[GRASS-SVN] r67624 - in grass-addons/grass7/imagery: . i.ortho.corr
Fri Jan 22 05:17:12 PST 2016
Author: lucadelu
Date: 2016-01-22 05:17:11 -0800 (Fri, 22 Jan 2016)
New Revision: 67624
Added:
   grass-addons/grass7/imagery/i.ortho.corr/
   grass-addons/grass7/imagery/i.ortho.corr/Makefile
   grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html
   grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.py
add i.ortho.corr script, it need more testing
Added: grass-addons/grass7/imagery/i.ortho.corr/Makefile
--- grass-addons/grass7/imagery/i.ortho.corr/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ortho.corr/Makefile	2016-01-22 13:17:11 UTC (rev 67624)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.ortho.corr
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html
--- grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.html	2016-01-22 13:17:11 UTC (rev 67624)
@@ -0,0 +1,43 @@
+<h2>DESCRIPTION</h2>
+<em>i.ortho.corr</em> create a new image, it search the images near the input map and the output contains part of near images where the camera angle value it's the best.
+<p>
+<h2>NOTES</h2>
+You must create a tile index contains all the images to correct, you can use gdaltindex to create it
+<div class="code"><pre>
+gdaltindex tile.shp $GRASSDATA/$LOCATION/$MAPSET/cellhd/*imagery.ortho
+</pre></div>
+The <em>field</em> option it's used for the field's name which contain the path to the file, the default is <em>location</em> that it is used by gdaltindex
+The <em>exclude</em> option it serve to remove some tiles, for example you have tile of different flight, you can pass a string or a regex
+<h2>EXAMPLES</h2>
+Create tile index
+</pre></div>
+Import tile index inside the mapset
+v.in.ogr dns=tile.shp out=tile_images
+</pre></div>
+Start i.ortho.corr with the default parameters, the output map's name it will be <em>image.ortho_corr</em>. You can use default parameters if you didn't change the output prefix in i.ortho.photo
+i.ortho.corr input=image.ortho tiles=tile_images
+</pre></div>
+Start i.ortho.corr with different parameters
+i.ortho.corr input=image.photo tiles=tile_images osuffix=.photo csuffix=.camera
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.ortho.photo.html">i.ortho.photo</a>,
+<a href="i.photo.rectify.html">i.photo.rectify</a>
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi, Fondazione E. Mach (Italy)
+<p><i>Last changed: $Date$</i>
Added: grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.py
--- grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.ortho.corr/i.ortho.corr.py	2016-01-22 13:17:11 UTC (rev 67624)
@@ -0,0 +1,287 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE:    i.ortho.corr
+# AUTHOR(S):    Luca Delucchi
+# PURPOSE:    It is useful to correct orthophoto using the camera angle map
+#        create by i.ortho.photo
+# COPYRIGHT:    (C) 2011 by Luca Delucchi
+#        This program is free software under the GNU General Public
+#        License (>=v2). Read the file COPYING that comes with GRASS
+#        for details.
+#%module
+#% description: Correct orthophoto taking part of the near orthophotos using the camera angle map
+#% keywords: imagery
+#%end
+#%option
+#% key: input
+#% type: string
+#% gisprompt: input raster
+#% key_desc: name
+#% description: Name of input raster map
+#% required: yes
+#%end
+#%option
+#% key: osuffix
+#% type: string
+#% gisprompt: suffix of ortophoto
+#% key_desc: ortho
+#% description: Suffix of ortophoto map, default is .ortho, use None for no suffix
+#% required: no
+#%end
+#%option
+#% key: csuffix
+#% type: string
+#% gisprompt: suffix of camera
+#% key_desc: ortho
+#% description: Suffix of camera angle map, default is .camera_angle, use None for no suffix
+#% required: no
+#%end
+#%option
+#% key: tiles
+#% type: string
+#% gisprompt: input vector tiles
+#% key_desc: name
+#% description: Name of input vector tiles map create by a list of orthophoto
+#% required: yes
+#%end
+#%option
+#% key: field
+#% type: string
+#% gisprompt: name of location's field
+#% key_desc: name
+#% description: Name of location's field in the input vector tiles map
+#% required: no
+#%end
+#%option
+#% key: exclude
+#% type: string
+#% gisprompt: pattern to exclude some tiles
+#% key_desc: name
+#% description: Pattern to use if you want exclude some tiles
+#% required: no
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: output raster
+#% key_desc: name
+#% description: Name of output raster map
+#% required: no
+#%end
+# import library
+import os
+import sys
+import os2emxpath
+import re
+import grass.script as grass
+def main():
+    # check if GISBASE is set
+    if "GISBASE" not in os.environ:
+        # return an error advice
+        print "You must be in GRASS GIS to run this program."
