[GRASS-SVN] r67546 - grass-addons/grass7/gui/wxpython/wx.mwprecip
Mon Jan 11 02:19:04 PST 2016
Author: krejcmat
Date: 2016-01-11 02:19:04 -0800 (Mon, 11 Jan 2016)
New Revision: 67546
   grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
   grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
   grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
   grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py
addons g.gui.mwprecip: add logger,  measuring elapsed time
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py	2016-01-11 09:44:55 UTC (rev 67545)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/g.gui.mwprecip.py	2016-01-11 10:19:04 UTC (rev 67546)
@@ -1,5 +1,5 @@
 #!/usr/bin/env python
-VERSION = 1.2
+VERSION = 1.3
 import sys
 import os
 import tempfile
@@ -20,7 +20,11 @@
 from gui_core.widgets import ColorTablesComboBox,PictureComboBox
 from core           import globalvar
 from core.utils     import  GetColorTables
+import wx.lib.scrolledpanel as scrolled
+import tempfile
+import logging
 class DBconn(wx.ScrolledWindow):
     def __init__(self, parent, settings={}):
         wx.ScrolledWindow.__init__(self, parent,  wx.ID_ANY, wx.DefaultPosition, wx.DefaultSize, wx.HSCROLL|wx.VSCROLL)
@@ -169,6 +173,10 @@
             self.loadSettings()
         self._layout()
+    def onChangeStatistic(self,evt=None):
+        if self.baselType.GetValue() == 'avg':
+            self.round.Disable()
+            self.quantile.Disable()
@@ -546,8 +554,11 @@
 class MWMainFrame(wx.Frame):
     def __init__(self, parent, id, title):
         wx.Frame.__init__(self, parent, id, title,style=wx.DEFAULT_FRAME_STYLE )
+        self.logger=None
         context=StaticContext()
         self.workPath = context.getTmpPath()
+        self.initLogger()
         self.initWorkingFoldrs()
         self.settings = {}
         self.settingsLst = []
@@ -615,6 +626,26 @@
         self.findProject()
         self.layout()
+    def initLogger(self):
+        logging.basicConfig(filename=os.path.join(self.workPath,'mwprecip.log'),
+                        level=logging.INFO,
+                        format='%(asctime)s %(name)-12s %(levelname)-8s %(message)s',
+                        datefmt='%m-%d %H:%M',
+                        filemode='w')
+        console = logging.StreamHandler()
+        console.setLevel(logging.INFO)
+        # set a format which is simpler for console use
+        formatter = logging.Formatter('%(name)-12s: %(levelname)-8s %(message)s')
+        # tell the handler to use this format
+        console.setFormatter(formatter)
+        # add the handler to the root logger
+        logging.getLogger('').addHandler(console)
+        self.logger=logging.getLogger('mwprecip.GUI')
     def onAbout(self,evt):
         dir=os.path.dirname(os.path.realpath(__file__))
         GMessage( "ver: %s \n %s"%(VERSION,dir),self)
@@ -652,7 +683,7 @@
     def OnLoadSettings(self, evt=None):
         currSelId = self.profilSelection.GetSelection()
         self.schema.SetValue(self.profilSelection.GetValue())
-        print  self.settingsLst[currSelId]
+        #print  self.settingsLst[currSelId]
         self.settings = self.settingsLst[currSelId]
         try:
@@ -695,15 +726,17 @@
             pass
         self.settings['workSchema'] = self.profilSelection.GetValue()
         if self.schema.GetValue() is not None:
             self.settings['workSchema'] = self.schema.GetValue()
         if toFile:
             tmpPath = os.path.join(self.workPath, "save", self.settings['workSchema'])
             saveDict(tmpPath, self.settings)
             self.findProject()
     def initWorkingFoldrs(self):
         savePath = os.path.join(self.workPath, 'save')
         if not os.path.exists(savePath):
             os.makedirs(savePath)
@@ -719,7 +752,7 @@
             GMessage('Cannot find "save" folder',self)
             return
         filePathList = getFilesInFoldr(projectDir, True)
-        print filePathList
+        #print filePathList
         # print 'filePathList',filePathList
         if filePathList != 0:
             self.profilSelection.Clear()
@@ -813,7 +846,7 @@
     def _onSetDatabaseDLG(self, evt):
         self.settings = self.databasePnl.saveSettings()
         self.dbDialog.Destroy()
     def createGeometry(self, type, name):
@@ -888,7 +921,7 @@
             lines = ''
             for r in res:
                 lines += str(r)[1:][:-1].replace('datetime.datetime', '').replace("'", "") + '\n'
