[GRASS-SVN] r67495 - grass-addons/grass7/vector/v.mapcalc
Tue Jan 5 19:23:04 PST 2016
Author: wenzeslaus
Date: 2016-01-05 19:23:04 -0800 (Tue, 05 Jan 2016)
New Revision: 67495
   grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html
   grass-addons/grass7/vector/v.mapcalc/v.mapcalc.py
v.mapcalc: updates for 7.x release, PEP8 compliance
Modified: grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html
--- grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html	2016-01-06 03:05:44 UTC (rev 67494)
+++ grass-addons/grass7/vector/v.mapcalc/v.mapcalc.html	2016-01-06 03:23:04 UTC (rev 67495)
@@ -71,17 +71,17 @@
 This example needed specific region setting. It should work in UTM and LL test locations. <br>
 First set the regions extent and create two vector maps with one random points, respectively:
 <div class="code"><pre>
-g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+g.region s=0 n=30 w=0 e=50 b=0 t=50 res=10 res3=10 -p3
-v.random --o -z output=point_1 n=1 seed=1
+v.random --o -z output=point_1 n=1 seed=1
+v.random --o -z output=point_2 n=1 seed=2
 v.info point_1
-v.random --o -z output=point_2 n=1 seed=2
 v.info point_2
 </pre></div>
 Then the vector algebra is used to create buffers around those points, cut out a subset and apply different boolean operation on the subsets in one statement:
-v.mapcalc --o expr="buff_and = (buff_p(point_1, 30.0) ~ buff_p(point_1, 20.0)) & \
+v.mapcalc --o expr="buff_and = (buff_p(point_1, 30.0) ~ buff_p(point_1, 20.0)) & \
                     (buff_p(point_2, 35) ~ buff_p(point_2, 25))"
 v.mapcalc --o expr="buff_or  = (buff_p(point_1, 30.0) ~ buff_p(point_1, 20.0)) | \
Modified: grass-addons/grass7/vector/v.mapcalc/v.mapcalc.py
--- grass-addons/grass7/vector/v.mapcalc/v.mapcalc.py	2016-01-06 03:05:44 UTC (rev 67494)
+++ grass-addons/grass7/vector/v.mapcalc/v.mapcalc.py	2016-01-06 03:23:04 UTC (rev 67495)
@@ -1,19 +1,17 @@
 #!/usr/bin/env python
 # -*- coding: utf-8 -*-
-# MODULE:       v.mapcalc
-# AUTHOR(S):    Thomas Leppelt, Soeren Gebbert, Thünen Institut Germany,
-# PURPOSE:      Vector map algebra
-# COPYRIGHT:    (C) 2011 by the GRASS Development Team
-#               This program is free software under the GNU General
-#               Public License (>=v2). Read the file COPYING that
-#               comes with GRASS for details.
+MODULE:       v.mapcalc
+AUTHOR(S):    Thomas Leppelt, Soeren Gebbert, Thünen Institut Germany,
+PURPOSE:      Vector map algebra
+COPYRIGHT:    (C) 2013-2015 by the GRASS Development Team
+              This program is free software under the GNU General
+              Public License (>=v2). Read the file COPYING that
+              comes with GRASS for details.
 #%module
 #% description: Vector algebra
 #% keywords: vector, mapcalc, algebra
@@ -23,7 +21,7 @@
 #% type: string
 #% description: The vector mapcalc expression
 #% key_desc: expression
-#% required : yes
+#% required: yes
 #%end
 import ply.lex as lex
@@ -34,37 +32,46 @@
 from grass.script import core as grass
 import grass.pygrass.modules as mod
 class CmdMapList(object):
     """Listing and execution of PyGRASS module objects"""
     def __init__(self):
         self.exec_list = []
     # Execute command list.
     def exec_cmd_list(self):
         for cmd in self.exec_list:
             cmd.run()
             if cmd.popen.returncode != 0:
-                grass.ScriptError("Error starting %s : \n%s"%(cmd.get_bash(), \
-                                                              cmd.popen.stderr))
-    # Print command list.
