[GRASS-SVN] r67535 - grass/trunk/lib/python/pygrass
Sun Jan 10 03:11:03 PST 2016
Author: martinl
Date: 2016-01-10 03:11:03 -0800 (Sun, 10 Jan 2016)
New Revision: 67535
   grass/trunk/lib/python/pygrass/utils.py
pygrass: change dirname in set_path() to optional - this functions needs major revision
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py	2016-01-10 10:30:46 UTC (rev 67534)
+++ grass/trunk/lib/python/pygrass/utils.py	2016-01-10 11:11:03 UTC (rev 67535)
@@ -283,7 +283,7 @@
         raise ValueError('Raster map does not exist.')
-def get_lib_path(modname, libname):
+def get_lib_path(modname, libname=None):
     """Return the path of the libname contained in the module.
     from os.path import isdir, join
@@ -291,7 +291,7 @@
     if isdir(join(getenv('GISBASE'), 'etc', modname)):
         path = join(os.getenv('GISBASE'), 'etc', modname)
-    elif getenv('GRASS_ADDON_BASE') and \
+    elif getenv('GRASS_ADDON_BASE') and libname and \
             isdir(join(getenv('GRASS_ADDON_BASE'), 'etc', modname, libname)):
         path = join(getenv('GRASS_ADDON_BASE'), 'etc', modname, libname)
@@ -300,18 +300,23 @@
             isdir(join(getenv('GRASS_ADDON_BASE'), modname, modname)):
         path = join(os.getenv('GRASS_ADDON_BASE'), modname, modname)
-    elif isdir(join('..', libname)):
+    elif libname and isdir(join('..', libname)):
         path = join('..', libname)
     else:
         path = None
     return path
-def set_path(modulename, dirname, path='.'):
+def set_path(modulename, dirname=None, path='.'):
+    """Set sys.path looking in the the local directory GRASS directories."""
     import sys
-    """Set sys.path looking in the the local directory GRASS directories."""
-    pathlib = os.path.join(path, dirname)
-    if os.path.exists(pathlib):
+    # TODO: why dirname is checked first - the logic should be revised
+    # TODO  probably also 'path' should be also removed - it's used only by
+    #       compilation process for addons (see r.green for details)
+    pathlib = None
+    if dirname:
+        pathlib = os.path.join(path, dirname)
+    if pathlib and os.path.exists(pathlib):
         # we are running the script from the script directory
         sys.path.append(os.path.abspath(pathlib))
     else:
