[GRASS-SVN] r68753 - grass/trunk/display/d.legend
Thu Jun 23 17:31:43 PDT 2016
Author: annakrat
Date: 2016-06-23 17:31:43 -0700 (Thu, 23 Jun 2016)
New Revision: 68753
   grass/trunk/display/d.legend/draw.c
   grass/trunk/display/d.legend/local_proto.h
   grass/trunk/display/d.legend/main.c
d.legend: logarithmic legend and fixes to background size, author Adam Laza
Modified: grass/trunk/display/d.legend/draw.c
--- grass/trunk/display/d.legend/draw.c	2016-06-23 22:03:32 UTC (rev 68752)
+++ grass/trunk/display/d.legend/draw.c	2016-06-24 00:31:43 UTC (rev 68753)
@@ -30,7 +30,7 @@
           struct Option *opt_at, struct Option *opt_fontsize,
           struct Option *opt_ticks, struct Option *opt_tstep,
           struct Option *opt_range, struct Flag *histo, struct Flag *hidestr,
-          int draw)
+          int log_sc, int draw, int digits)
     char buff[512];
     int black, white;
@@ -67,6 +67,9 @@
     int dx, dy;
     double coef;
     double ppl;
+    double bb,bt,bl,br;
+    char MaxLabel[512];
+    double num;
     if (draw) {
@@ -316,6 +319,13 @@
+        /* In case of log. scale raster doesn't contain negative or zero values */
+        if (log_sc)
+            if ((dmin<=0) || (dmax<=0))
+                G_fatal_error(_("Range [%.3f, %.3f] out of the logarithm domain."),
+                              dmin, dmax);
         if (use_catlist) {
             for (i = 0; i < catlistCount; i++) {
                 if ((catlist[i] < dmin) || (catlist[i] > dmax)) {
@@ -329,6 +339,9 @@
         do_cats = 0;            /* if only to get rid of the compiler warning  */
         cats_num = 0;           /* if only to get rid of the compiler warning  */
         /* determine how many significant digits to display based on range */
+        if (digits != -1) /* number of digits given by user */
+            sprintf(DispFormat, "%%.%df", digits);
+        else {/* automatic calculation */
         if (0 == (dmax - dmin)) /* trap divide by 0 for single value rasters */
             sprintf(DispFormat, "%%f");
         else {
@@ -340,6 +353,7 @@
             else
                 sprintf(DispFormat, "%%.2g");   /* eg 4.2e-9  */
     }                           /* end of is fp */
     if (use_catlist) {
@@ -372,6 +386,25 @@
         /* Draw the legend bar */
         if (draw) {
             for (k = 0; k < lleg; k++) {
+                if (log_sc) { /* logarithmic scale */
+                    num = k / lleg;
+                    val = dmin * pow(dmax/dmin, num);
+                    D_d_color(val, &colors);
+                    if (!flip) {
+                        if (horiz)
+                            D_box_abs(x0 + k, y0, x0 + k + 1, y0 + dy);
+                        else
+                            D_box_abs(x0, y0 + k, x0 + dx, y0 + k + 1);
+                    else {
+                        if (horiz)
+                            D_box_abs(x1 - k, y0, x1 - k - 1, y0 + dy);
+                        else
+                            D_box_abs(x0, y1 - k, x0 + dx, y1 - k - 1);
+                } /* linear scale */
+                else{
                 if (!fp) {
                     if (!flip)
                         tcell =
@@ -385,9 +418,9 @@
                 else {
                     if (!flip)
-                        val = dmin + k * (dmax - dmin) / lleg;
+                            val = dmin + k / lleg * (dmax - dmin);
                     else
-                        val = dmax - k * (dmax - dmin) / lleg;
+                            val = dmax - k / lleg * (dmax - dmin);
@@ -399,6 +432,7 @@
                               y0 + k + (dy ? -dy : 1));
         /* Format text */
         if (!fp) {              /* cut down labelnum so they don't repeat */
@@ -475,42 +509,91 @@
                     if (hide_catnum)
                         buff[0] = 0;    /* no text */
                     else {
+                        if (log_sc) {
+                            num = log10(dmax) - k * ((log10(dmax) - log10(dmin)) / (steps - 1));