+                grass.ScriptError(
+                    "Error starting %s : \n%s" % (cmd.get_bash(),
+                                                  cmd.popen.stderr))
+    # Print command list.
     def get_cmd_list(self):
         print(self.exec_list)
     # Add new command to list.
     def add_cmd(self, newcmd):
         self.exec_list.append(newcmd)
 class VectorAlgebraLexer(object):
     """!Lexical analyzer for the GRASS GIS vector algebra"""
     # Buffer functions from v.buffer
     vector_buff_functions = {
-       'buff_p'  : 'BUFF_POINT',
-       'buff_l'   : 'BUFF_LINE',
-       'buff_a'   : 'BUFF_AREA'
+        'buff_p': 'BUFF_POINT',
+        'buff_l': 'BUFF_LINE',
+        'buff_a': 'BUFF_AREA'
     # This is the list of token names.
     tokens = (
-        'INT',
+        'INT',
         'FLOAT',
         'LPAREN',
         'RPAREN',
@@ -76,26 +83,26 @@
         'NOT',  # v.overlay
         'OR',  # v.overlay
         'XOR',  # v.overlay
-        'DISOR', # v.patch
+        'DISOR',  # v.patch
     # Build the token list
     tokens = tokens + tuple(vector_buff_functions.values())
     # Regular expression rules for simple tokens
-    t_LPAREN  = r'\('
-    t_RPAREN  = r'\)'
-    t_COMMA   = r','
-    t_EQUALS  = r'='
-    t_AND     = r'&'
-    t_NOT     = r'\~'
-    t_OR      = r'\|'
-    t_XOR     = r'\^'
-    t_DISOR   = r'\+'
+    t_LPAREN = r'\('
+    t_RPAREN = r'\)'
+    t_COMMA = r','
+    t_EQUALS = r'='
+    t_AND = r'&'
+    t_NOT = r'\~'
+    t_OR = r'\|'
+    t_XOR = r'\^'
+    t_DISOR = r'\+'
     # These are the things that should be ignored.
     t_ignore = ' \t'
     def __init__(self):
         self.name_list = {}
@@ -104,18 +111,18 @@
         r'-?\d+\.\d*(e-?\d+)?'
         t.value = float(t.value)
         return t
     # Read in an int.
     def t_INT(self, t):
         r'-?\d+'
         t.value = int(t.value)
         return t
     # Ignore comments.
     def t_comment(self, t):
         r'[#][^\n]*'
         pass
     # Track line numbers.
     def t_newline(self, t):
         r'\n+'
@@ -134,103 +141,107 @@
     # Handle errors.
     def t_error(self, t):
-        raise SyntaxError("syntax error on line %d near '%s'" %
-            (t.lineno, t.value))
+        raise SyntaxError("syntax error on line %d near '%s'" %
+                          (t.lineno, t.value))
     # Build the lexer
-    def build(self,**kwargs):
+    def build(self, **kwargs):
         self.lexer = lex.lex(module=self, **kwargs)
     # Just for testing
-    def test(self,data):
+    def test(self, data):
         self.name_list = {}
         self.lexer.input(data)
         while True:
-             tok = self.lexer.token()
-             if not tok: break
-             print tok
+            tok = self.lexer.token()
+            if not tok:
+                break
+            print tok
 class VectorAlgebraParser(object):
     """This is the vector algebra parser class"""
     # Get the tokens from the lexer class
     tokens = VectorAlgebraLexer.tokens
     # Setting equal precedence level for boolean operations.
     precedence = (
-        ('left', 'AND', 'OR', 'NOT', 'XOR', 'DISOR'), # 1
+        ('left', 'AND', 'OR', 'NOT', 'XOR', 'DISOR'),  # 1
     def __init__(self, pid=None, run=True, debug=False):
         self.run = run
         self.debug = debug
         self.pid = pid
         self.lexer = VectorAlgebraLexer()
         self.lexer.build()
-        # Intermediate vector map names
+        # Intermediate vector map names
         self.names = {}
         # Count map names
         self.count = 0
         self.parser = yacc.yacc(module=self)
         # Create empty command list object
-        self.cmdlist = CmdMapList()
+        self.cmdlist = CmdMapList()
     def parse(self, expression):
         self.count = 0
         self.parser.parse(expression)
     def generate_vector_map_name(self):
-        """!Generate an unique intermediate vector map name
+        """!Generate an unique intermediate vector map name
            and register it in the objects map list for later removement.
