[GRASS-SVN] r67716 - grass/trunk/locale/po
Tue Feb 2 10:23:06 PST 2016
Author: neteler
Date: 2016-02-02 10:23:06 -0800 (Tue, 02 Feb 2016)
New Revision: 67716
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fi.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ro.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
i18n: remove duplicate messages with msguniq
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_ar.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35654,7 +35654,8 @@
 msgid "Unable to tokenize column string: [%s]"
 msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#: ../vector/v.transform/main.c:277
+#: ../vector/v.transform/main.c:277 ../vector/v.to.3d/trans3.c:80
+#: ../vector/v.to.3d/trans2.c:79
 #, fuzzy
 msgid "Transforming features..."
 msgstr "التوقيع ..."
@@ -38650,11 +38651,6 @@
 msgid "Reading categories..."
 msgstr "وصل الفئات...\n"
-#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
-#, fuzzy
-msgid "Transforming features..."
-msgstr "التوقيع ..."
 #: ../vector/v.to.3d/trans3.c:101
 #, fuzzy, c-format
 msgid "Feature id %d has no category - skipping"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_cs.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36017,8 +36017,7 @@
 msgstr "Nelze zacyklit řetězec ve sloupci: [%s]"
-#, fuzzy
+#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
 msgstr "Převádím prvky..."
@@ -39047,10 +39046,6 @@
 msgstr "Přidávám kategorie..."
-msgstr "Převádím prvky..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_de.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36087,10 +36087,9 @@
 msgstr "Kann Spalten-Zeichenkette [%s] nicht tokenisieren"
-#, fuzzy
-msgstr "Transformiere Feature..."
+msgstr "Transformiere Objekte..."
 #: ../vector/v.transform/main.c:290
 #, fuzzy, c-format
@@ -39158,10 +39157,6 @@
 msgstr "Lese Kategorien..."
-msgstr "Transformiere Objekte..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_el.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -34269,10 +34269,14 @@
 msgstr "Αδυναμία ανοίγματος του χάρτη raster <%s>"
 #, fuzzy
-msgstr "Εγγραφή %s από %s..."
+msgstr ""
+"#-#-#-#-#  grassmods_el.po (grassmods_el)  #-#-#-#-#\n"
+"Εγγραφή %s από %s...\n"
 #, fuzzy, c-format
@@ -37123,10 +37127,6 @@
 msgstr "Χάρτης επαναφόρτισης σε  m^3/s"
-msgstr ""
 #, c-format
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_es.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36221,10 +36221,9 @@
 msgstr "a"
-#, fuzzy
-msgstr "Trasponiendo la matriz de valores propios..."
+msgstr "Transformando elementos..."
 #, fuzzy, c-format
@@ -39305,10 +39304,6 @@
 msgstr "Adjuntando categorías..."
-msgstr "Transformando elementos..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_fi.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -32834,7 +32834,8 @@
 msgstr ""
 msgstr ""
@@ -35595,10 +35596,6 @@
 msgstr ""
-msgstr ""
 #, c-format
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_fr.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -37866,7 +37866,8 @@
 msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
 #, fuzzy
 msgstr "Rotation des données ... "
@@ -41080,11 +41081,6 @@
 msgstr "Rattachement des catégories...\n"
-#, fuzzy
-msgstr "Rotation des données ... "
 # c-format
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_it.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35498,8 +35498,7 @@
 msgstr ""
-#, fuzzy
 msgstr "Trasformazione degli elementi in corso..."
@@ -38489,10 +38488,6 @@
 msgstr "Assegnazione delle categorie in corso..."
