[GRASS-SVN] r67982 - in grass-addons/grass7/raster/r.futures: r.futures.calib r.futures.pga r.futures.potential
Mon Feb 29 20:19:54 PST 2016
Author: annakrat
Date: 2016-02-29 20:19:54 -0800 (Mon, 29 Feb 2016)
New Revision: 67982
   grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
   grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
   grass-addons/grass7/raster/r.futures/r.futures.potential/r.futures.potential.py
r.futures: reorder options in PGA; better solution for null values in Potential, add parser rules in calibration module
Modified: grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
--- grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py	2016-03-01 02:45:32 UTC (rev 67981)
+++ grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py	2016-03-01 04:19:54 UTC (rev 67982)
@@ -9,7 +9,7 @@
 # PURPOSE:      FUTURES patches calibration tool
-# COPYRIGHT:    (C) 2015 by the GRASS Development Team
+# COPYRIGHT:    (C) 2016 by the GRASS Development Team
 #               This program is free software under the GNU General Public
 #               License (>=v2). Read the file COPYING that comes with GRASS
@@ -38,7 +38,7 @@
 #% type: integer
 #% key: repeat
 #% description: How many times is the simulation repeated
-#% required: yes
+#% required: no
 #% answer: 10
 #% guisection: Calibration
 #%end
@@ -46,7 +46,7 @@
 #% key: compactness_mean
 #% type: double
 #% description: Patch compactness mean to be tested
-#% required: yes
+#% required: no
 #% multiple: yes
 #%end
@@ -54,7 +54,7 @@
 #% type: double
 #% key: compactness_range
 #% description: Patch compactness range to be tested
-#% required: yes
+#% required: no
 #% multiple: yes
 #%end
@@ -64,7 +64,7 @@
 #% description: Patch size discount factor
 #% key: discount_factor
 #% multiple: yes
-#% required: yes
+#% required: no
 #%end
 #%option
@@ -84,7 +84,7 @@
 #%option G_OPT_F_OUTPUT
 #% key: calibration_results
 #% description: Output file with calibration results
-#% required: yes
+#% required: no
 #%end
 #%option
@@ -97,7 +97,7 @@
 #%end
 #%option G_OPT_R_INPUT
 #% key: development_pressure
-#% required: yes
+#% required: no
 #% description: Raster map of development pressure
 #% guisection: PGA
 #%end
@@ -110,7 +110,7 @@
 #%end
 #%option G_OPT_R_INPUTS
 #% key: predictors
-#% required: yes
+#% required: no
 #% multiple: yes
 #% description: Names of predictor variable raster maps
 #% guisection: PGA
@@ -119,12 +119,12 @@
 #% key: n_dev_neighbourhood
 #% type: integer
 #% description: Size of square used to recalculate development pressure
-#% required: yes
+#% required: no
 #% guisection: PGA
 #%end
 #%option G_OPT_F_INPUT
 #% key: devpot_params
-#% required: yes
+#% required: no
 #% multiple: yes
 #% label: Development potential parameters for each region
 #% description: Each line should contain region ID followed by parameters. Values are separated by whitespace (spaces or tabs). First line is ignored, so it can be used for header
@@ -132,14 +132,14 @@
 #%end
 #% key: incentive_table
-#% required: yes
+#% required: no
 #% description: File containing incentive lookup table (infill vs. sprawl)
 #% guisection: PGA
 #%end
 #%option
 #% key: num_neighbors
 #% type: integer
-#% required: yes
+#% required: no
 #% multiple: no
 #% options: 4,8
 #% answer: 4
@@ -149,7 +149,7 @@
 #%option
 #% key: seed_search
 #% type: integer
-#% required: yes
+#% required: no
 #% multiple: no
 #% options: 1,2
 #% answer: 2
@@ -159,7 +159,7 @@
 #%option
 #% key: development_pressure_approach
 #% type: string
-#% required: yes
+#% required: no
 #% multiple: no
 #% options: occurrence,gravity,kernel
 #% answer: gravity
@@ -169,7 +169,7 @@
 #%option
 #% key: gamma
 #% type: double
-#% required: yes
+#% required: no
 #% multiple: no
 #% description: Influence of distance between neighboring cells
 #% guisection: PGA
@@ -177,9 +177,9 @@
 #%option
 #% key: scaling_factor
 #% type: double
-#% required: yes
+#% required: no
 #% multiple: no
-#% description: Scaling factor
+#% description: Scaling factor of development pressure
 #% guisection: PGA
 #%end
 #%option
@@ -198,12 +198,53 @@
 #%end
 #% key: demand
-#% required: yes
+#% required: no
 #% description: Control file with number of cells to convert
 #% guisection: PGA
 #%end
+#%flag
+#% key: l
+#% description: Only create patch size distribution file
+#% guisection: Calibration
+#%end
+#%rules
+#% collective: demand,scaling_factor,gamma,development_pressure_approach,seed_search,num_neighbors,incentive_table,devpot_params,n_dev_neighbourhood,predictors,development_pressure,calibration_results,discount_factor,compactness_range,compactness_mean,repeat
+#% exclusive: -l,demand
+#% exclusive: -l,num_steps
+#% exclusive: -l,scaling_factor
+#% exclusive: -l,gamma
+#% exclusive: -l,development_pressure_approach
+#% exclusive: -l,seed_search
+#% exclusive: -l,num_neighbors
+#% exclusive: -l,incentive_table
+#% exclusive: -l,devpot_params