-            print conn.pathworkSchemaDir
+            #print conn.pathworkSchemaDir
             #path=os.path.join(conn.pathworkSchemaDir, "export")
             io0 = open(path, "w+")
             io0.writelines(lines)
@@ -1023,7 +1056,6 @@
         conninfo['workPath'] = self.workPath
         if not info:  # prepare for computing
             self.dbConn = Database(**conninfo)
             self.connStatus = True
@@ -1180,3 +1212,4 @@
 if __name__ == "__main__":
     main()
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2016-01-11 09:44:55 UTC (rev 67545)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw3.py	2016-01-11 10:19:04 UTC (rev 67546)
@@ -3,6 +3,7 @@
 from math import sin, cos, atan2, degrees, tan, sqrt
 from datetime import datetime
+from datetime import timedelta
 import shutil
 import psycopg2
 import time
@@ -17,9 +18,13 @@
 import numpy as np
 from mw_util import *
+timeMes=MeasureTime()
+import logging
+logger = logging.getLogger('mwprecip.Computing')
 class PointInterpolation():
     def __init__(self, database, step, methodDist=False):
-        grass.message("Interpolating points along lines...")
+        timeMes.timeMsg("Interpolating points along lines...")
         self.step = float(step)
         self.database = database
         self.method = methodDist  # 'p' - points, else distance
@@ -89,6 +94,7 @@
         sql = "alter table %s.%s drop column long" % (
             self.database.schema, nametable)  # remove longtitude column from table
         self.database.connection.executeSql(sql, False, True)
+        timeMes.timeMsg("Interpolating points along lines-done")
     def destinationPointWGS(self, lat1, lon1, brng, s):
         a = 6378137
@@ -248,7 +254,7 @@
                 self.lon = float(f.next())
             f.close()
         except IOError as (errno, strerror):
-            grass.message( "I/O error({0}): {1}".format(errno, strerror))
+            grass.error( "I/O error({0}): {1}".format(errno, strerror))
         gaugeTMPfile = "gauge_tmp"
         removeLines(old_file=path,
@@ -265,7 +271,7 @@
                     tmp.append(stri)
                 f.close()
         # write list of string to database
         try:
@@ -273,7 +279,7 @@
                 io.writelines(tmp)
                 io.close()
         if not isTableExist(self.db.connection, self.schema, self.db.rgaugeTableName):
             # #create table for raingauge stations
@@ -308,15 +314,15 @@
     def __init__(self, type='noDryWin', pathToFile=None, statFce='quantile', quantile=97, roundMode=3, aw=0):
         if quantile is None:
             quantile=97
-            grass.message('Quantile is not defined. Default is 97')
+            logger.info('Quantile is not defined. Default is 97')
         self.quantile = quantile
         if roundMode is None:
             roundMode=3
-            grass.message('Round is not defined. Default is 3 decimal places')
+            logger.info('Round is not defined. Default is 3 decimal places')
         self.roundMode = roundMode
         if aw is None:
             aw=0
-            grass.message('Antena wetting value is not defined. Default is 0')
+            logger.info('Antena wetting value is not defined. Default is 0')
         self.aw = aw
         self.pathToFile = pathToFile
         self.type = type
@@ -448,7 +454,8 @@
     def crateTimeWin(self):
-        grass.message('creating time windows')
+        timeMes.timeMsg('creating time windows')
+        #timeMes.timeMsg()
         time_const = 0
         nameList = []
         tgrass_vector = []
@@ -457,7 +464,7 @@
         if self.typeID == 'gaugeid':
             prefix = 'g'
-        grass.message("from " + str(self.timestamp_min) + " to " + str(self.timestamp_max) + " per " + self.sumStep)
+        timeMes.timeMsg("from " + str(self.timestamp_min) + " to " + str(self.timestamp_max) + " per " + self.sumStep)
         # make timewindows from time interval
         while cur_timestamp < self.timestamp_max:
             self.numWindows += 1
@@ -489,8 +496,7 @@
             # sql = "SELECT (timestamp'%s')+ %s* interval '1 second'" % (cur_timestamp, self.intervalStr)
             # cur_timestamp = self.database.connection.executeSql(sql)[0][0]
             # rint cur_timestamp
-            #print  timedelta(seconds=1)
-            #print self.intervalStr
             cur_timestamp = cur_timestamp + self.intervalStr * timedelta(seconds=1)
