5240 10627 -4870 10669 -4490 10712 -4100 10757 -3700 10803
--3290 10850 -2880 10895 -2490 10937 -2080 10977 -1670 11021 -1240 11062
--820 11104 -420 11142 -10 11176 390 11208 790 11239 1180 11269 1560 11296
-1920 11318 2270 11338 2630 11357 2960 11368 3280 11378 3570 11386 3860 11391
-4120 11393 4380 11393 4600 11390 4810 11384 5000 11378 5160 11368 5300 11361
-5420 11352 5510 11344 5580 11333 5640 11324 5660 11311 5670 11301 5640 11293
-5610 11283 5540 11275 5450 11265 5350 11254 5210 11239 5080 11228 4890 11213
-4720 11198 4520 11180 4300 11158 4060 11132 3800 11104 3530 11069 3240 11030
-2950 10990 2660 10946 2330 10896 2010 10841 1680 10783 1320 10718 1000 10652
-660 10583 320 10512 10 10435 -320 10357 -650 10275 -950 10194 -1270 10111
--1570 10027 -1860 9938 -2170 9848 -2460 9755 -2720 9663 -2990 9576 -3280 9491
--3580 9401 -3870 9311 -4150 9224 -4450 9140 -4720 9061 -5020 8985 -5320 8914
--5630 8846 -5920 8786 -6210 8729 -6520 8680 -6830 8636 -7120 8599 -7430 8569
--7730 8544 -8040 8525 -8340 8514 -8650 8509 -8940 8512 -9220 8523 -9520 8538
--9800 8560 -10070 8586 -10350 8621 -10610 8661 -10870 8708 -11120 8759
--11380 8812 -11630 8871 -11870 8936 -12100 9004 -12330 9078 -12550 9153
--12760 9229 -12960 9307 -13170 9388 -13360 9475 -13540 9564 -13720 9652
--13880 9737 -14040 9823 -14190 9908 -14320 9994 -14450 10077 -14600 10159
--14700 10238 -14830 10311 -14940 10378 -15050 10443 -15150 10502 -15240 10556
--15350 10606 -15440 10650 -15540 10688 -15650 10718 -15750 10743 -15830 10762
--15940 10779 -16050 10792 -16180 10798 -16290 10797 -16430 10795 -16560 10785
--16690 10774 -16820 10759 -16950 10741 -17100 10719 -17250 10694 -17390 10668
--17560 10637 -17730 10604 -17890 10568 -18060 10529 -18240 10489 -18420 10445
--18580 10398 -18760 10348 -18960 10296 -19130 10240 -19300 10183 -19490 10123
--19650 10058 -19810 9991 -19950 9923 -20090 9851 -20220 9777 -20340 9701
--20430 9622 -20530 9541 -20580 9459 -20630 9374 -20660 9289 -20680 9200
--20670 9111 -20640 9019 -20600 8927 -20530 8833 -20450 8738 -20350 8644
--20220 8547 -20100 8449 -19960 8351 -19800 8253 -19620 8156 -19440 8058
--19230 7961 -19010 7864 -18800 7769 -18560 7674 -18310 7582 -18040 7491
--17760 7403 -17500 7318 -17240 7237 -16970 7161 -16670 7088 -16310 7018
--15960 6951 -15620 6890 -15270 6835 -14910 6784 -14570 6742 -14220 6703
--13870 6673 -13520 6648 -13170 6629 -12830 6615 -12480 6607 -12140 6605
--11800 6609 -11470 6619 -11150 6634 -10840 6653 -10540 6678 -10250 6708
--9970 6742 -9710 6780 -9450 6822 -9220 6867 -8990 6916 -8780 6967 -8590 7021
--8410 7078 -8240 7136 -8080 7197 -7950 7258 -7810 7321 -7710 7385 -7610 7450
--7520 7515 -7450 7580 -7380 7645 -7330 7711 -7290 7775 -7240 7840 -7210 7904
--7200 7966 -7180 8029 -7170 8090 -7170 8149 -7170 8209 -7180 8266 -7190 8322
--7220 8377 -7230 8430 -7250 8483 -7290 8532 -7310 8581 -7330 8628 -7360 8675
--7410 8720 -7440 8763 -7490 8802 -7520 8839 -7570 8876 -7610 8915 -7670 8954
--7700 8989 -7720 9020 -7730 9051 -7760 9081 -7780 9109 -7830 9137 -7840 9162
--7880 9188 -7900 9212 -7940 9235 -7960 9258 -7990 9279 -8020 9298 -8050 9318
--8060 9337 -8100 9355 -8110 9371 -8130 9388 -8160 9403 -8170 9418 -8200 9433
--8210 9446 -8230 9460 -8240 9472 -8260 9484 -8270 9496 -8290 9507 -8310 9518
--8320 9528 -8330 9538 -8350 9548 -8350 9557 -8360 9566 -8380 9575 -8390 9583
--8390 9591 -8410 9599 -8410 9606 -8430 9614 -8430 9621 -8440 9628 -8450 9634
--8460 9640 -8460 9647 -8470 9652 -8480 9659 -8480 9664 -8490 9669 -8500 9675
--8500 9679 -8500 9685 -8520 9689 -8520 9693 -8530 9698 -8530 9701 -8530 9706
-231: 15246970 -4438184 -10280 9939 -10270 9938 -10280 9938 -10290 9942
--10280 9943 -10290 9944 -10300 9945 -10300 9949 -10310 9947 -10320 9950
--10310 9950 -10330 9954 -10330 9954 -10350 9957 -10350 9959 -10360 9961
--10370 9962 -10380 9962 -10380 9965 -10400 9965 -10400 9965 -10400 9969
--10420 9973 -10410 9973 -10440 9974 -10440 9975 -10450 9978 -10450 9981
--10460 9981 -10470 9981 -10470 9985 -10490 9986 -10490 9989 -10500 9989
--10500 9995 -10510 9996 -10520 9997 -10520 10000 -10530 10003 -10540 10007
--10540 10008 -10560 10014 -10560 10017 -10570 10020 -10570 10025 -10580 10028
--10590 10031 -10610 10034 -10610 10037 -10620 10041 -10630 10046 -10650 10049
--10650 10051 -10670 10055 -10680 10061 -10690 10061 -10700 10066 -10700 10066
--10720 10070 -10730 10073 -10740 10074 -10750 10074 -10760 10076 -10770 10076
--10780 10078 -10790 10078 -10780 10078 -10800 10076 -10810 10077 -10810 10077
--10820 10076 -10820 10073 -10830 10073 -10830 10073 -10820 10070 -10840 10069
--10840 10069 -10840 10069 -10840 10069 -10840 10067 -10840 10070 -10840 10067
--10850 10068 -10850 10070 -10850 10071 -10840 10073 -10860 10075 -10850 10078
--10850 10082 -10850 10086 -10860 10091 -10850 10095 -10870 10100 -10880 10109
--10880 10115 -10890 10119 -10900 10125 -10910 10134 -10920 10140 -10920 10149
--10940 10155 -10940 10164 -10950 10171 -10970 10178 -10970 10182 -10990 10190
--11010 10198 -11000 10203 -11030 10209 -11040 10213 -11050 10218 -11050 10220
--11060 10224 -11080 10225 -11080 10226 -11090 10228 -11080 10229 -11090 10227
--11100 10224 -11090 10222 -11090 10219 -11100 10213 -11090 10208 -11080 10204
--11070 10196 -11050 10190 -11050 10185 -11040 10178 -11010 10169 -11000 10161
--10980 10152 -10960 10144 -10940 10134 -10910 10124 -10890 10116 -10860 10107
--10830 10098 -10800 10090 -10770 10082 -10750 10073 -10720 10067 -10690 10058
--10650 10049 -10630 10043 -10600 10037 -10580 10032 -10540 10027 -10520 10021
--10490 10018 -10470 10015 -10460 10010 -10430 10008 -10420 10007 -10390 10005
--10380 10000 -10380 10001 -10360 10002 -10370 10000 -10360 10001 -10370 9999
--10370 10001 -10370 10003 -10390 10002 -10400 10003 -10410 10001 -10440 10002
--10450 10003 -10490 10004 -10510 10004 -10530 10003 -10580 10003 -10610 10003
--10640 10000 -10680 10000 -10720 9998 -10750 9997 -10800 9995 -10840 9992
--10870 9989 -10920 9987 -10940 9984 -10970 9982 -11010 9981 -11030 9977
--11060 9972 -11090 9970 -11100 9969 -11110 9968 -11110 9965 -11110 9964
--11110 9961 -11100 9962 -11080 9962 -11040 9965 -11000 9967 -10960 9970
--10900 9973 -10830 9978 -10750 9986 -10660 9993 -10560 10004 -10440 10015
--10320 10025 -10180 10041 -10030 10055 -9860 10073 -9690 10093 -9490 10113
--9300 10135 -9090 10160 -8860 10185 -8620 10211 -8360 10242 -8100 10272
--7810 10307 -7530 10341 -7230 10375 -6920 10411 -6600 10449 -6250 10490
--5910 10531 -5560 10571 -5200 10613 -4830 10653 -4470 10696 -4080 10739
--3680 10785 -3290 10828 -2900 10866 -2510 10906 -2110 10947 -1710 10987
--1300 11028 -900 11063 -520 11098 -100 11128 270 11159 640 11187 1010 11213
-1360 11236 1710 11256 2050 11273 2380 11287 2680 11298 2970 11307 3250 11314
-3520 11319 3750 11320 3990 11319 4200 11314 4380 11311 4550 11304 4690 11301
-4800 11293 4910 11286 4980 11279 5040 11270 5080 11261 5080 11251 5090 11243
-5040 11236 5000 11229 4910 11217 4830 11208 4700 11193 4580 11180 4420 11168
-4250 11151 4080 11132 3860 11112 3640 11086 3410 11056 3140 11022 2880 10985
-2620 10946 2330 10903 2020 10854 1720 10801 1420 10743 1090 10683 770 10618
-450 10551 130 10482 -170 10409 -480 10333 -790 10254 -1090 10174 -1400 10093
--1690 10012 -1970 9928 -2270 9840 -2560 9750 -2820 9662 -3070 9577 -3370 9493
--3650 9407 -3930 9322 -4220 9237 -4490 9156 -4780 9081 -5060 9008 -5360 8938
--5660 8873 -5940 8812 -6230 8758 -6520 8709 -6820 8667 -7100 8630 -7400 8599
--7700 8574 -7990 8555 -8290 8541 -8580 8536 -8850 8537 -9140 8545 -9430 8559
--9680 8577 -9960 8602 -10220 8632 -10480 8669 -10730 8713 -10980 8759
--11220 8810 -11450 8865 -11690 8923 -11910 8989 -12130 9057 -12340 9128
--12550 9200 -12740 9274 -12930 9350 -13120 9432 -13280 9516 -13460 9598
--13620 9680 -13770 9761 -13890 9841 -14040 9922 -14170 10003 -14300 10079
--14400 10154 -14510 10223 -14640 10289 -14730 10352 -14820 10407 -14920 10462
--15010 10510 -15110 10553 -15210 10591 -15310 10622 -15400 10648 -15480 10668
--15570 10688 -15700 10701 -15810 10710 -15920 10713 -16040 10712 -16180 10706
--16290 10698 -16420 10686 -16540 10671 -16690 10653 -16830 10631 -16980 10608
--17120 10581 -17290 10551 -17450 10519 -17610 10483 -17770 10447 -17940 10405
--18110 10363 -18280 10317 -18450 10268 -18630 10217 -18790 10163 -18970 10108
--19110 10046 -19270 9985 -19410 9920 -19550 9853 -19660 9783 -19770 9712
--19880 9638 -19950 9562 -20010 9483 -20070 9404 -20100 9323 -20120 9240
--20120 9155 -20090 9067 -20060 8980 -20000 8891 -19940 8802 -19830 8710
--19730 8619 -19610 8527 -19490 8433 -19340 8339 -19180 8247 -19000 8155
--18820 8062 -18610 7969 -18400 7879 -18190 7789 -17950 7702 -17690 7615
--17430 7531 -17190 7450 -16950 7373 -16690 7301 -16400 7231 -16070 7164
--15740 7100 -15410 7042 -15080 6989 -14740 6940 -14420 6898 -14080 6862
--13760 6831 -13420 6807 -13100 6787 -12780 6773 -12440 6764 -12120 6760
--11800 6764 -11480 6771 -11180 6783 -10890 6802 -10600 6823 -10320 6849
--10060 6880 -9810 6915 -9550 6954 -9340 6995 -9110 7040 -8920 7087 -8720 7138
--8550 7190 -8390 7245 -8230 7301 -8100 7359 -7980 7417 -7860 7477 -7760 7538
--7670 7599 -7600 7661 -7530 7722 -7480 7784 -7430 7845 -7390 7906 -7350 7966
--7330 8026 -7310 8085 -7300 8143 -7290 8200 -7300 8256 -7290 8310 -7310 8364
--7320 8417 -7340 8468 -7350 8517 -7370 8565 -7400 8611 -7420 8657 -7460 8702
--7480 8745 -7520 8786 -7550 8824 -7600 8860 -7630 8895 -7670 8932 -7740 8970
--7760 9004 -7770 9034 -7780 9064 -7800 9093 -7840 9120 -7860 9147 -7890 9172
--7920 9196 -7950 9220 -7970 9242 -8000 9265 -8020 9284 -8050 9304 -8070 9323
--8100 9341 -8120 9359 -8140 9375 -8150 9391 -8180 9406 -8200 9420 -8210 9435
--8230 9448 -8250 9461 -8270 9474 -8280 9485 -8290 9497 -8310 9507 -8320 9518
--8330 9529 -8350 9538 -8360 9548 -8370 9557 -8370 9566 -8390 9574 -8400 9583
--8410 9590 -8420 9598 -8430 9606 -8430 9613 -8450 9619 -8450 9626 -8460 9633
--8470 9640 -8470 9645 -8480 9651 -8490 9657 -8490 9662 -8500 9668 -8510 9673
--8510 9678 -8520 9683 -8520 9687 -8530 9692 -8530 9696 -8540 9699 -8540 9704
-232: 15280500 -4429836 -10270 9937 -10280 9940 -10280 9939 -10280 9942
--10290 9941 -10290 9944 -10290 9945 -10300 9948 -10310 9947 -10320 9951
--10310 9951 -10330 9953 -10330 9954 -10330 9956 -10360 9958 -10360 9961
--10360 9962 -10370 9961 -10390 9965 -10390 9966 -10400 9964 -10410 9968
--10410 9971 -10420 9973 -10420 9974 -10430 9975 -10450 9977 -10450 9981
--10460 9980 -10460 9981 -10470 9983 -10490 9986 -10490 9989 -10480 9990
--10500 9992 -10510 9995 -10510 9996 -10520 10000 -10520 10002 -10530 10005
--10540 10008 -10550 10012 -10560 10016 -10560 10019 -10570 10022 -10580 10026
--10590 10029 -10590 10033 -10610 10036 -10620 10039 -10620 10043 -10640 10048
--10650 10050 -10660 10054 -10660 10056 -10680 10060 -10690 10063 -10700 10065
--10710 10069 -10720 10070 -10730 10071 -10740 10073 -10750 10074 -10770 10075
--10760 10073 -10780 10076 -10780 10076 -10780 10075 -10800 10075 -10800 10074
--10810 10073 -10800 10072 -10820 10071 -10810 10070 -10830 10069 -10820 10067
--10830 10065 -10830 10067 -10830 10066 -10830 10066 -10830 10067 -10830 10064
--10830 10066 -10830 10067 -10840 10068 -10840 10069 -10840 10071 -10840 10076
--10840 10079 -10830 10082 -10850 10086 -10850 10090 -10850 10095 -10870 10103
--10870 10109 -10870 10115 -10880 10121 -10890 10128 -10910 10135 -10910 10141
--10920 10150 -10930 10157 -10940 10166 -10940 10171 -10960 10177 -10970 10185
--10980 10190 -11000 10197 -11000 10202 -11020 10207 -11020 10211 -11040 10214
--11040 10218 -11060 10220 -11060 10222 -11050 10223 -11070 10223 -11070 10220
--11070 10220 -11070 10218 -11070 10215 -11070 10211 -11070 10205 -11050 10201
--11060 10195 -11030 10188 -11020 10184 -11000 10177 -11010 10168 -10970 10161
--10960 10153 -10940 10144 -10920 10135 -10890 10127 -10870 10117 -10840 10109
--10810 10101 -10790 10092 -10750 10085 -10730 10076 -10700 10069 -10670 10061
--10640 10053 -10610 10046 -10580 10041 -10550 10034 -10520 10030 -10500 10024
--10470 10020 -10450 10016 -10430 10013 -10410 10011 -10400 10008 -10370 10005
--10360 10003 -10360 10001 -10330 10001 -10340 9999 -10340 9999 -10330 9997
--10340 10000 -10350 9998 -10350 10000 -10370 9997 -10380 9997 -10390 9997
--10420 9997 -10460 9997 -10470 9996 -10490 9995 -10530 9995 -10560 9993
--10610 9991 -10640 9989 -10670 9987 -10710 9986 -10750 9983 -10800 9981
--10820 9976 -10870 9973 -10910 9970 -10930 9968 -10960 9965 -10990 9962
--11030 9958 -11060 9955 -11070 9953 -11080 9950 -11090 9947 -11090 9946
--11100 9945 -11080 9943 -11080 9943 -11030 9947 -11010 9946 -10970 9950
--10920 9952 -10850 9957 -10790 9964 -10700 9971 -10600 9981 -10500 9991
--10390 10000 -10260 10014 -10120 10030 -9960 10045 -9790 10065 -9610 10082
--9430 10104 -9230 10127 -9020 10151 -8800 10177 -8540 10204 -8280 10236
--8030 10266 -7740 10298 -7470 10332 -7170 10366 -6860 10401 -6530 10440
--6200 10479 -5860 10518 -5520 10557 -5180 10596 -4820 10636 -4440 10678
--4050 10719 -3690 10762 -3310 10800 -2940 10836 -2550 10874 -2150 10914
--1770 10952 -1380 10988 -1000 11019 -610 11050 -250 11079 120 11107 470 11133
-820 11156 1150 11176 1480 11193 1810 11206 2100 11220 2390 11229 2650 11237
-2910 11244 3150 11248 3380 11248 3590 11246 3780 11244 3940 11241 4090 11238
-4190 11233 4310 11229 4390 11222 4460 11215 4500 11207 4510 11201 4520 11192
-4490 11187 4440 11179 4390 11170 4310 11158 4200 11147 4080 11132 3940 11119
-3800 11104 3610 11086 3430 11063 3230 11039 3000 11009 2750 10976 2520 10941
-2260 10901 2000 10859 1720 10813 1430 10761 1140 10706 840 10646 540 10585
-230 10520 -60 10453 -360 10382 -660 10309 -950 10232 -1250 10155 -1530 10077
--1820 9998 -2100 9917 -2370 9832 -2670 9746 -2920 9659 -3170 9577 -3450 9497
--3730 9414 -4010 9332 -4290 9249 -4550 9173 -4840 9099 -5110 9029 -5410 8962
--5670 8898 -5970 8839 -6240 8786 -6530 8737 -6810 8696 -7100 8659 -7380 8629
--7670 8603 -7950 8584 -8230 8569 -8510 8562 -8780 8561 -9060 8567 -9330 8579
--9580 8595 -9840 8616 -10100 8644 -10350 8678 -10590 8717 -10840 8761
--11060 8807 -11290 8858 -11510 8913 -11720 8974 -11930 9038 -12150 9105
--12330 9173 -12520 9241 -12700 9314 -12880 9391 -13040 9469 -13200 9548
--13360 9626 -13490 9701 -13630 9776 -13760 9855 -13880 9930 -14000 10003
--14100 10074 -14210 10141 -14330 10204 -14410 10263 -14510 10318 -14600 10371
--14690 10417 -14780 10461 -14880 10498 -14970 10530 -15050 10555 -15140 10579
--15220 10598 -15330 10615 -15450 10624 -15550 10630 -15670 10632 -15790 10629
--15910 10623 -16020 10614 -16150 10602 -16280 10588 -16420 10569 -16560 10549
--16700 10525 -16850 10499 -17010 10469 -17150 10438 -17320 10404 -17480 10367
--17630 10328 -17800 10286 -17960 10240 -18130 10193 -18300 10144 -18440 10091
--18600 10035 -18740 9978 -18870 9916 -19000 9854 -19120 9790 -19230 9722
--19300 9652 -19400 9581 -19470 9507 -19520 9432 -19550 9356 -19580 9277
--19570 9197 -19570 9115 -19520 9031 -19480 8947 -19420 8862 -19340 8777
--19240 8689 -19130 8601 -19020 8512 -18880 8424 -18740 8336 -18580 8248
--18400 8160 -18210 8072 -18020 7986 -17810 7901 -17590 7818 -17350 7735
--17110 7656 -16880 7578 -16650 7505 -16410 7436 -16140 7370 -15820 7306
--15510 7245 -15210 7189 -14890 7138 -14570 7092 -14260 7050 -13960 7015
--13630 6985 -13330 6960 -13020 6941 -12710 6926 -12400 6917 -12090 6912
--11780 6913 -11490 6919 -11200 6930 -10930 6945 -10640 6964 -10390 6988
--10140 7015 -9890 7048 -9660 7082 -9430 7121 -9230 7161 -9040 7206 -8860 7252
--8680 7301 -8510 7351 -8380 7404 -8240 7458 -8120 7512 -8010 7569 -7900 7625
--7820 7683 -7740 7740 -7680 7799 -7620 7856 -7570 7915 -7520 7972 -7480 8028
--7460 8086 -7440 8141 -7430 8196 -7410 8251 -7420 8304 -7410 8355 -7410 8407
--7420 8456 -7450 8506 -7440 8552 -7470 8598 -7480 8643 -7510 8686 -7540 8729
--7570 8771 -7590 8809 -7630 8847 -7660 8880 -7700 8915 -7730 8950 -7800 8987
--7820 9020 -7820 9048 -7840 9077 -7850 9105 -7880 9132 -7910 9157 -7940 9182
--7950 9205 -7990 9228 -8010 9250 -8030 9272 -8060 9290 -8080 9310 -8100 9328
--8130 9346 -8140 9363 -8170 9379 -8180 9394 -8200 9409 -8220 9423 -8240 9437
--8250 9450 -8270 9463 -8280 9475 -8300 9487 -8310 9497 -8330 9509 -8340 9519
--8350 9529 -8360 9539 -8370 9547 -8380 9557 -8400 9566 -8400 9574 -8420 9582
--8420 9590 -8430 9597 -8440 9605 -8440 9612 -8450 9619 -8470 9625 -8470 9632
--8470 9638 -8490 9644 -8490 9650 -8500 9655 -8500 9661 -8510 9667 -8520 9671
--8520 9676 -8530 9681 -8530 9686 -8530 9690 -8550 9694 -8540 9698 -8550 9702
-233: 15314040 -4421492 -10270 9938 -10270 9937 -10280 9941 -10280 9943
--10290 9942 -10290 9945 -10300 9943 -10290 9945 -10310 9948 -10310 9949
--10310 9952 -10330 9953 -10320 9954 -10340 9956 -10350 9957 -10360 9959
--10360 9961 -10370 9963 -10380 9964 -10400 9967 -10390 9964 -10400 9966
--10410 9970 -10420 9974 -10420 9972 -10430 9976 -10440 9977 -10450 9980
--10450 9979 -10460 9981 -10470 9982 -10480 9986 -10480 9989 -10490 9989
--10490 9989 -10500 9994 -10500 9995 -10520 10000 -10510 10000 -10530 10003
--10540 10007 -10540 10012 -10550 10015 -10560 10017 -10570 10021 -10570 10023
--10590 10029 -10580 10031 -10600 10035 -10610 10039 -10620 10039 -10630 10045
--10640 10048 -10650 10052 -10660 10055 -10670 10057 -10680 10061 -10690 10064
--10700 10067 -10710 10067 -10720 10070 -10740 10071 -10740 10072 -10750 10072
--10760 10072 -10760 10072 -10770 10074 -10770 10074 -10790 10073 -10790 10071
--10800 10070 -10790 10070 -10800 10070 -10810 10068 -10810 10066 -10810 10065
--10810 10063 -10820 10064 -10820 10063 -10820 10064 -10820 10064 -10820 10064
--10820 10062 -10830 10063 -10820 10065 -10830 10067 -10820 10068 -10830 10072
--10830 10075 -10820 10079 -10840 10082 -10840 10086 -10840 10091 -10850 10098
--10860 10104 -10860 10109 -10870 10115 -10870 10122 -10890 10130 -10890 10136
--10910 10143 -10910 10152 -10920 10159 -10930 10166 -10950 10171 -10950 10178
--10960 10183 -10970 10191 -10990 10197 -11000 10200 -11000 10204 -11010 10208
--11030 10211 -11030 10215 -11030 10217 -11050 10217 -11040 10218 -11050 10214
--11040 10216 -11050 10213 -11050 10212 -11040 10207 -11050 10203 -11030 10199
--11030 10194 -11010 10185 -11000 10182 -10990 10176 -10970 10167 -10960 10160
--10940 10153 -10920 10144 -10890 10138 -10870 10128 -10850 10119 -10820 10111
--10800 10101 -10770 10095 -10730 10088 -10710 10078 -10680 10071 -10650 10064
--10630 10055 -10590 10050 -10560 10044 -10530 10039 -10510 10031 -10480 10026
--10450 10023 -10420 10017 -10420 10016 -10390 10013 -10370 10009 -10360 10007
--10340 10004 -10330 10002 -10310 10002 -10310 9999 -10310 9997 -10310 9996
--10310 9997 -10310 9996 -10320 9996 -10340 9994 -10340 9992 -10360 9992
--10390 9993 -10420 9991 -10430 9989 -10460 9988 -10490 9987 -10520 9984
--10560 9983 -10590 9979 -10630 9977 -10660 9976 -10710 9973 -10750 9969
--10790 9964 -10830 9961 -10860 9958 -10880 9955 -10920 9952 -10960 9947
--11000 9944 -11020 9940 -11030 9937 -11050 9936 -11060 9931 -11080 9929
--11080 9929 -11070 9926 -11060 9926 -11040 9928 -11000 9928 -10980 9930
--10920 9933 -10880 9937 -10820 9943 -10730 9950 -10650 9959 -10550 9967
--10450 9978 -10330 9989 -10200 10004 -10060 10018 -9890 10037 -9720 10054
--9560 10074 -9360 10095 -9170 10118 -8950 10143 -8710 10169 -8480 10199
--8220 10226 -7960 10258 -7680 10289 -7410 10321 -7110 10356 -6800 10392
--6490 10428 -6150 10466 -5840 10502 -5500 10540 -5150 10578 -4790 10617
--4440 10657 -4060 10697 -3710 10733 -3340 10768 -2980 10805 -2590 10843
--2220 10879 -1840 10912 -1490 10944 -1110 10973 -750 11001 -400 11028
--50 11054 280 11077 600 11096 930 11115 1230 11130 1530 11142 1820 11153
-2060 11162 2330 11170 2560 11175 2780 11178 3000 11178 3180 11177 3340 11177
-3490 11174 3610 11173 3710 11169 3810 11166 3880 11159 3920 11153 3950 11147
-3950 11140 3940 11136 3910 11129 3850 11121 3800 11109 3700 11097 3590 11085
-3460 11071 3320 11055 3180 11037 3000 11015 2810 10991 2580 10962 2370 10931
-2150 10896 1900 10856 1660 10817 1410 10771 1130 10722 860 10669 590 10610
-280 10551 20 10489 -290 10424 -550 10356 -840 10285 -1130 10211 -1410 10136
--1670 10062 -1960 9984 -2230 9906 -2500 9824 -2790 9741 -3030 9658 -3260 9577
--3540 9501 -3830 9421 -4090 9340 -4360 9263 -4620 9188 -4900 9117 -5170 9050
--5440 8984 -5710 8922 -5990 8865 -6260 8812 -6540 8766 -6810 8725 -7090 8688
--7360 8657 -7650 8631 -7910 8611 -8180 8596 -8450 8587 -8710 8586 -8980 8590
--9240 8598 -9480 8612 -9740 8631 -9980 8655 -10220 8686 -10460 8724 -10680 8761
--10910 8806 -11130 8852 -11340 8904 -11540 8961 -11750 9020 -11930 9084
--12130 9146 -12310 9211 -12480 9279 -12650 9351 -12790 9427 -12960 9500
--13100 9572 -13230 9645 -13360 9715 -13480 9789 -13600 9862 -13710 9931
--13810 9998 -13920 10062 -14010 10123 -14110 10179 -14200 10233 -14290 10283
--14370 10330 -14460 10371 -14540 10409 -14630 10441 -14720 10468 -14800 10491
--14880 10513 -14970 10530 -15090 10542 -15190 10549 -15300 10554 -15410 10553
--15520 10551 -15640 10544 -15770 10535 -15870 10523 -16010 10508 -16150 10491
--16280 10470 -16420 10446 -16570 10421 -16720 10393 -16870 10362 -17020 10329
--17170 10292 -17320 10254 -17480 10213 -17650 10169 -17790 10123 -17950 10075
--18080 10024 -18220 9969 -18350 9912 -18480 9855 -18570 9794 -18680 9731
--18770 9666 -18860 9598 -18940 9530 -18970 9459 -19020 9387 -19040 9313
--19050 9237 -19030 9160 -19010 9081 -18970 9001 -18910 8921 -18850 8840
--18770 8757 -18660 8673 -18560 8590 -18430 8505 -18310 8422 -18150 8338
--17990 8255 -17820 8172 -17630 8090 -17440 8009 -17240 7930 -17010 7853
--16790 7776 -16560 7702 -16360 7633 -16130 7567 -15880 7505 -15580 7444
--15280 7385 -14990 7331 -14700 7282 -14400 7238 -14110 7197 -13820 7163
--13520 7134 -13230 7110 -12920 7090 -12640 7075 -12350 7064 -12050 7059
--11770 7059 -11490 7063 -11210 7072 -10950 7085 -10690 7101 -10440 7123
--10210 7147 -9970 7177 -9740 7208 -9530 7244 -9330 7280 -9140 7322 -8980 7364
--8800 7409 -8640 7457 -8510 7505 -8380 7555 -8250 7606 -8140 7658 -8050 7712
--7950 7766 -7880 7819 -7820 7875 -7750 7928 -7710 7984 -7650 8037 -7610 8091
--7590 8145 -7560 8198 -7540 8249 -7530 8301 -7520 8352 -7520 8400 -7520 8450
--7530 8496 -7540 8544 -7540 8588 -7560 8631 -7580 8674 -7600 8716 -7620 8757
--7630 8797 -7680 8834 -7690 8869 -7730 8901 -7760 8935 -7790 8969 -7870 9004
--7880 9035 -7880 9064 -7890 9091 -7900 9118 -7930 9143 -7950 9168 -7980 9192
--8000 9214 -8020 9237 -8040 9258 -8070 9279 -8090 9297 -8120 9316 -8140 9333
--8150 9351 -8170 9367 -8190 9384 -8210 9398 -8220 9412 -8250 9426 -8260 9440
--8270 9452 -8290 9465 -8310 9477 -8310 9488 -8330 9499 -8340 9509 -8360 9520
--8370 9530 -8370 9539 -8390 9548 -8400 9557 -8410 9565 -8420 9574 -8420 9582
--8440 9589 -8440 9597 -8450 9604 -8460 9612 -8470 9617 -8470 9625 -8480 9631
--8490 9637 -8490 9643 -8500 9648 -8510 9655 -8520 9659 -8510 9665 -8530 9670
--8530 9675 -8540 9679 -8540 9684 -8540 9688 -8550 9693 -8560 9697 -8560 9700
-234: 15347600 -4413152 -10270 9937 -10270 9938 -10280 9940 -10280 9943
--10290 9943 -10290 9945 -10290 9943 -10300 9945 -10300 9949 -10310 9948
--10310 9951 -10330 9953 -10320 9954 -10340 9955 -10340 9958 -10350 9960
--10360 9960 -10380 9962 -10370 9964 -10390 9965 -10390 9965 -10400 9966
--10400 9969 -10420 9971 -10420 9973 -10420 9976 -10440 9976 -10450 9979
--10450 9979 -10460 9980 -10460 9981 -10470 9985 -10480 9988 -10480 9989
--10490 9988 -10500 9992 -10500 9995 -10500 9998 -10510 9999 -10530 10002
--10530 10007 -10540 10010 -10540 10013 -10560 10016 -10560 10018 -10570 10023
--10580 10026 -10580 10030 -10590 10034 -10610 10036 -10610 10039 -10620 10043
--10630 10045 -10640 10051 -10660 10053 -10660 10055 -10670 10058 -10680 10062
--10690 10064 -10700 10067 -10720 10068 -10720 10068 -10720 10069 -10750 10070
--10740 10071 -10750 10069 -10770 10071 -10760 10072 -10770 10071 -10780 10070
--10790 10068 -10780 10067 -10800 10067 -10800 10066 -10790 10064 -10800 10064
--10800 10062 -10800 10061 -10810 10061 -10810 10060 -10810 10061 -10810 10061
--10810 10060 -10810 10060 -10810 10063 -10820 10064 -10820 10066 -10810 10068
--10810 10072 -10820 10074 -10830 10078 -10820 10082 -10830 10088 -10840 10093
--10840 10098 -10850 10105 -10860 10110 -10860 10117 -10870 10124 -10870 10131
--10890 10138 -10900 10144 -10910 10153 -10910 10160 -10930 10164 -10930 10172
--10950 10176 -10950 10185 -10970 10190 -10980 10195 -10980 10198 -11000 10202
--11000 10205 -11000 10211 -11010 10211 -11030 10212 -11020 10211 -11020 10211
--11030 10210 -11020 10208 -11030 10207 -11020 10205 -11010 10200 -11020 10195
--11000 10191 -11000 10186 -10980 10179 -10960 10174 -10950 10166 -10940 10160
--10920 10151 -10890 10144 -10870 10138 -10860 10129 -10830 10121 -10800 10113
--10770 10104 -10750 10096 -10730 10089 -10690 10081 -10660 10074 -10630 10066
--10600 10058 -10580 10053 -10550 10048 -10520 10040 -10480 10034 -10460 10029
--10440 10025 -10410 10021 -10390 10018 -10370 10013 -10350 10012 -10340 10007
--10320 10005 -10310 10004 -10290 10001 -10280 10000 -10280 9996 -10290 9996
--10280 9995 -10290 9992 -10290 9994 -10300 9990 -10320 9990 -10330 9987
--10350 9988 -10380 9986 -10390 9983 -10420 9982 -10450 9980 -10480 9978
--10510 9973 -10560 9971 -10590 9969 -10610 9966 -10670 9963 -10700 9959
--10750 9954 -10780 9950 -10820 9946 -10840 9944 -10880 9939 -10920 9935
--10960 9929 -10980 9927 -11000 9923 -11020 9921 -11040 9918 -11050 9914
--11050 9913 -11070 9910 -11040 9910 -11020 9911 -11010 9912 -10970 9911
--10940 9915 -10900 9918 -10830 9922 -10760 9931 -10690 9937 -10600 9947
--10500 9954 -10390 9966 -10280 9979 -10140 9993 -9980 10009 -9840 10027
--9670 10044 -9490 10066 -9300 10087 -9100 10109 -8880 10135 -8650 10162
--8410 10189 -8160 10219 -7900 10247 -7640 10278 -7350 10311 -7050 10344
--6760 10380 -6450 10415 -6130 10450 -5810 10485 -5480 10521 -5130 10559
--4790 10597 -4440 10634 -4090 10668 -3740 10702 -3390 10737 -3020 10773
--2660 10807 -2300 10839 -1950 10870 -1600 10897 -1250 10924 -910 10953
--570 10977 -240 10999 70 11019 390 11039 670 11053 980 11066 1250 11078
-1500 11088 1740 11098 1990 11104 2210 11108 2390 11111 2590 11110 2750 11111
-2910 11112 3030 11112 3130 11109 3230 11107 3300 11103 3370 11097 3390 11093
-3390 11087 3390 11083 3380 11077 3330 11071 3290 11059 3190 11047 3100 11035
-2980 11023 2870 11006 2720 10988 2570 10968 2390 10942 2180 10916 1990 10884
-1760 10851 1560 10813 1320 10774 1070 10731 830 10682 580 10631 310 10576
-30 10517 -230 10459 -490 10395 -770 10330 -1030 10262 -1300 10190 -1580 10118
--1830 10046 -2110 9971 -2370 9896 -2640 9816 -2900 9736 -3150 9656 -3380 9578
--3640 9505 -3910 9427 -4180 9350 -4440 9276 -4690 9203 -4960 9134 -5230 9069
--5480 9006 -5760 8945 -6020 8890 -6280 8839 -6550 8793 -6820 8752 -7080 8717
--7350 8685 -7610 8659 -7880 8637 -8140 8622 -8390 8612 -8650 8609 -8900 8611
--9150 8617 -9400 8630 -9620 8646 -9870 8667 -10110 8696 -10320 8729 -10540 8764
--10760 8805 -10970 8847 -11170 8896 -11380 8948 -11560 9004 -11740 9063
--11930 9122 -12090 9182 -12270 9247 -12420 9316 -12560 9384 -12710 9453
--12850 9523 -12980 9591 -13100 9658 -13210 9728 -13320 9795 -13430 9863
--13530 9926 -13620 9987 -13710 10045 -13810 10099 -13900 10152 -13970 10200
--14060 10245 -14150 10286 -14220 10324 -14310 10356 -14390 10384 -14460 10407
--14540 10430 -14620 10449 -14740 10462 -14830 10472 -14940 10478 -15040 10480
--15140 10479 -15270 10476 -15370 10470 -15490 10460 -15610 10447 -15740 10433
--15870 10416 -16000 10396 -16140 10372 -16280 10348 -16430 10320 -16570 10291
--16720 10258 -16870 10222 -17010 10185 -17150 10145 -17310 10103 -17460 10058
--17570 10011 -17720 9960 -17840 9908 -17950 9854 -18050 9798 -18160 9739
--18250 9678 -18340 9615 -18400 9550 -18450 9485 -18490 9417 -18510 9347
--18530 9275 -18530 9203 -18500 9128 -18470 9053 -18420 8978 -18360 8900
--18290 8823 -18200 8743 -18110 8663 -18000 8585 -17880 8505 -17730 8425
--17590 8347 -17420 8268 -17260 8191 -17090 8114 -16880 8039 -16680 7965
--16460 7892 -16260 7823 -16070 7756 -15850 7695 -15610 7634 -15330 7577
--15050 7520 -14780 7469 -14510 7421 -14230 7378 -13950 7340 -13680 7307
--13390 7278 -13120 7254 -12850 7234 -12560 7219 -12290 7208 -12010 7201
--11740 7200 -11480 7203 -11220 7209 -10970 7221 -10720 7235 -10480 7254
--10270 7276 -10030 7302 -9820 7331 -9610 7363 -9430 7398 -9250 7434 -9070 7474
--8910 7516 -8760 7559 -8630 7604 -8490 7651 -8390 7698 -8270 7748 -8180 7796
--8090 7848 -8010 7898 -7940 7949 -7880 8000 -7840 8052 -7780 8102 -7730 8154
--7710 8203 -7670 8254 -7660 8303 -7640 8351 -7630 8399 -7620 8446 -7630 8492
--7630 8537 -7630 8582 -7640 8624 -7650 8665 -7660 8706 -7680 8745 -7700 8785
--7720 8823 -7740 8859 -7770 8892 -7790 8923 -7830 8955 -7850 8988 -7930 9022
--7940 9051 -7940 9079 -7940 9105 -7950 9131 -7970 9156 -8000 9179 -8020 9202
--8040 9224 -8060 9246 -8090 9266 -8100 9286 -8130 9305 -8140 9322 -8170 9339
--8180 9356 -8200 9372 -8220 9388 -8230 9402 -8260 9416 -8260 9429 -8280 9442
--8300 9456 -8310 9467 -8330 9478 -8330 9490 -8350 9500 -8360 9511 -8370 9521
--8380 9530 -8390 9540 -8410 9548 -8410 9558 -8420 9565 -8440 9574 -8440 9582
--8450 9589 -8450 9597 -8460 9603 -8480 9610 -8470 9618 -8490 9623 -8490 9630
--8500 9636 -8500 9642 -8520 9648 -8510 9653 -8520 9658 -8530 9664 -8540 9668
--8540 9673 -8550 9679 -8550 9682 -8560 9687 -8550 9691 -8570 9695 -8570 9698
-235: 15381170 -4404815 -10270 9937 -10270 9939 -10280 9940 -10280 9942
--10280 9943 -10290 9944 -10290 9944 -10300 9945 -10300 9949 -10310 9948
--10310 9951 -10320 9951 -10320 9954 -10340 9957 -10340 9957 -10350 9959
--10360 9961 -10370 9960 -10370 9962 -10380 9965 -10390 9966 -10400 9967
--10400 9967 -10410 9970 -10420 9972 -10420 9976 -10430 9975 -10440 9978
--10450 9979 -10450 9980 -10460 9981 -10470 9985 -10470 9986 -10490 9988
--10480 9987 -10490 9991 -10490 9994 -10510 9996 -10510 9998 -10520 10002
--10520 10005 -10530 10009 -10540 10010 -10550 10014 -10560 10018 -10560 10022
--10570 10023 -10580 10029 -10580 10032 -10600 10033 -10600 10038 -10620 10041
--10620 10044 -10640 10048 -10640 10051 -10660 10055 -10650 10057 -10680 10057
--10680 10062 -10700 10064 -10700 10067 -10710 10066 -10720 10066 -10730 10069
--10730 10068 -10740 10068 -10750 10069 -10760 10069 -10770 10069 -10760 10068
--10770 10066 -10780 10065 -10780 10064 -10790 10063 -10780 10064 -10790 10061
--10790 10060 -10790 10059 -10800 10059 -10800 10057 -10800 10058 -10790 10058
--10800 10057 -10800 10059 -10800 10060 -10810 10060 -10800 10063 -10810 10065
--10800 10069 -10810 10070 -10810 10074 -10810 10078 -10820 10084 -10820 10090
--10840 10093 -10830 10100 -10840 10107 -10850 10110 -10850 10119 -10860 10125
--10880 10133 -10880 10138 -10890 10147 -10900 10152 -10910 10159 -10920 10165
--10920 10172 -10940 10179 -10950 10183 -10960 10188 -10960 10192 -10970 10195
--10980 10201 -10990 10204 -10990 10204 -11000 10206 -11000 10205 -11000 10207
--11000 10205 -11000 10203 -11010 10204 -11000 10201 -11000 10196 -10980 10193
--10990 10187 -10970 10184 -10950 10179 -10940 10171 -10930 10166 -10920 10158
--10900 10152 -10870 10144 -10850 10137 -10840 10130 -10800 10122 -10790 10114
--10760 10105 -10730 10097 -10700 10091 -10670 10084 -10650 10076 -10620 10069
--10590 10061 -10560 10055 -10530 10051 -10500 10041 -10470 10037 -10440 10032
--10420 10028 -10390 10024 -10370 10018 -10360 10017 -10340 10013 -10310 10009
--10300 10006 -10290 10004 -10270 10001 -10260 9999 -10250 9997 -10260 9994
--10260 9994 -10260 9992 -10260 9990 -10280 9988 -10280 9987 -10290 9984
--10320 9983 -10340 9982 -10370 9978 -10380 9976 -10410 9974 -10440 9972
--10470 9967 -10520 9963 -10540 9960 -10580 9959 -10610 9953 -10660 9950
--10710 9944 -10740 9941 -10770 9936 -10810 9932 -10840 9928 -10880 9923
--10910 9918 -10940 9915 -10970 9910 -10990 9907 -11000 9904 -11030 9900
--11030 9898 -11040 9896 -11030 9895 -11010 9895 -11000 9896 -10970 9896
--10950 9897 -10900 9900 -10850 9904 -10790 9912 -10720 9917 -10640 9925
--10550 9933 -10450 9944 -10340 9956 -10210 9969 -10080 9983 -9940 9999
--9770 10017 -9610 10037 -9430 10056 -9240 10077 -9030 10102 -8820 10127
--8590 10153 -8350 10180 -8100 10207 -7860 10237 -7580 10266 -7310 10299
--7010 10334 -6720 10365 -6420 10397 -6120 10432 -5790 10466 -5460 10502
--5130 10538 -4800 10572 -4470 10606 -4120 10638 -3800 10671 -3440 10705
--3080 10738 -2740 10769 -2400 10797 -2080 10825 -1720 10851 -1400 10877
--1080 10902 -750 10924 -450 10944 -150 10963 150 10979 430 10992 690 11004
-940 11016 1180 11026 1420 11034 1640 11037 1820 11043 2020 11045 2170 11048
-2330 11049 2460 11049 2560 11049 2670 11047 2740 11046 2800 11042 2840 11037
-2840 11033 2860 11031 2850 11024 2820 11018 2770 11009 2690 10997 2610 10985
-2510 10973 2400 10957 2280 10939 2130 10919 1970 10895 1780 10869 1600 10838
-1400 10806 1190 10771 980 10731 750 10690 520 10643 290 10594 30 10541
--230 10485 -470 10429 -730 10367 -980 10304 -1240 10238 -1490 10170 -1750 10099
--2010 10031 -2250 9958 -2520 9885 -2780 9809 -3030 9731 -3280 9654 -3490 9581
--3750 9508 -4020 9434 -4260 9361 -4510 9287 -4780 9218 -5030 9151 -5280 9087
--5540 9027 -5800 8968 -6060 8915 -6300 8864 -6560 8819 -6830 8779 -7080 8743
--7330 8713 -7590 8685 -7850 8664 -8100 8647 -8340 8638 -8590 8632 -8830 8632
--9070 8636 -9300 8648 -9530 8660 -9770 8679 -9980 8706 -10190 8735 -10410 8768
--10610 8804 -10820 8844 -11000 8888 -11200 8937 -11390 8989 -11550 9044
--11740 9100 -11890 9156 -12060 9216 -12200 9281 -12330 9345 -12480 9410
--12600 9476 -12730 9540 -12840 9604 -12950 9669 -13060 9734 -13160 9797
--13250 9858 -13340 9916 -13420 9971 -13510 10024 -13590 10073 -13680 10121
--13750 10165 -13830 10205 -13920 10243 -14000 10274 -14050 10303 -14140 10326
--14200 10350 -14290 10371 -14400 10386 -14490 10397 -14580 10405 -14670 10408
--14790 10411 -14890 10409 -14990 10406 -15110 10398 -15210 10389 -15350 10377
--15460 10361 -15590 10346 -15710 10325 -15870 10303 -16000 10280 -16130 10252
--16280 10223 -16410 10192 -16540 10157 -16690 10121 -16830 10082 -16970 10040
--17090 9997 -17210 9951 -17340 9903 -17450 9852 -17560 9800 -17640 9746
--17740 9689 -17820 9630 -17880 9570 -17930 9508 -17980 9445 -18000 9379
--18030 9312 -18030 9244 -18010 9173 -17980 9103 -17940 9031 -17880 8959
--17830 8885 -17750 8811 -17660 8735 -17570 8660 -17450 8585 -17330 8510
--17190 8435 -17050 8361 -16890 8287 -16720 8215 -16540 8144 -16340 8073
--16150 8005 -15960 7939 -15770 7876 -15580 7816 -15340 7760 -15090 7704
--14820 7651 -14570 7601 -14310 7555 -14050 7515 -13800 7477 -13530 7445
--13280 7417 -13010 7394 -12740 7373 -12490 7358 -12220 7347 -11960 7339
--11720 7336 -11470 7338 -11210 7343 -10980 7352 -10740 7365 -10520 7382
--10310 7401 -10090 7424 -9890 7451 -9680 7479 -9510 7511 -9340 7545 -9170 7581
--9010 7620 -8870 7660 -8740 7701 -8610 7745 -8500 7789 -8400 7834 -8300 7881
--8210 7928 -8140 7975 -8060 8023 -8000 8071 -7950 8119 -7910 8167 -7850 8215
--7820 8262 -7790 8309 -7760 8356 -7750 8402 -7730 8447 -7730 8491 -7730 8534
--7720 8578 -7730 8619 -7730 8660 -7740 8700 -7740 8737 -7770 8776 -7770 8813
--7800 8849 -7820 8884 -7830 8915 -7870 8946 -7890 8975 -7910 9007 -7990 9040
--8000 9068 -7990 9094 -7990 9120 -8000 9144 -8020 9168 -8040 9191 -8060 9213
--8080 9234 -8100 9255 -8130 9275 -8140 9294 -8150 9311 -8180 9329 -8200 9345
--8210 9362 -8230 9377 -8250 9393 -8260 9406 -8270 9419 -8290 9433 -8310 9446
--8320 9458 -8330 9469 -8350 9481 -8350 9492 -8360 9501 -8380 9513 -8390 9522
--8400 9531 -8410 9540 -8420 9549 -8430 9558 -8440 9566 -8440 9574 -8460 9581
--8460 9590 -8470 9596 -8480 9603 -8480 9610 -8490 9617 -8500 9623 -8500 9629
--8510 9635 -8510 9641 -8520 9647 -8530 9651 -8530 9657 -8550 9662 -8540 9668
--8550 9672 -8560 9677 -8560 9681 -8560 9685 -8570 9689 -8570 9694 -8570 9696
-236: 15414750 -4396481 -10270 9937 -10270 9941 -10280 9939 -10280 9940
--10280 9942 -10290 9945 -10290 9944 -10290 9946 -10300 9948 -10300 9949
--10310 9951 -10320 9951 -10320 9953 -10340 9957 -10330 9957 -10350 9958
--10360 9959 -10360 9960 -10370 9963 -10380 9964 -10380 9966 -10390 9965
--10410 9969 -10400 9968 -10420 9971 -10420 9975 -10430 9976 -10430 9976
--10440 9979 -10450 9979 -10460 9981 -10460 9985 -10470 9984 -10480 9986
--10480 9987 -10480 9989 -10500 9993 -10500 9995 -10500 9998 -10520 10001
--10520 10003 -10520 10007 -10530 10010 -10540 10012 -10550 10015 -10560 10020
--10570 10022 -10570 10028 -10580 10028 -10590 10032 -10590 10037 -10610 10040
--10610 10042 -10630 10046 -10640 10049 -10650 10054 -10650 10054 -10670 10056
--10670 10059 -10680 10062 -10690 10063 -10710 10064 -10710 10066 -10710 10065
--10730 10065 -10730 10066 -10740 10067 -10750 10067 -10750 10066 -10750 10065
--10760 10066 -10770 10063 -10770 10061 -10770 10061 -10780 10061 -10780 10060
--10780 10058 -10780 10058 -10780 10056 -10790 10055 -10790 10056 -10780 10055
--10790 10054 -10790 10057 -10790 10057 -10790 10058 -10800 10060 -10790 10061
--10800 10065 -10790 10067 -10790 10070 -10800 10075 -10810 10079 -10820 10086
--10820 10089 -10820 10097 -10830 10100 -10830 10106 -10840 10114 -10850 10121
--10850 10127 -10870 10132 -10870 10140 -10890 10145 -10890 10152 -10900 10160
--10910 10166 -10920 10173 -10930 10177 -10940 10181 -10940 10186 -10950 10190
--10960 10195 -10960 10197 -10980 10198 -10970 10200 -10970 10200 -10980 10202
--10980 10201 -10980 10199 -10990 10198 -10980 10196 -10970 10193 -10960 10190
--10960 10185 -10950 10182 -10940 10176 -10920 10170 -10910 10166 -10890 10157
--10880 10150 -10860 10143 -10830 10136 -10810 10130 -10780 10122 -10770 10115
--10750 10107 -10710 10098 -10680 10092 -10660 10086 -10630 10080 -10610 10070
--10570 10064 -10550 10058 -10510 10054 -10480 10043 -10460 10038 -10430 10035
--10390 10030 -10380 10026 -10360 10022 -10340 10018 -10310 10013 -10300 10012
--10280 10007 -10260 10004 -10260 10003 -10240 9998 -10230 9996 -10230 9995
--10230 9993 -10240 9990 -10230 9989 -10250 9986 -10260 9983 -10260 9982
--10290 9979 -10300 9977 -10320 9974 -10350 9973 -10380 9969 -10400 9965
--10430 9961 -10470 9957 -10510 9954 -10540 9950 -10570 9946 -10620 9941
--10660 9936 -10690 9932 -10730 9927 -10770 9922 -10790 9917 -10840 9913
--10870 9907 -10900 9904 -10940 9898 -10950 9896 -10970 9891 -10990 9887
--11010 9885 -11020 9882 -11010 9882 -10990 9880 -10990 9879 -10970 9882
--10950 9882 -10900 9883 -10860 9887 -10810 9893 -10740 9899 -10680 9905
--10600 9913 -10500 9923 -10400 9934 -10280 9946 -10160 9959 -10020 9973
--9870 9990 -9720 10008 -9550 10027 -9380 10047 -9180 10070 -8970 10093
--8760 10118 -8530 10143 -8300 10169 -8060 10195 -7810 10224 -7530 10256
--7260 10287 -6990 10318 -6690 10347 -6410 10380 -6100 10412 -5780 10447
--5470 10480 -5140 10514 -4830 10545 -4500 10575 -4180 10607 -3840 10639
--3500 10671 -3170 10700 -2840 10728 -2520 10754 -2190 10781 -1880 10806
--1560 10829 -1260 10850 -950 10871 -660 10889 -380 10905 -100 10920 150 10933
-390 10945 640 10955 860 10963 1080 10970 1270 10976 1450 10980 1610 10983
-1750 10986 1910 10987 2010 10989 2110 10988 2180 10988 2250 10985 2290 10982
-2320 10979 2320 10976 2320 10972 2300 10965 2270 10956 2210 10947 2120 10935
-2050 10922 1930 10907 1830 10890 1700 10871 1560 10848 1380 10821 1210 10794
-1020 10761 840 10727 640 10689 420 10650 200 10605 -20 10558 -250 10505
--480 10453 -730 10399 -970 10340 -1200 10279 -1450 10215 -1680 10149 -1950 10082
--2180 10015 -2420 9945 -2670 9875 -2930 9802 -3170 9727 -3400 9653 -3620 9581
--3860 9512 -4120 9441 -4360 9370 -4600 9299 -4860 9233 -5090 9168 -5340 9106
--5590 9047 -5850 8990 -6090 8938 -6340 8888 -6590 8845 -6830 8805 -7070 8770
--7320 8739 -7580 8711 -7820 8689 -8070 8673 -8290 8661 -8530 8656 -8770 8653
--8980 8657 -9230 8663 -9440 8676 -9650 8692 -9870 8714 -10070 8742 -10280 8772
--10470 8805 -10670 8842 -10860 8882 -11020 8928 -11210 8976 -11380 9026
--11550 9079 -11690 9131 -11850 9188 -11990 9249 -12110 9309 -12240 9370
--12370 9431 -12480 9492 -12600 9553 -12690 9614 -12810 9675 -12890 9735
--12980 9793 -13060 9848 -13150 9901 -13230 9952 -13300 10000 -13380 10046
--13470 10088 -13520 10129 -13600 10164 -13690 10196 -13750 10224 -13810 10251
--13880 10274 -13960 10295 -14060 10313 -14140 10324 -14240 10334 -14330 10340
--14430 10344 -14520 10344 -14630 10343 -14730 10338 -14840 10332 -14950 10321
--15070 10309 -15190 10296 -15310 10278 -15450 10260 -15580 10238 -15710 10215
--15830 10188 -15960 10161 -16100 10129 -16230 10096 -16360 10060 -16500 10023
--16610 9984 -16740 9941 -16850 9896 -16960 9850 -17070 9802 -17150 9751
--17240 9698 -17310 9644 -17380 9587 -17440 9530 -17470 9471 -17510 9409
--17530 9347 -17540 9282 -17520 9217 -17510 9150 -17460 9083 -17430 9014
--17380 8945 -17310 8875 -17220 8803 -17140 8733 -17040 8662 -16930 8591
--16800 8521 -16670 8449 -16520 8381 -16360 8312 -16190 8244 -16030 8178
--15830 8113 -15660 8050 -15490 7991 -15290 7934 -15090 7880 -14850 7827
--14590 7776 -14360 7728 -14120 7685 -13870 7645 -13630 7610 -13390 7578
--13140 7552 -12900 7527 -12650 7509 -12410 7492 -12150 7480 -11920 7472
--11680 7468 -11440 7469 -11200 7473 -10980 7480 -10760 7490 -10550 7505
--10340 7522 -10140 7543 -9950 7567 -9760 7593 -9580 7622 -9420 7652 -9260 7686
--9100 7721 -8970 7758 -8840 7797 -8710 7837 -8610 7877 -8510 7920 -8420 7963
--8330 8007 -8250 8051 -8180 8096 -8110 8141 -8070 8185 -8010 8231 -7970 8276
--7920 8320 -7900 8364 -7870 8409 -7850 8451 -7840 8494 -7820 8536 -7830 8577
--7820 8618 -7820 8658 -7820 8696 -7820 8733 -7840 8770 -7840 8805 -7850 8842
--7860 8876 -7890 8909 -7900 8939 -7930 8967 -7960 8997 -7980 9026 -8040 9058
--8050 9085 -8040 9110 -8050 9134 -8050 9158 -8060 9181 -8090 9203 -8110 9224
--8120 9245 -8140 9264 -8160 9284 -8170 9301 -8190 9319 -8210 9336 -8230 9352
--8240 9367 -8260 9383 -8270 9397 -8290 9411 -8300 9423 -8320 9437 -8320 9449
--8350 9460 -8350 9473 -8360 9483 -8370 9493 -8390 9504 -8400 9514 -8410 9523
--8410 9533 -8420 9541 -8440 9550 -8450 9558 -8450 9566 -8460 9574 -8470 9582
--8470 9589 -8480 9596 -8500 9603 -8490 9610 -8510 9616 -8500 9623 -8520 9628
--8520 9634 -8530 9640 -8530 9646 -8540 9651 -8540 9655 -8550 9662 -8560 9666
--8550 9671 -8570 9675 -8570 9680 -8570 9684 -8570 9688 -8580 9691 -8590 9696
-237: 15448350 -4388149 -10280 9938 -10270 9939 -10270 9939 -10280 9941
--10280 9941 -10280 9943 -10300 9943 -10290 9946 -10290 9949 -10300 9949
--10310 9951 -10320 9951 -10320 9954 -10330 9956 -10340 9957 -10340 9956
--10350 9958 -10360 9961 -10370 9961 -10370 9964 -10390 9964 -10380 9966
--10400 9968 -10400 9970 -10420 9971 -10420 9974 -10420 9976 -10430 9975
--10440 9977 -10440 9978 -10460 9980 -10460 9984 -10460 9985 -10460 9984
--10480 9985 -10490 9989 -10490 9992 -10500 9994 -10490 9997 -10510 9998
--10520 10003 -10510 10005 -10530 10009 -10530 10010 -10550 10014 -10550 10018
--10560 10022 -10560 10025 -10580 10027 -10580 10029 -10590 10035 -10600 10038
--10610 10040 -10620 10044 -10630 10047 -10640 10051 -10640 10053 -10660 10054
--10660 10058 -10670 10059 -10680 10060 -10700 10062 -10700 10064 -10710 10064
--10710 10063 -10720 10063 -10730 10065 -10740 10064 -10740 10064 -10740 10064
--10750 10062 -10750 10062 -10760 10060 -10760 10058 -10770 10059 -10770 10057
--10770 10058 -10770 10055 -10770 10053 -10780 10054 -10770 10053 -10780 10052
--10770 10053 -10780 10054 -10780 10055 -10780 10055 -10790 10056 -10790 10059
--10780 10061 -10780 10064 -10780 10068 -10790 10071 -10800 10076 -10800 10080
--10810 10085 -10810 10092 -10810 10096 -10820 10101 -10830 10109 -10830 10114
--10840 10122 -10850 10127 -10860 10134 -10870 10139 -10870 10147 -10890 10153
--10890 10160 -10900 10166 -10910 10170 -10910 10176 -10930 10180 -10930 10184
--10940 10187 -10940 10191 -10950 10192 -10950 10196 -10950 10194 -10960 10196
--10960 10196 -10960 10195 -10960 10193 -10950 10191 -10950 10189 -10950 10187
--10940 10183 -10920 10179 -10920 10174 -10900 10167 -10890 10163 -10870 10157
--10860 10149 -10840 10142 -10810 10136 -10790 10130 -10760 10124 -10760 10116
--10720 10107 -10700 10099 -10660 10093 -10650 10087 -10620 10081 -10590 10073
--10550 10066 -10530 10060 -10500 10055 -10480 10047 -10440 10040 -10410 10038
--10370 10034 -10360 10026 -10350 10024 -10320 10019 -10300 10016 -10280 10013
--10260 10008 -10250 10005 -10230 10004 -10220 9999 -10220 9996 -10210 9995
--10200 9991 -10210 9990 -10210 9988 -10220 9984 -10220 9982 -10240 9979
--10250 9976 -10270 9973 -10290 9971 -10320 9968 -10340 9964 -10370 9960
--10390 9955 -10420 9952 -10470 9948 -10490 9944 -10530 9939 -10580 9934
--10610 9928 -10660 9923 -10680 9919 -10720 9914 -10760 9908 -10790 9904
--10830 9897 -10860 9894 -10900 9888 -10910 9885 -10940 9880 -10960 9875
--10980 9872 -10990 9870 -10980 9869 -10980 9866 -10970 9866 -10960 9867
--10940 9866 -10910 9870 -10880 9872 -10810 9875 -10770 9881 -10700 9887
--10630 9894 -10540 9903 -10460 9912 -10340 9924 -10230 9937 -10110 9949
--9960 9964 -9820 9982 -9660 9998 -9490 10018 -9320 10039 -9120 10061 -8920 10084
--8700 10108 -8490 10132 -8260 10157 -8010 10183 -7760 10213 -7500 10241
--7230 10272 -6960 10300 -6680 10330 -6400 10361 -6090 10393 -5780 10425
--5480 10456 -5180 10485 -4860 10516 -4560 10544 -4230 10576 -3890 10607
--3590 10633 -3270 10660 -2940 10688 -2650 10711 -2340 10737 -2030 10757
--1740 10780 -1450 10799 -1160 10818 -890 10833 -620 10849 -370 10863 -140 10875
-110 10886 320 10894 530 10904 710 10910 900 10914 1070 10920 1210 10923
-1350 10925 1460 10929 1550 10929 1650 10929 1710 10928 1760 10926 1790 10924
-1800 10922 1810 10918 1800 10912 1770 10904 1710 10895 1650 10885 1580 10871
-1470 10857 1390 10842 1270 10823 1140 10799 980 10776 820 10749 650 10716
-480 10684 280 10648 100 10610 -110 10566 -330 10521 -530 10473 -760 10421
--980 10369 -1210 10312 -1430 10255 -1670 10191 -1890 10129 -2130 10064
--2360 9999 -2600 9934 -2840 9865 -3070 9794 -3320 9724 -3540 9651 -3740 9583
--3980 9516 -4220 9448 -4470 9379 -4680 9311 -4940 9246 -5170 9183 -5420 9124
--5640 9068 -5890 9012 -6140 8960 -6380 8912 -6610 8869 -6840 8831 -7070 8795
--7310 8765 -7560 8738 -7800 8714 -8040 8698 -8260 8685 -8480 8677 -8700 8675
--8920 8675 -9140 8681 -9350 8692 -9550 8705 -9760 8725 -9950 8749 -10150 8776
--10350 8808 -10530 8840 -10700 8877 -10880 8920 -11030 8964 -11200 9011
--11360 9060 -11510 9109 -11640 9161 -11780 9218 -11900 9276 -12030 9331
--12140 9390 -12240 9448 -12360 9504 -12450 9563 -12550 9620 -12640 9676
--12720 9733 -12800 9784 -12870 9835 -12950 9883 -13030 9930 -13100 9974
--13170 10016 -13240 10055 -13300 10090 -13380 10122 -13440 10150 -13500 10177
--13560 10201 -13650 10222 -13730 10241 -13810 10255 -13910 10266 -13980 10273
--14080 10279 -14180 10282 -14270 10281 -14370 10280 -14460 10274 -14570 10268
--14680 10257 -14800 10247 -14920 10232 -15040 10217 -15170 10198 -15290 10177
--15400 10154 -15540 10129 -15650 10100 -15780 10072 -15920 10039 -16040 10005
--16160 9969 -16260 9930 -16390 9889 -16480 9846 -16580 9803 -16670 9755
--16760 9706 -16820 9656 -16900 9604 -16950 9550 -16990 9495 -17020 9437
--17060 9379 -17050 9319 -17050 9257 -17050 9195 -17000 9132 -16970 9067
--16940 9002 -16870 8936 -16800 8869 -16730 8802 -16630 8735 -16530 8670
--16420 8602 -16300 8535 -16160 8470 -16010 8404 -15860 8342 -15700 8278
--15530 8217 -15360 8157 -15200 8101 -15020 8047 -14830 7995 -14610 7945
--14370 7896 -14150 7851 -13920 7809 -13700 7771 -13470 7737 -13240 7707
--13010 7680 -12780 7657 -12550 7638 -12320 7621 -12090 7610 -11860 7600
--11640 7596 -11410 7595 -11190 7598 -10980 7603 -10770 7612 -10560 7624
--10370 7640 -10180 7659 -10000 7679 -9810 7703 -9650 7730 -9490 7757 -9340 7788
--9190 7820 -9050 7854 -8930 7890 -8810 7926 -8710 7965 -8610 8003 -8530 8044
--8440 8084 -8360 8126 -8290 8167 -8220 8210 -8180 8251 -8120 8294 -8060 8335
--8030 8378 -8000 8419 -7970 8460 -7950 8501 -7930 8541 -7930 8581 -7920 8619
--7910 8658 -7910 8696 -7910 8732 -7910 8767 -7910 8802 -7910 8836 -7920 8870
--7940 8903 -7960 8934 -7970 8962 -8000 8990 -8010 9018 -8040 9046 -8090 9076
--8110 9102 -8100 9126 -8090 9149 -8100 9172 -8110 9194 -8130 9215 -8150 9235
--8160 9255 -8180 9275 -8190 9292 -8210 9310 -8230 9327 -8240 9343 -8260 9358
--8270 9374 -8290 9388 -8300 9402 -8320 9416 -8320 9427 -8340 9441 -8350 9452
--8360 9464 -8380 9475 -8380 9486 -8400 9495 -8400 9506 -8420 9515 -8420 9525
--8440 9534 -8440 9543 -8450 9550 -8460 9559 -8460 9567 -8480 9575 -8480 9582
--8490 9589 -8500 9596 -8500 9603 -8510 9609 -8520 9616 -8520 9622 -8520 9628
--8530 9633 -8540 9639 -8550 9645 -8540 9650 -8560 9655 -8560 9660 -8560 9665
--8570 9670 -8570 9674 -8580 9678 -8580 9683 -8590 9687 -8580 9690 -8600 9694
-238: 15481950 -4379819 -10270 9937 -10270 9939 -10270 9939 -10280 9939
--10280 9941 -10280 9943 -10290 9943 -10290 9947 -10290 9947 -10300 9949
--10310 9951 -10310 9952 -10330 9953 -10330 9956 -10330 9957 -10340 9955
--10350 9957 -10350 9960 -10370 9961 -10370 9963 -10380 9965 -10380 9967
--10400 9966 -10400 9970 -10410 9970 -10420 9974 -10410 9975 -10430 9974
--10430 9976 -10440 9977 -10450 9980 -10460 9981 -10460 9985 -10450 9983
--10480 9985 -10480 9989 -10480 9990 -10490 9991 -10500 9996 -10500 9999
--10510 10001 -10510 10004 -10520 10008 -10530 10009 -10540 10010 -10540 10017
--10560 10021 -10560 10022 -10570 10026 -10570 10027 -10580 10032 -10590 10034
--10610 10040 -10610 10042 -10620 10045 -10630 10048 -10630 10051 -10650 10053
--10660 10056 -10660 10057 -10670 10058 -10680 10059 -10690 10061 -10700 10063
--10710 10061 -10710 10062 -10720 10062 -10720 10062 -10730 10062 -10730 10062
--10740 10060 -10750 10060 -10740 10058 -10750 10057 -10760 10055 -10750 10055
--10760 10056 -10760 10053 -10770 10052 -10760 10052 -10760 10051 -10770 10049
--10760 10050 -10770 10053 -10770 10052 -10770 10052 -10780 10053 -10770 10055
--10780 10058 -10770 10063 -10770 10064 -10770 10068 -10790 10071 -10790 10076
--10790 10081 -10810 10087 -10800 10092 -10800 10097 -10820 10102 -10820 10110
--10820 10116 -10830 10122 -10840 10128 -10860 10134 -10850 10139 -10870 10148
--10880 10154 -10880 10159 -10880 10164 -10900 10170 -10910 10174 -10910 10178
--10910 10180 -10930 10185 -10930 10187 -10930 10189 -10930 10189 -10930 10190
--10950 10191 -10940 10190 -10930 10189 -10920 10187 -10930 10185 -10930 10184
--10910 10178 -10910 10176 -10890 10171 -10890 10165 -10870 10161 -10850 10155
--10840 10149 -10820 10141 -10790 10135 -10770 10130 -10750 10123 -10730 10117
--10700 10107 -10690 10101 -10640 10093 -10640 10089 -10600 10082 -10570 10075
--10540 10067 -10510 10062 -10490 10057 -10460 10049 -10430 10044 -10400 10039
--10360 10035 -10350 10030 -10330 10026 -10300 10020 -10280 10017 -10270 10015
--10240 10009 -10230 10006 -10220 10004 -10200 10000 -10190 9998 -10190 9995
--10190 9991 -10180 9989 -10190 9986 -10190 9984 -10200 9980 -10210 9976
--10220 9975 -10240 9970 -10260 9968 -10270 9964 -10310 9959 -10330 9956
--10350 9950 -10390 9947 -10420 9943 -10450 9939 -10490 9932 -10530 9928
--10570 9922 -10620 9916 -10640 9912 -10670 9906 -10710 9900 -10750 9895
--10790 9889 -10820 9884 -10850 9879 -10870 9875 -10910 9870 -10920 9866
--10940 9861 -10960 9859 -10960 9856 -10970 9855 -10940 9853 -10940 9854
--10930 9853 -10910 9854 -10880 9857 -10830 9860 -10770 9866 -10730 9870
--10660 9876 -10580 9884 -10490 9893 -10400 9903 -10300 9915 -10180 9927
--10040 9941 -9910 9956 -9770 9973 -9600 9989 -9440 10009 -9260 10030 -9060 10052
--8870 10074 -8660 10097 -8430 10119 -8220 10145 -7970 10171 -7730 10199
--7470 10227 -7210 10256 -6940 10281 -6670 10311 -6390 10341 -6090 10372
--5800 10401 -5510 10428 -5220 10457 -4910 10485 -4600 10515 -4280 10543
--3980 10570 -3690 10594 -3370 10622 -3080 10645 -2790 10668 -2490 10690
--2210 10710 -1930 10730 -1640 10748 -1390 10763 -1120 10781 -880 10793
--650 10807 -420 10818 -210 10828 0 10837 180 10844 370 10850 530 10857
-670 10860 800 10865 920 10868 1030 10871 1120 10870 1170 10871 1230 10870
-1270 10869 1300 10867 1300 10863 1300 10859 1270 10852 1240 10843 1180 10833
-1110 10822 1030 10807 940 10793 850 10774 720 10753 580 10729 430 10704
-280 10672 120 10642 -60 10608 -240 10570 -430 10528 -620 10487 -830 10438
--1030 10390 -1240 10338 -1450 10285 -1670 10229 -1890 10170 -2110 10108
--2330 10048 -2550 9984 -2770 9921 -3010 9855 -3230 9788 -3470 9719 -3680 9650
--3870 9584 -4110 9519 -4340 9454 -4560 9388 -4790 9323 -5020 9259 -5260 9200
--5480 9141 -5710 9087 -5950 9033 -6170 8982 -6410 8935 -6640 8894 -6850 8856
--7080 8820 -7320 8790 -7550 8764 -7770 8740 -8000 8722 -8220 8708 -8450 8699
--8650 8696 -8850 8695 -9060 8698 -9270 8706 -9460 8719 -9660 8736 -9840 8757
--10020 8783 -10220 8810 -10400 8839 -10560 8874 -10720 8913 -10870 8954
--11030 8998 -11180 9042 -11320 9089 -11450 9138 -11580 9190 -11690 9243
--11820 9297 -11920 9351 -12030 9406 -12130 9459 -12210 9513 -12310 9569
--12390 9622 -12460 9674 -12540 9724 -12610 9773 -12690 9819 -12750 9864
--12830 9907 -12890 9947 -12950 9984 -13020 10020 -13080 10050 -13140 10080
--13200 10106 -13260 10131 -13340 10153 -13410 10172 -13500 10187 -13570 10199
--13660 10208 -13740 10216 -13840 10220 -13920 10223 -14020 10222 -14100 10219
--14200 10214 -14300 10207 -14420 10199 -14530 10187 -14650 10174 -14760 10158
--14880 10139 -15000 10120 -15120 10097 -15230 10073 -15340 10047 -15480 10017
--15600 9987 -15710 9953 -15820 9919 -15920 9881 -16020 9842 -16110 9801
--16200 9758 -16280 9713 -16350 9667 -16430 9618 -16480 9568 -16520 9517
--16550 9464 -16590 9409 -16590 9353 -16590 9296 -16590 9237 -16560 9177
--16530 9118 -16510 9056 -16440 8994 -16400 8932 -16310 8868 -16240 8806
--16140 8743 -16040 8680 -15930 8617 -15810 8555 -15670 8494 -15530 8434
--15380 8375 -15220 8316 -15070 8260 -14930 8206 -14750 8155 -14570 8107
--14370 8058 -14150 8011 -13940 7968 -13730 7929 -13520 7892 -13310 7859
--13100 7830 -12870 7804 -12660 7781 -12450 7763 -12240 7746 -12010 7733
--11800 7725 -11590 7718 -11380 7717 -11170 7719 -10970 7722 -10770 7730
--10580 7740 -10390 7754 -10210 7770 -10030 7789 -9870 7810 -9710 7833
--9550 7859 -9410 7887 -9260 7917 -9130 7947 -9010 7981 -8910 8014 -8800 8049
--8700 8086 -8630 8123 -8530 8160 -8470 8199 -8390 8238 -8330 8276 -8270 8316
--8220 8356 -8170 8395 -8120 8434 -8100 8473 -8060 8511 -8050 8550 -8030 8588
--8020 8625 -8010 8661 -8010 8698 -7990 8734 -7990 8767 -7980 8802 -7980 8833
--7990 8867 -7990 8898 -8010 8930 -8030 8959 -8040 8987 -8050 9012 -8070 9039
--8090 9066 -8150 9094 -8170 9119 -8150 9142 -8140 9165 -8150 9186 -8150 9207
--8170 9228 -8190 9247 -8200 9265 -8220 9284 -8230 9302 -8250 9319 -8260 9335
--8270 9350 -8290 9365 -8310 9380 -8310 9394 -8330 9407 -8340 9420 -8360 9433
--8360 9444 -8380 9456 -8380 9467 -8390 9478 -8410 9489 -8410 9498 -8430 9508
--8430 9517 -8440 9526 -8450 9536 -8460 9543 -8470 9552 -8470 9560 -8490 9567
--8490 9576 -8490 9582 -8510 9589 -8510 9597 -8510 9602 -8520 9610 -8530 9615
--8530 9621 -8540 9628 -8540 9633 -8550 9639 -8550 9643 -8570 9650 -8560 9654
--8570 9659 -8580 9664 -8570 9668 -8590 9673 -8580 9677 -8590 9682 -8590 9685
--8600 9689 -8610 9693
-239: 15515560 -4371492 -10260 9937 -10270 9938 -10280 9939 -10270 9938
--10280 9941 -10280 9944 -10290 9943 -10280 9946 -10290 9946 -10300 9951
--10310 9950 -10310 9950 -10320 9952 -10330 9953 -10330 9959 -10340 9956
--10340 9957 -10360 9962 -10350 9960 -10370 9960 -10370 9966 -10390 9966
--10390 9966 -10400 9968 -10410 9971 -10410 9973 -10410 9973 -10420 9974
--10430 9974 -10440 9976 -10440 9978 -10450 9981 -10460 9985 -10450 9983
--10470 9984 -10470 9987 -10480 9989 -10490 9990 -10490 9996 -10500 9997
--10500 10000 -10510 10002 -10510 10006 -10530 10008 -10530 10010 -10540 10015
--10550 10017 -10550 10021 -10560 10025 -10570 10026 -10570 10028 -10590 10032
--10590 10038 -10610 10041 -10610 10042 -10620 10045 -10630 10050 -10640 10052
--10640 10052 -10660 10054 -10660 10055 -10670 10058 -10680 10059 -10690 10061
--10690 10059 -10710 10060 -10700 10059 -10710 10060 -10720 10061 -10730 10060
--10730 10058 -10730 10057 -10740 10057 -10740 10055 -10740 10055 -10740 10054
--10750 10051 -10750 10052 -10750 10050 -10750 10049 -10750 10049 -10760 10048
--10750 10048 -10760 10048 -10760 10049 -10770 10051 -10760 10051 -10760 10052
--10760 10055 -10770 10060 -10760 10061 -10760 10064 -10770 10068 -10780 10071
--10780 10078 -10790 10082 -10790 10087 -10800 10093 -10790 10097 -10810 10104
--10810 10110 -10810 10117 -10830 10122 -10830 10128 -10840 10136 -10850 10140
--10860 10148 -10860 10153 -10870 10158 -10880 10163 -10890 10168 -10880 10173
--10900 10174 -10910 10178 -10900 10181 -10910 10182 -10920 10185 -10910 10184
--10920 10185 -10910 10185 -10910 10184 -10910 10184 -10900 10181 -10910 10179
--10890 10174 -10880 10172 -10870 10168 -10870 10163 -10850 10159 -10840 10152
--10820 10147 -10790 10140 -10770 10134 -10760 10130 -10740 10123 -10710 10115
--10680 10108 -10670 10102 -10630 10095 -10620 10089 -10580 10084 -10560 10076
--10520 10069 -10510 10064 -10480 10059 -10440 10051 -10420 10045 -10380 10041
--10360 10037 -10330 10033 -10320 10027 -10280 10023 -10270 10018 -10250 10015
--10230 10012 -10210 10008 -10200 10004 -10190 10001 -10170 9998 -10170 9995
--10160 9991 -10170 9989 -10160 9986 -10170 9980 -10170 9980 -10190 9976
--10190 9972 -10200 9969 -10230 9965 -10240 9961 -10270 9956 -10290 9951
--10320 9947 -10350 9942 -10380 9938 -10410 9934 -10450 9927 -10480 9922
--10520 9917 -10570 9911 -10590 9904 -10630 9899 -10670 9894 -10710 9888
--10750 9881 -10780 9875 -10800 9871 -10830 9867 -10860 9862 -10880 9857
--10910 9851 -10930 9849 -10930 9847 -10930 9843 -10930 9842 -10920 9841
--10920 9841 -10900 9842 -10870 9843 -10840 9846 -10780 9851 -10740 9854
--10680 9861 -10610 9866 -10530 9875 -10450 9884 -10340 9895 -10240 9904
--10120 9919 -9990 9932 -9860 9948 -9710 9964 -9560 9981 -9380 10001 -9200 10021
--9020 10042 -8810 10062 -8620 10084 -8400 10108 -8170 10133 -7930 10158
--7700 10184 -7450 10212 -7200 10236 -6930 10263 -6660 10291 -6380 10321
--6110 10348 -5840 10374 -5540 10400 -5260 10428 -4960 10455 -4660 10483
--4360 10507 -4080 10532 -3790 10557 -3500 10579 -3220 10602 -2940 10624
--2670 10643 -2390 10662 -2120 10681 -1860 10695 -1610 10713 -1370 10727
--1150 10739 -930 10752 -720 10762 -530 10772 -330 10779 -170 10788 10 10794
-140 10799 280 10804 400 10808 500 10811 590 10814 660 10813 710 10814 770 10813
-790 10812 810 10809 810 10805 780 10800 770 10791 710 10782 660 10772 580 10757
-510 10744 420 10726 310 10706 180 10683 50 10659 -100 10630 -240 10599
--400 10567 -570 10531 -750 10492 -940 10450 -1110 10404 -1310 10359 -1500 10310
--1700 10258 -1910 10204 -2120 10148 -2330 10089 -2530 10030 -2750 9970
--2960 9908 -3170 9846 -3410 9781 -3610 9715 -3820 9648 -4000 9585 -4240 9524
--4470 9459 -4680 9397 -4900 9333 -5110 9273 -5330 9215 -5560 9159 -5770 9105
--6010 9053 -6220 9005 -6450 8958 -6660 8918 -6880 8880 -7100 8844 -7320 8816
--7530 8788 -7760 8765 -7980 8746 -8190 8731 -8390 8721 -8610 8717 -8790 8715
--9000 8716 -9190 8722 -9360 8732 -9560 8747 -9740 8767 -9920 8789 -10080 8813
--10270 8841 -10430 8872 -10570 8907 -10720 8945 -10870 8987 -11000 9027
--11140 9071 -11270 9115 -11390 9164 -11490 9214 -11600 9265 -11710 9315
--11810 9367 -11910 9416 -11990 9468 -12080 9520 -12150 9571 -12220 9620
--12290 9668 -12360 9713 -12430 9759 -12500 9801 -12560 9843 -12620 9882
--12670 9919 -12730 9952 -12800 9983 -12860 10013 -12900 10038 -12970 10064
--13050 10086 -13110 10104 -13170 10121 -13260 10134 -13330 10145 -13420 10154
--13510 10160 -13580 10165 -13680 10166 -13750 10165 -13840 10163 -13940 10158
--14050 10151 -14150 10143 -14260 10131 -14380 10118 -14480 10103 -14600 10086
--14710 10066 -14820 10044 -14930 10021 -15050 9996 -15170 9967 -15270 9938
--15380 9906 -15470 9872 -15570 9837 -15660 9799 -15750 9760 -15820 9718
--15900 9676 -15970 9630 -16010 9585 -16070 9537 -16100 9489 -16130 9437
--16140 9385 -16140 9331 -16150 9277 -16120 9221 -16110 9165 -16080 9108
--16030 9049 -15990 8991 -15920 8931 -15850 8873 -15760 8814 -15670 8754
--15570 8695 -15470 8637 -15330 8579 -15210 8523 -15070 8466 -14930 8412
--14780 8357 -14640 8308 -14490 8258 -14330 8213 -14130 8168 -13920 8122
--13750 8081 -13540 8043 -13340 8008 -13150 7976 -12950 7948 -12740 7923
--12540 7900 -12350 7882 -12140 7866 -11940 7853 -11730 7843 -11540 7838
