[GRASS-SVN] r68745 - grass-addons/grass7/raster/r.forestfrag
Wed Jun 22 19:08:17 PDT 2016
Author: wenzeslaus
Date: 2016-06-22 19:08:17 -0700 (Wed, 22 Jun 2016)
New Revision: 68745
   grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: use one large r.mapcalc eval to classify pf and pff
Besides not using a lot of tmp maps and not
using r.series (no need for int afterwards) it also uses
string formatting instead of plus.
Small speed gain with small window size on NC SPM landclass
with size=3 before: real 0m1.363s, user 0m1.080s, sys 0m0.328s
after real 0m0.999s, user 0m0.852s, sys 0m0.192s.
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-23 01:37:04 UTC (rev 68744)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-23 02:08:17 UTC (rev 68745)
@@ -221,8 +221,8 @@
         pf = user_pf
     else:
         pf = tmpname('tmpA03_')
-    gs.mapcalc("$pf = if(" + ipl + ">=0, float($tmpA2) / float($tmpC3))", pf=pf,
-               tmpA2=tmpA2, tmpC3=tmpC3)
+    gs.mapcalc("$pf = if( $ipl >=0, float($tmpA2) / float($tmpC3))",
+               ipl=ipl, pf=pf, tmpA2=tmpA2, tmpC3=tmpC3)
     # computing pff values
@@ -254,14 +254,14 @@
     csub=range(-SWn, SWn, 1)
     for k in rsub:
       for l in csub:
-        text_file.write(tmpC4 + "[" + str(k) + "," + str(l) + "]*"
-        + tmpC4 + "[" + str(k) + "," + str(l+1) + "] + ")
+        text_file.write("{tmpC4}[{a},{b}]*{tmpC4}[{c},{d}] + ".format(
+                        tmpC4=tmpC4, a=k, b=l, c=k, d=l + 1))
     rsub=range(-SWn, SWn+1, 1)
     csub=range(SWn, -SWn, -1)
     for k in rsub:
       for l in csub:
-          text_file.write(tmpC4 + "[" + str(l) + "," + str(k) + "]*" + tmpC4
-          + "[" + str(l-1) + "," + str(k) + "] + ")
+                          tmpC4=tmpC4, a=l, b=k, c=l - 1, d=k))
     text_file.write("0")
     text_file.close()
@@ -282,14 +282,14 @@
     for k in rsub:
       for l in csub:
-        text_file.write("if((" + tmpC4 + "[" + str(k) + "," + str(l) + "]+"
-        + tmpC4 + "[" + str(k) + "," + str(l+1) + "])>0,1) + ")
+        text_file.write("if(({tmpC4}[{a},{b}]+{tmpC4}[{c},{d}])>0,1) + ".format(
     for k in rsub:
       for l in csub:
-          text_file.write("if((" + tmpC4 + "[" + str(l) + "," + str(k) + "]+"
-        + tmpC4 + "[" + str(l-1) + "," + str(k) + "])>0,1) + ")
     text_file.close()
@@ -302,35 +302,53 @@
         pff = user_pff
     else:
         pff = tmpname('tmpA07_')
-    gs.mapcalc("$pff = if(" + ipl + " >= 0, float($tmpl4) / float($tmpl5))",
-               tmpl4=tmpl4, tmpl5=tmpl5, pff=pff, quiet=True)
+    gs.mapcalc("$pff = if($ipl >= 0, float($tmpl4) / float($tmpl5))",
+               ipl=ipl, tmpl4=tmpl4, tmpl5=tmpl5, pff=pff,
+               quiet=True)
     # computing fragmentation index
+    # (a b) name, condition
+    # where a is a number used by Riitters et al. in ERRATUM (2)
+    # and b is a number used in the sh script by Sambale and Sylla
+    # b also defines 0 for non-forested which is consistent with input
+    # (1 1) edge, if Pf > 0.6 and Pf - Pff < 0
+    # (2 6) undetermined, if Pf > 0.6 and Pf = Pff
+    # (3 4) perforated, if Pf > 0.6 and Pf - Pff > 0
+    # (4 5) interior, if Pf = 1.0
+    # (5 1) patch, if Pf < 0.4
+    # (6 2) transitional, if 0.4 < Pf < 0.6
     gs.info(_("Step 3: Computing fragmentation index..."))
-    pf2 = tmpname('tmpA08_')
-    gs.mapcalc("$pf2 = $pf - $pff", pf2=pf2, pf=pf, pff=pff, quiet=True)
-    f1 = tmpname('tmpA09_') # patch
-    gs.mapcalc("$f1 = if($pf<0.4,1,0)", f1=f1, pf=pf, quiet=True)
-    f2 = tmpname('tmpA10_') # transitional
-    gs.mapcalc("$f2 = if($pf>=0.4 && $pf<0.6,2,0)", pf=pf, f2=f2, quiet=True)
-    f3 = tmpname('tmpA11_') # edge
-    gs.mapcalc("$f3 = if($pf>=0.6 && $pf2<0,3,0)", pf=pf, pf2=pf2, f3=f3, quiet=True)
-    f4 = tmpname('tmpA12_') # perforate
-    gs.mapcalc("$f4 = if($pf>0.6 && $pf<1 && $pf2>0,4,0)", pf=pf, pf2=pf2, f4=f4, quiet=True)
-    f5 = tmpname('tmpA13_') # interior
-    gs.mapcalc("$f5 = if($pf==1,5,0)", pf=pf, pff=pff, f5=f5, quiet=True)
-    f6 = tmpname('tmpA14_') # undetermined
-    gs.mapcalc("$f6 = if($pf>0.6 && $pf<1 && $pf2==0,6,0)", pf=pf, pf2=pf2, pff=pff, f6=f6, quiet=True) # undetermined
-    Index = tmpname('tmpA15_')
-    gs.run_command("r.series", input=[f1,f2,f3,f4,f5,f6], output=Index,
-                      method="sum", quiet=True)
     if clip_output:
         indexfin2 = tmpname('tmpA16_')
     else:
         indexfin2 = opl
-    gs.mapcalc("$if2 = int($ipl * $Index)",
-               if2=indexfin2, ipl=ipl, Index=Index)
+    gs.mapcalc(
+        "eval("
+        "dpf = $pf - $pff,"
+        # individual classes
+        "patch = if($pf < 0.4, 1, 0),"
+        "transitional = if($pf >= 0.4 && $pf < 0.6, 2, 0),"
+        "edge = if($pf >= 0.6 && dpf<0,3,0),"
+        "perforated = if($pf > 0.6 && $pf < 1 && dpf > 0, 4, 0),"
+        "interior = if($pf == 1, 5, 0),"
+        "undetermined = if($pf > 0.6 && $pf < 1 && dpf == 0, 6, 0),"
+        # null is considered as non-forest and we need to do it before +
+        "patch = if(isnull(patch), 0, patch),"
+        "transitional = if(isnull(transitional), 0, transitional),"
+        "edge = if(isnull(edge), 0, edge),"
+        "perforated = if(isnull(perforated), 0, perforated),"
+        "interior = if(isnull(interior), 0, interior),"
+        "undetermined = if(isnull(undetermined), 0, undetermined),"
+        # combine classes (they don't overlap)
+        # more readable than nested ifs from the ifs above
+        "all = patch + transitional + edge + perforated + interior + undetermined"
+        ")\n"
+        # mask result by non-forest (according to the input)
+        # removes the nonsense data created in the non-forested areas
+        "$out = all * $binary_forest",#
+        out=indexfin2, binary_forest=ipl, pf=pf, pff=pff)
     # Shrink the region
     if clip_output:
