[GRASS-SVN] r68693 - in grass-addons/grass7/raster/r.forestfrag: . testsuite
Tue Jun 14 18:22:11 PDT 2016
Author: wenzeslaus
Date: 2016-06-14 18:22:11 -0700 (Tue, 14 Jun 2016)
New Revision: 68693
Added:
   grass-addons/grass7/raster/r.forestfrag/testsuite/
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py
r.forestfrag: test suite for NC SPM and XY locations
Added: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py
--- grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py	2016-06-15 01:22:11 UTC (rev 68693)
@@ -0,0 +1,47 @@
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import grass.script.raster as gr
+class TestForestFrag(TestCase):
+    # TODO: replace by unified handing of maps
+    to_remove = []
+    landclass = 'landclass96'  # in full NC SPM
+    forest = 'rff_test_forest'
+    forest_frag = 'rff_test_forest_frag'
+    def setUp(self):
+        self.use_temp_region()
+        self.runModule('g.region', raster=self.landclass)
+        gr.mapcalc("{f} = if({c} == 5, 1, 0)".format(c=self.landclass,
+                                                     f=self.forest))
+        self.to_remove.append(self.forest)
+    def tearDown(self):
+        self.del_temp_region()
+        if self.to_remove:
+            self.runModule('g.remove', flags='f', type='raster',
+                           name=','.join(self.to_remove), verbose=True)
+    def test_3x3(self):
+        self.assertModule('r.forestfrag', input=self.forest,
+                          output=self.forest_frag, window=3)
+        self.assertRasterExists(self.forest_frag)
+        self.to_remove.append(self.forest_frag)
+        self.assertRasterMinMax(self.forest_frag, refmin=0, refmax=6)
+        # we don't have a check sum test for raster, so we just test all
+        ref = dict(north=228527.25, south=215018.25,
+                   east=644971, west=629980,
+                   nsres=28.5, ewres=28.5, rows=474, cols=526,
+                   cells=249324, datatype='CELL', ncats=6)
+        self.assertRasterFitsInfo(raster=self.forest_frag,
+                                  reference=ref, precision=0.0006)
+        ref = dict(n=249323, null_cells=1, cells=249324, min=0, max=5,
+                   range=5, mean=2.2925, mean_of_abs=2.2925,
+                   stddev=2.3564, variance=5.5526, coeff_var=102.7886,
+                   sum=571564)
+        self.assertRasterFitsUnivar(raster=self.forest_frag,
+if __name__ == '__main__':
+    test()
Added: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py
--- grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py	2016-06-15 01:22:11 UTC (rev 68693)
@@ -0,0 +1,244 @@
+# this is in fact taken from the NC SPM Location landclass96 raster map
+FOREST = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 1
+0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 1 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 1 1 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 1 0 1 1 1 1 1 1 1 1 1 1 1 0 0
+0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 0 0
+0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 1 1 1 1 0 1 1 1 1 1 1 1 1 1 1 0 0 0
+0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0
+0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0
+0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0
+FRAG_3 = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 2 2 2 1 0 0 0 1
+0 0 0 3 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 0 0 0 0 0 0 0 0 0
+0 0 0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 0 0 0 0 0 0 0 0 0
+0 3 4 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 0 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 0 0 0 1 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 3 4 4 4 4 5 5 4 4 0 0 4 4 0 0 0 0