--11340 7834 -11140 7835 -10960 7837 -10760 7843 -10580 7853 -10400 7863
--10240 7878 -10070 7895 -9900 7914 -9760 7935 -9610 7958 -9470 7983 -9330 8010
--9200 8039 -9090 8068 -8980 8100 -8890 8133 -8800 8165 -8700 8200 -8630 8235
--8560 8270 -8480 8307 -8420 8343 -8370 8379 -8310 8417 -8260 8453 -8220 8489
--8200 8527 -8150 8562 -8150 8599 -8110 8633 -8120 8669 -8090 8703 -8090 8738
--8080 8770 -8060 8804 -8060 8835 -8050 8866 -8050 8896 -8070 8927 -8070 8957
--8100 8984 -8100 9010 -8120 9036 -8130 9059 -8140 9086 -8200 9113 -8220 9137
--8190 9159 -8200 9179 -8190 9201 -8200 9220 -8210 9240 -8230 9259 -8240 9277
--8260 9294 -8270 9311 -8280 9328 -8300 9343 -8300 9357 -8320 9372 -8340 9387
--8340 9400 -8360 9412 -8360 9426 -8380 9437 -8390 9448 -8400 9460 -8400 9471
--8420 9481 -8430 9491 -8430 9501 -8450 9510 -8450 9519 -8450 9529 -8470 9536
--8480 9545 -8480 9553 -8490 9561 -8500 9568 -8510 9576 -8510 9583 -8510 9590
--8530 9596 -8520 9603 -8530 9609 -8540 9616 -8550 9621 -8550 9627 -8550 9633
--8560 9638 -8570 9643 -8570 9648 -8580 9654 -8580 9658 -8580 9663 -8590 9667
--8600 9672 -8590 9676 -8600 9681 -8600 9684 -8610 9687 -8610 9691
-240: 15549190 -4363167 -10270 9937 -10260 9937 -10280 9939 -10270 9939
--10270 9939 -10280 9944 -10290 9944 -10280 9945 -10300 9944 -10290 9951
--10310 9949 -10310 9951 -10320 9952 -10320 9954 -10330 9955 -10330 9957
--10340 9958 -10360 9960 -10350 9960 -10360 9960 -10370 9964 -10390 9966
--10380 9966 -10400 9967 -10400 9970 -10410 9972 -10410 9971 -10420 9975
--10420 9973 -10430 9976 -10450 9979 -10440 9981 -10460 9981 -10450 9984
--10450 9983 -10470 9984 -10480 9988 -10480 9991 -10480 9994 -10490 9995
--10500 9998 -10500 10002 -10510 10004 -10520 10007 -10530 10008 -10530 10013
--10550 10014 -10540 10019 -10550 10024 -10560 10024 -10570 10028 -10580 10030
--10590 10034 -10590 10038 -10610 10041 -10610 10044 -10620 10047 -10630 10048
--10630 10050 -10640 10051 -10660 10054 -10670 10056 -10660 10056 -10680 10058
--10680 10057 -10700 10058 -10690 10058 -10700 10058 -10710 10060 -10720 10058
--10720 10056 -10720 10054 -10720 10055 -10730 10054 -10730 10054 -10730 10052
--10740 10050 -10740 10049 -10740 10049 -10740 10046 -10750 10046 -10740 10047
--10740 10045 -10750 10045 -10750 10046 -10750 10049 -10750 10049 -10750 10051
--10760 10052 -10750 10055 -10760 10059 -10750 10060 -10760 10064 -10760 10068
--10760 10073 -10780 10078 -10790 10082 -10780 10089 -10780 10093 -10790 10099
--10800 10105 -10800 10110 -10800 10117 -10820 10122 -10820 10130 -10840 10134
--10830 10142 -10850 10148 -10850 10151 -10860 10157 -10870 10162 -10870 10166
--10870 10169 -10880 10171 -10890 10176 -10890 10176 -10890 10178 -10900 10179
--10890 10180 -10880 10181 -10890 10178 -10900 10179 -10880 10177 -10880 10175
--10870 10171 -10860 10168 -10860 10164 -10840 10160 -10830 10155 -10820 10150
--10790 10144 -10780 10138 -10760 10135 -10740 10128 -10710 10123 -10700 10114
--10670 10108 -10650 10103 -10620 10096 -10590 10090 -10580 10085 -10540 10077
--10520 10071 -10490 10066 -10460 10059 -10430 10053 -10410 10048 -10370 10042
--10350 10039 -10320 10034 -10300 10029 -10280 10024 -10250 10022 -10230 10015
--10220 10014 -10190 10010 -10190 10004 -10170 10002 -10150 9997 -10160 9995
--10140 9992 -10150 9989 -10140 9984 -10140 9981 -10150 9978 -10150 9975
--10170 9972 -10180 9966 -10200 9963 -10200 9959 -10230 9953 -10260 9949
--10280 9944 -10310 9938 -10340 9934 -10370 9930 -10410 9923 -10440 9917
--10470 9912 -10520 9904 -10550 9900 -10580 9893 -10620 9889 -10670 9881
--10700 9875 -10730 9868 -10760 9863 -10790 9859 -10810 9854 -10850 9849
--10870 9843 -10880 9841 -10900 9837 -10900 9834 -10900 9832 -10910 9831
--10900 9829 -10880 9831 -10860 9830 -10830 9834 -10790 9837 -10750 9840
--10690 9845 -10630 9851 -10570 9859 -10480 9866 -10390 9875 -10290 9885
--10190 9897 -10060 9911 -9940 9925 -9800 9939 -9660 9955 -9510 9973 -9330 9992
--9150 10011 -8960 10030 -8780 10050 -8570 10073 -8360 10096 -8140 10119
--7910 10145 -7670 10168 -7440 10192 -7180 10218 -6930 10244 -6660 10271
--6390 10297 -6140 10322 -5870 10346 -5580 10372 -5300 10399 -5020 10423
--4740 10448 -4470 10471 -4190 10495 -3910 10516 -3640 10538 -3370 10559
--3110 10578 -2830 10596 -2580 10615 -2330 10631 -2090 10646 -1850 10660
--1630 10675 -1430 10687 -1220 10699 -1030 10706 -840 10717 -670 10725
--510 10732 -370 10738 -240 10744 -120 10748 -10 10754 80 10755 150 10757
-210 10757 260 10757 300 10758 330 10755 320 10752 310 10746 310 10739 250 10731
-200 10721 150 10709 80 10694 -10 10679 -100 10660 -210 10638 -330 10613
--460 10588 -600 10557 -750 10526 -910 10493 -1070 10455 -1240 10415 -1410 10371
--1590 10328 -1780 10281 -1950 10231 -2140 10180 -2360 10127 -2550 10069
--2740 10013 -2940 9956 -3150 9897 -3350 9836 -3560 9774 -3780 9712 -3970 9647
--4150 9586 -4370 9527 -4590 9466 -4810 9403 -5010 9344 -5200 9286 -5420 9231
--5630 9175 -5850 9123 -6070 9073 -6270 9025 -6490 8982 -6700 8940 -6910 8903
--7100 8870 -7330 8839 -7530 8813 -7750 8789 -7950 8770 -8160 8755 -8360 8743
--8540 8738 -8750 8734 -8940 8735 -9110 8738 -9290 8746 -9460 8760 -9640 8777
--9810 8795 -9970 8818 -10140 8843 -10300 8871 -10430 8903 -10570 8939
--10710 8975 -10840 9014 -10970 9055 -11090 9095 -11210 9141 -11300 9188
--11410 9235 -11510 9282 -11600 9330 -11690 9378 -11770 9425 -11860 9475
--11920 9523 -11990 9569 -12050 9614 -12120 9659 -12180 9701 -12250 9743
--12300 9782 -12360 9820 -12410 9856 -12460 9889 -12520 9920 -12570 9948
--12630 9974 -12690 10000 -12750 10020 -12810 10039 -12870 10055 -12950 10071
--13030 10084 -13090 10095 -13180 10102 -13270 10108 -13340 10112 -13410 10113
--13490 10112 -13590 10110 -13690 10105 -13790 10099 -13890 10089 -14000 10079
--14100 10067 -14210 10052 -14320 10034 -14430 10016 -14520 9996 -14640 9973
--14740 9949 -14850 9921 -14960 9893 -15040 9862 -15140 9830 -15220 9796
--15310 9761 -15380 9722 -15450 9683 -15520 9642 -15570 9599 -15630 9556
--15650 9510 -15680 9463 -15710 9415 -15720 9364 -15710 9314 -15700 9262
--15700 9210 -15670 9156 -15630 9102 -15590 9046 -15530 8991 -15460 8937
--15390 8881 -15310 8825 -15230 8769 -15120 8715 -15010 8660 -14890 8607
--14770 8554 -14630 8503 -14500 8451 -14370 8404 -14230 8358 -14080 8315
--13900 8272 -13710 8228 -13540 8189 -13360 8153 -13180 8119 -12980 8088
--12800 8061 -12620 8037 -12420 8015 -12240 7997 -12040 7980 -11860 7968
--11660 7958 -11480 7951 -11290 7947 -11110 7947 -10940 7948 -10740 7953
--10580 7960 -10410 7970 -10250 7982 -10090 7998 -9950 8014 -9790 8033
--9670 8053 -9510 8077 -9400 8101 -9270 8127 -9160 8155 -9050 8183 -8960 8213
--8880 8243 -8780 8276 -8720 8307 -8640 8341 -8570 8374 -8500 8408 -8460 8441
--8400 8476 -8350 8511 -8310 8544 -8280 8579 -8250 8612 -8230 8646 -8210 8680
--8190 8712 -8180 8744 -8160 8777 -8150 8808 -8140 8838 -8130 8869 -8130 8897
--8120 8927 -8130 8955 -8140 8984 -8160 9009 -8160 9035 -8170 9057 -8190 9082
--8200 9105 -8250 9132 -8260 9154 -8250 9175 -8230 9195 -8240 9215 -8240 9234
--8260 9253 -8270 9271 -8280 9287 -8300 9305 -8310 9321 -8310 9336 -8330 9352
--8340 9365 -8350 9379 -8360 9393 -8370 9406 -8380 9419 -8400 9430 -8410 9442
--8410 9453 -8420 9464 -8430 9474 -8430 9485 -8450 9494 -8450 9503 -8470 9513
--8470 9522 -8480 9530 -8480 9538 -8490 9547 -8500 9554 -8510 9562 -8520 9570
--8510 9576 -8530 9584 -8530 9590 -8540 9596 -8530 9603 -8550 9609 -8550 9616
--8550 9621 -8570 9627 -8570 9632 -8570 9638 -8580 9643 -8580 9647 -8580 9653
--8590 9658 -8590 9662 -8610 9666 -8600 9671 -8600 9675 -8610 9679 -8610 9683
--8620 9686 -8620 9690
-241: 15582830 -4354846 -10270 9937 -10260 9937 -10270 9937 -10270 9941
--10280 9942 -10280 9943 -10280 9943 -10290 9943 -10290 9945 -10300 9947
--10290 9950 -10310 9949 -10320 9952 -10320 9955 -10330 9954 -10330 9957
--10340 9956 -10340 9960 -10360 9960 -10360 9961 -10360 9962 -10380 9964
--10380 9966 -10390 9968 -10400 9970 -10400 9971 -10410 9973 -10420 9974
--10410 9972 -10430 9975 -10440 9978 -10450 9980 -10450 9981 -10440 9981
--10460 9983 -10460 9982 -10470 9987 -10470 9990 -10480 9993 -10490 9994
--10490 9996 -10500 10000 -10510 10002 -10510 10005 -10520 10008 -10530 10011
--10530 10013 -10540 10016 -10540 10021 -10560 10023 -10560 10026 -10570 10029
--10580 10032 -10580 10035 -10600 10039 -10600 10041 -10610 10044 -10620 10046
--10620 10048 -10640 10049 -10650 10052 -10650 10054 -10660 10054 -10670 10055
--10670 10056 -10680 10055 -10690 10056 -10690 10056 -10700 10058 -10700 10057
--10710 10053 -10710 10053 -10720 10052 -10720 10054 -10720 10051 -10720 10050
--10730 10049 -10720 10047 -10730 10046 -10730 10045 -10740 10044 -10730 10044
--10740 10044 -10730 10043 -10740 10044 -10740 10045 -10740 10047 -10740 10049
--10740 10049 -10750 10051 -10740 10055 -10750 10058 -10740 10061 -10750 10064
--10760 10070 -10760 10073 -10760 10077 -10770 10084 -10770 10090 -10790 10094
--10780 10098 -10780 10106 -10790 10112 -10800 10116 -10810 10125 -10810 10129
--10820 10135 -10830 10141 -10830 10145 -10840 10151 -10850 10155 -10850 10159
--10850 10163 -10870 10166 -10860 10171 -10870 10169 -10870 10173 -10870 10173
--10870 10174 -10870 10175 -10870 10174 -10860 10174 -10860 10172 -10870 10170
--10850 10167 -10840 10164 -10830 10161 -10830 10156 -10800 10152 -10800 10147
--10770 10143 -10760 10136 -10740 10134 -10730 10127 -10690 10121 -10680 10116
--10660 10108 -10640 10102 -10600 10096 -10590 10091 -10560 10085 -10530 10078
--10500 10072 -10480 10066 -10450 10061 -10410 10054 -10400 10049 -10370 10046
--10340 10040 -10300 10035 -10290 10030 -10270 10027 -10240 10022 -10210 10018
--10210 10014 -10180 10011 -10170 10006 -10160 10003 -10140 9997 -10130 9995
--10130 9993 -10120 9989 -10120 9984 -10130 9981 -10120 9978 -10140 9973
--10130 9970 -10150 9966 -10160 9961 -10180 9957 -10200 9952 -10220 9946
--10240 9942 -10270 9935 -10300 9931 -10330 9926 -10370 9920 -10390 9913
--10440 9907 -10470 9901 -10500 9894 -10530 9889 -10570 9883 -10620 9876
--10650 9869 -10690 9862 -10710 9858 -10750 9853 -10770 9848 -10800 9841
--10830 9836 -10840 9832 -10870 9829 -10860 9826 -10870 9824 -10880 9821
--10880 9819 -10860 9820 -10840 9819 -10820 9822 -10790 9825 -10750 9828
--10700 9831 -10650 9836 -10580 9843 -10510 9850 -10430 9859 -10340 9866
--10240 9878 -10130 9890 -10020 9902 -9880 9917 -9750 9931 -9610 9947 -9450 9963
--9280 9981 -9100 10000 -8930 10019 -8730 10039 -8540 10061 -8320 10083
--8110 10105 -7880 10127 -7670 10151 -7420 10174 -7190 10198 -6920 10224
--6680 10248 -6420 10271 -6170 10296 -5910 10318 -5620 10343 -5360 10368
--5100 10390 -4830 10413 -4570 10435 -4310 10456 -4050 10476 -3790 10496
--3520 10514 -3270 10534 -3030 10552 -2780 10566 -2540 10582 -2330 10597
--2110 10611 -1910 10623 -1700 10635 -1510 10646 -1340 10654 -1170 10663
--1010 10670 -870 10678 -740 10685 -630 10689 -510 10696 -420 10697 -340 10701
--280 10701 -230 10702 -180 10703 -160 10702 -150 10699 -140 10693 -160 10687
--210 10680 -240 10670 -280 10659 -350 10647 -420 10631 -500 10613 -610 10594
--710 10569 -830 10544 -970 10516 -1090 10487 -1240 10454 -1390 10419 -1540 10381
--1710 10339 -1870 10297 -2030 10252 -2230 10205 -2400 10156 -2580 10105
--2770 10051 -2960 9996 -3140 9942 -3340 9885 -3530 9827 -3730 9768 -3930 9707
--4130 9646 -4300 9587 -4510 9529 -4720 9471 -4930 9412 -5110 9355 -5310 9298
--5510 9244 -5710 9191 -5920 9141 -6130 9093 -6330 9046 -6540 9003 -6740 8963
--6930 8928 -7130 8893 -7340 8864 -7530 8836 -7740 8813 -7940 8794 -8130 8777
--8320 8766 -8510 8759 -8690 8754 -8870 8753 -9050 8755 -9210 8761 -9380 8772
--9540 8787 -9710 8804 -9860 8823 -10020 8846 -10170 8872 -10300 8901 -10440 8934
--10560 8967 -10690 9002 -10810 9039 -10910 9078 -11030 9120 -11120 9163
--11220 9209 -11310 9252 -11410 9296 -11480 9341 -11570 9386 -11630 9433
--11710 9478 -11770 9522 -11830 9564 -11880 9607 -11940 9648 -12010 9687
--12060 9725 -12110 9762 -12150 9797 -12200 9828 -12250 9858 -12300 9888
--12360 9914 -12410 9938 -12460 9956 -12520 9977 -12580 9995 -12650 10011
--12720 10026 -12790 10037 -12880 10046 -12940 10054 -13010 10059 -13090 10062
--13170 10063 -13240 10062 -13340 10061 -13430 10055 -13550 10048 -13630 10041
--13730 10031 -13840 10018 -13940 10003 -14040 9988 -14140 9970 -14240 9950
--14340 9929 -14440 9904 -14550 9880 -14620 9851 -14710 9823 -14800 9792
--14880 9759 -14960 9725 -15030 9689 -15090 9651 -15140 9612 -15190 9572
--15230 9531 -15250 9486 -15290 9442 -15300 9396 -15300 9348 -15280 9300
--15300 9252 -15260 9201 -15240 9151 -15200 9099 -15160 9048 -15090 8996
--15030 8945 -14950 8892 -14880 8840 -14790 8789 -14690 8737 -14590 8688
--14470 8637 -14340 8589 -14220 8541 -14100 8496 -13980 8453 -13840 8412
--13660 8371 -13500 8331 -13360 8292 -13170 8258 -13010 8225 -12840 8196
--12650 8169 -12480 8145 -12300 8125 -12120 8106 -11950 8091 -11760 8078
--11600 8067 -11420 8060 -11240 8056 -11070 8054 -10910 8055 -10730 8058
--10570 8064 -10410 8073 -10260 8083 -10110 8096 -9970 8111 -9830 8127
--9700 8147 -9560 8167 -9440 8189 -9340 8213 -9220 8238 -9120 8264 -9030 8291
--8940 8320 -8860 8348 -8780 8379 -8720 8409 -8660 8440 -8580 8471 -8540 8502
--8490 8535 -8430 8566 -8390 8598 -8360 8630 -8330 8662 -8320 8693 -8290 8724
--8270 8755 -8250 8785 -8240 8815 -8220 8845 -8210 8874 -8200 8902 -8190 8929
--8200 8956 -8190 8984 -8210 9010 -8210 9034 -8220 9059 -8230 9080 -8240 9102
--8250 9126 -8300 9151 -8310 9171 -8290 9192 -8280 9211 -8290 9229 -8280 9248
--8300 9265 -8310 9283 -8320 9299 -8330 9315 -8350 9331 -8350 9345 -8360 9360
--8370 9373 -8380 9387 -8390 9400 -8400 9412 -8410 9424 -8420 9436 -8430 9447
--8440 9457 -8450 9468 -8450 9479 -8460 9488 -8460 9497 -8480 9507 -8480 9515
--8490 9524 -8490 9532 -8510 9541 -8510 9548 -8510 9556 -8520 9563 -8530 9570
--8540 9578 -8540 9584 -8540 9591 -8550 9597 -8550 9603 -8560 9609 -8570 9616
--8560 9621 -8570 9626 -8580 9632 -8580 9638 -8600 9642 -8590 9648 -8590 9652
--8600 9656 -8610 9662 -8610 9665 -8610 9670 -8620 9674 -8610 9678 -8620 9682
--8630 9685 -8620 9689
-242: 15616480 -4346527 -10270 9936 -10260 9938 -10270 9938 -10270 9941
--10280 9941 -10270 9942 -10280 9943 -10290 9943 -10290 9944 -10290 9947
--10300 9947 -10310 9951 -10310 9950 -10320 9955 -10320 9955 -10330 9955
--10340 9957 -10340 9958 -10350 9960 -10360 9960 -10360 9962 -10370 9965
--10380 9967 -10390 9966 -10390 9967 -10400 9971 -10410 9972 -10410 9973
--10410 9973 -10420 9974 -10440 9977 -10440 9978 -10440 9981 -10450 9981
--10450 9981 -10460 9981 -10460 9987 -10460 9988 -10480 9991 -10480 9993
--10490 9996 -10490 9998 -10500 10001 -10520 10003 -10510 10005 -10520 10009
--10520 10013 -10530 10014 -10540 10018 -10550 10020 -10550 10025 -10570 10027
--10570 10031 -10570 10032 -10590 10036 -10600 10038 -10600 10042 -10610 10044
--10610 10047 -10630 10046 -10640 10049 -10640 10050 -10650 10052 -10660 10054
--10660 10054 -10670 10054 -10680 10054 -10680 10054 -10680 10055 -10690 10055
--10710 10052 -10700 10052 -10700 10050 -10710 10051 -10710 10050 -10710 10048
--10720 10048 -10720 10044 -10720 10044 -10710 10043 -10730 10044 -10720 10042
--10730 10041 -10720 10041 -10730 10042 -10730 10044 -10730 10044 -10730 10045
--10730 10047 -10730 10048 -10740 10052 -10730 10054 -10740 10057 -10730 10062
--10750 10064 -10740 10070 -10750 10073 -10760 10079 -10760 10085 -10770 10089
--10760 10095 -10770 10101 -10780 10106 -10780 10112 -10790 10118 -10800 10124
--10800 10128 -10810 10134 -10820 10140 -10810 10146 -10830 10148 -10830 10152
--10840 10157 -10840 10160 -10840 10164 -10850 10163 -10850 10167 -10840 10167
--10850 10168 -10850 10170 -10860 10169 -10840 10169 -10850 10167 -10830 10166
--10830 10163 -10820 10160 -10810 10157 -10810 10153 -10780 10149 -10770 10144
--10760 10140 -10740 10135 -10730 10131 -10700 10126 -10690 10122 -10670 10114
--10640 10107 -10620 10101 -10590 10096 -10570 10090 -10550 10084 -10520 10079
--10480 10073 -10460 10068 -10450 10062 -10410 10055 -10380 10051 -10360 10047
--10330 10041 -10290 10038 -10280 10032 -10250 10027 -10240 10024 -10210 10019
--10180 10016 -10170 10012 -10160 10007 -10150 10003 -10120 9999 -10120 9996
--10110 9992 -10100 9989 -10110 9985 -10100 9982 -10100 9977 -10110 9973
--10110 9969 -10120 9964 -10130 9960 -10140 9956 -10170 9951 -10180 9944
--10210 9939 -10240 9935 -10260 9928 -10290 9922 -10320 9917 -10350 9912
--10390 9903 -10420 9897 -10450 9891 -10490 9885 -10530 9878 -10560 9871
--10600 9864 -10640 9859 -10670 9852 -10700 9848 -10720 9842 -10750 9835
--10790 9829 -10800 9826 -10820 9822 -10830 9819 -10840 9816 -10840 9813
--10840 9812 -10840 9809 -10830 9810 -10810 9812 -10770 9813 -10750 9816
--10700 9819 -10660 9823 -10600 9829 -10530 9834 -10460 9843 -10380 9850
--10290 9860 -10190 9870 -10070 9882 -9970 9896 -9830 9907 -9700 9922 -9550 9938
--9400 9954 -9240 9971 -9060 9988 -8890 10007 -8700 10027 -8500 10048 -8290 10068
--8090 10089 -7870 10111 -7650 10133 -7430 10154 -7180 10178 -6940 10201
--6690 10224 -6470 10245 -6200 10267 -5950 10291 -5690 10314 -5430 10335
--5190 10357 -4930 10377 -4680 10397 -4440 10417 -4190 10436 -3930 10455
--3690 10472 -3460 10489 -3220 10506 -2990 10519 -2780 10535 -2570 10549
--2370 10560 -2170 10573 -1990 10584 -1830 10593 -1650 10603 -1500 10611
--1360 10618 -1220 10625 -1120 10632 -1000 10638 -910 10641 -830 10644
--760 10646 -710 10647 -650 10648 -630 10648 -620 10645 -600 10641 -620 10636
--630 10630 -680 10620 -710 10609 -760 10599 -830 10584 -920 10566 -990 10549
--1090 10526 -1200 10502 -1310 10476 -1440 10447 -1560 10417 -1720 10383
--1860 10347 -2000 10307 -2140 10266 -2310 10224 -2480 10180 -2650 10133
--2820 10083 -3000 10032 -3180 9980 -3340 9927 -3530 9874 -3720 9818 -3900 9761
--4100 9704 -4290 9645 -4440 9587 -4650 9532 -4850 9476 -5040 9419 -5230 9363
--5410 9311 -5600 9258 -5800 9208 -5990 9158 -6190 9112 -6400 9065 -6590 9025
--6770 8986 -6970 8950 -7160 8916 -7350 8888 -7540 8860 -7740 8837 -7920 8817
--8110 8801 -8290 8788 -8470 8779 -8640 8774 -8810 8772 -8990 8772 -9130 8777
--9300 8785 -9460 8798 -9620 8813 -9770 8830 -9900 8850 -10050 8873 -10170 8900
--10300 8930 -10430 8961 -10550 8992 -10650 9026 -10750 9063 -10860 9102
--10950 9141 -11030 9183 -11130 9224 -11210 9266 -11290 9307 -11360 9351
--11440 9393 -11490 9436 -11560 9477 -11620 9518 -11660 9559 -11710 9597
--11770 9636 -11820 9671 -11870 9707 -11910 9740 -11950 9771 -12000 9802
--12050 9830 -12090 9855 -12130 9878 -12180 9898 -12250 9920 -12290 9939
--12370 9956 -12430 9971 -12490 9982 -12560 9994 -12630 10001 -12700 10008
--12790 10013 -12840 10015 -12920 10017 -13010 10015 -13100 10014 -13200 10009
--13280 10003 -13370 9994 -13490 9985 -13570 9973 -13660 9959 -13770 9944
--13860 9927 -13950 9909 -14050 9887 -14150 9864 -14220 9841 -14300 9814
--14400 9786 -14470 9758 -14550 9726 -14610 9693 -14680 9659 -14720 9623
--14770 9586 -14820 9548 -14840 9508 -14880 9467 -14900 9423 -14900 9380
--14890 9336 -14890 9291 -14880 9243 -14850 9197 -14830 9149 -14790 9101
--14730 9053 -14670 9004 -14620 8956 -14550 8907 -14460 8858 -14390 8811
--14280 8764 -14170 8716 -14050 8671 -13950 8626 -13840 8583 -13730 8543
--13600 8504 -13430 8465 -13290 8429 -13150 8392 -13010 8358 -12850 8327
--12680 8298 -12510 8272 -12350 8249 -12170 8229 -12000 8211 -11840 8196
--11680 8183 -11530 8172 -11360 8165 -11190 8160 -11030 8157 -10870 8157
--10710 8159 -10550 8164 -10400 8171 -10270 8180 -10120 8191 -9990 8204
--9850 8219 -9730 8236 -9610 8254 -9480 8275 -9380 8295 -9280 8319 -9180 8342
--9090 8368 -9000 8393 -8930 8420 -8850 8447 -8800 8475 -8720 8504 -8660 8533
--8610 8562 -8570 8592 -8510 8621 -8480 8651 -8430 8680 -8410 8710 -8390 8739
--8370 8768 -8340 8797 -8320 8825 -8310 8854 -8290 8881 -8270 8908 -8270 8935
--8260 8960 -8260 8986 -8250 9011 -8260 9037 -8270 9060 -8280 9082 -8280 9102
--8300 9124 -8300 9146 -8350 9169 -8360 9189 -8330 9209 -8320 9226 -8340 9244
--8330 9262 -8340 9278 -8340 9295 -8360 9310 -8370 9326 -8380 9341 -8380 9354
--8400 9369 -8400 9381 -8410 9394 -8420 9407 -8430 9419 -8440 9430 -8440 9442
--8460 9451 -8460 9463 -8470 9472 -8470 9483 -8480 9491 -8490 9501 -8490 9510
--8500 9518 -8510 9526 -8510 9535 -8530 9542 -8520 9550 -8540 9558 -8530 9564
--8550 9572 -8550 9578 -8550 9585 -8560 9592 -8560 9598 -8560 9603 -8580 9610
--8580 9615 -8570 9622 -8590 9626 -8590 9632 -8590 9637 -8600 9642 -8600 9647
--8610 9651 -8610 9657 -8620 9660 -8620 9665 -8620 9669 -8620 9673 -8630 9677
--8630 9681 -8630 9684 -8640 9688
-243: 15650130 -4338211 -10260 9936 -10260 9939 -10260 9938 -10280 9940
--10280 9941 -10270 9942 -10270 9942 -10290 9942 -10280 9945 -10300 9946
--10300 9947 -10300 9949 -10310 9950 -10310 9954 -10330 9954 -10320 9954
--10340 9959 -10340 9958 -10350 9958 -10350 9959 -10360 9963 -10370 9964
--10370 9966 -10390 9965 -10380 9967 -10400 9969 -10400 9972 -10410 9971
--10410 9972 -10420 9975 -10430 9976 -10430 9978 -10440 9980 -10440 9979
--10450 9981 -10450 9982 -10450 9985 -10470 9987 -10470 9989 -10480 9991
--10480 9994 -10490 9997 -10490 10000 -10510 10002 -10500 10002 -10520 10006
--10510 10011 -10530 10014 -10530 10017 -10530 10018 -10550 10022 -10560 10025
--10550 10029 -10580 10031 -10580 10031 -10590 10036 -10590 10040 -10600 10042
--10610 10044 -10620 10045 -10630 10046 -10630 10047 -10650 10051 -10640 10051
--10650 10052 -10660 10051 -10660 10054 -10670 10051 -10680 10052 -10680 10053
--10690 10052 -10690 10050 -10700 10049 -10690 10048 -10710 10050 -10700 10046
--10700 10044 -10710 10043 -10710 10042 -10710 10042 -10710 10042 -10710 10040
--10720 10039 -10710 10040 -10720 10040 -10720 10041 -10720 10042 -10720 10043
--10720 10044 -10720 10046 -10730 10048 -10720 10051 -10720 10055 -10730 10056
--10730 10062 -10730 10065 -10740 10069 -10740 10073 -10750 10080 -10750 10085
--10750 10091 -10760 10096 -10760 10102 -10770 10107 -10770 10111 -10780 10118
--10780 10122 -10790 10128 -10790 10135 -10810 10139 -10800 10142 -10820 10147
--10820 10150 -10820 10153 -10830 10157 -10820 10158 -10820 10161 -10820 10161
--10830 10163 -10840 10164 -10830 10165 -10820 10163 -10820 10162 -10820 10161
--10810 10158 -10800 10156 -10780 10153 -10780 10151 -10770 10145 -10750 10141
--10740 10137 -10730 10133 -10710 10129 -10680 10125 -10670 10118 -10660 10112
--10630 10108 -10610 10100 -10580 10095 -10550 10091 -10540 10085 -10500 10078
--10480 10074 -10450 10069 -10430 10062 -10400 10056 -10380 10052 -10340 10047
--10320 10043 -10290 10039 -10270 10035 -10250 10029 -10220 10025 -10200 10020
--10180 10016 -10150 10014 -10150 10009 -10120 10003 -10120 10000 -10100 9996
--10100 9993 -10080 9988 -10090 9987 -10080 9981 -10080 9978 -10080 9973
--10080 9968 -10100 9964 -10100 9959 -10110 9954 -10130 9950 -10150 9943
--10180 9938 -10200 9934 -10220 9927 -10250 9920 -10280 9915 -10310 9909
--10340 9900 -10370 9895 -10410 9888 -10450 9882 -10470 9875 -10510 9867
--10550 9861 -10580 9854 -10620 9848 -10650 9843 -10670 9837 -10710 9831
--10740 9824 -10760 9820 -10770 9816 -10790 9813 -10800 9810 -10800 9806
--10810 9804 -10820 9801 -10800 9802 -10780 9802 -10760 9804 -10740 9805
--10700 9808 -10660 9811 -10610 9816 -10540 9821 -10490 9827 -10400 9835
--10330 9844 -10240 9852 -10130 9863 -10030 9876 -9900 9885 -9790 9899
--9650 9914 -9500 9929 -9350 9944 -9200 9959 -9030 9977 -8850 9995 -8660 10015
--8480 10033 -8270 10053 -8080 10072 -7860 10093 -7640 10114 -7420 10134
--7200 10156 -6960 10177 -6740 10198 -6490 10219 -6250 10240 -6010 10262
--5760 10282 -5520 10302 -5280 10322 -5050 10342 -4800 10359 -4560 10379
--4330 10396 -4100 10413 -3880 10429 -3640 10445 -3420 10459 -3220 10475
--3010 10487 -2820 10501 -2630 10512 -2450 10523 -2290 10533 -2120 10543
--1980 10552 -1830 10560 -1710 10568 -1580 10574 -1480 10580 -1380 10585
--1310 10588 -1230 10591 -1170 10593 -1140 10594 -1080 10595 -1070 10592
--1050 10590 -1060 10585 -1070 10579 -1100 10570 -1130 10561 -1170 10550
--1240 10537 -1310 10521 -1370 10503 -1470 10484 -1570 10460 -1670 10435
--1770 10409 -1900 10379 -2040 10348 -2150 10313 -2290 10275 -2430 10236
--2590 10197 -2740 10154 -2890 10110 -3070 10063 -3220 10013 -3400 9964
--3560 9913 -3720 9864 -3910 9809 -4080 9754 -4270 9700 -4440 9643 -4590 9589
--4780 9534 -4970 9481 -5160 9426 -5330 9373 -5520 9322 -5690 9271 -5880 9224
--6080 9175 -6260 9130 -6460 9086 -6640 9045 -6830 9007 -7000 8973 -7190 8940
--7360 8911 -7560 8884 -7730 8861 -7920 8840 -8090 8824 -8260 8810 -8440 8800
--8590 8794 -8760 8790 -8930 8790 -9080 8793 -9230 8799 -9380 8810 -9520 8823
--9670 8838 -9800 8856 -9940 8875 -10060 8900 -10180 8927 -10290 8956 -10400 8985
--10500 9015 -10600 9050 -10700 9085 -10780 9122 -10880 9160 -10950 9199
--11030 9237 -11100 9277 -11170 9317 -11240 9357 -11300 9397 -11360 9436
--11410 9475 -11450 9513 -11500 9550 -11540 9587 -11590 9622 -11640 9654
--11670 9687 -11710 9718 -11760 9747 -11800 9775 -11840 9799 -11880 9823
--11910 9847 -11970 9869 -12020 9888 -12080 9905 -12150 9919 -12210 9932
--12270 9942 -12330 9952 -12410 9959 -12470 9965 -12540 9970 -12620 9972
--12690 9973 -12770 9972 -12870 9969 -12950 9966 -13030 9960 -13140 9951
--13210 9943 -13310 9931 -13410 9918 -13500 9904 -13570 9887 -13670 9869
--13770 9850 -13840 9828 -13920 9805 -14000 9779 -14080 9754 -14150 9726
--14210 9696 -14280 9664 -14320 9633 -14370 9599 -14420 9564 -14450 9527
--14480 9488 -14510 9449 -14520 9410 -14510 9368 -14510 9326 -14490 9283
--14490 9240 -14460 9195 -14430 9151 -14390 9105 -14330 9061 -14280 9015
--14220 8969 -14150 8925 -14080 8879 -13980 8835 -13880 8792 -13780 8748
--13690 8706 -13580 8666 -13480 8628 -13360 8591 -13200 8554 -13090 8522
--12970 8486 -12830 8454 -12670 8423 -12520 8396 -12360 8370 -12220 8348
--12050 8329 -11890 8311 -11740 8295 -11590 8283 -11440 8273 -11290 8264
--11130 8259 -10980 8256 -10830 8255 -10690 8256 -10530 8259 -10400 8265
--10250 8273 -10130 8282 -10000 8294 -9870 8307 -9750 8322 -9640 8338 -9530 8357
--9420 8376 -9320 8396 -9240 8418 -9140 8441 -9060 8464 -8990 8489 -8930 8514
--8850 8540 -8790 8567 -8730 8592 -8680 8620 -8640 8648 -8580 8674 -8550 8702
--8510 8730 -8480 8757 -8460 8784 -8430 8812 -8410 8838 -8390 8864 -8370 8891
--8360 8917 -8350 8943 -8330 8966 -8320 8992 -8320 9015 -8310 9039 -8310 9063
--8330 9085 -8320 9105 -8340 9125 -8340 9145 -8350 9166 -8410 9188 -8400 9207
--8380 9225 -8370 9242 -8370 9259 -8380 9276 -8380 9291 -8380 9307 -8400 9322
--8400 9336 -8410 9351 -8420 9364 -8430 9378 -8430 9389 -8450 9402 -8440 9414
--8460 9425 -8460 9437 -8470 9447 -8480 9457 -8490 9467 -8490 9477 -8490 9487
--8510 9495 -8510 9505 -8510 9512 -8520 9521 -8520 9530 -8530 9537 -8540 9544
--8540 9552 -8560 9559 -8560 9566 -8550 9573 -8570 9580 -8560 9586 -8570 9592
--8580 9599 -8570 9604 -8590 9610 -8590 9616 -8590 9621 -8600 9627 -8600 9631
--8610 9637 -8610 9642 -8610 9647 -8620 9651 -8620 9655 -8620 9660 -8630 9665
--8630 9668 -8640 9672 -8630 9677 -8650 9679 -8640 9683 -8640 9687
-244: 15683790 -4329895 -10260 9937 -10260 9937 -10260 9937 -10270 9939
--10270 9940 -10270 9942 -10280 9942 -10280 9943 -10280 9943 -10290 9948
--10300 9946 -10300 9948 -10310 9951 -10310 9953 -10320 9952 -10330 9954
--10330 9957 -10330 9958 -10350 9958 -10350 9960 -10360 9963 -10370 9963
--10370 9965 -10380 9963 -10380 9966 -10390 9969 -10390 9970 -10410 9970
--10400 9973 -10420 9973 -10420 9976 -10430 9977 -10440 9979 -10440 9979
--10440 9980 -10440 9982 -10460 9984 -10460 9986 -10460 9987 -10470 9989
--10480 9993 -10480 9995 -10490 9998 -10500 10000 -10500 10001 -10500 10005
--10520 10010 -10510 10010 -10520 10015 -10540 10016 -10530 10021 -10550 10023
--10550 10025 -10570 10028 -10570 10031 -10580 10032 -10580 10038 -10600 10040
--10600 10041 -10610 10043 -10620 10044 -10620 10046 -10630 10047 -10640 10049
--10640 10049 -10650 10050 -10650 10051 -10660 10051 -10660 10049 -10680 10051
--10680 10050 -10680 10048 -10680 10047 -10700 10048 -10690 10047 -10690 10044
--10690 10042 -10700 10042 -10690 10041 -10700 10040 -10710 10040 -10700 10038
--10700 10039 -10710 10038 -10710 10038 -10710 10039 -10700 10040 -10710 10041
--10710 10042 -10720 10042 -10710 10044 -10710 10048 -10710 10050 -10710 10055
--10720 10057 -10720 10062 -10730 10066 -10720 10069 -10740 10075 -10730 10080
--10740 10086 -10740 10092 -10750 10097 -10760 10102 -10750 10104 -10760 10112
--10770 10117 -10770 10124 -10770 10128 -10790 10132 -10780 10136 -10800 10140
--10800 10143 -10800 10148 -10800 10151 -10800 10152 -10800 10154 -10810 10156
--10800 10158 -10820 10158 -10800 10159 -10810 10157 -10800 10156 -10790 10157
--10790 10153 -10780 10152 -10770 10149 -10760 10147 -10750 10141 -10730 10138
--10720 10135 -10710 10130 -10690 10127 -10680 10122 -10650 10115 -10640 10111
--10620 10106 -10590 10099 -10570 10096 -10540 10089 -10520 10085 -10500 10080
--10470 10074 -10440 10069 -10420 10062 -10390 10058 -10360 10054 -10340 10048
--10310 10042 -10290 10039 -10260 10036 -10240 10030 -10210 10027 -10190 10021
--10170 10018 -10150 10014 -10130 10009 -10120 10006 -10100 10001 -10090 9997
--10070 9993 -10070 9990 -10070 9986 -10060 9982 -10050 9978 -10070 9973
--10060 9968 -10060 9964 -10080 9959 -10090 9954 -10090 9949 -10120 9942
--10140 9937 -10170 9932 -10180 9926 -10200 9921 -10240 9913 -10270 9906
--10290 9899 -10330 9892 -10360 9886 -10390 9880 -10430 9872 -10460 9865
--10500 9858 -10530 9851 -10570 9845 -10590 9840 -10620 9833 -10660 9827
--10680 9821 -10710 9815 -10730 9811 -10740 9807 -10760 9804 -10760 9801
--10780 9798 -10780 9795 -10770 9794 -10750 9794 -10740 9796 -10720 9796
--10700 9798 -10650 9801 -10600 9804 -10560 9809 -10500 9814 -10430 9821
--10360 9828 -10270 9836 -10180 9846 -10080 9856 -9970 9866 -9860 9879
--9730 9891 -9600 9905 -9460 9918 -9320 9933 -9160 9949 -8990 9965 -8810 9983
--8640 10000 -8450 10018 -8260 10036 -8060 10055 -7860 10074 -7640 10095
--7430 10113 -7220 10133 -7000 10153 -6770 10171 -6540 10192 -6300 10212
--6070 10231 -5850 10250 -5610 10269 -5390 10286 -5160 10305 -4920 10322
--4710 10339 -4490 10356 -4260 10370 -4050 10388 -3840 10401 -3640 10416
--3440 10428 -3250 10442 -3080 10453 -2890 10464 -2740 10474 -2580 10485
--2430 10494 -2300 10502 -2170 10510 -2040 10518 -1950 10523 -1850 10530
--1760 10533 -1690 10536 -1630 10539 -1590 10540 -1530 10542 -1510 10541
--1500 10539 -1490 10533 -1500 10529 -1510 10521 -1540 10514 -1590 10502
--1630 10491 -1680 10476 -1770 10458 -1840 10439 -1930 10419 -2010 10397
--2130 10371 -2220 10342 -2340 10314 -2470 10279 -2590 10244 -2710 10207
--2860 10170 -3000 10129 -3150 10086 -3300 10042 -3460 9995 -3610 9948
--3770 9901 -3930 9851 -4100 9800 -4260 9749 -4440 9695 -4590 9642 -4750 9589
--4900 9538 -5100 9487 -5260 9434 -5450 9383 -5610 9333 -5800 9285 -5970 9239
--6160 9191 -6330 9148 -6520 9106 -6700 9066 -6880 9029 -7040 8995 -7220 8963
--7390 8935 -7560 8907 -7740 8883 -7900 8864 -8080 8846 -8260 8832 -8400 8822
--8550 8814 -8720 8809 -8870 8808 -9020 8809 -9170 8814 -9310 8823 -9430 8834
--9580 8846 -9710 8862 -9830 8880 -9950 8902 -10060 8926 -10160 8953 -10280 8978
--10370 9006 -10460 9038 -10540 9071 -10630 9105 -10720 9140 -10790 9177
--10850 9211 -10930 9248 -10990 9287 -11060 9323 -11100 9362 -11160 9398
--11220 9435 -11250 9471 -11290 9506 -11340 9541 -11370 9574 -11410 9607
--11450 9637 -11500 9667 -11520 9696 -11560 9721 -11600 9747 -11640 9772
--11660 9802 -11700 9824 -11760 9842 -11820 9857 -11870 9871 -11940 9884
--11990 9894 -12050 9905 -12110 9912 -12190 9920 -12250 9925 -12320 9929
--12390 9931 -12470 9932 -12550 9931 -12620 9929 -12710 9925 -12790 9920
--12890 9912 -12960 9902 -13060 9892 -13140 9881 -13220 9866 -13320 9851
--13390 9833 -13470 9815 -13550 9794 -13630 9772 -13700 9749 -13780 9724
--13820 9697 -13880 9668 -13950 9640 -13990 9610 -14040 9577 -14070 9543
--14090 9509 -14140 9472 -14140 9436 -14150 9397 -14140 9360 -14130 9319
--14120 9279 -14110 9238 -14090 9197 -14050 9154 -14000 9113 -13960 9071
--13900 9028 -13850 8986 -13770 8944 -13690 8903 -13610 8861 -13510 8821
--13420 8782 -13340 8744 -13230 8708 -13120 8673 -12990 8638 -12880 8608
--12780 8576 -12640 8544 -12500 8515 -12360 8488 -12210 8464 -12070 8442
--11930 8423 -11770 8406 -11650 8391 -11490 8378 -11360 8368 -11210 8360
--11070 8353 -10920 8350 -10790 8348 -10650 8348 -10510 8351 -10380 8355
--10240 8362 -10130 8370 -10010 8379 -9890 8392 -9770 8404 -9670 8419 -9550 8436
--9460 8453 -9360 8471 -9270 8491 -9200 8512 -9120 8533 -9050 8556 -8970 8579
--8920 8603 -8850 8626 -8790 8652 -8750 8676 -8700 8701 -8650 8727 -8610 8752
--8580 8778 -8550 8803 -8520 8828 -8500 8854 -8480 8879 -8460 8903 -8430 8928
--8420 8952 -8410 8976 -8390 8999 -8380 9021 -8370 9044 -8380 9067 -8360 9088
--8380 9110 -8380 9129 -8380 9147 -8400 9167 -8390 9185 -8450 9207 -8450 9225
--8430 9242 -8420 9258 -8410 9274 -8410 9290 -8420 9304 -8430 9319 -8430 9334
--8440 9347 -8440 9361 -8450 9374 -8460 9386 -8460 9398 -8470 9410 -8480 9421
--8490 9432 -8490 9443 -8490 9453 -8510 9462 -8510 9473 -8510 9481 -8520 9491
--8520 9500 -8530 9508 -8530 9516 -8540 9524 -8540 9532 -8550 9540 -8560 9547
--8560 9554 -8570 9561 -8570 9567 -8570 9575 -8580 9581 -8580 9587 -8580 9593
--8600 9599 -8590 9605 -8600 9611 -8600 9616 -8600 9621 -8620 9627 -8610 9632
--8610 9637 -8610 9641 -8630 9646 -8630 9651 -8640 9656 -8620 9659 -8640 9664
--8650 9667 -8640 9672 -8650 9675 -8650 9679 -8660 9682 -8650 9686
-245: 15717470 -4321580 -10260 9936 -10260 9936 -10270 9935 -10260 9938
--10260 9941 -10280 9940 -10270 9942 -10280 9943 -10280 9945 -10290 9946
--10300 9946 -10300 9948 -10310 9951 -10300 9952 -10320 9951 -10320 9953
--10330 9958 -10340 9956 -10330 9959 -10350 9960 -10360 9962 -10370 9961
--10360 9964 -10380 9963 -10370 9966 -10390 9968 -10390 9969 -10400 9969
--10400 9972 -10410 9973 -10420 9976 -10420 9976 -10440 9979 -10430 9978
--10440 9978 -10440 9981 -10450 9984 -10450 9983 -10460 9986 -10470 9988
--10470 9992 -10470 9993 -10490 9995 -10490 9997 -10490 10001 -10500 10004
--10500 10007 -10510 10009 -10520 10012 -10520 10015 -10530 10018 -10540 10020
--10550 10023 -10560 10026 -10560 10029 -10570 10031 -10580 10035 -10580 10036
--10600 10039 -10600 10041 -10600 10042 -10620 10044 -10620 10045 -10630 10047
--10630 10047 -10630 10047 -10650 10049 -10650 10049 -10660 10048 -10660 10048
--10660 10047 -10670 10047 -10680 10047 -10680 10046 -10690 10044 -10680 10043
--10680 10041 -10680 10040 -10690 10040 -10690 10038 -10690 10037 -10700 10037
--10690 10038 -10690 10037 -10700 10036 -10700 10038 -10700 10036 -10700 10039
--10700 10039 -10700 10040 -10700 10042 -10700 10044 -10700 10047 -10700 10051
--10700 10055 -10710 10057 -10720 10063 -10710 10064 -10720 10071 -10720 10076
--10730 10081 -10720 10088 -10730 10091 -10740 10095 -10750 10100 -10740 10106
--10750 10113 -10750 10118 -10760 10122 -10760 10125 -10770 10129 -10770 10133
--10780 10138 -10780 10142 -10780 10145 -10780 10146 -10780 10148 -10780 10150
--10790 10152 -10790 10153 -10790 10152 -10780 10151 -10780 10151 -10770 10150
--10780 10151 -10760 10146 -10740 10145 -10740 10143 -10730 10138 -10720 10134
--10700 10131 -10690 10128 -10680 10124 -10660 10119 -10640 10113 -10620 10110
--10610 10103 -10580 10099 -10560 10094 -10530 10089 -10510 10084 -10480 10080
--10470 10074 -10430 10068 -10400 10063 -10390 10058 -10350 10055 -10340 10049
--10290 10044 -10280 10039 -10260 10036 -10230 10031 -10210 10028 -10180 10023
--10150 10018 -10150 10015 -10120 10009 -10100 10008 -10100 10002 -10070 9999
--10060 9996 -10050 9990 -10050 9986 -10040 9982 -10040 9978 -10040 9974
--10030 9969 -10050 9964 -10040 9959 -10060 9953 -10070 9948 -10090 9943
--10110 9937 -10130 9931 -10140 9925 -10160 9920 -10190 9912 -10220 9905
--10250 9898 -10280 9891 -10310 9884 -10340 9879 -10380 9870 -10410 9863
--10450 9856 -10470 9850 -10520 9843 -10530 9837 -10570 9830 -10600 9824
--10630 9818 -10660 9812 -10680 9808 -10690 9803 -10710 9800 -10730 9795
--10730 9794 -10730 9788 -10740 9789 -10730 9788 -10700 9787 -10700 9789
--10680 9789 -10640 9792 -10600 9794 -10560 9798 -10500 9802 -10450 9808
--10380 9815 -10300 9822 -10220 9830 -10130 9839 -10030 9848 -9920 9858
--9810 9871 -9680 9882 -9560 9895 -9420 9908 -9270 9922 -9120 9937 -8950 9954
--8790 9969 -8610 9986 -8440 10001 -8250 10020 -8060 10037 -7860 10055
--7650 10074 -7450 10091 -7250 10108 -7020 10127 -6820 10146 -6590 10164
--6370 10183 -6160 10200 -5920 10217 -5700 10233 -5500 10252 -5270 10268
--5070 10285 -4850 10300 -4640 10316 -4430 10331 -4240 10345 -4040 10359
--3850 10371 -3670 10383 -3510 10396 -3320 10406 -3170 10417 -3020 10428
--2880 10437 -2740 10445 -2620 10454 -2500 10461 -2390 10469 -2300 10474
--2210 10480 -2140 10481 -2070 10486 -2030 10487 -1980 10490 -1940 10489
--1920 10488 -1920 10484 -1910 10479 -1930 10473 -1950 10465 -1980 10456
--2020 10445 -2060 10430 -2140 10415 -2210 10397 -2280 10378 -2370 10356
--2460 10335 -2550 10306 -2650 10279 -2770 10248 -2880 10213 -3010 10178
--3130 10142 -3260 10104 -3400 10065 -3550 10022 -3690 9976 -3830 9933
--3980 9887 -4130 9840 -4290 9790 -4450 9743 -4610 9691 -4750 9640 -4900 9590
--5040 9544 -5220 9494 -5380 9443 -5560 9393 -5720 9345 -5890 9298 -6060 9254
--6240 9208 -6410 9166 -6590 9125 -6760 9087 -6920 9050 -7090 9017 -7250 8986
--7420 8957 -7580 8931 -7750 8906 -7900 8886 -8070 8869 -8230 8854 -8380 8843
--8530 8835 -8690 8829 -8820 8826 -8970 8826 -9100 8830 -9230 8836 -9370 8846
--9500 8855 -9620 8870 -9730 8886 -9850 8905 -9950 8927 -10050 8950 -10150 8974
--10230 8999 -10330 9029 -10410 9058 -10490 9091 -10560 9122 -10640 9156
--10700 9189 -10760 9223 -10820 9258 -10880 9293 -10930 9329 -10980 9364
--11020 9398 -11050 9431 -11100 9466 -11140 9498 -11170 9531 -11200 9561
--11240 9591 -11280 9619 -11310 9647 -11340 9673 -11370 9698 -11420 9722
--11410 9760 -11460 9782 -11510 9798 -11560 9812 -11620 9826 -11670 9838
--11730 9849 -11780 9858 -11850 9868 -11900 9876 -11970 9882 -12040 9887
--12100 9890 -12170 9893 -12240 9894 -12320 9894 -12400 9891 -12480 9886
--12560 9882 -12630 9875 -12720 9866 -12810 9856 -12880 9845 -12970 9832
--13040 9816 -13110 9801 -13190 9782 -13270 9763 -13340 9743 -13410 9721
--13460 9696 -13510 9672 -13580 9645 -13620 9617 -13670 9589 -13700 9558
--13730 9525 -13770 9494 -13790 9459 -13790 9425 -13780 9389 -13780 9352
--13780 9316 -13770 9277 -13760 9239 -13710 9200 -13680 9162 -13640 9122
--13600 9083 -13540 9043 -13490 9004 -13410 8966 -13330 8928 -13250 8889
--13170 8853 -13090 8817 -12990 8783 -12890 8751 -12780 8717 -12680 8690
--12570 8659 -12450 8629 -12320 8602 -12190 8575 -12060 8553 -11930 8532
--11790 8513 -11650 8496 -11540 8481 -11400 8469 -11270 8459 -11130 8449
--11000 8444 -10870 8440 -10740 8437 -10610 8436 -10490 8438 -10360 8442
--10230 8446 -10120 8454 -10010 8462 -9900 8472 -9790 8484 -9690 8497 -9570 8511
--9480 8528 -9400 8543 -9320 8562 -9240 8580 -9170 8600 -9090 8621 -9020 8641
--8970 8663 -8910 8686 -8860 8708 -8800 8730 -8760 8755 -8720 8777 -8670 8801
--8650 8825 -8610 8848 -8590 8872 -8560 8895 -8530 8918 -8520 8941 -8490 8964
--8470 8987 -8480 9009 -8450 9030 -8440 9051 -8430 9073 -8430 9094 -8430 9114
--8420 9134 -8430 9153 -8430 9169 -8450 9187 -8430 9206 -8500 9226 -8500 9244
--8470 9259 -8470 9274 -8450 9289 -8450 9303 -8450 9318 -8470 9332 -8470 9345
--8470 9358 -8470 9371 -8480 9384 -8490 9395 -8500 9407 -8500 9417 -8510 9429
--8510 9439 -8510 9449 -8530 9459 -8520 9468 -8530 9478 -8540 9486 -8540 9495
--8550 9504 -8540 9512 -8560 9519 -8550 9528 -8570 9535 -8570 9542 -8570 9549
--8580 9556 -8580 9563 -8580 9570 -8590 9576 -8590 9583 -8600 9588 -8600 9594
--8600 9600 -8610 9606 -8610 9611 -8610 9617 -8620 9622 -8620 9627 -8630 9632
--8620 9637 -8630 9641 -8640 9646 -8640 9650 -8640 9655 -8640 9659 -8650 9664
--8650 9667 -8660 9671 -8660 9674 -8660 9678 -8660 9681 -8660 9685
-246: 15751150 -4313269 -10260 9935 -10260 9936 -10260 9936 -10260 9938
--10270 9939 -10270 9939 -10270 9942 -10280 9944 -10280 9944 -10280 9945
--10300 9947 -10290 9947 -10310 9949 -10310 9952 -10310 9952 -10310 9952
--10330 9956 -10340 9956 -10330 9959 -10350 9959 -10350 9960 -10370 9962
--10360 9963 -10370 9962 -10370 9966 -10380 9965 -10390 9970 -10390 9969
--10400 9971 -10400 9971 -10420 9976 -10420 9976 -10430 9978 -10420 9976
--10440 9979 -10440 9980 -10440 9980 -10450 9984 -10450 9984 -10460 9986
--10470 9991 -10470 9993 -10480 9992 -10480 9994 -10490 10000 -10480 10002
--10500 10006 -10510 10008 -10510 10009 -10520 10013 -10520 10014 -10530 10019
--10540 10020 -10550 10024 -10550 10026 -10560 10030 -10570 10033 -10580 10032
--10590 10037 -10590 10039 -10600 10040 -10600 10041 -10610 10043 -10620 10045
--10620 10045 -10630 10045 -10630 10047 -10640 10048 -10650 10047 -10650 10046
--10650 10045 -10660 10046 -10670 10044 -10670 10044 -10670 10043 -10680 10042
--10670 10039 -10670 10038 -10680 10037 -10680 10037 -10680 10036 -10690 10036
--10680 10036 -10690 10034 -10680 10036 -10690 10035 -10690 10035 -10690 10035
--10690 10037 -10690 10038 -10690 10038 -10680 10043 -10690 10044 -10690 10048
--10700 10051 -10690 10053 -10700 10059 -10700 10061 -10700 10067 -10710 10071
--10710 10078 -10720 10081 -10710 10086 -10730 10089 -10720 10094 -10730 10102
--10730 10108 -10730 10111 -10740 10115 -10750 10120 -10740 10123 -10760 10126
--10750 10131 -10760 10137 -10760 10137 -10760 10142 -10760 10142 -10760 10145
--10770 10145 -10770 10146 -10770 10147 -10760 10146 -10760 10145 -10750 10144
--10750 10145 -10740 10144 -10720 10141 -10720 10138 -10720 10134 -10700 10130
--10690 10128 -10670 10125 -10660 10121 -10650 10116 -10630 10111 -10610 10106
--10580 10103 -10570 10098 -10550 10091 -10520 10088 -10500 10082 -10470 10080
--10460 10074 -10420 10068 -10400 10063 -10380 10058 -10350 10055 -10320 10049
--10300 10046 -10270 10040 -10240 10036 -10230 10033 -10210 10029 -10170 10023
--10150 10019 -10130 10015 -10110 10012 -10100 10008 -10080 10003 -10060 9999
--10050 9997 -10030 9991 -10030 9987 -10030 9983 -10020 9979 -10010 9974
--10020 9970 -10020 9965 -10020 9960 -10030 9953 -10040 9949 -10050 9942
--10070 9937 -10100 9931 -10100 9924 -10120 9920 -10150 9911 -10170 9905
--10210 9897 -10230 9891 -10260 9884 -10290 9876 -10330 9870 -10360 9861
--10390 9856 -10420 9849 -10450 9841 -10490 9836 -10510 9829 -10540 9821
--10580 9816 -10600 9811 -10620 9805 -10640 9800 -10660 9796 -10680 9791
--10690 9790 -10690 9785 -10690 9784 -10690 9782 -10680 9782 -10670 9781
--10650 9783 -10630 9783 -10590 9785 -10540 9789 -10510 9791 -10450 9797
--10400 9803 -10320 9808 -10250 9816 -10170 9823 -10070 9831 -9980 9842
--9880 9851 -9760 9862 -9640 9872 -9510 9885 -9380 9897 -9230 9911 -9090 9926
--8920 9940 -8770 9955 -8600 9969 -8430 9986 -8240 10002 -8060 10019 -7860 10035
--7680 10052 -7480 10066 -7270 10084 -7080 10102 -6860 10119 -6650 10136
--6450 10152 -6210 10169 -6000 10185 -5810 10201 -5590 10218 -5400 10233
--5200 10248 -5010 10261 -4800 10277 -4620 10290 -4430 10304 -4240 10316
--4070 10327 -3910 10340 -3740 10350 -3590 10362 -3440 10372 -3310 10381
--3180 10390 -3050 10398 -2930 10407 -2830 10414 -2740 10420 -2640 10425
--2580 10429 -2510 10432 -2450 10437 -2410 10438 -2370 10438 -2340 10437
--2330 10435 -2330 10431 -2330 10424 -2340 10419 -2370 10408 -2410 10400
--2450 10386 -2500 10373 -2560 10355 -2630 10338 -2710 10317 -2790 10296
--2870 10271 -2970 10245 -3070 10215 -3180 10183 -3290 10150 -3400 10116
--3530 10081 -3650 10042 -3790 10001 -3920 9959 -4060 9917 -4190 9874 -4330 9829
--4480 9783 -4630 9735 -4790 9688 -4920 9638 -5070 9591 -5170 9550 -5350 9501
--5500 9453 -5680 9403 -5840 9357 -5990 9312 -6160 9268 -6320 9225 -6490 9184
--6660 9144 -6820 9106 -6980 9072 -7140 9038 -7290 9008 -7440 8980 -7590 8953
--7770 8929 -7920 8910 -8070 8891 -8220 8877 -8360 8864 -8500 8856 -8640 8849
--8790 8844 -8920 8844 -9040 8846 -9180 8850 -9300 8858 -9430 8866 -9540 8879
--9640 8893 -9740 8909 -9840 8929 -9950 8949 -10030 8971 -10120 8995 -10200 9021
--10290 9048 -10350 9078 -10420 9108 -10500 9138 -10540 9169 -10610 9200
--10670 9233 -10710 9266 -10760 9300 -10810 9331 -10840 9364 -10870 9396
--10920 9428 -10940 9459 -10980 9489 -11000 9519 -11040 9548 -11070 9575
--11100 9601 -11140 9627 -11160 9653 -11200 9675 -11200 9716 -11230 9738
--11270 9753 -11330 9768 -11380 9781 -11420 9793 -11470 9804 -11530 9815
--11580 9824 -11640 9833 -11710 9841 -11750 9846 -11820 9851 -11890 9855
--11960 9857 -12020 9858 -12100 9857 -12170 9856 -12250 9851 -12320 9846
--12400 9840 -12480 9833 -12550 9823 -12630 9811 -12700 9800 -12780 9785
--12850 9770 -12920 9754 -12990 9735 -13060 9716 -13090 9695 -13160 9672
--13230 9649 -13260 9624 -13310 9597 -13350 9571 -13380 9541 -13420 9511
--13430 9480 -13450 9449 -13450 9417 -13440 9383 -13440 9348 -13440 9314
--13430 9278 -13400 9243 -13350 9207 -13330 9170 -13310 9133 -13260 9098
--13190 9061 -13140 9025 -13060 8989 -12990 8954 -12920 8919 -12850 8886
--12770 8855 -12660 8823 -12560 8792 -12460 8766 -12370 8737 -12250 8710
--12140 8683 -12020 8659 -11900 8637 -11780 8616 -11650 8599 -11540 8582
--11420 8568 -11300 8555 -11180 8545 -11060 8536 -10920 8530 -10810 8525
--10690 8523 -10570 8521 -10450 8521 -10330 8524 -10220 8529 -10110 8534
--10010 8541 -9900 8550 -9810 8560 -9700 8572 -9600 8585 -9510 8598 -9420 8614
--9350 8630 -9290 8646 -9210 8665 -9130 8683 -9070 8702 -9020 8722 -8970 8743
--8920 8763 -8850 8784 -8810 8805 -8770 8828 -8740 8848 -8710 8871 -8680 8892
--8640 8914 -8620 8935 -8590 8958 -8580 8978 -8550 9000 -8530 9021 -8530 9041
--8510 9062 -8490 9080 -8490 9101 -8490 9121 -8470 9140 -8480 9159 -8480 9175
--8480 9191 -8490 9208 -8480 9226 -8540 9246 -8550 9262 -8520 9276 -8510 9290
--8490 9304 -8490 9317 -8490 9331 -8500 9345 -8500 9357 -8500 9369 -8510 9382
--8520 9393 -8510 9404 -8530 9416 -8530 9425 -8530 9436 -8540 9446 -8540 9456
--8550 9465 -8550 9474 -8550 9483 -8550 9491 -8570 9500 -8570 9508 -8570 9515
--8570 9524 -8580 9531 -8580 9538 -8580 9545 -8590 9552 -8600 9558 -8600 9565
--8600 9572 -8600 9578 -8610 9583 -8600 9590 -8620 9596 -8610 9601 -8630 9606
--8630 9612 -8620 9618 -8630 9622 -8630 9627 -8640 9632 -8640 9637 -8640 9642
--8640 9646 -8650 9650 -8650 9655 -8660 9659 -8660 9662 -8660 9667 -8660 9670
--8670 9674 -8670 9677 -8670 9681 -8670 9683
-247: 15784840 -4304959 -10260 9935 -10260 9934 -10260 9936 -10260 9938
--10260 9938 -10270 9940 -10270 9941 -10270 9941 -10290 9943 -10280 9945
--10290 9947 -10290 9946 -10310 9949 -10300 9952 -10310 9952 -10310 9952
--10320 9954 -10340 9957 -10330 9957 -10350 9959 -10350 9959 -10350 9963
--10370 9962 -10360 9962 -10370 9966 -10380 9965 -10380 9967 -10390 9969
--10390 9970 -10400 9971 -10410 9974 -10420 9974 -10420 9977 -10420 9977
--10430 9978 -10430 9978 -10440 9979 -10440 9982 -10450 9983 -10460 9986
--10460 9988 -10460 9991 -10470 9991 -10470 9993 -10490 9997 -10480 10000
--10490 10004 -10500 10006 -10510 10008 -10510 10009 -10510 10013 -10530 10018
--10530 10017 -10540 10021 -10540 10024 -10560 10028 -10560 10030 -10570 10030
--10570 10036 -10590 10036 -10590 10038 -10600 10038 -10590 10040 -10600 10044
--10610 10043 -10630 10044 -10620 10045 -10630 10045 -10640 10046 -10640 10045
--10650 10044 -10650 10043 -10650 10042 -10660 10042 -10660 10041 -10660 10041
--10670 10038 -10660 10036 -10670 10036 -10670 10036 -10680 10035 -10670 10033
--10680 10034 -10670 10032 -10670 10034 -10680 10033 -10680 10033 -10680 10033
--10680 10035 -10670 10035 -10680 10036 -10680 10040 -10680 10042 -10670 10044
--10690 10048 -10680 10051 -10690 10055 -10680 10057 -10690 10062 -10700 10067
--10690 10073 -10700 10076 -10700 10081 -10710 10084 -10710 10089 -10710 10097
--10720 10101 -10710 10105 -10720 10110 -10720 10113 -10730 10116 -10730 10121
--10740 10125 -10740 10129 -10740 10132 -10740 10136 -10740 10136 -10740 10138
--10750 10140 -10750 10139 -10750 10142 -10740 10140 -10740 10140 -10730 10139
--10720 10139 -10720 10138 -10700 10136 -10710 10135 -10690 10129 -10690 10127
--10680 10124 -10650 10122 -10640 10116 -10640 10114 -10620 10109 -10590 10103
--10570 10101 -10550 10097 -10550 10090 -10510 10086 -10490 10081 -10460 10078
--10440 10073 -10430 10067 -10390 10064 -10360 10058 -10340 10055 -10320 10050
--10290 10046 -10270 10041 -10240 10036 -10220 10033 -10200 10030 -10170 10023
--10140 10020 -10120 10017 -10110 10013 -10080 10008 -10070 10005 -10050 10000
--10040 9997 -10020 9993 -10020 9989 -10000 9983 -10010 9980 -9990 9976
--9990 9970 -10000 9966 -9990 9960 -10010 9954 -10010 9949 -10020 9943
--10040 9937 -10050 9931 -10070 9925 -10080 9921 -10110 9911 -10130 9905
--10150 9897 -10190 9891 -10200 9883 -10250 9877 -10270 9869 -10300 9862
--10340 9855 -10370 9848 -10390 9841 -10420 9835 -10450 9828 -10490 9821
--10520 9815 -10540 9809 -10570 9804 -10590 9797 -10600 9794 -10630 9789
--10640 9787 -10640 9781 -10640 9780 -10650 9778 -10650 9777 -10640 9776
--10620 9776 -10600 9777 -10570 9777 -10530 9780 -10500 9783 -10450 9787
--10400 9792 -10340 9796 -10270 9802 -10200 9809 -10110 9817 -10030 9825
--9930 9834 -9830 9842 -9710 9853 -9600 9863 -9470 9874 -9350 9887 -9200 9899
--9050 9913 -8910 9926 -8750 9939 -8580 9954 -8420 9968 -8250 9984 -8070 9999
--7880 10013 -7700 10029 -7510 10043 -7320 10059 -7130 10076 -6910 10091
--6740 10106 -6470 10125 -6290 10141 -6100 10156 -5900 10169 -5730 10183
--5530 10198 -5350 10209 -5160 10224 -4980 10238 -4800 10251 -4630 10261
--4460 10274 -4300 10285 -4140 10297 -3990 10308 -3860 10317 -3720 10327
--3590 10336 -3470 10343 -3360 10352 -3250 10362 -3170 10367 -3070 10372
--2990 10376 -2940 10382 -2860 10385 -2830 10386 -2780 10388 -2760 10387
--2740 10386 -2730 10383 -2730 10378 -2740 10372 -2750 10363 -2780 10355
--2820 10343 -2860 10331 -2920 10314 -2970 10297 -3050 10279 -3120 10259
--3190 10237 -3290 10210 -3370 10183 -3470 10153 -3570 10122 -3670 10090
--3790 10057 -3910 10020 -4030 9983 -4150 9941 -4280 9901 -4400 9861 -4540 9818
--4680 9775 -4810 9730 -4960 9683 -5100 9637 -5220 9591 -5350 9553 -5490 9507
--5640 9461 -5810 9413 -5950 9369 -6090 9325 -6270 9283 -6420 9242 -6570 9200
--6730 9162 -6870 9126 -7040 9093 -7190 9060 -7330 9029 -7470 9003 -7630 8975
--7770 8952 -7940 8933 -8070 8914 -8210 8899 -8350 8886 -8480 8877 -8620 8869
--8750 8863 -8870 8861 -8990 8862 -9130 8866 -9240 8871 -9350 8878 -9460 8889
--9560 8900 -9650 8915 -9750 8932 -9850 8951 -9920 8970 -10010 8991 -10090 9016
--10160 9040 -10230 9067 -10290 9095 -10360 9123 -10400 9151 -10460 9180
--10510 9211 -10560 9241 -10600 9273 -10650 9302 -10660 9333 -10700 9363
--10740 9393 -10770 9423 -10790 9452 -10820 9480 -10850 9507 -10880 9533
--10910 9559 -10940 9585 -10960 9608 -10990 9630 -10990 9667 -11020 9689
--11050 9705 -11110 9721 -11150 9735 -11190 9748 -11240 9760 -11270 9771
--11330 9781 -11390 9792 -11440 9799 -11500 9807 -11550 9813 -11610 9817
--11680 9821 -11740 9823 -11800 9824 -11880 9824 -11960 9821 -12020 9819
--12090 9813 -12160 9808 -12220 9801 -12300 9792 -12380 9782 -12450 9769
--12520 9757 -12580 9743 -12650 9727 -12720 9710 -12760 9692 -12810 9671
--12880 9651 -12930 9629 -12960 9605 -13010 9581 -13030 9555 -13070 9527
--13100 9499 -13110 9471 -13120 9442 -13110 9411 -13110 9379 -13110 9348
--13110 9315 -13090 9282 -13050 9249 -13040 9215 -13010 9182 -12970 9148
--12920 9114 -12860 9081 -12800 9048 -12740 9015 -12680 8982 -12610 8951
--12530 8922 -12450 8893 -12350 8864 -12250 8837 -12160 8810 -12040 8785
--11950 8761 -11840 8738 -11730 8717 -11630 8698 -11520 8681 -11410 8665
--11300 8650 -11190 8638 -11090 8628 -10970 8619 -10860 8613 -10740 8607
--10640 8604 -10520 8603 -10420 8602 -10300 8604 -10200 8607 -10100 8611
--10000 8618 -9910 8625 -9800 8635 -9710 8644 -9630 8656 -9520 8668 -9460 8681
--9390 8696 -9310 8711 -9250 8727 -9180 8745 -9110 8761 -9070 8780 -9020 8798
--8960 8817 -8920 8836 -8870 8856 -8820 8875 -8790 8896 -8770 8915 -8730 8935
--8690 8956 -8680 8976 -8650 8995 -8630 9015 -8610 9035 -8590 9055 -8590 9074
--8560 9092 -8550 9110 -8540 9129 -8540 9147 -8530 9166 -8530 9182 -8530 9199
--8540 9213 -8520 9228 -8530 9245 -8590 9266 -8600 9281 -8560 9293 -8540 9306
--8540 9318 -8530 9332 -8530 9345 -8530 9356 -8540 9369 -8530 9381 -8540 9392
--8540 9403 -8550 9414 -8560 9424 -8550 9434 -8560 9443 -8560 9453 -8570 9463
--8570 9471 -8570 9480 -8580 9488 -8580 9497 -8590 9504 -8590 9513 -8580 9519
--8600 9527 -8590 9535 -8600 9541 -8600 9548 -8610 9554 -8610 9562 -8610 9567
--8620 9574 -8620 9579 -8620 9586 -8620 9591 -8630 9597 -8630 9602 -8640 9608
--8640 9613 -8640 9618 -8640 9622 -8640 9628 -8650 9633 -8650 9637 -8650 9642
--8660 9646 -8660 9650 -8660 9654 -8670 9659 -8660 9662 -8680 9666 -8670 9670
--8670 9673 -8680 9676 -8680 9680 -8690 9683
-248: 15818540 -4296650 -10260 9934 -10260 9935 -10250 9935 -10260 9937
--10260 9938 -10270 9938 -10270 9940 -10270 9941 -10280 9943 -10280 9943
--10290 9946 -10300 9948 -10290 9947 -10300 9952 -10310 9951 -10310 9952
--10320 9954 -10330 9956 -10330 9955 -10340 9959 -10350 9959 -10350 9961
--10360 9962 -10370 9962 -10360 9966 -10380 9965 -10380 9967 -10380 9968
--10390 9968 -10390 9971 -10410 9974 -10400 9973 -10420 9974 -10420 9976
--10420 9976 -10430 9977 -10430 9979 -10440 9981 -10440 9982 -10450 9984
--10460 9985 -10460 9989 -10460 9990 -10460 9993 -10480 9994 -10490 9999
--10480 10001 -10490 10003 -10500 10006 -10500 10008 -10510 10011 -10520 10014
--10520 10015 -10530 10019 -10540 10022 -10550 10026 -10550 10027 -10560 10029
--10570 10033 -10570 10034 -10580 10036 -10590 10036 -10580 10038 -10600 10041
--10600 10042 -10610 10042 -10610 10044 -10630 10044 -10620 10042 -10640 10043
--10630 10042 -10640 10042 -10650 10040 -10650 10040 -10650 10040 -10650 10039
--10650 10036 -10660 10035 -10660 10035 -10660 10034 -10670 10033 -10660 10033
--10660 10032 -10660 10031 -10670 10031 -10670 10031 -10670 10031 -10660 10032
--10670 10031 -10660 10033 -10670 10035 -10670 10038 -10660 10038 -10670 10041
--10670 10045 -10670 10048 -10680 10051 -10670 10054 -10680 10059 -10680 10062
--10670 10068 -10690 10071 -10690 10075 -10680 10079 -10700 10086 -10700 10090
--10690 10094 -10700 10101 -10700 10103 -10700 10107 -10710 10109 -10720 10116
--10720 10119 -10720 10123 -10720 10125 -10710 10128 -10720 10130 -10730 10133
--10720 10133 -10730 10134 -10720 10136 -10730 10135 -10720 10135 -10700 10133
--10710 10134 -10700 10134 -10690 10129 -10680 10129 -10680 10126 -10670 10123
--10660 10121 -10640 10117 -10630 10113 -10620 10109 -10600 10105 -10580 10103
--10560 10099 -10540 10093 -10530 10089 -10500 10085 -10480 10080 -10460 10076
--10430 10072 -10410 10066 -10390 10063 -10370 10059 -10330 10054 -10320 10050
--10280 10046 -10250 10042 -10240 10037 -10210 10033 -10200 10029 -10170 10025
--10130 10022 -10110 10018 -10110 10013 -10070 10009 -10060 10007 -10030 10001
--10030 9998 -10010 9993 -10000 9989 -10000 9985 -9980 9982 -9990 9976
--9970 9971 -9970 9967 -9970 9961 -9970 9956 -9980 9950 -10000 9944 -10000 9938
--10020 9932 -10020 9926 -10040 9920 -10070 9913 -10090 9905 -10110 9898
--10130 9891 -10160 9885 -10190 9877 -10220 9871 -10240 9862 -10280 9855
--10310 9848 -10330 9841 -10360 9834 -10400 9829 -10420 9822 -10460 9814
--10490 9808 -10510 9803 -10520 9797 -10550 9793 -10570 9788 -10580 9783
--10590 9781 -10600 9777 -10600 9775 -10610 9773 -10600 9771 -10580 9772
--10570 9771 -10540 9771 -10520 9773 -10490 9776 -10440 9779 -10400 9781
--10350 9786 -10280 9791 -10220 9796 -10140 9803 -10060 9811 -9980 9817
--9890 9826 -9780 9834 -9660 9843 -9560 9853 -9440 9863 -9310 9875 -9170 9887
--9040 9899 -8890 9911 -8730 9923 -8580 9938 -8420 9951 -8260 9964 -8070 9977
--7920 9992 -7730 10005 -7550 10019 -7370 10035 -7180 10048 -7000 10062
--6740 10083 -6570 10097 -6400 10110 -6220 10122 -6040 10134 -5860 10149
--5690 10160 -5520 10173 -5330 10187 -5170 10199 -5000 10210 -4830 10220
--4680 10233 -4530 10244 -4390 10255 -4260 10264 -4120 10273 -4000 10284
--3880 10291 -3770 10299 -3660 10308 -3580 10315 -3490 10321 -3400 10325
--3350 10330 -3280 10334 -3230 10337 -3190 10337 -3170 10339 -3130 10338
--3130 10336 -3130 10330 -3120 10326 -3130 10319 -3150 10311 -3190 10301
--3220 10288 -3270 10274 -3310 10258 -3390 10241 -3440 10223 -3510 10201
--3590 10177 -3670 10151 -3760 10124 -3850 10095 -3950 10064 -4050 10033
--4160 9999 -4270 9963 -4380 9924 -4500 9886 -4620 9849 -4750 9807 -4870 9767
--5010 9724 -5140 9679 -5270 9634 -5380 9591 -5520 9553 -5660 9510 -5800 9466
--5930 9422 -6070 9380 -6210 9337 -6380 9297 -6510 9257 -6660 9217 -6800 9180
--6950 9146 -7100 9112 -7240 9081 -7380 9052 -7510 9024 -7660 8998 -7790 8975
--7930 8955 -8080 8937 -8210 8921 -8340 8908 -8470 8898 -8590 8889 -8720 8882
--8820 8879 -8950 8878 -9070 8881 -9180 8886 -9290 8890 -9380 8899 -9480 8909
--9580 8922 -9660 8937 -9750 8954 -9830 8970 -9900 8990 -9970 9011 -10050 9034
--10110 9058 -10170 9084 -10220 9109 -10270 9135 -10320 9163 -10370 9190
--10410 9219 -10450 9248 -10480 9276 -10510 9304 -10530 9332 -10570 9361
--10590 9389 -10620 9416 -10640 9444 -10660 9468 -10700 9494 -10710 9519
--10750 9544 -10770 9566 -10780 9586 -10810 9613 -10820 9635 -10870 9653
--10890 9670 -10930 9687 -10970 9702 -11000 9715 -11050 9727 -11080 9740
--11150 9749 -11180 9760 -11240 9767 -11290 9774 -11340 9781 -11410 9785
--11470 9788 -11530 9791 -11580 9793 -11660 9791 -11720 9791 -11790 9787
--11850 9784 -11920 9778 -11990 9772 -12060 9763 -12120 9754 -12200 9744
--12250 9731 -12320 9718 -12380 9703 -12440 9688 -12480 9670 -12530 9652
--12590 9633 -12630 9611 -12670 9590 -12700 9566 -12740 9542 -12770 9517
--12780 9492 -12790 9464 -12790 9437 -12790 9409 -12790 9379 -12800 9349
--12780 9320 -12760 9289 -12740 9259 -12720 9227 -12690 9196 -12640 9165
--12610 9135 -12540 9103 -12480 9073 -12430 9043 -12380 9013 -12310 8987
--12230 8960 -12150 8934 -12030 8905 -11940 8880 -11840 8857 -11750 8834
--11660 8815 -11560 8794 -11480 8776 -11370 8760 -11280 8744 -11180 8731
--11080 8718 -10990 8708 -10880 8700 -10780 8692 -10680 8688 -10590 8683
--10480 8681 -10370 8681 -10280 8681 -10180 8683 -10070 8688 -10000 8692
--9890 8699 -9810 8706 -9730 8715 -9640 8725 -9550 8736 -9480 8747 -9410 8761
--9350 8774 -9280 8789 -9220 8804 -9170 8820 -9100 8836 -9060 8852 -9020 8870
--8960 8887 -8930 8906 -8880 8923 -8850 8942 -8810 8959 -8790 8979 -8750 8996
--8730 9015 -8700 9034 -8690 9051 -8670 9070 -8650 9088 -8640 9106 -8610 9122
--8610 9140 -8590 9156 -8590 9174 -8580 9191 -8580 9207 -8580 9221 -8580 9235
--8580 9249 -8570 9265 -8650 9284 -8640 9298 -8610 9310 -8580 9321 -8570 9334
--8560 9346 -8570 9358 -8570 9370 -8570 9380 -8570 9392 -8560 9403 -8580 9413
--8570 9423 -8580 9433 -8590 9442 -8590 9452 -8580 9460 -8590 9469 -8600 9478
--8600 9486 -8590 9494 -8610 9502 -8610 9509 -8610 9517 -8600 9524 -8610 9531
--8610 9538 -8620 9544 -8620 9551 -8620 9558 -8630 9563 -8640 9570 -8620 9576
--8640 9582 -8640 9587 -8630 9593 -8640 9598 -8640 9604 -8650 9609 -8660 9613
--8650 9619 -8660 9624 -8650 9628 -8660 9633 -8660 9637 -8670 9642 -8660 9647
--8680 9650 -8670 9654 -8670 9658 -8680 9663 -8680 9665 -8680 9669 -8690 9673
--8680 9676 -8700 9679 -8690 9683
Deleted: grass/branches/releasebranch_7_2/lib/proj/conus.lla
--- grass/branches/releasebranch_7_2/lib/proj/conus.lla	2016-12-31 22:06:28 UTC (rev 70179)
+++ grass/branches/releasebranch_7_2/lib/proj/conus.lla	2016-12-31 22:26:38 UTC (rev 70180)
@@ -1,5558 +0,0 @@
-Conterminous United States
- 273 121   1  -131.00000      .25000    20.00000      .25000
-0: 3535506 864138 -29499 4060 -29489 4061 -29478 4059 -29472 4057 -29464 4054
--29462 4050 -29464 4044 -29466 4039 -29474 4032 -29483 4026 -29495 4019
--29508 4013 -29522 4008 -29538 4004 -29554 4001 -29563 4000 -29580 4001
--29590 4003 -29598 4006 -29606 4012 -29611 4018 -29614 4027 -29615 4034
--29615 4043 -29608 4052 -29604 4058 -29598 4065 -29589 4070 -29582 4072
--29576 4073 -29572 4068 -29566 4062 -29565 4052 -29566 4039 -29570 4022
--29576 4002 -29584 3978 -29594 3955 -29606 3927 -29615 3899 -29625 3872
--29631 3844 -29630 3820 -29624 3800 -29610 3783 -29584 3773 -29544 3769
--29493 3769 -29427 3774 -29346 3788 -29248 3811 -29136 3851 -29014 3903
--28876 3953 -28731 4007 -28578 4069 -28420 4135 -28265 4205 -28115 4276
--27970 4347 -27838 4416 -27720 4481 -27627 4539 -27554 4589 -27505 4630
--27484 4660 -27493 4675 -27532 4679 -27596 4669 -27688 4644 -27806 4606
