[GRASS-SVN] r67485 - in grass/trunk/lib/python/temporal: . testsuite
Mon Jan 4 16:10:15 PST 2016
Author: huhabla
Date: 2016-01-04 16:10:15 -0800 (Mon, 04 Jan 2016)
New Revision: 67485
   grass/trunk/lib/python/temporal/temporal_algebra.py
   grass/trunk/lib/python/temporal/temporal_granularity.py
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
temporal framework: Improved common granularity computation and related fixes
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py	2016-01-04 23:26:26 UTC (rev 67484)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py	2016-01-05 00:10:15 UTC (rev 67485)
@@ -767,7 +767,7 @@
              space time datasets in the expression to generate the map lists.
              This function will analyze the expression to detect space time datasets
-             and computes the common granularity  from all granularities.
+             and computes the common granularity from all granularities.
              This granularity is then be used to generate the map lists. Hence, all
              maps from all STDS will have equidistant temporal extents. The only meaningful
@@ -817,6 +817,7 @@
             count += 1
         grans = []
+        start_times = []
         ttypes = {}
         dbif, connected = init_dbif(self.dbif)
@@ -828,6 +829,7 @@
                 return False
             grans.append(stds.get_granularity())
+            start_times.append(stds.get_temporal_extent_as_tuple()[0])
             ttypes[stds.get_temporal_type()] = stds.get_temporal_type()
         # Only one temporal type is allowed
@@ -837,7 +839,7 @@
         # Compute the common granularity
         if "absolute" in ttypes.keys():
-            self.granularity = compute_common_absolute_time_granularity(grans)
+            self.granularity = compute_common_absolute_time_granularity(grans, start_times)
         else:
             self.granularity = compute_common_relative_time_granularity(grans)
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py	2016-01-04 23:26:26 UTC (rev 67484)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py	2016-01-05 00:10:15 UTC (rev 67485)
@@ -675,7 +675,10 @@
                 return "1 second"
         # Make sure the granule does not exceed the hierarchy limit
         if int(num) > 60:
-            return "60 seconds"
+            if int(num)%60 == 0:
+                return "60 seconds"
+            else:
+                return "1 second"
     if granule in ["minutes",  "minute"]:
         # If the start minutes are different between the start dates
@@ -685,7 +688,10 @@
                 return "1 minute"
         if int(num) > 60:
-            return "60 minutes"
+                return "60 minutes"
+            else:
+                return "1 minute"
     if granule in ["hours",  "hour"]:
         # If the start hours are different between the start dates
@@ -695,7 +701,10 @@
                 return "1 hour"
         if int(num) > 24:
-            return "24 hours"
+            if int(num)%24 == 0:
+                return "24 hours"
+            else:
+                return "1 hour"
     if granule in ["days",  "day"]:
         # If the start days are different between the start dates
@@ -705,7 +714,10 @@
                 return "1 day"
         if int(num) > 365:
-            return "365 days"
+            if int(num)%365 == 0:
+                return "365 days"
+            else:
+                return "1 day"
     if granule in ["months",  "month"]:
         # If the start months are different between the start dates
@@ -715,7 +727,10 @@
                 return "1 month"
         if int(num) > 12:
-            return "12 months"
+            if int(num)%12 == 0:
+                return "12 months"
+            else:
+                return "1 month"
     return common_granule
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py	2016-01-04 23:26:26 UTC (rev 67484)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py	2016-01-05 00:10:15 UTC (rev 67485)
@@ -77,12 +77,12 @@
     def test_common_granularity_1(self):
         """Testing the common granularity function. """
-        ta = tgis.TemporalAlgebraParser(run = True, debug = True)
+        ta = tgis.TemporalAlgebraParser(run=True, debug=True)
         expr = 'R = A : B'
         ret = ta.setup_common_granularity(expression=expr)
         self.assertEqual(ret, True)
-        self.assertEqual(ta.granularity, "1 months")
+        self.assertEqual(ta.granularity, "1 month")
         ta.count = 0
         ta.stdstype = "strds"