             # go to next time interval
@@ -507,7 +513,7 @@
             grass.warning('Cannot write temporal registration file  %s' % os.path.join(self.path, TMPname))
-        grass.message('creating time windows-done')
+        timeMes.timeMsg('creating time windows-done')
     def logMsg(self, msg):
         if self.status.get('msg') == 'Done':
@@ -583,6 +589,7 @@
             # io1.write('mode|' + str(baseline.aw))
             # io1.close
         def computeBaselineFromTime():
             def chckTimeValidity(tIn):
@@ -591,7 +598,7 @@
                 try:
                     tIn = datetime.strptime(tIn, "%Y-%m-%d %H:%M:%S")
                 except ValueError:
-                    grass.message('Wrong datetime format')
+                    logger.info('Wrong datetime format')
                     return False
                 if tIn > tMax or tIn < tMin:
                     return False
@@ -664,7 +671,7 @@
                             try:
                                 time = datetime.strptime(time, "%Y-%m-%d %H:%M:%S")
                             except ValueError:
                                 return False
                             st += str(time).replace("\n", "")
                             fromt = time + timedelta(seconds=-60)
@@ -758,7 +765,7 @@
                             try:
                             except ValueError:
                                 return False
@@ -883,7 +890,7 @@
             self.baselineDict = readBaselineFromText(self.baseline.pathTofile)
         elif self.baseline.type == 'fromDryWin' :
-            grass.message('Computing baselines "dry window" "%s"...' % self.baseline.statFce)
+            logger.info('Computing baselines "dry window" "%s"...' % self.baseline.statFce)
             if computeBaselineFromTime():
                 self.baselineDict = readBaselineFromText(os.path.join(database.pathworkSchemaDir, 'baseline'))
                 return True
@@ -891,7 +898,7 @@
                 return False
         elif  self.baseline.type == 'noDryWin':
-            grass.message('Computing baselines "no dry window" "%s"...' % self.baseline.statFce)
+            logger.info('Computing baselines "no dry window" "%s"...' % self.baseline.statFce)
                 return True
@@ -926,7 +933,7 @@
         if not self.timeWin.setTimestamp():
             self.logMsg("Out of available time interval",1)
             return False
-        grass.message("Quering data")
+        timeMes.timeMsg("Quering data")
         sql = "SELECT linkid,lenght,polarization,frequency \
                 FROM %s.link" % self.database.dataSchema
@@ -966,7 +973,7 @@
         sql = "SELECT * from %s.record" % self.database.schema
         resu = self.database.connection.executeSql(sql, True, True)
-        grass.message("Quering data-done")
+        timeMes.timeMsg("Quering data-done")
         sql = "SELECT n2.time, n2.txpower-n2.rxpower as a,n1.lenght,n1.polarization,n1.frequency,n1.linkid\
                 FROM %s.link AS n1 \
@@ -990,29 +997,29 @@
         # self.database.connection.setIsoLvl(0)  #TODO dont know what is that
         # choose baseline source (quantile, user values, ) get dict linkid, baseline
-        grass.message("Computing baseline")
+        timeMes.timeMsg("Computing baseline")
         if not self.getBaselDict():
             self.logMsg('Dry interval is out of defined time interval(from,to)',1)
             return False
         if len(self.baselineDict) == 0:
             self.logMsg('Baselines coputation faild. Check dry windows',1)
             return False
-        grass.message("Computing baseline-done")
+        timeMes.timeMsg("Computing baseline-done")
         # check if baseline from text is correct
         if len(self.baselineDict) < link_num:
             sql = "SELECT linkid FROM link"
             links = self.database.connection.executeSql(sql, True, True)
             for link in links:
-                # grass.message(type(link))
+                # logger.info(type(link))
                 if not link[0] in self.baselineDict:
-                    grass.message("Linkid= %s is missing in txtfile" % str(link[0]))
-            grass.message(
+                    logger.info("Linkid= %s is missing in txtfile" % str(link[0]))
+            logger.info(
                 'Missing values "linkid,baseline," in text file. Data are not available in dry interval(baseline) .')