--27946 4552 -28105 4487 -28277 4408 -28458 4319 -28645 4222 -28832 4117
--29012 4006 -29181 3894 -29335 3779 -29471 3666 -29583 3554 -29667 3450
--29723 3352 -29750 3262 -29746 3182 -29712 3113 -29646 3057 -29550 3015
--29428 2985 -29282 2970 -29112 2969 -28922 2982 -28717 3007 -28496 3048
--28266 3102 -28027 3165 -27782 3244 -27532 3331 -27279 3431 -27025 3543
--26770 3665 -26513 3793 -26253 3923 -25990 4058 -25733 4205 -25481 4373
--25198 4542 -24930 4717 -24661 4894 -24388 5070 -24116 5240 -23842 5413
--23573 5593 -23307 5769 -23051 5932 -22809 6075 -22589 6207 -22393 6332
--22228 6446 -22099 6543 -22014 6611 -21980 6650 -22000 6657 -22078 6631
--22220 6574 -22431 6484 -22712 6363 -23059 6204 -23476 6016 -23961 5792
--24509 5540 -25113 5259 -25767 4953 -26468 4628 -27203 4285 -27960 3932
--28735 3573 -29517 3210 -30295 2849 -31061 2500 -31803 2156 -32516 1833
--33190 1527 -33815 1241 -34384 987 -34891 756 -35328 559 -35690 398 -35969 273
--36164 184 -36268 131 -36282 121 -36199 159 -36018 242 -35743 366 -35374 512
--34906 681 -34333 883 -33678 1143 -32981 1479 -32150 1853 -31261 2237
--30307 2638 -29304 3055 -28252 3488 -27155 3938 -26023 4399 -24872 4869
--23716 5343 -22557 5817 -21409 6284 -20288 6736 -19209 7172 -18177 7590
--17201 7978 -16299 8323 -15486 8633 -14768 8907 -14155 9138 -13652 9312
--13281 9420 -13047 9461 -12958 9448 -13008 9380 -13208 9257 -13577 9067
--14109 8808 -14790 8481 -15620 8096 -16602 7661 -17734 7189 -18993 6695
--20354 6183 -21813 5665 -23348 5153 -24931 4655 -26540 4179 -28152 3733
--29760 3322 -31341 2947 -32871 2614 -34336 2322 -35716 2072 -37008 1865
--38193 1697 -39266 1567 -40222 1473 -41058 1414 -41777 1389 -42378 1391
--42860 1414 -43233 1455 -43497 1512 -43666 1589 -43766 1714 -43764 1836
--43679 1955 -43531 2078 -43318 2201 -43049 2331 -42745 2462 -42401 2594
--42027 2723 -41626 2857 -41205 2985 -40772 3110 -40332 3233 -39882 3352
--39433 3465 -38988 3574 -38548 3678 -38116 3775 -37698 3865 -37291 3955
--36900 4034 -36523 4111 -36164 4182 -35821 4247 -35498 4307 -35194 4364
--34907 4417 -34640 4463 -34390 4505 -34155 4544 -33942 4580 -33742 4610
--33561 4639 -33389 4664 -33240 4686 -33100 4705 -32973 4722 -32860 4738
--32761 4750 -32665 4761 -32585 4771 -32514 4779 -32448 4784 -32394 4790
--32346 4793 -32299 4799 -32262 4800 -32227 4802 -32203 4801 -32178 4802
--32158 4802 -32144 4802 -32129 4801 -32115 4801 -32104 4798 -32097 4796
--32090 4796
-1: 3556217 847418 -29462 4057 -29458 4056 -29453 4055 -29453 4052 -29455 4048
--29461 4044 -29470 4038 -29485 4031 -29503 4025 -29519 4018 -29541 4010
--29562 4002 -29586 3997 -29611 3991 -29633 3988 -29653 3986 -29674 3984
--29692 3985 -29703 3988 -29716 3993 -29724 3998 -29729 4004 -29730 4013
--29730 4019 -29725 4028 -29717 4035 -29706 4041 -29695 4046 -29685 4050
--29670 4050 -29658 4048 -29648 4043 -29638 4036 -29629 4024 -29625 4010
--29624 3994 -29623 3974 -29622 3951 -29625 3929 -29627 3905 -29631 3881
--29628 3858 -29622 3837 -29610 3819 -29593 3807 -29563 3800 -29522 3798
--29472 3800 -29406 3807 -29329 3820 -29234 3844 -29125 3882 -29013 3934
--28882 3981 -28748 4033 -28604 4092 -28458 4153 -28315 4218 -28175 4283
--28044 4348 -27922 4409 -27817 4467 -27735 4517 -27673 4559 -27633 4592
--27619 4613 -27635 4622 -27677 4618 -27743 4601 -27834 4570 -27949 4525
--28084 4467 -28234 4397 -28395 4317 -28561 4226 -28732 4128 -28898 4025
--29056 3917 -29200 3807 -29325 3699 -29430 3592 -29511 3490 -29559 3395
--29579 3308 -29568 3231 -29523 3166 -29447 3113 -29339 3074 -29201 3050
--29036 3040 -28844 3044 -28630 3064 -28396 3101 -28147 3149 -27883 3213
--27609 3290 -27329 3378 -27042 3481 -26753 3592 -26464 3716 -26173 3852
--25883 3997 -25597 4148 -25307 4300 -25019 4454 -24735 4616 -24464 4800
--24163 4995 -23885 5187 -23609 5376 -23334 5554 -23062 5730 -22796 5913
--22536 6099 -22287 6268 -22051 6417 -21838 6547 -21651 6675 -21493 6796
--21372 6899 -21293 6971 -21264 7010 -21292 7013 -21379 6986 -21528 6925
--21745 6832 -22037 6704 -22402 6540 -22834 6339 -23336 6100 -23909 5827
--24543 5525 -25231 5194 -25965 4837 -26740 4462 -27542 4077 -28360 3679
--29186 3281 -30009 2883 -30820 2495 -31606 2118 -32360 1759 -33073 1420
--33739 1105 -34345 818 -34888 561 -35359 339 -35754 154 -36068 9 -36293 -99
--36426 -166 -36469 -196 -36414 -177 -36263 -109 -36009 10 -35663 167 -35223 349
--34684 548 -34035 783 -33300 1075 -32536 1449 -31653 1864 -30703 2286
--29686 2723 -28619 3173 -27506 3638 -26350 4119 -25163 4611 -23964 5109
--22762 5611 -21560 6112 -20371 6600 -19214 7074 -18101 7536 -17041 7973
--16040 8369 -15116 8726 -14287 9053 -13558 9341 -12937 9577 -12434 9740
--12066 9831 -11848 9867 -11779 9853 -11858 9780 -12096 9634 -12515 9403
--13112 9094 -13865 8712 -14778 8273 -15860 7787 -17106 7263 -18487 6711
--19984 6136 -21586 5555 -23271 4980 -25004 4422 -26761 3896 -28522 3406
--30274 2956 -31997 2556 -33661 2200 -35250 1893 -36745 1632 -38138 1418
--39415 1250 -40563 1121 -41583 1032 -42469 981 -43228 967 -43855 984 -44354 1020
--44736 1074 -44996 1147 -45154 1242 -45234 1371 -45207 1508 -45099 1646
--44919 1787 -44673 1933 -44369 2079 -44024 2226 -43639 2374 -43221 2520
--42773 2664 -42309 2806 -41832 2944 -41345 3078 -40850 3207 -40356 3331
--39867 3448 -39384 3559 -38913 3666 -38451 3764 -38006 3859 -37575 3946
--37162 4029 -36765 4104 -36389 4177 -36034 4240 -35696 4303 -35380 4358
--35083 4410 -34803 4455 -34546 4497 -34306 4537 -34083 4570 -33878 4602
--33688 4629 -33516 4654 -33357 4675 -33215 4696 -33085 4711 -32965 4726
--32858 4739 -32763 4750 -32680 4762 -32602 4767 -32536 4775 -32476 4779
--32421 4784 -32374 4788 -32332 4791 -32297 4791 -32267 4793 -32242 4794
--32219 4794 -32199 4795 -32179 4794 -32168 4794 -32151 4793 -32142 4792
-2: 3576936 830696 -29430 4053 -29431 4051 -29435 4050 -29443 4047 -29452 4043
--29467 4038 -29486 4033 -29508 4025 -29536 4016 -29562 4009 -29591 4001
--29623 3992 -29654 3986 -29687 3979 -29716 3974 -29745 3971 -29772 3969
--29794 3968 -29812 3970 -29827 3972 -29837 3977 -29844 3984 -29847 3990
--29844 3996 -29838 4003 -29828 4011 -29814 4018 -29800 4023 -29781 4026
--29760 4028 -29742 4028 -29723 4024 -29706 4018 -29689 4010 -29675 3999
--29665 3984 -29654 3969 -29644 3950 -29638 3932 -29633 3910 -29629 3891
--29618 3872 -29605 3854 -29589 3841 -29567 3830 -29536 3828 -29492 3827
--29441 3833 -29378 3840 -29304 3855 -29213 3878 -29110 3914 -29001 3965
--28883 4010 -28756 4059 -28624 4114 -28490 4172 -28358 4231 -28231 4290
--28110 4348 -28002 4403 -27909 4451 -27838 4494 -27787 4530 -27754 4552
--27749 4567 -27772 4568 -27815 4556 -27885 4532 -27974 4494 -28086 4445
--28215 4382 -28355 4308 -28503 4225 -28657 4133 -28809 4035 -28955 3933
--29089 3828 -29207 3722 -29303 3618 -29379 3520 -29426 3427 -29439 3341
--29423 3267 -29372 3203 -29289 3151 -29172 3115 -29021 3093 -28840 3086
--28632 3097 -28397 3122 -28139 3163 -27862 3221 -27568 3293 -27262 3380
--26947 3481 -26624 3594 -26298 3720 -25971 3856 -25644 4003 -25319 4163
--24996 4333 -24678 4507 -24362 4680 -24048 4851 -23739 5032 -23447 5231
--23135 5449 -22846 5657 -22562 5853 -22283 6041 -22010 6232 -21750 6422
--21501 6600 -21267 6756 -21053 6899 -20866 7033 -20711 7165 -20592 7275
--20514 7354 -20485 7392 -20510 7397 -20600 7372 -20753 7316 -20974 7228
--21267 7102 -21639 6933 -22089 6729 -22607 6476 -23198 6188 -23859 5865
--24581 5507 -25354 5119 -26171 4714 -27022 4290 -27893 3856 -28771 3414
--29649 2975 -30515 2546 -31356 2124 -32163 1727 -32927 1346 -33641 993
--34294 670 -34883 380 -35396 127 -35830 -86 -36182 -260 -36446 -391 -36616 -478
--36688 -525 -36666 -526 -36546 -481 -36324 -381 -35999 -228 -35581 -34
--35072 181 -34465 413 -33741 681 -32928 1006 -32097 1418 -31166 1871 -30156 2332
--29077 2804 -27948 3288 -26778 3785 -25566 4297 -24327 4820 -23081 5345
--21834 5876 -20592 6402 -19363 6911 -18170 7413 -17027 7899 -15936 8345
--14908 8757 -13962 9136 -13114 9482 -12372 9778 -11739 10003 -11233 10156
--10866 10250 -10658 10300 -10605 10290 -10707 10197 -10979 10007 -11444 9725
--12101 9365 -12923 8943 -13918 8467 -15096 7938 -16454 7358 -17965 6738
--19599 6087 -21349 5432 -23188 4784 -25076 4167 -26986 3588 -28898 3056
--30799 2576 -32668 2149 -34470 1774 -36185 1452 -37798 1184 -39294 966
--40663 797 -41888 670 -42968 588 -43906 546 -44699 545 -45352 576 -45867 627
--46250 698 -46508 787 -46652 900 -46710 1038 -46658 1189 -46521 1347 -46311 1509
--46028 1672 -45684 1834 -45297 1999 -44871 2162 -44407 2322 -43914 2479
--43403 2634 -42880 2784 -42348 2930 -41808 3067 -41268 3201 -40735 3327
--40212 3448 -39697 3561 -39194 3667 -38710 3768 -38240 3863 -37790 3950
--37359 4031 -36946 4109 -36559 4179 -36191 4244 -35843 4303 -35517 4358
--35212 4408 -34927 4453 -34663 4495 -34417 4531 -34190 4566 -33978 4597
--33786 4624 -33609 4647 -33451 4669 -33302 4686 -33168 4704 -33046 4719
--32937 4731 -32839 4742 -32753 4752 -32676 4760 -32604 4766 -32538 4772
--32484 4776 -32434 4780 -32389 4782 -32354 4785 -32321 4786 -32292 4787
--32267 4788 -32241 4789 -32224 4789 -32206 4789 -32190 4790
-3: 3597662 813971 -29408 4048 -29413 4047 -29424 4045 -29438 4042 -29460 4038
--29480 4032 -29508 4026 -29539 4018 -29577 4009 -29613 4001 -29648 3991
--29690 3982 -29729 3975 -29767 3967 -29805 3961 -29840 3957 -29871 3952
--29900 3952 -29922 3951 -29936 3953 -29952 3957 -29960 3962 -29961 3967
--29958 3973 -29947 3980 -29936 3987 -29919 3994 -29899 3999 -29873 4003
--29847 4006 -29820 4007 -29793 4006 -29766 4001 -29740 3995 -29718 3988
--29697 3976 -29678 3963 -29659 3950 -29644 3933 -29627 3917 -29615 3902
--29599 3887 -29580 3872 -29559 3862 -29532 3855 -29498 3856 -29453 3858
--29401 3865 -29340 3876 -29269 3889 -29183 3913 -29084 3948 -28981 3995
--28874 4040 -28757 4086 -28636 4137 -28513 4189 -28393 4244 -28278 4296
--28170 4349 -28075 4395 -27994 4436 -27934 4471 -27893 4498 -27869 4514
--27871 4519 -27898 4513 -27947 4494 -28017 4462 -28105 4419 -28213 4363
--28335 4296 -28465 4220 -28602 4134 -28738 4041 -28873 3943 -28998 3842
--29108 3740 -29198 3639 -29268 3541 -29312 3450 -29324 3365 -29304 3292
--29250 3227 -29161 3178 -29039 3141 -28882 3119 -28688 3116 -28466 3127
--28215 3158 -27938 3202 -27636 3266 -27316 3345 -26981 3441 -26633 3551
--26277 3675 -25914 3813 -25549 3963 -25185 4123 -24822 4294 -24463 4477
--24109 4670 -23761 4869 -23419 5062 -23081 5253 -22747 5450 -22435 5665
--22116 5904 -21815 6124 -21524 6332 -21238 6536 -20966 6737 -20709 6926
--20472 7092 -20253 7244 -20059 7396 -19897 7541 -19774 7665 -19692 7750
--19656 7794 -19675 7802 -19754 7785 -19905 7740 -20125 7665 -20414 7547
--20784 7384 -21238 7176 -21772 6916 -22378 6616 -23059 6274 -23809 5895
--24622 5480 -25482 5041 -26383 4582 -27313 4106 -28254 3620 -29195 3135
--30125 2658 -31033 2190 -31904 1741 -32731 1316 -33504 916 -34216 552
--34857 221 -35424 -69 -35907 -319 -36303 -524 -36609 -688 -36821 -803
--36935 -866 -36946 -887 -36859 -865 -36673 -792 -36382 -659 -35988 -472
--35497 -240 -34922 9 -34248 277 -33454 574 -32567 935 -31670 1384 -30689 1876
--29623 2372 -28487 2880 -27300 3397 -26076 3926 -24813 4470 -23525 5021
--22235 5576 -20947 6135 -19664 6682 -18399 7220 -17171 7750 -15995 8249
--14875 8710 -13819 9145 -12848 9551 -11981 9911 -11221 10200 -10576 10417
--10058 10578 -9689 10698 -9485 10763 -9442 10738 -9561 10602 -9860 10359
--10366 10034 -11077 9648 -11963 9207 -13033 8701 -14307 8120 -15780 7467
--17422 6761 -19201 6020 -21100 5280 -23098 4561 -25146 3883 -27213 3256
--29280 2688 -31335 2180 -33352 1728 -35297 1337 -37146 1002 -38877 725
--40479 504 -41941 334 -43241 214 -44380 141 -45366 110 -46194 123 -46868 169
--47392 239 -47780 326 -48027 433 -48155 565 -48194 717 -48113 886 -47944 1062
--47697 1242 -47377 1421 -46992 1603 -46561 1782 -46090 1960 -45581 2134
--45043 2304 -44483 2472 -43915 2632 -43335 2789 -42750 2938 -42167 3079
--41592 3214 -41023 3343 -40465 3463 -39925 3576 -39400 3684 -38891 3785
--38407 3878 -37938 3964 -37494 4046 -37073 4120 -36673 4188 -36296 4253
--35942 4312 -35610 4364 -35301 4412 -35012 4457 -34742 4496 -34494 4532
--34261 4567 -34051 4596 -33854 4621 -33676 4644 -33515 4665 -33365 4682
--33230 4699 -33105 4714 -32996 4726 -32898 4737 -32808 4746 -32727 4753
--32653 4760 -32591 4765 -32533 4771 -32480 4773 -32434 4777 -32398 4779
--32360 4780 -32331 4782 -32302 4784 -32278 4785 -32260 4785 -32237 4787
-4: 3618392 797240 -29397 4043 -29403 4043 -29424 4040 -29447 4037 -29473 4032
--29503 4027 -29540 4020 -29581 4011 -29624 4002 -29668 3992 -29714 3982
--29763 3972 -29808 3964 -29855 3956 -29897 3948 -29938 3941 -29974 3938
--30008 3934 -30031 3933 -30048 3934 -30065 3937 -30073 3940 -30073 3944
--30069 3951 -30056 3957 -30040 3964 -30016 3969 -29992 3976 -29960 3981
--29925 3984 -29892 3986 -29856 3987 -29817 3985 -29784 3981 -29751 3976
--29719 3968 -29691 3959 -29664 3949 -29638 3936 -29614 3925 -29593 3913
--29569 3902 -29544 3891 -29516 3884 -29486 3881 -29449 3884 -29403 3890
--29350 3899 -29292 3910 -29223 3925 -29141 3949 -29049 3983 -28952 4026
--28853 4069 -28749 4113 -28639 4159 -28527 4206 -28418 4256 -28316 4303
--28222 4348 -28138 4387 -28071 4420 -28020 4447 -27990 4466 -27975 4473
--27983 4471 -28016 4457 -28068 4432 -28137 4392 -28224 4343 -28327 4283
--28441 4211 -28562 4131 -28683 4045 -28806 3950 -28920 3852 -29024 3754
--29110 3655 -29173 3559 -29213 3467 -29226 3384 -29205 3308 -29150 3245
--29059 3193 -28933 3157 -28772 3134 -28573 3130 -28341 3143 -28075 3173
--27784 3222 -27465 3289 -27121 3373 -26760 3475 -26384 3592 -25995 3726
--25600 3874 -25199 4036 -24797 4210 -24397 4392 -24000 4588 -23608 4793
--23223 5011 -22848 5232 -22482 5447 -22121 5658 -21766 5871 -21432 6101
--21106 6359 -20796 6590 -20496 6813 -20206 7032 -19933 7238 -19682 7420
--19453 7585 -19249 7749 -19075 7914 -18937 8054 -18842 8153 -18797 8205
--18802 8221 -18865 8218 -18999 8192 -19208 8136 -19492 8035 -19852 7880
--20295 7673 -20832 7410 -21450 7103 -22145 6749 -22916 6352 -23758 5915
--24662 5452 -25613 4956 -26600 4439 -27611 3908 -28625 3374 -29630 2846
--30613 2322 -31562 1818 -32463 1339 -33309 888 -34089 472 -34796 94 -35424 -241
--35966 -534 -36418 -781 -36773 -981 -37032 -1129 -37192 -1220 -37247 -1263
--37198 -1259 -37046 -1212 -36794 -1110 -36436 -943 -35971 -719 -35412 -452
--34770 -167 -34036 132 -33175 464 -32220 858 -31257 1347 -30230 1875 -29109 2409
--27920 2949 -26682 3499 -25408 4061 -24099 4634 -22769 5213 -21435 5800
--20110 6381 -18789 6953 -17487 7522 -16227 8074 -15021 8587 -13869 9069
--12785 9534 -11788 9961 -10898 10322 -10118 10607 -9456 10833 -8922 11028
--8544 11174 -8338 11230 -8300 11163 -8427 10977 -8742 10702 -9288 10369
--10039 9982 -10985 9525 -12131 8974 -13497 8317 -15084 7568 -16854 6760
--18776 5923 -20836 5098 -23001 4311 -25212 3579 -27441 2908 -29664 2306
--31877 1767 -34052 1295 -36147 884 -38130 536 -39982 253 -41690 29 -43241 -136
--44619 -250 -45817 -312 -46850 -328 -47710 -298 -48399 -233 -48931 -144
--49316 -38 -49551 88 -49661 239 -49675 413 -49565 600 -49362 794 -49076 990
--48713 1187 -48285 1384 -47811 1579 -47294 1771 -46738 1959 -46152 2143
--45549 2320 -44930 2493 -44305 2660 -43675 2816 -43047 2969 -42429 3110
--41817 3247 -41219 3375 -40637 3495 -40073 3609 -39530 3713 -39008 3812
--38504 3903 -38028 3989 -37574 4067 -37142 4139 -36738 4208 -36356 4268
--35996 4326 -35664 4375 -35352 4423 -35058 4465 -34787 4503 -34540 4539
--34305 4570 -34092 4598 -33898 4622 -33720 4644 -33555 4665 -33405 4682
--33269 4697 -33148 4711 -33039 4724 -32937 4733 -32847 4741 -32762 4749
--32691 4756 -32628 4760 -32568 4766 -32514 4770 -32470 4773 -32428 4776
--32391 4776 -32360 4779 -32331 4781 -32309 4782 -32283 4784
-5: 3639118 780502 -29394 4038 -29407 4038 -29433 4036 -29463 4032 -29497 4027
--29539 4021 -29582 4013 -29629 4005 -29680 3994 -29734 3984 -29788 3973
--29841 3963 -29895 3953 -29945 3944 -29993 3935 -30040 3927 -30078 3922
--30115 3918 -30141 3916 -30161 3915 -30176 3916 -30183 3919 -30182 3923
--30174 3928 -30158 3934 -30137 3940 -30111 3946 -30075 3953 -30038 3958
--29997 3963 -29953 3967 -29908 3968 -29862 3968 -29816 3969 -29775 3965
--29733 3961 -29692 3955 -29657 3948 -29623 3940 -29589 3933 -29558 3924
--29528 3918 -29496 3911 -29463 3908 -29428 3907 -29389 3914 -29342 3921
--29287 3932 -29230 3946 -29165 3962 -29089 3985 -29004 4017 -28913 4059
--28824 4098 -28729 4138 -28630 4181 -28530 4224 -28433 4267 -28345 4308
--28264 4345 -28192 4378 -28136 4404 -28097 4422 -28076 4432 -28069 4433
--28086 4422 -28121 4400 -28175 4368 -28246 4323 -28329 4268 -28426 4202
--28533 4128 -28642 4045 -28750 3955 -28854 3862 -28949 3765 -29030 3668
--29092 3574 -29129 3483 -29138 3398 -29121 3322 -29066 3256 -28976 3203
--28849 3164 -28686 3141 -28485 3134 -28247 3146 -27975 3176 -27670 3224
--27338 3293 -26978 3380 -26595 3486 -26192 3609 -25778 3749 -25351 3906
--24917 4076 -24480 4263 -24043 4460 -23609 4666 -23179 4884 -22758 5113
--22344 5353 -21942 5596 -21554 5833 -21172 6064 -20797 6295 -20446 6538
--20110 6810 -19791 7057 -19484 7296 -19191 7524 -18919 7729 -18672 7911
--18452 8093 -18261 8272 -18104 8433 -17989 8549 -17922 8615 -17910 8647
--17954 8662 -18061 8661 -18244 8634 -18510 8553 -18857 8412 -19284 8209
--19802 7947 -20418 7637 -21121 7279 -21906 6875 -22766 6427 -23702 5942
--24700 5420 -25744 4863 -26821 4288 -27915 3705 -29005 3119 -30075 2537
--31110 1970 -32100 1430 -33032 919 -33893 444 -34680 10 -35380 -380 -35992 -722
--36508 -1018 -36924 -1262 -37238 -1448 -37448 -1576 -37554 -1650 -37551 -1671
--37439 -1644 -37224 -1567 -36906 -1433 -36482 -1233 -35951 -973 -35324 -671
--34620 -348 -33826 -16 -32905 349 -31887 778 -30865 1305 -29790 1869 -28621 2437
--27382 3011 -26100 3591 -24783 4186 -23431 4787 -22062 5396 -20692 6009
--19332 6614 -17975 7214 -16641 7813 -15348 8378 -14112 8912 -12931 9425
--11817 9915 -10794 10352 -9878 10710 -9075 11006 -8388 11272 -7836 11503
--7444 11647 -7229 11664 -7186 11552 -7309 11343 -7647 11080 -8197 10770
--9003 10384 -10007 9887 -11208 9257 -12657 8499 -14348 7640 -16247 6727
--18334 5801 -20562 4899 -22888 4049 -25274 3263 -27662 2548 -30059 1907
--32438 1337 -34762 839 -37000 410 -39122 52 -41103 -236 -42925 -457 -44573 -617
--46024 -718 -47280 -766 -48352 -765 -49239 -716 -49942 -630 -50477 -518
--50855 -391 -51074 -245 -51159 -70 -51148 124 -51005 333 -50764 543 -50438 758
--50033 972 -49560 1184 -49039 1393 -48476 1598 -47874 1800 -47239 1996
--46589 2184 -45926 2367 -45254 2542 -44578 2710 -43906 2870 -43244 3020
--42592 3162 -41952 3296 -41331 3423 -40729 3541 -40151 3653 -39592 3754
--39057 3851 -38545 3938 -38059 4021 -37600 4097 -37168 4168 -36756 4232
--36374 4290 -36015 4345 -35679 4393 -35367 4439 -35072 4478 -34805 4515
--34554 4547 -34323 4578 -34112 4604 -33918 4626 -33738 4648 -33576 4667
--33428 4684 -33294 4698 -33171 4710 -33061 4722 -32961 4732 -32868 4740
--32788 4747 -32719 4754 -32652 4758 -32592 4763 -32540 4767 -32494 4771
--32449 4773 -32414 4774 -32382 4778 -32352 4779 -32329 4781
-6: 3659832 763755 -29401 4035 -29423 4033 -29452 4030 -29489 4028 -29533 4021
--29582 4016 -29633 4006 -29687 3998 -29745 3987 -29806 3976 -29868 3965
--29927 3953 -29986 3942 -30043 3932 -30092 3922 -30142 3914 -30185 3907
--30221 3902 -30251 3898 -30271 3896 -30283 3897 -30290 3898 -30285 3902
--30275 3906 -30253 3911 -30229 3917 -30194 3924 -30153 3931 -30108 3937
--30057 3942 -30005 3946 -29951 3951 -29893 3953 -29838 3955 -29786 3956
--29734 3954 -29685 3951 -29638 3949 -29593 3945 -29552 3941 -29513 3938
--29475 3934 -29435 3931 -29398 3932 -29358 3934 -29315 3943 -29267 3954
--29215 3966 -29157 3982 -29096 3998 -29026 4022 -28947 4052 -28863 4091
--28784 4126 -28698 4164 -28609 4202 -28523 4240 -28439 4277 -28362 4311
--28294 4342 -28235 4367 -28190 4385 -28163 4397 -28150 4398 -28153 4390
--28173 4373 -28213 4343 -28271 4305 -28339 4253 -28419 4193 -28510 4123
--28608 4046 -28705 3960 -28799 3870 -28883 3776 -28959 3681 -29018 3588
--29054 3496 -29063 3411 -29043 3333 -28992 3266 -28907 3209 -28782 3169
--28618 3141 -28418 3131 -28180 3140 -27903 3168 -27593 3216 -27248 3282
--26877 3370 -26479 3476 -26056 3604 -25616 3749 -25164 3911 -24701 4089
--24231 4284 -23759 4493 -23290 4714 -22823 4943 -22364 5182 -21914 5434
--21475 5695 -21048 5962 -20638 6219 -20239 6469 -19847 6717 -19479 6976
--19133 7259 -18807 7523 -18495 7776 -18199 8008 -17927 8213 -17685 8412
--17473 8611 -17295 8793 -17154 8932 -17058 9017 -17017 9067 -17036 9107
--17116 9139 -17263 9142 -17493 9088 -17813 8964 -18220 8769 -18712 8513
--19301 8207 -19995 7857 -20784 7456 -21656 7009 -22608 6516 -23639 5974
--24733 5385 -25874 4770 -27044 4137 -28223 3494 -29390 2848 -30526 2212
--31617 1605 -32648 1025 -33608 483 -34484 -19 -35273 -474 -35965 -877
--36557 -1227 -37045 -1520 -37424 -1752 -37693 -1924 -37853 -2039 -37904 -2095
--37842 -2092 -37669 -2036 -37389 -1928 -37007 -1762 -36520 -1530 -35925 -1234
--35233 -893 -34469 -536 -33619 -167 -32645 230 -31570 693 -30495 1258
--29373 1855 -28162 2457 -26882 3063 -25559 3674 -24204 4297 -22818 4928
--21414 5565 -20012 6203 -18619 6831 -17233 7464 -15867 8081 -14547 8664
--13280 9224 -12070 9769 -10926 10277 -9875 10713 -8933 11083 -8102 11419
--7390 11729 -6811 11969 -6399 12080 -6170 12055 -6107 11929 -6240 11751
--6534 11534 -7151 11245 -7975 10827 -8996 10250 -10255 9511 -11767 8642
--13578 7683 -15640 6682 -17865 5676 -20253 4704 -22777 3784 -25327 2937
--27913 2168 -30450 1481 -32960 877 -35450 353 -37866 -89 -40148 -452 -42260 -741
--44190 -954 -45925 -1101 -47448 -1186 -48755 -1217 -49864 -1193 -50773 -1122
--51487 -1013 -52021 -878 -52388 -729 -52588 -560 -52646 -363 -52603 -143
--52425 84 -52143 316 -51776 547 -51329 775 -50808 1004 -50241 1227 -49631 1445
--48980 1660 -48301 1865 -47603 2066 -46893 2258 -46176 2441 -45456 2617
--44742 2784 -44037 2942 -43344 3090 -42664 3230 -42005 3363 -41364 3485
--40752 3601 -40158 3708 -39590 3804 -39047 3897 -38531 3983 -38043 4062
--37582 4134 -37145 4202 -36738 4262 -36355 4319 -35998 4369 -35663 4416
--35348 4458 -35062 4495 -34794 4529 -34545 4561 -34317 4588 -34107 4612
--33917 4634 -33742 4655 -33580 4672 -33435 4687 -33302 4699 -33179 4714
--33070 4723 -32970 4731 -32882 4741 -32806 4747 -32730 4753 -32666 4758
--32607 4762 -32555 4767 -32507 4768 -32466 4771 -32429 4775 -32397 4777
--32369 4779
-7: 3680527 746998 -29420 4031 -29447 4029 -29486 4026 -29528 4022 -29577 4017
--29633 4009 -29694 4001 -29754 3991 -29821 3979 -29885 3968 -29955 3956
--30017 3944 -30081 3931 -30141 3921 -30194 3909 -30248 3901 -30290 3892
--30327 3887 -30356 3881 -30377 3878 -30389 3878 -30394 3878 -30382 3880
--30367 3885 -30341 3889 -30311 3895 -30268 3902 -30220 3910 -30167 3915
--30107 3922 -30045 3928 -29981 3934 -29914 3939 -29849 3943 -29785 3946
--29723 3948 -29664 3949 -29606 3950 -29552 3950 -29502 3951 -29455 3951
--29408 3952 -29363 3952 -29318 3955 -29275 3963 -29231 3973 -29180 3986
--29129 4001 -29072 4017 -29015 4034 -28951 4058 -28877 4087 -28803 4122
--28732 4155 -28655 4188 -28580 4222 -28503 4254 -28433 4286 -28368 4313
--28314 4337 -28267 4355 -28232 4365 -28216 4369 -28213 4363 -28222 4347
--28248 4323 -28291 4286 -28351 4241 -28417 4184 -28494 4120 -28577 4045
--28664 3965 -28749 3878 -28828 3787 -28894 3694 -28949 3601 -28984 3511
--28995 3424 -28976 3346 -28927 3274 -28844 3215 -28726 3170 -28566 3140
--28367 3125 -28131 3129 -27856 3153 -27542 3197 -27193 3261 -26812 3347
--26403 3453 -25966 3579 -25508 3728 -25032 3892 -24544 4077 -24046 4278
--23544 4495 -23040 4727 -22538 4970 -22043 5220 -21557 5483 -21082 5756
--20618 6038 -20170 6325 -19741 6603 -19325 6872 -18921 7137 -18539 7413
--18181 7707 -17849 7988 -17533 8248 -17236 8481 -16965 8699 -16726 8919
--16524 9126 -16355 9292 -16228 9401 -16151 9475 -16133 9540 -16180 9607
--16290 9649 -16475 9626 -16748 9520 -17118 9338 -17582 9092 -18135 8801
--18792 8470 -19563 8090 -20437 7657 -21396 7171 -22440 6618 -23563 6009
--24757 5359 -25998 4683 -27267 3980 -28536 3266 -29784 2560 -30988 1878
--32132 1221 -33202 599 -34186 22 -35077 -510 -35865 -983 -36546 -1397
--37116 -1748 -37573 -2033 -37913 -2253 -38136 -2420 -38244 -2521 -38238 -2552
--38118 -2519 -37882 -2432 -37540 -2295 -37094 -2100 -36546 -1833 -35890 -1499
--35139 -1120 -34318 -725 -33416 -324 -32393 105 -31270 602 -30148 1202
--28985 1836 -27736 2467 -26421 3104 -25065 3746 -23680 4395 -22264 5053
--20831 5718 -19401 6376 -17983 7036 -16570 7691 -15176 8325 -13829 8932
--12536 9522 -11297 10094 -10124 10606 -9045 11047 -8074 11453 -7213 11843
--6469 12176 -5861 12391 -5424 12461 -5164 12426 -5101 12347 -5151 12239
--5532 12065 -6092 11752 -6909 11249 -7974 10562 -9265 9717 -10889 8760
--12818 7730 -14954 6660 -17352 5577 -19962 4519 -22643 3512 -25424 2582
--28082 1750 -30771 1012 -33507 374 -36196 -166 -38770 -614 -41185 -975
--43419 -1251 -45459 -1450 -47286 -1578 -48881 -1645 -50238 -1653 -51381 -1605
--52307 -1510 -53025 -1376 -53553 -1216 -53904 -1045 -54081 -852 -54108 -635
--54033 -388 -53817 -138 -53494 110 -53082 359 -52589 604 -52023 846 -51409 1083
--50752 1314 -50056 1539 -49328 1755 -48585 1966 -47830 2167 -47069 2358
--46306 2540 -45549 2715 -44804 2877 -44070 3032 -43352 3178 -42654 3314
--41980 3442 -41331 3560 -40704 3669 -40104 3771 -39530 3865 -38988 3952
--38472 4035 -37983 4109 -37521 4178 -37087 4241 -36684 4298 -36304 4350
--35948 4398 -35617 4442 -35308 4481 -35023 4516 -34760 4546 -34516 4576
--34291 4601 -34088 4624 -33899 4645 -33726 4662 -33570 4678 -33426 4693
--33296 4704 -33175 4716 -33068 4727 -32971 4734 -32887 4742 -32806 4748
--32734 4754 -32671 4758 -32615 4763 -32560 4765 -32513 4769 -32477 4772
--32439 4775 -32408 4777
-8: 3701194 730231 -29451 4027 -29483 4024 -29529 4022 -29578 4017 -29633 4012
--29694 4003 -29762 3995 -29832 3985 -29902 3972 -29970 3960 -30045 3948
--30114 3934 -30179 3921 -30241 3909 -30299 3898 -30352 3888 -30395 3878
--30432 3871 -30460 3864 -30479 3861 -30487 3859 -30488 3859 -30474 3860
--30452 3863 -30419 3868 -30382 3874 -30332 3881 -30277 3888 -30214 3895
--30145 3903 -30074 3911 -29998 3918 -29921 3926 -29845 3931 -29772 3938
--29699 3944 -29628 3947 -29560 3953 -29498 3956 -29438 3960 -29383 3965
--29328 3969 -29276 3974 -29227 3980 -29179 3991 -29134 4004 -29082 4018
--29030 4035 -28975 4052 -28921 4071 -28864 4094 -28796 4120 -28730 4153
--28668 4182 -28602 4212 -28538 4239 -28472 4268 -28416 4292 -28363 4314
--28321 4330 -28287 4340 -28263 4344 -28256 4340 -28262 4326 -28279 4304
--28309 4272 -28355 4229 -28415 4177 -28478 4117 -28551 4047 -28626 3969
--28704 3886 -28774 3799 -28837 3708 -28885 3616 -28918 3525 -28930 3440
--28914 3358 -28867 3284 -28789 3222 -28675 3172 -28523 3137 -28331 3117
--28096 3117 -27824 3134 -27514 3172 -27164 3233 -26778 3314 -26361 3418
--25917 3541 -25444 3690 -24951 3855 -24441 4043 -23919 4248 -23391 4470
--22857 4708 -22324 4962 -21793 5228 -21272 5501 -20761 5783 -20265 6077
--19779 6379 -19311 6685 -18866 6984 -18437 7270 -18021 7553 -17629 7844
--17263 8154 -16925 8446 -16605 8708 -16308 8950 -16038 9188 -15805 9422
--15607 9620 -15450 9761 -15334 9859 -15272 9952 -15275 10052 -15344 10135
--15484 10149 -15700 10068 -16012 9900 -16428 9672 -16945 9405 -17550 9109
--18277 8766 -19127 8366 -20074 7897 -21116 7353 -22253 6729 -23480 6056
--24778 5341 -26124 4586 -27490 3806 -28850 3026 -30176 2264 -31447 1522
--32647 812 -33758 142 -34768 -471 -35670 -1025 -36456 -1515 -37123 -1934
--37667 -2281 -38090 -2562 -38388 -2780 -38562 -2936 -38616 -3014 -38554 -3014
--38373 -2949 -38076 -2836 -37672 -2672 -37167 -2442 -36559 -2139 -35845 -1764
--35038 -1349 -34166 -921 -33217 -487 -32150 -26 -30986 505 -29826 1140
--28628 1806 -27348 2469 -26003 3134 -24623 3804 -23214 4479 -21774 5163
--20320 5850 -18870 6532 -17427 7218 -15993 7893 -14577 8545 -13206 9177
--11889 9800 -10623 10385 -9422 10900 -8313 11365 -7313 11827 -6420 12256
--5639 12577 -4997 12751 -4524 12811 -4252 12829 -4093 12842 -4221 12801
--4490 12616 -5017 12215 -5871 11596 -6969 10803 -8342 9896 -9986 8904
--11906 7834 -14241 6696 -16857 5513 -19617 4332 -22562 3205 -25336 2173
--28270 1265 -31232 483 -34099 -174 -36900 -717 -39622 -1156 -42204 -1501
--44585 -1758 -46744 -1934 -48663 -2039 -50322 -2081 -51724 -2062 -52892 -1991
--53831 -1870 -54547 -1711 -55062 -1529 -55393 -1332 -55541 -1117 -55536 -878
--55428 -605 -55171 -336 -54804 -68 -54349 198 -53808 458 -53196 714 -52536 963
--51834 1205 -51090 1441 -50318 1669 -49530 1886 -48731 2094 -47928 2293
--47122 2483 -46325 2660 -45541 2829 -44768 2990 -44014 3139 -43280 3280
--42571 3409 -41887 3531 -41229 3644 -40598 3746 -39995 3843 -39426 3932
--38882 4016 -38369 4092 -37884 4161 -37425 4226 -36998 4285 -36599 4337
--36222 4386 -35871 4431 -35548 4470 -35244 4506 -34963 4537 -34707 4568
--34469 4593 -34252 4616 -34051 4637 -33867 4656 -33697 4672 -33547 4687
--33405 4699 -33276 4711 -33162 4720 -33058 4731 -32963 4739 -32879 4744
--32801 4751 -32730 4754 -32670 4760 -32612 4763 -32559 4768 -32519 4770
--32480 4773 -32444 4776
-9: 3721827 713452 -29494 4023 -29531 4021 -29582 4017 -29637 4012 -29700 4006
--29769 3999 -29839 3989 -29913 3978 -29989 3966 -30064 3953 -30140 3939
--30213 3925 -30280 3911 -30345 3899 -30403 3885 -30454 3875 -30500 3864
--30533 3856 -30559 3849 -30575 3844 -30579 3841 -30575 3840 -30554 3840
--30527 3843 -30488 3848 -30443 3853 -30385 3860 -30319 3868 -30248 3876
--30170 3885 -30088 3894 -30002 3904 -29914 3913 -29827 3921 -29743 3931
--29660 3939 -29579 3948 -29500 3955 -29428 3964 -29362 3970 -29296 3979
--29235 3988 -29177 3996 -29122 4006 -29070 4019 -29022 4035 -28971 4050
--28918 4068 -28867 4087 -28816 4106 -28763 4129 -28703 4154 -28647 4181
--28591 4209 -28537 4232 -28484 4257 -28430 4279 -28385 4297 -28347 4312
--28316 4322 -28294 4324 -28282 4321 -28283 4309 -28298 4288 -28321 4260
--28356 4220 -28404 4171 -28462 4115 -28525 4049 -28590 3976 -28658 3895
--28723 3812 -28780 3721 -28826 3633 -28856 3543 -28867 3454 -28854 3373
--28812 3297 -28738 3230 -28628 3176 -28485 3136 -28301 3110 -28073 3103
--27807 3114 -27499 3146 -27155 3200 -26770 3276 -26349 3374 -25897 3494
--25419 3639 -24913 3801 -24388 3991 -23845 4197 -23294 4422 -22735 4664
--22173 4924 -21614 5200 -21058 5487 -20513 5780 -19981 6082 -19464 6395
--18962 6717 -18478 7042 -18018 7360 -17579 7663 -17154 7962 -16757 8267
--16383 8593 -16040 8890 -15719 9158 -15423 9417 -15155 9675 -14924 9908
--14734 10085 -14584 10214 -14479 10330 -14429 10463 -14447 10585 -14537 10642
--14700 10594 -14943 10445 -15288 10239 -15749 10008 -16295 9758 -16981 9473
--17759 9121 -18648 8689 -19692 8161 -20841 7540 -22070 6850 -23388 6107
--24778 5310 -26221 4471 -27688 3621 -29148 2777 -30566 1946 -31916 1135
--33174 367 -34324 -343 -35357 -986 -36266 -1561 -37045 -2063 -37692 -2488
--38207 -2836 -38591 -3119 -38845 -3330 -38968 -3460 -38966 -3507 -38846 -3478
--38604 -3389 -38248 -3250 -37783 -3052 -37219 -2784 -36555 -2443 -35789 -2033
--34930 -1586 -34011 -1122 -33021 -655 -31915 -160 -30718 402 -29530 1073
--28304 1768 -26999 2461 -25635 3153 -24237 3846 -22810 4548 -21355 5255
--19886 5961 -18420 6665 -16963 7374 -15511 8066 -14077 8736 -12687 9398
--11349 10047 -10057 10636 -8830 11159 -7693 11677 -6662 12192 -5733 12623
--4913 12910 -4232 13067 -3731 13175 -3380 13296 -3249 13403 -3290 13376
--3437 13107 -4027 12575 -4946 11845 -6038 11010 -7317 10118 -8883 9143
--11010 8044 -13530 6802 -16309 5462 -19318 4105 -22238 2820 -25476 1675
--28640 699 -31585 -107 -34543 -762 -37540 -1286 -40470 -1700 -43230 -2018
--45761 -2246 -48038 -2395 -50046 -2473 -51766 -2487 -53206 -2443 -54393 -2345
--55336 -2196 -56043 -2012 -56539 -1805 -56844 -1585 -56959 -1349 -56920 -1086
--56771 -792 -56475 -503 -56065 -216 -55563 65 -54978 340 -54322 607 -53615 870
--52867 1123 -52080 1368 -51263 1604 -50434 1829 -49592 2043 -48747 2249
--47904 2442 -47066 2626 -46244 2798 -45436 2962 -44645 3116 -43878 3257
--43136 3391 -42421 3515 -41730 3627 -41071 3734 -40441 3832 -39845 3921
--39275 4006 -38737 4082 -38228 4154 -37751 4219 -37301 4277 -36879 4331
--36484 4379 -36117 4425 -35776 4465 -35456 4500 -35161 4532 -34889 4563
--34639 4589 -34409 4612 -34197 4632 -34001 4653 -33822 4667 -33657 4683
--33509 4696 -33375 4708 -33251 4717 -33140 4729 -33037 4736 -32946 4743
--32866 4747 -32787 4752 -32721 4759 -32662 4762 -32604 4765 -32557 4769
--32516 4773 -32479 4775
-10: 3742416 696661 -29550 4019 -29590 4017 -29646 4014 -29707 4007 -29779 4002
--29850 3993 -29924 3984 -30002 3972 -30083 3959 -30161 3945 -30239 3931
--30314 3916 -30384 3902 -30447 3888 -30504 3874 -30556 3863 -30599 3850
--30630 3842 -30652 3833 -30664 3827 -30663 3824 -30653 3822 -30627 3821
--30590 3824 -30544 3828 -30490 3833 -30424 3841 -30348 3849 -30267 3858
--30180 3868 -30088 3878 -29991 3890 -29892 3902 -29794 3913 -29699 3924
--29605 3937 -29512 3948 -29427 3959 -29345 3970 -29269 3982 -29195 3995
--29128 4006 -29064 4019 -29002 4032 -28950 4047 -28897 4065 -28846 4083
--28795 4101 -28746 4121 -28698 4140 -28650 4162 -28598 4186 -28552 4211
--28504 4232 -28458 4252 -28416 4272 -28377 4288 -28344 4300 -28318 4308
--28300 4311 -28287 4307 -28288 4296 -28298 4277 -28319 4249 -28349 4213
--28388 4168 -28437 4115 -28495 4052 -28554 3982 -28613 3906 -28671 3824
--28724 3738 -28768 3650 -28795 3560 -28806 3473 -28794 3389 -28758 3313
--28690 3241 -28586 3183 -28448 3137 -28274 3106 -28058 3091 -27798 3096
--27498 3119 -27157 3166 -26779 3234 -26362 3325 -25906 3440 -25422 3578
--24912 3738 -24376 3923 -23819 4129 -23249 4355 -22667 4598 -22083 4862
--21495 5143 -20912 5438 -20336 5743 -19769 6056 -19220 6378 -18687 6710
--18170 7052 -17674 7394 -17204 7727 -16756 8046 -16326 8361 -15925 8680
--15546 9019 -15203 9320 -14884 9601 -14586 9883 -14322 10149 -14095 10366
--13910 10528 -13766 10670 -13668 10826 -13628 10990 -13658 11092 -13764 11084
--13943 10965 -14209 10785 -14583 10592 -15055 10404 -15708 10190 -16367 9907
--17175 9523 -18221 9025 -19345 8415 -20533 7723 -21833 6965 -23234 6140
--24728 5259 -26294 4352 -27892 3432 -29469 2510 -30983 1594 -32406 717
--33714 -100 -34897 -846 -35946 -1518 -36855 -2115 -37623 -2631 -38247 -3066
--38728 -3421 -39072 -3696 -39277 -3883 -39347 -3981 -39289 -4002 -39108 -3955
--38809 -3842 -38391 -3667 -37869 -3430 -37248 -3126 -36531 -2751 -35716 -2309
--34813 -1826 -33853 -1326 -32827 -823 -31690 -295 -30467 298 -29258 999
--28014 1722 -26693 2444 -25318 3158 -23908 3875 -22474 4598 -21012 5326
--19535 6047 -18062 6774 -16595 7500 -15131 8208 -13685 8897 -12280 9591
--10924 10253 -9611 10837 -8358 11400 -7195 11977 -6134 12513 -5168 12921
--4307 13187 -3586 13373 -3032 13579 -2646 13817 -2507 13975 -2309 13884
--2564 13473 -3241 12809 -4031 12041 -4946 11270 -6111 10476 -7865 9543
--10151 8375 -12831 6954 -15744 5374 -18809 3782 -22303 2316 -25689 1068
--28711 55 -31797 -743 -34975 -1364 -38175 -1850 -41297 -2229 -44237 -2514
--46920 -2715 -49321 -2833 -51420 -2881 -53200 -2866 -54673 -2792 -55873 -2664
--56812 -2487 -57502 -2275 -57973 -2042 -58246 -1800 -58324 -1543 -58245 -1259
--58055 -943 -57717 -634 -57264 -331 -56720 -36 -56088 253 -55389 532 -54638 804
--53847 1068 -53019 1320 -52159 1563 -51290 1795 -50408 2015 -49524 2226
--48643 2422 -47769 2610 -46912 2784 -46070 2952 -45246 3106 -44446 3251
--43670 3386 -42928 3510 -42210 3625 -41523 3732 -40866 3830 -40241 3921
--39651 4005 -39087 4083 -38558 4154 -38059 4218 -37588 4277 -37148 4331
--36735 4379 -36352 4424 -35993 4464 -35659 4499 -35350 4533 -35065 4561
--34801 4588 -34558 4611 -34334 4632 -34128 4651 -33943 4666 -33766 4682
--33609 4695 -33465 4706 -33334 4717 -33217 4727 -33109 4735 -33009 4741
--32925 4747 -32842 4751 -32772 4758 -32706 4761 -32648 4764 -32592 4769
--32550 4772 -32511 4775
-11: 3762957 679857 -29618 4016 -29663 4013 -29720 4010 -29789 4004 -29863 3997
--29940 3988 -30017 3979 -30099 3966 -30181 3953 -30262 3938 -30341 3923
--30416 3908 -30487 3892 -30548 3878 -30606 3863 -30654 3851 -30694 3837
--30722 3827 -30737 3819 -30744 3812 -30736 3807 -30720 3804 -30687 3803
--30641 3806 -30588 3809 -30524 3814 -30447 3822 -30363 3831 -30270 3841
--30174 3852 -30071 3864 -29963 3877 -29854 3891 -29745 3905 -29639 3920
--29535 3934 -29431 3949 -29338 3964 -29244 3979 -29162 3995 -29079 4009
--29005 4026 -28936 4041 -28870 4058 -28814 4076 -28760 4095 -28707 4114
--28659 4134 -28611 4153 -28568 4174 -28526 4195 -28482 4216 -28443 4238
--28405 4255 -28369 4270 -28338 4284 -28312 4294 -28291 4301 -28277 4303
--28271 4298 -28269 4288 -28280 4269 -28299 4242 -28328 4209 -28362 4167
--28405 4116 -28456 4056 -28511 3990 -28567 3917 -28618 3837 -28666 3755
--28708 3668 -28736 3581 -28746 3493 -28736 3409 -28702 3328 -28641 3257
--28546 3193 -28416 3141 -28247 3105 -28043 3083 -27795 3080 -27505 3096
--27172 3133 -26799 3191 -26389 3275 -25940 3381 -25453 3513 -24938 3666
--24398 3845 -23833 4047 -23247 4270 -22651 4513 -22046 4780 -21435 5062
--20827 5360 -20223 5672 -19627 5997 -19046 6331 -18480 6672 -17935 7022
--17409 7379 -16904 7735 -16427 8085 -15975 8419 -15543 8748 -15140 9082
--14762 9425 -14419 9738 -14102 10041 -13809 10337 -13546 10596 -13324 10796
--13144 10962 -13004 11140 -12910 11335 -12876 11489 -12914 11532 -13030 11452
--13223 11300 -13499 11147 -13877 11022 -14471 10894 -14975 10694 -15760 10376
--16766 9917 -17750 9325 -18861 8639 -20155 7884 -21551 7056 -23071 6158
--24704 5215 -26411 4238 -28130 3233 -29809 2216 -31404 1220 -32889 288
--34246 -574 -35458 -1361 -36520 -2070 -37429 -2694 -38184 -3227 -38779 -3670
--39225 -4021 -39524 -4272 -39679 -4427 -39694 -4507 -39578 -4515 -39338 -4445
--38978 -4296 -38504 -4080 -37925 -3806 -37249 -3472 -36485 -3064 -35625 -2586
--34683 -2062 -33689 -1526 -32633 -989 -31473 -432 -30233 190 -29012 920
--27757 1670 -26432 2415 -25053 3152 -23643 3888 -22210 4629 -20748 5368
--19271 6111 -17800 6855 -16330 7594 -14861 8311 -13409 9030 -11995 9751
--10624 10401 -9293 11007 -8018 11622 -6832 12235 -5743 12768 -4739 13158
--3835 13429 -3074 13685 -2456 14016 -2101 14349 -1713 14485 -1568 14263
--1944 13690 -2413 12960 -2941 12278 -3754 11689 -5101 11052 -7019 10142
--9393 8814 -11990 7096 -15059 5179 -18643 3302 -22303 1662 -25526 350
--28750 -643 -32043 -1383 -35399 -1944 -38777 -2382 -42084 -2728 -45196 -2989
--48035 -3168 -50561 -3260 -52750 -3278 -54589 -3229 -56096 -3118 -57303 -2953
--58235 -2742 -58904 -2500 -59346 -2241 -59583 -1973 -59621 -1694 -59498 -1390
--59268 -1055 -58887 -728 -58391 -411 -57805 -102 -57132 200 -56389 489
--55596 770 -54766 1040 -53899 1300 -53000 1548 -52092 1785 -51175 2010
--50255 2223 -49338 2423 -48431 2611 -47539 2791 -46666 2958 -45814 3114
--44981 3260 -44179 3395 -43407 3518 -42661 3634 -41949 3742 -41268 3840
--40619 3930 -40007 4015 -39422 4091 -38870 4162 -38351 4226 -37861 4283
--37402 4338 -36973 4386 -36576 4429 -36201 4468 -35853 4504 -35527 4535
--35233 4564 -34955 4591 -34700 4614 -34465 4634 -34250 4653 -34054 4669
--33868 4683 -33705 4694 -33552 4708 -33416 4718 -33290 4728 -33174 4734
--33072 4742 -32980 4747 -32893 4753 -32819 4756 -32748 4760 -32686 4765
--32631 4769 -32583 4771 -32541 4775
-12: 3783435 663039 -29695 4013 -29742 4011 -29808 4006 -29879 4001 -29955 3993
--30036 3984 -30117 3973 -30201 3961 -30285 3947 -30366 3931 -30447 3915
--30519 3900 -30587 3884 -30648 3868 -30704 3852 -30746 3839 -30782 3825
--30805 3814 -30816 3804 -30813 3796 -30800 3791 -30771 3788 -30734 3786
--30681 3788 -30616 3791 -30543 3797 -30455 3804 -30361 3814 -30258 3824
--30151 3838 -30036 3850 -29918 3866 -29798 3881 -29680 3898 -29560 3916
--29446 3933 -29336 3952 -29230 3969 -29131 3988 -29036 4007 -28949 4026
--28868 4045 -28794 4065 -28724 4084 -28665 4104 -28608 4124 -28556 4146
--28509 4165 -28466 4185 -28426 4206 -28388 4226 -28354 4245 -28322 4263
--28294 4275 -28269 4286 -28250 4294 -28234 4299 -28226 4300 -28224 4295
--28229 4283 -28240 4265 -28259 4240 -28288 4208 -28323 4166 -28362 4119
--28408 4063 -28459 3998 -28512 3929 -28563 3852 -28607 3771 -28644 3688
--28673 3601 -28686 3514 -28679 3430 -28646 3349 -28591 3274 -28505 3206
--28383 3152 -28226 3107 -28028 3079 -27793 3068 -27516 3075 -27193 3103
--26830 3152 -26428 3226 -25985 3321 -25506 3444 -24990 3590 -24447 3761
--23879 3957 -23286 4172 -22678 4414 -22056 4679 -21428 4961 -20797 5258
--20170 5573 -19548 5907 -18939 6251 -18343 6603 -17768 6958 -17214 7323
--16681 7695 -16172 8069 -15692 8432 -15241 8781 -14809 9122 -14410 9469
--14034 9814 -13697 10145 -13384 10469 -13095 10767 -12837 11010 -12619 11205
--12442 11399 -12306 11618 -12213 11821 -12182 11926 -12223 11896 -12347 11779
--12534 11661 -12821 11593 -13292 11552 -13645 11451 -14462 11213 -15342 10802
--16092 10236 -17113 9561 -18425 8821 -19820 8017 -21330 7139 -22967 6197
--24706 5196 -26510 4131 -28326 3021 -30102 1913 -31789 854 -33352 -136
--34766 -1058 -36012 -1898 -37087 -2648 -37993 -3296 -38726 -3842 -39291 -4284
--39694 -4613 -39945 -4838 -40046 -4980 -40004 -5052 -39828 -5044 -39529 -4935
--39109 -4743 -38578 -4488 -37945 -4184 -37221 -3819 -36410 -3375 -35512 -2855
--34537 -2289 -33515 -1718 -32440 -1155 -31263 -573 -30013 76 -28791 834
--27537 1612 -26214 2377 -24843 3132 -23443 3884 -22019 4636 -20569 5392
--19102 6145 -17638 6907 -16174 7652 -14708 8382 -13254 9135 -11838 9848
--10458 10508 -9113 11149 -7822 11800 -6616 12433 -5499 12962 -4460 13341
--3517 13641 -2700 14004 -2082 14458 -1600 14835 -1100 14876 -1135 14478
--1316 13787 -1404 13118 -1855 12668 -2902 12368 -4450 11905 -6333 10939
--8333 9311 -11066 7152 -14503 4799 -18387 2614 -21970 840 -25399 -455
--28873 -1345 -32347 -1973 -35827 -2455 -39337 -2853 -42810 -3187 -46103 -3451
--49091 -3625 -51728 -3700 -53995 -3685 -55883 -3591 -57418 -3433 -58636 -3224
--59562 -2969 -60213 -2688 -60627 -2399 -60830 -2102 -60827 -1802 -60665 -1477
--60394 -1124 -59972 -782 -59435 -451 -58809 -131 -58096 180 -57314 480
--56484 767 -55617 1044 -54713 1307 -53780 1561 -52837 1800 -51887 2028
--50935 2243 -49986 2445 -49046 2635 -48128 2814 -47221 2981 -46343 3140
--45485 3282 -44655 3418 -43856 3541 -43087 3657 -42350 3764 -41645 3860
--40975 3950 -40341 4034 -39736 4108 -39166 4179 -38626 4240 -38121 4299
--37645 4350 -37200 4398 -36785 4439 -36397 4478 -36036 4513 -35699 4543
--35390 4573 -35101 4598 -34835 4619 -34591 4641 -34365 4658 -34159 4673
--33968 4686 -33794 4699 -33634 4711 -33490 4720 -33358 4728 -33238 4736
--33130 4743 -33033 4749 -32943 4754 -32861 4757 -32789 4762 -32723 4765
--32665 4769 -32612 4772 -32569 4777
-13: 3803847 646207 -29783 4011 -29833 4008 -29903 4004 -29977 3998 -30055 3989
--30140 3980 -30223 3969 -30306 3956 -30392 3940 -30473 3925 -30551 3909
--30621 3892 -30688 3875 -30743 3859 -30796 3842 -30833 3827 -30865 3813
--30876 3801 -30881 3791 -30872 3782 -30850 3775 -30815 3772 -30766 3770
--30704 3771 -30629 3774 -30544 3779 -30447 3788 -30341 3798 -30228 3809
--30108 3823 -29985 3838 -29855 3855 -29724 3874 -29594 3892 -29467 3912
--29343 3933 -29220 3955 -29106 3976 -29000 3998 -28896 4020 -28803 4042
--28715 4065 -28637 4088 -28565 4109 -28500 4132 -28443 4155 -28393 4176
--28347 4196 -28306 4216 -28272 4236 -28240 4255 -28213 4272 -28190 4286
--28172 4294 -28158 4300 -28150 4302 -28147 4301 -28149 4295 -28160 4284
--28177 4265 -28197 4242 -28227 4209 -28263 4170 -28306 4123 -28349 4069
--28396 4009 -28449 3941 -28499 3867 -28542 3788 -28580 3708 -28607 3622
--28622 3537 -28618 3452 -28593 3371 -28540 3294 -28461 3224 -28350 3164
--28204 3115 -28016 3080 -27792 3061 -27526 3058 -27220 3078 -26868 3116
--26473 3180 -26043 3264 -25571 3376 -25062 3512 -24520 3672 -23951 3860
--23356 4069 -22741 4302 -22108 4564 -21467 4843 -20819 5138 -20170 5452
--19527 5790 -18894 6140 -18271 6499 -17667 6865 -17085 7233 -16526 7614
--15992 8004 -15482 8394 -15005 8769 -14557 9128 -14133 9479 -13737 9838
--13372 10189 -13042 10539 -12737 10875 -12453 11162 -12201 11392 -11989 11604
--11816 11840 -11679 12080 -11587 12252 -11554 12289 -11599 12214 -11706 12124
--11918 12100 -12226 12135 -12475 12138 -13259 11996 -13951 11649 -14490 11112
--15413 10450 -16723 9730 -18090 8973 -19544 8157 -21104 7267 -22783 6289
--24581 5207 -26483 4033 -28435 2823 -30358 1636 -32174 504 -33838 -569
--35314 -1567 -36589 -2465 -37666 -3247 -38554 -3912 -39259 -4459 -39780 -4886
--40134 -5197 -40330 -5415 -40373 -5557 -40271 -5616 -40034 -5565 -39674 -5410
--39195 -5178 -38610 -4893 -37926 -4560 -37154 -4160 -36303 -3671 -35373 -3109
--34371 -2508 -33329 -1910 -32242 -1324 -31058 -718 -29809 -40 -28594 744
--27349 1547 -26044 2331 -24689 3098 -23309 3860 -21906 4628 -20476 5390
--19029 6155 -17582 6923 -16131 7670 -14676 8429 -13229 9183 -11816 9898
--10432 10576 -9080 11241 -7776 11923 -6556 12574 -5415 13092 -4343 13465
--3362 13825 -2506 14314 -1872 14867 -1197 15220 -822 15108 -798 14541
--532 13837 -469 13384 -1227 13311 -2570 13368 -3997 13051 -5184 11906
--7064 9805 -9997 7035 -13880 4156 -17927 1669 -21713 -157 -25469 -1308
--29132 -1983 -32688 -2440 -36216 -2839 -39839 -3230 -43504 -3601 -46986 -3912
--50113 -4112 -52827 -4180 -55133 -4125 -57046 -3974 -58594 -3752 -59822 -3480
--60748 -3171 -61386 -2844 -61781 -2515 -61957 -2190 -61919 -1861 -61720 -1518
--61417 -1150 -60955 -793 -60384 -449 -59718 -120 -58972 200 -58156 504
--57292 797 -56393 1077 -55456 1345 -54494 1601 -53520 1841 -52541 2072
--51559 2286 -50582 2490 -49616 2677 -48669 2857 -47738 3023 -46832 3179
--45951 3321 -45098 3456 -44276 3578 -43483 3692 -42724 3797 -42000 3892
--41308 3981 -40655 4062 -40032 4135 -39442 4203 -38886 4265 -38365 4320
--37874 4370 -37413 4415 -36983 4456 -36582 4493 -36209 4527 -35860 4556
--35539 4584 -35240 4609 -34961 4630 -34709 4650 -34473 4665 -34259 4680
--34062 4692 -33879 4705 -33713 4715 -33561 4724 -33421 4732 -33297 4740
--33184 4746 -33082 4752 -32989 4755 -32902 4759 -32825 4764 -32759 4766
--32694 4771 -32643 4774 -32593 4777
-14: 3824187 629361 -29879 4010 -29934 4006 -30007 4002 -30083 3995 -30163 3987
--30246 3977 -30334 3965 -30417 3950 -30500 3935 -30580 3919 -30654 3902
--30722 3885 -30784 3867 -30837 3849 -30880 3833 -30912 3816 -30935 3802
--30940 3789 -30937 3777 -30918 3768 -30886 3761 -30842 3756 -30782 3754
--30710 3755 -30625 3758 -30529 3763 -30421 3772 -30303 3782 -30180 3796
--30048 3809 -29913 3827 -29773 3847 -29631 3865 -29490 3887 -29355 3910
--29219 3934 -29089 3959 -28966 3983 -28851 4009 -28741 4033 -28640 4060
--28548 4084 -28466 4111 -28389 4135 -28323 4160 -28266 4184 -28215 4205
--28173 4226 -28135 4246 -28105 4265 -28080 4282 -28061 4298 -28049 4307
--28038 4311 -28036 4310 -28040 4307 -28048 4301 -28063 4288 -28085 4270
--28112 4246 -28145 4213 -28183 4176 -28227 4131 -28275 4077 -28324 4020
--28373 3954 -28425 3881 -28471 3807 -28510 3727 -28538 3643 -28554 3560
--28556 3476 -28534 3394 -28490 3316 -28417 3243 -28315 3181 -28179 3126
--28006 3085 -27792 3058 -27539 3049 -27245 3057 -26908 3086 -26529 3138
--26106 3212 -25646 3311 -25147 3435 -24613 3583 -24045 3760 -23451 3961
--22834 4184 -22196 4439 -21545 4711 -20884 5001 -20220 5315 -19559 5652
--18903 6003 -18258 6365 -17629 6736 -17019 7115 -16436 7502 -15877 7900
--15344 8305 -14839 8704 -14369 9088 -13931 9457 -13515 9818 -13133 10185
--12779 10551 -12460 10918 -12167 11246 -11893 11518 -11649 11754 -11442 12001
--11273 12270 -11136 12500 -11042 12612 -11006 12594 -11033 12532 -11170 12532
--11332 12623 -11533 12721 -12129 12687 -12661 12423 -13055 11928 -13860 11278
--15125 10574 -16394 9874 -17686 9154 -19108 8373 -20672 7485 -22394 6445
--24310 5253 -26399 3966 -28563 2661 -30677 1380 -32638 140 -34392 -1036
--35912 -2109 -37193 -3050 -38254 -3854 -39109 -4525 -39769 -5067 -40239 -5484
--40536 -5797 -40670 -6020 -40653 -6149 -40487 -6165 -40188 -6059 -39766 -5864
--39231 -5603 -38592 -5295 -37860 -4926 -37046 -4481 -36160 -3950 -35202 -3352
--34181 -2728 -33128 -2108 -32035 -1495 -30856 -859 -29618 -152 -28419 657
--27197 1480 -25917 2271 -24591 3049 -23243 3824 -21872 4597 -20473 5361
--19055 6136 -17634 6900 -16206 7660 -14769 8425 -13337 9181 -11933 9907
--10553 10588 -9198 11277 -7891 11996 -6659 12649 -5499 13143 -4401 13527
--3380 13981 -2519 14594 -1784 15198 -1057 15460 -780 15171 -408 14502
-184 13922 -22 13835 -1221 14247 -2505 14690 -3012 14463 -3529 13013 -5295 10246
--8796 6664 -13306 3166 -17715 411 -21821 -1335 -25692 -2169 -29418 -2463
--32960 -2695 -36477 -3031 -40220 -3477 -44147 -3958 -47895 -4383 -51177 -4650
--53937 -4720 -56226 -4616 -58107 -4387 -59632 -4079 -60848 -3725 -61766 -3347
--62397 -2963 -62778 -2589 -62934 -2229 -62872 -1875 -62644 -1511 -62312 -1127
--61821 -758 -61220 -406 -60525 -67 -59749 256 -58905 565 -58015 861 -57086 1144
--56124 1413 -55136 1669 -54136 1910 -53134 2138 -52126 2353 -51123 2555
--50135 2742 -49164 2918 -48211 3082 -47282 3236 -46381 3377 -45504 3508
--44663 3628 -43850 3739 -43072 3842 -42328 3936 -41619 4022 -40948 4100
--40308 4171 -39700 4237 -39129 4295 -38593 4349 -38088 4397 -37613 4440
--37170 4478 -36757 4514 -36372 4546 -36010 4575 -35677 4599 -35371 4624
--35082 4643 -34819 4661 -34575 4676 -34353 4689 -34150 4702 -33957 4712
--33787 4722 -33628 4730 -33483 4738 -33353 4744 -33237 4750 -33126 4756
--33029 4759 -32941 4763 -32859 4766 -32790 4770 -32725 4773 -32667 4775
--32617 4778
-15: 3844448 612501 -29986 4010 -30043 4006 -30113 4000 -30195 3993 -30278 3985
--30360 3973 -30445 3962 -30529 3946 -30609 3931 -30686 3913 -30756 3896
--30821 3877 -30875 3860 -30923 3840 -30959 3823 -30981 3806 -30995 3790
--30994 3777 -30980 3764 -30949 3755 -30906 3747 -30855 3741 -30782 3739
--30697 3740 -30602 3742 -30494 3748 -30376 3757 -30247 3768 -30112 3782
--29966 3798 -29823 3817 -29672 3836 -29520 3859 -29369 3883 -29222 3910
--29078 3935 -28940 3963 -28808 3992 -28684 4020 -28570 4047 -28462 4076
--28365 4106 -28278 4133 -28202 4161 -28133 4188 -28075 4212 -28026 4234
--27984 4254 -27953 4275 -27927 4292 -27909 4310 -27899 4320 -27895 4326
--27896 4324 -27904 4319 -27919 4310 -27940 4297 -27967 4278 -28000 4254
--28038 4221 -28081 4185 -28128 4140 -28181 4088 -28235 4031 -28287 3967
--28337 3897 -28388 3825 -28432 3746 -28464 3664 -28483 3582 -28488 3499
--28475 3417 -28436 3340 -28373 3265 -28279 3198 -28154 3141 -27993 3095
--27793 3062 -27554 3043 -27272 3043 -26950 3062 -26586 3102 -26178 3164
--25728 3251 -25242 3361 -24718 3497 -24158 3663 -23567 3850 -22950 4063
--22314 4306 -21657 4571 -20988 4854 -20314 5162 -19636 5497 -18963 5846
--18298 6204 -17648 6579 -17015 6965 -16404 7362 -15822 7766 -15268 8176
--14742 8588 -14247 8994 -13790 9388 -13364 9766 -12965 10136 -12599 10511
--12262 10900 -11961 11267 -11682 11579 -11420 11845 -11187 12105 -10990 12391
--10823 12667 -10687 12854 -10588 12906 -10536 12878 -10586 12887 -10647 13007
--10802 13179 -11156 13257 -11566 13097 -11819 12663 -12505 12030 -13684 11336
--14784 10682 -15765 10077 -16987 9451 -18449 8724 -20100 7807 -21975 6663
--24108 5343 -26435 3935 -28817 2511 -31095 1098 -33164 -273 -34975 -1544
--36511 -2671 -37779 -3640 -38810 -4459 -39622 -5137 -40233 -5683 -40646 -6107
--40881 -6427 -40954 -6636 -40873 -6717 -40643 -6671 -40282 -6523 -39800 -6304
--39209 -6026 -38520 -5685 -37743 -5272 -36891 -4783 -35975 -4218 -34995 -3599
--33962 -2952 -32906 -2304 -31819 -1657 -30653 -987 -29436 -254 -28266 576
--27077 1401 -25834 2200 -24550 2992 -23243 3771 -21917 4539 -20561 5309
--19183 6083 -17796 6843 -16401 7607 -14991 8371 -13581 9139 -12192 9855
--10823 10541 -9474 11267 -8169 12006 -6932 12637 -5760 13113 -4643 13542
--3594 14098 -2731 14806 -1872 15403 -1225 15534 -853 15096 -76 14425 486 14093
--218 14480 -1609 15426 -2049 16260 -1297 16094 -1027 14251 -3089 10625
--7867 5953 -13341 1735 -18175 -1218 -22242 -2720 -25854 -2997 -29516 -2662
--32985 -2633 -36355 -2971 -40212 -3556 -44617 -4236 -48853 -4861 -52416 -5243
--55228 -5322 -57430 -5151 -59183 -4819 -60603 -4402 -61750 -3948 -62628 -3487
--63238 -3038 -63603 -2612 -63745 -2218 -63665 -1837 -63417 -1452 -63067 -1056
--62554 -677 -61931 -316 -61217 26 -60419 353 -59553 663 -58642 960 -57695 1243
--56710 1510 -55702 1765 -54681 2005 -53659 2231 -52632 2443 -51610 2642
--50601 2826 -49612 2999 -48638 3160 -47692 3311 -46770 3447 -45877 3574
--45016 3692 -44186 3801 -43393 3899 -42631 3990 -41907 4073 -41218 4147
--40562 4217 -39941 4279 -39355 4335 -38805 4384 -38288 4431 -37798 4470
--37345 4507 -36921 4541 -36522 4570 -36150 4597 -35809 4619 -35492 4642
--35196 4659 -34924 4676 -34670 4690 -34441 4702 -34231 4712 -34032 4722
--33855 4731 -33691 4738 -33541 4745 -33405 4751 -33283 4756 -33169 4761
--33068 4764 -32977 4768 -32893 4769 -32818 4773 -32751 4775 -32690 4778
--32639 4782
-16: 3864622 595629 -30099 4010 -30157 4005 -30229 4000 -30311 3993 -30396 3982
--30476 3972 -30558 3958 -30642 3943 -30718 3926 -30790 3909 -30854 3889
--30915 3871 -30960 3852 -31001 3832 -31027 3813 -31042 3796 -31044 3779
--31033 3766 -31008 3752 -30967 3741 -30914 3734 -30846 3726 -30765 3725
--30667 3724 -30559 3728 -30440 3733 -30311 3743 -30171 3755 -30021 3769
--29867 3787 -29711 3807 -29549 3829 -29391 3854 -29228 3880 -29071 3908
--28921 3938 -28771 3968 -28633 3999 -28502 4031 -28381 4063 -28269 4094
--28167 4126 -28076 4157 -28000 4186 -27929 4214 -27872 4240 -27824 4263
--27785 4282 -27758 4303 -27738 4319 -27729 4333 -27726 4341 -27732 4341
--27743 4334 -27762 4326 -27790 4310 -27822 4291 -27860 4265 -27907 4233
--27955 4197 -28009 4152 -28066 4100 -28125 4044 -28183 3981 -28241 3913
--28292 3842 -28340 3764 -28382 3684 -28407 3603 -28417 3522 -28409 3441
--28381 3362 -28327 3287 -28244 3219 -28128 3157 -27980 3107 -27794 3069
--27569 3043 -27303 3035 -26993 3044 -26645 3073 -26255 3122 -25817 3198
--25342 3293 -24831 3417 -24284 3566 -23701 3743 -23089 3942 -22453 4171
--21798 4426 -21126 4700 -20443 4998 -19754 5327 -19069 5672 -18388 6026
--17718 6396 -17065 6789 -16431 7193 -15824 7603 -15248 8016 -14703 8431
--14188 8847 -13708 9265 -13270 9671 -12864 10057 -12485 10434 -12142 10814
--11826 11224 -11549 11578 -11289 11876 -11046 12153 -10825 12449 -10638 12757
--10477 13010 -10340 13135 -10231 13156 -10187 13172 -10183 13291 -10246 13508
--10447 13684 -10708 13647 -10834 13305 -11365 12708 -12405 12016 -13337 11387
--13931 10884 -14834 10442 -16222 9937 -17894 9231 -19732 8226 -21796 6931
--24108 5454 -26594 3890 -29105 2307 -31487 742 -33629 -740 -35480 -2076
--37027 -3239 -38283 -4236 -39284 -5080 -40059 -5778 -40619 -6336 -40978 -6763
--41154 -7065 -41165 -7218 -41020 -7232 -40731 -7139 -40307 -6976 -39768 -6747
--39123 -6443 -38386 -6057 -37568 -5598 -36683 -5074 -35743 -4488 -34747 -3849
--33711 -3171 -32660 -2483 -31587 -1796 -30445 -1099 -29262 -346 -28132 496
--26987 1313 -25793 2127 -24562 2921 -23312 3696 -22041 4462 -20740 5230
--19412 5995 -18071 6752 -16716 7506 -15342 8280 -13962 9039 -12597 9739
--11245 10449 -9910 11201 -8614 11928 -7380 12538 -6205 13022 -5073 13506
--4027 14148 -3129 14908 -2220 15458 -1657 15459 -1049 14929 -37 14343
-212 14340 -933 15228 -1924 16701 -1038 17920 1222 17850 2237 15648 -852 11022
--7902 4794 -14542 -207 -19424 -3247 -22812 -4342 -25572 -3798 -29216 -2402
--32535 -2170 -35401 -2626 -39279 -3430 -44613 -4383 -49805 -5330 -53937 -5876
--56880 -5953 -58928 -5687 -60428 -5225 -61612 -4681 -62589 -4118 -63366 -3568
--63917 -3052 -64255 -2578 -64380 -2147 -64289 -1741 -64030 -1339 -63665 -932
--63144 -546 -62511 -183 -61783 162 -60974 489 -60095 799 -59171 1095 -58208 1375
--57212 1639 -56188 1889 -55154 2126 -54115 2347 -53075 2556 -52038 2750
--51013 2931 -50009 3099 -49020 3257 -48059 3401 -47120 3532 -46213 3656
--45336 3771 -44492 3873 -43683 3969 -42907 4055 -42169 4133 -41469 4206
--40796 4271 -40163 4330 -39563 4381 -39001 4428 -38471 4470 -37972 4508
--37507 4543 -37072 4572 -36661 4598 -36285 4623 -35931 4644 -35605 4663
--35301 4680 -35021 4694 -34761 4706 -34523 4718 -34304 4726 -34102 4734
--33920 4742 -33749 4748 -33595 4754 -33453 4759 -33326 4763 -33210 4767
--33103 4770 -33009 4773 -32924 4775 -32844 4775 -32774 4779 -32713 4782
--32659 4785
-17: 3884712 578745 -30219 4010 -30279 4007 -30352 4000 -30432 3992 -30513 3982
--30594 3969 -30674 3956 -30753 3940 -30826 3923 -30890 3904 -30948 3884
--31001 3864 -31039 3844 -31070 3824 -31085 3805 -31091 3786 -31080 3769
--31059 3753 -31020 3741 -30969 3728 -30902 3720 -30823 3714 -30728 3709
--30617 3710 -30498 3714 -30364 3719 -30225 3729 -30073 3742 -29912 3758
--29749 3776 -29579 3798 -29409 3823 -29236 3849 -29068 3877 -28903 3907
--28742 3941 -28586 3974 -28440 4008 -28303 4043 -28175 4077 -28060 4113
--27956 4146 -27862 4179 -27782 4212 -27713 4240 -27656 4268 -27611 4290
--27575 4311 -27553 4329 -27539 4343 -27538 4354 -27543 4360 -27560 4355
--27580 4346 -27613 4328 -27651 4308 -27697 4279 -27747 4249 -27804 4213
--27865 4165 -27929 4114 -27994 4060 -28061 3996 -28125 3929 -28186 3859
--28238 3781 -28285 3702 -28321 3624 -28341 3543 -28341 3462 -28321 3384
--28278 3308 -28206 3239 -28105 3176 -27967 3121 -27794 3079 -27586 3047
--27335 3031 -27041 3032 -26706 3050 -26332 3088 -25914 3150 -25452 3232
--24952 3343 -24416 3478 -23848 3639 -23245 3823 -22613 4038 -21961 4281
--21290 4542 -20606 4828 -19910 5147 -19213 5485 -18520 5832 -17835 6198
--17165 6589 -16511 6997 -15881 7413 -15281 7826 -14716 8240 -14185 8661
--13686 9092 -13228 9524 -12811 9937 -12431 10329 -12080 10706 -11764 11092
--11480 11508 -11230 11845 -10995 12144 -10774 12451 -10572 12778 -10398 13081
--10244 13279 -10105 13357 -9991 13389 -9936 13493 -9880 13718 -10018 13967
--10111 14057 -10160 13840 -10475 13314 -11302 12632 -12110 12002 -12392 11562
--12868 11294 -14122 11052 -15906 10640 -17786 9881 -19715 8709 -21793 7202
--24112 5507 -26630 3742 -29212 1990 -31690 311 -33930 -1234 -35852 -2614
--37431 -3825 -38690 -4874 -39669 -5759 -40405 -6475 -40918 -7028 -41222 -7426
--41340 -7665 -41292 -7744 -41087 -7708 -40737 -7604 -40256 -7443 -39659 -7195
--38965 -6843 -38184 -6405 -37330 -5909 -36416 -5362 -35456 -4758 -34454 -4086
--33420 -3364 -32384 -2631 -31335 -1912 -30229 -1197 -29091 -437 -28012 408
--26925 1233 -25791 2049 -24628 2838 -23445 3607 -22244 4367 -21009 5125
--19743 5877 -18458 6615 -17152 7369 -15824 8141 -14481 8873 -13144 9579
--11820 10307 -10505 11053 -9226 11767 -8004 12377 -6839 12872 -5699 13394
--4681 14095 -3728 14879 -2864 15375 -2320 15270 -1469 14700 -441 14249
--610 14574 -1874 15903 -2139 17823 246 19403 4121 19536 5637 17210 1117 11662
--9522 3030 -17029 -2609 -21384 -5539 -8882 738 -23954 -4768 -43713 -8297
--31556 -1339 -33036 -2060 -36559 -3083 -43649 -4281 -50510 -5741 -55688 -6489
--58949 -6526 -60815 -6128 -61924 -5524 -62723 -4852 -63408 -4187 -63998 -3557
--64446 -2982 -64734 -2467 -64834 -2005 -64735 -1581 -64471 -1167 -64106 -754
--63584 -367 -62948 -2 -62221 341 -61408 666 -60525 973 -59595 1262 -58627 1538
--57623 1797 -56591 2042 -55550 2272 -54503 2489 -53454 2691 -52405 2880
--51370 3055 -50355 3217 -49356 3370 -48379 3506 -47431 3635 -46511 3752
--45624 3861 -44767 3960 -43944 4050 -43157 4131 -42407 4206 -41694 4272
--41011 4333 -40365 4388 -39757 4436 -39181 4480 -38639 4517 -38133 4552
--37657 4582 -37211 4609 -36793 4632 -36405 4654 -36045 4672 -35709 4690
--35400 4704 -35111 4715 -34845 4726 -34599 4735 -34374 4742 -34167 4749
--33979 4755 -33803 4760 -33644 4764 -33498 4769 -33366 4771 -33246 4775
--33135 4777 -33039 4778 -32950 4780 -32869 4782 -32796 4783 -32731 4786
--32677 4788
-18: 3904710 561849 -30343 4013 -30406 4008 -30478 4001 -30555 3993 -30633 3982
--30713 3969 -30789 3954 -30860 3937 -30929 3919 -30987 3900 -31037 3879
--31079 3858 -31108 3837 -31127 3816 -31133 3796 -31128 3777 -31103 3758
--31068 3743 -31017 3728 -30951 3716 -30874 3707 -30779 3699 -30672 3696
--30548 3696 -30415 3700 -30269 3706 -30118 3716 -29953 3729 -29783 3746
--29607 3767 -29428 3790 -29246 3816 -29066 3843 -28887 3875 -28715 3909
--28546 3944 -28382 3980 -28231 4017 -28087 4055 -27955 4093 -27837 4131
--27729 4165 -27634 4203 -27551 4236 -27485 4268 -27428 4295 -27386 4317
--27356 4337 -27338 4352 -27332 4366 -27337 4375 -27354 4377 -27379 4369
--27411 4348 -27453 4330 -27505 4300 -27564 4269 -27627 4231 -27694 4183
