[GRASS-SVN] r68794 - sandbox/bo/i.segment.gsoc2016/i.segment
    svn_grass at osgeo.org
    Wed Jun 29 10:32:55 PDT 2016
Author: hao2309
Date: 2016-06-29 10:32:55 -0700 (Wed, 29 Jun 2016)
New Revision: 68794
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
added clustering/clump function to mean_shift
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-28 18:51:55 UTC (rev 68793)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-29 17:32:55 UTC (rev 68794)
@@ -5,6 +5,7 @@
 #include <string.h>
 #include <float.h>
 #include <math.h>
+#include <fcntl.h>
 #include <time.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
@@ -13,6 +14,8 @@
 #include <grass/rbtree.h>	/* Red Black Tree library functions */
 #include "iseg.h"
+#define INCR 1024
 /* standard gauss funtion:
  * a * exp(-(x - m)^2 / (2 * stddev^2)
  * a is not needed because the sum of weights is calculated for each
@@ -30,232 +33,380 @@
     return exp(-diff2 / (2 * var));
-int clustering2(struct globals *globals){
-	int class_val, px_count, first_change;/* the value of class */
-	int row, col, nrows, ncols, stop_row, stop_col,edge_row, edge_col,diag;
-	struct ngbr_stats Rin, Rstop;
-	nrows = globals->row_max;
-	ncols = globals->col_max;
-	CELL temp_id;
-	double cluster_threshold,cluster_threshold2;
-	int **indicator_matrix;
-	/* the indicator matrix to mark if the pixel has been clumped */
+static int cmp_cells(DCELL **a, int acol, DCELL **b, int bcol,
+                     DCELL *rng, int n, double threshold2)
+    int i;
+    double diff, diff2;
+    diff2 = 0;
+    for (i = 0; i < n; i++) {
+	if (Rast_is_d_null_value(&b[i][bcol]))
+	    return 0;
+	diff = a[i][acol] - b[i][bcol];
+	/* normalize with the band's range */
+	if (rng[i])
+	    diff /= rng[i];
+	diff2 += diff * diff;
+    /* normalize difference to the range [0, 1] */
+    diff2 /= n;
+    return (diff2 <= threshold2);
+int clump(struct globals *globals)
+    register int row, col,nin,diag;
+    register int i, n;
+    /* input */
+    DCELL **prev_in, **cur_in, **temp_in;
+    int bcol;
+    DCELL *rng, maxdiff;
+    double threshold,thresh2;
+	struct ngbr_stats Rin, Rabove, Rleft;
+    /* output */
+    CELL OLD, NEW;
+    CELL *temp_clump, *out_cell, *out_cellp;
+    CELL *prev_clump, *cur_clump;
+    CELL *index, *renumber;
+    CELL label;
+    int nrows, ncols;
+    int isnull;
+    int len;
+    int nalloc;
+    char *cname;
+    int cfd, csize;
+    CELL cat;
+	nin = globals->nbands;
+	threshold = globals->ms_range_bandwidth;
+    G_message(_("%d-band clumping with threshold %g"), nin, threshold);
 	Rin.mean = G_malloc(globals->datasize);
-	Rstop.mean = G_malloc(globals->datasize);
-	indicator_matrix = G_malloc(nrows *  sizeof(int*));
-	diag=0;
+    nrows = globals->row_max;
+    ncols = globals->col_max;
-	for (row = globals->row_min; row < nrows; row++) {
-		indicator_matrix[row] = G_malloc(ncols * sizeof(int));
-	    for (col = globals->col_min; col < ncols; col++) {
-			indicator_matrix[row][col] = 0;
+	diag = globals->diagonal;
-	G_message(_("Pass 1 of 2 for clustering"));
+    thresh2 = threshold * threshold;
+    /* allocate clump index */
+    nalloc = INCR;
+    index = (CELL *) G_malloc(nalloc * sizeof(CELL));
+    index[0] = 0;
+    renumber = NULL;
+    /* allocate DCELL buffers two columns larger than current window */
+    len = (ncols + 2) * sizeof(DCELL);
+    prev_in = (DCELL **) G_malloc(sizeof(DCELL *) * nin);
+	cur_in = (DCELL **) G_malloc(sizeof(DCELL *) * nin);
+    rng = G_malloc(sizeof(DCELL) * nin);
+    maxdiff = 0;
+    for (i = 0; i < nin; i++) {
+	DCELL min, max; /* min/max values of each input raster */
-	px_count=0;
-	class_val=0;
-	stop_row=0;
-	stop_col=0;
-	cluster_threshold = 0.05;
-	cluster_threshold2= pow(cluster_threshold ,2);
+	max = 0;
+	min =1;
-	while (px_count<nrows*ncols){
-		class_val+=1;
-		Segment_get(globals->bands_out, (void *)Rstop.mean, stop_row, stop_col);
