[GRASS-SVN] r68661 - sandbox/bo/i.segment.gsoc2016/i.segment
Thu Jun 9 20:01:30 PDT 2016
Author: hao2309
Date: 2016-06-09 20:01:30 -0700 (Thu, 09 Jun 2016)
New Revision: 68661
   sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
   sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
   sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
change some mistakes, create bands_seg2 in openfile.c
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
--- sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-06-10 01:48:56 UTC (rev 68660)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-06-10 03:01:30 UTC (rev 68661)
@@ -59,7 +59,7 @@
     int mb;
 	/* ===parameters for ms_setting=== */
-	double ms_bandwidth; /* "Moving window radiuns (1-32 in number of pixel) for mean shift" */
+	double ms_spatial_bandwidth; /* "Moving window radiuns (1-32 in number of pixel) for mean shift" */
 	double ms_range_bandwidth; /* Nomarlized range bandwidth for mean shift */
 	char *ms_suffix; /* a suffix to be appended to the input bands when writing out shifted band values */
 	/* ===end parameters for ms_setting=== */
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-10 01:48:56 UTC (rev 68660)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-10 03:01:30 UTC (rev 68661)
@@ -53,8 +53,7 @@
 	globals->bands_out = &globals->bands_seg2;
 	/*window size in pixel number*/
-	int n_bands = globals->nbands;
-	int window_size = globals->ms_bandwidth*2+1;
+	int window_size = globals->ms_spatial_bandwidth*2+1;
     alpha2 = globals->alpha * globals->alpha;
     t = 0;
@@ -96,11 +95,11 @@
 		if (!(FLAG_GET(globals->candidate_flag, row, col)))
 		    continue;
 		/* left bound of the window */
-		int window_row_north = row - globals->ms_bandwidth;
+		int window_row_north = row - globals->ms_spatial_bandwidth;
 		/* right bound of the window */
 		int window_row_south = window_row_north + window_size;
 		/* upper bound of the window */
-		int window_col_west = col - globals->ms_bandwidth;
+		int window_col_west = col - globals->ms_spatial_bandwidth;
 		/* lower bound of the window */
 		int window_col_east = window_col_west + window_size;
@@ -117,22 +116,20 @@
 		if (window_col_east > globals->col_max){
 			window_col_east = globals->col_max;
 		/* calculate new band values */
-		double sum_of_weights[n_bands];
-		memset(sum_of_weights,0,(n_bands)*sizeof(double));
-		double px_new_val[n_bands];
-		memset(px_new_val,0,(n_bands)*sizeof(double));
+		double sum_of_weights = 0;
+		double *px_new_val = G_malloc(sizeof(double) * globals->nbands);
 		/* start of the moving window */
 		for (int current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
 			for (int current_window_col = window_col_west;current_window_col<window_col_east;current_window_col++){
-				double weight[n_bands];
-				memset(weight,1,(n_bands)*sizeof(double));
+				double weight = 1;
 				/* adapt initial spatial and range bandwidths */
 				double distance2 = pow((current_window_row - row),2)+pow((current_window_col - col),2);
-				if (distance2 <= pow(globals->ms_bandwidth,2)){
+				if (distance2 <= pow(globals->ms_spatial_bandwidth,2)){
 					/* get the current pixel value */
-					Segment_get(&globals->bands_seg, (void *)Rin.mean,row, col);
+					Segment_get(globals->bands_in, (void *)Rin.mean,row, col);
 					/* get the current moving window pixel value */
 					Segment_get(&globals->bands_seg, (void *)Rwin.mean,current_window_row, current_window_col);
@@ -140,9 +137,9 @@
 					if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= (globals->ms_range_bandwidth * globals->ms_range_bandwidth)){
 						int n = globals->nbands - 1;
 						do{
-							weight[n_bands] *=gauss_kernel(pow((Rin.mean[n_bands]-Rwin.mean[n_bands]),2),globals->ms_range_bandwidth);
-							sum_of_weights[n_bands] += weight[n_bands];
-							px_new_val[n_bands] += Rwin.mean[n_bands]*weight[n_bands];
+							weight *=1;/* later can apply gaussian kernal */
+							sum_of_weights += weight;
+							px_new_val[n] += Rwin.mean[n]*weight;
 						} while(n--);
@@ -151,8 +148,13 @@
 		/* write the output to bands_out*/
-		Rout.mean = px_new_val;
-		Segment_put(&globals->bands_seg, (void *)Rout.mean, row, col);/* Segment_put(&globals->bands_seg2, (void *)Rout.mean, row, col); */
+		int n = globals->nbands - 1;
+		do{
+			Rout.mean[n] = px_new_val[n];
+			Rout.mean[n] /= sum_of_weights;
+		}while(n--);
+		Segment_put(globals->bands_out, (void *)Rout.mean, row, col);
+		/* Segment_put(&globals->bands_seg2, (void *)Rout.mean, row, col); */
 		/* if the squared difference between old and new band values
@@ -183,7 +185,7 @@
 	for (i = globals->row_min; i < globals->row_max; i++){
 	    for (j = globals->col_min; j < globals->col_max; j++) {
 			Segment_get(&globals->bands_seg, (void *)R_prt.mean,i, j);
-			G_message(_("\t%.2f"),R_prt.mean);
+			G_message(_("\t%.2f"),R_prt.mean[0]);
\ No newline at end of file
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c	2016-06-10 01:48:56 UTC (rev 68660)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c	2016-06-10 03:01:30 UTC (rev 68661)
@@ -83,6 +83,7 @@
 	globals->max_diff = 1;
 	globals->max_diff = (*globals->calculate_similarity) (&Ri, &Rk, globals);
     /* ********** find out file segmentation size ************ */
     G_debug(1, "Calculate temp file sizes...");
@@ -129,7 +130,7 @@
 	(&globals->bands_seg, G_tempfile(), globals->nrows, globals->ncols, srows,
 	 scols, inlen, nseg) != 1)
 	G_fatal_error("Unable to create input temporary files");
     if (Segment_open
 	(&globals->rid_seg, G_tempfile(), globals->nrows, globals->ncols, srows,
 	 scols, outlen, nseg * 2) != 1)
@@ -173,6 +174,13 @@
 	                    (void *)globals->bands_val, row, col) != 1)
 		G_fatal_error(_("Unable to write to temporary file"));
+		/* add globals->bands_seg2 when using mean shift */
+		if (globals->method == ORM_MS){
+			if(Segment_put(&globals->bands_seg2, &globals->bands_seg, row, col) !=1);
+			G_fatal_error(_("Unable to initiate the shift-value band for mean-shift"));
 	    if (!is_null) {
 		if (!globals->seeds) {
 		    /* sequentially number all cells with a unique segment ID */
@@ -215,6 +223,9 @@
     /* bounds/constraints */
     Rast_set_c_null_value(&globals->upper_bound, 1);
     Rast_set_c_null_value(&globals->lower_bound, 1);
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-10 01:48:56 UTC (rev 68660)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-06-10 03:01:30 UTC (rev 68661)
@@ -44,7 +44,7 @@
 	/* =========================parameters for ms_setting====================== */
 	ms_spatial_bandwidth = G_define_option();
-    ms_spatial_bandwidth->key = "ms_bandwidth";
+    ms_spatial_bandwidth->key = "ms_spatial_bandwidth";
     ms_spatial_bandwidth->type = TYPE_DOUBLE;
     ms_spatial_bandwidth->required = NO;
     ms_spatial_bandwidth->answer = "2";