+0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 0 0 0 2 0 4 5 5 5 4 4 4 4 4 4 2 0 0
+0 2 3 3 3 3 4 4 5 5 5 5 5 5 4 4 0 0 0 0 0 0 3 5 5 5 5 5 5 5 5 4 2 0 0
+0 0 0 0 0 0 0 4 5 5 5 5 5 5 4 0 0 2 3 3 2 0 4 5 5 4 4 3 3 3 3 2 0 0 0
+0 0 0 0 0 0 0 3 5 5 5 5 5 5 4 4 4 4 5 5 4 4 4 5 4 4 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 0 0 0 0 0 0 0 0 0 0
+0 2 3 3 3 3 4 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 0 0 0 0 0 0 0 0 0 0 0
+0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 0 0 0 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 2 0 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 0 0 0 0 0 0
+0 3 4 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 4 0 0 0 0 0
+0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 1 0 1 0
+FRAG_5 = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 2 1 1 1 0 0 0 1
+0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 3 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 0 0 0 0 0 0 0 0 0
+0 0 3 3 3 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 0 0 0 0 0 0 0 0 0
+0 0 3 3 4 5 5 5 5 5 5 5 5 5 5 4 3 3 4 3 4 4 4 4 3 3 0 0 0 1 0 0 0 0 0
+0 0 4 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 3 3 3 3 4 3 3 3 3 0 0 2 2 0 0 0 0
+0 0 3 3 3 3 3 3 4 5 5 5 5 4 3 4 4 0 0 0 4 0 4 3 4 3 3 6 3 3 3 2 1 0 0
+0 2 2 3 3 3 3 3 3 5 5 5 5 4 4 4 0 0 0 0 0 0 4 4 4 4 3 4 3 3 3 2 1 0 0
+0 0 0 0 0 0 0 3 3 5 5 5 5 4 4 0 0 3 3 3 4 0 4 3 3 3 3 3 3 3 2 2 0 0 0
+0 0 0 0 0 0 0 3 4 5 5 5 5 4 4 4 4 3 3 3 3 4 4 3 3 3 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 3 3 5 5 5 5 4 3 4 4 3 4 4 4 4 4 3 3 0 0 0 0 0 0 0 0 0 0
+0 2 2 3 3 3 3 3 3 5 5 5 5 5 5 5 5 5 5 5 5 5 4 6 0 0 0 0 0 0 0 0 0 0 0
+0 0 3 3 3 3 3 3 4 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 3 2 0 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 2 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 0 0 0 0 0 0 0
+0 0 3 3 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 3 0 0 0 0 0 0
+0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 2 0 0 0 0 0
+0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 2 1 0 1 0
+FRAG_7 = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 2 2 1 1 1 0 0 0 1
+0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 3 3 3 5 5 5 5 5 5 5 5 4 4 4 4 4 4 4 4 4 4 4 3 0 0 0 0 0 0 0 0 0
+0 0 0 3 3 3 5 5 5 5 5 5 5 4 4 4 4 4 4 4 4 4 4 4 3 3 0 0 0 1 0 0 0 0 0
+0 0 0 3 3 3 3 3 3 4 5 5 4 4 4 4 4 4 4 4 4 4 4 4 3 3 3 0 0 2 2 0 0 0 0
+0 0 0 3 3 3 3 3 3 3 5 5 4 4 4 4 4 0 0 0 4 0 4 4 3 3 3 3 2 2 2 1 1 0 0
+0 2 2 2 3 3 3 3 3 3 5 5 4 4 4 4 0 0 0 0 0 0 4 4 3 3 3 3 2 2 2 1 1 0 0
+0 0 0 0 0 0 0 3 3 3 5 5 4 4 4 0 0 4 4 4 4 0 4 3 3 3 3 2 2 2 1 1 0 0 0
+0 0 0 0 0 0 0 3 3 3 5 5 4 4 4 3 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 3 3 3 5 5 4 3 4 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0
+0 2 2 2 3 3 3 3 3 3 5 5 4 3 4 4 4 4 3 4 4 4 4 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 3 3 3 3 3 3 3 5 5 5 5 5 5 5 5 5 5 5 4 3 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 3 3 3 3 3 3 4 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 2 0 0 0 0 0 0 0 0 0
+0 0 0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 3 3 3 2 0 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 3 2 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 0 0 0 0 0 0 0
+0 0 0 3 3 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 3 0 0 0 0 0 0 0
+0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 2 0 0 0 0 0 0
+0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 2 0 0 0 0 0
+0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 2 2 1 0 1 0
+FRAG_9 = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 2 2 1 1 1 0 0 0 1