-		first_change =0;/* mark the first time non-clump */
-		/* get the first stop row when  */
-	    G_percent(row - globals->row_min,
-	              globals->row_max - globals->row_min, 4);
 			if (!(FLAG_GET(globals->candidate_flag, row, col)))
 				continue;
 			Segment_get(globals->bands_out, (void *)Rin.mean, row, col);
-			// G_message(_("row: %d, col: %d, temp_id is: %d"),row,col,temp_id);
-			if ((globals->calculate_similarity)(&Rin, &Rstop, globals) <= cluster_threshold2 && indicator_matrix[row][col]==0){
-				indicator_matrix[row][col]+=1;
-				/* if the seg is not in the edg of the image */
-				// if (row!= globals->row_min && col!=globals->col_min && row!=nrows-1 && col!=ncols-1){
-					// /* If this seg is saperate from surrounded segments */
-					// if (indicator_matrix[row+1][col]+indicator_matrix[row][col+1]+indicator_matrix[row-1][col]+indicator_matrix[row][col-1]==0){
-						// class_val+=1;
-						// if (diag){
-							// if (indicator_matrix[row-1][col-1]+indicator_matrix[row+1][col-1]+indicator_matrix[row-1][col+1]+indicator_matrix[row+1][col+1]==0){
-								// class_val+=1;
-				Segment_put(&globals->rid_seg, &class_val, row, col);
-				px_count+=1;
-			else if(first_change == 0 && indicator_matrix[row][col]==0){
-				first_change = 1;
-				stop_col = col;
-				stop_row = row;
+			if (Rin.mean[i]<min)
+				min = Rin.mean[i];
+			if (Rin.mean[i]>max)
+				max = Rin.mean[i];
-	return TRUE;
+	rng[i] = max - min;
+	maxdiff += rng[i] * rng[i];
+	prev_in[i] = (DCELL *) G_malloc(len);
+	cur_in[i] = (DCELL *) G_malloc(len);
-int clustering(struct globals *globals){
-	int row, col, n3, nin;
-	int diag;/* if using diag pixel */
-	int class_val;
-	struct ngbr_stats Rin, Rleft, Rabove;
-	CELL seg_id, left_new_val, above_new_val, *temp_clump;
-	CELL old_val, new_val;
-	double cluster_threshold, cluster_threshold2;
-    *             Part 2 cluster similar values            *
-    *         Refer clump.c to cluster super-pixels        *
-	Rleft.mean = G_malloc(globals->datasize);
-	Rin.mean = G_malloc(globals->datasize);
-	Rabove.mean = G_malloc(globals->datasize);
+	/* fake a previous row which is all NULL */
+	Rast_set_d_null_value(prev_in[i], ncols + 2);
-	G_percent_reset();
-	nin = globals->nbands;
-	diag=0;
-	class_val=0;
-	for (row = globals->row_min; row < globals->row_max; row++) {
-	    for (col = globals->col_min; col < globals->col_max; col++) {
-			if (!(FLAG_GET(globals->candidate_flag, row, col)))
-				continue;
-			old_val=new_val=0;
-			/* get the current pixel value */
+	/* set left and right edge to NULL */
+	Rast_set_d_null_value(&cur_in[i][0], 1);
+	Rast_set_d_null_value(&cur_in[i][ncols + 1], 1);
+    G_debug(1, "maximum possible difference: %g", maxdiff);
+    /* allocate CELL buffers two columns larger than current window */
+    len = (ncols + 2) * sizeof(CELL);
+    prev_clump = (CELL *) G_malloc(len);
+    cur_clump = (CELL *) G_malloc(len);
+    out_cell = (CELL *) G_malloc(len);
+    /* temp file for initial clump IDs */
+    cname = G_tempfile();
+    if ((cfd = open(cname, O_RDWR | O_CREAT | O_EXCL, 0600)) < 0)
+	G_fatal_error(_("Unable to open temp file"));
+    csize = ncols * sizeof(CELL);
+    /* initialize clump labels */
+    G_zero(cur_clump, len);
+    G_zero(prev_clump, len);
+    label = 0;
+     *                      PASS 1                      *
+     * pass thru the input, create initial clump labels *
+    G_message(_("Pass 1 of 2..."));
+    for (row = 0; row < nrows; row++) {
+	G_percent(row, nrows, 2);
+		for (col = 0; col < ncols; col++){
-			/* get left pixel value if not the first col*/
-			if(col != globals->col_min){
-			Segment_get(globals->bands_out, (void *)Rleft.mean, row, (col-1));
+				cur_in[i][col+1] = Rin.mean[i];
-			/* get above pixel value if not the first row*/
-			if(row != globals->row_min){
-			Segment_get(&globals->bands_seg2, (void *)Rabove.mean, row-1, col);
+	for (col = 1; col <= ncols; col++) {
+	    isnull = 0;