--27769 4132 -27841 4078 -27916 4014 -27990 3945 -28062 3874 -28124 3798
--28179 3720 -28222 3643 -28254 3562 -28267 3482 -28258 3403 -28225 3326
--28168 3258 -28079 3194 -27956 3137 -27798 3091 -27602 3052 -27368 3031
--27094 3023 -26773 3033 -26413 3060 -26011 3111 -25569 3179 -25083 3278
--24559 3397 -24003 3541 -23413 3710 -22792 3909 -22143 4137 -21476 4385
--20794 4656 -20098 4961 -19394 5289 -18691 5629 -17994 5985 -17308 6372
--16638 6779 -15989 7194 -15367 7609 -14778 8024 -14229 8445 -13714 8880
--13239 9328 -12803 9769 -12419 10184 -12071 10572 -11754 10951 -11473 11342
--11225 11739 -11010 12071 -10809 12394 -10613 12738 -10434 13074 -10275 13338
--10134 13479 -9990 13540 -9894 13627 -9749 13833 -9818 14118 -9807 14320
--9786 14252 -9908 13843 -10463 13199 -11119 12553 -11262 12125 -11338 11979
--12300 11997 -14150 11939 -16175 11541 -17983 10630 -19668 9194 -21529 7381
--23745 5391 -26302 3411 -29024 1552 -31711 -153 -34144 -1725 -36193 -3170
--37826 -4473 -39076 -5599 -40011 -6518 -40689 -7223 -41140 -7732 -41381 -8058
--41435 -8213 -41324 -8238 -41061 -8194 -40653 -8101 -40116 -7926 -39468 -7624
--38727 -7210 -37907 -6725 -37020 -6204 -36083 -5642 -35111 -5005 -34108 -4287
--33086 -3515 -32073 -2748 -31058 -2015 -29998 -1296 -28919 -532 -27904 317
--26886 1164 -25828 1975 -24742 2754 -23643 3512 -22523 4256 -21368 4993
--20175 5720 -18955 6444 -17709 7195 -16432 7943 -15134 8662 -13835 9373
--12541 10093 -11257 10825 -10000 11548 -8802 12156 -7652 12639 -6530 13177
--5538 13930 -4559 14736 -3787 15174 -3215 14987 -2202 14411 -1321 14099
--1795 14675 -3051 16294 -2526 18482 1074 20305 6153 20697 8161 18627 8500 15969
--13737 -193 -24990 -7300 -23717 -7537 -23169 -7208 -22652 -6035 -25721 1208
--27864 319 -27043 -936 -28693 -1700 -51507 -7568 -50420 -6037 -57298 -6946
--61207 -6857 -62946 -6314 -63588 -5593 -63881 -4834 -64172 -4098 -64505 -3417
--64810 -2804 -65025 -2263 -65101 -1785 -64994 -1350 -64737 -933 -64380 -520
--63868 -135 -63242 225 -62523 562 -61717 882 -60840 1181 -59914 1464 -58947 1731
--57944 1984 -56913 2221 -55869 2444 -54820 2653 -53765 2849 -52713 3029
--51672 3198 -50648 3354 -49643 3497 -48660 3630 -47700 3751 -46771 3862
--45876 3965 -45011 4058 -44177 4143 -43380 4218 -42621 4287 -41897 4349
--41205 4404 -40549 4455 -39929 4498 -39346 4538 -38796 4572 -38278 4602
--37793 4627 -37340 4650 -36915 4672 -36516 4690 -36151 4706 -35806 4719
--35490 4730 -35194 4739 -34922 4748 -34671 4756 -34439 4761 -34226 4766
--34034 4770 -33853 4774 -33689 4776 -33538 4780 -33402 4780 -33280 4784
--33166 4785 -33065 4786 -32974 4787 -32890 4788 -32814 4788 -32751 4789
--32692 4791
-19: 3924614 544945 -30473 4016 -30533 4010 -30605 4003 -30681 3994 -30755 3983
--30830 3968 -30901 3954 -30965 3935 -31026 3916 -31078 3896 -31118 3874
--31147 3853 -31166 3829 -31174 3809 -31168 3787 -31149 3767 -31112 3749
--31060 3731 -30999 3716 -30916 3704 -30825 3693 -30715 3686 -30595 3683
--30459 3682 -30311 3685 -30153 3693 -29989 3704 -29814 3717 -29631 3735
--29445 3758 -29255 3781 -29063 3809 -28876 3839 -28689 3874 -28506 3910
--28331 3947 -28163 3986 -28004 4027 -27856 4068 -27722 4108 -27597 4147
--27489 4187 -27391 4226 -27311 4261 -27243 4294 -27189 4321 -27152 4343
--27126 4360 -27114 4376 -27116 4388 -27128 4397 -27156 4394 -27191 4379
--27235 4355 -27290 4325 -27353 4293 -27424 4252 -27500 4203 -27581 4154
--27665 4099 -27750 4032 -27832 3962 -27916 3891 -27991 3814 -28058 3737
--28114 3660 -28158 3578 -28183 3497 -28189 3419 -28170 3344 -28125 3275
--28051 3209 -27946 3151 -27804 3101 -27623 3060 -27405 3033 -27146 3018
--26847 3020 -26500 3039 -26116 3078 -25688 3136 -25221 3219 -24712 3325
--24167 3450 -23590 3606 -22982 3788 -22346 3997 -21683 4230 -21003 4486
--20310 4772 -19607 5090 -18898 5420 -18191 5764 -17493 6140 -16808 6543
--16144 6954 -15502 7366 -14890 7781 -14315 8206 -13786 8644 -13295 9097
--12845 9551 -12443 9989 -12093 10397 -11785 10782 -11508 11165 -11270 11560
--11067 11925 -10893 12269 -10728 12632 -10566 12999 -10419 13314 -10287 13521
--10155 13621 -10038 13705 -9869 13875 -9823 14161 -9790 14441 -9680 14525
--9697 14271 -9984 13717 -10419 13067 -10517 12601 -10369 12492 -10904 12709
--12611 13014 -14769 13076 -16532 12589 -17778 11407 -18941 9590 -20557 7356
--22850 5005 -25669 2854 -28762 1030 -31840 -591 -34586 -2197 -36767 -3779
--38380 -5224 -39538 -6426 -40362 -7342 -40932 -7989 -41286 -8415 -41441 -8650
--41424 -8745 -41250 -8757 -40930 -8726 -40471 -8620 -39884 -8384 -39187 -8000
--38404 -7523 -37551 -7010 -36636 -6475 -35679 -5889 -34700 -5207 -33706 -4435
--32701 -3630 -31720 -2851 -30751 -2118 -29752 -1397 -28743 -626 -27805 236
--26867 1112 -25895 1913 -24903 2679 -23900 3409 -22877 4125 -21815 4831
--20704 5533 -19561 6245 -18381 6975 -17164 7695 -15915 8409 -14659 9105
--13405 9798 -12155 10541 -10930 11274 -9763 11849 -8636 12296 -7554 12864
--6584 13677 -5625 14488 -4957 14861 -4348 14611 -3293 14054 -2560 13849
--3353 14551 -4344 16239 -3697 18417 488 20197 5702 20570 7783 18569 3138 12851
--18256 -2010 -22760 -5710 -22183 -6396 -26618 -8927 -28635 -8168 -25577 71
--24967 825 -23091 -1494 -23078 -1483 -32329 -299 -52467 -7674 -57855 -6913
--62989 -6622 -64850 -6029 -65092 -5307 -64880 -4547 -64757 -3806 -64812 -3118
--64963 -2498 -65108 -1956 -65161 -1478 -65060 -1047 -64820 -634 -64485 -230
--63996 146 -63389 496 -62690 825 -61900 1134 -61038 1423 -60126 1697 -59170 1954
--58175 2197 -57151 2425 -56111 2640 -55065 2839 -54011 3027 -52961 3198
--51917 3359 -50891 3507 -49883 3643 -48895 3767 -47931 3882 -46996 3986
--46095 4083 -45221 4167 -44381 4246 -43576 4315 -42811 4378 -42076 4434
--41378 4485 -40715 4529 -40086 4568 -39495 4602 -38937 4631 -38410 4658
--37918 4680 -37458 4698 -37025 4716 -36618 4730 -36246 4743 -35897 4752
--35575 4760 -35269 4768 -34993 4774 -34738 4778 -34499 4783 -34281 4783
--34083 4788 -33897 4790 -33731 4790 -33577 4791 -33436 4793 -33309 4793
--33193 4793 -33090 4795 -32994 4794 -32909 4795 -32832 4794 -32766 4795
--32705 4796
-20: 3944427 528034 -30608 4020 -30666 4014 -30732 4006 -30805 3996 -30876 3983
--30945 3969 -31008 3953 -31066 3934 -31117 3913 -31159 3892 -31189 3870
--31206 3847 -31212 3823 -31209 3801 -31188 3779 -31155 3757 -31104 3738
--31038 3720 -30959 3704 -30863 3691 -30756 3680 -30634 3674 -30496 3668
--30347 3668 -30188 3673 -30015 3679 -29839 3690 -29651 3706 -29458 3724
--29263 3748 -29061 3772 -28863 3803 -28665 3837 -28470 3872 -28282 3910
--28098 3950 -27926 3993 -27762 4037 -27610 4080 -27472 4123 -27346 4165
--27235 4209 -27138 4248 -27057 4286 -26991 4318 -26941 4346 -26906 4367
--26887 4385 -26883 4401 -26891 4411 -26912 4415 -26951 4408 -27000 4386
--27052 4355 -27119 4321 -27197 4279 -27280 4230 -27370 4181 -27462 4124
--27559 4053 -27654 3981 -27747 3910 -27839 3833 -27920 3754 -27991 3675
--28047 3591 -28088 3508 -28110 3431 -28109 3356 -28081 3289 -28023 3222
--27933 3162 -27810 3109 -27648 3065 -27447 3036 -27205 3015 -26922 3012
--26598 3022 -26227 3053 -25816 3100 -25366 3168 -24874 3260 -24343 3368
--23777 3508 -23182 3675 -22559 3866 -21908 4080 -21233 4319 -20545 4589
--19844 4890 -19136 5208 -18424 5539 -17715 5900 -17019 6293 -16340 6699
--15682 7103 -15051 7514 -14453 7942 -13897 8387 -13390 8841 -12927 9298
--12508 9745 -12143 10169 -11835 10572 -11574 10961 -11343 11349 -11161 11741
--11000 12086 -10881 12458 -10772 12851 -10659 13213 -10543 13480 -10434 13632
--10324 13726 -10192 13865 -10045 14120 -10007 14435 -9852 14648 -9781 14572
--9898 14159 -10104 13548 -10124 13021 -9900 12855 -10048 13147 -11344 13744
--13432 14299 -15216 14390 -16100 13699 -16434 12130 -17170 9816 -18924 7043
--21744 4268 -25259 2046 -28883 476 -32528 -914 -35544 -2624 -37716 -4450
--39160 -6075 -40088 -7325 -40694 -8190 -41091 -8747 -41320 -9076 -41386 -9245
--41298 -9312 -41068 -9328 -40697 -9278 -40189 -9098 -39554 -8755 -38817 -8287
--37996 -7772 -37106 -7253 -36170 -6707 -35201 -6083 -34224 -5352 -33232 -4545
--32268 -3729 -31332 -2957 -30415 -2226 -29480 -1490 -28557 -694 -27696 190
--26864 1078 -25990 1867 -25104 2603 -24215 3294 -23303 3972 -22344 4648
--21328 5323 -20269 6008 -19165 6700 -18013 7402 -16820 8101 -15611 8760
--14399 9443 -13188 10209 -12000 10921 -10871 11430 -9774 11861 -8750 12489
--7800 13349 -6903 14126 -6330 14420 -5725 14142 -4662 13639 -4239 13502
--4800 14187 -6321 15714 -5491 17607 -1823 19029 2024 19016 3062 16609
--1743 10885 -13838 1574 -20928 -3934 -24835 -7021 -26654 -8016 -26855 -6770
--25688 -3168 -24729 -2850 -23899 -4934 -28245 -105 -19518 2758 -38680 -4888
--51235 -4080 -70541 -7722 -65763 -5118 -65937 -4611 -65409 -3968 -64976 -3296
--64817 -2650 -64850 -2061 -64950 -1544 -65002 -1084 -64923 -672 -64717 -275
--64420 113 -63964 474 -63390 810 -62722 1126 -61961 1421 -61122 1697 -60232 1958
--59296 2204 -58317 2435 -57305 2653 -56278 2856 -55239 3047 -54193 3222
--53149 3386 -52109 3537 -51083 3676 -50075 3803 -49088 3921 -48121 4026
--47185 4123 -46279 4211 -45401 4288 -44557 4359 -43747 4423 -42975 4479
--42236 4528 -41530 4573 -40861 4611 -40225 4644 -39629 4673 -39063 4697
--38531 4719 -38031 4737 -37563 4750 -37124 4765 -36713 4775 -36333 4784
--35979 4789 -35649 4796 -35340 4799 -35059 4802 -34798 4804 -34554 4806
--34332 4805 -34127 4808 -33940 4806 -33769 4805 -33612 4805 -33466 4806
--33336 4805 -33219 4803 -33111 4804 -33011 4802 -32926 4801 -32847 4800
--32778 4802 -32717 4802
-21: 3964143 511118 -30740 4025 -30797 4019 -30860 4009 -30928 3999 -30994 3986
--31056 3970 -31111 3952 -31161 3932 -31199 3912 -31231 3889 -31250 3865
--31254 3841 -31247 3817 -31228 3793 -31193 3770 -31145 3748 -31079 3727
--30997 3709 -30902 3691 -30790 3678 -30666 3667 -30530 3659 -30380 3655
--30217 3655 -30041 3658 -29857 3665 -29666 3678 -29468 3693 -29265 3714
--29058 3736 -28848 3765 -28640 3797 -28437 3833 -28233 3870 -28039 3910
--27851 3954 -27671 4000 -27507 4045 -27349 4093 -27208 4139 -27079 4184
--26969 4229 -26873 4270 -26793 4308 -26729 4342 -26683 4371 -26653 4394
--26640 4411 -26645 4425 -26660 4432 -26691 4430 -26740 4418 -26800 4390
--26865 4355 -26946 4312 -27037 4262 -27134 4214 -27237 4153 -27342 4079
--27450 4004 -27559 3934 -27660 3854 -27760 3770 -27849 3689 -27923 3601
--27980 3517 -28021 3440 -28038 3366 -28029 3297 -27993 3230 -27921 3167
--27817 3113 -27674 3068 -27495 3036 -27271 3014 -27007 3004 -26699 3010
--26350 3030 -25954 3070 -25518 3123 -25044 3201 -24531 3297 -23979 3419
--23394 3571 -22781 3744 -22146 3938 -21482 4161 -20798 4411 -20103 4694
--19398 4998 -18688 5313 -17974 5654 -17268 6035 -16576 6433 -15905 6829
--15258 7230 -14638 7657 -14055 8106 -13524 8564 -13043 9018 -12610 9461
--12228 9891 -11904 10310 -11644 10718 -11436 11116 -11271 11505 -11133 11891
--11048 12243 -10993 12639 -10930 13034 -10855 13356 -10784 13565 -10712 13685
--10648 13809 -10488 14022 -10420 14331 -10303 14623 -10112 14717 -10144 14486
--10227 13973 -10122 13410 -9834 13113 -9737 13321 -10496 14035 -12219 14994
--13964 15737 -14678 15773 -14284 14775 -13921 12723 -14679 9833 -17178 6430
--21209 3103 -25654 935 -29704 -35 -33860 -921 -37106 -2923 -39027 -5159
--40014 -6989 -40535 -8249 -40857 -9035 -41078 -9497 -41197 -9749 -41188 -9875
--41041 -9925 -40762 -9905 -40344 -9762 -39798 -9451 -39133 -8994 -38349 -8476
--37482 -7964 -36584 -7453 -35626 -6890 -34651 -6225 -33658 -5457 -32726 -4642
--31778 -3837 -30874 -3072 -30019 -2324 -29181 -1551 -28332 -713 -27626 196
--26857 1064 -26110 1825 -25350 2518 -24578 3165 -23788 3806 -22949 4444
--22046 5081 -21080 5718 -20058 6371 -18972 7059 -17835 7721 -16676 8345
--15509 9045 -14340 9814 -13193 10462 -12106 10918 -11047 11381 -10085 12072
--9164 12923 -8350 13615 -7872 13850 -7273 13613 -6430 13211 -5789 13104
--6858 13640 -8186 14834 -7587 16285 -5438 17277 -2962 16956 -2333 14572
--5768 9741 -13346 3166 -19755 -1944 -24001 -5195 -26137 -6567 -26488 -6101
--25262 -4180 -23638 -2566 -26659 -3956 -28916 -4142 -24221 -3418 -24345 -3242
--45529 -612 -56674 -2079 -71723 -5706 -65650 -3627 -65180 -3160 -64669 -2598
--64432 -2034 -64428 -1507 -64532 -1035 -64616 -615 -64582 -231 -64430 140
--64187 503 -63781 843 -63252 1161 -62623 1459 -61899 1738 -61097 2000
--60236 2246 -59327 2478 -58372 2696 -57380 2901 -56370 3092 -55347 3272
--54313 3437 -53277 3590 -52247 3730 -51227 3861 -50222 3978 -49237 4086
--48273 4182 -47338 4271 -46430 4351 -45552 4420 -44704 4484 -43892 4539
--43116 4589 -42372 4630 -41663 4668 -40989 4701 -40349 4726 -39746 4751
--39175 4770 -38638 4785 -38133 4799 -37657 4809 -37215 4817 -36797 4824
--36413 4828 -36051 4830 -35717 4834 -35406 4834 -35118 4833 -34850 4832
--34606 4833 -34378 4829 -34169 4828 -33980 4826 -33802 4823 -33642 4820
--33495 4820 -33360 4818 -33240 4815 -33130 4813 -33028 4810 -32941 4810
--32859 4808 -32789 4808 -32727 4806
-22: 3983768 494201 -30874 4030 -30928 4024 -30986 4014 -31048 4003 -31107 3988
--31161 3972 -31207 3952 -31248 3932 -31273 3910 -31294 3885 -31298 3861
--31290 3835 -31268 3811 -31233 3785 -31180 3761 -31117 3738 -31034 3716
--30940 3697 -30825 3678 -30698 3665 -30557 3653 -30406 3644 -30241 3641
--30061 3640 -29873 3643 -29679 3652 -29474 3664 -29264 3681 -29051 3701
--28834 3727 -28617 3757 -28399 3791 -28187 3827 -27979 3866 -27778 3912
--27587 3958 -27404 4006 -27234 4054 -27076 4105 -26931 4155 -26803 4202
--26692 4247 -26597 4290 -26520 4331 -26458 4368 -26418 4399 -26394 4420
--26387 4436 -26398 4445 -26424 4449 -26465 4445 -26524 4428 -26597 4395
--26676 4354 -26770 4304 -26875 4251 -26985 4188 -27101 4108 -27221 4033
--27344 3962 -27462 3879 -27577 3788 -27682 3701 -27778 3611 -27858 3525
--27917 3447 -27957 3371 -27969 3300 -27954 3230 -27908 3165 -27824 3111
--27704 3066 -27544 3034 -27344 3010 -27100 2996 -26812 2998 -26480 3010
--26105 3040 -25687 3084 -25224 3148 -24728 3234 -24194 3339 -23622 3479
--23018 3633 -22393 3806 -21745 4013 -21072 4245 -20380 4505 -19682 4791
--18976 5090 -18264 5410 -17554 5771 -16851 6160 -16167 6549 -15505 6937
--14870 7351 -14265 7800 -13703 8263 -13194 8717 -12744 9151 -12345 9576
--12000 9999 -11723 10427 -11524 10851 -11382 11256 -11242 11638 -11203 12016
--11201 12392 -11186 12792 -11190 13153 -11192 13414 -11182 13577 -11181 13704
--11097 13884 -11000 14160 -10966 14480 -10694 14699 -10630 14656 -10726 14301
--10551 13763 -10154 13331 -9901 13318 -10216 13905 -11381 15011 -12895 16280
--13623 17167 -12910 17090 -11512 15701 -10886 13099 -12263 9656 -16123 5624
--21848 1435 -27467 -555 -30811 -380 -35780 -156 -38966 -3000 -40165 -5894
--40490 -7933 -40584 -9165 -40672 -9864 -40768 -10250 -40822 -10446 -40772 -10525
--40602 -10512 -40292 -10379 -39876 -10082 -39312 -9628 -38580 -9106 -37775 -8601
--36925 -8124 -35966 -7622 -35003 -7032 -33991 -6332 -33083 -5552 -32087 -4751
--31174 -3959 -30360 -3181 -29611 -2387 -28826 -1555 -28190 -671 -27464 250
--26891 1060 -26252 1778 -25599 2423 -24981 3030 -24350 3626 -23645 4212
--22849 4787 -21977 5368 -21040 5993 -20028 6656 -18953 7273 -17845 7887
--16724 8602 -15594 9332 -14491 9911 -13442 10363 -12429 10889 -11526 11594
--10647 12359 -9921 12947 -9510 13190 -9059 13082 -8189 12816 -7797 12692
--8872 12986 -9713 13760 -10112 14750 -9383 15391 -7831 14985 -7018 12951
--9200 9147 -14326 4238 -19675 -202 -23668 -3446 -25963 -5231 -26834 -5699
--27414 -5860 -24131 -3047 -25445 -904 -27079 -5695 -23921 -3305 -19655 -6228
--38352 1588 -53471 -1613 -65985 -3614 -64119 -2603 -64108 -2225 -63783 -1774
--63635 -1310 -63692 -865 -63859 -456 -64012 -86 -64050 259 -63969 598
--63798 932 -63451 1247 -62980 1543 -62403 1820 -61726 2080 -60966 2327
--60143 2557 -59270 2772 -58344 2976 -57379 3168 -56392 3346 -55388 3514
--54372 3667 -53350 3808 -52332 3939 -51323 4057 -50326 4166 -49346 4263
--48388 4351 -47456 4431 -46550 4501 -45672 4562 -44825 4617 -44011 4664
--43234 4706 -42490 4742 -41776 4771 -41098 4796 -40456 4817 -39848 4833
--39273 4849 -38732 4858 -38222 4865 -37743 4871 -37295 4876 -36875 4876
--36483 4876 -36117 4875 -35779 4874 -35464 4872 -35170 4867 -34900 4864
--34649 4860 -34420 4855 -34208 4851 -34013 4847 -33834 4843 -33670 4837
--33518 4835 -33382 4831 -33259 4828 -33148 4823 -33042 4821 -32953 4818
--32870 4817 -32798 4815 -32733 4813
-23: 4003304 477284 -31005 4037 -31056 4031 -31109 4019 -31165 4007 -31215 3992
--31259 3974 -31296 3953 -31325 3931 -31339 3907 -31344 3883 -31333 3856
--31312 3830 -31275 3803 -31220 3777 -31153 3752 -31072 3727 -30972 3705
--30861 3683 -30728 3666 -30585 3651 -30428 3637 -30262 3630 -30079 3626
--29888 3624 -29685 3628 -29477 3637 -29260 3650 -29039 3666 -28817 3689
--28591 3718 -28365 3747 -28141 3782 -27924 3821 -27707 3865 -27502 3912
--27308 3961 -27123 4011 -26947 4064 -26789 4117 -26644 4168 -26515 4217
--26406 4266 -26311 4312 -26240 4357 -26181 4396 -26145 4426 -26127 4444
--26129 4456 -26148 4464 -26182 4466 -26235 4460 -26307 4440 -26392 4403
--26483 4353 -26593 4296 -26710 4228 -26837 4146 -26966 4070 -27103 3998
--27237 3909 -27370 3808 -27494 3715 -27611 3623 -27712 3534 -27798 3452
--27860 3374 -27897 3296 -27908 3221 -27886 3156 -27831 3101 -27734 3058
--27598 3025 -27421 3002 -27201 2985 -26936 2980 -26624 2989 -26267 3011
--25869 3047 -25424 3101 -24940 3178 -24421 3274 -23864 3395 -23274 3536
--22655 3688 -22018 3874 -21358 4092 -20680 4328 -19984 4589 -19282 4872
--18580 5172 -17871 5509 -17165 5882 -16468 6264 -15794 6639 -15143 7034
--14523 7472 -13934 7936 -13392 8392 -12910 8823 -12491 9235 -12127 9656
--11826 10095 -11611 10548 -11463 10983 -11332 11378 -11389 11743 -11407 12111
--11380 12505 -11490 12881 -11608 13185 -11690 13394 -11750 13546 -11772 13713
--11703 13955 -11751 14262 -11506 14543 -11321 14652 -11467 14483 -11367 14052
--10887 13551 -10474 13285 -10526 13538 -11183 14430 -12276 15831 -13034 17349
--12518 18372 -10673 18196 -8716 16325 -8469 13074 -10870 9266 -16383 4947
--24188 -693 -29632 -2903 -30592 -321 -36666 2283 -38170 -2845 -45525 -6547
--40009 -8864 -39821 -10020 -39834 -10645 -39954 -10975 -40058 -11110
--40071 -11102 -39936 -10958 -39709 -10653 -39273 -10194 -38646 -9660
--37989 -9158 -37186 -8717 -36207 -8286 -35277 -7778 -34257 -7152 -33354 -6428
--32268 -5658 -31380 -4874 -30590 -4078 -29850 -3254 -29114 -2391 -28569 -1494
--27785 -578 -27350 328 -26899 1057 -26393 1726 -25943 2330 -25470 2892
--24955 3423 -24379 3935 -23718 4438 -22968 4969 -22125 5577 -21187 6201
--20167 6783 -19104 7401 -18021 8106 -16928 8772 -15866 9312 -14848 9806
--13886 10373 -13037 11013 -12212 11642 -11559 12167 -11235 12506 -10893 12595
--10110 12460 -10109 12267 -10424 12273 -11523 12633 -12726 13234 -12955 13665
--11688 13341 -10922 11774 -12478 8845 -16310 4996 -20576 1118 -23823 -2073
--25840 -4111 -27563 -5314 -26133 -5564 -23291 -1514 -22174 -6087 -25384 -3687
--23891 -2048 -24105 -3378 -31807 -1489 -48559 -1322 -60452 -1874 -61655 -1438
--62368 -1197 -62423 -886 -62487 -538 -62684 -181 -62963 161 -63215 479
--63348 782 -63354 1085 -63264 1389 -62992 1675 -62587 1948 -62070 2203
--61449 2444 -60737 2672 -59962 2885 -59129 3084 -58238 3273 -57307 3450
--56347 3616 -55368 3769 -54375 3910 -53370 4040 -52369 4160 -51373 4267
--50388 4364 -49417 4451 -48468 4531 -47539 4600 -46639 4661 -45766 4712
--44919 4759 -44107 4798 -43331 4831 -42585 4860 -41871 4881 -41191 4898
--40548 4913 -39934 4923 -39357 4932 -38814 4935 -38301 4938 -37819 4938
--37365 4936 -36941 4932 -36546 4928 -36177 4924 -35835 4919 -35514 4912
--35217 4904 -34946 4897 -34689 4890 -34457 4884 -34240 4876 -34045 4870
--33861 4863 -33693 4856 -33542 4851 -33401 4846 -33275 4841 -33161 4837
--33055 4831 -32962 4828 -32879 4825 -32804 4822 -32739 4821
-24: 4022755 460372 -31132 4045 -31180 4037 -31228 4026 -31275 4012 -31317 3995
--31351 3976 -31377 3955 -31391 3930 -31392 3906 -31381 3879 -31357 3852
--31319 3824 -31264 3795 -31194 3769 -31109 3741 -31007 3716 -30892 3693
--30761 3670 -30612 3652 -30450 3634 -30280 3623 -30096 3615 -29896 3608
--29693 3607 -29476 3613 -29256 3621 -29026 3633 -28796 3652 -28563 3676
--28329 3705 -28096 3736 -27866 3772 -27641 3816 -27423 3863 -27212 3912
--27014 3962 -26828 4015 -26650 4072 -26492 4126 -26346 4181 -26219 4233
--26110 4286 -26020 4338 -25951 4384 -25899 4422 -25867 4447 -25854 4466
--25867 4476 -25892 4485 -25940 4487 -26002 4479 -26088 4453 -26187 4408
--26290 4347 -26414 4275 -26547 4194 -26690 4117 -26834 4043 -26986 3947
--27134 3835 -27282 3734 -27418 3642 -27544 3547 -27654 3458 -27746 3372
--27811 3286 -27848 3206 -27856 3137 -27828 3084 -27763 3042 -27655 3010
--27503 2984 -27311 2965 -27069 2957 -26782 2962 -26445 2980 -26066 3012
--25641 3061 -25173 3130 -24665 3219 -24125 3322 -23546 3450 -22937 3584
--22305 3748 -21657 3949 -20991 4166 -20307 4397 -19610 4658 -18911 4944
--18212 5255 -17510 5605 -16811 5975 -16122 6339 -15460 6711 -14823 7131
--14218 7587 -13645 8046 -13124 8475 -12671 8880 -12283 9292 -11964 9735
--11714 10207 -11518 10676 -11419 11099 -11571 11464 -11508 11802 -11541 12158
--11766 12549 -11997 12886 -12182 13137 -12313 13327 -12429 13509 -12454 13735
--12574 14016 -12460 14306 -12232 14502 -12358 14493 -12440 14220 -12000 13764
--11434 13332 -11317 13207 -11693 13625 -12372 14664 -12978 16190 -12855 17856
--11449 19074 -9069 18936 -7093 16458 -7903 12213 -12177 7596 -18230 5088
--28161 -2366 -36875 -2871 -28921 -740 -38692 6528 -36948 -3553 -35372 -7541
--43673 -9642 -37796 -10654 -38132 -11270 -38538 -11571 -38905 -11629
--39094 -11490 -39163 -11175 -38897 -10704 -38489 -10157 -38080 -9648
--37309 -9240 -36366 -8882 -35489 -8469 -34476 -7924 -33575 -7257 -32409 -6524
--31538 -5769 -30755 -4992 -29955 -4161 -29183 -3267 -28670 -2326 -27928 -1379
--27621 -463 -27319 394 -26917 1055 -26598 1687 -26194 2247 -25855 2744
--25564 3189 -25201 3616 -24698 4054 -24059 4557 -23298 5140 -22419 5719
--21446 6280 -20421 6899 -19371 7558 -18310 8164 -17284 8707 -16295 9248
--15381 9794 -14583 10307 -13815 10811 -13222 11349 -12997 11854 -12675 12144
--12356 12092 -12066 11790 -12250 11521 -13490 11551 -15249 11896 -15539 12249
--14612 12100 -14231 10988 -15822 8739 -18890 5586 -21925 2065 -23993 -1225
--26472 -4278 -25224 -4304 -22238 -4392 -22964 -4985 -24037 -3597 -23334 -3333
--23382 -2009 -23652 -1370 -28836 -3111 -45885 -804 -56386 -464 -59143 -343
--60372 -225 -60794 -38 -61103 211 -61477 493 -61894 777 -62265 1051 -62504 1318
--62606 1587 -62608 1861 -62418 2120 -62087 2368 -61637 2601 -61079 2822
--60423 3030 -59699 3227 -58911 3409 -58065 3583 -57169 3745 -56242 3897
--55292 4037 -54323 4166 -53342 4283 -52360 4391 -51380 4487 -50412 4573
--49452 4651 -48511 4718 -47592 4778 -46700 4829 -45832 4871 -44990 4908
--44180 4939 -43404 4963 -42662 4984 -41946 4997 -41266 5008 -40624 5013
--40008 5019 -39430 5020 -38882 5018 -38370 5014 -37884 5008 -37427 5001
--36999 4993 -36599 4984 -36232 4975 -35883 4967 -35560 4954 -35260 4943
--34985 4933 -34725 4922 -34489 4914 -34270 4904 -34070 4894 -33884 4885
--33716 4876 -33562 4868 -33419 4862 -33289 4856 -33171 4851 -33065 4844
--32969 4838 -32885 4834 -32810 4831 -32743 4829
-25: 4042123 443468 -31254 4053 -31298 4045 -31340 4033 -31378 4017 -31411 4000
--31434 3979 -31447 3955 -31446 3931 -31434 3903 -31406 3876 -31365 3846
--31309 3817 -31236 3788 -31150 3759 -31048 3731 -30928 3704 -30791 3679
--30640 3656 -30475 3635 -30298 3620 -30109 3607 -29910 3596 -29694 3590
--29476 3591 -29247 3594 -29014 3602 -28776 3616 -28534 3637 -28291 3661
--28049 3689 -27810 3723 -27576 3764 -27346 3811 -27122 3858 -26909 3908
--26708 3961 -26520 4019 -26345 4078 -26184 4136 -26040 4194 -25915 4251
--25809 4309 -25722 4362 -25656 4407 -25610 4442 -25585 4468 -25581 4488
--25601 4502 -25637 4510 -25694 4511 -25769 4496 -25869 4465 -25980 4409
--26098 4332 -26236 4251 -26388 4176 -26544 4097 -26706 3994 -26873 3871
--27038 3763 -27198 3668 -27348 3569 -27488 3465 -27607 3368 -27704 3271
--27775 3183 -27811 3113 -27817 3059 -27783 3019 -27710 2984 -27590 2956
--27424 2933 -27212 2923 -26951 2929 -26641 2945 -26282 2978 -25876 3025
--25428 3088 -24935 3170 -24403 3262 -23838 3370 -23241 3493 -22615 3633
--21970 3816 -21314 4016 -20644 4220 -19958 4453 -19263 4725 -18568 5016
--17878 5336 -17184 5686 -16494 6038 -15818 6391 -15168 6782 -14547 7223
--13957 7682 -13401 8114 -12901 8514 -12476 8915 -12135 9353 -11840 9835
--11599 10330 -11531 10785 -11659 11165 -11502 11485 -11617 11798 -11916 12142
--12349 12518 -12586 12816 -12795 13047 -13017 13261 -13180 13500 -13391 13775
--13450 14052 -13361 14272 -13406 14355 -13618 14233 -13376 13901 -12757 13456
--12469 13091 -12747 13031 -13230 13448 -13577 14385 -13561 15756 -12883 17361
--11330 18821 -10790 17620 -6683 16798 -9896 10332 -15347 5678 -26657 1248
--36398 765 -36391 5708 -31819 -3191 -35268 5147 -29258 -3023 -29403 -7263
--38556 -9412 -34690 -10830 -35798 -11601 -36792 -11926 -37530 -11906
--38047 -11628 -38073 -11170 -38029 -10619 -37922 -10102 -37228 -9711
--36446 -9421 -35637 -9109 -34679 -8657 -33766 -8042 -32579 -7331 -31657 -6599
--30857 -5858 -29940 -5067 -29066 -4181 -28503 -3210 -27892 -2207 -27634 -1239
--27424 -356 -27068 426 -26852 1068 -26569 1671 -26445 2177 -26428 2585
--26371 2938 -26159 3292 -25763 3684 -25210 4163 -24522 4704 -23700 5235
--22770 5780 -21779 6375 -20756 6975 -19725 7541 -18723 8106 -17761 8660
--16881 9123 -16123 9501 -15420 9939 -14896 10556 -14673 11232 -14532 11661
--14441 11628 -14049 11211 -14219 10751 -15785 10590 -17184 10828 -17278 11208
--16868 11260 -17403 10531 -19260 8803 -21611 6149 -23171 2871 -24912 -1181
--22188 -3069 -23096 -4572 -22106 -5449 -22421 -4533 -22694 -1851 -24412 -3656
--22776 -1524 -21958 -1592 -28425 -1482 -43741 -575 -53136 393 -56753 464
--58332 541 -59050 669 -59592 868 -60144 1110 -60704 1363 -61199 1608 -61551 1848
--61757 2090 -61851 2337 -61746 2572 -61495 2796 -61121 3007 -60627 3209
--60034 3398 -59364 3576 -58628 3744 -57828 3902 -56972 4050 -56080 4187
--55165 4315 -54225 4429 -53268 4536 -52307 4631 -51349 4716 -50397 4791
--49452 4858 -48525 4916 -47616 4963 -46732 5005 -45871 5037 -45037 5064
--44231 5086 -43460 5102 -42718 5113 -42006 5120 -41327 5121 -40683 5122
--40069 5119 -39491 5112 -38942 5104 -38425 5094 -37939 5083 -37480 5070
--37048 5057 -36648 5043 -36277 5029 -35925 5015 -35600 4999 -35297 4985
--35019 4972 -34757 4958 -34517 4945 -34296 4932 -34093 4921 -33905 4909
--33735 4897 -33577 4888 -33433 4879 -33300 4872 -33181 4864 -33073 4856
--32976 4850 -32889 4845 -32814 4840 -32745 4836
-26: 4061416 426575 -31373 4063 -31409 4053 -31445 4040 -31473 4024 -31495 4004
--31505 3981 -31503 3957 -31490 3930 -31460 3902 -31418 3871 -31359 3841
--31283 3810 -31193 3779 -31088 3748 -30967 3719 -30828 3691 -30672 3665
--30502 3640 -30321 3619 -30124 3603 -29917 3587 -29701 3576 -29477 3572
--29239 3572 -28999 3573 -28754 3582 -28506 3598 -28254 3619 -28003 3643
--27755 3672 -27509 3711 -27269 3755 -27037 3801 -26811 3849 -26595 3902
--26392 3959 -26205 4022 -26029 4084 -25869 4146 -25727 4209 -25605 4271
--25502 4329 -25420 4380 -25359 4423 -25318 4461 -25301 4493 -25305 4518
--25332 4533 -25381 4537 -25449 4531 -25537 4511 -25649 4473 -25775 4408
--25909 4322 -26062 4246 -26230 4162 -26403 4052 -26583 3919 -26766 3803
--26948 3706 -27125 3600 -27289 3478 -27440 3361 -27572 3255 -27676 3160
--27752 3084 -27791 3029 -27795 2985 -27756 2947 -27673 2914 -27542 2887
--27360 2876 -27132 2885 -26852 2906 -26519 2941 -26136 2988 -25704 3050
--25230 3125 -24710 3204 -24155 3296 -23567 3407 -22951 3531 -22308 3689
--21652 3878 -20990 4060 -20318 4265 -19635 4518 -18944 4794 -18260 5085
--17580 5401 -16897 5739 -16221 6078 -15557 6437 -14924 6853 -14318 7303
--13743 7741 -13203 8141 -12725 8528 -12344 8951 -11995 9433 -11746 9944
--11666 10429 -11631 10830 -11459 11148 -11676 11428 -12079 11729 -12520 12074
--12754 12434 -13050 12714 -13441 12963 -13795 13236 -14160 13534 -14408 13818
--14588 14037 -14618 14145 -14818 14107 -14837 13904 -14363 13558 -13916 13153
--14096 12830 -14608 12736 -14874 12965 -14690 13508 -14187 14315 -13507 15366
--12609 16753 -12010 17671 -8844 15900 -17550 6213 -22550 5780 -25389 1774
--32710 6943 -34808 5381 -42328 1852 -26598 1049 -24410 -2887 -25452 -6419
--33881 -8536 -31702 -10640 -33604 -11644 -35108 -12017 -36234 -11936
--36736 -11568 -37166 -11056 -37388 -10548 -36880 -10162 -36340 -9916
--35681 -9698 -34880 -9345 -33917 -8788 -32744 -8081 -31708 -7338 -30894 -6620
--29819 -5893 -28796 -5078 -28167 -4134 -27685 -3098 -27365 -2057 -27311 -1100
--26972 -273 -26699 431 -26677 1111 -26734 1688 -26935 2123 -27108 2441
--27163 2719 -27077 3015 -26816 3366 -26382 3800 -25791 4271 -25039 4752
--24155 5275 -23188 5830 -22181 6367 -21157 6914 -20178 7491 -19205 8010
--18350 8366 -17651 8648 -16998 9091 -16486 9803 -16263 10584 -16361 11057
--16333 10997 -15991 10513 -16542 9997 -17886 9813 -18535 10075 -18606 10540
--19091 10764 -20603 10319 -22679 8981 -24044 6750 -24061 3728 -23616 23
--21091 -2767 -25306 -1776 -18749 -7814 -19221 -3443 -22209 -2430 -23505 -2475
--23938 -2090 -23019 -2097 -25724 -1459 -41955 757 -50607 1414 -54606 1090
--56362 1069 -57291 1191 -58027 1402 -58740 1652 -59438 1902 -60055 2138
--60518 2361 -60825 2584 -61016 2809 -61000 3023 -60831 3224 -60531 3415
--60109 3598 -59580 3769 -58969 3931 -58287 4083 -57535 4227 -56723 4361
--55872 4484 -54990 4598 -54082 4701 -53154 4795 -52218 4878 -51281 4953
--50348 5016 -49422 5072 -48508 5119 -47613 5156 -46739 5186 -45886 5210
--45061 5227 -44263 5240 -43495 5245 -42758 5249 -42049 5247 -41371 5242
--40730 5233 -40117 5223 -39537 5209 -38991 5194 -38472 5178 -37985 5160
--37524 5142 -37091 5125 -36690 5104 -36314 5087 -35962 5067 -35634 5046
--35329 5029 -35048 5011 -34784 4995 -34542 4979 -34318 4963 -34113 4948
--33923 4934 -33751 4920 -33587 4909 -33445 4898 -33309 4888 -33189 4879
--33080 4870 -32981 4863 -32893 4856 -32815 4849 -32744 4845
-27: 4080639 409698 -31487 4073 -31515 4062 -31537 4047 -31557 4031 -31569 4008
--31565 3985 -31549 3958 -31519 3929 -31472 3899 -31413 3867 -31335 3835
--31243 3802 -31133 3769 -31009 3737 -30868 3706 -30708 3676 -30533 3648
--30347 3624 -30145 3601 -29930 3582 -29709 3566 -29476 3557 -29236 3551
--28984 3548 -28733 3551 -28479 3561 -28218 3578 -27958 3597 -27700 3623
--27446 3656 -27195 3696 -26952 3741 -26715 3786 -26487 3837 -26272 3895
--26069 3960 -25879 4024 -25708 4089 -25549 4156 -25410 4222 -25290 4285
--25191 4343 -25114 4392 -25059 4441 -25028 4487 -25015 4527 -25029 4552
--25066 4561 -25127 4559 -25204 4548 -25308 4526 -25433 4482 -25574 4408
--25721 4331 -25892 4242 -26076 4123 -26268 3984 -26466 3860 -26666 3759
--26867 3645 -27061 3501 -27242 3361 -27406 3242 -27550 3140 -27665 3058
--27747 2993 -27790 2943 -27790 2896 -27750 2855 -27658 2825 -27515 2815
--27318 2827 -27073 2857 -26773 2897 -26417 2947 -26009 3007 -25551 3074
--25048 3147 -24505 3223 -23925 3321 -23313 3437 -22677 3576 -22019 3747
--21353 3921 -20686 4099 -20017 4324 -19338 4591 -18657 4856 -17987 5134
--17321 5445 -16655 5773 -15992 6108 -15347 6485 -14728 6916 -14140 7356
--13579 7760 -13056 8133 -12613 8532 -12195 8998 -11963 9518 -11799 10025
--11591 10455 -11471 10779 -11690 11040 -12181 11305 -12650 11623 -12891 11988
--12955 12338 -13553 12624 -14195 12922 -14819 13259 -15295 13587 -15738 13829
--15890 13942 -16028 13922 -16223 13783 -16061 13546 -15613 13232 -15588 12887
--16118 12586 -16580 12385 -16401 12294 -15678 12233 -14999 12085 -14689 11798
--15619 10984 -13808 12810 -12934 14708 -26217 18299 -27184 1981 -34285 2822
--21340 12383 -28436 4336 -33804 -2120 -28025 2870 -22324 -658 -26025 -4359
--26926 -8090 -29695 -10349 -32042 -11536 -33829 -11933 -34931 -11827
--35875 -11450 -36447 -10995 -36220 -10618 -35905 -10387 -35578 -10229
--35009 -9971 -34018 -9480 -32850 -8771 -31688 -7980 -30857 -7238 -29681 -6561
--28469 -5863 -27762 -5034 -27363 -4045 -26961 -2964 -26933 -1906 -26644 -971
--26342 -196 -26593 449 -26725 1197 -27133 1744 -27395 2114 -27553 2365
--27766 2584 -27912 2813 -27885 3094 -27650 3434 -27174 3812 -26477 4246
--25602 4746 -24629 5250 -23610 5743 -22598 6276 -21575 6838 -20627 7288
--19802 7556 -19085 7806 -18437 8288 -18012 9052 -17819 9837 -18024 10271
--18026 10182 -17936 9733 -18859 9314 -19567 9260 -19713 9639 -20062 10199
--21518 10516 -23879 10216 -25768 9131 -25688 7262 -24809 4308 -20999 883
--20426 -4684 -22082 -4332 -19056 -3759 -19463 -2432 -21551 -1792 -22450 -3864
--22550 -8136 -23067 6711 -26013 -238 -41104 2051 -48673 1748 -52691 1181
--54488 1271 -55558 1527 -56446 1832 -57304 2130 -58129 2402 -58859 2640
--59430 2855 -59837 3064 -60121 3270 -60193 3464 -60107 3647 -59887 3819
--59536 3983 -59074 4139 -58523 4285 -57899 4424 -57194 4554 -56430 4673
--55620 4785 -54778 4886 -53902 4978 -53003 5059 -52094 5131 -51182 5194
--50270 5247 -49360 5292 -48465 5326 -47584 5354 -46723 5374 -45881 5389
--45065 5395 -44274 5398 -43513 5395 -42779 5389 -42076 5379 -41403 5365
--40763 5349 -40153 5331 -39573 5310 -39026 5288 -38508 5265 -38023 5241
--37562 5218 -37127 5194 -36723 5169 -36345 5145 -35995 5121 -35664 5097
--35356 5074 -35072 5054 -34807 5034 -34561 5013 -34337 4995 -34130 4978
--33938 4961 -33761 4945 -33600 4930 -33453 4918 -33318 4905 -33193 4895
--33083 4885 -32985 4876 -32895 4868 -32814 4860 -32743 4854
-28: 4099799 392841 -31590 4083 -31610 4071 -31624 4056 -31631 4036 -31629 4014
--31614 3987 -31580 3959 -31534 3928 -31472 3895 -31392 3863 -31296 3827
--31186 3793 -31056 3758 -30911 3725 -30748 3691 -30571 3660 -30379 3631
--30169 3605 -29950 3581 -29720 3559 -29482 3545 -29231 3535 -28976 3525
--28715 3522 -28450 3527 -28185 3539 -27915 3553 -27649 3573 -27382 3600
--27126 3638 -26868 3678 -26623 3720 -26385 3769 -26157 3825 -25941 3890
--25739 3958 -25550 4024 -25379 4091 -25226 4161 -25090 4230 -24975 4294
--24879 4351 -24810 4408 -24759 4468 -24736 4524 -24732 4563 -24754 4580
--24804 4583 -24873 4577 -24963 4567 -25080 4544 -25221 4495 -25378 4413
--25539 4338 -25727 4216 -25929 4070 -26138 3940 -26356 3833 -26574 3709
--26797 3543 -27008 3375 -27208 3239 -27389 3131 -27547 3038 -27672 2959
--27762 2892 -27810 2830 -27811 2778 -27764 2745 -27668 2736 -27513 2753
--27300 2793 -27038 2841 -26717 2894 -26340 2952 -25904 3014 -25419 3078
--24890 3147 -24319 3236 -23713 3349 -23078 3478 -22421 3632 -21747 3799
--21073 3959 -20404 4155 -19740 4402 -19069 4655 -18405 4892 -17753 5162
--17105 5475 -16459 5797 -15815 6136 -15188 6527 -14588 6955 -14015 7367
--13472 7734 -12970 8101 -12482 8535 -12236 9046 -11928 9576 -11664 10036
--11561 10380 -11694 10632 -12173 10870 -12606 11160 -12736 11522 -12996 11916
--13517 12257 -14415 12562 -15344 12913 -16080 13293 -16709 13606 -17032 13763
--17206 13750 -17457 13615 -17616 13421 -17392 13205 -17188 12968 -17536 12705
--18184 12417 -18358 12095 -17712 11688 -16719 11074 -16172 10070 -16439 8564
--18018 6770 -18374 8160 -16188 24011 -24947 19811 -34338 2873 -27017 1716
--23348 12935 -27136 4453 -25969 -1936 -24334 1892 -20953 507 -23907 -3658
--25864 -7990 -28880 -10332 -31244 -11456 -32890 -11817 -34281 -11732
--35219 -11427 -35315 -11093 -35186 -10853 -35295 -10704 -35005 -10503
--34110 -10077 -32930 -9373 -31678 -8515 -30804 -7692 -29678 -7015 -28289 -6435
--27415 -5799 -27022 -4983 -26590 -3967 -26317 -2849 -26068 -1769 -25733 -837
--26007 -84 -26635 545 -27070 1335 -27297 1860 -27368 2201 -27727 2411
--28299 2551 -28888 2658 -29224 2793 -29120 2990 -28682 3274 -27951 3678
--27043 4160 -26043 4633 -25008 5100 -23931 5620 -22960 6137 -21995 6514
--21066 6736 -20344 7000 -19900 7510 -19419 8247 -19259 8946 -19496 9305
--19379 9238 -19964 8942 -20774 8759 -21023 8944 -21000 9489 -21817 10117
--24135 10422 -27068 10091 -28421 9049 -28465 7065 -21107 5007 -19968 -759
--19765 -2763 -19723 -3958 -19115 -3206 -18972 -2581 -21225 -3766 -22802 -1238
--20976 120 -23771 2011 -25897 6385 -40561 -491 -47056 280 -50943 678 -52693 1305
--53853 1816 -54870 2243 -55855 2596 -56797 2886 -57634 3125 -58308 3333
--58812 3527 -59183 3715 -59344 3891 -59342 4057 -59201 4213 -58922 4361
--58528 4503 -58039 4635 -57470 4760 -56819 4879 -56099 4986 -55334 5087
--54528 5175 -53689 5256 -52822 5326 -51941 5387 -51054 5439 -50164 5482
--49275 5515 -48397 5539 -47531 5557 -46685 5567 -45855 5571 -45048 5567
--44267 5561 -43514 5549 -42787 5533 -42088 5514 -41422 5493 -40784 5468
--40176 5442 -39600 5414 -39054 5386 -38536 5356 -38049 5324 -37591 5295
--37156 5266 -36750 5235 -36371 5207 -36020 5178 -35687 5149 -35379 5122
--35093 5098 -34826 5074 -34579 5051 -34353 5028 -34142 5009 -33949 4989
--33772 4970 -33607 4954 -33460 4938 -33322 4925 -33198 4912 -33086 4900
--32985 4890 -32893 4880 -32813 4871 -32741 4864
-29: 4118902 376008 -31684 4093 -31696 4081 -31698 4064 -31693 4043 -31680 4017
--31648 3990 -31597 3959 -31533 3927 -31454 3891 -31358 3856 -31242 3819
--31112 3784 -30962 3746 -30794 3710 -30613 3675 -30414 3643 -30202 3611
--29975 3584 -29739 3557 -29491 3536 -29235 3522 -28970 3507 -28703 3497
--28427 3496 -28153 3502 -27877 3512 -27600 3523 -27324 3545 -27055 3577
--26793 3614 -26533 3653 -26285 3697 -26046 3751 -25820 3816 -25605 3883
--25405 3950 -25218 4017 -25051 4087 -24899 4162 -24770 4233 -24662 4299
--24568 4364 -24506 4435 -24463 4504 -24445 4560 -24451 4591 -24484 4598
--24544 4600 -24626 4600 -24728 4595 -24857 4568 -25013 4515 -25186 4425
--25366 4321 -25567 4178 -25788 4044 -26017 3931 -26254 3796 -26493 3612
--26737 3411 -26971 3255 -27189 3139 -27389 3032 -27562 2929 -27701 2835
--27800 2753 -27854 2685 -27857 2645 -27807 2638 -27704 2662 -27538 2711
--27312 2767 -27029 2822 -26690 2877 -26289 2936 -25826 2997 -25314 3066
--24753 3151 -24155 3267 -23523 3397 -22863 3540 -22181 3696 -21492 3849
--20810 4014 -20143 4232 -19487 4473 -18835 4682 -18188 4899 -17560 5182
--16938 5499 -16314 5814 -15690 6151 -15085 6543 -14507 6951 -13952 7327
--13427 7671 -12886 8056 -12577 8537 -12114 9077 -11879 9577 -11732 9955
--11761 10214 -12064 10428 -12402 10690 -12453 11044 -12689 11457 -13395 11865
--14733 12179 -15871 12492 -16794 12874 -17512 13262 -17961 13526 -18242 13581
--18547 13458 -18924 13257 -19000 13071 -18819 12931 -18894 12809 -19453 12639
--19973 12366 -19811 11948 -18918 11328 -18110 10419 -18006 9052 -18783 7066
--21003 4803 -26077 4595 -24486 25969 -26608 25461 -29021 2423 -21560 -1581
--19021 10306 -25425 968 -19554 726 -18935 7500 -19264 1724 -22693 -4712
--25777 -8903 -28835 -10628 -30911 -11404 -32570 -11733 -33870 -11757
--34383 -11576 -34466 -11338 -34915 -11137 -34990 -10920 -34284 -10524
--33107 -9833 -31849 -8904 -30927 -7959 -29944 -7210 -28494 -6705 -27334 -6302
--26794 -5783 -26312 -5008 -25666 -3971 -25235 -2792 -24824 -1643 -24994 -655
--25855 123 -26491 773 -26983 1538 -26926 2072 -27133 2434 -27947 2604
--29250 2582 -30355 2446 -30775 2339 -30721 2367 -30189 2591 -29395 3009
--28418 3508 -27345 3982 -26237 4449 -25220 4948 -24176 5409 -23085 5727
--22202 5941 -21694 6226 -21121 6719 -20641 7356 -20516 7922 -20531 8225
--20883 8260 -21634 8219 -22254 8362 -22416 8840 -22463 9568 -23698 10240
--26684 10457 -29936 9933 -30734 8700 -28142 7149 -18649 6242 -22195 -1923
--17213 -2218 -19373 -2629 -18121 -2202 -20229 -5232 -18697 393 -21948 887
--17068 -397 -20631 1328 -32309 4469 -41579 1335 -45891 1357 -49341 1282
--50953 1826 -52170 2335 -53301 2761 -54405 3107 -55458 3384 -56400 3606
--57170 3793 -57768 3969 -58224 4140 -58471 4299 -58551 4449 -58488 4591
--58282 4726 -57953 4854 -57525 4976 -57012 5091 -56413 5199 -55743 5296
--55017 5385 -54253 5464 -53447 5535 -52614 5595 -51762 5645 -50901 5686
--50035 5718 -49167 5741 -48307 5756 -47458 5764 -46626 5762 -45812 5756
--45014 5743 -44243 5727 -43500 5706 -42779 5681 -42089 5653 -41424 5622
--40794 5590 -40190 5556 -39616 5521 -39071 5485 -38555 5449 -38070 5411
--37612 5375 -37177 5340 -36773 5304 -36391 5270 -36038 5236 -35708 5204
--35395 5172 -35110 5144 -34841 5117 -34593 5089 -34364 5063 -34153 5041
--33957 5019 -33778 4996 -33614 4978 -33464 4960 -33325 4945 -33200 4930
--33087 4917 -32984 4904 -32890 4892 -32811 4884 -32738 4875
-30: 4137958 359204 -31769 4103 -31769 4090 -31763 4072 -31743 4048 -31714 4022
--31667 3992 -31603 3959 -31520 3924 -31422 3886 -31306 3849 -31171 3810
--31020 3772 -30849 3732 -30661 3694 -30460 3658 -30240 3623 -30008 3590
--29765 3559 -29510 3533 -29242 3512 -28972 3492 -28696 3476 -28412 3468
--28128 3469 -27840 3472 -27556 3477 -27271 3491 -26993 3517 -26716 3550
--26451 3584 -26191 3623 -25941 3673 -25704 3734 -25478 3803 -25266 3868
--25068 3933 -24885 4003 -24723 4080 -24579 4160 -24451 4237 -24348 4310
--24264 4387 -24206 4468 -24172 4538 -24160 4582 -24177 4603 -24218 4614
--24289 4626 -24383 4634 -24499 4630 -24642 4601 -24814 4539 -25003 4445
--25196 4297 -25415 4164 -25655 4049 -25904 3907 -26161 3706 -26424 3477
--26688 3296 -26945 3169 -27189 3047 -27408 2911 -27602 2778 -27755 2664
--27864 2580 -27925 2530 -27930 2522 -27879 2552 -27771 2607 -27595 2671
--27355 2725 -27052 2779 -26693 2835 -26268 2901 -25778 2977 -25230 3071
--24648 3194 -24017 3336 -23353 3474 -22667 3618 -21958 3763 -21250 3904
--20565 4083 -19907 4302 -19263 4498 -18626 4670 -18007 4899 -17407 5205
--16818 5516 -16222 5807 -15625 6135 -15048 6514 -14494 6898 -13960 7245
--13416 7588 -13007 8013 -12453 8534 -12195 9070 -12002 9504 -11911 9792
--11979 9995 -12152 10223 -12139 10559 -12381 10992 -13158 11437 -14507 11806
--16367 12051 -17444 12328 -18145 12703 -18638 13076 -19022 13282 -19483 13261
--20048 13086 -20366 12893 -20351 12786 -20296 12775 -20586 12786 -21115 12706
--21364 12434 -20937 11920 -20252 11158 -20136 10164 -20912 8830 -22869 6528
--24112 3725 -31641 1678 -28911 24619 -23037 25858 -20222 3918 -24426 1618
--19297 4679 -18848 2960 -6375 4435 -20887 15308 -18003 -4590 -21593 -8802
--25894 -10311 -28983 -10588 -30763 -11041 -32250 -11618 -33413 -11931
--33993 -11868 -34727 -11592 -35237 -11244 -34722 -10786 -33567 -10080
--32334 -9093 -31415 -8004 -30581 -7101 -29214 -6581 -27718 -6388 -26797 -6269
--26157 -5930 -25201 -5216 -24275 -4135 -23652 -2830 -23603 -1508 -24529 -365
--25624 496 -25929 1156 -26278 1806 -26251 2397 -27007 2851 -28845 2936
--30782 2590 -31887 2022 -32417 1584 -32211 1469 -31639 1716 -30721 2228
--29595 2807 -28463 3332 -27350 3819 -26230 4294 -25112 4695 -24148 4974
--23417 5187 -22661 5469 -22072 5888 -21568 6387 -21473 6831 -21703 7134
--22107 7342 -22790 7610 -23565 8104 -23803 8880 -23863 9795 -25374 10530
--28753 10689 -32084 9925 -34758 7921 -27278 6293 -15957 7918 -18621 -539
--17024 -3110 -16303 -1369 -23260 -4944 -20019 -7706 -17664 11713 -19812 4723
--15881 -7979 -23148 258 -34257 2950 -41623 2396 -44531 2845 -47668 2455
--49189 2760 -50480 3100 -51736 3412 -52963 3678 -54127 3898 -55168 4078
--56036 4234 -56723 4386 -57263 4537 -57591 4681 -57752 4818 -57762 4948
--57626 5072 -57361 5192 -56994 5304 -56536 5411 -55987 5510 -55363 5600
--54679 5681 -53954 5750 -53185 5812 -52384 5862 -51561 5903 -50727 5934
--49885 5956 -49038 5969 -48198 5974 -47368 5971 -46550 5961 -45748 5944
--44967 5922 -44204 5895 -43470 5865 -42758 5832 -42075 5793 -41419 5755
--40792 5715 -40193 5673 -39621 5629 -39079 5587 -38568 5543 -38083 5499
--37624 5457 -37194 5416 -36788 5375 -36407 5336 -36052 5296 -35722 5260
--35410 5224 -35121 5191 -34852 5159 -34603 5130 -34371 5101 -34161 5073
--33962 5049 -33783 5025 -33619 5003 -33467 4983 -33325 4967 -33199 4949
--33084 4934 -32982 4919 -32888 4906 -32807 4895 -32733 4886
-31: 4156973 342432 -31839 4113 -31833 4099 -31815 4079 -31780 4054 -31735 4025
--31672 3993 -31592 3958 -31493 3920 -31374 3881 -31238 3841 -31083 3799
--30910 3758 -30720 3717 -30512 3677 -30289 3637 -30050 3601 -29799 3567
--29536 3533 -29265 3506 -28981 3483 -28697 3459 -28402 3444 -28109 3438
--27813 3436 -27516 3434 -27224 3439 -26935 3459 -26650 3486 -26372 3516
--26103 3548 -25845 3591 -25593 3649 -25358 3714 -25135 3779 -24927 3841
--24733 3910 -24558 3988 -24397 4074 -24260 4161 -24139 4243 -24040 4327
--23964 4414 -23913 4495 -23886 4552 -23885 4588 -23910 4613 -23962 4640
--24042 4666 -24148 4680 -24279 4670 -24436 4635 -24624 4571 -24826 4470
--25034 4305 -25272 4183 -25530 4037 -25800 3826 -26078 3575 -26363 3366
--26652 3224 -26937 3090 -27206 2916 -27450 2731 -27663 2574 -27837 2466
--27959 2406 -28025 2395 -28034 2425 -27986 2482 -27870 2546 -27684 2601
--27429 2651 -27111 2708 -26727 2784 -26283 2880 -25756 2995 -25202 3134
--24553 3289 -23899 3436 -23210 3564 -22484 3693 -21750 3818 -21031 3958
--20336 4142 -19680 4328 -19051 4475 -18447 4646 -17865 4915 -17304 5229
--16755 5505 -16195 5761 -15635 6073 -15083 6445 -14552 6814 -14040 7146
--13537 7508 -13011 7971 -12596 8512 -12377 9008 -12142 9360 -12055 9576
--12018 9772 -11927 10074 -12142 10521 -12911 11025 -14385 11446 -16024 11692
--17621 11787 -18392 11953 -18859 12284 -19327 12654 -20082 12840 -21022 12807
--21672 12667 -21840 12571 -21808 12612 -21906 12768 -22213 12919 -22479 12906
--22348 12591 -21856 11920 -21698 10949 -22650 9868 -24753 8802 -27268 6572
--30387 -55 -30588 11063 -25887 19326 -21377 16833 -20848 1183 -20883 6827
--19842 2191 -17579 -494 -11467 6565 -10820 9737 -11828 -934 -18425 -7117
--25892 -8394 -28825 -8677 -29916 -9871 -31364 -11442 -33247 -12294 -34831 -12216
--35935 -11631 -35727 -10905 -34512 -10073 -33177 -9029 -32258 -7805 -31575 -6673
--30375 -5985 -28599 -5884 -27062 -6182 -26080 -6471 -24954 -6372 -23517 -5718
--22416 -4540 -22012 -2993 -22815 -1335 -24380 119 -25267 1110 -25143 1670
--25242 2066 -25682 2816 -27596 3481 -30296 3408 -32254 2479 -33273 1204
--33501 375 -33451 227 -32879 651 -31876 1377 -30728 2122 -29472 2748 -28260 3270
--27103 3713 -26114 4055 -25177 4291 -24161 4483 -23302 4715 -22680 5025
--22397 5386 -22501 5754 -22593 6121 -22915 6539 -23745 7109 -24818 7917
--24952 8948 -24960 10041 -26619 10910 -30053 11207 -32798 10586 -33487 8636
--25404 5731 -20859 2132 -18059 4048 -15989 3679 -15231 -245 -24128 -5581
--20746 -4761 -19752 5890 -19683 -1517 -17229 511 -22343 -2944 -34946 1355
--39928 3429 -43734 3580 -45784 3732 -47337 3854 -48767 3986 -50172 4130
--51535 4272 -52813 4406 -53958 4527 -54919 4644 -55694 4767 -56316 4902
--56722 5031 -56958 5156 -57039 5278 -56968 5396 -56764 5509 -56455 5618
--56051 5717 -55549 5811 -54969 5896 -54328 5969 -53640 6032 -52905 6085
--52136 6128 -51342 6159 -50535 6182 -49718 6195 -48892 6197 -48072 6192
--47259 6179 -46459 6160 -45671 6134 -44902 6102 -44152 6065 -43427 6026
--42726 5983 -42050 5937 -41401 5889 -40779 5841 -40186 5791 -39618 5740
--39080 5690 -38572 5640 -38090 5589 -37632 5540 -37201 5494 -36796 5447
--36418 5402 -36061 5359 -35730 5317 -35421 5278 -35130 5241 -34861 5203
--34610 5171 -34376 5137 -34164 5109 -33968 5080 -33786 5053 -33618 5030
--33465 5008 -33325 4988 -33197 4969 -33082 4953 -32977 4935 -32884 4920
--32802 4908 -32726 4898
-32: 4175961 325696 -31900 4123 -31884 4107 -31852 4086 -31806 4059 -31744 4027
--31663 3994 -31567 3955 -31449 3916 -31309 3874 -31154 3831 -30979 3786
--30786 3743 -30575 3701 -30347 3656 -30101 3616 -29844 3577 -29575 3539
--29291 3505 -29005 3477 -28706 3448 -28405 3425 -28100 3411 -27793 3404
--27489 3394 -27181 3392 -26884 3402 -26588 3424 -26301 3447 -26022 3474
--25751 3509 -25493 3559 -25248 3620 -25012 3683 -24794 3743 -24590 3808
--24403 3887 -24233 3977 -24080 4072 -23948 4162 -23833 4250 -23743 4342
--23675 4430 -23630 4499 -23611 4549 -23619 4590 -23653 4636 -23715 4685
--23806 4719 -23923 4726 -24068 4709 -24241 4673 -24443 4610 -24659 4498
--24884 4348 -25136 4195 -25413 3976 -25705 3710 -26004 3474 -26315 3312
--26632 3166 -26946 2960 -27242 2711 -27514 2496 -27752 2356 -27945 2283
--28084 2264 -28158 2286 -28175 2335 -28121 2393 -28011 2443 -27803 2488
--27542 2549 -27204 2641 -26815 2766 -26322 2916 -25814 3082 -25124 3252
--24516 3410 -23818 3530 -23072 3633 -22329 3740 -21566 3851 -20804 3993
--20107 4163 -19468 4307 -18884 4437 -18310 4648 -17772 4952 -17261 5237
--16755 5449 -16236 5669 -15699 5982 -15183 6365 -14716 6727 -14161 7053
--13739 7429 -13138 7915 -12853 8447 -12526 8883 -12314 9159 -12129 9345
--11937 9593 -12022 10022 -12665 10597 -14056 11147 -15740 11473 -17124 11488
--17827 11304 -18303 11247 -18841 11508 -19774 11963 -21419 12196 -22923 12239
--23559 12236 -23630 12327 -23647 12576 -23747 12923 -23798 13213 -23580 13237
--23054 12826 -22582 11893 -22963 10490 -24937 9005 -28562 8415 -29087 8759
--35290 4470 -30718 11220 -22867 11590 -21484 6289 -20803 1016 -19496 7350
--20534 -549 -14313 -2251 -10702 5118 -10357 7323 -8727 -48 -15098 -1552
--24656 -4784 -28332 -4969 -27283 -8225 -29421 -11617 -33904 -13058 -36772 -12523
--37441 -11193 -36186 -9870 -34431 -8648 -33252 -7358 -32649 -6017 -31696 -4973
--29796 -4667 -27526 -5203 -25869 -6205 -24610 -7049 -23105 -7226 -21531 -6606
--20599 -5257 -21035 -3328 -22902 -1106 -24762 908 -25051 2100 -24311 2251
--24306 2091 -25624 3226 -28653 4390 -31788 4084 -33425 2196 -33311 -239
--33676 -1432 -34196 -1365 -34082 -528 -33297 575 -32002 1574 -30617 2333
--29273 2882 -28119 3275 -26971 3539 -25775 3707 -24558 3833 -23729 3967
--23341 4150 -23279 4405 -23200 4754 -23136 5226 -23446 5850 -24680 6667
--25734 7698 -25713 8894 -25705 10110 -27591 11120 -31053 11687 -33530 11572
--33695 10340 -26682 7238 -21000 1000 -15743 7418 -28033 4830 -12695 -1766
--19168 -6719 -19583 -2164 -21707 3500 -20166 -4533 -18422 -3757 -25763 -658
--33410 2419 -37570 4687 -41403 4923 -43608 5006 -45383 4933 -47032 4856
--48625 4821 -50136 4829 -51537 4869 -52785 4928 -53838 5004 -54699 5101
--55398 5221 -55877 5340 -56183 5458 -56331 5578 -56321 5693 -56174 5804
--55918 5910 -55563 6009 -55106 6099 -54569 6181 -53968 6249 -53316 6307
--52614 6354 -51874 6390 -51109 6414 -50329 6428 -49533 6431 -48732 6424
--47932 6411 -47137 6388 -46353 6359 -45579 6324 -44825 6282 -44088 6237
--43372 6187 -42681 6135 -42013 6081 -41373 6025 -40758 5968 -40170 5910
--39608 5852 -39072 5795 -38568 5738 -38089 5680 -37633 5626 -37204 5572
--36802 5521 -36423 5469 -36065 5422 -35736 5377 -35424 5332 -35136 5290
--34865 5250 -34614 5212 -34381 5177 -34166 5144 -33969 5112 -33787 5084
--33617 5058 -33461 5032 -33323 5010 -33194 4991 -33077 4971 -32970 4951
--32878 4936 -32794 4921 -32718 4911
-33: 4194931 309001 -31951 4132 -31923 4114 -31878 4091 -31818 4063 -31738 4030
--31640 3992 -31526 3952 -31389 3910 -31230 3865 -31055 3819 -30859 3773
--30646 3727 -30412 3680 -30165 3634 -29900 3593 -29623 3549 -29337 3509
--29035 3476 -28731 3442 -28418 3411 -28101 3389 -27786 3375 -27466 3361
--27157 3348 -26840 3349 -26534 3363 -26236 3383 -25947 3400 -25669 3426
--25400 3467 -25143 3523 -24900 3582 -24672 3640 -24458 3701 -24261 3776
--24081 3869 -23916 3968 -23772 4066 -23647 4156 -23541 4249 -23457 4342
--23397 4424 -23359 4486 -23350 4541 -23365 4609 -23408 4683 -23480 4744
--23582 4769 -23711 4766 -23871 4747 -24057 4716 -24274 4652 -24506 4523
--24740 4388 -25010 4167 -25307 3890 -25619 3631 -25942 3448 -26277 3288
--26621 3056 -26968 2744 -27300 2454 -27600 2264 -27870 2173 -28086 2142
--28242 2145 -28326 2170 -28343 2207 -28311 2244 -28168 2285 -27992 2349
--27691 2462 -27356 2624 -26902 2817 -26454 3021 -25736 3213 -25239 3379
--24484 3495 -23735 3573 -22996 3651 -22188 3742 -21362 3854 -20606 4002
--19917 4154 -19318 4277 -18724 4435 -18209 4698 -17718 4994 -17251 5205
--16791 5346 -16301 5556 -15852 5903 -15410 6305 -14856 6650 -14523 6953
--13872 7327 -13450 7816 -13138 8320 -12763 8698 -12492 8924 -12206 9126
--12111 9481 -12479 10072 -13558 10788 -15047 11367 -16398 11538 -17157 11208
--16949 10567 -17494 10112 -18444 10287 -20079 11056 -23217 11382 -25384 11580
--26062 11814 -26069 12171 -25995 12668 -25807 13223 -25313 13646 -24490 13695
--23634 13162 -23195 11927 -24804 9593 -25823 7270 -31396 5666 -28565 6607
--35816 4447 -31325 7830 -22618 9151 -16757 6442 -22992 -1335 -21601 2598
--20050 2744 -18195 1043 -12498 6424 -5192 5671 -7521 -4577 -21051 5541
--23015 -2071 -24084 -1397 -20940 -7452 -27013 -12997 -35628 -14498 -39209 -12600
--38704 -9966 -36372 -7961 -34264 -6537 -33293 -5236 -32677 -3904 -31007 -2986
--28149 -3167 -25444 -4577 -23665 -6548 -22395 -8127 -21141 -8554 -19977 -7907
--19727 -6339 -21201 -3915 -24063 -860 -25962 2124 -25229 3767 -23198 2885
--23691 1337 -25805 3406 -29767 5734 -33213 5138 -33603 1772 -31208 -2699
--32361 -3945 -34799 -3182 -35922 -1621 -35392 23 -33896 1336 -32144 2214
--30536 2740 -28969 3034 -27538 3179 -26101 3233 -24939 3236 -24307 3232
--24071 3284 -23824 3466 -23448 3843 -23305 4436 -23876 5236 -25227 6218
--26207 7358 -26066 8595 -26311 9809 -28418 10816 -31863 11475 -34216 11732
--33557 11449 -29758 9275 -20225 -1882 -40811 -11081 -13152 16103 -13246 5206
--15706 2120 -14529 -740 -23707 -4198 -23697 -3372 -24212 -6538 -23224 142
--29930 4328 -35452 5819 -38893 6253 -41374 6136 -43435 5851 -45334 5582
--47129 5393 -48798 5284 -50322 5245 -51673 5250 -52816 5293 -53757 5371
--54525 5484 -55073 5599 -55443 5718 -55650 5840 -55695 5958 -55601 6074
--55393 6182 -55082 6283 -54668 6374 -54168 6454 -53604 6521 -52985 6575
--52314 6618 -51604 6647 -50865 6664 -50110 6671 -49339 6666 -48558 6651
--47778 6627 -47002 6596 -46233 6557 -45477 6513 -44734 6463 -44011 6408
--43308 6349 -42626 6287 -41968 6225 -41335 6161 -40727 6095 -40145 6030
--39588 5965 -39058 5900 -38558 5836 -38082 5773 -37626 5711 -37203 5653
--36801 5595 -36424 5538 -36067 5487 -35736 5436 -35427 5388 -35138 5340
--34866 5297 -34614 5256 -34380 5217 -34167 5179 -33967 5146 -33784 5115
--33613 5085 -33460 5059 -33318 5034 -33188 5011 -33070 4990 -32964 4971
--32870 4950 -32784 4937 -32709 4923
-34: 4213889 292351 -31986 4139 -31949 4121 -31892 4096 -31816 4065 -31720 4029
--31604 3991 -31471 3946 -31315 3903 -31136 3854 -30940 3805 -30725 3758
--30489 3708 -30236 3657 -29968 3612 -29687 3566 -29389 3518 -29082 3478
--28767 3442 -28444 3404 -28119 3372 -27788 3351 -27462 3331 -27133 3311
--26812 3301 -26495 3306 -26182 3320 -25883 3330 -25591 3345 -25313 3375
--25051 3423 -24797 3478 -24557 3534 -24337 3588 -24130 3659 -23941 3749
--23767 3852 -23613 3952 -23477 4045 -23361 4136 -23265 4231 -23187 4324
--23136 4402 -23105 4470 -23103 4553 -23127 4654 -23180 4745 -23259 4797
--23371 4807 -23514 4797 -23687 4787 -23890 4765 -24122 4697 -24365 4545
--24609 4387 -24894 4117 -25208 3846 -25538 3640 -25881 3469 -26244 3221
--26625 2855 -27011 2474 -27371 2214 -27731 2091 -28014 2044 -28254 2015
--28428 1995 -28536 1987 -28582 1997 -28500 2030 -28433 2101 -28162 2234
--27888 2435 -27480 2680 -27101 2928 -26430 3151 -26061 3323 -25210 3437
--24483 3493 -23747 3539 -22910 3610 -22049 3713 -21235 3848 -20443 4007
--19755 4154 -19077 4292 -18591 4499 -18088 4781 -17650 5013 -17265 5124
--16862 5220 -16541 5465 -16101 5866 -15589 6268 -15304 6560 -14777 6808
--14211 7165 -13942 7650 -13470 8128 -13047 8464 -12703 8670 -12478 8923
--12512 9413 -13102 10188 -14136 11072 -15256 11703 -15930 11712 -16071 10948
--15677 9647 -16646 8504 -18169 8505 -20132 10164 -25704 10420 -28773 10837
--29396 11402 -29142 12079 -28680 12840 -27880 13601 -26623 14162 -25227 14231
--24230 13578 -24012 12177 -25031 9870 -26425 6329 -34497 2173 -27716 494
--33719 -1750 -33755 4049 -16333 9679 -18912 6875 -23843 2418 -27547 -34
--20541 8207 -18195 2842 -16182 9148 -6757 11347 -8001 2683 -25181 -2665
--25250 2537 -19877 -4332 -13751 -9495 -18325 -15421 -38871 -16320 -42116 -12029
--39086 -7597 -35740 -5161 -33246 -4005 -32423 -3074 -31688 -1778 -29089 -769
--25273 -1386 -22218 -3959 -20588 -7249 -19972 -9816 -20009 -10300 -19813 -9511
--20106 -7773 -22292 -4880 -26131 -802 -28200 3757 -26058 6736 -20651 3907
--23246 -1259 -25781 2967 -30642 7773 -34688 6688 -33478 1439 -25493 -6983
--29590 -7039 -36231 -4843 -39143 -2277 -38570 3 -36411 1610 -33964 2508
--31626 2899 -29659 3005 -27973 2970 -26557 2855 -25506 2685 -24931 2507
--24460 2422 -23768 2551 -23220 2973 -23139 3696 -23869 4648 -25365 5727
--26288 6870 -26382 8032 -26949 9101 -29138 9867 -32292 10121 -34246 9772
--32932 8831 -26970 6465 -23753 -4350 -34678 932 -29223 11053 -12453 10532
--12345 4920 -17952 -2775 -24358 -5237 -27183 -5058 -15227 -4369 -28107 2913
--30755 6445 -33969 7268 -36799 7305 -39328 6931 -41617 6465 -43751 6058
--45741 5764 -47562 5582 -49204 5490 -50651 5466 -51877 5491 -52890 5564
--53719 5679 -54325 5802 -54752 5931 -55010 6062 -55103 6192 -55053 6316
--54886 6433 -54615 6539 -54237 6634 -53773 6715 -53240 6783 -52652 6835
--52010 6874 -51327 6900 -50614 6910 -49882 6911 -49134 6898 -48373 6875
--47613 6842 -46856 6802 -46104 6754 -45362 6701 -44633 6641 -43923 6577
--43232 6510 -42561 6440 -41913 6368 -41288 6296 -40689 6223 -40113 6149
--39563 6077 -39036 6005 -38540 5935 -38069 5866 -37616 5798 -37196 5733
--36794 5670 -36418 5609 -36066 5552 -35733 5495 -35425 5444 -35137 5393
--34864 5344 -34612 5300 -34378 5258 -34165 5218 -33962 5180 -33778 5145
--33609 5114 -33456 5086 -33311 5059 -33179 5033 -33062 5010 -32956 4989
--32860 4968 -32774 4950 -32698 4937
-35: 4232847 275749 -32013 4145 -31964 4126 -31891 4099 -31799 4065 -31686 4029
--31555 3986 -31401 3940 -31226 3892 -31029 3842 -30811 3791 -30575 3740
--30321 3684 -30046 3635 -29759 3587 -29459 3534 -29141 3486 -28818 3445
--28488 3404 -28148 3362 -27809 3331 -27467 3308 -27132 3281 -26794 3258
--26464 3253 -26142 3260 -25828 3265 -25529 3267 -25237 3285 -24963 3323
--24703 3374 -24456 3425 -24223 3474 -24011 3535 -23815 3618 -23632 3721
--23470 3824 -23325 3917 -23199 4004 -23092 4098 -23005 4201 -22940 4296
--22892 4382 -22873 4475 -22876 4593 -22908 4714 -22968 4801 -23055 4829
--23179 4825 -23334 4824 -23520 4832 -23741 4822 -23984 4745 -24239 4578
--24493 4367 -24785 4105 -25108 3889 -25459 3713 -25839 3460 -26234 3058
--26645 2589 -27046 2230 -27513 2053 -27831 1982 -28185 1914 -28468 1824
--28686 1739 -28789 1699 -28790 1715 -28818 1794 -28589 1950 -28416 2190
--28087 2483 -27764 2783 -27211 3040 -26896 3227 -26021 3335 -25313 3378
--24563 3395 -23726 3448 -22872 3553 -21992 3697 -21076 3871 -20229 4051
--19387 4208 -18899 4377 -18347 4613 -17965 4857 -17663 4984 -17373 5007
--17199 5108 -16752 5425 -16341 5865 -16103 6214 -15746 6401 -15143 6578
--14840 6922 -14455 7417 -13830 7889 -13376 8200 -13103 8398 -12941 8698
--13026 9309 -13439 10274 -14058 11370 -14527 12153 -14651 12098 -14508 10901
--14599 8817 -16466 6549 -18927 5902 -19182 9837 -29498 9196 -33179 10003
--33204 10989 -32329 11996 -31214 12985 -29599 13940 -27491 14664 -25585 14755
--24791 13814 -25873 11867 -27280 9823 -30988 4739 -28960 966 -27415 798
--28661 1089 -33709 -4389 -16584 7170 -20842 7797 -28854 4981 -28566 635
--19648 591 -14941 4990 -15085 12002 -16870 14688 -11765 3622 -24539 3666
--24275 -2617 -23446 -11388 -19816 -7649 -4599 -13402 -43749 -16986 -39766 -9930
--38042 -4175 -33610 -1856 -30512 -1633 -30130 -1593 -29982 -138 -26595 1710
--21598 980 -18344 -3217 -17251 -8234 -17932 -12275 -20579 -12160 -21605 -11054
--21357 -9375 -23168 -6292 -29374 -1404 -31379 5078 -28176 11730 -13881 6853
--22654 -6829 -26451 1131 -29805 10513 -36490 7933 -37286 1737 -13577 -14745
--25300 -9166 -40020 -5594 -44010 -2088 -42402 809 -38918 2571 -35378 3273
--32447 3336 -30230 3130 -28571 2857 -27129 2541 -26022 2162 -25153 1777
--24191 1529 -23136 1588 -22526 2061 -22456 2931 -23532 4065 -25305 5211
--26402 6288 -26869 7312 -27713 8208 -29670 8690 -32315 8352 -34644 6863
--36926 4423 -35815 2669 -16527 5921 -26762 10172 -25919 8987 -21898 8144
--18601 7464 -23635 -1055 -24231 -5980 -28070 -5723 -19628 -2354 -22549 4794
--27007 7562 -31181 7863 -34503 7672 -37385 7186 -39970 6655 -42341 6204
--44515 5879 -46474 5680 -48221 5578 -49750 5554 -51047 5587 -52117 5674
--53000 5803 -53653 5945 -54122 6095 -54421 6245 -54553 6393 -54539 6533
--54405 6662 -54167 6777 -53820 6880 -53385 6966 -52882 7035 -52321 7088
--51705 7124 -51046 7145 -50356 7152 -49648 7145 -48919 7127 -48179 7095
--47440 7054 -46698 7005 -45964 6949 -45236 6885 -44524 6818 -43826 6745
--43147 6669 -42487 6590 -41848 6510 -41233 6430 -40642 6349 -40073 6268
--39530 6189 -39009 6110 -38516 6034 -38049 5958 -37602 5885 -37183 5813
--36784 5746 -36410 5680 -36059 5616 -35728 5557 -35420 5500 -35130 5445