+                            val = pow(10,num);
+                        else{
                         if (!flip)
                             val = dmin + k * (dmax - dmin) / (steps - 1);
                         else
                             val = dmax - k * (dmax - dmin) / (steps - 1);
                         sprintf(buff, DispFormat, val);
                 if (draw) {
-                    ppl = (lleg) / (steps * 1.0 - 1);
                     if (!hide_catnum) {
+                        D_text_size(txsiz, txsiz);
+                        D_get_text_box(buff, &bb, &bt, &bl, &br);
                         if (!horiz) {
+                            if (log_sc) {
+                                coef = (log10(val) - log10(dmin)) / (log10(dmax) - log10(dmin));
+                                if (flip)
                             D_pos_abs(x1 + label_indent,
-                                      y0 + ppl * k + txsiz / 2);
-                            if (show_ticks)
-                                D_line_abs(x1, y0 + ppl * k, x1 + 6,
-                                           y0 + ppl * k);
+                                              y1 - coef * lleg + (bb - bt) / 2);
+                                else
+                                    D_pos_abs(x1 + label_indent,
+                                              y0 + coef * lleg + (bb - bt) / 2);
                         else {
-                            /* text width is 0.81 of text height? so even though we set width
-                               to txsiz with D_text_size(), we still have to reduce.. hmmm */
-                            D_pos_abs(x0 + ppl * k -
-                                      (strlen(buff) * txsiz * .81 / 2),
+                                ppl = (lleg) / (steps * 1.0 - 1);
+                                          y0 + ppl * k + (bb - bt) / 2);
+                            if (show_ticks) {
+                                D_use_color(black);
+                                if (log_sc)
+                                    if (flip)
+                                        D_line_abs(x1, y1 - coef * lleg,
+                                                   x1 + 6, y1 - coef * lleg);
+                                    else
+                                        D_line_abs(x1, y0 + coef * lleg,
+                                                   x1 + 6, y0 + coef * lleg);
+                                else
+                                    D_line_abs(x1, y0 + ppl * k,
+                                               x1 + 6, y0 + ppl * k);
+                        else {
+                            if (log_sc) {
+                                if (flip)
+                                    D_pos_abs(x1 - coef * wleg - ((br - bl) / 2),
                                       y1 + label_indent + txsiz);
-                            if (show_ticks)
-                                D_line_abs(x0 + ppl * k, y1, x0 + ppl * k,
-                                           y1 + 6);
+                                else
+                                    D_pos_abs(x0 + coef * wleg - ((br - bl) / 2),
+                                              y1 + label_indent + txsiz);
+                            else {
+                                ppl = (wleg) / (steps * 1.0 - 1);
+                                D_pos_abs(x0 + ppl * k - ((br - bl) / 2),
+                            if (show_ticks) {
+                                if (log_sc)
+                                    if (flip)
+                                        D_line_abs(x1 - coef * wleg, y1,
+                                                   x1 - coef * wleg, y1 + 6);
+                                    else
+                                        D_line_abs(x0 + coef * wleg, y1,
+                                                   x0 + coef * wleg, y1 + 6);
+                                else
+                                    D_line_abs(x0 + ppl * k, y1,