+		if (Rast_is_d_null_value(&cur_in[i][col])) {	/* don't clump NULL data */
+		    cur_clump[col] = 0;
+		    isnull = 1;
+		    break;
+	    if (isnull)
+		continue;
+	     * if the cell values are different to the left and above
+	     * (diagonal: and above left and above right)
+	     * then we must start a new clump
+	     * this new clump may eventually collide with another
+	     * clump and will have to be merged
+	    /* try to connect the current cell to an existing clump */
+	    OLD = NEW = 0;
+	    /* same clump as to the left */
+	    if (cmp_cells(cur_in, col, cur_in, col - 1, rng, nin, thresh2)) {
+		OLD = cur_clump[col] = cur_clump[col - 1];
+	    if (diag) {
+		/* check above right, center, left, in that order */
+		temp_clump = prev_clump + col + 1;
+		bcol = col + 1;
+		do {
+		    if (cmp_cells(cur_in, col, prev_in, bcol, rng, nin, thresh2)) {
+			cur_clump[col] = *temp_clump;
+			if (OLD == 0) {
+			    OLD = *temp_clump;
-			if (col == globals->col_min && row == globals->row_min){
-			class_val+=1;
-			seg_id=class_val;
-			else if (row == globals->row_min){
-			/* compare with left value and set if same cluster */
-			Segment_get(&globals->bands_seg2, (void *)Rleft.mean, row, col-1);
-			if ((globals->calculate_similarity)(&Rin, &Rleft, globals) <= cluster_threshold2){
-				G_debug(1, "row: %d, col: %d, left_similarity is: %f",row,col,(globals->calculate_similarity)(&Rin, &Rleft, globals));
-				Segment_get(&globals->rid_seg, (void *)&left_new_val, row, col-1);
-				seg_id = left_new_val;
-			/* end compare left */
-			else{
-				class_val+=1;
-				seg_id=class_val;
-			else if(col == globals->col_min){
-			/* compare with above value and set if same cluster */
-			if ((globals->calculate_similarity)(&Rin, &Rabove, globals) <= cluster_threshold2){
-				G_debug(1, "row: %d, col: %d, above_similarity is: %f",row,col,(globals->calculate_similarity)(&Rin, &Rabove, globals));
-				Segment_get(&globals->rid_seg, (void *)&above_new_val, row-1, col);
-				seg_id = above_new_val;
-			/* end compare above */
-			else{
-				class_val+=1;
-				seg_id=class_val;
-			else{
-				old_val=seg_id = left_new_val;
-				// G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, compare to left"),row,col,old_val,new_val);
-			if(diag){
-				// /* check above right, center, left, in that order */
-			else{
-					temp_clump = &above_new_val;
-					seg_id = *temp_clump;
-					// G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, compare to above"),row,col,old_val,new_val);
-					if (old_val==0){
-						old_val = *temp_clump;
-					else{
-					new_val = *temp_clump;
-					if(new_val != old_val){
-						/* conflict! preserve NEW clump ID and change OLD clump ID.
-					* Must go back to the left in the current row and to the right
-					* in the previous row to change all the clump values as well.
-					// G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, conflict"),row,col,old_val,new_val);
-					/* left of the current row from 1 to col - 1 */
-					for(n3 = globals->col_min+1; n3< col; n3++){
-						Segment_get(&globals->rid_seg, (void *)temp_clump, row, n3);
-						if (*temp_clump==old_val){
-							Segment_put(&globals->rid_seg, &new_val, row, n3);
-					// /* right of previous row from col + 1 to ncols */
-					for(n3 = col+1; n3< globals->col_max; n3++){
-						Segment_get(&globals->rid_seg, (void *)temp_clump, row-1, n3);
-							Segment_put(&globals->rid_seg, &new_val, row-1, n3);
+			else {
+			    NEW = *temp_clump;
+			    /* threshold > 0 and diagonal requires a bit of extra work
+			     * because of bridge cells:
+			     * A similar to B, B similar to C, but A not similar to C
+			     * -> B is bridge cell */
+			    if (NEW != OLD) {
+				CELL *temp_clump2;
+				/* conflict! preserve NEW clump ID and change OLD clump ID.
+				 * Must go back to the left in the current row and to the right
+				 * in the previous row to change all the clump values as well.
