[GRASS-SVN] r68998 - in grass/trunk/gui/wxpython: lmgr mapdisp
Mon Jul 18 06:34:52 PDT 2016
Author: annakrat
Date: 2016-07-18 06:34:52 -0700 (Mon, 18 Jul 2016)
New Revision: 68998
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapdisp/main.py
wxGUI: fix overlays in d.mon
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2016-07-17 08:11:01 UTC (rev 68997)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2016-07-18 13:34:52 UTC (rev 68998)
@@ -754,9 +754,9 @@
                 self.GetMapDisplay().AddBarscale()
         elif layertype == 'rastleg':
             if len(command) > 1:
-                self.GetMapDisplay().AddLegend(cmd=command, showDialog=False)
+                self.GetMapDisplay().AddLegend(cmd=command)
             else:
-                self.GetMapDisplay().AddLegend(showDialog=True)
+                self.GetMapDisplay().AddLegend()
         elif layertype == 'northarrow':
                 self.GetMapDisplay().AddArrow(cmd=command)
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2016-07-17 08:11:01 UTC (rev 68997)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2016-07-18 13:34:52 UTC (rev 68998)
@@ -1228,7 +1228,7 @@
         self.MapWindow.mouse['use'] = 'pointer'
-    def AddLegend(self, cmd=None, showDialog=None):
+    def AddLegend(self, cmd=None):
         """Handler for legend map decoration menu selection."""
         if cmd:
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2016-07-17 08:11:01 UTC (rev 68997)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2016-07-18 13:34:52 UTC (rev 68998)
@@ -83,6 +83,7 @@
         # TODO temporary solution, layer managment by different tools in GRASS
         # should be resovled
         self.ownedLayers = []
+        self.oldOverlays = []
         if mapfile:
             self.mapfileCmd = mapfile
@@ -175,28 +176,34 @@
                                                  layerType=ltype)[0]
                 args = {}
-                if ltype in ('barscale', 'rastleg', 'northarrow'):
-                    classLayer = Overlay
+                if ltype in ('barscale', 'rastleg', 'northarrow', 'text'):
+                    # TODO: this is still not optimal
+                    # it is there to prevent adding the same overlay multiple times
+                    if cmd in self.oldOverlays:
+                        continue
                     if ltype == 'rastleg':
-                        args['id'] = 0
+                        self._giface.GetMapDisplay().AddLegend(cmd=cmd)
                     elif ltype == 'barscale':
-                        args['id'] = 1
-                    else:
-                        args['id'] = 2
-                else:
-                    classLayer = MapLayer
-                    args['ltype'] = ltype
+                        self._giface.GetMapDisplay().AddBarscale(cmd=cmd)
+                    elif ltype == 'northarrow':
+                        self._giface.GetMapDisplay().AddArrow(cmd=cmd)
+                    elif ltype == 'text':
+                        self._giface.GetMapDisplay().AddDtext(cmd=cmd)
+                    self.oldOverlays.append(cmd)
+                    continue
-                mapLayer = classLayer(
-                    name=name,
-                    cmd=cmd,
-                    Map=None,
-                    hidden=True,
-                    render=False,
-                    mapfile=mapFile,
-                    **args)
-                mapLayer.GetRenderMgr().updateProgress.connect(
-                    self.GetRenderMgr().ReportProgress)
+                classLayer = MapLayer
+                args['ltype'] = ltype
+                mapLayer = classLayer(name=name,
+                                      cmd=cmd,
+                                      Map=None,
+                                      hidden=True,
+                                      render=False,
+                                      mapfile=mapFile,
+                                      **args)
+                mapLayer.GetRenderMgr().updateProgress.connect(self.GetRenderMgr().ReportProgress)
                 if render_env:
                     mapLayer.GetRenderMgr().UpdateRenderEnv(render_env)
                     render_env = dict()
@@ -316,7 +323,23 @@
     def __init__(self, map, giface):
         self._map = map
         self._giface = giface
+        self._index = 0
+    def __len__(self):
+        return len(self._map.GetListOfLayers())
+    def __iter__(self):
+        return self
+    def next(self):
+        items = self._map.GetListOfLayers()
+        try:
+            result = items[self._index]
+        except IndexError:
+            raise StopIteration
+        self._index += 1
+        return result
     def GetSelectedLayers(self, checkedOnly=True):
         # hidden and selected vs checked and selected