         temp = []
         errLinkList=[]
-        grass.message("Computing precipitation")
+        timeMes.timeMsg("Computing precipitation")
         skippedList = []
         for record in resu:
             curLinkData = linksDict[record[0]]  # record[0] is linkid
@@ -1056,18 +1063,18 @@
                 out = str(record[0]) + "|" + str(record[1]) + "|" + str(R1) + "\n"
                 temp.append(out)
-        grass.message("Computing precipitation-done")
+        timeMes.timeMsg("Computing precipitation-done")
         pathExp = os.path.join(self.database.pathworkSchemaDir, "precip")
         io = open(pathExp, 'w+')
         io.writelines(temp)
         io.close()
         #if getData:
-        grass.message("Computed data has been saved to <%s>" % pathExp)
-        grass.message("File structure is <linkid> <time> <precipitation>")
+        logger.info("Computed data has been saved to <%s>" % pathExp)
+        logger.info("File structure is <linkid> <time> <precipitation>")
-        grass.message("Writing computed precipitation to database...")
+        logger.info("Writing computed precipitation to database...")
         io1 = open(os.path.join(self.database.pathworkSchemaDir, "precip"), "r")
         self.database.connection.copyfrom(io1, compPrecTab)
@@ -1162,7 +1169,7 @@
             self.makeRGB(map)
     def makeRGB(self, map):
-        grass.message('Creating RGB column in database')
+        timeMes.timeMsg('Creating RGB column in database')
         try:
             if self.rules not in [None,""]:
                 for lay in range(1, self.getNumLayer(self.database.linkVecMapName), 1):
@@ -1186,7 +1193,7 @@
                            quiet=True,
                            layer=lay)
-            grass.message('Creating RGB column in database-done')
+            timeMes.timeMsg('Creating RGB column in database-done')
         except Exception, e:
             grass.warning("v.color error < %s>"%e)
@@ -1225,7 +1232,7 @@
                        quiet=True)
     def connectDBaLayers(self):
-        grass.message('Connecting tables to maps')
+        timeMes.timeMsg('Connecting tables to maps')
         inputMap = self.database.linkVecMapName
         if '@' in self.database.linkVecMapName:
             self.database.linkVecMapName=self.database.linkVecMapName.split('@')[0]
@@ -1265,7 +1272,7 @@
         for win in f.read().splitlines():
             layerNum += 1
             win = self.database.schema + '.' + win
-            grass.message( win)
+            logger.info( win)
             RunCommand('v.db.connect',
                        driver='pg',
                        map=self.database.linkVecMapName,
@@ -1275,7 +1282,7 @@
                        overwrite=True,
                        quiet=True)
         f.close()
-        grass.message('Connecting tables to maps-done')
+        timeMes.timeMsg('Connecting tables to maps-done')
         return self.database.linkVecMapName
@@ -1320,7 +1327,7 @@
         #print err
     def registerMaps(self):
-        grass.message('Registring maps to temporal database')
+        timeMes.timeMsg('Registring maps to temporal database')
         gisenv_grass = grass.gisenv()
         timeOfLay = self.timeWinConf.timestamp_min
         regTMP = ""
@@ -1336,8 +1343,8 @@
         io1 = open(regFilePath, 'w+')
         io1.writelines(regTMP), io1.close
         io1.close()
-        grass.message( 'datasetName %s'% self.datasetName)
-        grass.message(regFilePath)
+        logger.info( 'datasetName %s'% self.datasetName)
+        logger.info(regFilePath)
         RunCommand('t.register',
                    input=self.datasetName,
@@ -1345,7 +1352,7 @@
                    file=regFilePath,
                    overwrite=True)
-        grass.message('Registring maps to temporal database-done')
+        timeMes.timeMsg('Registring maps to temporal database-done')
 class Database():
