[GRASS-SVN] r68822 - in grass/branches/releasebranch_7_0: display/d.vect.thematic imagery/i.segment include/iostream lib/gmath lib/vector lib/vector/Vlib lib/vector/dglib raster/r.out.pov vector
Thu Jun 30 15:19:03 PDT 2016
Author: martinl
Date: 2016-06-30 15:19:03 -0700 (Thu, 30 Jun 2016)
New Revision: 68822
   grass/branches/releasebranch_7_0/display/d.vect.thematic/d.vect.thematic.html
   grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
   grass/branches/releasebranch_7_0/include/iostream/embuffer.h
   grass/branches/releasebranch_7_0/lib/gmath/blas_level_3.c
   grass/branches/releasebranch_7_0/lib/vector/Vlib/area.c
   grass/branches/releasebranch_7_0/lib/vector/dglib/BUGS
   grass/branches/releasebranch_7_0/lib/vector/vectorlib_topology.dox
   grass/branches/releasebranch_7_0/raster/r.out.pov/r.out.pov.html
   grass/branches/releasebranch_7_0/vector/vectorintro.html
Patch to fix various spelling errors (closes #3088)
Modified: grass/branches/releasebranch_7_0/display/d.vect.thematic/d.vect.thematic.html
--- grass/branches/releasebranch_7_0/display/d.vect.thematic/d.vect.thematic.html	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/display/d.vect.thematic/d.vect.thematic.html	2016-06-30 22:19:03 UTC (rev 68822)
@@ -24,7 +24,7 @@
 The <b>-l</b> flag instructs the module to print legend information
 (<i>class min | class max | number of observations in class |
-color</i>) to standard output for futher use in graphical software.
+color</i>) to standard output for further use in graphical software.
 When combined with the <b>-e</b> flag, the legend information will
 be extended with some additional statistical information. If the
 <b>-n</b> flag is set, the module will only print the legend
Modified: grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html
--- grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/imagery/i.segment/i.segment.html	2016-06-30 22:19:03 UTC (rev 68822)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
 Image segmentation or object recognition is the process of grouping
-similar pixels into unique segments, also refered to as objects.
+similar pixels into unique segments, also referred to as objects.
 Boundary and region based algorithms are described in the literature,
 currently a region growing and merging algorithm is implemented. Each
 object found during the segmentation process is given a unique ID and
@@ -46,7 +46,7 @@
 threshold of 1 would allow everything to be merged. Initial empirical
 tests indicate threshold values of 0.01 to 0.05 are reasonable values
 to start. It is recommended to start with a low value, e.g. 0.01, and
-then perform hierachical segmentation by using the output of the last
+then perform hierarchical segmentation by using the output of the last
 run as <b>seeds</b> for the next run.
 <h4>Calculation Formulas</h4>
Modified: grass/branches/releasebranch_7_0/include/iostream/embuffer.h
--- grass/branches/releasebranch_7_0/include/iostream/embuffer.h	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/include/iostream/embuffer.h	2016-06-30 22:19:03 UTC (rev 68822)
@@ -232,7 +232,7 @@
   //stream_len() on the stream, but it is more costly esp in the case
   //when streams are on disk and must be moved in and out just to find
   //stream length; streamsize is set only at stream creation, and the
-  //actual size must substract the number of iteme deleted from the
+  //actual size must subtract the number of iteme deleted from the
   //bos
   unsigned long* streamsize;
Modified: grass/branches/releasebranch_7_0/lib/gmath/blas_level_3.c
--- grass/branches/releasebranch_7_0/lib/gmath/blas_level_3.c	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/lib/gmath/blas_level_3.c	2016-06-30 22:19:03 UTC (rev 68822)
@@ -32,7 +32,7 @@
  * In case B == NULL, matrix A will be scaled by scalar a. \n
  * In case a == 1.0, a simple matrix addition is performed. \n
- * In case a == -1.0 matrix A is substracted from matrix B. \n
+ * In case a == -1.0 matrix A is subtracted from matrix B. \n
  * The result is written into matrix C.
@@ -93,7 +93,7 @@
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/area.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/area.c	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/area.c	2016-06-30 22:19:03 UTC (rev 68822)
@@ -397,7 +397,7 @@
     Vect_line_prune(Points);
     size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
-    /* substracting island areas */
+    /* subtracting island areas */
     for (i = 0; i < Area->n_isles; i++) {
 	Vect_get_isle_points(Map, Area->isles[i], Points);
Modified: grass/branches/releasebranch_7_0/lib/vector/dglib/BUGS
--- grass/branches/releasebranch_7_0/lib/vector/dglib/BUGS	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/lib/vector/dglib/BUGS	2016-06-30 22:19:03 UTC (rev 68822)
@@ -1,4 +1,4 @@
-Do not change bug numbers, these numbers are refered in Vlib/net.c
+Do not change bug numbers, these numbers are referred in Vlib/net.c
 BUG1 (24.2.2003):
 Cache for SP does not work properly. For examle:
Modified: grass/branches/releasebranch_7_0/lib/vector/vectorlib_topology.dox
--- grass/branches/releasebranch_7_0/lib/vector/vectorlib_topology.dox	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/lib/vector/vectorlib_topology.dox	2016-06-30 22:19:03 UTC (rev 68822)
@@ -400,7 +400,7 @@
 In GRASS, whenever an 'inner' ring does not touch the boundary of an
 outside area, also not in one point, it is an 'inner' ring (isle). The
 areas A2 and A3 form a single isle I1 located within area A1. The size
-of isle I1 is substracted from the size of area A1 when calculating
+of isle I1 is subtracted from the size of area A1 when calculating
 the size of area A1. Any centroids falling into isle I1 are excluded
 when searching for a centroid that can be attached to area A1. A1
 above can be exported from GRASS as polygon A1 with inner ring I1.
Modified: grass/branches/releasebranch_7_0/raster/r.out.pov/r.out.pov.html
--- grass/branches/releasebranch_7_0/raster/r.out.pov/r.out.pov.html	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/raster/r.out.pov/r.out.pov.html	2016-06-30 22:19:03 UTC (rev 68822)
@@ -5,7 +5,7 @@
 value is either 0 or 1) specifies the height-field type. When the user
 enters 0 the output will be actual heights. If entered 1 the cell-values
 will be normalized. If hftype is 0 (actual heights) the bias==value can
-be used to add or substract a value from heights. Use scale==value to scale
+be used to add or subtract a value from heights. Use scale==value to scale
 your heights by value. The GRASS program r.out.pov can be used to create
 height- field files for Persistence of Vision (POV) raytracer. POV can
 use a height-field defined in Targa (.TGA) image file format where the
Modified: grass/branches/releasebranch_7_0/vector/vectorintro.html
--- grass/branches/releasebranch_7_0/vector/vectorintro.html	2016-06-30 22:17:58 UTC (rev 68821)
+++ grass/branches/releasebranch_7_0/vector/vectorintro.html	2016-06-30 22:19:03 UTC (rev 68822)
@@ -67,7 +67,7 @@
 areas.  Topological representation of vector data helps to produce and
 maintain vector maps with clean geometry as well as enables certain
 analyses that can not be conducted with non-topological or spaghetti
-data. In GRASS, topological data are refered to as level 2 data and
+data. In GRASS, topological data are referred to as level 2 data and
 spaghetti data is referred to as level 1.
 <p>
 Sometimes topology is not necessary and the additional memory and