            The vector map names are unique between processes. Do not use the
            same object for map name generation in multiple threads.
         self.count += 1
-        if self.pid != None:
+        if self.pid is not None:
             pid = self.pid
         else:
             pid = os.getpid()
-        name = "tmp_vect_name_%i_%i"%(pid, self.count)
+        name = "tmp_vect_name_%i_%i" % (pid, self.count)
         self.names[name] = name
-        #print(name)
+        # print(name)
         return name
-    def p_statement_assign(self,t):
+    def p_statement_assign(self, t):
         statement : NAME EQUALS expression
                   | NAME EQUALS name
                   | NAME EQUALS paren_name
         # We remove the invalid vector name from the list
-        if self.names.has_key(t[3]):
+        if t[3] in self.names:
             self.names.pop(t[3])
         # We rename the resulting vector map
         if self.debug:
-            print "g.rename vector=%s,%s"%(t[3],t[1])
+            print "g.rename vector=%s,%s" % (t[3], t[1])
-	if self.run:
-	    m = mod.Module("g.rename", vect=(t[3],t[1]), overwrite=grass.overwrite,
-	                   run_ = False)
-	    self.cmdlist.add_cmd(m)
+        if self.run:
+            m = mod.Module('g.rename', vector=(t[3], t[1]),
+                           overwrite=grass.overwrite, run_=False)
+            self.cmdlist.add_cmd(m)
         self.remove_intermediate_vector_maps()
     def remove_intermediate_vector_maps(self):
         if self.debug:
             for name in self.names:
-                print "g.remove vect=%s"%(name)
+                print "g.remove type=vector name=%s -f" % (name)
         if self.run:
-	    for name in self.names:
-	        m = mod.Module("g.remove", vect=name, run_ = False)
+            for name in self.names:
+                m = mod.Module('g.remove', type='vector', name=name,
+                               flags='f', run_=False)
     def p_bool_and_operation(self, t):
         expression : name AND name
                    | expression AND name
                    | name AND expression
-                   | expression AND expression
+                   | expression AND expression
                    | name OR name
                    | expression OR name
                    | name OR expression
@@ -238,139 +249,140 @@
                    | name XOR name
                    | expression XOR name
                    | name XOR expression
-                   | expression XOR expression
+                   | expression XOR expression
                    | name NOT name
                    | expression NOT name
                    | name NOT expression
                    | expression NOT expression
-                   | name DISOR name
-                   | expression DISOR name
-                   | name DISOR expression
-                   | expression DISOR expression
+                   | name DISOR name
+                   | expression DISOR name
+                   | name DISOR expression
+                   | expression DISOR expression
         # Generate an intermediate name
         name = self.generate_vector_map_name()
         # Assign ids to expressions, names and operators.
-	firstid = 1
-	secondid = 3
-	operatorid = 2
-	# Define operation commands.
+        firstid = 1
+        secondid = 3
+        operatorid = 2
+        # Define operation commands.