+        sys.exit(1)
+    # input raster map
+    map_in = options['input']
+    # output raster map
+    map_out = options['output']
+    # vector tiles map
+    map_tiles = options['tiles']
+    # location's field
+    field = options['field']
+    if field == '':
+        field = 'location'
+    # orthophoto suffix
+    ortho = options['osuffix']
+    if ortho == '':
+        ortho = '.ortho'
+    # camera angle suffix
+    camera = options['csuffix']
+    if camera == '':
+        camera = '.camera_angle'
+    # check if the ortho and camera angle suffix
+    if ortho == camera:
+        print "Ortho and camera suffix can't be the same."
+    sys.exit(1)
+    ex_pattern = options['exclude']
+    # return the points
+    points = controlPoints(map_in)
+    # the tiles near input map
+    nearMaps = mapTile(points, map_in, map_tiles, field)
+    print nearMaps
+    # calculate output map
+    calcMap(map_in, map_out, nearMaps, ortho, camera, ex_pattern)
+def controlPoints(inputmap):
+    """ This function serve to return the coordinates of the photo's four
+    vertex
+    :param str inpumap: the input raster map's name
+    # return r.info about input file
+    rinfo = grass.raster_info(inputmap)
+    nsres = rinfo['nsres']
+    ewres = rinfo['ewres']
+    # create a dictionary for Nord East
+    NE = [rinfo['east'] - 2 * ewres, rinfo["north"] - 2 * nsres]
+    # create a dictionary for Nord West
+    NW = [rinfo['west'] + 2 * ewres, rinfo["north"] - 2 * nsres]
+    # create a dictionary for Sud East
+    SE = [rinfo['east'] - 2 * ewres, rinfo["south"] + 2 * nsres]
+    # create a dictionary for Sud West
+    SW = [rinfo['west'] + 2 * ewres, rinfo["south"] + 2 * nsres]
+    ## create a dictionary for Nord Center
+    #NC = {'x':rinfo['east']-(rinfo['east']-rinfo['west'])/2, 'y':rinfo["north"]-2*nsres}
+    ## create a dictionary for Sud Center
+    #SC = {'x':rinfo['east']-(rinfo['east']-rinfo['west'])/2,'y':rinfo["south"]+2*nsres}
+    ## create a dictionary for West Center
+    #WC = {'x':rinfo['west']+2*ewres, 'y':rinfo["north"] - (rinfo["north"] - rinfo["south"]) / 2 }
+    ## create a dictionary for East Center
+    #EC = {'x':rinfo['east']-2*ewres, 'y':rinfo["north"]- (rinfo["north"] - rinfo["south"]) / 2}
+    # create a dictionary to return the four point
+    retDict = {'NE': NE, 'NW': NW, 'SE': SE, 'SW': SW}  # 'NC' : NC,'SC' : SC,
+    # 'WC' : WC, 'EC' : EC}
+    # return the dictionary
+    return retDict
+def mapTile(points, inputmap, tilemap, field):
+    """ This function serve to return the name of the near maps of the
+    input map
+    :param points: the points returned by controlPoints function
+    :param tilemap: the tiles vector map's name
+    :param field: the field's name where it is set the name of other maps
+    # list of the map's names
+    nameFiles = []
+    # for each point
+    for k, v in points.iteritems():
+        # query the tiles vector map
+        what = vector_what(tilemap, v)
+        for l, m in what.iteritems():
+            if l != 'general':
+                # create the name for path
+                nameFile = os2emxpath.basename(m[field])
+                if nameFiles.count(nameFile) == 0:
+                    # add the file name to list
+                    nameFiles.append(nameFile)
+    # return list
+    nameFiles.remove(inputmap)
+    return nameFiles
+def vector_what(map, coor):
+    """!Return the result of v.what using the map and coordinates passed
+    @param map vector map name