--34860 5393 -34608 5345 -34371 5299 -34159 5256 -33957 5216 -33772 5178
--33604 5144 -33447 5112 -33303 5084 -33171 5056 -33052 5032 -32946 5008
--32849 4985 -32764 4966 -32687 4950
-36: 4251812 259199 -32026 4149 -31966 4128 -31879 4100 -31769 4065 -31641 4025
--31492 3980 -31317 3932 -31123 3880 -30908 3827 -30668 3775 -30415 3717
--30138 3662 -29844 3611 -29540 3555 -29218 3500 -28883 3454 -28542 3409
--28200 3359 -27845 3318 -27492 3289 -27140 3258 -26794 3226 -26450 3205
--26114 3204 -25790 3203 -25475 3198 -25174 3200 -24888 3224 -24619 3269
--24362 3316 -24123 3359 -23901 3409 -23696 3479 -23512 3575 -23342 3680
--23190 3776 -23057 3858 -22943 3948 -22847 4054 -22769 4168 -22714 4275
--22674 4381 -22661 4507 -22673 4648 -22712 4766 -22779 4824 -22873 4832
--23005 4832 -23173 4854 -23378 4888 -23604 4889 -23871 4812 -24128 4646
--24375 4393 -24679 4180 -25036 4007 -25423 3766 -25797 3354 -26205 2812
--26631 2340 -27200 2077 -27493 1966 -28052 1859 -28431 1684 -28735 1486
--28894 1353 -29040 1332 -29132 1422 -28994 1611 -28963 1886 -28740 2224
--28444 2570 -28008 2866 -27661 3074 -26912 3184 -26174 3219 -25439 3222
--24651 3258 -23775 3375 -22854 3553 -21854 3755 -20817 3968 -19781 4162
--19181 4325 -18551 4507 -18223 4723 -18001 4879 -17803 4894 -17729 4877
--17313 5036 -17060 5427 -16928 5850 -16658 6077 -16150 6130 -15783 6248
--15584 6611 -14920 7149 -14276 7635 -13928 7920 -13770 8080 -13577 8370
--13433 9033 -13402 10148 -13424 11511 -13438 12623 -13468 12737 -13475 11235
--13592 8628 -17777 4992 -21840 2195 -16987 10617 -35908 7436 -36602 9093
--36154 10570 -34626 11814 -33004 12917 -30655 14049 -27634 15059 -25080 15338
--24523 13874 -26207 10674 -28671 7637 -30537 4080 -26467 1665 -25484 627
--28751 2526 -36397 -6494 -24767 655 -24526 6300 -27424 3799 -23051 4935
--19719 2364 -17895 3586 -19561 13669 -12797 12998 -15790 2861 -22787 6210
--28114 -3479 -24876 -7669 -25050 -5246 -22851 -14934 -26815 -15816 -34384 -9163
--34759 -1472 -30208 937 -26008 -217 -26853 -1784 -29392 244 -25112 4631
--17926 4534 -14760 -2315 -14591 -9159 -16194 -15759 -23362 -13382 -25298 -11863
--22658 -10675 -22654 -7564 -27572 -2970 -34072 3647 -34478 16290 -2923 15163
--16987 -9284 -31914 -6500 -30749 12159 -35319 4622 -44849 4162 3379 -24866
--26367 -8281 -46835 -4782 -49126 -960 -45136 2642 -40070 4308 -35837 4439
--32798 3894 -30779 3256 -29091 2740 -27496 2248 -26018 1660 -24712 1020
--23321 548 -22157 486 -21465 996 -21490 2054 -23187 3499 -25454 4746 -26654 5705
--27527 6594 -28531 7461 -29719 7973 -30834 7570 -32200 5766 -33114 2740
--36605 4081 -23125 11971 -21863 9818 -29294 8940 -28708 8955 -30581 2374
--32554 913 -15459 4709 -22936 -3383 -20915 -1242 -21619 3696 -24871 6680
--28928 7217 -32551 7198 -35752 6828 -38607 6380 -41184 5994 -43510 5721
--45581 5564 -47410 5500 -49002 5510 -50349 5581 -51463 5702 -52383 5856
--53066 6033 -53564 6215 -53893 6393 -54051 6565 -54063 6726 -53957 6872
--53742 7000 -53421 7113 -53010 7205 -52531 7278 -51993 7331 -51400 7367
--50762 7386 -50095 7388 -49407 7375 -48698 7349 -47978 7311 -47255 7262
--46533 7205 -45814 7138 -45103 7067 -44405 6991 -43719 6909 -43053 6825
--42405 6739 -41776 6650 -41169 6562 -40588 6474 -40028 6385 -39489 6300
--38976 6213 -38486 6132 -38025 6050 -37583 5971 -37164 5894 -36770 5821
--36396 5750 -36051 5682 -35718 5618 -35410 5557 -35121 5497 -34850 5443
--34602 5392 -34366 5340 -34152 5295 -33949 5252 -33765 5211 -33594 5174
--33436 5140 -33293 5110 -33162 5080 -33043 5053 -32933 5028 -32837 5004
--32753 4981 -32674 4965
-37: 4270790 242703 -32027 4151 -31954 4129 -31854 4099 -31729 4062 -31581 4019
--31414 3972 -31224 3921 -31008 3865 -30772 3812 -30516 3754 -30240 3693
--29945 3638 -29633 3583 -29308 3519 -28967 3467 -28619 3420 -28257 3365
--27903 3312 -27536 3275 -27170 3242 -26808 3201 -26453 3167 -26104 3152
--25766 3147 -25437 3136 -25123 3123 -24826 3131 -24545 3164 -24279 3208
--24032 3246 -23802 3282 -23592 3335 -23399 3419 -23227 3521 -23071 3622
--22932 3705 -22812 3786 -22711 3888 -22629 4015 -22562 4146 -22513 4272
--22482 4403 -22479 4550 -22499 4690 -22546 4779 -22613 4808 -22713 4812
--22855 4837 -23040 4897 -23238 4961 -23516 4978 -23765 4916 -24034 4770
--24294 4517 -24632 4343 -24986 4126 -25302 3728 -25715 3145 -26164 2561
--26782 2179 -27008 2008 -27864 1865 -28254 1606 -28637 1267 -28897 990
--29252 888 -29398 979 -29412 1211 -29498 1535 -29380 1911 -29091 2293
--28733 2626 -28346 2861 -27794 2987 -27055 3023 -26390 3028 -25697 3064
--24771 3197 -23821 3427 -22796 3689 -21638 3936 -20446 4154 -19619 4323
--18868 4457 -18468 4608 -18261 4760 -18097 4809 -18037 4749 -17689 4754
--17603 4997 -17667 5423 -17446 5754 -17058 5812 -16732 5739 -16667 5843
--16254 6278 -15501 6894 -14970 7398 -14861 7628 -14686 7679 -14290 7839
--13769 8412 -13279 9554 -12933 11177 -12982 12819 -13487 13433 -14360 11667
--11390 9358 -17143 5964 -24462 1969 -30989 5754 -34149 6576 -37978 9631
--35777 9704 -35162 11300 -33794 12329 -31037 13608 -27002 15164 -23329 16349
--23271 14812 -25513 10197 -29969 5546 -31145 5333 -30106 1292 -28186 631
--28073 -2630 -29690 -2046 -30010 672 -29012 4580 -25906 3889 -19497 4348
--21306 2733 -24734 4790 -24778 11599 -10135 8946 -15602 1458 -23690 5279
--27045 1569 -21555 -2660 -27717 -1628 -25749 -9907 -24506 -15573 -33620 -9753
--32628 -5952 -27055 2700 -20077 824 -23818 -4512 -33267 -1840 -26655 8281
--14165 10216 -12847 -2145 -14676 -9083 -14330 -19716 -26988 -12845 -30068 -11470
--23887 -11262 -23093 -5824 -18321 -2963 -29826 -1324 -33365 -3286 -32289 20279
--10687 5500 -27024 -1779 -23000 5000 -13643 -11209 -40856 -8574 -19906 -6100
--28148 -1772 -49187 -7694 -49506 1136 -44018 5787 -38566 6775 -34895 5704
--32604 4243 -31021 3116 -29229 2492 -27228 1965 -25340 1206 -23681 243
--22286 -562 -21326 -851 -20608 -338 -20439 932 -23045 3000 -25933 4431
--26635 5184 -28204 5973 -29555 7026 -29815 7981 -29424 8304 -26564 6959
--26452 3416 -36795 7382 -30577 17714 -25315 12788 -33947 5285 -23562 -2727
--36129 9740 -33464 8236 -26350 1122 -20193 184 -18547 997 -20013 3686
--23384 5264 -27379 6045 -31190 6176 -34605 5987 -37643 5708 -40363 5465
--42789 5310 -44930 5250 -46805 5269 -48433 5350 -49806 5480 -50939 5654
--51873 5856 -52574 6076 -53086 6297 -53430 6512 -53603 6714 -53631 6897
--53542 7065 -53345 7209 -53041 7333 -52648 7434 -52189 7512 -51670 7568
--51097 7602 -50477 7619 -49831 7617 -49160 7599 -48470 7566 -47769 7521
--47064 7464 -46360 7399 -45656 7325 -44960 7244 -44276 7159 -43605 7070
--42952 6977 -42315 6883 -41696 6787 -41100 6692 -40526 6596 -39974 6502
--39444 6407 -38935 6317 -38454 6227 -37995 6141 -37556 6056 -37142 5975
--36751 5896 -36381 5820 -36036 5748 -35706 5679 -35397 5613 -35111 5552
--34839 5492 -34591 5437 -34357 5384 -34141 5334 -33941 5288 -33755 5245
--33584 5205 -33426 5170 -33282 5135 -33151 5105 -33031 5076 -32920 5048
--32825 5021 -32737 4999 -32661 4981
-38: 4289787 226263 -32014 4151 -31931 4128 -31816 4096 -31673 4056 -31511 4011
--31327 3961 -31117 3906 -30883 3851 -30629 3792 -30351 3729 -30054 3670
--29743 3612 -29410 3547 -29067 3484 -28709 3435 -28345 3378 -27971 3316
--27597 3266 -27221 3231 -26845 3187 -26473 3139 -26112 3108 -25759 3095
--25417 3082 -25089 3058 -24777 3045 -24482 3063 -24209 3101 -23953 3135
--23715 3160 -23495 3193 -23298 3256 -23123 3351 -22964 3454 -22824 3544
--22702 3621 -22595 3712 -22511 3837 -22442 3989 -22384 4139 -22344 4282
--22327 4428 -22329 4575 -22362 4688 -22396 4743 -22480 4758 -22586 4784
--22731 4857 -22893 4962 -23184 5058 -23394 5103 -23703 5070 -23954 4949
--24280 4733 -24533 4531 -24776 4165 -25253 3576 -25704 2902 -26276 2385
--26469 2118 -27565 1940 -27899 1625 -28360 1140 -28814 668 -29397 415
--29634 465 -29793 745 -29941 1140 -29897 1565 -29631 1973 -29348 2325
--29012 2588 -28601 2744 -27989 2807 -27415 2829 -26862 2886 -25944 3048
--24943 3343 -23902 3702 -22748 4019 -21520 4247 -20450 4390 -19523 4463
--18822 4513 -18457 4593 -18201 4661 -18060 4634 -17782 4566 -17799 4643
--18132 4964 -18037 5358 -17744 5533 -17565 5411 -17631 5259 -17580 5421
--16986 5983 -16303 6697 -16103 7207 -16059 7332 -15738 7173 -15068 7044
--14313 7307 -13716 8230 -13603 9932 -14451 12444 -15878 13497 -15543 10087
--8171 8346 -28912 4549 -30347 10590 -26272 10882 -31128 4635 -39278 6899
--34707 7092 -34426 9987 -33985 10828 -31103 12152 -25955 14288 -20158 17570
--20693 17683 -24140 15049 -30625 1847 -29612 5443 -34958 5042 -38483 -1142
--30122 -1997 -25282 -2471 -28901 2779 -27258 -426 -22000 -2000 -23337 2942
--21557 3643 -19151 6165 -23323 9526 -17533 7474 -19400 3332 -24813 2861
--23017 5224 -23093 3458 -25297 -2098 -24013 -8448 -23335 -9557 -29471 -8426
--28321 -17743 -32121 3473 -19482 4354 -21804 -8669 -44845 -8258 -32295 12341
--11043 17856 -13334 -5921 -21480 -8896 -18745 -12660 -19701 -14282 -30239 -11101
--23147 -13790 -28979 -3151 -17398 -2715 -23053 -1595 -30915 -2257 -21242 6773
--22943 5645 -23775 872 -21423 -2745 -22375 -1627 -32481 -10940 -29012 -11283
--34249 -7980 -47332 -2156 -44521 8353 -38749 11236 -34367 9505 -32838 6349
--31885 3851 -30960 2364 -28740 2035 -26341 1764 -24111 910 -22491 -507
--21698 -1788 -21396 -2480 -21147 -2311 -19042 -564 -23035 2688 -26523 4398
--24821 4710 -28657 5576 -31252 6927 -30738 8405 -29121 9477 -25671 8630
--25543 9439 -33079 26253 -34494 12302 -25215 6256 -34526 2406 -26003 -2945
--32962 8120 -35682 8397 -33150 2616 -17841 2681 -16449 2586 -18689 3319
--22507 4179 -26637 4690 -30544 4860 -34049 4835 -37161 4750 -39934 4695
--42393 4701 -44551 4781 -46433 4916 -48058 5093 -49428 5303 -50555 5546
--51480 5812 -52179 6086 -52691 6354 -53034 6605 -53212 6842 -53244 7054
--53161 7242 -52974 7405 -52680 7543 -52300 7653 -51856 7738 -51351 7795
--50795 7831 -50191 7845 -49562 7839 -48911 7816 -48238 7777 -47553 7725
--46865 7660 -46177 7587 -45491 7504 -44810 7416 -44140 7323 -43483 7226
--42842 7124 -42217 7024 -41609 6920 -41023 6818 -40458 6716 -39914 6614
--39392 6514 -38892 6417 -38413 6322 -37961 6230 -37528 6141 -37115 6053
--36728 5971 -36361 5890 -36017 5814 -35690 5740 -35381 5670 -35097 5605
--34827 5542 -34579 5483 -34345 5427 -34130 5375 -33929 5325 -33743 5279
--33572 5237 -33415 5198 -33269 5163 -33138 5130 -33016 5099 -32909 5068
--32812 5042 -32723 5016 -32645 4996
-39: 4308820 209882 -31993 4148 -31897 4124 -31768 4089 -31609 4048 -31430 4001
--31227 3946 -30998 3891 -30750 3832 -30472 3769 -30179 3704 -29863 3645
--29529 3579 -29182 3509 -28820 3452 -28445 3397 -28066 3329 -27677 3266
--27291 3223 -26904 3182 -26517 3123 -26139 3074 -25771 3049 -25416 3034
--25072 3005 -24747 2974 -24438 2969 -24148 2994 -23883 3027 -23637 3044
--23413 3059 -23209 3096 -23025 3173 -22867 3275 -22727 3375 -22606 3454
--22499 3533 -22414 3643 -22343 3798 -22291 3971 -22242 4135 -22223 4284
--22205 4428 -22225 4551 -22227 4630 -22315 4664 -22379 4696 -22466 4771
--22590 4902 -22880 5054 -23037 5188 -23408 5268 -23661 5267 -24017 5152
--24076 4971 -24277 4654 -24855 4090 -25257 3362 -25735 2716 -25961 2324
--27041 2096 -27392 1759 -27864 1168 -28576 474 -29426 -14 -29806 -95 -30015 200
--30229 689 -30230 1194 -30039 1630 -29886 1980 -29706 2249 -29408 2442
--28994 2562 -28500 2641 -28100 2741 -27316 2946 -26248 3308 -25145 3794
--24065 4260 -22944 4555 -21780 4644 -20633 4591 -19505 4476 -18707 4389
--18148 4383 -17792 4400 -17544 4367 -17603 4369 -18181 4551 -18374 4908
--18192 5202 -18183 5182 -18451 4912 -18702 4752 -18479 5041 -17847 5769
--17484 6590 -17472 7086 -17344 7056 -16760 6599 -15984 6033 -15420 5749
--15411 6111 -16469 7448 -19525 10138 -24542 12837 -11167 5660 -16583 241
--44517 8428 -20907 21673 -13905 18090 -21945 11000 -46053 4807 -30976 3241
--32852 9269 -34060 8321 -30693 9584 -25255 11101 -16031 16166 -19026 15459
--21090 11005 -41790 9709 -19800 6429 -31580 4315 -39461 1395 -39506 -374
--26505 403 -27678 999 -26033 -8872 -25421 2172 -25357 3383 -21294 2630
--18002 7667 -20607 8264 -19354 6231 -20790 5268 -24494 2890 -24967 4097
--21793 3410 -27099 -3362 -27354 -9930 -24883 -4259 -25095 -4048 -24605 -2664
--29410 -15541 -24216 1332 -18906 -4544 -55841 -20594 -38657 12765 -12668 18513
--14287 -8897 -18638 -4991 -20187 -6288 -16806 -12105 -22041 -12404 -26332 -10443
--21666 -4022 -23042 -2799 -24105 -5520 -22418 2482 -24363 10471 -23880 2705
--25109 -712 -25412 -2167 -29599 207 -23763 -13100 -37860 -7057 -34323 -5734
--50350 -5435 -38192 12829 -32295 14604 -28835 9965 -30912 5000 -31030 2225
--31058 704 -27738 1460 -25157 1851 -22785 991 -21523 -1154 -21944 -2995
--22643 -4374 -22618 -3902 -17923 -3079 -24090 1687 -24279 4559 -20731 3831
--29165 6326 -33988 7540 -31710 9030 -29311 11012 -23113 9693 -23405 20857
--31870 23291 -28338 19174 -32877 6016 -13665 -2236 -37926 1445 -35633 7586
--41899 9189 -29857 2638 -19309 2274 -17381 2283 -19157 2571 -22794 2926
--26797 3206 -30615 3384 -34069 3503 -37151 3620 -39898 3769 -42327 3965
--44451 4207 -46297 4480 -47884 4766 -49218 5068 -50312 5391 -51207 5739
--51881 6072 -52376 6387 -52705 6681 -52872 6951 -52898 7195 -52813 7408
--52626 7592 -52339 7744 -51965 7865 -51529 7954 -51037 8017 -50492 8054
--49904 8064 -49291 8055 -48655 8026 -47999 7981 -47331 7922 -46658 7849
--45987 7768 -45317 7678 -44651 7581 -43997 7480 -43353 7376 -42724 7267
--42111 7160 -41516 7048 -40940 6939 -40386 6831 -39848 6724 -39335 6618
--38841 6515 -38370 6414 -37920 6317 -37494 6224 -37086 6131 -36701 6044
--36338 5960 -35995 5879 -35669 5802 -35365 5727 -35080 5658 -34814 5592
--34563 5529 -34330 5471 -34117 5414 -33915 5363 -33728 5314 -33560 5269
--33401 5228 -33257 5190 -33123 5155 -33001 5123 -32894 5091 -32796 5060
--32708 5035 -32629 5011
-40: 4327888 193561 -31960 4142 -31851 4116 -31711 4080 -31535 4037 -31338 3986
--31119 3931 -30874 3872 -30603 3809 -30310 3743 -29997 3679 -29664 3614
--29312 3541 -28946 3474 -28568 3420 -28180 3350 -27783 3275 -27380 3222
--26981 3179 -26585 3121 -26191 3053 -25807 3011 -25432 2991 -25077 2964
--24735 2919 -24412 2888 -24108 2893 -23827 2920 -23572 2936 -23337 2936
--23129 2946 -22942 2996 -22775 3089 -22637 3195 -22520 3282 -22417 3354
--22333 3443 -22266 3580 -22220 3760 -22172 3946 -22167 4111 -22120 4253
--22136 4377 -22120 4470 -22222 4524 -22227 4568 -22273 4646 -22374 4788
--22605 4977 -22734 5173 -23108 5345 -23380 5461 -23766 5477 -23853 5333
--23916 5140 -24524 4659 -24831 3932 -25197 3186 -25458 2658 -26269 2356
--26778 2022 -27092 1392 -28092 507 -29270 -286 -29808 -627 -30016 -419
--30329 148 -30441 777 -30410 1276 -30434 1607 -30459 1836 -30326 2032
--30038 2227 -29620 2423 -29272 2632 -28715 2905 -27683 3318 -26477 3911
--25401 4583 -24442 5109 -23412 5268 -22158 5041 -20629 4648 -19181 4259
--18073 3997 -17322 3936 -16972 3990 -17095 4054 -17859 4201 -18494 4499
--18545 4833 -18636 4963 -19120 4744 -19633 4372 -19747 4272 -19355 4738
--18942 5652 -18885 6578 -18876 7052 -18430 6856 -17645 6071 -17045 4999
--17198 4050 -18522 3628 -21547 4215 -28898 7067 -56381 17694 -4965 3777
--5574 6665 -21337 31 -6392 11744 -9974 24660 -41588 24634 -45491 8974
--26373 3897 -31544 6883 -33966 5002 -25796 7948 -24317 7171 -15731 8823
--24230 12447 -17013 10014 -40258 7855 -20139 5614 -35018 5667 -37323 2171
--46418 644 -24115 1426 -18480 7146 -28264 -5710 -28158 -1772 -30929 1620
--21800 6316 -17453 10379 -21377 7745 -22218 4698 -24144 2536 -21957 2682
--23996 632 -25990 2392 -23222 -3269 -32219 -1617 -28020 -2070 -26510 -4493
--20503 -6120 -20939 -7297 -22896 -4057 -28363 375 -35299 -6901 -29917 -4035
--30684 2138 -16773 646 4879 -15398 -33395 6971 -36099 -12179 -26087 -4823
--24040 -5442 -21093 -5663 -7904 -3757 -30992 -3951 -22312 1958 -24385 5159
--26198 3376 -28000 -1000 -26355 -4412 -37015 -6334 -34048 6777 -33582 -6031
--33722 2706 -43431 2849 -34273 4195 -28601 10746 -23657 6173 -31425 1001
--29657 65 -32393 -1801 -26193 1213 -24470 2445 -21834 1714 -20816 -1750
--22727 -3850 -23931 -6272 -25374 -5708 -23994 -3952 -11710 -2718 -20388 4026
--18404 -82 -31686 13118 -37809 9634 -31073 9269 -28253 10375 -25665 24829
--26863 16910 -22280 20956 -21038 22624 -29726 2914 -19417 364 -34252 3250
--42087 10308 -41200 7004 -26628 4252 -20139 2652 -18588 1969 -20475 1617
--23807 1533 -27541 1621 -31179 1819 -34518 2089 -37517 2411 -40190 2773
--42547 3168 -44598 3582 -46373 3994 -47893 4396 -49163 4795 -50200 5201
--51043 5639 -51673 6035 -52132 6401 -52432 6739 -52579 7048 -52588 7325
--52493 7565 -52299 7771 -52011 7939 -51639 8070 -51208 8169 -50723 8233
--50190 8270 -49614 8279 -49015 8265 -48393 8230 -47752 8178 -47102 8111
--46444 8031 -45789 7942 -45135 7844 -44485 7739 -43844 7631 -43216 7518
--42600 7404 -42000 7289 -41416 7171 -40851 7056 -40306 6941 -39778 6829
--39273 6719 -38785 6609 -38319 6505 -37877 6402 -37456 6304 -37051 6208
--36671 6116 -36311 6028 -35970 5943 -35648 5862 -35345 5785 -35062 5711
--34796 5642 -34546 5576 -34314 5514 -34100 5455 -33901 5400 -33715 5350
--33543 5302 -33386 5258 -33241 5218 -33108 5181 -32985 5147 -32878 5112
--32779 5081 -32690 5053 -32612 5029
-41: 4346999 177300 -31918 4133 -31796 4105 -31641 4067 -31453 4022 -31240 3969
--31005 3912 -30739 3850 -30451 3783 -30140 3716 -29811 3650 -29460 3578
--29090 3502 -28706 3443 -28314 3377 -27909 3296 -27501 3226 -27085 3182
--26672 3127 -26267 3048 -25867 2984 -25477 2954 -25101 2930 -24743 2882
--24406 2825 -24088 2802 -23790 2817 -23517 2835 -23275 2827 -23058 2813
--22865 2831 -22695 2900 -22554 3004 -22437 3102 -22343 3174 -22265 3240
--22203 3347 -22164 3510 -22127 3709 -22139 3895 -22079 4049 -22103 4172
--22088 4270 -22164 4341 -22144 4399 -22176 4483 -22269 4629 -22396 4836
--22525 5072 -22754 5304 -23113 5509 -23491 5651 -23615 5661 -23771 5459
--24391 5188 -24562 4566 -24707 3792 -24904 3149 -25413 2756 -26048 2428
--26198 1831 -27312 842 -28834 -263 -29574 -998 -29797 -1054 -30216 -513
--30620 258 -30894 892 -31099 1232 -31296 1361 -31341 1463 -31098 1673
--30671 2025 -30251 2458 -29855 2917 -29034 3408 -27805 4024 -26624 4815
--25708 5647 -24933 6213 -23873 6119 -22169 5334 -20007 4460 -18108 3744
--16780 3292 -16118 3253 -16245 3499 -17259 3763 -18500 4130 -19052 4538
--19226 4776 -19749 4692 -20474 4282 -20806 3845 -20626 3843 -20288 4505
--20252 5613 -20372 6648 -20075 7116 -19198 6795 -18253 5733 -18082 4202
--19260 2677 -22189 1588 -26370 1331 -29550 859 -26216 5205 -24300 12674
--39012 20462 -23452 -8266 37642 -16205 -37109 38388 -59547 34080 -23834 13074
--21516 8095 -26029 9855 -36137 2681 -22865 3609 -24285 4262 -20072 1636
--24164 3140 -23428 12393 -35969 13843 -13810 4499 -37091 -7827 -35174 3022
--37239 3500 -24326 9631 -13093 11234 -25260 -1463 -34316 -1615 -36001 2469
--23871 10891 -16805 13665 -24770 7124 -24935 5493 -26442 3667 -25695 -353
--29529 -2299 -25183 -1880 -20483 -5115 -28342 -594 -27900 5538 -20135 6573
--19241 -10920 -21243 -3079 -25465 -2606 -30327 2775 -33634 -5015 -37591 -9000
--29739 -5490 -12509 -62 -17491 8062 -22000 -2000 -28000 -8000 -28000 -7000
--29249 -8289 -23628 -7637 -1530 -429 -17023 -9497 -24461 900 -26285 2334
--23703 2380 -24771 2339 -27701 -472 -40083 -10477 -34441 5563 -36125 8285
--33193 7566 -30807 1434 -44478 95 -33522 8905 -19421 1121 -34695 -3278
--27257 -223 -35904 -4096 -23771 1975 -25663 3021 -21682 3191 -20573 -2851
--23709 -3161 -24541 -5997 -29261 -6985 -23852 -5738 -3125 2320 -16244 3726
--19933 5576 -32725 8154 -35998 9959 -32590 12345 -30814 13417 -23205 28425
--34208 15880 -15829 13219 -17000 12000 -21563 10288 -22962 15443 -39077 2543
--37678 6000 -36234 6254 -26058 4828 -21215 2742 -19952 1419 -21766 443
--24887 -19 -28440 -56 -31942 210 -35185 659 -38101 1200 -40697 1782 -42971 2372
--44936 2949 -46619 3494 -48046 4007 -49230 4500 -50187 4994 -50963 5514
--51535 5974 -51945 6396 -52206 6784 -52320 7136 -52306 7448 -52194 7720
--51987 7947 -51690 8133 -51318 8276 -50890 8381 -50409 8448 -49883 8482
--49319 8489 -48732 8469 -48125 8428 -47499 8368 -46863 8292 -46223 8204
--45584 8107 -44945 8001 -44310 7888 -43685 7774 -43070 7652 -42469 7533
--41881 7411 -41310 7288 -40757 7166 -40219 7047 -39702 6930 -39205 6814
--38725 6702 -38266 6591 -37831 6485 -37413 6382 -37013 6283 -36637 6187
--36280 6094 -35943 6005 -35623 5922 -35322 5841 -35040 5764 -34776 5692
--34528 5623 -34298 5558 -34082 5496 -33883 5439 -33698 5385 -33525 5334
--33370 5289 -33224 5247 -33090 5208 -32969 5171 -32861 5135 -32760 5101
--32674 5072 -32594 5045
-42: 4366157 161100 -31868 4119 -31733 4090 -31564 4052 -31366 4003 -31136 3949
--30881 3889 -30599 3823 -30293 3755 -29966 3688 -29620 3615 -29251 3538
--28866 3468 -28465 3406 -28058 3325 -27638 3242 -27218 3187 -26791 3137
--26368 3059 -25954 2973 -25549 2924 -25153 2901 -24775 2858 -24420 2785
--24085 2728 -23772 2722 -23485 2738 -23224 2734 -22998 2701 -22798 2683
--22623 2719 -22477 2808 -22358 2913 -22269 2989 -22202 3040 -22151 3108
--22118 3236 -22100 3425 -22117 3631 -22076 3805 -22128 3939 -22126 4041
--22123 4123 -22164 4196 -22163 4288 -22259 4433 -22309 4645 -22431 4899
--22427 5161 -22850 5415 -23183 5645 -23393 5800 -23631 5794 -24155 5533
--24566 5146 -24387 4476 -24368 3797 -24680 3330 -25268 3005 -25487 2495
--26367 1517 -28093 178 -29124 -1027 -29353 -1566 -29843 -1270 -30712 -439
--31510 405 -31936 874 -32199 910 -32313 769 -32100 795 -31545 1190 -30957 1921
--30544 2790 -30040 3591 -29004 4260 -27736 4954 -26715 5845 -26022 6805
--25389 7504 -24046 7118 -21538 5389 -18449 3962 -16209 2958 -15059 2272
--14997 2374 -16118 3058 -18201 3572 -19771 4238 -20349 4761 -20699 4803
--21301 4458 -21817 3872 -21709 3362 -21348 3444 -21346 4298 -21780 5606
--21895 6769 -21050 7264 -19608 6906 -18539 5685 -18871 3777 -20722 1879
--24768 766 -29471 1339 -30325 79 -14907 2490 -45388 16604 -33794 22123
--23695 12102 12074 -12856 -26963 16668 -44229 21080 -20270 2257 -25067 8988
--28897 9803 -25408 1885 -25850 7713 -25878 6221 -22260 2229 -29736 11369
--23979 5480 -19317 7240 -15480 6477 -40539 9294 -32033 -1985 -29690 -2717
--18838 1642 -13221 5667 -34628 2997 -35146 2998 -33082 3605 -16143 12537
--22711 11928 -27653 9469 -29620 7767 -30838 7883 -26693 -662 -38720 -4575
--22677 -4191 -20910 -4572 -23705 -4451 -18018 4646 -12087 515 -19502 3451
--23389 9669 -30146 1354 -28855 2438 -27743 -4015 -29818 -10605 -21926 -15319
--26611 1050 -27447 5053 -26119 1906 -32896 -781 -33579 -7808 -31224 -7841
--7935 -10262 -21926 218 840 -14554 -24127 -1648 -24522 3507 -23265 5477
--24597 462 -29509 539 -28402 -1150 -38461 2157 -34768 4535 -38980 10375
--35026 5539 -36257 1543 -40955 -8841 -32872 -4693 -22604 799 -27337 3432
--32232 1303 -27312 1902 -29688 98 -22091 4601 -24334 -5244 -22861 -4135
--20759 -2977 -15226 -3475 -15010 506 -21847 8334 -6609 -7832 -22994 13519
--34269 8703 -33000 7000 -31898 11930 -30043 11609 -25678 14730 -29594 16230
--18538 6932 -21149 10025 -23633 33010 -18261 18974 -35783 4145 -43100 3747
--30478 7286 -23308 5469 -20665 2520 -20169 499 -22314 -1042 -25579 -1782
--29144 -1831 -32652 -1409 -35881 -728 -38782 58 -41332 862 -43528 1635
--45391 2357 -46968 3018 -48293 3630 -49380 4210 -50248 4786 -50944 5373
--51445 5898 -51797 6381 -52009 6823 -52084 7222 -52041 7575 -51904 7878
--51682 8129 -51373 8332 -50997 8486 -50566 8594 -50091 8661 -49571 8693
--49016 8693 -48441 8667 -47847 8618 -47237 8548 -46617 8463 -45993 8367
--45369 8261 -44746 8149 -44128 8027 -43518 7905 -42919 7780 -42330 7652
--41756 7525 -41198 7397 -40655 7271 -40128 7147 -39621 7025 -39132 6906
--38660 6788 -38209 6675 -37779 6564 -37367 6459 -36973 6354 -36601 6256
--36245 6160 -35911 6068 -35594 5980 -35297 5896 -35017 5817 -34755 5742
--34506 5669 -34276 5602 -34064 5537 -33865 5476 -33679 5421 -33507 5369
--33351 5320 -33205 5275 -33074 5235 -32952 5195 -32842 5157 -32743 5123
--32654 5091 -32576 5063
-43: 4385360 144959 -31809 4102 -31664 4072 -31483 4031 -31268 3981 -31024 3924
--30752 3862 -30454 3794 -30133 3725 -29789 3654 -29426 3576 -29043 3500
--28643 3434 -28223 3359 -27804 3268 -27370 3198 -26934 3149 -26501 3078
--26067 2981 -25648 2906 -25237 2875 -24838 2843 -24460 2768 -24107 2680
--23777 2638 -23472 2647 -23196 2652 -22948 2614 -22736 2561 -22559 2554
--22407 2615 -22285 2715 -22195 2800 -22136 2844 -22100 2874 -22076 2954
--22087 3111 -22079 3320 -22130 3522 -22168 3678 -22192 3790 -22132 3880
--22305 3965 -22212 4070 -22323 4218 -22353 4426 -22484 4676 -22288 4941
--22565 5199 -22860 5459 -23125 5708 -23488 5884 -24164 5878 -24615 5599
--24172 5125 -23878 4536 -24070 4069 -24610 3777 -25086 3395 -25593 2548
--27163 1122 -28471 -519 -28714 -1720 -29141 -1992 -30444 -1356 -31983 -327
--32843 451 -33067 599 -33037 199 -32838 -268 -32224 -229 -31401 581 -30787 1977
--30515 3511 -30041 4722 -28911 5393 -27696 5880 -26948 6687 -26401 7693
--25871 8867 -24052 8406 -20348 4952 -15893 3169 -13733 2130 -13383 988
--14372 1346 -16615 2912 -19903 3497 -21882 4603 -22437 5303 -22526 4970
--22599 4335 -22798 3607 -22257 2925 -21949 3020 -22558 4043 -23617 5581
--23632 6909 -21920 7431 -19808 7152 -18634 5951 -19694 3851 -21104 1177
--24918 -714 -29688 2403 -37518 3843 -28982 -2011 -26329 14345 -18342 16542
--29771 16694 -12457 2385 -25678 7885 -35277 7417 -24242 1530 -27209 3135
--34511 10230 -17341 231 -23315 13712 -24151 10716 -15038 6731 -31290 18645
--24527 5741 -15036 -6742 -24690 -54 -37920 8906 -27898 4292 -22277 -1713
--22248 -6537 -19041 -1536 -36970 4020 -28929 10045 -24014 4369 -21602 11206
--23495 11638 -29138 10594 -34319 4074 -34261 3035 -34606 -1173 -35338 8936
--22473 -3622 -23768 -2688 -21109 52 -18417 -7477 -9746 -1671 -14140 4707
--18974 23765 -28660 7124 -29078 8853 -22696 540 -28829 -3480 -21267 -9434
--34906 -14001 -26989 -1703 -28800 63 -39393 1805 -36938 1460 -38058 -5603
--677 -33560 1657 -8246 -21293 775 -21741 -2333 -17946 2364 -21286 5740
--22549 1795 -28540 5647 -26894 3782 -32401 -300 -30515 4716 -43423 8266
--42392 -7646 -41000 2000 -46533 -7476 -27894 1149 -24659 1350 -27737 1200
--36279 1584 -29921 -1771 -29665 -273 -18312 -2763 -24000 2000 -27360 -2597
--20640 5597 -8444 14787 459 670 -16173 -8600 -19612 -3725 -27230 6868
--37008 6621 -36447 2059 -23455 4273 -21454 9146 -24355 21747 -37357 24808
--13188 2851 -18237 17962 -28610 42679 -30082 17604 -28554 300 -44173 8255
--28904 7219 -21636 5157 -19359 1770 -19269 -870 -22049 -2893 -25716 -3774
--29608 -3689 -33264 -2990 -36621 -2001 -39546 -937 -42047 87 -44166 1025
--45934 1868 -47405 2623 -48617 3313 -49592 3968 -50355 4609 -50958 5240
--51380 5827 -51667 6371 -51824 6873 -51856 7322 -51778 7716 -51615 8051
--51373 8324 -51051 8539 -50667 8700 -50235 8810 -49762 8873 -49248 8899
--48704 8891 -48139 8855 -47559 8795 -46964 8717 -46360 8623 -45752 8517
--45146 8403 -44540 8283 -43938 8156 -43343 8026 -42760 7895 -42185 7762
--41625 7631 -41079 7498 -40548 7368 -40033 7240 -39534 7115 -39055 6991
--38592 6872 -38148 6755 -37722 6641 -37317 6531 -36928 6424 -36560 6322
--36210 6223 -35876 6129 -35564 6038 -35269 5952 -34991 5868 -34730 5790
--34483 5716 -34254 5646 -34042 5578 -33845 5514 -33659 5457 -33489 5402
--33329 5352 -33187 5304 -33055 5263 -32933 5220 -32823 5180 -32724 5144
--32635 5110 -32557 5081
-44: 4404619 128877 -31746 4080 -31591 4048 -31398 4006 -31166 3955 -30908 3897
--30620 3830 -30308 3762 -29970 3691 -29614 3615 -29230 3535 -28833 3465
--28417 3392 -27987 3304 -27552 3218 -27109 3161 -26656 3100 -26216 3004
--25777 2907 -25349 2856 -24931 2831 -24535 2767 -24157 2660 -23804 2577
--23483 2563 -23187 2577 -22921 2550 -22692 2473 -22501 2414 -22341 2432
--22217 2516 -22121 2609 -22066 2654 -22041 2657 -22032 2679 -22077 2785
--22025 2976 -22233 3201 -22162 3392 -22264 3524 -22266 3621 -22506 3716
--22301 3835 -22428 3996 -22502 4205 -22733 4449 -22420 4691 -22291 4912
--22574 5129 -22844 5379 -23296 5660 -24101 5889 -24805 5944 -24632 5729
--23546 5267 -23499 4887 -24122 4691 -24857 4515 -25253 3932 -26209 2617
--27537 701 -27911 -1206 -28105 -2370 -29528 -2388 -31843 -1465 -33528 -307
--33825 327 -33339 52 -32901 -924 -32523 -1830 -31761 -1701 -30881 -197
--30513 2215 -30639 4695 -30531 6398 -29299 6725 -28046 6476 -27678 6986
--26984 7621 -26719 9948 -24317 10314 -19024 3480 -12345 2329 -11128 1913
--12218 -434 -14376 179 -17144 3484 -22146 3334 -24541 5280 -24693 6323
--23876 5259 -22848 4392 -23493 3674 -22506 2510 -22359 2480 -23831 3669
--25969 5517 -25980 7080 -22834 7459 -20066 7354 -18718 6761 -21348 3242
--21750 1119 -24975 -1942 -33811 5454 -30449 658 -30575 -3694 -25846 8633
--22634 20582 -25786 12116 -21153 10032 -25696 8227 -33849 6506 -27929 -5247
--28218 -330 -27861 6453 -15125 8647 -26328 15460 -26062 10180 -13982 8161
--14074 20842 -22484 13925 -27751 -10012 -34664 -5830 -33710 351 -26038 6448
--20780 3214 -32548 -4692 -25705 -5277 -22770 1679 -20164 7488 -19389 9470
--21655 7810 -23684 7382 -29283 12022 -38784 1307 -36112 9621 -39959 5968
--38500 1165 -19536 -507 -21324 3822 -28766 -733 -17695 -10258 -14857 -223
--18677 5176 -12681 18381 -19444 10016 -20945 9955 -29919 3055 -32272 -3084
--27766 -13678 -30726 -9687 -24488 -4836 -31061 1548 -36695 4711 -29611 977
--27688 -6240 -4777 -31192 -10523 -14660 -27036 2864 -21412 2339 -10537 1702
--14827 697 -16000 3000 -28495 7037 -31923 9436 -31067 -4422 -26952 5706
--39010 8479 -52553 764 -52958 -8000 -45532 -10030 -28846 -4323 -23182 3330
--35482 1023 -29492 159 -30125 -1059 -28898 -2374 -23485 -2726 -23314 -498
--22750 1454 -18025 -849 2174 4418 -3543 10286 -13186 3344 -31147 2595
--28687 1143 -29221 4755 -34058 741 -10262 1895 -25447 7910 -33167 31818
--34552 26270 -12276 11547 -14121 24351 -34708 33880 -38161 12159 -30677 5713
--32839 8165 -30353 8747 -21141 5857 -17041 1474 -17378 -2364 -21084 -5030
--25707 -5960 -30069 -5567 -34093 -4441 -37537 -3057 -40465 -1683 -42934 -443
--44964 638 -46608 1573 -47933 2392 -48996 3132 -49835 3825 -50480 4507
--50975 5157 -51314 5795 -51532 6399 -51634 6955 -51619 7452 -51507 7882
--51313 8243 -51050 8534 -50714 8758 -50325 8918 -49890 9025 -49418 9080
--48911 9096 -48377 9077 -47825 9029 -47259 8958 -46680 8871 -46091 8766
--45502 8652 -44911 8530 -44326 8402 -43739 8270 -43160 8136 -42594 7999
--42034 7861 -41488 7726 -40953 7591 -40437 7458 -39931 7326 -39445 7198
--38973 7072 -38517 6950 -38081 6830 -37665 6714 -37262 6601 -36880 6491
--36517 6387 -36171 6285 -35840 6189 -35531 6094 -35238 6005 -34963 5920
--34704 5839 -34458 5761 -34230 5689 -34019 5619 -33822 5554 -33637 5492
--33467 5435 -33309 5383 -33167 5334 -33034 5290 -32914 5246 -32801 5203
--32705 5165 -32616 5130 -32537 5099
-45: 4423931 112852 -31680 4052 -31513 4021 -31308 3976 -31062 3925 -30789 3863
--30490 3795 -30162 3727 -29807 3653 -29436 3572 -29041 3496 -28626 3425
--28196 3341 -27755 3249 -27304 3177 -26851 3122 -26389 3036 -25940 2926
--25493 2849 -25058 2819 -24642 2774 -24241 2667 -23865 2546 -23518 2494
--23205 2506 -22917 2501 -22667 2421 -22454 2314 -22287 2270 -22152 2321
--22052 2418 -21989 2475 -21971 2463 -21978 2433 -22051 2467 -21979 2616
--22325 2847 -22108 3079 -22337 3249 -22532 3358 -22653 3454 -22448 3581
--22578 3764 -22716 3999 -23177 4256 -22744 4487 -22173 4648 -22395 4757
--22724 4886 -23102 5119 -23878 5465 -24863 5821 -25093 6031 -24254 5993
--23253 5681 -23783 5599 -24793 5684 -25332 5563 -25477 4653 -26150 2751
--26639 291 -26727 -1909 -27914 -3103 -30739 -2953 -33583 -1767 -34558 -450
--33560 93 -32099 -612 -31573 -2344 -31824 -3976 -31474 -3759 -30738 -1221
--30757 2606 -31593 6367 -32537 8811 -30658 8237 -28681 6348 -28812 6687
--28005 5573 -28720 9613 -25248 12376 -17736 829 -8245 2310 -9075 3373
--11962 -1426 -15112 -880 -16700 4768 -24033 2744 -26494 6406 -25876 7725
--23730 5662 -21126 4845 -25685 4211 -22477 2001 -22292 1751 -24761 3140
--29020 5450 -29607 7461 -23558 7033 -20733 7191 -18696 7289 -24885 2137
--26425 -1108 -17461 3184 -25711 4219 -23628 2608 -33817 6050 -32492 10038
--26487 5390 -30987 3983 -30980 8313 -21469 4897 -32430 9858 -25023 4305
--24448 -487 -17228 1925 -23648 4510 -35315 17683 -22146 6630 -9462 7818
--20623 24707 -23576 19511 -30450 -1639 -39019 -4304 -23305 -4501 -25801 1515
--35719 12789 -32301 -11441 -14426 2824 -10070 6758 -18101 -2316 -20245 -363
--21637 4637 -23274 9625 -24757 7602 -37689 6204 -42931 12505 -35242 4201
--32802 1552 -24944 1806 -23002 2923 -24306 3500 -16342 -3468 -33579 5903
--13465 5393 -18414 10688 -13674 5316 -20397 3982 -29182 -4592 -31187 -3572
--30316 -8776 -25132 -6584 -27714 -8598 -35562 4177 -35806 8387 -28575 2212
--21069 2472 -10033 -25102 -14843 -23128 -29952 -4214 -22603 7338 -736 6255
--12121 5550 -26007 468 -25475 3360 -28031 499 -34645 -4322 -26025 5178
--32347 10128 -72705 8693 -46697 -14777 -30421 -24292 -35083 -2922 -23796 3287
--24786 1380 -32702 -3699 -25846 5848 -27172 -7031 -21424 6627 -23054 -13328
--33623 7492 -25288 7199 282 2484 -6741 7702 -16093 8562 -28964 8097 -26429 1071
--20436 1954 -24338 6055 -8381 6666 -43230 5868 -30069 37427 -25309 21336
--18995 8980 -14732 26895 -62292 25350 -22577 5532 -17643 16721 -28146 8647
--34795 10085 -18334 8723 -12180 2507 -14224 -3835 -20202 -7450 -26091 -8275
--31239 -7325 -35418 -5604 -38908 -3746 -41817 -2045 -44146 -596 -45981 602
--47401 1594 -48515 2433 -49398 3164 -50084 3846 -50595 4526 -50960 5173
--51221 5845 -51373 6492 -51420 7090 -51361 7622 -51212 8080 -50990 8459
--50706 8756 -50358 8980 -49961 9136 -49524 9231 -49056 9277 -48556 9278
--48034 9246 -47495 9185 -46944 9103 -46382 9004 -45811 8891 -45240 8769
--44669 8640 -44100 8505 -43531 8369 -42972 8230 -42420 8089 -41877 7951
--41345 7811 -40826 7673 -40318 7539 -39826 7404 -39348 7275 -38886 7147
--38439 7023 -38013 6901 -37601 6783 -37206 6668 -36829 6556 -36471 6449
--36127 6345 -35802 6246 -35495 6150 -35205 6058 -34931 5970 -34674 5887
--34432 5807 -34206 5732 -33994 5660 -33798 5591 -33614 5528 -33445 5469
--33287 5414 -33143 5364 -33014 5316 -32893 5272 -32781 5228 -32684 5187
--32596 5149 -32515 5117
-46: 4443297 96879 -31610 4021 -31435 3987 -31217 3943 -30958 3888 -30672 3825
--30357 3758 -30017 3687 -29649 3608 -29260 3530 -28853 3455 -28425 3378
--27982 3285 -27530 3202 -27064 3141 -26603 3068 -26133 2960 -25673 2860
--25220 2812 -24781 2780 -24364 2691 -23961 2551 -23590 2450 -23247 2440
--22941 2457 -22667 2400 -22433 2262 -22238 2147 -22093 2139 -21987 2226
--21917 2307 -21891 2304 -21906 2229 -21992 2183 -21957 2258 -22334 2467
--22094 2735 -22376 2960 -22797 3099 -22747 3189 -22650 3304 -22783 3497
--22998 3778 -23665 4100 -23240 4379 -22329 4531 -22384 4522 -22919 4425
--23139 4407 -23525 4619 -24489 5091 -25333 5687 -25041 6176 -24032 6420
--23735 6385 -24913 6626 -25982 6985 -25555 6937 -24696 5623 -24299 3000
--24409 -108 -25531 -2700 -28545 -4106 -32620 -3944 -35212 -2427 -34676 -749
--31796 -53 -29301 -1023 -29476 -3718 -32017 -6749 -32749 -6555 -31767 -2499
--32027 3084 -33492 8309 -36479 12200 -32964 10049 -28717 4970 -31104 6919
--30740 1889 -33046 6352 -25398 1742 -11111 7984 -10156 3868 -7573 4268
--12457 1767 -17876 2520 -16685 -1478 -21623 5777 -25359 7867 -25663 6463
--23396 7021 -16126 5767 -29725 7225 -21810 808 -21388 941 -24357 2571
--32554 5422 -35564 8613 -22309 5848 -23171 5278 -21241 7661 -19632 4143
--23793 -1467 -23576 2647 -26685 2333 -17345 13434 -30354 8672 -32695 5358
--26155 2167 -34456 5447 -36718 6233 -31784 2343 -33403 4112 -23028 4891
--19310 3952 -13729 2900 -24325 2076 -35016 13598 -24030 5814 -15340 10061
--21299 20916 -16690 18237 -24302 8043 -35226 8947 -21508 -14071 -26171 -3604
--42839 1691 -32900 3331 -11453 9238 -2494 13356 -21252 -12726 -21497 -5540
--22250 2194 -24928 6620 -23367 6979 -30954 6651 -45125 9773 -29106 6525
--29431 4889 -30401 5568 -27317 4881 -24983 5820 -20256 5605 -30260 5767
--23932 -2483 -10072 7276 -12066 8638 -27287 -1897 -28345 -8538 -28969 -4449
--28498 -11517 -23884 -5903 -27085 -13786 -36874 8979 -38420 14863 -27101 307
--13522 -3892 -17651 -9188 -19623 -23671 -33815 207 -27232 6573 -4467 11151
--11567 2208 -25695 -5070 -26286 -550 -27150 -3667 -30485 -5522 -26000 -2000
--11007 4282 -52941 -14570 -64037 -447 -46536 -3326 -33793 940 -24609 -8405
--17683 1563 -26089 2611 -25682 2014 -21257 -2569 -22196 3262 -34994 -1209
--29369 2936 -24496 10944 -5843 2014 -14624 7330 -22844 4863 -27253 7739
--24988 4832 -12748 -1375 -15827 8497 -31313 15138 -35738 13551 -29680 29762
--27711 9616 -27373 4606 -17156 27088 -41351 22599 -33678 11467 -5721 22111
--24746 3060 -40451 4146 -9641 22779 -4639 5803 -11250 -5883 -20580 -10312
--27994 -10560 -33435 -8697 -37652 -6230 -41047 -3881 -43650 -1867 -45643 -229
--47120 1059 -48239 2060 -49111 2842 -49791 3487 -50278 4079 -50643 4694
--50917 5326 -51093 6005 -51176 6668 -51166 7285 -51064 7836 -50883 8304
--50635 8689 -50330 8985 -49973 9200 -49570 9342 -49135 9425 -48671 9453
--48180 9440 -47670 9393 -47148 9319 -46613 9225 -46069 9115 -45519 8993
--44968 8865 -44416 8729 -43866 8591 -43316 8450 -42774 8309 -42241 8166
--41714 8025 -41196 7885 -40691 7745 -40196 7610 -39715 7476 -39248 7344
--38796 7216 -38359 7090 -37939 6967 -37535 6848 -37145 6732 -36775 6618
--36420 6509 -36082 6403 -35761 6302 -35455 6204 -35170 6110 -34897 6020
--34642 5933 -34403 5853 -34180 5774 -33969 5701 -33773 5630 -33588 5563
--33420 5502 -33265 5445 -33121 5393 -32990 5345 -32870 5297 -32761 5252
--32663 5209 -32576 5169 -32493 5136
-47: 4462717 80956 -31542 3983 -31357 3949 -31125 3903 -30856 3847 -30554 3783
--30229 3716 -29874 3641 -29494 3561 -29093 3486 -28672 3410 -28232 3322
--27774 3234 -27312 3162 -26838 3096 -26366 3000 -25888 2889 -25420 2815
--24963 2783 -24519 2721 -24098 2584 -23698 2441 -23329 2388 -22992 2412
--22698 2394 -22434 2260 -22216 2079 -22047 1989 -21927 2038 -21846 2143
--21810 2175 -21821 2087 -21902 1959 -21938 1927 -22221 2069 -22191 2349
--22312 2640 -22942 2840 -22918 2935 -22823 3010 -22994 3172 -23375 3474
--24080 3894 -23874 4320 -22754 4603 -22602 4604 -23404 4310 -23709 3886
--23424 3634 -23641 3815 -24691 4501 -25499 5491 -25114 6397 -24434 6995
--25018 7273 -26784 7769 -27452 8393 -24909 8665 -21945 6929 -20154 3378
--21281 -517 -24966 -3614 -30144 -5563 -35123 -5684 -36875 -3576 -34396 -1164
--29178 107 -25480 -651 -26952 -4328 -34797 -10119 -36957 -10090 -34186 -3609
--33837 3607 -35023 9518 -44574 16765 -34784 11810 -28036 2629 -24740 5793
--47991 8583 -27266 5783 -21565 367 -23903 -1782 -27918 4615 6313 4225
--6317 1189 -21034 7897 -14790 6109 -13662 13032 -16075 -2113 -23211 -1680
--23943 6530 -9261 6497 -41111 11726 -19150 -1362 -20439 985 -21480 2518
--34340 5220 -44670 10934 -15447 3934 -21000 5000 -26356 5256 -18982 3793
--19751 500 -28911 4451 -31516 10176 -4451 7495 -25640 12307 -38236 4822
--30890 6717 -35168 9523 -31958 455 -30141 505 -42988 -901 -30545 -4350
--16829 5818 -17069 5865 -22287 2714 -27767 14625 -23640 5425 -17839 5315
--16646 14418 -15584 16893 -25844 14705 -30696 4896 -8838 -5935 -25321 -7166
--51465 -5390 -35992 6613 -20062 8243 -13608 -467 -14674 137 -17915 5352
--21831 2881 -25007 9712 -27221 11679 -31593 9021 -36075 1493 -27390 4362
--29529 5974 -31907 6577 -29817 6645 -25016 5103 -21047 7226 -23781 5516
--23061 7017 -16845 600 -21079 1715 -23866 -3263 -28919 -8284 -26536 -7531
--26519 -11786 -28693 -14471 -30096 1089 -34433 10992 -32468 8436 -20841 1108
--15179 -2481 -18338 -11369 -29305 -7688 -28999 917 -27286 -2138 -13520 3416
--17097 325 -23361 -2544 -25394 -964 -24483 1153 -28073 -6988 -26966 -6784
--23055 -490 -38671 -2576 -56302 -3087 -50554 -4417 -23311 2826 -23379 -8170
--25337 -8247 -19137 5094 -16981 1476 -22878 -2541 -21340 3684 -34532 -409
--34917 7380 -23154 16110 -14032 9933 -21226 -961 -28014 -3081 -24279 2913
--10158 7917 -21253 12196 -27021 10115 -36349 21422 -32449 7617 -30485 14559
--23812 3629 -19532 -848 -28296 16609 -32471 34358 -29079 33004 -12321 13473
--14730 6057 -26420 11878 -6114 26266 -1860 332 -11811 -11509 -24097 -13484
--31539 -12290 -36754 -9187 -40740 -6012 -43619 -3304 -45704 -1039 -47161 772
--48239 2124 -49047 3059 -49631 3684 -50045 4129 -50385 4534 -50633 5008
--50825 5616 -50900 6269 -50906 6917 -50846 7527 -50710 8075 -50502 8543
--50236 8919 -49916 9206 -49552 9407 -49147 9533 -48715 9597 -48259 9608
--47780 9577 -47285 9514 -46781 9427 -46265 9320 -45742 9200 -45214 9072
--44683 8936 -44152 8798 -43624 8655 -43094 8512 -42571 8369 -42054 8227
--41544 8085 -41043 7946 -40551 7807 -40070 7672 -39601 7537 -39145 7406
--38702 7278 -38275 7152 -37862 7030 -37465 6908 -37082 6792 -36716 6677
--36367 6567 -36033 6459 -35715 6356 -35415 6257 -35132 6160 -34861 6068
--34610 5980 -34371 5897 -34149 5817 -33942 5740 -33745 5668 -33562 5599
--33396 5535 -33241 5477 -33099 5422 -32965 5372 -32847 5323 -32738 5276
--32641 5230 -32555 5191 -32471 5153
-48: 4482183 65078 -31470 3939 -31278 3905 -31036 3858 -30755 3800 -30444 3737
--30106 3668 -29738 3590 -29346 3514 -28932 3438 -28500 3356 -28049 3266
--27579 3188 -27108 3121 -26625 3037 -26139 2929 -25657 2834 -25183 2787
--24720 2745 -24275 2633 -23850 2470 -23450 2364 -23086 2367 -22758 2387
--22470 2292 -22221 2078 -22023 1895 -21876 1869 -21782 1975 -21732 2063
--21733 2005 -21791 1821 -21889 1661 -22057 1681 -22301 1916 -22187 2259
--22926 2550 -23184 2693 -22914 2729 -23105 2798 -23850 3038 -24471 3502
--24480 4118 -23385 4694 -23024 4980 -24053 4772 -24847 4065 -24185 3144
--23074 2523 -23073 2635 -24403 3641 -25816 5244 -25799 6708 -25515 7658
--26719 8135 -28989 8669 -29573 9454 -23120 10786 -17111 8609 -13659 3835
--17893 -929 -25591 -4459 -32716 -7518 -38497 -8643 -39330 -5243 -35097 -1703
--27099 450 -21350 783 -22136 -2989 -41656 -13703 -45367 -13612 -37319 -2773
--39571 4907 -33097 7702 -51550 19402 -31105 6778 -21462 3171 -19076 7440
--41489 10498 -32834 5606 -30527 2329 -30037 3763 -25963 1237 -19123 2484
--14072 -2554 -11244 9388 -5805 5100 -3947 10228 -5811 1986 -17593 2073
--20607 4374 -28427 5987 -25147 4742 -25356 1672 -22881 3565 -21267 4902
--24596 6185 -44661 6144 -23176 3168 -26287 8556 -21302 6844 -16410 3631
--13119 6357 -33169 13168 -26291 3478 -13460 7650 -4924 10716 -27325 14156
--46027 12425 -36983 164 -34604 -129 -26024 10096 -42219 -23987 -40183 -24828
--20362 13597 -23216 11590 -25214 8877 -24631 11432 -21667 7418 -18214 3066
--18030 7950 -18236 10389 -24063 8640 -20833 5487 -2637 18113 -43015 1012
--45509 -13134 -21248 4776 -18288 11243 -20879 -4417 -20339 603 -21278 6460
--25528 4328 -26643 8094 -29113 13118 -26747 9838 -33860 -1624 -31795 -892
--28374 1896 -35141 6641 -33870 11389 -13947 2416 -18145 9979 -29264 6035
--28043 2406 -19908 -1324 -31234 1396 -24979 920 -26271 -1031 -21615 -8966
--24576 -5551 -27985 -5863 -33623 -1678 -26672 2040 -25538 3852 -21400 -2538
--22446 -5673 -22538 -6930 -25742 -3766 -25122 516 -24279 861 -17039 -1468
--22338 -3602 -26866 -2628 -20890 -521 -26770 5487 -22176 -2225 -25720 -11970
--24894 -700 -32210 -5105 -44408 -4171 -48160 -3967 -28047 11103 -20356 -1890
--28701 -9226 -34597 -3559 -15779 -3632 -16669 3050 -25794 3461 -29310 2792
--35812 9839 -21971 7644 -18723 8573 -26925 6479 -26623 -3277 -22267 831
--22350 11266 -21354 17504 -35243 20470 -26401 9254 -17250 6766 -36917 9733
--30818 -2753 -20653 -2233 -36967 41796 -29259 29812 -15733 9300 -16406 11735
--3585 11546 -3535 5476 1613 25278 -10037 4621 -14155 -12708 -29512 -13423
--34859 -12214 -39916 -8147 -43651 -4751 -45994 -2059 -47458 394 -48469 2421
--49180 3822 -49615 4607 -49908 4942 -50200 5052 -50380 5158 -50475 5418
--50583 5988 -50562 6584 -50513 7189 -50428 7777 -50276 8310 -50056 8769
--49777 9137 -49450 9410 -49084 9595 -48685 9703 -48261 9746 -47817 9737
--47354 9689 -46878 9608 -46392 9506 -45900 9388 -45399 9258 -44894 9122
--44387 8982 -43879 8839 -43372 8697 -42865 8553 -42361 8412 -41862 8270
--41370 8129 -40884 7993 -40407 7856 -39940 7723 -39483 7590 -39039 7460
--38605 7334 -38187 7207 -37781 7086 -37391 6965 -37016 6848 -36653 6733
--36312 6621 -35982 6514 -35669 6410 -35370 6307 -35090 6209 -34824 6116
--34575 6026 -34337 5940 -34117 5858 -33910 5780 -33716 5705 -33536 5634
--33369 5569 -33217 5508 -33073 5452 -32942 5399 -32824 5348 -32716 5300
--32616 5253 -32532 5210 -32450 5172
-49: 4501698 49239 -31403 3890 -31202 3854 -30951 3806 -30660 3750 -30337 3685
--29991 3613 -29610 3537 -29208 3463 -28783 3384 -28341 3297 -27876 3215
--27397 3144 -26919 3069 -26425 2969 -25933 2867 -25442 2800 -24959 2761
--24495 2681 -24048 2527 -23621 2380 -23223 2336 -22864 2369 -22541 2331
--22263 2136 -22031 1878 -21849 1746 -21727 1809 -21662 1946 -21642 1962
--21683 1777 -21791 1505 -21907 1351 -22279 1461 -22146 1799 -22740 2185
--23383 2433 -23037 2481 -23068 2437 -24226 2503 -24973 2856 -24984 3543
--24080 4440 -23568 5252 -24709 5599 -26240 5161 -26060 3905 -23937 2255
--21910 1067 -21814 1010 -23858 2433 -26883 4994 -27388 7138 -26947 8338
--27977 8732 -30728 8908 -33799 9226 -20423 13319 -11507 10294 -4770 4261
--15068 -1096 -28131 -4505 -35676 -9633 -42954 -13679 -42164 -6992 -38305 -2359
--27756 -21 -19007 1827 -15949 671 -50529 -14752 -53556 -13888 -42096 4880
--52603 6991 -46686 7449 -20110 8141 -17447 9160 -8834 13223 -34131 11684
--47716 1990 -34491 9802 -33271 -2000 -34244 668 -16735 -7135 -21043 324
--10691 -2009 -11960 4580 -13327 14572 -11675 350 -10728 6867 -9044 8805
--13553 2978 -26772 9365 -24228 2635 -26600 -210 -21400 3210 -24000 11000
--21014 8248 -29590 7219 -37436 -2117 -23206 14856 -23539 -4970 -15010 6758
--181 27310 -32944 7956 -20194 -7361 -17829 -2571 -7511 21166 -29699 22141
--36253 13910 -22557 3249 -20738 2331 -44551 11692 -38533 -39091 -41339 -36826
--38891 4536 -23774 18257 -32726 13773 -28426 8929 -23192 5159 -17894 4209
--20780 5250 -18372 6582 -21283 5877 -18185 7478 -15725 7377 -24488 3564
--41997 -1696 -21901 5856 -13114 7538 -26492 4070 -27535 4584 -28579 7421
--24821 5704 -26620 6425 -30207 14192 -27491 4226 -41220 -2628 -28191 991
--26236 478 -31713 323 -31023 2625 -17160 7015 -22119 4426 -28757 6895
--30281 5154 -24965 7301 -36208 6486 -28981 4036 -27941 3234 -22935 -5700
--16026 -4305 -21211 1529 -32583 -2617 -25638 -4815 -25287 -3322 -23493 -6725
--24066 -7705 -25349 -5887 -24284 -1873 -22810 574 -22282 1055 -14654 713
--18019 -3671 -26708 -4172 -25560 -45 -30408 260 -20938 987 -23372 -5110
--25872 -2311 -30423 -372 -35721 -5209 -40115 -8229 -32954 5517 -25502 3581
--33058 -11335 -25297 -907 -21192 -2863 -23337 -898 -25961 3847 -26957 3379
--31984 5074 -19181 7218 -19851 6020 -25870 6424 -32991 5827 -24807 4205
--20373 10167 -19615 17064 -21300 3287 -26604 3796 -5998 7704 -77002 29296
--29027 2263 -31176 12118 -17684 26708 -37893 18292 -13368 -5119 -19861 16651
--4755 35718 13757 -10043 -14960 3373 -9087 14594 4093 -12282 -30359 -8690
--32674 -11107 -40684 -5535 -45388 -2814 -47451 -676 -48609 2140 -49325 4593
--49653 6075 -49804 6605 -49980 6497 -50061 6124 -50070 5828 -50106 5814
--50023 6320 -49997 6847 -49968 7408 -49892 7974 -49738 8503 -49520 8961
--49253 9327 -48937 9592 -48574 9765 -48181 9854 -47768 9876 -47339 9844
--46896 9774 -46444 9674 -45983 9557 -45516 9425 -45041 9286 -44561 9142
--44081 8998 -43597 8855 -43113 8713 -42629 8571 -42145 8432 -41667 8294
--41191 8158 -40722 8025 -40259 7893 -39807 7762 -39361 7633 -38928 7506
--38505 7381 -38095 7259 -37697 7136 -37315 7017 -36946 6901 -36590 6786
--36253 6674 -35929 6565 -35618 6460 -35323 6357 -35045 6257 -34783 6162
--34536 6070 -34303 5983 -34083 5900 -33876 5818 -33687 5742 -33507 5669
--33341 5602 -33190 5539 -33048 5481 -32918 5427 -32800 5374 -32691 5323
--32592 5274 -32508 5230 -32429 5191
-50: 4521259 33434 -31339 3834 -31132 3797 -30874 3749 -30572 3692 -30240 3627
--29883 3554 -29495 3481 -29081 3406 -28645 3323 -28195 3240 -27721 3166
--27231 3094 -26741 3007 -26247 2904 -25742 2823 -25246 2777 -24762 2718
--24289 2593 -23839 2430 -23414 2335 -23013 2349 -22661 2359 -22347 2221
--22081 1941 -21861 1702 -21699 1670 -21598 1815 -21563 1923 -21580 1806
--21668 1477 -21777 1144 -22099 1048 -22192 1279 -22473 1713 -23338 2101
--23299 2250 -22977 2155 -24214 1999 -25534 2057 -25604 2548 -24686 3522
--24125 4807 -25268 6001 -27425 6551 -28452 5949 -26724 4043 -22937 1347
--20253 -635 -20399 -1060 -23298 761 -29370 4874 -29848 7721 -28359 8951
--27948 8840 -29552 8295 -41461 6618 -17284 15752 -8994 9330 5838 5265
--14260 413 -33099 -2447 -36731 -10844 -47913 -22366 -45386 -6711 -43943 -2723
--29555 -2766 -27330 -2649 -21218 -9415 -38467 6318 -41973 989 -40640 8139
--59675 3872 -39293 1766 -23390 2171 -12225 8197 -16459 9180 -35582 19914
--39974 1984 -35597 5628 1285 8170 -27023 15707 -41306 -18477 -10945 4107
--28456 -3527 -15932 -14714 -12245 13349 -25877 10652 -10889 13122 -11877 17080
--16974 -2641 -15387 1507 -37271 6197 -20384 4800 -16545 6260 -17575 -7759
--24337 8044 -28464 7365 -36348 1810 -18880 9097 -25811 13882 -22052 10675
-13322 28078 -29767 10093 13828 -19461 -28573 6959 -14255 25502 -45505 16257
--26286 10440 -20835 6211 -30562 6348 -47657 4525 -12502 -43475 -41080 -12349
--51435 -48816 -22083 21796 -31787 17067 -48002 15417 -26539 6673 -20589 1762
--23743 3017 -18961 5448 -16601 4325 -18706 5985 -22028 9538 -24909 8946
--21190 4885 -27475 1603 -23900 5099 -26758 6305 -30077 6433 -29713 6990
--24062 12827 -35910 5039 -25019 5087 -28564 2196 -30587 -4231 -35135 1204
--25681 -264 -36018 -733 -32924 -752 -16138 316 -20416 11652 -32489 9633
--31431 4967 -25408 9819 -36937 7691 -32263 6090 -31320 3859 -17775 -1830
--18941 -356 -21791 4320 -25494 -977 -28985 -8158 -26828 -6945 -24961 -11884
--24000 -9000 -23270 -7063 -25032 -2341 -24385 -3535 -18109 211 -16328 4136
--19504 751 -25372 -159 -21248 -1491 -26877 -1338 -24888 1147 -25185 -3220
--25851 833 -28072 2746 -33851 -6588 -35510 -5023 -34845 83 -26919 -5973
--30734 -4546 -21223 -1991 -20707 1860 -26177 -741 -25771 992 -24210 985
--28585 1541 -21565 5468 -21610 2585 -27433 5243 -33841 10006 -11997 -5255
--26901 7677 -23242 17324 -21153 7389 -6256 -1112 -12349 -8601 -84720 53739
--43280 28261 -29756 -9233 -28244 5233 -18083 -9670 -21917 -6330 -30000 38000
--12669 17871 -4934 14604 9211 11889 -7608 7636 -4797 -1774 -23461 -4626
--21084 -11116 -39320 -1802 -46191 -1813 -47796 -367 -49012 3732 -49544 7097
--49600 8695 -49559 8829 -49471 8107 -49365 7119 -49353 6340 -49216 6023
--49253 6454 -49279 6928 -49267 7477 -49205 8061 -49122 8620 -48942 9105
--48669 9489 -48345 9759 -47993 9923 -47624 9992 -47236 9990 -46836 9933
--46417 9835 -45992 9714 -45558 9576 -45119 9430 -44671 9281 -44220 9131
--43765 8985 -43309 8841 -42848 8702 -42386 8564 -41925 8430 -41468 8299
--41009 8169 -40556 8041 -40109 7916 -39669 7790 -39239 7667 -38814 7543
--38401 7422 -38002 7302 -37610 7182 -37235 7065 -36871 6950 -36523 6836
--36192 6724 -35871 6614 -35565 6508 -35274 6405 -34999 6305 -34739 6207
--34495 6113 -34264 6026 -34048 5940 -33843 5857 -33652 5778 -33477 5704
--33312 5635 -33162 5569 -33021 5510 -32893 5454 -32774 5399 -32667 5346
--32569 5296 -32482 5250 -32405 5209
-51: 4540860 17658 -31283 3770 -31069 3734 -30802 3686 -30493 3629 -30155 3562
--29786 3490 -29391 3421 -28968 3342 -28524 3259 -28063 3184 -27583 3116
--27088 3035 -26586 2940 -26085 2852 -25576 2795 -25069 2746 -24581 2652
--24106 2501 -23656 2370 -23227 2341 -22830 2371 -22479 2303 -22176 2057
--21916 1750 -21714 1598 -21572 1686 -21493 1860 -21486 1861 -21544 1564
--21652 1101 -21879 764 -22141 780 -22295 1149 -23027 1648 -23512 1975
--23091 1960 -23764 1663 -25754 1357 -26447 1383 -25429 2010 -24490 3310
--25530 5096 -28250 6870 -30405 7872 -30235 7301 -26904 4772 -21457 610
--19003 -2201 -20905 -3721 -22906 -1166 -32577 5281 -33026 8303 -29759 9328
--27681 8006 -26262 6346 -35178 7070 -23393 12396 -14233 -8032 5676 14028
--17009 11167 -36195 -301 -31712 -10261 -51134 -33997 -40353 -232 -46026 -2519
--27961 -3400 -28174 518 -28349 190 -31137 4443 -36167 6270 -36751 6735
--42400 1410 -33078 -5891 -42439 -5049 -23049 6498 -33010 10189 -23106 19838
--25435 21358 -28923 25502 -12534 -3687 -15961 -11208 -35094 768 -32422 1942
--16735 2996 1313 -3531 -28740 -5302 -25469 7162 -16132 12553 -19803 11498
--17845 -224 -12543 1999 -33415 5189 -23560 3224 -18448 2671 -17467 -13537
--21253 15429 -27108 8507 -29638 6081 -15270 9358 -41431 13416 -26087 16836
-10572 24176 -9314 9815 -10471 2061 -20255 13695 -9418 17162 -33226 8898
--17703 8537 -15595 9935 -29794 14136 -26938 -25202 1784 -58715 -54840 14978
--44843 -12332 -37972 -20181 -31726 9274 -74624 18168 -29656 7073 -24929 2850
--24089 2942 -21587 1698 -20123 717 -17871 8111 -17453 16276 -30430 6807
--28770 2941 -19833 1900 -24553 7527 -27441 12042 -28978 6187 -25884 7675
--19266 13166 -44710 -8263 -30110 2187 -26954 5759 -26000 1000 -25000 -4000
--43990 -4035 -34832 -439 -36594 -6454 -17016 -2337 -27584 6863 -36231 14418
--21149 8303 -28786 9861 -36769 6082 -37978 9669 -24889 4800 -10532 1626
--16267 3241 -22369 6703 -26429 8025 -27431 -4603 -26197 -18698 -28448 -17449
--26539 -6928 -21744 1877 -22452 -8411 -26746 -7170 -20950 481 -25963 1647
--12898 12303 -20852 -614 -14934 -1922 -18438 -3839 -32292 7011 -20055 -3720
--28338 -1606 -27580 -915 -36820 -3600 -37209 -1016 -41745 -1306 -21947 -5017
--24785 -5111 -20574 -2078 -23374 -605 -25470 -811 -25461 -552 -22943 -2712
--27745 2996 -23278 3086 -23882 3007 -28068 4187 -29142 4280 -24896 5477
--25196 5229 -16193 10776 -22786 4033 -9214 10967 -16992 -11664 -76869 20150
--48082 46871 -28057 10643 -26566 -5605 -22904 -3708 -34530 20313 -10534 7606
--16813 2639 -17653 7755 23021 13084 -7088 14696 -9431 6655 -18120 -5781
--24363 2186 -40088 -2567 -46306 -3424 -47215 -2899 -48840 5042 -49310 9802
--48984 11359 -48501 10888 -48068 9419 -47980 7710 -47955 6425 -48189 5854
--48293 6216 -48398 6708 -48473 7325 -48577 7999 -48452 8647 -48232 9206
--47992 9636 -47719 9925 -47402 10083 -47051 10129 -46681 10094 -46300 10001
--45910 9872 -45513 9723 -45111 9563 -44705 9402 -44289 9241 -43869 9087
--43442 8940 -43015 8798 -42579 8663 -42141 8533 -41703 8406 -41263 8283
--40826 8163 -40389 8043 -39955 7926 -39532 7808 -39111 7690 -38698 7573
--38295 7456 -37904 7340 -37521 7223 -37152 7109 -36795 6995 -36453 6883
--36124 6771 -35810 6662 -35509 6554 -35222 6452 -34950 6350 -34693 6251
--34451 6158 -34224 6066 -34008 5979 -33807 5895 -33620 5814 -33444 5738
--33281 5667 -33131 5599 -32993 5539 -32867 5480 -32749 5424 -32642 5370
--32543 5317 -32458 5269 -32382 5228
-52: 4560495 1902 -31235 3700 -31014 3664 -30740 3617 -30424 3558 -30082 3492
--29706 3424 -29301 3353 -28873 3273 -28420 3195 -27951 3128 -27464 3058
--26962 2969 -26455 2879 -25943 2815 -25433 2769 -24919 2698 -24426 2572
--23947 2431 -23493 2360 -23067 2376 -22671 2363 -22322 2188 -22025 1876
--21779 1620 -21587 1601 -21463 1775 -21411 1891 -21436 1709 -21519 1221
--21699 679 -21934 413 -22217 585 -22657 1083 -23322 1588 -23485 1779 -23330 1527
--25213 974 -27022 468 -26635 416 -24886 1129 -24976 2735 -28171 5087 -32075 7652
--33049 9410 -38642 6038 -22291 8049 -17520 933 -18532 -2029 -24990 -4198
--30935 -3772 -30988 5675 -32185 7812 -31043 9469 -31153 7438 -24543 7668
--19423 2542 -28631 7880 -20730 -854 -22737 8255 -9223 17215 -31303 -13816
--44968 -21879 -35620 -6399 -29820 -28 -33893 -4873 -37279 -2127 -25838 2369
--29370 -613 -29324 5937 -33061 9588 -34903 6509 -31535 2425 -34276 -8216
--35289 -4686 -33489 18298 -25305 11253 -29917 20135 -29406 13234 -31409 13755
--11513 3139 -25199 -301 -28170 -3354 -27655 -17125 -21091 342 -7928 7774
--17469 -4317 -25390 11185 -22590 10295 -22214 5681 -19895 -594 -8054 6993
--29767 6798 -24250 -3505 -19431 1963 -17629 -5719 -12940 14756 -27590 10249
--29260 14553 -26418 8132 -24320 8688 -11247 16082 -8671 13588 -12948 13273
--11809 2929 -19996 21853 -26354 16735 -18023 3882 -22544 8824 -5185 16771
--14853 12991 -16947 -16797 -10827 -46954 -51050 -2963 -45283 -27067 -43453 -8122
--51998 4815 -53708 12652 -38269 7092 -31328 1238 -21321 -622 -26258 553
--23615 1432 -21476 3707 -23352 11425 -24631 13834 -29125 1534 -20947 -1843
--25607 12681 -29608 18097 -27624 6335 -26505 4154 -26956 2084 -38413 4089
--27737 10600 -21225 -2582 -29519 -3922 -30269 -3912 -37933 -5414 -36120 -3849
--33463 -3696 -27830 -4579 -33348 6634 -34626 9423 -22607 8366 -24536 11744
--32377 12972 -37085 8767 -26491 5543 -14877 2883 -10328 2165 -22115 7403
--22985 9630 -9493 -1159 -35010 -18994 -38507 -18927 -25000 -14000 -22289 5645
--24711 -5645 -23236 -6327 -26308 2043 -25917 6801 -19919 7325 -11717 2839
--12159 3018 -11744 -699 -30029 1755 -16452 -5837 -30142 -3642 -37057 -640
--35377 833 -31210 -2794 -45370 -6629 -30703 -2684 -22256 -3314 -21328 -3765
--21447 -1002 -23777 -1467 -22425 -1712 -23552 -3008 -24641 2976 -25621 3522
--26145 3043 -27510 2105 -26471 6056 -24943 4760 -23544 5444 -17931 -629
--27128 10493 -30289 13315 -39862 4877 -51166 28877 -34440 29115 -35562 6877
--25066 -7332 -19556 -2593 -17755 11484 -18660 5146 -17819 -1168 -3715 5406
--12450 13626 -14601 14506 7153 13456 -18456 6306 -41809 6957 -19694 -3517
--48194 -4202 -45549 -5727 -48204 7604 -49822 11359 -47640 13371 -46359 12163
--45668 9980 -45735 7530 -46394 5814 -47003 5126 -47340 5494 -47618 6126
--47889 6931 -47726 7789 -47666 8605 -47598 9292 -47407 9800 -47114 10115
--46770 10260 -46416 10270 -46062 10186 -45708 10047 -45354 9877 -44996 9695
--44636 9512 -44270 9334 -43893 9167 -43507 9009 -43114 8863 -42715 8727
--42309 8599 -41894 8478 -41478 8363 -41060 8250 -40640 8141 -40220 8032
--39802 7924 -39390 7815 -38982 7706 -38580 7595 -38186 7484 -37804 7373
--37428 7261 -37067 7149 -36714 7038 -36379 6926 -36055 6817 -35745 6707
--35449 6600 -35166 6496 -34897 6394 -34645 6295 -34406 6200 -34180 6106
--33967 6017 -33768 5932 -33583 5850 -33411 5772 -33249 5698 -33100 5629
--32963 5566 -32838 5506 -32723 5449 -32615 5393 -32518 5338 -32434 5289
--32359 5245
-53: 4580159 -13840 -31196 3623 -30970 3587 -30692 3540 -30372 3482 -30019 3417
--29639 3351 -29229 3278 -28795 3201 -28336 3131 -27863 3068 -27369 2991
--26862 2902 -26345 2831 -25830 2786 -25312 2732 -24795 2631 -24297 2499
--23816 2404 -23360 2392 -22930 2402 -22538 2301 -22191 2037 -21902 1732
--21664 1596 -21485 1705 -21376 1884 -21349 1846 -21397 1441 -21551 803
--21690 273 -22073 153 -22433 502 -22748 1084 -23715 1515 -23484 1486 -24172 938
--26539 89 -27837 -655 -26114 -856 -24090 -164 -25796 1622 -31654 4492
--37102 7992 -34790 10734 -34013 9139 -23429 9903 -16908 23 -19572 -715
--28824 -26 -30913 2737 -37268 -1931 -35240 2246 -28714 8534 -36835 1757
--23130 3172 -23362 2824 -25903 10442 -19331 -1063 -31676 1957 -20988 11592
--26132 -14002 -30447 -7542 -28313 -8658 -35065 1270 -31229 1856 -30849 -175
--30301 1702 -26841 -375 -30858 8743 -31004 9318 -31104 4198 -30158 5235
--30570 4281 -34497 1750 -33103 8521 -29770 8903 -29095 10426 -20000 6000
--14000 9000 -38832 6450 -27320 4855 -28041 -166 -28858 -10216 -23268 -4320
--6015 10038 -14893 12012 -22276 2039 -28500 6078 -21931 4009 -17828 3310
--14335 9040 -26940 10982 -26152 -519 -3760 751 -1598 4358 -34013 3850
--32952 8136 -31783 11393 -28108 2699 -25026 1714 -17498 9765 -7999 24436
--4889 15242 -24266 14519 -10687 12421 -23125 8601 -14067 6848 -20355 8595
--12293 12852 -4904 5622 -13467 -3390 -26193 -26871 -40572 -12991 -44648 -19542
--52322 -14209 -59282 -8134 -33004 8562 -43574 6929 -30832 -2691 -25999 1343
--28457 -2144 -24138 -256 -22448 1367 -33583 13361 -27004 11238 -22902 4402
--22461 -194 -26119 11209 -29389 20030 -26480 9090 -27718 4191 -24543 682
--24320 2235 -28031 10375 -30189 3419 -34752 949 -40394 -9103 -36986 -4863
--29583 -2988 -32281 -3891 -31764 -3527 -28266 3157 -28479 5095 -28780 9499
--23428 9670 -27376 13727 -30992 13526 -29768 7351 -17525 -4005 -11020 1382
--28459 2023 -13166 -754 -11105 1395 -45675 -6748 -33513 -17492 -17501 -12808
--22893 3750 -25609 -2215 -28664 -2462 -28414 3822 -30420 5105 -25115 7899
--18349 3622 2484 5224 -6419 5216 -32627 -1244 -21406 -5853 -24848 129
--34324 -1546 -34016 -3977 -32172 -4432 -40005 -9344 -34892 -5901 -26563 -2406
--23056 -4435 -21774 -4346 -19899 -2488 -21229 -1507 -24335 625 -23659 1087
--26519 5274 -26572 5670 -27705 4733 -23390 2353 -21993 197 -24968 4564
--7585 -25993 -42295 29478 -52203 12488 -33688 26706 -34121 21247 -26763 28999
--47765 -2205 -30229 -3834 -16828 -3384 -19172 3384 -14515 6724 -18516 1615
--9159 25324 -28855 14744 -5934 8855 4979 738 -19206 10687 -41794 18313