+#% exclusive: -l,n_dev_neighbourhood
+#% exclusive: -l,predictors
+#% exclusive: -l,constrain_weight
+#% exclusive: -l,calibration_results
+#% exclusive: -l,discount_factor
+#% exclusive: -l,compactness_range
+#% exclusive: -l,compactness_mean
+#% exclusive: -l,repeat
+#% required: -l,demand
+#% required: -l,scaling_factor
+#% required: -l,gamma
+#% required: -l,development_pressure_approach
+#% required: -l,seed_search
+#% required: -l,num_neighbors
+#% required: -l,incentive_table
+#% required: -l,devpot_params
+#% required: -l,n_dev_neighbourhood
+#% required: -l,predictors
+#% required: -l,calibration_results
+#% required: -l,discount_factor
+#% required: -l,compactness_range
+#% required: -l,compactness_mean
+#% required: -l,repeat
+#%end
 import sys
 import os
 import atexit
@@ -366,10 +407,12 @@
 def main():
     dev_start = options['development_start']
     dev_end = options['development_end']
-    repeat = int(options['repeat'])
-    compactness_means = [float(each) for each in options['compactness_mean'].split(',')]
-    compactness_ranges = [float(each) for each in options['compactness_range'].split(',')]
-    discount_factors = [float(each) for each in options['discount_factor'].split(',')]
+    only_file = flags['l']
+    if not only_file:
+        repeat = int(options['repeat'])
+        compactness_means = [float(each) for each in options['compactness_mean'].split(',')]
+        compactness_ranges = [float(each) for each in options['compactness_range'].split(',')]
+        discount_factors = [float(each) for each in options['discount_factor'].split(',')]
     patches_file = options['patch_sizes']
     threshold = float(options['patch_threshold'])
     # v.clean removes size <= threshold, we want to keep size == threshold
@@ -397,9 +440,12 @@
     gcore.message(_("Analyzing original patches..."))
     diff_development(dev_start, dev_end, options['subregions'], orig_patch_diff)
     patch_analysis(orig_patch_diff, threshold, tmp_patch_vect, tmp_patch_vect2, temp_file.name)
+    if only_file:
+        write_patches_file(tmp_patch_vect, cell_size, patches_file)
+        return
     area, perimeter = np.loadtxt(fname=temp_file.name, unpack=True)
     compact = compactness(area, perimeter)
-    write_patches_file(tmp_patch_vect, cell_size, patches_file)
     # area histogram
     area = area / cell_size
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
--- grass-addons/grass7/raster/r.futures/r.futures.pga/main.c	2016-03-01 02:45:32 UTC (rev 67981)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/main.c	2016-03-01 04:19:54 UTC (rev 67982)
@@ -1453,6 +1453,34 @@
         _("Raster map of developed areas (=1), undeveloped (=0) and excluded (no data)");
     opt.developedFile->guisection = _("Basic input");
+    opt.indexFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.indexFile->key = "subregions";
+    opt.indexFile->required = YES;
+    opt.indexFile->description = _("Raster map of subregions");
+    opt.indexFile->guisection = _("Basic input");
+    opt.dumpFile = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt.dumpFile->key = "output";
+    opt.dumpFile->required = YES;
+    opt.dumpFile->description =
+        _("State of the development at the end of simulation");
+    opt.dumpFile->guisection = _("Output");
+    opt.outputSeries = G_define_standard_option(G_OPT_R_BASENAME_OUTPUT);
+    opt.outputSeries->key = "output_series";
+    opt.outputSeries->required = NO;
+    opt.outputSeries->label =
+        _("Basename for raster maps of development generated after each step");
+    opt.outputSeries->guisection = _("Output");
+    opt.numSteps = G_define_option();
+    opt.numSteps->key = "num_steps";
+    opt.numSteps->type = TYPE_INTEGER;
+    opt.numSteps->required = NO;
+    opt.numSteps->description =
+        _("Number of steps to be simulated");
+    opt.numSteps->guisection = _("Basic input");
     opt.addVariableFiles = G_define_standard_option(G_OPT_R_INPUTS);
     opt.addVariableFiles->key = "predictors";
     opt.addVariableFiles->required = YES;
@@ -1461,14 +1489,6 @@
     opt.addVariableFiles->description = _("Listed in the same order as in the development potential table");
     opt.addVariableFiles->guisection = _("Potential");
-    opt.controlFileAll = G_define_standard_option(G_OPT_F_INPUT);
-    opt.controlFileAll->key = "demand";
-    opt.controlFileAll->required = YES;
-    opt.controlFileAll->description =
-        _("Control file with number of cells to convert");
-    opt.controlFileAll->guisection = _("Demand");
     opt.devpotParamsFile = G_define_standard_option(G_OPT_F_INPUT);
     opt.devpotParamsFile->key = "devpot_params";
     opt.devpotParamsFile->required = YES;
@@ -1477,10 +1497,58 @@
     opt.devpotParamsFile->description =
         _("Each line should contain region ID followed"
           " by parameters (intercepts, development pressure, other predictors)."