+    @param coor a list of x,y coordinates
+    @return parsed output in dictionary
+    result = {}
+    # create string for east_north param
+    fields = grass.read_command('v.what', flags='ag', map=map, east_north=coor)
+    # split lines
+    fields = fields.splitlines()
+    # value for number of features
+    value = 0
+    # create a temporary dictionary
+    temp_dic = {}
+    # for each line
+    for field in fields:
+        # split key and value
+        kv = field.split('=', 1)
+        if len(kv) > 1:
+            # Start the new feature
+            if kv[0].strip() == 'Driver':
+                # if value is 0 dictionary contain general information about map
+                if value == 0:
+                    result['general'] = temp_dic
+                # else features
+                else:
+                    result['feature'+str(value)] = temp_dic
+                # value for the new feature
+                value = value + 1
+                # create a new temporary dictionary
+                temp_dic = {}
+                # add driver to the new dictionary
+                temp_dic[kv[0].strip()] = str(kv[1])
+            else:
+                # add value to the dictionary
+    # add the last feature
+    return result
+def calcMap(inmap, outmap, tiles, osuffix, csuffix, exclude):
+    """ Calculate the map of minimum of the other camera maps
+    maxValue = 30
+    # input map
+    prefix_input = inmap.strip(osuffix)
+    camera_input = prefix_input + csuffix
+    # set the re
+    if exclude != '':
+        r = re.compile(exclude)
+    # set the outmap if it isn't passed by user
+    if outmap == '':
+        outmap = prefix_input + '.ortho_corr'
+    # check for each map the best cameta angle
+    for i in range(0, len(tiles)):
+        if exclude != '':
+            exclude_tile = r.search(tiles[i])
+            if exclude_tile:
+                continue
+        prefix_tile = tiles[i].strip(osuffix)
+        camera_tile = prefix_tile + csuffix
+        # first tile start the new map
+        if i == 0:
+            grass.mapcalc("${out} = if(isnull(${c_tile}), ${in_map}, "
+                          "if(${c_input} >= ${maxV}, ${in_map}, "
+                          "if(${c_tile} >= ${maxV}, ${tile}, ${in_map})))",
+                          out=outmap, c_input=camera_input,
+                          c_tile=camera_tile, in_map=inmap, tile=tiles[i],
+                          maxV=maxValue)
+            grass.mapcalc("temp_camera = if(isnull(${c_tile}), ${c_input}, "
+                          "if(${c_input} >= ${maxV}, ${c_input}, "
+                          "if(${c_tile} >= ${maxV}, ${c_tile}, ${c_input})))",
+                          c_input=camera_input, c_tile=camera_tile,
+                          maxV=maxValue)
+        # for the other tile check the outmap
+        else:
+            grass.mapcalc("${out} = if(isnull(${c_tile}), ${out}, "
+                          "if(temp_camera >= ${maxV},${out}, "
+                          "if(${c_tile} >= ${maxV}, ${tile}, ${out})))",
+                          out=outmap, c_tile=camera_tile, tile=tiles[i],
+                          maxV=maxValue)
+            grass.mapcalc("temp_camera = if(isnull(${c_tile}), temp_camera, "
+                          "if(temp_camera >= ${maxV}, ${c_input}, "
+                          "if(${c_tile} >= ${maxV}, ${c_tile},${c_input})))",
+                          maxV=maxValue)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
