[GRASS-SVN] r67568 - grass/trunk/vector/v.out.ogr
Tue Jan 12 08:55:45 PST 2016
Author: martinl
Date: 2016-01-12 08:55:45 -0800 (Tue, 12 Jan 2016)
New Revision: 67568
   grass/trunk/vector/v.out.ogr/export_areas.c
   grass/trunk/vector/v.out.ogr/export_lines.c
fix indentation issue introduced in r67451
Modified: grass/trunk/vector/v.out.ogr/export_areas.c
--- grass/trunk/vector/v.out.ogr/export_areas.c	2016-01-12 16:35:06 UTC (rev 67567)
+++ grass/trunk/vector/v.out.ogr/export_areas.c	2016-01-12 16:55:45 UTC (rev 67568)
@@ -298,12 +298,11 @@
     /* Area */
     for (j = 0; j < Points->n_points; j++) {
-	if (Vect_is_3d(In))
-	        OGR_G_AddPoint(ring, Points->x[j], Points->y[j],
-        	               Points->z[j]);
+        if (Vect_is_3d(In))
+            OGR_G_AddPoint(ring, Points->x[j], Points->y[j],
+                           Points->z[j]);
 	else
-	        OGR_G_AddPoint_2D(ring, Points->x[j], Points->y[j]);
+            OGR_G_AddPoint_2D(ring, Points->x[j], Points->y[j]);
     OGR_G_AddGeometryDirectly(Ogr_geometry, ring);
@@ -316,11 +315,10 @@
         ring = OGR_G_CreateGeometry(wkbLinearRing);
 	    if(Vect_is_3d(In))
-	                           Points->z[j]);
+                               Points->z[j]);
 	    else
Modified: grass/trunk/vector/v.out.ogr/export_lines.c
--- grass/trunk/vector/v.out.ogr/export_lines.c	2016-01-12 16:35:06 UTC (rev 67567)
+++ grass/trunk/vector/v.out.ogr/export_lines.c	2016-01-12 16:55:45 UTC (rev 67568)
@@ -95,16 +95,18 @@
             if (OGR_G_GetGeometryType(Ogr_geometry) == wkbPoint) {
                 /* GV_POINTS -> wkbPoint */
 		if (Vect_is_3d(In))
-	                OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
-        	                       Points->z[0]);
-		else OGR_G_AddPoint_2D(Ogr_geometry, Points->x[0], Points->y[0]);
+                    OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
+                                   Points->z[0]);
+		else
+                    OGR_G_AddPoint_2D(Ogr_geometry, Points->x[0], Points->y[0]);
             else { /* GV_LINES -> wkbLinestring */
-	                OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
-        	                       Points->z[j]);
-		else OGR_G_AddPoint_2D(Ogr_geometry, Points->x[j], Points->y[j]);
+                        OGR_G_AddPoint(Ogr_geometry, Points->x[j], Points->y[j],
+                                       Points->z[j]);
+                    else
+                        OGR_G_AddPoint_2D(Ogr_geometry, Points->x[j], Points->y[j]);