     def __init__(self, name=None, user=None, password=None,
@@ -1493,15 +1500,15 @@
     def firstPreparation(self):
         if not isAttributExist(self.connection, 'public', 'link', 'lenght'):
-            grass.message("Add colum lenght")
+            logger.info("Add colum lenght")
             sql = "ALTER TABLE link ADD COLUMN lenght real; "
             self.connection.executeSql(sql, False, True)
-            # grass.message("Add colum frequency")
+            # logger.info("Add colum frequency")
             # sql = "ALTER TABLE link ADD COLUMN frequency real; "
             # self.connection.executeSql(sql, False, True)
-            # grass.message("Optimalization of frequency attribute")
+            # logger.info("Optimalization of frequency attribute")
             # sql = "UPDATE link\
             # SET frequency = record.frequency\
             # FROM record\
@@ -1511,7 +1518,7 @@
             #sql = "ALTER TABLE record DROP COLUMN frequency;"
             #self.connection.executeSql(sql, False, True)
-            grass.message("Add function for computing distance ")
+            logger.info("Add function for computing distance ")
             sql=r"CREATE OR REPLACE FUNCTION get_earth_distance1
                 (lon1 Float, lat1 Float, lon2 Float, lat2 Float, Radius Float DEFAULT 6387.7)
@@ -1530,7 +1537,7 @@
             sql = r"CREATE OR REPLACE FUNCTION get_earth_distance1 (lon1 Float, lat1 Float, lon2 Float, lat2 Float, Radius Float DEFAULT 6387.7) RETURNS FLOAT AS ' DECLARE K FLOAT := 57.29577951; v_dist FLOAT; BEGIN v_dist := (Radius * ACOS((SIN(Lat1 / K) * SIN(Lat2 / K)) + (COS(Lat1 / K) * COS(Lat2 / K) * COS(Lon2 / K - Lon1 / K)))); RETURN round(CAST (v_dist AS Numeric),3); END; ' LANGUAGE 'plpgsql';"
-            grass.message("Computing column lenght")
+            logger.info("Computing column lenght")
             sql = "UPDATE link SET lenght = get_earth_distance1(n1.long,n1.lat,n2.long,n2.lat) \
                     FROM node AS n1 JOIN \
                     link AS l ON n1.nodeid = fromnodeid \
@@ -1538,26 +1545,26 @@
                     WHERE link.linkid = l.linkid; "
-            #grass.message("Add column precip")
+            #logger.info("Add column precip")
             #sql = "ALTER TABLE record ADD COLUMN precip real; "
-            grass.message("Create sequence")
+            logger.info("Create sequence")
             sql = "CREATE SEQUENCE serial START 1; "
-            grass.message("Add column recordid")
+            logger.info("Add column recordid")
             sql = "ALTER TABLE record add column recordid integer default nextval('serial'); "
-            grass.message("Create index on recordid")
+            logger.info("Create index on recordid")
             sql = "CREATE INDEX idindex ON record USING btree(recordid); "
             sql = "CREATE INDEX timeindex ON record USING btree (time); "
-            grass.message("Add mode function")
+            logger.info("Add mode function")
             sql = "CREATE OR REPLACE FUNCTION _final_mode(anyarray)\
                         RETURNS anyelement AS $BODY$ SELECT a FROM unnest($1)\
                         a GROUP BY 1  ORDER BY COUNT(1) DESC, 1 LIMIT 1;\
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py	2016-01-11 09:44:55 UTC (rev 67545)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/mw_util.py	2016-01-11 10:19:04 UTC (rev 67546)
@@ -11,7 +11,13 @@
 import codecs
 from core.gcmd          import GMessage, GError
 from grass.script       import core as grass
+import grass.script as grass
+import time
+from datetime import datetime
+import logging
 class StaticContext():
     def __init__(self):
         gisenvDict = grass.gisenv()
@@ -418,7 +424,38 @@
     return tmp
+class MeasureTime():
+    def __init__(self):
+        self.startLast=None
+        self.end=None
+        self.start=None
+        self.logger = logging.getLogger('mwprecip.MeasureTime')