+				/* left of the current row from 1 to col - 1 */
+				temp_clump2 = cur_clump;
+				n = col - 1;
+				while (n-- > 0) {
+				    temp_clump2++;	/* skip left edge */
+				    if (*temp_clump2 == OLD)
+					*temp_clump2 = NEW;
+				/* (drive left, change all old to new)yb_note*/
+				/* right of previous row from col - 1 to ncols */
+				temp_clump2 = prev_clump + col - 1;
+				n = ncols - col + 2;
+				while (n-- > 0) {
+				    temp_clump2++;
+				/* modify the OLD index */
+				index[OLD] = NEW;
+				OLD = NEW;
+				NEW = 0;
-			if (new_val = 0 || old_val == new_val){
-				if (old_val ==0){
-					class_val+=1;
-					seg_id = class_val;
-					// G_message(_("row: %d, col: %d, oldval is: %d, newval is: %d, class++"),row,col,old_val,new_val);
+		    temp_clump--;
+		} while (bcol-- > col - 1);
+	    else {
+		/* check above */
+		if (cmp_cells(cur_in, col, prev_in, col, rng, nin, thresh2)) {
+		    temp_clump = prev_clump + col;
+		    if (OLD == 0) {
+		    else {
+			if (NEW != OLD) {
+			    temp_clump = cur_clump;
+			    n = col - 1;
+			    while (n-- > 0) {
+				temp_clump++;	/* skip left edge */
+				if (*temp_clump == OLD)
+				    *temp_clump = NEW;
+			    /* right of previous row from col + 1 to ncols */
+			    n = ncols - col;
+			    while (n-- > 0) {
+				temp_clump++;	/* skip col */
+			    index[OLD] = NEW;
+			    OLD = NEW;
+			    NEW = 0;
-		Segment_put(&globals->rid_seg, &seg_id, row, col);
+	    if (NEW == 0 || OLD == NEW) {	/* ok */
+		if (OLD == 0) {
+		    /* start a new clump */
+		    label++;
+		    cur_clump[col] = label;
+		    if (label >= nalloc) {
+			nalloc += INCR;
+			index =
+			    (CELL *) G_realloc(index,
+					       nalloc * sizeof(CELL));
+		    index[label] = label;
+	    /* else the relabelling above failed */
-	return TRUE;
+	/* write initial clump IDs */
+	/* this works also with writing out cur_clump, but only
+	 * prev_clump is complete and will not change any more */
+	if (row > 0) {
+	    if (write(cfd, prev_clump + 1, csize) != csize)
+		G_fatal_error(_("Unable to write to temp file"));
+	/* switch the buffers so that the current buffer becomes the previous */
+	temp_in = cur_in;
+	cur_in = prev_in;
+	prev_in = temp_in;
+	cur_clump = prev_clump;
+	prev_clump = temp_clump;
+    /* write last row with initial clump IDs */
+    G_percent(1, 1, 1);
+    /* generate a renumbering scheme */
+    G_message(_("Generating renumbering scheme..."));
+    G_debug(1, "%d initial labels", label);
+    /* allocate final clump ID */
+    renumber = (CELL *) G_malloc((label + 1) * sizeof(CELL));
+    renumber[0] = 0;
+    cat = 1;
+    G_percent(0, label, 1);
+    for (n = 1; n <= label; n++) {
+	G_percent(n, label, 1);
+	OLD = n;
+	NEW = index[n];
+	if (OLD != NEW) {
+	    renumber[n] = 0;
+	    /* find valid clump ID */
+	    while (OLD != NEW) {
+		OLD = NEW;
+		NEW = index[OLD];
+		if (NEW == n)
+		    G_fatal_error("Circular relabelling for %d", n);
+	    index[n] = NEW;
+	else
+	    /* set final clump id */
+	    renumber[n] = cat++;
+    /* rewind temp file */
+    lseek(cfd, 0, SEEK_SET);
+	 *                      PASS 2                      *
+	 * apply renumbering scheme to initial clump labels *
+	/* the input raster is no longer needed,
+	 * using instead the temp file with initial clump labels */
+	G_message(_("Pass 2 of 2..."));
+	    if (read(cfd, cur_clump, csize) != csize)
+		G_fatal_error(_("Unable to read from temp file"));
+	    out_cellp = out_cell;
+	    for (col = 0; col < ncols; col++) {
+		*out_cellp = renumber[index[*temp_clump]];
+		if (*out_cellp == 0)
+		    Rast_set_c_null_value(out_cellp, 1);
+		temp_clump++;
+		out_cellp++;
+			Segment_put(&globals->rid_seg, &out_cell[col], row, col);
+    close(cfd);
+    unlink(cname);
+    return TRUE;
 int mean_shift(struct globals *globals)
     int row, col, t, n1, n2;
@@ -417,7 +568,7 @@
 	G_message(_("Mean shift converged after %d iterations"), t);
-	if (clustering(globals) != TRUE)
+	if (clump(globals) != TRUE)
 	G_fatal_error(_("Error in clustering segments"));
     *         Part 3 identify connected components         *