--20405 -4997 -37839 -897 -49024 -3711 -48020 5860 -47723 13317 -46714 12210
--43226 11834 -42197 9438 -43097 6279 -44813 4333 -46059 3771 -46752 4303
--47155 5228 -46917 6347 -47075 7489 -47171 8549 -47029 9418 -46731 10023
--46381 10358 -46035 10466 -45708 10410 -45395 10256 -45083 10053 -44774 9834
--44462 9617 -44146 9412 -43824 9224 -43488 9053 -43140 8898 -42782 8757
--42415 8630 -42036 8514 -41647 8405 -41254 8301 -40856 8204 -40453 8106
--40051 8011 -39648 7913 -39248 7815 -38851 7714 -38460 7612 -38075 7508
--37700 7403 -37333 7295 -36977 7187 -36632 7078 -36301 6968 -35982 6859
--35677 6752 -35384 6644 -35106 6540 -34842 6437 -34593 6337 -34356 6240
--34134 6147 -33925 6054 -33728 5969 -33544 5883 -33373 5804 -33214 5728
--33070 5659 -32932 5594 -32809 5531 -32695 5473 -32587 5415 -32494 5359
--32410 5307 -32333 5263
-54: 4599849 -29578 -31169 3539 -30941 3504 -30657 3456 -30332 3398 -29975 3336
--29592 3272 -29178 3198 -28737 3125 -28273 3065 -27798 3000 -27297 2917
--26785 2841 -26266 2793 -25745 2752 -25221 2677 -24701 2561 -24197 2456
--23712 2420 -23255 2433 -22824 2387 -22432 2193 -22089 1896 -21802 1682
--21574 1691 -21407 1862 -21314 1941 -21305 1682 -21410 1075 -21516 382
--21822 -31 -22264 51 -22270 554 -23321 1136 -24009 1398 -23595 1080 -25016 207
--27780 -936 -28041 -1925 -24944 -2330 -22695 -1811 -26007 -90 -35755 3074
--45385 7600 -34882 11611 -22924 8937 -23710 5698 -22628 2869 -23766 3133
--38410 1746 -34449 5956 -33403 -1207 -36647 -3770 -18622 11094 -36671 -6496
--31825 3729 -34781 11591 -18430 1639 -17742 -397 -26616 -2822 -30586 -7517
--26768 -2146 -21875 -1072 -27149 -31 -39211 1858 -29204 1500 -25798 755
--25588 4468 -28542 12811 -24138 2544 -30443 6856 -30690 8281 -30153 6408
--38622 -498 -30240 4160 -34109 6024 -28193 5456 -26983 5437 -21643 6462
--28475 12843 -31669 5845 -26413 6150 -23659 5744 -18895 -5626 -20142 -647
--10386 616 -16576 4239 -26914 4606 -29761 5971 -22773 9356 -13577 8195
--16870 4610 -22570 6402 -24285 7987 -11302 1188 -9733 1521 -26247 6864
--40759 8854 -24284 1594 -24153 6216 -30042 -300 -31125 7867 -21286 14128
-20854 15561 -27425 23754 -16486 9275 -17351 3391 -11092 7239 -17148 9284
--16328 9429 -9946 765 -12717 -95 -32369 -3217 -44077 -6653 -58794 -13521
--50572 -18588 -28896 -20224 -20890 5736 -15849 6542 -36345 -7906 -38108 6327
--41063 -7071 -36122 -7083 -31482 8503 -36612 14237 -29167 13203 -23439 3615
--25906 753 -24597 13535 -26790 19384 -26241 7778 -25924 1404 -27388 -595
--22243 2665 -25593 4505 -34495 5989 -32869 3150 -48268 -10325 -26239 -1320
--24917 -3658 -35079 -5579 -27922 1590 -25381 5452 -25282 4744 -24582 3595
--23324 7854 -28917 14922 -25935 18949 -32563 7809 -24473 -7494 -15575 -5171
--27958 -2158 -13705 -9450 -14107 -900 -21375 -3559 -40190 -12961 -32381 -5282
--23397 3153 -21197 2917 -33063 2306 -31276 5074 -38528 5198 -27814 9484
--10020 6027 -1395 3438 -4771 6051 -28205 835 -24977 -3498 -24491 -90 -32504 -4736
--29943 -5840 -30720 -7437 -42793 -6045 -33820 -7496 -33946 323 -17488 -12809
--16540 -10441 -21220 -7448 -19703 -45 -23760 3591 -28260 1326 -25720 7731
--25249 7411 -23108 3651 -21490 2524 -26128 2873 -25257 1625 -24169 -4075
--36389 5715 -36606 17090 -32323 32816 -32191 2449 -38668 14385 -45332 10615
--30000 2000 -25214 1573 -20786 -3573 -22292 9148 -13075 25702 -7610 17503
--37070 13327 -12297 -2757 -14167 38345 -3835 1646 -27630 10408 -26948 -6291
--34389 7024 -41654 4458 -50693 -1201 -50021 10891 -43438 9791 -39626 9455
--38027 7972 -40339 3907 -43756 2104 -45785 1961 -46583 2833 -46351 4175
--46482 5708 -46635 7192 -46497 8567 -46160 9660 -45819 10362 -45537 10678
--45291 10698 -45047 10532 -44789 10273 -44515 9988 -44234 9714 -43954 9467
--43674 9249 -43388 9061 -43089 8895 -42776 8752 -42454 8625 -42117 8512
--41767 8410 -41403 8318 -41032 8230 -40655 8147 -40270 8064 -39881 7982
--39493 7896 -39105 7811 -38720 7719 -38338 7626 -37961 7529 -37594 7430
--37233 7327 -36884 7223 -36544 7117 -36222 7009 -35906 6901 -35603 6794
--35316 6687 -35042 6583 -34784 6478 -34537 6378 -34304 6280 -34084 6184
--33880 6092 -33685 6003 -33505 5917 -33335 5835 -33179 5758 -33033 5687
--32901 5620 -32778 5556 -32666 5496 -32561 5436 -32466 5378 -32385 5325
--32309 5279
-55: 4619557 -45322 -31158 3447 -30924 3413 -30637 3365 -30310 3308 -29950 3249
--29564 3183 -29147 3112 -28702 3048 -28239 2992 -27758 2922 -27254 2843
--26737 2787 -26213 2756 -25691 2704 -25164 2610 -24637 2504 -24128 2451
--23641 2461 -23183 2450 -22749 2323 -22357 2071 -22013 1826 -21732 1750
--21513 1869 -21353 2003 -21274 1889 -21296 1402 -21392 679 -21586 58 -21989 -146
--22114 148 -22595 729 -24014 1203 -23925 1199 -23682 553 -26036 -621 -28841 -1997
--27878 -3165 -23366 -3761 -20454 -3519 -24584 -2169 -39073 850 -65392 5303
--31800 15250 -7978 6672 -24268 847 -35056 4325 -34294 6165 -44535 -1745
--38353 1980 -15377 13169 -37651 -8423 -26555 6496 -25072 435 -29986 5702
--45915 1186 -19922 223 -15355 5527 -26403 -3223 -30512 -9444 -30280 -6902
--16910 2317 -27466 7429 -28216 1862 -26450 3219 -27644 1852 -15068 4347
--31129 18914 -30117 10060 -31723 5324 -32993 4400 -41284 2276 -22425 -1481
--21289 5437 -40286 5044 -38623 9483 -28389 12789 -21243 4046 -22560 11671
--39385 4261 -24177 8881 -17740 1894 -13458 1632 -15085 3372 -12863 -3413
--23736 -799 -34974 6191 -25850 2570 -27076 1345 -14189 2630 -12456 5520
--17963 12332 -27606 9193 -22700 4784 -10726 -2647 -3201 9265 -55258 4959
--26175 9130 -33567 14911 -28252 -4325 -29189 4742 -8258 22497 20940 15865
--22089 9378 -16528 -6433 -23589 -720 -15035 10996 -12566 8036 -13928 7324
--15043 1535 -19832 6924 -34848 11547 -31327 -1557 -85260 -3931 -43835 -6267
--2087 -39237 -18010 -3478 -24723 4639 -34488 -977 -33672 -1151 -43734 -3694
--39388 20 -38281 6016 -33978 6251 -28817 10495 -28415 7184 -30865 4028
--26308 16271 -24924 12206 -23587 4798 -26948 2701 -29676 1627 -29372 457
--23827 9946 -27856 -140 -26862 1232 -35533 -1383 -29800 -4150 -24541 -6413
--30767 -4468 -37410 3334 -28800 13271 -18549 11037 -20116 -929 -41009 3348
--16882 22137 -28063 10631 -33424 4835 -32535 -5931 -21880 -14275 -29080 -10758
--3654 -13757 -15958 1723 -21331 -1722 -34963 -6065 -27154 -169 -29831 706
--22639 3324 -31315 2847 -29696 14171 -34758 7352 -23013 4050 -16685 6119
-1727 -723 -4192 2251 -29847 3802 -28735 -6057 -33980 4201 -33573 246 -28574 -6582
--29324 -13401 -31231 -10912 -31035 -3092 -35876 11219 -16319 -9727 -15869 -13393
--20905 -10900 -26077 -4903 -27709 -421 -26473 -1668 -22067 9208 -24682 7416
--20700 5863 -25617 4609 -30099 3294 -17000 -2000 -34409 -6121 -32938 11696
--51155 18909 -44815 29456 -26937 -967 -21014 5189 -25503 15874 -49562 -5299
--24869 10625 -23255 9407 -31068 21314 -15824 38298 -8046 8595 -31160 14359
--8308 -2445 -17137 21110 -19293 7720 -17288 513 -25492 6563 -31483 6305
--40803 8510 -48786 12044 -54690 3740 -39010 3171 -36733 5380 -33448 6580
--36631 1710 -45523 -1214 -46380 206 -46260 1418 -45915 3191 -45946 5193
--45707 7001 -45309 8762 -45024 10118 -44899 10873 -44808 11087 -44688 10934
--44519 10588 -44295 10183 -44038 9801 -43767 9475 -43500 9211 -43238 9000
--42977 8829 -42709 8688 -42428 8569 -42137 8467 -41829 8376 -41506 8294
--41167 8222 -40816 8153 -40455 8086 -40089 8019 -39715 7950 -39338 7879
--38963 7804 -38588 7724 -38213 7639 -37845 7550 -37484 7455 -37130 7359
--36788 7258 -36454 7155 -36134 7049 -35825 6943 -35527 6835 -35244 6729
--34975 6624 -34720 6519 -34476 6416 -34250 6317 -34032 6221 -33831 6127
--33639 6037 -33462 5949 -33296 5864 -33142 5787 -32998 5712 -32867 5646
--32745 5580 -32637 5517 -32534 5457 -32441 5397 -32357 5343 -32284 5293
-56: 4639272 -61084 -31156 3348 -30926 3313 -30633 3265 -30308 3211 -29945 3153
--29559 3088 -29140 3021 -28694 2965 -28228 2908 -27743 2837 -27239 2772
--26721 2737 -26189 2708 -25669 2640 -25139 2542 -24608 2474 -24095 2476
--23610 2495 -23142 2425 -22709 2229 -22312 1988 -21970 1861 -21694 1922
--21473 2065 -21331 2059 -21256 1714 -21300 1062 -21414 358 -21700 -65
--21997 -13 -22159 439 -23272 979 -24266 1216 -23572 871 -24057 -96 -27338 -1489
--29849 -2960 -27737 -4154 -22263 -4800 -18620 -4746 -21759 -3892 -37930 -2233
--84707 5253 -31224 21574 10381 3564 -32991 -6019 -46381 8646 -35601 11631
--43438 -4633 -22953 9541 -22896 14808 -28245 -9020 -32092 2408 -25731 2858
--31672 9780 -47254 -4550 -46919 -7725 -12452 -5293 -12993 -7462 -28382 -16970
--28581 3017 -23621 12706 -14233 14548 -26292 6127 -29408 4225 -31942 3139
--29965 7848 -27687 11919 -21856 9649 -31750 9063 -31665 2759 -34690 -2507
--25310 7507 -20493 8741 -33980 5872 -34506 7121 -26021 10266 -34185 3732
--18653 6989 -29116 11042 -23455 13369 -19360 299 -12140 -3349 -12312 -4278
--19797 2550 -28713 2967 -29335 7267 -26279 5695 -28374 6021 -23141 -8827
--7650 13319 -16527 11930 -27689 10446 -30737 8627 -10370 5433 -11179 5465
--49144 1376 -31075 6381 -35062 2854 -25167 -956 -27527 1015 12266 27891
-19295 13746 -24541 11053 -25860 -3305 -25069 -1779 -12555 -1287 -17647 3412
--14243 4767 -16256 3106 -24061 3562 -28065 -661 -17944 3936 -87222 10408
--50572 10202 -1548 -35152 -15234 -20245 -30871 2952 -34855 3697 -41713 -7924
--43932 2779 -33908 2669 -30025 2930 -35036 4834 -29801 11269 -28183 12535
--33486 8027 -24572 9510 -27217 9758 -32004 4133 -31374 1945 -31966 2557
--26205 2961 -28203 4601 -20889 80 -22758 372 -32685 193 -22586 -5069 -22883 -4977
--24629 1962 -40723 13321 -36743 14506 -17307 5853 -27796 5096 -33298 9026
--16931 10702 -30987 7116 -43111 -3234 -32216 -11365 -1658 -14808 -28451 -20029
--7785 -9819 -26438 6172 -25523 2061 -30141 -577 -31935 -3407 -30491 3221
--25692 -488 -23861 5627 -28609 16003 -30280 13208 -20259 6575 -17309 5265
--1226 -962 -5476 -4370 -28052 1183 -29186 -10051 -42550 826 -31942 5534
--27497 -5164 -17037 -12117 -31334 -11342 -25379 -3855 -29630 11858 -20502 -242
--20577 -11296 -23697 -11281 -33607 -6009 -33735 -1319 -24179 1083 -21140 9603
--26639 -985 -25047 3066 -20793 -1333 -29888 3242 -20319 -2909 -35094 -2628
--55847 9207 -43401 24508 -37663 14377 -29999 824 -35996 -1288 -21226 15783
--22251 8617 -22298 10000 -24421 20910 -41630 23315 -11524 22107 -12498 22286
--32766 31819 -13840 -10890 -10730 2744 -24232 11311 -23892 6637 -14692 8361
--34608 3725 -42060 9731 -42306 18198 -52974 5569 -37078 -77 -37974 1854
--31026 3790 -34713 1532 -44264 -25 -49027 -1811 -45503 310 -44924 2406
--44650 4995 -44202 6952 -44043 9263 -44178 10912 -44331 11603 -44271 11565
--44114 11110 -43944 10499 -43755 9905 -43539 9419 -43302 9058 -43060 8806
--42824 8633 -42589 8511 -42351 8419 -42099 8345 -41836 8281 -41555 8223
--41256 8171 -40938 8122 -40608 8073 -40264 8026 -39911 7974 -39551 7922
--39186 7863 -38819 7800 -38453 7730 -38088 7653 -37726 7571 -37371 7483
--37024 7391 -36688 7292 -36359 7192 -36041 7089 -35739 6983 -35446 6876
--35168 6770 -34903 6664 -34651 6557 -34413 6454 -34188 6353 -33978 6255
--33778 6161 -33592 6068 -33416 5978 -33255 5893 -33102 5812 -32963 5737
--32832 5669 -32711 5602 -32606 5539 -32505 5476 -32413 5414 -32332 5358
--32256 5308
-57: 4658992 -76876 -31173 3240 -30941 3204 -30654 3158 -30324 3105 -29964 3049
--29575 2984 -29157 2924 -28710 2873 -28244 2814 -27761 2748 -27254 2701
--26733 2681 -26206 2645 -25679 2566 -25149 2486 -24614 2473 -24099 2508
--23609 2498 -23140 2362 -22702 2143 -22304 1986 -21962 2003 -21680 2144
--21471 2212 -21320 1997 -21278 1453 -21307 759 -21501 220 -21767 81 -22010 371
--22528 867 -23774 1215 -24055 1095 -23465 369 -24999 -867 -28774 -2338
--30758 -3719 -28088 -4738 -22915 -5202 -20454 -4980 -25184 -4073 -38723 -2441
--61154 8402 -34220 15152 -9063 10388 -49380 -7587 -32247 22228 -31921 49
--34123 -1631 -23252 -2727 -34984 -522 -34714 -519 -30338 6540 -23139 7233
--30941 -1851 -21511 3145 -39329 3796 -28852 -12150 -25742 -10066 -34366 -7859
--22645 2585 -26815 10592 -21863 17160 -21631 9607 -27450 5859 -27562 5836
--34023 3033 -30067 3229 -23206 12623 -31574 5608 -32009 2467 -29348 6350
--32561 8130 -26966 8745 -30405 8644 -30178 1461 -21286 4892 -27011 3175
--26313 8612 -18468 14236 -20037 13641 -8543 -2873 -18072 -5655 -20665 4050
--30013 4272 -22472 221 -30770 4233 -31882 7962 -25051 8352 -25545 6689
--169 15992 -18032 5326 -32317 8518 -32918 7663 -13132 7867 -11854 10140
--48858 7037 -22215 -1939 -17050 -2586 -15988 6347 -6663 11913 -5014 11599
--5070 4666 -29060 7526 -31253 -2004 -25184 -9799 -13353 -5189 -18330 4333
--17462 8208 -17451 7942 -22837 943 -21594 -3886 -20835 -3713 -62378 7811
--58612 12879 -6348 -38388 -13098 -12021 -38484 1081 -44163 1489 -31256 -4984
--51536 -8686 -45010 8530 -23830 996 -32440 10769 -36296 23911 -19915 14153
--25729 7738 -24624 10120 -34025 6395 -28145 5196 -43783 -786 -33904 435
--17904 464 -20321 2609 -30532 932 -15718 6412 -29539 3524 -23851 -3402
--25146 -16305 -16229 22034 -38996 15930 -34010 8770 -25950 982 -32006 3034
--27660 7279 -19241 12010 -31836 12937 -41680 -11217 -18281 -11271 -14368 -24369
--29760 -16689 -7803 -9167 -33234 10504 -28112 6361 -30163 2932 -33231 1676
--35771 -1406 -22957 3302 -17838 9267 -24931 8731 -27291 8548 -22357 11252
--18866 10096 -6726 -2367 -9321 -8037 -24948 -870 -32486 -3466 -37002 -8019
--30012 6532 -20123 -3068 -15663 -12401 -31020 -10748 -22300 -8728 -27294 8119
--20809 9188 -28317 -9471 -31776 -9974 -35618 -5796 -37115 -3294 -20414 -3060
--23247 1145 -24771 -2215 -23341 2002 -29143 1501 -31949 4524 -25913 -832
--29175 -1424 -50349 16181 -44185 18888 -31516 8313 -40683 3205 -31252 -6220
--34026 5347 -29184 9786 -8437 30760 -23721 29789 -23667 31140 -24007 24218
--36973 27593 -19747 -6218 -16750 -4001 -26503 20219 -16355 7311 -27471 -7021
--10433 3323 -23941 17684 -31433 5372 -57399 27948 -41968 3383 -31000 -3000
--32902 2674 -36098 3326 -36445 -352 -45499 -179 -47412 -2033 -43847 -1353
--42899 1632 -42986 5341 -42830 6940 -43508 10295 -44227 12199 -44317 12547
--43670 12025 -43100 11110 -42865 10142 -42816 9329 -42781 8750 -42693 8394
--42555 8201 -42388 8114 -42204 8083 -42004 8074 -41785 8070 -41551 8065
--41295 8053 -41020 8039 -40721 8018 -40407 7996 -40080 7967 -39741 7936
--39391 7896 -39035 7852 -38676 7799 -38318 7739 -37959 7670 -37604 7595
--37255 7512 -36914 7424 -36581 7329 -36258 7230 -35946 7127 -35648 7022
--35360 6916 -35086 6809 -34825 6702 -34578 6595 -34346 6489 -34123 6387
--33917 6287 -33722 6191 -33541 6097 -33370 6006 -33210 5919 -33061 5836
--32926 5760 -32797 5690 -32679 5623 -32572 5557 -32474 5493 -32386 5430
--32304 5372 -32231 5320
-58: 4678705 -92674 -31195 3108 -30973 3078 -30690 3038 -30365 2990 -30009 2936
--29618 2878 -29200 2821 -28756 2768 -28294 2711 -27805 2655 -27303 2613
--26785 2586 -26259 2548 -25730 2494 -25188 2449 -24673 2446 -24144 2465
--23623 2442 -23223 2337 -22734 2196 -22241 2112 -22015 2138 -21891 2213
--21447 2184 -21060 1926 -21275 1442 -21737 893 -21835 503 -21588 420 -21652 615
--22565 880 -24198 931 -25261 544 -25543 -338 -26494 -1577 -28351 -2902
--29238 -4027 -27754 -4765 -25136 -5028 -24561 -4624 -29662 -3710 -33869 -4213
--47151 10854 -35614 9644 -5423 22082 -58452 -16517 -43125 -4565 -35205 4266
--38105 1754 -26405 495 -25285 -1515 -31000 4000 -26900 7620 -43100 -6620
--17047 13759 -25820 1548 -33763 -1134 -25877 -7710 -38148 -5974 -23376 -3513
--24969 9024 -31349 7656 -34964 15744 -24420 14933 -21613 7538 -16782 10475
--29776 3792 -28366 4887 -25246 4773 -31167 7850 -32118 9955 -32648 7811
--36537 9509 -31123 -1232 -25891 4309 -27725 4351 -30275 -3351 -12952 121
--24473 3724 -14235 11839 -18449 18048 -7891 268 -18059 3367 -22780 3152
--19402 935 -759 -17454 -56153 26313 -36578 10974 -28550 6656 -28258 8671
--10152 13513 -18333 8127 -28316 8262 -31188 6983 -21028 6539 -17484 11613
--20511 3618 -24224 2533 -12058 -1365 -12687 8699 -8669 7293 -12784 8055
--17206 1843 -25018 2322 -25095 -4484 -21553 -9932 -22167 -6977 -26099 5601
--20179 15865 -18994 13588 -26951 -890 -16543 -9047 -22352 -8478 -43025 2455
--56514 932 -11084 -18480 -14408 -16784 -39209 5444 -46630 1398 -44566 -3716
--43536 -10945 -41669 -136 -22305 6999 -42820 12815 -34366 21025 -12738 13098
--21292 8354 -32424 5560 -28266 -987 -41311 -19 -40276 4543 -34990 5302
--13606 5461 -21967 7166 -16997 6275 -12707 11666 -34752 8197 -22312 2481
--12136 944 -26250 4877 -37714 16180 -28870 8369 -26013 2686 -38977 -231
--31355 5550 -22357 7282 -25150 11626 -34661 -3951 -27575 -20139 -11714 -29802
--5291 -13217 -40814 123 -35956 9285 -31273 7493 -30659 2077 -33701 1256
--28800 3178 -19802 5870 -19463 3731 -18442 6654 -17359 3359 -34942 11559
--28543 5923 -13793 -631 -10245 -4110 -22118 -4240 -29343 -4492 -33379 -2792
--26134 -4276 -23193 -3997 -20905 -5966 -19587 -5382 -21586 -3795 -27022 -2250
--21572 759 -35496 -1722 -38078 -4591 -37349 -5882 -20592 -13791 -21602 -836
--29951 -2384 -26408 -4506 -26930 3203 -31790 2446 -30679 4699 -31032 6347
--34771 5617 -29202 10278 -21262 9848 -38264 10765 -43463 3030 -39713 3921
--41617 6614 -28958 19936 -46292 27951 -86163 21846 55949 31354 -18297 32698
--33164 5107 -29616 1737 -31688 19915 -9088 28244 -12890 -13353 -7509 12715
--19989 4175 -42095 17692 -36407 4418 -32974 7101 -43704 15186 -42657 5576
--31374 -12762 -24157 -4664 -45370 4855 -43990 -2787 -47275 -6144 -36868 -1724
--41135 459 -41798 6571 -42435 7476 -46505 11360 -46246 14125 -45304 13606
--42693 12387 -40877 10858 -40345 9423 -40574 8355 -41032 7701 -41419 7392
--41653 7311 -41743 7358 -41723 7463 -41627 7583 -41472 7688 -41280 7774
--41053 7833 -40799 7870 -40520 7889 -40219 7897 -39904 7892 -39576 7882
--39235 7860 -38887 7833 -38535 7795 -38181 7746 -37829 7688 -37478 7620
--37134 7542 -36798 7459 -36470 7365 -36150 7269 -35843 7167 -35550 7062
--35268 6955 -34999 6848 -34741 6739 -34500 6631 -34272 6523 -34054 6420
--33855 6318 -33664 6220 -33487 6125 -33319 6032 -33164 5943 -33020 5861
--32884 5782 -32760 5710 -32644 5640 -32540 5574 -32445 5507 -32356 5444
--32276 5385 -32201 5333
-59: 4698404 -108497 -31233 2963 -31023 2940 -30747 2906 -30429 2865 -30075 2816
--29686 2762 -29274 2707 -28835 2653 -28372 2598 -27887 2547 -27387 2506
--26875 2475 -26350 2444 -25815 2412 -25281 2394 -24754 2399 -24244 2413
--23693 2401 -23323 2348 -22788 2279 -22271 2243 -22191 2257 -21995 2271
--21307 2193 -20985 1957 -21569 1580 -22182 1176 -21925 880 -21263 768
--21397 794 -22875 792 -25104 562 -26675 -40 -27011 -1017 -27020 -2204
--27534 -3323 -28235 -4101 -28364 -4483 -27903 -4782 -27967 -5289 -30948 -4581
--36933 2339 -39843 1423 -40821 7242 -29933 3265 -39129 -9901 -41687 -4274
--40722 2830 -37544 -908 -26076 1081 -29287 2324 -22961 4101 -25225 7851
--32224 -1329 -27889 4791 -22593 6997 -24666 7502 -20337 -3959 -39513 -2732
--33793 -893 -31006 4272 -30076 16911 -34551 13932 -26498 12165 -16563 10728
--20961 6867 -27965 3681 -26160 3423 -23697 7322 -28553 10124 -34473 13094
--41083 10184 -36325 6303 -30084 4367 -20292 1554 -30355 -9765 -14944 -2788
--12079 4541 -26396 1478 -20762 6952 -16605 12375 -13848 4860 -18149 4769
--25405 5393 -17588 5305 -13806 -4829 -43628 18828 -31977 10105 -26877 5136
--28650 7443 -20020 9507 -20832 7764 -23932 6844 -27258 5074 -21640 8086
--20322 9394 -22076 3867 -22279 596 -215 2449 -16506 13955 -16664 7006
--18307 4852 -17129 -4741 -21670 -419 -18915 -919 -17144 -4152 -31028 881
--27146 4491 -22618 6765 -21670 3867 -26316 4194 -16272 -3052 -21694 -5507
--33381 -3491 -42695 -4663 -17440 -2332 -20219 -18300 -43322 -1381 -47480 -2690
--46264 -4186 -39396 -3571 -44332 -3508 -25432 14183 -47997 6380 -24691 12874
--26280 7070 -18528 5963 -26279 1013 -29901 -2190 -39364 10527 -31437 7145
--31253 9010 -21101 5182 -24140 10247 -16117 11781 -14126 11736 -22743 9224
--25999 11413 -9991 12856 -24569 6353 -33770 12013 -33379 5373 -32825 4345
--35637 -1231 -26032 6755 -19039 7143 -38071 -6144 -28434 -1508 -20092 -20377
--29934 -4239 -18840 -6417 -30970 -5091 -40544 -3562 -28463 2900 -34842 271
--27711 -4916 -24655 4193 -14323 8647 -17171 6290 -25153 5356 -27578 721
--30002 5725 -23975 3846 -18758 988 -16484 -5482 -22671 -6348 -25594 -3439
--31246 -1850 -26827 -5916 -24565 -7503 -21552 -2319 -23647 -4813 -22837 -3446
--18995 -2603 -24764 688 -36078 2676 -36927 5213 -32298 672 -17929 -14323
--16888 -14176 -25034 -4785 -32434 -10292 -34231 -945 -30663 5344 -28995 5607
--32700 8307 -46393 6741 -5936 12748 -47688 18317 -35499 -1960 -33724 -1940
--31153 11835 -36963 49541 -42192 27080 -44202 6327 -59656 26030 333 22894
--7172 6414 -27852 10148 -35574 11939 -52707 26464 1369 21747 -10648 1870
-2124 3441 -3641 2528 -49605 13867 -37934 4901 -26680 4809 -42238 20427
--45236 9170 -38707 -2928 -40819 -7669 -25614 -6013 -38386 -8987 -41518 -11355
--34238 -524 -43933 -1612 -39543 5496 -45142 10084 -47038 17119 -50316 15264
--47158 14004 -41203 12189 -37840 10016 -37174 8100 -37882 6830 -38963 6203
--39924 6045 -40604 6164 -41011 6420 -41197 6716 -41234 7000 -41163 7240
--41024 7430 -40828 7569 -40595 7667 -40332 7735 -40043 7779 -39738 7808
--39418 7824 -39083 7826 -38740 7816 -38393 7793 -38043 7759 -37693 7709
--37347 7647 -37007 7574 -36675 7493 -36350 7404 -36037 7307 -35734 7205
--35444 7101 -35169 6993 -34905 6884 -34652 6774 -34416 6665 -34195 6556
--33981 6451 -33787 6347 -33603 6247 -33428 6150 -33267 6056 -33116 5967
--32975 5882 -32841 5803 -32720 5728 -32610 5657 -32507 5587 -32415 5521
--32327 5457 -32246 5396 -32172 5344
-60: 4718083 -124363 -31296 2810 -31089 2793 -30826 2766 -30513 2730 -30165 2686
--29783 2636 -29376 2582 -28941 2528 -28483 2473 -28007 2425 -27510 2384
--27003 2355 -26476 2333 -25952 2321 -25395 2324 -24919 2343 -24329 2370
--23881 2385 -23405 2380 -22882 2368 -22481 2368 -22321 2377 -21931 2364
--21292 2277 -21287 2082 -21994 1801 -22311 1502 -21679 1259 -21008 1103
--21582 978 -23629 760 -26079 306 -27412 -478 -27177 -1560 -26460 -2749
--26679 -3701 -28301 -4031 -30552 -3625 -32006 -3320 -33990 -5541 -28693 -7741
--38447 6284 -42669 -245 -49872 901 -27369 -4700 -40631 -19300 -37007 -1364
--29993 -6636 -34065 -306 -29237 7502 -30016 4125 -25006 3328 -28712 9559
--25288 3664 -27510 4816 -29345 3554 -22658 14879 -28457 5537 -29756 -107
--32124 3654 -34826 6795 -27492 12567 -29179 10119 -27395 14275 -21642 12367
--27920 4685 -24884 6761 -16488 8226 -27908 4333 -30444 4374 -33558 13312
--50461 8971 -33622 4923 -19830 4712 -18807 2151 -24272 -7478 -5518 -5636
--31752 25926 -20542 -22213 -19094 3152 -13303 16089 -31296 6423 -14094 1275
--19411 3586 -11196 3143 -27032 3883 -34040 8455 -47931 17383 -14308 5959
--28571 7786 -25604 6139 -22969 7073 -20045 6308 -22392 5971 -24000 5000
--25686 4352 -26955 6730 -18371 4473 18845 -6709 -17833 8154 -23000 13000
--21000 3000 -22574 3035 -24167 3480 -21406 3158 -20364 3677 -33209 2351
--18938 4794 -19812 -1247 -25280 909 -29581 3161 -15631 172 -23605 -3290
--27813 -3625 -30936 -8673 -21568 -640 -33060 -7971 -45377 -4307 -39589 -8781
--47155 -3579 -35588 860 -39482 2479 -38597 4319 -38610 2746 -29345 5808
--32918 4831 -32986 2932 -23106 2940 -28678 6922 -22534 8527 -29142 5909
--24106 6880 -18657 10099 -29947 8346 -17452 12335 -12936 13795 -13851 12648
--24704 6582 -18882 20861 -22954 13498 -31504 14047 -38726 3462 -40128 3445
--39297 -260 -27488 579 -23374 3858 -41217 -5647 -19127 -6009 -27413 -8752
--27970 -6246 -36122 -5415 -26094 -5003 -24644 -4766 -25705 -2218 -29323 1512
--21662 -1561 -27922 3432 -21877 8597 -16460 5716 -25404 3198 -31003 -4910
--29868 5440 -23976 6155 -16283 -8933 -21673 1884 -26560 -4256 -29234 -4461
--26566 -2735 -30107 -4527 -26259 -7330 -19989 -800 -28606 -5108 -20212 -3050
--14384 -5739 -22283 2460 -34554 1772 -28615 6219 -25207 8143 -21946 -1203
--17616 -11146 -33587 -10391 -36475 -17394 -23699 -5613 -29300 2739 -29802 2939
--41359 9157 -34337 7857 -43022 10925 -48831 26417 -51472 2753 -9504 -12056
--24136 -4380 -46538 114262 -38152 -9723 -39766 -5205 -23082 13928 -14012 28524
--35988 13476 -70000 15000 18418 44115 -27905 7136 -13788 1069 -13725 20680
--14371 -7460 -13699 -3226 -40308 16975 -36113 35771 -12694 -12286 -33708 8754
--50107 12472 -37000 -10000 -35479 -2437 -34521 -6563 -44000 -10000 -32966 -12732
--32034 3732 -46239 7692 -29088 2691 -54985 14377 -44009 15185 -50425 15033
--49457 12852 -40398 10457 -34419 8324 -34205 5958 -35568 4657 -37231 4251
--38659 4406 -39696 4843 -40361 5383 -40726 5913 -40879 6379 -40884 6760
--40791 7056 -40625 7278 -40411 7443 -40159 7567 -39879 7659 -39580 7727
--39263 7773 -38933 7801 -38593 7810 -38250 7801 -37901 7775 -37553 7732
--37209 7676 -36875 7607 -36545 7527 -36224 7439 -35914 7344 -35618 7242
--35332 7138 -35060 7029 -34802 6918 -34556 6808 -34326 6696 -34110 6587
--33905 6479 -33713 6373 -33536 6272 -33367 6173 -33211 6078 -33065 5987
--32927 5901 -32799 5820 -32682 5745 -32574 5672 -32474 5601 -32383 5532
--32298 5467 -32218 5406 -32140 5354
-61: 4737748 -140286 -31384 2652 -31180 2640 -30926 2618 -30623 2586 -30280 2547
--29906 2498 -29507 2446 -29082 2390 -28631 2337 -28159 2290 -27671 2251
--27164 2228 -26651 2216 -26114 2223 -25607 2247 -25033 2289 -24600 2339
--23989 2388 -23551 2430 -23144 2463 -22677 2494 -22340 2512 -21938 2499
--21592 2421 -21781 2271 -22203 2063 -22033 1835 -21308 1627 -21099 1440
--22321 1221 -24654 868 -26688 263 -27146 -665 -26092 -1892 -25009 -3220
--25725 -4221 -29165 -4189 -34310 -2367 -41173 650 -37987 530 -36113 -4086
--38197 -274 -42507 -7417 -71259 -13517 -18188 -8546 -31287 -8119 -33137 -3260
--27469 -7150 -25093 -2157 -28424 -1014 -35266 4168 -24247 2120 -32219 12008
--21498 5309 -27135 8674 -35846 8224 -26442 9723 -17976 8519 -25667 9548
--34189 10393 -29011 5910 -28768 7957 -29641 12008 -26864 13592 -24628 11362
--26957 6813 -27087 -4465 -23961 -4908 -27810 6236 -21436 20764 -43937 5726
--55371 9693 -29127 8694 6387 1639 -28052 6334 -32883 -2433 7473 -9696
--20313 9084 -39454 -8606 -24137 8469 -16729 5880 -18791 4339 -17505 4845
--20870 4401 -13426 9175 -27625 11010 -49499 10044 -28375 231 -17258 12649
--26671 3602 -28720 4700 -23237 10845 -16845 5506 -19806 4019 -23305 6000
--31356 4111 -24876 4218 -18689 4378 1185 -536 -9032 2750 -17988 8478 -16850 6652
--21597 6056 -29098 5893 -25353 3596 -23927 2546 -26379 -782 -15965 6508
--16766 3982 -26312 -310 -24904 3963 -32902 2020 -29607 1880 -25211 -7528
--23887 -7286 -29233 -466 -36007 -161 -32716 -6928 -41514 -5950 -41577 685
--36040 1206 -37783 1038 -38119 282 -38404 11208 -29959 -5867 -32508 1020
--31597 613 -20226 4192 -29960 8908 -29416 5375 -25034 6905 -20949 7682
--19409 9375 -24206 7253 -23485 11961 -21251 9583 -10837 10409 -24912 7900
--21891 41358 -21269 36011 -27763 3803 -44222 -5028 -47507 -2047 -44567 -725
--27848 35 -25209 -5617 -28227 -10057 -24883 -2044 -26481 -10304 -34087 -6519
--32756 -6903 -24725 -7324 -22467 -6381 -23811 -2120 -23526 7787 -20165 2641
--27847 4125 -24541 3315 -19246 3082 -23406 2217 -25807 3386 -30889 -2922
--26806 4003 -24984 -3505 -22850 -564 -25624 -3291 -26483 -5814 -25281 -8035
--25931 -1120 -36947 -4011 -26570 -2301 -28576 -6653 -15201 1679 -19175 1176
--13152 2172 -31616 -4199 -26527 -2540 -18405 4247 -16327 9407 -28447 -1
--33689 -8771 -24115 -23909 -23019 -18346 -29867 13856 -38781 5385 -38226 -1932
--35964 18674 -31987 22374 -50946 19420 -56380 15752 -38782 19288 -45323 3514
--37148 46454 -16982 17513 -17557 -16661 -23138 11343 -32809 23951 -38496 22367
--34297 27486 -20703 10514 -16000 11000 -11068 -796 -16998 6896 -21263 -4223
--57495 -1825 -35176 46948 -12419 5636 5160 10527 -18886 8432 -49987 6805
--42868 -400 -33342 -4343 -41342 -1613 -40986 2600 -31831 -7022 -38080 -2549
--63893 39323 -2128 -25174 -44379 4573 -47415 17246 -53136 14026 -55750 10940
--33758 10104 -34744 5326 -32892 2867 -34565 1905 -36409 2008 -37987 2652
--39161 3499 -39938 4359 -40394 5130 -40612 5772 -40662 6283 -40597 6680
--40450 6987 -40245 7226 -40000 7410 -39724 7554 -39430 7661 -39114 7739
--38782 7788 -38444 7812 -38100 7812 -37753 7794 -37408 7756 -37066 7704
--36732 7638 -36405 7561 -36088 7474 -35784 7378 -35490 7278 -35212 7172
--34944 7063 -34692 6951 -34453 6839 -34229 6725 -34019 6614 -33820 6505
--33637 6398 -33463 6294 -33302 6193 -33152 6097 -33011 6004 -32878 5917
--32755 5835 -32640 5758 -32536 5684 -32440 5613 -32351 5543 -32270 5475
--32189 5414 -32111 5361
-62: 4757399 -156279 -31497 2491 -31298 2481 -31047 2463 -30755 2435 -30424 2398
--30059 2350 -29670 2298 -29254 2242 -28810 2189 -28350 2144 -27870 2109
--27375 2092 -26856 2096 -26357 2121 -25779 2170 -25339 2238 -24759 2321
--24222 2409 -23829 2493 -23353 2569 -22844 2630 -22461 2669 -22170 2666
--22051 2609 -22138 2494 -22070 2335 -21583 2158 -21168 1979 -21700 1794
--23489 1547 -25634 1153 -26729 498 -26067 -509 -24264 -1890 -23020 -3527
--24394 -5028 -29945 -5444 -42085 -2847 -39943 4324 -44473 2137 -47712 604
--40076 -4333 -37355 -2944 -37340 -16711 -36900 -13735 -47374 -9511 -34490 -5637
--35021 -9311 -31726 918 -16009 -3671 -29624 6663 -27714 -2184 -20759 8463
--25404 5833 -36966 8935 -27814 7418 -18689 10134 -18250 12047 -32619 15999
--26157 9868 -26404 7025 -31359 8615 -33222 15105 -22844 10394 -22299 9085
--28287 3842 -32094 -4133 -14810 -1993 -36248 -2168 -17029 6112 -39485 5442
--47176 5737 -42710 9250 -13931 6707 -31288 9400 -24088 -1718 -12717 15607
--13246 -4777 -29381 -6271 -17276 8951 -13294 8629 -16066 5515 -19362 3308
--26006 -376 -28768 14755 -28623 12496 -29281 9048 -21380 5288 -21595 4702
--23811 -1332 -29582 4342 -25459 8324 -12475 5969 -26096 527 -19369 9062
--20345 2850 -24863 -742 -21181 6471 -18532 8293 -5840 -58 -16616 6937
--10489 11462 -19857 12796 -34093 2086 -26977 1657 -25455 548 -22555 1340
--21206 2907 -20072 1745 -21862 359 -24832 -4773 -38710 8486 -32654 6541
--23321 -5022 -33411 -1941 -30635 1782 -29959 -5272 -29425 -2999 -35692 -2563
--37382 -1482 -36610 3393 -33872 1736 -32762 3571 -31260 5637 -29423 -208
--25793 715 -23433 -343 -19818 2517 -38273 10682 -32334 -2307 -29968 -1576
--27132 2173 -22871 10251 -17695 16459 -25518 10583 -19835 12187 -24654 11702
--28560 8181 -26126 63341 -21132 60451 -25146 -11847 -46118 -12524 -47496 -6918
--41646 -7460 -33599 -10670 -22255 -12332 -24397 -5824 -28367 -4699 -26094 -5662
--32374 -3695 -30338 -6897 -17561 -2266 -26325 -6080 -22797 -4973 -16147 292
--19687 3637 -25253 3617 -28955 3223 -22646 3854 -25323 385 -26111 -433
--28576 2132 -30437 1145 -28432 -1577 -26418 -279 -22734 -2393 -23445 -5466
--18511 -9041 -27434 -7305 -21660 -1947 -41602 -5195 -30776 -3374 -18416 388
--24217 10496 -23517 1861 -21616 -7611 -22773 -5996 -15776 -2181 -5439 12111
--23510 5697 -28243 -12277 -22121 -26955 -35980 4481 -32840 10951 -36314 7762
--48947 7786 -45112 13235 -45374 20351 -33664 20158 -35940 20812 -51705 19416
--41011 10642 -23849 17196 -35420 23601 -27461 20823 -34265 13845 -20648 6341
--27399 23127 -33712 3709 -14857 2571 -17838 12575 -28669 7887 -29005 308
--32705 -4878 -44215 -7111 -36586 33842 -8098 22233 -8273 10931 -15000 18000
--30781 645 -31219 -611 -38341 908 -33659 58 -37270 6324 -27100 2839 -40879 1250
--49695 5387 -31056 5200 -33999 6829 -35135 12414 -43488 14718 -56569 14245
--41132 5855 -34608 664 -38453 -583 -35392 -965 -36725 -101 -38040 1096
--39081 2339 -39805 3479 -40239 4448 -40457 5231 -40512 5854 -40448 6345
--40300 6734 -40098 7043 -39858 7287 -39581 7476 -39281 7617 -38960 7717
--38630 7781 -38292 7816 -37947 7824 -37600 7812 -37255 7780 -36911 7732
--36578 7669 -36254 7594 -35940 7509 -35641 7414 -35353 7313 -35080 7206
--34819 7096 -34573 6981 -34341 6868 -34126 6752 -33921 6639 -33731 6528
--33553 6419 -33388 6313 -33232 6210 -33090 6113 -32953 6018 -32826 5930
--32709 5847 -32599 5769 -32497 5694 -32405 5621 -32319 5550 -32241 5483
--32162 5420 -32085 5366
-63: 4777029 -172349 -31633 2325 -31439 2319 -31196 2302 -30911 2276 -30591 2240
--30241 2192 -29863 2139 -29459 2084 -29030 2030 -28573 1986 -28106 1959
--27623 1951 -27119 1971 -26600 2017 -26097 2094 -25558 2195 -25060 2315
--24559 2444 -24044 2571 -23620 2689 -23114 2784 -22713 2845 -22520 2859
--22442 2820 -22254 2727 -21810 2597 -21342 2451 -21500 2303 -22756 2147
--24737 1943 -26265 1608 -26307 1028 -24790 77 -22605 -1348 -21244 -3286
--22666 -5617 -29831 -7677 -46001 -6772 -42234 9077 -50528 2618 -49532 -3318
--51393 4336 -50123 -11952 -31382 -13993 -33176 -9402 -33345 -11945 -35893 -7631
--36204 -4029 -37214 946 -5822 -7023 -26863 2839 -20101 -2762 -25659 7697
--24341 3303 -24721 5913 -30591 7728 -26430 12544 -27914 13056 -26653 11327
--23808 13400 -25598 11216 -30012 13527 -36805 7973 -20047 10145 -24574 9005
--28847 7166 -29692 8874 -27421 196 -25449 -3698 -32778 -7298 -31691 7198
--29707 -1165 -35995 1403 -34565 -490 -34962 8644 -27106 1764 -29170 21134
--27673 -699 -8456 -3614 -10087 14532 -8445 12777 -16620 5988 -23572 1927
--30521 4353 -28771 8234 -26281 9883 -19406 5539 -20704 5500 -24155 5305
--23596 4841 -30303 1457 -27265 4348 -23662 3837 -24155 1049 -18429 4248
--11797 4462 -16035 1031 -18511 4119 -19079 4584 -12932 5275 -16613 7522
--11058 13889 -17649 29701 -28072 -2363 -34319 -4855 -29257 -3530 -22627 -94
--22896 154 -25319 1691 -27163 -506 -29382 -8876 -41074 11097 -31294 5446
--22899 -6829 -34429 1193 -28374 4917 -28497 -4439 -25018 804 -30479 727
--34288 2248 -28302 3565 -33513 2105 -27021 1758 -32691 6716 -25235 4615
--17618 2897 -19570 -1709 -21249 -360 -32582 6034 -37617 -8904 -37747 -6649
--37181 2779 -20980 7146 -21244 11777 -23527 17801 -22309 21251 -25389 19130
--44429 18938 -30504 55036 -27594 50639 -26000 -2000 -35755 -3916 -49897 -4710
--27169 -16437 -25725 -18721 -27165 -18853 -34777 -3942 -31954 -6754 -25341 -2014
--26585 1997 -27960 2483 -12864 -7034 -27485 -4887 -18639 6 -21415 -3572
--20997 -6645 -25355 8993 -24288 -2053 -23217 -532 -26029 -535 -27477 554
--24906 -428 -33552 -1035 -31448 1035 -29281 3801 -21939 -1512 -19196 -7781
--22532 -13458 -19993 -13945 -21663 -1901 -31614 -3383 -38205 -1506 -32844 2648
--28137 6264 -18406 2255 -21227 -783 -20084 -7822 -23296 136 5049 9395
--15745 4157 -24472 -1654 -21678 -9344 -37908 694 -45458 4898 -40867 11838
--35333 7398 -50138 12551 -46740 17707 -36953 18197 -31765 16855 -40230 15581
--29265 13262 -25786 16254 -27144 23548 -29808 22114 -44103 25775 -38333 14757
--23033 10355 -30873 3649 -21425 5167 -27575 21833 -39360 -2397 -29695 -5615
--32945 -5988 -42000 3000 -30112 5874 -20284 17654 -21604 23472 -16000 9000
--14793 -4547 -12207 18547 -38001 3613 -34999 387 -26122 3201 -26235 3774
--35652 3622 -38211 6355 -30780 10048 -34505 2708 -37495 -12708 -52658 34765
--49132 29746 -40553 776 -36720 -3661 -40182 -2425 -36968 -2739 -37735 -1395
--38622 113 -39387 1573 -39921 2861 -40260 3941 -40412 4817 -40424 5524
--40337 6094 -40186 6553 -39976 6919 -39720 7205 -39432 7424 -39129 7585
--38810 7699 -38476 7775 -38133 7818 -37785 7836 -37432 7831 -37086 7806
--36746 7764 -36413 7705 -36090 7632 -35783 7547 -35486 7452 -35203 7349
--34936 7241 -34683 7127 -34445 7012 -34221 6893 -34012 6777 -33815 6661
--33635 6548 -33465 6437 -33308 6328 -33161 6224 -33021 6124 -32893 6029
--32775 5939 -32660 5856 -32554 5776 -32456 5702 -32369 5627 -32289 5556
--32211 5488 -32133 5423 -32059 5368
-64: 4796636 -188502 -31790 2157 -31603 2152 -31368 2136 -31094 2110 -30786 2073
--30452 2025 -30083 1970 -29697 1914 -29278 1860 -28840 1820 -28381 1799
--27916 1804 -27410 1842 -26935 1913 -26387 2020 -25889 2158 -25460 2319
--24793 2493 -24411 2667 -23990 2826 -23412 2956 -23041 3041 -22903 3070
--22722 3039 -22282 2953 -21726 2828 -21556 2692 -22291 2564 -23920 2458
--25639 2345 -26404 2163 -25769 1790 -24131 1078 -22355 -131 -21215 -1984
--24426 -4541 -25796 -8368 -55485 -13509 -43000 24000 -52552 -2956 -58966 -11541
--57263 -7055 -50486 -12074 -30857 -16336 -19786 -3736 -24213 -513 -41597 6922
--34053 -4301 -40709 -13564 -9701 -4362 -17874 -9425 -13223 -2552 -27655 6298
--32192 1613 -17243 8583 -21910 8196 -26072 12604 -26507 14486 -30589 10717
--22402 15657 -26496 6603 -29979 10445 -31313 7028 -18362 15263 -32803 13008
--30632 10844 -29166 9158 -28138 2464 -38108 3287 -40112 -6184 -23528 -5518
--30449 -6025 -27310 3319 -41050 -4 -28700 -2868 -27755 1206 -39212 15471
--41015 15332 -12728 6880 4340 13077 506 12609 -17316 1962 -27135 2131
--34910 7063 -26302 6097 -19147 3457 -16222 3676 -23594 6588 -29545 7366
--21822 2910 -31400 5871 -26372 7792 -26433 2734 -26239 1282 -20916 -3142
--18191 4231 -2450 4581 -13046 4037 -29023 7344 -14077 4964 -18116 9471
--6119 8454 -13752 30011 -29027 5828 -37986 -6764 -30159 -7082 -18739 -2253
--26623 1491 -31012 1499 -32998 1172 -33563 -414 -46670 5332 -28133 -746
--24228 -10105 -32670 6427 -30912 3425 -30293 254 -12682 612 -22282 591
--26036 2797 -27355 6486 -23951 6508 -26890 2241 -34097 7094 -26707 3671
--12100 4340 -21492 -4953 -24679 -6204 -27074 -85 -36959 -10626 -37876 -8189
--38953 5535 -24985 5771 -25107 5124 -27627 25488 -24485 25481 -16111 28876
--41514 21581 -33038 44861 -33000 45000 -40447 20991 -36314 -2836 -50655 -2952
--7497 -25964 -26613 -20109 -36806 -19012 -39111 -1665 -30782 -6004 -24862 -7585
--21948 -690 -26296 1437 -21797 -5240 -24065 -4651 -16190 -5083 -21298 -1453
--17083 -3535 -22866 -2362 -28089 2714 -24131 227 -31990 -1221 -24975 -3013
--26370 -1778 -30311 -353 -31504 2137 -30000 8000 -23820 -2021 -15765 -3816
--13006 -9209 -19746 -11465 -26663 -10489 -36772 -7474 -35833 -437 -35995 5686
--26783 1588 -23687 -72 -21643 -430 -15775 -2620 -21638 5881 -9552 -5598
--5721 -2880 -17853 3389 -24966 8481 -28851 4068 -44532 8467 -46348 15454
--32454 14982 -47824 7967 -40773 9548 -36850 16632 -29040 14073 -28769 20761
--37386 19238 -29465 12212 -20316 15056 -32954 18544 -44220 46484 -33879 12872
--37638 2374 -34796 1358 -33747 6984 -37383 6944 -32243 4905 -27314 3563
--39000 -1000 -39000 -6000 -24612 3007 -19723 11595 -22158 10510 -17507 13888
--17000 19000 -24200 2605 -25982 3161 -34818 3674 -20366 8068 -25737 5276
--32899 4120 -28987 5665 -24925 5903 -25992 -226 -53080 -16079 -61824 29059
--34192 22845 -37680 8499 -40670 2032 -38632 -2134 -38642 -2390 -39008 -1460
--39493 -105 -39909 1296 -40233 2574 -40397 3669 -40442 4585 -40398 5341
--40281 5960 -40086 6460 -39843 6853 -39576 7158 -39289 7388 -38981 7557
--38651 7682 -38308 7768 -37957 7825 -37607 7856 -37253 7860 -36907 7844
--36568 7806 -36235 7749 -35915 7677 -35609 7590 -35317 7493 -35040 7387
--34778 7275 -34534 7158 -34305 7039 -34091 6918 -33890 6798 -33704 6678
--33531 6563 -33371 6450 -33222 6340 -33083 6234 -32951 6131 -32832 6036
--32719 5945 -32611 5859 -32509 5781 -32416 5705 -32334 5631 -32257 5558
--32179 5490 -32106 5424 -32033 5370
-65: 4816216 -204741 -31965 1987 -31788 1981 -31563 1965 -31305 1938 -31008 1899
--30684 1848 -30337 1791 -29962 1733 -29559 1681 -29139 1643 -28702 1631
--28244 1650 -27761 1708 -27287 1806 -26736 1947 -26355 2126 -25717 2333
--25233 2555 -24905 2777 -24299 2982 -23737 3147 -23501 3257 -23329 3298
--22944 3264 -22386 3161 -21988 3012 -22208 2851 -23266 2719 -24768 2650
--25909 2650 -26094 2674 -25418 2603 -24597 2261 -24414 1485 -25122 177
--26820 -2036 -25474 -5687 -58606 -6298 -43869 20479 -52471 -7110 -44510 -1843
--63978 -36510 -47258 -8444 -25000 3000 -24848 -10209 -29103 521 -40279 2765
--39087 -3395 -25603 -12008 -18275 -16418 -12480 -11487 -9532 306 -30891 5626
--32860 6369 -15095 13417 -18288 12383 -21111 9242 -24822 13260 -26062 10221
--29746 4415 -22633 8497 -31736 10894 -22269 4514 -18760 17774 -42457 17281
--37431 12469 -33175 11435 -36100 8928 -37177 -2320 -44829 -16647 -8983 2985
--37457 478 -31575 6337 -32442 -7682 -34528 -2117 -20889 11649 -37842 12100
--41040 5977 -17548 12933 11698 -6417 -6702 15332 -16556 8066 -30475 6568
--38227 7803 -25448 3490 -19522 2889 -16410 1749 -22947 7226 -25230 7173
--26815 2394 -27437 5762 -25424 6821 -30636 5982 -30605 2193 -18317 1134
--2994 23342 -18346 -18733 -13058 10036 -31043 3313 -17225 13719 -22077 4696
--14171 15945 -1715 20118 -25043 9119 -42235 -4467 -28066 -9553 -13789 -8861
--32232 1668 -33352 849 -33090 1769 -38083 1902 -44510 700 -38086 -6249
--30036 -1288 -31579 1200 -19423 3363 -29299 1960 -13994 190 -16147 1490
--19401 4114 -20629 6833 -21373 7938 -31868 1588 -31130 8641 -24382 -356
--20872 2017 -24603 -1874 -26232 -4673 -31442 -4933 -31940 -3965 -36949 -3789
--31605 411 -25952 1730 -27514 4862 -15174 18803 -14514 25718 -16821 37049
--34737 35075 -42346 41455 -45027 35484 -54786 22813 -31326 1508 -32365 -10772
--32394 -20082 -33122 -20157 -32947 -13046 -35440 -6511 -26155 -10771
--22447 -4418 -19666 -8219 -25596 -3022 -24482 1728 -24376 -2252 -18767 -6327
--22146 -3134 -14577 -5105 -20244 1372 -24537 2242 -28465 431 -29938 -2051
--30856 -4972 -28932 -7260 -23961 -2059 -25836 8395 -34016 7873 -27693 1643
--20334 1680 -15353 -7460 -24651 -11021 -28740 -10948 -29550 -10370 -30141 -4269
--43696 605 -33654 -1039 -20454 -3989 -16462 -1100 -15785 -2950 -12937 -3805
--11755 -1036 -8580 2675 -22621 21510 -26635 843 -24723 14888 -46262 17623
--30607 22747 -26761 14276 -38933 1361 -42117 -4455 -30283 12586 -25148 22335
--34782 20110 -33856 17342 -18371 17398 -30677 10834 -44356 10091 -56222 48804
--30888 19921 -23607 2984 -46284 8337 -47684 8227 -36911 8404 -34000 15000
--30688 -7368 -35312 -6632 -26798 -2694 -26202 -2306 -20545 9168 -32956 13462
--19151 12011 -18011 9159 -20337 6200 -20679 7934 -42667 3518 -11654 11548
--24371 3080 -27629 1920 -27585 -18 -29263 1810 -29048 2088 -39963 7083
--46489 12915 -42478 11476 -41148 6861 -42214 4113 -40448 -426 -40258 -1240
--40309 -784 -40421 253 -40573 1455 -40612 2618 -40608 3662 -40549 4565
--40419 5326 -40208 5948 -39970 6446 -39719 6831 -39444 7131 -39138 7360
--38809 7537 -38466 7675 -38121 7779 -37770 7853 -37417 7895 -37064 7911
--36715 7899 -36371 7862 -36038 7805 -35720 7728 -35417 7638 -35129 7536
--34859 7423 -34608 7307 -34372 7184 -34153 7061 -33949 6937 -33758 6813
--33584 6691 -33423 6572 -33272 6458 -33132 6346 -33002 6238 -32879 6135
--32765 6037 -32662 5946 -32560 5861 -32463 5780 -32376 5705 -32295 5630
--32224 5559 -32149 5488 -32079 5424 -32007 5368
-66: 4835773 -221066 -32160 1816 -31992 1807 -31781 1790 -31537 1760 -31255 1716
--30947 1663 -30617 1602 -30260 1542 -29878 1491 -29473 1457 -29052 1454
--28614 1487 -28158 1567 -27645 1695 -27259 1873 -26663 2095 -26163 2352
--25857 2626 -25259 2903 -24595 3155 -24278 3361 -24118 3497 -23730 3544
--23139 3494 -22657 3352 -22596 3143 -23102 2912 -24072 2722 -25040 2642
--25530 2726 -25448 2959 -25248 3214 -25708 3221 -27605 2776 -31595 2163
--37270 1437 -33274 -2519 -31998 2778 -44200 11793 -57860 -10281 -47401 -26475
--40014 -18337 -42396 4012 -19911 -10357 -37930 5516 -35926 3925 -46544 -3752
--36466 -5612 -22567 -13132 -17423 -23134 -15414 -10209 -8242 -4761 -35099 6221
--36608 7402 -5533 22345 -26298 11180 -25823 2838 306 18486 -35661 8031
--37786 2629 -26190 11834 -27286 15034 -14440 5405 -11376 7233 -30112 11959
--59508 14317 -42273 11356 -30955 11098 -24862 122 -22707 -1144 -23909 3202
--46723 2784 -36460 5877 -43543 121 -30361 2884 -14950 2501 -40344 5772
--36795 9841 -19461 14812 2127 10168 -10227 -2411 -9033 9992 -33306 722
--45389 4586 -26628 2041 -17428 371 -16712 58 -22697 2552 -26144 2803 -23748 5306
--25354 6032 -28510 11962 -32162 3094 -31313 1187 -21696 1688 -21545 11116
-254 6313 -14198 4867 -28431 -583 -26014 7454 -15328 8742 -19345 25449
--2556 15675 -15007 12815 -28809 538 -26092 -15208 -20232 -14266 -38487 -2100
--38370 -2773 -32744 -2480 -44082 -4738 -43943 5485 -39519 -49 -36740 545
--31792 -433 -22063 1918 -23021 271 -6089 1167 -10883 1780 -10787 3670
--15721 2884 -21688 4015 -29889 5672 -28808 11560 -32000 2000 -28042 1314
--28400 -2515 -27858 -2825 -31312 -2244 -31360 -2872 -32118 -2848 -29762 -1018
--25148 -992 -24657 7922 -7181 19805 -25029 17549 -15224 17851 -31026 34330
--63448 62212 -58075 55204 -34360 7127 -25855 -1082 -19905 -15403 -31416 -23469
--39717 -18300 -39486 -9634 -33226 952 -23153 -12872 -26782 -5038 -25880 -14445
--19610 -5312 -21592 5677 -22838 -2319 -25737 -1725 -14132 -2148 -20792 -1602
--19884 -2338 -23504 -3677 -27090 128 -26035 -533 -23009 -6169 -31702 -7290
--31552 1512 -33406 2192 -34739 7314 -23626 2844 -24046 2122 -21199 -3073
--29039 -7234 -31974 -8179 -28346 -8445 -32258 -9951 -35316 -9195 -28600 -1716
--20302 -4574 -21530 -9595 -13601 -2467 -8710 -6053 -18792 2318 -16960 29640
--22487 21070 -29081 11986 -32158 8638 -48832 16046 -26307 20386 -5828 17622
--22563 6441 -31488 -5466 -29473 -318 -32433 18980 -28786 13563 -32494 18036
--22702 17807 -45421 15545 -47767 3600 -42569 38996 -30422 19466 -27337 12558
--51166 15991 -49864 13885 -36055 -726 -31640 18437 -26221 7883 -30882 89
--30683 -376 -38528 2404 -26736 4765 -21348 1111 -21986 2226 -22941 5197
--13993 6442 -13499 11581 -29392 6167 -24271 8008 -28626 1803 -20680 1296
--22832 3621 -30705 -3024 -38967 620 -36496 4783 -36593 9012 -42756 10600
--43314 7776 -41908 3212 -41613 718 -41523 -135 -41436 111 -41374 919 -41199 1932
--41051 2960 -40883 3918 -40656 4758 -40384 5464 -40131 6035 -39877 6486
--39592 6839 -39276 7122 -38945 7353 -38610 7545 -38269 7704 -37925 7827
--37570 7917 -37210 7969 -36849 7986 -36495 7972 -36150 7931 -35817 7867
--35503 7782 -35203 7684 -34924 7573 -34662 7454 -34421 7330 -34195 7203
--33989 7075 -33796 6947 -33618 6820 -33457 6695 -33306 6575 -33166 6458
--33037 6346 -32917 6237 -32804 6132 -32699 6033 -32602 5942 -32507 5857
--32418 5776 -32333 5701 -32257 5626 -32189 5555 -32121 5485 -32049 5419
--31981 5364
-67: 4855308 -237473 -32374 1642 -32218 1632 -32022 1610 -31791 1576 -31524 1528
--31235 1470 -30922 1404 -30587 1341 -30225 1290 -29840 1260 -29436 1265
--29038 1315 -28540 1417 -28173 1576 -27647 1792 -27104 2061 -26847 2370
--26295 2703 -25569 3037 -25177 3345 -25036 3598 -24696 3765 -24028 3820
--23390 3745 -23174 3541 -23431 3234 -23976 2873 -24510 2548 -24760 2370
--24708 2454 -24657 2858 -25136 3438 -26538 3663 -28862 2772 -33031 1172
--35673 939 -36138 2049 -26836 8686 -47379 -3071 -66785 -32615 -23052 811
--33948 2189 -27348 -5925 -30909 -16424 -46431 18815 -47374 2363 -39593 -7946
--33805 -4923 -31233 -11429 -11871 -24186 -3599 -17229 -31810 -2962 -44938 13367
--24813 9981 8716 29151 -34908 5941 -15802 4622 -11655 11443 -38007 5289
--41858 1450 -26697 13364 -21876 15739 -21831 12296 -22686 7761 -32263 7873
--45510 9713 -41280 3230 -23290 12219 -17525 9844 -10370 7783 -36175 9955
--48660 3783 -43694 2342 -34794 8708 -38044 11158 -20790 -13363 -33723 -5016
--36908 12688 -29284 14224 -15994 16346 -9338 2026 -6028 -2253 -18816 2160
--42818 6877 -31391 1821 -14683 -2391 -15634 -2797 -23429 -2125 -30145 -2470
--20086 7107 -26251 4138 -27281 10000 -29984 2192 -36453 3059 -20220 5853
--14026 9686 -536 13227 -24005 -1472 -27434 4188 -32313 7796 -33866 13487
--8698 26225 -5898 10403 -9361 2197 -20581 -1162 -21093 -12817 -26883 -4903
--34117 -5097 -47000 -2000 -27179 -6324 -46657 6684 -34496 -4654 -37592 -1525
--36530 -239 -32969 -1044 -26301 -666 -32098 4114 -1961 9051 3084 533 2892 -484
--22930 -4992 -27697 5190 -26212 11608 -27095 9956 -37075 935 -35620 -661
--25467 -733 -30963 -1127 -31412 567 -34906 -2903 -30995 -3920 -30560 -2996
--31622 1921 -19459 5434 -18403 9987 -18216 7825 -16876 2470 -51360 46066
--67574 69524 -52751 73403 -13910 -2053 -20910 -1865 -18564 -20266 -21965 -27600
--41226 -15219 -39598 -6369 -19941 5979 -27100 -11854 -35786 -14753 -20810 -7441
--29011 -3652 -21013 -1361 -25616 -644 -19853 1902 -18634 -588 -22585 -960
--21051 -693 -24210 -4390 -22835 -5881 -18900 -1775 -27097 -1459 -21999 -2151
--35689 852 -44959 -5296 -31532 2522 -24237 4817 -22187 2491 -25059 4245
--38310 -1357 -33854 -3966 -33871 -5157 -30929 -9763 -32279 -11967 -18225 -7415
--26149 -10817 -25828 -14525 -161 9013 -7498 -9018 -22097 11105 -29478 31532
--23528 17417 -27954 14332 -22911 13972 -32702 14154 -32272 17457 -10136 17652
--9079 17545 -24421 10172 -40024 -284 -16580 928 -47550 6568 -45778 3867
--18716 30247 -24318 8631 -55436 18315 -40507 20920 -20160 14076 -25285 8755
--56650 13363 -59228 15130 -34228 12531 -15236 30842 -56842 -6349 -38315 7533
--28501 456 -22564 11 -28422 -3945 -27728 4032 -23079 3938 -26396 4924
--5534 4733 -498 14517 -24898 11487 -35568 3870 -40868 2033 -24558 698
--15378 -338 -37231 -1823 -32089 -3497 -30193 6779 -38326 6590 -38415 7573
--40347 5344 -40752 2476 -41874 924 -42396 558 -42478 957 -42195 1736 -41861 2651
--41492 3565 -41076 4403 -40684 5125 -40362 5715 -40065 6186 -39742 6565
--39399 6879 -39059 7152 -38732 7396 -38403 7611 -38062 7790 -37705 7927
--37336 8022 -36966 8071 -36599 8081 -36244 8056 -35902 8002 -35573 7924
--35263 7828 -34972 7718 -34700 7598 -34449 7472 -34217 7342 -34006 7211
--33811 7077 -33632 6947 -33468 6816 -33320 6691 -33181 6568 -33055 6451
--32938 6337 -32827 6228 -32727 6123 -32631 6025 -32540 5933 -32454 5847
--32371 5767 -32290 5693 -32219 5619 -32155 5547 -32090 5478 -32023 5412
--31955 5356
-68: 4874819 -253959 -32606 1468 -32462 1455 -32279 1428 -32064 1388 -31815 1334
--31548 1269 -31255 1197 -30938 1130 -30596 1078 -30232 1051 -29867 1065
--29455 1129 -29051 1254 -28636 1443 -28070 1700 -27821 2016 -27345 2380
--26650 2776 -26208 3175 -25997 3547 -25703 3858 -25109 4066 -24363 4136
--23882 4039 -23923 3763 -24311 3321 -24649 2772 -24605 2219 -24191 1816
--23792 1762 -24033 2257 -25458 3309 -27970 4071 -30884 1749 -31012 -1200
--32178 -2939 -42749 4699 -42177 -11408 -42703 -4001 -32592 -3852 -28458 7324
--28273 -4247 -30114 -2476 -40160 5881 -45557 7659 -50011 2764 -41311 -7691
--36206 -8442 -27337 -20835 -12631 -15648 -7072 -4732 -37901 -14472 -34133 8074
--25399 5693 -9810 3473 -17295 17656 -9937 13727 -21538 14400 -38554 12005
--42665 6462 -25250 13338 -14763 12544 -23057 9462 -36491 12635 -28356 6401
--34294 14008 -29037 637 -45755 12691 -12132 12007 -41143 12941 -18354 6575
--34476 -433 -29523 1117 -19871 5283 -35776 -542 -43756 -3183 -40729 -970
--28624 8882 -34954 13597 -17817 14668 -38838 7561 440 -1632 -13339 15018
--32661 4827 -31640 1573 -6715 -5740 -13266 -5891 -20002 -6920 -28099 -11790
--26571 7497 -26434 12271 -42270 7434 -20976 2516 -43188 9184 -27347 3516
--21467 13731 -2806 8111 -7721 -4367 -21109 3567 -28111 8540 -19657 16267
--20438 10824 -15782 7629 -20503 1961 -26985 -2362 -12288 -2141 -27177 873
--41554 -394 -39070 -2058 -45944 -9103 -29502 1299 -22100 -4795 -35830 1839
--34537 1583 -36710 2115 -32524 6331 -30772 9652 -5229 9009 8293 -5309
-23628 1038 -30875 -3618 -34663 2585 -27589 7575 -25192 4200 -32897 2454
--34253 -4718 -27305 -3120 -33545 6384 -45939 -3640 -40914 -4521 -27871 -4945
--27209 -3331 -27067 -1563 -21708 3811 -17973 10218 -19319 6971 -32000 7000
--64000 29000 -66272 46826 -40353 58229 -8670 36467 -8000 2427 -35705 -26949
--32904 -12933 -34096 -13067 -8689 -11436 -18250 2607 -25796 -10144 -28265 -12027
--31166 -4867 -36834 -7133 -28382 -2001 -25628 -924 -11495 3357 -22413 941
--24603 523 -27479 104 -27324 -3162 -20781 -8958 -19026 -714 -19700 121
--26089 5265 -31904 -365 -39849 -4788 -36077 -6222 -15792 648 -18168 4908
--33336 9678 -44283 5158 -29671 11431 -50127 -8921 -35873 -12079 -35705 -15355
--27230 -14613 -14119 -4394 -6020 10561 -9274 -10218 -12590 -3319 -17790 5711
--23436 20199 -32651 16031 -19141 17104 -20323 18617 -27654 21120 -33873 19180
--15366 15972 -15359 18813 -18125 23549 -36604 -6736 -30908 -3179 -45243 14681
--50751 -964 -5492 19881 -26724 21071 -46779 8723 -48471 16982 -38076 15266
--9022 2079 -50219 11062 -57221 1568 -50834 5608 -57184 28552 -36529 18888
--29289 20054 -19651 11288 -5244 11848 -23782 -17963 -24209 -2613 -35642 13648
--39921 25215 11195 7206 24487 -9326 -31411 -4382 -42252 4437 -45088 778
--37059 3101 -5349 -6448 -30073 -4921 -39613 -4005 -32463 -3726 -38367 5421
--30261 6203 -35076 2685 -39024 871 -42096 502 -43373 978 -43458 1802 -43051 2716
--42454 3599 -41764 4393 -41171 5064 -40709 5605 -40308 6033 -39907 6379
--39509 6684 -39154 6972 -38835 7251 -38514 7516 -38173 7748 -37809 7936
--37433 8070 -37058 8152 -36687 8185 -36327 8174 -35974 8131 -35635 8057
--35311 7965 -35006 7857 -34721 7735 -34456 7607 -34215 7475 -33997 7340
--33798 7204 -33618 7068 -33455 6934 -33308 6803 -33174 6675 -33051 6553
--32939 6434 -32833 6322 -32734 6212 -32645 6107 -32561 6010 -32478 5917
--32398 5833 -32324 5754 -32248 5680 -32184 5607 -32120 5536 -32061 5467
--31994 5402 -31930 5346
-69: 4894309 -270516 -32853 1294 -32721 1277 -32552 1244 -32356 1197 -32126 1135
--31880 1061 -31606 983 -31315 909 -30994 854 -30656 830 -30308 850 -29930 927
--29583 1073 -29039 1293 -28791 1586 -28382 1951 -27731 2372 -27320 2833
--27094 3304 -26685 3752 -26131 4134 -25566 4403 -25021 4509 -24681 4405
--24743 4060 -25051 3473 -25115 2689 -24599 1822 -23691 1051 -23099 646
--23774 1009 -26537 2715 -31349 5463 -35644 2337 -41040 -6637 -35145 1366
--32585 -1136 -32249 -14420 -30879 -7923 -18488 7825 -23829 8251 -28739 2024
--38776 981 -44904 9201 -47425 6574 -62424 -226 -45691 -6689 -29322 -2956
--588 -29981 -10806 -22252 -38542 -4236 -32382 6889 -25337 3997 -30405 -556
--14254 -10875 -9986 11420 -9707 18926 -25071 25329 -49646 21337 -36990 12513
--27969 11382 -12909 10954 -19482 5919 -39788 6582 -30460 8408 -34184 12866
--31248 7151 -28547 16672 -32586 11592 -40620 8961 -21076 5288 -22946 -2714
--24426 6171 -19271 2045 -46105 -14953 -40669 9365 -38901 8902 -29801 6695
--21972 8814 -10055 8300 -45161 6929 -21453 2672 -40949 12716 3110 8927
--7268 5392 -13487 -6171 -20269 -8455 -13195 -16901 -43747 4028 -33197 3949
--33278 7177 -35767 15318 -27186 7877 -33583 -379 -28125 -3109 -23864 10373
--16047 6762 985 -7293 -10562 4192 -27087 6973 -21593 8472 -17988 6661
-2744 3835 -43846 9352 -40141 3010 -24657 -2003 -24564 -1829 -38566 6882
--39361 3237 -41101 -1377 -30689 496 -23433 -5614 -26796 647 -25562 927
--38317 2531 -34429 11332 -24030 7719 -26991 1062 -6824 -717 33560 1822
--31674 -17574 -22459 11648 -25327 8184 -26714 3332 -29332 -1893 -28827 -1699
--27472 -1547 -27141 2356 -47500 -3439 -42635 -4415 -36553 -6273 -30988 -4451
--26037 3471 -19902 3719 -18098 6519 -22733 8963 -18717 437 -68245 22337
--59143 42189 -26834 56314 -29200 29385 -7262 -4300 -30411 -10075 -23243 -11681
--19000 -15000 -23986 -3550 -23545 1219 -29244 -8810 -27225 -8859 -41000 -6000
--32548 -10011 -32442 4494 -22710 5777 -16079 3925 -19095 -1126 -21999 -2628
--28438 -5451 -26745 -6256 -29316 1897 -24293 3104 -18565 5516 -13070 6571
--19966 2644 -35006 4403 -26106 -509 -12438 -7424 -34647 -3405 -41094 8537
--51004 5896 -47017 2707 -42999 -2524 -44185 -11271 -31767 -16896 -38657 -3944
--7354 -7295 -3460 -3731 -18047 17918 -29327 2461 -32980 2817 -1250 5295
--9532 20790 -14595 16539 -19874 20027 -19394 20903 -30747 17447 -18442 14930
--22707 17011 -20222 13007 -37190 3942 -33814 4859 -41839 12950 -47062 10802
--20714 18570 -11693 18696 -42816 7648 -47709 3988 -68046 6400 -12086 7520
--27482 6256 -51082 7936 -51966 9937 -57374 18224 -40027 17358 -18500 17966
--10749 10932 -17654 13254 -23536 3838 -17498 824 -37537 8332 -47140 17690
--671 5833 29982 -11351 -22146 -862 -38020 880 -35648 -5803 -33792 -1860
--32322 -4230 -27752 -11674 -39133 -18175 -24414 -1850 -42456 10679 -19215 7120
--31464 -273 -39520 -1033 -43593 103 -44775 1577 -44561 2896 -43792 3959
--42783 4780 -41892 5391 -41200 5827 -40634 6135 -40094 6377 -39615 6606
--39230 6858 -38909 7141 -38590 7434 -38242 7708 -37873 7939 -37497 8111
--37127 8221 -36764 8273 -36402 8277 -36047 8242 -35693 8176 -35351 8088
--35027 7982 -34724 7863 -34444 7736 -34188 7602 -33958 7465 -33755 7325
--33571 7186 -33409 7048 -33265 6911 -33136 6779 -33019 6651 -32915 6528
--32816 6410 -32724 6297 -32641 6189 -32564 6085 -32487 5988 -32416 5897
--32343 5813 -32275 5736 -32208 5661 -32147 5592 -32088 5520 -32029 5453
--31967 5389 -31903 5332
-70: 4913784 -287137 -33113 1123 -32994 1100 -32843 1059 -32663 1004 -32455 931
--32226 848 -31977 761 -31709 680 -31411 619 -31106 595 -30765 619 -30475 707
--30013 870 -29684 1116 -29430 1444 -28827 1854 -28309 2331 -28289 2858
--27885 3407 -27040 3941 -26574 4413 -26448 4769 -26096 4943 -25571 4869
--25389 4487 -25585 3768 -25568 2740 -24855 1515 -23642 295 -22833 -673
--24536 -1639 -27176 911 -35518 8459 -37779 9413 -45000 -16000 -17037 5920
--31839 -12121 -38721 -8404 -16331 -2554 -20695 4771 -23398 5790 -28248 4651
--32225 2381 -37346 634 -47983 381 -66704 3966 -67790 14426 -7150 -8056
-13010 -27637 -25010 -7145 -52967 -9435 -30021 16362 -18995 -6413 -25754 1805
--28917 3291 -19525 5864 -35579 24358 -24203 13819 -31784 10643 -24665 7391
--18343 16721 -19113 15287 -22694 6857 -32249 5826 -34922 7499 -36922 3302
--43450 6913 -4268 36133 -45068 2587 -37645 4312 -21652 5113 -13546 -10075
--28418 7407 -26455 8862 -45378 6568 -38164 3936 -38645 8334 -29841 765
--10185 4968 -26902 5063 -46263 1934 -21000 7000 -25098 10200 -812 5428
--8010 7299 -25582 7551 -29611 -8143 -15759 -25160 -32546 -3391 -31434 6704
--34875 7636 -31292 8705 -31136 10488 -26686 4079 -22703 3269 -22350 15078
--7392 8190 -9800 -11499 -26422 -4154 -26515 -3830 -21282 5854 -24814 4643
--24053 8198 -30652 13062 -35803 7712 -27059 -207 -25757 -1437 -34097 3568
--35910 3163 -36078 793 -32292 -5160 -23384 -2867 -23789 396 -23573 2176
--28542 -840 -28259 9831 -18758 6215 -11172 8624 5291 9137 -3715 4809 -31114 -419
--29056 -3298 -30873 -3792 -28609 -4550 -27768 628 -28926 -3423 -27198 -3563
--32177 1093 -39199 -1548 -37357 -1133 -42712 -5057 -38873 -4459 -27417 7401
--12570 -1633 -13095 3557 -26935 3707 -29379 -1366 -62487 18160 -59475 29461
--45735 30326 -3345 50175 -2526 4225 -10971 -8886 -24629 -11692 -24661 -11898
--32062 2914 -25369 -2789 -26055 -7048 -30803 -10003 -33991 -5689 -35575 1420
--30919 5941 -25611 5502 -22247 2366 -19777 -2767 -18111 -2007 -22910 -989
--26292 2735 -39965 4626 -31254 5495 -12487 3044 -5984 15545 -8010 4632
--34940 11856 -32804 -24288 -4745 -5151 -44041 1948 -44129 6168 -48164 -1793
--51034 -4580 -37796 4496 -33652 -10731 -42299 -14060 -40911 3388 -13991 4857
--10508 7245 -21492 8363 -25945 10168 -30428 6944 -25757 9595 -19973 6399
-20930 9653 -21032 13513 -10390 24558 -40341 14587 -34575 20641 -12032 6556
--22596 2169 -33672 7268 -43146 6844 -29934 11807 -31469 16535 -27987 9812
--28442 629 -38877 19523 -63729 16027 -36461 6464 -31120 8133 -12582 6920
--40994 13170 -44499 9044 -47731 10109 -39785 9356 -25849 9183 -18347 15052
--16830 11994 -24536 9040 -22986 11073 -31609 -35 -42938 16641 -20602 11846
-24586 -3972 -26633 -4076 -33953 -3952 -35172 -4718 -30798 -1893 -25596 -2329
--39322 -24399 -32636 -19678 -18032 1056 -25624 9135 -17063 6874 -36202 -4102
--45397 -2258 -46268 679 -46271 2871 -45393 4463 -44089 5516 -42835 6144
--41837 6467 -41027 6599 -40302 6651 -39701 6718 -39268 6860 -38937 7088
--38609 7373 -38252 7669 -37880 7928 -37522 8129 -37175 8259 -36833 8327
--36483 8342 -36119 8318 -35749 8264 -35384 8186 -35034 8091 -34706 7981
--34405 7859 -34134 7728 -33889 7591 -33677 7449 -33490 7305 -33328 7162
--33187 7019 -33062 6883 -32955 6747 -32855 6619 -32771 6496 -32690 6378
--32614 6265 -32545 6158 -32479 6057 -32415 5959 -32351 5871 -32290 5788
--32227 5711 -32167 5640 -32111 5570 -32055 5501 -32000 5435 -31940 5371
--31877 5317
-71: 4933248 -303810 -33383 955 -33281 924 -33145 875 -32981 810 -32796 726
--32589 631 -32362 532 -32119 442 -31850 374 -31562 346 -31274 371 -30967 466
--30550 642 -30354 906 -30006 1265 -29218 1712 -29276 2240 -29296 2830
--28208 3458 -27306 4087 -27540 4668 -27895 5141 -27267 5429 -26154 5440
--25681 5082 -26037 4281 -26365 3033 -25805 1467 -24387 -121 -23168 -1432
--24576 -2936 -28832 -4589 -44802 2067 -54216 2688 -9000 -6000 -31737 -3893
--27037 -17 -21784 4141 -19930 -3229 -19512 -1002 -22392 1308 -34486 5748
--26959 -1743 -23634 -6777 -34753 -7881 -48964 -1730 -49880 20566 -10140 4548
--48544 -247 -40244 4429 -18007 -12212 -39260 1989 -27176 -659 -24600 5969
--33077 3838 -29741 8127 -32143 11727 -29091 6102 -24264 4441 -22516 7120
--24174 11613 -14639 21433 -18900 16652 -36313 10216 -41126 13891 -38819 3969
--32419 440 -21650 6675 -33506 12968 -25642 10142 -25513 5903 -26021 7718
--22407 -283 -28191 812 -42611 11669 -31540 14456 -39217 16564 -33046 -1857
--24389 2580 -33867 5220 -23376 -4664 -19644 -749 -21902 3189 -4350 -341
--11867 7121 -31513 10334 -30749 4650 -19788 -24009 -26950 -7975 -34277 16121
--38583 5589 -37343 5547 -26936 7114 -16882 5951 -16219 3991 -25090 6342
--15657 5632 -8049 -1558 -33925 -1031 -27145 -9194 -18841 489 -25169 4836
