[GRASS-SVN] r67773 - grass/branches/releasebranch_7_0/gui/wxpython/psmap
Sun Feb 7 13:58:37 PST 2016
Author: annakrat
Date: 2016-02-07 13:58:37 -0800 (Sun, 07 Feb 2016)
New Revision: 67773
   grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
   grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
wxGUI/psmap: fix #2852 - fit frame to match current region (merge from trunk, r67608)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py	2016-02-07 21:56:11 UTC (rev 67772)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/dialogs.py	2016-02-07 21:58:37 UTC (rev 67773)
@@ -1071,15 +1071,8 @@
             mapFrameDict['scale'] = self.scale[2]
             mapFrameDict['center'] = self.center[2]
+            region = grass.region()
-            env = grass.gisenv()
-            windFilePath = os.path.join(env['GISDBASE'], env['LOCATION_NAME'], env['MAPSET'], 'WIND')
-            try:
-                windFile = open(windFilePath, 'r').read()
-                region = grass.parse_key_val(windFile, sep = ':', val_type = float)
-            except IOError:
-                region = grass.region()
             raster = self.instruction.FindInstructionByType('raster')
             if raster:
                 rasterId = raster.id
@@ -1087,11 +1080,11 @@
                 rasterId = None
             if rasterId: # because of resolution
-                RunCommand('g.region', n = region['north'], s = region['south'],
-                            e = region['east'], w = region['west'], rast = self.instruction[rasterId]['raster'])
+                RunCommand('g.region', n=region['n'], s=region['s'],
+                            e=region['e'], w=region['w'], rast=self.instruction[rasterId]['raster'])
             else:
-                           e = region['east'], w = region['west'])
+                           e=region['e'], w=region['w'])
         elif scaleType == 3:
             mapFrameDict['drawMap'] = False
Modified: grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py
--- grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py	2016-02-07 21:56:11 UTC (rev 67772)
+++ grass/branches/releasebranch_7_0/gui/wxpython/psmap/utils.py	2016-02-07 21:58:37 UTC (rev 67773)
@@ -213,16 +213,7 @@
         res = grass.read_command("g.region", flags = 'gu', region = region)
         currRegionDict = grass.parse_key_val(res, val_type = float)
     elif scaleType == 2: # current region
-        try:
-        except IOError:
-            currRegionDict = grass.region()
-        regionDict = grass.parse_key_val(windFile, sep = ':', val_type = float)
-        region = grass.read_command("g.region", flags = 'gu', n = regionDict['north'], s = regionDict['south'],
-                                    e = regionDict['east'], w = regionDict['west'])
-        currRegionDict = grass.parse_key_val(region, val_type = float)
+        currRegionDict = grass.region()
     else:
         return None, None, None
