[GRASS-SVN] r67818 - grass-addons/grass7/raster/r.futures/r.futures.pga
Fri Feb 12 13:16:38 PST 2016
Author: wenzeslaus
Date: 2016-02-12 13:16:38 -0800 (Fri, 12 Feb 2016)
New Revision: 67818
   grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
r.futures: change types of variables to smaller types to save memory (changes results) and use GRASS malloc (see also r67807)
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
--- grass-addons/grass7/raster/r.futures/r.futures.pga/main.c	2016-02-11 18:12:56 UTC (rev 67817)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/main.c	2016-02-12 21:16:38 UTC (rev 67818)
@@ -129,13 +129,13 @@
     int cellID;
     /** value of the logit */
-    double logitVal;
+    float logitVal;
     /** whether or not cell previously considered...need to use this in the sort */
-    int bUntouched;
+    bool bUntouched;
     /** to support random pick based on their logitVal */
-    double cumulProb;
+    float cumulProb;
 } t_Undev;
 typedef struct
@@ -378,10 +378,10 @@
     pLandscape->totalCells = pLandscape->maxX * pLandscape->maxY;
     pLandscape->asCells =
-        (t_Cell *) malloc(sizeof(t_Cell) * pLandscape->totalCells);
+        (t_Cell *) G_malloc(sizeof(t_Cell) * pLandscape->totalCells);
     if (pLandscape->asCells) {
         /* just allocate enough space for every cell to be undev */
-        pLandscape->asUndev = (t_Undev *) malloc(sizeof(t_Undev) * pLandscape->totalCells);
+        pLandscape->asUndev = (t_Undev *) G_malloc(sizeof(t_Undev) * pLandscape->totalCells);
         if (pLandscape->asUndev) {
             bRet = 1;
@@ -1810,6 +1810,7 @@
     int i;
     for (i = 0; i < pLandscape->num_undevSites[regionID]; i++) {
+        // TODO: these might not me initialized (says also valgrind)
         if (p < pLandscape->asUndevs[regionID][i].cumulProb) {
             G_debug(3, _("getUnDevIndex1: cumulProb=%f"),
                               pLandscape->asUndevs[regionID][i].cumulProb);
@@ -1895,6 +1896,7 @@
     int j;
     for (j = 0; j < pParams->num_Regions; j++) {
+        // TODO: value of pLandscape->asUndevs[j][0].cumulProb is what?
         double sum = pLandscape->asUndevs[j][0].logitVal;
         for (i = 1; i < pLandscape->num_undevSites[j]; i++) {