--32916 14710 -31949 15611 -31778 7339 -30919 1160 -25045 -2074 -31853 1040
--32372 1721 -31832 1513 -30945 -10529 -29918 -2503 -21361 991 -20807 4045
--17433 3373 -24607 3181 -25489 2701 -4200 7972 2717 11821 -11873 19146
--34729 1459 -31014 -5203 -32288 -3564 -28777 -4666 -25049 -3098 -27372 -5617
--25071 -5632 -35156 1150 -39161 1938 -41426 743 -45143 -3754 -39960 -9822
--24024 -10174 -12379 4539 -9122 2125 -25649 14664 -34298 6389 -47090 18940
--43095 24944 -40107 23974 -29771 18249 -2099 2788 -3789 -571 -26236 1458
--34066 -745 -33690 -4260 -33643 -6114 -17209 -2808 -34970 -7088 -29968 -1855
--26625 123 -24365 5127 -27267 2553 -22696 4761 -19919 3041 -25050 -1951
--21582 3995 -20382 4443 -40296 9995 -17229 536 -16891 10131 -14062 7043
--13069 2768 -25888 11093 -24204 -7755 -34993 -5845 -41428 -933 -41826 -3003
--44372 -2528 -40572 -5723 -39105 -4336 -31856 -7895 -40170 -7281 -40482 4415
--27555 11570 -21073 11826 -22996 13394 -30298 15025 -24825 16929 -32082 11833
--13194 -9389 1454 -5423 -2947 -1581 1403 36903 -45192 24822 -35915 5414
--24845 -2121 -21277 7992 -33248 7410 -27760 9728 -29834 14577 -32674 9486
--32477 11534 -33635 4430 -37533 10817 -56855 19338 -31328 9820 -32967 13223
--13793 7685 -30625 11854 -33233 7857 -31847 6117 -24472 2793 -40013 11102
--39314 16353 -26099 6724 -24483 9823 -25087 21391 -25095 8226 -34497 2998
--22666 -3524 -17991 10434 -17320 -2376 -30042 -5516 -25415 -4907 -28643 -1129
--33370 -4301 -32240 -1460 -29243 -31528 -16728 -14076 -28307 7544 -11885 -5708
--40409 -981 -46297 883 -46603 2785 -46363 4888 -45238 6416 -43791 7247
--42513 7533 -41426 7476 -40477 7270 -39722 7079 -39217 7013 -38868 7107
--38534 7328 -38167 7609 -37805 7880 -37482 8094 -37189 8237 -36887 8315
--36552 8342 -36185 8332 -35794 8298 -35400 8244 -35019 8172 -34662 8085
--34337 7979 -34046 7860 -33790 7727 -33565 7585 -33370 7436 -33207 7287
--33068 7136 -32949 6990 -32849 6849 -32762 6710 -32686 6580 -32622 6456
--32560 6339 -32503 6227 -32448 6121 -32395 6020 -32343 5925 -32289 5838
--32236 5757 -32181 5683 -32126 5612 -32074 5544 -32025 5478 -31971 5413
--31913 5351 -31850 5298
-72: 4952707 -320523 -33668 790 -33576 752 -33455 694 -33310 617 -33147 519
--32961 412 -32759 299 -32537 198 -32297 120 -32032 84 -31798 107 -31455 202
--31135 384 -31102 661 -30275 1038 -30015 1514 -30474 2081 -29762 2726
--28261 3427 -28103 4150 -29229 4853 -29477 5473 -27954 5925 -26110 6099
--25688 5855 -26785 5054 -27954 3612 -27769 1658 -26012 -250 -23869 -919
--24621 1165 -32117 5223 -33000 -19000 -50000 -4000 -23517 -512 -25483 -3488
--26410 1009 -9393 2991 -18416 1655 -21959 3140 -26488 3018 -45862 -2723
--32805 914 -20825 -9573 -24752 -6680 -33202 3007 -43384 11089 -36086 4001
--43575 13502 -23708 9600 -30839 -3998 -38491 3232 -28487 620 -26473 2566
--33698 5176 -35131 6304 -37066 5728 -24453 287 -20093 -3251 -24245 4797
--25708 13853 -17622 30002 -13588 22586 -49813 8033 -30402 13015 -40459 2653
--33115 -488 -42126 -1623 -15608 12172 -6600 12423 -24207 6713 -29621 5875
--31290 3375 -34706 5132 -32134 20081 -27315 15849 -29666 6754 -41470 -1618
--30236 1392 -26182 301 -25403 1721 -25941 2821 -27167 -1010 -21112 -152
--25963 4695 -9441 10908 -29887 4837 -19377 289 -33300 -1501 -31048 -640
--37946 -1536 -45076 2105 -23518 3957 -6930 8349 -15374 6482 -25841 -5222
--23522 442 -15505 -1154 -28940 16718 -38517 -3805 -19734 -1998 -22588 4246
--28504 12784 -29649 14108 -29384 -109 -27882 -922 -20129 -1502 -27345 3519
--33250 3827 -35448 -341 -36000 -4523 -25908 819 -18057 1517 -18098 1635
--11886 2517 -26163 11986 -35513 1201 -7709 9679 -1440 15495 -8831 15626
--36225 -9791 -32036 -4561 -29140 -2587 -27076 -3831 -22676 -33 -24075 -4880
--30400 -6375 -38808 -1375 -41604 -813 -41268 -1535 -43112 -3403 -38303 -6001
--23248 -1394 -26237 328 -20299 -417 -9721 24851 -33614 -1658 -40528 9083
--37340 13781 -33219 13092 -22914 8580 -7998 6209 -18802 2368 -25520 3446
--34715 8480 -30759 -2309 -17102 -7767 -25783 -6213 -29376 -1156 -22172 2006
--25481 -929 -21668 5389 -24746 6656 -18998 7428 -26509 6619 -25528 4318
--23066 6277 -17119 5027 -44279 7845 -21208 2515 -15749 14942 -19544 8029
--20372 6262 -33530 -6230 -27953 -6456 -33014 3862 -37878 -3967 -39253 -1471
--41709 -4585 -36631 -4647 -34923 -4879 -36893 -1561 -29082 -11883 -32328 -1397
--34066 15459 -29650 19012 -28046 18632 -35628 22719 -20341 20880 -28593 16882
--15237 -23201 -32395 -28455 7991 19787 -2271 32534 -21839 11517 -30442 3680
--29749 2588 -24911 3556 -25142 4061 -29987 9851 -32128 7450 -34342 8537
--30206 9656 -22773 2354 -40002 14355 -49768 17199 -31260 12777 -26912 13061
--16541 9807 -33341 10917 -26694 13158 -32420 9114 -33800 5664 -43238 11726
--37279 10436 -25724 4597 -32404 11794 -30589 21062 -15238 8474 -29789 2823
--25446 -1896 -25023 711 -24245 -3783 -33966 -8543 -12906 -4363 -28439 -1131
--46408 -10565 -12106 -9765 -40931 -13990 -30710 -7588 -13576 2518 -22243 -7584
--40465 -911 -36725 -2257 -43883 2722 -44749 6504 -44145 8255 -42930 8818
--41682 8691 -40523 8227 -39589 7704 -38986 7325 -38618 7183 -38288 7265
--37926 7484 -37591 7742 -37332 7963 -37118 8114 -36882 8199 -36579 8238
--36210 8250 -35797 8248 -35379 8237 -34968 8210 -34587 8165 -34241 8096
--33928 8000 -33655 7882 -33415 7744 -33214 7593 -33042 7434 -32903 7274
--32792 7114 -32699 6959 -32625 6812 -32564 6668 -32512 6535 -32469 6410
--32429 6292 -32390 6181 -32351 6076 -32313 5977 -32273 5885 -32230 5799
--32184 5721 -32137 5648 -32088 5582 -32040 5514 -31992 5450 -31942 5387
--31886 5328 -31826 5276
-73: 4972167 -337264 -33959 632 -33878 586 -33775 517 -33648 426 -33502 315
--33343 192 -33160 65 -32965 -51 -32745 -141 -32519 -188 -32311 -173 -31912 -84
--31930 97 -31445 376 -30815 759 -31184 1249 -31220 1838 -29784 2521 -28721 3276
--29716 4085 -31151 4906 -30463 5691 -27741 6354 -25525 6773 -25900 6771
--28362 6105 -30550 4515 -30652 1875 -28198 -1470 -23274 -4421 -19196 -6177
--26404 -3922 -40484 -3854 -26860 -5729 -36561 1034 -23186 -9657 -30188 1003
--14655 4146 -19710 2398 -20590 5992 -23985 634 -34000 -1000 -35848 3165
--32600 -8746 -31402 -7964 -30569 12136 -41767 11627 -48899 -11660 -10368 31415
--27655 515 -33349 3821 -35275 5388 -34372 -2234 -21261 8553 -38715 9547
--39440 5372 -38833 3044 -26886 950 -15073 -10314 -29629 270 -32860 10057
--29939 36982 -18141 20730 -35378 13393 -32914 9579 -33391 3987 -30776 3600
--31912 4005 -15929 4213 -11914 5495 -21628 8309 -29349 11667 -35928 4098
--32870 4143 -32979 24613 -26267 21086 -30035 -4590 -29716 -5155 -37526 -3569
--22985 880 -37325 10508 -30902 4674 -33934 250 -27807 -769 -25900 10603
--16678 -4934 -18137 7743 -15771 7614 -27378 399 -30683 -28 -35901 -4988
--46290 -1294 -30411 1309 4979 9352 -10607 12532 -34805 -3179 -36072 -1200
--18931 6636 -24578 16153 -37650 -3218 -27095 -3108 -24000 1564 -25128 7630
--25327 9032 -28021 -1532 -27362 -1214 -19072 -3191 -27124 5275 -33439 4660
--37522 899 -32874 -1900 -19895 4377 -19763 7988 -20240 5268 -3083 1741
--32705 23148 -35038 -596 -17003 5957 -12594 13005 -10534 5764 -26759 -7530
--28221 -6364 -28448 -5867 -23431 1015 -26138 -3820 -22653 -6197 -32846 -7542
--37640 2289 -39759 -2221 -38741 -1785 -43803 -4979 -36714 -3365 -20855 -3335
--28835 -405 -27106 7863 -20623 24737 -34330 -4664 -34492 -1529 -30981 3470
--26772 5144 -13720 4730 -13839 3203 -27775 5725 -22860 7377 -38377 -1144
--16778 -257 -16151 -1089 -27183 3390 -27464 -258 -16019 -808 -19892 6409
--19920 5314 -25604 8964 -19319 11528 -26474 12564 -20817 16177 -23574 15564
--19867 1966 -44611 9958 -23432 5594 -32244 8114 -24336 8339 -26596 -3936
--33844 -13504 -29447 -7974 -30435 9547 -36456 -2571 -38962 -151 -35012 -4733
--31271 -2290 -30580 -3272 -35701 -697 -17264 -7575 -30135 -1028 -44145 17887
--34771 12684 -25824 13546 -28851 17125 -25438 15060 -26008 9043 -20496 10522
--9343 -359 -12735 -1233 -12384 294 -16687 4305 -25904 8522 -34330 6175
--17511 -2059 -28148 10347 -36006 7370 -27605 3362 -33004 1401 -27932 5465
--23621 3031 -39451 14054 -43158 20084 -29478 14724 -22161 15337 -24957 11316
--34413 9520 -23507 14863 -37726 8657 -41784 10411 -42113 14574 -35121 8616
--27394 4886 -29888 8497 -24736 8160 -18810 1227 -39840 1776 -28012 4368
--23344 6236 -21327 -5440 -23953 -8783 -22180 -3916 -23820 3916 -20482 291
--46777 -14503 -35746 -7343 -33026 -1240 -24163 -5527 -27912 -9815 -26147 -8729
--37319 -4408 -43243 4605 -44863 8242 -42920 9770 -41637 9891 -40341 9341
--39218 8513 -38475 7748 -38068 7262 -37765 7108 -37440 7209 -37154 7432
--36980 7660 -36879 7829 -36742 7932 -36492 7990 -36138 8037 -35723 8085
--35290 8139 -34874 8186 -34481 8210 -34119 8198 -33790 8148 -33493 8055
--33234 7932 -33016 7780 -32835 7613 -32692 7440 -32583 7263 -32499 7091
--32437 6925 -32393 6768 -32359 6620 -32335 6482 -32315 6355 -32298 6237
--32278 6127 -32258 6024 -32232 5927 -32203 5839 -32173 5755 -32136 5679
--32095 5610 -32051 5545 -32006 5481 -31962 5419 -31912 5358 -31860 5301
--31798 5250
-74: 4991630 -354017 -34253 481 -34184 427 -34098 346 -33991 242 -33865 115
--33724 -26 -33565 -168 -33391 -300 -33187 -405 -33029 -466 -32739 -465
--32573 -386 -32450 -218 -31842 52 -31701 427 -32122 910 -31487 1501 -29980 2192
--29907 2976 -31666 3837 -32537 4754 -30443 5691 -26786 6585 -25063 7323
--27055 7714 -30995 7441 -33771 6023 -33898 2923 -32446 -2023 -24229 -6305
--12653 -10181 -30599 343 -41771 -9637 -25257 -5403 -18306 -2504 -22384 -4747
--30469 710 -20482 -215 -23891 4039 -22631 877 -31916 -2431 -31339 2587
--29020 13172 -33039 -5594 -28457 -6574 -35747 7889 -42618 14412 -41551 6052
--26328 20655 -24513 -1132 -20784 3065 -26147 3310 -28776 -418 -36407 16546
--39848 15945 -30445 6063 -29686 371 -31799 -1300 -28147 -5243 -31129 -619
--31332 -576 -37274 12563 -24252 29050 -27874 21966 -30320 7879 -28082 4066
--27176 5205 -25140 4650 -21004 4524 -20086 4106 -22038 6130 -26789 16977
--28972 20146 -45278 2372 -37759 13802 -40025 14597 -17762 -4374 -26357 -1811
--39738 3859 -31359 6667 -36403 2773 -25645 -403 -39566 3155 -25283 458
--25289 3947 -6158 943 -3652 12001 -25913 4533 -30622 -290 -35561 2680
--40093 -5395 -40433 -1626 -31798 -2355 25 6115 -13423 18247 -31166 -7932
--33514 3317 -25386 11584 -25151 11342 -32549 -1693 -34811 -2006 -26745 -1821
--25605 1709 -21983 7907 -25291 2084 -25622 -1526 -18136 -8354 -27728 8195
--29724 5463 -31922 4114 -30503 2750 -20152 5047 -27113 7876 -20182 13535
--16332 22603 -21415 -62 -24358 -1826 -28821 3996 -28874 12898 -18558 -2239
--12503 -6828 -25696 -3798 -25306 -2180 -23819 -1595 -27033 -2816 -26601 -2855
--35652 -3010 -30329 -2044 -39225 -4265 -39271 -1744 -40577 -4016 -35212 -2240
--29423 -5834 -31705 -3266 -29971 6361 -30273 19282 -23076 -4695 -24067 -2308
--22859 -345 -23285 1597 -15983 3679 -21264 41 -27032 5156 -24095 297 -29558 1667
--21275 -7745 -27214 4768 -13326 5060 -19812 7915 -14591 2106 -15379 4481
--20592 5622 -25298 12167 -16600 12704 -16181 12419 -17915 26466 -25992 13883
--33429 15997 -29849 10752 -37055 5917 -45010 3843 -31312 4283 -29369 -5552
--31142 -7647 -30509 -6173 -35549 2288 -37044 -724 -44534 -1082 -27516 -4015
--24791 154 -23731 3746 -33257 2804 -19689 -7830 -25910 -1097 -32022 6936
--34166 6308 -32881 12031 -22736 4451 -22225 9895 -27726 5867 -31144 9343
--19434 2279 -13422 7378 -15900 3514 -18210 7693 -15088 12095 -27979 9805
--30101 338 -23383 7927 -27668 -821 -31207 5440 -30957 3787 -28089 5923
--28541 1247 -34203 14357 -35388 12398 -27391 11419 -22339 14731 -25446 10008
--39144 7442 -26865 11433 -41509 7847 -42246 16602 -32184 15266 -40178 9343
--30506 6137 -28526 11485 -26095 2584 -28721 140 -52427 7647 -23817 855
--16848 -1591 -18545 2040 -29135 -5474 -12621 -9347 -22181 1158 -32060 3609
--46502 -37 -27273 -4386 -26616 -9721 -16231 -10513 -40579 -1664 -37465 -6259
--37880 -8359 -41870 5869 -42181 9043 -41023 10044 -39865 9987 -38628 9211
--37667 8145 -37138 7242 -36847 6742 -36592 6646 -36389 6812 -36327 7065
--36365 7291 -36365 7448 -36210 7558 -35903 7660 -35515 7786 -35112 7933
--34725 8084 -34361 8209 -34005 8282 -33659 8294 -33331 8242 -33039 8137
--32790 7992 -32588 7819 -32432 7630 -32316 7435 -32238 7242 -32187 7054
--32161 6878 -32148 6712 -32150 6560 -32153 6418 -32161 6291 -32167 6172
--32169 6065 -32165 5965 -32156 5871 -32139 5785 -32118 5706 -32089 5634
--32055 5567 -32017 5504 -31974 5444 -31932 5384 -31885 5326 -31830 5271
--31771 5222
-75: 5011103 -370767 -34551 342 -34493 277 -34422 183 -34332 65 -34227 -78
--34104 -235 -33967 -396 -33812 -546 -33643 -668 -33485 -745 -33231 -761
--33162 -701 -32882 -552 -32440 -304 -32551 46 -32701 503 -31738 1065 -30634 1732
--31438 2499 -33276 3365 -33042 4323 -29630 5359 -25844 6443 -25623 7505
--29584 8395 -34445 8807 -36571 8139 -35298 5335 -34372 -750 -30818 -5315
--2282 -4803 -27877 -3143 -31518 -9086 -40154 -16859 -12956 2326 -23982 -2125
--21169 4626 -29847 -9217 -23302 793 -23822 1392 -35205 3413 -33166 3550
--37486 17414 -31120 -6794 -24735 -7911 -31823 10237 -39310 21306 -28793 12426
--24124 8169 -38280 -946 -18061 14636 -25160 3017 -38398 4300 -35193 12804
--34247 11110 -18559 -1094 -24343 2412 -30286 3565 -37997 163 -36365 959
--29952 -2040 -37417 6605 -28408 20688 -25578 18371 -22255 9110 -30527 7135
--26654 2702 -26891 6325 -21120 4341 -26564 5451 -28228 8559 -27487 10204
--27126 24340 -28288 3096 -30592 1975 -24980 -1978 -31993 9220 -35616 10864
--50061 12995 -14026 -9990 -6942 -23854 -30538 23513 -69850 9649 -30866 -354
--21268 868 -10384 12760 -11903 19687 -18161 -9812 -35505 658 -40357 4382
--44945 -881 -37455 -2445 -27016 3841 -8620 20420 -9233 17812 -28205 -5243
--41356 -2321 -24960 5170 -23278 6763 -29211 -2467 -40169 -3656 -27167 -7336
--34607 -10837 -42798 -15134 -2548 35513 -17018 6071 -26104 -7945 -18990 382
--22985 2900 -24272 2970 -22305 5857 -24092 6288 -29680 8112 -29356 13293
--18845 10605 -28050 3845 -23425 6748 -19000 2000 -24000 3000 -30497 3090
--26018 -1521 -23727 -822 -18284 -2320 -29790 1422 -21664 -90 -25477 -2424
--32786 -945 -35384 -1323 -41082 -3091 -43879 -1636 -36130 -4802 -31955 -8643
--32206 -6336 -26283 -8083 -33970 -3411 -30919 11492 -20949 1443 -22000 -1000
--21000 0 -21216 4388 -21159 -3298 -19272 704 -23110 5670 -23831 3573 -28370 2590
--21264 -170 -24824 3384 -15382 898 -9512 4407 -19610 6749 -16151 7835
--32261 9165 -19673 13030 -9070 32088 -12474 17366 -7226 21622 -31987 5084
--35622 4155 -38418 7996 -49038 15175 -48663 8877 -29060 -4315 -27677 -4465
--31982 -8026 -37519 -3167 -35736 227 -40762 1307 -44119 2699 -21542 -5304
--16611 380 -21745 2740 -26114 -1364 -25661 -1111 -28864 -1939 -20314 2446
--27293 5244 -29251 5036 -24626 6911 -28501 6616 -27073 6672 -33600 4692
--24982 6037 -19360 6993 -22475 7403 -4620 8079 -28947 10276 -16201 6883
--20600 5826 -26498 3564 -28869 2322 -30649 6216 -30903 4954 -26962 4633
--31481 3635 -35553 10914 -32412 7151 -30350 8675 -27986 10727 -18040 4222
--32929 8923 -35774 17026 -40174 12073 -30728 13138 -27059 13479 -42185 12323
--35624 4675 -39456 3286 -32361 1224 -36253 219 -39364 6030 -28022 8527
--18982 -5312 -12003 1980 -12092 -5183 -19923 -6485 -31000 2000 -24227 3316
--51140 8725 -24480 2522 -32785 -11738 -22854 -6243 -31575 624 -46520 -5389
--41541 -541 -42066 2350 -40112 6398 -39203 8360 -38140 8974 -36876 8240
--35952 7015 -35494 6049 -35277 5631 -35190 5687 -35273 5995 -35490 6351
--35675 6649 -35664 6880 -35453 7090 -35135 7329 -34817 7610 -34526 7907
--34251 8171 -33941 8358 -33589 8446 -33224 8437 -32876 8350 -32570 8205
--32314 8023 -32115 7820 -31982 7607 -31898 7394 -31858 7186 -31848 6989
--31864 6806 -31892 6635 -31933 6480 -31972 6340 -32007 6214 -32038 6098
--32063 5994 -32077 5898 -32083 5809 -32079 5726 -32067 5651 -32046 5583
--32017 5519 -31983 5461 -31944 5403 -31905 5345 -31858 5291 -31804 5237
--31741 5191
-76: 5030594 -387496 -34851 214 -34805 138 -34746 34 -34670 -102 -34585 -260
--34479 -436 -34362 -614 -34218 -781 -34090 -921 -33921 -1018 -33742 -1054
--33658 -1016 -33376 -895 -33034 -680 -33219 -371 -33236 38 -32119 544
--31493 1146 -32849 1848 -34320 2650 -32862 3565 -28669 4598 -25742 5753
--27676 7010 -33490 8304 -38646 9451 -38812 9991 -32195 8713 -21868 1980
--39575 -22969 -9976 -14240 -28089 -5661 -35160 -127 -43103 -3570 -12612 -294
--20847 6604 -2914 -11592 -27095 598 -26181 7362 -32600 2281 -51432 10626
--23854 18132 -34605 8105 -32971 4514 -13801 -2129 -47028 16988 -36282 15310
--14615 9819 -24637 5030 -40878 2244 -14385 18241 -26091 -6209 -53165 2625
--28990 8738 -28249 4531 -22834 -1064 -14629 1861 -23255 7361 -41816 2537
--37274 -764 -32081 410 -36547 6626 -30674 15209 -23868 14731 -21097 4299
--31272 5271 -25388 4292 -29952 5881 -22979 5463 -29260 9241 -30528 13404
--32747 9810 -23525 11142 -22954 4037 -22907 1848 -15401 -8510 -37422 6164
--41350 22341 -65176 20247 -7183 4961 -17620 6721 -21153 -7846 -55007 -9882
--44909 -7328 -16356 -4311 -10124 25971 -25777 43761 -20756 -12655 -32529 -8544
--31251 -1775 -34203 -276 -48012 -6421 -30910 3497 -15546 23894 -21063 6856
--13926 2957 -33702 2540 -29314 4608 -24538 5348 -24550 1512 -27860 -6964
--26744 -2632 -28158 -266 -26550 591 -27687 3512 -28046 -1468 -21541 -7850
--21059 -43 -22442 1107 -21788 439 -20377 8643 -21995 11529 -28202 7383
--28938 7393 -31406 10768 -30823 5698 -20920 6165 -24077 4578 -24010 2929
--28553 2417 -26766 975 -17679 -3089 -18904 -3884 -29181 332 -26631 2893
--28662 5105 -31056 2959 -38520 1331 -43026 -22 -45729 -990 -33619 -14102
--29678 -8104 -35524 -11146 -29782 -9246 -30653 -5561 -28775 1905 -22319 920
--24207 3501 -19324 -1432 -16661 6447 -23489 564 -25678 -1874 -14416 2758
--14966 8025 -27406 7494 -25543 1199 -22455 3109 -6599 3488 -15937 5801
--28342 31854 -12991 5579 -46774 7135 -31893 24432 -8574 31449 -3122 12910
--7469 3340 -38108 -10983 -28588 5309 -32095 6683 -42272 18935 -57703 9839
--29261 -6924 -18840 -3433 -26183 -4470 -39539 417 -30987 -48 -40781 -3585
--35664 -1214 -37025 -2599 -21147 -743 -21978 -1284 -25558 -4015 -25734 -164
--19085 1958 -26172 5074 -23884 6300 -19205 3241 -28269 7130 -27717 6206
--18341 5773 -33391 4723 -30389 3077 -22387 4197 -18038 8415 -21653 8977
--18273 3759 -19846 7483 -15087 8476 -25959 5993 -31146 5174 -31251 5913
--32419 2312 -25485 5334 -35202 5733 -35213 10680 -37137 5212 -30313 3600
--31495 4131 -18185 824 -28830 15885 -31255 18052 -33404 14026 -26878 12154
--21991 16405 -45676 14224 -42474 10746 -45524 2258 -39118 -1750 -40680 -2115
--31958 -2567 -29425 1300 -17239 -1249 -7346 2914 -12556 1065 -36476 1537
--16000 1000 -26891 638 -26742 4595 -26441 1716 -49217 2074 -32843 5269
--32354 -4131 -41064 -1393 -43148 44 -46919 2618 -40072 5054 -38218 6404
--37166 7705 -35287 6683 -33997 5085 -33481 4069 -33458 3856 -33736 4209
--34192 4790 -34635 5369 -34850 5856 -34797 6276 -34598 6695 -34412 7162
--34285 7660 -34170 8122 -33962 8467 -33636 8652 -33235 8675 -32804 8576
--32397 8401 -32034 8189 -31759 7960 -31576 7729 -31472 7501 -31428 7281
--31437 7071 -31485 6875 -31553 6694 -31628 6528 -31710 6379 -31786 6243
--31856 6122 -31915 6013 -31962 5913 -31995 5824 -32019 5739 -32024 5662
--32023 5591 -32007 5527 -31984 5468 -31951 5412 -31917 5358 -31877 5304
--31831 5251 -31776 5201 -31714 5157
-77: 5050103 -404186 -35149 100 -35114 15 -35068 -104 -35006 -253 -34930 -429
--34844 -620 -34747 -817 -34618 -1000 -34513 -1159 -34345 -1274 -34207 -1333
--34159 -1320 -33822 -1230 -33537 -1058 -33941 -800 -33703 -458 -32458 -37
--32351 466 -34068 1049 -34908 1720 -32388 2493 -28112 3392 -26773 4433
--30958 5627 -38344 6945 -44084 8256 -44793 9178 -40579 8559 -33713 2700
--7149 -20029 -14955 -13815 -26272 -7464 -28957 -4656 -22538 3109 -26341 2379
--13048 1109 -6227 4579 -22307 2979 -25886 7831 -40809 3621 -39809 20582
--33625 12918 -26301 10538 -24565 2062 -29647 13858 -44041 14573 -50723 14022
--2209 5831 -30144 -1005 -35443 3247 -23019 12256 -23422 3695 -48434 -10075
--35431 13632 -32370 6125 -22922 7404 -20469 776 -29669 769 -26494 2328
--34527 -2950 -33109 3447 -32191 4361 -32252 11983 -20546 10549 -27465 4526
--29903 6843 -29286 6432 -24541 4703 -20565 4839 -29069 10648 -30242 9880
--33429 7795 -28410 8863 -26093 8384 -21385 3689 -22416 -368 -35034 4908
--34182 4434 -70507 7633 -9866 16014 -21056 12228 -6538 -1918 -20147 -14184
--45285 -7139 -26601 -2634 -31256 19373 -24922 29110 -35663 5820 -34452 -2715
--29449 -624 -32592 358 -41287 -4097 -39820 5380 -22372 4767 -11416 9661
--21432 4166 -31290 4687 -26049 7114 -23205 5401 -18533 178 -24180 -4490
--32082 4911 -25945 938 -35995 2217 -30877 -552 -29039 -8060 -21531 -5465
--15988 -727 -17011 2261 -24126 538 -25007 5365 -17724 11069 -25198 7195
--28856 6213 -31743 8639 -30652 9123 -23623 2600 -26938 6230 -23456 5193
--22632 2945 -19903 2610 -22706 -164 -20380 -5520 -32187 1546 -32386 6439
--36377 6418 -33523 6380 -36949 996 -39461 -532 -42922 -4251 -36117 -7622
--37325 -11291 -25719 -14992 -32626 -12812 -18829 -10340 -34583 7838 -22246 726
--22224 1919 -14318 -1090 -18900 1453 -30347 1617 -28945 4102 -17639 3888
--18072 6888 -18724 3491 -25942 436 -24070 5365 -8788 24618 -12069 16578
--25379 17568 -21054 11837 -46963 10723 -34350 18602 -13177 21444 -8414 10502
--14698 3297 -34028 -6285 -25320 4257 -33055 9315 -41937 10383 -38446 6203
--18033 -1688 -20327 -3774 -33211 -446 -44227 8346 -10306 -299 -25374 -13343
--28298 -11691 -49606 3015 -44548 -12544 -27388 -1422 -26815 -3956 -17428 2540
--24243 4823 -24024 5637 -18382 5424 -18083 8770 -31916 6386 -21323 5543
-28269 11382 -55479 -244 -46396 -1107 -29863 1718 -16560 5668 -29000 10000
--19943 6615 -25247 3822 -16716 11472 -28569 1109 -23648 8200 -25486 3420
--31518 -945 -31748 6882 -48423 11963 -30252 7749 -29433 8868 -30768 2019
--35782 -2014 -29446 3532 -15213 13760 -19883 17299 -33715 16279 -26742 6319
--27864 17408 -40942 27397 -51805 12022 -50413 -4055 -42135 -7697 -41950 -776
--27954 -3527 -21019 1537 -18039 -1400 -17136 -2575 -22042 2675 -10369 11146
--23800 496 -19235 3523 -36587 4500 -26407 3327 -40644 2066 -39127 5584
--33312 4837 -37257 7337 -53431 826 -44793 924 -40015 3480 -39751 3860
--36750 6768 -33600 4533 -31558 2201 -31131 1240 -31601 1470 -32422 2338
--33244 3370 -33807 4320 -34025 5127 -34010 5845 -33985 6569 -34047 7329
--34140 8067 -34084 8661 -33825 9003 -33385 9064 -32837 8901 -32293 8616
--31775 8299 -31394 7998 -31130 7728 -30964 7487 -30900 7268 -30924 7064
--30998 6876 -31103 6698 -31227 6535 -31355 6385 -31487 6249 -31608 6125
--31713 6015 -31803 5914 -31873 5823 -31924 5740 -31960 5662 -31978 5591
--31983 5525 -31973 5467 -31952 5411 -31924 5360 -31889 5309 -31848 5259
--31805 5209 -31748 5162 -31684 5121
-78: 5069633 -420818 -35443 2 -35416 -93 -35383 -224 -35334 -388 -35271 -578
--35202 -786 -35108 -997 -35004 -1197 -34913 -1371 -34739 -1505 -34670 -1582
--34614 -1597 -34142 -1540 -34155 -1412 -34607 -1214 -33920 -951 -32745 -630
--33309 -256 -35140 169 -35128 649 -31834 1201 -28138 1847 -28611 2612
--34510 3506 -42516 4482 -47742 5372 -46888 5777 -38801 4795 -23778 79
--6331 -12907 -9886 -7872 -24775 -2801 -27876 -2181 -19197 2896 -23920 3743
--29365 9120 1778 6650 -26659 1666 -25405 5076 -25550 15468 -44646 21609
--34038 13492 -24808 12124 -8894 14565 -45054 7480 -35852 5994 -40560 3589
--24975 2108 -30559 10829 -38467 7136 -25850 -1239 -25934 4553 -41825 1483
--43163 5939 -27867 5916 -27118 5526 -22781 2744 -25640 903 -29186 2270
--25911 4168 -38323 4055 -37115 6017 -24994 3298 -20729 12948 -29434 6300
--23590 8649 -32912 9732 -26297 1603 -22953 3119 -26517 6778 -28466 6304
--31553 3894 -34548 3844 -25023 8352 -16700 2556 -37695 13574 -32081 10098
--37328 12480 -59665 8139 -26627 5136 -36205 -746 -14134 -1467 12287 7383
--30888 -10147 -36064 -2701 -37562 1319 -42437 20213 -27927 16535 -28779 3289
--24814 1285 -31281 4875 -38513 720 -38861 8957 -32844 645 2208 6564 -28326 3914
--33711 3664 -20854 4633 -18667 1848 -30533 1591 -35796 107 -29055 7281
--27234 -1991 -29194 564 -32653 2714 -27996 -11571 -18733 -7080 -4341 -2243
--22819 6304 -30037 6684 -22560 488 -10952 4653 -24494 5998 -28121 6964
--29288 6403 -33959 5100 -29597 3529 -26811 8832 -21437 7592 -20090 7144
--22545 3572 -22603 71 -17254 -2258 -37774 2914 -38649 8314 -39413 7483
--34307 5845 -37461 1281 -37160 862 -41419 -754 -36586 -1302 -30702 -18953
--13699 -9182 -21509 -14054 -21630 -5651 -42992 8332 -15759 -1730 -20651 -7361
--20333 -1450 -26586 -4873 -35591 -2901 -24451 16457 -21805 -3292 -23226 -7079
--15639 4790 -31369 4809 -31751 22264 -14420 19130 -15558 22395 2123 18881
--25337 8508 -36124 4431 -26354 12574 -16818 18403 -20519 12613 -29658 5939
--31360 6576 -24850 7356 -34897 11919 -36524 2554 -26145 5900 -7136 -1267
--21838 -3911 -40691 4864 -41720 20307 1691 -4812 -28792 -25445 -26400 -18187
--38642 -10520 -64496 -14972 -33147 3759 -29108 4632 -23210 -3637 -24838 1954
--16080 11675 -13581 17773 -24909 11985 -36517 2726 -24256 3418 -20450 7856
--19223 -6445 -28401 -1920 -24311 2630 -12816 4153 -26707 10578 -26429 13557
--28311 9368 -22309 5630 -28855 2368 -18168 3924 -19407 -289 -32063 -3485
--43672 5631 -47797 10997 -26165 10971 -25968 6363 -33003 6969 -34779 2636
--34537 985 -16689 6465 -21906 16938 -42651 15739 -29440 -4182 -46518 4748
--48942 2450 -38420 18563 -31525 5661 -34909 -2552 -35195 -2854 -22616 10880
--18829 8709 -26139 5557 -21151 3767 -23143 8730 -16698 -47 -1623 414 -22687 14570
--36121 4103 -33023 6624 -32065 30444 -50002 -18822 -38257 1721 -44379 9818
--50276 3044 -37973 2752 -41301 3599 -40239 212 -37454 6809 -30837 1073
--28376 -1910 -28664 -2306 -30047 -1233 -31504 410 -32586 2050 -33221 3489
--33526 4710 -33726 5795 -33963 6869 -34236 7948 -34343 8912 -34148 9567
--33643 9771 -32926 9530 -32199 9014 -31511 8435 -31036 7928 -30669 7543
--30422 7261 -30321 7051 -30330 6881 -30408 6730 -30538 6589 -30708 6454
--30901 6326 -31094 6203 -31278 6091 -31443 5985 -31581 5889 -31700 5802
--31793 5721 -31862 5647 -31908 5577 -31938 5513 -31949 5454 -31944 5400
--31925 5351 -31897 5304 -31863 5257 -31822 5211 -31776 5165 -31718 5120
--31650 5081
-79: 5089188 -437374 -35731 -77 -35715 -181 -35688 -325 -35652 -501 -35601 -706
--35542 -927 -35456 -1150 -35375 -1364 -35275 -1550 -35115 -1697 -35129 -1792
--34919 -1828 -34517 -1803 -34837 -1717 -34988 -1579 -33924 -1395 -33236 -1181
--34413 -947 -35880 -700 -34895 -439 -31322 -152 -28693 185 -30746 610
--37423 1151 -44956 1778 -48963 2351 -46538 2627 -35557 2839 -13269 4762
--4717 -1058 -20487 2688 -26551 1130 -25999 -481 -7267 2831 -29628 5339
--26948 7991 -12236 6642 -24591 546 -30651 9017 -23549 19978 -37404 14097
--26162 18172 -31162 11488 -23990 11380 -35087 6091 -38765 2328 -33598 3645
--27229 1362 -34217 9918 -35683 5581 -23152 1893 -23983 3562 -33782 4879
--47663 2880 -27549 6028 -31783 9155 -24381 -684 -29907 172 -27893 3177
--27509 8311 -32332 6492 -37035 9906 -23874 7066 -19862 4974 -21535 3057
--23901 8551 -34154 10197 -31499 1408 -26461 3141 -26072 5082 -26007 5060
--26684 2402 -37714 3743 -25665 5078 -13054 1806 -23998 14401 -37245 17436
--50164 12743 -67704 4028 -37373 2428 -25116 2541 2214 2048 -10171 3061
--23890 -312 -39493 3556 -44917 5581 -40236 7818 -27893 13262 -19802 16940
--24971 -15109 -33579 2478 -35285 5797 -33372 16978 -35345 3190 -5294 5639
--30550 11345 -35207 4066 -16374 -2443 -18443 -2538 -36734 3297 -38494 2614
--33838 3331 -25187 -2115 -27831 -2543 -36663 2817 -31549 -5804 -19156 -15313
--1761 -5494 -18303 18735 -28545 4339 -15761 -13113 -4567 11262 -23785 8267
--29337 7210 -29742 7637 -36408 2626 -36693 -1214 -28029 10230 -18851 7637
--15405 14670 -20746 7581 -20062 3004 -20444 -1397 -39513 1233 -42103 4296
--42311 9510 -38435 4824 -38635 5596 -31734 222 -39795 -289 -34661 2331
--27926 -10432 -8295 -10115 -13415 -13609 -23352 -254 -32187 3550 -9675 -6558
--24288 -5012 -22403 -5931 -38555 -6061 -42212 6097 -18230 20119 -20818 -20217
--18282 -18153 -26753 4164 -32447 8649 -25985 17048 -18815 18797 -16221 20252
--5024 19931 -22673 18794 -28003 5445 -21985 13794 -22228 16843 -16739 10223
--39667 9342 -31607 11959 -28352 10353 -37538 3414 -34640 2864 -21006 1361
--10531 -6590 -11977 5145 -39907 6272 -29439 10656 -37908 -7245 -40607 -25433
--14847 -18987 -23874 -7624 -44707 -7576 -42609 -3394 -40349 8065 -29537 1963
--25269 4955 -17668 13281 -11243 16165 -17123 7303 -31714 -2636 -32007 -6319
--25518 -4340 -14509 1928 -16774 6301 -26989 3714 -11207 3017 -21758 11444
--24811 10912 -26972 20506 -32409 1827 -33392 2942 -15127 -1997 -18286 4572
--33693 7506 -45201 2691 -45892 2459 -33422 16726 -33151 -3542 -28161 13649
--29729 4036 -37205 -2721 -42349 4829 -41983 15023 -45210 17554 -20178 -16923
--36308 2538 -37440 -7109 -38864 -1060 -29980 8864 -24116 17492 -24473 6726
--8945 5680 -18401 9345 -36026 13465 -23032 1318 -14284 -344 -17141 13478
--13733 11400 -29245 8410 -30243 2991 -32484 2192 -36317 16254 -37580 8729
--59000 9000 -44241 -1523 -67096 5324 -24004 9395 -29925 5766 -35204 1862
--37195 3754 -26335 -5357 -25544 -6814 -26765 -5782 -29343 -3566 -31296 -1041
--32438 1215 -33155 3161 -33739 4814 -34270 6244 -34672 7650 -34855 9041
--34666 10209 -34021 10844 -33017 10738 -31985 9962 -31080 8883 -30563 7893
--30152 7184 -29885 6758 -29758 6529 -29720 6413 -29761 6344 -29890 6285
--30093 6223 -30339 6150 -30600 6071 -30851 5987 -31082 5904 -31286 5823
--31460 5746 -31606 5674 -31724 5607 -31808 5544 -31870 5484 -31907 5430
--31923 5378 -31921 5331 -31902 5287 -31873 5245 -31838 5202 -31795 5160
--31743 5118 -31686 5076 -31614 5040
-80: 5108770 -453835 -36013 -135 -36006 -250 -35986 -402 -35959 -591 -35917 -807
--35865 -1038 -35786 -1271 -35723 -1492 -35601 -1686 -35496 -1842 -35504 -1947
--35158 -2000 -35003 -1998 -35363 -1947 -35036 -1858 -34034 -1747 -34052 -1630
--35330 -1527 -35994 -1449 -34260 -1403 -31051 -1378 -29714 -1339 -32714 -1216
--38990 -901 -44945 -280 -47188 671 -45033 1237 -33933 2983 -7201 12325
--9015 8326 -18287 6879 -26012 3240 -24595 4578 -8768 473 -31231 7260 -23862 7381
--18437 7843 -31076 -1624 -24670 14169 -32789 18428 -19414 6578 -37364 23259
--34519 8727 -23068 10538 -31729 6080 -36444 1826 -34873 1522 -34077 2000
--34685 7270 -30488 2661 -18368 6594 -29863 5015 -37045 3440 -41671 4569
--31565 6721 -32790 11965 -24755 82 -27986 160 -26972 4720 -26863 10426
--30183 12235 -39057 4178 -22383 4790 -24135 3016 -24171 3219 -21152 4360
--29546 5774 -25496 6182 -32883 3326 -28557 5080 -26645 6592 -24923 4851
--28816 2566 -31045 5343 -20669 7340 -20435 15497 -43656 10298 -71954 3733
--56387 3103 -37176 1147 -27139 8671 -6268 8757 -1752 2576 -14785 4068
--32047 3732 -33836 992 -43541 4426 -35346 12412 -15856 42833 -32999 -33745
--33663 -2889 -31176 4713 -34507 8531 -30502 13237 -16470 13469 -21948 14231
--31780 4116 -21814 -4377 -27444 -2910 -32346 1660 -38152 3571 -32410 -753
--29345 -4236 -33633 -4533 -37627 -3046 -42279 238 -21928 285 -7827 4364
--1451 596 -23119 -1511 -8472 -1196 -8180 3892 -18669 7784 -28261 5954
--29793 2105 -36481 2118 -41288 7970 -28251 10888 -15714 10584 -8885 12982
--19757 6009 -22610 8831 -24076 -2133 -42926 972 -45918 5242 -41395 9021
--39448 5804 -39251 5712 -33018 3198 -51982 -1198 -38454 1781 -15696 15
--3284 -12873 -1645 -18737 -19230 -3659 -23767 -587 -19395 -2969 -19254 -4878
--31104 -6311 -40388 -1341 -43248 5726 -17209 6255 -20278 -20309 -13181 -10336
--26698 -4837 -32540 10815 -15853 14633 -16018 17993 -21279 21662 -18794 16691
--22181 14149 -22668 11735 -24624 24096 -23676 19998 -16717 11102 -36444 9102
--36274 9927 -34380 7305 -38206 2224 -31759 5388 -19763 2283 -11406 -328
--16312 487 -28155 -676 -26280 1096 -15840 2378 -43060 -24620 -22878 -20518
--40265 -2192 -40778 -12619 -42615 -9471 -51409 15010 -37803 6173 -29207 5455
--22450 11769 -7540 11388 -7145 -2986 -16151 -1694 -32233 -13937 -32466 -10758
--23939 20121 -7882 16835 -34752 2686 -5939 -2117 -17796 8036 -27455 8228
--21793 10136 -35444 20075 -28257 3464 -19577 859 -24224 6530 -35626 8835
--39348 -3316 -55700 -485 -40644 10801 -36041 2717 -25579 19283 -28814 -3332
--32985 -6025 -49797 4067 -49092 7526 -52193 6090 -23847 -8062 -37416 3620
--42860 7428 -11596 -6303 -18842 4572 -22657 12835 -19288 6037 -7469 2463
--21148 8396 -36415 13281 -33722 9203 -23137 3434 -11726 5082 -18000 12000
--42436 6968 -4575 2374 -25786 2540 -22550 14289 -22654 14490 -70622 6636
--78645 14356 -40589 -1858 -33706 -1201 -29484 12652 -31200 7681 -37000 1046
--25179 -5847 -23557 -8244 -26626 -7386 -30060 -4613 -32006 -1449 -32832 1144
--33702 3478 -34797 5512 -35705 7143 -35905 8802 -35565 10501 -34698 11895
--33271 12478 -31626 11890 -30264 10269 -29621 8348 -29305 6860 -29234 5999
--29223 5636 -29179 5562 -29163 5616 -29247 5702 -29440 5768 -29707 5803
--30009 5805 -30319 5784 -30618 5743 -30898 5694 -31149 5641 -31361 5587
--31536 5534 -31675 5483 -31776 5434 -31847 5387 -31889 5341 -31909 5299
--31905 5259 -31883 5221 -31850 5184 -31813 5147 -31765 5108 -31710 5068
--31648 5031 -31573 4996
-81: 5128377 -470184 -36289 -172 -36288 -293 -36274 -456 -36252 -653 -36222 -877
--36167 -1115 -36103 -1353 -36041 -1577 -35903 -1773 -35864 -1929 -35767 -2038
--35437 -2096 -35492 -2107 -35591 -2078 -35003 -2025 -34480 -1964 -34866 -1923
--35677 -1920 -35462 -1980 -33564 -2111 -31300 -2304 -31136 -2516 -34153 -2631
--38821 -2414 -42214 -1425 -43610 -40 -32533 6794 -17831 11966 -24758 4617
--16781 13663 -19969 6928 -15601 8407 -16732 4629 -19002 4839 -33515 7142
--29048 9303 -30503 5176 -25862 383 -39300 10385 -20418 16287 -26663 16971
--29519 18882 -33675 11891 -21291 9268 -31267 1682 -35187 -307 -34857 -557
--36540 1218 -36911 3759 -29557 9112 -27171 4160 -31471 5363 -38439 4993
--36000 10000 -26561 3646 -22512 8773 -32364 867 -30567 1165 -26915 6350
--26470 11928 -29513 18485 -34496 1087 -26245 -1318 -31553 -239 -22034 3570
--10754 3898 -36325 6151 -26964 3499 -32094 5074 -29671 5703 -25340 3877
--28371 6492 -28507 6570 -38884 8314 -32593 9162 -30537 15080 -29060 7291
--67554 19212 -56584 -7792 -28772 -13819 -18352 1924 -9304 8105 -9321 8140
--20438 7877 -22203 6750 -30117 7274 -34680 3095 -28579 9773 -33447 14843
--33404 -6215 -34224 1034 -34668 5669 -34288 9833 -28735 7872 -22000 11000
--18000 6000 -22257 7905 -26258 3146 -32343 1545 -32809 3604 -36475 -1013
--35863 -2127 -37763 3333 -33572 -4522 -36811 -7013 -40691 -4144 -23404 -2479
--4039 -70 6057 141 -24538 -5197 -16276 4179 -8472 4480 -18952 11132 -31577 10138
--19799 7699 -39091 12172 -41975 -594 -23976 3853 -10045 2031 -11866 10105
--15256 15060 -26963 12555 -28179 6428 -43861 883 -40607 3673 -45609 8462
--38933 5574 -37211 3411 -40586 6650 -40617 -4041 -51338 -4699 -25305 -12494
-1224 -13408 7698 -9880 -11789 -4274 -32087 3072 -14318 -7347 -27468 1071
--28972 14 -31772 408 -37344 6707 -32270 -11866 -23448 -16478 -9041 -9235
--21701 -2384 -27260 8080 -15115 14111 -11444 17411 -20544 22567 -18903 17701
--24292 10191 -18623 14718 -29676 25873 -22510 21756 -25172 15496 -37231 8099
--37100 12229 -35398 7806 -39656 1829 -32802 -1722 -18182 -3068 -12877 529
--17086 -202 -22134 -4811 -18290 -1759 -29387 3011 -40770 -11011 -34999 -12895
--35625 -6311 -39299 -7471 -36425 -501 -50889 6199 -42749 5451 -29696 1131
--25956 2843 -5904 2011 -5356 -7173 -11404 2614 -25980 -269 -38607 3757
--27467 8116 -17897 9291 -8804 689 -7294 4386 -24551 11368 -31305 2387
--25383 4445 -24430 10349 -19785 11531 -25131 11667 -31981 9586 -38620 3962
--35673 1819 -44784 4479 -49006 16539 -42711 9558 -35576 2412 -35986 -6172
--32042 -10156 -38855 2307 -52590 8615 -48511 2805 -32774 -1799 -28788 -1518
--26668 797 -20825 -1019 -19660 7073 -20908 12154 -25683 4990 -15046 1240
--12888 5566 -38378 1746 -34771 14764 -18164 9001 -13114 2996 -25682 8958
--19372 4187 -9384 9606 -57962 -2136 -50662 -975 -89000 3000 -51000 30000
--8299 20618 -21691 4466 -26449 1351 -30592 5730 -25277 4509 -29831 3417
--24280 -3410 -21055 -7770 -28340 -7552 -31996 -4280 -33262 -591 -33279 1753
--34444 4277 -36422 6695 -37806 8194 -37209 10006 -35890 12071 -34082 13833
--31690 14470 -29203 13275 -27887 10369 -27528 7226 -27981 5225 -28485 4384
--28697 4264 -28715 4470 -28740 4766 -28859 5038 -29075 5240 -29364 5375
--29701 5450 -30063 5483 -30424 5485 -30761 5470 -31059 5447 -31307 5418
--31506 5387 -31659 5354 -31769 5320 -31839 5287 -31884 5252 -31901 5220
--31893 5186 -31867 5155 -31829 5123 -31784 5090 -31734 5055 -31674 5019
--31605 4984 -31526 4951
-82: 5148006 -486406 -36557 -184 -36558 -312 -36552 -481 -36533 -685 -36508 -913
--36455 -1155 -36402 -1391 -36325 -1613 -36201 -1803 -36174 -1953 -35978 -2055
--35774 -2109 -35832 -2119 -35615 -2094 -35167 -2055 -35059 -2020 -35321 -2017
--35361 -2075 -34637 -2217 -33292 -2459 -32267 -2801 -32745 -3199 -34749 -3534
--37089 -3542 -38289 -2667 -38916 -679 -32475 8022 -21432 19467 -18268 11552
--20104 9528 -22605 3322 -16432 9259 -19989 10108 -22548 5294 -34406 6223
--26804 9890 -25582 9042 -26005 6831 -39856 14540 -27856 16211 -25812 12828
--26085 13749 -36486 9892 -26503 5630 -28667 2233 -32972 200 -31893 -1256
--36901 1857 -39972 3554 -30070 4816 -22004 3643 -38329 7050 -39594 4053
--27000 4000 -30698 4143 -27302 7857 -30992 4542 -29439 3209 -24833 8770
--25549 11502 -31549 28551 -22932 -1212 -34343 -8563 -30233 1670 -22505 5480
--24495 6763 -28263 2250 -29407 4422 -31164 3462 -29453 5919 -25719 5524
--25098 4406 -33752 9786 -47006 9040 -36268 6479 -26000 14000 -24839 3824
--68161 21176 -64207 -6791 -21793 -37209 -8818 4101 -7182 9899 -2908 8652
--23551 16946 -30183 11496 -32212 7703 -27495 9489 -36142 6350 -30807 5918
--33361 3746 -36126 3896 -36503 4401 -31824 5560 -28687 3619 -19195 7445
--20125 5193 -17899 7795 -48401 14137 -29789 -4231 -30966 7885 -36687 4784
--38329 -2218 -39305 440 -33671 -1999 -33443 -7806 -42676 1591 -19711 9054
-6452 14988 2911 -8916 -34975 -15588 -23054 11818 -15256 19301 -39099 -5228
--28055 5144 -8670 9650 -17240 12923 -41244 -1290 -23010 4025 -16205 11361
--16307 21894 -10837 15536 -26154 -7470 -29532 -4232 -40123 -3860 -34688 3164
--45179 9806 -38969 9917 -37951 7307 -38484 3796 -37836 -2410 -37969 -3812
--19991 -7411 -926 -9105 11097 -12749 -17252 -4614 -55003 1325 -19569 -7308
--26654 -9495 -22027 5 -19335 3782 -34248 4817 -41134 1621 -19883 -23611
--14183 -17937 -23091 -8315 -28470 5596 -17753 14346 -13555 18071 -17507 21006
--17583 15990 -23306 4583 -26681 18778 -33389 27649 -31973 26855 -13505 5237
--31050 8829 -33921 13862 -32198 13526 -31001 5248 -34009 -4980 -24656 -9377
--13570 2889 -18725 -911 -25132 -5187 -29395 626 -31689 1028 -44164 -4358
--38082 -8512 -31450 -4650 -32525 -2542 -31306 974 -42411 3193 -39960 5534
--26478 -1302 -18644 268 -2627 -9473 -22678 7715 -37810 -716 -3138 8208
--27588 1835 -31528 -86 -25161 11569 -825 10252 -13201 3284 -23932 2926
--30157 1796 -16495 3754 -23388 2592 -30917 9808 -28468 15418 -31726 11718
--33845 5823 -35525 -101 -41739 1928 -11315 8911 -48662 4139 -59871 -948
--48260 1793 -37613 -383 -48944 -2895 -50658 4572 -41926 6270 -27653 3191
--22321 4433 -25171 -3902 -15603 -7234 -21623 4980 -25402 7885 -28969 7426
--23681 -5292 -12029 4613 -28979 7482 -37117 5918 -9642 10013 -17268 14927
--26630 7964 -34866 6448 -21240 11800 -45026 10936 -52007 4475 -71291 3319
--35728 12965 -27891 13730 -23694 5921 -26791 1590 -28609 76 -32015 6683
--21240 3760 -24200 -1878 -16919 -7896 -31175 -7233 -33279 -2796 -33648 1468
--33905 2489 -34342 4902 -37828 8136 -40299 8771 -37930 10745 -35422 13340
--32839 15780 -29390 16839 -25831 15087 -24601 10205 -25112 5245 -26776 2951
--27935 2499 -28367 2865 -28454 3458 -28473 4021 -28554 4466 -28745 4781
--29053 4989 -29453 5118 -29888 5193 -30320 5231 -30707 5248 -31036 5253
--31304 5249 -31513 5240 -31670 5227 -31777 5210 -31849 5188 -31886 5166
--31897 5141 -31883 5116 -31850 5090 -31806 5062 -31755 5033 -31696 5002
--31633 4969 -31556 4936 -31474 4906
-83: 5167654 -502488 -36816 -170 -36821 -303 -36818 -476 -36803 -684 -36779 -914
--36729 -1152 -36677 -1383 -36586 -1596 -36487 -1774 -36414 -1908 -36198 -1995
--36096 -2032 -35983 -2026 -35655 -1990 -35490 -1941 -35517 -1901 -35286 -1901
--34632 -1965 -34058 -2123 -33759 -2395 -33802 -2785 -34068 -3265 -34162 -3743
--33755 -4014 -32480 -3696 -29662 -2035 -25193 3087 -25522 22762 -13662 19383
--40744 7423 -23000 10000 -20483 7740 -22884 7201 -26694 10057 -36397 6815
--21803 14489 -23141 4509 -44571 13573 -31483 17604 -28964 14744 -18890 12517
--28524 12463 -33448 3516 -33043 2087 -32443 4681 -29653 1415 -28278 -326
--36357 -230 -36620 3427 -31324 1718 -25365 7364 -36584 1132 -31051 3504
--25443 -2143 -34557 7143 -29532 6507 -29274 4841 -28321 4290 -22957 12516
--21698 16460 -36300 14299 -16736 13149 -33705 -7399 -33667 3063 -22626 10147
-8320 34270 -69871 -26868 -35934 -2163 -28381 2230 -29682 7263 -29085 6968
--18964 1324 -36274 10782 -40506 10929 -39409 11044 -27171 6215 -28227 3133
--35142 4668 -40340 6354 -49334 -5638 -20200 -8624 -22518 -5667 -22845 1467
--9849 23980 -18717 16831 -35349 8307 -28795 6005 -39260 5018 -30663 8886
--31310 7423 -37143 2852 -38376 3584 -29686 1634 -30822 3539 -23807 7022
--20373 1675 -31361 6753 -37036 6104 -31506 5347 -38629 5924 -33755 5540
--44183 3685 -35783 878 -31986 4902 -18071 -6919 -43016 2720 -32396 9404
-1458 13787 -2975 -5152 -39843 -7861 -28032 8079 -27886 15589 -28524 11119
--10177 -3843 -8137 9317 -11633 7311 -36450 93 -22905 2300 -25319 15242
--29299 27166 -10409 -5451 -19255 756 -31337 -58 -36619 -5121 -25196 -2609
--47611 10599 -33114 6519 -31992 7904 -37117 4093 -29344 -2854 -30292 -4683
--22461 -4657 -13138 -896 9163 -6324 -18132 -6069 -55419 -4580 -43185 -14960
--25803 -6605 -8559 7954 -6378 3130 -27409 -8012 -31437 -3546 -22205 -17689
--20889 -17658 -27888 -10810 -33582 6648 -26767 11349 -17970 15449 -19904 19249
--19809 15201 -21044 -752 -27039 16598 -29923 21830 -27727 17992 -15921 4632
--29957 14636 -31926 15977 -35501 15760 -22128 15580 -26210 2424 -21543 -3998
--16911 674 -25293 -2891 -34485 -5258 -40999 -779 -38906 324 -30785 -4902
--39395 -2889 -30765 -1047 -29294 -1058 -25700 3766 -33232 -1955 -25066 2617
--23317 5561 -21955 10554 -14407 -3663 -15540 197 -29706 2156 -28308 392
--18139 9128 -29147 2594 -29700 6730 -12829 7190 -9171 -1190 -23816 2771
--24827 2720 -9453 7795 -26834 4512 -39224 4311 -28660 7539 -27493 7329
--30693 4023 -29578 -2176 -38744 -2682 -35189 3837 -42077 -2036 -55460 -5345
--41329 9576 -41214 3189 -63604 -1238 -50635 4780 -36487 11896 -19670 8917
--5022 -1763 -32787 -3055 -23780 -1671 -20591 986 -21068 -2239 -11833 5918
--27252 -13672 -25276 -10703 -37119 7098 -25285 10383 -6339 14516 -28929 36687
--21804 25918 -55583 -3142 -30858 5892 -42146 11060 -61060 3423 -61630 17011
--22097 4408 -19754 5836 -22497 6763 -30925 3641 -28319 727 -30780 1358
--26279 2902 -26000 2000 -27000 -9000 -28448 -5379 -31038 6 -30290 3621
--32561 3063 -31790 3591 -37993 9685 -42165 7813 -37130 10509 -34087 13783
--31594 17277 -27191 19505 -21294 17741 -20924 9749 -22428 1974 -25842 236
--27701 775 -28285 1827 -28315 2806 -28221 3564 -28234 4101 -28447 4462
--28837 4695 -29329 4845 -29838 4940 -30311 5003 -30721 5045 -31060 5074
--31333 5093 -31544 5105 -31698 5108 -31803 5106 -31866 5097 -31895 5083
--31899 5067 -31876 5047 -31835 5026 -31780 5004 -31720 4977 -31655 4948
--31584 4918 -31501 4888 -31412 4859
-84: 5187317 -518420 -37066 -128 -37073 -264 -37074 -440 -37063 -648 -37038 -874
--36986 -1106 -36933 -1327 -36830 -1523 -36749 -1682 -36612 -1795 -36440 -1856
--36334 -1867 -36043 -1833 -35783 -1767 -35836 -1690 -35721 -1618 -34846 -1581
--33980 -1605 -34055 -1713 -34860 -1930 -35380 -2259 -34592 -2682 -32486 -3112
--30100 -3329 -28152 -2844 -26099 -684 -23286 4568 -21870 13180 -21637 9973
--31422 12260 -26821 13504 -32417 14301 -35700 13821 -22686 13069 -37682 13488
--26785 15804 -33736 10205 -26481 11725 -27184 8631 -31234 11643 -22889 11646
--34667 12220 -29851 611 -35681 -1010 -35547 3466 -28358 2170 -28196 -191
--31118 2971 -33903 4674 -32025 4447 -29010 2401 -35710 1828 -33290 -1828
--29000 -2000 -25000 6000 -27095 6116 -22715 6110 -30203 7673 -24990 8459
--24876 9143 -30121 11499 -25532 12050 -30852 2600 -29993 7215 -34828 5495
--33795 1640 -35050 2402 -32112 365 -19386 5607 -27990 7036 -28549 6118
--24427 4775 -30846 7345 -34828 11595 -47385 12173 -24393 7570 -26387 6776
--39299 3639 -42180 3888 -40253 3852 -26565 -3605 -33418 -3053 -30987 5053
--5256 19110 -4888 18902 -45078 7190 -30302 -4126 -40871 -334 -24910 7142
--28196 6072 -38795 4445 -44214 2459 -31561 -95 -28874 1699 -23927 1029
--25838 3897 -33782 8875 -31452 5356 -36506 12113 -48709 7882 -42441 8490
--18967 28005 -36584 -6771 -40086 3210 -10327 -10268 -27432 215 -27621 4894
--14592 1210 -19812 -674 -25924 537 -27853 2423 -23590 7479 -21805 6758
--15980 6705 -12772 6635 -12548 4209 -28477 5031 -19812 -2079 -29493 6629
--39397 12180 -18886 1467 -20312 14223 -35769 4823 -25383 8047 -28617 224
--31306 2246 -36212 4625 -31009 6443 -32620 6553 -30916 -4347 -30646 620
--8342 5513 -8677 2755 -15760 -2559 -27906 -6659 -60925 -12556 -35987 -21388
--33000 -19000 24677 4678 -4380 1151 -26106 3048 -25867 -7894 -22702 -14834
--26310 -13977 -36621 -12471 -39106 7542 -34619 7652 -19528 10136 -24000 14786
--20704 8250 -19257 2346 -25966 16190 -24983 17677 -24346 14926 -22108 11116
--27375 10768 -22812 14236 -29113 21583 -30944 16323 -25427 7747 -17807 3540
--19623 644 -30955 1105 -41841 -2363 -41520 -1198 -35010 -655 -21264 -7148
--22684 -10056 -40649 2511 -38584 -2908 -19308 2267 -30400 -892 -26120 2247
--17741 1683 -17607 9976 -19897 9955 -29155 4895 -27238 4418 -19161 1313
--23817 5704 -29022 5983 -28053 3431 -18945 6250 -16887 1949 -25719 1580
--34663 500 -15178 7333 -9289 4944 -31480 3579 -29439 3880 -22117 5013
--32977 1853 -36259 -1241 -34136 -3036 -33726 1240 -50859 1977 -55701 -5401
--55268 5255 -42304 6894 -43000 2000 -50318 855 -33165 5628 -24116 4003
--21401 7514 -22625 -203 -18970 2785 -20501 7023 -16580 -5441 -12424 -9593
--25577 -16714 -35212 -1976 -27310 84 -12882 12712 -39919 21323 -81891 20727
--8018 41724 -19091 11549 -48579 1941 -45212 -5694 -35056 -7796 -40362 7489
--19648 13395 -15203 13829 -30642 14993 -32891 1446 -29571 1123 -34617 -1913
--31302 209 -24849 951 -38430 -1681 -30209 1048 -34276 5456 -9185 -4840
--51522 11280 -17879 -6268 -31567 11032 -45475 4395 -34306 9525 -32049 12824
--31806 17369 -26675 21765 -15323 21749 -17511 9080 -18961 -3080 -24770 -2003
--29574 65 -28119 1646 -27954 2777 -27795 3532 -27878 4020 -28224 4328
--28738 4526 -29306 4656 -29853 4751 -30339 4821 -30759 4880 -31105 4925
--31383 4962 -31595 4988 -31747 5005 -31847 5014 -31899 5012 -31917 5007
--31907 4995 -31870 4981 -31816 4963 -31750 4944 -31679 4921 -31605 4894
--31527 4866 -31435 4837 -31339 4811
-85: 5206994 -534195 -37308 -57 -37321 -194 -37318 -370 -37310 -575 -37285 -794
--37234 -1014 -37168 -1219 -37068 -1395 -36974 -1529 -36799 -1614 -36677 -1642
--36491 -1619 -36100 -1548 -35965 -1443 -36135 -1319 -35631 -1197 -34336 -1098
--33693 -1044 -34581 -1057 -36106 -1152 -36323 -1343 -33893 -1621 -29831 -1938
--26680 -2136 -26111 -1813 -27263 -190 -26892 3340 -21937 7606 -23296 3461
--19125 10393 -35838 21970 -40540 24320 -37781 20079 -31408 11994 -34315 16425
--29763 19656 -17814 2989 -26113 7094 -31905 9479 -31956 12996 -28149 5563
--32882 9529 -30378 2827 -21925 3339 -47247 -1535 -22750 475 -37563 434
--29162 6613 -34179 5092 -30959 4224 -32367 -465 -35351 2077 -33448 -1096
--29933 -2847 -18760 -2850 -23130 6437 -23897 12930 -28953 4288 -27031 4903
--25430 8468 -30550 13423 -30685 12282 -28324 5474 -37090 5872 -33455 4905
--36769 5104 -34027 4218 -31143 2146 -12348 3520 -28617 3587 -29606 3004
--24069 6867 -29695 4124 -60005 8512 -63190 37933 2955 5432 -15598 -13495
--45842 3941 -43440 4766 -27137 8191 -35788 6580 -36694 4336 -37316 7603
--13903 16600 -7961 16900 -30259 9999 -29536 -2290 -36474 -2555 -28842 -862
--26724 2736 -36182 674 -42762 -3515 -35674 -359 -27645 2662 -26547 24
--27438 639 -44032 10910 -37144 12523 -43387 13644 -33651 3205 -43101 8557
--22243 18029 -25846 -451 -29329 -1639 -19267 -1320 -17494 2039 -23505 1801
--21046 -561 -22425 -1330 -23297 -788 -21747 2733 -21053 5483 -20185 4501
--22934 3353 -20472 5495 -17385 8664 -17091 4816 -18796 3507 -22847 6098
--37712 9095 -25706 5566 -30820 12287 -29162 11679 -23765 10142 -28193 4304
--32359 1825 -38922 2483 -28487 1477 -33197 8616 -27782 4082 -25522 1879
--16592 7157 -16418 39 -21215 -1529 -27298 -1741 -27446 -8116 -18095 -26351
--7109 -9226 -5759 -10007 -31000 -1000 -25299 -2766 -22714 -11407 -21469 -11752
--28234 -5535 -43095 -11736 -38818 3357 -34736 5190 -26060 6614 -25082 8502
--22636 6226 -20364 3116 -21184 12512 -22084 19467 -26182 19757 -23875 8460
--22548 2867 -24401 6567 -36650 26117 -27218 18871 -22502 12616 -19257 9155
--28001 6368 -38926 2600 -35921 1813 -38790 1445 -28184 -141 -20912 -3888
--22100 -3744 -22648 -2162 -22824 -4786 -23286 -4703 -41748 -996 -35045 4601
--19207 7395 -10783 4962 -29179 9740 -25937 5267 -25779 5200 -23747 4157
--23211 4259 -31202 1331 -25012 6519 -21427 6451 -24921 5111 -33159 2280
--37920 -1779 -11622 -8461 -4916 8602 -27948 6248 -27197 3657 -21622 2389
--27575 2729 -29767 -1066 -43408 -4728 -45882 -1953 -67786 7085 -37828 509
--57352 7444 -40820 -953 -37000 1000 -45571 3688 -33633 -5381 -25792 7681
--20004 3012 -25925 6225 -13202 3801 -20083 9336 -21011 -6120 -27452 -4938
--24817 -3789 -37606 2682 -39958 7542 -47840 15298 -22635 8514 -34420 13827
--9846 18962 -35554 9421 -33651 8239 -52913 -3031 -41279 -2389 -27671 -1786
--22962 8558 -18598 22812 -30114 11010 -25336 8131 -23460 -1903 -36076 -4568
--28591 1166 -29000 1000 -32636 4940 -29364 2060 -41803 3970 -25055 -1450
--26142 10480 -38218 -8985 -21782 6985 -31881 5945 -36293 9070 -35744 9710
--34472 14390 -29689 20987 -7499 25647 -20017 9009 -16155 -8481 -24854 -1275
--26277 1210 -28449 2624 -26989 3432 -27104 3926 -27473 4212 -28027 4377
--28651 4484 -29269 4566 -29843 4638 -30359 4704 -30809 4765 -31181 4818
--31473 4862 -31690 4897 -31834 4919 -31916 4932 -31951 4935 -31948 4934
--31916 4925 -31863 4914 -31791 4901 -31711 4883 -31627 4862 -31543 4838
--31457 4812 -31358 4785 -31255 4760
-86: 5226681 -549809 -37546 44 -37558 -92 -37557 -265 -37548 -463 -37518 -672
--37468 -876 -37392 -1061 -37299 -1212 -37169 -1316 -36994 -1368 -36889 -1361
--36600 -1297 -36179 -1186 -36186 -1035 -36301 -861 -35392 -678 -34006 -507
--33779 -363 -35253 -260 -36977 -211 -36210 -232 -31871 -342 -26204 -579
--23084 -976 -25256 -1459 -31949 -1488 -36205 433 -24064 6220 -18559 687
--23712 9779 -39529 23907 -50132 22485 -21885 17617 -30934 16824 -31136 18528
--26060 9994 -19280 8451 -29210 9789 -36413 12657 -38918 11217 -28072 10299
--31387 4038 -26404 4448 -30441 4100 -29851 439 -17084 5184 -20657 9606
--47109 -2331 -45341 607 -33049 3629 -33507 -748 -30792 -2188 -31199 -4554
--27696 -4861 -22100 -2548 -23104 6632 -24760 9969 -27723 6294 -26161 7459
--26214 10355 -31475 10102 -33940 10990 -31075 5181 -40848 4046 -35875 7624
--34317 6875 -36394 5708 -22538 4474 -19565 1553 -27125 3815 -29656 1140
--25409 7214 -25735 4450 -26856 3336 -69046 17434 -17954 9566 -23565 3325
--37140 10691 -34014 10083 -37672 12232 -40491 7463 -37834 6161 -38284 10045
--28549 14861 -11330 15654 -25181 15373 -24923 -491 -35474 -2371 -30855 -8185
--22672 1209 -33974 -1558 -44282 -6754 -36417 -2273 -29343 7535 -37616 -5898
--15493 -4634 -59518 14518 -37021 10853 -34729 10393 -29928 6360 -40196 11167
--29488 9687 -21421 4198 -23845 37 -21904 1074 -16283 -1266 -15040 -421
--25489 -1386 -20972 -1836 -22806 -2342 -20804 1162 -18389 6894 -19697 6270
--16881 3754 -25547 5927 -22613 11192 -18984 3553 -18460 11928 -17091 12104
--40254 3039 -25221 5950 -25969 7797 -25433 9915 -27908 9011 -32215 8057
--35197 6237 -35737 6317 -34391 7639 -28848 2505 -30485 7330 -21023 2572
--23522 -2635 -27629 -2075 -26236 -3296 -27026 -5858 -16886 -11807 -13648 -12536
--14842 -17556 -22835 -11194 -23040 -5904 -11437 -4365 -19154 -5809 -23598 -4491
--32915 -2189 -30898 -7435 -34778 1022 -34996 3324 -29950 3128 -27630 2909
--28547 616 -25821 764 -28120 13609 -21799 16837 -21306 17105 -17351 13467
--21277 9634 -23541 21127 -24110 16828 -22927 15012 -24325 12583 -24462 9242
--33492 11064 -39095 2566 -40451 -4392 -37761 2920 -25660 5347 -27039 -6219
--19900 -6917 -21695 -2518 -11509 -2678 -28155 -646 -31784 3618 -27957 11141
--27471 3720 -17555 6107 -19658 10264 -28201 10631 -28256 6741 -28752 10187
--23210 3449 -32845 2240 -27758 1645 -26294 1016 -35638 1652 -32124 1498
--24212 1335 2801 30 -14815 3584 -30309 1602 -24617 -2192 -24448 -5683
--28894 2025 -28831 556 -63344 -23922 -46974 -23768 -42816 8353 -34746 36204
--43013 10044 -65317 -5583 -33212 11713 -43088 2020 -42896 -7272 -25684 265
--14823 -1461 -16951 19860 -26087 12738 -14854 2326 -20441 -2794 -31754 -2034
--30808 2800 -36373 2984 -36278 6685 -40759 6344 -28627 5731 -12244 12746
--36658 15497 -40609 -21 -35435 -3025 -41440 820 -40060 4616 -28984 994
--32060 19347 -28528 23011 -28141 1526 -19605 9095 -12304 6754 -34022 815
--36968 -55 -29163 -2179 -27916 2691 -31416 6071 -33329 4483 -31277 2765
--32227 5359 -27850 -3145 -16832 -805 -26541 4575 -33099 7324 -40314 4566
--33648 7716 -29398 12819 -9012 11075 -32553 14027 -16202 3695 -18425 2588
--21876 3421 -25180 4157 -25406 4468 -26205 4566 -26972 4569 -27722 4552
--28447 4548 -29145 4568 -29806 4606 -30411 4655 -30932 4708 -31342 4756
--31642 4796 -31844 4827 -31961 4848 -32011 4860 -32013 4863 -31979 4861
--31920 4855 -31845 4846 -31751 4833 -31657 4819 -31560 4800 -31465 4779
--31371 4755 -31265 4730 -31159 4707
-87: 5246374 -565263 -37777 178 -37786 43 -37789 -124 -37778 -313 -37745 -506
--37692 -692 -37609 -852 -37518 -975 -37351 -1048 -37195 -1064 -37073 -1020
--36692 -917 -36289 -763 -36415 -569 -36316 -345 -35208 -109 -33911 127
--33952 350 -35797 553 -37238 727 -35116 858 -28936 904 -21854 743 -18511 74
--22861 -1681 -37279 -5678 -51343 -8453 -26708 -4175 -19441 5547 -40273 21211
--24310 27351 -52201 15365 -23897 18632 -28760 17491 -27238 13487 -28723 11865
--28823 11608 -20134 17046 -31348 10830 -42834 7270 -33349 11117 -24015 5040
--19573 7898 -24866 2538 -27050 3452 -26586 -597 -27259 -396 -44312 5942
--45299 3515 -33742 5405 -31247 42 -26664 -6695 -30819 -8975 -25460 -6642
--23743 -3395 -24908 10252 -25987 8143 -26582 7848 -24755 9688 -26139 10574
--32716 5234 -38848 5798 -36158 9772 -46250 9893 -40845 3101 -29587 9580
--33975 7683 -21572 5207 -19439 1496 -24341 3261 -27437 1544 -28902 4497
--27574 4995 -31423 3588 -49531 8719 -25700 5165 -25054 10645 -32566 15716
--34300 20262 -38405 14217 -43860 5045 -36481 6071 -30928 7164 -31520 10796
--30141 16042 -28246 15152 -26127 6683 -30109 -2215 -24038 -6057 -25057 -3034
--33991 -4206 -43669 -4619 -35185 3239 -40583 2404 -38657 -3794 -27042 3540
--43998 3619 -28538 8452 -28132 10242 -44859 2765 -21882 13452 -30967 6437
--31142 3395 -27422 -1727 -20604 -1288 -16497 602 -21609 -2638 -23323 -3024
--12239 -2623 -20881 -2481 -23946 1565 -14633 5272 -18579 10458 -18430 14299
--24978 11081 -22546 7185 -21527 10328 -18655 16694 -15825 12672 -43123 1876
--28206 1733 -18514 3501 -19593 7144 -25972 7782 -34204 7052 -35622 6938
--33886 6652 -35438 4718 -35381 3790 -28022 5141 -23528 3401 -23493 -2147
--26815 -3196 -25032 -7173 -24017 4921 -17268 -11412 -15820 -17653 -19479 -23059
--29608 -20459 -24321 -3067 -12579 2210 -18909 -2767 -20295 -1735 -25982 -3489
--30927 -206 -33417 -3 -33586 1687 -31272 989 -28505 2429 -33807 1587 -33638 154
--33104 8731 -16979 9802 -18159 12164 -8592 16435 -13558 19225 -17754 17828
--15232 13507 -30492 17192 -33595 14446 -30421 12197 -30389 12334 -26046 2214
--35495 -7757 -34518 5230 -30163 10091 -23805 -4036 -11863 -10720 -32722 976
--19592 -1701 -24910 568 -28489 4882 -29347 7110 -31791 10172 -19726 1384
--18929 4080 -26297 16662 -28602 13857 -41000 9000 -17462 4011 -35538 4989
--33000 1000 -32435 -2086 -36565 86 -30614 -3110 -25233 2767 -5358 535
--8009 2754 -21450 -2240 -16321 -11779 -20884 -8605 -40012 12061 -39694 -1727
--57341 -23218 -48056 -20419 -43068 2440 -44571 19731 -54706 5944 -49669 -1221
--21728 42995 -42929 525 -49547 -334 -34683 1348 -19802 6360 -7944 4727
--7615 3058 -14603 3153 -26770 2212 -31932 3959 -32260 4386 -33404 5497
--26797 3201 -47250 7690 -35750 12310 -27655 7066 -31032 3989 -37421 2174
--39892 771 -36049 866 -36674 969 -42443 7270 -17288 18452 -35386 20897
--32708 -741 -11780 2449 -13919 16618 -34059 -483 -32824 -496 -35111 2710
--18860 -123 -32630 8890 -37269 5722 -34000 9000 -36069 -4610 -25696 -1532
--14913 -984 -19185 2619 -32136 3815 -45457 4905 -22989 2587 -19479 3425
--29957 11523 -23680 7519 -15685 4881 -15029 4374 -19194 5466 -23388 5737
--24124 5508 -25339 5196 -26352 4935 -27263 4765 -28152 4673 -29034 4641
--29876 4645 -30614 4670 -31203 4701 -31624 4731 -31895 4758 -32049 4776
--32113 4787 -32114 4793 -32071 4792 -31998 4788 -31908 4781 -31806 4773
--31695 4763 -31583 4750 -31471 4734 -31369 4715 -31267 4694 -31156 4671
--31046 4650
-88: 5266066 -580558 -37998 341 -38011 213 -38009 53 -38002 -121 -37969 -299
--37905 -461 -37827 -595 -37723 -688 -37530 -728 -37398 -708 -37243 -628
--36780 -489 -36451 -298 -36567 -67 -36316 195 -35163 470 -33827 748 -34139 1017
--36141 1271 -36990 1504 -33642 1711 -26239 1860 -18077 1836 -13337 1273
--16102 -828 -32109 -6693 -66283 -17699 -42315 -1636 -24883 4381 -33524 18413
--29891 19892 -41582 17751 -33674 24541 -30593 14259 -28478 14146 -27722 10516
--39626 14105 -19782 16945 -10945 12451 -41882 5548 -43258 10052 -22290 5107
--15030 7513 -25813 7384 -26040 7739 -29944 1122 -32507 2920 -41200 2049
--42057 2065 -28377 9745 -37762 -4132 -25181 -12033 -34373 -12523 -19150 -5339
--21847 -1208 -24562 13595 -25372 6155 -21334 12452 -26031 10058 -28609 10678
--33503 1507 -39173 7225 -50653 7145 -46325 11780 -34913 1884 -33299 9483
--29570 6830 -25120 2381 -18936 2017 -20900 3797 -29221 3005 -27624 2996
--26676 1958 -31986 6273 -32375 8904 -33398 5150 -30920 9229 -43107 12035
--36902 15828 -42180 12930 -39236 7398 -32894 6552 -23564 13263 -40067 12113
--40408 13333 -28947 12923 -23303 9627 -21481 3028 -21762 -2436 -27608 -2697
--32574 -4499 -42121 -3144 -34794 1885 -38990 1753 -36717 -369 -32129 4356
--36458 4950 -29567 7615 -26033 9298 -32365 6406 -32864 7469 -37252 1401
--36646 5172 -25830 -2054 -27832 -3626 -25691 -3990 -24236 -8469 -16165 -6545
--9428 2578 -19980 -167 -32690 3013 -15705 9086 -17973 15003 -13479 14805
--21244 16291 -22138 6094 -23129 10893 -30398 30845 2277 8805 -41251 3329
--41568 874 -29781 7507 -15848 5506 -14968 1634 -22836 -4 -31449 4775 -24354 3529
--25939 3088 -46633 4595 -33990 3340 -26279 3458 -21833 -995 -19514 -4390
--18464 -6999 -26611 4964 -19848 -4868 -18745 -18533 -18079 -22226 -32734 -19212
--37600 66 -15986 2750 -21030 868 -17681 -4436 -19259 -8467 -31405 2994
--32220 -6155 -33604 -7107 -33968 749 -31727 9501 -33498 8657 -32085 481
--18367 1109 -6524 4889 -25001 9211 -21083 11646 -13628 15214 2931 -2513
--20872 8923 -51357 27516 -45112 24615 -34800 19028 -24794 13899 -12958 4735
--18453 611 -29255 5816 -22392 9369 -24764 -5156 -23798 -4012 -26903 3479
--22786 -8976 -22068 2405 -26355 5282 -33326 9978 -32715 3811 -25982 2312
--24676 6012 -29518 14855 -31583 16618 -13129 6912 -25489 -417 -40275 -94
--26363 14126 -40944 -2317 -45770 -2440 -14844 -5106 -50633 -3094 -13265 -3912
--8033 -673 -12143 335 -16144 1731 -17961 545 -44497 -1325 -53155 -6467
--46442 -14962 -42101 -13274 -43021 -1644 -45609 8976 -49176 7119 -41907 9466
--29489 27404 -39832 9028 -54012 15425 -38292 -950 -32227 -4083 -3773 -2917
--1053 5079 53 7921 -32019 7195 -34123 10097 -37204 6852 -32800 5031 -33842 4458
--36426 5211 -27208 7041 -28546 11760 -43366 2521 -44201 -1283 -38559 1136
--37706 981 -39648 1984 -44352 10016 -30729 18515 -26070 13411 -23092 5055
--24458 5120 -14549 10009 -24958 695 -30838 -1912 -32846 -219 -21549 732
--28331 5435 -35580 4159 -41023 4383 -29977 1617 -25000 -2000 -16000 4000
--17726 3753 -29274 1247 -31558 3334 -33455 5089 -16022 7558 -29032 3975
--14990 -2081 -12341 858 -19406 7775 -20428 7792 -24020 6958 -23344 6130
--24515 5529 -25653 5147 -26804 4928 -27992 4813 -29166 4757 -30217 4734
--31052 4728 -31640 4728 -32001 4731 -32193 4733 -32264 4734 -32257 4732
--32198 4727 -32107 4722 -31996 4714 -31874 4707 -31746 4697 -31616 4688
--31487 4678 -31363 4663 -31251 4647 -31142 4629 -31027 4608 -30913 4589
-89: 5285754 -595702 -38214 538 -38225 415 -38227 269 -38217 109 -38186 -47