-          " Values are separated by whitespace (spaces or tabs)."
+          " Values are separated by tabs."
           " First line is ignored, so it can be used for header");
     opt.devpotParamsFile->guisection = _("Potential");
+    opt.devPressureFile = G_define_standard_option(G_OPT_R_INPUT);
+    opt.devPressureFile->key = "development_pressure";
+    opt.devPressureFile->required = YES;
+    opt.devPressureFile->description =
+        _("Raster map of development pressure");
+    opt.devPressureFile->guisection = _("Development pressure");
+    opt.nDevNeighbourhood = G_define_option();
+    opt.nDevNeighbourhood->key = "n_dev_neighbourhood";
+    opt.nDevNeighbourhood->type = TYPE_INTEGER;
+    opt.nDevNeighbourhood->required = YES;
+    opt.nDevNeighbourhood->description =
+        _("Size of square used to recalculate development pressure");
+    opt.nDevNeighbourhood->guisection = _("Development pressure");
+    opt.devPressureApproach = G_define_option();
+    opt.devPressureApproach->key = "development_pressure_approach";
+    opt.devPressureApproach->type = TYPE_STRING;
+    opt.devPressureApproach->required = YES;
+    opt.devPressureApproach->options = "occurrence,gravity,kernel";
+    opt.devPressureApproach->description =
+        _("Approaches to derive development pressure");
+    opt.devPressureApproach->answer = "gravity";
+    opt.devPressureApproach->guisection = _("Development pressure");
+    opt.alpha = G_define_option();
+    opt.alpha->key = "gamma";
+    opt.alpha->type = TYPE_DOUBLE;
+    opt.alpha->required = YES;
+    opt.alpha->description =
+        _("Influence of distance between neighboring cells");
+    opt.alpha->guisection = _("Development pressure");
+    opt.scalingFactor = G_define_option();
+    opt.scalingFactor->key = "scaling_factor";
+    opt.scalingFactor->type = TYPE_DOUBLE;
+    opt.scalingFactor->required = YES;
+    opt.scalingFactor->description =
+        _("Scaling factor of development pressure");
+    opt.scalingFactor->guisection = _("Development pressure");
+    opt.controlFileAll = G_define_standard_option(G_OPT_F_INPUT);
+    opt.controlFileAll->key = "demand";
+    opt.controlFileAll->required = YES;
+    opt.controlFileAll->description =
+        _("Control file with number of cells to convert");
+    opt.controlFileAll->guisection = _("Demand");
     opt.discountFactor = G_define_option();
     opt.discountFactor->key = "discount_factor";
     opt.discountFactor->type = TYPE_DOUBLE;
@@ -1531,61 +1599,7 @@
         _("File containing list of patch sizes to use");
     opt.parcelSizeFile->guisection = _("PGA");
-    opt.devPressureFile = G_define_standard_option(G_OPT_R_INPUT);
-    opt.devPressureFile->key = "development_pressure";
-    opt.devPressureFile->required = YES;
-    opt.devPressureFile->description =
-        _("Raster map of development pressure");
-    opt.devPressureFile->guisection = _("Development pressure");
-    opt.nDevNeighbourhood = G_define_option();
-    opt.nDevNeighbourhood->key = "n_dev_neighbourhood";
-    opt.nDevNeighbourhood->type = TYPE_INTEGER;
-    opt.nDevNeighbourhood->required = YES;
-    opt.nDevNeighbourhood->description =
-        _("Size of square used to recalculate development pressure");
-    opt.nDevNeighbourhood->guisection = _("Development pressure");
-    opt.devPressureApproach = G_define_option();
-    opt.devPressureApproach->key = "development_pressure_approach";
-    opt.devPressureApproach->type = TYPE_STRING;
-    opt.devPressureApproach->required = YES;
-    opt.devPressureApproach->options = "occurrence,gravity,kernel";
-    opt.devPressureApproach->description =