         if t[operatorid] == "&":
             if self.debug:
                 print "v.overlay operator=and ainput=%s binput=%s output=%s"\
-                      %(t[firstid], t[secondid], name)
+                      % (t[firstid], t[secondid], name)
-	    if self.run:
-		m = mod.Module("v.overlay", operator="and", ainput=t[firstid], \
-		               binput=t[secondid], output=name, run_ = False)
+            if self.run:
+                m = mod.Module("v.overlay", operator="and", ainput=t[firstid],
+                               binput=t[secondid], output=name, run_=False)
             t[0] = name
         elif t[operatorid] == "|":
             if self.debug:
                 print "v.overlay operator=or ainput=%s binput=%s output=%s"\
-	    if self.run:
-		m = mod.Module("v.overlay", operator="or", ainput=t[firstid], \
+            if self.run:
+                m = mod.Module("v.overlay", operator="or", ainput=t[firstid],
             t[0] = name
         elif t[operatorid] == "^":
             if self.debug:
                 print "v.overlay operator=xor ainput=%s binput=%s output=%s"\
-	    if self.run:
-		m = mod.Module("v.overlay", operator="xor", ainput=t[firstid], \
+            if self.run:
+                m = mod.Module("v.overlay", operator="xor", ainput=t[firstid],
             t[0] = name
         elif t[operatorid] == "~":
             if self.debug:
                 print "v.overlay operator=not ainput=%s binput=%s output=%s"\
-	    if self.run:
-		m = mod.Module("v.overlay", operator="not", ainput=t[firstid], \
+            if self.run:
+                m = mod.Module("v.overlay", operator="not", ainput=t[firstid],
             t[0] = name
         elif t[operatorid] == "+":
-	    patchinput = t[firstid] + ',' + t[secondid]
+            patchinput = t[firstid] + ',' + t[secondid]
             if self.debug:
                 print "v.patch input=%s output=%s"\
-                      %(patchinput, name)
+                      % (patchinput, name)
-	    if self.run:
-		m = mod.Module("v.patch", input=patchinput, output=name, run_ = False)
+            if self.run:
+                m = mod.Module(
+                    "v.patch", input=patchinput, output=name, run_=False)
             t[0] = name
-    def p_buffer_operation(self,t):
+    def p_buffer_operation(self, t):
-        expression : buff_function LPAREN name COMMA number RPAREN
+        expression : buff_function LPAREN name COMMA number RPAREN
                    | buff_function LPAREN expression COMMA number RPAREN
-	mapid = 3
-	operatorid = 5
+        mapid = 3
+        operatorid = 5
         if t[1] == "buff_p":
             if self.debug:
                 print "v.buffer input=%s type=point distance=%g output=%s"\
-                      %(t[mapid], t[operatorid], name)
-	    if self.run:
-		m = mod.Module("v.buffer", type="point", input=t[mapid], \
-		               distance=float(t[operatorid]), output=name, \
-		               run_ = False)
+                      % (t[mapid], t[operatorid], name)
+            if self.run:
+                m = mod.Module("v.buffer", type="point", input=t[mapid],
+                               distance=float(t[operatorid]), output=name,
+                               run_=False)
             t[0] = name
         elif t[1] == "buff_l":
             if self.debug:
                 print "v.buffer input=%s type=line distance=%g output=%s"\
-	    if self.run:
-		m = mod.Module("v.buffer", type="line", input=t[mapid], \
-		               run_ = False)
+            if self.run:
+                m = mod.Module("v.buffer", type="line", input=t[mapid],
+                               run_=False)
             t[0] = name
         elif t[1] == "buff_a":
             if self.debug:
                 print "v.buffer input=%s type=area distance=%g output=%s"\
-	    if self.run:
-		m = mod.Module("v.buffer", type="area", input=t[mapid], \
-		               run_ = False)
+            if self.run:
+                m = mod.Module("v.buffer", type="area", input=t[mapid],
+                               run_=False)
             t[0] = name
     def p_paren_expr(self, t):
         """ expression : LPAREN expression RPAREN"""
         t[0] = t[2]
     def p_number_int(self, t):
         """number : INT"""
         t[0] = t[1]
     def p_number_float(self, t):
         """number : FLOAT"""
         t[0] = t[1]
     def p_name(self, t):
         """name : NAME
                 | SYMBOL
@@ -382,22 +394,23 @@
                       | LPAREN SYMBOL RPAREN
         t[0] = t[2]
     def p_buff_function(self, t):
         """buff_function    : BUFF_POINT
                             | BUFF_LINE
                             | BUFF_AREA
         t[0] = t[1]
     # Error rule for syntax errors.
-    def p_error(self,t):
+    def p_error(self, t):
         raise SyntaxError("invalid syntax")
 def main():
     expression = options['expression']
-    p = VectorAlgebraParser(run = True, debug=False)
+    p = VectorAlgebraParser(run=True, debug=False)
     p.parse(expression)
     p.cmdlist.get_cmd_list()
     p.cmdlist.exec_cmd_list()
@@ -405,4 +418,3 @@
 if __name__ == "__main__":
     options, flags = grass.parser()
     sys.exit(main())