--38114 -186 -38043 -292 -37919 -353 -37713 -360 -37604 -308 -37396 -196
--36903 -25 -36618 194 -36670 453 -36420 737 -35072 1030 -33797 1320 -34362 1590
--36273 1827 -36483 2021 -32699 2158 -25496 2220 -17668 2161 -12110 1822
--10926 579 -20894 -4863 -88039 -31286 -45965 3057 -32403 10915 -30070 15746
--35011 17103 -43741 17290 -28276 16064 -26343 19866 -24065 11426 -25657 11943
--35065 11598 -14363 6866 -10207 14058 -47942 8490 -54846 11547 -17572 8825
--18940 7381 -29112 13009 -18650 4765 -29155 2612 -36181 4170 -39632 3686
--35855 4470 -28078 11499 -56362 -19332 -42830 -8258 -31058 -10530 -1567 -6758
--9625 1817 -23096 10924 -27413 13773 -19295 12748 -28821 10784 -35060 11427
--38061 7787 -42583 11055 -46568 10346 -32626 3409 -36569 -665 -35054 10972
--30826 6002 -29534 -4405 -18604 -2751 -22052 6478 -35884 6555 -25812 3065
--22948 5356 -31918 3677 -28461 5376 -29865 4673 -35305 6862 -54004 8707
--33617 12002 -46919 11693 -35137 10008 -30856 11134 -26042 12661 -43008 14729
--46386 10572 -26426 10287 -23081 11503 -22785 5418 -19765 2606 -26519 4130
--33544 -652 -38536 -6360 -27238 523 -36187 2670 -34141 2542 -31551 4317
--35575 6219 -34577 6796 -28727 8325 -36907 6006 -35262 3461 -37174 3558
--35538 5191 -28328 1664 -32507 -4892 -32864 -7301 -28962 -11269 -17490 -4576
--6848 1549 -14161 36 -32368 -8661 -24510 5806 3774 17938 -7207 19425 -21126 26861
--36544 11922 -33778 8229 -22336 21591 -5974 15699 -24782 16847 -48040 -3243
--33240 -4050 -11578 -3092 -11184 1106 -14837 7358 -30480 4858 -24054 2216
--26138 8037 -43364 2971 -31705 2030 -27599 1041 -23120 -470 -15115 -3111
--16100 -7068 -24668 -4138 -20773 5430 -25698 -16444 -12590 -15325 -36358 -11894
--46744 -538 -26497 -4404 -18148 -4362 -20375 -10842 -15278 -5710 -27884 -2222
--30017 -8594 -34468 -17733 -39590 -278 -37228 16213 -32166 15898 -25890 1544
--9765 -1913 -3336 3217 -31088 9755 -25350 14201 -20172 3431 -16351 -7224
--39852 5006 -44666 24974 -38636 26508 -29507 20241 -16101 12741 3765 2040
--12825 4924 -29933 9714 -13068 4869 -16949 -5043 -18095 -478 -20673 4132
--29086 2895 -21907 3502 -28622 843 -38566 -2687 -31752 11335 -26980 7430
--25631 6666 -27128 9100 -25584 8508 -12574 5279 -15671 7475 -37828 136
--23831 16058 -37636 349 -37527 -1326 -23066 -4966 -55089 -20551 -20888 69
--30428 5737 -16723 5822 -16520 -741 -29499 -352 -38832 3060 -60749 -3310
--32834 -6417 -35510 -7267 -40754 -1609 -44500 4856 -45104 8068 -39747 13129
--32878 21614 -34411 18710 -36139 22176 -28194 13909 -68557 -16048 -37582 -710
-3753 219 -5586 1243 -20431 9092 -25677 9748 -34677 6955 -31477 6127 -32613 6283
--41872 4406 -28107 6165 -30393 6589 -42994 3689 -46090 1207 -39487 -3446
--33594 -526 -33131 2361 -34395 6249 -33316 15732 -30666 9821 -34546 5953
--23935 2298 -19755 2937 -28510 187 -38631 4054 -31907 -2477 -35135 5601
--28110 -2505 -16716 2813 -31197 4011 -23640 8046 -24649 1890 -18043 -2118
--17174 6055 -24471 5808 -28430 10217 -26288 4830 -21684 6021 -25583 -169
--16435 -2191 -13607 604 -17074 5465 -21972 6651 -20857 6318 -22118 5730
--23540 5307 -25056 5091 -26657 4994 -28268 4939 -29728 4891 -30887 4844
--31685 4800 -32157 4763 -32386 4731 -32460 4709 -32439 4691 -32362 4678
--32249 4667 -32116 4656 -31970 4644 -31818 4634 -31666 4624 -31513 4614
--31368 4603 -31235 4590 -31113 4576 -30996 4559 -30876 4542 -30764 4524
-90: 5305438 -610704 -38422 767 -38433 654 -38440 520 -38430 379 -38393 245
--38324 134 -38256 56 -38112 25 -37910 49 -37809 130 -37552 270 -37057 464
--36752 703 -36860 976 -36480 1268 -34987 1561 -33920 1835 -34609 2068
--36038 2232 -35989 2294 -32906 2206 -27473 1899 -22332 1244 -20704 -17
--26804 -3212 -35890 -6937 -53716 -15120 -38966 4536 -34156 10910 -35065 12093
--27714 15604 -35903 13992 -32231 10578 -31230 15236 -20386 8978 -24764 11365
--28617 7725 -17976 18009 -22473 18575 -39557 6984 -46125 2275 -26677 16151
--25453 5389 -21238 7008 -9214 -934 -35429 8789 -40499 7800 -38917 7209
--28587 9776 -27880 7891 -52107 -14961 -52356 -12739 -25320 -13228 -3399 -3905
--8075 -2025 -23488 2616 -47502 25709 -22651 7601 -30186 12358 -34414 11655
--41411 14540 -42444 10926 -42924 8145 -13821 3580 -38542 -1250 -37309 23455
--31937 10852 -7249 -13222 -46123 -8927 -39203 2805 -23335 3898 -19781 11229
--20292 1101 -35370 2660 -30278 5255 -32299 8319 -29016 5968 -42893 9829
--39661 13889 -40593 9032 -41562 5544 -35267 19735 -33226 13425 -38498 11682
--39579 6064 -29945 8613 -28769 12883 -27813 7330 -19057 5929 -27503 12974
--34850 4407 -37001 -14122 -29348 214 -30580 3899 -30316 4601 -31017 5314
--35488 5810 -39123 5248 -35846 3897 -34255 5385 -40180 3629 -37194 3588
--35788 4240 -31452 593 -27000 -1676 -32386 -3600 -32434 -8049 -24729 -3293
--12347 43 -15870 2930 -25329 -2068 -52207 -3663 28443 -5988 22778 19439
--38857 92526 -52131 -2763 -39836 -16327 -13762 9048 -21262 28269 -5367 25299
--42727 -8664 -30934 -8918 -18322 -7219 -9306 3249 -6272 556 -26212 3354
--36686 -231 -30610 8430 -27521 3248 -25424 -3840 -25585 745 -26980 4046
--11534 743 -12766 -5818 -28197 -6989 -32080 -3067 -30537 -6723 -19530 -9258
--19905 -6177 -31908 -5734 -29762 -12866 -24202 -7764 -22237 -14174 -25593 -7210
--25205 -5171 -26349 -3265 -35153 -29539 -46934 -962 -43598 20086 -31668 15945
--19187 5313 -12387 -3470 -7829 4813 -27916 11087 -25675 12087 -27212 -2903
--31666 -6081 -64807 2547 -34620 23875 -24716 23052 -16448 13530 3380 3033
--5031 2202 -10206 9400 -13776 12033 -10335 6600 -12037 2289 -16601 11732
--17969 3236 -18693 5400 -30397 2127 -35496 3507 -37289 5739 -29934 4862
--24735 3525 -22708 3242 -22329 3945 -20521 3679 -15115 4150 -11854 15177
--30947 5849 -32311 7549 -32892 2818 -36657 2534 -30203 1542 -33918 -2114
--34168 -3587 -58412 -6265 -26146 -3098 -19360 2372 -23479 4088 -29374 3641
--41711 -685 -34391 -1845 -39932 -4216 -44066 -1006 -45832 3768 -44483 8306
--39983 13572 -35152 19022 -33908 20139 -34673 20046 -37829 11685 -57567 -5976
--41863 -3491 -16592 -3099 -21689 847 -18467 11961 -27000 3000 -28867 3479
--30196 721 -29510 5588 -30947 10787 -27555 4378 -36511 6186 -43349 3572
--49254 1522 -41600 2456 -32209 -2005 -24351 -1050 -35073 -7487 -42765 15693
--39859 11267 -33353 5462 -25601 -5569 -24680 -2185 -23146 1570 -33053 8178
--33919 8062 -36310 735 -25520 8129 -20012 6601 -27172 1572 -14523 7270
--14325 2387 -23544 3149 -19048 5369 -24820 4523 -27818 7254 -20110 4386
--22747 2791 -23081 4268 -17128 1748 -14629 1931 -15884 3843 -17176 4644
--18610 4647 -20517 4546 -22700 4620 -24957 4826 -27166 4995 -29155 5056
--30723 5022 -31768 4941 -32348 4851 -32607 4770 -32673 4709 -32636 4667
--32543 4643 -32416 4629 -32264 4616 -32097 4604 -31921 4589 -31740 4574
--31563 4559 -31390 4545 -31228 4532 -31084 4518 -30951 4503 -30830 4488
--30707 4472 -30595 4456
-91: 5325119 -625572 -38620 1027 -38640 926 -38646 808 -38636 687 -38600 579
--38534 493 -38468 445 -38307 443 -38117 495 -38013 600 -37732 761 -37214 970
--36931 1220 -37080 1496 -36455 1785 -35068 2064 -34282 2310 -34541 2492
--35503 2570 -35686 2485 -33829 2157 -30282 1470 -27445 266 -28746 -1604
--38201 -4544 -45543 -4829 -17394 2165 -31121 4214 -41677 7769 -41259 10348
--21941 19255 -23515 8188 -40100 5615 -29982 8896 -28131 8253 -21290 13026
--24245 10476 -14956 19438 -36725 15673 -46684 13482 -34126 5856 -26262 1505
--25782 6563 -22722 6142 -16589 1906 -31388 6586 -38011 5548 -35733 4293
--25166 10274 -25038 6401 -35722 -7781 -48603 -12555 -29958 -5109 -21711 -6717
--22066 -4339 -31098 2063 -38676 18922 -30863 12426 -33902 13606 -50784 18883
--33896 8819 -45281 -1994 -21204 11331 -13469 5499 -33198 3981 -34895 11205
--34116 5281 -22215 2846 -32022 352 -43484 -2591 -17906 2585 -12087 7332
--23272 6555 -37007 3639 -36124 6248 -34914 8305 -26993 5287 -29768 6345
--35932 20777 -14461 7067 -68198 -4907 -50054 25069 -35092 19281 -34789 9409
--32402 7140 -29840 10782 -31415 11101 -12576 23171 -36229 6159 -34111 12412
--39446 9517 -39516 -22314 -30387 -1254 -26683 3646 -26687 5313 -28948 5892
--33614 5042 -39613 2933 -41700 1801 -42826 3384 -40532 4346 -35219 1850
--33163 2222 -30317 399 -29804 -2456 -31419 -1776 -35827 -168 -35291 603
--15402 -1597 -22086 8594 -27575 5289 -39846 5483 -41956 7765 6262 36558
--25674 52005 -11407 3275 -39567 -12789 -7575 11563 9795 23047 -15247 -4556
--29863 1976 -30638 -4591 -19695 -2916 -16242 -4243 -15477 -11685 -16599 12576
--36239 -3295 -28870 -24 -22094 3676 -20416 -7286 -15115 -2543 -30291 7607
--20697 -1445 -5453 -5608 -36567 -4658 -28073 -641 -21151 1668 -31920 -17537
--21020 -9587 -20774 -1908 -23739 -12809 -21905 -15483 -29277 -8855 -28732 -11461
--26645 -8529 -26136 -3684 -39888 -5905 -47383 -2465 -51077 2376 -32471 3638
--12414 540 -20436 1942 -8648 16254 -33047 8834 -21089 6725 -18677 1662
--43648 947 -73060 4609 -35029 15278 -15308 12808 -3918 1217 9557 -724
--5935 17854 -8643 15640 -6711 9770 -11631 4842 -12727 3171 -17733 9948
--17782 7838 -26129 9953 -31027 8950 -26623 6864 -34762 4708 -22812 -1544
--19652 -1526 -17941 -255 -17166 1333 -16530 3130 -15649 6354 -19654 13462
--35717 13916 -35134 11264 -37320 6319 -41235 894 -33350 1954 -34765 -1570
--30796 -2613 -36828 -3430 -32656 -16629 -20996 258 -16737 10187 -29849 -1547
--35976 467 -32278 7422 -44575 422 -49803 332 -48504 4191 -45674 8269 -41352 12739
--37346 16640 -35707 18010 -36780 16565 -40973 10047 -48446 293 -40834 -1840
--27668 -1893 -25109 1105 -22136 6203 -28745 3708 -30000 3000 -27714 486
--26994 3909 -23483 6792 -29245 5616 -45656 5491 -46392 8715 -55382 4984
--45134 1007 -31809 -8808 -24551 -2514 -42467 -1299 -37049 10022 -50903 8079
--27157 5674 -38884 2721 -31180 1125 -31992 687 -10414 6114 -20601 5587
--20084 -986 -20367 5108 -26983 10792 -25458 2445 -18772 -706 -16306 4033
--16283 5278 -20643 7063 -26009 4569 -21774 3690 -18659 6248 -24096 6320
--24616 6113 -15191 3680 -15819 2638 -13995 2747 -14409 2674 -16041 2626
--19083 3004 -22545 3734 -25762 4536 -28498 5034 -30605 5191 -31954 5128
--32615 4982 -32834 4833 -32850 4715 -32795 4635 -32706 4596 -32581 4587
--32423 4590 -32241 4591 -32043 4581 -31839 4563 -31634 4539 -31432 4514
--31241 4490 -31062 4469 -30907 4451 -30767 4432 -30639 4416 -30519 4401
--30408 4386
-92: 5344800 -640320 -38818 1319 -38838 1231 -38846 1131 -38842 1033 -38801 950
--38745 892 -38682 871 -38504 896 -38333 971 -38229 1095 -37934 1270 -37376 1487
--37201 1738 -37203 2010 -36488 2287 -35480 2548 -34521 2770 -34257 2917
--34923 2944 -35594 2788 -34670 2360 -31882 1546 -28981 230 -28320 -1595
--30221 -3486 -30914 -3623 -28682 3521 -37527 5917 -44644 14462 -43997 6586
--30074 5057 -26035 5448 -29441 6473 -23830 8002 -31845 9138 -22854 14688
--16535 9898 4324 20816 -52794 -4719 -64941 22341 -28413 13207 -23128 4539
--26675 6545 -22701 6016 -22876 6078 -30306 7207 -36155 3630 -33301 1792
--20935 4115 -21870 6261 -28062 -1625 -45882 -11992 -33248 -1060 -32918 -4328
--29472 6 -42416 4999 -34081 12853 -39014 15135 -41988 13423 -31890 11091
--31171 9103 -29167 6572 -25653 7545 -21209 7402 -34013 3858 -30148 7256
--29698 5827 -33222 2560 -36985 -2306 -33958 1589 -22553 4051 -19004 7550
--23881 11145 -32180 7048 -34045 3231 -31527 6265 -32744 1869 -27792 2210
--21791 2452 -22708 6889 -61993 23879 -59946 22516 -31906 15628 -35105 12350
--30371 15989 -36182 35293 -27966 1368 -23227 -1531 -25949 8686 -37462 5152
--44627 -3789 -35993 -2252 -33327 4187 -25183 3862 -24568 5833 -27705 6928
--33414 5081 -40048 2657 -47287 1256 -49554 -252 -35926 2147 -40383 -510
--30304 1185 -32133 -315 -28783 1609 -31149 1731 -36594 2198 -47457 218
--10578 -5932 -12694 8212 -20728 10720 -29000 27000 -62017 3400 -38983 20600
--31000 19000 -11177 22935 -10248 12471 6136 11368 15190 10829 1099 -3603
--38000 0 -33958 2359 -15042 -3359 -30607 -1757 -14564 -6972 -18742 -5885
--34087 -9386 -27448 -5940 -23552 -7060 -14607 -2118 -12992 -3218 -24908 4086
--18669 3515 -9169 2740 -37214 -7826 -22145 -9389 -18883 -3871 -38720 -11988
--31131 -4502 -17813 -1464 -22662 -15540 -19822 -22083 -33127 -580 -28594 -18223
--26474 -9275 -22810 2177 -40578 -3432 -34226 -4117 -54010 -9272 -39963 -4980
--7545 5464 -25890 19626 -16930 3613 -32955 16362 -25218 2090 -19609 1348
--46462 6652 -51351 17320 -44370 7648 -12995 -875 -2140 7143 -4674 13091
--8786 13029 2247 13051 -2161 -2620 -4996 1282 -16982 5653 -23813 8387
--23935 12000 -16574 16949 -22337 8778 -21664 9652 -24941 3720 -22486 -3472
--17607 -2830 -13987 -1011 -12923 1305 -14882 5105 -19063 11482 -24222 14500
--35916 7258 -36606 15143 -37672 10996 -38908 2711 -34182 3245 -41459 -7484
--40786 -19966 -24897 14893 -22630 -8624 -31229 -1317 -25947 2063 -27000 -1000
--30321 -120 -27228 6036 -44527 6263 -49810 4525 -51217 4674 -46410 8256
--42358 11576 -38898 14320 -37365 15267 -38191 13756 -40887 9284 -43298 3558
--39112 784 -31822 209 -27950 1650 -26606 3962 -34000 5000 -30000 5000
--19302 1899 -22917 4377 -25781 5724 -33000 3000 -48015 -1117 -50716 146
--55678 6159 -53284 3217 -37828 913 -26861 921 -43391 3087 -36178 8447
--44851 1461 -26322 2321 -32084 3605 -28926 4146 -22210 4871 -22455 3929
--25008 2119 -18008 6611 -18348 1021 -24079 3168 -28262 4420 -21544 3001
--13265 -3176 -14435 4256 -20202 6353 -27723 3777 -19339 4320 -15843 8286
--23145 9738 -14663 8917 -18607 3705 -17242 3007 -12584 2203 -11469 1003
--13240 588 -18309 1432 -23573 2916 -27659 4467 -30532 5229 -32356 5358
--33110 5163 -33156 4906 -32959 4697 -32819 4559 -32771 4486 -32712 4482
--32579 4525 -32385 4577 -32160 4608 -31925 4609 -31695 4584 -31470 4544
--31252 4499 -31048 4457 -30862 4421 -30700 4392 -30557 4366 -30426 4345
--30308 4329 -30200 4314
-93: 5364483 -654959 -39006 1642 -39029 1567 -39042 1488 -39042 1413 -39003 1356
--38959 1325 -38894 1331 -38712 1379 -38556 1472 -38459 1610 -38137 1790
--37611 2007 -37467 2251 -37272 2510 -36758 2773 -35964 3020 -34682 3230
--33926 3374 -34649 3416 -35699 3306 -35093 2981 -32225 2372 -28587 1438
--26232 262 -25792 -739 -27387 -466 -35432 3506 -41022 3976 -42019 6086
--28192 5961 -49635 7322 -27136 4845 -29993 4934 -25140 6695 -28868 9906
--34707 16259 -11389 687 -7976 10248 -37100 6036 -42506 21831 -37294 9069
--30620 6468 -28983 7429 -25607 7716 -25441 10085 -29731 9675 -36236 1167
--32364 -5706 -20478 5129 -14570 12566 -17872 8934 -40843 -5234 -32839 -2142
--26273 -1815 -41287 -6644 -56080 -12 -41710 12637 -35841 18695 -34199 11682
--27994 8644 -34230 6805 -26707 7410 -29392 4535 -27716 8058 -32622 6647
--29149 6144 -30128 8565 -36777 987 -34716 -204 -34448 1839 -30968 5118
--26142 9852 -27928 11460 -23809 3705 -27098 6780 -24907 6514 -37707 1417
--24842 -1943 -23264 1712 -44364 15437 -40952 17406 -45302 22232 -34100 20939
--39510 16866 -36250 18354 -35192 21758 -36799 7860 -29779 -2236 -28294 5007
--33773 1813 -38255 -1051 -29235 -342 -33797 3499 -27713 5733 -24718 7160
--27968 9411 -36003 7997 -44457 6430 -51463 1894 -49686 -6183 -36621 -2791
--35713 -1193 -33145 2008 -30491 2928 -29661 3350 -33596 3158 -41512 3108
--49589 3403 -39624 2653 7765 6303 6684 8743 -9260 9161 -60827 15135 -42130 10077
--32593 10951 -18910 13642 -12134 12858 2760 -541 -2418 12644 -6247 14486
--23185 1024 -27807 2839 -27509 885 -23247 -10267 -20229 -5288 -22841 -1408
--32746 -4989 -30421 -8178 -27432 -14407 -8959 -5348 -10747 -5444 -17930 -1085
--16599 1351 -6439 1845 -30534 -9700 -25047 -14910 -14915 -2538 -29753 -2121
--49475 -9278 -15392 -9962 -16261 -8245 -26386 -12458 -28809 -16250 -36827 -17459
--27337 -8156 -23851 8076 -39096 -555 -41156 -2856 -42956 -15582 -38267 -6850
--15922 7768 -5344 40383 -34012 19693 -53070 -16782 -24156 3573 -26360 -1010
--43751 15230 -43673 8713 -32709 8181 -14553 1458 -97 7100 -5441 11292
--5260 13463 -563 6902 -4269 -1482 -10658 7278 -18945 -2085 -21587 7987
--19938 12601 -12779 21383 -20368 7681 -15386 5172 -19236 3789 -20165 1479
--14631 982 -9183 1254 -7843 2399 -13083 5678 -24809 13586 -24510 15899
--30047 16497 -38089 16634 -36679 11833 -33627 3550 -30795 2755 -39817 -13066
--40300 -19211 -40172 9564 -34371 -6276 -31357 -548 -24485 3760 -27818 1725
--31860 -7316 -25699 9357 -46028 7322 -49096 5599 -50016 5046 -45484 8096
--42121 10489 -39323 12365 -38053 12941 -38523 11764 -39909 8852 -40400 5324
--37805 3042 -33691 2313 -31066 3009 -30845 4619 -35410 5735 -32161 4723
--13073 2651 -24927 4349 -30000 5000 -34242 4808 -44909 4661 -58613 7034
--53872 3663 -52580 5123 -39229 1530 -35555 1181 -37338 591 -33005 1491
--35728 896 -33229 -3643 -24760 1275 -29283 2987 -28101 4580 -27432 3777
--25887 894 -25252 5017 -17985 8135 -17365 -4100 -25167 -65 -25779 1660
--7165 645 -14554 4086 -18661 4834 -23607 10260 -23175 572 -4982 2117 -27717 13522
--14109 7118 -22017 8447 -15891 5819 -9717 3038 -7566 -180 -9593 -1346
--18614 93 -26106 2350 -30496 4894 -32840 5636 -34048 5497 -33878 5026
--33150 4632 -32604 4397 -32527 4277 -32711 4240 -32756 4316 -32578 4464
--32278 4607 -31965 4691 -31681 4705 -31431 4668 -31203 4599 -30991 4523
--30791 4452 -30610 4391 -30451 4343 -30313 4306 -30187 4278 -30074 4257
--29974 4241
-94: 5384174 -669503 -39184 1992 -39214 1935 -39233 1875 -39236 1825 -39202 1794
--39174 1790 -39102 1819 -38930 1886 -38788 1992 -38701 2137 -38354 2315
--37912 2522 -37695 2751 -37365 2992 -37258 3236 -36392 3471 -34756 3683
--33970 3856 -34788 3969 -35859 4003 -35086 3938 -31960 3766 -28061 3517
--25472 3290 -25239 3269 -27905 3623 -35439 4171 -46420 5353 -27836 6785
--15127 -3193 -52693 14456 -41976 431 -33147 638 -31380 2680 -28641 2243
--33611 13045 -15637 -3033 -13534 3817 -18391 11234 -39439 9245 -38874 12737
--35130 12321 -32278 11281 -27893 10586 -27567 11005 -31169 9626 -36928 5410
--31709 -7775 -16487 18979 -20234 7772 -26798 10443 -34402 -357 -24194 -479
--19910 4561 -41603 1214 -38084 -20124 -50802 10585 -35980 16432 -33436 14394
--35076 11386 -29212 3027 -31448 5235 -36402 5238 -34886 9574 -27495 11142
--33107 9316 -31548 11104 -43060 -9240 -25778 -4327 -40610 -2962 -34745 6954
--24738 8321 -23118 7554 -26479 4551 -26772 7113 -21051 5684 -27726 2382
--31368 4915 -26208 3639 -28735 24235 -36947 21505 -41419 23486 -34921 22322
--49479 17474 -42612 16984 -30771 11026 -51771 8247 -34169 -7486 -29560 2696
--37378 2679 -34235 3151 -21560 -3454 -32649 4165 -28132 7179 -23706 6219
--26407 8306 -41094 17148 -47071 12921 -53118 1291 -44173 -6511 -37428 -6723
--37993 -2999 -33088 7797 -30293 3958 -30357 3696 -34685 2910 -42631 1379
--47375 1644 -43623 5677 1583 18124 10765 15456 -7737 5104 -46127 7530
--39563 3918 -41712 11139 -34905 24713 -12845 1602 -1682 -4617 -4237 7782
--133 -379 -20602 -3914 -12001 -4290 -8855 -970 -32401 -4402 -36441 5942
--35441 6959 -32727 236 -26835 -8537 -14602 -12871 -9095 -14116 -13543 -13361
--20175 -8122 -23071 -10680 -856 5459 -19874 -4894 -18654 -12347 -16001 -11054
--29705 -2041 -44111 -15902 -28964 -11284 -21890 -6268 -36343 -2879 -30962 -5620
--14640 -12170 -33313 -11509 -30117 -1561 -35463 -2039 -33873 791 -39837 -7366
--39529 2603 -25876 8816 -39759 23919 -29952 12669 -37540 -5900 -26826 982
--25724 1896 -38456 7278 -33879 11986 -28105 6055 -12977 1036 6358 4670
--5878 4447 -7760 10307 -4633 10801 -5519 1894 -13081 -495 -15580 6123
--20221 10470 -19377 20516 -16376 7170 -16542 9226 -13941 5086 -18681 2798
--20526 6481 -11153 5980 -2847 4771 -71 4300 -5470 6136 -26201 14667 -31602 16602
--31821 18880 -32416 19640 -37470 13590 -34152 2624 -35298 -883 -37516 -3457
--58000 -6000 -32376 -8875 -32986 -9488 -40288 -5968 -33768 -2677 -21775 -5662
--28043 1981 -38557 18327 -42588 6987 -44974 4803 -44078 6630 -42709 8221
--40609 9807 -38697 10954 -37843 11225 -38148 10367 -38797 8483 -38611 6235
--36937 4545 -34818 3814 -33846 4038 -34773 4762 -36479 5344 -33558 4720
--24183 3774 -20802 3977 -24799 4562 -29691 5129 -39023 5981 -52025 7491
--59468 7148 -64723 8983 -42209 3738 -35963 3045 -38050 -605 -31170 -1845
--34636 -3951 -29601 72 -6056 -2809 -23916 4342 -53382 -10810 -35576 1513
--28853 7336 -25288 2148 -13328 208 -11667 2515 -24153 1038 -25423 2071
--3955 4628 -21239 6098 -19504 4495 -19233 7096 -21065 7700 -11510 4166
--25486 4567 -20162 8375 -20128 7562 -8488 7145 -5116 4267 -4332 -1007
--4096 -3034 -20901 -626 -30244 2001 -33600 6104 -34582 6051 -35406 5418
--34002 4553 -32396 4084 -31689 3927 -32068 3880 -32847 3874 -33012 4082
--32611 4413 -32041 4700 -31556 4858 -31211 4886 -30969 4821 -30778 4709
--30608 4586 -30446 4473 -30292 4379 -30153 4307 -30029 4252 -29916 4213
--29816 4186 -29729 4166
-95: 5403882 -683964 -39355 2369 -39389 2328 -39418 2291 -39425 2266 -39397 2260
--39382 2280 -39316 2330 -39151 2412 -39028 2525 -38941 2667 -38604 2836
--38276 3025 -37787 3229 -37757 3445 -37674 3666 -36694 3885 -35134 4102
--34393 4315 -35151 4523 -35953 4736 -34881 4976 -31695 5291 -28106 5759
--26046 6492 -26423 7556 -29799 8647 -37385 7853 -43653 -3436 -19780 4194
--12258 2696 -33915 7739 -46362 7566 -48766 2344 -40246 -553 -44526 -72
--26107 -11288 -11921 -7765 -7879 6606 -13773 -1133 -38451 7557 -36562 21870
--36581 18930 -35943 14849 -28773 12345 -28683 10898 -31872 6831 -42130 1765
--27887 15277 -15233 19696 -23546 5578 -36392 4190 -71578 -4777 15654 1218
-13191 1634 -41516 -1462 -54339 12731 -46088 -846 -40446 5734 -31825 11674
--37349 12704 -24787 7606 -32289 6642 -40355 7658 -40682 10254 -28979 10080
--33213 10871 -31525 7569 -37585 -4784 -13228 -14279 -58376 -7417 -46407 1119
--10374 12606 -30649 9717 -35351 4340 -21379 2776 -24636 2530 -24295 7211
--32959 9600 -27376 -4394 -20705 32582 -22310 35792 -27269 26540 -43829 20028
--54388 20356 -50080 17490 -39566 10976 -49099 -9640 -37257 -4902 -33749 344
--36921 2286 -32517 -1886 -24435 -803 -29409 5367 -28040 5402 -25564 5033
--32889 17043 -39947 22190 -43706 17390 -46956 1813 -39845 -5995 -34801 -8043
--37829 -5334 -39753 8183 -32553 6671 -31750 4913 -35555 3310 -42935 90
--46036 2949 -40568 8676 -13336 23295 -1630 18301 -26235 -5153 -19372 -144
--25875 10059 -40857 -3013 -26589 2250 -27114 6761 -9544 1769 -4160 184
--5179 -1721 -16792 -7987 -5826 -8779 -8494 -934 -38721 8393 -28575 11903
--38096 -5689 -23903 9417 -13529 8900 -12683 -9543 -11360 -19565 -15748 -19075
--17753 -7132 -18454 -13431 -20352 -4247 -17316 -1219 -15138 -7091 -21262 -7241
--29855 -7467 -43301 -8810 -39686 -11657 -27182 -7895 -26413 -9457 -31673 -10871
--23916 -5737 -38963 -6673 -24942 -1174 -26133 -353 -31121 -1323 -29171 1111
--34010 7751 -36257 8399 -47749 11561 -37636 815 -34201 -524 -32206 5035
--29138 -740 -31724 3979 -21058 7771 -24812 3400 -12821 4757 3581 2339
--3553 -170 -8053 6028 -9195 11717 -4894 6888 -8537 5859 -17225 5157 -17721 6268
--9704 11151 -9717 15345 -24878 13137 -21614 6573 -28710 1622 -19620 8447
--5867 9234 3927 7628 5782 6411 -2594 7418 -25612 9707 -33703 13984 -34640 15854
--32928 17158 -24342 11730 -43797 6912 -45675 6404 -26081 -1185 -47673 -8228
--33747 -12090 -29351 -7303 -44193 -11378 -41856 -5368 -32754 -2571 -33868 2202
--52099 14139 -35346 10532 -37878 8127 -39319 8762 -39608 9127 -38676 9663
--37568 10054 -37145 9999 -37439 9312 -37734 8047 -37315 6552 -36210 5306
--35334 4602 -35577 4471 -36825 4669 -37659 4754 -34991 4357 -28278 3835
--22343 3730 -20882 3983 -22366 4371 -28759 4959 -42073 6009 -62973 8008
--91827 12905 -52139 3487 -29104 4494 -27536 6850 -28475 -1692 -11699 -739
--8140 -5063 -28763 -9039 -37279 -166 -40978 -1829 -49071 -542 -20103 3892
--33554 -15685 -20408 5455 -14949 11186 -23374 3489 -26365 6273 -20404 7684
--21387 3131 -16854 1680 -17469 5186 -17125 9538 -12915 1452 -21093 1719
--24393 3886 -16790 7222 -5729 11713 -7288 5968 287 442 3495 -2976 -26988 -93
--35067 1431 -35288 8059 -34302 5552 -36654 4871 -33286 3576 -30715 3273
--30132 3385 -31598 3460 -33649 3348 -33740 3749 -32670 4376 -31541 4876
--30789 5123 -30406 5149 -30238 5037 -30150 4862 -30080 4678 -29994 4513
--29897 4379 -29801 4277 -29706 4202 -29614 4149 -29533 4115 -29462 4090
-96: 5423610 -698356 -39514 2769 -39554 2746 -39594 2732 -39607 2730 -39587 2749
--39585 2792 -39527 2857 -39367 2950 -39275 3062 -39166 3197 -38947 3346
--38491 3507 -38120 3678 -38070 3856 -38000 4044 -37197 4240 -35679 4453
--34970 4692 -35632 4975 -36138 5330 -34770 5807 -31754 6470 -28841 7411
--27391 8700 -27445 10283 -28257 11685 -29619 11460 -33571 6630 -42766 -11761
--10172 10449 -30360 6354 -33675 5626 -35511 6735 -75671 -5967 -35787 -12231
--16820 -13304 -18298 -13630 6222 1959 -19104 7975 -37909 11657 -34316 20010
--36538 18103 -41252 14654 -28981 12574 -30212 13551 -30501 13006 -32095 10165
--34491 8322 -24077 9370 -14784 4836 -23815 11157 -56131 -560 -4256 -1934
-3452 6280 -41533 6342 -55417 7199 -48054 6460 -36417 5690 -31521 4299
--37396 11831 -30990 7822 -27913 9571 -40937 13053 -37711 9622 -41824 14738
--27139 12662 -22499 19411 -41158 -6900 -53604 -7267 -55676 -15898 -22867 -19397
--8868 -5851 -31357 13590 -33980 2909 -17862 4772 -21350 7244 -38091 3923
--30620 8055 -29522 1246 -25293 36051 -20602 43430 -26451 38450 -50081 4509
--32568 6121 -30989 4274 -52513 10874 -52467 2514 -43103 1160 -37544 -1019
--40162 152 -32627 4390 -24964 3428 -29670 6721 -34514 2198 -33233 6337
--33672 18536 -36004 22655 -38211 18404 -38933 4419 -37684 -1337 -31845 -2115
--39292 -3568 -45864 2563 -33053 3751 -35039 4183 -43019 3910 -39169 -2780
--46453 51 -39052 6424 -23809 21699 -31492 1915 -25778 977 -13783 -2886
--15684 2880 -26985 882 -24148 1535 -26156 -273 -8774 406 -8235 -2703 -5528 -1819
--6572 -5136 -9131 4014 -16710 -2012 -33932 5518 -26637 2582 -18453 3308
--23643 10952 -15879 2896 -13404 -1784 -10979 -11105 -12588 -13815 -16928 -17851
--20542 -21250 -27438 -6131 -20357 3536 -14628 -9274 -28485 -4204 -28109 2410
--43729 -7789 -36729 -13150 -28130 -7770 -32446 -4428 -35518 -20967 -18342 941
--27867 23 -56169 4870 -22556 11779 -20506 10555 -18672 11875 -26238 -18642
--31028 -2567 -42292 7194 -37324 -1128 -36987 -1501 -44397 3435 -26351 -6160
--29416 -139 -23587 1948 2382 -4434 -34251 7049 -209 5614 -7224 -3984 -6250 1967
--9385 8931 -9059 11768 -9964 13576 -12592 13750 -12189 7389 -20660 5923
-16734 8007 -42506 25109 -29016 5003 -31457 4683 -24927 7115 -1451 10258
-10223 8236 10582 5806 295 5416 -22118 7044 -32812 8755 -35157 8305 -24897 10928
--37842 9076 -39251 8194 -39870 4780 -27388 3682 -44814 2322 -26300 -3590
--25963 -4182 -51259 -17476 -48679 -3433 -40965 2155 -33407 -18391 -49778 15524
--40966 16184 -38595 12336 -38204 11150 -38021 10143 -37271 9661 -36512 9375
--36349 9008 -36659 8381 -36761 7466 -36230 6412 -35438 5459 -35293 4790
--36326 4443 -37994 4305 -38671 4155 -36289 3829 -30414 3446 -23311 3197
--17792 3091 -14937 3020 -16855 2957 -27164 3039 -53620 4582 -131289 15617
--73317 -9826 -9456 4057 -17294 28056 -34051 13050 4080 -8882 -10928 -10128
--33070 -11895 -41737 -1261 -36657 11975 -45037 -10815 -41219 -18443 -26005 -21
--21737 10102 -15909 12370 -21033 7266 -27099 5301 -25269 4538 -25885 -1315
--18558 3756 -19256 4113 -17179 7894 -10943 -2167 -23169 2240 -16449 5676
--13558 8838 -3956 13033 -26631 -6500 10451 15202 -3331 5644 -31212 -1205
--33626 2227 -32696 6748 -30177 2247 -39478 4332 -31378 2111 -28033 2470
--27857 3063 -31273 3270 -36047 2496 -35243 3246 -32607 4373 -30553 5151
--29517 5472 -29194 5465 -29211 5281 -29318 5028 -29406 4775 -29444 4555
--29433 4378 -29397 4245 -29344 4151 -29287 4084 -29229 4041 -29177 4014
-97: 5443375 -712692 -39663 3189 -39712 3185 -39754 3192 -39774 3215 -39772 3256
--39782 3317 -39726 3396 -39591 3492 -39501 3600 -39423 3716 -39222 3837
--38835 3961 -38411 4088 -38326 4218 -38516 4359 -37665 4516 -36163 4703
--35698 4938 -36385 5246 -36473 5662 -34846 6234 -32273 7024 -30398 8088
--29947 9438 -30402 10905 -30964 11880 -32491 10939 -34616 5901 -29523 -1974
--18562 4213 -25939 4554 -29557 4100 -16697 9113 -10502 3702 -29574 -2866
--49568 -21323 -34711 -17579 -16576 -2686 -29262 13344 -35390 11660 -25576 18740
--30561 14799 -40748 13333 -39942 9904 -33147 13608 -31277 14169 -30443 14356
--31125 17402 -32607 10830 -13911 15853 -26756 823 -34500 -5906 -14943 -11518
--22680 4462 -44952 8006 -33654 10445 -35384 7379 -46570 1001 -29188 3760
--40307 15317 -34421 12714 -34535 14213 -22958 16249 -40514 5683 -43626 16139
--33975 14251 -38694 17919 -54191 4008 -52168 -8342 -61530 -7790 19073 -26148
--27586 -3775 -33986 -2424 -19099 -3481 -10704 8960 -39212 5391 -50895 4601
--24329 7275 -32355 11015 -35242 28994 -20697 32877 -24913 24279 -38303 12532
--29130 3949 -31170 596 -47557 7980 -50347 12253 -44343 8622 -35704 -883
--43617 1027 -32952 4550 -26880 6026 -35495 6511 -38464 3572 -38673 7903
--32694 19043 -31276 18903 -31936 12270 -35670 6138 -43613 13168 -37966 21139
--38442 -26996 -34593 426 -34345 3699 -38572 3956 -54853 8067 -38115 -2089
--36670 -3108 -42536 5564 -28750 3022 -23799 4462 -28671 -826 -26928 -8157
--4191 -219 -24779 4766 -27387 -347 -25558 -2208 -3337 2003 -6898 -1139
--6143 -4607 -408 -9702 -16047 3657 -19045 4066 -29118 455 -21326 6027
--19091 5289 -28921 5443 -17343 -1435 -12131 2003 -7696 -393 -7963 -3879
--16357 -22730 -22406 -24204 -27148 -14597 -16096 4002 -25736 -2787 -30159 -5416
--27768 -4282 -22723 1859 -43127 -12314 -40506 -19485 -31765 -13000 -32056 3082
--23950 8914 -25280 5238 -39861 3959 -29032 16717 -29376 3684 -14681 -462
--23742 -15306 -31083 2524 -28058 2821 -45236 -1170 -36019 9200 -37444 1010
--33845 -6152 -37281 -3957 1156 -5200 25668 -18479 -59452 10123 -21447 3715
--26377 1144 7824 6943 -14548 1075 -25515 14311 -10936 16006 -9975 16496
--8584 11135 -12682 3536 -11213 18170 -5931 5664 -30395 17919 -35218 6933
--33660 6726 4659 11607 15431 6830 14015 2565 3592 643 -13519 2370 -24241 9552
--52627 -273 -31557 6413 -40505 7741 -28425 13828 -36753 14332 -36061 9226
--50900 -730 -28308 -1733 -32115 -2095 -37527 -6609 -41749 2140 -42560 -10298
--39676 -13356 -45371 6331 -41984 12273 -39575 12659 -38313 11398 -37418 10141
--36429 9209 -35714 8546 -35644 7993 -35933 7399 -35895 6694 -35260 5912
--34588 5157 -34814 4530 -36331 4080 -38421 3767 -39424 3497 -37548 3187
--32149 2845 -24380 2517 -16398 2202 -10243 1892 -8319 1676 -14206 1801
--31358 2851 -71281 3319 -148728 -19413 11372 6789 8287 30699 -43860 21416
--22734 1817 -35213 420 -43892 -2103 -49258 -3515 -31341 -13293 -40738 -36503
--41964 2761 -28200 11004 -24792 10552 -13957 10743 -14051 8585 -36833 5007
--33030 3220 -16109 4002 -17098 2615 -28240 5702 -21388 7213 -4100 -2243
--24506 9945 -22616 4435 -13516 1422 -18594 2377 -25158 -5943 288 15106
-187 13977 -36127 5421 -20607 2123 -23699 2653 -23972 2939 -47535 6857
--27123 405 -25120 2430 -24902 3388 -30881 3875 -41937 747 -37539 2494
--31933 4450 -28782 5511 -27670 5845 -27622 5760 -27964 5485 -28349 5156
--28645 4840 -28830 4572 -28923 4361 -28957 4203 -28957 4091 -28934 4014
--28909 3963 -28882 3932
-98: 5463187 -726984 -39797 3625 -39854 3640 -39905 3668 -39932 3713 -39939 3774
--39965 3852 -39919 3939 -39808 4033 -39723 4128 -39652 4220 -39534 4304
--39154 4382 -38623 4453 -38820 4523 -38945 4603 -37891 4703 -36730 4839
--36752 5033 -37244 5309 -36780 5694 -35063 6223 -33246 6929 -32606 7832
--33259 8919 -34228 10078 -34199 10987 -32511 10931 -25309 8452 -26444 3609
--22359 62 -19304 6132 -29847 3783 -12389 -434 -11382 2720 -23867 1646
--33470 -10419 -32245 -14306 -29207 -5459 -31034 11728 -28238 15609 -25142 21478
--31091 10966 -33195 12684 -43863 8269 -38721 12464 -35831 14246 -38296 17079
--27550 13311 -30591 12478 -26836 6028 -22483 6342 -3737 1883 -9949 -5818
--44163 2399 -57703 5852 -36519 3640 -28245 -4393 -53983 6986 -29551 6534
--36819 22073 -38622 10511 -28662 12740 -24787 13033 -38300 14616 -37961 15130
--28634 20457 -38843 14196 -43908 8503 -42588 -3975 -34392 -8775 -17048 -15410
--50839 -4965 -16012 -14033 -28204 -10306 -5665 17337 -61419 1452 -70487 7559
--9677 9973 -40832 13160 -44586 22643 -13077 24720 -13137 21297 -42607 8643
--28480 3778 -29560 5203 -41402 8214 -53387 10037 -46191 10825 -31938 2897
--47086 -583 -32757 4017 -27020 5851 -44179 9702 -23222 6155 -41256 16889
--34821 12941 -29295 11775 -31374 9087 -37242 9381 -43711 7505 -34706 4128
--32260 -2913 -45440 2477 -39340 3453 -40354 1626 -39618 3576 -56207 15202
--34830 -16485 -40093 -576 -31366 1634 -24145 5116 -24241 4021 -12527 1627
--21352 5333 -17062 -4186 -25747 -5608 -31030 -3647 -3509 -2378 2375 -5222
-3892 -11738 -8977 406 -19989 1305 -29137 9537 -30585 -2602 -18347 4343
--14743 5269 -23016 -5100 -22504 -5409 -12226 1540 -10374 2080 -7339 -2944
--11634 -15855 -18868 -18993 -22343 -15455 -23277 -5217 -27486 1485 -29624 -4031
--24527 -9049 -24827 3980 -39456 -9170 -36535 -13783 -34368 -6198 -36272 6886
--23704 8150 -21832 6731 -27447 3002 -17641 7301 -22711 -4338 -32563 463
--33070 -3938 -36637 4371 -28696 10105 -42385 -1283 -38647 3812 -41199 -302
--33198 419 -36322 -8684 -4471 3572 14147 -15112 -32147 -888 -29055 1497
--30520 -2350 -4328 3606 -12587 -13213 -27804 23227 -19356 13157 -16555 21306
--9934 24809 -41702 -8423 7885 18258 10746 14943 3076 13423 -40531 7961
--27226 16435 1626 8653 13759 2531 13825 -1765 5821 -4800 -7792 -3315 -26517 7103
--45965 2585 -40163 4589 -34016 13528 -33458 15242 -47423 15669 -31677 6238
--40718 -2290 -47675 -5784 -45857 -1889 -30362 1511 -35097 -4070 -40794 -2815
--40859 -3646 -42651 4328 -41386 9199 -39592 10448 -38229 9970 -37013 9007
--35833 8093 -35087 7366 -35037 6790 -35288 6270 -35137 5725 -34391 5136
--33703 4530 -34040 3966 -35785 3488 -38232 3108 -39762 2793 -38615 2497
--33900 2178 -26193 1822 -17319 1423 -9705 1036 -6149 796 -10897 1106 -24646 1754
--51502 1327 -78882 -2620 -6793 17553 -32341 37952 -55497 10299 -55162 -4251
--40593 7481 -34114 5860 -72845 -7519 -41997 -29288 -33432 -21142 -20583 -5894
--23436 5502 -25000 1000 -7186 8201 -20010 7800 -35862 3643 -28736 2134
--26537 7207 -19340 2103 -27812 1797 -17353 -1870 -4201 5682 -23859 22272
--20728 539 -14014 -3283 -17251 3433 -29761 5509 -20799 4429 3224 14604
--27415 11112 -17460 1273 -32686 4947 -19393 4564 -40510 2533 -24783 -693
--25455 4466 -21783 4279 -29014 6429 -54386 -3427 -39182 1656 -29689 4681
--26137 5837 -25491 6072 -25964 5895 -26716 5556 -27392 5180 -27891 4832
--28216 4541 -28406 4309 -28508 4138 -28556 4016 -28573 3933 -28577 3879
--28577 3846
-99: 5483056 -741248 -39917 4074 -39975 4106 -40040 4154 -40076 4220 -40094 4299
--40129 4389 -40099 4479 -40012 4567 -39918 4643 -39883 4702 -39842 4742
--39340 4764 -39023 4771 -39309 4771 -39068 4777 -38117 4804 -37623 4868
--37821 4991 -37825 5191 -36953 5482 -35504 5874 -34591 6363 -35002 6929
--36518 7536 -38236 8177 -39173 8982 -38730 10428 -30522 12346 -11905 5089
--20097 2091 -21314 6303 -21255 6335 -20110 2534 -14282 -2516 -21571 1211
--12450 -1604 -21979 -12256 -32470 -5884 -31062 8257 -27659 15148 -30933 15931
--27622 8527 -22087 9139 -43039 13926 -34712 16013 -32232 17683 -40260 18960
--37838 14401 -38913 8163 -34047 -23465 -23672 717 946 8099 -4352 3118
--49927 18137 -79608 9267 -41280 -5505 -33378 -7364 -56220 24223 -43672 11006
--36550 19662 -19722 12095 -22120 18272 -21634 9038 -30217 12021 -33660 11981
--27207 18900 -33395 16529 -34211 13637 -27922 -3719 -27020 -4895 -52591 347
--37343 -14392 -24619 -16381 -33316 -11220 -33738 3053 -49155 -916 -45588 20512
--31276 13406 -40022 10010 -38771 14608 -24855 17616 -23276 11276 -33600 9922
--28222 7369 -30222 11203 -44142 5832 -50669 6272 -42304 8488 -35888 2715
--36399 1240 -34632 7391 -25785 8733 -29620 17172 -32226 6868 -34249 18826
--27341 9019 -26022 4275 -47943 18251 -47069 25244 -51370 -4264 -37647 405
--38349 -1196 -38696 1145 -39661 1342 -38694 1742 -40449 209 -44570 7755
--38077 -5843 -41755 -709 -28622 3742 -34808 5540 -20048 5759 -28480 -1303
--5481 1288 -11302 7934 -8051 -7013 -27754 -12739 -7521 -4008 -5840 -3911
--468 -1517 -8503 -705 -27640 1761 -35015 720 -34339 -5021 -12655 4248
--5981 -1885 -20728 -8589 -16291 -9128 -20328 -1270 -13657 1349 -7524 -4883
--7987 -13440 -16007 -12595 -15291 -11722 -21562 -5938 -33281 212 -24743 1403
--23662 -4603 -34553 -93 -38712 -11357 -27438 -9873 -30529 -627 -38166 6480
--27465 6545 -23813 2711 -22662 817 -25897 1892 -29312 -2378 -30948 1981
--34142 2521 -32701 5984 -33495 8400 -42390 2594 -34314 -904 -27213 -4706
--27588 -9384 -24047 -8135 -29638 -4963 -22227 1971 -13296 -1538 -21982 3581
--18836 6759 -21884 4215 -16562 3264 -19816 6138 -12806 11570 -19192 12141
--22643 12114 -19062 7906 -2194 35533 -13 24516 9440 -11057 -18391 4145
--19007 15972 -1108 10823 9616 2015 10000 -2330 3482 -7811 -7832 -5691
--26874 5926 -36137 5936 -35704 4600 -46425 10570 -45236 15216 -53112 19079
--32975 2089 -23970 -4312 -58787 -9360 -51941 819 -34765 2479 -32317 2968
--36898 2853 -39184 2494 -40427 4874 -39860 7089 -38742 7903 -37626 7716
--36420 7095 -35219 6414 -34492 5831 -34462 5369 -34692 4978 -34475 4590
--33636 4162 -32849 3691 -33098 3208 -34841 2759 -37501 2378 -39574 2071
--39309 1805 -35608 1521 -28687 1179 -20115 779 -12355 410 -8215 247 -12139 1211
--21546 2674 -36699 4586 -47618 8304 -28048 21385 -47483 31484 -68202 18561
--66905 -4150 -37834 -18619 -13571 -6100 -83459 4923 -31328 -18996 -65818 -28283
--3754 -8907 -24409 2332 -16918 8169 47130 20342 -65223 -1268 -53909 333
--26643 810 -24326 3822 -15822 -609 -25967 -3424 -15587 -209 -18998 14523
--19147 18120 -12471 2687 -8281 -4773 -11388 6892 -35117 9431 -14143 5524
-3720 11933 -25106 12401 -22795 6934 -32294 188 -32227 4384 -35705 4548
--31360 1910 -21519 5628 -19671 3677 -21890 12150 -76125 -11979 -35124 1643
--25781 4756 -23615 5675 -23822 5856 -24765 5700 -25789 5395 -26638 5049
--27256 4720 -27668 4438 -27924 4213 -28076 4043 -28162 3921 -28211 3838
--28243 3786 -28270 3754
-100: 5503000 -755497 -40021 4530 -40083 4577 -40156 4645 -40200 4730
--40230 4824 -40271 4922 -40259 5012 -40193 5087 -40090 5138 -40121 5160
--40025 5149 -39593 5107 -39482 5043 -39530 4965 -39115 4888 -38638 4830
--38505 4812 -38425 4850 -38044 4957 -37221 5137 -36291 5376 -35991 5633
--36756 5837 -38313 5880 -40118 5648 -41721 5124 -42831 4755 -34595 6138
--1049 18314 -15774 9500 -20914 8202 -22445 6727 -25488 7485 -16467 3723
--14406 -2532 -2549 2725 -14708 -16341 -35222 -11184 -22268 7554 -25702 16055
--30421 13607 -35178 9374 -24730 8946 -30861 12588 -26588 25864 -31609 17887
--46857 16222 -43911 19296 -45625 -32717 -44640 -47715 -40661 -4344 -5548 25052
--6458 20313 -30517 36233 -101204 14144 -57267 -4307 -37115 -10928 -52457 20075
--42921 39995 -12598 12461 -4121 10998 -27908 23198 -20004 11398 -26922 8685
--30425 8265 -27558 12205 -33977 13990 -27969 7692 -24649 3515 -33993 7639
--37791 -4528 -35563 -11945 -35315 -10019 -47028 -8865 -67487 1944 -73072 6807
-12928 20724 -35544 6959 -37725 2250 -33240 8783 -30685 17390 -34499 6744
--35069 4108 -29325 4578 -33874 13065 -41197 6008 -46411 3323 -34374 8351
--32493 6154 -32173 6649 -31150 12589 -26657 11049 -29898 21166 -26919 8220
--31734 9489 -36914 11525 -30086 11137 -59958 26391 -58034 23030 -50273 -7512
--32010 -4744 -34284 -3375 -33965 1447 -38643 -586 -38751 2154 -41682 2513
--38336 2157 -38252 3613 -37129 4705 -45836 6711 -36301 -5554 -25897 100
--25266 -879 -8095 -6744 -14853 -11097 662 -387 -4445 -4524 -7095 -2055
--15781 -7895 -19269 5556 -17696 2565 -14512 3504 -32806 -1651 -38700 -7650
--13372 -5911 -43 -4987 -11225 -8494 -18914 -6615 -16854 3701 -25252 304
--11285 -13002 -3926 -23160 -17023 -10625 -11111 2849 -16228 5174 -20006 4722
--32823 551 -30831 -2903 -32402 -4199 -39323 -13296 -25926 -10638 -21518 4800
--30463 9725 -32422 5868 -24050 -491 -27994 -1035 -32093 3103 -33912 995
--22204 -1490 -34652 2424 -28706 8241 -30531 -236 -46044 6844 -29910 -2778
--26715 -8628 -27817 -4051 -29101 -5930 -37318 -3783 -41626 6792 -36134 13021
--23260 11671 745 4060 9935 -11470 -19437 -898 -22403 6112 -20127 -658
--19169 2728 -16936 2634 -12086 22666 -3160 38885 -21856 11190 13967 -9403
-5175 1631 -1717 9817 1086 12854 4867 10036 3591 4525 -4443 -10851 -16986 -13438
--25027 4412 -27952 21040 -18771 7230 -58273 11904 -52603 10382 -58013 23637
--47909 -8506 -47313 -10401 -29664 1950 -41209 5993 -39168 4312 -34147 7040
--36652 6356 -38743 5665 -39132 5144 -38397 5226 -37498 5271 -36617 5102
--35568 4773 -34480 4395 -33836 4060 -33855 3792 -34102 3571 -33882 3345
--33001 3072 -32083 2734 -32107 2347 -33642 1960 -36315 1624 -38820 1359
--39454 1142 -36987 911 -31342 614 -23800 258 -16591 -46 -12221 -86 -14968 1596
--20245 3877 -28142 7040 -34377 11731 -33762 18598 -45325 20657 -54593 9126
--47651 -11383 -37416 -23189 -113121 21152 47789 -36201 4782 15354 -140157 1378
--27102 -26601 -40652 1601 -32653 8373 -8461 6953 45466 13312 -94763 -3628
--36196 4008 -23023 1951 -8398 -491 -38612 63 -25659 2006 -18260 12706
--11277 13658 -2162 5225 -631 1190 -17094 1970 -30578 2475 -22444 -2054
--9970 17676 -26199 20772 -9634 525 -34810 -5409 -30087 8319 -33302 9813
--30786 9759 -21535 9908 -18415 3209 -38605 4954 -50523 -7741 -36321 -1738
--24125 2478 -24040 4255 -23817 4968 -24523 5111 -25421 4988 -26215 4754
--26815 4499 -27231 4262 -27508 4067 -27679 3914 -27788 3803 -27861 3729
--27914 3683 -27965 3655
-101: 5523026 -769749 -40102 4988 -40175 5051 -40253 5136 -40304 5237
--40342 5343 -40387 5445 -40401 5531 -40337 5589 -40255 5610 -40295 5589
--40164 5522 -39891 5415 -39766 5272 -39614 5111 -39378 4948 -39208 4804
--38902 4699 -38532 4655 -38238 4683 -37843 4779 -37265 4926 -36934 5067
--37156 5116 -37798 4933 -38514 4361 -39001 3314 -39004 2279 -36904 4132
--14937 20337 -16278 10356 -8848 16521 -22419 9655 -26618 8077 -22764 11013
--16696 -11098 -9672 -3072 -7143 -3167 -25986 -1455 -16354 -3141 -19555 18598
--31392 9621 -24024 11835 -29597 2920 -29031 11299 -18282 16053 -15239 -35044
--16902 -55478 -79403 65205 -66980 10464 -56319 -15137 -47583 179 -28757 18753
--23303 9343 -11966 33532 -122885 24311 -54226 22040 -35735 -2607 -32407 9592
--45556 24640 -2970 35891 -2774 18017 -10135 17721 -25100 7662 -31986 6786
--29827 5382 -22970 4193 -30490 6618 -33435 5675 -29097 6838 -26040 9368
--30546 380 -37573 -4814 -39872 1509 -47770 -7284 -69934 4835 -48885 8209
--21348 9879 -36870 3280 -39319 1236 -31791 11533 -28804 19576 -43338 1432
--37522 598 -29807 5389 -34302 11890 -31928 3706 -33780 3016 -36161 7157
--35291 8623 -34570 9972 -28971 19796 -23572 6054 -28575 8787 -20851 9387
--31605 10900 -66337 26101 -54105 24912 -58929 29033 -54821 20665 -53025 -14844
--25313 -6523 -20949 -5504 -24607 -1202 -43463 -5055 -40479 5680 -38224 4058
--34711 1122 -35120 345 -47331 12512 -46901 -3642 -30607 -4509 -33139 -3970
--28008 -6349 -18222 -12373 11645 -9181 -26751 -16404 -12018 -279 14345 4402
--7602 8118 -22827 11316 -10726 2109 -6145 4655 -34384 12234 -38687 -947
--14243 -20433 -1123 -16388 -3854 -12128 -12370 -5925 -31945 9349 -34909 4009
--1667 -33132 5390 -38745 -9640 -4543 -17141 11422 -16078 8454 -24308 5646
--35295 5146 -33847 4355 -11721 -655 -20808 -12349 -32105 -4406 -32645 -1576
--31294 6534 -32863 10312 -33490 -3555 -34889 -1992 -23778 4831 -25333 4161
--36604 -7051 -42396 6051 -21854 -573 -34659 9935 -36027 -5619 -42918 -7446
--34025 -5667 -30468 -3286 -28608 -3670 -33156 4139 -48058 8761 -51040 23608
--6248 9841 37412 -1919 6605 -23223 -27711 -3026 -31839 3540 -24940 -10057
--20652 3072 -17870 5945 -14633 5780 -7311 3865 -947 9344 7219 10397 10005 8846
-10359 11908 3841 15938 5399 13664 -985 20759 -12883 -13730 -37073 -29707
--53587 -21309 -10570 67094 16557 18543 -74146 26891 -50969 3926 -57957 9143
--34625 11593 -53875 -6354 -34239 -5364 -39245 4102 -39619 6323 -35764 7142
--39065 6969 -40465 6793 -38880 4377 -37190 2997 -36127 2503 -35385 2384
--34534 2338 -33623 2281 -33097 2219 -33184 2173 -33484 2132 -33327 2068
--32474 1943 -31445 1734 -31172 1453 -32335 1149 -34810 881 -37539 681
--38950 528 -37739 364 -33586 132 -27425 -160 -21122 -390 -16764 -335 -18205 1755
--20369 4369 -24056 7596 -28261 11228 -31981 14199 -39045 12849 -43444 4181
--40829 -7700 -38990 -10765 -58270 6136 8643 -17076 -25189 6005 -96777 1988
--57436 -12468 -49589 -1261 -37615 4803 -16694 5892 7847 8943 -55666 1495
--41183 3207 -29947 2123 -25119 904 -40151 1629 -21484 7026 -11483 12787
--10836 9443 -563 5604 -2238 4764 -15012 -2675 -24490 -2528 -21023 -9560
--16734 8676 -25951 -1384 -27034 8452 -31966 7519 -18260 23181 -29195 15309
--27520 13566 -12610 4779 -14803 5093 -42494 3147 -45045 -2596 -33919 -1133
--29001 1321 -25817 3060 -24872 3989 -25009 4373 -25530 4441 -26093 4350
--26561 4194 -26913 4026 -27157 3876 -27326 3755 -27439 3666 -27524 3606
--27597 3569 -27666 3550
-102: 5543146 -784019 -40162 5443 -40247 5521 -40326 5621 -40384 5735
--40430 5850 -40479 5953 -40512 6030 -40455 6069 -40388 6056 -40405 5989
--40312 5865 -40094 5686 -39894 5467 -39775 5220 -39736 4971 -39424 4741
--38804 4558 -38526 4445 -38728 4421 -38673 4488 -37975 4641 -37013 4845
--36255 5052 -35736 5197 -34881 5231 -32581 5185 -27503 5388 -21336 7175
--41400 15368 -25335 10493 -17184 9366 -20742 16606 -25451 5343 -24608 7868
--2581 2637 -28260 -7374 -22524 -3719 -6061 -5136 -5183 4184 -21234 19042
--32957 8354 -30560 8157 -32430 8071 -25811 6671 -23928 3345 -13962 -20156
--26221 -23685 -68597 30818 -59209 2937 -55516 -330 -51248 4104 -42210 22532
--49391 22671 -59568 8724 -72004 19190 -32165 14525 -27507 8439 -33407 22327
--22021 14487 -8329 21946 -8454 22392 -12826 21473 -28620 11019 -37847 9675
--30628 5456 -27208 853 -29093 5260 -24924 7279 -23297 6793 -34271 7550
--39953 4480 -45728 3352 -37058 6958 -57418 -5908 -54039 2131 -36358 -1359
--30570 7725 -39411 2236 -41404 1156 -34745 7843 -28858 14683 -43696 8704
--41287 -1096 -27744 1444 -30154 17238 -23873 1321 -28837 6044 -34919 6300
--35904 12528 -35353 12869 -25871 13483 -26658 3702 -42608 16617 -47964 25169
--52900 16756 -69754 24057 -53515 24457 -50948 25579 -40634 16240 -52636 -9239
--20504 -6714 -16164 -4566 -23125 -1468 -40661 -1264 -39008 -951 -35010 2004
--32897 2662 -34375 2114 -42054 7902 -39111 -4032 -40061 -3977 -42711 -5173
--19722 -13130 -8753 -10226 22515 -8723 -61812 -10777 -60251 1261 47217 -2235
-5881 23278 -6947 16725 -10217 3965 -8173 3849 -39034 -7562 -28484 -8281
--7055 -19574 -1322 -18305 -4814 -11344 -20523 -2231 -32520 5907 -28229 2
-10192 -39930 15056 -45401 -11936 -3564 -18087 10979 -22982 14870 -28214 4632
--32676 4603 -30500 6619 -12195 -610 -15758 -6545 -26750 -2605 -31701 372
--33268 6037 -37755 8503 -33367 -2452 -31413 -2363 -26265 2870 -32796 3507
--41786 4502 -50160 -7968 -26735 -3694 -33753 -2452 -17048 -8778 -44189 -10680
--42650 -7213 -39363 -1604 -31016 6624 -26508 15340 -25651 12366 -45346 16140
--999 -3090 16366 -1556 9288 -7792 -10419 -3142 -26931 15648 -36120 -41827
--29547 5851 -22700 11556 -17826 13215 7777 -7341 10734 -8186 250 13015
-6309 10538 15621 12773 5429 14411 945 -25111 5184 71837 -7393 -2351 -43403 -14325
--71178 13468 -55674 70508 -2616 -9470 -29782 12101 -34816 3685 -41251 7712
--36470 -2932 -53723 2412 -50642 5456 -36212 6626 -36429 8656 -37304 7965
--43844 6590 -44171 7684 -38807 2794 -35973 360 -34714 -230 -34100 -154
--33451 84 -32719 308 -32305 486 -32451 635 -32818 757 -32777 836 -32028 843
--30947 753 -30373 580 -31070 367 -33155 179 -35865 54 -37819 -25 -37709 -113
--35022 -272 -30345 -491 -25131 -660 -21057 -559 -21324 1556 -21429 4096
--22620 6904 -25251 9411 -29005 10510 -33760 8501 -36664 2824 -36404 -3531
--36345 -4910 -37858 -182 -17284 -6331 -37989 1383 -71251 696 -61198 -4404
--51876 -639 -40013 3067 -25537 4766 -16784 5969 -39531 3485 -39088 3564
--33276 3393 -27981 3619 -24813 5366 -5029 9150 4935 9902 -40566 -5876
--19199 10303 -16621 3577 -11096 -4487 -19186 -6245 -15588 -3392 -15255 7266
--22200 6231 -28973 9000 -28478 17365 -28932 19397 -24547 14122 -22670 15016
--18401 -8019 -23505 5902 -34331 4406 -37264 907 -33781 418 -29748 1373
--27147 2465 -25971 3250 -25688 3692 -25839 3878 -26130 3904 -26424 3845
--26673 3752 -26862 3656 -27007 3572 -27114 3511 -27206 3470 -27290 3448
--27374 3439
-103: 5563374 -798327 -40210 5892 -40287 5981 -40376 6095 -40443 6219
--40492 6339 -40544 6441 -40590 6507 -40541 6521 -40480 6476 -40490 6361
--40405 6177 -40180 5930 -39994 5632 -39995 5304 -39904 4970 -39258 4661
--38579 4406 -38735 4241 -39350 4190 -39217 4277 -37963 4514 -36244 4910
--34856 5483 -34031 6286 -33166 7462 -31436 9312 -28608 12241 -27099 16070
--38698 17721 -25327 1623 -22264 1614 -26930 6639 -26370 6516 -13428 5255
--19410 -7756 -25902 4643 -30852 5084 -8334 8300 -3849 8870 -11244 2383
--25448 5230 -32173 9041 -27596 8063 -29017 7920 -31353 5208 -20683 1381
--27957 -3701 -51913 645 -56156 -3973 -55688 3059 -54427 3831 -54281 10404
--54414 39594 -82409 -16111 -59883 19309 -35690 16930 -22284 17159 -8187 9044
--9757 11335 -7127 21860 -15228 29307 -21338 27421 -32168 18186 -35145 9310
--34543 6812 -29593 3072 -25493 3895 -22428 5459 -21313 5902 -37494 5323
--43546 5388 -45954 5008 -32518 662 -45507 1688 -63091 -330 -38638 478
--32315 6823 -42089 10 -42492 1012 -34130 7479 -28159 5875 -43860 10863
--31193 -3511 -28123 7266 -11985 2066 -37989 6058 -40852 -2086 -28863 21762
--34917 20175 -35016 7589 -17916 6189 -40870 19445 -80038 61644 -64560 16572
--58516 8857 -71445 16218 -41265 16622 -48234 20512 -31042 15228 -33750 -3451
--21732 -4838 -18092 -3139 -20958 -2037 -38562 -3228 -41502 -3195 -33554 1841
--31337 4907 -31354 576 -37089 3399 -41313 -373 -40794 -901 -37318 678
--28834 -3967 -10775 -4704 3722 -5371 -36898 -2377 -44529 13945 4394 -11356
-4179 4093 1937 2862 -13800 4028 -832 -1081 -38735 -10403 -22458 -17056
-5830 -23784 -3279 -19647 -10643 -10721 -23350 -316 -25565 5814 -15652 -8754
-15847 -31258 19894 -51006 -11082 -8120 -17538 8927 -29293 19253 -31280 5408
--29767 4573 -28229 2827 -17882 824 -17220 -3667 -24511 -3891 -25212 2755
--34088 10969 -33505 6801 -28475 1221 -39061 85 -31939 -85 -41000 6000
--56000 5000 -51933 -23213 -31435 -188 -43632 -13599 -16764 -12970 -24456 -14776
--34946 -10042 -42719 -1731 -29964 11610 -24033 17009 -8442 14911 -11208 17636
--12222 -7922 -5665 -8218 -903 -24548 -7308 13437 -18489 -3072 -25704 -7750
--37859 9304 -25042 12581 -23160 5707 25393 -6828 19695 -12244 -11450 6492
-2476 11924 13803 10234 21967 12256 7158 7324 2823 23756 6431 15669 -37933 191
--75919 20871 -63210 43106 -7350 2083 -53179 28015 -38910 9915 -42302 9240
--42913 4584 -70707 -6023 -49973 11804 -23329 11640 -31220 8072 -36765 6971
--48849 4258 -47573 9770 -37953 81 -34379 -2003 -33459 -2355 -32974 -2097
--32467 -1699 -31860 -1316 -31512 -989 -31677 -711 -32099 -474 -32202 -286
--31625 -173 -30574 -159 -29756 -234 -29968 -356 -31536 -463 -33994 -510
--36202 -512 -36925 -523 -35515 -600 -32253 -745 -28198 -863 -24659 -757
--24055 1107 -22971 3370 -22731 5702 -24141 7484 -27047 7913 -30533 6282
--32956 2788 -33725 -772 -33928 -1985 -33780 -1030 -30660 -2294 -42034 290
--57159 509 -56655 -859 -50521 570 -41733 2548 -32634 3842 -28588 4534
--35864 4024 -36950 4263 -33171 4819 -26735 5825 -18473 7459 -6539 9033
--4717 7551 -28392 853 -24874 6706 -31299 -4972 -15943 -10588 -19545 2856
--10729 -3961 -22073 7208 -10693 9368 -27978 8574 -34230 12878 -25990 16475
--19837 8954 -21148 4692 -38832 12439 -20539 4947 -27187 3875 -30019 2338
--30895 1581 -29222 1717 -27621 2222 -26628 2742 -26188 3128 -26097 3358
--26176 3463 -26314 3485 -26462 3460 -26595 3418 -26709 3376 -26808 3345
--26899 3326 -26994 3321 -27092 3325
-104: 5583723 -812693 -40234 6328 -40311 6428 -40405 6552 -40477 6683
--40530 6808 -40580 6905 -40633 6956 -40593 6948 -40538 6866 -40544 6705
--40427 6465 -40212 6150 -40081 5780 -40125 5373 -39825 4960 -38978 4576
--38515 4256 -39055 4047 -39655 3983 -39029 4107 -37132 4453 -35004 5058
--33723 5978 -33372 7308 -33288 9240 -33251 12095 -35072 16327 -35905 20809
--23717 13270 -25829 2246 -29082 -804 -29953 6835 -24184 4842 -9074 -14786
--24146 1833 -31451 10181 -15914 8086 908 18784 -17629 6067 -20523 418
--21002 7791 -27774 6934 -30035 7559 -34439 8831 -31693 5513 -26184 -18
--30413 -1298 -36872 2521 -53486 1153 -58104 3448 -55077 6443 -68611 8627
--74914 17222 -61990 10533 -63534 11450 -44621 7668 -21480 11725 11315 -1586
--1859 13204 -9213 24901 -18269 39651 -23589 32017 -31905 20382 -35078 11615
--37993 7395 -28939 4018 -21297 2286 -23142 2681 -22204 3015 -36061 4147
--41360 4750 -40421 2416 -36739 1558 -44073 4512 -58594 710 -47935 -392
--40759 3857 -41689 1303 -41101 557 -38234 2784 -40541 11983 -36760 14944
--22710 9678 -28196 20525 -18680 7269 -23047 -1289 -30093 -1376 -34657 10389
--49355 14536 -32953 8049 -40796 15864 -53570 35224 -80604 57053 -61870 8840
--34435 4005 -51721 2277 -44745 12351 -46735 14283 -40925 10218 -32038 5769
--26657 2665 -25287 -181 -21001 -3120 -36557 -4275 -37268 -5179 -36463 416
--29710 5181 -30488 4142 -34121 4107 -43971 2157 -42792 898 -31072 3349
--43794 8033 7691 -5502 -6558 -8389 -33574 -1463 -47114 13269 -12365 -6496
--6815 -4096 3006 -5123 -2844 -9612 -5427 -11273 -20641 -10151 -30841 -14362
-20642 -25971 -8832 -19900 -10976 -11527 -19101 -4141 -17986 3400 -6703 -1078
-3553 1772 3244 -17038 -6435 -5588 -17874 -11535 -13477 -8035 -31948 -8672
--28274 -299 -27226 3253 -23116 1855 -26664 -389 -24483 1889 -18631 3019
--31045 6587 -24917 2209 -31665 4113 -36072 1833 -35331 1360 -49537 -4835
--48771 -9135 -41437 -15129 -61626 -9021 -52127 -8722 -25154 -7535 -11792 -12985
--11285 -14432 -33943 2178 -17086 9426 -8104 16158 -13052 20827 21432 -6858
--29596 -2338 -4786 -1733 -14412 -19951 -22770 2378 -22778 6538 -33863 3120
--29475 5730 -16450 12818 -5223 4805 17370 -6327 5993 -12572 -9570 -5268
-2042 7961 5458 7041 13176 8361 12010 13652 14110 11574 17662 16043 -21174 7395
--72485 22642 -71135 28334 -26177 28397 -64647 40090 -56433 23881 -39530 9263
--43118 1582 -58008 23776 -64866 -5049 -11493 7123 -36609 2487 -44235 2956
--44493 4601 -43578 6020 -37942 650 -34614 -2132 -32548 -3066 -32209 -3096
--31678 -2829 -31102 -2473 -30756 -2122 -30889 -1798 -31330 -1506 -31578 -1252
--31218 -1067 -30287 -970 -29329 -962 -29108 -1001 -30112 -1030 -32143 -1005
--34328 -934 -35567 -866 -35151 -860 -33119 -929 -30195 -995 -27366 -900
--26266 579 -24657 2496 -23711 4437 -24314 5838 -26419 6158 -29121 5125
--31326 3043 -32595 908 -33304 -207 -34004 -335 -35564 -540 -42644 453
--50407 882 -51457 798 -47960 1513 -42251 2526 -36593 3334 -33989 3884
--35949 4179 -36292 4874 -33067 5954 -26540 7320 -18221 8672 -10729 9150
--11125 7214 -22118 2506 -25197 -1200 -28058 -12909 -21285 -16837 -24349 12774
--14503 10939 -20278 10490 -15869 7251 -20223 7310 -30336 8657 -28325 11940
--20019 5676 -15971 4389 -35193 10182 -28432 7980 -27864 5932 -29263 3863
--29361 2524 -28559 2018 -27578 2058 -26825 2334 -26378 2639 -26177 2883
--26128 3043 -26164 3130 -26239 3167 -26328 3175 -26418 3173 -26509 3172
--26604 3178 -26707 3191 -26822 3208
-105: 5604198 -827139 -40236 6747 -40313 6858 -40407 6988 -40490 7125
--40540 7250 -40591 7339 -40646 7377 -40609 7346 -40570 7229 -40544 7026
--40418 6732 -40210 6358 -40111 5919 -40116 5442 -39636 4955 -38787 4499
--38575 4119 -39171 3861 -39352 3781 -38102 3930 -35809 4358 -33913 5109
--33310 6225 -33453 7736 -33220 9635 -32173 11723 -31747 13285 -29820 12992
--31848 20658 -31481 10537 -29240 -1963 -33389 3415 -18719 11280 -13121 -20709
--24757 5548 -33980 10896 -18000 12163 -5680 18723 -31818 3006 -9920 2412
--13376 15229 -30596 5437 -28346 3948 -37331 7074 -30448 7000 -30943 3089
--28336 3452 -38145 -347 -45466 7060 -47099 -2216 -65072 12124 -91815 -1625
--73958 21798 -50220 24995 -59219 10880 -43956 14113 -19525 8000 -4349 11399
--11113 18355 -6286 20807 -5491 25275 -16941 23653 -30706 14944 -35469 9916
--36298 7306 -19043 3428 -14697 1714 -18105 111 -25721 1656 -40042 5105
--49835 6864 -51499 5681 -22346 -4871 -49791 11397 -57821 -799 -54436 -2966
--47335 3504 -43052 3866 -44080 3433 -52544 4359 -47453 15627 -36321 20835
--30873 23731 -10182 27065 -15465 9822 -3746 -7874 -14176 -1968 -49333 3605
--53915 2817 -49716 16946 -42360 17233 -49893 25927 -62041 32040 -58781 7918
--38627 6704 -45747 7502 -43581 13517 -43623 13730 -39781 9225 -34648 6752
--34006 2212 -35435 -740 -22383 -729 -34900 -1162 -37511 131 -36979 2440
--32732 5254 -31237 4742 -33565 4431 -39790 3140 -41990 1969 -45963 1455
--27302 -4228 2433 -13993 1590 -4346 -30641 9466 -32579 7499 -17095 -6175
--12520 -9343 -2329 -9156 -7110 -13307 -32341 -9477 -22165 -10652 -19637 -18248
-14518 -27018 -2852 -18146 -3323 -9011 -10227 -4561 -23596 1019 -12745 -5339
-8149 -8200 860 1130 -10650 -7497 -23620 -10740 -4453 10 -18723 -5133 -27146 -5385
--21417 5492 -27208 1143 -28263 -311 -27019 3771 -29319 1541 -29255 4587
--24510 2729 -23332 2176 -32923 11981 -42407 -248 -38187 -14335 -53271 -19159
--38587 -11214 -46512 -25875 -84058 -8663 -22900 6695 -2945 -10971 -4155 -8724
--23792 1096 862 -2569 5719 18012 -11689 25303 4407 -1421 -17645 -2253
--9654 -3199 -19537 -9748 -38926 1695 -27019 -190 -31319 -1167 -25862 -57
--13856 6486 -11900 -286 10502 -3842 193 -13117 -9511 -7255 2656 2711 8846 4454
-17742 5082 13887 9717 25374 8131 4357 20085 -17835 33332 -53054 36292
--52533 34651 -50413 36057 -64430 31291 -57565 28766 -53872 14894 -45134 6838
--43490 -4186 -50289 -1357 -40827 8047 -43661 4868 -44895 3591 -43075 3916
--40776 3589 -36904 583 -33984 -1794 -32379 -3020 -31583 -3434 -31002 -3409
--30422 -3192 -30040 -2911 -30102 -2613 -30522 -2318 -30890 -2043 -30764 -1815
--30033 -1661 -29055 -1587 -28517 -1556 -28989 -1518 -30501 -1429 -32442 -1291
--33897 -1150 -34160 -1062 -33111 -1047 -31199 -1058 -29148 -966 -27918 105
--26252 1678 -25092 3316 -25256 4528 -26780 4942 -28954 4441 -31004 3256
--32530 1921 -33658 978 -34957 561 -37429 491 -42086 980 -46439 1441 -47438 1737
--45509 2182 -41945 2691 -38311 3152 -36414 3632 -36777 4267 -36616 5310
--33668 6736 -27601 8321 -20192 9626 -14606 9904 -14499 8236 -19848 4141
--23704 -2387 -25655 -13751 -24960 -15864 -29582 5490 -22423 11853 -20569 11126
--11818 10645 -15878 10167 -17923 4668 -30811 8475 -29676 4651 -12615 -321
--30070 10999 -31079 11740 -29959 8422 -29228 5068 -28657 2942 -27949 1962
--27233 1734 -26653 1882 -26266 2159 -26045 2431 -25947 2642 -25937 2788
--25976 2880 -26044 2935 -26124 2970 -26214 3000 -26314 3030 -26431 3060
--26559 3093
-106: 5624804 -841686 -40211 7146 -40296 7263 -40387 7400 -40476 7540
--40523 7662 -40582 7744 -40629 7768 -40599 7713 -40564 7568 -40511 7326
--40394 6986 -40156 6562 -40071 6067 -40029 5526 -39459 4973 -38685 4449
--38575 4003 -38933 3690 -38555 3573 -36806 3715 -34607 4179 -33531 5004
--33864 6207 -34298 7767 -33250 9648 -29972 11823 -25645 14234 -19684 15712
--20768 10975 -15466 6648 -40163 -6374 -64881 12406 -30557 6630 -11607 -433
--34212 7853 -28802 4670 -24189 5774 -11391 10578 -16640 5680 -14466 12342
--15801 15329 -24261 7126 -30945 7084 -39603 8588 -32570 8267 -32349 4787
--35841 7508 -36206 3807 -37589 2388 -44989 4221 -60933 8018 -78397 8287
--80806 16731 -60932 17317 -55148 20231 -32832 14289 -24168 13711 -19000 27000
--27055 24315 -4362 13766 9260 10300 -11483 15087 -31648 7797 -35318 6748
--26010 7305 -11532 3806 -10233 3610 -14432 -1143 -28482 2891 -44451 6272
--53148 7075 -52479 3990 -41651 1459 -50991 8570 -55551 4323 -57424 1583
--52350 1013 -44276 6118 -43582 8655 -64362 6380 -47552 19183 -26799 12516
--25303 5112 -6233 17038 -12920 13050 -11410 10505 -24879 4803 -44226 3620
--52848 3578 -55515 6189 -43390 24181 -33146 19569 -41974 18160 -53804 5625
--41029 12698 -52014 8764 -47795 16854 -45446 16508 -36097 9269 -32954 3908
--37853 2887 -36699 1739 -32574 2469 -41919 1253 -37847 1627 -38802 3321
--36286 5730 -32155 3655 -32747 3849 -37106 2321 -41120 -465 -35840 -1552
--5888 -12716 5374 -8849 -4968 -1049 -37202 9638 -46267 4512 20350 -8747
--4535 -12700 -36501 -14291 -32384 -11852 -33371 -2262 -21492 -14857 -17330 -16608
-5222 -21025 3968 -13070 1182 -5944 -8603 -3179 -24008 -539 -25641 4605
-14594 -2768 13456 -11629 894 -3680 -34429 -2673 -6487 -8770 -16885 -9060
--25187 -8371 -31387 -4045 -28228 -3193 -29782 -202 -23694 666 -25340 2901
--35138 2034 -28462 1189 -27052 4650 -29474 13194 -35338 5205 -43346 -14511
--41293 -18891 -29311 -20745 -46175 -21252 -70199 -3554 -41730 1914 -20349 -5717
-4453 -12318 -14299 -1618 -5918 109 3171 6554 8298 9490 -4134 5905 -15736 2227
--17887 453 -18099 -638 -18563 -520 -38212 2055 -35355 -3561 -28107 -9440
--12445 -2438 -5504 -2827 -1983 -2983 -6259 -16099 -5967 -4613 1323 -1935
-7175 -1949 20056 -1629 11339 9218 43848 -3362 24497 50090 -7031 50408
--25002 50178 -53140 45153 -61555 41461 -68135 38889 -77404 25779 -84567 1932
--44135 6770 -50739 -3523 -52611 -10668 -44371 105 -41945 3108 -41167 3484