+                                               x0 + ppl * k, y1 + 6);
                         if (color)
+                            D_use_color(color);
                             D_text(buff);
-                if (strlen(buff) > MaxLabelLen)
+                if (strlen(buff) > MaxLabelLen) {
                     MaxLabelLen = strlen(buff);
+                    sprintf(MaxLabel, DispFormat, val);
             }                   /* for */
@@ -523,20 +606,29 @@
                 sprintf(buff, DispFormat, tick_values[i]);
+                if (log_sc) {
+                    coef = (log10(tick_values[i]) - log10(dmin)) / (log10(dmax) - log10(dmin));
+                else
                 coef = (tick_values[i] - dmin) / ((dmax - dmin) * 1.0);
                 if (draw) {
                     if (!flip) {
                         if (!horiz) {
-                            if (show_ticks)
+                            if (show_ticks) {
                                       y0 + coef * lleg + txsiz / 2);
                         else {
-                            if (show_ticks)
+                            if (show_ticks) {
@@ -544,31 +636,95 @@
                     else {
                         if (!horiz) {
-                            if (show_ticks)
+                            if (show_ticks) {
                                       y1 - coef * lleg + txsiz / 2);
                         else {
-                            if (show_ticks)
+                            if (show_ticks) {
                     D_text(buff);
+                    sprintf(MaxLabel, DispFormat, tick_values[i]);
         /* LABEL_STEP OPTION */
         if (opt_tstep->answer) {
+            if (log_sc) { /* logarithmic */
+                t_start=0;
+                while (log10(dmin) + t_start < log10(dmax)){
+                    num = ceil(log10(dmin)) + t_start;
+                    sprintf(buff, DispFormat, val);
+                    if (draw){
+                        if (!flip){
+                            if (!horiz){
+                                if (show_ticks) {
+                                          y0 + coef * lleg + txsiz / 2);
+                            else{
+                                if (show_ticks) {
+                                          (strlen(buff) * txsiz * .81 / 2),
+                        else{
+                            if (!horiz){
+                                if (show_ticks) {
+                                          y1 - coef * lleg + txsiz / 2);
+                            else{
+                                if (show_ticks){
+                        D_text(buff);
+                t_start += t_step;
+            else { /* linear */
             t_start = ceil(dmin / t_step) * t_step;
             if (t_start == -0)
                 t_start = 0;
@@ -577,16 +733,20 @@
                 if (!horiz)
                     while (t_start < dmax) {
                         sprintf(buff, DispFormat, t_start);
+                            sprintf(MaxLabel, DispFormat, t_start);
                         if (draw) {
                             coef = (t_start - dmin) / ((dmax - dmin) * 1.0);
-                            if (show_ticks)
+                            if (show_ticks) {
                             D_text(buff);
                         t_start += t_step;
@@ -594,17 +754,22 @@
                 else
                         if (draw) {
-                            if (show_ticks)
+                            if (show_ticks) {
                             D_text(buff);
                         t_start += t_step;
@@ -614,16 +779,21 @@
                 if (!horiz)
                         if (draw) {
-                            if (show_ticks)
+                            if (show_ticks) {
                             D_text(buff);
                         t_start += t_step;
@@ -631,23 +801,29 @@
                 else
                         if (draw) {
-                            if (show_ticks)
+                            if (show_ticks){