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 4 4 3 3 3 3 3 3 4 3 3 3 3 3 3 3 0 0 0 2 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 3 4 4 4 4 3 4 4 4 4 4 3 3 3 3 3 3 0 0 2 1 0 0 0 0
+2 2 0 0 3 3 3 3 3 3 3 4 4 4 4 3 4 0 0 0 4 0 3 3 3 3 3 2 2 1 1 1 1 0 0
+0 0 0 0 3 3 3 3 3 3 3 4 4 4 4 3 0 0 0 0 0 0 3 3 3 3 3 2 2 1 1 1 1 0 0
+0 0 0 0 0 0 0 3 3 3 3 4 4 4 4 0 0 4 4 4 4 0 3 3 3 3 3 2 2 1 1 1 0 0 0
+0 0 0 0 0 0 0 3 3 3 3 4 4 4 4 3 4 4 4 4 4 3 3 3 3 3 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 3 3 3 3 4 4 4 3 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 3 4 3 4 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 3 4 3 4 4 4 4 4 4 4 4 3 3 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 3 5 5 5 5 5 5 5 5 5 4 3 3 3 3 2 0 0 0 0 0 0 0 0 0
+0 0 0 0 3 3 3 3 3 3 4 5 5 5 5 5 5 5 5 5 4 3 3 3 3 3 2 0 0 0 0 0 0 0 0
+0 0 0 0 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 3 3 3 3 3 3 2 2 0 0 0 0 0 0 0
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 3 3 3 2 0 0 0 0 0 0 0
+0 0 0 0 3 3 4 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 4 3 3 3 3 3 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 2 0 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 2 2 0 0 0 0 0
+0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 2 2 1 0 1 0
+FRAG_13 = """\
+north: 220105.5
+south: 219478.5
+east: 634609.5
+west: 633612
+rows: 22
+cols: 35
+0 0 0 0 0 0 0 0 0 5 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 2 2 0 0 0 1
+0 0 0 0 0 0 0 0 0 5 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
+2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 1 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 4 0 0 0 3 0 3 3 3 3 2 2 2 2 1 1 1 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 3 3 3 3 2 2 2 1 1 1 1 0 0
+0 0 0 0 0 0 0 3 3 3 3 3 3 3 3 0 0 4 4 3 3 0 3 3 3 3 2 2 2 1 1 1 0 0 0
+0 0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 4 4 4 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 4 4 4 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 4 4 4 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 0 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 4 4 4 4 4 4 3 3 3 3 3 3 3 2 0 0 0 0 0 0 0 0
+0 0 0 0 0 0 3 3 3 3 3 3 3 5 5 5 5 5 4 3 3 3 3 3 3 3 2 2 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 0 0 0 0 5 5 5 5 5 0 0 0 0 0 0 0 0 2 2 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 2 2 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 2 2 0 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 0 2 2 0 0 0 0 0
+0 0 0 0 0 0 0 0 0 5 5 5 5 5 5 5 5 5 5 5 5 5 0 0 0 0 0 0 2 2 2 2 0 1 0
+class TestForestFragXY(TestCase):
+    to_remove = []
+    forest_frag_ref = 'rff_test_forest_frag_ref'
+    def setUp(self):
+        self.runModule('r.in.ascii', input='-', stdin_=FOREST,
+                       output=self.forest)
+        self.runModule('g.region', raster=self.forest)
+    def forest_frag_general(self, window, reference):
+        self.runModule('r.in.ascii', input='-', stdin_=reference,
+                       output=self.forest_frag_ref)
+        self.to_remove.append(self.forest_frag_ref)
+        self.assertRasterMinMax(self.forest_frag_ref, refmin=0, refmax=6)
+                          output=self.forest_frag, window=window)
+        self.assertRastersNoDifference(actual=self.forest_frag,
+                                       reference=self.forest_frag_ref,
+                                       precision=0)  # it's CELL type
+    def test_3(self):
+        self.forest_frag_general(3, FRAG_3)
+    def test_5(self):
+        self.forest_frag_general(5, FRAG_5)
+    def test_7(self):
+        self.forest_frag_general(7, FRAG_7)
+    def test_9(self):
+        self.forest_frag_general(9, FRAG_9)
+    def test_13(self):
+        self.forest_frag_general(13, FRAG_13)
+    test()