-msgstr "Trasformazione degli elementi in corso..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_ja.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35479,8 +35479,7 @@
 msgstr "列の文字を分割できません: [%s]"
-#, fuzzy
 msgstr "フィーチャーを変換中、、、"
@@ -38465,10 +38464,6 @@
 msgstr "カテゴリーを添付中、、、"
-msgstr "フィーチャーを変換中、、、"
 #, c-format
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_ko.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -34458,7 +34458,8 @@
 msgstr "출력할 격자지도"
 #, fuzzy
 msgstr "출력할 격자지도"
@@ -37330,11 +37331,6 @@
 msgstr "출력할 격자지도"
-#, fuzzy
-msgstr "출력할 격자지도"
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_lv.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35452,7 +35452,8 @@
 msgstr "Neiespējami atvērt šūnu failu[%s]"
 #, fuzzy
 msgstr "Drukā ... "
@@ -38492,11 +38493,6 @@
 msgstr "Pievieno kategorijas...\n"
-#, fuzzy
-msgstr "Drukā ... "
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_pl.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35568,10 +35568,9 @@
 msgstr "Nie mozna otworzyć pliku wejściowego <%s@%s>."
-#, fuzzy
-msgstr "Wczytywanie danych..."
+msgstr "Transformacja obiektów..."
 #, fuzzy, c-format
@@ -38572,10 +38571,6 @@
 msgstr "Dołączanie kategorii..."
-msgstr "Transformacja obiektów..."
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_pt.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36573,7 +36573,8 @@
 msgstr "Não consegui usar a coluna '%s'"
 #, fuzzy
 msgstr "Rotacionando dados ... "
@@ -39660,11 +39661,6 @@
 msgstr "Anexando categorias...\n"
-#, fuzzy
-msgstr "Rotacionando dados ... "
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36494,7 +36494,8 @@
 #, fuzzy
@@ -39586,11 +39587,6 @@
-#, fuzzy
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_ro.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -33403,9 +33403,9 @@
 msgstr ""
-msgstr ""
+msgstr "Transformarea trăsăturilor..."
 #, c-format
@@ -36257,10 +36257,6 @@
 msgstr ""
-msgstr "Transformarea trăsăturilor..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_ru.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36140,8 +36140,7 @@
 msgstr "Невозможно разбить строку %s"
-#, fuzzy
 msgstr "Трансформирование объектов..."
@@ -39194,10 +39193,6 @@
 msgstr "Присоединение категорий..."
-msgstr "Трансформирование объектов..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_sl.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35921,7 +35921,8 @@
 msgstr "Ne morem odpreti cellfile za [%s]"
 #, fuzzy
 msgstr "Ri¹em ..."
@@ -38937,11 +38938,6 @@
 msgstr "Pripajam kategorije...\n"
-#, fuzzy
-msgstr "Ri¹em ..."
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_th.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35758,7 +35758,8 @@
 msgstr "ไม่สามารถ  tokenize Column string: %s"
 #, fuzzy
 msgstr "กำลังอ่านข้อมูล ..."
@@ -38781,11 +38782,6 @@
 msgstr "กำลังแนบ หมวดหมู่ ..."
-#, fuzzy
-msgstr "กำลังอ่านข้อมูล ..."
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_tr.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35111,7 +35111,8 @@
 msgstr "<%s> sütunu kullanılamıyor"
 #, fuzzy
 msgstr "Veri okunuyor..."
@@ -38059,11 +38060,6 @@
 msgstr "Kategoriler ekleniyor..."
-#, fuzzy
-msgstr "Veri okunuyor..."
 #, fuzzy, c-format
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_vi.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -36147,8 +36147,7 @@
 msgstr "Không thể thẻ hoá chuỗi cột: [%s]"
-#, fuzzy
 msgstr "Đang chuyển đổi các đối tượng..."
 msgstr "Đang gắn các phạm trù..."
-msgstr "Đang chuyển đổi các đối tượng..."
 #, c-format
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2016-02-02 18:01:32 UTC (rev 67715)
+++ grass/trunk/locale/po/grassmods_zh.po	2016-02-02 18:23:06 UTC (rev 67716)
@@ -35839,7 +35839,8 @@
 msgstr "无法打开输出文件 <%s>"
 #, fuzzy
 msgstr "读取地图"
@@ -38845,11 +38846,6 @@
 msgstr "分类...\n"
-#, fuzzy
-msgstr "读取地图"
 #, fuzzy, c-format