                             D_text(buff);
                         t_start += t_step;
         if (draw) {
             /* Draw boxes outside of legend bar */
@@ -697,17 +873,20 @@
         /* display title or units */
         if (strlen(title) > 0) {
+            D_text_size(titsiz, titsiz);
+            D_get_text_box(title, &bb, &bt, &bl, &br);
             /* title */
             if (horiz) {
-                x_tit = (x0 + x1) / 2. - (strlen(title) * titsiz * 0.81) / 2;
+                x_tit = (x0 + x1) / 2. - (br - bl) / 2;
                 y_tit = y0 - (titsiz) - max_hist;
             else {
                 x_tit = x0;
                 y_tit = y0 - (titsiz);
-            x1_tit = x_tit + strlen(title) * titsiz * 0.81;
+            x1_tit = x_tit + (br - bl);
             if (draw) {
                 D_use_color(color);
                 /* use tit_fontsize */
@@ -733,15 +912,17 @@
                 units = "";
             if (strlen(units)) {
                 if (horiz) {
                     x_tit =
-                        (x0 + x1) / 2. - (strlen(units) * txsiz * 0.81) / 2;
+                        (x0 + x1) / 2. - (br - bl) / 2;
                     y_tit = y1 + (txsiz * 2.75);
                 else {
                     x_tit = x0;
-                x1_tit = x_tit + strlen(units) * titsiz * 0.81;
                 if (draw) {
                     D_use_color(color);
@@ -753,11 +934,11 @@
         if (!draw) {
             /* Draw background */
+            D_get_text_box(MaxLabel, &bb, &bt, &bl, &br);
             if (!horiz) {
                 x0bg = x0 - max_hist - txsiz;
-                x1bg =
-                    x0 + wleg + label_indent + (MaxLabelLen * txsiz * 0.81) +
-                    txsiz;
+                x1bg = x0 + wleg + label_indent + (br - bl) + txsiz;
                 if (x1bg < x1_tit)
                     x1bg = x1_tit + txsiz;
                 y1bg = y0 + lleg + txsiz;
@@ -767,8 +948,8 @@
                     y0bg = y0 - titsiz;
             else {
-                x0bg = x0 - (MaxLabelLen * txsiz * 0.81) / 2 - txsiz;
-                x1bg = x0 + wleg + (MaxLabelLen * txsiz * 0.81) / 2 + txsiz;
+                x0bg = x0 - (br - bl) / 2 - txsiz;
+                x1bg = x0 + wleg + (br - bl) / 2 + txsiz;
                 if (x1bg < x1_tit) {
                     x0bg = x_tit - txsiz;
@@ -971,8 +1152,10 @@
                                 catlist[catlistCount - i - 1]);
+                sprintf(MaxLabel, DispFormat, catlist[catlistCount - i - 1]);
             if (draw) {
                 D_pos_abs((l + 3 + dots_per_line), (cur_dot_row) - 3);
@@ -988,8 +1171,11 @@
             x_tit = x0;
             y_tit = y0;
             if (draw) {
                 D_use_color(color);
@@ -1007,8 +1193,10 @@
             /* sprintf(buff, "%d of %d categories\n", (j-1), cats_num); */
             sprintf(buff, "%d of %d categories\n", k, cats_num);
+                sprintf(MaxLabel, "%d of %d categories\n", k, cats_num);
             if (draw) {
                 if (opt_fontsize->answer != NULL)
@@ -1023,9 +1211,10 @@
         if (!draw) {
             x0bg = x0 - txsiz;
             x1bg =
-                x0 + dots_per_line + 3 + (MaxLabelLen * txsiz * 0.81) + txsiz;
+                x0 + dots_per_line + 3 + (br - bl) + txsiz;
             if (x1bg < x1_tit)
             y1bg = cur_dot_row + txsiz;
Modified: grass/trunk/display/d.legend/local_proto.h
--- grass/trunk/display/d.legend/local_proto.h	2016-06-23 22:03:32 UTC (rev 68752)
+++ grass/trunk/display/d.legend/local_proto.h	2016-06-24 00:31:43 UTC (rev 68753)
@@ -36,19 +36,10 @@
 void get_stats(const char *, struct stat_list *, int, int);
 void run_stats(const char *, int, const char *, int);
-/* background.c */
-void background(const char *, int, int, int, int, int, int, int, int, int,
-                int, int, int, struct Categories, struct Colors, double,
-                double, double, double, int, int, double, double, double *,
