[GRASS-SVN] r67991 - grass/trunk/lib/vector/neta
Thu Mar 3 13:12:15 PST 2016
Author: mmetz
Date: 2016-03-03 13:12:15 -0800 (Thu, 03 Mar 2016)
New Revision: 67991
   grass/trunk/lib/vector/neta/utils.c
netalib, utils.c: fix cost multiplier, update documentation
Modified: grass/trunk/lib/vector/neta/utils.c
--- grass/trunk/lib/vector/neta/utils.c	2016-03-03 20:44:45 UTC (rev 67990)
+++ grass/trunk/lib/vector/neta/utils.c	2016-03-03 21:12:15 UTC (rev 67991)
@@ -1,5 +1,5 @@
-   \file vector/neta/timetables.c
+   \file vector/neta/utils.c
    \brief Network Analysis library - utils
@@ -91,8 +91,8 @@
    the array node_costs. If there is no point with a category,
    node_costs=0.
-   node_costs are multiplied by 1000000 and truncated to integers (as
-   is done in Vect_net_build_graph)
+   node_costs are multiplied by the graph's cost multiplier and
+   truncated to integers (as is done in Vect_net_build_graph)
    \param In pointer to Map_info structure
    \param layer layer number
@@ -142,7 +142,7 @@
 		continue;
 	    Vect_get_line_nodes(In, i, &node, NULL);
 	    if (db_CatValArray_get_value_double(&vals, cat, &value) == DB_OK)
-		node_costs[node] = value * 1000000.0;
+		node_costs[node] = value * In->dgraph.cost_multip;
@@ -159,12 +159,13 @@
    nodes_to_features conains the index of a feature adjecent to each
    node or -1 if no such feature specified by varray
    exists. Nodes_to_features might be NULL, in which case it is left
-   unitialised.
+   unitialised. Nodes_to_features will be wrong if several lines connect
+   to the same node.
    \param map pointer to Map_info structure
    \param varray pointer to varray structure
    \param[out] nodes list of node ids
-   \param node_to_features ?
+   \param[out] nodes_to_features maps nodes to features
 void NetA_varray_to_nodes(struct Map_info *map, struct varray *varray,
 			  struct ilist *nodes, int *nodes_to_features)