-        _("Approaches to derive development pressure");
-    opt.devPressureApproach->answer = "gravity";
-    opt.devPressureApproach->guisection = _("Development pressure");
-    opt.alpha = G_define_option();
-    opt.alpha->key = "gamma";
-    opt.alpha->type = TYPE_DOUBLE;
-    opt.alpha->required = YES;
-    opt.alpha->description =
-        _("Influence of distance between neighboring cells");
-    opt.alpha->guisection = _("Development pressure");
-    opt.scalingFactor = G_define_option();
-    opt.scalingFactor->key = "scaling_factor";
-    opt.scalingFactor->type = TYPE_DOUBLE;
-    opt.scalingFactor->required = YES;
-    opt.scalingFactor->description =
-        _("Scaling factor");
-    opt.scalingFactor->guisection = _("Development pressure");
-    opt.indexFile = G_define_standard_option(G_OPT_R_INPUT);
-    opt.indexFile->key = "subregions";
-    opt.indexFile->required = YES;
-    opt.indexFile->description = _("Raster map of subregions with categories starting with 1");
-    opt.indexFile->guisection = _("Basic input");
-    opt.numSteps = G_define_option();
-    opt.numSteps->key = "num_steps";
-    opt.numSteps->type = TYPE_INTEGER;
-    opt.numSteps->required = NO;
-    opt.numSteps->description =
-        _("Number of steps to be simulated");
-    opt.numSteps->guisection = _("Basic input");
     opt.probLookupFile = G_define_standard_option(G_OPT_F_INPUT);
     opt.probLookupFile->key = "incentive_table";
     opt.probLookupFile->required = YES;
@@ -1623,19 +1637,6 @@
           " generator (use when you don't want to provide the seed option)");
     flg.generateSeed->guisection = _("Random numbers");
-    opt.dumpFile = G_define_standard_option(G_OPT_R_OUTPUT);
-    opt.dumpFile->key = "output";
-    opt.dumpFile->required = YES;
-    opt.dumpFile->description =
-        _("State of the development at the end of simulation");
-    opt.dumpFile->guisection = _("Output");
-    opt.outputSeries = G_define_standard_option(G_OPT_R_BASENAME_OUTPUT);
-    opt.outputSeries->key = "output_series";
-    opt.outputSeries->required = NO;
-    opt.outputSeries->label =
-        _("Basename for raster maps of development generated after each step");
-    opt.outputSeries->guisection = _("Output");
     // TODO: add mutually exclusive?
     // TODO: add flags or options to control values in series and final rasters
Modified: grass-addons/grass7/raster/r.futures/r.futures.potential/r.futures.potential.py
--- grass-addons/grass7/raster/r.futures/r.futures.potential/r.futures.potential.py	2016-03-01 02:45:32 UTC (rev 67981)
+++ grass-addons/grass7/raster/r.futures/r.futures.potential/r.futures.potential.py	2016-03-01 04:19:54 UTC (rev 67982)
@@ -97,7 +97,7 @@
 interc <- paste("(1|", opt$level, ")")
 fmla <- as.formula(paste(opt$response, " ~ ", paste(c(predictors, interc), collapse= "+")))
-model = glmer(formula=fmla, family = binomial, data=input_data, na.action = "na.omit")
+model = glmer(formula=fmla, family = binomial, data=input_data, na.action = "na.fail")
 if(opt$usedredge) {
     #create all possible models, always include county as the level
@@ -145,7 +145,10 @@
     TMP_POT = gscript.tempfile(create=False) + '_potential.csv'
     columns += [binary, level]
-    gscript.run_command('v.db.select', map=vinput, columns=columns, separator='comma', file=TMP_CSV)
+    where = "{c} IS NOT NULL".format(c=columns[0])
+    for c in columns[1:]:
+        where += " AND {c} IS NOT NULL".format(c=c)
+    gscript.run_command('v.db.select', map=vinput, columns=columns, separator='comma', where=where, file=TMP_CSV)
     if dredge:
         gscript.info(_("Running automatic model selection ..."))