-                int, int, int, double, double, const char *, double *, double,
-                int, int, struct Option *, struct Option *, struct Option *,
-                struct Option *, struct Option *, struct Option *,
-                struct Flag *, struct Flag *);
 /* draw.c */
 void draw(const char *, int, int, int, int, int, int, int, int, int, int, int,
           int, struct Categories, struct Colors, double, double, double,
           double, int, int, double, double, double *, int, int, int, double,
           double, const char *, double *, double, int, int, struct Option *,
           struct Option *, struct Option *, struct Option *, struct Option *,
-          struct Option *, struct Flag *, struct Flag *, int);
+          struct Option *, struct Flag *, struct Flag *, int, int, int);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2016-06-23 22:03:32 UTC (rev 68752)
+++ grass/trunk/display/d.legend/main.c	2016-06-24 00:31:43 UTC (rev 68753)
@@ -54,9 +54,9 @@
         *opt_thin, *opt_labelnum, *opt_at, *opt_use, *opt_range,
         *opt_font, *opt_path, *opt_charset, *opt_fontsize, *opt_title,
         *opt_ticks, *opt_tstep, *opt_brdcolor, *opt_bgcolor,
-        *opt_tit_fontsize;
+        *opt_tit_fontsize, *opt_digits;
     struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit, *histo,
-        *showtick, *showbg;
+        *showtick, *showbg, *log_sc;
     double X0, X1, Y0, Y1;
     int flip, UserRange;
     double UserRangeMin, UserRangeMax, UserRangeTemp;
@@ -68,6 +68,7 @@
     double t_step;
     int colorb, colorbg;
     double tit_fontsize;
+    int log_scale, digits;
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
@@ -148,9 +149,16 @@
     opt_tstep->type = TYPE_DOUBLE;
     opt_tstep->required = NO;
     opt_tstep->description = _("Display label every step");
-    opt_tstep->required = NO;
     opt_tstep->guisection = _("Gradient");
+    opt_digits = G_define_option();
+    opt_digits->key = "digits";
+    opt_digits->type = TYPE_INTEGER;
+    opt_digits->required = NO;
+    opt_digits->description = _("Number of digits after decimal point");
+    opt_digits->guisection = _("Advanced");
+    opt_digits->answer = NULL;
+    opt_digits->options = "0-6";
     opt_at = G_define_option();
     opt_at->key = "at";
@@ -270,6 +278,11 @@
     showbg->description = _("Show background");
     showbg->guisection = _("Background");
+    log_sc = G_define_flag();
+    log_sc->key = 'l';
+    log_sc->description = _("Use logarithmic scale");
+    log_sc->guisection = _("Advanced");
     G_option_required(opt_rast2d, opt_rast3d, NULL);
     G_option_exclusive(opt_rast2d, opt_rast3d, NULL);
     G_option_exclusive(hidenum, opt_ticks, NULL);
@@ -300,6 +313,7 @@
     do_smooth = smooth->answer;
     flip = flipit->answer;
     show_bg = showbg->answer;
+    log_scale = log_sc->answer;
     if (showtick->answer) {
         label_indent = 12;
@@ -307,6 +321,11 @@
     else
         label_indent = 6;
+    if (opt_digits->answer != NULL)
+        sscanf(opt_digits->answer, "%d", &digits);
+    else
+        digits = -1;
     color = D_parse_color(opt_color->answer, TRUE);
     if (opt_lines->answer != NULL)
@@ -442,7 +461,7 @@
              UserRangeMax, catlist, catlistCount, use_catlist, ticksCount,
              fontsize, tit_fontsize, title, tick_values, t_step, colorb,
              colorbg, opt_use, opt_at, opt_fontsize, opt_ticks, opt_tstep,
-             opt_range, histo, hidestr, 0);
+             opt_range, histo, hidestr, log_scale, 0, digits);
     draw(map_name, maptype, color, thin, lines, steps, fp, label_indent,
          hide_catnum, hide_catstr, show_ticks, hide_nodata, do_smooth, cats,
@@ -450,7 +469,7 @@
          catlist, catlistCount, use_catlist, ticksCount, fontsize,
          tit_fontsize, title, tick_values, t_step, colorb, colorbg, opt_use,
          opt_at, opt_fontsize, opt_ticks, opt_tstep, opt_range, histo,
-         hidestr, 1);
+         hidestr, log_scale, 1, digits);
     D_close_driver();