+    def timeMsg(self,msg,end=False):
+        if self.start is None:
+            self.start = time.time()
+            self.startLast= self.start
+            #grass.message("Measuring time - start: %s "%self.start)
+            self.logger.info("Measuring time - START: %s "%str(datetime.now()))
+        else:
+            self.end = time.time()
+            elapsedTotal=self.end - self.start
+            elapsedLast=self.end-self.startLast
+            self.startLast=self.end
+            #grass.message("Elapsed time from start < %s > : %s"%(msg,elapsed))
+            #grass.message("Elapsed time for last part < %s > : %s"%(msg,elapsedLast))
+            self.logger.info("TOTAL TIME < %s > : %s"%(msg,elapsedTotal))
+            self.logger.info("LAST PART TIME< %s > : %s"%(msg,elapsedLast))
+            if end:
+                #grass.message("Total time: %s"%(elapsed))
+                #grass.message("Measuring time - end: %s "%self.end)
+                self.logger.info("TOTAL TIME e: %s"%(elapsedTotal))
+                self.logger.info("Measuring time - END: %s "%str(datetime.now()))
 def isAttributExist(connection, schema, table, columns):
     sql = "SELECT EXISTS( SELECT * FROM information_schema.columns WHERE \
           table_schema = '%s' AND \
@@ -483,6 +520,8 @@
         print "I/O error({0}): {1}".format(e.errno, e.strerror)
 def randomWord(length):
     return ''.join(random.choice(string.lowercase) for i in range(length))
Modified: grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py
--- grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py	2016-01-11 09:44:55 UTC (rev 67545)
+++ grass-addons/grass7/gui/wxpython/wx.mwprecip/pgwrapper.py	2016-01-11 10:19:04 UTC (rev 67546)
@@ -4,6 +4,7 @@
 import sys
 import psycopg2 as ppg
 # import psycopg2.extensions
+import logging
 class pgwrapper:
     def __init__(self, dbname, host='', user='', passwd='', port=''):
@@ -14,6 +15,7 @@
         self.password = passwd  # Password for login to the database.
         self.connection = self.setConnect()  # Set a connection to the database
         self.cursor = self.setCursor()  # Generate cursor.
+        self.logger = logging.getLogger('mwprecip')
     def setConnect(self):
         conn_string = "dbname='%s'" % self.dbname
@@ -28,7 +30,9 @@
         try:
             conn = ppg.connect(conn_string)
         except:
-            print 'Cannot connect to database'
+            self.logger.error('Cannot connect to database')
+            self.print_message('Cannot connect to database')
+            return
         return conn
@@ -36,8 +40,8 @@
         try:
             return self.connection.cursor()
         except:
-            print 'cannot set cursor'
+            self.logger.error('Cannot set cursor')
+            self.print_message('Cannot set cursor')
     def setIsoLvl(self, lvl='0'):
         if lvl == 0:
@@ -53,6 +57,8 @@
         except Exception, err:
             self.connection.rollback()
+            self.logger.error(" Catched error (as expected):\n")
+            self.logger.error(err)
             self.print_message(" Catched error (as expected):\n")
             self.print_message(err)
@@ -67,6 +73,8 @@
+            self.logger.error("Catched error (as expected):\n")
             pass
@@ -80,13 +88,14 @@
     def executeSql(self, sql, results=True, commit=False):
         # Excute the SQL statement.
-        self.print_message (sql)
+        self.logger.debug(sql)
         try:
             self.cursor.execute(sql)
             self.print_message(e.pgerror)
+            self.logger.error(e.pgerror)
         if commit:
             self.connection.commit()
@@ -122,7 +131,6 @@
             sql_update_col = 'UPDATE "' + table + '" SET ' + parse
         else:
             sql_update_col = 'UPDATE "' + table + '" SET ' + parse + ' WHERE ' + where
-        print "upcol %s" % sql_update_col
         self.cursor.execute(sql_update_col)
